;   This file is a basic code template for code generation on the             *
;   PIC18F14K22. This file contains the basic code building blocks to build   *
;   upon.        *
;   Refer to the MPASM User's Guide for additional information on features    *
;   of the assembler.                                                         *
;   Refer to the respective data sheet for additional information on the      *
;   instruction set.                                                          *
;    Filename:         xxx.asm                                                *
;    Date:        *
;    File Version:                                                            *
;    Author:        *
;    Company:        *
;    Files Required: P18F14K22.INC                                            *
;    Notes:        *
;    Revision History:                                                        *
; PROCESSOR DECLARATION
     LIST      P=PIC18F14K22          ; list directive to define processor
     #INCLUDE <P18F14K22.INC>         ; processor specific variable definitions
; CONFIGURATION WORD SETUP
; The 'CONFIG' directive is used to embed the configuration word within the 
; .asm file. The lables following the directive are located in the respective 
; .inc file.  See the data sheet for additional information on configuration 
; word settings.
     ;Setup CONFIG11H
     CONFIG FOSC = IRC, PLLEN = OFF, PCLKEN = OFF, FCMEN = OFF, IESO = OFF
     ;Setup CONFIG2L
     CONFIG PWRTEN = ON, BOREN = OFF, BORV = 19
     ;Setup CONFIG2H
     CONFIG WDTEN = OFF, WDTPS = 1
     ;Setup CONFIG3H
     CONFIG MCLRE = ON, HFOFST = OFF
     ;Setup CONFIG4L
     CONFIG STVREN = OFF, LVP = OFF, BBSIZ = OFF, XINST = OFF
     ;Setup CONFIG5L
     CONFIG CP0 = OFF, CP1 = OFF
     ;Setup CONFIG5H
     CONFIG CPB = OFF, CPD = OFF
     ;Setup CONFIG6L
     CONFIG WRT0 = OFF, WRT1 = OFF
     ;Setup CONFIG6H
     CONFIG WRTB = OFF, WRTC = OFF, WRTD = OFF
     ;Setup CONFIG7L
     CONFIG EBTR0 = OFF, EBTR1 = OFF
     ;Setup CONFIG7H
     CONFIG EBTRB = OFF
; VARIABLE DEFINITIONS
; Refer to datasheet for available data memory (RAM) organization
    CBLOCK 0x60 ; Sample GPR variable register allocations
        MYVAR1  ; user variable at address 0x60
        MYVAR2  ; user variable at address 0x61
        MYVAR3  ; user variable at address 0x62
    ENDC
W_TEMP         EQU        0x000  ; w register for context saving (ACCESS)
STATUS_TEMP    EQU        0x001  ; status used for context saving 
BSR_TEMP       EQU        0x002  ; bank select used for ISR context saving
; EEPROM INITIALIZATION
; The 18F14K22 has 256 bytes of non-volatile EEPROM starting at 0xF00000
DATAEE    ORG  0xF00000 ; Starting address for EEPROM for 18F14K22
    DE    "MCHP"        ; Place 'M' 'C' 'H' 'P' at address 0,1,2,3
; RESET VECTOR
RES_VECT  ORG     0x0000            ; processor reset vector
          GOTO    START             ; go to beginning of program
; HIGH PRIORITY INTERRUPT VECTOR
ISRH      ORG     0x0008
          ; Run the High Priority Interrupt Service Routine
          GOTO    HIGH_ISR             
; LOW PRIORITY INTERRUPT VECTOR
ISRL      ORG     0x0018
          GOTO    LOW_ISR             
; HIGH PRIORITY INTERRUPT SERVICE ROUTINE
HIGH_ISR  
          ; Insert High Priority ISR Here
          RETFIE  FAST
; LOW PRIORITY INTERRUPT SERVICE ROUTINE
LOW_ISR
          ; Context Saving for Low ISR
          MOVWF   W_TEMP              ; save W register
          MOVFF   STATUS, STATUS_TEMP ; save status register
          MOVFF   BSR, BSR_TEMP       ; save bankselect register
          ; Insert Low Priority ISR Here
          MOVFF   BSR_TEMP, BSR       ; restore bankselect register
          MOVF    W_TEMP, W           ; restore W register
          MOVFF   STATUS_TEMP, STATUS ; restore status register
          RETFIE
; MAIN PROGRAM
START	
          ; Insert User Program Here
          GOTO $                      ; loop program counter
          END
