; Source created with Parsic Version 3.x
; at              : 2008.03.05. 22:45:06
; Project File    : C:\PROGRA~1\Parsic\IMP_MES.PIC
; Project Version : 1.0.0
; Created         : 2008.03.05. 22:23:00
; Last change     : 2008.03.05. 22:34:00
	PROCESSOR 16F628
	INCLUDE P16F628.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _HS_OSC & _LVP_OFF & _MCLRE_ON
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
S0	= 32	; located in Bank 0
OS1_FD	= 33	; located in Bank 0
MF1	= 34	; located in Bank 0
MF1_HI	= 35	; located in Bank 0
MF1_FD	= 36	; located in Bank 0
OS2_FD	= 37	; located in Bank 0
RAM	= 38	; located in Bank 0
SYS_WSAV	= 112	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 113	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 114	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	GOTO SYS_INIT
	NOP
	NOP
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
	BTFSS INTCON,T0IF	; TMR0 ?
	GOTO NOTMR0INT
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ MF1,F
	GOTO SYS_INT_LABEL_0
	INCF MF1_HI,F
SYS_INT_LABEL_0
NOTMR0INT
EXITINT
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Subroutines
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW 15
	BSF STATUS,RP0	; Bank 1
	MOVWF OPTION_REG
; Richtung setzen
	MOVLW B'11111111'
	MOVWF TRISA
	MOVLW B'01111111'
	MOVWF TRISB
	MOVLW 7	; Comparators off
	MOVWF CMCON
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'50'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
; One Shot -> OS1
	BTFSS PORTB,4
	GOTO LABEL_OS1_1
	BTFSC OS1_FD,0
	GOTO LABEL_OS1_1
	BSF OS1_FD,0
	BSF S0,0
	GOTO LABEL_OS1_2
LABEL_OS1_1
	BCF S0,0
	BTFSC PORTB,4
	GOTO LABEL_OS1_2
	BCF OS1_FD,0
LABEL_OS1_2
; RS-FLIP-FLOP -> RS1
	BTFSC S0,1
	GOTO LABEL_RS1_RESET
	BTFSS S0,0
	GOTO LABEL_RS1_ENDE
	BSF PORTB,7	; Ausgang setzen
	GOTO LABEL_RS1_ENDE
LABEL_RS1_RESET
	BCF PORTB,7	; Ausgang zurücksetzen
LABEL_RS1_ENDE
; Mono-Flop -> MF1
; Läuft der Impuls ?
	BTFSC MF1_FD,1
	GOTO LABEL_MF1_CHKTIME
; Test auf positive Flanke
	BTFSC MF1_FD,0
	GOTO LABEL_MF1_SETFD
	BTFSS PORTB,7
LABEL_MF1_RESET
	CLRF MF1
	CLRF MF1_HI
	BSF MF1_FD,1
	BSF S0,2
LABEL_MF1_CHKTIME
	MOVLW 1
	SUBWF MF1_HI,W
	BTFSS STATUS,ZERO
	GOTO LABEL_MF1_CHECK
	MOVLW 135
	SUBWF MF1,W
LABEL_MF1_CHECK
	BTFSS STATUS,CARRY
LABEL_MF1_TO
	BCF MF1_FD,1
	BCF S0,2
LABEL_MF1_SETFD
	BTFSS PORTB,7
	GOTO LABEL_MF1_CLR
	BSF MF1_FD,0
	GOTO LABEL_MF1_ENDE
LABEL_MF1_CLR
	BCF MF1_FD,0
LABEL_MF1_ENDE
; One Shot -> OS2
	BTFSC S0,2
	GOTO LABEL_OS2_1
	BTFSC OS2_FD,0
	GOTO LABEL_OS2_1
	BSF OS2_FD,0
	BSF S0,1
	GOTO LABEL_OS2_2
LABEL_OS2_1
	BCF S0,1
	BTFSS S0,2
	GOTO LABEL_OS2_2
	BCF OS2_FD,0
LABEL_OS2_2
	GOTO MAIN
	END
