<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.1">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="no" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="yes" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
</layers>
<library>
<description>&lt;b&gt;IC Packages an Sockets&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DIL04">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="2.54" y1="2.921" x2="-2.54" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-2.921" x2="2.54" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="2.54" y1="2.921" x2="2.54" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="2.921" x2="-2.54" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-2.921" x2="-2.54" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.016" x2="-2.54" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="4.191" y="-2.921" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-2.921" y="-2.667" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
</package>
<package name="DIL06">
<wire x1="3.81" y1="2.921" x2="-3.81" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-2.921" x2="3.81" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="3.81" y1="2.921" x2="3.81" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="2.921" x2="-3.81" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-2.921" x2="-3.81" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.016" x2="-3.81" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.413" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.064" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
</package>
<package name="DIL08">
<wire x1="5.08" y1="2.921" x2="-5.08" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.921" x2="-5.08" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="-5.08" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.016" x2="-5.08" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-5.334" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.556" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL16">
<description>LT1158</description>
<wire x1="10.16" y1="2.921" x2="-10.16" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-2.921" x2="10.16" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="10.16" y1="2.921" x2="10.16" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="2.921" x2="-10.16" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-2.921" x2="-10.16" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="1.016" x2="-10.16" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-10.541" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-7.493" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL18">
<wire x1="11.43" y1="2.921" x2="-11.43" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-2.921" x2="11.43" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="11.43" y1="2.921" x2="11.43" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="2.921" x2="-11.43" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-2.921" x2="-11.43" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="1.016" x2="-11.43" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-10.16" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="10.16" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="10.16" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="-10.16" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-11.684" y="-3.048" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-9.525" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL20">
<wire x1="12.7" y1="2.921" x2="-12.7" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-2.921" x2="12.7" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="12.7" y1="2.921" x2="12.7" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="2.921" x2="-12.7" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-2.921" x2="-12.7" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="1.016" x2="-12.7" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-13.081" y="-3.048" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="-9.779" y="-0.381" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="DIL24S">
<description>&lt;b&gt;Dual In Line Package Small&lt;/b&gt;</description>
<wire x1="15.24" y1="2.921" x2="-15.24" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-2.921" x2="15.24" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="15.24" y1="2.921" x2="15.24" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="2.921" x2="-15.24" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-2.921" x2="-15.24" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="1.016" x2="-15.24" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-15.494" y="-3.048" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-9.398" y="-0.762" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL24">
<wire x1="-15.24" y1="6.731" x2="-15.24" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-6.731" x2="-15.24" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-6.731" x2="15.24" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="15.24" y1="6.731" x2="15.24" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="15.24" y1="6.731" x2="-15.24" y2="6.731" width="0.1524" layer="21"/>
<pad name="1" x="-13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="-6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<text x="-15.494" y="-6.731" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-11.303" y="-0.889" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL28">
<wire x1="17.78" y1="6.731" x2="-17.78" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-6.731" x2="17.78" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="17.78" y1="6.731" x2="17.78" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="6.731" x2="-17.78" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-6.731" x2="-17.78" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="1.016" x2="-17.78" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="-8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="-11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="-13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="-16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<text x="-18.161" y="-6.604" size="1.778" layer="25" rot="R90">&gt;NAME</text>
<text x="-9.779" y="-0.889" size="1.778" layer="27">&gt;VALUE</text>
</package>
<package name="DIL32">
<wire x1="20.32" y1="6.731" x2="-20.32" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-6.731" x2="20.32" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="20.32" y1="6.731" x2="20.32" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="6.731" x2="-20.32" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-6.731" x2="-20.32" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="1.016" x2="-20.32" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="-1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="-3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="-6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="-8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="29" x="-11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="30" x="-13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="31" x="-16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="32" x="-19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<text x="-20.701" y="-6.604" size="1.778" layer="25" rot="R90">&gt;NAME</text>
<text x="-16.891" y="-0.889" size="1.778" layer="27">&gt;VALUE</text>
</package>
<package name="DIL40">
<wire x1="25.4" y1="6.731" x2="-25.4" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-6.731" x2="25.4" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="25.4" y1="6.731" x2="25.4" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="6.731" x2="-25.4" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-6.731" x2="-25.4" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="0.889" x2="-25.4" y2="-1.143" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-24.13" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-21.59" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="-3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="-1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="21.59" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="24.13" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="24.13" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="21.59" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="29" x="3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="30" x="1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="31" x="-1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="32" x="-3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="33" x="-6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="34" x="-8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="35" x="-11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="36" x="-13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="37" x="-16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="38" x="-19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="39" x="-21.59" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="40" x="-24.13" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<text x="-25.908" y="-6.604" size="1.778" layer="25" rot="R90">&gt;NAME</text>
<text x="-17.145" y="-1.016" size="1.778" layer="27">&gt;VALUE</text>
</package>
<package name="PLCC-S20-SOCKET">
<description>&lt;b&gt;Plastic Leaded Chip Carrier&lt;/b&gt; Socket</description>
<wire x1="7.62" y1="7.62" x2="-6.35" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="7.62" x2="-7.62" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="6.35" x2="-7.62" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-7.62" x2="-7.62" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="7.62" y1="-7.62" x2="7.62" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="3.175" x2="-3.175" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-6.604" x2="-3.429" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-5.588" y1="-6.604" x2="-6.604" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-5.588" x2="-4.445" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-4.445" x2="-2.921" y2="-4.445" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="-6.604" x2="-2.921" y2="-4.445" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="-6.604" x2="-2.159" y2="-6.604" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="-4.445" x2="-2.159" y2="-6.604" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="-4.445" x2="-1.651" y2="-4.445" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-6.604" x2="-1.651" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="-6.604" x2="-0.889" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-4.445" x2="-0.889" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-4.445" x2="-0.381" y2="-4.445" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="-6.604" x2="-0.381" y2="-4.445" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="-6.604" x2="0.381" y2="-6.604" width="0.1524" layer="51"/>
