; Source created with Parsic Version 4.0.6.21
; at              : 2014.01.23. 22:08:43
; Project File    : C:\Program Files\Parsic 4\Munka\HLX\EE_teszt\EE_teszt.PIC
; Project Version : 1.0.3
; Created         : 2014.01.23. 21:53:19
; Last change     : 2014.01.23. 22:08:42
	PROCESSOR 18F4550
	INCLUDE P18F4550.INC
	RADIX DEC
	__IDLOCS _IDLOC0,H'01'
	__IDLOCS _IDLOC1,H'00'
	__IDLOCS _IDLOC2,H'03'
	ERRORLEVEL -230
	__CONFIG _CONFIG1L,H'C0';192
	__CONFIG _CONFIG1H,H'30';48
	__CONFIG _CONFIG2L,H'DA';218
	__CONFIG _CONFIG2H,H'E6';230
	__CONFIG _CONFIG3H,H'79';121
	__CONFIG _CONFIG4L,H'9B';155
	__CONFIG _CONFIG5L,H'FF';255
	__CONFIG _CONFIG5H,H'FF';255
	__CONFIG _CONFIG6L,H'FF';255
	__CONFIG _CONFIG6H,H'FF';255
	__CONFIG _CONFIG7L,H'FF';255
	__CONFIG _CONFIG7H,H'FF';255
	ERRORLEVEL +230
; missing constants
ZERO	EQU Z	; ZERO-Flag
CARRY	EQU C	; CARRY-Flag
; variable
SYS_FSAV	EQU 0	; located in Bank ACCESS BANK
SYS_FSAV_1	EQU 1	; located in Bank ACCESS BANK
_FD1	EQU 2	; located in Bank ACCESS BANK
PWR	EQU 3	; located in Bank ACCESS BANK
SYS_TMP0	EQU 4	; located in Bank ACCESS BANK
SYS_TMP1	EQU 5	; located in Bank ACCESS BANK
SYS_TMP2	EQU 6	; located in Bank ACCESS BANK
SYS_TMP3	EQU 7	; located in Bank ACCESS BANK
SYS_TMP4	EQU 8	; located in Bank ACCESS BANK
SYS_TMP5	EQU 9	; located in Bank ACCESS BANK
SYS_TMP6	EQU 10	; located in Bank ACCESS BANK
SYS_TMP7	EQU 11	; located in Bank ACCESS BANK
SYS_TMP8	EQU 12	; located in Bank ACCESS BANK
SYS_TMP9	EQU 13	; located in Bank ACCESS BANK
SYS_TMP10	EQU 14	; located in Bank ACCESS BANK
SYS_TMP11	EQU 15	; located in Bank ACCESS BANK
S0	EQU 16	; located in Bank ACCESS BANK
ADAT1	EQU 17	; located in Bank ACCESS BANK
ADAT1_1	EQU 18	; located in Bank ACCESS BANK
TR49	EQU 19	; located in Bank ACCESS BANK
TR49_1	EQU 20	; located in Bank ACCESS BANK
; disable warning (Bankswitching)
	ERRORLEVEL -302
; disable warning (Pageswitching)
	ERRORLEVEL -306
; Program start
	ORG 0
	BRA SYS_INIT
	NOP
	NOP
	NOP
; Interrupt-address
	BTFSS INTCON,T0IF,A
