<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.2">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.007" unitdist="mm" unit="mm" style="lines" multiple="1" display="no" altdistance="0.007" altunitdist="mm" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="12" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="no" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<wire x1="44.66" y1="9.37" x2="125.12" y2="9.37" width="0" layer="20"/>
<wire x1="125.12" y1="9.37" x2="125.12" y2="47" width="0" layer="20"/>
<wire x1="125.12" y1="47" x2="44.66" y2="47" width="0" layer="20"/>
<wire x1="44.66" y1="47" x2="44.66" y2="9.37" width="0" layer="20"/>
<text x="50.445" y="26.317" size="1.6764" layer="1" ratio="15">+</text>
<text x="51.437" y="42.732" size="1.016" layer="1" ratio="15">1</text>
<text x="90.72" y="39.96" size="1.016" layer="1" ratio="15">16</text>
<text x="53.41" y="9.73" size="1.016" layer="1" ratio="1">Z Teszt</text>
<text x="46.69" y="40.194" size="1.016" layer="1" ratio="1" rot="SR270">Teszt</text>
<text x="106.463" y="11.69" size="1.016" layer="1" ratio="1">Z dióda</text>
</plain>
<libraries>
<library name="atmel">
<description>&lt;b&gt;AVR Devices&lt;/b&gt;&lt;p&gt;
Configurable logic, microcontrollers, nonvolatile memories&lt;p&gt;
Based on the following sources:&lt;p&gt;
&lt;ul&gt;
&lt;li&gt;www.atmel.com
&lt;li&gt;CD-ROM : Configurable Logic Microcontroller Nonvolatile Memory
&lt;li&gt;CadSoft download site, www.cadsoft.de or www.cadsoftusa.com , file at90smcu_v400.zip
&lt;li&gt;avr.lbr
&lt;/ul&gt;
&lt;author&gt;Revised by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="TQFP32-08">
<description>&lt;B&gt;Thin Plasic Quad Flat Package&lt;/B&gt; Grid 0.8 mm</description>
<wire x1="3.505" y1="3.505" x2="3.505" y2="-3.505" width="0.1524" layer="21"/>
<wire x1="3.505" y1="-3.505" x2="-3.505" y2="-3.505" width="0.1524" layer="21"/>
<wire x1="-3.505" y1="-3.505" x2="-3.505" y2="3.15" width="0.1524" layer="21"/>
<wire x1="-3.15" y1="3.505" x2="3.505" y2="3.505" width="0.1524" layer="21"/>
<wire x1="-3.15" y1="3.505" x2="-3.505" y2="3.15" width="0.1524" layer="21"/>
<circle x="-2.7432" y="2.7432" radius="0.3592" width="0.1524" layer="21"/>
<smd name="1" x="-4.2926" y="2.8" dx="1.27" dy="0.5588" layer="1"/>
<smd name="2" x="-4.2926" y="2" dx="1.27" dy="0.5588" layer="1"/>
<smd name="3" x="-4.2926" y="1.2" dx="1.27" dy="0.5588" layer="1"/>
<smd name="4" x="-4.2926" y="0.4" dx="1.27" dy="0.5588" layer="1"/>
<smd name="5" x="-4.2926" y="-0.4" dx="1.27" dy="0.5588" layer="1"/>
<smd name="6" x="-4.2926" y="-1.2" dx="1.27" dy="0.5588" layer="1"/>
<smd name="7" x="-4.2926" y="-2" dx="1.27" dy="0.5588" layer="1"/>
<smd name="8" x="-4.2926" y="-2.8" dx="1.27" dy="0.5588" layer="1"/>
<smd name="9" x="-2.8" y="-4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="10" x="-2" y="-4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="11" x="-1.2" y="-4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="12" x="-0.4" y="-4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="13" x="0.4" y="-4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="14" x="1.2" y="-4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="15" x="2" y="-4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="16" x="2.8" y="-4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="17" x="4.2926" y="-2.8" dx="1.27" dy="0.5588" layer="1"/>
<smd name="18" x="4.2926" y="-2" dx="1.27" dy="0.5588" layer="1"/>
<smd name="19" x="4.2926" y="-1.2" dx="1.27" dy="0.5588" layer="1"/>
<smd name="20" x="4.2926" y="-0.4" dx="1.27" dy="0.5588" layer="1"/>
<smd name="21" x="4.2926" y="0.4" dx="1.27" dy="0.5588" layer="1"/>
<smd name="22" x="4.2926" y="1.2" dx="1.27" dy="0.5588" layer="1"/>
<smd name="23" x="4.2926" y="2" dx="1.27" dy="0.5588" layer="1"/>
<smd name="24" x="4.2926" y="2.8" dx="1.27" dy="0.5588" layer="1"/>
<smd name="25" x="2.8" y="4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="26" x="2" y="4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="27" x="1.2" y="4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="28" x="0.4" y="4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="29" x="-0.4" y="4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="30" x="-1.2" y="4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="31" x="-2" y="4.2926" dx="0.5588" dy="1.27" layer="1"/>
<smd name="32" x="-2.8" y="4.2926" dx="0.5588" dy="1.27" layer="1"/>
<text x="-2.7686" y="5.08" size="0.8128" layer="25">&gt;NAME</text>
<text x="-3.0226" y="-1.27" size="0.8128" layer="27">&gt;VALUE</text>
<rectangle x1="-4.5466" y1="2.5714" x2="-3.556" y2="3.0286" layer="51"/>
<rectangle x1="-4.5466" y1="1.7714" x2="-3.556" y2="2.2286" layer="51"/>
<rectangle x1="-4.5466" y1="0.9714" x2="-3.556" y2="1.4286" layer="51"/>
<rectangle x1="-4.5466" y1="0.1714" x2="-3.556" y2="0.6286" layer="51"/>
<rectangle x1="-4.5466" y1="-0.6286" x2="-3.556" y2="-0.1714" layer="51"/>
<rectangle x1="-4.5466" y1="-1.4286" x2="-3.556" y2="-0.9714" layer="51"/>
<rectangle x1="-4.5466" y1="-2.2286" x2="-3.556" y2="-1.7714" layer="51"/>
<rectangle x1="-4.5466" y1="-3.0286" x2="-3.556" y2="-2.5714" layer="51"/>
<rectangle x1="-3.0286" y1="-4.5466" x2="-2.5714" y2="-3.556" layer="51"/>
<rectangle x1="-2.2286" y1="-4.5466" x2="-1.7714" y2="-3.556" layer="51"/>
<rectangle x1="-1.4286" y1="-4.5466" x2="-0.9714" y2="-3.556" layer="51"/>
<rectangle x1="-0.6286" y1="-4.5466" x2="-0.1714" y2="-3.556" layer="51"/>
<rectangle x1="0.1714" y1="-4.5466" x2="0.6286" y2="-3.556" layer="51"/>
<rectangle x1="0.9714" y1="-4.5466" x2="1.4286" y2="-3.556" layer="51"/>
<rectangle x1="1.7714" y1="-4.5466" x2="2.2286" y2="-3.556" layer="51"/>
<rectangle x1="2.5714" y1="-4.5466" x2="3.0286" y2="-3.556" layer="51"/>
<rectangle x1="3.556" y1="-3.0286" x2="4.5466" y2="-2.5714" layer="51"/>
<rectangle x1="3.556" y1="-2.2286" x2="4.5466" y2="-1.7714" layer="51"/>
<rectangle x1="3.556" y1="-1.4286" x2="4.5466" y2="-0.9714" layer="51"/>
<rectangle x1="3.556" y1="-0.6286" x2="4.5466" y2="-0.1714" layer="51"/>
<rectangle x1="3.556" y1="0.1714" x2="4.5466" y2="0.6286" layer="51"/>
<rectangle x1="3.556" y1="0.9714" x2="4.5466" y2="1.4286" layer="51"/>
<rectangle x1="3.556" y1="1.7714" x2="4.5466" y2="2.2286" layer="51"/>
<rectangle x1="3.556" y1="2.5714" x2="4.5466" y2="3.0286" layer="51"/>
<rectangle x1="2.5714" y1="3.556" x2="3.0286" y2="4.5466" layer="51"/>
<rectangle x1="1.7714" y1="3.556" x2="2.2286" y2="4.5466" layer="51"/>
<rectangle x1="0.9714" y1="3.556" x2="1.4286" y2="4.5466" layer="51"/>
<rectangle x1="0.1714" y1="3.556" x2="0.6286" y2="4.5466" layer="51"/>
<rectangle x1="-0.6286" y1="3.556" x2="-0.1714" y2="4.5466" layer="51"/>
<rectangle x1="-1.4286" y1="3.556" x2="-0.9714" y2="4.5466" layer="51"/>
<rectangle x1="-2.2286" y1="3.556" x2="-1.7714" y2="4.5466" layer="51"/>
<rectangle x1="-3.0286" y1="3.556" x2="-2.5714" y2="4.5466" layer="51"/>
</package>
</packages>
</library>
<library name="rcl">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="M1206">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
MELF 0.25 W</description>
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="1.143" y1="0.8382" x2="-1.143" y2="0.8382" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.8382" x2="-1.143" y2="-0.8382" width="0.1524" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-0.9144" x2="-1.1176" y2="0.9144" layer="51"/>
<rectangle x1="1.1176" y1="-0.9144" x2="1.7018" y2="0.9144" layer="51"/>
<rectangle x1="-0.3" y1="-0.8001" x2="0.3" y2="0.8001" layer="35"/>
</package>
</packages>
</library>
<library name="transistor-npn">
<description>&lt;b&gt;NPN Transistors&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="SOT23">
<description>&lt;b&gt;SOT-23&lt;/b&gt;</description>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.1524" layer="51"/>
<smd name="3" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="2" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="1" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2286" y1="0.7112" x2="0.2286" y2="1.2954" layer="51"/>
<rectangle x1="0.7112" y1="-1.2954" x2="1.1684" y2="-0.7112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.2954" x2="-0.7112" y2="-0.7112" layer="51"/>
</package>
</packages>
</library>
<library name="transistor-pnp">
<description>&lt;b&gt;PNP Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="SOT23-BEC">
<description>&lt;b&gt;TO-236&lt;/b&gt; ITT Intermetall</description>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.127" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.127" layer="51"/>
<smd name="C" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="E" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="B" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
</package>
</packages>
</library>
<library name="con-amp-quick">
<description>&lt;b&gt;AMP Connectors, Type QUICK&lt;/b&gt;&lt;p&gt;
<packages>
<package name="02P">
<description>&lt;b&gt;AMP QUICK CONNECTOR&lt;/b&gt;</description>
<wire x1="-2.286" y1="2.54" x2="-2.286" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.778" x2="-0.381" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="1.778" x2="-0.254" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.651" x2="0" y2="1.397" width="0.1524" layer="21"/>
<wire x1="0" y1="1.397" x2="0.254" y2="1.651" width="0.1524" layer="21"/>
<wire x1="0.254" y1="1.651" x2="0.381" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-2.159" x2="-0.254" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-2.286" x2="-2.286" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-2.159" x2="-0.254" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-2.159" x2="0.254" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-2.286" x2="0.254" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="0.381" y1="1.778" x2="2.286" y2="1.778" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.778" x2="2.286" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.778" x2="-2.286" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.778" x2="-2.286" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.778" x2="-1.905" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.778" x2="2.286" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.778" x2="1.905" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.778" x2="2.286" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.778" x2="1.905" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.778" x2="-0.635" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.778" x2="-1.905" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.27" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.778" x2="0.635" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.524" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.778" x2="0.635" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.524" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-1.524" x2="0.635" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-1.524" x2="0.254" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.524" x2="-0.254" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.524" x2="0.254" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.524" x2="-0.254" y2="1.651" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.524" x2="2.286" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.524" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.524" x2="2.286" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.524" x2="-2.286" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.524" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.524" x2="-2.286" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="2.54" x2="-1.524" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="2.54" x2="-1.524" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="2.54" x2="-1.016" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="2.667" x2="-1.524" y2="2.667" width="0.1524" layer="21"/>
<wire x1="1.016" y1="2.54" x2="1.016" y2="2.667" width="0.1524" layer="21"/>
<wire x1="1.524" y1="2.54" x2="2.286" y2="2.54" width="0.1524" layer="21"/>
<wire x1="1.524" y1="2.54" x2="1.524" y2="2.667" width="0.1524" layer="21"/>
<wire x1="1.524" y1="2.667" x2="1.016" y2="2.667" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.413" x2="0.254" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.54" x2="1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.413" x2="-0.254" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="2.413" x2="-0.254" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="2.54" x2="-1.016" y2="2.54" width="0.1524" layer="21"/>
<pad name="1" x="-1.27" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="2" x="1.27" y="0" drill="0.9144" shape="long" rot="R90"/>
<text x="-0.762" y="0.9398" size="0.9906" layer="21" ratio="12" rot="R90">1</text>
<text x="-2.286" y="2.9464" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.8354" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.6002" y1="-0.3302" x2="-0.9398" y2="0.3302" layer="51"/>
<rectangle x1="0.9398" y1="-0.3302" x2="1.6002" y2="0.3302" layer="51"/>
</package>
<package name="16P">
<wire x1="-18.161" y1="1.778" x2="-18.034" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-18.034" y1="1.651" x2="-17.78" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="1.397" x2="-17.526" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-17.526" y1="1.651" x2="-17.399" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-18.034" y1="-2.159" x2="-18.034" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-18.034" y1="-2.286" x2="-20.066" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-17.526" y1="-2.159" x2="-18.034" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-17.526" y1="-2.159" x2="-17.526" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-20.066" y1="2.54" x2="-20.066" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-20.066" y1="1.778" x2="-20.066" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-20.066" y1="-1.778" x2="-20.066" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-20.066" y1="-1.778" x2="-19.685" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-18.415" y1="-1.778" x2="-18.415" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="-1.778" x2="-19.685" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="-1.27" x2="-18.415" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-18.415" y1="-1.524" x2="-18.415" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-17.145" y1="-1.778" x2="-17.145" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-17.145" y1="-1.524" x2="-17.145" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-18.415" y1="-1.524" x2="-18.034" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-18.034" y1="-1.524" x2="-17.526" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-17.526" y1="-1.524" x2="-17.145" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="-1.524" x2="-20.066" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="-1.524" x2="-19.685" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-20.066" y1="-1.524" x2="-20.066" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-20.066" y1="2.54" x2="-19.304" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-19.304" y1="2.54" x2="-19.304" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-18.796" y1="2.54" x2="-18.796" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-18.796" y1="2.667" x2="-19.304" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-16.764" y1="2.54" x2="-16.764" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-16.256" y1="2.54" x2="-16.256" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-17.526" y1="2.413" x2="-17.526" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-18.034" y1="2.413" x2="-18.034" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-14.986" y1="-2.159" x2="-15.494" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-14.986" y1="-2.159" x2="-14.986" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-12.954" y1="-2.286" x2="-14.986" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-12.954" y1="1.778" x2="-12.954" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-1.778" x2="-13.335" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-1.27" x2="-13.335" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-15.875" y1="-1.778" x2="-15.875" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-15.875" y1="-1.524" x2="-15.875" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-1.778" x2="-14.605" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-1.524" x2="-14.605" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-15.875" y1="-1.524" x2="-15.494" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-15.494" y1="-1.524" x2="-14.986" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-14.986" y1="-1.524" x2="-14.605" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-1.524" x2="-12.954" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-1.524" x2="-13.335" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-14.224" y1="2.54" x2="-14.224" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-13.716" y1="2.54" x2="-12.954" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-13.716" y1="2.54" x2="-13.716" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-13.716" y1="2.667" x2="-14.224" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-14.986" y1="2.413" x2="-14.986" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-14.986" y1="2.54" x2="-14.224" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-14.986" y1="2.413" x2="-15.494" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-15.494" y1="2.413" x2="-15.494" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-16.256" y1="2.54" x2="-15.494" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-16.256" y1="2.667" x2="-16.764" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-17.526" y1="2.54" x2="-16.764" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-18.034" y1="2.413" x2="-17.526" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-18.034" y1="2.54" x2="-18.796" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="1.778" x2="-20.066" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-17.399" y1="1.778" x2="-15.494" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-15.494" y1="1.778" x2="-14.986" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-17.526" y1="1.651" x2="-17.526" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-18.034" y1="1.651" x2="-18.034" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-15.494" y1="1.778" x2="-15.494" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-14.986" y1="1.778" x2="-14.986" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-17.145" y1="-1.27" x2="-15.875" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-17.145" y1="-1.778" x2="-18.415" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-17.526" y1="-2.286" x2="-15.494" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-15.875" y1="-1.778" x2="-14.605" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-15.494" y1="-2.159" x2="-15.494" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-2.159" x2="-10.414" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-2.286" x2="-12.446" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-2.159" x2="-10.414" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-2.159" x2="-9.906" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="1.778" x2="-12.446" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-1.778" x2="-10.795" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-1.778" x2="-12.065" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-1.27" x2="-10.795" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-1.524" x2="-10.795" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-1.778" x2="-9.525" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-1.524" x2="-9.525" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-1.524" x2="-10.414" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-1.524" x2="-9.906" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-1.524" x2="-9.525" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-1.524" x2="-12.446" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-1.524" x2="-12.065" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="2.54" x2="-11.684" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-11.684" y1="2.54" x2="-11.684" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-11.176" y1="2.54" x2="-11.176" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-11.176" y1="2.667" x2="-11.684" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-9.144" y1="2.54" x2="-9.144" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="2.54" x2="-8.636" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="2.413" x2="-9.906" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="2.413" x2="-10.414" y2="2.54" width="0.1524" layer="21"/>
<wire x1="17.78" y1="1.397" x2="18.034" y2="1.651" width="0.1524" layer="21"/>
<wire x1="18.034" y1="1.651" x2="18.161" y2="1.778" width="0.1524" layer="21"/>
<wire x1="18.034" y1="-2.159" x2="17.526" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="18.034" y1="-2.159" x2="18.034" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="20.066" y1="-2.286" x2="18.034" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="18.161" y1="1.778" x2="20.066" y2="1.778" width="0.1524" layer="21"/>
<wire x1="20.066" y1="1.778" x2="20.066" y2="2.54" width="0.1524" layer="21"/>
<wire x1="20.066" y1="-1.778" x2="20.066" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="20.066" y1="-1.778" x2="19.685" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="20.066" y1="1.778" x2="20.066" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="19.685" y1="-1.778" x2="19.685" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="18.415" y1="-1.27" x2="19.685" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="17.145" y1="-1.778" x2="17.145" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="17.145" y1="-1.524" x2="17.145" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="18.415" y1="-1.778" x2="18.415" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="18.415" y1="-1.524" x2="18.415" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="17.145" y1="-1.524" x2="17.526" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="17.526" y1="-1.524" x2="18.034" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="18.034" y1="-1.524" x2="18.415" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="19.685" y1="-1.524" x2="20.066" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="19.685" y1="-1.524" x2="19.685" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="20.066" y1="-1.524" x2="20.066" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="18.796" y1="2.54" x2="18.796" y2="2.667" width="0.1524" layer="21"/>