<wire x1="0.381" y1="-4.445" x2="0.381" y2="-6.604" width="0.1524" layer="51"/>
<wire x1="0.381" y1="-4.445" x2="0.889" y2="-4.445" width="0.1524" layer="51"/>
<wire x1="0.889" y1="-6.604" x2="0.889" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-6.604" x2="1.651" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-4.445" x2="1.651" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-4.445" x2="2.159" y2="-4.445" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-6.604" x2="2.159" y2="-4.445" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-6.604" x2="2.921" y2="-6.604" width="0.1524" layer="51"/>
<wire x1="2.921" y1="-4.445" x2="2.921" y2="-6.604" width="0.1524" layer="51"/>
<wire x1="2.921" y1="-4.445" x2="4.445" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="6.604" y1="5.588" x2="4.445" y2="3.429" width="0.1524" layer="21"/>
<wire x1="6.604" y1="5.588" x2="5.588" y2="6.604" width="0.1524" layer="21"/>
<wire x1="5.588" y1="6.604" x2="3.429" y2="4.445" width="0.1524" layer="21"/>
<wire x1="4.445" y1="3.429" x2="4.445" y2="2.921" width="0.1524" layer="51"/>
<wire x1="6.604" y1="2.921" x2="4.445" y2="2.921" width="0.1524" layer="51"/>
<wire x1="6.604" y1="2.921" x2="6.604" y2="2.159" width="0.1524" layer="51"/>
<wire x1="4.445" y1="2.159" x2="6.604" y2="2.159" width="0.1524" layer="51"/>
<wire x1="4.445" y1="2.159" x2="4.445" y2="1.651" width="0.1524" layer="51"/>
<wire x1="6.604" y1="1.651" x2="4.445" y2="1.651" width="0.1524" layer="21"/>
<wire x1="6.604" y1="1.651" x2="6.604" y2="0.889" width="0.1524" layer="21"/>
<wire x1="4.445" y1="0.889" x2="6.604" y2="0.889" width="0.1524" layer="21"/>
<wire x1="4.445" y1="0.889" x2="4.445" y2="0.381" width="0.1524" layer="51"/>
<wire x1="6.604" y1="0.381" x2="4.445" y2="0.381" width="0.1524" layer="51"/>
<wire x1="6.604" y1="0.381" x2="6.604" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="4.445" y1="-0.381" x2="6.604" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="4.445" y1="-0.381" x2="4.445" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="6.604" y1="-0.889" x2="4.445" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="6.604" y1="-0.889" x2="6.604" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.651" x2="6.604" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.651" x2="4.445" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="6.604" y1="-2.159" x2="4.445" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="6.604" y1="-2.159" x2="6.604" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="4.445" y1="-2.921" x2="6.604" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="4.445" y1="-2.921" x2="4.445" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-3.429" x2="-4.445" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="-6.604" y1="-2.921" x2="-4.445" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="-6.604" y1="-2.921" x2="-6.604" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="-4.445" y1="-2.159" x2="-6.604" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="-4.445" y1="-2.159" x2="-4.445" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="-6.604" y1="-1.651" x2="-4.445" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-1.651" x2="-6.604" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-0.889" x2="-6.604" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-0.889" x2="-4.445" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-6.604" y1="-0.381" x2="-4.445" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-6.604" y1="-0.381" x2="-6.604" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-4.445" y1="0.381" x2="-6.604" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-4.445" y1="0.381" x2="-4.445" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-6.604" y1="0.889" x2="-4.445" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="0.889" x2="-6.604" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.651" x2="-6.604" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.651" x2="-4.445" y2="2.159" width="0.1524" layer="51"/>
<wire x1="-6.604" y1="2.159" x2="-4.445" y2="2.159" width="0.1524" layer="51"/>
<wire x1="-6.604" y1="2.159" x2="-6.604" y2="2.921" width="0.1524" layer="51"/>
<wire x1="-4.445" y1="2.921" x2="-6.604" y2="2.921" width="0.1524" layer="51"/>
<wire x1="-4.445" y1="2.921" x2="-4.445" y2="3.175" width="0.1524" layer="51"/>
<wire x1="3.429" y1="4.445" x2="2.921" y2="4.445" width="0.1524" layer="51"/>
<wire x1="2.921" y1="6.604" x2="2.921" y2="4.445" width="0.1524" layer="51"/>
<wire x1="2.921" y1="6.604" x2="2.159" y2="6.604" width="0.1524" layer="51"/>
<wire x1="2.159" y1="4.445" x2="2.159" y2="6.604" width="0.1524" layer="51"/>
<wire x1="2.159" y1="4.445" x2="1.651" y2="4.445" width="0.1524" layer="51"/>
<wire x1="1.651" y1="6.604" x2="1.651" y2="4.445" width="0.1524" layer="21"/>
<wire x1="1.651" y1="6.604" x2="0.889" y2="6.604" width="0.1524" layer="21"/>
<wire x1="0.889" y1="4.445" x2="0.889" y2="6.604" width="0.1524" layer="21"/>
<wire x1="0.889" y1="4.445" x2="0.381" y2="4.445" width="0.1524" layer="51"/>
<wire x1="0.381" y1="6.604" x2="0.381" y2="4.445" width="0.1524" layer="51"/>
<wire x1="0.381" y1="6.604" x2="-0.381" y2="6.604" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="4.445" x2="-0.381" y2="6.604" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="4.445" x2="-0.889" y2="4.445" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="6.604" x2="-0.889" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="6.604" x2="-1.651" y2="6.604" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="4.445" x2="-1.651" y2="6.604" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="4.445" x2="-2.159" y2="4.445" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="6.604" x2="-2.159" y2="4.445" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="6.604" x2="-2.921" y2="6.604" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="4.445" x2="-2.921" y2="6.604" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="4.445" x2="-3.175" y2="4.445" width="0.1524" layer="51"/>
<wire x1="0" y1="1.27" x2="0" y2="-0.635" width="0.508" layer="21"/>
<wire x1="0" y1="1.27" x2="0.635" y2="0.635" width="0.508" layer="21"/>
<wire x1="0.635" y1="0.635" x2="-0.635" y2="0.635" width="0.508" layer="21"/>
<wire x1="-0.635" y1="0.635" x2="0" y2="1.27" width="0.508" layer="21"/>
<pad name="1" x="0" y="5.08" drill="0.8128"/>
<pad name="2" x="0" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="3" x="-2.54" y="5.08" drill="0.8128" shape="octagon"/>
<pad name="4" x="-5.08" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="5" x="-2.54" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="6" x="-5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="7" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="8" x="-5.08" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="9" x="-2.54" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="10" x="-2.54" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="11" x="0" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="12" x="0" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="13" x="2.54" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="14" x="5.08" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="15" x="2.54" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="16" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="17" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="18" x="5.08" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="19" x="2.54" y="5.08" drill="0.8128" shape="octagon"/>
<pad name="20" x="2.54" y="2.54" drill="0.8128" shape="octagon"/>
<text x="0" y="8.001" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.35" y="8.001" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="PLCC-S28-SOCKET">
<wire x1="8.89" y1="8.89" x2="-7.62" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="8.89" x2="-8.89" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="7.62" x2="-8.89" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-8.89" x2="-8.89" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-8.89" x2="8.89" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="4.445" x2="-4.445" y2="5.715" width="0.1524" layer="21"/>
<wire x1="-6.858" y1="-7.874" x2="-4.699" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-6.858" y1="-7.874" x2="-7.874" y2="-6.858" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-6.858" x2="-5.715" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-5.715" x2="-4.191" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="-7.874" x2="-4.191" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="-7.874" x2="-3.429" y2="-7.874" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="-5.715" x2="-3.429" y2="-7.874" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="-5.715" x2="-2.921" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="-7.874" x2="-2.921" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-7.874" x2="-2.159" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-5.715" x2="-2.159" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-5.715" x2="-1.651" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-7.874" x2="-1.651" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-7.874" x2="-0.889" y2="-7.874" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="-5.715" x2="-0.889" y2="-7.874" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="-5.715" x2="-0.381" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="-7.874" x2="-0.381" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-7.874" x2="0.381" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-5.715" x2="0.381" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-5.715" x2="0.889" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="0.889" y1="-7.874" x2="0.889" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="0.889" y1="-7.874" x2="1.651" y2="-7.874" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-5.715" x2="1.651" y2="-7.874" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-5.715" x2="2.159" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-7.874" x2="2.159" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-7.874" x2="2.921" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-5.715" x2="2.921" y2="-7.874" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-5.715" x2="3.429" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-7.874" x2="3.429" y2="-5.715" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-7.874" x2="4.191" y2="-7.874" width="0.1524" layer="51"/>
<wire x1="4.191" y1="-5.715" x2="4.191" y2="-7.874" width="0.1524" layer="51"/>
<wire x1="4.191" y1="-5.715" x2="5.715" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="7.874" y1="6.858" x2="5.715" y2="4.699" width="0.1524" layer="21"/>
<wire x1="7.874" y1="6.858" x2="6.858" y2="7.874" width="0.1524" layer="21"/>
