<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.5.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="no"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="no" active="no"/>
<layer number="17" name="Pads" color="2" fill="1" visible="no" active="no"/>
<layer number="18" name="Vias" color="2" fill="1" visible="no" active="no"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="no"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="no" active="no"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="no"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="no"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="no"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="no"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="no"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="no"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="no"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="no"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="no"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="no"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="no"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="no"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="no"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="no"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="no"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="no"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="no"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="no"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="no"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="no"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="no"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="no"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="no"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="no"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="6" fill="1" visible="no" active="no"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<schematic xreflabel="%F%N/%S.%C%R" xrefpart="/%S.%C%R">
<libraries>
<library name="optocoupler">
<description>&lt;b&gt;Opto Couplers&lt;/b&gt;&lt;p&gt;
Siemens, Hewlett-Packard, Texas Instuments, Sharp, Motorola&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DIL06">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="3.81" y1="2.921" x2="-3.81" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-2.921" x2="3.81" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="3.81" y1="2.921" x2="3.81" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="2.921" x2="-3.81" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-2.921" x2="-3.81" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.016" x2="-3.81" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-2.54" y="-3.81" drill="0.8128" shape="offset" rot="R270"/>
<pad name="2" x="0" y="-3.81" drill="0.8128" shape="offset" rot="R270"/>
<pad name="5" x="0" y="3.81" drill="0.8128" shape="offset" rot="R90"/>
<pad name="6" x="-2.54" y="3.81" drill="0.8128" shape="offset" rot="R90"/>
<pad name="3" x="2.54" y="-3.81" drill="0.8128" shape="offset" rot="R270"/>
<pad name="4" x="2.54" y="3.81" drill="0.8128" shape="offset" rot="R90"/>
<text x="-2.413" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.064" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
</package>
</packages>
<symbols>
<symbol name="OK-B">
<wire x1="0" y1="-2.54" x2="0" y2="2.54" width="0.1524" layer="94"/>
<wire x1="0" y1="2.54" x2="5.08" y2="2.54" width="0.1524" layer="94"/>
<wire x1="0" y1="-2.54" x2="1.016" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="-2.413" y1="-2.413" x2="-1.016" y2="-1.016" width="0.1524" layer="94"/>
<wire x1="-1.016" y1="-1.016" x2="-1.905" y2="-1.397" width="0.1524" layer="94"/>
<wire x1="-1.905" y1="-1.397" x2="-1.397" y2="-1.905" width="0.1524" layer="94"/>
<wire x1="-1.397" y1="-1.905" x2="-1.016" y2="-1.016" width="0.1524" layer="94"/>
<wire x1="-1.143" y1="0.127" x2="-2.032" y2="-0.254" width="0.1524" layer="94"/>
<wire x1="-2.032" y1="-0.254" x2="-1.524" y2="-0.762" width="0.1524" layer="94"/>
<wire x1="-1.524" y1="-0.762" x2="-1.143" y2="0.127" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-1.27" x2="-1.143" y2="0.127" width="0.1524" layer="94"/>
<wire x1="-3.175" y1="0" x2="-4.445" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-4.445" y1="-2.54" x2="-5.715" y2="0" width="0.254" layer="94"/>
<wire x1="-3.175" y1="-2.54" x2="-4.445" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-4.445" y1="-2.54" x2="-5.715" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-3.175" y1="0" x2="-4.445" y2="0" width="0.254" layer="94"/>
<wire x1="-4.445" y1="0" x2="-4.445" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-4.445" y1="0" x2="-5.715" y2="0" width="0.254" layer="94"/>
<wire x1="-6.985" y1="-7.62" x2="4.445" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="-6.985" y1="5.08" x2="-6.985" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="4.445" y1="5.08" x2="4.445" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="2.54" x2="-4.445" y2="2.54" width="0.1524" layer="94"/>
<wire x1="-4.445" y1="2.54" x2="-4.445" y2="0" width="0.1524" layer="94"/>
<wire x1="-4.445" y1="-2.54" x2="-4.445" y2="-5.08" width="0.1524" layer="94"/>
<wire x1="-4.445" y1="-5.08" x2="-7.62" y2="-5.08" width="0.1524" layer="94"/>
<wire x1="-6.985" y1="5.08" x2="4.445" y2="5.08" width="0.4064" layer="94"/>
<wire x1="3.81" y1="0" x2="1.27" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="3.556" y2="-4.826" width="0.1524" layer="94"/>
<wire x1="3.81" y1="-5.08" x2="5.08" y2="-5.08" width="0.1524" layer="94"/>
<wire x1="3.81" y1="0" x2="5.08" y2="0" width="0.1524" layer="94"/>
<wire x1="3.048" y1="-3.556" x2="3.556" y2="-4.826" width="0.1524" layer="94"/>
<wire x1="3.556" y1="-4.826" x2="3.81" y2="-5.08" width="0.1524" layer="94"/>
<wire x1="3.556" y1="-4.826" x2="2.286" y2="-4.318" width="0.1524" layer="94"/>
<wire x1="2.286" y1="-4.318" x2="3.048" y2="-3.556" width="0.1524" layer="94"/>
<text x="-6.985" y="5.715" size="1.778" layer="95">&gt;NAME</text>
<text x="-6.985" y="-10.16" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="0.889" y1="-5.08" x2="1.651" y2="0" layer="94"/>
<pin name="A" x="-10.16" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="C" x="-10.16" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="BAS" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="EMI" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="COL" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="4N35" prefix="OK">
<description>&lt;b&gt;MOTOROLA OPTO COUPLER&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="OK-B" x="0" y="2.54"/>
</gates>
<devices>
<device name="" package="DIL06">
<connects>
<connect gate="G$1" pin="A" pad="1"/>
<connect gate="G$1" pin="BAS" pad="6"/>
<connect gate="G$1" pin="C" pad="2"/>
<connect gate="G$1" pin="COL" pad="5"/>
<connect gate="G$1" pin="EMI" pad="4"/>
</connects>
<technologies>
<technology name="">
<attribute name="MF" value="FAIRCHILD SEMICONDUCTOR" constant="no"/>
<attribute name="MPN" value="4N35" constant="no"/>
<attribute name="OC_FARNELL" value="1328375" constant="no"/>
<attribute name="OC_NEWARK" value="72K9946" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="led">
<description>&lt;b&gt;LEDs&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;br&gt;
Extended by Federico Battaglin &lt;author&gt;&amp;lt;federico.rd@fdpinternational.com&amp;gt;&lt;/author&gt; with DUOLED</description>
<packages>
<package name="1206">
<description>&lt;b&gt;CHICAGO MINIATURE LAMP, INC.&lt;/b&gt;&lt;p&gt;
7022X Series SMT LEDs 1206 Package Size</description>
<wire x1="1.55" y1="-0.75" x2="-1.55" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="-1.55" y1="-0.75" x2="-1.55" y2="0.75" width="0.1016" layer="51"/>
<wire x1="-1.55" y1="0.75" x2="1.55" y2="0.75" width="0.1016" layer="51"/>
<wire x1="1.55" y1="0.75" x2="1.55" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="-0.55" y1="-0.5" x2="0.55" y2="-0.5" width="0.1016" layer="21" curve="95.452622"/>
<wire x1="-0.55" y1="-0.5" x2="-0.55" y2="0.5" width="0.1016" layer="51" curve="-84.547378"/>
<wire x1="-0.55" y1="0.5" x2="0.55" y2="0.5" width="0.1016" layer="21" curve="-95.452622"/>
<wire x1="0.55" y1="0.5" x2="0.55" y2="-0.5" width="0.1016" layer="51" curve="-84.547378"/>
<smd name="A" x="-1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<smd name="C" x="1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.1" y1="-0.1" x2="0.1" y2="0.1" layer="21"/>
<rectangle x1="0.45" y1="-0.7" x2="0.8" y2="-0.45" layer="51"/>
<rectangle x1="0.8" y1="-0.7" x2="0.9" y2="0.5" layer="51"/>
<rectangle x1="0.8" y1="0.55" x2="0.9" y2="0.7" layer="51"/>
<rectangle x1="-0.9" y1="-0.7" x2="-0.8" y2="0.5" layer="51"/>
<rectangle x1="-0.9" y1="0.55" x2="-0.8" y2="0.7" layer="51"/>
<rectangle x1="0.45" y1="-0.7" x2="0.6" y2="-0.45" layer="21"/>
</package>
<package name="LD260">
<description>&lt;B&gt;LED&lt;/B&gt;&lt;p&gt;
5 mm, square, Siemens</description>
<wire x1="-1.27" y1="-1.27" x2="0" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0" y1="-1.27" x2="1.27" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.27" x2="0" y2="1.27" width="0.1524" layer="21"/>
<wire x1="0" y1="1.27" x2="-1.27" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-1.27" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.27" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.889" x2="1.27" y2="0" width="0.1524" layer="51"/>
<wire x1="1.27" y1="0" x2="1.27" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.27" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.889" x2="-1.27" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="0.889" width="0.1524" layer="51"/>
<wire x1="0" y1="1.27" x2="0.9917" y2="0.7934" width="0.1524" layer="21" curve="-51.33923"/>
<wire x1="-0.9917" y1="0.7934" x2="0" y2="1.27" width="0.1524" layer="21" curve="-51.33923"/>
<wire x1="0" y1="-1.27" x2="0.9917" y2="-0.7934" width="0.1524" layer="21" curve="51.33923"/>
<wire x1="-0.9917" y1="-0.7934" x2="0" y2="-1.27" width="0.1524" layer="21" curve="51.33923"/>
<wire x1="0.9558" y1="-0.8363" x2="1.27" y2="0" width="0.1524" layer="51" curve="41.185419"/>
<wire x1="0.9756" y1="0.813" x2="1.2699" y2="0" width="0.1524" layer="51" curve="-39.806332"/>
<wire x1="-1.27" y1="0" x2="-0.9643" y2="-0.8265" width="0.1524" layer="51" curve="40.600331"/>
<wire x1="-1.27" y1="0" x2="-0.9643" y2="0.8265" width="0.1524" layer="51" curve="-40.600331"/>
<wire x1="-0.889" y1="0" x2="0" y2="0.889" width="0.1524" layer="51" curve="-90"/>
<wire x1="-0.508" y1="0" x2="0" y2="0.508" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-0.508" x2="0.508" y2="0" width="0.1524" layer="21" curve="90"/>
<wire x1="0" y1="-0.889" x2="0.889" y2="0" width="0.1524" layer="51" curve="90"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="K" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-1.2954" y="1.4732" size="1.016" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-2.4892" size="1.016" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="1.27" y1="-0.635" x2="2.032" y2="0.635" layer="51"/>
<rectangle x1="1.905" y1="-0.635" x2="2.032" y2="0.635" layer="21"/>
</package>
<package name="LED2X5">
2 x 5 mm, rectangle</description>
<wire x1="-2.54" y1="-1.27" x2="2.54" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.27" x2="2.54" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.27" x2="-2.54" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.27" x2="-2.54" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0" x2="0.508" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="0.381" x2="-0.508" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="0.381" x2="0.508" y2="0" width="0.1524" layer="51"/>
<wire x1="0.508" y1="0" x2="1.778" y2="0" width="0.1524" layer="51"/>
<wire x1="0.508" y1="0" x2="-0.508" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="0.508" y1="0.381" x2="0.508" y2="0" width="0.1524" layer="51"/>
<wire x1="0.508" y1="0" x2="0.508" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="0.889" y1="-0.254" x2="1.143" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.762" x2="1.143" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.762" x2="0.9398" y2="-0.6096" width="0.1524" layer="51"/>
<wire x1="0.9398" y1="-0.6096" x2="1.143" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="1.397" y1="-0.254" x2="1.651" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-0.762" x2="1.651" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-0.762" x2="1.4478" y2="-0.6096" width="0.1524" layer="51"/>
<wire x1="1.4478" y1="-0.6096" x2="1.651" y2="-0.508" width="0.1524" layer="51"/>
<text x="-2.54" y="1.397" size="1.016" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-2.413" size="1.016" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.159" y1="-1.27" x2="2.413" y2="1.27" layer="21"/>
</package>
<package name="LED3MM">
3 mm, round</description>
<wire x1="1.5748" y1="-1.27" x2="1.5748" y2="1.27" width="0.254" layer="51"/>
<wire x1="-1.524" y1="0" x2="-1.1708" y2="0.9756" width="0.1524" layer="51" curve="-39.80361"/>
<wire x1="-1.524" y1="0" x2="-1.1391" y2="-1.0125" width="0.1524" layer="51" curve="41.633208"/>
<wire x1="1.1571" y1="0.9918" x2="1.524" y2="0" width="0.1524" layer="51" curve="-40.601165"/>
<wire x1="1.1708" y1="-0.9756" x2="1.524" y2="0" width="0.1524" layer="51" curve="39.80361"/>
<wire x1="0" y1="1.524" x2="1.2401" y2="0.8858" width="0.1524" layer="21" curve="-54.461337"/>
<wire x1="-1.2192" y1="0.9144" x2="0" y2="1.524" width="0.1524" layer="21" curve="-53.130102"/>
<wire x1="0" y1="-1.524" x2="1.203" y2="-0.9356" width="0.1524" layer="21" curve="52.126876"/>
<wire x1="-1.203" y1="-0.9356" x2="0" y2="-1.524" width="0.1524" layer="21" curve="52.126876"/>
<wire x1="-0.635" y1="0" x2="0" y2="0.635" width="0.1524" layer="51" curve="-90"/>
<wire x1="-1.016" y1="0" x2="0" y2="1.016" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-0.635" x2="0.635" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="0" y1="-1.016" x2="1.016" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="0" y1="2.032" x2="1.561" y2="1.3009" width="0.254" layer="21" curve="-50.193108"/>
<wire x1="-1.7929" y1="0.9562" x2="0" y2="2.032" width="0.254" layer="21" curve="-61.926949"/>
<wire x1="0" y1="-2.032" x2="1.5512" y2="-1.3126" width="0.254" layer="21" curve="49.763022"/>
<wire x1="-1.7643" y1="-1.0082" x2="0" y2="-2.032" width="0.254" layer="21" curve="60.255215"/>
<wire x1="-2.032" y1="0" x2="-1.7891" y2="0.9634" width="0.254" layer="51" curve="-28.301701"/>
<wire x1="-2.032" y1="0" x2="-1.7306" y2="-1.065" width="0.254" layer="51" curve="31.60822"/>
<text x="1.905" y="0.381" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="1.905" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="LED5MM">
5 mm, round</description>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="1.905" width="0.2032" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="1.905" width="0.254" layer="21" curve="-286.260205"/>
<wire x1="-1.143" y1="0" x2="0" y2="1.143" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-1.143" x2="1.143" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="-1.651" y1="0" x2="0" y2="1.651" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-1.651" x2="1.651" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="-2.159" y1="0" x2="0" y2="2.159" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-2.159" x2="2.159" y2="0" width="0.1524" layer="51" curve="90"/>
<circle x="0" y="0" radius="2.54" width="0.1524" layer="21"/>
<text x="3.175" y="0.5334" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.2004" y="-1.8034" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="LSU260">
1 mm, round, Siemens</description>
<wire x1="0" y1="-0.508" x2="-1.143" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="-0.508" x2="-1.143" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="0.508" x2="0" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="-0.254" x2="-1.397" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="-0.254" x2="-1.143" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-1.397" y1="-0.254" x2="-1.397" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-1.397" y1="0.254" x2="-1.143" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="0.254" x2="-1.143" y2="0.508" width="0.1524" layer="51"/>
<wire x1="0.508" y1="-0.254" x2="1.397" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="1.397" y1="-0.254" x2="1.397" y2="0.254" width="0.1524" layer="51"/>
<wire x1="1.397" y1="0.254" x2="0.508" y2="0.254" width="0.1524" layer="51"/>
<wire x1="0.381" y1="-0.381" x2="0.254" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-0.508" x2="-0.254" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-0.381" x2="-0.254" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.381" y1="0.381" x2="0.254" y2="0.508" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0.508" x2="-0.254" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0.381" x2="-0.254" y2="0.508" width="0.1524" layer="21"/>
<wire x1="0" y1="-0.254" x2="0.254" y2="0" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.254" y1="0" x2="0" y2="0.254" width="0.1524" layer="21" curve="-90"/>
<wire x1="0.381" y1="-0.381" x2="0.381" y2="0.381" width="0.1524" layer="21" curve="90"/>
<circle x="0" y="0" radius="0.508" width="0.1524" layer="51"/>
<text x="-1.2954" y="0.8382" size="1.016" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-1.8542" size="1.016" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.397" y1="-0.254" x2="-1.143" y2="0.254" layer="51"/>
<rectangle x1="0.508" y1="-0.254" x2="1.397" y2="0.254" layer="51"/>
</package>
<package name="LZR181">
<description>&lt;B&gt;LED BLOCK&lt;/B&gt;&lt;p&gt;
1 LED, Siemens</description>
<wire x1="-1.27" y1="-1.27" x2="1.27" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.889" x2="1.27" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="-0.889" x2="-1.27" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-0.8678" y1="0.7439" x2="0" y2="1.143" width="0.1524" layer="21" curve="-49.396139"/>
<wire x1="0" y1="1.143" x2="0.8678" y2="0.7439" width="0.1524" layer="21" curve="-49.396139"/>
<wire x1="-0.8678" y1="-0.7439" x2="0" y2="-1.143" width="0.1524" layer="21" curve="49.396139"/>
<wire x1="0" y1="-1.143" x2="0.8678" y2="-0.7439" width="0.1524" layer="21" curve="49.396139"/>
<wire x1="0.8678" y1="0.7439" x2="1.143" y2="0" width="0.1524" layer="51" curve="-40.604135"/>
<wire x1="0.8678" y1="-0.7439" x2="1.143" y2="0" width="0.1524" layer="51" curve="40.604135"/>
<wire x1="-1.143" y1="0" x2="-0.8678" y2="0.7439" width="0.1524" layer="51" curve="-40.604135"/>
<wire x1="-1.143" y1="0" x2="-0.8678" y2="-0.7439" width="0.1524" layer="51" curve="40.604135"/>
<wire x1="-1.27" y1="1.27" x2="1.27" y2="1.27" width="0.1524" layer="21"/>
<rectangle x1="1.27" y1="-0.889" x2="1.524" y2="0.254" layer="51"/>
<rectangle x1="-1.524" y1="-0.254" x2="-1.27" y2="0.254" layer="51"/>
</package>
<package name="Q62902-B152">
<description>&lt;b&gt;LED HOLDER&lt;/b&gt;&lt;p&gt;
<wire x1="-2.9718" y1="-1.8542" x2="-2.9718" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="-0.254" x2="-2.9718" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="0.254" x2="-2.9718" y2="1.8542" width="0.1524" layer="21"/>
<wire x1="2.9718" y1="-1.8542" x2="-2.1082" y2="-1.8542" width="0.1524" layer="21"/>
<wire x1="-2.1082" y1="-1.8542" x2="-2.54" y2="-1.8542" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.8542" x2="-2.1082" y2="1.8542" width="0.1524" layer="21"/>
<wire x1="-2.1082" y1="1.8542" x2="2.9718" y2="1.8542" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.8542" x2="-2.54" y2="1.8542" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.8542" x2="-2.9718" y2="-1.8542" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.8542" x2="-2.9718" y2="1.8542" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="0.254" x2="-2.9718" y2="-0.254" width="0.1524" layer="21" curve="180"/>
<wire x1="-1.1486" y1="0.8814" x2="0" y2="1.4478" width="0.1524" layer="21" curve="-52.498642"/>
<wire x1="0" y1="1.4478" x2="1.1476" y2="0.8827" width="0.1524" layer="21" curve="-52.433716"/>
<wire x1="-1.1351" y1="-0.8987" x2="0" y2="-1.4478" width="0.1524" layer="21" curve="51.629985"/>
<wire x1="0" y1="-1.4478" x2="1.1305" y2="-0.9044" width="0.1524" layer="21" curve="51.339172"/>
<wire x1="1.1281" y1="-0.9074" x2="1.4478" y2="0" width="0.1524" layer="51" curve="38.811177"/>
<wire x1="1.1401" y1="0.8923" x2="1.4478" y2="0" width="0.1524" layer="51" curve="-38.048073"/>
<wire x1="-1.4478" y1="0" x2="-1.1305" y2="-0.9044" width="0.1524" layer="51" curve="38.659064"/>
<wire x1="-1.4478" y1="0" x2="-1.1456" y2="0.8853" width="0.1524" layer="51" curve="-37.696376"/>
<wire x1="0" y1="1.7018" x2="1.4674" y2="0.8618" width="0.1524" layer="21" curve="-59.573488"/>
<wire x1="-1.4618" y1="0.8714" x2="0" y2="1.7018" width="0.1524" layer="21" curve="-59.200638"/>
<wire x1="0" y1="-1.7018" x2="1.4571" y2="-0.8793" width="0.1524" layer="21" curve="58.891781"/>
<wire x1="-1.4571" y1="-0.8793" x2="0" y2="-1.7018" width="0.1524" layer="21" curve="58.891781"/>
<wire x1="-1.7018" y1="0" x2="-1.4447" y2="0.8995" width="0.1524" layer="51" curve="-31.907626"/>
<wire x1="-1.7018" y1="0" x2="-1.4502" y2="-0.8905" width="0.1524" layer="51" curve="31.551992"/>
<wire x1="1.4521" y1="0.8874" x2="1.7018" y2="0" width="0.1524" layer="51" curve="-31.429586"/>
<wire x1="1.4459" y1="-0.8975" x2="1.7018" y2="0" width="0.1524" layer="51" curve="31.828757"/>
<wire x1="-2.1082" y1="1.8542" x2="-2.1082" y2="-1.8542" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="0" y2="0.635" width="0.1524" layer="21" curve="-90"/>
<wire x1="0.0539" y1="-1.0699" x2="1.0699" y2="-0.0539" width="0.1524" layer="51" curve="90"/>
<wire x1="2.9718" y1="1.8542" x2="2.9718" y2="-1.8542" width="0.1524" layer="21"/>
<pad name="K" x="-1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="A" x="1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-1.905" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.905" y="-3.556" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="Q62902-B153">
<wire x1="-5.5118" y1="-3.5052" x2="-5.5118" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-5.5118" y1="-0.254" x2="-5.5118" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-5.5118" y1="0.254" x2="-5.5118" y2="3.5052" width="0.1524" layer="21"/>
<wire x1="5.5118" y1="-3.5052" x2="-4.6482" y2="-3.5052" width="0.1524" layer="21"/>
<wire x1="-4.6482" y1="-3.5052" x2="-5.08" y2="-3.5052" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.5052" x2="-4.6482" y2="3.5052" width="0.1524" layer="21"/>
<wire x1="-4.6482" y1="3.5052" x2="5.5118" y2="3.5052" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.5052" x2="-5.08" y2="3.5052" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.5052" x2="-5.5118" y2="-3.5052" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.5052" x2="-5.5118" y2="3.5052" width="0.1524" layer="21"/>
<wire x1="-5.5118" y1="0.254" x2="-5.5118" y2="-0.254" width="0.1524" layer="21" curve="180"/>
<wire x1="-4.6482" y1="3.5052" x2="-4.6482" y2="-3.5052" width="0.1524" layer="21"/>
<wire x1="5.5118" y1="3.5052" x2="5.5118" y2="-3.5052" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.54" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-2.2129" y1="0.0539" x2="-0.0539" y2="2.2129" width="0.1524" layer="51" curve="-90.010616"/>
<circle x="0" y="0" radius="3.175" width="0.254" layer="21"/>
<text x="-4.191" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-5.08" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="Q62902-B155">
<wire x1="-1.27" y1="-3.048" x2="-1.27" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="10.033" y1="3.048" x2="2.921" y2="3.048" width="0.1524" layer="21"/>
<wire x1="10.033" y1="3.048" x2="10.033" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-3.048" x2="2.921" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-3.048" x2="2.921" y2="3.048" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-3.048" x2="10.033" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="2.921" y1="3.048" x2="-1.27" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.54" x2="-5.207" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.54" x2="-1.27" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-2.54" x2="-1.27" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-2.54" x2="-1.27" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.54" x2="-5.207" y2="-2.54" width="0.1524" layer="21" curve="180"/>
<wire x1="-6.985" y1="0.635" x2="-6.985" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="1.397" x2="-6.096" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="1.905" x2="-5.207" y2="-1.905" width="0.1524" layer="21"/>
<pad name="K" x="7.62" y="1.27" drill="0.8128" shape="long"/>
<pad name="A" x="7.62" y="-1.27" drill="0.8128" shape="long"/>
<text x="3.302" y="-2.794" size="1.016" layer="21" ratio="14">A+</text>
<text x="3.302" y="1.778" size="1.016" layer="21" ratio="14">K-</text>
<text x="11.684" y="-2.794" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="0.635" y="-4.445" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.921" y1="1.016" x2="6.731" y2="1.524" layer="21"/>
<rectangle x1="2.921" y1="-1.524" x2="6.731" y2="-1.016" layer="21"/>
<hole x="0" y="0" drill="0.8128"/>
</package>
<package name="Q62902-B156">
<wire x1="2.54" y1="-1.905" x2="2.54" y2="1.905" width="0.1524" layer="21"/>
<wire x1="0.0539" y1="-2.2129" x2="2.2129" y2="-0.0539" width="0.1524" layer="51" curve="90.005308"/>
<wire x1="2.54" y1="3.81" x2="3.81" y2="2.54" width="0.1524" layer="21"/>
<wire x1="2.54" y1="3.81" x2="-3.81" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-3.81" x2="-3.81" y2="3.81" width="0.1524" layer="21"/>
<wire x1="3.81" y1="2.54" x2="3.81" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-3.81" x2="-2.54" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-3.302" x2="-2.54" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-3.81" x2="2.54" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-3.302" x2="2.54" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-3.302" x2="-2.54" y2="-3.302" width="0.1524" layer="21"/>
<pad name="A" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="K" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-3.81" y="4.0894" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.7846" y="-5.3594" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.556" y="-3.302" size="1.016" layer="21" ratio="14">+</text>
<text x="2.794" y="-3.302" size="1.016" layer="21" ratio="14">-</text>
</package>
<package name="SFH480">
<description>&lt;B&gt;IR LED&lt;/B&gt;&lt;p&gt;
infrared emitting diode, Infineon
TO-18, lead spacing 2.54 mm, cathode marking&lt;p&gt;
Inifineon</description>
<wire x1="-2.159" y1="1.524" x2="-2.794" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="2.159" x2="-2.159" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="2.159" x2="-2.159" y2="2.794" width="0.1524" layer="21"/>
<wire x1="0" y1="1.778" x2="1.5358" y2="0.8959" width="0.1524" layer="21" curve="-59.743278"/>
<wire x1="-1.5358" y1="0.8959" x2="0" y2="1.778" width="0.1524" layer="21" curve="-59.743278"/>
<wire x1="-1.5358" y1="-0.8959" x2="0" y2="-1.778" width="0.1524" layer="21" curve="59.743278"/>
<wire x1="0" y1="-1.778" x2="1.5358" y2="-0.8959" width="0.1524" layer="21" curve="59.743278"/>
<wire x1="1.5142" y1="0.9318" x2="1.778" y2="0" width="0.1524" layer="51" curve="-31.606487"/>
<wire x1="1.5" y1="-0.9546" x2="1.778" y2="0" width="0.1524" layer="51" curve="32.472615"/>
<wire x1="-1.778" y1="0" x2="-1.5142" y2="-0.9318" width="0.1524" layer="51" curve="31.606487"/>
<wire x1="-1.778" y1="0" x2="-1.5" y2="0.9546" width="0.1524" layer="51" curve="-32.472615"/>
<circle x="0" y="0" radius="2.667" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.413" width="0.254" layer="21"/>
<text x="-1.27" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-4.318" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SFH482">
<pad name="K" x="1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
</package>
<package name="U57X32">
rectangle, 5.7 x 3.2 mm</description>
<wire x1="-3.175" y1="1.905" x2="3.175" y2="1.905" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.905" x2="3.175" y2="1.905" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.905" x2="-3.175" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.905" x2="-3.175" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="1.397" x2="2.667" y2="1.397" width="0.1524" layer="21"/>
<wire x1="2.667" y1="-1.397" x2="2.667" y2="1.397" width="0.1524" layer="21"/>
<wire x1="2.667" y1="-1.397" x2="-2.667" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="1.397" x2="-2.667" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.016" x2="2.54" y2="1.016" width="0.1524" layer="51"/>
<wire x1="2.286" y1="1.27" x2="2.286" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="0.508" x2="2.54" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="0" x2="2.54" y2="0" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-0.508" x2="2.54" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-1.016" x2="2.54" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-2.286" y1="1.27" x2="-2.286" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-1.778" y1="1.27" x2="-1.778" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="0.254" y1="1.27" x2="0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="0.762" y1="1.27" x2="0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="1.27" y1="1.27" x2="1.27" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="1.778" y1="1.27" x2="1.778" y2="-1.27" width="0.1524" layer="51"/>
<text x="3.683" y="0.254" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.683" y="-1.524" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="IRL80A">
IR transmitter Siemens</description>
<wire x1="0.889" y1="2.286" x2="0.889" y2="1.778" width="0.1524" layer="21"/>
<wire x1="0.889" y1="1.778" x2="0.889" y2="0.762" width="0.1524" layer="51"/>
<wire x1="0.889" y1="0.762" x2="0.889" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-0.635" x2="0.889" y2="-1.778" width="0.1524" layer="51"/>
<wire x1="0.889" y1="-1.778" x2="0.889" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-2.286" x2="-0.889" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="2.286" x2="-0.889" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.778" x2="-0.889" y2="0.762" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="0.762" x2="-0.889" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-0.762" x2="-0.889" y2="-1.778" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="-1.778" x2="-0.889" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="2.286" x2="0.889" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-0.762" x2="-0.889" y2="0.762" width="0.1524" layer="21" curve="-180"/>
<wire x1="-1.397" y1="0.254" x2="-1.397" y2="-0.254" width="0.0508" layer="21"/>
<wire x1="-1.143" y1="0.508" x2="-1.143" y2="-0.508" width="0.0508" layer="21"/>
<pad name="K" x="0" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="A" x="0" y="-1.27" drill="0.8128" shape="octagon"/>
<text x="1.27" y="0.381" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="1.27" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="P-LCC-2">
<description>&lt;b&gt;TOPLED® High-optical Power LED (HOP)&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... ls_t675.pdf</description>
<wire x1="-1.4" y1="-1.05" x2="-1.4" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="-1.4" y1="-1.6" x2="-1.1" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="-1.1" y1="-1.6" x2="-0.85" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="-0.85" y1="-1.6" x2="1.1" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="1.1" y1="-1.6" x2="1.4" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="1.4" y1="-1.6" x2="1.4" y2="1.6" width="0.2032" layer="51"/>
<wire x1="1.4" y1="1.6" x2="1.1" y2="1.6" width="0.2032" layer="51"/>
<wire x1="1.1" y1="1.6" x2="-1.1" y2="1.6" width="0.2032" layer="51"/>
<wire x1="-1.1" y1="1.6" x2="-1.4" y2="1.6" width="0.2032" layer="51"/>
<wire x1="-1.1" y1="1.6" x2="-1.1" y2="1.8" width="0.1016" layer="51"/>
<wire x1="-1.1" y1="1.8" x2="1.1" y2="1.8" width="0.1016" layer="51"/>
<wire x1="1.1" y1="1.8" x2="1.1" y2="1.6" width="0.1016" layer="51"/>
<wire x1="-1.1" y1="-1.6" x2="-1.1" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="-1.1" y1="-1.8" x2="1.1" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="1.1" y1="-1.8" x2="1.1" y2="-1.6" width="0.1016" layer="51"/>
<wire x1="-0.85" y1="-1.6" x2="-1.4" y2="-1.05" width="0.2032" layer="51"/>
<wire x1="-1.4" y1="1.6" x2="-1.4" y2="-1.05" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="1.1" width="0.2032" layer="51"/>
<smd name="C" x="0" y="-2.75" dx="4" dy="4" layer="1" stop="no" cream="no"/>
<smd name="A" x="0" y="2.75" dx="4" dy="4" layer="1" stop="no" cream="no"/>
<text x="-2.54" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.81" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<text x="-0.635" y="2.54" size="1.27" layer="21">A</text>
<text x="-0.635" y="-3.81" size="1.27" layer="21">C</text>
<rectangle x1="-1.3" y1="-2.25" x2="1.3" y2="-0.75" layer="31"/>
<rectangle x1="-1.3" y1="0.75" x2="1.3" y2="2.25" layer="31"/>
<rectangle x1="-0.25" y1="-0.25" x2="0.25" y2="0.25" layer="21"/>
<rectangle x1="-1.4" y1="0.65" x2="1.4" y2="2.35" layer="29"/>
<rectangle x1="-1.4" y1="-2.35" x2="1.4" y2="-0.65" layer="29"/>
</package>
<package name="OSRAM-MINI-TOP-LED">
<description>&lt;b&gt;BLUE LINETM Hyper Mini TOPLED® Hyper-Bright LED&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... LB M676.pdf</description>
<wire x1="-0.6" y1="0.9" x2="-0.6" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="-0.45" y1="-0.9" x2="-0.4" y2="-0.9" width="0.1016" layer="51"/>
<wire x1="-0.4" y1="-0.9" x2="0.6" y2="-0.9" width="0.1016" layer="51"/>
<wire x1="0.6" y1="-0.9" x2="0.6" y2="0.9" width="0.1016" layer="51"/>
<wire x1="0.6" y1="0.9" x2="-0.6" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-0.45" y1="0.95" x2="-0.45" y2="1.1" width="0.1016" layer="51"/>
<wire x1="-0.45" y1="1.1" x2="0.45" y2="1.1" width="0.1016" layer="51"/>
<wire x1="0.45" y1="1.1" x2="0.45" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-0.6" y1="-0.7" x2="-0.4" y2="-0.9" width="0.1016" layer="51"/>
<wire x1="-0.45" y1="-0.9" x2="-0.45" y2="-1.1" width="0.1016" layer="51"/>
<wire x1="-0.45" y1="-1.1" x2="0.45" y2="-1.1" width="0.1016" layer="51"/>
<wire x1="0.45" y1="-1.1" x2="0.45" y2="-0.95" width="0.1016" layer="51"/>
<smd name="A" x="0" y="2.6" dx="4" dy="4" layer="1" stop="no" cream="no"/>
<smd name="C" x="0" y="-2.6" dx="4" dy="4" layer="1" stop="no" cream="no"/>
<text x="-0.635" y="1.905" size="1.27" layer="21">A</text>
<text x="-0.635" y="-3.175" size="1.27" layer="21">C</text>
<rectangle x1="-0.5" y1="0.6" x2="0.5" y2="1.4" layer="29"/>
<rectangle x1="-0.5" y1="-1.4" x2="0.5" y2="-0.6" layer="29"/>
<rectangle x1="-0.15" y1="-0.6" x2="0.15" y2="-0.3" layer="51"/>
<rectangle x1="-0.45" y1="0.65" x2="0.45" y2="1.35" layer="31"/>
<rectangle x1="-0.45" y1="-1.35" x2="0.45" y2="-0.65" layer="31"/>
</package>
<package name="OSRAM-SIDELED">
<description>&lt;b&gt;Super SIDELED® High-Current LED&lt;/b&gt;&lt;p&gt;
LG A672, LP A672 &lt;br&gt;
Source: http://www.osram.convergy.de/ ... LG_LP_A672.pdf (2004.05.13)</description>
<wire x1="-1.85" y1="-2.05" x2="-1.85" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="-1.85" y1="-0.75" x2="-1.7" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="-1.7" y1="-0.75" x2="-1.7" y2="0.75" width="0.1016" layer="51"/>
<wire x1="-1.7" y1="0.75" x2="-1.85" y2="0.75" width="0.1016" layer="51"/>
<wire x1="-1.85" y1="0.75" x2="-1.85" y2="2.05" width="0.1016" layer="51"/>
<wire x1="-1.85" y1="2.05" x2="0.9" y2="2.05" width="0.1016" layer="51"/>
<wire x1="0.9" y1="2.05" x2="0.9" y2="-2.05" width="0.1016" layer="51"/>
<wire x1="0.9" y1="-2.05" x2="-1.85" y2="-2.05" width="0.1016" layer="51"/>
<wire x1="0.9" y1="-2.05" x2="1.05" y2="-2.05" width="0.1016" layer="51"/>
<wire x1="1.05" y1="-2.05" x2="1.85" y2="-1.85" width="0.1016" layer="51"/>
<wire x1="1.85" y1="-1.85" x2="1.85" y2="1.85" width="0.1016" layer="51"/>
<wire x1="1.85" y1="1.85" x2="1.05" y2="2.05" width="0.1016" layer="51"/>
<wire x1="1.05" y1="2.05" x2="0.9" y2="2.05" width="0.1016" layer="51"/>
