# Example makefile
### Project name (also used for output file name)
PROJECT = main
### Source files and search directory
CSRC    = main.c nrf24.c xprintf.c radioPinFunctions.c
ASRC    =
VPATH   = ./util ..
DEVICE  = attiny84
F_OSC   = 8000000
AVRDUDE = avrdude -c usbtiny -p t84 -U flash:w:$(PROJECT).hex
# Don't change anything below
### Include dirs, library dirs and definitions
LIBS	=
LIBDIRS	=
INCDIRS	=
DEFS	= F_CPU=$(F_OSC)
ADEFS	= F_CPU=$(F_OSC)
### Optimization level (0, 1, 2, 3, 4 or s)
OPTIMIZE = s
### C Standard level (c89, gnu89, c99 or gnu99)
CSTD = gnu89
### Warning contorls
WARNINGS = all extra
### Output directory
OBJDIR = obj
### Output file format (ihex, bin or both) and debugger type
OUTPUT	= ihex
DEBUG	= # dwarf-2
### Programs to build porject
CC      = avr-gcc
OBJCOPY = avr-objcopy
OBJDUMP = avr-objdump
SIZE    = avr-size
NM      = avr-nm
# Define all object files
COBJ      = $(CSRC:.c=.o)
AOBJ      = $(ASRC:.S=.o)
COBJ      := $(addprefix $(OBJDIR)/,$(COBJ))
AOBJ      := $(addprefix $(OBJDIR)/,$(AOBJ))
PROJECT   := $(OBJDIR)/$(PROJECT)
# Flags for C files
CFLAGS += -fdata-sections -ffunction-sections
CFLAGS += -Wno-deprecated-declarations -D__PROG_TYPES_COMPAT__
CFLAGS += -Wl,--gc-sections
CFLAGS += -Wall
CFLAGS += -std=$(CSTD)
CFLAGS += -g$(DEBUG)
CFLAGS += -mmcu=$(DEVICE)
CFLAGS += -O$(OPTIMIZE) -mcall-prologues
CFLAGS += $(addprefix -W,$(WARNINGS))
CFLAGS += $(addprefix -I,$(INCDIRS))
CFLAGS += $(addprefix -D,$(DEFS))
CFLAGS += -Wp,-M,-MP,-MT,$(OBJDIR)/$(*F).o,-MF,$(OBJDIR)/$(*F).d
# Assembler flags
ASFLAGS += $(addprefix -D,$(ADEFS)) -Wa,-gstabs,-g$(DEBUG)
ALL_ASFLAGS = -mmcu=$(DEVICE) -I. -x assembler-with-cpp $(ASFLAGS) -fdata-sections -ffunction-sections
# Linker flags
LDFLAGS += -Wl,-lm -Wl,--gc-sections,-Map,$(PROJECT).map
# Default target.
all: version build size
ifeq ($(OUTPUT),ihex)
build: elf hex lst sym
hex: $(PROJECT).hex
else
ifeq ($(OUTPUT),binary)
build: elf bin lst sym
bin: $(PROJECT).bin
else
ifeq ($(OUTPUT),both)
build: elf hex bin lst sym
hex: $(PROJECT).hex
bin: $(PROJECT).bin
else
$(error "Invalid format: $(OUTPUT)")
endif
endif
endif
elf: $(PROJECT).elf
lst: $(PROJECT).lst
sym: $(PROJECT).sym
# Display compiler version information.
version :
	@$(CC) --version
# Create final output file (.hex or .bin) from ELF output file.
%.hex: %.elf
	@echo
	$(OBJCOPY) -O ihex $< $@
%.bin: %.elf
	@echo
	$(OBJCOPY) -O binary $< $@
# Create extended listing file from ELF output file.
%.lst: %.elf
	@echo
	$(OBJDUMP) -h -S -C $< > $@
# Create a symbol table from ELF output file.
%.sym: %.elf
	@echo
	$(NM) -n $< > $@
# Display size of file.
size:
	@echo
	$(SIZE) -C --mcu=$(DEVICE) $(PROJECT).elf
# Link: create ELF output file from object files.
%.elf:  $(AOBJ) $(COBJ)
	@echo
	@echo Linking...
	$(CC) $(CFLAGS) $(AOBJ) $(COBJ) --output $@
# Compile: create object files from C source files. ARM or Thumb(-2)
$(COBJ) : $(OBJDIR)/%.o : %.c
	@echo
	@echo $< :
	$(CC) -c $(CFLAGS) $< -o $@
# Assemble: create object files from assembler source files. ARM or Thumb(-2)
$(AOBJ) : $(OBJDIR)/%.o : %.S
	@echo
	@echo $< :
	$(CC) -c $(ALL_ASFLAGS) $< -o $@
# Target: clean project.
clean:
	@echo
	rm -f -r $(OBJDIR) | exit 0
# Include the dependency files.
-include $(shell mkdir $(OBJDIR) 2>/dev/null) $(wildcard $(OBJDIR)/*.d)
upload:
	@echo
	$(AVRDUDE)
