<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.5.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.635" unitdist="mm" unit="mm" style="lines" multiple="1" display="no" altdistance="0.025" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<wire x1="0" y1="0" x2="160" y2="0" width="0" layer="20"/>
<wire x1="160" y1="0" x2="160" y2="100" width="0" layer="20"/>
<wire x1="160" y1="100" x2="0" y2="100" width="0" layer="20"/>
<wire x1="0" y1="100" x2="0" y2="0" width="0" layer="20"/>
</plain>
<libraries>
<library name="microchip">
<description>&lt;b&gt;Microchip PIC Microcontrollers and other Devices&lt;/b&gt;&lt;p&gt;
Based on the following sources :
&lt;ul&gt;
&lt;li&gt;Microchip Data Book, 1993
&lt;li&gt;THE EMERGING WORLD STANDARD, 1995/1996
&lt;li&gt;Microchip, Technical Library CD-ROM, June 1998
&lt;li&gt;www.microchip.com
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DIL40">
<description>&lt;B&gt;Dual In Line&lt;/B&gt;&lt;p&gt;
package type P</description>
<wire x1="-25.4" y1="-1.27" x2="-25.4" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="1.27" x2="-25.4" y2="-1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="25.4" y1="-6.223" x2="25.4" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="6.223" x2="-25.4" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="6.223" x2="25.4" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-6.223" x2="25.4" y2="-6.223" width="0.1524" layer="21"/>
<pad name="1" x="-24.13" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-21.59" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="-3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="-1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="21.59" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="24.13" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="24.13" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="21.59" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="29" x="3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="30" x="1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="31" x="-1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="32" x="-3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="33" x="-6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="34" x="-8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="35" x="-11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="36" x="-13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="37" x="-16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="38" x="-19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="39" x="-21.59" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="40" x="-24.13" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<text x="-25.781" y="-6.096" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-21.59" y="-2.2352" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="linear">
<description>&lt;b&gt;Linear Devices&lt;/b&gt;&lt;p&gt;
Operational amplifiers,  comparators, voltage regulators, ADCs, DACs, etc.&lt;p&gt;
<packages>
<package name="TO220V">
<description>&lt;b&gt;TO 200 vertical&lt;/b&gt;</description>
<wire x1="5.08" y1="-1.143" x2="4.953" y2="-4.064" width="0.127" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="4.953" y2="-4.064" width="0.127" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="-4.699" y2="-4.318" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-4.699" y2="-4.318" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-5.08" y2="-1.143" width="0.127" layer="21"/>
<circle x="-4.4958" y="-3.7084" radius="0.254" width="0.127" layer="21"/>
<pad name="1" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-5.08" y="-6.0452" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.175" y="-3.175" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="-3.175" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="-3.175" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-5.334" y1="-0.762" x2="5.334" y2="0" layer="21"/>
<rectangle x1="-5.334" y1="-1.27" x2="-3.429" y2="-0.762" layer="21"/>
<rectangle x1="-1.651" y1="-1.27" x2="-0.889" y2="-0.762" layer="21"/>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="-0.762" layer="51"/>
<rectangle x1="0.889" y1="-1.27" x2="1.651" y2="-0.762" layer="21"/>
<rectangle x1="3.429" y1="-1.27" x2="5.334" y2="-0.762" layer="21"/>
<rectangle x1="-0.889" y1="-1.27" x2="0.889" y2="-0.762" layer="51"/>
<rectangle x1="1.651" y1="-1.27" x2="3.429" y2="-0.762" layer="51"/>
</package>
</packages>
</library>
<library name="switch-misc">
<description>&lt;b&gt;Switches&lt;/b&gt;&lt;p&gt;
Marquardt, RAFI, ITT, and others&lt;p&gt;
<packages>
<package name="DT6">
<description>&lt;b&gt;ITT SWITCH&lt;/b&gt;</description>
<wire x1="1.016" y1="4.826" x2="1.016" y2="5.588" width="0.1524" layer="21"/>
<wire x1="1.016" y1="4.826" x2="-1.016" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="4.826" x2="-1.016" y2="5.588" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-5.969" x2="1.016" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-5.969" x2="-1.016" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-4.826" x2="-1.016" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-5.588" x2="1.016" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-5.588" x2="-1.016" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-5.588" x2="1.016" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="5.588" x2="1.016" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="5.588" x2="-1.016" y2="5.969" width="0.1524" layer="21"/>
<wire x1="1.016" y1="5.588" x2="1.016" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="2.54" x2="1.143" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.143" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="-1.905" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-2.54" x2="1.143" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.143" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="0.635" x2="2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0" x2="2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="-2.9512" x2="-5.334" y2="2.9512" width="0.1524" layer="21" curve="302.09017"/>
<wire x1="-2.347" y1="3.9236" x2="2.347" y2="3.9236" width="0.1524" layer="21" curve="-61.77363"/>
<wire x1="-1.8556" y1="3.7578" x2="1.8556" y2="3.7578" width="0.1524" layer="21" curve="-52.56028"/>
<wire x1="-1.8556" y1="-3.7578" x2="1.8556" y2="-3.7578" width="0.1524" layer="21" curve="52.56028"/>
<wire x1="-2.347" y1="-3.9236" x2="2.347" y2="-3.9236" width="0.1524" layer="21" curve="61.77363"/>
<wire x1="-5.334" y1="-2.9512" x2="-5.334" y2="2.9512" width="0.1524" layer="21"/>
<wire x1="-3.7578" y1="1.8556" x2="-3.7578" y2="-1.8556" width="0.1524" layer="21" curve="52.56028"/>
<wire x1="-3.9236" y1="2.347" x2="-3.9236" y2="-2.347" width="0.1524" layer="21" curve="61.77363"/>
<wire x1="-3.7578" y1="-1.8556" x2="-1.8556" y2="-3.7578" width="0.1524" layer="51" curve="37.43972"/>
<wire x1="-3.9236" y1="-2.347" x2="-2.347" y2="-3.9236" width="0.1524" layer="51" curve="28.22637"/>
<wire x1="-3.9236" y1="2.347" x2="-2.347" y2="3.9236" width="0.1524" layer="51" curve="-28.22637"/>
<wire x1="-3.7578" y1="1.8556" x2="-1.8556" y2="3.7578" width="0.1524" layer="51" curve="-37.43972"/>
<wire x1="3.7578" y1="-1.8556" x2="3.7578" y2="1.8556" width="0.1524" layer="21" curve="52.56028"/>