<wire x1="1.05" y1="2.05" x2="1.05" y2="-2.05" width="0.1016" layer="51"/>
<wire x1="-0.55" y1="-0.9" x2="-0.55" y2="0.9" width="0.1016" layer="51" curve="-167.319617"/>
<wire x1="-0.55" y1="-0.9" x2="0.85" y2="-1.2" width="0.1016" layer="51" style="shortdash"/>
<wire x1="-0.55" y1="0.9" x2="0.85" y2="1.2" width="0.1016" layer="51" style="shortdash"/>
<smd name="C" x="0" y="-2.5" dx="4" dy="4" layer="1" stop="no" cream="no"/>
<smd name="A" x="0" y="2.5" dx="4" dy="4" layer="1" stop="no" cream="no"/>
<text x="0.635" y="-3.175" size="1.27" layer="21" rot="R90">C</text>
<text x="0.635" y="2.54" size="1.27" layer="21" rot="R90">A</text>
<text x="-2.54" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.81" y="-2.54" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.1" y1="-2.2" x2="2.1" y2="-0.4" layer="29"/>
<rectangle x1="-2.1" y1="0.4" x2="2.1" y2="2.2" layer="29"/>
<rectangle x1="-1.9" y1="-2.1" x2="1.9" y2="-0.6" layer="31"/>
<rectangle x1="-1.9" y1="0.6" x2="1.9" y2="2.1" layer="31"/>
<rectangle x1="-1.85" y1="-2.05" x2="-0.7" y2="-1" layer="51"/>
</package>
<package name="SMART-LED">
<description>&lt;b&gt;SmartLEDTM Hyper-Bright LED&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... LA_LO_LS_LY L896.pdf</description>
<wire x1="-0.35" y1="0.6" x2="0.35" y2="0.6" width="0.1016" layer="51" style="shortdash"/>
<wire x1="0.35" y1="0.6" x2="0.35" y2="-0.6" width="0.1016" layer="21" style="shortdash"/>
<wire x1="0.35" y1="-0.6" x2="0.15" y2="-0.6" width="0.1016" layer="51" style="shortdash"/>
<wire x1="0.15" y1="-0.6" x2="-0.35" y2="-0.6" width="0.1016" layer="51" style="shortdash"/>
<wire x1="-0.35" y1="-0.6" x2="-0.35" y2="0.6" width="0.1016" layer="21" style="shortdash"/>
<wire x1="0.35" y1="-0.4" x2="0.15" y2="-0.6" width="0.1016" layer="51" style="shortdash"/>
<smd name="A" x="0" y="0.725" dx="0.35" dy="0.35" layer="1"/>
<smd name="B" x="0" y="-0.725" dx="0.35" dy="0.35" layer="1"/>
<text x="-0.635" y="-0.635" size="1.016" layer="25" rot="R90">&gt;NAME</text>
<text x="1.905" y="-0.635" size="1.016" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.15" y1="-0.35" x2="0.15" y2="-0.05" layer="21"/>
<rectangle x1="-0.15" y1="0.6" x2="0.15" y2="0.85" layer="51"/>
<rectangle x1="-0.15" y1="-0.85" x2="0.15" y2="-0.6" layer="51"/>
</package>
<package name="P-LCC-2-TOPLED-RG">
<description>&lt;b&gt;Hyper TOPLED® RG Hyper-Bright LED&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... LA_LO_LS_LY T776.pdf</description>
<wire x1="-1.1" y1="1.6" x2="-1.1" y2="2.45" width="0.1016" layer="51"/>
<wire x1="1.1" y1="2.45" x2="1.1" y2="1.6" width="0.1016" layer="51"/>
<wire x1="-1.1" y1="-1.6" x2="-1.1" y2="-2.45" width="0.1016" layer="51"/>
<wire x1="1.1" y1="-2.45" x2="1.1" y2="-1.6" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="1.1" width="0.2032" layer="21"/>
<smd name="C" x="0" y="-3.5" dx="4" dy="4" layer="1" stop="no" cream="no"/>
<smd name="A" x="0" y="3.5" dx="4" dy="4" layer="1" stop="no" cream="no"/>
<text x="-0.635" y="3.29" size="1.27" layer="21">A</text>
<text x="-0.635" y="-4.56" size="1.27" layer="21">C</text>
<rectangle x1="-1.3" y1="-3" x2="1.3" y2="-1.5" layer="31"/>
<rectangle x1="-1.3" y1="1.5" x2="1.3" y2="3" layer="31"/>
<rectangle x1="-1.15" y1="2.4" x2="1.15" y2="2.7" layer="51"/>
<rectangle x1="-1.15" y1="-2.7" x2="1.15" y2="-2.4" layer="51"/>
<rectangle x1="-1.5" y1="1.5" x2="1.5" y2="3.2" layer="29"/>
<rectangle x1="-1.5" y1="-3.2" x2="1.5" y2="-1.5" layer="29"/>
<hole x="0" y="0" drill="2.8"/>
</package>
<package name="MICRO-SIDELED">
<description>&lt;b&gt;Hyper Micro SIDELED®&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... LA_LO_LS_LY Y876.pdf</description>
<wire x1="0.65" y1="1.1" x2="-0.1" y2="1.1" width="0.1016" layer="51"/>
<wire x1="-0.1" y1="1.1" x2="-0.35" y2="1" width="0.1016" layer="51"/>
<wire x1="-0.35" y1="1" x2="-0.35" y2="-0.9" width="0.1016" layer="21"/>
<wire x1="-0.35" y1="-0.9" x2="-0.1" y2="-1.1" width="0.1016" layer="51"/>
<wire x1="-0.1" y1="-1.1" x2="0.65" y2="-1.1" width="0.1016" layer="51"/>
<wire x1="0.65" y1="-1.1" x2="0.65" y2="1.1" width="0.1016" layer="21"/>
<wire x1="0.6" y1="0.9" x2="0.25" y2="0.7" width="0.0508" layer="21"/>
<wire x1="0.25" y1="0.7" x2="0.25" y2="-0.7" width="0.0508" layer="21"/>
<wire x1="0.25" y1="-0.7" x2="0.6" y2="-0.9" width="0.0508" layer="21"/>
<smd name="A" x="0" y="1.95" dx="1.6" dy="1.6" layer="1" stop="no" cream="no"/>
<smd name="C" x="0" y="-1.95" dx="1.6" dy="1.6" layer="1" stop="no" cream="no"/>
<text x="-1.27" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="2.54" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.4" y1="1.1" x2="0.4" y2="1.8" layer="29"/>
<rectangle x1="-0.4" y1="-1.8" x2="0.4" y2="-1.1" layer="29"/>
<rectangle x1="-0.35" y1="-1.75" x2="0.35" y2="-1.15" layer="31"/>
<rectangle x1="-0.35" y1="1.15" x2="0.35" y2="1.75" layer="31"/>
<rectangle x1="-0.125" y1="1.125" x2="0.125" y2="1.75" layer="51"/>
<rectangle x1="-0.125" y1="-1.75" x2="0.125" y2="-1.125" layer="51"/>
</package>
<package name="P-LCC-4">
<description>&lt;b&gt;Power TOPLED®&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... LA_LO_LA_LY E67B.pdf</description>
<wire x1="-1.4" y1="-1.6" x2="-1" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="-1" y1="-1.6" x2="-0.85" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="-0.85" y1="-1.6" x2="1" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="1" y1="-1.6" x2="1.4" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="1.1" y1="1.6" x2="-1" y2="1.6" width="0.2032" layer="51"/>
<wire x1="-1" y1="1.6" x2="-1.4" y2="1.6" width="0.2032" layer="51"/>
<wire x1="-1" y1="1.6" x2="-1" y2="1.8" width="0.1016" layer="51"/>
<wire x1="-1" y1="1.8" x2="-0.5" y2="1.8" width="0.1016" layer="51"/>
<wire x1="-0.5" y1="1.8" x2="-0.5" y2="1.65" width="0.1016" layer="51"/>
<wire x1="0.5" y1="1.65" x2="0.5" y2="1.8" width="0.1016" layer="51"/>
<wire x1="0.5" y1="1.8" x2="1.1" y2="1.8" width="0.1016" layer="51"/>
<wire x1="-1" y1="-1.6" x2="-1" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="-1" y1="-1.8" x2="-0.5" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="-0.5" y1="-1.8" x2="-0.5" y2="-1.65" width="0.1016" layer="51"/>
<wire x1="0.5" y1="-1.65" x2="0.5" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="0.5" y1="-1.8" x2="1" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="1" y1="-1.8" x2="1" y2="-1.6" width="0.1016" layer="51"/>
<smd name="A" x="-2" y="3.15" dx="3.3" dy="4.8" layer="1" stop="no" cream="no"/>
<smd name="C@3" x="2" y="3.15" dx="3.3" dy="4.8" layer="1" stop="no" cream="no"/>
<smd name="C@4" x="2" y="-3.15" dx="3.3" dy="4.8" layer="1" stop="no" cream="no"/>
<smd name="C@1" x="-2" y="-3.15" dx="3.3" dy="4.8" layer="1" stop="no" cream="no"/>
<text x="-3.81" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="5.08" y="-2.54" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<text x="-1.905" y="-3.81" size="1.27" layer="21">C</text>
<text x="-1.905" y="2.54" size="1.27" layer="21">A</text>
<text x="1.27" y="2.54" size="1.27" layer="21">C</text>
<text x="1.27" y="-3.81" size="1.27" layer="21">C</text>
<rectangle x1="-1.15" y1="0.75" x2="-0.35" y2="1.85" layer="29"/>
<rectangle x1="0.35" y1="0.75" x2="1.15" y2="1.85" layer="29"/>
<rectangle x1="0.35" y1="-1.85" x2="1.15" y2="-0.75" layer="29"/>
<rectangle x1="-1.15" y1="-1.85" x2="-0.35" y2="-0.75" layer="29"/>
<rectangle x1="-1.1" y1="-1.8" x2="-0.4" y2="-0.8" layer="31"/>
<rectangle x1="0.4" y1="-1.8" x2="1.1" y2="-0.8" layer="31"/>
<rectangle x1="0.4" y1="0.8" x2="1.1" y2="1.8" layer="31"/>
<rectangle x1="-1.1" y1="0.8" x2="-0.4" y2="1.8" layer="31"/>
<rectangle x1="-0.2" y1="-0.2" x2="0.2" y2="0.2" layer="21"/>
</package>
<package name="CHIP-LED0603">
<description>&lt;b&gt;Hyper CHIPLED Hyper-Bright LED&lt;/b&gt;&lt;p&gt;
LB Q993&lt;br&gt;
Source: http://www.osram.convergy.de/ ... Lb_q993.pdf</description>
<wire x1="-0.4" y1="0.45" x2="-0.4" y2="-0.45" width="0.1016" layer="51"/>
<wire x1="0.4" y1="0.45" x2="0.4" y2="-0.45" width="0.1016" layer="51"/>
<smd name="C" x="0" y="0.75" dx="0.8" dy="0.8" layer="1"/>
<smd name="A" x="0" y="-0.75" dx="0.8" dy="0.8" layer="1"/>
<text x="-0.635" y="-0.635" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="1.905" y="-0.635" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.45" y1="0.45" x2="0.45" y2="0.85" layer="51"/>
<rectangle x1="-0.45" y1="-0.85" x2="0.45" y2="-0.45" layer="51"/>
<rectangle x1="-0.45" y1="0" x2="-0.3" y2="0.3" layer="21"/>
<rectangle x1="0.3" y1="0" x2="0.45" y2="0.3" layer="21"/>
<rectangle x1="-0.15" y1="0" x2="0.15" y2="0.3" layer="21"/>
</package>
<package name="CHIP-LED0805">
LB R99A&lt;br&gt;
Source: http://www.osram.convergy.de/ ... lb_r99a.pdf</description>
<wire x1="-0.625" y1="0.45" x2="-0.625" y2="-0.45" width="0.1016" layer="51"/>
<wire x1="0.625" y1="0.45" x2="0.625" y2="-0.475" width="0.1016" layer="51"/>
<smd name="C" x="0" y="1.05" dx="1.2" dy="1.2" layer="1"/>
<smd name="A" x="0" y="-1.05" dx="1.2" dy="1.2" layer="1"/>
<text x="-1.27" y="-1.27" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="2.54" y="-1.27" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.675" y1="0" x2="-0.525" y2="0.3" layer="21"/>
<rectangle x1="0.525" y1="0" x2="0.675" y2="0.3" layer="21"/>
<rectangle x1="-0.675" y1="0.45" x2="0.675" y2="1.05" layer="51"/>
<rectangle x1="-0.675" y1="-1.05" x2="0.675" y2="-0.45" layer="51"/>
</package>
<package name="MINI-TOPLED-SANTANA">
<description>&lt;b&gt;Mini TOPLED Santana®&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... LG M470.pdf</description>
<wire x1="0.7" y1="-1" x2="0.35" y2="-1" width="0.1016" layer="21"/>
<wire x1="0.35" y1="-1" x2="-0.7" y2="-1" width="0.1016" layer="21"/>
<wire x1="-0.7" y1="-1" x2="-0.7" y2="1" width="0.1016" layer="21"/>
<wire x1="-0.7" y1="1" x2="0.7" y2="1" width="0.1016" layer="21"/>
<wire x1="0.7" y1="1" x2="0.7" y2="-0.65" width="0.1016" layer="21"/>
<wire x1="0.7" y1="-0.65" x2="0.7" y2="-1" width="0.1016" layer="21"/>
<wire x1="0.45" y1="-0.7" x2="-0.45" y2="-0.7" width="0.1016" layer="21"/>
<wire x1="-0.45" y1="-0.7" x2="-0.45" y2="0.7" width="0.1016" layer="21"/>
<wire x1="-0.45" y1="0.7" x2="0.45" y2="0.7" width="0.1016" layer="21"/>
<wire x1="0.45" y1="0.7" x2="0.45" y2="-0.7" width="0.1016" layer="21"/>
<wire x1="0.7" y1="-0.65" x2="0.35" y2="-1" width="0.1016" layer="21"/>
<smd name="C" x="0" y="-2.2" dx="1.6" dy="1.6" layer="1" stop="no" cream="no"/>
<smd name="A" x="0" y="2.2" dx="1.6" dy="1.6" layer="1" stop="no" cream="no"/>
<rectangle x1="-0.55" y1="1.5" x2="0.55" y2="2.1" layer="29"/>
<rectangle x1="-0.55" y1="-2.1" x2="0.55" y2="-1.5" layer="29"/>
<rectangle x1="-0.5" y1="-2.05" x2="0.5" y2="-1.55" layer="31"/>
<rectangle x1="-0.5" y1="1.55" x2="0.5" y2="2.05" layer="31"/>
<rectangle x1="-0.2" y1="-0.4" x2="0.15" y2="-0.05" layer="21"/>
<rectangle x1="-0.5" y1="-2.1" x2="0.5" y2="-1.4" layer="51"/>
<rectangle x1="-0.5" y1="1.4" x2="0.5" y2="2.05" layer="51"/>
<rectangle x1="-0.5" y1="1" x2="0.5" y2="1.4" layer="21"/>
<rectangle x1="-0.5" y1="-1.4" x2="0.5" y2="-1.05" layer="21"/>
<hole x="0" y="0" drill="2.7"/>
</package>
<package name="CHIPLED_0805">
<description>&lt;b&gt;CHIPLED&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... LG_R971.pdf</description>
<wire x1="-0.35" y1="0.925" x2="0.35" y2="0.925" width="0.1016" layer="51" curve="162.394521"/>
<wire x1="-0.35" y1="-0.925" x2="0.35" y2="-0.925" width="0.1016" layer="51" curve="-162.394521"/>
<wire x1="0.575" y1="0.525" x2="0.575" y2="-0.525" width="0.1016" layer="51"/>
<wire x1="-0.575" y1="-0.5" x2="-0.575" y2="0.925" width="0.1016" layer="51"/>
<circle x="-0.45" y="0.85" radius="0.103" width="0.1016" layer="51"/>
<rectangle x1="0.3" y1="0.5" x2="0.625" y2="1" layer="51"/>
<rectangle x1="-0.325" y1="0.5" x2="-0.175" y2="0.75" layer="51"/>
<rectangle x1="0.175" y1="0.5" x2="0.325" y2="0.75" layer="51"/>
<rectangle x1="-0.2" y1="0.5" x2="0.2" y2="0.675" layer="51"/>
<rectangle x1="0.3" y1="-1" x2="0.625" y2="-0.5" layer="51"/>
<rectangle x1="-0.625" y1="-1" x2="-0.3" y2="-0.5" layer="51"/>
<rectangle x1="0.175" y1="-0.75" x2="0.325" y2="-0.5" layer="51"/>
<rectangle x1="-0.325" y1="-0.75" x2="-0.175" y2="-0.5" layer="51"/>
<rectangle x1="-0.2" y1="-0.675" x2="0.2" y2="-0.5" layer="51"/>
<rectangle x1="-0.1" y1="0" x2="0.1" y2="0.2" layer="21"/>
<rectangle x1="-0.6" y1="0.5" x2="-0.3" y2="0.8" layer="51"/>
<rectangle x1="-0.625" y1="0.925" x2="-0.3" y2="1" layer="51"/>
</package>
<package name="CHIPLED_1206">
Source: http://www.osram.convergy.de/ ... LG_LY N971.pdf</description>
<wire x1="-0.4" y1="1.6" x2="0.4" y2="1.6" width="0.1016" layer="51" curve="172.619069"/>
<wire x1="-0.8" y1="-0.95" x2="-0.8" y2="0.95" width="0.1016" layer="51"/>
<wire x1="0.8" y1="0.95" x2="0.8" y2="-0.95" width="0.1016" layer="51"/>
<circle x="-0.55" y="1.425" radius="0.1" width="0.1016" layer="51"/>
<smd name="C" x="0" y="1.75" dx="1.5" dy="1.5" layer="1"/>
<smd name="A" x="0" y="-1.75" dx="1.5" dy="1.5" layer="1"/>
<rectangle x1="-0.85" y1="1.525" x2="-0.35" y2="1.65" layer="51"/>
<rectangle x1="-0.85" y1="1.225" x2="-0.625" y2="1.55" layer="51"/>
<rectangle x1="-0.45" y1="1.225" x2="-0.325" y2="1.45" layer="51"/>
<rectangle x1="-0.65" y1="1.225" x2="-0.225" y2="1.35" layer="51"/>
<rectangle x1="0.35" y1="1.3" x2="0.85" y2="1.65" layer="51"/>
<rectangle x1="0.25" y1="1.225" x2="0.85" y2="1.35" layer="51"/>
<rectangle x1="-0.85" y1="0.95" x2="0.85" y2="1.25" layer="51"/>
<rectangle x1="-0.85" y1="-1.65" x2="0.85" y2="-0.95" layer="51"/>
<rectangle x1="-0.85" y1="0.35" x2="-0.525" y2="0.775" layer="21"/>
<rectangle x1="0.525" y1="0.35" x2="0.85" y2="0.775" layer="21"/>
<rectangle x1="-0.175" y1="0" x2="0.175" y2="0.35" layer="21"/>
</package>
<package name="CHIPLED_0603">
Source: http://www.osram.convergy.de/ ... LG_LY Q971.pdf</description>
<wire x1="-0.3" y1="0.8" x2="0.3" y2="0.8" width="0.1016" layer="51" curve="170.055574"/>
<wire x1="-0.275" y1="-0.825" x2="0.275" y2="-0.825" width="0.0508" layer="51" curve="-180"/>
<wire x1="-0.4" y1="0.375" x2="-0.4" y2="-0.35" width="0.1016" layer="51"/>
<wire x1="0.4" y1="0.35" x2="0.4" y2="-0.35" width="0.1016" layer="51"/>
<circle x="-0.35" y="0.625" radius="0.075" width="0.0508" layer="51"/>
<text x="-0.635" y="-1.27" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="1.905" y="-1.27" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.45" y1="0.7" x2="-0.25" y2="0.85" layer="51"/>
<rectangle x1="-0.275" y1="0.55" x2="-0.225" y2="0.6" layer="51"/>
<rectangle x1="-0.45" y1="0.35" x2="-0.4" y2="0.725" layer="51"/>
<rectangle x1="0.25" y1="0.55" x2="0.45" y2="0.85" layer="51"/>
<rectangle x1="-0.45" y1="0.35" x2="0.45" y2="0.575" layer="51"/>
<rectangle x1="-0.45" y1="-0.85" x2="-0.25" y2="-0.35" layer="51"/>
<rectangle x1="0.25" y1="-0.85" x2="0.45" y2="-0.35" layer="51"/>
<rectangle x1="-0.275" y1="-0.575" x2="0.275" y2="-0.35" layer="51"/>
<rectangle x1="-0.275" y1="-0.65" x2="-0.175" y2="-0.55" layer="51"/>
<rectangle x1="0.175" y1="-0.65" x2="0.275" y2="-0.55" layer="51"/>
<rectangle x1="-0.125" y1="0" x2="0.125" y2="0.25" layer="21"/>
</package>
<package name="CHIPLED-0603-TTW">
<description>&lt;b&gt;CHIPLED-0603&lt;/b&gt;&lt;p&gt;
Recommended Solder Pad useable for SmartLEDTM and Chipled - Package 0603&lt;br&gt;
Package able to withstand TTW-soldering heat&lt;br&gt;
Package suitable for TTW-soldering&lt;br&gt;
Source: http://www.osram.convergy.de/ ... LO_LS_LY L89K.pdf</description>
<smd name="C" x="0" y="0.875" dx="0.8" dy="0.5" layer="1" stop="no" cream="no"/>
<smd name="A" x="0" y="-0.875" dx="0.8" dy="0.5" layer="1" stop="no" cream="no"/>
<smd name="A@1" x="0" y="-0.5" dx="0.35" dy="0.35" layer="1"/>
<smd name="C@1" x="0" y="0.5" dx="0.35" dy="0.35" layer="1"/>
<rectangle x1="-0.175" y1="0.325" x2="0.175" y2="0.7" layer="29"/>
<rectangle x1="-0.4" y1="0.625" x2="0.4" y2="1.125" layer="29"/>
<rectangle x1="-0.4" y1="-1.125" x2="0.4" y2="-0.625" layer="29"/>
<rectangle x1="-0.175" y1="-0.675" x2="0.175" y2="-0.325" layer="29"/>
</package>
<package name="SMARTLED-TTW">
<description>&lt;b&gt;SmartLED TTW&lt;/b&gt;&lt;p&gt;
<smd name="A@1" x="0" y="-0.5" dx="0.35" dy="0.35" layer="1" stop="no" cream="no"/>
<smd name="C@1" x="0" y="0.5" dx="0.35" dy="0.35" layer="1" stop="no" cream="no"/>
<rectangle x1="-0.225" y1="0.3" x2="0.225" y2="0.975" layer="31"/>
<rectangle x1="-0.175" y1="-0.7" x2="0.175" y2="-0.325" layer="29" rot="R180"/>
<rectangle x1="-0.225" y1="-0.975" x2="0.225" y2="-0.3" layer="31" rot="R180"/>
</package>
<package name="LUMILED+">
<description>&lt;b&gt;Lumileds Lighting. LUXEON®&lt;/b&gt; with cool pad&lt;p&gt;
Source: K2.pdf</description>
<wire x1="-3.575" y1="2.3375" x2="-2.3375" y2="3.575" width="0.2032" layer="21"/>
<wire x1="-2.3375" y1="3.575" x2="2.3375" y2="3.575" width="0.2032" layer="21"/>
<wire x1="3.575" y1="2.3375" x2="3.575" y2="-3.575" width="0.2032" layer="21"/>
<wire x1="3.575" y1="-3.575" x2="-2.3375" y2="-3.575" width="0.2032" layer="21"/>
<wire x1="-2.3375" y1="-3.575" x2="-2.5" y2="-3.4125" width="0.2032" layer="21"/>
<wire x1="-2.5" y1="-3.4125" x2="-3.4125" y2="-2.5" width="0.2032" layer="21" curve="167.429893"/>
<wire x1="-3.4125" y1="-2.5" x2="-3.575" y2="-2.3375" width="0.2032" layer="21"/>
<wire x1="-3.575" y1="-2.3375" x2="-3.575" y2="2.3375" width="0.2032" layer="21"/>
<wire x1="2.3375" y1="3.575" x2="2.5" y2="3.4125" width="0.2032" layer="21"/>
<wire x1="2.5" y1="3.4125" x2="3.4125" y2="2.5" width="0.2032" layer="21" curve="167.429893"/>
<wire x1="3.4125" y1="2.5" x2="3.575" y2="2.3375" width="0.2032" layer="21"/>
<wire x1="-1.725" y1="2.225" x2="-1.0625" y2="2.5625" width="0.2032" layer="21" curve="-255.44999"/>
<wire x1="1.725" y1="-2.225" x2="1.0625" y2="-2.5625" width="0.2032" layer="21" curve="-255.44999"/>
<circle x="0" y="0" radius="2.725" width="0.2032" layer="51"/>
<smd name="1NC" x="-5.2" y="1.15" dx="2.9" dy="1.7" layer="1"/>
<smd name="2+" x="-5.2" y="-1.15" dx="2.9" dy="1.7" layer="1"/>
<smd name="3NC" x="5.2" y="-1.15" dx="2.9" dy="1.7" layer="1" rot="R180"/>
<smd name="4-" x="5.2" y="1.15" dx="2.9" dy="1.7" layer="1" rot="R180"/>
<text x="-3.175" y="3.81" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.175" y="-5.08" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-5.975" y1="0.575" x2="-3.625" y2="1.6" layer="51"/>
<rectangle x1="-5.975" y1="-1.6" x2="-3.625" y2="-0.575" layer="51"/>
<rectangle x1="3.625" y1="-1.6" x2="5.975" y2="-0.575" layer="51" rot="R180"/>
<rectangle x1="3.625" y1="0.575" x2="5.975" y2="1.6" layer="51" rot="R180"/>
<polygon width="0.4064" layer="1">
<vertex x="2.3383" y="1.35"/>
<vertex x="0" y="2.7"/>
<vertex x="-2.3383" y="1.35"/>
<vertex x="-2.3383" y="-1.35"/>
<vertex x="0" y="-2.7"/>
<vertex x="2.3383" y="-1.35"/>
</polygon>
<polygon width="0.4064" layer="29">
</polygon>
<polygon width="0.4064" layer="31">
</polygon>
</package>
<package name="LUMILED">
<description>&lt;b&gt;Lumileds Lighting. LUXEON®&lt;/b&gt; without cool pad&lt;p&gt;
</polygon>
</polygon>
</package>
<package name="LED10MM">
10 mm, round</description>
<wire x1="5.08" y1="-2.54" x2="5.08" y2="2.54" width="0.254" layer="21" curve="-306.869898"/>
<wire x1="4.445" y1="0" x2="0" y2="-4.445" width="0.127" layer="21" curve="-90"/>
<wire x1="3.81" y1="0" x2="0" y2="-3.81" width="0.127" layer="21" curve="-90"/>
<wire x1="3.175" y1="0" x2="0" y2="-3.175" width="0.127" layer="21" curve="-90"/>
<wire x1="2.54" y1="0" x2="0" y2="-2.54" width="0.127" layer="21" curve="-90"/>
<wire x1="-4.445" y1="0" x2="0" y2="4.445" width="0.127" layer="21" curve="-90"/>
<wire x1="-3.81" y1="0" x2="0" y2="3.81" width="0.127" layer="21" curve="-90"/>
<wire x1="-3.175" y1="0" x2="0" y2="3.175" width="0.127" layer="21" curve="-90"/>
<wire x1="-2.54" y1="0" x2="0" y2="2.54" width="0.127" layer="21" curve="-90"/>
<wire x1="5.08" y1="2.54" x2="5.08" y2="-2.54" width="0.254" layer="21"/>
<circle x="0" y="0" radius="5.08" width="0.127" layer="21"/>
<pad name="K" x="1.27" y="0" drill="0.8128" diameter="1.6764" shape="square"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" diameter="1.6764" shape="octagon"/>
<text x="6.35" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="6.35" y="-1.27" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="KA-3528ASYC">
<description>&lt;b&gt;SURFACE MOUNT LED LAMP&lt;/b&gt; 3.5x2.8mm&lt;p&gt;
Source: http://www.kingbright.com/manager/upload/pdf/KA-3528ASYC(Ver1189474662.1)</description>
<wire x1="-1.55" y1="1.35" x2="1.55" y2="1.35" width="0.1016" layer="21"/>
<wire x1="1.55" y1="1.35" x2="1.55" y2="-1.35" width="0.1016" layer="51"/>
<wire x1="1.55" y1="-1.35" x2="-1.55" y2="-1.35" width="0.1016" layer="21"/>
<wire x1="-1.55" y1="-1.35" x2="-1.55" y2="1.35" width="0.1016" layer="51"/>
<wire x1="-0.65" y1="0.95" x2="0.65" y2="0.95" width="0.1016" layer="21" curve="-68.40813"/>
<wire x1="0.65" y1="-0.95" x2="-0.65" y2="-0.95" width="0.1016" layer="21" curve="-68.40813"/>
<circle x="0" y="0" radius="1.15" width="0.1016" layer="51"/>
<smd name="A" x="-1.55" y="0" dx="1.5" dy="2.2" layer="1"/>
<smd name="C" x="1.55" y="0" dx="1.5" dy="2.2" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.75" y1="0.6" x2="-1.6" y2="1.1" layer="51"/>
<rectangle x1="-1.75" y1="-1.1" x2="-1.6" y2="-0.6" layer="51"/>
<rectangle x1="1.6" y1="-1.1" x2="1.75" y2="-0.6" layer="51" rot="R180"/>
<rectangle x1="1.6" y1="0.6" x2="1.75" y2="1.1" layer="51" rot="R180"/>
<polygon width="0.1016" layer="51">
<vertex x="1.55" y="-1.35"/>
<vertex x="1.55" y="-0.625"/>
<vertex x="0.825" y="-1.35"/>
</polygon>
<polygon width="0.1016" layer="21">
<vertex x="1.55" y="-1.175"/>
<vertex x="1" y="-1.175"/>
</polygon>
</package>
<package name="SML0805">
<description>&lt;b&gt;SML0805-2CW-TR (0805 PROFILE)&lt;/b&gt; COOL WHITE&lt;p&gt;
Source: http://www.ledtronics.com/ds/smd-0603/Dstr0093.pdf</description>
<wire x1="-0.95" y1="-0.55" x2="0.95" y2="-0.55" width="0.1016" layer="51"/>
<wire x1="0.95" y1="-0.55" x2="0.95" y2="0.55" width="0.1016" layer="51"/>
<wire x1="0.95" y1="0.55" x2="-0.95" y2="0.55" width="0.1016" layer="51"/>
<wire x1="-0.95" y1="0.55" x2="-0.95" y2="-0.55" width="0.1016" layer="51"/>
<wire x1="-0.175" y1="-0.025" x2="0" y2="0.15" width="0.0634" layer="21"/>
<wire x1="0" y1="0.15" x2="0.15" y2="0" width="0.0634" layer="21"/>
<wire x1="0.15" y1="0" x2="-0.025" y2="-0.175" width="0.0634" layer="21"/>
<wire x1="-0.025" y1="-0.175" x2="-0.175" y2="-0.025" width="0.0634" layer="21"/>
<circle x="-0.275" y="0.4" radius="0.125" width="0" layer="21"/>
<smd name="C" x="-1.05" y="0" dx="1.2" dy="1.2" layer="1"/>
<smd name="A" x="1.05" y="0" dx="1.2" dy="1.2" layer="1"/>
<text x="-1.5" y="1" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.5" y="-2" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="SML1206">
<description>&lt;b&gt;SML10XXKH-TR (HIGH INTENSITY) LED&lt;/b&gt;&lt;p&gt;
&lt;table&gt;
&lt;tr&gt;&lt;td&gt;SML10R3KH-TR&lt;/td&gt;&lt;td&gt;ULTRA RED&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;SML10E3KH-TR&lt;/td&gt;&lt;td&gt;SUPER REDSUPER BLUE&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;SML10O3KH-TR&lt;/td&gt;&lt;td&gt;SUPER ORANGE&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;SML10PY3KH-TR&lt;/td&gt;&lt;td&gt;PURE YELLOW&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;SML10OY3KH-TR&lt;/td&gt;&lt;td&gt;ULTRA YELLOW&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;SML10AG3KH-TR&lt;/td&gt;&lt;td&gt;AQUA GREEN&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;SML10BG3KH-TR&lt;/td&gt;&lt;td&gt;BLUE GREEN&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;SML10PB1KH-TR&lt;/td&gt;&lt;td&gt;SUPER BLUE&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;SML10CW1KH-TR&lt;/td&gt;&lt;td&gt;WHITE&lt;/td&gt;&lt;/tr&gt;
&lt;/table&gt;
Source: http://www.ledtronics.com/ds/smd-1206/dstr0094.PDF</description>
<wire x1="-1.5" y1="0.5" x2="-1.5" y2="-0.5" width="0.2032" layer="51" curve="-180"/>
<wire x1="1.5" y1="-0.5" x2="1.5" y2="0.5" width="0.2032" layer="51" curve="-180"/>
<circle x="-0.725" y="0.525" radius="0.125" width="0" layer="21"/>
<smd name="C" x="-1.75" y="0" dx="1.5" dy="1.5" layer="1"/>
<smd name="A" x="1.75" y="0" dx="1.5" dy="1.5" layer="1"/>
<text x="-1.5" y="-2.5" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="0.4" x2="-1.15" y2="0.8" layer="51"/>
<rectangle x1="-1.6" y1="-0.8" x2="-1.15" y2="-0.4" layer="51"/>
<rectangle x1="-1.175" y1="-0.6" x2="-1" y2="-0.275" layer="51"/>
<rectangle x1="1.15" y1="-0.8" x2="1.6" y2="-0.4" layer="51" rot="R180"/>
<rectangle x1="1.15" y1="0.4" x2="1.6" y2="0.8" layer="51" rot="R180"/>
<rectangle x1="1" y1="0.275" x2="1.175" y2="0.6" layer="51" rot="R180"/>
</package>
<package name="SML0603">
<description>&lt;b&gt;SML0603-XXX (HIGH INTENSITY) LED&lt;/b&gt;&lt;p&gt;
&lt;table&gt;
&lt;tr&gt;&lt;td&gt;AG3K&lt;/td&gt;&lt;td&gt;AQUA GREEN&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;B1K&lt;/td&gt;&lt;td&gt;SUPER BLUE&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;R1K&lt;/td&gt;&lt;td&gt;SUPER RED&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;R3K&lt;/td&gt;&lt;td&gt;ULTRA RED&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;O3K&lt;/td&gt;&lt;td&gt;SUPER ORANGE&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;O3KH&lt;/td&gt;&lt;td&gt;SOFT ORANGE&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;Y3KH&lt;/td&gt;&lt;td&gt;SUPER YELLOW&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;Y3K&lt;/td&gt;&lt;td&gt;SUPER YELLOW&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;2CW&lt;/td&gt;&lt;td&gt;WHITE&lt;/td&gt;&lt;/tr&gt;
&lt;/table&gt;
Source: http://www.ledtronics.com/ds/smd-0603/Dstr0092.pdf</description>
<wire x1="-0.75" y1="0.35" x2="0.75" y2="0.35" width="0.1016" layer="51"/>
<wire x1="0.75" y1="0.35" x2="0.75" y2="-0.35" width="0.1016" layer="51"/>
<wire x1="0.75" y1="-0.35" x2="-0.75" y2="-0.35" width="0.1016" layer="51"/>
<wire x1="-0.75" y1="-0.35" x2="-0.75" y2="0.35" width="0.1016" layer="51"/>
<wire x1="-0.45" y1="0.3" x2="-0.45" y2="-0.3" width="0.1016" layer="51"/>
<wire x1="0.45" y1="0.3" x2="0.45" y2="-0.3" width="0.1016" layer="51"/>
<wire x1="-0.2" y1="0.35" x2="0.2" y2="0.35" width="0.1016" layer="21"/>
<wire x1="-0.2" y1="-0.35" x2="0.2" y2="-0.35" width="0.1016" layer="21"/>
<smd name="C" x="-0.75" y="0" dx="0.8" dy="0.8" layer="1"/>
<smd name="A" x="0.75" y="0" dx="0.8" dy="0.8" layer="1"/>
<text x="-1" y="1" size="1.27" layer="25">&gt;NAME</text>
<text x="-1" y="-2" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.4" y1="0.175" x2="0" y2="0.4" layer="51"/>
<rectangle x1="-0.25" y1="0.175" x2="0" y2="0.4" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="LED">
<wire x1="1.27" y1="0" x2="0" y2="-2.54" width="0.254" layer="94"/>
<wire x1="0" y1="-2.54" x2="-1.27" y2="0" width="0.254" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="0" y2="-2.54" width="0.254" layer="94"/>
<wire x1="0" y1="-2.54" x2="-1.27" y2="-2.54" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="-1.27" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="-2.032" y1="-0.762" x2="-3.429" y2="-2.159" width="0.1524" layer="94"/>
<wire x1="-1.905" y1="-1.905" x2="-3.302" y2="-3.302" width="0.1524" layer="94"/>
<text x="3.556" y="-4.572" size="1.778" layer="95" rot="R90">&gt;NAME</text>
<text x="5.715" y="-4.572" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="C" x="0" y="-5.08" visible="off" length="short" direction="pas" rot="R90"/>
<pin name="A" x="0" y="2.54" visible="off" length="short" direction="pas" rot="R270"/>
<polygon width="0.1524" layer="94">
<vertex x="-3.429" y="-2.159"/>
<vertex x="-3.048" y="-1.27"/>
<vertex x="-2.54" y="-1.778"/>
</polygon>
<vertex x="-3.302" y="-3.302"/>
<vertex x="-2.921" y="-2.413"/>
<vertex x="-2.413" y="-2.921"/>
</polygon>
</symbol>
</symbols>
<devicesets>
<deviceset name="LED" prefix="LED" uservalue="yes">
<description>&lt;b&gt;LED&lt;/b&gt;&lt;p&gt;
&lt;u&gt;OSRAM&lt;/u&gt;:&lt;br&gt;
- &lt;u&gt;CHIPLED&lt;/u&gt;&lt;br&gt;
LG R971, LG N971, LY N971, LG Q971, LY Q971, LO R971, LY R971
LH N974, LH R974&lt;br&gt;
LS Q976, LO Q976, LY Q976&lt;br&gt;
LO Q996&lt;br&gt;
- &lt;u&gt;Hyper CHIPLED&lt;/u&gt;&lt;br&gt;
LW Q18S&lt;br&gt;
LB Q993, LB Q99A, LB R99A&lt;br&gt;
- &lt;u&gt;SideLED&lt;/u&gt;&lt;br&gt;
LS A670, LO A670, LY A670, LG A670, LP A670&lt;br&gt;
LB A673, LV A673, LT A673, LW A673&lt;br&gt;
LH A674&lt;br&gt;
LY A675&lt;br&gt;
LS A676, LA A676, LO A676, LY A676, LW A676&lt;br&gt;
LS A679, LY A679, LG A679&lt;br&gt;
-  &lt;u&gt;Hyper Micro SIDELED®&lt;/u&gt;&lt;br&gt;
LS Y876, LA Y876, LO Y876, LY Y876&lt;br&gt;
LT Y87S&lt;br&gt;
- &lt;u&gt;SmartLED&lt;/u&gt;&lt;br&gt;
LW L88C, LW L88S&lt;br&gt;
LB L89C, LB L89S, LG L890&lt;br&gt;
LS L89K, LO L89K, LY L89K&lt;br&gt;
LS L896, LA L896, LO L896, LY L896&lt;br&gt;
- &lt;u&gt;TOPLED&lt;/u&gt;&lt;br&gt;
LS T670, LO T670, LY T670, LG T670, LP T670&lt;br&gt;
LSG T670, LSP T670, LSY T670, LOP T670, LYG T670&lt;br&gt;
LG T671, LOG T671, LSG T671&lt;br&gt;
LB T673, LV T673, LT T673, LW T673&lt;br&gt;
LH T674&lt;br&gt;
LS T676, LA T676, LO T676, LY T676, LB T676, LH T676, LSB T676, LW T676&lt;br&gt;
LB T67C, LV T67C, LT T67C, LS T67K, LO T67K, LY T67K, LW E67C&lt;br&gt;
LS E67B, LA E67B, LO E67B, LY E67B, LB E67C, LV E67C, LT E67C&lt;br&gt;
LW T67C&lt;br&gt;
LS T679, LY T679, LG T679&lt;br&gt;
LS T770, LO T770, LY T770, LG T770, LP T770&lt;br&gt;
LB T773, LV T773, LT T773, LW T773&lt;br&gt;
LH T774&lt;br&gt;
LS E675, LA E675, LY E675, LS T675&lt;br&gt;
LS T776, LA T776, LO T776, LY T776, LB T776&lt;br&gt;
LHGB T686&lt;br&gt;
LT T68C, LB T68C&lt;br&gt;
- &lt;u&gt;Hyper Mini TOPLED®&lt;/u&gt;&lt;br&gt;
LB M676&lt;br&gt;
- &lt;u&gt;Mini TOPLED Santana®&lt;/u&gt;&lt;br&gt;
LG M470&lt;br&gt;
LS M47K, LO M47K, LY M47K
&lt;p&gt;
Source: http://www.osram.convergy.de&lt;p&gt;
&lt;u&gt;LUXEON:&lt;/u&gt;&lt;br&gt;
- &lt;u&gt;LUMILED®&lt;/u&gt;&lt;br&gt;
LXK2-PW12-R00, LXK2-PW12-S00, LXK2-PW14-U00, LXK2-PW14-V00&lt;br&gt;
LXK2-PM12-R00, LXK2-PM12-S00, LXK2-PM14-U00&lt;br&gt;
LXK2-PE12-Q00, LXK2-PE12-R00, LXK2-PE12-S00, LXK2-PE14-T00, LXK2-PE14-U00&lt;br&gt;
LXK2-PB12-K00, LXK2-PB12-L00, LXK2-PB12-M00, LXK2-PB14-N00, LXK2-PB14-P00, LXK2-PB14-Q00&lt;br&gt;
LXK2-PR12-L00, LXK2-PR12-M00, LXK2-PR14-Q00, LXK2-PR14-R00&lt;br&gt;
LXK2-PD12-Q00, LXK2-PD12-R00, LXK2-PD12-S00&lt;br&gt;
LXK2-PH12-R00, LXK2-PH12-S00&lt;br&gt;
LXK2-PL12-P00, LXK2-PL12-Q00, LXK2-PL12-R00
&lt;p&gt;
Source: www.luxeon.com&lt;p&gt;
&lt;u&gt;KINGBRIGHT:&lt;/U&gt;&lt;p&gt;
KA-3528ASYC&lt;br&gt;
Source: www.kingbright.com</description>
<gates>
<gate name="G$1" symbol="LED" x="0" y="0"/>
</gates>
<devices>
<device name="SMT1206" package="1206">
<connects>
<connect gate="G$1" pin="A" pad="A"/>
<connect gate="G$1" pin="C" pad="C"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="LD260" package="LD260">
<connects>
<connect gate="G$1" pin="C" pad="K"/>
</connects>
<technologies>
</technologies>
</device>
<device name="SQR2X5" package="LED2X5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3MM" package="LED3MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5MM" package="LED5MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LSU260" package="LSU260">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LZR181" package="LZR181">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B152" package="Q62902-B152">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B153" package="Q62902-B153">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B155" package="Q62902-B155">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B156" package="Q62902-B156">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SFH480" package="SFH480">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SFH482" package="SFH482">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SQR5.7X3.2" package="U57X32">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="IRL80A" package="IRL80A">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P-LCC-2" package="P-LCC-2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MINI-TOP" package="OSRAM-MINI-TOP-LED">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SIDELED" package="OSRAM-SIDELED">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMART-LED" package="SMART-LED">
<connects>
<connect gate="G$1" pin="C" pad="B"/>
</connects>
<technologies>
</technologies>
</device>
<device name="P-LCC-2-BACK" package="P-LCC-2-TOPLED-RG">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MICRO-SIDELED" package="MICRO-SIDELED">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P-LCC-4" package="P-LCC-4">
<connects>
<connect gate="G$1" pin="C" pad="C@4"/>
</connects>
<technologies>
</technologies>
</device>
<device name="CHIP-LED0603" package="CHIP-LED0603">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CHIP-LED0805" package="CHIP-LED0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TOPLED-SANTANA" package="MINI-TOPLED-SANTANA">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CHIPLED_0805" package="CHIPLED_0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CHIPLED_1206" package="CHIPLED_1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CHIPLED_0603" package="CHIPLED_0603">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CHIPLED-0603-TTW" package="CHIPLED-0603-TTW">
<connects>
<connect gate="G$1" pin="A" pad="A@1"/>
<connect gate="G$1" pin="C" pad="C@1"/>
</connects>
<technologies>
</technologies>
</device>
<device name="" package="SMARTLED-TTW">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-LUMILED+" package="LUMILED+">
<connects>
<connect gate="G$1" pin="A" pad="2+"/>
<connect gate="G$1" pin="C" pad="4-"/>
</connects>
<technologies>
</technologies>
</device>
<device name="-LUMILED" package="LUMILED">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="10MM" package="LED10MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="KA-3528ASYC" package="KA-3528ASYC">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SML0805" package="SML0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SML1206" package="SML1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SML0603" package="SML0603">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="resistor">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;map name="nav_main"&gt;
&lt;area shape="rect" coords="0,1,140,23" href="../military_specs.asp" title=""&gt;
&lt;area shape="rect" coords="0,24,140,51" href="../about.asp" title=""&gt;
&lt;area shape="rect" coords="1,52,140,77" href="../rfq.asp" title=""&gt;
&lt;area shape="rect" coords="0,78,139,103" href="../products.asp" title=""&gt;
&lt;area shape="rect" coords="1,102,138,128" href="../excess_inventory.asp" title=""&gt;
&lt;area shape="rect" coords="1,129,138,150" href="../edge.asp" title=""&gt;
&lt;area shape="rect" coords="1,151,139,178" href="../industry_links.asp" title=""&gt;
&lt;area shape="rect" coords="0,179,139,201" href="../comments.asp" title=""&gt;
&lt;area shape="rect" coords="1,203,138,231" href="../directory.asp" title=""&gt;
&lt;area shape="default" nohref&gt;
&lt;/map&gt;
&lt;html&gt;
&lt;title&gt;&lt;/title&gt;
 &lt;LINK REL="StyleSheet" TYPE="text/css" HREF="style-sheet.css"&gt;
&lt;body bgcolor="#ffffff" text="#000000" marginwidth="0" marginheight="0" topmargin="0" leftmargin="0"&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0 height="55%"&gt;
&lt;tr valign="top"&gt;
&lt;/td&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;
&lt;/BODY&gt;&lt;/HTML&gt;</description>
<packages>
<package name="R0402">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
chip</description>
<wire x1="-0.245" y1="0.224" x2="0.245" y2="0.224" width="0.1524" layer="51"/>
<wire x1="0.245" y1="-0.224" x2="-0.245" y2="-0.224" width="0.1524" layer="51"/>
<wire x1="-1.473" y1="0.483" x2="1.473" y2="0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.483" x2="1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.483" x2="-1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.483" x2="-1.473" y2="0.483" width="0.0508" layer="39"/>
<smd name="1" x="-0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<smd name="2" x="0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<text x="-0.635" y="0.762" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-2.032" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.554" y1="-0.3048" x2="-0.254" y2="0.2951" layer="51"/>
<rectangle x1="0.2588" y1="-0.3048" x2="0.5588" y2="0.2951" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="R0603">
chip</description>
