;	RCS Header $Id: fp24.a16 2.7 1996/10/07 13:50:29 F.J.Testa Exp $
;	$Revision: 2.7 $
;       PIC16 24 BIT FLOATING POINT LIBRARY
;       Unary operations: both input and output are in AEXP,AARG
;       Binary operations: input in AEXP,AARG and BEXP,BARG with output in AEXP,AARG
;       All routines return WREG = 0x00 for successful completion, and WREG = 0xFF
;       for an error condition specified in FPFLAGS.
;       All timings are worst case cycle counts
;         Routine               Function
;       FLO1624 16 bit integer to 24 bit floating point conversion
;       FLO24
;               Timing:            RND
;                               0       1
;                       0       83      83
;                  SAT
;                       1       88      88
;       NRM2424         24 bit normalization of unnormalized 24 bit floating point numbers
;       NRM24
;               Timing:            RND
;                               0       1
;                       0       72      72
;                  SAT
;                       1       77      77
;       INT2416         24 bit floating point to 16 bit integer conversion
;       INT24
;               Timing:            RND
;                               0       1
;                       0       83      89
;                  SAT
;                       1       83      92
;       FLO2424         24 bit integer to 24 bit floating point conversion
;               Timing:            RND
;                               0       1
;                       0       108     117
;                  SAT
;                       1       108     123
;       NRM3224   32 bit normalization of unnormalized 24 bit floating point numbers
;               Timing:            RND
;                               0       1
;                       0       94      103
;                  SAT
;                       1       94      109
;       INT2424         24 bit floating point to 24 bit integer conversion
;               Timing:            RND
;                               0       1
;                       0       105      113
;                  SAT
;                       1       105      115
;       FPA24           24 bit floating point add
;               Timing:            RND
;                               0       1
;                       0       197     208
;                  SAT
;                       1       197     213
;       FPS24           24 bit floating point subtract
;               Timing:            RND
;                               0       1
;                       0       199     240
;                  SAT
;                       1       199     215
;       FPM24           24 bit floating point multiply
;               Timing:            RND
;                               0       1
;                       0       298     309
;                  SAT
;                       1       298     313
;       FPD24           24 bit floating point divide
;               Timing:            RND
;                               0       1
;                       0       472     494
;                  SAT
;                       1       472     498
;       24 bit floating point representation
;       EXPONENT        8 bit biased exponent
;                       It is important to note that the use of biased exponents produces
;                       a unique representation of a floating point 0, given by
;                       EXP = HIGHBYTE = LOWBYTE = 0x00, with 0 being the only
;                       number with EXP = 0.
;       HIGHBYTE        8 bit most significant byte of fraction in sign-magnitude representation,
;                       with SIGN = MSB, implicit MSB = 1 and radix point to the right of MSB
;       LOWBYTE         8 bit least significant byte of sign-magnitude fraction
;       EXPONENT        HIGHBYTE        LOWBYTE
;       xxxxxxxx        S.xxxxxxx       xxxxxxxx
;                      RADIX
;                      POINT
;       Normalization routine
;       Input:  24 bit unnormalized floating point number in AEXP, AARGB0, AARGB1,
;               with sign in SIGN,MSB and other bits zero.
