<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.5.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.005" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.025" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<wire x1="89.027" y1="50.927" x2="4.572" y2="50.927" width="0" layer="20" style="shortdash"/>
<wire x1="4.572" y1="50.927" x2="4.572" y2="78.105" width="0" layer="20" style="shortdash"/>
<wire x1="4.572" y1="78.105" x2="96.774" y2="78.105" width="0" layer="20" style="shortdash"/>
<wire x1="97.917" y1="78.105" x2="125.73" y2="78.105" width="0" layer="20" style="shortdash"/>
<wire x1="125.73" y1="78.105" x2="125.73" y2="50.927" width="0" layer="20" style="shortdash"/>
<wire x1="125.73" y1="50.927" x2="90.297" y2="50.927" width="0" layer="20" style="shortdash"/>
</plain>
<libraries>
<library name="pot">
<packages>
<package name="CA14H">
<description>&lt;b&gt;POTENTIOMETER&lt;/b&gt;&lt;p&gt;
distributor Schukat</description>
<wire x1="7.112" y1="5.588" x2="7.112" y2="0.127" width="0.1524" layer="21"/>
<wire x1="6.477" y1="0" x2="3.683" y2="0" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="0" x2="-6.985" y2="0" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0" x2="-2.54" y2="0" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-0.381" x2="-2.413" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-0.381" x2="2.54" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.254" x2="2.54" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-0.381" x2="-2.54" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.254" x2="-2.54" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0" x2="-6.477" y2="0" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-0.254" x2="2.54" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="5.715" x2="-3.683" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="5.715" x2="-6.985" y2="5.715" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="6.096" x2="-3.683" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="6.096" x2="1.016" y2="6.096" width="0.1524" layer="51"/>
<wire x1="3.683" y1="5.969" x2="3.556" y2="6.096" width="0.1524" layer="21"/>
<wire x1="3.683" y1="5.969" x2="3.683" y2="5.715" width="0.1524" layer="21"/>
<wire x1="1.397" y1="5.715" x2="-1.397" y2="5.715" width="0.1524" layer="51"/>
<wire x1="1.143" y1="5.969" x2="-1.143" y2="5.969" width="0.1524" layer="51"/>
<wire x1="7.112" y1="0.127" x2="6.985" y2="0" width="0.1524" layer="21"/>
<wire x1="6.985" y1="0" x2="6.477" y2="0" width="0.1524" layer="21"/>
<wire x1="7.112" y1="5.588" x2="6.985" y2="5.715" width="0.1524" layer="21"/>
<wire x1="6.985" y1="5.715" x2="3.683" y2="5.715" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="5.715" x2="-7.112" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="0" x2="-7.112" y2="0.127" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="0.127" x2="-7.112" y2="5.588" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0" x2="3.683" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0" x2="-3.683" y2="0" width="0.1524" layer="21"/>
<wire x1="1.397" y1="5.715" x2="3.683" y2="5.715" width="0.1524" layer="21"/>
<wire x1="3.683" y1="5.969" x2="1.143" y2="5.969" width="0.1524" layer="21"/>
<wire x1="1.016" y1="6.096" x2="3.556" y2="6.096" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="6.096" x2="-3.556" y2="6.096" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="5.969" x2="-1.143" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="5.715" x2="-3.683" y2="5.715" width="0.1524" layer="21"/>
<pad name="A" x="-5.08" y="0" drill="1.3208" shape="long"/>
<pad name="S" x="0" y="5.08" drill="1.3208" shape="long"/>
<pad name="E" x="5.08" y="0" drill="1.3208" shape="long"/>
<text x="-2.54" y="6.604" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.191" y="1.905" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="B25P">
Beckman Helitrim 25</description>
<wire x1="3.175" y1="3.429" x2="-3.175" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-3.429" x2="-2.54" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="3.175" y1="3.429" x2="3.429" y2="3.175" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-3.429" x2="3.429" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-3.175" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-1.524" x2="3.429" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-0.254" x2="3.429" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-3.429" x2="-3.429" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="3.429" x2="-3.429" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="3.175" x2="-3.429" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-0.254" x2="-3.429" y2="-1.524" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="-1.524" x2="-3.429" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="0.762" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0" x2="1.524" y2="0.762" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.762" x2="0.762" y2="0.762" width="0.1524" layer="21"/>
<wire x1="0.762" y1="0.762" x2="0.381" y2="1.143" width="0.1524" layer="21"/>
<wire x1="0.381" y1="1.143" x2="0.381" y2="1.524" width="0.1524" layer="21"/>
<wire x1="0.381" y1="2.286" x2="-0.381" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="2.286" x2="-0.381" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="1.143" x2="-0.762" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0.762" x2="-1.524" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.762" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-0.381" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-0.381" x2="-0.381" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-1.524" x2="0.381" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-1.524" x2="0.381" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-0.381" x2="0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-1.397" x2="-2.032" y2="-1.651" width="0.3048" layer="51"/>
<wire x1="1.778" y1="-1.397" x2="2.032" y2="-1.651" width="0.3048" layer="51"/>
<wire x1="2.3876" y1="0.381" x2="2.7686" y2="0.381" width="0.3048" layer="21"/>
<wire x1="1.778" y1="2.032" x2="2.032" y2="2.286" width="0.3048" layer="21"/>
<wire x1="0" y1="2.7178" x2="0" y2="3.0988" width="0.3048" layer="21"/>
<wire x1="-1.905" y1="2.032" x2="-2.159" y2="2.286" width="0.3048" layer="21"/>
<wire x1="-2.3876" y1="0.381" x2="-2.7686" y2="0.381" width="0.3048" layer="21"/>
<wire x1="0.381" y1="1.524" x2="-0.381" y2="1.524" width="0.1524" layer="21"/>
<wire x1="0.381" y1="1.524" x2="0.381" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="1.524" x2="-0.381" y2="1.143" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-0.762" x2="-0.381" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-0.762" x2="0.381" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-0.762" x2="-0.381" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-3.048" x2="-2.54" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-3.048" x2="1.016" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="2.54" y1="-3.429" x2="2.54" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-3.429" x2="-0.635" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-3.429" x2="0.635" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="0.635" y1="-3.429" x2="2.54" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-3.429" x2="3.175" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-3.048" x2="-1.016" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-3.048" x2="2.54" y2="-3.048" width="0.1524" layer="21"/>
<circle x="0" y="0.381" radius="2.032" width="0.1524" layer="51"/>
<pad name="A" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="E" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="S" x="0" y="2.54" drill="0.8128" shape="octagon"/>
