//**  File name:     C:\Flowcode\18F4520 LCD\Flowcode1.c
//**  Title:         
//**  Description:   
//**  Generated by:  Flowcode v5.2.0.0
//**  Date:          Wednesday, November 12, 2014 18:43:30
//**  Licence:       Professional
//**  Registered to: Baxi
//**  Licence key:   JWK8FX
//**  http://www.matrixmultimedia.com
#define MX_PIC
#define MX_USES_UINT8 1
#define MX_USES_SINT16 1
#define MX_USES_CHAR 0
#define MX_USES_FLOAT 0
#define MX_USES_SINT32 0
#define MX_USES_BOOL 1
#define MX_USES_UINT16 0
#define MX_USES_UINT32 0
//Mikrovezérl? definíciók
#define P18F4520
#define FC_CAL_PIC
#define MX_ADC
#define MX_ADC_TYPE_13
#define MX_ADC_BITS_10
#define MX_EE
#define MX_EE_TYPE3
#define MX_EE_SIZE 256
#define MX_SPI_1
#define MX_SPI_1_MISO_PORT portc
#define MX_SPI_1_MISO_TRIS trisc
#define MX_SPI_1_MISO_PIN 4
#define MX_SPI_1_MOSI_PORT portc
#define MX_SPI_1_MOSI_TRIS trisc
#define MX_SPI_1_MOSI_PIN 5
#define MX_SPI_1_CLK_PORT portc
#define MX_SPI_1_CLK_TRIS trisc
#define MX_SPI_1_CLK_PIN 3
#define MX_SPI_1_SS_PORT porta
#define MX_SPI_1_SS_TRIS trisa
#define MX_SPI_1_SS_PIN 5
#define MX_UART_1
#define MX_UART_1_TX_PORT portc
#define MX_UART_1_TX_TRIS trisc
#define MX_UART_1_TX_PIN 6
#define MX_UART_1_RX_PORT portc
#define MX_UART_1_RX_TRIS trisc
#define MX_UART_1_RX_PIN 7
#define MX_I2C
#define MX_MI2C
#define MX_I2C_1
#define MX_I2C_1_SDA_PORT portc
#define MX_I2C_1_SDA_TRIS trisc
#define MX_I2C_1_SDA_PIN 4
#define MX_I2C_1_SCL_PORT portc
#define MX_I2C_1_SCL_TRIS trisc
#define MX_I2C_1_SCL_PIN 3
#define MX_PWM
#define MX_PWM_CNT 2
#define MX_PWM_PSCA1
#define MX_PWM_PSCA4
#define MX_PWM_PSCA16
#define MX_PWM_1_PORT portc
#define MX_PWM_1_TRIS trisc
#define MX_PWM_1_PIN 2
#define MX_PWM_2_PORT portc
#define MX_PWM_2_TRIS trisc
#define MX_PWM_2_PIN 1
#define MX_PWM_2_PORT_A portb
#define MX_PWM_2_TRIS_A trisb
#define MX_PWM_2_PIN_A 3
//Függvények
#define MX_CLK_SPEED 40000000
#ifdef _BOOSTC
#include <system.h>
#endif
#ifdef HI_TECH_C
#include <pic18.h>
#endif
//Konfigurációs adatok
#ifdef _BOOSTC
#pragma DATA 0x300000, 0xff
#endif
#ifdef _HI_TECH_C
%C__CONFIG(%A, %V);
#endif
#ifdef _BOOSTC
#pragma DATA 0x300001, 0xc2
#endif
#ifdef _HI_TECH_C
%C__CONFIG(%A, %V);
#endif
#ifdef _BOOSTC
#pragma DATA 0x300002, 0x6
#endif
#ifdef _HI_TECH_C
%C__CONFIG(%A, %V);
#endif
#ifdef _BOOSTC
#pragma DATA 0x300003, 0x1f
#endif
#ifdef _HI_TECH_C
%C__CONFIG(%A, %V);
#endif
#ifdef _BOOSTC
