<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.1">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="mil" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<description>Developed by element14 :&lt;br&gt;
element14 CAD Library consolidation.ulp
at 30/07/2012 16:53:57</description>
<packages>
<package name="SOT95P290X110-3N">
<smd name="1" x="-1.4478" y="0.9398" dx="0.9652" dy="0.5588" layer="1"/>
<smd name="2" x="-1.4478" y="-0.9398" dx="0.9652" dy="0.5588" layer="1"/>
<smd name="3" x="1.4478" y="0" dx="0.9652" dy="0.5588" layer="1"/>
<wire x1="0.9652" y1="0.6096" x2="0.9652" y2="1.4986" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-1.4986" x2="0.9652" y2="-1.4986" width="0.1524" layer="21"/>
<wire x1="0.9652" y1="-1.4986" x2="0.9652" y2="-0.6096" width="0.1524" layer="21"/>
<wire x1="0.9652" y1="1.4986" x2="0.3048" y2="1.4986" width="0.1524" layer="21"/>
<wire x1="0.3048" y1="1.4986" x2="-0.3048" y2="1.4986" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="1.4986" x2="-0.762" y2="1.4986" width="0.1524" layer="21"/>
<wire x1="-0.9652" y1="0.3302" x2="-0.9652" y2="-0.3302" width="0.1524" layer="21"/>
<wire x1="0.3048" y1="1.4986" x2="-0.3048" y2="1.4986" width="0.1524" layer="21" curve="-180"/>
<text x="-2.286" y="1.3716" size="1.27" layer="21" ratio="6" rot="SR0">*</text>
<wire x1="-0.9652" y1="-1.4986" x2="0.9652" y2="-1.4986" width="0" layer="51"/>
<wire x1="0.9652" y1="-1.4986" x2="0.9652" y2="-0.254" width="0" layer="51"/>
<wire x1="0.9652" y1="-0.254" x2="0.9652" y2="0.254" width="0" layer="51"/>
<wire x1="0.9652" y1="0.254" x2="0.9652" y2="1.4986" width="0" layer="51"/>
<wire x1="0.9652" y1="1.4986" x2="0.3048" y2="1.4986" width="0" layer="51"/>
<wire x1="0.3048" y1="1.4986" x2="-0.3048" y2="1.4986" width="0" layer="51"/>
<wire x1="-0.3048" y1="1.4986" x2="-0.9652" y2="1.4986" width="0" layer="51"/>
<wire x1="-0.9652" y1="1.4986" x2="-0.9652" y2="1.1938" width="0" layer="51"/>
<wire x1="-0.9652" y1="1.1938" x2="-0.9652" y2="0.7112" width="0" layer="51"/>
<wire x1="-0.9652" y1="0.7112" x2="-0.9652" y2="-0.7112" width="0" layer="51"/>
<wire x1="-0.9652" y1="1.1938" x2="-1.4986" y2="1.1938" width="0" layer="51"/>
<wire x1="-1.4986" y1="1.1938" x2="-1.4986" y2="0.7112" width="0" layer="51"/>
<wire x1="-1.4986" y1="0.7112" x2="-0.9652" y2="0.7112" width="0" layer="51"/>
<wire x1="-0.9652" y1="-1.4986" x2="-0.9652" y2="-1.1938" width="0" layer="51"/>
<wire x1="-0.9652" y1="-1.1938" x2="-0.9652" y2="-0.7112" width="0" layer="51"/>
<wire x1="-0.9652" y1="-0.7112" x2="-1.4986" y2="-0.7112" width="0" layer="51"/>
<wire x1="-1.4986" y1="-0.7112" x2="-1.4986" y2="-1.1938" width="0" layer="51"/>
<wire x1="-1.4986" y1="-1.1938" x2="-0.9652" y2="-1.1938" width="0" layer="51"/>
<wire x1="0.9652" y1="-0.254" x2="1.4986" y2="-0.254" width="0" layer="51"/>
<wire x1="1.4986" y1="-0.254" x2="1.4986" y2="0.254" width="0" layer="51"/>
<wire x1="1.4986" y1="0.254" x2="0.9652" y2="0.254" width="0" layer="51"/>
<wire x1="0.3048" y1="1.4986" x2="-0.3048" y2="1.4986" width="0" layer="51" curve="-180"/>
<text x="-2.286" y="1.3716" size="1.27" layer="51" ratio="6" rot="SR0">*</text>
<text x="-3.4544" y="2.54" size="2.0828" layer="25" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-3.4544" y="-4.445" size="2.0828" layer="27" ratio="10" rot="SR0">&gt;VALUE</text>
</package>
<package name="SOT95P290X100-3N">
</package>
<package name="DFN300X300X75-11N">
<smd name="1" x="-1.4478" y="0.9906" dx="0.7112" dy="0.254" layer="1"/>
<smd name="2" x="-1.4478" y="0.508" dx="0.7112" dy="0.254" layer="1"/>
<smd name="3" x="-1.4478" y="0" dx="0.7112" dy="0.254" layer="1"/>
<smd name="4" x="-1.4478" y="-0.508" dx="0.7112" dy="0.254" layer="1"/>
<smd name="5" x="-1.4478" y="-0.9906" dx="0.7112" dy="0.254" layer="1"/>
<smd name="6" x="1.4478" y="-0.9906" dx="0.7112" dy="0.254" layer="1"/>
<smd name="7" x="1.4478" y="-0.508" dx="0.7112" dy="0.254" layer="1"/>
<smd name="8" x="1.4478" y="0" dx="0.7112" dy="0.254" layer="1"/>
<smd name="9" x="1.4478" y="0.508" dx="0.7112" dy="0.254" layer="1"/>
<smd name="10" x="1.4478" y="0.9906" dx="0.7112" dy="0.254" layer="1"/>
<smd name="11" x="0" y="0" dx="1.651" dy="2.3876" layer="1"/>
<wire x1="0.9398" y1="-1.4986" x2="1.4986" y2="-1.4986" width="0.1524" layer="21"/>
<wire x1="-1.4986" y1="-1.4986" x2="-0.9398" y2="-1.4986" width="0.1524" layer="21"/>
<wire x1="1.4986" y1="1.4986" x2="0.9398" y2="1.4986" width="0.1524" layer="21"/>
<wire x1="-0.9398" y1="1.4986" x2="-1.4986" y2="1.4986" width="0.1524" layer="21"/>
<wire x1="-1.4986" y1="-1.4986" x2="1.4986" y2="-1.4986" width="0" layer="51"/>
<wire x1="1.4986" y1="-1.4986" x2="1.4986" y2="1.4986" width="0" layer="51"/>
<wire x1="1.4986" y1="1.4986" x2="0.3048" y2="1.4986" width="0" layer="51"/>
<wire x1="-0.3048" y1="1.4986" x2="-1.4986" y2="1.4986" width="0" layer="51"/>
<wire x1="-1.4986" y1="1.4986" x2="-1.4986" y2="-1.4986" width="0" layer="51"/>
<text x="-3.4544" y="1.905" size="2.0828" layer="25" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-3.4544" y="-3.81" size="2.0828" layer="27" ratio="10" rot="SR0">&gt;VALUE</text>
</package>
<package name="DIP254P762X533-16">
<pad name="1" x="-7.62" y="17.78" drill="1.1176" shape="square"/>
<pad name="2" x="-7.62" y="15.24" drill="1.1176"/>
<pad name="3" x="-7.62" y="12.7" drill="1.1176"/>
<pad name="4" x="-7.62" y="10.16" drill="1.1176"/>
<pad name="5" x="-7.62" y="7.62" drill="1.1176"/>
<pad name="6" x="-7.62" y="5.08" drill="1.1176"/>
<pad name="7" x="-7.62" y="2.54" drill="1.1176"/>
<pad name="8" x="-7.62" y="0" drill="1.1176"/>
<pad name="9" x="0" y="0" drill="1.1176"/>
<pad name="10" x="0" y="2.54" drill="1.1176"/>
<pad name="11" x="0" y="5.08" drill="1.1176"/>
<pad name="12" x="0" y="7.62" drill="1.1176"/>
<pad name="13" x="0" y="10.16" drill="1.1176"/>
<pad name="14" x="0" y="12.7" drill="1.1176"/>
<pad name="15" x="0" y="15.24" drill="1.1176"/>
<pad name="16" x="0" y="17.78" drill="1.1176"/>
<wire x1="-6.5532" y1="-0.762" x2="-1.0668" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-1.0668" y1="18.542" x2="-3.5052" y2="18.542" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="18.542" x2="-4.1148" y2="18.542" width="0.1524" layer="21"/>
<wire x1="-4.1148" y1="18.542" x2="-6.2992" y2="18.542" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="18.542" x2="-4.1148" y2="18.542" width="0.1524" layer="21" curve="-180"/>
<text x="-8.2042" y="18.8976" size="1.27" layer="21" ratio="6" rot="SR0">*</text>
<wire x1="-7.366" y1="17.2212" x2="-7.366" y2="18.3388" width="0" layer="51"/>
<wire x1="-7.366" y1="18.3388" x2="-8.1788" y2="18.3388" width="0" layer="51"/>
<wire x1="-8.1788" y1="18.3388" x2="-8.1788" y2="17.2212" width="0" layer="51"/>
<wire x1="-8.1788" y1="17.2212" x2="-7.366" y2="17.2212" width="0" layer="51"/>
<wire x1="-7.366" y1="14.6812" x2="-7.366" y2="15.7988" width="0" layer="51"/>
<wire x1="-7.366" y1="15.7988" x2="-8.1788" y2="15.7988" width="0" layer="51"/>
<wire x1="-8.1788" y1="15.7988" x2="-8.1788" y2="14.6812" width="0" layer="51"/>
<wire x1="-8.1788" y1="14.6812" x2="-7.366" y2="14.6812" width="0" layer="51"/>
<wire x1="-7.366" y1="12.1412" x2="-7.366" y2="13.2588" width="0" layer="51"/>
<wire x1="-7.366" y1="13.2588" x2="-8.1788" y2="13.2588" width="0" layer="51"/>
<wire x1="-8.1788" y1="13.2588" x2="-8.1788" y2="12.1412" width="0" layer="51"/>
<wire x1="-8.1788" y1="12.1412" x2="-7.366" y2="12.1412" width="0" layer="51"/>
<wire x1="-7.366" y1="9.6012" x2="-7.366" y2="10.7188" width="0" layer="51"/>
<wire x1="-7.366" y1="10.7188" x2="-8.1788" y2="10.7188" width="0" layer="51"/>
<wire x1="-8.1788" y1="10.7188" x2="-8.1788" y2="9.6012" width="0" layer="51"/>
<wire x1="-8.1788" y1="9.6012" x2="-7.366" y2="9.6012" width="0" layer="51"/>
<wire x1="-7.366" y1="7.0612" x2="-7.366" y2="8.1788" width="0" layer="51"/>
<wire x1="-7.366" y1="8.1788" x2="-8.1788" y2="8.1788" width="0" layer="51"/>
<wire x1="-8.1788" y1="8.1788" x2="-8.1788" y2="7.0612" width="0" layer="51"/>
<wire x1="-8.1788" y1="7.0612" x2="-7.366" y2="7.0612" width="0" layer="51"/>
<wire x1="-7.366" y1="4.5212" x2="-7.366" y2="5.6388" width="0" layer="51"/>
<wire x1="-7.366" y1="5.6388" x2="-8.1788" y2="5.6388" width="0" layer="51"/>
<wire x1="-8.1788" y1="5.6388" x2="-8.1788" y2="4.5212" width="0" layer="51"/>
<wire x1="-8.1788" y1="4.5212" x2="-7.366" y2="4.5212" width="0" layer="51"/>
<wire x1="-7.366" y1="1.9812" x2="-7.366" y2="3.0988" width="0" layer="51"/>
<wire x1="-7.366" y1="3.0988" x2="-8.1788" y2="3.0988" width="0" layer="51"/>
<wire x1="-8.1788" y1="3.0988" x2="-8.1788" y2="1.9812" width="0" layer="51"/>
<wire x1="-8.1788" y1="1.9812" x2="-7.366" y2="1.9812" width="0" layer="51"/>
<wire x1="-7.366" y1="-0.5588" x2="-7.366" y2="0.5588" width="0" layer="51"/>
<wire x1="-7.366" y1="0.5588" x2="-8.1788" y2="0.5588" width="0" layer="51"/>
<wire x1="-8.1788" y1="0.5588" x2="-8.1788" y2="-0.5588" width="0" layer="51"/>
<wire x1="-8.1788" y1="-0.5588" x2="-7.366" y2="-0.5588" width="0" layer="51"/>
<wire x1="-0.254" y1="0.5588" x2="-0.254" y2="-0.5588" width="0" layer="51"/>
<wire x1="-0.254" y1="-0.5588" x2="0.5588" y2="-0.5588" width="0" layer="51"/>
<wire x1="0.5588" y1="-0.5588" x2="0.5588" y2="0.5588" width="0" layer="51"/>
<wire x1="0.5588" y1="0.5588" x2="-0.254" y2="0.5588" width="0" layer="51"/>
<wire x1="-0.254" y1="3.0988" x2="-0.254" y2="1.9812" width="0" layer="51"/>
<wire x1="-0.254" y1="1.9812" x2="0.5588" y2="1.9812" width="0" layer="51"/>
<wire x1="0.5588" y1="1.9812" x2="0.5588" y2="3.0988" width="0" layer="51"/>
<wire x1="0.5588" y1="3.0988" x2="-0.254" y2="3.0988" width="0" layer="51"/>
<wire x1="-0.254" y1="5.6388" x2="-0.254" y2="4.5212" width="0" layer="51"/>
<wire x1="-0.254" y1="4.5212" x2="0.5588" y2="4.5212" width="0" layer="51"/>
<wire x1="0.5588" y1="4.5212" x2="0.5588" y2="5.6388" width="0" layer="51"/>
<wire x1="0.5588" y1="5.6388" x2="-0.254" y2="5.6388" width="0" layer="51"/>
<wire x1="-0.254" y1="8.1788" x2="-0.254" y2="7.0612" width="0" layer="51"/>
<wire x1="-0.254" y1="7.0612" x2="0.5588" y2="7.0612" width="0" layer="51"/>
<wire x1="0.5588" y1="7.0612" x2="0.5588" y2="8.1788" width="0" layer="51"/>
<wire x1="0.5588" y1="8.1788" x2="-0.254" y2="8.1788" width="0" layer="51"/>
<wire x1="-0.254" y1="10.7188" x2="-0.254" y2="9.6012" width="0" layer="51"/>
<wire x1="-0.254" y1="9.6012" x2="0.5588" y2="9.6012" width="0" layer="51"/>
<wire x1="0.5588" y1="9.6012" x2="0.5588" y2="10.7188" width="0" layer="51"/>
<wire x1="0.5588" y1="10.7188" x2="-0.254" y2="10.7188" width="0" layer="51"/>
<wire x1="-0.254" y1="13.2588" x2="-0.254" y2="12.1412" width="0" layer="51"/>
<wire x1="-0.254" y1="12.1412" x2="0.5588" y2="12.1412" width="0" layer="51"/>
<wire x1="0.5588" y1="12.1412" x2="0.5588" y2="13.2588" width="0" layer="51"/>
<wire x1="0.5588" y1="13.2588" x2="-0.254" y2="13.2588" width="0" layer="51"/>
<wire x1="-0.254" y1="15.7988" x2="-0.254" y2="14.6812" width="0" layer="51"/>
<wire x1="-0.254" y1="14.6812" x2="0.5588" y2="14.6812" width="0" layer="51"/>
<wire x1="0.5588" y1="14.6812" x2="0.5588" y2="15.7988" width="0" layer="51"/>
<wire x1="0.5588" y1="15.7988" x2="-0.254" y2="15.7988" width="0" layer="51"/>
<wire x1="-0.254" y1="18.3388" x2="-0.254" y2="17.2212" width="0" layer="51"/>
<wire x1="-0.254" y1="17.2212" x2="0.5588" y2="17.2212" width="0" layer="51"/>
<wire x1="0.5588" y1="17.2212" x2="0.5588" y2="18.3388" width="0" layer="51"/>
<wire x1="0.5588" y1="18.3388" x2="-0.254" y2="18.3388" width="0" layer="51"/>
<wire x1="-7.366" y1="-0.762" x2="-0.254" y2="-0.762" width="0" layer="51"/>
<wire x1="-0.254" y1="-0.762" x2="-0.254" y2="18.542" width="0" layer="51"/>
<wire x1="-0.254" y1="18.542" x2="-3.5052" y2="18.542" width="0" layer="51"/>
<wire x1="-3.5052" y1="18.542" x2="-4.1148" y2="18.542" width="0" layer="51"/>
<wire x1="-4.1148" y1="18.542" x2="-7.366" y2="18.542" width="0" layer="51"/>
<wire x1="-7.366" y1="18.542" x2="-7.366" y2="-0.762" width="0" layer="51"/>
<wire x1="-3.5052" y1="18.542" x2="-4.1148" y2="18.542" width="0" layer="51" curve="-180"/>
<text x="-8.2042" y="18.8976" size="1.27" layer="51" ratio="6" rot="SR0">*</text>
<text x="-8.3058" y="20.955" size="2.0828" layer="25" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-7.2644" y="-5.08" size="2.0828" layer="27" ratio="10" rot="SR0">&gt;VALUE</text>
</package>
<package name="SOIC127P1030X265-24N">
<smd name="1" x="-4.6736" y="6.985" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="2" x="-4.6736" y="5.715" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="3" x="-4.6736" y="4.445" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="4" x="-4.6736" y="3.175" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="5" x="-4.6736" y="1.905" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="6" x="-4.6736" y="0.635" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="7" x="-4.6736" y="-0.635" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="8" x="-4.6736" y="-1.905" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="9" x="-4.6736" y="-3.175" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="10" x="-4.6736" y="-4.445" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="11" x="-4.6736" y="-5.715" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="12" x="-4.6736" y="-6.985" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="13" x="4.6736" y="-6.985" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="14" x="4.6736" y="-5.715" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="15" x="4.6736" y="-4.445" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="16" x="4.6736" y="-3.175" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="17" x="4.6736" y="-1.905" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="18" x="4.6736" y="-0.635" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="19" x="4.6736" y="0.635" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="20" x="4.6736" y="1.905" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="21" x="4.6736" y="3.175" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="22" x="4.6736" y="4.445" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="23" x="4.6736" y="5.715" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="24" x="4.6736" y="6.985" dx="1.9812" dy="0.5588" layer="1"/>
<wire x1="-3.7592" y1="-7.6962" x2="3.7592" y2="-7.6962" width="0.1524" layer="21"/>
<wire x1="3.7592" y1="7.6962" x2="0.3048" y2="7.6962" width="0.1524" layer="21"/>
<wire x1="0.3048" y1="7.6962" x2="-0.3048" y2="7.6962" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="7.6962" x2="-3.7592" y2="7.6962" width="0.1524" layer="21"/>
<wire x1="0.3048" y1="7.6962" x2="-0.3048" y2="7.6962" width="0.1524" layer="21" curve="-180"/>
<text x="-5.5118" y="7.4168" size="1.27" layer="21" ratio="6" rot="SR0">*</text>
<wire x1="-3.7592" y1="6.731" x2="-3.7592" y2="7.239" width="0" layer="51"/>
<wire x1="-3.7592" y1="7.239" x2="-5.3086" y2="7.239" width="0" layer="51"/>
<wire x1="-5.3086" y1="7.239" x2="-5.3086" y2="6.731" width="0" layer="51"/>
<wire x1="-5.3086" y1="6.731" x2="-3.7592" y2="6.731" width="0" layer="51"/>
<wire x1="-3.7592" y1="5.461" x2="-3.7592" y2="5.969" width="0" layer="51"/>
<wire x1="-3.7592" y1="5.969" x2="-5.3086" y2="5.969" width="0" layer="51"/>
<wire x1="-5.3086" y1="5.969" x2="-5.3086" y2="5.461" width="0" layer="51"/>
<wire x1="-5.3086" y1="5.461" x2="-3.7592" y2="5.461" width="0" layer="51"/>
<wire x1="-3.7592" y1="4.191" x2="-3.7592" y2="4.699" width="0" layer="51"/>
<wire x1="-3.7592" y1="4.699" x2="-5.3086" y2="4.699" width="0" layer="51"/>
<wire x1="-5.3086" y1="4.699" x2="-5.3086" y2="4.191" width="0" layer="51"/>
<wire x1="-5.3086" y1="4.191" x2="-3.7592" y2="4.191" width="0" layer="51"/>
<wire x1="-3.7592" y1="2.921" x2="-3.7592" y2="3.429" width="0" layer="51"/>
<wire x1="-3.7592" y1="3.429" x2="-5.3086" y2="3.429" width="0" layer="51"/>
<wire x1="-5.3086" y1="3.429" x2="-5.3086" y2="2.921" width="0" layer="51"/>
<wire x1="-5.3086" y1="2.921" x2="-3.7592" y2="2.921" width="0" layer="51"/>
<wire x1="-3.7592" y1="1.651" x2="-3.7592" y2="2.159" width="0" layer="51"/>
<wire x1="-3.7592" y1="2.159" x2="-5.3086" y2="2.159" width="0" layer="51"/>
<wire x1="-5.3086" y1="2.159" x2="-5.3086" y2="1.651" width="0" layer="51"/>
<wire x1="-5.3086" y1="1.651" x2="-3.7592" y2="1.651" width="0" layer="51"/>
<wire x1="-3.7592" y1="0.381" x2="-3.7592" y2="0.889" width="0" layer="51"/>
<wire x1="-3.7592" y1="0.889" x2="-5.3086" y2="0.889" width="0" layer="51"/>
<wire x1="-5.3086" y1="0.889" x2="-5.3086" y2="0.381" width="0" layer="51"/>
<wire x1="-5.3086" y1="0.381" x2="-3.7592" y2="0.381" width="0" layer="51"/>
<wire x1="-3.7592" y1="-0.889" x2="-3.7592" y2="-0.381" width="0" layer="51"/>
<wire x1="-3.7592" y1="-0.381" x2="-5.3086" y2="-0.381" width="0" layer="51"/>
<wire x1="-5.3086" y1="-0.381" x2="-5.3086" y2="-0.889" width="0" layer="51"/>
<wire x1="-5.3086" y1="-0.889" x2="-3.7592" y2="-0.889" width="0" layer="51"/>
<wire x1="-3.7592" y1="-2.159" x2="-3.7592" y2="-1.651" width="0" layer="51"/>
<wire x1="-3.7592" y1="-1.651" x2="-5.3086" y2="-1.651" width="0" layer="51"/>
<wire x1="-5.3086" y1="-1.651" x2="-5.3086" y2="-2.159" width="0" layer="51"/>
<wire x1="-5.3086" y1="-2.159" x2="-3.7592" y2="-2.159" width="0" layer="51"/>
<wire x1="-3.7592" y1="-3.429" x2="-3.7592" y2="-2.921" width="0" layer="51"/>
<wire x1="-3.7592" y1="-2.921" x2="-5.3086" y2="-2.921" width="0" layer="51"/>
<wire x1="-5.3086" y1="-2.921" x2="-5.3086" y2="-3.429" width="0" layer="51"/>
<wire x1="-5.3086" y1="-3.429" x2="-3.7592" y2="-3.429" width="0" layer="51"/>
<wire x1="-3.7592" y1="-4.699" x2="-3.7592" y2="-4.191" width="0" layer="51"/>
<wire x1="-3.7592" y1="-4.191" x2="-5.3086" y2="-4.191" width="0" layer="51"/>
<wire x1="-5.3086" y1="-4.191" x2="-5.3086" y2="-4.699" width="0" layer="51"/>
<wire x1="-5.3086" y1="-4.699" x2="-3.7592" y2="-4.699" width="0" layer="51"/>
<wire x1="-3.7592" y1="-5.969" x2="-3.7592" y2="-5.461" width="0" layer="51"/>
<wire x1="-3.7592" y1="-5.461" x2="-5.3086" y2="-5.461" width="0" layer="51"/>
<wire x1="-5.3086" y1="-5.461" x2="-5.3086" y2="-5.969" width="0" layer="51"/>
<wire x1="-5.3086" y1="-5.969" x2="-3.7592" y2="-5.969" width="0" layer="51"/>
<wire x1="-3.7592" y1="-7.239" x2="-3.7592" y2="-6.731" width="0" layer="51"/>
<wire x1="-3.7592" y1="-6.731" x2="-5.3086" y2="-6.731" width="0" layer="51"/>
<wire x1="-5.3086" y1="-6.731" x2="-5.3086" y2="-7.239" width="0" layer="51"/>
<wire x1="-5.3086" y1="-7.239" x2="-3.7592" y2="-7.239" width="0" layer="51"/>
<wire x1="3.7592" y1="-6.731" x2="3.7592" y2="-7.239" width="0" layer="51"/>
<wire x1="3.7592" y1="-7.239" x2="5.3086" y2="-7.239" width="0" layer="51"/>
<wire x1="5.3086" y1="-7.239" x2="5.3086" y2="-6.731" width="0" layer="51"/>
<wire x1="5.3086" y1="-6.731" x2="3.7592" y2="-6.731" width="0" layer="51"/>
<wire x1="3.7592" y1="-5.461" x2="3.7592" y2="-5.969" width="0" layer="51"/>
<wire x1="3.7592" y1="-5.969" x2="5.3086" y2="-5.969" width="0" layer="51"/>
<wire x1="5.3086" y1="-5.969" x2="5.3086" y2="-5.461" width="0" layer="51"/>
<wire x1="5.3086" y1="-5.461" x2="3.7592" y2="-5.461" width="0" layer="51"/>
<wire x1="3.7592" y1="-4.191" x2="3.7592" y2="-4.699" width="0" layer="51"/>
<wire x1="3.7592" y1="-4.699" x2="5.3086" y2="-4.699" width="0" layer="51"/>
<wire x1="5.3086" y1="-4.699" x2="5.3086" y2="-4.191" width="0" layer="51"/>
<wire x1="5.3086" y1="-4.191" x2="3.7592" y2="-4.191" width="0" layer="51"/>
<wire x1="3.7592" y1="-2.921" x2="3.7592" y2="-3.429" width="0" layer="51"/>
<wire x1="3.7592" y1="-3.429" x2="5.3086" y2="-3.429" width="0" layer="51"/>
<wire x1="5.3086" y1="-3.429" x2="5.3086" y2="-2.921" width="0" layer="51"/>
<wire x1="5.3086" y1="-2.921" x2="3.7592" y2="-2.921" width="0" layer="51"/>
<wire x1="3.7592" y1="-1.651" x2="3.7592" y2="-2.159" width="0" layer="51"/>
<wire x1="3.7592" y1="-2.159" x2="5.3086" y2="-2.159" width="0" layer="51"/>
<wire x1="5.3086" y1="-2.159" x2="5.3086" y2="-1.651" width="0" layer="51"/>
<wire x1="5.3086" y1="-1.651" x2="3.7592" y2="-1.651" width="0" layer="51"/>
<wire x1="3.7592" y1="-0.381" x2="3.7592" y2="-0.889" width="0" layer="51"/>
<wire x1="3.7592" y1="-0.889" x2="5.3086" y2="-0.889" width="0" layer="51"/>
<wire x1="5.3086" y1="-0.889" x2="5.3086" y2="-0.381" width="0" layer="51"/>
<wire x1="5.3086" y1="-0.381" x2="3.7592" y2="-0.381" width="0" layer="51"/>
<wire x1="3.7592" y1="0.889" x2="3.7592" y2="0.381" width="0" layer="51"/>
<wire x1="3.7592" y1="0.381" x2="5.3086" y2="0.381" width="0" layer="51"/>
<wire x1="5.3086" y1="0.381" x2="5.3086" y2="0.889" width="0" layer="51"/>
<wire x1="5.3086" y1="0.889" x2="3.7592" y2="0.889" width="0" layer="51"/>
<wire x1="3.7592" y1="2.159" x2="3.7592" y2="1.651" width="0" layer="51"/>
<wire x1="3.7592" y1="1.651" x2="5.3086" y2="1.651" width="0" layer="51"/>
<wire x1="5.3086" y1="1.651" x2="5.3086" y2="2.159" width="0" layer="51"/>
<wire x1="5.3086" y1="2.159" x2="3.7592" y2="2.159" width="0" layer="51"/>
<wire x1="3.7592" y1="3.429" x2="3.7592" y2="2.921" width="0" layer="51"/>
<wire x1="3.7592" y1="2.921" x2="5.3086" y2="2.921" width="0" layer="51"/>
<wire x1="5.3086" y1="2.921" x2="5.3086" y2="3.429" width="0" layer="51"/>
<wire x1="5.3086" y1="3.429" x2="3.7592" y2="3.429" width="0" layer="51"/>
<wire x1="3.7592" y1="4.699" x2="3.7592" y2="4.191" width="0" layer="51"/>
<wire x1="3.7592" y1="4.191" x2="5.3086" y2="4.191" width="0" layer="51"/>
<wire x1="5.3086" y1="4.191" x2="5.3086" y2="4.699" width="0" layer="51"/>
<wire x1="5.3086" y1="4.699" x2="3.7592" y2="4.699" width="0" layer="51"/>
<wire x1="3.7592" y1="5.969" x2="3.7592" y2="5.461" width="0" layer="51"/>
<wire x1="3.7592" y1="5.461" x2="5.3086" y2="5.461" width="0" layer="51"/>
<wire x1="5.3086" y1="5.461" x2="5.3086" y2="5.969" width="0" layer="51"/>
<wire x1="5.3086" y1="5.969" x2="3.7592" y2="5.969" width="0" layer="51"/>
<wire x1="3.7592" y1="7.239" x2="3.7592" y2="6.731" width="0" layer="51"/>
<wire x1="3.7592" y1="6.731" x2="5.3086" y2="6.731" width="0" layer="51"/>
<wire x1="5.3086" y1="6.731" x2="5.3086" y2="7.239" width="0" layer="51"/>
<wire x1="5.3086" y1="7.239" x2="3.7592" y2="7.239" width="0" layer="51"/>
<wire x1="-3.7592" y1="-7.6962" x2="3.7592" y2="-7.6962" width="0" layer="51"/>
<wire x1="3.7592" y1="-7.6962" x2="3.7592" y2="7.6962" width="0" layer="51"/>
<wire x1="3.7592" y1="7.6962" x2="0.3048" y2="7.6962" width="0" layer="51"/>
<wire x1="0.3048" y1="7.6962" x2="-0.3048" y2="7.6962" width="0" layer="51"/>
<wire x1="-0.3048" y1="7.6962" x2="-3.7592" y2="7.6962" width="0" layer="51"/>
<wire x1="-3.7592" y1="7.6962" x2="-3.7592" y2="-7.6962" width="0" layer="51"/>
<wire x1="0.3048" y1="7.6962" x2="-0.3048" y2="7.6962" width="0" layer="51" curve="-180"/>
<text x="-5.5118" y="7.4168" size="1.27" layer="51" ratio="6" rot="SR0">*</text>
<text x="-3.4544" y="9.525" size="2.0828" layer="25" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-3.4544" y="-10.795" size="2.0828" layer="27" ratio="10" rot="SR0">&gt;VALUE</text>
</package>
<package name="DIP254P762X533-24">
<pad name="1" x="-7.62" y="27.94" drill="1.1176" shape="square"/>
<pad name="2" x="-7.62" y="25.4" drill="1.1176"/>
<pad name="3" x="-7.62" y="22.86" drill="1.1176"/>
<pad name="4" x="-7.62" y="20.32" drill="1.1176"/>
<pad name="5" x="-7.62" y="17.78" drill="1.1176"/>
<pad name="6" x="-7.62" y="15.24" drill="1.1176"/>
<pad name="7" x="-7.62" y="12.7" drill="1.1176"/>
<pad name="8" x="-7.62" y="10.16" drill="1.1176"/>
<pad name="9" x="-7.62" y="7.62" drill="1.1176"/>
<pad name="10" x="-7.62" y="5.08" drill="1.1176"/>
<pad name="11" x="-7.62" y="2.54" drill="1.1176"/>
<pad name="12" x="-7.62" y="0" drill="1.1176"/>
<pad name="13" x="0" y="0" drill="1.1176"/>
<pad name="14" x="0" y="2.54" drill="1.1176"/>
<pad name="15" x="0" y="5.08" drill="1.1176"/>
<pad name="16" x="0" y="7.62" drill="1.1176"/>
<pad name="17" x="0" y="10.16" drill="1.1176"/>
<pad name="18" x="0" y="12.7" drill="1.1176"/>
<pad name="19" x="0" y="15.24" drill="1.1176"/>
<pad name="20" x="0" y="17.78" drill="1.1176"/>
<pad name="21" x="0" y="20.32" drill="1.1176"/>
<pad name="22" x="0" y="22.86" drill="1.1176"/>
<pad name="23" x="0" y="25.4" drill="1.1176"/>
<pad name="24" x="0" y="27.94" drill="1.1176"/>
<wire x1="-0.635" y1="26.543" x2="-0.635" y2="26.797" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="24.003" x2="-0.635" y2="24.257" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="21.463" x2="-0.635" y2="21.717" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="18.923" x2="-0.635" y2="19.177" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="16.383" x2="-0.635" y2="16.637" width="0.1524" layer="21"/>
<wire x1="-6.8072" y1="-1.0414" x2="-0.8128" y2="-1.0414" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.143" x2="-0.635" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-0.8128" y1="28.9814" x2="-3.5052" y2="28.9814" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="28.9814" x2="-4.1148" y2="28.9814" width="0.1524" layer="21"/>
<wire x1="-4.1148" y1="28.9814" x2="-6.3246" y2="28.9814" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="24.257" x2="-6.985" y2="24.003" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="21.717" x2="-6.985" y2="21.463" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="19.177" x2="-6.985" y2="18.923" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="16.637" x2="-6.985" y2="16.383" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="14.097" x2="-6.985" y2="13.843" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="11.557" x2="-6.985" y2="11.303" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="9.017" x2="-6.985" y2="8.763" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="6.477" x2="-6.985" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="3.937" x2="-6.985" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="1.397" x2="-6.985" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="3.683" x2="-0.635" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="6.223" x2="-0.635" y2="6.477" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="8.763" x2="-0.635" y2="9.017" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="11.303" x2="-0.635" y2="11.557" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="13.843" x2="-0.635" y2="14.097" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="28.9814" x2="-4.1148" y2="28.9814" width="0.1524" layer="21" curve="-180"/>
<text x="-8.2042" y="29.0576" size="1.27" layer="21" ratio="6" rot="SR0">*</text>
<wire x1="-6.985" y1="27.3812" x2="-6.985" y2="28.4988" width="0" layer="51"/>
<wire x1="-6.985" y1="28.4988" x2="-8.1788" y2="28.4988" width="0" layer="51"/>
<wire x1="-8.1788" y1="28.4988" x2="-8.1788" y2="27.3812" width="0" layer="51"/>
<wire x1="-8.1788" y1="27.3812" x2="-6.985" y2="27.3812" width="0" layer="51"/>
<wire x1="-6.985" y1="24.8412" x2="-6.985" y2="25.9588" width="0" layer="51"/>
<wire x1="-6.985" y1="25.9588" x2="-8.1788" y2="25.9588" width="0" layer="51"/>
<wire x1="-8.1788" y1="25.9588" x2="-8.1788" y2="24.8412" width="0" layer="51"/>
<wire x1="-8.1788" y1="24.8412" x2="-6.985" y2="24.8412" width="0" layer="51"/>
<wire x1="-6.985" y1="22.3012" x2="-6.985" y2="23.4188" width="0" layer="51"/>
<wire x1="-6.985" y1="23.4188" x2="-8.1788" y2="23.4188" width="0" layer="51"/>
<wire x1="-8.1788" y1="23.4188" x2="-8.1788" y2="22.3012" width="0" layer="51"/>
<wire x1="-8.1788" y1="22.3012" x2="-6.985" y2="22.3012" width="0" layer="51"/>
<wire x1="-6.985" y1="19.7612" x2="-6.985" y2="20.8788" width="0" layer="51"/>
<wire x1="-6.985" y1="20.8788" x2="-8.1788" y2="20.8788" width="0" layer="51"/>
<wire x1="-8.1788" y1="20.8788" x2="-8.1788" y2="19.7612" width="0" layer="51"/>
<wire x1="-8.1788" y1="19.7612" x2="-6.985" y2="19.7612" width="0" layer="51"/>
<wire x1="-6.985" y1="17.2212" x2="-6.985" y2="18.3388" width="0" layer="51"/>
<wire x1="-6.985" y1="18.3388" x2="-8.1788" y2="18.3388" width="0" layer="51"/>
<wire x1="-8.1788" y1="17.2212" x2="-6.985" y2="17.2212" width="0" layer="51"/>
<wire x1="-6.985" y1="14.6812" x2="-6.985" y2="15.7988" width="0" layer="51"/>
<wire x1="-6.985" y1="15.7988" x2="-8.1788" y2="15.7988" width="0" layer="51"/>
<wire x1="-8.1788" y1="14.6812" x2="-6.985" y2="14.6812" width="0" layer="51"/>
<wire x1="-6.985" y1="12.1412" x2="-6.985" y2="13.2588" width="0" layer="51"/>
<wire x1="-6.985" y1="13.2588" x2="-8.1788" y2="13.2588" width="0" layer="51"/>
<wire x1="-8.1788" y1="12.1412" x2="-6.985" y2="12.1412" width="0" layer="51"/>
<wire x1="-6.985" y1="9.6012" x2="-6.985" y2="10.7188" width="0" layer="51"/>
<wire x1="-6.985" y1="10.7188" x2="-8.1788" y2="10.7188" width="0" layer="51"/>
<wire x1="-8.1788" y1="9.6012" x2="-6.985" y2="9.6012" width="0" layer="51"/>
<wire x1="-6.985" y1="7.0612" x2="-6.985" y2="8.1788" width="0" layer="51"/>
<wire x1="-6.985" y1="8.1788" x2="-8.1788" y2="8.1788" width="0" layer="51"/>
<wire x1="-8.1788" y1="7.0612" x2="-6.985" y2="7.0612" width="0" layer="51"/>
<wire x1="-6.985" y1="4.5212" x2="-6.985" y2="5.6388" width="0" layer="51"/>
<wire x1="-6.985" y1="5.6388" x2="-8.1788" y2="5.6388" width="0" layer="51"/>
<wire x1="-8.1788" y1="4.5212" x2="-6.985" y2="4.5212" width="0" layer="51"/>
<wire x1="-6.985" y1="1.9812" x2="-6.985" y2="3.0988" width="0" layer="51"/>
<wire x1="-6.985" y1="3.0988" x2="-8.1788" y2="3.0988" width="0" layer="51"/>
<wire x1="-8.1788" y1="1.9812" x2="-6.985" y2="1.9812" width="0" layer="51"/>
<wire x1="-6.985" y1="-0.5588" x2="-6.985" y2="0.5588" width="0" layer="51"/>
<wire x1="-6.985" y1="0.5588" x2="-8.1788" y2="0.5588" width="0" layer="51"/>
<wire x1="-8.1788" y1="-0.5588" x2="-6.985" y2="-0.5588" width="0" layer="51"/>
<wire x1="-0.635" y1="0.5588" x2="-0.635" y2="-0.5588" width="0" layer="51"/>
<wire x1="-0.635" y1="-0.5588" x2="0.5588" y2="-0.5588" width="0" layer="51"/>
<wire x1="0.5588" y1="0.5588" x2="-0.635" y2="0.5588" width="0" layer="51"/>
<wire x1="-0.635" y1="3.0988" x2="-0.635" y2="1.9812" width="0" layer="51"/>
<wire x1="-0.635" y1="1.9812" x2="0.5588" y2="1.9812" width="0" layer="51"/>
<wire x1="0.5588" y1="3.0988" x2="-0.635" y2="3.0988" width="0" layer="51"/>
<wire x1="-0.635" y1="5.6388" x2="-0.635" y2="4.5212" width="0" layer="51"/>
<wire x1="-0.635" y1="4.5212" x2="0.5588" y2="4.5212" width="0" layer="51"/>
<wire x1="0.5588" y1="5.6388" x2="-0.635" y2="5.6388" width="0" layer="51"/>
<wire x1="-0.635" y1="8.1788" x2="-0.635" y2="7.0612" width="0" layer="51"/>
<wire x1="-0.635" y1="7.0612" x2="0.5588" y2="7.0612" width="0" layer="51"/>
<wire x1="0.5588" y1="8.1788" x2="-0.635" y2="8.1788" width="0" layer="51"/>
<wire x1="-0.635" y1="10.7188" x2="-0.635" y2="9.6012" width="0" layer="51"/>
<wire x1="-0.635" y1="9.6012" x2="0.5588" y2="9.6012" width="0" layer="51"/>
<wire x1="0.5588" y1="10.7188" x2="-0.635" y2="10.7188" width="0" layer="51"/>
<wire x1="-0.635" y1="13.2588" x2="-0.635" y2="12.1412" width="0" layer="51"/>
<wire x1="-0.635" y1="12.1412" x2="0.5588" y2="12.1412" width="0" layer="51"/>
<wire x1="0.5588" y1="13.2588" x2="-0.635" y2="13.2588" width="0" layer="51"/>
<wire x1="-0.635" y1="15.7988" x2="-0.635" y2="14.6812" width="0" layer="51"/>
<wire x1="-0.635" y1="14.6812" x2="0.5588" y2="14.6812" width="0" layer="51"/>
<wire x1="0.5588" y1="15.7988" x2="-0.635" y2="15.7988" width="0" layer="51"/>
<wire x1="-0.635" y1="18.3388" x2="-0.635" y2="17.2212" width="0" layer="51"/>
<wire x1="-0.635" y1="17.2212" x2="0.5588" y2="17.2212" width="0" layer="51"/>
<wire x1="0.5588" y1="18.3388" x2="-0.635" y2="18.3388" width="0" layer="51"/>
<wire x1="-0.635" y1="20.8788" x2="-0.635" y2="19.7612" width="0" layer="51"/>
<wire x1="-0.635" y1="19.7612" x2="0.5588" y2="19.7612" width="0" layer="51"/>
<wire x1="0.5588" y1="19.7612" x2="0.5588" y2="20.8788" width="0" layer="51"/>
<wire x1="0.5588" y1="20.8788" x2="-0.635" y2="20.8788" width="0" layer="51"/>
<wire x1="-0.635" y1="23.4188" x2="-0.635" y2="22.3012" width="0" layer="51"/>
<wire x1="-0.635" y1="22.3012" x2="0.5588" y2="22.3012" width="0" layer="51"/>
<wire x1="0.5588" y1="22.3012" x2="0.5588" y2="23.4188" width="0" layer="51"/>
<wire x1="0.5588" y1="23.4188" x2="-0.635" y2="23.4188" width="0" layer="51"/>
<wire x1="-0.635" y1="25.9588" x2="-0.635" y2="24.8412" width="0" layer="51"/>
<wire x1="-0.635" y1="24.8412" x2="0.5588" y2="24.8412" width="0" layer="51"/>
<wire x1="0.5588" y1="24.8412" x2="0.5588" y2="25.9588" width="0" layer="51"/>
<wire x1="0.5588" y1="25.9588" x2="-0.635" y2="25.9588" width="0" layer="51"/>
<wire x1="-0.635" y1="28.4988" x2="-0.635" y2="27.3812" width="0" layer="51"/>
<wire x1="-0.635" y1="27.3812" x2="0.5588" y2="27.3812" width="0" layer="51"/>
<wire x1="0.5588" y1="27.3812" x2="0.5588" y2="28.4988" width="0" layer="51"/>
<wire x1="0.5588" y1="28.4988" x2="-0.635" y2="28.4988" width="0" layer="51"/>
<wire x1="-6.985" y1="-1.0414" x2="-0.635" y2="-1.0414" width="0" layer="51"/>
<wire x1="-0.635" y1="-1.0414" x2="-0.635" y2="28.9814" width="0" layer="51"/>
<wire x1="-0.635" y1="28.9814" x2="-3.5052" y2="28.9814" width="0" layer="51"/>
<wire x1="-3.5052" y1="28.9814" x2="-4.1148" y2="28.9814" width="0" layer="51"/>
<wire x1="-4.1148" y1="28.9814" x2="-6.985" y2="28.9814" width="0" layer="51"/>
<wire x1="-6.985" y1="28.9814" x2="-6.985" y2="-1.0414" width="0" layer="51"/>
<wire x1="-3.5052" y1="28.9814" x2="-4.1148" y2="28.9814" width="0" layer="51" curve="-180"/>
<text x="-8.2042" y="29.0576" size="1.27" layer="51" ratio="6" rot="SR0">*</text>
<text x="-8.7122" y="31.115" size="2.0828" layer="25" ratio="10" rot="SR0">&gt;NAME</text>
</package>
<package name="QFN50P500X500X100-29N">
<smd name="1" x="-2.3622" y="1.4986" dx="0.3048" dy="1.0668" layer="1" rot="R270"/>
<smd name="2" x="-2.3622" y="0.9906" dx="0.3048" dy="1.0668" layer="1" rot="R270"/>
<smd name="3" x="-2.3622" y="0.508" dx="0.3048" dy="1.0668" layer="1" rot="R270"/>
<smd name="4" x="-2.3622" y="0" dx="0.3048" dy="1.0668" layer="1" rot="R270"/>
<smd name="5" x="-2.3622" y="-0.508" dx="0.3048" dy="1.0668" layer="1" rot="R270"/>
<smd name="6" x="-2.3622" y="-0.9906" dx="0.3048" dy="1.0668" layer="1" rot="R270"/>
<smd name="7" x="-2.3622" y="-1.4986" dx="0.3048" dy="1.0668" layer="1" rot="R270"/>
<smd name="8" x="-1.4986" y="-2.3622" dx="0.3048" dy="1.0668" layer="1" rot="R180"/>