<wire x1="-0.432" y1="-0.356" x2="0.432" y2="-0.356" width="0.1524" layer="51"/>
<wire x1="0.432" y1="0.356" x2="-0.432" y2="0.356" width="0.1524" layer="51"/>
<wire x1="-1.473" y1="0.983" x2="1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.983" x2="1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.983" x2="-1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.983" x2="-1.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.85" y="0" dx="1" dy="1.1" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1" dy="1.1" layer="1"/>
<text x="-0.889" y="0.889" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.889" y="-2.032" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="0.4318" y1="-0.4318" x2="0.8382" y2="0.4318" layer="51"/>
<rectangle x1="-0.8382" y1="-0.4318" x2="-0.4318" y2="0.4318" layer="51"/>
</package>
<package name="R0805">
chip</description>
<wire x1="-0.41" y1="0.635" x2="0.41" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.41" y1="-0.635" x2="0.41" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<text x="-0.762" y="1.016" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.762" y="-2.286" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="0.4064" y1="-0.6985" x2="1.0564" y2="0.7015" layer="51"/>
<rectangle x1="-1.0668" y1="-0.6985" x2="-0.4168" y2="0.7015" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
<package name="R0805W">
chip, wave soldering</description>
<smd name="1" x="-0.94" y="0" dx="1.5" dy="1" layer="1"/>
<smd name="2" x="0.94" y="0" dx="1.5" dy="1" layer="1"/>
<text x="-0.635" y="1.016" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-2.159" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R1005">
chip</description>
<rectangle x1="-0.1999" y1="-0.3" x2="0.1999" y2="0.3" layer="35"/>
</package>
<package name="R1206">
chip</description>
<wire x1="0.9525" y1="-0.8128" x2="-0.9652" y2="-0.8128" width="0.1524" layer="51"/>
<wire x1="0.9525" y1="0.8128" x2="-0.9652" y2="0.8128" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="2" x="1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<smd name="1" x="-1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<text x="-1.397" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.397" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6891" y1="-0.8763" x2="-0.9525" y2="0.8763" layer="51"/>
<rectangle x1="0.9525" y1="-0.8763" x2="1.6891" y2="0.8763" layer="51"/>
<rectangle x1="-0.3" y1="-0.7" x2="0.3" y2="0.7" layer="35"/>
</package>
<package name="R1206W">
<wire x1="-0.913" y1="0.8" x2="0.888" y2="0.8" width="0.1524" layer="21"/>
<wire x1="-0.913" y1="-0.8" x2="0.888" y2="-0.8" width="0.1524" layer="21"/>
<smd name="1" x="-1.499" y="0" dx="1.8" dy="1.2" layer="1"/>
<smd name="2" x="1.499" y="0" dx="1.8" dy="1.2" layer="1"/>
<text x="-1.651" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.651" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-0.8763" x2="-0.9009" y2="0.8738" layer="51"/>
<rectangle x1="0.889" y1="-0.8763" x2="1.6391" y2="0.8738" layer="51"/>
</package>
<package name="R1210">
chip</description>
<wire x1="-0.913" y1="1.219" x2="0.939" y2="1.219" width="0.1524" layer="51"/>
<wire x1="-0.913" y1="-1.219" x2="0.939" y2="-1.219" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<text x="-1.27" y="1.651" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.921" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.3081" x2="-0.9009" y2="1.2918" layer="51"/>
<rectangle x1="0.9144" y1="-1.3081" x2="1.6645" y2="1.2918" layer="51"/>
<rectangle x1="-0.3" y1="-0.8999" x2="0.3" y2="0.8999" layer="35"/>
</package>
<package name="R1210W">
<wire x1="-0.913" y1="1.219" x2="0.939" y2="1.219" width="0.1524" layer="21"/>
<wire x1="-0.913" y1="-1.219" x2="0.939" y2="-1.219" width="0.1524" layer="21"/>
<smd name="1" x="-1.499" y="0" dx="1.8" dy="1.8" layer="1"/>
<smd name="2" x="1.499" y="0" dx="1.8" dy="1.8" layer="1"/>
<text x="-1.651" y="1.524" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.651" y="-2.794" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.3" y1="-0.8001" x2="0.3" y2="0.8001" layer="35"/>
</package>
<package name="R2010">
chip</description>
<wire x1="-1.662" y1="1.245" x2="1.662" y2="1.245" width="0.1524" layer="51"/>
<wire x1="-1.637" y1="-1.245" x2="1.687" y2="-1.245" width="0.1524" layer="51"/>
<wire x1="-3.473" y1="1.483" x2="3.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="3.473" y1="1.483" x2="3.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="3.473" y1="-1.483" x2="-3.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-3.473" y1="-1.483" x2="-3.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="-1.027" y1="1.245" x2="1.027" y2="1.245" width="0.1524" layer="21"/>
<wire x1="-1.002" y1="-1.245" x2="1.016" y2="-1.245" width="0.1524" layer="21"/>
<smd name="1" x="-2.2" y="0" dx="1.8" dy="2.7" layer="1"/>
<smd name="2" x="2.2" y="0" dx="1.8" dy="2.7" layer="1"/>
<text x="-2.159" y="1.651" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.159" y="-2.921" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.4892" y1="-1.3208" x2="-1.6393" y2="1.3292" layer="51"/>
<rectangle x1="1.651" y1="-1.3208" x2="2.5009" y2="1.3292" layer="51"/>
</package>
<package name="R2010W">
<wire x1="-1.662" y1="1.245" x2="1.662" y2="1.245" width="0.1524" layer="21"/>
<wire x1="-1.637" y1="-1.245" x2="1.687" y2="-1.245" width="0.1524" layer="21"/>
<smd name="1" x="-2.311" y="0" dx="2" dy="1.8" layer="1"/>
<smd name="2" x="2.311" y="0" dx="2" dy="1.8" layer="1"/>
<text x="-2.286" y="1.524" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.286" y="-2.921" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R2012">
chip</description>
<rectangle x1="-0.1001" y1="-0.5999" x2="0.1001" y2="0.5999" layer="35"/>
</package>
<package name="R2012W">
<text x="-0.635" y="-2.286" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R2512">
chip</description>
<wire x1="-2.362" y1="1.473" x2="2.387" y2="1.473" width="0.1524" layer="51"/>
<wire x1="-2.362" y1="-1.473" x2="2.387" y2="-1.473" width="0.1524" layer="51"/>
<wire x1="-3.973" y1="1.983" x2="3.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="1.983" x2="3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="-1.983" x2="-3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-3.973" y1="-1.983" x2="-3.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="1.473" x2="1.498" y2="1.473" width="0.1524" layer="21"/>
<wire x1="-1.473" y1="-1.473" x2="1.498" y2="-1.473" width="0.1524" layer="21"/>
<smd name="1" x="-2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<smd name="2" x="2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<text x="-2.667" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.667" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.2004" y1="-1.5494" x2="-2.3505" y2="1.5507" layer="51"/>
<rectangle x1="2.3622" y1="-1.5494" x2="3.2121" y2="1.5507" layer="51"/>
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="R2512W">
<wire x1="-2.362" y1="1.473" x2="2.387" y2="1.473" width="0.1524" layer="21"/>
<wire x1="-2.362" y1="-1.473" x2="2.387" y2="-1.473" width="0.1524" layer="21"/>
<smd name="1" x="-2.896" y="0" dx="2" dy="2.1" layer="1"/>
<smd name="2" x="2.896" y="0" dx="2" dy="2.1" layer="1"/>
<text x="-2.794" y="1.778" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.794" y="-3.048" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R3216">
chip</description>
<wire x1="-0.913" y1="0.8" x2="0.888" y2="0.8" width="0.1524" layer="51"/>
<wire x1="-0.913" y1="-0.8" x2="0.888" y2="-0.8" width="0.1524" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
</package>
<package name="R3216W">
<text x="-1.524" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R3225">
chip</description>
<text x="-1.397" y="1.651" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.397" y="-2.921" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.3" y1="-1" x2="0.3" y2="1" layer="35"/>
</package>
<package name="R3225W">
<text x="-1.397" y="1.524" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="R5025">
chip</description>
<wire x1="-0.9" y1="1.245" x2="0.9" y2="1.245" width="0.1524" layer="21"/>
<wire x1="-0.875" y1="-1.245" x2="0.925" y2="-1.245" width="0.1524" layer="21"/>
</package>
<package name="R5025W">
<text x="-2.286" y="1.651" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="R6332">
chip</description>
<text x="-2.794" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.794" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R6332W">
<text x="-2.921" y="1.778" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.921" y="-3.048" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="M0805">
MELF 0.10 W</description>
<wire x1="0.7112" y1="0.635" x2="-0.7112" y2="0.635" width="0.1524" layer="51"/>
<wire x1="0.7112" y1="-0.635" x2="-0.7112" y2="-0.635" width="0.1524" layer="51"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.6" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.6" layer="1"/>
<text x="-1.016" y="1.016" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.016" y="-2.286" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.0414" y1="-0.7112" x2="-0.6858" y2="0.7112" layer="51"/>
<rectangle x1="0.6858" y1="-0.7112" x2="1.0414" y2="0.7112" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5999" x2="0.1999" y2="0.5999" layer="35"/>
</package>
<package name="M1206">
MELF 0.25 W</description>
<wire x1="1.143" y1="0.8382" x2="-1.143" y2="0.8382" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.8382" x2="-1.143" y2="-0.8382" width="0.1524" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-0.9144" x2="-1.1176" y2="0.9144" layer="51"/>
<rectangle x1="1.1176" y1="-0.9144" x2="1.7018" y2="0.9144" layer="51"/>
</package>
<package name="M1406">
MELF 0.12 W</description>
<wire x1="-2.973" y1="0.983" x2="2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-0.983" x2="-2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-0.983" x2="-2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="0.983" x2="2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.3208" y1="0.762" x2="-1.3208" y2="0.762" width="0.1524" layer="51"/>
<wire x1="1.3208" y1="-0.762" x2="-1.3208" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="0.6858" y1="0.762" x2="-0.6858" y2="0.762" width="0.1524" layer="21"/>
<wire x1="0.6858" y1="-0.762" x2="-0.6858" y2="-0.762" width="0.1524" layer="21"/>
<smd name="1" x="-1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<smd name="2" x="1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<rectangle x1="-1.8542" y1="-0.8382" x2="-1.2954" y2="0.8382" layer="51"/>
<rectangle x1="1.2954" y1="-0.8382" x2="1.8542" y2="0.8382" layer="51"/>
</package>
<package name="M2012">
</package>
<package name="M2309">
<wire x1="-4.473" y1="1.483" x2="4.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="4.473" y1="-1.483" x2="-4.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-4.473" y1="-1.483" x2="-4.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="4.473" y1="1.483" x2="4.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="2.413" y1="1.1684" x2="-2.4384" y2="1.1684" width="0.1524" layer="51"/>
<wire x1="2.413" y1="-1.1684" x2="-2.413" y2="-1.1684" width="0.1524" layer="51"/>
<wire x1="1.651" y1="1.1684" x2="-1.6764" y2="1.1684" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-1.1684" x2="-1.651" y2="-1.1684" width="0.1524" layer="21"/>
<smd name="1" x="-2.85" y="0" dx="1.5" dy="2.6" layer="1"/>
<smd name="2" x="2.85" y="0" dx="1.5" dy="2.6" layer="1"/>
<text x="-2.794" y="1.651" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.794" y="-2.794" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.048" y1="-1.2446" x2="-2.3876" y2="1.2446" layer="51"/>
<rectangle x1="2.3876" y1="-1.2446" x2="3.048" y2="1.2446" layer="51"/>
</package>
<package name="M3216">
</package>
<package name="M3516">
<rectangle x1="-0.4001" y1="-0.7" x2="0.4001" y2="0.7" layer="35"/>
</package>
<package name="M5923">
</package>
<package name="0204/5">
type 0204, grid 5 mm</description>
<wire x1="2.54" y1="0" x2="2.032" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0" x2="-2.032" y2="0" width="0.508" layer="51"/>
<wire x1="-1.778" y1="0.635" x2="-1.524" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.778" y1="-0.635" x2="-1.524" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="-0.889" x2="1.778" y2="-0.635" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="0.889" x2="1.778" y2="0.635" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.778" y1="-0.635" x2="-1.778" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-1.524" y1="0.889" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.762" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-0.889" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-0.762" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.762" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.762" x2="-1.143" y2="0.762" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.762" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.762" x2="-1.143" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.889" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-0.889" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.635" x2="1.778" y2="0.635" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.0066" y="1.1684" size="0.9906" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="0.9906" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.032" y1="-0.254" x2="-1.778" y2="0.254" layer="51"/>
<rectangle x1="1.778" y1="-0.254" x2="2.032" y2="0.254" layer="51"/>
</package>
<package name="0204/7">
type 0204, grid 7.5 mm</description>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0.762" x2="-2.286" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.286" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="-1.016" x2="2.54" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.016" x2="2.54" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.54" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.016" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.889" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.016" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.889" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="-1.778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="-1.778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.016" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.016" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.762" x2="2.54" y2="0.762" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="1.2954" size="0.9906" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.6256" y="-0.4826" size="0.9906" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.54" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.54" y2="0.254" layer="21"/>
</package>
<package name="0207/10">
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
</package>
<package name="0207/12">
type 0207, grid 12 mm</description>
<wire x1="6.35" y1="0" x2="5.334" y2="0" width="0.6096" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.334" y2="0" width="0.6096" layer="51"/>
<wire x1="4.445" y1="0" x2="4.064" y2="0" width="0.6096" layer="21"/>
<wire x1="-4.445" y1="0" x2="-4.064" y2="0" width="0.6096" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.175" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.6858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.445" y1="-0.3048" x2="5.3086" y2="0.3048" layer="21"/>
<rectangle x1="-5.3086" y1="-0.3048" x2="-4.445" y2="0.3048" layer="21"/>
</package>
<package name="0207/15">
type 0207, grid 15mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.6096" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.6096" layer="51"/>
<wire x1="5.715" y1="0" x2="4.064" y2="0" width="0.6096" layer="21"/>
<wire x1="-5.715" y1="0" x2="-4.064" y2="0" width="0.6096" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.8128" shape="octagon"/>
<rectangle x1="5.715" y1="-0.3048" x2="6.5786" y2="0.3048" layer="21"/>
<rectangle x1="-6.5786" y1="-0.3048" x2="-5.715" y2="0.3048" layer="21"/>
</package>
<package name="0207/2V">
type 0207, grid 2.5 mm</description>
<wire x1="-1.27" y1="0" x2="-0.381" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.254" y1="0" x2="0.254" y2="0" width="0.6096" layer="21"/>
<wire x1="0.381" y1="0" x2="1.27" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.27" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="1.016" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-0.0508" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.0508" y="-2.2352" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/5V">
type 0207, grid 5 mm</description>
<wire x1="-2.54" y1="0" x2="-0.889" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.762" y1="0" x2="0.762" y2="0" width="0.6096" layer="21"/>
<wire x1="0.889" y1="0" x2="2.54" y2="0" width="0.6096" layer="51"/>
<circle x="-2.54" y="0" radius="1.27" width="0.1016" layer="21"/>
<circle x="-2.54" y="0" radius="1.016" width="0.1524" layer="51"/>
<text x="-1.143" y="0.889" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.143" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/7">
type 0207, grid 7.5 mm</description>
<wire x1="-3.81" y1="0" x2="-3.429" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="3.429" y1="0" x2="3.81" y2="0" width="0.6096" layer="51"/>
<text x="-2.54" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.5588" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.429" y1="-0.3048" x2="-3.175" y2="0.3048" layer="51"/>
<rectangle x1="3.175" y1="-0.3048" x2="3.429" y2="0.3048" layer="51"/>
</package>
<package name="0309/10">
type 0309, grid 10mm</description>
<wire x1="-4.699" y1="0" x2="-5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-4.318" y1="1.27" x2="-4.064" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.318" y1="-1.27" x2="-4.064" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="4.064" y1="-1.524" x2="4.318" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="4.064" y1="1.524" x2="4.318" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.318" y1="-1.27" x2="-4.318" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-4.064" y1="1.524" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.397" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="-1.524" x2="-3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-1.397" x2="-3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="1.397" x2="3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="1.397" x2="-3.302" y2="1.397" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-1.397" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-1.397" x2="-3.302" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="4.064" y1="1.524" x2="3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-1.524" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-1.27" x2="4.318" y2="1.27" width="0.1524" layer="51"/>
<wire x1="5.08" y1="0" x2="4.699" y2="0" width="0.6096" layer="51"/>
<text x="-4.191" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-0.6858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.6228" y1="-0.3048" x2="-4.318" y2="0.3048" layer="51"/>
<rectangle x1="4.318" y1="-0.3048" x2="4.6228" y2="0.3048" layer="51"/>
</package>
<package name="0309/12">
type 0309, grid 12.5 mm</description>
<wire x1="6.35" y1="0" x2="5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-4.318" y1="-1.27" x2="-4.318" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-1.27" x2="4.318" y2="1.27" width="0.1524" layer="21"/>
<rectangle x1="4.318" y1="-0.3048" x2="5.1816" y2="0.3048" layer="21"/>
<rectangle x1="-5.1816" y1="-0.3048" x2="-4.318" y2="0.3048" layer="21"/>
</package>
<package name="0411/12">
type 0411, grid 12.5 mm</description>
<wire x1="6.35" y1="0" x2="5.461" y2="0" width="0.762" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.461" y2="0" width="0.762" layer="51"/>
<wire x1="5.08" y1="-1.651" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.032" x2="5.08" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.08" y1="-1.651" x2="-4.699" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="4.699" y1="-2.032" x2="5.08" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.651" x2="-4.699" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="2.032" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="1.905" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.032" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="-1.905" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="3.937" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="3.937" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.651" x2="-5.08" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.032" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-2.032" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="0.9144" shape="octagon"/>
<text x="-5.08" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.5814" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.3594" y1="-0.381" x2="-5.08" y2="0.381" layer="21"/>
<rectangle x1="5.08" y1="-0.381" x2="5.3594" y2="0.381" layer="21"/>
</package>
<package name="0411/15">
type 0411, grid 15 mm</description>
<wire x1="-7.62" y1="0" x2="-6.35" y2="0" width="0.762" layer="51"/>
<wire x1="6.35" y1="0" x2="7.62" y2="0" width="0.762" layer="51"/>
<pad name="1" x="-7.62" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.9144" shape="octagon"/>
<rectangle x1="5.08" y1="-0.381" x2="6.477" y2="0.381" layer="21"/>
<rectangle x1="-6.477" y1="-0.381" x2="-5.08" y2="0.381" layer="21"/>
</package>
<package name="0411V">
type 0411, grid 3.81 mm</description>
<wire x1="1.27" y1="0" x2="0.3048" y2="0" width="0.762" layer="51"/>
<wire x1="-1.5748" y1="0" x2="-2.54" y2="0" width="0.762" layer="51"/>
<circle x="-2.54" y="0" radius="2.032" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.9144" shape="octagon"/>
<text x="-0.508" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.5334" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.4732" y1="-0.381" x2="0.2032" y2="0.381" layer="21"/>
</package>
<package name="0414/15">
type 0414, grid 15 mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.096" y1="1.905" x2="-5.842" y2="2.159" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.096" y1="-1.905" x2="-5.842" y2="-2.159" width="0.1524" layer="21" curve="90"/>
<wire x1="5.842" y1="-2.159" x2="6.096" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<wire x1="5.842" y1="2.159" x2="6.096" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.096" y1="-1.905" x2="-6.096" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="2.159" x2="-4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.032" x2="-4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-2.159" x2="-4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.032" x2="-4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.032" x2="4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.032" x2="-4.826" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="5.842" y1="2.159" x2="4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-2.159" x2="4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-1.905" x2="6.096" y2="1.905" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="1.016" shape="octagon"/>
<text x="-6.096" y="2.5654" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="6.096" y1="-0.4064" x2="6.5024" y2="0.4064" layer="21"/>
<rectangle x1="-6.5024" y1="-0.4064" x2="-6.096" y2="0.4064" layer="21"/>
</package>
<package name="0414V">
type 0414, grid 5 mm</description>
<wire x1="2.54" y1="0" x2="1.397" y2="0" width="0.8128" layer="51"/>
<wire x1="-2.54" y1="0" x2="-1.397" y2="0" width="0.8128" layer="51"/>
<circle x="-2.54" y="0" radius="2.159" width="0.1524" layer="21"/>
<circle x="-2.54" y="0" radius="1.143" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="1.016" shape="octagon"/>
<text x="-0.381" y="1.1684" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.381" y="-2.3622" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.2954" y1="-0.4064" x2="1.2954" y2="0.4064" layer="21"/>
</package>
<package name="0617/17">
type 0617, grid 17.5 mm</description>
<wire x1="-8.89" y1="0" x2="-8.636" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.874" y1="3.048" x2="-6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.794" x2="-6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-3.048" x2="-6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-2.794" x2="-6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="2.794" x2="6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="2.794" x2="-6.731" y2="2.794" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.794" x2="6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.794" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="7.874" y1="3.048" x2="6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="7.874" y1="-3.048" x2="6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-2.667" x2="-8.255" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="1.016" x2="-8.255" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="1.016" x2="-8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.667" x2="8.255" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="8.255" y1="1.016" x2="8.255" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="8.255" y1="1.016" x2="8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.636" y1="0" x2="8.89" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.255" y1="2.667" x2="-7.874" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="7.874" y1="3.048" x2="8.255" y2="2.667" width="0.1524" layer="21" curve="-90"/>
<wire x1="-8.255" y1="-2.667" x2="-7.874" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="7.874" y1="-3.048" x2="8.255" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<pad name="1" x="-8.89" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="8.89" y="0" drill="1.016" shape="octagon"/>
<text x="-8.128" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.096" y="-0.7112" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-8.5344" y1="-0.4064" x2="-8.2296" y2="0.4064" layer="51"/>
<rectangle x1="8.2296" y1="-0.4064" x2="8.5344" y2="0.4064" layer="51"/>
</package>
<package name="0617/22">
type 0617, grid 22.5 mm</description>
<wire x1="-10.287" y1="0" x2="-11.43" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.255" y1="-2.667" x2="-8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.667" x2="8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="10.287" y2="0" width="0.8128" layer="51"/>
<pad name="1" x="-11.43" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="11.43" y="0" drill="1.016" shape="octagon"/>
<text x="-8.255" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.477" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-10.1854" y1="-0.4064" x2="-8.255" y2="0.4064" layer="21"/>
<rectangle x1="8.255" y1="-0.4064" x2="10.1854" y2="0.4064" layer="21"/>
</package>
<package name="0617V">
type 0617, grid 5 mm</description>
<wire x1="-2.54" y1="0" x2="-1.27" y2="0" width="0.8128" layer="51"/>
<wire x1="1.27" y1="0" x2="2.54" y2="0" width="0.8128" layer="51"/>
<circle x="-2.54" y="0" radius="3.048" width="0.1524" layer="21"/>
<text x="0.635" y="1.4224" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.635" y="-2.6162" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.3208" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="0922/22">
type 0922, grid 22.5 mm</description>
<wire x1="11.43" y1="0" x2="10.795" y2="0" width="0.8128" layer="51"/>
<wire x1="-11.43" y1="0" x2="-10.795" y2="0" width="0.8128" layer="51"/>
<wire x1="-10.16" y1="-4.191" x2="-10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="4.572" x2="-8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="4.318" x2="-8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="-4.572" x2="-8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="-4.318" x2="-8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="4.318" x2="8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="4.318" x2="-8.636" y2="4.318" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-4.318" x2="8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-4.318" x2="-8.636" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="9.779" y1="4.572" x2="8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="9.779" y1="-4.572" x2="8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.191" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.191" x2="-9.779" y2="-4.572" width="0.1524" layer="21" curve="90"/>
<wire x1="-10.16" y1="4.191" x2="-9.779" y2="4.572" width="0.1524" layer="21" curve="-90"/>
<wire x1="9.779" y1="-4.572" x2="10.16" y2="-4.191" width="0.1524" layer="21" curve="90"/>
<wire x1="9.779" y1="4.572" x2="10.16" y2="4.191" width="0.1524" layer="21" curve="-90"/>
<text x="-10.16" y="5.1054" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-10.7188" y1="-0.4064" x2="-10.16" y2="0.4064" layer="51"/>
<rectangle x1="10.16" y1="-0.4064" x2="10.3124" y2="0.4064" layer="21"/>
<rectangle x1="-10.3124" y1="-0.4064" x2="-10.16" y2="0.4064" layer="21"/>
<rectangle x1="10.16" y1="-0.4064" x2="10.7188" y2="0.4064" layer="51"/>
</package>
<package name="P0613V">
type 0613, grid 5 mm</description>
<circle x="-2.54" y="0" radius="2.286" width="0.1524" layer="21"/>
<text x="-0.254" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.254" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.2954" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="P0613/15">
type 0613, grid 15 mm</description>
<wire x1="7.62" y1="0" x2="6.985" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.985" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.477" y1="2.032" x2="-6.223" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.477" y1="-2.032" x2="-6.223" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="6.223" y1="-2.286" x2="6.477" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="6.223" y1="2.286" x2="6.477" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.223" y1="2.286" x2="-5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.159" x2="-5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="-2.286" x2="-5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-2.159" x2="-5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="2.159" x2="5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="2.159" x2="-5.207" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.159" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.159" x2="-5.207" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="6.223" y1="2.286" x2="5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="6.223" y1="-2.286" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-0.635" x2="6.477" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-0.635" x2="6.477" y2="0.635" width="0.1524" layer="51"/>
<wire x1="6.477" y1="2.032" x2="6.477" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-2.032" x2="-6.477" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="0.635" x2="-6.477" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="0.635" x2="-6.477" y2="2.032" width="0.1524" layer="21"/>
<text x="-6.477" y="2.6924" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-0.7112" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-7.0358" y1="-0.4064" x2="-6.477" y2="0.4064" layer="51"/>
<rectangle x1="6.477" y1="-0.4064" x2="7.0358" y2="0.4064" layer="51"/>
</package>
<package name="P0817/22">
type 0817, grid 22.5 mm</description>
<wire x1="-10.414" y1="0" x2="-11.43" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.509" y1="-3.429" x2="-8.509" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="3.81" x2="-7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="3.556" x2="-7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="-3.81" x2="-7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-3.556" x2="-7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="3.556" x2="7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="3.556" x2="-6.985" y2="3.556" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-3.556" x2="7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-3.556" x2="-6.985" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="8.128" y1="3.81" x2="7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="8.128" y1="-3.81" x2="7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.429" x2="8.509" y2="3.429" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="10.414" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.509" y1="3.429" x2="-8.128" y2="3.81" width="0.1524" layer="21" curve="-90"/>
<wire x1="-8.509" y1="-3.429" x2="-8.128" y2="-3.81" width="0.1524" layer="21" curve="90"/>
<wire x1="8.128" y1="3.81" x2="8.509" y2="3.429" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.128" y1="-3.81" x2="8.509" y2="-3.429" width="0.1524" layer="21" curve="90"/>
<text x="-8.382" y="4.2164" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.223" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="6.604" y="-2.2606" size="1.27" layer="51" ratio="10" rot="R90">0817</text>
<rectangle x1="8.509" y1="-0.4064" x2="10.3124" y2="0.4064" layer="21"/>
<rectangle x1="-10.3124" y1="-0.4064" x2="-8.509" y2="0.4064" layer="21"/>
</package>
<package name="P0817V">
type 0817, grid 6.35 mm</description>
<wire x1="-3.81" y1="0" x2="-5.08" y2="0" width="0.8128" layer="51"/>
<wire x1="1.27" y1="0" x2="0" y2="0" width="0.8128" layer="51"/>
<circle x="-5.08" y="0" radius="3.81" width="0.1524" layer="21"/>
<circle x="-5.08" y="0" radius="1.27" width="0.1524" layer="51"/>
<pad name="1" x="-5.08" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="1.016" shape="octagon"/>
<text x="-1.016" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.016" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.858" y="2.032" size="1.016" layer="21" ratio="12">0817</text>
<rectangle x1="-3.81" y1="-0.4064" x2="0" y2="0.4064" layer="21"/>
</package>
<package name="V234/12">
type V234, grid 12.5 mm</description>
<wire x1="-4.953" y1="1.524" x2="-4.699" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="1.778" x2="4.953" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-1.778" x2="4.953" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.953" y1="-1.524" x2="-4.699" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.699" y1="1.778" x2="4.699" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="1.524" x2="-4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.778" x2="-4.699" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="4.953" y1="1.524" x2="4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0" x2="5.461" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.461" y2="0" width="0.8128" layer="51"/>
<pad name="1" x="-6.35" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="1.016" shape="octagon"/>
<text x="-4.953" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.953" y1="-0.4064" x2="5.4102" y2="0.4064" layer="21"/>
<rectangle x1="-5.4102" y1="-0.4064" x2="-4.953" y2="0.4064" layer="21"/>
</package>
<package name="V235/17">
type V235, grid 17.78 mm</description>
<wire x1="-6.731" y1="2.921" x2="6.731" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="2.54" x2="-7.112" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.921" x2="-6.731" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="7.112" y1="2.54" x2="7.112" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.89" y1="0" x2="7.874" y2="0" width="1.016" layer="51"/>
<wire x1="-7.874" y1="0" x2="-8.89" y2="0" width="1.016" layer="51"/>
<wire x1="-7.112" y1="-2.54" x2="-6.731" y2="-2.921" width="0.1524" layer="21" curve="90"/>
<wire x1="6.731" y1="2.921" x2="7.112" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.731" y1="-2.921" x2="7.112" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-7.112" y1="2.54" x2="-6.731" y2="2.921" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-8.89" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="8.89" y="0" drill="1.1938" shape="octagon"/>
<text x="-6.858" y="3.302" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.842" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="7.112" y1="-0.508" x2="7.747" y2="0.508" layer="21"/>
<rectangle x1="-7.747" y1="-0.508" x2="-7.112" y2="0.508" layer="21"/>
</package>
<package name="V526-0">
type V526-0, grid 2.5 mm</description>
