<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.4">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="no" active="no"/>
<layer number="17" name="Pads" color="2" fill="1" visible="no" active="no"/>
<layer number="18" name="Vias" color="2" fill="1" visible="no" active="no"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="no"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="no" active="no"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="no"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="no"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="no"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="no"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="no"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="no"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="no"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="no"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="no"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="no"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="no"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="no"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="no"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="no"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="no"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="no"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="no"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="no"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="no"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="no"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="no"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="no"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="no"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="no"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="6" fill="1" visible="no" active="no"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<schematic xreflabel="%F%N/%S.%C%R" xrefpart="/%S.%C%R">
<libraries>
<library name="rcl">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="R0402">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;</description>
<wire x1="-0.245" y1="0.224" x2="0.245" y2="0.224" width="0.1524" layer="51"/>
<wire x1="0.245" y1="-0.224" x2="-0.245" y2="-0.224" width="0.1524" layer="51"/>
<wire x1="-1.473" y1="0.483" x2="1.473" y2="0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.483" x2="1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.483" x2="-1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.483" x2="-1.473" y2="0.483" width="0.0508" layer="39"/>
<smd name="1" x="-0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<smd name="2" x="0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<text x="-0.635" y="0.635" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-1.905" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.554" y1="-0.3048" x2="-0.254" y2="0.2951" layer="51"/>
<rectangle x1="0.2588" y1="-0.3048" x2="0.5588" y2="0.2951" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="R0603">
<wire x1="-0.432" y1="-0.356" x2="0.432" y2="-0.356" width="0.1524" layer="51"/>
<wire x1="0.432" y1="0.356" x2="-0.432" y2="0.356" width="0.1524" layer="51"/>
<wire x1="-1.473" y1="0.983" x2="1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.983" x2="1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.983" x2="-1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.983" x2="-1.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.85" y="0" dx="1" dy="1.1" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1" dy="1.1" layer="1"/>
<rectangle x1="0.4318" y1="-0.4318" x2="0.8382" y2="0.4318" layer="51"/>
<rectangle x1="-0.8382" y1="-0.4318" x2="-0.4318" y2="0.4318" layer="51"/>
</package>
<package name="R0805">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="-0.41" y1="0.635" x2="0.41" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.41" y1="-0.635" x2="0.41" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<text x="-0.635" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="0.4064" y1="-0.6985" x2="1.0564" y2="0.7015" layer="51"/>
<rectangle x1="-1.0668" y1="-0.6985" x2="-0.4168" y2="0.7015" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
<package name="R0805W">
<description>&lt;b&gt;RESISTOR&lt;/b&gt; wave soldering&lt;p&gt;</description>
<smd name="1" x="-1.0525" y="0" dx="1.5" dy="1" layer="1"/>
<smd name="2" x="1.0525" y="0" dx="1.5" dy="1" layer="1"/>
</package>
<package name="R1005">
<rectangle x1="-0.1999" y1="-0.3" x2="0.1999" y2="0.3" layer="35"/>
</package>
<package name="R1206">
<wire x1="0.9525" y1="-0.8128" x2="-0.9652" y2="-0.8128" width="0.1524" layer="51"/>
<wire x1="0.9525" y1="0.8128" x2="-0.9652" y2="0.8128" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="2" x="1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<smd name="1" x="-1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6891" y1="-0.8763" x2="-0.9525" y2="0.8763" layer="51"/>
<rectangle x1="0.9525" y1="-0.8763" x2="1.6891" y2="0.8763" layer="51"/>
<rectangle x1="-0.3" y1="-0.7" x2="0.3" y2="0.7" layer="35"/>
</package>
<package name="R1206W">
wave soldering</description>
<wire x1="-0.913" y1="0.8" x2="0.888" y2="0.8" width="0.1524" layer="51"/>
<wire x1="-0.913" y1="-0.8" x2="0.888" y2="-0.8" width="0.1524" layer="51"/>
<smd name="1" x="-1.499" y="0" dx="1.8" dy="1.2" layer="1"/>
<smd name="2" x="1.499" y="0" dx="1.8" dy="1.2" layer="1"/>
<text x="-1.905" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-0.8763" x2="-0.9009" y2="0.8738" layer="51"/>
<rectangle x1="0.889" y1="-0.8763" x2="1.6391" y2="0.8738" layer="51"/>
</package>
<package name="R1210">
<wire x1="-0.913" y1="1.219" x2="0.939" y2="1.219" width="0.1524" layer="51"/>
<wire x1="-0.913" y1="-1.219" x2="0.939" y2="-1.219" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<text x="-2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.3081" x2="-0.9009" y2="1.2918" layer="51"/>
<rectangle x1="0.9144" y1="-1.3081" x2="1.6645" y2="1.2918" layer="51"/>
<rectangle x1="-0.3" y1="-0.8999" x2="0.3" y2="0.8999" layer="35"/>
</package>
<package name="R1210W">
<smd name="1" x="-1.499" y="0" dx="1.8" dy="1.8" layer="1"/>
<smd name="2" x="1.499" y="0" dx="1.8" dy="1.8" layer="1"/>
<rectangle x1="-0.3" y1="-0.8001" x2="0.3" y2="0.8001" layer="35"/>
</package>
<package name="R2010">
<wire x1="-1.662" y1="1.245" x2="1.662" y2="1.245" width="0.1524" layer="51"/>
<wire x1="-1.637" y1="-1.245" x2="1.687" y2="-1.245" width="0.1524" layer="51"/>
<wire x1="-3.473" y1="1.483" x2="3.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="3.473" y1="1.483" x2="3.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="3.473" y1="-1.483" x2="-3.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-3.473" y1="-1.483" x2="-3.473" y2="1.483" width="0.0508" layer="39"/>
<smd name="1" x="-2.2" y="0" dx="1.8" dy="2.7" layer="1"/>
<smd name="2" x="2.2" y="0" dx="1.8" dy="2.7" layer="1"/>
<text x="-3.175" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.175" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.4892" y1="-1.3208" x2="-1.6393" y2="1.3292" layer="51"/>
<rectangle x1="1.651" y1="-1.3208" x2="2.5009" y2="1.3292" layer="51"/>
</package>
<package name="R2010W">
<smd name="1" x="-2.311" y="0" dx="2" dy="1.8" layer="1"/>
<smd name="2" x="2.311" y="0" dx="2" dy="1.8" layer="1"/>
</package>
<package name="R2012">
<smd name="1" x="-0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<rectangle x1="-0.1001" y1="-0.5999" x2="0.1001" y2="0.5999" layer="35"/>
</package>
<package name="R2012W">
<smd name="1" x="-0.94" y="0" dx="1.5" dy="1" layer="1"/>
<smd name="2" x="0.94" y="0" dx="1.5" dy="1" layer="1"/>
</package>
<package name="R2512">
<wire x1="-2.362" y1="1.473" x2="2.387" y2="1.473" width="0.1524" layer="51"/>
<wire x1="-2.362" y1="-1.473" x2="2.387" y2="-1.473" width="0.1524" layer="51"/>
<wire x1="-3.973" y1="1.983" x2="3.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="1.983" x2="3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="-1.983" x2="-3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-3.973" y1="-1.983" x2="-3.973" y2="1.983" width="0.0508" layer="39"/>
<smd name="1" x="-2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<smd name="2" x="2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<rectangle x1="-3.2004" y1="-1.5494" x2="-2.3505" y2="1.5507" layer="51"/>
<rectangle x1="2.3622" y1="-1.5494" x2="3.2121" y2="1.5507" layer="51"/>
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="R2512W">
<smd name="1" x="-2.896" y="0" dx="2" dy="2.1" layer="1"/>
<smd name="2" x="2.896" y="0" dx="2" dy="2.1" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R3216">
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
</package>
<package name="R3216W">
</package>
<package name="R3225">
<rectangle x1="-0.3" y1="-1" x2="0.3" y2="1" layer="35"/>
</package>
<package name="R3225W">
</package>
<package name="R5025">
</package>
<package name="R5025W">
</package>
<package name="R6332">
Source: http://download.siliconexpert.com/pdfs/2005/02/24/Semi_Ap/2/VSH/Resistor/dcrcwfre.pdf</description>
<smd name="1" x="-3.1" y="0" dx="1" dy="3.2" layer="1"/>
<smd name="2" x="3.1" y="0" dx="1" dy="3.2" layer="1"/>
</package>
<package name="R6332W">
<smd name="1" x="-3.196" y="0" dx="1.2" dy="3.2" layer="1"/>
<smd name="2" x="3.196" y="0" dx="1.2" dy="3.2" layer="1"/>
</package>
<package name="M0805">
MELF 0.10 W</description>
<wire x1="0.7112" y1="0.635" x2="-0.7112" y2="0.635" width="0.1524" layer="51"/>
<wire x1="0.7112" y1="-0.635" x2="-0.7112" y2="-0.635" width="0.1524" layer="51"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.6" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.6" layer="1"/>
<rectangle x1="-1.0414" y1="-0.7112" x2="-0.6858" y2="0.7112" layer="51"/>
<rectangle x1="0.6858" y1="-0.7112" x2="1.0414" y2="0.7112" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5999" x2="0.1999" y2="0.5999" layer="35"/>
</package>
<package name="M1206">
MELF 0.25 W</description>
<wire x1="1.143" y1="0.8382" x2="-1.143" y2="0.8382" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.8382" x2="-1.143" y2="-0.8382" width="0.1524" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2" layer="1"/>
<rectangle x1="-1.7018" y1="-0.9144" x2="-1.1176" y2="0.9144" layer="51"/>
<rectangle x1="1.1176" y1="-0.9144" x2="1.7018" y2="0.9144" layer="51"/>
</package>
<package name="M1406">
MELF 0.12 W</description>
<wire x1="-2.973" y1="0.983" x2="2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-0.983" x2="-2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-0.983" x2="-2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="0.983" x2="2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.3208" y1="0.762" x2="-1.3208" y2="0.762" width="0.1524" layer="51"/>
<wire x1="1.3208" y1="-0.762" x2="-1.3208" y2="-0.762" width="0.1524" layer="51"/>
<smd name="1" x="-1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<smd name="2" x="1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<rectangle x1="-1.8542" y1="-0.8382" x2="-1.2954" y2="0.8382" layer="51"/>
<rectangle x1="1.2954" y1="-0.8382" x2="1.8542" y2="0.8382" layer="51"/>
</package>
<package name="M2012">
</package>
<package name="M2309">
<wire x1="-4.473" y1="1.483" x2="4.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="4.473" y1="-1.483" x2="-4.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-4.473" y1="-1.483" x2="-4.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="4.473" y1="1.483" x2="4.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="2.413" y1="1.1684" x2="-2.4384" y2="1.1684" width="0.1524" layer="51"/>
<wire x1="2.413" y1="-1.1684" x2="-2.413" y2="-1.1684" width="0.1524" layer="51"/>
<smd name="1" x="-2.85" y="0" dx="1.5" dy="2.6" layer="1"/>
<smd name="2" x="2.85" y="0" dx="1.5" dy="2.6" layer="1"/>
<text x="-2.54" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.048" y1="-1.2446" x2="-2.3876" y2="1.2446" layer="51"/>
<rectangle x1="2.3876" y1="-1.2446" x2="3.048" y2="1.2446" layer="51"/>
</package>
<package name="M3216">
</package>
<package name="M3516">
<rectangle x1="-0.4001" y1="-0.7" x2="0.4001" y2="0.7" layer="35"/>
</package>
<package name="M5923">
</package>
<package name="0204/5">
type 0204, grid 5 mm</description>
<wire x1="2.54" y1="0" x2="2.032" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0" x2="-2.032" y2="0" width="0.508" layer="51"/>
<wire x1="-1.778" y1="0.635" x2="-1.524" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.778" y1="-0.635" x2="-1.524" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="-0.889" x2="1.778" y2="-0.635" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="0.889" x2="1.778" y2="0.635" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.778" y1="-0.635" x2="-1.778" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-1.524" y1="0.889" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.762" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-0.889" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-0.762" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.762" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.762" x2="-1.143" y2="0.762" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.762" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.762" x2="-1.143" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.889" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-0.889" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.635" x2="1.778" y2="0.635" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.0066" y="1.1684" size="0.9906" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="0.9906" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.032" y1="-0.254" x2="-1.778" y2="0.254" layer="51"/>
<rectangle x1="1.778" y1="-0.254" x2="2.032" y2="0.254" layer="51"/>
</package>
<package name="0204/7">
type 0204, grid 7.5 mm</description>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0.762" x2="-2.286" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.286" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="-1.016" x2="2.54" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.016" x2="2.54" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.54" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.016" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.889" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.016" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.889" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="-1.778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="-1.778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.016" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.016" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.762" x2="2.54" y2="0.762" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="1.2954" size="0.9906" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.6256" y="-0.4826" size="0.9906" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.54" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.54" y2="0.254" layer="21"/>
</package>
<package name="0204V">
type 0204, grid 2.5 mm</description>
<wire x1="-1.27" y1="0" x2="1.27" y2="0" width="0.508" layer="51"/>
<wire x1="-0.127" y1="0" x2="0.127" y2="0" width="0.508" layer="21"/>
<circle x="-1.27" y="0" radius="0.889" width="0.1524" layer="51"/>
<circle x="-1.27" y="0" radius="0.635" width="0.0508" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.1336" y="1.1684" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/10">
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
</package>
<package name="0207/12">
type 0207, grid 12 mm</description>
<wire x1="6.35" y1="0" x2="5.334" y2="0" width="0.6096" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.334" y2="0" width="0.6096" layer="51"/>
<wire x1="4.445" y1="0" x2="4.064" y2="0" width="0.6096" layer="21"/>
<wire x1="-4.445" y1="0" x2="-4.064" y2="0" width="0.6096" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.175" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.6858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.445" y1="-0.3048" x2="5.3086" y2="0.3048" layer="21"/>
<rectangle x1="-5.3086" y1="-0.3048" x2="-4.445" y2="0.3048" layer="21"/>
</package>
<package name="0207/15">
type 0207, grid 15mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.6096" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.6096" layer="51"/>
<wire x1="5.715" y1="0" x2="4.064" y2="0" width="0.6096" layer="21"/>
<wire x1="-5.715" y1="0" x2="-4.064" y2="0" width="0.6096" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.8128" shape="octagon"/>
<rectangle x1="5.715" y1="-0.3048" x2="6.5786" y2="0.3048" layer="21"/>
<rectangle x1="-6.5786" y1="-0.3048" x2="-5.715" y2="0.3048" layer="21"/>
</package>
<package name="0207/2V">
type 0207, grid 2.5 mm</description>
<wire x1="-1.27" y1="0" x2="-0.381" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.254" y1="0" x2="0.254" y2="0" width="0.6096" layer="21"/>
<wire x1="0.381" y1="0" x2="1.27" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.27" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="1.016" width="0.1524" layer="51"/>
<text x="-0.0508" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.0508" y="-2.2352" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/5V">
type 0207, grid 5 mm</description>
<wire x1="-2.54" y1="0" x2="-0.889" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.762" y1="0" x2="0.762" y2="0" width="0.6096" layer="21"/>
<wire x1="0.889" y1="0" x2="2.54" y2="0" width="0.6096" layer="51"/>
<circle x="-2.54" y="0" radius="1.27" width="0.1016" layer="21"/>
<circle x="-2.54" y="0" radius="1.016" width="0.1524" layer="51"/>
<text x="-1.143" y="0.889" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.143" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/7">
type 0207, grid 7.5 mm</description>
<wire x1="-3.81" y1="0" x2="-3.429" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="3.429" y1="0" x2="3.81" y2="0" width="0.6096" layer="51"/>
<text x="-2.54" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.5588" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.429" y1="-0.3048" x2="-3.175" y2="0.3048" layer="51"/>
<rectangle x1="3.175" y1="-0.3048" x2="3.429" y2="0.3048" layer="51"/>
</package>
<package name="0309/10">
type 0309, grid 10mm</description>
<wire x1="-4.699" y1="0" x2="-5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-4.318" y1="1.27" x2="-4.064" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.318" y1="-1.27" x2="-4.064" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="4.064" y1="-1.524" x2="4.318" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="4.064" y1="1.524" x2="4.318" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.318" y1="-1.27" x2="-4.318" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-4.064" y1="1.524" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.397" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="-1.524" x2="-3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-1.397" x2="-3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="1.397" x2="3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="1.397" x2="-3.302" y2="1.397" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-1.397" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-1.397" x2="-3.302" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="4.064" y1="1.524" x2="3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-1.524" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-1.27" x2="4.318" y2="1.27" width="0.1524" layer="51"/>
<wire x1="5.08" y1="0" x2="4.699" y2="0" width="0.6096" layer="51"/>
<text x="-4.191" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-0.6858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.6228" y1="-0.3048" x2="-4.318" y2="0.3048" layer="51"/>
<rectangle x1="4.318" y1="-0.3048" x2="4.6228" y2="0.3048" layer="51"/>
</package>
<package name="0309/12">
type 0309, grid 12.5 mm</description>
<wire x1="6.35" y1="0" x2="5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-4.318" y1="-1.27" x2="-4.318" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-1.27" x2="4.318" y2="1.27" width="0.1524" layer="21"/>
<rectangle x1="4.318" y1="-0.3048" x2="5.1816" y2="0.3048" layer="21"/>
<rectangle x1="-5.1816" y1="-0.3048" x2="-4.318" y2="0.3048" layer="21"/>
</package>
<package name="0309V">
type 0309, grid 2.5 mm</description>
<wire x1="1.27" y1="0" x2="0.635" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.635" y1="0" x2="-1.27" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.524" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="0.762" width="0.1524" layer="51"/>
<text x="0.254" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.254" y="-2.2098" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-0.3048" x2="0.5588" y2="0.3048" layer="51"/>
<rectangle x1="-0.635" y1="-0.3048" x2="-0.3302" y2="0.3048" layer="51"/>
<rectangle x1="-0.3302" y1="-0.3048" x2="0.254" y2="0.3048" layer="21"/>
</package>
<package name="0411/12">
type 0411, grid 12.5 mm</description>
<wire x1="6.35" y1="0" x2="5.461" y2="0" width="0.762" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.461" y2="0" width="0.762" layer="51"/>
<wire x1="5.08" y1="-1.651" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.032" x2="5.08" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.08" y1="-1.651" x2="-4.699" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="4.699" y1="-2.032" x2="5.08" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.651" x2="-4.699" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="2.032" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="1.905" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.032" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="-1.905" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="3.937" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="3.937" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.651" x2="-5.08" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.032" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-2.032" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="0.9144" shape="octagon"/>
<text x="-5.08" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.5814" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.3594" y1="-0.381" x2="-5.08" y2="0.381" layer="21"/>
<rectangle x1="5.08" y1="-0.381" x2="5.3594" y2="0.381" layer="21"/>
</package>
<package name="0411/15">
type 0411, grid 15 mm</description>
<wire x1="-7.62" y1="0" x2="-6.35" y2="0" width="0.762" layer="51"/>
<wire x1="6.35" y1="0" x2="7.62" y2="0" width="0.762" layer="51"/>
<pad name="1" x="-7.62" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.9144" shape="octagon"/>
<rectangle x1="5.08" y1="-0.381" x2="6.477" y2="0.381" layer="21"/>
<rectangle x1="-6.477" y1="-0.381" x2="-5.08" y2="0.381" layer="21"/>
</package>
<package name="0411V">
type 0411, grid 3.81 mm</description>
<wire x1="1.27" y1="0" x2="0.3048" y2="0" width="0.762" layer="51"/>
<wire x1="-1.5748" y1="0" x2="-2.54" y2="0" width="0.762" layer="51"/>
<circle x="-2.54" y="0" radius="2.032" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.9144" shape="octagon"/>
<text x="-0.508" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.5334" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.4732" y1="-0.381" x2="0.2032" y2="0.381" layer="21"/>
</package>
<package name="0414/15">
type 0414, grid 15 mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.096" y1="1.905" x2="-5.842" y2="2.159" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.096" y1="-1.905" x2="-5.842" y2="-2.159" width="0.1524" layer="21" curve="90"/>
<wire x1="5.842" y1="-2.159" x2="6.096" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<wire x1="5.842" y1="2.159" x2="6.096" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.096" y1="-1.905" x2="-6.096" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="2.159" x2="-4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.032" x2="-4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-2.159" x2="-4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.032" x2="-4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.032" x2="4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.032" x2="-4.826" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="5.842" y1="2.159" x2="4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-2.159" x2="4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-1.905" x2="6.096" y2="1.905" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="1.016" shape="octagon"/>
<text x="-6.096" y="2.5654" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="6.096" y1="-0.4064" x2="6.5024" y2="0.4064" layer="21"/>
<rectangle x1="-6.5024" y1="-0.4064" x2="-6.096" y2="0.4064" layer="21"/>
</package>
<package name="0414V">
type 0414, grid 5 mm</description>
<wire x1="2.54" y1="0" x2="1.397" y2="0" width="0.8128" layer="51"/>
<wire x1="-2.54" y1="0" x2="-1.397" y2="0" width="0.8128" layer="51"/>
<circle x="-2.54" y="0" radius="2.159" width="0.1524" layer="21"/>
<circle x="-2.54" y="0" radius="1.143" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="1.016" shape="octagon"/>
<text x="-0.381" y="1.1684" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.381" y="-2.3622" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.2954" y1="-0.4064" x2="1.2954" y2="0.4064" layer="21"/>
</package>
<package name="0617/17">
type 0617, grid 17.5 mm</description>
<wire x1="-8.89" y1="0" x2="-8.636" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.874" y1="3.048" x2="-6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.794" x2="-6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-3.048" x2="-6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-2.794" x2="-6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="2.794" x2="6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="2.794" x2="-6.731" y2="2.794" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.794" x2="6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.794" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="7.874" y1="3.048" x2="6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="7.874" y1="-3.048" x2="6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-2.667" x2="-8.255" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="1.016" x2="-8.255" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="1.016" x2="-8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.667" x2="8.255" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="8.255" y1="1.016" x2="8.255" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="8.255" y1="1.016" x2="8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.636" y1="0" x2="8.89" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.255" y1="2.667" x2="-7.874" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="7.874" y1="3.048" x2="8.255" y2="2.667" width="0.1524" layer="21" curve="-90"/>
<wire x1="-8.255" y1="-2.667" x2="-7.874" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="7.874" y1="-3.048" x2="8.255" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<pad name="1" x="-8.89" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="8.89" y="0" drill="1.016" shape="octagon"/>
<text x="-8.128" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.096" y="-0.7112" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-8.5344" y1="-0.4064" x2="-8.2296" y2="0.4064" layer="51"/>
<rectangle x1="8.2296" y1="-0.4064" x2="8.5344" y2="0.4064" layer="51"/>
</package>
<package name="0617/22">
type 0617, grid 22.5 mm</description>
<wire x1="-10.287" y1="0" x2="-11.43" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.255" y1="-2.667" x2="-8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.667" x2="8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="10.287" y2="0" width="0.8128" layer="51"/>
<pad name="1" x="-11.43" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="11.43" y="0" drill="1.016" shape="octagon"/>
<text x="-8.255" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.477" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-10.1854" y1="-0.4064" x2="-8.255" y2="0.4064" layer="21"/>
<rectangle x1="8.255" y1="-0.4064" x2="10.1854" y2="0.4064" layer="21"/>
</package>
<package name="0617V">
type 0617, grid 5 mm</description>
<wire x1="-2.54" y1="0" x2="-1.27" y2="0" width="0.8128" layer="51"/>
<wire x1="1.27" y1="0" x2="2.54" y2="0" width="0.8128" layer="51"/>
<circle x="-2.54" y="0" radius="3.048" width="0.1524" layer="21"/>
<text x="0.635" y="1.4224" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.635" y="-2.6162" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.3208" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="0922/22">
type 0922, grid 22.5 mm</description>
<wire x1="11.43" y1="0" x2="10.795" y2="0" width="0.8128" layer="51"/>
<wire x1="-11.43" y1="0" x2="-10.795" y2="0" width="0.8128" layer="51"/>
<wire x1="-10.16" y1="-4.191" x2="-10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="4.572" x2="-8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="4.318" x2="-8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="-4.572" x2="-8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="-4.318" x2="-8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="4.318" x2="8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="4.318" x2="-8.636" y2="4.318" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-4.318" x2="8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-4.318" x2="-8.636" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="9.779" y1="4.572" x2="8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="9.779" y1="-4.572" x2="8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.191" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.191" x2="-9.779" y2="-4.572" width="0.1524" layer="21" curve="90"/>
<wire x1="-10.16" y1="4.191" x2="-9.779" y2="4.572" width="0.1524" layer="21" curve="-90"/>
<wire x1="9.779" y1="-4.572" x2="10.16" y2="-4.191" width="0.1524" layer="21" curve="90"/>
<wire x1="9.779" y1="4.572" x2="10.16" y2="4.191" width="0.1524" layer="21" curve="-90"/>
<text x="-10.16" y="5.1054" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-10.7188" y1="-0.4064" x2="-10.16" y2="0.4064" layer="51"/>
<rectangle x1="10.16" y1="-0.4064" x2="10.3124" y2="0.4064" layer="21"/>
<rectangle x1="-10.3124" y1="-0.4064" x2="-10.16" y2="0.4064" layer="21"/>
<rectangle x1="10.16" y1="-0.4064" x2="10.7188" y2="0.4064" layer="51"/>
</package>
<package name="P0613V">
type 0613, grid 5 mm</description>
<circle x="-2.54" y="0" radius="2.286" width="0.1524" layer="21"/>
<text x="-0.254" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.254" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.2954" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="P0613/15">
type 0613, grid 15 mm</description>
<wire x1="7.62" y1="0" x2="6.985" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.985" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.477" y1="2.032" x2="-6.223" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.477" y1="-2.032" x2="-6.223" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="6.223" y1="-2.286" x2="6.477" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="6.223" y1="2.286" x2="6.477" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.223" y1="2.286" x2="-5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.159" x2="-5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="-2.286" x2="-5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-2.159" x2="-5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="2.159" x2="5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="2.159" x2="-5.207" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.159" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.159" x2="-5.207" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="6.223" y1="2.286" x2="5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="6.223" y1="-2.286" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-0.635" x2="6.477" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-0.635" x2="6.477" y2="0.635" width="0.1524" layer="51"/>
<wire x1="6.477" y1="2.032" x2="6.477" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-2.032" x2="-6.477" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="0.635" x2="-6.477" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="0.635" x2="-6.477" y2="2.032" width="0.1524" layer="21"/>
<text x="-6.477" y="2.6924" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-0.7112" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-7.0358" y1="-0.4064" x2="-6.477" y2="0.4064" layer="51"/>
<rectangle x1="6.477" y1="-0.4064" x2="7.0358" y2="0.4064" layer="51"/>
</package>
<package name="P0817/22">
type 0817, grid 22.5 mm</description>
<wire x1="-10.414" y1="0" x2="-11.43" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.509" y1="-3.429" x2="-8.509" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="3.81" x2="-7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="3.556" x2="-7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="-3.81" x2="-7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-3.556" x2="-7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="3.556" x2="7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="3.556" x2="-6.985" y2="3.556" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-3.556" x2="7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-3.556" x2="-6.985" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="8.128" y1="3.81" x2="7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="8.128" y1="-3.81" x2="7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.429" x2="8.509" y2="3.429" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="10.414" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.509" y1="3.429" x2="-8.128" y2="3.81" width="0.1524" layer="21" curve="-90"/>
<wire x1="-8.509" y1="-3.429" x2="-8.128" y2="-3.81" width="0.1524" layer="21" curve="90"/>
<wire x1="8.128" y1="3.81" x2="8.509" y2="3.429" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.128" y1="-3.81" x2="8.509" y2="-3.429" width="0.1524" layer="21" curve="90"/>
<text x="-8.382" y="4.2164" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.223" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="6.604" y="-2.2606" size="1.27" layer="51" ratio="10" rot="R90">0817</text>
<rectangle x1="8.509" y1="-0.4064" x2="10.3124" y2="0.4064" layer="21"/>
<rectangle x1="-10.3124" y1="-0.4064" x2="-8.509" y2="0.4064" layer="21"/>
</package>
<package name="P0817V">
type 0817, grid 6.35 mm</description>
<wire x1="-3.81" y1="0" x2="-5.08" y2="0" width="0.8128" layer="51"/>
<wire x1="1.27" y1="0" x2="0" y2="0" width="0.8128" layer="51"/>
<circle x="-5.08" y="0" radius="3.81" width="0.1524" layer="21"/>
<circle x="-5.08" y="0" radius="1.27" width="0.1524" layer="51"/>
<pad name="1" x="-5.08" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="1.016" shape="octagon"/>
<text x="-1.016" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.016" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.858" y="2.032" size="1.016" layer="21" ratio="12">0817</text>
<rectangle x1="-3.81" y1="-0.4064" x2="0" y2="0.4064" layer="21"/>
</package>
<package name="V234/12">
type V234, grid 12.5 mm</description>
<wire x1="-4.953" y1="1.524" x2="-4.699" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="1.778" x2="4.953" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-1.778" x2="4.953" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.953" y1="-1.524" x2="-4.699" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.699" y1="1.778" x2="4.699" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="1.524" x2="-4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.778" x2="-4.699" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="4.953" y1="1.524" x2="4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0" x2="5.461" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.461" y2="0" width="0.8128" layer="51"/>
<pad name="1" x="-6.35" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="1.016" shape="octagon"/>
<text x="-4.953" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.953" y1="-0.4064" x2="5.4102" y2="0.4064" layer="21"/>
<rectangle x1="-5.4102" y1="-0.4064" x2="-4.953" y2="0.4064" layer="21"/>
</package>
<package name="V235/17">
type V235, grid 17.78 mm</description>
<wire x1="-6.731" y1="2.921" x2="6.731" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="2.54" x2="-7.112" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.921" x2="-6.731" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="7.112" y1="2.54" x2="7.112" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.89" y1="0" x2="7.874" y2="0" width="1.016" layer="51"/>
<wire x1="-7.874" y1="0" x2="-8.89" y2="0" width="1.016" layer="51"/>
<wire x1="-7.112" y1="-2.54" x2="-6.731" y2="-2.921" width="0.1524" layer="21" curve="90"/>
<wire x1="6.731" y1="2.921" x2="7.112" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.731" y1="-2.921" x2="7.112" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-7.112" y1="2.54" x2="-6.731" y2="2.921" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-8.89" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="8.89" y="0" drill="1.1938" shape="octagon"/>
<text x="-6.858" y="3.302" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.842" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="7.112" y1="-0.508" x2="7.747" y2="0.508" layer="21"/>
<rectangle x1="-7.747" y1="-0.508" x2="-7.112" y2="0.508" layer="21"/>
</package>
<package name="V526-0">
type V526-0, grid 2.5 mm</description>
<wire x1="-2.54" y1="1.016" x2="-2.286" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="1.27" x2="2.54" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="-1.27" x2="2.54" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.54" y1="-1.016" x2="-2.286" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.27" x2="-2.286" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.016" x2="2.54" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.27" x2="2.286" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.016" x2="-2.54" y2="-1.016" width="0.1524" layer="21"/>
<text x="-2.413" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.413" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0102R">
<description>&lt;b&gt;CECC Size RC2211&lt;/b&gt; Reflow Soldering&lt;p&gt;
source Beyschlag</description>
<wire x1="-1" y1="-0.5" x2="1" y2="-0.5" width="0.2032" layer="51"/>
<wire x1="1" y1="-0.5" x2="1" y2="0.5" width="0.2032" layer="51"/>
<wire x1="1" y1="0.5" x2="-1" y2="0.5" width="0.2032" layer="51"/>
<wire x1="-1" y1="0.5" x2="-1" y2="-0.5" width="0.2032" layer="51"/>
<smd name="1" x="-0.9" y="0" dx="0.5" dy="1.3" layer="1"/>
<smd name="2" x="0.9" y="0" dx="0.5" dy="1.3" layer="1"/>
<text x="-1.27" y="0.9525" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.2225" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0102W">
<description>&lt;b&gt;CECC Size RC2211&lt;/b&gt; Wave Soldering&lt;p&gt;
<smd name="1" x="-0.95" y="0" dx="0.6" dy="1.3" layer="1"/>
<smd name="2" x="0.95" y="0" dx="0.6" dy="1.3" layer="1"/>
</package>
<package name="MINI_MELF-0204R">
<description>&lt;b&gt;CECC Size RC3715&lt;/b&gt; Reflow Soldering&lt;p&gt;
<wire x1="-1.7" y1="-0.6" x2="1.7" y2="-0.6" width="0.2032" layer="51"/>
<wire x1="1.7" y1="-0.6" x2="1.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="1.7" y1="0.6" x2="-1.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-1.7" y1="0.6" x2="-1.7" y2="-0.6" width="0.2032" layer="51"/>
<wire x1="0.938" y1="0.6" x2="-0.938" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-0.938" y1="-0.6" x2="0.938" y2="-0.6" width="0.2032" layer="21"/>
<smd name="1" x="-1.5" y="0" dx="0.8" dy="1.6" layer="1"/>
<smd name="2" x="1.5" y="0" dx="0.8" dy="1.6" layer="1"/>
</package>
<package name="MINI_MELF-0204W">
<description>&lt;b&gt;CECC Size RC3715&lt;/b&gt; Wave Soldering&lt;p&gt;
<wire x1="0.684" y1="0.6" x2="-0.684" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-0.684" y1="-0.6" x2="0.684" y2="-0.6" width="0.2032" layer="21"/>
<smd name="1" x="-1.5" y="0" dx="1.2" dy="1.6" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.2" dy="1.6" layer="1"/>
</package>
<package name="MINI_MELF-0207R">
<description>&lt;b&gt;CECC Size RC6123&lt;/b&gt; Reflow Soldering&lt;p&gt;
<wire x1="-2.8" y1="-1" x2="2.8" y2="-1" width="0.2032" layer="51"/>
<wire x1="2.8" y1="-1" x2="2.8" y2="1" width="0.2032" layer="51"/>
<wire x1="2.8" y1="1" x2="-2.8" y2="1" width="0.2032" layer="51"/>
<wire x1="-2.8" y1="1" x2="-2.8" y2="-1" width="0.2032" layer="51"/>
<wire x1="1.2125" y1="1" x2="-1.2125" y2="1" width="0.2032" layer="21"/>
<wire x1="-1.2125" y1="-1" x2="1.2125" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-2.25" y="0" dx="1.6" dy="2.5" layer="1"/>
<smd name="2" x="2.25" y="0" dx="1.6" dy="2.5" layer="1"/>
<text x="-2.2225" y="1.5875" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.2225" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0207W">
<description>&lt;b&gt;CECC Size RC6123&lt;/b&gt; Wave Soldering&lt;p&gt;
<wire x1="1.149" y1="1" x2="-1.149" y2="1" width="0.2032" layer="21"/>
<wire x1="-1.149" y1="-1" x2="1.149" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-2.6" y="0" dx="2.4" dy="2.5" layer="1"/>
<smd name="2" x="2.6" y="0" dx="2.4" dy="2.5" layer="1"/>
<text x="-2.54" y="1.5875" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="0922V">
type 0922, grid 7.5 mm</description>
<wire x1="-5.08" y1="0" x2="-3.81" y2="0" width="0.8128" layer="51"/>
<circle x="-5.08" y="0" radius="4.572" width="0.1524" layer="21"/>
<circle x="-5.08" y="0" radius="1.905" width="0.1524" layer="21"/>
<text x="-0.508" y="1.6764" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.508" y="-2.9972" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.858" y="2.54" size="1.016" layer="21" ratio="12">0922</text>
<rectangle x1="-3.81" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="RDH/15">
type RDH, grid 15 mm</description>
<wire x1="-7.62" y1="0" x2="-6.858" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.096" y1="3.048" x2="-5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="2.794" x2="-5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-3.048" x2="-5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.794" x2="-5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.794" x2="5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.794" x2="-4.953" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-2.794" x2="5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-2.794" x2="-4.953" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="6.096" y1="3.048" x2="5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-3.048" x2="5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-2.667" x2="-6.477" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="1.016" x2="-6.477" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="1.016" x2="-6.477" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-2.667" x2="6.477" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="6.477" y1="1.016" x2="6.477" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="6.477" y1="1.016" x2="6.477" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.858" y1="0" x2="7.62" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.477" y1="2.667" x2="-6.096" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="3.048" x2="6.477" y2="2.667" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.477" y1="-2.667" x2="-6.096" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="6.096" y1="-3.048" x2="6.477" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<text x="-6.35" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="4.572" y="-1.7272" size="1.27" layer="51" ratio="10" rot="R90">RDH</text>
<rectangle x1="-6.7564" y1="-0.4064" x2="-6.4516" y2="0.4064" layer="51"/>
<rectangle x1="6.4516" y1="-0.4064" x2="6.7564" y2="0.4064" layer="51"/>
</package>
<package name="MINI_MELF-0102AX">
<description>&lt;b&gt;Mini MELF 0102 Axial&lt;/b&gt;</description>
<circle x="0" y="0" radius="0.6" width="0" layer="51"/>
<circle x="0" y="0" radius="0.6" width="0" layer="52"/>
<smd name="1" x="0" y="0" dx="1.9" dy="1.9" layer="1" roundness="100"/>
<smd name="2" x="0" y="0" dx="1.9" dy="1.9" layer="16" roundness="100"/>
<hole x="0" y="0" drill="1.3"/>
</package>
<package name="R0201">
<description>&lt;b&gt;RESISTOR&lt;/b&gt; chip&lt;p&gt;
Source: http://www.vishay.com/docs/20008/dcrcw.pdf</description>
<smd name="1" x="-0.255" y="0" dx="0.28" dy="0.43" layer="1"/>
<smd name="2" x="0.255" y="0" dx="0.28" dy="0.43" layer="1"/>
<rectangle x1="-0.3" y1="-0.15" x2="-0.15" y2="0.15" layer="51"/>
<rectangle x1="0.15" y1="-0.15" x2="0.3" y2="0.15" layer="51"/>
<rectangle x1="-0.15" y1="-0.15" x2="0.15" y2="0.15" layer="21"/>
</package>
<package name="VTA52">
<description>&lt;b&gt;Bulk Metal® Foil Technology&lt;/b&gt;, Tubular Axial Lead Resistors, Meets or Exceeds MIL-R-39005 Requirements&lt;p&gt;
MIL SIZE RBR52&lt;br&gt;
Source: VISHAY .. vta56.pdf</description>
<wire x1="-15.24" y1="0" x2="-13.97" y2="0" width="0.6096" layer="51"/>
<wire x1="12.6225" y1="0.025" x2="12.6225" y2="4.725" width="0.1524" layer="21"/>
<wire x1="12.6225" y1="4.725" x2="-12.6225" y2="4.725" width="0.1524" layer="21"/>
<wire x1="-12.6225" y1="4.725" x2="-12.6225" y2="0.025" width="0.1524" layer="21"/>
<wire x1="-12.6225" y1="0.025" x2="-12.6225" y2="-4.65" width="0.1524" layer="21"/>
<wire x1="-12.6225" y1="-4.65" x2="12.6225" y2="-4.65" width="0.1524" layer="21"/>
<wire x1="12.6225" y1="-4.65" x2="12.6225" y2="0.025" width="0.1524" layer="21"/>
<wire x1="13.97" y1="0" x2="15.24" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-15.24" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="15.24" y="0" drill="1.1" shape="octagon"/>
<text x="-3.81" y="5.08" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-13.97" y1="-0.3048" x2="-12.5675" y2="0.3048" layer="21"/>
<rectangle x1="12.5675" y1="-0.3048" x2="13.97" y2="0.3048" layer="21"/>
</package>
<package name="VTA53">
MIL SIZE RBR53&lt;br&gt;
<wire x1="-12.065" y1="0" x2="-10.795" y2="0" width="0.6096" layer="51"/>
<wire x1="9.8975" y1="0" x2="9.8975" y2="4.7" width="0.1524" layer="21"/>
<wire x1="9.8975" y1="4.7" x2="-9.8975" y2="4.7" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="4.7" x2="-9.8975" y2="0" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="0" x2="-9.8975" y2="-4.675" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="-4.675" x2="9.8975" y2="-4.675" width="0.1524" layer="21"/>
<wire x1="9.8975" y1="-4.675" x2="9.8975" y2="0" width="0.1524" layer="21"/>
<wire x1="10.795" y1="0" x2="12.065" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-12.065" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="12.065" y="0" drill="1.1" shape="octagon"/>
<rectangle x1="-10.795" y1="-0.3048" x2="-9.8425" y2="0.3048" layer="21"/>
<rectangle x1="9.8425" y1="-0.3048" x2="10.795" y2="0.3048" layer="21"/>
</package>
<package name="VTA54">
MIL SIZE RBR54&lt;br&gt;
<wire x1="9.8975" y1="0" x2="9.8975" y2="3.3" width="0.1524" layer="21"/>
<wire x1="9.8975" y1="3.3" x2="-9.8975" y2="3.3" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="3.3" x2="-9.8975" y2="0" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="0" x2="-9.8975" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="-3.3" x2="9.8975" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="9.8975" y1="-3.3" x2="9.8975" y2="0" width="0.1524" layer="21"/>
<text x="-3.81" y="3.81" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="VTA55">
MIL SIZE RBR55&lt;br&gt;
<wire x1="-8.255" y1="0" x2="-6.985" y2="0" width="0.6096" layer="51"/>
<wire x1="6.405" y1="0" x2="6.405" y2="3.3" width="0.1524" layer="21"/>
<wire x1="6.405" y1="3.3" x2="-6.405" y2="3.3" width="0.1524" layer="21"/>
<wire x1="-6.405" y1="3.3" x2="-6.405" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.405" y1="0" x2="-6.405" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="-6.405" y1="-3.3" x2="6.405" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="6.405" y1="-3.3" x2="6.405" y2="0" width="0.1524" layer="21"/>
<wire x1="6.985" y1="0" x2="8.255" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-8.255" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="8.255" y="0" drill="1.1" shape="octagon"/>
<rectangle x1="-6.985" y1="-0.3048" x2="-6.35" y2="0.3048" layer="21"/>
<rectangle x1="6.35" y1="-0.3048" x2="6.985" y2="0.3048" layer="21"/>
</package>
<package name="VTA56">
MIL SIZE RBR56&lt;br&gt;
<wire x1="4.5" y1="0" x2="4.5" y2="3.3" width="0.1524" layer="21"/>
<wire x1="4.5" y1="3.3" x2="-4.5" y2="3.3" width="0.1524" layer="21"/>
<wire x1="-4.5" y1="3.3" x2="-4.5" y2="0" width="0.1524" layer="21"/>
<wire x1="-4.5" y1="0" x2="-4.5" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="-4.5" y1="-3.3" x2="4.5" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="4.5" y1="-3.3" x2="4.5" y2="0" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="6.35" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-6.35" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="1.1" shape="octagon"/>
<rectangle x1="-5.08" y1="-0.3048" x2="-4.445" y2="0.3048" layer="21"/>
<rectangle x1="4.445" y1="-0.3048" x2="5.08" y2="0.3048" layer="21"/>
</package>
<package name="VMTA55">
MIL SIZE RNC55&lt;br&gt;
<wire x1="-5.08" y1="0" x2="-4.26" y2="0" width="0.6096" layer="51"/>
<wire x1="3.3375" y1="-1.45" x2="3.3375" y2="1.45" width="0.1524" layer="21"/>
<wire x1="3.3375" y1="1.45" x2="-3.3625" y2="1.45" width="0.1524" layer="21"/>
<wire x1="-3.3625" y1="1.45" x2="-3.3625" y2="-1.45" width="0.1524" layer="21"/>
<wire x1="-3.3625" y1="-1.45" x2="3.3375" y2="-1.45" width="0.1524" layer="21"/>
<wire x1="4.235" y1="0" x2="5.08" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-5.08" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="1.1" shape="octagon"/>
<text x="-3.175" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-4.26" y1="-0.3048" x2="-3.3075" y2="0.3048" layer="21"/>
<rectangle x1="3.2825" y1="-0.3048" x2="4.235" y2="0.3048" layer="21"/>
</package>
<package name="VMTB60">
MIL SIZE RNC60&lt;br&gt;
<wire x1="-6.35" y1="0" x2="-5.585" y2="0" width="0.6096" layer="51"/>
<wire x1="4.6875" y1="-1.95" x2="4.6875" y2="1.95" width="0.1524" layer="21"/>
<wire x1="4.6875" y1="1.95" x2="-4.6875" y2="1.95" width="0.1524" layer="21"/>
<wire x1="-4.6875" y1="1.95" x2="-4.6875" y2="-1.95" width="0.1524" layer="21"/>
<wire x1="-4.6875" y1="-1.95" x2="4.6875" y2="-1.95" width="0.1524" layer="21"/>
<wire x1="5.585" y1="0" x2="6.35" y2="0" width="0.6096" layer="51"/>
<text x="-4.445" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.445" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.585" y1="-0.3048" x2="-4.6325" y2="0.3048" layer="21"/>
<rectangle x1="4.6325" y1="-0.3048" x2="5.585" y2="0.3048" layer="21"/>
</package>
<package name="R4527">
<description>&lt;b&gt;Package 4527&lt;/b&gt;&lt;p&gt;
Source: http://www.vishay.com/docs/31059/wsrhigh.pdf</description>
<wire x1="-5.675" y1="-3.375" x2="5.65" y2="-3.375" width="0.2032" layer="21"/>
<wire x1="5.65" y1="-3.375" x2="5.65" y2="3.375" width="0.2032" layer="51"/>
<wire x1="5.65" y1="3.375" x2="-5.675" y2="3.375" width="0.2032" layer="21"/>
<wire x1="-5.675" y1="3.375" x2="-5.675" y2="-3.375" width="0.2032" layer="51"/>
<smd name="1" x="-4.575" y="0" dx="3.94" dy="5.84" layer="1"/>
<smd name="2" x="4.575" y="0" dx="3.94" dy="5.84" layer="1"/>
<text x="-5.715" y="3.81" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.715" y="-5.08" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC0001">
<description>&lt;b&gt;Wirewound Resistors, Precision Power&lt;/b&gt;&lt;p&gt;
Source: VISHAY wscwsn.pdf</description>
<wire x1="-3.075" y1="1.8" x2="-3.075" y2="-1.8" width="0.2032" layer="51"/>
<wire x1="-3.075" y1="-1.8" x2="3.075" y2="-1.8" width="0.2032" layer="21"/>
<wire x1="3.075" y1="-1.8" x2="3.075" y2="1.8" width="0.2032" layer="51"/>
<wire x1="3.075" y1="1.8" x2="-3.075" y2="1.8" width="0.2032" layer="21"/>
<wire x1="-3.075" y1="1.8" x2="-3.075" y2="1.606" width="0.2032" layer="21"/>
<wire x1="-3.075" y1="-1.606" x2="-3.075" y2="-1.8" width="0.2032" layer="21"/>
<wire x1="3.075" y1="1.606" x2="3.075" y2="1.8" width="0.2032" layer="21"/>
<wire x1="3.075" y1="-1.8" x2="3.075" y2="-1.606" width="0.2032" layer="21"/>
<smd name="1" x="-2.675" y="0" dx="2.29" dy="2.92" layer="1"/>
<smd name="2" x="2.675" y="0" dx="2.29" dy="2.92" layer="1"/>
<text x="-2.544" y="2.229" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.544" y="-3.501" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC0002">
<wire x1="-5.55" y1="3.375" x2="-5.55" y2="-3.375" width="0.2032" layer="51"/>
<wire x1="-5.55" y1="-3.375" x2="5.55" y2="-3.375" width="0.2032" layer="21"/>
<wire x1="5.55" y1="-3.375" x2="5.55" y2="3.375" width="0.2032" layer="51"/>
<wire x1="5.55" y1="3.375" x2="-5.55" y2="3.375" width="0.2032" layer="21"/>
<smd name="1" x="-4.575" y="0.025" dx="3.94" dy="5.84" layer="1"/>
<text x="-5.65" y="3.9" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.65" y="-5.15" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC01/2">
<wire x1="-2.45" y1="1.475" x2="-2.45" y2="-1.475" width="0.2032" layer="51"/>
<wire x1="-2.45" y1="-1.475" x2="2.45" y2="-1.475" width="0.2032" layer="21"/>
<wire x1="2.45" y1="-1.475" x2="2.45" y2="1.475" width="0.2032" layer="51"/>
<wire x1="2.45" y1="1.475" x2="-2.45" y2="1.475" width="0.2032" layer="21"/>
<wire x1="-2.45" y1="1.475" x2="-2.45" y2="1.106" width="0.2032" layer="21"/>
<wire x1="-2.45" y1="-1.106" x2="-2.45" y2="-1.475" width="0.2032" layer="21"/>
<wire x1="2.45" y1="1.106" x2="2.45" y2="1.475" width="0.2032" layer="21"/>
<wire x1="2.45" y1="-1.475" x2="2.45" y2="-1.106" width="0.2032" layer="21"/>
<smd name="1" x="-2.1" y="0" dx="2.16" dy="1.78" layer="1"/>
<smd name="2" x="2.1" y="0" dx="2.16" dy="1.78" layer="1"/>
<text x="-2.544" y="1.904" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.544" y="-3.176" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC2515">
<wire x1="-3.075" y1="-1.8" x2="3.05" y2="-1.8" width="0.2032" layer="21"/>
<wire x1="3.05" y1="-1.8" x2="3.05" y2="1.8" width="0.2032" layer="51"/>
<wire x1="3.05" y1="1.8" x2="-3.075" y2="1.8" width="0.2032" layer="21"/>
<wire x1="3.05" y1="1.606" x2="3.05" y2="1.8" width="0.2032" layer="21"/>
<wire x1="3.05" y1="-1.8" x2="3.05" y2="-1.606" width="0.2032" layer="21"/>
<text x="-3.2" y="2.15" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.2" y="-3.4" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC4527">
<wire x1="-5.675" y1="3.4" x2="-5.675" y2="-3.375" width="0.2032" layer="51"/>
<wire x1="-5.675" y1="-3.375" x2="5.675" y2="-3.375" width="0.2032" layer="21"/>
<wire x1="5.675" y1="-3.375" x2="5.675" y2="3.4" width="0.2032" layer="51"/>
<wire x1="5.675" y1="3.4" x2="-5.675" y2="3.4" width="0.2032" layer="21"/>
<text x="-5.775" y="3.925" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.775" y="-5.15" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC6927">
<wire x1="-8.65" y1="3.375" x2="-8.65" y2="-3.375" width="0.2032" layer="51"/>
<wire x1="-8.65" y1="-3.375" x2="8.65" y2="-3.375" width="0.2032" layer="21"/>
<wire x1="8.65" y1="-3.375" x2="8.65" y2="3.375" width="0.2032" layer="51"/>
<wire x1="8.65" y1="3.375" x2="-8.65" y2="3.375" width="0.2032" layer="21"/>
<smd name="1" x="-7.95" y="0.025" dx="3.94" dy="5.97" layer="1"/>
<smd name="2" x="7.95" y="0" dx="3.94" dy="5.97" layer="1"/>
<text x="-8.75" y="3.9" size="1.27" layer="25">&gt;NAME</text>
<text x="-8.75" y="-5.15" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R1218">
<description>&lt;b&gt;CRCW1218 Thick Film, Rectangular Chip Resistors&lt;/b&gt;&lt;p&gt;
Source: http://www.vishay.com .. dcrcw.pdf</description>
<wire x1="-0.913" y1="-2.219" x2="0.939" y2="-2.219" width="0.1524" layer="51"/>
<wire x1="0.913" y1="2.219" x2="-0.939" y2="2.219" width="0.1524" layer="51"/>
<smd name="1" x="-1.475" y="0" dx="1.05" dy="4.9" layer="1"/>
<smd name="2" x="1.475" y="0" dx="1.05" dy="4.9" layer="1"/>
<text x="-2.54" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-2.3" x2="-0.9009" y2="2.3" layer="51"/>
<rectangle x1="0.9144" y1="-2.3" x2="1.6645" y2="2.3" layer="51"/>
</package>
<package name="1812X7R">
<description>&lt;b&gt;Chip Monolithic Ceramic Capacitors&lt;/b&gt; Medium Voltage High Capacitance for General Use&lt;p&gt;
Source: http://www.murata.com .. GRM43DR72E224KW01.pdf</description>
<wire x1="-1.1" y1="1.5" x2="1.1" y2="1.5" width="0.2032" layer="51"/>
<wire x1="1.1" y1="-1.5" x2="-1.1" y2="-1.5" width="0.2032" layer="51"/>
<wire x1="-0.6" y1="1.5" x2="0.6" y2="1.5" width="0.2032" layer="21"/>
<wire x1="0.6" y1="-1.5" x2="-0.6" y2="-1.5" width="0.2032" layer="21"/>
<smd name="1" x="-1.425" y="0" dx="0.8" dy="3.5" layer="1"/>
<smd name="2" x="1.425" y="0" dx="0.8" dy="3.5" layer="1" rot="R180"/>
<text x="-1.9456" y="1.9958" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.9456" y="-3.7738" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.4" y1="-1.6" x2="-1.1" y2="1.6" layer="51"/>
<rectangle x1="1.1" y1="-1.6" x2="1.4" y2="1.6" layer="51" rot="R180"/>
</package>
<package name="CT3216">
<description>&lt;b&gt;TANTALUM CAPACITOR&lt;/b&gt;</description>
<wire x1="-2.973" y1="1.483" x2="2.973" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-1.483" x2="-2.973" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-1.483" x2="-2.973" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.973" y1="1.483" x2="2.973" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-1.651" y1="0.559" x2="-1.651" y2="-0.559" width="0.1524" layer="51"/>
<wire x1="1.651" y1="0.559" x2="1.651" y2="-0.559" width="0.1524" layer="51"/>
<wire x1="-1.535" y1="0.798" x2="-1.535" y2="-0.798" width="0.2032" layer="51"/>
<wire x1="-1.535" y1="-0.798" x2="1.535" y2="-0.798" width="0.2032" layer="51"/>
<wire x1="1.535" y1="-0.798" x2="1.535" y2="0.798" width="0.2032" layer="51"/>
<wire x1="1.535" y1="0.798" x2="-1.535" y2="0.798" width="0.2032" layer="51"/>
<wire x1="-0.7" y1="0" x2="-1.26" y2="0" width="0.2032" layer="51"/>
<wire x1="-0.97" y1="0.26" x2="-0.97" y2="-0.3" width="0.2032" layer="51"/>
<smd name="+" x="-1.4" y="0" dx="2" dy="1.2" layer="1"/>
<smd name="-" x="1.4" y="0" dx="2" dy="1.2" layer="1"/>
<text x="-2.54" y="1.27" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="CT3528">
<wire x1="-2.973" y1="1.983" x2="2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-1.983" x2="-2.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-1.983" x2="-2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="1.983" x2="2.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-1.637" y1="-1.383" x2="-1.637" y2="1.383" width="0.2032" layer="51"/>
<wire x1="-1.778" y1="1.016" x2="-1.778" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="1.637" y1="1.383" x2="-1.637" y2="1.383" width="0.2032" layer="51"/>
<wire x1="1.637" y1="-1.383" x2="-1.637" y2="-1.383" width="0.2032" layer="51"/>
<wire x1="1.778" y1="1.016" x2="1.778" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="1.637" y1="-1.383" x2="1.637" y2="1.383" width="0.2032" layer="51"/>
<wire x1="-0.68" y1="0" x2="-1.31" y2="0" width="0.2032" layer="51"/>
<wire x1="-1" y1="0.3" x2="-1" y2="-0.33" width="0.2032" layer="51"/>
<smd name="+" x="-1.5" y="0" dx="2" dy="2.2" layer="1"/>
<smd name="-" x="1.5" y="0" dx="2" dy="2.2" layer="1"/>
<text x="-2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="CT6032">
<wire x1="-4.473" y1="1.983" x2="4.473" y2="1.983" width="0.0508" layer="39"/>
<wire x1="4.473" y1="-1.983" x2="-4.473" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-4.473" y1="-1.983" x2="-4.473" y2="1.983" width="0.0508" layer="39"/>
<wire x1="4.473" y1="1.983" x2="4.473" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-2.932" y1="-1.637" x2="-2.932" y2="1.637" width="0.2032" layer="51"/>
<wire x1="-3.073" y1="1.067" x2="-3.073" y2="-1.067" width="0.1524" layer="51"/>
<wire x1="2.957" y1="1.637" x2="-2.932" y2="1.637" width="0.2032" layer="51"/>
<wire x1="2.957" y1="-1.637" x2="-2.932" y2="-1.637" width="0.2032" layer="51"/>
<wire x1="3.073" y1="1.067" x2="3.073" y2="-1.067" width="0.1524" layer="51"/>
<wire x1="2.957" y1="-1.637" x2="2.957" y2="1.637" width="0.2032" layer="51"/>
<wire x1="-1.18" y1="0" x2="-2.45" y2="0" width="0.2032" layer="51"/>
<wire x1="-1.8" y1="0.63" x2="-1.8" y2="-0.64" width="0.2032" layer="51"/>
<smd name="+" x="-2.5" y="0" dx="2.6" dy="2.2" layer="1"/>
<smd name="-" x="2.5" y="0" dx="2.6" dy="2.2" layer="1"/>
</package>
<package name="CT7343">
<wire x1="-4.973" y1="2.483" x2="4.973" y2="2.483" width="0.0508" layer="39"/>
<wire x1="4.973" y1="-2.483" x2="-4.973" y2="-2.483" width="0.0508" layer="39"/>
<wire x1="-4.973" y1="-2.483" x2="-4.973" y2="2.483" width="0.0508" layer="39"/>
<wire x1="4.973" y1="2.483" x2="4.973" y2="-2.483" width="0.0508" layer="39"/>
<wire x1="-3.592" y1="-2.195" x2="-3.592" y2="2.195" width="0.2032" layer="51"/>
<wire x1="-3.734" y1="1.143" x2="-3.734" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="3.582" y1="2.195" x2="-3.592" y2="2.195" width="0.2032" layer="51"/>
<wire x1="3.582" y1="-2.195" x2="-3.592" y2="-2.195" width="0.2032" layer="51"/>
<wire x1="3.734" y1="1.143" x2="3.734" y2="-1.143" width="0.1524" layer="51"/>
<wire x1="3.582" y1="-2.195" x2="3.582" y2="2.195" width="0.2032" layer="51"/>
<wire x1="-2.04" y1="0" x2="-3.09" y2="0" width="0.2032" layer="51"/>
<wire x1="-2.55" y1="0.52" x2="-2.55" y2="-0.52" width="0.2032" layer="51"/>
<smd name="+" x="-3.2" y="0" dx="2.6" dy="2.4" layer="1"/>
<smd name="-" x="3.2" y="0" dx="2.6" dy="2.4" layer="1"/>
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="B45181A">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
body 5 x 5 mm, rectangle, grid 2.54 mm</description>
<wire x1="2.032" y1="2.286" x2="-1.651" y2="2.286" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.905" x2="2.413" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="-2.286" x2="2.032" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.524" x2="-1.651" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.6764" x2="-1.778" y2="1.0414" width="0.1524" layer="21"/>
<wire x1="-1.4478" y1="1.3716" x2="-2.1082" y2="1.3716" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.635" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-1.2192" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-1.2192" x2="-0.127" y2="-1.2192" width="0.1524" layer="51"/>
<wire x1="-0.127" y1="-1.2192" x2="-0.127" y2="1.2192" width="0.1524" layer="51"/>
<wire x1="-0.127" y1="1.2192" x2="-0.635" y2="1.2192" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="1.2192" x2="-0.635" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-2.286" x2="-2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.524" x2="-2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.032" y1="2.286" x2="2.413" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.032" y1="-2.286" x2="2.413" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<text x="-1.905" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.048" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="B45181B">
body 7.6 x 5 mm, rectangle, grid 5.08 mm</description>
<wire x1="3.302" y1="2.413" x2="-2.921" y2="2.413" width="0.1524" layer="21"/>
<wire x1="3.683" y1="2.032" x2="3.683" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-2.413" x2="3.302" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="-2.921" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.2192" x2="-0.127" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="-1.2192" x2="-0.127" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="1.2192" x2="-0.635" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.2192" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-2.413" x2="-3.683" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="-3.683" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="3.302" y1="2.413" x2="3.683" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.302" y1="-2.413" x2="3.683" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<pad name="+" x="-2.54" y="0" drill="0.8128"/>
<pad name="-" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.921" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="4.191" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="21"/>
</package>
<package name="B45181C">
body 12.7 x 7.6 mm, rectangle, grid 10.16 mm</description>
<wire x1="5.842" y1="3.683" x2="-5.461" y2="3.683" width="0.1524" layer="21"/>
<wire x1="6.223" y1="3.302" x2="6.223" y2="-3.302" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-3.683" x2="5.842" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="2.921" x2="-5.461" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="1.6764" x2="-4.318" y2="1.0414" width="0.1524" layer="21"/>
<wire x1="-3.9878" y1="1.3716" x2="-4.6482" y2="1.3716" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-1.2192" x2="-0.254" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.2192" x2="-0.254" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.2192" x2="-0.762" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.2192" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-3.683" x2="-6.223" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="2.921" x2="-6.223" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.842" y1="3.683" x2="6.223" y2="3.302" width="0.1524" layer="21" curve="-90"/>
<wire x1="5.842" y1="-3.683" x2="6.223" y2="-3.302" width="0.1524" layer="21" curve="90"/>
<pad name="+" x="-5.08" y="0" drill="0.9144"/>
<pad name="-" x="5.08" y="0" drill="0.9144" shape="octagon"/>
<text x="-5.334" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="B45181D">
body 12.5 x 12.5 mm, rectangle, grid 10.16 mm</description>
<wire x1="5.842" y1="6.223" x2="-5.08" y2="6.223" width="0.1524" layer="21"/>
<wire x1="6.223" y1="5.842" x2="6.223" y2="-5.842" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-6.223" x2="5.842" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="5.08" x2="-5.08" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-6.223" x2="-6.223" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="5.08" x2="-6.223" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="5.842" y1="6.223" x2="6.223" y2="5.842" width="0.1524" layer="21" curve="-90"/>
<wire x1="5.842" y1="-6.223" x2="6.223" y2="-5.842" width="0.1524" layer="21" curve="90"/>
<text x="-5.08" y="6.604" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TT2D4">
diameter 4 mm, grid 2.54 mm</description>
<wire x1="-1.016" y1="0" x2="-0.508" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-0.889" x2="-0.1778" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-0.1778" y1="-0.889" x2="-0.1778" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-0.1778" y1="0.889" x2="-0.508" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="0.889" x2="-0.508" y2="0" width="0.1524" layer="51"/>
<wire x1="0.508" y1="0" x2="1.016" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-1.143" x2="-1.143" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.397" x2="-0.889" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.6985" y1="1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="21" curve="-113.419135"/>
<wire x1="-1.6985" y1="-1.1153" x2="1.6985" y2="-1.1153" width="0.1524" layer="21" curve="113.419135"/>
<wire x1="-1.6985" y1="1.1153" x2="-1.6985" y2="-1.1153" width="0.1524" layer="51" curve="66.580865"/>
<wire x1="1.6985" y1="-1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="51" curve="66.580865"/>
<pad name="-" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128"/>
<text x="2.159" y="0.762" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.159" y="-1.905" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.127" y1="-0.9398" x2="0.5588" y2="0.9398" layer="51"/>
</package>
<package name="TT2D4L">
<wire x1="2.159" y1="7.747" x2="2.159" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="1.016" x2="1.524" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.651" x2="-1.524" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="1.016" x2="2.159" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-1.27" y1="2.54" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="-0.635" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.651" x2="-0.3048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="1.651" x2="-0.3048" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="3.429" x2="-0.635" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="3.429" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.54" x2="0.762" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="3.429" x2="-1.016" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="3.81" x2="-1.397" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="7.747" x2="-2.159" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="7.747" x2="2.159" y2="7.747" width="0.1524" layer="21" curve="-180"/>
<text x="-2.54" y="1.397" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.778" y="4.318" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="1.905" y="1.778" size="0.9906" layer="21" ratio="12" rot="R90">TT</text>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.016" layer="51"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.016" layer="51"/>
<rectangle x1="0.889" y1="-0.127" x2="1.651" y2="0.635" layer="51"/>
<rectangle x1="-1.651" y1="-0.127" x2="-0.889" y2="0.635" layer="51"/>
<rectangle x1="0" y1="1.6002" x2="0.4318" y2="3.4798" layer="21"/>
</package>
<package name="TT2D5">
diameter 5 mm, grid 2.54 mm</description>
<wire x1="-1.27" y1="1.016" x2="-1.27" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.397" x2="-1.651" y2="1.397" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.54" width="0.1524" layer="21"/>
