<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.5.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.05" unitdist="inch" unit="mil" style="lines" multiple="1" display="yes" altdistance="25" altunitdist="mil" altunit="mil"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="116" name="centerDrill" color="7" fill="1" visible="no" active="yes"/>
<layer number="200" name="200bmp" color="1" fill="10" visible="no" active="no"/>
</layers>
<board>
<plain>
<wire x1="0" y1="0" x2="74.91" y2="0" width="0.25" layer="20"/>
<wire x1="74.91" y1="0" x2="74.91" y2="80.95" width="0.25" layer="20"/>
<wire x1="74.91" y1="80.95" x2="0" y2="80.95" width="0.25" layer="20"/>
<wire x1="0" y1="80.95" x2="0" y2="0" width="0.25" layer="20"/>
<wire x1="44.45" y1="61.595" x2="36.83" y2="61.595" width="0.4064" layer="41"/>
<wire x1="36.83" y1="61.595" x2="34.29" y2="59.055" width="0.4064" layer="41"/>
<wire x1="34.29" y1="59.055" x2="34.29" y2="55.88" width="0.4064" layer="41"/>
<wire x1="36.195" y1="21.59" x2="36.195" y2="38.1" width="0.4064" layer="41"/>
<rectangle x1="33.02" y1="36.83" x2="38.1" y2="41.91" layer="41"/>
<wire x1="27.305" y1="12.7" x2="29.845" y2="12.7" width="0.508" layer="41"/>
<wire x1="55.245" y1="7.62" x2="53.975" y2="6.35" width="0.6096" layer="41"/>
<wire x1="53.975" y1="6.35" x2="48.895" y2="6.35" width="0.6096" layer="41"/>
<wire x1="48.895" y1="6.35" x2="47.625" y2="7.62" width="0.6096" layer="41"/>
<wire x1="47.625" y1="7.62" x2="47.625" y2="13.335" width="0.6096" layer="41"/>
<wire x1="47.625" y1="13.335" x2="46.99" y2="13.97" width="0.6096" layer="41"/>
<wire x1="46.99" y1="13.97" x2="45.72" y2="13.97" width="0.6096" layer="41"/>
<wire x1="45.72" y1="59.69" x2="36.83" y2="59.69" width="0.6096" layer="41"/>
<wire x1="36.83" y1="59.69" x2="35.56" y2="58.42" width="0.6096" layer="41"/>
<wire x1="35.56" y1="58.42" x2="35.56" y2="56.515" width="0.6096" layer="41"/>
<wire x1="20.32" y1="70.485" x2="33.02" y2="70.485" width="0" layer="41"/>
<circle x="55.245" y="7.62" radius="0.635" width="0.4064" layer="41"/>
<wire x1="64.135" y1="15.24" x2="64.135" y2="12.7" width="2.1844" layer="41"/>
<rectangle x1="50.165" y1="8.89" x2="51.435" y2="14.605" layer="41"/>
<circle x="68.58" y="25.4" radius="1.419903125" width="0.3048" layer="41"/>
<rectangle x1="45.085" y1="14.605" x2="46.355" y2="15.875" layer="41"/>
<circle x="36.195" y="21.59" radius="0.635" width="0.3048" layer="41"/>
<wire x1="33.02" y1="5.715" x2="33.02" y2="15.24" width="0" layer="41"/>
<rectangle x1="24.765" y1="27.305" x2="26.035" y2="28.575" layer="41"/>
<rectangle x1="54.61" y1="27.305" x2="59.055" y2="28.575" layer="41"/>
<rectangle x1="54.61" y1="24.765" x2="59.055" y2="26.035" layer="41"/>
<rectangle x1="50.165" y1="40.005" x2="51.435" y2="40.64" layer="41"/>
<rectangle x1="33.655" y1="41.91" x2="37.465" y2="43.18" layer="41"/>
<rectangle x1="45.72" y1="31.75" x2="46.355" y2="40.64" layer="41"/>
<rectangle x1="45.085" y1="59.055" x2="46.355" y2="59.69" layer="41"/>
<rectangle x1="33.02" y1="52.07" x2="36.83" y2="57.15" layer="41"/>
<rectangle x1="34.29" y1="50.8" x2="36.195" y2="52.07" layer="41"/>
<wire x1="33.02" y1="52.07" x2="38.1" y2="52.07" width="0.3048" layer="41"/>
<rectangle x1="45.085" y1="60.325" x2="46.355" y2="60.96" layer="41"/>
<wire x1="33.02" y1="70.485" x2="33.02" y2="53.34" width="0" layer="41"/>
<wire x1="30.48" y1="12.7" x2="29.21" y2="13.97" width="0.4064" layer="42"/>
<wire x1="29.21" y1="13.97" x2="29.21" y2="17.78" width="0.4064" layer="42"/>
<wire x1="29.21" y1="17.78" x2="33.02" y2="21.59" width="0.4064" layer="42"/>
<wire x1="33.02" y1="21.59" x2="36.195" y2="21.59" width="0.4064" layer="42"/>
<circle x="30.48" y="12.7" radius="0.635" width="0.4064" layer="42"/>
<circle x="36.195" y="21.59" radius="0.635" width="0.4064" layer="42"/>
<wire x1="30.48" y1="12.7" x2="39.37" y2="12.7" width="0.6096" layer="42"/>
<wire x1="39.37" y1="12.7" x2="45.72" y2="19.05" width="0.6096" layer="42"/>
<wire x1="45.72" y1="19.05" x2="45.72" y2="59.69" width="0.6096" layer="42"/>
<circle x="45.72" y="59.69" radius="0.635" width="0.6096" layer="42"/>
<wire x1="55.245" y1="7.62" x2="60.325" y2="13.97" width="0.6096" layer="42"/>
<wire x1="60.325" y1="13.97" x2="66.675" y2="13.97" width="0.6096" layer="42"/>
<wire x1="66.675" y1="13.97" x2="71.12" y2="19.05" width="0.6096" layer="42"/>
<circle x="68.58" y="25.4" radius="1.419903125" width="0.254" layer="42"/>
<wire x1="64.135" y1="15.24" x2="64.135" y2="12.7" width="2.1844" layer="42"/>
<rectangle x1="39.37" y1="69.215" x2="44.45" y2="70.485" layer="42"/>
<wire x1="71.12" y1="19.05" x2="71.12" y2="22.86" width="0.6096" layer="42"/>
<wire x1="71.12" y1="22.86" x2="68.58" y2="25.4" width="0.6096" layer="42"/>
<circle x="55.245" y="7.62" radius="0.635" width="0.6096" layer="42"/>
<rectangle x1="33.02" y1="13.97" x2="35.56" y2="14.605" layer="41"/>
<rectangle x1="20.32" y1="25.4" x2="21.59" y2="26.67" layer="41"/>
<text x="8.89" y="31.115" size="1.4224" layer="1" rot="SR270">PC3</text>
<circle x="68.58" y="33.02" radius="0.455" width="0.51" layer="116"/>
<circle x="68.58" y="25.4" radius="0.455" width="0.51" layer="116"/>
<circle x="64.21" y="13.97" radius="0.375" width="0.35" layer="116"/>
<circle x="67.31" y="18.77" radius="0.375" width="0.35" layer="116"/>
<circle x="70.31" y="13.97" radius="0.375" width="0.35" layer="116"/>
<circle x="39.37" y="68.58" radius="0.379" width="0.358" layer="116"/>
<circle x="39.37" y="71.12" radius="0.379" width="0.358" layer="116"/>
<circle x="41.91" y="68.58" radius="0.379" width="0.358" layer="116"/>
<circle x="41.91" y="71.12" radius="0.379" width="0.358" layer="116"/>
<circle x="44.45" y="68.58" radius="0.379" width="0.358" layer="116"/>
<circle x="44.45" y="71.12" radius="0.379" width="0.358" layer="116"/>
<circle x="5.08" y="71.12" radius="0.379" width="0.358" layer="116"/>
<circle x="12.7" y="71.12" radius="0.379" width="0.358" layer="116"/>
<circle x="5.08" y="58.42" radius="0.379" width="0.358" layer="116"/>
<circle x="12.7" y="58.42" radius="0.379" width="0.358" layer="116"/>
<circle x="5.08" y="63.5" radius="0.379" width="0.358" layer="116"/>
<circle x="12.7" y="63.5" radius="0.379" width="0.358" layer="116"/>
<circle x="5.08" y="53.34" radius="0.379" width="0.358" layer="116"/>
<circle x="12.7" y="53.34" radius="0.379" width="0.358" layer="116"/>
<circle x="57.15" y="77.89" radius="0.75" width="1.1" layer="116"/>
<circle x="57.15" y="2.89" radius="0.75" width="1.1" layer="116"/>
<circle x="26.15" y="77.89" radius="0.75" width="1.1" layer="116"/>
<circle x="26.15" y="2.89" radius="0.75" width="1.1" layer="116"/>
<circle x="57.15" y="72.39" radius="0.375" width="0.35" layer="116"/>
<circle x="57.15" y="69.85" radius="0.375" width="0.35" layer="116"/>
<circle x="57.15" y="67.31" radius="0.375" width="0.35" layer="116"/>
<circle x="57.15" y="64.77" radius="0.375" width="0.35" layer="116"/>
<circle x="57.15" y="62.23" radius="0.375" width="0.35" layer="116"/>
<circle x="57.15" y="59.69" radius="0.375" width="0.35" layer="116"/>
<circle x="57.15" y="57.15" radius="0.375" width="0.35" layer="116"/>
<circle x="57.15" y="54.61" radius="0.375" width="0.35" layer="116"/>
<circle x="57.15" y="52.07" radius="0.375" width="0.35" layer="116"/>
<circle x="57.15" y="49.53" radius="0.375" width="0.35" layer="116"/>
<circle x="57.15" y="46.99" radius="0.375" width="0.35" layer="116"/>
<circle x="57.15" y="44.45" radius="0.375" width="0.35" layer="116"/>
<circle x="57.15" y="41.91" radius="0.375" width="0.35" layer="116"/>
<circle x="57.15" y="39.37" radius="0.375" width="0.35" layer="116"/>
<circle x="57.15" y="36.83" radius="0.375" width="0.35" layer="116"/>
<circle x="57.15" y="34.29" radius="0.375" width="0.35" layer="116"/>
<circle x="11.43" y="8.89" radius="0.328" width="0.256" layer="116"/>
<circle x="13.97" y="8.89" radius="0.328" width="0.256" layer="116"/>
<circle x="68.58" y="69.85" radius="0.375" width="0.35" layer="116"/>
<circle x="63.5" y="67.31" radius="0.375" width="0.35" layer="116"/>
<circle x="68.58" y="64.77" radius="0.375" width="0.35" layer="116"/>
<circle x="68.58" y="58.42" radius="0.375" width="0.35" layer="116"/>
<circle x="63.5" y="55.88" radius="0.375" width="0.35" layer="116"/>
<circle x="68.58" y="53.34" radius="0.375" width="0.35" layer="116"/>
<circle x="14.961" y="23.571" radius="0.379" width="0.358" layer="116"/>
<circle x="14.961" y="17.069" radius="0.379" width="0.358" layer="116"/>
<circle x="10.439" y="23.571" radius="0.379" width="0.358" layer="116"/>
<circle x="10.439" y="17.069" radius="0.379" width="0.358" layer="116"/>
<circle x="6.35" y="48.26" radius="0.455" width="0.51" layer="116"/>
<circle x="6.35" y="41.91" radius="0.455" width="0.51" layer="116"/>
<circle x="6.35" y="35.56" radius="0.455" width="0.51" layer="116"/>
<circle x="3.81" y="3.81" radius="0.925" width="1.45" layer="116"/>
<circle x="71.12" y="3.81" radius="0.925" width="1.45" layer="116"/>
<circle x="71.12" y="77.47" radius="0.925" width="1.45" layer="116"/>
<circle x="3.81" y="77.47" radius="0.925" width="1.45" layer="116"/>
<circle x="6.35" y="29.21" radius="0.455" width="0.51" layer="116"/>
<circle x="45.72" y="59.69" radius="0.325" width="0.25" layer="116"/>
<circle x="52.07" y="34.29" radius="0.325" width="0.25" layer="116"/>
<circle x="36.195" y="21.59" radius="0.325" width="0.25" layer="116"/>
<circle x="55.245" y="7.62" radius="0.325" width="0.25" layer="116"/>
<circle x="30.48" y="12.7" radius="0.325" width="0.25" layer="116"/>
<circle x="22.86" y="11.43" radius="0.325" width="0.25" layer="116"/>
<circle x="27.94" y="41.91" radius="0.325" width="0.25" layer="116"/>
<circle x="26.67" y="43.18" radius="0.325" width="0.25" layer="116"/>
<circle x="25.4" y="44.45" radius="0.325" width="0.25" layer="116"/>
<circle x="38.1" y="35.56" radius="0.325" width="0.25" layer="116"/>
<circle x="10.16" y="48.26" radius="0.325" width="0.25" layer="116"/>
<circle x="39.37" y="33.655" radius="0.325" width="0.25" layer="116"/>
<circle x="10.16" y="41.91" radius="0.325" width="0.25" layer="116"/>
<circle x="38.1" y="31.75" radius="0.325" width="0.25" layer="116"/>
<circle x="10.16" y="35.56" radius="0.325" width="0.25" layer="116"/>
<circle x="38.735" y="23.495" radius="0.325" width="0.25" layer="116"/>
<circle x="25.4" y="11.43" radius="0.325" width="0.25" layer="116"/>
<circle x="52.07" y="64.77" radius="0.325" width="0.25" layer="116"/>
<circle x="49.53" y="45.72" radius="0.325" width="0.25" layer="116"/>
<circle x="50.8" y="43.18" radius="0.325" width="0.25" layer="116"/>
<circle x="52.07" y="40.64" radius="0.325" width="0.25" layer="116"/>
<circle x="48.26" y="48.26" radius="0.325" width="0.25" layer="116"/>
<circle x="52.07" y="59.69" radius="0.325" width="0.25" layer="116"/>
<circle x="48.26" y="63.5" radius="0.325" width="0.25" layer="116"/>
<circle x="63.5" y="20.955" radius="0.325" width="0.25" layer="116"/>
<circle x="61.595" y="11.43" radius="0.325" width="0.25" layer="116"/>
<circle x="53.34" y="8.89" radius="0.325" width="0.25" layer="116"/>
<circle x="17.145" y="13.335" radius="0.325" width="0.25" layer="116"/>
<circle x="17.78" y="55.88" radius="0.325" width="0.25" layer="116"/>
<circle x="29.21" y="27.94" radius="0.325" width="0.25" layer="116"/>
<circle x="26.67" y="25.4" radius="0.325" width="0.25" layer="116"/>
<circle x="19.05" y="54.61" radius="0.325" width="0.25" layer="116"/>
<circle x="39.37" y="29.845" radius="0.325" width="0.25" layer="116"/>
<circle x="62.23" y="23.495" radius="0.325" width="0.25" layer="116"/>
<circle x="17.78" y="59.69" radius="0.325" width="0.25" layer="116"/>
<circle x="44.45" y="61.595" radius="0.325" width="0.25" layer="116"/>
<circle x="30.48" y="16.51" radius="0.325" width="0.25" layer="116"/>
</plain>
<libraries>
<library name="avr-7">
<packages>
<package name="AVR-ISP-6">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;&lt;p&gt; JTAG 6 Pin, 0.1" Straight</description>
<wire x1="-3.81" y1="2.54" x2="3.81" y2="2.54" width="0.254" layer="21"/>
<wire x1="3.81" y1="2.54" x2="3.81" y2="-2.54" width="0.254" layer="21"/>
<wire x1="3.81" y1="-2.54" x2="-3.81" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-3.81" y1="-2.54" x2="-3.81" y2="2.54" width="0.254" layer="21"/>
<pad name="1" x="-2.54" y="-1.27" drill="1.016" shape="square"/>
<pad name="2" x="-2.54" y="1.27" drill="1.016" shape="octagon"/>
<pad name="3" x="0" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="4" x="0" y="1.27" drill="1.016" shape="octagon"/>
<pad name="5" x="2.54" y="-1.27" drill="1.016" shape="octagon"/>
<pad name="6" x="2.54" y="1.27" drill="1.016" shape="octagon"/>
<text x="-3.81" y="-4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="3.175" size="1.27" layer="27" ratio="12">&gt;VALUE</text>
<rectangle x1="-2.794" y1="-1.524" x2="-2.286" y2="-1.016" layer="51"/>
<rectangle x1="-2.794" y1="1.016" x2="-2.286" y2="1.524" layer="51"/>
<rectangle x1="-0.254" y1="1.016" x2="0.254" y2="1.524" layer="51"/>
<rectangle x1="-0.254" y1="-1.524" x2="0.254" y2="-1.016" layer="51"/>
<rectangle x1="2.286" y1="1.016" x2="2.794" y2="1.524" layer="51"/>
<rectangle x1="2.286" y1="-1.524" x2="2.794" y2="-1.016" layer="51"/>
</package>
</packages>
</library>
<library name="solpad">
<packages>
<package name="SE13">
<description>&lt;b&gt;SOLDER PAD&lt;/b&gt;&lt;p&gt;
drill 1.3 mm</description>
<wire x1="-1.397" y1="0.508" x2="-1.397" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-1.397" x2="1.397" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.508" y1="1.397" x2="1.397" y2="0.508" width="0.1524" layer="21"/>
<wire x1="1.397" y1="0.508" x2="1.397" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="0.508" x2="-0.508" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.397" x2="0.508" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="-1.397" x2="-1.397" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-1.397" x2="-0.508" y2="-1.397" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="0.762" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="0.381" width="0.254" layer="51"/>
<pad name="MP" x="0" y="0" drill="1.3208" diameter="2.159" shape="octagon"/>
<text x="-1.27" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0" y="0.381" size="0.0254" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="gabor-lib">
<packages>
<package name="D1206">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
MELF 0.25 W</description>
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="1.143" y1="0.8382" x2="-1.143" y2="0.8382" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.8382" x2="-1.143" y2="-0.8382" width="0.1524" layer="51"/>
<wire x1="0.5" y1="0.5" x2="-0.5" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.5" y1="0" x2="0.5" y2="-0.5" width="0.2032" layer="21"/>
<wire x1="0.5" y1="-0.5" x2="0.5" y2="0.5" width="0.2032" layer="21"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-0.9144" x2="-1.1176" y2="0.9144" layer="51"/>
<rectangle x1="1.1176" y1="-0.9144" x2="1.7018" y2="0.9144" layer="51"/>
<rectangle x1="-0.3" y1="-0.8001" x2="0.3" y2="0.8001" layer="35"/>
<rectangle x1="-0.6096" y1="-0.7874" x2="-0.254" y2="0.7874" layer="21"/>
</package>
<package name="SO08">
<description>&lt;b&gt;Small Outline Package 8&lt;/b&gt;&lt;br&gt;
NS Package M08A</description>
<wire x1="2.4" y1="1.9" x2="2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.9" x2="-2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.9" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.4" x2="-2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="1.9" x2="2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<circle x="-1.778" y="-0.762" radius="0.254" width="0.127" layer="51"/>
<smd name="2" x="-0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="7" x="-0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="1" x="-1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="3" x="0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="4" x="1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="8" x="-1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="6" x="0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="5" x="1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<text x="-2.667" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.937" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.15" y1="-3.1" x2="-1.66" y2="-2" layer="51"/>
<rectangle x1="-0.88" y1="-3.1" x2="-0.39" y2="-2" layer="51"/>
<rectangle x1="0.39" y1="-3.1" x2="0.88" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="-3.1" x2="2.15" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="2" x2="2.15" y2="3.1" layer="51"/>
<rectangle x1="0.39" y1="2" x2="0.88" y2="3.1" layer="51"/>
<rectangle x1="-0.88" y1="2" x2="-0.39" y2="3.1" layer="51"/>
<rectangle x1="-2.15" y1="2" x2="-1.66" y2="3.1" layer="51"/>
</package>
</packages>
</library>
<library name="rcl">
<packages>
<package name="MINI_MELF-0204W">
<description>&lt;b&gt;CECC Size RC3715&lt;/b&gt; Wave Soldering&lt;p&gt;
source Beyschlag</description>
<wire x1="-1.7" y1="-0.6" x2="1.7" y2="-0.6" width="0.2032" layer="51"/>
<wire x1="1.7" y1="-0.6" x2="1.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="1.7" y1="0.6" x2="-1.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-1.7" y1="0.6" x2="-1.7" y2="-0.6" width="0.2032" layer="51"/>
<wire x1="0.684" y1="0.6" x2="-0.684" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-0.684" y1="-0.6" x2="0.684" y2="-0.6" width="0.2032" layer="21"/>
<smd name="1" x="-1.5" y="0" dx="1.2" dy="1.6" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.2" dy="1.6" layer="1"/>
<text x="-1.27" y="0.9525" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.2225" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R1206">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;</description>
<wire x1="0.9525" y1="-0.8128" x2="-0.9652" y2="-0.8128" width="0.1524" layer="51"/>
<wire x1="0.9525" y1="0.8128" x2="-0.9652" y2="0.8128" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="2" x="1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<smd name="1" x="-1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<rectangle x1="-1.6891" y1="-0.8763" x2="-0.9525" y2="0.8763" layer="51"/>
<rectangle x1="0.9525" y1="-0.8763" x2="1.6891" y2="0.8763" layer="51"/>