;       Use:    CALL    NRM2424 or      CALL    NRM24
;       Output: 24 bit normalized floating point number in AEXP, AARGB0, AARGB1
;       Result: AARG  <--  NORMALIZE( AARG )
;       Max Timing:     10+6+7*7+7 = 72 clks            SAT = 0
;                       10+6+7*7+1+11 = 77 clks SAT = 1
;       Min Timing:     14 clks                         AARG = 0
;                       5+9+4 = 18 clks
;       PM: 26                                          DM: 6
NRM2424
NRM24
		CLRF            TEMP			; clear exponent decrement
                MOVF            AARGB0,W		; test if highbyte=0
                BTFSS           _Z
                GOTO            NORM2424
                MOVF            AARGB1,W		; if so, shift 8 bits by move
                MOVWF           AARGB0
                BTFSC           _Z			; if highbyte=0, result=0
                GOTO            RES024
                CLRF            AARGB1
                BSF             TEMP,3
NORM2424        MOVF            TEMP,W
                SUBWF           EXP,F
                BTFSS           _Z
                BTFSS           _C
                GOTO            SETFUN24
                BCF             _C			; clear carry bit
NORM2424A       BTFSC           AARGB0,MSB		; if MSB=1, normalization done
                GOTO            FIXSIGN24
                RLF             AARGB1,F		; otherwise, shift left and 
                RLF             AARGB0,F		; decrement EXP
                DECFSZ          EXP,F
                GOTO            NORM2424A
                GOTO            SETFUN24                ; underflow if EXP=0
FIXSIGN24       BTFSS           SIGN,MSB
                BCF             AARGB0,MSB		; clear explicit MSB if positive
                RETLW           0
RES024          CLRF            AARGB0			; result equals zero
                CLRF            AARGB1
		CLRF		AARGB2			; clear extended byte
                CLRF            EXP
                RETLW           0
;       Integer to float conversion
;       Input:  24 bit 2's complement integer right justified in AARGB0, AARGB1, AARGB2
;       Use:    CALL    FLO2424
;       Output: 24 bit floating point number in AEXP, AARGB0, AARGB1
;       Result: AARG  <--  FLOAT( AARG )
;       Max Timing:     14+94 = 108 clks                RND = 0
;                       14+103 = 117 clks               RND = 1, SAT = 0
;                       14+109 = 123 clks               RND = 1, SAT = 1
;       Min Timing:     6+28 = 34 clks                  AARG = 0
;                       6+22 = 28 clks
;       PM: 14+51 = 65                                  DM: 7
FLO2424         MOVLW           D'23'+EXPBIAS		; initialize exponent and add bias
                MOVWF           EXP
                CLRF            SIGN
                BTFSS           AARGB0,MSB		; test sign
                GOTO            NRM3224
                COMF            AARGB2,F		; if < 0, negate and set MSB in SIGN
                COMF            AARGB1,F
                COMF            AARGB0,F
                INCF            AARGB2,F
                BTFSC           _Z
                INCF            AARGB1,F
                BTFSC           _Z
                INCF            AARGB0,F
                BSF             SIGN,MSB
;       Input:  32 bit unnormalized floating point number in AEXP, AARGB0, AARGB1,
;               AARGB2, with sign in SIGN,MSB
;       Use:    CALL    NRM3224
;       Max Timing:     21+6+7*8+7+4 = 94 clks  RND = 0
;                       21+6+7*8+20+4 = 103 clks        RND = 1, SAT = 0
;                       21+6+7*8+19+11 = 109 clks       RND = 1, SAT = 1
;       Min Timing:     22+6 = 28 clks                  AARG = 0
;                       5+9+4+4 = 22 clks
;       PM: 51                                          DM: 7
NRM3224         CLRF            TEMP                    ; clear exponent decrement
                BTFSS           _Z
                GOTO            NORM3224
                MOVWF           AARGB0
                MOVF            AARGB2,W
                MOVWF           AARGB1
                CLRF            AARGB2
                BSF             TEMP,3                  ; increase decrement by 8
                BTFSS           _Z
                GOTO            NORM3224
                MOVWF           AARGB0
                CLRF            AARGB1
                BCF             TEMP,3                  ; increase decrement by 8
                BSF             TEMP,4
                MOVF            AARGB0,W		; if highbyte=0, result=0
                BTFSC           _Z
                GOTO            RES024
NORM3224        MOVF            TEMP,W
                SUBWF           EXP,F
                BTFSS           _Z
                BTFSS           _C
                GOTO            SETFUN24
NORM3224A       BTFSC           AARGB0,MSB		; if MSB=1, normalization done
                GOTO            NRMRND3224
                RLF             AARGB2,F		; otherwise, shift left and 
                RLF             AARGB1,F		; decrement EXP
                RLF             AARGB0,F
                DECFSZ          EXP,F
                GOTO            NORM3224A
NRMRND3224      BTFSC           FPFLAGS,RND
                BTFSS           AARGB1,LSB
                GOTO            FIXSIGN24
		BTFSS		AARGB2,MSB		; round if next bit is set
                GOTO            FIXSIGN24
		INCF		AARGB1,F
                BTFSC           _Z
                INCF            AARGB0,F
                BTFSS           _Z                     ; has rounding caused carryout?