	BRA NOTIMERINTERRUPT
; add 8 to timer0, so interrupt comes every 250 uSec and not after 256 uSec
	MOVLW 8
	ADDWF TMR0,F,A	; W + f -> f
	INCFSZ TR49,F,A	; f + 1 -> f
	BRA TR49_NEXT
	INCF TR49_1,F,A	; f + 1 -> f
TR49_NEXT
	BCF INTCON,T0IF,A
NOTIMERINTERRUPT
EXITINT
	RETFIE FAST	; FAST = restore STATUS,BSR,W-register, enable GIE/GIEH, PEIE/GIEL
; Subroutines
SYS_DELAY
	MOVWF SYS_TMP0,A
SYS_DELAY_1
	DECFSZ SYS_TMP0,F,A	; f - 1 -> f
	BRA SYS_DELAY_1
SYS_DELAY_4
	RETURN
INTERNAL_WR
	MOVWF EEDATA,A
	MOVF SYS_TMP4,W,A
	MOVWF EEADR,A
; disable interrupts
	BCF INTCON,GIE,A
	BSF EECON1,WREN,A
	MOVLW 85
	MOVWF EECON2,A
	MOVLW 170
	MOVWF EECON2,A
	BSF EECON1,WR,A
	NOP
	BCF EECON1,WREN,A
	BSF INTCON,GIE,A
INTERNAL_WAIT
	BTFSC EECON1,WR,A
	BRA INTERNAL_WAIT
	RETURN
INTERNAL_RD
	MOVF SYS_TMP4,W,A
	MOVWF EEADR,A
	BSF EECON1,RD,A
	MOVF EEDATA,W,A
	RETURN
; Subroutines for LCD1
LCD1_INIT
; wait long
	CLRF SYS_TMP1,A	; 0 -> f
LCD1_INIT1
	RCALL LCD1_OUT4
	DECFSZ SYS_TMP1,F,A	; f - 1 -> f
	BRA LCD1_INIT1
; may be the display is already in 4-Bit mode !!
; so we have to reset it back to the 8-Bit mode - three times
; IR-Register
	BCF PORTD,4,A
	MOVF PORTD,W,A
	ANDLW 240
	IORLW 3
	MOVWF PORTD,A
; 1st
	BSF PORTD,5,A
	NOP
	BCF PORTD,5,A
; wait long
LCD1_INIT2
	RCALL LCD1_OUT4
	BRA LCD1_INIT2
; 2nd
	BSF PORTD,5,A
	NOP
	BCF PORTD,5,A
; wait long
LCD1_INIT3
	RCALL LCD1_OUT4
	BRA LCD1_INIT3
; 3rd
	BSF PORTD,5,A
	NOP
	BCF PORTD,5,A
; wait long
LCD1_INIT4
	RCALL LCD1_OUT4
	BRA LCD1_INIT4
; function set 4-bit, this is the last 8-Bit command
	BCF PORTD,0,A
	BSF PORTD,5,A
	NOP
	BCF PORTD,5,A
; wait long
LCD1_INIT5
	RCALL LCD1_OUT4
	BRA LCD1_INIT5
; function set 4-bit,2-lines = 00101000
	MOVLW 40
	RCALL LCD1_OUT
; display on, cursor off, blink off = 00001100
	MOVLW 12
	RCALL LCD1_OUT
; entrymode set = 00000110"
	MOVLW 6
	RCALL LCD1_OUT
; entrypoint display clear = 00000001
LCD1_CLR
	MOVLW 1
	RCALL LCD1_WRITE_IR
; wait long
LCD1_INIT6
	RCALL LCD1_OUT4
	BRA LCD1_INIT6
	BRA LCD1_OUT4
; LCD Write DDRAM or CGRAM