#pragma DATA 0x300004, 0xff
#endif
#ifdef _HI_TECH_C
%C__CONFIG(%A, %V);
#endif
#ifdef _BOOSTC
#pragma DATA 0x300005, 0x81
#endif
#ifdef _HI_TECH_C
%C__CONFIG(%A, %V);
#endif
#ifdef _BOOSTC
#pragma DATA 0x300006, 0x80
#endif
#ifdef _HI_TECH_C
%C__CONFIG(%A, %V);
#endif
#ifdef _BOOSTC
#pragma DATA 0x300007, 0xff
#endif
#ifdef _HI_TECH_C
%C__CONFIG(%A, %V);
#endif
#ifdef _BOOSTC
#pragma DATA 0x300008, 0xf
#endif
#ifdef _HI_TECH_C
%C__CONFIG(%A, %V);
#endif
#ifdef _BOOSTC
#pragma DATA 0x300009, 0xc0
#endif
#ifdef _HI_TECH_C
%C__CONFIG(%A, %V);
#endif
#ifdef _BOOSTC
#pragma DATA 0x30000a, 0xf
#endif
#ifdef _HI_TECH_C
%C__CONFIG(%A, %V);
#endif
#ifdef _BOOSTC
#pragma DATA 0x30000b, 0xe0
#endif
#ifdef _HI_TECH_C
%C__CONFIG(%A, %V);
#endif
#ifdef _BOOSTC
#pragma DATA 0x30000c, 0xf
#endif
#ifdef _HI_TECH_C
%C__CONFIG(%A, %V);
#endif
#ifdef _BOOSTC
#pragma DATA 0x30000d, 0x40
#endif
#ifdef _HI_TECH_C
%C__CONFIG(%A, %V);
#endif
//Bels? függvények
#include "C:\Program Files (x86)\Flowcode\v5\FCD\internals.c"
//Makró deklarációk
void FCM_wake_up();
//Változó deklarációk
#define FCV_TRUE (1)
#define FCV_FALSE (0)
MX_BOOL FCV_LED;
MX_SINT16 FCV_SZAMLALO;
//LCDDisplay(0): //Defines:
/**** Macro Substitutions ****
a = Unique Component Reference Number
b = D1 Port Letter
c = D2 Port Letter
d = D3 Port Letter
e = D4 Port Letter
f = RS Port Letter
g = E Port Letter
h = Data 1_Pin
i = Data 2 Pin
j = Data 3 Pin
k = Data 4 Pin
l = RS Pin
m = Enable Pin
n = Row Count
o = Column Count
	//component connections
	#define LCD_1__PORT0    portd
	#define LCD_1__PORT1    portd
	#define LCD_1__PORT2    portd
	#define LCD_1__PORT3    portd
	#define LCD_1__PORT4    portd
	#define LCD_1__PORT5    portd
	#define LCD_1__TRIS0    trisd
	#define LCD_1__TRIS1    trisd
	#define LCD_1__TRIS2    trisd
	#define LCD_1__TRIS3    trisd
	#define LCD_1__TRIS4    trisd
	#define LCD_1__TRIS5    trisd
	#define LCD_1__BIT0    	0
	#define LCD_1__BIT1    	1
	#define LCD_1__BIT2    	2
	#define LCD_1__BIT3    	3
	#define LCD_1__RS      	4
	#define LCD_1__E       	5
	#define LCD_1__ROWCNT	2
	#define LCD_1__COLCNT	16
	#ifdef _BOOSTC
	  #define LCD_1__DELAY   delay_10us(10)
	#endif
	#ifdef _C2C_
	  #define LCD_1__DELAY   delay_us(100)
	#endif
	#ifdef HI_TECH_C
	  #define LCD_1__DELAY   __delay_us(120)
	#endif
	#ifndef LCD_1__DELAY
	#endif
//LCDDisplay(0): //Makró deklarációk
void FCD_LCDDisplay0_RawSend(MX_UINT8 in, MX_UINT8 mask);
void FCD_LCDDisplay0_Start();