                GOTO            FIXSIGN24
                RRF             AARGB0,F		; if so, right shift
                RRF             AARGB1,F
                INCF            EXP,F
                BTFSC           _Z                     ; check for overflow
                GOTO            SETFOV24
                GOTO            FIXSIGN24
;       Float to integer conversion
;       Input:  24 bit floating point number in AEXP, AARGB0, AARGB1
;       Use:    CALL    INT2424
;       Output: 24 bit 2's complement integer right justified in AARGB0, AARGB1, AARGB2
;       Result: AARG  <--  INT( AARG )
;       Max Timing:     41+6*7+6+16 = 105 clks		RND = 0
;                       41+6*7+6+24 = 113 clks		RND = 1, SAT = 0
;                       41+6*7+6+26 = 115 clks  	RND = 1, SAT = 1
;       Min Timing:     5 clks
;       PM: 82                                          DM: 6
INT2424
                CLRF            AARGB2
		MOVF		EXP,W			; test for zero argument
		BTFSC		_Z
		RETLW		0x00
		MOVF            AARGB0,W		; save sign in SIGN
                MOVWF           SIGN
                BSF             AARGB0,MSB		; make MSB explicit
                MOVLW           EXPBIAS+D'23'		; remove bias from EXP
                SUBWF           EXP,F
                BTFSS           EXP,MSB
                GOTO            SETIOV24        
		COMF		EXP,F
		INCF		EXP,F        
                MOVLW           8                       ; do byte shift if EXP >= 8
                SUBWF           EXP,W
                BTFSS           _C
                GOTO            TSHIFT2424
                MOVWF           EXP
                RLF             AARGB2,F		; rotate next bit for rounding
                MOVF            AARGB1,W
                MOVWF           AARGB2
                MOVF            AARGB0,W
                MOVWF           AARGB1
                CLRF            AARGB0
                MOVLW           8                       ; do another byte shift if EXP >= 8
                SUBWF           EXP,W
                BTFSS           _C
                GOTO            TSHIFT2424
                MOVWF           EXP
                MOVF            AARGB1,W
                MOVWF           AARGB2
                CLRF            AARGB1
                SUBWF           EXP,W
                BTFSS           _C
                GOTO            TSHIFT2424
                MOVWF           EXP
                CLRF            AARGB2
		MOVF		EXP,W
		BTFSS		_Z
		BCF		_C
		GOTO		SHIFT2424OK
TSHIFT2424      MOVF            EXP,W                   ; shift completed if EXP = 0
                BTFSC           _Z
                GOTO            SHIFT2424OK
SHIFT2424       BCF             _C
                RRF             AARGB0,F		; right shift by EXP
                RRF             AARGB1,F
                RRF             AARGB2,F
                DECFSZ          EXP,F
                GOTO            SHIFT2424
SHIFT2424OK     BTFSC           FPFLAGS,RND
                BTFSS           AARGB2,LSB
                GOTO            INT2424OK
                BTFSS           _C
                GOTO            INT2424OK
                INCF            AARGB2,F
                BTFSC           _Z
                INCF            AARGB1,F
                BTFSC           _Z
                INCF            AARGB0,F
                BTFSC           AARGB0,MSB		; test for overflow
                GOTO            SETIOV24
INT2424OK       BTFSS           SIGN,MSB                ; if sign bit set, negate               
                RETLW           0
                COMF            AARGB0,F
                COMF            AARGB1,F
                COMF            AARGB2,F
                INCF            AARGB2,F
                BTFSC           _Z
                INCF            AARGB1,F
                BTFSC           _Z
                INCF            AARGB0,F
                RETLW           0
IRES024         CLRF            AARGB0			; integer result equals zero
                CLRF            AARGB1
                CLRF            AARGB2
                RETLW           0
SETIOV24        BSF             FPFLAGS,IOV             ; set integer overflow flag
                BTFSS           FPFLAGS,SAT             ; test for saturation
                RETLW           0xFF                    ; return error code in WREG
                CLRF            AARGB0			; saturate to largest two's
                BTFSS           SIGN,MSB                ; complement 24 bit integer
                MOVLW           0xFF
                MOVWF           AARGB0			; SIGN = 0, 0x 7F FF FF
                MOVWF           AARGB1			; SIGN = 1, 0x 80 00 00
                MOVWF           AARGB2
                RLF             SIGN,F
                RRF             AARGB0,F
;       Floating Point Multiply
;               24 bit floating point number in BEXP, BARGB0, BARGB1
;       Use:    CALL    FPM24
;       Output: 24 bit floating point product in AEXP, AARGB0, AARGB1
;       Result: AARG  <--  AARG * BARG
;       Max Timing:     25+15*16+15+18 = 298 clks       RND = 0