<rectangle x1="-0.3" y1="-0.7" x2="0.3" y2="0.7" layer="35"/>
</package>
<package name="153CLV-0505">
<description>&lt;b&gt;Aluminum electrolytic capacitors&lt;/b&gt;&lt;p&gt;
SMD (Chip) Long Life Vertical 153 CLV&lt;p&gt;
http://www.bccomponents.com/</description>
<wire x1="1.75" y1="-2.65" x2="-2.65" y2="-2.65" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="-2.65" x2="-2.65" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="-1.1" x2="-2.65" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-2.65" y1="1.1" x2="-2.65" y2="2.65" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="2.65" x2="1.75" y2="2.65" width="0.2032" layer="21"/>
<wire x1="2.65" y1="1.75" x2="2.65" y2="1.1" width="0.2032" layer="21"/>
<wire x1="2.65" y1="1.1" x2="2.65" y2="-1.1" width="0.2032" layer="51"/>
<wire x1="2.65" y1="-1.1" x2="2.65" y2="-1.75" width="0.2032" layer="21"/>
<wire x1="2.65" y1="-1.75" x2="1.75" y2="-2.65" width="0.2032" layer="21"/>
<wire x1="1.75" y1="2.65" x2="2.65" y2="1.75" width="0.2032" layer="21"/>
<wire x1="-2.2" y1="-0.95" x2="2.2" y2="-0.95" width="0.2032" layer="21" curve="133.28887"/>
<wire x1="-2.2" y1="-0.95" x2="-2.2" y2="0.95" width="0.2032" layer="51" curve="-46.71113"/>
<wire x1="-2.2" y1="0.95" x2="2.2" y2="0.95" width="0.2032" layer="21" curve="-133.28887"/>
<wire x1="2.2" y1="-0.95" x2="2.2" y2="0.95" width="0.2032" layer="51" curve="46.71113"/>
<smd name="+" x="2.2" y="0" dx="3" dy="1.6" layer="1"/>
<smd name="-" x="-2.2" y="0" dx="3" dy="1.6" layer="1"/>
<text x="-2.74" y="2.98" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.775" y="-4.235" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R0805">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="-0.41" y1="0.635" x2="0.41" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.41" y1="-0.635" x2="0.41" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<text x="-0.635" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="0.4064" y1="-0.6985" x2="1.0564" y2="0.7015" layer="51"/>
<rectangle x1="-1.0668" y1="-0.6985" x2="-0.4168" y2="0.7015" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
</packages>
</library>
<library name="lcd_2x16_led_backlight">
<packages>
<package name="HY-1602F">
<wire x1="-5.46" y1="2.5" x2="74.54" y2="2.5" width="0.127" layer="21"/>
<wire x1="74.54" y1="2.5" x2="74.54" y2="-33.5" width="0.127" layer="21"/>
<wire x1="74.54" y1="-33.5" x2="-5.46" y2="-33.5" width="0.127" layer="27"/>
<wire x1="-5.46" y1="-33.5" x2="-5.46" y2="2.5" width="0.127" layer="21"/>
<wire x1="-0.46" y1="-3" x2="69.54" y2="-3" width="0.127" layer="21"/>
<wire x1="69.54" y1="-3" x2="69.54" y2="-28" width="0.127" layer="21"/>
<wire x1="-0.46" y1="-3" x2="-0.46" y2="-28" width="0.127" layer="21"/>
<wire x1="-0.46" y1="-28" x2="69.54" y2="-28" width="0.127" layer="21"/>
<circle x="-2.96" y="0" radius="3.5693" width="0.127" layer="49"/>
<circle x="72.04" y="0" radius="3.5735" width="0.127" layer="49"/>
<circle x="72.04" y="-31" radius="3.5735" width="0.127" layer="49"/>
<circle x="-2.96" y="-31" radius="3.5693" width="0.127" layer="49"/>
<pad name="1" x="2.54" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="2" x="5.08" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="3" x="7.62" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="4" x="10.16" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="5" x="12.7" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="6" x="15.24" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="7" x="17.78" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="8" x="20.32" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="9" x="22.86" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="10" x="25.4" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="11" x="27.94" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="12" x="30.48" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="13" x="33.02" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="14" x="35.56" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="15" x="38.1" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<pad name="16" x="40.64" y="0" drill="1" diameter="1.9304" shape="long" rot="R90"/>
<text x="-5.46" y="2.8" size="1.27" layer="25">&gt;NAME</text>
<hole x="-2.96" y="0" drill="2.5"/>
<hole x="72.04" y="0" drill="2.5"/>
<hole x="-2.96" y="-31" drill="2.5"/>
<hole x="72.04" y="-31" drill="2.5"/>
</package>
</packages>
</library>
<library name="resistor">
<packages>
<package name="C1206">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
chip</description>
<wire x1="-0.965" y1="0.787" x2="0.965" y2="0.787" width="0.1016" layer="51"/>
<wire x1="-0.965" y1="-0.787" x2="0.965" y2="-0.787" width="0.1016" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<text x="-1.27" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-0.8509" x2="-0.9517" y2="0.8491" layer="51"/>
<rectangle x1="0.9517" y1="-0.8491" x2="1.7018" y2="0.8509" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="C0805">
chip</description>
<wire x1="-0.381" y1="0.66" x2="0.381" y2="0.66" width="0.1016" layer="51"/>
<wire x1="-0.356" y1="-0.66" x2="0.381" y2="-0.66" width="0.1016" layer="51"/>
<smd name="1" x="-0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<text x="-0.889" y="1.016" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.889" y="-2.286" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.0922" y1="-0.7239" x2="-0.3421" y2="0.7262" layer="51"/>
<rectangle x1="0.3556" y1="-0.7239" x2="1.1057" y2="0.7262" layer="51"/>
<rectangle x1="-0.1001" y1="-0.4001" x2="0.1001" y2="0.4001" layer="35"/>
</package>
<package name="C025-024X044">
grid 2.5 mm, outline 2.4 x 4.4 mm</description>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-1.651" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.159" y1="-0.635" x2="-1.651" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="1.651" y1="1.143" x2="-1.651" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-1.143" x2="-1.651" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="1.651" y1="1.143" x2="2.159" y2="0.635" width="0.1524" layer="21" curve="-90"/>
<wire x1="1.651" y1="-1.143" x2="2.159" y2="-0.635" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.3048" y1="0.762" x2="-0.3048" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0.762" x2="0.3302" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="1.27" y1="0" x2="0.3302" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0" x2="-0.3048" y2="0" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-1.778" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.778" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0204V">
type 0204, grid 2.5 mm</description>
<wire x1="-1.27" y1="0" x2="1.27" y2="0" width="0.508" layer="51"/>
<wire x1="-0.127" y1="0" x2="0.127" y2="0" width="0.508" layer="21"/>
<circle x="-1.27" y="0" radius="0.889" width="0.1524" layer="51"/>
<circle x="-1.27" y="0" radius="0.635" width="0.0508" layer="51"/>
<text x="-2.1336" y="1.1684" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="crystal">
<packages>
<package name="HC49UP">
<description>&lt;b&gt;CRYSTAL&lt;/b&gt;</description>
<wire x1="-5.1091" y1="1.143" x2="-3.429" y2="2.0321" width="0.0508" layer="21" curve="-55.770993"/>
<wire x1="-5.715" y1="1.143" x2="-5.715" y2="2.159" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.032" x2="5.1091" y2="1.143" width="0.0508" layer="21" curve="-55.772485"/>
<wire x1="5.715" y1="1.143" x2="5.715" y2="2.159" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-1.27" x2="-3.429" y2="-1.27" width="0.0508" layer="21"/>
<wire x1="3.429" y1="-2.032" x2="-3.429" y2="-2.032" width="0.0508" layer="21"/>
<wire x1="-3.429" y1="1.27" x2="3.429" y2="1.27" width="0.0508" layer="21"/>
<wire x1="5.461" y1="-2.413" x2="-5.461" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-0.381" x2="6.477" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="5.715" y1="0.381" x2="6.477" y2="0.381" width="0.1524" layer="51"/>
<wire x1="6.477" y1="-0.381" x2="6.477" y2="0.381" width="0.1524" layer="51"/>
<wire x1="5.461" y1="-2.413" x2="5.715" y2="-2.159" width="0.1524" layer="21" curve="90"/>
<wire x1="5.715" y1="-1.143" x2="5.715" y2="1.143" width="0.1524" layer="51"/>
<wire x1="5.715" y1="-2.159" x2="5.715" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-1.27" x2="3.9826" y2="-1.143" width="0.0508" layer="21" curve="25.842828"/>
<wire x1="3.429" y1="1.27" x2="3.9826" y2="1.143" width="0.0508" layer="21" curve="-25.842828"/>
<wire x1="3.429" y1="-2.032" x2="5.109" y2="-1.1429" width="0.0508" layer="21" curve="55.771157"/>
<wire x1="3.9826" y1="-1.143" x2="3.9826" y2="1.143" width="0.0508" layer="51" curve="128.314524"/>
<wire x1="5.1091" y1="-1.143" x2="5.1091" y2="1.143" width="0.0508" layer="51" curve="68.456213"/>
<wire x1="-5.1091" y1="-1.143" x2="-3.429" y2="-2.032" width="0.0508" layer="21" curve="55.772485"/>
<wire x1="-3.9826" y1="-1.143" x2="-3.9826" y2="1.143" width="0.0508" layer="51" curve="-128.314524"/>
<wire x1="-3.9826" y1="-1.143" x2="-3.429" y2="-1.27" width="0.0508" layer="21" curve="25.842828"/>
<wire x1="-3.9826" y1="1.143" x2="-3.429" y2="1.27" width="0.0508" layer="21" curve="-25.842828"/>
<wire x1="-6.477" y1="-0.381" x2="-6.477" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-5.1091" y1="-1.143" x2="-5.1091" y2="1.143" width="0.0508" layer="51" curve="-68.456213"/>
<wire x1="-5.715" y1="-1.143" x2="-5.715" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="-0.381" x2="-5.715" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="0.381" x2="-5.715" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="-2.159" x2="-5.715" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.159" x2="-5.461" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.715" y1="-0.381" x2="-6.477" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="0.381" x2="-6.477" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="2.032" x2="3.429" y2="2.032" width="0.0508" layer="21"/>
<wire x1="5.461" y1="2.413" x2="-5.461" y2="2.413" width="0.1524" layer="21"/>
<wire x1="5.461" y1="2.413" x2="5.715" y2="2.159" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.715" y1="2.159" x2="-5.461" y2="2.413" width="0.1524" layer="21" curve="-90"/>
<wire x1="-0.254" y1="0.635" x2="-0.254" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-0.635" x2="0.254" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-0.635" x2="0.254" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0.635" x2="-0.254" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0.635" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-1.016" y2="0" width="0.0508" layer="21"/>
<wire x1="0.635" y1="0.635" x2="0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="0.635" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.016" y2="0" width="0.0508" layer="21"/>
<smd name="1" x="-4.826" y="0" dx="5.334" dy="1.9304" layer="1"/>
<smd name="2" x="4.826" y="0" dx="5.334" dy="1.9304" layer="1"/>
<text x="-5.715" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.715" y="-4.191" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-6.604" y1="-3.048" x2="6.604" y2="3.048" layer="43"/>
</package>
</packages>
</library>
<library name="diode">
<packages>
<package name="DO41-7.6">
<description>&lt;b&gt;DO41&lt;/b&gt; 7.6mm x 2mm&lt;p&gt;
Source: http://www.diodes.com/datasheets/ds23001.pdf</description>
<wire x1="2.082" y1="-0.92" x2="-2.082" y2="-0.92" width="0.1524" layer="21"/>
<wire x1="2.082" y1="-0.92" x2="2.082" y2="0.92" width="0.1524" layer="21"/>
<wire x1="-2.082" y1="0.92" x2="2.082" y2="0.92" width="0.1524" layer="21"/>
<wire x1="-2.082" y1="0.92" x2="-2.082" y2="-0.92" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0" x2="2.494" y2="0" width="0.85" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.519" y2="0" width="0.85" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="1.1" diameter="1.7"/>
<pad name="A" x="3.81" y="0" drill="1.1" diameter="1.7"/>
<text x="-2.032" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-0.95" x2="-1.143" y2="0.92" layer="21"/>
<rectangle x1="2.082" y1="-0.425" x2="2.717" y2="0.425" layer="21"/>
<rectangle x1="-2.717" y1="-0.425" x2="-2.082" y2="0.425" layer="21"/>
</package>
<package name="DO35-7">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2 mm, horizontal, grid 7.62 mm</description>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="2.032" y1="1.016" x2="2.286" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="0.762" x2="2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.016" x2="2.286" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.286" y1="0.762" x2="-2.032" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="-0.762" x2="-2.032" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.032" y1="-1.016" x2="2.032" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0.762" x2="-2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.016" x2="2.032" y2="1.016" width="0.1524" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="3.81" y="0" drill="0.8128" shape="long"/>
<text x="-2.286" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.905" y1="-1.016" x2="-1.397" y2="1.016" layer="21"/>
<rectangle x1="2.286" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
</package>
<package name="DO35Z10">
diameter 2 mm, horizontal, grid 10.16mm</description>
<wire x1="5.08" y1="0" x2="4.191" y2="0" width="0.508" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.191" y2="0" width="0.508" layer="51"/>
<wire x1="0.254" y1="0.635" x2="0" y2="0.635" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="5.08" y="0" drill="0.8128" shape="long"/>
<text x="-2.286" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.286" y1="-0.254" x2="4.191" y2="0.254" layer="21"/>
<rectangle x1="-4.191" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
</package>
<package name="DO41-10">
diameter 2.54 mm, horizontal, grid 10.16 mm</description>
<wire x1="2.032" y1="-1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.762" layer="51"/>
<pad name="A" x="5.08" y="0" drill="1.1176"/>
<pad name="C" x="-5.08" y="0" drill="1.1176"/>
<text x="-2.032" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.27" x2="-1.143" y2="1.27" layer="21"/>
<rectangle x1="2.032" y1="-0.381" x2="3.937" y2="0.381" layer="21"/>
<rectangle x1="-3.937" y1="-0.381" x2="-2.032" y2="0.381" layer="21"/>
</package>
</packages>
</library>
<library name="transistor-pnp">
<packages>
<package name="SOT23-BEC">
<description>&lt;b&gt;TO-236&lt;/b&gt; ITT Intermetall</description>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.127" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.127" layer="51"/>
<smd name="C" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="E" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="B" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2286" y1="0.7112" x2="0.2286" y2="1.2954" layer="51"/>
<rectangle x1="0.7112" y1="-1.2954" x2="1.1684" y2="-0.7112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.2954" x2="-0.7112" y2="-0.7112" layer="51"/>
</package>
</packages>
</library>
<library name="con-jack">
<packages>
<package name="DCJ0202">
<description>&lt;b&gt;DC POWER JACK&lt;/b&gt;&lt;p&gt;
Source: DCJ0202.pdf</description>
<wire x1="1.65" y1="2.6" x2="-1.65" y2="2.6" width="0" layer="46"/>
<wire x1="-1.65" y1="2.6" x2="-1.65" y2="3.6" width="0" layer="46"/>
<wire x1="-1.65" y1="3.6" x2="1.65" y2="3.6" width="0" layer="46"/>
<wire x1="1.65" y1="3.6" x2="1.65" y2="2.6" width="0" layer="46"/>
<wire x1="5.3" y1="1.4" x2="4.3" y2="1.4" width="0" layer="46"/>
<wire x1="4.3" y1="1.4" x2="4.3" y2="-1.4" width="0" layer="46"/>
<wire x1="4.3" y1="-1.4" x2="5.3" y2="-1.4" width="0" layer="46"/>
<wire x1="5.3" y1="-1.4" x2="5.3" y2="1.4" width="0" layer="46"/>
<wire x1="1.4" y1="-3.5" x2="-1.4" y2="-3.5" width="0" layer="46"/>
<wire x1="-1.4" y1="-3.5" x2="-1.4" y2="-2.5" width="0" layer="46"/>
<wire x1="-1.4" y1="-2.5" x2="1.4" y2="-2.5" width="0" layer="46"/>
<wire x1="1.4" y1="-2.5" x2="1.4" y2="-3.5" width="0" layer="46"/>
<wire x1="-4.3" y1="-10.4" x2="4.3" y2="-10.4" width="0.2032" layer="21"/>
<wire x1="4.3" y1="-10.4" x2="4.3" y2="3.9" width="0.2032" layer="51"/>
<wire x1="4.3" y1="3.9" x2="-4.3" y2="3.9" width="0.2032" layer="51"/>
<wire x1="-4.3" y1="3.9" x2="-4.3" y2="-10.4" width="0.2032" layer="21"/>
<wire x1="-2.7" y1="3.9" x2="-4.3" y2="3.9" width="0.2032" layer="21"/>
<wire x1="4.3" y1="3.9" x2="2.7" y2="3.9" width="0.2032" layer="21"/>
<wire x1="-3" y1="-10.275" x2="-3" y2="-3" width="0.2032" layer="51" style="shortdash"/>
<wire x1="3" y1="-10.3" x2="3" y2="-3" width="0.2032" layer="51" style="shortdash"/>
<wire x1="3" y1="-3" x2="-3" y2="-3" width="0.2032" layer="51" style="shortdash"/>
<wire x1="-0.9" y1="-9" x2="-0.9" y2="-4.5" width="0.2032" layer="51" style="shortdash"/>
<wire x1="0.9" y1="-9" x2="0.9" y2="-4.5" width="0.2032" layer="51" style="shortdash"/>
<wire x1="-0.9" y1="-9" x2="0.9" y2="-9" width="0.2032" layer="51" curve="166.57811"/>
<wire x1="4.3" y1="-10.4" x2="4.3" y2="-2.45" width="0.2032" layer="21"/>
<wire x1="4.3" y1="2.3" x2="4.3" y2="3.9" width="0.2032" layer="21"/>
<pad name="1" x="0" y="3.1" drill="1" diameter="2" shape="long" rot="R180"/>
<pad name="3" x="0" y="-3" drill="1" diameter="2" shape="long" rot="R180"/>
<pad name="2" x="4.8" y="0" drill="1" diameter="2" shape="long" rot="R90"/>
<text x="-3.81" y="5.08" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.08" y="-10.16" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="led">
<packages>
<package name="LED5MM">
<description>&lt;B&gt;LED&lt;/B&gt;&lt;p&gt;
5 mm, round</description>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="1.905" width="0.2032" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="1.905" width="0.254" layer="21" curve="-286.260205"/>
<wire x1="-1.143" y1="0" x2="0" y2="1.143" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-1.143" x2="1.143" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="-1.651" y1="0" x2="0" y2="1.651" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-1.651" x2="1.651" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="-2.159" y1="0" x2="0" y2="2.159" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-2.159" x2="2.159" y2="0" width="0.1524" layer="51" curve="90"/>