<text x="2.54" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.54" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.762" y="-2.159" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT2D6">
diameter 6 mm, grid 2.54 mm</description>
<wire x1="-1.778" y1="1.524" x2="-1.016" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.143" x2="-1.397" y2="1.905" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.048" width="0.1524" layer="21"/>
<text x="2.921" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.921" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.254" y="-2.286" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT2D6L">
<wire x1="3.048" y1="10.033" x2="3.048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="10.033" x2="-3.048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="1.651" x2="-2.413" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.413" y1="1.016" x2="3.048" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.048" y1="10.033" x2="3.048" y2="10.033" width="0.1524" layer="21" curve="-180"/>
<wire x1="-1.143" y1="2.413" x2="-0.254" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="2.413" x2="-0.254" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.524" x2="0.0762" y2="1.524" width="0.1524" layer="21"/>
<wire x1="0.0762" y1="1.524" x2="0.0762" y2="3.302" width="0.1524" layer="21"/>
<wire x1="0.0762" y1="3.302" x2="-0.254" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="3.302" x2="-0.254" y2="2.413" width="0.1524" layer="21"/>
<wire x1="0.762" y1="2.413" x2="1.27" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="2.794" x2="-1.778" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="3.175" x2="-1.397" y2="3.175" width="0.1524" layer="21"/>
<text x="-3.429" y="1.397" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.667" y="1.651" size="0.9906" layer="21" ratio="12" rot="R90">TT</text>
<rectangle x1="0.381" y1="1.4732" x2="0.8128" y2="3.3528" layer="21"/>
</package>
<package name="TT2D7L">
diameter 7 mm, grid 2.54 mm</description>
<wire x1="3.556" y1="10.16" x2="3.556" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.016" x2="2.921" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.651" x2="-2.921" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.016" x2="3.556" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.556" y1="10.16" x2="-3.556" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="10.16" x2="3.556" y2="10.16" width="0.1524" layer="21" curve="-180"/>
<wire x1="-2.032" y1="2.794" x2="-2.032" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="3.175" x2="-1.651" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="2.413" x2="-0.508" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.413" x2="-0.508" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.524" x2="-0.1778" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="1.524" x2="-0.1778" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="3.302" x2="-0.508" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.302" x2="-0.508" y2="2.413" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.413" x2="1.016" y2="2.413" width="0.1524" layer="21"/>
<text x="-3.937" y="1.27" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.905" y="4.318" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="3.048" y="1.651" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="0.127" y1="1.4732" x2="0.5588" y2="3.3528" layer="21"/>
</package>
<package name="TT2D7">
<wire x1="-2.286" y1="0" x2="-3.048" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="-0.381" x2="-2.667" y2="0.381" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.556" width="0.1524" layer="21"/>
<text x="3.302" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.302" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.127" y="-2.667" size="1.27" layer="21" ratio="10">TT</text>
</package>
<package name="TT5D10">
diameter 10 mm, grid 5.08 mm</description>
<wire x1="-1.397" y1="0" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-0.127" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="-1.27" x2="-0.127" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="1.27" x2="-0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.651" x2="-1.397" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.143" x2="-1.905" y2="2.159" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="5.08" width="0.1524" layer="21"/>
<text x="4.191" y="3.302" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.794" y="1.143" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT5D11">
diameter 11 mm, grid 5.08 mm</description>
<wire x1="-1.27" y1="1.651" x2="-2.286" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="2.159" x2="-1.778" y2="1.143" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="5.588" width="0.1524" layer="21"/>
<text x="4.572" y="3.81" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.683" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="3.175" y="1.016" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT5D11L">
<wire x1="-5.08" y1="12.954" x2="-5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.016" x2="4.445" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.651" x2="-4.445" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="4.445" y1="1.016" x2="5.08" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="1.27" y1="0.635" x2="1.27" y2="0" width="0.762" layer="21"/>
<wire x1="1.524" y1="0" x2="1.27" y2="0" width="0.762" layer="51"/>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="0" width="0.762" layer="21"/>
<wire x1="-1.524" y1="0" x2="-1.27" y2="0" width="0.762" layer="51"/>
<wire x1="5.08" y1="12.954" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="4.318" x2="-1.778" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="3.937" x2="-1.397" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.921" x2="-0.508" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.921" x2="-0.508" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.032" x2="-0.1778" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="2.032" x2="-0.1778" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="3.81" x2="-0.508" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.81" x2="-0.508" y2="2.921" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.921" x2="1.27" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="12.954" x2="5.08" y2="12.954" width="0.1524" layer="21" curve="-180"/>
<pad name="-" x="2.54" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-2.54" y="0" drill="0.8128" diameter="1.6002"/>
<text x="-5.461" y="1.27" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.413" y="5.08" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="4.572" y="1.651" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.016" layer="21"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.016" layer="21"/>
<rectangle x1="1.651" y1="-0.381" x2="2.54" y2="0.381" layer="51"/>
<rectangle x1="-2.54" y1="-0.381" x2="-1.651" y2="0.381" layer="51"/>
<rectangle x1="0.127" y1="1.9812" x2="0.5588" y2="3.8608" layer="21"/>
</package>
<package name="TT5D6">
diameter 6 mm, grid 5.08 mm</description>
<wire x1="-2.908" y1="0.9307" x2="2.921" y2="0.889" width="0.1524" layer="21" curve="-145.325311"/>
<wire x1="2.8966" y1="-0.9655" x2="2.921" y2="0.889" width="0.1524" layer="51" curve="35.361865"/>
<wire x1="-2.921" y1="-0.889" x2="-2.8966" y2="0.9655" width="0.1524" layer="51" curve="-35.361865"/>
<wire x1="-2.9403" y1="-0.8232" x2="2.9211" y2="-0.889" width="0.1524" layer="21" curve="147.4323"/>
<wire x1="-1.524" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="-0.889" x2="-0.1778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="-0.889" x2="-0.1778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="0.889" x2="-0.508" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.889" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.27" x2="-1.016" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.651" x2="-1.397" y2="0.889" width="0.1524" layer="21"/>
<text x="2.921" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.921" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.508" y="-2.159" size="0.9906" layer="21" ratio="12">TT</text>
<rectangle x1="0.127" y1="-0.9398" x2="0.5588" y2="0.9398" layer="21"/>
</package>
<package name="TT5D6L">
<wire x1="-1.143" y1="2.54" x2="-0.508" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.54" x2="-0.508" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.651" x2="-0.1778" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="1.651" x2="-0.1778" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="3.429" x2="-0.508" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.429" x2="-0.508" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.54" x2="1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="2.921" x2="-1.905" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="3.302" x2="-1.524" y2="3.302" width="0.1524" layer="21"/>
<text x="-3.429" y="1.143" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.667" y="1.524" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="0.127" y1="1.6002" x2="0.5588" y2="3.4798" layer="21"/>
</package>
<package name="TT5D7">
diameter 7 mm, grid 5.08 mm</description>
<wire x1="-2.286" y1="1.524" x2="-1.27" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.016" x2="-1.778" y2="2.032" width="0.1524" layer="21"/>
<text x="3.302" y="2.032" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.635" y="-2.667" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT5D7L">
<wire x1="-2.159" y1="3.683" x2="-2.159" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="3.302" x2="-1.778" y2="3.302" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="2.667" x2="-0.508" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="2.667" x2="-0.508" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.778" x2="-0.1778" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="1.778" x2="-0.1778" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="3.556" x2="-0.508" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="3.556" x2="-0.508" y2="2.667" width="0.1524" layer="21"/>
<wire x1="0.508" y1="2.667" x2="1.016" y2="2.667" width="0.1524" layer="21"/>
<text x="-3.937" y="1.143" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.778" y="4.445" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="3.175" y="1.651" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="0.127" y1="1.7272" x2="0.5588" y2="3.6068" layer="21"/>
</package>
<package name="TT5D9">
diameter 9 mm, grid 5.08 mm</description>
<wire x1="-2.794" y1="1.397" x2="-3.81" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.905" x2="-3.302" y2="0.889" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="4.572" width="0.1524" layer="21"/>
<text x="3.81" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.921" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.159" y="1.016" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TT5D9L">
<wire x1="-4.572" y1="10.033" x2="-4.572" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.016" x2="3.937" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="1.651" x2="-3.937" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="3.937" y1="1.016" x2="4.572" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="4.572" y1="10.033" x2="4.572" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="3.937" x2="-1.778" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="3.556" x2="-1.397" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="2.794" x2="-0.381" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="2.794" x2="-0.381" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="1.905" x2="-0.0508" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.0508" y1="1.905" x2="-0.0508" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-0.0508" y1="3.683" x2="-0.381" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="3.683" x2="-0.381" y2="2.794" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.794" x2="1.397" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="10.033" x2="4.572" y2="10.033" width="0.1524" layer="21" curve="-180"/>
<text x="-4.953" y="1.143" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="4.064" y="1.778" size="1.27" layer="21" ratio="10" rot="R90">TT</text>
<rectangle x1="0.254" y1="1.8542" x2="0.6858" y2="3.7338" layer="21"/>
</package>
<package name="ETR1">
<wire x1="2.159" y1="2.54" x2="-2.032" y2="2.54" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.54" x2="2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.159" y1="0.635" x2="2.159" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-2.54" x2="2.159" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.889" x2="-2.794" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.889" x2="-2.032" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="0.889" x2="-2.794" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-0.889" x2="-2.032" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.9304" x2="-1.27" y2="1.2954" width="0.1524" layer="21"/>
<wire x1="-0.9398" y1="1.6256" x2="-1.6002" y2="1.6256" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-2.54" x2="-2.032" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="-0.889" x2="-2.032" y2="-0.889" width="0.1524" layer="21"/>
<text x="-2.032" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-4.064" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ETR2">
<wire x1="-3.302" y1="-2.159" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="2.159" x2="-3.302" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-2.159" x2="3.302" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.762" x2="-3.81" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.762" x2="-3.302" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.762" x2="-3.81" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-0.762" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-0.762" x2="-3.302" y2="0.762" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0.889" x2="-1.27" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.635" x2="-1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-2.159" x2="3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="0.762" x2="3.302" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="3.302" y1="0.762" x2="3.302" y2="2.159" width="0.1524" layer="21"/>
<text x="-3.302" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-3.683" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ETR3">
<wire x1="-3.302" y1="-2.54" x2="-3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="2.54" x2="-3.302" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-2.54" x2="3.302" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.762" x2="-3.302" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-2.54" x2="3.302" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="3.302" y1="0.762" x2="3.302" y2="2.54" width="0.1524" layer="21"/>
<text x="-3.302" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-4.064" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ETR4">
<wire x1="-0.762" y1="-1.0922" x2="-0.254" y2="-1.0922" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.0922" x2="-0.254" y2="1.0922" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.0922" x2="-0.762" y2="1.0922" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.0922" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-3.81" x2="-5.842" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.842" y1="3.81" x2="-5.842" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-3.81" x2="5.842" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.524" x2="-6.604" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.524" x2="-5.842" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="1.524" x2="-6.604" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-1.524" x2="-5.842" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-1.524" x2="-5.842" y2="1.524" width="0.1524" layer="51"/>
<wire x1="3.683" y1="0" x2="0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.0922" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0.9652" x2="-1.651" y2="0.3302" width="0.1524" layer="21"/>
<wire x1="-1.3208" y1="0.635" x2="-1.9558" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-3.81" x2="5.842" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="5.842" y1="0.762" x2="5.842" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="5.842" y1="0.762" x2="5.842" y2="3.81" width="0.1524" layer="21"/>
<pad name="+" x="-5.08" y="0" drill="0.8128"/>
<pad name="-" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-5.842" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.143" x2="0.762" y2="1.143" layer="21"/>
</package>
<package name="ETR5">
<wire x1="-5.842" y1="-6.1722" x2="-5.842" y2="-1.4986" width="0.1524" layer="21"/>
<wire x1="5.842" y1="6.1722" x2="-5.842" y2="6.1722" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-6.1722" x2="5.842" y2="-6.1722" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.4986" x2="-6.604" y2="1.4986" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.4986" x2="-5.842" y2="6.1722" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="1.4986" x2="-6.604" y2="-1.4986" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-1.4986" x2="-5.842" y2="-1.4986" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-1.4986" x2="-5.842" y2="1.4986" width="0.1524" layer="51"/>
<wire x1="-3.683" y1="0" x2="-1.2954" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.2954" y1="0" x2="-1.2954" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.2954" y1="1.524" x2="-0.635" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.524" x2="-0.635" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.524" x2="-1.2954" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.2954" y1="-1.524" x2="-1.2954" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="3.683" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.2954" x2="-1.905" y2="0.6604" width="0.1524" layer="21"/>
<wire x1="-1.6002" y1="0.9652" x2="-2.2352" y2="0.9652" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-6.1722" x2="5.842" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="5.842" y1="0.889" x2="5.842" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="5.842" y1="0.889" x2="5.842" y2="6.1722" width="0.1524" layer="21"/>
<text x="-5.842" y="6.477" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-5.08" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-0.3048" y1="-1.6002" x2="0.3302" y2="1.6002" layer="21"/>
</package>
<package name="P128-35">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="1.778" y1="2.54" x2="1.778" y2="1.397" width="0.1524" layer="21"/>
<wire x1="1.778" y1="1.397" x2="1.778" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.635" x2="1.778" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="1.778" y1="-0.635" x2="1.778" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-1.397" x2="1.778" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.635" x2="-1.778" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.778" y1="2.667" x2="-1.778" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="1.397" x2="-1.778" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.635" x2="-1.778" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-1.397" x2="-1.778" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="0.762" y1="3.556" x2="-0.762" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-3.556" x2="0.762" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-1.397" x2="2.159" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.016" x2="2.667" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="2.667" y1="0.508" x2="2.159" y2="1.016" width="0.1524" layer="51"/>
<wire x1="2.159" y1="1.016" x2="1.778" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-1.397" x2="-2.159" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0.508" x2="-2.159" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="1.016" x2="-1.778" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-1.016" x2="-2.667" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="2.667" y1="0.508" x2="2.667" y2="-0.508" width="0.1524" layer="51" curve="-180"/>
<wire x1="-2.667" y1="-0.508" x2="-2.667" y2="0.508" width="0.1524" layer="51" curve="-180"/>
<wire x1="-1.143" y1="1.9304" x2="-1.143" y2="1.2954" width="0.1524" layer="21"/>
<wire x1="-0.8128" y1="1.6256" x2="-1.4732" y2="1.6256" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.2192" x2="-0.254" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.2192" x2="-0.635" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-2.54" x2="-0.762" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="-3.556" x2="1.778" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="3.556" x2="1.778" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.778" y1="2.54" x2="-0.762" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<pad name="+" x="-2.667" y="0" drill="0.9144"/>
<pad name="-" x="2.667" y="0" drill="0.9144" shape="octagon"/>
<text x="-1.651" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-5.08" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="P128-40">
<wire x1="2.032" y1="2.54" x2="2.032" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.032" y1="1.143" x2="2.032" y2="0.762" width="0.1524" layer="21"/>
<wire x1="2.032" y1="0.762" x2="2.032" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="2.032" y1="-0.762" x2="2.032" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.143" x2="2.032" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.762" x2="-2.032" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="-2.032" y1="2.54" x2="-2.032" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.143" x2="-2.032" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-0.762" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.27" x2="-2.032" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="1.016" y1="3.556" x2="-1.016" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-3.556" x2="1.016" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.143" x2="2.159" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.016" x2="2.032" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.27" x2="-2.159" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.016" x2="-2.032" y2="1.143" width="0.1524" layer="21"/>
<wire x1="1.016" y1="3.556" x2="2.032" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="1.016" y1="-3.556" x2="2.032" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.032" y1="2.54" x2="-1.016" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.032" y1="-2.54" x2="-1.016" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<text x="-2.032" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-5.207" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="P128-50">
<wire x1="2.54" y1="3.048" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.143" x2="2.54" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="1.524" y1="4.064" x2="-1.524" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-4.064" x2="1.524" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.143" x2="2.667" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="2.667" y1="0.635" x2="2.54" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-1.143" x2="-2.54" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0.635" x2="-2.54" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="3.048" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.143" x2="-2.667" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.1684" x2="-1.27" y2="0.5334" width="0.1524" layer="21"/>
<wire x1="-0.9398" y1="0.8636" x2="-1.6002" y2="0.8636" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0.635" x2="-2.667" y2="-0.635" width="0.1524" layer="51" curve="180"/>
<wire x1="2.667" y1="-0.635" x2="2.667" y2="0.635" width="0.1524" layer="51" curve="180"/>
<wire x1="1.524" y1="4.064" x2="2.54" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="3.048" x2="-1.524" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-3.048" x2="-1.524" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="-4.064" x2="2.54" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<text x="-2.413" y="4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="P128-60">
<wire x1="3.048" y1="3.048" x2="3.048" y2="1.143" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-1.143" x2="3.048" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="2.032" y1="4.064" x2="-2.032" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-4.064" x2="2.032" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-1.143" x2="3.048" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-3.048" y1="-1.143" x2="-3.048" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="3.048" x2="-3.048" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-1.143" x2="-3.048" y2="1.143" width="0.1524" layer="51"/>
<wire x1="2.032" y1="-4.064" x2="3.048" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.048" y1="3.048" x2="-2.032" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.048" y1="-3.048" x2="-2.032" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="2.032" y1="4.064" x2="3.048" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-2.921" y="4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TAP5-45">
diameter 4.5 mm, grid 5.08 mm</description>
<wire x1="-1.397" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="-0.635" x2="-0.1778" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="-0.635" x2="-0.1778" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.1778" y1="0.635" x2="-0.508" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.635" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.381" x2="-1.143" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0.635" x2="-1.397" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.1778" y1="0.635" x2="0.1778" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0.635" x2="0.1778" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.1778" y1="-0.635" x2="0.508" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-0.635" x2="0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="0.508" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="-0.508" x2="0.3302" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-1.9144" y1="-1.2492" x2="1.9144" y2="-1.2492" width="0.1524" layer="21" curve="113.748837"/>
<wire x1="-1.9144" y1="1.2492" x2="1.9144" y2="1.2492" width="0.1524" layer="21" curve="-113.748837"/>
<wire x1="-1.9144" y1="1.2492" x2="-1.9144" y2="-1.2492" width="0.1524" layer="51" curve="66.251163"/>
<wire x1="1.9144" y1="-1.2492" x2="1.9144" y2="1.2492" width="0.1524" layer="51" curve="66.251163"/>
<text x="2.286" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.286" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.889" y="-1.905" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TAP5-50">
diameter 5.0 mm, grid 5.08 mm</description>
<wire x1="-2.1557" y1="1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="21" curve="-116.146571"/>
<wire x1="-2.1557" y1="-1.3432" x2="2.1557" y2="-1.3432" width="0.1524" layer="21" curve="116.146571"/>
<wire x1="-2.1557" y1="1.3432" x2="-2.1557" y2="-1.3432" width="0.1524" layer="51" curve="63.853429"/>
<wire x1="2.1557" y1="-1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="51" curve="63.853429"/>
<wire x1="-1.143" y1="0.635" x2="-1.143" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0.889" x2="-1.397" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.1778" y1="0.889" x2="0.1778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0.889" x2="0.1778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.1778" y1="-0.889" x2="0.508" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-0.889" x2="0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0" x2="0.508" y2="0.889" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="-0.762" x2="0.3302" y2="0.762" width="0.1524" layer="21"/>
<text x="2.54" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.889" y="-2.159" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TAP5-70">
diameter 7.0 mm, grid 5.08 mm</description>
<wire x1="-1.397" y1="0.508" x2="-1.397" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.762" x2="-1.651" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-3.3749" y1="-1.1199" x2="3.3749" y2="-1.1199" width="0.1524" layer="21" curve="143.285003"/>
<wire x1="-3.3749" y1="1.1199" x2="3.3749" y2="1.1199" width="0.1524" layer="21" curve="-143.285003"/>
<wire x1="-3.3749" y1="1.1199" x2="-3.3749" y2="-1.1199" width="0.1524" layer="51" curve="36.714997"/>
<wire x1="3.3749" y1="-1.1199" x2="3.3749" y2="1.1199" width="0.1524" layer="51" curve="36.714997"/>
<text x="3.175" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0.635" y="-2.413" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TAP5-60">
diameter 6.0 mm, grid 5.08 mm</description>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="0.889" x2="-1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.8702" y1="1.3574" x2="2.8702" y2="1.3574" width="0.1524" layer="21" curve="-129.378377"/>
<wire x1="-2.8702" y1="-1.3574" x2="2.8702" y2="-1.3574" width="0.1524" layer="21" curve="129.378377"/>
<wire x1="-2.8702" y1="1.3574" x2="-2.8702" y2="-1.3574" width="0.1524" layer="51" curve="50.621623"/>
<wire x1="2.8702" y1="-1.3574" x2="2.8702" y2="1.3574" width="0.1524" layer="51" curve="50.621623"/>
<text x="2.921" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.921" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="0" y="-2.54" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="TAP5-80">
diameter 8.0 mm, grid 5.08 mm</description>
<circle x="0" y="0" radius="4.318" width="0.1524" layer="21"/>
<text x="3.81" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="2.032" y="1.016" size="0.9906" layer="21" ratio="12">TT</text>
</package>
<package name="E1,8-4">
grid 1.8 mm, diameter 4 mm</description>
<wire x1="-1.524" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.016" x2="-0.254" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.016" x2="-0.254" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.016" x2="-0.762" y2="1.016" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.016" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.524" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.016" y1="1.397" x2="-0.508" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.143" x2="-0.762" y2="1.651" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.032" width="0.1524" layer="21"/>
<pad name="-" x="0.889" y="0" drill="0.7112" diameter="1.1684" shape="octagon"/>
<pad name="+" x="-0.889" y="0" drill="0.7112" diameter="1.1684"/>
<text x="2.159" y="-1.778" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.016" x2="0.762" y2="1.016" layer="51"/>
</package>
<package name="E15-5">
grid 15.24 mm, diameter 5 mm</description>
<wire x1="-4.064" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-2.667" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="-1.27" x2="-2.667" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="1.27" x2="-3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0" x2="5.207" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.143" x2="-3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="0.889" x2="-3.556" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.286" x2="-5.715" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="2.54" x2="5.461" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.286" x2="5.461" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.286" x2="-4.191" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="2.54" x2="-5.715" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.54" x2="-4.826" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="2.413" x2="-5.08" y2="2.413" width="0.3048" layer="21"/>
<wire x1="-5.461" y1="2.54" x2="-5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.286" x2="-4.826" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.286" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.286" x2="-4.445" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="2.413" x2="5.461" y2="2.413" width="0.3048" layer="21"/>
<wire x1="-4.445" y1="2.286" x2="5.715" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.032" x2="-4.445" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.286" x2="-4.445" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-2.54" x2="5.461" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.032" x2="-4.826" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.159" x2="-4.826" y2="-2.2352" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.032" x2="-4.445" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.159" x2="-4.445" y2="-2.2352" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.286" x2="-4.445" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.159" x2="-4.445" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.286" x2="5.715" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.286" x2="5.588" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.286" x2="-5.588" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-2.413" x2="-5.461" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.54" x2="-4.953" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.413" x2="-4.826" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-2.54" x2="-5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-2.413" x2="-4.953" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.286" x2="-4.318" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-2.413" x2="-4.191" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-2.413" x2="5.588" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-2.413" x2="5.461" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.461" y1="-2.4892" x2="-4.191" y2="-2.4892" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-2.4892" x2="-4.191" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.4892" x2="-5.461" y2="-2.4892" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-2.4892" x2="-5.461" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.2352" x2="-4.826" y2="-2.2352" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.2352" x2="-4.445" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.2352" x2="-4.826" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.159" x2="-4.572" y2="2.159" width="0.3048" layer="21"/>
<wire x1="7.62" y1="0" x2="6.477" y2="0" width="0.508" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.477" y2="0" width="0.508" layer="51"/>
<pad name="+" x="-7.62" y="0" drill="0.8128" diameter="2.159"/>
<pad name="-" x="7.62" y="0" drill="0.8128" diameter="2.159" shape="octagon"/>
<text x="-5.461" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.461" y="-4.1402" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.286" y1="-1.27" x2="-1.778" y2="1.27" layer="21"/>
<rectangle x1="-6.477" y1="-0.254" x2="-5.715" y2="0.254" layer="21"/>
<rectangle x1="5.715" y1="-0.254" x2="6.477" y2="0.254" layer="21"/>
</package>
<package name="E15-6">
grid 15.24 mm, diameter 6 mm</description>
<wire x1="-5.715" y1="-2.921" x2="-5.715" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="3.175" x2="5.461" y2="3.175" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.921" x2="5.461" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.921" x2="-4.191" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="3.175" x2="-5.715" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.175" x2="-4.826" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="3.048" x2="-5.08" y2="3.048" width="0.3048" layer="21"/>
<wire x1="-5.461" y1="3.175" x2="-5.08" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.921" x2="-4.826" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.921" x2="-4.826" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.921" x2="-4.445" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="3.048" x2="5.461" y2="3.048" width="0.3048" layer="21"/>
<wire x1="-4.445" y1="2.921" x2="5.715" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.667" x2="-4.445" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.921" x2="-4.445" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-3.175" x2="5.461" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.667" x2="-4.826" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.794" x2="-4.826" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="2.667" x2="-4.445" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.794" x2="-4.445" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.921" x2="-4.445" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.794" x2="-4.445" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.921" x2="5.715" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.921" x2="5.588" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.921" x2="-5.588" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-3.048" x2="-5.461" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.175" x2="-4.953" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-3.048" x2="-4.826" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-3.175" x2="-5.08" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-3.048" x2="-4.953" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.921" x2="-4.318" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-3.048" x2="-4.191" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="-3.048" x2="5.588" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-3.048" x2="5.461" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="5.461" y1="-3.1242" x2="-4.191" y2="-3.1242" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-3.1242" x2="-4.191" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.1242" x2="-5.461" y2="-3.1242" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-3.1242" x2="-5.461" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.8702" x2="-4.826" y2="-2.8702" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.8702" x2="-4.445" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.8702" x2="-4.826" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.794" x2="-4.572" y2="2.794" width="0.3048" layer="21"/>
<text x="-5.461" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-1.8542" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E15-9">
grid 15.24 mm, diameter 9 mm</description>
<wire x1="-4.445" y1="0" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="0" x2="-3.556" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-1.27" x2="-3.048" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-1.27" x2="-3.048" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="1.27" x2="-3.556" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.27" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="5.588" y2="0" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="1.143" x2="-4.191" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.889" x2="-3.937" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-4.318" x2="-6.096" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="4.572" x2="5.842" y2="4.572" width="0.1524" layer="21"/>
<wire x1="6.096" y1="4.318" x2="5.842" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="4.318" x2="-4.572" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="4.572" x2="-6.096" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="4.572" x2="-5.207" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="4.445" x2="-5.461" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-5.842" y1="4.572" x2="-5.461" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="4.318" x2="-5.207" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.318" x2="-5.207" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="4.318" x2="-4.826" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="4.445" x2="5.842" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-4.826" y1="4.318" x2="6.096" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.064" x2="-4.826" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.318" x2="-4.826" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-4.572" x2="5.842" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="4.064" x2="-5.207" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.191" x2="-5.207" y2="-4.2672" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="4.064" x2="-4.826" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.191" x2="-4.826" y2="-4.2672" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.318" x2="-4.826" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.191" x2="-4.826" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="6.096" y1="4.318" x2="6.096" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-4.318" x2="5.969" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-4.318" x2="-5.969" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-4.445" x2="-5.842" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-4.572" x2="-5.334" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="-4.445" x2="-5.207" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-4.572" x2="-5.461" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-4.445" x2="-5.334" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.318" x2="-4.699" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-4.445" x2="-4.572" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-4.445" x2="5.969" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="5.969" y1="-4.445" x2="5.842" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-4.5212" x2="-4.572" y2="-4.5212" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-4.5212" x2="-4.572" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-4.5212" x2="-5.842" y2="-4.5212" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-4.5212" x2="-5.842" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.2672" x2="-5.207" y2="-4.2672" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-4.2672" x2="-4.826" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-4.2672" x2="-5.207" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="4.191" x2="-4.953" y2="4.191" width="0.3048" layer="21"/>
<text x="-5.842" y="4.826" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.651" y="-1.9812" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.667" y1="-1.27" x2="-2.159" y2="1.27" layer="21"/>
<rectangle x1="6.096" y1="-0.254" x2="6.477" y2="0.254" layer="21"/>
<rectangle x1="-6.477" y1="-0.254" x2="-6.096" y2="0.254" layer="21"/>
</package>
<package name="E2,5-4R">
grid 2.54 mm, diameter 4 mm</description>
<wire x1="-0.127" y1="0" x2="0.0762" y2="0" width="0.6096" layer="21"/>
<wire x1="-2.794" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.254" x2="-2.54" y2="0.254" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0" x2="-1.27" y2="0" width="0.6096" layer="51"/>
<wire x1="0.508" y1="0.635" x2="0.5403" y2="-0.6456" width="0.1524" layer="21" curve="320.718856"/>
<wire x1="0.508" y1="0.635" x2="0.5403" y2="-0.6456" width="0.1524" layer="51" curve="-39.281144"/>
<text x="0.762" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.762" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5-5">
grid 2.54 mm, diameter 5 mm</description>
<wire x1="-1.651" y1="1.27" x2="-1.397" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.016" x2="-1.397" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.27" x2="-1.143" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.27" x2="-1.397" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<text x="2.413" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.413" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5-6">
grid 2.54 mm, diameter 6 mm</description>
<wire x1="-2.032" y1="1.27" x2="-1.651" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0.889" x2="-1.651" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.27" x2="-1.27" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.27" x2="-1.651" y2="1.651" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.794" width="0.1524" layer="21"/>
<text x="2.667" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.667" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5-7">
grid 2.54 mm, diameter 7 mm</description>
<wire x1="-3.048" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.429" width="0.1524" layer="21"/>
<text x="3.048" y="2.032" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.048" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2,5RE">
grid 2.54 mm, diameter 4 mm,</description>
<wire x1="0.254" y1="1.143" x2="0.254" y2="-1.143" width="0.1524" layer="21" curve="286.260205"/>
<wire x1="0.254" y1="-1.143" x2="0.254" y2="1.143" width="0.1524" layer="51" curve="73.739795"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.5748"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.5748" shape="octagon"/>
<text x="0.635" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.635" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2-4">
grid 2 mm, diameter 4 mm</description>
<wire x1="-0.762" y1="1.524" x2="-0.254" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="1.27" x2="-0.508" y2="1.778" width="0.1524" layer="21"/>
<wire x1="0.381" y1="1.524" x2="0.889" y2="1.524" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.159" width="0.1524" layer="21"/>
<pad name="-" x="1.016" y="0" drill="0.8128" diameter="1.27" shape="octagon"/>
<pad name="+" x="-1.016" y="0" drill="0.8128" diameter="1.27"/>
<text x="2.159" y="0.889" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.159" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E2-5">
grid 2.032 mm, diameter 5 mm</description>
<wire x1="-1.27" y1="1.778" x2="-0.762" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="1.524" x2="-1.016" y2="2.032" width="0.1524" layer="21"/>
<text x="2.54" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.54" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E22-10">
grid 22.86 mm, diameter 10 mm</description>
<wire x1="-6.35" y1="5.08" x2="8.509" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.699" x2="-8.89" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.699" x2="-8.509" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="5.08" x2="-8.001" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.699" x2="-8.001" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.699" x2="-6.731" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="5.08" x2="-6.731" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.699" x2="-7.62" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.699" x2="-6.731" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.699" x2="-7.62" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.318" x2="-6.731" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.699" x2="8.89" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="4.953" x2="8.509" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-6.477" y1="4.826" x2="8.636" y2="4.826" width="0.3048" layer="21"/>
<wire x1="-8.509" y1="4.953" x2="-8.001" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-8.636" y1="4.826" x2="-7.874" y2="4.826" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="4.572" x2="-6.858" y2="4.572" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="4.445" x2="-6.858" y2="4.445" width="0.3048" layer="21"/>
<wire x1="-8.89" y1="-4.699" x2="-8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-5.08" x2="-8.001" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.699" x2="-7.747" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.699" x2="-7.62" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.699" x2="-6.731" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-5.08" x2="-6.604" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-5.08" x2="8.509" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.318" x2="-6.731" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.826" x2="-7.747" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.826" x2="-8.509" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.826" x2="-8.001" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-4.826" x2="8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-4.826" x2="-6.731" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-4.953" x2="-8.001" y2="-4.953" width="0.254" layer="21"/>
<wire x1="-7.493" y1="-4.572" x2="-6.858" y2="-4.572" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-4.953" x2="8.509" y2="-4.953" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-4.445" x2="-6.731" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.445" x2="-7.62" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-4.445" x2="-6.731" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-5.08" x2="8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="8.763" y1="-4.826" x2="8.89" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="8.509" y1="5.08" x2="8.89" y2="4.699" width="0.1524" layer="21"/>
<wire x1="8.89" y1="4.699" x2="8.89" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-1.524" x2="-4.572" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-1.524" x2="-4.572" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="1.524" x2="-5.08" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.27" x2="-5.842" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="0.889" x2="-5.461" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.524" x2="-5.08" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0" x2="8.382" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="0" x2="-5.08" y2="0" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="9.779" y2="0" width="0.762" layer="51"/>
<wire x1="-11.43" y1="0" x2="-9.779" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-11.43" y="0" drill="1.016" diameter="3.1496"/>
<pad name="-" x="11.43" y="0" drill="1.016" diameter="3.1496" shape="octagon"/>
<text x="-8.509" y="5.334" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.7686" y="-2.3622" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.064" y1="-1.524" x2="-3.556" y2="1.524" layer="21"/>
<rectangle x1="-9.779" y1="-0.381" x2="-8.89" y2="0.381" layer="21"/>
<rectangle x1="8.89" y1="-0.381" x2="9.779" y2="0.381" layer="21"/>
</package>
<package name="E22-6">
grid 22.86 mm, diameter 6 mm</description>
<wire x1="-6.35" y1="3.175" x2="8.509" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.794" x2="-8.89" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.794" x2="-8.509" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.175" x2="-8.001" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.794" x2="-8.001" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.794" x2="-6.731" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="3.175" x2="-6.731" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.794" x2="-7.62" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.794" x2="-6.731" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.794" x2="-7.62" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="2.413" x2="-6.731" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.794" x2="8.89" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="3.048" x2="8.509" y2="3.048" width="0.3048" layer="21"/>
<wire x1="-6.477" y1="2.921" x2="8.636" y2="2.921" width="0.3048" layer="21"/>
<wire x1="-8.509" y1="3.048" x2="-8.001" y2="3.048" width="0.3048" layer="21"/>
<wire x1="-8.636" y1="2.921" x2="-7.874" y2="2.921" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="2.667" x2="-6.858" y2="2.667" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="2.54" x2="-6.858" y2="2.54" width="0.3048" layer="21"/>
<wire x1="-8.89" y1="-2.794" x2="-8.763" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-3.175" x2="-8.001" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.794" x2="-7.747" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.794" x2="-7.62" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.794" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-3.175" x2="-6.604" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-3.175" x2="8.509" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.413" x2="-6.731" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-2.921" x2="-7.747" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-2.921" x2="-8.509" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-2.921" x2="-8.001" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.921" x2="8.763" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.921" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-3.048" x2="-8.001" y2="-3.048" width="0.254" layer="21"/>
<wire x1="-7.493" y1="-2.667" x2="-6.858" y2="-2.667" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-3.048" x2="8.509" y2="-3.048" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-2.54" x2="-6.731" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.54" x2="-7.62" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-2.54" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.175" x2="8.763" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="8.763" y1="-2.921" x2="8.89" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.175" x2="8.89" y2="2.794" width="0.1524" layer="21"/>
<wire x1="8.89" y1="2.794" x2="8.89" y2="-2.794" width="0.1524" layer="21"/>
<text x="-8.509" y="3.429" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-8.4836" y="-5.2832" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E22-9">
grid 22.86 mm, diameter 9 mm</description>
<wire x1="-6.35" y1="4.445" x2="8.509" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.064" x2="-8.89" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.064" x2="-8.509" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.445" x2="-8.001" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.064" x2="-8.001" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.064" x2="-6.731" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="4.445" x2="-6.731" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.064" x2="-7.62" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.064" x2="-6.731" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.064" x2="-7.62" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="3.683" x2="-6.731" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="4.064" x2="8.89" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="4.318" x2="8.509" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-6.477" y1="4.191" x2="8.636" y2="4.191" width="0.3048" layer="21"/>
<wire x1="-8.509" y1="4.318" x2="-8.001" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-8.636" y1="4.191" x2="-7.874" y2="4.191" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="3.937" x2="-6.858" y2="3.937" width="0.3048" layer="21"/>
<wire x1="-7.493" y1="3.81" x2="-6.858" y2="3.81" width="0.3048" layer="21"/>
<wire x1="-8.89" y1="-4.064" x2="-8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-4.445" x2="-8.001" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.064" x2="-7.747" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.064" x2="-7.62" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-4.064" x2="-6.731" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-4.445" x2="-6.604" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-4.445" x2="8.509" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="3.683" x2="-6.731" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.191" x2="-7.747" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.191" x2="-8.509" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.191" x2="-8.001" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-4.191" x2="8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-4.191" x2="-6.731" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-4.318" x2="-8.001" y2="-4.318" width="0.254" layer="21"/>
<wire x1="-7.493" y1="-3.937" x2="-6.858" y2="-3.937" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-4.318" x2="8.509" y2="-4.318" width="0.254" layer="21"/>
<wire x1="-7.62" y1="-3.81" x2="-6.731" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-3.81" x2="-7.62" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-3.81" x2="-6.731" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.445" x2="8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="8.763" y1="-4.191" x2="8.89" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.445" x2="8.89" y2="4.064" width="0.1524" layer="21"/>
<wire x1="8.89" y1="4.064" x2="8.89" y2="-4.064" width="0.1524" layer="21"/>
<text x="-8.509" y="4.826" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E3,5-10">
grid 3.5 mm, diameter 10 mm</description>
<wire x1="-3.429" y1="1.143" x2="-2.667" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="0.762" x2="-3.048" y2="1.524" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<pad name="-" x="1.778" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.778" y="0" drill="0.8128" diameter="1.6002"/>
<text x="4.064" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="E25-10">
grid 25.4 mm, diameter 10 mm</description>
<wire x1="-10.16" y1="4.826" x2="-9.906" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="5.08" x2="-9.017" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="5.08" x2="-8.763" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="5.08" x2="9.906" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-5.08" x2="-9.017" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-5.08" x2="9.906" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.826" x2="-10.16" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="9.906" y1="5.08" x2="10.16" y2="4.826" width="0.1524" layer="21"/>
<wire x1="9.906" y1="-5.08" x2="10.033" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.826" x2="10.16" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="5.08" x2="-8.001" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="4.826" x2="-8.763" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.826" x2="-8.001" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.826" x2="10.16" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.826" x2="-8.763" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.826" x2="-8.763" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="4.572" x2="-8.001" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="4.953" x2="9.906" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-9.906" y1="4.953" x2="-9.017" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-8.763" y1="-4.826" x2="-8.763" y2="-4.7752" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.826" x2="-8.001" y2="-4.7752" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.699" x2="-8.763" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.699" x2="-8.001" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.826" x2="-8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.699" x2="-8.001" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-1.524" x2="-5.842" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-1.524" x2="-5.842" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="1.524" x2="-6.35" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="1.27" x2="-7.112" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="0.889" x2="-6.731" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="1.524" x2="-6.35" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0" x2="-6.35" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="0" x2="9.652" y2="0" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="0" x2="-6.35" y2="0" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.826" x2="-10.033" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-10.033" y1="-4.953" x2="-9.906" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-5.08" x2="-8.89" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-4.953" x2="-8.763" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-10.033" y1="-4.953" x2="-8.89" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-5.0292" x2="-9.017" y2="-5.0292" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-5.0292" x2="-9.017" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.7752" x2="-8.001" y2="-4.7752" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.7752" x2="-8.763" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.7752" x2="-8.001" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-5.08" x2="-7.874" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.953" x2="-8.001" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-5.08" x2="-7.747" y2="-5.0292" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-5.0292" x2="9.906" y2="-5.0292" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.953" x2="10.033" y2="-4.953" width="0.1524" layer="21"/>
<wire x1="10.033" y1="-4.953" x2="10.16" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="4.699" x2="-8.128" y2="4.699" width="0.3048" layer="21"/>
<wire x1="12.7" y1="0" x2="11.049" y2="0" width="0.762" layer="51"/>
<wire x1="-12.7" y1="0" x2="-11.049" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-12.7" y="0" drill="1.1176" diameter="3.1496"/>
<pad name="-" x="12.7" y="0" drill="1.1176" diameter="3.1496" shape="octagon"/>
<text x="-9.906" y="5.334" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.0386" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.334" y1="-1.524" x2="-4.826" y2="1.524" layer="21"/>
<rectangle x1="-11.049" y1="-0.381" x2="-10.16" y2="0.381" layer="21"/>
<rectangle x1="10.16" y1="-0.381" x2="11.049" y2="0.381" layer="21"/>
</package>
<package name="E25-9">
grid 25.4 mm, diameter 9 mm</description>
<wire x1="-10.16" y1="4.191" x2="-9.906" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="4.445" x2="-9.017" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="4.445" x2="-8.763" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="4.445" x2="9.906" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-4.445" x2="-9.017" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.445" x2="9.906" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.191" x2="-10.16" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="9.906" y1="4.445" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="9.906" y1="-4.445" x2="10.033" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.191" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="4.445" x2="-8.001" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="4.191" x2="-8.763" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.191" x2="-8.001" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.191" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.191" x2="-8.763" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="4.191" x2="-8.763" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="3.937" x2="-8.001" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="4.318" x2="9.906" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-9.906" y1="4.318" x2="-9.017" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-8.763" y1="-4.191" x2="-8.763" y2="-4.1402" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.191" x2="-8.001" y2="-4.1402" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.064" x2="-8.763" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.064" x2="-8.001" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.191" x2="-8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.064" x2="-8.001" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.191" x2="-10.033" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-10.033" y1="-4.318" x2="-9.906" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-4.445" x2="-8.89" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-4.318" x2="-8.763" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-10.033" y1="-4.318" x2="-8.89" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-4.3942" x2="-9.017" y2="-4.3942" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-4.3942" x2="-9.017" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.1402" x2="-8.001" y2="-4.1402" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-4.1402" x2="-8.763" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-4.1402" x2="-8.001" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.445" x2="-7.874" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.318" x2="-8.001" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.445" x2="-7.747" y2="-4.3942" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-4.3942" x2="9.906" y2="-4.3942" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.318" x2="10.033" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="10.033" y1="-4.318" x2="10.16" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="4.064" x2="-8.128" y2="4.064" width="0.3048" layer="21"/>
<text x="-9.779" y="4.826" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E3,5-8">
grid 3.5 mm, diameter 8 mm</description>
<circle x="0" y="0" radius="4.064" width="0.1524" layer="21"/>
<text x="3.302" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E30-10">
grid 30.48 mm, diameter 10 mm</description>
<wire x1="12.7" y1="4.699" x2="12.7" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="4.699" x2="-12.7" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="4.699" x2="-12.319" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="5.08" x2="-11.811" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.699" x2="-11.811" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.699" x2="-10.541" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="4.699" x2="-10.16" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.699" x2="-11.43" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="4.699" x2="-10.541" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="4.699" x2="-11.43" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="4.699" x2="12.7" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.191" x2="-10.541" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="4.953" x2="-11.811" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-12.446" y1="4.826" x2="-11.684" y2="4.826" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="4.572" x2="-10.668" y2="4.572" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="4.318" x2="-10.668" y2="4.318" width="0.3048" layer="21"/>
<wire x1="-10.16" y1="4.953" x2="12.319" y2="4.953" width="0.3048" layer="21"/>
<wire x1="-10.287" y1="4.826" x2="12.446" y2="4.826" width="0.3048" layer="21"/>
<wire x1="-12.7" y1="-4.699" x2="-12.573" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-5.08" x2="-11.811" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-4.699" x2="-11.557" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-4.699" x2="-10.541" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-5.08" x2="-10.414" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-4.826" x2="-11.557" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-4.826" x2="-12.319" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-11.557" y1="-4.826" x2="-11.811" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-4.826" x2="12.573" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-4.826" x2="-10.541" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="4.191" x2="-11.43" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="4.191" x2="-10.541" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-4.445" x2="-10.541" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-4.445" x2="-11.43" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="-4.445" x2="-10.541" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.953" x2="12.319" y2="-4.953" width="0.3048" layer="21"/>
<wire x1="-12.319" y1="-4.953" x2="-11.811" y2="-4.953" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="-4.572" x2="-10.668" y2="-4.572" width="0.3048" layer="21"/>
<wire x1="12.7" y1="-4.699" x2="12.573" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="12.319" y1="-5.08" x2="-10.16" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="12.573" y1="-4.826" x2="12.319" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="12.7" y1="4.699" x2="12.319" y2="5.08" width="0.1524" layer="21"/>
<wire x1="12.319" y1="5.08" x2="-10.16" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="-1.524" x2="-7.874" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-1.524" x2="-7.874" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="1.524" x2="-8.382" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-9.144" y1="1.27" x2="-9.144" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="0.889" x2="-8.763" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="1.524" x2="-8.382" y2="0" width="0.1524" layer="21"/>
<wire x1="-8.382" y1="0" x2="-8.382" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="0" x2="11.557" y2="0" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="0" x2="-8.382" y2="0" width="0.1524" layer="21"/>
<wire x1="15.24" y1="0" x2="13.462" y2="0" width="0.762" layer="51"/>
<wire x1="-15.24" y1="0" x2="-13.462" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-15.24" y="0" drill="1.1176" diameter="3.1496"/>
<pad name="-" x="15.24" y="0" drill="1.1176" diameter="3.1496" shape="octagon"/>
<text x="-12.319" y="5.334" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.0706" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-7.366" y1="-1.524" x2="-6.858" y2="1.524" layer="21"/>
<rectangle x1="-13.462" y1="-0.381" x2="-12.7" y2="0.381" layer="21"/>
<rectangle x1="12.7" y1="-0.381" x2="13.462" y2="0.381" layer="21"/>
</package>
<package name="E30-12">
grid 30.48 mm, diameter 12 mm</description>
<wire x1="12.7" y1="5.969" x2="12.7" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="5.969" x2="-12.7" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="5.969" x2="-12.319" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="6.35" x2="-11.811" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.969" x2="-11.811" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.969" x2="-10.541" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="5.969" x2="-10.16" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.969" x2="-11.43" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="5.969" x2="-10.541" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="5.969" x2="-11.43" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="5.969" x2="12.7" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.461" x2="-10.541" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="6.223" x2="-11.811" y2="6.223" width="0.3048" layer="21"/>