;                       25+15*16+15+29 = 309 clks       RND = 1, SAT = 0
;                       25+15*16+15+33 = 313 clks       RND = 1, SAT = 1
;       Min Timing:     6+5 = 11 clks                   AARG * BARG = 0
;                       24+15*11+14+15 = 218 clks
;       PM: 80                                  DM: 11
FPM24           MOVF            AEXP,W                  ; test for zero arguments
                BTFSS           _Z
                MOVF            BEXP,W
                BTFSC           _Z
                GOTO            RES024
M24BNE0         MOVF            AARGB0,W
                XORWF           BARGB0,W
                MOVWF           SIGN                    ; save sign in SIGN
                MOVF            BEXP,W
                ADDWF           EXP,F
                MOVLW           EXPBIAS-1
                BTFSS           _C
                GOTO            MTUN24
                SUBWF           EXP,F
                BTFSC           _C
                GOTO            SETFOV24                ; set multiply overflow flag
                GOTO            MOK24
MTUN24          SUBWF           EXP,F
                BTFSS           _C
                GOTO            SETFUN24
MOK24
                MOVF            AARGB0,W
                MOVWF           AARGB2			; move result to AARG
                MOVF            AARGB1,W
                MOVWF           AARGB3
		BSF             AARGB2,MSB		; make argument MSB's explicit
                BSF             BARGB0,MSB
                BCF             _C
                CLRF            AARGB0			; clear initial partial product
                CLRF            AARGB1
                MOVLW           D'16'
                MOVWF           TEMP                    ; initialize counter
MLOOP24         BTFSS           AARGB3,LSB		; test next bit
                GOTO            MNOADD24
MADD24          MOVF            BARGB1,W
                ADDWF           AARGB1,F
                MOVF            BARGB0,W
                BTFSC           _C
                INCFSZ          BARGB0,W
                ADDWF           AARGB0,F
MNOADD24        RRF             AARGB0,F
                RRF             AARGB1,F
                RRF             AARGB2,F
                RRF             AARGB3,F
                BCF             _C
                DECFSZ          TEMP,F
                GOTO            MLOOP24
                BTFSC           AARGB0,MSB		; check for postnormalization
                GOTO            MROUND24
                RLF             AARGB2,F
                RLF             AARGB1,F
                RLF             AARGB0,F
                DECF            EXP,F
MROUND24        BTFSC           FPFLAGS,RND
                BTFSS           AARGB1,LSB
                GOTO            MUL24OK
                GOTO            MUL24OK
		INCF		AARGB1,F
                BTFSC           _Z
                INCF            AARGB0,F
                GOTO            MUL24OK
                RRF             AARGB1,F
                INCF            EXP,F
                GOTO            SETFOV24
MUL24OK         BTFSS           SIGN,MSB
                RETLW           0  
SETFOV24        BSF             FPFLAGS,FOV             ; set floating point underflag
                MOVLW           0xFF
                MOVWF           AEXP                    ; saturate to largest floating
                MOVWF           AARGB0			; point number = 0x FF 7F FF
                MOVWF           AARGB1			; modulo the appropriate sign bit
                RLF             SIGN,F
                RRF             AARGB0,F
;       Floating Point Divide
;       Input:  24 bit floating point dividend in AEXP, AARGB0, AARGB1
;               24 bit floating point divisor in BEXP, BARGB0, BARGB1
;       Use:    CALL    FPD24
;       Output: 24 bit floating point quotient in AEXP, AARGB0, AARGB1
;       Result: AARG  <--  AARG / BARG
;       Max Timing:     32+13+15*26+25+12 = 472 clks    RND = 0
;                       32+13+15*26+25+34 = 494 clks    RND = 1, SAT = 0
;                       32+13+15*26+25+38 = 498 clks    RND = 1, SAT = 1
;       Min Timing:     7+5 = 12 clks
;       PM: 120                                 DM: 11
FPD24           MOVF            BEXP,W                  ; test for divide by zero
                BTFSC           _Z
                GOTO            SETFDZ24
                MOVF            AEXP,W
                BTFSC           _Z
                GOTO            RES024
D24BNE0         MOVF            AARGB0,W
                XORWF           BARGB0,W
                BSF             AARGB0,MSB		; make argument MSB's explicit
                BSF             BARGB0,MSB
TALIGN24        CLRF            TEMP                    ; clear align increment
                MOVF            AARGB0,W
                MOVWF           AARGB2			; test for alignment
                MOVF            AARGB1,W
                MOVWF           AARGB3
                MOVF            BARGB1,W
                SUBWF           AARGB3, f