void FCD_LCDDisplay0_Clear();
void FCD_LCDDisplay0_PrintASCII(MX_UINT8 Character);
void FCD_LCDDisplay0_Command(MX_UINT8 in);
void FCD_LCDDisplay0_Cursor(MX_UINT8 x, MX_UINT8 y);
void FCD_LCDDisplay0_PrintNumber(MX_SINT16 Number);
void FCD_LCDDisplay0_PrintString(MX_STRING String, MX_UINT8 MSZ_String);
void FCD_LCDDisplay0_ScrollDisplay(MX_UINT8 Direction, MX_UINT8 Num_Positions);
void FCD_LCDDisplay0_ClearLine(MX_UINT8 Line);
void FCD_LCDDisplay0_RAM_Write(MX_UINT8 nIdx, MX_UINT8 d0, MX_UINT8 d1, MX_UINT8 d2, MX_UINT8 d3, MX_UINT8 d4, MX_UINT8 d5, MX_UINT8 d6, MX_UINT8 d7);
//LED(0): //Defines:
a = Unique Reference
b = LED Port Letter
c = LED Pin Number
d = LED Active Polarity
#define LED_3__LED_PORT		portb
#define LED_3__LED_TRIS		trisb
#define LED_3__LED_PIN		2
#define LED_3__LED_POLE		1
//LED(0): //Makró deklarációk
void FCD_LED0_LEDOn();
void FCD_LED0_LEDOff();
//LCDDisplay(0): //Makró implementációk
		MX_UINT8 pt;
		FC_CAL_Bit_Low(LCD_1__PORT0, LCD_1__BIT0);
		FC_CAL_Bit_Low(LCD_1__PORT1, LCD_1__BIT1);
		FC_CAL_Bit_Low(LCD_1__PORT2, LCD_1__BIT2);
		FC_CAL_Bit_Low(LCD_1__PORT3, LCD_1__BIT3);
		FC_CAL_Bit_Low(LCD_1__PORT4, LCD_1__RS);
		FC_CAL_Bit_Low(LCD_1__PORT5, LCD_1__E);
		pt = ((in >> 4) & 0x0f);
		if (pt & 0x01)
		    FC_CAL_Bit_High(LCD_1__PORT0, LCD_1__BIT0);
		if (pt & 0x02)
		    FC_CAL_Bit_High(LCD_1__PORT1, LCD_1__BIT1);
		if (pt & 0x04)
		    FC_CAL_Bit_High(LCD_1__PORT2, LCD_1__BIT2);
		if (pt & 0x08)
		    FC_CAL_Bit_High(LCD_1__PORT3, LCD_1__BIT3);
		if (mask)
		    FC_CAL_Bit_High(LCD_1__PORT4, LCD_1__RS);
		LCD_1__DELAY;
		FC_CAL_Bit_High (LCD_1__PORT5, LCD_1__E);
		LCD_1__DELAY;
		FC_CAL_Bit_Low (LCD_1__PORT5, LCD_1__E);
		pt = (in & 0x0f);
		LCD_1__DELAY;
		if (pt & 0x01)
		if (pt & 0x02)
		if (pt & 0x04)
		if (pt & 0x08)
		if (mask)
		LCD_1__DELAY;
		LCD_1__DELAY;
		LCD_1__DELAY;
		FC_CAL_Bit_Low_DDR(LCD_1__PORT0, LCD_1__TRIS0, LCD_1__BIT0);
		FC_CAL_Bit_Low_DDR(LCD_1__PORT1, LCD_1__TRIS1, LCD_1__BIT1);
		FC_CAL_Bit_Low_DDR(LCD_1__PORT2, LCD_1__TRIS2, LCD_1__BIT2);
		FC_CAL_Bit_Low_DDR(LCD_1__PORT3, LCD_1__TRIS3, LCD_1__BIT3);
		FC_CAL_Bit_Low_DDR(LCD_1__PORT4, LCD_1__TRIS4, LCD_1__RS);
		FC_CAL_Bit_Low_DDR(LCD_1__PORT5, LCD_1__TRIS5, LCD_1__E);
		Wdt_Delay_Ms(12);
		FCD_LCDDisplay0_RawSend(0x33, 0);
		Wdt_Delay_Ms(2);
		Wdt_Delay_Ms(2);
		FCD_LCDDisplay0_RawSend(0x32, 0);
		Wdt_Delay_Ms(2);
		FCD_LCDDisplay0_RawSend(0x2c, 0);
		Wdt_Delay_Ms(2);