<smd name="9" x="-0.9906" y="-2.3622" dx="0.3048" dy="1.0668" layer="1" rot="R180"/>
<smd name="10" x="-0.508" y="-2.3622" dx="0.3048" dy="1.0668" layer="1" rot="R180"/>
<smd name="11" x="0" y="-2.3622" dx="0.3048" dy="1.0668" layer="1" rot="R180"/>
<smd name="12" x="0.508" y="-2.3622" dx="0.3048" dy="1.0668" layer="1" rot="R180"/>
<smd name="13" x="0.9906" y="-2.3622" dx="0.3048" dy="1.0668" layer="1" rot="R180"/>
<smd name="14" x="1.4986" y="-2.3622" dx="0.3048" dy="1.0668" layer="1" rot="R180"/>
<smd name="15" x="2.3622" y="-1.4986" dx="0.3048" dy="1.0668" layer="1" rot="R270"/>
<smd name="16" x="2.3622" y="-0.9906" dx="0.3048" dy="1.0668" layer="1" rot="R270"/>
<smd name="17" x="2.3622" y="-0.508" dx="0.3048" dy="1.0668" layer="1" rot="R270"/>
<smd name="18" x="2.3622" y="0" dx="0.3048" dy="1.0668" layer="1" rot="R270"/>
<smd name="19" x="2.3622" y="0.508" dx="0.3048" dy="1.0668" layer="1" rot="R270"/>
<smd name="20" x="2.3622" y="0.9906" dx="0.3048" dy="1.0668" layer="1" rot="R270"/>
<smd name="21" x="2.3622" y="1.4986" dx="0.3048" dy="1.0668" layer="1" rot="R270"/>
<smd name="22" x="1.4986" y="2.3622" dx="0.3048" dy="1.0668" layer="1" rot="R180"/>
<smd name="23" x="0.9906" y="2.3622" dx="0.3048" dy="1.0668" layer="1" rot="R180"/>
<smd name="24" x="0.508" y="2.3622" dx="0.3048" dy="1.0668" layer="1" rot="R180"/>
<smd name="25" x="0" y="2.3622" dx="0.3048" dy="1.0668" layer="1" rot="R180"/>
<smd name="26" x="-0.508" y="2.3622" dx="0.3048" dy="1.0668" layer="1" rot="R180"/>
<smd name="27" x="-0.9906" y="2.3622" dx="0.3048" dy="1.0668" layer="1" rot="R180"/>
<smd name="28" x="-1.4986" y="2.3622" dx="0.3048" dy="1.0668" layer="1" rot="R180"/>
<smd name="29" x="0" y="0" dx="3.1496" dy="3.1496" layer="1"/>
<wire x1="-0.508" y1="-3.2258" x2="-0.508" y2="-4.2418" width="0.1524" layer="21"/>
<wire x1="4.2418" y1="0.9652" x2="3.2258" y2="0.9652" width="0.1524" layer="21"/>
<wire x1="2.4892" y1="1.9812" x2="2.4892" y2="2.4892" width="0.1524" layer="21"/>
<wire x1="1.9812" y1="-2.4892" x2="2.4892" y2="-2.4892" width="0.1524" layer="21"/>
<wire x1="-1.9812" y1="2.4892" x2="-2.4892" y2="2.4892" width="0.1524" layer="21"/>
<wire x1="-2.4892" y1="-2.4892" x2="-1.9812" y2="-2.4892" width="0.1524" layer="21"/>
<wire x1="2.4892" y1="-2.4892" x2="2.4892" y2="-1.9812" width="0.1524" layer="21"/>
<wire x1="2.4892" y1="2.4892" x2="1.9812" y2="2.4892" width="0.1524" layer="21"/>
<wire x1="-2.4892" y1="2.4892" x2="-2.4892" y2="1.9812" width="0.1524" layer="21"/>
<wire x1="-2.4892" y1="-1.9812" x2="-2.4892" y2="-2.4892" width="0.1524" layer="21"/>
<text x="-4.0894" y="1.4986" size="1.27" layer="21" ratio="6" rot="SR0">*</text>
<wire x1="-2.4892" y1="1.2192" x2="-1.2192" y2="2.4892" width="0" layer="51"/>
<wire x1="1.3462" y1="2.4892" x2="1.651" y2="2.4892" width="0" layer="51"/>
<wire x1="1.651" y1="2.4892" x2="1.651" y2="2.5654" width="0" layer="51"/>
<wire x1="1.651" y1="2.5654" x2="1.3462" y2="2.5654" width="0" layer="51"/>
<wire x1="1.3462" y1="2.5654" x2="1.3462" y2="2.4892" width="0" layer="51"/>
<wire x1="0.8382" y1="2.4892" x2="1.143" y2="2.4892" width="0" layer="51"/>
<wire x1="1.143" y1="2.4892" x2="1.143" y2="2.5654" width="0" layer="51"/>
<wire x1="1.143" y1="2.5654" x2="0.8382" y2="2.5654" width="0" layer="51"/>
<wire x1="0.8382" y1="2.5654" x2="0.8382" y2="2.4892" width="0" layer="51"/>
<wire x1="0.3556" y1="2.4892" x2="0.6604" y2="2.4892" width="0" layer="51"/>
<wire x1="0.6604" y1="2.4892" x2="0.6604" y2="2.5654" width="0" layer="51"/>
<wire x1="0.6604" y1="2.5654" x2="0.3556" y2="2.5654" width="0" layer="51"/>
<wire x1="0.3556" y1="2.5654" x2="0.3556" y2="2.4892" width="0" layer="51"/>
<wire x1="-0.1524" y1="2.4892" x2="0.1524" y2="2.4892" width="0" layer="51"/>
<wire x1="0.1524" y1="2.4892" x2="0.1524" y2="2.5654" width="0" layer="51"/>
<wire x1="0.1524" y1="2.5654" x2="-0.1524" y2="2.5654" width="0" layer="51"/>
<wire x1="-0.1524" y1="2.5654" x2="-0.1524" y2="2.4892" width="0" layer="51"/>
<wire x1="-0.6604" y1="2.4892" x2="-0.3556" y2="2.4892" width="0" layer="51"/>
<wire x1="-0.3556" y1="2.4892" x2="-0.3556" y2="2.5654" width="0" layer="51"/>
<wire x1="-0.3556" y1="2.5654" x2="-0.6604" y2="2.5654" width="0" layer="51"/>
<wire x1="-0.6604" y1="2.5654" x2="-0.6604" y2="2.4892" width="0" layer="51"/>
<wire x1="-1.143" y1="2.4892" x2="-0.8382" y2="2.4892" width="0" layer="51"/>
<wire x1="-0.8382" y1="2.4892" x2="-0.8382" y2="2.5654" width="0" layer="51"/>
<wire x1="-0.8382" y1="2.5654" x2="-1.143" y2="2.5654" width="0" layer="51"/>
<wire x1="-1.143" y1="2.5654" x2="-1.143" y2="2.4892" width="0" layer="51"/>
<wire x1="-1.651" y1="2.4892" x2="-1.3462" y2="2.4892" width="0" layer="51"/>
<wire x1="-1.3462" y1="2.4892" x2="-1.3462" y2="2.5654" width="0" layer="51"/>
<wire x1="-1.3462" y1="2.5654" x2="-1.651" y2="2.5654" width="0" layer="51"/>
<wire x1="-1.651" y1="2.5654" x2="-1.651" y2="2.4892" width="0" layer="51"/>
<wire x1="-2.4892" y1="1.3462" x2="-2.4892" y2="1.651" width="0" layer="51"/>
<wire x1="-2.4892" y1="1.651" x2="-2.5654" y2="1.651" width="0" layer="51"/>
<wire x1="-2.5654" y1="1.651" x2="-2.5654" y2="1.3462" width="0" layer="51"/>
<wire x1="-2.5654" y1="1.3462" x2="-2.4892" y2="1.3462" width="0" layer="51"/>
<wire x1="-2.4892" y1="0.8382" x2="-2.4892" y2="1.143" width="0" layer="51"/>
<wire x1="-2.4892" y1="1.143" x2="-2.5654" y2="1.143" width="0" layer="51"/>
<wire x1="-2.5654" y1="1.143" x2="-2.5654" y2="0.8382" width="0" layer="51"/>
<wire x1="-2.5654" y1="0.8382" x2="-2.4892" y2="0.8382" width="0" layer="51"/>
<wire x1="-2.4892" y1="0.3556" x2="-2.4892" y2="0.6604" width="0" layer="51"/>
<wire x1="-2.4892" y1="0.6604" x2="-2.5654" y2="0.6604" width="0" layer="51"/>
<wire x1="-2.5654" y1="0.6604" x2="-2.5654" y2="0.3556" width="0" layer="51"/>
<wire x1="-2.5654" y1="0.3556" x2="-2.4892" y2="0.3556" width="0" layer="51"/>
<wire x1="-2.4892" y1="-0.1524" x2="-2.4892" y2="0.1524" width="0" layer="51"/>
<wire x1="-2.4892" y1="0.1524" x2="-2.5654" y2="0.1524" width="0" layer="51"/>
<wire x1="-2.5654" y1="0.1524" x2="-2.5654" y2="-0.1524" width="0" layer="51"/>
<wire x1="-2.5654" y1="-0.1524" x2="-2.4892" y2="-0.1524" width="0" layer="51"/>
<wire x1="-2.4892" y1="-0.6604" x2="-2.4892" y2="-0.3556" width="0" layer="51"/>
<wire x1="-2.4892" y1="-0.3556" x2="-2.5654" y2="-0.3556" width="0" layer="51"/>
<wire x1="-2.5654" y1="-0.3556" x2="-2.5654" y2="-0.6604" width="0" layer="51"/>
<wire x1="-2.5654" y1="-0.6604" x2="-2.4892" y2="-0.6604" width="0" layer="51"/>
<wire x1="-2.4892" y1="-1.143" x2="-2.4892" y2="-0.8382" width="0" layer="51"/>
<wire x1="-2.4892" y1="-0.8382" x2="-2.5654" y2="-0.8382" width="0" layer="51"/>
<wire x1="-2.5654" y1="-0.8382" x2="-2.5654" y2="-1.143" width="0" layer="51"/>
<wire x1="-2.5654" y1="-1.143" x2="-2.4892" y2="-1.143" width="0" layer="51"/>
<wire x1="-2.4892" y1="-1.651" x2="-2.4892" y2="-1.3462" width="0" layer="51"/>
<wire x1="-2.4892" y1="-1.3462" x2="-2.5654" y2="-1.3462" width="0" layer="51"/>
<wire x1="-2.5654" y1="-1.3462" x2="-2.5654" y2="-1.651" width="0" layer="51"/>
<wire x1="-2.5654" y1="-1.651" x2="-2.4892" y2="-1.651" width="0" layer="51"/>
<wire x1="-1.3462" y1="-2.4892" x2="-1.651" y2="-2.4892" width="0" layer="51"/>
<wire x1="-1.651" y1="-2.4892" x2="-1.651" y2="-2.5654" width="0" layer="51"/>
<wire x1="-1.651" y1="-2.5654" x2="-1.3462" y2="-2.5654" width="0" layer="51"/>
<wire x1="-1.3462" y1="-2.5654" x2="-1.3462" y2="-2.4892" width="0" layer="51"/>
<wire x1="-0.8382" y1="-2.4892" x2="-1.143" y2="-2.4892" width="0" layer="51"/>
<wire x1="-1.143" y1="-2.4892" x2="-1.143" y2="-2.5654" width="0" layer="51"/>
<wire x1="-1.143" y1="-2.5654" x2="-0.8382" y2="-2.5654" width="0" layer="51"/>
<wire x1="-0.8382" y1="-2.5654" x2="-0.8382" y2="-2.4892" width="0" layer="51"/>
<wire x1="-0.3556" y1="-2.4892" x2="-0.6604" y2="-2.4892" width="0" layer="51"/>
<wire x1="-0.6604" y1="-2.4892" x2="-0.6604" y2="-2.5654" width="0" layer="51"/>
<wire x1="-0.6604" y1="-2.5654" x2="-0.3556" y2="-2.5654" width="0" layer="51"/>
<wire x1="-0.3556" y1="-2.5654" x2="-0.3556" y2="-2.4892" width="0" layer="51"/>
<wire x1="0.1524" y1="-2.4892" x2="-0.1524" y2="-2.4892" width="0" layer="51"/>
<wire x1="-0.1524" y1="-2.4892" x2="-0.1524" y2="-2.5654" width="0" layer="51"/>
<wire x1="-0.1524" y1="-2.5654" x2="0.1524" y2="-2.5654" width="0" layer="51"/>
<wire x1="0.1524" y1="-2.5654" x2="0.1524" y2="-2.4892" width="0" layer="51"/>
<wire x1="0.6604" y1="-2.4892" x2="0.3556" y2="-2.4892" width="0" layer="51"/>
<wire x1="0.3556" y1="-2.4892" x2="0.3556" y2="-2.5654" width="0" layer="51"/>
<wire x1="0.3556" y1="-2.5654" x2="0.6604" y2="-2.5654" width="0" layer="51"/>
<wire x1="0.6604" y1="-2.5654" x2="0.6604" y2="-2.4892" width="0" layer="51"/>
<wire x1="1.143" y1="-2.4892" x2="0.8382" y2="-2.4892" width="0" layer="51"/>
<wire x1="0.8382" y1="-2.4892" x2="0.8382" y2="-2.5654" width="0" layer="51"/>
<wire x1="0.8382" y1="-2.5654" x2="1.143" y2="-2.5654" width="0" layer="51"/>
<wire x1="1.143" y1="-2.5654" x2="1.143" y2="-2.4892" width="0" layer="51"/>
<wire x1="1.651" y1="-2.4892" x2="1.3462" y2="-2.4892" width="0" layer="51"/>
<wire x1="1.3462" y1="-2.4892" x2="1.3462" y2="-2.5654" width="0" layer="51"/>
<wire x1="1.3462" y1="-2.5654" x2="1.651" y2="-2.5654" width="0" layer="51"/>
<wire x1="1.651" y1="-2.5654" x2="1.651" y2="-2.4892" width="0" layer="51"/>
<wire x1="2.4892" y1="-1.3462" x2="2.4892" y2="-1.651" width="0" layer="51"/>
<wire x1="2.4892" y1="-1.651" x2="2.5654" y2="-1.651" width="0" layer="51"/>
<wire x1="2.5654" y1="-1.651" x2="2.5654" y2="-1.3462" width="0" layer="51"/>
<wire x1="2.5654" y1="-1.3462" x2="2.4892" y2="-1.3462" width="0" layer="51"/>
<wire x1="2.4892" y1="-0.8382" x2="2.4892" y2="-1.143" width="0" layer="51"/>
<wire x1="2.4892" y1="-1.143" x2="2.5654" y2="-1.143" width="0" layer="51"/>
<wire x1="2.5654" y1="-1.143" x2="2.5654" y2="-0.8382" width="0" layer="51"/>
<wire x1="2.5654" y1="-0.8382" x2="2.4892" y2="-0.8382" width="0" layer="51"/>
<wire x1="2.4892" y1="-0.3556" x2="2.4892" y2="-0.6604" width="0" layer="51"/>
<wire x1="2.4892" y1="-0.6604" x2="2.5654" y2="-0.6604" width="0" layer="51"/>
<wire x1="2.5654" y1="-0.6604" x2="2.5654" y2="-0.3556" width="0" layer="51"/>
<wire x1="2.5654" y1="-0.3556" x2="2.4892" y2="-0.3556" width="0" layer="51"/>
<wire x1="2.4892" y1="0.1524" x2="2.4892" y2="-0.1524" width="0" layer="51"/>
<wire x1="2.4892" y1="-0.1524" x2="2.5654" y2="-0.1524" width="0" layer="51"/>
<wire x1="2.5654" y1="-0.1524" x2="2.5654" y2="0.1524" width="0" layer="51"/>
<wire x1="2.5654" y1="0.1524" x2="2.4892" y2="0.1524" width="0" layer="51"/>
<wire x1="2.4892" y1="0.6604" x2="2.4892" y2="0.3556" width="0" layer="51"/>
<wire x1="2.4892" y1="0.3556" x2="2.5654" y2="0.3556" width="0" layer="51"/>
<wire x1="2.5654" y1="0.3556" x2="2.5654" y2="0.6604" width="0" layer="51"/>
<wire x1="2.5654" y1="0.6604" x2="2.4892" y2="0.6604" width="0" layer="51"/>
<wire x1="2.4892" y1="1.143" x2="2.4892" y2="0.8382" width="0" layer="51"/>
<wire x1="2.4892" y1="0.8382" x2="2.5654" y2="0.8382" width="0" layer="51"/>
<wire x1="2.5654" y1="0.8382" x2="2.5654" y2="1.143" width="0" layer="51"/>
<wire x1="2.5654" y1="1.143" x2="2.4892" y2="1.143" width="0" layer="51"/>
<wire x1="2.4892" y1="1.651" x2="2.4892" y2="1.3462" width="0" layer="51"/>
<wire x1="2.4892" y1="1.3462" x2="2.5654" y2="1.3462" width="0" layer="51"/>
<wire x1="2.5654" y1="1.3462" x2="2.5654" y2="1.651" width="0" layer="51"/>
<wire x1="2.5654" y1="1.651" x2="2.4892" y2="1.651" width="0" layer="51"/>
<wire x1="-2.4892" y1="-2.4892" x2="2.4892" y2="-2.4892" width="0" layer="51"/>
<wire x1="2.4892" y1="-2.4892" x2="2.4892" y2="2.4892" width="0" layer="51"/>
<wire x1="2.4892" y1="2.4892" x2="-2.4892" y2="2.4892" width="0" layer="51"/>
<wire x1="-2.4892" y1="2.4892" x2="-2.4892" y2="-2.4892" width="0" layer="51"/>
<text x="-4.0894" y="1.4986" size="1.27" layer="51" ratio="6" rot="SR0">*</text>
<text x="-3.4544" y="5.08" size="2.0828" layer="25" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-3.4544" y="-6.985" size="2.0828" layer="27" ratio="10" rot="SR0">&gt;VALUE</text>
</package>
<package name="QFN50P500X500X100-33N">
<smd name="1" x="-2.4384" y="1.7526" dx="0.3556" dy="0.9144" layer="1" rot="R270"/>
<smd name="2" x="-2.4384" y="1.2446" dx="0.3556" dy="0.9144" layer="1" rot="R270"/>
<smd name="3" x="-2.4384" y="0.762" dx="0.3556" dy="0.9144" layer="1" rot="R270"/>
<smd name="4" x="-2.4384" y="0.254" dx="0.3556" dy="0.9144" layer="1" rot="R270"/>
<smd name="5" x="-2.4384" y="-0.254" dx="0.3556" dy="0.9144" layer="1" rot="R270"/>
<smd name="6" x="-2.4384" y="-0.762" dx="0.3556" dy="0.9144" layer="1" rot="R270"/>
<smd name="7" x="-2.4384" y="-1.2446" dx="0.3556" dy="0.9144" layer="1" rot="R270"/>
<smd name="8" x="-2.4384" y="-1.7526" dx="0.3556" dy="0.9144" layer="1" rot="R270"/>
<smd name="9" x="-1.7526" y="-2.4384" dx="0.3556" dy="0.9144" layer="1" rot="R180"/>
<smd name="10" x="-1.2446" y="-2.4384" dx="0.3556" dy="0.9144" layer="1" rot="R180"/>
<smd name="11" x="-0.762" y="-2.4384" dx="0.3556" dy="0.9144" layer="1" rot="R180"/>
<smd name="12" x="-0.254" y="-2.4384" dx="0.3556" dy="0.9144" layer="1" rot="R180"/>
<smd name="13" x="0.254" y="-2.4384" dx="0.3556" dy="0.9144" layer="1" rot="R180"/>
<smd name="14" x="0.762" y="-2.4384" dx="0.3556" dy="0.9144" layer="1" rot="R180"/>
<smd name="15" x="1.2446" y="-2.4384" dx="0.3556" dy="0.9144" layer="1" rot="R180"/>
<smd name="16" x="1.7526" y="-2.4384" dx="0.3556" dy="0.9144" layer="1" rot="R180"/>
<smd name="17" x="2.4384" y="-1.7526" dx="0.3556" dy="0.9144" layer="1" rot="R270"/>
<smd name="18" x="2.4384" y="-1.2446" dx="0.3556" dy="0.9144" layer="1" rot="R270"/>
<smd name="19" x="2.4384" y="-0.762" dx="0.3556" dy="0.9144" layer="1" rot="R270"/>
<smd name="20" x="2.4384" y="-0.254" dx="0.3556" dy="0.9144" layer="1" rot="R270"/>
<smd name="21" x="2.4384" y="0.254" dx="0.3556" dy="0.9144" layer="1" rot="R270"/>
<smd name="22" x="2.4384" y="0.762" dx="0.3556" dy="0.9144" layer="1" rot="R270"/>
<smd name="23" x="2.4384" y="1.2446" dx="0.3556" dy="0.9144" layer="1" rot="R270"/>
<smd name="24" x="2.4384" y="1.7526" dx="0.3556" dy="0.9144" layer="1" rot="R270"/>
<smd name="25" x="1.7526" y="2.4384" dx="0.3556" dy="0.9144" layer="1" rot="R180"/>
<smd name="26" x="1.2446" y="2.4384" dx="0.3556" dy="0.9144" layer="1" rot="R180"/>
<smd name="27" x="0.762" y="2.4384" dx="0.3556" dy="0.9144" layer="1" rot="R180"/>
<smd name="28" x="0.254" y="2.4384" dx="0.3556" dy="0.9144" layer="1" rot="R180"/>
<smd name="29" x="-0.254" y="2.4384" dx="0.3556" dy="0.9144" layer="1" rot="R180"/>
<smd name="30" x="-0.762" y="2.4384" dx="0.3556" dy="0.9144" layer="1" rot="R180"/>
<smd name="31" x="-1.2446" y="2.4384" dx="0.3556" dy="0.9144" layer="1" rot="R180"/>
<smd name="32" x="-1.7526" y="2.4384" dx="0.3556" dy="0.9144" layer="1" rot="R180"/>
<smd name="33" x="0" y="0" dx="3.4036" dy="3.4036" layer="1"/>
<wire x1="3.2258" y1="-0.2794" x2="4.2164" y2="-0.2794" width="0.1524" layer="21"/>
<wire x1="-0.7112" y1="3.2004" x2="-0.7112" y2="4.2164" width="0.1524" layer="21"/>
<wire x1="-1.2446" y1="-3.2004" x2="-1.2446" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="2.4892" y1="2.2606" x2="2.4892" y2="2.4892" width="0.1524" layer="21"/>
<wire x1="2.2606" y1="-2.4892" x2="2.4892" y2="-2.4892" width="0.1524" layer="21"/>
<wire x1="-2.4892" y1="-2.2606" x2="-2.4892" y2="-2.4892" width="0.1524" layer="21"/>
<wire x1="-2.2606" y1="2.4892" x2="-2.4892" y2="2.4892" width="0.1524" layer="21"/>
<wire x1="-2.4892" y1="-2.4892" x2="-2.2606" y2="-2.4892" width="0.1524" layer="21"/>
<wire x1="2.4892" y1="-2.4892" x2="2.4892" y2="-2.2606" width="0.1524" layer="21"/>
<wire x1="2.4892" y1="2.4892" x2="2.2606" y2="2.4892" width="0.1524" layer="21"/>
<wire x1="-2.4892" y1="2.4892" x2="-2.4892" y2="2.2606" width="0.1524" layer="21"/>
<text x="-4.0894" y="1.7526" size="1.27" layer="21" ratio="6" rot="SR0">*</text>
<wire x1="1.5748" y1="2.4892" x2="1.9304" y2="2.4892" width="0" layer="51"/>
<wire x1="1.9304" y1="2.4892" x2="1.9304" y2="2.5654" width="0" layer="51"/>
<wire x1="1.9304" y1="2.5654" x2="1.5748" y2="2.5654" width="0" layer="51"/>
<wire x1="1.5748" y1="2.5654" x2="1.5748" y2="2.4892" width="0" layer="51"/>
<wire x1="1.0668" y1="2.4892" x2="1.4224" y2="2.4892" width="0" layer="51"/>
<wire x1="1.4224" y1="2.4892" x2="1.4224" y2="2.5654" width="0" layer="51"/>
<wire x1="1.4224" y1="2.5654" x2="1.0668" y2="2.5654" width="0" layer="51"/>
<wire x1="1.0668" y1="2.5654" x2="1.0668" y2="2.4892" width="0" layer="51"/>
<wire x1="0.5842" y1="2.4892" x2="0.9144" y2="2.4892" width="0" layer="51"/>
<wire x1="0.9144" y1="2.4892" x2="0.9144" y2="2.5654" width="0" layer="51"/>
<wire x1="0.9144" y1="2.5654" x2="0.5842" y2="2.5654" width="0" layer="51"/>
<wire x1="0.5842" y1="2.5654" x2="0.5842" y2="2.4892" width="0" layer="51"/>
<wire x1="0.0762" y1="2.4892" x2="0.4318" y2="2.4892" width="0" layer="51"/>
<wire x1="0.4318" y1="2.4892" x2="0.4318" y2="2.5654" width="0" layer="51"/>
<wire x1="0.4318" y1="2.5654" x2="0.0762" y2="2.5654" width="0" layer="51"/>
<wire x1="0.0762" y1="2.5654" x2="0.0762" y2="2.4892" width="0" layer="51"/>
<wire x1="-0.4318" y1="2.4892" x2="-0.0762" y2="2.4892" width="0" layer="51"/>
<wire x1="-0.0762" y1="2.4892" x2="-0.0762" y2="2.5654" width="0" layer="51"/>
<wire x1="-0.0762" y1="2.5654" x2="-0.4318" y2="2.5654" width="0" layer="51"/>
<wire x1="-0.4318" y1="2.5654" x2="-0.4318" y2="2.4892" width="0" layer="51"/>
<wire x1="-0.9144" y1="2.4892" x2="-0.5842" y2="2.4892" width="0" layer="51"/>
<wire x1="-0.5842" y1="2.4892" x2="-0.5842" y2="2.5654" width="0" layer="51"/>
<wire x1="-0.5842" y1="2.5654" x2="-0.9144" y2="2.5654" width="0" layer="51"/>
<wire x1="-0.9144" y1="2.5654" x2="-0.9144" y2="2.4892" width="0" layer="51"/>
<wire x1="-1.4224" y1="2.4892" x2="-1.0668" y2="2.4892" width="0" layer="51"/>
<wire x1="-1.0668" y1="2.4892" x2="-1.0668" y2="2.5654" width="0" layer="51"/>
<wire x1="-1.0668" y1="2.5654" x2="-1.4224" y2="2.5654" width="0" layer="51"/>
<wire x1="-1.4224" y1="2.5654" x2="-1.4224" y2="2.4892" width="0" layer="51"/>
<wire x1="-1.9304" y1="2.4892" x2="-1.5748" y2="2.4892" width="0" layer="51"/>
<wire x1="-1.5748" y1="2.4892" x2="-1.5748" y2="2.5654" width="0" layer="51"/>
<wire x1="-1.5748" y1="2.5654" x2="-1.9304" y2="2.5654" width="0" layer="51"/>
<wire x1="-1.9304" y1="2.5654" x2="-1.9304" y2="2.4892" width="0" layer="51"/>
<wire x1="-2.4892" y1="1.5748" x2="-2.4892" y2="1.9304" width="0" layer="51"/>
<wire x1="-2.4892" y1="1.9304" x2="-2.5654" y2="1.9304" width="0" layer="51"/>
<wire x1="-2.5654" y1="1.9304" x2="-2.5654" y2="1.5748" width="0" layer="51"/>
<wire x1="-2.5654" y1="1.5748" x2="-2.4892" y2="1.5748" width="0" layer="51"/>
<wire x1="-2.4892" y1="1.0668" x2="-2.4892" y2="1.4224" width="0" layer="51"/>
<wire x1="-2.4892" y1="1.4224" x2="-2.5654" y2="1.4224" width="0" layer="51"/>
<wire x1="-2.5654" y1="1.4224" x2="-2.5654" y2="1.0668" width="0" layer="51"/>
<wire x1="-2.5654" y1="1.0668" x2="-2.4892" y2="1.0668" width="0" layer="51"/>
<wire x1="-2.4892" y1="0.5842" x2="-2.4892" y2="0.9144" width="0" layer="51"/>
<wire x1="-2.4892" y1="0.9144" x2="-2.5654" y2="0.9144" width="0" layer="51"/>
<wire x1="-2.5654" y1="0.9144" x2="-2.5654" y2="0.5842" width="0" layer="51"/>
<wire x1="-2.5654" y1="0.5842" x2="-2.4892" y2="0.5842" width="0" layer="51"/>
<wire x1="-2.4892" y1="0.0762" x2="-2.4892" y2="0.4318" width="0" layer="51"/>
<wire x1="-2.4892" y1="0.4318" x2="-2.5654" y2="0.4318" width="0" layer="51"/>
<wire x1="-2.5654" y1="0.4318" x2="-2.5654" y2="0.0762" width="0" layer="51"/>
<wire x1="-2.5654" y1="0.0762" x2="-2.4892" y2="0.0762" width="0" layer="51"/>
<wire x1="-2.4892" y1="-0.4318" x2="-2.4892" y2="-0.0762" width="0" layer="51"/>
<wire x1="-2.4892" y1="-0.0762" x2="-2.5654" y2="-0.0762" width="0" layer="51"/>
<wire x1="-2.5654" y1="-0.0762" x2="-2.5654" y2="-0.4318" width="0" layer="51"/>
<wire x1="-2.5654" y1="-0.4318" x2="-2.4892" y2="-0.4318" width="0" layer="51"/>
<wire x1="-2.4892" y1="-0.9144" x2="-2.4892" y2="-0.5842" width="0" layer="51"/>
<wire x1="-2.4892" y1="-0.5842" x2="-2.5654" y2="-0.5842" width="0" layer="51"/>
<wire x1="-2.5654" y1="-0.5842" x2="-2.5654" y2="-0.9144" width="0" layer="51"/>
<wire x1="-2.5654" y1="-0.9144" x2="-2.4892" y2="-0.9144" width="0" layer="51"/>
<wire x1="-2.4892" y1="-1.4224" x2="-2.4892" y2="-1.0668" width="0" layer="51"/>
<wire x1="-2.4892" y1="-1.0668" x2="-2.5654" y2="-1.0668" width="0" layer="51"/>
<wire x1="-2.5654" y1="-1.0668" x2="-2.5654" y2="-1.4224" width="0" layer="51"/>
<wire x1="-2.5654" y1="-1.4224" x2="-2.4892" y2="-1.4224" width="0" layer="51"/>
<wire x1="-2.4892" y1="-1.9304" x2="-2.4892" y2="-1.5748" width="0" layer="51"/>
<wire x1="-2.4892" y1="-1.5748" x2="-2.5654" y2="-1.5748" width="0" layer="51"/>
<wire x1="-2.5654" y1="-1.5748" x2="-2.5654" y2="-1.9304" width="0" layer="51"/>
<wire x1="-2.5654" y1="-1.9304" x2="-2.4892" y2="-1.9304" width="0" layer="51"/>
<wire x1="-1.5748" y1="-2.4892" x2="-1.9304" y2="-2.4892" width="0" layer="51"/>
<wire x1="-1.9304" y1="-2.4892" x2="-1.9304" y2="-2.5654" width="0" layer="51"/>
<wire x1="-1.9304" y1="-2.5654" x2="-1.5748" y2="-2.5654" width="0" layer="51"/>
<wire x1="-1.5748" y1="-2.5654" x2="-1.5748" y2="-2.4892" width="0" layer="51"/>
<wire x1="-1.0668" y1="-2.4892" x2="-1.4224" y2="-2.4892" width="0" layer="51"/>
<wire x1="-1.4224" y1="-2.4892" x2="-1.4224" y2="-2.5654" width="0" layer="51"/>
<wire x1="-1.4224" y1="-2.5654" x2="-1.0668" y2="-2.5654" width="0" layer="51"/>
<wire x1="-1.0668" y1="-2.5654" x2="-1.0668" y2="-2.4892" width="0" layer="51"/>
<wire x1="-0.5842" y1="-2.4892" x2="-0.9144" y2="-2.4892" width="0" layer="51"/>
<wire x1="-0.9144" y1="-2.4892" x2="-0.9144" y2="-2.5654" width="0" layer="51"/>
<wire x1="-0.9144" y1="-2.5654" x2="-0.5842" y2="-2.5654" width="0" layer="51"/>
<wire x1="-0.5842" y1="-2.5654" x2="-0.5842" y2="-2.4892" width="0" layer="51"/>
<wire x1="-0.0762" y1="-2.4892" x2="-0.4318" y2="-2.4892" width="0" layer="51"/>
<wire x1="-0.4318" y1="-2.4892" x2="-0.4318" y2="-2.5654" width="0" layer="51"/>
<wire x1="-0.4318" y1="-2.5654" x2="-0.0762" y2="-2.5654" width="0" layer="51"/>
<wire x1="-0.0762" y1="-2.5654" x2="-0.0762" y2="-2.4892" width="0" layer="51"/>
<wire x1="0.4318" y1="-2.4892" x2="0.0762" y2="-2.4892" width="0" layer="51"/>
<wire x1="0.0762" y1="-2.4892" x2="0.0762" y2="-2.5654" width="0" layer="51"/>
<wire x1="0.0762" y1="-2.5654" x2="0.4318" y2="-2.5654" width="0" layer="51"/>
<wire x1="0.4318" y1="-2.5654" x2="0.4318" y2="-2.4892" width="0" layer="51"/>
<wire x1="0.9144" y1="-2.4892" x2="0.5842" y2="-2.4892" width="0" layer="51"/>
<wire x1="0.5842" y1="-2.4892" x2="0.5842" y2="-2.5654" width="0" layer="51"/>
<wire x1="0.5842" y1="-2.5654" x2="0.9144" y2="-2.5654" width="0" layer="51"/>
<wire x1="0.9144" y1="-2.5654" x2="0.9144" y2="-2.4892" width="0" layer="51"/>
<wire x1="1.4224" y1="-2.4892" x2="1.0668" y2="-2.4892" width="0" layer="51"/>
<wire x1="1.0668" y1="-2.4892" x2="1.0668" y2="-2.5654" width="0" layer="51"/>
<wire x1="1.0668" y1="-2.5654" x2="1.4224" y2="-2.5654" width="0" layer="51"/>
<wire x1="1.4224" y1="-2.5654" x2="1.4224" y2="-2.4892" width="0" layer="51"/>
<wire x1="1.9304" y1="-2.4892" x2="1.5748" y2="-2.4892" width="0" layer="51"/>
<wire x1="1.5748" y1="-2.4892" x2="1.5748" y2="-2.5654" width="0" layer="51"/>
<wire x1="1.5748" y1="-2.5654" x2="1.9304" y2="-2.5654" width="0" layer="51"/>
<wire x1="1.9304" y1="-2.5654" x2="1.9304" y2="-2.4892" width="0" layer="51"/>
<wire x1="2.4892" y1="-1.5748" x2="2.4892" y2="-1.9304" width="0" layer="51"/>
<wire x1="2.4892" y1="-1.9304" x2="2.5654" y2="-1.9304" width="0" layer="51"/>
<wire x1="2.5654" y1="-1.9304" x2="2.5654" y2="-1.5748" width="0" layer="51"/>
<wire x1="2.5654" y1="-1.5748" x2="2.4892" y2="-1.5748" width="0" layer="51"/>
<wire x1="2.4892" y1="-1.0668" x2="2.4892" y2="-1.4224" width="0" layer="51"/>
<wire x1="2.4892" y1="-1.4224" x2="2.5654" y2="-1.4224" width="0" layer="51"/>
<wire x1="2.5654" y1="-1.4224" x2="2.5654" y2="-1.0668" width="0" layer="51"/>
<wire x1="2.5654" y1="-1.0668" x2="2.4892" y2="-1.0668" width="0" layer="51"/>
<wire x1="2.4892" y1="-0.5842" x2="2.4892" y2="-0.9144" width="0" layer="51"/>
<wire x1="2.4892" y1="-0.9144" x2="2.5654" y2="-0.9144" width="0" layer="51"/>
<wire x1="2.5654" y1="-0.9144" x2="2.5654" y2="-0.5842" width="0" layer="51"/>
<wire x1="2.5654" y1="-0.5842" x2="2.4892" y2="-0.5842" width="0" layer="51"/>
<wire x1="2.4892" y1="-0.0762" x2="2.4892" y2="-0.4318" width="0" layer="51"/>
<wire x1="2.4892" y1="-0.4318" x2="2.5654" y2="-0.4318" width="0" layer="51"/>
<wire x1="2.5654" y1="-0.4318" x2="2.5654" y2="-0.0762" width="0" layer="51"/>
<wire x1="2.5654" y1="-0.0762" x2="2.4892" y2="-0.0762" width="0" layer="51"/>
<wire x1="2.4892" y1="0.4318" x2="2.4892" y2="0.0762" width="0" layer="51"/>
<wire x1="2.4892" y1="0.0762" x2="2.5654" y2="0.0762" width="0" layer="51"/>
<wire x1="2.5654" y1="0.0762" x2="2.5654" y2="0.4318" width="0" layer="51"/>
<wire x1="2.5654" y1="0.4318" x2="2.4892" y2="0.4318" width="0" layer="51"/>
<wire x1="2.4892" y1="0.9144" x2="2.4892" y2="0.5842" width="0" layer="51"/>
<wire x1="2.4892" y1="0.5842" x2="2.5654" y2="0.5842" width="0" layer="51"/>
<wire x1="2.5654" y1="0.5842" x2="2.5654" y2="0.9144" width="0" layer="51"/>
<wire x1="2.5654" y1="0.9144" x2="2.4892" y2="0.9144" width="0" layer="51"/>
<wire x1="2.4892" y1="1.4224" x2="2.4892" y2="1.0668" width="0" layer="51"/>
<wire x1="2.4892" y1="1.0668" x2="2.5654" y2="1.0668" width="0" layer="51"/>
<wire x1="2.5654" y1="1.0668" x2="2.5654" y2="1.4224" width="0" layer="51"/>
<wire x1="2.5654" y1="1.4224" x2="2.4892" y2="1.4224" width="0" layer="51"/>
<wire x1="2.4892" y1="1.9304" x2="2.4892" y2="1.5748" width="0" layer="51"/>
<wire x1="2.4892" y1="1.5748" x2="2.5654" y2="1.5748" width="0" layer="51"/>
<wire x1="2.5654" y1="1.5748" x2="2.5654" y2="1.9304" width="0" layer="51"/>
<wire x1="2.5654" y1="1.9304" x2="2.4892" y2="1.9304" width="0" layer="51"/>
<text x="-4.0894" y="1.7526" size="1.27" layer="51" ratio="6" rot="SR0">*</text>
</package>
<package name="SOP65P640X120-25N">
<smd name="1" x="-2.921" y="3.5814" dx="1.4732" dy="0.3556" layer="1"/>
<smd name="2" x="-2.921" y="2.921" dx="1.4732" dy="0.3556" layer="1"/>
<smd name="3" x="-2.921" y="2.286" dx="1.4732" dy="0.3556" layer="1"/>
<smd name="4" x="-2.921" y="1.6256" dx="1.4732" dy="0.3556" layer="1"/>
<smd name="5" x="-2.921" y="0.9652" dx="1.4732" dy="0.3556" layer="1"/>
<smd name="6" x="-2.921" y="0.3302" dx="1.4732" dy="0.3556" layer="1"/>
<smd name="7" x="-2.921" y="-0.3302" dx="1.4732" dy="0.3556" layer="1"/>
<smd name="8" x="-2.921" y="-0.9652" dx="1.4732" dy="0.3556" layer="1"/>
<smd name="9" x="-2.921" y="-1.6256" dx="1.4732" dy="0.3556" layer="1"/>
<smd name="10" x="-2.921" y="-2.286" dx="1.4732" dy="0.3556" layer="1"/>
<smd name="11" x="-2.921" y="-2.921" dx="1.4732" dy="0.3556" layer="1"/>
<smd name="12" x="-2.921" y="-3.5814" dx="1.4732" dy="0.3556" layer="1"/>
<smd name="13" x="2.921" y="-3.5814" dx="1.4732" dy="0.3556" layer="1"/>
<smd name="14" x="2.921" y="-2.921" dx="1.4732" dy="0.3556" layer="1"/>
<smd name="15" x="2.921" y="-2.286" dx="1.4732" dy="0.3556" layer="1"/>
<smd name="16" x="2.921" y="-1.6256" dx="1.4732" dy="0.3556" layer="1"/>
<smd name="17" x="2.921" y="-0.9652" dx="1.4732" dy="0.3556" layer="1"/>
<smd name="18" x="2.921" y="-0.3302" dx="1.4732" dy="0.3556" layer="1"/>
<smd name="19" x="2.921" y="0.3302" dx="1.4732" dy="0.3556" layer="1"/>
<smd name="20" x="2.921" y="0.9652" dx="1.4732" dy="0.3556" layer="1"/>
<smd name="21" x="2.921" y="1.6256" dx="1.4732" dy="0.3556" layer="1"/>
<smd name="22" x="2.921" y="2.286" dx="1.4732" dy="0.3556" layer="1"/>
<smd name="23" x="2.921" y="2.921" dx="1.4732" dy="0.3556" layer="1"/>
<smd name="24" x="2.921" y="3.5814" dx="1.4732" dy="0.3556" layer="1"/>
<smd name="25" x="0" y="0" dx="2.9972" dy="4.318" layer="1"/>
<wire x1="-3.9878" y1="-2.286" x2="-4.9784" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="3.9878" y1="0.9144" x2="5.0038" y2="0.9144" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-3.9116" x2="1.905" y2="-3.9116" width="0.1524" layer="21"/>
<wire x1="1.905" y1="3.9116" x2="0.3048" y2="3.9116" width="0.1524" layer="21"/>
<wire x1="0.3048" y1="3.9116" x2="-0.3048" y2="3.9116" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="3.9116" x2="-1.905" y2="3.9116" width="0.1524" layer="21"/>
<wire x1="0.3048" y1="3.9116" x2="-0.3048" y2="3.9116" width="0.1524" layer="21" curve="-180"/>
<text x="-3.7592" y="3.81" size="1.27" layer="21" ratio="6" rot="SR0">*</text>
<wire x1="-2.2098" y1="3.429" x2="-2.2098" y2="3.7338" width="0" layer="51"/>
<wire x1="-2.2098" y1="3.7338" x2="-3.302" y2="3.7338" width="0" layer="51"/>
<wire x1="-3.302" y1="3.7338" x2="-3.302" y2="3.429" width="0" layer="51"/>
<wire x1="-3.302" y1="3.429" x2="-2.2098" y2="3.429" width="0" layer="51"/>
<wire x1="-2.2098" y1="2.7686" x2="-2.2098" y2="3.0734" width="0" layer="51"/>
<wire x1="-2.2098" y1="3.0734" x2="-3.302" y2="3.0734" width="0" layer="51"/>
<wire x1="-3.302" y1="3.0734" x2="-3.302" y2="2.7686" width="0" layer="51"/>
<wire x1="-3.302" y1="2.7686" x2="-2.2098" y2="2.7686" width="0" layer="51"/>
<wire x1="-2.2098" y1="2.1336" x2="-2.2098" y2="2.4384" width="0" layer="51"/>
<wire x1="-2.2098" y1="2.4384" x2="-3.302" y2="2.4384" width="0" layer="51"/>
<wire x1="-3.302" y1="2.4384" x2="-3.302" y2="2.1336" width="0" layer="51"/>
<wire x1="-3.302" y1="2.1336" x2="-2.2098" y2="2.1336" width="0" layer="51"/>
<wire x1="-2.2098" y1="1.4732" x2="-2.2098" y2="1.778" width="0" layer="51"/>
<wire x1="-2.2098" y1="1.778" x2="-3.302" y2="1.778" width="0" layer="51"/>
<wire x1="-3.302" y1="1.778" x2="-3.302" y2="1.4732" width="0" layer="51"/>
<wire x1="-3.302" y1="1.4732" x2="-2.2098" y2="1.4732" width="0" layer="51"/>
<wire x1="-2.2098" y1="0.8128" x2="-2.2098" y2="1.1176" width="0" layer="51"/>
<wire x1="-2.2098" y1="1.1176" x2="-3.302" y2="1.1176" width="0" layer="51"/>
<wire x1="-3.302" y1="1.1176" x2="-3.302" y2="0.8128" width="0" layer="51"/>
<wire x1="-3.302" y1="0.8128" x2="-2.2098" y2="0.8128" width="0" layer="51"/>
<wire x1="-2.2098" y1="0.1778" x2="-2.2098" y2="0.4826" width="0" layer="51"/>
<wire x1="-2.2098" y1="0.4826" x2="-3.302" y2="0.4826" width="0" layer="51"/>
<wire x1="-3.302" y1="0.4826" x2="-3.302" y2="0.1778" width="0" layer="51"/>
<wire x1="-3.302" y1="0.1778" x2="-2.2098" y2="0.1778" width="0" layer="51"/>
<wire x1="-2.2098" y1="-0.4826" x2="-2.2098" y2="-0.1778" width="0" layer="51"/>
<wire x1="-2.2098" y1="-0.1778" x2="-3.302" y2="-0.1778" width="0" layer="51"/>
<wire x1="-3.302" y1="-0.1778" x2="-3.302" y2="-0.4826" width="0" layer="51"/>
<wire x1="-3.302" y1="-0.4826" x2="-2.2098" y2="-0.4826" width="0" layer="51"/>
<wire x1="-2.2098" y1="-1.1176" x2="-2.2098" y2="-0.8128" width="0" layer="51"/>
<wire x1="-2.2098" y1="-0.8128" x2="-3.302" y2="-0.8128" width="0" layer="51"/>
<wire x1="-3.302" y1="-0.8128" x2="-3.302" y2="-1.1176" width="0" layer="51"/>
<wire x1="-3.302" y1="-1.1176" x2="-2.2098" y2="-1.1176" width="0" layer="51"/>
<wire x1="-2.2098" y1="-1.778" x2="-2.2098" y2="-1.4732" width="0" layer="51"/>
<wire x1="-2.2098" y1="-1.4732" x2="-3.302" y2="-1.4732" width="0" layer="51"/>
<wire x1="-3.302" y1="-1.4732" x2="-3.302" y2="-1.778" width="0" layer="51"/>
<wire x1="-3.302" y1="-1.778" x2="-2.2098" y2="-1.778" width="0" layer="51"/>
<wire x1="-2.2098" y1="-2.4384" x2="-2.2098" y2="-2.1336" width="0" layer="51"/>
<wire x1="-2.2098" y1="-2.1336" x2="-3.302" y2="-2.1336" width="0" layer="51"/>
<wire x1="-3.302" y1="-2.1336" x2="-3.302" y2="-2.4384" width="0" layer="51"/>
<wire x1="-3.302" y1="-2.4384" x2="-2.2098" y2="-2.4384" width="0" layer="51"/>
<wire x1="-2.2098" y1="-3.0734" x2="-2.2098" y2="-2.7686" width="0" layer="51"/>
<wire x1="-2.2098" y1="-2.7686" x2="-3.302" y2="-2.7686" width="0" layer="51"/>
<wire x1="-3.302" y1="-2.7686" x2="-3.302" y2="-3.0734" width="0" layer="51"/>
<wire x1="-3.302" y1="-3.0734" x2="-2.2098" y2="-3.0734" width="0" layer="51"/>
<wire x1="-2.2098" y1="-3.7338" x2="-2.2098" y2="-3.429" width="0" layer="51"/>
<wire x1="-2.2098" y1="-3.429" x2="-3.302" y2="-3.429" width="0" layer="51"/>
<wire x1="-3.302" y1="-3.429" x2="-3.302" y2="-3.7338" width="0" layer="51"/>
<wire x1="-3.302" y1="-3.7338" x2="-2.2098" y2="-3.7338" width="0" layer="51"/>
<wire x1="2.2098" y1="-3.429" x2="2.2098" y2="-3.7338" width="0" layer="51"/>
<wire x1="2.2098" y1="-3.7338" x2="3.302" y2="-3.7338" width="0" layer="51"/>
<wire x1="3.302" y1="-3.7338" x2="3.302" y2="-3.429" width="0" layer="51"/>
<wire x1="3.302" y1="-3.429" x2="2.2098" y2="-3.429" width="0" layer="51"/>
<wire x1="2.2098" y1="-2.7686" x2="2.2098" y2="-3.0734" width="0" layer="51"/>
<wire x1="2.2098" y1="-3.0734" x2="3.302" y2="-3.0734" width="0" layer="51"/>
<wire x1="3.302" y1="-3.0734" x2="3.302" y2="-2.7686" width="0" layer="51"/>
<wire x1="3.302" y1="-2.7686" x2="2.2098" y2="-2.7686" width="0" layer="51"/>
<wire x1="2.2098" y1="-2.1336" x2="2.2098" y2="-2.4384" width="0" layer="51"/>
<wire x1="2.2098" y1="-2.4384" x2="3.302" y2="-2.4384" width="0" layer="51"/>
<wire x1="3.302" y1="-2.4384" x2="3.302" y2="-2.1336" width="0" layer="51"/>
<wire x1="3.302" y1="-2.1336" x2="2.2098" y2="-2.1336" width="0" layer="51"/>
<wire x1="2.2098" y1="-1.4732" x2="2.2098" y2="-1.778" width="0" layer="51"/>
<wire x1="2.2098" y1="-1.778" x2="3.302" y2="-1.778" width="0" layer="51"/>
<wire x1="3.302" y1="-1.778" x2="3.302" y2="-1.4732" width="0" layer="51"/>
<wire x1="3.302" y1="-1.4732" x2="2.2098" y2="-1.4732" width="0" layer="51"/>
<wire x1="2.2098" y1="-0.8128" x2="2.2098" y2="-1.1176" width="0" layer="51"/>
<wire x1="2.2098" y1="-1.1176" x2="3.302" y2="-1.1176" width="0" layer="51"/>
<wire x1="3.302" y1="-1.1176" x2="3.302" y2="-0.8128" width="0" layer="51"/>
<wire x1="3.302" y1="-0.8128" x2="2.2098" y2="-0.8128" width="0" layer="51"/>
<wire x1="2.2098" y1="-0.1778" x2="2.2098" y2="-0.4826" width="0" layer="51"/>
<wire x1="2.2098" y1="-0.4826" x2="3.302" y2="-0.4826" width="0" layer="51"/>
<wire x1="3.302" y1="-0.4826" x2="3.302" y2="-0.1778" width="0" layer="51"/>