                MOVF            BARGB0,W
                BTFSS           _C
                INCFSZ          BARGB0,W
                SUBWF           AARGB2, f
                CLRF            AARGB2
                CLRF            AARGB3
                BTFSS           _C
                GOTO            DALIGN24OK
                BCF             _C                      ; align if necessary
                RRF             AARGB0,F
                RRF             AARGB1,F
                RRF             AARGB2,F
                MOVLW           0x01
                MOVWF           TEMP                    ; save align increment          
DALIGN24OK      MOVF            BEXP,W                  ; compare AEXP and BEXP
                SUBWF           EXP,F
                BTFSS           _C
                GOTO            ALTB24
AGEB24          MOVLW           EXPBIAS-1
                ADDWF           TEMP,W
                ADDWF           EXP,F
                BTFSC           _C
                GOTO            SETFOV24
                GOTO            DARGOK24                ; set overflow flag
ALTB24          MOVLW           EXPBIAS-1
                ADDWF           TEMP,W
                ADDWF           EXP,F
                BTFSS           _C
                GOTO            SETFUN24                ; set underflow flag
DARGOK24        MOVLW           D'16'			; initialize counter
                MOVWF           TEMPB1
DLOOP24         RLF             AARGB3,F		; left shift
                RLF             AARGB2,F
                RLF             AARGB1,F
                RLF             AARGB0,F
                RLF             TEMP,F
                MOVF            BARGB1,W		; subtract
                SUBWF           AARGB1,F
                MOVF            BARGB0,W
                BTFSS           _C
                INCFSZ          BARGB0,W
                SUBWF           AARGB0,F
                RLF             BARGB0,W
                IORWF           TEMP,F
                BTFSS           TEMP,LSB                ; test for restore
                GOTO            DREST24
                BSF             AARGB3,LSB
                GOTO            DOK24
DREST24         MOVF            BARGB1,W		; restore if necessary
                ADDWF           AARGB1,F
                MOVF            BARGB0,W
                BTFSC           _C
                INCF            BARGB0,W
                ADDWF           AARGB0,F
                BCF             AARGB3,LSB
DOK24           DECFSZ          TEMPB1,F
                GOTO            DLOOP24
DROUND24        BTFSC           FPFLAGS,RND
                BTFSS           AARGB3,LSB
                GOTO            DIV24OK
                BCF             _C
                RLF             AARGB1,F		; compute next significant bit
                RLF             AARGB0,F		; for rounding
                RLF             TEMP,F
                SUBWF           AARGB1,F
                MOVF            BARGB0,W
                BTFSS           _C
                INCFSZ          BARGB0,W
                SUBWF           AARGB0,F
                RLF             BARGB0,W
                IORWF           TEMP,W
                ANDLW           0x01            
                ADDWF           AARGB3,F
                BTFSC           _C
                INCF            AARGB2,F
                BTFSS           _Z                      ; test if rounding caused carryout
                GOTO            DIV24OK
                RRF             AARGB2,F
                RRF             AARGB3,F
                INCF            EXP,F
                BTFSC           _Z                      ; test for overflow
                GOTO            SETFOV24
DIV24OK         BTFSS           SIGN,MSB
                BCF             AARGB2,MSB		; clear explicit MSB if positive
                MOVF            AARGB2,W
                MOVWF           AARGB0			; move result to AARG
                MOVF            AARGB3,W
                MOVWF           AARGB1
                RETLW           0
SETFUN24        BSF             FPFLAGS,FUN             ; set floating point underflag
                MOVLW           0x01                    ; saturate to smallest floating
                MOVWF           AEXP                    ; point number = 0x 01 00 00
                CLRF            AARGB0			; modulo the appropriate sign bit
                CLRF            AARGB1
                RLF             SIGN,F
                RRF             AARGB0,F
SETFDZ24        BSF             FPFLAGS,FDZ             ; set divide by zero flag
                RETLW           0xFF
;       Floating Point Subtract
;       Use:    CALL FPS24
;       Output: 24 bit floating point sum in AEXP, AARGB0, AARGB1
;       Result: AARG  <--  AARG - BARG
;       Max Timing:     2+197 = 199 clks                RND = 0
;                       2+208 = 210 clks                RND = 1, SAT = 0
;                       2+213 = 215 clks                RND = 1, SAT = 1
;       Min Timing:     2+12 = 14 clks
;       PM: 2+112 = 114                         DM: 11
