<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.5.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="yes" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="yes"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="yes"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="yes"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="yes"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="yes"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="yes"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="yes"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="yes"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="yes"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="yes"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="yes"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="yes"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="yes"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<packages>
<package name="TDA7291P13TR">
<smd name="P$1" x="-5" y="-4.2" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$2" x="-5" y="-3.7" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$3" x="-5" y="-3.2" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$4" x="-5" y="-2.7" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$5" x="-5" y="-2.2" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$6" x="-5" y="-1.7" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$7" x="-5" y="-1.2" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$8" x="-5" y="-0.7" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$9" x="-5" y="-0.2" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$10" x="-5" y="0.3" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$11" x="-5" y="0.8" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$12" x="-5" y="1.3" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$13" x="-5" y="1.8" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$14" x="-5" y="2.3" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$15" x="-5" y="2.8" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$16" x="-5" y="3.3" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$17" x="-5" y="3.8" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$18" x="-5" y="4.3" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$19" x="5" y="-4.2" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$20" x="5" y="-3.7" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$21" x="5" y="-3.2" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$22" x="5" y="-2.7" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$23" x="5" y="-2.2" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$24" x="5" y="-1.7" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$25" x="5" y="-1.2" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$26" x="5" y="-0.7" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$27" x="5" y="-0.2" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$28" x="5" y="0.3" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$29" x="5" y="0.8" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$30" x="5" y="1.3" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$31" x="5" y="1.8" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$32" x="5" y="2.3" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$33" x="5" y="2.8" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$34" x="5" y="3.3" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$35" x="5" y="3.8" dx="0.8128" dy="0.4064" layer="1"/>
<smd name="P$36" x="5" y="4.3" dx="0.8128" dy="0.4064" layer="1"/>
<wire x1="-3.7" y1="5.2" x2="3.7" y2="5.2" width="0.127" layer="1"/>
<wire x1="3.7" y1="5.2" x2="3.7" y2="-5.3" width="0.127" layer="1"/>
<wire x1="3.7" y1="-5.3" x2="-3.7" y2="-5.3" width="0.127" layer="1"/>
<wire x1="-3.7" y1="-5.3" x2="-3.7" y2="5.2" width="0.127" layer="1"/>
<wire x1="-2.3" y1="3.5" x2="2.3" y2="3.5" width="0.127" layer="51"/>
<wire x1="2.3" y1="-3.5" x2="-2.3" y2="-3.5" width="0.127" layer="51"/>
<wire x1="-2.3" y1="-3.5" x2="-2.3" y2="3.5" width="0.127" layer="51"/>
<wire x1="2.3" y1="-3.5" x2="2.3" y2="3.5" width="0.127" layer="51"/>
<polygon width="0.127" layer="51">
<vertex x="-2.3" y="3.5"/>
<vertex x="2.3" y="3.5"/>
<vertex x="2.3" y="-3.5"/>
<vertex x="-2.3" y="-3.5"/>
</polygon>
<circle x="-3" y="-4.5" radius="0.5" width="0.127" layer="1"/>
</package>
</packages>
<symbols>
<symbol name="TDA7291P13TR">
<pin name="P$1" x="-17.78" y="-40.64" length="middle"/>
<pin name="P$2" x="-17.78" y="-35.56" length="middle"/>
<pin name="P$3" x="-17.78" y="-30.48" length="middle"/>
<pin name="P$4" x="-17.78" y="-25.4" length="middle"/>
<pin name="P$5" x="-17.78" y="-20.32" length="middle"/>
<pin name="P$6" x="-17.78" y="-15.24" length="middle"/>
<pin name="P$7" x="-17.78" y="-10.16" length="middle"/>
<pin name="P$8" x="-17.78" y="-5.08" length="middle"/>