<text x="-3.175" y="3.81" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.1496" y="-5.08" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.413" y="-2.794" size="0.9906" layer="21" ratio="12">3</text>
<text x="-2.921" y="-2.794" size="0.9906" layer="21" ratio="12">1</text>
</package>
</packages>
</library>
<library name="40xx">
<packages>
<package name="SO08">
<description>&lt;b&gt;Small Outline package 8&lt;/b&gt; 150 mil</description>
<wire x1="2.159" y1="1.9558" x2="-2.159" y2="1.9558" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.9558" x2="2.54" y2="-1.5748" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.54" y1="1.5748" x2="-2.159" y2="1.9558" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="1.9558" x2="2.54" y2="1.5748" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-1.5748" x2="-2.159" y2="-1.9558" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.159" y1="-1.9558" x2="2.159" y2="-1.9558" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.5748" x2="2.54" y2="1.5748" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.5748" x2="-2.54" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.508" x2="-2.54" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.508" x2="-2.54" y2="-1.5748" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.508" x2="-2.54" y2="-0.508" width="0.1524" layer="21" curve="-180"/>
<wire x1="-2.54" y1="-1.6002" x2="2.54" y2="-1.6002" width="0.0508" layer="21"/>
<smd name="1" x="-1.905" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="8" x="-1.905" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="2" x="-0.635" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="3" x="0.635" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="7" x="-0.635" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="6" x="0.635" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="4" x="1.905" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="5" x="1.905" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<text x="4.445" y="-2.54" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-3.175" y="-1.905" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<rectangle x1="1.651" y1="1.9558" x2="2.159" y2="3.0988" layer="51"/>
<rectangle x1="-2.159" y1="-3.0988" x2="-1.651" y2="-1.9558" layer="51"/>
<rectangle x1="-0.889" y1="-3.0988" x2="-0.381" y2="-1.9558" layer="51"/>
<rectangle x1="0.381" y1="-3.0734" x2="0.889" y2="-1.9304" layer="51"/>
<rectangle x1="1.651" y1="-3.0988" x2="2.159" y2="-1.9558" layer="51"/>
<rectangle x1="0.381" y1="1.9558" x2="0.889" y2="3.0988" layer="51"/>
<rectangle x1="-0.889" y1="1.9558" x2="-0.381" y2="3.0988" layer="51"/>
<rectangle x1="-2.159" y1="1.9558" x2="-1.651" y2="3.0988" layer="51"/>
</package>
</packages>
</library>
<library name="transistor-npn">
<packages>
<package name="TO92-BCE">
<description>&lt;b&gt;TO-92&lt;/b&gt;&lt;p&gt;
grid 5.08 mm</description>
<wire x1="-2.095" y1="-1.651" x2="2.095" y2="-1.651" width="0.127" layer="21"/>
<wire x1="-2.413" y1="1.1359" x2="2.413" y2="1.1359" width="0.127" layer="21" curve="-129.583345"/>
<wire x1="1.136" y1="-0.127" x2="-1.136" y2="-0.127" width="0.127" layer="51"/>
<wire x1="-2.413" y1="1.1359" x2="-2.664" y2="-0.127" width="0.127" layer="51" curve="27.937554"/>
<wire x1="-2.664" y1="-0.127" x2="-2.413" y2="-1.1359" width="0.127" layer="51" curve="22.478763"/>
<wire x1="-1.404" y1="-0.127" x2="-2.664" y2="-0.127" width="0.127" layer="51"/>
<wire x1="-2.4135" y1="-1.1359" x2="-2.095" y2="-1.651" width="0.127" layer="21" curve="13.038528"/>
<wire x1="-1.136" y1="-0.127" x2="-1.404" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.413" y1="-1.1359" x2="2.664" y2="-0.127" width="0.127" layer="51" curve="22.478763"/>
<wire x1="2.664" y1="-0.127" x2="2.413" y2="1.1359" width="0.127" layer="51" curve="27.937554"/>
<wire x1="2.664" y1="-0.127" x2="1.404" y2="-0.127" width="0.127" layer="51"/>
<wire x1="1.404" y1="-0.127" x2="1.136" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.095" y1="-1.651" x2="2.4247" y2="-1.1118" width="0.127" layer="21" curve="13.609443"/>
<pad name="C" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="-2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="B" x="2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.54" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TO92-">
<description>&lt;b&gt;TO 92 pad in line&lt;/b&gt;</description>
<wire x1="-2.0945" y1="-1.651" x2="2.0945" y2="-1.651" width="0.127" layer="21"/>
<wire x1="-2.413" y1="1.1359" x2="2.413" y2="1.1359" width="0.127" layer="21" curve="-129.583"/>
<wire x1="1.1359" y1="-0.127" x2="-1.1359" y2="-0.127" width="0.127" layer="51"/>
<wire x1="-2.413" y1="1.1359" x2="-2.664" y2="-0.127" width="0.127" layer="51" curve="27.9376"/>
<wire x1="-2.664" y1="-0.127" x2="-2.413" y2="-1.1359" width="0.127" layer="51" curve="22.4788"/>
<wire x1="-1.4041" y1="-0.127" x2="-2.664" y2="-0.127" width="0.127" layer="51"/>
<wire x1="-2.413" y1="-1.1359" x2="-2.0945" y2="-1.651" width="0.127" layer="21" curve="13.0385"/>
<wire x1="-1.1359" y1="-0.127" x2="-1.4041" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.413" y1="-1.1359" x2="2.664" y2="-0.127" width="0.127" layer="51" curve="22.4788"/>
<wire x1="2.664" y1="-0.127" x2="2.413" y2="1.1359" width="0.127" layer="51" curve="27.9376"/>
<wire x1="2.664" y1="-0.127" x2="1.4041" y2="-0.127" width="0.127" layer="51"/>
<wire x1="1.4041" y1="-0.127" x2="1.1359" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.0945" y1="-1.651" x2="2.4242" y2="-1.1118" width="0.127" layer="21" curve="13.6094"/>
<pad name="3" x="-2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="1" x="2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
</package>
</packages>
</library>
<library name="relay">
<packages>
<package name="G5LE">
<description>&lt;b&gt;RELAY&lt;/b&gt;&lt;p&gt;
1 x switch, 10 A/120 V AC, 8 A/30 V ADC, Omron</description>
<wire x1="-12.065" y1="8.255" x2="10.541" y2="8.255" width="0.1524" layer="21"/>
<wire x1="10.541" y1="-8.255" x2="10.541" y2="8.255" width="0.1524" layer="21"/>
<wire x1="10.541" y1="-8.255" x2="-12.065" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="8.255" x2="-12.065" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="5.969" x2="-4.445" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="5.969" x2="-4.445" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.635" x2="-5.715" y2="0.635" width="0.254" layer="21"/>
<wire x1="-5.715" y1="0.635" x2="-5.715" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-0.635" x2="-3.175" y2="0.635" width="0.254" layer="21"/>
<wire x1="-3.175" y1="0.635" x2="-4.445" y2="0.635" width="0.254" layer="21"/>
<wire x1="-5.715" y1="-0.635" x2="-4.445" y2="-0.635" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-0.635" x2="-4.445" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-0.635" x2="-3.175" y2="-0.635" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-5.969" x2="-5.08" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-0.635" x2="-3.175" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0" x2="4.064" y2="0" width="0.1524" layer="21"/>
<wire x1="4.064" y1="0" x2="4.699" y2="0.635" width="0.254" layer="21"/>
<wire x1="4.699" y1="3.7338" x2="4.699" y2="0.635" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-0.635" x2="4.699" y2="-3.7592" width="0.1524" layer="21"/>
<wire x1="4.699" y1="0.635" x2="5.0292" y2="0.9398" width="0.254" layer="21"/>
<wire x1="-7.366" y1="0" x2="-6.35" y2="0" width="0.1524" layer="21"/>
<pad name="P" x="-9.525" y="0" drill="1.3208" shape="long"/>
<pad name="1" x="-7.493" y="-5.969" drill="1.3208" shape="long"/>
<pad name="2" x="-7.493" y="5.969" drill="1.3208" shape="long"/>
<pad name="O" x="4.699" y="5.969" drill="1.3208" shape="long"/>
<pad name="S" x="4.699" y="-5.969" drill="1.3208" shape="long"/>