<wire x1="6.858" y1="7.874" x2="4.699" y2="5.715" width="0.1524" layer="21"/>
<wire x1="5.715" y1="4.699" x2="5.715" y2="4.191" width="0.1524" layer="51"/>
<wire x1="7.874" y1="4.191" x2="5.715" y2="4.191" width="0.1524" layer="51"/>
<wire x1="7.874" y1="4.191" x2="7.874" y2="3.429" width="0.1524" layer="51"/>
<wire x1="5.715" y1="3.429" x2="7.874" y2="3.429" width="0.1524" layer="51"/>
<wire x1="5.715" y1="3.429" x2="5.715" y2="2.921" width="0.1524" layer="51"/>
<wire x1="7.874" y1="2.921" x2="5.715" y2="2.921" width="0.1524" layer="21"/>
<wire x1="7.874" y1="2.921" x2="7.874" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.159" x2="7.874" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.715" y1="2.159" x2="5.715" y2="1.651" width="0.1524" layer="51"/>
<wire x1="7.874" y1="1.651" x2="5.715" y2="1.651" width="0.1524" layer="51"/>
<wire x1="7.874" y1="1.651" x2="7.874" y2="0.889" width="0.1524" layer="51"/>
<wire x1="5.715" y1="0.889" x2="7.874" y2="0.889" width="0.1524" layer="51"/>
<wire x1="5.715" y1="0.889" x2="5.715" y2="0.381" width="0.1524" layer="51"/>
<wire x1="7.874" y1="0.381" x2="5.715" y2="0.381" width="0.1524" layer="21"/>
<wire x1="7.874" y1="0.381" x2="7.874" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-0.381" x2="7.874" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-0.381" x2="5.715" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="7.874" y1="-0.889" x2="5.715" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="7.874" y1="-0.889" x2="7.874" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="5.715" y1="-1.651" x2="7.874" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="5.715" y1="-1.651" x2="5.715" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="7.874" y1="-2.159" x2="5.715" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="7.874" y1="-2.159" x2="7.874" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.921" x2="7.874" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-2.921" x2="5.715" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="7.874" y1="-3.429" x2="5.715" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="7.874" y1="-3.429" x2="7.874" y2="-4.191" width="0.1524" layer="51"/>
<wire x1="5.715" y1="-4.191" x2="7.874" y2="-4.191" width="0.1524" layer="51"/>
<wire x1="5.715" y1="-4.191" x2="5.715" y2="-5.715" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-4.699" x2="-5.715" y2="-4.191" width="0.1524" layer="51"/>
<wire x1="-7.874" y1="-4.191" x2="-5.715" y2="-4.191" width="0.1524" layer="51"/>
<wire x1="-7.874" y1="-4.191" x2="-7.874" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="-3.429" x2="-7.874" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="-3.429" x2="-5.715" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="-7.874" y1="-2.921" x2="-5.715" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-2.921" x2="-7.874" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.159" x2="-7.874" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.159" x2="-5.715" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="-7.874" y1="-1.651" x2="-5.715" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="-7.874" y1="-1.651" x2="-7.874" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="-0.889" x2="-7.874" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="-0.889" x2="-5.715" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-7.874" y1="-0.381" x2="-5.715" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-0.381" x2="-7.874" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="0.381" x2="-7.874" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="0.381" x2="-5.715" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-7.874" y1="0.889" x2="-5.715" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-7.874" y1="0.889" x2="-7.874" y2="1.651" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="1.651" x2="-7.874" y2="1.651" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="1.651" x2="-5.715" y2="2.159" width="0.1524" layer="51"/>
<wire x1="-7.874" y1="2.159" x2="-5.715" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="2.159" x2="-7.874" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.921" x2="-7.874" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="2.921" x2="-5.715" y2="3.429" width="0.1524" layer="51"/>
<wire x1="-7.874" y1="3.429" x2="-5.715" y2="3.429" width="0.1524" layer="51"/>
<wire x1="-7.874" y1="3.429" x2="-7.874" y2="4.191" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="4.191" x2="-7.874" y2="4.191" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="4.191" x2="-5.715" y2="4.445" width="0.1524" layer="51"/>
<wire x1="4.699" y1="5.715" x2="4.191" y2="5.715" width="0.1524" layer="51"/>
<wire x1="4.191" y1="7.874" x2="4.191" y2="5.715" width="0.1524" layer="51"/>
<wire x1="4.191" y1="7.874" x2="3.429" y2="7.874" width="0.1524" layer="51"/>
<wire x1="3.429" y1="5.715" x2="3.429" y2="7.874" width="0.1524" layer="51"/>
<wire x1="3.429" y1="5.715" x2="2.921" y2="5.715" width="0.1524" layer="51"/>
<wire x1="2.921" y1="7.874" x2="2.921" y2="5.715" width="0.1524" layer="21"/>
<wire x1="2.921" y1="7.874" x2="2.159" y2="7.874" width="0.1524" layer="21"/>
<wire x1="2.159" y1="5.715" x2="2.159" y2="7.874" width="0.1524" layer="21"/>
<wire x1="2.159" y1="5.715" x2="1.651" y2="5.715" width="0.1524" layer="51"/>
<wire x1="1.651" y1="7.874" x2="1.651" y2="5.715" width="0.1524" layer="51"/>
<wire x1="1.651" y1="7.874" x2="0.889" y2="7.874" width="0.1524" layer="51"/>
<wire x1="0.889" y1="5.715" x2="0.889" y2="7.874" width="0.1524" layer="51"/>
<wire x1="0.889" y1="5.715" x2="0.381" y2="5.715" width="0.1524" layer="51"/>
<wire x1="0.381" y1="7.874" x2="0.381" y2="5.715" width="0.1524" layer="21"/>
<wire x1="0.381" y1="7.874" x2="-0.381" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="5.715" x2="-0.381" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="5.715" x2="-0.889" y2="5.715" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="7.874" x2="-0.889" y2="5.715" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="7.874" x2="-1.651" y2="7.874" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="5.715" x2="-1.651" y2="7.874" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="5.715" x2="-2.159" y2="5.715" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="7.874" x2="-2.159" y2="5.715" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="7.874" x2="-2.921" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="5.715" x2="-2.921" y2="7.874" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="5.715" x2="-3.429" y2="5.715" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="7.874" x2="-3.429" y2="5.715" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="7.874" x2="-4.191" y2="7.874" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="5.715" x2="-4.191" y2="7.874" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="5.715" x2="-4.445" y2="5.715" width="0.1524" layer="51"/>
<wire x1="0" y1="5.588" x2="0" y2="3.175" width="0.1524" layer="21"/>
<wire x1="0" y1="5.588" x2="0.635" y2="4.953" width="0.508" layer="21"/>
<wire x1="0.635" y1="4.953" x2="-0.635" y2="4.953" width="0.508" layer="21"/>
<wire x1="-0.635" y1="4.953" x2="0" y2="5.588" width="0.508" layer="21"/>
<circle x="-2.54" y="2.54" radius="1.27" width="0.1524" layer="51"/>
<circle x="2.54" y="2.54" radius="1.27" width="0.1524" layer="51"/>
<circle x="-2.54" y="-2.54" radius="1.27" width="0.1524" layer="51"/>
<circle x="2.54" y="-2.54" radius="1.27" width="0.1524" layer="51"/>
<pad name="1" x="1.27" y="3.81" drill="0.8128"/>
<pad name="2" x="-1.27" y="6.35" drill="0.8128" shape="octagon"/>
<pad name="3" x="-1.27" y="3.81" drill="0.8128" shape="octagon"/>
<pad name="4" x="-3.81" y="6.35" drill="0.8128" shape="octagon"/>
<pad name="5" x="-6.35" y="3.81" drill="0.8128" shape="octagon"/>
<pad name="6" x="-3.81" y="3.81" drill="0.8128" shape="octagon"/>
<pad name="7" x="-6.35" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="8" x="-3.81" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="9" x="-6.35" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="10" x="-3.81" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="11" x="-6.35" y="-3.81" drill="0.8128" shape="octagon"/>
<pad name="12" x="-3.81" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="13" x="-3.81" y="-3.81" drill="0.8128" shape="octagon"/>
<pad name="14" x="-1.27" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="15" x="-1.27" y="-3.81" drill="0.8128" shape="octagon"/>
<pad name="16" x="1.27" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="17" x="1.27" y="-3.81" drill="0.8128" shape="octagon"/>
<pad name="18" x="3.81" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="19" x="6.35" y="-3.81" drill="0.8128" shape="octagon"/>
<pad name="20" x="3.81" y="-3.81" drill="0.8128" shape="octagon"/>
<pad name="21" x="6.35" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="22" x="3.81" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="23" x="6.35" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="24" x="3.81" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="25" x="6.35" y="3.81" drill="0.8128" shape="octagon"/>
<pad name="26" x="3.81" y="6.35" drill="0.8128" shape="octagon"/>
<pad name="27" x="3.81" y="3.81" drill="0.8128" shape="octagon"/>
<pad name="28" x="1.27" y="6.35" drill="0.8128" shape="octagon"/>
<text x="0" y="9.271" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-7.62" y="9.271" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="PLCC-S32--SOCKET">
<wire x1="8.89" y1="10.16" x2="-7.62" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="10.16" x2="-8.89" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="8.89" x2="-8.89" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-10.16" x2="-8.89" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-10.16" x2="8.89" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="5.715" x2="-4.445" y2="6.985" width="0.1524" layer="21"/>
<wire x1="-6.858" y1="-9.144" x2="-4.699" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-6.858" y1="-9.144" x2="-7.874" y2="-8.128" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-8.128" x2="-5.715" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-6.985" x2="-4.191" y2="-6.985" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="-9.144" x2="-4.191" y2="-6.985" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="-9.144" x2="-3.429" y2="-9.144" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="-6.985" x2="-3.429" y2="-9.144" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="-6.985" x2="-2.921" y2="-6.985" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="-9.144" x2="-2.921" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-9.144" x2="-2.159" y2="-9.144" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-6.985" x2="-2.159" y2="-9.144" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-6.985" x2="-1.651" y2="-6.985" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-9.144" x2="-1.651" y2="-6.985" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-9.144" x2="-0.889" y2="-9.144" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="-6.985" x2="-0.889" y2="-9.144" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="-6.985" x2="-0.381" y2="-6.985" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="-9.144" x2="-0.381" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-9.144" x2="0.381" y2="-9.144" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-6.985" x2="0.381" y2="-9.144" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-6.985" x2="0.889" y2="-6.985" width="0.1524" layer="51"/>
