<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.4">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.025" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.025" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<wire x1="0" y1="0" x2="107.93" y2="0" width="0" layer="20"/>
<wire x1="107.93" y1="0" x2="107.93" y2="98.73" width="0" layer="20"/>
<wire x1="107.93" y1="98.73" x2="0" y2="98.73" width="0" layer="20"/>
<wire x1="0" y1="98.73" x2="0" y2="0" width="0" layer="20"/>
</plain>
<libraries>
<library name="display-kingbright-1">
<description>&lt;b&gt;KINGBRIGHT Numeric Displays&lt;/b&gt;&lt;p&gt;
&lt;author&gt;librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="SA56-11">
<description>&lt;b&gt;Kingbright 14.2mm (0.56 INCH) SINGLE DIGIT NUMERIC DUISPLAY&lt;/b&gt;&lt;p&gt;
Source: SA56-11EWA(Ver1189471036.pdf</description>
<wire x1="6.273" y1="-9.434" x2="6.273" y2="9.434" width="0.1524" layer="21"/>
<wire x1="-6.273" y1="9.434" x2="6.273" y2="9.434" width="0.1524" layer="21"/>
<wire x1="-6.273" y1="9.434" x2="-6.273" y2="-9.434" width="0.1524" layer="21"/>
<wire x1="6.273" y1="-9.434" x2="-6.273" y2="-9.434" width="0.1524" layer="21"/>
<wire x1="2.4372" y1="-6.5358" x2="2.107" y2="-6.866" width="0.4064" layer="51"/>
<circle x="4.572" y="-6.35" radius="0.381" width="0.762" layer="51"/>
<pad name="1" x="-5.08" y="-7.62" drill="0.8" shape="long" rot="R90"/>
<pad name="2" x="-2.54" y="-7.62" drill="0.8" shape="long" rot="R90"/>
<pad name="3" x="0" y="-7.62" drill="0.8" shape="long" rot="R90"/>
<pad name="4" x="2.54" y="-7.62" drill="0.8" shape="long" rot="R90"/>
<pad name="5" x="5.08" y="-7.62" drill="0.8" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="7.62" drill="0.8" shape="long" rot="R90"/>
<pad name="7" x="2.54" y="7.62" drill="0.8" shape="long" rot="R90"/>
<pad name="8" x="0" y="7.62" drill="0.8" shape="long" rot="R90"/>
<pad name="9" x="-2.54" y="7.62" drill="0.8" shape="long" rot="R90"/>
<pad name="10" x="-5.08" y="7.62" drill="0.8" shape="long" rot="R90"/>
<text x="-6.35" y="10.16" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.35" y="-11.43" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<polygon width="0.4064" layer="51">
<vertex x="-1.425" y="6.1"/>
<vertex x="-1.25" y="7.1"/>
<vertex x="3.675" y="7.1"/>
<vertex x="3.55" y="6.1"/>
</polygon>
<vertex x="3.2565" y="1.0555"/>
<vertex x="4.3128" y="7.0544"/>
<vertex x="4.622" y="7.0626" curve="-104.72173"/>
<vertex x="5.2533" y="6.2038"/>
<vertex x="4.2" y="0.5"/>
<vertex x="3.725" y="0.5"/>
</polygon>
<vertex x="-2.95" y="1.1"/>
<vertex x="-1.9" y="7.1"/>
<vertex x="-2.175" y="7.1" curve="77.708822"/>
<vertex x="-3.075" y="6.375"/>
<vertex x="-4.1" y="0.5"/>
<vertex x="-3.525" y="0.5"/>
</polygon>
<vertex x="-3.05" y="0.025"/>
<vertex x="-2.425" y="0.65"/>
<vertex x="2.7" y="0.65"/>
<vertex x="3.075" y="0.125"/>
<vertex x="2.625" y="-0.35"/>
<vertex x="-2.675" y="-0.35"/>
</polygon>
<vertex x="1.5" y="-5.825"/>
<vertex x="1.325" y="-6.825"/>
<vertex x="-3.6" y="-6.825"/>
<vertex x="-3.475" y="-5.825"/>
</polygon>
<vertex x="-3.2565" y="-0.7305"/>
<vertex x="-4.2378" y="-6.7794"/>
<vertex x="-4.547" y="-6.7876" curve="-104.72173"/>
<vertex x="-5.1783" y="-5.9288"/>
<vertex x="-4.2" y="-0.175"/>
<vertex x="-3.725" y="-0.175"/>
</polygon>
<vertex x="2.975" y="-0.975"/>
<vertex x="1.975" y="-6.825"/>
<vertex x="2.25" y="-6.825" curve="77.708822"/>
<vertex x="3.15" y="-6.1"/>
<vertex x="4.1" y="-0.425"/>
<vertex x="3.525" y="-0.425"/>
</polygon>
</package>
</packages>
</library>
<library name="transistor">
<description>&lt;b&gt;Transistors&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="TO92-EBC">
<description>&lt;b&gt;TO-92&lt;/b&gt; Pads In Line E B C from top&lt;p&gt;</description>
<wire x1="-2.095" y1="-2.921" x2="2.095" y2="-2.921" width="0.127" layer="21"/>
<wire x1="-2.413" y1="-0.1341" x2="2.413" y2="-0.1341" width="0.127" layer="21" curve="-129.583"/>
<wire x1="1.136" y1="-1.397" x2="-1.136" y2="-1.397" width="0.127" layer="51"/>
<wire x1="-2.413" y1="-0.1341" x2="-2.664" y2="-1.397" width="0.127" layer="51" curve="27.9376"/>
<wire x1="-2.664" y1="-1.397" x2="-2.413" y2="-2.4059" width="0.127" layer="51" curve="22.4788"/>
<wire x1="-1.404" y1="-1.397" x2="-2.664" y2="-1.397" width="0.127" layer="51"/>
<wire x1="-2.4135" y1="-2.4059" x2="-2.095" y2="-2.921" width="0.127" layer="21" curve="13.0385"/>
<wire x1="-1.136" y1="-1.397" x2="-1.404" y2="-1.397" width="0.127" layer="21"/>
<wire x1="2.413" y1="-2.4059" x2="2.664" y2="-1.397" width="0.127" layer="51" curve="22.4788"/>
<wire x1="2.664" y1="-1.397" x2="2.413" y2="-0.1341" width="0.127" layer="51" curve="27.9376"/>
<wire x1="2.664" y1="-1.397" x2="1.404" y2="-1.397" width="0.127" layer="51"/>
<wire x1="1.404" y1="-1.397" x2="1.136" y2="-1.397" width="0.127" layer="21"/>
<wire x1="2.095" y1="-2.921" x2="2.4247" y2="-2.3818" width="0.127" layer="21" curve="13.6094"/>
<pad name="C" x="2.54" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<pad name="E" x="-2.54" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<pad name="B" x="0" y="-1.27" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.54" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-4.572" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="rcl">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="0207/10">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.7" diameter="1.9304" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.7" diameter="1.9304" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
</package>
<package name="E5-8,5">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 5.08 mm, diameter 8.5 mm</description>
<wire x1="-1.143" y1="0" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.143" x2="-0.254" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.143" x2="-0.254" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.143" x2="-0.889" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.143" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.143" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="2.032" x2="-3.302" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.651" x2="-2.921" y2="1.651" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="0" x2="-1.143" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="4.445" width="0.1524" layer="21"/>
<pad name="+" x="-2.54" y="0" drill="1.016" diameter="2.54"/>
<pad name="-" x="2.54" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<text x="4.1402" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.5146" y="-3.0226" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.143" x2="0.889" y2="1.143" layer="21"/>
</package>
<package name="C050-025X075">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.016" x2="-3.683" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.27" x2="3.429" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.016" x2="3.683" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="-3.429" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="3.683" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.27" x2="3.683" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.016" x2="-3.429" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.016" x2="-3.429" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" diameter="1.9304" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" diameter="1.9304" shape="octagon"/>
<text x="-3.429" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="diode">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
<packages>
<package name="DO41-10">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2.54 mm, horizontal, grid 10.16 mm</description>
