<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.6.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="100" unitdist="mil" unit="mil" style="lines" multiple="1" display="yes" altdistance="0.025" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="yes" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="yes" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="yes" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="yes"/>
<layer number="51" name="tDocu" color="6" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
</layers>
<library>
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DO35-10">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2 mm, horizontal, grid 10.16 mm</description>
<wire x1="5.08" y1="0" x2="4.191" y2="0" width="0.508" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.191" y2="0" width="0.508" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.032" y1="1.016" x2="2.286" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="0.762" x2="-2.032" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="-0.762" x2="-2.032" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.032" y1="-1.016" x2="2.286" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="-0.762" x2="2.286" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0.762" x2="-2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.016" x2="2.032" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.016" x2="2.032" y2="-1.016" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="5.08" y="0" drill="0.8128" shape="long"/>
<text x="-2.159" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.905" y1="-1.016" x2="-1.397" y2="1.016" layer="21"/>
<rectangle x1="2.286" y1="-0.254" x2="4.191" y2="0.254" layer="21"/>
<rectangle x1="-4.191" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
</package>
<package name="P1-10E">
diameter 3 mm, horizontal, grid 10.16 mm</description>
<wire x1="-3.175" y1="-1.524" x2="3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.524" x2="-3.175" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.524" x2="3.175" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.524" x2="-3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="3.81" y2="0" width="0.762" layer="51"/>
<wire x1="-5.08" y1="0" x2="-3.81" y2="0" width="0.762" layer="51"/>
<pad name="C" x="-5.08" y="0" drill="1.1176" shape="long"/>
<pad name="A" x="5.08" y="0" drill="1.1176" shape="long"/>
<text x="-3.175" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.794" y1="-1.524" x2="-2.032" y2="1.524" layer="21"/>
<rectangle x1="3.175" y1="-0.381" x2="3.683" y2="0.381" layer="21"/>
<rectangle x1="-3.683" y1="-0.381" x2="-3.175" y2="0.381" layer="21"/>
</package>
<package name="DO15-12">
diameter 3.5 mm, horizontal, grid 12.7 mm</description>
<wire x1="-3.81" y1="-1.778" x2="3.81" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.778" x2="-3.81" y2="1.778" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-1.778" x2="3.81" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.778" x2="-3.81" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0" x2="5.334" y2="0" width="0.762" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.334" y2="0" width="0.762" layer="51"/>
<pad name="C" x="-6.35" y="0" drill="1.1176" shape="long"/>
<pad name="A" x="6.35" y="0" drill="1.1176" shape="long"/>
<text x="-3.683" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-1.397" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.048" y1="-1.778" x2="-2.413" y2="1.778" layer="21"/>
<rectangle x1="-5.207" y1="-0.381" x2="-3.81" y2="0.381" layer="21"/>
<rectangle x1="3.81" y1="-0.381" x2="5.207" y2="0.381" layer="21"/>
</package>
<package name="DO27-15E">
diameter 5 mm, horizontal, grid 15.24 mm</description>
<wire x1="-1.27" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0.5842" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.143" y2="0.5842" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.5842" x2="1.143" y2="-0.5842" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.5842" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.5842" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.54" x2="-5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.54" x2="5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.54" x2="5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.54" x2="-5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0" x2="5.842" y2="0" width="1.27" layer="51"/>
<wire x1="-7.62" y1="0" x2="-5.842" y2="0" width="1.27" layer="51"/>
<pad name="C" x="-7.62" y="0" drill="1.4986" shape="long"/>
<pad name="A" x="7.62" y="0" drill="1.4986" shape="long"/>
<text x="-5.08" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.191" y1="-2.54" x2="-3.429" y2="2.54" layer="21"/>
<rectangle x1="-5.588" y1="-0.635" x2="-5.08" y2="0.635" layer="21"/>
<rectangle x1="5.08" y1="-0.635" x2="5.588" y2="0.635" layer="21"/>
</package>
<package name="DO27-15">
<wire x1="7.62" y1="0" x2="6.223" y2="0" width="1.27" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.223" y2="0" width="1.27" layer="51"/>
<rectangle x1="-5.969" y1="-0.635" x2="-5.08" y2="0.635" layer="21"/>
<rectangle x1="5.08" y1="-0.635" x2="5.969" y2="0.635" layer="21"/>
</package>
<package name="RAD2,5L">
diameter 2.54 mm, vertical, grid 2.54 mm, elongated pad</description>
<wire x1="0.3048" y1="0" x2="-0.2032" y2="0" width="0.6096" layer="21"/>
<wire x1="1.27" y1="0" x2="0.381" y2="0" width="0.6096" layer="51"/>
<wire x1="-1.27" y1="0" x2="-0.381" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.905" width="0.1524" layer="21"/>
<pad name="C" x="-1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="A" x="1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="0.5842" y="1.6002" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.5842" y="-2.4892" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RAD2,5">
diameter 2.54 mm, vertical, grid 2.54 mm</description>
<wire x1="0.3048" y1="0" x2="-0.2794" y2="0" width="0.6096" layer="21"/>
<wire x1="1.27" y1="0" x2="0.508" y2="0" width="0.6096" layer="51"/>
<pad name="C" x="-1.27" y="0" drill="0.8128"/>
<pad name="A" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="0.9144" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.889" y="0.9906" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="RAD5G">
diameter 5.08 mm, vertical, grid 5.08 mm</description>
<wire x1="0.3048" y1="0" x2="-0.3048" y2="0" width="1.27" layer="21"/>
<wire x1="2.54" y1="0" x2="0.762" y2="0" width="1.27" layer="51"/>
<wire x1="-2.54" y1="0" x2="-0.762" y2="0" width="1.27" layer="51"/>
<circle x="-2.54" y="0" radius="2.54" width="0.1524" layer="21"/>
<pad name="C" x="-2.54" y="0" drill="1.4986" shape="octagon"/>
<pad name="A" x="2.54" y="0.0254" drill="1.4986" shape="octagon"/>
<text x="0.2286" y="-2.5146" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.0254" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="DO35-7">
diameter 2 mm, horizontal, grid 7.62 mm</description>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="2.286" y1="0.762" x2="2.286" y2="-0.762" width="0.1524" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="3.81" y="0" drill="0.8128" shape="long"/>
<text x="-2.286" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.286" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
</package>
<package name="DO35-7A">
<wire x1="3.81" y1="0" x2="2.667" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.667" y2="0" width="0.508" layer="51"/>
<text x="-2.286" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-2.667" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
<rectangle x1="2.286" y1="-0.254" x2="2.667" y2="0.254" layer="21"/>
</package>
<package name="DO41-7">
diameter 2.54 mm, horizontal, grid 7.62 mm</description>
<wire x1="2.032" y1="-1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0" x2="2.794" y2="0" width="0.762" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.794" y2="0" width="0.762" layer="51"/>
<pad name="C" x="-3.81" y="0" drill="1.1176"/>
<pad name="A" x="3.81" y="0" drill="1.1176"/>
<text x="-2.032" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.27" x2="-1.143" y2="1.27" layer="21"/>
<rectangle x1="2.032" y1="-0.381" x2="2.667" y2="0.381" layer="21"/>
<rectangle x1="-2.667" y1="-0.381" x2="-2.032" y2="0.381" layer="21"/>
</package>
<package name="P1-10">
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.762" layer="51"/>
<text x="-3.048" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.937" y1="-0.381" x2="-3.175" y2="0.381" layer="21"/>
<rectangle x1="3.175" y1="-0.381" x2="3.937" y2="0.381" layer="21"/>
</package>
<package name="P6-15">
diameter 9 mm, horizontal, grid 15.24 mm</description>
<wire x1="-4.699" y1="-4.572" x2="-4.699" y2="4.572" width="0.1524" layer="21"/>
<wire x1="4.699" y1="4.572" x2="4.699" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="4.572" x2="4.699" y2="4.572" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-4.572" x2="-4.699" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="2.54" y2="0" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.635" x2="1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<pad name="C" x="-7.62" y="0" drill="1.6002" shape="long"/>
<pad name="A" x="7.62" y="0" drill="1.6002" shape="long"/>
<text x="-4.6736" y="4.8514" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.3622" y="-3.302" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.429" y1="-4.572" x2="-2.921" y2="4.572" layer="21"/>
<rectangle x1="4.699" y1="-0.635" x2="5.969" y2="0.635" layer="21"/>
<rectangle x1="-5.969" y1="-0.635" x2="-4.699" y2="0.635" layer="21"/>
</package>
<package name="DO41Z10">
diameter 2.54 mm, horizontal, grid 10.16 mm</description>
<wire x1="5.08" y1="0" x2="3.937" y2="0" width="0.762" layer="51"/>
<wire x1="0.254" y1="0.635" x2="0" y2="0.635" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="1.1176"/>
<pad name="A" x="5.08" y="0" drill="1.1176"/>
<text x="-1.905" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.905" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.032" y1="-0.381" x2="3.937" y2="0.381" layer="21"/>
<rectangle x1="-3.937" y1="-0.381" x2="-2.032" y2="0.381" layer="21"/>
</package>
<package name="DO35Z10">
diameter 2 mm, horizontal, grid 10.16mm</description>
<text x="-2.286" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="P1Z12">
diameter 3 mm, horizontal, grid 12.7 mm</description>
<text x="-3.048" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.048" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.381" x2="5.207" y2="0.381" layer="21"/>
<rectangle x1="-5.207" y1="-0.381" x2="-3.175" y2="0.381" layer="21"/>
</package>
<package name="DO35Z7">
<text x="-2.159" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="P1Z12E">
<wire x1="6.35" y1="0" x2="5.08" y2="0" width="0.762" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.08" y2="0" width="0.762" layer="51"/>
<text x="-3.175" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="3.175" y1="-0.381" x2="4.953" y2="0.381" layer="21"/>
<rectangle x1="-4.953" y1="-0.381" x2="-3.175" y2="0.381" layer="21"/>
</package>
<package name="CB417-12">
<wire x1="-4.572" y1="-1.778" x2="-4.572" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.572" y1="1.778" x2="-4.572" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.572" y1="1.778" x2="4.572" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-1.778" x2="4.572" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0" x2="5.08" y2="0" width="1.1176" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.08" y2="0" width="1.1176" layer="51"/>
<pad name="C" x="-6.35" y="0" drill="1.397" shape="long"/>
<pad name="A" x="6.35" y="0" drill="1.397" shape="long"/>
<text x="-4.572" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.794" y="-1.397" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.81" y1="-1.778" x2="-3.302" y2="1.778" layer="21"/>
<rectangle x1="4.572" y1="-0.5334" x2="4.953" y2="0.5334" layer="21"/>
<rectangle x1="-4.953" y1="-0.5334" x2="-4.572" y2="0.5334" layer="21"/>
</package>
<package name="CB429-15">
<wire x1="0" y1="0" x2="1.27" y2="0.5842" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.5842" x2="1.27" y2="-0.5842" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.5842" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="-0.5842" x2="0.381" y2="-0.5842" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0" x2="6.096" y2="0" width="1.016" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.096" y2="0" width="1.016" layer="51"/>
<pad name="C" x="-7.62" y="0" drill="1.397" shape="long"/>
<pad name="A" x="7.62" y="0" drill="1.397" shape="long"/>
<rectangle x1="-4.318" y1="-2.54" x2="-3.302" y2="2.54" layer="21"/>
<rectangle x1="-5.969" y1="-0.508" x2="-5.08" y2="0.508" layer="21"/>
<rectangle x1="5.08" y1="-0.508" x2="5.969" y2="0.508" layer="21"/>
</package>
<package name="DO41-10">
<text x="-2.032" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DO34-7">
diameter 1.8 mm, horizontal, grid 7.62 mm</description>
<wire x1="-1.524" y1="-0.889" x2="1.524" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.889" x2="-1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-0.889" x2="1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.889" x2="-1.524" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="0.889" y1="0.508" x2="0.889" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-0.508" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="1.27" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="0.889" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0.508" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="-0.127" y2="-0.508" width="0.1524" layer="21"/>
<text x="-1.524" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.143" y1="-0.889" x2="-0.762" y2="0.889" layer="21"/>
<rectangle x1="1.524" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-1.524" y2="0.254" layer="21"/>
</package>
<package name="DO34-5">
diameter 1.8 mm, horizontal, grid 5.08 mm</description>
<wire x1="2.54" y1="0" x2="1.778" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0" x2="-1.778" y2="0" width="0.508" layer="51"/>
<pad name="C" x="-2.54" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="2.54" y="0" drill="0.8128" shape="long"/>
<text x="-1.651" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-0.254" x2="-1.524" y2="0.254" layer="21"/>
<rectangle x1="1.524" y1="-0.254" x2="1.651" y2="0.254" layer="21"/>
</package>
<package name="CB417-15">
diameter 3.5 mm, horizontal, grid 15.24 mm</description>
<wire x1="7.62" y1="0" x2="6.35" y2="0" width="1.1176" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.35" y2="0" width="1.1176" layer="51"/>
<rectangle x1="4.572" y1="-0.5334" x2="6.223" y2="0.5334" layer="21"/>
<rectangle x1="-6.223" y1="-0.5334" x2="-4.572" y2="0.5334" layer="21"/>
</package>
<package name="DO27Z15">
<wire x1="0" y1="0.5842" x2="0.254" y2="0.5842" width="0.1524" layer="21"/>
</package>
<package name="DO27Z15E">
</package>
<package name="DO201-15">
diameter 5.6 mm, horizontal, grid 15.24 mm</description>
<wire x1="-5.08" y1="-2.794" x2="-5.08" y2="2.794" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.794" x2="5.08" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.794" x2="5.08" y2="2.794" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.794" x2="-5.08" y2="-2.794" width="0.1524" layer="21"/>
<text x="-5.08" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-4.191" y1="-2.794" x2="-3.429" y2="2.794" layer="21"/>
</package>
<package name="P1-12">
</package>
<package name="GT32">
<wire x1="-1.016" y1="-0.635" x2="-1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="-1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="-1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-0.635" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="1.1176" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="1.1176" shape="octagon"/>
<text x="-2.032" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="ER900">
<wire x1="-2.286" y1="-1.016" x2="2.286" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.016" x2="-2.286" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.016" x2="2.286" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.016" x2="-2.286" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" shape="long"/>
<pad name="2" x="3.81" y="0" drill="0.8128" shape="long"/>
</package>
<package name="TO220ACK">
2-lead molded, horizontal</description>
<wire x1="-5.207" y1="-1.27" x2="5.207" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.207" y1="14.605" x2="-5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-1.27" x2="5.207" y2="11.176" width="0.1524" layer="21"/>
<wire x1="5.207" y1="11.176" x2="4.318" y2="11.176" width="0.1524" layer="21"/>
<wire x1="4.318" y1="11.176" x2="4.318" y2="12.7" width="0.1524" layer="21"/>
<wire x1="4.318" y1="12.7" x2="5.207" y2="12.7" width="0.1524" layer="21"/>
<wire x1="5.207" y1="12.7" x2="5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="11.176" x2="-4.318" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="11.176" x2="-4.318" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="12.7" x2="-5.207" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="12.7" x2="-5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<wire x1="-1.143" y1="0.635" x2="-0.508" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.508" y1="1.27" x2="0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="-0.508" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.635" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.635" x2="0.508" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.27" x2="-0.508" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.635" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<circle x="0" y="11.176" radius="1.8034" width="0.1524" layer="21"/>
<circle x="0" y="11.176" radius="2.921" width="0" layer="42"/>
<circle x="0" y="11.176" radius="2.921" width="0" layer="43"/>
<pad name="C" x="-2.54" y="-3.81" drill="1.1176" shape="long" rot="R90"/>
<pad name="A" x="2.54" y="-3.81" drill="1.1176" shape="long" rot="R90"/>
<text x="-5.461" y="-1.27" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.937" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="7.874" size="0.9906" layer="21" ratio="10">A15,2mm</text>
<rectangle x1="-3.175" y1="-2.159" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-2.159" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="-3.175" y1="-3.81" x2="-1.905" y2="-2.159" layer="51"/>
<rectangle x1="1.905" y1="-3.81" x2="3.175" y2="-2.159" layer="51"/>
<rectangle x1="-0.635" y1="-2.159" x2="0.635" y2="-1.27" layer="21"/>
<hole x="0" y="11.176" drill="3.302"/>
</package>
<package name="DO218L">
<wire x1="-7.62" y1="-6.35" x2="7.62" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="7.62" y1="6.223" x2="7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0" x2="7.62" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-3.81" x2="7.62" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-6.35" x2="-7.62" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-3.81" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="6.223" width="0.1524" layer="21"/>
<wire x1="7.62" y1="6.223" x2="-7.62" y2="6.223" width="0.1524" layer="21"/>
<wire x1="6.985" y1="5.715" x2="-6.985" y2="5.715" width="0.0508" layer="21"/>
<wire x1="6.985" y1="0.508" x2="6.985" y2="5.715" width="0.0508" layer="21"/>
<wire x1="-6.985" y1="-5.715" x2="6.985" y2="-5.715" width="0.0508" layer="21"/>
<wire x1="7.62" y1="12.065" x2="5.08" y2="14.605" width="0.1524" layer="21"/>
<wire x1="7.62" y1="12.065" x2="7.62" y2="6.223" width="0.1524" layer="21"/>
<wire x1="5.08" y1="14.605" x2="-5.08" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="12.065" x2="-5.08" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="12.065" x2="-7.62" y2="6.223" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0" x2="7.62" y2="-3.81" width="0.1524" layer="21" curve="180"/>
<wire x1="6.985" y1="-5.715" x2="6.985" y2="-4.318" width="0.0508" layer="21"/>
<wire x1="6.9522" y1="0.4991" x2="6.9851" y2="-4.3178" width="0.0508" layer="21" curve="149.733471"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="-3.81" width="0.1524" layer="21" curve="-180"/>
<wire x1="-6.985" y1="-5.715" x2="-6.985" y2="-4.318" width="0.0508" layer="21"/>
<wire x1="-6.985" y1="0.508" x2="-6.985" y2="5.715" width="0.0508" layer="21"/>
<wire x1="-6.985" y1="-4.318" x2="-6.985" y2="0.508" width="0.0508" layer="21" curve="150.512874"/>
<wire x1="-1.143" y1="-4.445" x2="-0.508" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-3.81" x2="0.508" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-5.08" x2="-0.508" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="-4.445" x2="1.016" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="-4.445" x2="0.508" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="-3.81" x2="-0.508" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="-4.445" x2="-0.508" y2="-5.08" width="0.1524" layer="21"/>
<circle x="0" y="10.16" radius="2.159" width="0.1524" layer="21"/>
<circle x="0" y="10.16" radius="3.81" width="0" layer="42"/>
<circle x="0" y="10.16" radius="3.81" width="0" layer="43"/>
<pad name="C" x="-5.461" y="-10.16" drill="1.397" shape="long" rot="R90"/>
<pad name="A" x="5.461" y="-10.16" drill="1.397" shape="long" rot="R90"/>
<text x="-7.874" y="-6.35" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-5.08" y="0" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-6.096" y1="-7.366" x2="-4.318" y2="-6.35" layer="21"/>
<rectangle x1="4.318" y1="-7.366" x2="6.096" y2="-6.35" layer="21"/>
<rectangle x1="-6.096" y1="-8.128" x2="-4.826" y2="-6.35" layer="21"/>
<rectangle x1="4.826" y1="-8.128" x2="6.096" y2="-6.35" layer="21"/>
<rectangle x1="-6.096" y1="-10.16" x2="-4.826" y2="-8.128" layer="51"/>
<rectangle x1="4.826" y1="-10.16" x2="6.096" y2="-8.128" layer="51"/>
<hole x="0" y="10.16" drill="4.1148"/>
</package>
<package name="DO220L">
<pad name="C" x="-2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="A" x="2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<text x="-4.445" y="7.874" size="0.9906" layer="21" ratio="10">A17,5mm</text>
<rectangle x1="-3.175" y1="-4.572" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-4.572" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="2.159" y1="-6.35" x2="2.921" y2="-4.699" layer="51"/>
<rectangle x1="2.159" y1="-4.699" x2="2.921" y2="-4.572" layer="21"/>
<rectangle x1="-2.921" y1="-6.35" x2="-2.159" y2="-4.699" layer="51"/>
<rectangle x1="-2.921" y1="-4.699" x2="-2.159" y2="-4.572" layer="21"/>
</package>
<package name="TO92H">
2-lead plastic, vertical</description>
<wire x1="-2.286" y1="-1.27" x2="2.286" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.27" x2="2.2705" y2="-1.2974" width="0.1524" layer="21" curve="-238.798935"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="3.175" y="0.635" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="P1-12E">
</package>
<package name="TO220AB">
3-lead molded horzintal</description>
<pad name="A1" x="-2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="C" x="0" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="A2" x="2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<rectangle x1="2.159" y1="-4.445" x2="2.921" y2="-3.81" layer="21"/>
<rectangle x1="-0.381" y1="-4.445" x2="0.381" y2="-3.81" layer="21"/>
<rectangle x1="-2.921" y1="-4.445" x2="-2.159" y2="-3.81" layer="21"/>
<rectangle x1="-3.175" y1="-3.81" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="-0.635" y1="-3.81" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-3.81" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="2.159" y1="-6.35" x2="2.921" y2="-4.445" layer="51"/>
<rectangle x1="-0.381" y1="-6.35" x2="0.381" y2="-4.445" layer="51"/>
<rectangle x1="-2.921" y1="-6.35" x2="-2.159" y2="-4.445" layer="51"/>
</package>
<package name="TOP3L">
3-lead molded, horizontal</description>
<wire x1="-7.874" y1="-1.778" x2="7.874" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="7.874" y1="8.763" x2="7.874" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-1.778" x2="-7.874" y2="8.763" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="8.763" x2="-7.874" y2="11.811" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="11.811" x2="-3.1242" y2="15.8496" width="0.1524" layer="21"/>
<wire x1="7.874" y1="8.763" x2="-7.874" y2="8.763" width="0.1524" layer="21"/>
<wire x1="7.874" y1="8.763" x2="7.874" y2="11.811" width="0.1524" layer="21"/>
<wire x1="-7.366" y1="-1.27" x2="7.366" y2="-1.27" width="0.0508" layer="21"/>
<wire x1="7.366" y1="8.255" x2="7.366" y2="-1.27" width="0.0508" layer="21"/>
<wire x1="7.366" y1="8.255" x2="-7.366" y2="8.255" width="0.0508" layer="21"/>
<wire x1="-7.366" y1="-1.27" x2="-7.366" y2="8.255" width="0.0508" layer="21"/>
<wire x1="0" y1="17.145" x2="3.1431" y2="15.8431" width="0.1524" layer="21" curve="-45.000078"/>
<wire x1="-3.1431" y1="15.8431" x2="0" y2="17.145" width="0.1524" layer="21" curve="-45.000078"/>
<wire x1="7.874" y1="11.811" x2="3.1242" y2="15.875" width="0.1524" layer="21"/>
<circle x="0" y="12.7" radius="2.159" width="0.1524" layer="21"/>
<circle x="0" y="12.7" radius="3.81" width="0" layer="42"/>
<circle x="0" y="12.7" radius="3.81" width="0" layer="43"/>
<pad name="A1" x="-5.588" y="-7.62" drill="1.397" shape="long" rot="R90"/>
<pad name="C" x="0" y="-7.62" drill="1.397" shape="long" rot="R90"/>
<pad name="A2" x="5.588" y="-7.62" drill="1.397" shape="long" rot="R90"/>
<text x="-8.128" y="-1.778" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-5.08" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-7.366" y="9.144" size="0.9906" layer="21" ratio="10">A20,3mm</text>
<rectangle x1="-6.223" y1="-3.81" x2="-3.81" y2="-1.778" layer="21"/>
<rectangle x1="-1.397" y1="-3.81" x2="1.397" y2="-1.778" layer="21"/>
<rectangle x1="3.81" y1="-3.81" x2="6.223" y2="-1.778" layer="21"/>
<rectangle x1="-6.223" y1="-7.493" x2="-4.953" y2="-5.588" layer="51"/>
<rectangle x1="-0.635" y1="-7.493" x2="0.635" y2="-5.588" layer="51"/>
<rectangle x1="4.953" y1="-7.493" x2="6.223" y2="-5.588" layer="51"/>
<rectangle x1="4.953" y1="-5.588" x2="6.223" y2="-3.81" layer="21"/>
<rectangle x1="-0.635" y1="-5.588" x2="0.635" y2="-3.81" layer="21"/>
<rectangle x1="-6.223" y1="-5.588" x2="-4.953" y2="-3.81" layer="21"/>
<hole x="0" y="12.7" drill="4.1148"/>
</package>
<package name="DOP3L">
<wire x1="-0.762" y1="0" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="0.889" y1="0.635" x2="0.889" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-0.635" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="0.889" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0.635" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="-0.127" y2="-0.635" width="0.1524" layer="21"/>
<pad name="C" x="-5.588" y="-7.62" drill="1.397" shape="long" rot="R90"/>
<pad name="A" x="5.588" y="-7.62" drill="1.397" shape="long" rot="R90"/>
<rectangle x1="-6.223" y1="-5.715" x2="-4.953" y2="-3.81" layer="21"/>
<rectangle x1="-6.223" y1="-7.62" x2="-4.953" y2="-5.715" layer="51"/>
<rectangle x1="4.953" y1="-5.715" x2="6.223" y2="-3.81" layer="21"/>
<rectangle x1="4.953" y1="-7.62" x2="6.223" y2="-5.715" layer="51"/>
</package>
<package name="P2-15">
diameter 5 mm, horizontal, grid 12.7 mm</description>
<wire x1="-4.826" y1="-2.54" x2="-4.826" y2="2.54" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.54" x2="4.826" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.54" x2="4.826" y2="2.54" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.54" x2="-4.826" y2="-2.54" width="0.1524" layer="21"/>
<text x="-4.8006" y="2.8194" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.9022" y="-4.699" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.429" y1="-2.54" x2="-2.921" y2="2.54" layer="21"/>
<rectangle x1="4.826" y1="-0.635" x2="5.969" y2="0.635" layer="21"/>
<rectangle x1="-5.969" y1="-0.635" x2="-4.826" y2="0.635" layer="21"/>
</package>
<package name="P3-15">
<wire x1="7.62" y1="0" x2="6.096" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.096" y2="0" width="0.8128" layer="51"/>
<pad name="C" x="-7.62" y="0" drill="1.1176" shape="long"/>
<pad name="A" x="7.62" y="0" drill="1.1176" shape="long"/>
<text x="-4.8006" y="3.0734" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="4.826" y1="-0.4064" x2="5.969" y2="0.4064" layer="21"/>
<rectangle x1="-5.969" y1="-0.4064" x2="-4.826" y2="0.4064" layer="21"/>
</package>
<package name="SOT54H">
<wire x1="-1.651" y1="2.032" x2="1.651" y2="2.032" width="0.1524" layer="21" curve="280.388858"/>
<wire x1="1.651" y1="2.032" x2="-1.651" y2="2.032" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-1.905" x2="0.508" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="0.508" y1="-0.635" x2="-0.381" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-0.381" y1="-1.27" x2="0.508" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-0.508" y1="-1.905" x2="-0.508" y2="-0.635" width="0.2032" layer="21"/>
<pad name="C" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
</package>
<package name="SOT54E">
3-lead plastic, vertical</description>
<wire x1="-1.778" y1="-1.778" x2="1.778" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="1.7961" y1="-1.7961" x2="2.54" y2="0" width="0.1524" layer="21" curve="45.000645"/>
<wire x1="0.7649" y1="2.4221" x2="2.54" y2="0" width="0.1524" layer="21" curve="-72.473997"/>
<wire x1="-2.54" y1="0" x2="-1.7961" y2="-1.7961" width="0.1524" layer="21" curve="45.000645"/>
<wire x1="-2.54" y1="0" x2="-0.7649" y2="2.4221" width="0.1524" layer="21" curve="-72.473997"/>
<wire x1="0" y1="2.54" x2="0.9206" y2="2.3673" width="0.1524" layer="51" curve="-21.250166"/>
<wire x1="-0.8781" y1="2.3834" x2="0" y2="2.54" width="0.1524" layer="51" curve="-20.225015"/>
<pad name="A1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="C" x="0" y="1.905" drill="0.8128" shape="octagon"/>
<pad name="A2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="2.921" y="-1.397" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.921" y="0.508" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="DO201T15">
<wire x1="-0.381" y1="0.4572" x2="-0.381" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0.635" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-0.4572" x2="0.381" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-0.635" x2="0" y2="-0.635" width="0.1524" layer="21"/>
</package>
<package name="P6T15">
<wire x1="-0.381" y1="0.508" x2="-0.381" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-0.508" x2="0.381" y2="-0.635" width="0.1524" layer="21"/>
</package>
<package name="C1702-15">
<wire x1="7.62" y1="0" x2="6.096" y2="0" width="1.1176" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.096" y2="0" width="1.1176" layer="51"/>
<rectangle x1="4.572" y1="-0.5334" x2="5.9436" y2="0.5334" layer="21"/>
<rectangle x1="-5.9436" y1="-0.5334" x2="-4.572" y2="0.5334" layer="21"/>
</package>
<package name="C4111-15">
diameter 5.3 mm, horizontal, grid 15.24 mm</description>
<wire x1="-5.08" y1="-2.667" x2="-5.08" y2="2.667" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.667" x2="5.08" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.667" x2="5.08" y2="2.667" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.667" x2="-5.08" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0.5842" x2="0" y2="0.5842" width="0.1524" layer="21"/>
<rectangle x1="-4.318" y1="-2.667" x2="-3.302" y2="2.667" layer="21"/>
</package>
<package name="SOD57Z10">
diameter 4 mm, vertical, grid 10.16 mm</description>
<wire x1="5.08" y1="0" x2="3.81" y2="0" width="0.8128" layer="51"/>
<wire x1="-5.08" y1="0" x2="-3.81" y2="0" width="0.8128" layer="51"/>
<wire x1="-1.143" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0.635" x2="0.508" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-0.635" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="1.016" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="0.508" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.016" x2="1.397" y2="1.016" width="0.1524" layer="21" curve="-131.11209"/>
<wire x1="-1.397" y1="-1.016" x2="1.397" y2="-1.016" width="0.1524" layer="21" curve="131.11209"/>
<wire x1="-2.286" y1="1.016" x2="-1.397" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.016" x2="1.397" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.016" x2="-1.397" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.397" y1="-1.016" x2="2.286" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="0.635" x2="-0.508" y2="0.635" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="1.1938" shape="long"/>
<pad name="A" x="5.08" y="0" drill="1.1938" shape="long"/>
<text x="-2.286" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.556" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.8354" y1="-0.4064" x2="-2.286" y2="0.4064" layer="21"/>
<rectangle x1="2.286" y1="-0.4064" x2="3.8354" y2="0.4064" layer="21"/>
</package>
<package name="SOD64Z10">
diameter 4.8 mm, vertical, grid 10.16 mm</description>
<wire x1="5.08" y1="0" x2="3.556" y2="0" width="1.3716" layer="51"/>
<wire x1="-5.08" y1="0" x2="-3.556" y2="0" width="1.3716" layer="51"/>
<wire x1="-2.54" y1="1.397" x2="-2.54" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.397" x2="2.54" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.397" x2="1.397" y2="1.397" width="0.1524" layer="21" curve="-131.11209"/>
<wire x1="-1.397" y1="-1.397" x2="1.397" y2="-1.397" width="0.1524" layer="21" curve="131.11209"/>
<wire x1="-2.54" y1="1.397" x2="-1.397" y2="1.397" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.397" x2="1.397" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.397" x2="-1.397" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="1.397" y1="-1.397" x2="2.54" y2="-1.397" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="1.6002" shape="long"/>
<pad name="A" x="5.08" y="0" drill="1.6002" shape="long"/>
<text x="-2.54" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.937" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.905" y1="-1.397" x2="-1.397" y2="1.397" layer="21"/>
<rectangle x1="2.54" y1="-0.6604" x2="3.3274" y2="0.6604" layer="21"/>
<rectangle x1="-3.3274" y1="-0.6604" x2="-2.54" y2="0.6604" layer="21"/>
</package>
<package name="SOD64Z12">
diameter 4.8 mm, vertical, grid 12.7 mm</description>
<wire x1="6.35" y1="0" x2="4.826" y2="0" width="1.3716" layer="51"/>
<wire x1="-6.35" y1="0" x2="-4.826" y2="0" width="1.3716" layer="51"/>
<pad name="C" x="-6.35" y="0" drill="1.6002" shape="long"/>
<pad name="A" x="6.35" y="0" drill="1.6002" shape="long"/>
<rectangle x1="2.54" y1="-0.6604" x2="4.572" y2="0.6604" layer="21"/>
<rectangle x1="-4.572" y1="-0.6604" x2="-2.54" y2="0.6604" layer="21"/>
</package>
<package name="F126Z12">
<wire x1="6.35" y1="0" x2="4.826" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.35" y1="0" x2="-4.826" y2="0" width="0.8128" layer="51"/>