<wire x1="-2.54" y1="1.016" x2="-2.286" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="1.27" x2="2.54" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="-1.27" x2="2.54" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.54" y1="-1.016" x2="-2.286" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.27" x2="-2.286" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.016" x2="2.54" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.27" x2="2.286" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.016" x2="-2.54" y2="-1.016" width="0.1524" layer="21"/>
<text x="-2.413" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.413" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0102AX">
<description>&lt;b&gt;Mini MELF 0102 Axial&lt;/b&gt;</description>
<circle x="0" y="0" radius="0.6" width="0" layer="51"/>
<circle x="0" y="0" radius="0.6" width="0" layer="52"/>
<smd name="1" x="0" y="0" dx="1.9" dy="1.9" layer="1" roundness="100"/>
<smd name="2" x="0" y="0" dx="1.9" dy="1.9" layer="16" roundness="100"/>
<text x="-1.27" y="0.9525" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.2225" size="1.27" layer="27">&gt;VALUE</text>
<hole x="0" y="0" drill="1.3"/>
</package>
<package name="0922V">
type 0922, grid 7.5 mm</description>
<wire x1="-5.08" y1="0" x2="-3.81" y2="0" width="0.8128" layer="51"/>
<circle x="-5.08" y="0" radius="4.572" width="0.1524" layer="21"/>
<circle x="-5.08" y="0" radius="1.905" width="0.1524" layer="21"/>
<text x="-0.508" y="1.6764" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.508" y="-2.9972" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.858" y="2.54" size="1.016" layer="21" ratio="12">0922</text>
<rectangle x1="-3.81" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="MINI_MELF-0102R">
<description>&lt;b&gt;CECC Size RC2211&lt;/b&gt; Reflow Soldering&lt;p&gt;
source Beyschlag</description>
<wire x1="-1" y1="-0.5" x2="1" y2="-0.5" width="0.2032" layer="51"/>
<wire x1="1" y1="-0.5" x2="1" y2="0.5" width="0.2032" layer="51"/>
<wire x1="1" y1="0.5" x2="-1" y2="0.5" width="0.2032" layer="51"/>
<wire x1="-1" y1="0.5" x2="-1" y2="-0.5" width="0.2032" layer="51"/>
<smd name="1" x="-0.9" y="0" dx="0.5" dy="1.3" layer="1"/>
<smd name="2" x="0.9" y="0" dx="0.5" dy="1.3" layer="1"/>
</package>
<package name="MINI_MELF-0102W">
<description>&lt;b&gt;CECC Size RC2211&lt;/b&gt; Wave Soldering&lt;p&gt;
<smd name="1" x="-0.95" y="0" dx="0.6" dy="1.3" layer="1"/>
<smd name="2" x="0.95" y="0" dx="0.6" dy="1.3" layer="1"/>
</package>
<package name="MINI_MELF-0204R">
<description>&lt;b&gt;CECC Size RC3715&lt;/b&gt; Reflow Soldering&lt;p&gt;
<wire x1="-1.7" y1="-0.6" x2="1.7" y2="-0.6" width="0.2032" layer="51"/>
<wire x1="1.7" y1="-0.6" x2="1.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="1.7" y1="0.6" x2="-1.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-1.7" y1="0.6" x2="-1.7" y2="-0.6" width="0.2032" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="0.8" dy="1.6" layer="1"/>
<smd name="2" x="1.5" y="0" dx="0.8" dy="1.6" layer="1"/>
</package>
<package name="MINI_MELF-0204W">
<description>&lt;b&gt;CECC Size RC3715&lt;/b&gt; Wave Soldering&lt;p&gt;
<smd name="1" x="-1.5" y="0" dx="1.2" dy="1.6" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.2" dy="1.6" layer="1"/>
</package>
<package name="MINI_MELF-0207R">
<description>&lt;b&gt;CECC Size RC6123&lt;/b&gt; Reflow Soldering&lt;p&gt;
<wire x1="-2.8" y1="-1" x2="2.8" y2="-1" width="0.2032" layer="51"/>
<wire x1="2.8" y1="-1" x2="2.8" y2="1" width="0.2032" layer="51"/>
<wire x1="2.8" y1="1" x2="-2.8" y2="1" width="0.2032" layer="51"/>
<wire x1="-2.8" y1="1" x2="-2.8" y2="-1" width="0.2032" layer="51"/>
<smd name="1" x="-2.25" y="0" dx="1.6" dy="2.5" layer="1"/>
<smd name="2" x="2.25" y="0" dx="1.6" dy="2.5" layer="1"/>
<text x="-2.2225" y="1.5875" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.2225" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0207W">
<description>&lt;b&gt;CECC Size RC6123&lt;/b&gt; Wave Soldering&lt;p&gt;
<smd name="1" x="-2.6" y="0" dx="2.4" dy="2.5" layer="1"/>
<smd name="2" x="2.6" y="0" dx="2.4" dy="2.5" layer="1"/>
<text x="-2.54" y="1.5875" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RDH/15">
type RDH, grid 15 mm</description>
<wire x1="-7.62" y1="0" x2="-6.858" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.096" y1="3.048" x2="-5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="2.794" x2="-5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-3.048" x2="-5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.794" x2="-5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.794" x2="5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.794" x2="-4.953" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-2.794" x2="5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-2.794" x2="-4.953" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="6.096" y1="3.048" x2="5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-3.048" x2="5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-2.667" x2="-6.477" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="1.016" x2="-6.477" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="1.016" x2="-6.477" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-2.667" x2="6.477" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="6.477" y1="1.016" x2="6.477" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="6.477" y1="1.016" x2="6.477" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.858" y1="0" x2="7.62" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.477" y1="2.667" x2="-6.096" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="3.048" x2="6.477" y2="2.667" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.477" y1="-2.667" x2="-6.096" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="6.096" y1="-3.048" x2="6.477" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<text x="-6.35" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="4.572" y="-1.7272" size="1.27" layer="51" ratio="10" rot="R90">RDH</text>
<rectangle x1="-6.7564" y1="-0.4064" x2="-6.4516" y2="0.4064" layer="51"/>
<rectangle x1="6.4516" y1="-0.4064" x2="6.7564" y2="0.4064" layer="51"/>
</package>
<package name="0204V">
type 0204, grid 2.5 mm</description>
<wire x1="-1.27" y1="0" x2="1.27" y2="0" width="0.508" layer="51"/>
<wire x1="-0.127" y1="0" x2="0.127" y2="0" width="0.508" layer="21"/>
<circle x="-1.27" y="0" radius="0.889" width="0.1524" layer="51"/>
<circle x="-1.27" y="0" radius="0.635" width="0.0508" layer="51"/>
<text x="-2.1336" y="1.1684" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0309V">
type 0309, grid 2.5 mm</description>
<wire x1="1.27" y1="0" x2="0.635" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.635" y1="0" x2="-1.27" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.524" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="0.762" width="0.1524" layer="51"/>
<text x="0.254" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.254" y="-2.2098" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-0.3048" x2="0.5588" y2="0.3048" layer="51"/>
<rectangle x1="-0.635" y1="-0.3048" x2="-0.3302" y2="0.3048" layer="51"/>
<rectangle x1="-0.3302" y1="-0.3048" x2="0.254" y2="0.3048" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="R-US">
<wire x1="-2.54" y1="0" x2="-2.159" y2="1.016" width="0.2032" layer="94"/>
<wire x1="-2.159" y1="1.016" x2="-1.524" y2="-1.016" width="0.2032" layer="94"/>
<wire x1="-1.524" y1="-1.016" x2="-0.889" y2="1.016" width="0.2032" layer="94"/>
<wire x1="-0.889" y1="1.016" x2="-0.254" y2="-1.016" width="0.2032" layer="94"/>
<wire x1="-0.254" y1="-1.016" x2="0.381" y2="1.016" width="0.2032" layer="94"/>
<wire x1="0.381" y1="1.016" x2="1.016" y2="-1.016" width="0.2032" layer="94"/>
<wire x1="1.016" y1="-1.016" x2="1.651" y2="1.016" width="0.2032" layer="94"/>
<wire x1="1.651" y1="1.016" x2="2.286" y2="-1.016" width="0.2032" layer="94"/>
<wire x1="2.286" y1="-1.016" x2="2.54" y2="0" width="0.2032" layer="94"/>
<text x="-3.81" y="1.4986" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.81" y="-3.302" size="1.778" layer="96">&gt;VALUE</text>
<pin name="2" x="5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1" rot="R180"/>
<pin name="1" x="-5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="R-US_" prefix="R" uservalue="yes">
<description>&lt;B&gt;RESISTOR&lt;/B&gt;, American symbol</description>
<gates>
<gate name="G$1" symbol="R-US" x="0" y="0"/>
</gates>
<devices>
<device name="R0402" package="R0402">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="R0603" package="R0603">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R0805" package="R0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R0805W" package="R0805W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1005" package="R1005">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1206" package="R1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1206W" package="R1206W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1210" package="R1210">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1210W" package="R1210W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2010" package="R2010">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2010W" package="R2010W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2012" package="R2012">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2012W" package="R2012W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2512" package="R2512">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2512W" package="R2512W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3216" package="R3216">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3216W" package="R3216W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3225" package="R3225">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3225W" package="R3225W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R5025" package="R5025">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R5025W" package="R5025W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R6332" package="R6332">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R6332W" package="R6332W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M0805" package="M0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M1206" package="M1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M1406" package="M1406">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M2012" package="M2012">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M2309" package="M2309">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M3216" package="M3216">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M3516" package="M3516">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M5923" package="M5923">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/5" package="0204/5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/7" package="0204/7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/10" package="0207/10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/12" package="0207/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/15" package="0207/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/2V" package="0207/2V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/5V" package="0207/5V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/7" package="0207/7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0309/10" package="0309/10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0309/12" package="0309/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0411/12" package="0411/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0411/15" package="0411/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0411/3V" package="0411V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0414/15" package="0414/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0414/5V" package="0414V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0617/17" package="0617/17">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0617/22" package="0617/22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0617/5V" package="0617V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0922/22" package="0922/22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0613/5V" package="P0613V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0613/15" package="P0613/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0817/22" package="P0817/22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0817/7V" package="P0817V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V234/12" package="V234/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V235/17" package="V235/17">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V526-0" package="V526-0">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0102AX" package="MINI_MELF-0102AX">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0922V" package="0922V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0102R" package="MINI_MELF-0102R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0102W" package="MINI_MELF-0102W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0204R" package="MINI_MELF-0204R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0204W" package="MINI_MELF-0204W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0207R" package="MINI_MELF-0207R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0207W" package="MINI_MELF-0207W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="RDH/15" package="RDH/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/2V" package="0204V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0309/V" package="0309V">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="solpad">
<description>&lt;b&gt;Solder Pads/Test Points&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="LSP10">
<description>&lt;b&gt;SOLDER PAD&lt;/b&gt;&lt;p&gt;
drill 1.0 mm</description>
<wire x1="-1.27" y1="0.254" x2="-1.27" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.254" x2="1.27" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.254" x2="1.143" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.254" x2="1.143" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.254" x2="-1.143" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.254" x2="-1.143" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.254" x2="0.635" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="-0.254" x2="-0.635" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0.254" x2="0.635" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0.254" x2="-0.635" y2="0.254" width="0.1524" layer="51"/>
<wire x1="0.635" y1="-0.254" x2="1.143" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="0.254" x2="-0.635" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="0.254" x2="-1.143" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-0.254" x2="0.635" y2="-0.254" width="0.1524" layer="51"/>
<pad name="MP" x="0" y="0" drill="1.016" diameter="2.159" shape="octagon"/>
<text x="-1.27" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0" y="0.254" size="0.0254" layer="27">&gt;VALUE</text>
</package>
</packages>
<symbols>
<symbol name="LSP">
<wire x1="-1.016" y1="2.032" x2="1.016" y2="0" width="0.254" layer="94"/>
<wire x1="-1.016" y1="0" x2="1.016" y2="2.032" width="0.254" layer="94"/>
<circle x="0" y="1.016" radius="1.016" width="0.4064" layer="94"/>
<text x="-1.27" y="2.921" size="1.778" layer="95">&gt;NAME</text>
<pin name="MP" x="0" y="-2.54" visible="off" length="short" direction="pas" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="LSP10" prefix="LSP">
<description>&lt;b&gt;SOLDER PAD&lt;/b&gt;&lt;p&gt; drill 1.0 mm, distributor Buerklin, 12H555</description>
<gates>
<gate name="1" symbol="LSP" x="0" y="0"/>
</gates>
<devices>
<device name="" package="LSP10">
<connects>
<connect gate="1" pin="MP" pad="MP"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="relay">
<description>&lt;b&gt;Relays&lt;/b&gt;&lt;p&gt;
&lt;ul&gt;
&lt;li&gt;Eichhoff
&lt;li&gt;Finder
&lt;li&gt;Fujitsu
&lt;li&gt;HAMLIN
&lt;li&gt;OMRON
&lt;li&gt;Matsushita
&lt;li&gt;NAiS
&lt;li&gt;Siemens
&lt;li&gt;Schrack
&lt;/ul&gt;
<packages>
<package name="351">
<description>&lt;b&gt;RELAY&lt;/b&gt;&lt;p&gt;
2 x switch, same as G5 V-2, Omron</description>
<wire x1="-5.08" y1="-5.08" x2="15.24" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-5.08" x2="15.24" y2="5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="5.08" x2="-5.08" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="5.08" x2="-5.08" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.27" x2="-3.81" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.27" x2="-3.81" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-1.27" x2="-5.08" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-1.27" x2="-5.08" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="3.81" x2="-1.905" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="3.81" x2="-1.905" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0.635" x2="-3.175" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0.635" x2="-3.175" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-0.635" x2="-0.635" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0.635" x2="-1.905" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-0.635" x2="-1.905" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-0.635" x2="-1.905" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-0.635" x2="-0.635" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-3.81" x2="-2.794" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-0.635" x2="-0.635" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="2.794" x2="3.81" y2="1.905" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.905" x2="11.43" y2="1.905" width="0.1524" layer="21"/>
<wire x1="11.43" y1="1.905" x2="11.43" y2="3.175" width="0.1524" layer="21"/>
<wire x1="11.43" y1="3.175" x2="10.795" y2="3.81" width="0.1524" layer="21"/>
<wire x1="9.9822" y1="3.81" x2="10.795" y2="3.81" width="0.1524" layer="21"/>
<wire x1="12.065" y1="3.81" x2="12.9032" y2="3.81" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-2.794" x2="3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-1.905" x2="11.43" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="11.43" y1="-1.905" x2="11.43" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="11.43" y1="-3.175" x2="10.795" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="9.9822" y1="-3.81" x2="10.795" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-3.81" x2="10.4902" y2="-4.1402" width="0.1524" layer="21"/>
<wire x1="12.065" y1="-3.81" x2="12.9032" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="10.795" y1="3.81" x2="10.4902" y2="4.1402" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="P1" x="3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="O1" x="8.89" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="S1" x="13.97" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="S2" x="13.97" y="3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="O2" x="8.89" y="3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="P2" x="3.81" y="3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="-3.81" y="3.81" drill="1.016" shape="long" rot="R90"/>
<text x="17.78" y="-5.08" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="14.732" y="-1.397" size="1.27" layer="51" ratio="10" rot="R90">351</text>
<text x="1.27" y="-0.889" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.08" y1="-1.27" x2="-3.81" y2="1.27" layer="21"/>
</package>
<package name="CQ1">
<description>&lt;b&gt;AUTOMOTIVE QUIET RELAY&lt;/b&gt; NAiS&lt;p&gt;
Source: http://www.mew-europe.com/.. en_ds_61208_0000.pdf</description>
<wire x1="-7.8" y1="6.4" x2="7.8" y2="6.4" width="0.2032" layer="21"/>
<wire x1="8.4" y1="5.8" x2="8.4" y2="-5.8" width="0.2032" layer="21"/>
<wire x1="7.8" y1="-6.4" x2="-7.8" y2="-6.4" width="0.2032" layer="21"/>
<wire x1="-8.4" y1="-5.8" x2="-8.4" y2="5.8" width="0.2032" layer="21"/>
<wire x1="-8.4" y1="5.8" x2="-7.8" y2="6.4" width="0.2032" layer="21" curve="-90"/>
<wire x1="7.8" y1="6.4" x2="8.4" y2="5.8" width="0.2032" layer="21" curve="-90"/>
<wire x1="8.4" y1="-5.8" x2="7.8" y2="-6.4" width="0.2032" layer="21" curve="-90"/>
<wire x1="-7.8" y1="-6.4" x2="-8.4" y2="-5.8" width="0.2032" layer="21" curve="-90"/>
<pad name="NO" x="-5.7" y="5" drill="1.5" rot="R180"/>
<pad name="NC" x="-5.7" y="-5" drill="1.5" rot="R180"/>
<pad name="1" x="4.5" y="-5" drill="1.5" rot="R180"/>
<pad name="2" x="4.5" y="5" drill="1.5" rot="R180"/>
<pad name="C" x="7" y="0" drill="1.5" rot="R180"/>
<text x="-7.62" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-7.62" y="-1.27" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
<symbols>
<symbol name="K">
<wire x1="-3.81" y1="-1.905" x2="-1.905" y2="-1.905" width="0.254" layer="94"/>
<wire x1="3.81" y1="-1.905" x2="3.81" y2="1.905" width="0.254" layer="94"/>
<wire x1="3.81" y1="1.905" x2="1.905" y2="1.905" width="0.254" layer="94"/>
<wire x1="-3.81" y1="1.905" x2="-3.81" y2="-1.905" width="0.254" layer="94"/>
<wire x1="0" y1="-2.54" x2="0" y2="-1.905" width="0.1524" layer="94"/>
<wire x1="0" y1="-1.905" x2="3.81" y2="-1.905" width="0.254" layer="94"/>
<wire x1="0" y1="2.54" x2="0" y2="1.905" width="0.1524" layer="94"/>
<wire x1="0" y1="1.905" x2="-3.81" y2="1.905" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-1.905" x2="1.905" y2="1.905" width="0.1524" layer="94"/>
<wire x1="-1.905" y1="-1.905" x2="0" y2="-1.905" width="0.254" layer="94"/>
<wire x1="1.905" y1="1.905" x2="0" y2="1.905" width="0.254" layer="94"/>
<text x="1.27" y="2.921" size="1.778" layer="96">&gt;VALUE</text>
<text x="1.27" y="5.08" size="1.778" layer="95">&gt;PART</text>
<pin name="2" x="0" y="-5.08" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="1" x="0" y="5.08" visible="pad" length="short" direction="pas" rot="R270"/>
</symbol>
<symbol name="U">
<wire x1="3.175" y1="5.08" x2="1.905" y2="5.08" width="0.254" layer="94"/>
<wire x1="-3.175" y1="5.08" x2="-1.905" y2="5.08" width="0.254" layer="94"/>
<wire x1="0" y1="1.27" x2="2.54" y2="5.715" width="0.254" layer="94"/>
<wire x1="0" y1="1.27" x2="0" y2="0" width="0.254" layer="94"/>
<circle x="0" y="1.27" radius="0.127" width="0.4064" layer="94"/>
<text x="2.54" y="0" size="1.778" layer="95">&gt;PART</text>
<pin name="O" x="5.08" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="S" x="-5.08" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="P" x="0" y="-2.54" visible="pad" length="short" direction="pas" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="351" prefix="K">
2 x switch, Omron</description>
<gates>
<gate name="1" symbol="K" x="0" y="0" addlevel="must"/>
<gate name="2" symbol="U" x="17.78" y="-2.54" addlevel="always" swaplevel="1"/>
<gate name="3" symbol="U" x="17.78" y="-17.78" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="" package="351">
<connects>
<connect gate="1" pin="1" pad="1"/>
<connect gate="1" pin="2" pad="16"/>
<connect gate="2" pin="O" pad="O1"/>
<connect gate="2" pin="P" pad="P1"/>
<connect gate="2" pin="S" pad="S1"/>
<connect gate="3" pin="O" pad="O2"/>
<connect gate="3" pin="P" pad="P2"/>
<connect gate="3" pin="S" pad="S2"/>
</connects>
<technologies>
<technology name="">
<attribute name="MF" value="" constant="no"/>
<attribute name="MPN" value="" constant="no"/>
<attribute name="OC_FARNELL" value="unknown" constant="no"/>
<attribute name="OC_NEWARK" value="unknown" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="CQ1-12V" prefix="K">
<gates>
<gate name="1" symbol="K" x="-7.62" y="0" addlevel="must"/>
<gate name="2" symbol="U" x="10.16" y="0" addlevel="always"/>
</gates>
<devices>
<device name="" package="CQ1">
<connects>
<connect gate="1" pin="2" pad="2"/>
<connect gate="2" pin="O" pad="NC"/>
<connect gate="2" pin="P" pad="C"/>
<connect gate="2" pin="S" pad="NO"/>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="diode">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
<packages>
<package name="DO41-10">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2.54 mm, horizontal, grid 10.16 mm</description>
<wire x1="2.032" y1="-1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<pad name="A" x="5.08" y="0" drill="1.1176"/>
<pad name="C" x="-5.08" y="0" drill="1.1176"/>
<text x="-2.032" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.27" x2="-1.143" y2="1.27" layer="21"/>
<rectangle x1="2.032" y1="-0.381" x2="3.937" y2="0.381" layer="21"/>
<rectangle x1="-3.937" y1="-0.381" x2="-2.032" y2="0.381" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="D">
<wire x1="-1.27" y1="-1.27" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="-1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="1.27" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="1.27" y2="-1.27" width="0.254" layer="94"/>
<text x="2.54" y="0.4826" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="-2.3114" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A" x="-2.54" y="0" visible="off" length="short" direction="pas"/>
<pin name="C" x="2.54" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="1N4004" prefix="D">
general purpose rectifier, 1 A</description>
<gates>
<gate name="1" symbol="D" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DO41-10">
<connects>
<connect gate="1" pin="A" pad="A"/>
<connect gate="1" pin="C" pad="C"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="transistor">
<description>&lt;b&gt;Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="TO220">
<description>&lt;b&gt;TO 220 horizontal&lt;/b&gt;</description>
<wire x1="-5.207" y1="-1.27" x2="5.207" y2="-1.27" width="0.127" layer="21"/>
<wire x1="5.207" y1="14.605" x2="-5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="5.207" y1="-1.27" x2="5.207" y2="11.176" width="0.127" layer="21"/>
<wire x1="5.207" y1="11.176" x2="4.318" y2="11.176" width="0.127" layer="21"/>
<wire x1="4.318" y1="11.176" x2="4.318" y2="12.7" width="0.127" layer="21"/>
<wire x1="4.318" y1="12.7" x2="5.207" y2="12.7" width="0.127" layer="21"/>
<wire x1="5.207" y1="12.7" x2="5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="11.176" width="0.127" layer="21"/>
<wire x1="-5.207" y1="11.176" x2="-4.318" y2="11.176" width="0.127" layer="21"/>
<wire x1="-4.318" y1="11.176" x2="-4.318" y2="12.7" width="0.127" layer="21"/>
<wire x1="-4.318" y1="12.7" x2="-5.207" y2="12.7" width="0.127" layer="21"/>
<wire x1="-5.207" y1="12.7" x2="-5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<circle x="0" y="11.176" radius="1.8034" width="0.127" layer="21"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="42"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="43"/>
<pad name="1" x="-2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<text x="-3.81" y="5.207" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.937" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="7.874" size="0.9906" layer="21" ratio="12">A17,5mm</text>
<text x="-3.175" y="0" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="0" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="0" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="2.159" y1="-4.699" x2="2.921" y2="-4.064" layer="21"/>
<rectangle x1="-0.381" y1="-4.699" x2="0.381" y2="-4.064" layer="21"/>
<rectangle x1="-2.921" y1="-4.699" x2="-2.159" y2="-4.064" layer="21"/>
<rectangle x1="-3.175" y1="-4.064" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="-0.635" y1="-4.064" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-4.064" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="-2.921" y1="-6.604" x2="-2.159" y2="-4.699" layer="51"/>
<rectangle x1="-0.381" y1="-6.604" x2="0.381" y2="-4.699" layer="51"/>
<rectangle x1="2.159" y1="-6.604" x2="2.921" y2="-4.699" layer="51"/>
<hole x="0" y="11.176" drill="3.302"/>
</package>
<package name="TO3">
<description>&lt;b&gt;TO-3&lt;/b&gt;</description>
<wire x1="6.3754" y1="-10.9982" x2="17.3736" y2="-4.5212" width="0.1524" layer="21"/>
<wire x1="5.969" y1="11.2014" x2="17.3736" y2="4.5212" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="10.9982" x2="-17.272" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-5.9436" y1="-11.2268" x2="-17.2466" y2="-4.5974" width="0.1524" layer="21"/>
<wire x1="17.3366" y1="4.545" x2="19.812" y2="0" width="0.1524" layer="21" curve="-57.1487"/>
<wire x1="17.3366" y1="-4.545" x2="19.812" y2="0" width="0.1524" layer="21" curve="57.1487"/>
<wire x1="-19.812" y1="0" x2="-17.0927" y2="4.6935" width="0.1524" layer="21" curve="-60.1731"/>
<wire x1="-19.812" y1="0" x2="-17.1555" y2="-4.657" width="0.1524" layer="21" curve="59.4042"/>
<wire x1="0" y1="-12.7" x2="6.3718" y2="-10.9859" width="0.1524" layer="21" curve="30.1136"/>
<wire x1="-5.9765" y1="-11.2059" x2="0" y2="-12.7" width="0.1524" layer="21" curve="28.0726"/>
<wire x1="-6.3718" y1="10.9859" x2="0" y2="12.7" width="0.1524" layer="21" curve="-30.1136"/>
<wire x1="0" y1="12.7" x2="5.9765" y2="11.2059" width="0.1524" layer="21" curve="-28.0726"/>
<circle x="0" y="0" radius="9.3726" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="11.684" width="0.0508" layer="21"/>
<circle x="15.113" y="0" radius="2.159" width="0.1524" layer="51"/>
<circle x="-15.113" y="0" radius="2.159" width="0.1524" layer="51"/>
<pad name="E" x="-1.778" y="-5.461" drill="1.1938" diameter="3.1496" shape="long"/>
<pad name="B" x="-1.778" y="5.461" drill="1.1938" diameter="3.1496" shape="long"/>
<pad name="C" x="15.113" y="0" drill="4.1148" diameter="6.477"/>
<pad name="C/" x="-15.113" y="0" drill="4.1148" diameter="6.477"/>
<text x="-5.08" y="1.27" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="15.24" y="-4.953" size="1.27" layer="51" ratio="10" rot="R90">C</text>
<text x="-3.81" y="-6.223" size="1.27" layer="51" ratio="10" rot="R90">E</text>
<text x="-3.81" y="4.572" size="1.27" layer="51" ratio="10" rot="R90">B</text>
</package>
<package name="TO18">
<description>&lt;b&gt;TO 18&lt;/b&gt;</description>
<wire x1="0.9289" y1="2.227" x2="2.227" y2="0.9289" width="0.0508" layer="51" curve="-44.7172"/>
<wire x1="0.9289" y1="-2.227" x2="2.227" y2="-0.9289" width="0.0508" layer="51" curve="44.7172"/>
<wire x1="-3.937" y1="-0.508" x2="-3.937" y2="0.508" width="0.127" layer="21"/>
<wire x1="-2.227" y1="-0.9289" x2="0.929" y2="2.2271" width="0.0508" layer="21" curve="-135.281"/>
<wire x1="-2.227" y1="-0.9289" x2="-0.9289" y2="-2.227" width="0.0508" layer="51" curve="44.7172"/>
<wire x1="-3.937" y1="-0.508" x2="-2.8765" y2="-0.508" width="0.127" layer="21"/>
<wire x1="-0.9289" y1="-2.227" x2="0.9289" y2="-2.227" width="0.0508" layer="21" curve="45.2828"/>
<wire x1="-3.937" y1="0.508" x2="-2.8765" y2="0.508" width="0.127" layer="21"/>
<wire x1="2.227" y1="-0.9289" x2="2.227" y2="0.9289" width="0.0508" layer="21" curve="45.2828"/>
<circle x="0" y="0" radius="2.921" width="0.127" layer="21"/>
<pad name="1" x="-1.27" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="3" x="1.27" y="1.27" drill="0.8128" shape="octagon"/>
<text x="3.175" y="0" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.905" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-1.905" y="-1.27" size="1.27" layer="51" ratio="10">1</text>
<text x="0.635" y="-1.27" size="1.27" layer="51" ratio="10">2</text>
<text x="0" y="0.635" size="1.27" layer="51" ratio="10">3</text>
</package>
<package name="TO18-">
<description>&lt;b&gt;TO-18&lt;/b&gt;</description>
<wire x1="-2.2098" y1="-0.9692" x2="2.2098" y2="-0.9692" width="0.0508" layer="21" curve="132.636"/>
<wire x1="-0.9692" y1="2.2098" x2="0.9692" y2="2.2098" width="0.0508" layer="51" curve="-47.3637"/>
<wire x1="-2.2098" y1="0.9692" x2="-2.2098" y2="-0.9692" width="0.0508" layer="51" curve="47.3637"/>
<wire x1="-2.2098" y1="0.9692" x2="-0.9692" y2="2.2098" width="0.0508" layer="21" curve="-42.6363"/>
<wire x1="2.2098" y1="-0.9692" x2="2.2098" y2="0.9692" width="0.0508" layer="51" curve="47.3637"/>
<wire x1="1.649" y1="-2.411" x2="2.413" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="2.411" y1="-1.649" x2="3.175" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-3.175" x2="3.175" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="0.9692" y1="2.2098" x2="2.2098" y2="0.9692" width="0.0508" layer="21" curve="-42.6363"/>
<circle x="0" y="0" radius="2.921" width="0.1524" layer="21"/>
<pad name="1" x="1.905" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="0" y="1.905" drill="0.8128" shape="octagon"/>
<pad name="3" x="-1.905" y="0" drill="0.8128" shape="octagon"/>
<text x="3.302" y="0.381" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.302" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="1.016" y="-1.143" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.508" y="0.635" size="1.27" layer="51" ratio="10">2</text>
<text x="-1.905" y="-1.27" size="1.27" layer="51" ratio="10">3</text>
</package>
<package name="TO202">
<description>&lt;b&gt;TO 202 horizontal&lt;/b&gt;</description>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="7.3406" width="0.127" layer="21"/>
<wire x1="-3.5052" y1="7.3406" x2="-3.5052" y2="8.8138" width="0.127" layer="21"/>
<wire x1="-3.5052" y1="8.8138" x2="-5.207" y2="8.8138" width="0.127" layer="21"/>
<wire x1="5.207" y1="8.8138" x2="3.5052" y2="8.8138" width="0.127" layer="21"/>
<wire x1="3.5052" y1="8.8138" x2="3.5052" y2="7.3406" width="0.127" layer="21"/>
<wire x1="5.2578" y1="-1.27" x2="5.2578" y2="7.3406" width="0.127" layer="21"/>
<wire x1="-5.207" y1="7.3406" x2="-3.5052" y2="7.3406" width="0.127" layer="21"/>
<wire x1="3.8354" y1="-1.27" x2="3.8354" y2="7.3406" width="0.127" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="3.8354" y2="-1.27" width="0.127" layer="21"/>
<wire x1="5.207" y1="21.717" x2="5.207" y2="8.8138" width="0.127" layer="21"/>
<wire x1="5.207" y1="21.717" x2="-5.207" y2="21.717" width="0.127" layer="21"/>
<wire x1="-5.207" y1="21.717" x2="-5.207" y2="8.8138" width="0.127" layer="21"/>
<wire x1="-3.5052" y1="7.3406" x2="3.5052" y2="7.3406" width="0.127" layer="21"/>
<wire x1="3.8354" y1="-1.27" x2="5.2578" y2="-1.27" width="0.127" layer="21"/>
<wire x1="3.8354" y1="7.3406" x2="5.2578" y2="7.3406" width="0.127" layer="21"/>
<wire x1="3.5052" y1="7.3406" x2="3.8354" y2="7.3406" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-1.016" x2="4.953" y2="-1.016" width="0.0508" layer="21"/>
<wire x1="4.953" y1="7.112" x2="4.953" y2="-1.016" width="0.0508" layer="21"/>
<wire x1="4.953" y1="7.112" x2="-4.953" y2="7.112" width="0.0508" layer="21"/>
<wire x1="-4.953" y1="-1.016" x2="-4.953" y2="7.112" width="0.0508" layer="21"/>
<circle x="-3.7592" y="-0.2286" radius="0.4318" width="0" layer="21"/>
<circle x="0" y="17.78" radius="1.651" width="0.127" layer="21"/>
<circle x="0" y="17.78" radius="4.191" width="0" layer="42"/>
<circle x="0" y="17.78" radius="4.191" width="0" layer="43"/>
<pad name="1" x="-2.54" y="-5.08" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-5.08" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-5.08" drill="1.1176" shape="long" rot="R90"/>
<text x="-2.54" y="4.318" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.445" y="2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-2.54" y="-0.635" size="1.27" layer="21" ratio="10">1</text>
<text x="-0.635" y="-0.635" size="1.27" layer="21" ratio="10">2</text>
<text x="1.905" y="-0.635" size="1.27" layer="21" ratio="10">3</text>
<rectangle x1="-0.635" y1="-2.54" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-2.54" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="-3.175" y1="-2.54" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="2.159" y1="-3.429" x2="2.921" y2="-2.54" layer="21"/>
<rectangle x1="2.159" y1="-5.08" x2="2.921" y2="-3.429" layer="51"/>
<rectangle x1="-0.381" y1="-3.429" x2="0.381" y2="-2.54" layer="21"/>
<rectangle x1="-2.921" y1="-3.429" x2="-2.159" y2="-2.54" layer="21"/>
<rectangle x1="-0.381" y1="-5.08" x2="0.381" y2="-3.429" layer="51"/>
<rectangle x1="-2.921" y1="-5.08" x2="-2.159" y2="-3.429" layer="51"/>
<hole x="0" y="17.78" drill="3.302"/>
</package>
<package name="TO202V">
<description>&lt;b&gt;TO 202 vertical&lt;/b&gt;</description>
<wire x1="-4.826" y1="-4.7498" x2="2.794" y2="-4.7498" width="0.127" layer="21"/>
<wire x1="-4.826" y1="-0.127" x2="4.8006" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.794" y1="-4.7498" x2="4.8006" y2="-2.794" width="0.127" layer="21"/>
<wire x1="-4.826" y1="-4.7498" x2="-4.826" y2="-0.127" width="0.127" layer="21"/>
<wire x1="4.8006" y1="-0.127" x2="4.8006" y2="-2.794" width="0.127" layer="21"/>
<circle x="-4.064" y="-3.9878" radius="0.4318" width="0.127" layer="21"/>