<wire x1="3.302" y1="-0.1778" x2="2.2098" y2="-0.1778" width="0" layer="51"/>
<wire x1="2.2098" y1="0.4826" x2="2.2098" y2="0.1778" width="0" layer="51"/>
<wire x1="2.2098" y1="0.1778" x2="3.302" y2="0.1778" width="0" layer="51"/>
<wire x1="3.302" y1="0.1778" x2="3.302" y2="0.4826" width="0" layer="51"/>
<wire x1="3.302" y1="0.4826" x2="2.2098" y2="0.4826" width="0" layer="51"/>
<wire x1="2.2098" y1="1.1176" x2="2.2098" y2="0.8128" width="0" layer="51"/>
<wire x1="2.2098" y1="0.8128" x2="3.302" y2="0.8128" width="0" layer="51"/>
<wire x1="3.302" y1="0.8128" x2="3.302" y2="1.1176" width="0" layer="51"/>
<wire x1="3.302" y1="1.1176" x2="2.2098" y2="1.1176" width="0" layer="51"/>
<wire x1="2.2098" y1="1.778" x2="2.2098" y2="1.4732" width="0" layer="51"/>
<wire x1="2.2098" y1="1.4732" x2="3.302" y2="1.4732" width="0" layer="51"/>
<wire x1="3.302" y1="1.4732" x2="3.302" y2="1.778" width="0" layer="51"/>
<wire x1="3.302" y1="1.778" x2="2.2098" y2="1.778" width="0" layer="51"/>
<wire x1="2.2098" y1="2.4384" x2="2.2098" y2="2.1336" width="0" layer="51"/>
<wire x1="2.2098" y1="2.1336" x2="3.302" y2="2.1336" width="0" layer="51"/>
<wire x1="3.302" y1="2.1336" x2="3.302" y2="2.4384" width="0" layer="51"/>
<wire x1="3.302" y1="2.4384" x2="2.2098" y2="2.4384" width="0" layer="51"/>
<wire x1="2.2098" y1="3.0734" x2="2.2098" y2="2.7686" width="0" layer="51"/>
<wire x1="2.2098" y1="2.7686" x2="3.302" y2="2.7686" width="0" layer="51"/>
<wire x1="3.302" y1="2.7686" x2="3.302" y2="3.0734" width="0" layer="51"/>
<wire x1="3.302" y1="3.0734" x2="2.2098" y2="3.0734" width="0" layer="51"/>
<wire x1="2.2098" y1="3.7338" x2="2.2098" y2="3.429" width="0" layer="51"/>
<wire x1="2.2098" y1="3.429" x2="3.302" y2="3.429" width="0" layer="51"/>
<wire x1="3.302" y1="3.429" x2="3.302" y2="3.7338" width="0" layer="51"/>
<wire x1="3.302" y1="3.7338" x2="2.2098" y2="3.7338" width="0" layer="51"/>
<wire x1="-2.2098" y1="-3.9116" x2="2.2098" y2="-3.9116" width="0" layer="51"/>
<wire x1="2.2098" y1="-3.9116" x2="2.2098" y2="3.9116" width="0" layer="51"/>
<wire x1="2.2098" y1="3.9116" x2="0.3048" y2="3.9116" width="0" layer="51"/>
<wire x1="0.3048" y1="3.9116" x2="-0.3048" y2="3.9116" width="0" layer="51"/>
<wire x1="-0.3048" y1="3.9116" x2="-2.2098" y2="3.9116" width="0" layer="51"/>
<wire x1="-2.2098" y1="3.9116" x2="-2.2098" y2="-3.9116" width="0" layer="51"/>
<wire x1="0.3048" y1="3.9116" x2="-0.3048" y2="3.9116" width="0" layer="51" curve="-180"/>
<text x="-3.7592" y="3.81" size="1.27" layer="51" ratio="6" rot="SR0">*</text>
<text x="-3.4544" y="4.953" size="2.0828" layer="25" ratio="10" rot="SR0">&gt;NAME</text>
</package>
<package name="QFN50P400X400X80-25N">
<smd name="1" x="-2.0066" y="1.2446" dx="0.3048" dy="0.762" layer="1" rot="R270"/>
<smd name="2" x="-2.0066" y="0.762" dx="0.3048" dy="0.762" layer="1" rot="R270"/>
<smd name="3" x="-2.0066" y="0.254" dx="0.3048" dy="0.762" layer="1" rot="R270"/>
<smd name="4" x="-2.0066" y="-0.254" dx="0.3048" dy="0.762" layer="1" rot="R270"/>
<smd name="5" x="-2.0066" y="-0.762" dx="0.3048" dy="0.762" layer="1" rot="R270"/>
<smd name="6" x="-2.0066" y="-1.2446" dx="0.3048" dy="0.762" layer="1" rot="R270"/>
<smd name="7" x="-1.2446" y="-2.0066" dx="0.3048" dy="0.762" layer="1" rot="R180"/>
<smd name="8" x="-0.762" y="-2.0066" dx="0.3048" dy="0.762" layer="1" rot="R180"/>
<smd name="9" x="-0.254" y="-2.0066" dx="0.3048" dy="0.762" layer="1" rot="R180"/>
<smd name="10" x="0.254" y="-2.0066" dx="0.3048" dy="0.762" layer="1" rot="R180"/>
<smd name="11" x="0.762" y="-2.0066" dx="0.3048" dy="0.762" layer="1" rot="R180"/>
<smd name="12" x="1.2446" y="-2.0066" dx="0.3048" dy="0.762" layer="1" rot="R180"/>
<smd name="13" x="2.0066" y="-1.2446" dx="0.3048" dy="0.762" layer="1" rot="R270"/>
<smd name="14" x="2.0066" y="-0.762" dx="0.3048" dy="0.762" layer="1" rot="R270"/>
<smd name="15" x="2.0066" y="-0.254" dx="0.3048" dy="0.762" layer="1" rot="R270"/>
<smd name="16" x="2.0066" y="0.254" dx="0.3048" dy="0.762" layer="1" rot="R270"/>
<smd name="17" x="2.0066" y="0.762" dx="0.3048" dy="0.762" layer="1" rot="R270"/>
<smd name="18" x="2.0066" y="1.2446" dx="0.3048" dy="0.762" layer="1" rot="R270"/>
<smd name="19" x="1.2446" y="2.0066" dx="0.3048" dy="0.762" layer="1" rot="R180"/>
<smd name="20" x="0.762" y="2.0066" dx="0.3048" dy="0.762" layer="1" rot="R180"/>
<smd name="21" x="0.254" y="2.0066" dx="0.3048" dy="0.762" layer="1" rot="R180"/>
<smd name="22" x="-0.254" y="2.0066" dx="0.3048" dy="0.762" layer="1" rot="R180"/>
<smd name="23" x="-0.762" y="2.0066" dx="0.3048" dy="0.762" layer="1" rot="R180"/>
<smd name="24" x="-1.2446" y="2.0066" dx="0.3048" dy="0.762" layer="1" rot="R180"/>
<smd name="25" x="0" y="0" dx="2.6924" dy="2.6924" layer="1"/>
<wire x1="0.762" y1="2.7178" x2="0.762" y2="3.7592" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-2.667" x2="0.254" y2="-3.7084" width="0.1524" layer="21"/>
<wire x1="2.0066" y1="1.7272" x2="2.0066" y2="2.0066" width="0.1524" layer="21"/>
<wire x1="1.7272" y1="-2.0066" x2="2.0066" y2="-2.0066" width="0.1524" layer="21"/>
<wire x1="-2.0066" y1="-1.7272" x2="-2.0066" y2="-2.0066" width="0.1524" layer="21"/>
<wire x1="-1.7272" y1="2.0066" x2="-2.0066" y2="2.0066" width="0.1524" layer="21"/>
<wire x1="-2.0066" y1="-2.0066" x2="-1.7272" y2="-2.0066" width="0.1524" layer="21"/>
<wire x1="2.0066" y1="-2.0066" x2="2.0066" y2="-1.7272" width="0.1524" layer="21"/>
<wire x1="2.0066" y1="2.0066" x2="1.7272" y2="2.0066" width="0.1524" layer="21"/>
<wire x1="-2.0066" y1="2.0066" x2="-2.0066" y2="1.7272" width="0.1524" layer="21"/>
<text x="-3.5814" y="1.2446" size="1.27" layer="21" ratio="6" rot="SR0">*</text>
<wire x1="-2.0066" y1="0.7366" x2="-0.7366" y2="2.0066" width="0" layer="51"/>
<wire x1="1.0922" y1="2.0066" x2="1.397" y2="2.0066" width="0" layer="51"/>
<wire x1="1.397" y1="2.0066" x2="1.397" y2="2.0828" width="0" layer="51"/>
<wire x1="1.397" y1="2.0828" x2="1.0922" y2="2.0828" width="0" layer="51"/>
<wire x1="1.0922" y1="2.0828" x2="1.0922" y2="2.0066" width="0" layer="51"/>
<wire x1="0.6096" y1="2.0066" x2="0.889" y2="2.0066" width="0" layer="51"/>
<wire x1="0.889" y1="2.0066" x2="0.889" y2="2.0828" width="0" layer="51"/>
<wire x1="0.889" y1="2.0828" x2="0.6096" y2="2.0828" width="0" layer="51"/>
<wire x1="0.6096" y1="2.0828" x2="0.6096" y2="2.0066" width="0" layer="51"/>
<wire x1="0.1016" y1="2.0066" x2="0.4064" y2="2.0066" width="0" layer="51"/>
<wire x1="0.4064" y1="2.0066" x2="0.4064" y2="2.0828" width="0" layer="51"/>
<wire x1="0.4064" y1="2.0828" x2="0.1016" y2="2.0828" width="0" layer="51"/>
<wire x1="0.1016" y1="2.0828" x2="0.1016" y2="2.0066" width="0" layer="51"/>
<wire x1="-0.4064" y1="2.0066" x2="-0.1016" y2="2.0066" width="0" layer="51"/>
<wire x1="-0.1016" y1="2.0066" x2="-0.1016" y2="2.0828" width="0" layer="51"/>
<wire x1="-0.1016" y1="2.0828" x2="-0.4064" y2="2.0828" width="0" layer="51"/>
<wire x1="-0.4064" y1="2.0828" x2="-0.4064" y2="2.0066" width="0" layer="51"/>
<wire x1="-0.889" y1="2.0066" x2="-0.6096" y2="2.0066" width="0" layer="51"/>
<wire x1="-0.6096" y1="2.0066" x2="-0.6096" y2="2.0828" width="0" layer="51"/>
<wire x1="-0.6096" y1="2.0828" x2="-0.889" y2="2.0828" width="0" layer="51"/>
<wire x1="-0.889" y1="2.0828" x2="-0.889" y2="2.0066" width="0" layer="51"/>
<wire x1="-1.397" y1="2.0066" x2="-1.0922" y2="2.0066" width="0" layer="51"/>
<wire x1="-1.0922" y1="2.0066" x2="-1.0922" y2="2.0828" width="0" layer="51"/>
<wire x1="-1.0922" y1="2.0828" x2="-1.397" y2="2.0828" width="0" layer="51"/>
<wire x1="-1.397" y1="2.0828" x2="-1.397" y2="2.0066" width="0" layer="51"/>
<wire x1="-2.0066" y1="1.0922" x2="-2.0066" y2="1.397" width="0" layer="51"/>
<wire x1="-2.0066" y1="1.397" x2="-2.0828" y2="1.397" width="0" layer="51"/>
<wire x1="-2.0828" y1="1.397" x2="-2.0828" y2="1.0922" width="0" layer="51"/>
<wire x1="-2.0828" y1="1.0922" x2="-2.0066" y2="1.0922" width="0" layer="51"/>
<wire x1="-2.0066" y1="0.6096" x2="-2.0066" y2="0.889" width="0" layer="51"/>
<wire x1="-2.0066" y1="0.889" x2="-2.0828" y2="0.889" width="0" layer="51"/>
<wire x1="-2.0828" y1="0.889" x2="-2.0828" y2="0.6096" width="0" layer="51"/>
<wire x1="-2.0828" y1="0.6096" x2="-2.0066" y2="0.6096" width="0" layer="51"/>
<wire x1="-2.0066" y1="0.1016" x2="-2.0066" y2="0.4064" width="0" layer="51"/>
<wire x1="-2.0066" y1="0.4064" x2="-2.0828" y2="0.4064" width="0" layer="51"/>
<wire x1="-2.0828" y1="0.4064" x2="-2.0828" y2="0.1016" width="0" layer="51"/>
<wire x1="-2.0828" y1="0.1016" x2="-2.0066" y2="0.1016" width="0" layer="51"/>
<wire x1="-2.0066" y1="-0.4064" x2="-2.0066" y2="-0.1016" width="0" layer="51"/>
<wire x1="-2.0066" y1="-0.1016" x2="-2.0828" y2="-0.1016" width="0" layer="51"/>
<wire x1="-2.0828" y1="-0.1016" x2="-2.0828" y2="-0.4064" width="0" layer="51"/>
<wire x1="-2.0828" y1="-0.4064" x2="-2.0066" y2="-0.4064" width="0" layer="51"/>
<wire x1="-2.0066" y1="-0.889" x2="-2.0066" y2="-0.6096" width="0" layer="51"/>
<wire x1="-2.0066" y1="-0.6096" x2="-2.0828" y2="-0.6096" width="0" layer="51"/>
<wire x1="-2.0828" y1="-0.6096" x2="-2.0828" y2="-0.889" width="0" layer="51"/>
<wire x1="-2.0828" y1="-0.889" x2="-2.0066" y2="-0.889" width="0" layer="51"/>
<wire x1="-2.0066" y1="-1.397" x2="-2.0066" y2="-1.0922" width="0" layer="51"/>
<wire x1="-2.0066" y1="-1.0922" x2="-2.0828" y2="-1.0922" width="0" layer="51"/>
<wire x1="-2.0828" y1="-1.0922" x2="-2.0828" y2="-1.397" width="0" layer="51"/>
<wire x1="-2.0828" y1="-1.397" x2="-2.0066" y2="-1.397" width="0" layer="51"/>
<wire x1="-1.0922" y1="-2.0066" x2="-1.397" y2="-2.0066" width="0" layer="51"/>
<wire x1="-1.397" y1="-2.0066" x2="-1.397" y2="-2.0828" width="0" layer="51"/>
<wire x1="-1.397" y1="-2.0828" x2="-1.0922" y2="-2.0828" width="0" layer="51"/>
<wire x1="-1.0922" y1="-2.0828" x2="-1.0922" y2="-2.0066" width="0" layer="51"/>
<wire x1="-0.6096" y1="-2.0066" x2="-0.889" y2="-2.0066" width="0" layer="51"/>
<wire x1="-0.889" y1="-2.0066" x2="-0.889" y2="-2.0828" width="0" layer="51"/>
<wire x1="-0.889" y1="-2.0828" x2="-0.6096" y2="-2.0828" width="0" layer="51"/>
<wire x1="-0.6096" y1="-2.0828" x2="-0.6096" y2="-2.0066" width="0" layer="51"/>
<wire x1="-0.1016" y1="-2.0066" x2="-0.4064" y2="-2.0066" width="0" layer="51"/>
<wire x1="-0.4064" y1="-2.0066" x2="-0.4064" y2="-2.0828" width="0" layer="51"/>
<wire x1="-0.4064" y1="-2.0828" x2="-0.1016" y2="-2.0828" width="0" layer="51"/>
<wire x1="-0.1016" y1="-2.0828" x2="-0.1016" y2="-2.0066" width="0" layer="51"/>
<wire x1="0.4064" y1="-2.0066" x2="0.1016" y2="-2.0066" width="0" layer="51"/>
<wire x1="0.1016" y1="-2.0066" x2="0.1016" y2="-2.0828" width="0" layer="51"/>
<wire x1="0.1016" y1="-2.0828" x2="0.4064" y2="-2.0828" width="0" layer="51"/>
<wire x1="0.4064" y1="-2.0828" x2="0.4064" y2="-2.0066" width="0" layer="51"/>
<wire x1="0.889" y1="-2.0066" x2="0.6096" y2="-2.0066" width="0" layer="51"/>
<wire x1="0.6096" y1="-2.0066" x2="0.6096" y2="-2.0828" width="0" layer="51"/>
<wire x1="0.6096" y1="-2.0828" x2="0.889" y2="-2.0828" width="0" layer="51"/>
<wire x1="0.889" y1="-2.0828" x2="0.889" y2="-2.0066" width="0" layer="51"/>
<wire x1="1.397" y1="-2.0066" x2="1.0922" y2="-2.0066" width="0" layer="51"/>
<wire x1="1.0922" y1="-2.0066" x2="1.0922" y2="-2.0828" width="0" layer="51"/>
<wire x1="1.0922" y1="-2.0828" x2="1.397" y2="-2.0828" width="0" layer="51"/>
<wire x1="1.397" y1="-2.0828" x2="1.397" y2="-2.0066" width="0" layer="51"/>
<wire x1="2.0066" y1="-1.0922" x2="2.0066" y2="-1.397" width="0" layer="51"/>
<wire x1="2.0066" y1="-1.397" x2="2.0828" y2="-1.397" width="0" layer="51"/>
<wire x1="2.0828" y1="-1.397" x2="2.0828" y2="-1.0922" width="0" layer="51"/>
<wire x1="2.0828" y1="-1.0922" x2="2.0066" y2="-1.0922" width="0" layer="51"/>
<wire x1="2.0066" y1="-0.6096" x2="2.0066" y2="-0.889" width="0" layer="51"/>
<wire x1="2.0066" y1="-0.889" x2="2.0828" y2="-0.889" width="0" layer="51"/>
<wire x1="2.0828" y1="-0.889" x2="2.0828" y2="-0.6096" width="0" layer="51"/>
<wire x1="2.0828" y1="-0.6096" x2="2.0066" y2="-0.6096" width="0" layer="51"/>
<wire x1="2.0066" y1="-0.1016" x2="2.0066" y2="-0.4064" width="0" layer="51"/>
<wire x1="2.0066" y1="-0.4064" x2="2.0828" y2="-0.4064" width="0" layer="51"/>
<wire x1="2.0828" y1="-0.4064" x2="2.0828" y2="-0.1016" width="0" layer="51"/>
<wire x1="2.0828" y1="-0.1016" x2="2.0066" y2="-0.1016" width="0" layer="51"/>
<wire x1="2.0066" y1="0.4064" x2="2.0066" y2="0.1016" width="0" layer="51"/>
<wire x1="2.0066" y1="0.1016" x2="2.0828" y2="0.1016" width="0" layer="51"/>
<wire x1="2.0828" y1="0.1016" x2="2.0828" y2="0.4064" width="0" layer="51"/>
<wire x1="2.0828" y1="0.4064" x2="2.0066" y2="0.4064" width="0" layer="51"/>
<wire x1="2.0066" y1="0.889" x2="2.0066" y2="0.6096" width="0" layer="51"/>
<wire x1="2.0066" y1="0.6096" x2="2.0828" y2="0.6096" width="0" layer="51"/>
<wire x1="2.0828" y1="0.6096" x2="2.0828" y2="0.889" width="0" layer="51"/>
<wire x1="2.0828" y1="0.889" x2="2.0066" y2="0.889" width="0" layer="51"/>
<wire x1="2.0066" y1="1.397" x2="2.0066" y2="1.0922" width="0" layer="51"/>
<wire x1="2.0066" y1="1.0922" x2="2.0828" y2="1.0922" width="0" layer="51"/>
<wire x1="2.0828" y1="1.0922" x2="2.0828" y2="1.397" width="0" layer="51"/>
<wire x1="2.0828" y1="1.397" x2="2.0066" y2="1.397" width="0" layer="51"/>
<wire x1="-2.0066" y1="-2.0066" x2="2.0066" y2="-2.0066" width="0" layer="51"/>
<wire x1="2.0066" y1="-2.0066" x2="2.0066" y2="2.0066" width="0" layer="51"/>
<wire x1="2.0066" y1="2.0066" x2="-2.0066" y2="2.0066" width="0" layer="51"/>
<wire x1="-2.0066" y1="2.0066" x2="-2.0066" y2="-2.0066" width="0" layer="51"/>
<text x="-3.5814" y="1.2446" size="1.27" layer="51" ratio="6" rot="SR0">*</text>
<text x="-3.4544" y="-6.477" size="2.0828" layer="27" ratio="10" rot="SR0">&gt;VALUE</text>
</package>
<package name="QFN50P500X500X90-33N">
<wire x1="3.175" y1="-0.2794" x2="4.191" y2="-0.2794" width="0.1524" layer="21"/>
<wire x1="-0.7366" y1="3.2004" x2="-0.7366" y2="4.2418" width="0.1524" layer="21"/>
<wire x1="-1.2192" y1="-3.2004" x2="-1.2192" y2="-4.2164" width="0.1524" layer="21"/>
</package>
<package name="SOP65P640X120-24N">
<wire x1="-3.9624" y1="-2.2606" x2="-5.0038" y2="-2.2606" width="0.1524" layer="21"/>
<wire x1="4.0132" y1="0.9652" x2="5.0292" y2="0.9652" width="0.1524" layer="21"/>
</package>
<package name="QFN50P300X300X75-17N">
<smd name="1" x="-1.4478" y="0.762" dx="0.254" dy="0.7112" layer="1" rot="R270"/>
<smd name="2" x="-1.4478" y="0.254" dx="0.254" dy="0.7112" layer="1" rot="R270"/>
<smd name="3" x="-1.4478" y="-0.254" dx="0.254" dy="0.7112" layer="1" rot="R270"/>
<smd name="4" x="-1.4478" y="-0.762" dx="0.254" dy="0.7112" layer="1" rot="R270"/>
<smd name="5" x="-0.762" y="-1.4478" dx="0.254" dy="0.7112" layer="1" rot="R180"/>
<smd name="6" x="-0.254" y="-1.4478" dx="0.254" dy="0.7112" layer="1" rot="R180"/>
<smd name="7" x="0.254" y="-1.4478" dx="0.254" dy="0.7112" layer="1" rot="R180"/>
<smd name="8" x="0.762" y="-1.4478" dx="0.254" dy="0.7112" layer="1" rot="R180"/>
<smd name="9" x="1.4478" y="-0.762" dx="0.254" dy="0.7112" layer="1" rot="R270"/>
<smd name="10" x="1.4478" y="-0.254" dx="0.254" dy="0.7112" layer="1" rot="R270"/>
<smd name="11" x="1.4478" y="0.254" dx="0.254" dy="0.7112" layer="1" rot="R270"/>
<smd name="12" x="1.4478" y="0.762" dx="0.254" dy="0.7112" layer="1" rot="R270"/>
<smd name="13" x="0.762" y="1.4478" dx="0.254" dy="0.7112" layer="1" rot="R180"/>
<smd name="14" x="0.254" y="1.4478" dx="0.254" dy="0.7112" layer="1" rot="R180"/>
<smd name="15" x="-0.254" y="1.4478" dx="0.254" dy="0.7112" layer="1" rot="R180"/>
<smd name="16" x="-0.762" y="1.4478" dx="0.254" dy="0.7112" layer="1" rot="R180"/>
<smd name="17" x="0" y="0" dx="1.7018" dy="1.7018" layer="1"/>
<wire x1="3.1496" y1="-0.1524" x2="2.1336" y2="-0.1524" width="0.1524" layer="21"/>
<wire x1="1.4986" y1="1.2192" x2="1.4986" y2="1.4986" width="0.1524" layer="21"/>
<wire x1="1.2192" y1="-1.4986" x2="1.4986" y2="-1.4986" width="0.1524" layer="21"/>
<wire x1="-1.2192" y1="1.4986" x2="-1.4986" y2="1.4986" width="0.1524" layer="21"/>
<wire x1="-1.4986" y1="-1.4986" x2="-1.2192" y2="-1.4986" width="0.1524" layer="21"/>
<wire x1="1.4986" y1="-1.4986" x2="1.4986" y2="-1.2192" width="0.1524" layer="21"/>
<wire x1="1.4986" y1="1.4986" x2="1.2192" y2="1.4986" width="0.1524" layer="21"/>
<wire x1="-1.4986" y1="1.4986" x2="-1.4986" y2="1.2192" width="0.1524" layer="21"/>
<wire x1="-1.4986" y1="-1.2192" x2="-1.4986" y2="-1.4986" width="0.1524" layer="21"/>
<text x="-3.0226" y="0.7366" size="1.27" layer="21" ratio="6" rot="SR0">*</text>
<wire x1="-1.4986" y1="0.2286" x2="-0.2286" y2="1.4986" width="0" layer="51"/>
<wire x1="0.8636" y1="1.4986" x2="0.635" y2="1.4986" width="0" layer="51"/>
<wire x1="0.381" y1="1.4986" x2="0.127" y2="1.4986" width="0" layer="51"/>
<wire x1="-0.127" y1="1.4986" x2="-0.381" y2="1.4986" width="0" layer="51"/>
<wire x1="-0.635" y1="1.4986" x2="-0.8636" y2="1.4986" width="0" layer="51"/>
<wire x1="-1.4986" y1="0.8636" x2="-1.4986" y2="0.635" width="0" layer="51"/>
<wire x1="-1.4986" y1="0.381" x2="-1.4986" y2="0.127" width="0" layer="51"/>
<wire x1="-1.4986" y1="-0.127" x2="-1.4986" y2="-0.381" width="0" layer="51"/>
<wire x1="-1.4986" y1="-0.635" x2="-1.4986" y2="-0.8636" width="0" layer="51"/>
<wire x1="-0.8636" y1="-1.4986" x2="-0.635" y2="-1.4986" width="0" layer="51"/>
<wire x1="-0.381" y1="-1.4986" x2="-0.127" y2="-1.4986" width="0" layer="51"/>
<wire x1="0.127" y1="-1.4986" x2="0.381" y2="-1.4986" width="0" layer="51"/>
<wire x1="0.635" y1="-1.4986" x2="0.8636" y2="-1.4986" width="0" layer="51"/>
<wire x1="1.4986" y1="-0.8636" x2="1.4986" y2="-0.635" width="0" layer="51"/>
<wire x1="1.4986" y1="-0.381" x2="1.4986" y2="-0.127" width="0" layer="51"/>
<wire x1="1.4986" y1="0.127" x2="1.4986" y2="0.381" width="0" layer="51"/>
<wire x1="1.4986" y1="0.635" x2="1.4986" y2="0.8636" width="0" layer="51"/>
<wire x1="-1.4986" y1="-1.4986" x2="1.4986" y2="-1.4986" width="0" layer="51"/>
<wire x1="1.4986" y1="-1.4986" x2="1.4986" y2="1.4986" width="0" layer="51"/>
<wire x1="1.4986" y1="1.4986" x2="-1.4986" y2="1.4986" width="0" layer="51"/>
<wire x1="-1.4986" y1="1.4986" x2="-1.4986" y2="-1.4986" width="0" layer="51"/>
<text x="-3.0226" y="0.7366" size="1.27" layer="51" ratio="6" rot="SR0">*</text>
<text x="-3.4544" y="3.937" size="2.0828" layer="25" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-3.4544" y="-5.08" size="2.0828" layer="27" ratio="10" rot="SR0">&gt;VALUE</text>
</package>
<package name="PLCC127P1753X1753X457-44N">
<smd name="1" x="0" y="8.001" dx="0.5842" dy="2.3876" layer="1" rot="R180"/>
<smd name="2" x="-1.27" y="8.001" dx="0.5842" dy="2.3876" layer="1" rot="R180"/>
<smd name="3" x="-2.54" y="8.001" dx="0.5842" dy="2.3876" layer="1" rot="R180"/>
<smd name="4" x="-3.81" y="8.001" dx="0.5842" dy="2.3876" layer="1" rot="R180"/>
<smd name="5" x="-5.08" y="8.001" dx="0.5842" dy="2.3876" layer="1" rot="R180"/>
<smd name="6" x="-6.35" y="8.001" dx="0.5842" dy="2.3876" layer="1" rot="R180"/>
<smd name="7" x="-8.001" y="6.35" dx="0.5842" dy="2.3876" layer="1" rot="R270"/>
<smd name="8" x="-8.001" y="5.08" dx="0.5842" dy="2.3876" layer="1" rot="R270"/>
<smd name="9" x="-8.001" y="3.81" dx="0.5842" dy="2.3876" layer="1" rot="R270"/>
<smd name="10" x="-8.001" y="2.54" dx="0.5842" dy="2.3876" layer="1" rot="R270"/>
<smd name="11" x="-8.001" y="1.27" dx="0.5842" dy="2.3876" layer="1" rot="R270"/>
<smd name="12" x="-8.001" y="0" dx="0.5842" dy="2.3876" layer="1" rot="R270"/>
<smd name="13" x="-8.001" y="-1.27" dx="0.5842" dy="2.3876" layer="1" rot="R270"/>
<smd name="14" x="-8.001" y="-2.54" dx="0.5842" dy="2.3876" layer="1" rot="R270"/>
<smd name="15" x="-8.001" y="-3.81" dx="0.5842" dy="2.3876" layer="1" rot="R270"/>
<smd name="16" x="-8.001" y="-5.08" dx="0.5842" dy="2.3876" layer="1" rot="R270"/>
<smd name="17" x="-8.001" y="-6.35" dx="0.5842" dy="2.3876" layer="1" rot="R270"/>
<smd name="18" x="-6.35" y="-8.001" dx="0.5842" dy="2.3876" layer="1" rot="R180"/>
<smd name="19" x="-5.08" y="-8.001" dx="0.5842" dy="2.3876" layer="1" rot="R180"/>
<smd name="20" x="-3.81" y="-8.001" dx="0.5842" dy="2.3876" layer="1" rot="R180"/>
<smd name="21" x="-2.54" y="-8.001" dx="0.5842" dy="2.3876" layer="1" rot="R180"/>
<smd name="22" x="-1.27" y="-8.001" dx="0.5842" dy="2.3876" layer="1" rot="R180"/>
<smd name="23" x="0" y="-8.001" dx="0.5842" dy="2.3876" layer="1" rot="R180"/>
<smd name="24" x="1.27" y="-8.001" dx="0.5842" dy="2.3876" layer="1" rot="R180"/>
<smd name="25" x="2.54" y="-8.001" dx="0.5842" dy="2.3876" layer="1" rot="R180"/>
<smd name="26" x="3.81" y="-8.001" dx="0.5842" dy="2.3876" layer="1" rot="R180"/>
<smd name="27" x="5.08" y="-8.001" dx="0.5842" dy="2.3876" layer="1" rot="R180"/>
<smd name="28" x="6.35" y="-8.001" dx="0.5842" dy="2.3876" layer="1" rot="R180"/>
<smd name="29" x="8.001" y="-6.35" dx="0.5842" dy="2.3876" layer="1" rot="R270"/>
<smd name="30" x="8.001" y="-5.08" dx="0.5842" dy="2.3876" layer="1" rot="R270"/>
<smd name="31" x="8.001" y="-3.81" dx="0.5842" dy="2.3876" layer="1" rot="R270"/>
<smd name="32" x="8.001" y="-2.54" dx="0.5842" dy="2.3876" layer="1" rot="R270"/>
<smd name="33" x="8.001" y="-1.27" dx="0.5842" dy="2.3876" layer="1" rot="R270"/>
<smd name="34" x="8.001" y="0" dx="0.5842" dy="2.3876" layer="1" rot="R270"/>
<smd name="35" x="8.001" y="1.27" dx="0.5842" dy="2.3876" layer="1" rot="R270"/>
<smd name="36" x="8.001" y="2.54" dx="0.5842" dy="2.3876" layer="1" rot="R270"/>
<smd name="37" x="8.001" y="3.81" dx="0.5842" dy="2.3876" layer="1" rot="R270"/>
<smd name="38" x="8.001" y="5.08" dx="0.5842" dy="2.3876" layer="1" rot="R270"/>
<smd name="39" x="8.001" y="6.35" dx="0.5842" dy="2.3876" layer="1" rot="R270"/>
<smd name="40" x="6.35" y="8.001" dx="0.5842" dy="2.3876" layer="1" rot="R180"/>
<smd name="41" x="5.08" y="8.001" dx="0.5842" dy="2.3876" layer="1" rot="R180"/>
<smd name="42" x="3.81" y="8.001" dx="0.5842" dy="2.3876" layer="1" rot="R180"/>
<smd name="43" x="2.54" y="8.001" dx="0.5842" dy="2.3876" layer="1" rot="R180"/>
<smd name="44" x="1.27" y="8.001" dx="0.5842" dy="2.3876" layer="1" rot="R180"/>
<wire x1="6.4008" y1="10.5664" x2="6.4008" y2="9.5504" width="0.1524" layer="21"/>
<wire x1="-9.5504" y1="2.6416" x2="-10.5664" y2="2.6416" width="0.1524" layer="21"/>
<wire x1="10.541" y1="-5.0038" x2="9.525" y2="-5.0038" width="0.1524" layer="21"/>
<wire x1="-3.8862" y1="-10.5664" x2="-3.8862" y2="-9.5504" width="0.1524" layer="21"/>
<wire x1="8.3058" y1="6.985" x2="8.3058" y2="8.3058" width="0.1524" layer="21"/>
<wire x1="-8.3058" y1="7.0358" x2="-7.0358" y2="8.3058" width="0.1524" layer="21"/>
<wire x1="-8.3058" y1="-8.3058" x2="-6.985" y2="-8.3058" width="0.1524" layer="21"/>
<wire x1="8.3058" y1="-8.3058" x2="8.3058" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="8.3058" y1="8.3058" x2="6.985" y2="8.3058" width="0.1524" layer="21"/>
<wire x1="-8.3058" y1="8.3058" x2="-8.3058" y2="6.985" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="8.3058" x2="-8.3058" y2="8.3058" width="0.1524" layer="21"/>
<wire x1="-8.3058" y1="-6.985" x2="-8.3058" y2="-8.3058" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-8.3058" x2="8.3058" y2="-8.3058" width="0.1524" layer="21"/>
<text x="-0.5842" y="9.6012" size="1.27" layer="21" ratio="6" rot="SR0">*</text>
<wire x1="-8.3058" y1="7.0358" x2="-7.0358" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="-6.604" y1="8.3058" x2="-6.096" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="-6.096" y1="8.3058" x2="-6.096" y2="8.8392" width="0.0508" layer="51"/>
<wire x1="-6.096" y1="8.8392" x2="-6.604" y2="8.8392" width="0.0508" layer="51"/>
<wire x1="-6.604" y1="8.8392" x2="-6.604" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="-5.334" y1="8.3058" x2="-4.826" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="-4.826" y1="8.3058" x2="-4.826" y2="8.8392" width="0.0508" layer="51"/>
<wire x1="-4.826" y1="8.8392" x2="-5.334" y2="8.8392" width="0.0508" layer="51"/>
<wire x1="-5.334" y1="8.8392" x2="-5.334" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="-4.064" y1="8.3058" x2="-3.556" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="-3.556" y1="8.3058" x2="-3.556" y2="8.8392" width="0.0508" layer="51"/>
<wire x1="-3.556" y1="8.8392" x2="-4.064" y2="8.8392" width="0.0508" layer="51"/>
<wire x1="-4.064" y1="8.8392" x2="-4.064" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="-2.794" y1="8.3058" x2="-2.286" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="-2.286" y1="8.3058" x2="-2.286" y2="8.8392" width="0.0508" layer="51"/>
<wire x1="-2.286" y1="8.8392" x2="-2.794" y2="8.8392" width="0.0508" layer="51"/>
<wire x1="-2.794" y1="8.8392" x2="-2.794" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="-1.524" y1="8.3058" x2="-1.016" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="-1.016" y1="8.3058" x2="-1.016" y2="8.8392" width="0.0508" layer="51"/>
<wire x1="-1.016" y1="8.8392" x2="-1.524" y2="8.8392" width="0.0508" layer="51"/>
<wire x1="-1.524" y1="8.8392" x2="-1.524" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="-0.254" y1="8.3058" x2="0.254" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="0.254" y1="8.3058" x2="0.254" y2="8.8392" width="0.0508" layer="51"/>
<wire x1="0.254" y1="8.8392" x2="-0.254" y2="8.8392" width="0.0508" layer="51"/>
<wire x1="-0.254" y1="8.8392" x2="-0.254" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="1.016" y1="8.3058" x2="1.524" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="1.524" y1="8.3058" x2="1.524" y2="8.8392" width="0.0508" layer="51"/>
<wire x1="1.524" y1="8.8392" x2="1.016" y2="8.8392" width="0.0508" layer="51"/>
<wire x1="1.016" y1="8.8392" x2="1.016" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="2.286" y1="8.3058" x2="2.794" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="2.794" y1="8.3058" x2="2.794" y2="8.8392" width="0.0508" layer="51"/>
<wire x1="2.794" y1="8.8392" x2="2.286" y2="8.8392" width="0.0508" layer="51"/>
<wire x1="2.286" y1="8.8392" x2="2.286" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="3.556" y1="8.3058" x2="4.064" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="4.064" y1="8.3058" x2="4.064" y2="8.8392" width="0.0508" layer="51"/>
<wire x1="4.064" y1="8.8392" x2="3.556" y2="8.8392" width="0.0508" layer="51"/>
<wire x1="3.556" y1="8.8392" x2="3.556" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="4.826" y1="8.3058" x2="5.334" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="5.334" y1="8.3058" x2="5.334" y2="8.8392" width="0.0508" layer="51"/>
<wire x1="5.334" y1="8.8392" x2="4.826" y2="8.8392" width="0.0508" layer="51"/>
<wire x1="4.826" y1="8.8392" x2="4.826" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="6.096" y1="8.3058" x2="6.604" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="6.604" y1="8.3058" x2="6.604" y2="8.8392" width="0.0508" layer="51"/>
<wire x1="6.604" y1="8.8392" x2="6.096" y2="8.8392" width="0.0508" layer="51"/>
<wire x1="6.096" y1="8.8392" x2="6.096" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="-8.3058" y1="6.096" x2="-8.3058" y2="6.604" width="0.0508" layer="51"/>
<wire x1="-8.3058" y1="6.604" x2="-8.8392" y2="6.604" width="0.0508" layer="51"/>
<wire x1="-8.8392" y1="6.604" x2="-8.8392" y2="6.096" width="0.0508" layer="51"/>
<wire x1="-8.8392" y1="6.096" x2="-8.3058" y2="6.096" width="0.0508" layer="51"/>
<wire x1="-8.3058" y1="4.826" x2="-8.3058" y2="5.334" width="0.0508" layer="51"/>
<wire x1="-8.3058" y1="5.334" x2="-8.8392" y2="5.334" width="0.0508" layer="51"/>
<wire x1="-8.8392" y1="5.334" x2="-8.8392" y2="4.826" width="0.0508" layer="51"/>
<wire x1="-8.8392" y1="4.826" x2="-8.3058" y2="4.826" width="0.0508" layer="51"/>
<wire x1="-8.3058" y1="3.556" x2="-8.3058" y2="4.064" width="0.0508" layer="51"/>
<wire x1="-8.3058" y1="4.064" x2="-8.8392" y2="4.064" width="0.0508" layer="51"/>
<wire x1="-8.8392" y1="4.064" x2="-8.8392" y2="3.556" width="0.0508" layer="51"/>
<wire x1="-8.8392" y1="3.556" x2="-8.3058" y2="3.556" width="0.0508" layer="51"/>
<wire x1="-8.3058" y1="2.286" x2="-8.3058" y2="2.794" width="0.0508" layer="51"/>
<wire x1="-8.3058" y1="2.794" x2="-8.8392" y2="2.794" width="0.0508" layer="51"/>
<wire x1="-8.8392" y1="2.794" x2="-8.8392" y2="2.286" width="0.0508" layer="51"/>
<wire x1="-8.8392" y1="2.286" x2="-8.3058" y2="2.286" width="0.0508" layer="51"/>
<wire x1="-8.3058" y1="1.016" x2="-8.3058" y2="1.524" width="0.0508" layer="51"/>
<wire x1="-8.3058" y1="1.524" x2="-8.8392" y2="1.524" width="0.0508" layer="51"/>
<wire x1="-8.8392" y1="1.524" x2="-8.8392" y2="1.016" width="0.0508" layer="51"/>
<wire x1="-8.8392" y1="1.016" x2="-8.3058" y2="1.016" width="0.0508" layer="51"/>
<wire x1="-8.3058" y1="-0.254" x2="-8.3058" y2="0.254" width="0.0508" layer="51"/>
<wire x1="-8.3058" y1="0.254" x2="-8.8392" y2="0.254" width="0.0508" layer="51"/>
<wire x1="-8.8392" y1="0.254" x2="-8.8392" y2="-0.254" width="0.0508" layer="51"/>
<wire x1="-8.8392" y1="-0.254" x2="-8.3058" y2="-0.254" width="0.0508" layer="51"/>
<wire x1="-8.3058" y1="-1.524" x2="-8.3058" y2="-1.016" width="0.0508" layer="51"/>
<wire x1="-8.3058" y1="-1.016" x2="-8.8392" y2="-1.016" width="0.0508" layer="51"/>
<wire x1="-8.8392" y1="-1.016" x2="-8.8392" y2="-1.524" width="0.0508" layer="51"/>
<wire x1="-8.8392" y1="-1.524" x2="-8.3058" y2="-1.524" width="0.0508" layer="51"/>
<wire x1="-8.3058" y1="-2.794" x2="-8.3058" y2="-2.286" width="0.0508" layer="51"/>
<wire x1="-8.3058" y1="-2.286" x2="-8.8392" y2="-2.286" width="0.0508" layer="51"/>
<wire x1="-8.8392" y1="-2.286" x2="-8.8392" y2="-2.794" width="0.0508" layer="51"/>
<wire x1="-8.8392" y1="-2.794" x2="-8.3058" y2="-2.794" width="0.0508" layer="51"/>
<wire x1="-8.3058" y1="-4.064" x2="-8.3058" y2="-3.556" width="0.0508" layer="51"/>
<wire x1="-8.3058" y1="-3.556" x2="-8.8392" y2="-3.556" width="0.0508" layer="51"/>
<wire x1="-8.8392" y1="-3.556" x2="-8.8392" y2="-4.064" width="0.0508" layer="51"/>
<wire x1="-8.8392" y1="-4.064" x2="-8.3058" y2="-4.064" width="0.0508" layer="51"/>
<wire x1="-8.3058" y1="-5.334" x2="-8.3058" y2="-4.826" width="0.0508" layer="51"/>
<wire x1="-8.3058" y1="-4.826" x2="-8.8392" y2="-4.826" width="0.0508" layer="51"/>
<wire x1="-8.8392" y1="-4.826" x2="-8.8392" y2="-5.334" width="0.0508" layer="51"/>
<wire x1="-8.8392" y1="-5.334" x2="-8.3058" y2="-5.334" width="0.0508" layer="51"/>
<wire x1="-8.3058" y1="-6.604" x2="-8.3058" y2="-6.096" width="0.0508" layer="51"/>
<wire x1="-8.3058" y1="-6.096" x2="-8.8392" y2="-6.096" width="0.0508" layer="51"/>
<wire x1="-8.8392" y1="-6.096" x2="-8.8392" y2="-6.604" width="0.0508" layer="51"/>
<wire x1="-8.8392" y1="-6.604" x2="-8.3058" y2="-6.604" width="0.0508" layer="51"/>
<wire x1="-6.096" y1="-8.3058" x2="-6.604" y2="-8.3058" width="0.0508" layer="51"/>
<wire x1="-6.604" y1="-8.3058" x2="-6.604" y2="-8.8392" width="0.0508" layer="51"/>
<wire x1="-6.604" y1="-8.8392" x2="-6.096" y2="-8.8392" width="0.0508" layer="51"/>
<wire x1="-6.096" y1="-8.8392" x2="-6.096" y2="-8.3058" width="0.0508" layer="51"/>
<wire x1="-4.826" y1="-8.3058" x2="-5.334" y2="-8.3058" width="0.0508" layer="51"/>
<wire x1="-5.334" y1="-8.3058" x2="-5.334" y2="-8.8392" width="0.0508" layer="51"/>
<wire x1="-5.334" y1="-8.8392" x2="-4.826" y2="-8.8392" width="0.0508" layer="51"/>
<wire x1="-4.826" y1="-8.8392" x2="-4.826" y2="-8.3058" width="0.0508" layer="51"/>
<wire x1="-3.556" y1="-8.3058" x2="-4.064" y2="-8.3058" width="0.0508" layer="51"/>
<wire x1="-4.064" y1="-8.3058" x2="-4.064" y2="-8.8392" width="0.0508" layer="51"/>
<wire x1="-4.064" y1="-8.8392" x2="-3.556" y2="-8.8392" width="0.0508" layer="51"/>
<wire x1="-3.556" y1="-8.8392" x2="-3.556" y2="-8.3058" width="0.0508" layer="51"/>
<wire x1="-2.286" y1="-8.3058" x2="-2.794" y2="-8.3058" width="0.0508" layer="51"/>
<wire x1="-2.794" y1="-8.3058" x2="-2.794" y2="-8.8392" width="0.0508" layer="51"/>
<wire x1="-2.794" y1="-8.8392" x2="-2.286" y2="-8.8392" width="0.0508" layer="51"/>
<wire x1="-2.286" y1="-8.8392" x2="-2.286" y2="-8.3058" width="0.0508" layer="51"/>
<wire x1="-1.016" y1="-8.3058" x2="-1.524" y2="-8.3058" width="0.0508" layer="51"/>
<wire x1="-1.524" y1="-8.3058" x2="-1.524" y2="-8.8392" width="0.0508" layer="51"/>
<wire x1="-1.524" y1="-8.8392" x2="-1.016" y2="-8.8392" width="0.0508" layer="51"/>
<wire x1="-1.016" y1="-8.8392" x2="-1.016" y2="-8.3058" width="0.0508" layer="51"/>
<wire x1="0.254" y1="-8.3058" x2="-0.254" y2="-8.3058" width="0.0508" layer="51"/>
<wire x1="-0.254" y1="-8.3058" x2="-0.254" y2="-8.8392" width="0.0508" layer="51"/>
<wire x1="-0.254" y1="-8.8392" x2="0.254" y2="-8.8392" width="0.0508" layer="51"/>
<wire x1="0.254" y1="-8.8392" x2="0.254" y2="-8.3058" width="0.0508" layer="51"/>
<wire x1="1.524" y1="-8.3058" x2="1.016" y2="-8.3058" width="0.0508" layer="51"/>
<wire x1="1.016" y1="-8.3058" x2="1.016" y2="-8.8392" width="0.0508" layer="51"/>
<wire x1="1.016" y1="-8.8392" x2="1.524" y2="-8.8392" width="0.0508" layer="51"/>
<wire x1="1.524" y1="-8.8392" x2="1.524" y2="-8.3058" width="0.0508" layer="51"/>
<wire x1="2.794" y1="-8.3058" x2="2.286" y2="-8.3058" width="0.0508" layer="51"/>
<wire x1="2.286" y1="-8.3058" x2="2.286" y2="-8.8392" width="0.0508" layer="51"/>
<wire x1="2.286" y1="-8.8392" x2="2.794" y2="-8.8392" width="0.0508" layer="51"/>
<wire x1="2.794" y1="-8.8392" x2="2.794" y2="-8.3058" width="0.0508" layer="51"/>
<wire x1="4.064" y1="-8.3058" x2="3.556" y2="-8.3058" width="0.0508" layer="51"/>
<wire x1="3.556" y1="-8.3058" x2="3.556" y2="-8.8392" width="0.0508" layer="51"/>
<wire x1="3.556" y1="-8.8392" x2="4.064" y2="-8.8392" width="0.0508" layer="51"/>
<wire x1="4.064" y1="-8.8392" x2="4.064" y2="-8.3058" width="0.0508" layer="51"/>
<wire x1="5.334" y1="-8.3058" x2="4.826" y2="-8.3058" width="0.0508" layer="51"/>
<wire x1="4.826" y1="-8.3058" x2="4.826" y2="-8.8392" width="0.0508" layer="51"/>
<wire x1="4.826" y1="-8.8392" x2="5.334" y2="-8.8392" width="0.0508" layer="51"/>
<wire x1="5.334" y1="-8.8392" x2="5.334" y2="-8.3058" width="0.0508" layer="51"/>
<wire x1="6.604" y1="-8.3058" x2="6.096" y2="-8.3058" width="0.0508" layer="51"/>
<wire x1="6.096" y1="-8.3058" x2="6.096" y2="-8.8392" width="0.0508" layer="51"/>
<wire x1="6.096" y1="-8.8392" x2="6.604" y2="-8.8392" width="0.0508" layer="51"/>
<wire x1="6.604" y1="-8.8392" x2="6.604" y2="-8.3058" width="0.0508" layer="51"/>
