 * MPU6050.c
 *  Created on: Sep 21, 2014
 *      Author: Norbi
#include "MPU6050.h"
#define timeConstant 0.1
void MPU6050_Test_I2C()
    unsigned char Data = 0x00;
    Data=LDByteReadI2C(MPU6050_ADDRESS, MPU6050_RA_WHO_AM_I, &Data, 1);
    if(Data == 0xd1)
     //   printf("\nI2C Read Test Passed, MPU6050 Address: 0x%x", Data);
    else
     //   printf("ERROR: I2C Read Test Failed, Stopping");
        while(1){}    
void Setup_MPU6050()
	//Sets sample rate to 1000/1+1 = 500Hz
	LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_SMPLRT_DIV, 3);
	//Disable FSync, 48Hz DLPF
	LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_CONFIG, 0x03);
	//Disable gyro self tests, scale of 500 degrees/s
	LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_GYRO_CONFIG, 0b00001000);
	//Disable accel self tests, scale of +-4g, no DHPF
	LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_ACCEL_CONFIG, 0b00001000);
    //Freefall threshold of |0mg|
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_FF_THR, 0x00);
    //Freefall duration limit of 0
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_FF_DUR, 0x00);
    //Motion threshold of 0mg
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_MOT_THR, 0x00);
    //Motion duration of 0s
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_MOT_DUR, 0x00);
    //Zero motion threshold
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_ZRMOT_THR, 0x00);
    //Zero motion duration threshold
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_ZRMOT_DUR, 0x00);
    //Disable sensor output to FIFO buffer
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_FIFO_EN, 0x00);
    //AUX I2C setup
    //Sets AUX I2C to single master control, plus other config
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_I2C_MST_CTRL, 0x00);
    //Setup AUX I2C slaves
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_I2C_SLV0_ADDR, 0x00);
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_I2C_SLV0_REG, 0x00);
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_I2C_SLV0_CTRL, 0x00);
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_I2C_SLV1_ADDR, 0x00);
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_I2C_SLV1_REG, 0x00);
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_I2C_SLV1_CTRL, 0x00);
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_I2C_SLV2_ADDR, 0x00);
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_I2C_SLV2_REG, 0x00);
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_I2C_SLV2_CTRL, 0x00);
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_I2C_SLV3_ADDR, 0x00);
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_I2C_SLV3_REG, 0x00);
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_I2C_SLV3_CTRL, 0x00);
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_I2C_SLV4_ADDR, 0x00);
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_I2C_SLV4_REG, 0x00);
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_I2C_SLV4_DO, 0x00);
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_I2C_SLV4_CTRL, 0x00);
