; Source created with Parsic Version 3.x
; at              : 2008.03.25. 22:14:16
; Project File    : C:\PROGRA~1\Parsic\5M_3S.PIC
; Project Version : 1.0.3
; Created         : 2008.03.25. 21:05:48
; Last change     : 2008.03.25. 21:34:42
	PROCESSOR 16F628
	INCLUDE P16F628.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _XT_OSC & _LVP_OFF & _MCLRE_OFF
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
ZV2	= 32	; located in Bank 0
ZV2_HI	= 33	; located in Bank 0
EE1_FD	= 34	; located in Bank 0
TR1	= 35	; located in Bank 0
TR1_HI	= 36	; located in Bank 0
S2	= 37	; located in Bank 0
ZV1	= 38	; located in Bank 0
ZV1_HI	= 39	; located in Bank 0
ZV1_FD	= 40	; located in Bank 0
ZV2_FD	= 41	; located in Bank 0
OS1_FD	= 42	; located in Bank 0
OS2_FD	= 43	; located in Bank 0
S1	= 44	; located in Bank 0
S1_HI	= 45	; located in Bank 0
S0	= 46	; located in Bank 0
S0_HI	= 47	; located in Bank 0
OS3_FD	= 48	; located in Bank 0
S3	= 49	; located in Bank 0
RAM	= 50	; located in Bank 0
SYS_TMP1	= 112	; located in Bank 0, 1, 2, 3
SYS_TMP2	= 113	; located in Bank 0, 1, 2, 3
SYS_WSAV	= 114	; located in Bank 0, 1, 2, 3
SYS_SSAV	= 115	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 116	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	GOTO SYS_INIT
	NOP
	NOP
;Interrupt-Adress
	MOVWF SYS_WSAV	; save register
	SWAPF STATUS,W
	CLRF STATUS	; bank 0
	MOVWF SYS_SSAV
	MOVFW FSR
	MOVWF SYS_FSAV
	BTFSS INTCON,T0IF	; TMR0 ?
	GOTO NOTMR0INT
	BCF INTCON,T0IF	; Interrupt quitieren
	BCF STATUS,RP0	; Bank 0
	BCF STATUS,RP1	; Bank 0
	INCFSZ TR1,F
	GOTO SYS_INT_LABEL_0
	INCF TR1_HI,F
SYS_INT_LABEL_0
NOTMR0INT
EXITINT
	MOVFW SYS_FSAV
	MOVWF FSR
	SWAPF SYS_SSAV,W	; Register zurück
	MOVWF STATUS
	SWAPF SYS_WSAV,F
	SWAPF SYS_WSAV,W
	RETFIE
; Subroutines
EEINT_WRITE
	MOVFW INDF
	ADDWF SYS_TMP2,F
EEINT_WRITE_0
	BSF STATUS,RP0	; Bank 1
	BCF STATUS,RP1	; Bank 1
	MOVWF EEDATA
	BSF EECON1,WREN
EEINT_DISINT
	BCF INTCON,GIE
	BTFSC INTCON,GIE
	GOTO EEINT_DISINT
	MOVLW H'55'
	MOVWF EECON2
	MOVLW H'AA'
	MOVWF EECON2
	BSF EECON1,WR	; start write
	BSF INTCON,GIE
EEINT_WRITE_1
	BTFSC EECON1,WR	; ready ?
	GOTO EEINT_WRITE_1	; no
	BCF EECON1,WREN
	INCF EEADR,F
	INCF FSR,F
	DECFSZ SYS_TMP1,F
	GOTO EEINT_WRITE
	RETURN
EEINT_READ
	BSF EECON1,RD
	MOVFW EEDATA
	MOVWF INDF
	INCF EEADR,F
	INCF FSR,F
	DECFSZ SYS_TMP1,F
	GOTO EEINT_READ
	RETURN
; EE-Modul -> EE1
WRITE_EE1
	MOVLW 0
	MOVWF EEADR
	INCF EEADR,F
	CLRF SYS_TMP2
