/* LICENSE - Dutchtronix License Terms
/*  Copyright  2010 Johannes P.M. de Rie
**  The text of this license was derived from the University of
**  Washington's Free-Fork License, as used on the University of
**  Washington IMAP toolkit (Copyright 2001 University of Washington).
Dutchtronix Free-Fork License
The Dutchtronix Oscilloscope Clock and Derivaties Software Project
This Dutchtronix Distribution (code and documentation) is made available to
the open source community as a public service by Jan P.M. de Rie
Contact Jan P.M. de Rie at jdr@dutchtronix.com for information on
other licensing arrangements (e.g. for use in proprietary applications).
Under this license, this Distribution may be modified and the original
version and modified versions may be copied, distributed, publicly
displayed and performed provided that the following conditions are
met:
(1) modified versions are distributed with source code and
documentation and with permission for others to use any code and
documentation (whether in original or modified versions) as granted
under this license;
(2) if modified, the source code, documentation, and user run-time
elements should be clearly labeled by placing an identifier of origin
(such as a name, initial, or other tag) after the version number;
(3) users, modifiers, distributors, and others coming into possession
or using the Distribution in original or modified form accept the
entire risk as to the possession, use, and performance of the
Distribution;
(4) this copyright management information (software identifier and
version number, copyright notice and license) shall be retained in all
versions of the Distribution;
(5)Johannes P.M. de Rie may make modifications to the Distribution
that are substantially similar to modified versions of the
Distribution, and may make, use, sell, copy, distribute, publicly
display, and perform such modifications, including making such
modifications available under this or other licenses, without
obligation or restriction;
(6) modifications incorporating code, libraries, and/or documentation
subject to any other open source license may be made, and the
resulting work may be distributed under the terms of such open source
license if required by that open source license, but doing so will not
affect this Distribution, other modifications made under this license
or modifications made under other Jan P.M. de Rie licensing
arrangements;
(7) no permission is granted to distribute, publicly display, or
publicly perform modifications to the Distribution made using
proprietary materials that cannot be released in source format under
conditions of this license;
(8) the name of Johannes P.M. de Rie may not be used in advertising
or publicity pertaining to Distribution of the software without
specific, prior written permission.
This software is made available "AS IS", and
JOHANNES P.M. DE RIE DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED,
WITH REGARD TO THIS SOFTWARE, INCLUDING WITHOUT LIMITATION ALL IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE,
AND IN NO EVENT SHALL JOHANNES P.M. DE RIE BE LIABLE FOR ANY
SPECIAL, INDIRECT OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES WHATSOEVER
RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN ACTION OF
CONTRACT, TORT (INCLUDING NEGLIGENCE) OR STRICT LIABILITY, ARISING OUT
OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
