<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.5.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="yes"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="yes"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="yes"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="yes"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="yes"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="yes"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="yes"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="yes"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="yes"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="yes"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="yes"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="yes"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="yes"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<packages>
<package name="IEC-C14">
<pad name="P$1" x="-9.22" y="0" drill="1.3" diameter="2.54" shape="long" rot="R90"/>
<pad name="P$2" x="0" y="0" drill="1.3" diameter="2.54" shape="long" rot="R90"/>
<pad name="P$3" x="9.17" y="0" drill="1.3" diameter="2.54" shape="long" rot="R90"/>
<wire x1="-14.74" y1="-20.19" x2="14.47" y2="-20.19" width="3.2" layer="21"/>
<wire x1="-13.69" y1="-0.01" x2="-13.69" y2="-18.82" width="0.127" layer="21"/>
<wire x1="-13.69" y1="-18.82" x2="-13.71" y2="-18.84" width="0.127" layer="21"/>
<wire x1="-13.71" y1="-18.84" x2="13.69" y2="-18.84" width="0.127" layer="21"/>
<wire x1="13.69" y1="-18.84" x2="13.69" y2="0.01" width="0.127" layer="21"/>
<wire x1="13.69" y1="0.01" x2="-13.69" y2="0.01" width="0.127" layer="21"/>
<wire x1="-11.43" y1="0" x2="-11.43" y2="-19.05" width="0.127" layer="21"/>
<wire x1="11.43" y1="0" x2="11.43" y2="-19.05" width="0.127" layer="21"/>
<polygon width="0.127" layer="21">
<vertex x="-8.89" y="-13.97"/>
<vertex x="-6.35" y="-13.97"/>
<vertex x="-6.35" y="-8.89"/>
<vertex x="-7.62" y="-7.62"/>
<vertex x="-8.89" y="-8.89"/>
</polygon>
<vertex x="6.35" y="-13.97"/>
<vertex x="8.89" y="-13.97"/>
<vertex x="8.89" y="-8.89"/>
<vertex x="7.62" y="-7.62"/>
<vertex x="6.35" y="-8.89"/>
</polygon>
</package>
</packages>
<symbols>
<symbol name="IEC-C14">
<pin name="P$1" x="-5.08" y="2.54" visible="off" length="short"/>
<pin name="P$2" x="-5.08" y="0" visible="off" length="short"/>
<pin name="P$3" x="-5.08" y="-2.54" visible="off" length="short"/>
<wire x1="-2.54" y1="5.08" x2="-2.54" y2="2.54" width="0.254" layer="94"/>
<wire x1="-2.54" y1="2.54" x2="-2.54" y2="0" width="0.254" layer="94"/>
<wire x1="-2.54" y1="0" x2="-2.54" y2="-5.08" width="0.254" layer="94"/>
<wire x1="-2.54" y1="0" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="1.08" width="0.254" layer="94"/>
<wire x1="0" y1="1.08" x2="0.01" y2="-1.06" width="0.254" layer="94"/>
<wire x1="0.49" y1="0.43" x2="0.49" y2="-0.5" width="0.254" layer="94"/>
<wire x1="-2.54" y1="5.08" x2="0" y2="5.08" width="0.254" layer="94"/>
<wire x1="0" y1="5.08" x2="2.54" y2="2.54" width="0.254" layer="94"/>
<wire x1="2.54" y1="2.54" x2="2.54" y2="-2.54" width="0.254" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="0" y2="-5.08" width="0.254" layer="94"/>
<wire x1="0" y1="-5.08" x2="-2.54" y2="-5.08" width="0.254" layer="94"/>
<wire x1="-2.54" y1="2.54" x2="-1.86" y2="2.54" width="0.254" layer="94"/>
<wire x1="-1.86" y1="2.54" x2="-1.33" y2="3.07" width="0.254" layer="94"/>
<wire x1="-1.33" y1="3.07" x2="0.02" y2="3.07" width="0.254" layer="94"/>
<wire x1="0.02" y1="3.07" x2="-1.32" y2="3.07" width="0.254" layer="94"/>
<wire x1="-1.32" y1="3.07" x2="-1.83" y2="2.56" width="0.254" layer="94"/>
<wire x1="-1.83" y1="2.56" x2="-1.31" y2="2.04" width="0.254" layer="94"/>
<wire x1="-1.31" y1="2.04" x2="0.04" y2="2.04" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-2.54" x2="-1.86" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-1.86" y1="-2.54" x2="-1.33" y2="-2.01" width="0.254" layer="94"/>
<wire x1="-1.33" y1="-2.01" x2="0.02" y2="-2.01" width="0.254" layer="94"/>
<wire x1="0.02" y1="-2.01" x2="-1.32" y2="-2.01" width="0.254" layer="94"/>
<wire x1="-1.32" y1="-2.01" x2="-1.83" y2="-2.52" width="0.254" layer="94"/>
<wire x1="-1.83" y1="-2.52" x2="-1.31" y2="-3.04" width="0.254" layer="94"/>
<wire x1="-1.31" y1="-3.04" x2="0.04" y2="-3.04" width="0.254" layer="94"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="IEC-C14">
<gates>
<gate name="G$1" symbol="IEC-C14" x="0" y="0"/>
</gates>
<devices>
<device name="" package="IEC-C14">
<connects>
<connect gate="G$1" pin="P$1" pad="P$1"/>
<connect gate="G$1" pin="P$2" pad="P$2"/>
<connect gate="G$1" pin="P$3" pad="P$3"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
