* Title:    I2C master library using hardware TWI interface
* Author:   Peter Fleury <pfleury@gmx.ch>  http://jump.to/fleury
* File:     $Id: twimaster.c,v 1.3 2005/07/02 11:14:21 Peter Exp $
* Software: AVR-GCC 3.4.3 / avr-libc 1.2.3
* Target:   any AVR device with hardware TWI 
* Usage:    API compatible with I2C Software Library i2cmaster.h
#include <inttypes.h>
#include <compat/twi.h>
#include <i2cmaster.h>
/* define CPU frequency in Mhz here if not defined in Makefile */
#ifndef F_CPU
#define F_CPU 4000000UL
#endif
/* I2C clock in Hz */
#define SCL_CLOCK  100000L
 Initialization of the I2C bus interface. Need to be called only once
void i2c_init(void)
  /* initialize TWI clock: 100 kHz clock, TWPS = 0 => prescaler = 1 */
  TWSR = 0;                         /* no prescaler */
  TWBR = ((F_CPU/SCL_CLOCK)-16)/2;  /* must be > 10 for stable operation */
}/* i2c_init */
  Issues a start condition and sends address and transfer direction.
  return 0 = device accessible, 1= failed to access device
unsigned char i2c_start(unsigned char address)
    uint8_t   twst;
	// send START condition
	TWCR = (1<<TWINT) | (1<<TWSTA) | (1<<TWEN);
	// wait until transmission completed
	while(!(TWCR & (1<<TWINT)));
	// check value of TWI Status Register. Mask prescaler bits.
	twst = TW_STATUS & 0xF8;
	if ( (twst != TW_START) && (twst != TW_REP_START)) return 1;
	// send device address
	TWDR = address;
	TWCR = (1<<TWINT) | (1<<TWEN);
	// wail until transmission completed and ACK/NACK has been received
	if ( (twst != TW_MT_SLA_ACK) && (twst != TW_MR_SLA_ACK) ) return 1;
	return 0;
}/* i2c_start */
 If device is busy, use ack polling to wait until device is ready
 Input:   address and transfer direction of I2C device
void i2c_start_wait(unsigned char address)
    uint8_t   twst;
    while ( 1 )
    	if ( (twst != TW_START) && (twst != TW_REP_START)) continue;
    	TWDR = address;
    	if ( (twst == TW_MT_SLA_NACK )||(twst ==TW_MR_DATA_NACK) ) 
    	    /* device busy, send stop condition to terminate write operation */
	        TWCR = (1<<TWINT) | (1<<TWEN) | (1<<TWSTO);
	        // wait until stop condition is executed and bus released
	        while(TWCR & (1<<TWSTO));
    	    continue;
    	//if( twst != TW_MT_SLA_ACK) return 1;
    	break;
}/* i2c_start_wait */
 Issues a repeated start condition and sends address and transfer direction 
 Return:  0 device accessible
          1 failed to access device
unsigned char i2c_rep_start(unsigned char address)
    return i2c_start( address );
}/* i2c_rep_start */
 Terminates the data transfer and releases the I2C bus
void i2c_stop(void)
    /* send stop condition */
}/* i2c_stop */
  Send one byte to I2C device
  Input:    byte to be transfered
  Return:   0 write successful 
            1 write failed
unsigned char i2c_write( unsigned char data )
    uint8_t   twst;
	// send data to the previously addressed device
	TWDR = data;
	if( twst != TW_MT_DATA_ACK) return 1;
	return 0;
}/* i2c_write */
 Read one byte from the I2C device, request more data from device 
 Return:  byte read from I2C device
unsigned char i2c_readAck(void)
	TWCR = (1<<TWINT) | (1<<TWEN) | (1<<TWEA);
    return TWDR;
}/* i2c_readAck */
 Read one byte from the I2C device, read is followed by a stop condition 
unsigned char i2c_readNak(void)
    return TWDR;
}/* i2c_readNak */