<wire x1="2.032" y1="-1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.762" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<pad name="A" x="5.08" y="0" drill="0.7" diameter="2.1844"/>
<pad name="C" x="-5.08" y="0" drill="0.7" diameter="2.1844"/>
<text x="-2.032" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.27" x2="-1.143" y2="1.27" layer="21"/>
<rectangle x1="2.032" y1="-0.381" x2="3.937" y2="0.381" layer="21"/>
<rectangle x1="-3.937" y1="-0.381" x2="-2.032" y2="0.381" layer="21"/>
</package>
</packages>
</library>
<library name="linear">
<description>&lt;b&gt;Linear Devices&lt;/b&gt;&lt;p&gt;
Operational amplifiers,  comparators, voltage regulators, ADCs, DACs, etc.&lt;p&gt;
<packages>
<package name="TO220V">
<description>&lt;b&gt;TO 200 vertical&lt;/b&gt;</description>
<wire x1="5.08" y1="-1.143" x2="4.953" y2="-4.064" width="0.127" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="4.953" y2="-4.064" width="0.127" layer="21"/>
<wire x1="4.699" y1="-4.318" x2="-4.699" y2="-4.318" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-4.699" y2="-4.318" width="0.127" layer="21"/>
<wire x1="-4.953" y1="-4.064" x2="-5.08" y2="-1.143" width="0.127" layer="21"/>
<circle x="-4.4958" y="-3.7084" radius="0.254" width="0.127" layer="21"/>
<pad name="1" x="-2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="0" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-2.54" drill="1.016" shape="long" rot="R90"/>
<text x="-5.08" y="-6.0452" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-7.62" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.175" y="-3.175" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="-3.175" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="-3.175" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="-5.334" y1="-0.762" x2="5.334" y2="0" layer="21"/>
<rectangle x1="-5.334" y1="-1.27" x2="-3.429" y2="-0.762" layer="21"/>
<rectangle x1="-1.651" y1="-1.27" x2="-0.889" y2="-0.762" layer="21"/>
<rectangle x1="-3.429" y1="-1.27" x2="-1.651" y2="-0.762" layer="51"/>
<rectangle x1="0.889" y1="-1.27" x2="1.651" y2="-0.762" layer="21"/>
<rectangle x1="3.429" y1="-1.27" x2="5.334" y2="-0.762" layer="21"/>
<rectangle x1="-0.889" y1="-1.27" x2="0.889" y2="-0.762" layer="51"/>
<rectangle x1="1.651" y1="-1.27" x2="3.429" y2="-0.762" layer="51"/>
</package>
</packages>
</library>
<library name="microchip">
<description>&lt;b&gt;Microchip PIC Microcontrollers and other Devices&lt;/b&gt;&lt;p&gt;
Based on the following sources :
&lt;ul&gt;
&lt;li&gt;Microchip Data Book, 1993
&lt;li&gt;THE EMERGING WORLD STANDARD, 1995/1996
&lt;li&gt;Microchip, Technical Library CD-ROM, June 1998
&lt;li&gt;www.microchip.com
&lt;/ul&gt;
<packages>
<package name="DIL18">
<description>&lt;B&gt;Dual In Line&lt;/B&gt;&lt;p&gt;
package type P</description>
<wire x1="-11.43" y1="-0.635" x2="-11.43" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-0.635" x2="-11.43" y2="0.635" width="0.1524" layer="21" curve="180"/>
<wire x1="11.43" y1="-2.54" x2="-11.43" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="11.43" y1="-2.54" x2="11.43" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="2.54" x2="11.43" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="2.54" x2="-11.43" y2="0.635" width="0.1524" layer="21"/>
<pad name="1" x="-10.16" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="10.16" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="10.16" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="-10.16" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-11.8618" y="-2.54" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-10.16" y="-0.889" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="DS1820">
<description>Dallas DS1820 (TO-92)
&lt;br&gt;
&lt;a href="http://jayakody2000lk.wordpress.com"&gt;jayakody2000lk.wordpress.com&lt;/a&gt;</description>
<packages>
<package name="TO-92">
<wire x1="-2.095" y1="-1.651" x2="-0.7869" y2="2.5484" width="0.1524" layer="21" curve="-111.097684"/>
<wire x1="0.7869" y1="2.5484" x2="2.095" y2="-1.651" width="0.1524" layer="21" curve="-111.097684"/>
<wire x1="-2.095" y1="-1.651" x2="2.095" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-2.254" y1="-0.254" x2="-0.286" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-2.655" y1="-0.254" x2="-2.254" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="-0.286" y1="-0.254" x2="0.286" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="2.254" y1="-0.254" x2="2.655" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="0.286" y1="-0.254" x2="2.254" y2="-0.254" width="0.1524" layer="51"/>
<wire x1="-0.7864" y1="2.5484" x2="0.7864" y2="2.5484" width="0.1524" layer="51" curve="-34.298964"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" diameter="1.27" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="0.8128" diameter="1.27" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="0" drill="0.8128" diameter="1.27" shape="long" rot="R90"/>
<text x="3.683" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="4.191" y="-1.27" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="crystal">
<description>&lt;b&gt;Crystals and Crystal Resonators&lt;/b&gt;&lt;p&gt;
<packages>
<package name="HC49U70">
<description>&lt;b&gt;CRYSTAL&lt;/b&gt;</description>
<wire x1="-3.048" y1="-2.54" x2="3.048" y2="-2.54" width="0.4064" layer="21"/>
<wire x1="-3.048" y1="2.54" x2="3.048" y2="2.54" width="0.4064" layer="21"/>
<wire x1="-3.048" y1="-2.032" x2="3.048" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-0.3302" y1="1.016" x2="-0.3302" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.3302" y1="-1.016" x2="0.3048" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="0.3048" y1="-1.016" x2="0.3048" y2="1.016" width="0.1524" layer="21"/>
<wire x1="0.3048" y1="1.016" x2="-0.3302" y2="1.016" width="0.1524" layer="21"/>
<wire x1="0.6858" y1="1.016" x2="0.6858" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.6858" y1="1.016" x2="-0.6858" y2="0" width="0.1524" layer="21"/>
<wire x1="0.6858" y1="0" x2="1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="0.6858" y1="0" x2="0.6858" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.6858" y1="0" x2="-1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.6858" y1="0" x2="-0.6858" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="2.54" x2="-3.048" y2="-2.54" width="0.4064" layer="21" curve="180"/>
<wire x1="3.048" y1="2.54" x2="3.048" y2="-2.54" width="0.4064" layer="21" curve="-180"/>
<wire x1="-3.048" y1="-2.032" x2="-3.048" y2="2.032" width="0.1524" layer="21" curve="-180"/>
<wire x1="3.048" y1="2.032" x2="3.048" y2="-2.032" width="0.1524" layer="21" curve="-180"/>
<wire x1="3.048" y1="2.032" x2="-3.048" y2="2.032" width="0.1524" layer="21"/>
<pad name="1" x="-2.413" y="0" drill="0.8128" diameter="1.9304"/>
<pad name="2" x="2.413" y="0" drill="0.8128" diameter="1.9304"/>
<text x="-5.08" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.445" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.572" y1="-2.794" x2="-4.064" y2="2.794" layer="43"/>
<rectangle x1="-5.08" y1="-2.54" x2="-4.572" y2="2.54" layer="43"/>
<rectangle x1="-5.588" y1="-2.032" x2="-5.08" y2="2.032" layer="43"/>
<rectangle x1="-5.842" y1="-1.27" x2="-5.588" y2="1.27" layer="43"/>
<rectangle x1="-4.064" y1="-3.048" x2="4.064" y2="3.048" layer="43"/>
<rectangle x1="4.064" y1="-2.794" x2="4.572" y2="2.794" layer="43"/>
<rectangle x1="4.572" y1="-2.54" x2="5.08" y2="2.54" layer="43"/>
<rectangle x1="5.08" y1="-2.032" x2="5.588" y2="2.032" layer="43"/>
<rectangle x1="5.588" y1="-1.27" x2="5.842" y2="1.27" layer="43"/>
</package>
</packages>
</library>
<library name="switch-misc">
<description>&lt;b&gt;Switches&lt;/b&gt;&lt;p&gt;
Marquardt, RAFI, ITT, and others&lt;p&gt;
<packages>
<package name="DT6">
<description>&lt;b&gt;ITT SWITCH&lt;/b&gt;</description>