<wire x1="8.3058" y1="-6.096" x2="8.3058" y2="-6.604" width="0.0508" layer="51"/>
<wire x1="8.3058" y1="-6.604" x2="8.8392" y2="-6.604" width="0.0508" layer="51"/>
<wire x1="8.8392" y1="-6.604" x2="8.8392" y2="-6.096" width="0.0508" layer="51"/>
<wire x1="8.8392" y1="-6.096" x2="8.3058" y2="-6.096" width="0.0508" layer="51"/>
<wire x1="8.3058" y1="-4.826" x2="8.3058" y2="-5.334" width="0.0508" layer="51"/>
<wire x1="8.3058" y1="-5.334" x2="8.8392" y2="-5.334" width="0.0508" layer="51"/>
<wire x1="8.8392" y1="-5.334" x2="8.8392" y2="-4.826" width="0.0508" layer="51"/>
<wire x1="8.8392" y1="-4.826" x2="8.3058" y2="-4.826" width="0.0508" layer="51"/>
<wire x1="8.3058" y1="-3.556" x2="8.3058" y2="-4.064" width="0.0508" layer="51"/>
<wire x1="8.3058" y1="-4.064" x2="8.8392" y2="-4.064" width="0.0508" layer="51"/>
<wire x1="8.8392" y1="-4.064" x2="8.8392" y2="-3.556" width="0.0508" layer="51"/>
<wire x1="8.8392" y1="-3.556" x2="8.3058" y2="-3.556" width="0.0508" layer="51"/>
<wire x1="8.3058" y1="-2.286" x2="8.3058" y2="-2.794" width="0.0508" layer="51"/>
<wire x1="8.3058" y1="-2.794" x2="8.8392" y2="-2.794" width="0.0508" layer="51"/>
<wire x1="8.8392" y1="-2.794" x2="8.8392" y2="-2.286" width="0.0508" layer="51"/>
<wire x1="8.8392" y1="-2.286" x2="8.3058" y2="-2.286" width="0.0508" layer="51"/>
<wire x1="8.3058" y1="-1.016" x2="8.3058" y2="-1.524" width="0.0508" layer="51"/>
<wire x1="8.3058" y1="-1.524" x2="8.8392" y2="-1.524" width="0.0508" layer="51"/>
<wire x1="8.8392" y1="-1.524" x2="8.8392" y2="-1.016" width="0.0508" layer="51"/>
<wire x1="8.8392" y1="-1.016" x2="8.3058" y2="-1.016" width="0.0508" layer="51"/>
<wire x1="8.3058" y1="0.254" x2="8.3058" y2="-0.254" width="0.0508" layer="51"/>
<wire x1="8.3058" y1="-0.254" x2="8.8392" y2="-0.254" width="0.0508" layer="51"/>
<wire x1="8.8392" y1="-0.254" x2="8.8392" y2="0.254" width="0.0508" layer="51"/>
<wire x1="8.8392" y1="0.254" x2="8.3058" y2="0.254" width="0.0508" layer="51"/>
<wire x1="8.3058" y1="1.524" x2="8.3058" y2="1.016" width="0.0508" layer="51"/>
<wire x1="8.3058" y1="1.016" x2="8.8392" y2="1.016" width="0.0508" layer="51"/>
<wire x1="8.8392" y1="1.016" x2="8.8392" y2="1.524" width="0.0508" layer="51"/>
<wire x1="8.8392" y1="1.524" x2="8.3058" y2="1.524" width="0.0508" layer="51"/>
<wire x1="8.3058" y1="2.794" x2="8.3058" y2="2.286" width="0.0508" layer="51"/>
<wire x1="8.3058" y1="2.286" x2="8.8392" y2="2.286" width="0.0508" layer="51"/>
<wire x1="8.8392" y1="2.286" x2="8.8392" y2="2.794" width="0.0508" layer="51"/>
<wire x1="8.8392" y1="2.794" x2="8.3058" y2="2.794" width="0.0508" layer="51"/>
<wire x1="8.3058" y1="4.064" x2="8.3058" y2="3.556" width="0.0508" layer="51"/>
<wire x1="8.3058" y1="3.556" x2="8.8392" y2="3.556" width="0.0508" layer="51"/>
<wire x1="8.8392" y1="3.556" x2="8.8392" y2="4.064" width="0.0508" layer="51"/>
<wire x1="8.8392" y1="4.064" x2="8.3058" y2="4.064" width="0.0508" layer="51"/>
<wire x1="8.3058" y1="5.334" x2="8.3058" y2="4.826" width="0.0508" layer="51"/>
<wire x1="8.3058" y1="4.826" x2="8.8392" y2="4.826" width="0.0508" layer="51"/>
<wire x1="8.8392" y1="4.826" x2="8.8392" y2="5.334" width="0.0508" layer="51"/>
<wire x1="8.8392" y1="5.334" x2="8.3058" y2="5.334" width="0.0508" layer="51"/>
<wire x1="8.3058" y1="6.604" x2="8.3058" y2="6.096" width="0.0508" layer="51"/>
<wire x1="8.3058" y1="6.096" x2="8.8392" y2="6.096" width="0.0508" layer="51"/>
<wire x1="8.8392" y1="6.096" x2="8.8392" y2="6.604" width="0.0508" layer="51"/>
<wire x1="8.8392" y1="6.604" x2="8.3058" y2="6.604" width="0.0508" layer="51"/>
<wire x1="-8.3058" y1="-8.3058" x2="8.3058" y2="-8.3058" width="0.0508" layer="51"/>
<wire x1="8.3058" y1="-8.3058" x2="8.3058" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="8.3058" y1="8.3058" x2="-8.3058" y2="8.3058" width="0.0508" layer="51"/>
<wire x1="-8.3058" y1="8.3058" x2="-8.3058" y2="-8.3058" width="0.0508" layer="51"/>
<text x="-0.5842" y="9.6012" size="1.27" layer="51" ratio="6" rot="SR0">*</text>
<text x="-3.4544" y="10.16" size="2.0828" layer="25" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-3.4544" y="-13.335" size="2.0828" layer="27" ratio="10" rot="SR0">&gt;VALUE</text>
</package>
<package name="SOIC127P1032X265-20N">
<smd name="1" x="-4.699" y="5.715" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="2" x="-4.699" y="4.445" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="3" x="-4.699" y="3.175" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="4" x="-4.699" y="1.905" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="5" x="-4.699" y="0.635" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="6" x="-4.699" y="-0.635" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="7" x="-4.699" y="-1.905" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="8" x="-4.699" y="-3.175" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="9" x="-4.699" y="-4.445" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="10" x="-4.699" y="-5.715" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="11" x="4.699" y="-5.715" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="12" x="4.699" y="-4.445" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="13" x="4.699" y="-3.175" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="14" x="4.699" y="-1.905" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="15" x="4.699" y="-0.635" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="16" x="4.699" y="0.635" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="17" x="4.699" y="1.905" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="18" x="4.699" y="3.175" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="19" x="4.699" y="4.445" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="20" x="4.699" y="5.715" dx="1.9812" dy="0.5588" layer="1"/>
<wire x1="3.81" y1="6.3246" x2="3.81" y2="6.5024" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-6.3246" x2="-3.81" y2="-6.5024" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-6.5024" x2="3.81" y2="-6.5024" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-6.5024" x2="3.81" y2="-6.3246" width="0.1524" layer="21"/>
<wire x1="3.81" y1="6.5024" x2="0.3048" y2="6.5024" width="0.1524" layer="21"/>
<wire x1="0.3048" y1="6.5024" x2="-0.3048" y2="6.5024" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="6.5024" x2="-3.81" y2="6.5024" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="6.5024" x2="-3.81" y2="6.3246" width="0.1524" layer="21"/>
<wire x1="0.3048" y1="6.5024" x2="-0.3048" y2="6.5024" width="0.1524" layer="21" curve="-180"/>
<text x="-5.5118" y="6.1468" size="1.27" layer="21" ratio="6" rot="SR0">*</text>
<wire x1="-3.81" y1="5.461" x2="-3.81" y2="5.969" width="0" layer="51"/>
<wire x1="-3.81" y1="5.969" x2="-5.334" y2="5.969" width="0" layer="51"/>
<wire x1="-5.334" y1="5.969" x2="-5.334" y2="5.461" width="0" layer="51"/>
<wire x1="-5.334" y1="5.461" x2="-3.81" y2="5.461" width="0" layer="51"/>
<wire x1="-3.81" y1="4.191" x2="-3.81" y2="4.699" width="0" layer="51"/>
<wire x1="-3.81" y1="4.699" x2="-5.334" y2="4.699" width="0" layer="51"/>
<wire x1="-5.334" y1="4.699" x2="-5.334" y2="4.191" width="0" layer="51"/>
<wire x1="-5.334" y1="4.191" x2="-3.81" y2="4.191" width="0" layer="51"/>
<wire x1="-3.81" y1="2.921" x2="-3.81" y2="3.429" width="0" layer="51"/>
<wire x1="-3.81" y1="3.429" x2="-5.334" y2="3.429" width="0" layer="51"/>
<wire x1="-5.334" y1="3.429" x2="-5.334" y2="2.921" width="0" layer="51"/>
<wire x1="-5.334" y1="2.921" x2="-3.81" y2="2.921" width="0" layer="51"/>
<wire x1="-3.81" y1="1.651" x2="-3.81" y2="2.159" width="0" layer="51"/>
<wire x1="-3.81" y1="2.159" x2="-5.334" y2="2.159" width="0" layer="51"/>
<wire x1="-5.334" y1="2.159" x2="-5.334" y2="1.651" width="0" layer="51"/>
<wire x1="-5.334" y1="1.651" x2="-3.81" y2="1.651" width="0" layer="51"/>
<wire x1="-3.81" y1="0.381" x2="-3.81" y2="0.889" width="0" layer="51"/>
<wire x1="-3.81" y1="0.889" x2="-5.334" y2="0.889" width="0" layer="51"/>
<wire x1="-5.334" y1="0.889" x2="-5.334" y2="0.381" width="0" layer="51"/>
<wire x1="-5.334" y1="0.381" x2="-3.81" y2="0.381" width="0" layer="51"/>
<wire x1="-3.81" y1="-0.889" x2="-3.81" y2="-0.381" width="0" layer="51"/>
<wire x1="-3.81" y1="-0.381" x2="-5.334" y2="-0.381" width="0" layer="51"/>
<wire x1="-5.334" y1="-0.381" x2="-5.334" y2="-0.889" width="0" layer="51"/>
<wire x1="-5.334" y1="-0.889" x2="-3.81" y2="-0.889" width="0" layer="51"/>
<wire x1="-3.81" y1="-2.159" x2="-3.81" y2="-1.651" width="0" layer="51"/>
<wire x1="-3.81" y1="-1.651" x2="-5.334" y2="-1.651" width="0" layer="51"/>
<wire x1="-5.334" y1="-1.651" x2="-5.334" y2="-2.159" width="0" layer="51"/>
<wire x1="-5.334" y1="-2.159" x2="-3.81" y2="-2.159" width="0" layer="51"/>
<wire x1="-3.81" y1="-3.429" x2="-3.81" y2="-2.921" width="0" layer="51"/>
<wire x1="-3.81" y1="-2.921" x2="-5.334" y2="-2.921" width="0" layer="51"/>
<wire x1="-5.334" y1="-2.921" x2="-5.334" y2="-3.429" width="0" layer="51"/>
<wire x1="-5.334" y1="-3.429" x2="-3.81" y2="-3.429" width="0" layer="51"/>
<wire x1="-3.81" y1="-4.699" x2="-3.81" y2="-4.191" width="0" layer="51"/>
<wire x1="-3.81" y1="-4.191" x2="-5.334" y2="-4.191" width="0" layer="51"/>
<wire x1="-5.334" y1="-4.191" x2="-5.334" y2="-4.699" width="0" layer="51"/>
<wire x1="-5.334" y1="-4.699" x2="-3.81" y2="-4.699" width="0" layer="51"/>
<wire x1="-3.81" y1="-5.969" x2="-3.81" y2="-5.461" width="0" layer="51"/>
<wire x1="-3.81" y1="-5.461" x2="-5.334" y2="-5.461" width="0" layer="51"/>
<wire x1="-5.334" y1="-5.461" x2="-5.334" y2="-5.969" width="0" layer="51"/>
<wire x1="-5.334" y1="-5.969" x2="-3.81" y2="-5.969" width="0" layer="51"/>
<wire x1="3.81" y1="-5.461" x2="3.81" y2="-5.969" width="0" layer="51"/>
<wire x1="3.81" y1="-5.969" x2="5.334" y2="-5.969" width="0" layer="51"/>
<wire x1="5.334" y1="-5.969" x2="5.334" y2="-5.461" width="0" layer="51"/>
<wire x1="5.334" y1="-5.461" x2="3.81" y2="-5.461" width="0" layer="51"/>
<wire x1="3.81" y1="-4.191" x2="3.81" y2="-4.699" width="0" layer="51"/>
<wire x1="3.81" y1="-4.699" x2="5.334" y2="-4.699" width="0" layer="51"/>
<wire x1="5.334" y1="-4.699" x2="5.334" y2="-4.191" width="0" layer="51"/>
<wire x1="5.334" y1="-4.191" x2="3.81" y2="-4.191" width="0" layer="51"/>
<wire x1="3.81" y1="-2.921" x2="3.81" y2="-3.429" width="0" layer="51"/>
<wire x1="3.81" y1="-3.429" x2="5.334" y2="-3.429" width="0" layer="51"/>
<wire x1="5.334" y1="-3.429" x2="5.334" y2="-2.921" width="0" layer="51"/>
<wire x1="5.334" y1="-2.921" x2="3.81" y2="-2.921" width="0" layer="51"/>
<wire x1="3.81" y1="-1.651" x2="3.81" y2="-2.159" width="0" layer="51"/>
<wire x1="3.81" y1="-2.159" x2="5.334" y2="-2.159" width="0" layer="51"/>
<wire x1="5.334" y1="-2.159" x2="5.334" y2="-1.651" width="0" layer="51"/>
<wire x1="5.334" y1="-1.651" x2="3.81" y2="-1.651" width="0" layer="51"/>
<wire x1="3.81" y1="-0.381" x2="3.81" y2="-0.889" width="0" layer="51"/>
<wire x1="3.81" y1="-0.889" x2="5.334" y2="-0.889" width="0" layer="51"/>
<wire x1="5.334" y1="-0.889" x2="5.334" y2="-0.381" width="0" layer="51"/>
<wire x1="5.334" y1="-0.381" x2="3.81" y2="-0.381" width="0" layer="51"/>
<wire x1="3.81" y1="0.889" x2="3.81" y2="0.381" width="0" layer="51"/>
<wire x1="3.81" y1="0.381" x2="5.334" y2="0.381" width="0" layer="51"/>
<wire x1="5.334" y1="0.381" x2="5.334" y2="0.889" width="0" layer="51"/>
<wire x1="5.334" y1="0.889" x2="3.81" y2="0.889" width="0" layer="51"/>
<wire x1="3.81" y1="2.159" x2="3.81" y2="1.651" width="0" layer="51"/>
<wire x1="3.81" y1="1.651" x2="5.334" y2="1.651" width="0" layer="51"/>
<wire x1="5.334" y1="1.651" x2="5.334" y2="2.159" width="0" layer="51"/>
<wire x1="5.334" y1="2.159" x2="3.81" y2="2.159" width="0" layer="51"/>
<wire x1="3.81" y1="3.429" x2="3.81" y2="2.921" width="0" layer="51"/>
<wire x1="3.81" y1="2.921" x2="5.334" y2="2.921" width="0" layer="51"/>
<wire x1="5.334" y1="2.921" x2="5.334" y2="3.429" width="0" layer="51"/>
<wire x1="5.334" y1="3.429" x2="3.81" y2="3.429" width="0" layer="51"/>
<wire x1="3.81" y1="4.699" x2="3.81" y2="4.191" width="0" layer="51"/>
<wire x1="3.81" y1="4.191" x2="5.334" y2="4.191" width="0" layer="51"/>
<wire x1="5.334" y1="4.191" x2="5.334" y2="4.699" width="0" layer="51"/>
<wire x1="5.334" y1="4.699" x2="3.81" y2="4.699" width="0" layer="51"/>
<wire x1="3.81" y1="5.969" x2="3.81" y2="5.461" width="0" layer="51"/>
<wire x1="3.81" y1="5.461" x2="5.334" y2="5.461" width="0" layer="51"/>
<wire x1="5.334" y1="5.461" x2="5.334" y2="5.969" width="0" layer="51"/>
<wire x1="5.334" y1="5.969" x2="3.81" y2="5.969" width="0" layer="51"/>
<wire x1="-3.81" y1="-6.5024" x2="3.81" y2="-6.5024" width="0" layer="51"/>
<wire x1="3.81" y1="-6.5024" x2="3.81" y2="6.5024" width="0" layer="51"/>
<wire x1="3.81" y1="6.5024" x2="0.3048" y2="6.5024" width="0" layer="51"/>
<wire x1="0.3048" y1="6.5024" x2="-0.3048" y2="6.5024" width="0" layer="51"/>
<wire x1="-0.3048" y1="6.5024" x2="-3.81" y2="6.5024" width="0" layer="51"/>
<wire x1="-3.81" y1="6.5024" x2="-3.81" y2="-6.5024" width="0" layer="51"/>
<wire x1="0.3048" y1="6.5024" x2="-0.3048" y2="6.5024" width="0" layer="51" curve="-180"/>
<text x="-5.5118" y="6.1468" size="1.27" layer="51" ratio="6" rot="SR0">*</text>
<text x="-3.4544" y="8.255" size="2.0828" layer="25" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-3.4544" y="-10.16" size="2.0828" layer="27" ratio="10" rot="SR0">&gt;VALUE</text>
</package>
<package name="DFN200X200X60-9N">
<smd name="1" x="-1.0414" y="0.762" dx="0.6858" dy="0.3048" layer="1"/>
<smd name="2" x="-1.0414" y="0.254" dx="0.6858" dy="0.3048" layer="1"/>
<smd name="3" x="-1.0414" y="-0.254" dx="0.6858" dy="0.3048" layer="1"/>
<smd name="4" x="-1.0414" y="-0.762" dx="0.6858" dy="0.3048" layer="1"/>
<smd name="5" x="1.0414" y="-0.762" dx="0.6858" dy="0.3048" layer="1"/>
<smd name="6" x="1.0414" y="-0.254" dx="0.6858" dy="0.3048" layer="1"/>
<smd name="7" x="1.0414" y="0.254" dx="0.6858" dy="0.3048" layer="1"/>
<smd name="8" x="1.0414" y="0.762" dx="0.6858" dy="0.3048" layer="1"/>
<smd name="9" x="0" y="0" dx="0.889" dy="1.6002" layer="1"/>
<wire x1="-0.9906" y1="-0.9906" x2="0.9906" y2="-0.9906" width="0" layer="51"/>
<wire x1="0.9906" y1="-0.9906" x2="0.9906" y2="0.9906" width="0" layer="51"/>
<wire x1="0.9906" y1="0.9906" x2="0.3048" y2="0.9906" width="0" layer="51"/>
<wire x1="0.3048" y1="0.9906" x2="-0.3048" y2="0.9906" width="0" layer="51"/>
<wire x1="-0.3048" y1="0.9906" x2="-0.9906" y2="0.9906" width="0" layer="51"/>
<wire x1="-0.9906" y1="0.9906" x2="-0.9906" y2="-0.9906" width="0" layer="51"/>
<wire x1="0.3048" y1="0.9906" x2="-0.3048" y2="0.9906" width="0" layer="51" curve="-180"/>
<text x="-3.4544" y="2.54" size="2.0828" layer="25" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-3.4544" y="-3.81" size="2.0828" layer="27" ratio="10" rot="SR0">&gt;VALUE</text>
</package>
<package name="SOP63P600X175-24N">
<smd name="1" x="-2.4638" y="3.5052" dx="1.9812" dy="0.3556" layer="1"/>
<smd name="2" x="-2.4638" y="2.8448" dx="1.9812" dy="0.3556" layer="1"/>
<smd name="3" x="-2.4638" y="2.2352" dx="1.9812" dy="0.3556" layer="1"/>
<smd name="4" x="-2.4638" y="1.5748" dx="1.9812" dy="0.3556" layer="1"/>
<smd name="5" x="-2.4638" y="0.9652" dx="1.9812" dy="0.3556" layer="1"/>
<smd name="6" x="-2.4638" y="0.3048" dx="1.9812" dy="0.3556" layer="1"/>
<smd name="7" x="-2.4638" y="-0.3048" dx="1.9812" dy="0.3556" layer="1"/>
<smd name="8" x="-2.4638" y="-0.9652" dx="1.9812" dy="0.3556" layer="1"/>
<smd name="9" x="-2.4638" y="-1.5748" dx="1.9812" dy="0.3556" layer="1"/>
<smd name="10" x="-2.4638" y="-2.2352" dx="1.9812" dy="0.3556" layer="1"/>
<smd name="11" x="-2.4638" y="-2.8448" dx="1.9812" dy="0.3556" layer="1"/>
<smd name="12" x="-2.4638" y="-3.5052" dx="1.9812" dy="0.3556" layer="1"/>
<smd name="13" x="2.4638" y="-3.5052" dx="1.9812" dy="0.3556" layer="1"/>
<smd name="14" x="2.4638" y="-2.8448" dx="1.9812" dy="0.3556" layer="1"/>
<smd name="15" x="2.4638" y="-2.2352" dx="1.9812" dy="0.3556" layer="1"/>
<smd name="16" x="2.4638" y="-1.5748" dx="1.9812" dy="0.3556" layer="1"/>
<smd name="17" x="2.4638" y="-0.9652" dx="1.9812" dy="0.3556" layer="1"/>
<smd name="18" x="2.4638" y="-0.3048" dx="1.9812" dy="0.3556" layer="1"/>
<smd name="19" x="2.4638" y="0.3048" dx="1.9812" dy="0.3556" layer="1"/>
<smd name="20" x="2.4638" y="0.9652" dx="1.9812" dy="0.3556" layer="1"/>
<smd name="21" x="2.4638" y="1.5748" dx="1.9812" dy="0.3556" layer="1"/>
<smd name="22" x="2.4638" y="2.2352" dx="1.9812" dy="0.3556" layer="1"/>
<smd name="23" x="2.4638" y="2.8448" dx="1.9812" dy="0.3556" layer="1"/>
<smd name="24" x="2.4638" y="3.5052" dx="1.9812" dy="0.3556" layer="1"/>
<wire x1="-3.7846" y1="-2.1336" x2="-4.8006" y2="-2.1336" width="0.1524" layer="21"/>
<wire x1="4.7752" y1="1.0414" x2="3.7592" y2="1.0414" width="0.1524" layer="21"/>
<wire x1="1.9558" y1="4.0132" x2="1.9558" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-1.9558" y1="-4.0132" x2="-1.9558" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-1.9558" y1="-4.318" x2="1.9558" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="1.9558" y1="-4.318" x2="1.9558" y2="-4.0132" width="0.1524" layer="21"/>
<wire x1="1.9558" y1="4.318" x2="0.3048" y2="4.318" width="0.1524" layer="21"/>
<wire x1="0.3048" y1="4.318" x2="-0.3048" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="4.318" x2="-1.9558" y2="4.318" width="0.1524" layer="21"/>
<wire x1="-1.9558" y1="4.318" x2="-1.9558" y2="4.0132" width="0.1524" layer="21"/>
<wire x1="0.3048" y1="4.318" x2="-0.3048" y2="4.318" width="0.1524" layer="21" curve="-180"/>
<text x="-3.302" y="3.7084" size="1.27" layer="21" ratio="6" rot="SR0">*</text>
<wire x1="-1.9558" y1="3.3528" x2="-1.9558" y2="3.6322" width="0" layer="51"/>
<wire x1="-1.9558" y1="3.6322" x2="-3.0988" y2="3.6322" width="0" layer="51"/>
<wire x1="-3.0988" y1="3.6322" x2="-3.0988" y2="3.3528" width="0" layer="51"/>
<wire x1="-3.0988" y1="3.3528" x2="-1.9558" y2="3.3528" width="0" layer="51"/>
<wire x1="-1.9558" y1="2.7178" x2="-1.9558" y2="2.9972" width="0" layer="51"/>
<wire x1="-1.9558" y1="2.9972" x2="-3.0988" y2="2.9972" width="0" layer="51"/>
<wire x1="-3.0988" y1="2.9972" x2="-3.0988" y2="2.7178" width="0" layer="51"/>
<wire x1="-3.0988" y1="2.7178" x2="-1.9558" y2="2.7178" width="0" layer="51"/>
<wire x1="-1.9558" y1="2.0828" x2="-1.9558" y2="2.3622" width="0" layer="51"/>
<wire x1="-1.9558" y1="2.3622" x2="-3.0988" y2="2.3622" width="0" layer="51"/>
<wire x1="-3.0988" y1="2.3622" x2="-3.0988" y2="2.0828" width="0" layer="51"/>
<wire x1="-3.0988" y1="2.0828" x2="-1.9558" y2="2.0828" width="0" layer="51"/>
<wire x1="-1.9558" y1="1.4478" x2="-1.9558" y2="1.7272" width="0" layer="51"/>
<wire x1="-1.9558" y1="1.7272" x2="-3.0988" y2="1.7272" width="0" layer="51"/>
<wire x1="-3.0988" y1="1.7272" x2="-3.0988" y2="1.4478" width="0" layer="51"/>
<wire x1="-3.0988" y1="1.4478" x2="-1.9558" y2="1.4478" width="0" layer="51"/>
<wire x1="-1.9558" y1="0.8128" x2="-1.9558" y2="1.0922" width="0" layer="51"/>
<wire x1="-1.9558" y1="1.0922" x2="-3.0988" y2="1.0922" width="0" layer="51"/>
<wire x1="-3.0988" y1="1.0922" x2="-3.0988" y2="0.8128" width="0" layer="51"/>
<wire x1="-3.0988" y1="0.8128" x2="-1.9558" y2="0.8128" width="0" layer="51"/>
<wire x1="-1.9558" y1="0.1778" x2="-1.9558" y2="0.4572" width="0" layer="51"/>
<wire x1="-1.9558" y1="0.4572" x2="-3.0988" y2="0.4572" width="0" layer="51"/>
<wire x1="-3.0988" y1="0.4572" x2="-3.0988" y2="0.1778" width="0" layer="51"/>
<wire x1="-3.0988" y1="0.1778" x2="-1.9558" y2="0.1778" width="0" layer="51"/>
<wire x1="-1.9558" y1="-0.4572" x2="-1.9558" y2="-0.1778" width="0" layer="51"/>
<wire x1="-1.9558" y1="-0.1778" x2="-3.0988" y2="-0.1778" width="0" layer="51"/>
<wire x1="-3.0988" y1="-0.1778" x2="-3.0988" y2="-0.4572" width="0" layer="51"/>
<wire x1="-3.0988" y1="-0.4572" x2="-1.9558" y2="-0.4572" width="0" layer="51"/>
<wire x1="-1.9558" y1="-1.0922" x2="-1.9558" y2="-0.8128" width="0" layer="51"/>
<wire x1="-1.9558" y1="-0.8128" x2="-3.0988" y2="-0.8128" width="0" layer="51"/>
<wire x1="-3.0988" y1="-0.8128" x2="-3.0988" y2="-1.0922" width="0" layer="51"/>
<wire x1="-3.0988" y1="-1.0922" x2="-1.9558" y2="-1.0922" width="0" layer="51"/>
<wire x1="-1.9558" y1="-1.7272" x2="-1.9558" y2="-1.4478" width="0" layer="51"/>
<wire x1="-1.9558" y1="-1.4478" x2="-3.0988" y2="-1.4478" width="0" layer="51"/>
<wire x1="-3.0988" y1="-1.4478" x2="-3.0988" y2="-1.7272" width="0" layer="51"/>
<wire x1="-3.0988" y1="-1.7272" x2="-1.9558" y2="-1.7272" width="0" layer="51"/>
<wire x1="-1.9558" y1="-2.3622" x2="-1.9558" y2="-2.0828" width="0" layer="51"/>
<wire x1="-1.9558" y1="-2.0828" x2="-3.0988" y2="-2.0828" width="0" layer="51"/>
<wire x1="-3.0988" y1="-2.0828" x2="-3.0988" y2="-2.3622" width="0" layer="51"/>
<wire x1="-3.0988" y1="-2.3622" x2="-1.9558" y2="-2.3622" width="0" layer="51"/>
<wire x1="-1.9558" y1="-2.9972" x2="-1.9558" y2="-2.7178" width="0" layer="51"/>
<wire x1="-1.9558" y1="-2.7178" x2="-3.0988" y2="-2.7178" width="0" layer="51"/>
<wire x1="-3.0988" y1="-2.7178" x2="-3.0988" y2="-2.9972" width="0" layer="51"/>
<wire x1="-3.0988" y1="-2.9972" x2="-1.9558" y2="-2.9972" width="0" layer="51"/>
<wire x1="-1.9558" y1="-3.6322" x2="-1.9558" y2="-3.3528" width="0" layer="51"/>
<wire x1="-1.9558" y1="-3.3528" x2="-3.0988" y2="-3.3528" width="0" layer="51"/>
<wire x1="-3.0988" y1="-3.3528" x2="-3.0988" y2="-3.6322" width="0" layer="51"/>
<wire x1="-3.0988" y1="-3.6322" x2="-1.9558" y2="-3.6322" width="0" layer="51"/>
<wire x1="1.9558" y1="-3.3528" x2="1.9558" y2="-3.6322" width="0" layer="51"/>
<wire x1="1.9558" y1="-3.6322" x2="3.0988" y2="-3.6322" width="0" layer="51"/>
<wire x1="3.0988" y1="-3.6322" x2="3.0988" y2="-3.3528" width="0" layer="51"/>
<wire x1="3.0988" y1="-3.3528" x2="1.9558" y2="-3.3528" width="0" layer="51"/>
<wire x1="1.9558" y1="-2.7178" x2="1.9558" y2="-2.9972" width="0" layer="51"/>
<wire x1="1.9558" y1="-2.9972" x2="3.0988" y2="-2.9972" width="0" layer="51"/>
<wire x1="3.0988" y1="-2.9972" x2="3.0988" y2="-2.7178" width="0" layer="51"/>
<wire x1="3.0988" y1="-2.7178" x2="1.9558" y2="-2.7178" width="0" layer="51"/>
<wire x1="1.9558" y1="-2.0828" x2="1.9558" y2="-2.3622" width="0" layer="51"/>
<wire x1="1.9558" y1="-2.3622" x2="3.0988" y2="-2.3622" width="0" layer="51"/>
<wire x1="3.0988" y1="-2.3622" x2="3.0988" y2="-2.0828" width="0" layer="51"/>
<wire x1="3.0988" y1="-2.0828" x2="1.9558" y2="-2.0828" width="0" layer="51"/>
<wire x1="1.9558" y1="-1.4478" x2="1.9558" y2="-1.7272" width="0" layer="51"/>
<wire x1="1.9558" y1="-1.7272" x2="3.0988" y2="-1.7272" width="0" layer="51"/>
<wire x1="3.0988" y1="-1.7272" x2="3.0988" y2="-1.4478" width="0" layer="51"/>
<wire x1="3.0988" y1="-1.4478" x2="1.9558" y2="-1.4478" width="0" layer="51"/>
<wire x1="1.9558" y1="-0.8128" x2="1.9558" y2="-1.0922" width="0" layer="51"/>
<wire x1="1.9558" y1="-1.0922" x2="3.0988" y2="-1.0922" width="0" layer="51"/>
<wire x1="3.0988" y1="-1.0922" x2="3.0988" y2="-0.8128" width="0" layer="51"/>
<wire x1="3.0988" y1="-0.8128" x2="1.9558" y2="-0.8128" width="0" layer="51"/>
<wire x1="1.9558" y1="-0.1778" x2="1.9558" y2="-0.4572" width="0" layer="51"/>
<wire x1="1.9558" y1="-0.4572" x2="3.0988" y2="-0.4572" width="0" layer="51"/>
<wire x1="3.0988" y1="-0.4572" x2="3.0988" y2="-0.1778" width="0" layer="51"/>
<wire x1="3.0988" y1="-0.1778" x2="1.9558" y2="-0.1778" width="0" layer="51"/>
<wire x1="1.9558" y1="0.4572" x2="1.9558" y2="0.1778" width="0" layer="51"/>
<wire x1="1.9558" y1="0.1778" x2="3.0988" y2="0.1778" width="0" layer="51"/>
<wire x1="3.0988" y1="0.1778" x2="3.0988" y2="0.4572" width="0" layer="51"/>
<wire x1="3.0988" y1="0.4572" x2="1.9558" y2="0.4572" width="0" layer="51"/>
<wire x1="1.9558" y1="1.0922" x2="1.9558" y2="0.8128" width="0" layer="51"/>
<wire x1="1.9558" y1="0.8128" x2="3.0988" y2="0.8128" width="0" layer="51"/>
<wire x1="3.0988" y1="0.8128" x2="3.0988" y2="1.0922" width="0" layer="51"/>
<wire x1="3.0988" y1="1.0922" x2="1.9558" y2="1.0922" width="0" layer="51"/>
<wire x1="1.9558" y1="1.7272" x2="1.9558" y2="1.4478" width="0" layer="51"/>
<wire x1="1.9558" y1="1.4478" x2="3.0988" y2="1.4478" width="0" layer="51"/>
<wire x1="3.0988" y1="1.4478" x2="3.0988" y2="1.7272" width="0" layer="51"/>
<wire x1="3.0988" y1="1.7272" x2="1.9558" y2="1.7272" width="0" layer="51"/>
<wire x1="1.9558" y1="2.3622" x2="1.9558" y2="2.0828" width="0" layer="51"/>
<wire x1="1.9558" y1="2.0828" x2="3.0988" y2="2.0828" width="0" layer="51"/>
<wire x1="3.0988" y1="2.0828" x2="3.0988" y2="2.3622" width="0" layer="51"/>
<wire x1="3.0988" y1="2.3622" x2="1.9558" y2="2.3622" width="0" layer="51"/>
<wire x1="1.9558" y1="2.9972" x2="1.9558" y2="2.7178" width="0" layer="51"/>
<wire x1="1.9558" y1="2.7178" x2="3.0988" y2="2.7178" width="0" layer="51"/>
<wire x1="3.0988" y1="2.7178" x2="3.0988" y2="2.9972" width="0" layer="51"/>
<wire x1="3.0988" y1="2.9972" x2="1.9558" y2="2.9972" width="0" layer="51"/>
<wire x1="1.9558" y1="3.6322" x2="1.9558" y2="3.3528" width="0" layer="51"/>
<wire x1="1.9558" y1="3.3528" x2="3.0988" y2="3.3528" width="0" layer="51"/>
<wire x1="3.0988" y1="3.3528" x2="3.0988" y2="3.6322" width="0" layer="51"/>
<wire x1="3.0988" y1="3.6322" x2="1.9558" y2="3.6322" width="0" layer="51"/>
<wire x1="-1.9558" y1="-4.318" x2="1.9558" y2="-4.318" width="0" layer="51"/>
<wire x1="1.9558" y1="-4.318" x2="1.9558" y2="4.318" width="0" layer="51"/>
<wire x1="1.9558" y1="4.318" x2="0.3048" y2="4.318" width="0" layer="51"/>
<wire x1="0.3048" y1="4.318" x2="-0.3048" y2="4.318" width="0" layer="51"/>
<wire x1="-0.3048" y1="4.318" x2="-1.9558" y2="4.318" width="0" layer="51"/>
<wire x1="-1.9558" y1="4.318" x2="-1.9558" y2="-4.318" width="0" layer="51"/>
<wire x1="0.3048" y1="4.318" x2="-0.3048" y2="4.318" width="0" layer="51" curve="-180"/>
<text x="-3.302" y="3.7084" size="1.27" layer="51" ratio="6" rot="SR0">*</text>
<text x="-3.4544" y="-6.985" size="2.0828" layer="27" ratio="10" rot="SR0">&gt;VALUE</text>
</package>
<package name="SOIC127P1030X265-16N">
<smd name="1" x="-4.6736" y="4.445" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="2" x="-4.6736" y="3.175" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="3" x="-4.6736" y="1.905" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="4" x="-4.6736" y="0.635" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="5" x="-4.6736" y="-0.635" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="6" x="-4.6736" y="-1.905" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="7" x="-4.6736" y="-3.175" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="8" x="-4.6736" y="-4.445" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="9" x="4.6736" y="-4.445" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="10" x="4.6736" y="-3.175" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="11" x="4.6736" y="-1.905" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="12" x="4.6736" y="-0.635" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="13" x="4.6736" y="0.635" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="14" x="4.6736" y="1.905" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="15" x="4.6736" y="3.175" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="16" x="4.6736" y="4.445" dx="1.9812" dy="0.5588" layer="1"/>
<wire x1="-3.7592" y1="4.191" x2="-3.7592" y2="4.699" width="0" layer="51"/>
<wire x1="-3.7592" y1="4.699" x2="-5.3086" y2="4.699" width="0" layer="51"/>
<wire x1="-5.3086" y1="4.699" x2="-5.3086" y2="4.191" width="0" layer="51"/>
<wire x1="-5.3086" y1="4.191" x2="-3.7592" y2="4.191" width="0" layer="51"/>
<wire x1="-3.7592" y1="2.921" x2="-3.7592" y2="3.429" width="0" layer="51"/>
<wire x1="-3.7592" y1="3.429" x2="-5.3086" y2="3.429" width="0" layer="51"/>
<wire x1="-5.3086" y1="3.429" x2="-5.3086" y2="2.921" width="0" layer="51"/>
<wire x1="-5.3086" y1="2.921" x2="-3.7592" y2="2.921" width="0" layer="51"/>
<wire x1="-3.7592" y1="1.651" x2="-3.7592" y2="2.159" width="0" layer="51"/>
<wire x1="-3.7592" y1="2.159" x2="-5.3086" y2="2.159" width="0" layer="51"/>
<wire x1="-5.3086" y1="2.159" x2="-5.3086" y2="1.651" width="0" layer="51"/>
<wire x1="-5.3086" y1="1.651" x2="-3.7592" y2="1.651" width="0" layer="51"/>
<wire x1="-3.7592" y1="0.381" x2="-3.7592" y2="0.889" width="0" layer="51"/>
<wire x1="-3.7592" y1="0.889" x2="-5.3086" y2="0.889" width="0" layer="51"/>
<wire x1="-5.3086" y1="0.889" x2="-5.3086" y2="0.381" width="0" layer="51"/>
<wire x1="-5.3086" y1="0.381" x2="-3.7592" y2="0.381" width="0" layer="51"/>
<wire x1="-3.7592" y1="-0.889" x2="-3.7592" y2="-0.381" width="0" layer="51"/>
<wire x1="-3.7592" y1="-0.381" x2="-5.3086" y2="-0.381" width="0" layer="51"/>
<wire x1="-5.3086" y1="-0.381" x2="-5.3086" y2="-0.889" width="0" layer="51"/>
<wire x1="-5.3086" y1="-0.889" x2="-3.7592" y2="-0.889" width="0" layer="51"/>
<wire x1="-3.7592" y1="-2.159" x2="-3.7592" y2="-1.651" width="0" layer="51"/>
<wire x1="-3.7592" y1="-1.651" x2="-5.3086" y2="-1.651" width="0" layer="51"/>
<wire x1="-5.3086" y1="-1.651" x2="-5.3086" y2="-2.159" width="0" layer="51"/>
<wire x1="-5.3086" y1="-2.159" x2="-3.7592" y2="-2.159" width="0" layer="51"/>
<wire x1="-3.7592" y1="-3.429" x2="-3.7592" y2="-2.921" width="0" layer="51"/>
<wire x1="-3.7592" y1="-2.921" x2="-5.3086" y2="-2.921" width="0" layer="51"/>
<wire x1="-5.3086" y1="-2.921" x2="-5.3086" y2="-3.429" width="0" layer="51"/>
<wire x1="-5.3086" y1="-3.429" x2="-3.7592" y2="-3.429" width="0" layer="51"/>
<wire x1="-3.7592" y1="-4.699" x2="-3.7592" y2="-4.191" width="0" layer="51"/>
<wire x1="-3.7592" y1="-4.191" x2="-5.3086" y2="-4.191" width="0" layer="51"/>
<wire x1="-5.3086" y1="-4.191" x2="-5.3086" y2="-4.699" width="0" layer="51"/>
<wire x1="-5.3086" y1="-4.699" x2="-3.7592" y2="-4.699" width="0" layer="51"/>
<wire x1="3.7592" y1="-4.191" x2="3.7592" y2="-4.699" width="0" layer="51"/>
<wire x1="3.7592" y1="-4.699" x2="5.3086" y2="-4.699" width="0" layer="51"/>
<wire x1="5.3086" y1="-4.699" x2="5.3086" y2="-4.191" width="0" layer="51"/>
<wire x1="5.3086" y1="-4.191" x2="3.7592" y2="-4.191" width="0" layer="51"/>
<wire x1="3.7592" y1="-2.921" x2="3.7592" y2="-3.429" width="0" layer="51"/>
<wire x1="3.7592" y1="-3.429" x2="5.3086" y2="-3.429" width="0" layer="51"/>
<wire x1="5.3086" y1="-3.429" x2="5.3086" y2="-2.921" width="0" layer="51"/>
<wire x1="5.3086" y1="-2.921" x2="3.7592" y2="-2.921" width="0" layer="51"/>
<wire x1="3.7592" y1="-1.651" x2="3.7592" y2="-2.159" width="0" layer="51"/>
<wire x1="3.7592" y1="-2.159" x2="5.3086" y2="-2.159" width="0" layer="51"/>
<wire x1="5.3086" y1="-2.159" x2="5.3086" y2="-1.651" width="0" layer="51"/>
<wire x1="5.3086" y1="-1.651" x2="3.7592" y2="-1.651" width="0" layer="51"/>
<wire x1="3.7592" y1="-0.381" x2="3.7592" y2="-0.889" width="0" layer="51"/>
<wire x1="3.7592" y1="-0.889" x2="5.3086" y2="-0.889" width="0" layer="51"/>
<wire x1="5.3086" y1="-0.889" x2="5.3086" y2="-0.381" width="0" layer="51"/>
<wire x1="5.3086" y1="-0.381" x2="3.7592" y2="-0.381" width="0" layer="51"/>
<wire x1="3.7592" y1="0.889" x2="3.7592" y2="0.381" width="0" layer="51"/>
<wire x1="3.7592" y1="0.381" x2="5.3086" y2="0.381" width="0" layer="51"/>
<wire x1="5.3086" y1="0.381" x2="5.3086" y2="0.889" width="0" layer="51"/>
<wire x1="5.3086" y1="0.889" x2="3.7592" y2="0.889" width="0" layer="51"/>
<wire x1="3.7592" y1="2.159" x2="3.7592" y2="1.651" width="0" layer="51"/>
<wire x1="3.7592" y1="1.651" x2="5.3086" y2="1.651" width="0" layer="51"/>
<wire x1="5.3086" y1="1.651" x2="5.3086" y2="2.159" width="0" layer="51"/>
<wire x1="5.3086" y1="2.159" x2="3.7592" y2="2.159" width="0" layer="51"/>
<wire x1="3.7592" y1="3.429" x2="3.7592" y2="2.921" width="0" layer="51"/>
<wire x1="3.7592" y1="2.921" x2="5.3086" y2="2.921" width="0" layer="51"/>
<wire x1="5.3086" y1="2.921" x2="5.3086" y2="3.429" width="0" layer="51"/>
<wire x1="5.3086" y1="3.429" x2="3.7592" y2="3.429" width="0" layer="51"/>
<wire x1="3.7592" y1="4.699" x2="3.7592" y2="4.191" width="0" layer="51"/>
<wire x1="3.7592" y1="4.191" x2="5.3086" y2="4.191" width="0" layer="51"/>
<wire x1="5.3086" y1="4.191" x2="5.3086" y2="4.699" width="0" layer="51"/>
<wire x1="5.3086" y1="4.699" x2="3.7592" y2="4.699" width="0" layer="51"/>
<wire x1="-3.7592" y1="-5.1562" x2="3.7592" y2="-5.1562" width="0" layer="51"/>
<wire x1="3.7592" y1="-5.1562" x2="3.7592" y2="5.1562" width="0" layer="51"/>
<wire x1="3.7592" y1="5.1562" x2="0.3048" y2="5.1562" width="0" layer="51"/>
<wire x1="0.3048" y1="5.1562" x2="-0.3048" y2="5.1562" width="0" layer="51"/>
<wire x1="-0.3048" y1="5.1562" x2="-3.7592" y2="5.1562" width="0" layer="51"/>
<wire x1="-3.7592" y1="5.1562" x2="-3.7592" y2="-5.1562" width="0" layer="51"/>
<wire x1="0.3048" y1="5.1562" x2="-0.3048" y2="5.1562" width="0" layer="51" curve="-180"/>
<text x="-5.5118" y="4.8768" size="1.27" layer="51" ratio="6" rot="SR0">*</text>
<wire x1="7.0358" y1="-3.1242" x2="6.0198" y2="-3.1242" width="0.1524" layer="21"/>
<wire x1="-3.7592" y1="-5.1562" x2="3.7592" y2="-5.1562" width="0.1524" layer="21"/>
<wire x1="3.7592" y1="5.1562" x2="0.3048" y2="5.1562" width="0.1524" layer="21"/>
<wire x1="0.3048" y1="5.1562" x2="-0.3048" y2="5.1562" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="5.1562" x2="-3.7592" y2="5.1562" width="0.1524" layer="21"/>
<wire x1="0.3048" y1="5.1562" x2="-0.3048" y2="5.1562" width="0.1524" layer="21" curve="-180"/>
<text x="-5.5118" y="4.8768" size="1.27" layer="21" ratio="6" rot="SR0">*</text>
<text x="-3.4544" y="6.985" size="2.0828" layer="25" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-3.4544" y="-8.255" size="2.0828" layer="27" ratio="10" rot="SR0">&gt;VALUE</text>
</package>
<package name="SOIC127P600X175-8N">
<smd name="1" x="-2.4638" y="1.905" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="2" x="-2.4638" y="0.635" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="3" x="-2.4638" y="-0.635" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="4" x="-2.4638" y="-1.905" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="5" x="2.4638" y="-1.905" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="6" x="2.4638" y="-0.635" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="7" x="2.4638" y="0.635" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="8" x="2.4638" y="1.905" dx="1.9812" dy="0.5588" layer="1"/>