FPS24           MOVLW           0x80
                XORWF           BARGB0,F
;       Floating Point Add
;       Use:    CALL FPA24
;       Max Timing:     25+28+6*6+5+31+72 = 197 clks            RND = 0
;                       25+28+6*6+5+42+72 = 208 clks            RND = 1, SAT = 0
;                       25+28+6*6+5+42+77 = 213 clks            RND = 1, SAT = 1
;       Min Timing:     8+4 = 12 clks
;       PM: 112                                                 DM: 11
FPA24           MOVF            AARGB0,W		; exclusive or of signs in TEMP
                XORWF           BARGB0,W
                MOVWF           TEMP
		CLRF		BARGB2
                MOVF            AEXP,W                  ; use AARG if AEXP >= BEXP
                SUBWF           BEXP,W
                BTFSS           _C
                GOTO            USEA24
                MOVF            BEXP,W                  ; use BARG if AEXP < BEXP
                MOVWF           AARGB4			; therefore, swap AARG and BARG
                MOVF            AEXP,W
                MOVWF           BEXP
                MOVF            AARGB4,W
                MOVWF           AEXP
                MOVF            BARGB0,W
                MOVWF           AARGB4
                MOVF            AARGB0,W
                MOVWF           BARGB0
                MOVF            AARGB4,W
                MOVWF           AARGB0
                MOVF            BARGB1,W
                MOVWF           AARGB4
                MOVF            AARGB1,W
                MOVWF           BARGB1
                MOVF            AARGB4,W
                MOVWF           AARGB1
USEA24          MOVF            BEXP,W                  ; return AARG if BARG = 0
                BTFSC           _Z
                RETLW           0x00
                MOVF            AARGB0,W
                BSF             AARGB0,MSB		; make MSB's explicit
                BSF             BARGB0,MSB
                MOVF            BEXP,W                  ; compute shift count in BEXP
                SUBWF           AEXP,W
                MOVWF           BEXP
                BTFSC           _Z
                GOTO            ALIGNED24
                MOVLW           8
                SUBWF           BEXP,W
                BTFSS           _C                      ; if BEXP >= 8, do byte shift
                GOTO            ALIGNB24
                MOVWF           BEXP
                MOVF            BARGB1,W		; keep for postnormalization
		MOVWF		BARGB2
                MOVF            BARGB0,W
		MOVWF		BARGB1
                CLRF            BARGB0
                MOVLW           8
                SUBWF           BEXP,W
                BTFSS           _C                      ; if BEXP >= 8, BARG = 0 relative to AARG
                GOTO            ALIGNB24
                MOVF            SIGN,W
                MOVWF           AARGB0
                RETLW           0x00
ALIGNB24        MOVF            BEXP,W                  ; already aligned if BEXP = 0
                BTFSC           _Z
                GOTO            ALIGNED24
ALOOPB24        BCF             _C                      ; right shift by BEXP
                RRF             BARGB0,F
                RRF             BARGB1,F
		RRF		BARGB2,F
                DECFSZ          BEXP,F
                GOTO            ALOOPB24
ALIGNED24       BTFSS           TEMP,MSB                ; negate if signs opposite
                GOTO            AOK24
		COMF		BARGB2,F
                COMF            BARGB1,F
                COMF            BARGB0,F
                INCF            BARGB2,F
                BTFSC           _Z
                INCF            BARGB1,F
		BTFSC		_Z
		INCF		BARGB0,F
AOK24
                MOVF    	BARGB2,W
                ADDWF   	AARGB2,F
                MOVF            BARGB1,W
                BTFSC           _C
                INCFSZ          BARGB1,W
                ADDWF           AARGB1,F
                MOVF            BARGB0,W
                BTFSC           _C
                INCFSZ          BARGB0,W
                ADDWF           AARGB0,F
                BTFSC           TEMP,MSB
                GOTO            ACOMP24
                BTFSS           _C
                GOTO            NRMRND3224
                RRF             AARGB0,F		; shift right and increment EXP
                RRF             AARGB1,F
		RRF		AARGB2,F
                INCFSZ          AEXP,F
                GOTO            NRMRND3224
                GOTO            SETFOV24
ACOMP24         BTFSC           _C
                GOTO            NRM3224			; normalize and fix sign
		COMF		AARGB2,F
                COMF            AARGB1,F		; negate, toggle sign bit and
                COMF            AARGB0,F		; then normalize
                INCF            AARGB2,F
                BTFSC           _Z
                INCF            AARGB1,F
                BTFSC           _Z
                INCF            AARGB0,F
                MOVLW           0x80
                XORWF           SIGN,F
                GOTO            NRM24