<wire x1="1.016" y1="4.826" x2="1.016" y2="5.588" width="0.1524" layer="21"/>
<wire x1="1.016" y1="4.826" x2="-1.016" y2="4.826" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="4.826" x2="-1.016" y2="5.588" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-5.969" x2="1.016" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-5.969" x2="-1.016" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-4.826" x2="-1.016" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-5.588" x2="1.016" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-5.588" x2="-1.016" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-5.588" x2="1.016" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="5.588" x2="1.016" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="5.588" x2="-1.016" y2="5.969" width="0.1524" layer="21"/>
<wire x1="1.016" y1="5.588" x2="1.016" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="2.54" x2="1.143" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.143" x2="-2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="-1.905" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-2.54" x2="1.143" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.143" x2="2.54" y2="0.635" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.635" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="0.635" x2="2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0" x2="2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="-2.9512" x2="-5.334" y2="2.9512" width="0.1524" layer="21" curve="302.09017"/>
<wire x1="-2.347" y1="3.9236" x2="2.347" y2="3.9236" width="0.1524" layer="21" curve="-61.77363"/>
<wire x1="-1.8556" y1="3.7578" x2="1.8556" y2="3.7578" width="0.1524" layer="21" curve="-52.56028"/>
<wire x1="-1.8556" y1="-3.7578" x2="1.8556" y2="-3.7578" width="0.1524" layer="21" curve="52.56028"/>
<wire x1="-2.347" y1="-3.9236" x2="2.347" y2="-3.9236" width="0.1524" layer="21" curve="61.77363"/>
<wire x1="-5.334" y1="-2.9512" x2="-5.334" y2="2.9512" width="0.1524" layer="21"/>
<wire x1="-3.7578" y1="1.8556" x2="-3.7578" y2="-1.8556" width="0.1524" layer="21" curve="52.56028"/>
<wire x1="-3.9236" y1="2.347" x2="-3.9236" y2="-2.347" width="0.1524" layer="21" curve="61.77363"/>
<wire x1="-3.7578" y1="-1.8556" x2="-1.8556" y2="-3.7578" width="0.1524" layer="51" curve="37.43972"/>
<wire x1="-3.9236" y1="-2.347" x2="-2.347" y2="-3.9236" width="0.1524" layer="51" curve="28.22637"/>
<wire x1="-3.9236" y1="2.347" x2="-2.347" y2="3.9236" width="0.1524" layer="51" curve="-28.22637"/>
<wire x1="-3.7578" y1="1.8556" x2="-1.8556" y2="3.7578" width="0.1524" layer="51" curve="-37.43972"/>
<wire x1="3.7578" y1="-1.8556" x2="3.7578" y2="1.8556" width="0.1524" layer="21" curve="52.56028"/>
<wire x1="3.9236" y1="-2.347" x2="3.9236" y2="2.347" width="0.1524" layer="21" curve="61.77363"/>
<wire x1="1.8556" y1="-3.7578" x2="3.7578" y2="-1.8556" width="0.1524" layer="51" curve="37.43972"/>
<wire x1="2.347" y1="-3.9236" x2="3.9236" y2="-2.347" width="0.1524" layer="51" curve="28.22637"/>
<wire x1="1.8556" y1="3.7578" x2="3.7578" y2="1.8556" width="0.1524" layer="51" curve="-37.43972"/>
<wire x1="2.347" y1="3.9236" x2="3.9236" y2="2.347" width="0.1524" layer="51" curve="-28.22637"/>
<pad name="1" x="-2.54" y="2.54" drill="0.6" diameter="1.9304" shape="octagon"/>
<pad name="2" x="2.54" y="2.54" drill="0.6" diameter="1.9304" shape="octagon"/>
<pad name="3" x="2.54" y="-2.54" drill="0.6" diameter="1.9304" shape="octagon"/>
<pad name="4" x="-2.54" y="-2.54" drill="0.6" diameter="1.9304" shape="octagon"/>
<text x="-2.54" y="6.477" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-7.874" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="solpad">
<description>&lt;b&gt;Solder Pads/Test Points&lt;/b&gt;&lt;p&gt;
<packages>
<package name="SE14">
<description>&lt;b&gt;SOLDER PAD&lt;/b&gt;&lt;p&gt;
drill 1.4 mm</description>
<wire x1="-1.524" y1="0.635" x2="-1.524" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.524" x2="1.524" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.524" x2="1.524" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.635" x2="1.524" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.635" x2="-0.635" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.524" x2="0.635" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.524" x2="-1.524" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.524" x2="-0.635" y2="-1.524" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="0.762" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="0.381" width="0.254" layer="51"/>
<pad name="MP" x="0" y="0" drill="1.397" diameter="2.54" shape="octagon"/>
<text x="-1.397" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0" y="0.381" size="0.0254" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="LED1" library="display-kingbright-1" package="SA56-11" value="7-SEG_SA56-11" x="34.29" y="85.09"/>
<element name="LED2" library="display-kingbright-1" package="SA56-11" value="7-SEG_SA56-11" x="46.99" y="85.09"/>
<element name="LED3" library="display-kingbright-1" package="SA56-11" value="7-SEG_SA56-11" x="59.69" y="85.09"/>
<element name="LED4" library="display-kingbright-1" package="SA56-11" value="7-SEG_SA56-11" x="72.39" y="85.09"/>
<element name="T1" library="transistor" package="TO92-EBC" value="BC 556B" x="33.02" y="66.04" rot="R90"/>
<element name="T2" library="transistor" package="TO92-EBC" value="BC 556B" x="45.72" y="66.04" rot="R90"/>
<element name="T3" library="transistor" package="TO92-EBC" value="BC 556B" x="58.42" y="66.04" rot="R90"/>
<element name="T4" library="transistor" package="TO92-EBC" value="BC 556B" x="71.12" y="66.04" rot="R90"/>
<element name="R1" library="rcl" package="0207/10" value="1k" x="67.31" y="60.96" rot="R90"/>
<element name="R2" library="rcl" package="0207/10" value="1k" x="63.5" y="60.96" rot="R90"/>
<element name="R3" library="rcl" package="0207/10" value="1k" x="50.8" y="60.96" rot="R90"/>
<element name="R4" library="rcl" package="0207/10" value="1k" x="41.91" y="64.77" rot="R90"/>
<element name="R5" library="rcl" package="0207/10" value="" x="13.97" y="59.69" rot="R90"/>
<element name="R6" library="rcl" package="0207/10" value="" x="17.78" y="59.69" rot="R90"/>
<element name="R7" library="rcl" package="0207/10" value="" x="20.32" y="35.56" rot="R180"/>
<element name="R8" library="rcl" package="0207/10" value="" x="27.94" y="63.5" rot="R90"/>
<element name="R9" library="rcl" package="0207/10" value="" x="20.32" y="31.75" rot="R180"/>
<element name="R10" library="rcl" package="0207/10" value="" x="20.32" y="27.94" rot="R180"/>
<element name="R11" library="rcl" package="0207/10" value="" x="20.32" y="39.37" rot="R180"/>
<element name="R12" library="rcl" package="0207/10" value="" x="31.4325" y="53.34" rot="R90"/>
<element name="R13" library="rcl" package="0207/10" value="10k" x="28.2575" y="18.7325" rot="R180"/>
<element name="R14" library="rcl" package="0207/10" value="10k" x="56.1975" y="22.5425" rot="R180"/>
<element name="R15" library="rcl" package="0207/10" value="10k" x="26.3525" y="21.9075" rot="R180"/>
<element name="D1" library="diode" package="DO41-10" value="1N4004" x="95.25" y="52.07" rot="R180"/>
<element name="D2" library="diode" package="DO41-10" value="1N4004" x="95.25" y="44.45" rot="R180"/>
<element name="D3" library="diode" package="DO41-10" value="1N4004" x="95.25" y="48.26"/>
<element name="D4" library="diode" package="DO41-10" value="1N4004" x="95.25" y="40.64"/>
<element name="IC2" library="linear" package="TO220V" value="7805TV" x="86.36" y="66.04" rot="R270"/>
<element name="C1" library="rcl" package="E5-8,5" value="470uF" x="90.17" y="30.48" rot="R270"/>
<element name="C2" library="rcl" package="E5-8,5" value="100uF" x="83.82" y="50.8" rot="R270"/>