		FCD_LCDDisplay0_RawSend(0x06, 0);
		Wdt_Delay_Ms(2);
		FCD_LCDDisplay0_RawSend(0x0c, 0);
		Wdt_Delay_Ms(2);
		//clear the display
		FCD_LCDDisplay0_RawSend(0x01, 0);
		Wdt_Delay_Ms(2);
		FCD_LCDDisplay0_RawSend(0x02, 0);
		Wdt_Delay_Ms(2);
		Wdt_Delay_Ms(2);
		Wdt_Delay_Ms(2);
		FCD_LCDDisplay0_RawSend(Character, 0x10);
		FCD_LCDDisplay0_RawSend(in, 0);
		Wdt_Delay_Ms(2);
	  #if (LCD_1__ROWCNT == 1)
	    y=0x80;
	  #endif
	  #if (LCD_1__ROWCNT == 2)
		if (y==0)
			y=0x80;
		else
			y=0xc0;
	  #endif
	  #if (LCD_1__ROWCNT == 4)
		if (y==0)
			y=0x80;
		else if (y==1)
			y=0xc0;
		#if (LCD_1__COLCNT == 16)
			else if (y==2)
				y=0x90;
			else
				y=0xd0;
		#endif
		#if (LCD_1__COLCNT == 20)
			else if (y==2)
				y=0x94;
			else
				y=0xd4;
		#endif
	  #endif
		FCD_LCDDisplay0_RawSend(y+x, 0);
		Wdt_Delay_Ms(2);
		MX_SINT16 tmp_int;
		MX_UINT8 tmp_byte;
		if (Number < 0)
			FCD_LCDDisplay0_RawSend('-', 0x10);
			Number = 0 - Number;
		tmp_int = Number;
		if (Number >= 10000)
			tmp_byte = tmp_int / 10000;
			FCD_LCDDisplay0_RawSend('0' + tmp_byte, 0x10);
			while (tmp_byte > 0)
				tmp_int = tmp_int - 10000;
				tmp_byte--;
		if (Number >= 1000)
			tmp_byte = tmp_int / 1000;
				tmp_int = tmp_int - 1000;
				tmp_byte--;
		if (Number >= 100)
			tmp_byte = tmp_int / 100;
				tmp_int = tmp_int - 100;
				tmp_byte--;
		if (Number >= 10)
			tmp_byte = tmp_int / 10;
				tmp_int = tmp_int - 10;
				tmp_byte--;
		FCD_LCDDisplay0_RawSend('0' + tmp_int, 0x10);
		MX_UINT8 idx = 0;
		for (idx=0; idx<MSZ_String; idx++)
			if (String[idx] == 0)
				break;
			FCD_LCDDisplay0_RawSend(String[idx], 0x10);
		MX_UINT8 cmd = 0;
		MX_UINT8 count;
		//Choose the direction
		switch (Direction)
			case 0:
			case 'l':
			case 'L':
				cmd = 0x18;
				break;
			case 1:
			case 'r':
			case 'R':
				cmd = 0x1C;
				break;
			default:
				break;
		//If direction accepted then scroll the specified amount
		if (cmd)
			for (count = 0; count < Num_Positions; count++)
				FCD_LCDDisplay0_Command(cmd);
		MX_UINT8 count;
		MX_UINT8 rowcount;
		//Define number of columns per line
			rowcount=80;
		#endif
			rowcount=40;
		#endif
				rowcount=16;
			#endif
				rowcount=20;
			#endif
		#endif
		//Start at beginning of the line
		FCD_LCDDisplay0_Cursor (0, Line);
		//Send out spaces to clear line
		for (count = 0; count < rowcount; count++)
			FCD_LCDDisplay0_RawSend(' ', 0x10);
		//Move back to the beginning of the line.