<circle x="0" y="0" radius="2.54" width="0.1524" layer="21"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="K" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="3.175" y="0.5334" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.2004" y="-1.8034" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="switch-omron">
<packages>
<package name="B3F-10XX">
<description>&lt;b&gt;OMRON SWITCH&lt;/b&gt;</description>
<wire x1="3.302" y1="-0.762" x2="3.048" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-0.762" x2="3.302" y2="0.762" width="0.1524" layer="21"/>
<wire x1="3.048" y1="0.762" x2="3.302" y2="0.762" width="0.1524" layer="21"/>
<wire x1="3.048" y1="1.016" x2="3.048" y2="2.54" width="0.1524" layer="51"/>
<wire x1="-3.302" y1="0.762" x2="-3.048" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.762" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-0.762" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.048" y1="2.54" x2="2.54" y2="3.048" width="0.1524" layer="51"/>
<wire x1="2.54" y1="-3.048" x2="3.048" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="3.048" y1="-2.54" x2="3.048" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="3.048" x2="-3.048" y2="2.54" width="0.1524" layer="51"/>
<wire x1="-3.048" y1="2.54" x2="-3.048" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-3.048" x2="-3.048" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="-3.048" y1="-2.54" x2="-3.048" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="-1.27" width="0.0508" layer="51"/>
<wire x1="1.27" y1="-1.27" x2="-1.27" y2="-1.27" width="0.0508" layer="51"/>
<wire x1="1.27" y1="-1.27" x2="1.27" y2="1.27" width="0.0508" layer="51"/>
<wire x1="-1.27" y1="1.27" x2="1.27" y2="1.27" width="0.0508" layer="51"/>
<wire x1="-1.27" y1="3.048" x2="-1.27" y2="2.794" width="0.0508" layer="21"/>
<wire x1="1.27" y1="2.794" x2="-1.27" y2="2.794" width="0.0508" layer="21"/>
<wire x1="1.27" y1="2.794" x2="1.27" y2="3.048" width="0.0508" layer="21"/>
<wire x1="1.143" y1="-2.794" x2="-1.27" y2="-2.794" width="0.0508" layer="21"/>
<wire x1="1.143" y1="-2.794" x2="1.143" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="-1.27" y1="-2.794" x2="-1.27" y2="-3.048" width="0.0508" layer="21"/>
<wire x1="2.54" y1="-3.048" x2="2.159" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-3.048" x2="-2.159" y2="-3.048" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="-3.048" x2="-1.27" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="3.048" x2="-2.159" y2="3.048" width="0.1524" layer="51"/>
<wire x1="2.54" y1="3.048" x2="2.159" y2="3.048" width="0.1524" layer="51"/>
<wire x1="2.159" y1="3.048" x2="1.27" y2="3.048" width="0.1524" layer="21"/>
<wire x1="1.27" y1="3.048" x2="-1.27" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="3.048" x2="-2.159" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-3.048" x2="1.143" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-3.048" x2="2.159" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-0.762" x2="3.048" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="3.048" y1="0.762" x2="3.048" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-0.762" x2="-3.048" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="0.762" x2="-3.048" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-2.159" x2="1.27" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="1.27" y1="2.286" x2="-1.27" y2="2.286" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="1.27" x2="-2.413" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="-0.508" x2="-2.413" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-2.413" y1="0.508" x2="-2.159" y2="-0.381" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="1.778" width="0.1524" layer="21"/>
<circle x="-2.159" y="-2.159" radius="0.508" width="0.1524" layer="51"/>
<circle x="2.159" y="-2.032" radius="0.508" width="0.1524" layer="51"/>
<circle x="2.159" y="2.159" radius="0.508" width="0.1524" layer="51"/>
<circle x="-2.159" y="2.159" radius="0.508" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="0.635" width="0.0508" layer="51"/>
<circle x="0" y="0" radius="0.254" width="0.1524" layer="21"/>
<pad name="1" x="-3.2512" y="2.2606" drill="1.016" shape="long"/>
<pad name="3" x="-3.2512" y="-2.2606" drill="1.016" shape="long"/>
<pad name="2" x="3.2512" y="2.2606" drill="1.016" shape="long"/>
<pad name="4" x="3.2512" y="-2.2606" drill="1.016" shape="long"/>
<text x="-3.048" y="3.683" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.048" y="-5.08" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.318" y="1.651" size="1.27" layer="51" ratio="10">1</text>
<text x="3.556" y="1.524" size="1.27" layer="51" ratio="10">2</text>
<text x="-4.572" y="-2.794" size="1.27" layer="51" ratio="10">3</text>
<text x="3.556" y="-2.794" size="1.27" layer="51" ratio="10">4</text>
</package>
</packages>
</library>
<library name="transistor-npn">
<packages>
<package name="SOT23">
<description>&lt;b&gt;SOT-23&lt;/b&gt;</description>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.1524" layer="51"/>
<smd name="3" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="2" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="1" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
</package>
<package name="TO92-EBC">
<description>&lt;b&gt;TO-92&lt;/b&gt;&lt;p&gt;
 grid 5.08 mm</description>
<wire x1="-2.095" y1="-2.921" x2="2.095" y2="-2.921" width="0.127" layer="21"/>
<wire x1="-2.413" y1="-0.1341" x2="2.413" y2="-0.1341" width="0.127" layer="21" curve="-129.583"/>
<wire x1="1.136" y1="-1.397" x2="-1.136" y2="-1.397" width="0.127" layer="51"/>
<wire x1="-2.413" y1="-0.1341" x2="-2.664" y2="-1.397" width="0.127" layer="51" curve="27.9376"/>
<wire x1="-2.664" y1="-1.397" x2="-2.413" y2="-2.4059" width="0.127" layer="51" curve="22.4788"/>
<wire x1="-1.404" y1="-1.397" x2="-2.664" y2="-1.397" width="0.127" layer="51"/>
<wire x1="-2.4135" y1="-2.4059" x2="-2.095" y2="-2.921" width="0.127" layer="21" curve="13.0385"/>
<wire x1="-1.136" y1="-1.397" x2="-1.404" y2="-1.397" width="0.127" layer="21"/>
<wire x1="2.413" y1="-2.4059" x2="2.664" y2="-1.397" width="0.127" layer="51" curve="22.4788"/>
<wire x1="2.664" y1="-1.397" x2="2.413" y2="-0.1341" width="0.127" layer="51" curve="27.9376"/>
<wire x1="2.664" y1="-1.397" x2="1.404" y2="-1.397" width="0.127" layer="51"/>
<wire x1="1.404" y1="-1.397" x2="1.136" y2="-1.397" width="0.127" layer="21"/>
<wire x1="2.095" y1="-2.921" x2="2.4247" y2="-2.3818" width="0.127" layer="21" curve="13.6094"/>
<pad name="C" x="-2.54" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="2.54" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<pad name="B" x="0" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.54" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-4.572" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="gabor">
<packages>
<package name="CA6V">
<description>&lt;b&gt;Trimm resistor&lt;/b&gt; ACP Spain&lt;p&gt;
Model CA6 STD</description>
<circle x="0" y="0" radius="1.4199" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="2.54" drill="1"/>
<pad name="2" x="0" y="-2.54" drill="1"/>
<pad name="3" x="2.54" y="2.54" drill="1"/>
<text x="-2.515" y="4.205" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.515" y="-4.97" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.016" y1="-0.254" x2="1.016" y2="0.254" layer="21"/>
<rectangle x1="-0.254" y1="-1.016" x2="0.254" y2="1.016" layer="21"/>
<wire x1="-2.921" y1="3.175" x2="-1.27" y2="3.175" width="0.127" layer="21"/>
<wire x1="-1.27" y1="3.175" x2="1.27" y2="3.175" width="0.127" layer="21"/>
<wire x1="1.27" y1="3.175" x2="2.921" y2="3.175" width="0.127" layer="21"/>
<wire x1="2.921" y1="3.175" x2="3.175" y2="2.921" width="0.127" layer="21" curve="-90"/>
<wire x1="3.175" y1="2.921" x2="3.175" y2="1.905" width="0.127" layer="21"/>
<wire x1="3.175" y1="1.905" x2="3.175" y2="-2.921" width="0.127" layer="21"/>
<wire x1="3.175" y1="-2.921" x2="2.921" y2="-3.175" width="0.127" layer="21" curve="-90"/>
<wire x1="2.921" y1="-3.175" x2="1.27" y2="-3.175" width="0.127" layer="21"/>
<wire x1="1.27" y1="-3.175" x2="-1.27" y2="-3.175" width="0.127" layer="21"/>
<wire x1="-1.27" y1="-3.175" x2="-2.921" y2="-3.175" width="0.127" layer="21"/>
<wire x1="-2.921" y1="-3.175" x2="-3.175" y2="-2.921" width="0.127" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-2.921" x2="-3.175" y2="1.905" width="0.127" layer="21"/>
<wire x1="-3.175" y1="1.905" x2="-3.175" y2="2.921" width="0.127" layer="21"/>
<wire x1="-3.175" y1="2.921" x2="-2.921" y2="3.175" width="0.127" layer="21" curve="-90"/>
<wire x1="-3.175" y1="1.905" x2="-1.524" y2="1.905" width="0.127" layer="21"/>
<wire x1="-1.524" y1="1.905" x2="-1.27" y2="2.159" width="0.127" layer="21" curve="90"/>
<wire x1="-1.27" y1="2.159" x2="-1.27" y2="3.175" width="0.127" layer="21"/>
<wire x1="1.27" y1="3.175" x2="1.27" y2="2.159" width="0.127" layer="21"/>
<wire x1="1.27" y1="2.159" x2="1.524" y2="1.905" width="0.127" layer="21" curve="90"/>
<wire x1="1.524" y1="1.905" x2="3.175" y2="1.905" width="0.127" layer="21"/>
<wire x1="-1.27" y1="-3.175" x2="-1.27" y2="-2.159" width="0.127" layer="21"/>
<wire x1="-1.27" y1="-2.159" x2="-1.016" y2="-1.905" width="0.127" layer="21" curve="-90"/>
<wire x1="-1.016" y1="-1.905" x2="1.016" y2="-1.905" width="0.127" layer="21"/>
<wire x1="1.016" y1="-1.905" x2="1.27" y2="-2.159" width="0.127" layer="21" curve="-90"/>
<wire x1="1.27" y1="-2.159" x2="1.27" y2="-3.175" width="0.127" layer="21"/>
</package>
</packages>
</library>
<library name="relay">
<description>&lt;b&gt;Relays&lt;/b&gt;&lt;p&gt;
&lt;ul&gt;
&lt;li&gt;Eichhoff
&lt;li&gt;Finder
&lt;li&gt;Fujitsu
&lt;li&gt;HAMLIN
&lt;li&gt;OMRON
&lt;li&gt;Matsushita
&lt;li&gt;NAiS
&lt;li&gt;Siemens
&lt;li&gt;Schrack
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="351">
<description>&lt;b&gt;RELAY&lt;/b&gt;&lt;p&gt;
2 x switch, same as G5 V-2, Omron</description>
<wire x1="-5.08" y1="-5.08" x2="15.24" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-5.08" x2="15.24" y2="5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="5.08" x2="-5.08" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="5.08" x2="-5.08" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.27" x2="-3.81" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.27" x2="-3.81" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-1.27" x2="-5.08" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-1.27" x2="-5.08" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="3.81" x2="-1.905" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="3.81" x2="-1.905" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0.635" x2="-3.175" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0.635" x2="-3.175" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-0.635" x2="-0.635" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0.635" x2="-1.905" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-0.635" x2="-1.905" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-0.635" x2="-1.905" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-0.635" x2="-0.635" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-3.81" x2="-2.794" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-0.635" x2="-0.635" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="2.794" x2="3.81" y2="1.905" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.905" x2="11.43" y2="1.905" width="0.1524" layer="21"/>
<wire x1="11.43" y1="1.905" x2="11.43" y2="3.175" width="0.1524" layer="21"/>
<wire x1="11.43" y1="3.175" x2="10.795" y2="3.81" width="0.1524" layer="21"/>
<wire x1="9.9822" y1="3.81" x2="10.795" y2="3.81" width="0.1524" layer="21"/>
<wire x1="12.065" y1="3.81" x2="12.9032" y2="3.81" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-2.794" x2="3.81" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-1.905" x2="11.43" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="11.43" y1="-1.905" x2="11.43" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="11.43" y1="-3.175" x2="10.795" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="9.9822" y1="-3.81" x2="10.795" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-3.81" x2="10.4902" y2="-4.1402" width="0.1524" layer="21"/>
<wire x1="12.065" y1="-3.81" x2="12.9032" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="10.795" y1="3.81" x2="10.4902" y2="4.1402" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="P1" x="3.81" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="O1" x="8.89" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="S1" x="13.97" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="S2" x="13.97" y="3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="O2" x="8.89" y="3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="P2" x="3.81" y="3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="-3.81" y="3.81" drill="1.016" shape="long" rot="R90"/>
<text x="17.78" y="-5.08" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="14.732" y="-1.397" size="1.27" layer="51" ratio="10" rot="R90">351</text>
<text x="1.27" y="-0.889" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.08" y1="-1.27" x2="-3.81" y2="1.27" layer="21"/>
</package>
</packages>
</library>
<library name="holes">
<description>&lt;b&gt;Mounting Holes and Pads&lt;/b&gt;&lt;p&gt;
<packages>
<package name="3,2">
<description>&lt;b&gt;MOUNTING HOLE&lt;/b&gt; 3.2 mm with drill center</description>
<wire x1="-2.159" y1="0" x2="0" y2="-2.159" width="2.4892" layer="51" curve="90" cap="flat"/>
<wire x1="0" y1="2.159" x2="2.159" y2="0" width="2.4892" layer="51" curve="-90" cap="flat"/>
<circle x="0" y="0" radius="3.429" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="0.762" width="0.4572" layer="51"/>
<circle x="0" y="0" radius="3.048" width="2.032" layer="39"/>
<circle x="0" y="0" radius="3.048" width="2.032" layer="43"/>
<circle x="0" y="0" radius="3.048" width="2.032" layer="40"/>
<circle x="0" y="0" radius="3.048" width="2.032" layer="41"/>
<circle x="0" y="0" radius="3.048" width="2.032" layer="42"/>
<circle x="0" y="0" radius="1.7" width="0.2032" layer="21"/>
<hole x="0" y="0" drill="3.2"/>
</package>
</packages>
</library>
<library name="microphon">
<description>&lt;b&gt;Microphon&lt;/b&gt; from&lt;p&gt;
JLI Electronics - www.jlielectronics.com&lt;br&gt;
Panansonic - http://industrial.panasonic.com&lt;br&gt;
&lt;p&gt;
&lt;author&gt;librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="F6050AP">
<description>&lt;b&gt;Omnibidirectional Electret Condenser Microphon&lt;/b&gt;&lt;p&gt;
Source: F6050AP.pdf</description>
<circle x="0" y="0" radius="2.8754" width="0.2032" layer="21"/>
<circle x="0" y="0" radius="2.625" width="1" layer="41"/>
<pad name="2" x="0" y="-1.27" drill="0.7" diameter="1.2"/>
<pad name="1" x="0" y="1.27" drill="0.7" diameter="1.2"/>
<text x="-2.4" y="3.2" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.4" y="-4.8" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="1.5499" y1="-2.0251" x2="1.9499" y2="-1.4751" layer="21" rot="R45"/>
<rectangle x1="-1.95" y1="-2.025" x2="-1.55" y2="-1.475" layer="21" rot="R315"/>
</package>
</packages>
</library>
<library name="atmel">
<description>&lt;b&gt;AVR Devices&lt;/b&gt;&lt;p&gt;
Configurable logic, microcontrollers, nonvolatile memories&lt;p&gt;
Based on the following sources:&lt;p&gt;
&lt;ul&gt;
&lt;li&gt;www.atmel.com
&lt;li&gt;CD-ROM : Configurable Logic Microcontroller Nonvolatile Memory
&lt;li&gt;CadSoft download site, www.cadsoft.de or www.cadsoftusa.com , file at90smcu_v400.zip
&lt;li&gt;avr.lbr
&lt;/ul&gt;
&lt;author&gt;Revised by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DIL28-3">
<description>&lt;B&gt;Dual In Line&lt;/B&gt; 0.3 inch</description>
<wire x1="-18.542" y1="-0.635" x2="-18.542" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="0.635" x2="-18.542" y2="-0.635" width="0.1524" layer="21" curve="-180"/>
<wire x1="-18.542" y1="-2.794" x2="18.542" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="2.794" x2="-18.542" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="2.794" x2="18.542" y2="2.794" width="0.1524" layer="21"/>
<wire x1="18.542" y1="2.794" x2="18.542" y2="-2.794" width="0.1524" layer="21"/>
<pad name="1" x="-16.51" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="16.51" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="16.51" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="-11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="-13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="-16.51" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-19.2024" y="-2.54" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-15.875" y="-0.635" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="inductors">
<description>&lt;b&gt;Inductors and Filters&lt;/b&gt;&lt;p&gt;
Based on the previous library ind-a.lbr&lt;p&gt;
<packages>
<package name="LBC-SE">
<description>&lt;B&gt;INDUCTOR&lt;/B&gt;&lt;p&gt;
B82144, verticalmanufacturer Siemens</description>
<wire x1="2.54" y1="0" x2="1.143" y2="0" width="0.6096" layer="51"/>
<wire x1="-1.143" y1="0" x2="-2.54" y2="0" width="0.6096" layer="51"/>
<circle x="-2.54" y="0" radius="2.667" width="0.1524" layer="21"/>
<circle x="-2.54" y="0" radius="1.524" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.9144" shape="octagon"/>
<text x="-5.08" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.318" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.143" y1="-0.3048" x2="1.143" y2="0.3048" layer="21"/>
</package>
</packages>
</library>
<library name="tlown">
<description>Saját alkatrészek</description>
<packages>
<package name="MC34063">
<description>Switching regulator</description>
<pad name="1" x="-5.08" y="6.35" drill="0.8" shape="square"/>
<pad name="2" x="-5.08" y="3.81" drill="0.8" shape="long"/>
<pad name="3" x="-5.08" y="1.27" drill="0.8" shape="long"/>
<pad name="4" x="-5.08" y="-1.27" drill="0.8" shape="long"/>
<pad name="5" x="2.54" y="-1.27" drill="0.8" shape="long"/>
<pad name="6" x="2.54" y="1.27" drill="0.8" shape="long"/>
<pad name="7" x="2.54" y="3.81" drill="0.8" shape="long"/>
<pad name="8" x="2.54" y="6.35" drill="0.8" shape="long"/>
<wire x1="-3.81" y1="7.62" x2="-3.81" y2="-2.54" width="0.127" layer="21"/>