<wire x1="-1.9558" y1="1.651" x2="-1.9558" y2="2.159" width="0" layer="51"/>
<wire x1="-1.9558" y1="2.159" x2="-3.0988" y2="2.159" width="0" layer="51"/>
<wire x1="-3.0988" y1="2.159" x2="-3.0988" y2="1.651" width="0" layer="51"/>
<wire x1="-3.0988" y1="1.651" x2="-1.9558" y2="1.651" width="0" layer="51"/>
<wire x1="-1.9558" y1="0.381" x2="-1.9558" y2="0.889" width="0" layer="51"/>
<wire x1="-1.9558" y1="0.889" x2="-3.0988" y2="0.889" width="0" layer="51"/>
<wire x1="-3.0988" y1="0.889" x2="-3.0988" y2="0.381" width="0" layer="51"/>
<wire x1="-3.0988" y1="0.381" x2="-1.9558" y2="0.381" width="0" layer="51"/>
<wire x1="-1.9558" y1="-0.889" x2="-1.9558" y2="-0.381" width="0" layer="51"/>
<wire x1="-1.9558" y1="-0.381" x2="-3.0988" y2="-0.381" width="0" layer="51"/>
<wire x1="-3.0988" y1="-0.381" x2="-3.0988" y2="-0.889" width="0" layer="51"/>
<wire x1="-3.0988" y1="-0.889" x2="-1.9558" y2="-0.889" width="0" layer="51"/>
<wire x1="-1.9558" y1="-2.159" x2="-1.9558" y2="-1.651" width="0" layer="51"/>
<wire x1="-1.9558" y1="-1.651" x2="-3.0988" y2="-1.651" width="0" layer="51"/>
<wire x1="-3.0988" y1="-1.651" x2="-3.0988" y2="-2.159" width="0" layer="51"/>
<wire x1="-3.0988" y1="-2.159" x2="-1.9558" y2="-2.159" width="0" layer="51"/>
<wire x1="1.9558" y1="-1.651" x2="1.9558" y2="-2.159" width="0" layer="51"/>
<wire x1="1.9558" y1="-2.159" x2="3.0988" y2="-2.159" width="0" layer="51"/>
<wire x1="3.0988" y1="-2.159" x2="3.0988" y2="-1.651" width="0" layer="51"/>
<wire x1="3.0988" y1="-1.651" x2="1.9558" y2="-1.651" width="0" layer="51"/>
<wire x1="1.9558" y1="-0.381" x2="1.9558" y2="-0.889" width="0" layer="51"/>
<wire x1="1.9558" y1="-0.889" x2="3.0988" y2="-0.889" width="0" layer="51"/>
<wire x1="3.0988" y1="-0.889" x2="3.0988" y2="-0.381" width="0" layer="51"/>
<wire x1="3.0988" y1="-0.381" x2="1.9558" y2="-0.381" width="0" layer="51"/>
<wire x1="1.9558" y1="0.889" x2="1.9558" y2="0.381" width="0" layer="51"/>
<wire x1="1.9558" y1="0.381" x2="3.0988" y2="0.381" width="0" layer="51"/>
<wire x1="3.0988" y1="0.381" x2="3.0988" y2="0.889" width="0" layer="51"/>
<wire x1="3.0988" y1="0.889" x2="1.9558" y2="0.889" width="0" layer="51"/>
<wire x1="1.9558" y1="2.159" x2="1.9558" y2="1.651" width="0" layer="51"/>
<wire x1="1.9558" y1="1.651" x2="3.0988" y2="1.651" width="0" layer="51"/>
<wire x1="3.0988" y1="1.651" x2="3.0988" y2="2.159" width="0" layer="51"/>
<wire x1="3.0988" y1="2.159" x2="1.9558" y2="2.159" width="0" layer="51"/>
<wire x1="-1.9558" y1="-2.4384" x2="1.9558" y2="-2.4384" width="0" layer="51"/>
<wire x1="1.9558" y1="-2.4384" x2="1.9558" y2="2.4384" width="0" layer="51"/>
<wire x1="1.9558" y1="2.4384" x2="0.3048" y2="2.4384" width="0" layer="51"/>
<wire x1="0.3048" y1="2.4384" x2="-0.3048" y2="2.4384" width="0" layer="51"/>
<wire x1="-0.3048" y1="2.4384" x2="-1.9558" y2="2.4384" width="0" layer="51"/>
<wire x1="-1.9558" y1="2.4384" x2="-1.9558" y2="-2.4384" width="0" layer="51"/>
<wire x1="0.3048" y1="2.4384" x2="-0.3048" y2="2.4384" width="0" layer="51" curve="-180"/>
<text x="-3.302" y="2.3368" size="1.27" layer="51" ratio="6" rot="SR0">*</text>
<wire x1="-1.27" y1="-2.4384" x2="1.27" y2="-2.4384" width="0.1524" layer="21"/>
<wire x1="1.27" y1="2.4384" x2="0.3048" y2="2.4384" width="0.1524" layer="21"/>
<wire x1="0.3048" y1="2.4384" x2="-0.3048" y2="2.4384" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="2.4384" x2="-1.27" y2="2.4384" width="0.1524" layer="21"/>
<wire x1="0.3048" y1="2.4384" x2="-0.3048" y2="2.4384" width="0.1524" layer="21" curve="-180"/>
<text x="-3.302" y="2.3368" size="1.27" layer="21" ratio="6" rot="SR0">*</text>
<text x="-3.4544" y="4.445" size="2.0828" layer="25" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-3.4544" y="-5.715" size="2.0828" layer="27" ratio="10" rot="SR0">&gt;VALUE</text>
</package>
<package name="SOP127P620X160-9N">
<smd name="1" x="-2.8956" y="1.905" dx="1.1176" dy="0.4572" layer="1"/>
<smd name="2" x="-2.8956" y="0.635" dx="1.1176" dy="0.4572" layer="1"/>
<smd name="3" x="-2.8956" y="-0.635" dx="1.1176" dy="0.4572" layer="1"/>
<smd name="4" x="-2.8956" y="-1.905" dx="1.1176" dy="0.4572" layer="1"/>
<smd name="5" x="2.8956" y="-1.905" dx="1.1176" dy="0.4572" layer="1"/>
<smd name="6" x="2.8956" y="-0.635" dx="1.1176" dy="0.4572" layer="1"/>
<smd name="7" x="2.8956" y="0.635" dx="1.1176" dy="0.4572" layer="1"/>
<smd name="8" x="2.8956" y="1.905" dx="1.1176" dy="0.4572" layer="1"/>
<smd name="9" x="0" y="0" dx="2.6924" dy="2.8956" layer="1"/>
<wire x1="-2.2098" y1="1.7018" x2="-2.2098" y2="2.1082" width="0" layer="51"/>
<wire x1="-2.2098" y1="2.1082" x2="-3.0988" y2="2.1082" width="0" layer="51"/>
<wire x1="-3.0988" y1="2.1082" x2="-3.0988" y2="1.7018" width="0" layer="51"/>
<wire x1="-3.0988" y1="1.7018" x2="-2.2098" y2="1.7018" width="0" layer="51"/>
<wire x1="-2.2098" y1="0.4318" x2="-2.2098" y2="0.8382" width="0" layer="51"/>
<wire x1="-2.2098" y1="0.8382" x2="-3.0988" y2="0.8382" width="0" layer="51"/>
<wire x1="-3.0988" y1="0.8382" x2="-3.0988" y2="0.4318" width="0" layer="51"/>
<wire x1="-3.0988" y1="0.4318" x2="-2.2098" y2="0.4318" width="0" layer="51"/>
<wire x1="-2.2098" y1="-0.8382" x2="-2.2098" y2="-0.4318" width="0" layer="51"/>
<wire x1="-2.2098" y1="-0.4318" x2="-3.0988" y2="-0.4318" width="0" layer="51"/>
<wire x1="-3.0988" y1="-0.4318" x2="-3.0988" y2="-0.8382" width="0" layer="51"/>
<wire x1="-3.0988" y1="-0.8382" x2="-2.2098" y2="-0.8382" width="0" layer="51"/>
<wire x1="-2.2098" y1="-2.1082" x2="-2.2098" y2="-1.7018" width="0" layer="51"/>
<wire x1="-2.2098" y1="-1.7018" x2="-3.0988" y2="-1.7018" width="0" layer="51"/>
<wire x1="-3.0988" y1="-1.7018" x2="-3.0988" y2="-2.1082" width="0" layer="51"/>
<wire x1="-3.0988" y1="-2.1082" x2="-2.2098" y2="-2.1082" width="0" layer="51"/>
<wire x1="2.2098" y1="-1.7018" x2="2.2098" y2="-2.1082" width="0" layer="51"/>
<wire x1="2.2098" y1="-2.1082" x2="3.0988" y2="-2.1082" width="0" layer="51"/>
<wire x1="3.0988" y1="-2.1082" x2="3.0988" y2="-1.7018" width="0" layer="51"/>
<wire x1="3.0988" y1="-1.7018" x2="2.2098" y2="-1.7018" width="0" layer="51"/>
<wire x1="2.2098" y1="-0.4318" x2="2.2098" y2="-0.8382" width="0" layer="51"/>
<wire x1="2.2098" y1="-0.8382" x2="3.0988" y2="-0.8382" width="0" layer="51"/>
<wire x1="3.0988" y1="-0.8382" x2="3.0988" y2="-0.4318" width="0" layer="51"/>
<wire x1="3.0988" y1="-0.4318" x2="2.2098" y2="-0.4318" width="0" layer="51"/>
<wire x1="2.2098" y1="0.8382" x2="2.2098" y2="0.4318" width="0" layer="51"/>
<wire x1="2.2098" y1="0.4318" x2="3.0988" y2="0.4318" width="0" layer="51"/>
<wire x1="3.0988" y1="0.4318" x2="3.0988" y2="0.8382" width="0" layer="51"/>
<wire x1="3.0988" y1="0.8382" x2="2.2098" y2="0.8382" width="0" layer="51"/>
<wire x1="2.2098" y1="2.1082" x2="2.2098" y2="1.7018" width="0" layer="51"/>
<wire x1="2.2098" y1="1.7018" x2="3.0988" y2="1.7018" width="0" layer="51"/>
<wire x1="3.0988" y1="1.7018" x2="3.0988" y2="2.1082" width="0" layer="51"/>
<wire x1="3.0988" y1="2.1082" x2="2.2098" y2="2.1082" width="0" layer="51"/>
<wire x1="-2.2098" y1="-2.5908" x2="2.2098" y2="-2.5908" width="0" layer="51"/>
<wire x1="2.2098" y1="-2.5908" x2="2.2098" y2="2.5908" width="0" layer="51"/>
<wire x1="2.2098" y1="2.5908" x2="0.3048" y2="2.5908" width="0" layer="51"/>
<wire x1="0.3048" y1="2.5908" x2="-0.3048" y2="2.5908" width="0" layer="51"/>
<wire x1="-0.3048" y1="2.5908" x2="-2.2098" y2="2.5908" width="0" layer="51"/>
<wire x1="-2.2098" y1="2.5908" x2="-2.2098" y2="-2.5908" width="0" layer="51"/>
<wire x1="0.3048" y1="2.5908" x2="-0.3048" y2="2.5908" width="0" layer="51" curve="-180"/>
<text x="-3.7338" y="2.2352" size="1.27" layer="51" ratio="6" rot="SR0">*</text>
<wire x1="2.2098" y1="2.4384" x2="2.2098" y2="2.5908" width="0.1524" layer="21"/>
<wire x1="2.2098" y1="1.1684" x2="2.2098" y2="1.3716" width="0.1524" layer="21"/>
<wire x1="2.2098" y1="-0.1016" x2="2.2098" y2="0.1016" width="0.1524" layer="21"/>
<wire x1="2.2098" y1="-1.3716" x2="2.2098" y2="-1.1684" width="0.1524" layer="21"/>
<wire x1="-2.2098" y1="-2.4384" x2="-2.2098" y2="-2.5908" width="0.1524" layer="21"/>
<wire x1="-2.2098" y1="-1.1684" x2="-2.2098" y2="-1.3716" width="0.1524" layer="21"/>
<wire x1="-2.2098" y1="0.1016" x2="-2.2098" y2="-0.1016" width="0.1524" layer="21"/>
<wire x1="-2.2098" y1="-2.5908" x2="2.2098" y2="-2.5908" width="0.1524" layer="21"/>
<wire x1="2.2098" y1="-2.5908" x2="2.2098" y2="-2.4384" width="0.1524" layer="21"/>
<wire x1="2.2098" y1="2.5908" x2="0.3048" y2="2.5908" width="0.1524" layer="21"/>
<wire x1="0.3048" y1="2.5908" x2="-0.3048" y2="2.5908" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="2.5908" x2="-2.2098" y2="2.5908" width="0.1524" layer="21"/>
<wire x1="-2.2098" y1="2.5908" x2="-2.2098" y2="2.4384" width="0.1524" layer="21"/>
<wire x1="-2.2098" y1="1.3716" x2="-2.2098" y2="1.1684" width="0.1524" layer="21"/>
<wire x1="0.3048" y1="2.5908" x2="-0.3048" y2="2.5908" width="0.1524" layer="21" curve="-180"/>
<text x="-3.7338" y="2.2352" size="1.27" layer="21" ratio="6" rot="SR0">*</text>
</package>
<package name="SOIC127P1032X265-24N">
<smd name="1" x="-4.699" y="6.985" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="2" x="-4.699" y="5.715" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="3" x="-4.699" y="4.445" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="4" x="-4.699" y="3.175" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="5" x="-4.699" y="1.905" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="6" x="-4.699" y="0.635" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="7" x="-4.699" y="-0.635" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="8" x="-4.699" y="-1.905" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="9" x="-4.699" y="-3.175" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="10" x="-4.699" y="-4.445" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="11" x="-4.699" y="-5.715" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="12" x="-4.699" y="-6.985" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="13" x="4.699" y="-6.985" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="14" x="4.699" y="-5.715" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="15" x="4.699" y="-4.445" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="16" x="4.699" y="-3.175" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="17" x="4.699" y="-1.905" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="18" x="4.699" y="-0.635" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="19" x="4.699" y="0.635" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="20" x="4.699" y="1.905" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="21" x="4.699" y="3.175" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="22" x="4.699" y="4.445" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="23" x="4.699" y="5.715" dx="1.9812" dy="0.5588" layer="1"/>
<smd name="24" x="4.699" y="6.985" dx="1.9812" dy="0.5588" layer="1"/>
<wire x1="-5.9944" y1="-4.4704" x2="-7.0104" y2="-4.4704" width="0.1524" layer="21"/>
<wire x1="7.0104" y1="1.9812" x2="5.9944" y2="1.9812" width="0.1524" layer="21"/>
<wire x1="3.81" y1="7.5946" x2="3.81" y2="7.7978" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-7.5946" x2="-3.81" y2="-7.7978" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-7.7978" x2="3.81" y2="-7.7978" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-7.7978" x2="3.81" y2="-7.5946" width="0.1524" layer="21"/>
<wire x1="3.81" y1="7.7978" x2="0.3048" y2="7.7978" width="0.1524" layer="21"/>
<wire x1="0.3048" y1="7.7978" x2="-0.3048" y2="7.7978" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="7.7978" x2="-3.81" y2="7.7978" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="7.7978" x2="-3.81" y2="7.5946" width="0.1524" layer="21"/>
<wire x1="0.3048" y1="7.7978" x2="-0.3048" y2="7.7978" width="0.1524" layer="21" curve="-180"/>
<text x="-5.5118" y="7.4168" size="1.27" layer="21" ratio="6" rot="SR0">*</text>
<wire x1="-3.81" y1="6.731" x2="-3.81" y2="7.239" width="0" layer="51"/>
<wire x1="-3.81" y1="7.239" x2="-5.334" y2="7.239" width="0" layer="51"/>
<wire x1="-5.334" y1="7.239" x2="-5.334" y2="6.731" width="0" layer="51"/>
<wire x1="-5.334" y1="6.731" x2="-3.81" y2="6.731" width="0" layer="51"/>
<wire x1="-3.81" y1="-7.239" x2="-3.81" y2="-6.731" width="0" layer="51"/>
<wire x1="-3.81" y1="-6.731" x2="-5.334" y2="-6.731" width="0" layer="51"/>
<wire x1="-5.334" y1="-6.731" x2="-5.334" y2="-7.239" width="0" layer="51"/>
<wire x1="-5.334" y1="-7.239" x2="-3.81" y2="-7.239" width="0" layer="51"/>
<wire x1="3.81" y1="-6.731" x2="3.81" y2="-7.239" width="0" layer="51"/>
<wire x1="3.81" y1="-7.239" x2="5.334" y2="-7.239" width="0" layer="51"/>
<wire x1="5.334" y1="-7.239" x2="5.334" y2="-6.731" width="0" layer="51"/>
<wire x1="5.334" y1="-6.731" x2="3.81" y2="-6.731" width="0" layer="51"/>
<wire x1="3.81" y1="7.239" x2="3.81" y2="6.731" width="0" layer="51"/>
<wire x1="3.81" y1="6.731" x2="5.334" y2="6.731" width="0" layer="51"/>
<wire x1="5.334" y1="6.731" x2="5.334" y2="7.239" width="0" layer="51"/>
<wire x1="5.334" y1="7.239" x2="3.81" y2="7.239" width="0" layer="51"/>
<wire x1="-3.81" y1="-7.7978" x2="3.81" y2="-7.7978" width="0" layer="51"/>
<wire x1="3.81" y1="-7.7978" x2="3.81" y2="7.7978" width="0" layer="51"/>
<wire x1="3.81" y1="7.7978" x2="0.3048" y2="7.7978" width="0" layer="51"/>
<wire x1="0.3048" y1="7.7978" x2="-0.3048" y2="7.7978" width="0" layer="51"/>
<wire x1="-0.3048" y1="7.7978" x2="-3.81" y2="7.7978" width="0" layer="51"/>
<wire x1="-3.81" y1="7.7978" x2="-3.81" y2="-7.7978" width="0" layer="51"/>
<wire x1="0.3048" y1="7.7978" x2="-0.3048" y2="7.7978" width="0" layer="51" curve="-180"/>
<text x="-5.5118" y="7.4168" size="1.27" layer="51" ratio="6" rot="SR0">*</text>
<text x="-3.4544" y="9.525" size="2.0828" layer="25" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-3.4544" y="-10.795" size="2.0828" layer="27" ratio="10" rot="SR0">&gt;VALUE</text>
</package>
<package name="DIP254P762X533-18">
<pad name="1" x="-7.62" y="20.32" drill="1.1176" shape="square"/>
<pad name="2" x="-7.62" y="17.78" drill="1.1176"/>
<pad name="3" x="-7.62" y="15.24" drill="1.1176"/>
<pad name="4" x="-7.62" y="12.7" drill="1.1176"/>
<pad name="5" x="-7.62" y="10.16" drill="1.1176"/>
<pad name="6" x="-7.62" y="7.62" drill="1.1176"/>
<pad name="7" x="-7.62" y="5.08" drill="1.1176"/>
<pad name="8" x="-7.62" y="2.54" drill="1.1176"/>
<pad name="9" x="-7.62" y="0" drill="1.1176"/>
<pad name="10" x="0" y="0" drill="1.1176"/>
<pad name="11" x="0" y="2.54" drill="1.1176"/>
<pad name="12" x="0" y="5.08" drill="1.1176"/>
<pad name="13" x="0" y="7.62" drill="1.1176"/>
<pad name="14" x="0" y="10.16" drill="1.1176"/>
<pad name="15" x="0" y="12.7" drill="1.1176"/>
<pad name="16" x="0" y="15.24" drill="1.1176"/>
<pad name="17" x="0" y="17.78" drill="1.1176"/>
<pad name="18" x="0" y="20.32" drill="1.1176"/>
<wire x1="-0.635" y1="18.923" x2="-0.635" y2="19.177" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="16.383" x2="-0.635" y2="16.637" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="13.843" x2="-0.635" y2="14.097" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="11.303" x2="-0.635" y2="11.557" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="8.763" x2="-0.635" y2="9.017" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-1.27" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.143" x2="-0.635" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="21.59" x2="-3.5052" y2="21.59" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="21.59" x2="-4.1148" y2="21.59" width="0.1524" layer="21"/>
<wire x1="-4.1148" y1="21.59" x2="-6.477" y2="21.59" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="16.637" x2="-6.985" y2="16.383" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="14.097" x2="-6.985" y2="13.843" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="11.557" x2="-6.985" y2="11.303" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="9.017" x2="-6.985" y2="8.763" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="6.477" x2="-6.985" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="3.937" x2="-6.985" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="1.397" x2="-6.985" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="3.683" x2="-0.635" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="6.223" x2="-0.635" y2="6.477" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="21.59" x2="-4.1148" y2="21.59" width="0" layer="21" curve="-180"/>
<text x="-8.2042" y="21.4376" size="1.27" layer="21" ratio="6" rot="SR0">*</text>
<wire x1="-6.985" y1="19.7612" x2="-6.985" y2="20.8788" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="20.8788" x2="-8.1788" y2="20.8788" width="0.1524" layer="51"/>
<wire x1="-8.1788" y1="20.8788" x2="-8.1788" y2="19.7612" width="0.1524" layer="51"/>
<wire x1="-8.1788" y1="19.7612" x2="-6.985" y2="19.7612" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="17.2212" x2="-6.985" y2="18.3388" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="18.3388" x2="-8.1788" y2="18.3388" width="0.1524" layer="51"/>
<wire x1="-8.1788" y1="18.3388" x2="-8.1788" y2="17.2212" width="0.1524" layer="51"/>
<wire x1="-8.1788" y1="17.2212" x2="-6.985" y2="17.2212" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="14.6812" x2="-6.985" y2="15.7988" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="15.7988" x2="-8.1788" y2="15.7988" width="0.1524" layer="51"/>
<wire x1="-8.1788" y1="15.7988" x2="-8.1788" y2="14.6812" width="0.1524" layer="51"/>
<wire x1="-8.1788" y1="14.6812" x2="-6.985" y2="14.6812" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="12.1412" x2="-6.985" y2="13.2588" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="13.2588" x2="-8.1788" y2="13.2588" width="0.1524" layer="51"/>
<wire x1="-8.1788" y1="13.2588" x2="-8.1788" y2="12.1412" width="0.1524" layer="51"/>
<wire x1="-8.1788" y1="12.1412" x2="-6.985" y2="12.1412" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="9.6012" x2="-6.985" y2="10.7188" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="10.7188" x2="-8.1788" y2="10.7188" width="0.1524" layer="51"/>
<wire x1="-8.1788" y1="10.7188" x2="-8.1788" y2="9.6012" width="0.1524" layer="51"/>
<wire x1="-8.1788" y1="9.6012" x2="-6.985" y2="9.6012" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="7.0612" x2="-6.985" y2="8.1788" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="8.1788" x2="-8.1788" y2="8.1788" width="0.1524" layer="51"/>
<wire x1="-8.1788" y1="8.1788" x2="-8.1788" y2="7.0612" width="0.1524" layer="51"/>
<wire x1="-8.1788" y1="7.0612" x2="-6.985" y2="7.0612" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="4.5212" x2="-6.985" y2="5.6388" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="5.6388" x2="-8.1788" y2="5.6388" width="0.1524" layer="51"/>
<wire x1="-8.1788" y1="5.6388" x2="-8.1788" y2="4.5212" width="0.1524" layer="51"/>
<wire x1="-8.1788" y1="4.5212" x2="-6.985" y2="4.5212" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="1.9812" x2="-6.985" y2="3.0988" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="3.0988" x2="-8.1788" y2="3.0988" width="0.1524" layer="51"/>
<wire x1="-8.1788" y1="3.0988" x2="-8.1788" y2="1.9812" width="0.1524" layer="51"/>
<wire x1="-8.1788" y1="1.9812" x2="-6.985" y2="1.9812" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="-0.5588" x2="-6.985" y2="0.5588" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="0.5588" x2="-8.1788" y2="0.5588" width="0.1524" layer="51"/>
<wire x1="-8.1788" y1="0.5588" x2="-8.1788" y2="-0.5588" width="0.1524" layer="51"/>
<wire x1="-8.1788" y1="-0.5588" x2="-6.985" y2="-0.5588" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="0.5588" x2="-0.635" y2="-0.5588" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-0.5588" x2="0.5588" y2="-0.5588" width="0.1524" layer="51"/>
<wire x1="0.5588" y1="-0.5588" x2="0.5588" y2="0.5588" width="0.1524" layer="51"/>
<wire x1="0.5588" y1="0.5588" x2="-0.635" y2="0.5588" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="3.0988" x2="-0.635" y2="1.9812" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="1.9812" x2="0.5588" y2="1.9812" width="0.1524" layer="51"/>
<wire x1="0.5588" y1="1.9812" x2="0.5588" y2="3.0988" width="0.1524" layer="51"/>
<wire x1="0.5588" y1="3.0988" x2="-0.635" y2="3.0988" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="5.6388" x2="-0.635" y2="4.5212" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="4.5212" x2="0.5588" y2="4.5212" width="0.1524" layer="51"/>
<wire x1="0.5588" y1="4.5212" x2="0.5588" y2="5.6388" width="0.1524" layer="51"/>
<wire x1="0.5588" y1="5.6388" x2="-0.635" y2="5.6388" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="8.1788" x2="-0.635" y2="7.0612" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="7.0612" x2="0.5588" y2="7.0612" width="0.1524" layer="51"/>
<wire x1="0.5588" y1="7.0612" x2="0.5588" y2="8.1788" width="0.1524" layer="51"/>
<wire x1="0.5588" y1="8.1788" x2="-0.635" y2="8.1788" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="10.7188" x2="-0.635" y2="9.6012" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="9.6012" x2="0.5588" y2="9.6012" width="0.1524" layer="51"/>
<wire x1="0.5588" y1="9.6012" x2="0.5588" y2="10.7188" width="0.1524" layer="51"/>
<wire x1="0.5588" y1="10.7188" x2="-0.635" y2="10.7188" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="13.2588" x2="-0.635" y2="12.1412" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="12.1412" x2="0.5588" y2="12.1412" width="0.1524" layer="51"/>
<wire x1="0.5588" y1="12.1412" x2="0.5588" y2="13.2588" width="0.1524" layer="51"/>
<wire x1="0.5588" y1="13.2588" x2="-0.635" y2="13.2588" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="15.7988" x2="-0.635" y2="14.6812" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="14.6812" x2="0.5588" y2="14.6812" width="0.1524" layer="51"/>
<wire x1="0.5588" y1="14.6812" x2="0.5588" y2="15.7988" width="0.1524" layer="51"/>
<wire x1="0.5588" y1="15.7988" x2="-0.635" y2="15.7988" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="18.3388" x2="-0.635" y2="17.2212" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="17.2212" x2="0.5588" y2="17.2212" width="0.1524" layer="51"/>
<wire x1="0.5588" y1="17.2212" x2="0.5588" y2="18.3388" width="0.1524" layer="51"/>
<wire x1="0.5588" y1="18.3388" x2="-0.635" y2="18.3388" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="20.8788" x2="-0.635" y2="19.7612" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="19.7612" x2="0.5588" y2="19.7612" width="0.1524" layer="51"/>
<wire x1="0.5588" y1="19.7612" x2="0.5588" y2="20.8788" width="0.1524" layer="51"/>
<wire x1="0.5588" y1="20.8788" x2="-0.635" y2="20.8788" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="-1.27" x2="-0.635" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="-1.27" x2="-0.635" y2="21.59" width="0.1524" layer="51"/>
<wire x1="-0.635" y1="21.59" x2="-3.5052" y2="21.59" width="0.1524" layer="51"/>
<wire x1="-3.5052" y1="21.59" x2="-4.1148" y2="21.59" width="0.1524" layer="51"/>
<wire x1="-4.1148" y1="21.59" x2="-6.985" y2="21.59" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="21.59" x2="-6.985" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-3.5052" y1="21.59" x2="-4.1148" y2="21.59" width="0" layer="51" curve="-180"/>
<text x="-8.2042" y="21.4376" size="1.27" layer="51" ratio="6" rot="SR0">*</text>
<text x="-8.763" y="22.86" size="2.0828" layer="25" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-7.2644" y="-5.08" size="2.0828" layer="27" ratio="10" rot="SR0">&gt;VALUE</text>
</package>
<package name="DIP254P762X533-20">
<pad name="1" x="-7.62" y="22.86" drill="1.1176" shape="square"/>
<pad name="2" x="-7.62" y="20.32" drill="1.1176"/>
<pad name="3" x="-7.62" y="17.78" drill="1.1176"/>
<pad name="4" x="-7.62" y="15.24" drill="1.1176"/>
<pad name="5" x="-7.62" y="12.7" drill="1.1176"/>
<pad name="6" x="-7.62" y="10.16" drill="1.1176"/>
<pad name="7" x="-7.62" y="7.62" drill="1.1176"/>
<pad name="8" x="-7.62" y="5.08" drill="1.1176"/>
<pad name="9" x="-7.62" y="2.54" drill="1.1176"/>
<pad name="10" x="-7.62" y="0" drill="1.1176"/>
<pad name="11" x="0" y="0" drill="1.1176"/>
<pad name="12" x="0" y="2.54" drill="1.1176"/>
<pad name="13" x="0" y="5.08" drill="1.1176"/>
<pad name="14" x="0" y="7.62" drill="1.1176"/>
<pad name="15" x="0" y="10.16" drill="1.1176"/>
<pad name="16" x="0" y="12.7" drill="1.1176"/>
<pad name="17" x="0" y="15.24" drill="1.1176"/>
<pad name="18" x="0" y="17.78" drill="1.1176"/>
<pad name="19" x="0" y="20.32" drill="1.1176"/>
<pad name="20" x="0" y="22.86" drill="1.1176"/>
<wire x1="-0.254" y1="24.1554" x2="-0.254" y2="24.892" width="0.1524" layer="21"/>
<wire x1="-7.366" y1="-1.2954" x2="-7.366" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-7.366" y1="-2.032" x2="-0.254" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-2.032" x2="-0.254" y2="-1.2954" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="24.892" x2="-3.5052" y2="24.892" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="24.892" x2="-4.1148" y2="24.892" width="0.1524" layer="21"/>
<wire x1="-4.1148" y1="24.892" x2="-7.366" y2="24.892" width="0.1524" layer="21"/>
<wire x1="-7.366" y1="24.892" x2="-7.366" y2="24.1808" width="0.1524" layer="21"/>
<wire x1="-3.5052" y1="24.892" x2="-4.1148" y2="24.892" width="0.1524" layer="21" curve="-180"/>
<text x="-8.2042" y="23.9776" size="1.27" layer="21" ratio="6" rot="SR0">*</text>
<wire x1="-7.366" y1="22.3012" x2="-7.366" y2="23.4188" width="0" layer="51"/>
<wire x1="-7.366" y1="23.4188" x2="-8.1788" y2="23.4188" width="0" layer="51"/>
<wire x1="-8.1788" y1="23.4188" x2="-8.1788" y2="22.3012" width="0" layer="51"/>
<wire x1="-8.1788" y1="22.3012" x2="-7.366" y2="22.3012" width="0" layer="51"/>
<wire x1="-7.366" y1="19.7612" x2="-7.366" y2="20.8788" width="0" layer="51"/>
<wire x1="-7.366" y1="20.8788" x2="-8.1788" y2="20.8788" width="0" layer="51"/>
<wire x1="-8.1788" y1="20.8788" x2="-8.1788" y2="19.7612" width="0" layer="51"/>
<wire x1="-8.1788" y1="19.7612" x2="-7.366" y2="19.7612" width="0" layer="51"/>
<wire x1="-7.366" y1="17.2212" x2="-7.366" y2="18.3388" width="0" layer="51"/>
<wire x1="-7.366" y1="18.3388" x2="-8.1788" y2="18.3388" width="0" layer="51"/>
<wire x1="-8.1788" y1="18.3388" x2="-8.1788" y2="17.2212" width="0" layer="51"/>
<wire x1="-8.1788" y1="17.2212" x2="-7.366" y2="17.2212" width="0" layer="51"/>
<wire x1="-7.366" y1="14.6812" x2="-7.366" y2="15.7988" width="0" layer="51"/>
<wire x1="-7.366" y1="15.7988" x2="-8.1788" y2="15.7988" width="0" layer="51"/>
<wire x1="-8.1788" y1="15.7988" x2="-8.1788" y2="14.6812" width="0" layer="51"/>
<wire x1="-8.1788" y1="14.6812" x2="-7.366" y2="14.6812" width="0" layer="51"/>
<wire x1="-7.366" y1="12.1412" x2="-7.366" y2="13.2588" width="0" layer="51"/>
<wire x1="-7.366" y1="13.2588" x2="-8.1788" y2="13.2588" width="0" layer="51"/>
<wire x1="-8.1788" y1="13.2588" x2="-8.1788" y2="12.1412" width="0" layer="51"/>
<wire x1="-8.1788" y1="12.1412" x2="-7.366" y2="12.1412" width="0" layer="51"/>
<wire x1="-7.366" y1="9.6012" x2="-7.366" y2="10.7188" width="0" layer="51"/>
<wire x1="-7.366" y1="10.7188" x2="-8.1788" y2="10.7188" width="0" layer="51"/>
<wire x1="-8.1788" y1="10.7188" x2="-8.1788" y2="9.6012" width="0" layer="51"/>
<wire x1="-8.1788" y1="9.6012" x2="-7.366" y2="9.6012" width="0" layer="51"/>
<wire x1="-7.366" y1="7.0612" x2="-7.366" y2="8.1788" width="0" layer="51"/>
<wire x1="-7.366" y1="8.1788" x2="-8.1788" y2="8.1788" width="0" layer="51"/>
<wire x1="-8.1788" y1="8.1788" x2="-8.1788" y2="7.0612" width="0" layer="51"/>
<wire x1="-8.1788" y1="7.0612" x2="-7.366" y2="7.0612" width="0" layer="51"/>
<wire x1="-7.366" y1="4.5212" x2="-7.366" y2="5.6388" width="0" layer="51"/>
<wire x1="-7.366" y1="5.6388" x2="-8.1788" y2="5.6388" width="0" layer="51"/>
<wire x1="-8.1788" y1="5.6388" x2="-8.1788" y2="4.5212" width="0" layer="51"/>
<wire x1="-8.1788" y1="4.5212" x2="-7.366" y2="4.5212" width="0" layer="51"/>
<wire x1="-7.366" y1="1.9812" x2="-7.366" y2="3.0988" width="0" layer="51"/>
<wire x1="-7.366" y1="3.0988" x2="-8.1788" y2="3.0988" width="0" layer="51"/>
<wire x1="-8.1788" y1="3.0988" x2="-8.1788" y2="1.9812" width="0" layer="51"/>
<wire x1="-8.1788" y1="1.9812" x2="-7.366" y2="1.9812" width="0" layer="51"/>
<wire x1="-7.366" y1="-0.5588" x2="-7.366" y2="0.5588" width="0" layer="51"/>
<wire x1="-7.366" y1="0.5588" x2="-8.1788" y2="0.5588" width="0" layer="51"/>
<wire x1="-8.1788" y1="0.5588" x2="-8.1788" y2="-0.5588" width="0" layer="51"/>
<wire x1="-8.1788" y1="-0.5588" x2="-7.366" y2="-0.5588" width="0" layer="51"/>
<wire x1="-0.254" y1="0.5588" x2="-0.254" y2="-0.5588" width="0" layer="51"/>
<wire x1="-0.254" y1="-0.5588" x2="0.5588" y2="-0.5588" width="0" layer="51"/>
<wire x1="0.5588" y1="-0.5588" x2="0.5588" y2="0.5588" width="0" layer="51"/>
<wire x1="0.5588" y1="0.5588" x2="-0.254" y2="0.5588" width="0" layer="51"/>
<wire x1="-0.254" y1="3.0988" x2="-0.254" y2="1.9812" width="0" layer="51"/>
<wire x1="-0.254" y1="1.9812" x2="0.5588" y2="1.9812" width="0" layer="51"/>
<wire x1="0.5588" y1="1.9812" x2="0.5588" y2="3.0988" width="0" layer="51"/>
<wire x1="0.5588" y1="3.0988" x2="-0.254" y2="3.0988" width="0" layer="51"/>
<wire x1="-0.254" y1="5.6388" x2="-0.254" y2="4.5212" width="0" layer="51"/>
<wire x1="-0.254" y1="4.5212" x2="0.5588" y2="4.5212" width="0" layer="51"/>
<wire x1="0.5588" y1="4.5212" x2="0.5588" y2="5.6388" width="0" layer="51"/>
<wire x1="0.5588" y1="5.6388" x2="-0.254" y2="5.6388" width="0" layer="51"/>
<wire x1="-0.254" y1="8.1788" x2="-0.254" y2="7.0612" width="0" layer="51"/>
<wire x1="-0.254" y1="7.0612" x2="0.5588" y2="7.0612" width="0" layer="51"/>
<wire x1="0.5588" y1="7.0612" x2="0.5588" y2="8.1788" width="0" layer="51"/>
<wire x1="0.5588" y1="8.1788" x2="-0.254" y2="8.1788" width="0" layer="51"/>
<wire x1="-0.254" y1="10.7188" x2="-0.254" y2="9.6012" width="0" layer="51"/>
<wire x1="-0.254" y1="9.6012" x2="0.5588" y2="9.6012" width="0" layer="51"/>
<wire x1="0.5588" y1="9.6012" x2="0.5588" y2="10.7188" width="0" layer="51"/>
<wire x1="0.5588" y1="10.7188" x2="-0.254" y2="10.7188" width="0" layer="51"/>
<wire x1="-0.254" y1="13.2588" x2="-0.254" y2="12.1412" width="0" layer="51"/>
<wire x1="-0.254" y1="12.1412" x2="0.5588" y2="12.1412" width="0" layer="51"/>
<wire x1="0.5588" y1="12.1412" x2="0.5588" y2="13.2588" width="0" layer="51"/>
<wire x1="0.5588" y1="13.2588" x2="-0.254" y2="13.2588" width="0" layer="51"/>
<wire x1="-0.254" y1="15.7988" x2="-0.254" y2="14.6812" width="0" layer="51"/>
<wire x1="-0.254" y1="14.6812" x2="0.5588" y2="14.6812" width="0" layer="51"/>
<wire x1="0.5588" y1="14.6812" x2="0.5588" y2="15.7988" width="0" layer="51"/>
<wire x1="0.5588" y1="15.7988" x2="-0.254" y2="15.7988" width="0" layer="51"/>
<wire x1="-0.254" y1="18.3388" x2="-0.254" y2="17.2212" width="0" layer="51"/>
<wire x1="-0.254" y1="17.2212" x2="0.5588" y2="17.2212" width="0" layer="51"/>
<wire x1="0.5588" y1="17.2212" x2="0.5588" y2="18.3388" width="0" layer="51"/>
<wire x1="0.5588" y1="18.3388" x2="-0.254" y2="18.3388" width="0" layer="51"/>
<wire x1="-0.254" y1="20.8788" x2="-0.254" y2="19.7612" width="0" layer="51"/>
<wire x1="-0.254" y1="19.7612" x2="0.5588" y2="19.7612" width="0" layer="51"/>
<wire x1="0.5588" y1="19.7612" x2="0.5588" y2="20.8788" width="0" layer="51"/>
<wire x1="0.5588" y1="20.8788" x2="-0.254" y2="20.8788" width="0" layer="51"/>
<wire x1="-0.254" y1="23.4188" x2="-0.254" y2="22.3012" width="0" layer="51"/>
<wire x1="-0.254" y1="22.3012" x2="0.5588" y2="22.3012" width="0" layer="51"/>
<wire x1="0.5588" y1="22.3012" x2="0.5588" y2="23.4188" width="0" layer="51"/>
<wire x1="0.5588" y1="23.4188" x2="-0.254" y2="23.4188" width="0" layer="51"/>
<wire x1="-7.366" y1="-2.032" x2="-0.254" y2="-2.032" width="0" layer="51"/>
<wire x1="-0.254" y1="-2.032" x2="-0.254" y2="24.892" width="0" layer="51"/>
<wire x1="-0.254" y1="24.892" x2="-3.5052" y2="24.892" width="0" layer="51"/>
<wire x1="-3.5052" y1="24.892" x2="-4.1148" y2="24.892" width="0" layer="51"/>
<wire x1="-4.1148" y1="24.892" x2="-7.366" y2="24.892" width="0" layer="51"/>
<wire x1="-7.366" y1="24.892" x2="-7.366" y2="-2.032" width="0" layer="51"/>
<wire x1="-3.5052" y1="24.892" x2="-4.1148" y2="24.892" width="0" layer="51" curve="-180"/>
<text x="-8.2042" y="23.9776" size="1.27" layer="51" ratio="6" rot="SR0">*</text>
<text x="-8.1534" y="26.035" size="2.0828" layer="25" ratio="10" rot="SR0">&gt;NAME</text>
</package>
</packages>
<symbols>
<symbol name="A1101ELHLT-T">
<pin name="VCC" x="-17.78" y="0" length="middle" direction="pwr"/>
<pin name="GND" x="-17.78" y="-5.08" length="middle" direction="pas"/>
<pin name="VOUT" x="17.78" y="0" length="middle" direction="out" rot="R180"/>
<wire x1="-12.7" y1="5.08" x2="-12.7" y2="-10.16" width="0.4064" layer="94"/>
<wire x1="-12.7" y1="-10.16" x2="12.7" y2="-10.16" width="0.4064" layer="94"/>
<wire x1="12.7" y1="-10.16" x2="12.7" y2="5.08" width="0.4064" layer="94"/>
<wire x1="12.7" y1="5.08" x2="-12.7" y2="5.08" width="0.4064" layer="94"/>
<text x="-5.3594" y="9.1186" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-3.8862" y="-14.3256" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A1203LLHLT-T">
<text x="-4.2926" y="-14.097" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A1321ELHLT-T">
</symbol>
<symbol name="A3901SEJTR-T">
<pin name="VBB" x="-17.78" y="7.62" length="middle" direction="pwr"/>
<pin name="IN1" x="-17.78" y="2.54" length="middle" direction="in"/>
<pin name="IN2" x="-17.78" y="0" length="middle" direction="in"/>
<pin name="IN3" x="-17.78" y="-2.54" length="middle" direction="in"/>
<pin name="IN4" x="-17.78" y="-5.08" length="middle" direction="in"/>
<pin name="GND" x="-17.78" y="-10.16" length="middle" direction="pas"/>
<pin name="EPAD" x="-17.78" y="-12.7" length="middle" direction="pas"/>
<pin name="OUT1" x="17.78" y="7.62" length="middle" direction="out" rot="R180"/>
<pin name="OUT2" x="17.78" y="5.08" length="middle" direction="out" rot="R180"/>
<pin name="OUT3" x="17.78" y="2.54" length="middle" direction="out" rot="R180"/>
<pin name="OUT4" x="17.78" y="0" length="middle" direction="out" rot="R180"/>
<wire x1="-12.7" y1="12.7" x2="-12.7" y2="-17.78" width="0.4064" layer="94"/>