<element name="C3" library="rcl" package="C050-025X075" value="100n" x="77.47" y="60.96" rot="R270"/>
<element name="C4" library="rcl" package="C050-025X075" value="100n" x="91.44" y="57.15" rot="R180"/>
<element name="R16" library="rcl" package="0207/10" value="10k" x="49.53" y="8.89" rot="R270"/>
<element name="R17" library="rcl" package="0207/10" value="10k" x="73.66" y="8.89" rot="R270"/>
<element name="R18" library="rcl" package="0207/10" value="10k" x="80.01" y="8.89" rot="R270"/>
<element name="IC3" library="microchip" package="DIL18" value="PIC16F628P" x="46.99" y="43.18" rot="R180">
<attribute name="OC_NEWARK" value="19C7272" x="-15.24" y="73.66" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="PIC16F628-04I/P" x="-15.24" y="73.66" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="MICROCHIP" x="-15.24" y="73.66" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="9760407" x="-15.24" y="73.66" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="IC1" library="DS1820" package="TO-92" value="DS1820" x="49.53" y="31.75" rot="R180"/>
<element name="C5" library="rcl" package="C050-025X075" value="" x="73.66" y="48.26" rot="R180"/>
<element name="C6" library="rcl" package="C050-025X075" value="" x="73.66" y="43.18" rot="R180"/>
<element name="Q1" library="crystal" package="HC49U70" value="" x="66.04" y="45.72" rot="R90">
<attribute name="OC_NEWARK" value="unknown" x="120.65" y="64.77" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MPN" value="" x="120.65" y="64.77" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="MF" value="" x="120.65" y="64.77" size="1.778" layer="27" rot="R90" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="120.65" y="64.77" size="1.778" layer="27" rot="R90" display="off"/>
</element>
<element name="C7" library="rcl" package="C050-025X075" value="" x="46.99" y="43.18" rot="R270"/>
<element name="R19" library="rcl" package="0207/10" value="4k7" x="55.88" y="30.48" rot="R270"/>
<element name="R20" library="rcl" package="0207/10" value="10k" x="25.4" y="8.89" rot="R270"/>
<element name="R21" library="rcl" package="0207/10" value="10k" x="32.7025" y="30.7975" rot="R90"/>
<element name="S1" library="switch-misc" package="DT6" value="DT6" x="40.64" y="11.43"/>
<element name="S2" library="switch-misc" package="DT6" value="DT6" x="64.77" y="11.43"/>
<element name="S3" library="switch-misc" package="DT6" value="DT6" x="88.9" y="11.43"/>
<element name="LSP1" library="solpad" package="SE14" value="SE14" x="104.14" y="52.07"/>
<element name="LSP2" library="solpad" package="SE14" value="SE14" x="104.14" y="40.64"/>
<element name="S4" library="switch-misc" package="DT6" value="Reset" x="16.51" y="11.43"/>
</elements>
<signals>
<signal name="N$1">
<contactref element="T4" pad="C"/>
<contactref element="LED4" pad="3"/>
<wire x1="72.39" y1="68.58" x2="72.39" y2="77.47" width="1.27" layer="16"/>
</signal>
<signal name="N$2">
<contactref element="LED3" pad="3"/>
<contactref element="T3" pad="C"/>
<wire x1="59.69" y1="68.58" x2="59.69" y2="77.47" width="1.27" layer="16"/>
</signal>
<signal name="N$5">
<contactref element="LED4" pad="7"/>
<contactref element="LED1" pad="7"/>
<contactref element="LED3" pad="7"/>
<contactref element="LED2" pad="7"/>
<contactref element="R5" pad="2"/>
<wire x1="36.83" y1="92.71" x2="36.83" y2="91.44" width="1.27" layer="16"/>
<via x="36.83" y="91.44" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="36.83" y1="91.44" x2="36.83" y2="87.3125" width="0.8128" layer="1"/>
<via x="36.83" y="87.3125" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="36.83" y1="87.3125" x2="25.4" y2="87.3125" width="1.016" layer="16"/>
<wire x1="36.83" y1="87.3125" x2="49.53" y2="87.3125" width="1.016" layer="16"/>
<via x="49.53" y="87.3125" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="49.53" y1="87.3125" x2="49.53" y2="91.44" width="0.8128" layer="1"/>
<via x="49.53" y="91.44" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="49.53" y1="91.44" x2="49.53" y2="92.71" width="1.27" layer="16"/>
<wire x1="62.23" y1="92.71" x2="62.23" y2="91.44" width="1.27" layer="16"/>
<via x="62.23" y="91.44" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="62.23" y1="91.44" x2="62.23" y2="87.3125" width="0.8128" layer="1"/>
<via x="62.23" y="87.3125" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="62.23" y1="87.3125" x2="49.53" y2="87.3125" width="1.016" layer="16"/>
<wire x1="74.93" y1="87.3125" x2="62.23" y2="87.3125" width="1.016" layer="16"/>
<wire x1="74.93" y1="87.3125" x2="74.93" y2="92.71" width="1.016" layer="16"/>
<wire x1="25.4" y1="87.3125" x2="23.8125" y2="87.3125" width="1.27" layer="16"/>
<wire x1="23.8125" y1="87.3125" x2="13.97" y2="77.47" width="1.27" layer="16"/>
<wire x1="13.97" y1="77.47" x2="13.97" y2="64.77" width="1.27" layer="16"/>
</signal>
<signal name="N$3">
<contactref element="LED4" pad="6"/>
<contactref element="LED1" pad="6"/>
<contactref element="LED3" pad="6"/>
<contactref element="LED2" pad="6"/>
<contactref element="R6" pad="2"/>
<wire x1="26.67" y1="85.09" x2="39.37" y2="85.09" width="1.016" layer="16"/>
<wire x1="39.37" y1="85.09" x2="52.07" y2="85.09" width="1.016" layer="16"/>
<wire x1="52.07" y1="85.09" x2="64.77" y2="85.09" width="1.016" layer="16"/>
<wire x1="64.77" y1="85.09" x2="76.835" y2="85.09" width="1.016" layer="16"/>
<wire x1="77.47" y1="92.71" x2="77.47" y2="85.725" width="1.016" layer="16"/>
<wire x1="77.47" y1="85.725" x2="76.835" y2="85.09" width="1.016" layer="16"/>
<wire x1="39.37" y1="92.71" x2="39.37" y2="91.44" width="0.8128" layer="16"/>
<via x="39.37" y="91.44" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="39.37" y1="91.44" x2="39.37" y2="85.09" width="0.8128" layer="1"/>
<via x="39.37" y="85.09" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="52.07" y1="92.71" x2="52.07" y2="91.44" width="0.8128" layer="16"/>
<via x="52.07" y="91.44" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="52.07" y1="91.44" x2="52.07" y2="85.09" width="0.8128" layer="1"/>
<via x="52.07" y="85.09" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="64.77" y1="92.71" x2="64.77" y2="91.44" width="0.8128" layer="16"/>
<via x="64.77" y="91.44" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="64.77" y1="91.44" x2="64.77" y2="85.09" width="0.8128" layer="1"/>
<via x="64.77" y="85.09" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="17.78" y1="64.77" x2="17.78" y2="77.47" width="1.27" layer="16"/>
<wire x1="17.78" y1="77.47" x2="25.4" y2="85.09" width="1.27" layer="16"/>
<wire x1="25.4" y1="85.09" x2="26.67" y2="85.09" width="1.27" layer="16"/>
</signal>
<signal name="N$4">
<contactref element="LED4" pad="4"/>
<contactref element="LED1" pad="4"/>
<contactref element="LED3" pad="4"/>
<contactref element="LED2" pad="4"/>
<contactref element="R7" pad="2"/>
<wire x1="49.53" y1="77.47" x2="49.53" y2="78.105" width="1.27" layer="16"/>
<wire x1="74.93" y1="77.47" x2="74.93" y2="82.8675" width="1.016" layer="16"/>
<wire x1="74.93" y1="82.8675" x2="62.23" y2="82.8675" width="1.016" layer="16"/>
<wire x1="62.23" y1="82.8675" x2="50.4825" y2="82.8675" width="1.016" layer="16"/>
<wire x1="49.53" y1="82.8675" x2="36.83" y2="82.8675" width="1.016" layer="16"/>
<wire x1="36.83" y1="77.47" x2="36.83" y2="78.74" width="0.8128" layer="16"/>
<via x="36.83" y="78.74" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="36.83" y1="78.74" x2="36.83" y2="82.8675" width="0.8128" layer="1"/>
<via x="36.83" y="82.8675" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="62.23" y1="77.47" x2="62.23" y2="78.74" width="0.8128" layer="16"/>
<via x="62.23" y="78.74" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="62.23" y1="78.74" x2="62.23" y2="82.8675" width="0.8128" layer="1"/>