<wire x1="3.9236" y1="-2.347" x2="3.9236" y2="2.347" width="0.1524" layer="21" curve="61.77363"/>
<wire x1="1.8556" y1="-3.7578" x2="3.7578" y2="-1.8556" width="0.1524" layer="51" curve="37.43972"/>
<wire x1="2.347" y1="-3.9236" x2="3.9236" y2="-2.347" width="0.1524" layer="51" curve="28.22637"/>
<wire x1="1.8556" y1="3.7578" x2="3.7578" y2="1.8556" width="0.1524" layer="51" curve="-37.43972"/>
<wire x1="2.347" y1="3.9236" x2="3.9236" y2="2.347" width="0.1524" layer="51" curve="-28.22637"/>
<pad name="1" x="-2.54" y="2.54" drill="1.1176" shape="octagon"/>
<pad name="2" x="2.54" y="2.54" drill="1.1176" shape="octagon"/>
<pad name="3" x="2.54" y="-2.54" drill="1.1176" shape="octagon"/>
<pad name="4" x="-2.54" y="-2.54" drill="1.1176" shape="octagon"/>
<text x="-2.54" y="6.477" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-7.874" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="con-ptr500">
<description>&lt;b&gt;PTR Connectors&lt;/b&gt;&lt;p&gt;
Aug. 2004 / PTR Meßtechnik:&lt;br&gt;
Die Bezeichnung der Serie AK505 wurde geändert.&lt;br&gt;
Es handelt sich hierbei um AK500 in horizontaler Ausführung.&lt;p&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=LEFT&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Alte Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Neue Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2DS,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2DS-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AKZ505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AKZ500/2-5.08-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TABLE&gt;
<packages>
<package name="AK500/2">
<description>&lt;b&gt;CONNECTOR&lt;/b&gt;</description>
<wire x1="-5.08" y1="-3.556" x2="-5.08" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.937" x2="-5.08" y2="3.937" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.937" x2="5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.556" x2="5.08" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.048" x2="-5.588" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.048" x2="-5.08" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="3.175" x2="-5.588" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="2.032" x2="-5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.159" x2="-5.08" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.159" x2="5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.159" x2="5.08" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.159" x2="5.08" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.159" x2="-5.08" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.159" x2="5.08" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="1.4986" y1="-1.397" x2="3.9116" y2="1.016" width="0.1524" layer="51"/>
<wire x1="1.1176" y1="-1.016" x2="3.5306" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-3.9116" y1="-1.016" x2="-1.4986" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-3.5306" y1="-1.397" x2="-1.1176" y2="1.016" width="0.1524" layer="51"/>
<wire x1="1.4986" y1="-1.016" x2="3.5306" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-3.5306" y1="-1.016" x2="-1.4986" y2="1.016" width="0.6096" layer="51"/>
<wire x1="1.1176" y1="-1.016" x2="1.4986" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="3.5306" y1="1.397" x2="3.9116" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-3.9116" y1="-1.016" x2="-3.5306" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-1.4986" y1="1.397" x2="-1.1176" y2="1.016" width="0.1524" layer="51"/>
<circle x="2.5146" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="-2.5146" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="2.5146" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="-2.5146" y="0" radius="1.778" width="0.1524" layer="51"/>
<pad name="1" x="-2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-5.08" y="4.445" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="2.54" size="0.9906" layer="21" ratio="12">1</text>
<text x="0.635" y="2.54" size="0.9906" layer="21" ratio="12">2</text>
<rectangle x1="-0.381" y1="-1.905" x2="0.381" y2="1.905" layer="21"/>
</package>
<package name="AK500/3">
<wire x1="-7.5184" y1="-3.556" x2="-7.5184" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="7.5184" y1="3.937" x2="-7.5184" y2="3.937" width="0.1524" layer="21"/>
<wire x1="7.5184" y1="3.937" x2="7.5184" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="-3.556" x2="7.5184" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="3.048" x2="-8.0264" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="3.048" x2="-7.5184" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.0264" y1="3.175" x2="-8.0264" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-8.0264" y1="2.032" x2="-7.5184" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="2.159" x2="-7.5184" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="2.159" x2="7.5184" y2="2.159" width="0.1524" layer="21"/>
<wire x1="7.5184" y1="2.159" x2="7.5184" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="-2.159" x2="7.5184" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-7.5184" y1="-2.159" x2="-7.5184" y2="2.159" width="0.1524" layer="21"/>
<wire x1="7.5184" y1="-2.159" x2="7.5184" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-1.397" x2="1.397" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-1.397" y1="-1.016" x2="1.016" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-6.4008" y1="-1.016" x2="-3.9878" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-6.0198" y1="-1.397" x2="-3.6068" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-1.016" y1="-1.016" x2="1.016" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-6.0198" y1="-1.016" x2="-3.9878" y2="1.016" width="0.6096" layer="51"/>
<wire x1="-1.397" y1="-1.016" x2="-1.016" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="1.016" y1="1.397" x2="1.397" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-6.4008" y1="-1.016" x2="-6.0198" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-3.9878" y1="1.397" x2="-3.6068" y2="1.016" width="0.1524" layer="51"/>
<wire x1="3.9878" y1="-1.016" x2="6.0198" y2="1.016" width="0.6096" layer="51"/>
<wire x1="3.9878" y1="-1.397" x2="6.4008" y2="1.016" width="0.1524" layer="51"/>
<wire x1="3.6068" y1="-1.016" x2="6.0198" y2="1.397" width="0.1524" layer="51"/>
<wire x1="3.6068" y1="-1.016" x2="3.9878" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="6.0198" y1="1.397" x2="6.4008" y2="1.016" width="0.1524" layer="51"/>
<circle x="0" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="-5.0038" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="-5.0038" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="5.0038" y="0" radius="1.778" width="0.1524" layer="51"/>
<circle x="5.0038" y="3.048" radius="0.508" width="0.1524" layer="21"/>
<pad name="1" x="-5.0038" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="3" x="5.0038" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-7.5946" y="4.445" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.5946" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.731" y="2.54" size="0.9906" layer="21" ratio="12">1</text>
<text x="-1.905" y="2.54" size="0.9906" layer="21" ratio="12">2</text>
<text x="3.175" y="2.54" size="0.9906" layer="21" ratio="12">3</text>