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_I2C_SLV4_DI, 0x00);
    //MPU6050_RA_I2C_MST_STATUS //Read-only
    //Setup INT pin and AUX I2C pass through
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_INT_PIN_CFG, 0x00);
    //Enable data ready interrupt
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_INT_ENABLE, 0x00);
    //MPU6050_RA_DMP_INT_STATUS        //Read-only
    //MPU6050_RA_INT_STATUS 3A        //Read-only
    //MPU6050_RA_ACCEL_XOUT_H         //Read-only
    //MPU6050_RA_ACCEL_XOUT_L         //Read-only
    //MPU6050_RA_ACCEL_YOUT_H         //Read-only
    //MPU6050_RA_ACCEL_YOUT_L         //Read-only
    //MPU6050_RA_ACCEL_ZOUT_H         //Read-only
    //MPU6050_RA_ACCEL_ZOUT_L         //Read-only
    //MPU6050_RA_TEMP_OUT_H         //Read-only
    //MPU6050_RA_TEMP_OUT_L         //Read-only
    //MPU6050_RA_GYRO_XOUT_H         //Read-only
    //MPU6050_RA_GYRO_XOUT_L         //Read-only
    //MPU6050_RA_GYRO_YOUT_H         //Read-only
    //MPU6050_RA_GYRO_YOUT_L         //Read-only
    //MPU6050_RA_GYRO_ZOUT_H         //Read-only
    //MPU6050_RA_GYRO_ZOUT_L         //Read-only
    //MPU6050_RA_EXT_SENS_DATA_00     //Read-only
    //MPU6050_RA_EXT_SENS_DATA_01     //Read-only
    //MPU6050_RA_EXT_SENS_DATA_02     //Read-only
    //MPU6050_RA_EXT_SENS_DATA_03     //Read-only
    //MPU6050_RA_EXT_SENS_DATA_04     //Read-only
    //MPU6050_RA_EXT_SENS_DATA_05     //Read-only
    //MPU6050_RA_EXT_SENS_DATA_06     //Read-only
    //MPU6050_RA_EXT_SENS_DATA_07     //Read-only
    //MPU6050_RA_EXT_SENS_DATA_08     //Read-only
    //MPU6050_RA_EXT_SENS_DATA_09     //Read-only
    //MPU6050_RA_EXT_SENS_DATA_10     //Read-only
    //MPU6050_RA_EXT_SENS_DATA_11     //Read-only
    //MPU6050_RA_EXT_SENS_DATA_12     //Read-only
    //MPU6050_RA_EXT_SENS_DATA_13     //Read-only
    //MPU6050_RA_EXT_SENS_DATA_14     //Read-only
    //MPU6050_RA_EXT_SENS_DATA_15     //Read-only
    //MPU6050_RA_EXT_SENS_DATA_16     //Read-only
    //MPU6050_RA_EXT_SENS_DATA_17     //Read-only
    //MPU6050_RA_EXT_SENS_DATA_18     //Read-only
    //MPU6050_RA_EXT_SENS_DATA_19     //Read-only
    //MPU6050_RA_EXT_SENS_DATA_20     //Read-only
    //MPU6050_RA_EXT_SENS_DATA_21     //Read-only
    //MPU6050_RA_EXT_SENS_DATA_22     //Read-only
    //MPU6050_RA_EXT_SENS_DATA_23     //Read-only
    //MPU6050_RA_MOT_DETECT_STATUS     //Read-only
    //Slave out, dont care
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_I2C_SLV0_DO, 0x00);
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_I2C_SLV1_DO, 0x00);
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_I2C_SLV2_DO, 0x00);
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_I2C_SLV3_DO, 0x00);
    //More slave config
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_I2C_MST_DELAY_CTRL, 0x00);
    //Reset sensor signal paths
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_SIGNAL_PATH_RESET, 0x00);
    //Motion detection control
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_MOT_DETECT_CTRL, 0x00);