<wire x1="-12.7" y1="-17.78" x2="12.7" y2="-17.78" width="0.4064" layer="94"/>
<wire x1="12.7" y1="-17.78" x2="12.7" y2="12.7" width="0.4064" layer="94"/>
<wire x1="12.7" y1="12.7" x2="-12.7" y2="12.7" width="0.4064" layer="94"/>
<text x="-5.3594" y="14.351" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-4.4196" y="-20.5486" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A3953SB-T">
<pin name="LOGIC_SUPPLY" x="-25.4" y="17.78" length="middle" direction="pwr"/>
<pin name="LOAD_SUPPLY" x="-25.4" y="12.7" length="middle" direction="pwr"/>
<pin name="LOAD_SUPPLY_2" x="-25.4" y="10.16" length="middle" direction="pwr"/>
<pin name="~EN" x="-25.4" y="5.08" length="middle" direction="in"/>
<pin name="SENSE" x="-25.4" y="2.54" length="middle" direction="in"/>
<pin name="RC" x="-25.4" y="-2.54" length="middle" direction="in"/>
<pin name="MODE" x="-25.4" y="-5.08" length="middle" direction="in"/>
<pin name="~BRAKE" x="-25.4" y="-7.62" length="middle" direction="in"/>
<pin name="REF" x="-25.4" y="-10.16" length="middle" direction="in"/>
<pin name="PHASE" x="-25.4" y="-12.7" length="middle" direction="in"/>
<pin name="GND_2" x="-25.4" y="-17.78" length="middle" direction="pas"/>
<pin name="GND_3" x="-25.4" y="-20.32" length="middle" direction="pas"/>
<pin name="GND_4" x="-25.4" y="-22.86" length="middle" direction="pas"/>
<pin name="GND" x="-25.4" y="-25.4" length="middle" direction="pas"/>
<pin name="OUTA" x="25.4" y="17.78" length="middle" direction="out" rot="R180"/>
<pin name="OUTB" x="25.4" y="15.24" length="middle" direction="out" rot="R180"/>
<wire x1="-20.32" y1="22.86" x2="-20.32" y2="-30.48" width="0.4064" layer="94"/>
<wire x1="-20.32" y1="-30.48" x2="20.32" y2="-30.48" width="0.4064" layer="94"/>
<wire x1="20.32" y1="-30.48" x2="20.32" y2="22.86" width="0.4064" layer="94"/>
<wire x1="20.32" y1="22.86" x2="-20.32" y2="22.86" width="0.4064" layer="94"/>
<text x="-4.6482" y="25.4762" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-4.2164" y="-34.6202" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A3955SB-T">
<pin name="LOGIC_SUPPLY" x="-25.4" y="20.32" length="middle" direction="pwr"/>
<pin name="LOAD_SUPPLY" x="-25.4" y="15.24" length="middle" direction="pwr"/>
<pin name="D0" x="-25.4" y="10.16" length="middle" direction="in"/>
<pin name="D1" x="-25.4" y="7.62" length="middle" direction="in"/>
<pin name="D2" x="-25.4" y="5.08" length="middle" direction="in"/>
<pin name="SENSE" x="-25.4" y="0" length="middle" direction="in"/>
<pin name="RC" x="-25.4" y="-5.08" length="middle" direction="in"/>
<pin name="PFD" x="-25.4" y="-7.62" length="middle" direction="in"/>
<pin name="OUTA" x="25.4" y="20.32" length="middle" direction="out" rot="R180"/>
<pin name="OUTB" x="25.4" y="17.78" length="middle" direction="out" rot="R180"/>
<wire x1="-20.32" y1="25.4" x2="-20.32" y2="-30.48" width="0.4064" layer="94"/>
<wire x1="20.32" y1="-30.48" x2="20.32" y2="25.4" width="0.4064" layer="94"/>
<wire x1="20.32" y1="25.4" x2="-20.32" y2="25.4" width="0.4064" layer="94"/>
<text x="-6.1214" y="27.9146" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-5.588" y="-34.1376" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A3967SLB-T">
<pin name="LOAD_SUPPLY1" x="-27.94" y="27.94" length="middle" direction="pwr"/>
<pin name="LOAD_SUPPLY2" x="-27.94" y="25.4" length="middle" direction="pwr"/>
<pin name="LOGIC_SUPPLY" x="-27.94" y="22.86" length="middle" direction="in"/>
<pin name="MS1" x="-27.94" y="17.78" length="middle" direction="in"/>
<pin name="MS2" x="-27.94" y="15.24" length="middle" direction="in"/>
<pin name="SENSE1" x="-27.94" y="10.16" length="middle" direction="in"/>
<pin name="SENSE2" x="-27.94" y="7.62" length="middle" direction="in"/>
<pin name="RC1" x="-27.94" y="2.54" length="middle" direction="in"/>
<pin name="RC2" x="-27.94" y="0" length="middle" direction="in"/>
<pin name="REF" x="-27.94" y="-5.08" length="middle" direction="in"/>
<pin name="STEP" x="-27.94" y="-7.62" length="middle" direction="in"/>
<pin name="DIR" x="-27.94" y="-10.16" length="middle" direction="in"/>
<pin name="PFD" x="-27.94" y="-12.7" length="middle" direction="in"/>
<pin name="~RESET" x="-27.94" y="-15.24" length="middle" direction="in"/>
<pin name="~SLEEP" x="-27.94" y="-17.78" length="middle" direction="in"/>
<pin name="~ENABLE" x="-27.94" y="-20.32" length="middle" direction="in"/>
<pin name="GND_2" x="-27.94" y="-25.4" length="middle" direction="pas"/>
<pin name="GND_3" x="-27.94" y="-27.94" length="middle" direction="pas"/>
<pin name="GND_4" x="-27.94" y="-30.48" length="middle" direction="pas"/>
<pin name="GND" x="-27.94" y="-33.02" length="middle" direction="pas"/>
<pin name="OUT1A" x="27.94" y="27.94" length="middle" direction="out" rot="R180"/>
<pin name="OUT1B" x="27.94" y="25.4" length="middle" direction="out" rot="R180"/>
<pin name="OUT2A" x="27.94" y="20.32" length="middle" direction="out" rot="R180"/>
<pin name="OUT2B" x="27.94" y="17.78" length="middle" direction="out" rot="R180"/>
<wire x1="-22.86" y1="33.02" x2="-22.86" y2="-38.1" width="0.4064" layer="94"/>
<wire x1="-22.86" y1="-38.1" x2="22.86" y2="-38.1" width="0.4064" layer="94"/>
<wire x1="22.86" y1="-38.1" x2="22.86" y2="33.02" width="0.4064" layer="94"/>
<wire x1="22.86" y1="33.02" x2="-22.86" y2="33.02" width="0.4064" layer="94"/>
<text x="-5.9944" y="35.1028" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-3.0988" y="-42.5196" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A3972SB-T">
<pin name="LOGIC_SUPPLY" x="-25.4" y="27.94" length="middle" direction="pwr"/>
<pin name="LOAD_SUPPLY1" x="-25.4" y="25.4" length="middle" direction="pwr"/>
<pin name="LOAD_SUPPLY2" x="-25.4" y="22.86" length="middle" direction="pwr"/>
<pin name="CLK" x="-25.4" y="17.78" length="middle" direction="in"/>
<pin name="OSC" x="-25.4" y="15.24" length="middle" direction="in"/>
<pin name="SEN1" x="-25.4" y="10.16" length="middle" direction="in"/>
<pin name="SEN2" x="-25.4" y="7.62" length="middle" direction="in"/>
<pin name="CP1" x="-25.4" y="2.54" length="middle" direction="pas"/>
<pin name="CP2" x="-25.4" y="0" length="middle" direction="pas"/>
<pin name="STRB" x="-25.4" y="-5.08" length="middle" direction="in"/>
<pin name="DATA" x="-25.4" y="-7.62" length="middle" direction="in"/>
<pin name="VCP" x="-25.4" y="-10.16" length="middle" direction="pas"/>
<pin name="REF" x="-25.4" y="-12.7" length="middle" direction="in"/>
<pin name="MUX" x="-25.4" y="-15.24" length="middle" direction="pas"/>
<pin name="VREG" x="-25.4" y="-17.78" length="middle" direction="pas"/>
<pin name="SLEEP" x="-25.4" y="-20.32" length="middle" direction="in"/>
<pin name="GND_2" x="-25.4" y="-25.4" length="middle" direction="pas"/>
<pin name="GND_3" x="-25.4" y="-27.94" length="middle" direction="pas"/>
<pin name="GND_4" x="-25.4" y="-30.48" length="middle" direction="pas"/>
<pin name="GND" x="-25.4" y="-33.02" length="middle" direction="pas"/>
<pin name="OUT1A" x="25.4" y="27.94" length="middle" direction="out" rot="R180"/>
<pin name="OUT1B" x="25.4" y="25.4" length="middle" direction="out" rot="R180"/>
<pin name="OUT2A" x="25.4" y="22.86" length="middle" direction="out" rot="R180"/>
<pin name="OUT2B" x="25.4" y="20.32" length="middle" direction="out" rot="R180"/>
<wire x1="-20.32" y1="33.02" x2="-20.32" y2="-38.1" width="0.4064" layer="94"/>
<wire x1="-20.32" y1="-38.1" x2="20.32" y2="-38.1" width="0.4064" layer="94"/>
<wire x1="20.32" y1="-38.1" x2="20.32" y2="33.02" width="0.4064" layer="94"/>
<wire x1="20.32" y1="33.02" x2="-20.32" y2="33.02" width="0.4064" layer="94"/>
<text x="-6.6802" y="35.6362" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-3.9624" y="-42.3418" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A4931METTR-T">
<pin name="VBB" x="-20.32" y="27.94" length="middle" direction="pwr"/>
<pin name="VCP" x="-20.32" y="22.86" length="middle" direction="pas"/>
<pin name="DIR" x="-20.32" y="20.32" length="middle" direction="in"/>
<pin name="SENSE" x="-20.32" y="17.78" length="middle" direction="pas"/>
<pin name="BRAKEZ" x="-20.32" y="15.24" length="middle" direction="in"/>
<pin name="CLD" x="-20.32" y="10.16" length="middle" direction="pas"/>
<pin name="EN" x="-20.32" y="7.62" length="middle" direction="in"/>
<pin name="HA+" x="-20.32" y="2.54" length="middle" direction="in"/>
<pin name="HA-" x="-20.32" y="0" length="middle" direction="in"/>
<pin name="HB+" x="-20.32" y="-2.54" length="middle" direction="in"/>
<pin name="HB-" x="-20.32" y="-5.08" length="middle" direction="in"/>
<pin name="HC+" x="-20.32" y="-7.62" length="middle" direction="in"/>
<pin name="HC-" x="-20.32" y="-10.16" length="middle" direction="in"/>
<pin name="CP1" x="-20.32" y="-15.24" length="middle" direction="pas"/>
<pin name="CP2" x="-20.32" y="-17.78" length="middle" direction="pas"/>
<pin name="SA" x="-20.32" y="-22.86" length="middle" direction="pas"/>
<pin name="SB" x="-20.32" y="-25.4" length="middle" direction="pas"/>
<pin name="SC" x="-20.32" y="-27.94" length="middle" direction="pas"/>
<pin name="GND" x="-20.32" y="-33.02" length="middle" direction="pas"/>
<pin name="EPAD" x="-20.32" y="-35.56" length="middle" direction="pas"/>
<pin name="GLA" x="20.32" y="27.94" length="middle" direction="out" rot="R180"/>
<pin name="GLB" x="20.32" y="25.4" length="middle" direction="out" rot="R180"/>
<pin name="GLC" x="20.32" y="22.86" length="middle" direction="out" rot="R180"/>
<pin name="GHA" x="20.32" y="17.78" length="middle" direction="out" rot="R180"/>
<pin name="GHB" x="20.32" y="15.24" length="middle" direction="out" rot="R180"/>
<pin name="HBIAS" x="20.32" y="12.7" length="middle" direction="out" rot="R180"/>
<pin name="GHC" x="20.32" y="10.16" length="middle" direction="out" rot="R180"/>
<pin name="FG1" x="20.32" y="5.08" length="middle" direction="out" rot="R180"/>
<pin name="FG2" x="20.32" y="2.54" length="middle" direction="out" rot="R180"/>
<wire x1="-15.24" y1="33.02" x2="-15.24" y2="-40.64" width="0.4064" layer="94"/>
<wire x1="-15.24" y1="-40.64" x2="15.24" y2="-40.64" width="0.4064" layer="94"/>
<wire x1="15.24" y1="-40.64" x2="15.24" y2="33.02" width="0.4064" layer="94"/>
<wire x1="15.24" y1="33.02" x2="-15.24" y2="33.02" width="0.4064" layer="94"/>
<text x="-4.9784" y="36.1442" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-3.7846" y="-44.8056" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A4982SETTR-T">
<pin name="VDD" x="-20.32" y="25.4" length="middle" direction="pwr"/>
<pin name="VBB1" x="-20.32" y="22.86" length="middle" direction="pwr"/>
<pin name="VBB2" x="-20.32" y="20.32" length="middle" direction="pwr"/>
<pin name="~ENABLE" x="-20.32" y="15.24" length="middle" direction="in"/>
<pin name="VCP" x="-20.32" y="12.7" length="middle" direction="pas"/>
<pin name="VREG" x="-20.32" y="10.16" length="middle" direction="pas"/>
<pin name="~RESET" x="-20.32" y="7.62" length="middle" direction="in"/>
<pin name="ROSC" x="-20.32" y="5.08" length="middle" direction="in"/>
<pin name="~SLEEP" x="-20.32" y="2.54" length="middle" direction="in"/>
<pin name="REF" x="-20.32" y="0" length="middle" direction="in"/>
<pin name="STEP" x="-20.32" y="-2.54" length="middle" direction="in"/>
<pin name="DIR" x="-20.32" y="-5.08" length="middle" direction="in"/>
<pin name="SENSE1" x="-20.32" y="-7.62" length="middle" direction="in"/>
<pin name="SENSE2" x="-20.32" y="-10.16" length="middle" direction="in"/>
<pin name="CP1" x="-20.32" y="-12.7" length="middle" direction="pas"/>
<pin name="CP2" x="-20.32" y="-15.24" length="middle" direction="pas"/>
<pin name="MS1" x="-20.32" y="-17.78" length="middle" direction="in"/>
<pin name="MS2" x="-20.32" y="-20.32" length="middle" direction="in"/>
<pin name="GND_2" x="-20.32" y="-25.4" length="middle" direction="in"/>
<pin name="GND" x="-20.32" y="-27.94" length="middle" direction="pas"/>
<pin name="PAD" x="-20.32" y="-30.48" length="middle" direction="pas"/>
<pin name="OUT1A" x="20.32" y="25.4" length="middle" direction="out" rot="R180"/>
<pin name="OUT2A" x="20.32" y="22.86" length="middle" direction="out" rot="R180"/>
<pin name="OUT1B" x="20.32" y="20.32" length="middle" direction="out" rot="R180"/>
<pin name="OUT2B" x="20.32" y="17.78" length="middle" direction="out" rot="R180"/>
<pin name="NC_2" x="20.32" y="12.7" length="middle" direction="nc" rot="R180"/>
<pin name="NC_3" x="20.32" y="10.16" length="middle" direction="nc" rot="R180"/>
<pin name="NC_4" x="20.32" y="7.62" length="middle" direction="nc" rot="R180"/>
<pin name="NC_5" x="20.32" y="5.08" length="middle" direction="nc" rot="R180"/>
<pin name="NC_6" x="20.32" y="2.54" length="middle" direction="nc" rot="R180"/>
<pin name="NC_7" x="20.32" y="0" length="middle" direction="nc" rot="R180"/>
<pin name="NC_8" x="20.32" y="-2.54" length="middle" direction="nc" rot="R180"/>
<pin name="NC" x="20.32" y="-5.08" length="middle" direction="nc" rot="R180"/>
<wire x1="-15.24" y1="30.48" x2="-15.24" y2="-35.56" width="0.4064" layer="94"/>
<wire x1="-15.24" y1="-35.56" x2="15.24" y2="-35.56" width="0.4064" layer="94"/>
<wire x1="15.24" y1="-35.56" x2="15.24" y2="30.48" width="0.4064" layer="94"/>
<wire x1="15.24" y1="30.48" x2="-15.24" y2="30.48" width="0.4064" layer="94"/>
<text x="-5.5626" y="32.8168" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-4.3434" y="-39.9034" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A4982SLPTR-T">
<pin name="VDD" x="-17.78" y="25.4" length="middle" direction="pwr"/>
<pin name="VBB1" x="-17.78" y="22.86" length="middle" direction="pwr"/>
<pin name="VBB2" x="-17.78" y="20.32" length="middle" direction="pwr"/>
<pin name="CP1" x="-17.78" y="15.24" length="middle" direction="pas"/>
<pin name="CP2" x="-17.78" y="12.7" length="middle" direction="pas"/>
<pin name="MS1" x="-17.78" y="10.16" length="middle" direction="in"/>
<pin name="MS2" x="-17.78" y="7.62" length="middle" direction="in"/>
<pin name="VCP" x="-17.78" y="5.08" length="middle" direction="pas"/>
<pin name="VREG" x="-17.78" y="2.54" length="middle" direction="pas"/>
<pin name="~RESET" x="-17.78" y="0" length="middle" direction="in"/>
<pin name="ROSC" x="-17.78" y="-2.54" length="middle" direction="in"/>
<pin name="~SLEEP" x="-17.78" y="-5.08" length="middle" direction="in"/>
<pin name="STEP" x="-17.78" y="-7.62" length="middle" direction="in"/>
<pin name="REF" x="-17.78" y="-10.16" length="middle" direction="in"/>
<pin name="DIR" x="-17.78" y="-12.7" length="middle" direction="in"/>
<pin name="~ENABLE" x="-17.78" y="-15.24" length="middle" direction="in"/>
<pin name="SENSE1" x="-17.78" y="-17.78" length="middle" direction="in"/>
<pin name="SENSE2" x="-17.78" y="-20.32" length="middle" direction="in"/>
<pin name="GND_2" x="-17.78" y="-25.4" length="middle" direction="pas"/>
<pin name="GND" x="-17.78" y="-27.94" length="middle" direction="pas"/>
<pin name="PAD" x="-17.78" y="-30.48" length="middle" direction="pas"/>
<pin name="OUT1A" x="17.78" y="25.4" length="middle" direction="out" rot="R180"/>
<pin name="OUT2A" x="17.78" y="22.86" length="middle" direction="out" rot="R180"/>
<pin name="OUT1B" x="17.78" y="17.78" length="middle" direction="out" rot="R180"/>
<pin name="OUT2B" x="17.78" y="15.24" length="middle" direction="out" rot="R180"/>
<wire x1="-12.7" y1="30.48" x2="-12.7" y2="-35.56" width="0.4064" layer="94"/>
<wire x1="-12.7" y1="-35.56" x2="12.7" y2="-35.56" width="0.4064" layer="94"/>
<wire x1="12.7" y1="-35.56" x2="12.7" y2="30.48" width="0.4064" layer="94"/>
<wire x1="12.7" y1="30.48" x2="-12.7" y2="30.48" width="0.4064" layer="94"/>
<text x="-4.2418" y="32.8168" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-5.6642" y="-39.5224" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A4983SETTR-T">
<pin name="VDD" x="-17.78" y="33.02" length="middle" direction="pwr"/>
<pin name="VBB1" x="-17.78" y="30.48" length="middle" direction="pwr"/>
<pin name="VBB2" x="-17.78" y="27.94" length="middle" direction="pwr"/>
<pin name="ROSC" x="-17.78" y="22.86" length="middle" direction="in"/>
<pin name="VCP" x="-17.78" y="20.32" length="middle" direction="pas"/>
<pin name="STEP" x="-17.78" y="17.78" length="middle" direction="in"/>
<pin name="REF" x="-17.78" y="15.24" length="middle" direction="in"/>
<pin name="DIR" x="-17.78" y="12.7" length="middle" direction="in"/>
<pin name="ENABLE" x="-17.78" y="10.16" length="middle" direction="in"/>
<pin name="RESET" x="-17.78" y="7.62" length="middle" direction="in"/>
<pin name="SLEEP" x="-17.78" y="5.08" length="middle" direction="in"/>
<pin name="VREG" x="-17.78" y="2.54" length="middle" direction="in"/>
<pin name="CP1" x="-17.78" y="-2.54" length="middle" direction="in"/>
<pin name="CP2" x="-17.78" y="-5.08" length="middle" direction="in"/>
<pin name="MS1" x="-17.78" y="-10.16" length="middle" direction="in"/>
<pin name="MS2" x="-17.78" y="-12.7" length="middle" direction="in"/>
<pin name="MS3" x="-17.78" y="-15.24" length="middle" direction="in"/>
<pin name="SENSE1" x="-17.78" y="-20.32" length="middle" direction="in"/>
<pin name="SENSE2" x="-17.78" y="-22.86" length="middle" direction="in"/>
<pin name="NC_2" x="-17.78" y="-27.94" length="middle" direction="nc"/>
<pin name="NC_3" x="-17.78" y="-30.48" length="middle" direction="nc"/>
<pin name="NC" x="-17.78" y="-33.02" length="middle" direction="nc"/>
<pin name="GND_2" x="-17.78" y="-35.56" length="middle" direction="pas"/>
<pin name="GND" x="-17.78" y="-38.1" length="middle" direction="pas"/>
<pin name="EPAD" x="-17.78" y="-40.64" length="middle" direction="pas"/>
<pin name="OUT1B" x="17.78" y="33.02" length="middle" direction="out" rot="R180"/>
<pin name="OUT1A" x="17.78" y="30.48" length="middle" direction="out" rot="R180"/>
<pin name="OUT2A" x="17.78" y="27.94" length="middle" direction="out" rot="R180"/>
<pin name="OUT2B" x="17.78" y="25.4" length="middle" direction="out" rot="R180"/>
<wire x1="-12.7" y1="38.1" x2="-12.7" y2="-45.72" width="0.4064" layer="94"/>
<wire x1="-12.7" y1="-45.72" x2="12.7" y2="-45.72" width="0.4064" layer="94"/>
<wire x1="12.7" y1="-45.72" x2="12.7" y2="38.1" width="0.4064" layer="94"/>
<wire x1="12.7" y1="38.1" x2="-12.7" y2="38.1" width="0.4064" layer="94"/>
<text x="-5.7912" y="40.5384" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-3.7846" y="-49.8094" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A4984SESTR-T">
<pin name="CP1" x="-20.32" y="7.62" length="middle" direction="pas"/>
<pin name="CP2" x="-20.32" y="5.08" length="middle" direction="pas"/>
<pin name="MS1" x="-20.32" y="2.54" length="middle" direction="in"/>
<pin name="MS2" x="-20.32" y="0" length="middle" direction="in"/>
<pin name="~RESET" x="-20.32" y="-2.54" length="middle" direction="in"/>
<pin name="ROSC" x="-20.32" y="-5.08" length="middle" direction="in"/>
<pin name="~SLEEP" x="-20.32" y="-7.62" length="middle" direction="in"/>
<pin name="STEP" x="-20.32" y="-10.16" length="middle" direction="in"/>
<pin name="REF" x="-20.32" y="-12.7" length="middle" direction="in"/>
<pin name="DIR" x="-20.32" y="-15.24" length="middle" direction="in"/>
<pin name="SENSE1" x="-20.32" y="-17.78" length="middle" direction="in"/>
<pin name="SENSE2" x="-20.32" y="-20.32" length="middle" direction="in"/>
<pin name="GND_2" x="-20.32" y="-25.4" length="middle" direction="pas"/>
<pin name="OUT1B" x="20.32" y="17.78" length="middle" direction="out" rot="R180"/>
<pin name="OUT2B" x="20.32" y="15.24" length="middle" direction="out" rot="R180"/>
<text x="-4.2418" y="32.9946" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-4.5466" y="-40.4622" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A4984SETTR-T">
<text x="-3.6576" y="33.1724" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-5.4864" y="-39.9034" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A4984SLPTR-T">
<text x="-4.4196" y="32.8168" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
</symbol>
<symbol name="A4985SESTR-T">
<text x="-4.9784" y="32.8168" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-5.4864" y="-40.6654" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A4985SETTR-T">
<text x="-5.1816" y="32.8168" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-5.1054" y="-40.1066" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A4985SLPTR-T">
<text x="-4.0386" y="33.3756" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-4.5466" y="-41.0464" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A4986SLPTR-T">
<pin name="IN02" x="-17.78" y="10.16" length="middle" direction="in"/>
<pin name="IN12" x="-17.78" y="7.62" length="middle" direction="in"/>
<pin name="IN11" x="-17.78" y="0" length="middle" direction="in"/>
<pin name="IN01" x="-17.78" y="-7.62" length="middle" direction="in"/>
<pin name="PH1" x="-17.78" y="-12.7" length="middle" direction="in"/>
<pin name="PH2" x="-17.78" y="-15.24" length="middle" direction="in"/>
<text x="-4.9784" y="33.1724" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-6.4262" y="-40.2844" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A4987SESTR-T">
<pin name="PH1" x="-17.78" y="15.24" length="middle" direction="in"/>
<pin name="PH2" x="-17.78" y="12.7" length="middle" direction="in"/>
<pin name="CP1" x="-17.78" y="10.16" length="middle" direction="pas"/>
<pin name="CP2" x="-17.78" y="7.62" length="middle" direction="pas"/>
<pin name="ROSC" x="-17.78" y="0" length="middle" direction="in"/>
<pin name="~SLEEP" x="-17.78" y="-2.54" length="middle" direction="in"/>
<pin name="REF" x="-17.78" y="-5.08" length="middle" direction="in"/>
<pin name="IN02" x="-17.78" y="-7.62" length="middle" direction="in"/>
<pin name="IN01" x="-17.78" y="-10.16" length="middle" direction="in"/>
<pin name="IN12" x="-17.78" y="-12.7" length="middle" direction="in"/>
<pin name="IN11" x="-17.78" y="-15.24" length="middle" direction="in"/>
<pin name="OUT1B" x="17.78" y="25.4" length="middle" direction="out" rot="R180"/>
<pin name="OUT2B" x="17.78" y="22.86" length="middle" direction="out" rot="R180"/>
<pin name="OUT1A" x="17.78" y="20.32" length="middle" direction="out" rot="R180"/>
<pin name="OUT2A" x="17.78" y="17.78" length="middle" direction="out" rot="R180"/>
<text x="-4.1656" y="-40.2844" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A4987SLPTR-T">
<pin name="IN01" x="-17.78" y="10.16" length="middle" direction="in"/>
<pin name="IN02" x="-17.78" y="7.62" length="middle" direction="in"/>
<pin name="IN11" x="-17.78" y="5.08" length="middle" direction="in"/>
<pin name="IN12" x="-17.78" y="2.54" length="middle" direction="in"/>
<pin name="VCP" x="-17.78" y="0" length="middle" direction="pas"/>
<pin name="VREG" x="-17.78" y="-2.54" length="middle" direction="pas"/>
<pin name="ROSC" x="-17.78" y="-5.08" length="middle" direction="in"/>
<pin name="~SLEEP" x="-17.78" y="-7.62" length="middle" direction="in"/>
<pin name="OUT1B" x="17.78" y="20.32" length="middle" direction="out" rot="R180"/>
<pin name="OUT2B" x="17.78" y="17.78" length="middle" direction="out" rot="R180"/>
<text x="-5.8674" y="-40.1066" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A4988SETTR-T">
<pin name="VDD" x="-17.78" y="30.48" length="middle" direction="pwr"/>
<pin name="VBB1" x="-17.78" y="27.94" length="middle" direction="pwr"/>
<pin name="VBB2" x="-17.78" y="25.4" length="middle" direction="pwr"/>
<pin name="CP1" x="-17.78" y="20.32" length="middle" direction="pas"/>
<pin name="CP2" x="-17.78" y="17.78" length="middle" direction="pas"/>
<pin name="~ENABLE" x="-17.78" y="15.24" length="middle" direction="in"/>
<pin name="VCP" x="-17.78" y="12.7" length="middle" direction="pas"/>
<pin name="VREG" x="-17.78" y="10.16" length="middle" direction="pas"/>
<pin name="STEP" x="-17.78" y="7.62" length="middle" direction="in"/>
<pin name="REF" x="-17.78" y="5.08" length="middle" direction="in"/>
<pin name="DIR" x="-17.78" y="2.54" length="middle" direction="in"/>
<pin name="SENSE1" x="-17.78" y="0" length="middle" direction="in"/>
<pin name="SENSE2" x="-17.78" y="-2.54" length="middle" direction="in"/>
<pin name="~RESET" x="-17.78" y="-5.08" length="middle" direction="in"/>
<pin name="ROSC" x="-17.78" y="-7.62" length="middle" direction="in"/>
<pin name="~SLEEP" x="-17.78" y="-10.16" length="middle" direction="in"/>
<pin name="MS1" x="-17.78" y="-15.24" length="middle" direction="in"/>
<pin name="MS2" x="-17.78" y="-17.78" length="middle" direction="in"/>
<pin name="MS3" x="-17.78" y="-20.32" length="middle" direction="in"/>
<pin name="NC_2" x="-17.78" y="-25.4" length="middle" direction="nc"/>
<pin name="NC_3" x="-17.78" y="-27.94" length="middle" direction="nc"/>
<pin name="NC" x="-17.78" y="-30.48" length="middle" direction="nc"/>
<pin name="GND_2" x="-17.78" y="-33.02" length="middle" direction="pas"/>
<pin name="GND" x="-17.78" y="-35.56" length="middle" direction="pas"/>
<pin name="PAD" x="-17.78" y="-38.1" length="middle" direction="pas"/>
<pin name="OUT1B" x="17.78" y="27.94" length="middle" direction="out" rot="R180"/>
<pin name="OUT2A" x="17.78" y="25.4" length="middle" direction="out" rot="R180"/>
<wire x1="-12.7" y1="35.56" x2="-12.7" y2="-43.18" width="0.4064" layer="94"/>
<wire x1="-12.7" y1="-43.18" x2="12.7" y2="-43.18" width="0.4064" layer="94"/>
<wire x1="12.7" y1="-43.18" x2="12.7" y2="35.56" width="0.4064" layer="94"/>
<wire x1="12.7" y1="35.56" x2="-12.7" y2="35.56" width="0.4064" layer="94"/>
<text x="-4.9276" y="38.3032" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-5.5626" y="-48.0822" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A6275EA-T">
<pin name="LOGIC_SUPPLY" x="-25.4" y="10.16" length="middle" direction="pwr"/>
<pin name="CLK" x="-25.4" y="5.08" length="middle" direction="in"/>
<pin name="LE" x="-25.4" y="0" length="middle" direction="in"/>
<pin name="OE" x="-25.4" y="-2.54" length="middle" direction="in"/>
<pin name="SERI" x="-25.4" y="-7.62" length="middle" direction="in"/>
<pin name="GND" x="-25.4" y="-12.7" length="middle" direction="pas"/>
<pin name="R_EXT" x="25.4" y="10.16" length="middle" direction="pas" rot="R180"/>
<pin name="SERO" x="25.4" y="7.62" length="middle" direction="out" rot="R180"/>
<pin name="OUT_0" x="25.4" y="2.54" length="middle" direction="out" rot="R180"/>
<pin name="OUT_1" x="25.4" y="0" length="middle" direction="out" rot="R180"/>
<pin name="OUT_2" x="25.4" y="-2.54" length="middle" direction="out" rot="R180"/>
<pin name="OUT_3" x="25.4" y="-5.08" length="middle" direction="out" rot="R180"/>
<pin name="OUT_4" x="25.4" y="-7.62" length="middle" direction="out" rot="R180"/>
<pin name="OUT_5" x="25.4" y="-10.16" length="middle" direction="out" rot="R180"/>
<pin name="OUT_6" x="25.4" y="-12.7" length="middle" direction="out" rot="R180"/>
<pin name="OUT_7" x="25.4" y="-15.24" length="middle" direction="out" rot="R180"/>
<wire x1="-20.32" y1="15.24" x2="-20.32" y2="-20.32" width="0.4064" layer="94"/>
<wire x1="-20.32" y1="-20.32" x2="20.32" y2="-20.32" width="0.4064" layer="94"/>
<wire x1="20.32" y1="-20.32" x2="20.32" y2="15.24" width="0.4064" layer="94"/>
<wire x1="20.32" y1="15.24" x2="-20.32" y2="15.24" width="0.4064" layer="94"/>
<text x="-5.461" y="17.9832" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-3.8862" y="-24.6126" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A6276EA-T">
<pin name="VDD" x="-25.4" y="17.78" length="middle" direction="pwr"/>
<pin name="LATCH_ENABLE" x="-25.4" y="12.7" length="middle" direction="in"/>
<pin name="OUT_EN" x="-25.4" y="7.62" length="middle" direction="in"/>
<pin name="CLK" x="-25.4" y="2.54" length="middle" direction="in"/>
<pin name="SERIN" x="-25.4" y="-2.54" length="middle" direction="in"/>
<pin name="REXT" x="-25.4" y="-7.62" length="middle" direction="pas"/>
<pin name="OUT0" x="25.4" y="17.78" length="middle" direction="out" rot="R180"/>
<pin name="OUT1" x="25.4" y="15.24" length="middle" direction="out" rot="R180"/>
<pin name="OUT2" x="25.4" y="12.7" length="middle" direction="out" rot="R180"/>
<pin name="OUT3" x="25.4" y="10.16" length="middle" direction="out" rot="R180"/>
<pin name="OUT4" x="25.4" y="7.62" length="middle" direction="out" rot="R180"/>
<pin name="OUT5" x="25.4" y="5.08" length="middle" direction="out" rot="R180"/>
<pin name="OUT6" x="25.4" y="2.54" length="middle" direction="out" rot="R180"/>
<pin name="OUT7" x="25.4" y="0" length="middle" direction="out" rot="R180"/>
<pin name="OUT8" x="25.4" y="-2.54" length="middle" direction="out" rot="R180"/>
<pin name="OUT9" x="25.4" y="-5.08" length="middle" direction="out" rot="R180"/>
<pin name="OUT10" x="25.4" y="-7.62" length="middle" direction="out" rot="R180"/>
<pin name="OUT11" x="25.4" y="-10.16" length="middle" direction="out" rot="R180"/>
<pin name="OUT12" x="25.4" y="-12.7" length="middle" direction="out" rot="R180"/>
<pin name="OUT13" x="25.4" y="-15.24" length="middle" direction="out" rot="R180"/>
<pin name="OUT14" x="25.4" y="-17.78" length="middle" direction="out" rot="R180"/>
<pin name="OUT15" x="25.4" y="-20.32" length="middle" direction="out" rot="R180"/>
<pin name="SERO" x="25.4" y="-25.4" length="middle" direction="out" rot="R180"/>
<text x="-5.08" y="24.5872" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-3.2004" y="-34.7726" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A6279EETTR-T">
<pin name="LOGIC_SUPPLY" x="-26.67" y="17.78" length="middle" direction="pwr"/>
<pin name="REXT" x="-26.67" y="12.7" length="middle" direction="in"/>
<pin name="LATCH_ENABLE" x="-26.67" y="10.16" length="middle" direction="in"/>
<pin name="CLOCK" x="-26.67" y="7.62" length="middle" direction="in"/>
<pin name="SERIAL_DATA_IN" x="-26.67" y="5.08" length="middle" direction="in"/>
<pin name="OUTPUT_ENABLE" x="-26.67" y="2.54" length="middle" direction="in"/>
<pin name="NC_2" x="-26.67" y="-2.54" length="middle" direction="nc"/>
<pin name="NC_3" x="-26.67" y="-5.08" length="middle" direction="nc"/>
<pin name="NC_4" x="-26.67" y="-7.62" length="middle" direction="nc"/>
<pin name="NC" x="-26.67" y="-10.16" length="middle" direction="nc"/>
<pin name="GND" x="-26.67" y="-15.24" length="middle" direction="pas"/>
<pin name="EP" x="-26.67" y="-17.78" length="middle" direction="pas"/>
<pin name="OUT0" x="26.67" y="17.78" length="middle" direction="out" rot="R180"/>
<pin name="OUT1" x="26.67" y="15.24" length="middle" direction="out" rot="R180"/>
<pin name="OUT2" x="26.67" y="12.7" length="middle" direction="out" rot="R180"/>
<pin name="OUT3" x="26.67" y="10.16" length="middle" direction="out" rot="R180"/>
<pin name="OUT4" x="26.67" y="7.62" length="middle" direction="out" rot="R180"/>
<pin name="OUT5" x="26.67" y="5.08" length="middle" direction="out" rot="R180"/>
<pin name="OUT6" x="26.67" y="2.54" length="middle" direction="out" rot="R180"/>
<pin name="OUT7" x="26.67" y="0" length="middle" direction="out" rot="R180"/>
<pin name="OUT8" x="26.67" y="-2.54" length="middle" direction="out" rot="R180"/>
<pin name="OUT9" x="26.67" y="-5.08" length="middle" direction="out" rot="R180"/>
<pin name="OUT10" x="26.67" y="-7.62" length="middle" direction="out" rot="R180"/>
<pin name="OUT11" x="26.67" y="-10.16" length="middle" direction="out" rot="R180"/>
<pin name="OUT12" x="26.67" y="-12.7" length="middle" direction="out" rot="R180"/>
<pin name="OUT13" x="26.67" y="-15.24" length="middle" direction="out" rot="R180"/>
<pin name="OUT14" x="26.67" y="-17.78" length="middle" direction="out" rot="R180"/>
<pin name="OUT15" x="26.67" y="-20.32" length="middle" direction="out" rot="R180"/>
<pin name="SERIAL_DATA_OUT" x="26.67" y="-25.4" length="middle" direction="out" rot="R180"/>
<wire x1="-21.59" y1="22.86" x2="-21.59" y2="-30.48" width="0.4064" layer="94"/>
<wire x1="-21.59" y1="-30.48" x2="21.59" y2="-30.48" width="0.4064" layer="94"/>
<wire x1="21.59" y1="-30.48" x2="21.59" y2="22.86" width="0.4064" layer="94"/>
<wire x1="21.59" y1="22.86" x2="-21.59" y2="22.86" width="0.4064" layer="94"/>
<text x="-5.3594" y="26.8986" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-4.2418" y="-37.3888" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A6279ELPTR-T">
<pin name="LOGIC_SUPPLY" x="-27.94" y="15.24" length="middle" direction="pwr"/>
<pin name="CLOCK" x="-27.94" y="10.16" length="middle" direction="in"/>
<pin name="SERIAL_DATA_IN" x="-27.94" y="7.62" length="middle" direction="in"/>
<pin name="LATCH_ENABLE" x="-27.94" y="5.08" length="middle" direction="in"/>
<pin name="OUTPUT_ENABLE" x="-27.94" y="2.54" length="middle" direction="in"/>
<pin name="REXT" x="-27.94" y="0" length="middle" direction="in"/>
<pin name="GND" x="-27.94" y="-5.08" length="middle" direction="pas"/>
<pin name="EP" x="-27.94" y="-7.62" length="middle" direction="pas"/>
<pin name="OUT0" x="27.94" y="17.78" length="middle" direction="out" rot="R180"/>
<pin name="OUT1" x="27.94" y="15.24" length="middle" direction="out" rot="R180"/>
<pin name="OUT2" x="27.94" y="12.7" length="middle" direction="out" rot="R180"/>
<pin name="OUT3" x="27.94" y="10.16" length="middle" direction="out" rot="R180"/>
<pin name="OUT4" x="27.94" y="7.62" length="middle" direction="out" rot="R180"/>
<pin name="OUT5" x="27.94" y="5.08" length="middle" direction="out" rot="R180"/>
<pin name="OUT6" x="27.94" y="2.54" length="middle" direction="out" rot="R180"/>
<pin name="OUT7" x="27.94" y="0" length="middle" direction="out" rot="R180"/>
<pin name="OUT8" x="27.94" y="-2.54" length="middle" direction="out" rot="R180"/>
<pin name="OUT9" x="27.94" y="-5.08" length="middle" direction="out" rot="R180"/>
<pin name="OUT10" x="27.94" y="-7.62" length="middle" direction="out" rot="R180"/>
<pin name="OUT11" x="27.94" y="-10.16" length="middle" direction="out" rot="R180"/>
<pin name="OUT12" x="27.94" y="-12.7" length="middle" direction="out" rot="R180"/>
<pin name="OUT13" x="27.94" y="-15.24" length="middle" direction="out" rot="R180"/>
<pin name="OUT14" x="27.94" y="-17.78" length="middle" direction="out" rot="R180"/>
<pin name="OUT15" x="27.94" y="-20.32" length="middle" direction="out" rot="R180"/>
<pin name="SERIAL_DATA_OUT" x="27.94" y="-25.4" length="middle" direction="out" rot="R180"/>
<wire x1="-22.86" y1="22.86" x2="-22.86" y2="-30.48" width="0.4064" layer="94"/>
<wire x1="-22.86" y1="-30.48" x2="22.86" y2="-30.48" width="0.4064" layer="94"/>
<wire x1="22.86" y1="-30.48" x2="22.86" y2="22.86" width="0.4064" layer="94"/>
<wire x1="22.86" y1="22.86" x2="-22.86" y2="22.86" width="0.4064" layer="94"/>