<rectangle x1="-2.8956" y1="-1.905" x2="-2.1336" y2="1.905" layer="21"/>
<rectangle x1="2.1336" y1="-1.905" x2="2.8956" y2="1.905" layer="21"/>
</package>
</packages>
</library>
<library name="rcl">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="C050-025X075">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.016" x2="-3.683" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.27" x2="3.429" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.016" x2="3.683" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="-3.429" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="3.683" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.27" x2="3.683" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.016" x2="-3.429" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.016" x2="-3.429" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.429" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5-6">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 2.54 mm, diameter 6 mm</description>
<wire x1="-2.032" y1="1.27" x2="-1.651" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0.889" x2="-1.651" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.27" x2="-1.27" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.27" x2="-1.651" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="2.794" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<text x="2.667" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.667" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="RTRIM64Y">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; Spectrol&lt;p&gt;
Cermet MIL-R-22097</description>
<wire x1="1.05" y1="-4.8" x2="-3.3" y2="-4.8" width="0.254" layer="21"/>
<wire x1="-3.3" y1="-4.8" x2="-3.3" y2="4.8" width="0.254" layer="21"/>
<wire x1="-3.3" y1="4.8" x2="1.05" y2="4.8" width="0.254" layer="21"/>
<wire x1="1.05" y1="4.8" x2="1.05" y2="3.2" width="0.254" layer="21"/>
<wire x1="1.05" y1="3.2" x2="0.8" y2="3.2" width="0.254" layer="21"/>
<wire x1="0.8" y1="3.2" x2="0.8" y2="-3.2" width="0.254" layer="21"/>
<wire x1="0.8" y1="-3.2" x2="1.05" y2="-3.2" width="0.254" layer="21"/>
<wire x1="1.05" y1="-3.2" x2="1.05" y2="-4.8" width="0.254" layer="21"/>
<circle x="-1.9" y="-3.35" radius="1.1" width="0.1524" layer="21"/>
<pad name="1" x="0" y="-2.54" drill="0.6096"/>
<pad name="2" x="-2.54" y="0" drill="0.6096"/>
<pad name="3" x="0" y="2.54" drill="0.6096"/>
<text x="-3.84" y="-4.95" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="2.75" y="-4.95" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.1" y1="-4.4" x2="-1.7" y2="-2.3" layer="21"/>
</package>
<package name="C025-025X050">
grid 2.5 mm, outline 2.5 x 5 mm</description>
<wire x1="-2.159" y1="1.27" x2="2.159" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.27" x2="-2.159" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.27" x2="2.413" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.016" x2="-2.159" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.27" x2="2.413" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.016" x2="-2.159" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="0" x2="0.381" y2="0" width="0.1524" layer="51"/>
<wire x1="0.381" y1="0" x2="0.254" y2="0" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="0.762" width="0.254" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="-0.254" y2="0" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.286" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/10">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
</package>
</packages>
</library>
<library name="crystal">
<description>&lt;b&gt;Crystals and Crystal Resonators&lt;/b&gt;&lt;p&gt;
<packages>
<package name="HC49/S">
<description>&lt;b&gt;CRYSTAL&lt;/b&gt;</description>
<wire x1="-3.048" y1="-2.159" x2="3.048" y2="-2.159" width="0.4064" layer="21"/>
<wire x1="-3.048" y1="2.159" x2="3.048" y2="2.159" width="0.4064" layer="21"/>
<wire x1="-3.048" y1="-1.651" x2="3.048" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="3.048" y1="1.651" x2="-3.048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="0.254" y2="0.762" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0.762" x2="0.254" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-0.762" x2="-0.254" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-0.762" x2="-0.254" y2="0.762" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0.762" x2="0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="0.635" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0.762" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.27" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-1.27" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="2.159" x2="-3.048" y2="-2.159" width="0.4064" layer="21" curve="180"/>
<wire x1="3.048" y1="-2.159" x2="3.048" y2="2.159" width="0.4064" layer="21" curve="180"/>
<wire x1="-3.048" y1="1.651" x2="-3.048" y2="-1.651" width="0.1524" layer="21" curve="180"/>
<wire x1="3.048" y1="-1.651" x2="3.048" y2="1.651" width="0.1524" layer="21" curve="180"/>
<pad name="1" x="-2.413" y="0" drill="0.8128"/>
<pad name="2" x="2.413" y="0" drill="0.8128"/>
<text x="-5.08" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-3.937" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.445" y1="-2.54" x2="4.445" y2="2.54" layer="43"/>
<rectangle x1="-5.08" y1="-1.905" x2="-4.445" y2="1.905" layer="43"/>
<rectangle x1="-5.715" y1="-1.27" x2="-5.08" y2="1.27" layer="43"/>
<rectangle x1="4.445" y1="-1.905" x2="5.08" y2="1.905" layer="43"/>
<rectangle x1="5.08" y1="-1.27" x2="5.715" y2="1.27" layer="43"/>
</package>
</packages>
</library>
<library name="con-3m">
<description>&lt;b&gt;3M Connectors&lt;/b&gt;&lt;p&gt;
PCMCIA-CompactFlash Connectors&lt;p&gt;
Zero Insertion Force Socked&lt;p&gt;
<packages>
<package name="PAK100/2500-10">
<description>&lt;b&gt;3M (TM) Pak 100 4-Wall Header&lt;/b&gt; Straight&lt;p&gt;
Source: 3M</description>
<wire x1="-10" y1="4.2" x2="10" y2="4.2" width="0.2032" layer="21"/>
<wire x1="10" y1="4.2" x2="10" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="10" y1="-4.2" x2="5.938" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="5.938" y1="-4.2" x2="5.938" y2="-3.9" width="0.2032" layer="21"/>
<wire x1="5.938" y1="-3.9" x2="4.459" y2="-3.9" width="0.2032" layer="21"/>
<wire x1="4.459" y1="-3.9" x2="4.459" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="4.459" y1="-4.2" x2="1.883" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="1.883" y1="-4.2" x2="1.883" y2="-2.65" width="0.2032" layer="21"/>
<wire x1="1.883" y1="-2.65" x2="-1.883" y2="-2.65" width="0.2032" layer="21"/>
<wire x1="-1.883" y1="-2.65" x2="-1.883" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="1.883" y1="-4.2" x2="-1.883" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="-1.883" y1="-4.2" x2="-10" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="-10" y1="-4.2" x2="-10" y2="4.2" width="0.2032" layer="21"/>
<wire x1="-8.875" y1="3.275" x2="8.875" y2="3.275" width="0.2032" layer="21"/>
<wire x1="8.875" y1="3.275" x2="8.875" y2="-3.275" width="0.2032" layer="21"/>
<wire x1="8.875" y1="-3.275" x2="1.883" y2="-3.275" width="0.2032" layer="21"/>
<wire x1="-1.883" y1="-3.275" x2="-8.875" y2="-3.275" width="0.2032" layer="21"/>
<wire x1="-8.875" y1="-3.275" x2="-8.875" y2="3.275" width="0.2032" layer="21"/>