<wire x1="-3.81" y1="-2.54" x2="1.27" y2="-2.54" width="0.127" layer="21"/>
<wire x1="1.27" y1="-2.54" x2="1.27" y2="7.62" width="0.127" layer="21"/>
<wire x1="1.27" y1="7.62" x2="-3.81" y2="7.62" width="0.127" layer="21"/>
<text x="-5.08" y="8.89" size="1.27" layer="21">&gt;NAME</text>
<text x="-5.08" y="-5.08" size="1.27" layer="21">&gt;VALUE</text>
</package>
<package name="MCP738X">
<description>Microchip MCP7383x egycellás automata akkutöltő.</description>
<smd name="3" x="-2.54" y="2.54" dx="1.27" dy="0.635" layer="1"/>
<smd name="2" x="-2.54" y="1.27" dx="1.27" dy="0.635" layer="1"/>
<smd name="1" x="-2.54" y="0" dx="1.27" dy="0.635" layer="1"/>
<smd name="5" x="2.54" y="0" dx="1.27" dy="0.635" layer="1"/>
<smd name="4" x="2.54" y="2.54" dx="1.27" dy="0.635" layer="1"/>
<wire x1="-1.27" y1="2.54" x2="-1.27" y2="0" width="0.127" layer="1"/>
<wire x1="-1.27" y1="0" x2="1.27" y2="0" width="0.127" layer="1"/>
<wire x1="1.27" y1="0" x2="1.27" y2="2.54" width="0.127" layer="1"/>
<wire x1="1.27" y1="2.54" x2="-1.27" y2="2.54" width="0.127" layer="1"/>
<text x="-2.54" y="3.81" size="1.27" layer="21">&gt;NAME</text>
<text x="-2.54" y="-2.54" size="1.27" layer="21">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="switch">
<description>&lt;b&gt;Switches&lt;/b&gt;&lt;p&gt;
Marquardt, Siemens, C&amp;K, ITT, and others&lt;p&gt;
<packages>
<package name="320-916">
<description>&lt;b&gt;TOGGLE SWITCH&lt;/b&gt;&lt;p&gt;
distributor RS Components</description>
<wire x1="-2.8702" y1="6.6802" x2="-3.5052" y2="6.0452" width="0.1524" layer="21"/>
<wire x1="-2.8702" y1="6.6802" x2="2.8702" y2="6.6802" width="0.1524" layer="21"/>
<wire x1="3.5052" y1="6.0452" x2="2.8702" y2="6.6802" width="0.1524" layer="21"/>
<wire x1="2.8702" y1="-6.6802" x2="3.5052" y2="-6.0452" width="0.1524" layer="21"/>
<wire x1="2.8702" y1="-6.6802" x2="-2.8702" y2="-6.6802" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="-6.0452" x2="-2.8702" y2="-6.6802" width="0.1524" layer="21"/>
<wire x1="4.318" y1="2.286" x2="4.318" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="2.286" x2="-4.318" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="1.905" y1="-3.175" x2="2.54" y2="-2.54" width="0.1524" layer="51"/>
<wire x1="1.905" y1="-3.175" x2="-1.905" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-2.54" x2="-1.905" y2="-3.175" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-2.54" x2="-2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-1.905" y1="-1.27" x2="-2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-1.905" y1="-1.27" x2="1.905" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="1.6002" y1="1.27" x2="2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="3.5052" y1="-6.0452" x2="3.5052" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="3.5052" y1="6.0452" x2="3.5052" y2="2.8702" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="2.8702" x2="-3.5052" y2="6.0452" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="-6.0452" x2="-3.5052" y2="-2.8194" width="0.1524" layer="21"/>
<wire x1="-1.6002" y1="1.27" x2="-2.54" y2="-1.905" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-2.54" x2="2.54" y2="-2.54" width="0.1524" layer="51" curve="-270"/>
<wire x1="-2.54" y1="-1.27" x2="2.54" y2="-1.27" width="0.1524" layer="51" curve="-233.130102"/>
<wire x1="-1.6002" y1="1.27" x2="1.6002" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="-2.286" x2="-3.5052" y2="-2.8194" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="-2.8194" x2="0" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="4.318" y1="-2.286" x2="3.5052" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="3.5052" y1="-2.8702" x2="0" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="4.318" y1="2.286" x2="3.5052" y2="2.8702" width="0.1524" layer="21"/>
<wire x1="3.5052" y1="2.8702" x2="0" y2="5.08" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="2.286" x2="-3.5052" y2="2.8702" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="2.8702" x2="0" y2="5.08" width="0.1524" layer="51"/>
<pad name="3" x="0" y="-4.0132" drill="2.0066" shape="long"/>
<pad name="2" x="0" y="0" drill="2.0066" shape="long"/>
<pad name="1" x="0" y="4.0132" drill="2.0066" shape="long"/>
<text x="-2.54" y="7.62" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-9.525" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="320-938">
<wire x1="-5.4102" y1="6.6802" x2="-6.0452" y2="6.0452" width="0.1524" layer="21"/>
<wire x1="-5.4102" y1="6.6802" x2="5.4102" y2="6.6802" width="0.1524" layer="21"/>
<wire x1="6.0452" y1="6.0452" x2="5.4102" y2="6.6802" width="0.1524" layer="21"/>
<wire x1="5.4102" y1="-6.6802" x2="6.0452" y2="-6.0452" width="0.1524" layer="21"/>
<wire x1="5.4102" y1="-6.6802" x2="-5.4102" y2="-6.6802" width="0.1524" layer="21"/>
<wire x1="-6.0452" y1="-6.0452" x2="-5.4102" y2="-6.6802" width="0.1524" layer="21"/>
<wire x1="6.0452" y1="6.0452" x2="6.0452" y2="-6.0452" width="0.1524" layer="21"/>
<wire x1="-6.0452" y1="-6.0452" x2="-6.0452" y2="6.0452" width="0.1524" layer="21"/>
<wire x1="4.318" y1="2.286" x2="4.318" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="2.286" x2="-4.318" y2="-2.286" width="0.1524" layer="51"/>
<wire x1="4.318" y1="2.286" x2="0" y2="5.08" width="0.1524" layer="51"/>
<wire x1="0" y1="5.08" x2="-4.318" y2="2.286" width="0.1524" layer="51"/>
<wire x1="-4.318" y1="-2.286" x2="0" y2="-5.08" width="0.1524" layer="51"/>
<wire x1="0" y1="-5.08" x2="4.318" y2="-2.286" width="0.1524" layer="51"/>
<pad name="3" x="-2.3876" y="-4.0132" drill="2.0066" shape="octagon"/>
<pad name="2" x="-2.3876" y="0" drill="2.0066" shape="octagon"/>
<pad name="1" x="-2.3876" y="4.0132" drill="2.0066" shape="octagon"/>
<pad name="4" x="2.3876" y="4.0132" drill="2.0066" shape="octagon"/>
<pad name="5" x="2.3876" y="0" drill="2.0066" shape="octagon"/>
<pad name="6" x="2.3876" y="-4.0132" drill="2.0066" shape="octagon"/>
<text x="-5.08" y="7.62" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-9.525" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="battery">
<description>&lt;b&gt;Lithium Batteries and NC Accus&lt;/b&gt;&lt;p&gt;
<packages>
<package name="3V60R">
<description>&lt;b&gt;NC ACCU&lt;/b&gt; Varta</description>
<wire x1="-10.414" y1="-3.302" x2="-10.414" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-1.778" x2="9.525" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-5.842" x2="-10.414" y2="-3.302" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="3.302" x2="-10.414" y2="5.842" width="0.1524" layer="51"/>
<wire x1="-9.906" y1="-5.842" x2="-10.414" y2="-5.842" width="0.1524" layer="51"/>
<wire x1="-9.906" y1="-5.842" x2="-9.906" y2="-3.302" width="0.1524" layer="51"/>
<wire x1="-9.906" y1="-3.302" x2="-9.906" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="3.302" x2="-9.906" y2="5.842" width="0.1524" layer="51"/>
<wire x1="9.017" y1="-1.778" x2="9.017" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-9.906" y1="5.842" x2="-10.414" y2="5.842" width="0.1524" layer="51"/>
<wire x1="-9.525" y1="0" x2="-8.509" y2="0" width="0.254" layer="21"/>
<wire x1="-9.017" y1="0.508" x2="-9.017" y2="-0.508" width="0.254" layer="21"/>
<wire x1="7.112" y1="0.635" x2="7.112" y2="-0.635" width="0.254" layer="21"/>
<wire x1="-0.381" y1="-2.54" x2="-0.381" y2="0" width="0.254" layer="21"/>
<wire x1="2.286" y1="0" x2="0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-0.381" y2="2.54" width="0.254" layer="21"/>
<wire x1="-0.889" y1="-1.524" x2="-1.905" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="-2.032" x2="-1.397" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="9.017" y1="1.778" x2="9.017" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="6.477" x2="-9.017" y2="6.477" width="0.1524" layer="21"/>
<wire x1="-9.271" y1="-6.477" x2="-9.017" y2="-6.477" width="0.1524" layer="51"/>
<wire x1="9.017" y1="-8.382" x2="9.017" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-1.778" x2="9.525" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-2.54" x2="9.017" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="9.017" y1="-2.54" x2="9.017" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="9.525" y1="1.778" x2="9.525" y2="2.54" width="0.1524" layer="21"/>
<wire x1="9.525" y1="2.54" x2="9.017" y2="2.54" width="0.1524" layer="21"/>
<wire x1="9.017" y1="2.54" x2="9.017" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-0.762" x2="-10.414" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-0.762" x2="-9.906" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-0.762" x2="-10.414" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="0.762" x2="-10.414" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="0.762" x2="-9.906" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="0.762" x2="-10.414" y2="3.302" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-0.762" x2="9.017" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="9.525" y1="-0.762" x2="9.525" y2="0.762" width="0.1524" layer="51"/>
<wire x1="9.017" y1="-0.762" x2="9.017" y2="0.762" width="0.1524" layer="51"/>
<wire x1="9.525" y1="0.762" x2="9.017" y2="0.762" width="0.1524" layer="51"/>
<wire x1="9.525" y1="0.762" x2="9.525" y2="1.778" width="0.1524" layer="51"/>
<wire x1="9.017" y1="0.762" x2="9.017" y2="1.778" width="0.1524" layer="51"/>
<wire x1="-8.128" y1="6.477" x2="-8.128" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="8.382" x2="9.017" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="-8.382" x2="9.017" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="6.477" x2="-8.128" y2="-6.477" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="-6.477" x2="-8.128" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-5.842" x2="-9.271" y2="-6.477" width="0.1524" layer="51" curve="90"/>
<wire x1="-9.906" y1="5.842" x2="-9.271" y2="6.477" width="0.1524" layer="51" curve="-90"/>
<wire x1="-9.017" y1="-6.477" x2="-8.128" y2="-6.477" width="0.1524" layer="21"/>
<wire x1="-9.271" y1="6.477" x2="-9.017" y2="6.477" width="0.1524" layer="51"/>
<pad name="+" x="-10.16" y="-5.08" drill="1.3208" diameter="3.1496" shape="octagon"/>
<pad name="+@1" x="-10.16" y="5.08" drill="1.3208" diameter="3.1496" shape="octagon"/>
<pad name="-" x="9.271" y="0" drill="1.3208" diameter="3.1496" shape="octagon"/>
<text x="-10.922" y="-2.54" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.016" y="-7.62" size="1.27" layer="21" ratio="10">NC-3V6</text>
<text x="-4.445" y="-3.175" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.889" y2="1.27" layer="21"/>
</package>
</packages>
</library>
<library name="linear">
<description>&lt;b&gt;Linear Devices&lt;/b&gt;&lt;p&gt;
Operational amplifiers,  comparators, voltage regulators, ADCs, DACs, etc.&lt;p&gt;
<packages>
<package name="TO220H">
<description>&lt;b&gt;TO-220&lt;/b&gt;</description>
<wire x1="-5.207" y1="-7.62" x2="5.207" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="5.207" y1="8.255" x2="-5.207" y2="8.255" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-7.62" x2="5.207" y2="4.826" width="0.1524" layer="21"/>
<wire x1="5.207" y1="4.826" x2="4.318" y2="4.826" width="0.1524" layer="21"/>
<wire x1="4.318" y1="4.826" x2="4.318" y2="6.35" width="0.1524" layer="21"/>
<wire x1="4.318" y1="6.35" x2="5.207" y2="6.35" width="0.1524" layer="21"/>
<wire x1="5.207" y1="6.35" x2="5.207" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-7.62" x2="-5.207" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.826" x2="-4.318" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="4.826" x2="-4.318" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="6.35" x2="-5.207" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="6.35" x2="-5.207" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-6.985" x2="4.572" y2="-6.985" width="0.0508" layer="21"/>
<wire x1="4.572" y1="1.27" x2="4.572" y2="-6.985" width="0.0508" layer="21"/>
<wire x1="4.572" y1="1.27" x2="-4.572" y2="1.27" width="0.0508" layer="21"/>
<wire x1="-4.572" y1="-6.985" x2="-4.572" y2="1.27" width="0.0508" layer="21"/>
<circle x="0" y="4.826" radius="1.8034" width="0.1524" layer="21"/>
<circle x="0" y="4.826" radius="2.54" width="0" layer="43"/>
<circle x="0" y="4.826" radius="2.54" width="0" layer="42"/>
<pad name="1" x="-2.54" y="-10.16" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-10.16" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-10.16" drill="1.1176" shape="long" rot="R90"/>
<text x="-5.461" y="-10.922" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="7.366" y="-11.049" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<rectangle x1="2.159" y1="-11.049" x2="2.921" y2="-10.414" layer="21"/>
<rectangle x1="-0.381" y1="-11.049" x2="0.381" y2="-10.414" layer="21"/>
<rectangle x1="-2.921" y1="-11.049" x2="-2.159" y2="-10.414" layer="21"/>
<rectangle x1="-3.175" y1="-10.414" x2="-1.905" y2="-7.62" layer="21"/>
<rectangle x1="-0.635" y1="-10.414" x2="0.635" y2="-7.62" layer="21"/>
<rectangle x1="1.905" y1="-10.414" x2="3.175" y2="-7.62" layer="21"/>
<hole x="0" y="4.826" drill="3.302"/>
</package>
</packages>
</library>
<library name="con-lumberg">
<description>&lt;b&gt;Lumberg Connectors&lt;/b&gt;&lt;p&gt;
include con-mfs.lbr - 2001.03.22&lt;br&gt;
Jack connectors - 2005.11.23&lt;p&gt;
http://www.lumberg.de&lt;p&gt;
<packages>
<package name="1503_09">
<description>&lt;b&gt;Jack connectors according to JISC 6560, 3.5 mm&lt;/b&gt;&lt;p&gt;
Klinkeneinbaukupplung nach JISC 6560, 3,5 mm, 3-polig/&lt;br&gt;
stereo, abgewinkelte Ausführung, mit 2 Öffnern und Lötaugen,&lt;br&gt;
für Leiterplatten Rückseitenmontage&lt;p&gt;
Source: http://www.lumberg.com/Produkte/PDFs/1503_09.pdf</description>
<wire x1="0.75" y1="-2.1" x2="0.35" y2="-1.7" width="0" layer="46" curve="90"/>
<wire x1="0.35" y1="-1.7" x2="-0.35" y2="-1.7" width="0" layer="46"/>
<wire x1="-0.35" y1="-1.7" x2="-0.75" y2="-2.1" width="0" layer="46" curve="90"/>
<wire x1="-0.75" y1="-2.1" x2="-0.35" y2="-2.5" width="0" layer="46" curve="90"/>
<wire x1="-0.35" y1="-2.5" x2="0.35" y2="-2.5" width="0" layer="46"/>
<wire x1="0.35" y1="-2.5" x2="0.75" y2="-2.1" width="0" layer="46" curve="90"/>
<wire x1="-4.55" y1="-6.15" x2="-4.15" y2="-5.75" width="0" layer="46" curve="90"/>
<wire x1="-4.15" y1="-5.75" x2="-4.15" y2="-5.05" width="0" layer="46"/>
<wire x1="-4.15" y1="-5.05" x2="-4.55" y2="-4.65" width="0" layer="46" curve="90"/>
<wire x1="-4.55" y1="-4.65" x2="-4.95" y2="-5.05" width="0" layer="46" curve="90"/>
<wire x1="-4.95" y1="-5.05" x2="-4.95" y2="-5.75" width="0" layer="46"/>
<wire x1="-4.95" y1="-5.75" x2="-4.55" y2="-6.15" width="0" layer="46" curve="90"/>
<wire x1="-3.25" y1="-13.1" x2="-3.65" y2="-12.7" width="0" layer="46" curve="90"/>
<wire x1="-3.65" y1="-12.7" x2="-4.35" y2="-12.7" width="0" layer="46"/>
<wire x1="-4.35" y1="-12.7" x2="-4.75" y2="-13.1" width="0" layer="46" curve="90"/>
<wire x1="-4.75" y1="-13.1" x2="-4.35" y2="-13.5" width="0" layer="46" curve="90"/>
<wire x1="-4.35" y1="-13.5" x2="-3.65" y2="-13.5" width="0" layer="46"/>
<wire x1="-3.65" y1="-13.5" x2="-3.25" y2="-13.1" width="0" layer="46" curve="90"/>
<wire x1="2.65" y1="-9.25" x2="3.05" y2="-8.85" width="0" layer="46" curve="90"/>
<wire x1="3.05" y1="-8.85" x2="3.05" y2="-8.15" width="0" layer="46"/>
<wire x1="3.05" y1="-8.15" x2="2.65" y2="-7.75" width="0" layer="46" curve="90"/>
<wire x1="2.65" y1="-7.75" x2="2.25" y2="-8.15" width="0" layer="46" curve="90"/>
<wire x1="2.25" y1="-8.15" x2="2.25" y2="-8.85" width="0" layer="46"/>
<wire x1="2.25" y1="-8.85" x2="2.65" y2="-9.25" width="0" layer="46" curve="90"/>
<wire x1="5.05" y1="-10.65" x2="5.45" y2="-10.25" width="0" layer="46" curve="90"/>
<wire x1="5.45" y1="-10.25" x2="5.45" y2="-9.55" width="0" layer="46"/>
<wire x1="5.45" y1="-9.55" x2="5.05" y2="-9.15" width="0" layer="46" curve="90"/>
<wire x1="5.05" y1="-9.15" x2="4.65" y2="-9.55" width="0" layer="46" curve="90"/>
<wire x1="4.65" y1="-9.55" x2="4.65" y2="-10.25" width="0" layer="46"/>
<wire x1="4.65" y1="-10.25" x2="5.05" y2="-10.65" width="0" layer="46" curve="90"/>
<wire x1="-5.4" y1="-0.1" x2="5.9" y2="-0.1" width="0.2032" layer="21"/>
<wire x1="5.9" y1="-0.1" x2="5.9" y2="-14" width="0.2032" layer="21"/>
<wire x1="5.9" y1="-14" x2="-5.4" y2="-14" width="0.2032" layer="21"/>
<wire x1="-5.4" y1="-14" x2="-5.4" y2="-0.1" width="0.2032" layer="21"/>
<wire x1="-2.9" y1="0" x2="-2.9" y2="3.4" width="0.2032" layer="21"/>
<wire x1="-2.9" y1="3.4" x2="2.9" y2="3.4" width="0.2032" layer="21"/>
<wire x1="2.9" y1="3.4" x2="2.9" y2="0" width="0.2032" layer="21"/>
<pad name="1" x="0" y="-2.1" drill="0.8" diameter="1.2" shape="long" rot="R180"/>
<pad name="2" x="-4.55" y="-5.4" drill="0.8" diameter="1.2" shape="long" rot="R90"/>
<pad name="3" x="5.05" y="-9.9" drill="0.8" diameter="1.2" shape="long" rot="R90"/>
<pad name="4" x="-4" y="-13.1" drill="0.8" diameter="1.2" shape="long" rot="R180"/>
<pad name="5" x="2.65" y="-8.5" drill="0.8" diameter="1.2" shape="long" rot="R90"/>
<text x="0" y="7.24" size="1.27" layer="25">&gt;NAME</text>
<text x="0" y="-19.24" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default *">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="1"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
</autorouter>
<elements>
<element name="JP1" library="avr-7" package="AVR-ISP-6" value="AVR-ISP-6VERT" x="41.91" y="69.85"/>
<element name="TP1" library="solpad" package="SE13" value="SE13" x="6.35" y="48.26" rot="R180"/>
<element name="TP2" library="solpad" package="SE13" value="SE13" x="6.35" y="41.91" rot="R180"/>
<element name="TP3" library="solpad" package="SE13" value="SE13" x="6.35" y="35.56" rot="R180"/>
<element name="TL431" library="gabor-lib" package="SO08" value="" x="48.26" y="24.13" smashed="yes" rot="R90">
<attribute name="NAME" x="50.165" y="21.463" size="1.27" layer="25" rot="R180"/>
<attribute name="VALUE" x="50.165" y="28.067" size="1.27" layer="27" rot="R180"/>
</element>
<element name="R1" library="rcl" package="MINI_MELF-0204W" value="680" x="15.24" y="48.26" smashed="yes" rot="R180">
<attribute name="NAME" x="11.938" y="48.641" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="17.5006" y="48.895" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R2" library="rcl" package="R0805" value="470k" x="14.605" y="45.085" smashed="yes" rot="R180">