<pad name="1" x="-2.54" y="-2.54" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-2.54" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-2.54" drill="1.1176" shape="long" rot="R90"/>
<text x="-4.445" y="-6.985" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.445" y="-8.89" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.175" y="-1.905" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="-1.905" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="-1.905" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="3.429" y1="-2.794" x2="4.826" y2="-2.286" layer="21"/>
<rectangle x1="0.889" y1="-2.794" x2="1.651" y2="-2.286" layer="21"/>
<rectangle x1="-1.651" y1="-2.794" x2="-0.889" y2="-2.286" layer="21"/>
<rectangle x1="-4.826" y1="-2.794" x2="-3.429" y2="-2.286" layer="21"/>
<rectangle x1="-3.429" y1="-2.794" x2="-1.651" y2="-2.286" layer="51"/>
<rectangle x1="-0.889" y1="-2.794" x2="0.889" y2="-2.286" layer="51"/>
<rectangle x1="1.651" y1="-2.794" x2="3.429" y2="-2.286" layer="51"/>
</package>
<package name="SOT93">
<description>SOT-93&lt;p&gt;
grid 5.45 mm</description>
<wire x1="-7.62" y1="-6.35" x2="7.62" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="7.62" y1="6.223" x2="7.62" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="7.62" y1="6.223" x2="6.985" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-6.35" x2="-7.62" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="6.223" x2="-6.985" y2="6.985" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="6.223" x2="-7.62" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="6.985" x2="-7.62" y2="6.985" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="6.985" x2="-7.62" y2="9.525" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="9.525" x2="-3.1242" y2="13.3096" width="0.1524" layer="21"/>
<wire x1="6.985" y1="6.223" x2="6.985" y2="6.985" width="0.1524" layer="21"/>
<wire x1="6.985" y1="6.223" x2="-6.985" y2="6.223" width="0.1524" layer="21"/>
<wire x1="6.985" y1="6.985" x2="7.62" y2="6.985" width="0.1524" layer="21"/>
<wire x1="7.62" y1="6.985" x2="7.62" y2="9.525" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-5.715" x2="6.985" y2="-5.715" width="0.0508" layer="21"/>
<wire x1="6.985" y1="5.715" x2="6.985" y2="-5.715" width="0.0508" layer="21"/>
<wire x1="6.985" y1="5.715" x2="-6.985" y2="5.715" width="0.0508" layer="21"/>
<wire x1="-6.985" y1="-5.715" x2="-6.985" y2="5.715" width="0.0508" layer="21"/>
<wire x1="0" y1="14.605" x2="3.1431" y2="13.3031" width="0.1524" layer="21" curve="-45.0001"/>
<wire x1="-3.1431" y1="13.3031" x2="0" y2="14.605" width="0.1524" layer="21" curve="-45.0001"/>
<wire x1="7.62" y1="9.525" x2="3.1242" y2="13.335" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-5.715" x2="7.62" y2="-6.35" width="0.0508" layer="51"/>
<wire x1="6.985" y1="5.715" x2="7.62" y2="6.35" width="0.0508" layer="51"/>
<wire x1="-6.985" y1="5.715" x2="-7.62" y2="6.35" width="0.0508" layer="51"/>
<wire x1="-6.985" y1="-5.715" x2="-7.62" y2="-6.35" width="0.0508" layer="51"/>
<circle x="0" y="10.16" radius="2.159" width="0.1524" layer="21"/>
<circle x="0" y="10.16" radius="5.08" width="0" layer="42"/>
<circle x="0" y="10.16" radius="5.08" width="0" layer="43"/>
<pad name="B" x="-5.461" y="-10.16" drill="1.397" shape="long" rot="R90"/>
<pad name="C" x="0" y="-10.16" drill="1.397" shape="long" rot="R90"/>
<pad name="E" x="5.461" y="-10.16" drill="1.397" shape="long" rot="R90"/>
<text x="-5.08" y="2.54" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="0" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.477" y="6.604" size="1.016" layer="21" ratio="10">A20,3mm</text>
<rectangle x1="-6.096" y1="-7.366" x2="-4.318" y2="-6.35" layer="21"/>
<rectangle x1="4.318" y1="-7.366" x2="6.096" y2="-6.35" layer="21"/>
<rectangle x1="-1.143" y1="-7.366" x2="1.143" y2="-6.35" layer="21"/>
<rectangle x1="-6.096" y1="-8.128" x2="-4.826" y2="-6.35" layer="21"/>
<rectangle x1="-0.635" y1="-8.128" x2="0.635" y2="-6.35" layer="21"/>
<rectangle x1="4.826" y1="-8.128" x2="6.096" y2="-6.35" layer="21"/>
<rectangle x1="-6.096" y1="-10.287" x2="-4.826" y2="-8.128" layer="51"/>
<rectangle x1="-0.635" y1="-10.287" x2="0.635" y2="-8.128" layer="51"/>
<rectangle x1="4.826" y1="-10.287" x2="6.096" y2="-8.128" layer="51"/>
<hole x="0" y="10.16" drill="4.1148"/>
</package>
<package name="SOT93V">
<wire x1="7.62" y1="-2.032" x2="3.429" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-2.032" x2="2.032" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-2.032" x2="-2.032" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="-2.032" y1="-2.032" x2="-3.429" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.032" x2="-7.62" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="-7.62" y1="0" x2="7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-7.239" y1="-5.08" x2="7.239" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.032" x2="-7.239" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0" x2="7.62" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-2.032" x2="7.239" y2="-5.08" width="0.1524" layer="21"/>
<pad name="B" x="-5.461" y="-2.54" drill="1.397" shape="long" rot="R90"/>
<pad name="C" x="0" y="-2.54" drill="1.397" shape="long" rot="R90"/>
<pad name="E" x="5.461" y="-2.54" drill="1.397" shape="long" rot="R90"/>
<text x="-1.397" y="-6.858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-7.62" y="-6.858" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-7.62" y1="-2.032" x2="7.62" y2="0" layer="51"/>
</package>
<package name="TO126">
<description>&lt;b&gt;TO 126 horizontal&lt;/b&gt;</description>
<wire x1="-3.937" y1="-1.27" x2="-3.937" y2="9.144" width="0.127" layer="21"/>
<wire x1="-3.937" y1="9.144" x2="3.937" y2="9.144" width="0.127" layer="21"/>
<wire x1="3.937" y1="9.144" x2="3.937" y2="-1.27" width="0.127" layer="21"/>
<wire x1="-3.937" y1="-1.27" x2="3.937" y2="-1.27" width="0.127" layer="21"/>
<wire x1="1.2393" y1="3.1591" x2="1.9493" y2="3.8858" width="0.127" layer="21" curve="25.6775"/>
<wire x1="0.7687" y1="3.6188" x2="1.2393" y2="3.1591" width="0.127" layer="21"/>
<wire x1="-0.7687" y1="3.6188" x2="-1.2393" y2="3.1591" width="0.127" layer="21"/>
<wire x1="-1.4787" y1="4.3456" x2="-1.9493" y2="3.8858" width="0.127" layer="21"/>
<wire x1="-1.9493" y1="3.8858" x2="-1.2393" y2="3.1591" width="0.127" layer="21" curve="25.6775"/>
<wire x1="0.508" y1="6.6509" x2="0.508" y2="7.3088" width="0.127" layer="21"/>
<wire x1="-0.508" y1="6.6509" x2="-0.508" y2="7.3088" width="0.127" layer="21"/>
<wire x1="-0.508" y1="7.3088" x2="0.508" y2="7.3088" width="0.127" layer="21" curve="-25.6796"/>
<wire x1="1.4787" y1="4.3456" x2="1.9493" y2="3.8858" width="0.127" layer="21"/>
<circle x="-3.1242" y="-0.4826" radius="0.4318" width="0" layer="21"/>
<circle x="0" y="5.08" radius="3.81" width="0" layer="42"/>
<circle x="0" y="5.08" radius="3.81" width="0" layer="43"/>
<circle x="0" y="5.08" radius="1.651" width="0.127" layer="21"/>
<pad name="1" x="-2.286" y="-5.08" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.286" y="-5.08" drill="1.1176" shape="long" rot="R90"/>
<text x="-2.54" y="7.62" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="1.397" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-2.54" y="-0.889" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.508" y="-0.889" size="1.27" layer="51" ratio="10">2</text>
<text x="1.778" y="-0.889" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-0.635" y1="-3.048" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="-2.667" y1="-3.429" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="-2.667" y1="-5.207" x2="-1.905" y2="-3.429" layer="51"/>
<rectangle x1="-0.381" y1="-3.429" x2="0.381" y2="-1.27" layer="21"/>
<rectangle x1="-0.381" y1="-5.207" x2="0.381" y2="-3.429" layer="51"/>
<rectangle x1="1.905" y1="-3.429" x2="2.667" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-5.207" x2="2.667" y2="-3.429" layer="51"/>
<hole x="0" y="5.08" drill="3.302"/>
</package>
<package name="TO126V">
<description>&lt;b&gt;TO 126 vertical&lt;/b&gt;</description>
<wire x1="-3.937" y1="-0.127" x2="-3.937" y2="-1.27" width="0.127" layer="21"/>
<wire x1="-3.937" y1="-1.27" x2="-3.683" y2="-2.794" width="0.127" layer="21"/>
<wire x1="3.683" y1="-2.794" x2="3.937" y2="-1.27" width="0.127" layer="21"/>
<wire x1="3.937" y1="-1.27" x2="3.937" y2="-0.127" width="0.127" layer="21"/>
<wire x1="-3.683" y1="-2.794" x2="-2.794" y2="-2.794" width="0.127" layer="21"/>
<wire x1="-2.794" y1="-2.794" x2="-1.778" y2="-2.794" width="0.127" layer="51"/>
<wire x1="-1.778" y1="-2.794" x2="-0.508" y2="-2.794" width="0.127" layer="21"/>
<wire x1="-0.508" y1="-2.794" x2="0.508" y2="-2.794" width="0.127" layer="51"/>
<wire x1="0.508" y1="-2.794" x2="1.778" y2="-2.794" width="0.127" layer="21"/>
<wire x1="1.778" y1="-2.794" x2="2.794" y2="-2.794" width="0.127" layer="51"/>
<wire x1="2.794" y1="-2.794" x2="3.683" y2="-2.794" width="0.127" layer="21"/>
<circle x="-3.175" y="-2.159" radius="0.4064" width="0.127" layer="51"/>
<pad name="1" x="-2.286" y="-1.27" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="-1.27" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="2.286" y="-1.27" drill="1.016" shape="long" rot="R90"/>
<text x="-3.9624" y="-4.5466" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.9878" y="-6.3246" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-2.54" y="-1.905" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.381" y="-1.905" size="1.27" layer="51" ratio="10">2</text>
<text x="2.032" y="-1.905" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-3.937" y1="-0.381" x2="-3.175" y2="0" layer="21"/>
<rectangle x1="-1.397" y1="-0.381" x2="-0.889" y2="0" layer="21"/>
<rectangle x1="0.889" y1="-0.381" x2="1.397" y2="0" layer="21"/>
<rectangle x1="3.175" y1="-0.381" x2="3.937" y2="0" layer="21"/>
<rectangle x1="-3.175" y1="-0.381" x2="-1.397" y2="0" layer="51"/>
<rectangle x1="-0.889" y1="-0.381" x2="0.889" y2="0" layer="51"/>
<rectangle x1="1.397" y1="-0.381" x2="3.175" y2="0" layer="51"/>
</package>
<package name="TO218">
<description>&lt;b&gt;TO 218 horizontal&lt;/b&gt;</description>
<wire x1="-7.62" y1="-6.35" x2="7.62" y2="-6.35" width="0.127" layer="21"/>
<wire x1="7.62" y1="6.223" x2="7.62" y2="0" width="0.127" layer="21"/>
<wire x1="7.62" y1="0" x2="7.62" y2="-3.81" width="0.127" layer="21"/>
<wire x1="7.62" y1="-3.81" x2="7.62" y2="-6.35" width="0.127" layer="21"/>
<wire x1="-7.62" y1="-6.35" x2="-7.62" y2="-3.81" width="0.127" layer="21"/>
<wire x1="-7.62" y1="-3.81" x2="-7.62" y2="0" width="0.127" layer="21"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="6.223" width="0.127" layer="21"/>
<wire x1="7.62" y1="6.223" x2="-7.62" y2="6.223" width="0.127" layer="21"/>
<wire x1="6.985" y1="0.508" x2="6.985" y2="5.715" width="0.0508" layer="21"/>
<wire x1="7.62" y1="12.065" x2="5.08" y2="14.605" width="0.127" layer="21"/>
<wire x1="7.62" y1="12.065" x2="7.62" y2="6.223" width="0.127" layer="21"/>
<wire x1="5.08" y1="14.605" x2="-5.08" y2="14.605" width="0.127" layer="21"/>
<wire x1="-7.62" y1="12.065" x2="-5.08" y2="14.605" width="0.127" layer="21"/>
<wire x1="-7.62" y1="12.065" x2="-7.62" y2="6.223" width="0.127" layer="21"/>
<wire x1="7.62" y1="0" x2="7.62" y2="-3.81" width="0.127" layer="21" curve="180"/>
<wire x1="6.985" y1="-5.715" x2="6.985" y2="-4.318" width="0.0508" layer="21"/>
<wire x1="6.9522" y1="0.4991" x2="6.9851" y2="-4.3178" width="0.0508" layer="21" curve="149.733"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="-3.81" width="0.127" layer="21" curve="-180"/>
<wire x1="-6.985" y1="-5.715" x2="-6.985" y2="-4.318" width="0.0508" layer="21"/>
<wire x1="-6.985" y1="0.508" x2="-6.985" y2="5.715" width="0.0508" layer="21"/>
<wire x1="-6.985" y1="-4.318" x2="-6.985" y2="0.508" width="0.0508" layer="21" curve="150.513"/>
<circle x="0" y="10.16" radius="2.159" width="0.127" layer="21"/>
<pad name="1" x="-5.461" y="-10.16" drill="1.397" shape="long" rot="R90"/>
<pad name="2" x="0" y="-10.16" drill="1.397" shape="long" rot="R90"/>
<pad name="3" x="5.461" y="-10.16" drill="1.397" shape="long" rot="R90"/>
<text x="-5.08" y="-5.08" size="1.27" layer="21" ratio="10">1</text>
<text x="-0.635" y="-5.08" size="1.27" layer="21" ratio="10">2</text>
<text x="4.445" y="-5.08" size="1.27" layer="21" ratio="10">3</text>
</package>
<package name="TO218V">
<description>&lt;b&gt;TO 218 vertical&lt;/b&gt;</description>
<wire x1="-6.985" y1="-5.08" x2="6.985" y2="-5.08" width="0.127" layer="21"/>
<wire x1="6.985" y1="-5.08" x2="7.366" y2="-4.699" width="0.127" layer="21"/>
<wire x1="7.366" y1="-4.699" x2="7.62" y2="-1.524" width="0.127" layer="21"/>
<wire x1="-6.985" y1="-5.08" x2="-7.366" y2="-4.699" width="0.127" layer="21"/>
<wire x1="-7.366" y1="-4.699" x2="-7.62" y2="-1.524" width="0.127" layer="21"/>
<pad name="1" x="-5.461" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<pad name="2" x="0" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<pad name="3" x="5.461" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<text x="-1.016" y="-6.858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.096" y="-4.445" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="-4.445" size="1.27" layer="51" ratio="10">2</text>
<text x="4.826" y="-4.445" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-7.874" y1="-1.143" x2="7.874" y2="0" layer="21"/>
<rectangle x1="-3.556" y1="-2.032" x2="-1.905" y2="-1.143" layer="21"/>
<rectangle x1="1.905" y1="-2.032" x2="3.556" y2="-1.143" layer="21"/>
<rectangle x1="-7.874" y1="-2.032" x2="-7.239" y2="-1.143" layer="21"/>
<rectangle x1="7.239" y1="-2.032" x2="7.874" y2="-1.143" layer="21"/>
<rectangle x1="3.556" y1="-2.032" x2="7.239" y2="-1.143" layer="51"/>
<rectangle x1="-7.239" y1="-2.032" x2="-3.556" y2="-1.143" layer="51"/>
<rectangle x1="-1.905" y1="-2.032" x2="1.905" y2="-1.143" layer="51"/>
</package>
<package name="TO220V">
<description>&lt;b&gt;TO 220 vertical&lt;/b&gt;</description>
<wire x1="5.08" y1="-1.143" x2="4.953" y2="-4.064" width="0.127" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="4.953" y2="-4.064" width="0.127" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="-4.699" y2="-4.318" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-4.699" y2="-4.318" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-5.08" y2="-1.143" width="0.127" layer="21"/>
<circle x="-4.4958" y="-3.7084" radius="0.254" width="0.127" layer="21"/>
<pad name="1" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-5.08" y="-6.0452" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.334" y1="-0.762" x2="5.334" y2="0" layer="21"/>
<rectangle x1="-5.334" y1="-1.27" x2="-3.429" y2="-0.762" layer="21"/>
<rectangle x1="-1.651" y1="-1.27" x2="-0.889" y2="-0.762" layer="21"/>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="-0.762" layer="51"/>
<rectangle x1="0.889" y1="-1.27" x2="1.651" y2="-0.762" layer="21"/>
<rectangle x1="3.429" y1="-1.27" x2="5.334" y2="-0.762" layer="21"/>
<rectangle x1="-0.889" y1="-1.27" x2="0.889" y2="-0.762" layer="51"/>
<rectangle x1="1.651" y1="-1.27" x2="3.429" y2="-0.762" layer="51"/>
</package>
<package name="TO225AA">
<description>&lt;b&gt;TO-225&lt;/b&gt;&lt;p&gt;
grid 2.54 mm, vertical</description>
<wire x1="-3.4925" y1="-6.985" x2="-3.4925" y2="3.81" width="0.127" layer="21"/>
<wire x1="-3.4925" y1="3.81" x2="3.4925" y2="3.81" width="0.127" layer="21"/>
<wire x1="3.4925" y1="3.81" x2="3.4925" y2="-6.985" width="0.127" layer="21"/>
<wire x1="-3.4925" y1="-6.985" x2="3.4925" y2="-6.985" width="0.127" layer="21"/>
<wire x1="-2.381" y1="-8.096" x2="-2.381" y2="-9.525" width="0.4064" layer="21"/>
<wire x1="0" y1="-7.779" x2="0" y2="-9.525" width="0.4064" layer="21"/>
<wire x1="2.3813" y1="-8.0963" x2="2.381" y2="-9.525" width="0.4064" layer="21"/>
<wire x1="-2.54" y1="3.175" x2="-2.54" y2="-3.334" width="0.127" layer="51"/>
<wire x1="-2.54" y1="-3.334" x2="2.54" y2="-3.334" width="0.127" layer="51"/>
<wire x1="2.54" y1="-3.334" x2="2.54" y2="3.175" width="0.127" layer="51"/>
<wire x1="2.54" y1="3.175" x2="-2.54" y2="3.175" width="0.127" layer="51"/>
<wire x1="-1.949" y1="1.194" x2="-1.2391" y2="1.9206" width="0.127" layer="21" curve="-25.6749"/>
<wire x1="-0.769" y1="1.461" x2="-1.239" y2="1.921" width="0.127" layer="21"/>
<wire x1="0.769" y1="1.461" x2="1.239" y2="1.921" width="0.127" layer="21"/>
<wire x1="1.479" y1="0.734" x2="1.949" y2="1.194" width="0.127" layer="21"/>
<wire x1="1.239" y1="1.921" x2="1.949" y2="1.1944" width="0.127" layer="21" curve="-25.6741"/>
<wire x1="-0.508" y1="-1.571" x2="-0.508" y2="-2.229" width="0.127" layer="21"/>
<wire x1="0.508" y1="-1.571" x2="0.508" y2="-2.229" width="0.127" layer="21"/>
<wire x1="-0.508" y1="-2.229" x2="0.508" y2="-2.229" width="0.127" layer="21" curve="25.6785"/>
<wire x1="-1.479" y1="0.734" x2="-1.949" y2="1.194" width="0.127" layer="21"/>
<circle x="0" y="0" radius="3.81" width="0" layer="42"/>
<circle x="0" y="0" radius="3.81" width="0" layer="43"/>
<circle x="0" y="0" radius="1.651" width="0.127" layer="21"/>
<pad name="1" x="-2.3813" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="0" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="2.3813" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.6988" y="-6.6675" size="1.27" layer="51">1</text>
<text x="-0.4763" y="-6.6675" size="1.27" layer="51">2</text>
<text x="1.905" y="-6.6675" size="1.27" layer="51">3</text>
<text x="3.0163" y="5.3975" size="1.27" layer="25" ratio="10" rot="R180">&gt;NAME</text>
<text x="3.4925" y="-3.7783" size="1.27" layer="27" ratio="10" rot="R180">&gt;VALUE</text>
<rectangle x1="-2.6988" y1="-8.255" x2="-2.0638" y2="-6.985" layer="21"/>
<rectangle x1="2.0638" y1="-8.255" x2="2.6988" y2="-6.985" layer="21"/>
<rectangle x1="-0.3175" y1="-7.9375" x2="0.3175" y2="-6.985" layer="21"/>
<hole x="0" y="0" drill="3.302"/>
</package>
<package name="TO39">
<description>&lt;b&gt;TO-39&lt;/b&gt;</description>
<wire x1="-4.0386" y1="-3.5306" x2="-3.5052" y2="-2.9972" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="-3.5306" x2="-3.5052" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="-4.064" x2="-4.0386" y2="-3.5306" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="4.572" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.8608" width="0.0508" layer="21"/>
<pad name="1" x="0" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="3" x="0" y="2.54" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="5.08" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TO5">
<description>&lt;b&gt;TO 5&lt;/b&gt;</description>
<wire x1="-4.0386" y1="-3.5306" x2="-3.5052" y2="-2.9972" width="0.127" layer="21"/>
<wire x1="-2.9718" y1="-3.5306" x2="-3.5052" y2="-4.064" width="0.127" layer="21"/>
<wire x1="-3.5052" y1="-4.064" x2="-4.0386" y2="-3.5306" width="0.127" layer="21"/>
<circle x="0" y="0" radius="4.572" width="0.127" layer="21"/>
</package>
<package name="TO66">
<description>&lt;b&gt;TO-66&lt;/b&gt;</description>
<wire x1="-3.501" y1="-7.895" x2="3.5012" y2="-7.895" width="0.1524" layer="21" curve="47.8332"/>
<wire x1="-3.501" y1="7.895" x2="3.5012" y2="7.895" width="0.1524" layer="21" curve="-47.8332"/>
<wire x1="-13.711" y1="3.3666" x2="-13.711" y2="-3.367" width="0.1524" layer="21" curve="132.168"/>
<wire x1="-3.501" y1="-7.895" x2="-13.711" y2="-3.367" width="0.1524" layer="21"/>
<wire x1="-3.501" y1="7.895" x2="-13.711" y2="3.367" width="0.1524" layer="21"/>
<wire x1="13.711" y1="-3.367" x2="13.711" y2="3.3666" width="0.1524" layer="21" curve="132.168"/>
<wire x1="3.501" y1="-7.895" x2="13.711" y2="-3.367" width="0.1524" layer="21"/>
<wire x1="3.501" y1="7.895" x2="13.711" y2="3.367" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="7.874" width="0.0508" layer="21"/>
<circle x="0" y="0" radius="6.35" width="0.1524" layer="21"/>
<circle x="-12.192" y="0" radius="1.905" width="0.1524" layer="51"/>
<circle x="12.192" y="0" radius="1.905" width="0.1524" layer="51"/>
<pad name="TO66" x="-12.192" y="0" drill="3.302" diameter="6.35"/>
<pad name="3" x="12.192" y="0" drill="3.302" diameter="6.35"/>
<pad name="2" x="-2.54" y="2.54" drill="1.1176" diameter="2.54" shape="long"/>
<pad name="1" x="-2.54" y="-2.54" drill="1.1176" diameter="2.54" shape="long"/>
<text x="8.89" y="-4.445" size="1.27" layer="21" ratio="10">3</text>
<text x="1.27" y="-2.54" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="3.175" y="-3.175" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-5.08" y="1.905" size="1.27" layer="21" ratio="10">2</text>
<text x="-5.08" y="-3.175" size="1.27" layer="21" ratio="10">1</text>
</package>
<package name="TO92">
<description>&lt;b&gt;TO 92&lt;/b&gt;</description>
<wire x1="-2.0946" y1="-1.651" x2="-2.6549" y2="-0.254" width="0.127" layer="21" curve="-32.781"/>
<wire x1="-2.6549" y1="-0.254" x2="-0.7863" y2="2.5485" width="0.127" layer="21" curve="-78.3185"/>
<wire x1="0.7863" y1="2.5484" x2="2.0945" y2="-1.651" width="0.127" layer="21" curve="-111.1"/>
<wire x1="-2.0945" y1="-1.651" x2="2.0945" y2="-1.651" width="0.127" layer="21"/>
<wire x1="-2.2537" y1="-0.254" x2="-0.2863" y2="-0.254" width="0.127" layer="51"/>
<wire x1="-2.6549" y1="-0.254" x2="-2.2537" y2="-0.254" width="0.127" layer="21"/>
<wire x1="-0.2863" y1="-0.254" x2="0.2863" y2="-0.254" width="0.127" layer="21"/>
<wire x1="2.2537" y1="-0.254" x2="2.6549" y2="-0.254" width="0.127" layer="21"/>
<wire x1="0.2863" y1="-0.254" x2="2.2537" y2="-0.254" width="0.127" layer="51"/>
<wire x1="-0.7863" y1="2.5485" x2="0.7863" y2="2.5485" width="0.127" layer="51" curve="-34.2936"/>
<pad name="1" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="3" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="3.175" y="0.635" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.635" y="0.635" size="1.27" layer="51" ratio="10">2</text>
<text x="-2.159" y="0" size="1.27" layer="51" ratio="10">3</text>
<text x="1.143" y="0" size="1.27" layer="51" ratio="10">1</text>
</package>
<package name="TO92-EBC">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads In Line E B C from top&lt;p&gt;</description>
<wire x1="-2.095" y1="-2.921" x2="2.095" y2="-2.921" width="0.127" layer="21"/>
<wire x1="-2.413" y1="-0.1341" x2="2.413" y2="-0.1341" width="0.127" layer="21" curve="-129.583"/>
<wire x1="1.136" y1="-1.397" x2="-1.136" y2="-1.397" width="0.127" layer="51"/>
<wire x1="-2.413" y1="-0.1341" x2="-2.664" y2="-1.397" width="0.127" layer="51" curve="27.9376"/>
<wire x1="-2.664" y1="-1.397" x2="-2.413" y2="-2.4059" width="0.127" layer="51" curve="22.4788"/>
<wire x1="-1.404" y1="-1.397" x2="-2.664" y2="-1.397" width="0.127" layer="51"/>
<wire x1="-2.4135" y1="-2.4059" x2="-2.095" y2="-2.921" width="0.127" layer="21" curve="13.0385"/>
<wire x1="-1.136" y1="-1.397" x2="-1.404" y2="-1.397" width="0.127" layer="21"/>
<wire x1="2.413" y1="-2.4059" x2="2.664" y2="-1.397" width="0.127" layer="51" curve="22.4788"/>
<wire x1="2.664" y1="-1.397" x2="2.413" y2="-0.1341" width="0.127" layer="51" curve="27.9376"/>
<wire x1="2.664" y1="-1.397" x2="1.404" y2="-1.397" width="0.127" layer="51"/>
<wire x1="1.404" y1="-1.397" x2="1.136" y2="-1.397" width="0.127" layer="21"/>
<wire x1="2.095" y1="-2.921" x2="2.4247" y2="-2.3818" width="0.127" layer="21" curve="13.6094"/>
<pad name="C" x="2.54" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="-2.54" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<pad name="B" x="0" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.54" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-4.572" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TO92-E1">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads Triangle Reverse</description>
<wire x1="-2.095" y1="-1.651" x2="-0.7869" y2="2.5484" width="0.127" layer="21" curve="-111.098"/>
<wire x1="0.7869" y1="2.5484" x2="2.095" y2="-1.651" width="0.127" layer="21" curve="-111.098"/>
<wire x1="-2.095" y1="-1.651" x2="2.095" y2="-1.651" width="0.127" layer="21"/>
<wire x1="-2.254" y1="-0.254" x2="-0.286" y2="-0.254" width="0.127" layer="51"/>
<wire x1="-2.655" y1="-0.254" x2="-2.254" y2="-0.254" width="0.127" layer="21"/>
<wire x1="-0.286" y1="-0.254" x2="0.286" y2="-0.254" width="0.127" layer="21"/>
<wire x1="2.254" y1="-0.254" x2="2.655" y2="-0.254" width="0.127" layer="21"/>
<wire x1="0.286" y1="-0.254" x2="2.254" y2="-0.254" width="0.127" layer="51"/>
<wire x1="-0.7864" y1="2.5484" x2="0.7864" y2="2.5484" width="0.127" layer="51" curve="-34.299"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="3" x="1.27" y="0" drill="0.8128" shape="octagon"/>
</package>
<package name="TO92L">
<description>&lt;b&gt;TO-92&lt;/b&gt;&lt;p&gt;
grid 5.08 mm</description>
<wire x1="-1.1359" y1="2.413" x2="-0.127" y2="2.664" width="0.1524" layer="51" curve="-22.4788"/>
<wire x1="-0.127" y1="2.664" x2="1.1359" y2="2.413" width="0.1524" layer="51" curve="-27.9376"/>
<wire x1="-1.1359" y1="-2.413" x2="-0.127" y2="-2.664" width="0.1524" layer="51" curve="22.4788"/>
<wire x1="-0.127" y1="-2.664" x2="1.1359" y2="-2.413" width="0.1524" layer="51" curve="27.9376"/>
<wire x1="-1.651" y1="2.095" x2="-1.651" y2="-2.095" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="-1.404" x2="-0.127" y2="1.404" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="-2.664" x2="-0.127" y2="-1.404" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-2.095" x2="-1.1118" y2="-2.4247" width="0.1524" layer="21" curve="13.6094"/>
<wire x1="-0.127" y1="1.404" x2="-0.127" y2="2.664" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="2.095" x2="-1.1359" y2="2.4135" width="0.1524" layer="21" curve="-13.0385"/>
<wire x1="2.413" y1="-1.1359" x2="2.413" y2="1.1359" width="0.1524" layer="51" curve="50.4167"/>
<wire x1="1.1359" y1="-2.413" x2="2.413" y2="-1.1359" width="0.1524" layer="21" curve="39.5833"/>
<wire x1="1.1359" y1="2.413" x2="2.413" y2="1.1359" width="0.1524" layer="21" curve="-39.5833"/>
<pad name="1" x="0" y="-2.54" drill="0.8128" shape="long"/>
<pad name="3" x="0" y="2.54" drill="0.8128" shape="long"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="long"/>
<text x="-1.524" y="3.556" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-4.953" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TOP3">
<description>&lt;b&gt;TOP 3 horizontal&lt;/b&gt;</description>
<wire x1="-7.874" y1="-1.778" x2="7.874" y2="-1.778" width="0.127" layer="21"/>
<wire x1="7.874" y1="8.763" x2="7.874" y2="-1.778" width="0.127" layer="21"/>
<wire x1="-7.874" y1="-1.778" x2="-7.874" y2="8.763" width="0.127" layer="21"/>
<wire x1="-7.874" y1="8.763" x2="-7.874" y2="11.811" width="0.127" layer="21"/>
<wire x1="-7.874" y1="11.811" x2="-3.1242" y2="15.8496" width="0.127" layer="21"/>
<wire x1="7.874" y1="8.763" x2="-7.874" y2="8.763" width="0.127" layer="21"/>
<wire x1="7.874" y1="8.763" x2="7.874" y2="11.811" width="0.127" layer="21"/>
<wire x1="-7.366" y1="-1.27" x2="7.366" y2="-1.27" width="0.0508" layer="21"/>
<wire x1="7.366" y1="8.255" x2="7.366" y2="-1.27" width="0.0508" layer="21"/>
<wire x1="7.366" y1="8.255" x2="-7.366" y2="8.255" width="0.0508" layer="21"/>
<wire x1="-7.366" y1="-1.27" x2="-7.366" y2="8.255" width="0.0508" layer="21"/>
<wire x1="0" y1="17.145" x2="3.1431" y2="15.8431" width="0.127" layer="21" curve="-45.0001"/>
<wire x1="-3.1431" y1="15.8431" x2="0" y2="17.145" width="0.127" layer="21" curve="-45.0001"/>
<wire x1="7.874" y1="11.811" x2="3.1242" y2="15.875" width="0.127" layer="21"/>
<circle x="0" y="12.7" radius="2.159" width="0.127" layer="21"/>
<circle x="0" y="12.7" radius="5.08" width="0" layer="42"/>
<circle x="0" y="12.7" radius="5.08" width="0" layer="43"/>
<pad name="1" x="-5.588" y="-7.62" drill="1.397" shape="long" rot="R90"/>
<pad name="2" x="0" y="-7.62" drill="1.397" shape="long" rot="R90"/>
<pad name="3" x="5.588" y="-7.62" drill="1.397" shape="long" rot="R90"/>
<text x="-5.08" y="5.08" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-7.366" y="9.144" size="0.9906" layer="21" ratio="12">A20,3mm</text>
<text x="-5.715" y="-0.635" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="-0.635" size="1.27" layer="51" ratio="10">2</text>
<text x="4.445" y="-0.635" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-6.223" y1="-3.81" x2="-3.81" y2="-1.778" layer="21"/>
<rectangle x1="-1.397" y1="-3.81" x2="1.397" y2="-1.778" layer="21"/>
<rectangle x1="3.81" y1="-3.81" x2="6.223" y2="-1.778" layer="21"/>
<rectangle x1="-6.223" y1="-5.715" x2="-4.953" y2="-3.81" layer="21"/>
<rectangle x1="-6.223" y1="-7.62" x2="-4.953" y2="-5.715" layer="51"/>
<rectangle x1="-0.635" y1="-5.715" x2="0.635" y2="-3.81" layer="21"/>
<rectangle x1="-0.635" y1="-7.62" x2="0.635" y2="-5.715" layer="51"/>
<rectangle x1="4.953" y1="-5.715" x2="6.223" y2="-3.81" layer="21"/>
<rectangle x1="4.953" y1="-7.62" x2="6.223" y2="-5.715" layer="51"/>
<hole x="0" y="12.7" drill="4.1148"/>
</package>
<package name="TOP3V">
<description>&lt;b&gt;TOP 3 vertical&lt;/b&gt;</description>
<wire x1="7.366" y1="-4.699" x2="7.493" y2="-1.524" width="0.127" layer="21"/>
<wire x1="-7.366" y1="-4.699" x2="-7.493" y2="-1.524" width="0.127" layer="21"/>
<wire x1="6.985" y1="-5.08" x2="6.35" y2="-5.08" width="0.127" layer="21"/>
<wire x1="6.35" y1="-5.08" x2="4.572" y2="-5.08" width="0.127" layer="51"/>
<wire x1="4.572" y1="-5.08" x2="0.889" y2="-5.08" width="0.127" layer="21"/>
<wire x1="0.889" y1="-5.08" x2="-0.889" y2="-5.08" width="0.127" layer="51"/>
<wire x1="-0.889" y1="-5.08" x2="-4.572" y2="-5.08" width="0.127" layer="21"/>
<wire x1="-4.572" y1="-5.08" x2="-6.35" y2="-5.08" width="0.127" layer="51"/>
<wire x1="-6.35" y1="-5.08" x2="-6.985" y2="-5.08" width="0.127" layer="21"/>
<pad name="B" x="-5.461" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<pad name="C" x="0" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<pad name="E" x="5.461" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<text x="-1.524" y="-6.858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.096" y="-4.445" size="1.27" layer="51" ratio="10">B</text>
<text x="-0.635" y="-4.445" size="1.27" layer="51" ratio="10">C</text>
<text x="4.826" y="-4.445" size="1.27" layer="51" ratio="10">E</text>
<rectangle x1="-7.874" y1="-1.524" x2="-6.858" y2="-1.143" layer="21"/>
<rectangle x1="-4.064" y1="-1.524" x2="-1.397" y2="-1.143" layer="21"/>
<rectangle x1="1.397" y1="-1.524" x2="4.064" y2="-1.143" layer="21"/>
<rectangle x1="6.858" y1="-1.524" x2="7.874" y2="-1.143" layer="21"/>
<rectangle x1="-6.858" y1="-1.524" x2="-4.064" y2="-1.143" layer="51"/>
<rectangle x1="-1.397" y1="-1.524" x2="1.397" y2="-1.143" layer="51"/>
<rectangle x1="4.064" y1="-1.524" x2="6.858" y2="-1.143" layer="51"/>
</package>
<package name="SOT23-BEC">
<description>TO-236 ITT Intermetall</description>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.127" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.127" layer="51"/>
<smd name="C" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="E" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="B" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2286" y1="0.7112" x2="0.2286" y2="1.2954" layer="51"/>
<rectangle x1="0.7112" y1="-1.2954" x2="1.1684" y2="-0.7112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.2954" x2="-0.7112" y2="-0.7112" layer="51"/>
</package>
<package name="SOT23-EBC">
<description>&lt;b&gt;SOT-23 (EBC)&lt;/b&gt;</description>
<smd name="B" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="E" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
</package>
<package name="TO92-BCE">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads In Line B C E from top&lt;p&gt;</description>
<wire x1="-2.413" y1="1.1359" x2="2.413" y2="1.1359" width="0.127" layer="21" curve="-129.583"/>
<wire x1="1.136" y1="-0.127" x2="-1.136" y2="-0.127" width="0.127" layer="51"/>
<wire x1="-2.413" y1="1.1359" x2="-2.664" y2="-0.127" width="0.127" layer="51" curve="27.9376"/>
<wire x1="-2.664" y1="-0.127" x2="-2.413" y2="-1.1359" width="0.127" layer="51" curve="22.4788"/>
<wire x1="-1.404" y1="-0.127" x2="-2.664" y2="-0.127" width="0.127" layer="51"/>
<wire x1="-2.4135" y1="-1.1359" x2="-2.095" y2="-1.651" width="0.127" layer="21" curve="13.0385"/>
<wire x1="-1.136" y1="-0.127" x2="-1.404" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.413" y1="-1.1359" x2="2.664" y2="-0.127" width="0.127" layer="51" curve="22.4788"/>
<wire x1="2.664" y1="-0.127" x2="2.413" y2="1.1359" width="0.127" layer="51" curve="27.9376"/>
<wire x1="2.664" y1="-0.127" x2="1.404" y2="-0.127" width="0.127" layer="51"/>
<wire x1="1.404" y1="-0.127" x2="1.136" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.095" y1="-1.651" x2="2.4247" y2="-1.1118" width="0.127" layer="21" curve="13.6094"/>
<pad name="C" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="B" x="-2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.54" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TO92-CBE">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads In Line  C B E from top&lt;p&gt;</description>
<pad name="C" x="-2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="B" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
</package>
<package name="TO92-BEC">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads In Line  B E C from top&lt;p&gt;</description>
<pad name="C" x="2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
</package>
<package name="TO92-CEB">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads In Line C E B from top&lt;p&gt;</description>
<pad name="B" x="2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
</package>
<package name="SC59-BEC">
<description>SC59 (SOT23) Motorola</description>
<wire x1="1.4224" y1="0.8604" x2="1.4224" y2="-0.8604" width="0.127" layer="51"/>
<wire x1="1.4224" y1="-0.8604" x2="-1.4224" y2="-0.8604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="-0.8604" x2="-1.4224" y2="0.8604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="0.8604" x2="1.4224" y2="0.8604" width="0.127" layer="51"/>
<smd name="C" x="0" y="1.2" dx="1" dy="1.4" layer="1"/>
<smd name="E" x="0.95" y="-1.2" dx="1" dy="1.4" layer="1"/>
<smd name="B" x="-0.95" y="-1.2" dx="1" dy="1.4" layer="1"/>
<rectangle x1="-0.2286" y1="0.9112" x2="0.2286" y2="1.4954" layer="51"/>
<rectangle x1="0.7112" y1="-1.4954" x2="1.1684" y2="-0.9112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.4954" x2="-0.7112" y2="-0.9112" layer="51"/>
</package>
<package name="SOT89-BCE">
<description>SOT89 Basis Collector Emitter</description>
<wire x1="2.235" y1="-1.245" x2="-2.235" y2="-1.245" width="0.127" layer="51"/>
<wire x1="2.235" y1="1.219" x2="2.235" y2="-1.245" width="0.127" layer="51"/>
<wire x1="-2.235" y1="-1.245" x2="-2.235" y2="1.219" width="0.127" layer="51"/>
<wire x1="-2.235" y1="1.219" x2="2.235" y2="1.219" width="0.127" layer="51"/>
<wire x1="-0.7874" y1="1.5748" x2="-0.3556" y2="2.0066" width="0.1998" layer="51"/>
<wire x1="-0.3556" y1="2.0066" x2="0.3556" y2="2.0066" width="0.1998" layer="51"/>
<wire x1="0.3556" y1="2.0066" x2="0.7874" y2="1.5748" width="0.1998" layer="51"/>
<wire x1="0.7874" y1="1.5748" x2="0.7874" y2="1.2954" width="0.1998" layer="51"/>
<wire x1="0.7874" y1="1.2954" x2="-0.7874" y2="1.2954" width="0.1998" layer="51"/>
<wire x1="-0.7874" y1="1.2954" x2="-0.7874" y2="1.5748" width="0.1998" layer="51"/>
<smd name="B" x="-1.499" y="-1.981" dx="0.8" dy="1.4" layer="1"/>
<smd name="E" x="1.499" y="-1.981" dx="0.8" dy="1.4" layer="1"/>
<smd name="C" x="0" y="-1.727" dx="0.8" dy="1.9" layer="1" stop="no" cream="no"/>
<text x="-2.54" y="3.175" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.4051" y="-4.3449" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7272" y1="-2.1082" x2="-1.27" y2="-1.27" layer="51"/>
<rectangle x1="1.27" y1="-2.1082" x2="1.7272" y2="-1.27" layer="51"/>
<rectangle x1="-0.2794" y1="-2.1082" x2="0.2794" y2="-1.27" layer="51"/>
<rectangle x1="-0.4" y1="-2.68" x2="0.4" y2="-1.28" layer="31"/>
<rectangle x1="-0.5" y1="-2.78" x2="0.5" y2="-1.18" layer="29"/>
<polygon width="0.1998" layer="51">
<vertex x="-0.7874" y="1.3208"/>
<vertex x="-0.7874" y="1.5748"/>
<vertex x="-0.3556" y="2.0066"/>
<vertex x="0.3048" y="2.0066"/>
<vertex x="0.3556" y="2.0066"/>
<vertex x="0.7874" y="1.5748"/>
<vertex x="0.7874" y="1.2954"/>
<vertex x="-0.7874" y="1.2954"/>
</polygon>
<polygon width="1.7" layer="29">
<vertex x="-0.275" y="2.025"/>
<vertex x="-0.275" y="-0.15"/>
<vertex x="0.25" y="-0.15"/>
<vertex x="0.25" y="2.025"/>
</polygon>
<polygon width="1.3" layer="31">
<vertex x="-0.25" y="2.05"/>
<vertex x="0.275" y="2.05"/>
<vertex x="0.275" y="-0.125"/>
<vertex x="-0.25" y="-0.125"/>