<pad name="1" x="-5.08" y="-1.27" drill="1" diameter="1.4224"/>
<pad name="2" x="-5.08" y="1.27" drill="1" diameter="1.4224"/>
<pad name="3" x="-2.54" y="-1.27" drill="1" diameter="1.4224"/>
<pad name="4" x="-2.54" y="1.27" drill="1" diameter="1.4224"/>
<pad name="5" x="0" y="-1.27" drill="1" diameter="1.4224"/>
<pad name="6" x="0" y="1.27" drill="1" diameter="1.4224"/>
<pad name="7" x="2.54" y="-1.27" drill="1" diameter="1.4224"/>
<pad name="8" x="2.54" y="1.27" drill="1" diameter="1.4224"/>
<pad name="9" x="5.08" y="-1.27" drill="1" diameter="1.4224"/>
<pad name="10" x="5.08" y="1.27" drill="1" diameter="1.4224"/>
<text x="-10.16" y="4.572" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="4.572" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="diode">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
<packages>
<package name="DO35-7">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2 mm, horizontal, grid 7.62 mm</description>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.032" y1="1.016" x2="2.286" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="0.762" x2="2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.016" x2="2.286" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.286" y1="0.762" x2="-2.032" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="-0.762" x2="-2.032" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.032" y1="-1.016" x2="2.032" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0.762" x2="-2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.016" x2="2.032" y2="1.016" width="0.1524" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="3.81" y="0" drill="0.8128" shape="long"/>
<text x="-2.286" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.905" y1="-1.016" x2="-1.397" y2="1.016" layer="21"/>
<rectangle x1="2.286" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
</package>
</packages>
</library>
<library name="switch-tact">
<description>&lt;b&gt;Diptronics THMD &amp; SMD tact switches&lt;/b&gt;
&lt;p&gt;&lt;ul&gt;
&lt;li&gt;DTS-3: 3.5x6mm THMD tact switch
&lt;li&gt;DTS-6, DTS-64: 6x6mm THMD tact switch
&lt;li&gt;DTSM-3: 3.5x6mm SMD tact switch
&lt;li&gt;DTSM-6, DTSM-64: 6x6mm SMD tact switch
&lt;/ul&gt;&lt;/p&gt;
&lt;p&gt;&lt;b&gt;Doublecheck before using!&lt;/b&gt;&lt;/p&gt;</description>
<packages>
<package name="DTS-6">
<wire x1="-3.1" y1="3.1" x2="3.1" y2="3.1" width="0.2032" layer="51"/>
<wire x1="3.1" y1="3.1" x2="3.1" y2="-3.1" width="0.2032" layer="51"/>
<wire x1="3.1" y1="-3.1" x2="-3.1" y2="-3.1" width="0.2032" layer="51"/>
<wire x1="-3.1" y1="-3.1" x2="-3.1" y2="3.1" width="0.2032" layer="51"/>
<wire x1="1.5" y1="3.1" x2="-1.5" y2="3.1" width="0.2032" layer="21"/>
<wire x1="3.1" y1="-1" x2="3.1" y2="1" width="0.2032" layer="21"/>
<wire x1="1.5" y1="-3.1" x2="-1.5" y2="-3.1" width="0.2032" layer="21"/>
<wire x1="-3.1" y1="-1" x2="-3.1" y2="1" width="0.2032" layer="21"/>
<circle x="0" y="0" radius="1.75" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="1.75" width="0.2032" layer="21"/>
<pad name="1" x="-3.25" y="2.25" drill="1" shape="long"/>
<pad name="2" x="3.25" y="2.25" drill="1" shape="long"/>
<pad name="3" x="-3.25" y="-2.25" drill="1" shape="long"/>
<pad name="4" x="3.25" y="-2.25" drill="1" shape="long"/>
<text x="-2.54" y="3.81" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-5.08" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="con-molex">
<description>&lt;b&gt;Molex Connectors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="22-23-2021">
<description>.100" (2.54mm) Center Headers - 2 Pin</description>
<wire x1="-2.54" y1="3.175" x2="2.54" y2="3.175" width="0.254" layer="21"/>
<wire x1="2.54" y1="3.175" x2="2.54" y2="1.27" width="0.254" layer="21"/>
<wire x1="2.54" y1="1.27" x2="2.54" y2="-3.175" width="0.254" layer="21"/>
<wire x1="2.54" y1="-3.175" x2="-2.54" y2="-3.175" width="0.254" layer="21"/>
<wire x1="-2.54" y1="-3.175" x2="-2.54" y2="1.27" width="0.254" layer="21"/>
<wire x1="-2.54" y1="1.27" x2="-2.54" y2="3.175" width="0.254" layer="21"/>
<wire x1="-2.54" y1="1.27" x2="2.54" y2="1.27" width="0.254" layer="21"/>
<pad name="1" x="-1.27" y="0" drill="1" shape="long" rot="R90"/>
<pad name="2" x="1.27" y="0" drill="1" shape="long" rot="R90"/>
<text x="-2.54" y="3.81" size="1.016" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-5.08" size="1.016" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="relay">
<description>&lt;b&gt;Relays&lt;/b&gt;&lt;p&gt;
&lt;ul&gt;
&lt;li&gt;Eichhoff
&lt;li&gt;Finder
&lt;li&gt;Fujitsu
&lt;li&gt;HAMLIN
&lt;li&gt;OMRON
&lt;li&gt;Matsushita
&lt;li&gt;NAiS
&lt;li&gt;Siemens
&lt;li&gt;Schrack
&lt;/ul&gt;
<packages>
<package name="AXICOM">
<pad name="P$3" x="0" y="-2.54" drill="1" diameter="2"/>
<pad name="P$8" x="0" y="5.08" drill="1" diameter="2"/>
<pad name="P$2" x="-2.54" y="-2.54" drill="1" diameter="2"/>
<pad name="P$1" x="-5.08" y="-2.54" drill="1" diameter="2"/>
<pad name="P$4" x="2.54" y="-2.54" drill="1" diameter="2"/>
<pad name="P$5" x="5.08" y="-2.54" drill="1" diameter="2"/>
<pad name="P$9" x="-2.54" y="5.08" drill="1" diameter="2"/>
<pad name="P$10" x="-5.08" y="5.08" drill="1" diameter="2"/>
<pad name="P$7" x="2.54" y="5.08" drill="1" diameter="2"/>
<pad name="P$6" x="5.08" y="5.08" drill="1" diameter="2"/>
<wire x1="-5.08" y1="5.08" x2="-5.08" y2="2.54" width="0.127" layer="21" curve="-180"/>
<wire x1="-5.08" y1="2.54" x2="-5.08" y2="0" width="0.127" layer="21" curve="-180"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="-2.54" width="0.127" layer="21" curve="-180"/>
<wire x1="-7.11" y1="6.43" x2="-7.11" y2="-3.89" width="0.127" layer="21"/>
<wire x1="7.01" y1="6.42" x2="7.01" y2="-3.88" width="0.127" layer="21"/>
<wire x1="-7.12" y1="6.48" x2="7.02" y2="6.48" width="0.127" layer="21"/>
<wire x1="-7.12" y1="-3.94" x2="7.02" y2="-3.94" width="0.127" layer="21"/>
</package>
</packages>
</library>
<library name="transistor-npn">
<description>&lt;b&gt;NPN Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="TO92-EBC">
<description>&lt;b&gt;TO-92&lt;/b&gt;&lt;p&gt;
 grid 5.08 mm</description>
<wire x1="-2.095" y1="-2.921" x2="2.095" y2="-2.921" width="0.127" layer="21"/>
<wire x1="-2.413" y1="-0.1341" x2="2.413" y2="-0.1341" width="0.127" layer="21" curve="-129.583"/>
<wire x1="1.136" y1="-1.397" x2="-1.136" y2="-1.397" width="0.127" layer="51"/>
<wire x1="-2.413" y1="-0.1341" x2="-2.664" y2="-1.397" width="0.127" layer="51" curve="27.9376"/>
<wire x1="-2.664" y1="-1.397" x2="-2.413" y2="-2.4059" width="0.127" layer="51" curve="22.4788"/>
<wire x1="-1.404" y1="-1.397" x2="-2.664" y2="-1.397" width="0.127" layer="51"/>
<wire x1="-2.4135" y1="-2.4059" x2="-2.095" y2="-2.921" width="0.127" layer="21" curve="13.0385"/>
<wire x1="-1.136" y1="-1.397" x2="-1.404" y2="-1.397" width="0.127" layer="21"/>
<wire x1="2.413" y1="-2.4059" x2="2.664" y2="-1.397" width="0.127" layer="51" curve="22.4788"/>
<wire x1="2.664" y1="-1.397" x2="2.413" y2="-0.1341" width="0.127" layer="51" curve="27.9376"/>
<wire x1="2.664" y1="-1.397" x2="1.404" y2="-1.397" width="0.127" layer="51"/>
<wire x1="1.404" y1="-1.397" x2="1.136" y2="-1.397" width="0.127" layer="21"/>
<wire x1="2.095" y1="-2.921" x2="2.4247" y2="-2.3818" width="0.127" layer="21" curve="13.6094"/>