<wire x1="-12.446" y1="6.096" x2="-11.684" y2="6.096" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="5.842" x2="-10.668" y2="5.842" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="5.588" x2="-10.668" y2="5.588" width="0.3048" layer="21"/>
<wire x1="-10.16" y1="6.223" x2="12.319" y2="6.223" width="0.3048" layer="21"/>
<wire x1="-10.287" y1="6.096" x2="12.446" y2="6.096" width="0.3048" layer="21"/>
<wire x1="-12.7" y1="-5.969" x2="-12.573" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-6.35" x2="-11.811" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.969" x2="-11.557" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.969" x2="-10.541" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-6.35" x2="-10.414" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-6.096" x2="-11.557" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-6.096" x2="-12.319" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-11.557" y1="-6.096" x2="-11.811" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-6.096" x2="12.573" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-6.096" x2="-10.541" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.461" x2="-11.43" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="5.461" x2="-10.541" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.715" x2="-10.541" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.715" x2="-11.43" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="-5.715" x2="-10.541" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-6.223" x2="12.319" y2="-6.223" width="0.3048" layer="21"/>
<wire x1="-12.319" y1="-6.223" x2="-11.811" y2="-6.223" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="-5.842" x2="-10.668" y2="-5.842" width="0.3048" layer="21"/>
<wire x1="12.7" y1="-5.969" x2="12.573" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="12.319" y1="-6.35" x2="-10.16" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="12.573" y1="-6.096" x2="12.319" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="12.7" y1="5.969" x2="12.319" y2="6.35" width="0.1524" layer="21"/>
<wire x1="12.319" y1="6.35" x2="-10.16" y2="6.35" width="0.1524" layer="21"/>
<text x="-12.192" y="6.731" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E30-16">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 30.48 mm, diameter 16 mm</description>
<wire x1="12.7" y1="7.747" x2="12.7" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="7.747" x2="-12.7" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="7.747" x2="-12.319" y2="8.128" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="8.128" x2="-11.811" y2="8.128" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.747" x2="-11.811" y2="8.128" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.747" x2="-10.541" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="7.747" x2="-10.16" y2="8.128" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.747" x2="-11.43" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="7.747" x2="-10.541" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="7.747" x2="-11.43" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="7.747" x2="12.7" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.239" x2="-10.541" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="8.001" x2="-11.811" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-12.446" y1="7.874" x2="-11.684" y2="7.874" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="7.62" x2="-10.668" y2="7.62" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="7.366" x2="-10.668" y2="7.366" width="0.3048" layer="21"/>
<wire x1="-10.16" y1="8.001" x2="12.319" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-10.287" y1="7.874" x2="12.446" y2="7.874" width="0.3048" layer="21"/>
<wire x1="-12.7" y1="-7.62" x2="-12.573" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-8.001" x2="-11.811" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-7.62" x2="-11.557" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-7.62" x2="-10.541" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-8.001" x2="-10.414" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-7.747" x2="-11.557" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-12.573" y1="-7.747" x2="-12.319" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-11.557" y1="-7.747" x2="-11.811" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-7.747" x2="12.573" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-7.747" x2="-10.541" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="7.239" x2="-11.43" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="7.239" x2="-10.541" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-7.366" x2="-10.541" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-7.366" x2="-11.43" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-10.541" y1="-7.366" x2="-10.541" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-7.874" x2="12.319" y2="-7.874" width="0.3048" layer="21"/>
<wire x1="-12.319" y1="-7.874" x2="-11.811" y2="-7.874" width="0.3048" layer="21"/>
<wire x1="-11.303" y1="-7.493" x2="-10.668" y2="-7.493" width="0.3048" layer="21"/>
<wire x1="12.7" y1="-7.62" x2="12.573" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="12.319" y1="-8.001" x2="-10.16" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="12.573" y1="-7.747" x2="12.319" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="12.7" y1="7.747" x2="12.319" y2="8.128" width="0.1524" layer="21"/>
<wire x1="12.319" y1="8.128" x2="-10.16" y2="8.128" width="0.1524" layer="21"/>
<text x="-12.319" y="8.382" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E35-12">
grid 35.56 mm, diameter 12 mm</description>
<wire x1="15.24" y1="5.969" x2="15.24" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="5.969" x2="-15.24" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="5.969" x2="-14.859" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="6.35" x2="-13.716" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.969" x2="-13.716" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.969" x2="-12.446" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="5.969" x2="-12.065" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.969" x2="-13.335" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="5.969" x2="-12.446" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="5.969" x2="-13.335" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="5.969" x2="15.24" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.461" x2="-12.446" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="6.223" x2="-13.716" y2="6.223" width="0.3048" layer="21"/>
<wire x1="-14.986" y1="6.096" x2="-13.589" y2="6.096" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="5.842" x2="-12.573" y2="5.842" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="5.588" x2="-12.573" y2="5.588" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="6.223" x2="14.859" y2="6.223" width="0.3048" layer="21"/>
<wire x1="-12.192" y1="6.096" x2="14.986" y2="6.096" width="0.3048" layer="21"/>
<wire x1="-15.24" y1="-5.969" x2="-15.113" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="-6.35" x2="-13.716" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.969" x2="-13.462" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.969" x2="-12.446" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-6.35" x2="-12.319" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-6.096" x2="-13.462" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-6.096" x2="-14.859" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-13.462" y1="-6.096" x2="-13.716" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-6.096" x2="15.113" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-6.096" x2="-12.446" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="5.461" x2="-13.335" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="5.461" x2="-12.446" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.715" x2="-12.446" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.715" x2="-13.335" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-5.715" x2="-12.446" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-6.223" x2="14.859" y2="-6.223" width="0.3048" layer="21"/>
<wire x1="-14.859" y1="-6.223" x2="-13.716" y2="-6.223" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="-5.842" x2="-12.573" y2="-5.842" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-5.969" x2="15.113" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-6.35" x2="-12.065" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="15.113" y1="-6.096" x2="14.859" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="15.24" y1="5.969" x2="14.859" y2="6.35" width="0.1524" layer="21"/>
<wire x1="14.859" y1="6.35" x2="-12.065" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-10.287" y1="-1.524" x2="-9.779" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="-1.524" x2="-9.779" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="1.524" x2="-10.287" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="1.27" x2="-11.049" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="0.889" x2="-10.668" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-10.287" y1="1.524" x2="-10.287" y2="0" width="0.1524" layer="21"/>
<wire x1="-10.287" y1="0" x2="-10.287" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="0" x2="14.097" y2="0" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="0" x2="-10.287" y2="0" width="0.1524" layer="21"/>
<wire x1="17.78" y1="0" x2="16.002" y2="0" width="0.762" layer="51"/>
<wire x1="-17.78" y1="0" x2="-16.002" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-17.78" y="0" drill="1.1176" diameter="3.1496"/>
<pad name="-" x="17.78" y="0" drill="1.1176" diameter="3.1496" shape="octagon"/>
<text x="-14.732" y="6.731" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.9756" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-9.271" y1="-1.524" x2="-8.763" y2="1.524" layer="21"/>
<rectangle x1="-16.129" y1="-0.381" x2="-15.24" y2="0.381" layer="21"/>
<rectangle x1="15.24" y1="-0.381" x2="16.129" y2="0.381" layer="21"/>
</package>
<package name="E35-14">
grid 30.48 mm, diameter 14 mm</description>
<wire x1="15.24" y1="7.239" x2="15.24" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.239" x2="-15.24" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.239" x2="-14.859" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="7.62" x2="-13.716" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.239" x2="-13.716" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.239" x2="-12.446" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.239" x2="-12.065" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.239" x2="-13.335" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.239" x2="-12.446" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.239" x2="-13.335" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.239" x2="15.24" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="6.731" x2="-12.446" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="7.493" x2="-13.716" y2="7.493" width="0.3048" layer="21"/>
<wire x1="-14.986" y1="7.366" x2="-13.589" y2="7.366" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="7.112" x2="-12.573" y2="7.112" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="6.858" x2="-12.573" y2="6.858" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="7.493" x2="14.859" y2="7.493" width="0.3048" layer="21"/>
<wire x1="-12.192" y1="7.366" x2="14.986" y2="7.366" width="0.3048" layer="21"/>
<wire x1="-15.24" y1="-7.239" x2="-15.113" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="-7.62" x2="-13.716" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.239" x2="-13.462" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.239" x2="-12.446" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-7.62" x2="-12.319" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-7.366" x2="-13.462" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-7.366" x2="-14.859" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-13.462" y1="-7.366" x2="-13.716" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-7.366" x2="15.113" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-7.366" x2="-12.446" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="6.731" x2="-13.335" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="6.731" x2="-12.446" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-6.985" x2="-12.446" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-6.985" x2="-13.335" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-6.985" x2="-12.446" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-7.493" x2="14.859" y2="-7.493" width="0.3048" layer="21"/>
<wire x1="-14.859" y1="-7.493" x2="-13.716" y2="-7.493" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="-7.112" x2="-12.573" y2="-7.112" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-7.239" x2="15.113" y2="-7.366" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-7.62" x2="-12.065" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="15.113" y1="-7.366" x2="14.859" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="15.24" y1="7.239" x2="14.859" y2="7.62" width="0.1524" layer="21"/>
<wire x1="14.859" y1="7.62" x2="-12.065" y2="7.62" width="0.1524" layer="21"/>
<text x="-14.859" y="8.001" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E35-16">
<wire x1="15.24" y1="7.874" x2="15.24" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.874" x2="-15.24" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.874" x2="-14.859" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="8.255" x2="-13.716" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.874" x2="-13.716" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.874" x2="-12.446" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.874" x2="-12.065" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.874" x2="-13.335" y2="7.366" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.874" x2="-12.446" y2="7.366" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="7.874" x2="-13.335" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.874" x2="15.24" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.366" x2="-12.446" y2="7.366" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="8.128" x2="-13.716" y2="8.128" width="0.3048" layer="21"/>
<wire x1="-14.986" y1="8.001" x2="-13.589" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="7.747" x2="-12.573" y2="7.747" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="7.493" x2="-12.573" y2="7.493" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="8.128" x2="14.859" y2="8.128" width="0.3048" layer="21"/>
<wire x1="-12.192" y1="8.001" x2="14.986" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-15.24" y1="-7.874" x2="-15.113" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="-8.255" x2="-13.716" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.874" x2="-13.462" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.874" x2="-12.446" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-8.255" x2="-12.319" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-8.001" x2="-13.462" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-8.001" x2="-14.859" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-13.462" y1="-8.001" x2="-13.716" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-8.001" x2="15.113" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-8.001" x2="-12.446" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="7.366" x2="-13.335" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="7.366" x2="-12.446" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.62" x2="-12.446" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-7.62" x2="-13.335" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-7.62" x2="-12.446" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-8.128" x2="14.859" y2="-8.128" width="0.3048" layer="21"/>
<wire x1="-14.859" y1="-8.128" x2="-13.716" y2="-8.128" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="-7.747" x2="-12.573" y2="-7.747" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-7.874" x2="15.113" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-8.255" x2="-12.065" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="15.113" y1="-8.001" x2="14.859" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="15.24" y1="7.874" x2="14.859" y2="8.255" width="0.1524" layer="21"/>
<wire x1="14.859" y1="8.255" x2="-12.065" y2="8.255" width="0.1524" layer="21"/>
<text x="-14.859" y="8.636" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E35-18">
grid 30.48 mm, diameter 18 mm</description>
<wire x1="15.24" y1="9.779" x2="15.24" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="9.779" x2="-15.24" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="9.779" x2="-14.859" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="10.16" x2="-13.716" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.779" x2="-13.716" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.779" x2="-12.446" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="9.779" x2="-12.065" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.779" x2="-13.335" y2="9.271" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="9.779" x2="-12.446" y2="9.271" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="9.779" x2="-13.335" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="9.779" x2="15.24" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.271" x2="-12.446" y2="9.271" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="10.033" x2="-13.716" y2="10.033" width="0.3048" layer="21"/>
<wire x1="-14.986" y1="9.906" x2="-13.589" y2="9.906" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="9.652" x2="-12.573" y2="9.652" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="9.398" x2="-12.573" y2="9.398" width="0.3048" layer="21"/>
<wire x1="-12.065" y1="10.033" x2="14.859" y2="10.033" width="0.3048" layer="21"/>
<wire x1="-12.192" y1="9.906" x2="14.986" y2="9.906" width="0.3048" layer="21"/>
<wire x1="-15.24" y1="-9.779" x2="-15.113" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-14.859" y1="-10.16" x2="-13.716" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-9.779" x2="-13.462" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-9.779" x2="-12.446" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-10.16" x2="-12.319" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-9.906" x2="-13.462" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-9.906" x2="-14.859" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-13.462" y1="-9.906" x2="-13.716" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-9.906" x2="15.113" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="-12.319" y1="-9.906" x2="-12.446" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="9.271" x2="-13.335" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="9.271" x2="-12.446" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-9.525" x2="-12.446" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-9.525" x2="-13.335" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-12.446" y1="-9.525" x2="-12.446" y2="-9.779" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-10.033" x2="14.859" y2="-10.033" width="0.3048" layer="21"/>
<wire x1="-14.859" y1="-10.033" x2="-13.716" y2="-10.033" width="0.3048" layer="21"/>
<wire x1="-13.208" y1="-9.652" x2="-12.573" y2="-9.652" width="0.3048" layer="21"/>
<wire x1="15.24" y1="-9.779" x2="15.113" y2="-9.906" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-10.16" x2="-12.065" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="15.113" y1="-9.906" x2="14.859" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="15.24" y1="9.779" x2="14.859" y2="10.16" width="0.1524" layer="21"/>
<wire x1="14.859" y1="10.16" x2="-12.065" y2="10.16" width="0.1524" layer="21"/>
<text x="-14.859" y="10.541" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-16.002" y1="-0.381" x2="-15.24" y2="0.381" layer="21"/>
<rectangle x1="15.24" y1="-0.381" x2="16.002" y2="0.381" layer="21"/>
</package>
<package name="E45-16">
grid 45.72 mm, diameter 16 mm</description>
<wire x1="-20.32" y1="7.747" x2="-19.812" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="8.255" x2="-18.288" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="8.255" x2="-17.78" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-7.747" x2="-19.939" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.255" x2="-18.288" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-8.255" x2="-18.161" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="7.747" x2="-20.32" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.747" x2="-16.51" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.255" x2="19.812" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.747" x2="-17.78" y2="-7.6962" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-7.747" x2="-16.51" y2="-7.6962" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-8.128" x2="-18.161" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-8.128" x2="-19.812" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-8.128" x2="-17.78" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-7.747" x2="-16.129" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-8.128" x2="-16.002" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.255" x2="-19.812" y2="-8.2042" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.2042" x2="-18.288" y2="-8.2042" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.255" x2="-16.002" y2="-8.2042" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.62" x2="-16.51" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.6962" x2="-16.51" y2="-7.6962" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.6962" x2="-17.78" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-7.6962" x2="-16.51" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.2042" x2="19.812" y2="-8.2042" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-8.255" x2="19.939" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-8.128" x2="19.939" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-8.128" x2="20.32" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="7.747" x2="-16.002" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="8.255" x2="19.812" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="7.747" x2="-17.78" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="7.747" x2="20.32" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-7.62" x2="-17.78" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.239" x2="-17.78" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-7.62" x2="-16.51" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="7.239" x2="-16.51" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.747" x2="-16.51" y2="7.747" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.239" x2="-16.51" y2="7.239" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="8.128" x2="-18.288" y2="8.128" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="8.128" x2="19.812" y2="8.128" width="0.3048" layer="21"/>
<wire x1="19.812" y1="8.255" x2="20.32" y2="7.747" width="0.1524" layer="21"/>
<wire x1="20.32" y1="7.747" x2="20.32" y2="-7.747" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-1.524" x2="-3.048" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="-1.524" x2="-3.048" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="1.524" x2="-3.556" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="1.27" x2="-4.318" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="0.889" x2="-3.937" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.524" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="0" x2="-3.556" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0" x2="19.05" y2="0" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="0" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="7.62" x2="-16.637" y2="7.62" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="7.874" x2="-18.034" y2="7.874" width="0.3048" layer="21"/>
<wire x1="-17.653" y1="7.366" x2="-16.637" y2="7.366" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="7.874" x2="20.066" y2="7.874" width="0.3048" layer="21"/>
<wire x1="22.86" y1="0" x2="20.955" y2="0" width="0.762" layer="51"/>
<wire x1="-22.86" y1="0" x2="-20.955" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-22.86" y="0" drill="1.1176" diameter="3.81"/>
<pad name="-" x="22.86" y="0" drill="1.1176" diameter="3.81" shape="octagon"/>
<text x="-19.812" y="8.763" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.2446" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.54" y1="-1.524" x2="-2.032" y2="1.524" layer="21"/>
<rectangle x1="20.32" y1="-0.381" x2="20.828" y2="0.381" layer="21"/>
<rectangle x1="-20.828" y1="-0.381" x2="-20.32" y2="0.381" layer="21"/>
</package>
<package name="E45-18">
grid 45.72 mm, diameter 18 mm</description>
<wire x1="-20.32" y1="8.382" x2="-19.812" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="8.89" x2="-18.288" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="8.89" x2="-17.78" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-8.382" x2="-19.939" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.89" x2="-18.288" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-8.89" x2="-18.161" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="8.382" x2="-20.32" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.382" x2="-16.51" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.89" x2="19.812" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.382" x2="-17.78" y2="-8.3312" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-8.382" x2="-16.51" y2="-8.3312" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-8.763" x2="-18.161" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-8.763" x2="-19.812" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-8.763" x2="-17.78" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-8.382" x2="-16.129" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-8.763" x2="-16.002" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.89" x2="-19.812" y2="-8.8392" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-8.8392" x2="-18.288" y2="-8.8392" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.89" x2="-16.002" y2="-8.8392" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.255" x2="-16.51" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.3312" x2="-16.51" y2="-8.3312" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.3312" x2="-17.78" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-8.3312" x2="-16.51" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-8.8392" x2="19.812" y2="-8.8392" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-8.89" x2="19.939" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-8.763" x2="19.939" y2="-8.763" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-8.763" x2="20.32" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="8.382" x2="-16.002" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="8.89" x2="19.812" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="8.382" x2="-17.78" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="8.382" x2="20.32" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.255" x2="-17.78" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.874" x2="-17.78" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-8.255" x2="-16.51" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="7.874" x2="-16.51" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="8.382" x2="-16.51" y2="8.382" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="7.874" x2="-16.51" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="8.763" x2="-18.288" y2="8.763" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="8.763" x2="19.812" y2="8.763" width="0.3048" layer="21"/>
<wire x1="19.812" y1="8.89" x2="20.32" y2="8.382" width="0.1524" layer="21"/>
<wire x1="20.32" y1="8.382" x2="20.32" y2="-8.382" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="8.255" x2="-16.637" y2="8.255" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="8.509" x2="-18.034" y2="8.509" width="0.3048" layer="21"/>
<wire x1="-17.653" y1="8.001" x2="-16.637" y2="8.001" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="8.509" x2="20.066" y2="8.509" width="0.3048" layer="21"/>
<text x="-19.558" y="9.271" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E45-21">
grid 45.72 mm, diameter 21 mm</description>
<wire x1="-20.32" y1="10.287" x2="-19.812" y2="10.795" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="10.795" x2="-18.288" y2="10.795" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="10.795" x2="-17.78" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-10.287" x2="-19.939" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-10.795" x2="-18.288" y2="-10.795" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-10.795" x2="-18.161" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="10.287" x2="-20.32" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.287" x2="-16.51" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-10.795" x2="19.812" y2="-10.795" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.287" x2="-17.78" y2="-10.2362" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.287" x2="-16.51" y2="-10.2362" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-10.668" x2="-18.161" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-10.668" x2="-19.812" y2="-10.795" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-10.668" x2="-17.78" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.287" x2="-16.129" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.668" x2="-16.002" y2="-10.795" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-10.795" x2="-19.812" y2="-10.7442" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-10.7442" x2="-18.288" y2="-10.7442" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-10.795" x2="-16.002" y2="-10.7442" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.16" x2="-16.51" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.2362" x2="-16.51" y2="-10.2362" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.2362" x2="-17.78" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.2362" x2="-16.51" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-10.7442" x2="19.812" y2="-10.7442" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-10.795" x2="19.939" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.668" x2="19.939" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-10.668" x2="20.32" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.287" x2="-16.002" y2="10.795" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="10.795" x2="19.812" y2="10.795" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="10.287" x2="-17.78" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.287" x2="20.32" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.16" x2="-17.78" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="9.779" x2="-17.78" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.16" x2="-16.51" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="9.779" x2="-16.51" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="10.287" x2="-16.51" y2="10.287" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="9.779" x2="-16.51" y2="9.779" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="10.668" x2="-18.288" y2="10.668" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="10.668" x2="19.812" y2="10.668" width="0.3048" layer="21"/>
<wire x1="19.812" y1="10.795" x2="20.32" y2="10.287" width="0.1524" layer="21"/>
<wire x1="20.32" y1="10.287" x2="20.32" y2="-10.287" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="10.16" x2="-16.637" y2="10.16" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="10.414" x2="-18.034" y2="10.414" width="0.3048" layer="21"/>
<wire x1="-17.653" y1="9.906" x2="-16.637" y2="9.906" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="10.414" x2="20.066" y2="10.414" width="0.3048" layer="21"/>
<text x="-19.685" y="11.176" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E45-22">
grid 45.72 mm, diameter 22 mm</description>
<wire x1="-20.32" y1="10.541" x2="-19.812" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="11.049" x2="-18.288" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="11.049" x2="-17.78" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-10.541" x2="-19.939" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-11.049" x2="-18.288" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-11.049" x2="-18.161" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="10.541" x2="-20.32" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.541" x2="-16.51" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-11.049" x2="19.812" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.541" x2="-17.78" y2="-10.4902" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.541" x2="-16.51" y2="-10.4902" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-10.922" x2="-18.161" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-10.922" x2="-19.812" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-10.922" x2="-17.78" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.541" x2="-16.129" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.922" x2="-16.002" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-11.049" x2="-19.812" y2="-10.9982" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-10.9982" x2="-18.288" y2="-10.9982" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-11.049" x2="-16.002" y2="-10.9982" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.414" x2="-16.51" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.4902" x2="-16.51" y2="-10.4902" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.4902" x2="-17.78" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.4902" x2="-16.51" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-10.9982" x2="19.812" y2="-10.9982" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-11.049" x2="19.939" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.922" x2="19.939" y2="-10.922" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-10.922" x2="20.32" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.541" x2="-16.002" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="11.049" x2="19.812" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="10.541" x2="-17.78" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.541" x2="20.32" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-10.414" x2="-17.78" y2="10.033" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="10.033" x2="-17.78" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-10.414" x2="-16.51" y2="10.033" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="10.033" x2="-16.51" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="10.541" x2="-16.51" y2="10.541" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="10.033" x2="-16.51" y2="10.033" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="10.922" x2="-18.288" y2="10.922" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="10.922" x2="19.812" y2="10.922" width="0.3048" layer="21"/>
<wire x1="19.812" y1="11.049" x2="20.32" y2="10.541" width="0.1524" layer="21"/>
<wire x1="20.32" y1="10.541" x2="20.32" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="10.414" x2="-16.637" y2="10.414" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="10.668" x2="-18.034" y2="10.668" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="10.668" x2="20.066" y2="10.668" width="0.3048" layer="21"/>
<text x="-19.685" y="11.43" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E45-25">
grid 45.72 mm, diameter 25 mm</description>
<wire x1="-20.32" y1="12.192" x2="-19.812" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="12.7" x2="-18.288" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="12.7" x2="-17.78" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.192" x2="-19.939" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-12.7" x2="-18.288" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-18.288" y1="-12.7" x2="-18.161" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-20.32" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.192" x2="-16.51" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-12.7" x2="19.812" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.192" x2="-17.78" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-12.192" x2="-16.51" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-12.573" x2="-18.161" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-19.939" y1="-12.573" x2="-19.812" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-18.161" y1="-12.573" x2="-17.78" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-12.192" x2="-16.129" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-12.573" x2="-16.002" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-12.7" x2="-19.812" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="-12.6492" x2="-18.288" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-12.7" x2="-16.002" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.065" x2="-16.51" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.1412" x2="-16.51" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.1412" x2="-17.78" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-12.1412" x2="-16.51" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="-12.6492" x2="19.812" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="19.812" y1="-12.7" x2="19.939" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-12.573" x2="19.939" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="19.939" y1="-12.573" x2="20.32" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="12.192" x2="-16.002" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-16.002" y1="12.7" x2="19.812" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-17.78" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="12.192" x2="20.32" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-12.065" x2="-17.78" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="11.684" x2="-17.78" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="-12.065" x2="-16.51" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="11.684" x2="-16.51" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="12.192" x2="-16.51" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="11.684" x2="-16.51" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-19.812" y1="12.573" x2="-18.288" y2="12.573" width="0.3048" layer="21"/>
<wire x1="-16.002" y1="12.573" x2="19.812" y2="12.573" width="0.3048" layer="21"/>
<wire x1="19.812" y1="12.7" x2="20.32" y2="12.192" width="0.1524" layer="21"/>
<wire x1="20.32" y1="12.192" x2="20.32" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="12.065" x2="-16.637" y2="12.065" width="0.3048" layer="21"/>
<wire x1="-20.066" y1="12.319" x2="-18.034" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-17.653" y1="11.811" x2="-16.637" y2="11.811" width="0.3048" layer="21"/>
<wire x1="-16.256" y1="12.319" x2="20.066" y2="12.319" width="0.3048" layer="21"/>
<text x="-19.558" y="13.208" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E5-10,5">
grid 5.08 mm, diameter 10.5 mm</description>
<wire x1="-1.143" y1="0" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.143" x2="-0.254" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.143" x2="-0.254" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.143" x2="-0.889" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.143" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.143" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.651" x2="-3.81" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.27" x2="-4.191" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="0" x2="-1.143" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="5.08" width="0.1524" layer="21"/>
<pad name="+" x="-2.54" y="0" drill="1.016" diameter="2.54"/>
<pad name="-" x="2.54" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<text x="4.699" y="2.7432" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.1242" y="-3.2258" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.143" x2="0.889" y2="1.143" layer="21"/>
</package>
<package name="E5-13">
grid 5.08 mm, diameter 13 mm</description>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.27" x2="-0.889" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.27" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="0" x2="-4.445" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.635" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0" x2="1.524" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="6.985" width="0.1524" layer="21"/>
<text x="6.3754" y="4.1148" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.572" y="-3.937" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.889" y2="1.27" layer="21"/>
</package>
<package name="E5-4">
grid 5.05 mm, diameter 4 mm</description>
<wire x1="-1.6985" y1="1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="21" curve="-113.419135"/>
<wire x1="-1.6985" y1="-1.1153" x2="1.6985" y2="-1.1153" width="0.1524" layer="21" curve="113.419135"/>
<wire x1="-1.6985" y1="1.1153" x2="-1.6985" y2="-1.1153" width="0.1524" layer="51" curve="66.580865"/>
<wire x1="1.6985" y1="-1.1153" x2="1.6985" y2="1.1153" width="0.1524" layer="51" curve="66.580865"/>
<wire x1="-1.397" y1="0" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-1.016" x2="-0.254" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.016" x2="-0.254" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.016" x2="-0.762" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="1.016" x2="-0.762" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.635" x2="-1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.381" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<pad name="+" x="-2.54" y="0" drill="0.8128" diameter="1.905"/>
<pad name="-" x="2.54" y="0" drill="0.8128" diameter="1.905" shape="octagon"/>
<text x="2.159" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.159" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.016" x2="0.762" y2="1.016" layer="21"/>
</package>
<package name="E5-5">
grid 5.08 mm, diameter 5 mm</description>
<wire x1="-2.1557" y1="1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="21" curve="-116.146571"/>
<wire x1="-2.1557" y1="-1.3432" x2="2.1557" y2="-1.3432" width="0.1524" layer="21" curve="116.146571"/>
<wire x1="-2.1557" y1="1.3432" x2="-2.1557" y2="-1.3432" width="0.1524" layer="51" curve="63.853429"/>
<wire x1="2.1557" y1="-1.3432" x2="2.1557" y2="1.3432" width="0.1524" layer="51" curve="63.853429"/>
<text x="2.54" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.54" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E5-6">
grid 5.08 mm, diameter 6 mm</description>
<wire x1="-2.8702" y1="1.3574" x2="2.8702" y2="1.3574" width="0.1524" layer="21" curve="-129.378377"/>
<wire x1="-2.8702" y1="-1.3574" x2="2.8702" y2="-1.3574" width="0.1524" layer="21" curve="129.378377"/>
<wire x1="-2.8702" y1="1.3574" x2="-2.8702" y2="-1.3574" width="0.1524" layer="51" curve="50.621623"/>
<wire x1="2.8702" y1="-1.3574" x2="2.8702" y2="1.3574" width="0.1524" layer="51" curve="50.621623"/>
<text x="3.048" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.048" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E5-8,5">
grid 5.08 mm, diameter 8.5 mm</description>
<wire x1="-3.302" y1="2.032" x2="-3.302" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="-2.921" y2="1.651" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="4.445" width="0.1524" layer="21"/>
<text x="4.1402" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.5146" y="-3.0226" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E50-25">
grid 50 mm, diameter 25 mm</description>
<wire x1="22.225" y1="-12.192" x2="21.844" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="21.717" y1="-12.7" x2="-18.542" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="21.717" y1="12.7" x2="22.225" y2="12.192" width="0.1524" layer="21"/>
<wire x1="22.225" y1="12.192" x2="22.225" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="12.192" x2="-22.352" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="12.192" x2="-22.86" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="12.7" x2="-20.828" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-20.828" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-19.05" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="12.7" x2="-19.05" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="12.7" x2="21.717" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="12.192" x2="-20.32" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="12.192" x2="-19.05" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="12.192" x2="-20.32" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="11.684" x2="-19.05" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="12.192" x2="22.225" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-20.193" y1="12.065" x2="-19.177" y2="12.065" width="0.3048" layer="21"/>
<wire x1="-20.193" y1="11.811" x2="-19.177" y2="11.811" width="0.3048" layer="21"/>
<wire x1="-22.352" y1="12.573" x2="-20.828" y2="12.573" width="0.3048" layer="21"/>
<wire x1="-22.606" y1="12.319" x2="-22.479" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-22.479" y1="12.319" x2="-22.479" y2="12.446" width="0.3048" layer="21"/>
<wire x1="-22.479" y1="12.319" x2="-20.701" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-20.701" y1="12.319" x2="-20.701" y2="12.446" width="0.3048" layer="21"/>
<wire x1="-20.701" y1="12.319" x2="-20.574" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-18.542" y1="12.573" x2="21.717" y2="12.573" width="0.3048" layer="21"/>
<wire x1="-18.796" y1="12.319" x2="-18.669" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="12.319" x2="-18.669" y2="12.446" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="12.319" x2="21.971" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-22.86" y1="-12.192" x2="-22.479" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-12.7" x2="-20.828" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.192" x2="-20.701" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.192" x2="-19.05" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-12.192" x2="-18.669" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="11.684" x2="-20.32" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="11.684" x2="-19.05" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="-12.573" x2="-20.701" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="-12.573" x2="-22.352" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-20.701" y1="-12.573" x2="-20.828" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.065" x2="-19.05" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.065" x2="-20.32" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-12.065" x2="-19.05" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-18.669" y1="-12.573" x2="21.844" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-18.669" y1="-12.573" x2="-18.542" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-12.7" x2="-22.352" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-12.6492" x2="-20.828" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.1412" x2="-19.05" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-12.1412" x2="-20.32" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-12.1412" x2="-19.05" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-12.7" x2="-18.542" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-12.6492" x2="21.717" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="21.844" y1="-12.573" x2="21.717" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-1.524" x2="-5.588" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-1.524" x2="-5.588" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="1.524" x2="-6.096" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-6.858" y1="1.27" x2="-6.858" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-7.239" y1="0.889" x2="-6.477" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="1.524" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="0" x2="-6.096" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="0" x2="20.955" y2="0" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="0" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="24.765" y1="0" x2="22.86" y2="0" width="0.762" layer="51"/>
<wire x1="-25.4" y1="0" x2="-23.495" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-25.4" y="0" drill="1.1176" diameter="3.81"/>
<pad name="-" x="24.765" y="0" drill="1.1176" diameter="3.81" shape="octagon"/>
<text x="-22.098" y="13.208" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.7846" y="-2.4892" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.08" y1="-1.524" x2="-4.572" y2="1.524" layer="21"/>
<rectangle x1="22.225" y1="-0.381" x2="22.733" y2="0.381" layer="21"/>
<rectangle x1="-23.368" y1="-0.381" x2="-22.86" y2="0.381" layer="21"/>
</package>
<package name="E50-30">
grid 50 mm, diameter 30 mm</description>
<wire x1="22.225" y1="-14.732" x2="21.844" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="21.717" y1="-15.24" x2="-18.542" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="21.717" y1="15.24" x2="22.225" y2="14.732" width="0.1524" layer="21"/>
<wire x1="22.225" y1="14.732" x2="22.225" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.732" x2="-22.352" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.732" x2="-22.86" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="15.24" x2="-20.828" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.732" x2="-20.828" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.732" x2="-19.05" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="15.24" x2="-19.05" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="15.24" x2="21.717" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.732" x2="-20.32" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="14.732" x2="-19.05" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.732" x2="-20.32" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.224" x2="-19.05" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="14.732" x2="22.225" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-20.193" y1="14.605" x2="-19.177" y2="14.605" width="0.3048" layer="21"/>
<wire x1="-20.193" y1="14.351" x2="-19.177" y2="14.351" width="0.3048" layer="21"/>
<wire x1="-22.352" y1="15.113" x2="-20.828" y2="15.113" width="0.3048" layer="21"/>
<wire x1="-22.606" y1="14.859" x2="-22.479" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-22.479" y1="14.859" x2="-22.479" y2="14.986" width="0.3048" layer="21"/>
<wire x1="-22.479" y1="14.859" x2="-20.701" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-20.701" y1="14.859" x2="-20.701" y2="14.986" width="0.3048" layer="21"/>
<wire x1="-20.701" y1="14.859" x2="-20.574" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-18.542" y1="15.113" x2="21.717" y2="15.113" width="0.3048" layer="21"/>
<wire x1="-18.796" y1="14.859" x2="-18.669" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="14.859" x2="-18.669" y2="14.986" width="0.3048" layer="21"/>
<wire x1="-18.669" y1="14.859" x2="21.971" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-22.86" y1="-14.732" x2="-22.479" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-15.24" x2="-20.828" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.732" x2="-20.701" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.732" x2="-19.05" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-14.732" x2="-18.669" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="14.224" x2="-20.32" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="14.224" x2="-19.05" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="-15.113" x2="-20.701" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-22.479" y1="-15.113" x2="-22.352" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-20.701" y1="-15.113" x2="-20.828" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.605" x2="-19.05" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.605" x2="-20.32" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-14.605" x2="-19.05" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-18.669" y1="-15.113" x2="21.844" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-18.669" y1="-15.113" x2="-18.542" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-15.24" x2="-22.352" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-22.352" y1="-15.1892" x2="-20.828" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.6812" x2="-19.05" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-14.6812" x2="-20.32" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-19.05" y1="-14.6812" x2="-19.05" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-15.24" x2="-18.542" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-15.1892" x2="21.717" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="21.844" y1="-15.113" x2="21.717" y2="-15.24" width="0.1524" layer="21"/>
<pad name="+" x="-25.4" y="0" drill="1.1938" diameter="3.81"/>
<pad name="-" x="24.765" y="0" drill="1.1938" diameter="3.81" shape="octagon"/>
<text x="-21.971" y="15.748" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E55-25">
grid 55 mm, diameter 25 mm</description>
<wire x1="-25.4" y1="12.192" x2="-24.892" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="12.7" x2="-23.368" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-23.368" y1="12.7" x2="-22.86" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-12.192" x2="-25.019" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-12.7" x2="-23.368" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-23.368" y1="-12.7" x2="-23.241" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="12.192" x2="-25.4" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.192" x2="-21.59" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-12.7" x2="24.892" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.192" x2="-22.86" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-12.192" x2="-21.59" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-25.019" y1="-12.573" x2="-23.241" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-25.019" y1="-12.573" x2="-24.892" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-23.241" y1="-12.573" x2="-22.86" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-12.192" x2="-21.209" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-12.573" x2="-21.082" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-12.7" x2="-24.892" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-12.6492" x2="-23.368" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-12.7" x2="-21.082" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.065" x2="-21.59" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.1412" x2="-21.59" y2="-12.1412" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.1412" x2="-22.86" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-12.1412" x2="-21.59" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-12.6492" x2="24.892" y2="-12.6492" width="0.1524" layer="21"/>
<wire x1="24.892" y1="-12.7" x2="25.019" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-12.573" x2="25.019" y2="-12.573" width="0.1524" layer="21"/>
<wire x1="25.019" y1="-12.573" x2="25.4" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="12.192" x2="-21.082" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="12.7" x2="24.892" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="12.192" x2="-22.86" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="12.192" x2="25.4" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-12.065" x2="-22.86" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="11.684" x2="-22.86" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-12.065" x2="-21.59" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="11.684" x2="-21.59" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="12.192" x2="-21.59" y2="12.192" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="11.684" x2="-21.59" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="12.573" x2="-23.368" y2="12.573" width="0.3048" layer="21"/>
<wire x1="-21.082" y1="12.573" x2="24.892" y2="12.573" width="0.3048" layer="21"/>
<wire x1="24.892" y1="12.7" x2="25.4" y2="12.192" width="0.1524" layer="21"/>
<wire x1="25.4" y1="12.192" x2="25.4" y2="-12.192" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0" x2="24.13" y2="0" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="0" x2="-3.556" y2="0" width="0.1524" layer="21"/>
<wire x1="-22.733" y1="12.065" x2="-21.717" y2="12.065" width="0.3048" layer="21"/>
<wire x1="-25.146" y1="12.319" x2="-23.114" y2="12.319" width="0.3048" layer="21"/>
<wire x1="-22.733" y1="11.811" x2="-21.717" y2="11.811" width="0.3048" layer="21"/>
<wire x1="-21.336" y1="12.319" x2="25.146" y2="12.319" width="0.3048" layer="21"/>
<wire x1="27.94" y1="0" x2="26.035" y2="0" width="0.762" layer="51"/>
<wire x1="-27.94" y1="0" x2="-26.035" y2="0" width="0.762" layer="51"/>
<pad name="+" x="-27.94" y="0" drill="1.1176" diameter="3.81"/>
<pad name="-" x="27.94" y="0" drill="1.1176" diameter="3.81" shape="octagon"/>
<text x="-24.638" y="13.208" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="25.4" y1="-0.381" x2="25.908" y2="0.381" layer="21"/>
<rectangle x1="-25.908" y1="-0.381" x2="-25.4" y2="0.381" layer="21"/>
</package>
<package name="E55-30">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 55 mm, diameter 30 mm</description>
<wire x1="-25.4" y1="14.732" x2="-24.892" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="15.24" x2="-23.368" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-23.368" y1="15.24" x2="-22.86" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-14.732" x2="-25.019" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-15.24" x2="-23.368" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-23.368" y1="-15.24" x2="-23.241" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="14.732" x2="-25.4" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.732" x2="-21.59" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-15.24" x2="24.892" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.732" x2="-22.86" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-14.732" x2="-21.59" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-25.019" y1="-15.113" x2="-23.241" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-25.019" y1="-15.113" x2="-24.892" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-23.241" y1="-15.113" x2="-22.86" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-14.732" x2="-21.209" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-15.113" x2="-21.082" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-15.24" x2="-24.892" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="-15.1892" x2="-23.368" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-15.24" x2="-21.082" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.605" x2="-21.59" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.6812" x2="-21.59" y2="-14.6812" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.6812" x2="-22.86" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-14.6812" x2="-21.59" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="-15.1892" x2="24.892" y2="-15.1892" width="0.1524" layer="21"/>
<wire x1="24.892" y1="-15.24" x2="25.019" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="-21.209" y1="-15.113" x2="25.019" y2="-15.113" width="0.1524" layer="21"/>
<wire x1="25.019" y1="-15.113" x2="25.4" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="14.732" x2="-21.082" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-21.082" y1="15.24" x2="24.892" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="14.732" x2="-22.86" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="14.732" x2="25.4" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-14.605" x2="-22.86" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.224" x2="-22.86" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="-14.605" x2="-21.59" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-21.59" y1="14.224" x2="-21.59" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.732" x2="-21.59" y2="14.732" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="14.224" x2="-21.59" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-24.892" y1="15.113" x2="-23.368" y2="15.113" width="0.3048" layer="21"/>
<wire x1="-21.082" y1="15.113" x2="24.892" y2="15.113" width="0.3048" layer="21"/>
<wire x1="24.892" y1="15.24" x2="25.4" y2="14.732" width="0.1524" layer="21"/>
<wire x1="25.4" y1="14.732" x2="25.4" y2="-14.732" width="0.1524" layer="21"/>
<wire x1="-22.733" y1="14.605" x2="-21.717" y2="14.605" width="0.3048" layer="21"/>
<wire x1="-25.146" y1="14.859" x2="-23.114" y2="14.859" width="0.3048" layer="21"/>
<wire x1="-22.733" y1="14.351" x2="-21.717" y2="14.351" width="0.3048" layer="21"/>
<wire x1="-21.336" y1="14.859" x2="25.146" y2="14.859" width="0.3048" layer="21"/>
<pad name="+" x="-27.94" y="0" drill="1.1938" diameter="3.81"/>
<pad name="-" x="27.94" y="0" drill="1.1938" diameter="3.81" shape="octagon"/>
<text x="-24.511" y="15.748" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="E5R">
grid 5.08 mm, diameter 9 mm</description>
<wire x1="-0.889" y1="0" x2="0.9398" y2="0" width="0.6096" layer="21"/>
<wire x1="-5.588" y1="0" x2="-4.572" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.508" x2="-5.08" y2="0.508" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0" x2="1.143" y2="0" width="0.6096" layer="51"/>
<wire x1="-2.54" y1="0" x2="-1.016" y2="0" width="0.6096" layer="51"/>
<wire x1="1.778" y1="-1.143" x2="1.7821" y2="1.1275" width="0.1524" layer="21" curve="-330.552701"/>
<wire x1="1.7732" y1="1.1613" x2="1.7781" y2="-1.143" width="0.1524" layer="51" curve="-29.895306"/>
<pad name="+" x="-2.54" y="0" drill="0.8128" diameter="2.54"/>
<pad name="-" x="2.54" y="0" drill="0.8128" diameter="2.54" shape="octagon"/>
<text x="1.651" y="2.4638" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E7,5-16">
grid 7.62 mm, diameter 16 mm</description>
<wire x1="0.635" y1="0" x2="2.032" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-2.032" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.905" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.905" x2="-0.254" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.905" x2="-0.254" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.905" x2="-0.889" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-7.493" y1="0" x2="-5.969" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-0.762" x2="-6.731" y2="0.762" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="8.255" width="0.1524" layer="21"/>
<pad name="-" x="3.81" y="0" drill="1.016" diameter="3.1496" shape="octagon"/>
<pad name="+" x="-3.81" y="0" drill="1.016" diameter="3.1496"/>
<text x="7.874" y="3.81" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.2926" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.905" x2="0.889" y2="1.905" layer="21"/>
</package>
<package name="E7,5-18">
grid 7.62 mm, diameter 18 mm</description>
<circle x="0" y="0" radius="8.89" width="0.1524" layer="21"/>
<text x="8.001" y="5.08" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="EB20D">
grid 10.16 mm, diameter 20 mm</description>
<wire x1="-2.54" y1="0" x2="-1.5748" y2="0" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="0" x2="-1.5748" y2="2.54" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="2.54" x2="-0.4318" y2="2.54" width="0.254" layer="21"/>
<wire x1="-0.4318" y1="2.54" x2="-0.4318" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-0.4318" y1="-2.54" x2="-1.5748" y2="-2.54" width="0.254" layer="21"/>
<wire x1="-1.5748" y1="-2.54" x2="-1.5748" y2="0" width="0.254" layer="21"/>
<wire x1="0.635" y1="0" x2="2.54" y2="0" width="0.254" layer="21"/>
<wire x1="-2.794" y1="2.54" x2="-2.794" y2="1.27" width="0.254" layer="21"/>
<wire x1="-2.159" y1="1.905" x2="-3.429" y2="1.905" width="0.254" layer="21"/>
<circle x="0" y="0" radius="10.16" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="7.62" width="0.1524" layer="21"/>
<pad name="+" x="-5.08" y="0" drill="2.0066" diameter="4.5974"/>
<pad name="-" x="5.08" y="0" drill="2.0066" diameter="4.5974" shape="octagon"/>
<text x="7.8994" y="7.366" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.0546" y="-5.08" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.3302" y1="-2.54" x2="1.6002" y2="2.54" layer="21"/>
</package>
<package name="EB22,5D">
grid 10.16 mm, diameter 22.5 mm</description>
<circle x="0" y="0" radius="8.89" width="0.254" layer="21"/>
<circle x="0" y="0" radius="11.303" width="0.1524" layer="21"/>
<text x="8.4074" y="8.509" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.0546" y="-5.715" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="EB25D">
grid 10.16 mm, diameter 25 mm</description>
<circle x="0" y="0" radius="12.7" width="0.254" layer="21"/>
<text x="9.6774" y="9.525" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="EB30D">
grid 10.16 mm, diameter 30 mm</description>
<circle x="0" y="0" radius="15.24" width="0.254" layer="21"/>
<circle x="0" y="0" radius="12.065" width="0.254" layer="21"/>
<text x="10.8204" y="11.938" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.0546" y="-7.62" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="EB35D">
grid 10.16 mm, diameter 35 mm</description>
<wire x1="1.397" y1="0" x2="2.54" y2="0" width="0.254" layer="21"/>
<circle x="0" y="0" radius="17.78" width="0.254" layer="21"/>
<circle x="0" y="0" radius="13.97" width="0.254" layer="21"/>
<text x="12.954" y="13.462" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="085CS_1R">
<description>&lt;b&gt;Aluminum electrolytic capacitors&lt;/b&gt; reflow soldering&lt;p&gt;
SMD (Chip) Standard 085 CS&lt;p&gt;
http://www.bccomponents.com/</description>
<wire x1="5.7" y1="-0.95" x2="5.95" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="5.95" y1="-0.7" x2="5.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="5.95" y1="0.7" x2="5.7" y2="0.95" width="0.1016" layer="51"/>
<wire x1="5.7" y1="0.95" x2="5.7" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="5.8" y1="-0.75" x2="5.8" y2="0.75" width="0.2032" layer="51"/>
<wire x1="-5.7" y1="0.95" x2="-5.95" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-5.95" y1="0.7" x2="-5.95" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="-5.95" y1="-0.7" x2="-5.7" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="-5.7" y1="-0.95" x2="-5.7" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-5.8" y1="0.75" x2="-5.8" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="5.15" y1="-1.85" x2="5.15" y2="1.85" width="0.2032" layer="51"/>
<wire x1="5.15" y1="1.85" x2="-5.15" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-5.15" y1="1.85" x2="-5.15" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="-5.15" y1="-1.85" x2="5.15" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="5.1" y1="-1.35" x2="3.3" y2="-1.35" width="0.2032" layer="51"/>
<wire x1="3.3" y1="-1.35" x2="3.2" y2="-1.75" width="0.2032" layer="21"/>
<wire x1="5.05" y1="1.35" x2="3.3" y2="1.35" width="0.2032" layer="51"/>
<wire x1="3.3" y1="1.35" x2="3.2" y2="1.75" width="0.2032" layer="21"/>
<wire x1="-7" y1="2.2" x2="-7" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="7" y1="2.2" x2="7" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="-7" y1="2.2" x2="7" y2="2.2" width="0.2032" layer="39"/>
<wire x1="-7" y1="-2.2" x2="7" y2="-2.2" width="0.2032" layer="39"/>
<smd name="+" x="4.75" y="0" dx="2.9" dy="2.5" layer="1"/>
<smd name="-" x="-4.75" y="0" dx="2.9" dy="2.5" layer="1"/>
<text x="-5.31" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.31" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="3.3" y1="-1" x2="5.65" y2="1" layer="51"/>
<rectangle x1="-5.65" y1="-1" x2="-3.3" y2="1" layer="51"/>
</package>
<package name="085CS_1W">
<description>&lt;b&gt;Aluminum electrolytic capacitors&lt;/b&gt; wave soldering&lt;p&gt;
<wire x1="5.15" y1="1.85" x2="3.2" y2="1.85" width="0.2032" layer="51"/>
<wire x1="3.2" y1="1.85" x2="-5.15" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-5.15" y1="1.85" x2="-5.15" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="-5.15" y1="-1.85" x2="3.2" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="3.2" y1="-1.85" x2="5.15" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="3.3" y1="-1.35" x2="3.2" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="3.3" y1="1.35" x2="3.2" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-8.6" y1="4" x2="-8.6" y2="-4" width="0.2032" layer="39"/>
<wire x1="8.6" y1="4" x2="8.6" y2="-4" width="0.2032" layer="39"/>
<wire x1="-8.6" y1="4" x2="8.6" y2="4" width="0.2032" layer="39"/>
<wire x1="-8.6" y1="-4" x2="8.6" y2="-4" width="0.2032" layer="39"/>
<smd name="+" x="5.95" y="0" dx="4.7" dy="3.7" layer="1" roundness="50"/>
<smd name="-" x="-5.95" y="0" dx="4.7" dy="3.7" layer="1" roundness="50"/>
</package>
<package name="085CS_1AR">
<wire x1="4.2" y1="-0.95" x2="4.45" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="4.45" y1="-0.7" x2="4.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="4.45" y1="0.7" x2="4.2" y2="0.95" width="0.1016" layer="51"/>
<wire x1="4.2" y1="0.95" x2="4.2" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="4.3" y1="-0.75" x2="4.3" y2="0.75" width="0.2032" layer="51"/>