<text x="-5.3594" y="25.1968" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-5.1816" y="-34.8996" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A6280EESTR-T">
<pin name="VIN" x="-17.78" y="12.7" length="middle" direction="pwr"/>
<pin name="VREG" x="-17.78" y="7.62" length="middle" direction="in"/>
<pin name="REXT" x="-17.78" y="5.08" length="middle" direction="pas"/>
<pin name="CI" x="-17.78" y="2.54" length="middle" direction="in"/>
<pin name="LI" x="-17.78" y="0" length="middle" direction="in"/>
<pin name="OEI" x="-17.78" y="-2.54" length="middle" direction="in"/>
<pin name="SDI" x="-17.78" y="-5.08" length="middle" direction="in"/>
<pin name="LGND" x="-17.78" y="-10.16" length="middle" direction="pas"/>
<pin name="PGND" x="-17.78" y="-12.7" length="middle" direction="pas"/>
<pin name="EPAD" x="-17.78" y="-17.78" length="middle" direction="pas"/>
<pin name="LO" x="17.78" y="12.7" length="middle" direction="out" rot="R180"/>
<pin name="CO" x="17.78" y="10.16" length="middle" direction="out" rot="R180"/>
<pin name="OEO" x="17.78" y="7.62" length="middle" direction="out" rot="R180"/>
<pin name="SDO" x="17.78" y="5.08" length="middle" rot="R180"/>
<pin name="OUT0" x="17.78" y="0" length="middle" direction="out" rot="R180"/>
<pin name="OUT1" x="17.78" y="-2.54" length="middle" direction="out" rot="R180"/>
<pin name="OUT2" x="17.78" y="-5.08" length="middle" direction="out" rot="R180"/>
<wire x1="-12.7" y1="17.78" x2="-12.7" y2="-22.86" width="0.4064" layer="94"/>
<wire x1="-12.7" y1="-22.86" x2="12.7" y2="-22.86" width="0.4064" layer="94"/>
<wire x1="12.7" y1="-22.86" x2="12.7" y2="17.78" width="0.4064" layer="94"/>
<wire x1="12.7" y1="17.78" x2="-12.7" y2="17.78" width="0.4064" layer="94"/>
<text x="-4.953" y="19.6342" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-4.3434" y="-25.8826" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A6282EESTR-T">
<pin name="VDD" x="-17.78" y="17.78" length="middle" direction="pwr"/>
<pin name="CLK" x="-17.78" y="12.7" length="middle" direction="in"/>
<pin name="REXT" x="-17.78" y="10.16" length="middle" direction="in"/>
<pin name="LE" x="-17.78" y="7.62" length="middle" direction="in"/>
<pin name="~OE" x="-17.78" y="5.08" length="middle" direction="in"/>
<pin name="SDI" x="-17.78" y="2.54" length="middle" direction="in"/>
<pin name="GND" x="-17.78" y="-2.54" length="middle" direction="pas"/>
<pin name="EPAD" x="-17.78" y="-5.08" length="middle" direction="pas"/>
<pin name="OUT0" x="17.78" y="17.78" length="middle" direction="out" rot="R180"/>
<pin name="OUT1" x="17.78" y="15.24" length="middle" direction="out" rot="R180"/>
<pin name="OUT2" x="17.78" y="12.7" length="middle" direction="out" rot="R180"/>
<pin name="OUT3" x="17.78" y="10.16" length="middle" direction="out" rot="R180"/>
<pin name="OUT4" x="17.78" y="7.62" length="middle" direction="out" rot="R180"/>
<pin name="OUT5" x="17.78" y="5.08" length="middle" direction="out" rot="R180"/>
<pin name="OUT6" x="17.78" y="2.54" length="middle" direction="out" rot="R180"/>
<pin name="OUT7" x="17.78" y="0" length="middle" direction="out" rot="R180"/>
<pin name="OUT8" x="17.78" y="-2.54" length="middle" direction="out" rot="R180"/>
<pin name="OUT9" x="17.78" y="-5.08" length="middle" direction="out" rot="R180"/>
<pin name="OUT10" x="17.78" y="-7.62" length="middle" direction="out" rot="R180"/>
<pin name="OUT11" x="17.78" y="-10.16" length="middle" direction="out" rot="R180"/>
<pin name="OUT12" x="17.78" y="-12.7" length="middle" direction="out" rot="R180"/>
<pin name="OUT13" x="17.78" y="-15.24" length="middle" direction="out" rot="R180"/>
<pin name="OUT14" x="17.78" y="-17.78" length="middle" direction="out" rot="R180"/>
<pin name="OUT15" x="17.78" y="-20.32" length="middle" direction="out" rot="R180"/>
<pin name="SDO" x="17.78" y="-25.4" length="middle" direction="out" rot="R180"/>
<wire x1="-12.7" y1="22.86" x2="-12.7" y2="-30.48" width="0.4064" layer="94"/>
<wire x1="-12.7" y1="-30.48" x2="12.7" y2="-30.48" width="0.4064" layer="94"/>
<wire x1="12.7" y1="-30.48" x2="12.7" y2="22.86" width="0.4064" layer="94"/>
<wire x1="12.7" y1="22.86" x2="-12.7" y2="22.86" width="0.4064" layer="94"/>
<text x="-5.3594" y="24.9936" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-5.334" y="-33.5534" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A6832SEPTR-T">
<pin name="LOGIC_SUPPLY" x="-30.48" y="38.1" length="middle" direction="pwr"/>
<pin name="CLK" x="-30.48" y="33.02" length="middle" direction="in"/>
<pin name="STROBE" x="-30.48" y="30.48" length="middle" direction="in"/>
<pin name="OUT_ENABLE" x="-30.48" y="27.94" length="middle" direction="in"/>
<pin name="SERIAL_DATA_IN" x="-30.48" y="25.4" length="middle" direction="in"/>
<pin name="NC_2" x="-30.48" y="20.32" length="middle" direction="nc"/>
<pin name="NC_3" x="-30.48" y="17.78" length="middle" direction="nc"/>
<pin name="NC_4" x="-30.48" y="15.24" length="middle" direction="nc"/>
<pin name="NC_5" x="-30.48" y="12.7" length="middle" direction="nc"/>
<pin name="NC" x="-30.48" y="10.16" length="middle" direction="nc"/>
<pin name="GND" x="-30.48" y="5.08" length="middle" direction="pas"/>
<pin name="OUT1" x="30.48" y="38.1" length="middle" direction="out" rot="R180"/>
<pin name="OUT2" x="30.48" y="35.56" length="middle" direction="out" rot="R180"/>
<pin name="OUT3" x="30.48" y="33.02" length="middle" direction="out" rot="R180"/>
<pin name="OUT4" x="30.48" y="30.48" length="middle" direction="out" rot="R180"/>
<pin name="OUT5" x="30.48" y="27.94" length="middle" direction="out" rot="R180"/>
<pin name="OUT6" x="30.48" y="25.4" length="middle" direction="out" rot="R180"/>
<pin name="OUT7" x="30.48" y="22.86" length="middle" direction="out" rot="R180"/>
<pin name="OUT8" x="30.48" y="20.32" length="middle" direction="out" rot="R180"/>
<pin name="OUT9" x="30.48" y="17.78" length="middle" direction="out" rot="R180"/>
<pin name="OUT10" x="30.48" y="15.24" length="middle" direction="out" rot="R180"/>
<pin name="OUT11" x="30.48" y="12.7" length="middle" direction="out" rot="R180"/>
<pin name="OUT12" x="30.48" y="10.16" length="middle" direction="out" rot="R180"/>
<pin name="OUT13" x="30.48" y="7.62" length="middle" direction="out" rot="R180"/>
<pin name="OUT14" x="30.48" y="5.08" length="middle" direction="out" rot="R180"/>
<pin name="OUT15" x="30.48" y="2.54" length="middle" direction="out" rot="R180"/>
<pin name="OUT16" x="30.48" y="0" length="middle" direction="out" rot="R180"/>
<pin name="OUT17" x="30.48" y="-2.54" length="middle" direction="out" rot="R180"/>
<pin name="OUT18" x="30.48" y="-5.08" length="middle" direction="out" rot="R180"/>
<pin name="OUT19" x="30.48" y="-7.62" length="middle" direction="out" rot="R180"/>
<pin name="OUT20" x="30.48" y="-10.16" length="middle" direction="out" rot="R180"/>
<pin name="OUT21" x="30.48" y="-12.7" length="middle" direction="out" rot="R180"/>
<pin name="OUT22" x="30.48" y="-15.24" length="middle" direction="out" rot="R180"/>
<pin name="OUT23" x="30.48" y="-17.78" length="middle" direction="out" rot="R180"/>
<pin name="OUT24" x="30.48" y="-20.32" length="middle" direction="out" rot="R180"/>
<pin name="OUT25" x="30.48" y="-22.86" length="middle" direction="out" rot="R180"/>
<pin name="OUT26" x="30.48" y="-25.4" length="middle" direction="out" rot="R180"/>
<pin name="OUT27" x="30.48" y="-27.94" length="middle" direction="out" rot="R180"/>
<pin name="OUT28" x="30.48" y="-30.48" length="middle" direction="out" rot="R180"/>
<pin name="OUT29" x="30.48" y="-33.02" length="middle" direction="out" rot="R180"/>
<pin name="OUT30" x="30.48" y="-35.56" length="middle" direction="out" rot="R180"/>
<pin name="OUT31" x="30.48" y="-38.1" length="middle" direction="out" rot="R180"/>
<pin name="OUT32" x="30.48" y="-40.64" length="middle" direction="out" rot="R180"/>
<pin name="SERIAL_DATA_OUT" x="30.48" y="-45.72" length="middle" direction="out" rot="R180"/>
<wire x1="-25.4" y1="43.18" x2="-25.4" y2="-50.8" width="0.4064" layer="94"/>
<wire x1="-25.4" y1="-50.8" x2="25.4" y2="-50.8" width="0.4064" layer="94"/>
<wire x1="25.4" y1="-50.8" x2="25.4" y2="43.18" width="0.4064" layer="94"/>
<wire x1="25.4" y1="43.18" x2="-25.4" y2="43.18" width="0.4064" layer="94"/>
<text x="-5.1816" y="45.0596" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-3.7846" y="-54.61" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A6841SLW-20-T">
<pin name="VEE_2" x="-22.86" y="15.24" length="middle" direction="pwr"/>
<pin name="VEE" x="-22.86" y="12.7" length="middle" direction="pwr"/>
<pin name="CLK" x="-22.86" y="7.62" length="middle" direction="in"/>
<pin name="ST" x="-22.86" y="5.08" length="middle" direction="in"/>
<pin name="DATA_IN" x="-22.86" y="2.54" length="middle" direction="in"/>
<pin name="VDD" x="-22.86" y="0" length="middle" direction="in"/>
<pin name="~OE" x="-22.86" y="-2.54" length="middle" direction="in"/>
<pin name="K" x="-22.86" y="-7.62" length="middle" direction="in"/>
<pin name="NC_2" x="-22.86" y="-12.7" length="middle" direction="nc"/>
<pin name="NC" x="-22.86" y="-15.24" length="middle" direction="nc"/>
<pin name="GND" x="-22.86" y="-20.32" length="middle" direction="pas"/>
<pin name="DATA_OUT" x="22.86" y="15.24" length="middle" direction="out" rot="R180"/>
<pin name="OUT_1" x="22.86" y="10.16" length="middle" direction="out" rot="R180"/>
<pin name="OUT_2" x="22.86" y="7.62" length="middle" direction="out" rot="R180"/>
<pin name="OUT_3" x="22.86" y="5.08" length="middle" direction="out" rot="R180"/>
<pin name="OUT_4" x="22.86" y="2.54" length="middle" direction="out" rot="R180"/>
<pin name="OUT_5" x="22.86" y="0" length="middle" direction="out" rot="R180"/>
<pin name="OUT_6" x="22.86" y="-2.54" length="middle" direction="out" rot="R180"/>
<pin name="OUT_7" x="22.86" y="-5.08" length="middle" direction="out" rot="R180"/>
<pin name="OUT_8" x="22.86" y="-7.62" length="middle" direction="out" rot="R180"/>
<wire x1="-17.78" y1="20.32" x2="-17.78" y2="-25.4" width="0.4064" layer="94"/>
<wire x1="-17.78" y1="-25.4" x2="17.78" y2="-25.4" width="0.4064" layer="94"/>
<wire x1="17.78" y1="-25.4" x2="17.78" y2="20.32" width="0.4064" layer="94"/>
<wire x1="17.78" y1="20.32" x2="-17.78" y2="20.32" width="0.4064" layer="94"/>
<text x="-5.4864" y="22.9362" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-3.9116" y="-30.3784" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A8732EEETR-T">
<pin name="VIN_DRV" x="-20.32" y="7.62" length="middle" direction="pwr"/>
<pin name="TRIG" x="-20.32" y="2.54" length="middle" direction="in"/>
<pin name="SW" x="-20.32" y="0" length="middle" direction="pas"/>
<pin name="VBAT" x="-20.32" y="-2.54" length="middle" direction="pwr"/>
<pin name="CHARGE" x="-20.32" y="-5.08" length="middle" direction="in"/>
<pin name="GND" x="-20.32" y="-10.16" length="middle" direction="pas"/>
<pin name="EP" x="-20.32" y="-12.7" length="middle" direction="pas"/>
<pin name="~DONE" x="20.32" y="7.62" length="middle" direction="out" rot="R180"/>
<pin name="GATE" x="20.32" y="5.08" length="middle" direction="out" rot="R180"/>
<wire x1="-15.24" y1="12.7" x2="-15.24" y2="-17.78" width="0.4064" layer="94"/>
<wire x1="-15.24" y1="-17.78" x2="15.24" y2="-17.78" width="0.4064" layer="94"/>
<wire x1="15.24" y1="-17.78" x2="15.24" y2="12.7" width="0.4064" layer="94"/>
<wire x1="15.24" y1="12.7" x2="-15.24" y2="12.7" width="0.4064" layer="94"/>
<text x="-5.2578" y="15.3162" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-4.1656" y="-22.3266" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="A8735EEETR-T">
<text x="-5.1816" y="15.4178" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-3.5814" y="-21.9456" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="ACS709LLFTR-20BB-T">
<pin name="VCC" x="-33.02" y="35.56" length="middle" direction="pwr"/>
<pin name="VOC" x="-33.02" y="27.94" length="middle" direction="in"/>
<pin name="IP+_2" x="-33.02" y="22.86" length="middle"/>
<pin name="IP+_3" x="-33.02" y="20.32" length="middle"/>
<pin name="IP+_4" x="-33.02" y="17.78" length="middle"/>
<pin name="IP+_5" x="-33.02" y="15.24" length="middle"/>
<pin name="IP+_6" x="-33.02" y="12.7" length="middle"/>
<pin name="IP+" x="-33.02" y="10.16" length="middle"/>
<pin name="IP-_2" x="-33.02" y="7.62" length="middle"/>
<pin name="IP-_3" x="-33.02" y="5.08" length="middle"/>
<pin name="IP-_4" x="-33.02" y="2.54" length="middle"/>
<pin name="IP-_5" x="-33.02" y="0" length="middle"/>
<pin name="IP-_6" x="-33.02" y="-2.54" length="middle"/>
<pin name="IP-" x="-33.02" y="-5.08" length="middle"/>
<pin name="FILTER" x="-33.02" y="-10.16" length="middle" direction="in"/>
<pin name="~FAULT" x="-33.02" y="-17.78" length="middle" direction="in"/>
<pin name="FAULT_EN" x="-33.02" y="-22.86" length="middle" direction="in"/>
<pin name="GND" x="-33.02" y="-27.94" length="middle" direction="pas"/>
<pin name="NC_2" x="-33.02" y="-33.02" length="middle" direction="nc"/>
<pin name="NC_3" x="-33.02" y="-35.56" length="middle" direction="nc"/>
<pin name="NC_4" x="-33.02" y="-38.1" length="middle" direction="nc"/>
<pin name="NC" x="-33.02" y="-40.64" length="middle" direction="nc"/>
<pin name="VZCR" x="33.02" y="35.56" length="middle" direction="out" rot="R180"/>
<pin name="VIOUT" x="33.02" y="27.94" length="middle" direction="out" rot="R180"/>
<wire x1="-27.94" y1="40.64" x2="-27.94" y2="-45.72" width="0.4064" layer="94"/>
<wire x1="-27.94" y1="-45.72" x2="27.94" y2="-45.72" width="0.4064" layer="94"/>
<wire x1="27.94" y1="-45.72" x2="27.94" y2="40.64" width="0.4064" layer="94"/>
<wire x1="27.94" y1="40.64" x2="-27.94" y2="40.64" width="0.4064" layer="94"/>
<text x="-5.6896" y="42.4434" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-5.3848" y="-49.4792" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="ACS709LLFTR-35BB-T">
<pin name="VCC" x="-17.78" y="27.94" length="middle" direction="pwr"/>
<pin name="VOC" x="-17.78" y="25.4" length="middle" direction="in"/>
<pin name="IP+_2" x="-17.78" y="20.32" length="middle"/>
<pin name="IP+_3" x="-17.78" y="17.78" length="middle"/>
<pin name="IP+_4" x="-17.78" y="15.24" length="middle"/>
<pin name="IP+_5" x="-17.78" y="12.7" length="middle"/>
<pin name="IP+_6" x="-17.78" y="10.16" length="middle"/>
<pin name="IP+" x="-17.78" y="7.62" length="middle"/>
<pin name="IP-_2" x="-17.78" y="5.08" length="middle"/>
<pin name="IP-_3" x="-17.78" y="2.54" length="middle"/>
<pin name="IP-_4" x="-17.78" y="0" length="middle"/>
<pin name="IP-_5" x="-17.78" y="-2.54" length="middle"/>
<pin name="IP-_6" x="-17.78" y="-5.08" length="middle"/>
<pin name="IP-" x="-17.78" y="-7.62" length="middle"/>
<pin name="FILTER" x="-17.78" y="-12.7" length="middle" direction="in"/>
<pin name="FAULT_EN" x="-17.78" y="-15.24" length="middle" direction="in"/>
<pin name="~FAULT" x="-17.78" y="-17.78" length="middle" direction="in"/>
<pin name="NC_2" x="-17.78" y="-22.86" length="middle" direction="nc"/>
<pin name="NC_3" x="-17.78" y="-25.4" length="middle" direction="nc"/>
<pin name="NC_4" x="-17.78" y="-27.94" length="middle" direction="nc"/>
<pin name="VZCR" x="17.78" y="27.94" length="middle" direction="out" rot="R180"/>
<pin name="VIOUT" x="17.78" y="22.86" length="middle" direction="out" rot="R180"/>
<wire x1="-12.7" y1="33.02" x2="-12.7" y2="-40.64" width="0.4064" layer="94"/>
<wire x1="-12.7" y1="-40.64" x2="12.7" y2="-40.64" width="0.4064" layer="94"/>
<wire x1="12.7" y1="-40.64" x2="12.7" y2="33.02" width="0.4064" layer="94"/>
<wire x1="12.7" y1="33.02" x2="-12.7" y2="33.02" width="0.4064" layer="94"/>
<text x="-5.6388" y="35.4076" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-4.7498" y="-43.7896" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="ACS710KLATR-25CB-T">
<pin name="VCC" x="-17.78" y="17.78" length="middle" direction="pwr"/>
<pin name="IP+_2" x="-17.78" y="12.7" length="middle" direction="in"/>
<pin name="IP+_3" x="-17.78" y="10.16" length="middle" direction="in"/>
<pin name="IP+_4" x="-17.78" y="7.62" length="middle" direction="in"/>
<pin name="IP+" x="-17.78" y="5.08" length="middle" direction="in"/>
<pin name="IP-_2" x="-17.78" y="0" length="middle" direction="in"/>
<pin name="IP-_3" x="-17.78" y="-2.54" length="middle" direction="in"/>
<pin name="IP-_4" x="-17.78" y="-5.08" length="middle" direction="in"/>
<pin name="IP-" x="-17.78" y="-7.62" length="middle" direction="in"/>
<pin name="VOC" x="-17.78" y="-15.24" length="middle" direction="in"/>
<pin name="GND" x="-17.78" y="-22.86" length="middle" direction="pas"/>
<pin name="VZCR" x="17.78" y="17.78" length="middle" direction="out" rot="R180"/>
<pin name="VIOUT" x="17.78" y="15.24" length="middle" direction="out" rot="R180"/>
<pin name="FAULT_EN" x="17.78" y="12.7" length="middle" direction="in" rot="R180"/>
<wire x1="-12.7" y1="22.86" x2="-12.7" y2="-27.94" width="0.4064" layer="94"/>
<wire x1="-12.7" y1="-27.94" x2="12.7" y2="-27.94" width="0.4064" layer="94"/>
<wire x1="12.7" y1="-27.94" x2="12.7" y2="22.86" width="0.4064" layer="94"/>
<text x="-5.2578" y="24.4348" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-4.2672" y="-31.242" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="ACS712ELCTR-05B-T">
<pin name="VCC" x="-17.78" y="7.62" length="middle" direction="pwr"/>
<pin name="IP+_2" x="-17.78" y="2.54" length="middle" direction="in"/>
<pin name="IP+" x="-17.78" y="-2.54" length="middle" direction="in"/>
<pin name="IP-" x="-17.78" y="-5.08" length="middle" direction="in"/>
<pin name="FILTER" x="-17.78" y="-10.16" length="middle" direction="in"/>
<pin name="GND" x="-17.78" y="-15.24" length="middle" direction="pas"/>
<pin name="VIOUT" x="17.78" y="7.62" length="middle" direction="out" rot="R180"/>
<wire x1="-12.7" y1="12.7" x2="-12.7" y2="-20.32" width="0.4064" layer="94"/>
<wire x1="-12.7" y1="-20.32" x2="12.7" y2="-20.32" width="0.4064" layer="94"/>
<wire x1="12.7" y1="-20.32" x2="12.7" y2="12.7" width="0.4064" layer="94"/>
<text x="-5.2578" y="15.1638" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-3.4798" y="-25.4" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="ACS712ELCTR-20A-T">
</symbol>
<symbol name="SI-8005Q">
<pin name="IN" x="-17.78" y="7.62" length="middle" direction="pwr"/>
<pin name="BS" x="-17.78" y="2.54" length="middle" direction="pas"/>
<pin name="FB" x="-17.78" y="0" length="middle" direction="in"/>
<pin name="COMP" x="-17.78" y="-2.54" length="middle" direction="pas"/>
<pin name="EN" x="-17.78" y="-5.08" length="middle" direction="in"/>
<pin name="SS" x="-17.78" y="-7.62" length="middle" direction="in"/>
<pin name="GND" x="-17.78" y="-12.7" length="middle" direction="pas"/>
<pin name="EP" x="-17.78" y="-15.24" length="middle" direction="pas"/>
<pin name="SW" x="17.78" y="7.62" length="middle" direction="pas" rot="R180"/>
<text x="-5.5626" y="14.732" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-4.4958" y="-24.892" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="UDN2559B-T">
<pin name="VCC" x="-17.78" y="15.24" length="middle" direction="pwr"/>
<pin name="EN" x="-17.78" y="10.16" length="middle" direction="in"/>
<pin name="K_2" x="-17.78" y="5.08" length="middle" direction="pas"/>
<pin name="K" x="-17.78" y="2.54" length="middle" direction="pas"/>
<pin name="IN1" x="-17.78" y="-2.54" length="middle" direction="in"/>
<pin name="IN2" x="-17.78" y="-5.08" length="middle" direction="in"/>
<pin name="IN3" x="-17.78" y="-7.62" length="middle" direction="in"/>
<pin name="IN4" x="-17.78" y="-10.16" length="middle" direction="in"/>
<pin name="GND_2" x="-17.78" y="-15.24" length="middle" direction="pas"/>
<pin name="GND_3" x="-17.78" y="-17.78" length="middle" direction="pas"/>
<pin name="GND_4" x="-17.78" y="-20.32" length="middle" direction="pas"/>
<wire x1="-12.7" y1="20.32" x2="-12.7" y2="-27.94" width="0.4064" layer="94"/>
<wire x1="12.7" y1="-27.94" x2="12.7" y2="20.32" width="0.4064" layer="94"/>
<wire x1="12.7" y1="20.32" x2="-12.7" y2="20.32" width="0.4064" layer="94"/>
<text x="-4.8514" y="22.8854" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-3.937" y="-32.3596" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="UDN2916B-T">
<pin name="LOGIC_SUPPLY" x="-27.94" y="30.48" length="middle" direction="pwr"/>
<pin name="LOAD_SUPPLY" x="-27.94" y="27.94" length="middle" direction="pwr"/>
<pin name="VREF1" x="-27.94" y="22.86" length="middle" direction="in"/>
<pin name="VREF_2" x="-27.94" y="20.32" length="middle" direction="in"/>
<pin name="SEN1" x="-27.94" y="15.24" length="middle" direction="in"/>
<pin name="SEN2" x="-27.94" y="12.7" length="middle" direction="in"/>
<pin name="I01" x="-27.94" y="7.62" length="middle" direction="in"/>
<pin name="I02" x="-27.94" y="5.08" length="middle" direction="in"/>
<pin name="I11" x="-27.94" y="2.54" length="middle" direction="in"/>
<pin name="I12" x="-27.94" y="0" length="middle" direction="in"/>
<pin name="E1" x="-27.94" y="-5.08" length="middle" direction="in"/>
<pin name="E2" x="-27.94" y="-7.62" length="middle" direction="in"/>
<pin name="RC1" x="-27.94" y="-12.7" length="middle" direction="in"/>
<pin name="RC2" x="-27.94" y="-15.24" length="middle" direction="in"/>
<pin name="PHASE_1" x="-27.94" y="-20.32" length="middle" direction="in"/>
<pin name="PHASE_2" x="-27.94" y="-22.86" length="middle" direction="in"/>
<pin name="GND_2" x="-27.94" y="-27.94" length="middle" direction="pas"/>
<pin name="GND_3" x="-27.94" y="-30.48" length="middle" direction="pas"/>
<pin name="GND_4" x="-27.94" y="-33.02" length="middle" direction="pas"/>
<pin name="GND" x="-27.94" y="-35.56" length="middle" direction="pas"/>
<pin name="OUT_1A" x="27.94" y="30.48" length="middle" direction="out" rot="R180"/>
<pin name="OUT_2A" x="27.94" y="27.94" length="middle" direction="out" rot="R180"/>
<pin name="OUT_1B" x="27.94" y="22.86" length="middle" direction="out" rot="R180"/>
<pin name="OUT_2B" x="27.94" y="20.32" length="middle" direction="out" rot="R180"/>
<wire x1="-22.86" y1="35.56" x2="-22.86" y2="-40.64" width="0.4064" layer="94"/>
<wire x1="-22.86" y1="-40.64" x2="22.86" y2="-40.64" width="0.4064" layer="94"/>
<wire x1="22.86" y1="-40.64" x2="22.86" y2="35.56" width="0.4064" layer="94"/>
<wire x1="22.86" y1="35.56" x2="-22.86" y2="35.56" width="0.4064" layer="94"/>
<text x="-5.4864" y="38.2524" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-4.7244" y="-45.5168" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="UDN2916LBTR-T">
<pin name="LOGIC_SUPPLY" x="-25.4" y="30.48" length="middle" direction="in"/>
<pin name="LOAD_SUPPLY" x="-25.4" y="25.4" length="middle" direction="pwr"/>
<pin name="I01" x="-25.4" y="20.32" length="middle" direction="pas"/>
<pin name="I02" x="-25.4" y="17.78" length="middle" direction="in"/>
<pin name="I11" x="-25.4" y="15.24" length="middle" direction="in"/>
<pin name="I12" x="-25.4" y="12.7" length="middle" direction="in"/>
<pin name="PHASE1" x="-25.4" y="7.62" length="middle" direction="in"/>
<pin name="PHASE_2" x="-25.4" y="5.08" length="middle" direction="in"/>
<pin name="RC1" x="-25.4" y="0" length="middle" direction="in"/>
<pin name="RC2" x="-25.4" y="-2.54" length="middle" direction="in"/>
<pin name="VREF_1" x="-25.4" y="-7.62" length="middle" direction="in"/>
<pin name="VREF_2" x="-25.4" y="-10.16" length="middle" direction="in"/>
<pin name="SENSE_1" x="-25.4" y="-17.78" length="middle" direction="in"/>
<pin name="SENSE_2" x="-25.4" y="-20.32" length="middle" direction="in"/>
<pin name="E1" x="-25.4" y="-25.4" length="middle" direction="in"/>
<pin name="E2" x="-25.4" y="-27.94" length="middle" direction="in"/>
<pin name="GROUND_2" x="-25.4" y="-33.02" length="middle" direction="pas"/>
<pin name="GROUND_3" x="-25.4" y="-35.56" length="middle" direction="pas"/>
<pin name="GROUND_4" x="-25.4" y="-38.1" length="middle" direction="pas"/>
<pin name="GROUND" x="-25.4" y="-40.64" length="middle" direction="pas"/>
<pin name="OUT1A" x="25.4" y="33.02" length="middle" direction="out" rot="R180"/>
<pin name="OUT1B" x="25.4" y="30.48" length="middle" direction="out" rot="R180"/>
<pin name="OUT2A" x="25.4" y="25.4" length="middle" direction="out" rot="R180"/>
<pin name="OUT2B" x="25.4" y="22.86" length="middle" direction="out" rot="R180"/>
<wire x1="-20.32" y1="38.1" x2="-20.32" y2="-45.72" width="0.4064" layer="94"/>
<wire x1="-20.32" y1="-45.72" x2="20.32" y2="-45.72" width="0.4064" layer="94"/>
<wire x1="20.32" y1="-45.72" x2="20.32" y2="38.1" width="0.4064" layer="94"/>
<wire x1="20.32" y1="38.1" x2="-20.32" y2="38.1" width="0.4064" layer="94"/>
<text x="-5.0546" y="39.6748" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-5.5118" y="-49.2506" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="UDN2981A-T">
<pin name="VS" x="-17.78" y="10.16" length="middle" direction="pwr"/>
<pin name="IN1" x="-17.78" y="5.08" length="middle" direction="in"/>
<pin name="IN2" x="-17.78" y="2.54" length="middle" direction="in"/>
<pin name="IN3" x="-17.78" y="0" length="middle" direction="in"/>
<pin name="IN4" x="-17.78" y="-2.54" length="middle" direction="in"/>
<pin name="IN5" x="-17.78" y="-5.08" length="middle" direction="in"/>
<pin name="IN6" x="-17.78" y="-7.62" length="middle" direction="in"/>
<pin name="IN7" x="-17.78" y="-10.16" length="middle" direction="in"/>
<pin name="IN8" x="-17.78" y="-12.7" length="middle" direction="in"/>
<pin name="GND" x="-17.78" y="-17.78" length="middle" direction="pas"/>
<pin name="OUT1" x="17.78" y="10.16" length="middle" direction="out" rot="R180"/>
<pin name="OUT2" x="17.78" y="7.62" length="middle" direction="out" rot="R180"/>
<pin name="OUT3" x="17.78" y="5.08" length="middle" direction="out" rot="R180"/>
<pin name="OUT4" x="17.78" y="2.54" length="middle" direction="out" rot="R180"/>
<pin name="OUT5" x="17.78" y="0" length="middle" direction="out" rot="R180"/>
<pin name="OUT6" x="17.78" y="-2.54" length="middle" direction="out" rot="R180"/>
<pin name="OUT7" x="17.78" y="-5.08" length="middle" direction="out" rot="R180"/>
<pin name="OUT8" x="17.78" y="-7.62" length="middle" direction="out" rot="R180"/>
<wire x1="-12.7" y1="15.24" x2="-12.7" y2="-22.86" width="0.4064" layer="94"/>
<wire x1="12.7" y1="-22.86" x2="12.7" y2="15.24" width="0.4064" layer="94"/>
<wire x1="12.7" y1="15.24" x2="-12.7" y2="15.24" width="0.4064" layer="94"/>
<text x="-4.7244" y="19.2786" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-5.2324" y="-28.5242" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="UDN2982A-T">
<pin name="RL_2" x="17.78" y="10.16" length="middle" direction="pas" rot="R180"/>
<pin name="RL_3" x="17.78" y="7.62" length="middle" direction="pas" rot="R180"/>
<pin name="RL_4" x="17.78" y="5.08" length="middle" direction="pas" rot="R180"/>
<pin name="RL_5" x="17.78" y="2.54" length="middle" direction="pas" rot="R180"/>
<pin name="RL_6" x="17.78" y="0" length="middle" direction="pas" rot="R180"/>
<pin name="RL_7" x="17.78" y="-2.54" length="middle" direction="pas" rot="R180"/>
<pin name="RL_8" x="17.78" y="-5.08" length="middle" direction="pas" rot="R180"/>
<pin name="RL" x="17.78" y="-7.62" length="middle" direction="pas" rot="R180"/>
<text x="-4.826" y="17.8308" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-4.2164" y="-27.0256" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
<symbol name="UDN2987A-6-T">
<pin name="VS" x="-17.78" y="15.24" length="middle" direction="pwr"/>
<pin name="OE/~R" x="-17.78" y="10.16" length="middle" direction="in"/>
<pin name="FAULT" x="-17.78" y="7.62" length="middle" direction="in"/>
<pin name="IN1" x="-17.78" y="2.54" length="middle" direction="in"/>
<pin name="IN2" x="-17.78" y="0" length="middle" direction="in"/>
<pin name="IN3" x="-17.78" y="-2.54" length="middle" direction="in"/>
<pin name="IN4" x="-17.78" y="-5.08" length="middle" direction="in"/>
<pin name="IN5" x="-17.78" y="-7.62" length="middle" direction="in"/>
<pin name="IN6" x="-17.78" y="-10.16" length="middle" direction="in"/>
<pin name="IN7" x="-17.78" y="-12.7" length="middle" direction="in"/>
<pin name="IN8" x="-17.78" y="-15.24" length="middle" direction="in"/>
<pin name="GND" x="-17.78" y="-20.32" length="middle" direction="pas"/>
<wire x1="-12.7" y1="20.32" x2="-12.7" y2="-25.4" width="0.4064" layer="94"/>
<wire x1="-12.7" y1="-25.4" x2="12.7" y2="-25.4" width="0.4064" layer="94"/>
<wire x1="12.7" y1="-25.4" x2="12.7" y2="20.32" width="0.4064" layer="94"/>
<text x="-5.3594" y="22.479" size="2.0828" layer="95" ratio="10" rot="SR0">&gt;NAME</text>
<text x="-5.0546" y="-28.4226" size="2.0828" layer="96" ratio="10" rot="SR0">&gt;VALUE</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="A1101ELHLT-T" prefix="U">
<description>Continuous-Time Switch Family</description>
<gates>
<gate name="A" symbol="A1101ELHLT-T" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SOT95P290X110-3N">
<connects>
<connect gate="A" pin="GND" pad="3"/>
<connect gate="A" pin="VCC" pad="1"/>
<connect gate="A" pin="VOUT" pad="2"/>
</connects>
<technologies>
<technology name="">
<attribute name="MPN" value="A1101ELHLT-T" constant="no"/>
<attribute name="OC_FARNELL" value="1198077" constant="no"/>
<attribute name="OC_NEWARK" value="30K5851" constant="no"/>
<attribute name="PACKAGE" value="SOT-23-3" constant="no"/>
<attribute name="SUPPLIER" value="ALLEGRO MICROSYSTEMS" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A1203LLHLT-T" prefix="U">
<description>Continuous-Time Bipolar Switch Family</description>
<gates>
<gate name="A" symbol="A1203LLHLT-T" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SOT95P290X100-3N">
<connects>
</connects>
<technologies>
<attribute name="MPN" value="A1203LLHLT-T" constant="no"/>
<attribute name="OC_FARNELL" value="1791384" constant="no"/>
<attribute name="OC_NEWARK" value="67R6749" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A1321ELHLT-T" prefix="U">
<description>Ratiometric Linear Hall Effect Sensor ICs for High-Temperature Operation</description>
<gates>
<gate name="A" symbol="A1321ELHLT-T" x="0" y="0"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="A1321ELHLT-T" constant="no"/>
<attribute name="OC_FARNELL" value="1521677" constant="no"/>
<attribute name="OC_NEWARK" value="65K5145" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A3901SEJTR-T" prefix="U">
<description>Dual Full Bridge Low Voltage Motor Driver</description>
<gates>
<gate name="A" symbol="A3901SEJTR-T" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DFN300X300X75-11N">
<connects>
<connect gate="A" pin="EPAD" pad="11"/>
<connect gate="A" pin="IN1" pad="1"/>
<connect gate="A" pin="IN2" pad="2"/>
<connect gate="A" pin="IN3" pad="4"/>
<connect gate="A" pin="IN4" pad="5"/>
<connect gate="A" pin="OUT1" pad="10"/>
<connect gate="A" pin="OUT2" pad="9"/>
<connect gate="A" pin="OUT3" pad="7"/>
<connect gate="A" pin="OUT4" pad="6"/>
<connect gate="A" pin="VBB" pad="8"/>
</connects>
<technologies>
<attribute name="MPN" value="A3901SEJTR-T" constant="no"/>
<attribute name="OC_FARNELL" value="1651947" constant="no"/>
<attribute name="OC_NEWARK" value="87K3379" constant="no"/>
<attribute name="PACKAGE" value="DFN-10" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A3953SB-T" prefix="U">
<description>Full-Bridge PWM Motor Driver</description>
<gates>
<gate name="A" symbol="A3953SB-T" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIP254P762X533-16">
<connects>
<connect gate="A" pin="GND" pad="13"/>
<connect gate="A" pin="GND_2" pad="4"/>
<connect gate="A" pin="GND_3" pad="5"/>
<connect gate="A" pin="GND_4" pad="12"/>
<connect gate="A" pin="LOAD_SUPPLY" pad="9"/>
<connect gate="A" pin="LOAD_SUPPLY_2" pad="16"/>
<connect gate="A" pin="LOGIC_SUPPLY" pad="6"/>
<connect gate="A" pin="MODE" pad="14"/>
<connect gate="A" pin="OUTA" pad="10"/>
<connect gate="A" pin="OUTB" pad="15"/>
<connect gate="A" pin="PHASE" pad="7"/>
<connect gate="A" pin="RC" pad="3"/>
<connect gate="A" pin="REF" pad="2"/>
<connect gate="A" pin="SENSE" pad="11"/>
<connect gate="A" pin="~BRAKE" pad="1"/>
<connect gate="A" pin="~EN" pad="8"/>
</connects>
<technologies>
<attribute name="MPN" value="A3953SB-T" constant="no"/>
<attribute name="OC_FARNELL" value="1193497" constant="no"/>
<attribute name="OC_NEWARK" value="08J5866" constant="no"/>
<attribute name="PACKAGE" value="PDIP-16" constant="no"/>
<attribute name="SUPPLIER" value="Allegro" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A3955SB-T" prefix="U">
<description>Full-Bridge PWM Microstepping Motor Driver</description>
<gates>
<gate name="A" symbol="A3955SB-T" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="D0" pad="14"/>
<connect gate="A" pin="D1" pad="9"/>
<connect gate="A" pin="D2" pad="8"/>
<connect gate="A" pin="LOAD_SUPPLY" pad="16"/>
<connect gate="A" pin="PFD" pad="1"/>
</connects>
<technologies>
<attribute name="MPN" value="A3955SB-T" constant="no"/>
<attribute name="OC_FARNELL" value="1193488" constant="no"/>
<attribute name="OC_NEWARK" value="59J2482" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A3967SLB-T" prefix="U">
<description>Microstepping Driver with Translator</description>
<gates>
<gate name="A" symbol="A3967SLB-T" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SOIC127P1030X265-24N">
<connects>
<connect gate="A" pin="DIR" pad="11"/>
<connect gate="A" pin="GND" pad="19"/>
<connect gate="A" pin="GND_2" pad="7"/>
<connect gate="A" pin="GND_3" pad="6"/>
<connect gate="A" pin="GND_4" pad="18"/>
<connect gate="A" pin="LOAD_SUPPLY1" pad="20"/>
<connect gate="A" pin="LOAD_SUPPLY2" pad="5"/>
<connect gate="A" pin="LOGIC_SUPPLY" pad="14"/>
<connect gate="A" pin="MS1" pad="12"/>
<connect gate="A" pin="MS2" pad="13"/>
<connect gate="A" pin="OUT1A" pad="16"/>
<connect gate="A" pin="OUT1B" pad="21"/>
<connect gate="A" pin="OUT2A" pad="9"/>
<connect gate="A" pin="OUT2B" pad="4"/>
<connect gate="A" pin="PFD" pad="24"/>
<connect gate="A" pin="RC1" pad="23"/>
<connect gate="A" pin="RC2" pad="2"/>
<connect gate="A" pin="REF" pad="1"/>
<connect gate="A" pin="SENSE1" pad="17"/>
<connect gate="A" pin="SENSE2" pad="8"/>
<connect gate="A" pin="STEP" pad="10"/>
<connect gate="A" pin="~ENABLE" pad="15"/>
<connect gate="A" pin="~RESET" pad="22"/>
<connect gate="A" pin="~SLEEP" pad="3"/>
</connects>
<technologies>
<attribute name="MPN" value="A3967SLB-T" constant="no"/>
<attribute name="OC_FARNELL" value="1521715" constant="no"/>
<attribute name="OC_NEWARK" value="-" constant="no"/>
<attribute name="PACKAGE" value="SOIC-24" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A3972SB-T" prefix="U">