<pad name="C" x="-2.54" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="2.54" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<pad name="B" x="0" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.54" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-4.572" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="con-garry">
<description>&lt;b&gt;Pin Header Connectors&lt;/b&gt;&lt;p&gt;
&lt;a href="www.mpe-connector.de"&gt;Menufacturer&lt;/a&gt;&lt;p&gt;
<packages>
<package name="332-04">
<description>&lt;b&gt;4 Pin - 2mm Dual Row&lt;/b&gt;&lt;p&gt;
Source: www.mpe-connector.de / garry_shortform_2012.pdf</description>
<wire x1="-1.85" y1="-1.9" x2="1.85" y2="-1.9" width="0.2032" layer="21"/>
<wire x1="1.85" y1="-1.9" x2="1.85" y2="-0.4" width="0.2032" layer="21"/>
<wire x1="1.85" y1="0.4" x2="1.85" y2="1.9" width="0.2032" layer="21"/>
<wire x1="1.85" y1="1.9" x2="-1.85" y2="1.9" width="0.2032" layer="21"/>
<wire x1="-1.85" y1="1.9" x2="-1.85" y2="0.4" width="0.2032" layer="21"/>
<wire x1="-1.85" y1="-0.4" x2="-1.85" y2="-1.9" width="0.2032" layer="21"/>
<wire x1="-1.85" y1="0.4" x2="-1.85" y2="-0.4" width="0.2032" layer="21" curve="-129.185"/>
<wire x1="1.85" y1="-0.4" x2="1.85" y2="0.4" width="0.2032" layer="21" curve="-129.185"/>
<pad name="1" x="-1" y="-1" drill="0.9" diameter="1.27"/>
<pad name="2" x="-1" y="1" drill="0.9" diameter="1.27"/>
<pad name="3" x="1" y="-1" drill="0.9" diameter="1.27"/>
<pad name="4" x="1" y="1" drill="0.9" diameter="1.27"/>
<text x="-1.65" y="-1.75" size="0.3048" layer="21" font="vector">1</text>
<text x="-1.62" y="2.19" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.62" y="3.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.25" y1="-1.25" x2="-0.75" y2="-0.75" layer="51"/>
<rectangle x1="-1.25" y1="0.75" x2="-0.75" y2="1.25" layer="51"/>
<rectangle x1="0.75" y1="-1.25" x2="1.25" y2="-0.75" layer="51"/>
<rectangle x1="0.75" y1="0.75" x2="1.25" y2="1.25" layer="51"/>
<wire x1="-1" y1="1" x2="-1" y2="-6" width="0.55" layer="51"/>
<wire x1="1" y1="1" x2="1" y2="-6" width="0.55" layer="51"/>
</package>
<package name="332-02">
<description>&lt;b&gt;2 Pin - 2mm Dual Row&lt;/b&gt;&lt;p&gt;
<wire x1="-0.85" y1="-1.9" x2="0.85" y2="-1.9" width="0.2032" layer="21"/>
<wire x1="0.85" y1="-1.9" x2="0.85" y2="-0.4" width="0.2032" layer="21"/>
<wire x1="0.85" y1="0.4" x2="0.85" y2="1.9" width="0.2032" layer="21"/>
<wire x1="0.85" y1="1.9" x2="-0.85" y2="1.9" width="0.2032" layer="21"/>
<wire x1="-0.85" y1="1.9" x2="-0.85" y2="0.4" width="0.2032" layer="21"/>
<wire x1="-0.85" y1="-0.4" x2="-0.85" y2="-1.9" width="0.2032" layer="21"/>
<wire x1="-0.85" y1="0.4" x2="-0.85" y2="-0.4" width="0.2032" layer="21" curve="-129.185"/>
<wire x1="0.85" y1="-0.4" x2="0.85" y2="0.4" width="0.2032" layer="21" curve="-129.185"/>
<pad name="1" x="0" y="-1" drill="0.9" diameter="1.27"/>
<pad name="2" x="0" y="1" drill="0.9" diameter="1.27"/>
<text x="-0.65" y="-1.75" size="0.3048" layer="21" font="vector">1</text>
<text x="-0.62" y="-3.81" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.62" y="2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.25" y1="-1.25" x2="0.25" y2="-0.75" layer="51"/>
<rectangle x1="-0.25" y1="0.75" x2="0.25" y2="1.25" layer="51"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="IC1" library="microchip" package="DIL40" value="PIC16F877P" x="88.9" y="46.99">
<attribute name="OC_NEWARK" value="61K3463" x="128.27" y="-2.54" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="PIC16F877-04/P" x="128.27" y="-2.54" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="MICROCHIP" x="128.27" y="-2.54" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="9761349" x="128.27" y="-2.54" size="1.778" layer="27" display="off"/>
</element>
<element name="IC2" library="linear" package="TO220V" value="7805TV" x="57.15" y="70.485"/>
<element name="S1" library="switch-misc" package="DT6" value="DT6" x="13.97" y="21.59" rot="R270"/>
<element name="X1" library="con-ptr500" package="AK500/2" value="" x="34.29" y="64.135" rot="R90">
<attribute name="OC_NEWARK" value="unknown" x="110.49" y="114.935" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="110.49" y="114.935" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MF" value="" x="110.49" y="114.935" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="110.49" y="114.935" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="C1" library="rcl" package="C050-025X075" value="" x="54.61" y="61.595" rot="R270"/>
<element name="C2" library="rcl" package="C050-025X075" value="" x="60.96" y="61.595" rot="R270"/>
<element name="C3" library="rcl" package="E2,5-6" value="" x="48.26" y="62.865" rot="R270"/>
<element name="R1" library="rcl" package="RTRIM64Y" value="" x="121.92" y="33.02" rot="R90"/>
<element name="Q1" library="crystal" package="HC49/S" value="" x="95.25" y="30.48" rot="R90">
<attribute name="OC_NEWARK" value="unknown" x="181.61" y="49.53" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="181.61" y="49.53" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MF" value="" x="181.61" y="49.53" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="1667008" x="181.61" y="49.53" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="C4" library="rcl" package="C025-025X050" value="" x="99.06" y="33.02" rot="R90"/>
<element name="C5" library="rcl" package="C025-025X050" value="" x="99.06" y="27.94" rot="R270"/>
<element name="X3" library="con-3m" package="PAK100/2500-10" value="2510-" x="121.285" y="46.99" rot="R90">
<attribute name="OC_NEWARK" value="46F4725" x="186.055" y="100.33" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="2510-6002UB" x="186.055" y="100.33" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MF" value="3M" x="186.055" y="100.33" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="9838244" x="186.055" y="100.33" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="D1" library="diode" package="DO35-7" value="1N4148DO35-7" x="46.355" y="57.785" rot="R180"/>
<element name="S2" library="switch-tact" package="DTS-6" value="DTS-6" x="52.705" y="41.91"/>
<element name="R2" library="rcl" package="0207/10" value="" x="87.63" y="30.48" rot="R90"/>
<element name="C6" library="rcl" package="C050-025X075" value="" x="59.69" y="41.91" rot="R90"/>
<element name="R3" library="rcl" package="0207/10" value="" x="64.135" y="34.29" rot="R180"/>
<element name="R4" library="rcl" package="0207/10" value="" x="85.09" y="30.48" rot="R90"/>
<element name="R5" library="rcl" package="0207/10" value="" x="84.455" y="61.595" rot="R180"/>
<element name="X2" library="con-molex" package="22-23-2021" value="22-23-2021" x="71.755" y="61.595">
<attribute name="OC_NEWARK" value="25C3832" x="102.235" y="-4.445" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="22-23-2021" x="102.235" y="-4.445" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="MOLEX" x="102.235" y="-4.445" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="1462926" x="102.235" y="-4.445" size="1.778" layer="27" display="off"/>
</element>
<element name="X4" library="con-molex" package="22-23-2021" value="22-23-2021" x="13.97" y="31.75">
<attribute name="OC_NEWARK" value="25C3832" x="53.34" y="-34.29" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="22-23-2021" x="53.34" y="-34.29" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="MOLEX" x="53.34" y="-34.29" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="1462926" x="53.34" y="-34.29" size="1.778" layer="27" display="off"/>
