#include "PT2313.h"
loudness:off
gain:0db
source:user assigned:
volume:muted or presetted
void PT2313::initialize(byte src,bool muted){
	Wire.begin();
	TWBR = ((F_CPU / 100000L) - 16) / 2;//force to 100khz!
	if (muted){
		volume(63);//muted
	} else {
		volume(PT2313_DEFVOL);
	audioSwitch_reg = 0x5C;
	source(src);
	balance(0);
	equalize(0,0);
	equalize(1,0);
void PT2313::source(byte val) {
	val = boundary(val,0,3);
	switch(val){
	case 0:
		bitClear(audioSwitch_reg,0);
		bitClear(audioSwitch_reg,1);
	break;
	case 1:
		bitSet(audioSwitch_reg,0);
	break;
	case 2:
		bitSet(audioSwitch_reg,1);
	break;
	writeByte(audioSwitch_reg);
void PT2313::gain(byte val) {
	switch(val){
	case 0://0db
		bitSet(audioSwitch_reg,3);
		bitSet(audioSwitch_reg,4);
	break;
	case 1://+3,75db
		bitClear(audioSwitch_reg,3);
	break;
	case 2://+7.5db
		bitClear(audioSwitch_reg,4);
	break;
	case 3://+11.25db
	break;
void PT2313::loudness(bool val) {
	if (val){
		bitClear(audioSwitch_reg,2);
	} else {
		bitSet(audioSwitch_reg,2);
void PT2313::volume(byte val) {
	val = boundary(val,0,0x3F);
	writeByte(PT2313_VOL_REG|(0x3F - val));
void PT2313::equalize(bool band,int val){
	byte temp;
	val = boundary(val,-7,7);
	if (val < 0) {
		temp = 7 - abs(val);
	} else {
		temp = 15 - val;
	if (band == 1){//treble
		writeByte(PT2313_TREBLE_REG|temp);
	} else {//bass
		writeByte(PT2313_BASS_REG|temp);
void PT2313::equalize(int bss,int trb){
	byte tempT;
	byte tempB;
	bss = boundary(bss,-7,7);
	trb = boundary(trb,-7,7);
	if (trb < 0) {
		tempT = 7 - abs(trb);
	} else {
		tempT = 15 - trb;
	if (bss < 0) {
		tempB = 7 - abs(bss);
	} else {
		tempB = 15 - bss;
	writeByte(PT2313_TREBLE_REG|tempT);
	writeByte(PT2313_BASS_REG|tempB);
void PT2313::balance(int val) {
	val = boundary(val,-31,31);
	if (val == 0) {
		writeByte(PT2313_L_ATT_REG|0x00);
		writeByte(PT2313_R_ATT_REG|0x00);
	} else {
		if (val < 0) {
			writeByte(PT2313_R_ATT_REG|((byte)abs(val)));
		} else {
			writeByte(PT2313_L_ATT_REG|((byte)abs(val)));
int PT2313::boundary(int val,int min,int max){
	if (val < min) val = min;
	if (val > max) val = max;
	return val;
void PT2313::writeByte(byte val) {
	Wire.beginTransmission(PT2313_ADDR);
	Wire.write(val);
	Wire.endTransmission();
	delay(10);