<pad name="C" x="-6.35" y="0" drill="1.016" shape="long"/>
<pad name="A" x="6.35" y="0" drill="1.016" shape="long"/>
<rectangle x1="-2.54" y1="-1.524" x2="-1.778" y2="1.524" layer="21"/>
<rectangle x1="-4.8514" y1="-0.4064" x2="-3.175" y2="0.4064" layer="21"/>
<rectangle x1="3.175" y1="-0.4064" x2="4.8514" y2="0.4064" layer="21"/>
</package>
<package name="CB429-17">
diameter 5 mm, horizontal, grid 17 mm</description>
<wire x1="8.89" y1="0" x2="7.366" y2="0" width="1.016" layer="51"/>
<wire x1="-8.89" y1="0" x2="-7.366" y2="0" width="1.016" layer="51"/>
<pad name="C" x="-8.89" y="0" drill="1.397" shape="long"/>
<pad name="A" x="8.89" y="0" drill="1.397" shape="long"/>
<rectangle x1="5.08" y1="-0.508" x2="7.239" y2="0.508" layer="21"/>
<rectangle x1="-7.239" y1="-0.508" x2="-5.08" y2="0.508" layer="21"/>
</package>
<package name="DO13M">
diameter 6.35 mm metall, horizontal, grid 20.32 mm</description>
<wire x1="-7.239" y1="3.175" x2="-7.239" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-7.239" y1="-3.175" x2="1.905" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="1.905" y1="3.175" x2="-7.239" y2="3.175" width="0.1524" layer="21"/>
<wire x1="7.239" y1="-1.27" x2="7.239" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-3.175" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.27" x2="1.905" y2="3.175" width="0.1524" layer="21"/>
<wire x1="10.16" y1="0" x2="8.636" y2="0" width="0.9144" layer="51"/>
<wire x1="-8.636" y1="0" x2="-10.16" y2="0" width="0.9144" layer="51"/>
<wire x1="-4.191" y1="0" x2="-2.921" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="0" x2="-1.778" y2="0.5842" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.5842" x2="-1.778" y2="-0.5842" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.5842" x2="-2.921" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="0" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.4572" x2="-3.302" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.635" x2="-2.921" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="0.635" x2="-2.921" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.4572" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-2.921" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-0.635" x2="-2.921" y2="0" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-1.27" x2="6.35" y2="-1.27" width="0.1524" layer="21" curve="-86.050132"/>
<wire x1="2.794" y1="1.27" x2="6.35" y2="1.27" width="0.1524" layer="21" curve="86.050132"/>
<wire x1="7.239" y1="1.27" x2="6.35" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.794" y1="1.27" x2="1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="2.794" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-1.27" x2="7.239" y2="-1.27" width="0.1524" layer="21"/>
<pad name="C" x="-10.16" y="0" drill="1.1938" shape="long"/>
<pad name="A" x="10.16" y="0" drill="1.1938" shape="long"/>
<text x="-7.239" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.461" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="7.239" y1="-0.4318" x2="8.7122" y2="0.4318" layer="21"/>
<rectangle x1="-8.7122" y1="-0.4318" x2="-7.239" y2="0.4318" layer="21"/>
<rectangle x1="-6.731" y1="-3.175" x2="-6.096" y2="3.175" layer="21"/>
</package>
<package name="AG">
diameter 9 mm, horizontal, grid 10.16 mm</description>
<wire x1="7.62" y1="0" x2="5.842" y2="0" width="1.4732" layer="51"/>
<wire x1="-7.62" y1="0" x2="-5.842" y2="0" width="1.4732" layer="51"/>
<pad name="C" x="-7.62" y="0" drill="1.8034" shape="long"/>
<pad name="A" x="7.62" y="0" drill="1.8034" shape="long"/>
<text x="-4.8006" y="4.8514" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.4892" y="-3.302" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.81" y1="-4.572" x2="-3.302" y2="4.572" layer="21"/>
<rectangle x1="4.699" y1="-0.7112" x2="5.6134" y2="0.7112" layer="21"/>
<rectangle x1="-5.6134" y1="-0.7112" x2="-4.699" y2="0.7112" layer="21"/>
</package>
<package name="SOD81">
diameter 2.3 mm, vertical, grid 10.16 mm</description>
<wire x1="-1.905" y1="1.143" x2="1.905" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-2.54" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-2.159" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.381" x2="-2.54" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.381" x2="-2.159" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.635" x2="2.54" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.381" x2="2.54" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.54" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.381" x2="2.413" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.508" x2="2.413" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.508" x2="2.159" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.381" x2="2.413" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.508" x2="2.413" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.508" x2="2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.381" x2="-2.413" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.508" x2="-2.413" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.508" x2="-2.159" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.381" x2="-2.413" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-0.508" x2="-2.413" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-0.508" x2="-2.159" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.381" x2="2.159" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.381" x2="2.159" y2="0.508" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-0.381" x2="2.159" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.381" x2="2.159" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-0.381" x2="-2.159" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-0.381" x2="-2.159" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="0.381" x2="-2.159" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.381" x2="-2.159" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.143" x2="2.159" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.159" y1="0.889" x2="-1.905" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="1.905" y1="1.143" x2="2.159" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.159" y1="-0.889" x2="-1.905" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="-1.905" y1="-1.143" x2="1.905" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.635" x2="2.159" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-2.159" y2="0.889" width="0.1524" layer="21"/>
<text x="-2.032" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-1.651" y1="-1.143" x2="-1.143" y2="1.143" layer="21"/>
<rectangle x1="-3.937" y1="-0.381" x2="-2.159" y2="0.381" layer="21"/>
<rectangle x1="2.159" y1="-0.381" x2="3.937" y2="0.381" layer="21"/>
</package>
<package name="DO34Z7">
<wire x1="0.127" y1="0.508" x2="-0.127" y2="0.508" width="0.1524" layer="21"/>
</package>
<package name="F126Z10">
<pad name="C" x="-5.08" y="0" drill="1.016" shape="long"/>
<pad name="A" x="5.08" y="0" drill="1.016" shape="long"/>
<rectangle x1="3.175" y1="-0.4064" x2="3.7338" y2="0.4064" layer="21"/>
<rectangle x1="-3.7338" y1="-0.4064" x2="-3.175" y2="0.4064" layer="21"/>
</package>
<package name="TO220AC">
</package>
<package name="TO3P">
<wire x1="-8.255" y1="-1.778" x2="8.255" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-1.397" x2="7.62" y2="-1.397" width="0.0508" layer="21"/>
<wire x1="7.62" y1="10.287" x2="7.62" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-1.778" x2="-8.255" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="10.287" x2="-6.35" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="10.287" x2="-8.255" y2="17.653" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="12.192" x2="-6.35" y2="15.748" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="17.653" x2="-6.35" y2="15.748" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="16.129" x2="-7.62" y2="17.653" width="0.0508" layer="21"/>
<wire x1="-6.096" y1="16.129" x2="-6.096" y2="11.811" width="0.0508" layer="21"/>
<wire x1="-7.62" y1="10.287" x2="-6.096" y2="11.811" width="0.0508" layer="21"/>
<wire x1="-7.62" y1="10.287" x2="-7.62" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="8.255" y1="19.812" x2="8.255" y2="17.653" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="17.653" x2="-8.255" y2="19.812" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="19.812" x2="-8.255" y2="19.812" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="19.812" x2="-7.62" y2="17.653" width="0.0508" layer="21"/>
<wire x1="8.255" y1="19.812" x2="7.62" y2="19.812" width="0.1524" layer="21"/>
<wire x1="7.62" y1="19.812" x2="-7.62" y2="19.812" width="0.1524" layer="21"/>
<wire x1="7.62" y1="19.812" x2="7.62" y2="17.653" width="0.0508" layer="21"/>
<wire x1="7.62" y1="17.653" x2="6.096" y2="16.129" width="0.0508" layer="21"/>
<wire x1="6.35" y1="15.748" x2="8.255" y2="17.653" width="0.1524" layer="21"/>
<wire x1="8.255" y1="17.653" x2="8.255" y2="10.287" width="0.1524" layer="21"/>
<wire x1="6.35" y1="12.192" x2="6.35" y2="15.748" width="0.1524" layer="21"/>
<wire x1="6.096" y1="16.129" x2="6.096" y2="11.811" width="0.0508" layer="21"/>
<wire x1="8.255" y1="10.287" x2="6.35" y2="12.192" width="0.1524" layer="21"/>
<wire x1="7.62" y1="10.287" x2="6.096" y2="11.811" width="0.0508" layer="21"/>
<wire x1="8.255" y1="10.287" x2="8.255" y2="-1.778" width="0.1524" layer="21"/>
<circle x="0" y="13.97" radius="1.651" width="0.1524" layer="21"/>
<circle x="0" y="13.97" radius="3.81" width="0" layer="42"/>
<circle x="0" y="13.97" radius="3.81" width="0" layer="43"/>
<pad name="1" x="-5.588" y="-7.62" drill="1.6002" shape="long" rot="R90"/>
<pad name="2" x="0" y="-7.62" drill="1.6002" shape="long" rot="R90"/>
<pad name="3" x="5.588" y="-7.62" drill="1.6002" shape="long" rot="R90"/>
<text x="-8.636" y="-1.778" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-6.477" y="17.78" size="0.9906" layer="21" ratio="10">A21,6mm</text>
<rectangle x1="-1.524" y1="-3.302" x2="1.524" y2="-1.778" layer="21"/>
<rectangle x1="4.572" y1="-3.302" x2="6.604" y2="-1.778" layer="21"/>
<rectangle x1="-0.635" y1="-5.588" x2="0.635" y2="-3.302" layer="21"/>
<rectangle x1="4.953" y1="-5.588" x2="6.223" y2="-3.302" layer="21"/>
<rectangle x1="-6.604" y1="-3.302" x2="-4.572" y2="-1.778" layer="21"/>
<rectangle x1="-6.223" y1="-5.588" x2="-4.953" y2="-3.302" layer="21"/>
<hole x="0" y="13.97" drill="3.6068"/>
</package>
<package name="G4-12">
diameter 7.62 mm, horizontal, grid 12.7 mm</description>
<wire x1="3.556" y1="1.27" x2="3.556" y2="-1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="-3.556" y1="-1.27" x2="-3.556" y2="1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="6.35" y1="0" x2="5.08" y2="0" width="1.27" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.08" y2="0" width="1.27" layer="51"/>
<wire x1="3.937" y1="0.889" x2="4.318" y2="0.508" width="0.6096" layer="21"/>
<wire x1="4.318" y1="-0.508" x2="3.937" y2="-0.889" width="0.6096" layer="21"/>
<wire x1="-4.318" y1="0.508" x2="-3.937" y2="0.889" width="0.6096" layer="21"/>
<wire x1="-4.318" y1="-0.508" x2="-3.937" y2="-0.889" width="0.6096" layer="21"/>
<wire x1="-2.667" y1="-2.286" x2="-2.667" y2="2.286" width="0.6096" layer="21"/>
<wire x1="-3.175" y1="1.524" x2="-3.175" y2="-1.524" width="0.6096" layer="21"/>
<wire x1="-3.556" y1="1.016" x2="-3.556" y2="-1.016" width="0.6096" layer="21"/>
<wire x1="-3.175" y1="-1.524" x2="-2.921" y2="-2.032" width="0.6096" layer="21"/>
<wire x1="-2.921" y1="2.032" x2="-3.175" y2="1.524" width="0.6096" layer="21"/>
<wire x1="-0.762" y1="0" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0.508" x2="0.635" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-0.508" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="1.016" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="0.635" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0.508" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-0.381" y2="-0.508" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.81" width="0.1524" layer="21"/>
<text x="-3.429" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.81" y1="-0.635" x2="4.953" y2="0.635" layer="21"/>
<rectangle x1="-4.953" y1="-0.635" x2="-3.81" y2="0.635" layer="21"/>
</package>
<package name="DO204-10">
diameter 4 mm, horizontal, grid 10 mm</description>
<wire x1="2.54" y1="0.635" x2="2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="2.5255" y2="0.6542" width="0.1524" layer="21" curve="-105.826017"/>
<wire x1="-2.5255" y1="-0.6542" x2="2.54" y2="-0.635" width="0.1524" layer="21" curve="105.826017"/>
<wire x1="2.54" y1="0.635" x2="2.921" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.048" y1="0.508" x2="2.921" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="2.921" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-0.508" x2="2.921" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-0.508" x2="3.048" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-2.921" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="0.508" x2="-2.921" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-0.508" x2="-2.921" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-0.508" x2="-3.048" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.016" x2="-1.778" y2="-1.016" width="0.6096" layer="21"/>
<wire x1="-2.286" y1="0.508" x2="-2.286" y2="-0.508" width="0.6096" layer="21"/>
<wire x1="-2.032" y1="-0.762" x2="-2.286" y2="-0.508" width="0.6096" layer="21"/>
<wire x1="-2.286" y1="0.508" x2="-2.032" y2="0.762" width="0.6096" layer="21"/>
<wire x1="-2.794" y1="0.381" x2="-2.794" y2="-0.381" width="0.6096" layer="21"/>
<wire x1="2.794" y1="0.381" x2="2.794" y2="-0.381" width="0.6096" layer="21"/>
<wire x1="5.08" y1="0" x2="3.683" y2="0" width="0.8128" layer="51"/>
<wire x1="-5.08" y1="0" x2="-3.683" y2="0" width="0.8128" layer="51"/>
<wire x1="-0.889" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0.508" x2="0.508" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-0.508" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="0.508" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.508" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.508" width="0.1524" layer="21"/>
<text x="-2.54" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.556" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.048" y1="-0.4064" x2="3.6068" y2="0.4064" layer="21"/>
<rectangle x1="-3.6068" y1="-0.4064" x2="-3.048" y2="0.4064" layer="21"/>
</package>
<package name="TO220ABS">
3-lead molded, vertical</description>
<wire x1="5.08" y1="-1.143" x2="4.953" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="4.953" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="-4.699" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-4.699" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-5.08" y2="-1.143" width="0.1524" layer="21"/>
<circle x="-4.4958" y="-3.7084" radius="0.254" width="0" layer="21"/>
<pad name="A1" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="C" x="0" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="A2" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-5.08" y="-6.0452" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.334" y1="-0.762" x2="5.334" y2="0" layer="21"/>
<rectangle x1="-5.334" y1="-1.27" x2="-3.429" y2="-0.762" layer="21"/>
<rectangle x1="-1.651" y1="-1.27" x2="-0.889" y2="-0.762" layer="21"/>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="-0.762" layer="51"/>
<rectangle x1="0.889" y1="-1.27" x2="1.651" y2="-0.762" layer="21"/>
<rectangle x1="3.429" y1="-1.27" x2="5.334" y2="-0.762" layer="21"/>
<rectangle x1="-0.889" y1="-1.27" x2="0.889" y2="-0.762" layer="51"/>
<rectangle x1="1.651" y1="-1.27" x2="3.429" y2="-0.762" layer="51"/>
</package>
<package name="DO220S">
2-lead molded, vertical</description>
<pad name="C" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="A" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-4.572" y="-6.0452" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.572" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.27" x2="1.651" y2="-0.762" layer="21"/>
</package>
<package name="TO220ACS">
</package>
<package name="DO218S">
<wire x1="-6.985" y1="-5.08" x2="6.985" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-5.08" x2="7.366" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="7.366" y1="-4.699" x2="7.62" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-5.08" x2="-7.366" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-7.366" y1="-4.699" x2="-7.62" y2="-1.524" width="0.1524" layer="21"/>
<pad name="C" x="-5.461" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<pad name="A" x="5.461" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<text x="-7.62" y="-6.858" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-6.858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-7.874" y1="-1.143" x2="7.874" y2="0" layer="21"/>
<rectangle x1="-7.874" y1="-2.032" x2="-7.239" y2="-1.143" layer="21"/>
<rectangle x1="7.239" y1="-2.032" x2="7.874" y2="-1.143" layer="21"/>
<rectangle x1="3.556" y1="-2.032" x2="7.239" y2="-1.143" layer="51"/>
<rectangle x1="-7.239" y1="-2.032" x2="-3.556" y2="-1.143" layer="51"/>
<rectangle x1="-3.556" y1="-2.032" x2="3.556" y2="-1.143" layer="21"/>
</package>
<package name="SOD81Z">
</package>
<package name="SOD84">
diameter 3.3 mm, vertical, grid 10.16 mm</description>
<wire x1="-1.905" y1="1.651" x2="1.905" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.651" x2="2.159" y2="-1.397" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.159" y1="1.397" x2="-1.905" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="1.905" y1="1.651" x2="2.159" y2="1.397" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.159" y1="-1.397" x2="-1.905" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-1.905" y1="-1.651" x2="1.905" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.635" x2="2.159" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-2.159" y2="1.397" width="0.1524" layer="21"/>
<text x="-2.032" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.651" x2="-1.143" y2="1.651" layer="21"/>
</package>
<package name="SOD57-10">
</package>
<package name="SOD64-10">
</package>
<package name="SOD64-12">
</package>
<package name="SOD83-12">
<wire x1="-3.81" y1="1.397" x2="-3.81" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-1.397" x2="3.81" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.397" x2="-2.667" y2="1.397" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.397" x2="2.667" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-1.397" x2="-2.667" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="2.667" y1="-1.397" x2="3.81" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="1.397" x2="2.6841" y2="1.3841" width="0.1524" layer="21" curve="-74.015899"/>
<wire x1="-2.6841" y1="-1.3841" x2="2.667" y2="-1.397" width="0.1524" layer="21" curve="74.015899"/>
<rectangle x1="-3.175" y1="-1.397" x2="-2.667" y2="1.397" layer="21"/>
<rectangle x1="3.81" y1="-0.6604" x2="4.6228" y2="0.6604" layer="21"/>
<rectangle x1="-4.6228" y1="-0.6604" x2="-3.81" y2="0.6604" layer="21"/>
</package>
<package name="SOD61A">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 3.5 mm, vertical, grid 10.16 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6604" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6604" layer="51"/>
<wire x1="-2.54" y1="0.635" x2="-2.921" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-2.54" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="0.381" x2="-2.921" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-0.381" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.635" x2="2.921" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.921" y1="0.381" x2="2.921" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="2.921" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="2.54" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-0.381" x2="2.794" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.508" x2="2.794" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.508" x2="2.54" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.921" y1="0.381" x2="2.794" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.508" x2="2.794" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.508" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="0.381" x2="-2.794" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.508" x2="-2.794" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.508" x2="-2.54" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-0.381" x2="-2.794" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.508" x2="-2.794" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.508" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.794" y1="0.381" x2="2.54" y2="0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.381" x2="2.54" y2="0.508" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-0.381" x2="2.54" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.381" x2="2.54" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-0.381" x2="-2.54" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.381" x2="-2.54" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="0.381" x2="-2.54" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="2.5178" y2="0.655" width="0.1524" layer="21" curve="-84.093979"/>
<wire x1="-2.5178" y1="-0.655" x2="2.54" y2="-0.635" width="0.1524" layer="21" curve="84.093979"/>
<pad name="C" x="-5.08" y="0" drill="0.9144" shape="long"/>
<pad name="A" x="5.08" y="0" drill="0.9144" shape="long"/>
<text x="-2.54" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.921" y1="-0.3302" x2="4.0132" y2="0.3302" layer="21"/>
<rectangle x1="-4.0132" y1="-0.3302" x2="-2.921" y2="0.3302" layer="21"/>
<rectangle x1="2.54" y1="-0.381" x2="2.921" y2="0.381" layer="21"/>
<rectangle x1="-2.921" y1="-0.381" x2="-2.54" y2="0.381" layer="21"/>
</package>
<package name="SOD61B">
diameter 3.5 mm, vertical, grid 15.24 mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.6604" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.6604" layer="51"/>
<wire x1="-4.445" y1="0.635" x2="-4.826" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.635" x2="-4.445" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="0.381" x2="-4.826" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-0.381" x2="-4.445" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="4.445" y1="0.635" x2="4.826" y2="0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="0.381" x2="4.826" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-0.635" x2="4.826" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-0.635" x2="4.445" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-0.381" x2="4.699" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-0.508" x2="4.699" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-0.508" x2="4.445" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="0.381" x2="4.699" y2="0.381" width="0.1524" layer="21"/>
<wire x1="4.445" y1="0.508" x2="4.699" y2="0.381" width="0.1524" layer="21"/>
<wire x1="4.445" y1="0.508" x2="4.445" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="0.381" x2="-4.699" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.508" x2="-4.699" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.508" x2="-4.445" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-0.381" x2="-4.699" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-0.508" x2="-4.699" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-0.508" x2="-4.445" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="4.699" y1="0.381" x2="4.445" y2="0.381" width="0.1524" layer="21"/>
<wire x1="4.445" y1="0.381" x2="4.445" y2="0.508" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-0.381" x2="4.445" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-0.381" x2="4.445" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-0.381" x2="-4.445" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-0.381" x2="-4.445" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="0.381" x2="-4.445" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.381" x2="-4.445" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.635" x2="4.4429" y2="0.636" width="0.1524" layer="21" curve="-52.21463"/>
<wire x1="-4.4429" y1="-0.636" x2="4.445" y2="-0.635" width="0.1524" layer="21" curve="52.21463"/>
<pad name="C" x="-7.62" y="0" drill="0.9144" shape="long"/>
<pad name="A" x="7.62" y="0" drill="0.9144" shape="long"/>
<text x="-2.794" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.794" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.445" y1="-0.381" x2="4.826" y2="0.381" layer="21"/>
<rectangle x1="-4.826" y1="-0.381" x2="-4.445" y2="0.381" layer="21"/>
<rectangle x1="4.826" y1="-0.3302" x2="6.5278" y2="0.3302" layer="21"/>
<rectangle x1="-6.5278" y1="-0.3302" x2="-4.826" y2="0.3302" layer="21"/>
</package>
<package name="SOD61C">
diameter 3.5 mm, vertical, grid 17.78 mm</description>
<wire x1="8.89" y1="0" x2="7.874" y2="0" width="0.6604" layer="51"/>
<wire x1="-8.89" y1="0" x2="-7.874" y2="0" width="0.6604" layer="51"/>
<wire x1="-5.588" y1="0.635" x2="-5.969" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="0.635" x2="-5.588" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="0.381" x2="-5.969" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-0.381" x2="-5.588" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="5.588" y1="0.635" x2="5.969" y2="0.381" width="0.1524" layer="21"/>
<wire x1="5.969" y1="0.381" x2="5.969" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-0.635" x2="5.969" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-0.635" x2="5.588" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="5.969" y1="-0.381" x2="5.842" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-0.508" x2="5.842" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-0.508" x2="5.588" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="5.969" y1="0.381" x2="5.842" y2="0.381" width="0.1524" layer="21"/>
<wire x1="5.588" y1="0.508" x2="5.842" y2="0.381" width="0.1524" layer="21"/>
<wire x1="5.588" y1="0.508" x2="5.588" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="0.381" x2="-5.842" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="0.508" x2="-5.842" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="0.508" x2="-5.588" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-0.381" x2="-5.842" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-0.508" x2="-5.842" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-0.508" x2="-5.588" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="5.842" y1="0.381" x2="5.588" y2="0.381" width="0.1524" layer="21"/>
<wire x1="5.588" y1="0.381" x2="5.588" y2="0.508" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-0.381" x2="5.588" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-0.381" x2="5.588" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-0.381" x2="-5.588" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-0.381" x2="-5.588" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="0.381" x2="-5.588" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="0.381" x2="-5.588" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-5.55" y1="0.65" x2="-4.55" y2="1" width="0.1524" layer="21"/>
<wire x1="-4.55" y1="1" x2="-3.4" y2="1.3" width="0.1524" layer="21"/>
<wire x1="-3.4" y1="1.3" x2="-2.05" y2="1.55" width="0.1524" layer="21"/>
<wire x1="-2.05" y1="1.55" x2="-1" y2="1.65" width="0.1524" layer="21"/>
<wire x1="-1" y1="1.65" x2="0" y2="1.7" width="0.1524" layer="21"/>
<wire x1="5.55" y1="-0.65" x2="4.55" y2="-1" width="0.1524" layer="21"/>
<wire x1="4.55" y1="-1" x2="3.4" y2="-1.3" width="0.1524" layer="21"/>
<wire x1="3.4" y1="-1.3" x2="2.05" y2="-1.55" width="0.1524" layer="21"/>
<wire x1="2.05" y1="-1.55" x2="1" y2="-1.65" width="0.1524" layer="21"/>
<wire x1="1" y1="-1.65" x2="0" y2="-1.7" width="0.1524" layer="21"/>
<wire x1="5.55" y1="0.65" x2="4.55" y2="1" width="0.1524" layer="21"/>
<wire x1="4.55" y1="1" x2="3.4" y2="1.3" width="0.1524" layer="21"/>
<wire x1="3.4" y1="1.3" x2="2.05" y2="1.55" width="0.1524" layer="21"/>
<wire x1="2.05" y1="1.55" x2="1" y2="1.65" width="0.1524" layer="21"/>
<wire x1="1" y1="1.65" x2="0" y2="1.7" width="0.1524" layer="21"/>
<wire x1="-5.55" y1="-0.65" x2="-4.55" y2="-1" width="0.1524" layer="21"/>
<wire x1="-4.55" y1="-1" x2="-3.4" y2="-1.3" width="0.1524" layer="21"/>
<wire x1="-3.4" y1="-1.3" x2="-2.05" y2="-1.55" width="0.1524" layer="21"/>
<wire x1="-2.05" y1="-1.55" x2="-1" y2="-1.65" width="0.1524" layer="21"/>
<wire x1="-1" y1="-1.65" x2="0" y2="-1.7" width="0.1524" layer="21"/>
<pad name="C" x="-8.89" y="0" drill="0.9144" shape="long"/>
<pad name="A" x="8.89" y="0" drill="0.9144" shape="long"/>
<text x="-2.286" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="5.588" y1="-0.381" x2="5.969" y2="0.381" layer="21"/>
<rectangle x1="-5.969" y1="-0.381" x2="-5.588" y2="0.381" layer="21"/>
<rectangle x1="5.969" y1="-0.3302" x2="7.8232" y2="0.3302" layer="21"/>
<rectangle x1="-7.8232" y1="-0.3302" x2="-5.969" y2="0.3302" layer="21"/>
</package>
<package name="SOD61D">
<wire x1="-4.826" y1="0.635" x2="-5.207" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="0.635" x2="-4.826" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="0.381" x2="-5.207" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-0.381" x2="-4.826" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="4.826" y1="0.635" x2="5.207" y2="0.381" width="0.1524" layer="21"/>
<wire x1="5.207" y1="0.381" x2="5.207" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-0.635" x2="5.207" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-0.635" x2="4.826" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-0.381" x2="5.08" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-0.508" x2="5.08" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-0.508" x2="4.826" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="5.207" y1="0.381" x2="5.08" y2="0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="0.508" x2="5.08" y2="0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="0.508" x2="4.826" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="0.381" x2="-5.08" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="0.508" x2="-5.08" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="0.508" x2="-4.826" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-0.381" x2="-5.08" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-0.508" x2="-5.08" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-0.508" x2="-4.826" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.381" x2="4.826" y2="0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="0.381" x2="4.826" y2="0.508" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-0.381" x2="4.826" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-0.381" x2="4.826" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.381" x2="-4.826" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-0.381" x2="-4.826" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.381" x2="-4.826" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="0.635" x2="4.8254" y2="0.6353" width="0.1524" layer="21" curve="-49.511667"/>
<wire x1="-4.8254" y1="-0.6353" x2="4.826" y2="-0.635" width="0.1524" layer="21" curve="49.511667"/>
<text x="-2.54" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.826" y1="-0.381" x2="5.207" y2="0.381" layer="21"/>
<rectangle x1="-5.207" y1="-0.381" x2="-4.826" y2="0.381" layer="21"/>
<rectangle x1="5.207" y1="-0.3302" x2="6.5278" y2="0.3302" layer="21"/>
<rectangle x1="-6.5278" y1="-0.3302" x2="-5.207" y2="0.3302" layer="21"/>
</package>
<package name="SOD61E">
diameter 3.5 mm, vertical, grid 20.32 mm</description>
<wire x1="10.16" y1="0" x2="9.144" y2="0" width="0.6604" layer="51"/>
<wire x1="-10.16" y1="0" x2="-9.144" y2="0" width="0.6604" layer="51"/>
<wire x1="-6.35" y1="0.635" x2="-6.731" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.635" x2="-6.35" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0.381" x2="-6.731" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-0.381" x2="-6.35" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0.635" x2="6.731" y2="0.381" width="0.1524" layer="21"/>
<wire x1="6.731" y1="0.381" x2="6.731" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="6.731" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="6.35" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-0.381" x2="6.604" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-0.508" x2="6.604" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-0.508" x2="6.35" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="6.731" y1="0.381" x2="6.604" y2="0.381" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0.508" x2="6.604" y2="0.381" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0.508" x2="6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0.381" x2="-6.604" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.508" x2="-6.604" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.508" x2="-6.35" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-0.381" x2="-6.604" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-0.508" x2="-6.604" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-0.508" x2="-6.35" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="6.604" y1="0.381" x2="6.35" y2="0.381" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0.381" x2="6.35" y2="0.508" width="0.1524" layer="21"/>
<wire x1="6.604" y1="-0.381" x2="6.35" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-0.381" x2="6.35" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-0.381" x2="-6.35" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-0.381" x2="-6.35" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="0.381" x2="-6.35" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.381" x2="-6.35" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.635" x2="6.3161" y2="0.6464" width="0.1524" layer="21" curve="-37.137105"/>
<wire x1="-6.3161" y1="-0.6464" x2="6.35" y2="-0.635" width="0.1524" layer="21" curve="37.137105"/>
<pad name="C" x="-10.16" y="0" drill="0.9144" shape="long"/>
<pad name="A" x="10.16" y="0" drill="0.9144" shape="long"/>
<text x="-3.048" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.048" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="6.35" y1="-0.381" x2="6.731" y2="0.381" layer="21"/>
<rectangle x1="-6.731" y1="-0.381" x2="-6.35" y2="0.381" layer="21"/>
<rectangle x1="6.731" y1="-0.3302" x2="9.0678" y2="0.3302" layer="21"/>
<rectangle x1="-9.0678" y1="-0.3302" x2="-6.731" y2="0.3302" layer="21"/>
</package>
<package name="SOT1862L">
<wire x1="-5.207" y1="-1.397" x2="5.207" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-1.397" x2="5.207" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-1.397" x2="-5.207" y2="7.239" width="0.1524" layer="21"/>
<wire x1="5.207" y1="15.113" x2="2.921" y2="15.113" width="0.1524" layer="21"/>