<attribute name="NAME" x="11.303" y="45.466" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="16.8656" y="45.72" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R3" library="rcl" package="MINI_MELF-0204W" value="680" x="15.24" y="41.91" smashed="yes" rot="R180">
<attribute name="NAME" x="11.938" y="42.291" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="17.5006" y="42.545" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R4" library="rcl" package="R0805" value="470k" x="14.605" y="38.735" smashed="yes" rot="R180">
<attribute name="NAME" x="11.303" y="39.116" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="16.8656" y="39.37" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R5" library="rcl" package="MINI_MELF-0204W" value="680" x="15.24" y="35.56" smashed="yes" rot="R180">
<attribute name="NAME" x="11.938" y="35.941" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="17.5006" y="36.195" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R6" library="rcl" package="R0805" value="470k" x="14.605" y="32.385" smashed="yes" rot="R180">
<attribute name="NAME" x="11.303" y="32.766" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="16.8656" y="33.02" size="1.27" layer="27" ratio="10" rot="R180"/>
</element>
<element name="R7" library="rcl" package="R1206" value="3k3" x="48.26" y="36.195" smashed="yes">
<attribute name="NAME" x="42.545" y="35.56" size="1.27" layer="25"/>
<attribute name="VALUE" x="46.99" y="33.655" size="1.27" layer="27"/>
</element>
<element name="R8" library="rcl" package="R1206" value="10k" x="48.26" y="33.02" smashed="yes">
<attribute name="NAME" x="42.545" y="32.385" size="1.27" layer="25"/>
<attribute name="VALUE" x="46.99" y="30.48" size="1.27" layer="27"/>
</element>
<element name="R9" library="rcl" package="R1206" value="2k2" x="48.26" y="29.21" smashed="yes" rot="R180">
<attribute name="NAME" x="41.91" y="28.575" size="1.27" layer="25"/>
<attribute name="VALUE" x="49.53" y="31.75" size="1.27" layer="27" rot="R180"/>
</element>
<element name="LCD1" library="lcd_2x16_led_backlight" package="HY-1602F" value="LCD_2X16_SIL" x="57.15" y="74.93" rot="R270"/>
<element name="R10" library="rcl" package="R1206" value="33" x="57.15" y="22.225" smashed="yes" rot="R180">
<attribute name="NAME" x="63.5" y="22.86" size="1.27" layer="25" rot="R180"/>
<attribute name="VALUE" x="58.42" y="24.765" size="1.27" layer="27" rot="R180"/>
</element>
<element name="R11" library="gabor" package="CA6V" value="10K" x="66.04" y="67.31" rot="R270"/>
<element name="C1" library="resistor" package="C1206" value="22p" x="23.495" y="64.135" smashed="yes" rot="R270">
<attribute name="NAME" x="21.082" y="65.278" size="1.27" layer="25" ratio="10" rot="R270"/>
<attribute name="VALUE" x="24.638" y="65.278" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="C2" library="resistor" package="C1206" value="22p" x="23.495" y="57.785" smashed="yes" rot="R90">
<attribute name="NAME" x="25.908" y="56.642" size="1.27" layer="25" ratio="10" rot="R90"/>
<attribute name="VALUE" x="22.352" y="56.642" size="1.27" layer="27" ratio="10" rot="R90"/>
</element>
<element name="Q1" library="crystal" package="HC49UP" value="16 MHz" x="27.94" y="60.96" smashed="yes" rot="R90">
<attribute name="NAME" x="29.21" y="54.483" size="1.27" layer="25" ratio="10" rot="R180"/>
<attribute name="VALUE" x="31.877" y="55.88" size="1.27" layer="27" ratio="10" rot="R90"/>
<attribute name="MF" value="" x="27.94" y="60.96" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="27.94" y="60.96" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="27.94" y="60.96" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="27.94" y="60.96" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="C3" library="resistor" package="C0805" value="100n" x="34.925" y="55.88"/>
<element name="C4" library="resistor" package="C0805" value="1n" x="35.56" y="40.64" smashed="yes">
<attribute name="NAME" x="30.607" y="39.497" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="35.687" y="42.418" size="1.27" layer="27" ratio="10"/>
</element>
<element name="C5" library="resistor" package="C0805" value="100n" x="35.56" y="38.1" smashed="yes">
<attribute name="NAME" x="30.607" y="36.957" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="33.782" y="35.433" size="1.27" layer="27" ratio="10"/>
</element>
<element name="R12" library="rcl" package="R1206" value="10k" x="55.245" y="26.67" smashed="yes" rot="R90">
<attribute name="NAME" x="57.15" y="29.845" size="1.27" layer="25" rot="R90"/>
<attribute name="VALUE" x="57.785" y="25.4" size="1.27" layer="27" rot="R90"/>
</element>
<element name="C6" library="resistor" package="C1206" value="4,7n" x="48.26" y="39.37" smashed="yes" rot="R180">
<attribute name="NAME" x="44.45" y="39.497" size="1.27" layer="25" rot="R180"/>
<attribute name="VALUE" x="49.53" y="41.783" size="1.27" layer="27" rot="R180"/>
</element>
<element name="D1" library="gabor-lib" package="D1206" value="1N4148" x="58.42" y="26.67" smashed="yes" rot="R90">
<attribute name="NAME" x="59.055" y="30.48" size="1.27" layer="25" rot="R90"/>
<attribute name="VALUE" x="60.96" y="25.4" size="1.27" layer="27" rot="R90"/>
</element>
<element name="J1" library="con-jack" package="DCJ0202" value="DCJ0202" x="67.31" y="13.97" smashed="yes" rot="R90">
<attribute name="MF" value="" x="67.31" y="13.97" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="67.31" y="13.97" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="67.31" y="13.97" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="67.31" y="13.97" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="NAME" x="68.58" y="11.43" size="1.27" layer="25" rot="R180"/>
<attribute name="VALUE" x="77.47" y="8.89" size="1.27" layer="27" rot="R180"/>
</element>
<element name="S1" library="switch-omron" package="B3F-10XX" value="" x="12.7" y="20.32" smashed="yes" rot="R270">
<attribute name="MF" value="" x="12.7" y="20.32" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="B3F-1000" x="12.7" y="20.32" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_FARNELL" value="176432" x="12.7" y="20.32" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_NEWARK" value="36M3542" x="12.7" y="20.32" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="NAME" x="12.192" y="24.003" size="1.27" layer="25" ratio="10"/>
<attribute name="VALUE" x="7.62" y="23.368" size="1.27" layer="27" ratio="10" rot="R270"/>
</element>
<element name="R17" library="rcl" package="R1206" value="27k" x="29.21" y="24.13" smashed="yes" rot="R270">
<attribute name="NAME" x="30.48" y="25.4" size="1.27" layer="25"/>
<attribute name="VALUE" x="30.48" y="22.86" size="1.27" layer="27"/>
</element>
<element name="R18" library="rcl" package="R1206" value="10K" x="57.15" y="19.05" rot="R180"/>
<element name="K1" library="relay" package="351" value="RY5W-K" x="8.89" y="67.31" rot="R270">
<attribute name="OC_NEWARK" value="unknown" x="8.89" y="67.31" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MPN" value="" x="8.89" y="67.31" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="MF" value="" x="8.89" y="67.31" size="1.778" layer="27" rot="R270" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="8.89" y="67.31" size="1.778" layer="27" rot="R270" display="off"/>
</element>
<element name="T3" library="transistor-npn" package="SOT23" value="BC547C" x="19.05" y="10.16" rot="R90"/>
<element name="R20" library="rcl" package="R1206" value="4,7k" x="24.13" y="8.89" rot="R180"/>
<element name="D3" library="gabor-lib" package="D1206" value="1N4148" x="8.89" y="68.58" rot="MR0"/>
<element name="U$1" library="holes" package="3,2" value="" x="3.81" y="3.81"/>
<element name="U$2" library="holes" package="3,2" value="" x="71.12" y="3.81"/>
<element name="U$3" library="holes" package="3,2" value="" x="71.12" y="77.47"/>
<element name="U$4" library="holes" package="3,2" value="" x="3.81" y="77.47"/>
<element name="T6" library="transistor-npn" package="TO92-EBC" value="BC547C" x="34.29" y="34.29"/>
<element name="T4" library="transistor-npn" package="TO92-EBC" value="BC547C" x="26.67" y="29.21"/>
<element name="C8" library="resistor" package="C025-024X044" value="100n" x="34.29" y="19.05"/>
<element name="R23" library="resistor" package="0204V" value="100k" x="33.02" y="24.13"/>
<element name="R24" library="resistor" package="0204V" value="1M" x="26.67" y="27.94"/>
<element name="R25" library="resistor" package="0204V" value="1M" x="26.67" y="26.67"/>
<element name="R26" library="resistor" package="0204V" value="10k" x="30.48" y="35.56"/>
<element name="M1" library="microphon" package="F6050AP" value="ELECTRET_MICROPHON-F6050AP" x="31.75" y="34.29"/>
<element name="IC3" library="atmel" package="DIL28-3" value="ATMEGA328-P" x="41.91" y="35.56">
<attribute name="OC_NEWARK" value="unknown" x="41.91" y="35.56" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="41.91" y="35.56" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="" x="41.91" y="35.56" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="41.91" y="35.56" size="1.778" layer="27" display="off"/>
</element>
<element name="L1" library="inductors" package="LBC-SE" value="33uH" x="35.56" y="17.78"/>
<element name="D4" library="diode" package="DO41-7.6" value="1N5818" x="40.64" y="39.37"/>
<element name="R21" library="resistor" package="0204V" value="0.5" x="38.1" y="13.97"/>
<element name="R22" library="resistor" package="0204V" value="180" x="38.1" y="17.78"/>
<element name="R27" library="resistor" package="0204V" value="1k5" x="27.94" y="19.05"/>
<element name="R28" library="resistor" package="0204V" value="56k" x="27.94" y="15.24"/>
<element name="R29" library="resistor" package="0204V" value="33k" x="50.8" y="30.48"/>
<element name="C11" library="rcl" package="153CLV-0505" value="100µF" x="40.64" y="25.4"/>
<element name="C12" library="resistor" package="C1206" value="1n" x="29.21" y="26.67"/>
<element name="C13" library="resistor" package="C1206" value="100n" x="33.02" y="20.32"/>
<element name="U$5" library="tlown" package="MC34063" value="" x="34.29" y="21.59"/>
<element name="R30" library="resistor" package="0204V" value="300" x="26.67" y="48.26"/>
<element name="R31" library="resistor" package="0204V" value="33k" x="34.29" y="25.4"/>
<element name="T7" library="transistor-pnp" package="SOT23-BEC" value="BC557C" x="52.07" y="20.32"/>
<element name="D5" library="diode" package="DO35-7" value="1N4148" x="34.29" y="22.86"/>
<element name="D6" library="diode" package="DO35-7" value="1N4148" x="57.15" y="19.05"/>
<element name="D7" library="diode" package="DO35-7" value="1N4148" x="35.56" y="16.51"/>
<element name="C14" library="rcl" package="153CLV-0505" value="47µF 50V" x="41.91" y="24.13"/>
<element name="S2" library="switch" package="320-916" value="" x="19.05" y="25.4"/>
<element name="R32" library="resistor" package="0204V" value="180k" x="50.8" y="24.13"/>
<element name="R33" library="resistor" package="0204V" value="20k" x="36.83" y="33.02"/>
<element name="C15" library="resistor" package="C1206" value="10n" x="36.83" y="10.16"/>
<element name="D8" library="diode" package="DO35Z10" value="ZPD5V1" x="38.1" y="38.1"/>
<element name="TP4" library="solpad" package="SE13" value="SE13" x="44.45" y="31.75"/>
<element name="TP5" library="solpad" package="SE13" value="SE13" x="50.8" y="45.72"/>
<element name="S3" library="switch" package="320-916" value="" x="39.37" y="21.59"/>
<element name="ZÉNER" library="diode" package="DO35Z10" value="Zx" x="35.56" y="20.32"/>
<element name="S4" library="switch" package="320-938" value="" x="52.07" y="25.4"/>
<element name="R34" library="rcl" package="R1206" value="470" x="43.18" y="25.4"/>
<element name="R35" library="rcl" package="R1206" value="10K" x="59.69" y="39.37"/>
<element name="C16" library="resistor" package="C1206" value="100n" x="46.99" y="26.67"/>
<element name="R36" library="rcl" package="R1206" value="10K" x="36.83" y="13.97"/>
<element name="R37" library="gabor" package="CA6V" value="10K" x="36.83" y="27.94"/>
<element name="U$6" library="tlown" package="MC34063" value="" x="48.26" y="22.86"/>
<element name="L2" library="inductors" package="LBC-SE" value="33uH" x="35.56" y="19.05"/>
<element name="R38" library="resistor" package="0204V" value="180" x="39.37" y="19.05"/>
<element name="R39" library="resistor" package="0204V" value="0.22" x="26.67" y="19.05"/>
<element name="C17" library="rcl" package="153CLV-0505" value="100µF" x="49.53" y="34.29"/>
<element name="R40" library="resistor" package="0204V" value="3k3" x="26.67" y="10.16"/>
<element name="R41" library="resistor" package="0204V" value="10k" x="41.91" y="27.94"/>
<element name="C20" library="resistor" package="C1206" value="1,5n" x="34.29" y="24.13"/>
<element name="D9" library="diode" package="DO41-7.6" value="1N5818" x="40.64" y="38.1"/>
<element name="C21" library="resistor" package="C1206" value="100n" x="44.45" y="21.59"/>
<element name="C22" library="rcl" package="153CLV-0505" value="470µF" x="45.72" y="21.59"/>
<element name="G1" library="battery" package="3V60R" value="3V7" x="54.61" y="34.29"/>
<element name="D10" library="diode" package="DO41-7.6" value="1N5818" x="34.29" y="17.78"/>
<element name="S6" library="switch" package="320-916" value="" x="45.72" y="39.37"/>
<element name="U$7" library="tlown" package="MCP738X" value="MCP73832" x="40.64" y="27.94"/>
<element name="LED2" library="led" package="LED5MM" value="" x="46.99" y="19.05"/>
<element name="R14" library="resistor" package="0204V" value="470" x="55.88" y="16.51"/>
<element name="C7" library="rcl" package="153CLV-0505" value="4,7µF" x="27.94" y="27.94"/>
<element name="C9" library="rcl" package="153CLV-0505" value="4,7µF" x="16.51" y="21.59"/>
<element name="R15" library="resistor" package="0204V" value="2k" x="22.86" y="33.02"/>
<element name="IC2" library="linear" package="TO220H" value="7805" x="34.29" y="34.29"/>
<element name="C10" library="resistor" package="C025-024X044" value="100n" x="30.48" y="19.05"/>
<element name="C18" library="resistor" package="C025-024X044" value="100n" x="60.96" y="33.02"/>
<element name="C19" library="rcl" package="153CLV-0505" value="47µF" x="45.72" y="33.02"/>
<element name="C23" library="rcl" package="153CLV-0505" value="47µF" x="50.8" y="41.91"/>
<element name="D2" library="diode" package="DO41-10" value="1N4004" x="35.56" y="24.13"/>
<element name="C24" library="resistor" package="C025-024X044" value="100n" x="49.53" y="16.51"/>
<element name="X1" library="con-lumberg" package="1503_09" value="TP6" x="24.13" y="22.86">
<attribute name="OC_NEWARK" value="unknown" x="24.13" y="22.86" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="24.13" y="22.86" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="" x="24.13" y="22.86" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="1243244" x="24.13" y="22.86" size="1.778" layer="27" display="off"/>
</element>
<element name="X2" library="con-lumberg" package="1503_09" value="VCC out" x="10.16" y="21.59">
<attribute name="OC_NEWARK" value="unknown" x="10.16" y="21.59" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="10.16" y="21.59" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="" x="10.16" y="21.59" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="1243244" x="10.16" y="21.59" size="1.778" layer="27" display="off"/>
</element>
</elements>
<signals>
<signal name="GND">
<contactref element="JP1" pad="6"/>
<contactref element="TL431" pad="4"/>
<contactref element="R7" pad="1"/>
<contactref element="LCD1" pad="16"/>
<contactref element="LCD1" pad="5"/>
<contactref element="LCD1" pad="1"/>
<contactref element="R11" pad="1"/>
<contactref element="C6" pad="2"/>
<contactref element="C1" pad="2"/>
<contactref element="C2" pad="2"/>
<contactref element="C3" pad="2"/>
<wire x1="59.69" y1="62.23" x2="57.15" y2="62.23" width="0.4064" layer="16"/>
<wire x1="60.96" y1="60.96" x2="59.69" y2="62.23" width="0.4064" layer="16"/>
<wire x1="60.96" y1="35.56" x2="60.96" y2="60.96" width="0.4064" layer="16"/>
<wire x1="59.69" y1="34.29" x2="60.96" y2="35.56" width="0.4064" layer="16"/>
<wire x1="57.15" y1="34.29" x2="59.69" y2="34.29" width="0.4064" layer="16"/>
<polygon width="0.6096" layer="1" rank="2">
<vertex x="46.355" y="6.35"/>
<vertex x="33.655" y="6.35"/>
<vertex x="33.655" y="14.605"/>
<vertex x="46.355" y="14.605"/>
</polygon>
<polygon width="0.4064" layer="1" isolate="0.3048" rank="6">
<vertex x="20.32" y="50.8"/>
<vertex x="20.32" y="69.85"/>
<vertex x="32.385" y="69.85"/>
<vertex x="32.385" y="50.8"/>
</polygon>
<wire x1="23.495" y1="59.185" x2="23.495" y2="62.735" width="0.4064" layer="1"/>
<wire x1="35.16" y1="53.6575" x2="35.4775" y2="53.975" width="0.508" layer="1"/>
<wire x1="35.4775" y1="53.975" x2="35.56" y2="53.975" width="0.4064" layer="1"/>
<wire x1="35.775" y1="53.975" x2="36.4425" y2="53.975" width="0.508" layer="1"/>
<wire x1="36.4425" y1="53.975" x2="36.76" y2="53.6575" width="0.508" layer="1"/>
<wire x1="35.775" y1="55.88" x2="35.775" y2="53.975" width="0.508" layer="1"/>
<wire x1="35.775" y1="53.975" x2="35.56" y2="53.975" width="0.508" layer="1"/>
<wire x1="57.15" y1="72.39" x2="45.72" y2="72.39" width="0.4064" layer="16"/>
<wire x1="45.72" y1="72.39" x2="44.45" y2="71.12" width="0.4064" layer="16"/>
<wire x1="57.15" y1="62.23" x2="52.07" y2="62.23" width="0.4064" layer="16"/>
<wire x1="52.07" y1="62.23" x2="49.53" y2="59.69" width="0.4064" layer="16"/>
<wire x1="49.53" y1="59.69" x2="45.72" y2="59.69" width="0.4064" layer="16"/>
<via x="45.72" y="59.69" extent="1-16" drill="0.8" shape="octagon"/>
<wire x1="45.72" y1="59.69" x2="36.83" y2="59.69" width="0.4064" layer="1"/>
<wire x1="36.83" y1="59.69" x2="35.775" y2="58.635" width="0.4064" layer="1"/>
<wire x1="35.775" y1="58.635" x2="35.775" y2="55.88" width="0.4064" layer="1"/>
<wire x1="23.495" y1="62.735" x2="21.9075" y2="62.735" width="0.4064" layer="1"/>
<wire x1="21.9075" y1="62.735" x2="21.59" y2="63.0525" width="0.4064" layer="1"/>
<wire x1="21.59" y1="63.0525" x2="21.59" y2="68.8975" width="0.4064" layer="1"/>
<wire x1="21.59" y1="68.8975" x2="21.9075" y2="69.215" width="0.4064" layer="1"/>
<wire x1="21.9075" y1="69.215" x2="34.6075" y2="69.215" width="0.8128" layer="1"/>