<wire x1="0.889" y1="-9.144" x2="0.889" y2="-6.985" width="0.1524" layer="51"/>
<wire x1="0.889" y1="-9.144" x2="1.651" y2="-9.144" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-6.985" x2="1.651" y2="-9.144" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-6.985" x2="2.159" y2="-6.985" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-9.144" x2="2.159" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-9.144" x2="2.921" y2="-9.144" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-6.985" x2="2.921" y2="-9.144" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-6.985" x2="3.429" y2="-6.985" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-9.144" x2="3.429" y2="-6.985" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-9.144" x2="4.191" y2="-9.144" width="0.1524" layer="51"/>
<wire x1="4.191" y1="-6.985" x2="4.191" y2="-9.144" width="0.1524" layer="51"/>
<wire x1="4.191" y1="-6.985" x2="5.715" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="7.874" y1="8.128" x2="5.715" y2="5.969" width="0.1524" layer="21"/>
<wire x1="7.874" y1="8.128" x2="6.858" y2="9.144" width="0.1524" layer="21"/>
<wire x1="6.858" y1="9.144" x2="4.699" y2="6.985" width="0.1524" layer="21"/>
<wire x1="5.715" y1="5.969" x2="5.715" y2="5.461" width="0.1524" layer="51"/>
<wire x1="7.874" y1="5.461" x2="5.715" y2="5.461" width="0.1524" layer="51"/>
<wire x1="7.874" y1="5.461" x2="7.874" y2="4.699" width="0.1524" layer="51"/>
<wire x1="5.715" y1="4.699" x2="7.874" y2="4.699" width="0.1524" layer="51"/>
<wire x1="7.874" y1="4.191" x2="5.715" y2="4.191" width="0.1524" layer="21"/>
<wire x1="7.874" y1="4.191" x2="7.874" y2="3.429" width="0.1524" layer="21"/>
<wire x1="5.715" y1="3.429" x2="7.874" y2="3.429" width="0.1524" layer="21"/>
<wire x1="7.874" y1="2.921" x2="5.715" y2="2.921" width="0.1524" layer="51"/>
<wire x1="5.715" y1="-0.381" x2="7.874" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="7.874" y1="-0.889" x2="5.715" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="7.874" y1="-0.889" x2="7.874" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.651" x2="7.874" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="7.874" y1="-2.159" x2="5.715" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="7.874" y1="-2.159" x2="7.874" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="5.715" y1="-2.921" x2="7.874" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="7.874" y1="-3.429" x2="5.715" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="7.874" y1="-3.429" x2="7.874" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-4.191" x2="7.874" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-4.191" x2="5.715" y2="-4.699" width="0.1524" layer="51"/>
<wire x1="7.874" y1="-4.699" x2="5.715" y2="-4.699" width="0.1524" layer="51"/>
<wire x1="7.874" y1="-4.699" x2="7.874" y2="-5.461" width="0.1524" layer="51"/>
<wire x1="5.715" y1="-5.461" x2="7.874" y2="-5.461" width="0.1524" layer="51"/>
<wire x1="5.715" y1="-5.461" x2="5.715" y2="-6.985" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-5.969" x2="-5.715" y2="-5.461" width="0.1524" layer="51"/>
<wire x1="-7.874" y1="-5.461" x2="-5.715" y2="-5.461" width="0.1524" layer="51"/>
<wire x1="-7.874" y1="-5.461" x2="-7.874" y2="-4.699" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="-4.699" x2="-7.874" y2="-4.699" width="0.1524" layer="51"/>
<wire x1="-7.874" y1="-4.191" x2="-5.715" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-4.191" x2="-7.874" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-3.429" x2="-7.874" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-2.921" x2="-5.715" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="-7.874" y1="-2.921" x2="-7.874" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="-2.159" x2="-7.874" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="-7.874" y1="-1.651" x2="-5.715" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-1.651" x2="-7.874" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-0.889" x2="-7.874" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-0.381" x2="-5.715" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="2.921" x2="-7.874" y2="2.921" width="0.1524" layer="51"/>
<wire x1="-7.874" y1="3.429" x2="-5.715" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="3.429" x2="-7.874" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="4.191" x2="-7.874" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="4.191" x2="-5.715" y2="4.699" width="0.1524" layer="51"/>
<wire x1="-7.874" y1="4.699" x2="-5.715" y2="4.699" width="0.1524" layer="51"/>
<wire x1="-7.874" y1="4.699" x2="-7.874" y2="5.461" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="5.461" x2="-7.874" y2="5.461" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="5.461" x2="-5.715" y2="5.715" width="0.1524" layer="51"/>
<wire x1="4.699" y1="6.985" x2="4.191" y2="6.985" width="0.1524" layer="51"/>
<wire x1="4.191" y1="9.144" x2="4.191" y2="6.985" width="0.1524" layer="51"/>
<wire x1="4.191" y1="9.144" x2="3.429" y2="9.144" width="0.1524" layer="51"/>
<wire x1="3.429" y1="6.985" x2="3.429" y2="9.144" width="0.1524" layer="51"/>
<wire x1="3.429" y1="6.985" x2="2.921" y2="6.985" width="0.1524" layer="51"/>
<wire x1="2.921" y1="9.144" x2="2.921" y2="6.985" width="0.1524" layer="21"/>
<wire x1="2.921" y1="9.144" x2="2.159" y2="9.144" width="0.1524" layer="21"/>
<wire x1="2.159" y1="6.985" x2="2.159" y2="9.144" width="0.1524" layer="21"/>
<wire x1="2.159" y1="6.985" x2="1.651" y2="6.985" width="0.1524" layer="51"/>
<wire x1="1.651" y1="9.144" x2="1.651" y2="6.985" width="0.1524" layer="51"/>
<wire x1="1.651" y1="9.144" x2="0.889" y2="9.144" width="0.1524" layer="51"/>
<wire x1="0.889" y1="6.985" x2="0.889" y2="9.144" width="0.1524" layer="51"/>
<wire x1="0.889" y1="6.985" x2="0.381" y2="6.985" width="0.1524" layer="51"/>
<wire x1="0.381" y1="9.144" x2="0.381" y2="6.985" width="0.1524" layer="21"/>
<wire x1="0.381" y1="9.144" x2="-0.381" y2="9.144" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="6.985" x2="-0.381" y2="9.144" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="6.985" x2="-0.889" y2="6.985" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="9.144" x2="-0.889" y2="6.985" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="9.144" x2="-1.651" y2="9.144" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="6.985" x2="-1.651" y2="9.144" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="6.985" x2="-2.159" y2="6.985" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="9.144" x2="-2.159" y2="6.985" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="9.144" x2="-2.921" y2="9.144" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="6.985" x2="-2.921" y2="9.144" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="6.985" x2="-3.429" y2="6.985" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="9.144" x2="-3.429" y2="6.985" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="9.144" x2="-4.191" y2="9.144" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="6.985" x2="-4.191" y2="9.144" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="6.985" x2="-4.445" y2="6.985" width="0.1524" layer="51"/>
<wire x1="0" y1="6.731" x2="0" y2="4.445" width="0.1524" layer="21"/>
<wire x1="0" y1="6.731" x2="0.635" y2="6.096" width="0.508" layer="21"/>
<wire x1="0.635" y1="6.096" x2="-0.635" y2="6.096" width="0.508" layer="21"/>
<wire x1="-0.635" y1="6.096" x2="0" y2="6.731" width="0.508" layer="21"/>
<wire x1="7.874" y1="2.921" x2="7.874" y2="2.159" width="0.1524" layer="51"/>
<wire x1="5.715" y1="2.159" x2="7.874" y2="2.159" width="0.1524" layer="51"/>
<wire x1="7.874" y1="1.651" x2="5.715" y2="1.651" width="0.1524" layer="21"/>
<wire x1="7.874" y1="1.651" x2="7.874" y2="0.889" width="0.1524" layer="21"/>
<wire x1="5.715" y1="0.889" x2="7.874" y2="0.889" width="0.1524" layer="21"/>
<wire x1="7.874" y1="0.381" x2="5.715" y2="0.381" width="0.1524" layer="51"/>
<wire x1="7.874" y1="0.381" x2="7.874" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-7.874" y1="-0.381" x2="-7.874" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="0.381" x2="-7.874" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-7.874" y1="0.889" x2="-5.715" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="0.889" x2="-7.874" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="1.651" x2="-7.874" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="2.159" x2="-5.715" y2="2.159" width="0.1524" layer="51"/>
<wire x1="-7.874" y1="2.159" x2="-7.874" y2="2.921" width="0.1524" layer="51"/>
<pad name="1" x="1.27" y="5.08" drill="0.8128"/>
<pad name="2" x="-1.27" y="7.62" drill="0.8128" shape="octagon"/>
<pad name="3" x="-1.27" y="5.08" drill="0.8128" shape="octagon"/>
<pad name="4" x="-3.81" y="7.62" drill="0.8128" shape="octagon"/>
<pad name="5" x="-6.35" y="5.08" drill="0.8128" shape="octagon"/>
<pad name="6" x="-3.81" y="5.08" drill="0.8128" shape="octagon"/>
<pad name="7" x="-6.35" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="8" x="-3.81" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="9" x="-6.35" y="0" drill="0.8128" shape="octagon"/>
<pad name="10" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="11" x="-6.35" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="12" x="-3.81" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="13" x="-6.35" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="14" x="-3.81" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="15" x="-3.81" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="16" x="-1.27" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="17" x="-1.27" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="18" x="1.27" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="19" x="1.27" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="20" x="3.81" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="21" x="6.35" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="22" x="3.81" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="23" x="6.35" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="24" x="3.81" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="25" x="6.35" y="0" drill="0.8128" shape="octagon"/>