<wire x1="2.921" y1="15.621" x2="2.921" y2="15.113" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="15.113" x2="-2.921" y2="15.113" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="15.621" x2="-2.921" y2="15.113" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="15.621" x2="2.921" y2="15.621" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="7.239" x2="5.207" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="7.239" x2="-5.207" y2="15.113" width="0.1524" layer="21"/>
<wire x1="5.207" y1="7.239" x2="5.207" y2="15.113" width="0.1524" layer="21"/>
<text x="-3.81" y="4.445" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="1.905" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.175" y1="-4.699" x2="-1.905" y2="-1.397" layer="21"/>
<rectangle x1="1.905" y1="-4.699" x2="3.175" y2="-1.397" layer="21"/>
<rectangle x1="2.159" y1="-6.477" x2="2.921" y2="-4.826" layer="51"/>
<rectangle x1="2.159" y1="-4.826" x2="2.921" y2="-4.699" layer="21"/>
<rectangle x1="-2.921" y1="-6.477" x2="-2.159" y2="-4.826" layer="51"/>
<rectangle x1="-2.921" y1="-4.826" x2="-2.159" y2="-4.699" layer="21"/>
</package>
<package name="SOT1862S">
<wire x1="4.953" y1="-4.445" x2="5.207" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-4.445" x2="-4.953" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.191" x2="-4.953" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.191" x2="-5.207" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-2.921" x2="-5.207" y2="-0.127" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-4.191" x2="5.207" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.921" x2="5.207" y2="-0.127" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-2.921" x2="2.921" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="-3.302" y1="-2.921" x2="-2.921" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="-1.778" y1="-2.921" x2="1.778" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-3.683" x2="-0.381" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-3.302" x2="-0.381" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-3.683" x2="0.381" y2="-3.302" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-3.683" x2="0.889" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-3.683" x2="-0.381" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-3.302" x2="0.381" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-4.064" x2="-0.381" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-2.921" x2="2.921" y2="-0.127" width="0.1524" layer="51"/>
<wire x1="5.207" y1="-2.921" x2="3.302" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-2.921" x2="-2.921" y2="-0.127" width="0.1524" layer="51"/>
<wire x1="-5.207" y1="-2.921" x2="-3.302" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-2.921" x2="1.778" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="-2.921" x2="-1.778" y2="-2.921" width="0.1524" layer="51"/>
<pad name="C" x="-2.54" y="-1.651" drill="1.016" shape="long" rot="R90"/>
<pad name="A" x="2.54" y="-1.651" drill="1.016" shape="long" rot="R90"/>
<rectangle x1="-5.207" y1="-0.254" x2="5.207" y2="0" layer="21"/>
</package>
<package name="SOT186L">
<text x="-5.461" y="-1.524" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<rectangle x1="-0.381" y1="-4.826" x2="0.381" y2="-4.699" layer="21"/>
<rectangle x1="-0.381" y1="-6.477" x2="0.381" y2="-4.826" layer="51"/>
</package>
<package name="SOT186S">
<wire x1="-1.778" y1="-2.921" x2="-0.762" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="0.762" y1="-2.921" x2="1.778" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.921" x2="5.207" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-2.921" x2="-5.207" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-2.921" x2="-2.921" y2="0" width="0.1524" layer="51"/>
<wire x1="2.921" y1="-2.921" x2="2.921" y2="0" width="0.1524" layer="51"/>
<wire x1="5.207" y1="0" x2="-5.207" y2="0" width="0.1524" layer="21"/>
<pad name="A1" x="-2.54" y="-1.651" drill="1.016" shape="long" rot="R90"/>
<pad name="A2" x="2.54" y="-1.651" drill="1.016" shape="long" rot="R90"/>
<pad name="C" x="0" y="-1.651" drill="1.016" shape="long" rot="R90"/>
</package>
<package name="BR210S">
<pad name="T1" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="T2" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
</package>
<package name="BR220S">
<pad name="T2" x="0" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="T3" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
</package>
<package name="SOT93L">
<wire x1="-7.493" y1="-6.35" x2="7.493" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="7.493" y1="6.223" x2="7.493" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="7.493" y1="6.223" x2="6.858" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="-6.35" x2="-7.493" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-6.858" y1="6.223" x2="-6.858" y2="6.985" width="0.1524" layer="21"/>
<wire x1="-6.858" y1="6.223" x2="-7.493" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-6.858" y1="6.985" x2="-7.112" y2="6.985" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="6.985" x2="-7.112" y2="8.255" width="0.1524" layer="21"/>
<wire x1="6.858" y1="6.223" x2="6.858" y2="6.985" width="0.1524" layer="21"/>
<wire x1="6.858" y1="6.223" x2="-6.858" y2="6.223" width="0.1524" layer="21"/>
<wire x1="6.858" y1="6.985" x2="7.112" y2="6.985" width="0.1524" layer="21"/>
<wire x1="7.112" y1="6.985" x2="7.112" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-5.715" x2="6.985" y2="-5.715" width="0.0508" layer="21"/>
<wire x1="6.985" y1="5.715" x2="6.985" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="6.985" y1="5.715" x2="-6.985" y2="5.715" width="0.0508" layer="21"/>
<wire x1="-6.985" y1="-5.715" x2="-6.985" y2="5.715" width="0.1524" layer="21"/>
<wire x1="6.858" y1="8.255" x2="7.112" y2="8.255" width="0.1524" layer="21"/>
<wire x1="6.858" y1="8.255" x2="6.858" y2="11.938" width="0.1524" layer="21"/>
<wire x1="-6.858" y1="8.255" x2="-7.112" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-6.858" y1="8.255" x2="-6.858" y2="11.938" width="0.1524" layer="21"/>
<wire x1="-6.858" y1="11.938" x2="-4.318" y2="14.478" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.318" y1="14.478" x2="6.858" y2="11.938" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.318" y1="14.478" x2="-4.318" y2="14.478" width="0.1524" layer="21"/>
<pad name="A1" x="-5.461" y="-10.16" drill="1.397" shape="long" rot="R90"/>
<pad name="C" x="0" y="-10.16" drill="1.397" shape="long" rot="R90"/>
<pad name="A2" x="5.461" y="-10.16" drill="1.397" shape="long" rot="R90"/>
<rectangle x1="-6.35" y1="-7.747" x2="-4.572" y2="-6.731" layer="21"/>
<rectangle x1="4.572" y1="-7.747" x2="6.35" y2="-6.731" layer="21"/>
<rectangle x1="-6.096" y1="-9.779" x2="-4.826" y2="-8.89" layer="51"/>
<rectangle x1="-6.096" y1="-8.255" x2="-4.826" y2="-6.35" layer="21"/>
<rectangle x1="-6.096" y1="-10.16" x2="-4.826" y2="-8.255" layer="51"/>
<rectangle x1="-0.635" y1="-8.255" x2="0.635" y2="-6.35" layer="21"/>
<rectangle x1="-0.635" y1="-10.16" x2="0.635" y2="-8.255" layer="51"/>
<rectangle x1="4.826" y1="-8.255" x2="6.096" y2="-6.35" layer="21"/>
<rectangle x1="4.826" y1="-10.16" x2="6.096" y2="-8.255" layer="51"/>
<rectangle x1="-0.889" y1="-7.747" x2="0.889" y2="-6.731" layer="21"/>
</package>
<package name="SOT93S">
<wire x1="7.493" y1="-2.032" x2="3.429" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-2.032" x2="2.032" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-2.032" x2="-2.032" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="-2.032" y1="-2.032" x2="-3.429" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.032" x2="-7.493" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="-7.493" y1="0" x2="7.493" y2="0" width="0.1524" layer="21"/>
<wire x1="7.366" y1="-4.699" x2="6.985" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-5.08" x2="-6.985" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-7.366" y1="-4.699" x2="-6.985" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="7.493" y1="0" x2="7.493" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="7.493" y1="-2.032" x2="7.366" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="0" x2="-7.493" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="-2.032" x2="-7.366" y2="-4.699" width="0.1524" layer="21"/>
<pad name="A1" x="-5.461" y="-2.54" drill="1.397" shape="long" rot="R90"/>
<pad name="C" x="0" y="-2.54" drill="1.397" shape="long" rot="R90"/>
<pad name="A2" x="5.461" y="-2.54" drill="1.397" shape="long" rot="R90"/>
<text x="-1.524" y="-6.731" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-7.62" y="-6.731" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-6.858" y1="-2.032" x2="6.858" y2="0" layer="51"/>
</package>
<package name="SOT82L">
<wire x1="-3.937" y1="-1.27" x2="-3.937" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="4.572" x2="-3.937" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="7.62" x2="-3.937" y2="9.906" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="9.906" x2="3.937" y2="9.906" width="0.1524" layer="21"/>
<wire x1="3.937" y1="9.906" x2="3.937" y2="7.62" width="0.1524" layer="21"/>
<wire x1="3.937" y1="7.62" x2="3.937" y2="4.572" width="0.1524" layer="21"/>
<wire x1="3.937" y1="4.572" x2="3.937" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.27" x2="3.937" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.937" y1="4.572" x2="3.937" y2="7.62" width="0.1524" layer="21" curve="-180"/>
<wire x1="-3.937" y1="7.62" x2="-3.937" y2="4.572" width="0.1524" layer="21" curve="-180"/>
<pad name="A1" x="-2.286" y="-5.08" drill="1.1176" shape="long" rot="R90"/>
<pad name="C" x="0" y="-5.08" drill="1.1176" shape="long" rot="R90"/>
<pad name="A2" x="2.286" y="-5.08" drill="1.1176" shape="long" rot="R90"/>
<text x="-4.318" y="-1.27" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.175" y="2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.667" y1="-4.953" x2="-1.905" y2="-3.429" layer="51"/>
<rectangle x1="-0.381" y1="-4.953" x2="0.381" y2="-3.429" layer="51"/>
<rectangle x1="1.905" y1="-4.953" x2="2.667" y2="-3.429" layer="51"/>
<rectangle x1="-0.635" y1="-2.667" x2="0.635" y2="-1.651" layer="21"/>
<rectangle x1="1.651" y1="-2.667" x2="2.921" y2="-1.651" layer="21"/>
<rectangle x1="-2.921" y1="-2.667" x2="-1.651" y2="-1.651" layer="21"/>
<rectangle x1="-2.667" y1="-3.429" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="-0.381" y1="-3.429" x2="0.381" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-3.429" x2="2.667" y2="-1.27" layer="21"/>
</package>
<package name="SOT82S">
<wire x1="-3.937" y1="-0.127" x2="-3.937" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.27" x2="-3.683" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.794" x2="3.937" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.937" y1="-1.27" x2="3.937" y2="-0.127" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="-2.794" x2="-2.794" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-2.794" x2="-1.778" y2="-2.794" width="0.1524" layer="51"/>
<wire x1="-1.778" y1="-2.794" x2="-0.508" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="-2.794" x2="0.508" y2="-2.794" width="0.1524" layer="51"/>
<wire x1="0.508" y1="-2.794" x2="1.778" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-2.794" x2="2.794" y2="-2.794" width="0.1524" layer="51"/>
<wire x1="2.794" y1="-2.794" x2="3.683" y2="-2.794" width="0.1524" layer="21"/>
<pad name="A1" x="-2.286" y="-1.27" drill="1.016" shape="long" rot="R90"/>
<pad name="C" x="0" y="-1.27" drill="1.016" shape="long" rot="R90"/>
<pad name="A2" x="2.286" y="-1.27" drill="1.016" shape="long" rot="R90"/>
<text x="-3.4544" y="-4.2926" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.4798" y="-5.9436" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.937" y1="-0.381" x2="-3.175" y2="0" layer="21"/>
<rectangle x1="-1.397" y1="-0.381" x2="-0.889" y2="0" layer="21"/>
<rectangle x1="0.889" y1="-0.381" x2="1.397" y2="0" layer="21"/>
<rectangle x1="3.175" y1="-0.381" x2="3.937" y2="0" layer="21"/>
<rectangle x1="-3.175" y1="-0.381" x2="-1.397" y2="0" layer="51"/>
<rectangle x1="-0.889" y1="-0.381" x2="0.889" y2="0" layer="51"/>
<rectangle x1="1.397" y1="-0.381" x2="3.175" y2="0" layer="51"/>
</package>
<package name="SGB-10">
diameter 4.6 mm, vertical, grid 10.16 mm</description>
<wire x1="5.08" y1="0" x2="3.175" y2="0" width="1.27" layer="51"/>
<wire x1="-5.08" y1="0" x2="-3.175" y2="0" width="1.27" layer="51"/>
<wire x1="2.032" y1="0.635" x2="2.032" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.635" x2="-2.032" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.635" x2="2.032" y2="0.635" width="0.1524" layer="21" curve="-147.920113"/>
<wire x1="-2.032" y1="-0.635" x2="2.032" y2="-0.635" width="0.1524" layer="21" curve="147.920113"/>
<wire x1="-1.397" y1="1.4478" x2="-1.397" y2="-1.4478" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="1.2954" x2="-1.5748" y2="-1.27" width="0.254" layer="21"/>
<text x="-2.54" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.302" y1="-0.635" x2="-2.032" y2="0.635" layer="21"/>
<rectangle x1="2.032" y1="-0.635" x2="3.302" y2="0.635" layer="21"/>
</package>
<package name="G4-15">
diameter 7.62 mm, horizontal, grid 15.24 mm</description>
<wire x1="7.62" y1="0" x2="5.715" y2="0" width="1.27" layer="51"/>
<wire x1="-7.62" y1="0" x2="-5.715" y2="0" width="1.27" layer="51"/>
<wire x1="0.635" y1="0.762" x2="0.635" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-0.762" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="0.635" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0.762" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-0.381" y2="-0.762" width="0.1524" layer="21"/>
<pad name="C" x="-7.62" y="0" drill="1.6002" shape="long"/>
<pad name="A" x="7.62" y="0" drill="1.6002" shape="long"/>
<text x="-2.413" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="3.81" y1="-0.635" x2="5.842" y2="0.635" layer="21"/>
<rectangle x1="-5.842" y1="-0.635" x2="-3.81" y2="0.635" layer="21"/>
</package>
<package name="SGA-10">
<wire x1="5.08" y1="0" x2="3.175" y2="0" width="0.8128" layer="51"/>
<wire x1="-5.08" y1="0" x2="-3.175" y2="0" width="0.8128" layer="51"/>
<wire x1="2.032" y1="0.381" x2="2.032" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.1938" x2="-1.397" y2="-1.1938" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="1.0414" x2="-1.5748" y2="-1.016" width="0.254" layer="21"/>
<wire x1="-2.032" y1="0.381" x2="-2.032" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.381" x2="2.032" y2="0.381" width="0.1524" layer="21" curve="-145.291951"/>
<wire x1="-2.032" y1="-0.381" x2="2.032" y2="-0.381" width="0.1524" layer="21" curve="145.291951"/>
<pad name="C" x="-5.08" y="0" drill="1.1176" shape="long"/>
<pad name="A" x="5.08" y="0" drill="1.1176" shape="long"/>
<rectangle x1="2.032" y1="-0.4064" x2="3.8608" y2="0.4064" layer="21"/>
<rectangle x1="-3.8608" y1="-0.4064" x2="-2.032" y2="0.4064" layer="21"/>
</package>
<package name="SGC-10">
diameter 5 mm, vertical, grid 10.16 mm</description>
<wire x1="-1.397" y1="1.9558" x2="-1.397" y2="-1.9558" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="1.778" x2="-1.5748" y2="-1.778" width="0.254" layer="21"/>
<wire x1="-2.032" y1="0.635" x2="2.032" y2="0.635" width="0.1524" layer="21" curve="-180"/>
<wire x1="-2.032" y1="-0.635" x2="2.032" y2="-0.635" width="0.1524" layer="21" curve="180"/>
<text x="-2.54" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-4.318" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C1702E15">
diameter 3.5 mm, horizontal, grid 15.24 mm</description>
<wire x1="-4.572" y1="-1.778" x2="-4.572" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.572" y1="1.778" x2="-4.572" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.572" y1="1.778" x2="4.572" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-1.778" x2="4.572" y2="-1.778" width="0.1524" layer="21"/>
<pad name="C" x="-7.62" y="0" drill="1.397" shape="long"/>
<pad name="A" x="7.62" y="0" drill="1.397" shape="long"/>
<text x="-4.572" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.794" y="-1.397" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.81" y1="-1.778" x2="-3.302" y2="1.778" layer="21"/>
</package>
<package name="C5102">
diameter 2.8 mm, horizontal, grid 10.10 mm</description>
<wire x1="5.08" y1="0" x2="4.191" y2="0" width="0.508" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.191" y2="0" width="0.508" layer="51"/>
<wire x1="-0.508" y1="0.635" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="3.556" y1="1.397" x2="3.81" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.81" y1="1.143" x2="-3.556" y2="1.397" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.81" y1="-1.143" x2="-3.556" y2="-1.397" width="0.1524" layer="21" curve="90"/>
<wire x1="3.556" y1="-1.397" x2="3.81" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="3.81" y1="-1.143" x2="3.81" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.143" x2="-3.81" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.397" x2="3.556" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-1.397" x2="3.556" y2="-1.397" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="5.08" y="0" drill="0.8128" shape="long"/>
<text x="-3.683" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.683" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.81" y1="-0.254" x2="4.191" y2="0.254" layer="21"/>
<rectangle x1="-4.191" y1="-0.254" x2="-3.81" y2="0.254" layer="21"/>
<rectangle x1="-3.302" y1="-1.397" x2="-2.54" y2="1.397" layer="21"/>
</package>
<package name="C182A">
2-lead plasic, vertical</description>
<wire x1="2.286" y1="1.27" x2="-2.286" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.2705" y1="1.2724" x2="2.286" y2="1.27" width="0.1524" layer="21" curve="240.509903"/>
<pad name="A" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="C" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="3.175" y="0.635" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C182B">
<wire x1="-2.286" y1="-1.27" x2="2.286" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.27" x2="2.2955" y2="-1.2474" width="0.1524" layer="21" curve="-239.051371"/>
</package>
<package name="TO18D">
2-lead metall, vertical</description>
<wire x1="1.651" y1="-2.286" x2="2.286" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-2.921" x2="2.921" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-2.286" x2="2.286" y2="-1.651" width="0.1524" layer="21"/>
<circle x="0" y="0.0254" radius="2.7686" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.54" width="0.0508" layer="21"/>
<text x="3.175" y="0.762" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.143" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SOT54A">
3-lead plastic, vertical</description>
<wire x1="-1.778" y1="-1.778" x2="1.778" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="1.7961" y1="-1.7961" x2="2.54" y2="0" width="0.1524" layer="21" curve="45.000645"/>
<wire x1="0.7649" y1="2.4221" x2="2.54" y2="0" width="0.1524" layer="21" curve="-72.473997"/>
<wire x1="-2.54" y1="0" x2="-1.7961" y2="-1.7961" width="0.1524" layer="21" curve="45.000645"/>
<wire x1="-2.54" y1="0" x2="-0.7649" y2="2.4221" width="0.1524" layer="21" curve="-72.473997"/>
<wire x1="0" y1="2.54" x2="0.9206" y2="2.3673" width="0.1524" layer="51" curve="-21.250166"/>
<wire x1="-0.8781" y1="2.3834" x2="0" y2="2.54" width="0.1524" layer="51" curve="-20.225015"/>
<pad name="A1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="C" x="0" y="1.905" drill="0.8128" shape="octagon"/>
<pad name="A2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="2.921" y="-1.397" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.921" y="0.508" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="SOT54B">
2-lead plastic, vertical</description>
<wire x1="1.778" y1="1.778" x2="-1.778" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0" x2="-1.7961" y2="1.7961" width="0.1524" layer="21" curve="-45.000645"/>
<wire x1="1.7961" y1="1.7961" x2="2.54" y2="0" width="0.1524" layer="21" curve="-45.000645"/>
<wire x1="-2.54" y1="0" x2="2.54" y2="0" width="0.1524" layer="21" curve="180"/>
<wire x1="0.635" y1="-1.905" x2="0.635" y2="-0.635" width="0.2032" layer="21"/>
<wire x1="0.635" y1="-0.635" x2="-0.381" y2="-1.27" width="0.2032" layer="21"/>
<wire x1="-0.381" y1="-1.27" x2="0.635" y2="-1.905" width="0.2032" layer="21"/>
<wire x1="-0.508" y1="-0.635" x2="-0.508" y2="-1.905" width="0.2032" layer="21"/>
<text x="2.921" y="-1.143" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="G4-12E">
<pad name="C" x="-6.35" y="0" drill="1.6002" shape="long"/>
<pad name="A" x="6.35" y="0" drill="1.6002" shape="long"/>
<text x="-2.921" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C2673">
diameter 5.2 mm, horizontal, grid 15.24 mm</description>
<wire x1="4.826" y1="-2.667" x2="-4.826" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.667" x2="4.826" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.667" x2="4.826" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.667" x2="-4.826" y2="-2.667" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0" x2="6.096" y2="0" width="1.27" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.096" y2="0" width="1.27" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<pad name="A" x="7.62" y="0" drill="1.4986" shape="long"/>
<pad name="C" x="-7.62" y="0" drill="1.4986" shape="long"/>
<text x="-4.699" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.937" y1="-2.667" x2="-2.54" y2="2.667" layer="21"/>
<rectangle x1="4.826" y1="-0.635" x2="5.969" y2="0.635" layer="21"/>
<rectangle x1="-5.969" y1="-0.635" x2="-4.826" y2="0.635" layer="21"/>
</package>
<package name="C2672">
diameter 6.3 mm, horizontal, grid 15.24 mm</description>
<wire x1="4.699" y1="-3.175" x2="-4.699" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-3.175" x2="4.699" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="3.175" x2="4.699" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="3.175" x2="-4.699" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0" x2="5.969" y2="0" width="1.27" layer="51"/>
<wire x1="-7.62" y1="0" x2="-5.969" y2="0" width="1.27" layer="51"/>
<text x="-4.699" y="3.556" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.699" y1="-0.635" x2="5.842" y2="0.635" layer="21"/>
<rectangle x1="-5.842" y1="-0.635" x2="-4.699" y2="0.635" layer="21"/>
<rectangle x1="-3.937" y1="-3.175" x2="-2.54" y2="3.175" layer="21"/>
</package>
<package name="C2992">
diameter 2.3 mm, horizontal, grid 10.16 mm</description>
<wire x1="2.286" y1="1.143" x2="2.54" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="0.889" x2="-2.286" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.889" x2="-2.286" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="-1.143" x2="2.54" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.54" y1="-0.889" x2="2.54" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.889" x2="-2.54" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.143" x2="2.286" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.143" x2="2.286" y2="-1.143" width="0.1524" layer="21"/>
<text x="-2.413" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.413" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.54" y1="-0.254" x2="4.191" y2="0.254" layer="21"/>
<rectangle x1="-1.905" y1="-1.143" x2="-1.397" y2="1.143" layer="21"/>
<rectangle x1="-4.191" y1="-0.254" x2="-2.54" y2="0.254" layer="21"/>
</package>
<package name="TO218L">
3-lead molded, horizontal</description>
<wire x1="-7.62" y1="-6.35" x2="7.62" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="7.62" y1="6.223" x2="7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0" x2="7.62" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-3.81" x2="7.62" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-6.35" x2="-7.62" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-3.81" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="6.223" width="0.1524" layer="21"/>
<wire x1="7.62" y1="6.223" x2="-7.62" y2="6.223" width="0.1524" layer="21"/>
<wire x1="6.985" y1="0.508" x2="6.985" y2="5.715" width="0.0508" layer="21"/>
<wire x1="7.62" y1="12.065" x2="5.08" y2="14.605" width="0.1524" layer="21"/>
<wire x1="7.62" y1="12.065" x2="7.62" y2="6.223" width="0.1524" layer="21"/>
<wire x1="5.08" y1="14.605" x2="-5.08" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="12.065" x2="-5.08" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="12.065" x2="-7.62" y2="6.223" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0" x2="7.62" y2="-3.81" width="0.1524" layer="21" curve="180"/>
<wire x1="6.985" y1="-5.715" x2="6.985" y2="-4.318" width="0.0508" layer="21"/>
<wire x1="6.9522" y1="0.4991" x2="6.9851" y2="-4.3178" width="0.0508" layer="21" curve="149.733471"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="-3.81" width="0.1524" layer="21" curve="-180"/>
<wire x1="-6.985" y1="-5.715" x2="-6.985" y2="-4.318" width="0.0508" layer="21"/>
<wire x1="-6.985" y1="0.508" x2="-6.985" y2="5.715" width="0.0508" layer="21"/>
<wire x1="-6.985" y1="-4.318" x2="-6.985" y2="0.508" width="0.0508" layer="21" curve="150.512874"/>
<circle x="0" y="10.16" radius="2.159" width="0.1524" layer="21"/>
<circle x="0" y="10.16" radius="3.81" width="0" layer="42"/>
<circle x="0" y="10.16" radius="3.81" width="0" layer="43"/>
<text x="-8.128" y="-6.096" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-5.08" y="0" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-6.096" y1="-7.366" x2="-4.318" y2="-6.35" layer="21"/>
<rectangle x1="4.318" y1="-7.366" x2="6.096" y2="-6.35" layer="21"/>
<rectangle x1="-1.143" y1="-7.366" x2="1.143" y2="-6.35" layer="21"/>
<rectangle x1="-6.096" y1="-8.128" x2="-4.826" y2="-6.35" layer="21"/>
<rectangle x1="-6.096" y1="-10.287" x2="-4.826" y2="-8.128" layer="51"/>
<rectangle x1="-0.635" y1="-8.128" x2="0.635" y2="-6.35" layer="21"/>
<rectangle x1="4.826" y1="-8.128" x2="6.096" y2="-6.35" layer="21"/>
<rectangle x1="-0.635" y1="-10.287" x2="0.635" y2="-8.128" layer="51"/>
<rectangle x1="4.826" y1="-10.287" x2="6.096" y2="-8.128" layer="51"/>
<hole x="0" y="10.16" drill="4.1148"/>
</package>
<package name="TO218S">
<pad name="A1" x="-5.461" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<pad name="C" x="0" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<pad name="A2" x="5.461" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<text x="-1.397" y="-6.731" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.556" y1="-2.032" x2="-1.905" y2="-1.143" layer="21"/>
<rectangle x1="1.905" y1="-2.032" x2="3.556" y2="-1.143" layer="21"/>
<rectangle x1="-1.905" y1="-2.032" x2="1.905" y2="-1.143" layer="51"/>
</package>
<package name="C221B1A">
2-lead molded, horizontal</description>
<wire x1="-5.207" y1="-1.27" x2="5.207" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.207" y1="14.478" x2="-5.207" y2="14.478" width="0.1524" layer="21"/>
<wire x1="5.207" y1="8.001" x2="-5.207" y2="8.001" width="0.1524" layer="21"/>
<wire x1="5.207" y1="8.001" x2="5.207" y2="14.478" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="8.001" x2="-5.207" y2="14.478" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-1.27" x2="5.207" y2="8.001" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="8.001" width="0.1524" layer="21"/>
<wire x1="4.953" y1="6.731" x2="4.953" y2="-1.016" width="0.0508" layer="21"/>
<wire x1="4.953" y1="6.731" x2="-4.953" y2="6.731" width="0.0508" layer="21"/>
<wire x1="4.953" y1="-1.016" x2="-4.953" y2="-1.016" width="0.0508" layer="21"/>
<wire x1="-4.953" y1="6.731" x2="-4.953" y2="-1.016" width="0.0508" layer="21"/>
<wire x1="-2.794" y1="-4.191" x2="-3.175" y2="-3.81" width="0.508" layer="21"/>
<wire x1="3.175" y1="-3.81" x2="2.794" y2="-4.191" width="0.508" layer="21"/>
<circle x="0" y="11.176" radius="1.8034" width="0.1524" layer="21"/>
<circle x="0" y="11.176" radius="2.921" width="0" layer="42"/>
<circle x="0" y="11.176" radius="2.921" width="0" layer="43"/>
<pad name="C" x="-2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="A" x="2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<text x="-2.54" y="4.191" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="1.651" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.826" y="8.382" size="0.9906" layer="21" ratio="10">A17,5mm</text>
<rectangle x1="2.159" y1="-4.445" x2="2.921" y2="-3.81" layer="21"/>
<rectangle x1="-2.921" y1="-4.445" x2="-2.159" y2="-3.81" layer="21"/>
<rectangle x1="-3.429" y1="-3.81" x2="-2.159" y2="-1.27" layer="21"/>
<rectangle x1="2.159" y1="-3.81" x2="3.429" y2="-1.27" layer="21"/>
<rectangle x1="2.159" y1="-6.35" x2="2.921" y2="-4.445" layer="51"/>
<rectangle x1="-2.921" y1="-6.35" x2="-2.159" y2="-4.445" layer="51"/>
<hole x="0" y="11.176" drill="3.302"/>
</package>
<package name="C221B1B">
<pad name="A" x="-2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="C" x="2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
</package>
<package name="C221B1AS">
<wire x1="5.207" y1="-1.143" x2="5.08" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-4.826" x2="5.08" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-4.826" x2="-4.826" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-4.572" x2="-4.826" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-4.572" x2="-5.207" y2="-1.143" width="0.1524" layer="21"/>
<text x="-5.08" y="-6.4262" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-8.001" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.334" y1="-1.397" x2="-3.429" y2="-0.889" layer="21"/>
<rectangle x1="-3.429" y1="-1.397" x2="-1.651" y2="-0.889" layer="51"/>
<rectangle x1="3.429" y1="-1.397" x2="5.334" y2="-0.889" layer="21"/>
<rectangle x1="1.651" y1="-1.397" x2="3.429" y2="-0.889" layer="51"/>
<rectangle x1="-1.651" y1="-1.397" x2="1.651" y2="-0.889" layer="21"/>
<rectangle x1="-5.334" y1="-0.889" x2="5.334" y2="0" layer="21"/>
</package>
<package name="C221B1BS">
<pad name="C" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="A" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-5.08" y="-6.5532" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-8.128" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C221A4">
<wire x1="0.381" y1="-3.683" x2="0" y2="-4.064" width="0.508" layer="21"/>
<wire x1="0" y1="-4.064" x2="-0.381" y2="-3.683" width="0.508" layer="21"/>
<pad name="A1" x="-2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="A2" x="2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="C" x="0" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<rectangle x1="-0.635" y1="-3.81" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="-0.381" y1="-6.35" x2="0.381" y2="-4.445" layer="51"/>
<rectangle x1="-0.381" y1="-4.445" x2="0.381" y2="-3.81" layer="21"/>
</package>
<package name="TO220CH">
<wire x1="5.207" y1="14.605" x2="-5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-1.27" x2="5.207" y2="11.176" width="0.1524" layer="21"/>
<wire x1="5.207" y1="11.176" x2="4.318" y2="11.176" width="0.1524" layer="21"/>
<wire x1="4.318" y1="11.176" x2="4.318" y2="12.7" width="0.1524" layer="21"/>
<wire x1="4.318" y1="12.7" x2="5.207" y2="12.7" width="0.1524" layer="21"/>
<wire x1="5.207" y1="12.7" x2="5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="11.176" x2="-4.318" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="11.176" x2="-4.318" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="12.7" x2="-5.207" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="12.7" x2="-5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<wire x1="-0.381" y1="-3.81" x2="-0.254" y2="-3.937" width="0.508" layer="21"/>
<wire x1="0.381" y1="-3.81" x2="0.254" y2="-3.937" width="0.508" layer="21"/>
<pad name="A1" x="-2.54" y="-3.81" drill="1.1176" shape="long" rot="R90"/>
<pad name="C" x="0" y="-8.89" drill="1.1176" shape="long" rot="R90"/>
<pad name="A2" x="2.54" y="-3.81" drill="1.1176" shape="long" rot="R90"/>
<text x="-5.588" y="-1.27" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.937" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="7.874" size="0.9906" layer="21" ratio="10">A15,2mm</text>
<rectangle x1="-3.175" y1="-2.159" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="-3.175" y1="-3.81" x2="-1.905" y2="-2.159" layer="51"/>
<rectangle x1="1.905" y1="-2.159" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-3.81" x2="3.175" y2="-2.159" layer="51"/>
<rectangle x1="-0.381" y1="-8.89" x2="0.381" y2="-7.239" layer="51"/>
<rectangle x1="-0.381" y1="-7.239" x2="0.381" y2="-3.937" layer="21"/>
<rectangle x1="-0.635" y1="-3.937" x2="0.635" y2="-1.27" layer="21"/>
</package>
<package name="TO220CSH">
<pad name="C" x="0" y="-7.62" drill="1.016" shape="long" rot="R90"/>
<text x="1.524" y="-6.0452" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="1.524" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-0.508" y1="-7.62" x2="0.508" y2="-5.842" layer="51"/>
<rectangle x1="-0.508" y1="-5.842" x2="0.508" y2="-4.318" layer="21"/>
</package>
<package name="C1103">
2-leaded metal can</description>
<wire x1="-17.4498" y1="3.9624" x2="-17.4011" y2="-3.9914" width="0.1524" layer="21" curve="118.558689"/>
<wire x1="-13.0556" y1="2.7432" x2="13.0556" y2="2.7432" width="0.1524" layer="21" curve="-156.267631"/>
<wire x1="-13.0556" y1="-2.7432" x2="13.0556" y2="-2.7432" width="0.1524" layer="21" curve="156.267631"/>
<wire x1="17.6276" y1="-3.8354" x2="7.2136" y2="-11.2268" width="0.1524" layer="21"/>
<wire x1="-17.4498" y1="3.9624" x2="-6.731" y2="11.5062" width="0.1524" layer="21"/>
<wire x1="-17.399" y1="-3.9878" x2="-7.2136" y2="-11.2268" width="0.1524" layer="21"/>
<wire x1="17.6276" y1="-3.8354" x2="18.0062" y2="3.5531" width="0.1524" layer="21" curve="106.57825"/>
<wire x1="13.0556" y1="-2.7432" x2="13.3039" y2="-0.9902" width="0.1524" layer="51" curve="7.609539"/>
<wire x1="-13.3039" y1="0.9902" x2="-13.0556" y2="2.7432" width="0.1524" layer="51" curve="-7.609539"/>
<wire x1="-13.3096" y1="-0.9906" x2="-13.0612" y2="-2.7444" width="0.1524" layer="51" curve="7.609749"/>
<wire x1="13.5128" y1="-6.7564" x2="14.72" y2="-3.4008" width="0.1524" layer="21" curve="13.556147"/>
<wire x1="14.732" y1="-3.4036" x2="14.983" y2="-2.0316" width="0.1524" layer="51" curve="5.287163"/>
<wire x1="13.5382" y1="-6.7056" x2="14.7201" y2="-3.4009" width="0.1524" layer="21" curve="13.340541"/>
<wire x1="14.732" y1="-3.3274" x2="14.9661" y2="-2.0293" width="0.1524" layer="51" curve="5.005596"/>
<wire x1="-14.732" y1="-3.4036" x2="-13.5238" y2="-6.7619" width="0.1524" layer="21" curve="13.556012"/>
<wire x1="-14.986" y1="-2.032" x2="-14.735" y2="-3.4043" width="0.1524" layer="51" curve="5.287251"/>
<wire x1="-14.7201" y1="3.4009" x2="-13.5382" y2="6.7056" width="0.1524" layer="21" curve="-13.340541"/>
<wire x1="-14.9661" y1="2.0293" x2="-14.732" y2="3.3274" width="0.1524" layer="51" curve="-5.005596"/>
<wire x1="18.0086" y1="3.556" x2="6.731" y2="11.5062" width="0.1524" layer="21"/>
