program negyszog;
{ Declarations section }
const
  ccode: array[1..50] of word = (61890,62010,62140,62260,62370,62480,62585,62690,62790,62885,62980,63050,63120,63200,63285,
                                 63363,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
                                 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
                                 0,64617,64632);
procedure InitTimer1();
begin                  //Prescaler 1:1; TMR1 Preload = 61805; Actual Interrupt Time : 1,4924 ms
  {T1CON         := 0x01;
  TMR1IF_bit         := 0;
  TMR1H         := 0xF1;
  TMR1L         := 0x6D;
  TMR1IE_bit         := 1;}
  T1CON := 1;                  // Timer1 settings
  PIR1.TMR1IF := 0;            // clear TMR1IF
  TMR1H := 0xF1;               // Initialize Timer1 register
  TMR1L := 0x6D;
  PIE1.TMR1IE  := 1;
  INTCON         := 0xC0;
end;
procedure Interrupt();
begin
  if (TMR1IF_bit) then
  begin
    TMR1IF_bit := 0;
    TMR1H         := Hi(ccode[portb]);
    TMR1L         := Lo(ccode[portb]);
    //Enter your code here
    porta.0:=1;
    delay_us(200);
    porta.0:=0;
  end;
end;
begin
  { Main program }
  TRISA  := 0;                       // PORTA is output
  TRISB  := 255;
  CMCON := 7;
  InitTimer1;
  while TRUE do
    begin
    end;
end.