<pad name="26" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="27" x="6.35" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="28" x="3.81" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="29" x="6.35" y="5.08" drill="0.8128" shape="octagon"/>
<pad name="30" x="3.81" y="7.62" drill="0.8128" shape="octagon"/>
<pad name="31" x="3.81" y="5.08" drill="0.8128" shape="octagon"/>
<pad name="32" x="1.27" y="7.62" drill="0.8128" shape="octagon"/>
<text x="0" y="10.541" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-7.62" y="10.541" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="PLCC-S44-SOCKET">
<wire x1="11.43" y1="11.43" x2="-10.16" y2="11.43" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="11.43" x2="-11.43" y2="10.16" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="10.16" x2="-11.43" y2="-11.43" width="0.1524" layer="21"/>
<wire x1="11.43" y1="-11.43" x2="-11.43" y2="-11.43" width="0.1524" layer="21"/>
<wire x1="11.43" y1="-11.43" x2="11.43" y2="11.43" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="6.985" x2="-6.985" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-9.398" y1="-10.414" x2="-7.239" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-9.398" y1="-10.414" x2="-10.414" y2="-9.398" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-9.398" x2="-8.255" y2="-7.239" width="0.1524" layer="21"/>
<wire x1="-7.239" y1="-8.255" x2="-6.731" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-6.731" y1="-10.414" x2="-6.731" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-6.731" y1="-10.414" x2="-5.969" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="-5.969" y1="-8.255" x2="-5.969" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="-5.969" y1="-8.255" x2="-5.461" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-5.461" y1="-10.414" x2="-5.461" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="-10.414" x2="-4.699" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-8.255" x2="-4.699" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-8.255" x2="-4.191" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="-10.414" x2="-4.191" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="-10.414" x2="-3.429" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="-8.255" x2="-3.429" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="-8.255" x2="-2.921" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="-10.414" x2="-2.921" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-10.414" x2="-2.159" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-8.255" x2="-2.159" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-8.255" x2="-1.651" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-10.414" x2="-1.651" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-10.414" x2="-0.889" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="-8.255" x2="-0.889" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="-8.255" x2="-0.381" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="-10.414" x2="-0.381" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="-10.414" x2="0.381" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-8.255" x2="0.381" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="0.381" y1="-8.255" x2="0.889" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="0.889" y1="-10.414" x2="0.889" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="0.889" y1="-10.414" x2="1.651" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-8.255" x2="1.651" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="10.414" y1="9.398" x2="8.255" y2="7.239" width="0.1524" layer="21"/>
<wire x1="10.414" y1="9.398" x2="9.398" y2="10.414" width="0.1524" layer="21"/>
<wire x1="9.398" y1="10.414" x2="7.239" y2="8.255" width="0.1524" layer="21"/>
<wire x1="8.255" y1="7.239" x2="8.255" y2="6.731" width="0.1524" layer="51"/>
<wire x1="10.414" y1="6.731" x2="8.255" y2="6.731" width="0.1524" layer="51"/>
<wire x1="10.414" y1="6.731" x2="10.414" y2="5.969" width="0.1524" layer="51"/>
<wire x1="8.255" y1="5.969" x2="10.414" y2="5.969" width="0.1524" layer="51"/>
<wire x1="8.255" y1="5.969" x2="8.255" y2="5.461" width="0.1524" layer="51"/>
<wire x1="10.414" y1="5.461" x2="8.255" y2="5.461" width="0.1524" layer="21"/>
<wire x1="10.414" y1="5.461" x2="10.414" y2="4.699" width="0.1524" layer="21"/>
<wire x1="8.255" y1="4.699" x2="10.414" y2="4.699" width="0.1524" layer="21"/>
<wire x1="8.255" y1="4.699" x2="8.255" y2="4.191" width="0.1524" layer="51"/>
<wire x1="10.414" y1="4.191" x2="8.255" y2="4.191" width="0.1524" layer="51"/>
<wire x1="10.414" y1="4.191" x2="10.414" y2="3.429" width="0.1524" layer="51"/>
<wire x1="8.255" y1="3.429" x2="10.414" y2="3.429" width="0.1524" layer="51"/>
<wire x1="8.255" y1="3.429" x2="8.255" y2="2.921" width="0.1524" layer="51"/>
<wire x1="10.414" y1="2.921" x2="8.255" y2="2.921" width="0.1524" layer="21"/>
<wire x1="10.414" y1="2.921" x2="10.414" y2="2.159" width="0.1524" layer="21"/>
<wire x1="8.255" y1="2.159" x2="10.414" y2="2.159" width="0.1524" layer="21"/>
<wire x1="8.255" y1="2.159" x2="8.255" y2="1.651" width="0.1524" layer="51"/>
<wire x1="10.414" y1="1.651" x2="8.255" y2="1.651" width="0.1524" layer="51"/>
<wire x1="10.414" y1="1.651" x2="10.414" y2="0.889" width="0.1524" layer="51"/>
<wire x1="8.255" y1="0.889" x2="10.414" y2="0.889" width="0.1524" layer="51"/>
<wire x1="8.255" y1="0.889" x2="8.255" y2="0.381" width="0.1524" layer="51"/>
<wire x1="10.414" y1="0.381" x2="8.255" y2="0.381" width="0.1524" layer="21"/>
<wire x1="10.414" y1="0.381" x2="10.414" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-0.381" x2="10.414" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-0.381" x2="8.255" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-0.889" x2="8.255" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-0.889" x2="10.414" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-1.651" x2="10.414" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-7.239" x2="-8.255" y2="-6.731" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-6.731" x2="-8.255" y2="-6.731" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-6.731" x2="-10.414" y2="-5.969" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-5.969" x2="-10.414" y2="-5.969" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-5.969" x2="-8.255" y2="-5.461" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-5.461" x2="-8.255" y2="-5.461" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-5.461" x2="-10.414" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-4.699" x2="-10.414" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-4.699" x2="-8.255" y2="-4.191" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-4.191" x2="-8.255" y2="-4.191" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-4.191" x2="-10.414" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-3.429" x2="-10.414" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-3.429" x2="-8.255" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-2.921" x2="-8.255" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-2.921" x2="-10.414" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-2.159" x2="-10.414" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-2.159" x2="-8.255" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-1.651" x2="-8.255" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-1.651" x2="-10.414" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-0.889" x2="-10.414" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-0.889" x2="-8.255" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="-0.381" x2="-8.255" y2="-0.381" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-0.381" x2="-10.414" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="0.381" x2="-10.414" y2="0.381" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="0.381" x2="-8.255" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="0.889" x2="-8.255" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="0.889" x2="-10.414" y2="1.651" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="1.651" x2="-10.414" y2="1.651" width="0.1524" layer="51"/>
<wire x1="7.239" y1="8.255" x2="6.731" y2="8.255" width="0.1524" layer="51"/>
<wire x1="6.731" y1="10.414" x2="6.731" y2="8.255" width="0.1524" layer="51"/>
<wire x1="6.731" y1="10.414" x2="5.969" y2="10.414" width="0.1524" layer="51"/>
<wire x1="5.969" y1="8.255" x2="5.969" y2="10.414" width="0.1524" layer="51"/>
<wire x1="5.969" y1="8.255" x2="5.461" y2="8.255" width="0.1524" layer="51"/>
<wire x1="5.461" y1="10.414" x2="5.461" y2="8.255" width="0.1524" layer="21"/>
<wire x1="5.461" y1="10.414" x2="4.699" y2="10.414" width="0.1524" layer="21"/>
<wire x1="4.699" y1="8.255" x2="4.699" y2="10.414" width="0.1524" layer="21"/>
<wire x1="4.699" y1="8.255" x2="4.191" y2="8.255" width="0.1524" layer="51"/>
<wire x1="4.191" y1="10.414" x2="4.191" y2="8.255" width="0.1524" layer="51"/>
<wire x1="4.191" y1="10.414" x2="3.429" y2="10.414" width="0.1524" layer="51"/>
<wire x1="3.429" y1="8.255" x2="3.429" y2="10.414" width="0.1524" layer="51"/>
<wire x1="3.429" y1="8.255" x2="2.921" y2="8.255" width="0.1524" layer="51"/>
<wire x1="2.921" y1="10.414" x2="2.921" y2="8.255" width="0.1524" layer="21"/>
<wire x1="2.921" y1="10.414" x2="2.159" y2="10.414" width="0.1524" layer="21"/>
<wire x1="2.159" y1="8.255" x2="2.159" y2="10.414" width="0.1524" layer="21"/>
<wire x1="2.159" y1="8.255" x2="1.651" y2="8.255" width="0.1524" layer="51"/>
<wire x1="1.651" y1="10.414" x2="1.651" y2="8.255" width="0.1524" layer="51"/>
<wire x1="1.651" y1="10.414" x2="0.889" y2="10.414" width="0.1524" layer="51"/>
<wire x1="0.889" y1="8.255" x2="0.889" y2="10.414" width="0.1524" layer="51"/>
<wire x1="0.889" y1="8.255" x2="0.381" y2="8.255" width="0.1524" layer="51"/>
<wire x1="0.381" y1="10.414" x2="0.381" y2="8.255" width="0.1524" layer="21"/>
<wire x1="0.381" y1="10.414" x2="-0.381" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="8.255" x2="-0.381" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="8.255" x2="-0.889" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="10.414" x2="-0.889" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="10.414" x2="-1.651" y2="10.414" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="8.255" x2="-1.651" y2="10.414" width="0.1524" layer="51"/>
<wire x1="0" y1="5.08" x2="0" y2="3.175" width="0.508" layer="21"/>
<wire x1="0" y1="5.08" x2="0.635" y2="4.445" width="0.508" layer="21"/>
<wire x1="0.635" y1="4.445" x2="-0.635" y2="4.445" width="0.508" layer="21"/>