<wire x1="-4.2" y1="0.95" x2="-4.45" y2="0.7" width="0.1016" layer="51"/>
<wire x1="-4.45" y1="0.7" x2="-4.45" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="-4.45" y1="-0.7" x2="-4.2" y2="-0.95" width="0.1016" layer="51"/>
<wire x1="-4.2" y1="-0.95" x2="-4.2" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-4.3" y1="0.75" x2="-4.3" y2="-0.75" width="0.2032" layer="51"/>
<wire x1="3.65" y1="-1.85" x2="3.65" y2="1.85" width="0.2032" layer="51"/>
<wire x1="3.65" y1="1.85" x2="-3.65" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-3.65" y1="1.85" x2="-3.65" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="-3.65" y1="-1.85" x2="3.65" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="3.6" y1="-1.35" x2="1.8" y2="-1.35" width="0.2032" layer="51"/>
<wire x1="1.8" y1="-1.35" x2="1.7" y2="-1.75" width="0.2032" layer="21"/>
<wire x1="3.55" y1="1.35" x2="1.8" y2="1.35" width="0.2032" layer="51"/>
<wire x1="1.8" y1="1.35" x2="1.7" y2="1.75" width="0.2032" layer="21"/>
<wire x1="-5.5" y1="2.2" x2="-5.5" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="5.5" y1="2.2" x2="5.5" y2="-2.2" width="0.2032" layer="39"/>
<wire x1="-5.5" y1="2.2" x2="5.5" y2="2.2" width="0.2032" layer="39"/>
<wire x1="-5.5" y1="-2.2" x2="5.5" y2="-2.2" width="0.2032" layer="39"/>
<smd name="+" x="3.25" y="0" dx="2.9" dy="2.5" layer="1"/>
<smd name="-" x="-3.25" y="0" dx="2.9" dy="2.5" layer="1"/>
<text x="-3.81" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.81" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="1.8" y1="-1" x2="4.15" y2="1" layer="51"/>
<rectangle x1="-4.15" y1="-1" x2="-1.8" y2="1" layer="51"/>
</package>
<package name="085CS_1AW">
<wire x1="3.65" y1="1.85" x2="1.7" y2="1.85" width="0.2032" layer="51"/>
<wire x1="1.7" y1="1.85" x2="-3.65" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-3.65" y1="-1.85" x2="1.7" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="1.7" y1="-1.85" x2="3.65" y2="-1.85" width="0.2032" layer="51"/>
<wire x1="1.8" y1="-1.35" x2="1.7" y2="-1.85" width="0.2032" layer="21"/>
<wire x1="1.8" y1="1.35" x2="1.7" y2="1.85" width="0.2032" layer="21"/>
<wire x1="-6.9" y1="4.1" x2="-6.9" y2="-4.1" width="0.2032" layer="39"/>
<wire x1="6.9" y1="4.1" x2="6.9" y2="-4.1" width="0.2032" layer="39"/>
<wire x1="-6.9" y1="4.1" x2="6.9" y2="4.1" width="0.2032" layer="39"/>
<wire x1="-6.9" y1="-4.1" x2="6.9" y2="-4.1" width="0.2032" layer="39"/>
<smd name="+" x="4.45" y="0" dx="4.7" dy="3.7" layer="1" roundness="50"/>
<smd name="-" x="-4.45" y="0" dx="4.7" dy="3.7" layer="1" roundness="50"/>
</package>
<package name="139CLL-2R">
SMD (Chip) Long Life 139 CLL&lt;p&gt;
<wire x1="-8.1" y1="3.9" x2="-8.1" y2="-3.9" width="0.2032" layer="39"/>
<wire x1="-8.1" y1="-3.9" x2="8.1" y2="-3.9" width="0.2032" layer="39"/>
<wire x1="8.1" y1="-3.9" x2="8.1" y2="3.9" width="0.2032" layer="39"/>
<wire x1="8.1" y1="3.9" x2="-8.1" y2="3.9" width="0.2032" layer="39"/>
<wire x1="7.15" y1="-0.6" x2="6.9" y2="-0.85" width="0.254" layer="51"/>
<wire x1="6.9" y1="-0.85" x2="6.9" y2="0.85" width="0.254" layer="51"/>
<wire x1="6.9" y1="0.85" x2="7.15" y2="0.6" width="0.254" layer="51"/>
<wire x1="7.15" y1="0.6" x2="7.15" y2="-0.6" width="0.254" layer="51"/>
<wire x1="-7.15" y1="0.6" x2="-6.9" y2="0.85" width="0.254" layer="51"/>
<wire x1="-6.9" y1="0.85" x2="-6.9" y2="-0.85" width="0.254" layer="51"/>
<wire x1="-6.9" y1="-0.85" x2="-7.15" y2="-0.6" width="0.254" layer="51"/>
<wire x1="-7.15" y1="-0.6" x2="-7.15" y2="0.6" width="0.254" layer="51"/>
<wire x1="6.4" y1="-3.05" x2="-6.4" y2="-3.05" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="-3.05" x2="-6.4" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="-1.6" x2="-6.4" y2="1.6" width="0.2032" layer="51"/>
<wire x1="-6.4" y1="1.6" x2="-6.4" y2="3.05" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="3.05" x2="6.4" y2="3.05" width="0.2032" layer="21"/>
<wire x1="6.4" y1="3.05" x2="6.4" y2="1.6" width="0.2032" layer="21"/>
<wire x1="6.4" y1="1.6" x2="6.4" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="6.4" y1="-1.6" x2="6.4" y2="-3.05" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-2" x2="4.5" y2="-2" width="0.2032" layer="21"/>
<wire x1="4.5" y1="-2" x2="4.25" y2="-2.95" width="0.2032" layer="21"/>
<wire x1="6.35" y1="2" x2="4.5" y2="2" width="0.2032" layer="21"/>
<wire x1="4.5" y1="2" x2="4.25" y2="2.95" width="0.2032" layer="21"/>
<smd name="+" x="6.2" y="0" dx="3.5" dy="2.8" layer="1"/>
<smd name="-" x="-6.2" y="0" dx="3.5" dy="2.8" layer="1"/>
<text x="-2.54" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.81" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="4.5" y1="-1" x2="6.85" y2="1" layer="51"/>
<rectangle x1="-6.85" y1="-1" x2="-4.5" y2="1" layer="51"/>
</package>
<package name="139CLL-2W">
<wire x1="-10.15" y1="3.9" x2="-10.15" y2="-3.9" width="0.2032" layer="39"/>
<wire x1="-10.15" y1="-3.9" x2="10.15" y2="-3.9" width="0.2032" layer="39"/>
<wire x1="10.15" y1="-3.9" x2="10.15" y2="3.9" width="0.2032" layer="39"/>
<wire x1="10.15" y1="3.9" x2="-10.15" y2="3.9" width="0.2032" layer="39"/>
<wire x1="-6.4" y1="-3.05" x2="-6.4" y2="3.05" width="0.2032" layer="51"/>
<wire x1="6.4" y1="3.05" x2="6.4" y2="-3.05" width="0.2032" layer="51"/>
<wire x1="6.35" y1="-2" x2="4.5" y2="-2" width="0.2032" layer="51"/>
<wire x1="6.35" y1="2" x2="4.5" y2="2" width="0.2032" layer="51"/>
<smd name="+" x="7.15" y="0" dx="4.3" dy="5" layer="1" roundness="50"/>
<smd name="-" x="-7.15" y="0" dx="4.3" dy="5" layer="1" roundness="50"/>
</package>
<package name="139CLL-3R">
<wire x1="-8.1" y1="4.6" x2="-8.1" y2="-4.6" width="0.2032" layer="39"/>
<wire x1="-8.1" y1="-4.6" x2="8.1" y2="-4.6" width="0.2032" layer="39"/>
<wire x1="8.1" y1="-4.6" x2="8.1" y2="4.6" width="0.2032" layer="39"/>
<wire x1="8.1" y1="4.6" x2="-8.1" y2="4.6" width="0.2032" layer="39"/>
<wire x1="6.4" y1="-3.75" x2="-6.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="-3.75" x2="-6.4" y2="-1.6" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="1.6" x2="-6.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="-6.4" y1="3.75" x2="6.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="6.4" y1="3.75" x2="6.4" y2="1.6" width="0.2032" layer="21"/>
<wire x1="6.4" y1="-1.6" x2="6.4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="6.35" y1="-2.7" x2="4.5" y2="-2.7" width="0.2032" layer="21"/>
<wire x1="4.5" y1="-2.7" x2="4.25" y2="-3.65" width="0.2032" layer="21"/>
<wire x1="6.35" y1="2.7" x2="4.5" y2="2.7" width="0.2032" layer="21"/>
<wire x1="4.5" y1="2.7" x2="4.25" y2="3.65" width="0.2032" layer="21"/>
</package>
<package name="139CLL-3W">
<wire x1="-10.6" y1="6.4" x2="-10.6" y2="-6.4" width="0.2032" layer="39"/>
<wire x1="-10.6" y1="-6.4" x2="9.2" y2="-6.4" width="0.2032" layer="39"/>
<wire x1="9.2" y1="-6.4" x2="9.2" y2="6.4" width="0.2032" layer="39"/>
<wire x1="9.2" y1="6.4" x2="-10.6" y2="6.4" width="0.2032" layer="39"/>
<smd name="+" x="7.15" y="0" dx="4.3" dy="6" layer="1" roundness="50"/>
<smd name="-" x="-7.15" y="0" dx="4.3" dy="6" layer="1" roundness="50"/>
</package>
<package name="140CLH-0810">
<description>&lt;b&gt;Aluminum electrolytic capacitors SMD (Chip)&lt;/b&gt;&lt;p&gt;
Long life base plate, High temperature 140 CLH&lt;p&gt;
<wire x1="-4.85" y1="4.2" x2="3.4" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.85" y1="2.75" x2="4.85" y2="1.45" width="0.2032" layer="21"/>
<wire x1="4.85" y1="1.45" x2="4.85" y2="-1.45" width="0.2032" layer="51"/>
<wire x1="4.85" y1="-1.45" x2="4.85" y2="-2.75" width="0.2032" layer="21"/>
<wire x1="3.4" y1="-4.2" x2="-4.85" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="-4.85" y1="-4.2" x2="-4.85" y2="-1.45" width="0.2032" layer="21"/>
<wire x1="-4.85" y1="-1.45" x2="-4.85" y2="1.45" width="0.2032" layer="51"/>
<wire x1="-4.85" y1="1.45" x2="-4.85" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.85" y1="2.75" x2="3.4" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.85" y1="-2.75" x2="3.4" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="-3.65" y1="1.4" x2="3.65" y2="1.4" width="0.2032" layer="21" curve="-138.030204"/>
<wire x1="3.65" y1="1.4" x2="3.65" y2="-1.4" width="0.2032" layer="51" curve="-41.969796"/>
<wire x1="-3.65" y1="-1.4" x2="3.65" y2="-1.4" width="0.2032" layer="21" curve="138.030204"/>
<wire x1="-3.65" y1="-1.4" x2="-3.65" y2="1.4" width="0.2032" layer="51" curve="-41.969796"/>
<smd name="+" x="3.25" y="0" dx="3.5" dy="2.5" layer="1"/>
<smd name="-" x="-3.25" y="0" dx="3.5" dy="2.5" layer="1"/>
<text x="-5.38" y="-2.74" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="0.635" y="-3.175" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
<package name="140CLH-1010">
<wire x1="-5.8" y1="5.15" x2="4.35" y2="5.15" width="0.2032" layer="21"/>
<wire x1="5.8" y1="3.7" x2="5.8" y2="1.45" width="0.2032" layer="21"/>
<wire x1="5.8" y1="1.45" x2="5.8" y2="-1.45" width="0.2032" layer="51"/>
<wire x1="5.8" y1="-1.45" x2="5.8" y2="-3.7" width="0.2032" layer="21"/>
<wire x1="4.35" y1="-5.15" x2="-5.8" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="-5.8" y1="-5.15" x2="-5.8" y2="-1.45" width="0.2032" layer="21"/>
<wire x1="-5.8" y1="-1.45" x2="-5.8" y2="1.45" width="0.2032" layer="51"/>
<wire x1="-5.8" y1="1.45" x2="-5.8" y2="5.15" width="0.2032" layer="21"/>
<wire x1="5.8" y1="3.7" x2="4.35" y2="5.15" width="0.2032" layer="21"/>
<wire x1="5.8" y1="-3.7" x2="4.35" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="-4.7" y1="-1.4" x2="4.7" y2="-1.4" width="0.2032" layer="21" curve="146.825323"/>
<wire x1="4.7" y1="-1.4" x2="4.7" y2="1.4" width="0.2032" layer="51" curve="33.174677"/>
<wire x1="-4.7" y1="1.4" x2="4.7" y2="1.4" width="0.2032" layer="21" curve="-146.825323"/>
<wire x1="-4.7" y1="1.4" x2="-4.7" y2="-1.4" width="0.2032" layer="51" curve="33.174677"/>
<smd name="+" x="4.15" y="0" dx="4.3" dy="2.5" layer="1"/>
<smd name="-" x="-4.15" y="0" dx="4.3" dy="2.5" layer="1"/>
<text x="-2.74" y="1.93" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.375" y="-2.885" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="140CLH-1014">
<text x="-2.69" y="1.98" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.225" y="-2.935" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="150CLZ-0810">
Long life base plate, very low impedance 150 CLZ&lt;p&gt;
<text x="-5.43" y="-2.74" size="1.27" layer="25" rot="R90">&gt;NAME</text>
</package>
<package name="150CLZ-1010">
<text x="-2.79" y="1.93" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.075" y="-2.885" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="150CLZ-1014">
<wire x1="-4.7" y1="-1.4" x2="-4.7" y2="1.4" width="0.2032" layer="51" curve="-33.174677"/>
<text x="-2.74" y="1.88" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.025" y="-2.935" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0405">
<description>&lt;b&gt;Aluminum electrolytic capacitors&lt;/b&gt;&lt;p&gt;
SMD (Chip) Long Life Vertical 153 CLV&lt;p&gt;
<wire x1="1.25" y1="-2.15" x2="-2.15" y2="-2.15" width="0.2032" layer="21"/>
<wire x1="-2.15" y1="-2.15" x2="-2.15" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-2.15" y1="-1.1" x2="-2.15" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-2.15" y1="1.1" x2="-2.15" y2="2.15" width="0.2032" layer="21"/>
<wire x1="-2.15" y1="2.15" x2="1.25" y2="2.15" width="0.2032" layer="21"/>
<wire x1="2.15" y1="1.25" x2="2.15" y2="1.1" width="0.2032" layer="21"/>
<wire x1="2.15" y1="1.1" x2="2.15" y2="-1.05" width="0.2032" layer="51"/>
<wire x1="2.15" y1="-1.05" x2="2.15" y2="-1.25" width="0.2032" layer="21"/>
<wire x1="2.15" y1="-1.25" x2="1.25" y2="-2.15" width="0.2032" layer="21"/>
<wire x1="1.25" y1="2.15" x2="2.15" y2="1.25" width="0.2032" layer="21"/>
<wire x1="-1.65" y1="-0.95" x2="1.65" y2="-0.95" width="0.2032" layer="21" curve="120.136976"/>
<wire x1="-1.65" y1="-0.95" x2="-1.65" y2="0.95" width="0.2032" layer="51" curve="-59.863024"/>
<wire x1="-1.65" y1="0.95" x2="1.65" y2="0.95" width="0.2032" layer="21" curve="-120.136976"/>
<wire x1="1.65" y1="-0.95" x2="1.65" y2="0.95" width="0.2032" layer="51" curve="59.863024"/>
<smd name="+" x="1.8" y="0" dx="2.6" dy="1.6" layer="1"/>
<smd name="-" x="-1.8" y="0" dx="2.6" dy="1.6" layer="1"/>
<text x="-2.24" y="2.48" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.275" y="-3.735" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0505">
<wire x1="1.75" y1="-2.65" x2="-2.65" y2="-2.65" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="-2.65" x2="-2.65" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="-1.1" x2="-2.65" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-2.65" y1="1.1" x2="-2.65" y2="2.65" width="0.2032" layer="21"/>
<wire x1="-2.65" y1="2.65" x2="1.75" y2="2.65" width="0.2032" layer="21"/>
<wire x1="2.65" y1="1.75" x2="2.65" y2="1.1" width="0.2032" layer="21"/>
<wire x1="2.65" y1="1.1" x2="2.65" y2="-1.1" width="0.2032" layer="51"/>
<wire x1="2.65" y1="-1.1" x2="2.65" y2="-1.75" width="0.2032" layer="21"/>
<wire x1="2.65" y1="-1.75" x2="1.75" y2="-2.65" width="0.2032" layer="21"/>
<wire x1="1.75" y1="2.65" x2="2.65" y2="1.75" width="0.2032" layer="21"/>
<wire x1="-2.2" y1="-0.95" x2="2.2" y2="-0.95" width="0.2032" layer="21" curve="133.28887"/>
<wire x1="-2.2" y1="-0.95" x2="-2.2" y2="0.95" width="0.2032" layer="51" curve="-46.71113"/>
<wire x1="-2.2" y1="0.95" x2="2.2" y2="0.95" width="0.2032" layer="21" curve="-133.28887"/>
<wire x1="2.2" y1="-0.95" x2="2.2" y2="0.95" width="0.2032" layer="51" curve="46.71113"/>
<smd name="+" x="2.2" y="0" dx="3" dy="1.6" layer="1"/>
<smd name="-" x="-2.2" y="0" dx="3" dy="1.6" layer="1"/>
<text x="-2.74" y="2.98" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.775" y="-4.235" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0605">
<wire x1="2.4" y1="-3.3" x2="-3.3" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-3.3" x2="-3.3" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="-1.1" x2="-3.3" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-3.3" y1="1.1" x2="-3.3" y2="3.3" width="0.2032" layer="21"/>
<wire x1="-3.3" y1="3.3" x2="2.4" y2="3.3" width="0.2032" layer="21"/>
<wire x1="3.3" y1="2.4" x2="3.3" y2="1.1" width="0.2032" layer="21"/>
<wire x1="3.3" y1="1.1" x2="3.3" y2="-1.1" width="0.2032" layer="51"/>
<wire x1="3.3" y1="-1.1" x2="3.3" y2="-2.4" width="0.2032" layer="21"/>
<wire x1="3.3" y1="-2.4" x2="2.4" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="2.4" y1="3.3" x2="3.3" y2="2.4" width="0.2032" layer="21"/>
<wire x1="-2.95" y1="-0.9" x2="2.95" y2="-0.95" width="0.2032" layer="21" curve="145.181395"/>
<wire x1="-2.95" y1="-0.9" x2="-2.95" y2="0.95" width="0.2032" layer="51" curve="-34.818605"/>
<wire x1="-2.95" y1="0.95" x2="2.95" y2="0.9" width="0.2032" layer="21" curve="-145.181395"/>
<wire x1="2.95" y1="-0.95" x2="2.95" y2="0.9" width="0.2032" layer="51" curve="34.818605"/>
<smd name="+" x="2.7" y="0" dx="3.5" dy="1.6" layer="1"/>
<smd name="-" x="-2.7" y="0" dx="3.5" dy="1.6" layer="1"/>
<text x="-3.39" y="3.63" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.425" y="-4.885" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0807">
<wire x1="3.3" y1="-4.2" x2="-4.2" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="-4.2" x2="-4.2" y2="-1.1" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="-1.1" x2="-4.2" y2="1.1" width="0.2032" layer="51"/>
<wire x1="-4.2" y1="1.1" x2="-4.2" y2="4.2" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="4.2" x2="3.3" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.2" y1="3.3" x2="4.2" y2="1.1" width="0.2032" layer="21"/>
<wire x1="4.2" y1="1.1" x2="4.2" y2="-1.1" width="0.2032" layer="51"/>
<wire x1="4.2" y1="-1.1" x2="4.2" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="4.2" y1="-3.3" x2="3.3" y2="-4.2" width="0.2032" layer="21"/>
<wire x1="3.3" y1="4.2" x2="4.2" y2="3.3" width="0.2032" layer="21"/>
<wire x1="-3.75" y1="-1.05" x2="3.75" y2="-1.05" width="0.2032" layer="21" curve="148.008335"/>
<wire x1="-3.75" y1="-1.05" x2="-3.75" y2="1.05" width="0.2032" layer="51" curve="-31.284493"/>
<wire x1="-3.75" y1="1.05" x2="3.75" y2="1.05" width="0.2032" layer="21" curve="-148.008335"/>
<wire x1="3.75" y1="1.05" x2="3.75" y2="-1.05" width="0.2032" layer="51" curve="-31.284493"/>
<smd name="+" x="3.05" y="0" dx="4" dy="1.6" layer="1"/>
<smd name="-" x="-3.05" y="0" dx="4" dy="1.6" layer="1"/>
<text x="-4.29" y="4.53" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.325" y="-5.785" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-0810">
<wire x1="-4.2" y1="-4.2" x2="-4.2" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="-1.5" x2="-4.2" y2="1.5" width="0.2032" layer="51"/>
<wire x1="-4.2" y1="1.5" x2="-4.2" y2="4.2" width="0.2032" layer="21"/>
<wire x1="4.2" y1="3.3" x2="4.2" y2="1.5" width="0.2032" layer="21"/>
<wire x1="4.2" y1="1.5" x2="4.2" y2="-1.5" width="0.2032" layer="51"/>
<wire x1="4.2" y1="-1.5" x2="4.2" y2="-3.3" width="0.2032" layer="21"/>
<wire x1="3.65" y1="-1.4" x2="3.65" y2="1.4" width="0.2032" layer="51" curve="41.969796"/>
</package>
<package name="153CLV-1010">
<wire x1="4.3" y1="-5.2" x2="-5.2" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="-5.2" y1="-5.2" x2="-5.2" y2="-1.5" width="0.2032" layer="21"/>
<wire x1="-5.2" y1="-1.5" x2="-5.2" y2="1.5" width="0.2032" layer="51"/>
<wire x1="-5.2" y1="1.5" x2="-5.2" y2="5.2" width="0.2032" layer="21"/>
<wire x1="-5.2" y1="5.2" x2="4.3" y2="5.2" width="0.2032" layer="21"/>
<wire x1="5.2" y1="4.3" x2="5.2" y2="1.5" width="0.2032" layer="21"/>
<wire x1="5.2" y1="1.5" x2="5.2" y2="-1.5" width="0.2032" layer="51"/>
<wire x1="5.2" y1="-1.5" x2="5.2" y2="-4.3" width="0.2032" layer="21"/>
<wire x1="5.2" y1="-4.3" x2="4.3" y2="-5.2" width="0.2032" layer="21"/>
<wire x1="4.3" y1="5.2" x2="5.2" y2="4.3" width="0.2032" layer="21"/>
<wire x1="4.65" y1="-1.55" x2="4.65" y2="1.55" width="0.2032" layer="51" curve="36.869898"/>
<wire x1="-4.65" y1="-1.55" x2="-4.65" y2="1.55" width="0.2032" layer="51" curve="-36.869898"/>
<wire x1="-4.65" y1="-1.55" x2="4.65" y2="-1.55" width="0.2032" layer="21" curve="143.130102"/>
<wire x1="-4.65" y1="1.55" x2="4.65" y2="1.55" width="0.2032" layer="21" curve="-143.130102"/>
<smd name="+" x="4" y="0" dx="4" dy="2.5" layer="1"/>
<smd name="-" x="-4" y="0" dx="4" dy="2.5" layer="1"/>
<text x="-5.29" y="5.53" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.325" y="-6.785" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="153CLV-1012">
</package>
<package name="153CLV-1014">
</package>
<package name="175TMP-0808">
High Temperature solid electrolytic SMD 175 TMP&lt;p&gt;
<wire x1="3.2" y1="-4.1" x2="-4.1" y2="-4.1" width="0.2032" layer="21"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="-1.55" width="0.2032" layer="21"/>
<wire x1="-4.1" y1="-1.55" x2="-4.1" y2="1.55" width="0.2032" layer="51"/>
<wire x1="-4.1" y1="1.55" x2="-4.1" y2="4.1" width="0.2032" layer="21"/>
<wire x1="-4.1" y1="4.1" x2="3.2" y2="4.1" width="0.2032" layer="21"/>
<wire x1="4.1" y1="3.2" x2="4.1" y2="1.5" width="0.2032" layer="21"/>
<wire x1="4.1" y1="1.5" x2="4.1" y2="-1.55" width="0.2032" layer="51"/>
<wire x1="4.1" y1="-1.55" x2="4.1" y2="-3.2" width="0.2032" layer="21"/>
<wire x1="4.1" y1="-3.2" x2="3.2" y2="-4.1" width="0.2032" layer="21"/>
<wire x1="3.2" y1="4.1" x2="4.1" y2="3.2" width="0.2032" layer="21"/>
<wire x1="-3.6" y1="-1.45" x2="3.6" y2="-1.45" width="0.2032" layer="21" curve="136.123039"/>
<wire x1="-3.6" y1="-1.45" x2="-3.6" y2="1.45" width="0.2032" layer="51" curve="-43.876961"/>
<wire x1="-3.6" y1="1.45" x2="3.6" y2="1.45" width="0.2032" layer="21" curve="-136.123039"/>
<wire x1="3.6" y1="1.45" x2="3.6" y2="-1.45" width="0.2032" layer="51" curve="-43.876961"/>
<smd name="+" x="3.5" y="0" dx="3" dy="2.5" layer="1"/>
<smd name="-" x="-3.5" y="0" dx="3" dy="2.5" layer="1"/>
</package>
<package name="175TMP-0810">
<wire x1="3.6" y1="-1.45" x2="3.6" y2="1.45" width="0.2032" layer="51" curve="43.876961"/>
</package>
<package name="A/3216-18R">
<description>&lt;b&gt;Chip Capacitor Type KEMET A / EIA 3216-18 reflow solder&lt;/b&gt;&lt;p&gt;KEMET S / EIA 3216-12</description>
<wire x1="-1.45" y1="0.6" x2="1.45" y2="0.6" width="0.1016" layer="51"/>
<wire x1="1.45" y1="0.6" x2="1.45" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="1.45" y1="-0.6" x2="-1.45" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="-1.45" y1="-0.6" x2="-1.45" y2="0.6" width="0.1016" layer="51"/>
<smd name="+" x="1.375" y="0" dx="1.95" dy="1.5" layer="1"/>
<smd name="-" x="-1.375" y="0" dx="1.95" dy="1.5" layer="1"/>
<text x="-1.95" y="1" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.95" y="-2.325" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-0.6" x2="-1.475" y2="0.6" layer="51"/>
<rectangle x1="1.475" y1="-0.6" x2="1.6" y2="0.6" layer="51"/>
<rectangle x1="0.8" y1="-0.625" x2="1.1" y2="0.625" layer="51"/>
</package>
<package name="A/3216-18W">
<description>&lt;b&gt;Chip Capacitor Type KEMET A / EIA 3216-18 Wave solder&lt;/b&gt;&lt;p&gt;
<smd name="+" x="1.475" y="0" dx="2.15" dy="1.8" layer="1"/>
<smd name="-" x="-1.475" y="0" dx="2.15" dy="1.8" layer="1"/>
</package>
<package name="B/3528-21R">
<description>&lt;b&gt;Chip Capacitor Type KEMET B / EIA 3528-21 reflow solder&lt;/b&gt;&lt;p&gt;KEMET T / EIA 3528-12</description>
<wire x1="-1.6" y1="1.2" x2="1.6" y2="1.2" width="0.1016" layer="51"/>
<wire x1="1.6" y1="1.2" x2="1.6" y2="-1.2" width="0.1016" layer="51"/>
<wire x1="1.6" y1="-1.2" x2="-1.6" y2="-1.2" width="0.1016" layer="51"/>
<wire x1="-1.6" y1="-1.2" x2="-1.6" y2="1.2" width="0.1016" layer="51"/>
<smd name="+" x="1.525" y="0" dx="1.95" dy="2.5" layer="1"/>
<smd name="-" x="-1.525" y="0" dx="1.95" dy="2.5" layer="1"/>
<text x="-1.95" y="1.6" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.95" y="-2.925" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.75" y1="-0.6" x2="-1.625" y2="0.6" layer="51"/>
<rectangle x1="1.625" y1="-0.6" x2="1.75" y2="0.6" layer="51"/>
<rectangle x1="0.95" y1="-1.225" x2="1.25" y2="1.225" layer="51"/>
</package>
<package name="B/3528-21W">
<description>&lt;b&gt;Chip Capacitor Type KEMET B / EIA 3528-21 Wave solder&lt;/b&gt;&lt;p&gt;
<smd name="+" x="1.625" y="0" dx="2.15" dy="1.8" layer="1"/>
<smd name="-" x="-1.625" y="0" dx="2.15" dy="1.8" layer="1"/>
</package>
<package name="C/6032-28R">
<description>&lt;b&gt;Chip Capacitor Type KEMET C / EIA 6032-28 reflow solder&lt;/b&gt;&lt;p&gt;KEMET U / EIA 6032-15</description>
<wire x1="-2.8" y1="1.55" x2="2.8" y2="1.55" width="0.1016" layer="51"/>
<wire x1="2.8" y1="1.55" x2="2.8" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="2.8" y1="-1.55" x2="-2.8" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="-2.8" y1="-1.55" x2="-2.8" y2="1.55" width="0.1016" layer="51"/>
<smd name="+" x="2.525" y="0" dx="2.55" dy="2.5" layer="1"/>
<smd name="-" x="-2.525" y="0" dx="2.55" dy="2.5" layer="1"/>
<text x="-3" y="1.825" size="1.27" layer="25">&gt;NAME</text>
<text x="-3" y="-3.05" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3" y1="-1.1" x2="-2.85" y2="1.1" layer="51"/>
<rectangle x1="2.85" y1="-1.1" x2="3" y2="1.1" layer="51"/>
<rectangle x1="1.95" y1="-1.575" x2="2.45" y2="1.575" layer="51"/>
</package>
<package name="C/6032-28W">
<description>&lt;b&gt;Chip Capacitor Type KEMET C / EIA 6032-28 Wafe solder&lt;/b&gt;&lt;p&gt;
<smd name="+" x="2.625" y="0" dx="2.75" dy="1.8" layer="1"/>
<smd name="-" x="-2.625" y="0" dx="2.75" dy="1.8" layer="1"/>
</package>
<package name="D/7343-31R">
<description>&lt;b&gt;Chip Capacitor Type KEMET D / EIA 7343-21&lt;/b&gt;&lt;p&gt;KEMET V / EIA 7343-20, KEMET X / EIA 7343-43 reflow solder</description>
<wire x1="-3.45" y1="2.1" x2="3.45" y2="2.1" width="0.1016" layer="51"/>
<wire x1="3.45" y1="2.1" x2="3.45" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="3.45" y1="-2.1" x2="-3.45" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="-3.45" y1="-2.1" x2="-3.45" y2="2.1" width="0.1016" layer="51"/>
<smd name="+" x="3.175" y="0" dx="2.55" dy="2.7" layer="1"/>
<smd name="-" x="-3.175" y="0" dx="2.55" dy="2.7" layer="1"/>
<text x="-3.65" y="2.3" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.65" y="-3.575" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-1.2" x2="-3.5" y2="1.2" layer="51"/>
<rectangle x1="3.5" y1="-1.2" x2="3.65" y2="1.2" layer="51"/>
<rectangle x1="2.675" y1="-2.125" x2="3.15" y2="2.125" layer="51"/>
</package>
<package name="D/7343-31W">
KEMET V / EIA 7343-20, KEMET X / EIA 7343-43 Wafe solder</description>
<smd name="+" x="3.375" y="0" dx="2.95" dy="2.7" layer="1"/>
<smd name="-" x="-3.375" y="0" dx="2.95" dy="2.7" layer="1"/>
</package>
<package name="E/7260-38R">
<description>&lt;b&gt;Chip Capacitor Type KEMET E / EIA 7260-38 reflow solder&lt;/b&gt;</description>
<wire x1="-3.45" y1="2.95" x2="3.45" y2="2.95" width="0.1016" layer="51"/>
<wire x1="3.45" y1="2.95" x2="3.45" y2="-2.95" width="0.1016" layer="51"/>
<wire x1="3.45" y1="-2.95" x2="-3.45" y2="-2.95" width="0.1016" layer="51"/>
<wire x1="-3.45" y1="-2.95" x2="-3.45" y2="2.95" width="0.1016" layer="51"/>
<smd name="+" x="3.175" y="0" dx="2.55" dy="4.4" layer="1"/>
<smd name="-" x="-3.175" y="0" dx="2.55" dy="4.4" layer="1"/>
<text x="-4.45" y="3.15" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.45" y="-4.475" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-2.05" x2="-3.5" y2="2.05" layer="51"/>
<rectangle x1="3.5" y1="-2.05" x2="3.65" y2="2.05" layer="51"/>
<rectangle x1="2.675" y1="-2.975" x2="3.15" y2="2.975" layer="51"/>
</package>
<package name="E/7260-38W">
<description>&lt;b&gt;Chip Capacitor Type KEMET E / EIA 7260-38 Wafe solder&lt;/b&gt;</description>
<smd name="+" x="3.375" y="0" dx="2.95" dy="4.4" layer="1"/>
<smd name="-" x="-3.375" y="0" dx="2.95" dy="4.4" layer="1"/>
</package>
<package name="R/2012-12R">
<description>&lt;b&gt;Chip Capacitor Type KEMET R/EIA 2012-12 reflow solder&lt;/b&gt;</description>
<wire x1="-0.85" y1="0.6" x2="0.85" y2="0.6" width="0.1016" layer="51"/>
<wire x1="0.85" y1="0.6" x2="0.85" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="0.85" y1="-0.6" x2="-0.85" y2="-0.6" width="0.1016" layer="51"/>
<wire x1="-0.85" y1="-0.6" x2="-0.85" y2="0.6" width="0.1016" layer="51"/>
<smd name="+" x="1.175" y="0" dx="1.55" dy="1.8" layer="1"/>
<smd name="-" x="-1.175" y="0" dx="1.55" dy="1.8" layer="1"/>
<rectangle x1="-1" y1="-0.45" x2="-0.875" y2="0.45" layer="51"/>
<rectangle x1="0.875" y1="-0.45" x2="1" y2="0.45" layer="51"/>
<rectangle x1="0.3" y1="-0.625" x2="0.5" y2="0.625" layer="51"/>
</package>
<package name="R/2012-12W">
<description>&lt;b&gt;Chip Capacitor Type KEMET R/EIA 2012-12 Wafe solder&lt;/b&gt;</description>
<smd name="+" x="1.275" y="0" dx="1.75" dy="1.26" layer="1"/>
<smd name="-" x="-1.275" y="0" dx="1.75" dy="1.26" layer="1"/>
</package>
<package name="PANASONIC_A">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package A&lt;/b&gt;</description>
<wire x1="-1.6" y1="1.6" x2="0.8" y2="1.6" width="0.1016" layer="51"/>
<wire x1="0.8" y1="1.6" x2="1.6" y2="0.8" width="0.1016" layer="51"/>
<wire x1="1.6" y1="0.8" x2="1.6" y2="-0.8" width="0.1016" layer="51"/>
<wire x1="1.6" y1="-0.8" x2="0.8" y2="-1.6" width="0.1016" layer="51"/>
<wire x1="0.8" y1="-1.6" x2="-1.6" y2="-1.6" width="0.1016" layer="51"/>
<wire x1="-1.6" y1="-1.6" x2="-1.6" y2="1.6" width="0.1016" layer="51"/>
<wire x1="-1.1" y1="0.95" x2="1.1" y2="0.95" width="0.1016" layer="21" curve="-98.369832"/>
<wire x1="-1.1" y1="-0.95" x2="1.15" y2="-0.9" width="0.1016" layer="21" curve="101.144396"/>
<wire x1="-1.6" y1="0.95" x2="-1.6" y2="1.6" width="0.1016" layer="21"/>
<wire x1="-1.6" y1="1.6" x2="0.8" y2="1.6" width="0.1016" layer="21"/>
<wire x1="0.8" y1="1.6" x2="1.5" y2="0.9" width="0.1016" layer="21"/>
<wire x1="1.5" y1="-0.9" x2="0.8" y2="-1.6" width="0.1016" layer="21"/>
<wire x1="0.8" y1="-1.6" x2="-1.6" y2="-1.6" width="0.1016" layer="21"/>
<wire x1="-1.6" y1="-1.6" x2="-1.6" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="-0.8" y1="1.2" x2="-0.8" y2="-1.2" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="1.45" width="0.1016" layer="51"/>
<smd name="-" x="-1.3" y="0" dx="2" dy="1.5" layer="1"/>
<smd name="+" x="1.3" y="0" dx="2" dy="1.5" layer="1"/>
<text x="-1.65" y="1.75" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.65" y="-2.825" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.8" y1="-0.3" x2="-1.45" y2="0.3" layer="51"/>
<rectangle x1="1.45" y1="-0.3" x2="1.8" y2="0.3" layer="51"/>
<polygon width="0.1016" layer="51">
<vertex x="-0.85" y="1.1"/>
<vertex x="-1.15" y="0.8"/>
<vertex x="-1.35" y="0.3"/>
<vertex x="-1.35" y="-0.3"/>
<vertex x="-1.15" y="-0.8"/>
<vertex x="-0.85" y="-1.1"/>
<vertex x="-0.85" y="1.05"/>
</polygon>
</package>
<package name="PANASONIC_B">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package B&lt;/b&gt;</description>
<wire x1="-2.1" y1="2.1" x2="1" y2="2.1" width="0.1016" layer="51"/>
<wire x1="1" y1="2.1" x2="2.1" y2="1" width="0.1016" layer="51"/>
<wire x1="2.1" y1="1" x2="2.1" y2="-1" width="0.1016" layer="51"/>
<wire x1="2.1" y1="-1" x2="1" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="1" y1="-2.1" x2="-2.1" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="-2.1" y1="-2.1" x2="-2.1" y2="2.1" width="0.1016" layer="51"/>
<wire x1="-1.75" y1="0.85" x2="1.75" y2="0.85" width="0.1016" layer="21" curve="-128.186984"/>
<wire x1="-1.75" y1="-0.85" x2="1.75" y2="-0.85" width="0.1016" layer="21" curve="128.186984"/>
<wire x1="-2.1" y1="0.85" x2="-2.1" y2="2.1" width="0.1016" layer="21"/>
<wire x1="-2.1" y1="2.1" x2="1" y2="2.1" width="0.1016" layer="21"/>
<wire x1="1" y1="2.1" x2="2.1" y2="1" width="0.1016" layer="21"/>
<wire x1="2.1" y1="-1" x2="1" y2="-2.1" width="0.1016" layer="21"/>
<wire x1="1" y1="-2.1" x2="-2.1" y2="-2.1" width="0.1016" layer="21"/>
<wire x1="-2.1" y1="-2.1" x2="-2.1" y2="-0.85" width="0.1016" layer="21"/>
<wire x1="-1.2" y1="1.5" x2="-1.2" y2="-1.5" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="1.95" width="0.1016" layer="51"/>
<smd name="-" x="-1.6" y="0" dx="2.2" dy="1.4" layer="1"/>
<smd name="+" x="1.6" y="0" dx="2.2" dy="1.4" layer="1"/>
<text x="-2.15" y="2.3" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.15" y="-3.275" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.3" y1="-0.35" x2="-1.85" y2="0.35" layer="51"/>
<rectangle x1="1.9" y1="-0.35" x2="2.3" y2="0.35" layer="51"/>
<vertex x="-1.25" y="1.45"/>
<vertex x="-1.7" y="0.85"/>
<vertex x="-1.85" y="0.35"/>
<vertex x="-1.85" y="-0.4"/>
<vertex x="-1.7" y="-0.85"/>
<vertex x="-1.25" y="-1.4"/>
<vertex x="-1.25" y="1.4"/>
</polygon>
</package>
<package name="PANASONIC_C">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package C&lt;/b&gt;</description>
<wire x1="-2.6" y1="2.6" x2="1.25" y2="2.6" width="0.1016" layer="51"/>
<wire x1="1.25" y1="2.6" x2="2.6" y2="1.25" width="0.1016" layer="51"/>
<wire x1="2.6" y1="1.25" x2="2.6" y2="-1.25" width="0.1016" layer="51"/>
<wire x1="2.6" y1="-1.25" x2="1.25" y2="-2.6" width="0.1016" layer="51"/>
<wire x1="1.25" y1="-2.6" x2="-2.6" y2="-2.6" width="0.1016" layer="51"/>
<wire x1="-2.6" y1="-2.6" x2="-2.6" y2="2.6" width="0.1016" layer="51"/>
<wire x1="-2.6" y1="0.95" x2="-2.6" y2="2.6" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="2.6" x2="1.25" y2="2.6" width="0.1016" layer="21"/>
<wire x1="1.25" y1="2.6" x2="2.6" y2="1.25" width="0.1016" layer="21"/>
<wire x1="2.6" y1="1.25" x2="2.6" y2="0.95" width="0.1016" layer="21"/>
<wire x1="2.6" y1="-0.95" x2="2.6" y2="-1.25" width="0.1016" layer="21"/>
<wire x1="2.6" y1="-1.25" x2="1.25" y2="-2.6" width="0.1016" layer="21"/>
<wire x1="1.25" y1="-2.6" x2="-2.6" y2="-2.6" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="-2.6" x2="-2.6" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="-2.3" y1="0.85" x2="2.3" y2="0.85" width="0.1016" layer="21" curve="-139.434882"/>
<wire x1="-2.3" y1="-0.85" x2="2.3" y2="-0.85" width="0.1016" layer="21" curve="139.434882"/>
<wire x1="-1.55" y1="1.85" x2="-1.55" y2="-1.85" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="2.45" width="0.1016" layer="51"/>
<smd name="-" x="-2.05" y="0" dx="2.6" dy="1.4" layer="1"/>
<smd name="+" x="2.05" y="0" dx="2.6" dy="1.4" layer="1"/>
<text x="-2.6" y="2.75" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.65" y="-3.775" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.95" y1="-0.35" x2="-2.4" y2="0.35" layer="51"/>
<rectangle x1="2.4" y1="-0.35" x2="2.95" y2="0.35" layer="51"/>
<vertex x="-1.6" y="1.8"/>
<vertex x="-2" y="1.35"/>
<vertex x="-2.25" y="0.75"/>
<vertex x="-2.45" y="0.05"/>
<vertex x="-2.25" y="-0.75"/>
<vertex x="-1.95" y="-1.35"/>
<vertex x="-1.6" y="-1.8"/>
</polygon>
</package>
<package name="PANASONIC_D">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package D&lt;/b&gt;</description>
<wire x1="-3.25" y1="3.25" x2="1.55" y2="3.25" width="0.1016" layer="51"/>
<wire x1="1.55" y1="3.25" x2="3.25" y2="1.55" width="0.1016" layer="51"/>
<wire x1="3.25" y1="1.55" x2="3.25" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="3.25" y1="-1.55" x2="1.55" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="1.55" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="-3.25" y1="-3.25" x2="-3.25" y2="3.25" width="0.1016" layer="51"/>
<wire x1="-3.25" y1="0.95" x2="-3.25" y2="3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="3.25" x2="1.55" y2="3.25" width="0.1016" layer="21"/>
<wire x1="1.55" y1="3.25" x2="3.25" y2="1.55" width="0.1016" layer="21"/>
<wire x1="3.25" y1="1.55" x2="3.25" y2="0.95" width="0.1016" layer="21"/>
<wire x1="3.25" y1="-0.95" x2="3.25" y2="-1.55" width="0.1016" layer="21"/>
<wire x1="3.25" y1="-1.55" x2="1.55" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="1.55" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="-3.25" x2="-3.25" y2="-0.95" width="0.1016" layer="21"/>
<wire x1="-2.95" y1="0.95" x2="2.95" y2="0.95" width="0.1016" layer="21" curve="-144.299363"/>
<wire x1="-2.95" y1="-0.95" x2="2.95" y2="-0.95" width="0.1016" layer="21" curve="144.299363"/>
<wire x1="-2.1" y1="2.25" x2="-2.1" y2="-2.2" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="3.1" width="0.1016" layer="51"/>
<smd name="-" x="-2.4" y="0" dx="3" dy="1.4" layer="1"/>
<smd name="+" x="2.4" y="0" dx="3" dy="1.4" layer="1"/>
<text x="-1.75" y="1" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.75" y="-1.975" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-0.35" x2="-3.05" y2="0.35" layer="51"/>
<rectangle x1="3.05" y1="-0.35" x2="3.65" y2="0.35" layer="51"/>
<vertex x="-2.15" y="2.15"/>
<vertex x="-2.6" y="1.6"/>
<vertex x="-2.9" y="0.9"/>
<vertex x="-3.05" y="0"/>
<vertex x="-2.9" y="-0.95"/>
<vertex x="-2.55" y="-1.65"/>
<vertex x="-2.15" y="-2.15"/>
<vertex x="-2.15" y="2.1"/>
</polygon>
</package>
<package name="PANASONIC_E">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package E&lt;/b&gt;</description>
<wire x1="-4.1" y1="4.1" x2="1.8" y2="4.1" width="0.1016" layer="51"/>
<wire x1="1.8" y1="4.1" x2="4.1" y2="1.8" width="0.1016" layer="51"/>
<wire x1="4.1" y1="1.8" x2="4.1" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="4.1" y1="-1.8" x2="1.8" y2="-4.1" width="0.1016" layer="51"/>
<wire x1="1.8" y1="-4.1" x2="-4.1" y2="-4.1" width="0.1016" layer="51"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="4.1" width="0.1016" layer="51"/>
<wire x1="-4.1" y1="0.9" x2="-4.1" y2="4.1" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="4.1" x2="1.8" y2="4.1" width="0.1016" layer="21"/>
<wire x1="1.8" y1="4.1" x2="4.1" y2="1.8" width="0.1016" layer="21"/>
<wire x1="4.1" y1="1.8" x2="4.1" y2="0.9" width="0.1016" layer="21"/>
<wire x1="4.1" y1="-0.9" x2="4.1" y2="-1.8" width="0.1016" layer="21"/>
<wire x1="4.1" y1="-1.8" x2="1.8" y2="-4.1" width="0.1016" layer="21"/>
<wire x1="1.8" y1="-4.1" x2="-4.1" y2="-4.1" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="-0.9" width="0.1016" layer="21"/>
<wire x1="-2.2" y1="3.25" x2="-2.2" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="-3.85" y1="0.9" x2="3.85" y2="0.9" width="0.1016" layer="21" curve="-153.684915"/>
<wire x1="-3.85" y1="-0.9" x2="3.85" y2="-0.9" width="0.1016" layer="21" curve="153.684915"/>
<circle x="0" y="0" radius="3.95" width="0.1016" layer="51"/>
<smd name="-" x="-3" y="0" dx="3.8" dy="1.4" layer="1"/>
<smd name="+" x="3" y="0" dx="3.8" dy="1.4" layer="1"/>
<text x="-1.8" y="1.3" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.8" y="-2.225" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-4.5" y1="-0.35" x2="-3.8" y2="0.35" layer="51"/>
<rectangle x1="3.8" y1="-0.35" x2="4.5" y2="0.35" layer="51"/>
<vertex x="-2.25" y="3.2"/>
<vertex x="-3" y="2.5"/>
<vertex x="-3.6" y="1.5"/>
<vertex x="-3.85" y="0.65"/>
<vertex x="-3.85" y="-0.65"/>
<vertex x="-3.55" y="-1.6"/>
<vertex x="-2.95" y="-2.55"/>
<vertex x="-2.25" y="-3.2"/>
<vertex x="-2.25" y="3.15"/>
</polygon>
</package>
<package name="PANASONIC_F">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package F&lt;/b&gt;</description>
<wire x1="-4.1" y1="1" x2="-4.1" y2="4.1" width="0.1016" layer="21"/>
<wire x1="4.1" y1="1.8" x2="4.1" y2="1" width="0.1016" layer="21"/>
<wire x1="4.1" y1="-1" x2="4.1" y2="-1.8" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="-1" width="0.1016" layer="21"/>
<circle x="0" y="0" radius="4" width="0.001" layer="51"/>
<smd name="-" x="-3.55" y="0" dx="4" dy="1.6" layer="1"/>
<smd name="+" x="3.55" y="0" dx="4" dy="1.6" layer="1"/>
<text x="-1.75" y="1.3" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.75" y="-2.375" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-4.85" y1="-0.45" x2="-3.9" y2="0.45" layer="51"/>
<rectangle x1="3.9" y1="-0.45" x2="4.85" y2="0.45" layer="51"/>
</polygon>
</package>
<package name="PANASONIC_G">
<description>&lt;b&gt;Panasonic Aluminium Electrolytic Capacitor VS-Serie Package G&lt;/b&gt;</description>
<wire x1="-5.1" y1="5.1" x2="2.8" y2="5.1" width="0.1016" layer="51"/>
<wire x1="2.8" y1="5.1" x2="5.1" y2="2.8" width="0.1016" layer="51"/>
<wire x1="5.1" y1="2.8" x2="5.1" y2="-2.8" width="0.1016" layer="51"/>
<wire x1="5.1" y1="-2.8" x2="2.8" y2="-5.1" width="0.1016" layer="51"/>
<wire x1="2.8" y1="-5.1" x2="-5.1" y2="-5.1" width="0.1016" layer="51"/>
<wire x1="-5.1" y1="-5.1" x2="-5.1" y2="5.1" width="0.1016" layer="51"/>
<wire x1="-5.1" y1="1" x2="-5.1" y2="5.1" width="0.1016" layer="21"/>
<wire x1="-5.1" y1="5.1" x2="2.8" y2="5.1" width="0.1016" layer="21"/>
<wire x1="2.8" y1="5.1" x2="5.1" y2="2.8" width="0.1016" layer="21"/>
<wire x1="5.1" y1="2.8" x2="5.1" y2="1" width="0.1016" layer="21"/>
<wire x1="5.1" y1="-1" x2="5.1" y2="-2.8" width="0.1016" layer="21"/>
<wire x1="5.1" y1="-2.8" x2="2.8" y2="-5.1" width="0.1016" layer="21"/>
<wire x1="2.8" y1="-5.1" x2="-5.1" y2="-5.1" width="0.1016" layer="21"/>
<wire x1="-5.1" y1="-5.1" x2="-5.1" y2="-1" width="0.1016" layer="21"/>
<wire x1="-4.85" y1="-1" x2="4.85" y2="-1" width="0.1016" layer="21" curve="156.699401"/>
<wire x1="-4.85" y1="1" x2="4.85" y2="1" width="0.1016" layer="21" curve="-156.699401"/>
<wire x1="-3.25" y1="3.7" x2="-3.25" y2="-3.65" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="4.95" width="0.1016" layer="51"/>
<smd name="-" x="-4.25" y="0" dx="3.9" dy="1.6" layer="1"/>
<smd name="+" x="4.25" y="0" dx="3.9" dy="1.6" layer="1"/>
<text x="-2.55" y="1.75" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.55" y="-2.675" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-5.85" y1="-0.45" x2="-4.9" y2="0.45" layer="51"/>
<rectangle x1="4.9" y1="-0.45" x2="5.85" y2="0.45" layer="51"/>
<vertex x="-3.3" y="3.6"/>
<vertex x="-4.05" y="2.75"/>
<vertex x="-4.65" y="1.55"/>
<vertex x="-4.85" y="0.45"/>
<vertex x="-4.85" y="-0.45"/>
<vertex x="-4.65" y="-1.55"/>
<vertex x="-4.05" y="-2.75"/>
<vertex x="-3.3" y="-3.6"/>
<vertex x="-3.3" y="3.55"/>
</polygon>
</package>
<package name="TT2D5L">
diameter 5 mm, grid 2.54 mm</description>
<wire x1="-2.54" y1="8.89" x2="2.54" y2="8.89" width="0.1524" layer="21" curve="-180"/>
<wire x1="2.54" y1="8.89" x2="2.54" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="8.89" x2="-2.54" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.016" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.651" x2="-1.905" y2="1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="1.905" y1="1.016" x2="2.54" y2="1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-1.27" y1="2.54" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="-0.635" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.651" x2="-0.3048" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="1.651" x2="-0.3048" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="3.429" x2="-0.635" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="3.429" x2="-0.635" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.381" y1="2.54" x2="0.889" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="3.429" x2="-1.143" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="3.81" x2="-1.524" y2="3.048" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<text x="-2.921" y="1.397" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="1.778" y="4.318" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="2.286" y="1.651" size="0.9906" layer="21" ratio="12" rot="R90">TT</text>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.016" layer="51"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.016" layer="51"/>
<rectangle x1="0.889" y1="-0.127" x2="1.651" y2="0.635" layer="51"/>
<rectangle x1="-1.651" y1="-0.127" x2="-0.889" y2="0.635" layer="51"/>
<rectangle x1="0" y1="1.6002" x2="0.4318" y2="3.4798" layer="21"/>
</package>
<package name="E2,5-6E">
grid 2.54 mm, diameter 6 mm</description>
<wire x1="-2.159" y1="0" x2="-2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-0.254" x2="-2.413" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="2.794" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.5748" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.5748"/>
<text x="2.667" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.667" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="SMC_A">
<description>&lt;b&gt;Chip Capacitor &lt;/b&gt; Polar tantalum capacitors with solid electrolyte&lt;p&gt;
Siemens Matsushita Components B 45 194, B 45 197, B 45 198&lt;br&gt;
Source: www.farnell.com/datasheets/247.pdf</description>
<wire x1="-1.45" y1="0.75" x2="1.45" y2="0.75" width="0.1016" layer="51"/>
<wire x1="1.45" y1="0.75" x2="1.45" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="1.45" y1="-0.75" x2="-1.45" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="-1.45" y1="-0.75" x2="-1.45" y2="0.75" width="0.1016" layer="51"/>
<smd name="+" x="-1.5" y="0" dx="1.6" dy="1.4" layer="1"/>
<smd name="-" x="1.5" y="0" dx="1.6" dy="1.4" layer="1" rot="R180"/>
<text x="-1.6" y="0.975" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-2" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-0.6" x2="-1.4" y2="0.6" layer="51"/>
<rectangle x1="1.4" y1="-0.6" x2="1.6" y2="0.6" layer="51" rot="R180"/>
<rectangle x1="-1.45" y1="-0.75" x2="-0.8" y2="0.75" layer="51"/>
</package>
<package name="SMC_Z">
<description>&lt;b&gt;Chip Capacitor&lt;/b&gt; Polar tantalum capacitors with solid electrolyte&lt;p&gt;
Siemens Matsushita Components B 45 194&lt;br&gt;
<wire x1="-0.9" y1="0.575" x2="0.9" y2="0.575" width="0.1016" layer="51"/>
<wire x1="0.9" y1="-0.575" x2="-0.9" y2="-0.575" width="0.1016" layer="51"/>
<wire x1="-0.9" y1="0.575" x2="-0.9" y2="-0.575" width="0.1016" layer="51"/>
<wire x1="0.9" y1="-0.575" x2="0.9" y2="0.575" width="0.1016" layer="51"/>
<smd name="+" x="-1" y="0" dx="1" dy="1.2" layer="1"/>
<smd name="-" x="1" y="0" dx="1" dy="1.2" layer="1"/>
<text x="-1" y="0.8" size="1.27" layer="25">&gt;NAME</text>
<text x="-1" y="-2.1" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1" y1="-0.45" x2="-0.9" y2="0.45" layer="51"/>
<rectangle x1="0.9" y1="-0.45" x2="1" y2="0.45" layer="51" rot="R180"/>
<rectangle x1="-0.9" y1="-0.6" x2="-0.5" y2="0.6" layer="51"/>
</package>
<package name="SMC_P">
<wire x1="-1.675" y1="0.75" x2="1.65" y2="0.75" width="0.1016" layer="51"/>
<wire x1="1.65" y1="-0.75" x2="-1.675" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="-1.675" y1="0.75" x2="-1.675" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="1.65" y1="-0.75" x2="1.65" y2="0.75" width="0.1016" layer="51"/>
<smd name="+" x="-1.575" y="0" dx="1.6" dy="1.4" layer="1"/>
<smd name="-" x="1.575" y="0" dx="1.6" dy="1.4" layer="1" rot="R180"/>
<text x="-1" y="1" size="1.27" layer="25">&gt;NAME</text>
<text x="-1" y="-2.275" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.8" y1="-0.45" x2="-1.7" y2="0.45" layer="51"/>
<rectangle x1="1.7" y1="-0.45" x2="1.8" y2="0.45" layer="51" rot="R180"/>
<rectangle x1="-1.65" y1="-0.75" x2="-1.075" y2="0.725" layer="51"/>
</package>
<package name="SMC_B">
<wire x1="-1.6" y1="1.35" x2="1.6" y2="1.35" width="0.1016" layer="51"/>
<wire x1="1.6" y1="1.35" x2="1.6" y2="-1.35" width="0.1016" layer="51"/>
<wire x1="1.6" y1="-1.35" x2="-1.6" y2="-1.35" width="0.1016" layer="51"/>
<wire x1="-1.6" y1="-1.35" x2="-1.6" y2="1.35" width="0.1016" layer="51"/>
<smd name="+" x="-1.5" y="0" dx="1.6" dy="2.4" layer="1"/>
<smd name="-" x="1.5" y="0" dx="1.6" dy="2.4" layer="1" rot="R180"/>
<text x="-1.905" y="1.905" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.75" y1="-1.1" x2="-1.55" y2="1.1" layer="51"/>
<rectangle x1="1.55" y1="-1.1" x2="1.75" y2="1.1" layer="51" rot="R180"/>
<rectangle x1="-1.6" y1="-1.35" x2="-0.95" y2="1.35" layer="51"/>
</package>
<package name="SMC_C">
<wire x1="-2.85" y1="1.55" x2="2.85" y2="1.55" width="0.1016" layer="51"/>
<wire x1="2.85" y1="1.55" x2="2.85" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="2.85" y1="-1.55" x2="-2.85" y2="-1.55" width="0.1016" layer="51"/>
<wire x1="-2.85" y1="-1.55" x2="-2.85" y2="1.55" width="0.1016" layer="51"/>
<smd name="+" x="-2.5" y="0" dx="2.4" dy="2.4" layer="1"/>
<smd name="-" x="2.5" y="0" dx="2.4" dy="2.4" layer="1" rot="R180"/>
<rectangle x1="-3" y1="-1.1" x2="-2.8" y2="1.1" layer="51"/>
<rectangle x1="2.8" y1="-1.1" x2="3" y2="1.1" layer="51" rot="R180"/>
<rectangle x1="-2.85" y1="-1.55" x2="-1.9" y2="1.55" layer="51"/>
</package>
<package name="SMC_D">
<wire x1="-3.5" y1="2.1" x2="3.5" y2="2.1" width="0.1016" layer="51"/>
<wire x1="3.5" y1="2.1" x2="3.5" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="3.5" y1="-2.1" x2="-3.5" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="-3.5" y1="-2.1" x2="-3.5" y2="2.1" width="0.1016" layer="51"/>
<smd name="+" x="-3.15" y="0" dx="2.4" dy="2.8" layer="1"/>
<smd name="-" x="3.15" y="0" dx="2.4" dy="2.8" layer="1" rot="R180"/>
<text x="-2.54" y="2.54" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.81" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-3.65" y1="-1.2" x2="-3.45" y2="1.2" layer="51"/>
<rectangle x1="3.45" y1="-1.2" x2="3.65" y2="1.2" layer="51" rot="R180"/>
<rectangle x1="-3.5" y1="-2.1" x2="-2.4" y2="2.1" layer="51"/>
</package>
<package name="SMC_E">
</package>
<package name="SANYO-OSCON_9E">
<description>&lt;b&gt;SANYO OSCON Capacitor&lt;/b&gt;&lt;p&gt;
Source: e_os_all.pdf</description>
<wire x1="-3.55" y1="0" x2="-2.8" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="3.9" width="0.2032" layer="21"/>
<pad name="-" x="-1.75" y="0" drill="0.8" diameter="1.27"/>
<pad name="+" x="1.75" y="0" drill="0.8" diameter="1.27"/>
<text x="-1.905" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="SANYO-OSCON_9F">
<wire x1="-4.55" y1="0" x2="-3.6" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="4.9" width="0.2032" layer="21"/>
<pad name="-" x="-2.5" y="0" drill="0.8" diameter="1.27"/>
<pad name="+" x="2.5" y="0" drill="0.8" diameter="1.27"/>
</package>
<package name="SANYO-OSCON_A">
<wire x1="-1.55" y1="-0.4" x2="-1.55" y2="0.4" width="0.4064" layer="51"/>
<circle x="0" y="0" radius="1.9" width="0.2032" layer="21"/>
<pad name="-" x="-1" y="0" drill="0.7" diameter="1.1"/>
<pad name="+" x="1" y="0" drill="0.7" diameter="1.1"/>
</package>
<package name="SANYO-OSCON_A'">
<pad name="-" x="-0.75" y="0" drill="0.6" diameter="1"/>
<pad name="+" x="0.75" y="0" drill="0.6" diameter="1"/>
</package>
<package name="SANYO-OSCON_B">
<wire x1="-1.9" y1="-0.4" x2="-1.9" y2="0.4" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="2.4" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_B'">
</package>
<package name="SANYO-OSCON_C">
<wire x1="-2.2" y1="0" x2="-2.7" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="3.05" width="0.2032" layer="21"/>
<pad name="-" x="-1.25" y="0" drill="0.8" diameter="1.27"/>
<pad name="+" x="1.25" y="0" drill="0.8" diameter="1.27"/>
</package>
<package name="SANYO-OSCON_C'">
<circle x="0" y="0" radius="3.0504" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_C6">
<pad name="-" x="-1.25" y="0" drill="0.7" diameter="1.27"/>
<pad name="+" x="1.25" y="0" drill="0.7" diameter="1.27"/>
<text x="-1.905" y="3.175" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<polygon width="0.2032" layer="21">
<vertex x="-2.15" y="-2.1" curve="-41.039434"/>
<vertex x="-3" y="0.1" curve="-41.67409"/>
</polygon>
</package>
<package name="SANYO-OSCON_D">
</package>
<package name="SANYO-OSCON_E">
<wire x1="-3.5" y1="0" x2="-2.7" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="3.9003" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_E'">
</package>
<package name="SANYO-OSCON_E1">
<wire x1="-3.55" y1="0" x2="-2.75" y2="0" width="0.4064" layer="21"/>
</package>
<package name="SANYO-OSCON_E12">
<vertex x="-2.65" y="2.7"/>
<vertex x="-2.65" y="-2.75" curve="-41.038922"/>
<vertex x="-3.8" y="0" curve="-41.675057"/>
</polygon>
</package>
<package name="SANYO-OSCON_E13">
</polygon>
</package>
<package name="SANYO-OSCON_E7">
<pad name="-" x="-1.75" y="0" drill="0.7" diameter="1.27"/>
<pad name="+" x="1.75" y="0" drill="0.7" diameter="1.27"/>
<vertex x="-2.65" y="2.8"/>
<vertex x="-2.65" y="-2.8" curve="-41.039891"/>
<vertex x="-3.85" y="0" curve="-41.675747"/>
</polygon>
</package>
<package name="SANYO-OSCON_E9">
</polygon>
</package>
<package name="SANYO-OSCON_F">
<wire x1="-4.5" y1="0" x2="-3.6" y2="0" width="0.4064" layer="21"/>
</package>
<package name="SANYO-OSCON_F'">
<wire x1="-3.55" y1="0" x2="-4.4" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="4.9002" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_F0">
</package>
<package name="SANYO-OSCON_F13">
<text x="-2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-3.4" y="3.45"/>
<vertex x="-3.4" y="-3.4" curve="-41.039359"/>
<vertex x="-4.85" y="0" curve="-41.674636"/>
</polygon>
</package>
<package name="SANYO-OSCON_F8">
<pad name="-" x="-2.5" y="0" drill="0.7" diameter="1.27"/>
<pad name="+" x="2.5" y="0" drill="0.7" diameter="1.27"/>
<vertex x="-3.6" y="3.2"/>
<vertex x="-3.6" y="-3.25" curve="-41.039474"/>
<vertex x="-4.85" y="0" curve="-41.675359"/>
</polygon>
</package>
<package name="SANYO-OSCON_G">
<wire x1="-4.5" y1="0" x2="-5.7" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="6.15" width="0.2032" layer="21"/>
</package>
<package name="SANYO-OSCON_H">
<wire x1="-7" y1="0" x2="-5.7" y2="0" width="0.4064" layer="21"/>
<circle x="0" y="0" radius="7.9001" width="0.2032" layer="21"/>
<pad name="-" x="-3.75" y="0" drill="0.8" diameter="1.27"/>
<pad name="+" x="3.75" y="0" drill="0.8" diameter="1.27"/>
</package>
<package name="SANYO-OSCON_SMD_A5">
<description>&lt;b&gt;SANYO OSCON Capacitor&lt;/b&gt; SMD type with conductive polymer electrolyte&lt;p&gt;
<wire x1="-2.05" y1="2.05" x2="1.25" y2="2.05" width="0.2032" layer="21"/>
<wire x1="1.25" y1="2.05" x2="2.05" y2="1.25" width="0.2032" layer="21"/>
<wire x1="2.05" y1="1.25" x2="2.05" y2="-1.25" width="0.2032" layer="51"/>
<wire x1="2.05" y1="-1.25" x2="1.25" y2="-2.05" width="0.2032" layer="21"/>
<wire x1="1.25" y1="-2.05" x2="-2.05" y2="-2.05" width="0.2032" layer="21"/>
<wire x1="-2.05" y1="-2.05" x2="-2.05" y2="2.05" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="1.85" width="0.2032" layer="51"/>
<text x="-1.905" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<polygon width="0.2032" layer="51">
<vertex x="-1.2" y="-1.35"/>
<vertex x="-1.2" y="1.35" curve="44.759919"/>
<vertex x="-1.8" y="0" curve="39.027281"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_B6">
<wire x1="-2.55" y1="2.55" x2="1.75" y2="2.55" width="0.2032" layer="21"/>
<wire x1="1.75" y1="2.55" x2="2.55" y2="1.75" width="0.2032" layer="21"/>
<wire x1="2.55" y1="1.75" x2="2.55" y2="-1.75" width="0.2032" layer="51"/>
<wire x1="2.55" y1="-1.75" x2="1.75" y2="-2.55" width="0.2032" layer="21"/>
<wire x1="1.75" y1="-2.55" x2="-2.55" y2="-2.55" width="0.2032" layer="21"/>
<wire x1="-2.55" y1="-2.55" x2="-2.55" y2="2.55" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="2.35" width="0.2032" layer="51"/>
<text x="-2.54" y="3.175" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-4.445" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-1.6" y="-1.65"/>
<vertex x="-1.6" y="1.65" curve="35.983944"/>
<vertex x="-2.3" y="0" curve="42.321615"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_C6">
<wire x1="-3.2" y1="3.2" x2="2.4" y2="3.2" width="0.2032" layer="21"/>
<wire x1="2.4" y1="3.2" x2="3.2" y2="2.4" width="0.2032" layer="21"/>
<wire x1="3.2" y1="2.4" x2="3.2" y2="-2.4" width="0.2032" layer="51"/>
<wire x1="3.2" y1="-2.4" x2="2.4" y2="-3.2" width="0.2032" layer="21"/>
<wire x1="2.4" y1="-3.2" x2="-3.2" y2="-3.2" width="0.2032" layer="21"/>
<wire x1="-3.2" y1="-3.2" x2="-3.2" y2="3.2" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="2.95" width="0.2032" layer="51"/>
<smd name="-" x="-2.8" y="0" dx="3.5" dy="1.6" layer="1"/>
<smd name="+" x="2.8" y="0" dx="3.5" dy="1.6" layer="1"/>
<text x="-3.175" y="3.81" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.175" y="-5.08" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-2.2" y="1.9"/>
<vertex x="-2.2" y="-1.9" curve="-39.18521"/>
<vertex x="-2.85" y="0" curve="-36.094684"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_E12">
<wire x1="-4.05" y1="4.05" x2="2.95" y2="4.05" width="0.2032" layer="21"/>
<wire x1="2.95" y1="4.05" x2="4.05" y2="2.95" width="0.2032" layer="21"/>
<wire x1="4.05" y1="2.95" x2="4.05" y2="-2.95" width="0.2032" layer="51"/>
<wire x1="2.95" y1="-4.05" x2="-4.05" y2="-4.05" width="0.2032" layer="21"/>
<wire x1="-4.05" y1="-4.05" x2="-4.05" y2="4.05" width="0.2032" layer="51"/>
<wire x1="4.05" y1="-2.95" x2="2.95" y2="-4.05" width="0.2032" layer="21"/>
<circle x="0" y="0" radius="3.85" width="0.2032" layer="51"/>
<smd name="-" x="-3.5" y="0" dx="4.15" dy="1.9" layer="1"/>
<smd name="+" x="3.5" y="0" dx="4.15" dy="1.9" layer="1"/>
<text x="-3.81" y="4.445" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.81" y="-5.715" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-2.6" y="-2.75"/>
<vertex x="-2.6" y="2.75" curve="44.955417"/>
<vertex x="-3.85" y="0" curve="45.23973"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_E7">
<vertex x="-2.7" y="2.65"/>
<vertex x="-2.7" y="-2.65" curve="-47.290335"/>
<vertex x="-3.8" y="0" curve="-44.001093"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_F12">
<wire x1="-5.05" y1="5.05" x2="3.95" y2="5.05" width="0.2032" layer="21"/>
<wire x1="3.95" y1="5.05" x2="5.05" y2="3.95" width="0.2032" layer="21"/>
<wire x1="5.05" y1="3.95" x2="5.05" y2="-3.95" width="0.2032" layer="51"/>
<wire x1="3.95" y1="-5.05" x2="-5.05" y2="-5.05" width="0.2032" layer="21"/>
<wire x1="-5.05" y1="-5.05" x2="-5.05" y2="5.05" width="0.2032" layer="51"/>
<wire x1="5.05" y1="-3.95" x2="3.95" y2="-5.05" width="0.2032" layer="21"/>
<circle x="0" y="0" radius="4.8" width="0.2032" layer="51"/>
<smd name="-" x="-4.5" y="0" dx="4.7" dy="1.9" layer="1"/>
<smd name="+" x="4.5" y="0" dx="4.7" dy="1.9" layer="1"/>
<text x="-5.08" y="5.715" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.08" y="-6.985" size="1.27" layer="27">&gt;VALUE</text>
<vertex x="-3.05" y="-3.65"/>
<vertex x="-3.05" y="3.65" curve="48.708973"/>
<vertex x="-4.75" y="0" curve="43.982679"/>
</polygon>
</package>
<package name="SANYO-OSCON_SMD_F8">
<vertex x="-3.05" y="3.65" curve="41.376652"/>
<vertex x="-4.75" y="0" curve="43.010397"/>
</polygon>
</package>
<package name="UD-10X10_NICHICON">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 10 x 10 mm&lt;p&gt;
Source: http://products.nichicon.co.jp/en/pdf/XJA043/e-ud.pdf</description>
<wire x1="-5.1" y1="5.1" x2="4.3" y2="5.1" width="0.1016" layer="51"/>
<wire x1="4.3" y1="5.1" x2="5.1" y2="4.3" width="0.1016" layer="51"/>
<wire x1="5.1" y1="4.3" x2="5.1" y2="-4.3" width="0.1016" layer="51"/>
<wire x1="5.1" y1="-4.3" x2="4.3" y2="-5.1" width="0.1016" layer="51"/>
<wire x1="4.3" y1="-5.1" x2="-5.1" y2="-5.1" width="0.1016" layer="51"/>
<wire x1="-4.875" y1="0.85" x2="4.875" y2="0.85" width="0.1016" layer="21" curve="-160.259855"/>
<wire x1="-5.1" y1="0.875" x2="-5.1" y2="5.1" width="0.1016" layer="21"/>
<wire x1="-5.1" y1="5.1" x2="4.3" y2="5.1" width="0.1016" layer="21"/>
<wire x1="4.3" y1="5.1" x2="5.1" y2="4.3" width="0.1016" layer="21"/>
<wire x1="5.1" y1="-4.3" x2="4.3" y2="-5.1" width="0.1016" layer="21"/>
<wire x1="4.3" y1="-5.1" x2="-5.1" y2="-5.1" width="0.1016" layer="21"/>
<wire x1="-5.1" y1="-5.1" x2="-5.1" y2="-0.85" width="0.1016" layer="21"/>
<wire x1="4.875" y1="-0.85" x2="-4.875" y2="-0.85" width="0.1016" layer="21" curve="-160.259855"/>
<smd name="-" x="-3.95" y="0" dx="3.6" dy="1.3" layer="1"/>
<smd name="+" x="3.925" y="0" dx="3.6" dy="1.3" layer="1"/>
<text x="-5.08" y="5.715" size="1.016" layer="25">&gt;NAME</text>
<text x="-5.08" y="-6.35" size="1.016" layer="27">&gt;VALUE</text>
<vertex x="-4.05" y="2.8" curve="69.465624"/>
<vertex x="-4.05" y="-2.825"/>
</polygon>
</package>
<package name="UD-4X5,8_NICHICON">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 4 x 5.8 mm&lt;p&gt;
<wire x1="-2.1" y1="2.1" x2="1.3" y2="2.1" width="0.1016" layer="51"/>
<wire x1="1.3" y1="2.1" x2="2.1" y2="1.3" width="0.1016" layer="51"/>
<wire x1="2.1" y1="1.3" x2="2.1" y2="-1.3" width="0.1016" layer="51"/>
<wire x1="2.1" y1="-1.3" x2="1.3" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="1.3" y1="-2.1" x2="-2.1" y2="-2.1" width="0.1016" layer="51"/>
<wire x1="-1.75" y1="0.875" x2="1.75" y2="0.875" width="0.1016" layer="21" curve="-126.263848"/>
<wire x1="-2.1" y1="0.9" x2="-2.1" y2="2.1" width="0.1016" layer="21"/>
<wire x1="-2.1" y1="2.1" x2="1.3" y2="2.1" width="0.1016" layer="21"/>
<wire x1="1.3" y1="2.1" x2="2.1" y2="1.3" width="0.1016" layer="21"/>
<wire x1="2.1" y1="-1.3" x2="1.3" y2="-2.1" width="0.1016" layer="21"/>
<wire x1="1.3" y1="-2.1" x2="-2.1" y2="-2.1" width="0.1016" layer="21"/>
<wire x1="-2.1" y1="-2.1" x2="-2.1" y2="-0.9" width="0.1016" layer="21"/>
<wire x1="1.75" y1="-0.875" x2="-1.75" y2="-0.875" width="0.1016" layer="21" curve="-126.263848"/>
<circle x="0" y="0" radius="1.9527" width="0.1016" layer="51"/>
<smd name="-" x="-1.425" y="0" dx="2" dy="1" layer="1"/>
<smd name="+" x="1.425" y="0" dx="2" dy="1" layer="1"/>
<text x="-1.905" y="2.54" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.016" layer="27">&gt;VALUE</text>
<vertex x="-1.55" y="1.175" curve="72.275472"/>
<vertex x="-1.55" y="-1.175"/>
</polygon>
</package>
<package name="UD-5X5,8_NICHICON">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 5 x 5.8 mm&lt;p&gt;
<wire x1="-2.6" y1="2.6" x2="1.8" y2="2.6" width="0.1016" layer="51"/>
<wire x1="1.8" y1="2.6" x2="2.6" y2="1.8" width="0.1016" layer="51"/>
<wire x1="2.6" y1="1.8" x2="2.6" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="2.6" y1="-1.8" x2="1.8" y2="-2.6" width="0.1016" layer="51"/>
<wire x1="1.8" y1="-2.6" x2="-2.6" y2="-2.6" width="0.1016" layer="51"/>
<wire x1="-2.3" y1="0.85" x2="2.275" y2="0.9" width="0.1016" layer="21" curve="-137.986421"/>
<wire x1="-2.6" y1="0.7" x2="-2.6" y2="2.6" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="2.6" x2="1.8" y2="2.6" width="0.1016" layer="21"/>
<wire x1="1.8" y1="2.6" x2="2.6" y2="1.8" width="0.1016" layer="21"/>
<wire x1="2.6" y1="-1.8" x2="1.8" y2="-2.6" width="0.1016" layer="21"/>
<wire x1="1.8" y1="-2.6" x2="-2.6" y2="-2.6" width="0.1016" layer="21"/>
<wire x1="-2.6" y1="-2.6" x2="-2.6" y2="-0.7" width="0.1016" layer="21"/>
<wire x1="2.3" y1="-0.85" x2="-2.275" y2="-0.9" width="0.1016" layer="21" curve="-137.986421"/>
<circle x="0" y="0" radius="2.4501" width="0.1016" layer="51"/>
<smd name="-" x="-1.7" y="0" dx="2.3" dy="1" layer="1"/>
<smd name="+" x="1.725" y="0" dx="2.3" dy="1" layer="1"/>
<text x="-2.54" y="3.175" size="1.016" layer="25">&gt;NAME</text>
<vertex x="-1.55" y="1.875" curve="100.118878"/>
<vertex x="-1.55" y="-1.875"/>
</polygon>
</package>
<package name="UD-6,3X5,8_NICHICON">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 6.3 x 5.8 mm&lt;p&gt;
<wire x1="-3.25" y1="3.25" x2="2.45" y2="3.25" width="0.1016" layer="51"/>
<wire x1="2.45" y1="3.25" x2="3.25" y2="2.45" width="0.1016" layer="51"/>
<wire x1="3.25" y1="2.45" x2="3.25" y2="-2.45" width="0.1016" layer="51"/>
<wire x1="3.25" y1="-2.45" x2="2.45" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="2.45" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="51"/>
<wire x1="-3" y1="0.775" x2="2.975" y2="0.85" width="0.1016" layer="21" curve="-149.753145"/>
<wire x1="-3.25" y1="0.8" x2="-3.25" y2="3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="3.25" x2="2.45" y2="3.25" width="0.1016" layer="21"/>
<wire x1="2.45" y1="3.25" x2="3.25" y2="2.45" width="0.1016" layer="21"/>
<wire x1="3.25" y1="-2.45" x2="2.45" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="2.45" y1="-3.25" x2="-3.25" y2="-3.25" width="0.1016" layer="21"/>
<wire x1="-3.25" y1="-3.25" x2="-3.25" y2="-0.7" width="0.1016" layer="21"/>
<wire x1="3" y1="-0.775" x2="-2.975" y2="-0.85" width="0.1016" layer="21" curve="-149.753145"/>
<circle x="0" y="0" radius="3.1001" width="0.1016" layer="51"/>
<smd name="-" x="-2.35" y="0" dx="2.8" dy="1" layer="1"/>
<smd name="+" x="2.35" y="0" dx="2.8" dy="1" layer="1"/>
<text x="-3.175" y="3.81" size="1.016" layer="25">&gt;NAME</text>
<text x="-3.175" y="-4.445" size="1.016" layer="27">&gt;VALUE</text>
<vertex x="-2.2" y="2.15" curve="88.581463"/>
<vertex x="-2.2" y="-2.15"/>
</polygon>
</package>
<package name="UD-6,3X7,7_NICHICON">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 6.3 x 7.7 mm&lt;p&gt;
</polygon>
</package>
<package name="UD-8X10_NICHICON">
<description>&lt;b&gt;ALUMINUM ELECTROLYTIC CAPACITORS&lt;/b&gt; UD Series 8 x 10 mm&lt;p&gt;
<wire x1="-4.1" y1="4.1" x2="3.3" y2="4.1" width="0.1016" layer="51"/>
<wire x1="3.3" y1="4.1" x2="4.1" y2="3.3" width="0.1016" layer="51"/>
<wire x1="4.1" y1="3.3" x2="4.1" y2="-3.3" width="0.1016" layer="51"/>
<wire x1="4.1" y1="-3.3" x2="3.3" y2="-4.1" width="0.1016" layer="51"/>
<wire x1="3.3" y1="-4.1" x2="-4.1" y2="-4.1" width="0.1016" layer="51"/>
<wire x1="-3.85" y1="0.875" x2="3.85" y2="0.875" width="0.1016" layer="21" curve="-154.459402"/>
<wire x1="-4.1" y1="0.825" x2="-4.1" y2="4.1" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="4.1" x2="3.3" y2="4.1" width="0.1016" layer="21"/>
<wire x1="3.3" y1="4.1" x2="4.1" y2="3.3" width="0.1016" layer="21"/>
<wire x1="4.1" y1="-3.3" x2="3.3" y2="-4.1" width="0.1016" layer="21"/>
<wire x1="3.3" y1="-4.1" x2="-4.1" y2="-4.1" width="0.1016" layer="21"/>
<wire x1="-4.1" y1="-4.1" x2="-4.1" y2="-0.85" width="0.1016" layer="21"/>
<wire x1="3.85" y1="-0.875" x2="-3.85" y2="-0.875" width="0.1016" layer="21" curve="-154.459402"/>
<smd name="-" x="-3.125" y="0" dx="3.3" dy="1.3" layer="1"/>
<smd name="+" x="3.125" y="0" dx="3.3" dy="1.3" layer="1"/>
<text x="-3.81" y="4.445" size="1.016" layer="25">&gt;NAME</text>
<text x="-3.81" y="-5.715" size="1.016" layer="27">&gt;VALUE</text>
<vertex x="-3.05" y="2.475" curve="77.887741"/>
<vertex x="-3.05" y="-2.475"/>
</polygon>
</package>
<package name="C0402">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;</description>
<wire x1="-0.245" y1="0.224" x2="0.245" y2="0.224" width="0.1524" layer="51"/>
<wire x1="0.245" y1="-0.224" x2="-0.245" y2="-0.224" width="0.1524" layer="51"/>
<wire x1="-1.473" y1="0.483" x2="1.473" y2="0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.483" x2="1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.483" x2="-1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.483" x2="-1.473" y2="0.483" width="0.0508" layer="39"/>
<smd name="1" x="-0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<smd name="2" x="0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<text x="-0.635" y="0.635" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-1.905" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.554" y1="-0.3048" x2="-0.254" y2="0.2951" layer="51"/>
<rectangle x1="0.2588" y1="-0.3048" x2="0.5588" y2="0.2951" layer="51"/>
<rectangle x1="-0.1999" y1="-0.3" x2="0.1999" y2="0.3" layer="35"/>
</package>
<package name="C0504">
<wire x1="-1.473" y1="0.983" x2="1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.983" x2="1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.983" x2="-1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.983" x2="-1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-0.294" y1="0.559" x2="0.294" y2="0.559" width="0.1016" layer="51"/>
<wire x1="-0.294" y1="-0.559" x2="0.294" y2="-0.559" width="0.1016" layer="51"/>
<smd name="1" x="-0.7" y="0" dx="1" dy="1.3" layer="1"/>
<smd name="2" x="0.7" y="0" dx="1" dy="1.3" layer="1"/>
<text x="-0.635" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.6604" y1="-0.6223" x2="-0.2804" y2="0.6276" layer="51"/>
<rectangle x1="0.2794" y1="-0.6223" x2="0.6594" y2="0.6276" layer="51"/>
<rectangle x1="-0.1001" y1="-0.4001" x2="0.1001" y2="0.4001" layer="35"/>
</package>
<package name="C0603">
<wire x1="-0.356" y1="0.432" x2="0.356" y2="0.432" width="0.1016" layer="51"/>
<wire x1="-0.356" y1="-0.419" x2="0.356" y2="-0.419" width="0.1016" layer="51"/>
<smd name="1" x="-0.85" y="0" dx="1.1" dy="1" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.1" dy="1" layer="1"/>
<rectangle x1="-0.8382" y1="-0.4699" x2="-0.3381" y2="0.4801" layer="51"/>
<rectangle x1="0.3302" y1="-0.4699" x2="0.8303" y2="0.4801" layer="51"/>
</package>
<package name="C0805">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-0.381" y1="0.66" x2="0.381" y2="0.66" width="0.1016" layer="51"/>
<wire x1="-0.356" y1="-0.66" x2="0.381" y2="-0.66" width="0.1016" layer="51"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.0922" y1="-0.7239" x2="-0.3421" y2="0.7262" layer="51"/>
<rectangle x1="0.3556" y1="-0.7239" x2="1.1057" y2="0.7262" layer="51"/>
</package>
<package name="C1005">
</package>
<package name="C1206">
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-0.965" y1="0.787" x2="0.965" y2="0.787" width="0.1016" layer="51"/>
<wire x1="-0.965" y1="-0.787" x2="0.965" y2="-0.787" width="0.1016" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<rectangle x1="-1.7018" y1="-0.8509" x2="-0.9517" y2="0.8491" layer="51"/>
<rectangle x1="0.9517" y1="-0.8491" x2="1.7018" y2="0.8509" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="C1210">
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="-0.9652" y1="1.2446" x2="0.9652" y2="1.2446" width="0.1016" layer="51"/>
<wire x1="-0.9652" y1="-1.2446" x2="0.9652" y2="-1.2446" width="0.1016" layer="51"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-1.2954" x2="-0.9517" y2="1.3045" layer="51"/>
<rectangle x1="0.9517" y1="-1.3045" x2="1.7018" y2="1.2954" layer="51"/>
</package>
<package name="C1310">
<rectangle x1="-0.1001" y1="-0.3" x2="0.1001" y2="0.3" layer="35"/>
</package>
<package name="C1608">
</package>
<package name="C1812">
<wire x1="-2.973" y1="1.983" x2="2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-1.983" x2="-2.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-1.983" x2="-2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="-1.4732" y1="1.6002" x2="1.4732" y2="1.6002" width="0.1016" layer="51"/>
<wire x1="-1.4478" y1="-1.6002" x2="1.4732" y2="-1.6002" width="0.1016" layer="51"/>
<wire x1="2.973" y1="1.983" x2="2.973" y2="-1.983" width="0.0508" layer="39"/>
<smd name="1" x="-1.95" y="0" dx="1.9" dy="3.4" layer="1"/>
<smd name="2" x="1.95" y="0" dx="1.9" dy="3.4" layer="1"/>
<rectangle x1="-2.3876" y1="-1.651" x2="-1.4376" y2="1.649" layer="51"/>
<rectangle x1="1.4478" y1="-1.651" x2="2.3978" y2="1.649" layer="51"/>
<rectangle x1="-0.3" y1="-0.4001" x2="0.3" y2="0.4001" layer="35"/>
</package>
<package name="C1825">
<wire x1="-2.973" y1="3.483" x2="2.973" y2="3.483" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-3.483" x2="-2.973" y2="-3.483" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-3.483" x2="-2.973" y2="3.483" width="0.0508" layer="39"/>
<wire x1="-1.4986" y1="3.2766" x2="1.4732" y2="3.2766" width="0.1016" layer="51"/>
<wire x1="-1.4732" y1="-3.2766" x2="1.4986" y2="-3.2766" width="0.1016" layer="51"/>
<wire x1="2.973" y1="3.483" x2="2.973" y2="-3.483" width="0.0508" layer="39"/>
<smd name="1" x="-1.95" y="0" dx="1.9" dy="6.8" layer="1"/>
<smd name="2" x="1.95" y="0" dx="1.9" dy="6.8" layer="1"/>
<text x="-1.905" y="3.81" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-5.08" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.413" y1="-3.3528" x2="-1.463" y2="3.3472" layer="51"/>
<rectangle x1="1.4478" y1="-3.3528" x2="2.3978" y2="3.3472" layer="51"/>
<rectangle x1="-0.7" y1="-0.7" x2="0.7" y2="0.7" layer="35"/>
</package>
<package name="C2012">
<smd name="1" x="-0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
</package>
<package name="C3216">
<rectangle x1="-0.3" y1="-0.5001" x2="0.3" y2="0.5001" layer="35"/>
</package>
<package name="C3225">
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
<package name="C4532">
<rectangle x1="-0.4001" y1="-0.7" x2="0.4001" y2="0.7" layer="35"/>
</package>
<package name="C4564">
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="C025-024X044">
