; WS2812 LEDSZALAG MEGHAJTÓ 
;MAX 37 LED, MERT NINCS TÖBB MEMŐRIA
;KIJELZENDŐ KÉP FSR1 = 5F NÉL KEZDŐDIK 
;ZÖLD VÖRÖS KÉK SORRENDBEN   
;UTOLSÓ A 01 BYTE ON 
;pic16F1503 PROCESSZORRAL.
;MELLÉKESEN A KÉP TÖRLŐDIK;
	PROCESSOR 16F1503
	INCLUDE P16F1503.INC 
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
__CONFIG    _CONFIG1,_FOSC_ECH& _CLKOUTEN_OFF&_WDTE_OFF&_PWRTE_OFF&_MCLRE_ON&_CP_OFF&_BOREN_OFF &_FOSC_INTOSC
__CONFIG    _CONFIG2,_LVP_OFF & _STVREN_ON &_WRT_OFF
	CBLOCK 
	ENDC
	CBLOCK 70
			JB 				
			NUM				;LED SZÁMA
			LUME			;FÉNYERŐ
			ORA
			S_ORA
			MIN
			SEC	
			JB2
	ENDC
#DEFINE ZOLD 	JB,1
#DEFINE KEK  	JB,2
#DEFINE PIROS 	JB,3
#DEFINE ZO		1
#DEFINE KE		2
#DEFINE PI		3
#DEFINE KIJ		JB2,1
LED MACRO  LED,SZIN,FENY		
			MOVLW LED
			MOVWF NUM		;HELY MENTÉSE
			CLRF JB	
			BSF JB,SZIN
			MOVLW FENY
			MOVWF LUME
			CALL LED_K
	ENDM
;KONSTANSOK
;	AH_OSZT =4500  1   A    TÖLTŐÁRAM ESETÉN 0.01 AH FELBONTÁSSAL
;			=45000 0,1 A  	
ORG 0
	CLRF STATUS
	CLRF PCLATH
	GOTO START
ORG 04
	NOP
	BANKSEL PIR1
	BCF PIR1,TMR1IF 
	BANKSEL TMR1L 
	MOVLW 0XDD
	ADDWF TMR1L
	MOVLW 0XF0
	ADDWFC TMR1H
	INCF SEC
	MOVLW 0X3C
	XORWF SEC,W
	BTFSS STATUS,Z
	BRA VEG
	CLRF SEC
	INCF MIN,F
	MOVLW D'60'
	XORWF MIN,W		
	BTFSS STATUS,Z
	BRA LEP
	CLRF MIN
LEP
	INCF S_ORA
	MOVLW D'12'
	XORWF S_ORA,W
	BTFSS STATUS,Z
	BRA VEG
	CLRF S_ORA
	INCF ORA
	MOVLW D'60'
	XORWF ORA,W
	BTFSS STATUS,Z
	BRA VEG
	CLRF ORA
VEG	
	MOVLW 0X20
	MOVWF FSR1H
	MOVFW ORA
	MOVWF NUM
	CLRF JB
	BSF PIROS
	MOVLW 0X0F
	MOVWF LUME
	CALL LED_K
	MOVFW MIN
	MOVWF NUM
	CLRF JB
	BSF ZOLD
	MOVLW 0X0F
	MOVWF LUME
	CALL LED_K
	MOVFW SEC
	MOVWF NUM
	CLRF JB
	BSF KEK
	MOVLW 0X0F
	MOVWF LUME
	CALL LED_K
	BSF KIJ
	RETFIE					;MÉRÉSEK BEFEJEZÉSE
ORG 100
START
				;bit 7 Unimplemented: Read as ‘0’
				;bit 6-3 IRCF<3:0>: Internal Oscillator Frequency Select bits
				;	1111 =16MHz
				;	1110 =8MHz
				;	1101 =4MHz
				;	1100 =2MHz
				;	1011 =1MHz
				;	1010 =500kHz(1)
				;	1001 =250kHz(1)
				;	1000 =125kHz(1)
				;	0111 = 500 kHz (default upon Reset)
				;	0110 =250kHz
				;	0101 =125kHz
				;	0100 =62.5kHz
				;	001x =31.25kHz
				;	000x = 31 kHz (LFINTOSC)
				;bit 2 Unimplemented: Read as ‘0’
				;bit 1-0 SCS<1:0>: System Clock Select bits
				;	1x = Internal oscillator block
				;	01 = Reserved
				;	00 = Clock determined by FOSC<1:0> in Configuration Words.