    //Disables FIFO, AUX I2C, FIFO and I2C reset bits to 0
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_USER_CTRL, 0x00);
    //Sets clock source to gyro reference w/ PLL
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_PWR_MGMT_1, 0b00000010);
    //Controls frequency of wakeups in accel low power mode plus the sensor standby modes
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_PWR_MGMT_2, 0x00);
    //MPU6050_RA_BANK_SEL            //Not in datasheet
    //MPU6050_RA_MEM_START_ADDR        //Not in datasheet
    //MPU6050_RA_MEM_R_W            //Not in datasheet
    //MPU6050_RA_DMP_CFG_1            //Not in datasheet
    //MPU6050_RA_DMP_CFG_2            //Not in datasheet
    //MPU6050_RA_FIFO_COUNTH        //Read-only
    //MPU6050_RA_FIFO_COUNTL        //Read-only
    //Data transfer to and from the FIFO buffer
    LDByteWriteI2C(MPU6050_ADDRESS, MPU6050_RA_FIFO_R_W, 0x00);
    //MPU6050_RA_WHO_AM_I             //Read-only, I2C address
    //printf("\nMPU6050 Setup Complete");
unsigned char GYRO_XOUT_H = ' ';
unsigned char GYRO_XOUT_L = ' ';
unsigned char GYRO_YOUT_H = ' ';
unsigned char GYRO_YOUT_L = ' ';
unsigned char GYRO_ZOUT_H = ' ';
unsigned char GYRO_ZOUT_L = ' ';
signed long GYRO_XOUT_OFFSET_1000SUM = 0;
signed long GYRO_YOUT_OFFSET_1000SUM = 0;
signed long GYRO_ZOUT_OFFSET_1000SUM = 0;
signed int GYRO_XOUT_OFFSET = 0;
signed int GYRO_YOUT_OFFSET = 0;
signed int GYRO_ZOUT_OFFSET = 0;
float dt=0.004;
float GYRO_XANGLE = 0;
float GYRO_YANGLE = 0;
float GYRO_ZANGLE = 0;
signed int GYRO_XOUT = 0;
signed int GYRO_YOUT = 0;
signed int GYRO_ZOUT = 0;
float GYRO_XRATE = 0;
float GYRO_YRATE = 0;
float GYRO_ZRATE = 0;
unsigned char ACCEL_XOUT_H = ' ';
unsigned char ACCEL_XOUT_L = ' ';
unsigned char ACCEL_YOUT_H = ' ';
unsigned char ACCEL_YOUT_L = ' ';
unsigned char ACCEL_ZOUT_H = ' ';
unsigned char ACCEL_ZOUT_L = ' ';
signed int ACCEL_XOUT = 0;
signed int ACCEL_YOUT = 0;
signed int ACCEL_ZOUT = 0;
float ACCEL_XANGLE;
float ACCEL_YANGLE;
float gyro_xsensitivity=66.5;
float gyro_ysensitivity=66.5;
float gyro_zsensitivity=66.5;
float COMPLEMENTARY_XANGLE = 0;
float COMPLEMENTARY_YANGLE = 0;
float a = 0.9994;
float filter_xterm[3] = {0,0,0};
float filter_yterm[3] = {0,0,0};
void Calibrate_Gyros()
	int x = 0;
	for(x = 0; x<5000; x++)
		LDByteReadI2C(MPU6050_ADDRESS, MPU6050_RA_GYRO_XOUT_H, &GYRO_XOUT_H, 1);
		LDByteReadI2C(MPU6050_ADDRESS, MPU6050_RA_GYRO_XOUT_L, &GYRO_XOUT_L, 1);
		LDByteReadI2C(MPU6050_ADDRESS, MPU6050_RA_GYRO_YOUT_H, &GYRO_YOUT_H, 1);
		LDByteReadI2C(MPU6050_ADDRESS, MPU6050_RA_GYRO_YOUT_L, &GYRO_YOUT_L, 1);
		LDByteReadI2C(MPU6050_ADDRESS, MPU6050_RA_GYRO_ZOUT_H, &GYRO_ZOUT_H, 1);
		LDByteReadI2C(MPU6050_ADDRESS, MPU6050_RA_GYRO_ZOUT_L, &GYRO_ZOUT_L, 1);
		GYRO_XOUT_OFFSET_1000SUM += ((GYRO_XOUT_H<<8)|GYRO_XOUT_L);
		GYRO_YOUT_OFFSET_1000SUM += ((GYRO_YOUT_H<<8)|GYRO_YOUT_L);
		GYRO_ZOUT_OFFSET_1000SUM += ((GYRO_ZOUT_H<<8)|GYRO_ZOUT_L);
		Delay_mS(1);
	GYRO_XOUT_OFFSET = GYRO_XOUT_OFFSET_1000SUM/5000;