<wire x1="-0.635" y1="4.445" x2="0" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="8.255" x2="-2.159" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="10.414" x2="-2.159" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="10.414" x2="-2.921" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="8.255" x2="-2.921" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="8.255" x2="-3.429" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="10.414" x2="-3.429" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="10.414" x2="-4.191" y2="10.414" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="8.255" x2="-4.191" y2="10.414" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="8.255" x2="-4.699" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-4.699" y1="10.414" x2="-4.699" y2="8.255" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="10.414" x2="-5.461" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="8.255" x2="-5.461" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-5.461" y1="8.255" x2="-5.969" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-5.969" y1="10.414" x2="-5.969" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-5.969" y1="10.414" x2="-6.731" y2="10.414" width="0.1524" layer="51"/>
<wire x1="-6.731" y1="8.255" x2="-6.731" y2="10.414" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-8.255" x2="2.159" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-10.414" x2="2.159" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-10.414" x2="2.921" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-8.255" x2="2.921" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-8.255" x2="3.429" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-10.414" x2="3.429" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-10.414" x2="4.191" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="4.191" y1="-8.255" x2="4.191" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="4.191" y1="-8.255" x2="4.699" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="4.699" y1="-10.414" x2="4.699" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-10.414" x2="5.461" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="5.461" y1="-8.255" x2="5.461" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="5.461" y1="-8.255" x2="5.969" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="5.969" y1="-10.414" x2="5.969" y2="-8.255" width="0.1524" layer="51"/>
<wire x1="5.969" y1="-10.414" x2="6.731" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="6.731" y1="-8.255" x2="6.731" y2="-10.414" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="6.731" x2="-8.255" y2="6.731" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="6.731" x2="-10.414" y2="5.969" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="5.969" x2="-10.414" y2="5.969" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="5.969" x2="-8.255" y2="5.461" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="5.461" x2="-8.255" y2="5.461" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="5.461" x2="-10.414" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="4.699" x2="-10.414" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="4.699" x2="-8.255" y2="4.191" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="4.191" x2="-8.255" y2="4.191" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="4.191" x2="-10.414" y2="3.429" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="3.429" x2="-10.414" y2="3.429" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="3.429" x2="-8.255" y2="2.921" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="2.921" x2="-8.255" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="2.921" x2="-10.414" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="2.159" x2="-10.414" y2="2.159" width="0.1524" layer="21"/>
<wire x1="10.414" y1="-6.731" x2="8.255" y2="-6.731" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-6.731" x2="10.414" y2="-5.969" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-5.969" x2="10.414" y2="-5.969" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-5.969" x2="8.255" y2="-5.461" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-5.461" x2="8.255" y2="-5.461" width="0.1524" layer="21"/>
<wire x1="10.414" y1="-5.461" x2="10.414" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-4.699" x2="10.414" y2="-4.699" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-4.699" x2="8.255" y2="-4.191" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-4.191" x2="8.255" y2="-4.191" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-4.191" x2="10.414" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-3.429" x2="10.414" y2="-3.429" width="0.1524" layer="51"/>
<wire x1="8.255" y1="-3.429" x2="8.255" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-2.921" x2="8.255" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="10.414" y1="-2.921" x2="10.414" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.159" x2="10.414" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-8.255" x2="8.255" y2="-8.255" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-8.255" x2="8.255" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-1.651" x2="8.255" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="-6.985" y1="8.255" x2="-6.731" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="6.731" x2="-8.255" y2="6.985" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="2.159" x2="-8.255" y2="1.651" width="0.1524" layer="51"/>
<circle x="-2.54" y="2.54" radius="1.27" width="0.1524" layer="21"/>
<circle x="2.54" y="2.54" radius="1.27" width="0.1524" layer="21"/>
<circle x="-2.54" y="-2.54" radius="1.27" width="0.1524" layer="21"/>
<circle x="2.54" y="-2.54" radius="1.27" width="0.1524" layer="21"/>
<pad name="1" x="1.27" y="6.35" drill="0.8128"/>
<pad name="2" x="-1.27" y="8.89" drill="0.8128" shape="octagon"/>
<pad name="3" x="-1.27" y="6.35" drill="0.8128" shape="octagon"/>
<pad name="4" x="-3.81" y="8.89" drill="0.8128" shape="octagon"/>
<pad name="5" x="-3.81" y="6.35" drill="0.8128" shape="octagon"/>
<pad name="6" x="-6.35" y="8.89" drill="0.8128" shape="octagon"/>
<pad name="7" x="-8.89" y="6.35" drill="0.8128" shape="octagon"/>
<pad name="8" x="-6.35" y="6.35" drill="0.8128" shape="octagon"/>
<pad name="9" x="-8.89" y="3.81" drill="0.8128" shape="octagon"/>
<pad name="10" x="-6.35" y="3.81" drill="0.8128" shape="octagon"/>
<pad name="11" x="-8.89" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="12" x="-6.35" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="13" x="-8.89" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="14" x="-6.35" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="15" x="-8.89" y="-3.81" drill="0.8128" shape="octagon"/>
<pad name="16" x="-6.35" y="-3.81" drill="0.8128" shape="octagon"/>
<pad name="17" x="-8.89" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="18" x="-6.35" y="-8.89" drill="0.8128" shape="octagon"/>
<pad name="19" x="-6.35" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="20" x="-3.81" y="-8.89" drill="0.8128" shape="octagon"/>
<pad name="21" x="-3.81" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="22" x="-1.27" y="-8.89" drill="0.8128" shape="octagon"/>
<pad name="23" x="-1.27" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="24" x="1.27" y="-8.89" drill="0.8128" shape="octagon"/>
<pad name="25" x="1.27" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="26" x="3.81" y="-8.89" drill="0.8128" shape="octagon"/>
<pad name="27" x="3.81" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="28" x="6.35" y="-8.89" drill="0.8128" shape="octagon"/>
<pad name="29" x="8.89" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="30" x="6.35" y="-6.35" drill="0.8128" shape="octagon"/>
<pad name="31" x="8.89" y="-3.81" drill="0.8128" shape="octagon"/>
<pad name="32" x="6.35" y="-3.81" drill="0.8128" shape="octagon"/>
<pad name="33" x="8.89" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="34" x="6.35" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="35" x="8.89" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="36" x="6.35" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="37" x="8.89" y="3.81" drill="0.8128" shape="octagon"/>
<pad name="38" x="6.35" y="3.81" drill="0.8128" shape="octagon"/>
<pad name="39" x="8.89" y="6.35" drill="0.8128" shape="octagon"/>
<pad name="40" x="6.35" y="8.89" drill="0.8128" shape="octagon"/>
<pad name="41" x="6.35" y="6.35" drill="0.8128" shape="octagon"/>
<pad name="42" x="3.81" y="8.89" drill="0.8128" shape="octagon"/>
<pad name="43" x="3.81" y="6.35" drill="0.8128" shape="octagon"/>
<pad name="44" x="1.27" y="8.89" drill="0.8128" shape="octagon"/>
<text x="0" y="11.938" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-10.16" y="11.938" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="PLCC-S52-SOCKET">
<wire x1="12.7" y1="12.7" x2="-11.43" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="12.7" x2="-12.7" y2="11.43" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="11.43" x2="-12.7" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="12.7" y1="-12.7" x2="-12.7" y2="-12.7" width="0.1524" layer="21"/>
<wire x1="12.7" y1="-12.7" x2="12.7" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="8.255" x2="-8.255" y2="9.525" width="0.1524" layer="21"/>
<wire x1="-10.668" y1="-11.684" x2="-8.509" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="-10.668" y1="-11.684" x2="-11.684" y2="-10.668" width="0.1524" layer="21"/>
<wire x1="-11.684" y1="-10.668" x2="-9.525" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-9.525" x2="-8.001" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="-8.001" y1="-11.684" x2="-8.001" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="-8.001" y1="-11.684" x2="-7.239" y2="-11.684" width="0.1524" layer="51"/>
<wire x1="-7.239" y1="-9.525" x2="-7.239" y2="-11.684" width="0.1524" layer="51"/>
<wire x1="-5.461" y1="-11.684" x2="-5.461" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="-5.461" y1="-11.684" x2="-4.699" y2="-11.684" width="0.1524" layer="51"/>
<wire x1="-4.699" y1="-9.525" x2="-4.699" y2="-11.684" width="0.1524" layer="51"/>
<wire x1="-4.699" y1="-9.525" x2="-4.191" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="-11.684" x2="-4.191" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-11.684" x2="-3.429" y2="-11.684" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-9.525" x2="-3.429" y2="-11.684" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-9.525" x2="-2.921" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="-11.684" x2="-2.921" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="-11.684" x2="-2.159" y2="-11.684" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="-9.525" x2="-2.159" y2="-11.684" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="-9.525" x2="-1.651" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-11.684" x2="-1.651" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="-11.684" x2="-0.889" y2="-11.684" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-9.525" x2="-0.889" y2="-11.684" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-9.525" x2="-0.381" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="-11.684" x2="-0.381" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="-11.684" x2="0.381" y2="-11.684" width="0.1524" layer="51"/>
<wire x1="0.381" y1="-9.525" x2="0.381" y2="-11.684" width="0.1524" layer="51"/>