LCD1_WRITE_DDRAM
; DDRAM or CGRAM
	BSF PORTD,4,A
	BRA LCD1_OUT
; LCD Set CGRAM
LCD1_SET_CGRAM
	IORLW 64
	BRA LCD1_WRITE_IR
; LCD Set DDRAM
LCD1_SET_DDRAM
	IORLW 128
; LCD Write IR
LCD1_WRITE_IR
; IR-Register
	BCF PORTD,4,A
; LCD Out Bit-7...4 first
; W-Register contains the byte to be written
LCD1_OUT
	MOVWF SYS_TMP1,A
LCD1_OUT1
	CLRF SYS_TMP3,A	; 0 -> f
LCD1_OUT2
	SWAPF SYS_TMP1,W,A
LCD1_OUT3
	ANDLW 15
	MOVWF SYS_TMP2,A
	MOVF PORTD,W,A
	ANDLW 240
	IORWF SYS_TMP2,W,A
	MOVWF PORTD,A
	BSF PORTD,5,A
	NOP
	BCF PORTD,5,A
	BTFSC SYS_TMP3,0,A
	BRA LCD1_OUT4
	BSF SYS_TMP3,0,A
	MOVF SYS_TMP1,W,A
	BRA LCD1_OUT3
LCD1_OUT4
	MOVLW 17
	MOVWF SYS_TMP3,A
LCD1_OUT5
	DECFSZ SYS_TMP3,F,A	; f - 1 -> f
	BRA LCD1_OUT5
	RETURN
; GOTOXY - Set Cursor Position
; SYS_TMP1  = X
; SYS_TMP2  = Y
; SYS_TMP12 = copy of X (only if a 1 Line-Display is used)
LCD1_GOTOXY
; Ypos bit-0
	MOVLW 64
	BTFSC SYS_TMP2,0,A
	ADDWF SYS_TMP1,F,A	; W + f -> f
	MOVLW 20
; Ypos bit-1
	BTFSC SYS_TMP2,1,A
	MOVF SYS_TMP1,W,A
	BRA LCD1_SET_DDRAM
LCD1_CONVERTHEX
; only lower nibble
	ANDLW 15
	MOVWF SYS_TMP1,A
; add asc'0', if greater or equal 10 add asc'7'
	MOVLW 10
	SUBWF SYS_TMP1,W,A	; f - W -> W
	MOVLW 55
	BTFSS STATUS,CARRY,A
	MOVLW 48
	MOVF SYS_TMP1,W,A
	BRA LCD1_WRITE_DDRAM
; Write String
LCD1_WRITESTR
	RCALL LCD1_GETROMCHAR
; last is zero
	ANDLW 255
	BTFSC STATUS,ZERO,A
	RETURN
	RCALL LCD1_WRITE_DDRAM
; next char
	INCF SYS_TMP5,F,A	; f + 1 -> f
	INCFSZ SYS_TMP5,F,A	; f + 1 -> f
	BRA LCD1_WRITESTR
; next page
	INCF SYS_TMP6,F,A	; f + 1 -> f
	BRA LCD1_WRITESTR
; direct jump into the table
LCD1_GETROMCHAR
	MOVF SYS_TMP6,W,A
	MOVWF PCLATH,A
	MOVF SYS_TMP5,W,A
	MOVWF PCL,A
LCD1_WRITE_DEZ
; test zero
	ANDLW 255
	BTFSS STATUS,ZERO,A
	BCF SYS_TMP9,0,A
	BTFSS SYS_TMP9,0,A
	ADDLW 48	; k + W -> W
	BTFSC SYS_TMP9,0,A
	ADDLW 32	; k + W -> W
LCD1_CONVERTDEZ
	MOVF SYS_TMP10,F,A
	BTFSS STATUS,ZERO,A
	DECF SYS_TMP10,F	; f - 1 -> f
	CLRF SYS_TMP11,A	; 0 -> f
LCD1_CONVERTDEZ2
	INCF SYS_TMP11,F,A	; f + 1 -> f
	MOVF SYS_TMP1,W,A