grid 2.5 mm, outline 2.4 x 4.4 mm</description>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-1.651" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.159" y1="-0.635" x2="-1.651" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="1.651" y1="1.143" x2="-1.651" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-1.143" x2="-1.651" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="1.651" y1="1.143" x2="2.159" y2="0.635" width="0.1524" layer="21" curve="-90"/>
<wire x1="1.651" y1="-1.143" x2="2.159" y2="-0.635" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.3048" y1="0.762" x2="-0.3048" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0.762" x2="0.3302" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="1.27" y1="0" x2="0.3302" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0" x2="-0.3048" y2="0" width="0.1524" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-1.778" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.778" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-025X050">
grid 2.5 mm, outline 2.5 x 5 mm</description>
<wire x1="-2.159" y1="1.27" x2="2.159" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.27" x2="-2.159" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.27" x2="2.413" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.016" x2="-2.159" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.27" x2="2.413" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.016" x2="-2.159" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="0" x2="0.381" y2="0" width="0.1524" layer="51"/>
<wire x1="0.381" y1="0" x2="0.254" y2="0" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="0.762" width="0.254" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="-0.254" y2="0" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<text x="-2.286" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-030X050">
grid 2.5 mm, outline 3 x 5 mm</description>
<wire x1="-2.159" y1="1.524" x2="2.159" y2="1.524" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.524" x2="-2.159" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.27" x2="2.413" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.27" x2="-2.413" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.524" x2="2.413" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.27" x2="-2.159" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.524" x2="2.413" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.27" x2="-2.159" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-040X050">
grid 2.5 mm, outline 4 x 5 mm</description>
<wire x1="-2.159" y1="1.905" x2="2.159" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.905" x2="-2.159" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.651" x2="2.413" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.651" x2="-2.413" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.905" x2="2.413" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.651" x2="-2.159" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.905" x2="2.413" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.651" x2="-2.159" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-050X050">
grid 2.5 mm, outline 5 x 5 mm</description>
<wire x1="-2.159" y1="2.286" x2="2.159" y2="2.286" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-2.286" x2="-2.159" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.032" x2="2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="2.032" x2="-2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.286" x2="2.413" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="2.032" x2="-2.159" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-2.286" x2="2.413" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-2.032" x2="-2.159" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-060X050">
grid 2.5 mm, outline 6 x 5 mm</description>
<wire x1="-2.159" y1="2.794" x2="2.159" y2="2.794" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-2.794" x2="-2.159" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.54" x2="2.413" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="2.54" x2="-2.413" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.794" x2="2.413" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="2.54" x2="-2.159" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-2.794" x2="2.413" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-2.54" x2="-2.159" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025_050-024X070">
grid 2.5 mm + 5 mm, outline 2.4 x 7 mm</description>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="0.635" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="-1.143" x2="-3.9624" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="1.143" x2="-3.9624" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-0.635" x2="-4.191" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.699" y1="0.635" x2="-4.191" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.699" y1="-0.635" x2="-4.699" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.143" x2="-2.5654" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.143" x2="-2.5654" y2="-1.143" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="3" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.81" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025_050-025X075">
grid 2.5 + 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="4.953" y1="1.016" x2="4.953" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="4.699" y1="1.27" x2="4.953" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-1.27" x2="4.953" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="1.27" x2="4.699" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.27" x2="2.794" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.413" y2="0.762" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-0.762" x2="2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.254" x2="2.413" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0" x2="2.286" y2="0" width="0.1524" layer="51"/>
<wire x1="2.286" y1="0" x2="2.794" y2="0" width="0.1524" layer="21"/>
<wire x1="2.794" y1="0" x2="3.302" y2="0" width="0.1524" layer="51"/>
<pad name="3" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.159" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025_050-035X075">
grid 2.5 + 5 mm, outline 3.5 x 7.5 mm</description>
<wire x1="-2.159" y1="1.778" x2="2.159" y2="1.778" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.778" x2="-2.159" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.524" x2="-2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.778" x2="2.413" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.524" x2="-2.159" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.778" x2="2.413" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.524" x2="-2.159" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="4.953" y1="1.524" x2="4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.699" y1="1.778" x2="4.953" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-1.778" x2="4.953" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="1.778" x2="4.699" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.778" x2="2.794" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.524" x2="2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.508" x2="2.413" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.381" y1="0" x2="0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="2.286" y1="0" x2="1.778" y2="0" width="0.1524" layer="51"/>
<text x="-2.286" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025_050-045X075">
grid 2.5 + 5 mm, outline 4.5 x 7.5 mm</description>
<wire x1="4.953" y1="2.032" x2="4.953" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.286" x2="4.953" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-2.286" x2="4.953" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="2.286" x2="4.699" y2="2.286" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.286" x2="2.794" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.032" x2="2.413" y2="1.397" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.397" x2="2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.762" x2="2.413" y2="-0.762" width="0.1524" layer="21"/>
<text x="-2.286" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C025_050-055X075">
grid 2.5 + 5 mm, outline 5.5 x 7.5 mm</description>
<wire x1="4.953" y1="2.54" x2="4.953" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.794" x2="4.953" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-2.794" x2="4.953" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="2.794" x2="4.699" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.794" x2="2.794" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.54" x2="2.413" y2="2.032" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-2.032" x2="2.413" y2="-2.54" width="0.1524" layer="21"/>
<text x="-2.286" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-024X044">
grid 5 mm, outline 2.4 x 4.4 mm</description>
<wire x1="-0.3048" y1="0.762" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0.762" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="1.27" y1="0" x2="0.3302" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0" x2="-0.3048" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.159" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.159" y1="-0.381" x2="2.54" y2="0.381" layer="51"/>
<rectangle x1="-2.54" y1="-0.381" x2="-2.159" y2="0.381" layer="51"/>
</package>
<package name="C050-025X075">
grid 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.016" x2="-3.683" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.27" x2="3.429" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.016" x2="3.683" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="-3.429" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="3.683" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.27" x2="3.683" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.016" x2="-3.429" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.016" x2="-3.429" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-045X075">
grid 5 mm, outline 4.5 x 7.5 mm</description>
<wire x1="-3.683" y1="2.032" x2="-3.683" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.286" x2="3.429" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.032" x2="3.683" y2="2.032" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.286" x2="-3.429" y2="2.286" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.286" x2="3.683" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.286" x2="3.683" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.032" x2="-3.429" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.032" x2="-3.429" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<text x="-3.556" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-030X075">
grid 5 mm, outline 3 x 7.5 mm</description>
<wire x1="-3.683" y1="1.27" x2="-3.683" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.524" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.27" x2="3.683" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="3.683" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.524" x2="3.683" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.27" x2="-3.429" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.27" x2="-3.429" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<text x="-3.556" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-050X075">
grid 5 mm, outline 5 x 7.5 mm</description>
<wire x1="-3.683" y1="2.286" x2="-3.683" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.54" x2="3.429" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.286" x2="3.683" y2="2.286" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.54" x2="-3.429" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.54" x2="3.683" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.54" x2="3.683" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.286" x2="-3.429" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.286" x2="-3.429" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-055X075">
grid 5 mm, outline 5.5 x 7.5 mm</description>
<wire x1="-3.683" y1="2.54" x2="-3.683" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.794" x2="3.429" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.54" x2="3.683" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.794" x2="-3.429" y2="2.794" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.794" x2="3.683" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.794" x2="3.683" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.54" x2="-3.429" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.54" x2="-3.429" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-075X075">
grid 5 mm, outline 7.5 x 7.5 mm</description>
<wire x1="-1.524" y1="0" x2="-0.4572" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.4572" y1="0" x2="-0.4572" y2="0.762" width="0.4064" layer="21"/>
<wire x1="-0.4572" y1="0" x2="-0.4572" y2="-0.762" width="0.4064" layer="21"/>
<wire x1="0.4318" y1="0.762" x2="0.4318" y2="0" width="0.4064" layer="21"/>
<wire x1="0.4318" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.4318" y1="0" x2="0.4318" y2="-0.762" width="0.4064" layer="21"/>
<wire x1="-3.683" y1="3.429" x2="-3.683" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-3.683" x2="3.429" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-3.429" x2="3.683" y2="3.429" width="0.1524" layer="21"/>
<wire x1="3.429" y1="3.683" x2="-3.429" y2="3.683" width="0.1524" layer="21"/>
<wire x1="3.429" y1="3.683" x2="3.683" y2="3.429" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-3.683" x2="3.683" y2="-3.429" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-3.429" x2="-3.429" y2="-3.683" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="3.429" x2="-3.429" y2="3.683" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050H075X075">
Horizontal, grid 5 mm, outline 7.5 x 7.5 mm</description>
<wire x1="-3.683" y1="7.112" x2="-3.683" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0.508" x2="-3.302" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.508" x2="-1.778" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-1.778" y1="0.508" x2="1.778" y2="0.508" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.508" x2="3.302" y2="0.508" width="0.1524" layer="51"/>
<wire x1="3.302" y1="0.508" x2="3.683" y2="0.508" width="0.1524" layer="21"/>
<wire x1="3.683" y1="0.508" x2="3.683" y2="7.112" width="0.1524" layer="21"/>
<wire x1="3.175" y1="7.62" x2="-3.175" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="2.413" x2="-0.3048" y2="1.778" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="1.778" x2="-0.3048" y2="1.143" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="1.778" x2="-1.651" y2="1.778" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="2.413" x2="0.3302" y2="1.778" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="1.778" x2="0.3302" y2="1.143" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="1.778" x2="1.651" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="7.112" x2="-3.175" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.175" y1="7.62" x2="3.683" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="0" x2="-2.54" y2="0.254" width="0.508" layer="51"/>
<wire x1="2.54" y1="0" x2="2.54" y2="0.254" width="0.508" layer="51"/>
<text x="-3.302" y="8.001" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.794" y1="0.127" x2="-2.286" y2="0.508" layer="51"/>
<rectangle x1="2.286" y1="0.127" x2="2.794" y2="0.508" layer="51"/>
</package>
<package name="C075-032X103">
grid 7.5 mm, outline 3.2 x 10.3 mm</description>
<wire x1="4.826" y1="1.524" x2="-4.826" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-1.524" x2="4.826" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.27" x2="5.08" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.826" y1="1.524" x2="5.08" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.826" y1="-1.524" x2="5.08" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="-1.27" x2="-4.826" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.27" x2="-4.826" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="0.508" y1="0" x2="2.54" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.889" x2="-0.508" y2="0" width="0.4064" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.889" width="0.4064" layer="21"/>
<wire x1="0.508" y1="0.889" x2="0.508" y2="0" width="0.4064" layer="21"/>
<wire x1="0.508" y1="0" x2="0.508" y2="-0.889" width="0.4064" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.9144" shape="octagon"/>
<text x="-4.826" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.826" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C075-042X103">
grid 7.5 mm, outline 4.2 x 10.3 mm</description>
<wire x1="4.826" y1="2.032" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.778" x2="-5.08" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.032" x2="4.826" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.778" x2="5.08" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="5.08" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.826" y1="-2.032" x2="5.08" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="-1.778" x2="-4.826" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.778" x2="-4.826" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.27" y1="0" x2="2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0" x2="-2.159" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.27" x2="-2.159" y2="0" width="0.4064" layer="21"/>
<wire x1="-2.159" y1="0" x2="-2.159" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="0" width="0.4064" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-1.27" width="0.4064" layer="21"/>
<text x="-4.699" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C075-052X106">
grid 7.5 mm, outline 5.2 x 10.6 mm</description>
<wire x1="4.953" y1="2.54" x2="-4.953" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.286" x2="-5.207" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.54" x2="4.953" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.286" x2="5.207" y2="2.286" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.54" x2="5.207" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.953" y1="-2.54" x2="5.207" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="-2.286" x2="-4.953" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="2.286" x2="-4.953" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-4.826" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C102-043X133">
grid 10.2 mm, outline 4.3 x 13.3 mm</description>
<wire x1="-3.175" y1="1.27" x2="-3.175" y2="0" width="0.4064" layer="21"/>
<wire x1="-2.286" y1="1.27" x2="-2.286" y2="0" width="0.4064" layer="21"/>
<wire x1="3.81" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="-2.286" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-3.81" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0" x2="-3.175" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-6.096" y1="2.032" x2="6.096" y2="2.032" width="0.1524" layer="21"/>
<wire x1="6.604" y1="1.524" x2="6.604" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-2.032" x2="-6.096" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-1.524" x2="-6.604" y2="1.524" width="0.1524" layer="21"/>
<wire x1="6.096" y1="2.032" x2="6.604" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-2.032" x2="6.604" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-1.524" x2="-6.096" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="1.524" x2="-6.096" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-5.08" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="1.016" shape="octagon"/>
<text x="-6.096" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C102-054X133">
grid 10.2 mm, outline 5.4 x 13.3 mm</description>
<wire x1="-6.096" y1="2.54" x2="6.096" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.032" x2="6.604" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-2.54" x2="-6.096" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.032" x2="-6.604" y2="2.032" width="0.1524" layer="21"/>
<wire x1="6.096" y1="2.54" x2="6.604" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-2.54" x2="6.604" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-2.032" x2="-6.096" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="2.032" x2="-6.096" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-6.096" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-1.905" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C102-064X133">
grid 10.2 mm, outline 6.4 x 13.3 mm</description>
<wire x1="-6.096" y1="3.048" x2="6.096" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.54" x2="6.604" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-3.048" x2="-6.096" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.54" x2="-6.604" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.096" y1="3.048" x2="6.604" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-3.048" x2="6.604" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-2.54" x2="-6.096" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="2.54" x2="-6.096" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-6.096" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C102_152-062X184">
grid 10.2 mm + 15.2 mm, outline 6.2 x 18.4 mm</description>
<wire x1="-3.683" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="3.683" y2="0" width="0.1524" layer="21"/>
<wire x1="6.477" y1="0" x2="8.636" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="3.048" x2="6.223" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.223" y1="-3.048" x2="-6.096" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.223" y1="3.048" x2="6.731" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.223" y1="-3.048" x2="6.731" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="6.731" y1="2.54" x2="6.731" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="11.176" y1="3.048" x2="11.684" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="11.176" y1="-3.048" x2="11.684" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="11.176" y1="-3.048" x2="7.112" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="7.112" y1="3.048" x2="11.176" y2="3.048" width="0.1524" layer="21"/>
<wire x1="11.684" y1="2.54" x2="11.684" y2="-2.54" width="0.1524" layer="21"/>
<pad name="3" x="10.033" y="0" drill="1.016" shape="octagon"/>
<text x="-5.969" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-054X183">
grid 15 mm, outline 5.4 x 18.3 mm</description>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="0" width="0.4064" layer="21"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="1.27" x2="-4.191" y2="0" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="-4.191" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="9.017" y1="2.032" x2="9.017" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-2.54" x2="-8.509" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-2.032" x2="-9.017" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="2.54" x2="8.509" y2="2.54" width="0.1524" layer="21"/>
<wire x1="8.509" y1="2.54" x2="9.017" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-2.54" x2="9.017" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-2.032" x2="-8.509" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="2.032" x2="-8.509" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-7.493" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="7.493" y="0" drill="1.016" shape="octagon"/>
<text x="-8.382" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-064X183">
grid 15 mm, outline 6.4 x 18.3 mm</description>
<wire x1="9.017" y1="2.54" x2="9.017" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.048" x2="-8.509" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-2.54" x2="-9.017" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.048" x2="8.509" y2="3.048" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.048" x2="9.017" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-3.048" x2="9.017" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-2.54" x2="-8.509" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="2.54" x2="-8.509" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C150-072X183">
grid 15 mm, outline 7.2 x 18.3 mm</description>
<wire x1="9.017" y1="3.048" x2="9.017" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.556" x2="-8.509" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.048" x2="-9.017" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.556" x2="8.509" y2="3.556" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.556" x2="9.017" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-3.556" x2="9.017" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.048" x2="-8.509" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.048" x2="-8.509" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-084X183">
grid 15 mm, outline 8.4 x 18.3 mm</description>
<wire x1="9.017" y1="3.556" x2="9.017" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.064" x2="-8.509" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.556" x2="-9.017" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.064" x2="8.509" y2="4.064" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.064" x2="9.017" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-4.064" x2="9.017" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.556" x2="-8.509" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.556" x2="-8.509" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-091X182">
grid 15 mm, outline 9.1 x 18.2 mm</description>
<wire x1="9.017" y1="3.937" x2="9.017" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.445" x2="-8.509" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.937" x2="-9.017" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.445" x2="8.509" y2="4.445" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.445" x2="9.017" y2="3.937" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-4.445" x2="9.017" y2="-3.937" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.937" x2="-8.509" y2="-4.445" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.937" x2="-8.509" y2="4.445" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="4.826" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C225-062X268">
grid 22.5 mm, outline 6.2 x 26.8 mm</description>
<wire x1="-12.827" y1="3.048" x2="12.827" y2="3.048" width="0.1524" layer="21"/>
<wire x1="13.335" y1="2.54" x2="13.335" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-3.048" x2="-12.827" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-2.54" x2="-13.335" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="1.905" x2="-6.731" y2="0" width="0.4064" layer="21"/>
<wire x1="-6.731" y1="0" x2="-6.731" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-7.62" y2="0" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="12.827" y1="3.048" x2="13.335" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-3.048" x2="13.335" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-2.54" x2="-12.827" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="2.54" x2="-12.827" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="-9.652" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="9.652" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-11.303" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="11.303" y="0" drill="1.016" shape="octagon"/>
<text x="-12.7" y="3.429" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C225-074X268">
grid 22.5 mm, outline 7.4 x 26.8 mm</description>
<wire x1="-12.827" y1="3.556" x2="12.827" y2="3.556" width="0.1524" layer="21"/>
<wire x1="13.335" y1="3.048" x2="13.335" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-3.556" x2="-12.827" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-3.048" x2="-13.335" y2="3.048" width="0.1524" layer="21"/>
<wire x1="12.827" y1="3.556" x2="13.335" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-3.556" x2="13.335" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-3.048" x2="-12.827" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="3.048" x2="-12.827" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<text x="-12.827" y="3.937" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C225-087X268">
grid 22.5 mm, outline 8.7 x 26.8 mm</description>
<wire x1="-12.827" y1="4.318" x2="12.827" y2="4.318" width="0.1524" layer="21"/>
<wire x1="13.335" y1="3.81" x2="13.335" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-4.318" x2="-12.827" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-3.81" x2="-13.335" y2="3.81" width="0.1524" layer="21"/>
<wire x1="12.827" y1="4.318" x2="13.335" y2="3.81" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-4.318" x2="13.335" y2="-3.81" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-3.81" x2="-12.827" y2="-4.318" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="3.81" x2="-12.827" y2="4.318" width="0.1524" layer="21" curve="-90"/>
<text x="-12.827" y="4.699" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C225-108X268">
grid 22.5 mm, outline 10.8 x 26.8 mm</description>
<wire x1="-12.827" y1="5.334" x2="12.827" y2="5.334" width="0.1524" layer="21"/>
<wire x1="13.335" y1="4.826" x2="13.335" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-5.334" x2="-12.827" y2="-5.334" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-4.826" x2="-13.335" y2="4.826" width="0.1524" layer="21"/>
<wire x1="12.827" y1="5.334" x2="13.335" y2="4.826" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-5.334" x2="13.335" y2="-4.826" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-4.826" x2="-12.827" y2="-5.334" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="4.826" x2="-12.827" y2="5.334" width="0.1524" layer="21" curve="-90"/>
<text x="-12.954" y="5.715" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C225-113X268">
grid 22.5 mm, outline 11.3 x 26.8 mm</description>
<wire x1="-12.827" y1="5.588" x2="12.827" y2="5.588" width="0.1524" layer="21"/>
<wire x1="13.335" y1="5.08" x2="13.335" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-5.588" x2="-12.827" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.08" x2="-13.335" y2="5.08" width="0.1524" layer="21"/>
<wire x1="12.827" y1="5.588" x2="13.335" y2="5.08" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-5.588" x2="13.335" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-5.08" x2="-12.827" y2="-5.588" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="5.08" x2="-12.827" y2="5.588" width="0.1524" layer="21" curve="-90"/>
<text x="-12.954" y="5.969" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-093X316">
grid 27.5 mm, outline 9.3 x 31.6 mm</description>
<wire x1="-15.24" y1="4.572" x2="15.24" y2="4.572" width="0.1524" layer="21"/>
<wire x1="15.748" y1="4.064" x2="15.748" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-4.572" x2="-15.24" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-4.064" x2="-15.748" y2="4.064" width="0.1524" layer="21"/>
<wire x1="15.24" y1="4.572" x2="15.748" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-4.572" x2="15.748" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-4.064" x2="-15.24" y2="-4.572" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="4.064" x2="-15.24" y2="4.572" width="0.1524" layer="21" curve="-90"/>
<wire x1="-11.557" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="11.557" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-13.716" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="13.716" y="0" drill="1.1938" shape="octagon"/>
<text x="-15.24" y="4.953" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-113X316">
grid 27.5 mm, outline 11.3 x 31.6 mm</description>
<wire x1="-15.24" y1="5.588" x2="15.24" y2="5.588" width="0.1524" layer="21"/>
<wire x1="15.748" y1="5.08" x2="15.748" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-5.588" x2="-15.24" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-5.08" x2="-15.748" y2="5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="5.588" x2="15.748" y2="5.08" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-5.588" x2="15.748" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-5.08" x2="-15.24" y2="-5.588" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="5.08" x2="-15.24" y2="5.588" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="5.969" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-134X316">
grid 27.5 mm, outline 13.4 x 31.6 mm</description>
<wire x1="-15.24" y1="6.604" x2="15.24" y2="6.604" width="0.1524" layer="21"/>
<wire x1="15.748" y1="6.096" x2="15.748" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-6.604" x2="-15.24" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-6.096" x2="-15.748" y2="6.096" width="0.1524" layer="21"/>
<wire x1="15.24" y1="6.604" x2="15.748" y2="6.096" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-6.604" x2="15.748" y2="-6.096" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-6.096" x2="-15.24" y2="-6.604" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="6.096" x2="-15.24" y2="6.604" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="6.985" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-205X316">
grid 27.5 mm, outline 20.5 x 31.6 mm</description>
<wire x1="-15.24" y1="10.16" x2="15.24" y2="10.16" width="0.1524" layer="21"/>
<wire x1="15.748" y1="9.652" x2="15.748" y2="-9.652" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-10.16" x2="-15.24" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-9.652" x2="-15.748" y2="9.652" width="0.1524" layer="21"/>
<wire x1="15.24" y1="10.16" x2="15.748" y2="9.652" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-10.16" x2="15.748" y2="-9.652" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-9.652" x2="-15.24" y2="-10.16" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="9.652" x2="-15.24" y2="10.16" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="10.541" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.318" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C325-137X374">
grid 32.5 mm, outline 13.7 x 37.4 mm</description>
<wire x1="-14.2748" y1="0" x2="-12.7" y2="0" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="1.905" x2="-12.7" y2="0" width="0.4064" layer="21"/>
<wire x1="-11.811" y1="1.905" x2="-11.811" y2="0" width="0.4064" layer="21"/>
<wire x1="-11.811" y1="0" x2="14.2748" y2="0" width="0.1524" layer="21"/>
<wire x1="-11.811" y1="0" x2="-11.811" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="-12.7" y1="0" x2="-12.7" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="18.542" y1="6.731" x2="18.542" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="6.731" x2="-18.542" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-6.731" x2="18.542" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="18.542" y1="6.731" x2="-18.542" y2="6.731" width="0.1524" layer="21"/>
<pad name="1" x="-16.256" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="16.256" y="0" drill="1.1938" shape="octagon"/>
<text x="-18.2372" y="7.0612" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-10.8458" y="-2.8702" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C325-162X374">
grid 32.5 mm, outline 16.2 x 37.4 mm</description>
<wire x1="18.542" y1="8.001" x2="18.542" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="8.001" x2="-18.542" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-8.001" x2="18.542" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="18.542" y1="8.001" x2="-18.542" y2="8.001" width="0.1524" layer="21"/>
<text x="-18.3642" y="8.3312" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C325-182X374">
grid 32.5 mm, outline 18.2 x 37.4 mm</description>
<wire x1="18.542" y1="9.017" x2="18.542" y2="-9.017" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="9.017" x2="-18.542" y2="-9.017" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-9.017" x2="18.542" y2="-9.017" width="0.1524" layer="21"/>
<wire x1="18.542" y1="9.017" x2="-18.542" y2="9.017" width="0.1524" layer="21"/>
<text x="-18.3642" y="9.3472" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C375-192X418">
grid 37.5 mm, outline 19.2 x 41.8 mm</description>
<wire x1="-20.32" y1="8.509" x2="20.32" y2="8.509" width="0.1524" layer="21"/>
<wire x1="20.828" y1="8.001" x2="20.828" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-8.509" x2="-20.32" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-8.001" x2="-20.828" y2="8.001" width="0.1524" layer="21"/>
<wire x1="20.32" y1="8.509" x2="20.828" y2="8.001" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-8.509" x2="20.828" y2="-8.001" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-8.001" x2="-20.32" y2="-8.509" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="8.001" x2="-20.32" y2="8.509" width="0.1524" layer="21" curve="-90"/>
<wire x1="-16.002" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="16.002" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-18.796" y="0" drill="1.3208" shape="octagon"/>
<pad name="2" x="18.796" y="0" drill="1.3208" shape="octagon"/>
<text x="-20.447" y="8.89" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C375-203X418">
grid 37.5 mm, outline 20.3 x 41.8 mm</description>
<wire x1="-20.32" y1="10.16" x2="20.32" y2="10.16" width="0.1524" layer="21"/>
<wire x1="20.828" y1="9.652" x2="20.828" y2="-9.652" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-10.16" x2="-20.32" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-9.652" x2="-20.828" y2="9.652" width="0.1524" layer="21"/>
<wire x1="20.32" y1="10.16" x2="20.828" y2="9.652" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-10.16" x2="20.828" y2="-9.652" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-9.652" x2="-20.32" y2="-10.16" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="9.652" x2="-20.32" y2="10.16" width="0.1524" layer="21" curve="-90"/>
<text x="-20.32" y="10.541" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C050-035X075">
grid 5 mm, outline 3.5 x 7.5 mm</description>
<wire x1="-3.683" y1="1.524" x2="-3.683" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.778" x2="3.429" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.524" x2="3.683" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.778" x2="-3.429" y2="1.778" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.778" x2="3.683" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.778" x2="3.683" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.524" x2="-3.429" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.524" x2="-3.429" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<text x="-3.556" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C375-155X418">
grid 37.5 mm, outline 15.5 x 41.8 mm</description>
<wire x1="-20.32" y1="7.62" x2="20.32" y2="7.62" width="0.1524" layer="21"/>
<wire x1="20.828" y1="7.112" x2="20.828" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-7.62" x2="-20.32" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-7.112" x2="-20.828" y2="7.112" width="0.1524" layer="21"/>
<wire x1="20.32" y1="7.62" x2="20.828" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-7.62" x2="20.828" y2="-7.112" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-7.112" x2="-20.32" y2="-7.62" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="7.112" x2="-20.32" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<text x="-20.447" y="8.001" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C075-063X106">
grid 7.5 mm, outline 6.3 x 10.6 mm</description>
<wire x1="4.953" y1="3.048" x2="-4.953" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.794" x2="-5.207" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-3.048" x2="4.953" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.794" x2="5.207" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.953" y1="3.048" x2="5.207" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.953" y1="-3.048" x2="5.207" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="-2.794" x2="-4.953" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="2.794" x2="-4.953" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-4.826" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C275-154X316">
grid 27.5 mm, outline 15.4 x 31.6 mm</description>
<wire x1="-15.24" y1="7.62" x2="15.24" y2="7.62" width="0.1524" layer="21"/>
<wire x1="15.748" y1="7.112" x2="15.748" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-7.62" x2="-15.24" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-7.112" x2="-15.748" y2="7.112" width="0.1524" layer="21"/>
<wire x1="15.24" y1="7.62" x2="15.748" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-7.62" x2="15.748" y2="-7.112" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-7.112" x2="-15.24" y2="-7.62" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="7.112" x2="-15.24" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="8.001" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-173X316">
grid 27.5 mm, outline 17.3 x 31.6 mm</description>
<wire x1="-15.24" y1="8.509" x2="15.24" y2="8.509" width="0.1524" layer="21"/>
<wire x1="15.748" y1="8.001" x2="15.748" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-8.509" x2="-15.24" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-8.001" x2="-15.748" y2="8.001" width="0.1524" layer="21"/>
<wire x1="15.24" y1="8.509" x2="15.748" y2="8.001" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-8.509" x2="15.748" y2="-8.001" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-8.001" x2="-15.24" y2="-8.509" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="8.001" x2="-15.24" y2="8.509" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="8.89" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C0402K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 0204 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 1005</description>
<wire x1="-0.425" y1="0.2" x2="0.425" y2="0.2" width="0.1016" layer="51"/>
<wire x1="0.425" y1="-0.2" x2="-0.425" y2="-0.2" width="0.1016" layer="51"/>
<smd name="1" x="-0.6" y="0" dx="0.925" dy="0.74" layer="1"/>
<smd name="2" x="0.6" y="0" dx="0.925" dy="0.74" layer="1"/>
<text x="-0.5" y="0.425" size="1.016" layer="25">&gt;NAME</text>
<text x="-0.5" y="-1.45" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-0.5" y1="-0.25" x2="-0.225" y2="0.25" layer="51"/>
<rectangle x1="0.225" y1="-0.25" x2="0.5" y2="0.25" layer="51"/>
</package>
<package name="C0603K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 0603 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 1608</description>
<wire x1="-0.725" y1="0.35" x2="0.725" y2="0.35" width="0.1016" layer="51"/>
<wire x1="0.725" y1="-0.35" x2="-0.725" y2="-0.35" width="0.1016" layer="51"/>
<smd name="1" x="-0.875" y="0" dx="1.05" dy="1.08" layer="1"/>
<smd name="2" x="0.875" y="0" dx="1.05" dy="1.08" layer="1"/>
<text x="-0.8" y="0.65" size="1.016" layer="25">&gt;NAME</text>
<text x="-0.8" y="-1.65" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-0.8" y1="-0.4" x2="-0.45" y2="0.4" layer="51"/>
<rectangle x1="0.45" y1="-0.4" x2="0.8" y2="0.4" layer="51"/>
</package>
<package name="C0805K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 0805 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 2012</description>
<wire x1="-0.925" y1="0.6" x2="0.925" y2="0.6" width="0.1016" layer="51"/>
<wire x1="0.925" y1="-0.6" x2="-0.925" y2="-0.6" width="0.1016" layer="51"/>
<smd name="1" x="-1" y="0" dx="1.3" dy="1.6" layer="1"/>
<smd name="2" x="1" y="0" dx="1.3" dy="1.6" layer="1"/>
<text x="-1" y="0.875" size="1.016" layer="25">&gt;NAME</text>
<text x="-1" y="-1.9" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1" y1="-0.65" x2="-0.5" y2="0.65" layer="51"/>
<rectangle x1="0.5" y1="-0.65" x2="1" y2="0.65" layer="51"/>
</package>
<package name="C1206K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1206 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 3216</description>
<wire x1="-1.525" y1="0.75" x2="1.525" y2="0.75" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-0.75" x2="-1.525" y2="-0.75" width="0.1016" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="1.5" dy="2" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.5" dy="2" layer="1"/>
<text x="-1.6" y="1.1" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-2.1" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-0.8" x2="-1.1" y2="0.8" layer="51"/>
<rectangle x1="1.1" y1="-0.8" x2="1.6" y2="0.8" layer="51"/>
</package>
<package name="C1210K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1210 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 3225</description>
<wire x1="-1.525" y1="1.175" x2="1.525" y2="1.175" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-1.175" x2="-1.525" y2="-1.175" width="0.1016" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="1.5" dy="2.9" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.5" dy="2.9" layer="1"/>
<text x="-1.6" y="1.55" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-2.575" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-1.25" x2="-1.1" y2="1.25" layer="51"/>
<rectangle x1="1.1" y1="-1.25" x2="1.6" y2="1.25" layer="51"/>
</package>
<package name="C1812K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1812 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 4532</description>
<wire x1="-2.175" y1="1.525" x2="2.175" y2="1.525" width="0.1016" layer="51"/>
<wire x1="2.175" y1="-1.525" x2="-2.175" y2="-1.525" width="0.1016" layer="51"/>
<smd name="1" x="-2.05" y="0" dx="1.8" dy="3.7" layer="1"/>
<smd name="2" x="2.05" y="0" dx="1.8" dy="3.7" layer="1"/>
<text x="-2.25" y="1.95" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.25" y="-2.975" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.25" y1="-1.6" x2="-1.65" y2="1.6" layer="51"/>
<rectangle x1="1.65" y1="-1.6" x2="2.25" y2="1.6" layer="51"/>
</package>
<package name="C1825K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1825 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 4564</description>
<wire x1="-1.525" y1="3.125" x2="1.525" y2="3.125" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-3.125" x2="-1.525" y2="-3.125" width="0.1016" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="1.8" dy="6.9" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.8" dy="6.9" layer="1"/>
<text x="-1.6" y="3.55" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-4.625" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-3.2" x2="-1.1" y2="3.2" layer="51"/>
<rectangle x1="1.1" y1="-3.2" x2="1.6" y2="3.2" layer="51"/>
</package>
<package name="C2220K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 2220 reflow solder&lt;/b&gt;&lt;p&gt;Metric Code Size 5650</description>
<wire x1="-2.725" y1="2.425" x2="2.725" y2="2.425" width="0.1016" layer="51"/>
<wire x1="2.725" y1="-2.425" x2="-2.725" y2="-2.425" width="0.1016" layer="51"/>
<smd name="1" x="-2.55" y="0" dx="1.85" dy="5.5" layer="1"/>
<smd name="2" x="2.55" y="0" dx="1.85" dy="5.5" layer="1"/>
<text x="-2.8" y="2.95" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.8" y="-3.975" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.8" y1="-2.5" x2="-2.2" y2="2.5" layer="51"/>
<rectangle x1="2.2" y1="-2.5" x2="2.8" y2="2.5" layer="51"/>
</package>
<package name="C2225K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 2225 reflow solder&lt;/b&gt;&lt;p&gt;Metric Code Size 5664</description>
<wire x1="-2.725" y1="3.075" x2="2.725" y2="3.075" width="0.1016" layer="51"/>
<wire x1="2.725" y1="-3.075" x2="-2.725" y2="-3.075" width="0.1016" layer="51"/>
<smd name="1" x="-2.55" y="0" dx="1.85" dy="6.8" layer="1"/>
<smd name="2" x="2.55" y="0" dx="1.85" dy="6.8" layer="1"/>
<text x="-2.8" y="3.6" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.8" y="-4.575" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.8" y1="-3.15" x2="-2.2" y2="3.15" layer="51"/>
<rectangle x1="2.2" y1="-3.15" x2="2.8" y2="3.15" layer="51"/>
</package>
<package name="HPC0201">
<description>&lt;b&gt; &lt;/b&gt;&lt;p&gt;
Source: http://www.vishay.com/docs/10129/hpc0201a.pdf</description>
<smd name="1" x="-0.18" y="0" dx="0.2" dy="0.35" layer="1"/>
<smd name="2" x="0.18" y="0" dx="0.2" dy="0.35" layer="1"/>
<text x="-0.75" y="0.74" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.785" y="-1.865" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.305" y1="-0.15" x2="0.305" y2="0.15" layer="51"/>
</package>
<package name="C0201">
<description>Source: http://www.avxcorp.com/docs/catalogs/cx5r.pdf</description>
<smd name="1" x="-0.25" y="0" dx="0.25" dy="0.35" layer="1"/>
<smd name="2" x="0.25" y="0" dx="0.25" dy="0.35" layer="1"/>
<text x="-0.635" y="0.635" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-1.905" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.3" y1="-0.15" x2="-0.15" y2="0.15" layer="51"/>
<rectangle x1="0.15" y1="-0.15" x2="0.3" y2="0.15" layer="51"/>
<rectangle x1="-0.15" y1="0.1" x2="0.15" y2="0.15" layer="51"/>
<rectangle x1="-0.15" y1="-0.15" x2="0.15" y2="-0.1" layer="51"/>
</package>
<package name="C1808">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
Source: AVX .. aphvc.pdf</description>
<wire x1="-1.4732" y1="0.9502" x2="1.4732" y2="0.9502" width="0.1016" layer="51"/>
<wire x1="-1.4478" y1="-0.9502" x2="1.4732" y2="-0.9502" width="0.1016" layer="51"/>
<smd name="1" x="-1.95" y="0" dx="1.6" dy="2.2" layer="1"/>
<smd name="2" x="1.95" y="0" dx="1.6" dy="2.2" layer="1"/>
<text x="-2.233" y="1.827" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.233" y="-2.842" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.275" y1="-1.015" x2="-1.225" y2="1.015" layer="51"/>
<rectangle x1="1.225" y1="-1.015" x2="2.275" y2="1.015" layer="51"/>
</package>
<package name="C3640">
<wire x1="-3.8322" y1="5.0496" x2="3.8322" y2="5.0496" width="0.1016" layer="51"/>
<wire x1="-3.8322" y1="-5.0496" x2="3.8322" y2="-5.0496" width="0.1016" layer="51"/>
<smd name="1" x="-4.267" y="0" dx="2.6" dy="10.7" layer="1"/>
<smd name="2" x="4.267" y="0" dx="2.6" dy="10.7" layer="1"/>
<text x="-4.647" y="6.465" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.647" y="-7.255" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-4.57" y1="-5.1" x2="-3.05" y2="5.1" layer="51"/>
<rectangle x1="3.05" y1="-5.1" x2="4.5688" y2="5.1" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="R-EU">
<wire x1="-2.54" y1="-0.889" x2="2.54" y2="-0.889" width="0.254" layer="94"/>
<wire x1="2.54" y1="0.889" x2="-2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="2.54" y1="-0.889" x2="2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-0.889" x2="-2.54" y2="0.889" width="0.254" layer="94"/>
<text x="-3.81" y="1.4986" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.81" y="-3.302" size="1.778" layer="96">&gt;VALUE</text>
<pin name="2" x="5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1" rot="R180"/>
<pin name="1" x="-5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
</symbol>
<symbol name="CPOL">
<wire x1="-1.524" y1="-0.889" x2="1.524" y2="-0.889" width="0.254" layer="94"/>
<wire x1="1.524" y1="-0.889" x2="1.524" y2="0" width="0.254" layer="94"/>
<wire x1="-1.524" y1="0" x2="-1.524" y2="-0.889" width="0.254" layer="94"/>
<wire x1="-1.524" y1="0" x2="1.524" y2="0" width="0.254" layer="94"/>
<text x="1.143" y="0.4826" size="1.778" layer="95">&gt;NAME</text>
<text x="-0.5842" y="0.4064" size="1.27" layer="94" rot="R90">+</text>
<text x="1.143" y="-4.5974" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-2.54" x2="1.651" y2="-1.651" layer="94"/>
<pin name="-" x="0" y="-5.08" visible="off" length="short" direction="pas" rot="R90"/>
<pin name="+" x="0" y="2.54" visible="off" length="short" direction="pas" rot="R270"/>
</symbol>
<symbol name="C-EU">
<wire x1="0" y1="0" x2="0" y2="-0.508" width="0.1524" layer="94"/>
<wire x1="0" y1="-2.54" x2="0" y2="-2.032" width="0.1524" layer="94"/>
<text x="1.524" y="0.381" size="1.778" layer="95">&gt;NAME</text>
<text x="1.524" y="-4.699" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-2.032" y1="-2.032" x2="2.032" y2="-1.524" layer="94"/>
<rectangle x1="-2.032" y1="-1.016" x2="2.032" y2="-0.508" layer="94"/>
<pin name="1" x="0" y="2.54" visible="off" length="short" direction="pas" swaplevel="1" rot="R270"/>
<pin name="2" x="0" y="-5.08" visible="off" length="short" direction="pas" swaplevel="1" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="R-EU_" prefix="R" uservalue="yes">
<description>&lt;B&gt;RESISTOR&lt;/B&gt;, European symbol</description>
<gates>
<gate name="G$1" symbol="R-EU" x="0" y="0"/>
</gates>
<devices>
<device name="R0402" package="R0402">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="R0603" package="R0603">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R0805" package="R0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R0805W" package="R0805W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1005" package="R1005">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1206" package="R1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1206W" package="R1206W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1210" package="R1210">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1210W" package="R1210W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2010" package="R2010">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2010W" package="R2010W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2012" package="R2012">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2012W" package="R2012W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2512" package="R2512">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2512W" package="R2512W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3216" package="R3216">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3216W" package="R3216W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3225" package="R3225">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3225W" package="R3225W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R5025" package="R5025">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R5025W" package="R5025W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R6332" package="R6332">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R6332W" package="R6332W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M0805" package="M0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M1206" package="M1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M1406" package="M1406">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M2012" package="M2012">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M2309" package="M2309">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M3216" package="M3216">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M3516" package="M3516">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M5923" package="M5923">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/5" package="0204/5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/7" package="0204/7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/2V" package="0204V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/10" package="0207/10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/12" package="0207/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/15" package="0207/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/2V" package="0207/2V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/5V" package="0207/5V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/7" package="0207/7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0309/10" package="0309/10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0309/12" package="0309/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0309/V" package="0309V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0411/12" package="0411/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0411/15" package="0411/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0411/3V" package="0411V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0414/15" package="0414/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0414/5V" package="0414V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0617/17" package="0617/17">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0617/22" package="0617/22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0617/5V" package="0617V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0922/22" package="0922/22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0613/5V" package="P0613V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0613/15" package="P0613/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0817/22" package="P0817/22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0817/7V" package="P0817V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V234/12" package="V234/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V235/17" package="V235/17">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V526-0" package="V526-0">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0102R" package="MINI_MELF-0102R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0102W" package="MINI_MELF-0102W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0204R" package="MINI_MELF-0204R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0204W" package="MINI_MELF-0204W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0207R" package="MINI_MELF-0207R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0207W" package="MINI_MELF-0207W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0922V" package="0922V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="RDH/15" package="RDH/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0102AX" package="MINI_MELF-0102AX">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R0201" package="R0201">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VTA52" package="VTA52">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VTA53" package="VTA53">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VTA54" package="VTA54">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VTA55" package="VTA55">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VTA56" package="VTA56">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VMTA55" package="VMTA55">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VMTB60" package="VMTB60">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R4527" package="R4527">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WSC0001" package="WSC0001">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WSC0002" package="WSC0002">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WSC01/2" package="WSC01/2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WSC2515" package="WSC2515">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WSC4527" package="WSC4527">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WSC6927" package="WSC6927">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1218" package="R1218">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="1812X7R" package="1812X7R">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="CPOL-EU" prefix="C" uservalue="yes">
<description>&lt;B&gt;POLARIZED CAPACITOR&lt;/B&gt;, European symbol</description>
<gates>
<gate name="G$1" symbol="CPOL" x="0" y="0"/>
</gates>
<devices>
<device name="CT3216" package="CT3216">
<connects>
<connect gate="G$1" pin="+" pad="+"/>
<connect gate="G$1" pin="-" pad="-"/>
</connects>
<technologies>
</technologies>
</device>
<device name="CT3528" package="CT3528">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CT6032" package="CT6032">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CT7343" package="CT7343">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B45181A" package="B45181A">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B45181B" package="B45181B">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B45181C" package="B45181C">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B45181D" package="B45181D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT2D4" package="TT2D4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT2D4L" package="TT2D4L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT2D5" package="TT2D5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT2D6" package="TT2D6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT2D6L" package="TT2D6L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT2D7L" package="TT2D7L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT2D7" package="TT2D7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT5D10" package="TT5D10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT5D11" package="TT5D11">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT5D11L" package="TT5D11L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT6D6" package="TT5D6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT5D6L" package="TT5D6L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT5D7" package="TT5D7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT5D7L" package="TT5D7L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT5D9" package="TT5D9">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT5D9L" package="TT5D9L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ETR1" package="ETR1">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ETR2" package="ETR2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ETR3" package="ETR3">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ETR4" package="ETR4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ETR5" package="ETR5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P128-35" package="P128-35">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P128-40" package="P128-40">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P128-50" package="P128-50">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P128-60" package="P128-60">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TAP5-45" package="TAP5-45">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TAP5-50" package="TAP5-50">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TAP5-70" package="TAP5-70">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TAP5-60" package="TAP5-60">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TAP5-80" package="TAP5-80">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E1.8-4" package="E1,8-4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E15-5AXIAL" package="E15-5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E15-6AXIAL" package="E15-6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E15-9AXIAL" package="E15-9">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E2.5-5V" package="E2,5-4R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E2.5-5" package="E2,5-5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E2.5-6" package="E2,5-6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E2.5-7" package="E2,5-7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E2.5-4V" package="E2,5RE">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E2-4" package="E2-4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E2-5" package="E2-5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E22-10AXIAL" package="E22-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E22-6AXIAL" package="E22-6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E22-9AXIAL" package="E22-9">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E3.5-10" package="E3,5-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E25-10AXIAL" package="E25-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E25-9AXIAL" package="E25-9">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E3.5-8" package="E3,5-8">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E30-10AXIAL" package="E30-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E30-12AXIAL" package="E30-12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E30-16AXIAL" package="E30-16">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E35-12AXIAL" package="E35-12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E35-14AXIAL" package="E35-14">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E35-16AXIAL" package="E35-16">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E35-18AXIAL" package="E35-18">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E45-16AXIAL" package="E45-16">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E45-18AXIAL" package="E45-18">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E45-21AXIAL" package="E45-21">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E45-22AXIAL" package="E45-22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E45-25AXIAL" package="E45-25">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E5-10.5" package="E5-10,5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E5-13" package="E5-13">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E5-4" package="E5-4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E5-5" package="E5-5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E5-6" package="E5-6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E5-8.5" package="E5-8,5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E50-25AXIAL" package="E50-25">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E50-30AXIAL" package="E50-30">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E55-25AXIAL" package="E55-25">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E55-30AXIAL" package="E55-30">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E5-9VAXIAL" package="E5R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E7.5-16" package="E7,5-16">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E7.5-18" package="E7,5-18">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E10-20" package="EB20D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E10-22.5" package="EB22,5D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E10-25" package="EB25D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E10-30" package="EB30D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E10-35" package="EB35D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="085CS-1R" package="085CS_1R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="085CS-1W" package="085CS_1W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="085CS-1AR" package="085CS_1AR">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="085CS-1AW" package="085CS_1AW">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="139CLL-2R" package="139CLL-2R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="139CLL-2W" package="139CLL-2W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="139CLL-3R" package="139CLL-3R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="139CLL-3W" package="139CLL-3W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="140CLH-0810" package="140CLH-0810">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="140CLH-1010" package="140CLH-1010">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="140CLH-1014" package="140CLH-1014">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150CLZ-0810" package="150CLZ-0810">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150CLZ-1010" package="150CLZ-1010">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150CLZ-1014" package="150CLZ-1014">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="153CLV-0405" package="153CLV-0405">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="153CLV-0505" package="153CLV-0505">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="153CLV-0605" package="153CLV-0605">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="153CLV-0807" package="153CLV-0807">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="153CLV-0810" package="153CLV-0810">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="153CLV-1010" package="153CLV-1010">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="153CLV-1012" package="153CLV-1012">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="153CLV-1014" package="153CLV-1014">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="175TMP-0808" package="175TMP-0808">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="175TMP-0810" package="175TMP-0810">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="A/3216-18R" package="A/3216-18R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="A/3216-18W" package="A/3216-18W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B/3528-21R" package="B/3528-21R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B/3528-21W" package="B/3528-21W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C/6032-28R" package="C/6032-28R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C/6032-28W" package="C/6032-28W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="D/7343-31R" package="D/7343-31R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="D/7343-31W" package="D/7343-31W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E/7260-38R" package="E/7260-38R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E/7260-38W" package="E/7260-38W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R/2012-12R" package="R/2012-12R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R/2012-12W" package="R/2012-12W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="A" package="PANASONIC_A">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B" package="PANASONIC_B">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C" package="PANASONIC_C">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="D" package="PANASONIC_D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E" package="PANASONIC_E">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="F" package="PANASONIC_F">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="G" package="PANASONIC_G">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TT2D5L" package="TT2D5L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="E2,5-6E" package="E2,5-6E">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMCA" package="SMC_A">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMCZ" package="SMC_Z">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMCP" package="SMC_P">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMCB" package="SMC_B">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMCC" package="SMC_C">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMCD" package="SMC_D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMCE" package="SMC_E">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_9E" package="SANYO-OSCON_9E">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_9F" package="SANYO-OSCON_9F">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_A" package="SANYO-OSCON_A">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_A'" package="SANYO-OSCON_A'">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_B" package="SANYO-OSCON_B">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_B'" package="SANYO-OSCON_B'">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_C" package="SANYO-OSCON_C">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_C'" package="SANYO-OSCON_C'">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_C6" package="SANYO-OSCON_C6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_D" package="SANYO-OSCON_D">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_E" package="SANYO-OSCON_E">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_E'" package="SANYO-OSCON_E'">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_E1" package="SANYO-OSCON_E1">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_E12" package="SANYO-OSCON_E12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_E13" package="SANYO-OSCON_E13">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_E7" package="SANYO-OSCON_E7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_E9" package="SANYO-OSCON_E9">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_F" package="SANYO-OSCON_F">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_F'" package="SANYO-OSCON_F'">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_F0" package="SANYO-OSCON_F0">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_F13" package="SANYO-OSCON_F13">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_F8" package="SANYO-OSCON_F8">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_G" package="SANYO-OSCON_G">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_H" package="SANYO-OSCON_H">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_SMD_A5" package="SANYO-OSCON_SMD_A5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_SMD_B6" package="SANYO-OSCON_SMD_B6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_SMD_C6" package="SANYO-OSCON_SMD_C6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_SMD_E12" package="SANYO-OSCON_SMD_E12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_SMD_E7" package="SANYO-OSCON_SMD_E7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_SMD_F12" package="SANYO-OSCON_SMD_F12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SANYO_SMD_F8" package="SANYO-OSCON_SMD_F8">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="UD-10X10" package="UD-10X10_NICHICON">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="UD-4X5,8" package="UD-4X5,8_NICHICON">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="UD-5X5,8" package="UD-5X5,8_NICHICON">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="UD-6,3X8,8" package="UD-6,3X5,8_NICHICON">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="UD-6,3X7,7" package="UD-6,3X7,7_NICHICON">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="UD-8X10" package="UD-8X10_NICHICON">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-EU" prefix="C" uservalue="yes">