<text x="12.827" y="-8.255" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="9.525" y="-7.62" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="rcl">
<packages>
<package name="0207/10">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
</package>
<package name="C050-030X075">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 5 mm, outline 3 x 7.5 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.27" x2="-3.683" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.524" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.27" x2="3.683" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="3.683" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.524" x2="3.683" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.27" x2="-3.429" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.27" x2="-3.429" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.556" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C0805K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 0805 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 2012</description>
<wire x1="-0.925" y1="0.6" x2="0.925" y2="0.6" width="0.1016" layer="51"/>
<wire x1="0.925" y1="-0.6" x2="-0.925" y2="-0.6" width="0.1016" layer="51"/>
<smd name="1" x="-1" y="0" dx="1.3" dy="1.6" layer="1"/>
<smd name="2" x="1" y="0" dx="1.3" dy="1.6" layer="1"/>
<text x="-1" y="0.875" size="1.016" layer="25">&gt;NAME</text>
<text x="-1" y="-1.9" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1" y1="-0.65" x2="-0.5" y2="0.65" layer="51"/>
<rectangle x1="0.5" y1="-0.65" x2="1" y2="0.65" layer="51"/>
</package>
<package name="E3,5-8">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 3.5 mm, diameter 8 mm</description>
<wire x1="-3.429" y1="1.143" x2="-2.667" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="0.762" x2="-3.048" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="4.064" width="0.1524" layer="21"/>
<pad name="-" x="1.778" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.778" y="0" drill="0.8128" diameter="1.6002"/>
<text x="3.302" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="E2,5-6">
grid 2.54 mm, diameter 6 mm</description>
<wire x1="-2.032" y1="1.27" x2="-1.651" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0.889" x2="-1.651" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.27" x2="-1.27" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.27" x2="-1.651" y2="1.651" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.794" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<text x="2.667" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.667" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-025X050">
grid 2.5 mm, outline 2.5 x 5 mm</description>
<wire x1="-2.159" y1="1.27" x2="2.159" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.27" x2="-2.159" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.27" x2="2.413" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.016" x2="-2.159" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.27" x2="2.413" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.016" x2="-2.159" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="0" x2="0.381" y2="0" width="0.1524" layer="51"/>
<wire x1="0.381" y1="0" x2="0.254" y2="0" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="0.762" width="0.254" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="-0.254" y2="0" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.286" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-025X075">
grid 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="-3.683" y1="1.016" x2="-3.683" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.27" x2="3.429" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.016" x2="3.683" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="-3.429" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="3.683" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.27" x2="3.683" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.016" x2="-3.429" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.016" x2="-3.429" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E3,5-10">
grid 3.5 mm, diameter 10 mm</description>
<circle x="0" y="0" radius="5.08" width="0.1524" layer="21"/>
<text x="4.064" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="led">
<packages>
<package name="LED5MM">
<description>&lt;B&gt;LED&lt;/B&gt;&lt;p&gt;
5 mm, round</description>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="1.905" width="0.2032" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="1.905" width="0.254" layer="21" curve="-286.260205"/>
<wire x1="-1.143" y1="0" x2="0" y2="1.143" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-1.143" x2="1.143" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="-1.651" y1="0" x2="0" y2="1.651" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-1.651" x2="1.651" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="-2.159" y1="0" x2="0" y2="2.159" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-2.159" x2="2.159" y2="0" width="0.1524" layer="51" curve="90"/>
<circle x="0" y="0" radius="2.54" width="0.1524" layer="21"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="K" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="3.175" y="0.5334" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.2004" y="-1.8034" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="diode">
<packages>
<package name="D-5">
<description>&lt;b&gt;DIODE&lt;/b&gt;</description>
<wire x1="1.397" y1="0.889" x2="-1.397" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="-0.889" x2="1.397" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="0.889" x2="-1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="1.397" y1="-0.889" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="0" x2="-1.397" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.397" y1="0" x2="1.397" y2="0.889" width="0.1524" layer="21"/>
<pad name="A" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="C" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-1.905" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.016" y1="-0.889" x2="-0.508" y2="0.889" layer="21"/>
</package>
<package name="C221B1AS">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
2-lead molded, vertical</description>
<wire x1="5.207" y1="-1.143" x2="5.08" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-4.826" x2="5.08" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-4.826" x2="-4.826" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-4.572" x2="-4.826" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-4.572" x2="-5.207" y2="-1.143" width="0.1524" layer="21"/>
<pad name="C" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="A" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-5.08" y="-6.4262" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-8.001" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.334" y1="-1.397" x2="-3.429" y2="-0.889" layer="21"/>
<rectangle x1="-3.429" y1="-1.397" x2="-1.651" y2="-0.889" layer="51"/>
<rectangle x1="3.429" y1="-1.397" x2="5.334" y2="-0.889" layer="21"/>
<rectangle x1="1.651" y1="-1.397" x2="3.429" y2="-0.889" layer="51"/>
<rectangle x1="-1.651" y1="-1.397" x2="1.651" y2="-0.889" layer="21"/>
<rectangle x1="-5.334" y1="-0.889" x2="5.334" y2="0" layer="21"/>
</package>
<package name="D-7.5">
<wire x1="1.905" y1="0.889" x2="-1.905" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-0.889" x2="1.905" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0" x2="-2.794" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0.889" x2="-1.905" y2="0" width="0.1524" layer="21"/>
<wire x1="2.794" y1="0" x2="1.905" y2="0" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-0.889" x2="1.905" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0" x2="-1.905" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.905" y1="0" x2="1.905" y2="0.889" width="0.1524" layer="21"/>