<pin name="P$9" x="-17.78" y="0" length="middle"/>
<pin name="P$10" x="-17.78" y="5.08" length="middle"/>
<pin name="P$11" x="-17.78" y="10.16" length="middle"/>
<pin name="P$12" x="-17.78" y="15.24" length="middle"/>
<pin name="P$13" x="-17.78" y="20.32" length="middle"/>
<pin name="P$14" x="-17.78" y="25.4" length="middle"/>
<pin name="P$15" x="-17.78" y="30.48" length="middle"/>
<pin name="P$16" x="-17.78" y="35.56" length="middle"/>
<pin name="P$17" x="-17.78" y="40.64" length="middle"/>
<pin name="P$18" x="-17.78" y="45.72" length="middle"/>
<pin name="P$19" x="17.78" y="-40.64" length="middle" rot="R180"/>
<pin name="P$20" x="17.78" y="-35.56" length="middle" rot="R180"/>
<pin name="P$21" x="17.78" y="-30.48" length="middle" rot="R180"/>
<pin name="P$22" x="17.78" y="-25.4" length="middle" rot="R180"/>
<pin name="P$23" x="17.78" y="-20.32" length="middle" rot="R180"/>
<pin name="P$24" x="17.78" y="-15.24" length="middle" rot="R180"/>
<pin name="P$25" x="17.78" y="-10.16" length="middle" rot="R180"/>
<pin name="P$26" x="17.78" y="-5.08" length="middle" rot="R180"/>
<pin name="P$27" x="17.78" y="0" length="middle" rot="R180"/>
<pin name="P$28" x="17.78" y="5.08" length="middle" rot="R180"/>
<pin name="P$29" x="17.78" y="10.16" length="middle" rot="R180"/>
<pin name="P$30" x="17.78" y="15.24" length="middle" rot="R180"/>
<pin name="P$31" x="17.78" y="20.32" length="middle" rot="R180"/>
<pin name="P$32" x="17.78" y="25.4" length="middle" rot="R180"/>
<pin name="P$33" x="17.78" y="30.48" length="middle" rot="R180"/>
<pin name="P$34" x="17.78" y="35.56" length="middle" rot="R180"/>
<pin name="P$35" x="17.78" y="40.64" length="middle" rot="R180"/>
<pin name="P$36" x="17.78" y="45.72" length="middle" rot="R180"/>
<wire x1="-15.24" y1="48.26" x2="15.24" y2="48.26" width="0.254" layer="94"/>
<wire x1="15.24" y1="48.26" x2="15.24" y2="-43.18" width="0.254" layer="94"/>
<wire x1="15.24" y1="-43.18" x2="1.27" y2="-43.18" width="0.254" layer="94"/>
<wire x1="1.27" y1="-43.18" x2="-3.81" y2="-43.18" width="0.254" layer="94"/>
<wire x1="-3.81" y1="-43.18" x2="-15.24" y2="-43.18" width="0.254" layer="94"/>
<wire x1="-15.24" y1="-43.18" x2="-15.24" y2="48.26" width="0.254" layer="94"/>
<wire x1="-3.81" y1="-43.18" x2="1.27" y2="-43.18" width="0.254" layer="94" curve="-126.869898"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="TDA7291P13TR" uservalue="yes">
<description>AMP, AUDIO, DUAL, CLASS D, 36PSSOEPD
 Amplifier Class: D
 No. of Channels: 2
 Output Power: 9.5W
 Supply Voltage Range: 5V to 18V
 Amplifier Case Style: PowerSSO
 No. of Pins: 36
 Load Impedance: 6ohm
 Operating Temperature Min: 0°C
 Operating Temperature Max: 70°C
 Packaging: Each
 MSL: -
 Amplifer Supply Voltage: 5V to 18V
 Base Number: 7491
 Load Impedance Min: 8ohm
 Operating Temperature Range: 0°C to +70°C
 Output Power (Pout): 9.5W @ 8ohm
 Power Rating RMS: 10W
 SVHC: No SVHC (16-Dec-2013)
 Supply Voltage Max: 18V
 Supply Voltage Min: 5V
 THD + N: 0.1% @ 1W, 6ohm, VCC=11V
 Termination Type: SMD</description>
<gates>
<gate name="G$1" symbol="TDA7291P13TR" x="-0.254" y="-0.254"/>
</gates>
<devices>
<device name="" package="TDA7291P13TR">
<connects>
<connect gate="G$1" pin="P$1" pad="P$1"/>
<connect gate="G$1" pin="P$10" pad="P$10"/>
<connect gate="G$1" pin="P$11" pad="P$11"/>
<connect gate="G$1" pin="P$12" pad="P$12"/>
<connect gate="G$1" pin="P$13" pad="P$13"/>
<connect gate="G$1" pin="P$14" pad="P$14"/>
<connect gate="G$1" pin="P$15" pad="P$15"/>
<connect gate="G$1" pin="P$16" pad="P$16"/>
<connect gate="G$1" pin="P$17" pad="P$17"/>
<connect gate="G$1" pin="P$18" pad="P$18"/>
<connect gate="G$1" pin="P$19" pad="P$19"/>
<connect gate="G$1" pin="P$2" pad="P$2"/>
<connect gate="G$1" pin="P$20" pad="P$20"/>
<connect gate="G$1" pin="P$21" pad="P$21"/>
<connect gate="G$1" pin="P$22" pad="P$22"/>
<connect gate="G$1" pin="P$23" pad="P$23"/>
<connect gate="G$1" pin="P$24" pad="P$24"/>
<connect gate="G$1" pin="P$25" pad="P$25"/>
<connect gate="G$1" pin="P$26" pad="P$26"/>
<connect gate="G$1" pin="P$27" pad="P$27"/>
<connect gate="G$1" pin="P$28" pad="P$28"/>
<connect gate="G$1" pin="P$29" pad="P$29"/>
<connect gate="G$1" pin="P$3" pad="P$3"/>
<connect gate="G$1" pin="P$30" pad="P$30"/>
<connect gate="G$1" pin="P$31" pad="P$31"/>
<connect gate="G$1" pin="P$32" pad="P$32"/>
<connect gate="G$1" pin="P$33" pad="P$33"/>
<connect gate="G$1" pin="P$34" pad="P$34"/>
<connect gate="G$1" pin="P$35" pad="P$35"/>
<connect gate="G$1" pin="P$36" pad="P$36"/>
<connect gate="G$1" pin="P$4" pad="P$4"/>
<connect gate="G$1" pin="P$5" pad="P$5"/>
<connect gate="G$1" pin="P$6" pad="P$6"/>
<connect gate="G$1" pin="P$7" pad="P$7"/>
<connect gate="G$1" pin="P$8" pad="P$8"/>
<connect gate="G$1" pin="P$9" pad="P$9"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