<wire x1="13.0612" y1="2.7444" x2="13.3096" y2="0.9906" width="0.1524" layer="51" curve="-7.609749"/>
<wire x1="13.5491" y1="6.711" x2="14.732" y2="3.4036" width="0.1524" layer="21" curve="-13.340582"/>
<wire x1="14.7515" y1="3.3318" x2="14.986" y2="2.032" width="0.1524" layer="51" curve="-5.00551"/>
<wire x1="14.735" y1="3.4043" x2="14.986" y2="2.032" width="0.1524" layer="51" curve="-5.287251"/>
<circle x="0" y="0" radius="11.176" width="0.1524" layer="21"/>
<circle x="15.0876" y="0" radius="2.032" width="0.1524" layer="51"/>
<circle x="15.113" y="0" radius="3.429" width="0.1524" layer="51"/>
<circle x="-15.113" y="0" radius="3.429" width="0.1524" layer="51"/>
<circle x="-15.0876" y="0" radius="2.032" width="0.1524" layer="51"/>
<pad name="A2" x="-1.778" y="-5.461" drill="1.3208" shape="long"/>
<pad name="A1" x="-1.778" y="5.461" drill="1.3208" shape="long"/>
<pad name="C" x="15.113" y="0" drill="4.1148" diameter="6.477"/>
<pad name="C@1" x="-15.113" y="0" drill="4.1148" diameter="6.477"/>
<text x="2.54" y="-2.54" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="5.08" y="-5.08" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
</package>
<package name="C1103/">
2-leaded metal can / 45 deg.</description>
<wire x1="-7.2898" y1="11.176" x2="11.176" y2="-7.2898" width="0.1524" layer="21" curve="-156.230628"/>
<wire x1="-11.176" y1="7.2898" x2="7.2898" y2="-11.176" width="0.1524" layer="21" curve="156.230628"/>
<wire x1="-9.5504" y1="15.1384" x2="3.3782" y2="12.9032" width="0.1524" layer="21"/>
<wire x1="9.7536" y1="-15.1892" x2="-2.8448" y2="-13.0302" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="9.4742" x2="-13.0302" y2="-2.8448" width="0.1524" layer="21"/>
<wire x1="-15.1183" y1="9.4728" x2="-9.5504" y2="15.1384" width="0.1524" layer="21" curve="-119.068999"/>
<wire x1="-12.8103" y1="7.9906" x2="-12.0142" y2="9.144" width="0.1524" layer="51" curve="-5.320346"/>
<wire x1="-14.3344" y1="4.8035" x2="-12.827" y2="8.001" width="0.1524" layer="21" curve="-13.428168"/>
<wire x1="-9.1544" y1="12.0279" x2="-8.0772" y2="12.7762" width="0.1524" layer="51" curve="-4.973392"/>
<wire x1="-11.1777" y1="7.2909" x2="-10.1092" y2="8.7122" width="0.1524" layer="51" curve="-7.639797"/>
<wire x1="-8.7109" y1="10.1077" x2="-7.2898" y2="11.176" width="0.1524" layer="51" curve="-7.639871"/>
<wire x1="-8.0004" y1="12.826" x2="-4.826" y2="14.3256" width="0.1524" layer="21" curve="-13.336802"/>
<wire x1="15.24" y1="-10.2108" x2="12.9032" y2="3.3782" width="0.1524" layer="21"/>
<wire x1="9.7536" y1="-15.1892" x2="15.2278" y2="-10.212" width="0.1524" layer="21" curve="106.804044"/>
<wire x1="12.0142" y1="-9.144" x2="12.7617" y2="-8.068" width="0.1524" layer="51" curve="4.973506"/>
<wire x1="12.0142" y1="-9.144" x2="12.8103" y2="-7.9906" width="0.1524" layer="51" curve="5.320346"/>
<wire x1="8.001" y1="-12.827" x2="9.1559" y2="-12.0298" width="0.1524" layer="51" curve="5.320342"/>
<wire x1="8.0772" y1="-12.7762" x2="9.1544" y2="-12.0279" width="0.1524" layer="51" curve="4.973392"/>
<wire x1="4.8006" y1="-14.3256" x2="7.9961" y2="-12.8192" width="0.1524" layer="21" curve="13.427977"/>
<wire x1="4.826" y1="-14.3256" x2="8.0004" y2="-12.826" width="0.1524" layer="21" curve="13.336802"/>
<wire x1="7.2898" y1="-11.176" x2="8.7109" y2="-10.1077" width="0.1524" layer="51" curve="7.639871"/>
<wire x1="10.1092" y1="-8.7122" x2="11.1777" y2="-7.2909" width="0.1524" layer="51" curve="7.639797"/>
<wire x1="12.827" y1="-8.001" x2="14.3267" y2="-4.8264" width="0.1524" layer="21" curve="13.336613"/>
<circle x="-10.668" y="10.668" radius="2.032" width="0.1524" layer="51"/>
<circle x="10.668" y="-10.668" radius="2.032" width="0.1524" layer="51"/>
<pad name="A2" x="-5.08" y="-2.54" drill="1.3208" shape="octagon"/>
<pad name="A1" x="2.54" y="5.08" drill="1.3208" shape="octagon"/>
<pad name="C" x="10.668" y="-10.668" drill="4.1148" diameter="6.477"/>
<pad name="C@1" x="-10.668" y="10.668" drill="4.1148" diameter="6.477"/>
<text x="-1.905" y="0" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DO07">
diameter 2.54 mm, horizontal, grid 10.16 mm</description>
<wire x1="3.302" y1="1.27" x2="3.556" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.556" y1="1.016" x2="-3.302" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.556" y1="-1.016" x2="-3.302" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="3.302" y1="-1.27" x2="3.556" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="3.556" y1="-1.016" x2="3.556" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.016" x2="-3.556" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.27" x2="3.302" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-1.27" x2="3.302" y2="-1.27" width="0.1524" layer="21"/>
<text x="-3.429" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="1.27" layer="21"/>
<rectangle x1="3.556" y1="-0.254" x2="4.191" y2="0.254" layer="21"/>
<rectangle x1="-4.191" y1="-0.254" x2="-3.556" y2="0.254" layer="21"/>
</package>
<package name="F126-10">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 3 mm, horizontal, grid 10.16 mm</description>
<wire x1="-3.175" y1="-1.524" x2="3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.524" x2="-3.175" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.524" x2="3.175" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.524" x2="-3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="3.81" y2="0" width="0.8128" layer="51"/>
<wire x1="-5.08" y1="0" x2="-3.81" y2="0" width="0.8128" layer="51"/>
<pad name="C" x="-5.08" y="0" drill="1.016" shape="long"/>
<pad name="A" x="5.08" y="0" drill="1.016" shape="long"/>
<text x="-3.175" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.54" y1="-1.524" x2="-1.778" y2="1.524" layer="21"/>
<rectangle x1="3.175" y1="-0.4064" x2="3.7338" y2="0.4064" layer="21"/>
<rectangle x1="-3.7338" y1="-0.4064" x2="-3.175" y2="0.4064" layer="21"/>
</package>
<package name="F126-12">
diameter 3 mm, horizontal, grid 12.7 mm</description>
<wire x1="6.35" y1="0" x2="4.826" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.35" y1="0" x2="-4.826" y2="0" width="0.8128" layer="51"/>
<pad name="C" x="-6.35" y="0" drill="1.016" shape="long"/>
<pad name="A" x="6.35" y="0" drill="1.016" shape="long"/>
<rectangle x1="-4.8514" y1="-0.4064" x2="-3.175" y2="0.4064" layer="21"/>
<rectangle x1="3.175" y1="-0.4064" x2="4.8514" y2="0.4064" layer="21"/>
</package>
<package name="IW220ACS">
2-lead molded, vertical</description>
<wire x1="4.699" y1="-4.318" x2="4.953" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="-4.699" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-4.699" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="5.334" y1="-0.127" x2="4.953" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-5.334" y2="-0.127" width="0.1524" layer="21"/>
<circle x="-4.4958" y="-3.7084" radius="0.254" width="0" layer="21"/>
<pad name="C" x="-2.54" y="-2.54" drill="1.1176" shape="long" rot="R90"/>
<pad name="A" x="2.54" y="-2.54" drill="1.1176" shape="long" rot="R90"/>
<text x="-5.08" y="-5.9182" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.334" y1="-0.762" x2="5.334" y2="0" layer="21"/>
<rectangle x1="-5.334" y1="-1.27" x2="-3.429" y2="-0.762" layer="21"/>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="-0.762" layer="51"/>
<rectangle x1="1.651" y1="-1.27" x2="3.429" y2="-0.762" layer="51"/>
<rectangle x1="-1.651" y1="-1.27" x2="1.651" y2="-0.762" layer="21"/>
<rectangle x1="3.937" y1="-2.794" x2="5.08" y2="-1.27" layer="21"/>
<rectangle x1="3.429" y1="-1.27" x2="5.207" y2="-0.762" layer="21"/>
<rectangle x1="5.08" y1="-1.905" x2="5.207" y2="-1.27" layer="21"/>
<rectangle x1="1.143" y1="-2.794" x2="3.937" y2="-1.27" layer="51"/>
<rectangle x1="-1.143" y1="-2.794" x2="1.143" y2="-1.27" layer="21"/>
<rectangle x1="-3.937" y1="-2.794" x2="-1.143" y2="-1.27" layer="51"/>
<rectangle x1="-5.08" y1="-2.794" x2="-3.937" y2="-1.27" layer="21"/>
<rectangle x1="-5.207" y1="-1.905" x2="-5.08" y2="-1.27" layer="21"/>
</package>
<package name="IW220ABS">
3-lead molded, vertical</description>
<pad name="A1" x="-2.54" y="-2.54" drill="1.1176" shape="long" rot="R90"/>
<pad name="C" x="0" y="-2.54" drill="1.1176" shape="long" rot="R90"/>
<pad name="A2" x="2.54" y="-2.54" drill="1.1176" shape="long" rot="R90"/>
<text x="-4.572" y="-6.0452" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.572" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="1.651" y1="-2.794" x2="3.429" y2="-0.762" layer="51"/>
<rectangle x1="3.429" y1="-2.794" x2="5.08" y2="-1.27" layer="21"/>
<rectangle x1="-0.889" y1="-2.794" x2="0.889" y2="-0.762" layer="51"/>
<rectangle x1="-3.429" y1="-2.794" x2="-1.651" y2="-0.762" layer="51"/>
<rectangle x1="0.889" y1="-2.794" x2="1.651" y2="-0.762" layer="21"/>
<rectangle x1="-1.651" y1="-2.794" x2="-0.889" y2="-0.762" layer="21"/>
<rectangle x1="-5.08" y1="-2.794" x2="-3.429" y2="-1.27" layer="21"/>
</package>
<package name="F126-10A">
</package>
<package name="F126-12A">
</package>
<package name="F126Z10A">
diameter 3 mm, horizontal, grid 7.62 mm</description>
<wire x1="0.254" y1="0.635" x2="0" y2="0.635" width="0.1524" layer="21"/>
</package>
<package name="F126Z12A">
</package>
<package name="DO35-7B">
diameter 2 mm, horizontal, grid 7.62 mm</description>
<wire x1="3.81" y1="0" x2="2.667" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.667" y2="0" width="0.508" layer="51"/>
<wire x1="2.032" y1="1.016" x2="2.286" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="0.762" x2="-2.032" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="-0.762" x2="-2.032" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.032" y1="-1.016" x2="2.286" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="0.762" x2="2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0.762" x2="-2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.016" x2="2.032" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.016" x2="2.032" y2="-1.016" width="0.1524" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="3.81" y="0" drill="0.8128" shape="long"/>
<text x="-2.286" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.905" y1="-1.016" x2="-1.397" y2="1.016" layer="21"/>
<rectangle x1="-2.667" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
<rectangle x1="2.286" y1="-0.254" x2="2.667" y2="0.254" layer="21"/>
</package>
<package name="C1702-05">
diameter 3.5 mm, vertical, grid 5.08 mm</description>
<wire x1="2.54" y1="0" x2="0.762" y2="0" width="1.0668" layer="51"/>
<wire x1="-2.54" y1="0" x2="-0.889" y2="0" width="1.0668" layer="51"/>
<circle x="-2.54" y="0" radius="1.778" width="0.1524" layer="21"/>
<pad name="C" x="-2.54" y="0" drill="1.397" shape="octagon"/>
<pad name="A" x="2.54" y="0" drill="1.397" shape="octagon"/>
<text x="-4.318" y="2.032" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-0.7366" y1="-0.5334" x2="0.635" y2="0.5334" layer="21"/>
</package>
<package name="SIL05C">
<description>4 &lt;B&gt;DIODES&lt;/B&gt;&lt;p&gt;
single in line 4 diodes with common cathode</description>
<wire x1="5.842" y1="2.032" x2="-5.842" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.143" x2="-4.318" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="1.143" x2="-4.318" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="-1.143" x2="-5.842" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="-5.842" y1="-1.143" x2="-5.842" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="1.524" x2="-4.191" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-1.524" x2="-5.969" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="1.524" x2="-5.842" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="5.842" y1="2.032" x2="6.35" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="5.842" y1="-2.032" x2="6.35" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.35" y1="-1.524" x2="-5.842" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="6.35" y1="-1.524" x2="6.35" y2="1.524" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-2.032" x2="-5.842" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-1.524" x2="-6.35" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="1.524" x2="-5.969" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="1.524" x2="-5.969" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="-1.016" x2="-0.635" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="1.397" y1="-1.016" x2="0.635" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-1.016" x2="0.635" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="0.635" y1="-0.381" x2="0.635" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="0.635" y1="-1.016" x2="0.635" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="0.635" y1="-1.651" x2="-0.635" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-1.651" x2="-0.635" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-1.016" x2="-0.635" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="0.635" y1="-1.016" x2="-0.635" y2="-1.016" width="0.1524" layer="51"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="5.08" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-5.969" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.969" y="-3.556" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SIL05A">
single in line 4 diodes with common anode</description>
<wire x1="-5.842" y1="1.016" x2="-4.318" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="1.016" x2="-4.318" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="-1.016" x2="-5.842" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-5.842" y1="-1.016" x2="-5.842" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-4.064" y1="1.524" x2="-4.064" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="-1.524" x2="-6.096" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="1.524" x2="-6.096" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="1.524" x2="-6.096" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.397" y1="-1.143" x2="0.635" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="-1.397" y1="-1.143" x2="-0.635" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="0.635" y1="-1.143" x2="-0.635" y2="-1.778" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-1.778" x2="-0.635" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-1.143" x2="-0.635" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-0.508" x2="0.635" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="0.635" y1="-0.508" x2="0.635" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="0.635" y1="-1.143" x2="0.635" y2="-1.778" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-1.143" x2="0.635" y2="-1.143" width="0.1524" layer="51"/>
<text x="-6.096" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.223" y="-3.556" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SIL08A">
<description>7 &lt;B&gt;DIODES&lt;/B&gt;&lt;p&gt;
single in line 7 diodes with common anode</description>
<wire x1="-9.652" y1="-2.032" x2="9.652" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="9.652" y1="2.032" x2="-9.652" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-9.652" y1="1.143" x2="-8.128" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-8.128" y1="1.143" x2="-8.128" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="-8.128" y1="-1.143" x2="-9.652" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="-9.652" y1="-1.143" x2="-9.652" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-8.001" y1="1.524" x2="-8.001" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-1.524" x2="-9.779" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="1.524" x2="-9.652" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="9.652" y1="-2.032" x2="10.16" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="9.652" y1="2.032" x2="10.16" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="-10.16" y1="-1.524" x2="-9.652" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="10.16" y1="1.524" x2="10.16" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="1.524" x2="-10.16" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="-1.524" x2="-9.779" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="1.524" x2="-8.001" y2="1.524" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-1.016" x2="0.762" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="-1.016" x2="-0.508" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="0.762" y1="-1.016" x2="-0.508" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-1.651" x2="-0.508" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-1.016" x2="-0.508" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-0.381" x2="0.762" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="0.762" y1="-0.381" x2="0.762" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="0.762" y1="-1.016" x2="0.762" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-1.016" x2="0.762" y2="-1.016" width="0.1524" layer="51"/>
<pad name="1" x="-8.89" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-6.35" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-3.81" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="3.81" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="6.35" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="8.89" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-9.652" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-9.652" y="-3.556" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SIL08C">
single in line 7 diodes with common cathode</description>
</package>
<package name="SIL09A">
<description>8 &lt;B&gt;DIODES&lt;/B&gt;&lt;p&gt;
single in line 8 diodes with common anode</description>
<wire x1="-10.922" y1="-2.032" x2="10.922" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="10.922" y1="2.032" x2="-10.922" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-10.922" y1="1.143" x2="-9.398" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="1.143" x2="-9.398" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="-9.398" y1="-1.143" x2="-10.922" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="-10.922" y1="-1.143" x2="-10.922" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-9.271" y1="1.524" x2="-9.271" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-9.271" y1="-1.524" x2="-11.049" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="1.524" x2="-10.922" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="10.922" y1="-2.032" x2="11.43" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="10.922" y1="2.032" x2="11.43" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="-11.43" y1="-1.524" x2="-10.922" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="11.43" y1="1.524" x2="11.43" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-1.524" x2="-11.43" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="-1.524" x2="-11.049" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="1.524" x2="-9.271" y2="1.524" width="0.1524" layer="21"/>
<pad name="1" x="-10.16" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-7.62" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-5.08" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="5.08" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="10.16" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-10.922" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-10.922" y="-3.556" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SIL09C">
single in line 8 diodes with common cathode</description>
<text x="-11.176" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-11.176" y="-3.556" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TO236">
3-lead smd</description>
<wire x1="-1.4" y1="1.15" x2="-0.7" y2="1.15" width="0.2032" layer="21"/>
<wire x1="-1.4" y1="1.15" x2="-1.4" y2="-0.2" width="0.2032" layer="21"/>
<wire x1="-0.3" y1="-1.15" x2="0.3" y2="-1.15" width="0.2032" layer="21"/>
<wire x1="1.4" y1="-0.2" x2="1.4" y2="1.15" width="0.2032" layer="21"/>
<wire x1="1.4" y1="1.15" x2="0.7" y2="1.15" width="0.2032" layer="21"/>
<wire x1="-0.7" y1="1.15" x2="0.7" y2="1.15" width="0.2032" layer="51"/>
<wire x1="-1.4" y1="-0.2" x2="-1.4" y2="-1.15" width="0.2032" layer="51"/>
<wire x1="-1.4" y1="-1.15" x2="-0.3" y2="-1.15" width="0.2032" layer="51"/>
<wire x1="0.3" y1="-1.15" x2="1.4" y2="-1.15" width="0.2032" layer="51"/>
<wire x1="1.4" y1="-1.15" x2="1.4" y2="-0.2" width="0.2032" layer="51"/>
<smd name="C" x="0" y="1" dx="1" dy="1.2" layer="1"/>
<smd name="A" x="-1" y="-1" dx="1" dy="1.2" layer="1"/>
<smd name="NC" x="1" y="-1" dx="1" dy="1.2" layer="1"/>
<text x="-1.397" y="1.794" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.524" y="-3.064" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2" y1="0.6" x2="0.2" y2="1.25" layer="51"/>
<rectangle x1="-1.2" y1="-1.25" x2="-0.8" y2="-0.6" layer="51"/>
<rectangle x1="0.8" y1="-1.25" x2="1.2" y2="-0.6" layer="51"/>
</package>
<package name="SOT23">
<description>&lt;B&gt;DIODE&lt;/B&gt;</description>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="-0.1524" x2="-1.4224" y2="0.6604" width="0.1524" layer="21"/>
<wire x1="-1.4224" y1="0.6604" x2="-0.8636" y2="0.6604" width="0.1524" layer="21"/>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.1524" width="0.1524" layer="21"/>
<wire x1="0.8636" y1="0.6604" x2="1.4224" y2="0.6604" width="0.1524" layer="21"/>
<smd name="3" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="2" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="1" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2286" y1="0.7112" x2="0.2286" y2="1.2954" layer="51"/>
<rectangle x1="0.7112" y1="-1.2954" x2="1.1684" y2="-0.7112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.2954" x2="-0.7112" y2="-0.7112" layer="51"/>
</package>
<package name="SOD523">
<wire x1="-0.59" y1="0.4" x2="0.59" y2="0.4" width="0.1016" layer="51"/>
<wire x1="0.59" y1="0.4" x2="0.59" y2="-0.4" width="0.1016" layer="51"/>
<wire x1="0.59" y1="-0.4" x2="-0.59" y2="-0.4" width="0.1016" layer="51"/>
<wire x1="-0.59" y1="-0.4" x2="-0.59" y2="0.4" width="0.1016" layer="51"/>
<smd name="A" x="0.7" y="0" dx="0.7" dy="0.5" layer="1"/>
<smd name="C" x="-0.6" y="0" dx="0.7" dy="0.5" layer="1"/>
<text x="-0.635" y="0.635" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-1.905" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.75" y1="-0.17" x2="-0.54" y2="0.17" layer="51"/>
<rectangle x1="0.54" y1="-0.17" x2="0.75" y2="0.17" layer="51"/>
<rectangle x1="-0.59" y1="-0.4" x2="-0.3" y2="0.4" layer="51"/>
</package>
<package name="SOD80C">
<wire x1="1.3208" y1="0.7874" x2="-1.3208" y2="0.7874" width="0.1524" layer="51"/>
<wire x1="1.3208" y1="-0.7874" x2="-1.3208" y2="-0.7874" width="0.1524" layer="51"/>
<wire x1="0.627" y1="0.6" x2="-0.373" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.373" y1="0" x2="0.627" y2="-0.6" width="0.2032" layer="21"/>
<wire x1="0.627" y1="-0.6" x2="0.627" y2="0.6" width="0.2032" layer="21"/>
<smd name="C" x="-1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<smd name="A" x="1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<text x="-1.524" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.8542" y1="-0.8636" x2="-1.2954" y2="0.8636" layer="51"/>
<rectangle x1="1.2954" y1="-0.8636" x2="1.8542" y2="0.8636" layer="51"/>
<rectangle x1="-0.8636" y1="-0.7874" x2="-0.254" y2="0.7874" layer="21"/>
</package>
<package name="SMB">
<wire x1="-2.2606" y1="1.905" x2="2.2606" y2="1.905" width="0.1016" layer="21"/>
<wire x1="-2.2606" y1="-1.905" x2="2.2606" y2="-1.905" width="0.1016" layer="21"/>
<wire x1="-2.2606" y1="-1.905" x2="-2.2606" y2="1.905" width="0.1016" layer="51"/>
<wire x1="2.2606" y1="-1.905" x2="2.2606" y2="1.905" width="0.1016" layer="51"/>
<wire x1="0.193" y1="1" x2="-0.83" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.83" y1="0" x2="0.193" y2="-1" width="0.2032" layer="21"/>
<wire x1="0.193" y1="-1" x2="0.193" y2="1" width="0.2032" layer="21"/>
<smd name="C" x="-2.2" y="0" dx="2.4" dy="2.4" layer="1"/>
<smd name="A" x="2.2" y="0" dx="2.4" dy="2.4" layer="1"/>
<text x="-2.159" y="2.159" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.159" y="-3.429" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.794" y1="-1.0922" x2="-2.2606" y2="1.0922" layer="51"/>
<rectangle x1="2.2606" y1="-1.0922" x2="2.794" y2="1.0922" layer="51"/>
<rectangle x1="-1.35" y1="-1.9" x2="-0.8" y2="1.9" layer="51"/>
</package>
<package name="D-10">
<description>&lt;b&gt;DIODE&lt;/b&gt;</description>
<wire x1="-3.175" y1="0" x2="-3.937" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.524" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="3.937" y1="0" x2="3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.524" x2="3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0" x2="-3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="0" x2="3.175" y2="1.524" width="0.1524" layer="21"/>
<text x="-3.175" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.286" y1="-1.524" x2="-1.524" y2="1.524" layer="21"/>
</package>
<package name="D-12.5">
<wire x1="-3.175" y1="0" x2="-5.207" y2="0" width="0.1524" layer="21"/>
<wire x1="5.207" y1="0" x2="3.175" y2="0" width="0.1524" layer="21"/>
<pad name="A" x="6.35" y="0" drill="0.8128" shape="long"/>
<pad name="C" x="-6.35" y="0" drill="0.8128" shape="long"/>
</package>
<package name="D-2.5">
<wire x1="0.508" y1="0.762" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="0.508" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.762" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-1.27" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0" x2="0.508" y2="0" width="0.1524" layer="51"/>
<wire x1="0.508" y1="-0.762" x2="0.508" y2="0.762" width="0.1524" layer="21"/>
<text x="-1.651" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="D-7.5">
<wire x1="1.905" y1="0.889" x2="-1.905" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-0.889" x2="1.905" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0" x2="-2.794" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0.889" x2="-1.905" y2="0" width="0.1524" layer="21"/>
<wire x1="2.794" y1="0" x2="1.905" y2="0" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-0.889" x2="1.905" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0" x2="-1.905" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.905" y1="0" x2="1.905" y2="0.889" width="0.1524" layer="21"/>
<text x="-1.905" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.27" y1="-0.889" x2="-0.762" y2="0.889" layer="21"/>
</package>
<package name="ZDIO-5">
<description>&lt;b&gt;Z DIODE&lt;/b&gt;</description>
<wire x1="0" y1="1.27" x2="-1.27" y2="1.27" width="0.254" layer="21"/>
<wire x1="-1.27" y1="0" x2="1.27" y2="1.27" width="0.254" layer="21"/>
<wire x1="1.27" y1="1.27" x2="1.27" y2="0" width="0.254" layer="21"/>
<wire x1="1.27" y1="-1.27" x2="-1.27" y2="0" width="0.254" layer="21"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="0" width="0.254" layer="21"/>
<wire x1="1.27" y1="0" x2="1.651" y2="0" width="0.254" layer="21"/>
<wire x1="1.27" y1="0" x2="1.27" y2="-1.27" width="0.254" layer="21"/>
<wire x1="-1.651" y1="0" x2="-1.27" y2="0" width="0.254" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-1.27" width="0.254" layer="21"/>
<wire x1="-1.27" y1="-1.27" x2="-2.54" y2="-1.27" width="0.254" layer="21"/>
<pad name="A" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="C" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.6162" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ZDIO-10">
<wire x1="-3.556" y1="0" x2="-1.27" y2="0" width="0.254" layer="21"/>
<wire x1="1.27" y1="0" x2="3.556" y2="0" width="0.254" layer="21"/>
<text x="-2.4892" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="ZDIO12.5">
<wire x1="1.27" y1="0" x2="4.699" y2="0" width="0.254" layer="21"/>
<wire x1="-4.826" y1="0" x2="-1.27" y2="0" width="0.254" layer="21"/>
<pad name="A" x="6.223" y="0" drill="0.8128" shape="long"/>
<text x="-2.6162" y="1.7018" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.667" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ZDIO-7.5">
<wire x1="1.27" y1="0" x2="2.794" y2="0" width="0.254" layer="21"/>
<wire x1="-2.794" y1="0" x2="-1.27" y2="0" width="0.254" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="A" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.4892" y="1.7018" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="ZDIO-2.5">
<wire x1="-0.254" y1="0.762" x2="-0.508" y2="0.762" width="0.254" layer="21"/>
<wire x1="-0.508" y1="0" x2="0.762" y2="0.762" width="0.254" layer="21"/>
<wire x1="0.762" y1="-0.762" x2="-0.508" y2="0" width="0.254" layer="21"/>
<wire x1="-0.508" y1="0.762" x2="-0.508" y2="0" width="0.254" layer="21"/>
<wire x1="0.762" y1="0.762" x2="0.762" y2="-0.762" width="0.254" layer="51"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.508" y1="-0.762" x2="-0.762" y2="-0.762" width="0.254" layer="21"/>
<wire x1="0.508" y1="0.254" x2="0.508" y2="0" width="0.6096" layer="51"/>
<wire x1="0.508" y1="0" x2="0.508" y2="-0.254" width="0.6096" layer="51"/>
<wire x1="0.508" y1="0" x2="-0.254" y2="0" width="0.6096" layer="51"/>
<text x="-1.3462" y="1.0668" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="D-5">
<wire x1="1.397" y1="0.889" x2="-1.397" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="-0.889" x2="1.397" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="0.889" x2="-1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="1.397" y1="-0.889" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="0" x2="-1.397" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.397" y1="0" x2="1.397" y2="0.889" width="0.1524" layer="21"/>
<rectangle x1="-1.016" y1="-0.889" x2="-0.508" y2="0.889" layer="21"/>
</package>
<package name="SOT223">
<description>&lt;b&gt;Small Outline Transistor&lt;/b&gt;</description>
<wire x1="3.277" y1="1.778" x2="3.277" y2="-1.778" width="0.2032" layer="21"/>
<wire x1="3.277" y1="-1.778" x2="-3.277" y2="-1.778" width="0.2032" layer="21"/>
<wire x1="-3.277" y1="-1.778" x2="-3.277" y2="1.778" width="0.2032" layer="21"/>
<wire x1="-3.277" y1="1.778" x2="3.277" y2="1.778" width="0.2032" layer="21"/>
<smd name="1" x="-2.311" y="-3.099" dx="1.219" dy="2.235" layer="1"/>
<smd name="2" x="0" y="-3.099" dx="1.219" dy="2.235" layer="1"/>
<smd name="3" x="2.311" y="-3.099" dx="1.219" dy="2.235" layer="1"/>
<smd name="4" x="0" y="3.099" dx="3.6" dy="2.2" layer="1"/>
<text x="-2.54" y="0.0508" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-1.3208" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6002" y1="1.8034" x2="1.6002" y2="3.6576" layer="51"/>
<rectangle x1="-0.4318" y1="-3.6576" x2="0.4318" y2="-1.8034" layer="51"/>
<rectangle x1="-2.7432" y1="-3.6576" x2="-1.8796" y2="-1.8034" layer="51"/>
<rectangle x1="1.8796" y1="-3.6576" x2="2.7432" y2="-1.8034" layer="51"/>
</package>
<package name="SOD80-R">
<description>&lt;b&gt;SOD80 Reflow soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<smd name="C" x="-1.65" y="0" dx="1" dy="1.7" layer="1"/>
<smd name="A" x="1.65" y="0" dx="1" dy="1.7" layer="1"/>
</package>
<package name="SOD80-W">
<description>&lt;b&gt;SOD80 Wave soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
</package>
<package name="SOD110-R">
<description>&lt;b&gt;SOD110 Reflow soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<wire x1="-1" y1="0.5" x2="1.05" y2="0.5" width="0.1016" layer="51"/>
<wire x1="1.05" y1="0.5" x2="1.05" y2="-0.5" width="0.1016" layer="51"/>
<wire x1="1.05" y1="-0.5" x2="-1" y2="-0.5" width="0.1016" layer="51"/>
<wire x1="-1" y1="-0.5" x2="-1" y2="0.5" width="0.1016" layer="51"/>
<smd name="C" x="-0.95" y="0" dx="0.8" dy="1" layer="1"/>
<smd name="A" x="0.95" y="0" dx="0.8" dy="1" layer="1"/>
<rectangle x1="-0.65" y1="-0.45" x2="-0.4" y2="0.45" layer="51"/>
</package>
<package name="SOD106-R">
<description>&lt;b&gt;SOD106 Reflow soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<wire x1="1.8208" y1="0.7874" x2="-1.8208" y2="0.7874" width="0.1524" layer="51"/>
<wire x1="1.8208" y1="-0.7874" x2="-1.8208" y2="-0.7874" width="0.1524" layer="51"/>
<wire x1="0.127" y1="0.6" x2="-0.873" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.873" y1="0" x2="0.127" y2="-0.6" width="0.2032" layer="21"/>
<wire x1="0.127" y1="-0.6" x2="0.127" y2="0.6" width="0.2032" layer="21"/>
<smd name="C" x="-2.25" y="0" dx="1.6" dy="2.1" layer="1"/>
<smd name="A" x="2.25" y="0" dx="1.6" dy="2.1" layer="1"/>
<text x="-1.524" y="1.293" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.524" y="-2.563" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.3542" y1="-0.8636" x2="-1.7954" y2="0.8636" layer="51"/>
<rectangle x1="1.7954" y1="-0.8636" x2="2.3542" y2="0.8636" layer="51"/>
<rectangle x1="-1.3636" y1="-0.7874" x2="-0.754" y2="0.7874" layer="21"/>
</package>
<package name="SOD106-W">
<description>&lt;b&gt;SOD106 Wave soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<smd name="C" x="-2.85" y="0" dx="2.3" dy="3.2" layer="1"/>
<smd name="A" x="2.85" y="0" dx="2.3" dy="3.2" layer="1"/>
<text x="-3.374" y="1.793" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.324" y="-3.163" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="SOD106A-R">
<description>&lt;b&gt;SOD106A Reflow soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<smd name="C" x="-2.2" y="0" dx="1.7" dy="2.1" layer="1"/>
<smd name="A" x="2.2" y="0" dx="1.7" dy="2.1" layer="1"/>
<text x="-2.374" y="1.293" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.374" y="-2.513" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.3636" y1="-0.7874" x2="-0.754" y2="0.7874" layer="51"/>
</package>
<package name="SOD106A-W">
<description>&lt;b&gt;SOD106A Wave soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<smd name="C" x="-2.75" y="0" dx="3.1" dy="2.5" layer="1"/>
<smd name="A" x="2.75" y="0" dx="3.1" dy="2.5" layer="1"/>
</package>
<package name="SOD110-W">
<description>&lt;b&gt;SOD110 Wave soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<smd name="C" x="-1.15" y="0" dx="1" dy="1.2" layer="1"/>
<smd name="A" x="1.15" y="0" dx="1" dy="1.2" layer="1"/>
</package>
<package name="SOT23-R">
<description>&lt;b&gt;SOT323 Reflow soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<wire x1="1.5724" y1="0.6604" x2="1.5724" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="1.5724" y1="-0.6604" x2="-1.5724" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="-1.5724" y1="-0.6604" x2="-1.5724" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.5724" y1="0.6604" x2="1.5724" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.5724" y1="-0.6524" x2="-1.5724" y2="0.6604" width="0.1524" layer="21"/>
<wire x1="-1.5724" y1="0.6604" x2="-0.5136" y2="0.6604" width="0.1524" layer="21"/>
<wire x1="1.5724" y1="0.6604" x2="1.5724" y2="-0.6524" width="0.1524" layer="21"/>
<wire x1="0.5636" y1="0.6604" x2="1.5724" y2="0.6604" width="0.1524" layer="21"/>
<wire x1="0.4224" y1="-0.6604" x2="-0.4364" y2="-0.6604" width="0.1524" layer="21"/>
<smd name="3" x="0" y="1" dx="0.6" dy="0.7" layer="1"/>
<smd name="2" x="0.95" y="-1" dx="0.6" dy="0.7" layer="1"/>