<pad name="A" x="3.81" y="0" drill="0.8128" shape="long"/>
<pad name="C" x="-3.81" y="0" drill="0.8128" shape="long"/>
<rectangle x1="-1.27" y1="-0.889" x2="-0.762" y2="0.889" layer="21"/>
</package>
</packages>
</library>
<library name="con-ptr500">
<description>&lt;b&gt;PTR Connectors&lt;/b&gt;&lt;p&gt;
Aug. 2004 / PTR Meßtechnik:&lt;br&gt;
Die Bezeichnung der Serie AK505 wurde geändert.&lt;br&gt;
Es handelt sich hierbei um AK500 in horizontaler Ausführung.&lt;p&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=LEFT&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Alte Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Neue Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2DS,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2DS-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AKZ505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AKZ500/2-5.08-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TABLE&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="AK500/2">
<description>&lt;b&gt;CONNECTOR&lt;/b&gt;</description>
<wire x1="-5.08" y1="-3.556" x2="-5.08" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.937" x2="-5.08" y2="3.937" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.937" x2="5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.556" x2="5.08" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.048" x2="-5.588" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.048" x2="-5.08" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="3.175" x2="-5.588" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="2.032" x2="-5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.159" x2="-5.08" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.159" x2="5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.159" x2="5.08" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.159" x2="5.08" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.159" x2="-5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.159" x2="5.08" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="1.4986" y1="-1.397" x2="3.9116" y2="1.016" width="0.1524" layer="51"/>
<wire x1="1.1176" y1="-1.016" x2="3.5306" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-3.9116" y1="-1.016" x2="-1.4986" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-3.5306" y1="-1.397" x2="-1.1176" y2="1.016" width="0.1524" layer="51"/>
<wire x1="1.4986" y1="-1.016" x2="3.5306" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-3.5306" y1="-1.016" x2="-1.4986" y2="1.016" width="0.6096" layer="51"/>
<wire x1="1.1176" y1="-1.016" x2="1.4986" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="3.5306" y1="1.397" x2="3.9116" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-3.9116" y1="-1.016" x2="-3.5306" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-1.4986" y1="1.397" x2="-1.1176" y2="1.016" width="0.1524" layer="51"/>
<circle x="2.5146" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="-2.5146" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="2.5146" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="-2.5146" y="0" radius="1.778" width="0.1524" layer="51"/>
<pad name="1" x="-2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-5.08" y="4.445" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="2.54" size="0.9906" layer="21" ratio="12">1</text>
<text x="0.635" y="2.54" size="0.9906" layer="21" ratio="12">2</text>
<rectangle x1="-0.381" y1="-1.905" x2="0.381" y2="1.905" layer="21"/>
</package>
<package name="AK500/3">
<wire x1="-7.5184" y1="-3.556" x2="-7.5184" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="7.5184" y1="3.937" x2="-7.5184" y2="3.937" width="0.1524" layer="21"/>
<wire x1="7.5184" y1="3.937" x2="7.5184" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="-3.556" x2="7.5184" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="3.048" x2="-8.0264" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="3.048" x2="-7.5184" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.0264" y1="3.175" x2="-8.0264" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-8.0264" y1="2.032" x2="-7.5184" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="2.159" x2="-7.5184" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="2.159" x2="7.5184" y2="2.159" width="0.1524" layer="21"/>
<wire x1="7.5184" y1="2.159" x2="7.5184" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="-2.159" x2="7.5184" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="-2.159" x2="-7.5184" y2="2.159" width="0.1524" layer="21"/>
<wire x1="7.5184" y1="-2.159" x2="7.5184" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-1.397" x2="1.397" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-1.397" y1="-1.016" x2="1.016" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-6.4008" y1="-1.016" x2="-3.9878" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-6.0198" y1="-1.397" x2="-3.6068" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-1.016" y1="-1.016" x2="1.016" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-6.0198" y1="-1.016" x2="-3.9878" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-1.397" y1="-1.016" x2="-1.016" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="1.016" y1="1.397" x2="1.397" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-6.4008" y1="-1.016" x2="-6.0198" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-3.9878" y1="1.397" x2="-3.6068" y2="1.016" width="0.1524" layer="51"/>
<wire x1="3.9878" y1="-1.016" x2="6.0198" y2="1.016" width="0.6096" layer="51"/>
<wire x1="3.9878" y1="-1.397" x2="6.4008" y2="1.016" width="0.1524" layer="51"/>
<wire x1="3.6068" y1="-1.016" x2="6.0198" y2="1.397" width="0.1524" layer="51"/>
<wire x1="3.6068" y1="-1.016" x2="3.9878" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="6.0198" y1="1.397" x2="6.4008" y2="1.016" width="0.1524" layer="51"/>
<circle x="0" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="-5.0038" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="-5.0038" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="5.0038" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="5.0038" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<pad name="1" x="-5.0038" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="3" x="5.0038" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-7.5946" y="4.445" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.5946" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.731" y="2.54" size="0.9906" layer="21" ratio="12">1</text>
<text x="-1.905" y="2.54" size="0.9906" layer="21" ratio="12">2</text>
<text x="3.175" y="2.54" size="0.9906" layer="21" ratio="12">3</text>
<rectangle x1="-2.8956" y1="-1.905" x2="-2.1336" y2="1.905" layer="21"/>
<rectangle x1="2.1336" y1="-1.905" x2="2.8956" y2="1.905" layer="21"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default *">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="100mil"/>
<param name="rlMaxPadTop" value="25mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="100mil"/>
<param name="rlMaxPadBottom" value="25mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
</autorouter>
<elements>
<element name="E$4" library="pot" package="CA14H" value="" x="67.183" y="63.627" rot="R270"/>
<element name="E$1" library="40xx" package="SO08" value="LM358" x="81.153" y="64.262" rot="MR270"/>
<element name="E$2" library="transistor-npn" package="TO92-BCE" value="" x="89.408" y="60.706" rot="R90"/>
<element name="E$5" library="relay" package="G5LE" value="" x="114.3" y="60.833"/>
<element name="E$3" library="rcl" package="0207/10" value="2,2K" x="72.263" y="54.356"/>
<element name="E$6" library="rcl" package="C050-030X075" value="" x="80.264" y="57.912" rot="R90"/>