<wire x1="0.381" y1="-9.525" x2="0.889" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="0.889" y1="-11.684" x2="0.889" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-11.684" x2="1.651" y2="-11.684" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-9.525" x2="1.651" y2="-11.684" width="0.1524" layer="21"/>
<wire x1="11.684" y1="10.668" x2="9.525" y2="8.509" width="0.1524" layer="21"/>
<wire x1="11.684" y1="10.668" x2="10.668" y2="11.684" width="0.1524" layer="21"/>
<wire x1="10.668" y1="11.684" x2="8.509" y2="9.525" width="0.1524" layer="21"/>
<wire x1="9.525" y1="8.509" x2="9.525" y2="8.001" width="0.1524" layer="51"/>
<wire x1="11.684" y1="8.001" x2="9.525" y2="8.001" width="0.1524" layer="51"/>
<wire x1="11.684" y1="8.001" x2="11.684" y2="7.239" width="0.1524" layer="51"/>
<wire x1="9.525" y1="7.239" x2="11.684" y2="7.239" width="0.1524" layer="51"/>
<wire x1="11.684" y1="5.461" x2="9.525" y2="5.461" width="0.1524" layer="51"/>
<wire x1="11.684" y1="5.461" x2="11.684" y2="4.699" width="0.1524" layer="51"/>
<wire x1="9.525" y1="4.699" x2="11.684" y2="4.699" width="0.1524" layer="51"/>
<wire x1="9.525" y1="4.699" x2="9.525" y2="4.191" width="0.1524" layer="51"/>
<wire x1="11.684" y1="4.191" x2="9.525" y2="4.191" width="0.1524" layer="21"/>
<wire x1="11.684" y1="4.191" x2="11.684" y2="3.429" width="0.1524" layer="21"/>
<wire x1="9.525" y1="3.429" x2="11.684" y2="3.429" width="0.1524" layer="21"/>
<wire x1="9.525" y1="3.429" x2="9.525" y2="2.921" width="0.1524" layer="51"/>
<wire x1="11.684" y1="2.921" x2="9.525" y2="2.921" width="0.1524" layer="51"/>
<wire x1="11.684" y1="2.921" x2="11.684" y2="2.159" width="0.1524" layer="51"/>
<wire x1="9.525" y1="2.159" x2="11.684" y2="2.159" width="0.1524" layer="51"/>
<wire x1="9.525" y1="2.159" x2="9.525" y2="1.651" width="0.1524" layer="51"/>
<wire x1="11.684" y1="1.651" x2="9.525" y2="1.651" width="0.1524" layer="21"/>
<wire x1="11.684" y1="1.651" x2="11.684" y2="0.889" width="0.1524" layer="21"/>
<wire x1="9.525" y1="0.889" x2="11.684" y2="0.889" width="0.1524" layer="21"/>
<wire x1="9.525" y1="0.889" x2="9.525" y2="0.381" width="0.1524" layer="51"/>
<wire x1="11.684" y1="0.381" x2="9.525" y2="0.381" width="0.1524" layer="51"/>
<wire x1="11.684" y1="0.381" x2="11.684" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="9.525" y1="-0.381" x2="11.684" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="9.525" y1="-0.381" x2="9.525" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="11.684" y1="-0.889" x2="9.525" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="11.684" y1="-0.889" x2="11.684" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-1.651" x2="11.684" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-8.509" x2="-9.525" y2="-8.001" width="0.1524" layer="51"/>
<wire x1="-11.684" y1="-8.001" x2="-9.525" y2="-8.001" width="0.1524" layer="51"/>
<wire x1="-11.684" y1="-8.001" x2="-11.684" y2="-7.239" width="0.1524" layer="51"/>
<wire x1="-9.525" y1="-7.239" x2="-11.684" y2="-7.239" width="0.1524" layer="51"/>
<wire x1="-11.684" y1="-5.461" x2="-9.525" y2="-5.461" width="0.1524" layer="51"/>
<wire x1="-11.684" y1="-5.461" x2="-11.684" y2="-4.699" width="0.1524" layer="51"/>
<wire x1="-9.525" y1="-4.699" x2="-11.684" y2="-4.699" width="0.1524" layer="51"/>
<wire x1="-9.525" y1="-4.699" x2="-9.525" y2="-4.191" width="0.1524" layer="51"/>
<wire x1="-11.684" y1="-4.191" x2="-9.525" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-11.684" y1="-4.191" x2="-11.684" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-3.429" x2="-11.684" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-3.429" x2="-9.525" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="-11.684" y1="-2.921" x2="-9.525" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="-11.684" y1="-2.921" x2="-11.684" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="-9.525" y1="-2.159" x2="-11.684" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="-9.525" y1="-2.159" x2="-9.525" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="-11.684" y1="-1.651" x2="-9.525" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-11.684" y1="-1.651" x2="-11.684" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-0.889" x2="-11.684" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-0.889" x2="-9.525" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-11.684" y1="-0.381" x2="-9.525" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-11.684" y1="-0.381" x2="-11.684" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-9.525" y1="0.381" x2="-11.684" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-9.525" y1="0.381" x2="-9.525" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-11.684" y1="0.889" x2="-9.525" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-11.684" y1="0.889" x2="-11.684" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="1.651" x2="-11.684" y2="1.651" width="0.1524" layer="21"/>
<wire x1="8.509" y1="9.525" x2="8.001" y2="9.525" width="0.1524" layer="51"/>
<wire x1="8.001" y1="11.684" x2="8.001" y2="9.525" width="0.1524" layer="51"/>
<wire x1="8.001" y1="11.684" x2="7.239" y2="11.684" width="0.1524" layer="51"/>
<wire x1="7.239" y1="9.525" x2="7.239" y2="11.684" width="0.1524" layer="51"/>
<wire x1="5.461" y1="11.684" x2="5.461" y2="9.525" width="0.1524" layer="51"/>
<wire x1="5.461" y1="11.684" x2="4.699" y2="11.684" width="0.1524" layer="51"/>
<wire x1="4.699" y1="9.525" x2="4.699" y2="11.684" width="0.1524" layer="51"/>
<wire x1="4.699" y1="9.525" x2="4.191" y2="9.525" width="0.1524" layer="51"/>
<wire x1="4.191" y1="11.684" x2="4.191" y2="9.525" width="0.1524" layer="21"/>
<wire x1="4.191" y1="11.684" x2="3.429" y2="11.684" width="0.1524" layer="21"/>
<wire x1="3.429" y1="9.525" x2="3.429" y2="11.684" width="0.1524" layer="21"/>
<wire x1="3.429" y1="9.525" x2="2.921" y2="9.525" width="0.1524" layer="51"/>
<wire x1="2.921" y1="11.684" x2="2.921" y2="9.525" width="0.1524" layer="51"/>
<wire x1="2.921" y1="11.684" x2="2.159" y2="11.684" width="0.1524" layer="51"/>
<wire x1="2.159" y1="9.525" x2="2.159" y2="11.684" width="0.1524" layer="51"/>
<wire x1="2.159" y1="9.525" x2="1.651" y2="9.525" width="0.1524" layer="51"/>
<wire x1="1.651" y1="11.684" x2="1.651" y2="9.525" width="0.1524" layer="21"/>
<wire x1="1.651" y1="11.684" x2="0.889" y2="11.684" width="0.1524" layer="21"/>
<wire x1="0.889" y1="9.525" x2="0.889" y2="11.684" width="0.1524" layer="21"/>
<wire x1="0.889" y1="9.525" x2="0.381" y2="9.525" width="0.1524" layer="51"/>
<wire x1="0.381" y1="11.684" x2="0.381" y2="9.525" width="0.1524" layer="51"/>
<wire x1="0.381" y1="11.684" x2="-0.381" y2="11.684" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="9.525" x2="-0.381" y2="11.684" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="9.525" x2="-0.889" y2="9.525" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="11.684" x2="-0.889" y2="9.525" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="11.684" x2="-1.651" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="9.525" x2="-1.651" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="4.445" x2="0" y2="5.08" width="0.508" layer="21"/>
<wire x1="-1.651" y1="9.525" x2="-2.159" y2="9.525" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="11.684" x2="-2.159" y2="9.525" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="11.684" x2="-2.921" y2="11.684" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="9.525" x2="-2.921" y2="11.684" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="9.525" x2="-3.429" y2="9.525" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="11.684" x2="-3.429" y2="9.525" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="11.684" x2="-4.191" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="9.525" x2="-4.191" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="9.525" x2="-4.699" y2="9.525" width="0.1524" layer="51"/>
<wire x1="-4.699" y1="11.684" x2="-4.699" y2="9.525" width="0.1524" layer="51"/>
<wire x1="-4.699" y1="11.684" x2="-5.461" y2="11.684" width="0.1524" layer="51"/>
<wire x1="-5.461" y1="9.525" x2="-5.461" y2="11.684" width="0.1524" layer="51"/>
<wire x1="-7.239" y1="11.684" x2="-7.239" y2="9.525" width="0.1524" layer="51"/>
<wire x1="-7.239" y1="11.684" x2="-8.001" y2="11.684" width="0.1524" layer="51"/>
<wire x1="-8.001" y1="9.525" x2="-8.001" y2="11.684" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-9.525" x2="2.159" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-11.684" x2="2.159" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-11.684" x2="2.921" y2="-11.684" width="0.1524" layer="51"/>
<wire x1="2.921" y1="-9.525" x2="2.921" y2="-11.684" width="0.1524" layer="51"/>
<wire x1="2.921" y1="-9.525" x2="3.429" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-11.684" x2="3.429" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-11.684" x2="4.191" y2="-11.684" width="0.1524" layer="21"/>
<wire x1="4.191" y1="-9.525" x2="4.191" y2="-11.684" width="0.1524" layer="21"/>
<wire x1="4.191" y1="-9.525" x2="4.699" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="4.699" y1="-11.684" x2="4.699" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="4.699" y1="-11.684" x2="5.461" y2="-11.684" width="0.1524" layer="51"/>
<wire x1="5.461" y1="-9.525" x2="5.461" y2="-11.684" width="0.1524" layer="51"/>
<wire x1="7.239" y1="-11.684" x2="7.239" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="7.239" y1="-11.684" x2="8.001" y2="-11.684" width="0.1524" layer="51"/>
<wire x1="8.001" y1="-9.525" x2="8.001" y2="-11.684" width="0.1524" layer="51"/>
<wire x1="-11.684" y1="8.001" x2="-9.525" y2="8.001" width="0.1524" layer="51"/>
<wire x1="-11.684" y1="8.001" x2="-11.684" y2="7.239" width="0.1524" layer="51"/>
<wire x1="-9.525" y1="7.239" x2="-11.684" y2="7.239" width="0.1524" layer="51"/>
<wire x1="-11.684" y1="5.461" x2="-9.525" y2="5.461" width="0.1524" layer="51"/>
<wire x1="-11.684" y1="5.461" x2="-11.684" y2="4.699" width="0.1524" layer="51"/>
<wire x1="-9.525" y1="4.699" x2="-11.684" y2="4.699" width="0.1524" layer="51"/>
<wire x1="-9.525" y1="4.699" x2="-9.525" y2="4.191" width="0.1524" layer="51"/>
<wire x1="-11.684" y1="4.191" x2="-9.525" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-11.684" y1="4.191" x2="-11.684" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="3.429" x2="-11.684" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="3.429" x2="-9.525" y2="2.921" width="0.1524" layer="51"/>
<wire x1="-11.684" y1="2.921" x2="-9.525" y2="2.921" width="0.1524" layer="51"/>
<wire x1="-11.684" y1="2.921" x2="-11.684" y2="2.159" width="0.1524" layer="51"/>
<wire x1="-9.525" y1="2.159" x2="-11.684" y2="2.159" width="0.1524" layer="51"/>
<wire x1="11.684" y1="-8.001" x2="9.525" y2="-8.001" width="0.1524" layer="51"/>
<wire x1="11.684" y1="-8.001" x2="11.684" y2="-7.239" width="0.1524" layer="51"/>
<wire x1="9.525" y1="-7.239" x2="11.684" y2="-7.239" width="0.1524" layer="51"/>