<smd name="1" x="-0.95" y="-1" dx="0.6" dy="0.7" layer="1"/>
</package>
<package name="SOT23-W">
<description>&lt;b&gt;SOT323 Wave soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<smd name="3" x="0" y="1.3" dx="2.8" dy="1.4" layer="1"/>
<smd name="2" x="1.1" y="-1.3" dx="1.2" dy="1.4" layer="1"/>
<smd name="1" x="-1.1" y="-1.3" dx="1.2" dy="1.4" layer="1"/>
</package>
<package name="SOT143-R">
<description>&lt;b&gt;SOT143 / SOT143B Reflow soldering&lt;/b&gt;&lt;p&gt;
Source:  Philips SC01_Mounting_1996.pdf / BAS70_1PS7XSB70_SER_8.pdf</description>
<wire x1="-1.4478" y1="0.635" x2="1.4478" y2="0.635" width="0.1016" layer="51"/>
<wire x1="-1.4478" y1="-0.635" x2="1.4478" y2="-0.635" width="0.1016" layer="51"/>
<wire x1="-1.4478" y1="-0.635" x2="-1.4478" y2="0.635" width="0.1016" layer="51"/>
<wire x1="1.4478" y1="-0.635" x2="1.4478" y2="0.635" width="0.1016" layer="51"/>
<smd name="1" x="-0.75" y="-1" dx="1" dy="0.7" layer="1"/>
<smd name="3" x="0.95" y="1" dx="0.6" dy="0.7" layer="1"/>
<smd name="4" x="-0.95" y="1" dx="0.6" dy="0.7" layer="1"/>
<text x="-1.6" y="1.6" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.6" y="-2.85" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="0.7366" y1="-1.3208" x2="1.1938" y2="-0.635" layer="51"/>
<rectangle x1="0.7112" y1="0.635" x2="1.1684" y2="1.3208" layer="51"/>
<rectangle x1="-1.143" y1="0.635" x2="-0.6858" y2="1.3208" layer="51"/>
<rectangle x1="-1.1938" y1="-1.3208" x2="-0.3048" y2="-0.635" layer="51"/>
</package>
<package name="SOT143-W">
<description>&lt;b&gt;Wave soldering footprint SOT143B&lt;/b&gt;&lt;p&gt;
Source: Philips - BAS70_1PS7XSB70_SER_8.pdf</description>
<smd name="1" x="-1.1" y="-1.3" dx="1.2" dy="1.45" layer="1"/>
<smd name="2" x="1.2" y="-1.3" dx="1" dy="1.45" layer="1"/>
<smd name="3" x="1.1" y="1.3" dx="1.2" dy="1.45" layer="1"/>
<smd name="4" x="-1.1" y="1.3" dx="1.2" dy="1.45" layer="1"/>
<text x="-1.5" y="2.2" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.5" y="-3.45" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="SOT223-R">
<description>&lt;b&gt;SOT223 Reflow soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<wire x1="-3.35" y1="1.8" x2="-3.35" y2="-1.8" width="0.254" layer="51"/>
<wire x1="-3.35" y1="-1.8" x2="3.35" y2="-1.8" width="0.254" layer="51"/>
<wire x1="3.35" y1="-1.8" x2="3.35" y2="1.8" width="0.254" layer="51"/>
<wire x1="3.35" y1="1.8" x2="-3.35" y2="1.8" width="0.254" layer="51"/>
<wire x1="-3.35" y1="-1.8" x2="-3.35" y2="1.8" width="0.254" layer="21"/>
<wire x1="-3.35" y1="1.8" x2="-1.85" y2="1.8" width="0.254" layer="21"/>
<wire x1="3.35" y1="-1.8" x2="3.35" y2="1.8" width="0.254" layer="21"/>
<wire x1="3.35" y1="1.8" x2="1.85" y2="1.8" width="0.254" layer="21"/>
<wire x1="-1.5" y1="-1.8" x2="-0.8" y2="-1.8" width="0.254" layer="21"/>
<wire x1="0.8" y1="-1.8" x2="1.5" y2="-1.8" width="0.254" layer="21"/>
<smd name="1" x="-2.3" y="-3.05" dx="1.3" dy="1.3" layer="1"/>
<smd name="2" x="0" y="-3.05" dx="1.3" dy="1.3" layer="1"/>
<smd name="3" x="2.3" y="-3.05" dx="1.3" dy="1.3" layer="1"/>
<smd name="4" x="0" y="3.05" dx="3.6" dy="1.3" layer="1"/>
<text x="-3.25" y="3.9" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.95" y="-0.55" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.75" y1="-3.45" x2="-1.85" y2="-1.9" layer="51"/>
<rectangle x1="-0.45" y1="-3.45" x2="0.45" y2="-1.9" layer="51"/>
<rectangle x1="1.85" y1="-3.45" x2="2.75" y2="-1.9" layer="51"/>
<rectangle x1="-1.55" y1="1.9" x2="1.55" y2="3.45" layer="51"/>
</package>
<package name="SOT223-W">
<description>&lt;b&gt;SOT223 Wave soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<smd name="1" x="-2.7" y="-3.1" dx="1.9" dy="1.9" layer="1"/>
<smd name="2" x="0" y="-3.1" dx="1.1" dy="1.9" layer="1"/>
<smd name="3" x="2.7" y="-3.1" dx="1.9" dy="1.9" layer="1"/>
<smd name="4" x="0" y="3.1" dx="6.7" dy="1.9" layer="1"/>
<text x="-3.25" y="4.25" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="SOT323-R">
<description>&lt;b&gt;SOT323 Reflow soldering&lt;/b&gt;&lt;p&gt;
<wire x1="0.9224" y1="0.4604" x2="0.9224" y2="-0.4604" width="0.1524" layer="51"/>
<wire x1="0.9224" y1="-0.4604" x2="-0.9224" y2="-0.4604" width="0.1524" layer="51"/>
<wire x1="-0.9224" y1="-0.4604" x2="-0.9224" y2="0.4604" width="0.1524" layer="51"/>
<wire x1="-0.9224" y1="0.4604" x2="0.9224" y2="0.4604" width="0.1524" layer="51"/>
<wire x1="0.9224" y1="0.4604" x2="0.9224" y2="-0.4604" width="0.1524" layer="21"/>
<wire x1="0.9224" y1="-0.4604" x2="-0.9224" y2="-0.4604" width="0.1524" layer="21"/>
<wire x1="-0.9224" y1="-0.4604" x2="-0.9224" y2="0.4604" width="0.1524" layer="21"/>
<wire x1="-0.9224" y1="0.4604" x2="0.9224" y2="0.4604" width="0.1524" layer="21"/>
<smd name="1" x="-0.65" y="-0.925" dx="0.6" dy="0.55" layer="1"/>
<smd name="2" x="0.65" y="-0.925" dx="0.6" dy="0.55" layer="1"/>
<smd name="3" x="0" y="0.925" dx="0.6" dy="0.55" layer="1"/>
<text x="-1" y="1.3" size="1.27" layer="25">&gt;NAME</text>
<text x="-1" y="-2.6" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.8" y1="-1.1" x2="-0.5" y2="-0.5" layer="51"/>
<rectangle x1="0.5" y1="-1.1" x2="0.8" y2="-0.5" layer="51"/>
<rectangle x1="-0.15" y1="0.5" x2="0.15" y2="1.1" layer="51"/>
</package>
<package name="SOT323-W">
<description>&lt;b&gt;SOT323 Wave soldering&lt;/b&gt;&lt;p&gt;
<smd name="1" x="-0.9" y="-1.275" dx="0.9" dy="1.45" layer="1"/>
<smd name="2" x="0.9" y="-1.275" dx="0.9" dy="1.45" layer="1"/>
<smd name="3" x="0" y="1.275" dx="2.1" dy="1.45" layer="1"/>
<text x="-1" y="2.2" size="1.27" layer="25">&gt;NAME</text>
<text x="-1" y="-3.35" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="SC70-3-R">
<description>&lt;b&gt;SC70-3 Reflow soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
</package>
<package name="SC70-3-W">
<description>&lt;b&gt;SC70-3 Wave soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
</package>
<package name="SOT346-R">
<description>&lt;b&gt;SOT346 Reflow soldering&lt;/b&gt; (SC59) Philips SC01_Mounting_1996.pdf</description>
<wire x1="-1.55" y1="0.85" x2="1.55" y2="0.85" width="0.2032" layer="51"/>
<wire x1="1.55" y1="0.85" x2="1.55" y2="-0.85" width="0.2032" layer="51"/>
<wire x1="1.55" y1="-0.85" x2="-1.55" y2="-0.85" width="0.2032" layer="51"/>
<wire x1="-1.55" y1="-0.85" x2="-1.55" y2="0.85" width="0.2032" layer="51"/>
<wire x1="-1.55" y1="-0.85" x2="-1.55" y2="0.85" width="0.2032" layer="21"/>
<wire x1="-1.55" y1="0.85" x2="-0.6" y2="0.85" width="0.2032" layer="21"/>
<wire x1="0.6" y1="0.85" x2="1.55" y2="0.85" width="0.2032" layer="21"/>
<wire x1="1.55" y1="0.85" x2="1.55" y2="-0.85" width="0.2032" layer="21"/>
<wire x1="0.25" y1="-0.85" x2="-0.25" y2="-0.85" width="0.2032" layer="21"/>
<smd name="1" x="-0.95" y="-1.2" dx="0.7" dy="0.9" layer="1"/>
<smd name="2" x="0.95" y="-1.2" dx="0.7" dy="0.9" layer="1"/>
<smd name="3" x="0" y="1.2" dx="0.7" dy="0.9" layer="1"/>
<text x="-1.65" y="1.85" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.65" y="-3.1" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.15" y1="-1.5" x2="-0.75" y2="-0.95" layer="51"/>
<rectangle x1="0.75" y1="-1.5" x2="1.15" y2="-0.95" layer="51"/>
<rectangle x1="-0.2" y1="0.95" x2="0.2" y2="1.5" layer="51"/>
</package>
<package name="SOT346-W">
<description>&lt;b&gt;SOT346 Wave soldering&lt;/b&gt; (SC59) Philips SC01_Mounting_1996.pdf</description>
<wire x1="-1.55" y1="-0.4" x2="-1.55" y2="0.4" width="0.2032" layer="21"/>
<wire x1="1.55" y1="0.4" x2="1.55" y2="-0.4" width="0.2032" layer="21"/>
<smd name="1" x="-1.1" y="-1.45" dx="1.2" dy="1.7" layer="1"/>
<smd name="2" x="1.1" y="-1.45" dx="1.2" dy="1.7" layer="1"/>
<smd name="3" x="0" y="1.45" dx="2.8" dy="1.7" layer="1"/>
<text x="-1.65" y="2.5" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.65" y="-3.8" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="SC59-W">
<description>&lt;b&gt;SC59 Wave soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<wire x1="-1.55" y1="0.85" x2="1.55" y2="0.85" width="0.254" layer="51"/>
<wire x1="1.55" y1="0.85" x2="1.55" y2="-0.85" width="0.254" layer="51"/>
<wire x1="1.55" y1="-0.85" x2="-1.55" y2="-0.85" width="0.254" layer="51"/>
<wire x1="-1.55" y1="-0.85" x2="-1.55" y2="0.85" width="0.254" layer="51"/>
<wire x1="-1.55" y1="-0.4" x2="-1.55" y2="0.4" width="0.254" layer="21"/>
<wire x1="1.55" y1="0.4" x2="1.55" y2="-0.4" width="0.254" layer="21"/>
<wire x1="0.25" y1="-0.85" x2="-0.25" y2="-0.85" width="0.254" layer="21"/>
</package>
<package name="SC59-R">
<description>&lt;b&gt;SC59 Reflow soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<wire x1="-1.55" y1="-0.85" x2="-1.55" y2="0.85" width="0.254" layer="21"/>
<wire x1="-1.55" y1="0.85" x2="-0.6" y2="0.85" width="0.254" layer="21"/>
<wire x1="0.6" y1="0.85" x2="1.55" y2="0.85" width="0.254" layer="21"/>
<wire x1="1.55" y1="0.85" x2="1.55" y2="-0.85" width="0.254" layer="21"/>
</package>
<package name="SO20_SOT163-1-R">
<description>&lt;b&gt;SO20 / SOT163-1 Reflow soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<wire x1="-6.55" y1="3.75" x2="6.55" y2="3.75" width="0.254" layer="21"/>
<wire x1="6.55" y1="3.75" x2="6.55" y2="-3.75" width="0.254" layer="21"/>
<wire x1="6.55" y1="-3.75" x2="-6.55" y2="-3.75" width="0.254" layer="21"/>
<wire x1="-6.55" y1="-3.75" x2="-6.55" y2="3.75" width="0.254" layer="21"/>
<wire x1="-6.45" y1="1.2" x2="-6.45" y2="-1.2" width="0.254" layer="21" curve="-180"/>
<smd name="1" x="-5.715" y="-4.78" dx="0.6" dy="1.5" layer="1"/>
<smd name="2" x="-4.445" y="-4.78" dx="0.6" dy="1.5" layer="1"/>
<smd name="3" x="-3.175" y="-4.78" dx="0.6" dy="1.5" layer="1"/>
<smd name="4" x="-1.905" y="-4.78" dx="0.6" dy="1.5" layer="1"/>
<smd name="5" x="-0.635" y="-4.78" dx="0.6" dy="1.5" layer="1"/>
<smd name="6" x="0.635" y="-4.78" dx="0.6" dy="1.5" layer="1"/>
<smd name="7" x="1.905" y="-4.78" dx="0.6" dy="1.5" layer="1"/>
<smd name="8" x="3.175" y="-4.78" dx="0.6" dy="1.5" layer="1"/>
<smd name="9" x="4.445" y="-4.78" dx="0.6" dy="1.5" layer="1"/>
<smd name="10" x="5.715" y="-4.78" dx="0.6" dy="1.5" layer="1"/>
<smd name="11" x="5.715" y="4.78" dx="0.6" dy="1.5" layer="1"/>
<smd name="12" x="4.445" y="4.78" dx="0.6" dy="1.5" layer="1"/>
<smd name="13" x="3.175" y="4.78" dx="0.6" dy="1.5" layer="1"/>
<smd name="14" x="1.905" y="4.78" dx="0.6" dy="1.5" layer="1"/>
<smd name="15" x="0.635" y="4.78" dx="0.6" dy="1.5" layer="1"/>
<smd name="16" x="-0.635" y="4.78" dx="0.6" dy="1.5" layer="1"/>
<smd name="17" x="-1.905" y="4.78" dx="0.6" dy="1.5" layer="1"/>
<smd name="18" x="-3.175" y="4.78" dx="0.6" dy="1.5" layer="1"/>
<smd name="19" x="-4.445" y="4.78" dx="0.6" dy="1.5" layer="1"/>
<smd name="20" x="-5.715" y="4.78" dx="0.6" dy="1.5" layer="1"/>
<text x="-7" y="-3.9" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="-4.25" y="-0.6" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-5.9055" y1="-5.0165" x2="-5.5245" y2="-3.8735" layer="51"/>
<rectangle x1="-4.6355" y1="-5.0165" x2="-4.2545" y2="-3.8735" layer="51"/>
<rectangle x1="-3.3655" y1="-5.0165" x2="-2.9845" y2="-3.8735" layer="51"/>
<rectangle x1="-2.0955" y1="-5.0165" x2="-1.7145" y2="-3.8735" layer="51"/>
<rectangle x1="-0.8255" y1="-5.0165" x2="-0.4445" y2="-3.8735" layer="51"/>
<rectangle x1="0.4445" y1="-5.0165" x2="0.8255" y2="-3.8735" layer="51"/>
<rectangle x1="1.7145" y1="-5.0165" x2="2.0955" y2="-3.8735" layer="51"/>
<rectangle x1="2.9845" y1="-5.0165" x2="3.3655" y2="-3.8735" layer="51"/>
<rectangle x1="4.2545" y1="-5.0165" x2="4.6355" y2="-3.8735" layer="51"/>
<rectangle x1="5.5245" y1="-5.0165" x2="5.9055" y2="-3.8735" layer="51"/>
<rectangle x1="5.5245" y1="3.8735" x2="5.9055" y2="5.0165" layer="51"/>
<rectangle x1="4.2545" y1="3.8735" x2="4.6355" y2="5.0165" layer="51"/>
<rectangle x1="2.9845" y1="3.8735" x2="3.3655" y2="5.0165" layer="51"/>
<rectangle x1="1.7145" y1="3.8735" x2="2.0955" y2="5.0165" layer="51"/>
<rectangle x1="0.4445" y1="3.8735" x2="0.8255" y2="5.0165" layer="51"/>
<rectangle x1="-0.8255" y1="3.8735" x2="-0.4445" y2="5.0165" layer="51"/>
<rectangle x1="-2.0955" y1="3.8735" x2="-1.7145" y2="5.0165" layer="51"/>
<rectangle x1="-3.3655" y1="3.8735" x2="-2.9845" y2="5.0165" layer="51"/>
<rectangle x1="-4.6355" y1="3.8735" x2="-4.2545" y2="5.0165" layer="51"/>
<rectangle x1="-5.9055" y1="3.8735" x2="-5.5245" y2="5.0165" layer="51"/>
</package>
<package name="SO20_SOT163-1-W">
<description>&lt;b&gt;SO20 / SOT163-1 Wave soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<wire x1="-6.55" y1="3.8" x2="6.55" y2="3.8" width="0.254" layer="21"/>
<wire x1="6.55" y1="3.8" x2="6.55" y2="-3.8" width="0.254" layer="21"/>
<wire x1="6.55" y1="-3.8" x2="-6.55" y2="-3.8" width="0.254" layer="21"/>
<wire x1="-6.55" y1="-3.8" x2="-6.55" y2="3.8" width="0.254" layer="21"/>
<smd name="1" x="-5.715" y="-4.83" dx="0.6" dy="1.8" layer="1"/>
<smd name="2" x="-4.445" y="-4.83" dx="0.6" dy="1.8" layer="1"/>
<smd name="3" x="-3.175" y="-4.83" dx="0.6" dy="1.8" layer="1"/>
<smd name="4" x="-1.905" y="-4.83" dx="0.6" dy="1.8" layer="1"/>
<smd name="5" x="-0.635" y="-4.83" dx="0.6" dy="1.8" layer="1"/>
<smd name="6" x="0.635" y="-4.83" dx="0.6" dy="1.5" layer="1"/>
<smd name="7" x="1.905" y="-4.83" dx="0.6" dy="1.8" layer="1"/>
<smd name="8" x="3.175" y="-4.83" dx="0.6" dy="1.8" layer="1"/>
<smd name="9" x="4.445" y="-4.83" dx="0.6" dy="1.8" layer="1"/>
<smd name="10" x="6.165" y="-4.83" dx="1.5" dy="1.8" layer="1"/>
<smd name="11" x="6.165" y="4.83" dx="1.5" dy="1.8" layer="1"/>
<smd name="12" x="4.445" y="4.83" dx="0.6" dy="1.8" layer="1"/>
<smd name="13" x="3.175" y="4.83" dx="0.6" dy="1.8" layer="1"/>
<smd name="14" x="1.905" y="4.83" dx="0.6" dy="1.8" layer="1"/>
<smd name="15" x="0.635" y="4.83" dx="0.6" dy="1.8" layer="1"/>
<smd name="16" x="-0.635" y="4.83" dx="0.6" dy="1.8" layer="1"/>
<smd name="17" x="-1.905" y="4.83" dx="0.6" dy="1.8" layer="1"/>
<smd name="18" x="-3.175" y="4.83" dx="0.6" dy="1.8" layer="1"/>
<smd name="19" x="-4.445" y="4.83" dx="0.6" dy="1.8" layer="1"/>
<smd name="20" x="-5.715" y="4.83" dx="0.6" dy="1.8" layer="1"/>
<text x="-7" y="-3.95" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<rectangle x1="-5.9055" y1="-5.0665" x2="-5.5245" y2="-3.9235" layer="51"/>
<rectangle x1="-4.6355" y1="-5.0665" x2="-4.2545" y2="-3.9235" layer="51"/>
<rectangle x1="-3.3655" y1="-5.0665" x2="-2.9845" y2="-3.9235" layer="51"/>
<rectangle x1="-2.0955" y1="-5.0665" x2="-1.7145" y2="-3.9235" layer="51"/>
<rectangle x1="-0.8255" y1="-5.0665" x2="-0.4445" y2="-3.9235" layer="51"/>
<rectangle x1="0.4445" y1="-5.0665" x2="0.8255" y2="-3.9235" layer="51"/>
<rectangle x1="1.7145" y1="-5.0665" x2="2.0955" y2="-3.9235" layer="51"/>
<rectangle x1="2.9845" y1="-5.0665" x2="3.3655" y2="-3.9235" layer="51"/>
<rectangle x1="4.2545" y1="-5.0665" x2="4.6355" y2="-3.9235" layer="51"/>
<rectangle x1="5.5245" y1="-5.0665" x2="5.9055" y2="-3.9235" layer="51"/>
<rectangle x1="5.5245" y1="3.9235" x2="5.9055" y2="5.0665" layer="51"/>
<rectangle x1="4.2545" y1="3.9235" x2="4.6355" y2="5.0665" layer="51"/>
<rectangle x1="2.9845" y1="3.9235" x2="3.3655" y2="5.0665" layer="51"/>
<rectangle x1="1.7145" y1="3.9235" x2="2.0955" y2="5.0665" layer="51"/>
<rectangle x1="0.4445" y1="3.9235" x2="0.8255" y2="5.0665" layer="51"/>
<rectangle x1="-0.8255" y1="3.9235" x2="-0.4445" y2="5.0665" layer="51"/>
<rectangle x1="-2.0955" y1="3.9235" x2="-1.7145" y2="5.0665" layer="51"/>
<rectangle x1="-3.3655" y1="3.9235" x2="-2.9845" y2="5.0665" layer="51"/>
<rectangle x1="-4.6355" y1="3.9235" x2="-4.2545" y2="5.0665" layer="51"/>
<rectangle x1="-5.9055" y1="3.9235" x2="-5.5245" y2="5.0665" layer="51"/>
</package>
<package name="SMC">
<wire x1="-3.5606" y1="3.105" x2="3.5606" y2="3.105" width="0.1016" layer="21"/>
<wire x1="-3.5606" y1="-3.105" x2="3.5606" y2="-3.105" width="0.1016" layer="21"/>
<wire x1="-3.5606" y1="-3.105" x2="-3.5606" y2="3.105" width="0.1016" layer="51"/>
<wire x1="3.5606" y1="-3.105" x2="3.5606" y2="3.105" width="0.1016" layer="51"/>
<wire x1="0.543" y1="1" x2="-0.83" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.83" y1="0" x2="0.543" y2="-1" width="0.2032" layer="21"/>
<wire x1="0.543" y1="-1" x2="0.543" y2="1" width="0.2032" layer="21"/>
<smd name="C" x="-3.7" y="0" dx="2.8" dy="3.8" layer="1"/>
<smd name="A" x="3.7" y="0" dx="2.8" dy="3.8" layer="1"/>
<text x="-3.459" y="3.359" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.459" y="-4.629" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-4.094" y1="-1.0922" x2="-3.5606" y2="1.0922" layer="51"/>
<rectangle x1="3.5606" y1="-1.0922" x2="4.094" y2="1.0922" layer="51"/>
<rectangle x1="-2.1" y1="-3.1" x2="-0.85" y2="3.1" layer="21"/>
</package>
<package name="SOD123">
<description>&lt;b&gt;Diode&lt;/b&gt;</description>
<wire x1="-1.1" y1="0.7" x2="1.1" y2="0.7" width="0.254" layer="51"/>
<wire x1="1.1" y1="0.7" x2="1.1" y2="-0.7" width="0.254" layer="51"/>
<wire x1="1.1" y1="-0.7" x2="-1.1" y2="-0.7" width="0.254" layer="51"/>
<wire x1="-1.1" y1="-0.7" x2="-1.1" y2="0.7" width="0.254" layer="51"/>
<smd name="C" x="-1.9" y="0" dx="1.4" dy="1.4" layer="1"/>
<smd name="A" x="1.9" y="0" dx="1.4" dy="1.4" layer="1"/>
<text x="-1.1" y="1" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.1" y="-2.3" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.95" y1="-0.45" x2="-1.2" y2="0.4" layer="51"/>
<rectangle x1="1.2" y1="-0.45" x2="1.95" y2="0.4" layer="51"/>
<rectangle x1="-1.05" y1="-0.65" x2="-0.15" y2="0.7" layer="51"/>
</package>
<package name="MELF-MLL41">
<description>&lt;b&gt;DIODE&lt;/b&gt;&lt;p&gt;
Package DO-213AB = http://www.diotec.com/pdf/sm4001.pdf</description>
<wire x1="2.0828" y1="1.1938" x2="-2.159" y2="1.1938" width="0.1524" layer="51"/>
<wire x1="2.0828" y1="-1.1938" x2="-2.1336" y2="-1.1938" width="0.1524" layer="51"/>
<wire x1="0.627" y1="1" x2="-0.746" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.746" y1="0" x2="0.627" y2="-1" width="0.2032" layer="21"/>
<wire x1="0.627" y1="-1" x2="0.627" y2="1" width="0.2032" layer="21"/>
<wire x1="1.1208" y1="1.1938" x2="-1.097" y2="1.1938" width="0.1524" layer="21"/>
<wire x1="1.1208" y1="-1.1938" x2="-1.0716" y2="-1.1938" width="0.1524" layer="21"/>
<smd name="C" x="-2.625" y="0" dx="2.5" dy="3" layer="1"/>
<smd name="A" x="2.625" y="0" dx="2.5" dy="3" layer="1"/>
<text x="-2.663" y="1.724" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.663" y="-2.994" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="2.0574" y1="-1.27" x2="2.5654" y2="1.27" layer="51"/>
<rectangle x1="-2.6162" y1="-1.27" x2="-2.1082" y2="1.27" layer="51"/>
<rectangle x1="-1.4478" y1="-1.1938" x2="-0.5588" y2="1.1938" layer="51"/>
</package>
<package name="DO214BA">
<wire x1="-2.5" y1="1.35" x2="2.5" y2="1.35" width="0.254" layer="51"/>
<wire x1="2.5" y1="1.35" x2="2.5" y2="-1.35" width="0.254" layer="51"/>
<wire x1="2.5" y1="-1.35" x2="-2.5" y2="-1.35" width="0.254" layer="51"/>
<wire x1="-2.5" y1="-1.35" x2="-2.5" y2="1.35" width="0.254" layer="51"/>
<wire x1="-0.8" y1="0" x2="0.65" y2="0.95" width="0.254" layer="21"/>
<wire x1="0.65" y1="0.95" x2="0.65" y2="-0.95" width="0.254" layer="21"/>
<wire x1="0.65" y1="-0.95" x2="-0.8" y2="0" width="0.254" layer="21"/>
<smd name="C" x="-2.05" y="0" dx="1.8" dy="1.7" layer="1"/>
<smd name="A" x="2.05" y="0" dx="1.8" dy="1.7" layer="1"/>
<text x="-2.64" y="1.736" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.64" y="-3.056" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.85" y1="-0.7" x2="-2.6" y2="0.65" layer="51"/>
<rectangle x1="2.6" y1="-0.7" x2="2.85" y2="0.65" layer="51"/>
<rectangle x1="-1" y1="-1.05" x2="-0.7" y2="1.05" layer="21"/>
</package>
<package name="DO214AC">
<wire x1="-2.3" y1="1" x2="2.3" y2="1" width="0.254" layer="51"/>
<wire x1="2.3" y1="1" x2="2.3" y2="-0.95" width="0.254" layer="51"/>
<wire x1="2.3" y1="-0.95" x2="-2.3" y2="-0.95" width="0.254" layer="51"/>
<wire x1="-2.3" y1="-0.95" x2="-2.3" y2="1" width="0.254" layer="51"/>
<wire x1="-0.8" y1="0" x2="0.25" y2="0.75" width="0.254" layer="21"/>
<wire x1="0.25" y1="0.75" x2="0.25" y2="-0.7" width="0.254" layer="21"/>
<wire x1="0.25" y1="-0.7" x2="-0.8" y2="0" width="0.254" layer="21"/>
<text x="-2.64" y="1.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.64" y="-2.556" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.65" y1="-0.7" x2="-2.4" y2="0.65" layer="51"/>
<rectangle x1="2.4" y1="-0.7" x2="2.65" y2="0.65" layer="51"/>
</package>
<package name="DO214AA">
<wire x1="-2.4" y1="1.1" x2="2.4" y2="1.1" width="0.254" layer="51"/>
<wire x1="2.4" y1="1.1" x2="2.4" y2="-1.1" width="0.254" layer="51"/>
<wire x1="2.4" y1="-1.1" x2="-2.4" y2="-1.1" width="0.254" layer="51"/>
<wire x1="-2.4" y1="-1.1" x2="-2.4" y2="1.1" width="0.254" layer="51"/>
<wire x1="-1.2" y1="0" x2="0.05" y2="0.7" width="0.254" layer="21"/>
<wire x1="0.05" y1="0.7" x2="0.05" y2="-0.7" width="0.254" layer="21"/>
<wire x1="0.05" y1="-0.7" x2="-1.2" y2="0" width="0.254" layer="21"/>
<smd name="C" x="-2.55" y="0" dx="1.8" dy="2.2" layer="1"/>
<smd name="A" x="2.55" y="0" dx="1.8" dy="2.2" layer="1"/>
<text x="-2.64" y="1.436" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.64" y="-2.706" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.75" y1="-0.7" x2="-2.5" y2="0.65" layer="51"/>
<rectangle x1="2.5" y1="-0.7" x2="2.75" y2="0.65" layer="51"/>
<rectangle x1="-1.4" y1="-1.05" x2="-1.1" y2="1.05" layer="21"/>
</package>
<package name="MINIMELF">
<description>&lt;b&gt;Mini Melf Diode&lt;/b&gt;</description>
<wire x1="0.5" y1="0.5" x2="-0.5" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.5" y1="0" x2="0.5" y2="-0.5" width="0.2032" layer="21"/>
<wire x1="0.5" y1="-0.5" x2="0.5" y2="0.5" width="0.2032" layer="21"/>
<text x="-1.651" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.651" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="MICROMELF-R">
<description>&lt;b&gt;Micro Melf Diode Reflow soldering&lt;/b&gt; VISHAY mcl4148.pdf</description>
<wire x1="-0.65" y1="0.55" x2="0.65" y2="0.55" width="0.1524" layer="51"/>
<wire x1="-0.65" y1="-0.55" x2="0.65" y2="-0.55" width="0.1524" layer="51"/>
<smd name="C" x="-0.8" y="0" dx="0.8" dy="1.2" layer="1"/>
<smd name="A" x="0.8" y="0" dx="0.8" dy="1.2" layer="1"/>
<text x="-1.201" y="0.843" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.201" y="-2.063" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.95" y1="-0.65" x2="-0.65" y2="0.65" layer="51"/>
<rectangle x1="0.65" y1="-0.65" x2="0.95" y2="0.65" layer="51"/>
<rectangle x1="-0.5" y1="-0.55" x2="-0.2" y2="0.55" layer="51"/>
</package>
<package name="MICROMELF-W">
<description>&lt;b&gt;Micro Melf Diode Wave soldering&lt;/b&gt; VISHAY mcl4148.pdf</description>
<smd name="C" x="-0.95" y="0" dx="0.9" dy="1.4" layer="1"/>
<smd name="A" x="0.95" y="0" dx="0.9" dy="1.4" layer="1"/>
<rectangle x1="-0.5" y1="-0.5" x2="-0.2" y2="0.55" layer="51"/>
</package>
<package name="SC79_INFINEON">
<description>&lt;b&gt;Diode Package&lt;/b&gt; Reflow soldering&lt;p&gt;
INFINEON, www.infineon.com/cmc_upload/0/000/010/257/eh_db_5b.pdf</description>
<wire x1="-0.55" y1="0.35" x2="0.55" y2="0.35" width="0.1016" layer="21"/>
<wire x1="0.55" y1="0.35" x2="0.55" y2="-0.35" width="0.1016" layer="51"/>
<wire x1="0.55" y1="-0.35" x2="-0.55" y2="-0.35" width="0.1016" layer="21"/>
<wire x1="-0.55" y1="-0.35" x2="-0.55" y2="0.35" width="0.1016" layer="51"/>
<smd name="C" x="-0.675" y="0" dx="0.35" dy="0.35" layer="1"/>
<smd name="A" x="0.675" y="0" dx="0.35" dy="0.35" layer="1"/>
<text x="-0.8" y="0.6" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.8" y="-1.8" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.8" y1="-0.15" x2="-0.55" y2="0.15" layer="51"/>
<rectangle x1="0.55" y1="-0.15" x2="0.8" y2="0.15" layer="51"/>
<rectangle x1="-0.55" y1="-0.35" x2="0" y2="0.35" layer="51"/>
</package>
<package name="SCD80_INFINEON">
<wire x1="-0.6" y1="0.35" x2="-0.6" y2="-0.35" width="0.1016" layer="51"/>
<wire x1="-0.6" y1="-0.35" x2="0.6" y2="-0.35" width="0.1016" layer="21"/>
<wire x1="0.6" y1="-0.35" x2="0.6" y2="0.35" width="0.1016" layer="51"/>
<wire x1="0.6" y1="0.35" x2="-0.6" y2="0.35" width="0.1016" layer="21"/>
<smd name="C" x="-0.725" y="0" dx="0.35" dy="0.35" layer="1"/>
<smd name="A" x="0.725" y="0" dx="0.35" dy="0.35" layer="1"/>
<text x="-0.9" y="0.5" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.9" y="-1.8" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.6" y1="-0.35" x2="0" y2="0.35" layer="51"/>
<rectangle x1="-0.85" y1="-0.15" x2="-0.6" y2="0.15" layer="51"/>
<rectangle x1="0.6" y1="-0.15" x2="0.85" y2="0.15" layer="51"/>
</package>
<package name="SOD323R_INFINEON">
<wire x1="-0.8" y1="0.55" x2="0.8" y2="0.55" width="0.1016" layer="21"/>
<wire x1="0.8" y1="0.55" x2="0.8" y2="-0.55" width="0.1016" layer="21"/>
<wire x1="0.8" y1="-0.55" x2="-0.8" y2="-0.55" width="0.1016" layer="21"/>
<wire x1="-0.8" y1="-0.55" x2="-0.8" y2="0.55" width="0.1016" layer="51"/>
<smd name="C" x="-1.25" y="0" dx="0.8" dy="0.6" layer="1"/>
<smd name="A" x="1.25" y="0" dx="0.8" dy="0.6" layer="1"/>
<text x="-1.65" y="0.75" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.65" y="-2" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.8" y1="-0.55" x2="0" y2="0.55" layer="21"/>
<rectangle x1="-1.25" y1="-0.15" x2="-0.8" y2="0.15" layer="51"/>
<rectangle x1="0.8" y1="-0.15" x2="1.25" y2="0.15" layer="51"/>
</package>
<package name="SOD323W_INFINEON">
<description>&lt;b&gt;Diode Package&lt;/b&gt; Wave soldering&lt;p&gt;
<wire x1="0" y1="-0.7" x2="0" y2="0.6" width="0.127" layer="48"/>
<wire x1="0" y1="0.6" x2="-0.2" y2="0.2" width="0.127" layer="48"/>
<wire x1="-0.2" y1="0.2" x2="0.2" y2="0.2" width="0.127" layer="48"/>
<wire x1="0.2" y1="0.2" x2="0" y2="0.6" width="0.127" layer="48"/>
<wire x1="0" y1="-0.7" x2="0.2" y2="-0.3" width="0.127" layer="48"/>
<wire x1="0.2" y1="-0.3" x2="-0.2" y2="-0.3" width="0.127" layer="48"/>
<wire x1="-0.2" y1="-0.3" x2="0" y2="-0.7" width="0.127" layer="48"/>
<smd name="C" x="-1.35" y="0" dx="1" dy="0.6" layer="1"/>
<smd name="A" x="1.35" y="0" dx="1" dy="0.6" layer="1"/>
<text x="0.4" y="0.4" size="0.254" layer="48">direction of pcb</text>
<text x="0.4" y="-0.05" size="0.254" layer="48">transportation for</text>
<text x="0.4" y="-0.5" size="0.254" layer="48">wavesoldering</text>
</package>
<package name="GF1">
<description>&lt;b&gt;GF1&lt;/b&gt;&lt;p&gt;
General Semiconductor</description>
<wire x1="-2.24" y1="1.32" x2="2.24" y2="1.32" width="0.254" layer="21"/>
<wire x1="2.24" y1="1.32" x2="2.24" y2="-1.32" width="0.254" layer="21"/>
<wire x1="2.24" y1="-1.32" x2="-2.24" y2="-1.32" width="0.254" layer="21"/>
<wire x1="-2.24" y1="-1.32" x2="-2.24" y2="1.32" width="0.254" layer="21"/>
<smd name="C" x="-2.12" y="0" dx="1.32" dy="1.68" layer="1"/>
<smd name="A" x="1.87" y="0" dx="1.85" dy="1.68" layer="1"/>
<text x="-2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.86" y1="-0.84" x2="-2.32" y2="0.84" layer="51"/>
<rectangle x1="2.34" y1="-0.84" x2="2.86" y2="0.84" layer="51"/>
<rectangle x1="-1.9" y1="-1.05" x2="-1.25" y2="1.05" layer="51"/>
<rectangle x1="-1.4" y1="-1.05" x2="-1.25" y2="1.05" layer="21"/>
</package>
<package name="POWERMITE">
<description>&lt;b&gt;Footprint Powermite&lt;/b&gt; SOD80C, SOD87&lt;p&gt;
Source: http://www.semiconductors.philips.com/acrobat_download/literature/9397/75007774.pdf</description>
<wire x1="-1.385" y1="0.7" x2="-1.585" y2="0.5" width="0.2032" layer="51"/>
<wire x1="-1.385" y1="0.7" x2="1.415" y2="0.7" width="0.2032" layer="51"/>
<wire x1="1.415" y1="0.7" x2="1.615" y2="0.5" width="0.2032" layer="51"/>
<wire x1="1.415" y1="-0.7" x2="1.615" y2="-0.5" width="0.2032" layer="51"/>
<wire x1="1.415" y1="-0.7" x2="-1.385" y2="-0.7" width="0.2032" layer="51"/>
<wire x1="-1.385" y1="-0.7" x2="-1.585" y2="-0.5" width="0.2032" layer="51"/>
<smd name="1" x="-0.635" y="0" dx="2.7" dy="2.5" layer="1"/>
<smd name="2" x="1.665" y="0" dx="0.7" dy="1.3" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="1.565" y1="-0.8" x2="1.865" y2="0.8" layer="51"/>
<rectangle x1="-1.835" y1="-0.8" x2="-1.535" y2="0.8" layer="51"/>
<rectangle x1="-1.16" y1="-0.65" x2="-0.885" y2="0.65" layer="51"/>
</package>
<package name="SOD87-R">
<description>&lt;b&gt;SOD87 Reflow soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<smd name="C" x="-1.65" y="0" dx="1" dy="1.9" layer="1"/>
<smd name="A" x="1.65" y="0" dx="1" dy="1.9" layer="1"/>
</package>
<package name="SOD87-W">
<description>&lt;b&gt;SOD87 Wave soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<wire x1="1.4708" y1="0.7874" x2="-1.4708" y2="0.7874" width="0.1524" layer="51"/>
<wire x1="1.4708" y1="-0.7874" x2="-1.4708" y2="-0.7874" width="0.1524" layer="51"/>
<wire x1="0.477" y1="0.6" x2="-0.523" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.523" y1="0" x2="0.477" y2="-0.6" width="0.2032" layer="21"/>
<wire x1="0.477" y1="-0.6" x2="0.477" y2="0.6" width="0.2032" layer="21"/>
<smd name="C" x="-1.925" y="0" dx="1.55" dy="2" layer="1"/>
<smd name="A" x="1.925" y="0" dx="1.55" dy="2" layer="1"/>
<rectangle x1="-2.0042" y1="-0.8636" x2="-1.4454" y2="0.8636" layer="51"/>
<rectangle x1="1.4454" y1="-0.8636" x2="2.0042" y2="0.8636" layer="51"/>
<rectangle x1="-1.0136" y1="-0.7874" x2="-0.404" y2="0.7874" layer="21"/>
</package>
<package name="SOD323-R">
<description>&lt;b&gt;SOD323 Reflow soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<wire x1="-1" y1="0.7" x2="1" y2="0.7" width="0.1524" layer="51"/>
<wire x1="1" y1="0.7" x2="1" y2="-0.7" width="0.1524" layer="51"/>
<wire x1="1" y1="-0.7" x2="-1" y2="-0.7" width="0.1524" layer="51"/>
<wire x1="-1" y1="-0.7" x2="-1" y2="0.7" width="0.1524" layer="51"/>
<wire x1="-0.5" y1="0" x2="0.1" y2="0.4" width="0.1524" layer="51"/>
<wire x1="0.1" y1="0.4" x2="0.1" y2="-0.4" width="0.1524" layer="51"/>
<wire x1="0.1" y1="-0.4" x2="-0.5" y2="0" width="0.1524" layer="51"/>
<smd name="C" x="-1.1" y="0" dx="0.6" dy="0.6" layer="1"/>
<smd name="A" x="1.1" y="0" dx="0.6" dy="0.6" layer="1"/>
<rectangle x1="-0.7" y1="-0.7" x2="-0.5" y2="0.7" layer="51"/>
</package>
<package name="SOD323-W">
<description>&lt;b&gt;SOD323 Wave soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<smd name="C" x="-1.45" y="0" dx="1.5" dy="1.2" layer="1"/>
<smd name="A" x="1.45" y="0" dx="1.5" dy="1.2" layer="1"/>
</package>
<package name="SOT89-R">
<description>&lt;b&gt;SOT89 Reflow soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<wire x1="2.2724" y1="1.6104" x2="2.2724" y2="-1.1104" width="0.1524" layer="51"/>
<wire x1="2.2724" y1="-1.1104" x2="-2.2724" y2="-1.1104" width="0.1524" layer="51"/>
<wire x1="-2.2724" y1="-1.1104" x2="-2.2724" y2="1.6104" width="0.1524" layer="51"/>
<wire x1="-2.2724" y1="1.6104" x2="2.2724" y2="1.6104" width="0.1524" layer="51"/>
<wire x1="-2.2724" y1="-1.1024" x2="-2.2724" y2="1.6104" width="0.1524" layer="21"/>
<wire x1="-2.2724" y1="1.6104" x2="-1.2136" y2="1.6104" width="0.1524" layer="21"/>
<wire x1="2.2724" y1="1.6104" x2="2.2724" y2="-1.1024" width="0.1524" layer="21"/>
<wire x1="1.2636" y1="1.6104" x2="2.2724" y2="1.6104" width="0.1524" layer="21"/>
<wire x1="-0.5776" y1="-1.1104" x2="-0.9364" y2="-1.1104" width="0.1524" layer="21"/>
<wire x1="0.9224" y1="-1.1104" x2="0.5636" y2="-1.1104" width="0.1524" layer="21"/>
<smd name="1" x="1.5" y="-1.75" dx="0.7" dy="1.1" layer="1"/>
<smd name="2" x="-1.5" y="-1.75" dx="0.7" dy="1.1" layer="1"/>
<smd name="3" x="0" y="-1.4" dx="0.7" dy="1.8" layer="1" stop="no" cream="no"/>
<text x="-2.205" y="2.455" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.205" y="-3.825" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.75" y1="-2.15" x2="-1.25" y2="-1.15" layer="51"/>
<rectangle x1="-0.25" y1="-2.15" x2="0.25" y2="-1.15" layer="51"/>
<rectangle x1="1.25" y1="-2.15" x2="1.75" y2="-1.15" layer="51"/>
<rectangle x1="-0.85" y1="1.65" x2="0.85" y2="2.2" layer="51"/>
<rectangle x1="-0.45" y1="-2.4" x2="0.45" y2="-1.1" layer="29"/>
<rectangle x1="-0.35" y1="-2.3" x2="0.35" y2="-1.2" layer="31"/>
<rectangle x1="-1.1" y1="-0.6" x2="1.1" y2="2.4" layer="29"/>
<rectangle x1="-0.95" y1="-0.45" x2="0.95" y2="2.25" layer="31"/>
<polygon width="0.1016" layer="1">
<vertex x="0" y="-1.875"/>
<vertex x="0.3" y="-1.875"/>
<vertex x="0.3" y="-0.45"/>
<vertex x="0.95" y="-0.45"/>
<vertex x="0.95" y="2.25"/>
<vertex x="-0.95" y="2.25"/>
<vertex x="-0.95" y="-0.45"/>
<vertex x="-0.55" y="-0.45"/>
<vertex x="-0.3" y="-0.45"/>
<vertex x="-0.3" y="-1.875"/>
</polygon>
</package>
<package name="SOT89-W">
<description>&lt;b&gt;SOT89 Wave soldering&lt;/b&gt; Philips SC01_Mounting_1996.pdf</description>
<smd name="1" x="1.9" y="-2.1" dx="1.5" dy="1.8" layer="1"/>
<smd name="2" x="-1.9" y="-2.1" dx="1.5" dy="1.8" layer="1"/>
<smd name="4" x="0" y="-1.73" dx="0.7" dy="2.55" layer="1" stop="no" cream="no"/>
<text x="-2.205" y="3.705" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.205" y="-4.475" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.45" y1="-3.1" x2="0.45" y2="-1.1" layer="29"/>
<rectangle x1="-0.35" y1="-3" x2="0.35" y2="-1.2" layer="31"/>
<rectangle x1="-1.3" y1="-0.6" x2="1.3" y2="3.6" layer="29"/>
<rectangle x1="-1.125" y1="-0.4" x2="1.125" y2="3.425" layer="31"/>
<vertex x="-0.3" y="-2.55"/>
<vertex x="0.3" y="-2.55"/>
<vertex x="1.15" y="-0.45"/>
<vertex x="1.15" y="3.45"/>
<vertex x="-1.15" y="3.45"/>
<vertex x="-1.15" y="-0.45"/>
</polygon>
</package>
<package name="SMBJ">
<description>&lt;b&gt;DO-214AA Modified J_BEND&lt;/b&gt;&lt;p&gt;
Source: www.rsonline.de .. SMBJ12/C/15/C/24/C/30/C/5.0/C/7.5/C Voltage Suppressor. Data Sheet</description>
<wire x1="2.24" y1="1.92" x2="2.24" y2="-1.92" width="0.1016" layer="51"/>
<wire x1="2.24" y1="-1.92" x2="-2.24" y2="-1.92" width="0.1016" layer="21"/>
<wire x1="-2.24" y1="-1.92" x2="-2.24" y2="1.92" width="0.1016" layer="51"/>
<wire x1="-2.24" y1="1.92" x2="2.24" y2="1.92" width="0.1016" layer="21"/>
<smd name="C" x="-2.03" y="0" dx="1.78" dy="2.16" layer="1"/>
<smd name="A" x="2.04" y="0" dx="1.78" dy="2.16" layer="1" rot="R180"/>
<text x="-1.905" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.8" y1="-1.1" x2="-2.25" y2="1.1" layer="51"/>
<rectangle x1="2.25" y1="-1.1" x2="2.8" y2="1.1" layer="51"/>
</package>
<package name="SMBG">
<description>&lt;b&gt;DO-214AA GULL-WING&lt;/b&gt;&lt;p&gt;
<wire x1="2.24" y1="1.85" x2="2.24" y2="-1.85" width="0.1016" layer="21"/>
<wire x1="2.24" y1="-1.85" x2="-2.24" y2="-1.85" width="0.1016" layer="21"/>
<wire x1="-2.24" y1="-1.85" x2="-2.24" y2="1.85" width="0.1016" layer="21"/>
<wire x1="-2.24" y1="1.85" x2="2.24" y2="1.85" width="0.1016" layer="21"/>
<smd name="C" x="-3.17" y="0" dx="1.27" dy="2.16" layer="1"/>
<smd name="A" x="3.17" y="0" dx="1.27" dy="2.16" layer="1" rot="R180"/>
<rectangle x1="-3.24" y1="-1.05" x2="-2.23" y2="1.05" layer="51"/>
<rectangle x1="2.24" y1="-1.05" x2="3.24" y2="1.05" layer="51"/>
</package>
<package name="SOT363_PHILIPS">
<description>&lt;b&gt;Small Outline Transistor; 6 leads&lt;/b&gt;&lt;p&gt;
Philips Semiconductors, SOT363.pdf</description>
<wire x1="-1" y1="0.55" x2="1" y2="0.55" width="0.2032" layer="51"/>