</element>
<element name="U$1" library="relay" package="AXICOM" value="AXICOM" x="47.625" y="28.575" rot="R180"/>
<element name="Q2" library="transistor-npn" package="TO92-EBC" value="BC546A" x="66.675" y="23.495" rot="R270"/>
<element name="X5" library="con-garry" package="332-04" value="332-04" x="60.325" y="50.165" rot="R270"/>
<element name="X6" library="con-garry" package="332-02" value="332-02" x="107.95" y="35.56" rot="R180"/>
<element name="R6" library="rcl" package="0207/10" value="" x="102.87" y="26.035" rot="R90"/>
<element name="R7" library="rcl" package="0207/10" value="" x="90.17" y="30.48" rot="R270"/>
<element name="D2" library="diode" package="DO35-7" value="1N4148DO35-7" x="57.15" y="27.305" rot="R90"/>
<element name="X10" library="con-ptr500" package="AK500/3" value="" x="34.29" y="46.99" rot="R90">
<attribute name="OC_NEWARK" value="unknown" x="97.79" y="133.35" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="97.79" y="133.35" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MF" value="" x="97.79" y="133.35" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="97.79" y="133.35" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="X11" library="con-ptr500" package="AK500/3" value="" x="34.29" y="16.51" rot="R90">
<attribute name="OC_NEWARK" value="unknown" x="110.49" y="36.83" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="110.49" y="36.83" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MF" value="" x="110.49" y="36.83" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="110.49" y="36.83" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="X12" library="con-ptr500" package="AK500/3" value="" x="34.29" y="31.75" rot="R90">
<attribute name="OC_NEWARK" value="unknown" x="110.49" y="68.58" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="110.49" y="68.58" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MF" value="" x="110.49" y="68.58" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="110.49" y="68.58" size="1.778" layer="27" rot="R90" display="off"/>
</element>
</elements>
<signals>
<signal name="N$1">
<contactref element="IC2" pad="1"/>
<contactref element="C1" pad="1"/>
<contactref element="C3" pad="+"/>
<contactref element="D1" pad="C"/>
<contactref element="R3" pad="2"/>
<wire x1="54.61" y1="64.135" x2="50.165" y2="64.135" width="1.016" layer="16"/>
<wire x1="50.165" y1="64.135" x2="48.26" y2="64.135" width="1.016" layer="16"/>
<wire x1="54.61" y1="67.945" x2="54.61" y2="64.135" width="1.016" layer="16"/>
<wire x1="59.055" y1="34.29" x2="55.245" y2="34.29" width="0.8128" layer="16"/>
<wire x1="55.245" y1="34.29" x2="52.705" y2="36.83" width="0.8128" layer="16"/>
<wire x1="52.705" y1="36.83" x2="52.705" y2="47.625" width="0.8128" layer="16"/>
<wire x1="50.165" y1="57.785" x2="50.165" y2="50.165" width="1.016" layer="16"/>
<wire x1="50.165" y1="50.165" x2="52.705" y2="47.625" width="1.016" layer="16"/>
<wire x1="50.165" y1="57.785" x2="50.165" y2="64.135" width="1.016" layer="16"/>
</signal>
<signal name="VCC">
<contactref element="IC2" pad="3"/>
<contactref element="C2" pad="1"/>
<contactref element="IC1" pad="32"/>
<contactref element="IC1" pad="11"/>
<contactref element="X3" pad="2"/>
<contactref element="R1" pad="3"/>
<contactref element="R2" pad="2"/>
<contactref element="X2" pad="1"/>
<contactref element="R7" pad="1"/>
<wire x1="59.69" y1="67.945" x2="60.96" y2="66.675" width="1.016" layer="16"/>
<wire x1="60.96" y1="66.675" x2="60.96" y2="64.135" width="1.016" layer="16"/>
<wire x1="90.17" y1="39.37" x2="90.17" y2="41.275" width="0.8128" layer="16"/>
<wire x1="90.17" y1="41.275" x2="90.805" y2="41.91" width="0.8128" layer="16"/>
<wire x1="90.805" y1="41.91" x2="120.015" y2="41.91" width="0.8128" layer="16"/>
<wire x1="119.38" y1="33.02" x2="119.38" y2="41.275" width="0.8128" layer="16"/>
<wire x1="119.38" y1="41.275" x2="120.015" y2="41.91" width="0.8128" layer="16"/>
<wire x1="70.485" y1="61.595" x2="63.5" y2="61.595" width="0.8128" layer="16"/>
<wire x1="63.5" y1="61.595" x2="60.96" y2="64.135" width="0.8128" layer="16"/>
<wire x1="70.485" y1="62.23" x2="70.485" y2="61.595" width="0.8128" layer="16"/>
<contactref element="X5" pad="1"/>
<wire x1="63.5" y1="61.595" x2="63.5" y2="57.785" width="0.8128" layer="16"/>
<wire x1="63.5" y1="57.785" x2="59.69" y2="53.975" width="0.8128" layer="16"/>
<wire x1="59.69" y1="53.975" x2="59.69" y2="51.53" width="0.8128" layer="16"/>
<wire x1="59.69" y1="51.53" x2="59.325" y2="51.165" width="0.8128" layer="16"/>
<wire x1="87.63" y1="35.56" x2="90.17" y2="35.56" width="0.8128" layer="16"/>
<wire x1="90.17" y1="39.37" x2="90.17" y2="35.56" width="0.8128" layer="16"/>
<wire x1="85.09" y1="54.61" x2="85.09" y2="66.04" width="1.016" layer="16"/>
<wire x1="85.09" y1="66.04" x2="86.36" y2="67.31" width="1.016" layer="16"/>
<wire x1="86.36" y1="67.31" x2="124.46" y2="67.31" width="1.016" layer="16"/>
<wire x1="124.46" y1="67.31" x2="130.175" y2="61.595" width="1.016" layer="16"/>
<wire x1="130.175" y1="61.595" x2="130.175" y2="25.4" width="1.016" layer="16"/>
<wire x1="130.175" y1="25.4" x2="125.73" y2="20.955" width="1.016" layer="16"/>
<wire x1="125.73" y1="20.955" x2="119.38" y2="20.955" width="1.016" layer="16"/>
<wire x1="119.38" y1="20.955" x2="117.475" y2="22.86" width="1.016" layer="16"/>
<wire x1="117.475" y1="22.86" x2="117.475" y2="31.75" width="1.016" layer="16"/>
<wire x1="117.475" y1="31.75" x2="118.745" y2="33.02" width="1.016" layer="16"/>
<wire x1="118.745" y1="33.02" x2="119.38" y2="33.02" width="1.016" layer="16"/>
<wire x1="70.485" y1="62.23" x2="70.485" y2="64.135" width="1.016" layer="16"/>
<wire x1="70.485" y1="64.135" x2="72.39" y2="66.04" width="1.016" layer="16"/>
<wire x1="72.39" y1="66.04" x2="85.09" y2="66.04" width="1.016" layer="16"/>
</signal>
<signal name="GND">
<contactref element="IC2" pad="2"/>
<contactref element="X1" pad="2"/>
<contactref element="C3" pad="-"/>
<contactref element="C1" pad="2"/>
<contactref element="C2" pad="2"/>
<contactref element="IC1" pad="31"/>
<contactref element="IC1" pad="12"/>
<contactref element="X3" pad="1"/>
<contactref element="R1" pad="1"/>
<contactref element="C4" pad="1"/>
<contactref element="C5" pad="1"/>
<contactref element="S2" pad="2"/>
<contactref element="C6" pad="2"/>
<contactref element="R4" pad="1"/>
<contactref element="R5" pad="1"/>
<contactref element="U$1" pad="P$1"/>
<contactref element="D2" pad="A"/>
<wire x1="59.69" y1="44.45" x2="71.12" y2="44.45" width="0.8128" layer="16"/>
<wire x1="71.12" y1="44.45" x2="76.2" y2="49.53" width="0.8128" layer="16"/>
<wire x1="87.63" y1="54.61" x2="87.63" y2="50.165" width="0.8128" layer="16"/>
<wire x1="87.63" y1="50.165" x2="86.995" y2="49.53" width="0.8128" layer="16"/>
<wire x1="86.995" y1="49.53" x2="76.2" y2="49.53" width="0.8128" layer="16"/>
<contactref element="X5" pad="3"/>
<polygon width="0.8128" layer="16" isolate="0.5">
<vertex x="25.4" y="6.35"/>
<vertex x="134.62" y="6.35"/>
<vertex x="134.62" y="74.295"/>
<vertex x="25.4" y="74.295"/>
</polygon>
</signal>
<signal name="N$3">
<contactref element="R1" pad="2"/>
<contactref element="X3" pad="3"/>
<wire x1="121.92" y1="30.48" x2="125.095" y2="30.48" width="0.8128" layer="16"/>
<wire x1="125.095" y1="30.48" x2="126.365" y2="31.75" width="0.8128" layer="16"/>