<wire x1="19.304" y1="2.54" x2="20.066" y2="2.54" width="0.1524" layer="21"/>
<wire x1="19.304" y1="2.54" x2="19.304" y2="2.667" width="0.1524" layer="21"/>
<wire x1="19.304" y1="2.667" x2="18.796" y2="2.667" width="0.1524" layer="21"/>
<wire x1="18.034" y1="2.413" x2="18.034" y2="2.54" width="0.1524" layer="21"/>
<wire x1="18.034" y1="2.54" x2="18.796" y2="2.54" width="0.1524" layer="21"/>
<wire x1="18.034" y1="2.413" x2="17.526" y2="2.413" width="0.1524" layer="21"/>
<wire x1="17.526" y1="2.413" x2="17.526" y2="2.54" width="0.1524" layer="21"/>
<wire x1="17.399" y1="1.778" x2="17.526" y2="1.651" width="0.1524" layer="21"/>
<wire x1="17.526" y1="1.651" x2="17.78" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="2.667" x2="-9.144" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="2.54" x2="-9.144" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="2.413" x2="-9.906" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="2.54" x2="-11.176" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="1.778" x2="-10.414" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="1.778" x2="-9.906" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="1.778" x2="-10.414" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="17.526" y1="1.651" x2="17.526" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="18.034" y1="1.651" x2="18.034" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-1.778" x2="-10.795" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="17.145" y1="-1.778" x2="18.415" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="17.526" y1="-2.159" x2="17.526" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-14.986" y1="1.778" x2="-12.954" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="1.778" x2="-9.906" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-12.954" y1="-2.159" x2="-12.954" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-2.159" x2="-12.446" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-2.159" x2="-12.954" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-1.778" x2="-13.335" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-1.524" x2="-12.954" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="1.778" x2="-12.954" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="2.413" x2="-12.954" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-12.954" y1="2.54" x2="-12.954" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="2.54" x2="-12.446" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-2.159" x2="-7.874" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-2.286" x2="-9.906" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-7.366" y1="-2.159" x2="-7.874" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-7.366" y1="-2.159" x2="-7.366" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-1.778" x2="-8.255" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-1.27" x2="-8.255" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-1.524" x2="-8.255" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-1.778" x2="-6.985" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-1.524" x2="-6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-1.524" x2="-7.874" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-1.524" x2="-7.366" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-7.366" y1="-1.524" x2="-6.985" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="2.54" x2="-6.604" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="2.54" x2="-6.096" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-7.366" y1="2.413" x2="-7.366" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="2.413" x2="-7.874" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="2.667" x2="-6.604" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-7.366" y1="2.54" x2="-6.604" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="2.413" x2="-7.366" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="2.54" x2="-8.636" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="1.778" x2="-7.874" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-7.366" y1="1.778" x2="-7.366" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="1.778" x2="-7.874" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-1.778" x2="-8.255" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="1.778" x2="-7.366" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="-2.159" x2="-5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="-2.286" x2="-7.366" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.159" x2="-5.334" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.159" x2="-4.826" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.778" x2="-5.715" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-1.27" x2="-5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.524" x2="-5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.778" x2="-4.445" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.524" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.524" x2="-5.334" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="-1.524" x2="-4.826" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-1.524" x2="-4.445" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="2.54" x2="-4.064" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="2.54" x2="-3.556" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.413" x2="-4.826" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="2.413" x2="-5.334" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="2.667" x2="-4.064" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.54" x2="-4.064" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="2.413" x2="-4.826" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="2.54" x2="-6.096" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-7.366" y1="1.778" x2="-5.334" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="1.778" x2="-4.826" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="1.778" x2="-5.334" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.778" x2="-5.715" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="1.778" x2="-4.826" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-2.159" x2="-2.794" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-2.286" x2="-4.826" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-2.159" x2="-2.794" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-2.159" x2="-2.286" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.778" x2="-3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.27" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.524" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.524" x2="-2.794" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-1.524" x2="-2.286" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.524" x2="-1.905" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="2.413" x2="-2.286" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="2.413" x2="-2.794" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="2.413" x2="-2.286" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="2.54" x2="-3.556" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="1.778" x2="-2.794" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="1.778" x2="-2.794" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.778" x2="-3.175" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="1.778" x2="-2.286" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="2.413" x2="0.254" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.778" x2="-0.254" y2="1.778" width="0.1524" layer="21"/>
<wire x1="0.254" y1="1.778" x2="0.254" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.778" x2="-0.254" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.778" x2="-0.635" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.778" x2="0.254" y2="1.778" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-2.159" x2="2.286" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-2.159" x2="2.286" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-2.159" x2="2.794" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.778" x2="3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.524" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.524" x2="2.794" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-1.524" x2="3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.556" y1="2.54" x2="3.556" y2="2.667" width="0.1524" layer="21"/>
<wire x1="4.064" y1="2.54" x2="4.064" y2="2.667" width="0.1524" layer="21"/>
<wire x1="2.794" y1="2.413" x2="2.794" y2="2.54" width="0.1524" layer="21"/>
<wire x1="2.286" y1="2.413" x2="2.286" y2="2.54" width="0.1524" layer="21"/>
<wire x1="4.064" y1="2.667" x2="3.556" y2="2.667" width="0.1524" layer="21"/>
<wire x1="2.794" y1="2.54" x2="3.556" y2="2.54" width="0.1524" layer="21"/>
<wire x1="2.286" y1="2.413" x2="2.794" y2="2.413" width="0.1524" layer="21"/>
<wire x1="2.286" y1="2.54" x2="1.524" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.254" y1="1.778" x2="2.286" y2="1.778" width="0.1524" layer="21"/>
<wire x1="2.794" y1="1.778" x2="2.794" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.778" x2="1.905" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.778" x2="2.794" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.159" x2="4.826" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.286" x2="2.794" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.334" y1="-2.159" x2="4.826" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="5.334" y1="-2.159" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.778" x2="4.445" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.524" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.778" x2="5.715" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.524" x2="5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.524" x2="4.826" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-1.524" x2="5.334" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.334" y1="-1.524" x2="5.715" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.096" y1="2.54" x2="6.096" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.54" x2="6.604" y2="2.667" width="0.1524" layer="21"/>
<wire x1="5.334" y1="2.413" x2="5.334" y2="2.54" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.413" x2="4.826" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.667" x2="6.096" y2="2.667" width="0.1524" layer="21"/>
<wire x1="5.334" y1="2.54" x2="6.096" y2="2.54" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.413" x2="5.334" y2="2.413" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.54" x2="4.064" y2="2.54" width="0.1524" layer="21"/>
<wire x1="2.794" y1="1.778" x2="4.826" y2="1.778" width="0.1524" layer="21"/>
<wire x1="5.334" y1="1.778" x2="5.334" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.826" y1="1.778" x2="4.826" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.778" x2="4.445" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="4.826" y1="1.778" x2="5.334" y2="1.778" width="0.1524" layer="21"/>
<wire x1="7.366" y1="-2.159" x2="7.366" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="7.366" y1="-2.286" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="7.874" y1="-2.159" x2="7.366" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="7.874" y1="-2.159" x2="7.874" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-1.778" x2="6.985" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.27" x2="6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-1.524" x2="6.985" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-1.778" x2="8.255" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-1.524" x2="8.255" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-1.524" x2="7.366" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="7.366" y1="-1.524" x2="7.874" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="7.874" y1="-1.524" x2="8.255" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="8.636" y1="2.54" x2="8.636" y2="2.667" width="0.1524" layer="21"/>
<wire x1="9.144" y1="2.54" x2="9.144" y2="2.667" width="0.1524" layer="21"/>
<wire x1="7.874" y1="2.413" x2="7.874" y2="2.54" width="0.1524" layer="21"/>
<wire x1="7.366" y1="2.413" x2="7.366" y2="2.54" width="0.1524" layer="21"/>
<wire x1="9.144" y1="2.667" x2="8.636" y2="2.667" width="0.1524" layer="21"/>
<wire x1="7.874" y1="2.54" x2="8.636" y2="2.54" width="0.1524" layer="21"/>
<wire x1="7.366" y1="2.413" x2="7.874" y2="2.413" width="0.1524" layer="21"/>
<wire x1="7.366" y1="2.54" x2="6.604" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.334" y1="1.778" x2="7.366" y2="1.778" width="0.1524" layer="21"/>
<wire x1="7.874" y1="1.778" x2="7.874" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="7.366" y1="1.778" x2="7.366" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-1.778" x2="6.985" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="7.366" y1="1.778" x2="7.874" y2="1.778" width="0.1524" layer="21"/>
<wire x1="9.906" y1="-2.159" x2="9.906" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="9.906" y1="-2.286" x2="7.874" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="10.414" y1="-2.159" x2="9.906" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="10.414" y1="-2.159" x2="10.414" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-1.778" x2="9.525" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-1.27" x2="9.525" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-1.524" x2="9.525" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-1.778" x2="10.795" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-1.524" x2="10.795" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-1.524" x2="9.906" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="9.906" y1="-1.524" x2="10.414" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="10.414" y1="-1.524" x2="10.795" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="11.176" y1="2.54" x2="11.176" y2="2.667" width="0.1524" layer="21"/>
<wire x1="11.684" y1="2.54" x2="11.684" y2="2.667" width="0.1524" layer="21"/>
<wire x1="10.414" y1="2.413" x2="10.414" y2="2.54" width="0.1524" layer="21"/>
<wire x1="9.906" y1="2.413" x2="9.906" y2="2.54" width="0.1524" layer="21"/>
<wire x1="11.684" y1="2.667" x2="11.176" y2="2.667" width="0.1524" layer="21"/>
<wire x1="10.414" y1="2.54" x2="11.176" y2="2.54" width="0.1524" layer="21"/>
<wire x1="9.906" y1="2.413" x2="10.414" y2="2.413" width="0.1524" layer="21"/>
<wire x1="9.906" y1="2.54" x2="9.144" y2="2.54" width="0.1524" layer="21"/>
<wire x1="7.874" y1="1.778" x2="9.906" y2="1.778" width="0.1524" layer="21"/>
<wire x1="10.414" y1="1.778" x2="10.414" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="9.906" y1="1.778" x2="9.906" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-1.778" x2="9.525" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="9.906" y1="1.778" x2="10.414" y2="1.778" width="0.1524" layer="21"/>
<wire x1="12.446" y1="-2.159" x2="12.446" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="12.446" y1="-2.286" x2="10.414" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="12.954" y1="-2.159" x2="12.446" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="12.954" y1="-2.159" x2="12.954" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="12.065" y1="-1.778" x2="12.065" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-1.27" x2="12.065" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="12.065" y1="-1.524" x2="12.065" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="13.335" y1="-1.778" x2="13.335" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="13.335" y1="-1.524" x2="13.335" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="12.065" y1="-1.524" x2="12.446" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="12.446" y1="-1.524" x2="12.954" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="12.954" y1="-1.524" x2="13.335" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="13.716" y1="2.54" x2="13.716" y2="2.667" width="0.1524" layer="21"/>
<wire x1="14.224" y1="2.54" x2="14.224" y2="2.667" width="0.1524" layer="21"/>
<wire x1="12.954" y1="2.413" x2="12.954" y2="2.54" width="0.1524" layer="21"/>
<wire x1="12.446" y1="2.413" x2="12.446" y2="2.54" width="0.1524" layer="21"/>
<wire x1="14.224" y1="2.667" x2="13.716" y2="2.667" width="0.1524" layer="21"/>
<wire x1="12.954" y1="2.54" x2="13.716" y2="2.54" width="0.1524" layer="21"/>
<wire x1="12.446" y1="2.413" x2="12.954" y2="2.413" width="0.1524" layer="21"/>
<wire x1="12.446" y1="2.54" x2="11.684" y2="2.54" width="0.1524" layer="21"/>
<wire x1="10.414" y1="1.778" x2="12.446" y2="1.778" width="0.1524" layer="21"/>
<wire x1="12.954" y1="1.778" x2="12.954" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="12.446" y1="1.778" x2="12.446" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="13.335" y1="-1.778" x2="12.065" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="12.446" y1="1.778" x2="12.954" y2="1.778" width="0.1524" layer="21"/>
<wire x1="14.986" y1="-2.159" x2="14.986" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="14.986" y1="-2.286" x2="12.954" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="15.494" y1="-2.159" x2="14.986" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="15.494" y1="-2.159" x2="15.494" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="14.605" y1="-1.778" x2="14.605" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="13.335" y1="-1.27" x2="14.605" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="14.605" y1="-1.524" x2="14.605" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="15.875" y1="-1.778" x2="15.875" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="15.875" y1="-1.524" x2="15.875" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="14.605" y1="-1.524" x2="14.986" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="14.986" y1="-1.524" x2="15.494" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="15.494" y1="-1.524" x2="15.875" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="16.256" y1="2.54" x2="16.256" y2="2.667" width="0.1524" layer="21"/>
<wire x1="16.764" y1="2.54" x2="16.764" y2="2.667" width="0.1524" layer="21"/>
<wire x1="15.494" y1="2.413" x2="15.494" y2="2.54" width="0.1524" layer="21"/>
<wire x1="14.986" y1="2.413" x2="14.986" y2="2.54" width="0.1524" layer="21"/>
<wire x1="16.764" y1="2.667" x2="16.256" y2="2.667" width="0.1524" layer="21"/>
<wire x1="15.494" y1="2.54" x2="16.256" y2="2.54" width="0.1524" layer="21"/>
<wire x1="14.986" y1="2.413" x2="15.494" y2="2.413" width="0.1524" layer="21"/>
<wire x1="14.986" y1="2.54" x2="14.224" y2="2.54" width="0.1524" layer="21"/>
<wire x1="12.954" y1="1.778" x2="14.986" y2="1.778" width="0.1524" layer="21"/>
<wire x1="15.494" y1="1.778" x2="15.494" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="14.986" y1="1.778" x2="14.986" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="15.875" y1="-1.778" x2="14.605" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="14.986" y1="1.778" x2="15.494" y2="1.778" width="0.1524" layer="21"/>
<wire x1="16.764" y1="2.54" x2="17.526" y2="2.54" width="0.1524" layer="21"/>
<wire x1="15.494" y1="1.778" x2="17.399" y2="1.778" width="0.1524" layer="21"/>
<wire x1="15.875" y1="-1.27" x2="17.145" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="17.526" y1="-2.286" x2="15.494" y2="-2.286" width="0.1524" layer="21"/>
<pad name="1" x="-19.05" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="2" x="-16.51" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="3" x="-13.97" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="4" x="-11.43" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="5" x="-8.89" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="7" x="-3.81" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="6" x="-6.35" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="16" x="19.05" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="8" x="-1.27" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="9" x="1.27" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="10" x="3.81" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="11" x="6.35" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="12" x="8.89" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="13" x="11.43" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="14" x="13.97" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="15" x="16.51" y="0" drill="0.9144" shape="long" rot="R90"/>
<text x="-18.542" y="0.9398" size="0.9906" layer="21" ratio="12" rot="R90">1</text>
<text x="-20.066" y="2.9464" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-20.066" y="-3.8354" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-19.3802" y1="-0.3302" x2="-18.7198" y2="0.3302" layer="51"/>
<rectangle x1="-16.8402" y1="-0.3302" x2="-16.1798" y2="0.3302" layer="51"/>
<rectangle x1="-14.3002" y1="-0.3302" x2="-13.6398" y2="0.3302" layer="51"/>
<rectangle x1="-11.7602" y1="-0.3302" x2="-11.0998" y2="0.3302" layer="51"/>
<rectangle x1="-9.2202" y1="-0.3302" x2="-8.5598" y2="0.3302" layer="51"/>
<rectangle x1="-4.1402" y1="-0.3302" x2="-3.4798" y2="0.3302" layer="51"/>
<rectangle x1="-6.6802" y1="-0.3302" x2="-6.0198" y2="0.3302" layer="51"/>
<rectangle x1="18.7198" y1="-0.3302" x2="19.3802" y2="0.3302" layer="51"/>
<rectangle x1="3.4798" y1="-0.3302" x2="4.1402" y2="0.3302" layer="51"/>
<rectangle x1="6.0198" y1="-0.3302" x2="6.6802" y2="0.3302" layer="51"/>
<rectangle x1="8.5598" y1="-0.3302" x2="9.2202" y2="0.3302" layer="51"/>
<rectangle x1="11.0998" y1="-0.3302" x2="11.7602" y2="0.3302" layer="51"/>
<rectangle x1="13.6398" y1="-0.3302" x2="14.3002" y2="0.3302" layer="51"/>
<rectangle x1="16.1798" y1="-0.3302" x2="16.8402" y2="0.3302" layer="51"/>
</package>
</packages>
</library>
<library name="led">