<wire x1="1" y1="0.55" x2="1" y2="-0.55" width="0.2032" layer="21"/>
<wire x1="1" y1="-0.55" x2="-1" y2="-0.55" width="0.2032" layer="51"/>
<wire x1="-1" y1="-0.55" x2="-1" y2="0.55" width="0.2032" layer="21"/>
<circle x="-0.7" y="-0.25" radius="0.15" width="0" layer="21"/>
<smd name="1" x="-0.65" y="-0.8" dx="0.4" dy="0.8" layer="1"/>
<smd name="2" x="0" y="-0.8" dx="0.4" dy="0.8" layer="1"/>
<smd name="3" x="0.65" y="-0.8" dx="0.4" dy="0.8" layer="1"/>
<smd name="4" x="0.65" y="0.8" dx="0.4" dy="0.8" layer="1"/>
<smd name="5" x="0" y="0.8" dx="0.4" dy="0.8" layer="1"/>
<smd name="6" x="-0.65" y="0.8" dx="0.4" dy="0.8" layer="1"/>
<text x="-1.1" y="1.45" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.1" y="-2.7" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.8" y1="-1.1" x2="-0.5" y2="-0.6" layer="51"/>
<rectangle x1="-0.15" y1="-1.1" x2="0.15" y2="-0.6" layer="51"/>
<rectangle x1="0.5" y1="-1.1" x2="0.8" y2="-0.6" layer="51"/>
<rectangle x1="0.5" y1="0.6" x2="0.8" y2="1.1" layer="51"/>
<rectangle x1="-0.15" y1="0.6" x2="0.15" y2="1.1" layer="51"/>
<rectangle x1="-0.8" y1="0.6" x2="-0.5" y2="1.1" layer="51"/>
</package>
<package name="SOT666">
<description>&lt;b&gt;SOT 666 Reflow soldering foorprint&lt;/b&gt;&lt;p&gt;
<wire x1="-0.8" y1="-0.6" x2="0.8" y2="-0.6" width="0.1016" layer="21"/>
<wire x1="0.8" y1="-0.6" x2="0.8" y2="0.6" width="0.1016" layer="21"/>
<wire x1="0.8" y1="0.6" x2="-0.8" y2="0.6" width="0.1016" layer="21"/>
<wire x1="-0.8" y1="0.6" x2="-0.8" y2="-0.6" width="0.1016" layer="21"/>
<circle x="-0.525" y="-0.3" radius="0.15" width="0" layer="21"/>
<smd name="1" x="-0.537" y="-0.85" dx="0.5" dy="0.375" layer="1" rot="R90"/>
<smd name="2" x="0" y="-0.923" dx="0.65" dy="0.3" layer="1" rot="R90"/>
<smd name="3" x="0.538" y="-0.85" dx="0.5" dy="0.375" layer="1" rot="R90"/>
<smd name="4" x="0.538" y="0.849" dx="0.5" dy="0.375" layer="1" rot="R90"/>
<smd name="5" x="0" y="0.925" dx="0.65" dy="0.3" layer="1" rot="R90"/>
<smd name="6" x="-0.538" y="0.85" dx="0.5" dy="0.375" layer="1" rot="R90"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.6125" y1="-0.8625" x2="-0.3875" y2="-0.6125" layer="51" rot="R90"/>
<rectangle x1="-0.1125" y1="-0.8625" x2="0.1125" y2="-0.6125" layer="51" rot="R90"/>
<rectangle x1="0.3875" y1="-0.8625" x2="0.6125" y2="-0.6125" layer="51" rot="R90"/>
<rectangle x1="0.3875" y1="0.6125" x2="0.6125" y2="0.8625" layer="51" rot="R270"/>
<rectangle x1="-0.1125" y1="0.6125" x2="0.1125" y2="0.8625" layer="51" rot="R270"/>
<rectangle x1="-0.6125" y1="0.6125" x2="-0.3875" y2="0.8625" layer="51" rot="R270"/>
</package>
<package name="SOT363W">
<description>&lt;b&gt;Wave soldering footprint SOT363 (SC-88)&lt;/b&gt;&lt;p&gt;
<wire x1="1" y1="0.55" x2="1" y2="-0.55" width="0.2032" layer="51"/>
<wire x1="-1" y1="-0.55" x2="-1" y2="0.55" width="0.2032" layer="51"/>
<smd name="1" x="-1.25" y="-1.225" dx="1.5" dy="1.3" layer="1"/>
<smd name="2" x="0" y="-1.225" dx="0.3" dy="1.3" layer="1" roundness="100"/>
<smd name="3" x="1.25" y="-1.225" dx="1.5" dy="1.3" layer="1"/>
<smd name="4" x="1.25" y="1.225" dx="1.5" dy="1.3" layer="1"/>
<smd name="5" x="0" y="1.225" dx="0.3" dy="1.3" layer="1" roundness="100"/>
<smd name="6" x="-1.25" y="1.225" dx="1.5" dy="1.3" layer="1"/>
<text x="-2" y="2" size="1.27" layer="25">&gt;NAME</text>
<text x="-2" y="-3.5" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="TO263AB">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
&lt;B&gt;Package:&lt;/B&gt; TO263AB</description>
<wire x1="-5.334" y1="14.478" x2="5.334" y2="14.478" width="0.127" layer="21"/>
<wire x1="-3.048" y1="16.764" x2="3.048" y2="16.764" width="0.127" layer="21"/>
<wire x1="-5.334" y1="5.334" x2="-5.334" y2="14.478" width="0.127" layer="21"/>
<wire x1="5.334" y1="5.334" x2="5.334" y2="14.478" width="0.127" layer="21"/>
<wire x1="-5.334" y1="5.334" x2="-3.048" y2="5.334" width="0.127" layer="21"/>
<wire x1="-3.048" y1="5.334" x2="-2.032" y2="5.334" width="0.127" layer="21"/>
<wire x1="-2.032" y1="5.334" x2="-0.508" y2="5.334" width="0.127" layer="21"/>
<wire x1="-0.508" y1="5.334" x2="0.508" y2="5.334" width="0.127" layer="21"/>
<wire x1="0.508" y1="5.334" x2="2.032" y2="5.334" width="0.127" layer="21"/>
<wire x1="2.032" y1="5.334" x2="3.048" y2="5.334" width="0.127" layer="21"/>
<wire x1="3.048" y1="5.334" x2="5.334" y2="5.334" width="0.127" layer="21"/>
<wire x1="-5.334" y1="14.478" x2="-3.048" y2="16.764" width="0.127" layer="21"/>
<wire x1="5.334" y1="14.478" x2="3.048" y2="16.764" width="0.127" layer="21"/>
<wire x1="-4.826" y1="13.97" x2="4.826" y2="13.97" width="0.127" layer="51"/>
<wire x1="4.826" y1="13.97" x2="4.826" y2="5.842" width="0.127" layer="51"/>
<wire x1="4.826" y1="5.842" x2="-4.826" y2="5.842" width="0.127" layer="51"/>
<wire x1="-4.826" y1="5.842" x2="-4.826" y2="13.97" width="0.127" layer="51"/>
<wire x1="-3.048" y1="3.81" x2="-2.794" y2="3.81" width="0.127" layer="21"/>
<wire x1="-2.794" y1="3.81" x2="-2.286" y2="3.81" width="0.127" layer="21"/>
<wire x1="-2.286" y1="3.81" x2="-2.032" y2="3.81" width="0.127" layer="21"/>
<wire x1="-3.048" y1="3.81" x2="-3.048" y2="5.334" width="0.127" layer="21"/>
<wire x1="-2.032" y1="3.81" x2="-2.032" y2="5.334" width="0.127" layer="21"/>
<wire x1="-2.794" y1="3.81" x2="-2.794" y2="2.032" width="0.127" layer="21"/>
<wire x1="-2.794" y1="2.032" x2="-2.286" y2="2.032" width="0.127" layer="21"/>
<wire x1="-2.286" y1="2.032" x2="-2.286" y2="3.81" width="0.127" layer="21"/>
<wire x1="-0.508" y1="3.81" x2="-0.508" y2="5.334" width="0.127" layer="21"/>
<wire x1="0.508" y1="3.81" x2="0.508" y2="5.334" width="0.127" layer="21"/>
<wire x1="-0.508" y1="3.81" x2="0.508" y2="3.81" width="0.127" layer="21"/>
<wire x1="2.032" y1="3.81" x2="2.032" y2="5.334" width="0.127" layer="21"/>
<wire x1="3.048" y1="3.81" x2="3.048" y2="5.334" width="0.127" layer="21"/>
<wire x1="2.032" y1="3.81" x2="2.286" y2="3.81" width="0.127" layer="21"/>
<wire x1="2.286" y1="3.81" x2="2.794" y2="3.81" width="0.127" layer="21"/>
<wire x1="2.794" y1="3.81" x2="3.048" y2="3.81" width="0.127" layer="21"/>
<wire x1="2.286" y1="3.81" x2="2.286" y2="2.032" width="0.127" layer="21"/>
<wire x1="2.286" y1="2.032" x2="2.794" y2="2.032" width="0.127" layer="21"/>
<wire x1="2.794" y1="2.032" x2="2.794" y2="3.81" width="0.127" layer="21"/>
<wire x1="-2.794" y1="2.032" x2="-2.794" y2="0.762" width="0.127" layer="51"/>
<wire x1="-2.794" y1="0.762" x2="-2.286" y2="0.762" width="0.127" layer="51"/>
<wire x1="-2.286" y1="0.762" x2="-2.286" y2="2.032" width="0.127" layer="51"/>
<wire x1="2.286" y1="2.032" x2="2.286" y2="0.762" width="0.127" layer="51"/>
<wire x1="2.286" y1="0.762" x2="2.794" y2="0.762" width="0.127" layer="51"/>
<wire x1="2.794" y1="0.762" x2="2.794" y2="2.032" width="0.127" layer="51"/>
<wire x1="2.794" y1="2.032" x2="2.286" y2="2.032" width="0.127" layer="51"/>
<wire x1="-2.794" y1="2.032" x2="-2.286" y2="2.032" width="0.127" layer="51"/>
<smd name="1" x="-2.54" y="0" dx="2.032" dy="3.81" layer="1"/>
<smd name="2" x="2.54" y="0" dx="2.032" dy="3.81" layer="1"/>
<smd name="K" x="0" y="9.906" dx="10.668" dy="8.382" layer="1"/>
<text x="-2.794" y="4.318" size="0.6096" layer="21">1</text>
<text x="-0.254" y="4.318" size="0.6096" layer="21">K</text>
<text x="2.286" y="4.318" size="0.6096" layer="21">2</text>
<text x="-6.35" y="6.35" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="7.62" y="6.35" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="SMA-DO214AC">
<wire x1="-2.2225" y1="0.635" x2="2.2225" y2="0.635" width="0.127" layer="51"/>
<wire x1="-2.2225" y1="-0.635" x2="2.2225" y2="-0.635" width="0.127" layer="51"/>
<wire x1="0.3175" y1="0" x2="-0.3175" y2="0.4763" width="0.127" layer="21"/>
<wire x1="-0.3175" y1="0.4763" x2="-0.3175" y2="0" width="0.127" layer="21"/>
<wire x1="-0.3175" y1="0" x2="-0.3175" y2="-0.4763" width="0.127" layer="21"/>
<wire x1="-0.3175" y1="-0.4763" x2="0.3175" y2="0" width="0.127" layer="21"/>
<wire x1="0.3175" y1="0" x2="0.3175" y2="0.4763" width="0.127" layer="21"/>
<wire x1="0.3175" y1="0" x2="0.3175" y2="-0.4763" width="0.127" layer="21"/>
<wire x1="-0.3175" y1="0" x2="-1.1113" y2="0" width="0.127" layer="21"/>
<wire x1="0.3175" y1="0" x2="1.1113" y2="0" width="0.127" layer="21"/>
<smd name="A" x="-2.05" y="0" dx="1.8" dy="1.7" layer="1"/>
<smd name="K" x="2.05" y="0" dx="1.8" dy="1.7" layer="1"/>
<text x="-3.175" y="1.5875" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.175" y="-2.8575" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.3813" y1="-0.635" x2="-1.5875" y2="0.635" layer="51"/>
<rectangle x1="1.5875" y1="-0.635" x2="2.3813" y2="0.635" layer="51"/>
</package>
<package name="S6058">
<description>&lt;b&gt;Si PIN Quadrant photodiode&lt;/b&gt;&lt;p&gt;
Source: http://sales.hamamatsu.com/assets/pdf/parts_S/S7379-01_etc.pdf</description>
<wire x1="-2" y1="2.35" x2="2" y2="2.35" width="0.1016" layer="21"/>
<wire x1="2" y1="2.35" x2="2" y2="-2.35" width="0.1016" layer="21"/>
<wire x1="2" y1="-2.35" x2="-2" y2="-2.35" width="0.1016" layer="21"/>
<wire x1="-2" y1="-2.35" x2="-2" y2="2.35" width="0.1016" layer="21"/>
<wire x1="-0.3" y1="-0.6" x2="-0.3" y2="-0.075" width="0.1016" layer="21"/>
<wire x1="-0.3" y1="-0.075" x2="-0.075" y2="-0.075" width="0.1016" layer="21"/>
<wire x1="-0.075" y1="-0.075" x2="-0.075" y2="-0.6" width="0.1016" layer="21"/>
<wire x1="-0.075" y1="-0.6" x2="-0.3" y2="-0.6" width="0.1016" layer="21"/>
<wire x1="0.3" y1="0.6" x2="0.3" y2="0.075" width="0.1016" layer="21"/>
<wire x1="0.3" y1="0.075" x2="0.075" y2="0.075" width="0.1016" layer="21"/>
<wire x1="0.075" y1="0.075" x2="0.075" y2="0.6" width="0.1016" layer="21"/>
<wire x1="0.075" y1="0.6" x2="0.3" y2="0.6" width="0.1016" layer="21"/>
<wire x1="0.075" y1="-0.6" x2="0.075" y2="-0.075" width="0.1016" layer="21"/>
<wire x1="0.075" y1="-0.075" x2="0.3" y2="-0.075" width="0.1016" layer="21"/>
<wire x1="0.3" y1="-0.075" x2="0.3" y2="-0.6" width="0.1016" layer="21"/>
<wire x1="0.3" y1="-0.6" x2="0.075" y2="-0.6" width="0.1016" layer="21"/>
<wire x1="-0.075" y1="0.6" x2="-0.075" y2="0.075" width="0.1016" layer="21"/>
<wire x1="-0.075" y1="0.075" x2="-0.3" y2="0.075" width="0.1016" layer="21"/>
<wire x1="-0.3" y1="0.075" x2="-0.3" y2="0.6" width="0.1016" layer="21"/>
<wire x1="-0.3" y1="0.6" x2="-0.075" y2="0.6" width="0.1016" layer="21"/>
<smd name="1" x="-4.805" y="1.905" dx="1.4" dy="0.6" layer="1"/>
<smd name="2" x="-4.805" y="0.635" dx="1.4" dy="0.6" layer="1"/>
<smd name="3" x="-4.805" y="-0.635" dx="1.4" dy="0.6" layer="1"/>
<smd name="4" x="-4.805" y="-1.905" dx="1.4" dy="0.6" layer="1"/>
<smd name="5" x="4.805" y="-1.905" dx="1.4" dy="0.6" layer="1" rot="R180"/>
<smd name="6" x="4.805" y="-0.635" dx="1.4" dy="0.6" layer="1" rot="R180"/>
<smd name="7" x="4.805" y="0.635" dx="1.4" dy="0.6" layer="1" rot="R180"/>
<smd name="8" x="4.805" y="1.905" dx="1.4" dy="0.6" layer="1" rot="R180"/>
<text x="-0.725" y="0.225" size="0.3048" layer="21">a</text>
<text x="-0.725" y="-0.475" size="0.3048" layer="21">b</text>
<text x="0.425" y="-0.475" size="0.3048" layer="21">c</text>
<text x="0.425" y="0.225" size="0.3048" layer="21">d</text>
<rectangle x1="-4.1" y1="1.65" x2="-3.3" y2="2.15" layer="51"/>
<rectangle x1="-3.3" y1="1.7" x2="-2" y2="2.1" layer="21"/>
<rectangle x1="-5.45" y1="1.7" x2="-4.1" y2="2.1" layer="51"/>
<rectangle x1="-4.1" y1="0.38" x2="-3.3" y2="0.88" layer="51"/>
<rectangle x1="-3.3" y1="0.43" x2="-2" y2="0.83" layer="21"/>
<rectangle x1="-5.45" y1="0.43" x2="-4.1" y2="0.83" layer="51"/>
<rectangle x1="-4.1" y1="-0.89" x2="-3.3" y2="-0.39" layer="51"/>
<rectangle x1="-3.3" y1="-0.84" x2="-2" y2="-0.44" layer="21"/>
<rectangle x1="-5.45" y1="-0.84" x2="-4.1" y2="-0.44" layer="51"/>
<rectangle x1="-4.1" y1="-2.16" x2="-3.3" y2="-1.66" layer="51"/>
<rectangle x1="-3.3" y1="-2.11" x2="-2" y2="-1.71" layer="21"/>
<rectangle x1="-5.45" y1="-2.11" x2="-4.1" y2="-1.71" layer="51"/>
<rectangle x1="3.3" y1="-2.15" x2="4.1" y2="-1.65" layer="51" rot="R180"/>
<rectangle x1="2" y1="-2.1" x2="3.3" y2="-1.7" layer="21" rot="R180"/>
<rectangle x1="4.1" y1="-2.1" x2="5.45" y2="-1.7" layer="51" rot="R180"/>
<rectangle x1="3.3" y1="-0.88" x2="4.1" y2="-0.38" layer="51" rot="R180"/>
<rectangle x1="2" y1="-0.83" x2="3.3" y2="-0.43" layer="21" rot="R180"/>
<rectangle x1="4.1" y1="-0.83" x2="5.45" y2="-0.43" layer="51" rot="R180"/>
<rectangle x1="3.3" y1="0.39" x2="4.1" y2="0.89" layer="51" rot="R180"/>
<rectangle x1="2" y1="0.44" x2="3.3" y2="0.84" layer="21" rot="R180"/>
<rectangle x1="4.1" y1="0.44" x2="5.45" y2="0.84" layer="51" rot="R180"/>
<rectangle x1="3.3" y1="1.66" x2="4.1" y2="2.16" layer="51" rot="R180"/>
<rectangle x1="2" y1="1.71" x2="3.3" y2="2.11" layer="21" rot="R180"/>
<rectangle x1="4.1" y1="1.71" x2="5.45" y2="2.11" layer="51" rot="R180"/>
</package>
<package name="S6695-01">
<wire x1="-0.95" y1="-0.95" x2="-0.95" y2="-0.075" width="0.1016" layer="21"/>
<wire x1="-0.95" y1="-0.075" x2="-0.075" y2="-0.075" width="0.1016" layer="21"/>
<wire x1="-0.075" y1="-0.075" x2="-0.075" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="-0.075" y1="-0.95" x2="-0.95" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="0.95" y1="0.95" x2="0.95" y2="0.075" width="0.1016" layer="21"/>
<wire x1="0.95" y1="0.075" x2="0.075" y2="0.075" width="0.1016" layer="21"/>
<wire x1="0.075" y1="0.075" x2="0.075" y2="0.95" width="0.1016" layer="21"/>
<wire x1="0.075" y1="0.95" x2="0.95" y2="0.95" width="0.1016" layer="21"/>
<wire x1="0.075" y1="-0.95" x2="0.075" y2="-0.075" width="0.1016" layer="21"/>
<wire x1="0.075" y1="-0.075" x2="0.95" y2="-0.075" width="0.1016" layer="21"/>
<wire x1="0.95" y1="-0.075" x2="0.95" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="0.95" y1="-0.95" x2="0.075" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="-0.075" y1="0.95" x2="-0.075" y2="0.075" width="0.1016" layer="21"/>
<wire x1="-0.075" y1="0.075" x2="-0.95" y2="0.075" width="0.1016" layer="21"/>
<wire x1="-0.95" y1="0.075" x2="-0.95" y2="0.95" width="0.1016" layer="21"/>
<wire x1="-0.95" y1="0.95" x2="-0.075" y2="0.95" width="0.1016" layer="21"/>
<smd name="1" x="-3.305" y="1.27" dx="1.4" dy="0.6" layer="1"/>
<smd name="2" x="-3.305" y="0" dx="1.4" dy="0.6" layer="1"/>
<smd name="3" x="-3.305" y="-1.27" dx="1.4" dy="0.6" layer="1"/>
<smd name="4" x="3.305" y="-1.27" dx="1.4" dy="0.6" layer="1"/>
<smd name="5" x="3.305" y="0" dx="1.4" dy="0.6" layer="1"/>
<smd name="6" x="3.305" y="1.27" dx="1.4" dy="0.6" layer="1"/>
<text x="-1.5" y="0.5" size="0.3048" layer="21">a</text>
<text x="-1.5" y="-0.75" size="0.3048" layer="21">b</text>
<text x="1.25" y="-0.75" size="0.3048" layer="21">c</text>
<text x="1.25" y="0.5" size="0.3048" layer="21">d</text>
<rectangle x1="-3.55" y1="1.015" x2="-2.025" y2="1.515" layer="51"/>
<rectangle x1="-3.55" y1="-0.255" x2="-2.025" y2="0.245" layer="51"/>
<rectangle x1="-3.55" y1="-1.525" x2="-2.025" y2="-1.025" layer="51"/>
<rectangle x1="2.025" y1="-1.515" x2="3.55" y2="-1.015" layer="51" rot="R180"/>
<rectangle x1="2.025" y1="-0.245" x2="3.55" y2="0.255" layer="51" rot="R180"/>
<rectangle x1="2.025" y1="1.025" x2="3.55" y2="1.525" layer="51" rot="R180"/>
</package>
<package name="S7379-01">
<wire x1="-0.075" y1="-0.95" x2="-0.1" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="-0.1" y1="-0.95" x2="-0.95" y2="-0.1" width="0.1016" layer="21" curve="-90"/>
<wire x1="-0.95" y1="-0.1" x2="-0.95" y2="-0.075" width="0.1016" layer="21"/>
<wire x1="0.075" y1="0.95" x2="0.1" y2="0.95" width="0.1016" layer="21"/>
<wire x1="0.1" y1="0.95" x2="0.95" y2="0.1" width="0.1016" layer="21" curve="-90"/>
<wire x1="0.95" y1="0.1" x2="0.95" y2="0.075" width="0.1016" layer="21"/>
<wire x1="0.95" y1="-0.075" x2="0.95" y2="-0.1" width="0.1016" layer="21"/>
<wire x1="0.95" y1="-0.1" x2="0.1" y2="-0.95" width="0.1016" layer="21" curve="-90"/>
<wire x1="0.1" y1="-0.95" x2="0.075" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="-0.95" y1="0.075" x2="-0.95" y2="0.1" width="0.1016" layer="21"/>
<wire x1="-0.95" y1="0.1" x2="-0.1" y2="0.95" width="0.1016" layer="21" curve="-90"/>
<wire x1="-0.1" y1="0.95" x2="-0.075" y2="0.95" width="0.1016" layer="21"/>
<text x="-1.25" y="0.75" size="0.3048" layer="21">a</text>
<text x="-1.25" y="-1" size="0.3048" layer="21">b</text>
<text x="1" y="-1" size="0.3048" layer="21">c</text>
<text x="1" y="0.75" size="0.3048" layer="21">d</text>
</package>
<package name="DO-214AC">
<description>&lt;b&gt;SURFACE MOUNT GENERAL RECTIFIER&lt;/b&gt; JEDEC DO-214AC molded platic body&lt;p&gt;
Method 2026&lt;br&gt;
Source: http://www.kingtronics.com/SMD_M7/M7_SMD_4007.pdf</description>
<wire x1="-2.15" y1="1.3" x2="2.15" y2="1.3" width="0.2032" layer="51"/>
<wire x1="2.15" y1="1.3" x2="2.15" y2="-1.3" width="0.2032" layer="51"/>
<wire x1="2.15" y1="-1.3" x2="-2.15" y2="-1.3" width="0.2032" layer="51"/>
<wire x1="-2.15" y1="-1.3" x2="-2.15" y2="1.3" width="0.2032" layer="51"/>
<wire x1="-1.035" y1="1.3" x2="1.025" y2="1.3" width="0.2032" layer="21"/>
<wire x1="1.025" y1="-1.3" x2="-1.035" y2="-1.3" width="0.2032" layer="21"/>
<smd name="C" x="-2.025" y="0" dx="1.8" dy="2.4" layer="1"/>
<smd name="A" x="2.025" y="0" dx="1.8" dy="2.4" layer="1" rot="R180"/>
<rectangle x1="-2.825" y1="-1.1" x2="-2.175" y2="1.1" layer="51"/>
<rectangle x1="2.175" y1="-1.1" x2="2.825" y2="1.1" layer="51" rot="R180"/>
<rectangle x1="-1.065" y1="-1.225" x2="-0.39" y2="1.225" layer="21"/>
<rectangle x1="-1.75" y1="-1.225" x2="-1.075" y2="1.225" layer="51"/>
</package>
<package name="SOD-123_MINI-SMA">
<description>&lt;b&gt;Molded plasitc,JEDEC SOD-123/Mini SMA&lt;/b&gt;&lt;p&gt;
Source: Comchip CGRM4001-G.pdf</description>
<wire x1="-1.8725" y1="0.835" x2="1.8725" y2="0.835" width="0.127" layer="51"/>
<wire x1="-1.8725" y1="-0.835" x2="1.8725" y2="-0.835" width="0.127" layer="51"/>
<wire x1="-0.3175" y1="0" x2="0.3175" y2="-0.4763" width="0.127" layer="21"/>
<wire x1="0.3175" y1="-0.4763" x2="0.3175" y2="0" width="0.127" layer="21"/>
<wire x1="0.3175" y1="0.4763" x2="-0.3175" y2="0" width="0.127" layer="21"/>
<wire x1="-0.3175" y1="0" x2="-0.3175" y2="0.4763" width="0.127" layer="21"/>
<wire x1="0.3175" y1="0" x2="0.5613" y2="0" width="0.127" layer="21"/>
<wire x1="-0.3175" y1="0" x2="-0.5613" y2="0" width="0.127" layer="21"/>
<smd name="A" x="1.8" y="0" dx="1.5" dy="2.1" layer="1" rot="R180"/>
<smd name="C" x="-1.8" y="0" dx="1.5" dy="2.1" layer="1" rot="R180"/>
<text x="-3.048" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.048" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.95" y1="-0.9" x2="-1.5875" y2="0.9" layer="51"/>
<rectangle x1="1.5875" y1="-0.9" x2="1.95" y2="0.9" layer="51"/>
<rectangle x1="-1.0249" y1="-0.9" x2="-0.6625" y2="0.9" layer="51"/>
</package>
<package name="DO41-7.6">
<description>&lt;b&gt;DO41&lt;/b&gt; 7.6mm x 2mm&lt;p&gt;
Source: http://www.diodes.com/datasheets/ds23001.pdf</description>
<wire x1="2.082" y1="-0.92" x2="-2.082" y2="-0.92" width="0.1524" layer="21"/>
<wire x1="2.082" y1="-0.92" x2="2.082" y2="0.92" width="0.1524" layer="21"/>
<wire x1="-2.082" y1="0.92" x2="2.082" y2="0.92" width="0.1524" layer="21"/>
<wire x1="-2.082" y1="0.92" x2="-2.082" y2="-0.92" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0" x2="2.494" y2="0" width="0.85" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.519" y2="0" width="0.85" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="1.1" diameter="1.7"/>
<pad name="A" x="3.81" y="0" drill="1.1" diameter="1.7"/>
<text x="-2.032" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-0.95" x2="-1.143" y2="0.92" layer="21"/>
<rectangle x1="2.082" y1="-0.425" x2="2.717" y2="0.425" layer="21"/>
<rectangle x1="-2.717" y1="-0.425" x2="-2.082" y2="0.425" layer="21"/>
</package>
<package name="SMA">
<description>&lt;b&gt;SMA&lt;/b&gt; CASE 403D-02&lt;p&gt;
Source: http://www.onsemi.com/pub_link/Collateral/MBRA340T3-D.PDF</description>
<wire x1="-2.25" y1="1.825" x2="2.25" y2="1.825" width="0.254" layer="21"/>
<wire x1="2.25" y1="-1.825" x2="-2.25" y2="-1.825" width="0.254" layer="21"/>
<wire x1="-2.25" y1="1.825" x2="-2.25" y2="1.25" width="0.254" layer="21"/>
<wire x1="2.25" y1="1.25" x2="2.25" y2="-1.25" width="0.254" layer="51"/>
<wire x1="-2.25" y1="-1.825" x2="-2.25" y2="-1.25" width="0.254" layer="21"/>
<wire x1="2.25" y1="-1.825" x2="2.25" y2="-1.25" width="0.254" layer="21" curve="-1.904406"/>
<wire x1="2.25" y1="1.825" x2="2.25" y2="1.25" width="0.254" layer="21"/>
<wire x1="-2.25" y1="-1.25" x2="-2.25" y2="1.25" width="0.254" layer="51"/>
<smd name="C" x="-2" y="0" dx="2" dy="2" layer="1"/>
<smd name="A" x="2" y="0" dx="2" dy="2" layer="1"/>
<text x="-2.75" y="2" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.75" y="-3.5" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.38" y1="-0.825" x2="2.8" y2="0.8" layer="51"/>
<rectangle x1="-2.8" y1="-0.8" x2="-2.38" y2="0.8" layer="51"/>
<rectangle x1="-1.5" y1="-1.75" x2="-0.75" y2="1.75" layer="51"/>
<rectangle x1="-1.5" y1="1.25" x2="-0.75" y2="1.75" layer="21"/>
<rectangle x1="-1.5" y1="-1.75" x2="-0.75" y2="-1.25" layer="21"/>
</package>
<package name="SOD123FL">
<description>SOD-123FL CASE 498-01 ISSUE A&lt;br&gt;</description>
<wire x1="-1.35" y1="0.8" x2="1.35" y2="0.8" width="0.2032" layer="51"/>
<wire x1="1.35" y1="0.8" x2="1.35" y2="-0.8" width="0.2032" layer="51"/>
<wire x1="1.35" y1="-0.8" x2="-1.35" y2="-0.8" width="0.2032" layer="51"/>
<wire x1="-1.35" y1="-0.8" x2="-1.35" y2="0.8" width="0.2032" layer="51"/>
<wire x1="-0.85" y1="0.8" x2="0.85" y2="0.8" width="0.2032" layer="21"/>
<wire x1="0.85" y1="-0.8" x2="-0.85" y2="-0.8" width="0.2032" layer="21"/>
<smd name="A" x="1.625" y="0" dx="0.91" dy="1.22" layer="1"/>
<smd name="C" x="-1.625" y="0" dx="0.91" dy="1.22" layer="1" rot="R180"/>
<text x="-2" y="1" size="1.27" layer="25">&gt;NAME</text>
<text x="-2" y="-2.5" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.8" y1="-0.55" x2="-1.425" y2="0.55" layer="51"/>
<rectangle x1="1.425" y1="-0.55" x2="1.8" y2="0.55" layer="51" rot="R180"/>
<rectangle x1="-0.95" y1="-0.775" x2="-0.65" y2="0.8" layer="21"/>
</package>
<package name="DO201V">
diameter 5.6 mm, vertical, grid 5.08 mm</description>
<wire x1="-1.905" y1="1.905" x2="-0.635" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.905" x2="0.508" y2="2.4892" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.4892" x2="0.508" y2="1.3208" width="0.1524" layer="21"/>
<wire x1="0.508" y1="1.3208" x2="-0.635" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.905" x2="1.651" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0" x2="1.143" y2="0" width="1.27" layer="51"/>
<wire x1="-2.54" y1="0" x2="-1.143" y2="0" width="1.27" layer="51"/>
<wire x1="-1.016" y1="2.3622" x2="-1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="2.54" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="-0.635" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.4478" x2="-0.254" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.27" x2="-0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="-0.635" y2="1.905" width="0.1524" layer="21"/>
<pad name="C" x="-2.54" y="0" drill="1.4" diameter="3.175" shape="octagon"/>
<pad name="A" x="2.54" y="0" drill="1.4" diameter="3.175" shape="octagon"/>
<text x="-3.175" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-0.889" y1="-0.635" x2="0" y2="0.635" layer="21"/>
<rectangle x1="0" y1="-0.635" x2="0.889" y2="0.635" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="D">
<wire x1="-1.27" y1="-1.27" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="-1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="1.27" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="1.27" y2="-1.27" width="0.254" layer="94"/>
<text x="2.54" y="0.4826" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="-2.3114" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A" x="-2.54" y="0" visible="off" length="short" direction="pas"/>
<pin name="C" x="2.54" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="ZD">
<wire x1="1.27" y1="-1.27" x2="0.635" y2="-1.27" width="0.254" layer="94"/>
<text x="-1.778" y="1.905" size="1.778" layer="95">&gt;NAME</text>
<text x="-1.778" y="-3.429" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="SCHOTTKY">
<wire x1="1.905" y1="1.27" x2="1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="1.905" y1="1.27" x2="1.905" y2="1.016" width="0.254" layer="94"/>
<wire x1="0.635" y1="-1.016" x2="0.635" y2="-1.27" width="0.254" layer="94"/>
<text x="-2.286" y="1.905" size="1.778" layer="95">&gt;NAME</text>
<text x="-2.286" y="-3.429" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="DIAC">
<wire x1="-2.54" y1="-2.54" x2="0" y2="-1.27" width="0.254" layer="94"/>
<wire x1="0" y1="-1.27" x2="-2.54" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-2.54" y1="0" x2="-2.54" y2="-2.54" width="0.254" layer="94"/>
<wire x1="0" y1="-1.27" x2="0" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-2.54" y1="2.54" x2="-2.54" y2="1.27" width="0.254" layer="94"/>
<wire x1="-2.54" y1="1.27" x2="-2.54" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="-2.54" y2="1.27" width="0.254" layer="94"/>
<wire x1="-2.54" y1="1.27" x2="0" y2="2.54" width="0.254" layer="94"/>
<wire x1="0" y1="2.54" x2="0" y2="0" width="0.254" layer="94"/>
<text x="0.762" y="0.889" size="1.778" layer="95">&gt;NAME</text>
<text x="0.762" y="-2.667" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-5.08" y="0" visible="off" length="short" direction="pas"/>
<pin name="2" x="2.54" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="SCHOTTKY-BIDIR">
<wire x1="0" y1="0" x2="1.27" y2="0" width="0.1524" layer="94"/>
<wire x1="3.81" y1="1.27" x2="3.81" y2="-1.27" width="0.254" layer="94"/>
<wire x1="3.81" y1="-1.27" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="3.81" y2="1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="2.54" y2="0" width="0.1524" layer="94"/>
<text x="-1.27" y="1.905" size="1.778" layer="95">&gt;NAME</text>
<text x="-1.27" y="-3.429" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-2.54" y="0" visible="off" length="short" direction="pas"/>
<pin name="2" x="5.08" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="TD">
<wire x1="1.27" y1="0" x2="1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="1.27" x2="0.635" y2="1.27" width="0.254" layer="94"/>
<wire x1="0.635" y1="-1.27" x2="1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="-1.27" x2="1.27" y2="0" width="0.254" layer="94"/>
<text x="-2.032" y="2.0066" size="1.778" layer="95">&gt;NAME</text>
<text x="-2.032" y="-3.5814" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="ZD-U">
<text x="-1.524" y="1.905" size="1.778" layer="95">&gt;NAME</text>
<text x="-1.524" y="-3.429" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="KD">
<wire x1="-0.381" y1="2.675" x2="-0.381" y2="2.04" width="0.254" layer="94"/>
<wire x1="0.381" y1="2.675" x2="0.381" y2="2.04" width="0.254" layer="94"/>
<wire x1="1.651" y1="2.04" x2="0.381" y2="2.04" width="0.1524" layer="94"/>
<wire x1="0.381" y1="2.04" x2="0.381" y2="1.405" width="0.254" layer="94"/>
<wire x1="-0.381" y1="2.04" x2="-1.651" y2="2.04" width="0.1524" layer="94"/>
<wire x1="-0.381" y1="2.04" x2="-0.381" y2="1.405" width="0.254" layer="94"/>
<text x="-2.032" y="3.175" size="1.778" layer="95">&gt;NAME</text>
<text x="-1.778" y="-3.683" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="KDD">
<wire x1="-1.27" y1="1.27" x2="1.27" y2="2.54" width="0.254" layer="94"/>
<wire x1="1.27" y1="2.54" x2="-1.27" y2="3.81" width="0.254" layer="94"/>
<wire x1="1.27" y1="3.81" x2="1.27" y2="2.54" width="0.254" layer="94"/>
<wire x1="0" y1="2.54" x2="1.27" y2="2.54" width="0.1524" layer="94"/>
<wire x1="-1.27" y1="3.81" x2="-1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="2.54" x2="1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="2.54" y1="2.54" x2="1.27" y2="2.54" width="0.1524" layer="94"/>
<wire x1="-0.254" y1="0.762" x2="-0.254" y2="0" width="0.254" layer="94"/>
<wire x1="0.381" y1="0.762" x2="0.381" y2="0" width="0.254" layer="94"/>
<wire x1="1.651" y1="0" x2="0.381" y2="0" width="0.1524" layer="94"/>
<wire x1="0.381" y1="0" x2="0.381" y2="-0.762" width="0.254" layer="94"/>
<wire x1="-0.254" y1="0" x2="-1.524" y2="0" width="0.1524" layer="94"/>
<wire x1="-0.254" y1="0" x2="-0.254" y2="-0.762" width="0.254" layer="94"/>
<wire x1="-1.27" y1="-3.81" x2="1.27" y2="-2.54" width="0.254" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="-1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="-1.27" x2="1.27" y2="-2.54" width="0.254" layer="94"/>
<wire x1="0" y1="-2.54" x2="1.27" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="-1.27" y1="-1.27" x2="-1.27" y2="-3.81" width="0.254" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="1.27" y2="-3.81" width="0.254" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="1.27" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="2.54" y2="2.54" width="0.1524" layer="94"/>
<circle x="2.54" y="0" radius="0.127" width="0.4064" layer="94"/>
<text x="-2.032" y="4.318" size="1.778" layer="95">&gt;NAME</text>
<text x="-2.032" y="-6.096" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A1" x="-2.54" y="2.54" visible="off" length="short" direction="pas" swaplevel="1"/>
<pin name="C" x="5.08" y="0" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="A2" x="-2.54" y="-2.54" visible="off" length="short" direction="pas" swaplevel="1"/>
</symbol>
<symbol name="DD">
<wire x1="-3.81" y1="-1.27" x2="-1.27" y2="0" width="0.254" layer="94"/>
<wire x1="-1.27" y1="0" x2="-3.81" y2="1.27" width="0.254" layer="94"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="0" width="0.254" layer="94"/>
<wire x1="-2.54" y1="0" x2="-1.27" y2="0" width="0.1524" layer="94"/>
<wire x1="-3.81" y1="1.27" x2="-3.81" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="3.81" y1="1.27" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="3.81" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-1.27" y1="0" x2="1.27" y2="0" width="0.1524" layer="94"/>
<wire x1="2.54" y1="0" x2="1.27" y2="0" width="0.1524" layer="94"/>
<wire x1="3.81" y1="-1.27" x2="3.81" y2="1.27" width="0.254" layer="94"/>
<circle x="0" y="0" radius="0.127" width="0.4064" layer="94"/>
<text x="0.762" y="2.0066" size="1.778" layer="95">&gt;NAME</text>
<text x="-4.826" y="-3.4544" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A1" x="-5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
<pin name="A2" x="5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1" rot="R180"/>
<pin name="C" x="0" y="2.54" visible="off" length="short" direction="pas" rot="R270"/>
</symbol>
<symbol name="BR210">
<wire x1="-1.27" y1="-2.54" x2="1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="-1.27" x2="-1.27" y2="0" width="0.254" layer="94"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-1.27" y1="2.54" x2="-1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="2.54" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="-1.27" y1="0" x2="-2.54" y2="0" width="0.1524" layer="94"/>
<circle x="0" y="0" radius="3.81" width="0.254" layer="94"/>
<text x="-3.81" y="4.318" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.81" y="-6.35" size="1.778" layer="96">&gt;VALUE</text>
<pin name="T1" x="-5.08" y="0" visible="pad" length="short" direction="pas"/>
<pin name="T2" x="5.08" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="BR220">
<wire x1="-3.81" y1="-2.54" x2="-1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-1.27" y1="-1.27" x2="-3.81" y2="0" width="0.254" layer="94"/>
<wire x1="-3.81" y1="0" x2="-3.81" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-1.27" y1="-1.27" x2="-1.27" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-3.81" y1="2.54" x2="-3.81" y2="1.27" width="0.254" layer="94"/>
<wire x1="-3.81" y1="1.27" x2="-3.81" y2="0" width="0.254" layer="94"/>
<wire x1="-3.81" y1="1.27" x2="-1.27" y2="2.54" width="0.254" layer="94"/>
<wire x1="-1.27" y1="2.54" x2="-1.27" y2="0" width="0.254" layer="94"/>
<wire x1="-3.81" y1="0" x2="-5.08" y2="0" width="0.1524" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="3.81" y2="-1.27" width="0.254" layer="94"/>
<wire x1="3.81" y1="0" x2="3.81" y2="-1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="1.27" y2="-2.54" width="0.254" layer="94"/>
<wire x1="3.81" y1="-1.27" x2="3.81" y2="-2.54" width="0.254" layer="94"/>
<wire x1="3.81" y1="0" x2="1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="1.27" x2="3.81" y2="2.54" width="0.254" layer="94"/>
<wire x1="3.81" y1="2.54" x2="3.81" y2="0" width="0.254" layer="94"/>
<wire x1="5.08" y1="0" x2="3.81" y2="0" width="0.1524" layer="94"/>
<wire x1="1.27" y1="0" x2="0" y2="0" width="0.1524" layer="94"/>
<wire x1="2.54" y1="3.81" x2="-2.54" y2="3.81" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-3.81" x2="2.54" y2="-3.81" width="0.254" layer="94"/>
<wire x1="-2.54" y1="3.81" x2="-2.54" y2="-3.81" width="0.254" layer="94" curve="180"/>
<wire x1="2.54" y1="3.81" x2="2.54" y2="-3.81" width="0.254" layer="94" curve="-180"/>
<wire x1="0" y1="-2.54" x2="0" y2="0" width="0.1524" layer="94"/>
<wire x1="0" y1="0" x2="-1.27" y2="0" width="0.1524" layer="94"/>
<text x="-4.318" y="6.35" size="1.778" layer="95">&gt;NAME</text>
<text x="-4.318" y="4.318" size="1.778" layer="96">&gt;VALUE</text>
<pin name="T1" x="-7.62" y="0" visible="pad" length="short" direction="pas"/>
<pin name="T2" x="0" y="-5.08" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="T3" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="SDD">
<wire x1="-0.635" y1="1.016" x2="-0.635" y2="1.27" width="0.254" layer="94"/>
<wire x1="-0.635" y1="1.27" x2="-1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-1.016" x2="-1.905" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-1.27" y1="-1.27" x2="-1.905" y2="-1.27" width="0.254" layer="94"/>
<wire x1="1.905" y1="-1.016" x2="1.905" y2="-1.27" width="0.254" layer="94"/>
<wire x1="1.905" y1="-1.27" x2="1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="0.635" y1="1.016" x2="0.635" y2="1.27" width="0.254" layer="94"/>
<text x="-4.318" y="-3.9624" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="BW">
<text x="-2.54" y="1.905" size="1.778" layer="95">&gt;NAME</text>
<text x="-2.54" y="-3.683" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="THERMO">
<wire x1="-1.27" y1="2.54" x2="-1.27" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="-3.81" y1="-0.635" x2="-3.81" y2="-1.905" width="0.1524" layer="94"/>
<wire x1="-4.445" y1="-1.27" x2="-3.175" y2="-1.27" width="0.1524" layer="94"/>
<text x="0.762" y="0.635" size="1.778" layer="95">&gt;NAME</text>
<text x="0.762" y="-2.413" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="D4C">
<wire x1="-1.778" y1="-1.651" x2="-2.54" y2="0" width="0.254" layer="94"/>
<wire x1="-2.54" y1="0" x2="-3.302" y2="-1.651" width="0.254" layer="94"/>
<wire x1="-1.778" y1="0" x2="-2.54" y2="0" width="0.254" layer="94"/>