	GYRO_YOUT_OFFSET = GYRO_YOUT_OFFSET_1000SUM/5000;
	GYRO_ZOUT_OFFSET = GYRO_ZOUT_OFFSET_1000SUM/5000;
//	printf("\nGyro X offset sum: %ld Gyro X offset: %d", GYRO_XOUT_OFFSET_1000SUM, GYRO_XOUT_OFFSET);
//	printf("\nGyro Y offset sum: %ld Gyro Y offset: %d", GYRO_YOUT_OFFSET_1000SUM, GYRO_YOUT_OFFSET);
//	printf("\nGyro Z offset sum: %ld Gyro Z offset: %d", GYRO_ZOUT_OFFSET_1000SUM, GYRO_ZOUT_OFFSET);
//Gets raw accelerometer data, performs no processing
void Get_Accel_Values()
	LDByteReadI2C(MPU6050_ADDRESS, MPU6050_RA_ACCEL_XOUT_H, &ACCEL_XOUT_H, 1);
	LDByteReadI2C(MPU6050_ADDRESS, MPU6050_RA_ACCEL_XOUT_L, &ACCEL_XOUT_L, 1);
	LDByteReadI2C(MPU6050_ADDRESS, MPU6050_RA_ACCEL_YOUT_H, &ACCEL_YOUT_H, 1);
	LDByteReadI2C(MPU6050_ADDRESS, MPU6050_RA_ACCEL_YOUT_L, &ACCEL_YOUT_L, 1);
	LDByteReadI2C(MPU6050_ADDRESS, MPU6050_RA_ACCEL_ZOUT_H, &ACCEL_ZOUT_H, 1);
	LDByteReadI2C(MPU6050_ADDRESS, MPU6050_RA_ACCEL_ZOUT_L, &ACCEL_ZOUT_L, 1);
	ACCEL_XOUT = ((ACCEL_XOUT_H<<8)|ACCEL_XOUT_L);
	ACCEL_YOUT = ((ACCEL_YOUT_H<<8)|ACCEL_YOUT_L);
	ACCEL_ZOUT = ((ACCEL_ZOUT_H<<8)|ACCEL_ZOUT_L);		
//Converts the already acquired accelerometer data into 3D euler angles
void Get_Accel_Angles()
	ACCEL_XANGLE = 57.295*atan((float)ACCEL_YOUT/ sqrt(pow((float)ACCEL_ZOUT,2)+pow((float)ACCEL_XOUT,2)));
	ACCEL_YANGLE = 57.295*atan((float)-ACCEL_XOUT/ sqrt(pow((float)ACCEL_ZOUT,2)+pow((float)ACCEL_YOUT,2)));	
//Function to read the gyroscope rate data and convert it into degrees/s
void Get_Gyro_Rates()
	GYRO_XOUT = ((GYRO_XOUT_H<<8)|GYRO_XOUT_L) - GYRO_XOUT_OFFSET;
	GYRO_YOUT = ((GYRO_YOUT_H<<8)|GYRO_YOUT_L) - GYRO_YOUT_OFFSET;
	GYRO_ZOUT = ((GYRO_ZOUT_H<<8)|GYRO_ZOUT_L) - GYRO_ZOUT_OFFSET;
	GYRO_XRATE = (float)GYRO_XOUT/gyro_xsensitivity;
	GYRO_YRATE = (float)GYRO_YOUT/gyro_ysensitivity;
	GYRO_ZRATE = (float)GYRO_ZOUT/gyro_zsensitivity;
	GYRO_XANGLE += (float)GYRO_XRATE*dt;
	GYRO_YANGLE += (float)GYRO_YRATE*dt;
	GYRO_ZANGLE += (float)GYRO_ZRATE*dt;
//Runs a complementary filter configured via float a
void complementary_filter()
	COMPLEMENTARY_XANGLE = (COMPLEMENTARY_XANGLE + GYRO_XRATE*dt)*a + ACCEL_XANGLE*(1-a);
	COMPLEMENTARY_YANGLE = (COMPLEMENTARY_YANGLE + GYRO_YRATE*dt)*a + ACCEL_YANGLE*(1-a);		
//Runs 2nd order complementary filter
void second_order_complementary_filter() //http://code.google.com/p/aeroquad/source/browse/trunk/AeroQuad/Filter.pde?r=143
	filter_xterm[0] = (ACCEL_XANGLE - COMPLEMENTARY_XANGLE) * timeConstant * timeConstant;
	filter_yterm[0] = (ACCEL_YANGLE - COMPLEMENTARY_YANGLE) * timeConstant * timeConstant;
  	filter_xterm[2] = (dt * filter_xterm[0]) + filter_xterm[2];
  	filter_yterm[2] = (dt * filter_yterm[0]) + filter_yterm[2];
  	filter_xterm[1] = filter_xterm[2] + (ACCEL_XANGLE - COMPLEMENTARY_XANGLE) * 2 * timeConstant + GYRO_XRATE;
  	filter_yterm[1] = filter_yterm[2] + (ACCEL_YANGLE - COMPLEMENTARY_YANGLE) * 2 * timeConstant + GYRO_YRATE;
  	COMPLEMENTARY_XANGLE = (dt * filter_xterm[1]) + COMPLEMENTARY_XANGLE;
  	COMPLEMENTARY_YANGLE = (dt * filter_yterm[1]) + COMPLEMENTARY_YANGLE;