<description>&lt;b&gt;LEDs&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;br&gt;
Extended by Federico Battaglin &lt;author&gt;&amp;lt;federico.rd@fdpinternational.com&amp;gt;&lt;/author&gt; with DUOLED</description>
<packages>
<package name="LED3MM">
<description>&lt;B&gt;LED&lt;/B&gt;&lt;p&gt;
3 mm, round</description>
<wire x1="1.5748" y1="-1.27" x2="1.5748" y2="1.27" width="0.254" layer="51"/>
<wire x1="-1.524" y1="0" x2="-1.1708" y2="0.9756" width="0.1524" layer="51" curve="-39.80361"/>
<wire x1="-1.524" y1="0" x2="-1.1391" y2="-1.0125" width="0.1524" layer="51" curve="41.633208"/>
<wire x1="1.1571" y1="0.9918" x2="1.524" y2="0" width="0.1524" layer="51" curve="-40.601165"/>
<wire x1="1.1708" y1="-0.9756" x2="1.524" y2="0" width="0.1524" layer="51" curve="39.80361"/>
<wire x1="0" y1="1.524" x2="1.2401" y2="0.8858" width="0.1524" layer="21" curve="-54.461337"/>
<wire x1="-1.2192" y1="0.9144" x2="0" y2="1.524" width="0.1524" layer="21" curve="-53.130102"/>
<wire x1="0" y1="-1.524" x2="1.203" y2="-0.9356" width="0.1524" layer="21" curve="52.126876"/>
<wire x1="-1.203" y1="-0.9356" x2="0" y2="-1.524" width="0.1524" layer="21" curve="52.126876"/>
<wire x1="-0.635" y1="0" x2="0" y2="0.635" width="0.1524" layer="51" curve="-90"/>
<wire x1="-1.016" y1="0" x2="0" y2="1.016" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-0.635" x2="0.635" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="0" y1="-1.016" x2="1.016" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="0" y1="2.032" x2="1.561" y2="1.3009" width="0.254" layer="21" curve="-50.193108"/>
<wire x1="-1.7929" y1="0.9562" x2="0" y2="2.032" width="0.254" layer="21" curve="-61.926949"/>
<wire x1="0" y1="-2.032" x2="1.5512" y2="-1.3126" width="0.254" layer="21" curve="49.763022"/>
<wire x1="-1.7643" y1="-1.0082" x2="0" y2="-2.032" width="0.254" layer="21" curve="60.255215"/>
<wire x1="-2.032" y1="0" x2="-1.7891" y2="0.9634" width="0.254" layer="51" curve="-28.301701"/>
<wire x1="-2.032" y1="0" x2="-1.7306" y2="-1.065" width="0.254" layer="51" curve="31.60822"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="K" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="1.905" y="0.381" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="1.905" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="resistor">
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;/ul&gt;
&lt;p&gt;
&lt;p&gt;
&lt;map name="nav_main"&gt;
&lt;area shape="rect" coords="0,1,140,23" href="../military_specs.asp" title=""&gt;
&lt;area shape="rect" coords="0,24,140,51" href="../about.asp" title=""&gt;
&lt;area shape="rect" coords="1,52,140,77" href="../rfq.asp" title=""&gt;
&lt;area shape="rect" coords="0,78,139,103" href="../products.asp" title=""&gt;
&lt;area shape="rect" coords="1,102,138,128" href="../excess_inventory.asp" title=""&gt;
&lt;area shape="rect" coords="1,129,138,150" href="../edge.asp" title=""&gt;
&lt;area shape="rect" coords="1,151,139,178" href="../industry_links.asp" title=""&gt;
&lt;area shape="rect" coords="0,179,139,201" href="../comments.asp" title=""&gt;
&lt;area shape="rect" coords="1,203,138,231" href="../directory.asp" title=""&gt;
&lt;area shape="default" nohref&gt;
&lt;/map&gt;
&lt;html&gt;
&lt;title&gt;&lt;/title&gt;
 &lt;LINK REL="StyleSheet" TYPE="text/css" HREF="style-sheet.css"&gt;
&lt;body bgcolor="#ffffff" text="#000000" marginwidth="0" marginheight="0" topmargin="0" leftmargin="0"&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0 height="55%"&gt;
&lt;/td&gt;
&lt;P&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;/B&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
   &lt;TD ALIGN=CENTER&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
  &lt;TR&gt;
      &lt;P&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
    &lt;/TD&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;
&lt;/BODY&gt;&lt;/HTML&gt;</description>
<packages>
<package name="153CLV-0605">
<description>&lt;b&gt;Aluminum electrolytic capacitors&lt;/b&gt;&lt;p&gt;
SMD (Chip) Long Life Vertical 153 CLV&lt;p&gt;
http://www.bccomponents.com/</description>
<wire x1="2.4" y1="-3.3" x2="-3.3" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-3.3" x2="-3.3" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-1.1" x2="-3.3" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-3.3" y1="1.1" x2="-3.3" y2="3.3" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="3.3" x2="2.4" y2="3.3" width="0.2032" layer="21"/>
<wire x1="3.3" y1="2.4" x2="3.3" y2="1.1" width="0.2032" layer="21"/>
<wire x1="3.3" y1="1.1" x2="3.3" y2="-1.1" width="0.2032" layer="51"/>
<wire x1="3.3" y1="-1.1" x2="3.3" y2="-2.4" width="0.2032" layer="21"/>
<wire x1="3.3" y1="-2.4" x2="2.4" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="2.4" y1="3.3" x2="3.3" y2="2.4" width="0.2032" layer="21"/>
<wire x1="-2.95" y1="-0.9" x2="2.95" y2="-0.95" width="0.2032" layer="21" curve="145.181395"/>
<wire x1="-2.95" y1="-0.9" x2="-2.95" y2="0.95" width="0.2032" layer="51" curve="-34.818605"/>
<wire x1="-2.95" y1="0.95" x2="2.95" y2="0.9" width="0.2032" layer="21" curve="-145.181395"/>
<wire x1="2.95" y1="-0.95" x2="2.95" y2="0.9" width="0.2032" layer="51" curve="34.818605"/>
<smd name="+" x="2.7" y="0" dx="3.5" dy="1.6" layer="1"/>
<smd name="-" x="-2.7" y="0" dx="3.5" dy="1.6" layer="1"/>
<text x="-3.39" y="3.63" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.425" y="-4.885" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="C1206">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
chip</description>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-0.965" y1="0.787" x2="0.965" y2="0.787" width="0.1016" layer="51"/>
<wire x1="-0.965" y1="-0.787" x2="0.965" y2="-0.787" width="0.1016" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<text x="-1.27" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-0.8509" x2="-0.9517" y2="0.8491" layer="51"/>
<rectangle x1="0.9517" y1="-0.8491" x2="1.7018" y2="0.8509" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="CT7343">
chip
tantalum</description>
<wire x1="-4.973" y1="2.483" x2="4.973" y2="2.483" width="0.0508" layer="39"/>
<wire x1="4.973" y1="-2.483" x2="-4.973" y2="-2.483" width="0.0508" layer="39"/>
<wire x1="-4.973" y1="-2.483" x2="-4.973" y2="2.483" width="0.0508" layer="39"/>
<wire x1="4.973" y1="2.483" x2="4.973" y2="-2.483" width="0.0508" layer="39"/>
<wire x1="3.592" y1="2.195" x2="3.592" y2="-2.195" width="0.2032" layer="51"/>
<wire x1="3.734" y1="-1.143" x2="3.734" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-3.582" y1="-2.195" x2="3.592" y2="-2.195" width="0.2032" layer="21"/>
<wire x1="-3.582" y1="2.195" x2="3.592" y2="2.195" width="0.2032" layer="21"/>
<wire x1="-3.734" y1="-1.143" x2="-3.734" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-3.582" y1="2.195" x2="-3.582" y2="-2.195" width="0.2032" layer="51"/>
<wire x1="2.04" y1="0" x2="3.09" y2="0" width="0.2032" layer="51"/>
<wire x1="2.55" y1="-0.52" x2="2.55" y2="0.52" width="0.2032" layer="51"/>
<wire x1="3.592" y1="-1.615" x2="3.592" y2="-2.195" width="0.2032" layer="21"/>
<wire x1="-3.582" y1="-1.615" x2="-3.582" y2="-2.195" width="0.2032" layer="21"/>
<wire x1="3.592" y1="2.195" x2="3.592" y2="1.615" width="0.2032" layer="21"/>
<wire x1="-3.582" y1="2.195" x2="-3.582" y2="1.615" width="0.2032" layer="21"/>
<smd name="+" x="3.2" y="0" dx="2.6" dy="2.4" layer="1"/>
<smd name="-" x="-3.2" y="0" dx="2.6" dy="2.4" layer="1"/>
<text x="-3.175" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.175" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="A/3216-18R">
<description>&lt;b&gt;Chip Capacitor Type KEMET A / EIA 3216-18 Reflow solder&lt;/b&gt;&lt;p&gt;
KEMET S / EIA 3216-12</description>
<wire x1="-1.45" y1="0.6" x2="1.45" y2="0.6" width="0.1016" layer="51"/>
<wire x1="1.45" y1="0.6" x2="1.45" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="1.45" y1="-0.6" x2="-1.45" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="-1.45" y1="-0.6" x2="-1.45" y2="0.6" width="0.1016" layer="51"/>
<smd name="+" x="1.375" y="0" dx="1.95" dy="1.5" layer="1"/>
<smd name="-" x="-1.375" y="0" dx="1.95" dy="1.5" layer="1"/>
<text x="-1.95" y="1" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.95" y="-2.325" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-0.6" x2="-1.475" y2="0.6" layer="51"/>
<rectangle x1="1.475" y1="-0.6" x2="1.6" y2="0.6" layer="51"/>
<rectangle x1="0.8" y1="-0.625" x2="1.1" y2="0.625" layer="51"/>
</package>
<package name="M3516">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
MELF 0.12 W</description>
<wire x1="-2.973" y1="0.983" x2="2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-0.983" x2="-2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-0.983" x2="-2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="0.983" x2="2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.3208" y1="0.762" x2="-1.3208" y2="0.762" width="0.1524" layer="51"/>
<wire x1="1.3208" y1="-0.762" x2="-1.3208" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="0.6858" y1="0.762" x2="-0.6858" y2="0.762" width="0.1524" layer="21"/>
<wire x1="0.6858" y1="-0.762" x2="-0.6858" y2="-0.762" width="0.1524" layer="21"/>
<smd name="1" x="-1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<smd name="2" x="1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<text x="-1.651" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.651" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.8542" y1="-0.8382" x2="-1.2954" y2="0.8382" layer="51"/>
<rectangle x1="1.2954" y1="-0.8382" x2="1.8542" y2="0.8382" layer="51"/>
<rectangle x1="-0.4001" y1="-0.7" x2="0.4001" y2="0.7" layer="35"/>
</package>
<package name="M1206">
MELF 0.25 W</description>
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="1.143" y1="0.8382" x2="-1.143" y2="0.8382" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.8382" x2="-1.143" y2="-0.8382" width="0.1524" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-0.9144" x2="-1.1176" y2="0.9144" layer="51"/>
<rectangle x1="1.1176" y1="-0.9144" x2="1.7018" y2="0.9144" layer="51"/>
<rectangle x1="-0.3" y1="-0.8001" x2="0.3" y2="0.8001" layer="35"/>
</package>
<package name="R2010W">
chip, wave soldering</description>
<wire x1="-1.662" y1="1.245" x2="1.662" y2="1.245" width="0.1524" layer="21"/>
<wire x1="-1.637" y1="-1.245" x2="1.687" y2="-1.245" width="0.1524" layer="21"/>
<wire x1="-3.473" y1="1.483" x2="3.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="3.473" y1="1.483" x2="3.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="3.473" y1="-1.483" x2="-3.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-3.473" y1="-1.483" x2="-3.473" y2="1.483" width="0.0508" layer="39"/>
<smd name="1" x="-2.311" y="0" dx="2" dy="1.8" layer="1"/>
<smd name="2" x="2.311" y="0" dx="2" dy="1.8" layer="1"/>
<text x="-2.286" y="1.524" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.286" y="-2.921" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.4892" y1="-1.3208" x2="-1.6393" y2="1.3292" layer="51"/>
<rectangle x1="1.651" y1="-1.3208" x2="2.5009" y2="1.3292" layer="51"/>
</package>
<package name="M1406">
<rectangle x1="-0.3" y1="-0.7" x2="0.3" y2="0.7" layer="35"/>
</package>
<package name="C3216">
chip</description>
<rectangle x1="-0.3" y1="-0.5001" x2="0.3" y2="0.5001" layer="35"/>
</package>
</packages>
</library>
<library name="v-reg">
<description>&lt;b&gt;Voltage Regulators&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DPACK">
<description>&lt;b&gt;DPAK&lt;/b&gt;&lt;p&gt;
PLASTIC PACKAGE CASE 369C-01&lt;br&gt;
Source: http://www.onsemi.co.jp .. LM317M-D.PDF</description>
<wire x1="3.2766" y1="3.8354" x2="3.277" y2="-2.159" width="0.2032" layer="21"/>
<wire x1="3.277" y1="-2.159" x2="-3.277" y2="-2.159" width="0.2032" layer="21"/>
<wire x1="-3.277" y1="-2.159" x2="-3.2766" y2="3.8354" width="0.2032" layer="21"/>
<wire x1="-3.277" y1="3.835" x2="3.2774" y2="3.8346" width="0.2032" layer="51"/>
<wire x1="-2.5654" y1="3.937" x2="-2.5654" y2="4.6482" width="0.2032" layer="51"/>
<wire x1="-2.5654" y1="4.6482" x2="-2.1082" y2="5.1054" width="0.2032" layer="51"/>
<wire x1="-2.1082" y1="5.1054" x2="2.1082" y2="5.1054" width="0.2032" layer="51"/>
<wire x1="2.1082" y1="5.1054" x2="2.5654" y2="4.6482" width="0.2032" layer="51"/>
<wire x1="2.5654" y1="4.6482" x2="2.5654" y2="3.937" width="0.2032" layer="51"/>
<wire x1="2.5654" y1="3.937" x2="-2.5654" y2="3.937" width="0.2032" layer="51"/>
<smd name="4" x="0" y="2.38" dx="5.8" dy="6.2" layer="1"/>
<smd name="1" x="-2.28" y="-4.8" dx="1.6" dy="3" layer="1"/>
<smd name="3" x="2.28" y="-4.8" dx="1.6" dy="3" layer="1"/>
<text x="-3.81" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="5.08" y="-2.54" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.7178" y1="-5.1562" x2="-1.8542" y2="-2.2606" layer="51"/>
<rectangle x1="1.8542" y1="-5.1562" x2="2.7178" y2="-2.2606" layer="51"/>
<rectangle x1="-0.4318" y1="-3.0226" x2="0.4318" y2="-2.2606" layer="21"/>
<polygon width="0.1998" layer="51">
<vertex x="-2.5654" y="3.937"/>
<vertex x="-2.5654" y="4.6482"/>
<vertex x="-2.1082" y="5.1054"/>
<vertex x="2.1082" y="5.1054"/>
<vertex x="2.5654" y="4.6482"/>
<vertex x="2.5654" y="3.937"/>
</polygon>
</package>
<package name="SO-08">
<description>&lt;B&gt;Small Outline Narrow Plastic Gull Wing&lt;/B&gt;&lt;p&gt;
150-mil body, package type SN</description>
<wire x1="-2.9" y1="3.9" x2="2.9" y2="3.9" width="0.1998" layer="39"/>
<wire x1="2.9" y1="3.9" x2="2.9" y2="-3.9" width="0.1998" layer="39"/>
<wire x1="2.9" y1="-3.9" x2="-2.9" y2="-3.9" width="0.1998" layer="39"/>
<wire x1="-2.9" y1="-3.9" x2="-2.9" y2="3.9" width="0.1998" layer="39"/>
<wire x1="2.4" y1="1.9" x2="2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.9" x2="-2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.9" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.4" x2="-2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="1.9" x2="2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<smd name="2" x="-0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="7" x="-0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="1" x="-1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="3" x="0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="4" x="1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="8" x="-1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="6" x="0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="5" x="1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<text x="-2.667" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.937" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<text x="-1.905" y="-0.635" size="0.4064" layer="48">IPC SO8</text>
<text x="-1.905" y="0.365" size="0.3048" layer="48">JEDEC MS-012 AA</text>
<rectangle x1="-2.1501" y1="-3.1001" x2="-1.6599" y2="-2" layer="51"/>
<rectangle x1="-0.8801" y1="-3.1001" x2="-0.3899" y2="-2" layer="51"/>
<rectangle x1="0.3899" y1="-3.1001" x2="0.8801" y2="-2" layer="51"/>
<rectangle x1="1.6599" y1="-3.1001" x2="2.1501" y2="-2" layer="51"/>
<rectangle x1="1.6599" y1="2" x2="2.1501" y2="3.1001" layer="51"/>
<rectangle x1="0.3899" y1="2" x2="0.8801" y2="3.1001" layer="51"/>
<rectangle x1="-0.8801" y1="2" x2="-0.3899" y2="3.1001" layer="51"/>
<rectangle x1="-2.1501" y1="2" x2="-1.6599" y2="3.1001" layer="51"/>
<rectangle x1="-1" y1="-1" x2="1" y2="1" layer="35"/>
</package>
</packages>
</library>
<library name="diode">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
<packages>
<package name="SOT23">
<description>&lt;B&gt;DIODE&lt;/B&gt;</description>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="-0.1524" x2="-1.4224" y2="0.6604" width="0.1524" layer="21"/>
<wire x1="-1.4224" y1="0.6604" x2="-0.8636" y2="0.6604" width="0.1524" layer="21"/>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.1524" width="0.1524" layer="21"/>
<wire x1="0.8636" y1="0.6604" x2="1.4224" y2="0.6604" width="0.1524" layer="21"/>
<smd name="3" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="2" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="1" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2286" y1="0.7112" x2="0.2286" y2="1.2954" layer="51"/>
<rectangle x1="0.7112" y1="-1.2954" x2="1.1684" y2="-0.7112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.2954" x2="-0.7112" y2="-0.7112" layer="51"/>
</package>
<package name="SOD-123_MINI-SMA">
<description>&lt;b&gt;Molded plasitc,JEDEC SOD-123/Mini SMA&lt;/b&gt;&lt;p&gt;
Source: Comchip CGRM4001-G.pdf</description>
<wire x1="-1.8725" y1="0.835" x2="1.8725" y2="0.835" width="0.127" layer="51"/>
<wire x1="-1.8725" y1="-0.835" x2="1.8725" y2="-0.835" width="0.127" layer="51"/>
<wire x1="-0.3175" y1="0" x2="0.3175" y2="-0.4763" width="0.127" layer="21"/>
<wire x1="0.3175" y1="-0.4763" x2="0.3175" y2="0" width="0.127" layer="21"/>
<wire x1="0.3175" y1="0" x2="0.3175" y2="0.4763" width="0.127" layer="21"/>
<wire x1="0.3175" y1="0.4763" x2="-0.3175" y2="0" width="0.127" layer="21"/>
<wire x1="-0.3175" y1="0" x2="-0.3175" y2="-0.4763" width="0.127" layer="21"/>
<wire x1="-0.3175" y1="0" x2="-0.3175" y2="0.4763" width="0.127" layer="21"/>
<wire x1="0.3175" y1="0" x2="0.5613" y2="0" width="0.127" layer="21"/>
<wire x1="-0.3175" y1="0" x2="-0.5613" y2="0" width="0.127" layer="21"/>
<smd name="A" x="1.8" y="0" dx="1.5" dy="2.1" layer="1" rot="R180"/>
<smd name="C" x="-1.8" y="0" dx="1.5" dy="2.1" layer="1" rot="R180"/>
<text x="-3.048" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.048" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.95" y1="-0.9" x2="-1.5875" y2="0.9" layer="51"/>
<rectangle x1="1.5875" y1="-0.9" x2="1.95" y2="0.9" layer="51"/>
<rectangle x1="-1.0249" y1="-0.9" x2="-0.6625" y2="0.9" layer="51"/>
</package>
<package name="SOD80C">
<wire x1="1.3208" y1="0.7874" x2="-1.3208" y2="0.7874" width="0.1524" layer="51"/>
<wire x1="1.3208" y1="-0.7874" x2="-1.3208" y2="-0.7874" width="0.1524" layer="51"/>
<wire x1="0.627" y1="0.6" x2="-0.373" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.373" y1="0" x2="0.627" y2="-0.6" width="0.2032" layer="21"/>
<wire x1="0.627" y1="-0.6" x2="0.627" y2="0.6" width="0.2032" layer="21"/>
<smd name="C" x="-1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<smd name="A" x="1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<text x="-1.524" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.8542" y1="-0.8636" x2="-1.2954" y2="0.8636" layer="51"/>
<rectangle x1="1.2954" y1="-0.8636" x2="1.8542" y2="0.8636" layer="51"/>
<rectangle x1="-0.8636" y1="-0.7874" x2="-0.254" y2="0.7874" layer="21"/>
</package>
<package name="SMB">
<wire x1="-2.2606" y1="1.905" x2="2.2606" y2="1.905" width="0.1016" layer="21"/>
<wire x1="-2.2606" y1="-1.905" x2="2.2606" y2="-1.905" width="0.1016" layer="21"/>
<wire x1="-2.2606" y1="-1.905" x2="-2.2606" y2="1.905" width="0.1016" layer="51"/>
<wire x1="2.2606" y1="-1.905" x2="2.2606" y2="1.905" width="0.1016" layer="51"/>
<wire x1="0.193" y1="1" x2="-0.83" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.83" y1="0" x2="0.193" y2="-1" width="0.2032" layer="21"/>
<wire x1="0.193" y1="-1" x2="0.193" y2="1" width="0.2032" layer="21"/>
<smd name="C" x="-2.2" y="0" dx="2.4" dy="2.4" layer="1"/>
<smd name="A" x="2.2" y="0" dx="2.4" dy="2.4" layer="1"/>
<text x="-2.159" y="2.159" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.159" y="-3.429" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.794" y1="-1.0922" x2="-2.2606" y2="1.0922" layer="51"/>
<rectangle x1="2.2606" y1="-1.0922" x2="2.794" y2="1.0922" layer="51"/>
<rectangle x1="-1.35" y1="-1.9" x2="-0.8" y2="1.9" layer="51"/>
</package>
</packages>
</library>
<library name="con-amp-mt">
<description>&lt;b&gt;AMP Connectors, Type MT&lt;/b&gt;&lt;p&gt;
include  Type MT6; con-amp-mt6.lbr&lt;p&gt;
<packages>
<package name="L03P">
<description>&lt;b&gt;AMP MT CONNECTOR&lt;/b&gt;</description>
<wire x1="3.668" y1="-4.345" x2="-3.596" y2="-4.345" width="0.1524" layer="21"/>
<wire x1="3.668" y1="6.45" x2="4.176" y2="7.339" width="0.1524" layer="21"/>
<wire x1="3.668" y1="-3.456" x2="-3.596" y2="-3.456" width="0.1524" layer="21"/>
<wire x1="3.668" y1="-3.456" x2="3.668" y2="-4.345" width="0.1524" layer="21"/>
<wire x1="3.668" y1="6.45" x2="3.668" y2="5.815" width="0.1524" layer="21"/>
<wire x1="3.668" y1="5.815" x2="3.668" y2="-3.456" width="0.1524" layer="21"/>
<wire x1="3.668" y1="5.815" x2="-3.596" y2="5.815" width="0.1524" layer="21"/>
<wire x1="-3.596" y1="-3.456" x2="-3.596" y2="-4.345" width="0.1524" layer="21"/>
<wire x1="-3.596" y1="5.815" x2="-3.596" y2="-3.456" width="0.1524" layer="21"/>
<wire x1="-6.136" y1="-5.869" x2="-6.136" y2="7.339" width="0.1524" layer="21"/>
<wire x1="-6.136" y1="7.339" x2="-4.104" y2="7.339" width="0.1524" layer="21"/>
<wire x1="-4.104" y1="7.339" x2="-3.596" y2="6.45" width="0.1524" layer="21"/>
<wire x1="-3.596" y1="6.45" x2="-3.596" y2="5.815" width="0.1524" layer="21"/>
<wire x1="6.183" y1="-5.869" x2="6.183" y2="7.339" width="0.1524" layer="21"/>
<wire x1="6.183" y1="7.339" x2="4.176" y2="7.339" width="0.1524" layer="21"/>
<wire x1="2.5" y1="3.529" x2="2.5" y2="3.021" width="0.6604" layer="21"/>
<wire x1="6.183" y1="-5.869" x2="3.491" y2="-5.869" width="0.1524" layer="21"/>
<wire x1="1.509" y1="-5.869" x2="3.491" y2="-5.869" width="0.1524" layer="51"/>
<wire x1="1.509" y1="-5.869" x2="1.001" y2="-5.869" width="0.1524" layer="21"/>
<wire x1="-0.98" y1="-5.869" x2="1.001" y2="-5.869" width="0.1524" layer="51"/>
<wire x1="-0.98" y1="-5.869" x2="-1.488" y2="-5.869" width="0.1524" layer="21"/>
<wire x1="-3.469" y1="-5.869" x2="-1.488" y2="-5.869" width="0.1524" layer="51"/>
<wire x1="-3.494" y1="-5.869" x2="-6.136" y2="-5.869" width="0.1524" layer="21"/>
<wire x1="0" y1="3.529" x2="0" y2="3.021" width="0.6604" layer="21"/>
<wire x1="-2.504" y1="3.529" x2="-2.504" y2="3.021" width="0.6604" layer="21"/>
<pad name="3" x="-2.5" y="-6.25" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="-6.25" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="2.5" y="-6.25" drill="1.016" shape="long" rot="R90"/>
<text x="-6.0344" y="-8.79" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.485" y="-1.17" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="5.6242" y="-4.345" size="1.27" layer="21" ratio="10" rot="R90">1</text>
<text x="-4.0532" y="-4.472" size="1.27" layer="21" ratio="10" rot="R90">3</text>