</polygon>
<polygon width="0.3" layer="1">
<vertex x="0.25" y="-2.05"/>
<vertex x="-0.25" y="-2.05"/>
<vertex x="-0.25" y="-0.75" curve="-90"/>
<vertex x="-0.875" y="-0.125"/>
<vertex x="-0.875" y="2.05" curve="-90"/>
<vertex x="-0.225" y="2.625"/>
<vertex x="0.25" y="2.625" curve="-90"/>
<vertex x="0.875" y="2.025"/>
<vertex x="0.875" y="-0.125" curve="-90"/>
<vertex x="0.25" y="-0.75"/>
</polygon>
</package>
<package name="SOT37">
<description>&lt;b&gt;SOT-37&lt;/b&gt;&lt;p&gt;
Motorola CASE 317A-01 ISSUE B&lt;br&gt;
http://www.ee.siue.edu/~alozows/library/datasheets/BFR96.pdf</description>
<wire x1="5.3086" y1="0.508" x2="5.3086" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-5.3086" x2="0.508" y2="-5.3086" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="6.5024" x2="0.508" y2="6.5024" width="0.1524" layer="51"/>
<wire x1="0.508" y1="-2.2352" x2="0.508" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-2.794" x2="0.508" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-3.048" x2="0.635" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="0.508" y1="-3.429" x2="0.635" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="0.508" y1="-3.429" x2="0.508" y2="-5.3086" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-2.2352" x2="-0.508" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-2.794" x2="-0.508" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-3.048" x2="-0.635" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-3.429" x2="-0.635" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-3.429" x2="-0.508" y2="-5.3086" width="0.1524" layer="51"/>
<wire x1="2.2352" y1="-0.508" x2="2.794" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-0.635" x2="2.794" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-0.635" x2="3.429" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-0.508" x2="3.429" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-0.508" x2="5.3086" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="2.2098" y1="0.508" x2="2.794" y2="0.508" width="0.1524" layer="21"/>
<wire x1="2.794" y1="0.635" x2="2.794" y2="0.508" width="0.1524" layer="21"/>
<wire x1="3.048" y1="0.635" x2="3.429" y2="0.635" width="0.1524" layer="51"/>
<wire x1="3.429" y1="0.508" x2="3.429" y2="0.635" width="0.1524" layer="51"/>
<wire x1="3.429" y1="0.508" x2="5.3086" y2="0.508" width="0.1524" layer="51"/>
<wire x1="0.508" y1="2.2352" x2="0.508" y2="2.794" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.794" x2="0.508" y2="2.794" width="0.1524" layer="21"/>
<wire x1="0.635" y1="3.048" x2="0.635" y2="3.429" width="0.1524" layer="51"/>
<wire x1="0.508" y1="3.429" x2="0.635" y2="3.429" width="0.1524" layer="51"/>
<wire x1="0.508" y1="3.429" x2="0.508" y2="6.5024" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="2.2352" x2="-0.508" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.794" x2="-0.508" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="3.048" x2="-0.635" y2="3.429" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="3.429" x2="-0.635" y2="3.429" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="3.429" x2="-0.508" y2="6.5024" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-2.794" x2="-0.635" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-2.794" x2="0.635" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-0.635" x2="2.794" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="3.048" y1="0.635" x2="2.794" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.794" x2="0.635" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.794" x2="-0.635" y2="3.048" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.286" width="0.1524" layer="21"/>
<circle x="0" y="1.524" radius="0.508" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.175" width="0" layer="41"/>
<circle x="0" y="0" radius="3.175" width="0" layer="42"/>
<smd name="3" x="0" y="-5.08" dx="1.9304" dy="3.81" layer="1"/>
<smd name="2" x="5.08" y="0" dx="3.81" dy="1.9304" layer="1"/>
<smd name="1" x="0" y="5.08" dx="1.9304" dy="3.81" layer="1"/>
<text x="4.445" y="1.27" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="6.35" y="1.27" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="3.175" y="-2.286" size="1.016" layer="21" ratio="10">E</text>
<text x="1.27" y="-4.191" size="1.016" layer="21" ratio="10">B</text>
<text x="1.27" y="3.175" size="1.016" layer="21" ratio="10">C</text>
<text x="-1.524" y="-4.318" size="1.27" layer="47">5,1</text>
<rectangle x1="-0.508" y1="-2.794" x2="0.508" y2="-2.413" layer="21"/>
<rectangle x1="-0.635" y1="-3.048" x2="0.635" y2="-2.794" layer="21"/>
<rectangle x1="-0.635" y1="-3.429" x2="0.635" y2="-3.048" layer="51"/>
<rectangle x1="-0.508" y1="-5.334" x2="0.508" y2="-3.429" layer="51"/>
<rectangle x1="2.413" y1="-0.508" x2="2.794" y2="0.508" layer="21"/>
<rectangle x1="2.794" y1="-0.635" x2="3.048" y2="0.635" layer="21"/>
<rectangle x1="3.048" y1="-0.635" x2="3.429" y2="0.635" layer="51"/>
<rectangle x1="3.429" y1="-0.508" x2="5.334" y2="0.508" layer="51"/>
<rectangle x1="-0.508" y1="3.429" x2="0.508" y2="6.477" layer="51"/>
<rectangle x1="-0.635" y1="3.048" x2="0.635" y2="3.429" layer="51"/>
<rectangle x1="-0.635" y1="2.794" x2="0.635" y2="3.048" layer="21"/>
<rectangle x1="-0.508" y1="2.413" x2="0.508" y2="2.794" layer="21"/>
<hole x="0" y="0" drill="5.08"/>
</package>
<package name="TO92-ECB">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads In Line E C B from top&lt;p&gt;</description>
<wire x1="-2.413" y1="1.1359" x2="-2.664" y2="-0.127" width="0.127" layer="51" curve="27.9407"/>
<wire x1="2.664" y1="-0.127" x2="2.413" y2="1.1359" width="0.127" layer="51" curve="27.9333"/>
<pad name="E" x="-2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
</package>
</packages>
<symbols>
<symbol name="NPN-DAR">
<wire x1="5.08" y1="2.54" x2="2.032" y2="2.54" width="0.1524" layer="94"/>
<wire x1="1.424" y1="-1.424" x2="2.286" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="2.921" y1="-2.54" x2="2.286" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="0.916" y1="-2.186" x2="1.424" y2="-1.424" width="0.1524" layer="94"/>
<wire x1="2.286" y1="-2.54" x2="0.916" y2="-2.186" width="0.1524" layer="94"/>
<wire x1="2.032" y1="2.54" x2="0.508" y2="1.27" width="0.1524" layer="94"/>
<wire x1="5.08" y1="0" x2="3.683" y2="-1.27" width="0.1524" layer="94"/>
<wire x1="5.08" y1="-5.08" x2="3.964" y2="-4.699" width="0.1524" layer="94"/>
<wire x1="4.572" y1="-4.064" x2="5.08" y2="-5.08" width="0.1524" layer="94"/>
<wire x1="3.964" y1="-4.699" x2="4.572" y2="-4.064" width="0.1524" layer="94"/>
<wire x1="1.186" y1="-1.84" x2="0.208" y2="-1.197" width="0.1524" layer="94"/>
<wire x1="4.28" y1="-4.38" x2="3.483" y2="-3.61" width="0.1524" layer="94"/>
<wire x1="2.159" y1="-2.413" x2="1.397" y2="-1.524" width="0.127" layer="94"/>
<wire x1="1.397" y1="-1.524" x2="1.016" y2="-2.159" width="0.127" layer="94"/>
<wire x1="1.016" y1="-2.159" x2="2.032" y2="-2.413" width="0.127" layer="94"/>
<wire x1="2.032" y1="-2.413" x2="1.397" y2="-1.651" width="0.127" layer="94"/>
<wire x1="1.397" y1="-1.651" x2="1.143" y2="-2.032" width="0.127" layer="94"/>
<wire x1="1.143" y1="-2.032" x2="1.905" y2="-2.286" width="0.254" layer="94"/>
<wire x1="1.905" y1="-2.286" x2="1.397" y2="-1.778" width="0.254" layer="94"/>
<wire x1="1.397" y1="-1.778" x2="1.397" y2="-1.905" width="0.254" layer="94"/>
<wire x1="4.953" y1="-4.953" x2="4.572" y2="-4.191" width="0.127" layer="94"/>
<wire x1="4.572" y1="-4.191" x2="4.064" y2="-4.699" width="0.127" layer="94"/>
<wire x1="4.064" y1="-4.699" x2="4.826" y2="-4.953" width="0.127" layer="94"/>
<wire x1="4.826" y1="-4.953" x2="4.572" y2="-4.318" width="0.127" layer="94"/>
<wire x1="4.572" y1="-4.318" x2="4.191" y2="-4.699" width="0.254" layer="94"/>
<wire x1="4.191" y1="-4.699" x2="4.699" y2="-4.826" width="0.254" layer="94"/>
<wire x1="4.699" y1="-4.826" x2="4.572" y2="-4.572" width="0.254" layer="94"/>
<wire x1="4.572" y1="-4.572" x2="4.445" y2="-4.572" width="0.254" layer="94"/>
<circle x="5.08" y="2.54" radius="0.381" width="0" layer="94"/>
<text x="-6.35" y="7.62" size="1.778" layer="95">&gt;NAME</text>
<text x="-4.064" y="5.08" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-0.254" y1="-2.54" x2="0.508" y2="2.54" layer="94"/>
<rectangle x1="2.921" y1="-5.08" x2="3.683" y2="0" layer="94"/>
<pin name="B" x="-2.54" y="0" visible="pad" length="short" direction="pas"/>
<pin name="E" x="5.08" y="-7.62" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="C" x="5.08" y="2.54" visible="pad" length="short" direction="pas" rot="R270"/>
</symbol>
<symbol name="NPN">
<wire x1="2.54" y1="2.54" x2="0.508" y2="1.524" width="0.1524" layer="94"/>
<wire x1="1.778" y1="-1.524" x2="2.54" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="1.27" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="1.778" y2="-1.524" width="0.1524" layer="94"/>
<wire x1="1.54" y1="-2.04" x2="0.308" y2="-1.424" width="0.1524" layer="94"/>
<wire x1="1.524" y1="-2.413" x2="2.286" y2="-2.413" width="0.254" layer="94"/>
<wire x1="2.286" y1="-2.413" x2="1.778" y2="-1.778" width="0.254" layer="94"/>
<wire x1="1.778" y1="-1.778" x2="1.524" y2="-2.286" width="0.254" layer="94"/>
<wire x1="1.524" y1="-2.286" x2="1.905" y2="-2.286" width="0.254" layer="94"/>
<wire x1="1.905" y1="-2.286" x2="1.778" y2="-2.032" width="0.254" layer="94"/>
<text x="-10.16" y="7.62" size="1.778" layer="95">&gt;NAME</text>
<text x="-10.16" y="5.08" size="1.778" layer="96">&gt;VALUE</text>
<pin name="B" x="-2.54" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
<pin name="E" x="2.54" y="-5.08" visible="off" length="short" direction="pas" swaplevel="3" rot="R90"/>
<pin name="C" x="2.54" y="5.08" visible="off" length="short" direction="pas" swaplevel="2" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="TIP122" prefix="T">
<description>&lt;b&gt;NPN BIPOLAR DARLINGTON TRANSISTOR&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="NPN-DAR" x="0" y="0"/>
</gates>
<devices>
<device name="" package="TO220">
<connects>
<connect gate="G$1" pin="B" pad="1"/>
<connect gate="G$1" pin="C" pad="2"/>
<connect gate="G$1" pin="E" pad="3"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="*-NPN-" prefix="T" uservalue="yes">
<description>NPN Transistror&lt;p&gt;
BF959 corrected 2008.03.06&lt;br&gt;</description>
<gates>
<gate name="G$1" symbol="NPN" x="0" y="0"/>
</gates>
<devices>
<device name="TO3/" package="TO3">
<connects>
<connect gate="G$1" pin="B" pad="B"/>
<connect gate="G$1" pin="C" pad="C"/>
<connect gate="G$1" pin="E" pad="E"/>
</connects>
<technologies>
</technologies>
</device>
<device name="TO18-EBC" package="TO18">
<connects>
<connect gate="G$1" pin="B" pad="2"/>
<connect gate="G$1" pin="C" pad="3"/>
<connect gate="G$1" pin="E" pad="1"/>
</connects>
<technologies>
<technology name="2N2218"/>
<technology name="2N2222"/>
<technology name="2N2222A"/>
<technology name="2N2369"/>
<technology name="2N2369A"/>
<technology name="2N2484"/>
<technology name="2N2896"/>
<technology name="2N3700"/>
<technology name="2N930"/>
<technology name="BC107A"/>
<technology name="BC107B"/>
<technology name="BC108B"/>
<technology name="BC108C"/>
<technology name="BCY58-IX"/>
<technology name="BCY58-VIII"/>
<technology name="BCY59-VII"/>
<technology name="BCY59-VIII"/>
<technology name="BCY59-X"/>
<technology name="BSS71"/>
<technology name="BSS72"/>
<technology name="BSS73"/>
<technology name="BSX20"/>
</technologies>
</device>
<device name="TO18-" package="TO18-">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO202" package="TO202">
<connects>
<connect gate="G$1" pin="B" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
<device name="TO202V" package="TO202V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOT93" package="SOT93">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOT93V" package="SOT93V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO126" package="TO126">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO126V" package="TO126V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO218" package="TO218">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO218V" package="TO218V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO220" package="TO220">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO220V" package="TO220V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO225AA" package="TO225AA">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO39-EBC" package="TO39">
<connects>
</connects>
<technologies>
<technology name="2N1613"/>
<technology name="2N1711"/>
<technology name="2N1893"/>
<technology name="2N2102"/>
<technology name="2N2219"/>
<technology name="2N2219A"/>
<technology name="2N3019"/>
<technology name="2N3020"/>
<technology name="2N3439"/>
<technology name="2N3440"/>
<technology name="BC140-10"/>
<technology name="BC140-16"/>
<technology name="BC141-10"/>
<technology name="BC141-16"/>
<technology name="BFY50"/>
<technology name="BSX45-16"/>
<technology name="BSX46-10"/>
<technology name="BSX46-16"/>
</technologies>
</device>
<device name="TO5" package="TO5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO66" package="TO66">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO92" package="TO92">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO92-EBC" package="TO92-EBC">
<connects>
</connects>
<technologies>
<technology name="29"/>
<technology name="92"/>
<technology name="BC317"/>
<technology name="BC318"/>
<technology name="BC319"/>
<technology name="MPSA06"/>
<technology name="MPSA13"/>
<technology name="MPSA14"/>
<technology name="MPSA18"/>
<technology name="MPSA28"/>
<technology name="MPSA42"/>
<technology name="MPSA44"/>
</technologies>
</device>
<device name="TO92-E1" package="TO92-E1">
<connects>
<connect gate="G$1" pin="C" pad="1"/>
</connects>
<technologies>
</technologies>
</device>
<device name="TO92L" package="TO92L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TOP3" package="TOP3">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TOP3V" package="TOP3V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOT23-BEC" package="SOT23-BEC">
<connects>
</connects>
<technologies>
<technology name="BC808"/>
<technology name="BC817"/>
<technology name="BC817-16"/>
<technology name="BC817-16LT1"/>
<technology name="BC817-25"/>
<technology name="BC817-25LT1"/>
<technology name="BC817-40"/>
<technology name="BC817-40LT1"/>
<technology name="BC818"/>
<technology name="BC818-16"/>
<technology name="BC818-25"/>
<technology name="BC818-40"/>
<technology name="BC846"/>
<technology name="BC846A"/>
<technology name="BC846ALT1"/>
<technology name="BC846B"/>
<technology name="BC846BLT1"/>
<technology name="BC847"/>
<technology name="BC847A"/>
<technology name="BC847ALT1"/>
<technology name="BC847B"/>
<technology name="BC847BLT1"/>
<technology name="BC847C"/>
<technology name="BC847CLT1"/>
<technology name="BC848"/>
<technology name="BC848A"/>
<technology name="BC848ALT1"/>
<technology name="BC848B"/>
<technology name="BC848BLT1"/>
<technology name="BC848C"/>
<technology name="BC848CLT1"/>
<technology name="BC849"/>
<technology name="BC850"/>
<technology name="BCF29"/>
<technology name="BCF30"/>
<technology name="BCF32"/>
<technology name="BCF33"/>
<technology name="BCF81"/>
<technology name="BCV71"/>
<technology name="BCV72"/>
<technology name="BCW31"/>
<technology name="BCW32"/>
<technology name="BCW33"/>
<technology name="BCW60"/>
<technology name="BCW71"/>
<technology name="BCW72"/>
<technology name="BCW81"/>
<technology name="BCX19"/>
<technology name="BCX20"/>
<technology name="BCX70"/>
<technology name="BF820"/>
<technology name="BF822"/>
<technology name="BFR53"/>
<technology name="BFR92"/>
<technology name="BFR92A"/>
<technology name="BFR93"/>
<technology name="BFR93A"/>
<technology name="BFS17"/>
<technology name="BFS19"/>
<technology name="BFS20"/>
<technology name="BFT25"/>
<technology name="BSR12"/>
<technology name="BSR13"/>
<technology name="BSR14"/>
<technology name="BSV52LT1"/>
<technology name="MMBT2222ALT1"/>
<technology name="MMBT2369LT1"/>
<technology name="MMBT2484LT1"/>
<technology name="MMBT3904LT1"/>
<technology name="MMBT4401LT1"/>
<technology name="MMBT5551LT1"/>
<technology name="MMBT6429LT1"/>
<technology name="MMBT6517LT1"/>
<technology name="MMBT918LT1"/>
<technology name="MMBTA42LT1"/>
<technology name="MMBTH10LT1"/>
<technology name="MMBTH24LT1"/>
</technologies>
</device>
<device name="SOT23-EBC" package="SOT23-EBC">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO92-BCE" package="TO92-BCE">
<connects>
</connects>
<technologies>
<technology name="BF420"/>
<technology name="BF422"/>
</technologies>
</device>
<device name="TO92-CBE" package="TO92-CBE">
<connects>
</connects>
<technologies>
<technology name="2N4124"/>
<technology name="2N5400"/>
<technology name="2N5401"/>
<technology name="2N5550"/>
<technology name="2N5551"/>
<technology name="2N6427"/>
<technology name="2N6517"/>
<technology name="2N6520"/>
<technology name="BC237"/>
<technology name="BC238"/>
<technology name="BC239"/>
<technology name="BC328"/>
<technology name="BC337"/>
<technology name="BC337-16"/>
<technology name="BC337-25"/>
<technology name="BC337-40"/>
<technology name="BC338-16"/>
<technology name="BC338-25"/>
<technology name="BC338-40"/>
<technology name="BC372"/>
<technology name="BC373"/>
<technology name="BC447"/>
<technology name="BC449"/>
<technology name="BC449A"/>
<technology name="BC485"/>
<technology name="BC487"/>
<technology name="BC489"/>
<technology name="BC517"/>
<technology name="BC546"/>
<technology name="BC547"/>
<technology name="BC547A"/>
<technology name="BC547B"/>
<technology name="BC548"/>
<technology name="BC549"/>
<technology name="BC550"/>
<technology name="BC618"/>
<technology name="BF391"/>
<technology name="BF393"/>
<technology name="BF844"/>
<technology name="MPS2222A"/>
<technology name="MPSL51"/>
<technology name="MPSW42"/>
</technologies>
</device>
<device name="TO92-BEC" package="TO92-BEC">
<connects>
</connects>
<technologies>
<technology name="BF199"/>
<technology name="BF224"/>
<technology name="BF240"/>
</technologies>
</device>
<device name="TO92-CEB" package="TO92-CEB">
<connects>
</connects>
<technologies>
<technology name="BF374"/>
<technology name="BF959"/>
<technology name="MPHS10"/>
</technologies>
</device>
<device name="SC59-BEC" package="SC59-BEC">
<connects>
</connects>
<technologies>
<technology name="MMUN2211LT1"/>
<technology name="MMUN2212LT1"/>
<technology name="MMUN2213LT1"/>
<technology name="MMUN2214LT1"/>
</technologies>
</device>
<device name="SOT89-BCE" package="SOT89-BCE">
<connects>
</connects>
<technologies>
<technology name="BC868"/>
<technology name="BCX54"/>
<technology name="BCX55"/>
<technology name="BCX56"/>
<technology name="BF622"/>
</technologies>
</device>
<device name="SOT-37" package="SOT37">
<connects>
<connect gate="G$1" pin="E" pad="2"/>
</connects>
<technologies>
<technology name="BFR96"/>
</technologies>
</device>
<device name="TO92-ECB" package="TO92-ECB">
<connects>
</connects>
<technologies>
<technology name="BC167"/>
<technology name="BC168"/>
<technology name="BC169"/>
<technology name="BC368"/>
<technology name="BC635"/>
<technology name="BC637"/>
<technology name="BC639"/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="fuse">
<description>&lt;b&gt;Fuses and Fuse Holders&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="GSH15">
<description>&lt;b&gt;FUSE HOLDER&lt;/b&gt;&lt;p&gt;
grid 15mm, 19649 Wickmann</description>
<wire x1="-12.573" y1="-4.572" x2="-12.573" y2="4.572" width="0.1524" layer="21"/>
<wire x1="12.573" y1="4.572" x2="12.573" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.921" x2="5.08" y2="2.921" width="0.0508" layer="21"/>
<wire x1="-11.43" y1="3.683" x2="-8.382" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-3.683" x2="-11.43" y2="3.683" width="0.1524" layer="21"/>
<wire x1="11.43" y1="3.683" x2="11.43" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="0" x2="5.207" y2="0" width="0.0508" layer="21"/>
<wire x1="12.573" y1="-4.572" x2="5.08" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-3.048" x2="5.08" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-3.048" x2="-5.08" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-4.572" x2="-12.573" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="4.572" x2="-5.08" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.048" x2="5.08" y2="3.048" width="0.1524" layer="21"/>
<wire x1="5.08" y1="4.572" x2="5.08" y2="3.683" width="0.1524" layer="21"/>
<wire x1="5.08" y1="4.572" x2="12.573" y2="4.572" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-3.683" x2="6.858" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="6.858" y1="-4.191" x2="6.858" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="6.858" y1="-4.191" x2="8.382" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="8.382" y1="-3.683" x2="8.382" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="8.382" y1="-3.683" x2="11.43" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.683" x2="6.858" y2="3.683" width="0.1524" layer="21"/>
<wire x1="6.858" y1="4.191" x2="6.858" y2="3.683" width="0.1524" layer="21"/>
<wire x1="6.858" y1="4.191" x2="8.382" y2="4.191" width="0.1524" layer="21"/>
<wire x1="8.382" y1="3.683" x2="8.382" y2="4.191" width="0.1524" layer="21"/>
<wire x1="8.382" y1="3.683" x2="11.43" y2="3.683" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.683" x2="5.08" y2="3.048" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-3.683" x2="5.08" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.048" x2="-5.08" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.683" x2="-5.08" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-4.572" x2="-5.08" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.683" x2="-5.08" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.858" y1="3.683" x2="-5.08" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.858" y1="4.191" x2="-6.858" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="4.191" x2="-6.858" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="3.683" x2="-8.382" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-6.858" y1="-3.683" x2="-5.08" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-6.858" y1="-4.191" x2="-6.858" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="-4.191" x2="-6.858" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="-3.683" x2="-8.382" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="-3.683" x2="-11.43" y2="-3.683" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<pad name="2" x="7.62" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<text x="-4.4196" y="3.6068" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.4196" y="-5.461" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.08" y1="1.651" x2="5.08" y2="2.159" layer="21"/>
<rectangle x1="-5.08" y1="-2.159" x2="5.08" y2="-1.651" layer="21"/>
<rectangle x1="5.08" y1="-3.175" x2="5.715" y2="-1.524" layer="21"/>
<rectangle x1="5.08" y1="1.524" x2="5.715" y2="3.175" layer="21"/>
<rectangle x1="5.08" y1="-1.524" x2="5.715" y2="1.524" layer="51"/>
<rectangle x1="10.287" y1="-2.032" x2="10.541" y2="2.032" layer="21"/>
<rectangle x1="6.731" y1="1.905" x2="8.509" y2="2.032" layer="51"/>
<rectangle x1="6.731" y1="-2.032" x2="8.509" y2="-1.905" layer="51"/>
<rectangle x1="5.715" y1="2.032" x2="10.541" y2="3.175" layer="21"/>
<rectangle x1="5.715" y1="-3.175" x2="10.541" y2="-2.032" layer="21"/>
<rectangle x1="7.112" y1="-3.937" x2="8.128" y2="-3.175" layer="21"/>
<rectangle x1="7.112" y1="3.175" x2="8.128" y2="3.937" layer="21"/>
<rectangle x1="-5.715" y1="-1.524" x2="-5.08" y2="1.524" layer="51"/>
<rectangle x1="-5.715" y1="1.524" x2="-5.08" y2="3.175" layer="21"/>
<rectangle x1="-5.715" y1="-3.175" x2="-5.08" y2="-1.524" layer="21"/>
<rectangle x1="-10.541" y1="-3.175" x2="-5.715" y2="-2.032" layer="21"/>
<rectangle x1="-8.509" y1="-2.032" x2="-6.731" y2="-1.905" layer="51"/>
<rectangle x1="-10.541" y1="-2.032" x2="-10.287" y2="2.032" layer="21"/>
<rectangle x1="-8.509" y1="1.905" x2="-6.731" y2="2.032" layer="51"/>
<rectangle x1="-10.541" y1="2.032" x2="-5.715" y2="3.175" layer="21"/>
<rectangle x1="-8.128" y1="3.175" x2="-7.112" y2="3.937" layer="21"/>
<rectangle x1="-8.128" y1="-3.937" x2="-7.112" y2="-3.175" layer="21"/>
<rectangle x1="5.715" y1="-2.032" x2="6.731" y2="-1.905" layer="21"/>
<rectangle x1="5.715" y1="1.905" x2="6.731" y2="2.032" layer="21"/>
<rectangle x1="8.509" y1="1.905" x2="10.287" y2="2.032" layer="21"/>
<rectangle x1="8.509" y1="-2.032" x2="10.287" y2="-1.905" layer="21"/>
<rectangle x1="-10.287" y1="1.905" x2="-8.509" y2="2.032" layer="21"/>
<rectangle x1="-6.731" y1="1.905" x2="-5.715" y2="2.032" layer="21"/>
<rectangle x1="-6.731" y1="-2.032" x2="-5.715" y2="-1.905" layer="21"/>
<rectangle x1="-10.287" y1="-2.032" x2="-8.509" y2="-1.905" layer="21"/>
<hole x="0" y="0" drill="2.794"/>
</package>
</packages>
<symbols>
<symbol name="FUSE">
<wire x1="-3.81" y1="-0.762" x2="3.81" y2="-0.762" width="0.254" layer="94"/>
<wire x1="3.81" y1="0.762" x2="-3.81" y2="0.762" width="0.254" layer="94"/>
<wire x1="3.81" y1="-0.762" x2="3.81" y2="0.762" width="0.254" layer="94"/>
<wire x1="-3.81" y1="0.762" x2="-3.81" y2="-0.762" width="0.254" layer="94"/>
<wire x1="-2.54" y1="0" x2="2.54" y2="0" width="0.1524" layer="94"/>
<text x="-3.81" y="1.397" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.81" y="-2.921" size="1.778" layer="96">&gt;VALUE</text>
<pin name="2" x="5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1" rot="R180"/>
<pin name="1" x="-5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="GSH15" prefix="F" uservalue="yes">
<gates>
<gate name="1" symbol="FUSE" x="0" y="0"/>
</gates>
<devices>
<device name="" package="GSH15">
<connects>
<connect gate="1" pin="1" pad="1"/>
<connect gate="1" pin="2" pad="2"/>
</connects>
<technologies>
<technology name="">
<attribute name="MF" value="" constant="no"/>
<attribute name="MPN" value="64900001039" constant="no"/>
<attribute name="OC_FARNELL" value="1271673" constant="no"/>
<attribute name="OC_NEWARK" value="02P0318" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="linear">
<description>&lt;b&gt;Linear Devices&lt;/b&gt;&lt;p&gt;
Operational amplifiers,  comparators, voltage regulators, ADCs, DACs, etc.&lt;p&gt;
<packages>
<package name="DIL08">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="5.08" y1="2.921" x2="-5.08" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.921" x2="-5.08" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="-5.08" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.016" x2="-5.08" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128" diameter="1.27" rot="R90"/>
<text x="-5.334" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.556" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SO08">
<description>&lt;b&gt;Small Outline Package 8&lt;/b&gt;&lt;br&gt;
NS Package M08A</description>
<wire x1="2.4" y1="1.9" x2="2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.9" x2="-2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.9" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.4" x2="-2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="1.9" x2="2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<smd name="2" x="-0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="7" x="-0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="1" x="-1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="3" x="0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="4" x="1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="8" x="-1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="6" x="0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="5" x="1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<text x="-2.667" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.937" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.15" y1="-3.1" x2="-1.66" y2="-2" layer="51"/>
<rectangle x1="-0.88" y1="-3.1" x2="-0.39" y2="-2" layer="51"/>
<rectangle x1="0.39" y1="-3.1" x2="0.88" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="-3.1" x2="2.15" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="2" x2="2.15" y2="3.1" layer="51"/>
<rectangle x1="0.39" y1="2" x2="0.88" y2="3.1" layer="51"/>
<rectangle x1="-0.88" y1="2" x2="-0.39" y2="3.1" layer="51"/>
<rectangle x1="-2.15" y1="2" x2="-1.66" y2="3.1" layer="51"/>
</package>
<description>&lt;b&gt;TO-92&lt;/b&gt;</description>
<wire x1="-2.095" y1="-1.651" x2="-0.7869" y2="2.5484" width="0.1524" layer="21" curve="-111.097684"/>
<wire x1="0.7869" y1="2.5484" x2="2.095" y2="-1.651" width="0.1524" layer="21" curve="-111.097684"/>
<wire x1="-2.095" y1="-1.651" x2="2.095" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-2.254" y1="-0.254" x2="-0.286" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-2.655" y1="-0.254" x2="-2.254" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-0.286" y1="-0.254" x2="0.286" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="2.254" y1="-0.254" x2="2.655" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="0.286" y1="-0.254" x2="2.254" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-0.7864" y1="2.5484" x2="0.7864" y2="2.5484" width="0.1524" layer="51" curve="-34.298964"/>
<pad name="2" x="0" y="1.905" drill="0.8128" shape="octagon"/>
<text x="2.413" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.921" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TO220H">
<description>&lt;b&gt;TO-220&lt;/b&gt;</description>
<wire x1="-5.207" y1="-7.62" x2="5.207" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="5.207" y1="8.255" x2="-5.207" y2="8.255" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-7.62" x2="5.207" y2="4.826" width="0.1524" layer="21"/>
<wire x1="5.207" y1="4.826" x2="4.318" y2="4.826" width="0.1524" layer="21"/>
<wire x1="4.318" y1="4.826" x2="4.318" y2="6.35" width="0.1524" layer="21"/>
<wire x1="4.318" y1="6.35" x2="5.207" y2="6.35" width="0.1524" layer="21"/>
<wire x1="5.207" y1="6.35" x2="5.207" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-7.62" x2="-5.207" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.826" x2="-4.318" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="4.826" x2="-4.318" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="6.35" x2="-5.207" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="6.35" x2="-5.207" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-6.985" x2="4.572" y2="-6.985" width="0.0508" layer="21"/>
<wire x1="4.572" y1="1.27" x2="4.572" y2="-6.985" width="0.0508" layer="21"/>
<wire x1="4.572" y1="1.27" x2="-4.572" y2="1.27" width="0.0508" layer="21"/>
<wire x1="-4.572" y1="-6.985" x2="-4.572" y2="1.27" width="0.0508" layer="21"/>
<circle x="0" y="4.826" radius="1.8034" width="0.1524" layer="21"/>
<circle x="0" y="4.826" radius="2.54" width="0" layer="43"/>
<circle x="0" y="4.826" radius="2.54" width="0" layer="42"/>
<pad name="1" x="-2.54" y="-10.16" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-10.16" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-10.16" drill="1.1176" shape="long" rot="R90"/>
<text x="-5.461" y="-10.922" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="7.366" y="-11.049" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="2.159" y1="-11.049" x2="2.921" y2="-10.414" layer="21"/>
<rectangle x1="-0.381" y1="-11.049" x2="0.381" y2="-10.414" layer="21"/>
<rectangle x1="-2.921" y1="-11.049" x2="-2.159" y2="-10.414" layer="21"/>
<rectangle x1="-3.175" y1="-10.414" x2="-1.905" y2="-7.62" layer="21"/>
<rectangle x1="-0.635" y1="-10.414" x2="0.635" y2="-7.62" layer="21"/>
<rectangle x1="1.905" y1="-10.414" x2="3.175" y2="-7.62" layer="21"/>
<hole x="0" y="4.826" drill="3.302"/>
</package>
<package name="SOT223">
<description>&lt;b&gt;Small Outline Transistor&lt;/b&gt;</description>
<wire x1="3.2766" y1="1.778" x2="3.2766" y2="-1.778" width="0.2032" layer="21"/>
<wire x1="3.2766" y1="-1.778" x2="-3.2766" y2="-1.778" width="0.2032" layer="21"/>
<wire x1="-3.2766" y1="-1.778" x2="-3.2766" y2="1.778" width="0.2032" layer="21"/>
<wire x1="-3.2766" y1="1.778" x2="3.2766" y2="1.778" width="0.2032" layer="21"/>
<smd name="1" x="-2.3114" y="-3.0988" dx="1.2192" dy="2.2352" layer="1"/>
<smd name="2" x="0" y="-3.0988" dx="1.2192" dy="2.2352" layer="1"/>
<smd name="3" x="2.3114" y="-3.0988" dx="1.2192" dy="2.2352" layer="1"/>
<smd name="4" x="0" y="3.099" dx="3.6" dy="2.2" layer="1"/>
<text x="1.0208" y="-4.318" size="0.8128" layer="21" ratio="12">3</text>
<text x="1.905" y="2.54" size="0.8128" layer="21" ratio="12">4</text>
<text x="-3.4526" y="-4.318" size="0.8128" layer="21" ratio="12">1</text>
<text x="-1.2906" y="-4.3274" size="0.8128" layer="21" ratio="12">2</text>
<text x="-2.54" y="0.0508" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-1.3208" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6002" y1="1.8034" x2="1.6002" y2="3.6576" layer="51"/>
<rectangle x1="-0.4318" y1="-3.6576" x2="0.4318" y2="-1.8034" layer="51"/>
<rectangle x1="-2.7432" y1="-3.6576" x2="-1.8796" y2="-1.8034" layer="51"/>
<rectangle x1="1.8796" y1="-3.6576" x2="2.7432" y2="-1.8034" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="LM311">
<wire x1="-3.81" y1="3.175" x2="-3.81" y2="1.905" width="0.1524" layer="94"/>
<wire x1="-4.445" y1="2.54" x2="-3.175" y2="2.54" width="0.1524" layer="94"/>
<wire x1="-4.445" y1="-2.54" x2="-3.175" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="-5.08" y1="5.08" x2="-5.08" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="5.08" x2="-2.54" y2="3.8862" width="0.1524" layer="94"/>
<wire x1="0" y1="5.08" x2="0" y2="2.6162" width="0.1524" layer="94"/>
<wire x1="0" y1="-5.08" x2="0" y2="-2.6162" width="0.1524" layer="94"/>
<wire x1="2.6416" y1="1.2954" x2="5.08" y2="2.54" width="0.1524" layer="94"/>
<wire x1="-5.08" y1="5.08" x2="5.08" y2="0" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="-3.8862" x2="-2.54" y2="-5.08" width="0.1524" layer="94"/>
<wire x1="-5.08" y1="-5.08" x2="5.08" y2="0" width="0.4064" layer="94"/>
<text x="2.54" y="5.715" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="-5.08" size="1.778" layer="96">&gt;VALUE</text>
<text x="1.27" y="3.175" size="0.8128" layer="93" rot="R90">ON</text>
<text x="3.175" y="2.54" size="0.8128" layer="93" rot="R90">ON/STR</text>
<text x="1.27" y="-5.08" size="0.8128" layer="93" rot="R90">GND</text>
<text x="-1.27" y="4.445" size="0.8128" layer="93" rot="R90">V+</text>
<text x="-1.27" y="-5.715" size="0.8128" layer="93" rot="R90">V-</text>
<pin name="ON/STR" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="-IN" x="-7.62" y="-2.54" visible="pad" length="short" direction="in"/>
<pin name="+IN" x="-7.62" y="2.54" visible="pad" length="short" direction="in"/>
<pin name="ON" x="0" y="7.62" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="OUT" x="7.62" y="0" visible="pad" length="short" direction="out" rot="R180"/>
<pin name="GND" x="0" y="-7.62" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="V+" x="-2.54" y="7.62" visible="pad" length="short" direction="pwr" rot="R270"/>
<pin name="V-" x="-2.54" y="-7.62" visible="pad" length="short" direction="pwr" rot="R90"/>
</symbol>
<symbol name="317">
<wire x1="-7.62" y1="-2.54" x2="7.62" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-2.54" x2="7.62" y2="5.08" width="0.4064" layer="94"/>
<wire x1="7.62" y1="5.08" x2="-7.62" y2="5.08" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="5.08" x2="-7.62" y2="-2.54" width="0.4064" layer="94"/>
<text x="-7.62" y="8.255" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="5.715" size="1.778" layer="96">&gt;VALUE</text>
<text x="-2.032" y="-1.524" size="1.524" layer="95">ADJ</text>
<pin name="VI" x="-10.16" y="2.54" length="short" direction="in"/>
<pin name="ADJ" x="0" y="-5.08" visible="pad" length="short" direction="in" rot="R90"/>
<pin name="VO" x="10.16" y="2.54" length="short" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="LM311" prefix="IC">
<description>&lt;b&gt;COMPARATOR&lt;/b&gt;</description>
<gates>
<gate name="A" symbol="LM311" x="5.08" y="0"/>
</gates>
<devices>
<device name="N" package="DIL08">
<connects>
<connect gate="A" pin="+IN" pad="2"/>
<connect gate="A" pin="-IN" pad="3"/>
<connect gate="A" pin="GND" pad="1"/>
<connect gate="A" pin="ON" pad="5"/>
<connect gate="A" pin="ON/STR" pad="6"/>
<connect gate="A" pin="OUT" pad="7"/>
<connect gate="A" pin="V+" pad="8"/>
<connect gate="A" pin="V-" pad="4"/>
</connects>
<technologies>
</technologies>
</device>