	BANKSEL OSCCON
	MOVLW B'01111010'			;OSC= 2MHZ	
	MOVWF OSCCON
	MOVLW 20			;MEMÓRIA TÖRLÉS
	MOVWF FSR1H
	MOVLW 00
	MOVWF FSR1L
	MOVLW 00
MEM
	MOVWF INDF1
	INCFSZ FSR1L,f
	BRA MEM
	INCF FSR1H,F
	BTFSS FSR1H,2	 
	BRA MEM
	MOVLW 070
	MOVWF FSR1L
	MOVLW 00
	MOVWF FSR1H
	MOVLW 0
MEM1
	MOVWF INDF1			;JUKAK TÖRLÉSE
	INCF FSR1L,f
	BTFSS FSR1L,7
	BRA MEM1
	BANKSEL TRISA
	MOVLW B'11111111'
	MOVWF TRISA
	MOVLW B'11111010'			;SDO KIMENET
	MOVWF TRISC
	BANKSEL ANSELA
	MOVLW B'00000000'			;MINDEN PORT DIGITÁLIS
	MOVWF ANSELA
	MOVLW B'00000000'
	MOVWF ANSELC
	BANKSEL PIE1
	BCF PIE1,SSP1IE			;MEGSZAKÍTÁS ENGEDÉLYEZÉSE
	BSF INTCON ,PEIE
	BSF INTCON ,GIE			;SPI MEGSZAKÍTÁS ENGEDÉLYEZÉSE			
; sspcon
		;bit 7 WCOL: Write Collision Detect bit
			;Master mode:
						;1 = A write to the SSPxBUF register was attempted while the I2C conditions were not valid for a transmission to be started
						;0 = No collision
			;Slave mode:
						;1 = The SSPxBUF register is written while it is still transmitting the previous word (must be cleared in software)
						;0 = No collision
		;bit 6 SSPOV: Receive Overflow Indicator bit(1)
			;In SPI mode:
						;1 = A new byte is received while the SSPxBUF register is still holding the previous data. In case of overflow, the data in SSPxSR is lost.
							;Overflow can only occur in Slave mode. In Slave mode, the user must read the SSPxBUF, even if only transmitting data, to avoid
							;setting overflow. In Master mode, the overflow bit is not set since each new reception (and transmission) is initiated by writing to the
							;SSPxBUF register (must be cleared in software).
						;0 = No overflow
			;In I2 C mode:
						;1 = A byte is received while the SSPxBUF register is still holding the previous byte. SSPOV is a “don’t care” in Transmit mode
							;(must be cleared in software).
						;0 = No overflow
		;bit 5 SSPEN: Synchronous Serial Port Enable bit
			;In both modes, when enabled, these pins must be properly configured as input or output
			;In SPI mode:
						;1 = Enables serial port and configures SCKx, SDOx, SDIx and SSx as the source of the serial port pins(2)
						;0 = Disables serial port and configures these pins as I/O port pins
			;In I2 C mode:
						;1 = Enables the serial port and configures the SDAx and SCLx pins as the source of the serial port pins(3)
		;bit 4 CKP: Clock Polarity Select bit
			;In SPI mode:
						;1 = Idle state for clock is a high level
						;0 = Idle state for clock is a low level
			;In I2 C Slave mode: SCLx release control
						;1 = Enable clock
						;0 = Holds clock low (clock stretch). (Used to ensure data setup time.)