<element name="E$7" library="rcl" package="C0805K" value="470nF" x="80.264" y="57.912" rot="MR90"/>
<element name="E$8" library="rcl" package="0207/10" value="330K" x="75.438" y="68.58" rot="R90"/>
<element name="E$9" library="rcl" package="C0805K" value="470nF" x="92.964" y="67.183" rot="MR180"/>
<element name="E$10" library="rcl" package="C050-030X075" value="" x="79.121" y="71.12" rot="R90"/>
<element name="E$11" library="rcl" package="C050-030X075" value="" x="92.964" y="67.183" rot="R180"/>
<element name="E$12" library="rcl" package="C0805K" value="470nF" x="79.121" y="71.12" rot="MR90"/>
<element name="E$13" library="rcl" package="0207/10" value="1K" x="83.947" y="63.5" rot="R90"/>
<element name="E$14" library="led" package="LED5MM" value="" x="86.614" y="53.848" rot="R270"/>
<element name="E$15" library="rcl" package="0207/10" value="150K" x="67.437" y="73.66" rot="R180"/>
<element name="E$17" library="rcl" package="0207/10" value="1K" x="62.357" y="65.913" rot="R270"/>
<element name="E$18" library="rcl" package="0207/10" value="1K" x="87.503" y="71.12" rot="R180"/>
<element name="E$19" library="rcl" package="0207/10" value="470R" x="96.139" y="53.721" rot="R180"/>
<element name="E$20" library="transistor-npn" package="TO92-BCE" value="" x="95.123" y="60.706" rot="R270"/>
<element name="E$23" library="diode" package="D-5" value="" x="100.076" y="60.833" rot="R90"/>
<element name="E$24" library="con-ptr500" package="AK500/2" value="" x="101.981" y="73.406"/>
<element name="E$25" library="con-ptr500" package="AK500/3" value="" x="117.475" y="73.279"/>
<element name="E$16" library="pot" package="B25P" value="" x="67.564" y="63.754" rot="R270"/>
<element name="E$22" library="rcl" package="E3,5-8" value="" x="50.673" y="56.134" rot="R90"/>
<element name="E$26" library="diode" package="C221B1AS" value="" x="60.706" y="52.197" rot="R180"/>
<element name="E$28" library="diode" package="D-5" value="" x="44.45" y="73.914" rot="R270"/>
<element name="E$29" library="rcl" package="0207/10" value="" x="44.45" y="62.357" rot="R90"/>
<element name="E$30" library="diode" package="D-7.5" value="" x="54.229" y="61.976"/>
<element name="E$21" library="diode" package="D-5" value="" x="41.529" y="67.818" rot="R90"/>
<element name="E$31" library="rcl" package="E2,5-6" value="" x="40.132" y="74.422" rot="R90"/>
<element name="E$32" library="diode" package="D-7.5" value="" x="41.529" y="57.785" rot="R90"/>
<element name="E$33" library="rcl" package="C025-025X050" value="" x="44.45" y="54.102" rot="R90"/>
<element name="E$34" library="transistor-npn" package="TO92-" value="" x="29.845" y="57.785" rot="R180"/>
<element name="E$35" library="transistor-npn" package="TO92-" value="" x="29.718" y="74.041" rot="R270"/>
<element name="E$36" library="rcl" package="C050-025X075" value="" x="35.433" y="74.295" rot="R90"/>
<element name="E$37" library="rcl" package="0207/10" value="" x="38.354" y="65.532" rot="R90"/>
<element name="E$38" library="rcl" package="0207/10" value="" x="33.909" y="52.705" rot="R180"/>
<element name="E$39" library="rcl" package="0207/10" value="" x="35.56" y="60.833" rot="R90"/>
<element name="E$40" library="diode" package="D-5" value="" x="31.75" y="65.913" rot="R270"/>
<element name="E$41" library="rcl" package="E3,5-10" value="" x="20.32" y="56.388" rot="R180"/>
<element name="E$42" library="diode" package="D-7.5" value="" x="23.876" y="66.04" rot="R180"/>
<element name="E$43" library="diode" package="D-7.5" value="" x="23.749" y="68.834" rot="R180"/>
<element name="E$44" library="diode" package="D-7.5" value="" x="14.224" y="64.389" rot="R270"/>
<element name="E$45" library="diode" package="D-7.5" value="" x="11.176" y="60.325" rot="R270"/>
<element name="E$46" library="rcl" package="0207/10" value="" x="8.128" y="67.183" rot="R90"/>
<element name="E$47" library="rcl" package="0207/10" value="" x="24.13" y="63.246" rot="R180"/>
<element name="E$27" library="con-ptr500" package="AK500/2" value="" x="21.844" y="73.66"/>
</elements>
<signals>
<signal name="S$2">
<wire x1="78.486" y1="64.897" x2="80.264" y2="64.897" width="0.8128" layer="16"/>
<wire x1="80.264" y1="64.897" x2="80.264" y2="61.087" width="0.8128" layer="16"/>
</signal>
<signal name="S$3">
<wire x1="80.264" y1="60.833" x2="80.264" y2="58.801" width="0.8128" layer="16"/>
</signal>
<signal name="S$5">
<contactref element="E$4" pad="S"/>
<wire x1="77.724" y1="63.627" x2="72.263" y2="63.627" width="0.8128" layer="16"/>
</signal>
<signal name="S$7">
<contactref element="E$10" pad="2"/>
<contactref element="E$8" pad="2"/>
<wire x1="79.121" y1="73.66" x2="75.438" y2="73.66" width="0.8128" layer="16"/>
</signal>
<signal name="S$8">
<contactref element="E$14" pad="A"/>
<wire x1="86.614" y1="55.118" x2="84.836" y2="55.118" width="0.8128" layer="16"/>
<wire x1="84.836" y1="55.118" x2="83.947" y2="56.007" width="0.8128" layer="16"/>
<wire x1="83.947" y1="56.007" x2="83.947" y2="58.293" width="0.8128" layer="16"/>
</signal>
<signal name="S$9">
<wire x1="72.644" y1="73.66" x2="72.644" y2="71.247" width="0.8128" layer="16"/>
<wire x1="72.644" y1="71.247" x2="69.977" y2="68.58" width="0.8128" layer="16"/>
<wire x1="69.977" y1="68.58" x2="67.564" y2="68.58" width="0.8128" layer="16"/>
</signal>
<signal name="S$6">
<contactref element="E$4" pad="E"/>
<wire x1="67.183" y1="54.229" x2="67.183" y2="58.547" width="0.8128" layer="16"/>
</signal>
<signal name="S$10">
<contactref element="E$15" pad="2"/>
<wire x1="62.357" y1="73.66" x2="62.357" y2="71.12" width="0.8128" layer="16"/>
</signal>
<signal name="S$1">
<contactref element="E$13" pad="2"/>
<contactref element="E$10" pad="1"/>
<wire x1="79.121" y1="68.58" x2="82.169" y2="68.58" width="0.8128" layer="16"/>
<wire x1="82.169" y1="68.58" x2="83.947" y2="68.58" width="0.8128" layer="16"/>
<wire x1="77.089" y1="68.58" x2="79.121" y2="68.58" width="0.8128" layer="16"/>
<wire x1="75.946" y1="67.437" x2="77.089" y2="68.58" width="0.8128" layer="16"/>
<wire x1="77.47" y1="66.167" x2="77.216" y2="66.167" width="0.8128" layer="16"/>
<wire x1="77.216" y1="66.167" x2="75.946" y2="67.437" width="0.8128" layer="16"/>
<wire x1="82.296" y1="71.12" x2="82.296" y2="68.707" width="0.8128" layer="16"/>
<wire x1="82.296" y1="68.707" x2="82.169" y2="68.58" width="0.8128" layer="16"/>
</signal>
<signal name="S$13">
<wire x1="78.359" y1="64.897" x2="76.581" y2="64.897" width="0.8128" layer="16"/>
<wire x1="76.581" y1="64.897" x2="75.819" y2="65.659" width="0.8128" layer="16"/>
<wire x1="75.819" y1="65.659" x2="74.803" y2="65.659" width="0.8128" layer="16"/>
<wire x1="74.803" y1="65.659" x2="73.279" y2="67.183" width="0.8128" layer="16"/>
<wire x1="73.279" y1="67.183" x2="70.993" y2="67.183" width="0.8128" layer="16"/>
<wire x1="70.993" y1="67.183" x2="67.183" y2="63.373" width="0.8128" layer="16"/>
<wire x1="67.183" y1="63.373" x2="62.484" y2="63.373" width="0.8128" layer="16"/>
</signal>
<signal name="S$11">
<wire x1="62.357" y1="60.96" x2="62.357" y2="63.373" width="0.8128" layer="16"/>
</signal>
<signal name="S$14">
<contactref element="E$6" pad="1"/>
<wire x1="78.486" y1="55.372" x2="77.47" y2="54.356" width="0.8128" layer="16"/>
<wire x1="80.264" y1="55.372" x2="78.486" y2="55.372" width="0.8128" layer="16"/>
<wire x1="83.185" y1="52.451" x2="86.741" y2="52.451" width="0.8128" layer="16"/>
<wire x1="83.185" y1="52.451" x2="80.264" y2="55.372" width="0.8128" layer="16"/>
<wire x1="63.881" y1="52.451" x2="83.185" y2="52.451" width="0.8128" layer="16"/>
</signal>
<signal name="S$15">
<contactref element="E$2" pad="C"/>
<wire x1="89.408" y1="60.706" x2="86.233" y2="60.706" width="0.8128" layer="16"/>
<wire x1="86.233" y1="60.706" x2="86.233" y2="64.389" width="0.8128" layer="16"/>
<wire x1="86.233" y1="64.389" x2="86.868" y2="64.389" width="0.8128" layer="16"/>