<rectangle x1="2.1952" y1="-3.456" x2="2.8048" y2="3.148" layer="21"/>
<rectangle x1="2.1952" y1="-6.504" x2="2.8048" y2="-5.869" layer="51"/>
<rectangle x1="-0.294" y1="-3.456" x2="0.3156" y2="3.148" layer="21"/>
<rectangle x1="-0.294" y1="-6.504" x2="0.3156" y2="-5.869" layer="51"/>
<rectangle x1="-2.8086" y1="-6.504" x2="-2.199" y2="-5.869" layer="51"/>
<rectangle x1="-2.8086" y1="-3.456" x2="-2.199" y2="3.148" layer="21"/>
</package>
</packages>
</library>
<library name="crystal">
<description>&lt;b&gt;Crystals and Crystal Resonators&lt;/b&gt;&lt;p&gt;
<packages>
<package name="SM49">
<description>&lt;b&gt;CRYSTAL&lt;/b&gt;</description>
<wire x1="3.429" y1="-2.032" x2="5.109" y2="-1.1429" width="0.0508" layer="21" curve="55.771157"/>
<wire x1="5.715" y1="-1.143" x2="5.715" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-5.1091" y1="-1.143" x2="-3.429" y2="-2.032" width="0.0508" layer="21" curve="55.772485"/>
<wire x1="-5.715" y1="-1.143" x2="-5.715" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.27" x2="3.429" y2="1.27" width="0.0508" layer="21"/>
<wire x1="-3.429" y1="2.032" x2="3.429" y2="2.032" width="0.0508" layer="21"/>
<wire x1="3.429" y1="-1.27" x2="-3.429" y2="-1.27" width="0.0508" layer="21"/>
<wire x1="-5.461" y1="2.413" x2="5.461" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="0.381" x2="-6.477" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="-0.381" x2="-6.477" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="0.381" x2="-6.477" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="2.159" x2="-5.461" y2="2.413" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.715" y1="1.143" x2="-5.715" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="2.159" x2="-5.715" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.9826" y1="1.143" x2="-3.429" y2="1.27" width="0.0508" layer="21" curve="-25.842828"/>
<wire x1="-3.9826" y1="-1.143" x2="-3.429" y2="-1.27" width="0.0508" layer="21" curve="25.842828"/>
<wire x1="-5.1091" y1="1.143" x2="-3.429" y2="2.0321" width="0.0508" layer="21" curve="-55.770993"/>
<wire x1="-3.9826" y1="1.143" x2="-3.9826" y2="-1.143" width="0.0508" layer="51" curve="128.314524"/>
<wire x1="-5.1091" y1="1.143" x2="-5.1091" y2="-1.143" width="0.0508" layer="51" curve="68.456213"/>
<wire x1="3.429" y1="2.032" x2="5.1091" y2="1.143" width="0.0508" layer="21" curve="-55.772485"/>
<wire x1="3.9826" y1="1.143" x2="3.9826" y2="-1.143" width="0.0508" layer="51" curve="-128.314524"/>
<wire x1="3.429" y1="1.27" x2="3.9826" y2="1.143" width="0.0508" layer="21" curve="-25.842828"/>
<wire x1="3.429" y1="-1.27" x2="3.9826" y2="-1.143" width="0.0508" layer="21" curve="25.842828"/>
<wire x1="6.477" y1="0.381" x2="6.477" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="5.1091" y1="1.143" x2="5.1091" y2="-1.143" width="0.0508" layer="51" curve="-68.456213"/>
<wire x1="5.715" y1="1.143" x2="5.715" y2="0.381" width="0.1524" layer="51"/>
<wire x1="5.715" y1="0.381" x2="5.715" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="5.715" y1="-0.381" x2="5.715" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="5.715" y1="2.159" x2="5.715" y2="1.143" width="0.1524" layer="21"/>
<wire x1="5.461" y1="2.413" x2="5.715" y2="2.159" width="0.1524" layer="21" curve="-90"/>
<wire x1="5.715" y1="0.381" x2="6.477" y2="0.381" width="0.1524" layer="51"/>
<wire x1="5.715" y1="-0.381" x2="6.477" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-2.032" x2="-3.429" y2="-2.032" width="0.0508" layer="21"/>
<wire x1="-5.461" y1="-2.413" x2="5.461" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.159" x2="-5.461" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="5.461" y1="-2.413" x2="5.715" y2="-2.159" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.254" y1="0.635" x2="-0.254" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-0.635" x2="0.254" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-0.635" x2="0.254" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0.635" x2="-0.254" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0.635" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-1.143" y2="0" width="0.0508" layer="21"/>
<wire x1="0.635" y1="0.635" x2="0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="0.635" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.143" y2="0" width="0.0508" layer="21"/>
<smd name="1" x="-4.826" y="0" dx="5.08" dy="1.778" layer="1"/>
<smd name="2" x="4.826" y="0" dx="5.08" dy="1.778" layer="1"/>
<text x="-5.715" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.715" y="-4.064" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-6.604" y1="-2.54" x2="6.604" y2="2.794" layer="43"/>
</package>
</packages>
</library>
<library name="inductors">
<description>&lt;b&gt;Inductors and Filters&lt;/b&gt;&lt;p&gt;
Based on the previous library ind-a.lbr&lt;p&gt;
<packages>
<package name="DR73">
<description>&lt;b&gt;High Power Density, High Efficiency, Shielded Inductors&lt;/b&gt;&lt;p&gt;
Source: coiltronics_dr_series.pdf</description>
<wire x1="-3.7" y1="3.7" x2="3.7" y2="3.7" width="0.2032" layer="21"/>
<wire x1="3.7" y1="3.7" x2="3.7" y2="-3.7" width="0.2032" layer="21"/>
<wire x1="3.7" y1="-3.7" x2="-3.7" y2="-3.7" width="0.2032" layer="21"/>
<wire x1="-3.7" y1="-3.7" x2="-3.7" y2="3.7" width="0.2032" layer="21"/>
<wire x1="0" y1="2.975" x2="-2.4" y2="1.75" width="0.2032" layer="21" curve="53.855356"/>
<wire x1="0" y1="2.975" x2="2.4" y2="1.75" width="0.2032" layer="21" curve="-53.855356"/>
<wire x1="0" y1="-2.975" x2="2.4" y2="-1.75" width="0.2032" layer="21" curve="53.855356"/>
<wire x1="0" y1="-2.975" x2="-2.4" y2="-1.75" width="0.2032" layer="21" curve="-53.855356"/>
<circle x="0" y="0" radius="2.975" width="0.2032" layer="51"/>
<smd name="1" x="-3" y="0" dx="2.5" dy="3.25" layer="1"/>
<smd name="2" x="3" y="0" dx="2.5" dy="3.25" layer="1"/>
<text x="-3.5" y="4" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.5" y="-5.5" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.8215" y1="1.984" x2="-1.7215" y2="2.559" layer="21" rot="R45"/>
<rectangle x1="-2.8215" y1="-2.559" x2="-1.7215" y2="-1.984" layer="21" rot="R135"/>
<rectangle x1="1.7215" y1="-2.559" x2="2.8215" y2="-1.984" layer="21" rot="R225"/>
<rectangle x1="1.7215" y1="1.984" x2="2.8215" y2="2.559" layer="21" rot="R315"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules>
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="10mil"/>
<param name="mdPadVia" value="10mil"/>
<param name="mdViaVia" value="10mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="10mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="*"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="0"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="IC1" library="atmel" package="TQFP32-08" value="MEGA328 P" x="78.105" y="26.162" rot="R270">
<attribute name="OC_NEWARK" value="73M8863" x="73.024990625" y="8.382003125" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="ATMEGA8-16AU" x="73.024990625" y="8.382003125" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MF" value="" x="73.024990625" y="8.382003125" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_FARNELL" value="9171371" x="73.024990625" y="8.382003125" size="1.778" layer="27" rot="R270" display="off"/>
</element>
<element name="R1" library="rcl" package="M1206" value="680" x="67.507" y="26.141" rot="R179.9"/>
<element name="R2" library="rcl" package="M1206" value="470k" x="67.507" y="23.487" rot="R180"/>
<element name="R3" library="rcl" package="M1206" value="680" x="67.437" y="20.903" rot="R180"/>
<element name="R4" library="rcl" package="M1206" value="470k" x="67.437" y="18.319" rot="R179.8"/>
<element name="R5" library="rcl" package="M1206" value="680" x="73.795" y="16.618" rot="R270"/>
<element name="R6" library="rcl" package="M1206" value="470k" x="76.213" y="16.637" rot="R270"/>
<element name="R7" library="rcl" package="M1206" value="3,3k" x="59.836" y="21.24"/>
<element name="R8" library="rcl" package="M1206" value="27k" x="63.747" y="27.711" rot="R90.1"/>
<element name="R9" library="rcl" package="M1206" value="100k" x="61.082" y="24.969" rot="R269.9"/>
<element name="R10" library="rcl" package="M1206" value="33k" x="59.836" y="18.699" rot="R180"/>
<element name="R11" library="rcl" package="M1206" value="10k" x="91.111" y="28.602" rot="R89.9"/>
<element name="R12" library="rcl" package="M1206" value="3,3k" x="98.512" y="27.531"/>
<element name="R13" library="rcl" package="M1206" value="10k" x="88.519" y="28.575" rot="R90.1"/>
<element name="R14" library="rcl" package="M1206" value="27k" x="67.507" y="28.878" rot="R359.9"/>
<element name="R15" library="rcl" package="M1206" value="2,2k" x="94.597" y="28.702" rot="R90.1"/>
<element name="Q1" library="transistor-npn" package="SOT23" value="BC847" x="54.846" y="28.899" rot="R270"/>
<element name="Q2" library="transistor-npn" package="SOT23" value="BC847" x="54.846" y="25.908" rot="R90"/>
<element name="Q3" library="transistor-pnp" package="SOT23-BEC" value="BC857" x="60.582" y="14.605" rot="R180"/>
<element name="SL1" library="con-amp-quick" package="02P" value="9v külső" x="48.615" y="27.648" rot="R90">
<attribute name="OC_NEWARK" value="unknown" x="53.695" y="53.048" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="53.695" y="53.048" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MF" value="" x="53.695" y="53.048" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="53.695" y="53.048" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="LED1" library="led" package="LED3MM" value="led" x="48.514" y="23.002" rot="R90"/>
<element name="C1" library="resistor" package="C1206" value="1n" x="82.169" y="16.637" rot="R90"/>
<element name="C2" library="resistor" package="C1206" value="10n" x="58.476" y="24.941" rot="R90"/>
<element name="C3" library="resistor" package="C1206" value="100n" x="79.653" y="16.574" rot="R270"/>
<element name="C4" library="resistor" package="C1206" value="100n" x="78.382" y="35.338" rot="R90"/>
<element name="C5" library="resistor" package="C1206" value="100n" x="92.1546" y="35.772" rot="R90"/>
<element name="C6" library="resistor" package="C1206" value="100n" x="98.515" y="30.067"/>
<element name="IC2" library="v-reg" package="DPACK" value="7805" x="98.806" y="38.1"/>
<element name="C7" library="resistor" package="C1206" value=" 22p" x="65.909" y="32.971"/>
<element name="C8" library="resistor" package="C1206" value=" 22p" x="73.094" y="32.92" rot="R180"/>
<element name="C9" library="resistor" package="C1206" value="10uf" x="94.414" y="35.76" rot="R90"/>
<element name="C10" library="resistor" package="A/3216-18R" value="10uf" x="58.102" y="33.02" rot="R270"/>
<element name="TP1" library="con-amp-mt" package="L03P" value="TP" x="90.805" y="25.654" rot="MR0">
<attribute name="OC_NEWARK" value="unknown" x="90.805" y="25.654" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="MPN" value="" x="90.805" y="25.654" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="MF" value="" x="90.805" y="25.654" size="1.778" layer="28" rot="MR0" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="90.805" y="25.654" size="1.778" layer="28" rot="MR0" display="off"/>
</element>
<element name="CS1" library="con-amp-quick" package="16P" value="Cs1" x="72.39" y="43.18">
<attribute name="OC_NEWARK" value="unknown" x="72.39" y="43.18" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="72.39" y="43.18" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="" x="72.39" y="43.18" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="72.39" y="43.18" size="1.778" layer="27" display="off"/>
</element>
<element name="R16" library="rcl" package="M1206" value="18k" x="56.616" y="39.453"/>
<element name="R17" library="rcl" package="M1206" value="2,2k" x="56.624" y="36.889"/>
<element name="R18" library="rcl" package="M1206" value="100" x="89.66" y="35.752" rot="R90"/>
<element name="QF1" library="crystal" package="SM49" value="8MHZ" x="68.694" y="36.136" rot="R179.9">
<attribute name="OC_NEWARK" value="unknown" x="68.694" y="36.136" size="1.778" layer="27" rot="R179.9" display="off"/>
<attribute name="MPN" value="" x="68.694" y="36.136" size="1.778" layer="27" rot="R179.9" display="off"/>
<attribute name="MF" value="" x="68.694" y="36.136" size="1.778" layer="27" rot="R179.9" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="68.694" y="36.136" size="1.778" layer="27" rot="R179.9" display="off"/>
</element>
<element name="D2" library="diode" package="SOT23" value="ref" x="98.684" y="24.424" rot="R90"/>
<element name="D1" library="diode" package="SOD-123_MINI-SMA" value="4148" x="56.058" y="18.714" rot="R90"/>
<element name="R21" library="resistor" package="M1406" value="0" x="77.496" y="39.386" rot="R180"/>
<element name="R22" library="resistor" package="M1406" value="0" x="84.455" y="39.385"/>
<element name="R19" library="resistor" package="M1406" value="0" x="95.451" y="22.888" rot="R90"/>
<element name="R20" library="rcl" package="M1206" value="0" x="89.662" y="15.24"/>
<element name="R24" library="resistor" package="M1406" value="0" x="85.09" y="16.456" rot="R270"/>
<element name="R25" library="rcl" package="M1206" value="0" x="67.437" y="14.986"/>
<element name="R26" library="rcl" package="M1206" value="0" x="85.725" y="35.814" rot="R270"/>
<element name="IC3" library="v-reg" package="SO-08" value="MC34063" x="114.441" y="33.615" rot="R90"/>
<element name="D3" library="diode" package="SMB" value="ss24" x="119.168" y="26.391" rot="R90"/>
<element name="R23" library="resistor" package="M1206" value="180" x="111.896" y="29.464" rot="R180"/>
<element name="R27" library="resistor" package="M1206" value="1,5" x="105.556" y="30.557" rot="R270"/>
<element name="R28" library="resistor" package="M1406" value="2k" x="109.084" y="37.386" rot="R270"/>
<element name="R29" library="resistor" package="M1406" value="62k" x="116.145" y="27.965" rot="R90"/>
<element name="C11" library="resistor" package="CT7343" value="100uf" x="106.129" y="37.697" rot="R270"/>
<element name="C12" library="resistor" package="153CLV-0605" value="47uf" x="121.86" y="34.028" rot="R270"/>
<element name="C13" library="resistor" package="C3216" value="560pf" x="113.692" y="37.406" rot="R180"/>
<element name="R31" library="resistor" package="M1406" value="180k" x="106.355" y="20.988" rot="R270"/>
<element name="C14" library="resistor" package="C1206" value="10nf" x="109.077" y="21.204" rot="R270"/>
<element name="R32" library="resistor" package="M1406" value="20k" x="111.586" y="21.014" rot="R270"/>
<element name="R33" library="inductors" package="DR73" value="L1  220uh" x="110.148" y="26.091" rot="R180"/>
<element name="R35" library="resistor" package="M3516" value="0" x="51.281" y="23.866" rot="R90"/>
<element name="D4" library="diode" package="SOD-123_MINI-SMA" value="4148" x="117.24" y="19.58" rot="R90"/>
<element name="D5" library="diode" package="SOD-123_MINI-SMA" value="4148" x="114.405" y="15.93" rot="R90"/>
<element name="D6" library="diode" package="SOD-123_MINI-SMA" value="4148" x="115.92" y="11.368" rot="R180"/>
<element name="Q4" library="transistor-pnp" package="SOT23-BEC" value="BC857" x="118.26" y="14.31" rot="R90"/>
<element name="R37" library="resistor" package="M1406" value="300" x="119.81" y="19.748" rot="R90"/>
<element name="R38" library="resistor" package="M1406" value="33k" x="122.116" y="19.765" rot="R90"/>
<element name="D7" library="diode" package="SOD80C" value="3,3v" x="53.536" y="18.641" rot="R90"/>
<element name="D8" library="diode" package="SOD-123_MINI-SMA" value="4148" x="48.125" y="33.012" rot="R90"/>
<element name="D9" library="diode" package="SOD-123_MINI-SMA" value="4148" x="53.13" y="32.83" rot="R180"/>
<element name="SL2" library="con-amp-quick" package="02P" value="Teszt" x="49.91" y="38.43" rot="R270">
<attribute name="OC_NEWARK" value="unknown" x="49.91" y="38.43" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="" x="49.91" y="38.43" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MF" value="" x="49.91" y="38.43" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="49.91" y="38.43" size="1.778" layer="27" rot="R270" display="off"/>
</element>
<element name="SL3" library="con-amp-quick" package="02P" value="Z teszt" x="55.09" y="13.79" rot="R180">
<attribute name="OC_NEWARK" value="unknown" x="55.09" y="13.79" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="55.09" y="13.79" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="55.09" y="13.79" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="55.09" y="13.79" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="SL4" library="con-amp-quick" package="02P" value="Z dióda" x="108.703" y="16.359" rot="R180">
<attribute name="OC_NEWARK" value="unknown" x="108.703" y="16.359" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="108.703" y="16.359" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="108.703" y="16.359" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="108.703" y="16.359" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="R34" library="rcl" package="M1206" value="12k" x="50.876" y="16.639" rot="R270"/>
<element name="R30" library="resistor" package="M1206" value="1,5" x="108.038" y="30.66" rot="R270"/>
<element name="R36" library="resistor" package="R2010W" value="0" x="100.779" y="19.6" rot="R270"/>
</elements>
<signals>
<signal name="GND">
<contactref element="IC1" pad="21"/>
<contactref element="C8" pad="2"/>
<contactref element="C7" pad="2"/>
<contactref element="C10" pad="-"/>
<contactref element="SL1" pad="2"/>
<contactref element="IC2" pad="4"/>
<contactref element="C5" pad="2"/>
<contactref element="C9" pad="2"/>
<contactref element="C6" pad="2"/>
<contactref element="Q2" pad="2"/>
<contactref element="R12" pad="2"/>
<contactref element="CS1" pad="5"/>
<contactref element="CS1" pad="16"/>
<contactref element="Q1" pad="2"/>
<contactref element="C4" pad="2"/>
<contactref element="IC1" pad="5"/>
<contactref element="IC1" pad="3"/>
<contactref element="CS1" pad="1"/>
<contactref element="R20" pad="2"/>
<wire x1="77.71" y1="23.368" x2="77.71" y2="28.194" width="0.254" layer="1"/>
<wire x1="77.71" y1="28.194" x2="77.71" y2="30.226" width="0.254" layer="1"/>
<wire x1="78.459" y1="22.66" x2="77.71" y2="23.368" width="0.254" layer="1"/>
<wire x1="78.486" y1="22.098" x2="78.459" y2="22.66" width="0.254" layer="1"/>
<wire x1="77.71" y1="30.226" x2="77.705" y2="30.4546" width="0.254" layer="1"/>
<wire x1="78.486" y1="22.098" x2="78.505" y2="21.8694" width="0.254" layer="1"/>
<wire x1="78.486" y1="21.844" x2="78.505" y2="21.8694" width="0.254" layer="1"/>
<wire x1="79.29" y1="29.718" x2="79.297" y2="30.226" width="0.254" layer="1"/>
<wire x1="77.71" y1="28.194" x2="79.29" y2="29.718" width="0.254" layer="1"/>
<wire x1="79.297" y1="30.226" x2="79.305" y2="30.4546" width="0.254" layer="1"/>
<wire x1="67.366" y1="44.231" x2="67.366" y2="39.756" width="0.254" layer="1"/>
<wire x1="66.639" y1="45.483" x2="67.366" y2="44.231" width="0.254" layer="1"/>
<wire x1="64.661" y1="45.476" x2="66.639" y2="45.483" width="0.254" layer="1"/>
<wire x1="63.5" y1="43.18" x2="64.661" y2="45.476" width="0.254" layer="1"/>
<wire x1="98.806" y1="40.386" x2="99.431" y2="39.761" width="0.254" layer="1"/>
<wire x1="99.431" y1="39.761" x2="99.568" y2="39.624" width="0.254" layer="1"/>
<wire x1="98.806" y1="40.386" x2="98.806" y2="40.48" width="0.254" layer="1"/>
<wire x1="61.438" y1="41.015" x2="59.359" y2="38.136" width="0.254" layer="1"/>
<wire x1="59.35" y1="34.338" x2="58.166" y2="34.344" width="0.254" layer="1"/>
<wire x1="59.35" y1="37.996" x2="59.35" y2="34.338" width="0.254" layer="1"/>
<wire x1="58.166" y1="34.344" x2="58.102" y2="34.395" width="0.254" layer="1"/>
<wire x1="57.404" y1="26.924" x2="55.626" y2="26.924" width="0.254" layer="1"/>
<wire x1="58.288" y1="26.688" x2="57.404" y2="26.924" width="0.254" layer="1"/>
<wire x1="55.626" y1="26.924" x2="55.946" y2="26.858" width="0.254" layer="1"/>
<wire x1="61.438" y1="41.015" x2="63.486" y2="41.008" width="0.254" layer="1"/>
<wire x1="63.486" y1="41.008" x2="63.5" y2="41.167" width="0.254" layer="1"/>
<wire x1="53.63" y1="27.686" x2="53.34" y2="27.686" width="0.254" layer="1"/>
<wire x1="55.372" y1="27.064" x2="53.63" y2="27.686" width="0.254" layer="1"/>
<wire x1="53.34" y1="27.686" x2="53.746" y2="27.949" width="0.254" layer="1"/>
<wire x1="55.372" y1="27.064" x2="55.946" y2="26.858" width="0.254" layer="1"/>
<wire x1="63.5" y1="43.18" x2="63.5" y2="43.307" width="0.6096" layer="1"/>
<contactref element="R28" pad="1"/>
<contactref element="C11" pad="-"/>
<contactref element="IC3" pad="2"/>
<contactref element="C13" pad="2"/>
<contactref element="C14" pad="2"/>
<contactref element="R32" pad="2"/>
<wire x1="91.109" y1="14.771" x2="91.062" y2="15.24" width="0.508" layer="1"/>
<wire x1="91.109" y1="14.771" x2="92.75" y2="14.773" width="0.254" layer="1"/>
<wire x1="79.302" y1="31.992" x2="79.305" y2="30.4546" width="0.254" layer="1"/>
<wire x1="77.47" y1="44.196" x2="77.436" y2="38.054" width="0.254" layer="1"/>
<wire x1="78.659" y1="45.827" x2="77.47" y2="44.196" width="0.254" layer="1"/>
<wire x1="64.008" y1="44.196" x2="63.5" y2="43.18" width="0.254" layer="1"/>
<wire x1="79.302" y1="31.992" x2="79.818" y2="33.315" width="0.254" layer="1"/>
<wire x1="79.818" y1="33.315" x2="79.797" y2="37.025" width="0.254" layer="1"/>
<wire x1="79.797" y1="37.025" x2="78.272" y2="37.025" width="0.254" layer="1"/>
<wire x1="77.436" y1="38.054" x2="77.93" y2="37.487" width="0.254" layer="1"/>
<wire x1="78.462" y1="37.062" x2="78.546" y2="36.985" width="0.254" layer="1"/>
<wire x1="78.546" y1="36.985" x2="77.93" y2="37.487" width="0.254" layer="1"/>
<wire x1="53.34" y1="43.18" x2="53.298" y2="42.37" width="0.254" layer="1"/>
<contactref element="IC3" pad="4"/>
<wire x1="59.135" y1="45.496" x2="54.861" y2="45.503" width="0.254" layer="1"/>
<wire x1="59.69" y1="44.958" x2="59.135" y2="45.496" width="0.254" layer="1"/>
<wire x1="59.69" y1="41.768" x2="59.69" y2="44.958" width="0.254" layer="1"/>
<wire x1="78.659" y1="45.827" x2="90.117" y2="45.827" width="0.254" layer="1"/>
<wire x1="90.117" y1="45.827" x2="91.44" y2="43.18" width="0.254" layer="1"/>
<wire x1="53.088" y1="34.695" x2="53.088" y2="39.546" width="0.254" layer="1"/>
<wire x1="53.088" y1="39.546" x2="53.298" y2="42.37" width="0.254" layer="1"/>