<via x="62.23" y="82.8675" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="49.53" y1="77.47" x2="49.53" y2="78.74" width="0.8128" layer="16"/>
<via x="49.53" y="78.74" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="49.53" y1="78.74" x2="49.53" y2="82.8675" width="0.8128" layer="1"/>
<via x="49.53" y="82.8675" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="49.53" y1="82.8675" x2="50.4825" y2="82.8675" width="0.8128" layer="16"/>
<wire x1="36.83" y1="82.8675" x2="26.9875" y2="82.8675" width="1.016" layer="16"/>
<wire x1="26.9875" y1="82.8675" x2="25.4" y2="81.28" width="1.016" layer="16"/>
<wire x1="7.62" y1="57.15" x2="7.62" y2="46.99" width="1.27" layer="16"/>
<wire x1="12.7" y1="62.23" x2="20.32" y2="62.23" width="1.27" layer="16"/>
<wire x1="20.32" y1="62.23" x2="21.59" y2="63.5" width="1.27" layer="16"/>
<wire x1="15.24" y1="35.56" x2="16.51" y2="35.56" width="0.8128" layer="16"/>
<wire x1="16.51" y1="35.56" x2="17.4625" y2="36.83" width="0.8128" layer="16"/>
<wire x1="17.4625" y1="36.83" x2="17.4625" y2="41.91" width="0.8128" layer="16"/>
<wire x1="17.4625" y1="41.91" x2="16.1925" y2="43.18" width="0.8128" layer="16"/>
<wire x1="16.1925" y1="43.18" x2="11.43" y2="43.18" width="0.8128" layer="16"/>
<wire x1="25.4" y1="81.28" x2="21.59" y2="77.47" width="1.27" layer="16"/>
<wire x1="21.59" y1="77.47" x2="21.59" y2="63.5" width="1.27" layer="16"/>
<wire x1="7.62" y1="46.99" x2="10.16" y2="44.45" width="1.27" layer="16"/>
<wire x1="7.62" y1="57.15" x2="12.7" y2="62.23" width="1.27" layer="16"/>
<wire x1="11.43" y1="43.18" x2="10.16" y2="44.45" width="0.8128" layer="16"/>
</signal>
<signal name="N$6">
<contactref element="LED4" pad="2"/>
<contactref element="LED1" pad="2"/>
<contactref element="LED3" pad="2"/>
<contactref element="LED2" pad="2"/>
<contactref element="R8" pad="2"/>
<wire x1="27.94" y1="68.58" x2="27.94" y2="73.3425" width="1.27" layer="16"/>
<wire x1="31.75" y1="74.93" x2="31.75" y2="77.47" width="1.27" layer="16"/>
<via x="31.75" y="74.93" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="31.75" y1="74.93" x2="43.4975" y2="74.93" width="0.8128" layer="1"/>
<via x="43.4975" y="74.93" extent="1-16" drill="0.6" diameter="1.6764"/>
<via x="44.7675" y="74.93" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="44.45" y1="74.93" x2="44.7675" y2="74.93" width="0.8128" layer="16"/>
<wire x1="44.7675" y1="74.93" x2="56.1975" y2="74.93" width="0.8128" layer="1"/>
<via x="56.1975" y="74.93" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="56.1975" y1="74.93" x2="57.15" y2="74.93" width="0.8128" layer="16"/>
<via x="57.4675" y="74.93" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="57.4675" y1="74.93" x2="69.85" y2="74.93" width="0.8128" layer="1"/>
<wire x1="69.85" y1="74.93" x2="69.85" y2="77.47" width="0.8128" layer="1"/>
<wire x1="43.4975" y1="74.93" x2="44.45" y2="74.93" width="0.8128" layer="16"/>
<wire x1="44.45" y1="74.93" x2="44.45" y2="77.47" width="0.8128" layer="16"/>
<wire x1="57.15" y1="77.47" x2="57.15" y2="74.93" width="0.8128" layer="16"/>
<wire x1="57.15" y1="74.93" x2="57.4675" y2="74.93" width="0.8128" layer="16"/>
<wire x1="31.75" y1="74.93" x2="29.5275" y2="74.93" width="1.27" layer="16"/>
<wire x1="29.5275" y1="74.93" x2="27.94" y2="73.3425" width="1.27" layer="16"/>
</signal>
<signal name="N$7">
<contactref element="LED4" pad="1"/>
<contactref element="LED1" pad="1"/>
<contactref element="LED3" pad="1"/>
<contactref element="LED2" pad="1"/>
<contactref element="R9" pad="2"/>
<wire x1="29.21" y1="80.645" x2="41.91" y2="80.645" width="1.016" layer="16"/>
<wire x1="41.91" y1="77.47" x2="41.91" y2="80.645" width="1.016" layer="16"/>
<wire x1="41.91" y1="80.645" x2="54.61" y2="80.645" width="1.016" layer="16"/>
<wire x1="54.61" y1="77.47" x2="54.61" y2="80.645" width="1.016" layer="16"/>
<wire x1="54.61" y1="80.645" x2="67.31" y2="80.645" width="1.016" layer="16"/>
<wire x1="67.31" y1="80.645" x2="67.31" y2="77.47" width="1.016" layer="16"/>
<wire x1="29.21" y1="80.645" x2="29.21" y2="77.47" width="1.27" layer="16"/>
<wire x1="29.21" y1="77.47" x2="27.94" y2="77.47" width="1.27" layer="16"/>
<wire x1="27.94" y1="77.47" x2="24.13" y2="73.66" width="1.27" layer="16"/>
<wire x1="24.13" y1="73.66" x2="24.13" y2="60.96" width="1.27" layer="16"/>
<wire x1="24.13" y1="60.96" x2="22.86" y2="59.69" width="1.27" layer="16"/>
<wire x1="10.16" y1="55.88" x2="10.16" y2="48.26" width="1.27" layer="16"/>
<wire x1="10.16" y1="48.26" x2="11.43" y2="46.99" width="1.27" layer="16"/>
<wire x1="22.86" y1="59.69" x2="13.97" y2="59.69" width="1.27" layer="16"/>
<wire x1="11.43" y1="46.99" x2="12.7" y2="45.72" width="0.8128" layer="16"/>
<wire x1="12.7" y1="45.72" x2="16.51" y2="45.72" width="0.8128" layer="16"/>
<wire x1="16.51" y1="45.72" x2="19.3675" y2="42.8625" width="0.8128" layer="16"/>
<wire x1="19.3675" y1="42.8625" x2="19.3675" y2="35.2425" width="0.8128" layer="16"/>
<wire x1="19.3675" y1="35.2425" x2="16.51" y2="31.75" width="0.8128" layer="16"/>
<wire x1="16.51" y1="31.75" x2="15.24" y2="31.75" width="0.8128" layer="16"/>
<wire x1="13.97" y1="59.69" x2="10.16" y2="55.88" width="1.27" layer="16"/>
</signal>
<signal name="N$8">
<contactref element="LED4" pad="9"/>
<contactref element="LED1" pad="9"/>
<contactref element="LED3" pad="9"/>
<contactref element="LED2" pad="9"/>
<contactref element="R10" pad="2"/>
<wire x1="2.54" y1="44.45" x2="2.54" y2="73.66" width="1.27" layer="16"/>
<wire x1="31.75" y1="96.52" x2="25.4" y2="96.52" width="1.27" layer="16"/>
<wire x1="25.4" y1="96.52" x2="2.54" y2="73.66" width="1.27" layer="16"/>
<wire x1="31.75" y1="92.71" x2="31.75" y2="96.52" width="1.27" layer="16"/>
<wire x1="31.75" y1="96.52" x2="44.45" y2="96.52" width="1.27" layer="16"/>
<wire x1="44.45" y1="96.52" x2="57.15" y2="96.52" width="1.27" layer="16"/>
<wire x1="57.15" y1="96.52" x2="69.215" y2="96.52" width="1.27" layer="16"/>
<wire x1="69.215" y1="96.52" x2="69.85" y2="95.885" width="1.27" layer="16"/>
<wire x1="69.85" y1="95.885" x2="69.85" y2="92.71" width="1.27" layer="16"/>
<wire x1="57.15" y1="92.71" x2="57.15" y2="96.52" width="1.27" layer="16"/>
<wire x1="44.45" y1="92.71" x2="44.45" y2="96.52" width="1.27" layer="16"/>
<wire x1="15.24" y1="27.94" x2="13.97" y2="27.94" width="1.27" layer="16"/>
<wire x1="13.97" y1="27.94" x2="11.43" y2="30.48" width="1.27" layer="16"/>
<wire x1="11.43" y1="30.48" x2="11.43" y2="35.56" width="1.27" layer="16"/>
<wire x1="11.43" y1="35.56" x2="2.54" y2="44.45" width="1.27" layer="16"/>
</signal>
<signal name="N$9">
<contactref element="LED4" pad="10"/>
<contactref element="LED1" pad="10"/>
<contactref element="LED3" pad="10"/>
<contactref element="LED2" pad="10"/>
<contactref element="R11" pad="2"/>
<wire x1="15.24" y1="39.37" x2="11.43" y2="39.37" width="1.27" layer="16"/>
<wire x1="67.31" y1="92.71" x2="67.31" y2="89.2175" width="1.016" layer="16"/>
<wire x1="67.31" y1="89.2175" x2="54.61" y2="89.2175" width="1.016" layer="16"/>
<wire x1="54.61" y1="92.71" x2="54.61" y2="89.2175" width="1.016" layer="16"/>
<wire x1="54.61" y1="89.2175" x2="41.91" y2="89.2175" width="1.016" layer="16"/>
<wire x1="41.91" y1="92.71" x2="41.91" y2="89.2175" width="1.016" layer="16"/>
<wire x1="41.91" y1="89.2175" x2="29.21" y2="89.2175" width="1.016" layer="16"/>
<wire x1="29.21" y1="89.2175" x2="29.21" y2="90.17" width="1.016" layer="16"/>
<wire x1="29.21" y1="90.17" x2="29.21" y2="92.71" width="1.016" layer="16"/>
<wire x1="11.43" y1="39.37" x2="5.08" y2="45.72" width="1.27" layer="16"/>
<wire x1="5.08" y1="45.72" x2="5.08" y2="60.96" width="1.27" layer="16"/>
<wire x1="5.08" y1="60.96" x2="11.43" y2="67.31" width="1.27" layer="16"/>
<wire x1="11.43" y1="67.31" x2="11.43" y2="78.74" width="1.27" layer="16"/>