<description>Dual DMOS Full-Bridge Microstepping PWM Motor Driver</description>
<gates>
<gate name="A" symbol="A3972SB-T" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIP254P762X533-24">
<connects>
<connect gate="A" pin="CLK" pad="11"/>
<connect gate="A" pin="CP1" pad="2"/>
<connect gate="A" pin="CP2" pad="3"/>
<connect gate="A" pin="DATA" pad="12"/>
<connect gate="A" pin="GND_2" pad="6"/>
<connect gate="A" pin="GND_3" pad="7"/>
<connect gate="A" pin="LOAD_SUPPLY1" pad="5"/>
<connect gate="A" pin="LOAD_SUPPLY2" pad="20"/>
<connect gate="A" pin="LOGIC_SUPPLY" pad="15"/>
<connect gate="A" pin="MUX" pad="14"/>
<connect gate="A" pin="OSC" pad="24"/>
<connect gate="A" pin="OUT1A" pad="9"/>
<connect gate="A" pin="OUT1B" pad="4"/>
<connect gate="A" pin="OUT2A" pad="16"/>
<connect gate="A" pin="OUT2B" pad="21"/>
<connect gate="A" pin="REF" pad="13"/>
<connect gate="A" pin="SEN1" pad="8"/>
<connect gate="A" pin="SEN2" pad="17"/>
<connect gate="A" pin="SLEEP" pad="23"/>
<connect gate="A" pin="STRB" pad="10"/>
<connect gate="A" pin="VCP" pad="1"/>
<connect gate="A" pin="VREG" pad="22"/>
</connects>
<technologies>
<attribute name="MPN" value="A3972SB-T" constant="no"/>
<attribute name="OC_FARNELL" value="1457114" constant="no"/>
<attribute name="OC_NEWARK" value="59J2487" constant="no"/>
<attribute name="PACKAGE" value="PDIP-24" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A4931METTR-T" prefix="U">
<description>3-Phase Brushless DC Motor</description>
<gates>
<gate name="A" symbol="A4931METTR-T" x="0" y="0"/>
</gates>
<devices>
<device name="" package="QFN50P500X500X100-29N">
<connects>
<connect gate="A" pin="BRAKEZ" pad="28"/>
<connect gate="A" pin="CLD" pad="25"/>
<connect gate="A" pin="CP1" pad="9"/>
<connect gate="A" pin="CP2" pad="10"/>
<connect gate="A" pin="DIR" pad="26"/>
<connect gate="A" pin="EN" pad="27"/>
<connect gate="A" pin="EPAD" pad="29"/>
<connect gate="A" pin="FG1" pad="23"/>
<connect gate="A" pin="FG2" pad="24"/>
<connect gate="A" pin="GHA" pad="21"/>
<connect gate="A" pin="GHB" pad="19"/>
<connect gate="A" pin="GHC" pad="17"/>
<connect gate="A" pin="GLA" pad="16"/>
<connect gate="A" pin="GLB" pad="15"/>
<connect gate="A" pin="GLC" pad="14"/>
<connect gate="A" pin="GND" pad="7"/>
<connect gate="A" pin="HA+" pad="1"/>
<connect gate="A" pin="HA-" pad="2"/>
<connect gate="A" pin="HB+" pad="3"/>
<connect gate="A" pin="HB-" pad="4"/>
<connect gate="A" pin="HBIAS" pad="8"/>
<connect gate="A" pin="HC+" pad="5"/>
<connect gate="A" pin="HC-" pad="6"/>
<connect gate="A" pin="SA" pad="22"/>
<connect gate="A" pin="SB" pad="20"/>
<connect gate="A" pin="SC" pad="18"/>
<connect gate="A" pin="SENSE" pad="13"/>
<connect gate="A" pin="VBB" pad="11"/>
<connect gate="A" pin="VCP" pad="12"/>
</connects>
<technologies>
<attribute name="MPN" value="A4931METTR-T" constant="no"/>
<attribute name="OC_FARNELL" value="1688964" constant="no"/>
<attribute name="OC_NEWARK" value="61M4134" constant="no"/>
<attribute name="PACKAGE" value="QFN-28" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A4982SETTR-T" prefix="U">
<description>DMOS Microstepping Driver with Translator and Overcurrent Protection</description>
<gates>
<gate name="A" symbol="A4982SETTR-T" x="0" y="0"/>
</gates>
<devices>
<device name="" package="QFN50P500X500X100-33N">
<connects>
<connect gate="A" pin="CP1" pad="7"/>
<connect gate="A" pin="CP2" pad="8"/>
<connect gate="A" pin="DIR" pad="20"/>
<connect gate="A" pin="MS1" pad="11"/>
<connect gate="A" pin="MS2" pad="12"/>
<connect gate="A" pin="NC" pad="31"/>
<connect gate="A" pin="NC_2" pad="2"/>
<connect gate="A" pin="NC_3" pad="4"/>
<connect gate="A" pin="NC_4" pad="21"/>
<connect gate="A" pin="NC_5" pad="23"/>
<connect gate="A" pin="NC_6" pad="26"/>
<connect gate="A" pin="NC_7" pad="29"/>
<connect gate="A" pin="NC_8" pad="28"/>
<connect gate="A" pin="OUT1A" pad="27"/>
<connect gate="A" pin="OUT1B" pad="24"/>
<connect gate="A" pin="OUT2A" pad="30"/>
<connect gate="A" pin="OUT2B" pad="1"/>
<connect gate="A" pin="PAD" pad="33"/>
<connect gate="A" pin="REF" pad="18"/>
<connect gate="A" pin="ROSC" pad="14"/>
<connect gate="A" pin="SENSE1" pad="25"/>
<connect gate="A" pin="SENSE2" pad="32"/>
<connect gate="A" pin="STEP" pad="17"/>
<connect gate="A" pin="VBB1" pad="22"/>
<connect gate="A" pin="VBB2" pad="3"/>
<connect gate="A" pin="VCP" pad="9"/>
<connect gate="A" pin="VDD" pad="16"/>
<connect gate="A" pin="VREG" pad="10"/>
<connect gate="A" pin="~ENABLE" pad="5"/>
<connect gate="A" pin="~RESET" pad="13"/>
<connect gate="A" pin="~SLEEP" pad="15"/>
</connects>
<technologies>
<attribute name="MPN" value="A4982SETTR-T" constant="no"/>
<attribute name="OC_FARNELL" value="-" constant="no"/>
<attribute name="OC_NEWARK" value="67R9667" constant="no"/>
<attribute name="PACKAGE" value="QFN-32" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A4982SLPTR-T" prefix="U">
<gates>
<gate name="A" symbol="A4982SLPTR-T" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SOP65P640X120-25N">
<connects>
<connect gate="A" pin="CP1" pad="1"/>
<connect gate="A" pin="CP2" pad="2"/>
<connect gate="A" pin="DIR" pad="14"/>
<connect gate="A" pin="GND" pad="24"/>
<connect gate="A" pin="GND_2" pad="13"/>
<connect gate="A" pin="MS1" pad="5"/>
<connect gate="A" pin="MS2" pad="6"/>
<connect gate="A" pin="OUT1A" pad="18"/>
<connect gate="A" pin="OUT1B" pad="15"/>
<connect gate="A" pin="OUT2A" pad="19"/>
<connect gate="A" pin="OUT2B" pad="22"/>
<connect gate="A" pin="PAD" pad="25"/>
<connect gate="A" pin="REF" pad="12"/>
<connect gate="A" pin="ROSC" pad="8"/>
<connect gate="A" pin="SENSE2" pad="20"/>
<connect gate="A" pin="STEP" pad="11"/>
<connect gate="A" pin="VBB1" pad="16"/>
<connect gate="A" pin="VBB2" pad="21"/>
<connect gate="A" pin="VCP" pad="3"/>
<connect gate="A" pin="VDD" pad="10"/>
<connect gate="A" pin="VREG" pad="4"/>
<connect gate="A" pin="~ENABLE" pad="23"/>
<connect gate="A" pin="~RESET" pad="7"/>
<connect gate="A" pin="~SLEEP" pad="9"/>
</connects>
<technologies>
<attribute name="MPN" value="A4982SLPTR-T" constant="no"/>
<attribute name="OC_NEWARK" value="67R9668" constant="no"/>
<attribute name="PACKAGE" value="TSSOP-24" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A4983SETTR-T" prefix="U">
<description>DMOS Microstepping Driver</description>
<gates>
<gate name="A" symbol="A4983SETTR-T" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="CP1" pad="4"/>
<connect gate="A" pin="CP2" pad="5"/>
<connect gate="A" pin="DIR" pad="19"/>
<connect gate="A" pin="ENABLE" pad="2"/>
<connect gate="A" pin="GND" pad="18"/>
<connect gate="A" pin="GND_2" pad="3"/>
<connect gate="A" pin="MS1" pad="9"/>
<connect gate="A" pin="MS2" pad="10"/>
<connect gate="A" pin="MS3" pad="11"/>
<connect gate="A" pin="NC" pad="25"/>
<connect gate="A" pin="NC_2" pad="7"/>
<connect gate="A" pin="NC_3" pad="20"/>
<connect gate="A" pin="OUT1A" pad="24"/>
<connect gate="A" pin="OUT2A" pad="26"/>
<connect gate="A" pin="REF" pad="17"/>
<connect gate="A" pin="RESET" pad="12"/>
<connect gate="A" pin="ROSC" pad="13"/>
<connect gate="A" pin="SENSE1" pad="23"/>
<connect gate="A" pin="SENSE2" pad="27"/>
<connect gate="A" pin="SLEEP" pad="14"/>
<connect gate="A" pin="STEP" pad="16"/>
<connect gate="A" pin="VBB2" pad="28"/>
<connect gate="A" pin="VCP" pad="6"/>
<connect gate="A" pin="VDD" pad="15"/>
<connect gate="A" pin="VREG" pad="8"/>
</connects>
<technologies>
<attribute name="MPN" value="A4983SETTR-T" constant="no"/>
<attribute name="OC_FARNELL" value="1688956" constant="no"/>
<attribute name="OC_NEWARK" value="39M6763" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A4984SESTR-T" prefix="U">
<gates>
<gate name="A" symbol="A4984SESTR-T" x="0" y="0"/>
</gates>
<devices>
<device name="" package="QFN50P400X400X80-25N">
<connects>
<connect gate="A" pin="DIR" pad="17"/>
<connect gate="A" pin="GND" pad="16"/>
<connect gate="A" pin="MS1" pad="8"/>
<connect gate="A" pin="MS2" pad="9"/>
<connect gate="A" pin="OUT1A" pad="21"/>
<connect gate="A" pin="OUT1B" pad="18"/>
<connect gate="A" pin="OUT2A" pad="22"/>
<connect gate="A" pin="REF" pad="15"/>
<connect gate="A" pin="ROSC" pad="11"/>
<connect gate="A" pin="SENSE1" pad="20"/>
<connect gate="A" pin="SENSE2" pad="23"/>
<connect gate="A" pin="STEP" pad="14"/>
<connect gate="A" pin="VBB1" pad="19"/>
<connect gate="A" pin="VBB2" pad="24"/>
<connect gate="A" pin="VDD" pad="13"/>
<connect gate="A" pin="VREG" pad="7"/>
<connect gate="A" pin="~ENABLE" pad="2"/>
<connect gate="A" pin="~RESET" pad="10"/>
<connect gate="A" pin="~SLEEP" pad="12"/>
</connects>
<technologies>
<attribute name="MPN" value="A4984SESTR-T" constant="no"/>
<attribute name="OC_NEWARK" value="67R9669" constant="no"/>
<attribute name="PACKAGE" value="QFN-24" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A4984SETTR-T" prefix="U">
<gates>
<gate name="A" symbol="A4984SETTR-T" x="0" y="0"/>
</gates>
<devices>
<device name="" package="QFN50P500X500X90-33N">
<connects>
</connects>
<technologies>
<attribute name="MPN" value="A4984SETTR-T" constant="no"/>
<attribute name="OC_NEWARK" value="67R9670" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A4984SLPTR-T" prefix="U">
<gates>
<gate name="A" symbol="A4984SLPTR-T" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SOP65P640X120-24N">
<connects>
</connects>
<technologies>
<attribute name="MPN" value="A4984SLPTR-T" constant="no"/>
<attribute name="OC_NEWARK" value="67R9671" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A4985SESTR-T" prefix="U">
<gates>
<gate name="A" symbol="A4985SESTR-T" x="0" y="0"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="A4985SESTR-T" constant="no"/>
<attribute name="OC_NEWARK" value="67R9672" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A4985SETTR-T" prefix="U">
<gates>
<gate name="A" symbol="A4985SETTR-T" x="0" y="0"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="A4985SETTR-T" constant="no"/>
<attribute name="OC_NEWARK" value="67R9673" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A4985SLPTR-T" prefix="U">
<gates>
<gate name="A" symbol="A4985SLPTR-T" x="0" y="0"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="A4985SLPTR-T" constant="no"/>
<attribute name="OC_NEWARK" value="67R9674" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A4986SLPTR-T" prefix="U">
<gates>
<gate name="A" symbol="A4986SLPTR-T" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="IN01" pad="11"/>
<connect gate="A" pin="IN02" pad="5"/>
<connect gate="A" pin="IN11" pad="7"/>
<connect gate="A" pin="IN12" pad="6"/>
<connect gate="A" pin="PH1" pad="14"/>
<connect gate="A" pin="PH2" pad="23"/>
</connects>
<technologies>
<attribute name="MPN" value="A4986SLPTR-T" constant="no"/>
<attribute name="OC_NEWARK" value="67R9675" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A4987SESTR-T" prefix="U">
<description>DMOS Dual Full-Bridge PWM Motor Driver with Overcurrent Protection</description>
<gates>
<gate name="A" symbol="A4987SESTR-T" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="IN01" pad="14"/>
<connect gate="A" pin="IN02" pad="8"/>
<connect gate="A" pin="IN11" pad="10"/>
<connect gate="A" pin="IN12" pad="9"/>
<connect gate="A" pin="PH1" pad="17"/>
<connect gate="A" pin="PH2" pad="2"/>
</connects>
<technologies>
<attribute name="MPN" value="A4987SESTR-T" constant="no"/>
<attribute name="OC_NEWARK" value="67R9676" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A4987SLPTR-T" prefix="U">
<gates>
<gate name="A" symbol="A4987SLPTR-T" x="0" y="0"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="A4987SLPTR-T" constant="no"/>
<attribute name="OC_NEWARK" value="67R9677" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A4988SETTR-T" prefix="U">
<gates>
<gate name="A" symbol="A4988SETTR-T" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="PAD" pad="29"/>
<connect gate="A" pin="~RESET" pad="12"/>
<connect gate="A" pin="~SLEEP" pad="14"/>
</connects>
<technologies>
<attribute name="MPN" value="A4988SETTR-T" constant="no"/>
<attribute name="OC_NEWARK" value="67R9678" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A6275EA-T" prefix="U">
<description>8-Bit Serial Input Constant-Current Latched LED Driver</description>
<gates>
<gate name="A" symbol="A6275EA-T" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="CLK" pad="3"/>
<connect gate="A" pin="GND" pad="1"/>
<connect gate="A" pin="LE" pad="4"/>
<connect gate="A" pin="LOGIC_SUPPLY" pad="16"/>
<connect gate="A" pin="OE" pad="13"/>
<connect gate="A" pin="OUT_0" pad="5"/>
<connect gate="A" pin="OUT_1" pad="6"/>
<connect gate="A" pin="OUT_2" pad="7"/>
<connect gate="A" pin="OUT_3" pad="8"/>
<connect gate="A" pin="OUT_4" pad="9"/>
<connect gate="A" pin="OUT_5" pad="10"/>
<connect gate="A" pin="OUT_6" pad="11"/>
<connect gate="A" pin="OUT_7" pad="12"/>
<connect gate="A" pin="R_EXT" pad="15"/>
<connect gate="A" pin="SERI" pad="2"/>
<connect gate="A" pin="SERO" pad="14"/>
</connects>
<technologies>
<attribute name="MPN" value="A6275EA-T" constant="no"/>
<attribute name="OC_FARNELL" value="1193490" constant="no"/>
<attribute name="OC_NEWARK" value="87K3395" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A6276EA-T" prefix="U">
<description>16-Bit Serial Input, Constant-Current Latched LED Driver</description>
<gates>
<gate name="A" symbol="A6276EA-T" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="LATCH_ENABLE" pad="4"/>
<connect gate="A" pin="OUT0" pad="5"/>
<connect gate="A" pin="OUT1" pad="6"/>
<connect gate="A" pin="OUT10" pad="15"/>
<connect gate="A" pin="OUT11" pad="16"/>
<connect gate="A" pin="OUT12" pad="17"/>
<connect gate="A" pin="OUT13" pad="18"/>
<connect gate="A" pin="OUT14" pad="19"/>
<connect gate="A" pin="OUT15" pad="20"/>
<connect gate="A" pin="OUT2" pad="7"/>
<connect gate="A" pin="OUT3" pad="8"/>
<connect gate="A" pin="OUT4" pad="9"/>
<connect gate="A" pin="OUT5" pad="10"/>
<connect gate="A" pin="OUT6" pad="11"/>
<connect gate="A" pin="OUT7" pad="12"/>
<connect gate="A" pin="OUT8" pad="13"/>
<connect gate="A" pin="OUT9" pad="14"/>
<connect gate="A" pin="OUT_EN" pad="21"/>
<connect gate="A" pin="REXT" pad="23"/>
<connect gate="A" pin="SERIN" pad="2"/>
<connect gate="A" pin="SERO" pad="22"/>
<connect gate="A" pin="VDD" pad="24"/>
</connects>
<technologies>
<attribute name="MPN" value="A6276EA-T" constant="no"/>
<attribute name="OC_NEWARK" value="87K3398" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A6279EETTR-T" prefix="U">
<description>LED Drivers with Open LED Detection</description>
<gates>
<gate name="A" symbol="A6279EETTR-T" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="CLOCK" pad="7"/>
<connect gate="A" pin="EP" pad="29"/>
<connect gate="A" pin="GND" pad="5"/>
<connect gate="A" pin="LATCH_ENABLE" pad="9"/>
<connect gate="A" pin="LOGIC_SUPPLY" pad="3"/>
<connect gate="A" pin="NC" pad="4"/>
<connect gate="A" pin="NC_2" pad="8"/>
<connect gate="A" pin="NC_3" pad="18"/>
<connect gate="A" pin="NC_4" pad="28"/>
<connect gate="A" pin="OUT0" pad="10"/>
<connect gate="A" pin="OUT1" pad="11"/>
<connect gate="A" pin="OUT10" pad="21"/>
<connect gate="A" pin="OUT11" pad="22"/>
<connect gate="A" pin="OUT12" pad="23"/>
<connect gate="A" pin="OUT13" pad="24"/>
<connect gate="A" pin="OUT14" pad="25"/>
<connect gate="A" pin="OUT15" pad="26"/>
<connect gate="A" pin="OUT2" pad="12"/>
<connect gate="A" pin="OUT3" pad="13"/>
<connect gate="A" pin="OUT4" pad="14"/>
<connect gate="A" pin="OUT5" pad="15"/>
<connect gate="A" pin="OUT6" pad="16"/>
<connect gate="A" pin="OUT7" pad="17"/>
<connect gate="A" pin="OUT8" pad="19"/>
<connect gate="A" pin="OUT9" pad="20"/>
<connect gate="A" pin="OUTPUT_ENABLE" pad="27"/>
<connect gate="A" pin="REXT" pad="2"/>
<connect gate="A" pin="SERIAL_DATA_IN" pad="6"/>
<connect gate="A" pin="SERIAL_DATA_OUT" pad="1"/>
</connects>
<technologies>
<attribute name="MPN" value="A6279EETTR-T" constant="no"/>
<attribute name="OC_FARNELL" value="1812333" constant="no"/>
<attribute name="OC_NEWARK" value="19M5477" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A6279ELPTR-T" prefix="U">
<description>Serial-Input Constant-Current Latched LED Drivers with Open LED Detection</description>
<gates>
<gate name="A" symbol="A6279ELPTR-T" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="CLOCK" pad="3"/>
<connect gate="A" pin="EP" pad="25"/>
<connect gate="A" pin="LOGIC_SUPPLY" pad="24"/>
<connect gate="A" pin="OUTPUT_ENABLE" pad="21"/>
<connect gate="A" pin="SERIAL_DATA_IN" pad="2"/>
<connect gate="A" pin="SERIAL_DATA_OUT" pad="22"/>
</connects>
<technologies>
<attribute name="MPN" value="A6279ELPTR-T" constant="no"/>
<attribute name="OC_FARNELL" value="1812412" constant="no"/>
<attribute name="OC_NEWARK" value="87K3407" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A6280EESTR-T" prefix="U">
<description>3-Channel Constant-Current LED Driver</description>
<gates>
<gate name="A" symbol="A6280EESTR-T" x="0" y="0"/>
</gates>
<devices>
<device name="" package="QFN50P300X300X75-17N">
<connects>
<connect gate="A" pin="CI" pad="5"/>
<connect gate="A" pin="CO" pad="16"/>
<connect gate="A" pin="EPAD" pad="17"/>
<connect gate="A" pin="LGND" pad="3"/>
<connect gate="A" pin="LI" pad="7"/>
<connect gate="A" pin="LO" pad="14"/>
<connect gate="A" pin="OEI" pad="6"/>
<connect gate="A" pin="OEO" pad="15"/>
<connect gate="A" pin="OUT0" pad="12"/>
<connect gate="A" pin="PGND" pad="10"/>
<connect gate="A" pin="REXT" pad="1"/>
<connect gate="A" pin="SDI" pad="8"/>
<connect gate="A" pin="SDO" pad="13"/>
<connect gate="A" pin="VIN" pad="4"/>
<connect gate="A" pin="VREG" pad="2"/>
</connects>
<technologies>
<attribute name="MPN" value="A6280EESTR-T" constant="no"/>
<attribute name="OC_FARNELL" value="1325029" constant="no"/>
<attribute name="OC_NEWARK" value="19M5479" constant="no"/>
<attribute name="PACKAGE" value="QFN-16" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A6282EESTR-T" prefix="U">
<description>16-Channel Constant-Current LED Driver</description>
<gates>
<gate name="A" symbol="A6282EESTR-T" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="CLK" pad="6"/>
<connect gate="A" pin="EPAD" pad="25"/>
<connect gate="A" pin="GND" pad="4"/>
<connect gate="A" pin="LE" pad="7"/>
<connect gate="A" pin="OUT0" pad="8"/>
<connect gate="A" pin="OUT1" pad="9"/>
<connect gate="A" pin="OUT10" pad="18"/>
<connect gate="A" pin="OUT11" pad="19"/>
<connect gate="A" pin="OUT12" pad="20"/>
<connect gate="A" pin="OUT13" pad="21"/>
<connect gate="A" pin="OUT14" pad="22"/>
<connect gate="A" pin="OUT15" pad="23"/>
<connect gate="A" pin="OUT2" pad="10"/>
<connect gate="A" pin="OUT3" pad="11"/>
<connect gate="A" pin="OUT4" pad="12"/>
<connect gate="A" pin="OUT5" pad="13"/>
<connect gate="A" pin="OUT6" pad="14"/>
<connect gate="A" pin="OUT7" pad="15"/>
<connect gate="A" pin="OUT8" pad="16"/>
<connect gate="A" pin="OUT9" pad="17"/>
<connect gate="A" pin="SDI" pad="5"/>
<connect gate="A" pin="SDO" pad="1"/>
<connect gate="A" pin="VDD" pad="3"/>
<connect gate="A" pin="~OE" pad="24"/>
</connects>
<technologies>
<attribute name="MPN" value="A6282EESTR-T" constant="no"/>
<attribute name="OC_FARNELL" value="1688967" constant="no"/>
<attribute name="OC_NEWARK" value="72M5990" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A6832SEPTR-T" prefix="U">
<description>DABiC-5 32-Bit Serial Input Latched Sink Drivers</description>
<gates>
<gate name="A" symbol="A6832SEPTR-T" x="0" y="0"/>
</gates>
<devices>
<device name="" package="PLCC127P1753X1753X457-44N">
<connects>
<connect gate="A" pin="CLK" pad="44"/>
<connect gate="A" pin="LOGIC_SUPPLY" pad="1"/>
<connect gate="A" pin="NC" pad="40"/>
<connect gate="A" pin="NC_2" pad="5"/>
<connect gate="A" pin="NC_4" pad="23"/>
<connect gate="A" pin="NC_5" pad="28"/>
<connect gate="A" pin="OUT13" pad="19"/>
<connect gate="A" pin="OUT14" pad="20"/>
<connect gate="A" pin="OUT15" pad="21"/>
<connect gate="A" pin="OUT16" pad="22"/>
<connect gate="A" pin="OUT17" pad="24"/>
<connect gate="A" pin="OUT18" pad="25"/>
<connect gate="A" pin="OUT19" pad="26"/>
<connect gate="A" pin="OUT20" pad="27"/>
<connect gate="A" pin="OUT21" pad="29"/>
<connect gate="A" pin="OUT22" pad="30"/>
<connect gate="A" pin="OUT23" pad="31"/>
<connect gate="A" pin="OUT24" pad="32"/>
<connect gate="A" pin="OUT25" pad="33"/>
<connect gate="A" pin="OUT26" pad="34"/>
<connect gate="A" pin="OUT27" pad="35"/>
<connect gate="A" pin="OUT28" pad="36"/>
<connect gate="A" pin="OUT29" pad="37"/>
<connect gate="A" pin="OUT30" pad="38"/>
<connect gate="A" pin="OUT31" pad="39"/>
<connect gate="A" pin="OUT32" pad="41"/>
<connect gate="A" pin="OUT_ENABLE" pad="42"/>
<connect gate="A" pin="SERIAL_DATA_OUT" pad="43"/>
<connect gate="A" pin="STROBE" pad="4"/>
</connects>
<technologies>
<attribute name="MPN" value="A6832SEPTR-T" constant="no"/>
<attribute name="OC_NEWARK" value="31K6684" constant="no"/>
<attribute name="PACKAGE" value="PLCC-44" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A6841SLW-20-T" prefix="U">
<description>DABiC-5 8-Bit Serial Input Latched Sink Drivers</description>
<gates>
<gate name="A" symbol="A6841SLW-20-T" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SOIC127P1032X265-20N">
<connects>
<connect gate="A" pin="CLK" pad="2"/>
<connect gate="A" pin="DATA_IN" pad="3"/>
<connect gate="A" pin="DATA_OUT" pad="6"/>
<connect gate="A" pin="K" pad="12"/>
<connect gate="A" pin="NC" pad="11"/>
<connect gate="A" pin="NC_2" pad="10"/>
<connect gate="A" pin="OUT_1" pad="20"/>
<connect gate="A" pin="OUT_2" pad="19"/>
<connect gate="A" pin="OUT_3" pad="18"/>
<connect gate="A" pin="OUT_4" pad="17"/>
<connect gate="A" pin="OUT_5" pad="16"/>
<connect gate="A" pin="OUT_6" pad="15"/>
<connect gate="A" pin="OUT_7" pad="14"/>
<connect gate="A" pin="OUT_8" pad="13"/>
<connect gate="A" pin="ST" pad="7"/>
<connect gate="A" pin="VDD" pad="5"/>
<connect gate="A" pin="VEE" pad="1"/>
<connect gate="A" pin="VEE_2" pad="9"/>
<connect gate="A" pin="~OE" pad="8"/>
</connects>
<technologies>
<attribute name="MPN" value="A6841SLW-20-T" constant="no"/>
<attribute name="OC_FARNELL" value="1198100" constant="no"/>
<attribute name="PACKAGE" value="SOIC-20" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A8732EEETR-T" prefix="U">
<description>Ultra Small Mobile Phone Xenon Photoflash Capacitor Charger with IGBT Driver</description>
<gates>
<gate name="A" symbol="A8732EEETR-T" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DFN200X200X60-9N">
<connects>
<connect gate="A" pin="CHARGE" pad="8"/>
<connect gate="A" pin="EP" pad="9"/>
<connect gate="A" pin="GATE" pad="3"/>
<connect gate="A" pin="SW" pad="5"/>
<connect gate="A" pin="TRIG" pad="2"/>
<connect gate="A" pin="VBAT" pad="6"/>
<connect gate="A" pin="VIN_DRV" pad="7"/>
<connect gate="A" pin="~DONE" pad="1"/>
</connects>
<technologies>
<attribute name="MPN" value="A8732EEETR-T" constant="no"/>
<attribute name="OC_NEWARK" value="67R9679" constant="no"/>
<attribute name="PACKAGE" value="DFN-8" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="A8735EEETR-T" prefix="U">
<gates>
<gate name="A" symbol="A8735EEETR-T" x="0" y="0"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="A8735EEETR-T" constant="no"/>
<attribute name="OC_NEWARK" value="67R9680" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ACS709LLFTR-20BB-T" prefix="U">
<description>High Bandwidth, Fast Fault Response Current Sensor IC In Thermally Enhanced Package</description>
<gates>
<gate name="A" symbol="ACS709LLFTR-20BB-T" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SOP63P600X175-24N">
<connects>
<connect gate="A" pin="FAULT_EN" pad="22"/>
<connect gate="A" pin="FILTER" pad="17"/>
<connect gate="A" pin="GND" pad="15"/>
<connect gate="A" pin="IP+" pad="6"/>
<connect gate="A" pin="IP+_2" pad="1"/>
<connect gate="A" pin="IP+_3" pad="2"/>
<connect gate="A" pin="IP+_4" pad="3"/>
<connect gate="A" pin="IP+_5" pad="4"/>
<connect gate="A" pin="IP+_6" pad="5"/>
<connect gate="A" pin="IP-" pad="12"/>
<connect gate="A" pin="IP-_2" pad="7"/>
<connect gate="A" pin="IP-_3" pad="8"/>
<connect gate="A" pin="IP-_4" pad="9"/>
<connect gate="A" pin="IP-_5" pad="10"/>
<connect gate="A" pin="IP-_6" pad="11"/>
<connect gate="A" pin="NC" pad="14"/>
<connect gate="A" pin="NC_2" pad="23"/>
<connect gate="A" pin="NC_3" pad="13"/>
<connect gate="A" pin="NC_4" pad="24"/>
<connect gate="A" pin="VCC" pad="20"/>
<connect gate="A" pin="VIOUT" pad="18"/>
<connect gate="A" pin="VOC" pad="21"/>
<connect gate="A" pin="VZCR" pad="16"/>
<connect gate="A" pin="~FAULT" pad="19"/>
</connects>
<technologies>
<attribute name="MPN" value="ACS709LLFTR-20BB-T" constant="no"/>
<attribute name="OC_FARNELL" value="1858083" constant="no"/>
<attribute name="OC_NEWARK" value="58R3722" constant="no"/>
<attribute name="PACKAGE" value="SOP-24" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ACS709LLFTR-35BB-T" prefix="U">
<gates>
<gate name="A" symbol="ACS709LLFTR-35BB-T" x="0" y="0"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="ACS709LLFTR-35BB-T" constant="no"/>
<attribute name="OC_FARNELL" value="1858082" constant="no"/>
<attribute name="OC_NEWARK" value="58R3721" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ACS710KLATR-25CB-T" prefix="U">
<description>Current Sensor with Integrated Overcurrent Detection</description>
<gates>
<gate name="A" symbol="ACS710KLATR-25CB-T" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SOIC127P1030X265-16N">
<connects>
<connect gate="A" pin="FAULT_EN" pad="16"/>
<connect gate="A" pin="FILTER" pad="11"/>
<connect gate="A" pin="GND" pad="9"/>
<connect gate="A" pin="IP+" pad="4"/>
<connect gate="A" pin="IP-" pad="8"/>
<connect gate="A" pin="IP-_2" pad="5"/>
<connect gate="A" pin="IP-_3" pad="6"/>
<connect gate="A" pin="IP-_4" pad="7"/>
<connect gate="A" pin="VCC" pad="14"/>
<connect gate="A" pin="VIOUT" pad="12"/>
<connect gate="A" pin="VOC" pad="15"/>
<connect gate="A" pin="VZCR" pad="10"/>
<connect gate="A" pin="~FAULT" pad="13"/>
</connects>
<technologies>
<attribute name="MPN" value="ACS710KLATR-25CB-T" constant="no"/>
<attribute name="OC_FARNELL" value="1791413" constant="no"/>
<attribute name="OC_NEWARK" value="34R2578" constant="no"/>
<attribute name="PACKAGE" value="SOICW-16" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ACS712ELCTR-05B-T" prefix="U">
<description>Linear Current Sensor</description>
<gates>
<gate name="A" symbol="ACS712ELCTR-05B-T" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SOIC127P600X175-8N">
<connects>
<connect gate="A" pin="FILTER" pad="6"/>
<connect gate="A" pin="IP+" pad="2"/>
<connect gate="A" pin="IP-" pad="3"/>
<connect gate="A" pin="IP-_2" pad="4"/>
<connect gate="A" pin="VCC" pad="8"/>
<connect gate="A" pin="VIOUT" pad="7"/>
</connects>
<technologies>
<attribute name="MPN" value="ACS712ELCTR-05B-T" constant="no"/>
<attribute name="OC_FARNELL" value="1329623" constant="no"/>
<attribute name="OC_NEWARK" value="27M3644" constant="no"/>
<attribute name="PACKAGE" value="SOIC-8" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="ACS712ELCTR-20A-T" prefix="U">
<gates>
<gate name="A" symbol="ACS712ELCTR-20A-T" x="0" y="0"/>
</gates>
<devices>
<connects>
</connects>
<technologies>
<attribute name="MPN" value="ACS712ELCTR-20A-T" constant="no"/>
<attribute name="OC_FARNELL" value="1329624" constant="no"/>
<attribute name="OC_NEWARK" value="31M3133" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="SI-8005Q" prefix="U">
<description>Step-Down Switching Regulator with Current-Mode Control</description>
<gates>
<gate name="A" symbol="SI-8005Q" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SOP127P620X160-9N">
<connects>
<connect gate="A" pin="BS" pad="1"/>
<connect gate="A" pin="COMP" pad="6"/>
<connect gate="A" pin="EN" pad="7"/>
<connect gate="A" pin="FB" pad="5"/>
<connect gate="A" pin="IN" pad="2"/>
<connect gate="A" pin="SS" pad="8"/>
<connect gate="A" pin="SW" pad="3"/>
</connects>
<technologies>
<attribute name="MPN" value="SI-8005Q" constant="no"/>
<attribute name="OC_FARNELL" value="1791398" constant="no"/>
<attribute name="OC_NEWARK" value="67R9074" constant="no"/>
<attribute name="PACKAGE" value="SOP-8" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="UDN2559B-T" prefix="U">
<description>Protected Quad Power Driver</description>
<gates>
<gate name="A" symbol="UDN2559B-T" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="EN" pad="14"/>
<connect gate="A" pin="IN1" pad="9"/>
<connect gate="A" pin="IN2" pad="10"/>
<connect gate="A" pin="IN3" pad="15"/>
<connect gate="A" pin="IN4" pad="16"/>
<connect gate="A" pin="K" pad="7"/>
<connect gate="A" pin="K_2" pad="2"/>
<connect gate="A" pin="OUT1" pad="8"/>
<connect gate="A" pin="OUT2" pad="6"/>
<connect gate="A" pin="OUT3" pad="3"/>
<connect gate="A" pin="OUT4" pad="1"/>
<connect gate="A" pin="VCC" pad="11"/>
</connects>
<technologies>
<attribute name="MPN" value="UDN2559B-T" constant="no"/>
<attribute name="OC_FARNELL" value="1521727" constant="no"/>
<attribute name="OC_NEWARK" value="87K5085" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="UDN2916B-T" prefix="U">
<description>Dual Full-Bridge PWM Motor Driver</description>
<gates>
<gate name="A" symbol="UDN2916B-T" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="E1" pad="23"/>
<connect gate="A" pin="E2" pad="3"/>
<connect gate="A" pin="GND_2" pad="18"/>
<connect gate="A" pin="GND_4" pad="19"/>
<connect gate="A" pin="I01" pad="20"/>
<connect gate="A" pin="I02" pad="8"/>
<connect gate="A" pin="I11" pad="17"/>
<connect gate="A" pin="I12" pad="9"/>
<connect gate="A" pin="LOAD_SUPPLY" pad="24"/>
<connect gate="A" pin="LOGIC_SUPPLY" pad="13"/>
<connect gate="A" pin="OUT_1A" pad="1"/>
<connect gate="A" pin="OUT_1B" pad="21"/>
<connect gate="A" pin="OUT_2A" pad="2"/>
<connect gate="A" pin="OUT_2B" pad="5"/>
<connect gate="A" pin="PHASE_1" pad="16"/>
<connect gate="A" pin="PHASE_2" pad="10"/>
<connect gate="A" pin="RC1" pad="14"/>
<connect gate="A" pin="RC2" pad="12"/>
<connect gate="A" pin="SEN1" pad="22"/>
<connect gate="A" pin="SEN2" pad="4"/>
<connect gate="A" pin="VREF1" pad="15"/>
<connect gate="A" pin="VREF_2" pad="11"/>
</connects>
<technologies>
<attribute name="MPN" value="UDN2916B-T" constant="no"/>
<attribute name="OC_FARNELL" value="1193494" constant="no"/>
<attribute name="OC_NEWARK" value="65K7908" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="UDN2916LBTR-T" prefix="U">
<description>DUAL FULL-BRIDGE PWM MOTOR DRIVER</description>
<gates>
<gate name="A" symbol="UDN2916LBTR-T" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SOIC127P1032X265-24N">
<connects>
<connect gate="A" pin="E1" pad="16"/>
<connect gate="A" pin="E2" pad="21"/>
<connect gate="A" pin="GROUND" pad="7"/>
<connect gate="A" pin="GROUND_2" pad="18"/>
<connect gate="A" pin="GROUND_3" pad="6"/>
<connect gate="A" pin="GROUND_4" pad="19"/>
<connect gate="A" pin="I01" pad="13"/>
<connect gate="A" pin="I02" pad="1"/>
<connect gate="A" pin="I11" pad="12"/>
<connect gate="A" pin="I12" pad="2"/>
<connect gate="A" pin="LOGIC_SUPPLY" pad="8"/>
<connect gate="A" pin="OUT1A" pad="17"/>
<connect gate="A" pin="OUT1B" pad="14"/>
<connect gate="A" pin="OUT2A" pad="20"/>
<connect gate="A" pin="OUT2B" pad="23"/>
<connect gate="A" pin="PHASE1" pad="11"/>
<connect gate="A" pin="PHASE_2" pad="3"/>
<connect gate="A" pin="RC1" pad="9"/>
<connect gate="A" pin="RC2" pad="5"/>
<connect gate="A" pin="SENSE_1" pad="15"/>
<connect gate="A" pin="SENSE_2" pad="22"/>
<connect gate="A" pin="VREF_1" pad="10"/>
<connect gate="A" pin="VREF_2" pad="4"/>
</connects>
<technologies>
<attribute name="MPN" value="UDN2916LBTR-T" constant="no"/>
<attribute name="OC_FARNELL" value="1707913" constant="no"/>
<attribute name="OC_NEWARK" value="59P3286" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="UDN2981A-T" prefix="U">
<description>8-Channel Source Drivers</description>
<gates>
<gate name="A" symbol="UDN2981A-T" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIP254P762X533-18">
<connects>
<connect gate="A" pin="GND" pad="10"/>
<connect gate="A" pin="IN3" pad="3"/>
<connect gate="A" pin="IN4" pad="4"/>
<connect gate="A" pin="IN5" pad="5"/>
<connect gate="A" pin="IN6" pad="6"/>
<connect gate="A" pin="IN7" pad="7"/>
<connect gate="A" pin="IN8" pad="8"/>
<connect gate="A" pin="OUT1" pad="18"/>
<connect gate="A" pin="OUT2" pad="17"/>
<connect gate="A" pin="OUT3" pad="16"/>
<connect gate="A" pin="OUT4" pad="15"/>
<connect gate="A" pin="OUT5" pad="14"/>
<connect gate="A" pin="OUT6" pad="13"/>
<connect gate="A" pin="OUT8" pad="11"/>
<connect gate="A" pin="VS" pad="9"/>
</connects>
<technologies>
<attribute name="MPN" value="UDN2981A-T" constant="no"/>
<attribute name="OC_FARNELL" value="1193495" constant="no"/>
<attribute name="OC_NEWARK" value="31K7841" constant="no"/>
<attribute name="PACKAGE" value="PDIP-18" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="UDN2982A-T" prefix="U">
<gates>
<gate name="A" symbol="UDN2982A-T" x="0" y="0"/>
</gates>
<devices>
<connects>
<connect gate="A" pin="RL" pad="18"/>
<connect gate="A" pin="RL_2" pad="11"/>
<connect gate="A" pin="RL_3" pad="12"/>
<connect gate="A" pin="RL_4" pad="15"/>
<connect gate="A" pin="RL_5" pad="16"/>
<connect gate="A" pin="RL_6" pad="13"/>
<connect gate="A" pin="RL_7" pad="14"/>
<connect gate="A" pin="RL_8" pad="17"/>
</connects>
<technologies>
<attribute name="MPN" value="UDN2982A-T" constant="no"/>
<attribute name="OC_FARNELL" value="1521728" constant="no"/>
<attribute name="OC_NEWARK" value="31K7842" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="UDN2987A-6-T" prefix="U">
<description>8-CHANNEL SOURCE DRIVER WITH OVER-CURRENT PROTECTION</description>
<gates>
<gate name="A" symbol="UDN2987A-6-T" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIP254P762X533-20">
<connects>
<connect gate="A" pin="FAULT" pad="9"/>
<connect gate="A" pin="GND" pad="12"/>
<connect gate="A" pin="OE/~R" pad="10"/>
<connect gate="A" pin="OUT1" pad="20"/>
<connect gate="A" pin="OUT2" pad="19"/>
<connect gate="A" pin="OUT3" pad="18"/>
<connect gate="A" pin="OUT4" pad="17"/>
<connect gate="A" pin="OUT5" pad="16"/>
<connect gate="A" pin="OUT6" pad="15"/>
<connect gate="A" pin="OUT7" pad="14"/>
<connect gate="A" pin="VS" pad="11"/>
</connects>
<technologies>
<attribute name="MPN" value="UDN2987A-6-T" constant="no"/>
<attribute name="OC_FARNELL" value="1521729" constant="no"/>
<attribute name="OC_NEWARK" value="87K5089" constant="no"/>
<attribute name="PACKAGE" value="DIP-20" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