<wire x1="34.6075" y1="69.215" x2="35.56" y2="68.2625" width="0.4064" layer="1"/>
<wire x1="35.56" y1="68.2625" x2="35.56" y2="66.04" width="0.4064" layer="1"/>
<wire x1="35.56" y1="66.04" x2="36.83" y2="64.77" width="0.4064" layer="1"/>
<wire x1="36.83" y1="64.77" x2="44.45" y2="64.77" width="0.4064" layer="1"/>
<wire x1="44.45" y1="64.77" x2="45.72" y2="63.5" width="0.4064" layer="1"/>
<wire x1="45.72" y1="63.5" x2="45.72" y2="59.69" width="0.4064" layer="1"/>
<wire x1="57.15" y1="34.29" x2="52.07" y2="34.29" width="0.4064" layer="16"/>
<via x="52.07" y="34.29" extent="1-16" drill="0.8" shape="octagon" alwaysstop="yes"/>
<wire x1="46.86" y1="39.37" x2="46.86" y2="36.217" width="0.4064" layer="1"/>
<wire x1="46.86" y1="36.217" x2="46.838" y2="36.195" width="0.4064" layer="1"/>
<wire x1="48.26" y1="31.75" x2="48.26" y2="34.29" width="0.4064" layer="1"/>
<wire x1="48.26" y1="34.29" x2="46.99" y2="34.925" width="0.4064" layer="1"/>
<wire x1="46.99" y1="34.925" x2="46.99" y2="36.195" width="0.4064" layer="1"/>
<wire x1="46.99" y1="36.195" x2="46.838" y2="36.195" width="0.4064" layer="1"/>
<wire x1="45.72" y1="59.69" x2="45.72" y2="19.05" width="0.6096" layer="16"/>
<via x="36.195" y="21.59" extent="1-16" drill="0.8" shape="octagon"/>
<wire x1="36.195" y1="21.59" x2="36.195" y2="37.885" width="0.508" layer="1"/>
<wire x1="45.72" y1="19.05" x2="39.37" y2="12.7" width="0.6096" layer="16"/>
<wire x1="39.37" y1="12.7" x2="30.48" y2="12.7" width="0.6096" layer="16"/>
<via x="30.48" y="12.7" extent="1-16" drill="0.8" shape="octagon"/>
<wire x1="30.48" y1="12.7" x2="34.185" y2="12.7" width="0.6096" layer="16"/>
<wire x1="33.02" y1="21.59" x2="36.195" y2="21.59" width="0.6096" layer="16"/>
<wire x1="20.955" y1="18.415" x2="20.955" y2="13.97" width="0.4064" layer="1"/>
<wire x1="20.955" y1="13.97" x2="22.225" y2="12.7" width="0.4064" layer="1"/>
<wire x1="22.225" y1="12.7" x2="30.48" y2="12.7" width="0.4064" layer="1"/>
<wire x1="52.07" y1="31.115" x2="52.07" y2="34.29" width="0.4064" layer="1"/>
<wire x1="68.58" y1="69.85" x2="66.04" y2="72.39" width="0.4064" layer="16"/>
<wire x1="66.04" y1="72.39" x2="57.15" y2="72.39" width="0.4064" layer="16"/>
<wire x1="68.58" y1="69.85" x2="68.58" y2="68.58" width="0.4064" layer="16"/>
<wire x1="68.58" y1="68.58" x2="64.77" y2="64.77" width="0.4064" layer="16"/>
<wire x1="64.77" y1="64.77" x2="62.23" y2="64.77" width="0.4064" layer="16"/>
<wire x1="62.23" y1="64.77" x2="59.69" y2="62.23" width="0.4064" layer="16"/>
<polygon width="0.4064" layer="1" isolate="0.3048" orphans="yes" rank="6">
<vertex x="0" y="81.28"/>
<vertex x="74.93" y="81.28"/>
<vertex x="74.93" y="0"/>
<vertex x="0" y="0"/>
</polygon>
<wire x1="48.26" y1="31.75" x2="48.895" y2="31.115" width="0.4064" layer="1"/>
<wire x1="48.895" y1="31.115" x2="52.07" y2="31.115" width="0.4064" layer="1"/>
<polygon width="0.254" layer="16" spacing="0.254" isolate="0.3048" orphans="yes">
</polygon>
<contactref element="T3" pad="2"/>
<wire x1="52.07" y1="31.115" x2="52.07" y2="27.94" width="0.4064" layer="1"/>
<wire x1="52.07" y1="27.94" x2="50.86" y2="26.73" width="0.4064" layer="1"/>
<wire x1="50.86" y1="26.73" x2="50.86" y2="26.035" width="0.4064" layer="1"/>
<via x="22.86" y="11.43" extent="1-16" drill="0.8" shape="octagon"/>
<wire x1="30.48" y1="12.7" x2="34.18" y2="12.7" width="0.8128" layer="1"/>
<wire x1="34.18" y1="12.7" x2="34.18" y2="12.915" width="0.8128" layer="1"/>
<wire x1="30.48" y1="12.7" x2="29.21" y2="13.97" width="0.6096" layer="16"/>
<wire x1="29.21" y1="13.97" x2="29.21" y2="17.78" width="0.6096" layer="16"/>
<wire x1="29.21" y1="17.78" x2="33.02" y2="21.59" width="0.6096" layer="16"/>
<wire x1="22.86" y1="11.43" x2="24.765" y2="9.525" width="0.6096" layer="16"/>
<wire x1="24.765" y1="9.525" x2="27.305" y2="9.525" width="0.6096" layer="16"/>
<wire x1="27.305" y1="9.525" x2="30.48" y2="12.7" width="0.6096" layer="16"/>
<wire x1="22.86" y1="11.43" x2="21.59" y2="11.43" width="0.6096" layer="1"/>
<wire x1="21.59" y1="11.43" x2="21.27" y2="11.11" width="0.6096" layer="1"/>
<wire x1="21.27" y1="11.11" x2="20.15" y2="11.11" width="0.6096" layer="1"/>
<contactref element="IC3" pad="8"/>
<contactref element="C5" pad="2"/>
<contactref element="C4" pad="2"/>
<contactref element="IC3" pad="22"/>
<contactref element="R35" pad="1"/>
<contactref element="S1" pad="3"/>
<contactref element="S1" pad="4"/>
<contactref element="S4" pad="5"/>
<wire x1="10.4394" y1="17.0688" x2="10.4394" y2="9.8806" width="0.4064" layer="16"/>
<wire x1="10.4394" y1="23.5712" x2="10.4394" y2="17.0688" width="0.3048" layer="16"/>
<contactref element="R27" pad="1"/>
<contactref element="C11" pad="-"/>
<contactref element="C15" pad="2"/>
<contactref element="TP5" pad="MP"/>
<contactref element="C17" pad="-"/>
<contactref element="R40" pad="1"/>
<contactref element="C21" pad="2"/>
<contactref element="C22" pad="-"/>
<contactref element="J1" pad="3"/>
<contactref element="C24" pad="2"/>
<contactref element="C14" pad="-"/>
<contactref element="R31" pad="1"/>
<contactref element="C13" pad="2"/>
<contactref element="D8" pad="A"/>
<contactref element="R33" pad="1"/>
<contactref element="U$5" pad="4"/>
<contactref element="C12" pad="2"/>
<contactref element="U$5" pad="2"/>
<contactref element="C20" pad="2"/>
<contactref element="U$6" pad="2"/>
<contactref element="U$6" pad="4"/>
<contactref element="U$7" pad="2"/>
<contactref element="R15" pad="1"/>
<contactref element="C7" pad="-"/>
<contactref element="C23" pad="-"/>
<contactref element="C10" pad="2"/>
<contactref element="IC2" pad="2"/>
<contactref element="C18" pad="2"/>
<contactref element="C19" pad="-"/>
<contactref element="C9" pad="-"/>
<wire x1="47.625" y1="7.62" x2="48.895" y2="6.35" width="0.6096" layer="1"/>
<wire x1="47.625" y1="13.335" x2="47.625" y2="7.62" width="0.6096" layer="1"/>
<wire x1="46.99" y1="13.97" x2="47.625" y2="13.335" width="0.6096" layer="1"/>
<wire x1="45.85" y1="13.97" x2="46.99" y2="13.97" width="0.6096" layer="1"/>
<wire x1="48.895" y1="6.35" x2="53.975" y2="6.35" width="0.6096" layer="1"/>
<wire x1="53.975" y1="6.35" x2="55.245" y2="7.62" width="0.6096" layer="1"/>
<via x="55.245" y="7.62" extent="1-16" drill="0.8" shape="octagon"/>
<wire x1="55.245" y1="7.62" x2="56.515" y2="8.89" width="0.6096" layer="16"/>
<wire x1="56.515" y1="8.89" x2="67.31" y2="8.89" width="0.6096" layer="16"/>
<wire x1="67.31" y1="8.89" x2="70.31" y2="11.89" width="0.6096" layer="16"/>
<wire x1="70.31" y1="11.89" x2="70.31" y2="13.97" width="0.6096" layer="16"/>
<contactref element="X1" pad="1"/>
<contactref element="X2" pad="1"/>
<wire x1="35.56" y1="33.02" x2="38.23" y2="10.16" width="0" layer="19" extent="1-1"/>
<wire x1="43.18" y1="38.1" x2="38.23" y2="10.16" width="0" layer="19" extent="1-1"/>
<wire x1="39.71" y1="24.13" x2="35.56" y2="33.02" width="0" layer="19" extent="1-1"/>
<wire x1="50.8" y1="45.72" x2="43.18" y2="38.1" width="0" layer="19" extent="1-1"/>
<wire x1="54.4576" y1="25.4" x2="50.8" y2="45.72" width="0" layer="19" extent="1-1"/>
<wire x1="33.02" y1="25.4" x2="39.71" y2="24.13" width="0" layer="19" extent="1-1"/>
<wire x1="29.21" y1="20.32" x2="33.02" y2="25.4" width="0" layer="19" extent="1-1"/>
<wire x1="29.21" y1="25.4" x2="29.21" y2="20.32" width="0" layer="19" extent="1-1"/>
<wire x1="38.44" y1="25.4" x2="29.21" y2="25.4" width="0" layer="19" extent="1-1"/>
<wire x1="30.61" y1="26.67" x2="38.44" y2="25.4" width="0" layer="19" extent="1-1"/>
<wire x1="34.42" y1="20.32" x2="30.61" y2="26.67" width="0" layer="19" extent="1-1"/>
<wire x1="26.67" y1="19.05" x2="38.44" y2="25.4" width="0" layer="19" extent="1-1"/>
<wire x1="43.18" y1="31.75" x2="26.67" y2="19.05" width="0" layer="19" extent="1-1"/>
<wire x1="40.64" y1="39.37" x2="43.18" y2="31.75" width="0" layer="19" extent="1-1"/>
<wire x1="10.4394" y1="9.8806" x2="40.64" y2="39.37" width="0" layer="19" extent="16-16"/>
<wire x1="20.15" y1="11.11" x2="10.4394" y2="9.8806" width="0" layer="19" extent="1-16"/>
<wire x1="36.41" y1="38.1" x2="36.195" y2="37.885" width="0" layer="19" extent="1-1"/>
<wire x1="36.41" y1="40.64" x2="36.41" y2="38.1" width="0" layer="19" extent="1-1"/>
<wire x1="45.85" y1="13.97" x2="45.72" y2="19.05" width="0" layer="19" extent="1-16"/>
<wire x1="58.268" y1="39.37" x2="54.4576" y2="25.4" width="0" layer="19" extent="1-1"/>
<wire x1="43.18" y1="26.67" x2="58.268" y2="39.37" width="0" layer="19" extent="1-1"/>
<wire x1="43.18" y1="21.59" x2="43.18" y2="26.67" width="0" layer="19" extent="1-1"/>
<wire x1="47.33" y1="34.29" x2="43.18" y2="21.59" width="0" layer="19" extent="1-1"/>
<wire x1="25.4" y1="10.16" x2="47.33" y2="34.29" width="0" layer="19" extent="1-1"/>
<wire x1="35.69" y1="24.13" x2="25.4" y2="10.16" width="0" layer="19" extent="1-1"/>
<wire x1="45.85" y1="21.59" x2="35.69" y2="24.13" width="0" layer="19" extent="1-1"/>
<wire x1="43.52" y1="21.59" x2="45.85" y2="21.59" width="0" layer="19" extent="1-1"/>
<wire x1="38.1" y1="29.21" x2="43.52" y2="21.59" width="0" layer="19" extent="1-1"/>
<wire x1="25.74" y1="27.94" x2="38.1" y2="29.21" width="0" layer="19" extent="1-1"/>
<wire x1="14.31" y1="21.59" x2="25.74" y2="27.94" width="0" layer="19" extent="1-1"/>
<wire x1="21.59" y1="33.02" x2="14.31" y2="21.59" width="0" layer="19" extent="1-1"/>
<wire x1="34.29" y1="24.13" x2="21.59" y2="33.02" width="0" layer="19" extent="1-1"/>
<wire x1="31.75" y1="19.05" x2="34.29" y2="24.13" width="0" layer="19" extent="1-1"/>
<wire x1="62.23" y1="33.02" x2="31.75" y2="19.05" width="0" layer="19" extent="1-1"/>
<wire x1="43.52" y1="33.02" x2="62.23" y2="33.02" width="0" layer="19" extent="1-1"/>
<wire x1="48.6" y1="41.91" x2="43.52" y2="33.02" width="0" layer="19" extent="1-1"/>
<wire x1="24.13" y1="20.76" x2="48.6" y2="41.91" width="0" layer="19" extent="1-1"/>
<wire x1="10.16" y1="19.49" x2="24.13" y2="20.76" width="0" layer="19" extent="1-1"/>
<wire x1="50.8" y1="16.51" x2="24.13" y2="20.76" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="VCC">
<contactref element="JP1" pad="2"/>
<contactref element="R9" pad="1"/>
<contactref element="LCD1" pad="2"/>
<contactref element="R12" pad="1"/>
<contactref element="D1" pad="1"/>
<contactref element="R17" pad="2"/>
<contactref element="C3" pad="1"/>
<vertex x="40.005" y="15.875"/>
<vertex x="33.655" y="15.875"/>
<vertex x="33.655" y="19.05"/>
<vertex x="40.005" y="19.05"/>
</polygon>
<wire x1="34.36" y1="53.905" x2="34.075" y2="54.19" width="0.508" layer="1"/>
<wire x1="34.075" y1="54.19" x2="34.075" y2="55.88" width="0.508" layer="1"/>
<wire x1="39.37" y1="71.12" x2="40.64" y2="69.85" width="0.4064" layer="16"/>
<wire x1="40.64" y1="69.85" x2="50.165" y2="69.85" width="0.4064" layer="16"/>
<wire x1="50.165" y1="69.85" x2="57.15" y2="69.85" width="0.4064" layer="16"/>
<via x="44.45" y="61.595" extent="1-16" drill="0.8" shape="octagon"/>
<wire x1="44.45" y1="61.595" x2="36.83" y2="61.595" width="0.4064" layer="1"/>
<wire x1="36.83" y1="61.595" x2="34.29" y2="59.055" width="0.4064" layer="1"/>
<wire x1="34.29" y1="59.055" x2="34.29" y2="56.095" width="0.4064" layer="1"/>
<wire x1="34.29" y1="56.095" x2="34.075" y2="55.88" width="0.4064" layer="1"/>
<wire x1="44.45" y1="61.595" x2="48.895" y2="61.595" width="0.6096" layer="16"/>
<wire x1="48.895" y1="61.595" x2="50.165" y2="62.865" width="0.6096" layer="16"/>
<wire x1="50.165" y1="62.865" x2="50.165" y2="69.85" width="0.6096" layer="16"/>
<wire x1="44.45" y1="61.595" x2="44.45" y2="21.59" width="0.6096" layer="16"/>
<wire x1="44.45" y1="21.59" x2="39.37" y2="16.51" width="0.6096" layer="16"/>
<wire x1="39.37" y1="16.51" x2="30.48" y2="16.51" width="0.6096" layer="16"/>
<via x="30.48" y="16.51" extent="1-16" drill="0.8" shape="octagon"/>
<wire x1="30.48" y1="16.51" x2="31.75" y2="16.51" width="0.8128" layer="16"/>
<wire x1="55.245" y1="25.248" x2="58.42" y2="25.248" width="0.4064" layer="1"/>
<wire x1="58.42" y1="25.248" x2="58.42" y2="25.27" width="0.4064" layer="1"/>
<wire x1="49.682" y1="29.21" x2="49.682" y2="28.092" width="0.4064" layer="1"/>
<wire x1="49.682" y1="28.092" x2="48.895" y2="27.305" width="0.4064" layer="1"/>
<wire x1="48.895" y1="27.305" x2="48.895" y2="21.59" width="0.4064" layer="1"/>
<wire x1="48.895" y1="21.59" x2="49.53" y2="20.955" width="0.4064" layer="1"/>
<wire x1="55.245" y1="25.248" x2="55.245" y2="22.225" width="0.4064" layer="1"/>
<wire x1="49.53" y1="20.955" x2="52.705" y2="20.955" width="0.4064" layer="1"/>
<wire x1="52.705" y1="20.955" x2="53.975" y2="22.225" width="0.4064" layer="1"/>
<wire x1="30.48" y1="16.51" x2="34.29" y2="16.51" width="0.8128" layer="1"/>
<wire x1="29.21" y1="16.51" x2="29.21" y2="22.708" width="0.4064" layer="1"/>
<wire x1="27.94" y1="15.24" x2="29.21" y2="16.51" width="0.4064" layer="1"/>
<wire x1="29.21" y1="16.51" x2="30.48" y2="16.51" width="0.4064" layer="1"/>
<wire x1="53.975" y1="22.225" x2="55.245" y2="22.225" width="0.4064" layer="1"/>
<contactref element="R18" pad="2"/>
<wire x1="57.15" y1="6.35" x2="55.88" y2="5.08" width="0.4064" layer="1"/>
<wire x1="55.88" y1="5.08" x2="29.21" y2="5.08" width="0.4064" layer="1"/>
<wire x1="57.15" y1="6.35" x2="57.15" y2="15.24" width="0.4064" layer="1"/>
<wire x1="57.15" y1="15.24" x2="55.728" y2="16.358" width="0.4064" layer="1"/>
<wire x1="55.728" y1="16.358" x2="55.728" y2="19.05" width="0.4064" layer="1"/>
<wire x1="27.94" y1="6.35" x2="29.21" y2="5.08" width="0.4064" layer="1"/>
<contactref element="IC3" pad="7"/>
<contactref element="K1" pad="16"/>
<contactref element="D3" pad="1"/>
<wire x1="10.29" y1="68.58" x2="11.43" y2="68.58" width="0.6096" layer="16"/>
<wire x1="11.43" y1="68.58" x2="12.7" y2="69.85" width="0.6096" layer="16"/>
<wire x1="12.7" y1="69.85" x2="12.7" y2="71.12" width="0.6096" layer="16"/>
<wire x1="12.7" y1="71.12" x2="16.51" y2="71.12" width="0.6096" layer="16"/>
<wire x1="16.51" y1="71.12" x2="19.05" y2="73.66" width="0.6096" layer="16"/>
<wire x1="19.05" y1="73.66" x2="50.013" y2="73.66" width="0.6096" layer="16"/>
<contactref element="S3" pad="2"/>
<contactref element="R37" pad="3"/>
<contactref element="C22" pad="+"/>
<contactref element="D9" pad="C"/>
<contactref element="R41" pad="2"/>
<contactref element="C21" pad="1"/>
<contactref element="R10" pad="2"/>
<contactref element="X2" pad="2"/>
<wire x1="43.05" y1="21.59" x2="47.92" y2="21.59" width="0" layer="19" extent="1-1"/>
<wire x1="36.83" y1="38.1" x2="47.92" y2="21.59" width="0" layer="19" extent="1-1"/>
<wire x1="43.18" y1="27.94" x2="36.83" y2="38.1" width="0" layer="19" extent="1-1"/>
<wire x1="39.37" y1="30.48" x2="43.18" y2="27.94" width="0" layer="19" extent="1-1"/>
<wire x1="39.37" y1="21.59" x2="39.37" y2="30.48" width="0" layer="19" extent="1-1"/>
<wire x1="5.61" y1="16.19" x2="47.92" y2="21.59" width="0" layer="19" extent="1-1"/>
<wire x1="40.64" y1="31.75" x2="39.37" y2="21.59" width="0" layer="19" extent="1-1"/>
<wire x1="29.21" y1="5.08" x2="40.64" y2="31.75" width="0" layer="19" extent="1-1"/>
<wire x1="55.728" y1="22.225" x2="55.728" y2="19.05" width="0" layer="19" extent="1-1"/>
<wire x1="55.245" y1="22.225" x2="55.728" y2="22.225" width="0" layer="19" extent="1-1"/>
<wire x1="44.45" y1="21.59" x2="48.895" y2="21.59" width="0" layer="19" extent="1-16"/>
<wire x1="50.013" y1="73.66" x2="50.165" y2="69.85" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$1">
<contactref element="JP1" pad="3"/>
<contactref element="R6" pad="1"/>
<wire x1="29.9974" y1="43.9674" x2="27.94" y2="41.91" width="0.508" layer="1"/>
<wire x1="27.94" y1="41.91" x2="18.415" y2="32.385" width="0.508" layer="1"/>
<wire x1="18.415" y1="32.385" x2="15.555" y2="32.385" width="0.508" layer="1"/>
<wire x1="41.91" y1="68.58" x2="41.91" y2="66.04" width="0.4064" layer="16"/>
<wire x1="41.91" y1="66.04" x2="39.37" y2="63.5" width="0.4064" layer="16"/>
<wire x1="39.37" y1="63.5" x2="29.21" y2="63.5" width="0.4064" layer="16"/>
<wire x1="29.21" y1="63.5" x2="27.94" y2="62.23" width="0.4064" layer="16"/>
<wire x1="27.94" y1="62.23" x2="27.94" y2="41.91" width="0.4064" layer="16"/>
<via x="27.94" y="41.91" extent="1-16" drill="0.8" shape="octagon"/>
<contactref element="IC3" pad="19"/>
<wire x1="48.26" y1="39.37" x2="18.415" y2="32.385" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$2">
<contactref element="JP1" pad="1"/>
<contactref element="R5" pad="1"/>
<wire x1="28.95" y1="45.46" x2="26.67" y2="43.18" width="0.508" layer="1"/>
<wire x1="26.67" y1="43.18" x2="19.05" y2="35.56" width="0.508" layer="1"/>
<wire x1="19.05" y1="35.56" x2="16.74" y2="35.56" width="0.508" layer="1"/>
<wire x1="39.37" y1="68.58" x2="39.37" y2="66.04" width="0.4064" layer="16"/>
<wire x1="39.37" y1="66.04" x2="38.1" y2="64.77" width="0.4064" layer="16"/>
<wire x1="38.1" y1="64.77" x2="28.575" y2="64.77" width="0.4064" layer="16"/>
<wire x1="28.575" y1="64.77" x2="26.67" y2="62.865" width="0.4064" layer="16"/>
<wire x1="26.67" y1="62.865" x2="26.67" y2="43.18" width="0.4064" layer="16"/>
<via x="26.67" y="43.18" extent="1-16" drill="0.8" shape="octagon"/>
<contactref element="IC3" pad="18"/>
<wire x1="50.8" y1="39.37" x2="19.05" y2="35.56" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$3">
<contactref element="JP1" pad="4"/>
<contactref element="R4" pad="1"/>
<wire x1="27.21" y1="46.26" x2="25.4" y2="44.45" width="0.508" layer="1"/>
<wire x1="25.4" y1="44.45" x2="19.685" y2="38.735" width="0.508" layer="1"/>
<wire x1="19.685" y1="38.735" x2="15.555" y2="38.735" width="0.508" layer="1"/>
<wire x1="41.91" y1="71.12" x2="40.64" y2="72.39" width="0.4064" layer="16"/>
<wire x1="40.64" y1="72.39" x2="26.67" y2="72.39" width="0.4064" layer="16"/>
<wire x1="26.67" y1="72.39" x2="25.4" y2="71.12" width="0.4064" layer="16"/>
<wire x1="25.4" y1="71.12" x2="25.4" y2="44.45" width="0.4064" layer="16"/>
<via x="25.4" y="44.45" extent="1-16" drill="0.8" shape="octagon"/>
<contactref element="IC3" pad="17"/>
<wire x1="53.34" y1="39.37" x2="19.685" y2="38.735" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$4">
<contactref element="TP1" pad="MP"/>
<contactref element="R1" pad="2"/>
<contactref element="R2" pad="2"/>
<via x="38.1" y="35.56" extent="1-16" drill="0.8" shape="octagon"/>
<wire x1="38.1" y1="35.56" x2="22.86" y2="35.56" width="0.6096" layer="16"/>
<wire x1="37.56" y1="42.45" x2="39.37" y2="40.64" width="0.508" layer="1"/>
<wire x1="39.37" y1="40.64" x2="39.37" y2="36.83" width="0.508" layer="1"/>