	BCF STATUS,IRP	; vars - located in Bank 0
	MOVLW 2
	MOVWF SYS_TMP1
	MOVLW LOW ZV2
	MOVWF FSR
	CALL EEINT_WRITE
	MOVLW 0	; write checksum
	MOVWF EEADR
	INCF SYS_TMP1,F
	MOVLW LOW SYS_TMP2
	MOVWF FSR
	MOVFW INDF
	CALL EEINT_WRITE_0
	RETURN
; EE-Modul -> EE1
READ_EE1
	MOVLW 0
	MOVWF EEADR
	INCF EEADR,F	; test checksum
	CLRF SYS_TMP2
	MOVLW 2
	MOVWF SYS_TMP1
READ_EE1_0
	BSF EECON1,RD
	MOVFW EEDATA
	ADDWF SYS_TMP2,F
	INCF EEADR,F
	DECFSZ SYS_TMP1,F
	GOTO READ_EE1_0
	MOVLW 0
	MOVWF EEADR
	BSF EECON1,RD
	MOVFW EEDATA
	SUBWF SYS_TMP2,W
	BTFSS STATUS,ZERO
	RETURN	; Checksum error
	INCF EEADR,F
	MOVLW 2
	MOVWF SYS_TMP1
	MOVLW LOW ZV2
	MOVWF FSR
	CALL EEINT_READ
	RETURN
;Initialisierung
SYS_INIT
	MOVLW B'00100000'
	MOVWF INTCON
; Set output before direction
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW 15
	MOVWF OPTION_REG
; Richtung setzen
	MOVLW B'11111111'
	MOVWF TRISA
	MOVLW B'11111110'
	MOVWF TRISB
	MOVLW 7	; Comparators off
	MOVWF CMCON
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'50'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	CALL READ_EE1	; read vars from internal EE
	CLRF TMR0
	BCF INTCON,T0IF
	BSF INTCON,GIE	; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
; Timer -> TR1
	MOVLW 7	; Test auf >=
	SUBWF TR1_HI,W	;F-W -> W
	BTFSS STATUS,ZERO
	GOTO LABEL_TR1_CHECK
	MOVLW 161
	SUBWF TR1,W	;F-W -> W
LABEL_TR1_CHECK
	BTFSS STATUS,CARRY
	GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
	SUBWF TR1_HI,F	;F-W -> F
	MOVLW 161
	SUBWF TR1,F	;F-W -> F
	BTFSS STATUS,CARRY
	DECF TR1_HI,F
LABEL_TR1_SET	; toggel output
	BTFSC S2,0
	GOTO LABEL_TR1_CLR
	BSF S2,0
	GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
	BCF S2,0
LABEL_TR1_ENDE
; Zähler -> ZV1
	BTFSS S2,4	; Reset ?
	GOTO LABEL_ZV1_COUNT
	CLRF ZV1
	CLRF ZV1_HI
	GOTO LABEL_ZV1_SETOUT
LABEL_ZV1_COUNT
; Test auf positive Flanke
	BTFSS S2,0
	GOTO LABEL_ZV1_SETFD
	BTFSC ZV1_FD,0
	BSF ZV1_FD,0
	BTFSC S2,1	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV1_BACKWARD
	INCFSZ ZV1,F
	INCF ZV1_HI,F
LABEL_ZV1_BACKWARD
	DECF ZV1,F
	INCFSZ ZV1,W
	DECF ZV1_HI,F
LABEL_ZV1_SETOUT
LABEL_ZV1_SETFD
; Test auf negative Flanke
	BTFSC S2,0
	GOTO LABEL_ZV1_EXIT
	BCF ZV1_FD,0
LABEL_ZV1_EXIT
; GND
	BCF S2,1	; immer Low
; Zähler -> ZV2
	BTFSS S2,5	; Reset ?
	GOTO LABEL_ZV2_COUNT
	CLRF ZV2
	CLRF ZV2_HI
	GOTO LABEL_ZV2_SETOUT
LABEL_ZV2_COUNT
	BTFSS S3,0
	GOTO LABEL_ZV2_SETFD
	BTFSC ZV2_FD,0
	BSF ZV2_FD,0
	BTFSC S2,6	; Vorwärts oder Rückwärts ?