<wire x1="11.43" y1="78.74" x2="22.86" y2="90.17" width="1.27" layer="16"/>
<wire x1="22.86" y1="90.17" x2="29.21" y2="90.17" width="1.27" layer="16"/>
</signal>
<signal name="N$10">
<contactref element="LED2" pad="3"/>
<contactref element="T2" pad="C"/>
<wire x1="46.99" y1="68.58" x2="46.99" y2="77.47" width="1.27" layer="16"/>
</signal>
<signal name="N$11">
<contactref element="LED1" pad="3"/>
<contactref element="T1" pad="C"/>
<wire x1="34.29" y1="68.58" x2="34.29" y2="77.47" width="1.27" layer="16"/>
</signal>
<signal name="N$17">
<contactref element="R8" pad="1"/>
<contactref element="IC3" pad="6"/>
<wire x1="44.45" y1="52.07" x2="40.64" y2="55.88" width="1.27" layer="16"/>
<wire x1="40.64" y1="55.88" x2="29.21" y2="55.88" width="1.27" layer="16"/>
<wire x1="29.21" y1="55.88" x2="27.94" y2="57.15" width="1.27" layer="16"/>
<wire x1="27.94" y1="57.15" x2="27.94" y2="58.42" width="1.27" layer="16"/>
<wire x1="44.45" y1="46.99" x2="44.45" y2="52.07" width="1.27" layer="16"/>
</signal>
<signal name="N$18">
<contactref element="R5" pad="1"/>
<contactref element="IC3" pad="7"/>
<wire x1="13.97" y1="55.88" x2="15.24" y2="57.15" width="1.27" layer="16"/>
<wire x1="15.24" y1="57.15" x2="20.32" y2="57.15" width="1.27" layer="16"/>
<wire x1="20.32" y1="57.15" x2="21.59" y2="55.88" width="1.27" layer="16"/>
<wire x1="21.59" y1="55.88" x2="21.59" y2="54.61" width="1.27" layer="16"/>
<wire x1="21.59" y1="54.61" x2="22.86" y2="53.34" width="1.27" layer="16"/>
<wire x1="22.86" y1="53.34" x2="39.37" y2="53.34" width="1.27" layer="16"/>
<wire x1="41.91" y1="50.8" x2="39.37" y2="53.34" width="1.27" layer="16"/>
<wire x1="13.97" y1="54.61" x2="13.97" y2="55.88" width="1.27" layer="16"/>
<wire x1="41.91" y1="46.99" x2="41.91" y2="50.8" width="1.27" layer="16"/>
</signal>
<signal name="N$19">
<contactref element="R6" pad="1"/>
<contactref element="R13" pad="2"/>
<contactref element="IC3" pad="8"/>
<wire x1="39.37" y1="49.53" x2="38.1" y2="50.8" width="1.27" layer="16"/>
<wire x1="17.78" y1="54.61" x2="17.78" y2="52.07" width="1.27" layer="16"/>
<wire x1="17.78" y1="52.07" x2="19.05" y2="50.8" width="1.27" layer="16"/>
<wire x1="19.05" y1="50.8" x2="38.1" y2="50.8" width="1.27" layer="16"/>
<wire x1="39.37" y1="46.99" x2="39.37" y2="45.4025" width="0.8128" layer="16"/>
<wire x1="39.37" y1="45.4025" x2="38.1" y2="44.1325" width="0.8128" layer="16"/>
<wire x1="38.1" y1="44.1325" x2="25.0825" y2="44.1325" width="0.8128" layer="16"/>
<wire x1="25.0825" y1="44.1325" x2="23.1775" y2="42.2275" width="0.8128" layer="16"/>
<wire x1="23.1775" y1="42.2275" x2="23.1775" y2="26.035" width="0.8128" layer="16"/>
<wire x1="39.37" y1="46.99" x2="39.37" y2="49.53" width="1.27" layer="16"/>
<wire x1="23.1775" y1="26.035" x2="24.13" y2="25.0825" width="0.8128" layer="16"/>
<wire x1="24.13" y1="25.0825" x2="24.13" y2="19.685" width="0.8128" layer="16"/>
<wire x1="24.13" y1="19.685" x2="23.1775" y2="18.7325" width="0.8128" layer="16"/>
</signal>
<signal name="N$20">
<contactref element="R12" pad="1"/>
<contactref element="R15" pad="2"/>
<contactref element="IC3" pad="9"/>
<wire x1="36.83" y1="46.99" x2="31.4325" y2="46.99" width="1.27" layer="16"/>
<wire x1="31.4325" y1="46.99" x2="31.4325" y2="48.26" width="1.27" layer="16"/>
<wire x1="36.83" y1="46.99" x2="25.4" y2="46.99" width="0.8128" layer="16"/>
<wire x1="25.4" y1="46.99" x2="21.2725" y2="43.18" width="0.8128" layer="16"/>
<wire x1="21.2725" y1="43.18" x2="21.2725" y2="21.9075" width="0.8128" layer="16"/>
</signal>
<signal name="N$21">
<contactref element="R11" pad="1"/>
<contactref element="IC3" pad="10"/>
<wire x1="36.83" y1="39.37" x2="36.83" y2="34.925" width="0.8128" layer="16"/>
<wire x1="36.83" y1="34.925" x2="36.7665" y2="33.5915" width="0.8128" layer="16"/>
<wire x1="36.7665" y1="33.5915" x2="30.226" y2="33.5915" width="0.8128" layer="16"/>
<wire x1="30.226" y1="33.5915" x2="28.575" y2="35.2425" width="0.8128" layer="16"/>
<wire x1="28.575" y1="35.2425" x2="28.575" y2="38.1" width="0.8128" layer="16"/>
<wire x1="28.575" y1="38.1" x2="27.305" y2="39.37" width="0.8128" layer="16"/>
<wire x1="27.305" y1="39.37" x2="25.4" y2="39.37" width="0.8128" layer="16"/>
</signal>
<signal name="N$22">
<contactref element="R7" pad="1"/>
<contactref element="IC3" pad="11"/>
<wire x1="25.4" y1="35.56" x2="29.337" y2="31.6865" width="0.8128" layer="16"/>
<wire x1="29.337" y1="31.6865" x2="39.37" y2="31.6865" width="0.8128" layer="16"/>
<wire x1="39.37" y1="31.6865" x2="39.37" y2="39.37" width="0.8128" layer="16"/>
</signal>
<signal name="N$23">
<contactref element="R9" pad="1"/>
<contactref element="R14" pad="2"/>
<contactref element="IC3" pad="12"/>
<wire x1="41.91" y1="29.7815" x2="28.0035" y2="29.7815" width="0.8128" layer="16"/>
<wire x1="28.0035" y1="29.7815" x2="26.035" y2="31.75" width="0.8128" layer="16"/>
<wire x1="26.035" y1="31.75" x2="25.4" y2="31.75" width="0.8128" layer="16"/>
<wire x1="47.9425" y1="22.5425" x2="51.1175" y2="22.5425" width="0.8128" layer="16"/>
<wire x1="41.91" y1="29.7815" x2="41.91" y2="39.37" width="0.8128" layer="16"/>
<wire x1="41.91" y1="29.7815" x2="41.91" y2="28.575" width="0.8128" layer="16"/>
<wire x1="41.91" y1="28.575" x2="47.9425" y2="22.5425" width="0.8128" layer="16"/>
</signal>
<signal name="N$24">
<contactref element="R10" pad="1"/>
<contactref element="IC3" pad="13"/>
<wire x1="25.4" y1="27.94" x2="39.37" y2="27.94" width="0.8128" layer="16"/>
<wire x1="39.37" y1="27.94" x2="48.26" y2="19.05" width="0.8128" layer="16"/>
<wire x1="48.26" y1="19.05" x2="52.07" y2="19.05" width="0.8128" layer="16"/>
<wire x1="52.07" y1="19.05" x2="53.594" y2="20.32" width="0.8128" layer="16"/>
<wire x1="53.594" y1="20.32" x2="53.594" y2="24.13" width="0.8128" layer="16"/>
<wire x1="53.594" y1="24.13" x2="52.07" y2="25.4" width="0.8128" layer="16"/>
<wire x1="52.07" y1="25.4" x2="48.26" y2="25.4" width="0.8128" layer="16"/>
<wire x1="48.26" y1="25.4" x2="44.45" y2="29.21" width="0.8128" layer="16"/>
<wire x1="44.45" y1="29.21" x2="44.45" y2="39.37" width="0.8128" layer="16"/>
</signal>
<signal name="N$25">
<contactref element="R12" pad="2"/>
<contactref element="LED2" pad="5"/>
<wire x1="31.4325" y1="58.42" x2="31.115" y2="58.7375" width="1.016" layer="16"/>
<wire x1="31.115" y1="58.7375" x2="31.115" y2="72.0725" width="1.016" layer="16"/>
<via x="31.115" y="72.0725" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="31.115" y1="72.0725" x2="52.07" y2="72.0725" width="1.016" layer="1"/>
<via x="52.07" y="72.0725" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="52.07" y1="72.0725" x2="52.07" y2="77.47" width="1.016" layer="16"/>
</signal>
<signal name="N$26">
<contactref element="T1" pad="B"/>
<contactref element="R4" pad="2"/>
<wire x1="34.29" y1="66.04" x2="38.1" y2="66.04" width="1.27" layer="16"/>
<wire x1="38.1" y1="66.04" x2="41.91" y2="69.85" width="1.27" layer="16"/>
</signal>
<signal name="N$27">
<contactref element="T2" pad="B"/>
<contactref element="R3" pad="2"/>
<wire x1="46.99" y1="66.04" x2="50.8" y2="66.04" width="1.27" layer="16"/>
</signal>
<signal name="N$28">
<contactref element="T3" pad="B"/>
<contactref element="R2" pad="2"/>
<wire x1="59.69" y1="66.04" x2="63.5" y2="66.04" width="1.27" layer="16"/>
</signal>
<signal name="N$13">
<contactref element="R1" pad="1"/>
<contactref element="IC3" pad="3"/>
<wire x1="67.31" y1="55.88" x2="67.31" y2="56.8325" width="1.016" layer="16"/>
<wire x1="67.31" y1="56.8325" x2="65.786" y2="58.3565" width="0.8128" layer="16"/>
<wire x1="65.786" y1="58.3565" x2="58.3565" y2="58.3565" width="0.8128" layer="16"/>
<wire x1="52.07" y1="52.07" x2="52.07" y2="46.99" width="1.27" layer="16"/>
<wire x1="52.07" y1="52.07" x2="57.15" y2="57.15" width="1.27" layer="16"/>