<description>&lt;B&gt;CAPACITOR&lt;/B&gt;, European symbol</description>
<gates>
<gate name="G$1" symbol="C-EU" x="0" y="0"/>
</gates>
<devices>
<device name="C0402" package="C0402">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0504" package="C0504">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0603" package="C0603">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0805" package="C0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1005" package="C1005">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1206" package="C1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1210" package="C1210">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1310" package="C1310">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1608" package="C1608">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1812" package="C1812">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1825" package="C1825">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C2012" package="C2012">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C3216" package="C3216">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C3225" package="C3225">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C4532" package="C4532">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C4564" package="C4564">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-024X044" package="C025-024X044">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-025X050" package="C025-025X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-030X050" package="C025-030X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-040X050" package="C025-040X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-050X050" package="C025-050X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-060X050" package="C025-060X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C025_050-024X070" package="C025_050-024X070">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025_050-025X075" package="C025_050-025X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025_050-035X075" package="C025_050-035X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025_050-045X075" package="C025_050-045X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025_050-055X075" package="C025_050-055X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-024X044" package="C050-024X044">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-025X075" package="C050-025X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-045X075" package="C050-045X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-030X075" package="C050-030X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-050X075" package="C050-050X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-055X075" package="C050-055X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-075X075" package="C050-075X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050H075X075" package="C050H075X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="075-032X103" package="C075-032X103">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="075-042X103" package="C075-042X103">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="075-052X106" package="C075-052X106">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="102-043X133" package="C102-043X133">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="102-054X133" package="C102-054X133">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="102-064X133" package="C102-064X133">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="102_152-062X184" package="C102_152-062X184">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-054X183" package="C150-054X183">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-064X183" package="C150-064X183">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-072X183" package="C150-072X183">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-084X183" package="C150-084X183">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-091X182" package="C150-091X182">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-062X268" package="C225-062X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-074X268" package="C225-074X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-087X268" package="C225-087X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-108X268" package="C225-108X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-113X268" package="C225-113X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-093X316" package="C275-093X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-113X316" package="C275-113X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-134X316" package="C275-134X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-205X316" package="C275-205X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="325-137X374" package="C325-137X374">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="325-162X374" package="C325-162X374">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="325-182X374" package="C325-182X374">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="375-192X418" package="C375-192X418">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="375-203X418" package="C375-203X418">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-035X075" package="C050-035X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="375-155X418" package="C375-155X418">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="075-063X106" package="C075-063X106">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-154X316" package="C275-154X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-173X316" package="C275-173X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0402K" package="C0402K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0603K" package="C0603K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0805K" package="C0805K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1206K" package="C1206K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1210K" package="C1210K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1812K" package="C1812K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1825K" package="C1825K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C2220K" package="C2220K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C2225K" package="C2225K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="HPC0201" package="HPC0201">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0201" package="C0201">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1808" package="C1808">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C3640" package="C3640">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="diode">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DO35-10">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2 mm, horizontal, grid 10.16 mm</description>
<wire x1="5.08" y1="0" x2="4.191" y2="0" width="0.508" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.191" y2="0" width="0.508" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.032" y1="1.016" x2="2.286" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="0.762" x2="-2.032" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="-0.762" x2="-2.032" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.032" y1="-1.016" x2="2.286" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="-0.762" x2="2.286" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0.762" x2="-2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.016" x2="2.032" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.016" x2="2.032" y2="-1.016" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="5.08" y="0" drill="0.8128" shape="long"/>
<text x="-2.159" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.905" y1="-1.016" x2="-1.397" y2="1.016" layer="21"/>
<rectangle x1="2.286" y1="-0.254" x2="4.191" y2="0.254" layer="21"/>
<rectangle x1="-4.191" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
</package>
<package name="DO35-7">
diameter 2 mm, horizontal, grid 7.62 mm</description>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="2.286" y1="0.762" x2="2.286" y2="-0.762" width="0.1524" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="3.81" y="0" drill="0.8128" shape="long"/>
<text x="-2.286" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.286" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
</package>
<package name="DO41-10">
diameter 2.54 mm, horizontal, grid 10.16 mm</description>
<wire x1="2.032" y1="-1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.762" layer="51"/>
<pad name="A" x="5.08" y="0" drill="1.1176"/>
<pad name="C" x="-5.08" y="0" drill="1.1176"/>
<text x="-2.032" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.27" x2="-1.143" y2="1.27" layer="21"/>
<rectangle x1="2.032" y1="-0.381" x2="3.937" y2="0.381" layer="21"/>
<rectangle x1="-3.937" y1="-0.381" x2="-2.032" y2="0.381" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="D">
<wire x1="-1.27" y1="-1.27" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="-1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="1.27" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="1.27" y2="-1.27" width="0.254" layer="94"/>
<text x="2.54" y="0.4826" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="-2.3114" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A" x="-2.54" y="0" visible="off" length="short" direction="pas"/>
<pin name="C" x="2.54" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="1N4148" prefix="D">
high speed (Philips)</description>
<gates>
<gate name="G$1" symbol="D" x="0" y="0"/>
</gates>
<devices>
<device name="DO35-10" package="DO35-10">
<connects>
<connect gate="G$1" pin="A" pad="A"/>
<connect gate="G$1" pin="C" pad="C"/>
</connects>
<technologies>
</technologies>
</device>
<device name="DO35-7" package="DO35-7">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="1N4004" prefix="D">
general purpose rectifier, 1 A</description>
<gates>
<gate name="1" symbol="D" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DO41-10">
<connects>
<connect gate="1" pin="A" pad="A"/>
<connect gate="1" pin="C" pad="C"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="transistor">
<description>&lt;b&gt;Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="TO3">
<description>&lt;b&gt;TO-3&lt;/b&gt;</description>
<wire x1="6.3754" y1="-10.9982" x2="17.3736" y2="-4.5212" width="0.1524" layer="21"/>
<wire x1="5.969" y1="11.2014" x2="17.3736" y2="4.5212" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="10.9982" x2="-17.272" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-5.9436" y1="-11.2268" x2="-17.2466" y2="-4.5974" width="0.1524" layer="21"/>
<wire x1="17.3366" y1="4.545" x2="19.812" y2="0" width="0.1524" layer="21" curve="-57.1487"/>
<wire x1="17.3366" y1="-4.545" x2="19.812" y2="0" width="0.1524" layer="21" curve="57.1487"/>
<wire x1="-19.812" y1="0" x2="-17.0927" y2="4.6935" width="0.1524" layer="21" curve="-60.1731"/>
<wire x1="-19.812" y1="0" x2="-17.1555" y2="-4.657" width="0.1524" layer="21" curve="59.4042"/>
<wire x1="0" y1="-12.7" x2="6.3718" y2="-10.9859" width="0.1524" layer="21" curve="30.1136"/>
<wire x1="-5.9765" y1="-11.2059" x2="0" y2="-12.7" width="0.1524" layer="21" curve="28.0726"/>
<wire x1="-6.3718" y1="10.9859" x2="0" y2="12.7" width="0.1524" layer="21" curve="-30.1136"/>
<wire x1="0" y1="12.7" x2="5.9765" y2="11.2059" width="0.1524" layer="21" curve="-28.0726"/>
<circle x="0" y="0" radius="9.3726" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="11.684" width="0.0508" layer="21"/>
<circle x="15.113" y="0" radius="2.159" width="0.1524" layer="51"/>
<circle x="-15.113" y="0" radius="2.159" width="0.1524" layer="51"/>
<pad name="E" x="-1.778" y="-5.461" drill="1.1938" diameter="3.1496" shape="long"/>
<pad name="B" x="-1.778" y="5.461" drill="1.1938" diameter="3.1496" shape="long"/>
<pad name="C" x="15.113" y="0" drill="4.1148" diameter="6.477"/>
<pad name="C/" x="-15.113" y="0" drill="4.1148" diameter="6.477"/>
<text x="-5.08" y="1.27" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="15.24" y="-4.953" size="1.27" layer="51" ratio="10" rot="R90">C</text>
<text x="-3.81" y="-6.223" size="1.27" layer="51" ratio="10" rot="R90">E</text>
<text x="-3.81" y="4.572" size="1.27" layer="51" ratio="10" rot="R90">B</text>
</package>
<package name="TO18">
<description>&lt;b&gt;TO 18&lt;/b&gt;</description>
<wire x1="0.9289" y1="2.227" x2="2.227" y2="0.9289" width="0.0508" layer="51" curve="-44.7172"/>
<wire x1="0.9289" y1="-2.227" x2="2.227" y2="-0.9289" width="0.0508" layer="51" curve="44.7172"/>
<wire x1="-3.937" y1="-0.508" x2="-3.937" y2="0.508" width="0.127" layer="21"/>
<wire x1="-2.227" y1="-0.9289" x2="0.929" y2="2.2271" width="0.0508" layer="21" curve="-135.281"/>
<wire x1="-2.227" y1="-0.9289" x2="-0.9289" y2="-2.227" width="0.0508" layer="51" curve="44.7172"/>
<wire x1="-3.937" y1="-0.508" x2="-2.8765" y2="-0.508" width="0.127" layer="21"/>
<wire x1="-0.9289" y1="-2.227" x2="0.9289" y2="-2.227" width="0.0508" layer="21" curve="45.2828"/>
<wire x1="-3.937" y1="0.508" x2="-2.8765" y2="0.508" width="0.127" layer="21"/>
<wire x1="2.227" y1="-0.9289" x2="2.227" y2="0.9289" width="0.0508" layer="21" curve="45.2828"/>
<circle x="0" y="0" radius="2.921" width="0.127" layer="21"/>
<pad name="1" x="-1.27" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="3" x="1.27" y="1.27" drill="0.8128" shape="octagon"/>
<text x="3.175" y="0" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.905" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-1.905" y="-1.27" size="1.27" layer="51" ratio="10">1</text>
<text x="0.635" y="-1.27" size="1.27" layer="51" ratio="10">2</text>
<text x="0" y="0.635" size="1.27" layer="51" ratio="10">3</text>
</package>
<package name="TO18-">
<description>&lt;b&gt;TO-18&lt;/b&gt;</description>
<wire x1="-2.2098" y1="-0.9692" x2="2.2098" y2="-0.9692" width="0.0508" layer="21" curve="132.636"/>
<wire x1="-0.9692" y1="2.2098" x2="0.9692" y2="2.2098" width="0.0508" layer="51" curve="-47.3637"/>
<wire x1="-2.2098" y1="0.9692" x2="-2.2098" y2="-0.9692" width="0.0508" layer="51" curve="47.3637"/>
<wire x1="-2.2098" y1="0.9692" x2="-0.9692" y2="2.2098" width="0.0508" layer="21" curve="-42.6363"/>
<wire x1="2.2098" y1="-0.9692" x2="2.2098" y2="0.9692" width="0.0508" layer="51" curve="47.3637"/>
<wire x1="1.649" y1="-2.411" x2="2.413" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="2.411" y1="-1.649" x2="3.175" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-3.175" x2="3.175" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="0.9692" y1="2.2098" x2="2.2098" y2="0.9692" width="0.0508" layer="21" curve="-42.6363"/>
<circle x="0" y="0" radius="2.921" width="0.1524" layer="21"/>
<pad name="1" x="1.905" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="0" y="1.905" drill="0.8128" shape="octagon"/>
<pad name="3" x="-1.905" y="0" drill="0.8128" shape="octagon"/>
<text x="3.302" y="0.381" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.302" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="1.016" y="-1.143" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.508" y="0.635" size="1.27" layer="51" ratio="10">2</text>
<text x="-1.905" y="-1.27" size="1.27" layer="51" ratio="10">3</text>
</package>
<package name="TO202">
<description>&lt;b&gt;TO 202 horizontal&lt;/b&gt;</description>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="7.3406" width="0.127" layer="21"/>
<wire x1="-3.5052" y1="7.3406" x2="-3.5052" y2="8.8138" width="0.127" layer="21"/>
<wire x1="-3.5052" y1="8.8138" x2="-5.207" y2="8.8138" width="0.127" layer="21"/>
<wire x1="5.207" y1="8.8138" x2="3.5052" y2="8.8138" width="0.127" layer="21"/>
<wire x1="3.5052" y1="8.8138" x2="3.5052" y2="7.3406" width="0.127" layer="21"/>
<wire x1="5.2578" y1="-1.27" x2="5.2578" y2="7.3406" width="0.127" layer="21"/>
<wire x1="-5.207" y1="7.3406" x2="-3.5052" y2="7.3406" width="0.127" layer="21"/>
<wire x1="3.8354" y1="-1.27" x2="3.8354" y2="7.3406" width="0.127" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="3.8354" y2="-1.27" width="0.127" layer="21"/>
<wire x1="5.207" y1="21.717" x2="5.207" y2="8.8138" width="0.127" layer="21"/>
<wire x1="5.207" y1="21.717" x2="-5.207" y2="21.717" width="0.127" layer="21"/>
<wire x1="-5.207" y1="21.717" x2="-5.207" y2="8.8138" width="0.127" layer="21"/>
<wire x1="-3.5052" y1="7.3406" x2="3.5052" y2="7.3406" width="0.127" layer="21"/>
<wire x1="3.8354" y1="-1.27" x2="5.2578" y2="-1.27" width="0.127" layer="21"/>
<wire x1="3.8354" y1="7.3406" x2="5.2578" y2="7.3406" width="0.127" layer="21"/>
<wire x1="3.5052" y1="7.3406" x2="3.8354" y2="7.3406" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-1.016" x2="4.953" y2="-1.016" width="0.0508" layer="21"/>
<wire x1="4.953" y1="7.112" x2="4.953" y2="-1.016" width="0.0508" layer="21"/>
<wire x1="4.953" y1="7.112" x2="-4.953" y2="7.112" width="0.0508" layer="21"/>
<wire x1="-4.953" y1="-1.016" x2="-4.953" y2="7.112" width="0.0508" layer="21"/>
<circle x="-3.7592" y="-0.2286" radius="0.4318" width="0" layer="21"/>
<circle x="0" y="17.78" radius="1.651" width="0.127" layer="21"/>
<circle x="0" y="17.78" radius="4.191" width="0" layer="42"/>
<circle x="0" y="17.78" radius="4.191" width="0" layer="43"/>
<pad name="1" x="-2.54" y="-5.08" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-5.08" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-5.08" drill="1.1176" shape="long" rot="R90"/>
<text x="-2.54" y="4.318" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.445" y="2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-2.54" y="-0.635" size="1.27" layer="21" ratio="10">1</text>
<text x="-0.635" y="-0.635" size="1.27" layer="21" ratio="10">2</text>
<text x="1.905" y="-0.635" size="1.27" layer="21" ratio="10">3</text>
<rectangle x1="-0.635" y1="-2.54" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-2.54" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="-3.175" y1="-2.54" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="2.159" y1="-3.429" x2="2.921" y2="-2.54" layer="21"/>
<rectangle x1="2.159" y1="-5.08" x2="2.921" y2="-3.429" layer="51"/>
<rectangle x1="-0.381" y1="-3.429" x2="0.381" y2="-2.54" layer="21"/>
<rectangle x1="-2.921" y1="-3.429" x2="-2.159" y2="-2.54" layer="21"/>
<rectangle x1="-0.381" y1="-5.08" x2="0.381" y2="-3.429" layer="51"/>
<rectangle x1="-2.921" y1="-5.08" x2="-2.159" y2="-3.429" layer="51"/>
<hole x="0" y="17.78" drill="3.302"/>
</package>
<package name="TO202V">
<description>&lt;b&gt;TO 202 vertical&lt;/b&gt;</description>
<wire x1="-4.826" y1="-4.7498" x2="2.794" y2="-4.7498" width="0.127" layer="21"/>
<wire x1="-4.826" y1="-0.127" x2="4.8006" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.794" y1="-4.7498" x2="4.8006" y2="-2.794" width="0.127" layer="21"/>
<wire x1="-4.826" y1="-4.7498" x2="-4.826" y2="-0.127" width="0.127" layer="21"/>
<wire x1="4.8006" y1="-0.127" x2="4.8006" y2="-2.794" width="0.127" layer="21"/>
<circle x="-4.064" y="-3.9878" radius="0.4318" width="0.127" layer="21"/>
<pad name="1" x="-2.54" y="-2.54" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-2.54" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-2.54" drill="1.1176" shape="long" rot="R90"/>
<text x="-4.445" y="-6.985" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.445" y="-8.89" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.175" y="-1.905" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="-1.905" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="-1.905" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="3.429" y1="-2.794" x2="4.826" y2="-2.286" layer="21"/>
<rectangle x1="0.889" y1="-2.794" x2="1.651" y2="-2.286" layer="21"/>
<rectangle x1="-1.651" y1="-2.794" x2="-0.889" y2="-2.286" layer="21"/>
<rectangle x1="-4.826" y1="-2.794" x2="-3.429" y2="-2.286" layer="21"/>
<rectangle x1="-3.429" y1="-2.794" x2="-1.651" y2="-2.286" layer="51"/>
<rectangle x1="-0.889" y1="-2.794" x2="0.889" y2="-2.286" layer="51"/>
<rectangle x1="1.651" y1="-2.794" x2="3.429" y2="-2.286" layer="51"/>
</package>
<package name="SOT93">
<description>SOT-93&lt;p&gt;
grid 5.45 mm</description>
<wire x1="-7.62" y1="-6.35" x2="7.62" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="7.62" y1="6.223" x2="7.62" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="7.62" y1="6.223" x2="6.985" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-6.35" x2="-7.62" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="6.223" x2="-6.985" y2="6.985" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="6.223" x2="-7.62" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="6.985" x2="-7.62" y2="6.985" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="6.985" x2="-7.62" y2="9.525" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="9.525" x2="-3.1242" y2="13.3096" width="0.1524" layer="21"/>
<wire x1="6.985" y1="6.223" x2="6.985" y2="6.985" width="0.1524" layer="21"/>
<wire x1="6.985" y1="6.223" x2="-6.985" y2="6.223" width="0.1524" layer="21"/>
<wire x1="6.985" y1="6.985" x2="7.62" y2="6.985" width="0.1524" layer="21"/>
<wire x1="7.62" y1="6.985" x2="7.62" y2="9.525" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-5.715" x2="6.985" y2="-5.715" width="0.0508" layer="21"/>
<wire x1="6.985" y1="5.715" x2="6.985" y2="-5.715" width="0.0508" layer="21"/>
<wire x1="6.985" y1="5.715" x2="-6.985" y2="5.715" width="0.0508" layer="21"/>
<wire x1="-6.985" y1="-5.715" x2="-6.985" y2="5.715" width="0.0508" layer="21"/>
<wire x1="0" y1="14.605" x2="3.1431" y2="13.3031" width="0.1524" layer="21" curve="-45.0001"/>
<wire x1="-3.1431" y1="13.3031" x2="0" y2="14.605" width="0.1524" layer="21" curve="-45.0001"/>
<wire x1="7.62" y1="9.525" x2="3.1242" y2="13.335" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-5.715" x2="7.62" y2="-6.35" width="0.0508" layer="51"/>
<wire x1="6.985" y1="5.715" x2="7.62" y2="6.35" width="0.0508" layer="51"/>
<wire x1="-6.985" y1="5.715" x2="-7.62" y2="6.35" width="0.0508" layer="51"/>
<wire x1="-6.985" y1="-5.715" x2="-7.62" y2="-6.35" width="0.0508" layer="51"/>
<circle x="0" y="10.16" radius="2.159" width="0.1524" layer="21"/>
<circle x="0" y="10.16" radius="5.08" width="0" layer="42"/>
<circle x="0" y="10.16" radius="5.08" width="0" layer="43"/>
<pad name="B" x="-5.461" y="-10.16" drill="1.397" shape="long" rot="R90"/>
<pad name="C" x="0" y="-10.16" drill="1.397" shape="long" rot="R90"/>
<pad name="E" x="5.461" y="-10.16" drill="1.397" shape="long" rot="R90"/>
<text x="-5.08" y="2.54" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="0" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.477" y="6.604" size="1.016" layer="21" ratio="10">A20,3mm</text>
<rectangle x1="-6.096" y1="-7.366" x2="-4.318" y2="-6.35" layer="21"/>
<rectangle x1="4.318" y1="-7.366" x2="6.096" y2="-6.35" layer="21"/>
<rectangle x1="-1.143" y1="-7.366" x2="1.143" y2="-6.35" layer="21"/>
<rectangle x1="-6.096" y1="-8.128" x2="-4.826" y2="-6.35" layer="21"/>
<rectangle x1="-0.635" y1="-8.128" x2="0.635" y2="-6.35" layer="21"/>
<rectangle x1="4.826" y1="-8.128" x2="6.096" y2="-6.35" layer="21"/>
<rectangle x1="-6.096" y1="-10.287" x2="-4.826" y2="-8.128" layer="51"/>
<rectangle x1="-0.635" y1="-10.287" x2="0.635" y2="-8.128" layer="51"/>
<rectangle x1="4.826" y1="-10.287" x2="6.096" y2="-8.128" layer="51"/>
<hole x="0" y="10.16" drill="4.1148"/>
</package>
<package name="SOT93V">
<wire x1="7.62" y1="-2.032" x2="3.429" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-2.032" x2="2.032" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-2.032" x2="-2.032" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="-2.032" y1="-2.032" x2="-3.429" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.032" x2="-7.62" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="-7.62" y1="0" x2="7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-7.239" y1="-5.08" x2="7.239" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="-2.032" x2="-7.239" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0" x2="7.62" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-2.032" x2="7.239" y2="-5.08" width="0.1524" layer="21"/>
<pad name="B" x="-5.461" y="-2.54" drill="1.397" shape="long" rot="R90"/>
<pad name="C" x="0" y="-2.54" drill="1.397" shape="long" rot="R90"/>
<pad name="E" x="5.461" y="-2.54" drill="1.397" shape="long" rot="R90"/>
<text x="-1.397" y="-6.858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-7.62" y="-6.858" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-7.62" y1="-2.032" x2="7.62" y2="0" layer="51"/>
</package>
<package name="TO126">
<description>&lt;b&gt;TO 126 horizontal&lt;/b&gt;</description>
<wire x1="-3.937" y1="-1.27" x2="-3.937" y2="9.144" width="0.127" layer="21"/>
<wire x1="-3.937" y1="9.144" x2="3.937" y2="9.144" width="0.127" layer="21"/>
<wire x1="3.937" y1="9.144" x2="3.937" y2="-1.27" width="0.127" layer="21"/>
<wire x1="-3.937" y1="-1.27" x2="3.937" y2="-1.27" width="0.127" layer="21"/>
<wire x1="1.2393" y1="3.1591" x2="1.9493" y2="3.8858" width="0.127" layer="21" curve="25.6775"/>
<wire x1="0.7687" y1="3.6188" x2="1.2393" y2="3.1591" width="0.127" layer="21"/>
<wire x1="-0.7687" y1="3.6188" x2="-1.2393" y2="3.1591" width="0.127" layer="21"/>
<wire x1="-1.4787" y1="4.3456" x2="-1.9493" y2="3.8858" width="0.127" layer="21"/>
<wire x1="-1.9493" y1="3.8858" x2="-1.2393" y2="3.1591" width="0.127" layer="21" curve="25.6775"/>
<wire x1="0.508" y1="6.6509" x2="0.508" y2="7.3088" width="0.127" layer="21"/>
<wire x1="-0.508" y1="6.6509" x2="-0.508" y2="7.3088" width="0.127" layer="21"/>
<wire x1="-0.508" y1="7.3088" x2="0.508" y2="7.3088" width="0.127" layer="21" curve="-25.6796"/>
<wire x1="1.4787" y1="4.3456" x2="1.9493" y2="3.8858" width="0.127" layer="21"/>
<circle x="-3.1242" y="-0.4826" radius="0.4318" width="0" layer="21"/>
<circle x="0" y="5.08" radius="3.81" width="0" layer="42"/>
<circle x="0" y="5.08" radius="3.81" width="0" layer="43"/>
<circle x="0" y="5.08" radius="1.651" width="0.127" layer="21"/>
<pad name="1" x="-2.286" y="-5.08" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.286" y="-5.08" drill="1.1176" shape="long" rot="R90"/>
<text x="-2.54" y="7.62" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="1.397" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-2.54" y="-0.889" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.508" y="-0.889" size="1.27" layer="51" ratio="10">2</text>
<text x="1.778" y="-0.889" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-0.635" y1="-3.048" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="-2.667" y1="-3.429" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="-2.667" y1="-5.207" x2="-1.905" y2="-3.429" layer="51"/>
<rectangle x1="-0.381" y1="-3.429" x2="0.381" y2="-1.27" layer="21"/>
<rectangle x1="-0.381" y1="-5.207" x2="0.381" y2="-3.429" layer="51"/>
<rectangle x1="1.905" y1="-3.429" x2="2.667" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-5.207" x2="2.667" y2="-3.429" layer="51"/>
<hole x="0" y="5.08" drill="3.302"/>
</package>
<package name="TO126V">
<description>&lt;b&gt;TO 126 vertical&lt;/b&gt;</description>
<wire x1="-3.937" y1="-0.127" x2="-3.937" y2="-1.27" width="0.127" layer="21"/>
<wire x1="-3.937" y1="-1.27" x2="-3.683" y2="-2.794" width="0.127" layer="21"/>
<wire x1="3.683" y1="-2.794" x2="3.937" y2="-1.27" width="0.127" layer="21"/>
<wire x1="3.937" y1="-1.27" x2="3.937" y2="-0.127" width="0.127" layer="21"/>
<wire x1="-3.683" y1="-2.794" x2="-2.794" y2="-2.794" width="0.127" layer="21"/>
<wire x1="-2.794" y1="-2.794" x2="-1.778" y2="-2.794" width="0.127" layer="51"/>
<wire x1="-1.778" y1="-2.794" x2="-0.508" y2="-2.794" width="0.127" layer="21"/>
<wire x1="-0.508" y1="-2.794" x2="0.508" y2="-2.794" width="0.127" layer="51"/>
<wire x1="0.508" y1="-2.794" x2="1.778" y2="-2.794" width="0.127" layer="21"/>
<wire x1="1.778" y1="-2.794" x2="2.794" y2="-2.794" width="0.127" layer="51"/>
<wire x1="2.794" y1="-2.794" x2="3.683" y2="-2.794" width="0.127" layer="21"/>
<circle x="-3.175" y="-2.159" radius="0.4064" width="0.127" layer="51"/>
<pad name="1" x="-2.286" y="-1.27" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="-1.27" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="2.286" y="-1.27" drill="1.016" shape="long" rot="R90"/>
<text x="-3.9624" y="-4.5466" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.9878" y="-6.3246" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-2.54" y="-1.905" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.381" y="-1.905" size="1.27" layer="51" ratio="10">2</text>
<text x="2.032" y="-1.905" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-3.937" y1="-0.381" x2="-3.175" y2="0" layer="21"/>
<rectangle x1="-1.397" y1="-0.381" x2="-0.889" y2="0" layer="21"/>
<rectangle x1="0.889" y1="-0.381" x2="1.397" y2="0" layer="21"/>
<rectangle x1="3.175" y1="-0.381" x2="3.937" y2="0" layer="21"/>
<rectangle x1="-3.175" y1="-0.381" x2="-1.397" y2="0" layer="51"/>
<rectangle x1="-0.889" y1="-0.381" x2="0.889" y2="0" layer="51"/>
<rectangle x1="1.397" y1="-0.381" x2="3.175" y2="0" layer="51"/>
</package>
<package name="TO218">
<description>&lt;b&gt;TO 218 horizontal&lt;/b&gt;</description>
<wire x1="-7.62" y1="-6.35" x2="7.62" y2="-6.35" width="0.127" layer="21"/>
<wire x1="7.62" y1="6.223" x2="7.62" y2="0" width="0.127" layer="21"/>
<wire x1="7.62" y1="0" x2="7.62" y2="-3.81" width="0.127" layer="21"/>
<wire x1="7.62" y1="-3.81" x2="7.62" y2="-6.35" width="0.127" layer="21"/>
<wire x1="-7.62" y1="-6.35" x2="-7.62" y2="-3.81" width="0.127" layer="21"/>
<wire x1="-7.62" y1="-3.81" x2="-7.62" y2="0" width="0.127" layer="21"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="6.223" width="0.127" layer="21"/>
<wire x1="7.62" y1="6.223" x2="-7.62" y2="6.223" width="0.127" layer="21"/>
<wire x1="6.985" y1="0.508" x2="6.985" y2="5.715" width="0.0508" layer="21"/>
<wire x1="7.62" y1="12.065" x2="5.08" y2="14.605" width="0.127" layer="21"/>
<wire x1="7.62" y1="12.065" x2="7.62" y2="6.223" width="0.127" layer="21"/>
<wire x1="5.08" y1="14.605" x2="-5.08" y2="14.605" width="0.127" layer="21"/>
<wire x1="-7.62" y1="12.065" x2="-5.08" y2="14.605" width="0.127" layer="21"/>
<wire x1="-7.62" y1="12.065" x2="-7.62" y2="6.223" width="0.127" layer="21"/>
<wire x1="7.62" y1="0" x2="7.62" y2="-3.81" width="0.127" layer="21" curve="180"/>
<wire x1="6.985" y1="-5.715" x2="6.985" y2="-4.318" width="0.0508" layer="21"/>
<wire x1="6.9522" y1="0.4991" x2="6.9851" y2="-4.3178" width="0.0508" layer="21" curve="149.733"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="-3.81" width="0.127" layer="21" curve="-180"/>
<wire x1="-6.985" y1="-5.715" x2="-6.985" y2="-4.318" width="0.0508" layer="21"/>
<wire x1="-6.985" y1="0.508" x2="-6.985" y2="5.715" width="0.0508" layer="21"/>
<wire x1="-6.985" y1="-4.318" x2="-6.985" y2="0.508" width="0.0508" layer="21" curve="150.513"/>
<circle x="0" y="10.16" radius="2.159" width="0.127" layer="21"/>
<pad name="1" x="-5.461" y="-10.16" drill="1.397" shape="long" rot="R90"/>
<pad name="2" x="0" y="-10.16" drill="1.397" shape="long" rot="R90"/>
<pad name="3" x="5.461" y="-10.16" drill="1.397" shape="long" rot="R90"/>
<text x="-5.08" y="-5.08" size="1.27" layer="21" ratio="10">1</text>
<text x="-0.635" y="-5.08" size="1.27" layer="21" ratio="10">2</text>
<text x="4.445" y="-5.08" size="1.27" layer="21" ratio="10">3</text>
</package>
<package name="TO218V">
<description>&lt;b&gt;TO 218 vertical&lt;/b&gt;</description>
<wire x1="-6.985" y1="-5.08" x2="6.985" y2="-5.08" width="0.127" layer="21"/>
<wire x1="6.985" y1="-5.08" x2="7.366" y2="-4.699" width="0.127" layer="21"/>
<wire x1="7.366" y1="-4.699" x2="7.62" y2="-1.524" width="0.127" layer="21"/>
<wire x1="-6.985" y1="-5.08" x2="-7.366" y2="-4.699" width="0.127" layer="21"/>
<wire x1="-7.366" y1="-4.699" x2="-7.62" y2="-1.524" width="0.127" layer="21"/>
<pad name="1" x="-5.461" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<pad name="2" x="0" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<pad name="3" x="5.461" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<text x="-1.016" y="-6.858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.096" y="-4.445" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="-4.445" size="1.27" layer="51" ratio="10">2</text>
<text x="4.826" y="-4.445" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-7.874" y1="-1.143" x2="7.874" y2="0" layer="21"/>
<rectangle x1="-3.556" y1="-2.032" x2="-1.905" y2="-1.143" layer="21"/>
<rectangle x1="1.905" y1="-2.032" x2="3.556" y2="-1.143" layer="21"/>
<rectangle x1="-7.874" y1="-2.032" x2="-7.239" y2="-1.143" layer="21"/>
<rectangle x1="7.239" y1="-2.032" x2="7.874" y2="-1.143" layer="21"/>
<rectangle x1="3.556" y1="-2.032" x2="7.239" y2="-1.143" layer="51"/>
<rectangle x1="-7.239" y1="-2.032" x2="-3.556" y2="-1.143" layer="51"/>
<rectangle x1="-1.905" y1="-2.032" x2="1.905" y2="-1.143" layer="51"/>
</package>
<package name="TO220">
<description>&lt;b&gt;TO 220 horizontal&lt;/b&gt;</description>
<wire x1="-5.207" y1="-1.27" x2="5.207" y2="-1.27" width="0.127" layer="21"/>
<wire x1="5.207" y1="14.605" x2="-5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="5.207" y1="-1.27" x2="5.207" y2="11.176" width="0.127" layer="21"/>
<wire x1="5.207" y1="11.176" x2="4.318" y2="11.176" width="0.127" layer="21"/>
<wire x1="4.318" y1="11.176" x2="4.318" y2="12.7" width="0.127" layer="21"/>
<wire x1="4.318" y1="12.7" x2="5.207" y2="12.7" width="0.127" layer="21"/>
<wire x1="5.207" y1="12.7" x2="5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="11.176" width="0.127" layer="21"/>
<wire x1="-5.207" y1="11.176" x2="-4.318" y2="11.176" width="0.127" layer="21"/>
<wire x1="-4.318" y1="11.176" x2="-4.318" y2="12.7" width="0.127" layer="21"/>
<wire x1="-4.318" y1="12.7" x2="-5.207" y2="12.7" width="0.127" layer="21"/>
<wire x1="-5.207" y1="12.7" x2="-5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<circle x="0" y="11.176" radius="1.8034" width="0.127" layer="21"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="42"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="43"/>
<pad name="1" x="-2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<text x="-3.81" y="5.207" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.937" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="7.874" size="0.9906" layer="21" ratio="12">A17,5mm</text>
<text x="-3.175" y="0" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="0" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="0" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="2.159" y1="-4.699" x2="2.921" y2="-4.064" layer="21"/>
<rectangle x1="-0.381" y1="-4.699" x2="0.381" y2="-4.064" layer="21"/>
<rectangle x1="-2.921" y1="-4.699" x2="-2.159" y2="-4.064" layer="21"/>
<rectangle x1="-3.175" y1="-4.064" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="-0.635" y1="-4.064" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-4.064" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="-2.921" y1="-6.604" x2="-2.159" y2="-4.699" layer="51"/>
<rectangle x1="-0.381" y1="-6.604" x2="0.381" y2="-4.699" layer="51"/>
<rectangle x1="2.159" y1="-6.604" x2="2.921" y2="-4.699" layer="51"/>
<hole x="0" y="11.176" drill="3.302"/>
</package>
<package name="TO220V">
<description>&lt;b&gt;TO 220 vertical&lt;/b&gt;</description>
<wire x1="5.08" y1="-1.143" x2="4.953" y2="-4.064" width="0.127" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="4.953" y2="-4.064" width="0.127" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="-4.699" y2="-4.318" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-4.699" y2="-4.318" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-5.08" y2="-1.143" width="0.127" layer="21"/>
<circle x="-4.4958" y="-3.7084" radius="0.254" width="0.127" layer="21"/>
<pad name="1" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-5.08" y="-6.0452" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.334" y1="-0.762" x2="5.334" y2="0" layer="21"/>
<rectangle x1="-5.334" y1="-1.27" x2="-3.429" y2="-0.762" layer="21"/>
<rectangle x1="-1.651" y1="-1.27" x2="-0.889" y2="-0.762" layer="21"/>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="-0.762" layer="51"/>
<rectangle x1="0.889" y1="-1.27" x2="1.651" y2="-0.762" layer="21"/>
<rectangle x1="3.429" y1="-1.27" x2="5.334" y2="-0.762" layer="21"/>
<rectangle x1="-0.889" y1="-1.27" x2="0.889" y2="-0.762" layer="51"/>
<rectangle x1="1.651" y1="-1.27" x2="3.429" y2="-0.762" layer="51"/>
</package>
<package name="TO225AA">
<description>&lt;b&gt;TO-225&lt;/b&gt;&lt;p&gt;
grid 2.54 mm, vertical</description>
<wire x1="-3.4925" y1="-6.985" x2="-3.4925" y2="3.81" width="0.127" layer="21"/>
<wire x1="-3.4925" y1="3.81" x2="3.4925" y2="3.81" width="0.127" layer="21"/>
<wire x1="3.4925" y1="3.81" x2="3.4925" y2="-6.985" width="0.127" layer="21"/>
<wire x1="-3.4925" y1="-6.985" x2="3.4925" y2="-6.985" width="0.127" layer="21"/>
<wire x1="-2.381" y1="-8.096" x2="-2.381" y2="-9.525" width="0.4064" layer="21"/>
<wire x1="0" y1="-7.779" x2="0" y2="-9.525" width="0.4064" layer="21"/>
<wire x1="2.3813" y1="-8.0963" x2="2.381" y2="-9.525" width="0.4064" layer="21"/>
<wire x1="-2.54" y1="3.175" x2="-2.54" y2="-3.334" width="0.127" layer="51"/>
<wire x1="-2.54" y1="-3.334" x2="2.54" y2="-3.334" width="0.127" layer="51"/>
<wire x1="2.54" y1="-3.334" x2="2.54" y2="3.175" width="0.127" layer="51"/>
<wire x1="2.54" y1="3.175" x2="-2.54" y2="3.175" width="0.127" layer="51"/>
<wire x1="-1.949" y1="1.194" x2="-1.2391" y2="1.9206" width="0.127" layer="21" curve="-25.6749"/>
<wire x1="-0.769" y1="1.461" x2="-1.239" y2="1.921" width="0.127" layer="21"/>
<wire x1="0.769" y1="1.461" x2="1.239" y2="1.921" width="0.127" layer="21"/>
<wire x1="1.479" y1="0.734" x2="1.949" y2="1.194" width="0.127" layer="21"/>
<wire x1="1.239" y1="1.921" x2="1.949" y2="1.1944" width="0.127" layer="21" curve="-25.6741"/>
<wire x1="-0.508" y1="-1.571" x2="-0.508" y2="-2.229" width="0.127" layer="21"/>
<wire x1="0.508" y1="-1.571" x2="0.508" y2="-2.229" width="0.127" layer="21"/>
<wire x1="-0.508" y1="-2.229" x2="0.508" y2="-2.229" width="0.127" layer="21" curve="25.6785"/>
<wire x1="-1.479" y1="0.734" x2="-1.949" y2="1.194" width="0.127" layer="21"/>
<circle x="0" y="0" radius="3.81" width="0" layer="42"/>
<circle x="0" y="0" radius="3.81" width="0" layer="43"/>
<circle x="0" y="0" radius="1.651" width="0.127" layer="21"/>
<pad name="1" x="-2.3813" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="0" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="2.3813" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.6988" y="-6.6675" size="1.27" layer="51">1</text>
<text x="-0.4763" y="-6.6675" size="1.27" layer="51">2</text>
<text x="1.905" y="-6.6675" size="1.27" layer="51">3</text>
<text x="3.0163" y="5.3975" size="1.27" layer="25" ratio="10" rot="R180">&gt;NAME</text>
<text x="3.4925" y="-3.7783" size="1.27" layer="27" ratio="10" rot="R180">&gt;VALUE</text>
<rectangle x1="-2.6988" y1="-8.255" x2="-2.0638" y2="-6.985" layer="21"/>
<rectangle x1="2.0638" y1="-8.255" x2="2.6988" y2="-6.985" layer="21"/>
<rectangle x1="-0.3175" y1="-7.9375" x2="0.3175" y2="-6.985" layer="21"/>
<hole x="0" y="0" drill="3.302"/>
</package>
<package name="TO39">
<description>&lt;b&gt;TO-39&lt;/b&gt;</description>
<wire x1="-4.0386" y1="-3.5306" x2="-3.5052" y2="-2.9972" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="-3.5306" x2="-3.5052" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="-4.064" x2="-4.0386" y2="-3.5306" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="4.572" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.8608" width="0.0508" layer="21"/>
<pad name="1" x="0" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="3" x="0" y="2.54" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="5.08" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TO5">
<description>&lt;b&gt;TO 5&lt;/b&gt;</description>
<wire x1="-4.0386" y1="-3.5306" x2="-3.5052" y2="-2.9972" width="0.127" layer="21"/>
<wire x1="-2.9718" y1="-3.5306" x2="-3.5052" y2="-4.064" width="0.127" layer="21"/>
<wire x1="-3.5052" y1="-4.064" x2="-4.0386" y2="-3.5306" width="0.127" layer="21"/>
<circle x="0" y="0" radius="4.572" width="0.127" layer="21"/>
</package>
<package name="TO66">
<description>&lt;b&gt;TO-66&lt;/b&gt;</description>
<wire x1="-3.501" y1="-7.895" x2="3.5012" y2="-7.895" width="0.1524" layer="21" curve="47.8332"/>
<wire x1="-3.501" y1="7.895" x2="3.5012" y2="7.895" width="0.1524" layer="21" curve="-47.8332"/>
<wire x1="-13.711" y1="3.3666" x2="-13.711" y2="-3.367" width="0.1524" layer="21" curve="132.168"/>
<wire x1="-3.501" y1="-7.895" x2="-13.711" y2="-3.367" width="0.1524" layer="21"/>
<wire x1="-3.501" y1="7.895" x2="-13.711" y2="3.367" width="0.1524" layer="21"/>
<wire x1="13.711" y1="-3.367" x2="13.711" y2="3.3666" width="0.1524" layer="21" curve="132.168"/>
<wire x1="3.501" y1="-7.895" x2="13.711" y2="-3.367" width="0.1524" layer="21"/>
<wire x1="3.501" y1="7.895" x2="13.711" y2="3.367" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="7.874" width="0.0508" layer="21"/>
<circle x="0" y="0" radius="6.35" width="0.1524" layer="21"/>
<circle x="-12.192" y="0" radius="1.905" width="0.1524" layer="51"/>
<circle x="12.192" y="0" radius="1.905" width="0.1524" layer="51"/>
<pad name="TO66" x="-12.192" y="0" drill="3.302" diameter="6.35"/>
<pad name="3" x="12.192" y="0" drill="3.302" diameter="6.35"/>
<pad name="2" x="-2.54" y="2.54" drill="1.1176" diameter="2.54" shape="long"/>
<pad name="1" x="-2.54" y="-2.54" drill="1.1176" diameter="2.54" shape="long"/>
<text x="8.89" y="-4.445" size="1.27" layer="21" ratio="10">3</text>
<text x="1.27" y="-2.54" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="3.175" y="-3.175" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-5.08" y="1.905" size="1.27" layer="21" ratio="10">2</text>
<text x="-5.08" y="-3.175" size="1.27" layer="21" ratio="10">1</text>
</package>
<package name="TO92">
<description>&lt;b&gt;TO 92&lt;/b&gt;</description>
<wire x1="-2.0946" y1="-1.651" x2="-2.6549" y2="-0.254" width="0.127" layer="21" curve="-32.781"/>
<wire x1="-2.6549" y1="-0.254" x2="-0.7863" y2="2.5485" width="0.127" layer="21" curve="-78.3185"/>
<wire x1="0.7863" y1="2.5484" x2="2.0945" y2="-1.651" width="0.127" layer="21" curve="-111.1"/>
<wire x1="-2.0945" y1="-1.651" x2="2.0945" y2="-1.651" width="0.127" layer="21"/>
<wire x1="-2.2537" y1="-0.254" x2="-0.2863" y2="-0.254" width="0.127" layer="51"/>
<wire x1="-2.6549" y1="-0.254" x2="-2.2537" y2="-0.254" width="0.127" layer="21"/>
<wire x1="-0.2863" y1="-0.254" x2="0.2863" y2="-0.254" width="0.127" layer="21"/>
<wire x1="2.2537" y1="-0.254" x2="2.6549" y2="-0.254" width="0.127" layer="21"/>
<wire x1="0.2863" y1="-0.254" x2="2.2537" y2="-0.254" width="0.127" layer="51"/>
<wire x1="-0.7863" y1="2.5485" x2="0.7863" y2="2.5485" width="0.127" layer="51" curve="-34.2936"/>
<pad name="1" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="3" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="3.175" y="0.635" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.175" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.635" y="0.635" size="1.27" layer="51" ratio="10">2</text>
<text x="-2.159" y="0" size="1.27" layer="51" ratio="10">3</text>
<text x="1.143" y="0" size="1.27" layer="51" ratio="10">1</text>
</package>
<package name="TO92-EBC">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads In Line E B C from top&lt;p&gt;</description>
<wire x1="-2.095" y1="-2.921" x2="2.095" y2="-2.921" width="0.127" layer="21"/>
<wire x1="-2.413" y1="-0.1341" x2="2.413" y2="-0.1341" width="0.127" layer="21" curve="-129.583"/>
<wire x1="1.136" y1="-1.397" x2="-1.136" y2="-1.397" width="0.127" layer="51"/>
<wire x1="-2.413" y1="-0.1341" x2="-2.664" y2="-1.397" width="0.127" layer="51" curve="27.9376"/>
<wire x1="-2.664" y1="-1.397" x2="-2.413" y2="-2.4059" width="0.127" layer="51" curve="22.4788"/>
<wire x1="-1.404" y1="-1.397" x2="-2.664" y2="-1.397" width="0.127" layer="51"/>
<wire x1="-2.4135" y1="-2.4059" x2="-2.095" y2="-2.921" width="0.127" layer="21" curve="13.0385"/>
<wire x1="-1.136" y1="-1.397" x2="-1.404" y2="-1.397" width="0.127" layer="21"/>
<wire x1="2.413" y1="-2.4059" x2="2.664" y2="-1.397" width="0.127" layer="51" curve="22.4788"/>
<wire x1="2.664" y1="-1.397" x2="2.413" y2="-0.1341" width="0.127" layer="51" curve="27.9376"/>
<wire x1="2.664" y1="-1.397" x2="1.404" y2="-1.397" width="0.127" layer="51"/>
<wire x1="1.404" y1="-1.397" x2="1.136" y2="-1.397" width="0.127" layer="21"/>
<wire x1="2.095" y1="-2.921" x2="2.4247" y2="-2.3818" width="0.127" layer="21" curve="13.6094"/>
<pad name="C" x="2.54" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="-2.54" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<pad name="B" x="0" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.54" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-4.572" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TO92-E1">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads Triangle Reverse</description>
<wire x1="-2.095" y1="-1.651" x2="-0.7869" y2="2.5484" width="0.127" layer="21" curve="-111.098"/>
<wire x1="0.7869" y1="2.5484" x2="2.095" y2="-1.651" width="0.127" layer="21" curve="-111.098"/>
<wire x1="-2.095" y1="-1.651" x2="2.095" y2="-1.651" width="0.127" layer="21"/>
<wire x1="-2.254" y1="-0.254" x2="-0.286" y2="-0.254" width="0.127" layer="51"/>
<wire x1="-2.655" y1="-0.254" x2="-2.254" y2="-0.254" width="0.127" layer="21"/>
<wire x1="-0.286" y1="-0.254" x2="0.286" y2="-0.254" width="0.127" layer="21"/>
<wire x1="2.254" y1="-0.254" x2="2.655" y2="-0.254" width="0.127" layer="21"/>
<wire x1="0.286" y1="-0.254" x2="2.254" y2="-0.254" width="0.127" layer="51"/>
<wire x1="-0.7864" y1="2.5484" x2="0.7864" y2="2.5484" width="0.127" layer="51" curve="-34.299"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="3" x="1.27" y="0" drill="0.8128" shape="octagon"/>
</package>
<package name="TO92L">
<description>&lt;b&gt;TO-92&lt;/b&gt;&lt;p&gt;
grid 5.08 mm</description>
<wire x1="-1.1359" y1="2.413" x2="-0.127" y2="2.664" width="0.1524" layer="51" curve="-22.4788"/>
<wire x1="-0.127" y1="2.664" x2="1.1359" y2="2.413" width="0.1524" layer="51" curve="-27.9376"/>
<wire x1="-1.1359" y1="-2.413" x2="-0.127" y2="-2.664" width="0.1524" layer="51" curve="22.4788"/>
<wire x1="-0.127" y1="-2.664" x2="1.1359" y2="-2.413" width="0.1524" layer="51" curve="27.9376"/>
<wire x1="-1.651" y1="2.095" x2="-1.651" y2="-2.095" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="-1.404" x2="-0.127" y2="1.404" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="-2.664" x2="-0.127" y2="-1.404" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-2.095" x2="-1.1118" y2="-2.4247" width="0.1524" layer="21" curve="13.6094"/>
<wire x1="-0.127" y1="1.404" x2="-0.127" y2="2.664" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="2.095" x2="-1.1359" y2="2.4135" width="0.1524" layer="21" curve="-13.0385"/>
<wire x1="2.413" y1="-1.1359" x2="2.413" y2="1.1359" width="0.1524" layer="51" curve="50.4167"/>
<wire x1="1.1359" y1="-2.413" x2="2.413" y2="-1.1359" width="0.1524" layer="21" curve="39.5833"/>
<wire x1="1.1359" y1="2.413" x2="2.413" y2="1.1359" width="0.1524" layer="21" curve="-39.5833"/>
<pad name="1" x="0" y="-2.54" drill="0.8128" shape="long"/>
<pad name="3" x="0" y="2.54" drill="0.8128" shape="long"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="long"/>
<text x="-1.524" y="3.556" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-4.953" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TOP3">
<description>&lt;b&gt;TOP 3 horizontal&lt;/b&gt;</description>
<wire x1="-7.874" y1="-1.778" x2="7.874" y2="-1.778" width="0.127" layer="21"/>
<wire x1="7.874" y1="8.763" x2="7.874" y2="-1.778" width="0.127" layer="21"/>
<wire x1="-7.874" y1="-1.778" x2="-7.874" y2="8.763" width="0.127" layer="21"/>
<wire x1="-7.874" y1="8.763" x2="-7.874" y2="11.811" width="0.127" layer="21"/>
<wire x1="-7.874" y1="11.811" x2="-3.1242" y2="15.8496" width="0.127" layer="21"/>
<wire x1="7.874" y1="8.763" x2="-7.874" y2="8.763" width="0.127" layer="21"/>
<wire x1="7.874" y1="8.763" x2="7.874" y2="11.811" width="0.127" layer="21"/>
<wire x1="-7.366" y1="-1.27" x2="7.366" y2="-1.27" width="0.0508" layer="21"/>
<wire x1="7.366" y1="8.255" x2="7.366" y2="-1.27" width="0.0508" layer="21"/>
<wire x1="7.366" y1="8.255" x2="-7.366" y2="8.255" width="0.0508" layer="21"/>
<wire x1="-7.366" y1="-1.27" x2="-7.366" y2="8.255" width="0.0508" layer="21"/>
<wire x1="0" y1="17.145" x2="3.1431" y2="15.8431" width="0.127" layer="21" curve="-45.0001"/>
<wire x1="-3.1431" y1="15.8431" x2="0" y2="17.145" width="0.127" layer="21" curve="-45.0001"/>
<wire x1="7.874" y1="11.811" x2="3.1242" y2="15.875" width="0.127" layer="21"/>
<circle x="0" y="12.7" radius="2.159" width="0.127" layer="21"/>
<circle x="0" y="12.7" radius="5.08" width="0" layer="42"/>
<circle x="0" y="12.7" radius="5.08" width="0" layer="43"/>
<pad name="1" x="-5.588" y="-7.62" drill="1.397" shape="long" rot="R90"/>
<pad name="2" x="0" y="-7.62" drill="1.397" shape="long" rot="R90"/>
<pad name="3" x="5.588" y="-7.62" drill="1.397" shape="long" rot="R90"/>
<text x="-5.08" y="5.08" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-7.366" y="9.144" size="0.9906" layer="21" ratio="12">A20,3mm</text>
<text x="-5.715" y="-0.635" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="-0.635" size="1.27" layer="51" ratio="10">2</text>
<text x="4.445" y="-0.635" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-6.223" y1="-3.81" x2="-3.81" y2="-1.778" layer="21"/>
<rectangle x1="-1.397" y1="-3.81" x2="1.397" y2="-1.778" layer="21"/>
<rectangle x1="3.81" y1="-3.81" x2="6.223" y2="-1.778" layer="21"/>
<rectangle x1="-6.223" y1="-5.715" x2="-4.953" y2="-3.81" layer="21"/>
<rectangle x1="-6.223" y1="-7.62" x2="-4.953" y2="-5.715" layer="51"/>
<rectangle x1="-0.635" y1="-5.715" x2="0.635" y2="-3.81" layer="21"/>
<rectangle x1="-0.635" y1="-7.62" x2="0.635" y2="-5.715" layer="51"/>
<rectangle x1="4.953" y1="-5.715" x2="6.223" y2="-3.81" layer="21"/>
<rectangle x1="4.953" y1="-7.62" x2="6.223" y2="-5.715" layer="51"/>
<hole x="0" y="12.7" drill="4.1148"/>
</package>
<package name="TOP3V">
<description>&lt;b&gt;TOP 3 vertical&lt;/b&gt;</description>
<wire x1="7.366" y1="-4.699" x2="7.493" y2="-1.524" width="0.127" layer="21"/>
<wire x1="-7.366" y1="-4.699" x2="-7.493" y2="-1.524" width="0.127" layer="21"/>
<wire x1="6.985" y1="-5.08" x2="6.35" y2="-5.08" width="0.127" layer="21"/>
<wire x1="6.35" y1="-5.08" x2="4.572" y2="-5.08" width="0.127" layer="51"/>
<wire x1="4.572" y1="-5.08" x2="0.889" y2="-5.08" width="0.127" layer="21"/>
<wire x1="0.889" y1="-5.08" x2="-0.889" y2="-5.08" width="0.127" layer="51"/>
<wire x1="-0.889" y1="-5.08" x2="-4.572" y2="-5.08" width="0.127" layer="21"/>
<wire x1="-4.572" y1="-5.08" x2="-6.35" y2="-5.08" width="0.127" layer="51"/>
<wire x1="-6.35" y1="-5.08" x2="-6.985" y2="-5.08" width="0.127" layer="21"/>
<pad name="B" x="-5.461" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<pad name="C" x="0" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<pad name="E" x="5.461" y="-3.175" drill="1.397" shape="long" rot="R90"/>
<text x="-1.524" y="-6.858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.096" y="-4.445" size="1.27" layer="51" ratio="10">B</text>
<text x="-0.635" y="-4.445" size="1.27" layer="51" ratio="10">C</text>
<text x="4.826" y="-4.445" size="1.27" layer="51" ratio="10">E</text>
<rectangle x1="-7.874" y1="-1.524" x2="-6.858" y2="-1.143" layer="21"/>
<rectangle x1="-4.064" y1="-1.524" x2="-1.397" y2="-1.143" layer="21"/>
<rectangle x1="1.397" y1="-1.524" x2="4.064" y2="-1.143" layer="21"/>
<rectangle x1="6.858" y1="-1.524" x2="7.874" y2="-1.143" layer="21"/>
<rectangle x1="-6.858" y1="-1.524" x2="-4.064" y2="-1.143" layer="51"/>
<rectangle x1="-1.397" y1="-1.524" x2="1.397" y2="-1.143" layer="51"/>
<rectangle x1="4.064" y1="-1.524" x2="6.858" y2="-1.143" layer="51"/>
</package>
<package name="SOT23-BEC">
<description>TO-236 ITT Intermetall</description>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.127" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.127" layer="51"/>
<smd name="C" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="E" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="B" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2286" y1="0.7112" x2="0.2286" y2="1.2954" layer="51"/>
<rectangle x1="0.7112" y1="-1.2954" x2="1.1684" y2="-0.7112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.2954" x2="-0.7112" y2="-0.7112" layer="51"/>
</package>
<package name="SOT23-EBC">
<description>&lt;b&gt;SOT-23 (EBC)&lt;/b&gt;</description>
<smd name="B" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="E" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
</package>
<package name="TO92-BCE">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads In Line B C E from top&lt;p&gt;</description>
<wire x1="-2.413" y1="1.1359" x2="2.413" y2="1.1359" width="0.127" layer="21" curve="-129.583"/>
<wire x1="1.136" y1="-0.127" x2="-1.136" y2="-0.127" width="0.127" layer="51"/>
<wire x1="-2.413" y1="1.1359" x2="-2.664" y2="-0.127" width="0.127" layer="51" curve="27.9376"/>
<wire x1="-2.664" y1="-0.127" x2="-2.413" y2="-1.1359" width="0.127" layer="51" curve="22.4788"/>
<wire x1="-1.404" y1="-0.127" x2="-2.664" y2="-0.127" width="0.127" layer="51"/>
<wire x1="-2.4135" y1="-1.1359" x2="-2.095" y2="-1.651" width="0.127" layer="21" curve="13.0385"/>
<wire x1="-1.136" y1="-0.127" x2="-1.404" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.413" y1="-1.1359" x2="2.664" y2="-0.127" width="0.127" layer="51" curve="22.4788"/>
<wire x1="2.664" y1="-0.127" x2="2.413" y2="1.1359" width="0.127" layer="51" curve="27.9376"/>
<wire x1="2.664" y1="-0.127" x2="1.404" y2="-0.127" width="0.127" layer="51"/>
<wire x1="1.404" y1="-0.127" x2="1.136" y2="-0.127" width="0.127" layer="21"/>
<wire x1="2.095" y1="-1.651" x2="2.4247" y2="-1.1118" width="0.127" layer="21" curve="13.6094"/>
<pad name="C" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="B" x="-2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.54" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TO92-CBE">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads In Line  C B E from top&lt;p&gt;</description>
<pad name="C" x="-2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="B" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
</package>
<package name="TO92-BEC">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads In Line  B E C from top&lt;p&gt;</description>
<pad name="C" x="2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="0" y="0" drill="0.8128" shape="long" rot="R90"/>
</package>
<package name="TO92-CEB">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads In Line C E B from top&lt;p&gt;</description>
<pad name="B" x="2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
</package>
<package name="SC59-BEC">
<description>SC59 (SOT23) Motorola</description>
<wire x1="1.4224" y1="0.8604" x2="1.4224" y2="-0.8604" width="0.127" layer="51"/>
<wire x1="1.4224" y1="-0.8604" x2="-1.4224" y2="-0.8604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="-0.8604" x2="-1.4224" y2="0.8604" width="0.127" layer="51"/>
<wire x1="-1.4224" y1="0.8604" x2="1.4224" y2="0.8604" width="0.127" layer="51"/>
<smd name="C" x="0" y="1.2" dx="1" dy="1.4" layer="1"/>
<smd name="E" x="0.95" y="-1.2" dx="1" dy="1.4" layer="1"/>
<smd name="B" x="-0.95" y="-1.2" dx="1" dy="1.4" layer="1"/>
<rectangle x1="-0.2286" y1="0.9112" x2="0.2286" y2="1.4954" layer="51"/>
<rectangle x1="0.7112" y1="-1.4954" x2="1.1684" y2="-0.9112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.4954" x2="-0.7112" y2="-0.9112" layer="51"/>
</package>
<package name="SOT89-BCE">
<description>SOT98 Basis Collector Emitter</description>
<wire x1="2.235" y1="-1.245" x2="-2.235" y2="-1.245" width="0.127" layer="51"/>
<wire x1="2.235" y1="1.219" x2="2.235" y2="-1.245" width="0.127" layer="51"/>
<wire x1="-2.235" y1="-1.245" x2="-2.235" y2="1.219" width="0.127" layer="51"/>
<wire x1="-2.235" y1="1.219" x2="2.235" y2="1.219" width="0.127" layer="51"/>
<wire x1="-0.7874" y1="1.5748" x2="-0.3556" y2="2.0066" width="0.1998" layer="51"/>
<wire x1="-0.3556" y1="2.0066" x2="0.3556" y2="2.0066" width="0.1998" layer="51"/>
<wire x1="0.3556" y1="2.0066" x2="0.7874" y2="1.5748" width="0.1998" layer="51"/>
<wire x1="0.7874" y1="1.5748" x2="0.7874" y2="1.2954" width="0.1998" layer="51"/>
<wire x1="0.7874" y1="1.2954" x2="-0.7874" y2="1.2954" width="0.1998" layer="51"/>
<wire x1="-0.7874" y1="1.2954" x2="-0.7874" y2="1.5748" width="0.1998" layer="51"/>
<smd name="B" x="-1.499" y="-1.981" dx="0.8" dy="1.4" layer="1"/>
<smd name="E" x="1.499" y="-1.981" dx="0.8" dy="1.4" layer="1"/>
<smd name="C" x="0" y="-1.727" dx="0.8" dy="1.9" layer="1" stop="no" cream="no"/>
<text x="-2.54" y="3.175" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.4051" y="-4.3449" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7272" y1="-2.1082" x2="-1.27" y2="-1.27" layer="51"/>
<rectangle x1="1.27" y1="-2.1082" x2="1.7272" y2="-1.27" layer="51"/>
<rectangle x1="-0.2794" y1="-2.1082" x2="0.2794" y2="-1.27" layer="51"/>
<rectangle x1="-0.4" y1="-2.68" x2="0.4" y2="-1.28" layer="31"/>
<rectangle x1="-0.5" y1="-2.78" x2="0.5" y2="-1.18" layer="29"/>
<polygon width="0.1998" layer="51">
<vertex x="-0.7874" y="1.3208"/>
<vertex x="-0.7874" y="1.5748"/>
<vertex x="-0.3556" y="2.0066"/>
<vertex x="0.3048" y="2.0066"/>
<vertex x="0.3556" y="2.0066"/>
<vertex x="0.7874" y="1.5748"/>
<vertex x="0.7874" y="1.2954"/>
<vertex x="-0.7874" y="1.2954"/>
</polygon>
<polygon width="1.7" layer="29">
<vertex x="-0.275" y="2.025"/>
<vertex x="-0.275" y="-0.15"/>
<vertex x="0.25" y="-0.15"/>
<vertex x="0.25" y="2.025"/>
</polygon>
<polygon width="1.3" layer="31">
<vertex x="-0.25" y="2.05"/>
<vertex x="0.275" y="2.05"/>
<vertex x="0.275" y="-0.125"/>
<vertex x="-0.25" y="-0.125"/>
</polygon>
<polygon width="0.3" layer="1">
<vertex x="0.25" y="-2.05"/>
<vertex x="-0.25" y="-2.05"/>
<vertex x="-0.25" y="-0.75" curve="-90"/>
<vertex x="-0.875" y="-0.125"/>
<vertex x="-0.875" y="2.05" curve="-90"/>
<vertex x="-0.225" y="2.625"/>
<vertex x="0.25" y="2.625" curve="-90"/>
<vertex x="0.875" y="2.025"/>
<vertex x="0.875" y="-0.125" curve="-90"/>
<vertex x="0.25" y="-0.75"/>
</polygon>
</package>
<package name="SOT37">
<description>&lt;b&gt;SOT-37&lt;/b&gt;&lt;p&gt;
Motorola CASE 317A-01 ISSUE B&lt;br&gt;
http://www.ee.siue.edu/~alozows/library/datasheets/BFR96.pdf</description>
<wire x1="5.3086" y1="0.508" x2="5.3086" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-5.3086" x2="0.508" y2="-5.3086" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="6.5024" x2="0.508" y2="6.5024" width="0.1524" layer="51"/>
<wire x1="0.508" y1="-2.2352" x2="0.508" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-2.794" x2="0.508" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-3.048" x2="0.635" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="0.508" y1="-3.429" x2="0.635" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="0.508" y1="-3.429" x2="0.508" y2="-5.3086" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-2.2352" x2="-0.508" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-2.794" x2="-0.508" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-3.048" x2="-0.635" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-3.429" x2="-0.635" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="-3.429" x2="-0.508" y2="-5.3086" width="0.1524" layer="51"/>
<wire x1="2.2352" y1="-0.508" x2="2.794" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-0.635" x2="2.794" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-0.635" x2="3.429" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-0.508" x2="3.429" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-0.508" x2="5.3086" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="2.2098" y1="0.508" x2="2.794" y2="0.508" width="0.1524" layer="21"/>
<wire x1="2.794" y1="0.635" x2="2.794" y2="0.508" width="0.1524" layer="21"/>
<wire x1="3.048" y1="0.635" x2="3.429" y2="0.635" width="0.1524" layer="51"/>
<wire x1="3.429" y1="0.508" x2="3.429" y2="0.635" width="0.1524" layer="51"/>
<wire x1="3.429" y1="0.508" x2="5.3086" y2="0.508" width="0.1524" layer="51"/>
<wire x1="0.508" y1="2.2352" x2="0.508" y2="2.794" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.794" x2="0.508" y2="2.794" width="0.1524" layer="21"/>
<wire x1="0.635" y1="3.048" x2="0.635" y2="3.429" width="0.1524" layer="51"/>
<wire x1="0.508" y1="3.429" x2="0.635" y2="3.429" width="0.1524" layer="51"/>
<wire x1="0.508" y1="3.429" x2="0.508" y2="6.5024" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="2.2352" x2="-0.508" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.794" x2="-0.508" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="3.048" x2="-0.635" y2="3.429" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="3.429" x2="-0.635" y2="3.429" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="3.429" x2="-0.508" y2="6.5024" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-2.794" x2="-0.635" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-2.794" x2="0.635" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-0.635" x2="2.794" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="3.048" y1="0.635" x2="2.794" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.635" y1="2.794" x2="0.635" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="2.794" x2="-0.635" y2="3.048" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.286" width="0.1524" layer="21"/>
<circle x="0" y="1.524" radius="0.508" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="3.175" width="0" layer="41"/>
<circle x="0" y="0" radius="3.175" width="0" layer="42"/>
<smd name="3" x="0" y="-5.08" dx="1.9304" dy="3.81" layer="1"/>
<smd name="2" x="5.08" y="0" dx="3.81" dy="1.9304" layer="1"/>
<smd name="1" x="0" y="5.08" dx="1.9304" dy="3.81" layer="1"/>
<text x="4.445" y="1.27" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="6.35" y="1.27" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="3.175" y="-2.286" size="1.016" layer="21" ratio="10">E</text>
<text x="1.27" y="-4.191" size="1.016" layer="21" ratio="10">B</text>
<text x="1.27" y="3.175" size="1.016" layer="21" ratio="10">C</text>
<text x="-1.524" y="-4.318" size="1.27" layer="47">5,1</text>
<rectangle x1="-0.508" y1="-2.794" x2="0.508" y2="-2.413" layer="21"/>
<rectangle x1="-0.635" y1="-3.048" x2="0.635" y2="-2.794" layer="21"/>
<rectangle x1="-0.635" y1="-3.429" x2="0.635" y2="-3.048" layer="51"/>
<rectangle x1="-0.508" y1="-5.334" x2="0.508" y2="-3.429" layer="51"/>
<rectangle x1="2.413" y1="-0.508" x2="2.794" y2="0.508" layer="21"/>
<rectangle x1="2.794" y1="-0.635" x2="3.048" y2="0.635" layer="21"/>
<rectangle x1="3.048" y1="-0.635" x2="3.429" y2="0.635" layer="51"/>
<rectangle x1="3.429" y1="-0.508" x2="5.334" y2="0.508" layer="51"/>
<rectangle x1="-0.508" y1="3.429" x2="0.508" y2="6.477" layer="51"/>
<rectangle x1="-0.635" y1="3.048" x2="0.635" y2="3.429" layer="51"/>
<rectangle x1="-0.635" y1="2.794" x2="0.635" y2="3.048" layer="21"/>
<rectangle x1="-0.508" y1="2.413" x2="0.508" y2="2.794" layer="21"/>
<hole x="0" y="0" drill="5.08"/>
</package>
<package name="TO92-ECB">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads In Line E C B from top&lt;p&gt;</description>
<wire x1="-2.413" y1="1.1359" x2="-2.664" y2="-0.127" width="0.127" layer="51" curve="27.9407"/>
<wire x1="2.664" y1="-0.127" x2="2.413" y2="1.1359" width="0.127" layer="51" curve="27.9333"/>
<pad name="E" x="-2.54" y="0" drill="0.8128" shape="long" rot="R90"/>
</package>
</packages>
<symbols>
<symbol name="NPN">
<wire x1="2.54" y1="2.54" x2="0.508" y2="1.524" width="0.1524" layer="94"/>
<wire x1="1.778" y1="-1.524" x2="2.54" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="1.27" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="1.778" y2="-1.524" width="0.1524" layer="94"/>
<wire x1="1.54" y1="-2.04" x2="0.308" y2="-1.424" width="0.1524" layer="94"/>
<wire x1="1.524" y1="-2.413" x2="2.286" y2="-2.413" width="0.254" layer="94"/>
<wire x1="2.286" y1="-2.413" x2="1.778" y2="-1.778" width="0.254" layer="94"/>
<wire x1="1.778" y1="-1.778" x2="1.524" y2="-2.286" width="0.254" layer="94"/>
<wire x1="1.524" y1="-2.286" x2="1.905" y2="-2.286" width="0.254" layer="94"/>
<wire x1="1.905" y1="-2.286" x2="1.778" y2="-2.032" width="0.254" layer="94"/>
<text x="-10.16" y="7.62" size="1.778" layer="95">&gt;NAME</text>
<text x="-10.16" y="5.08" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-0.254" y1="-2.54" x2="0.508" y2="2.54" layer="94"/>
<pin name="B" x="-2.54" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
<pin name="E" x="2.54" y="-5.08" visible="off" length="short" direction="pas" swaplevel="3" rot="R90"/>
<pin name="C" x="2.54" y="5.08" visible="off" length="short" direction="pas" swaplevel="2" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="*-NPN-" prefix="T" uservalue="yes">
<description>NPN Transistror&lt;p&gt;
BF959 corrected 2008.03.06&lt;br&gt;</description>
<gates>
<gate name="G$1" symbol="NPN" x="0" y="0"/>
</gates>
<devices>
<device name="TO3/" package="TO3">
<connects>
<connect gate="G$1" pin="B" pad="B"/>
<connect gate="G$1" pin="E" pad="E"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="TO18-EBC" package="TO18">
<connects>
<connect gate="G$1" pin="B" pad="2"/>
<connect gate="G$1" pin="C" pad="3"/>
<connect gate="G$1" pin="E" pad="1"/>
</connects>
<technologies>
<technology name="2N2218"/>
<technology name="2N2222"/>
<technology name="2N2222A"/>
<technology name="2N2369"/>
<technology name="2N2369A"/>
<technology name="2N2484"/>
<technology name="2N2896"/>
<technology name="2N3700"/>
<technology name="2N930"/>
<technology name="BC107A"/>
<technology name="BC107B"/>
<technology name="BC108B"/>
<technology name="BC108C"/>
<technology name="BCY58-IX"/>
<technology name="BCY58-VIII"/>
<technology name="BCY59-VII"/>
<technology name="BCY59-VIII"/>
<technology name="BCY59-X"/>
<technology name="BSS71"/>
<technology name="BSS72"/>
<technology name="BSS73"/>
<technology name="BSX20"/>
</technologies>
</device>
<device name="TO18-" package="TO18-">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO202" package="TO202">
<connects>
<connect gate="G$1" pin="B" pad="3"/>