<wire x1="-3.302" y1="-1.651" x2="-2.54" y2="-1.651" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-1.651" x2="-2.54" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-1.651" x2="-1.778" y2="-1.651" width="0.254" layer="94"/>
<wire x1="-2.54" y1="1.27" x2="-2.54" y2="0" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="0" x2="-3.302" y2="0" width="0.254" layer="94"/>
<wire x1="-2.54" y1="1.27" x2="0" y2="1.27" width="0.1524" layer="94"/>
<wire x1="0" y1="1.27" x2="0" y2="0" width="0.1524" layer="94"/>
<wire x1="0" y1="1.27" x2="2.54" y2="1.27" width="0.1524" layer="94"/>
<wire x1="2.54" y1="1.27" x2="2.54" y2="0" width="0.1524" layer="94"/>
<wire x1="2.54" y1="1.27" x2="5.08" y2="1.27" width="0.1524" layer="94"/>
<wire x1="5.08" y1="1.27" x2="5.08" y2="0" width="0.1524" layer="94"/>
<wire x1="5.08" y1="-2.54" x2="5.08" y2="-1.651" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="2.54" y2="-1.651" width="0.1524" layer="94"/>
<wire x1="0" y1="-2.54" x2="0" y2="-1.651" width="0.1524" layer="94"/>
<wire x1="0" y1="-1.651" x2="0.762" y2="-1.651" width="0.254" layer="94"/>
<wire x1="-0.762" y1="-1.651" x2="0" y2="-1.651" width="0.254" layer="94"/>
<wire x1="2.54" y1="-1.651" x2="3.302" y2="-1.651" width="0.254" layer="94"/>
<wire x1="5.08" y1="-1.651" x2="5.842" y2="-1.651" width="0.254" layer="94"/>
<wire x1="1.778" y1="-1.651" x2="2.54" y2="-1.651" width="0.254" layer="94"/>
<wire x1="4.318" y1="-1.651" x2="5.08" y2="-1.651" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-2.54" x2="-5.08" y2="2.54" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="2.54" x2="-2.54" y2="2.54" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="2.54" x2="7.62" y2="2.54" width="0.4064" layer="94"/>
<wire x1="7.62" y1="2.54" x2="7.62" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="-2.54" x2="7.62" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="1.27" x2="-2.54" y2="2.54" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-1.651" x2="-2.54" y2="0" width="0.1524" layer="94"/>
<wire x1="0" y1="0" x2="-0.762" y2="-1.651" width="0.254" layer="94"/>
<wire x1="2.54" y1="0" x2="1.778" y2="-1.651" width="0.254" layer="94"/>
<wire x1="5.08" y1="0" x2="4.318" y2="-1.651" width="0.254" layer="94"/>
<wire x1="0.762" y1="-1.651" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="3.302" y1="-1.651" x2="2.54" y2="0" width="0.254" layer="94"/>
<wire x1="5.842" y1="-1.651" x2="5.08" y2="0" width="0.254" layer="94"/>
<wire x1="0.762" y1="0" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="3.302" y1="0" x2="2.54" y2="0" width="0.254" layer="94"/>
<wire x1="5.842" y1="0" x2="5.08" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="-0.762" y2="0" width="0.254" layer="94"/>
<wire x1="2.54" y1="0" x2="1.778" y2="0" width="0.254" layer="94"/>
<wire x1="5.08" y1="0" x2="4.318" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="-1.651" x2="0" y2="0" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-1.651" x2="2.54" y2="0" width="0.1524" layer="94"/>
<wire x1="5.08" y1="-1.651" x2="5.08" y2="0" width="0.1524" layer="94"/>
<circle x="2.54" y="1.27" radius="0.254" width="0.4064" layer="94"/>
<circle x="0" y="1.27" radius="0.254" width="0.4064" layer="94"/>
<circle x="-2.54" y="1.27" radius="0.254" width="0.4064" layer="94"/>
<text x="0" y="5.334" size="1.778" layer="95">&gt;NAME</text>
<text x="0" y="3.175" size="1.778" layer="96">&gt;VALUE</text>
<pin name="C" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="2" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="3" x="0" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="4" x="2.54" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="5" x="5.08" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
</symbol>
<symbol name="D4A">
<wire x1="-2.54" y1="-1.651" x2="-1.778" y2="0" width="0.254" layer="94"/>
<wire x1="-3.302" y1="0" x2="-2.54" y2="-1.651" width="0.254" layer="94"/>
<wire x1="-0.762" y1="0" x2="0" y2="-1.651" width="0.254" layer="94"/>
<wire x1="0" y1="-1.651" x2="-0.762" y2="-1.651" width="0.254" layer="94"/>
<wire x1="1.778" y1="0" x2="2.54" y2="-1.651" width="0.254" layer="94"/>
<wire x1="2.54" y1="-1.651" x2="1.778" y2="-1.651" width="0.254" layer="94"/>
<wire x1="4.318" y1="0" x2="5.08" y2="-1.651" width="0.254" layer="94"/>
<wire x1="5.08" y1="-1.651" x2="4.318" y2="-1.651" width="0.254" layer="94"/>
<wire x1="0.762" y1="-1.651" x2="0" y2="-1.651" width="0.254" layer="94"/>
<wire x1="0" y1="-1.651" x2="0.762" y2="0" width="0.254" layer="94"/>
<wire x1="3.302" y1="-1.651" x2="2.54" y2="-1.651" width="0.254" layer="94"/>
<wire x1="2.54" y1="-1.651" x2="3.302" y2="0" width="0.254" layer="94"/>
<wire x1="5.842" y1="-1.651" x2="5.08" y2="-1.651" width="0.254" layer="94"/>
<wire x1="5.08" y1="-1.651" x2="5.842" y2="0" width="0.254" layer="94"/>
<pin name="A" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="C2" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="C3" x="0" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="C4" x="2.54" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="C5" x="5.08" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
</symbol>
<symbol name="DNC">
<wire x1="0.762" y1="-1.016" x2="0" y2="1.016" width="0.254" layer="94"/>
<wire x1="0" y1="1.016" x2="-0.762" y2="-1.016" width="0.254" layer="94"/>
<wire x1="-0.762" y1="1.016" x2="0" y2="1.016" width="0.254" layer="94"/>
<wire x1="0" y1="1.524" x2="0" y2="1.016" width="0.1524" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="1.016" width="0.1524" layer="94"/>
<wire x1="-0.762" y1="-1.016" x2="0.762" y2="-1.016" width="0.254" layer="94"/>
<wire x1="0" y1="1.016" x2="0.762" y2="1.016" width="0.254" layer="94"/>
<text x="-1.3716" y="-2.54" size="1.778" layer="95" rot="R90">&gt;NAME</text>
<text x="2.9464" y="-2.54" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="A" x="0" y="-2.54" visible="pad" length="short" direction="pas" rot="R90"/>
</symbol>
<symbol name="DN">
<pin name="C" x="0" y="2.54" visible="pad" length="short" direction="pas" rot="R270"/>
</symbol>
<symbol name="D8A">
<wire x1="-7.62" y1="-1.651" x2="-6.858" y2="0" width="0.254" layer="94"/>
<wire x1="-8.382" y1="0" x2="-7.62" y2="-1.651" width="0.254" layer="94"/>
<wire x1="-6.858" y1="0" x2="-7.62" y2="0" width="0.254" layer="94"/>
<wire x1="-8.382" y1="-1.651" x2="-7.62" y2="-1.651" width="0.254" layer="94"/>
<wire x1="-7.62" y1="-1.651" x2="-7.62" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="-7.62" y1="-1.651" x2="-6.858" y2="-1.651" width="0.254" layer="94"/>
<wire x1="-7.62" y1="1.27" x2="-7.62" y2="0" width="0.1524" layer="94"/>
<wire x1="-7.62" y1="0" x2="-8.382" y2="0" width="0.254" layer="94"/>
<wire x1="-7.62" y1="1.27" x2="-5.08" y2="1.27" width="0.1524" layer="94"/>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="0" width="0.1524" layer="94"/>
<wire x1="-5.08" y1="1.27" x2="-2.54" y2="1.27" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-2.54" x2="-2.54" y2="-1.651" width="0.1524" layer="94"/>
<wire x1="-5.08" y1="-2.54" x2="-5.08" y2="-1.651" width="0.1524" layer="94"/>
<wire x1="-10.16" y1="-2.54" x2="-10.16" y2="2.54" width="0.4064" layer="94"/>
<wire x1="-10.16" y1="2.54" x2="-7.62" y2="2.54" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="2.54" x2="12.7" y2="2.54" width="0.4064" layer="94"/>
<wire x1="12.7" y1="2.54" x2="12.7" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="-10.16" y1="-2.54" x2="2.54" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="5.08" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="5.08" y1="-2.54" x2="7.62" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-2.54" x2="10.16" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="10.16" y1="-2.54" x2="12.7" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="1.27" x2="-7.62" y2="2.54" width="0.1524" layer="94"/>
<wire x1="-7.62" y1="-1.651" x2="-7.62" y2="0" width="0.1524" layer="94"/>
<wire x1="-5.842" y1="0" x2="-5.08" y2="-1.651" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-1.651" x2="-5.842" y2="-1.651" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-1.651" x2="-3.302" y2="-1.651" width="0.254" layer="94"/>
<wire x1="-4.318" y1="-1.651" x2="-5.08" y2="-1.651" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-1.651" x2="-4.318" y2="0" width="0.254" layer="94"/>
<wire x1="-1.778" y1="-1.651" x2="-2.54" y2="-1.651" width="0.254" layer="94"/>
<wire x1="-4.318" y1="0" x2="-5.08" y2="0" width="0.254" layer="94"/>
<wire x1="-5.08" y1="0" x2="-5.842" y2="0" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-1.651" x2="-5.08" y2="0" width="0.1524" layer="94"/>
<wire x1="5.08" y1="1.27" x2="7.62" y2="1.27" width="0.1524" layer="94"/>
<wire x1="7.62" y1="1.27" x2="7.62" y2="0" width="0.1524" layer="94"/>
<wire x1="7.62" y1="-2.54" x2="7.62" y2="-1.651" width="0.1524" layer="94"/>
<wire x1="6.858" y1="0" x2="7.62" y2="-1.651" width="0.254" layer="94"/>
<wire x1="7.62" y1="-1.651" x2="6.858" y2="-1.651" width="0.254" layer="94"/>
<wire x1="8.382" y1="-1.651" x2="7.62" y2="-1.651" width="0.254" layer="94"/>
<wire x1="7.62" y1="-1.651" x2="8.382" y2="0" width="0.254" layer="94"/>
<wire x1="8.382" y1="0" x2="7.62" y2="0" width="0.254" layer="94"/>
<wire x1="7.62" y1="0" x2="6.858" y2="0" width="0.254" layer="94"/>
<wire x1="7.62" y1="-1.651" x2="7.62" y2="0" width="0.1524" layer="94"/>
<wire x1="7.62" y1="1.27" x2="10.16" y2="1.27" width="0.1524" layer="94"/>
<wire x1="10.16" y1="1.27" x2="10.16" y2="0" width="0.1524" layer="94"/>
<wire x1="10.16" y1="-2.54" x2="10.16" y2="-1.651" width="0.1524" layer="94"/>
<wire x1="9.398" y1="0" x2="10.16" y2="-1.651" width="0.254" layer="94"/>
<wire x1="10.16" y1="-1.651" x2="9.398" y2="-1.651" width="0.254" layer="94"/>
<wire x1="10.922" y1="-1.651" x2="10.16" y2="-1.651" width="0.254" layer="94"/>
<wire x1="10.16" y1="-1.651" x2="10.922" y2="0" width="0.254" layer="94"/>
<wire x1="10.922" y1="0" x2="10.16" y2="0" width="0.254" layer="94"/>
<wire x1="10.16" y1="0" x2="9.398" y2="0" width="0.254" layer="94"/>
<wire x1="10.16" y1="-1.651" x2="10.16" y2="0" width="0.1524" layer="94"/>
<circle x="-5.08" y="1.27" radius="0.254" width="0.4064" layer="94"/>
<circle x="-7.62" y="1.27" radius="0.254" width="0.4064" layer="94"/>
<circle x="5.08" y="1.27" radius="0.254" width="0.4064" layer="94"/>
<circle x="7.62" y="1.27" radius="0.254" width="0.4064" layer="94"/>
<text x="-5.08" y="5.334" size="1.778" layer="95">&gt;NAME</text>
<text x="-5.08" y="3.175" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A" x="-7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="C2" x="-7.62" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="C3" x="-5.08" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="C4" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="C5" x="0" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="C6" x="2.54" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="C7" x="5.08" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="C8" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="C9" x="10.16" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
</symbol>
<symbol name="D8C">
<wire x1="-6.858" y1="-1.651" x2="-7.62" y2="0" width="0.254" layer="94"/>
<wire x1="-7.62" y1="0" x2="-8.382" y2="-1.651" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-1.651" x2="-4.318" y2="-1.651" width="0.254" layer="94"/>
<wire x1="-5.842" y1="-1.651" x2="-5.08" y2="-1.651" width="0.254" layer="94"/>
<wire x1="-5.08" y1="0" x2="-5.842" y2="-1.651" width="0.254" layer="94"/>
<wire x1="-4.318" y1="-1.651" x2="-5.08" y2="0" width="0.254" layer="94"/>
<wire x1="7.62" y1="-1.651" x2="8.382" y2="-1.651" width="0.254" layer="94"/>
<wire x1="6.858" y1="-1.651" x2="7.62" y2="-1.651" width="0.254" layer="94"/>
<wire x1="7.62" y1="0" x2="6.858" y2="-1.651" width="0.254" layer="94"/>
<wire x1="8.382" y1="-1.651" x2="7.62" y2="0" width="0.254" layer="94"/>
<wire x1="10.16" y1="-1.651" x2="10.922" y2="-1.651" width="0.254" layer="94"/>
<wire x1="9.398" y1="-1.651" x2="10.16" y2="-1.651" width="0.254" layer="94"/>
<wire x1="10.16" y1="0" x2="9.398" y2="-1.651" width="0.254" layer="94"/>
<wire x1="10.922" y1="-1.651" x2="10.16" y2="0" width="0.254" layer="94"/>
<pin name="C" x="-7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="2" x="-7.62" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="3" x="-5.08" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="4" x="-2.54" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="5" x="0" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="6" x="2.54" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="7" x="5.08" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="8" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
<pin name="9" x="10.16" y="-5.08" visible="pad" length="short" direction="pas" swaplevel="1" rot="R90"/>
</symbol>
<symbol name="DNA">
<wire x1="-0.762" y1="1.016" x2="0" y2="-1.016" width="0.254" layer="94"/>
<wire x1="0" y1="-1.016" x2="0.762" y2="1.016" width="0.254" layer="94"/>
<wire x1="0.762" y1="-1.016" x2="0" y2="-1.016" width="0.254" layer="94"/>
<wire x1="0.762" y1="1.016" x2="0" y2="1.016" width="0.254" layer="94"/>
<wire x1="0" y1="1.016" x2="0" y2="0" width="0.1524" layer="94"/>
<wire x1="0" y1="1.016" x2="-0.762" y2="1.016" width="0.254" layer="94"/>
<wire x1="0" y1="-1.016" x2="-0.762" y2="-1.016" width="0.254" layer="94"/>
<pin name="C" x="0" y="-2.54" visible="pad" length="short" direction="pas" rot="R90"/>
</symbol>
<symbol name="DN1">
<wire x1="0.762" y1="1.016" x2="-0.762" y2="1.016" width="0.254" layer="94"/>
<text x="3.2004" y="-2.54" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="A" x="0" y="2.54" visible="pad" length="short" direction="pas" rot="R270"/>
</symbol>
<symbol name="KA2KA">
<wire x1="-1.27" y1="1.27" x2="-3.81" y2="0" width="0.254" layer="94"/>
<wire x1="-3.81" y1="0" x2="-1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-3.81" y1="-1.27" x2="-3.81" y2="0" width="0.254" layer="94"/>
<wire x1="-2.54" y1="0" x2="-3.81" y2="0" width="0.1524" layer="94"/>
<wire x1="-1.27" y1="-1.27" x2="-1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="-3.81" y1="0" x2="-3.81" y2="1.27" width="0.254" layer="94"/>
<wire x1="-3.81" y1="0" x2="1.27" y2="0" width="0.1524" layer="94"/>
<pin name="C" x="-5.08" y="0" visible="off" length="short" direction="pas"/>
<pin name="A" x="5.08" y="0" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="AC" x="0" y="2.54" visible="off" length="short" direction="pas" rot="R270"/>
</symbol>
<symbol name="DIODE">
<wire x1="-1.27" y1="-1.905" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="-1.27" y2="1.905" width="0.254" layer="94"/>
<wire x1="-1.27" y1="1.905" x2="-1.27" y2="-1.905" width="0.254" layer="94"/>
<wire x1="1.397" y1="1.905" x2="1.397" y2="-1.905" width="0.254" layer="94"/>
<text x="-2.3114" y="2.6416" size="1.778" layer="95">&gt;NAME</text>
<text x="-2.5654" y="-4.4958" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="D-ZENER">
<wire x1="1.397" y1="-1.905" x2="2.032" y2="-1.905" width="0.254" layer="94"/>
<wire x1="1.397" y1="1.905" x2="0.762" y2="1.905" width="0.254" layer="94"/>
<text x="-2.9464" y="2.6416" size="1.778" layer="95">&gt;NAME</text>
<text x="-4.4704" y="-4.4958" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="A2K">
<wire x1="-2.71" y1="0" x2="-1.016" y2="0" width="0.1524" layer="94"/>
<wire x1="-1.016" y1="0" x2="1.016" y2="0" width="0.1524" layer="94"/>
<wire x1="1.016" y1="0" x2="2.71" y2="0" width="0.1524" layer="94"/>
<wire x1="-3.556" y1="-1.27" x2="-1.016" y2="0" width="0.254" layer="94"/>
<wire x1="-1.016" y1="0" x2="-3.556" y2="1.27" width="0.254" layer="94"/>
<wire x1="-1.016" y1="1.27" x2="-1.016" y2="0" width="0.254" layer="94"/>
<wire x1="-3.556" y1="1.27" x2="-3.556" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-1.016" y1="0" x2="-1.016" y2="-1.27" width="0.254" layer="94"/>
<wire x1="3.556" y1="1.27" x2="1.016" y2="0" width="0.254" layer="94"/>
<wire x1="1.016" y1="0" x2="3.556" y2="-1.27" width="0.254" layer="94"/>
<wire x1="1.016" y1="-1.27" x2="1.016" y2="0" width="0.254" layer="94"/>
<wire x1="3.556" y1="-1.27" x2="3.556" y2="1.27" width="0.254" layer="94"/>
<wire x1="1.016" y1="0" x2="1.016" y2="1.27" width="0.254" layer="94"/>
<pin name="A1" x="-5.08" y="0" visible="off" length="short" direction="pas"/>
<pin name="A2" x="5.08" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="K2A">
<wire x1="1.27" y1="1.27" x2="3.81" y2="0" width="0.254" layer="94"/>
<wire x1="3.81" y1="0" x2="1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="3.81" y1="-1.27" x2="3.81" y2="0" width="0.254" layer="94"/>
<wire x1="-3.81" y1="0" x2="3.81" y2="0" width="0.1524" layer="94"/>
<wire x1="1.27" y1="-1.27" x2="1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="3.81" y1="0" x2="3.81" y2="1.27" width="0.254" layer="94"/>
<pin name="K1" x="-5.08" y="0" visible="off" length="short" direction="pas"/>
<pin name="K2" x="5.08" y="0" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="A" x="0" y="2.54" visible="off" length="short" direction="pas" rot="R270"/>
</symbol>
<symbol name="SUPPRESSOR">
<wire x1="1.27" y1="-1.27" x2="0" y2="1.27" width="0.254" layer="94"/>
<wire x1="0" y1="1.27" x2="-1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="1.905" x2="1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="1.27" x2="0" y2="1.27" width="0.254" layer="94"/>
<wire x1="-1.27" y1="-1.27" x2="1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="0" y1="1.27" x2="-1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="0.635" width="0.254" layer="94"/>
<text x="2.794" y="1.905" size="1.778" layer="95">&gt;NAME</text>
<text x="2.794" y="-0.889" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A" x="0" y="-2.54" visible="off" length="short" direction="pas" rot="R90"/>
</symbol>
<symbol name="SCHOTTKY-1">
</symbol>
<symbol name="SDD_AKAK">
<wire x1="2.54" y1="0" x2="3.81" y2="0" width="0.1524" layer="94"/>
<wire x1="3.175" y1="-1.016" x2="3.175" y2="-1.27" width="0.254" layer="94"/>
<wire x1="3.175" y1="-1.27" x2="3.81" y2="-1.27" width="0.254" layer="94"/>
<wire x1="4.445" y1="1.016" x2="4.445" y2="1.27" width="0.254" layer="94"/>
<wire x1="3.81" y1="1.27" x2="4.445" y2="1.27" width="0.254" layer="94"/>
<wire x1="-1.27" y1="0" x2="3.81" y2="0" width="0.1524" layer="94"/>
<pin name="C2" x="5.08" y="0" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="C1A2" x="0" y="2.54" visible="off" length="short" direction="pas" rot="R270"/>
</symbol>
<symbol name="SDD-1">
</symbol>
<symbol name="SDD_KAAK">
<wire x1="-3.81" y1="0" x2="-1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="-4.445" y1="1.016" x2="-4.445" y2="1.27" width="0.254" layer="94"/>
<wire x1="-4.445" y1="1.27" x2="-3.81" y2="1.27" width="0.254" layer="94"/>
<wire x1="-3.175" y1="-1.016" x2="-3.175" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-3.81" y1="0" x2="-3.81" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-3.81" y1="-1.27" x2="-3.175" y2="-1.27" width="0.254" layer="94"/>
<pin name="K1" x="-5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
<pin name="K2" x="5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1" rot="R180"/>
<pin name="AA" x="0" y="2.54" visible="off" length="short" direction="pas" rot="R270"/>
</symbol>
<symbol name="DH">
<wire x1="-2.54" y1="0" x2="0" y2="0" width="0.1524" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="2.54" width="0.1524" layer="94"/>
<wire x1="0" y1="2.54" x2="2.54" y2="2.54" width="0.1524" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="0" y1="-2.54" x2="2.54" y2="-2.54" width="0.1524" layer="94"/>
<text x="-7.62" y="3.81" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="-5.08" size="1.778" layer="96">&gt;VALUE</text>
<pin name="2" x="-5.08" y="0" visible="off" length="short" direction="pas"/>
<pin name="K" x="5.08" y="-2.54" visible="off" length="short" direction="pas" rot="R180"/>
<pin name="1" x="5.08" y="2.54" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="D-1">
<text x="-2.54" y="2.54" size="1.778" layer="95">&gt;NAME</text>
<text x="-2.54" y="-3.81" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="PHOTODIODE">
<wire x1="1.905" y1="-1.27" x2="0" y2="1.27" width="0.254" layer="94"/>
<wire x1="0" y1="1.27" x2="-1.905" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-1.27" x2="1.905" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-1.905" y1="1.397" x2="1.905" y2="1.397" width="0.254" layer="94"/>
<wire x1="-3.556" y1="1.016" x2="-4.572" y2="2.032" width="0.1524" layer="94"/>
<wire x1="-2.794" y1="1.778" x2="-3.81" y2="2.794" width="0.1524" layer="94"/>
<text x="3.81" y="1.27" size="1.778" layer="95">&gt;NAME</text>
<text x="3.81" y="-1.27" size="1.778" layer="96">&gt;VALUE</text>
<polygon width="0.1524" layer="94">
<vertex x="-4.064" y="1.016"/>
<vertex x="-3.556" y="1.524"/>
<vertex x="-3.302" y="0.762"/>
</polygon>
<vertex x="-3.302" y="1.778"/>
<vertex x="-2.794" y="2.286"/>
<vertex x="-2.54" y="1.524"/>
</polygon>
</symbol>
<symbol name="QUADRANT-PHOTODIODE-2C-4A">
<wire x1="-6.096" y1="-3.556" x2="-7.62" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-7.62" y1="-1.27" x2="-9.144" y2="-3.556" width="0.254" layer="94"/>
<wire x1="-9.144" y1="-3.556" x2="-6.096" y2="-3.556" width="0.254" layer="94"/>
<wire x1="-9.144" y1="-1.27" x2="-7.62" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-7.62" y1="-1.27" x2="-6.096" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-9.906" y1="-1.27" x2="-10.668" y2="-0.508" width="0.1524" layer="94"/>
<wire x1="-9.144" y1="-0.508" x2="-9.906" y2="0.254" width="0.1524" layer="94"/>
<wire x1="-1.016" y1="-3.556" x2="-2.54" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-1.27" x2="-4.064" y2="-3.556" width="0.254" layer="94"/>
<wire x1="-4.064" y1="-3.556" x2="-1.016" y2="-3.556" width="0.254" layer="94"/>
<wire x1="-4.064" y1="-1.27" x2="-2.54" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-1.27" x2="-1.016" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-4.826" y1="-1.27" x2="-5.588" y2="-0.508" width="0.1524" layer="94"/>
<wire x1="-4.064" y1="-0.508" x2="-4.826" y2="0.254" width="0.1524" layer="94"/>
<wire x1="4.064" y1="-3.556" x2="2.54" y2="-1.27" width="0.254" layer="94"/>
<wire x1="2.54" y1="-1.27" x2="1.016" y2="-3.556" width="0.254" layer="94"/>
<wire x1="1.016" y1="-3.556" x2="4.064" y2="-3.556" width="0.254" layer="94"/>
<wire x1="1.016" y1="-1.27" x2="2.54" y2="-1.27" width="0.254" layer="94"/>
<wire x1="2.54" y1="-1.27" x2="4.064" y2="-1.27" width="0.254" layer="94"/>
<wire x1="0.254" y1="-1.27" x2="-0.508" y2="-0.508" width="0.1524" layer="94"/>
<wire x1="1.016" y1="-0.508" x2="0.254" y2="0.254" width="0.1524" layer="94"/>
<wire x1="9.144" y1="-3.556" x2="7.62" y2="-1.27" width="0.254" layer="94"/>
<wire x1="7.62" y1="-1.27" x2="6.096" y2="-3.556" width="0.254" layer="94"/>
<wire x1="6.096" y1="-3.556" x2="9.144" y2="-3.556" width="0.254" layer="94"/>
<wire x1="6.096" y1="-1.27" x2="7.62" y2="-1.27" width="0.254" layer="94"/>
<wire x1="7.62" y1="-1.27" x2="9.144" y2="-1.27" width="0.254" layer="94"/>
<wire x1="5.334" y1="-1.27" x2="4.572" y2="-0.508" width="0.1524" layer="94"/>
<wire x1="6.096" y1="-0.508" x2="5.334" y2="0.254" width="0.1524" layer="94"/>
<wire x1="-7.62" y1="-5.08" x2="-7.62" y2="1.27" width="0.1524" layer="94"/>
<wire x1="-7.62" y1="1.27" x2="-2.54" y2="1.27" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="1.27" x2="2.54" y2="1.27" width="0.1524" layer="94"/>
<wire x1="2.54" y1="1.27" x2="7.62" y2="1.27" width="0.1524" layer="94"/>
<wire x1="7.62" y1="1.27" x2="7.62" y2="-5.08" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-5.08" x2="2.54" y2="1.27" width="0.1524" layer="94"/>
<wire x1="-2.54" y1="-5.08" x2="-2.54" y2="1.27" width="0.1524" layer="94"/>
<wire x1="2.54" y1="1.27" x2="2.54" y2="2.54" width="0.1524" layer="94"/>
<circle x="-2.54" y="1.27" radius="0.3592" width="0" layer="94"/>
<circle x="2.54" y="1.27" radius="0.3592" width="0" layer="94"/>
<text x="8.89" y="1.27" size="1.778" layer="95">&gt;NAME</text>
<text x="10.16" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<pin name="AA" x="-7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="AB" x="-2.54" y="-7.62" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="C1" x="-2.54" y="5.08" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="AC" x="2.54" y="-7.62" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="C2" x="2.54" y="5.08" visible="pad" length="short" direction="pas" rot="R270"/>
<pin name="AD" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R90"/>
<vertex x="-10.414" y="-1.27"/>
<vertex x="-9.906" y="-0.762"/>
<vertex x="-9.652" y="-1.524"/>
</polygon>
<vertex x="-9.652" y="-0.508"/>
<vertex x="-9.144" y="0"/>
<vertex x="-8.89" y="-0.762"/>
</polygon>
<vertex x="-5.334" y="-1.27"/>
<vertex x="-4.826" y="-0.762"/>
<vertex x="-4.572" y="-1.524"/>
</polygon>
<vertex x="-4.572" y="-0.508"/>
<vertex x="-4.064" y="0"/>
<vertex x="-3.81" y="-0.762"/>
</polygon>
<vertex x="-0.254" y="-1.27"/>
<vertex x="0.254" y="-0.762"/>
<vertex x="0.508" y="-1.524"/>
</polygon>
<vertex x="0.508" y="-0.508"/>
<vertex x="1.016" y="0"/>
<vertex x="1.27" y="-0.762"/>
</polygon>
<vertex x="4.826" y="-1.27"/>
<vertex x="5.334" y="-0.762"/>
<vertex x="5.588" y="-1.524"/>
</polygon>
<vertex x="5.588" y="-0.508"/>
<vertex x="6.096" y="0"/>
<vertex x="6.35" y="-0.762"/>
</polygon>
</symbol>
<symbol name="SDD_AKKA">
<wire x1="-3.81" y1="1.27" x2="-1.27" y2="0" width="0.254" layer="94"/>
<wire x1="-1.27" y1="0" x2="-3.81" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-3.81" y1="-1.27" x2="-3.81" y2="1.27" width="0.254" layer="94"/>
<wire x1="-0.635" y1="-1.016" x2="-0.635" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-0.635" y1="-1.27" x2="-1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="-1.27" y1="-1.27" x2="-1.27" y2="0" width="0.254" layer="94"/>
<wire x1="-1.905" y1="1.016" x2="-1.905" y2="1.27" width="0.254" layer="94"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="-1.27" y1="1.27" x2="-1.905" y2="1.27" width="0.254" layer="94"/>
<pin name="CC" x="0" y="2.54" visible="off" length="short" direction="pas" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="1N4148" prefix="D">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
high speed (Philips)</description>
<gates>
<gate name="G$1" symbol="D" x="0" y="0"/>
</gates>
<devices>
<device name="DO35-10" package="DO35-10">
<connects>
<connect gate="G$1" pin="A" pad="A"/>
<connect gate="G$1" pin="C" pad="C"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="DO35-7" package="DO35-7">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1N4004" prefix="D">
general purpose rectifier, 1 A</description>
<gates>
<gate name="1" symbol="D" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DO41-10">
<connects>
<connect gate="1" pin="A" pad="A"/>
<connect gate="1" pin="C" pad="C"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BY550" prefix="D">
Si200 V, 5 A</description>
<gates>
</gates>
<devices>
<device name="" package="DO27-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="P600" prefix="D">
high voltage diode, silicon rectifier&lt;p&gt;
1.0 A to 6.0 A, 50 V to 1300 V&lt;p&gt;
http://www.kosemi.com/product/diosr.html</description>
<gates>
</gates>
<devices>
<device name="" package="P6-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ZPD" prefix="D">
<description>&lt;b&gt;Z DIODE&lt;/b&gt;&lt;p&gt;
500 mW</description>
<gates>
<gate name="G$1" symbol="ZD" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DO35Z10">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ZY" prefix="D">
<description>&lt;b&gt;Z DIODE&lt;/b&gt;</description>
<gates>
<gate name="1" symbol="ZD" x="0" y="0"/>
</gates>
<devices>
<device name="" package="P1Z12">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ZPY" prefix="D">
1 W</description>
<gates>
</gates>
<devices>
<device name="" package="DO41Z10">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="TSD15" prefix="D">
<description>&lt;B&gt;DIODE&lt;/B&gt;</description>
<gates>
<gate name="G$1" symbol="SCHOTTKY" x="0" y="0"/>
</gates>
<devices>
<device name="" package="CB429-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="GT32" prefix="D">
<description>Trigger &lt;B&gt;DIODE&lt;/B&gt;</description>
<gates>
<gate name="1" symbol="DIAC" x="0" y="0"/>
</gates>
<devices>
<device name="" package="GT32">
<connects>
<connect gate="1" pin="1" pad="1"/>
<connect gate="1" pin="2" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BZX85" prefix="D">
<gates>
<gate name="D" symbol="ZD" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="D" pin="A" pad="A"/>
<connect gate="D" pin="C" pad="C"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAV17" prefix="D">
silicon-epitaxial planar diode</description>
<gates>
</gates>
<devices>
<device name="" package="DO35-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BA243A" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ZZ22" prefix="D">
<gates>
<gate name="1" symbol="SCHOTTKY-BIDIR" x="0" y="0"/>
</gates>
<devices>
<device name="" package="P2-15">
<connects>
<connect gate="1" pin="1" pad="A"/>
<connect gate="1" pin="2" pad="C"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ZZY22" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="P3-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MBD701" prefix="D">
<description>UHF &lt;B&gt;DIODE&lt;/B&gt;</description>
<gates>
<gate name="1" symbol="SCHOTTKY" x="0" y="0"/>
</gates>
<devices>
<device name="" package="TO92H">
<connects>
<connect gate="1" pin="A" pad="1"/>
<connect gate="1" pin="C" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BA221" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAS15" prefix="D">
high speed</description>
<gates>
</gates>
<devices>
<device name="" package="DO34-7">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAT81" prefix="D">
 barrier diode</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BB112" prefix="D">
<description>Capacity &lt;b&gt;DIODE&lt;/b&gt;&lt;p&gt;
variable-capacitance diode</description>
<gates>
<gate name="1" symbol="KD" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SOT54H">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BB212" prefix="D">
variable-capacitance double diode, 9 V</description>
<gates>
<gate name="1" symbol="KDD" x="0" y="2.54"/>
</gates>
<devices>
<device name="" package="SOT54E">
<connects>
<connect gate="1" pin="A1" pad="A1"/>
<connect gate="1" pin="A2" pad="A2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAT19" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAT42" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="P4KEXX" prefix="D">
transient-voltage suppressor</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="P6KEXX" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="CB417-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="15KEXXD" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="DO201T15">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="5KPXX" prefix="D">
transient voltage suppressor</description>
<gates>
</gates>
<devices>
<device name="" package="P6T15">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="P6KEXXA" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="C1702-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1N5908" prefix="D">
schottky</description>
<gates>
</gates>
<devices>
<device name="" package="C4111-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1N6267A" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ICTE5" prefix="D">
<description>Transient-suppressor &lt;B&gt;DIODE&lt;/B&gt;</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BZT03XX" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="SOD57Z10">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BZW03XX" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="SOD64Z12">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BZW04XX" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="F126Z12">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BZW04XXB" prefix="D">
uni and bidirectional supressor diode</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="P6KEXXC" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="15KEXX" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="CB429-17">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="15KEXXC" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1N5638" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="DO13M">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BZW50" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="AG">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BZW50B" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BZX55" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ZDXX" prefix="D">
1.3 W</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ZTK" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ZTE" prefix="D">
300 mW</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1N4728" prefix="D">
3.3 V, 1W, 5 percent</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1N5333" prefix="D">
3.3 V, 5W, 5 percent (Motorola)</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1N821" prefix="D">
<description>Reference &lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
temperature compensated, 6,2 V</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BZD23" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="SOD81">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BZV10" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="DO34Z7">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BZX90" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BZY97" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="SB120" prefix="D">
barrier rectifier, 1 A (Fairchild)</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="SB320" prefix="D">
barrier rectifier, 3 A (Fairchild)</description>
<gates>
</gates>
<devices>
<device name="" package="DO201-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MBR750" prefix="D">
barrier rectifier, 7.5 A, 50 V</description>
<gates>
</gates>
<devices>
<device name="" package="TO220AC">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="FE2A" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="DO204-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYV27" prefix="D">
ultra fast</description>
<gates>
</gates>
<devices>
<device name="" package="SOD57-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="FE3A" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="G4-12">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="EGP10A" prefix="D">
ultra fast-recovery rectifier</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="EGP20A" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="DO15-12">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="EGP30A" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="UF5400" prefix="D">
ultra fast rectifier, 3 A</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="FES08AT" prefix="D">
ultra-fast recovery rectifier</description>