<wire x1="86.868" y1="64.389" x2="87.884" y2="65.405" width="0.8128" layer="16"/>
<wire x1="87.884" y1="65.405" x2="87.884" y2="69.342" width="0.8128" layer="16"/>
<wire x1="87.884" y1="69.342" x2="89.662" y2="71.12" width="0.8128" layer="16"/>
<wire x1="89.662" y1="71.12" x2="92.456" y2="71.12" width="0.8128" layer="16"/>
</signal>
<signal name="S$17">
<wire x1="93.218" y1="60.198" x2="90.932" y2="57.912" width="0.8128" layer="16"/>
<wire x1="90.932" y1="57.912" x2="90.805" y2="57.912" width="0.8128" layer="16"/>
</signal>
<signal name="S$4">
<wire x1="96.012" y1="63.373" x2="96.012" y2="58.166" width="0.8128" layer="16" curve="-180"/>
</signal>
<signal name="S$19">
<wire x1="93.345" y1="61.341" x2="92.202" y2="62.484" width="0.8128" layer="16"/>
<wire x1="92.202" y1="62.484" x2="92.202" y2="66.802" width="0.8128" layer="16"/>
</signal>
<signal name="S$20">
<wire x1="89.408" y1="64.643" x2="98.425" y2="64.643" width="0.3048" layer="1"/>
<via x="89.408" y="64.643" extent="1-16" drill="0.6" diameter="1.6764" shape="octagon"/>
<via x="98.425" y="64.643" extent="1-16" drill="0.6" diameter="1.6764" shape="octagon"/>
</signal>
<signal name="S$22">
<wire x1="72.644" y1="59.182" x2="72.644" y2="52.578" width="0.8128" layer="16"/>
<wire x1="72.644" y1="59.182" x2="74.676" y2="61.214" width="0.8128" layer="16"/>
<wire x1="77.978" y1="62.357" x2="77.089" y2="62.357" width="0.8128" layer="16"/>
<wire x1="74.676" y1="61.214" x2="75.946" y2="61.214" width="0.8128" layer="16"/>
<wire x1="75.946" y1="61.214" x2="77.089" y2="62.357" width="0.8128" layer="16"/>
</signal>
<signal name="S$25">
<contactref element="E$23" pad="A"/>
<contactref element="E$5" pad="2"/>
<wire x1="100.076" y1="63.373" x2="99.568" y2="63.373" width="0.8128" layer="16"/>
<wire x1="99.568" y1="63.373" x2="98.425" y2="64.516" width="0.8128" layer="16"/>
<wire x1="98.425" y1="64.516" x2="98.425" y2="65.913" width="0.8128" layer="16"/>
<wire x1="98.425" y1="65.913" x2="99.314" y2="66.802" width="0.8128" layer="16"/>
<wire x1="99.314" y1="66.802" x2="106.807" y2="66.802" width="0.8128" layer="16"/>
</signal>
<signal name="S$21">
<wire x1="62.357" y1="73.787" x2="62.357" y2="75.692" width="0.8128" layer="16"/>
<wire x1="62.357" y1="75.692" x2="79.883" y2="75.692" width="0.8128" layer="16"/>
</signal>
<signal name="S$42">
<contactref element="E$17" pad="2"/>
<wire x1="62.357" y1="60.579" x2="62.357" y2="60.706" width="1.016" layer="16"/>
<wire x1="62.357" y1="60.706" x2="62.357" y2="60.833" width="1.016" layer="16"/>
<wire x1="62.357" y1="60.706" x2="58.166" y2="56.515" width="0.8128" layer="16"/>
<wire x1="58.166" y1="56.515" x2="58.166" y2="54.102" width="0.8128" layer="16"/>
</signal>
<signal name="S$30">
<via x="84.201" y="74.676" extent="1-16" drill="0.6" diameter="1.9304" shape="octagon"/>
<via x="92.202" y="74.676" extent="1-16" drill="0.6" diameter="1.9304" shape="octagon"/>
<wire x1="84.201" y1="74.676" x2="92.202" y2="74.676" width="0.254" layer="1"/>
</signal>
<signal name="S$24">
<wire x1="84.201" y1="75.565" x2="84.201" y2="74.041" width="0.8128" layer="16"/>
</signal>
<signal name="S$31">
<wire x1="79.883" y1="75.692" x2="84.074" y2="75.692" width="0.8128" layer="16"/>
</signal>
<signal name="S$26">
<wire x1="86.36" y1="66.167" x2="86.36" y2="76.073" width="0.8128" layer="16"/>
<wire x1="86.36" y1="76.073" x2="86.36" y2="76.581" width="0.8128" layer="16"/>
<wire x1="84.074" y1="66.167" x2="86.36" y2="66.167" width="0.8128" layer="16"/>
<wire x1="86.36" y1="76.073" x2="84.963" y2="77.47" width="0.8128" layer="16"/>
<wire x1="84.963" y1="77.47" x2="56.896" y2="77.47" width="0.8128" layer="16"/>
<wire x1="56.896" y1="77.47" x2="53.975" y2="74.549" width="0.8128" layer="16"/>
<wire x1="53.975" y1="74.549" x2="53.975" y2="65.786" width="0.8128" layer="16"/>
<wire x1="53.975" y1="65.786" x2="50.419" y2="62.23" width="0.8128" layer="16"/>
<wire x1="50.419" y1="62.23" x2="50.419" y2="62.103" width="0.8128" layer="16"/>
</signal>
<signal name="S$12">
<contactref element="E$19" pad="2"/>
<contactref element="E$20" pad="B"/>
<wire x1="91.059" y1="53.721" x2="91.059" y2="53.9968" width="0.8128" layer="16"/>
<wire x1="91.059" y1="53.9968" x2="91.1334" y2="54.1764" width="0.8128" layer="16" curve="-44.999323"/>
<wire x1="91.1334" y1="54.1764" x2="95.123" y2="58.166" width="0.8128" layer="16"/>
</signal>
<signal name="S$28">
<wire x1="118.618" y1="77.216" x2="112.522" y2="77.216" width="1.016" layer="16"/>
<wire x1="112.522" y1="77.216" x2="112.522" y2="73.279" width="1.016" layer="16"/>
<wire x1="118.618" y1="77.216" x2="120.015" y2="75.819" width="1.016" layer="16"/>
<wire x1="120.015" y1="75.819" x2="120.015" y2="67.945" width="1.016" layer="16"/>
<wire x1="120.015" y1="67.945" x2="119.126" y2="67.056" width="1.016" layer="16"/>
</signal>
<signal name="S$29">
<contactref element="E$25" pad="2"/>
<wire x1="117.475" y1="73.279" x2="117.475" y2="71.628" width="1.016" layer="16"/>
<wire x1="117.475" y1="71.628" x2="115.062" y2="69.215" width="1.016" layer="16"/>
<wire x1="115.062" y1="69.215" x2="115.062" y2="61.595" width="1.016" layer="16"/>
<wire x1="115.062" y1="61.595" x2="114.427" y2="60.96" width="1.016" layer="16"/>
<wire x1="104.648" y1="60.706" x2="104.775" y2="60.833" width="1.27" layer="16"/>
<wire x1="104.775" y1="60.833" x2="113.919" y2="60.833" width="1.27" layer="16"/>
<wire x1="113.919" y1="60.833" x2="114.3" y2="60.833" width="1.016" layer="16"/>
<wire x1="114.3" y1="60.833" x2="114.427" y2="60.96" width="1.016" layer="16"/>
</signal>
<signal name="S$33">
<wire x1="122.682" y1="73.406" x2="122.682" y2="68.707" width="1.016" layer="16"/>
<wire x1="122.682" y1="68.707" x2="123.825" y2="67.564" width="1.016" layer="16"/>
<wire x1="123.698" y1="61.214" x2="122.682" y2="60.198" width="1.27" layer="16"/>
<wire x1="122.682" y1="60.198" x2="122.301" y2="59.817" width="1.27" layer="16"/>
<wire x1="122.301" y1="59.817" x2="119.126" y2="56.642" width="1.27" layer="16"/>
<wire x1="119.126" y1="56.642" x2="119.126" y2="54.864" width="1.27" layer="16"/>
<wire x1="123.825" y1="67.564" x2="123.825" y2="61.341" width="1.016" layer="16"/>
<wire x1="123.825" y1="61.341" x2="122.682" y2="60.198" width="1.016" layer="16"/>
</signal>
<signal name="S$32">
<wire x1="104.775" y1="73.406" x2="104.775" y2="77.343" width="1.016" layer="16"/>
</signal>
<signal name="S$23">
<contactref element="E$20" pad="E"/>
<wire x1="95.123" y1="63.246" x2="95.25" y2="63.373" width="1.016" layer="16"/>
<wire x1="95.25" y1="63.373" x2="95.25" y2="67.31" width="1.016" layer="16"/>
<wire x1="95.25" y1="67.31" x2="97.028" y2="69.088" width="1.016" layer="16"/>
<wire x1="97.028" y1="69.088" x2="97.028" y2="71.628" width="1.016" layer="16"/>
<wire x1="97.028" y1="71.628" x2="93.98" y2="74.676" width="1.016" layer="16"/>
<wire x1="93.98" y1="74.676" x2="92.329" y2="74.676" width="1.016" layer="16"/>
</signal>
<signal name="S$18">
<wire x1="90.551" y1="67.056" x2="92.075" y2="67.056" width="1.016" layer="16"/>
<wire x1="92.075" y1="67.056" x2="92.075" y2="68.834" width="1.016" layer="16"/>
<wire x1="92.075" y1="68.834" x2="93.345" y2="68.834" width="1.016" layer="16"/>
<wire x1="93.345" y1="68.834" x2="94.742" y2="70.231" width="1.016" layer="16"/>
<wire x1="94.742" y1="70.231" x2="95.25" y2="70.739" width="0.6096" layer="16"/>
<wire x1="95.25" y1="70.739" x2="95.25" y2="71.501" width="0.6096" layer="16"/>
<wire x1="95.25" y1="71.501" x2="93.853" y2="72.898" width="0.6096" layer="16"/>
<wire x1="93.853" y1="72.898" x2="90.932" y2="72.898" width="0.6096" layer="16"/>
<wire x1="90.932" y1="72.898" x2="90.17" y2="73.66" width="0.6096" layer="16"/>
<wire x1="90.17" y1="73.66" x2="90.17" y2="75.438" width="0.6096" layer="16"/>
<wire x1="90.17" y1="75.438" x2="91.059" y2="76.327" width="0.6096" layer="16"/>