	SUBWF SYS_TMP5,F,A	; f - W -> f
	MOVF SYS_TMP2,W,A
	INCFSZ SYS_TMP2,W,A	; f + 1 -> w
	SUBWF SYS_TMP6,F,A	; f - W -> f
	MOVF SYS_TMP3,W,A
	INCFSZ SYS_TMP3,W,A	; f + 1 -> w
	SUBWF SYS_TMP7,F,A	; f - W -> f
	MOVF SYS_TMP4,W,A
	INCFSZ SYS_TMP4,W,A	; f + 1 -> w
	SUBWF SYS_TMP8,F,A	; f - W -> f
	BTFSC STATUS,CARRY,A
	BRA LCD1_CONVERTDEZ2
	MOVF SYS_TMP1,W,A
	ADDWF SYS_TMP5,F,A	; W + f -> f
	MOVF SYS_TMP2,W,A
	ADDWF SYS_TMP6,F,A	; W + f -> f
	MOVF SYS_TMP3,W,A
	ADDWF SYS_TMP7,F,A	; W + f -> f
	MOVF SYS_TMP4,W,A
	ADDWF SYS_TMP8,F,A	; W + f -> f
	DECF SYS_TMP11,W	; f + 1 -> w
	RETURN
LCD1_1000000000
	MOVLW 0
	MOVWF SYS_TMP1,A
	MOVLW 202
	MOVWF SYS_TMP2,A
	MOVLW 154
	MOVWF SYS_TMP3,A
	MOVLW 59
	MOVWF SYS_TMP4,A
	RCALL LCD1_CONVERTDEZ
	MOVF SYS_TMP10,F,A
	BTFSS STATUS,ZERO,A
	BRA LCD1_100000000
	RCALL LCD1_WRITE_DEZ
LCD1_100000000
	MOVLW 0
	MOVWF SYS_TMP1,A
	MOVLW 225
	MOVWF SYS_TMP2,A
	MOVLW 245
	MOVWF SYS_TMP3,A
	MOVLW 5
	MOVWF SYS_TMP4,A
	MOVF SYS_TMP10,F,A
	BTFSS STATUS,ZERO,A
	BRA LCD1_10000000
LCD1_10000000
	MOVLW 128
	MOVWF SYS_TMP1,A
	MOVLW 150
	MOVWF SYS_TMP2,A
	MOVLW 152
	MOVWF SYS_TMP3,A
	MOVLW 0
	MOVWF SYS_TMP4,A
	MOVF SYS_TMP10,F,A
	BTFSS STATUS,ZERO,A
	BRA LCD1_1000000
LCD1_1000000
	MOVLW 64
	MOVWF SYS_TMP1,A
	MOVLW 66
	MOVWF SYS_TMP2,A
	MOVLW 15
	MOVWF SYS_TMP3,A
	MOVLW 0
	MOVWF SYS_TMP4,A
	MOVF SYS_TMP10,F,A
	BTFSS STATUS,ZERO,A
	BRA LCD1_100000
LCD1_100000
	MOVLW 160
	MOVWF SYS_TMP1,A
	MOVLW 134
	MOVWF SYS_TMP2,A
	MOVLW 1
	MOVWF SYS_TMP3,A
	MOVLW 0
	MOVWF SYS_TMP4,A
	MOVF SYS_TMP10,F,A
	BTFSS STATUS,ZERO,A
	BRA LCD1_10000
LCD1_10000
	MOVLW 16
	MOVWF SYS_TMP1,A
	MOVLW 39
	MOVWF SYS_TMP2,A
	MOVLW 0
	MOVWF SYS_TMP3,A
	MOVLW 0
	MOVWF SYS_TMP4,A
	MOVF SYS_TMP10,F,A
	BTFSS STATUS,ZERO,A
	BRA LCD1_1000
LCD1_1000
	MOVLW 232
	MOVWF SYS_TMP1,A
	MOVLW 3
	MOVWF SYS_TMP2,A
	MOVLW 0
	MOVWF SYS_TMP3,A
	MOVLW 0
	MOVWF SYS_TMP4,A
	MOVF SYS_TMP10,F,A
	BTFSS STATUS,ZERO,A
	BRA LCD1_100
LCD1_100
	MOVLW 100
	MOVWF SYS_TMP1,A
	MOVLW 0
	MOVWF SYS_TMP2,A
	MOVLW 0
	MOVWF SYS_TMP3,A