<wire x1="126.365" y1="31.75" x2="126.365" y2="42.545" width="0.8128" layer="16"/>
<wire x1="126.365" y1="42.545" x2="124.46" y2="44.45" width="0.8128" layer="16"/>
<wire x1="124.46" y1="44.45" x2="122.555" y2="44.45" width="0.8128" layer="16"/>
</signal>
<signal name="N$4">
<contactref element="IC1" pad="3"/>
<contactref element="X3" pad="4"/>
<wire x1="77.47" y1="35.56" x2="70.485" y2="35.56" width="0.5" layer="16"/>
<wire x1="70.485" y1="35.56" x2="69.85" y2="36.195" width="0.5" layer="16"/>
<wire x1="69.85" y1="36.195" x2="69.85" y2="39.37" width="0.5" layer="16"/>
<wire x1="120.015" y1="44.45" x2="81.915" y2="44.45" width="0.5" layer="16"/>
<wire x1="81.915" y1="44.45" x2="78.74" y2="41.275" width="0.5" layer="16"/>
<wire x1="78.74" y1="41.275" x2="78.74" y2="36.83" width="0.5" layer="16"/>
<wire x1="78.74" y1="36.83" x2="77.47" y2="35.56" width="0.5" layer="16"/>
</signal>
<signal name="N$5">
<contactref element="IC1" pad="4"/>
<contactref element="X3" pad="5"/>
<wire x1="122.555" y1="46.99" x2="121.285" y2="45.72" width="0.5" layer="16"/>
<wire x1="121.285" y1="45.72" x2="79.375" y2="45.72" width="0.5" layer="16"/>
<wire x1="79.375" y1="45.72" x2="76.2" y2="42.545" width="0.5" layer="16"/>
<wire x1="76.2" y1="42.545" x2="76.2" y2="37.465" width="0.5" layer="16"/>
<wire x1="76.2" y1="37.465" x2="75.565" y2="36.83" width="0.5" layer="16"/>
<wire x1="75.565" y1="36.83" x2="73.025" y2="36.83" width="0.5" layer="16"/>
<wire x1="73.025" y1="36.83" x2="72.39" y2="37.465" width="0.5" layer="16"/>
<wire x1="72.39" y1="37.465" x2="72.39" y2="39.37" width="0.5" layer="16"/>
</signal>
<signal name="N$6">
<contactref element="IC1" pad="5"/>
<contactref element="X3" pad="6"/>
<wire x1="74.93" y1="39.37" x2="74.93" y2="43.815" width="0.5" layer="16"/>
<wire x1="74.93" y1="43.815" x2="78.105" y2="46.99" width="0.5" layer="16"/>
<wire x1="78.105" y1="46.99" x2="120.015" y2="46.99" width="0.5" layer="16"/>
</signal>
<signal name="N$7">
<contactref element="IC1" pad="27"/>
<contactref element="X3" pad="7"/>
<wire x1="122.555" y1="49.53" x2="122.555" y2="50.165" width="0.5" layer="16"/>
<wire x1="122.555" y1="50.165" x2="121.92" y2="50.8" width="0.5" layer="16"/>
<wire x1="121.92" y1="50.8" x2="99.06" y2="50.8" width="0.5" layer="16"/>
<wire x1="99.06" y1="50.8" x2="97.79" y2="52.07" width="0.5" layer="16"/>
<wire x1="97.79" y1="52.07" x2="97.79" y2="54.61" width="0.5" layer="16"/>
</signal>
<signal name="N$8">
<contactref element="IC1" pad="28"/>
<contactref element="X3" pad="8"/>
<wire x1="120.015" y1="49.53" x2="96.52" y2="49.53" width="0.5" layer="16"/>
<wire x1="96.52" y1="49.53" x2="95.25" y2="50.8" width="0.5" layer="16"/>
<wire x1="95.25" y1="50.8" x2="95.25" y2="54.61" width="0.5" layer="16"/>
</signal>
<signal name="N$9">
<contactref element="IC1" pad="29"/>
<contactref element="X3" pad="9"/>
<wire x1="122.555" y1="52.07" x2="122.555" y2="54.61" width="0.5" layer="16"/>
<wire x1="122.555" y1="54.61" x2="118.745" y2="58.42" width="0.5" layer="16"/>
<wire x1="118.745" y1="58.42" x2="93.345" y2="58.42" width="0.5" layer="16"/>
<wire x1="93.345" y1="58.42" x2="92.71" y2="57.785" width="0.5" layer="16"/>
<wire x1="92.71" y1="57.785" x2="92.71" y2="54.61" width="0.5" layer="16"/>
</signal>
<signal name="N$10">
<contactref element="IC1" pad="30"/>
<contactref element="X3" pad="10"/>
<wire x1="120.015" y1="52.07" x2="99.695" y2="52.07" width="0.5" layer="16"/>
<wire x1="99.695" y1="52.07" x2="99.06" y2="52.705" width="0.5" layer="16"/>
<wire x1="99.06" y1="52.705" x2="99.06" y2="56.515" width="0.5" layer="16"/>
<wire x1="99.06" y1="56.515" x2="98.425" y2="57.15" width="0.5" layer="16"/>
<wire x1="98.425" y1="57.15" x2="94.615" y2="57.15" width="0.5" layer="16"/>
<wire x1="94.615" y1="57.15" x2="93.98" y2="56.515" width="0.5" layer="16"/>
<wire x1="93.98" y1="56.515" x2="93.98" y2="52.705" width="0.5" layer="16"/>
<wire x1="93.98" y1="52.705" x2="93.345" y2="52.07" width="0.5" layer="16"/>
<wire x1="93.345" y1="52.07" x2="90.805" y2="52.07" width="0.5" layer="16"/>
<wire x1="90.805" y1="52.07" x2="90.17" y2="52.705" width="0.5" layer="16"/>
<wire x1="90.17" y1="52.705" x2="90.17" y2="54.61" width="0.5" layer="16"/>
</signal>
<signal name="N$11">
<contactref element="IC1" pad="13"/>
<contactref element="C4" pad="2"/>
<contactref element="Q1" pad="2"/>
<wire x1="95.25" y1="39.37" x2="95.25" y2="34.29" width="0.8128" layer="16"/>
<wire x1="95.25" y1="34.29" x2="95.25" y2="32.893" width="0.8128" layer="16"/>
<wire x1="99.06" y1="34.29" x2="95.25" y2="34.29" width="0.8128" layer="16"/>
</signal>
<signal name="N$12">
<contactref element="C5" pad="2"/>
<contactref element="Q1" pad="1"/>
<contactref element="IC1" pad="14"/>
<wire x1="97.79" y1="39.37" x2="97.79" y2="37.465" width="0.8128" layer="16"/>
<wire x1="97.79" y1="37.465" x2="99.06" y2="36.195" width="0.8128" layer="16"/>
<wire x1="99.06" y1="36.195" x2="100.33" y2="36.195" width="0.8128" layer="16"/>
<wire x1="100.33" y1="36.195" x2="100.965" y2="35.56" width="0.8128" layer="16"/>
<wire x1="100.965" y1="35.56" x2="100.965" y2="27.305" width="0.8128" layer="16"/>
<wire x1="100.965" y1="27.305" x2="100.33" y2="26.67" width="0.8128" layer="16"/>
<wire x1="100.33" y1="26.67" x2="99.06" y2="26.67" width="0.8128" layer="16"/>
<wire x1="95.25" y1="28.067" x2="95.25" y2="27.94" width="0.8128" layer="16"/>
<wire x1="95.25" y1="27.94" x2="96.52" y2="26.67" width="0.8128" layer="16"/>
<wire x1="96.52" y1="26.67" x2="99.06" y2="26.67" width="0.8128" layer="16"/>
</signal>
<signal name="N$2">
<contactref element="X1" pad="1"/>
<contactref element="D1" pad="A"/>
<wire x1="34.29" y1="61.6204" x2="38.7096" y2="61.6204" width="1.016" layer="16"/>
<wire x1="38.7096" y1="61.6204" x2="42.545" y2="57.785" width="1.016" layer="16"/>
</signal>
<signal name="N$13">
<contactref element="R2" pad="1"/>
<contactref element="S2" pad="4"/>
<contactref element="C6" pad="1"/>
<contactref element="IC1" pad="1"/>
<wire x1="59.69" y1="39.37" x2="64.77" y2="39.37" width="0.8128" layer="16"/>
<wire x1="64.77" y1="39.37" x2="64.77" y2="32.385" width="0.8128" layer="16"/>
<wire x1="55.955" y1="39.66" x2="59.4" y2="39.66" width="0.8128" layer="16"/>
<wire x1="59.4" y1="39.66" x2="59.69" y2="39.37" width="0.8128" layer="16"/>
<wire x1="87.63" y1="25.4" x2="87.63" y2="28.575" width="1.016" layer="16"/>
<wire x1="87.63" y1="28.575" x2="86.36" y2="29.845" width="1.016" layer="16"/>
<wire x1="86.36" y1="29.845" x2="67.31" y2="29.845" width="1.016" layer="16"/>
<wire x1="67.31" y1="29.845" x2="64.77" y2="32.385" width="1.016" layer="16"/>
</signal>
<signal name="N$16">
<contactref element="R3" pad="1"/>
<contactref element="R4" pad="2"/>
<contactref element="IC1" pad="9"/>
<wire x1="85.09" y1="39.37" x2="85.09" y2="35.56" width="0.8128" layer="16"/>
<wire x1="69.215" y1="34.29" x2="83.82" y2="34.29" width="0.8128" layer="16"/>
<wire x1="83.82" y1="34.29" x2="85.09" y2="35.56" width="0.8128" layer="16"/>
</signal>
<signal name="N$14">
<contactref element="IC1" pad="33"/>
<contactref element="R5" pad="2"/>
<contactref element="X2" pad="2"/>
<wire x1="73.025" y1="61.595" x2="79.375" y2="61.595" width="1.016" layer="16"/>
<wire x1="79.375" y1="61.595" x2="82.55" y2="58.42" width="1.016" layer="16"/>
<wire x1="82.55" y1="58.42" x2="82.55" y2="54.61" width="1.016" layer="16"/>
</signal>
<signal name="N$18">
