-- Company:
-- Engineer:
-- Create Date:    20:41:19 10/25/2008
-- Design Name:
-- Module Name:    villi - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
Library ieee;
Use ieee.std_logic_1164.ALL;
Use ieee.STD_LOGIC_ARITH.ALL;
Use ieee.std_logic_unsigned.ALL;
Entity k1 is
 port( LED: out std_logic_vector(15 downto 0);--SRAM címzés
      CLK: in std_logic;
		SCLK: inout std_logic;--Segéd órajel
		SCLKI: inout std_logic;--Inverz Segéd órajel
		GTS1: in std_logic;--Engedélyező láb
		DACLK: inout std_logic;--ADC órajele
		ClkSel: in std_logic_vector(3 downto 0);
		CS1: out std_logic;
		LED_ZOLD: out std_logic;
		MCLK: inout std_logic);--Másodlagos órajel,SRAM WE jel
end;
Architecture rtl of k1 is
signal count: std_logic_vector(16 downto 0):="00000000000000000";
signal count2: std_logic_vector(0 downto 0):="0";
signal count3: std_logic_vector(0 downto 0):="0";
signal ADC_div: std_logic_vector(8 downto 0):="000001111";
signal ADCClk: std_logic:='0';
begin
 SCLK <= CLK when ClkSel="0000" else ADCClk;--SRAM WE írásengedély jel is
 LED <= count(16 downto 1);--Egyszerű 16bites számláló
 DACLK <= count2(0) after 0ns;--SRAM WE írásengedély jel is
 MCLK <= count2(0) after 0ns;
 CS1 <= count2(0) after 0ns;
 SCLKI <= not(SCLK);
 LED_ZOLD <= count(16);
 process(SCLK)
 begin
  if SCLK'event and SCLK='1' then
   if GTS1='1' then
   count <= count+1;
	else
	count <= "00000000000000000";-- SRAM Címzés nullázása
	end if;
  end if;
 end process;
process(SCLK)
 begin
  if SCLK'event and SCLK='1' then --Kettővel való leosztott jel
   if GTS1='1' then
	count2 <= count2+1;
	else
	count2 <= "0";--Másodlagos órajel nullázás
	end if;
  end if;
 end process;
process(SCLK)
 begin
  if SCLK'event and SCLK='0' then --Kettővel való leosztott jel
   if GTS1='1' then
	count3 <= count3+1;
	else
	count3 <= "0";--Másodlagos órajel nullázás
	end if;
  end if;
 end process;
ClkDivP: process(CLK,GTS1)
 begin
  if GTS1='0' then
  ADCClk <= '0';
  ADC_div <= "000001001";
  elsif CLK='0' and CLK'event then
	if ADC_div="000000000" then
		ADCClk <= not(ADCClk);
		case ClkSel is
			when "0001" =>								  -- Div2
			when "0010" => ADC_div <= "000000001";  -- Div4 (érték+1)*2=osztás érték
			when "0011" => ADC_div <= "000000100";  -- Div10
 			when "0100" => ADC_div <= "000001001";  -- Div20
			when "0101" => ADC_div <= "000010011";  -- Div40
			when "0110" => ADC_div <= "000110001";  -- Div100
			when "0111" => ADC_div <= "001100011";  -- Div200
			when "1000" => ADC_div <= "011000111";  -- Div400
			when "1001" => ADC_div <= "111110011";  -- Div1000
			when others => ADC_div <= "111110011";  -- Div1000
		end case;
	else
		ADC_div <= (unsigned(ADC_div)-1);
	end if;
	end if;
end process;
 process(CLK,GTS1)
 begin
   if GTS1='0' then
	MCLK <= 'Z';
	DACLK <= 'Z';
	CS1 <= 'Z';
	LED(0) <= 'Z';
	LED(1) <= 'Z';
	LED(2) <= 'Z';
	LED(3) <= 'Z';
	LED(4) <= 'Z';
	LED(5) <= 'Z';
	LED(6) <= 'Z';
	LED(7) <= 'Z';
	LED(8) <= 'Z';
	LED(9) <= 'Z';
	LED(10) <= 'Z';
	LED(11) <= 'Z';
	LED(12) <= 'Z';
	LED(13) <= 'Z';
	LED(14) <= 'Z';
	LED(15) <= 'Z';
	end if;
 end if;
 end process;
end;