	   //set CGRAM address
	   FCD_LCDDisplay0_RawSend(64 + (nIdx << 3), 0);
	   delay_ms(2);
	   //write CGRAM data
	   FCD_LCDDisplay0_RawSend(d0, 0x10);
	   FCD_LCDDisplay0_RawSend(d1, 0x10);
	   FCD_LCDDisplay0_RawSend(d2, 0x10);
	   FCD_LCDDisplay0_RawSend(d3, 0x10);
	   FCD_LCDDisplay0_RawSend(d4, 0x10);
	   FCD_LCDDisplay0_RawSend(d5, 0x10);
	   FCD_LCDDisplay0_RawSend(d6, 0x10);
	   FCD_LCDDisplay0_RawSend(d7, 0x10);
	   //Clear the display
	   delay_ms(2);
	   delay_ms(2);
//LED(0): //Makró implementációk
		#if( LED_3__LED_POLE == 1)									//Active high polarity
			FC_CAL_Bit_High_DDR( LED_3__LED_PORT , LED_3__LED_TRIS , LED_3__LED_PIN );
		#else													//Active low polarity
			FC_CAL_Bit_Low_DDR( LED_3__LED_PORT , LED_3__LED_TRIS , LED_3__LED_PIN );
		#endif
		#endif
#include "C:\Program Files (x86)\Flowcode\v5\CAL\includes.c"
void FCM_wake_up()
	//Számítás
	//Számítás:
	//  led = 1
	FCV_LED = 1;
void main()
	//Initialization
	adcon1 = 0x0F;
	//Interrupt initialization code
	//Számítás
	//Számítás:
	//  szamlalo = 0
	//  led = 0
	FCV_SZAMLALO = 0;
	FCV_LED = 0;
	//Megszakítás
	//Megszakítás: Engedélyezés RB0INT
	st_bit(intcon2, INTEDG0);
	st_bit(intcon, GIE);
	st_bit(intcon, INT0IE);
	//Komponens makró hívása
	//Komponens makró hívása: Start()
	//Ciklus
	//Ciklus: Amíg1
	while (1)
		//Feltételes elágazás
		//Feltételes elágazás: szamlalo = 10?
		if (FCV_SZAMLALO == 10)
			//Számítás
			//Számítás:
			//  szamlalo = 0
			FCV_SZAMLALO = 0;
			//Komponens makró hívása: LEDOn()
			FCD_LED0_LEDOn();
			//Komponens makró hívása: Clear()
			//Komponens makró hívása: PrintString("GO TO SLEEP")
			FCD_LCDDisplay0_PrintString("GO TO SLEEP", 11);
			//Késleltetés
			//Késleltetés: 1 s
			Wdt_Delay_S(1);
			//C kód
			//C kód:
			sleep();
		// } else {
		//Komponens makró hívása: PrintNumber(szamlalo)
		FCD_LCDDisplay0_PrintNumber(FCV_SZAMLALO);
		//Számítás
		//Számítás:
		//  szamlalo = szamlalo + 1
		FCV_SZAMLALO = FCV_SZAMLALO + 1;
		//Komponens makró hívása: LEDOff()
		FCD_LED0_LEDOff();
		//Késleltetés
		//Késleltetés: 300 ms
		Wdt_Delay_Ms(255);
		Wdt_Delay_Ms(45);
	mainendloop: goto mainendloop;
void MX_INTERRUPT_MACRO(void)
	//Handler code for [RB0INT]
	#ifndef MX_INTHANDLER_intcon_INT0IF
	#define MX_INTHANDLER_intcon_INT0IF
	if (ts_bit(intcon, INT0IF) && ts_bit(intcon, INT0IE))
		#ifdef USE_FLOWCODE_ICD
			extern char ICD_Interrupt_Enable = 1;
		#endif
		FCM_wake_up();
		cr_bit(intcon, INT0IF);
			extern char ICD_Interrupt_Enable = 0;
		#endif	
	#else
	#warning "This interrupt has previously been enabled, so the macro <wake_up> may never get called."
	#endif
