R1, R2				- 220R resistor (x2)
R4, R8				- 1K resistor (x2)
R3, R5, R6, R7 		- 10K resistor (x4)
C1, C2, C3, C4, C7	- 100nF Ceramic Capacitor 2.5mm pitch (x5)
C5, C6				- 10UF 16V electrolytic cap (x2)
D1					- 1N4001 Rectifier Diode
D2 - D17			- 1N4148 Small Signal Diode (x16)
REG1     			- 78L05Z +5V Regulator TO92
MIDI, PWR			- 3mm LED (x2)
IC1					- PIC16F1825 Microcontroller
					- 14 pin DIP IC socket
IC2, IC3			- 74HC595 Shift Register (x2)
					- 16 pin DIP IC socket (x2)
S1-S37				- 6mm x 6mm Momentary Tactile Switch (x37)
ONOFF               - Miniature slide switch
MIDI_OUT			- 5 PIN DIN socket PCB mount
ICSP                - 6 way SIL pin header
BAT1				- PP3 Battery Box
STYLUS				- 4mm Banana Plug on wire
					- LE STRUM PCB
Hardware			- 20mm M3 Hex Standoff (x2)
					- 25mm M3 Hex Standoff (x2)
					- M3 x 8mm Machine Screw (x4)
