<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.2">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="yes" active="yes"/>
<layer number="3" name="Route3" color="4" fill="3" visible="yes" active="yes"/>
<layer number="4" name="Route4" color="1" fill="4" visible="yes" active="yes"/>
<layer number="5" name="Route5" color="4" fill="4" visible="yes" active="yes"/>
<layer number="6" name="Route6" color="1" fill="8" visible="yes" active="yes"/>
<layer number="7" name="Route7" color="4" fill="8" visible="yes" active="yes"/>
<layer number="8" name="Route8" color="1" fill="2" visible="yes" active="yes"/>
<layer number="9" name="Route9" color="4" fill="2" visible="yes" active="yes"/>
<layer number="10" name="Route10" color="1" fill="7" visible="yes" active="yes"/>
<layer number="11" name="Route11" color="4" fill="7" visible="yes" active="yes"/>
<layer number="12" name="Route12" color="1" fill="5" visible="yes" active="yes"/>
<layer number="13" name="Route13" color="4" fill="5" visible="yes" active="yes"/>
<layer number="14" name="Route14" color="1" fill="6" visible="yes" active="yes"/>
<layer number="15" name="Route15" color="4" fill="6" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="yes" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="yes" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="yes" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="yes" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="yes" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="yes" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="yes" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="yes" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="yes" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="yes" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="yes" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<packages>
<package name="NOKIA5110">
<description>nokia5110</description>
<wire x1="0" y1="0" x2="45.085" y2="0" width="0.127" layer="21"/>
<wire x1="45.085" y1="0" x2="45.085" y2="45.085" width="0.127" layer="21"/>
<wire x1="45.085" y1="45.085" x2="0" y2="45.085" width="0.127" layer="21"/>
<wire x1="0" y1="45.085" x2="0" y2="0" width="0.127" layer="21"/>
<pad name="15" x="23.749" y="42.545" drill="0.8" diameter="1.9304"/>
<pad name="16" x="26.289" y="42.545" drill="0.8" diameter="1.9304"/>
<pad name="17" x="28.829" y="42.545" drill="0.8" diameter="1.9304"/>
<pad name="18" x="31.369" y="42.545" drill="0.8" diameter="1.9304"/>
<pad name="14" x="21.209" y="42.545" drill="0.8" diameter="1.9304"/>
<pad name="13" x="18.669" y="42.545" drill="0.8" diameter="1.9304"/>
<pad name="12" x="16.129" y="42.545" drill="0.8" diameter="1.9304"/>
<pad name="11" x="13.589" y="42.545" drill="0.8" diameter="1.9304"/>
<pad name="5" x="23.749" y="2.54" drill="0.8" diameter="1.9304"/>
<pad name="6" x="26.289" y="2.54" drill="0.8" diameter="1.9304"/>
<pad name="7" x="28.829" y="2.54" drill="0.8" diameter="1.9304"/>
<pad name="8" x="31.369" y="2.54" drill="0.8" diameter="1.9304"/>
<pad name="4" x="21.209" y="2.54" drill="0.8" diameter="1.9304"/>
<pad name="3" x="18.669" y="2.54" drill="0.8" diameter="1.9304"/>
<pad name="2" x="16.129" y="2.54" drill="0.8" diameter="1.9304"/>
<pad name="1" x="13.589" y="2.54" drill="0.8" diameter="1.9304"/>