			;In I2 C Master mode:
						;Unused in this mode
		;bit 3-0 SSPM<3:0>: Synchronous Serial Port Mode Select bits
							;0000 = SPI Master mode, clock = FOSC/4
							;0001 = SPI Master mode, clock = FOSC/16
							;0010 = SPI Master mode, clock = FOSC/64
							;0011 = SPI Master mode, clock = TMR2 output/2
							;0100 = SPI Slave mode, clock = SCKx pin, SS pin control enabled
							;0101 = SPI Slave mode, clock = SCKx pin, SS pin control disabled, SSx can be used as I/O pin
							;0110 = I2C Slave mode, 7-bit address
							;0111 = I2C Slave mode, 10-bit address
							;1000 = I2C Master mode, clock = FOSC/(4 * (SSPxADD+1))(4)
							;1001 = Reserved
							;1010 = SPI Master mode, clock = FOSC/(4 * (SSPxADD+1))(5)
							;1011 = I2C firmware controlled Master mode (Slave idle)
							;1100 = Reserved
							;1101 = Reserved
							;1110 = I2C Slave mode, 7-bit address with Start and Stop bit interrupts enabled
							;1111 = I2C Slave mode, 10-bit address with Start and Stop bit interrupts enabled
	BANKSEL SSP1CON1
	MOVLW B'00000000'
	MOVWF SSP1CON1  	
	BANKSEL APFCON
	BCF APFCON,SDOSEL			;ADATKIMENET AZ RC2
;SSPCON3 
;			bit 7 ACKTIM: Acknowledge Time Status bit (I2C mode only)(3)
;						1 = Indicates the I2C bus is in an Acknowledge sequence, set on 8TH falling edge of SCLx clock
;						0 = Not an Acknowledge sequence, cleared on 9TH rising edge of SCLx clock
;			bit 6 PCIE: Stop Condition Interrupt Enable bit (I2C mode only)
;						1 = Enable interrupt on detection of Stop condition
;						0 = Stop detection interrupts are disabled(2)
;			bit 5 SCIE: Start Condition Interrupt Enable bit (I2C mode only)
;						1 = Enable interrupt on detection of Start or Restart conditions
;						0 = Start detection interrupts are disabled(2)
;			bit 4 BOEN: Buffer Overwrite Enable bit
;				In SPI Slave mode:(1)
;						1 = SSPxBUF updates every time that a new data byte is shifted in ignoring the BF bit
;						0 = If new byte is received with BF bit of the SSPxSTAT register already set, SSPOV bit of the
;								SSPxCON1 register is set, and the buffer is not updated
;				In I2C Master mode:
;						This bit is ignored.
;				In I2C Slave mode:
;						1 = SSPxBUF is updated and ACK is generated for a received address/data byte, ignoring the
;								state of the SSPOV bit only if the BF bit = 0.
;						0 = SSPxBUF is only updated when SSPOV is clear
;			bit 3 SDAHT: SDAx Hold Time Selection bit (I2C mode only)
;						1 = Minimum of 300 ns hold time on SDAx after the falling edge of SCLx
;						0 = Minimum of 100 ns hold time on SDAx after the falling edge of SCLx
;			bit 2 SBCDE: Slave Mode Bus Collision Detect Enable bit (I2C Slave mode only)
;								If on the rising edge of SCLx, SDAx is sampled low when the module is outputting a high state, the
;								BCLxIF bit of the PIR2 register is set, and bus goes idle
;						1 = Enable slave bus collision interrupts
;						0 = Slave bus collision interrupts are disabled
;			bit 1 AHEN: Address Hold Enable bit (I2C Slave mode only)
;						1 = Following the 8th falling edge of SCLx for a matching received address byte; CKP bit of the
;								SSPxCON1 register will be cleared and the SCLx will be held low.
;						0 = Address holding is disabled
;			bit 0 DHEN: Data Hold Enable bit (I2C Slave mode only)
;						1 = Following the 8th falling edge of SCLx for a received data byte; slave hardware clears the CKP bit
;							of the SSPxCON1 register and SCLx is held low.