<wire x1="59.69" y1="41.768" x2="60.24" y2="41.012" width="0.254" layer="1"/>
<wire x1="60.24" y1="41.012" x2="61.438" y2="41.015" width="0.254" layer="1"/>
<wire x1="54.861" y1="45.503" x2="53.271" y2="44.037" width="0.254" layer="1"/>
<wire x1="92.1546" y1="37.172" x2="92.1276" y2="37.163" width="0.254" layer="1"/>
<wire x1="92.1276" y1="37.163" x2="94.414" y2="37.16" width="0.254" layer="1"/>
<wire x1="96.417" y1="39.069" x2="97.006" y2="39.341" width="0.254" layer="1"/>
<wire x1="97.006" y1="39.341" x2="98.302" y2="39.341" width="0.254" layer="1"/>
<wire x1="98.302" y1="39.341" x2="99.431" y2="39.761" width="0.254" layer="1"/>
<wire x1="52.758" y1="42.397" x2="53.088" y2="39.546" width="0.254" layer="1"/>
<wire x1="53.088" y1="39.546" x2="53.919" y2="42.39" width="0.254" layer="1"/>
<wire x1="101.007" y1="39.069" x2="101.007" y2="38.88" width="0.254" layer="1"/>
<wire x1="53.848" y1="42.418" x2="53.34" y2="43.18" width="0.254" layer="1"/>
<wire x1="78.335" y1="36.761" x2="78.388" y2="37.051" width="0.254" layer="1"/>
<wire x1="78.335" y1="36.761" x2="78.546" y2="36.985" width="0.254" layer="1"/>
<wire x1="105.982" y1="40.775" x2="106.129" y2="40.897" width="0.254" layer="1"/>
<wire x1="99.568" y1="39.624" x2="98.806" y2="40.48" width="0.254" layer="1"/>
<wire x1="111.217" y1="19.387" x2="111.056" y2="19.436" width="0.4064" layer="1"/>
<wire x1="117.041" y1="32.98" x2="114.907" y2="32.98" width="0.4064" layer="1"/>
<wire x1="114.907" y1="32.98" x2="114.907" y2="35.532" width="0.4064" layer="1"/>
<wire x1="114.907" y1="35.532" x2="116.334" y2="35.532" width="0.4064" layer="1"/>
<wire x1="116.334" y1="35.532" x2="117.041" y2="35.52" width="0.4064" layer="1"/>
<wire x1="114.907" y1="35.532" x2="114.166" y2="35.532" width="0.4064" layer="1"/>
<wire x1="114.166" y1="35.532" x2="112.292" y2="37.406" width="0.4064" layer="1"/>
<wire x1="100.062" y1="40.367" x2="100.118" y2="40.992" width="0.4064" layer="1"/>
<wire x1="94.414" y1="37.16" x2="94.417" y2="37.664" width="0.4064" layer="1"/>
<wire x1="99.086" y1="40.474" x2="98.302" y2="39.341" width="0.4064" layer="1"/>
<wire x1="104.963903125" y1="40.990096875" x2="106.129" y2="40.897" width="0.4064" layer="1"/>
<contactref element="C12" pad="-"/>
<contactref element="R38" pad="2"/>
<wire x1="121.86" y1="36.728" x2="122.279" y2="36.154" width="0.4064" layer="1"/>
<wire x1="123.586" y1="36.728" x2="121.94679375" y2="36.724409375" width="0.4064" layer="1"/>
<wire x1="122.116" y1="21.465" x2="122.186" y2="21.441" width="0.4064" layer="1"/>
<wire x1="122.186" y1="21.441" x2="123.613" y2="21.441" width="0.4064" layer="1"/>
<wire x1="123.613" y1="21.441" x2="123.593" y2="36.732409375" width="0.4064" layer="1"/>
<contactref element="R17" pad="1"/>
<wire x1="59.35" y1="37.996" x2="59.359" y2="38.136" width="0.254" layer="1"/>
<wire x1="67.309" y1="32.971" x2="67.659" y2="33.067" width="0.254" layer="1"/>
<wire x1="67.659" y1="33.067" x2="69.454" y2="33.06" width="0.254" layer="1"/>
<wire x1="71.694" y1="32.92" x2="71.624" y2="32.536" width="0.254" layer="1"/>
<wire x1="69.44" y1="31.64" x2="63.14" y2="31.64" width="0.254" layer="1"/>
<wire x1="63.14" y1="31.64" x2="60.62" y2="34.93" width="0.254" layer="1"/>
<wire x1="60.62" y1="34.93" x2="60.62" y2="37.94" width="0.254" layer="1"/>
<wire x1="60.62" y1="37.94" x2="62.02" y2="39.76" width="0.254" layer="1"/>
<wire x1="62.02" y1="39.76" x2="66.684" y2="39.76" width="0.254" layer="1"/>
<wire x1="66.684" y1="39.76" x2="67.366" y2="39.756" width="0.254" layer="1"/>
<wire x1="69.44" y1="31.64" x2="69.446" y2="31.92" width="0.254" layer="1"/>
<wire x1="69.446" y1="31.92" x2="69.454" y2="33.06" width="0.254" layer="1"/>
<contactref element="SL4" pad="1"/>
<wire x1="91.44" y1="43.18" x2="96.61" y2="43.18" width="0.4064" layer="1"/>
<wire x1="96.61" y1="43.18" x2="97.02" y2="42.77" width="0.4064" layer="1"/>
<wire x1="111.038" y1="19.047" x2="111.056" y2="19.436" width="0.4064" layer="1"/>
<wire x1="109.973" y1="16.359" x2="111.038" y2="19.047" width="0.4064" layer="1"/>
<wire x1="123.592" y1="19.635" x2="123.613" y2="21.441" width="0.4064" layer="1"/>
<wire x1="49.315" y1="29.054" x2="49.455" y2="28.923" width="0.254" layer="1"/>
<wire x1="54.952" y1="36.97" x2="57.752" y2="34.648" width="0.254" layer="1"/>
<wire x1="57.752" y1="34.648" x2="58.45" y2="34.16" width="0.254" layer="1"/>
<wire x1="58.45" y1="34.16" x2="58.147" y2="34.44" width="0.254" layer="1"/>
<wire x1="58.147" y1="34.44" x2="58.102" y2="34.395" width="0.254" layer="1"/>
<wire x1="53.088" y1="34.695" x2="55.535" y2="34.695" width="0.254" layer="1"/>
<wire x1="55.535" y1="34.695" x2="56.28" y2="34.02" width="0.254" layer="1"/>
<wire x1="56.28" y1="34.02" x2="56.28" y2="32.55" width="0.254" layer="1"/>
<wire x1="56.28" y1="32.55" x2="56.277" y2="30.103" width="0.254" layer="1"/>
<wire x1="60.34" y1="30.1" x2="60.83" y2="29.47" width="0.254" layer="1"/>
<wire x1="60.83" y1="29.47" x2="60.83" y2="26.4134375" width="0.254" layer="1"/>
<wire x1="56.277" y1="30.103" x2="56.795" y2="30.1" width="0.254" layer="1"/>
<wire x1="56.795" y1="30.1" x2="60.34" y2="30.1" width="0.254" layer="1"/>
<wire x1="49.315" y1="29.054" x2="52.08" y2="29.05" width="0.4064" layer="1"/>
<wire x1="52.08" y1="29.05" x2="53.746" y2="27.949" width="0.4064" layer="1"/>
<wire x1="94.417" y1="37.664" x2="96.621" y2="37.674" width="0.6096" layer="1"/>
<wire x1="96.621" y1="37.674" x2="99.086" y2="40.474" width="0.6096" layer="1"/>
<wire x1="104.963903125" y1="40.990096875" x2="100.118" y2="40.992" width="0.6096" layer="1"/>
<wire x1="109.1031625" y1="41.011096875" x2="104.963903125" y2="40.990096875" width="0.6096" layer="1"/>
<wire x1="109.1031625" y1="41.011096875" x2="109.084" y2="39.086" width="0.6096" layer="1"/>
<wire x1="69.454" y1="33.06" x2="71.694" y2="33.06" width="0.254" layer="1"/>
<wire x1="71.694" y1="33.06" x2="71.694" y2="32.92" width="0.254" layer="1"/>
<wire x1="67.366" y1="39.756" x2="69.108" y2="39.756" width="0.254" layer="1"/>
<wire x1="69.108" y1="39.756" x2="70.861" y2="38.038" width="0.254" layer="1"/>
<wire x1="70.861" y1="38.038" x2="77.392" y2="38.038" width="0.254" layer="1"/>
<wire x1="77.392" y1="38.038" x2="77.436" y2="38.054" width="0.254" layer="1"/>
<wire x1="111.404" y1="19.44" x2="111.586" y2="19.314" width="0.254" layer="1"/>
<wire x1="111.038" y1="19.047" x2="111.353" y2="19.614" width="0.4064" layer="1"/>
<wire x1="111.353" y1="19.614" x2="123.592" y2="19.635" width="0.4064" layer="1"/>
<wire x1="109.084" y1="39.086" x2="109.324" y2="39.046" width="0.6096" layer="1"/>
<wire x1="109.324" y1="39.046" x2="109.48" y2="39.046" width="0.6096" layer="1"/>
<wire x1="109.48" y1="39.046" x2="112.292" y2="39.034" width="0.6096" layer="1"/>
<wire x1="112.292" y1="39.034" x2="112.292" y2="37.406" width="0.6096" layer="1"/>
<wire x1="109.077" y1="19.804" x2="112.048" y2="19.811" width="0.4064" layer="1"/>
<wire x1="112.048" y1="19.811" x2="111.586" y2="19.314" width="0.4064" layer="1"/>
<wire x1="118.198" y1="33.008" x2="118.982" y2="33.008" width="0.4064" layer="1"/>
<wire x1="118.982" y1="33.008" x2="121.604" y2="35.63" width="0.4064" layer="1"/>
<wire x1="101.605" y1="23.474" x2="101.605" y2="27.881" width="0.254" layer="1"/>
<wire x1="101.605" y1="27.881" x2="99.912" y2="27.881" width="0.254" layer="1"/>
<wire x1="99.912" y1="27.881" x2="99.912" y2="27.531" width="0.254" layer="1"/>
<contactref element="R36" pad="2"/>
<wire x1="101.605" y1="23.474" x2="100.093" y2="23.474" width="0.254" layer="1"/>
<wire x1="100.093" y1="23.474" x2="100.093" y2="23.471" width="0.254" layer="1"/>
<wire x1="99.907" y1="21.775" x2="99.923465625" y2="21.845971875" width="0.254" layer="1"/>
<wire x1="99.923465625" y1="21.845971875" x2="100.24" y2="21.523" width="0.254" layer="1"/>
<wire x1="100.24" y1="21.523" x2="100.072" y2="21.791" width="0.254" layer="1"/>
<wire x1="100.1" y1="21.973" x2="100.1" y2="23.464" width="0.254" layer="1"/>
<wire x1="100.779" y1="17.289" x2="101.976" y2="17.493" width="0.254" layer="1"/>
<wire x1="101.976" y1="17.493" x2="105.126" y2="21" width="0.254" layer="1"/>
<wire x1="105.126" y1="21" x2="107.888" y2="20.993" width="0.254" layer="1"/>
<wire x1="107.888" y1="20.993" x2="109.077" y2="19.804" width="0.254" layer="1"/>
<wire x1="100.1" y1="23.464" x2="100.093" y2="23.471" width="0.254" layer="1"/>
<wire x1="99.915" y1="30.067" x2="99.915" y2="27.534" width="0.4064" layer="1"/>
<wire x1="99.915" y1="27.534" x2="99.912" y2="27.531" width="0.4064" layer="1"/>
<wire x1="92.75" y1="14.773" x2="92.99749375" y2="14.92" width="0.254" layer="1"/>
<wire x1="92.99749375" y1="14.92" x2="99.923465625" y2="21.845971875" width="0.254" layer="1"/>
<contactref element="C2" pad="2"/>
<contactref element="R9" pad="1"/>
<wire x1="58.476" y1="26.341" x2="61.084440625" y2="26.341" width="0.4064" layer="1"/>
<wire x1="61.084440625" y1="26.341" x2="61.084440625" y2="26.368996875" width="0.4064" layer="1"/>
<wire x1="61.084440625" y1="26.368996875" x2="60.83" y2="26.368996875" width="0.4064" layer="1"/>
<wire x1="60.83" y1="26.368996875" x2="60.83" y2="26.4134375" width="0.4064" layer="1"/>
<wire x1="123.593" y1="36.732409375" x2="123.586" y2="36.728" width="0" layer="19" extent="1-1"/>
<wire x1="121.86" y1="36.728" x2="121.94679375" y2="36.724409375" width="0" layer="19" extent="1-1"/>
<wire x1="111.404" y1="19.44" x2="111.353" y2="19.614" width="0" layer="19" extent="1-1"/>
<wire x1="121.604" y1="35.63" x2="122.279" y2="36.154" width="0" layer="19" extent="1-1"/>
<wire x1="117.041" y1="32.98" x2="118.198" y2="33.008" width="0" layer="19" extent="1-1"/>
<wire x1="99.568" y1="39.624" x2="100.062" y2="40.367" width="0" layer="19" extent="1-1"/>
<wire x1="101.007" y1="39.069" x2="99.568" y2="39.624" width="0" layer="19" extent="1-1"/>
<wire x1="97.02" y1="42.77" x2="98.806" y2="40.48" width="0" layer="19" extent="1-1"/>
<wire x1="78.382" y1="36.738" x2="78.335" y2="36.761" width="0" layer="19" extent="1-1"/>
<wire x1="78.272" y1="37.025" x2="78.388" y2="37.051" width="0" layer="19" extent="1-1"/>
<wire x1="59.359" y1="38.136" x2="60.62" y2="37.94" width="0" layer="19" extent="1-1"/>
<wire x1="55.224" y1="36.889" x2="54.952" y2="36.97" width="0" layer="19" extent="1-1"/>
<wire x1="53.34" y1="43.18" x2="53.271" y2="44.037" width="0" layer="19" extent="1-1"/>
<wire x1="58.288" y1="26.688" x2="58.476" y2="26.341" width="0" layer="19" extent="1-1"/>
<wire x1="48.615" y1="28.918" x2="49.315" y2="29.054" width="0" layer="19" extent="1-1"/>
<wire x1="100.24" y1="21.523" x2="100.779" y2="17.289" width="0" layer="19" extent="1-1"/>
<wire x1="100.1" y1="21.973" x2="100.072" y2="21.791" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="TP1">
<contactref element="IC1" pad="23"/>
<contactref element="TP1" pad="1"/>
<contactref element="R24" pad="1"/>
<wire x1="80.101" y1="20.908" x2="80.102" y2="21.79" width="0.254" layer="1"/>
<wire x1="82.377" y1="19.558" x2="80.101" y2="20.908" width="0.254" layer="1"/>
<wire x1="88.138" y1="19.558" x2="85.09" y2="19.558" width="0.254" layer="1"/>
<wire x1="85.09" y1="19.558" x2="82.377" y2="19.558" width="0.254" layer="1"/>
<wire x1="80.102" y1="21.79" x2="80.105" y2="21.8694" width="0.254" layer="1"/>
<wire x1="88.138" y1="19.558" x2="88.305" y2="19.404" width="0.254" layer="1"/>
<wire x1="85.09" y1="19.558" x2="85.09" y2="18.156" width="0.254" layer="1"/>
</signal>
<signal name="TP3">
<contactref element="R6" pad="2"/>
<contactref element="R5" pad="2"/>
<contactref element="TP1" pad="3"/>
<contactref element="R19" pad="1"/>
<wire x1="75.946" y1="15.24" x2="73.152" y2="15.24" width="0.254" layer="1"/>
<wire x1="73.152" y1="15.24" x2="73.795" y2="15.218" width="0.254" layer="1"/>
<wire x1="75.946" y1="15.24" x2="76.213" y2="15.237" width="0.254" layer="1"/>
<wire x1="77.38" y1="15.345" x2="76.2" y2="15.24" width="0.254" layer="1"/>
<wire x1="78.463" y1="16.617" x2="77.38" y2="15.345" width="0.254" layer="1"/>
<wire x1="89.535" y1="21.336" x2="89.549" y2="17.726" width="0.254" layer="1"/>
<wire x1="93.218" y1="21.336" x2="89.535" y2="21.336" width="0.254" layer="1"/>
<wire x1="93.218" y1="19.558" x2="93.218" y2="21.336" width="0.254" layer="1"/>
<wire x1="76.2" y1="15.24" x2="76.213" y2="15.237" width="0.254" layer="1"/>
<wire x1="93.218" y1="19.558" x2="93.305" y2="19.404" width="0.254" layer="1"/>
<wire x1="93.218" y1="21.336" x2="95.758" y2="21.336" width="0.254" layer="1"/>
<wire x1="95.758" y1="21.336" x2="95.451" y2="21.188" width="0.254" layer="1"/>
<wire x1="89.549" y1="17.726" x2="89.497" y2="17.726" width="0.254" layer="1"/>
<wire x1="89.497" y1="17.726" x2="88.767" y2="16.996" width="0.254" layer="1"/>
<wire x1="88.767" y1="16.996" x2="86.522" y2="16.996" width="0.254" layer="1"/>
<wire x1="86.522" y1="16.996" x2="86.178" y2="16.715" width="0.254" layer="1"/>
<wire x1="86.178" y1="16.715" x2="82.466" y2="16.715" width="0.254" layer="1"/>
<wire x1="82.466" y1="16.715" x2="82.369" y2="16.618" width="0.254" layer="1"/>
<wire x1="82.369" y1="16.618" x2="78.464" y2="16.618" width="0.254" layer="1"/>
<wire x1="78.464" y1="16.618" x2="78.463" y2="16.617" width="0.254" layer="1"/>
</signal>
<signal name="N$4">
<contactref element="IC1" pad="12"/>
<contactref element="R1" pad="1"/>
<wire x1="69.088" y1="26.924" x2="69.342" y2="26.571" width="0.254" layer="1"/>
<wire x1="73.653" y1="26.571" x2="73.8124" y2="26.562" width="0.254" layer="1"/>
<wire x1="69.088" y1="26.924" x2="68.906996875" y2="26.13855625" width="0.254" layer="1"/>
<wire x1="69.342" y1="26.571" x2="73.653" y2="26.571" width="0.254" layer="1"/>
</signal>
<signal name="N$5">
<contactref element="IC1" pad="13"/>
<contactref element="R2" pad="1"/>
<wire x1="72.742" y1="25.762" x2="73.653" y2="25.768" width="0.254" layer="1"/>
<wire x1="73.653" y1="25.768" x2="73.8124" y2="25.762" width="0.254" layer="1"/>
<wire x1="72.742" y1="25.762" x2="71.3622125" y2="25.75479375" width="0.254" layer="1"/>
<wire x1="71.3622125" y1="25.75479375" x2="71.548" y2="25.752" width="0.254" layer="1"/>
<wire x1="68.907" y1="23.487" x2="69.169" y2="23.578" width="0.254" layer="1"/>
<wire x1="69.169" y1="23.578" x2="69.96" y2="24.35258125" width="0.254" layer="1"/>
<wire x1="69.96" y1="24.35258125" x2="71.3622125" y2="25.75479375" width="0.254" layer="1"/>
</signal>
<signal name="N$6">
<contactref element="IC1" pad="14"/>
<contactref element="R3" pad="1"/>
<wire x1="73.66" y1="24.973" x2="73.8124" y2="24.962" width="0.254" layer="1"/>
<wire x1="68.837" y1="20.903" x2="70.197" y2="20.917" width="0.254" layer="1"/>
<wire x1="70.197" y1="20.917" x2="70.511" y2="21.259" width="0.254" layer="1"/>
<wire x1="70.511" y1="21.259" x2="70.525" y2="23.503671875" width="0.254" layer="1"/>
<wire x1="70.525" y1="23.503671875" x2="71.834778125" y2="24.97445" width="0.254" layer="1"/>
<wire x1="71.834778125" y1="24.97445" x2="73.80695" y2="24.96745" width="0.254" layer="1"/>
<wire x1="73.80695" y1="24.96745" x2="73.8124" y2="24.962" width="0.254" layer="1"/>
</signal>
<signal name="N$7">
<contactref element="R4" pad="1"/>
<contactref element="IC1" pad="15"/>
<wire x1="72.887" y1="24.157" x2="73.66" y2="24.157" width="0.254" layer="1"/>
<wire x1="73.66" y1="24.157" x2="73.8124" y2="24.162" width="0.254" layer="1"/>
<wire x1="69.088" y1="18.796" x2="68.836990625" y2="18.3141125" width="0.254" layer="1"/>
<wire x1="72.887" y1="24.157" x2="72.183" y2="24.151" width="0.254" layer="1"/>
<wire x1="69.088" y1="18.796" x2="70.463" y2="18.796" width="0.254" layer="1"/>
<wire x1="70.463" y1="18.796" x2="71.407" y2="19.74" width="0.254" layer="1"/>
<wire x1="71.407" y1="19.74" x2="71.393" y2="23.186" width="0.254" layer="1"/>
<wire x1="71.393" y1="23.186" x2="72.183" y2="24.151" width="0.254" layer="1"/>
</signal>
<signal name="N$8">
<contactref element="R5" pad="1"/>
<contactref element="IC1" pad="16"/>
<wire x1="73.66" y1="18.542" x2="73.66" y2="23.114" width="0.254" layer="1"/>
<wire x1="73.152" y1="18.034" x2="73.66" y2="18.542" width="0.254" layer="1"/>
<wire x1="73.66" y1="23.114" x2="73.8124" y2="23.362" width="0.254" layer="1"/>
<wire x1="73.152" y1="18.034" x2="73.795" y2="18.018" width="0.254" layer="1"/>
</signal>
<signal name="N$9">
<contactref element="R6" pad="1"/>
<contactref element="IC1" pad="17"/>
<wire x1="75.303" y1="18.796" x2="75.303" y2="21.844" width="0.254" layer="1"/>
<wire x1="75.946" y1="18.288" x2="75.303" y2="18.796" width="0.254" layer="1"/>
<wire x1="75.303" y1="21.844" x2="75.305" y2="21.8694" width="0.254" layer="1"/>
<wire x1="75.946" y1="18.288" x2="76.213" y2="18.037" width="0.254" layer="1"/>
</signal>
<signal name="N$17">
<contactref element="IC1" pad="10"/>
<wire x1="72.179" y1="28.193" x2="73.66" y2="28.194" width="0.254" layer="1"/>
<wire x1="72.178" y1="30.467" x2="72.179" y2="28.193" width="0.254" layer="1"/>
<wire x1="64.958" y1="30.467" x2="72.178" y2="30.467" width="0.254" layer="1"/>
<wire x1="73.66" y1="28.194" x2="73.8124" y2="28.162" width="0.254" layer="1"/>
<contactref element="R8" pad="2"/>
<wire x1="63.74455625" y1="29.110996875" x2="63.74455625" y2="29.25355625" width="0.254" layer="1"/>
<wire x1="63.74455625" y1="29.25355625" x2="64.958" y2="30.467" width="0.254" layer="1"/>
</signal>
<signal name="N$11">
<contactref element="Q3" pad="B"/>
<contactref element="R7" pad="2"/>
<contactref element="R10" pad="1"/>
<wire x1="61.722" y1="18.542" x2="61.722" y2="15.748" width="0.254" layer="1"/>
<wire x1="61.738" y1="18.796" x2="61.722" y2="18.542" width="0.254" layer="1"/>
<wire x1="61.722" y1="15.748" x2="61.532" y2="15.705" width="0.254" layer="1"/>
<wire x1="61.738" y1="18.796" x2="61.738" y2="21.59" width="0.254" layer="1"/>
<wire x1="61.738" y1="21.59" x2="61.236" y2="21.24" width="0.254" layer="1"/>
<wire x1="61.738" y1="18.796" x2="61.236" y2="18.699" width="0.254" layer="1"/>
</signal>
<signal name="N$12">
<contactref element="LED1" pad="A"/>
<contactref element="R7" pad="1"/>
<contactref element="SL2" pad="2"/>
<wire x1="48.514" y1="21.732" x2="48.507" y2="21.76" width="0.254" layer="1"/>
<wire x1="48.507" y1="21.76" x2="49.98" y2="23.45" width="0.254" layer="1"/>
<wire x1="49.98" y1="23.45" x2="56" y2="23.45" width="0.254" layer="1"/>
<wire x1="56" y1="23.45" x2="58.247" y2="20.72" width="0.254" layer="1"/>
<wire x1="58.247" y1="20.72" x2="57.766" y2="21.77" width="0.254" layer="1"/>
<wire x1="57.766" y1="21.77" x2="58.436" y2="21.24" width="0.254" layer="1"/>
<wire x1="49.91" y1="37.16" x2="49.91" y2="34.16" width="0.4064" layer="1"/>
<wire x1="46.396" y1="32.97" x2="46.386" y2="23.516" width="0.254" layer="1"/>
<wire x1="46.396" y1="32.97" x2="49.466" y2="32.946" width="0.254" layer="1"/>
<wire x1="49.466" y1="32.946" x2="49.91" y2="34.16" width="0.254" layer="1"/>
<wire x1="46.386" y1="23.488" x2="48.43" y2="21.691" width="0.254" layer="1"/>
<wire x1="48.43" y1="21.691" x2="48.514" y2="21.732" width="0.254" layer="1"/>
<wire x1="46.386" y1="23.488" x2="46.386" y2="23.516" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$13">
<contactref element="Q2" pad="3"/>
<contactref element="LED1" pad="K"/>
<wire x1="53.401" y1="25.896" x2="53.296" y2="26.048" width="0.254" layer="1"/>
<wire x1="53.296" y1="26.048" x2="53.746" y2="25.908" width="0.254" layer="1"/>
<wire x1="53.401" y1="25.896" x2="53.751" y2="25.624" width="0.254" layer="1"/>
<wire x1="53.746" y1="25.908" x2="53.746" y2="24.696" width="0.254" layer="1"/>
<wire x1="53.746" y1="24.696" x2="53.34" y2="24.29" width="0.254" layer="1"/>
<wire x1="53.34" y1="24.29" x2="48.364" y2="24.29" width="0.254" layer="1"/>
<wire x1="48.364" y1="24.29" x2="48.514" y2="24.272" width="0.254" layer="1"/>
</signal>
<signal name="N$21">
<contactref element="IC2" pad="1"/>
<contactref element="C5" pad="1"/>
<contactref element="C9" pad="1"/>
<contactref element="R11" pad="2"/>
<wire x1="96.52" y1="32.448" x2="96.647" y2="33.464" width="0.254" layer="1"/>
<wire x1="96.647" y1="33.464" x2="96.647" y2="34.29" width="0.254" layer="1"/>
<wire x1="96.52" y1="32.448" x2="96.526" y2="33.3" width="0.254" layer="1"/>
<wire x1="96.647" y1="33.464" x2="96.52305" y2="33.911465625" width="0.254" layer="1"/>
<wire x1="96.52305" y1="33.911465625" x2="96.526" y2="33.3" width="0.254" layer="1"/>
<wire x1="96.65005" y1="32.956" x2="96.52305" y2="33.911465625" width="0.254" layer="1"/>
<contactref element="Q3" pad="C"/>
<wire x1="60.96" y1="13.462" x2="60.706" y2="13.462" width="0.254" layer="1"/>
<wire x1="60.706" y1="13.462" x2="60.582" y2="13.505" width="0.254" layer="1"/>
<wire x1="60.96" y1="13.462" x2="60.96" y2="13.516" width="0.254" layer="1"/>
<wire x1="92.1546" y1="34.372" x2="92.7136" y2="34.36" width="0.254" layer="1"/>
<wire x1="92.7136" y1="34.36" x2="94.414" y2="34.36" width="0.254" layer="1"/>
<wire x1="94.414" y1="34.36" x2="94.414" y2="34.29" width="0.254" layer="1"/>
<wire x1="94.414" y1="34.29" x2="96.647" y2="34.29" width="0.254" layer="1"/>
<wire x1="96.647" y1="34.29" x2="96.66" y2="34.29" width="0.4064" layer="1"/>
<wire x1="96.66" y1="34.29" x2="96.66" y2="35.91" width="0.4064" layer="1"/>
<wire x1="96.66" y1="35.91" x2="102.638" y2="35.91" width="0.4064" layer="1"/>
<wire x1="102.638" y1="35.91" x2="102.638" y2="31.588" width="0.4064" layer="1"/>
<wire x1="102.635" y1="26.366" x2="102.645" y2="25.505" width="0.4064" layer="1"/>
<wire x1="99.232" y1="20.061" x2="91.622" y2="12.143" width="0.4064" layer="1"/>
<wire x1="91.622" y1="12.143" x2="60.514" y2="12.171" width="0.4064" layer="1"/>
<wire x1="60.514" y1="12.171" x2="60.531" y2="13.053" width="0.4064" layer="1"/>
<wire x1="60.531" y1="13.053" x2="60.614" y2="13.473" width="0.4064" layer="1"/>
<wire x1="60.614" y1="13.473" x2="60.582" y2="13.505" width="0.4064" layer="1"/>
<wire x1="102.635" y1="26.366" x2="102.627" y2="26.498" width="0.4064" layer="1"/>
<wire x1="102.627" y1="26.498" x2="102.62" y2="31.381" width="0.4064" layer="1"/>
<wire x1="102.62" y1="31.381" x2="102.638" y2="31.588" width="0.4064" layer="1"/>
<wire x1="92.1546" y1="34.372" x2="91.42" y2="34.37" width="0.254" layer="1"/>
<wire x1="91.42" y1="34.37" x2="91.42" y2="30.38" width="0.254" layer="1"/>
<wire x1="91.42" y1="30.38" x2="91.113440625" y2="30.001996875" width="0.254" layer="1"/>
<wire x1="101.75" y1="20.067" x2="102.648" y2="21" width="0.4064" layer="1"/>
<wire x1="102.648" y1="21" x2="102.648" y2="25.473" width="0.4064" layer="1"/>
<wire x1="102.648" y1="25.473" x2="102.645" y2="25.505" width="0.4064" layer="1"/>