<connect gate="G$1" pin="C" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
<device name="TO202V" package="TO202V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOT93" package="SOT93">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOT93V" package="SOT93V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO126" package="TO126">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO126V" package="TO126V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO218" package="TO218">
<connects>
<connect gate="G$1" pin="B" pad="1"/>
<connect gate="G$1" pin="E" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
<device name="TO218V" package="TO218V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO220" package="TO220">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO220V" package="TO220V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO225AA" package="TO225AA">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO39-EBC" package="TO39">
<connects>
</connects>
<technologies>
<technology name="2N1613"/>
<technology name="2N1711"/>
<technology name="2N1893"/>
<technology name="2N2102"/>
<technology name="2N2219"/>
<technology name="2N2219A"/>
<technology name="2N3019"/>
<technology name="2N3020"/>
<technology name="2N3439"/>
<technology name="2N3440"/>
<technology name="BC140-10"/>
<technology name="BC140-16"/>
<technology name="BC141-10"/>
<technology name="BC141-16"/>
<technology name="BFY50"/>
<technology name="BSX45-16"/>
<technology name="BSX46-10"/>
<technology name="BSX46-16"/>
</technologies>
</device>
<device name="TO5" package="TO5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO66" package="TO66">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO92" package="TO92">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO92-EBC" package="TO92-EBC">
<connects>
<connect gate="G$1" pin="C" pad="C"/>
</connects>
<technologies>
<technology name="BC317"/>
<technology name="BC318"/>
<technology name="BC319"/>
</technologies>
</device>
<device name="TO92-E1" package="TO92-E1">
<connects>
<connect gate="G$1" pin="C" pad="1"/>
</connects>
<technologies>
</technologies>
</device>
<device name="TO92L" package="TO92L">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TOP3" package="TOP3">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TOP3V" package="TOP3V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOT23-BEC" package="SOT23-BEC">
<connects>
</connects>
<technologies>
<technology name="BC808"/>
<technology name="BC817"/>
<technology name="BC817-16"/>
<technology name="BC817-16LT1"/>
<technology name="BC817-25"/>
<technology name="BC817-25LT1"/>
<technology name="BC817-40"/>
<technology name="BC817-40LT1"/>
<technology name="BC818"/>
<technology name="BC818-16"/>
<technology name="BC818-25"/>
<technology name="BC818-40"/>
<technology name="BC846"/>
<technology name="BC846A"/>
<technology name="BC846ALT1"/>
<technology name="BC846B"/>
<technology name="BC846BLT1"/>
<technology name="BC847"/>
<technology name="BC847A"/>
<technology name="BC847ALT1"/>
<technology name="BC847B"/>
<technology name="BC847BLT1"/>
<technology name="BC847C"/>
<technology name="BC847CLT1"/>
<technology name="BC848"/>
<technology name="BC848A"/>
<technology name="BC848ALT1"/>
<technology name="BC848B"/>
<technology name="BC848BLT1"/>
<technology name="BC848C"/>
<technology name="BC848CLT1"/>
<technology name="BC849"/>
<technology name="BC850"/>
<technology name="BCF29"/>
<technology name="BCF30"/>
<technology name="BCF32"/>
<technology name="BCF33"/>
<technology name="BCF81"/>
<technology name="BCV71"/>
<technology name="BCV72"/>
<technology name="BCW31"/>
<technology name="BCW32"/>
<technology name="BCW33"/>
<technology name="BCW60"/>
<technology name="BCW71"/>
<technology name="BCW72"/>
<technology name="BCW81"/>
<technology name="BCX19"/>
<technology name="BCX20"/>
<technology name="BCX70"/>
<technology name="BF820"/>
<technology name="BF822"/>
<technology name="BFR53"/>
<technology name="BFR92"/>
<technology name="BFR92A"/>
<technology name="BFR93"/>
<technology name="BFR93A"/>
<technology name="BFS17"/>
<technology name="BFS19"/>
<technology name="BFS20"/>
<technology name="BFT25"/>
<technology name="BSR12"/>
<technology name="BSR13"/>
<technology name="BSR14"/>
<technology name="BSV52LT1"/>
<technology name="MMBT2222ALT1"/>
<technology name="MMBT2369LT1"/>
<technology name="MMBT2484LT1"/>
<technology name="MMBT3904LT1"/>
<technology name="MMBT4401LT1"/>
<technology name="MMBT5551LT1"/>
<technology name="MMBT6429LT1"/>
<technology name="MMBT6517LT1"/>
<technology name="MMBT918LT1"/>
<technology name="MMBTA42LT1"/>
<technology name="MMBTH10LT1"/>
<technology name="MMBTH24LT1"/>
</technologies>
</device>
<device name="SOT23-EBC" package="SOT23-EBC">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TO92-BCE" package="TO92-BCE">
<connects>
</connects>
<technologies>
<technology name="BF420"/>
<technology name="BF422"/>
</technologies>
</device>
<device name="TO92-CBE" package="TO92-CBE">
<connects>
</connects>
<technologies>
<technology name="2N4124"/>
<technology name="2N5400"/>
<technology name="2N5401"/>
<technology name="2N5550"/>
<technology name="2N5551"/>
<technology name="2N6427"/>
<technology name="2N6517"/>
<technology name="2N6520"/>
<technology name="BC237"/>
<technology name="BC238"/>
<technology name="BC239"/>
<technology name="BC328"/>
<technology name="BC337"/>
<technology name="BC337-16"/>
<technology name="BC337-25"/>
<technology name="BC337-40"/>
<technology name="BC338-16"/>
<technology name="BC338-25"/>
<technology name="BC338-40"/>
<technology name="BC372"/>
<technology name="BC373"/>
<technology name="BC447"/>
<technology name="BC449"/>
<technology name="BC449A"/>
<technology name="BC485"/>
<technology name="BC487"/>
<technology name="BC489"/>
<technology name="BC517"/>
<technology name="BC546"/>
<technology name="BC547"/>
<technology name="BC547A"/>
<technology name="BC547B"/>
<technology name="BC548"/>
<technology name="BC549"/>
<technology name="BC550"/>
<technology name="BC618"/>
<technology name="BF391"/>
<technology name="BF393"/>
<technology name="BF844"/>
<technology name="MPS2222A"/>
<technology name="MPSA06"/>
<technology name="MPSA13"/>
<technology name="MPSA14"/>
<technology name="MPSA18"/>
<technology name="MPSA29"/>
<technology name="MPSA42"/>
<technology name="MPSA44"/>
<technology name="MPSA92"/>
<technology name="MPSA93"/>
<technology name="MPSL51"/>
<technology name="MPSW42"/>
</technologies>
</device>
<device name="TO92-BEC" package="TO92-BEC">
<connects>
</connects>
<technologies>
<technology name="BF199"/>
<technology name="BF224"/>
<technology name="BF240"/>
</technologies>
</device>
<device name="TO92-CEB" package="TO92-CEB">
<connects>
</connects>
<technologies>
<technology name="BF374"/>
<technology name="BF959"/>
<technology name="MPHS10"/>
</technologies>
</device>
<device name="SC59-BEC" package="SC59-BEC">
<connects>
</connects>
<technologies>
<technology name="MMUN2211LT1"/>
<technology name="MMUN2212LT1"/>
<technology name="MMUN2213LT1"/>
<technology name="MMUN2214LT1"/>
</technologies>
</device>
<device name="SOT89-BCE" package="SOT89-BCE">
<connects>
</connects>
<technologies>
<technology name="BC868"/>
<technology name="BCX54"/>
<technology name="BCX55"/>
<technology name="BCX56"/>
<technology name="BF622"/>
</technologies>
</device>
<device name="SOT-37" package="SOT37">
<connects>
<connect gate="G$1" pin="E" pad="2"/>
</connects>
<technologies>
<technology name="BFR96"/>
</technologies>
</device>
<device name="TO92-ECB" package="TO92-ECB">
<connects>
</connects>
<technologies>
<technology name="BC167"/>
<technology name="BC168"/>
<technology name="BC169"/>
<technology name="BC368"/>
<technology name="BC635"/>
<technology name="BC637"/>
<technology name="BC639"/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="led">
<description>&lt;b&gt;LEDs&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;br&gt;
Extended by Federico Battaglin &lt;author&gt;&amp;lt;federico.rd@fdpinternational.com&amp;gt;&lt;/author&gt; with DUOLED</description>
<packages>
<package name="1206">
<description>&lt;b&gt;CHICAGO MINIATURE LAMP, INC.&lt;/b&gt;&lt;p&gt;
7022X Series SMT LEDs 1206 Package Size</description>
<wire x1="1.55" y1="-0.75" x2="-1.55" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="-1.55" y1="-0.75" x2="-1.55" y2="0.75" width="0.1016" layer="51"/>
<wire x1="-1.55" y1="0.75" x2="1.55" y2="0.75" width="0.1016" layer="51"/>
<wire x1="1.55" y1="0.75" x2="1.55" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="-0.55" y1="-0.5" x2="0.55" y2="-0.5" width="0.1016" layer="21" curve="95.452622"/>
<wire x1="-0.55" y1="-0.5" x2="-0.55" y2="0.5" width="0.1016" layer="51" curve="-84.547378"/>
<wire x1="-0.55" y1="0.5" x2="0.55" y2="0.5" width="0.1016" layer="21" curve="-95.452622"/>
<wire x1="0.55" y1="0.5" x2="0.55" y2="-0.5" width="0.1016" layer="51" curve="-84.547378"/>
<smd name="A" x="-1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<smd name="C" x="1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.1" y1="-0.1" x2="0.1" y2="0.1" layer="21"/>
<rectangle x1="0.45" y1="-0.7" x2="0.8" y2="-0.45" layer="51"/>
<rectangle x1="0.8" y1="-0.7" x2="0.9" y2="0.5" layer="51"/>
<rectangle x1="0.8" y1="0.55" x2="0.9" y2="0.7" layer="51"/>
<rectangle x1="-0.9" y1="-0.7" x2="-0.8" y2="0.5" layer="51"/>
<rectangle x1="-0.9" y1="0.55" x2="-0.8" y2="0.7" layer="51"/>
<rectangle x1="0.45" y1="-0.7" x2="0.6" y2="-0.45" layer="21"/>
</package>
<package name="LD260">
<description>&lt;B&gt;LED&lt;/B&gt;&lt;p&gt;
5 mm, square, Siemens</description>
<wire x1="-1.27" y1="-1.27" x2="0" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0" y1="-1.27" x2="1.27" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.27" x2="0" y2="1.27" width="0.1524" layer="21"/>
<wire x1="0" y1="1.27" x2="-1.27" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-1.27" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.27" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.889" x2="1.27" y2="0" width="0.1524" layer="51"/>
<wire x1="1.27" y1="0" x2="1.27" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.27" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.889" x2="-1.27" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="0.889" width="0.1524" layer="51"/>
<wire x1="0" y1="1.27" x2="0.9917" y2="0.7934" width="0.1524" layer="21" curve="-51.33923"/>
<wire x1="-0.9917" y1="0.7934" x2="0" y2="1.27" width="0.1524" layer="21" curve="-51.33923"/>
<wire x1="0" y1="-1.27" x2="0.9917" y2="-0.7934" width="0.1524" layer="21" curve="51.33923"/>
<wire x1="-0.9917" y1="-0.7934" x2="0" y2="-1.27" width="0.1524" layer="21" curve="51.33923"/>
<wire x1="0.9558" y1="-0.8363" x2="1.27" y2="0" width="0.1524" layer="51" curve="41.185419"/>
<wire x1="0.9756" y1="0.813" x2="1.2699" y2="0" width="0.1524" layer="51" curve="-39.806332"/>
<wire x1="-1.27" y1="0" x2="-0.9643" y2="-0.8265" width="0.1524" layer="51" curve="40.600331"/>
<wire x1="-1.27" y1="0" x2="-0.9643" y2="0.8265" width="0.1524" layer="51" curve="-40.600331"/>
<wire x1="-0.889" y1="0" x2="0" y2="0.889" width="0.1524" layer="51" curve="-90"/>
<wire x1="-0.508" y1="0" x2="0" y2="0.508" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-0.508" x2="0.508" y2="0" width="0.1524" layer="21" curve="90"/>
<wire x1="0" y1="-0.889" x2="0.889" y2="0" width="0.1524" layer="51" curve="90"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="K" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-1.2954" y="1.4732" size="1.016" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-2.4892" size="1.016" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="1.27" y1="-0.635" x2="2.032" y2="0.635" layer="51"/>
<rectangle x1="1.905" y1="-0.635" x2="2.032" y2="0.635" layer="21"/>
</package>
<package name="LED2X5">
2 x 5 mm, rectangle</description>
<wire x1="-2.54" y1="-1.27" x2="2.54" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.27" x2="2.54" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.27" x2="-2.54" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.27" x2="-2.54" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="0" x2="0.508" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="0.381" x2="-0.508" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-0.508" y1="0.381" x2="0.508" y2="0" width="0.1524" layer="51"/>
<wire x1="0.508" y1="0" x2="1.778" y2="0" width="0.1524" layer="51"/>
<wire x1="0.508" y1="0" x2="-0.508" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="0.508" y1="0.381" x2="0.508" y2="0" width="0.1524" layer="51"/>
<wire x1="0.508" y1="0" x2="0.508" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="0.889" y1="-0.254" x2="1.143" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.762" x2="1.143" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.762" x2="0.9398" y2="-0.6096" width="0.1524" layer="51"/>
<wire x1="0.9398" y1="-0.6096" x2="1.143" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="1.397" y1="-0.254" x2="1.651" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-0.762" x2="1.651" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-0.762" x2="1.4478" y2="-0.6096" width="0.1524" layer="51"/>
<wire x1="1.4478" y1="-0.6096" x2="1.651" y2="-0.508" width="0.1524" layer="51"/>
<text x="-2.54" y="1.397" size="1.016" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-2.413" size="1.016" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.159" y1="-1.27" x2="2.413" y2="1.27" layer="21"/>
</package>
<package name="LED3MM">
3 mm, round</description>
<wire x1="1.5748" y1="-1.27" x2="1.5748" y2="1.27" width="0.254" layer="51"/>
<wire x1="-1.524" y1="0" x2="-1.1708" y2="0.9756" width="0.1524" layer="51" curve="-39.80361"/>
<wire x1="-1.524" y1="0" x2="-1.1391" y2="-1.0125" width="0.1524" layer="51" curve="41.633208"/>
<wire x1="1.1571" y1="0.9918" x2="1.524" y2="0" width="0.1524" layer="51" curve="-40.601165"/>
<wire x1="1.1708" y1="-0.9756" x2="1.524" y2="0" width="0.1524" layer="51" curve="39.80361"/>
<wire x1="0" y1="1.524" x2="1.2401" y2="0.8858" width="0.1524" layer="21" curve="-54.461337"/>
<wire x1="-1.2192" y1="0.9144" x2="0" y2="1.524" width="0.1524" layer="21" curve="-53.130102"/>
<wire x1="0" y1="-1.524" x2="1.203" y2="-0.9356" width="0.1524" layer="21" curve="52.126876"/>
<wire x1="-1.203" y1="-0.9356" x2="0" y2="-1.524" width="0.1524" layer="21" curve="52.126876"/>
<wire x1="-0.635" y1="0" x2="0" y2="0.635" width="0.1524" layer="51" curve="-90"/>
<wire x1="-1.016" y1="0" x2="0" y2="1.016" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-0.635" x2="0.635" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="0" y1="-1.016" x2="1.016" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="0" y1="2.032" x2="1.561" y2="1.3009" width="0.254" layer="21" curve="-50.193108"/>
<wire x1="-1.7929" y1="0.9562" x2="0" y2="2.032" width="0.254" layer="21" curve="-61.926949"/>
<wire x1="0" y1="-2.032" x2="1.5512" y2="-1.3126" width="0.254" layer="21" curve="49.763022"/>
<wire x1="-1.7643" y1="-1.0082" x2="0" y2="-2.032" width="0.254" layer="21" curve="60.255215"/>
<wire x1="-2.032" y1="0" x2="-1.7891" y2="0.9634" width="0.254" layer="51" curve="-28.301701"/>
<wire x1="-2.032" y1="0" x2="-1.7306" y2="-1.065" width="0.254" layer="51" curve="31.60822"/>
<text x="1.905" y="0.381" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="1.905" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="LED5MM">
5 mm, round</description>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="1.905" width="0.2032" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="1.905" width="0.254" layer="21" curve="-286.260205"/>
<wire x1="-1.143" y1="0" x2="0" y2="1.143" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-1.143" x2="1.143" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="-1.651" y1="0" x2="0" y2="1.651" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-1.651" x2="1.651" y2="0" width="0.1524" layer="51" curve="90"/>
<wire x1="-2.159" y1="0" x2="0" y2="2.159" width="0.1524" layer="51" curve="-90"/>
<wire x1="0" y1="-2.159" x2="2.159" y2="0" width="0.1524" layer="51" curve="90"/>
<circle x="0" y="0" radius="2.54" width="0.1524" layer="21"/>
<text x="3.175" y="0.5334" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.2004" y="-1.8034" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="LSU260">
1 mm, round, Siemens</description>
<wire x1="0" y1="-0.508" x2="-1.143" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="-0.508" x2="-1.143" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="0.508" x2="0" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="-0.254" x2="-1.397" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="-0.254" x2="-1.143" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-1.397" y1="-0.254" x2="-1.397" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-1.397" y1="0.254" x2="-1.143" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-1.143" y1="0.254" x2="-1.143" y2="0.508" width="0.1524" layer="51"/>
<wire x1="0.508" y1="-0.254" x2="1.397" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="1.397" y1="-0.254" x2="1.397" y2="0.254" width="0.1524" layer="51"/>
<wire x1="1.397" y1="0.254" x2="0.508" y2="0.254" width="0.1524" layer="51"/>
<wire x1="0.381" y1="-0.381" x2="0.254" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-0.508" x2="-0.254" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-0.381" x2="-0.254" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.381" y1="0.381" x2="0.254" y2="0.508" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0.508" x2="-0.254" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0.381" x2="-0.254" y2="0.508" width="0.1524" layer="21"/>
<wire x1="0" y1="-0.254" x2="0.254" y2="0" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.254" y1="0" x2="0" y2="0.254" width="0.1524" layer="21" curve="-90"/>
<wire x1="0.381" y1="-0.381" x2="0.381" y2="0.381" width="0.1524" layer="21" curve="90"/>
<circle x="0" y="0" radius="0.508" width="0.1524" layer="51"/>
<text x="-1.2954" y="0.8382" size="1.016" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-1.8542" size="1.016" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.397" y1="-0.254" x2="-1.143" y2="0.254" layer="51"/>
<rectangle x1="0.508" y1="-0.254" x2="1.397" y2="0.254" layer="51"/>
</package>
<package name="LZR181">
<description>&lt;B&gt;LED BLOCK&lt;/B&gt;&lt;p&gt;
1 LED, Siemens</description>
<wire x1="-1.27" y1="-1.27" x2="1.27" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.889" x2="1.27" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="-0.889" x2="-1.27" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-0.8678" y1="0.7439" x2="0" y2="1.143" width="0.1524" layer="21" curve="-49.396139"/>
<wire x1="0" y1="1.143" x2="0.8678" y2="0.7439" width="0.1524" layer="21" curve="-49.396139"/>
<wire x1="-0.8678" y1="-0.7439" x2="0" y2="-1.143" width="0.1524" layer="21" curve="49.396139"/>
<wire x1="0" y1="-1.143" x2="0.8678" y2="-0.7439" width="0.1524" layer="21" curve="49.396139"/>
<wire x1="0.8678" y1="0.7439" x2="1.143" y2="0" width="0.1524" layer="51" curve="-40.604135"/>
<wire x1="0.8678" y1="-0.7439" x2="1.143" y2="0" width="0.1524" layer="51" curve="40.604135"/>
<wire x1="-1.143" y1="0" x2="-0.8678" y2="0.7439" width="0.1524" layer="51" curve="-40.604135"/>
<wire x1="-1.143" y1="0" x2="-0.8678" y2="-0.7439" width="0.1524" layer="51" curve="40.604135"/>
<wire x1="-1.27" y1="1.27" x2="1.27" y2="1.27" width="0.1524" layer="21"/>
<rectangle x1="1.27" y1="-0.889" x2="1.524" y2="0.254" layer="51"/>
<rectangle x1="-1.524" y1="-0.254" x2="-1.27" y2="0.254" layer="51"/>
</package>
<package name="Q62902-B152">
<description>&lt;b&gt;LED HOLDER&lt;/b&gt;&lt;p&gt;
<wire x1="-2.9718" y1="-1.8542" x2="-2.9718" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="-0.254" x2="-2.9718" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="0.254" x2="-2.9718" y2="1.8542" width="0.1524" layer="21"/>
<wire x1="2.9718" y1="-1.8542" x2="-2.1082" y2="-1.8542" width="0.1524" layer="21"/>
<wire x1="-2.1082" y1="-1.8542" x2="-2.54" y2="-1.8542" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.8542" x2="-2.1082" y2="1.8542" width="0.1524" layer="21"/>
<wire x1="-2.1082" y1="1.8542" x2="2.9718" y2="1.8542" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.8542" x2="-2.54" y2="1.8542" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.8542" x2="-2.9718" y2="-1.8542" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.8542" x2="-2.9718" y2="1.8542" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="0.254" x2="-2.9718" y2="-0.254" width="0.1524" layer="21" curve="180"/>
<wire x1="-1.1486" y1="0.8814" x2="0" y2="1.4478" width="0.1524" layer="21" curve="-52.498642"/>
<wire x1="0" y1="1.4478" x2="1.1476" y2="0.8827" width="0.1524" layer="21" curve="-52.433716"/>
<wire x1="-1.1351" y1="-0.8987" x2="0" y2="-1.4478" width="0.1524" layer="21" curve="51.629985"/>
<wire x1="0" y1="-1.4478" x2="1.1305" y2="-0.9044" width="0.1524" layer="21" curve="51.339172"/>
<wire x1="1.1281" y1="-0.9074" x2="1.4478" y2="0" width="0.1524" layer="51" curve="38.811177"/>
<wire x1="1.1401" y1="0.8923" x2="1.4478" y2="0" width="0.1524" layer="51" curve="-38.048073"/>
<wire x1="-1.4478" y1="0" x2="-1.1305" y2="-0.9044" width="0.1524" layer="51" curve="38.659064"/>
<wire x1="-1.4478" y1="0" x2="-1.1456" y2="0.8853" width="0.1524" layer="51" curve="-37.696376"/>
<wire x1="0" y1="1.7018" x2="1.4674" y2="0.8618" width="0.1524" layer="21" curve="-59.573488"/>
<wire x1="-1.4618" y1="0.8714" x2="0" y2="1.7018" width="0.1524" layer="21" curve="-59.200638"/>
<wire x1="0" y1="-1.7018" x2="1.4571" y2="-0.8793" width="0.1524" layer="21" curve="58.891781"/>
<wire x1="-1.4571" y1="-0.8793" x2="0" y2="-1.7018" width="0.1524" layer="21" curve="58.891781"/>
<wire x1="-1.7018" y1="0" x2="-1.4447" y2="0.8995" width="0.1524" layer="51" curve="-31.907626"/>
<wire x1="-1.7018" y1="0" x2="-1.4502" y2="-0.8905" width="0.1524" layer="51" curve="31.551992"/>
<wire x1="1.4521" y1="0.8874" x2="1.7018" y2="0" width="0.1524" layer="51" curve="-31.429586"/>
<wire x1="1.4459" y1="-0.8975" x2="1.7018" y2="0" width="0.1524" layer="51" curve="31.828757"/>
<wire x1="-2.1082" y1="1.8542" x2="-2.1082" y2="-1.8542" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="0" y2="0.635" width="0.1524" layer="21" curve="-90"/>
<wire x1="0.0539" y1="-1.0699" x2="1.0699" y2="-0.0539" width="0.1524" layer="51" curve="90"/>
<wire x1="2.9718" y1="1.8542" x2="2.9718" y2="-1.8542" width="0.1524" layer="21"/>
<pad name="K" x="-1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="A" x="1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="-1.905" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.905" y="-3.556" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="Q62902-B153">
<wire x1="-5.5118" y1="-3.5052" x2="-5.5118" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-5.5118" y1="-0.254" x2="-5.5118" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-5.5118" y1="0.254" x2="-5.5118" y2="3.5052" width="0.1524" layer="21"/>
<wire x1="5.5118" y1="-3.5052" x2="-4.6482" y2="-3.5052" width="0.1524" layer="21"/>
<wire x1="-4.6482" y1="-3.5052" x2="-5.08" y2="-3.5052" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.5052" x2="-4.6482" y2="3.5052" width="0.1524" layer="21"/>
<wire x1="-4.6482" y1="3.5052" x2="5.5118" y2="3.5052" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.5052" x2="-5.08" y2="3.5052" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-3.5052" x2="-5.5118" y2="-3.5052" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.5052" x2="-5.5118" y2="3.5052" width="0.1524" layer="21"/>
<wire x1="-5.5118" y1="0.254" x2="-5.5118" y2="-0.254" width="0.1524" layer="21" curve="180"/>
<wire x1="-4.6482" y1="3.5052" x2="-4.6482" y2="-3.5052" width="0.1524" layer="21"/>
<wire x1="5.5118" y1="3.5052" x2="5.5118" y2="-3.5052" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.905" x2="-2.54" y2="-1.905" width="0.254" layer="21"/>
<wire x1="-2.2129" y1="0.0539" x2="-0.0539" y2="2.2129" width="0.1524" layer="51" curve="-90.010616"/>
<circle x="0" y="0" radius="3.175" width="0.254" layer="21"/>
<text x="-4.191" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-5.08" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="Q62902-B155">
<wire x1="-1.27" y1="-3.048" x2="-1.27" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="10.033" y1="3.048" x2="2.921" y2="3.048" width="0.1524" layer="21"/>
<wire x1="10.033" y1="3.048" x2="10.033" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-3.048" x2="2.921" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-3.048" x2="2.921" y2="3.048" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-3.048" x2="10.033" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="2.921" y1="3.048" x2="-1.27" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.54" x2="-5.207" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="2.54" x2="-1.27" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-2.54" x2="-1.27" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-2.54" x2="-1.27" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.54" x2="-5.207" y2="-2.54" width="0.1524" layer="21" curve="180"/>
<wire x1="-6.985" y1="0.635" x2="-6.985" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="1.397" x2="-6.096" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="1.905" x2="-5.207" y2="-1.905" width="0.1524" layer="21"/>
<pad name="K" x="7.62" y="1.27" drill="0.8128" shape="long"/>
<pad name="A" x="7.62" y="-1.27" drill="0.8128" shape="long"/>
<text x="3.302" y="-2.794" size="1.016" layer="21" ratio="14">A+</text>
<text x="3.302" y="1.778" size="1.016" layer="21" ratio="14">K-</text>
<text x="11.684" y="-2.794" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="0.635" y="-4.445" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.921" y1="1.016" x2="6.731" y2="1.524" layer="21"/>
<rectangle x1="2.921" y1="-1.524" x2="6.731" y2="-1.016" layer="21"/>
<hole x="0" y="0" drill="0.8128"/>
</package>
<package name="Q62902-B156">
<wire x1="2.54" y1="-1.905" x2="2.54" y2="1.905" width="0.1524" layer="21"/>
<wire x1="0.0539" y1="-2.2129" x2="2.2129" y2="-0.0539" width="0.1524" layer="51" curve="90.005308"/>
<wire x1="2.54" y1="3.81" x2="3.81" y2="2.54" width="0.1524" layer="21"/>
<wire x1="2.54" y1="3.81" x2="-3.81" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-3.81" x2="-3.81" y2="3.81" width="0.1524" layer="21"/>
<wire x1="3.81" y1="2.54" x2="3.81" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-3.81" x2="-2.54" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-3.302" x2="-2.54" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-3.81" x2="2.54" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-3.302" x2="2.54" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-3.302" x2="-2.54" y2="-3.302" width="0.1524" layer="21"/>
<pad name="A" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="K" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-3.81" y="4.0894" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.7846" y="-5.3594" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.556" y="-3.302" size="1.016" layer="21" ratio="14">+</text>
<text x="2.794" y="-3.302" size="1.016" layer="21" ratio="14">-</text>
</package>
<package name="SFH480">
<description>&lt;B&gt;IR LED&lt;/B&gt;&lt;p&gt;
infrared emitting diode, Infineon
TO-18, lead spacing 2.54 mm, cathode marking&lt;p&gt;
Inifineon</description>
<wire x1="-2.159" y1="1.524" x2="-2.794" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="2.159" x2="-2.159" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="2.159" x2="-2.159" y2="2.794" width="0.1524" layer="21"/>
<wire x1="0" y1="1.778" x2="1.5358" y2="0.8959" width="0.1524" layer="21" curve="-59.743278"/>
<wire x1="-1.5358" y1="0.8959" x2="0" y2="1.778" width="0.1524" layer="21" curve="-59.743278"/>
<wire x1="-1.5358" y1="-0.8959" x2="0" y2="-1.778" width="0.1524" layer="21" curve="59.743278"/>
<wire x1="0" y1="-1.778" x2="1.5358" y2="-0.8959" width="0.1524" layer="21" curve="59.743278"/>
<wire x1="1.5142" y1="0.9318" x2="1.778" y2="0" width="0.1524" layer="51" curve="-31.606487"/>
<wire x1="1.5" y1="-0.9546" x2="1.778" y2="0" width="0.1524" layer="51" curve="32.472615"/>
<wire x1="-1.778" y1="0" x2="-1.5142" y2="-0.9318" width="0.1524" layer="51" curve="31.606487"/>
<wire x1="-1.778" y1="0" x2="-1.5" y2="0.9546" width="0.1524" layer="51" curve="-32.472615"/>
<circle x="0" y="0" radius="2.667" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.413" width="0.254" layer="21"/>
<text x="-1.27" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-4.318" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SFH482">
<pad name="K" x="1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
</package>
<package name="U57X32">
rectangle, 5.7 x 3.2 mm</description>
<wire x1="-3.175" y1="1.905" x2="3.175" y2="1.905" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.905" x2="3.175" y2="1.905" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.905" x2="-3.175" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.905" x2="-3.175" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="1.397" x2="2.667" y2="1.397" width="0.1524" layer="21"/>
<wire x1="2.667" y1="-1.397" x2="2.667" y2="1.397" width="0.1524" layer="21"/>
<wire x1="2.667" y1="-1.397" x2="-2.667" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="1.397" x2="-2.667" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.016" x2="2.54" y2="1.016" width="0.1524" layer="51"/>
<wire x1="2.286" y1="1.27" x2="2.286" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="0.508" x2="2.54" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="0" x2="2.54" y2="0" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-0.508" x2="2.54" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-1.016" x2="2.54" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-2.286" y1="1.27" x2="-2.286" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-1.778" y1="1.27" x2="-1.778" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="0.254" y1="1.27" x2="0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="0.762" y1="1.27" x2="0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="1.27" y1="1.27" x2="1.27" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="1.778" y1="1.27" x2="1.778" y2="-1.27" width="0.1524" layer="51"/>
<text x="3.683" y="0.254" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.683" y="-1.524" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="IRL80A">
IR transmitter Siemens</description>
<wire x1="0.889" y1="2.286" x2="0.889" y2="1.778" width="0.1524" layer="21"/>
<wire x1="0.889" y1="1.778" x2="0.889" y2="0.762" width="0.1524" layer="51"/>
<wire x1="0.889" y1="0.762" x2="0.889" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-0.635" x2="0.889" y2="-1.778" width="0.1524" layer="51"/>
<wire x1="0.889" y1="-1.778" x2="0.889" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-2.286" x2="-0.889" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="2.286" x2="-0.889" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.778" x2="-0.889" y2="0.762" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="0.762" x2="-0.889" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-0.762" x2="-0.889" y2="-1.778" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="-1.778" x2="-0.889" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="2.286" x2="0.889" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-0.762" x2="-0.889" y2="0.762" width="0.1524" layer="21" curve="-180"/>
<wire x1="-1.397" y1="0.254" x2="-1.397" y2="-0.254" width="0.0508" layer="21"/>
<wire x1="-1.143" y1="0.508" x2="-1.143" y2="-0.508" width="0.0508" layer="21"/>
<pad name="K" x="0" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="A" x="0" y="-1.27" drill="0.8128" shape="octagon"/>
<text x="1.27" y="0.381" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="1.27" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="P-LCC-2">
<description>&lt;b&gt;TOPLED® High-optical Power LED (HOP)&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... ls_t675.pdf</description>
<wire x1="-1.4" y1="-1.05" x2="-1.4" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="-1.4" y1="-1.6" x2="-1.1" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="-1.1" y1="-1.6" x2="-0.85" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="-0.85" y1="-1.6" x2="1.1" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="1.1" y1="-1.6" x2="1.4" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="1.4" y1="-1.6" x2="1.4" y2="1.6" width="0.2032" layer="51"/>
<wire x1="1.4" y1="1.6" x2="1.1" y2="1.6" width="0.2032" layer="51"/>
<wire x1="1.1" y1="1.6" x2="-1.1" y2="1.6" width="0.2032" layer="51"/>
<wire x1="-1.1" y1="1.6" x2="-1.4" y2="1.6" width="0.2032" layer="51"/>
<wire x1="-1.1" y1="1.6" x2="-1.1" y2="1.8" width="0.1016" layer="51"/>
<wire x1="-1.1" y1="1.8" x2="1.1" y2="1.8" width="0.1016" layer="51"/>
<wire x1="1.1" y1="1.8" x2="1.1" y2="1.6" width="0.1016" layer="51"/>
<wire x1="-1.1" y1="-1.6" x2="-1.1" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="-1.1" y1="-1.8" x2="1.1" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="1.1" y1="-1.8" x2="1.1" y2="-1.6" width="0.1016" layer="51"/>
<wire x1="-0.85" y1="-1.6" x2="-1.4" y2="-1.05" width="0.2032" layer="51"/>
<wire x1="-1.4" y1="1.6" x2="-1.4" y2="-1.05" width="0.2032" layer="51"/>
<circle x="0" y="0" radius="1.1" width="0.2032" layer="51"/>
<smd name="C" x="0" y="-2.75" dx="4" dy="4" layer="1" stop="no" cream="no"/>
<smd name="A" x="0" y="2.75" dx="4" dy="4" layer="1" stop="no" cream="no"/>
<text x="-2.54" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.81" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<text x="-0.635" y="2.54" size="1.27" layer="21">A</text>
<text x="-0.635" y="-3.81" size="1.27" layer="21">C</text>
<rectangle x1="-1.3" y1="-2.25" x2="1.3" y2="-0.75" layer="31"/>
<rectangle x1="-1.3" y1="0.75" x2="1.3" y2="2.25" layer="31"/>
<rectangle x1="-0.25" y1="-0.25" x2="0.25" y2="0.25" layer="21"/>
<rectangle x1="-1.4" y1="0.65" x2="1.4" y2="2.35" layer="29"/>
<rectangle x1="-1.4" y1="-2.35" x2="1.4" y2="-0.65" layer="29"/>
</package>
<package name="OSRAM-MINI-TOP-LED">
<description>&lt;b&gt;BLUE LINETM Hyper Mini TOPLED® Hyper-Bright LED&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... LB M676.pdf</description>
<wire x1="-0.6" y1="0.9" x2="-0.6" y2="-0.7" width="0.1016" layer="51"/>
<wire x1="-0.45" y1="-0.9" x2="-0.4" y2="-0.9" width="0.1016" layer="51"/>
<wire x1="-0.4" y1="-0.9" x2="0.6" y2="-0.9" width="0.1016" layer="51"/>
<wire x1="0.6" y1="-0.9" x2="0.6" y2="0.9" width="0.1016" layer="51"/>
<wire x1="0.6" y1="0.9" x2="-0.6" y2="0.9" width="0.1016" layer="51"/>
<wire x1="-0.45" y1="0.95" x2="-0.45" y2="1.1" width="0.1016" layer="51"/>
<wire x1="-0.45" y1="1.1" x2="0.45" y2="1.1" width="0.1016" layer="51"/>
<wire x1="0.45" y1="1.1" x2="0.45" y2="0.95" width="0.1016" layer="51"/>
<wire x1="-0.6" y1="-0.7" x2="-0.4" y2="-0.9" width="0.1016" layer="51"/>
<wire x1="-0.45" y1="-0.9" x2="-0.45" y2="-1.1" width="0.1016" layer="51"/>
<wire x1="-0.45" y1="-1.1" x2="0.45" y2="-1.1" width="0.1016" layer="51"/>
<wire x1="0.45" y1="-1.1" x2="0.45" y2="-0.95" width="0.1016" layer="51"/>
<smd name="A" x="0" y="2.6" dx="4" dy="4" layer="1" stop="no" cream="no"/>
<smd name="C" x="0" y="-2.6" dx="4" dy="4" layer="1" stop="no" cream="no"/>
<text x="-0.635" y="1.905" size="1.27" layer="21">A</text>
<text x="-0.635" y="-3.175" size="1.27" layer="21">C</text>
<rectangle x1="-0.5" y1="0.6" x2="0.5" y2="1.4" layer="29"/>
<rectangle x1="-0.5" y1="-1.4" x2="0.5" y2="-0.6" layer="29"/>
<rectangle x1="-0.15" y1="-0.6" x2="0.15" y2="-0.3" layer="51"/>
<rectangle x1="-0.45" y1="0.65" x2="0.45" y2="1.35" layer="31"/>
<rectangle x1="-0.45" y1="-1.35" x2="0.45" y2="-0.65" layer="31"/>
</package>
<package name="OSRAM-SIDELED">
<description>&lt;b&gt;Super SIDELED® High-Current LED&lt;/b&gt;&lt;p&gt;
LG A672, LP A672 &lt;br&gt;
Source: http://www.osram.convergy.de/ ... LG_LP_A672.pdf (2004.05.13)</description>
<wire x1="-1.85" y1="-2.05" x2="-1.85" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="-1.85" y1="-0.75" x2="-1.7" y2="-0.75" width="0.1016" layer="51"/>
<wire x1="-1.7" y1="-0.75" x2="-1.7" y2="0.75" width="0.1016" layer="51"/>
<wire x1="-1.7" y1="0.75" x2="-1.85" y2="0.75" width="0.1016" layer="51"/>
<wire x1="-1.85" y1="0.75" x2="-1.85" y2="2.05" width="0.1016" layer="51"/>
<wire x1="-1.85" y1="2.05" x2="0.9" y2="2.05" width="0.1016" layer="51"/>
<wire x1="0.9" y1="2.05" x2="0.9" y2="-2.05" width="0.1016" layer="51"/>
<wire x1="0.9" y1="-2.05" x2="-1.85" y2="-2.05" width="0.1016" layer="51"/>
<wire x1="0.9" y1="-2.05" x2="1.05" y2="-2.05" width="0.1016" layer="51"/>
<wire x1="1.05" y1="-2.05" x2="1.85" y2="-1.85" width="0.1016" layer="51"/>
<wire x1="1.85" y1="-1.85" x2="1.85" y2="1.85" width="0.1016" layer="51"/>
<wire x1="1.85" y1="1.85" x2="1.05" y2="2.05" width="0.1016" layer="51"/>
<wire x1="1.05" y1="2.05" x2="0.9" y2="2.05" width="0.1016" layer="51"/>
<wire x1="1.05" y1="2.05" x2="1.05" y2="-2.05" width="0.1016" layer="51"/>
<wire x1="-0.55" y1="-0.9" x2="-0.55" y2="0.9" width="0.1016" layer="51" curve="-167.319617"/>
<wire x1="-0.55" y1="-0.9" x2="0.85" y2="-1.2" width="0.1016" layer="51" style="shortdash"/>
<wire x1="-0.55" y1="0.9" x2="0.85" y2="1.2" width="0.1016" layer="51" style="shortdash"/>
<smd name="C" x="0" y="-2.5" dx="4" dy="4" layer="1" stop="no" cream="no"/>
<smd name="A" x="0" y="2.5" dx="4" dy="4" layer="1" stop="no" cream="no"/>
<text x="0.635" y="-3.175" size="1.27" layer="21" rot="R90">C</text>
<text x="0.635" y="2.54" size="1.27" layer="21" rot="R90">A</text>
<text x="-2.54" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.81" y="-2.54" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.1" y1="-2.2" x2="2.1" y2="-0.4" layer="29"/>
<rectangle x1="-2.1" y1="0.4" x2="2.1" y2="2.2" layer="29"/>
<rectangle x1="-1.9" y1="-2.1" x2="1.9" y2="-0.6" layer="31"/>
<rectangle x1="-1.9" y1="0.6" x2="1.9" y2="2.1" layer="31"/>
<rectangle x1="-1.85" y1="-2.05" x2="-0.7" y2="-1" layer="51"/>
</package>
<package name="SMART-LED">
<description>&lt;b&gt;SmartLEDTM Hyper-Bright LED&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... LA_LO_LS_LY L896.pdf</description>
<wire x1="-0.35" y1="0.6" x2="0.35" y2="0.6" width="0.1016" layer="51" style="shortdash"/>
<wire x1="0.35" y1="0.6" x2="0.35" y2="-0.6" width="0.1016" layer="21" style="shortdash"/>
<wire x1="0.35" y1="-0.6" x2="0.15" y2="-0.6" width="0.1016" layer="51" style="shortdash"/>
<wire x1="0.15" y1="-0.6" x2="-0.35" y2="-0.6" width="0.1016" layer="51" style="shortdash"/>
<wire x1="-0.35" y1="-0.6" x2="-0.35" y2="0.6" width="0.1016" layer="21" style="shortdash"/>
<wire x1="0.35" y1="-0.4" x2="0.15" y2="-0.6" width="0.1016" layer="51" style="shortdash"/>
<smd name="A" x="0" y="0.725" dx="0.35" dy="0.35" layer="1"/>
<smd name="B" x="0" y="-0.725" dx="0.35" dy="0.35" layer="1"/>
<text x="-0.635" y="-0.635" size="1.016" layer="25" rot="R90">&gt;NAME</text>
<text x="1.905" y="-0.635" size="1.016" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.15" y1="-0.35" x2="0.15" y2="-0.05" layer="21"/>
<rectangle x1="-0.15" y1="0.6" x2="0.15" y2="0.85" layer="51"/>
<rectangle x1="-0.15" y1="-0.85" x2="0.15" y2="-0.6" layer="51"/>
</package>
<package name="P-LCC-2-TOPLED-RG">
<description>&lt;b&gt;Hyper TOPLED® RG Hyper-Bright LED&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... LA_LO_LS_LY T776.pdf</description>
<wire x1="-1.1" y1="1.6" x2="-1.1" y2="2.45" width="0.1016" layer="51"/>
<wire x1="1.1" y1="2.45" x2="1.1" y2="1.6" width="0.1016" layer="51"/>
<wire x1="-1.1" y1="-1.6" x2="-1.1" y2="-2.45" width="0.1016" layer="51"/>
<wire x1="1.1" y1="-2.45" x2="1.1" y2="-1.6" width="0.1016" layer="51"/>
<circle x="0" y="0" radius="1.1" width="0.2032" layer="21"/>
<smd name="C" x="0" y="-3.5" dx="4" dy="4" layer="1" stop="no" cream="no"/>
<smd name="A" x="0" y="3.5" dx="4" dy="4" layer="1" stop="no" cream="no"/>
<text x="-0.635" y="3.29" size="1.27" layer="21">A</text>
<text x="-0.635" y="-4.56" size="1.27" layer="21">C</text>
<rectangle x1="-1.3" y1="-3" x2="1.3" y2="-1.5" layer="31"/>
<rectangle x1="-1.3" y1="1.5" x2="1.3" y2="3" layer="31"/>
<rectangle x1="-1.15" y1="2.4" x2="1.15" y2="2.7" layer="51"/>
<rectangle x1="-1.15" y1="-2.7" x2="1.15" y2="-2.4" layer="51"/>
<rectangle x1="-1.5" y1="1.5" x2="1.5" y2="3.2" layer="29"/>
<rectangle x1="-1.5" y1="-3.2" x2="1.5" y2="-1.5" layer="29"/>
<hole x="0" y="0" drill="2.8"/>
</package>
<package name="MICRO-SIDELED">
<description>&lt;b&gt;Hyper Micro SIDELED®&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... LA_LO_LS_LY Y876.pdf</description>
<wire x1="0.65" y1="1.1" x2="-0.1" y2="1.1" width="0.1016" layer="51"/>
<wire x1="-0.1" y1="1.1" x2="-0.35" y2="1" width="0.1016" layer="51"/>
<wire x1="-0.35" y1="1" x2="-0.35" y2="-0.9" width="0.1016" layer="21"/>
<wire x1="-0.35" y1="-0.9" x2="-0.1" y2="-1.1" width="0.1016" layer="51"/>
<wire x1="-0.1" y1="-1.1" x2="0.65" y2="-1.1" width="0.1016" layer="51"/>
<wire x1="0.65" y1="-1.1" x2="0.65" y2="1.1" width="0.1016" layer="21"/>
<wire x1="0.6" y1="0.9" x2="0.25" y2="0.7" width="0.0508" layer="21"/>
<wire x1="0.25" y1="0.7" x2="0.25" y2="-0.7" width="0.0508" layer="21"/>
<wire x1="0.25" y1="-0.7" x2="0.6" y2="-0.9" width="0.0508" layer="21"/>
<smd name="A" x="0" y="1.95" dx="1.6" dy="1.6" layer="1" stop="no" cream="no"/>
<smd name="C" x="0" y="-1.95" dx="1.6" dy="1.6" layer="1" stop="no" cream="no"/>
<text x="-1.27" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="2.54" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.4" y1="1.1" x2="0.4" y2="1.8" layer="29"/>
<rectangle x1="-0.4" y1="-1.8" x2="0.4" y2="-1.1" layer="29"/>
<rectangle x1="-0.35" y1="-1.75" x2="0.35" y2="-1.15" layer="31"/>
<rectangle x1="-0.35" y1="1.15" x2="0.35" y2="1.75" layer="31"/>
<rectangle x1="-0.125" y1="1.125" x2="0.125" y2="1.75" layer="51"/>
<rectangle x1="-0.125" y1="-1.75" x2="0.125" y2="-1.125" layer="51"/>
</package>
<package name="P-LCC-4">
<description>&lt;b&gt;Power TOPLED®&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... LA_LO_LA_LY E67B.pdf</description>
<wire x1="-1.4" y1="-1.6" x2="-1" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="-1" y1="-1.6" x2="-0.85" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="-0.85" y1="-1.6" x2="1" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="1" y1="-1.6" x2="1.4" y2="-1.6" width="0.2032" layer="51"/>
<wire x1="1.1" y1="1.6" x2="-1" y2="1.6" width="0.2032" layer="51"/>
<wire x1="-1" y1="1.6" x2="-1.4" y2="1.6" width="0.2032" layer="51"/>
<wire x1="-1" y1="1.6" x2="-1" y2="1.8" width="0.1016" layer="51"/>
<wire x1="-1" y1="1.8" x2="-0.5" y2="1.8" width="0.1016" layer="51"/>
<wire x1="-0.5" y1="1.8" x2="-0.5" y2="1.65" width="0.1016" layer="51"/>
<wire x1="0.5" y1="1.65" x2="0.5" y2="1.8" width="0.1016" layer="51"/>
<wire x1="0.5" y1="1.8" x2="1.1" y2="1.8" width="0.1016" layer="51"/>
<wire x1="-1" y1="-1.6" x2="-1" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="-1" y1="-1.8" x2="-0.5" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="-0.5" y1="-1.8" x2="-0.5" y2="-1.65" width="0.1016" layer="51"/>
<wire x1="0.5" y1="-1.65" x2="0.5" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="0.5" y1="-1.8" x2="1" y2="-1.8" width="0.1016" layer="51"/>
<wire x1="1" y1="-1.8" x2="1" y2="-1.6" width="0.1016" layer="51"/>
<smd name="A" x="-2" y="3.15" dx="3.3" dy="4.8" layer="1" stop="no" cream="no"/>
<smd name="C@3" x="2" y="3.15" dx="3.3" dy="4.8" layer="1" stop="no" cream="no"/>
<smd name="C@4" x="2" y="-3.15" dx="3.3" dy="4.8" layer="1" stop="no" cream="no"/>
<smd name="C@1" x="-2" y="-3.15" dx="3.3" dy="4.8" layer="1" stop="no" cream="no"/>
<text x="-3.81" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="5.08" y="-2.54" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<text x="-1.905" y="-3.81" size="1.27" layer="21">C</text>
<text x="-1.905" y="2.54" size="1.27" layer="21">A</text>
<text x="1.27" y="2.54" size="1.27" layer="21">C</text>
<text x="1.27" y="-3.81" size="1.27" layer="21">C</text>
<rectangle x1="-1.15" y1="0.75" x2="-0.35" y2="1.85" layer="29"/>
<rectangle x1="0.35" y1="0.75" x2="1.15" y2="1.85" layer="29"/>
<rectangle x1="0.35" y1="-1.85" x2="1.15" y2="-0.75" layer="29"/>
<rectangle x1="-1.15" y1="-1.85" x2="-0.35" y2="-0.75" layer="29"/>
<rectangle x1="-1.1" y1="-1.8" x2="-0.4" y2="-0.8" layer="31"/>
<rectangle x1="0.4" y1="-1.8" x2="1.1" y2="-0.8" layer="31"/>
<rectangle x1="0.4" y1="0.8" x2="1.1" y2="1.8" layer="31"/>
<rectangle x1="-1.1" y1="0.8" x2="-0.4" y2="1.8" layer="31"/>
<rectangle x1="-0.2" y1="-0.2" x2="0.2" y2="0.2" layer="21"/>
</package>
<package name="CHIP-LED0603">
<description>&lt;b&gt;Hyper CHIPLED Hyper-Bright LED&lt;/b&gt;&lt;p&gt;
LB Q993&lt;br&gt;
Source: http://www.osram.convergy.de/ ... Lb_q993.pdf</description>
<wire x1="-0.4" y1="0.45" x2="-0.4" y2="-0.45" width="0.1016" layer="51"/>
<wire x1="0.4" y1="0.45" x2="0.4" y2="-0.45" width="0.1016" layer="51"/>
<smd name="C" x="0" y="0.75" dx="0.8" dy="0.8" layer="1"/>
<smd name="A" x="0" y="-0.75" dx="0.8" dy="0.8" layer="1"/>
<text x="-0.635" y="-0.635" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="1.905" y="-0.635" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.45" y1="0.45" x2="0.45" y2="0.85" layer="51"/>
<rectangle x1="-0.45" y1="-0.85" x2="0.45" y2="-0.45" layer="51"/>
<rectangle x1="-0.45" y1="0" x2="-0.3" y2="0.3" layer="21"/>
<rectangle x1="0.3" y1="0" x2="0.45" y2="0.3" layer="21"/>
<rectangle x1="-0.15" y1="0" x2="0.15" y2="0.3" layer="21"/>
</package>
<package name="CHIP-LED0805">
LB R99A&lt;br&gt;
Source: http://www.osram.convergy.de/ ... lb_r99a.pdf</description>
<wire x1="-0.625" y1="0.45" x2="-0.625" y2="-0.45" width="0.1016" layer="51"/>
<wire x1="0.625" y1="0.45" x2="0.625" y2="-0.475" width="0.1016" layer="51"/>
<smd name="C" x="0" y="1.05" dx="1.2" dy="1.2" layer="1"/>
<smd name="A" x="0" y="-1.05" dx="1.2" dy="1.2" layer="1"/>
<text x="-1.27" y="-1.27" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="2.54" y="-1.27" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.675" y1="0" x2="-0.525" y2="0.3" layer="21"/>
<rectangle x1="0.525" y1="0" x2="0.675" y2="0.3" layer="21"/>
<rectangle x1="-0.675" y1="0.45" x2="0.675" y2="1.05" layer="51"/>
<rectangle x1="-0.675" y1="-1.05" x2="0.675" y2="-0.45" layer="51"/>
</package>
<package name="MINI-TOPLED-SANTANA">
<description>&lt;b&gt;Mini TOPLED Santana®&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... LG M470.pdf</description>
<wire x1="0.7" y1="-1" x2="0.35" y2="-1" width="0.1016" layer="21"/>
<wire x1="0.35" y1="-1" x2="-0.7" y2="-1" width="0.1016" layer="21"/>
<wire x1="-0.7" y1="-1" x2="-0.7" y2="1" width="0.1016" layer="21"/>
<wire x1="-0.7" y1="1" x2="0.7" y2="1" width="0.1016" layer="21"/>
<wire x1="0.7" y1="1" x2="0.7" y2="-0.65" width="0.1016" layer="21"/>
<wire x1="0.7" y1="-0.65" x2="0.7" y2="-1" width="0.1016" layer="21"/>
<wire x1="0.45" y1="-0.7" x2="-0.45" y2="-0.7" width="0.1016" layer="21"/>
<wire x1="-0.45" y1="-0.7" x2="-0.45" y2="0.7" width="0.1016" layer="21"/>
<wire x1="-0.45" y1="0.7" x2="0.45" y2="0.7" width="0.1016" layer="21"/>
<wire x1="0.45" y1="0.7" x2="0.45" y2="-0.7" width="0.1016" layer="21"/>
<wire x1="0.7" y1="-0.65" x2="0.35" y2="-1" width="0.1016" layer="21"/>
<smd name="C" x="0" y="-2.2" dx="1.6" dy="1.6" layer="1" stop="no" cream="no"/>
<smd name="A" x="0" y="2.2" dx="1.6" dy="1.6" layer="1" stop="no" cream="no"/>
<rectangle x1="-0.55" y1="1.5" x2="0.55" y2="2.1" layer="29"/>
<rectangle x1="-0.55" y1="-2.1" x2="0.55" y2="-1.5" layer="29"/>
<rectangle x1="-0.5" y1="-2.05" x2="0.5" y2="-1.55" layer="31"/>
<rectangle x1="-0.5" y1="1.55" x2="0.5" y2="2.05" layer="31"/>
<rectangle x1="-0.2" y1="-0.4" x2="0.15" y2="-0.05" layer="21"/>
<rectangle x1="-0.5" y1="-2.1" x2="0.5" y2="-1.4" layer="51"/>
<rectangle x1="-0.5" y1="1.4" x2="0.5" y2="2.05" layer="51"/>
<rectangle x1="-0.5" y1="1" x2="0.5" y2="1.4" layer="21"/>
<rectangle x1="-0.5" y1="-1.4" x2="0.5" y2="-1.05" layer="21"/>
<hole x="0" y="0" drill="2.7"/>
</package>
<package name="CHIPLED_0805">
<description>&lt;b&gt;CHIPLED&lt;/b&gt;&lt;p&gt;
Source: http://www.osram.convergy.de/ ... LG_R971.pdf</description>
<wire x1="-0.35" y1="0.925" x2="0.35" y2="0.925" width="0.1016" layer="51" curve="162.394521"/>
<wire x1="-0.35" y1="-0.925" x2="0.35" y2="-0.925" width="0.1016" layer="51" curve="-162.394521"/>
<wire x1="0.575" y1="0.525" x2="0.575" y2="-0.525" width="0.1016" layer="51"/>
<wire x1="-0.575" y1="-0.5" x2="-0.575" y2="0.925" width="0.1016" layer="51"/>
<circle x="-0.45" y="0.85" radius="0.103" width="0.1016" layer="51"/>
<rectangle x1="0.3" y1="0.5" x2="0.625" y2="1" layer="51"/>
<rectangle x1="-0.325" y1="0.5" x2="-0.175" y2="0.75" layer="51"/>
<rectangle x1="0.175" y1="0.5" x2="0.325" y2="0.75" layer="51"/>
<rectangle x1="-0.2" y1="0.5" x2="0.2" y2="0.675" layer="51"/>
<rectangle x1="0.3" y1="-1" x2="0.625" y2="-0.5" layer="51"/>
<rectangle x1="-0.625" y1="-1" x2="-0.3" y2="-0.5" layer="51"/>
<rectangle x1="0.175" y1="-0.75" x2="0.325" y2="-0.5" layer="51"/>
<rectangle x1="-0.325" y1="-0.75" x2="-0.175" y2="-0.5" layer="51"/>
<rectangle x1="-0.2" y1="-0.675" x2="0.2" y2="-0.5" layer="51"/>
<rectangle x1="-0.1" y1="0" x2="0.1" y2="0.2" layer="21"/>
<rectangle x1="-0.6" y1="0.5" x2="-0.3" y2="0.8" layer="51"/>
<rectangle x1="-0.625" y1="0.925" x2="-0.3" y2="1" layer="51"/>
</package>
<package name="CHIPLED_1206">
Source: http://www.osram.convergy.de/ ... LG_LY N971.pdf</description>
<wire x1="-0.4" y1="1.6" x2="0.4" y2="1.6" width="0.1016" layer="51" curve="172.619069"/>
<wire x1="-0.8" y1="-0.95" x2="-0.8" y2="0.95" width="0.1016" layer="51"/>
<wire x1="0.8" y1="0.95" x2="0.8" y2="-0.95" width="0.1016" layer="51"/>
<circle x="-0.55" y="1.425" radius="0.1" width="0.1016" layer="51"/>
<smd name="C" x="0" y="1.75" dx="1.5" dy="1.5" layer="1"/>
<smd name="A" x="0" y="-1.75" dx="1.5" dy="1.5" layer="1"/>
<rectangle x1="-0.85" y1="1.525" x2="-0.35" y2="1.65" layer="51"/>
<rectangle x1="-0.85" y1="1.225" x2="-0.625" y2="1.55" layer="51"/>
<rectangle x1="-0.45" y1="1.225" x2="-0.325" y2="1.45" layer="51"/>
<rectangle x1="-0.65" y1="1.225" x2="-0.225" y2="1.35" layer="51"/>
<rectangle x1="0.35" y1="1.3" x2="0.85" y2="1.65" layer="51"/>
<rectangle x1="0.25" y1="1.225" x2="0.85" y2="1.35" layer="51"/>
<rectangle x1="-0.85" y1="0.95" x2="0.85" y2="1.25" layer="51"/>
<rectangle x1="-0.85" y1="-1.65" x2="0.85" y2="-0.95" layer="51"/>
<rectangle x1="-0.85" y1="0.35" x2="-0.525" y2="0.775" layer="21"/>
<rectangle x1="0.525" y1="0.35" x2="0.85" y2="0.775" layer="21"/>
<rectangle x1="-0.175" y1="0" x2="0.175" y2="0.35" layer="21"/>
</package>
<package name="CHIPLED_0603">
Source: http://www.osram.convergy.de/ ... LG_LY Q971.pdf</description>
<wire x1="-0.3" y1="0.8" x2="0.3" y2="0.8" width="0.1016" layer="51" curve="170.055574"/>
<wire x1="-0.275" y1="-0.825" x2="0.275" y2="-0.825" width="0.0508" layer="51" curve="-180"/>
<wire x1="-0.4" y1="0.375" x2="-0.4" y2="-0.35" width="0.1016" layer="51"/>
<wire x1="0.4" y1="0.35" x2="0.4" y2="-0.35" width="0.1016" layer="51"/>
<circle x="-0.35" y="0.625" radius="0.075" width="0.0508" layer="51"/>
<text x="-0.635" y="-1.27" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="1.905" y="-1.27" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-0.45" y1="0.7" x2="-0.25" y2="0.85" layer="51"/>
<rectangle x1="-0.275" y1="0.55" x2="-0.225" y2="0.6" layer="51"/>
<rectangle x1="-0.45" y1="0.35" x2="-0.4" y2="0.725" layer="51"/>
<rectangle x1="0.25" y1="0.55" x2="0.45" y2="0.85" layer="51"/>
<rectangle x1="-0.45" y1="0.35" x2="0.45" y2="0.575" layer="51"/>
<rectangle x1="-0.45" y1="-0.85" x2="-0.25" y2="-0.35" layer="51"/>
<rectangle x1="0.25" y1="-0.85" x2="0.45" y2="-0.35" layer="51"/>
<rectangle x1="-0.275" y1="-0.575" x2="0.275" y2="-0.35" layer="51"/>
<rectangle x1="-0.275" y1="-0.65" x2="-0.175" y2="-0.55" layer="51"/>
<rectangle x1="0.175" y1="-0.65" x2="0.275" y2="-0.55" layer="51"/>
<rectangle x1="-0.125" y1="0" x2="0.125" y2="0.25" layer="21"/>
</package>
<package name="CHIPLED-0603-TTW">
<description>&lt;b&gt;CHIPLED-0603&lt;/b&gt;&lt;p&gt;
Recommended Solder Pad useable for SmartLEDTM and Chipled - Package 0603&lt;br&gt;
Package able to withstand TTW-soldering heat&lt;br&gt;
Package suitable for TTW-soldering&lt;br&gt;
Source: http://www.osram.convergy.de/ ... LO_LS_LY L89K.pdf</description>
<smd name="C" x="0" y="0.875" dx="0.8" dy="0.5" layer="1" stop="no" cream="no"/>
<smd name="A" x="0" y="-0.875" dx="0.8" dy="0.5" layer="1" stop="no" cream="no"/>
<smd name="A@1" x="0" y="-0.5" dx="0.35" dy="0.35" layer="1"/>
<smd name="C@1" x="0" y="0.5" dx="0.35" dy="0.35" layer="1"/>
<rectangle x1="-0.175" y1="0.325" x2="0.175" y2="0.7" layer="29"/>
<rectangle x1="-0.4" y1="0.625" x2="0.4" y2="1.125" layer="29"/>
<rectangle x1="-0.4" y1="-1.125" x2="0.4" y2="-0.625" layer="29"/>
<rectangle x1="-0.175" y1="-0.675" x2="0.175" y2="-0.325" layer="29"/>
</package>
<package name="SMARTLED-TTW">
<description>&lt;b&gt;SmartLED TTW&lt;/b&gt;&lt;p&gt;
<smd name="A@1" x="0" y="-0.5" dx="0.35" dy="0.35" layer="1" stop="no" cream="no"/>
<smd name="C@1" x="0" y="0.5" dx="0.35" dy="0.35" layer="1" stop="no" cream="no"/>
<rectangle x1="-0.225" y1="0.3" x2="0.225" y2="0.975" layer="31"/>
<rectangle x1="-0.175" y1="-0.7" x2="0.175" y2="-0.325" layer="29" rot="R180"/>
<rectangle x1="-0.225" y1="-0.975" x2="0.225" y2="-0.3" layer="31" rot="R180"/>
</package>
<package name="LUMILED+">
<description>&lt;b&gt;Lumileds Lighting. LUXEON®&lt;/b&gt; with cool pad&lt;p&gt;
Source: K2.pdf</description>
<wire x1="-3.575" y1="2.3375" x2="-2.3375" y2="3.575" width="0.2032" layer="21"/>
<wire x1="-2.3375" y1="3.575" x2="2.3375" y2="3.575" width="0.2032" layer="21"/>
<wire x1="3.575" y1="2.3375" x2="3.575" y2="-3.575" width="0.2032" layer="21"/>
<wire x1="3.575" y1="-3.575" x2="-2.3375" y2="-3.575" width="0.2032" layer="21"/>
<wire x1="-2.3375" y1="-3.575" x2="-2.5" y2="-3.4125" width="0.2032" layer="21"/>
<wire x1="-2.5" y1="-3.4125" x2="-3.4125" y2="-2.5" width="0.2032" layer="21" curve="167.429893"/>
<wire x1="-3.4125" y1="-2.5" x2="-3.575" y2="-2.3375" width="0.2032" layer="21"/>
<wire x1="-3.575" y1="-2.3375" x2="-3.575" y2="2.3375" width="0.2032" layer="21"/>
<wire x1="2.3375" y1="3.575" x2="2.5" y2="3.4125" width="0.2032" layer="21"/>
<wire x1="2.5" y1="3.4125" x2="3.4125" y2="2.5" width="0.2032" layer="21" curve="167.429893"/>
<wire x1="3.4125" y1="2.5" x2="3.575" y2="2.3375" width="0.2032" layer="21"/>
<wire x1="-1.725" y1="2.225" x2="-1.0625" y2="2.5625" width="0.2032" layer="21" curve="-255.44999"/>
<wire x1="1.725" y1="-2.225" x2="1.0625" y2="-2.5625" width="0.2032" layer="21" curve="-255.44999"/>
<circle x="0" y="0" radius="2.725" width="0.2032" layer="51"/>
<smd name="1NC" x="-5.2" y="1.15" dx="2.9" dy="1.7" layer="1"/>
<smd name="2+" x="-5.2" y="-1.15" dx="2.9" dy="1.7" layer="1"/>
<smd name="3NC" x="5.2" y="-1.15" dx="2.9" dy="1.7" layer="1" rot="R180"/>
<smd name="4-" x="5.2" y="1.15" dx="2.9" dy="1.7" layer="1" rot="R180"/>
<text x="-3.175" y="3.81" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.175" y="-5.08" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-5.975" y1="0.575" x2="-3.625" y2="1.6" layer="51"/>
<rectangle x1="-5.975" y1="-1.6" x2="-3.625" y2="-0.575" layer="51"/>
<rectangle x1="3.625" y1="-1.6" x2="5.975" y2="-0.575" layer="51" rot="R180"/>
<rectangle x1="3.625" y1="0.575" x2="5.975" y2="1.6" layer="51" rot="R180"/>
<polygon width="0.4064" layer="1">
<vertex x="2.3383" y="1.35"/>
<vertex x="0" y="2.7"/>
<vertex x="-2.3383" y="1.35"/>
<vertex x="-2.3383" y="-1.35"/>
<vertex x="0" y="-2.7"/>
<vertex x="2.3383" y="-1.35"/>
</polygon>
<polygon width="0.4064" layer="29">
</polygon>
<polygon width="0.4064" layer="31">
</polygon>
</package>
<package name="LUMILED">
<description>&lt;b&gt;Lumileds Lighting. LUXEON®&lt;/b&gt; without cool pad&lt;p&gt;
</polygon>
</polygon>
</package>
<package name="LED10MM">
10 mm, round</description>
<wire x1="5.08" y1="-2.54" x2="5.08" y2="2.54" width="0.254" layer="21" curve="-306.869898"/>
<wire x1="4.445" y1="0" x2="0" y2="-4.445" width="0.127" layer="21" curve="-90"/>
<wire x1="3.81" y1="0" x2="0" y2="-3.81" width="0.127" layer="21" curve="-90"/>
<wire x1="3.175" y1="0" x2="0" y2="-3.175" width="0.127" layer="21" curve="-90"/>
<wire x1="2.54" y1="0" x2="0" y2="-2.54" width="0.127" layer="21" curve="-90"/>
<wire x1="-4.445" y1="0" x2="0" y2="4.445" width="0.127" layer="21" curve="-90"/>
<wire x1="-3.81" y1="0" x2="0" y2="3.81" width="0.127" layer="21" curve="-90"/>
<wire x1="-3.175" y1="0" x2="0" y2="3.175" width="0.127" layer="21" curve="-90"/>
<wire x1="-2.54" y1="0" x2="0" y2="2.54" width="0.127" layer="21" curve="-90"/>
<wire x1="5.08" y1="2.54" x2="5.08" y2="-2.54" width="0.254" layer="21"/>
<circle x="0" y="0" radius="5.08" width="0.127" layer="21"/>
<pad name="K" x="1.27" y="0" drill="0.8128" diameter="1.6764" shape="square"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" diameter="1.6764" shape="octagon"/>
<text x="6.35" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="6.35" y="-1.27" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="KA-3528ASYC">
<description>&lt;b&gt;SURFACE MOUNT LED LAMP&lt;/b&gt; 3.5x2.8mm&lt;p&gt;
Source: http://www.kingbright.com/manager/upload/pdf/KA-3528ASYC(Ver1189474662.1)</description>
<wire x1="-1.55" y1="1.35" x2="1.55" y2="1.35" width="0.1016" layer="21"/>
<wire x1="1.55" y1="1.35" x2="1.55" y2="-1.35" width="0.1016" layer="51"/>
<wire x1="1.55" y1="-1.35" x2="-1.55" y2="-1.35" width="0.1016" layer="21"/>
<wire x1="-1.55" y1="-1.35" x2="-1.55" y2="1.35" width="0.1016" layer="51"/>
<wire x1="-0.65" y1="0.95" x2="0.65" y2="0.95" width="0.1016" layer="21" curve="-68.40813"/>
<wire x1="0.65" y1="-0.95" x2="-0.65" y2="-0.95" width="0.1016" layer="21" curve="-68.40813"/>
<circle x="0" y="0" radius="1.15" width="0.1016" layer="51"/>
<smd name="A" x="-1.55" y="0" dx="1.5" dy="2.2" layer="1"/>
<smd name="C" x="1.55" y="0" dx="1.5" dy="2.2" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.75" y1="0.6" x2="-1.6" y2="1.1" layer="51"/>
<rectangle x1="-1.75" y1="-1.1" x2="-1.6" y2="-0.6" layer="51"/>
<rectangle x1="1.6" y1="-1.1" x2="1.75" y2="-0.6" layer="51" rot="R180"/>
<rectangle x1="1.6" y1="0.6" x2="1.75" y2="1.1" layer="51" rot="R180"/>
<polygon width="0.1016" layer="51">
<vertex x="1.55" y="-1.35"/>
<vertex x="1.55" y="-0.625"/>
<vertex x="0.825" y="-1.35"/>
</polygon>
<polygon width="0.1016" layer="21">
<vertex x="1.55" y="-1.175"/>
<vertex x="1" y="-1.175"/>
</polygon>
</package>
<package name="SML0805">
<description>&lt;b&gt;SML0805-2CW-TR (0805 PROFILE)&lt;/b&gt; COOL WHITE&lt;p&gt;
Source: http://www.ledtronics.com/ds/smd-0603/Dstr0093.pdf</description>
<wire x1="-0.95" y1="-0.55" x2="0.95" y2="-0.55" width="0.1016" layer="51"/>
<wire x1="0.95" y1="-0.55" x2="0.95" y2="0.55" width="0.1016" layer="51"/>
<wire x1="0.95" y1="0.55" x2="-0.95" y2="0.55" width="0.1016" layer="51"/>
<wire x1="-0.95" y1="0.55" x2="-0.95" y2="-0.55" width="0.1016" layer="51"/>
<wire x1="-0.175" y1="-0.025" x2="0" y2="0.15" width="0.0634" layer="21"/>
<wire x1="0" y1="0.15" x2="0.15" y2="0" width="0.0634" layer="21"/>
<wire x1="0.15" y1="0" x2="-0.025" y2="-0.175" width="0.0634" layer="21"/>
<wire x1="-0.025" y1="-0.175" x2="-0.175" y2="-0.025" width="0.0634" layer="21"/>
<circle x="-0.275" y="0.4" radius="0.125" width="0" layer="21"/>
<smd name="C" x="-1.05" y="0" dx="1.2" dy="1.2" layer="1"/>
<smd name="A" x="1.05" y="0" dx="1.2" dy="1.2" layer="1"/>
<text x="-1.5" y="1" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.5" y="-2" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="SML1206">
<description>&lt;b&gt;SML10XXKH-TR (HIGH INTENSITY) LED&lt;/b&gt;&lt;p&gt;
&lt;table&gt;
&lt;tr&gt;&lt;td&gt;SML10R3KH-TR&lt;/td&gt;&lt;td&gt;ULTRA RED&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;SML10E3KH-TR&lt;/td&gt;&lt;td&gt;SUPER REDSUPER BLUE&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;SML10O3KH-TR&lt;/td&gt;&lt;td&gt;SUPER ORANGE&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;SML10PY3KH-TR&lt;/td&gt;&lt;td&gt;PURE YELLOW&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;SML10OY3KH-TR&lt;/td&gt;&lt;td&gt;ULTRA YELLOW&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;SML10AG3KH-TR&lt;/td&gt;&lt;td&gt;AQUA GREEN&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;SML10BG3KH-TR&lt;/td&gt;&lt;td&gt;BLUE GREEN&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;SML10PB1KH-TR&lt;/td&gt;&lt;td&gt;SUPER BLUE&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;SML10CW1KH-TR&lt;/td&gt;&lt;td&gt;WHITE&lt;/td&gt;&lt;/tr&gt;
&lt;/table&gt;
Source: http://www.ledtronics.com/ds/smd-1206/dstr0094.PDF</description>
<wire x1="-1.5" y1="0.5" x2="-1.5" y2="-0.5" width="0.2032" layer="51" curve="-180"/>
<wire x1="1.5" y1="-0.5" x2="1.5" y2="0.5" width="0.2032" layer="51" curve="-180"/>
<circle x="-0.725" y="0.525" radius="0.125" width="0" layer="21"/>
<smd name="C" x="-1.75" y="0" dx="1.5" dy="1.5" layer="1"/>
<smd name="A" x="1.75" y="0" dx="1.5" dy="1.5" layer="1"/>
<text x="-1.5" y="-2.5" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="0.4" x2="-1.15" y2="0.8" layer="51"/>
<rectangle x1="-1.6" y1="-0.8" x2="-1.15" y2="-0.4" layer="51"/>
<rectangle x1="-1.175" y1="-0.6" x2="-1" y2="-0.275" layer="51"/>
<rectangle x1="1.15" y1="-0.8" x2="1.6" y2="-0.4" layer="51" rot="R180"/>
<rectangle x1="1.15" y1="0.4" x2="1.6" y2="0.8" layer="51" rot="R180"/>
<rectangle x1="1" y1="0.275" x2="1.175" y2="0.6" layer="51" rot="R180"/>
</package>
<package name="SML0603">
<description>&lt;b&gt;SML0603-XXX (HIGH INTENSITY) LED&lt;/b&gt;&lt;p&gt;
&lt;table&gt;
&lt;tr&gt;&lt;td&gt;AG3K&lt;/td&gt;&lt;td&gt;AQUA GREEN&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;B1K&lt;/td&gt;&lt;td&gt;SUPER BLUE&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;R1K&lt;/td&gt;&lt;td&gt;SUPER RED&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;R3K&lt;/td&gt;&lt;td&gt;ULTRA RED&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;O3K&lt;/td&gt;&lt;td&gt;SUPER ORANGE&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;O3KH&lt;/td&gt;&lt;td&gt;SOFT ORANGE&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;Y3KH&lt;/td&gt;&lt;td&gt;SUPER YELLOW&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;Y3K&lt;/td&gt;&lt;td&gt;SUPER YELLOW&lt;/td&gt;&lt;/tr&gt;
&lt;tr&gt;&lt;td&gt;2CW&lt;/td&gt;&lt;td&gt;WHITE&lt;/td&gt;&lt;/tr&gt;
&lt;/table&gt;
Source: http://www.ledtronics.com/ds/smd-0603/Dstr0092.pdf</description>
<wire x1="-0.75" y1="0.35" x2="0.75" y2="0.35" width="0.1016" layer="51"/>
<wire x1="0.75" y1="0.35" x2="0.75" y2="-0.35" width="0.1016" layer="51"/>
<wire x1="0.75" y1="-0.35" x2="-0.75" y2="-0.35" width="0.1016" layer="51"/>
<wire x1="-0.75" y1="-0.35" x2="-0.75" y2="0.35" width="0.1016" layer="51"/>
<wire x1="-0.45" y1="0.3" x2="-0.45" y2="-0.3" width="0.1016" layer="51"/>
<wire x1="0.45" y1="0.3" x2="0.45" y2="-0.3" width="0.1016" layer="51"/>
<wire x1="-0.2" y1="0.35" x2="0.2" y2="0.35" width="0.1016" layer="21"/>
<wire x1="-0.2" y1="-0.35" x2="0.2" y2="-0.35" width="0.1016" layer="21"/>
<smd name="C" x="-0.75" y="0" dx="0.8" dy="0.8" layer="1"/>
<smd name="A" x="0.75" y="0" dx="0.8" dy="0.8" layer="1"/>
<text x="-1" y="1" size="1.27" layer="25">&gt;NAME</text>
<text x="-1" y="-2" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.4" y1="0.175" x2="0" y2="0.4" layer="51"/>
<rectangle x1="-0.25" y1="0.175" x2="0" y2="0.4" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="LED">
<wire x1="1.27" y1="0" x2="0" y2="-2.54" width="0.254" layer="94"/>
<wire x1="0" y1="-2.54" x2="-1.27" y2="0" width="0.254" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="0" y2="-2.54" width="0.254" layer="94"/>
<wire x1="0" y1="-2.54" x2="-1.27" y2="-2.54" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="-1.27" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="-2.032" y1="-0.762" x2="-3.429" y2="-2.159" width="0.1524" layer="94"/>
<wire x1="-1.905" y1="-1.905" x2="-3.302" y2="-3.302" width="0.1524" layer="94"/>
<text x="3.556" y="-4.572" size="1.778" layer="95" rot="R90">&gt;NAME</text>
<text x="5.715" y="-4.572" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="C" x="0" y="-5.08" visible="off" length="short" direction="pas" rot="R90"/>
<pin name="A" x="0" y="2.54" visible="off" length="short" direction="pas" rot="R270"/>
<polygon width="0.1524" layer="94">
<vertex x="-3.429" y="-2.159"/>
<vertex x="-3.048" y="-1.27"/>
<vertex x="-2.54" y="-1.778"/>
</polygon>
<vertex x="-3.302" y="-3.302"/>
<vertex x="-2.921" y="-2.413"/>
<vertex x="-2.413" y="-2.921"/>
</polygon>
</symbol>
</symbols>
<devicesets>
<deviceset name="LED" prefix="LED" uservalue="yes">
<description>&lt;b&gt;LED&lt;/b&gt;&lt;p&gt;
&lt;u&gt;OSRAM&lt;/u&gt;:&lt;br&gt;
- &lt;u&gt;CHIPLED&lt;/u&gt;&lt;br&gt;
LG R971, LG N971, LY N971, LG Q971, LY Q971, LO R971, LY R971
LH N974, LH R974&lt;br&gt;
LS Q976, LO Q976, LY Q976&lt;br&gt;
LO Q996&lt;br&gt;
- &lt;u&gt;Hyper CHIPLED&lt;/u&gt;&lt;br&gt;
LW Q18S&lt;br&gt;
LB Q993, LB Q99A, LB R99A&lt;br&gt;
- &lt;u&gt;SideLED&lt;/u&gt;&lt;br&gt;
LS A670, LO A670, LY A670, LG A670, LP A670&lt;br&gt;
LB A673, LV A673, LT A673, LW A673&lt;br&gt;
LH A674&lt;br&gt;
LY A675&lt;br&gt;
LS A676, LA A676, LO A676, LY A676, LW A676&lt;br&gt;
LS A679, LY A679, LG A679&lt;br&gt;
-  &lt;u&gt;Hyper Micro SIDELED®&lt;/u&gt;&lt;br&gt;
LS Y876, LA Y876, LO Y876, LY Y876&lt;br&gt;
LT Y87S&lt;br&gt;
- &lt;u&gt;SmartLED&lt;/u&gt;&lt;br&gt;
LW L88C, LW L88S&lt;br&gt;
LB L89C, LB L89S, LG L890&lt;br&gt;
LS L89K, LO L89K, LY L89K&lt;br&gt;
LS L896, LA L896, LO L896, LY L896&lt;br&gt;
- &lt;u&gt;TOPLED&lt;/u&gt;&lt;br&gt;
LS T670, LO T670, LY T670, LG T670, LP T670&lt;br&gt;
LSG T670, LSP T670, LSY T670, LOP T670, LYG T670&lt;br&gt;
LG T671, LOG T671, LSG T671&lt;br&gt;
LB T673, LV T673, LT T673, LW T673&lt;br&gt;
LH T674&lt;br&gt;
LS T676, LA T676, LO T676, LY T676, LB T676, LH T676, LSB T676, LW T676&lt;br&gt;
LB T67C, LV T67C, LT T67C, LS T67K, LO T67K, LY T67K, LW E67C&lt;br&gt;
LS E67B, LA E67B, LO E67B, LY E67B, LB E67C, LV E67C, LT E67C&lt;br&gt;
LW T67C&lt;br&gt;
LS T679, LY T679, LG T679&lt;br&gt;
LS T770, LO T770, LY T770, LG T770, LP T770&lt;br&gt;
LB T773, LV T773, LT T773, LW T773&lt;br&gt;
LH T774&lt;br&gt;
LS E675, LA E675, LY E675, LS T675&lt;br&gt;
LS T776, LA T776, LO T776, LY T776, LB T776&lt;br&gt;
LHGB T686&lt;br&gt;
LT T68C, LB T68C&lt;br&gt;
- &lt;u&gt;Hyper Mini TOPLED®&lt;/u&gt;&lt;br&gt;
LB M676&lt;br&gt;
- &lt;u&gt;Mini TOPLED Santana®&lt;/u&gt;&lt;br&gt;
LG M470&lt;br&gt;
LS M47K, LO M47K, LY M47K
&lt;p&gt;
Source: http://www.osram.convergy.de&lt;p&gt;
&lt;u&gt;LUXEON:&lt;/u&gt;&lt;br&gt;
- &lt;u&gt;LUMILED®&lt;/u&gt;&lt;br&gt;
LXK2-PW12-R00, LXK2-PW12-S00, LXK2-PW14-U00, LXK2-PW14-V00&lt;br&gt;
LXK2-PM12-R00, LXK2-PM12-S00, LXK2-PM14-U00&lt;br&gt;
LXK2-PE12-Q00, LXK2-PE12-R00, LXK2-PE12-S00, LXK2-PE14-T00, LXK2-PE14-U00&lt;br&gt;
LXK2-PB12-K00, LXK2-PB12-L00, LXK2-PB12-M00, LXK2-PB14-N00, LXK2-PB14-P00, LXK2-PB14-Q00&lt;br&gt;
LXK2-PR12-L00, LXK2-PR12-M00, LXK2-PR14-Q00, LXK2-PR14-R00&lt;br&gt;
LXK2-PD12-Q00, LXK2-PD12-R00, LXK2-PD12-S00&lt;br&gt;
LXK2-PH12-R00, LXK2-PH12-S00&lt;br&gt;
LXK2-PL12-P00, LXK2-PL12-Q00, LXK2-PL12-R00
&lt;p&gt;
Source: www.luxeon.com&lt;p&gt;
&lt;u&gt;KINGBRIGHT:&lt;/U&gt;&lt;p&gt;
KA-3528ASYC&lt;br&gt;
Source: www.kingbright.com</description>
<gates>
<gate name="G$1" symbol="LED" x="0" y="0"/>
</gates>
<devices>
<device name="SMT1206" package="1206">
<connects>
<connect gate="G$1" pin="A" pad="A"/>
<connect gate="G$1" pin="C" pad="C"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="LD260" package="LD260">
<connects>
<connect gate="G$1" pin="C" pad="K"/>
</connects>
<technologies>
</technologies>
</device>
<device name="SQR2X5" package="LED2X5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="3MM" package="LED3MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="5MM" package="LED5MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LSU260" package="LSU260">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="LZR181" package="LZR181">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B152" package="Q62902-B152">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B153" package="Q62902-B153">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B155" package="Q62902-B155">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="B156" package="Q62902-B156">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SFH480" package="SFH480">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SFH482" package="SFH482">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SQR5.7X3.2" package="U57X32">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="IRL80A" package="IRL80A">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P-LCC-2" package="P-LCC-2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MINI-TOP" package="OSRAM-MINI-TOP-LED">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SIDELED" package="OSRAM-SIDELED">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMART-LED" package="SMART-LED">
<connects>
<connect gate="G$1" pin="C" pad="B"/>
</connects>
<technologies>
</technologies>
</device>
<device name="P-LCC-2-BACK" package="P-LCC-2-TOPLED-RG">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MICRO-SIDELED" package="MICRO-SIDELED">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P-LCC-4" package="P-LCC-4">
<connects>
<connect gate="G$1" pin="C" pad="C@4"/>
</connects>
<technologies>
</technologies>
</device>