;						0 = Data holding is disabled
	BANKSEL SSP1CON3
	MOVLW B'11101111'
;SSPSTAT
;		bit 7 SMP: SPI Data Input Sample bit
;			SPI Master mode:
;				1 = Input data sampled at end of data output time
;				0 = Input data sampled at middle of data output time
;			SPI Slave mode:	SMP must be cleared when SPI is used in Slave mode
;			 In I2 C Master or Slave mode:
;				1 = Slew rate control disabled for standard speed mode (100 kHz and 1 MHz)
;				0 = Slew rate control enabled for high speed mode (400 kHz)
;		bit 6 CKE: SPI Clock Edge Select bit (SPI mode only)
;			In SPI Master or Slave mode:
;				1 = Transmit occurs on transition from active to Idle clock state
;				0 = Transmit occurs on transition from Idle to active clock state
;			In I2 C™ mode only:
;				1 = Enable input logic so that thresholds are compliant with SMBus specification
;				0 = Disable SMBus specific inputs
;		bit 5 D/A: Data/Address bit (I2C mode only)
;				1 = Indicates that the last byte received or transmitted was data
;				0 = Indicates that the last byte received or transmitted was address
;		bit 4 P: Stop bit
;			(I2C mode only. This bit is cleared when the MSSPx module is disabled, SSPEN is cleared.)
;				1 = Indicates that a Stop bit has been detected last (this bit is ‘0’ on Reset)
;				0 = Stop bit was not detected last
;		bit 3 S: Start bit
;				1 = Indicates that a Start bit has been detected last (this bit is ‘0’ on Reset)
;				0 = Start bit was not detected last
;		bit 2 R/W: Read/Write bit information
;			 (I2C mode only)
;					This bit holds the R/W bit information following the last address match. This bit is only valid from the address match
;					to the next Start bit, Stop bit, or not ACK bit.
;			In I2 C Slave mode:
;				1 = Read
;				0 = Write
;			In I2 C Master mode:
;				1 = Transmit is in progress
;				0 = Transmit is not in progress
;						OR-ing this bit with SEN, RSEN, PEN, RCEN or ACKEN will indicate if the MSSPx is in Idle mode.
;		bit 1 UA: Update Address bit 
;			(10-bit I2C mode only)
;				1 = Indicates that the user needs to update the address in the SSPxADD register
;				0 = Address does not need to be updated
;		bit 0 BF: Buffer Full Status bit
;			Receive (SPI and I2 C modes):
;				1 = Receive complete, SSPxBUF is full
;				0 = Receive not complete, SSPxBUF is empty
;			Transmit (I2 C mode only):
;				1 = Data transmit in progress (does not include the ACK and Stop bits), SSPxBUF is full
;				0 = Data transmit complete (does not include the ACK and Stop bits), SSPxBUF is empty
	BANKSEL SSP1STAT
	MOVLW B'11111111'
;  T2CON
;		bit 7 Unimplemented: Read as ‘0’
;		bit 6-3 T2OUTPS<3:0>: Timer2 Output Postscaler Select bits
;				0000 = 1:1 Postscaler
;				0001 = 1:2 Postscaler
;				0010 = 1:3 Postscaler
;				0011 = 1:4 Postscaler