<wire x1="39.37" y1="36.83" x2="38.1" y2="35.56" width="0.508" layer="1"/>
<wire x1="13.183" y1="48.26" x2="13.74" y2="48.26" width="0.8128" layer="1"/>
<wire x1="22.86" y1="35.56" x2="10.16" y2="48.26" width="0.6096" layer="16"/>
<via x="10.16" y="48.26" extent="1-16" drill="0.8" shape="octagon"/>
<wire x1="10.16" y1="48.26" x2="13.74" y2="48.26" width="0.8128" layer="1"/>
<wire x1="6.35" y1="48.26" x2="10.16" y2="48.26" width="0.8128" layer="16"/>
<contactref element="K1" pad="P1"/>
<contactref element="K1" pad="P2"/>
<wire x1="12.7" y1="63.5" x2="5.08" y2="63.5" width="0.6096" layer="16"/>
<wire x1="14.605" y1="63.5" x2="15.875" y2="62.23" width="0.6096" layer="16"/>
<wire x1="15.875" y1="62.23" x2="15.875" y2="52.07" width="0.6096" layer="16"/>
<wire x1="15.875" y1="52.07" x2="14.605" y2="50.8" width="0.6096" layer="16"/>
<wire x1="14.605" y1="50.8" x2="8.89" y2="50.8" width="0.6096" layer="16"/>
<wire x1="14.605" y1="63.5" x2="12.7" y2="63.5" width="0.6096" layer="16"/>
<wire x1="8.89" y1="50.8" x2="6.35" y2="48.26" width="0.6096" layer="16"/>
<wire x1="13.655" y1="45.085" x2="12.065" y2="45.085" width="0.6096" layer="1"/>
<wire x1="12.065" y1="45.085" x2="10.16" y2="46.99" width="0.6096" layer="1"/>
<wire x1="10.16" y1="46.99" x2="10.16" y2="48.26" width="0.6096" layer="1"/>
<wire x1="10.16" y1="48.26" x2="6.35" y2="48.26" width="0.8128" layer="1"/>
<contactref element="IC3" pad="23"/>
<wire x1="38.1" y1="39.37" x2="22.86" y2="35.56" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$5">
<contactref element="TP2" pad="MP"/>
<contactref element="R3" pad="2"/>
<contactref element="R4" pad="2"/>
<wire x1="13.183" y1="41.91" x2="13.74" y2="41.91" width="0.8128" layer="1"/>
<wire x1="39.8526" y1="43.9674" x2="41.275" y2="42.545" width="0.508" layer="1"/>
<via x="39.37" y="33.655" extent="1-16" drill="0.8" shape="octagon"/>
<wire x1="39.37" y1="33.655" x2="18.415" y2="33.655" width="0.6096" layer="16"/>
<wire x1="41.275" y1="42.545" x2="41.275" y2="35.56" width="0.508" layer="1"/>
<wire x1="41.275" y1="35.56" x2="39.37" y2="33.655" width="0.508" layer="1"/>
<wire x1="18.415" y1="33.655" x2="10.16" y2="41.91" width="0.6096" layer="16"/>
<via x="10.16" y="41.91" extent="1-16" drill="0.8" shape="octagon"/>
<wire x1="10.16" y1="41.91" x2="13.74" y2="41.91" width="0.8128" layer="1"/>
<wire x1="6.35" y1="41.91" x2="10.16" y2="41.91" width="0.8128" layer="16"/>
<contactref element="K1" pad="O2"/>
<wire x1="12.7" y1="58.42" x2="10.16" y2="58.42" width="0.6096" layer="16"/>
<wire x1="10.16" y1="58.42" x2="8.89" y2="57.15" width="0.6096" layer="16"/>
<wire x1="8.89" y1="57.15" x2="8.89" y2="53.34" width="0.6096" layer="16"/>
<wire x1="8.89" y1="53.34" x2="6.35" y2="50.8" width="0.6096" layer="16"/>
<wire x1="6.35" y1="50.8" x2="5.08" y2="50.8" width="0.6096" layer="16"/>
<wire x1="5.08" y1="50.8" x2="3.81" y2="49.53" width="0.6096" layer="16"/>
<wire x1="3.81" y1="49.53" x2="3.81" y2="44.45" width="0.6096" layer="16"/>
<wire x1="3.81" y1="44.45" x2="6.35" y2="41.91" width="0.6096" layer="16"/>
<wire x1="13.655" y1="38.735" x2="12.065" y2="38.735" width="0.6096" layer="1"/>
<wire x1="12.065" y1="38.735" x2="10.16" y2="40.64" width="0.6096" layer="1"/>
<wire x1="10.16" y1="40.64" x2="10.16" y2="41.91" width="0.6096" layer="1"/>
<wire x1="10.16" y1="41.91" x2="6.35" y2="41.91" width="0.8128" layer="1"/>
<contactref element="IC3" pad="24"/>
<wire x1="35.56" y1="39.37" x2="18.415" y2="33.655" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$6">
<contactref element="R5" pad="2"/>
<contactref element="TP3" pad="MP"/>
<contactref element="R6" pad="2"/>
<wire x1="13.183" y1="35.56" x2="13.74" y2="35.56" width="0.8128" layer="1"/>
<wire x1="41.535" y1="45.46" x2="42.545" y2="44.45" width="0.508" layer="1"/>
<via x="38.1" y="31.75" extent="1-16" drill="0.8" shape="octagon"/>
<wire x1="38.1" y1="31.75" x2="13.97" y2="31.75" width="0.6096" layer="16"/>
<wire x1="42.545" y1="44.45" x2="42.545" y2="33.655" width="0.508" layer="1"/>
<wire x1="42.545" y1="33.655" x2="40.64" y2="31.75" width="0.508" layer="1"/>
<wire x1="40.64" y1="31.75" x2="38.1" y2="31.75" width="0.508" layer="1"/>
<wire x1="13.97" y1="31.75" x2="10.16" y2="35.56" width="0.6096" layer="16"/>
<via x="10.16" y="35.56" extent="1-16" drill="0.8" shape="octagon"/>
<wire x1="10.16" y1="35.56" x2="13.74" y2="35.56" width="0.8128" layer="1"/>
<wire x1="6.35" y1="35.56" x2="10.16" y2="35.56" width="0.8128" layer="16"/>
<contactref element="K1" pad="O1"/>
<wire x1="5.08" y1="58.42" x2="3.175" y2="58.42" width="0.6096" layer="16"/>
<wire x1="3.175" y1="58.42" x2="1.905" y2="57.15" width="0.6096" layer="16"/>
<wire x1="1.905" y1="57.15" x2="1.905" y2="40.005" width="0.6096" layer="16"/>
<wire x1="1.905" y1="40.005" x2="6.35" y2="35.56" width="0.6096" layer="16"/>
<wire x1="13.655" y1="32.385" x2="12.065" y2="32.385" width="0.6096" layer="1"/>
<wire x1="12.065" y1="32.385" x2="10.16" y2="34.29" width="0.6096" layer="1"/>
<wire x1="10.16" y1="34.29" x2="10.16" y2="35.56" width="0.6096" layer="1"/>
<wire x1="10.16" y1="35.56" x2="6.35" y2="35.56" width="0.8128" layer="1"/>
<contactref element="IC3" pad="25"/>
<wire x1="13.97" y1="31.75" x2="33.02" y2="39.37" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$7">
<contactref element="R1" pad="1"/>
<wire x1="17.78" y1="48.26" x2="16.74" y2="48.26" width="0.4064" layer="1"/>
<wire x1="21.825" y1="48.66" x2="21.425" y2="48.26" width="0.508" layer="1"/>
<wire x1="21.425" y1="48.26" x2="16.74" y2="48.26" width="0.508" layer="1"/>
<contactref element="IC3" pad="14"/>
<wire x1="58.42" y1="31.75" x2="21.425" y2="48.26" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$8">
<contactref element="R2" pad="1"/>
<wire x1="23.73" y1="47.86" x2="20.955" y2="45.085" width="0.508" layer="1"/>
<wire x1="20.955" y1="45.085" x2="15.555" y2="45.085" width="0.508" layer="1"/>
<contactref element="IC3" pad="15"/>
<wire x1="58.42" y1="39.37" x2="20.955" y2="45.085" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$9">
<contactref element="R3" pad="1"/>
<wire x1="25.47" y1="47.06" x2="20.32" y2="41.91" width="0.508" layer="1"/>
<wire x1="20.32" y1="41.91" x2="16.74" y2="41.91" width="0.508" layer="1"/>
<contactref element="IC3" pad="16"/>
<wire x1="55.88" y1="39.37" x2="20.32" y2="41.91" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$10">
<contactref element="TL431" pad="8"/>
<contactref element="R9" pad="2"/>
<wire x1="45.085" y1="45.72" x2="43.745" y2="47.06" width="0.4064" layer="1"/>
<wire x1="45.085" y1="45.72" x2="45.085" y2="29.21" width="0.4064" layer="1"/>
<wire x1="45.085" y1="29.21" x2="46.838" y2="29.21" width="0.4064" layer="1"/>
<wire x1="45.66" y1="22.225" x2="44.45" y2="22.225" width="0.4064" layer="1"/>
<wire x1="44.45" y1="22.225" x2="43.815" y2="22.86" width="0.4064" layer="1"/>
<contactref element="R20" pad="1"/>
<wire x1="43.815" y1="22.86" x2="43.815" y2="23.495" width="0.4064" layer="1"/>
<wire x1="43.815" y1="23.495" x2="43.815" y2="26.67" width="0.4064" layer="1"/>
<wire x1="43.815" y1="26.67" x2="45.085" y2="27.94" width="0.4064" layer="1"/>
<wire x1="45.085" y1="27.94" x2="45.085" y2="29.21" width="0.4064" layer="1"/>
<via x="38.735" y="23.495" extent="1-16" drill="0.8" shape="octagon"/>
<wire x1="38.735" y1="23.495" x2="26.035" y2="23.495" width="0.4064" layer="16"/>
<wire x1="38.735" y1="23.495" x2="43.815" y2="23.495" width="0.4064" layer="1"/>
<via x="25.4" y="11.43" extent="1-16" drill="0.8" shape="octagon"/>
<wire x1="25.4" y1="11.43" x2="25.4" y2="22.86" width="0.4064" layer="16"/>
<wire x1="25.4" y1="22.86" x2="26.035" y2="23.495" width="0.4064" layer="16"/>
<wire x1="25.4" y1="11.43" x2="25.4" y2="9.042" width="0.4064" layer="1"/>
<wire x1="25.4" y1="9.042" x2="25.552" y2="8.89" width="0.4064" layer="1"/>
<contactref element="IC3" pad="27"/>
<wire x1="25.552" y1="8.89" x2="27.94" y2="39.37" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$11">
<contactref element="R7" pad="2"/>
<contactref element="R8" pad="2"/>
<wire x1="49.682" y1="36.195" x2="49.682" y2="33.02" width="0.4064" layer="1"/>
<wire x1="49.682" y1="36.195" x2="49.53" y2="36.195" width="0.4064" layer="1"/>
<wire x1="48.26" y1="38.252" x2="48.26" y2="41.91" width="0.4064" layer="1"/>
<wire x1="48.26" y1="41.91" x2="46.99" y2="43.18" width="0.4064" layer="1"/>
<wire x1="46.99" y1="43.18" x2="46.99" y2="45.72" width="0.4064" layer="1"/>
<wire x1="46.99" y1="45.72" x2="44.85" y2="47.86" width="0.4064" layer="1"/>
<wire x1="48.26" y1="38.252" x2="49.682" y2="36.83" width="0.4064" layer="1"/>
<wire x1="49.682" y1="36.83" x2="49.682" y2="36.195" width="0.4064" layer="1"/>
<contactref element="IC3" pad="28"/>
<wire x1="25.4" y1="39.37" x2="49.682" y2="33.02" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$13">
<contactref element="LCD1" pad="12"/>
<wire x1="48.165" y1="50.26" x2="49.53" y2="48.895" width="0.4064" layer="1"/>
<wire x1="49.53" y1="48.895" x2="49.53" y2="45.72" width="0.4064" layer="1"/>
<wire x1="49.53" y1="45.72" x2="50.8" y2="44.45" width="0.4064" layer="16"/>
<wire x1="50.8" y1="44.45" x2="57.15" y2="44.45" width="0.4064" layer="16"/>
<via x="49.53" y="45.72" extent="1-16" drill="0.8" shape="octagon"/>
<contactref element="IC3" pad="3"/>
<wire x1="30.48" y1="31.75" x2="50.8" y2="44.45" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$14">
<contactref element="LCD1" pad="13"/>
<wire x1="48.635" y1="51.06" x2="50.8" y2="48.895" width="0.4064" layer="1"/>
<wire x1="50.8" y1="48.895" x2="50.8" y2="43.18" width="0.4064" layer="1"/>
<wire x1="50.8" y1="43.18" x2="52.07" y2="41.91" width="0.4064" layer="16"/>
<wire x1="52.07" y1="41.91" x2="57.15" y2="41.91" width="0.4064" layer="16"/>
<via x="50.8" y="43.18" extent="1-16" drill="0.8" shape="octagon"/>
<contactref element="IC3" pad="4"/>
<wire x1="33.02" y1="31.75" x2="52.07" y2="41.91" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$15">
<contactref element="LCD1" pad="14"/>
<wire x1="48.4124" y1="52.5526" x2="52.07" y2="48.895" width="0.4064" layer="1"/>
<wire x1="52.07" y1="48.895" x2="52.07" y2="40.64" width="0.4064" layer="1"/>
<wire x1="52.07" y1="40.64" x2="53.34" y2="39.37" width="0.4064" layer="16"/>
<wire x1="53.34" y1="39.37" x2="57.15" y2="39.37" width="0.4064" layer="16"/>
<via x="52.07" y="40.64" extent="1-16" drill="0.8" shape="octagon"/>
<contactref element="IC3" pad="5"/>
<wire x1="35.56" y1="31.75" x2="53.34" y2="39.37" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$17">
<contactref element="LCD1" pad="6"/>
<wire x1="21.33" y1="51.06" x2="20.32" y2="52.07" width="0.4064" layer="1"/>
<wire x1="20.32" y1="52.07" x2="20.32" y2="71.12" width="0.4064" layer="1"/>
<wire x1="20.32" y1="71.12" x2="20.955" y2="71.755" width="0.4064" layer="1"/>
<wire x1="20.955" y1="71.755" x2="34.925" y2="71.755" width="0.4064" layer="1"/>
<wire x1="34.925" y1="71.755" x2="36.83" y2="73.66" width="0.4064" layer="1"/>
<wire x1="36.83" y1="73.66" x2="46.99" y2="73.66" width="0.4064" layer="1"/>
<wire x1="46.99" y1="73.66" x2="48.26" y2="72.39" width="0.4064" layer="1"/>
<wire x1="48.26" y1="72.39" x2="48.26" y2="68.58" width="0.4064" layer="1"/>
<wire x1="48.26" y1="68.58" x2="49.53" y2="67.31" width="0.4064" layer="1"/>
<via x="52.07" y="59.69" extent="1-16" drill="0.8" shape="octagon"/>
<wire x1="52.07" y1="59.69" x2="57.15" y2="59.69" width="0.4064" layer="16"/>
<wire x1="53.34" y1="62.865" x2="52.07" y2="61.595" width="0.4064" layer="1"/>
<wire x1="52.07" y1="61.595" x2="52.07" y2="59.69" width="0.4064" layer="1"/>
<wire x1="53.34" y1="62.865" x2="53.34" y2="66.04" width="0.4064" layer="1"/>
<wire x1="53.34" y1="66.04" x2="52.07" y2="67.31" width="0.4064" layer="1"/>
<wire x1="52.07" y1="67.31" x2="49.53" y2="67.31" width="0.4064" layer="1"/>
<contactref element="IC3" pad="11"/>
<wire x1="50.8" y1="31.75" x2="21.33" y2="51.06" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$18">
<contactref element="LCD1" pad="15"/>
<wire x1="57.15" y1="36.83" x2="51.435" y2="36.83" width="0.4064" layer="16"/>
<wire x1="51.435" y1="36.83" x2="50.165" y2="35.56" width="0.4064" layer="16"/>
<wire x1="50.165" y1="35.56" x2="50.165" y2="33.02" width="0.4064" layer="16"/>
<wire x1="50.165" y1="33.02" x2="51.435" y2="31.75" width="0.4064" layer="16"/>
<wire x1="51.435" y1="31.75" x2="60.325" y2="31.75" width="0.4064" layer="16"/>
<wire x1="65.405" y1="53.34" x2="62.23" y2="50.165" width="0.4064" layer="16"/>
<wire x1="62.23" y1="50.165" x2="62.23" y2="33.655" width="0.4064" layer="16"/>
<wire x1="62.23" y1="33.655" x2="60.325" y2="31.75" width="0.4064" layer="16"/>
</signal>
<signal name="N$19">
<contactref element="R11" pad="2"/>
<contactref element="LCD1" pad="3"/>
<wire x1="57.15" y1="67.31" x2="63.5" y2="67.31" width="0.4064" layer="16"/>
</signal>
<signal name="N$20">
<contactref element="Q1" pad="2"/>
<contactref element="C1" pad="1"/>
<wire x1="23.495" y1="65.535" x2="23.746" y2="65.786" width="0.4064" layer="1"/>
<wire x1="23.746" y1="65.786" x2="27.94" y2="65.786" width="0.4064" layer="1"/>
<wire x1="33.56" y1="53.435" x2="31.115" y2="55.88" width="0.4064" layer="1"/>
<wire x1="31.115" y1="55.88" x2="31.115" y2="64.77" width="0.4064" layer="1"/>
<wire x1="31.115" y1="64.77" x2="30.099" y2="65.786" width="0.4064" layer="1"/>
<wire x1="30.099" y1="65.786" x2="27.94" y2="65.786" width="0.4064" layer="1"/>
</signal>
<signal name="N$21">
<contactref element="Q1" pad="1"/>
<contactref element="C2" pad="1"/>
<wire x1="23.495" y1="56.385" x2="23.746" y2="56.134" width="0.4064" layer="1"/>
<wire x1="23.746" y1="56.134" x2="27.94" y2="56.134" width="0.4064" layer="1"/>
<wire x1="32.76" y1="52.965" x2="29.591" y2="56.134" width="0.4064" layer="1"/>
<wire x1="29.591" y1="56.134" x2="27.94" y2="56.134" width="0.4064" layer="1"/>
</signal>
<signal name="N$22">
<contactref element="JP1" pad="5"/>
<wire x1="44.45" y1="68.58" x2="46.99" y2="68.58" width="0.4064" layer="16"/>
<wire x1="46.99" y1="68.58" x2="48.26" y2="67.31" width="0.4064" layer="16"/>
<wire x1="48.26" y1="67.31" x2="48.26" y2="63.5" width="0.4064" layer="16"/>
<via x="48.26" y="63.5" extent="1-16" drill="0.8" shape="octagon"/>
<wire x1="48.26" y1="63.5" x2="48.26" y2="54.61" width="0.4064" layer="1"/>
<wire x1="48.26" y1="54.61" x2="53.34" y2="49.53" width="0.4064" layer="1"/>
<wire x1="53.34" y1="49.53" x2="53.34" y2="40.005" width="0.4064" layer="1"/>
<wire x1="53.34" y1="40.005" x2="52.705" y2="39.37" width="0.4064" layer="1"/>
<wire x1="53.34" y1="31.115" x2="53.34" y2="38.735" width="0.4064" layer="1"/>
<wire x1="53.34" y1="39.37" x2="53.34" y2="40.005" width="0.4064" layer="1"/>
<wire x1="52.705" y1="39.37" x2="53.34" y2="38.735" width="0.4064" layer="1"/>
<wire x1="53.34" y1="38.735" x2="53.34" y2="39.37" width="0.4064" layer="1"/>
<wire x1="53.34" y1="39.37" x2="52.705" y2="39.37" width="0.4064" layer="1"/>
<wire x1="53.34" y1="31.115" x2="55.245" y2="29.21" width="0.4064" layer="1"/>
<contactref element="D1" pad="2"/>
<contactref element="IC3" pad="1"/>
<contactref element="R12" pad="2"/>
<wire x1="58.42" y1="28.092" x2="58.42" y2="28.07" width="0.4064" layer="1"/>
<contactref element="C6" pad="1"/>
<wire x1="55.245" y1="28.092" x2="58.42" y2="28.07" width="0" layer="19" extent="1-1"/>
<wire x1="55.245" y1="29.21" x2="55.245" y2="28.092" width="0" layer="19" extent="1-1"/>
<wire x1="49.66" y1="39.37" x2="52.705" y2="39.37" width="0" layer="19" extent="1-1"/>
<wire x1="25.4" y1="31.75" x2="55.245" y2="28.092" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="+UB">
<contactref element="R8" pad="1"/>
<vertex x="52.705" y="15.875"/>
<vertex x="41.275" y="15.875"/>
<vertex x="41.275" y="19.05"/>
<vertex x="52.705" y="19.05"/>
</polygon>
<wire x1="46.99" y1="33.02" x2="46.838" y2="33.02" width="0.4064" layer="1"/>
<wire x1="46.838" y1="33.02" x2="46.838" y2="31.902" width="0.4064" layer="1"/>
<wire x1="46.838" y1="31.902" x2="48.26" y2="30.48" width="0.4064" layer="1"/>
<wire x1="48.26" y1="30.48" x2="48.26" y2="27.94" width="0.4064" layer="1"/>
<wire x1="48.26" y1="27.94" x2="47.625" y2="27.305" width="0.4064" layer="1"/>
<wire x1="47.625" y1="27.305" x2="47.625" y2="17.78" width="0.4064" layer="1"/>
<wire x1="47.625" y1="17.78" x2="50.8" y2="17.78" width="0.4064" layer="1"/>
<contactref element="S4" pad="2"/>
<contactref element="D10" pad="A"/>
<contactref element="C24" pad="1"/>
<contactref element="S6" pad="3"/>
<wire x1="38.1" y1="17.78" x2="45.72" y2="35.3568" width="0" layer="19" extent="1-1"/>
<wire x1="48.26" y1="16.51" x2="45.72" y2="35.3568" width="0" layer="19" extent="1-1"/>
<wire x1="49.6824" y1="25.4" x2="38.1" y2="17.78" width="0" layer="19" extent="1-1"/>
<wire x1="47.625" y1="17.78" x2="49.6824" y2="25.4" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$34">
<contactref element="S1" pad="2"/>
<contactref element="S1" pad="1"/>
<wire x1="17.46" y1="28.89" x2="14.9606" y2="26.3906" width="0.4064" layer="1"/>
<wire x1="14.9606" y1="26.3906" x2="14.9606" y2="23.5712" width="0.4064" layer="1"/>
<wire x1="14.9606" y1="17.0688" x2="14.9606" y2="23.5712" width="0.3048" layer="16"/>
<contactref element="S4" pad="6"/>
<contactref element="R17" pad="1"/>
<contactref element="IC3" pad="13"/>
<contactref element="R23" pad="1"/>
<contactref element="T6" pad="C"/>
<wire x1="20.39" y1="49.46" x2="17.78" y2="52.07" width="0.4064" layer="1"/>
<wire x1="17.78" y1="52.07" x2="17.78" y2="55.88" width="0.4064" layer="1"/>
<via x="17.78" y="55.88" extent="1-16" drill="0.8" shape="octagon"/>
<wire x1="17.78" y1="55.88" x2="17.78" y2="46.99" width="0.4064" layer="16"/>
<wire x1="17.78" y1="46.99" x2="26.67" y2="38.1" width="0.4064" layer="16"/>
<wire x1="26.67" y1="38.1" x2="40.64" y2="38.1" width="0.4064" layer="16"/>
<wire x1="40.64" y1="38.1" x2="41.91" y2="36.83" width="0.4064" layer="16"/>
<wire x1="41.91" y1="36.83" x2="41.91" y2="29.21" width="0.4064" layer="16"/>
<wire x1="41.91" y1="29.21" x2="40.64" y2="27.94" width="0.4064" layer="16"/>
<wire x1="40.64" y1="27.94" x2="29.21" y2="27.94" width="0.4064" layer="16"/>
<via x="29.21" y="27.94" extent="1-16" drill="0.8" shape="octagon"/>
<wire x1="29.21" y1="27.94" x2="29.21" y2="25.552" width="0.4064" layer="1"/>
<wire x1="17.46" y1="28.89" x2="29.21" y2="27.94" width="0" layer="19" extent="1-16"/>
<wire x1="31.75" y1="33.02" x2="14.9606" y2="17.0688" width="0" layer="19" extent="1-1"/>