	GOTO LABEL_ZV2_BACKWARD
	INCFSZ ZV2,F
	INCF ZV2_HI,F
LABEL_ZV2_BACKWARD
	DECF ZV2,F
	INCFSZ ZV2,W
	DECF ZV2_HI,F
LABEL_ZV2_SETOUT
LABEL_ZV2_SETFD
	BTFSC S3,0
	GOTO LABEL_ZV2_EXIT
	BCF ZV2_FD,0
LABEL_ZV2_EXIT
; One Shot -> OS1
	BTFSC PORTA,0
	GOTO LABEL_OS1_1
	BTFSC OS1_FD,0
	GOTO LABEL_OS1_1
	BSF OS1_FD,0
	BSF S2,3
	GOTO LABEL_OS1_2
LABEL_OS1_1
	BCF S2,3
	BTFSS PORTA,0
	GOTO LABEL_OS1_2
	BCF OS1_FD,0
LABEL_OS1_2
; One Shot -> OS2
	BTFSC PORTA,1
	GOTO LABEL_OS2_1
	BTFSC OS2_FD,0
	GOTO LABEL_OS2_1
	BSF OS2_FD,0
	BSF S2,6
	GOTO LABEL_OS2_2
LABEL_OS2_1
	BCF S2,6
	BTFSS PORTA,1
	GOTO LABEL_OS2_2
	BCF OS2_FD,0
LABEL_OS2_2
; Vergleich -> IF1
	MOVFW S0_HI
	SUBWF ZV1_HI,W	; F - W -> W
	BTFSS STATUS,ZERO	; Wenn ZERO gesetzt LOW-Byte testen
	GOTO LABEL_IF1_CHECK
	MOVFW S0
	SUBWF ZV1,W	; F - W -> W
LABEL_IF1_CHECK
	BTFSS STATUS,CARRY	; Test auf -> >=
	GOTO LABEL_IF1_FALSE
LABEL_IF1_TRUE
	BSF S2,2
	GOTO LABEL_IF1_EXIT
LABEL_IF1_FALSE
	BCF S2,2
LABEL_IF1_EXIT
; Vergleich -> IF2
	MOVFW S1_HI
	GOTO LABEL_IF2_CHECK
	MOVFW S1
LABEL_IF2_CHECK
	BTFSS STATUS,ZERO	; Test auf -> =
	GOTO LABEL_IF2_FALSE
LABEL_IF2_TRUE
	BSF S2,7
	GOTO LABEL_IF2_EXIT
LABEL_IF2_FALSE
	BCF S2,7
LABEL_IF2_EXIT
;AF1
	MOVFW S0_HI
	ADDLW HIGH 3
	MOVWF S1_HI
	MOVFW S0
	ADDLW LOW 3
	MOVWF S1
	BTFSC STATUS,CARRY
	INCF S1_HI,F
LABEL_AF1_EXIT
; UND - Gatter -> LG1
LABEL_LG1_1
	BTFSS S2,2
	GOTO LABEL_LG1_FALSE
LABEL_LG1_2
	BTFSS S2,0
LABEL_LG1_TRUE
	BSF PORTB,0
	GOTO LABEL_LG1_ENDE
LABEL_LG1_FALSE
	BCF PORTB,0
LABEL_LG1_ENDE
;AF2
	MOVFW ZV2_HI
	ADDLW HIGH 120
	MOVWF S0_HI
	MOVFW ZV2
	ADDLW LOW 120
	MOVWF S0
	BTFSC STATUS,CARRY
	INCF S0_HI,F
LABEL_AF2_EXIT
; One Shot -> OS3
	BTFSS S2,7
	GOTO LABEL_OS3_1
	BTFSC OS3_FD,0
	GOTO LABEL_OS3_1
	BSF OS3_FD,0
	BSF S2,4
	GOTO LABEL_OS3_2
LABEL_OS3_1
	BCF S2,4
	BTFSC S2,7
	GOTO LABEL_OS3_2
	BCF OS3_FD,0
LABEL_OS3_2
; ODER - Gatter -> LG2
LABEL_LG2_1
	BTFSC S2,3
	GOTO LABEL_LG2_TRUE
LABEL_LG2_2
	BTFSC S2,6
	GOTO LABEL_LG2_TRUE
LABEL_LG2_FALSE
	BCF S3,0
	GOTO LABEL_LG2_ENDE
LABEL_LG2_TRUE
	BSF S3,0
LABEL_LG2_ENDE
; Schmitt-Trigger 16-Bit -> ST1
	MOVLW LOW 300
	MOVWF SYS_TMP1
	MOVLW HIGH 300
	MOVWF SYS_TMP2
	BTFSS S2,5	; Ausgang gesetzt ?
	GOTO LABEL_ST1_TEST	; without Hysterese
	MOVLW HIGH 0
	SUBWF SYS_TMP2,F
	MOVLW LOW 0
	SUBWF SYS_TMP1,F
	BTFSS STATUS,CARRY
	DECF SYS_TMP2,F
LABEL_ST1_TEST
	MOVFW SYS_TMP2
	SUBWF ZV2_HI,W
	BTFSS STATUS,ZERO
	GOTO LABEL_ST1_TEST2
	MOVFW SYS_TMP1
	SUBWF ZV2,W
LABEL_ST1_TEST2
	BTFSS STATUS,CARRY
	GOTO LABEL_ST1_RESET
LABEL_ST1_SET
	BSF S2,5	; if greater or equal
	GOTO LABEL_ST1_ENDE
LABEL_ST1_RESET
	BCF S2,5	; if less
LABEL_ST1_ENDE
; EE-Modul -> EE1
; Test of falling edge
	BTFSC S3,0
	GOTO LABEL_EE1_SETFD
	BTFSS EE1_FD,0
	BCF EE1_FD,0
	CALL WRITE_EE1
LABEL_EE1_SETFD
; test input
	BTFSS S3,0
	GOTO LABEL_EE1_EXIT
	BSF EE1_FD,0
LABEL_EE1_EXIT
	GOTO MAIN
	ORG H'2100'
	DE 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	END
