; Source created with Parsic Version 3.x
; at              : 2008.03.28. 23:01:12
; Project File    : C:\PROGRA~1\PARSIC\COMP_76.PIC
; Project Version : 1.0.3
; Created         : 2008.03.28. 22:52:00
; Last change     : 2008.03.28. 23:01:11
	PROCESSOR 16F876
	INCLUDE P16F876.INC
	RADIX DEC
	__IDLOCS H'0100'
	__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _BODEN_ON & _XT_OSC & _LVP_OFF & _CPD_OFF & _DEBUG_OFF
; Diverses
ZERO	EQU Z	; ZERO-Flag
CARRY	 EQU C	; CARRY-Flag
; Variable
ADC0	= 32	; located in Bank 0
ADC0_HI	= 33	; located in Bank 0
S0	= 34	; located in Bank 0
RAM	= 35	; located in Bank 0
SYS_TMP1	= 114	; located in Bank 0, 1, 2, 3
SYS_FSAV	= 115	; located in Bank 0, 1, 2, 3
	ERRORLEVEL -302	; disable warning (Bankswitching)
	ERRORLEVEL -306	; disable warning (Pageswitching)
;Programmanfang
	ORG 0
	CLRF STATUS	; switch to RAM-Bank 0
	MOVLW HIGH SYS_INIT	; set page
	MOVWF PCLATH
	GOTO SYS_INIT
	RETURN
; Subroutines
; Read  -> AN0
READ_AN0
	MOVLW B'100'
	BSF STATUS,RP0	; Bank 1
	BCF STATUS,RP1	; Bank 1
	MOVWF ADCON1
	BSF TRISA,0
	BSF ADCON1,ADFM	; Right-Justified
	MOVLW B'11000001'	; CH0
	BCF STATUS,RP0	; Bank 0
	MOVWF ADCON0
	MOVLW 5
	MOVWF SYS_TMP1
SYS_ADC_LABEL_0
	DECFSZ SYS_TMP1,F
	GOTO SYS_ADC_LABEL_0
	BSF ADCON0,GO	; Start convert
SYS_ADC_LABEL_1
	BTFSC ADCON0,GO	; ready ?
	GOTO SYS_ADC_LABEL_1	; no
	MOVFW ADRESL
	MOVWF ADC0
	MOVFW ADRESH
	MOVWF ADC0_HI
	MOVLW 6
	MOVWF ADCON1
	MOVLW B'11111111'
	MOVWF TRISA
	RETURN
;Initialisierung
SYS_INIT
	MOVLW B'00000000'
	MOVWF INTCON
; Set output before direction
	BCF STATUS,RP1	; Bank 0
	MOVLW B'00000000'
	MOVWF PORTA
	MOVLW B'00000000'
	MOVWF PORTB
	MOVLW B'00000000'
	MOVWF PORTC
	MOVLW 143
	MOVWF OPTION_REG
	MOVLW 6	; all Digital
	MOVWF ADCON1
; Richtung setzen
	MOVLW B'11111111'
	MOVWF TRISA
	MOVLW B'11111111'
	MOVWF TRISB
	MOVLW B'11111111'
	MOVWF TRISC
; init vars
; Clear RAM
	BCF STATUS,IRP
	MOVLW 32
	MOVWF FSR
CR1
	CLRF INDF
	INCF FSR,F
	BTFSS FSR,7
	GOTO CR1
	BSF FSR,5
CR2
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR2
	BSF STATUS,IRP
	MOVLW 16
	MOVWF FSR
CR3
	CLRF INDF
	INCF FSR,F
	MOVLW H'70'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR3
	MOVLW 144
	MOVWF FSR
CR4
	CLRF INDF
	INCF FSR,F
	MOVLW H'F0'
	SUBWF FSR,W
	BTFSS STATUS,ZERO
	GOTO CR4
;******* Haupt-Programm ***********
MAIN
	CALL READ_AN0
; Vergleich -> IF1
	MOVLW HIGH 770
	SUBWF ADC0_HI,W	; F - W -> W
	BTFSS STATUS,ZERO	; Wenn ZERO gesetzt LOW-Byte testen
	GOTO LABEL_IF1_CHECK
	MOVLW LOW 770
	SUBWF ADC0,W	; F - W -> W
LABEL_IF1_CHECK
	BTFSS STATUS,CARRY	; Test auf -> >=
	GOTO LABEL_IF1_FALSE
LABEL_IF1_TRUE
	BSF S0,0
	GOTO LABEL_IF1_EXIT
LABEL_IF1_FALSE
	BCF S0,0
LABEL_IF1_EXIT
; Vergleich -> IF2
	MOVLW HIGH 772
	GOTO LABEL_IF2_CHECK
	MOVLW LOW 772
LABEL_IF2_CHECK
	GOTO LABEL_IF2_FALSE
	BTFSC STATUS,ZERO
LABEL_IF2_TRUE
	BSF S0,1
	GOTO LABEL_IF2_EXIT
LABEL_IF2_FALSE
	BCF S0,1
LABEL_IF2_EXIT
; EXKLUSIVODER - Gatter -> LG1
	CLRF SYS_TMP1
	BTFSS S0,0
	GOTO LABEL_LG1_1
	INCF SYS_TMP1,F
LABEL_LG1_1
	BTFSS S0,1
	GOTO LABEL_LG1_2
	INCF SYS_TMP1,F
LABEL_LG1_2
	DECF SYS_TMP1,F
	BTFSC STATUS,ZERO
	BSF S0,2
	BTFSS STATUS,ZERO
	BCF S0,2
	GOTO MAIN
	END