<device name="CHIP-LED0603" package="CHIP-LED0603">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CHIP-LED0805" package="CHIP-LED0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="TOPLED-SANTANA" package="MINI-TOPLED-SANTANA">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CHIPLED_0805" package="CHIPLED_0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CHIPLED_1206" package="CHIPLED_1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CHIPLED_0603" package="CHIPLED_0603">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="CHIPLED-0603-TTW" package="CHIPLED-0603-TTW">
<connects>
<connect gate="G$1" pin="A" pad="A@1"/>
<connect gate="G$1" pin="C" pad="C@1"/>
</connects>
<technologies>
</technologies>
</device>
<device name="" package="SMARTLED-TTW">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-LUMILED+" package="LUMILED+">
<connects>
<connect gate="G$1" pin="A" pad="2+"/>
<connect gate="G$1" pin="C" pad="4-"/>
</connects>
<technologies>
</technologies>
</device>
<device name="-LUMILED" package="LUMILED">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="10MM" package="LED10MM">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="KA-3528ASYC" package="KA-3528ASYC">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SML0805" package="SML0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SML1206" package="SML1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SML0603" package="SML0603">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="pinhead">
<description>&lt;b&gt;Pin Header Connectors&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="1X02">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<wire x1="-1.905" y1="1.27" x2="-0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="-0.635" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.27" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.635" x2="2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<pad name="1" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-2.6162" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.524" y1="-0.254" x2="-1.016" y2="0.254" layer="51"/>
<rectangle x1="1.016" y1="-0.254" x2="1.524" y2="0.254" layer="51"/>
</package>
<package name="1X02/90">
<wire x1="-2.54" y1="-1.905" x2="0" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="0" y1="-1.905" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.635" x2="-2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="6.985" x2="-1.27" y2="1.27" width="0.762" layer="21"/>
<wire x1="0" y1="-1.905" x2="2.54" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="0.635" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="6.985" x2="1.27" y2="1.27" width="0.762" layer="21"/>
<pad name="1" x="-1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="1.27" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-3.175" y="-3.81" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="4.445" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-1.651" y1="0.635" x2="-0.889" y2="1.143" layer="21"/>
<rectangle x1="0.889" y1="0.635" x2="1.651" y2="1.143" layer="21"/>
<rectangle x1="-1.651" y1="-2.921" x2="-0.889" y2="-1.905" layer="21"/>
<rectangle x1="0.889" y1="-2.921" x2="1.651" y2="-1.905" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="PINHD2">
<wire x1="-6.35" y1="-2.54" x2="1.27" y2="-2.54" width="0.4064" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="1.27" y2="5.08" width="0.4064" layer="94"/>
<wire x1="1.27" y1="5.08" x2="-6.35" y2="5.08" width="0.4064" layer="94"/>
<wire x1="-6.35" y1="5.08" x2="-6.35" y2="-2.54" width="0.4064" layer="94"/>
<text x="-6.35" y="5.715" size="1.778" layer="95">&gt;NAME</text>
<text x="-6.35" y="-5.08" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-2.54" y="2.54" visible="pad" length="short" direction="pas" function="dot"/>
<pin name="2" x="-2.54" y="0" visible="pad" length="short" direction="pas" function="dot"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="PINHD-1X2" prefix="JP" uservalue="yes">
<gates>
<gate name="G$1" symbol="PINHD2" x="0" y="0"/>
</gates>
<devices>
<device name="" package="1X02">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/90" package="1X02/90">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="relay">
<description>&lt;b&gt;Relays&lt;/b&gt;&lt;p&gt;
&lt;ul&gt;
&lt;li&gt;Eichhoff
&lt;li&gt;Finder
&lt;li&gt;Fujitsu
&lt;li&gt;HAMLIN
&lt;li&gt;OMRON
&lt;li&gt;Matsushita
&lt;li&gt;NAiS
&lt;li&gt;Siemens
&lt;li&gt;Schrack
&lt;/ul&gt;
<packages>
<package name="G5LE">
<description>&lt;b&gt;RELAY&lt;/b&gt;&lt;p&gt;
1 x switch, 10 A/120 V AC, 8 A/30 V ADC, Omron</description>
<wire x1="-12.065" y1="8.255" x2="10.541" y2="8.255" width="0.1524" layer="21"/>
<wire x1="10.541" y1="-8.255" x2="10.541" y2="8.255" width="0.1524" layer="21"/>
<wire x1="10.541" y1="-8.255" x2="-12.065" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="8.255" x2="-12.065" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="5.969" x2="-4.445" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="5.969" x2="-4.445" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.635" x2="-5.715" y2="0.635" width="0.254" layer="21"/>
<wire x1="-5.715" y1="0.635" x2="-5.715" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-0.635" x2="-3.175" y2="0.635" width="0.254" layer="21"/>
<wire x1="-3.175" y1="0.635" x2="-4.445" y2="0.635" width="0.254" layer="21"/>
<wire x1="-5.715" y1="-0.635" x2="-4.445" y2="-0.635" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-0.635" x2="-4.445" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-0.635" x2="-3.175" y2="-0.635" width="0.254" layer="21"/>
<wire x1="-4.445" y1="-5.969" x2="-5.08" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-0.635" x2="-3.175" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0" x2="4.064" y2="0" width="0.1524" layer="21"/>
<wire x1="4.064" y1="0" x2="4.699" y2="0.635" width="0.254" layer="21"/>
<wire x1="4.699" y1="3.7338" x2="4.699" y2="0.635" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-0.635" x2="4.699" y2="-3.7592" width="0.1524" layer="21"/>
<wire x1="4.699" y1="0.635" x2="5.0292" y2="0.9398" width="0.254" layer="21"/>
<wire x1="-7.366" y1="0" x2="-6.35" y2="0" width="0.1524" layer="21"/>
<pad name="P" x="-9.525" y="0" drill="1.3208" shape="long"/>
<pad name="1" x="-7.493" y="-5.969" drill="1.3208" shape="long"/>
<pad name="2" x="-7.493" y="5.969" drill="1.3208" shape="long"/>
<pad name="O" x="4.699" y="5.969" drill="1.3208" shape="long"/>
<pad name="S" x="4.699" y="-5.969" drill="1.3208" shape="long"/>
<text x="12.827" y="-8.255" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="9.525" y="-7.62" size="1.778" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
</package>
</packages>
<symbols>
<symbol name="K">
<wire x1="-3.81" y1="-1.905" x2="-1.905" y2="-1.905" width="0.254" layer="94"/>
<wire x1="3.81" y1="-1.905" x2="3.81" y2="1.905" width="0.254" layer="94"/>
<wire x1="3.81" y1="1.905" x2="1.905" y2="1.905" width="0.254" layer="94"/>
<wire x1="-3.81" y1="1.905" x2="-3.81" y2="-1.905" width="0.254" layer="94"/>
<wire x1="0" y1="-2.54" x2="0" y2="-1.905" width="0.1524" layer="94"/>
<wire x1="0" y1="-1.905" x2="3.81" y2="-1.905" width="0.254" layer="94"/>
<wire x1="0" y1="2.54" x2="0" y2="1.905" width="0.1524" layer="94"/>
<wire x1="0" y1="1.905" x2="-3.81" y2="1.905" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-1.905" x2="1.905" y2="1.905" width="0.1524" layer="94"/>
<wire x1="-1.905" y1="-1.905" x2="0" y2="-1.905" width="0.254" layer="94"/>
<wire x1="1.905" y1="1.905" x2="0" y2="1.905" width="0.254" layer="94"/>
<text x="1.27" y="2.921" size="1.778" layer="96">&gt;VALUE</text>
<text x="1.27" y="5.08" size="1.778" layer="95">&gt;PART</text>
<pin name="2" x="0" y="-5.08" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="1" x="0" y="5.08" visible="pad" length="short" direction="pas" rot="R270"/>
</symbol>
<symbol name="U">
<wire x1="3.175" y1="5.08" x2="1.905" y2="5.08" width="0.254" layer="94"/>
<wire x1="-3.175" y1="5.08" x2="-1.905" y2="5.08" width="0.254" layer="94"/>
<wire x1="0" y1="1.27" x2="2.54" y2="5.715" width="0.254" layer="94"/>
<wire x1="0" y1="1.27" x2="0" y2="0" width="0.254" layer="94"/>
<circle x="0" y="1.27" radius="0.127" width="0.4064" layer="94"/>
<text x="2.54" y="0" size="1.778" layer="95">&gt;PART</text>
<pin name="O" x="5.08" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="S" x="-5.08" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="P" x="0" y="-2.54" visible="pad" length="short" direction="pas" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="G5L" prefix="K">
<gates>
<gate name="1" symbol="K" x="0" y="0" addlevel="must"/>
<gate name="2" symbol="U" x="17.78" y="-2.54" addlevel="always"/>
</gates>
<devices>
<device name="" package="G5LE">
<connects>
<connect gate="1" pin="1" pad="1"/>
<connect gate="1" pin="2" pad="2"/>
<connect gate="2" pin="O" pad="O"/>
<connect gate="2" pin="P" pad="P"/>
<connect gate="2" pin="S" pad="S"/>
</connects>
<technologies>
<technology name="">
<attribute name="MF" value="" constant="no"/>
<attribute name="MPN" value="" constant="no"/>
<attribute name="OC_FARNELL" value="unknown" constant="no"/>
<attribute name="OC_NEWARK" value="unknown" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="con-ptr500">
<description>&lt;b&gt;PTR Connectors&lt;/b&gt;&lt;p&gt;
Aug. 2004 / PTR Meßtechnik:&lt;br&gt;
Die Bezeichnung der Serie AK505 wurde geändert.&lt;br&gt;
Es handelt sich hierbei um AK500 in horizontaler Ausführung.&lt;p&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=LEFT&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Alte Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;Neue Bezeichnung&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AK505/2DS,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AK500/2DS-5.0-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;AKZ505/2,grau&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#0000FF"&gt;AKZ500/2-5.08-H-GRAU&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
  &lt;/TABLE&gt;
<packages>
<package name="AK300/3">
<description>&lt;b&gt;CONNECTOR&lt;/b&gt;</description>
<wire x1="7.5438" y1="6.223" x2="7.5438" y2="3.175" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="6.223" x2="-7.5438" y2="6.223" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="6.223" x2="8.0518" y2="6.223" width="0.1524" layer="21"/>
<wire x1="8.0518" y1="6.223" x2="8.0518" y2="1.397" width="0.1524" layer="21"/>
<wire x1="8.0518" y1="1.397" x2="7.5438" y2="1.651" width="0.1524" layer="21"/>
<wire x1="8.0518" y1="-5.461" x2="7.5438" y2="-5.207" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="-5.207" x2="7.5438" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="8.0518" y1="-3.81" x2="7.5438" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="-4.064" x2="7.5438" y2="-5.207" width="0.1524" layer="21"/>
<wire x1="8.0518" y1="-3.81" x2="8.0518" y2="-5.461" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-6.223" x2="-2.032" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="2.032" y1="0.254" x2="2.032" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-6.223" x2="2.032" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-6.223" x2="2.9718" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="-6.223" x2="-2.9718" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="-6.223" x2="-2.032" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-7.0358" y1="0.254" x2="-7.0358" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-7.5438" y1="-6.223" x2="-7.0358" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-7.0358" y1="-6.223" x2="-2.9718" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-4.318" x2="2.032" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-4.318" x2="-2.032" y2="0.254" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-4.318" x2="2.032" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="-4.318" x2="-7.0358" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="-4.318" x2="-2.9718" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-7.0358" y1="-4.318" x2="-7.0358" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-3.683" x2="1.651" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-3.683" x2="-1.651" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="-3.683" x2="-1.651" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-3.3528" y1="-3.683" x2="-3.3528" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-3.3528" y1="-3.683" x2="-6.6548" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-6.6548" y1="-3.683" x2="-6.6548" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-6.6548" y1="-0.508" x2="-6.2738" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-3.3528" y1="-0.508" x2="-3.7338" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-0.508" x2="-1.27" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-0.508" x2="1.27" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-7.5438" y1="-6.223" x2="-7.5438" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-7.5438" y1="0.635" x2="-7.5438" y2="3.175" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="1.651" x2="7.5438" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="0.635" x2="7.5438" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-7.5438" y1="3.175" x2="7.5438" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-7.5438" y1="3.175" x2="-7.5438" y2="6.223" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="3.175" x2="7.5438" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="3.429" x2="-2.032" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="5.969" x2="2.032" y2="5.969" width="0.1524" layer="21"/>
<wire x1="2.032" y1="5.969" x2="2.032" y2="3.429" width="0.1524" layer="21"/>
<wire x1="2.032" y1="3.429" x2="-2.032" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="3.429" x2="-2.9718" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="3.429" x2="-7.0358" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-7.0358" y1="3.429" x2="-7.0358" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="5.969" x2="-7.0358" y2="5.969" width="0.1524" layer="21"/>
<wire x1="1.4682" y1="4.0849" x2="1.5239" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="-1.4732" y1="4.1656" x2="1.5146" y2="4.1189" width="0.1524" layer="21" curve="75.530157"/>
<wire x1="-1.6256" y1="5.0038" x2="1.5288" y2="5.0588" width="0.1524" layer="21" curve="-100.022513"/>
<wire x1="-1.5748" y1="5.0546" x2="-1.4311" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="-1.6256" y1="4.445" x2="1.4224" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-1.4986" y1="4.318" x2="1.5494" y2="4.953" width="0.1524" layer="21"/>
<wire x1="-3.5102" y1="4.0849" x2="-3.4545" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="-6.4516" y1="4.1656" x2="-3.4638" y2="4.1188" width="0.1524" layer="21" curve="75.528719"/>
<wire x1="-6.604" y1="5.0038" x2="-3.4496" y2="5.0588" width="0.1524" layer="21" curve="-100.022513"/>
<wire x1="-6.5532" y1="5.0546" x2="-6.4095" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="-6.604" y1="4.445" x2="-3.556" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="4.318" x2="-3.429" y2="4.953" width="0.1524" layer="21"/>
<wire x1="-7.0358" y1="0.254" x2="-6.6548" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-2.9718" y1="0.254" x2="-3.3528" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-3.3528" y1="0.254" x2="-6.6548" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-7.5438" y1="0.635" x2="-6.6548" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.6548" y1="0.635" x2="-3.3528" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-3.3528" y1="0.635" x2="-1.651" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.5438" y1="0.635" x2="6.6548" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.651" y1="0.635" x2="-1.651" y2="0.635" width="0.1524" layer="51"/>
<wire x1="2.032" y1="0.254" x2="1.651" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="0.254" x2="-1.651" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0.254" x2="1.651" y2="0.254" width="0.1524" layer="51"/>
<wire x1="6.6548" y1="0.635" x2="3.3782" y2="0.635" width="0.1524" layer="51"/>
<wire x1="1.6764" y1="0.635" x2="3.3528" y2="0.635" width="0.1524" layer="21"/>
<wire x1="7.0358" y1="-6.223" x2="7.5438" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="7.0358" y1="0.254" x2="7.0358" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="7.0358" y1="-4.318" x2="7.0358" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="7.0358" y1="0.254" x2="6.6548" y2="0.254" width="0.1524" layer="21"/>
<wire x1="3.3782" y1="0.254" x2="6.6548" y2="0.254" width="0.1524" layer="51"/>
<wire x1="2.9718" y1="0.254" x2="3.3782" y2="0.254" width="0.1524" layer="21"/>
<wire x1="2.9718" y1="-6.223" x2="2.9718" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="2.9718" y1="-6.223" x2="7.0358" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="2.9718" y1="-4.318" x2="7.0358" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="6.6548" y1="-3.683" x2="3.3528" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="6.6548" y1="-3.683" x2="6.6548" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="6.6548" y1="-0.508" x2="6.2738" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="3.3528" y1="-0.508" x2="3.7084" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="3.3528" y1="-3.683" x2="3.3528" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="2.9718" y1="3.429" x2="2.9718" y2="5.969" width="0.1524" layer="21"/>
<wire x1="2.9718" y1="5.969" x2="7.0358" y2="5.969" width="0.1524" layer="21"/>
<wire x1="7.0358" y1="5.969" x2="7.0358" y2="3.429" width="0.1524" layer="21"/>
<wire x1="7.0358" y1="3.429" x2="2.9718" y2="3.429" width="0.1524" layer="21"/>
<wire x1="6.472" y1="4.0849" x2="6.5277" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="3.5306" y1="4.1656" x2="6.5184" y2="4.1189" width="0.1524" layer="21" curve="75.530157"/>
<wire x1="3.3782" y1="5.0038" x2="6.5324" y2="5.0586" width="0.1524" layer="21" curve="-100.0232"/>
<wire x1="3.429" y1="5.0546" x2="3.5727" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="3.3782" y1="4.445" x2="6.4262" y2="5.08" width="0.1524" layer="21"/>
<wire x1="3.5052" y1="4.318" x2="6.5532" y2="4.953" width="0.1524" layer="21"/>
<wire x1="2.9718" y1="-4.318" x2="2.9718" y2="0.254" width="0.1524" layer="21"/>
<pad name="1" x="-5.0038" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="3" x="5.0038" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-7.5692" y="6.731" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.5692" y="-8.636" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.985" y="1.27" size="1.27" layer="21" ratio="10">1</text>
<text x="-1.905" y="1.27" size="1.27" layer="21" ratio="10">2</text>
<text x="3.175" y="1.27" size="1.27" layer="21" ratio="10">3</text>
<rectangle x1="-6.2738" y1="-2.54" x2="-3.7338" y2="0.254" layer="51"/>
<rectangle x1="-1.27" y1="-2.54" x2="1.27" y2="0.254" layer="51"/>
<rectangle x1="3.7338" y1="-2.54" x2="6.2738" y2="0.254" layer="51"/>
</package>
<package name="AK300/2">
<wire x1="5.08" y1="6.223" x2="5.08" y2="3.175" width="0.1524" layer="21"/>
<wire x1="5.08" y1="6.223" x2="-5.08" y2="6.223" width="0.1524" layer="21"/>
<wire x1="5.08" y1="6.223" x2="5.588" y2="6.223" width="0.1524" layer="21"/>
<wire x1="5.588" y1="6.223" x2="5.588" y2="1.397" width="0.1524" layer="21"/>
<wire x1="5.588" y1="1.397" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-5.461" x2="5.08" y2="-5.207" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-5.207" x2="5.08" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-3.81" x2="5.08" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-4.064" x2="5.08" y2="-5.207" width="0.1524" layer="21"/>
<wire x1="5.588" y1="-3.81" x2="5.588" y2="-5.461" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-6.223" x2="0.4572" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="0.254" x2="4.5212" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-6.223" x2="4.5212" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="-6.223" x2="5.08" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="-6.223" x2="-0.4826" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="-6.223" x2="0.4572" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="0.254" x2="-4.5466" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-6.223" x2="-4.5466" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="-6.223" x2="-0.4826" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-4.318" x2="4.5212" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="-4.318" x2="0.4572" y2="0.254" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="-4.318" x2="4.5212" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="-4.318" x2="-4.5466" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="-4.318" x2="-0.4826" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="-4.318" x2="-4.5466" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="4.1402" y1="-3.683" x2="4.1402" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="4.1402" y1="-3.683" x2="0.8382" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="0.8382" y1="-3.683" x2="0.8382" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-0.8636" y1="-3.683" x2="-0.8636" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-0.8636" y1="-3.683" x2="-4.1656" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-4.1656" y1="-3.683" x2="-4.1656" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-4.1656" y1="-0.508" x2="-3.7846" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-0.8636" y1="-0.508" x2="-1.2446" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="0.8382" y1="-0.508" x2="1.2192" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="4.1402" y1="-0.508" x2="3.7592" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="-6.223" x2="-5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.635" x2="-5.08" y2="3.175" width="0.1524" layer="21"/>
<wire x1="5.08" y1="1.651" x2="5.08" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="5.08" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.175" x2="5.08" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="3.175" x2="-5.08" y2="6.223" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.175" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="3.429" x2="0.4572" y2="5.969" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="5.969" x2="4.5212" y2="5.969" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="5.969" x2="4.5212" y2="3.429" width="0.1524" layer="21"/>
<wire x1="4.5212" y1="3.429" x2="0.4572" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="3.429" x2="-0.4826" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="3.429" x2="-4.5466" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="3.429" x2="-4.5466" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="5.969" x2="-4.5466" y2="5.969" width="0.1524" layer="21"/>
<wire x1="3.9574" y1="4.0849" x2="4.0131" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="1.016" y1="4.1656" x2="4.0038" y2="4.1189" width="0.1524" layer="21" curve="75.530157"/>
<wire x1="0.8636" y1="5.0038" x2="4.0178" y2="5.0586" width="0.1524" layer="21" curve="-100.0232"/>
<wire x1="0.9144" y1="5.0546" x2="1.0581" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="0.8636" y1="4.445" x2="3.9116" y2="5.08" width="0.1524" layer="21"/>
<wire x1="0.9906" y1="4.318" x2="4.0386" y2="4.953" width="0.1524" layer="21"/>
<wire x1="-1.0464" y1="4.0849" x2="-0.9907" y2="5.0545" width="0.1524" layer="21" curve="90.564135"/>
<wire x1="-3.9878" y1="4.1656" x2="-1" y2="4.1188" width="0.1524" layer="21" curve="75.528719"/>
<wire x1="-4.1402" y1="5.0038" x2="-0.9858" y2="5.0588" width="0.1524" layer="21" curve="-100.022513"/>
<wire x1="-4.0894" y1="5.0546" x2="-3.9457" y2="4.1297" width="0.1524" layer="21" curve="104.208873"/>
<wire x1="-4.1402" y1="4.445" x2="-1.0922" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-4.0132" y1="4.318" x2="-0.9652" y2="4.953" width="0.1524" layer="21"/>
<wire x1="-4.5466" y1="0.254" x2="-4.1656" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-0.4826" y1="0.254" x2="-0.8636" y2="0.254" width="0.1524" layer="21"/>
<wire x1="-0.8636" y1="0.254" x2="-4.1656" y2="0.254" width="0.1524" layer="51"/>
<wire x1="-5.08" y1="0.635" x2="-4.1656" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-4.1656" y1="0.635" x2="-0.8636" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.8636" y1="0.635" x2="0.8382" y2="0.635" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0.635" x2="4.1402" y2="0.635" width="0.1524" layer="21"/>
<wire x1="4.1402" y1="0.635" x2="0.8382" y2="0.635" width="0.1524" layer="51"/>
<wire x1="4.5212" y1="0.254" x2="4.1402" y2="0.254" width="0.1524" layer="21"/>
<wire x1="0.4572" y1="0.254" x2="0.8382" y2="0.254" width="0.1524" layer="21"/>
<wire x1="0.8382" y1="0.254" x2="4.1402" y2="0.254" width="0.1524" layer="51"/>
<pad name="1" x="-2.5146" y="0" drill="1.3208" shape="long" rot="R90"/>
<pad name="2" x="2.4892" y="0" drill="1.3208" shape="long" rot="R90"/>
<text x="-5.08" y="6.731" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-8.636" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.4958" y="1.27" size="1.27" layer="21" ratio="10">1</text>
<text x="0.5842" y="1.27" size="1.27" layer="21" ratio="10">2</text>
<rectangle x1="-3.7846" y1="-2.54" x2="-1.2446" y2="0.254" layer="51"/>
<rectangle x1="1.2192" y1="-2.54" x2="3.7592" y2="0.254" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="KL">
<circle x="1.27" y="0" radius="1.27" width="0.254" layer="94"/>
<text x="-1.27" y="0.889" size="1.778" layer="95" rot="R180">&gt;NAME</text>
<pin name="KL" x="5.08" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="KLV">
<text x="-3.81" y="-3.683" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="AK300/3" prefix="X" uservalue="yes">
<gates>
<gate name="-1" symbol="KL" x="0" y="5.08" addlevel="always"/>
<gate name="-2" symbol="KL" x="0" y="0" addlevel="always"/>
<gate name="-3" symbol="KLV" x="0" y="-5.08" addlevel="always"/>
</gates>
<devices>
<device name="" package="AK300/3">
<connects>
<connect gate="-1" pin="KL" pad="1"/>
<connect gate="-2" pin="KL" pad="2"/>
<connect gate="-3" pin="KL" pad="3"/>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="AK300/2" prefix="X" uservalue="yes">
<gates>
<gate name="-2" symbol="KLV" x="0" y="0" addlevel="always"/>
</gates>
<devices>
<device name="" package="AK300/2">
<connects>
</connects>
<technologies>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="v-reg">
<description>&lt;b&gt;Voltage Regulators&lt;/b&gt;&lt;p&gt;
<packages>
<package name="78XXS">
<description>&lt;b&gt;VOLTAGE REGULATOR&lt;/b&gt;</description>
<wire x1="4.826" y1="-4.318" x2="5.08" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-4.318" x2="-4.826" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-4.064" x2="-4.826" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.143" x2="5.08" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-4.064" x2="-5.08" y2="-1.143" width="0.1524" layer="21"/>
<circle x="-4.6228" y="-3.7084" radius="0.254" width="0" layer="21"/>
<pad name="IN" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="GND" x="0" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="OUT" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-5.08" y="-6.0452" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-0.635" y="-3.81" size="1.27" layer="51" ratio="10">-</text>
<text x="-3.175" y="-3.81" size="1.27" layer="51" ratio="10">I</text>
<text x="1.905" y="-3.81" size="1.27" layer="51" ratio="10">O</text>
<rectangle x1="-5.334" y1="-1.27" x2="-3.429" y2="0" layer="21"/>
<rectangle x1="-3.429" y1="-0.762" x2="-1.651" y2="0" layer="21"/>
<rectangle x1="-1.651" y1="-1.27" x2="-0.889" y2="0" layer="21"/>
<rectangle x1="-0.889" y1="-0.762" x2="0.889" y2="0" layer="21"/>
<rectangle x1="0.889" y1="-1.27" x2="1.651" y2="0" layer="21"/>
<rectangle x1="1.651" y1="-0.762" x2="3.429" y2="0" layer="21"/>
<rectangle x1="3.429" y1="-1.27" x2="5.334" y2="0" layer="21"/>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="-0.762" layer="51"/>
<rectangle x1="-0.889" y1="-1.27" x2="0.889" y2="-0.762" layer="51"/>
<rectangle x1="1.651" y1="-1.27" x2="3.429" y2="-0.762" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="78XX">
<wire x1="-5.08" y1="-5.08" x2="5.08" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="5.08" y1="-5.08" x2="5.08" y2="2.54" width="0.4064" layer="94"/>
<wire x1="5.08" y1="2.54" x2="-5.08" y2="2.54" width="0.4064" layer="94"/>
<wire x1="-5.08" y1="2.54" x2="-5.08" y2="-5.08" width="0.4064" layer="94"/>
<text x="2.54" y="-7.62" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="-10.16" size="1.778" layer="96">&gt;VALUE</text>
<text x="-2.032" y="-4.318" size="1.524" layer="95">GND</text>
<text x="-4.445" y="-0.635" size="1.524" layer="95">IN</text>
<text x="0.635" y="-0.635" size="1.524" layer="95">OUT</text>
<pin name="IN" x="-7.62" y="0" visible="off" length="short" direction="in"/>
<pin name="GND" x="0" y="-7.62" visible="off" length="short" direction="in" rot="R90"/>
<pin name="OUT" x="7.62" y="0" visible="off" length="short" direction="pas" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="78XXS" prefix="IC" uservalue="yes">
<gates>
<gate name="1" symbol="78XX" x="0" y="0"/>
</gates>
<devices>
<device name="" package="78XXS">
<connects>
<connect gate="1" pin="GND" pad="GND"/>
<connect gate="1" pin="IN" pad="IN"/>
<connect gate="1" pin="OUT" pad="OUT"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="supply1">
<description>&lt;b&gt;Supply Symbols&lt;/b&gt;&lt;p&gt;
 GND, VCC, 0V, +5V, -5V, etc.&lt;p&gt;
 Please keep in mind, that these devices are necessary for the
 automatic wiring of the supply signals.&lt;p&gt;
 The pin name defined in the symbol is identical to the net which is to be wired automatically.&lt;p&gt;
 In this library the device names are the same as the pin names of the symbols, therefore the correct signal names appear next to the supply symbols in the schematic.&lt;p&gt;
<packages>
</packages>
<symbols>
<symbol name="+12V">
<wire x1="1.27" y1="-1.905" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="-1.27" y2="-1.905" width="0.254" layer="94"/>
<wire x1="1.27" y1="-0.635" x2="0" y2="1.27" width="0.254" layer="94"/>
<wire x1="0" y1="1.27" x2="-1.27" y2="-0.635" width="0.254" layer="94"/>
<text x="-2.54" y="-5.08" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="+12V" x="0" y="-2.54" visible="off" length="short" direction="sup" rot="R90"/>
</symbol>
<symbol name="GND">
<wire x1="-1.905" y1="0" x2="1.905" y2="0" width="0.254" layer="94"/>
<text x="-2.54" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<pin name="GND" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="+12V" prefix="P+">
<description>&lt;b&gt;SUPPLY SYMBOL&lt;/b&gt;</description>
<gates>
<gate name="1" symbol="+12V" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="GND" prefix="GND">
<gates>
<gate name="1" symbol="GND" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="40xx">
<description>&lt;b&gt;CMOS Logic Devices, 4000 Series&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola &lt;i&gt;CMOS LOGIC DATA&lt;/i&gt;; book, 02/88, DL131 REV 1
&lt;li&gt;http://www.elexp.com
&lt;li&gt;http://www.intersil.com
&lt;li&gt;http://www.ls3c.com.tw/product/1/COMOS.html
&lt;/ul&gt;
<packages>
<package name="DIL14">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="8.89" y1="2.921" x2="-8.89" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.921" x2="8.89" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="8.89" y1="2.921" x2="8.89" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.921" x2="-8.89" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.921" x2="-8.89" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="1.016" x2="-8.89" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-9.271" y="-3.048" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-6.731" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SO14">
<description>&lt;b&gt;Small Outline package&lt;/b&gt; 150 mil</description>
<wire x1="4.064" y1="1.9558" x2="-4.064" y2="1.9558" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-1.9558" x2="4.445" y2="-1.5748" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.445" y1="1.5748" x2="-4.064" y2="1.9558" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.064" y1="1.9558" x2="4.445" y2="1.5748" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.445" y1="-1.5748" x2="-4.064" y2="-1.9558" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.064" y1="-1.9558" x2="4.064" y2="-1.9558" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.5748" x2="4.445" y2="1.5748" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.5748" x2="-4.445" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.508" x2="-4.445" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-0.508" x2="-4.445" y2="-1.5748" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="0.508" x2="-4.445" y2="-0.508" width="0.1524" layer="21" curve="-180"/>
<wire x1="-4.445" y1="-1.6002" x2="4.445" y2="-1.6002" width="0.1524" layer="21"/>
<smd name="1" x="-3.81" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="14" x="-3.81" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="2" x="-2.54" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="3" x="-1.27" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="13" x="-2.54" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="12" x="-1.27" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="4" x="0" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="11" x="0" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="5" x="1.27" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="6" x="2.54" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="10" x="1.27" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="9" x="2.54" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="7" x="3.81" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="8" x="3.81" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<text x="-3.556" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.699" y="-1.778" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<rectangle x1="-0.254" y1="1.9558" x2="0.254" y2="3.0988" layer="51"/>
<rectangle x1="-4.064" y1="-3.0988" x2="-3.556" y2="-1.9558" layer="51"/>
<rectangle x1="-2.794" y1="-3.0988" x2="-2.286" y2="-1.9558" layer="51"/>
<rectangle x1="-1.524" y1="-3.0734" x2="-1.016" y2="-1.9304" layer="51"/>
<rectangle x1="-0.254" y1="-3.0988" x2="0.254" y2="-1.9558" layer="51"/>
<rectangle x1="-1.524" y1="1.9558" x2="-1.016" y2="3.0988" layer="51"/>
<rectangle x1="-2.794" y1="1.9558" x2="-2.286" y2="3.0988" layer="51"/>
<rectangle x1="-4.064" y1="1.9558" x2="-3.556" y2="3.0988" layer="51"/>
<rectangle x1="1.016" y1="1.9558" x2="1.524" y2="3.0988" layer="51"/>
<rectangle x1="2.286" y1="1.9558" x2="2.794" y2="3.0988" layer="51"/>
<rectangle x1="3.556" y1="1.9558" x2="4.064" y2="3.0988" layer="51"/>
<rectangle x1="1.016" y1="-3.0988" x2="1.524" y2="-1.9558" layer="51"/>
<rectangle x1="2.286" y1="-3.0988" x2="2.794" y2="-1.9558" layer="51"/>
<rectangle x1="3.556" y1="-3.0988" x2="4.064" y2="-1.9558" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="4013">
<wire x1="-7.62" y1="-7.62" x2="7.62" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="7.62" y1="-7.62" x2="7.62" y2="10.16" width="0.4064" layer="94"/>
<wire x1="7.62" y1="10.16" x2="-7.62" y2="10.16" width="0.4064" layer="94"/>
<wire x1="-7.62" y1="10.16" x2="-7.62" y2="-7.62" width="0.4064" layer="94"/>
<text x="-7.62" y="10.795" size="1.778" layer="95">&gt;NAME</text>
<text x="-7.62" y="-10.16" size="1.778" layer="96">&gt;VALUE</text>
<pin name="Q" x="12.7" y="7.62" length="middle" direction="out" rot="R180"/>
<pin name="!Q" x="12.7" y="-5.08" length="middle" direction="out" rot="R180"/>
<pin name="CLK" x="-12.7" y="0" length="middle" direction="in" function="clk"/>
<pin name="R" x="-12.7" y="-5.08" length="middle" direction="in"/>
<pin name="D" x="-12.7" y="2.54" length="middle" direction="in"/>
<pin name="S" x="-12.7" y="7.62" length="middle" direction="in"/>
</symbol>
<symbol name="PWRN">
<text x="-1.27" y="-0.635" size="1.778" layer="95">&gt;NAME</text>
<text x="1.905" y="2.54" size="1.27" layer="95" rot="R90">VDD</text>
<text x="1.905" y="-5.842" size="1.27" layer="95" rot="R90">VSS</text>
<pin name="VSS" x="0" y="-7.62" visible="pad" length="middle" direction="pwr" rot="R90"/>
<pin name="VDD" x="0" y="7.62" visible="pad" length="middle" direction="pwr" rot="R270"/>
</symbol>
<symbol name="4081">
<wire x1="-2.54" y1="5.08" x2="-2.54" y2="-5.08" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="5.08" x2="-2.54" y2="-5.08" width="0.4064" layer="94" curve="-180"/>
<text x="2.54" y="3.175" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="-5.08" size="1.778" layer="96">&gt;VALUE</text>
<pin name="I0" x="-7.62" y="2.54" visible="pad" length="middle" direction="in" swaplevel="1"/>
<pin name="I1" x="-7.62" y="-2.54" visible="pad" length="middle" direction="in" swaplevel="1"/>
<pin name="O" x="7.62" y="0" visible="pad" length="middle" direction="out" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="4013" prefix="IC">
<description>Dual D &lt;b&gt;FLIP FLOP&lt;/b&gt;, set/reset</description>
<gates>
<gate name="A" symbol="4013" x="20.32" y="0" swaplevel="1"/>
<gate name="B" symbol="4013" x="20.32" y="-25.4" swaplevel="1"/>
<gate name="P" symbol="PWRN" x="-5.08" y="0" addlevel="request"/>
</gates>
<devices>
<device name="N" package="DIL14">
<connects>
<connect gate="A" pin="!Q" pad="2"/>
<connect gate="A" pin="CLK" pad="3"/>
<connect gate="A" pin="D" pad="5"/>
<connect gate="A" pin="Q" pad="1"/>
<connect gate="A" pin="R" pad="4"/>
<connect gate="A" pin="S" pad="6"/>
<connect gate="B" pin="!Q" pad="12"/>
<connect gate="B" pin="CLK" pad="11"/>
<connect gate="B" pin="D" pad="9"/>
<connect gate="B" pin="Q" pad="13"/>
<connect gate="B" pin="R" pad="10"/>
<connect gate="B" pin="S" pad="8"/>
<connect gate="P" pin="VDD" pad="14"/>
<connect gate="P" pin="VSS" pad="7"/>
</connects>
<technologies>
</technologies>
</device>
<device name="D" package="SO14">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="4081" prefix="IC">
<description>Quad 2-input &lt;b&gt;AND&lt;/b&gt;</description>
<gates>
<gate name="A" symbol="4081" x="15.24" y="7.62" swaplevel="1"/>
<gate name="B" symbol="4081" x="15.24" y="-7.62" swaplevel="1"/>
<gate name="C" symbol="4081" x="38.1" y="7.62" swaplevel="1"/>
<gate name="D" symbol="4081" x="38.1" y="-7.62" swaplevel="1"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="I0" pad="1"/>
<connect gate="A" pin="I1" pad="2"/>
<connect gate="A" pin="O" pad="3"/>
<connect gate="B" pin="I0" pad="5"/>
<connect gate="B" pin="I1" pad="6"/>
<connect gate="B" pin="O" pad="4"/>
<connect gate="C" pin="I0" pad="8"/>
<connect gate="C" pin="I1" pad="9"/>
<connect gate="C" pin="O" pad="10"/>
<connect gate="D" pin="I0" pad="12"/>
<connect gate="D" pin="I1" pad="13"/>
<connect gate="D" pin="O" pad="11"/>
</connects>
<technologies>
</technologies>
</device>
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<parts>
<part name="R1" library="rcl" deviceset="R-EU_" device="0207/10" value="1k"/>
<part name="C1" library="rcl" deviceset="CPOL-EU" device="E3.5-10" value="470uF/50V"/>
<part name="D1" library="diode" deviceset="1N4148" device="DO35-10"/>
<part name="D2" library="diode" deviceset="1N4004" device="" value="1N4001"/>
<part name="T1" library="transistor" deviceset="*-NPN-" device="TO92-CBE" technology="BC337-40" value="BC337"/>
<part name="LED1" library="led" deviceset="LED" device="5MM" value="POWER"/>
<part name="START" library="pinhead" deviceset="PINHD-1X2" device=""/>
<part name="K2" library="relay" deviceset="G5L" device=""/>
<part name="SZIRÉNA" library="relay" deviceset="G5L" device=""/>
<part name="X1" library="con-ptr500" deviceset="AK300/3" device=""/>
<part name="X2" library="con-ptr500" deviceset="AK300/3" device=""/>
<part name="X3" library="con-ptr500" deviceset="AK300/2" device=""/>
<part name="IC1" library="v-reg" deviceset="78XXS" device="" value="7812"/>
<part name="P+1" library="supply1" deviceset="+12V" device=""/>
<part name="GND2" library="supply1" deviceset="GND" device=""/>
<part name="C2" library="rcl" deviceset="CPOL-EU" device="E3.5-10" value="470uF/50V"/>
<part name="GND3" library="supply1" deviceset="GND" device=""/>
<part name="P+3" library="supply1" deviceset="+12V" device=""/>
<part name="ÉRZÉKELŐK" library="con-ptr500" deviceset="AK300/2" device=""/>
<part name="GND4" library="supply1" deviceset="GND" device=""/>
<part name="C3" library="rcl" deviceset="CPOL-EU" device="E3.5-10" value="10uF/35V"/>
<part name="R2" library="rcl" deviceset="R-EU_" device="0207/10" value="10k"/>
<part name="GND5" library="supply1" deviceset="GND" device=""/>
<part name="IC3" library="40xx" deviceset="4013" device="N"/>
<part name="R3" library="rcl" deviceset="R-EU_" device="0207/10" value="10k"/>
<part name="RESET" library="pinhead" deviceset="PINHD-1X2" device=""/>
<part name="R4" library="rcl" deviceset="R-EU_" device="0207/10" value="10k"/>
<part name="GND6" library="supply1" deviceset="GND" device=""/>
<part name="C4" library="rcl" deviceset="CPOL-EU" device="E3.5-10" value="33uF/35V"/>
<part name="IC4" library="40xx" deviceset="4081" device="N"/>
<part name="R5" library="rcl" deviceset="R-EU_" device="0207/10" value="1k"/>
<part name="LED2" library="led" deviceset="LED" device="5MM" value="ESCAPE"/>
<part name="R6" library="rcl" deviceset="R-EU_" device="0207/10" value="1M"/>
<part name="C5" library="rcl" deviceset="CPOL-EU" device="E3.5-10" value="10uF/35V"/>
<part name="C6" library="rcl" deviceset="CPOL-EU" device="E3.5-10" value="22uF/35V"/>
<part name="GND7" library="supply1" deviceset="GND" device=""/>
<part name="ESCAPETIME" library="pinhead" deviceset="PINHD-1X2" device=""/>
<part name="R7" library="rcl" deviceset="R-EU_" device="0207/10" value="10k"/>
<part name="R8" library="rcl" deviceset="R-EU_" device="0207/10" value="1M"/>
<part name="C7" library="rcl" deviceset="CPOL-EU" device="E3.5-10" value="10uF/35V"/>
<part name="C8" library="rcl" deviceset="CPOL-EU" device="E3.5-10" value="10uF/35V"/>
<part name="J2" library="pinhead" deviceset="PINHD-1X2" device=""/>
<part name="J3" library="pinhead" deviceset="PINHD-1X2" device=""/>
<part name="C9" library="rcl" deviceset="CPOL-EU" device="E3.5-10" value="100uF/35V"/>
<part name="C10" library="rcl" deviceset="CPOL-EU" device="E3.5-10" value="100uF/35V"/>
<part name="R9" library="rcl" deviceset="R-EU_" device="0207/10" value="1M"/>
<part name="J4" library="pinhead" deviceset="PINHD-1X2" device=""/>
<part name="C11" library="rcl" deviceset="CPOL-EU" device="E3.5-10" value="100uF/35V"/>
<part name="D3" library="diode" deviceset="1N4148" device="DO35-10"/>
<part name="R10" library="rcl" deviceset="R-EU_" device="0207/10" value="10k"/>
<part name="T2" library="transistor" deviceset="*-NPN-" device="TO92-CBE" technology="BC337-40" value="BC337"/>
<part name="D4" library="diode" deviceset="1N4004" device="" value="1N4001"/>
<part name="R11" library="rcl" deviceset="R-EU_" device="0207/10" value="1k"/>
<part name="SZIRÉNALED" library="led" deviceset="LED" device="5MM" value="ESCAPE"/>
<part name="C12" library="rcl" deviceset="C-EU" device="050-025X075"/>
<part name="C13" library="rcl" deviceset="C-EU" device="050-025X075"/>
</parts>
<sheets>
<sheet>
<plain>
</plain>
<instances>
<instance part="R1" gate="G$1" x="20.32" y="35.56"/>
<instance part="C1" gate="G$1" x="12.7" y="66.04"/>
<instance part="D1" gate="G$1" x="30.48" y="-10.16"/>
<instance part="D2" gate="1" x="116.84" y="38.1" rot="R90"/>
<instance part="T1" gate="G$1" x="121.92" y="22.86"/>
<instance part="LED1" gate="G$1" x="30.48" y="35.56" rot="R90"/>
<instance part="START" gate="G$1" x="15.24" y="17.78" rot="R270"/>
<instance part="K2" gate="1" x="124.46" y="38.1"/>
<instance part="K2" gate="2" x="91.44" y="76.2"/>
<instance part="SZIRÉNA" gate="1" x="142.24" y="7.62"/>
<instance part="SZIRÉNA" gate="2" x="111.76" y="76.2"/>
<instance part="X1" gate="-1" x="86.36" y="63.5" rot="R90"/>
<instance part="X1" gate="-2" x="91.44" y="63.5" rot="R90"/>
<instance part="X1" gate="-3" x="96.52" y="63.5" rot="R90"/>
<instance part="X2" gate="-1" x="106.68" y="63.5" rot="R90"/>
<instance part="X2" gate="-2" x="111.76" y="63.5" rot="R90"/>
<instance part="X2" gate="-3" x="116.84" y="63.5" rot="R90"/>
<instance part="X3" gate="-1" x="0" y="73.66"/>
<instance part="X3" gate="-2" x="-2.54" y="-60.96"/>
<instance part="IC1" gate="1" x="27.94" y="73.66"/>
<instance part="P+1" gate="1" x="38.1" y="81.28"/>
<instance part="GND2" gate="1" x="12.7" y="53.34"/>
<instance part="C2" gate="G$1" x="43.18" y="66.04"/>
<instance part="GND3" gate="1" x="43.18" y="53.34"/>
<instance part="P+3" gate="1" x="0" y="50.8"/>
<instance part="ÉRZÉKELŐK" gate="-1" x="0" y="-27.94"/>
<instance part="ÉRZÉKELŐK" gate="-2" x="0" y="-40.64"/>
<instance part="GND4" gate="1" x="38.1" y="30.48"/>
<instance part="C3" gate="G$1" x="27.94" y="17.78"/>
<instance part="R2" gate="G$1" x="35.56" y="15.24" rot="R270"/>
<instance part="GND5" gate="1" x="27.94" y="2.54"/>
<instance part="IC3" gate="A" x="55.88" y="17.78"/>
<instance part="IC3" gate="B" x="55.88" y="-35.56"/>
<instance part="R3" gate="G$1" x="7.62" y="-20.32" rot="R270"/>
<instance part="RESET" gate="G$1" x="15.24" y="-20.32" rot="R270"/>
<instance part="R4" gate="G$1" x="40.64" y="-50.8" rot="R270"/>
<instance part="GND6" gate="1" x="7.62" y="-68.58"/>
<instance part="C4" gate="G$1" x="20.32" y="-33.02"/>
<instance part="IC4" gate="A" x="93.98" y="22.86"/>
<instance part="IC4" gate="B" x="88.9" y="-30.48"/>
<instance part="IC4" gate="C" x="124.46" y="-33.02"/>
<instance part="R5" gate="G$1" x="81.28" y="35.56"/>
<instance part="LED2" gate="G$1" x="91.44" y="35.56" rot="R90"/>
<instance part="R6" gate="G$1" x="73.66" y="15.24" rot="R270"/>
<instance part="C5" gate="G$1" x="73.66" y="2.54"/>
<instance part="C6" gate="G$1" x="88.9" y="2.54"/>
<instance part="GND7" gate="1" x="66.04" y="-10.16"/>
<instance part="ESCAPETIME" gate="G$1" x="88.9" y="12.7" rot="R90"/>
<instance part="R7" gate="G$1" x="111.76" y="22.86"/>
<instance part="R8" gate="G$1" x="73.66" y="-40.64" rot="R270"/>
<instance part="C7" gate="G$1" x="73.66" y="-53.34"/>
<instance part="C8" gate="G$1" x="88.9" y="-53.34"/>
<instance part="J2" gate="G$1" x="88.9" y="-43.18" rot="R90"/>
<instance part="J3" gate="G$1" x="104.14" y="-43.18" rot="R90"/>
<instance part="C9" gate="G$1" x="101.6" y="-53.34"/>
<instance part="C10" gate="G$1" x="109.22" y="-53.34"/>
<instance part="R9" gate="G$1" x="109.22" y="-40.64" rot="R270"/>
<instance part="J4" gate="G$1" x="124.46" y="-43.18" rot="R90"/>
<instance part="C11" gate="G$1" x="129.54" y="-53.34"/>
<instance part="D3" gate="G$1" x="78.74" y="-17.78" rot="R180"/>
<instance part="R10" gate="G$1" x="129.54" y="-12.7"/>
<instance part="T2" gate="G$1" x="139.7" y="-12.7"/>
<instance part="D4" gate="1" x="134.62" y="7.62" rot="R90"/>
<instance part="R11" gate="G$1" x="129.54" y="12.7" rot="R90"/>
<instance part="SZIRÉNALED" gate="G$1" x="129.54" y="2.54"/>
<instance part="IC3" gate="P" x="68.58" y="71.12" rot="R270"/>
<instance part="IC4" gate="P" x="68.58" y="58.42" rot="R270"/>
<instance part="C12" gate="G$1" x="66.04" y="78.74" rot="R90"/>
<instance part="C13" gate="G$1" x="66.04" y="63.5" rot="R90"/>
</instances>
<busses>
</busses>
<nets>
<net name="N$1" class="0">
<segment>
<pinref part="X3" gate="-1" pin="KL"/>
<pinref part="IC1" gate="1" pin="IN"/>
<wire x1="5.08" y1="73.66" x2="12.7" y2="73.66" width="0.1524" layer="91"/>
<wire x1="12.7" y1="73.66" x2="20.32" y2="73.66" width="0.1524" layer="91"/>
<wire x1="12.7" y1="68.58" x2="12.7" y2="73.66" width="0.1524" layer="91"/>
<junction x="12.7" y="73.66"/>
<pinref part="C1" gate="G$1" pin="+"/>
</segment>
</net>
<net name="GND" class="0">
<segment>
<pinref part="GND2" gate="1" pin="GND"/>
<wire x1="12.7" y1="55.88" x2="12.7" y2="60.96" width="0.1524" layer="91"/>
<pinref part="C1" gate="G$1" pin="-"/>
</segment>
<segment>
<pinref part="LED1" gate="G$1" pin="C"/>
<pinref part="GND4" gate="1" pin="GND"/>
<wire x1="35.56" y1="35.56" x2="38.1" y2="35.56" width="0.1524" layer="91"/>
<wire x1="38.1" y1="35.56" x2="38.1" y2="33.02" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="C3" gate="G$1" pin="-"/>
<wire x1="27.94" y1="12.7" x2="27.94" y2="7.62" width="0.1524" layer="91"/>
<wire x1="27.94" y1="7.62" x2="35.56" y2="7.62" width="0.1524" layer="91"/>
<pinref part="R2" gate="G$1" pin="2"/>
<wire x1="35.56" y1="7.62" x2="35.56" y2="10.16" width="0.1524" layer="91"/>
<junction x="27.94" y="7.62"/>
<pinref part="GND5" gate="1" pin="GND"/>
<wire x1="27.94" y1="5.08" x2="27.94" y2="7.62" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="X3" gate="-2" pin="KL"/>
<wire x1="2.54" y1="-60.96" x2="7.62" y2="-60.96" width="0.1524" layer="91"/>
<pinref part="ÉRZÉKELŐK" gate="-2" pin="KL"/>
<wire x1="7.62" y1="-60.96" x2="20.32" y2="-60.96" width="0.1524" layer="91"/>
<wire x1="20.32" y1="-60.96" x2="40.64" y2="-60.96" width="0.1524" layer="91"/>
<wire x1="40.64" y1="-60.96" x2="73.66" y2="-60.96" width="0.1524" layer="91"/>
<wire x1="73.66" y1="-60.96" x2="88.9" y2="-60.96" width="0.1524" layer="91"/>
<wire x1="88.9" y1="-60.96" x2="101.6" y2="-60.96" width="0.1524" layer="91"/>
<wire x1="109.22" y1="-60.96" x2="129.54" y2="-60.96" width="0.1524" layer="91"/>
<wire x1="5.08" y1="-40.64" x2="7.62" y2="-40.64" width="0.1524" layer="91"/>
<wire x1="7.62" y1="-40.64" x2="7.62" y2="-60.96" width="0.1524" layer="91"/>
<junction x="7.62" y="-60.96"/>
<pinref part="R4" gate="G$1" pin="2"/>
<wire x1="40.64" y1="-55.88" x2="40.64" y2="-60.96" width="0.1524" layer="91"/>
<pinref part="GND6" gate="1" pin="GND"/>
<wire x1="7.62" y1="-66.04" x2="7.62" y2="-60.96" width="0.1524" layer="91"/>
<pinref part="C4" gate="G$1" pin="-"/>
<wire x1="20.32" y1="-38.1" x2="20.32" y2="-60.96" width="0.1524" layer="91"/>
<junction x="20.32" y="-60.96"/>
<pinref part="C9" gate="G$1" pin="-"/>
<wire x1="101.6" y1="-58.42" x2="101.6" y2="-60.96" width="0.1524" layer="91"/>
<junction x="101.6" y="-60.96"/>
<wire x1="101.6" y1="-60.96" x2="109.22" y2="-60.96" width="0.1524" layer="91"/>
<pinref part="C10" gate="G$1" pin="-"/>
<wire x1="109.22" y1="-58.42" x2="109.22" y2="-60.96" width="0.1524" layer="91"/>
<junction x="109.22" y="-60.96"/>
<pinref part="C11" gate="G$1" pin="-"/>
<wire x1="129.54" y1="-58.42" x2="129.54" y2="-60.96" width="0.1524" layer="91"/>
<pinref part="C7" gate="G$1" pin="-"/>
<wire x1="73.66" y1="-58.42" x2="73.66" y2="-60.96" width="0.1524" layer="91"/>
<pinref part="C8" gate="G$1" pin="-"/>
<wire x1="88.9" y1="-58.42" x2="88.9" y2="-60.96" width="0.1524" layer="91"/>
<junction x="73.66" y="-60.96"/>
<junction x="88.9" y="-60.96"/>
<junction x="40.64" y="-60.96"/>
<pinref part="T2" gate="G$1" pin="E"/>
<wire x1="142.24" y1="-17.78" x2="142.24" y2="-60.96" width="0.1524" layer="91"/>
<wire x1="142.24" y1="-60.96" x2="129.54" y2="-60.96" width="0.1524" layer="91"/>
<junction x="129.54" y="-60.96"/>
</segment>
<segment>
<pinref part="C6" gate="G$1" pin="-"/>
<wire x1="88.9" y1="-2.54" x2="88.9" y2="-5.08" width="0.1524" layer="91"/>
<wire x1="88.9" y1="-5.08" x2="73.66" y2="-5.08" width="0.1524" layer="91"/>
<pinref part="C5" gate="G$1" pin="-"/>
<wire x1="73.66" y1="-5.08" x2="73.66" y2="-2.54" width="0.1524" layer="91"/>
<pinref part="GND7" gate="1" pin="GND"/>
<wire x1="73.66" y1="-5.08" x2="66.04" y2="-5.08" width="0.1524" layer="91"/>
<wire x1="66.04" y1="-5.08" x2="66.04" y2="-7.62" width="0.1524" layer="91"/>
<junction x="73.66" y="-5.08"/>
<pinref part="T1" gate="G$1" pin="E"/>
<wire x1="88.9" y1="-5.08" x2="124.46" y2="-5.08" width="0.1524" layer="91"/>
<wire x1="124.46" y1="-5.08" x2="124.46" y2="17.78" width="0.1524" layer="91"/>
<junction x="88.9" y="-5.08"/>
</segment>
<segment>
<pinref part="C2" gate="G$1" pin="-"/>
<pinref part="GND3" gate="1" pin="GND"/>
<wire x1="43.18" y1="60.96" x2="43.18" y2="58.42" width="0.1524" layer="91"/>
<pinref part="C12" gate="G$1" pin="1"/>
<wire x1="43.18" y1="58.42" x2="43.18" y2="55.88" width="0.1524" layer="91"/>
<wire x1="63.5" y1="78.74" x2="58.42" y2="78.74" width="0.1524" layer="91"/>
<wire x1="58.42" y1="78.74" x2="58.42" y2="71.12" width="0.1524" layer="91"/>
<pinref part="IC4" gate="P" pin="VSS"/>
<wire x1="58.42" y1="71.12" x2="58.42" y2="63.5" width="0.1524" layer="91"/>
<wire x1="58.42" y1="63.5" x2="58.42" y2="58.42" width="0.1524" layer="91"/>
<wire x1="58.42" y1="58.42" x2="60.96" y2="58.42" width="0.1524" layer="91"/>
<pinref part="IC3" gate="P" pin="VSS"/>
<wire x1="60.96" y1="71.12" x2="58.42" y2="71.12" width="0.1524" layer="91"/>
<pinref part="C13" gate="G$1" pin="1"/>
<wire x1="63.5" y1="63.5" x2="58.42" y2="63.5" width="0.1524" layer="91"/>
<junction x="58.42" y="71.12"/>
<junction x="58.42" y="63.5"/>
<wire x1="58.42" y1="58.42" x2="43.18" y2="58.42" width="0.1524" layer="91"/>
<junction x="43.18" y="58.42"/>
<junction x="58.42" y="58.42"/>
<pinref part="IC1" gate="1" pin="GND"/>
<wire x1="27.94" y1="66.04" x2="27.94" y2="58.42" width="0.1524" layer="91"/>
<wire x1="43.18" y1="58.42" x2="27.94" y2="58.42" width="0.1524" layer="91"/>
</segment>
</net>
<net name="+12V" class="0">
<segment>
<pinref part="IC1" gate="1" pin="OUT"/>
<wire x1="35.56" y1="73.66" x2="38.1" y2="73.66" width="0.1524" layer="91"/>
<wire x1="38.1" y1="73.66" x2="38.1" y2="78.74" width="0.1524" layer="91"/>
<junction x="38.1" y="73.66"/>
<pinref part="P+1" gate="1" pin="+12V"/>
<pinref part="C2" gate="G$1" pin="+"/>
<wire x1="43.18" y1="73.66" x2="43.18" y2="68.58" width="0.1524" layer="91"/>
<junction x="43.18" y="73.66"/>
<wire x1="43.18" y1="73.66" x2="50.8" y2="73.66" width="0.1524" layer="91"/>
<wire x1="50.8" y1="73.66" x2="50.8" y2="86.36" width="0.1524" layer="91"/>
<wire x1="50.8" y1="86.36" x2="78.74" y2="86.36" width="0.1524" layer="91"/>
<pinref part="C12" gate="G$1" pin="2"/>
<wire x1="71.12" y1="78.74" x2="78.74" y2="78.74" width="0.1524" layer="91"/>
<wire x1="78.74" y1="78.74" x2="78.74" y2="71.12" width="0.1524" layer="91"/>
<pinref part="IC3" gate="P" pin="VDD"/>
<wire x1="78.74" y1="71.12" x2="76.2" y2="71.12" width="0.1524" layer="91"/>
<wire x1="78.74" y1="71.12" x2="78.74" y2="63.5" width="0.1524" layer="91"/>
<pinref part="C13" gate="G$1" pin="2"/>
<wire x1="78.74" y1="63.5" x2="71.12" y2="63.5" width="0.1524" layer="91"/>
<pinref part="IC4" gate="P" pin="VDD"/>
<wire x1="78.74" y1="63.5" x2="78.74" y2="58.42" width="0.1524" layer="91"/>
<wire x1="78.74" y1="58.42" x2="76.2" y2="58.42" width="0.1524" layer="91"/>
<junction x="78.74" y="71.12"/>
<junction x="78.74" y="63.5"/>
<wire x1="78.74" y1="86.36" x2="78.74" y2="78.74" width="0.1524" layer="91"/>
<junction x="78.74" y="78.74"/>
<wire x1="38.1" y1="73.66" x2="43.18" y2="73.66" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="P+3" gate="1" pin="+12V"/>
<wire x1="0" y1="48.26" x2="0" y2="45.72" width="0.1524" layer="91"/>
<wire x1="0" y1="45.72" x2="7.62" y2="45.72" width="0.1524" layer="91"/>
<wire x1="7.62" y1="45.72" x2="12.7" y2="45.72" width="0.1524" layer="91"/>
<wire x1="12.7" y1="45.72" x2="116.84" y2="45.72" width="0.1524" layer="91"/>
<junction x="7.62" y="45.72"/>
<pinref part="R1" gate="G$1" pin="1"/>
<wire x1="116.84" y1="45.72" x2="124.46" y2="45.72" width="0.1524" layer="91"/>
<wire x1="7.62" y1="25.4" x2="7.62" y2="45.72" width="0.1524" layer="91"/>
<wire x1="15.24" y1="35.56" x2="12.7" y2="35.56" width="0.1524" layer="91"/>
<wire x1="12.7" y1="35.56" x2="12.7" y2="45.72" width="0.1524" layer="91"/>
<junction x="12.7" y="45.72"/>
<pinref part="START" gate="G$1" pin="2"/>
<wire x1="15.24" y1="20.32" x2="15.24" y2="25.4" width="0.1524" layer="91"/>
<wire x1="15.24" y1="25.4" x2="7.62" y2="25.4" width="0.1524" layer="91"/>
<pinref part="R3" gate="G$1" pin="1"/>
<wire x1="7.62" y1="-15.24" x2="7.62" y2="-5.08" width="0.1524" layer="91"/>
<junction x="7.62" y="25.4"/>
<pinref part="RESET" gate="G$1" pin="2"/>
<wire x1="7.62" y1="-5.08" x2="7.62" y2="25.4" width="0.1524" layer="91"/>
<wire x1="15.24" y1="-17.78" x2="15.24" y2="-5.08" width="0.1524" layer="91"/>
<wire x1="15.24" y1="-5.08" x2="7.62" y2="-5.08" width="0.1524" layer="91"/>
<junction x="7.62" y="-5.08"/>
<wire x1="15.24" y1="-5.08" x2="40.64" y2="-5.08" width="0.1524" layer="91"/>
<wire x1="40.64" y1="-5.08" x2="40.64" y2="12.7" width="0.1524" layer="91"/>
<pinref part="IC3" gate="A" pin="R"/>
<wire x1="40.64" y1="12.7" x2="43.18" y2="12.7" width="0.1524" layer="91"/>
<junction x="15.24" y="-5.08"/>
<pinref part="K2" gate="1" pin="1"/>
<wire x1="124.46" y1="43.18" x2="124.46" y2="45.72" width="0.1524" layer="91"/>
<pinref part="D2" gate="1" pin="C"/>
<wire x1="116.84" y1="40.64" x2="116.84" y2="45.72" width="0.1524" layer="91"/>
<junction x="116.84" y="45.72"/>
<pinref part="D4" gate="1" pin="C"/>
<wire x1="134.62" y1="10.16" x2="134.62" y2="20.32" width="0.1524" layer="91"/>
<pinref part="SZIRÉNA" gate="1" pin="1"/>
<wire x1="134.62" y1="20.32" x2="142.24" y2="20.32" width="0.1524" layer="91"/>
<wire x1="142.24" y1="20.32" x2="142.24" y2="12.7" width="0.1524" layer="91"/>
<wire x1="124.46" y1="45.72" x2="142.24" y2="45.72" width="0.1524" layer="91"/>
<wire x1="142.24" y1="45.72" x2="142.24" y2="20.32" width="0.1524" layer="91"/>
<junction x="142.24" y="20.32"/>
<junction x="124.46" y="45.72"/>
<pinref part="R11" gate="G$1" pin="2"/>
<wire x1="129.54" y1="17.78" x2="129.54" y2="20.32" width="0.1524" layer="91"/>
<wire x1="129.54" y1="20.32" x2="134.62" y2="20.32" width="0.1524" layer="91"/>
<junction x="134.62" y="20.32"/>
</segment>
</net>
<net name="N$3" class="0">
<segment>
<pinref part="LED1" gate="G$1" pin="A"/>
<pinref part="R1" gate="G$1" pin="2"/>
<wire x1="27.94" y1="35.56" x2="25.4" y2="35.56" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$4" class="0">
<segment>
<pinref part="START" gate="G$1" pin="1"/>
<wire x1="17.78" y1="20.32" x2="17.78" y2="25.4" width="0.1524" layer="91"/>
<wire x1="17.78" y1="25.4" x2="27.94" y2="25.4" width="0.1524" layer="91"/>
<pinref part="C3" gate="G$1" pin="+"/>
<wire x1="27.94" y1="20.32" x2="27.94" y2="25.4" width="0.1524" layer="91"/>
<wire x1="27.94" y1="25.4" x2="35.56" y2="25.4" width="0.1524" layer="91"/>
<pinref part="R2" gate="G$1" pin="1"/>
<wire x1="35.56" y1="25.4" x2="35.56" y2="20.32" width="0.1524" layer="91"/>
<junction x="27.94" y="25.4"/>
<pinref part="IC3" gate="A" pin="S"/>
<wire x1="35.56" y1="25.4" x2="43.18" y2="25.4" width="0.1524" layer="91"/>
<junction x="35.56" y="25.4"/>
</segment>
</net>
<net name="N$5" class="0">
<segment>
<pinref part="ÉRZÉKELŐK" gate="-1" pin="KL"/>
<wire x1="5.08" y1="-27.94" x2="7.62" y2="-27.94" width="0.1524" layer="91"/>
<pinref part="R3" gate="G$1" pin="2"/>
<wire x1="7.62" y1="-25.4" x2="7.62" y2="-27.94" width="0.1524" layer="91"/>
<pinref part="IC3" gate="B" pin="S"/>
<wire x1="43.18" y1="-27.94" x2="20.32" y2="-27.94" width="0.1524" layer="91"/>
<pinref part="C4" gate="G$1" pin="+"/>
<wire x1="20.32" y1="-27.94" x2="7.62" y2="-27.94" width="0.1524" layer="91"/>
<wire x1="20.32" y1="-30.48" x2="20.32" y2="-27.94" width="0.1524" layer="91"/>
<junction x="7.62" y="-27.94"/>
<junction x="20.32" y="-27.94"/>
</segment>
</net>
<net name="N$6" class="0">
<segment>
<pinref part="RESET" gate="G$1" pin="1"/>
<wire x1="17.78" y1="-17.78" x2="17.78" y2="-10.16" width="0.1524" layer="91"/>
<wire x1="17.78" y1="-10.16" x2="27.94" y2="-10.16" width="0.1524" layer="91"/>
<pinref part="D1" gate="G$1" pin="A"/>
</segment>
</net>
<net name="N$7" class="0">
<segment>
<pinref part="D1" gate="G$1" pin="C"/>
<wire x1="33.02" y1="-10.16" x2="40.64" y2="-10.16" width="0.1524" layer="91"/>
<wire x1="40.64" y1="-10.16" x2="40.64" y2="-40.64" width="0.1524" layer="91"/>
<pinref part="IC3" gate="B" pin="R"/>
<wire x1="40.64" y1="-40.64" x2="43.18" y2="-40.64" width="0.1524" layer="91"/>
<pinref part="R4" gate="G$1" pin="1"/>
<wire x1="40.64" y1="-45.72" x2="40.64" y2="-40.64" width="0.1524" layer="91"/>
<junction x="40.64" y="-40.64"/>
<pinref part="D3" gate="G$1" pin="C"/>
<wire x1="76.2" y1="-17.78" x2="50.8" y2="-17.78" width="0.1524" layer="91"/>
<wire x1="50.8" y1="-17.78" x2="50.8" y2="-10.16" width="0.1524" layer="91"/>
<wire x1="50.8" y1="-10.16" x2="40.64" y2="-10.16" width="0.1524" layer="91"/>
<junction x="40.64" y="-10.16"/>
</segment>
</net>
<net name="N$2" class="0">
<segment>
<pinref part="IC3" gate="A" pin="Q"/>
<pinref part="IC4" gate="A" pin="I0"/>
<wire x1="68.58" y1="25.4" x2="73.66" y2="25.4" width="0.1524" layer="91"/>
<wire x1="73.66" y1="25.4" x2="86.36" y2="25.4" width="0.1524" layer="91"/>
<wire x1="73.66" y1="25.4" x2="73.66" y2="35.56" width="0.1524" layer="91"/>
<pinref part="R5" gate="G$1" pin="1"/>
<wire x1="73.66" y1="35.56" x2="76.2" y2="35.56" width="0.1524" layer="91"/>
<junction x="73.66" y="25.4"/>
<pinref part="R6" gate="G$1" pin="1"/>
<wire x1="73.66" y1="20.32" x2="73.66" y2="25.4" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$8" class="0">
<segment>
<pinref part="R5" gate="G$1" pin="2"/>
<pinref part="LED2" gate="G$1" pin="A"/>
<wire x1="86.36" y1="35.56" x2="88.9" y2="35.56" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$9" class="0">
<segment>
<pinref part="IC4" gate="A" pin="O"/>
<wire x1="101.6" y1="22.86" x2="104.14" y2="22.86" width="0.1524" layer="91"/>
<wire x1="104.14" y1="22.86" x2="104.14" y2="35.56" width="0.1524" layer="91"/>
<pinref part="LED2" gate="G$1" pin="C"/>
<wire x1="104.14" y1="35.56" x2="96.52" y2="35.56" width="0.1524" layer="91"/>
<junction x="104.14" y="22.86"/>
<pinref part="R7" gate="G$1" pin="1"/>
<wire x1="106.68" y1="22.86" x2="104.14" y2="22.86" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$11" class="0">
<segment>
<pinref part="C5" gate="G$1" pin="+"/>
<pinref part="R6" gate="G$1" pin="2"/>
<wire x1="73.66" y1="5.08" x2="73.66" y2="7.62" width="0.1524" layer="91"/>
<wire x1="73.66" y1="7.62" x2="73.66" y2="10.16" width="0.1524" layer="91"/>
<wire x1="73.66" y1="7.62" x2="78.74" y2="7.62" width="0.1524" layer="91"/>
<wire x1="78.74" y1="7.62" x2="78.74" y2="20.32" width="0.1524" layer="91"/>
<pinref part="IC4" gate="A" pin="I1"/>
<wire x1="78.74" y1="20.32" x2="86.36" y2="20.32" width="0.1524" layer="91"/>
<junction x="73.66" y="7.62"/>
<pinref part="ESCAPETIME" gate="G$1" pin="1"/>
<wire x1="86.36" y1="10.16" x2="86.36" y2="7.62" width="0.1524" layer="91"/>
<wire x1="86.36" y1="7.62" x2="78.74" y2="7.62" width="0.1524" layer="91"/>
<junction x="78.74" y="7.62"/>
</segment>
</net>
<net name="N$12" class="0">
<segment>
<pinref part="ESCAPETIME" gate="G$1" pin="2"/>
<pinref part="C6" gate="G$1" pin="+"/>
<wire x1="88.9" y1="10.16" x2="88.9" y2="5.08" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$10" class="0">
<segment>
<pinref part="T1" gate="G$1" pin="B"/>
<pinref part="R7" gate="G$1" pin="2"/>
<wire x1="119.38" y1="22.86" x2="116.84" y2="22.86" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$13" class="0">
<segment>
<pinref part="K2" gate="1" pin="2"/>
<pinref part="T1" gate="G$1" pin="C"/>
<wire x1="124.46" y1="33.02" x2="124.46" y2="30.48" width="0.1524" layer="91"/>
<pinref part="D2" gate="1" pin="A"/>
<wire x1="124.46" y1="30.48" x2="124.46" y2="27.94" width="0.1524" layer="91"/>
<wire x1="124.46" y1="30.48" x2="116.84" y2="30.48" width="0.1524" layer="91"/>
<wire x1="116.84" y1="30.48" x2="116.84" y2="35.56" width="0.1524" layer="91"/>
<junction x="124.46" y="30.48"/>
</segment>
</net>
<net name="N$14" class="0">
<segment>
<pinref part="X1" gate="-2" pin="KL"/>
<pinref part="K2" gate="2" pin="P"/>
<wire x1="91.44" y1="68.58" x2="91.44" y2="73.66" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$15" class="0">
<segment>
<pinref part="X1" gate="-1" pin="KL"/>
<pinref part="K2" gate="2" pin="S"/>
<wire x1="86.36" y1="68.58" x2="86.36" y2="81.28" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$16" class="0">
<segment>
<pinref part="X1" gate="-3" pin="KL"/>
<pinref part="K2" gate="2" pin="O"/>
<wire x1="96.52" y1="68.58" x2="96.52" y2="81.28" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$17" class="0">
<segment>
<pinref part="X2" gate="-2" pin="KL"/>
<pinref part="SZIRÉNA" gate="2" pin="P"/>
<wire x1="111.76" y1="68.58" x2="111.76" y2="73.66" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$18" class="0">
<segment>
<pinref part="X2" gate="-1" pin="KL"/>
<pinref part="SZIRÉNA" gate="2" pin="S"/>
<wire x1="106.68" y1="68.58" x2="106.68" y2="81.28" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$19" class="0">
<segment>
<pinref part="X2" gate="-3" pin="KL"/>
<pinref part="SZIRÉNA" gate="2" pin="O"/>
<wire x1="116.84" y1="68.58" x2="116.84" y2="81.28" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$20" class="0">
<segment>
<pinref part="IC3" gate="B" pin="Q"/>
<pinref part="IC4" gate="B" pin="I0"/>
<wire x1="68.58" y1="-27.94" x2="73.66" y2="-27.94" width="0.1524" layer="91"/>
<pinref part="R8" gate="G$1" pin="1"/>
<wire x1="73.66" y1="-27.94" x2="81.28" y2="-27.94" width="0.1524" layer="91"/>
<wire x1="73.66" y1="-35.56" x2="73.66" y2="-27.94" width="0.1524" layer="91"/>
<junction x="73.66" y="-27.94"/>
</segment>
</net>
<net name="N$21" class="0">
<segment>
<pinref part="C7" gate="G$1" pin="+"/>
<pinref part="R8" gate="G$1" pin="2"/>
<wire x1="73.66" y1="-50.8" x2="73.66" y2="-48.26" width="0.1524" layer="91"/>
<wire x1="73.66" y1="-48.26" x2="73.66" y2="-45.72" width="0.1524" layer="91"/>
<wire x1="73.66" y1="-48.26" x2="78.74" y2="-48.26" width="0.1524" layer="91"/>
<wire x1="78.74" y1="-48.26" x2="78.74" y2="-33.02" width="0.1524" layer="91"/>
<junction x="73.66" y="-48.26"/>
<pinref part="J2" gate="G$1" pin="1"/>
<wire x1="86.36" y1="-45.72" x2="86.36" y2="-48.26" width="0.1524" layer="91"/>
<wire x1="86.36" y1="-48.26" x2="78.74" y2="-48.26" width="0.1524" layer="91"/>
<junction x="78.74" y="-48.26"/>
<pinref part="IC4" gate="B" pin="I1"/>
<wire x1="78.74" y1="-33.02" x2="81.28" y2="-33.02" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$22" class="0">
<segment>
<pinref part="J2" gate="G$1" pin="2"/>
<pinref part="C8" gate="G$1" pin="+"/>
<wire x1="88.9" y1="-45.72" x2="88.9" y2="-50.8" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$23" class="0">
<segment>
<pinref part="C9" gate="G$1" pin="+"/>
<pinref part="J3" gate="G$1" pin="1"/>
<wire x1="101.6" y1="-50.8" x2="101.6" y2="-45.72" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$24" class="0">
<segment>
<pinref part="J3" gate="G$1" pin="2"/>
<wire x1="104.14" y1="-45.72" x2="104.14" y2="-48.26" width="0.1524" layer="91"/>
<wire x1="104.14" y1="-48.26" x2="109.22" y2="-48.26" width="0.1524" layer="91"/>
<pinref part="C10" gate="G$1" pin="+"/>
<wire x1="109.22" y1="-48.26" x2="109.22" y2="-50.8" width="0.1524" layer="91"/>
<pinref part="R9" gate="G$1" pin="2"/>
<wire x1="109.22" y1="-45.72" x2="109.22" y2="-48.26" width="0.1524" layer="91"/>
<junction x="109.22" y="-48.26"/>
<pinref part="J4" gate="G$1" pin="1"/>
<wire x1="121.92" y1="-45.72" x2="121.92" y2="-48.26" width="0.1524" layer="91"/>
<wire x1="121.92" y1="-48.26" x2="114.3" y2="-48.26" width="0.1524" layer="91"/>
<pinref part="IC4" gate="C" pin="I1"/>
<wire x1="114.3" y1="-48.26" x2="109.22" y2="-48.26" width="0.1524" layer="91"/>
<wire x1="116.84" y1="-35.56" x2="114.3" y2="-35.56" width="0.1524" layer="91"/>
<wire x1="114.3" y1="-35.56" x2="114.3" y2="-48.26" width="0.1524" layer="91"/>
<junction x="114.3" y="-48.26"/>
</segment>
</net>
<net name="N$25" class="0">
<segment>
<pinref part="IC4" gate="B" pin="O"/>
<pinref part="IC4" gate="C" pin="I0"/>
<wire x1="96.52" y1="-30.48" x2="109.22" y2="-30.48" width="0.1524" layer="91"/>
<pinref part="R9" gate="G$1" pin="1"/>
<wire x1="109.22" y1="-30.48" x2="116.84" y2="-30.48" width="0.1524" layer="91"/>
<wire x1="109.22" y1="-35.56" x2="109.22" y2="-30.48" width="0.1524" layer="91"/>
<junction x="109.22" y="-30.48"/>
<wire x1="109.22" y1="-30.48" x2="109.22" y2="-12.7" width="0.1524" layer="91"/>
<pinref part="R10" gate="G$1" pin="1"/>
<wire x1="109.22" y1="-12.7" x2="124.46" y2="-12.7" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$26" class="0">
<segment>
<pinref part="C11" gate="G$1" pin="+"/>
<wire x1="129.54" y1="-50.8" x2="129.54" y2="-48.26" width="0.1524" layer="91"/>
<pinref part="J4" gate="G$1" pin="2"/>
<wire x1="129.54" y1="-48.26" x2="124.46" y2="-48.26" width="0.1524" layer="91"/>
<wire x1="124.46" y1="-48.26" x2="124.46" y2="-45.72" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$28" class="0">
<segment>
<pinref part="D3" gate="G$1" pin="A"/>
<wire x1="81.28" y1="-17.78" x2="134.62" y2="-17.78" width="0.1524" layer="91"/>
<wire x1="134.62" y1="-17.78" x2="134.62" y2="-33.02" width="0.1524" layer="91"/>
<pinref part="IC4" gate="C" pin="O"/>
<wire x1="134.62" y1="-33.02" x2="132.08" y2="-33.02" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$27" class="0">
<segment>
<pinref part="R10" gate="G$1" pin="2"/>
<pinref part="T2" gate="G$1" pin="B"/>
<wire x1="134.62" y1="-12.7" x2="137.16" y2="-12.7" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$30" class="0">
<segment>
<pinref part="SZIRÉNA" gate="1" pin="2"/>
<pinref part="T2" gate="G$1" pin="C"/>
<wire x1="142.24" y1="2.54" x2="142.24" y2="-5.08" width="0.1524" layer="91"/>
<pinref part="D4" gate="1" pin="A"/>
<wire x1="142.24" y1="-5.08" x2="142.24" y2="-7.62" width="0.1524" layer="91"/>
<wire x1="134.62" y1="5.08" x2="134.62" y2="-5.08" width="0.1524" layer="91"/>
<wire x1="134.62" y1="-5.08" x2="142.24" y2="-5.08" width="0.1524" layer="91"/>
<junction x="142.24" y="-5.08"/>
<pinref part="SZIRÉNALED" gate="G$1" pin="C"/>
<wire x1="129.54" y1="-2.54" x2="129.54" y2="-5.08" width="0.1524" layer="91"/>
<wire x1="129.54" y1="-5.08" x2="134.62" y2="-5.08" width="0.1524" layer="91"/>
<junction x="134.62" y="-5.08"/>
</segment>
</net>
<net name="N$29" class="0">
<segment>
<pinref part="R11" gate="G$1" pin="1"/>
<pinref part="SZIRÉNALED" gate="G$1" pin="A"/>
<wire x1="129.54" y1="5.08" x2="129.54" y2="7.62" width="0.1524" layer="91"/>
</segment>
</net>
</nets>
</sheet>
</sheets>
</schematic>
</drawing>
</eagle>