<wire x1="31.75" y1="24.13" x2="31.75" y2="33.02" width="0" layer="19" extent="1-1"/>
<wire x1="55.88" y1="31.75" x2="31.75" y2="24.13" width="0" layer="19" extent="1-1"/>
<wire x1="54.4576" y1="21.3868" x2="55.88" y2="31.75" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$16">
<contactref element="LCD1" pad="11"/>
<wire x1="47.06" y1="49.46" x2="48.26" y2="48.26" width="0.4064" layer="1"/>
<wire x1="48.26" y1="48.26" x2="49.53" y2="46.99" width="0.4064" layer="16"/>
<wire x1="49.53" y1="46.99" x2="57.15" y2="46.99" width="0.4064" layer="16"/>
<via x="48.26" y="48.26" extent="1-16" drill="0.8" shape="octagon"/>
<contactref element="IC3" pad="2"/>
<wire x1="27.94" y1="31.75" x2="49.53" y2="46.99" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$24">
<contactref element="R18" pad="1"/>
<contactref element="R11" pad="3"/>
<wire x1="58.572" y1="19.05" x2="60.96" y2="19.05" width="0.4064" layer="1"/>
<wire x1="60.96" y1="19.05" x2="62.23" y2="20.32" width="0.4064" layer="1"/>
<wire x1="68.58" y1="64.77" x2="68.58" y2="61.595" width="0.4064" layer="16"/>
<wire x1="68.58" y1="61.595" x2="71.755" y2="58.42" width="0.4064" layer="16"/>
<wire x1="71.755" y1="58.42" x2="71.755" y2="52.07" width="0.4064" layer="16"/>
<wire x1="71.755" y1="52.07" x2="70.485" y2="50.8" width="0.4064" layer="16"/>
<wire x1="70.485" y1="50.8" x2="66.675" y2="50.8" width="0.4064" layer="16"/>
<wire x1="66.675" y1="50.8" x2="64.77" y2="48.895" width="0.4064" layer="16"/>
<wire x1="64.77" y1="48.895" x2="64.77" y2="31.75" width="0.4064" layer="16"/>
<wire x1="64.77" y1="31.75" x2="63.5" y2="30.48" width="0.4064" layer="16"/>
<wire x1="63.5" y1="30.48" x2="63.5" y2="21.59" width="0.4064" layer="16"/>
<wire x1="63.5" y1="21.59" x2="62.23" y2="20.32" width="0.4064" layer="16"/>
<via x="62.23" y="20.32" extent="1-16" drill="0.8" shape="octagon"/>
</signal>
<signal name="N$36">
<contactref element="R10" pad="1"/>
<wire x1="58.572" y1="22.225" x2="60.96" y2="22.225" width="0.4064" layer="1"/>
<wire x1="60.96" y1="22.225" x2="62.23" y2="23.495" width="0.4064" layer="1"/>
<wire x1="69.85" y1="58.42" x2="70.485" y2="57.785" width="0.4064" layer="16"/>
<wire x1="70.485" y1="57.785" x2="70.485" y2="52.705" width="0.4064" layer="16"/>
<wire x1="70.485" y1="52.705" x2="69.85" y2="52.07" width="0.4064" layer="16"/>
<wire x1="69.85" y1="52.07" x2="66.04" y2="52.07" width="0.4064" layer="16"/>
<wire x1="66.04" y1="52.07" x2="63.5" y2="49.53" width="0.4064" layer="16"/>
<wire x1="63.5" y1="49.53" x2="63.5" y2="33.02" width="0.4064" layer="16"/>
<wire x1="63.5" y1="33.02" x2="62.23" y2="31.75" width="0.4064" layer="16"/>
<wire x1="62.23" y1="31.75" x2="62.23" y2="23.495" width="0.4064" layer="16"/>
<via x="62.23" y="23.495" extent="1-16" drill="0.8" shape="octagon"/>
</signal>
<signal name="N$35">
<contactref element="IC3" pad="26"/>
<contactref element="R32" pad="1"/>
<contactref element="R33" pad="2"/>
<contactref element="C15" pad="1"/>
<contactref element="D8" pad="C"/>
<wire x1="35.43" y1="10.16" x2="33.02" y2="38.1" width="0" layer="19" extent="1-1"/>
<wire x1="38.1" y1="33.02" x2="35.43" y2="10.16" width="0" layer="19" extent="1-1"/>
<wire x1="49.53" y1="24.13" x2="38.1" y2="33.02" width="0" layer="19" extent="1-1"/>
<wire x1="30.48" y1="39.37" x2="49.53" y2="24.13" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$38">
<wire x1="33.655" y1="50.165" x2="33.655" y2="46.355" width="0.254" layer="1"/>
<wire x1="33.655" y1="46.355" x2="37.465" y2="46.355" width="0.254" layer="1"/>
<wire x1="37.465" y1="46.355" x2="37.465" y2="49.53" width="0.254" layer="1"/>
<wire x1="37.465" y1="49.53" x2="36.83" y2="50.165" width="0.254" layer="1"/>
<wire x1="36.83" y1="50.165" x2="33.655" y2="50.165" width="0.254" layer="1"/>
</signal>
<signal name="N$39">
<contactref element="T3" pad="1"/>
<contactref element="R20" pad="2"/>
<wire x1="22.708" y1="8.89" x2="21.59" y2="8.89" width="0.4064" layer="1"/>
<wire x1="21.59" y1="8.89" x2="21.27" y2="9.21" width="0.4064" layer="1"/>
<wire x1="21.27" y1="9.21" x2="20.15" y2="9.21" width="0.4064" layer="1"/>
</signal>
<signal name="N$41">
<contactref element="T3" pad="3"/>
<contactref element="K1" pad="1"/>
<contactref element="D3" pad="2"/>
<wire x1="7.49" y1="68.58" x2="5.08" y2="68.58" width="0.6096" layer="16"/>
<wire x1="5.08" y1="71.12" x2="5.08" y2="68.58" width="0.6096" layer="16"/>
<wire x1="5.08" y1="68.58" x2="5.08" y2="66.675" width="0.6096" layer="16"/>
<wire x1="5.08" y1="66.675" x2="6.35" y2="65.405" width="0.6096" layer="16"/>
<wire x1="6.35" y1="65.405" x2="16.51" y2="65.405" width="0.6096" layer="16"/>
<wire x1="16.51" y1="65.405" x2="17.78" y2="64.135" width="0.6096" layer="16"/>
<wire x1="17.78" y1="64.135" x2="17.78" y2="59.69" width="0.6096" layer="16"/>
<via x="17.78" y="59.69" extent="1-16" drill="0.8" shape="octagon"/>
<wire x1="17.78" y1="59.69" x2="15.875" y2="57.785" width="0.6096" layer="1"/>
<wire x1="15.875" y1="57.785" x2="15.875" y2="52.07" width="0.6096" layer="1"/>
<wire x1="15.875" y1="52.07" x2="14.605" y2="50.8" width="0.6096" layer="1"/>
<wire x1="14.605" y1="50.8" x2="4.445" y2="50.8" width="0.6096" layer="1"/>
<wire x1="4.445" y1="50.8" x2="3.175" y2="49.53" width="0.6096" layer="1"/>
<wire x1="3.175" y1="49.53" x2="3.175" y2="25.4" width="0.6096" layer="1"/>
<wire x1="3.175" y1="25.4" x2="4.445" y2="24.13" width="0.6096" layer="1"/>
<wire x1="4.445" y1="24.13" x2="6.35" y2="24.13" width="0.6096" layer="1"/>
<wire x1="6.35" y1="24.13" x2="7.62" y2="22.86" width="0.6096" layer="1"/>
<wire x1="7.62" y1="22.86" x2="7.62" y2="15.24" width="0.6096" layer="1"/>
<wire x1="7.62" y1="15.24" x2="10.16" y2="12.7" width="0.6096" layer="1"/>
<wire x1="10.16" y1="12.7" x2="13.97" y2="12.7" width="0.6096" layer="1"/>
<wire x1="13.97" y1="12.7" x2="16.51" y2="10.16" width="0.6096" layer="1"/>
<wire x1="16.51" y1="10.16" x2="17.95" y2="10.16" width="0.6096" layer="1"/>
</signal>
<signal name="N$28">
<contactref element="J1" pad="2"/>
<wire x1="68.58" y1="21.59" x2="67.31" y2="20.32" width="0.6096" layer="16"/>
<wire x1="67.31" y1="20.32" x2="67.31" y2="18.77" width="0.6096" layer="16"/>
<contactref element="G1" pad="-"/>
<wire x1="67.31" y1="18.77" x2="63.881" y2="34.29" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$42">
<contactref element="R26" pad="1"/>
<contactref element="M1" pad="2"/>
<contactref element="C8" pad="2"/>
<wire x1="31.75" y1="33.02" x2="29.21" y2="35.56" width="0" layer="19" extent="1-1"/>
<wire x1="35.56" y1="19.05" x2="31.75" y2="33.02" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$43">
<contactref element="C8" pad="1"/>
<contactref element="T4" pad="B"/>
<contactref element="R25" pad="1"/>
<wire x1="33.02" y1="19.05" x2="25.4" y2="26.67" width="0" layer="19" extent="1-1"/>
<wire x1="26.67" y1="27.94" x2="33.02" y2="19.05" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$44">
<contactref element="R24" pad="1"/>
<contactref element="T4" pad="C"/>
<contactref element="T6" pad="B"/>
<wire x1="24.13" y1="27.94" x2="25.4" y2="27.94" width="0" layer="19" extent="1-1"/>
<wire x1="34.29" y1="33.02" x2="24.13" y2="27.94" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$46">
<contactref element="R26" pad="2"/>
<contactref element="R23" pad="2"/>
<contactref element="R24" pad="2"/>
<contactref element="R25" pad="2"/>
<wire x1="27.94" y1="26.67" x2="31.75" y2="35.56" width="0" layer="19" extent="1-1"/>
<wire x1="27.94" y1="27.94" x2="27.94" y2="26.67" width="0" layer="19" extent="1-1"/>
<wire x1="34.29" y1="24.13" x2="27.94" y2="27.94" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$47">
<contactref element="M1" pad="1"/>
<contactref element="T6" pad="E"/>
<contactref element="T4" pad="E"/>
<wire x1="29.21" y1="27.94" x2="31.75" y2="35.56" width="0" layer="19" extent="1-1"/>
<wire x1="36.83" y1="33.02" x2="29.21" y2="27.94" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$23">
<contactref element="IC3" pad="20"/>
<contactref element="C5" pad="1"/>
<wire x1="45.72" y1="39.37" x2="34.71" y2="38.1" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$37">
<contactref element="IC3" pad="21"/>
<contactref element="C4" pad="1"/>
<wire x1="43.18" y1="39.37" x2="34.71" y2="40.64" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$40">
<contactref element="U$5" pad="8"/>
<contactref element="R22" pad="1"/>
<wire x1="36.83" y1="17.78" x2="36.83" y2="27.94" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$45">
<contactref element="R21" pad="2"/>
<contactref element="L1" pad="1"/>
<contactref element="R22" pad="2"/>
<contactref element="U$5" pad="7"/>
<wire x1="39.37" y1="17.78" x2="36.83" y2="25.4" width="0" layer="19" extent="1-1"/>
<wire x1="39.37" y1="13.97" x2="39.37" y2="17.78" width="0" layer="19" extent="1-1"/>
<wire x1="33.02" y1="17.78" x2="39.37" y2="13.97" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$48">
<contactref element="L1" pad="2"/>
<contactref element="U$5" pad="1"/>
<contactref element="D4" pad="A"/>
<wire x1="44.45" y1="39.37" x2="29.21" y2="27.94" width="0" layer="19" extent="1-1"/>
<wire x1="38.1" y1="17.78" x2="44.45" y2="39.37" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$52">
<contactref element="D4" pad="C"/>
<contactref element="R30" pad="1"/>
<contactref element="C14" pad="+"/>
<contactref element="D5" pad="A"/>
<contactref element="S2" pad="2"/>
<contactref element="C13" pad="1"/>
<wire x1="44.11" y1="24.13" x2="19.05" y2="25.4" width="0" layer="19" extent="1-1"/>
<wire x1="38.1" y1="22.86" x2="44.11" y2="24.13" width="0" layer="19" extent="1-1"/>
<wire x1="25.4" y1="48.26" x2="38.1" y2="22.86" width="0" layer="19" extent="1-1"/>
<wire x1="31.62" y1="20.32" x2="25.4" y2="48.26" width="0" layer="19" extent="1-1"/>
<wire x1="36.83" y1="39.37" x2="31.62" y2="20.32" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$53">
<contactref element="U$5" pad="5"/>
<contactref element="R27" pad="2"/>
<contactref element="R28" pad="1"/>
<contactref element="R29" pad="1"/>
<wire x1="49.53" y1="30.48" x2="36.83" y2="20.32" width="0" layer="19" extent="1-1"/>
<wire x1="26.67" y1="15.24" x2="49.53" y2="30.48" width="0" layer="19" extent="1-1"/>
<wire x1="29.21" y1="19.05" x2="26.67" y2="15.24" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$49">
<contactref element="R30" pad="2"/>
<contactref element="T7" pad="E"/>
<wire x1="27.94" y1="48.26" x2="53.02" y2="19.22" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$50">
<contactref element="D5" pad="C"/>
<contactref element="D6" pad="A"/>
<wire x1="60.96" y1="19.05" x2="30.48" y2="22.86" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$55">
<contactref element="D6" pad="C"/>
<contactref element="D7" pad="A"/>
<wire x1="39.37" y1="16.51" x2="53.34" y2="19.05" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$56">
<contactref element="T7" pad="B"/>
<contactref element="R31" pad="2"/>
<contactref element="D7" pad="C"/>
<wire x1="51.12" y1="19.22" x2="31.75" y2="16.51" width="0" layer="19" extent="1-1"/>
<wire x1="35.56" y1="25.4" x2="51.12" y2="19.22" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$58">
<contactref element="S2" pad="1"/>
<contactref element="R28" pad="2"/>
<wire x1="29.21" y1="15.24" x2="19.05" y2="29.4132" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$59">
<contactref element="R29" pad="2"/>
<contactref element="S2" pad="3"/>
<wire x1="52.07" y1="30.48" x2="19.05" y2="21.3868" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$57">
<contactref element="T7" pad="C"/>
<contactref element="R32" pad="2"/>
<contactref element="TP4" pad="MP"/>
<wire x1="52.07" y1="21.42" x2="52.07" y2="24.13" width="0" layer="19" extent="1-1"/>
<wire x1="44.45" y1="31.75" x2="52.07" y2="24.13" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$60">
<contactref element="R21" pad="1"/>
<contactref element="C11" pad="+"/>
<contactref element="U$5" pad="6"/>
<contactref element="S4" pad="3"/>
<wire x1="42.84" y1="25.4" x2="36.83" y2="22.86" width="0" layer="19" extent="1-1"/>
<wire x1="36.83" y1="13.97" x2="42.84" y2="25.4" width="0" layer="19" extent="1-1"/>
<wire x1="49.6824" y1="21.3868" x2="36.83" y2="22.86" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$62">
<contactref element="C16" pad="2"/>
<contactref element="R34" pad="1"/>
<wire x1="41.758" y1="25.4" x2="48.39" y2="26.67" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$63">
<contactref element="R36" pad="1"/>
<contactref element="R35" pad="2"/>
<contactref element="C16" pad="1"/>
<contactref element="LCD1" pad="4"/>
<contactref element="IC3" pad="6"/>
<wire x1="37.56" y1="53.6575" x2="38.5125" y2="54.61" width="0.4064" layer="1"/>
<wire x1="38.5125" y1="54.61" x2="45.72" y2="54.61" width="0.4064" layer="1"/>
<wire x1="45.72" y1="54.61" x2="46.99" y2="55.88" width="0.4064" layer="1"/>
<wire x1="46.99" y1="55.88" x2="46.99" y2="64.135" width="0.4064" layer="1"/>
<wire x1="46.99" y1="64.135" x2="47.625" y2="64.77" width="0.4064" layer="1"/>
<wire x1="47.625" y1="64.77" x2="52.07" y2="64.77" width="0.4064" layer="1"/>
<via x="52.07" y="64.77" extent="1-16" drill="0.8" shape="octagon"/>
<wire x1="52.07" y1="64.77" x2="57.15" y2="64.77" width="0.4064" layer="16"/>
<wire x1="45.59" y1="26.67" x2="35.408" y2="13.97" width="0" layer="19" extent="1-1"/>
<wire x1="61.112" y1="39.37" x2="45.59" y2="26.67" width="0" layer="19" extent="1-1"/>
<wire x1="38.1" y1="31.75" x2="61.112" y2="39.37" width="0" layer="19" extent="1-1"/>
<wire x1="37.56" y1="53.6575" x2="38.1" y2="31.75" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$64">
<contactref element="R36" pad="2"/>
<contactref element="R37" pad="1"/>
<contactref element="R37" pad="2"/>
<wire x1="34.29" y1="30.48" x2="36.83" y2="25.4" width="0" layer="19" extent="1-1"/>
<wire x1="38.252" y1="13.97" x2="36.83" y2="25.4" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$12">
<contactref element="U$6" pad="8"/>
<contactref element="R38" pad="1"/>
<wire x1="50.8" y1="29.21" x2="38.1" y2="19.05" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$25">
<contactref element="R39" pad="1"/>
<contactref element="C17" pad="+"/>
<contactref element="U$6" pad="6"/>
<contactref element="D10" pad="C"/>
<wire x1="25.4" y1="19.05" x2="30.48" y2="17.78" width="0" layer="19" extent="1-1"/>
<wire x1="51.73" y1="34.29" x2="25.4" y2="19.05" width="0" layer="19" extent="1-1"/>
<wire x1="50.8" y1="24.13" x2="25.4" y2="19.05" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$26">
<contactref element="R39" pad="2"/>
<contactref element="R38" pad="2"/>
<contactref element="U$6" pad="7"/>
<contactref element="L2" pad="1"/>
<wire x1="40.64" y1="19.05" x2="27.94" y2="19.05" width="0" layer="19" extent="1-1"/>
<wire x1="33.02" y1="19.05" x2="40.64" y2="19.05" width="0" layer="19" extent="1-1"/>
<wire x1="50.8" y1="26.67" x2="33.02" y2="19.05" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$31">
<contactref element="U$6" pad="1"/>
<contactref element="L2" pad="2"/>
<contactref element="D9" pad="A"/>
<wire x1="38.1" y1="19.05" x2="44.45" y2="38.1" width="0" layer="19" extent="1-1"/>
<wire x1="43.18" y1="29.21" x2="38.1" y2="19.05" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$32">
<contactref element="U$6" pad="5"/>
<contactref element="R40" pad="2"/>
<contactref element="R41" pad="1"/>
<wire x1="27.94" y1="10.16" x2="40.64" y2="27.94" width="0" layer="19" extent="1-1"/>
<wire x1="50.8" y1="21.59" x2="27.94" y2="10.16" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$30">
<contactref element="C9" pad="+"/>
<contactref element="C18" pad="1"/>
<contactref element="C19" pad="+"/>
<contactref element="IC2" pad="3"/>
<contactref element="U$7" pad="4"/>
<contactref element="LED2" pad="A"/>
<wire x1="47.92" y1="33.02" x2="59.69" y2="33.02" width="0" layer="19" extent="1-1"/>
<wire x1="36.83" y1="24.13" x2="59.69" y2="33.02" width="0" layer="19" extent="1-1"/>
<wire x1="18.71" y1="21.59" x2="36.83" y2="24.13" width="0" layer="19" extent="1-1"/>
<wire x1="45.72" y1="19.05" x2="18.71" y2="21.59" width="0" layer="19" extent="1-1"/>
<wire x1="43.18" y1="30.48" x2="45.72" y2="19.05" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$66">
<contactref element="U$7" pad="5"/>
<contactref element="R15" pad="2"/>
<wire x1="43.18" y1="27.94" x2="24.13" y2="33.02" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$68">
<contactref element="U$7" pad="3"/>
<contactref element="C7" pad="+"/>
<contactref element="G1" pad="+"/>
<contactref element="S6" pad="2"/>
<wire x1="44.45" y1="29.21" x2="45.72" y2="39.37" width="0" layer="19" extent="1-1"/>
<wire x1="38.1" y1="30.48" x2="45.72" y2="39.37" width="0" layer="19" extent="1-1"/>
<wire x1="30.14" y1="27.94" x2="38.1" y2="30.48" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$27">
<contactref element="C23" pad="+"/>
<contactref element="C10" pad="1"/>
<contactref element="IC2" pad="1"/>
<contactref element="D2" pad="C"/>
<wire x1="53" y1="41.91" x2="30.48" y2="24.13" width="0" layer="19" extent="1-1"/>
<wire x1="29.21" y1="19.05" x2="53" y2="41.91" width="0" layer="19" extent="1-1"/>
<wire x1="31.75" y1="24.13" x2="29.21" y2="19.05" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$69">
<contactref element="J1" pad="1"/>
<contactref element="D2" pad="A"/>
<wire x1="64.21" y1="13.97" x2="40.64" y2="24.13" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$51">
<contactref element="U$5" pad="3"/>
<contactref element="C12" pad="1"/>
<wire x1="27.81" y1="26.67" x2="29.21" y2="22.86" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$29">
<contactref element="U$6" pad="3"/>
<contactref element="C20" pad="1"/>
<wire x1="43.18" y1="24.13" x2="32.89" y2="24.13" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$33">
<contactref element="LED2" pad="K"/>
<contactref element="R14" pad="2"/>
<wire x1="48.26" y1="19.05" x2="57.15" y2="16.51" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$61">
<contactref element="R14" pad="1"/>
<contactref element="U$7" pad="1"/>
<wire x1="38.1" y1="27.94" x2="54.61" y2="16.51" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$54">
<contactref element="R34" pad="2"/>
<contactref element="X1" pad="2"/>
<wire x1="44.602" y1="25.4" x2="19.58" y2="17.46" width="0" layer="19" extent="1-1"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