<wire x1="57.15" y1="57.15" x2="58.3565" y2="58.3565" width="1.016" layer="16"/>
</signal>
<signal name="N$14">
<contactref element="R2" pad="1"/>
<contactref element="IC3" pad="2"/>
<wire x1="63.5" y1="55.88" x2="60.96" y2="55.88" width="1.27" layer="16"/>
<wire x1="60.96" y1="55.88" x2="54.61" y2="49.53" width="1.27" layer="16"/>
<wire x1="54.61" y1="49.53" x2="54.61" y2="46.99" width="1.27" layer="16"/>
</signal>
<signal name="N$15">
<contactref element="R3" pad="1"/>
<contactref element="IC3" pad="1"/>
<wire x1="50.8" y1="55.88" x2="53.975" y2="59.944" width="1.27" layer="16"/>
<wire x1="53.975" y1="59.944" x2="68.961" y2="59.944" width="0.8128" layer="16"/>
<wire x1="71.12" y1="57.15" x2="71.12" y2="52.07" width="1.27" layer="16"/>
<wire x1="68.961" y1="59.944" x2="71.12" y2="57.785" width="0.8128" layer="16"/>
<wire x1="71.12" y1="57.785" x2="71.12" y2="57.15" width="0.8128" layer="16"/>
<wire x1="71.12" y1="52.07" x2="60.96" y2="52.07" width="1.27" layer="16"/>
<wire x1="60.96" y1="52.07" x2="57.15" y2="48.26" width="1.27" layer="16"/>
<wire x1="57.15" y1="48.26" x2="57.15" y2="46.99" width="1.27" layer="16"/>
</signal>
<signal name="N$16">
<contactref element="R4" pad="1"/>
<contactref element="IC3" pad="18"/>
<wire x1="41.91" y1="59.69" x2="48.26" y2="59.69" width="1.27" layer="16"/>
<wire x1="49.784" y1="61.595" x2="71.12" y2="61.595" width="0.8128" layer="16"/>
<wire x1="73.66" y1="58.42" x2="73.66" y2="39.37" width="1.27" layer="16"/>
<wire x1="73.66" y1="39.37" x2="57.15" y2="39.37" width="1.27" layer="16"/>
<wire x1="71.12" y1="61.595" x2="73.66" y2="59.055" width="0.8128" layer="16"/>
<wire x1="73.66" y1="59.055" x2="73.66" y2="58.42" width="0.8128" layer="16"/>
<wire x1="49.784" y1="61.595" x2="49.784" y2="61.214" width="1.016" layer="16"/>
<wire x1="49.784" y1="61.214" x2="48.26" y2="59.69" width="1.016" layer="16"/>
</signal>
<signal name="N$29">
<contactref element="R1" pad="2"/>
<contactref element="T4" pad="B"/>
<wire x1="67.31" y1="66.04" x2="72.39" y2="66.04" width="1.27" layer="16"/>
</signal>
<signal name="+5V">
<contactref element="T4" pad="E"/>
<contactref element="T3" pad="E"/>
<contactref element="T2" pad="E"/>
<contactref element="T1" pad="E"/>
<contactref element="C3" pad="1"/>
<contactref element="C2" pad="+"/>
<contactref element="R18" pad="2"/>
<contactref element="R16" pad="2"/>
<contactref element="R17" pad="2"/>
<contactref element="IC1" pad="3"/>
<contactref element="C7" pad="2"/>
<contactref element="IC3" pad="14"/>
<contactref element="R19" pad="2"/>
<contactref element="R20" pad="2"/>
<wire x1="80.01" y1="3.81" x2="73.66" y2="3.81" width="1.778" layer="16"/>
<wire x1="73.66" y1="3.81" x2="55.8165" y2="3.81" width="1.778" layer="16"/>
<wire x1="55.8165" y1="3.81" x2="49.53" y2="3.81" width="1.778" layer="16"/>
<wire x1="49.53" y1="3.81" x2="25.4" y2="3.81" width="1.778" layer="16"/>
<wire x1="34.29" y1="63.5" x2="46.99" y2="63.5" width="1.27" layer="16"/>
<wire x1="46.99" y1="63.5" x2="59.69" y2="63.5" width="1.27" layer="16"/>
<wire x1="59.69" y1="63.5" x2="72.39" y2="63.5" width="0.8128" layer="16"/>
<wire x1="46.99" y1="39.37" x2="46.99" y2="40.64" width="1.27" layer="16"/>
<wire x1="72.39" y1="63.5" x2="77.47" y2="63.5" width="1.27" layer="16"/>
<wire x1="77.47" y1="63.5" x2="83.82" y2="63.5" width="1.27" layer="16"/>
<wire x1="83.82" y1="53.34" x2="83.82" y2="63.5" width="1.27" layer="16"/>
<wire x1="46.99" y1="40.64" x2="46.99" y2="31.75" width="1.27" layer="16"/>
<wire x1="55.88" y1="25.4" x2="55.8165" y2="25.3365" width="0.8128" layer="16"/>
<wire x1="55.8165" y1="25.3365" x2="55.8165" y2="18.034" width="0.8128" layer="16"/>
<via x="55.8165" y="18.034" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="55.8165" y1="18.034" x2="55.8165" y2="5.715" width="0.8128" layer="1"/>
<via x="55.8165" y="5.715" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="55.8165" y1="5.715" x2="55.8165" y2="3.81" width="0.8128" layer="16"/>
<wire x1="46.99" y1="31.75" x2="46.99" y2="29.845" width="0.8128" layer="16"/>
<wire x1="46.99" y1="29.845" x2="49.2125" y2="27.6225" width="0.8128" layer="16"/>
<wire x1="49.2125" y1="27.6225" x2="54.61" y2="27.6225" width="0.8128" layer="16"/>
<wire x1="54.61" y1="27.6225" x2="55.88" y2="26.3525" width="0.8128" layer="16"/>
<wire x1="55.88" y1="26.3525" x2="55.88" y2="25.4" width="0.8128" layer="16"/>
<wire x1="97.79" y1="36.83" x2="97.155" y2="37.465" width="1.27" layer="16"/>
<wire x1="97.155" y1="37.465" x2="97.155" y2="68.58" width="1.27" layer="16"/>
<wire x1="80.01" y1="3.81" x2="97.79" y2="3.81" width="1.27" layer="16"/>
<wire x1="97.79" y1="3.81" x2="97.79" y2="36.83" width="1.27" layer="16"/>
<contactref element="IC2" pad="3"/>
<wire x1="97.155" y1="68.58" x2="93.98" y2="71.755" width="1.27" layer="16"/>
<wire x1="93.98" y1="71.755" x2="80.01" y2="71.755" width="1.27" layer="16"/>
<wire x1="80.01" y1="71.755" x2="77.47" y2="69.215" width="1.27" layer="16"/>
<wire x1="77.47" y1="69.215" x2="77.47" y2="63.5" width="1.27" layer="16"/>
</signal>
<signal name="N$12">
<contactref element="D2" pad="C"/>
<contactref element="D4" pad="A"/>
<contactref element="LSP2" pad="MP"/>
<wire x1="100.33" y1="44.45" x2="100.33" y2="40.64" width="1.27" layer="16"/>
<wire x1="104.14" y1="40.64" x2="100.33" y2="40.64" width="1.27" layer="16"/>
</signal>
<signal name="N$30">
<contactref element="D1" pad="C"/>
<contactref element="D3" pad="A"/>
<contactref element="LSP1" pad="MP"/>
<wire x1="100.33" y1="52.07" x2="100.33" y2="48.26" width="1.27" layer="16"/>
<wire x1="100.33" y1="52.07" x2="104.14" y2="52.07" width="1.27" layer="16"/>
</signal>
<signal name="N$32">
<contactref element="D3" pad="C"/>
<contactref element="D4" pad="C"/>
<contactref element="C1" pad="+"/>
<contactref element="C4" pad="1"/>
<wire x1="90.17" y1="40.64" x2="92.71" y2="40.64" width="1.27" layer="16"/>
<wire x1="92.71" y1="40.64" x2="93.98" y2="41.91" width="1.27" layer="16"/>
<wire x1="93.98" y1="41.91" x2="93.98" y2="48.26" width="1.27" layer="16"/>
<wire x1="90.17" y1="48.26" x2="93.98" y2="48.26" width="1.27" layer="16"/>
<wire x1="90.17" y1="40.64" x2="90.17" y2="33.02" width="1.27" layer="16"/>
<contactref element="IC2" pad="1"/>
<wire x1="93.98" y1="48.26" x2="93.98" y2="57.15" width="1.27" layer="16"/>
<wire x1="93.98" y1="57.15" x2="93.98" y2="66.675" width="1.27" layer="16"/>
<wire x1="93.98" y1="66.675" x2="92.075" y2="68.58" width="1.27" layer="16"/>
<wire x1="92.075" y1="68.58" x2="83.82" y2="68.58" width="1.27" layer="16"/>
</signal>
<signal name="GND">
<contactref element="D1" pad="A"/>
<contactref element="D2" pad="A"/>
<contactref element="C4" pad="2"/>
<contactref element="C1" pad="-"/>
<contactref element="C3" pad="2"/>
<contactref element="C2" pad="-"/>
<contactref element="IC3" pad="5"/>
<contactref element="IC1" pad="1"/>
<contactref element="C5" pad="1"/>
<contactref element="C6" pad="1"/>
<contactref element="C7" pad="1"/>
<contactref element="S1" pad="4"/>
<contactref element="S3" pad="4"/>
<contactref element="S2" pad="4"/>
<contactref element="S4" pad="4"/>
<wire x1="13.97" y1="8.89" x2="38.1" y2="8.89" width="1.778" layer="16"/>
<wire x1="38.1" y1="8.89" x2="62.23" y2="8.89" width="1.778" layer="16"/>
<wire x1="62.23" y1="8.89" x2="86.36" y2="8.89" width="1.778" layer="16"/>
<wire x1="86.36" y1="8.89" x2="91.44" y2="8.89" width="1.778" layer="16"/>
<wire x1="94.615" y1="8.89" x2="91.44" y2="8.89" width="1.27" layer="16"/>
<wire x1="46.99" y1="46.99" x2="46.99" y2="45.72" width="1.27" layer="16"/>
<wire x1="77.47" y1="48.26" x2="77.47" y2="52.705" width="1.27" layer="16"/>
<wire x1="77.47" y1="52.705" x2="77.47" y2="58.42" width="1.27" layer="16"/>
<wire x1="83.82" y1="48.26" x2="77.47" y2="48.26" width="1.27" layer="16"/>