<gates>
</gates>
<devices>
<device name="" package="DO220S">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYW29" prefix="D">
ultra fast rectifier, 200 V, 8 A</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="FEP16AT" prefix="D">
dual ultra-fast recovery rectifier, common cathode</description>
<gates>
<gate name="1" symbol="DD" x="0" y="0"/>
</gates>
<devices>
<device name="" package="TO220ABS">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYV32" prefix="D">
2 x Si diode&lt;p&gt;
200 V, 20 A/230 Apeak, 25 ns</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="FEP30AP" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="TO3P">
<connects>
<connect gate="1" pin="A1" pad="1"/>
<connect gate="1" pin="A2" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1N5060GP" prefix="D">
controlled avalanche rectifier</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="GP15" prefix="D">
low leakage at high temperature, 2 A (Diotec)</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BY251" prefix="D">
Si, 200 V, 3 A</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1N5624" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1N4942" prefix="D">
1.0 A, 200 V, 150 ns</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="RGP10" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="RGP15" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="RGP30" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1N5059" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYW52" prefix="D">
silicon mesa rectifier (Vishay Telefunken)</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="RG1" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYV95" prefix="D">
fast soft-recovery controlled avalanche rectifier</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYW32" prefix="D">
fast silicon-mesa rectifier (Vishay Telefunken)</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYW772" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1N5400" prefix="D">
standard rectifier, 3 A, 50 V (Motorola)</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="SRP100" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1N4933" prefix="D">
fast recovery rectifier, 1A</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BY396" prefix="D">
Si,100 V, 3 A</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BY500" prefix="D">
fast recovery diode, 5 A, 800 V</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="GI820" prefix="D">
fast-recovery silicon diode, 6 A (Diotec)</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYW51" prefix="D">
hyperfast dual diode</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MUR810" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="TO220ACS">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="GE1001" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A114" prefix="D">
germanium</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BA157" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="P1-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BA296" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BY527" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYD13" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYD14" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="SOD84">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYM36" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="SOD64-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYV28" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYW95" prefix="D">
fast soft-recovery rectifier</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BY228" prefix="D">
damper diode</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BY505" prefix="D">
high-voltage soft recovery rectifier</description>
<gates>
</gates>
<devices>
<device name="" package="SOD61A">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BY609" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="SOD61B">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BY619" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="SOD61C">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BY707" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="SOD61D">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BY712" prefix="D">
fast high-voltage soft-recovery rectifier</description>
<gates>
</gates>
<devices>
<device name="" package="SOD61E">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYX90G" prefix="D">
high voltage</description>
<gates>
</gates>
<devices>
<device name="" package="SOD83-12">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BR210" prefix="D">
<description>&lt;B&gt;DIAC&lt;/B&gt;</description>
<gates>
<gate name="1" symbol="BR210" x="0" y="0"/>
</gates>
<devices>
<device name="" package="BR210S">
<connects>
<connect gate="1" pin="T1" pad="T1"/>
<connect gate="1" pin="T2" pad="T2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BR220" prefix="D">
double diode</description>
<gates>
<gate name="1" symbol="BR220" x="0" y="0"/>
</gates>
<devices>
<device name="" package="BR220S">
<connects>
<connect gate="1" pin="T3" pad="T3"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PBYR635" prefix="D">
<description>Dual &lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
<gates>
<gate name="1" symbol="SDD" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SOT82S">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PBYR3035" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="SOT93S">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYT52" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="SGA-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BY203" prefix="D">
Si, 2 kV, 0.25 A, 300 ns</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYV12" prefix="D">
fast silicon mesa rectifier (Vishay Telefunken)</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYT51" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYT85" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAS70" prefix="D">
<description>&lt;b&gt;Silicon Schottky Diodes&lt;/b&gt;&lt;p&gt;
General-purpose diode for high-speed switching</description>
<gates>
</gates>
<devices>
<device name="" package="SOT23">
<connects>
<connect gate="1" pin="C" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAW75" prefix="D">
<gates>
<gate name="D" symbol="D" x="0" y="0"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1N4446" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAV21" prefix="D">
high-voltage general purpose diode</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="FE5D" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="UF4003" prefix="D">
ultrafast recovery diode, 200 V&lt;p&gt;
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MUR150RL" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MUR440RL" prefix="D">
ultra-fast recovery rectifier, Vrrm = 40 V, 4 A</description>
<gates>
</gates>
<devices>
<device name="" package="C2673">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MUR620CT" prefix="D">
dual rectifier, 6 A, 200 V, common cathode</description>
<gates>
</gates>
<devices>
<device name="" package="TO220AB">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MUR820" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="C221B1A">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MBR3035CT" prefix="D">
dual barrier rectifier, 30 A, 30 V, common cathode</description>
<gates>
</gates>
<devices>
<device name="" package="C1103">
<connects>
<connect gate="1" pin="C" pad="C C@1" route="any"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYV36" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYV96" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYW55" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYW96" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1N5061" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BY448" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BY584" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="AA112" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="DO07">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="AA215" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="AA119" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYW100" prefix="D">
high-efficiency fast rectifier (ST)</description>
<gates>
</gates>
<devices>
<device name="" package="F126-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYW80" prefix="D">
high-efficiency fast recovery rectifier (ST)</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYW51F" prefix="D">
dual ultra fast diode, 200 V (ST)</description>
<gates>
</gates>
<devices>
<device name="" package="IW220ABS">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYT01" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYT08P" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYT03" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAT49" prefix="D">
small signal diode</description>
<gates>
<gate name="A" symbol="SCHOTTKY" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="A" pad="A"/>
<connect gate="A" pin="C" pad="C"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BYV10" prefix="D">
power diode</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="D5-1A" prefix="DN">
<description>4 &lt;B&gt;DIODES&lt;/B&gt;&lt;p&gt;
SIL, common anode</description>
<gates>
<gate name="A" symbol="D4A" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SIL05A">
<connects>
<connect gate="A" pin="A" pad="1"/>
<connect gate="A" pin="C2" pad="2"/>
<connect gate="A" pin="C3" pad="3"/>
<connect gate="A" pin="C4" pad="4"/>
<connect gate="A" pin="C5" pad="5"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="D5-1C" prefix="DN">
SIL, common cathode</description>
<gates>
<gate name="A" symbol="D4C" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SIL05C">
<connects>
<connect gate="A" pin="2" pad="2"/>
<connect gate="A" pin="3" pad="3"/>
<connect gate="A" pin="4" pad="4"/>
<connect gate="A" pin="5" pad="5"/>
<connect gate="A" pin="C" pad="1"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="D8-3A" prefix="DN">
SIL, anode marked</description>
<gates>
<gate name="A" symbol="DN" x="0" y="0" swaplevel="1"/>
<gate name="B" symbol="DN" x="7.62" y="0" swaplevel="1"/>
<gate name="C" symbol="DN" x="15.24" y="0" swaplevel="1"/>
<gate name="D" symbol="DN" x="22.86" y="0" swaplevel="1"/>
</gates>
<devices>
<device name="" package="SIL08A">
<connects>
<connect gate="A" pin="C" pad="2"/>
<connect gate="B" pin="A" pad="3"/>
<connect gate="B" pin="C" pad="4"/>
<connect gate="C" pin="A" pad="5"/>
<connect gate="C" pin="C" pad="6"/>
<connect gate="D" pin="A" pad="7"/>
<connect gate="D" pin="C" pad="8"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="D8-3C" prefix="DN">
SIL, cathode marked</description>
<gates>
<gate name="A" symbol="DN" x="-5.08" y="0" swaplevel="1"/>
<gate name="B" symbol="DN" x="2.54" y="0" swaplevel="1"/>
<gate name="C" symbol="DN" x="10.16" y="0" swaplevel="1"/>
<gate name="D" symbol="DN" x="17.78" y="0" swaplevel="1"/>
</gates>
<devices>
<device name="" package="SIL08C">
<connects>
<connect gate="A" pin="A" pad="2"/>
<connect gate="B" pin="A" pad="4"/>
<connect gate="B" pin="C" pad="3"/>
<connect gate="C" pin="A" pad="6"/>
<connect gate="C" pin="C" pad="5"/>
<connect gate="D" pin="A" pad="8"/>
<connect gate="D" pin="C" pad="7"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="D9-1A" prefix="DN">
<description>8 &lt;B&gt;DIODES&lt;/B&gt;&lt;p&gt;
<gates>
<gate name="A" symbol="D8A" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SIL09A">
<connects>
<connect gate="A" pin="C6" pad="6"/>
<connect gate="A" pin="C7" pad="7"/>
<connect gate="A" pin="C8" pad="8"/>
<connect gate="A" pin="C9" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="D9-1C" prefix="DN">
<gates>
<gate name="A" symbol="D8C" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SIL09C">
<connects>
<connect gate="A" pin="6" pad="6"/>
<connect gate="A" pin="7" pad="7"/>
<connect gate="A" pin="8" pad="8"/>
<connect gate="A" pin="9" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="D5-1CS" prefix="DN">
SIL, common anode (single gate)</description>
<gates>
<gate name="A" symbol="DN" x="-7.62" y="0"/>
<gate name="B" symbol="DNC" x="0" y="0"/>
<gate name="C" symbol="DNC" x="7.62" y="0"/>
<gate name="D" symbol="DNC" x="15.24" y="0"/>
</gates>
<devices>
<connects>
<connect gate="C" pin="A" pad="4"/>
<connect gate="D" pin="A" pad="5"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="D5-1AS" prefix="DN">
<gates>
<gate name="B" symbol="DNA" x="-5.08" y="0"/>
<gate name="C" symbol="DNA" x="2.54" y="0"/>
<gate name="D" symbol="DNA" x="10.16" y="0"/>
<gate name="A" symbol="DN1" x="-12.7" y="0"/>
</gates>
<devices>
<connects>
<connect gate="C" pin="C" pad="4"/>
<connect gate="D" pin="C" pad="5"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="D9-1AS" prefix="DN">
<gates>
<gate name="A" symbol="DN1" x="0" y="0"/>
<gate name="B" symbol="DNA" x="7.62" y="0"/>
<gate name="C" symbol="DNA" x="15.24" y="0"/>
<gate name="D" symbol="DNA" x="22.86" y="0"/>
<gate name="E" symbol="DNA" x="0" y="-12.7"/>
<gate name="F" symbol="DNA" x="7.62" y="-12.7"/>
<gate name="G" symbol="DNA" x="15.24" y="-12.7"/>
<gate name="H" symbol="DNA" x="22.86" y="-12.7"/>
</gates>
<devices>
<connects>
<connect gate="E" pin="C" pad="6"/>
<connect gate="F" pin="C" pad="7"/>
<connect gate="G" pin="C" pad="8"/>
<connect gate="H" pin="C" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="D9-1CS" prefix="DN">
SIL, common cathode (single gate)</description>
<gates>
<gate name="A" symbol="DN" x="0" y="0"/>
<gate name="B" symbol="DNC" x="7.62" y="0"/>
<gate name="C" symbol="DNC" x="15.24" y="0"/>
<gate name="D" symbol="DNC" x="22.86" y="0"/>
<gate name="E" symbol="DNC" x="0" y="-15.24"/>
<gate name="F" symbol="DNC" x="7.62" y="-15.24"/>
<gate name="G" symbol="DNC" x="15.24" y="-15.24"/>
<gate name="H" symbol="DNC" x="22.86" y="-15.24"/>
</gates>
<devices>
<connects>
<connect gate="E" pin="A" pad="6"/>
<connect gate="F" pin="A" pad="7"/>
<connect gate="G" pin="A" pad="8"/>
<connect gate="H" pin="A" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="OA91" prefix="D">
germanium signal diode&lt;p&gt;
115 V 50 mA</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="OA95" prefix="D">
germanium diode&lt;p&gt;
115 V, 50 mA/150 mA</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BZX84CSMD" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="TO236">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAV199" prefix="D">
low-leakage double diode</description>
<gates>
<gate name="G$1" symbol="KA2KA" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="A" pad="1"/>
<connect gate="G$1" pin="AC" pad="3"/>
<connect gate="G$1" pin="C" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BB141" prefix="D">
<gates>
<gate name="G$1" symbol="KD" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SOD523">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BBY51" prefix="D">
variable-capacitance diode (Infineon)</description>
<gates>
<gate name="G$1" symbol="KDD" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="A1" pad="1"/>
<connect gate="G$1" pin="A2" pad="2"/>
<connect gate="G$1" pin="C" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PMLL4150" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="SOD80C">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ES2D" prefix="D">
super fast rectifier, 2 A</description>
<gates>
</gates>
<devices>
<device name="" package="SMB">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ZENER-DIODE" prefix="D" uservalue="yes">
<description>Z-Diode</description>
<gates>
</gates>
<devices>
<device name="DO35Z10" package="DO35Z10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DO41Z10" package="DO41Z10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1702-15" package="C1702-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DO13M" package="DO13M">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD57-10" package="SOD57Z10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DO34-7" package="DO34Z7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD64-10" package="SOD64Z10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD64-12" package="SOD64Z12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO236" package="TO236">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="F126-10" package="F126Z10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="F126-12" package="F126Z12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ZD-10" package="ZDIO-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ZD-2.5" package="ZDIO-2.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ZD-5" package="ZDIO-5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ZD-7.5" package="ZDIO-7.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ZD-12.5" package="ZDIO12.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P1-Z12" package="P1Z12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P1-12" package="P1Z12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD80C" package="SOD80C">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOT23" package="SOT23">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOT223" package="SOT223">
<connects>
<connect gate="G$1" pin="C" pad="4"/>
</connects>
<technologies>
</technologies>
</device>
<device name="SMB" package="SMB">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIODE-" prefix="D" uservalue="yes">
<description>&lt;b&gt;DIODE&lt;/b&gt;</description>
<gates>
</gates>
<devices>
<device name="DO41-10" package="DO41-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DO204-10" package="DO204-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DO15-12" package="DO15-12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD57-10" package="SOD57-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DO201-15" package="DO201-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DO07" package="DO07">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P1-10" package="P1-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P2-15" package="P2-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DO34-7" package="DO34-7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOT54H" package="SOT54H">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD523" package="SOD523">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO18D" package="TO18D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1702-05" package="C1702-05">
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SGA-10" package="SGA-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD64-10" package="SOD64-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD61A" package="SOD61A">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD61B" package="SOD61B">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD61C" package="SOD61C">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD61D" package="SOD61D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD61E" package="SOD61E">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DO27-15" package="DO27-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD81" package="SOD81">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD84" package="SOD84">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="F126-10" package="F126-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DO220S" package="DO220S">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO220H" package="TO220AC">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO220V" package="TO220ACS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="G4-12" package="G4-12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD83-12" package="SOD83-12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P6-15" package="P6-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C2673" package="C2673">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C221B1A" package="C221B1A">
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="D-10" package="D-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="D-12.5" package="D-12.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="D-2.5" package="D-2.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="D-5" package="D-5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="D-7.5" package="D-7.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD106-R" package="SOD106-R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMC" package="SMC">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD106-W" package="SOD106-W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD106A-R" package="SOD106A-R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD110-W" package="SOD110-W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD110-R" package="SOD110-R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD123" package="SOD123">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD323-R" package="SOD323-R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD323-W" package="SOD323-W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="GF1" package="GF1">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MINIMELF" package="MINIMELF">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF-MLL41" package="MELF-MLL41">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MICROMELF-R" package="MICROMELF-R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MICROMELF-W" package="MICROMELF-W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SC79_INFINEON" package="SC79_INFINEON">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SCD80-INFINEON" package="SCD80_INFINEON">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DO214AA" package="DO214AA">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DO214AC" package="DO214AC">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DO214BA" package="DO214BA">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DO-214AC" package="DO-214AC">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DO41-7.6" package="DO41-7.6">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="SCHOTTKY-DIODE" prefix="D" uservalue="yes">
<description>Schottky Diode</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C4111-15" package="C4111-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P6T15" package="P6T15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CB429-17" package="CB429-17">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DO201T15" package="DO201T15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="F126Z12" package="F126Z12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="AG" package="AG">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO92H" package="TO92H">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CB417-15" package="CB417-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CB429-15" package="CB429-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMD" package="SMB">
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DO201V" package="DO201V">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIODE_SCHOTTKY2-" prefix="D" uservalue="yes">
<description>&lt;b&gt;Schottky Bidirectional Diode&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="SCHOTTKY-BIDIR" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="1" pad="A"/>
<connect gate="G$1" pin="2" pad="C"/>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P3-15" package="P3-15">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIODE_2CACA-" prefix="D" uservalue="yes">
<description>&lt;b&gt;2 Diodes - Cathode-Anode|Cathode-Anode&lt;/b&gt;</description>
<gates>
<gate name="-B1" symbol="KA2KA" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="-B1" pin="A" pad="1"/>
<connect gate="-B1" pin="AC" pad="3"/>
<connect gate="-B1" pin="C" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIAC-" prefix="D" uservalue="yes">
<description>&lt;b&gt;DIAC&lt;/b&gt;</description>
<gates>
<gate name="-B1" symbol="DIAC" x="0" y="0"/>
</gates>
<devices>
<device name="BR210S" package="BR210S">
<connects>
<connect gate="-B1" pin="1" pad="T1"/>
<connect gate="-B1" pin="2" pad="T2"/>
</connects>
<technologies>
</technologies>
</device>
<device name="GT32" package="GT32">
<connects>
<connect gate="-B1" pin="1" pad="1"/>
<connect gate="-B1" pin="2" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
<connects>
<connect gate="-B1" pin="1" pad="A"/>
<connect gate="-B1" pin="2" pad="C"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIODE-2CAPACITANCE" prefix="D" uservalue="yes">
<gates>
<gate name="-B1" symbol="KDD" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="-B1" pin="A1" pad="1"/>
<connect gate="-B1" pin="A2" pad="2"/>
<connect gate="-B1" pin="C" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
<device name="SOT54E" package="SOT54E">
<connects>
<connect gate="-B1" pin="A1" pad="A1"/>
<connect gate="-B1" pin="A2" pad="A2"/>
<connect gate="-B1" pin="C" pad="C"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIODE_CAPACITANCE-" prefix="D" uservalue="yes">
<description>Capacity &lt;b&gt;DIODE&lt;/b&gt;&lt;p&gt;</description>
<gates>
<gate name="-B1" symbol="KD" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="-B1" pin="A" pad="A"/>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIAC2-" prefix="D" uservalue="yes">
<description>&lt;B&gt;DIAC&lt;/B&gt;&lt;p&gt;
<gates>
<gate name="-B1" symbol="BR220" x="0" y="0"/>
</gates>
<devices>
<device name="BR220H" package="BR220S">
<connects>
<connect gate="-B1" pin="T1" pad="T1"/>
<connect gate="-B1" pin="T2" pad="T2"/>
<connect gate="-B1" pin="T3" pad="T3"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIODE-2AC|CA" prefix="D" uservalue="yes">
<description>Dual &lt;b&gt;DIODE&lt;/b&gt; Anode-Cathode|Cathode-Anode</description>
<gates>
<gate name="-B1" symbol="DD" x="0" y="0"/>
</gates>
<devices>
<device name="TO220V" package="TO220ABS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="IW220V" package="IW220ABS">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1103" package="C1103">
<connects>
<connect gate="-B1" pin="C" pad="C C@1" route="any"/>
</connects>
<technologies>
</technologies>
</device>
<device name="C1103/" package="C1103/">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO220H" package="TO220AB">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO3P" package="TO3P">
<connects>
<connect gate="-B1" pin="A2" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIODE_2SCHOTTKY-" prefix="D" uservalue="yes">
<description>Dual &lt;B&gt;SCHOTTKY DIODE&lt;/B&gt;&lt;p&gt;
<gates>
<gate name="-B1" symbol="SDD" x="0" y="0"/>
</gates>
<devices>
<device name="SOT82V" package="SOT82S">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOT82H" package="SOT82L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOT93H" package="SOT93L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOT93V" package="SOT93S">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIODE-2CA|AC" prefix="D" uservalue="yes">
<description>Dual &lt;b&gt;DIODE&lt;/b&gt; Cathode-Anode|Anode-Cathode</description>
<gates>
<gate name="G$1" symbol="K2A" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="A" pad="3"/>
<connect gate="G$1" pin="K1" pad="1"/>
<connect gate="G$1" pin="K2" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="SUPPRESSOR-" prefix="D" uservalue="yes">
<description>&lt;b&gt;Suppressor diode&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="SUPPRESSOR" x="0" y="0"/>
</gates>
<devices>
<device name="SMBG" package="SMBG">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMBJ" package="SMBJ">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MBRS130LT3" prefix="D">
<description>&lt;b&gt;Schottky Power Rectifier&lt;/b&gt;&lt;p&gt;
Source: http://www.onsemi.com/pub/Collateral/MBRS130LT3-D.PDF</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="PMLL41*" prefix="D">
<description>&lt;b&gt;High-speed diodes&lt;/b&gt;&lt;p&gt;
Source: http://www.semiconductors.philips.com/acrobat_download/datasheets/PMLL4150_2.pdf</description>
<gates>
</gates>
<devices>
<device name="" package="POWERMITE">
<connects>
<connect gate="G$1" pin="A" pad="2"/>
<connect gate="G$1" pin="C" pad="1"/>
</connects>
<technologies>
<technology name="50"/>
<technology name="51"/>
<technology name="53"/>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAS40" prefix="D">
<gates>
<gate name="1" symbol="SCHOTTKY-1" x="0" y="0"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAS40-04" prefix="D">
<gates>
<gate name="G$1" symbol="SDD_AKAK" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="C1A2" pad="3"/>
<connect gate="G$1" pin="C2" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAS40-05" prefix="D">
<gates>
<gate name="G$1" symbol="SDD-1" x="0" y="2.54"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAS40-06" prefix="D">
<gates>
<gate name="G$1" symbol="SDD_KAAK" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="AA" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAS70-04" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAS70-05" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAS70-06" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAS70-07" prefix="D">
General-purpose diode for high-speed switching&lt;br&gt;
Source: BAS70_1PS7XSB70_SER_8.pdf</description>
<gates>
<gate name="A" symbol="SCHOTTKY" x="0" y="5.08"/>
<gate name="B" symbol="SCHOTTKY" x="0" y="-5.08"/>
</gates>
<devices>
<device name="" package="SOT143-R">
<connects>
<connect gate="A" pin="A" pad="4"/>
<connect gate="B" pin="C" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
<device name="S" package="SOT363_PHILIPS">
<connects>
<connect gate="A" pin="C" pad="6"/>
</connects>
<technologies>
</technologies>
</device>
<device name="V" package="SOT666">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAS70VV" prefix="D">
<gates>
<gate name="A" symbol="SCHOTTKY" x="0" y="10.16"/>
<gate name="B" symbol="SCHOTTKY" x="0" y="0"/>
<gate name="C" symbol="SCHOTTKY" x="0" y="-10.16"/>
</gates>
<devices>
<device name="" package="SOT666">
<connects>
<connect gate="B" pin="A" pad="2"/>
<connect gate="B" pin="C" pad="5"/>
<connect gate="C" pin="A" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAS70XY" prefix="D">
<gates>
<gate name="A" symbol="SDD_AKAK" x="0" y="5.08"/>
<gate name="B" symbol="SDD_AKAK" x="0" y="-5.08"/>
</gates>
<devices>
<device name="" package="SOT363_PHILIPS">
<connects>
<connect gate="A" pin="A1" pad="1"/>
<connect gate="A" pin="C1A2" pad="6"/>
<connect gate="B" pin="A1" pad="4"/>
<connect gate="B" pin="C1A2" pad="3"/>
<connect gate="B" pin="C2" pad="5"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BY229B" prefix="D">
Fast Switching Rectifier, 8A (Vishay)</description>
<gates>
<gate name="G$1" symbol="DH" x="0" y="0"/>
</gates>
<devices>
<device name="" package="TO263AB">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
<connect gate="G$1" pin="K" pad="K"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="GF1" prefix="D">
<gates>
<gate name="D" symbol="D-1" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SMA-DO214AC">
<connects>
<connect gate="D" pin="C" pad="K"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="S6058" prefix="D">
<description>&lt;b&gt;Si PIN Quadrant photodiode&lt;/b&gt;&lt;p&gt;
Source: http://sales.hamamatsu.com/assets/pdf/parts_S/S7379-01_etc.pdf</description>
<gates>
<gate name="G$1" symbol="QUADRANT-PHOTODIODE-2C-4A" x="0" y="0"/>
</gates>
<devices>
<device name="" package="S6058">
<connects>
<connect gate="G$1" pin="AA" pad="2"/>
<connect gate="G$1" pin="AB" pad="3"/>
<connect gate="G$1" pin="AC" pad="6"/>
<connect gate="G$1" pin="AD" pad="7"/>
<connect gate="G$1" pin="C1" pad="4"/>
<connect gate="G$1" pin="C2" pad="8"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="S6695-01" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="S6695-01">
<connects>
<connect gate="G$1" pin="AA" pad="1"/>
<connect gate="G$1" pin="AC" pad="4"/>
<connect gate="G$1" pin="AD" pad="6"/>
<connect gate="G$1" pin="C1" pad="2"/>
<connect gate="G$1" pin="C2" pad="5"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="S7379-01" prefix="D">
<gates>
</gates>
<devices>
<device name="" package="S7379-01">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MBR0520LT" prefix="D">
<description>&lt;b&gt;SCHOTTKY BARRIER RECTIFIER&lt;/b&gt;&lt;p&gt;
Source: http://onsemi.com .. MBR0520LT1-D.pdf</description>
<gates>
</gates>
<devices>
<device name="" package="SOD123">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="CGRM400*-G" prefix="D">
<description>&lt;b&gt;Molded plasitc,JEDEC SOD-123/Mini SMA&lt;/b&gt;&lt;p&gt;
Source: Comchip CGRM4001-G.pdf</description>
<gates>
</gates>
<devices>
<device name="" package="SOD-123_MINI-SMA">
<connects>
</connects>
<technologies>
<technology name="1"/>
<technology name="2"/>
<technology name="3"/>
<technology name="4"/>
<technology name="5"/>
<technology name="6"/>
<technology name="7"/>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1N581*" prefix="D">
<description>&lt;b&gt;1.0A SCHOTTKY BARRIER RECTIFIER&lt;/b&gt;&lt;p&gt;
Source: http://www.diodes.com/datasheets/ds23001.pdf</description>
<gates>
</gates>
<devices>
<device name="" package="DO41-7.6">
<connects>
</connects>
<technologies>
<technology name="7-B"/>
<technology name="7-T"/>
<technology name="8-B"/>
<technology name="8-T"/>
<technology name="9-B"/>
<technology name="9-T"/>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAT54" prefix="D">
<description>&lt;b&gt;Schottky Diodes&lt;/b&gt;&lt;p&gt;
Source: Fairchild .. BAT54.pdf</description>
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAT54A" prefix="D">
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAT54C" prefix="D">
<gates>
<gate name="G$1" symbol="SDD_AKKA" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="G$1" pin="CC" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="BAT54S" prefix="D">
Pin connection corrected 2011-05-04&lt;br&gt;
<gates>
</gates>
<devices>
<connects>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MBRA340T3" prefix="D">
<description>&lt;b&gt;Surface Mount Schottky Power Rectifier&lt;/b&gt;&lt;p&gt;
Source: http://www.onsemi.com/pub_link/Collateral/MBRA340T3-D.PDF</description>
<gates>
<gate name="G$1" symbol="DIODE" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SMA">
<connects>
<connect gate="G$1" pin="A" pad="A"/>
<connect gate="G$1" pin="C" pad="C"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MBRS3*0T3" prefix="D">
<description>&lt;b&gt;SCHOTTKY BARRIER RECTIFIER 3.0 AMPERES 20, 30, 40 VOLT&lt;/b&gt;&lt;p&gt;
Source: MBRS340T3-D.pdf</description>
<gates>
</gates>
<devices>
<device name="" package="SMC">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="SMF5.0AT1" prefix="D">
<description>&lt;b&gt;200 W Transient Voltage Suppressor&lt;/b&gt;&lt;p&gt;
Source: &lt;a href="http://www.onsemi.com/pub_link/Collateral/SMF5.0AT1-D.PDF"&gt;Data sheet&lt;/b&gt;</description>
<gates>
</gates>
<devices>
<device name="" package="SOD123FL">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