<contactref element="S1" pad="4"/>
<contactref element="X4" pad="1"/>
<wire x1="11.43" y1="24.13" x2="11.43" y2="30.48" width="1.27" layer="16"/>
<wire x1="11.43" y1="30.48" x2="12.7" y2="31.75" width="1.27" layer="16"/>
</signal>
<signal name="N$19">
<contactref element="S1" pad="2"/>
<contactref element="X4" pad="2"/>
<wire x1="16.51" y1="19.05" x2="16.51" y2="20.32" width="1.27" layer="16"/>
<wire x1="16.51" y1="20.32" x2="18.415" y2="22.225" width="1.27" layer="16"/>
<wire x1="18.415" y1="22.225" x2="18.415" y2="28.575" width="1.27" layer="16"/>
<wire x1="18.415" y1="28.575" x2="15.24" y2="31.75" width="1.27" layer="16"/>
</signal>
<signal name="N$15">
<contactref element="IC1" pad="34"/>
<wire x1="80.01" y1="54.61" x2="80.01" y2="51.435" width="0.5" layer="16"/>
<wire x1="80.01" y1="51.435" x2="79.375" y2="50.8" width="0.5" layer="16"/>
<wire x1="79.375" y1="50.8" x2="71.755" y2="50.8" width="0.5" layer="16"/>
<wire x1="71.755" y1="50.8" x2="69.85" y2="48.895" width="0.5" layer="16"/>
<contactref element="X5" pad="4"/>
<wire x1="69.85" y1="48.895" x2="61.595" y2="48.895" width="0.5" layer="16"/>
<wire x1="61.595" y1="48.895" x2="61.325" y2="49.165" width="0.5" layer="16"/>
</signal>
<signal name="N$17">
<contactref element="IC1" pad="35"/>
<wire x1="77.47" y1="54.61" x2="77.47" y2="53.34" width="0.5" layer="16"/>
<wire x1="77.47" y1="53.34" x2="76.2" y2="52.07" width="0.5" layer="16"/>
<wire x1="76.2" y1="52.07" x2="71.12" y2="52.07" width="0.5" layer="16"/>
<wire x1="71.12" y1="52.07" x2="69.215" y2="50.165" width="0.5" layer="16"/>
<contactref element="X5" pad="2"/>
<wire x1="69.215" y1="50.165" x2="62.325" y2="50.165" width="0.5" layer="16"/>
<wire x1="62.325" y1="50.165" x2="61.325" y2="51.165" width="0.5" layer="16"/>
</signal>
<signal name="N$20">
<contactref element="X6" pad="2"/>
<contactref element="IC1" pad="16"/>
<wire x1="102.87" y1="39.37" x2="102.87" y2="37.465" width="0.8128" layer="16"/>
<wire x1="102.87" y1="37.465" x2="106.045" y2="34.29" width="0.8128" layer="16"/>
<wire x1="106.045" y1="34.29" x2="107.68" y2="34.29" width="0.8128" layer="16"/>
<wire x1="107.68" y1="34.29" x2="107.95" y2="34.56" width="0.8128" layer="16"/>
</signal>
<signal name="N$21">
<contactref element="X6" pad="1"/>
<contactref element="IC1" pad="17"/>
<wire x1="107.95" y1="36.56" x2="106.315" y2="36.56" width="0.8128" layer="16"/>
<wire x1="106.315" y1="36.56" x2="105.41" y2="37.465" width="0.8128" layer="16"/>
<wire x1="105.41" y1="37.465" x2="105.41" y2="39.37" width="0.8128" layer="16"/>
</signal>
<signal name="N$22">
<contactref element="IC1" pad="15"/>
<contactref element="R6" pad="2"/>
<wire x1="102.87" y1="31.115" x2="102.87" y2="35.56" width="0.8128" layer="16"/>
<wire x1="102.87" y1="35.56" x2="100.33" y2="38.1" width="0.8128" layer="16"/>
<wire x1="100.33" y1="38.1" x2="100.33" y2="39.37" width="0.8128" layer="16"/>
</signal>
<signal name="N$23">
<contactref element="R6" pad="1"/>
<contactref element="Q2" pad="B"/>
<wire x1="65.405" y1="23.495" x2="78.105" y2="23.495" width="0.8128" layer="16"/>
<wire x1="78.105" y1="23.495" x2="80.645" y2="20.955" width="0.8128" layer="16"/>
<wire x1="80.645" y1="20.955" x2="102.87" y2="20.955" width="0.8128" layer="16"/>
</signal>
<signal name="N$24">
<contactref element="Q2" pad="C"/>
<contactref element="R7" pad="2"/>
<wire x1="65.405" y1="26.035" x2="79.375" y2="26.035" width="1.016" layer="16"/>
<wire x1="79.375" y1="26.035" x2="82.55" y2="22.86" width="1.016" layer="16"/>
<wire x1="82.55" y1="22.86" x2="88.9" y2="22.86" width="1.016" layer="16"/>
<wire x1="88.9" y1="22.86" x2="90.17" y2="24.13" width="1.016" layer="16"/>
<wire x1="90.17" y1="24.13" x2="90.17" y2="25.4" width="1.016" layer="16"/>
</signal>
<signal name="N$25">
<contactref element="Q2" pad="E"/>
<contactref element="U$1" pad="P$10"/>
<contactref element="D2" pad="C"/>
<wire x1="52.705" y1="23.495" x2="57.15" y2="23.495" width="0.8128" layer="16"/>
<wire x1="57.15" y1="23.495" x2="60.325" y2="23.495" width="0.8128" layer="16"/>
<wire x1="60.325" y1="23.495" x2="62.865" y2="20.955" width="0.8128" layer="16"/>
<wire x1="62.865" y1="20.955" x2="65.405" y2="20.955" width="0.8128" layer="16"/>
</signal>
<signal name="N$29">
<contactref element="U$1" pad="P$4"/>
<contactref element="X10" pad="1"/>
<wire x1="45.085" y1="31.115" x2="45.085" y2="32.385" width="1.016" layer="16"/>
<wire x1="45.085" y1="32.385" x2="38.735" y2="38.735" width="1.016" layer="16"/>
<wire x1="38.735" y1="38.735" x2="38.735" y2="40.64" width="1.016" layer="16"/>
<wire x1="38.735" y1="40.64" x2="37.465" y2="41.91" width="1.016" layer="16"/>
<wire x1="37.465" y1="41.91" x2="34.3662" y2="41.91" width="1.016" layer="16"/>
<wire x1="34.3662" y1="41.91" x2="34.29" y2="41.9862" width="1.016" layer="16"/>
</signal>
<signal name="N$32">
<contactref element="X12" pad="1"/>
<contactref element="X12" pad="2"/>
<contactref element="X12" pad="3"/>
<wire x1="34.29" y1="26.7462" x2="34.29" y2="31.75" width="1.016" layer="16"/>
<wire x1="34.29" y1="31.75" x2="34.29" y2="36.7538" width="1.016" layer="16"/>
</signal>
<signal name="N$26">
<contactref element="U$1" pad="P$2"/>
<contactref element="X10" pad="3"/>
<wire x1="50.165" y1="31.115" x2="50.165" y2="34.925" width="1.016" layer="16"/>
<wire x1="50.165" y1="34.925" x2="45.72" y2="39.37" width="1.016" layer="16"/>
<wire x1="45.72" y1="39.37" x2="45.72" y2="44.45" width="1.016" layer="16"/>
<wire x1="45.72" y1="44.45" x2="38.1" y2="52.07" width="1.016" layer="16"/>
<wire x1="38.1" y1="52.07" x2="34.3662" y2="52.07" width="1.016" layer="16"/>
<wire x1="34.3662" y1="52.07" x2="34.29" y2="51.9938" width="1.016" layer="16"/>
</signal>
<signal name="N$28">
<contactref element="U$1" pad="P$3"/>
<contactref element="X10" pad="2"/>
<wire x1="34.29" y1="46.99" x2="39.37" y2="46.99" width="1.016" layer="16"/>
<wire x1="39.37" y1="46.99" x2="42.545" y2="43.815" width="1.016" layer="16"/>
<wire x1="42.545" y1="43.815" x2="42.545" y2="38.735" width="1.016" layer="16"/>
<wire x1="42.545" y1="38.735" x2="47.625" y2="33.655" width="1.016" layer="16"/>
<wire x1="47.625" y1="33.655" x2="47.625" y2="31.115" width="1.016" layer="16"/>
</signal>
<signal name="N$27">
<contactref element="U$1" pad="P$7"/>
<contactref element="X11" pad="3"/>
<wire x1="45.085" y1="23.495" x2="45.085" y2="22.225" width="1.016" layer="16"/>
<wire x1="45.085" y1="22.225" x2="43.815" y2="20.955" width="1.016" layer="16"/>
<wire x1="43.815" y1="20.955" x2="34.8488" y2="20.955" width="1.016" layer="16"/>
<wire x1="34.8488" y1="20.955" x2="34.29" y2="21.5138" width="1.016" layer="16"/>
</signal>
<signal name="N$30">
<contactref element="U$1" pad="P$9"/>
<contactref element="X11" pad="1"/>
<wire x1="34.29" y1="11.5062" x2="43.8912" y2="11.5062" width="1.016" layer="16"/>
<wire x1="43.8912" y1="11.5062" x2="50.165" y2="17.78" width="1.016" layer="16"/>
<wire x1="50.165" y1="17.78" x2="50.165" y2="23.495" width="1.016" layer="16"/>
</signal>
<signal name="N$31">
<contactref element="U$1" pad="P$8"/>
<contactref element="X11" pad="2"/>
<wire x1="47.625" y1="23.495" x2="47.625" y2="19.685" width="1.016" layer="16"/>
<wire x1="47.625" y1="19.685" x2="44.45" y2="16.51" width="1.016" layer="16"/>
<wire x1="44.45" y1="16.51" x2="34.29" y2="16.51" width="1.016" layer="16"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