	MOVLW 0
	MOVWF SYS_TMP4,A
	MOVF SYS_TMP10,F,A
	BTFSS STATUS,ZERO,A
	BRA LCD1_10
LCD1_10
	MOVLW 10
	MOVWF SYS_TMP1,A
	MOVLW 0
	MOVWF SYS_TMP2,A
	MOVLW 0
	MOVWF SYS_TMP3,A
	MOVLW 0
	MOVWF SYS_TMP4,A
	MOVF SYS_TMP10,F,A
	BTFSS STATUS,ZERO,A
	BRA LCD1_1
LCD1_1
	BCF SYS_TMP9,0,A
	MOVF SYS_TMP5,W,A
	BRA LCD1_WRITE_DEZ
; Initialisation
SYS_INIT
	CLRF INTCON,A	; 0 -> f
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA,A
	MOVLW B'00000000'
	MOVWF PORTB,A
	MOVLW B'00000000'
	MOVWF PORTC,A
	MOVLW B'00000000'
	MOVWF PORTD,A
	MOVLW B'00000000'
	MOVWF PORTE,A
; set direction
	MOVLW B'11111111'
	MOVWF TRISA,A
	MOVLW B'11111111'
	MOVWF TRISB,A
	MOVLW B'11111111'
	MOVWF TRISC,A
	MOVLW B'11000000'
	MOVWF TRISD,A
	MOVLW B'111'
	MOVWF TRISE,A
; init some registers
; Timer 0
	MOVLW 223
	MOVWF T0CON,A
	BSF INTCON,T0IE,A
; A/D off
	MOVLW 15
	MOVWF ADCON1,A
	CLRF ADCON2,A	; 0 -> f
; Clear RAM
; Clear from $000 to $7FF
	LFSR 0,0
SYSClearRAM1
	CLRF POSTINC0,A	; 0 -> f
	MOVLW 255
	SUBWF FSR0L,W,A	; f - W -> W
	BTFSS STATUS,ZERO,A
	BRA SYSClearRAM1
	MOVLW 7
	SUBWF FSR0H,W,A	; f - W -> W
	BTFSS STATUS,ZERO,A
	BRA SYSClearRAM1
; init vars
; EE1
; set start-address
	MOVLW 0
	MOVWF SYS_TMP4,A
	RCALL INTERNAL_RD
	MOVWF ADAT1,A
	INCF SYS_TMP4,F,A	; f + 1 -> f
	RCALL INTERNAL_RD
	MOVWF ADAT1_1,A
; Init LCD-module -> LCD1
	RCALL LCD1_INIT
	CLRF TMR0,A	; 0 -> f
; enable interrupts
	BCF INTCON,T0IF,A
	BSF INTCON,GIE,A
; Main program
MAIN
; EE1
; check negative edge
	BTFSS _FD1,0,A
	BRA EE1_SETFD
	BTFSC S0,0,A
	BRA EE1_SETFD
	BCF _FD1,0,A
; set start-address
	MOVLW 0
	MOVWF SYS_TMP4,A
; write data
	MOVF ADAT1,W,A
	RCALL INTERNAL_WR
; write data
	MOVF ADAT1_1,W,A
	RCALL INTERNAL_WR
EE1_SETFD
; check positive
	BTFSS S0,0,A
	BRA EE1_EXIT
	BSF _FD1,0,A
EE1_EXIT
; OS3
; check positive edge
	BTFSC _FD1,1,A
	BRA OS3_SETFD
	BTFSS PORTB,1,A
	BRA OS3_SETFD
	BSF _FD1,1,A
	BSF S0,0,A
	BRA OS3_EXIT
OS3_SETFD
	BCF S0,0,A
	BTFSC PORTB,1,A
	BRA OS3_EXIT
	BCF _FD1,1,A
OS3_EXIT
; ADAT1
	BTFSS S0,1,A
	BRA ADAT1_COUNT