<wire x1="77.47" y1="48.26" x2="76.2" y2="48.26" width="1.27" layer="16"/>
<wire x1="76.2" y1="48.26" x2="76.2" y2="43.18" width="1.27" layer="16"/>
<wire x1="83.82" y1="48.26" x2="83.82" y2="44.45" width="1.27" layer="16"/>
<wire x1="83.82" y1="44.45" x2="83.82" y2="36.195" width="1.27" layer="16"/>
<wire x1="83.82" y1="36.195" x2="86.36" y2="33.655" width="1.27" layer="16"/>
<wire x1="86.36" y1="33.655" x2="86.36" y2="29.845" width="1.27" layer="16"/>
<wire x1="52.07" y1="31.75" x2="71.12" y2="31.75" width="1.27" layer="16"/>
<wire x1="71.12" y1="31.75" x2="76.2" y2="36.83" width="1.27" layer="16"/>
<wire x1="76.2" y1="36.83" x2="76.2" y2="43.18" width="1.27" layer="16"/>
<wire x1="86.995" y1="52.07" x2="90.17" y2="52.07" width="1.27" layer="16"/>
<wire x1="83.82" y1="48.26" x2="86.995" y2="48.26" width="1.27" layer="16"/>
<wire x1="86.995" y1="48.26" x2="86.995" y2="52.07" width="1.27" layer="16"/>
<wire x1="90.17" y1="44.45" x2="83.82" y2="44.45" width="1.27" layer="16"/>
<via x="46.99" y="52.705" extent="1-16" drill="0.6" diameter="1.6764"/>
<via x="77.47" y="52.705" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="46.99" y1="45.72" x2="46.99" y2="52.705" width="1.27" layer="16"/>
<wire x1="46.99" y1="52.705" x2="77.47" y2="52.705" width="1.27" layer="1"/>
<contactref element="IC2" pad="2"/>
<wire x1="83.82" y1="66.04" x2="88.265" y2="66.04" width="1.27" layer="16"/>
<wire x1="88.265" y1="66.04" x2="90.17" y2="64.135" width="1.27" layer="16"/>
<wire x1="90.17" y1="64.135" x2="90.17" y2="57.15" width="1.27" layer="16"/>
<wire x1="90.17" y1="57.15" x2="90.17" y2="52.07" width="1.27" layer="16"/>
<wire x1="94.615" y1="8.89" x2="94.615" y2="26.035" width="1.27" layer="16"/>
<wire x1="94.615" y1="26.035" x2="90.17" y2="27.94" width="1.27" layer="16"/>
<wire x1="88.9" y1="57.15" x2="90.17" y2="57.15" width="1.27" layer="16"/>
<wire x1="86.36" y1="29.845" x2="88.265" y2="27.94" width="1.27" layer="16"/>
<wire x1="88.265" y1="27.94" x2="90.17" y2="27.94" width="1.27" layer="16"/>
</signal>
<signal name="N$31">
<contactref element="R13" pad="1"/>
<contactref element="R16" pad="1"/>
<contactref element="S1" pad="2"/>
<wire x1="33.3375" y1="18.7325" x2="38.1" y2="13.97" width="1.27" layer="16"/>
<wire x1="49.53" y1="13.97" x2="43.18" y2="13.97" width="1.6764" layer="16"/>
<wire x1="38.1" y1="13.97" x2="43.18" y2="13.97" width="1.6764" layer="16"/>
</signal>
<signal name="N$33">
<contactref element="R14" pad="1"/>
<contactref element="R17" pad="1"/>
<contactref element="S2" pad="2"/>
<wire x1="61.2775" y1="22.5425" x2="63.8175" y2="22.5425" width="1.27" layer="16"/>
<wire x1="63.8175" y1="22.5425" x2="67.31" y2="19.05" width="1.27" layer="16"/>
<wire x1="67.31" y1="19.05" x2="67.31" y2="13.97" width="1.27" layer="16"/>
<wire x1="73.66" y1="13.97" x2="67.31" y2="13.97" width="1.6764" layer="16"/>
<wire x1="62.23" y1="13.97" x2="67.31" y2="13.97" width="1.6764" layer="16"/>
</signal>
<signal name="N$34">
<contactref element="R18" pad="1"/>
<contactref element="S3" pad="2"/>
<contactref element="R15" pad="1"/>
<wire x1="91.44" y1="13.97" x2="80.01" y2="13.97" width="1.778" layer="16"/>
<wire x1="31.4325" y1="21.9075" x2="41.275" y2="21.9075" width="1.27" layer="16"/>
<wire x1="41.275" y1="21.9075" x2="46.355" y2="16.8275" width="1.27" layer="16"/>
<wire x1="46.355" y1="16.8275" x2="51.435" y2="16.8275" width="1.27" layer="16"/>
<wire x1="51.435" y1="16.8275" x2="53.6575" y2="14.605" width="1.27" layer="16"/>
<wire x1="53.6575" y1="14.605" x2="57.15" y2="14.605" width="1.27" layer="16"/>
<wire x1="57.15" y1="14.605" x2="58.7375" y2="16.1925" width="1.27" layer="16"/>
<wire x1="58.7375" y1="16.1925" x2="58.7375" y2="24.4475" width="1.27" layer="16"/>
<wire x1="58.7375" y1="24.4475" x2="60.325" y2="26.035" width="1.27" layer="16"/>
<wire x1="60.325" y1="26.035" x2="76.835" y2="26.035" width="1.27" layer="16"/>
<wire x1="76.835" y1="26.035" x2="80.01" y2="22.86" width="1.27" layer="16"/>
<wire x1="80.01" y1="22.86" x2="80.01" y2="13.97" width="1.27" layer="16"/>
</signal>
<signal name="N$35">
<contactref element="IC3" pad="17"/>
<contactref element="IC1" pad="2"/>
<contactref element="R19" pad="1"/>
<wire x1="49.53" y1="31.75" x2="49.53" y2="34.29" width="1.27" layer="16"/>
<wire x1="49.53" y1="34.29" x2="50.8" y2="35.56" width="1.27" layer="16"/>
<wire x1="50.8" y1="35.56" x2="54.61" y2="35.56" width="1.27" layer="16"/>
<wire x1="54.61" y1="35.56" x2="55.88" y2="35.56" width="1.27" layer="16"/>
<wire x1="54.61" y1="39.37" x2="54.61" y2="35.56" width="1.27" layer="16"/>
</signal>
<signal name="N$36">
<contactref element="C5" pad="2"/>
<contactref element="Q1" pad="2"/>
<contactref element="IC3" pad="15"/>
<wire x1="66.04" y1="48.133" x2="70.993" y2="48.133" width="1.27" layer="16"/>
<wire x1="70.993" y1="48.133" x2="71.12" y2="48.26" width="1.27" layer="16"/>
<wire x1="66.04" y1="48.133" x2="65.913" y2="48.133" width="1.016" layer="16"/>
<wire x1="65.913" y1="48.133" x2="62.23" y2="44.45" width="1.016" layer="16"/>
<wire x1="62.23" y1="44.45" x2="53.0225" y2="44.45" width="1.016" layer="16"/>
<wire x1="53.0225" y1="44.45" x2="49.53" y2="40.64" width="1.016" layer="16"/>
<wire x1="49.53" y1="40.64" x2="49.53" y2="39.37" width="1.016" layer="16"/>
</signal>
<signal name="N$37">
<contactref element="C6" pad="2"/>
<contactref element="Q1" pad="1"/>
<contactref element="IC3" pad="16"/>
<wire x1="66.04" y1="43.307" x2="70.993" y2="43.307" width="1.27" layer="16"/>
<wire x1="70.993" y1="43.307" x2="71.12" y2="43.18" width="1.27" layer="16"/>
<wire x1="52.07" y1="39.37" x2="52.07" y2="40.64" width="1.016" layer="16"/>
<wire x1="52.07" y1="40.64" x2="53.34" y2="41.91" width="1.016" layer="16"/>
<wire x1="53.34" y1="41.91" x2="64.643" y2="41.91" width="1.016" layer="16"/>
<wire x1="64.643" y1="41.91" x2="66.04" y2="43.307" width="1.016" layer="16"/>
</signal>
<signal name="N$42">
<contactref element="IC3" pad="4"/>
<contactref element="R21" pad="2"/>
<wire x1="49.53" y1="46.99" x2="49.53" y2="43.815" width="0.8128" layer="16"/>
<wire x1="49.53" y1="43.815" x2="48.895" y2="43.18" width="0.8128" layer="16"/>
<wire x1="48.895" y1="43.18" x2="40.64" y2="43.18" width="0.8128" layer="16"/>
<wire x1="40.64" y1="43.18" x2="39.6875" y2="42.2275" width="0.8128" layer="16"/>
<wire x1="39.6875" y1="42.2275" x2="35.2425" y2="42.2275" width="0.8128" layer="16"/>
<wire x1="35.2425" y1="42.2275" x2="32.7025" y2="39.6875" width="0.8128" layer="16"/>
<wire x1="32.7025" y1="39.6875" x2="32.7025" y2="35.8775" width="0.8128" layer="16"/>
</signal>
<signal name="N$43">
<contactref element="R20" pad="1"/>
<contactref element="R21" pad="1"/>
<contactref element="S4" pad="2"/>
<wire x1="19.05" y1="13.97" x2="25.4" y2="13.97" width="1.778" layer="16"/>
<wire x1="25.4" y1="13.97" x2="25.7175" y2="13.97" width="1.27" layer="16"/>
<wire x1="25.7175" y1="13.97" x2="26.67" y2="14.9225" width="1.27" layer="16"/>
<wire x1="26.67" y1="14.9225" x2="26.67" y2="23.495" width="1.27" layer="16"/>
<wire x1="26.67" y1="23.495" x2="29.21" y2="25.7175" width="1.27" layer="16"/>
<wire x1="29.21" y1="25.7175" x2="32.7025" y2="25.7175" width="1.27" layer="16"/>
<wire x1="19.05" y1="13.97" x2="13.97" y2="13.97" width="1.6764" layer="16"/>
</signal>
<signal name="N$38">
<via x="102.87" y="5.08" extent="1-16" drill="0.6" diameter="6.4516"/>
</signal>
<signal name="N$39">
<via x="5.08" y="5.08" extent="1-16" drill="0.6" diameter="6.4516"/>
</signal>
<signal name="N$41">
<via x="80.01" y="30.48" extent="1-16" drill="0.6" diameter="6.4516"/>
</signal>
<signal name="N$44">
<via x="102.87" y="93.98" extent="1-16" drill="0.6" diameter="6.4516"/>
</signal>
<signal name="N$45">
<via x="5.08" y="93.98" extent="1-16" drill="0.6" diameter="6.4516"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