<wire x1="91.059" y1="76.327" x2="97.028" y2="76.327" width="0.6096" layer="16"/>
<wire x1="97.028" y1="76.327" x2="99.568" y2="73.787" width="0.6096" layer="16"/>
</signal>
<signal name="S$27">
<wire x1="87.122" y1="77.47" x2="86.36" y2="76.708" width="0.6096" layer="16"/>
<wire x1="108.712" y1="77.089" x2="108.839" y2="76.962" width="1.016" layer="16"/>
<wire x1="108.839" y1="76.962" x2="109.855" y2="75.946" width="1.016" layer="16"/>
<wire x1="109.855" y1="75.946" x2="109.855" y2="69.85" width="1.016" layer="16"/>
<wire x1="109.855" y1="69.85" x2="111.252" y2="68.453" width="1.016" layer="16"/>
<wire x1="111.252" y1="68.453" x2="111.252" y2="64.643" width="1.016" layer="16"/>
<wire x1="108.331" y1="63.5" x2="104.14" y2="63.5" width="0.8128" layer="16"/>
<wire x1="104.14" y1="63.5" x2="102.997" y2="63.5" width="0.8128" layer="16"/>
<wire x1="102.997" y1="63.5" x2="100.203" y2="60.706" width="0.8128" layer="16"/>
<wire x1="100.203" y1="60.706" x2="100.076" y2="60.706" width="0.8128" layer="16"/>
<wire x1="100.076" y1="60.706" x2="100.076" y2="58.166" width="0.8128" layer="16"/>
<wire x1="100.076" y1="58.166" x2="103.378" y2="54.864" width="0.8128" layer="16"/>
<wire x1="103.378" y1="54.864" x2="103.632" y2="54.864" width="0.8128" layer="16"/>
<wire x1="103.632" y1="54.864" x2="106.68" y2="54.864" width="0.8128" layer="16"/>
<wire x1="102.4364" y1="53.6684" x2="103.632" y2="54.864" width="0.8128" layer="16"/>
<wire x1="102.2568" y1="53.594" x2="102.4364" y2="53.6684" width="0.8128" layer="16" curve="44.999323"/>
<wire x1="101.219" y1="53.594" x2="102.2568" y2="53.594" width="0.8128" layer="16"/>
<wire x1="111.252" y1="64.643" x2="110.109" y2="63.5" width="1.016" layer="16"/>
<wire x1="110.109" y1="63.5" x2="104.14" y2="63.5" width="1.016" layer="16"/>
<wire x1="87.122" y1="77.47" x2="108.331" y2="77.47" width="0.6096" layer="16"/>
<wire x1="108.331" y1="77.47" x2="108.839" y2="76.962" width="0.6096" layer="16"/>
<wire x1="108.839" y1="76.962" x2="108.712" y2="76.962" width="0.6096" layer="16"/>
</signal>
<signal name="S$34">
<via x="75.692" y="58.293" extent="1-16" drill="2.2" diameter="3.81"/>
<via x="6.731" y="75.692" extent="1-16" drill="2.2" diameter="3.81"/>
<via x="6.731" y="53.213" extent="1-16" drill="2.2" diameter="3.81"/>
</signal>
<signal name="S$36">
<via x="48.895" y="72.898" extent="1-16" drill="1.1" diameter="2.1844" shape="octagon"/>
</signal>
<signal name="S$37">
<via x="49.149" y="67.818" extent="1-16" drill="1.1" diameter="2.1844" shape="octagon"/>
<wire x1="49.149" y1="67.818" x2="48.133" y2="67.818" width="0.8128" layer="16"/>
<wire x1="48.133" y1="67.818" x2="42.037" y2="61.722" width="0.8128" layer="16"/>
<wire x1="42.037" y1="61.722" x2="41.529" y2="61.722" width="0.8128" layer="16"/>
</signal>
<signal name="S$38">
<via x="58.039" y="65.278" extent="1-16" drill="1.1" diameter="2.1844" shape="octagon"/>
<wire x1="58.039" y1="65.278" x2="58.674" y2="64.643" width="0.8128" layer="16"/>
<wire x1="58.674" y1="64.643" x2="58.674" y2="61.468" width="0.8128" layer="16"/>
<wire x1="58.674" y1="61.468" x2="58.801" y2="61.468" width="0.8128" layer="16"/>
</signal>
<signal name="S$39">
<via x="49.149" y="65.278" extent="1-16" drill="1.1" diameter="2.1844" shape="octagon"/>
</signal>
<signal name="S$35">
<via x="48.895" y="75.438" extent="1-16" drill="1.1" diameter="2.1844" shape="octagon"/>
</signal>
<signal name="S$40">
<via x="58.039" y="75.438" extent="1-16" drill="1.1" diameter="2.1844" shape="octagon"/>
</signal>
<signal name="S$41">
<wire x1="58.166" y1="75.311" x2="55.626" y2="72.771" width="0.8128" layer="16"/>
</signal>
<signal name="S$43">
<wire x1="65.024" y1="52.578" x2="64.008" y2="53.594" width="0.8128" layer="16"/>
<wire x1="64.008" y1="53.594" x2="64.008" y2="54.356" width="0.8128" layer="16"/>
</signal>
<signal name="S$44">
<wire x1="50.165" y1="60.452" x2="48.387" y2="58.674" width="0.8128" layer="16"/>
<wire x1="48.387" y1="58.674" x2="48.387" y2="55.245" width="0.8128" layer="16"/>
<contactref element="E$22" pad="+"/>
<wire x1="48.387" y1="55.245" x2="49.276" y2="54.356" width="0.8128" layer="16"/>
<wire x1="49.276" y1="54.356" x2="50.673" y2="54.356" width="0.8128" layer="16"/>
</signal>
<signal name="S$45">
<wire x1="49.022" y1="75.438" x2="47.879" y2="76.581" width="0.8128" layer="16"/>
<wire x1="47.879" y1="76.581" x2="44.45" y2="76.581" width="0.8128" layer="16"/>
<wire x1="44.45" y1="76.581" x2="44.323" y2="76.454" width="0.8128" layer="16"/>
</signal>
<signal name="S$47">
<wire x1="50.419" y1="60.706" x2="50.546" y2="60.833" width="0.8128" layer="16"/>
<wire x1="50.546" y1="60.833" x2="50.546" y2="61.976" width="0.8128" layer="16"/>
</signal>
<signal name="S$46">
<wire x1="50.8" y1="57.785" x2="54.229" y2="61.214" width="0.8128" layer="16"/>
<wire x1="54.229" y1="61.214" x2="54.229" y2="63.754" width="0.8128" layer="16"/>
<wire x1="54.229" y1="63.754" x2="55.626" y2="65.151" width="0.8128" layer="16"/>
<wire x1="55.626" y1="65.151" x2="55.626" y2="72.644" width="0.8128" layer="16"/>
</signal>
<signal name="S$48">
<wire x1="50.673" y1="57.658" x2="56.896" y2="51.435" width="0.8128" layer="16"/>
<contactref element="E$2" pad="E"/>
<wire x1="86.741" y1="52.578" x2="89.408" y2="55.372" width="0.8128" layer="16"/>
<wire x1="89.408" y1="55.372" x2="89.408" y2="58.166" width="0.8128" layer="16"/>
<wire x1="56.896" y1="51.435" x2="85.598" y2="51.435" width="0.8128" layer="16"/>
<wire x1="85.598" y1="51.435" x2="86.741" y2="52.578" width="0.8128" layer="16"/>
<wire x1="86.741" y1="52.578" x2="86.106" y2="52.578" width="0.8128" layer="16"/>
<wire x1="86.106" y1="52.578" x2="85.471" y2="51.943" width="0.8128" layer="16"/>
<wire x1="85.471" y1="51.943" x2="64.389" y2="51.943" width="0.8128" layer="16"/>
<wire x1="64.389" y1="51.943" x2="62.992" y2="53.34" width="0.8128" layer="16"/>
</signal>
<signal name="S$49">
<wire x1="49.276" y1="65.151" x2="44.577" y2="60.452" width="0.8128" layer="16"/>
<wire x1="44.577" y1="60.452" x2="44.577" y2="57.15" width="0.8128" layer="16"/>
</signal>
<signal name="S$51">
<contactref element="E$21" pad="A"/>
<contactref element="E$28" pad="A"/>
<wire x1="41.529" y1="70.358" x2="42.418" y2="71.374" width="0.8128" layer="16"/>
<wire x1="42.418" y1="71.374" x2="44.069" y2="71.374" width="0.8128" layer="16"/>
<contactref element="E$31" pad="+"/>
<wire x1="44.069" y1="71.374" x2="44.45" y2="71.374" width="0.8128" layer="16"/>
<wire x1="40.132" y1="73.152" x2="41.91" y2="71.374" width="0.8128" layer="16"/>
<wire x1="41.91" y1="71.374" x2="42.418" y2="71.374" width="0.8128" layer="16"/>
</signal>
<signal name="S$16">
<contactref element="E$29" pad="2"/>
<wire x1="41.529" y1="65.405" x2="43.561" y2="67.437" width="0.8128" layer="16"/>
<wire x1="43.561" y1="67.437" x2="44.45" y2="67.437" width="0.8128" layer="16"/>
</signal>
<signal name="S$52">
<contactref element="E$33" pad="1"/>
<contactref element="E$32" pad="C"/>
<wire x1="44.45" y1="52.832" x2="42.672" y2="52.832" width="0.8128" layer="16"/>
<wire x1="42.672" y1="52.832" x2="41.529" y2="53.975" width="0.8128" layer="16"/>
<wire x1="39.116" y1="52.705" x2="40.259" y2="52.705" width="0.8128" layer="16"/>
<wire x1="40.259" y1="52.705" x2="41.529" y2="53.975" width="0.8128" layer="16"/>
<wire x1="41.529" y1="53.975" x2="41.529" y2="53.848" width="0.8128" layer="16"/>
</signal>
<signal name="S$53">
<contactref element="E$28" pad="C"/>
<wire x1="39.878" y1="77.47" x2="40.005" y2="77.47" width="0.8128" layer="16"/>
<wire x1="40.005" y1="77.47" x2="43.434" y2="77.47" width="0.8128" layer="16"/>
<wire x1="43.434" y1="77.47" x2="44.45" y2="76.454" width="0.8128" layer="16"/>
<wire x1="39.878" y1="77.47" x2="35.687" y2="77.47" width="0.8128" layer="16"/>
</signal>
<signal name="S$54">
<wire x1="35.56" y1="71.882" x2="37.211" y2="71.882" width="0.8128" layer="16"/>