;				0100 = 1:5 Postscaler
;				0101 = 1:6 Postscaler
;				0110 = 1:7 Postscaler
;				0111 = 1:8 Postscaler
;				1000 = 1:9 Postscaler
;				1001 = 1:10 Postscaler
;				1010 = 1:11 Postscaler
;				1011 = 1:12 Postscaler
;				1100 = 1:13 Postscaler
;				1101 = 1:14 Postscaler
;				1110 = 1:15 Postscaler
;				1111 = 1:16 Postscaler
;		bit 2 TMR2ON: Timer2 On bit
;				1 = Timer2 is on
;				0 = Timer2 is off
;		bit 1-0 T2CKPS<1:0>: Timer2 Clock Prescale Select bits
;				00 = Prescaler is 1
;				01 = Prescaler is 4
;				10 = Prescaler is 16
;				11 = Prescaler is 64
;T1CON
;		bit 7-6 TMR1CS<1:0>: Timer1 Clock Source Select bits
;				11 =Timer1 clock source is LFINTOSC
;				10 =Timer1 clock source is T1CKI pin (on rising edge)
;				01 =Timer1 clock source is system clock (FOSC)
;				00 =Timer1 clock source is instruction clock (FOSC/4)
;		bit 5-4 T1CKPS<1:0>: Timer1 Input Clock Prescale Select bits
;				11 = 1:8 Prescale value
;				10 = 1:4 Prescale value
;				01 = 1:2 Prescale value
;				00 = 1:1 Prescale value
;		bit 3 Unimplemented: Read as ‘0’
;		bit 2 T1SYNC: Timer1 Synchronization Control bit
;				1 = Do not synchronize asynchronous clock input
;				0 = Synchronize asynchronous clock input with system clock (FOSC)
;		bit 1 Unimplemented: Read as ‘0’
;		bit 0 TMR1ON: Timer1 On bit
;				1 = Enables Timer1
;				0 = Stops Timer1 and clears Timer1 gate flip-flop
	BANKSEL T1CON			;LFINTOSC BEMENET /8
	MOVLW B'11110001'
	MOVWF T1CON	 
; T1GCON
;		bit 7 TMR1GE: Timer1 Gate Enable bit
;			If TMR1ON = 0:
;			If TMR1ON = 1:
;				1 = Timer1 counting is controlled by the Timer1 gate function
;				0 = Timer1 counts regardless of Timer1 gate function
;		bit 6 T1GPOL: Timer1 Gate Polarity bit
;				1 = Timer1 gate is active-high (Timer1 counts when gate is high)
;				0 = Timer1 gate is active-low (Timer1 counts when gate is low)
;		bit 5 T1GTM: Timer1 Gate Toggle Mode bit
;				1 = Timer1 Gate Toggle mode is enabled
;				0 = Timer1 Gate Toggle mode is disabled and toggle flip-flop is cleared
;					Timer1 gate flip-flop toggles on every rising edge.
;		bit 4 T1GSPM: Timer1 Gate Single-Pulse Mode bit
;				1 = Timer1 gate Single-Pulse mode is enabled and is controlling Timer1 gate
;				0 = Timer1 gate Single-Pulse mode is disabled
;		bit 3 T1GGO/DONE: Timer1 Gate Single-Pulse Acquisition Status bit
;				1 = Timer1 gate single-pulse acquisition is ready, waiting for an edge
;				0 = Timer1 gate single-pulse acquisition has completed or has not been started
;		bit 2 T1GVAL: Timer1 Gate Current State bit	
;					Indicates the current state of the Timer1 gate that could be provided to TMR1H:TMR1L.
;					Unaffected by Timer1 Gate Enable (TMR1GE).
;		bit 0 T1GSS<1:0>: Timer1 Gate Source Select bits
;				11 = Comparator 2 optionally synchronized output (sync_C2OUT)
