* image
* filename: C:/LCDprog/6x8E.xml
* name: Image
* preset name: Monochrome
* data block size: 8 bit(s), uint8_t
* RLE compression enabled: no
* conversion type: Monochrome, Diffuse Dither 128
* bits per pixel: 1
* preprocess:
*  main scan direction: top_to_bottom
*  line scan direction: forward
*  inverse: yes
 typedef struct {
     const uint8_t *data;
     uint16_t width;
     uint16_t height;
     } tImage;
#include <stdint.h>
static const uint8_t image_data_Image[8] = {
    0x3f, 
    0x20, 
    0x20, 
    0x3c, 
    0x20, 
    0x20, 
    0x20, 
    0x3f
const tImage Image = { image_data_Image, 8, 8};