<wire x1="37.211" y1="71.882" x2="38.354" y2="70.739" width="0.8128" layer="16"/>
</signal>
<signal name="S$55">
<wire x1="41.402" y1="65.278" x2="39.497" y2="65.278" width="0.8128" layer="16"/>
<wire x1="39.497" y1="65.278" x2="38.354" y2="64.135" width="0.8128" layer="16"/>
<contactref element="E$37" pad="1"/>
<wire x1="38.354" y1="64.135" x2="38.354" y2="60.452" width="0.8128" layer="16"/>
</signal>
<signal name="S$57">
<contactref element="E$34" pad="3"/>
<contactref element="E$39" pad="1"/>
<wire x1="32.385" y1="57.785" x2="34.417" y2="55.753" width="0.8128" layer="16"/>
<wire x1="34.417" y1="55.753" x2="35.56" y2="55.753" width="0.8128" layer="16"/>
</signal>
<signal name="S$58">
<wire x1="41.656" y1="61.595" x2="41.529" y2="61.468" width="0.8128" layer="16"/>
<wire x1="41.529" y1="61.468" x2="41.529" y2="58.547" width="0.8128" layer="16"/>
<wire x1="41.529" y1="58.547" x2="40.894" y2="57.912" width="0.8128" layer="16"/>
<wire x1="40.894" y1="57.912" x2="36.322" y2="57.912" width="0.8128" layer="16"/>
<wire x1="36.322" y1="57.912" x2="32.893" y2="61.341" width="0.8128" layer="16"/>
<wire x1="32.893" y1="61.341" x2="32.004" y2="61.341" width="0.8128" layer="16"/>
<wire x1="32.004" y1="61.341" x2="29.845" y2="59.182" width="0.8128" layer="16"/>
<wire x1="29.845" y1="59.182" x2="29.845" y2="58.039" width="0.8128" layer="16"/>
</signal>
<signal name="S$59">
<contactref element="E$35" pad="3"/>
<wire x1="29.718" y1="76.581" x2="32.131" y2="76.581" width="0.8128" layer="16"/>
<wire x1="32.131" y1="76.581" x2="33.782" y2="74.93" width="0.8128" layer="16"/>
<wire x1="33.782" y1="74.93" x2="38.481" y2="74.93" width="0.8128" layer="16"/>
<wire x1="49.022" y1="72.898" x2="48.133" y2="73.787" width="0.8128" layer="16"/>
<wire x1="48.133" y1="73.787" x2="44.323" y2="73.787" width="0.8128" layer="16"/>
<wire x1="44.323" y1="73.787" x2="43.815" y2="74.295" width="0.8128" layer="16"/>
<wire x1="43.815" y1="74.295" x2="42.164" y2="74.295" width="0.8128" layer="16"/>
<wire x1="42.164" y1="74.295" x2="40.767" y2="75.692" width="0.8128" layer="16"/>
<wire x1="38.481" y1="74.93" x2="39.243" y2="75.692" width="0.8128" layer="16"/>
<wire x1="39.243" y1="75.692" x2="40.767" y2="75.692" width="0.8128" layer="16"/>
</signal>
<signal name="S$60">
<wire x1="29.845" y1="74.168" x2="29.972" y2="74.041" width="0.8128" layer="16"/>
<wire x1="29.972" y1="74.041" x2="31.877" y2="74.041" width="0.8128" layer="16"/>
<wire x1="31.877" y1="74.041" x2="33.02" y2="72.898" width="0.8128" layer="16"/>
<wire x1="33.02" y1="72.898" x2="33.02" y2="70.358" width="0.8128" layer="16"/>
<wire x1="35.687" y1="66.04" x2="37.592" y2="64.135" width="0.8128" layer="16"/>
<wire x1="37.592" y1="64.135" x2="38.481" y2="64.135" width="0.8128" layer="16"/>
<wire x1="33.02" y1="70.358" x2="35.687" y2="67.691" width="0.8128" layer="16"/>
<wire x1="35.687" y1="67.691" x2="35.687" y2="66.04" width="0.8128" layer="16"/>
</signal>
<signal name="S$61">
<contactref element="E$35" pad="1"/>
<contactref element="E$40" pad="C"/>
<wire x1="29.718" y1="71.501" x2="31.75" y2="69.469" width="0.8128" layer="16"/>
<wire x1="31.75" y1="69.469" x2="31.75" y2="68.453" width="0.8128" layer="16"/>
</signal>
<signal name="S$62">
<contactref element="E$40" pad="A"/>
<wire x1="31.75" y1="63.373" x2="30.607" y2="63.373" width="0.8128" layer="16"/>
<wire x1="30.607" y1="63.373" x2="27.305" y2="60.071" width="0.8128" layer="16"/>
<wire x1="27.305" y1="60.071" x2="27.305" y2="59.309" width="0.8128" layer="16"/>
</signal>
<signal name="S$63">
<contactref element="E$38" pad="2"/>
<contactref element="E$41" pad="+"/>
<wire x1="28.829" y1="52.705" x2="25.781" y2="52.705" width="0.8128" layer="16"/>
<wire x1="25.781" y1="52.705" x2="22.098" y2="56.388" width="0.8128" layer="16"/>
</signal>
<signal name="S$65">
<wire x1="31.623" y1="64.008" x2="28.956" y2="64.008" width="0.8128" layer="16"/>
</signal>
<signal name="S$66">
<wire x1="32.004" y1="62.611" x2="29.337" y2="62.611" width="0.8128" layer="16"/>
<wire x1="29.337" y1="62.611" x2="29.21" y2="62.738" width="0.8128" layer="16"/>
</signal>
<signal name="S$56">
<wire x1="21.844" y1="56.769" x2="22.479" y2="56.134" width="0.8128" layer="16"/>
</signal>
<signal name="S$50">
<wire x1="19.177" y1="63.119" x2="18.796" y2="63.119" width="0.8128" layer="16"/>
</signal>
<signal name="S$67">
<wire x1="22.352" y1="56.388" x2="22.352" y2="59.944" width="0.8128" layer="16"/>
<wire x1="22.352" y1="59.944" x2="27.813" y2="65.405" width="0.8128" layer="16"/>
<wire x1="27.813" y1="65.405" x2="27.813" y2="69.215" width="0.8128" layer="16"/>
</signal>
<signal name="S$68">
<contactref element="E$45" pad="A"/>
<contactref element="E$44" pad="A"/>
<wire x1="11.176" y1="56.515" x2="14.224" y2="60.579" width="0.8128" layer="16"/>
<wire x1="14.224" y1="60.579" x2="14.478" y2="60.579" width="0.8128" layer="16"/>
<wire x1="14.478" y1="60.579" x2="18.669" y2="56.388" width="0.8128" layer="16"/>
</signal>
<signal name="S$72">
<wire x1="24.384" y1="73.66" x2="24.384" y2="70.739" width="0.8128" layer="16"/>
<wire x1="24.384" y1="70.739" x2="23.749" y2="70.104" width="0.8128" layer="16"/>
</signal>
<signal name="S$69">
<wire x1="17.78" y1="65.913" x2="16.129" y2="64.262" width="0.8128" layer="16"/>
<wire x1="16.129" y1="64.262" x2="11.176" y2="64.262" width="0.8128" layer="16"/>
<wire x1="17.78" y1="65.913" x2="21.082" y2="65.913" width="0.6096" layer="16"/>
<wire x1="21.082" y1="65.913" x2="21.082" y2="66.04" width="0.6096" layer="16"/>
<wire x1="21.082" y1="66.04" x2="21.336" y2="66.04" width="0.6096" layer="16"/>
<wire x1="21.336" y1="66.04" x2="22.606" y2="67.31" width="0.6096" layer="16"/>
<wire x1="22.606" y1="67.31" x2="22.606" y2="68.961" width="0.6096" layer="16"/>
<wire x1="22.606" y1="68.961" x2="23.622" y2="69.977" width="0.6096" layer="16"/>
</signal>
<signal name="S$70">
<contactref element="E$46" pad="2"/>
<wire x1="19.431" y1="73.66" x2="9.525" y2="73.66" width="0.8128" layer="16"/>
<wire x1="9.525" y1="73.66" x2="8.128" y2="72.263" width="0.8128" layer="16"/>
</signal>
<signal name="S$71">
<wire x1="20.066" y1="68.707" x2="16.764" y2="68.707" width="0.8128" layer="16"/>
<wire x1="16.764" y1="68.707" x2="16.256" y2="68.199" width="0.8128" layer="16"/>
<wire x1="16.256" y1="68.199" x2="11.049" y2="68.199" width="0.8128" layer="16"/>
<wire x1="11.049" y1="68.199" x2="8.128" y2="65.278" width="0.8128" layer="16"/>
<wire x1="8.128" y1="65.278" x2="8.128" y2="62.484" width="0.8128" layer="16"/>
<wire x1="8.128" y1="62.484" x2="8.001" y2="62.357" width="0.8128" layer="16"/>
<wire x1="8.001" y1="62.357" x2="8.001" y2="61.976" width="0.8128" layer="16"/>
<wire x1="8.001" y1="61.976" x2="8.128" y2="61.976" width="0.8128" layer="16"/>
<wire x1="8.128" y1="61.976" x2="8.255" y2="61.849" width="0.8128" layer="16"/>
</signal>
<signal name="S$73">
<wire x1="24.003" y1="68.834" x2="24.003" y2="65.786" width="0.6096" layer="16"/>
<wire x1="19.05" y1="63.119" x2="19.05" y2="58.801" width="0.8128" layer="16"/>
<wire x1="19.05" y1="58.801" x2="18.542" y2="58.293" width="0.8128" layer="16"/>
<wire x1="18.542" y1="58.293" x2="18.542" y2="56.515" width="0.8128" layer="16"/>
<wire x1="18.542" y1="56.515" x2="18.415" y2="56.388" width="0.8128" layer="16"/>
<wire x1="24.003" y1="65.786" x2="21.336" y2="63.119" width="0.6096" layer="16"/>
<wire x1="21.336" y1="63.119" x2="19.05" y2="63.119" width="0.6096" layer="16"/>
<wire x1="24.003" y1="68.834" x2="26.797" y2="71.628" width="0.6096" layer="16"/>
<wire x1="26.797" y1="71.628" x2="26.797" y2="76.073" width="0.6096" layer="16"/>
<wire x1="26.797" y1="76.073" x2="27.432" y2="76.708" width="0.6096" layer="16"/>
<wire x1="27.432" y1="76.708" x2="29.591" y2="76.708" width="0.6096" layer="16"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