	CLRF ADAT1,A	; 0 -> f
	CLRF ADAT1_1,A	; 0 -> f
	BRA ADAT1_SETOUT
ADAT1_COUNT
	BTFSC _FD1,2,A
	BRA ADAT1_SETFD
	BTFSS S0,0,A
	BRA ADAT1_SETFD
	BSF _FD1,2,A
	BTFSC PWR,0,A
	BRA ADAT1_BACKWARD
	INCFSZ ADAT1,F,A	; f + 1 -> f
	BRA ADAT1_SETOUT
	INCF ADAT1_1,F,A	; f + 1 -> f
	BRA ADAT1_SETOUT
ADAT1_BACKWARD
	DECF ADAT1,F	; f - 1 -> f
	INCFSZ ADAT1,W,A	; f + 1 -> w
	BRA ADAT1_SETOUT
	DECF ADAT1_1,F,A	; f - 1 -> f
ADAT1_SETOUT
ADAT1_SETFD
; check negative
	BTFSC S0,0,A
	BRA ADAT1_EXIT
	BCF _FD1,2,A
ADAT1_EXIT
; LM38
	BCF S0,2,A
	BCF S0,3,A
; copy
	MOVF ADAT1,W,A
	MOVWF ADAT1,A
	MOVF ADAT1_1,W,A
	MOVWF ADAT1_1,A
; check top
	MOVLW 0
	SUBWF ADAT1_1,W,A	; f - W -> W
	BTFSS STATUS,ZERO,A
	BRA LM38_CHECKTOP
	MOVLW 40
	SUBWF ADAT1,W,A	; f - W -> W
LM38_CHECKTOP
	BRA LM38_BOTTOM
	BTFSC STATUS,ZERO,A
	BRA LM38_BOTTOM
	BSF S0,2,A
	MOVLW 40
	MOVWF ADAT1,A
	MOVLW 0
	MOVWF ADAT1_1,A
	BRA LM38_EXIT
; check bottom
LM38_BOTTOM
	MOVLW 0
	BTFSS STATUS,ZERO,A
	BRA LM38_CHECKBOTTOM
	MOVLW 0
LM38_CHECKBOTTOM
	BRA LM38_EXIT
	BSF S0,3,A
	MOVLW 0
	MOVWF ADAT1,A
	MOVLW 0
	MOVWF ADAT1_1,A
LM38_EXIT
; LCD1
; LT46
	BTFSC _FD1,3,A
	BRA LT46_SETFD
	BTFSS S0,4,A
	BRA LT46_SETFD
	BSF _FD1,3,A
	MOVLW 5
	MOVWF SYS_TMP1,A
	MOVLW 2
	MOVWF SYS_TMP2,A
	RCALL LCD1_GOTOXY
	MOVF ADAT1,W,A
	MOVWF SYS_TMP5,A
	MOVF ADAT1_1,W,A
	MOVWF SYS_TMP6,A
	CLRF SYS_TMP7,A	; 0 -> f
	CLRF SYS_TMP8,A	; 0 -> f
	BSF SYS_TMP9,0,A
	MOVLW 4
	MOVWF SYS_TMP10,A
	RCALL LCD1_10000
LT46_SETFD
; check negative
	BTFSC S0,4,A
	BRA LT46_EXIT
	BCF _FD1,3,A
LT46_EXIT
; TR49
	BCF INTCON,GIE,A
	MOVLW 0
	SUBWF TR49_1,W,A	; f - W -> W
	BTFSS STATUS,ZERO,A
	BRA TR49_CHECK
	MOVLW 200
	SUBWF TR49,W,A	; f - W -> W
TR49_CHECK
	BRA TR49_END
TR49_RESET
	MOVLW 0
	SUBWF TR49_1,F,A	; f - W -> f
	MOVLW 200
	SUBWF TR49,F,A	; f - W -> f
	DECF TR49_1,F,A	; f - 1 -> f
TR49_SET
	BTFSC S0,4,A
	BRA TR49_CLR
	BSF S0,4,A
	BRA TR49_END
TR49_CLR
	BCF S0,4,A
TR49_END
	BSF INTCON,GIE,A
	BRA MAIN
	ORG H'F00000'
	DE 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	END