<wire x1="99.232" y1="20.061" x2="101.744" y2="20.061" width="0.4064" layer="1"/>
<wire x1="101.744" y1="20.061" x2="101.75" y2="20.067" width="0.4064" layer="1"/>
</signal>
<signal name="N$10">
<contactref element="R13" pad="1"/>
<contactref element="IC1" pad="29"/>
<wire x1="89.027" y1="26.543" x2="83.058" y2="26.543" width="0.254" layer="1"/>
<wire x1="88.392" y1="26.924" x2="89.027" y2="26.543" width="0.254" layer="1"/>
<wire x1="83.058" y1="26.543" x2="82.3976" y2="26.562" width="0.254" layer="1"/>
<wire x1="88.392" y1="26.924" x2="88.521440625" y2="27.175" width="0.254" layer="1"/>
</signal>
<signal name="N$24">
<contactref element="C8" pad="1"/>
<contactref element="IC1" pad="8"/>
<contactref element="QF1" pad="1"/>
<wire x1="75.305" y1="30.4546" x2="75.305" y2="32.206" width="0.254" layer="1"/>
<wire x1="75.305" y1="32.206" x2="74.494" y2="32.92" width="0.254" layer="1"/>
<wire x1="74.494" y1="32.92" x2="74.494" y2="36.68" width="0.254" layer="1"/>
<wire x1="74.494" y1="36.68" x2="73.519990625" y2="36.127575" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$16">
<contactref element="C1" pad="2"/>
<contactref element="IC1" pad="20"/>
<wire x1="77.69" y1="21.055" x2="77.697" y2="21.844" width="0.254" layer="1"/>
<wire x1="77.697" y1="21.844" x2="77.705" y2="21.8694" width="0.254" layer="1"/>
<wire x1="77.69" y1="21.055" x2="77.686" y2="20.216" width="0.254" layer="1"/>
<wire x1="77.686" y1="20.216" x2="78.9" y2="20.217" width="0.254" layer="1"/>
<wire x1="78.9" y1="20.217" x2="82.0005375" y2="18.54909375" width="0.254" layer="1"/>
<wire x1="82.042" y1="18.288" x2="82.169" y2="18.037" width="0.254" layer="1"/>
<wire x1="82.0005375" y1="18.54909375" x2="82.042" y2="18.288" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$20">
<contactref element="R12" pad="1"/>
<contactref element="R11" pad="1"/>
<contactref element="IC1" pad="28"/>
<wire x1="91.13555625" y1="25.781" x2="82.55" y2="25.781" width="0.254" layer="1"/>
<wire x1="82.55" y1="25.781" x2="82.3976" y2="25.762" width="0.254" layer="1"/>
<wire x1="91.694" y1="26.924" x2="91.10855625" y2="27.202" width="0.254" layer="1"/>
<wire x1="97.677" y1="27.518" x2="97.263" y2="27.308" width="0.254" layer="1"/>
<wire x1="96.347" y1="28.66" x2="97.677" y2="27.518" width="0.254" layer="1"/>
<wire x1="93.571" y1="28.659" x2="96.347" y2="28.66" width="0.254" layer="1"/>
<wire x1="92.388" y1="27.32" x2="93.571" y2="28.659" width="0.254" layer="1"/>
<wire x1="97.263" y1="27.308" x2="97.112" y2="27.531" width="0.254" layer="1"/>
<wire x1="92.388" y1="27.32" x2="91.10855625" y2="27.202" width="0.254" layer="1"/>
<wire x1="91.13555625" y1="25.781" x2="91.10855625" y2="27.202" width="0.254" layer="1"/>
</signal>
<signal name="N$25">
<contactref element="R15" pad="1"/>
<contactref element="IC1" pad="27"/>
<contactref element="D2" pad="3"/>
<wire x1="92.578" y1="25" x2="82.269" y2="24.965" width="0.254" layer="1"/>
<wire x1="94.138" y1="27.313" x2="92.578" y2="25" width="0.254" layer="1"/>
<wire x1="82.269" y1="24.965" x2="82.3976" y2="24.962" width="0.254" layer="1"/>
<wire x1="94.138" y1="27.313" x2="94.599440625" y2="27.302" width="0.254" layer="1"/>
<wire x1="96.094" y1="25.842" x2="97.599" y2="25.848" width="0.254" layer="1"/>
<wire x1="96.094" y1="25.842" x2="94.599440625" y2="27.302" width="0.254" layer="1"/>
<wire x1="97.599" y1="25.848" x2="97.599" y2="24.382" width="0.254" layer="1"/>
<wire x1="97.599" y1="24.382" x2="97.584" y2="24.424" width="0.254" layer="1"/>
</signal>
<signal name="N$1">
<contactref element="R16" pad="2"/>
<contactref element="R17" pad="2"/>
<contactref element="CS1" pad="3"/>
<wire x1="58.374" y1="42.255" x2="58.347" y2="42.255" width="0.254" layer="1"/>
<wire x1="58.024" y1="36.889" x2="58.03" y2="38.78" width="0.254" layer="1"/>
<wire x1="58.374" y1="42.255" x2="58.42" y2="43.18" width="0" layer="19" extent="1-1"/>
<wire x1="58.016" y1="39.453" x2="58.374" y2="42.255" width="0" layer="19" extent="1-1"/>
<wire x1="58.03" y1="38.78" x2="58.016" y2="39.453" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$3">
<contactref element="R18" pad="2"/>
<contactref element="CS1" pad="15"/>
<wire x1="88.9" y1="43.18" x2="88.9" y2="37.53" width="0.254" layer="1"/>
<wire x1="88.9" y1="37.53" x2="89.1" y2="37.53" width="0.254" layer="1"/>
<wire x1="89.154" y1="37.592" x2="89.408" y2="37.338" width="0.254" layer="1"/>
<wire x1="89.408" y1="37.338" x2="89.66" y2="37.152" width="0.254" layer="1"/>
<wire x1="89.154" y1="37.592" x2="89.1" y2="37.53" width="0.254" layer="1"/>
</signal>
<signal name="N$26">
<contactref element="IC1" pad="9"/>
<contactref element="CS1" pad="6"/>
<wire x1="61.701" y1="40.353" x2="60.019" y2="38.041" width="0.254" layer="1"/>
<wire x1="66.04" y1="40.353" x2="66.04" y2="40.64" width="0.254" layer="1"/>
<wire x1="73.785" y1="31.065" x2="62.775" y2="31.065" width="0.254" layer="1"/>
<wire x1="62.775" y1="31.065" x2="59.99" y2="34.65" width="0.254" layer="1"/>
<wire x1="60.019" y1="38.041" x2="59.99" y2="37.831" width="0.254" layer="1"/>
<wire x1="59.99" y1="37.831" x2="59.99" y2="34.65" width="0.254" layer="1"/>
<wire x1="61.701" y1="40.353" x2="66.04" y2="40.353" width="0.254" layer="1"/>
<wire x1="73.785" y1="31.065" x2="73.8124" y2="31.0376" width="0.254" layer="1"/>
<wire x1="73.8124" y1="31.0376" x2="73.8124" y2="28.962" width="0.254" layer="1"/>
<wire x1="66.04" y1="40.64" x2="66.04" y2="43.18" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$27">
<contactref element="IC1" pad="2"/>
<contactref element="R21" pad="1"/>
<wire x1="80.137" y1="30.607" x2="80.105" y2="30.4546" width="0.254" layer="1"/>
<wire x1="79.3" y1="39.624" x2="79.196" y2="39.386" width="0.254" layer="1"/>
<wire x1="80.388" y1="33.199" x2="80.388" y2="36.911" width="0.254" layer="1"/>
<wire x1="80.388" y1="36.911" x2="80.38" y2="38.421" width="0.254" layer="1"/>
<wire x1="80.38" y1="38.421" x2="79.196" y2="39.386" width="0.254" layer="1"/>
<wire x1="80.137" y1="30.607" x2="80.109" y2="30.634" width="0.254" layer="1"/>
<wire x1="80.109" y1="30.634" x2="80.109" y2="31.995" width="0.254" layer="1"/>
<wire x1="80.109" y1="31.995" x2="80.388" y2="33.199" width="0.254" layer="1"/>
</signal>
<signal name="N$29">
<contactref element="CS1" pad="13"/>
<contactref element="R26" pad="1"/>
<wire x1="84.836" y1="37.719" x2="85.598" y2="37.338" width="0.254" layer="1"/>
<wire x1="84.836" y1="41.411" x2="84.836" y2="37.719" width="0.254" layer="1"/>
<wire x1="85.598" y1="37.338" x2="85.725" y2="37.214" width="0.254" layer="1"/>
<wire x1="84.836" y1="41.411" x2="83.82" y2="43.18" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$30">
<contactref element="IC1" pad="31"/>
<contactref element="CS1" pad="12"/>
<wire x1="83.185" y1="28.194" x2="82.55" y2="28.194" width="0.254" layer="1"/>
<wire x1="87.279" y1="35.814" x2="87.279" y2="32.558" width="0.254" layer="1"/>
<wire x1="84.074" y1="35.814" x2="87.279" y2="35.814" width="0.254" layer="1"/>
<wire x1="84.095" y1="40.592" x2="84.074" y2="35.814" width="0.254" layer="1"/>
<wire x1="82.55" y1="28.194" x2="82.3976" y2="28.162" width="0.254" layer="1"/>
<wire x1="83.185" y1="28.194" x2="86.373" y2="28.188" width="0.254" layer="1"/>
<wire x1="86.373" y1="28.188" x2="86.373" y2="31.158" width="0.254" layer="1"/>
<wire x1="86.373" y1="31.158" x2="87.279" y2="32.558" width="0.254" layer="1"/>
<wire x1="81.27" y1="41.04" x2="81.242" y2="41.069" width="0.254" layer="1"/>
<wire x1="81.242" y1="41.069" x2="81.27" y2="42.66" width="0.254" layer="1"/>
<wire x1="84.095" y1="40.592" x2="83.3" y2="41.069" width="0.254" layer="1"/>
<wire x1="83.3" y1="41.069" x2="81.242" y2="41.069" width="0.254" layer="1"/>
<wire x1="81.27" y1="42.66" x2="81.28" y2="43.18" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$22">
<contactref element="C7" pad="1"/>
<contactref element="IC1" pad="7"/>
<contactref element="QF1" pad="2"/>
<wire x1="76.1" y1="33.274" x2="76.1" y2="30.48" width="0.254" layer="1"/>
<wire x1="76.897" y1="34.164" x2="76.1" y2="33.274" width="0.254" layer="1"/>
<wire x1="76.897" y1="36.8" x2="76.897" y2="34.164" width="0.254" layer="1"/>
<wire x1="76.897" y1="36.8" x2="76.897" y2="36.831" width="0.254" layer="1"/>
<wire x1="76.1" y1="30.48" x2="76.105" y2="30.4546" width="0.254" layer="1"/>
<wire x1="64.479" y1="37.513" x2="64.509" y2="32.971" width="0.254" layer="1"/>
<wire x1="64.479" y1="37.513" x2="76.891" y2="37.492" width="0.254" layer="1"/>
<wire x1="76.891" y1="37.492" x2="76.897" y2="36.8" width="0.254" layer="1"/>
<wire x1="64.479" y1="37.513" x2="63.86800625" y2="36.144421875" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$23">
<contactref element="IC1" pad="25"/>
<contactref element="R19" pad="2"/>
<wire x1="94.488" y1="24.257" x2="93.599" y2="24.257" width="0.254" layer="1"/>
<wire x1="94.488" y1="24.257" x2="95.451" y2="24.588" width="0.254" layer="1"/>
<wire x1="82.3976" y1="23.362" x2="86.36" y2="23.362" width="0.254" layer="1"/>
<wire x1="86.36" y1="23.362" x2="86.36" y2="22.86" width="0.254" layer="1"/>
<wire x1="86.36" y1="22.86" x2="93.599" y2="22.86" width="0.254" layer="1"/>
<wire x1="93.599" y1="22.86" x2="93.599" y2="24.257" width="0.254" layer="1"/>
</signal>
<signal name="N$18">
<contactref element="SL1" pad="1"/>
<contactref element="R35" pad="2"/>
<wire x1="48.615" y1="26.378" x2="51.281" y2="25.566" width="0.4064" layer="1"/>
</signal>
<signal name="N$19">
<contactref element="Q1" pad="3"/>
<contactref element="R14" pad="2"/>
<contactref element="IC1" pad="11"/>
<wire x1="55.946" y1="28.899" x2="58.947" y2="28.892" width="0.3048" layer="1"/>
<wire x1="73.8124" y1="27.362" x2="73.9364" y2="27.378" width="0.254" layer="1"/>
<wire x1="73.9364" y1="27.378" x2="70.308" y2="27.402" width="0.254" layer="1"/>
<wire x1="70.308" y1="27.402" x2="70.308" y2="28.877" width="0.254" layer="1"/>
<wire x1="68.906996875" y1="28.87555625" x2="70.308" y2="28.877" width="0.254" layer="1"/>
<wire x1="58.947" y1="28.892" x2="68.906996875" y2="28.87555625" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$34">
<contactref element="CS1" pad="4"/>
<contactref element="R21" pad="2"/>
<wire x1="68.58" y1="46.132" x2="69.834" y2="44.39" width="0.254" layer="1"/>
<wire x1="62.676" y1="46.132" x2="68.58" y2="46.132" width="0.254" layer="1"/>
<wire x1="60.96" y1="43.18" x2="60.96" y2="43.688" width="0.254" layer="1"/>
<wire x1="60.96" y1="43.688" x2="62.676" y2="46.132" width="0.254" layer="1"/>
<wire x1="69.834" y1="44.39" x2="69.82" y2="40.534" width="0.254" layer="1"/>
<wire x1="69.82" y1="40.534" x2="69.82" y2="40.283" width="0.254" layer="1"/>
<wire x1="69.82" y1="40.283" x2="70.714" y2="39.389" width="0.254" layer="1"/>
<wire x1="70.714" y1="39.389" x2="75.793" y2="39.389" width="0.254" layer="1"/>
<wire x1="75.793" y1="39.389" x2="75.796" y2="39.386" width="0.254" layer="1"/>
</signal>
<signal name="N$31">
<contactref element="C1" pad="1"/>
<contactref element="C3" pad="2"/>
<contactref element="R20" pad="1"/>
<wire x1="82.042" y1="15.24" x2="79.248" y2="15.24" width="0.254" layer="1"/>
<wire x1="79.248" y1="15.24" x2="79.653" y2="15.174" width="0.254" layer="1"/>
<wire x1="82.042" y1="15.24" x2="82.169" y2="15.237" width="0.254" layer="1"/>
<wire x1="86.106" y1="16.002" x2="86.868" y2="15.24" width="0.254" layer="1"/>
<wire x1="83.058" y1="16.002" x2="86.106" y2="16.002" width="0.254" layer="1"/>
<wire x1="82.296" y1="15.24" x2="83.058" y2="16.002" width="0.254" layer="1"/>
<wire x1="82.296" y1="15.24" x2="82.169" y2="15.237" width="0.254" layer="1"/>
<wire x1="86.868" y1="15.24" x2="88.262" y2="15.24" width="0.254" layer="1"/>
</signal>
<signal name="N$33">
<contactref element="R22" pad="2"/>
<contactref element="CS1" pad="14"/>
<wire x1="86.36" y1="43.18" x2="86.36" y2="39.96" width="0.254" layer="1"/>
<wire x1="86.36" y1="39.96" x2="86.13" y2="39.96" width="0.254" layer="1"/>
<wire x1="86.13" y1="39.96" x2="86.155" y2="39.385" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$35">
<contactref element="R4" pad="2"/>
<contactref element="R3" pad="2"/>
<wire x1="66.04" y1="18.796" x2="66.04" y2="21.336" width="0.254" layer="1"/>
<wire x1="66.04" y1="21.336" x2="66.037" y2="20.903" width="0.254" layer="1"/>
<wire x1="66.04" y1="18.796" x2="66.03700625" y2="18.323884375" width="0.254" layer="1"/>
<contactref element="TP1" pad="2"/>
<contactref element="IC1" pad="24"/>
<wire x1="81.026" y1="21.844" x2="80.905" y2="21.8694" width="0.254" layer="1"/>
<wire x1="94.256" y1="22.86" x2="94.234" y2="22.098" width="0.254" layer="1"/>
<wire x1="97.649" y1="22.86" x2="94.256" y2="22.86" width="0.254" layer="1"/>
<wire x1="97.649" y1="20.531" x2="97.649" y2="22.86" width="0.254" layer="1"/>
<wire x1="94.059" y1="17.013" x2="97.649" y2="20.531" width="0.254" layer="1"/>
<wire x1="90.805" y1="19.404" x2="90.791" y2="17.02" width="0.254" layer="1"/>
<wire x1="90.791" y1="17.02" x2="94.059" y2="17.013" width="0.254" layer="1"/>
<wire x1="81.026" y1="22.098" x2="80.905" y2="21.8694" width="0.254" layer="1"/>
<wire x1="66.04" y1="17.272" x2="66.04" y2="18.542" width="0.254" layer="1"/>
<wire x1="67.437" y1="16.129" x2="66.04" y2="17.272" width="0.254" layer="1"/>
<wire x1="67.437" y1="13.843" x2="67.437" y2="16.129" width="0.254" layer="1"/>
<wire x1="67.818" y1="13.014" x2="67.437" y2="13.843" width="0.254" layer="1"/>
<wire x1="88.9" y1="13.014" x2="67.818" y2="13.014" width="0.254" layer="1"/>
<wire x1="89.662" y1="14.224" x2="88.9" y2="13.014" width="0.254" layer="1"/>
<wire x1="89.669" y1="16.441" x2="89.662" y2="14.224" width="0.254" layer="1"/>
<wire x1="66.04" y1="18.542" x2="66.03700625" y2="18.323884375" width="0.254" layer="1"/>
<wire x1="94.234" y1="22.098" x2="86.319" y2="22.098" width="0.254" layer="1"/>
<wire x1="86.319" y1="22.098" x2="86.319" y2="21.165" width="0.254" layer="1"/>
<wire x1="86.319" y1="21.165" x2="82.208" y2="21.165" width="0.254" layer="1"/>
<wire x1="82.208" y1="21.165" x2="82.208" y2="21.86" width="0.254" layer="1"/>
<wire x1="82.208" y1="21.86" x2="80.892" y2="21.8554" width="0.254" layer="1"/>
<wire x1="80.892" y1="21.8554" x2="80.905" y2="21.8694" width="0.254" layer="1"/>
<wire x1="89.669" y1="16.441" x2="90.248" y2="17.02" width="0.254" layer="1"/>
<wire x1="90.248" y1="17.02" x2="90.791" y2="17.02" width="0.254" layer="1"/>
</signal>
<signal name="N$39">
<contactref element="R2" pad="2"/>
<contactref element="R1" pad="2"/>
<contactref element="R25" pad="1"/>
<wire x1="66.04" y1="24.384" x2="66.04" y2="26.924" width="0.254" layer="1"/>
<wire x1="66.04" y1="26.924" x2="66.107" y2="26.143440625" width="0.254" layer="1"/>
<wire x1="66.04" y1="24.384" x2="66.107" y2="23.487" width="0.254" layer="1"/>
<wire x1="64.54" y1="15.075" x2="65.786" y2="15.042" width="0.254" layer="1"/>
<wire x1="66.024" y1="23.094" x2="64.554" y2="23.087" width="0.254" layer="1"/>
<wire x1="65.786" y1="15.042" x2="66.037" y2="14.986" width="0.254" layer="1"/>
<wire x1="66.024" y1="23.094" x2="66.107" y2="23.487" width="0.254" layer="1"/>
<wire x1="64.54" y1="15.075" x2="64.554" y2="15.075" width="0.254" layer="1"/>
<wire x1="64.554" y1="15.075" x2="64.554" y2="23.087" width="0.254" layer="1"/>
</signal>
<signal name="N$40">
<contactref element="R25" pad="2"/>
<contactref element="R24" pad="2"/>
<wire x1="84.844" y1="14.732" x2="85.09" y2="14.732" width="0.254" layer="1"/>
<wire x1="84.012" y1="13.795" x2="84.844" y2="14.732" width="0.254" layer="1"/>
<wire x1="69.684" y1="13.795" x2="84.012" y2="13.795" width="0.254" layer="1"/>
<wire x1="69.088" y1="14.986" x2="69.684" y2="13.795" width="0.254" layer="1"/>
<wire x1="85.09" y1="14.732" x2="85.09" y2="14.756" width="0.254" layer="1"/>
<wire x1="69.088" y1="14.986" x2="68.837" y2="14.986" width="0.254" layer="1"/>
</signal>
<signal name="N$38">
<via x="47.752" y="12.192" extent="1-16" drill="0.6" diameter="2.54"/>
</signal>
<signal name="N$41">
<via x="47.752" y="43.18" extent="1-16" drill="0.6" diameter="2.54"/>
</signal>
<signal name="N$42">
<via x="122.809" y="43.18" extent="1-16" drill="0.6" diameter="2.54"/>
</signal>
<signal name="N$43">
<via x="122.809" y="12.192" extent="1-16" drill="0.6" diameter="2.54"/>
</signal>
<signal name="N$46">
<contactref element="R13" pad="2"/>
<contactref element="C10" pad="+"/>
<contactref element="R15" pad="2"/>
<contactref element="CS1" pad="2"/>
<contactref element="R16" pad="1"/>
<contactref element="R18" pad="1"/>
<contactref element="C3" pad="1"/>
<contactref element="IC1" pad="18"/>
<contactref element="C4" pad="1"/>
<contactref element="IC1" pad="4"/>
<contactref element="IC1" pad="6"/>
<contactref element="R14" pad="1"/>
<contactref element="IC2" pad="3"/>
<contactref element="C6" pad="1"/>
<wire x1="76.119" y1="21.871" x2="76.105" y2="21.8694" width="0.254" layer="1"/>
<wire x1="76.892" y1="23.347" x2="76.906" y2="30.233" width="0.254" layer="1"/>
<wire x1="76.092" y1="22.633" x2="76.892" y2="23.347" width="0.254" layer="1"/>
<wire x1="76.092" y1="22.098" x2="76.092" y2="22.633" width="0.254" layer="1"/>
<wire x1="76.906" y1="30.233" x2="76.905" y2="30.4546" width="0.254" layer="1"/>
<wire x1="76.092" y1="22.098" x2="76.105" y2="21.8694" width="0.254" layer="1"/>
<wire x1="78.513" y1="32.004" x2="78.513" y2="30.48" width="0.254" layer="1"/>
<wire x1="76.894" y1="32.286" x2="78.445" y2="32.286" width="0.254" layer="1"/>
<wire x1="76.908" y1="30.48" x2="76.894" y2="32.286" width="0.254" layer="1"/>
<wire x1="78.513" y1="30.48" x2="78.505" y2="30.4546" width="0.254" layer="1"/>
<wire x1="76.908" y1="30.48" x2="76.905" y2="30.4546" width="0.254" layer="1"/>
<wire x1="58.166" y1="31.566" x2="58.534" y2="31.561" width="0.254" layer="1"/>
<wire x1="58.166" y1="31.566" x2="58.102" y2="31.645" width="0.254" layer="1"/>
<wire x1="55.468" y1="39.212" x2="55.118" y2="39.37" width="0.254" layer="1"/>
<wire x1="55.118" y1="39.37" x2="55.216" y2="39.453" width="0.254" layer="1"/>
<wire x1="78.486" y1="18.034" x2="78.994" y2="18.034" width="0.254" layer="1"/>
<wire x1="77.216" y1="16.637" x2="78.486" y2="18.034" width="0.254" layer="1"/>
<wire x1="67.963" y1="16.637" x2="77.216" y2="16.637" width="0.254" layer="1"/>
<wire x1="67.416" y1="17.225" x2="67.963" y2="16.637" width="0.254" layer="1"/>
<wire x1="67.451" y1="27.329" x2="67.416" y2="17.225" width="0.254" layer="1"/>
<wire x1="66.18" y1="28.992" x2="67.451" y2="27.329" width="0.254" layer="1"/>
<wire x1="78.994" y1="18.034" x2="79.653" y2="17.974" width="0.254" layer="1"/>
<wire x1="66.18" y1="28.992" x2="66.107" y2="28.880440625" width="0.254" layer="1"/>
<wire x1="100.838" y1="33.274" x2="101.086" y2="33.3" width="0.254" layer="1"/>
<wire x1="88.646" y1="29.972" x2="89.789" y2="28.575" width="0.254" layer="1"/>
<wire x1="88.646" y1="29.972" x2="88.51655625" y2="29.974996875" width="0.254" layer="1"/>
<wire x1="101.086" y1="33.401" x2="101.086" y2="33.3" width="0.254" layer="1"/>
<wire x1="76.119" y1="21.871" x2="76.119" y2="19.556" width="0.254" layer="1"/>
<wire x1="76.119" y1="19.556" x2="77.535" y2="19.549" width="0.254" layer="1"/>
<wire x1="77.535" y1="19.549" x2="79.033" y2="18.516" width="0.254" layer="1"/>
<wire x1="79.033" y1="18.516" x2="79.11" y2="18.63" width="0.254" layer="1"/>
<wire x1="79.12" y1="18.614" x2="78.994" y2="18.288" width="0.254" layer="1"/>
<wire x1="78.994" y1="18.288" x2="79.653" y2="17.974" width="0.254" layer="1"/>
<wire x1="79.12" y1="18.614" x2="79.033" y2="18.516" width="0.254" layer="1"/>
<wire x1="78.518" y1="33.136" x2="78.519" y2="33.479" width="0.254" layer="1"/>
<wire x1="78.513" y1="32.004" x2="78.518" y2="33.136" width="0.254" layer="1"/>
<wire x1="53.962" y1="39.176" x2="55.468" y2="39.212" width="0.254" layer="1"/>
<wire x1="53.962" y1="35.348" x2="53.962" y2="39.176" width="0.254" layer="1"/>
<wire x1="58.376" y1="31.54" x2="58.156" y2="31.62" width="0.254" layer="1"/>
<wire x1="55.468" y1="39.212" x2="55.216" y2="39.453" width="0.254" layer="1"/>
<wire x1="58.376" y1="31.54" x2="58.102" y2="31.645" width="0.254" layer="1"/>
<wire x1="55.118" y1="39.37" x2="55.118" y2="39.555" width="0.254" layer="1"/>
<wire x1="55.118" y1="39.555" x2="54.926" y2="39.506" width="0.254" layer="1"/>
<wire x1="54.926" y1="39.506" x2="55.836" y2="42.692" width="0.254" layer="1"/>
<wire x1="55.836" y1="42.692" x2="55.998" y2="42.579" width="0.254" layer="1"/>
<wire x1="94.973" y1="30.078" x2="95.337" y2="30.078" width="0.4064" layer="1"/>
<wire x1="89.789" y1="28.575" x2="92.329" y2="28.575" width="0.254" layer="1"/>
<wire x1="64.894" y1="27.724" x2="65.73" y2="28.35" width="0.254" layer="1"/>
<wire x1="88.646" y1="29.972" x2="89.502" y2="31.633" width="0.254" layer="1"/>
<wire x1="89.502" y1="31.633" x2="89.663" y2="31.99" width="0.254" layer="1"/>
<wire x1="89.66" y1="34.352" x2="89.67" y2="33.46" width="0.254" layer="1"/>
<wire x1="58.156" y1="31.62" x2="58.18" y2="31.97" width="0.254" layer="1"/>
<wire x1="100.838" y1="33.274" x2="100.838" y2="32.828" width="0.4064" layer="1"/>
<wire x1="94.59455625" y1="30.101996875" x2="97.549003125" y2="30.136996875" width="0.4064" layer="1"/>
<wire x1="60.699" y1="31.561" x2="58.534" y2="31.561" width="0.254" layer="1"/>
<wire x1="61.91" y1="27.724" x2="64.894" y2="27.724" width="0.254" layer="1"/>
<wire x1="53.962" y1="35.348" x2="55.862" y2="35.348" width="0.254" layer="1"/>
<wire x1="55.862" y1="35.348" x2="56.84" y2="34.51" width="0.254" layer="1"/>
<wire x1="56.84" y1="34.51" x2="56.84" y2="33.25" width="0.254" layer="1"/>
<wire x1="56.84" y1="33.25" x2="57.75" y2="32.34" width="0.254" layer="1"/>
<wire x1="60.699" y1="31.561" x2="61.53" y2="30.45" width="0.254" layer="1"/>
<wire x1="61.53" y1="30.45" x2="61.53" y2="27.964" width="0.254" layer="1"/>
<wire x1="61.53" y1="27.964" x2="61.91" y2="27.724" width="0.254" layer="1"/>
<wire x1="89.67" y1="33.46" x2="89.67" y2="32.494" width="0.254" layer="1"/>
<wire x1="89.67" y1="32.494" x2="89.663" y2="31.99" width="0.254" layer="1"/>
<wire x1="92.329" y1="28.575" x2="93.656" y2="30.097" width="0.254" layer="1"/>
<wire x1="93.656" y1="30.097" x2="94.59455625" y2="30.101996875" width="0.254" layer="1"/>
<wire x1="97.549003125" y1="30.136996875" x2="97.549003125" y2="30.454003125" width="0.4064" layer="1"/>
<wire x1="97.549003125" y1="30.454003125" x2="98.98" y2="31.885" width="0.4064" layer="1"/>
<wire x1="98.98" y1="31.885" x2="100.506" y2="31.885" width="0.4064" layer="1"/>