;				10 = Comparator 1 optionally synchronized output (sync_C1OUT)
;				01 = Timer0 overflow output
;				00 = Timer1 gate pin	
	BANKSEL T1GCON
	MOVLW B'00000000'
	MOVWF T1GCON
	BANKSEL PIE1
	BSF PIE1,TMR1IE
	BANKSEL PIR1
	BSF PIR1,TMR1IF
	MOVLW 0X20
	MOVWF FSR1H			;FELSŐ FÉL BEÁLLÍTÁSA MEMÓRIA OLVASÁSRA
;					FŐPROGRAM
;	LED 0,PI,0X01
;	LED 0,ZO,0X01
;	LED 0,KE, 0X02 
;	LED 1,PI,0X02
;	LED 2,PI,0X04 
;	LED 3,PI,0X08
;	LED D'58',PI,0X0F
;	LED D'59',PI,0X01  	
VV	BTFSS KIJ
	BRA VV
	BCF KIJ
	CALL DISP
	BRA VV	
LED_K 
	MOVFW NUM		;FÉLBYTE KISZAMOLÁSA
	ADDWF NUM,W
	ADDWF NUM,W	
	RRF WREG
	MOVWF FSR1L
	BTFSS STATUS,C 
	BRA PAROS
ZOLD_L					;
	INCF FSR1L			;NEM NULLÁVAL KEZD
	BTFSS ZOLD
	BRA PIROS_L
	INCF FSR1L		
	MOVFW LUME
	SWAPF WREG,F
	IORWF INDF1,F		;FELSŐ BYTE ALSÓ FELE A ZÖLD 	
 	BRA RET
PIROS_L
	BTFSS PIROS
	BRA KEK_L
	INCF FSR1L
	MOVFW LUME
	IORWF INDF1,F
	BRA RET
KEK_L
	BTFSS KEK
	BRA RET
	MOVFW LUME
	SWAPF WREG,F
	IORWF INDF1,F
	BRA RET
PAROS
ZOLD_H
	INCF FSR1L		;LAP KEZDETE
	BTFSS ZOLD
	BRA PIROS_H
	INCF FSR1L		
	MOVFW LUME
	IORWF INDF1,F		;FÉNY A HELYÉRE 	
 	BRA RET
PIROS_H
	BTFSS PIROS
	BRA KEK_H
	MOVFW LUME
	SWAPF WREG,F
	IORWF INDF1,F
	BRA RET
KEK_H
	BTFSS KEK
	BRA RET
	MOVFW LUME
	IORWF INDF1,F
	BRA RET
RET
	RETURN	
DISP 
	MOVLW 20
	MOVWF FSR1H
	MOVLW 0X5A
	MOVWF FSR1L		;MUTATÓ AZ ELEJÉRE
	BANKSEL INTCON
	BCF INTCON,GIE	;MEGSZAKÍTÁS TILTÁSA  
	BANKSEL PORTC
	BRA IND2		;KEZDŐ CSALÁS
IND
	BCF PORTC,0
IND2
	BSF PORTC,0			;1 BIT
	RLF INDF1				;BIT_1	
	RLF PORTC				;KIKÜLDVE A PORTRA
	RLF INDF1				;BIT_2	KIOLVASÁSA 						
	BCF PORTC,0				;ADAT VÉGE
	NOP						;A BÉKE KEDVÉÉRT
	BSF PORTC,0			;2. BIT
	RLF PORTC				;BIT KIKÜLDÉSE
	RLF INDF1				;BIT_3 KIOLVASÁSA
	BCF PORTC,0
	NOP
	BSF PORTC,0			;3. BIT
	RLF INDF1				;BIT_4 KIOLVASÁSA
	BCF PORTC,0
	NOP
	BSF PORTC,0			;4. BIT
	CLRC				;BIT_5 KIOLVASÁSA
	BCF PORTC,0
	NOP	
	BSF PORTC,0			;5. BIT
	CLRC			;BIT_6  KIOLVASÁSA
	BCF PORTC,0
	NOP
	BSF PORTC,0			;6. BIT
	CLRC			;BIT_7  KIOLVASÁSA
	BCF PORTC,0
	NOP
	BSF PORTC,0			;7. BIT
	CLRC				;BIT_8 KIOLVASÁSA
	BCF PORTC,0
	NOP
	BSF PORTC,0			;2. BIT
	BCF PORTC,0
	NOP
	BSF PORTC,0			;3. BIT
	BCF PORTC,0
	NOP
	BSF PORTC,0			;4. BIT
	RLF INDF1				;BIT_5 KIOLVASÁSA
	BCF PORTC,0
	NOP	
	BSF PORTC,0			;5. BIT
	RLF INDF1				;BIT_6  KIOLVASÁSA
	BCF PORTC,0
	NOP
	BSF PORTC,0			;2. BIT
	CLRC				;BIT_3 KIOLVASÁSA
	BCF PORTC,0
	NOP
	BSF PORTC,0			;3. BIT
	CLRC				;BIT_4 KIOLVASÁSA
	BCF PORTC,0
	NOP
	BSF PORTC,0			;4. BIT
	BCF PORTC,0
	NOP	
	BSF PORTC,0			;5. BIT
	BCF PORTC,0
	NOP
	BSF PORTC,0			;8. BIT						50
	RLF PORTC				;BIT KIKÜLDÉSE			75
	DECFSZ FSR1L
	BRA IND	
	BCF PORTC,0				;KIJELZÉS VÉGE
	BANKSEL INTCON
	BSF INTCON,GIE			;MEGSZAKÍTÁS ENGEDÉLYEZÉSE 
	RETURN
END                                         