<circle x="2.54" y="2.54" radius="0.762" width="1.016" layer="21"/>
<circle x="2.54" y="42.545" radius="0.762" width="1.016" layer="21"/>
<circle x="42.545" y="42.545" radius="0.772509375" width="1.016" layer="21"/>
<circle x="42.545" y="2.54" radius="0.772509375" width="1.016" layer="21"/>
<wire x1="3.81" y1="10.16" x2="7.62" y2="6.35" width="0.127" layer="21" curve="90"/>
<wire x1="7.62" y1="6.35" x2="36.83" y2="6.35" width="0.127" layer="21"/>
<wire x1="36.83" y1="6.35" x2="41.91" y2="11.43" width="0.127" layer="21" curve="90"/>
<wire x1="41.91" y1="11.43" x2="41.91" y2="27.94" width="0.127" layer="21"/>
<wire x1="41.91" y1="27.94" x2="38.1" y2="31.75" width="0.127" layer="21" curve="90"/>
<wire x1="38.1" y1="31.75" x2="7.62" y2="31.75" width="0.127" layer="21"/>
<wire x1="7.62" y1="31.75" x2="3.81" y2="27.94" width="0.127" layer="21" curve="90"/>
<wire x1="3.81" y1="27.94" x2="3.81" y2="10.16" width="0.127" layer="21"/>
<text x="11.43" y="24.13" size="2.54" layer="21">Nokia5110 pcb</text>
</package>
</packages>
<symbols>
<symbol name="NOKIA5110">
<wire x1="0" y1="5.08" x2="37.465" y2="5.08" width="0.254" layer="94"/>
<wire x1="37.465" y1="5.08" x2="37.465" y2="20.32" width="0.254" layer="94"/>
<wire x1="37.465" y1="20.32" x2="0" y2="20.32" width="0.254" layer="94"/>
<wire x1="0" y1="20.32" x2="0" y2="5.08" width="0.254" layer="94"/>
<pin name="1" x="10.16" y="0" length="middle" rot="R90"/>
<pin name="2" x="12.7" y="0" length="middle" rot="R90"/>
<pin name="3" x="15.24" y="0" length="middle" rot="R90"/>
<pin name="4" x="17.78" y="0" length="middle" rot="R90"/>
<pin name="5" x="20.32" y="0" length="middle" rot="R90"/>
<pin name="6" x="22.86" y="0" length="middle" rot="R90"/>
<pin name="7" x="25.4" y="0" length="middle" rot="R90"/>
<pin name="8" x="27.94" y="0" length="middle" rot="R90"/>
<pin name="RSC" x="10.16" y="25.4" length="middle" rot="R270"/>
<pin name="CE" x="12.7" y="25.4" length="middle" rot="R270"/>
<pin name="DC" x="15.24" y="25.4" length="middle" rot="R270"/>
<pin name="DIN" x="17.78" y="25.4" length="middle" rot="R270"/>
<pin name="CLK" x="20.32" y="25.4" length="middle" rot="R270"/>
<pin name="VCC" x="22.86" y="25.4" length="middle" rot="R270"/>
<pin name="LIGHT" x="25.4" y="25.4" length="middle" rot="R270"/>
<pin name="GND" x="27.94" y="25.4" length="middle" rot="R270"/>
<text x="2.54" y="10.16" size="1.27" layer="94">Nokia5110 pcb</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="NOKIA5110" uservalue="yes">
<gates>
<gate name="G$1" symbol="NOKIA5110" x="-104.14" y="0"/>
</gates>
<devices>
<device name="" package="NOKIA5110">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
<connect gate="G$1" pin="3" pad="3"/>
<connect gate="G$1" pin="4" pad="4"/>
<connect gate="G$1" pin="5" pad="5"/>
<connect gate="G$1" pin="6" pad="6"/>
<connect gate="G$1" pin="7" pad="7"/>
<connect gate="G$1" pin="8" pad="8"/>
<connect gate="G$1" pin="CE" pad="12"/>
<connect gate="G$1" pin="CLK" pad="15"/>
<connect gate="G$1" pin="DC" pad="13"/>
<connect gate="G$1" pin="DIN" pad="14"/>
<connect gate="G$1" pin="GND" pad="18"/>
<connect gate="G$1" pin="LIGHT" pad="17"/>
<connect gate="G$1" pin="RSC" pad="11"/>
<connect gate="G$1" pin="VCC" pad="16"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