<device name="D" package="SO08">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="*317" prefix="IC">
<description>Positive &lt;b&gt;VOLTAGE REGULATOR&lt;/b&gt;</description>
<gates>
<gate name="A1" symbol="317" x="0" y="-2.54"/>
</gates>
<devices>
<device name="LZ" package="TO92">
<connects>
<connect gate="A1" pin="ADJ" pad="1"/>
<connect gate="A1" pin="VI" pad="3"/>
<connect gate="A1" pin="VO" pad="2"/>
</connects>
<technologies>
<technology name="LM"/>
</technologies>
</device>
<device name="T" package="TO220H">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="EMP" package="SOT223">
<connects>
<connect gate="A1" pin="VO" pad="4"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="pot">
<description>&lt;b&gt;Potentiometers&lt;/b&gt;&lt;p&gt;
Beckman, Copal, Piher, Spectrol, Schukat&lt;p&gt;
<packages>
<package name="3RP/1610N">
<description>&lt;b&gt;16mm Potentiometer&lt;/b&gt; one level&lt;p&gt;
Source: http://www.alphapotentiometers.net/html/16mm_pot_2.html</description>
<wire x1="-8.35" y1="-3.7" x2="8.35" y2="-3.7" width="0.2032" layer="21"/>
<wire x1="-8.35" y1="-5.7" x2="-7.25" y2="-5.7" width="0.2032" layer="21"/>
<wire x1="-8.35" y1="-3.7" x2="-8.35" y2="-5.7" width="0.2032" layer="21"/>
<wire x1="-7.25" y1="-5.7" x2="-7.25" y2="-3.8" width="0.2032" layer="21"/>
<wire x1="-8.35" y1="-1.7" x2="8.35" y2="-1.7" width="0.2032" layer="21"/>
<wire x1="-8.35" y1="5.4" x2="8.35" y2="5.4" width="0.2032" layer="21"/>
<wire x1="-2.9" y1="-10.2" x2="-2.9" y2="-13.7" width="0.2032" layer="21"/>
<wire x1="2.9" y1="-13.7" x2="2.9" y2="-10.2" width="0.2032" layer="21"/>
<wire x1="-3.4" y1="-3.8" x2="-3.4" y2="-9.9" width="0.2032" layer="21"/>
<wire x1="-3.4" y1="-9.9" x2="-2.9" y2="-10.2" width="0.2032" layer="21"/>
<wire x1="2.9" y1="-10.2" x2="3.4" y2="-9.9" width="0.2032" layer="21"/>
<wire x1="3.4" y1="-9.9" x2="3.4" y2="-3.8" width="0.2032" layer="21"/>
<wire x1="-2.9" y1="-10.2" x2="2.9" y2="-10.2" width="0.2032" layer="21"/>
<wire x1="-2.9" y1="-13.7" x2="2.9" y2="-13.7" width="0.2032" layer="21"/>
<wire x1="-8.35" y1="-3.7" x2="-8.35" y2="5.4" width="0.2032" layer="21"/>
<wire x1="8.35" y1="-3.7" x2="8.35" y2="5.4" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-9.525" x2="3.3" y2="-9" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-9.025" x2="3.3" y2="-8.5" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-8.525" x2="3.3" y2="-8" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-8.025" x2="3.3" y2="-7.5" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-7.525" x2="3.3" y2="-7" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-7.025" x2="3.3" y2="-6.5" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-6.525" x2="3.3" y2="-6" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-6.025" x2="3.3" y2="-5.5" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-5.525" x2="3.3" y2="-5" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-5.025" x2="3.3" y2="-4.5" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-4.525" x2="3.3" y2="-4" width="0.2032" layer="21"/>
<wire x1="-3.075" y1="-10.025" x2="3.3" y2="-9.5" width="0.2032" layer="21"/>
<pad name="1" x="-5" y="0" drill="1.2" diameter="2.1844"/>
<pad name="2" x="0" y="0" drill="1.2" diameter="2.1844"/>
<pad name="3" x="5" y="0" drill="1.2" diameter="2.1844"/>
<text x="-8.255" y="5.715" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.175" y="2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
<symbols>
<symbol name="POT_EU-">
<wire x1="-0.762" y1="2.54" x2="-0.762" y2="-2.54" width="0.254" layer="94"/>
<wire x1="0.762" y1="-2.54" x2="0.762" y2="2.54" width="0.254" layer="94"/>
<wire x1="2.54" y1="0" x2="1.651" y2="0" width="0.1524" layer="94"/>
<wire x1="1.651" y1="0" x2="-1.8796" y2="1.7526" width="0.1524" layer="94"/>
<wire x1="0.762" y1="2.54" x2="-0.762" y2="2.54" width="0.254" layer="94"/>
<wire x1="-0.762" y1="-2.54" x2="0.762" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-2.1597" y1="1.2939" x2="-3.1989" y2="2.4495" width="0.1524" layer="94"/>
<wire x1="-3.1989" y1="2.4495" x2="-1.7018" y2="2.2352" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-2.54" x2="-2.54" y2="-0.508" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-0.508" x2="-3.048" y2="-1.524" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-0.508" x2="-2.032" y2="-1.524" width="0.1524" layer="94"/>
<wire x1="-2.1597" y1="1.2939" x2="-1.7018" y2="2.2352" width="0.1524" layer="94"/>
<text x="-5.969" y="-3.81" size="1.778" layer="95" rot="R90">&gt;NAME</text>
<text x="-3.81" y="-3.81" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="A" x="0" y="-5.08" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="E" x="0" y="5.08" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="S" x="5.08" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="3RP/1610N" prefix="R" uservalue="yes">
<gates>
<gate name="G$1" symbol="POT_EU-" x="0" y="0"/>
</gates>
<devices>
<device name="" package="3RP/1610N">
<connects>
<connect gate="G$1" pin="A" pad="1"/>
<connect gate="G$1" pin="S" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="docu-dummy">
<description>Dummy symbols</description>
<packages>
</packages>
<symbols>
<symbol name="ELKO">
<wire x1="-1.524" y1="-0.889" x2="1.524" y2="-0.889" width="0.254" layer="94"/>
<wire x1="1.524" y1="-0.889" x2="1.524" y2="0" width="0.254" layer="94"/>
<wire x1="-1.524" y1="0" x2="-1.524" y2="-0.889" width="0.254" layer="94"/>
<wire x1="-1.524" y1="0" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="2.54" width="0.1524" layer="94"/>
<wire x1="0" y1="-2.54" x2="0" y2="-5.08" width="0.1524" layer="94"/>
<text x="-0.5842" y="0.4064" size="1.27" layer="94" rot="R90">+</text>
<rectangle x1="-1.651" y1="-2.54" x2="1.651" y2="-1.651" layer="94"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="ELKO" prefix="C">
<description>&lt;b&gt;ELektrolyt Capacitor&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="ELKO" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="capacitor-wima">
<description>&lt;b&gt;WIMA Capacitors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="C10B4">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 13.4 x 4 mm, grid 10.16 mm</description>
<wire x1="-3.175" y1="1.27" x2="-3.175" y2="0" width="0.4064" layer="21"/>
<wire x1="-2.286" y1="1.27" x2="-2.286" y2="0" width="0.4064" layer="21"/>
<wire x1="3.81" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="-2.286" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-3.81" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0" x2="-3.175" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-6.096" y1="2.032" x2="6.096" y2="2.032" width="0.1524" layer="21"/>
<wire x1="6.604" y1="1.524" x2="6.604" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-2.032" x2="-6.096" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-1.524" x2="-6.604" y2="1.524" width="0.1524" layer="21"/>
<wire x1="6.096" y1="2.032" x2="6.604" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-2.032" x2="6.604" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-1.524" x2="-6.096" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="1.524" x2="-6.096" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-5.08" y="0" drill="1.016" diameter="2.159" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="1.016" diameter="2.159" shape="octagon"/>
<text x="-3.429" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C10B5">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 13.4 x 5 mm, grid 10.16 mm</description>
<wire x1="-6.096" y1="2.54" x2="6.096" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.032" x2="6.604" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-2.54" x2="-6.096" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.032" x2="-6.604" y2="2.032" width="0.1524" layer="21"/>
<wire x1="6.096" y1="2.54" x2="6.604" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-2.54" x2="6.604" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-2.032" x2="-6.096" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="2.032" x2="-6.096" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-5.08" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-1.905" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C10B6">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 13.4 x 6 mm, grid 10.16 mm</description>
<wire x1="-6.096" y1="3.048" x2="6.096" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.54" x2="6.604" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-3.048" x2="-6.096" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.54" x2="-6.604" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.096" y1="3.048" x2="6.604" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-3.048" x2="6.604" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-2.54" x2="-6.096" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="2.54" x2="-6.096" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-5.08" y="3.302" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C15B5">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 18 x 5 mm, grid 15 mm</description>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="0" width="0.4064" layer="21"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="1.27" x2="-4.191" y2="0" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="-4.191" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="9.017" y1="2.032" x2="9.017" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-2.54" x2="-8.509" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-2.032" x2="-9.017" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="2.54" x2="8.509" y2="2.54" width="0.1524" layer="21"/>
<wire x1="8.509" y1="2.54" x2="9.017" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-2.54" x2="9.017" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-2.032" x2="-8.509" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="2.032" x2="-8.509" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-7.493" y="0" drill="1.016" diameter="2.159" shape="octagon"/>
<pad name="2" x="7.493" y="0" drill="1.016" diameter="2.159" shape="octagon"/>
<text x="-7.493" y="2.794" size="1.397" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.032" size="1.397" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C15B6">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 18 x 6 mm, grid 15 mm</description>
<wire x1="9.017" y1="2.54" x2="9.017" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.048" x2="-8.509" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-2.54" x2="-9.017" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.048" x2="8.509" y2="3.048" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.048" x2="9.017" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-3.048" x2="9.017" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-2.54" x2="-8.509" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="2.54" x2="-8.509" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-7.493" y="3.302" size="1.397" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C15B7">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 18 x 7 mm, grid 15 mm</description>
<wire x1="9.017" y1="3.048" x2="9.017" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.556" x2="-8.509" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.048" x2="-9.017" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.556" x2="8.509" y2="3.556" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.556" x2="9.017" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-3.556" x2="9.017" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.048" x2="-8.509" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.048" x2="-8.509" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<text x="-7.493" y="3.81" size="1.397" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.286" size="1.397" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C15B8">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 18 x 8 mm, grid 15 mm</description>
<wire x1="9.017" y1="3.556" x2="9.017" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.064" x2="-8.509" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.556" x2="-9.017" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.064" x2="8.509" y2="4.064" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.064" x2="9.017" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-4.064" x2="9.017" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.556" x2="-8.509" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.556" x2="-8.509" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<text x="-7.493" y="4.318" size="1.397" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.54" size="1.397" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C15B9">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 18 x 9 mm, grid 15 mm</description>
<wire x1="9.017" y1="3.937" x2="9.017" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.445" x2="-8.509" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.937" x2="-9.017" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.445" x2="8.509" y2="4.445" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.445" x2="9.017" y2="3.937" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-4.445" x2="9.017" y2="-3.937" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.937" x2="-8.509" y2="-4.445" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.937" x2="-8.509" y2="4.445" width="0.1524" layer="21" curve="-90"/>
<text x="-7.493" y="4.699" size="1.397" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C2.5-2">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 5 x 2.5 mm, grid 2.54 mm</description>
<wire x1="-2.159" y1="1.27" x2="2.159" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.27" x2="-2.159" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.27" x2="2.413" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.016" x2="-2.159" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.27" x2="2.413" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.016" x2="-2.159" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="1.27" y1="0" x2="0.381" y2="0" width="0.1524" layer="51"/>
<wire x1="0.381" y1="0" x2="0.254" y2="0" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="0.762" width="0.254" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="-0.254" y2="0" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-1.27" y2="0" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<text x="-1.651" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C2.5-4">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 5 x 4 mm, grid 2.54 mm</description>
<wire x1="-2.159" y1="1.905" x2="2.159" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.905" x2="-2.159" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.651" x2="2.413" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.651" x2="-2.413" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.905" x2="2.413" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.651" x2="-2.159" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.905" x2="2.413" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.651" x2="-2.159" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<text x="-1.651" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C2.5-5">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 5 x 5 mm, grid 2.54 mm</description>
<wire x1="-2.159" y1="2.286" x2="2.159" y2="2.286" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-2.286" x2="-2.159" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.032" x2="2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="2.032" x2="-2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.286" x2="2.413" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="2.032" x2="-2.159" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-2.286" x2="2.413" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-2.032" x2="-2.159" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<text x="-1.778" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.778" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C2.5-6">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 5 x 6 mm, grid 2.54 mm</description>
<wire x1="-2.159" y1="2.794" x2="2.159" y2="2.794" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-2.794" x2="-2.159" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.54" x2="2.413" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="2.54" x2="-2.413" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.794" x2="2.413" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="2.54" x2="-2.159" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-2.794" x2="2.413" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-2.54" x2="-2.159" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<text x="2.667" y="0.762" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.905" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C22.5B10">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 27 x 10 mm, grid 22.5 mm</description>
<wire x1="-12.827" y1="5.334" x2="12.827" y2="5.334" width="0.1524" layer="21"/>
<wire x1="13.335" y1="4.826" x2="13.335" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-5.334" x2="-12.827" y2="-5.334" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-4.826" x2="-13.335" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="1.905" x2="-6.731" y2="0" width="0.4064" layer="21"/>
<wire x1="-6.731" y1="0" x2="-6.731" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-7.62" y2="0" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="12.827" y1="5.334" x2="13.335" y2="4.826" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-5.334" x2="13.335" y2="-4.826" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-4.826" x2="-12.827" y2="-5.334" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="4.826" x2="-12.827" y2="5.334" width="0.1524" layer="21" curve="-90"/>
<wire x1="-9.652" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="9.652" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-11.303" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<pad name="2" x="11.303" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<text x="-11.303" y="5.588" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C22.5B11">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 27 x 11 mm, grid 22.5 mm</description>
<wire x1="-12.827" y1="5.588" x2="12.827" y2="5.588" width="0.1524" layer="21"/>
<wire x1="13.335" y1="5.08" x2="13.335" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-5.588" x2="-12.827" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.08" x2="-13.335" y2="5.08" width="0.1524" layer="21"/>
<wire x1="12.827" y1="5.588" x2="13.335" y2="5.08" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-5.588" x2="13.335" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-5.08" x2="-12.827" y2="-5.588" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="5.08" x2="-12.827" y2="5.588" width="0.1524" layer="21" curve="-90"/>
<text x="-11.303" y="5.842" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C22.5B6">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 27 x 6 mm, grid 22.5 mm</description>
<wire x1="-12.827" y1="3.048" x2="12.827" y2="3.048" width="0.1524" layer="21"/>
<wire x1="13.335" y1="2.54" x2="13.335" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-3.048" x2="-12.827" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-2.54" x2="-13.335" y2="2.54" width="0.1524" layer="21"/>
<wire x1="12.827" y1="3.048" x2="13.335" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-3.048" x2="13.335" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-2.54" x2="-12.827" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="2.54" x2="-12.827" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-11.303" y="3.302" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C22.5B7">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 27 x 7 mm, grid 22.5 mm</description>
<wire x1="-12.827" y1="3.556" x2="12.827" y2="3.556" width="0.1524" layer="21"/>
<wire x1="13.335" y1="3.048" x2="13.335" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-3.556" x2="-12.827" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-3.048" x2="-13.335" y2="3.048" width="0.1524" layer="21"/>
<wire x1="12.827" y1="3.556" x2="13.335" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-3.556" x2="13.335" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-3.048" x2="-12.827" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="3.048" x2="-12.827" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<text x="-11.303" y="3.81" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C22.5B8">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 27 x 8 mm, grid 22.5 mm</description>
<wire x1="-12.827" y1="4.318" x2="12.827" y2="4.318" width="0.1524" layer="21"/>
<wire x1="13.335" y1="3.81" x2="13.335" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-4.318" x2="-12.827" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-3.81" x2="-13.335" y2="3.81" width="0.1524" layer="21"/>
<wire x1="12.827" y1="4.318" x2="13.335" y2="3.81" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-4.318" x2="13.335" y2="-3.81" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-3.81" x2="-12.827" y2="-4.318" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="3.81" x2="-12.827" y2="4.318" width="0.1524" layer="21" curve="-90"/>
<text x="-11.303" y="4.572" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C27.5B11">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 31.6 x 11 mm, grid 27.5 mm</description>
<wire x1="-15.24" y1="5.588" x2="15.24" y2="5.588" width="0.1524" layer="21"/>
<wire x1="15.748" y1="5.08" x2="15.748" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-5.588" x2="-15.24" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-5.08" x2="-15.748" y2="5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="5.588" x2="15.748" y2="5.08" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-5.588" x2="15.748" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-5.08" x2="-15.24" y2="-5.588" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="5.08" x2="-15.24" y2="5.588" width="0.1524" layer="21" curve="-90"/>
<wire x1="-11.557" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="11.557" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-13.716" y="0" drill="1.1938" diameter="3.1496" shape="octagon"/>
<pad name="2" x="13.716" y="0" drill="1.1938" diameter="3.1496" shape="octagon"/>
<text x="-13.716" y="5.842" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C27.5B13">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 31.6 x 13 mm, grid 27.5 mm</description>
<wire x1="-15.24" y1="6.604" x2="15.24" y2="6.604" width="0.1524" layer="21"/>
<wire x1="15.748" y1="6.096" x2="15.748" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-6.604" x2="-15.24" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-6.096" x2="-15.748" y2="6.096" width="0.1524" layer="21"/>
<wire x1="15.24" y1="6.604" x2="15.748" y2="6.096" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-6.604" x2="15.748" y2="-6.096" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-6.096" x2="-15.24" y2="-6.604" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="6.096" x2="-15.24" y2="6.604" width="0.1524" layer="21" curve="-90"/>
<text x="-13.716" y="6.858" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C27.5B15">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 31.6 x 15 mm, grid 27.5 mm</description>
<wire x1="-15.24" y1="7.62" x2="15.24" y2="7.62" width="0.1524" layer="21"/>
<wire x1="15.748" y1="7.112" x2="15.748" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-7.62" x2="-15.24" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-7.112" x2="-15.748" y2="7.112" width="0.1524" layer="21"/>
<wire x1="15.24" y1="7.62" x2="15.748" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-7.62" x2="15.748" y2="-7.112" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-7.112" x2="-15.24" y2="-7.62" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="7.112" x2="-15.24" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<text x="-13.716" y="7.874" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C27.5B17">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 31.6 x 17 mm, grid 27.5 mm</description>
<wire x1="-15.24" y1="8.509" x2="15.24" y2="8.509" width="0.1524" layer="21"/>
<wire x1="15.748" y1="8.001" x2="15.748" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-8.509" x2="-15.24" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-8.001" x2="-15.748" y2="8.001" width="0.1524" layer="21"/>
<wire x1="15.24" y1="8.509" x2="15.748" y2="8.001" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-8.509" x2="15.748" y2="-8.001" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-8.001" x2="-15.24" y2="-8.509" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="8.001" x2="-15.24" y2="8.509" width="0.1524" layer="21" curve="-90"/>
<text x="-13.716" y="8.763" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C27.5B20">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 31.6 x 20 mm, grid 27.5 mm</description>
<wire x1="-15.24" y1="10.16" x2="15.24" y2="10.16" width="0.1524" layer="21"/>
<wire x1="15.748" y1="9.652" x2="15.748" y2="-9.652" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-10.16" x2="-15.24" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-9.652" x2="-15.748" y2="9.652" width="0.1524" layer="21"/>
<wire x1="15.24" y1="10.16" x2="15.748" y2="9.652" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-10.16" x2="15.748" y2="-9.652" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-9.652" x2="-15.24" y2="-10.16" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="9.652" x2="-15.24" y2="10.16" width="0.1524" layer="21" curve="-90"/>
<text x="-13.589" y="10.414" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.318" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C27.5B9">
<description>&lt;B&gt;MKS4&lt;/B&gt;, 31.6 x 9 mm, grid 27.5 mm</description>
<wire x1="-15.24" y1="4.572" x2="15.24" y2="4.572" width="0.1524" layer="21"/>
<wire x1="15.748" y1="4.064" x2="15.748" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-4.572" x2="-15.24" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-4.064" x2="-15.748" y2="4.064" width="0.1524" layer="21"/>
<wire x1="15.24" y1="4.572" x2="15.748" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-4.572" x2="15.748" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-4.064" x2="-15.24" y2="-4.572" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="4.064" x2="-15.24" y2="4.572" width="0.1524" layer="21" curve="-90"/>
<text x="-13.589" y="4.826" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C37.5B15">
<description>&lt;B&gt;MKP4&lt;/B&gt;, 42 x 15 mm, grid 37.5 mm</description>
<wire x1="-20.32" y1="7.62" x2="20.32" y2="7.62" width="0.1524" layer="21"/>
<wire x1="20.828" y1="7.112" x2="20.828" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-7.62" x2="-20.32" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-7.112" x2="-20.828" y2="7.112" width="0.1524" layer="21"/>
<wire x1="20.32" y1="7.62" x2="20.828" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-7.62" x2="20.828" y2="-7.112" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-7.112" x2="-20.32" y2="-7.62" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="7.112" x2="-20.32" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<wire x1="-16.002" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="16.002" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-18.796" y="0" drill="1.3208" diameter="3.1496" shape="octagon"/>
<pad name="2" x="18.796" y="0" drill="1.3208" diameter="3.1496" shape="octagon"/>
<text x="-18.796" y="7.874" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C37.5B19">
<description>&lt;B&gt;MKP4&lt;/B&gt;, 42 x 19 mm, grid 37.5 mm</description>
<wire x1="-20.32" y1="8.509" x2="20.32" y2="8.509" width="0.1524" layer="21"/>
<wire x1="20.828" y1="8.001" x2="20.828" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-8.509" x2="-20.32" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-8.001" x2="-20.828" y2="8.001" width="0.1524" layer="21"/>
<wire x1="20.32" y1="8.509" x2="20.828" y2="8.001" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-8.509" x2="20.828" y2="-8.001" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-8.001" x2="-20.32" y2="-8.509" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="8.001" x2="-20.32" y2="8.509" width="0.1524" layer="21" curve="-90"/>
<text x="-18.796" y="8.89" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C37.5B20">
<description>&lt;B&gt;MKP4&lt;/B&gt;, 42 x 20 mm, grid 37.5 mm</description>
<wire x1="-20.32" y1="10.16" x2="20.32" y2="10.16" width="0.1524" layer="21"/>
<wire x1="20.828" y1="9.652" x2="20.828" y2="-9.652" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-10.16" x2="-20.32" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-9.652" x2="-20.828" y2="9.652" width="0.1524" layer="21"/>
<wire x1="20.32" y1="10.16" x2="20.828" y2="9.652" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-10.16" x2="20.828" y2="-9.652" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-9.652" x2="-20.32" y2="-10.16" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="9.652" x2="-20.32" y2="10.16" width="0.1524" layer="21" curve="-90"/>
<text x="-18.796" y="10.414" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C5B2.5">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 7.5 x 2.5 mm, grid 5.08 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.016" x2="-3.683" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.27" x2="3.429" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.016" x2="3.683" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="-3.429" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="3.683" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.27" x2="3.683" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.016" x2="-3.429" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.016" x2="-3.429" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<text x="-2.032" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C5B3">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 7.5 x 3 mm, grid 5.08 mm</description>
<wire x1="-3.683" y1="1.27" x2="-3.683" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.524" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.27" x2="3.683" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="3.683" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.524" x2="3.683" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.27" x2="-3.429" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.27" x2="-3.429" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<text x="-2.54" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C5B3.5">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 7.5 x 4 mm, grid 5.08 mm</description>
<wire x1="-3.683" y1="1.524" x2="-3.683" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.778" x2="3.429" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.524" x2="3.683" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.778" x2="-3.429" y2="1.778" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.778" x2="3.683" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.778" x2="3.683" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.524" x2="-3.429" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.524" x2="-3.429" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<text x="-2.54" y="2.032" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C5B4.5">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 7.5 x 4.5 mm, grid 5.08 mm</description>
<wire x1="-3.683" y1="2.032" x2="-3.683" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.286" x2="3.429" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.032" x2="3.683" y2="2.032" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.286" x2="-3.429" y2="2.286" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.286" x2="3.683" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.286" x2="3.683" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.032" x2="-3.429" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.032" x2="-3.429" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<text x="-2.54" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C5B5">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 7.5 x 5 mm, grid 5.08 mm</description>
<wire x1="-3.683" y1="2.286" x2="-3.683" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.54" x2="3.429" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.286" x2="3.683" y2="2.286" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.54" x2="-3.429" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.54" x2="3.683" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.54" x2="3.683" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.286" x2="-3.429" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.286" x2="-3.429" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-2.54" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C5B5.5">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 7.5 x 5.5 mm, grid 5.08 mm</description>
<wire x1="-3.683" y1="2.54" x2="-3.683" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.794" x2="3.429" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.54" x2="3.683" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.794" x2="-3.429" y2="2.794" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.794" x2="3.683" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.794" x2="3.683" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.54" x2="-3.429" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.54" x2="-3.429" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<text x="-2.54" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C5B7.2">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 7.5 x 7.2 mm, grid 5.08 mm</description>
<wire x1="-1.524" y1="0" x2="-0.4572" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.4572" y1="0" x2="-0.4572" y2="0.762" width="0.4064" layer="21"/>
<wire x1="-0.4572" y1="0" x2="-0.4572" y2="-0.762" width="0.4064" layer="21"/>
<wire x1="0.4318" y1="0.762" x2="0.4318" y2="0" width="0.4064" layer="21"/>
<wire x1="0.4318" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.4318" y1="0" x2="0.4318" y2="-0.762" width="0.4064" layer="21"/>
<wire x1="-3.683" y1="3.429" x2="-3.683" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-3.683" x2="3.429" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-3.429" x2="3.683" y2="3.429" width="0.1524" layer="21"/>
<wire x1="3.429" y1="3.683" x2="-3.429" y2="3.683" width="0.1524" layer="21"/>
<wire x1="3.429" y1="3.683" x2="3.683" y2="3.429" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-3.683" x2="3.683" y2="-3.429" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-3.429" x2="-3.429" y2="-3.683" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="3.429" x2="-3.429" y2="3.683" width="0.1524" layer="21" curve="-90"/>
<text x="-2.54" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C7.5B3">
<description>&lt;B&gt;MKS3&lt;/B&gt;, 10 x 3 mm, grid 7.62 mm</description>
<wire x1="4.826" y1="1.524" x2="-4.826" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-1.524" x2="4.826" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.27" x2="5.08" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.826" y1="1.524" x2="5.08" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.826" y1="-1.524" x2="5.08" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="-1.27" x2="-4.826" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.27" x2="-4.826" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="0.508" y1="0" x2="2.54" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.889" x2="-0.508" y2="0" width="0.4064" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.889" width="0.4064" layer="21"/>
<wire x1="0.508" y1="0.889" x2="0.508" y2="0" width="0.4064" layer="21"/>
<wire x1="0.508" y1="0" x2="0.508" y2="-0.889" width="0.4064" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.9144" diameter="1.905" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.9144" diameter="1.905" shape="octagon"/>
<text x="-3.81" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C7.5B4">
<description>&lt;B&gt;MKS3&lt;/B&gt;, 10 x 4 mm, grid 7.62 mm</description>