<wire x1="100.506" y1="31.885" x2="101.346" y2="32.725" width="0.4064" layer="1"/>
<wire x1="101.346" y1="32.725" x2="101.346" y2="32.774" width="0.4064" layer="1"/>
<wire x1="101.346" y1="32.774" x2="100.838" y2="32.828" width="0" layer="19" extent="1-1"/>
<wire x1="94.973" y1="30.078" x2="94.59455625" y2="30.101996875" width="0" layer="19" extent="1-1"/>
<wire x1="97.115" y1="30.067" x2="97.549003125" y2="30.136996875" width="0" layer="19" extent="1-1"/>
<wire x1="78.513" y1="30.48" x2="88.51655625" y2="29.974996875" width="0" layer="19" extent="1-1"/>
<wire x1="78.445" y1="32.286" x2="78.513" y2="32.004" width="0" layer="19" extent="1-1"/>
<wire x1="78.382" y1="33.938" x2="78.519" y2="33.479" width="0" layer="19" extent="1-1"/>
<wire x1="65.73" y1="28.35" x2="66.107" y2="28.880440625" width="0" layer="19" extent="1-1"/>
<wire x1="57.75" y1="32.34" x2="58.18" y2="31.97" width="0" layer="19" extent="1-1"/>
<wire x1="55.88" y1="43.18" x2="55.836" y2="42.692" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$2">
<contactref element="CS1" pad="11"/>
<contactref element="IC1" pad="30"/>
<wire x1="83.247" y1="27.386" x2="82.55" y2="27.378" width="0.254" layer="1"/>
<wire x1="88.041" y1="36.603" x2="88.041" y2="32.531" width="0.254" layer="1"/>
<wire x1="87.63" y1="36.576" x2="88.041" y2="36.603" width="0.254" layer="1"/>
<wire x1="87.63" y1="44.196" x2="87.63" y2="36.576" width="0.254" layer="1"/>
<wire x1="86.868" y1="45.028" x2="87.63" y2="44.196" width="0.254" layer="1"/>
<wire x1="80.518" y1="45.028" x2="86.868" y2="45.028" width="0.254" layer="1"/>
<wire x1="78.74" y1="43.18" x2="80.364" y2="44.928" width="0.254" layer="1"/>
<wire x1="80.364" y1="44.928" x2="80.518" y2="45.028" width="0.254" layer="1"/>
<wire x1="82.55" y1="27.378" x2="82.3976" y2="27.362" width="0.254" layer="1"/>
<wire x1="78.867" y1="43.434" x2="78.994" y2="43.434" width="0.6096" layer="1"/>
<wire x1="78.994" y1="43.434" x2="80.364" y2="44.928" width="0.6096" layer="1"/>
<wire x1="83.247" y1="27.386" x2="86.94" y2="27.391" width="0.254" layer="1"/>
<wire x1="86.94" y1="27.391" x2="86.94" y2="30.888" width="0.254" layer="1"/>
<wire x1="86.94" y1="30.888" x2="88.041" y2="32.531" width="0.254" layer="1"/>
</signal>
<signal name="N$47">
<contactref element="IC1" pad="1"/>
<contactref element="R22" pad="1"/>
<wire x1="80.918" y1="31.587" x2="80.905" y2="30.4546" width="0.254" layer="1"/>
<wire x1="82.55" y1="39.37" x2="82.755" y2="39.385" width="0.254" layer="1"/>
<wire x1="80.918" y1="31.587" x2="80.932" y2="36.07" width="0.254" layer="1"/>
<wire x1="80.932" y1="36.07" x2="82.748" y2="36.07" width="0.254" layer="1"/>
<wire x1="82.748" y1="36.07" x2="82.755" y2="39.385" width="0.254" layer="1"/>
</signal>
<signal name="N$28">
<contactref element="IC1" pad="32"/>
<contactref element="R26" pad="2"/>
<wire x1="82.924" y1="28.984" x2="82.3976" y2="28.962" width="0.254" layer="1"/>
<wire x1="86.106" y1="33.782" x2="85.725" y2="34.414" width="0.254" layer="1"/>
<wire x1="86.106" y1="33.782" x2="85.8038125" y2="34.3139875" width="0.254" layer="1"/>
<wire x1="85.8038125" y1="34.3139875" x2="85.698" y2="33.917" width="0.254" layer="1"/>
<wire x1="82.924" y1="28.984" x2="83.166" y2="28.983" width="0.254" layer="1"/>
<wire x1="83.166" y1="28.983" x2="85.779" y2="28.998" width="0.254" layer="1"/>
<wire x1="85.779" y1="28.998" x2="85.8038125" y2="34.3139875" width="0.254" layer="1"/>
</signal>
<signal name="N$37">
<via x="77.724" y="32.256" extent="1-16" drill="0.6" shape="square"/>
</signal>
<signal name="N$45">
<via x="58.899" y="28.886" extent="1-16" drill="0.6" shape="square"/>
</signal>
<signal name="N$48">
<via x="89.606" y="32.202" extent="1-16" drill="0.6" shape="square"/>
</signal>
<signal name="N$49">
<via x="70.913" y="28.895" extent="1-16" drill="0.6" shape="square"/>
</signal>
<signal name="N$44">
<via x="92.075" y="23.749" extent="1-16" drill="0.6" shape="square"/>
</signal>
<signal name="N$50">
<wire x1="82.55" y1="24.157" x2="86.94" y2="24.157" width="0.254" layer="1"/>
<wire x1="86.94" y1="24.157" x2="86.94" y2="23.76" width="0.254" layer="1"/>
<wire x1="86.94" y1="23.76" x2="91.8" y2="23.76" width="0.254" layer="1"/>
</signal>
<signal name="N$52">
<via x="47.752" y="43.18" extent="1-16" drill="0.5" diameter="0.3048"/>
</signal>
<signal name="N$66">
<via x="122.809" y="12.192" extent="1-16" drill="0.5" diameter="0.3048"/>
</signal>
<signal name="N$63">
<via x="122.809" y="43.18" extent="1-16" drill="0.5" diameter="0.3048"/>
</signal>
<signal name="N$67">
<via x="76.2" y="43.18" extent="1-16" drill="0.5" diameter="0.3048"/>
<via x="73.66" y="43.18" extent="1-16" drill="0.5" diameter="0.3048"/>
<via x="71.12" y="43.18" extent="1-16" drill="0.5" diameter="0.3048"/>
<via x="68.58" y="43.18" extent="1-16" drill="0.5" diameter="0.3048"/>
<via x="66.04" y="43.18" extent="1-16" drill="0.5" diameter="0.3048"/>
<via x="63.5" y="43.18" extent="1-16" drill="0.5" diameter="0.3048"/>
<via x="60.96" y="43.18" extent="1-16" drill="0.5" diameter="0.3048"/>
<via x="58.42" y="43.18" extent="1-16" drill="0.5" diameter="0.3048"/>
<wire x1="73.66" y1="43.18" x2="76.2" y2="43.18" width="0" layer="19" extent="1-1"/>
<wire x1="71.12" y1="43.18" x2="73.66" y2="43.18" width="0" layer="19" extent="1-1"/>
<wire x1="68.58" y1="43.18" x2="71.12" y2="43.18" width="0" layer="19" extent="1-1"/>
<wire x1="66.04" y1="43.18" x2="68.58" y2="43.18" width="0" layer="19" extent="1-1"/>
<wire x1="63.5" y1="43.18" x2="66.04" y2="43.18" width="0" layer="19" extent="1-1"/>
<wire x1="60.96" y1="43.18" x2="63.5" y2="43.18" width="0" layer="19" extent="1-1"/>
<wire x1="58.42" y1="43.18" x2="60.96" y2="43.18" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$161">
<via x="86.36" y="43.18" extent="1-16" drill="0.5" diameter="0.3048"/>
<via x="88.9" y="43.18" extent="1-16" drill="0.5" diameter="0.3048"/>
<via x="91.44" y="43.18" extent="1-16" drill="0.5" diameter="0.3048"/>
<via x="92.075" y="23.749" extent="1-16" drill="0.5" diameter="0.3048"/>
<wire x1="88.9" y1="43.18" x2="91.44" y2="43.18" width="0" layer="19" extent="1-1"/>
<wire x1="86.36" y1="43.18" x2="88.9" y2="43.18" width="0" layer="19" extent="1-1"/>
<wire x1="92.075" y1="23.749" x2="91.44" y2="43.18" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$53">
<via x="78.74" y="43.18" extent="1-16" drill="0.5" diameter="0.3048"/>
<via x="81.28" y="43.18" extent="1-16" drill="0.5" diameter="0.3048"/>
<via x="83.818" y="43.18" extent="1-16" drill="0.5" diameter="0.3048"/>
<wire x1="83.818" y1="43.18" x2="81.28" y2="43.18" width="0" layer="19" extent="1-1"/>
<wire x1="78.74" y1="43.18" x2="81.28" y2="43.18" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$54">
<via x="93.345" y="19.431" extent="1-16" drill="0.5" diameter="1.27"/>
<via x="90.805" y="19.304" extent="1-16" drill="0.5" diameter="1.27"/>
<via x="88.265" y="19.431" extent="1-16" drill="0.5" diameter="1.27"/>
<wire x1="90.805" y1="19.304" x2="93.345" y2="19.431" width="0" layer="19" extent="1-1"/>
<wire x1="88.265" y1="19.431" x2="90.805" y2="19.304" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$55">
</signal>
<signal name="N$56">
<contactref element="D3" pad="A"/>
<contactref element="IC3" pad="1"/>
<contactref element="R33" pad="1"/>
<wire x1="112.414" y1="26.906" x2="113.148" y2="26.091" width="0.254" layer="1"/>
<wire x1="118.166" y1="28.277" x2="119.168" y2="28.591" width="0.254" layer="1"/>
<wire x1="117.001" y1="31.739" x2="116.59" y2="31.739" width="0.254" layer="1"/>
<wire x1="117.74" y1="31.652" x2="117.001" y2="31.739" width="0.254" layer="1"/>
<wire x1="116.59" y1="31.739" x2="117.041" y2="31.71" width="0.254" layer="1"/>
<wire x1="113.862" y1="27.183" x2="113.862" y2="26.929" width="0.6096" layer="1"/>
<wire x1="113.148" y1="26.091" x2="115.06" y2="28.003" width="0.6096" layer="1"/>
<wire x1="115.06" y1="28.003" x2="118.516" y2="28.003" width="0.6096" layer="1"/>
<wire x1="118.51" y1="31.651" x2="119.168" y2="31.07" width="0.4064" layer="1"/>
<wire x1="119.168" y1="31.07" x2="119.168" y2="28.591" width="0.4064" layer="1"/>
<wire x1="118.51" y1="31.651" x2="118.448" y2="31.652" width="0.4064" layer="1"/>
<wire x1="118.448" y1="31.652" x2="117.74" y2="31.652" width="0.4064" layer="1"/>
<wire x1="118.516" y1="28.003" x2="118.166" y2="28.277" width="0" layer="19" extent="1-1"/>
<wire x1="113.862" y1="26.929" x2="113.148" y2="26.091" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$57">
<contactref element="IC3" pad="8"/>
<contactref element="R23" pad="1"/>
<wire x1="112.652" y1="31.664" x2="113.296" y2="29.464" width="0.254" layer="1"/>
<wire x1="112.652" y1="31.664" x2="111.841" y2="31.71" width="0.254" layer="1"/>
</signal>
<signal name="N$58">
<contactref element="IC3" pad="7"/>
<contactref element="R23" pad="2"/>
<contactref element="R27" pad="2"/>
<contactref element="R33" pad="2"/>
<wire x1="110.0198875" y1="33.009" x2="110.593" y2="33.009" width="0.254" layer="1"/>
<wire x1="110.593" y1="33.009" x2="111.841" y2="32.98" width="0.254" layer="1"/>
<wire x1="109.844" y1="28.912" x2="110.496" y2="29.464" width="0.254" layer="1"/>
<wire x1="107.678" y1="26.434" x2="107.148" y2="26.091" width="0.4064" layer="1"/>
<contactref element="R30" pad="2"/>
<wire x1="108.038" y1="29.26" x2="108.024" y2="29.253" width="0.4064" layer="1"/>
<wire x1="105.875" y1="29.05" x2="105.691" y2="29.234" width="0.4064" layer="1"/>
<wire x1="105.691" y1="29.234" x2="105.556" y2="29.157" width="0.4064" layer="1"/>
<wire x1="107.678" y1="26.434" x2="108.038" y2="26.676" width="0.6096" layer="1"/>
<wire x1="108.038" y1="26.676" x2="108.038" y2="29.26" width="0.6096" layer="1"/>
<wire x1="105.875" y1="29.05" x2="105.56" y2="29.05" width="0.4064" layer="1"/>
<wire x1="105.56" y1="29.05" x2="105.49" y2="29.12" width="0.4064" layer="1"/>
<wire x1="105.49" y1="29.12" x2="107.31" y2="29.12" width="0.4064" layer="1"/>
<wire x1="107.31" y1="29.12" x2="108.038" y2="29.26" width="0.4064" layer="1"/>
<wire x1="108.038" y1="29.26" x2="110.012" y2="29.302" width="0.4064" layer="1"/>
<wire x1="110.012" y1="29.302" x2="110.0128875" y2="29.344634375" width="0.4064" layer="1"/>
<wire x1="110.0128875" y1="29.344634375" x2="110.496" y2="29.464" width="0.4064" layer="1"/>
<wire x1="110.0198875" y1="33.009" x2="110.0128875" y2="29.344634375" width="0.254" layer="1"/>
</signal>
<signal name="N$64">
<contactref element="C13" pad="1"/>
<contactref element="IC3" pad="3"/>
<wire x1="116.586" y1="34.29" x2="117.094" y2="34.29" width="0.254" layer="1"/>
<wire x1="116.586" y1="34.29" x2="117.041" y2="34.25" width="0.254" layer="1"/>
<wire x1="116.586" y1="37.338" x2="115.316" y2="37.338" width="0.254" layer="1"/>
<wire x1="118.991" y1="36.16" x2="116.586" y2="37.338" width="0.254" layer="1"/>
<wire x1="118.984" y1="34.297" x2="118.991" y2="36.16" width="0.254" layer="1"/>
<wire x1="117.094" y1="34.29" x2="118.984" y2="34.297" width="0.254" layer="1"/>
<wire x1="115.316" y1="37.338" x2="115.092" y2="37.406" width="0.254" layer="1"/>
<wire x1="117.094" y1="34.29" x2="117.041" y2="34.25" width="0.254" layer="1"/>
</signal>
<signal name="N$61">
<contactref element="C14" pad="1"/>
<contactref element="IC1" pad="26"/>
<contactref element="R31" pad="1"/>
<contactref element="R32" pad="1"/>
<wire x1="109.914" y1="22.582" x2="111.519" y2="22.582" width="0.254" layer="1"/>
<wire x1="108.974" y1="22.659" x2="109.21" y2="22.029" width="0.254" layer="1"/>
<wire x1="109.21" y1="22.029" x2="109.077" y2="22.604" width="0.254" layer="1"/>
<wire x1="109.077" y1="22.604" x2="106.188" y2="22.555" width="0.254" layer="1"/>
<wire x1="106.188" y1="22.555" x2="104.837" y2="23.794" width="0.254" layer="1"/>
<wire x1="104.837" y1="23.794" x2="104.973" y2="23.769" width="0.254" layer="1"/>
<wire x1="104.973" y1="23.769" x2="104.791" y2="23.769" width="0.254" layer="1"/>
<wire x1="111.519" y1="22.582" x2="111.586" y2="22.714" width="0" layer="19" extent="1-1"/>
<wire x1="109.077" y1="22.604" x2="109.914" y2="22.582" width="0" layer="19" extent="1-1"/>
<wire x1="106.355" y1="22.688" x2="106.188" y2="22.555" width="0" layer="19" extent="1-1"/>
<wire x1="82.3976" y1="24.162" x2="104.791" y2="23.769" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$62">
<contactref element="IC3" pad="5"/>
<contactref element="R28" pad="2"/>
<contactref element="R29" pad="2"/>
<wire x1="109.647" y1="35.569" x2="109.062" y2="35.611" width="0.254" layer="1"/>
<wire x1="109.062" y1="35.611" x2="109.084" y2="35.686" width="0.254" layer="1"/>
<wire x1="110.944" y1="35.549" x2="111.841" y2="35.52" width="0.254" layer="1"/>
<wire x1="112.743" y1="35.522" x2="113.763" y2="34.756" width="0.254" layer="1"/>
<wire x1="111.171" y1="35.522" x2="112.743" y2="35.522" width="0.254" layer="1"/>
<wire x1="111.171" y1="35.522" x2="111.841" y2="35.52" width="0.254" layer="1"/>
<wire x1="113.763" y1="34.756" x2="113.799" y2="34.72" width="0.254" layer="1"/>
<wire x1="113.799" y1="34.72" x2="113.799" y2="31.836" width="0.254" layer="1"/>
<wire x1="113.799" y1="31.836" x2="115.865" y2="29.77" width="0.254" layer="1"/>
<wire x1="115.865" y1="29.77" x2="116.145" y2="29.665" width="0.254" layer="1"/>
<wire x1="109.647" y1="35.569" x2="108.367" y2="35.549" width="0.254" layer="1"/>
<wire x1="108.367" y1="35.549" x2="110.944" y2="35.549" width="0.254" layer="1"/>
</signal>
<signal name="N$68">
</signal>
<signal name="N$69">
<via x="105.001" y="23.817" extent="1-16" drill="0.6" shape="square"/>
</signal>
<signal name="N$76">
<via x="95.504" y="43.053" extent="1-16" drill="0.0158" diameter="1.016" shape="square"/>
</signal>
<signal name="N$77">
<via x="94.615" y="43.053" extent="1-16" drill="0.0158" diameter="1.016" shape="square"/>
</signal>
<signal name="N$78">
<via x="93.726" y="43.053" extent="1-16" drill="0.0158" diameter="1.016" shape="square"/>
</signal>
<signal name="N$79">
<via x="92.837" y="43.053" extent="1-16" drill="0.0158" diameter="1.016" shape="square"/>
</signal>
<signal name="N$80">
<via x="92.456" y="43.053" extent="1-16" drill="0.0158" diameter="1.016" shape="square"/>
</signal>
<signal name="N$81">
</signal>
<signal name="N$82">
</signal>
<signal name="N$83">
</signal>
<signal name="N$84">
</signal>
<signal name="N$85">
</signal>
<signal name="N$86">
</signal>
<signal name="N$87">
</signal>
<signal name="N$101">
<via x="92.448" y="42.201" extent="1-16" drill="0.001" diameter="1.016" shape="square"/>
</signal>
<signal name="N$102">
<via x="93.447" y="42.201" extent="1-16" drill="0.001" diameter="1.016" shape="square"/>
</signal>
<signal name="N$103">
<via x="94.392" y="42.201" extent="1-16" drill="0.001" diameter="1.016" shape="square"/>
</signal>
<signal name="N$104">
<via x="95.202" y="42.201" extent="1-16" drill="0.001" diameter="1.016" shape="square"/>
</signal>
<signal name="N$105">
<via x="95.931" y="42.201" extent="1-16" drill="0.001" diameter="1.016" shape="square"/>
</signal>
<signal name="N$106">
<via x="91.908" y="41.904" extent="1-16" drill="0.001" diameter="0.02"/>
</signal>
<signal name="N$107">
<via x="91.746" y="41.904" extent="1-16" drill="0.001" diameter="0.02"/>
</signal>
<signal name="N$108">
<via x="91.611" y="41.931" extent="1-16" drill="0.001" diameter="0.02"/>
</signal>
<signal name="N$109">
<via x="91.503" y="41.958" extent="1-16" drill="0.001" diameter="0.02"/>
</signal>
<signal name="N$110">
<via x="91.692" y="41.904" extent="1-16" drill="0.001" diameter="0.02"/>
</signal>
<signal name="N$111">
<via x="91.827" y="41.904" extent="1-16" drill="0.001" diameter="0.02"/>
</signal>
<signal name="N$112">
<via x="91.584" y="41.931" extent="1-16" drill="0.001" diameter="0.02"/>
</signal>
<signal name="N$113">
<via x="91.53" y="41.931" extent="1-16" drill="0.001" diameter="0.02"/>
</signal>
<signal name="N$114">
<via x="91.638" y="41.904" extent="1-16" drill="0.001" diameter="0.02"/>
</signal>
<signal name="N$115">
<via x="91.476" y="41.931" extent="1-16" drill="0.001" diameter="0.02"/>
</signal>
<signal name="N$116">
<via x="91.557" y="41.904" extent="1-16" drill="0.001" diameter="0.02"/>
</signal>
<signal name="N$117">
<via x="81.775" y="31.245" extent="1-16" drill="0.01" diameter="0.254"/>
</signal>
<signal name="N$118">
<via x="53.325" y="43.173" extent="1-16" drill="0.01" diameter="1.016"/>
</signal>
<signal name="N$119">
<via x="55.863" y="43.2" extent="1-16" drill="0.01" diameter="1.016"/>
<via x="58.516" y="43.158" extent="1-16" drill="0.01" diameter="1.016"/>
<wire x1="55.863" y1="43.2" x2="58.516" y2="43.158" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$92">
<via x="118.065" y="30.92" extent="1-16" drill="0.01" diameter="0.004"/>
</signal>
<signal name="N$120">
<wire x1="44.303" y1="47.365" x2="124.954" y2="47.393" width="0.254" layer="1"/>
<wire x1="124.954" y1="47.393" x2="124.947" y2="9.306" width="0.254" layer="1"/>
<wire x1="124.947" y1="9.306" x2="44.38" y2="9.32" width="0.254" layer="1"/>
<wire x1="44.38" y1="9.32" x2="44.303" y2="47.365" width="0.254" layer="1"/>
</signal>
<signal name="S$1">
</signal>
<signal name="S$2">
</signal>
<signal name="S$3">
</signal>
<signal name="N$89">
</signal>
<signal name="N$125">
</signal>
<signal name="N$126">
</signal>
<signal name="N$130">
</signal>
<signal name="N$131">
</signal>
<signal name="N$132">
</signal>
<signal name="N$133">
</signal>
<signal name="N$121">
<wire x1="91.989" y1="44.091" x2="90.126" y2="45.802" width="0.254" layer="1"/>
<wire x1="90.126" y1="45.802" x2="90.882" y2="43.389" width="0.254" layer="1"/>
</signal>
<signal name="N$134">
<via x="90.558" y="44.955" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$135">
<via x="91.098" y="44.307" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$74">
<wire x1="81.864" y1="42.363" x2="81.27" y2="41.04" width="0.254" layer="1"/>
<wire x1="81.27" y1="41.04" x2="80.703" y2="42.336" width="0.254" layer="1"/>
</signal>
<signal name="N$75">
<via x="81.432" y="41.715" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$90">
<via x="81.108" y="41.769" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$138">
<wire x1="78.3" y1="44.28" x2="80.282" y2="44.799" width="0.254" layer="1"/>
<wire x1="80.282" y1="44.799" x2="79.299" y2="42.822" width="0.254" layer="1"/>
</signal>
<signal name="N$139">
<via x="79.407" y="44.253" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$140">
<via x="79.677" y="44.523" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$141">
<via x="79.11" y="44.28" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$142">
<via x="79.38" y="44.41" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$144">
<wire x1="76.761" y1="44.01" x2="75.627" y2="44.01" width="0.254" layer="1"/>
</signal>
<signal name="N$98">
<wire x1="75.627" y1="43.956" x2="76.194" y2="45.333" width="0.254" layer="1"/>
<wire x1="76.194" y1="45.333" x2="76.761" y2="44.064" width="0.254" layer="1"/>
</signal>
<signal name="N$143">
<via x="76.14" y="44.55" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$145">
<via x="76.113" y="44.847" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$146">
<via x="76.41" y="44.631" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$148">
<wire x1="75.627" y1="42.363" x2="76.788" y2="42.363" width="0.254" layer="1"/>
<wire x1="75.627" y1="42.363" x2="76.167" y2="41.121" width="0.254" layer="1"/>
<wire x1="76.167" y1="41.121" x2="76.788" y2="42.363" width="0.254" layer="1"/>
</signal>
<signal name="N$99">
<via x="76.248" y="41.499" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$147">
<via x="76.113" y="41.742" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$149">
<via x="76.275" y="41.796" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$96">
<wire x1="73.116" y1="43.929" x2="73.629" y2="45.225" width="0.254" layer="1"/>
</signal>
<signal name="N$150">
<wire x1="74.25" y1="44.01" x2="73.656" y2="45.252" width="0.254" layer="1"/>
</signal>
<signal name="N$151">
<via x="73.71" y="44.82" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$152">
<via x="73.51" y="44.55" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$153">
<via x="73.71" y="44.55" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$97">
<wire x1="73.089" y1="42.255" x2="73.656" y2="41.094" width="0.254" layer="1"/>
<wire x1="73.656" y1="41.094" x2="74.223" y2="42.336" width="0.254" layer="1"/>
</signal>
<signal name="N$155">
<via x="73.44" y="41.85" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$156">
<via x="73.71" y="41.85" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$157">
<wire x1="70.551" y1="44.064" x2="71.145" y2="45.252" width="0.254" layer="1"/>
<wire x1="71.145" y1="45.252" x2="71.658" y2="44.01" width="0.254" layer="1"/>
</signal>
<signal name="N$158">
<via x="71.01" y="44.55" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$159">
<via x="71.064" y="44.847" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$160">
<via x="71.172" y="44.577" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$162">
<wire x1="84.807" y1="41.283" x2="83.511" y2="41.985" width="0.254" layer="1"/>
</signal>
<signal name="N$163">
<wire x1="84.834" y1="41.391" x2="84.402" y2="42.714" width="0.254" layer="1"/>
</signal>
<signal name="N$164">
<via x="84.672" y="41.58" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$165">
<via x="84.375" y="41.634" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$166">
<via x="84.159" y="41.769" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$167">
<via x="84.375" y="42.039" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$168">
<via x="84.564" y="41.931" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$169">
<wire x1="62.991" y1="44.172" x2="64.657" y2="45.48" width="0.254" layer="1"/>
</signal>
<signal name="N$170">
<via x="64.233" y="44.907" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$51">
<wire x1="63.504" y1="41.148" x2="62.937" y2="42.363" width="0.254" layer="1"/>
<wire x1="63.504" y1="41.148" x2="64.071" y2="42.336" width="0.254" layer="1"/>
</signal>
<signal name="N$71">
<via x="63.45" y="41.85" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$91">
<via x="63.72" y="41.85" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$173">
<via x="63.369" y="41.85" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$72">
<wire x1="66.042" y1="40.635" x2="65.475" y2="42.39" width="0.254" layer="1"/>
</signal>
<signal name="N$73">
<wire x1="66.042" y1="40.527" x2="66.609" y2="42.39" width="0.254" layer="1"/>
</signal>
<signal name="N$93">
<wire x1="60.561" y1="44.307" x2="62.122" y2="45.333" width="0.254" layer="1"/>
<wire x1="62.122" y1="45.333" x2="61.506" y2="43.605" width="0.254" layer="1"/>
</signal>
<signal name="N$95">
<via x="61.587" y="44.226" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$179">
<via x="61.317" y="44.496" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$180">
<via x="61.641" y="44.577" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$181">
<wire x1="85.779" y1="42.39" x2="86.346" y2="40.203" width="0.254" layer="1"/>
<wire x1="86.346" y1="40.203" x2="86.94" y2="42.39" width="0.254" layer="1"/>
</signal>
<signal name="N$182">
<via x="86.238" y="41.283" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$183">
<via x="86.103" y="41.472" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$184">
<via x="86.049" y="41.688" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$185">
<via x="86.481" y="41.31" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$186">
<via x="86.481" y="41.553" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$187">
<via x="86.535" y="41.796" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$188">
<wire x1="57.834" y1="42.444" x2="58.347" y2="40.095" width="0.254" layer="1"/>
<wire x1="58.347" y1="40.095" x2="58.995" y2="42.363" width="0.254" layer="1"/>
</signal>
<signal name="N$189">
<via x="58.212" y="41.256" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$191">
<via x="58.104" y="41.742" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$192">
<via x="58.428" y="41.148" extent="1-16" drill="0.01"/>
</signal>
<signal name="N$195">
</signal>
<signal name="N$199">
</signal>
<signal name="N$200">
</signal>
<signal name="N$201">
</signal>
<signal name="N$196">
<wire x1="55.296" y1="42.39" x2="55.109" y2="39.998" width="0.254" layer="1"/>
<wire x1="55.109" y1="39.998" x2="56.387" y2="42.266" width="0.254" layer="1"/>
</signal>
<signal name="N$197">
<via x="55.491" y="41.024" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$198">
<via x="55.701" y="41.31" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$202">
<via x="55.674" y="41.499" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$203">
<via x="55.62" y="41.715" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$204">
<via x="55.411" y="41.735" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$205">
<via x="55.885" y="41.644" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$206">
<via x="55.492" y="41.44" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$207">
<via x="56.009" y="41.909" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$190">
<via x="58.185" y="41.499" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$193">
<via x="58.509" y="41.445" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$194">
<via x="58.59" y="41.634" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$208">
<via x="58.644" y="41.769" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$209">
<via x="53.163" y="41.337" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$210">
<via x="53.163" y="41.607" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$211">
<via x="53.055" y="41.769" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$212">
<via x="53.278" y="40.953" extent="1-16" drill="0.001"/>
<via x="53.131" y="41.072" extent="1-16" drill="0.001"/>
<via x="53.25" y="41.73" extent="1-16" drill="0.001"/>
<wire x1="53.131" y1="41.072" x2="53.278" y2="40.953" width="0" layer="19" extent="1-1"/>
<wire x1="53.25" y1="41.73" x2="53.131" y2="41.072" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$213">
<via x="53.514" y="41.726" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$214">
<via x="53.072" y="41.47" extent="1-16" drill="0.001"/>
<via x="53.352" y="41.169" extent="1-16" drill="0.001"/>
<via x="53.45" y="41.435" extent="1-16" drill="0.001"/>
<wire x1="53.45" y1="41.435" x2="53.352" y2="41.169" width="0" layer="19" extent="1-1"/>
<wire x1="53.072" y1="41.47" x2="53.45" y2="41.435" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$94">
<wire x1="54.742" y1="45.351" x2="52.92" y2="44.307" width="0.254" layer="1"/>
</signal>
<signal name="N$215">
<wire x1="54.803" y1="45.409" x2="53.892" y2="43.929" width="0.254" layer="1"/>
</signal>
<signal name="N$216">
<via x="53.892" y="44.334" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$217">
<via x="54.243" y="44.847" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$218">
<via x="54.081" y="44.55" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$219">
<via x="53.676" y="44.631" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$171">
<via x="63.999" y="44.603" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$172">
<via x="64.179" y="44.742" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$70">
<via x="63.504" y="41.58" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$174">
<via x="66.069" y="41.175" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$175">
<via x="66.069" y="41.445" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$176">
<via x="66.042" y="41.715" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$177">
<via x="66.177" y="41.742" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$178">
<via x="65.853" y="41.688" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$154">
<via x="73.629" y="41.553" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$100">
<wire x1="78.165" y1="42.363" x2="78.732" y2="41.04" width="0.254" layer="1"/>
<wire x1="78.732" y1="41.04" x2="79.299" y2="42.282" width="0.254" layer="1"/>
</signal>
<signal name="N$220">
<via x="78.759" y="41.499" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$221">
<via x="78.624" y="41.661" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$222">
<via x="78.867" y="41.715" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$136">
<via x="90.801" y="44.739" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$137">
<via x="90.99" y="44.496" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$127">
<wire x1="88.317" y1="42.363" x2="88.884" y2="40.419" width="0.254" layer="1"/>
<wire x1="88.884" y1="40.419" x2="89.478" y2="42.363" width="0.254" layer="1"/>
</signal>
<signal name="N$128">
<via x="88.776" y="41.418" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$129">
<via x="88.695" y="41.688" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$223">
<via x="89.073" y="41.499" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$224">
<via x="89.127" y="41.742" extent="1-16" drill="0.001"/>
</signal>
<signal name="N$60">
<contactref element="R29" pad="1"/>
<contactref element="D3" pad="C"/>
<contactref element="C12" pad="+"/>
<contactref element="D4" pad="A"/>
<contactref element="R37" pad="2"/>
<wire x1="119.168" y1="24.191" x2="119.766" y2="23.47" width="0.254" layer="1"/>
<wire x1="119.184" y1="24.058" x2="118.316" y2="23.784" width="0.254" layer="1"/>
<wire x1="121.86" y1="31.328" x2="121.833" y2="31.349" width="0.4064" layer="1"/>
<wire x1="121.833" y1="31.349" x2="121.833" y2="26.385" width="0.4064" layer="1"/>
<wire x1="121.833" y1="26.385" x2="118.769" y2="23.76" width="0.4064" layer="1"/>
<wire x1="118.769" y1="23.76" x2="119.168" y2="24.191" width="0.4064" layer="1"/>
<wire x1="119.184" y1="24.058" x2="119.766" y2="23.47" width="0.3048" layer="1"/>
<wire x1="117.492" y1="21.404" x2="117.24" y2="21.38" width="0.3048" layer="1"/>
<wire x1="117.24" y1="21.38" x2="117.394" y2="20.86" width="0.3048" layer="1"/>
<wire x1="118.316" y1="23.784" x2="119.398" y2="24.431" width="0.4064" layer="1"/>
<wire x1="119.398" y1="24.431" x2="116.145" y2="26.265" width="0.4064" layer="1"/>
<wire x1="119.766" y1="23.47" x2="119.766" y2="21.464" width="0.4064" layer="1"/>
<wire x1="119.766" y1="21.464" x2="119.81" y2="21.448" width="0.4064" layer="1"/>
<wire x1="117.492" y1="21.404" x2="119.766" y2="21.404" width="0.4064" layer="1"/>
<wire x1="119.766" y1="21.404" x2="119.81" y2="21.448" width="0.4064" layer="1"/>
</signal>
<signal name="N$228">
<contactref element="Q4" pad="B"/>
<contactref element="D6" pad="C"/>
<contactref element="R38" pad="1"/>
<wire x1="117.72" y1="11.368" x2="119.353" y2="11.368" width="0.4064" layer="1"/>
<wire x1="119.353" y1="11.368" x2="119.36" y2="13.36" width="0.4064" layer="1"/>
<wire x1="119.36" y1="13.36" x2="120.54" y2="13.37" width="0.3048" layer="1"/>
<wire x1="120.54" y1="13.37" x2="122.18" y2="15.07" width="0.3048" layer="1" curve="-90"/>
<wire x1="122.18" y1="15.07" x2="122.197" y2="15.086" width="0.3048" layer="1"/>
<wire x1="122.197" y1="15.086" x2="122.416" y2="15.305" width="0.254" layer="1"/>
<wire x1="122.416" y1="15.305" x2="122.416" y2="17.542" width="0.254" layer="1"/>
<wire x1="122.416" y1="17.542" x2="122.116" y2="18.065" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$229">
<contactref element="R37" pad="1"/>
<contactref element="Q4" pad="E"/>
<wire x1="119.36" y1="15.26" x2="119.81" y2="15.239" width="0.4064" layer="1"/>
<wire x1="119.81" y1="15.239" x2="119.81" y2="18.048" width="0.4064" layer="1"/>
</signal>
<signal name="N$231">
<contactref element="Q4" pad="C"/>
<contactref element="R31" pad="2"/>
<wire x1="117.16" y1="14.31" x2="116.91" y2="14.31" width="0.4064" layer="1"/>
<wire x1="116.91" y1="14.31" x2="116.91" y2="15.94" width="0.4064" layer="1"/>
<wire x1="116.91" y1="15.94" x2="112.454" y2="15.947" width="0.4064" layer="1"/>
<wire x1="112.454" y1="15.947" x2="110.956" y2="13.863" width="0.4064" layer="1"/>
<wire x1="110.956" y1="13.863" x2="107.461" y2="13.863" width="0.4064" layer="1"/>
<wire x1="107.461" y1="13.863" x2="107.443" y2="17.157" width="0.4064" layer="1"/>
<contactref element="SL4" pad="2"/>
<wire x1="107.443" y1="17.157" x2="107.443" y2="17.563" width="0.4064" layer="1"/>
<wire x1="107.443" y1="17.563" x2="106.351" y2="18.655" width="0.4064" layer="1"/>
<wire x1="106.351" y1="18.655" x2="106.355" y2="19.288" width="0" layer="19" extent="1-1"/>
<wire x1="107.433" y1="16.359" x2="107.443" y2="17.157" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$65">
<contactref element="D4" pad="C"/>
<contactref element="D5" pad="A"/>
<wire x1="114.405" y1="17.73" x2="117.45" y2="17.73" width="0.4064" layer="1"/>
<wire x1="117.45" y1="17.73" x2="117.24" y2="17.78" width="0.4064" layer="1"/>
</signal>
<signal name="N$226">
<contactref element="D5" pad="C"/>
<contactref element="D6" pad="A"/>
<wire x1="114.405" y1="14.13" x2="114.134" y2="14.102" width="0.4064" layer="1"/>
<wire x1="114.134" y1="14.102" x2="114.12" y2="11.368" width="0.4064" layer="1"/>
</signal>
<signal name="N$227">
<via x="91.21" y="44.59" extent="1-16" drill="0.01" diameter="0.01"/>
</signal>
<signal name="N$230">
<via x="91.07" y="44.73" extent="1-16" drill="0.01" diameter="0.01"/>
</signal>
<signal name="N$232">
<via x="90.86" y="44.94" extent="1-16" drill="0.01" diameter="0.01"/>
</signal>
<signal name="N$233">
<via x="90.65" y="44.66" extent="1-16" drill="0.01" diameter="0.01"/>
</signal>
<signal name="N$234">
<via x="90.79" y="44.38" extent="1-16" drill="0.01" diameter="0.01"/>
</signal>
<signal name="N$235">
<via x="90.79" y="44.17" extent="1-16" drill="0.01" diameter="0.01"/>
</signal>
<signal name="N$236">
<via x="61.6" y="44.66" extent="1-16" drill="0.01" diameter="0.01"/>
</signal>
<signal name="N$237">
<via x="63.91" y="44.59" extent="1-16" drill="0.01" diameter="0.01"/>
</signal>
<signal name="N$238">
<via x="64.05" y="44.66" extent="1-16" drill="0.01" diameter="0.01"/>
</signal>
<signal name="N$239">
<via x="64.127" y="44.856" extent="1-16" drill="0.01" diameter="0.01"/>
</signal>
<signal name="N$240">
<via x="58.38" y="40.81" extent="1-16" drill="0.01" diameter="0.01"/>
</signal>
<signal name="N$241">
<via x="58.38" y="41.72" extent="1-16" drill="0.01" diameter="0.01"/>
</signal>
<signal name="N$242">
<via x="79.436" y="44.065" extent="1-16" drill="0.01" diameter="0.01"/>
</signal>
<signal name="N$88">
<contactref element="IC3" pad="6"/>
<contactref element="R27" pad="1"/>
<contactref element="C11" pad="+"/>
<wire x1="107.91339375" y1="32.033240625" x2="108.118" y2="32.037" width="0.254" layer="1"/>
<wire x1="111.025" y1="34.225" x2="111.841" y2="34.25" width="0.254" layer="1"/>
<wire x1="106.538" y1="34.326" x2="105.936" y2="34.237" width="0.254" layer="1"/>
<wire x1="106.727" y1="34.862" x2="106.344" y2="34.545" width="0.254" layer="1"/>
<wire x1="106.344" y1="34.545" x2="105.936" y2="34.237" width="0.254" layer="1"/>
<wire x1="106.727" y1="34.862" x2="106.129" y2="34.497" width="0.254" layer="1"/>
<contactref element="SL3" pad="2"/>
<wire x1="92.176" y1="11.319" x2="55.09" y2="11.27" width="0.4064" layer="1"/>
<wire x1="53.82" y1="13.79" x2="53.82" y2="12.54" width="0.4064" layer="1"/>
<wire x1="53.82" y1="12.54" x2="55.09" y2="11.27" width="0.4064" layer="1"/>
<contactref element="R34" pad="2"/>
<wire x1="53.82" y1="13.79" x2="53.76" y2="13.79" width="0.4064" layer="1"/>
<wire x1="53.76" y1="13.79" x2="52.85" y2="15.12" width="0.4064" layer="1"/>
<wire x1="52.85" y1="15.12" x2="51.52" y2="15.19" width="0.4064" layer="1"/>
<wire x1="51.52" y1="15.19" x2="50.876" y2="15.239" width="0.4064" layer="1"/>
<wire x1="99.491" y1="18.998" x2="92.176" y2="11.319" width="0.4064" layer="1"/>
<wire x1="105.556" y1="31.957" x2="105.57" y2="33.779" width="0.4064" layer="1"/>
<wire x1="105.57" y1="33.779" x2="106.344" y2="34.545" width="0.4064" layer="1"/>
<contactref element="R30" pad="1"/>
<wire x1="108.118" y1="32.037" x2="108.092" y2="32.011" width="0.4064" layer="1"/>
<wire x1="108.092" y1="32.011" x2="108.038" y2="32.06" width="0.4064" layer="1"/>
<wire x1="111.025" y1="34.225" x2="109.538153125" y2="34.225" width="0.4064" layer="1"/>
<wire x1="109.538153125" y1="34.225" x2="107.91339375" y2="32.033240625" width="0.4064" layer="1"/>
<wire x1="105.452" y1="31.988" x2="106.043" y2="32.002" width="0.4064" layer="1"/>
<wire x1="106.043" y1="32.002" x2="107.378" y2="31.988" width="0.4064" layer="1"/>
<wire x1="107.378" y1="31.988" x2="108.038" y2="32.06" width="0.4064" layer="1"/>
<wire x1="103.586" y1="32.004" x2="106.043" y2="32.002" width="0.4064" layer="1"/>
<wire x1="99.491" y1="18.998" x2="101.78" y2="18.998" width="0.4064" layer="1"/>
<wire x1="101.78" y1="18.998" x2="103.523" y2="20.741" width="0.4064" layer="1"/>
<wire x1="103.523" y1="20.741" x2="103.523" y2="31.941" width="0.4064" layer="1"/>
<wire x1="103.523" y1="31.941" x2="103.586" y2="32.004" width="0.4064" layer="1"/>
<wire x1="105.452" y1="31.988" x2="105.556" y2="31.957" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$123">
<contactref element="D8" pad="A"/>
<contactref element="D7" pad="A"/>
<wire x1="48.42" y1="20.054" x2="45.64" y2="22.54" width="0.3048" layer="1"/>
<wire x1="45.64" y1="22.54" x2="45.64" y2="34.817" width="0.3048" layer="1"/>
<wire x1="45.64" y1="34.817" x2="48.125" y2="34.812" width="0.3048" layer="1"/>
<wire x1="48.42" y1="20.054" x2="52.85" y2="20.054" width="0.254" layer="1"/>
<wire x1="52.85" y1="20.054" x2="53.536" y2="20.341" width="0.254" layer="1"/>
</signal>
<signal name="N$15">
<contactref element="D9" pad="A"/>
<contactref element="SL2" pad="1"/>
<wire x1="49.91" y1="39.7" x2="51.9" y2="39.7" width="0.4064" layer="1"/>
<wire x1="51.94" y1="34.58" x2="51.33" y2="32.83" width="0.4064" layer="1"/>
<wire x1="51.9" y1="39.7" x2="51.94" y2="34.58" width="0.4064" layer="1"/>
</signal>
<signal name="N$124">
<contactref element="D9" pad="C"/>
<contactref element="Q1" pad="1"/>
<contactref element="D8" pad="C"/>
<wire x1="48.125" y1="31.212" x2="48.02" y2="31.017" width="0.254" layer="1"/>
<wire x1="48.02" y1="31.017" x2="47.53" y2="31.85" width="0.254" layer="1"/>
<wire x1="48.02" y1="31.017" x2="52.08" y2="30.996" width="0.254" layer="1"/>
<wire x1="52.08" y1="30.996" x2="53.746" y2="29.849" width="0.254" layer="1"/>
<wire x1="53.746" y1="29.849" x2="54.93" y2="32.83" width="0.254" layer="1"/>
</signal>
<signal name="N$32">
<contactref element="SL3" pad="1"/>
<contactref element="D1" pad="C"/>
<contactref element="R10" pad="2"/>
<contactref element="Q3" pad="E"/>
<wire x1="56.07" y1="16.984" x2="56.278228125" y2="17.058753125" width="0.3048" layer="1"/>
<wire x1="56.278228125" y1="17.058753125" x2="58.583546875" y2="17.0674625" width="0.3048" layer="1"/>
<wire x1="58.583546875" y1="17.0674625" x2="59.632" y2="17.054" width="0.3048" layer="1"/>
<wire x1="59.632" y1="17.054" x2="59.632" y2="15.705" width="0.3048" layer="1"/>
<wire x1="58.436" y1="18.699" x2="58.583546875" y2="18.699" width="0.3048" layer="1"/>
<wire x1="58.583546875" y1="18.699" x2="58.583546875" y2="17.0674625" width="0.3048" layer="1"/>
<wire x1="56.5" y1="16.83698125" x2="56.278228125" y2="17.058753125" width="0.254" layer="1"/>
<wire x1="56.36" y1="13.79" x2="56.36" y2="16.69698125" width="0.4064" layer="1"/>
<wire x1="56.36" y1="16.69698125" x2="56.5" y2="16.83698125" width="0.4064" layer="1"/>
<wire x1="56.07" y1="16.984" x2="56.058" y2="16.914" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$249">
<via x="88.27" y="19.39" extent="1-16" drill="0.1" diameter="1.016"/>
</signal>
<signal name="N$250">
<via x="90.79" y="19.32" extent="1-16" drill="0.1" diameter="1.016"/>
</signal>
<signal name="N$251">
<via x="93.31" y="19.46" extent="1-16" drill="0.1" diameter="1.016"/>
</signal>
<signal name="N$252">
<via x="107.436" y="16.338" extent="1-16" drill="0.1" diameter="1.016"/>
</signal>
<signal name="N$253">
<via x="109.977" y="16.366" extent="1-16" drill="0.1" diameter="1.016"/>
</signal>
<signal name="N$36">
<contactref element="D1" pad="A"/>
<contactref element="R35" pad="1"/>
<wire x1="51.52" y1="21.898" x2="56.012" y2="21.898" width="0.254" layer="1"/>
<wire x1="56.012" y1="21.898" x2="56.14" y2="21.77" width="0.254" layer="1"/>
<wire x1="56.14" y1="21.77" x2="56.14" y2="20.736" width="0.254" layer="1"/>
<wire x1="56.14" y1="20.736" x2="56.058" y2="20.514" width="0.254" layer="1"/>
<wire x1="51.52" y1="21.898" x2="51.281" y2="22.166" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$59">
<contactref element="D7" pad="C"/>
<contactref element="R34" pad="1"/>
<wire x1="53.536" y1="16.941" x2="51.05" y2="18.32" width="0.4064" layer="1"/>
<wire x1="51.05" y1="18.32" x2="50.61" y2="18.27" width="0.4064" layer="1"/>
<wire x1="50.61" y1="18.27" x2="50.876" y2="18.039" width="0.4064" layer="1"/>
</signal>
<signal name="N$122">
<via x="60.935" y="43.183" extent="1-16" drill="0.1" diameter="1.016"/>
</signal>
<signal name="N$243">
<via x="63.546" y="43.183" extent="1-16" drill="0.1" diameter="1.016"/>
</signal>
<signal name="N$244">
<via x="66.073" y="43.162" extent="1-16" drill="0.1" diameter="1.016"/>
</signal>
<signal name="N$245">
<via x="68.642" y="43.162" extent="1-16" drill="0.1" diameter="1.016"/>
</signal>
<signal name="N$246">
<via x="71.078" y="43.225" extent="1-16" drill="0.1" diameter="1.016"/>
</signal>
<signal name="N$247">
<via x="73.626" y="43.162" extent="1-16" drill="0.1" diameter="1.016"/>
</signal>
<signal name="N$248">
<via x="76.258" y="43.204" extent="1-16" drill="0.1" diameter="1.016"/>
</signal>
<signal name="N$254">
<via x="78.806" y="43.183" extent="1-16" drill="0.1" diameter="1.016"/>
</signal>
<signal name="N$255">
<via x="81.27" y="43.12" extent="1-16" drill="0.1" diameter="1.016"/>
</signal>
<signal name="N$256">
<via x="83.818" y="43.204" extent="1-16" drill="0.1" diameter="1.016"/>
</signal>
<signal name="N$257">
<via x="86.387" y="43.141" extent="1-16" drill="0.1" diameter="1.016"/>
</signal>
<signal name="N$258">
<via x="88.914" y="43.12" extent="1-16" drill="0.1" diameter="1.016"/>
</signal>
<signal name="N$259">
<via x="91.441" y="43.246" extent="1-16" drill="0.1" diameter="1.016"/>
</signal>
<signal name="N$260">
<via x="53.823" y="13.783" extent="1-16" drill="0.1" diameter="1.016"/>
</signal>
<signal name="N$261">
<via x="56.385" y="13.783" extent="1-16" drill="0.1" diameter="1.016"/>
</signal>
<signal name="N$262">
<via x="48.622" y="26.376" extent="1-16" drill="0.1" diameter="1.016"/>
</signal>
<signal name="N$263">
<via x="48.622" y="28.924" extent="1-16" drill="0.1" diameter="1.016"/>
</signal>
<signal name="N$264">
<via x="49.917" y="37.156" extent="1-16" drill="0.1" diameter="1.016"/>
</signal>
<signal name="N$265">
<via x="49.917" y="39.662" extent="1-16" drill="0.1" diameter="1.016"/>
</signal>
<signal name="N$266">
<via x="48.517" y="24.276" extent="1-16" drill="0.1" diameter="0.8128"/>
</signal>
<signal name="N$267">
<via x="48.503" y="21.735" extent="1-16" drill="0.1" diameter="0.8128"/>
</signal>
<signal name="N$268">
<via x="58.898" y="28.875" extent="1-16" drill="0.1" diameter="0.8128"/>
</signal>
<signal name="N$269">
<via x="70.91" y="28.896" extent="1-16" drill="0.1" diameter="0.8128"/>
</signal>
<signal name="N$270">
<via x="77.721" y="32.256" extent="1-16" drill="0.1" diameter="0.8128"/>
</signal>
<signal name="N$271">
<via x="89.6" y="32.235" extent="1-16" drill="0.1" diameter="0.8128"/>
</signal>
<signal name="N$272">
<via x="92.071" y="23.751" extent="1-16" drill="0.1" diameter="0.8128"/>
</signal>
<signal name="N$273">
<via x="104.916" y="23.87" extent="1-16" drill="0.1" diameter="0.8128"/>
</signal>
<signal name="N$225">
<contactref element="D2" pad="1"/>
<contactref element="R36" pad="1"/>
<wire x1="100.779" y1="21.911" x2="99.784" y2="23.474" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$14">
<contactref element="Q2" pad="1"/>
<contactref element="R8" pad="1"/>
<contactref element="R9" pad="2"/>
<contactref element="C2" pad="1"/>
<wire x1="55.946" y1="24.958" x2="56.305" y2="24.958" width="0.254" layer="1"/>
<wire x1="56.305" y1="24.958" x2="57.771" y2="23.492" width="0.254" layer="1"/>
<wire x1="57.771" y1="23.492" x2="58.427" y2="23.492" width="0.254" layer="1"/>
<wire x1="58.427" y1="23.492" x2="58.476" y2="23.541" width="0.254" layer="1"/>
<wire x1="61.07955625" y1="23.569" x2="58.504" y2="23.569" width="0.254" layer="1"/>
<wire x1="58.504" y1="23.569" x2="58.476" y2="23.541" width="0.254" layer="1"/>
<wire x1="61.07955625" y1="23.569" x2="62.629" y2="23.569" width="0.254" layer="1"/>
<wire x1="62.629" y1="23.569" x2="63.826" y2="24.766" width="0.254" layer="1"/>
<wire x1="63.826" y1="24.766" x2="63.826" y2="26.234440625" width="0.254" layer="1"/>
<wire x1="63.826" y1="26.234440625" x2="63.749440625" y2="26.311" width="0.254" layer="1"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