<wire x1="4.826" y1="2.032" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.778" x2="-5.08" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.032" x2="4.826" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.778" x2="5.08" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="5.08" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.826" y1="-2.032" x2="5.08" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="-1.778" x2="-4.826" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.778" x2="-4.826" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.27" y1="0" x2="2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0" x2="-2.159" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.27" x2="-2.159" y2="0" width="0.4064" layer="21"/>
<wire x1="-2.159" y1="0" x2="-2.159" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="0" width="0.4064" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-1.27" width="0.4064" layer="21"/>
<text x="-3.81" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-3.556" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C7.5B5">
<description>&lt;B&gt;MKS3&lt;/B&gt;, 10 x 5 mm, grid 7.62 mm</description>
<wire x1="4.953" y1="2.54" x2="-4.953" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.286" x2="-5.207" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.54" x2="4.953" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.286" x2="5.207" y2="2.286" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.54" x2="5.207" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.953" y1="-2.54" x2="5.207" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="-2.286" x2="-4.953" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="2.286" x2="-4.953" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-3.81" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-4.064" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C7.5B6">
<description>&lt;B&gt;MKS3&lt;/B&gt;, 10 x 6 mm, grid 7.62 mm</description>
<wire x1="4.953" y1="3.048" x2="-4.953" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.794" x2="-5.207" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-3.048" x2="4.953" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.794" x2="5.207" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.953" y1="3.048" x2="5.207" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.953" y1="-3.048" x2="5.207" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="-2.794" x2="-4.953" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="2.794" x2="-4.953" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-3.683" y="3.302" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.889" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C2.5-3">
<description>&lt;B&gt;MKS2&lt;/B&gt;, 5 x 3 mm, grid 2.54 mm</description>
<wire x1="-2.159" y1="1.524" x2="2.159" y2="1.524" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.524" x2="-2.159" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.27" x2="2.413" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.27" x2="-2.413" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.524" x2="2.413" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.27" x2="-2.159" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.524" x2="2.413" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.27" x2="-2.159" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<text x="-1.651" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
<symbols>
<symbol name="C">
<wire x1="0" y1="-2.54" x2="0" y2="-2.032" width="0.1524" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="-0.508" width="0.1524" layer="94"/>
<text x="1.524" y="0.381" size="1.778" layer="95">&gt;NAME</text>
<text x="1.524" y="-4.699" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-2.032" y1="-1.016" x2="2.032" y2="-0.508" layer="94"/>
<rectangle x1="-2.032" y1="-2.032" x2="2.032" y2="-1.524" layer="94"/>
<pin name="1" x="0" y="2.54" visible="off" length="short" direction="pas" swaplevel="1" rot="R270"/>
<pin name="2" x="0" y="-5.08" visible="off" length="short" direction="pas" swaplevel="1" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="C" prefix="C" uservalue="yes">
<description>&lt;B&gt;CAPACITOR&lt;/B&gt;&lt;p&gt;
naming: grid - package width</description>
<gates>
<gate name="G$1" symbol="C" x="0" y="0"/>
</gates>
<devices>
<device name="10/4" package="C10B4">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="10/5" package="C10B5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="10/6" package="C10B6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="15/5" package="C15B5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="15/6" package="C15B6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="15/7" package="C15B7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="15/8" package="C15B8">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="15/9" package="C15B9">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2.5/2" package="C2.5-2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2.5/4" package="C2.5-4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2.5/5" package="C2.5-5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2.5/6" package="C2.5-6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="22/10" package="C22.5B10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="22/11" package="C22.5B11">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="22/6" package="C22.5B6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="22/7" package="C22.5B7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="22/8" package="C22.5B8">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27/11" package="C27.5B11">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27/13" package="C27.5B13">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27/15" package="C27.5B15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27/17" package="C27.5B17">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27/20" package="C27.5B20">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="27/9" package="C27.5B9">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="37/15" package="C37.5B15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="37/19" package="C37.5B19">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="37/20" package="C37.5B20">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5/2.5" package="C5B2.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5/3" package="C5B3">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5/3.5" package="C5B3.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5/4.5" package="C5B4.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5/5" package="C5B5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5/5.5" package="C5B5.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5/7.2" package="C5B7.2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="7.5/3" package="C7.5B3">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="7.5/4" package="C7.5B4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="7.5/5" package="C7.5B5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="7.5/6" package="C7.5B6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2,5-3" package="C2.5-3">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<parts>
<part name="OK1" library="optocoupler" deviceset="4N35" device=""/>
<part name="OK2" library="optocoupler" deviceset="4N35" device=""/>
<part name="OK3" library="optocoupler" deviceset="4N35" device=""/>
<part name="LED1" library="led" deviceset="LED" device="5MM"/>
<part name="LED2" library="led" deviceset="LED" device="5MM"/>
<part name="LED3" library="led" deviceset="LED" device="5MM"/>
<part name="R1" library="resistor" deviceset="R-US_" device="0207/10" value="470"/>
<part name="R2" library="resistor" deviceset="R-US_" device="0207/10" value="470"/>
<part name="R3" library="resistor" deviceset="R-US_" device="0207/10" value="470"/>
<part name="RF.SIG.1" library="solpad" deviceset="LSP10" device=""/>
<part name="RF.SIG.2" library="solpad" deviceset="LSP10" device=""/>
<part name="RF.SIG.3" library="solpad" deviceset="LSP10" device=""/>
<part name="K1" library="relay" deviceset="351" device=""/>
<part name="K2" library="relay" deviceset="351" device=""/>
<part name="K3" library="relay" deviceset="CQ1-12V" device=""/>
<part name="D1" library="diode" deviceset="1N4004" device=""/>
<part name="D2" library="diode" deviceset="1N4004" device=""/>
<part name="D3" library="diode" deviceset="1N4004" device=""/>
<part name="T1" library="transistor" deviceset="TIP122" device=""/>
<part name="T2" library="transistor" deviceset="TIP122" device=""/>
<part name="T3" library="transistor" deviceset="TIP122" device=""/>
<part name="T4" library="transistor" deviceset="TIP122" device=""/>
<part name="R4" library="resistor" deviceset="R-US_" device="0207/10" value="510"/>
<part name="R5" library="resistor" deviceset="R-US_" device="0207/10" value="510"/>
<part name="R6" library="resistor" deviceset="R-US_" device="0207/10" value="510"/>
<part name="R7" library="resistor" deviceset="R-US_" device="0207/10" value="510"/>
<part name="MOTOR-" library="solpad" deviceset="LSP10" device=""/>
<part name="MOTOR+" library="solpad" deviceset="LSP10" device=""/>
<part name="ALARM.1" library="solpad" deviceset="LSP10" device=""/>
<part name="ALARM.2" library="solpad" deviceset="LSP10" device=""/>
<part name="BATT.-" library="solpad" deviceset="LSP10" device=""/>
<part name="BATT.+" library="solpad" deviceset="LSP10" device=""/>
<part name="RFVEVO+" library="solpad" deviceset="LSP10" device=""/>
<part name="R8" library="resistor" deviceset="R-US_" device="0207/10" value="0.05"/>
<part name="F1" library="fuse" deviceset="GSH15" device="" value="4A"/>
<part name="F2" library="fuse" deviceset="GSH15" device="" value="1A"/>
<part name="IC1" library="linear" deviceset="LM311" device="N"/>
<part name="R9" library="resistor" deviceset="R-US_" device="0207/10" value="10K"/>
<part name="R10" library="resistor" deviceset="R-US_" device="0207/10" value="10K"/>
<part name="R11" library="resistor" deviceset="R-US_" device="0207/10" value="10K"/>
<part name="R12" library="resistor" deviceset="R-US_" device="0207/10" value="10K"/>
<part name="IC2" library="linear" deviceset="*317" device="T"/>
<part name="R13" library="pot" deviceset="3RP/1610N" device="" value="1K"/>
<part name="R14" library="pot" deviceset="3RP/1610N" device="" value="5K"/>
<part name="C1" library="docu-dummy" deviceset="ELKO" device="" value="10uF"/>
<part name="T5" library="transistor" deviceset="*-NPN-" device="TO92-CBE" technology="BC337" value="BC 337"/>
<part name="D4" library="diode" deviceset="1N4004" device=""/>
<part name="DC.IN.-" library="solpad" deviceset="LSP10" device=""/>
<part name="DC.IN.+" library="solpad" deviceset="LSP10" device=""/>
<part name="T6" library="transistor" deviceset="*-NPN-" device="TO92-CBE" technology="BC547A"/>
<part name="C2" library="docu-dummy" deviceset="ELKO" device=""/>
<part name="C3" library="capacitor-wima" deviceset="C" device="5/2.5" value="220nF"/>
<part name="C4" library="capacitor-wima" deviceset="C" device="5/2.5" value="220nF"/>
<part name="R15" library="resistor" deviceset="R-US_" device="0207/10" value="100"/>
<part name="R16" library="resistor" deviceset="R-US_" device="0207/10" value="120"/>
<part name="R17" library="resistor" deviceset="R-US_" device="0207/10" value="470"/>
<part name="R18" library="resistor" deviceset="R-US_" device="0207/10" value="0.5"/>
</parts>
<sheets>
<sheet>
<plain>
</plain>
<instances>
<instance part="OK1" gate="G$1" x="30.48" y="66.04"/>
<instance part="OK2" gate="G$1" x="30.48" y="43.18"/>
<instance part="OK3" gate="G$1" x="30.48" y="20.32"/>
<instance part="LED1" gate="G$1" x="20.32" y="76.2"/>
<instance part="LED2" gate="G$1" x="15.24" y="50.8"/>
<instance part="LED3" gate="G$1" x="7.62" y="27.94"/>
<instance part="R1" gate="G$1" x="7.62" y="38.1" rot="R270"/>
<instance part="R2" gate="G$1" x="20.32" y="86.36" rot="R270"/>
<instance part="R3" gate="G$1" x="15.24" y="60.96" rot="R270"/>
<instance part="RF.SIG.1" gate="1" x="-10.16" y="60.96" rot="R90"/>
<instance part="RF.SIG.2" gate="1" x="-10.16" y="38.1" rot="R90"/>
<instance part="RF.SIG.3" gate="1" x="-10.16" y="15.24" rot="R90"/>
<instance part="K1" gate="1" x="50.8" y="63.5"/>
<instance part="K1" gate="2" x="68.58" y="86.36"/>
<instance part="K1" gate="3" x="63.5" y="53.34"/>
<instance part="K2" gate="1" x="50.8" y="40.64"/>
<instance part="K2" gate="2" x="68.58" y="73.66"/>
<instance part="K2" gate="3" x="63.5" y="30.48"/>
<instance part="K3" gate="1" x="121.92" y="50.8" rot="R180"/>
<instance part="K3" gate="2" x="104.14" y="50.8" rot="R270"/>
<instance part="D1" gate="1" x="43.18" y="63.5" rot="R90"/>
<instance part="D2" gate="1" x="43.18" y="40.64" rot="R90"/>
<instance part="D3" gate="1" x="129.54" y="50.8" rot="R90"/>
<instance part="T1" gate="G$1" x="91.44" y="88.9"/>
<instance part="T2" gate="G$1" x="91.44" y="71.12"/>
<instance part="T3" gate="G$1" x="119.38" y="88.9"/>
<instance part="T4" gate="G$1" x="119.38" y="71.12"/>
<instance part="R4" gate="G$1" x="81.28" y="88.9"/>
<instance part="R5" gate="G$1" x="81.28" y="71.12"/>
<instance part="R6" gate="G$1" x="109.22" y="88.9"/>
<instance part="R7" gate="G$1" x="109.22" y="71.12"/>
<instance part="MOTOR-" gate="1" x="104.14" y="101.6"/>
<instance part="MOTOR+" gate="1" x="109.22" y="101.6"/>
<instance part="ALARM.1" gate="1" x="38.1" y="7.62" rot="R180"/>
<instance part="ALARM.2" gate="1" x="43.18" y="7.62" rot="R180"/>
<instance part="BATT.-" gate="1" x="-10.16" y="-7.62" rot="R90"/>
<instance part="BATT.+" gate="1" x="-10.16" y="101.6" rot="R90"/>
<instance part="RFVEVO+" gate="1" x="-10.16" y="81.28" rot="R90"/>
<instance part="R8" gate="G$1" x="78.74" y="10.16"/>
<instance part="F1" gate="1" x="2.54" y="96.52"/>
<instance part="F2" gate="1" x="228.6" y="93.98" rot="MR180"/>
<instance part="IC1" gate="A" x="149.86" y="50.8"/>
<instance part="R9" gate="G$1" x="139.7" y="40.64" rot="R90"/>
<instance part="R10" gate="G$1" x="139.7" y="78.74" rot="R90"/>
<instance part="R11" gate="G$1" x="139.7" y="63.5" rot="R90"/>
<instance part="R12" gate="G$1" x="114.3" y="33.02"/>
<instance part="IC2" gate="A1" x="195.58" y="91.44" rot="MR0"/>
<instance part="R13" gate="G$1" x="134.62" y="20.32" rot="R180"/>
<instance part="R14" gate="G$1" x="170.18" y="58.42" rot="MR180"/>
<instance part="C1" gate="G$1" x="119.38" y="12.7"/>
<instance part="T5" gate="G$1" x="129.54" y="40.64" rot="MR0"/>
<instance part="D4" gate="1" x="149.86" y="96.52" rot="R180"/>
<instance part="DC.IN.-" gate="1" x="238.76" y="86.36" rot="MR90"/>
<instance part="DC.IN.+" gate="1" x="238.76" y="93.98" rot="MR90"/>
<instance part="T6" gate="G$1" x="210.82" y="73.66"/>
<instance part="C2" gate="G$1" x="218.44" y="91.44" rot="MR0"/>
<instance part="C3" gate="G$1" x="210.82" y="91.44" rot="MR0"/>
<instance part="C4" gate="G$1" x="180.34" y="91.44" rot="MR0"/>
<instance part="R15" gate="G$1" x="195.58" y="73.66" rot="R180"/>
<instance part="R16" gate="G$1" x="170.18" y="88.9" rot="MR270"/>
<instance part="R17" gate="G$1" x="170.18" y="73.66" rot="MR270"/>
<instance part="R18" gate="G$1" x="200.66" y="58.42" rot="R180"/>
</instances>
<busses>
</busses>
<nets>
<net name="N$1" class="0">
<segment>
<pinref part="R1" gate="G$1" pin="2"/>
<pinref part="LED3" gate="G$1" pin="A"/>
<wire x1="7.62" y1="33.02" x2="7.62" y2="30.48" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$2" class="0">
<segment>
<pinref part="OK2" gate="G$1" pin="A"/>
<pinref part="LED2" gate="G$1" pin="C"/>
<wire x1="20.32" y1="45.72" x2="15.24" y2="45.72" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$3" class="0">
<segment>
<pinref part="OK1" gate="G$1" pin="A"/>
<pinref part="LED1" gate="G$1" pin="C"/>
<wire x1="20.32" y1="68.58" x2="20.32" y2="71.12" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$4" class="0">
<segment>
<pinref part="OK3" gate="G$1" pin="A"/>
<pinref part="LED3" gate="G$1" pin="C"/>
<wire x1="20.32" y1="22.86" x2="7.62" y2="22.86" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$5" class="0">
<segment>
<pinref part="LED2" gate="G$1" pin="A"/>
<pinref part="R3" gate="G$1" pin="2"/>
<wire x1="15.24" y1="53.34" x2="15.24" y2="55.88" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$6" class="0">
<segment>
<pinref part="LED1" gate="G$1" pin="A"/>
<pinref part="R2" gate="G$1" pin="2"/>
<wire x1="20.32" y1="78.74" x2="20.32" y2="81.28" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$7" class="0">
<segment>
<pinref part="R1" gate="G$1" pin="1"/>
<wire x1="7.62" y1="43.18" x2="7.62" y2="81.28" width="0.1524" layer="91"/>
<wire x1="7.62" y1="81.28" x2="7.62" y2="96.52" width="0.1524" layer="91"/>
<wire x1="7.62" y1="96.52" x2="15.24" y2="96.52" width="0.1524" layer="91"/>
<pinref part="R2" gate="G$1" pin="1"/>
<wire x1="15.24" y1="96.52" x2="20.32" y2="96.52" width="0.1524" layer="91"/>
<wire x1="20.32" y1="96.52" x2="20.32" y2="91.44" width="0.1524" layer="91"/>
<pinref part="R3" gate="G$1" pin="1"/>
<wire x1="15.24" y1="66.04" x2="15.24" y2="96.52" width="0.1524" layer="91"/>
<pinref part="K1" gate="1" pin="1"/>
<wire x1="50.8" y1="68.58" x2="50.8" y2="71.12" width="0.1524" layer="91"/>
<wire x1="50.8" y1="71.12" x2="50.8" y2="96.52" width="0.1524" layer="91"/>
<wire x1="50.8" y1="96.52" x2="20.32" y2="96.52" width="0.1524" layer="91"/>
<pinref part="D1" gate="1" pin="C"/>
<wire x1="43.18" y1="66.04" x2="43.18" y2="71.12" width="0.1524" layer="91"/>
<wire x1="43.18" y1="71.12" x2="50.8" y2="71.12" width="0.1524" layer="91"/>
<pinref part="K2" gate="1" pin="1"/>
<wire x1="50.8" y1="45.72" x2="50.8" y2="53.34" width="0.1524" layer="91"/>
<wire x1="50.8" y1="53.34" x2="53.34" y2="53.34" width="0.1524" layer="91"/>
<wire x1="53.34" y1="53.34" x2="53.34" y2="96.52" width="0.1524" layer="91"/>
<wire x1="53.34" y1="96.52" x2="50.8" y2="96.52" width="0.1524" layer="91"/>
<pinref part="D2" gate="1" pin="C"/>
<wire x1="43.18" y1="43.18" x2="43.18" y2="53.34" width="0.1524" layer="91"/>
<wire x1="43.18" y1="53.34" x2="50.8" y2="53.34" width="0.1524" layer="91"/>
<junction x="50.8" y="71.12"/>
<junction x="50.8" y="96.52"/>
<junction x="20.32" y="96.52"/>
<junction x="15.24" y="96.52"/>
<junction x="50.8" y="53.34"/>
<junction x="53.34" y="96.52"/>
<wire x1="53.34" y1="96.52" x2="63.5" y2="96.52" width="0.1524" layer="91"/>
<pinref part="K2" gate="2" pin="S"/>
<pinref part="K1" gate="2" pin="S"/>
<wire x1="63.5" y1="78.74" x2="63.5" y2="91.44" width="0.1524" layer="91"/>
<wire x1="63.5" y1="91.44" x2="63.5" y2="96.52" width="0.1524" layer="91"/>
<junction x="63.5" y="91.44"/>
<junction x="63.5" y="96.52"/>
<pinref part="T3" gate="G$1" pin="C"/>
<wire x1="124.46" y1="91.44" x2="124.46" y2="96.52" width="0.1524" layer="91"/>
<wire x1="124.46" y1="96.52" x2="96.52" y2="96.52" width="0.1524" layer="91"/>
<pinref part="T1" gate="G$1" pin="C"/>
<wire x1="96.52" y1="96.52" x2="63.5" y2="96.52" width="0.1524" layer="91"/>
<wire x1="96.52" y1="91.44" x2="96.52" y2="96.52" width="0.1524" layer="91"/>
<junction x="96.52" y="96.52"/>
<pinref part="F1" gate="1" pin="2"/>
<junction x="7.62" y="96.52"/>
<pinref part="RFVEVO+" gate="1" pin="MP"/>
<wire x1="-7.62" y1="81.28" x2="7.62" y2="81.28" width="0.1524" layer="91"/>
<junction x="7.62" y="81.28"/>
<pinref part="K3" gate="1" pin="2"/>
<wire x1="121.92" y1="55.88" x2="129.54" y2="55.88" width="0.1524" layer="91"/>
<wire x1="129.54" y1="55.88" x2="129.54" y2="96.52" width="0.1524" layer="91"/>
<wire x1="129.54" y1="96.52" x2="124.46" y2="96.52" width="0.1524" layer="91"/>
<pinref part="D3" gate="1" pin="C"/>
<wire x1="129.54" y1="53.34" x2="129.54" y2="55.88" width="0.1524" layer="91"/>
<junction x="129.54" y="55.88"/>
<junction x="124.46" y="96.52"/>
<pinref part="IC1" gate="A" pin="V+"/>
<wire x1="147.32" y1="58.42" x2="147.32" y2="96.52" width="0.1524" layer="91"/>
<wire x1="147.32" y1="96.52" x2="139.7" y2="96.52" width="0.1524" layer="91"/>
<pinref part="R10" gate="G$1" pin="2"/>
<wire x1="139.7" y1="96.52" x2="129.54" y2="96.52" width="0.1524" layer="91"/>
<wire x1="139.7" y1="83.82" x2="139.7" y2="96.52" width="0.1524" layer="91"/>
<junction x="129.54" y="96.52"/>
<junction x="139.7" y="96.52"/>
<pinref part="D4" gate="1" pin="C"/>
<junction x="147.32" y="96.52"/>
</segment>
</net>
<net name="N$8" class="0">
<segment>
<pinref part="OK3" gate="G$1" pin="C"/>
<pinref part="RF.SIG.3" gate="1" pin="MP"/>
<wire x1="20.32" y1="15.24" x2="-7.62" y2="15.24" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$9" class="0">
<segment>
<pinref part="RF.SIG.2" gate="1" pin="MP"/>
<pinref part="OK2" gate="G$1" pin="C"/>
<wire x1="-7.62" y1="38.1" x2="20.32" y2="38.1" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$10" class="0">
<segment>
<pinref part="RF.SIG.1" gate="1" pin="MP"/>
<pinref part="OK1" gate="G$1" pin="C"/>
<wire x1="-7.62" y1="60.96" x2="20.32" y2="60.96" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$13" class="0">
<segment>
<pinref part="K1" gate="1" pin="2"/>
<wire x1="50.8" y1="58.42" x2="43.18" y2="58.42" width="0.1524" layer="91"/>
<wire x1="43.18" y1="58.42" x2="40.64" y2="58.42" width="0.1524" layer="91"/>
<wire x1="40.64" y1="58.42" x2="40.64" y2="66.04" width="0.1524" layer="91"/>
<pinref part="OK1" gate="G$1" pin="COL"/>
<wire x1="40.64" y1="66.04" x2="38.1" y2="66.04" width="0.1524" layer="91"/>
<pinref part="K1" gate="3" pin="S"/>
<wire x1="58.42" y1="58.42" x2="50.8" y2="58.42" width="0.1524" layer="91"/>
<junction x="50.8" y="58.42"/>
<pinref part="D1" gate="1" pin="A"/>
<wire x1="43.18" y1="60.96" x2="43.18" y2="58.42" width="0.1524" layer="91"/>
<junction x="43.18" y="58.42"/>
</segment>
</net>
<net name="N$16" class="0">
<segment>
<pinref part="K2" gate="1" pin="2"/>
<wire x1="50.8" y1="35.56" x2="43.18" y2="35.56" width="0.1524" layer="91"/>
<pinref part="D2" gate="1" pin="A"/>
<wire x1="43.18" y1="38.1" x2="43.18" y2="35.56" width="0.1524" layer="91"/>
<wire x1="43.18" y1="35.56" x2="40.64" y2="35.56" width="0.1524" layer="91"/>
<wire x1="40.64" y1="35.56" x2="40.64" y2="43.18" width="0.1524" layer="91"/>
<pinref part="OK2" gate="G$1" pin="COL"/>
<wire x1="40.64" y1="43.18" x2="38.1" y2="43.18" width="0.1524" layer="91"/>
<pinref part="K2" gate="3" pin="S"/>
<wire x1="58.42" y1="35.56" x2="50.8" y2="35.56" width="0.1524" layer="91"/>
<junction x="50.8" y="35.56"/>
<junction x="43.18" y="35.56"/>
</segment>
</net>
<net name="10UF" class="0">
<segment>
<pinref part="OK1" gate="G$1" pin="EMI"/>
<pinref part="OK2" gate="G$1" pin="EMI"/>
<wire x1="38.1" y1="60.96" x2="38.1" y2="38.1" width="0.1524" layer="91"/>
<wire x1="38.1" y1="38.1" x2="38.1" y2="27.94" width="0.1524" layer="91"/>
<wire x1="38.1" y1="27.94" x2="50.8" y2="27.94" width="0.1524" layer="91"/>
<wire x1="50.8" y1="27.94" x2="50.8" y2="10.16" width="0.1524" layer="91"/>
<junction x="38.1" y="38.1"/>
<pinref part="K1" gate="3" pin="P"/>
<pinref part="K2" gate="3" pin="P"/>
<wire x1="63.5" y1="50.8" x2="63.5" y2="27.94" width="0.1524" layer="91"/>
<wire x1="63.5" y1="27.94" x2="50.8" y2="27.94" width="0.1524" layer="91"/>
<junction x="50.8" y="27.94"/>
<junction x="63.5" y="27.94"/>
<pinref part="BATT.-" gate="1" pin="MP"/>
<wire x1="73.66" y1="10.16" x2="50.8" y2="10.16" width="0.1524" layer="91"/>
<wire x1="-7.62" y1="-7.62" x2="50.8" y2="-7.62" width="0.1524" layer="91"/>
<wire x1="50.8" y1="-7.62" x2="50.8" y2="10.16" width="0.1524" layer="91"/>
<pinref part="R8" gate="G$1" pin="1"/>
<junction x="50.8" y="10.16"/>
<wire x1="50.8" y1="-7.62" x2="119.38" y2="-7.62" width="0.1524" layer="91"/>
<pinref part="IC1" gate="A" pin="GND"/>
<pinref part="IC1" gate="A" pin="V-"/>
<wire x1="119.38" y1="-7.62" x2="127" y2="-7.62" width="0.1524" layer="91"/>
<wire x1="127" y1="-7.62" x2="129.54" y2="-7.62" width="0.1524" layer="91"/>
<wire x1="129.54" y1="-7.62" x2="134.62" y2="-7.62" width="0.1524" layer="91"/>
<wire x1="134.62" y1="-7.62" x2="147.32" y2="-7.62" width="0.1524" layer="91"/>
<wire x1="147.32" y1="43.18" x2="149.86" y2="43.18" width="0.1524" layer="91"/>
<wire x1="147.32" y1="-7.62" x2="147.32" y2="43.18" width="0.1524" layer="91"/>
<pinref part="R13" gate="G$1" pin="E"/>
<wire x1="134.62" y1="15.24" x2="134.62" y2="-7.62" width="0.1524" layer="91"/>
<pinref part="R13" gate="G$1" pin="S"/>
<wire x1="129.54" y1="20.32" x2="129.54" y2="-7.62" width="0.1524" layer="91"/>
<wire x1="119.38" y1="7.62" x2="119.38" y2="-7.62" width="0.1524" layer="91"/>
<pinref part="T5" gate="G$1" pin="E"/>
<wire x1="127" y1="35.56" x2="127" y2="-7.62" width="0.1524" layer="91"/>
<junction x="119.38" y="-7.62"/>
<junction x="50.8" y="-7.62"/>
<junction x="127" y="-7.62"/>
<junction x="129.54" y="-7.62"/>
<junction x="134.62" y="-7.62"/>
<label x="116.84" y="10.16" size="1.778" layer="95" rot="R90"/>
<wire x1="147.32" y1="-7.62" x2="170.18" y2="-7.62" width="0.1524" layer="91"/>
<pinref part="R14" gate="G$1" pin="E"/>
<wire x1="170.18" y1="-7.62" x2="170.18" y2="53.34" width="0.1524" layer="91"/>
<wire x1="175.26" y1="53.34" x2="170.18" y2="53.34" width="0.1524" layer="91"/>
<pinref part="R14" gate="G$1" pin="S"/>
<wire x1="175.26" y1="58.42" x2="175.26" y2="53.34" width="0.1524" layer="91"/>
<wire x1="180.34" y1="58.42" x2="175.26" y2="58.42" width="0.1524" layer="91"/>
<pinref part="C4" gate="G$1" pin="2"/>
<wire x1="180.34" y1="86.36" x2="180.34" y2="58.42" width="0.1524" layer="91"/>
<wire x1="190.5" y1="58.42" x2="180.34" y2="58.42" width="0.1524" layer="91"/>
<pinref part="R15" gate="G$1" pin="2"/>
<wire x1="190.5" y1="73.66" x2="190.5" y2="58.42" width="0.1524" layer="91"/>
<pinref part="R18" gate="G$1" pin="2"/>
<wire x1="195.58" y1="58.42" x2="190.5" y2="58.42" width="0.1524" layer="91"/>
<junction x="147.32" y="-7.62"/>
<junction x="175.26" y="58.42"/>
<junction x="170.18" y="53.34"/>
<junction x="180.34" y="58.42"/>
<junction x="190.5" y="58.42"/>
</segment>
</net>
<net name="N$14" class="0">
<segment>
<pinref part="T1" gate="G$1" pin="B"/>
<pinref part="R4" gate="G$1" pin="2"/>
<wire x1="86.36" y1="88.9" x2="88.9" y2="88.9" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$15" class="0">
<segment>
<pinref part="T2" gate="G$1" pin="B"/>
<pinref part="R5" gate="G$1" pin="2"/>
<wire x1="86.36" y1="71.12" x2="88.9" y2="71.12" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$18" class="0">
<segment>
<pinref part="T3" gate="G$1" pin="B"/>
<pinref part="R6" gate="G$1" pin="2"/>
<wire x1="114.3" y1="88.9" x2="116.84" y2="88.9" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$19" class="0">
<segment>
<pinref part="T4" gate="G$1" pin="B"/>
<pinref part="R7" gate="G$1" pin="2"/>
<wire x1="116.84" y1="71.12" x2="114.3" y2="71.12" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$20" class="0">
<segment>
<pinref part="T2" gate="G$1" pin="E"/>
<pinref part="T4" gate="G$1" pin="E"/>
<wire x1="96.52" y1="63.5" x2="101.6" y2="63.5" width="0.1524" layer="91"/>
<pinref part="K3" gate="2" pin="P"/>
<wire x1="101.6" y1="63.5" x2="124.46" y2="63.5" width="0.1524" layer="91"/>
<wire x1="101.6" y1="50.8" x2="101.6" y2="63.5" width="0.1524" layer="91"/>
<junction x="101.6" y="63.5"/>
</segment>
</net>
<net name="N$22" class="0">
<segment>
<pinref part="T2" gate="G$1" pin="C"/>
<pinref part="T1" gate="G$1" pin="E"/>
<wire x1="96.52" y1="73.66" x2="96.52" y2="78.74" width="0.1524" layer="91"/>
<pinref part="MOTOR-" gate="1" pin="MP"/>
<wire x1="96.52" y1="78.74" x2="96.52" y2="81.28" width="0.1524" layer="91"/>
<wire x1="104.14" y1="99.06" x2="104.14" y2="78.74" width="0.1524" layer="91"/>
<wire x1="104.14" y1="78.74" x2="96.52" y2="78.74" width="0.1524" layer="91"/>
<junction x="96.52" y="78.74"/>
</segment>
</net>
<net name="N$23" class="0">
<segment>
<pinref part="T3" gate="G$1" pin="E"/>
<pinref part="T4" gate="G$1" pin="C"/>
<wire x1="124.46" y1="81.28" x2="124.46" y2="78.74" width="0.1524" layer="91"/>
<pinref part="MOTOR+" gate="1" pin="MP"/>
<wire x1="124.46" y1="78.74" x2="124.46" y2="73.66" width="0.1524" layer="91"/>
<wire x1="109.22" y1="99.06" x2="109.22" y2="78.74" width="0.1524" layer="91"/>
<wire x1="109.22" y1="78.74" x2="124.46" y2="78.74" width="0.1524" layer="91"/>
<junction x="124.46" y="78.74"/>
</segment>
</net>
<net name="N$25" class="0">
<segment>
<pinref part="R6" gate="G$1" pin="1"/>
<wire x1="104.14" y1="88.9" x2="99.06" y2="88.9" width="0.1524" layer="91"/>
<wire x1="99.06" y1="88.9" x2="99.06" y2="76.2" width="0.1524" layer="91"/>
<wire x1="99.06" y1="76.2" x2="76.2" y2="76.2" width="0.1524" layer="91"/>
<pinref part="R5" gate="G$1" pin="1"/>
<wire x1="76.2" y1="76.2" x2="76.2" y2="71.12" width="0.1524" layer="91"/>
<pinref part="K2" gate="2" pin="P"/>
<wire x1="68.58" y1="71.12" x2="76.2" y2="71.12" width="0.1524" layer="91"/>
<junction x="76.2" y="71.12"/>
</segment>
</net>
<net name="N$26" class="0">
<segment>
<pinref part="R7" gate="G$1" pin="1"/>
<wire x1="104.14" y1="71.12" x2="101.6" y2="71.12" width="0.1524" layer="91"/>
<wire x1="101.6" y1="71.12" x2="101.6" y2="81.28" width="0.1524" layer="91"/>
<wire x1="101.6" y1="81.28" x2="76.2" y2="81.28" width="0.1524" layer="91"/>
<pinref part="R4" gate="G$1" pin="1"/>
<wire x1="76.2" y1="81.28" x2="76.2" y2="83.82" width="0.1524" layer="91"/>
<pinref part="K1" gate="2" pin="P"/>
<wire x1="76.2" y1="83.82" x2="76.2" y2="88.9" width="0.1524" layer="91"/>
<wire x1="68.58" y1="83.82" x2="76.2" y2="83.82" width="0.1524" layer="91"/>
<junction x="76.2" y="83.82"/>
</segment>
</net>
<net name="N$11" class="0">
<segment>
<pinref part="OK3" gate="G$1" pin="EMI"/>
<pinref part="ALARM.1" gate="1" pin="MP"/>
<wire x1="38.1" y1="15.24" x2="38.1" y2="10.16" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$12" class="0">
<segment>
<pinref part="OK3" gate="G$1" pin="COL"/>
<wire x1="38.1" y1="20.32" x2="40.64" y2="20.32" width="0.1524" layer="91"/>
<wire x1="40.64" y1="20.32" x2="43.18" y2="17.78" width="0.1524" layer="91"/>
<pinref part="ALARM.2" gate="1" pin="MP"/>
<wire x1="43.18" y1="17.78" x2="43.18" y2="10.16" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$21" class="0">
<segment>
<wire x1="109.22" y1="33.02" x2="109.22" y2="10.16" width="0.1524" layer="91"/>
<wire x1="109.22" y1="10.16" x2="83.82" y2="10.16" width="0.1524" layer="91"/>
<pinref part="R8" gate="G$1" pin="2"/>
<pinref part="R12" gate="G$1" pin="1"/>
<pinref part="K3" gate="2" pin="O"/>
<wire x1="109.22" y1="45.72" x2="109.22" y2="33.02" width="0.1524" layer="91"/>
<junction x="109.22" y="33.02"/>
</segment>
</net>
<net name="N$24" class="0">
<segment>
<pinref part="BATT.+" gate="1" pin="MP"/>
<wire x1="-7.62" y1="101.6" x2="-5.08" y2="101.6" width="0.1524" layer="91"/>
<wire x1="-5.08" y1="101.6" x2="-5.08" y2="96.52" width="0.1524" layer="91"/>
<pinref part="F1" gate="1" pin="1"/>
<wire x1="-5.08" y1="96.52" x2="-2.54" y2="96.52" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$28" class="0">
<segment>
<pinref part="D3" gate="1" pin="A"/>
<wire x1="129.54" y1="48.26" x2="129.54" y2="45.72" width="0.1524" layer="91"/>
<pinref part="K3" gate="1" pin="1"/>
<wire x1="129.54" y1="45.72" x2="127" y2="45.72" width="0.1524" layer="91"/>
<pinref part="T5" gate="G$1" pin="C"/>
<junction x="127" y="45.72"/>
<wire x1="127" y1="45.72" x2="121.92" y2="45.72" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$31" class="0">
<segment>
<pinref part="IC1" gate="A" pin="+IN"/>
<wire x1="142.24" y1="53.34" x2="139.7" y2="53.34" width="0.1524" layer="91"/>
<pinref part="R11" gate="G$1" pin="1"/>
<wire x1="139.7" y1="53.34" x2="139.7" y2="58.42" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$32" class="0">
<segment>
<pinref part="R11" gate="G$1" pin="2"/>
<wire x1="139.7" y1="68.58" x2="139.7" y2="71.12" width="0.1524" layer="91"/>
<wire x1="139.7" y1="71.12" x2="139.7" y2="76.2" width="0.1524" layer="91"/>
<wire x1="139.7" y1="71.12" x2="134.62" y2="71.12" width="0.1524" layer="91"/>
<pinref part="R13" gate="G$1" pin="A"/>
<wire x1="134.62" y1="71.12" x2="134.62" y2="25.4" width="0.1524" layer="91"/>
<junction x="139.7" y="71.12"/>
</segment>
</net>
<net name="N$27" class="0">
<segment>
<pinref part="IC1" gate="A" pin="-IN"/>
<wire x1="142.24" y1="48.26" x2="139.7" y2="48.26" width="0.1524" layer="91"/>
<pinref part="R9" gate="G$1" pin="2"/>
<wire x1="139.7" y1="48.26" x2="139.7" y2="45.72" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$34" class="0">
<segment>
<pinref part="T5" gate="G$1" pin="B"/>
<wire x1="132.08" y1="40.64" x2="157.48" y2="40.64" width="0.1524" layer="91"/>
<pinref part="IC1" gate="A" pin="OUT"/>
<wire x1="157.48" y1="40.64" x2="157.48" y2="50.8" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$35" class="0">
<segment>
<wire x1="119.38" y1="15.24" x2="119.38" y2="33.02" width="0.1524" layer="91"/>
<pinref part="R12" gate="G$1" pin="2"/>
<wire x1="119.38" y1="33.02" x2="139.7" y2="33.02" width="0.1524" layer="91"/>
<pinref part="R9" gate="G$1" pin="1"/>
<wire x1="139.7" y1="33.02" x2="139.7" y2="35.56" width="0.1524" layer="91"/>
<junction x="119.38" y="33.02"/>
</segment>
</net>
<net name="N$17" class="0">
<segment>
<pinref part="IC2" gate="A1" pin="VI"/>
<pinref part="C3" gate="G$1" pin="1"/>
<wire x1="205.74" y1="93.98" x2="210.82" y2="93.98" width="0.1524" layer="91"/>
<wire x1="210.82" y1="93.98" x2="218.44" y2="93.98" width="0.1524" layer="91"/>
<pinref part="F2" gate="1" pin="1"/>
<junction x="218.44" y="93.98"/>
<wire x1="218.44" y1="93.98" x2="223.52" y2="93.98" width="0.1524" layer="91"/>
<junction x="210.82" y="93.98"/>
</segment>
</net>
<net name="N$29" class="0">
<segment>
<pinref part="F2" gate="1" pin="2"/>
<pinref part="DC.IN.+" gate="1" pin="MP"/>
<wire x1="233.68" y1="93.98" x2="236.22" y2="93.98" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$33" class="0">
<segment>
<pinref part="IC2" gate="A1" pin="ADJ"/>
<wire x1="195.58" y1="86.36" x2="195.58" y2="81.28" width="0.1524" layer="91"/>
<wire x1="195.58" y1="81.28" x2="213.36" y2="81.28" width="0.1524" layer="91"/>
<pinref part="T6" gate="G$1" pin="C"/>
<wire x1="213.36" y1="81.28" x2="213.36" y2="78.74" width="0.1524" layer="91"/>
<pinref part="R16" gate="G$1" pin="2"/>
<pinref part="R17" gate="G$1" pin="1"/>
<wire x1="170.18" y1="83.82" x2="170.18" y2="81.28" width="0.1524" layer="91"/>
<wire x1="170.18" y1="81.28" x2="170.18" y2="78.74" width="0.1524" layer="91"/>
<wire x1="195.58" y1="81.28" x2="170.18" y2="81.28" width="0.1524" layer="91"/>
<junction x="195.58" y="81.28"/>
<junction x="170.18" y="81.28"/>
</segment>
</net>
<net name="1000UF" class="0">
<segment>
<pinref part="R18" gate="G$1" pin="1"/>
<pinref part="T6" gate="G$1" pin="E"/>
<wire x1="205.74" y1="58.42" x2="213.36" y2="58.42" width="0.1524" layer="91"/>
<wire x1="213.36" y1="58.42" x2="213.36" y2="68.58" width="0.1524" layer="91"/>
<wire x1="213.36" y1="58.42" x2="218.44" y2="58.42" width="0.1524" layer="91"/>
<pinref part="DC.IN.-" gate="1" pin="MP"/>
<wire x1="236.22" y1="86.36" x2="218.44" y2="86.36" width="0.1524" layer="91"/>
<pinref part="C3" gate="G$1" pin="2"/>
<wire x1="218.44" y1="86.36" x2="210.82" y2="86.36" width="0.1524" layer="91"/>
<wire x1="218.44" y1="58.42" x2="218.44" y2="86.36" width="0.1524" layer="91"/>
<junction x="213.36" y="58.42"/>
<junction x="218.44" y="86.36"/>
<label x="220.98" y="86.36" size="1.778" layer="95"/>
</segment>
</net>
<net name="N$38" class="0">
<segment>
<pinref part="IC2" gate="A1" pin="VO"/>
<pinref part="R16" gate="G$1" pin="1"/>
<wire x1="185.42" y1="93.98" x2="180.34" y2="93.98" width="0.1524" layer="91"/>
<pinref part="C4" gate="G$1" pin="1"/>
<wire x1="180.34" y1="93.98" x2="170.18" y2="93.98" width="0.1524" layer="91"/>
<junction x="180.34" y="93.98"/>
<wire x1="170.18" y1="93.98" x2="157.48" y2="93.98" width="0.1524" layer="91"/>
<pinref part="D4" gate="1" pin="A"/>
<wire x1="157.48" y1="93.98" x2="157.48" y2="96.52" width="0.1524" layer="91"/>
<wire x1="157.48" y1="96.52" x2="152.4" y2="96.52" width="0.1524" layer="91"/>
<junction x="170.18" y="93.98"/>
</segment>
</net>
<net name="N$39" class="0">
<segment>
<pinref part="T6" gate="G$1" pin="B"/>
<pinref part="R15" gate="G$1" pin="1"/>
<wire x1="208.28" y1="73.66" x2="200.66" y2="73.66" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$41" class="0">
<segment>
<pinref part="R17" gate="G$1" pin="2"/>
<pinref part="R14" gate="G$1" pin="A"/>
<wire x1="170.18" y1="68.58" x2="170.18" y2="63.5" width="0.1524" layer="91"/>
</segment>
</net>
</nets>
</sheet>
<sheet>
<plain>
</plain>
<instances>
</instances>
<busses>
</busses>
<nets>
</nets>
</sheet>
</sheets>
</schematic>
</drawing>
</eagle>