<wire x1="11.684" y1="-5.461" x2="9.525" y2="-5.461" width="0.1524" layer="51"/>
<wire x1="11.684" y1="-5.461" x2="11.684" y2="-4.699" width="0.1524" layer="51"/>
<wire x1="9.525" y1="-4.699" x2="11.684" y2="-4.699" width="0.1524" layer="51"/>
<wire x1="9.525" y1="-4.699" x2="9.525" y2="-4.191" width="0.1524" layer="51"/>
<wire x1="11.684" y1="-4.191" x2="9.525" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="11.684" y1="-4.191" x2="11.684" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-3.429" x2="11.684" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-3.429" x2="9.525" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="11.684" y1="-2.921" x2="9.525" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="11.684" y1="-2.921" x2="11.684" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="9.525" y1="-2.159" x2="11.684" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="8.001" y1="-9.525" x2="9.525" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-9.525" x2="9.525" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-1.651" x2="9.525" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="9.525" x2="-8.001" y2="9.525" width="0.1524" layer="51"/>
<wire x1="-9.525" y1="8.001" x2="-9.525" y2="8.255" width="0.1524" layer="51"/>
<wire x1="-9.525" y1="2.159" x2="-9.525" y2="1.651" width="0.1524" layer="51"/>
<wire x1="9.525" y1="-7.239" x2="9.525" y2="-6.731" width="0.1524" layer="51"/>
<wire x1="11.684" y1="-6.731" x2="9.525" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="11.684" y1="-6.731" x2="11.684" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-5.969" x2="11.684" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-5.969" x2="9.525" y2="-5.461" width="0.1524" layer="51"/>
<wire x1="9.525" y1="5.461" x2="9.525" y2="5.969" width="0.1524" layer="51"/>
<wire x1="11.684" y1="5.969" x2="9.525" y2="5.969" width="0.1524" layer="21"/>
<wire x1="11.684" y1="5.969" x2="11.684" y2="6.731" width="0.1524" layer="21"/>
<wire x1="9.525" y1="6.731" x2="11.684" y2="6.731" width="0.1524" layer="21"/>
<wire x1="9.525" y1="6.731" x2="9.525" y2="7.239" width="0.1524" layer="51"/>
<wire x1="7.239" y1="9.525" x2="6.731" y2="9.525" width="0.1524" layer="51"/>
<wire x1="6.731" y1="11.684" x2="6.731" y2="9.525" width="0.1524" layer="21"/>
<wire x1="6.731" y1="11.684" x2="5.969" y2="11.684" width="0.1524" layer="21"/>
<wire x1="5.969" y1="9.525" x2="5.969" y2="11.684" width="0.1524" layer="21"/>
<wire x1="5.969" y1="9.525" x2="5.461" y2="9.525" width="0.1524" layer="51"/>
<wire x1="-5.461" y1="9.525" x2="-5.969" y2="9.525" width="0.1524" layer="51"/>
<wire x1="-5.969" y1="11.684" x2="-5.969" y2="9.525" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="11.684" x2="-6.731" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="9.525" x2="-6.731" y2="11.684" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="9.525" x2="-7.239" y2="9.525" width="0.1524" layer="51"/>
<wire x1="-9.525" y1="7.239" x2="-9.525" y2="6.731" width="0.1524" layer="51"/>
<wire x1="-11.684" y1="6.731" x2="-9.525" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-11.684" y1="6.731" x2="-11.684" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="5.969" x2="-11.684" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="5.969" x2="-9.525" y2="5.461" width="0.1524" layer="51"/>
<wire x1="5.461" y1="-9.525" x2="5.969" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="5.969" y1="-11.684" x2="5.969" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="5.969" y1="-11.684" x2="6.731" y2="-11.684" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-9.525" x2="6.731" y2="-11.684" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-9.525" x2="7.239" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="-7.239" y1="-9.525" x2="-6.731" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="-6.731" y1="-11.684" x2="-6.731" y2="-9.525" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-11.684" x2="-5.969" y2="-11.684" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-9.525" x2="-5.969" y2="-11.684" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-9.525" x2="-5.461" y2="-9.525" width="0.1524" layer="51"/>
<wire x1="-9.525" y1="-5.461" x2="-9.525" y2="-5.969" width="0.1524" layer="51"/>
<wire x1="-11.684" y1="-5.969" x2="-9.525" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-11.684" y1="-5.969" x2="-11.684" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-6.731" x2="-11.684" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-9.525" y1="-6.731" x2="-9.525" y2="-7.239" width="0.1524" layer="51"/>
<pad name="1" x="0" y="10.16" drill="0.8128"/>
<pad name="2" x="0" y="7.62" drill="0.8128" shape="octagon"/>
<pad name="3" x="-2.54" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="4" x="-2.54" y="7.62" drill="0.8128" shape="octagon"/>
<pad name="5" x="-5.08" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="6" x="-5.08" y="7.62" drill="0.8128" shape="octagon"/>
<pad name="7" x="-7.62" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="8" x="-10.16" y="7.62" drill="0.8128" shape="octagon"/>
<pad name="9" x="-7.62" y="7.62" drill="0.8128" shape="octagon"/>
<pad name="10" x="-10.16" y="5.08" drill="0.8128" shape="octagon"/>
<pad name="11" x="-7.62" y="5.08" drill="0.8128" shape="octagon"/>
<pad name="12" x="-10.16" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="13" x="-7.62" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="14" x="-10.16" y="0" drill="0.8128" shape="octagon"/>
<pad name="15" x="-7.62" y="0" drill="0.8128" shape="octagon"/>
<pad name="16" x="-10.16" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="17" x="-7.62" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="18" x="-10.16" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="19" x="-7.62" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="20" x="-10.16" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="21" x="-7.62" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="22" x="-7.62" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="23" x="-5.08" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="24" x="-5.08" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="25" x="-2.54" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="26" x="-2.54" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="27" x="0" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="28" x="0" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="29" x="2.54" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="30" x="2.54" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="31" x="5.08" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="32" x="5.08" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="33" x="7.62" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="34" x="10.16" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="35" x="7.62" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="36" x="10.16" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="37" x="7.62" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="38" x="10.16" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="39" x="7.62" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="40" x="10.16" y="0" drill="0.8128" shape="octagon"/>
<pad name="41" x="7.62" y="0" drill="0.8128" shape="octagon"/>
<pad name="42" x="10.16" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="43" x="7.62" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="45" x="7.62" y="5.08" drill="0.8128" shape="octagon"/>
<pad name="44" x="10.16" y="5.08" drill="0.8128" shape="octagon"/>
<pad name="46" x="10.16" y="7.62" drill="0.8128" shape="octagon"/>
<pad name="47" x="7.62" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="48" x="7.62" y="7.62" drill="0.8128" shape="octagon"/>
<pad name="49" x="5.08" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="50" x="5.08" y="7.62" drill="0.8128" shape="octagon"/>
<pad name="51" x="2.54" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="52" x="2.54" y="7.62" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="13.081" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-11.43" y="13.081" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="PLCC-S68-SOCKET">
<description>&lt;b&gt;Plastic Leaded Chip Carrier&lt;/b&gt; Socket</description>
<wire x1="15.24" y1="15.24" x2="-13.97" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="15.24" x2="-15.24" y2="13.97" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="13.97" x2="-15.24" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-15.24" x2="-15.24" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-15.24" x2="15.24" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="10.795" x2="-10.795" y2="12.065" width="0.1524" layer="21"/>
<wire x1="-13.208" y1="-14.224" x2="-11.049" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-13.208" y1="-14.224" x2="-14.224" y2="-13.208" width="0.1524" layer="21"/>
<wire x1="-14.224" y1="-13.208" x2="-12.065" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="-12.065" x2="-10.541" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="-10.541" y1="-14.224" x2="-10.541" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="-10.541" y1="-14.224" x2="-9.779" y2="-14.224" width="0.1524" layer="51"/>
<wire x1="-9.779" y1="-12.065" x2="-9.779" y2="-14.224" width="0.1524" layer="51"/>
<wire x1="-5.461" y1="-14.224" x2="-5.461" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="-5.461" y1="-14.224" x2="-4.699" y2="-14.224" width="0.1524" layer="51"/>
<wire x1="-4.699" y1="-12.065" x2="-4.699" y2="-14.224" width="0.1524" layer="51"/>
<wire x1="-4.699" y1="-12.065" x2="-4.191" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="-14.224" x2="-4.191" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-14.224" x2="-3.429" y2="-14.224" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-12.065" x2="-3.429" y2="-14.224" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-12.065" x2="-2.921" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="-14.224" x2="-2.921" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="-14.224" x2="-2.159" y2="-14.224" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="-12.065" x2="-2.159" y2="-14.224" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="-12.065" x2="-1.651" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-14.224" x2="-1.651" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="-14.224" x2="-0.889" y2="-14.224" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-12.065" x2="-0.889" y2="-14.224" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-12.065" x2="-0.381" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="-14.224" x2="-0.381" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="-14.224" x2="0.381" y2="-14.224" width="0.1524" layer="51"/>
<wire x1="0.381" y1="-12.065" x2="0.381" y2="-14.224" width="0.1524" layer="51"/>
<wire x1="0.381" y1="-12.065" x2="0.889" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="0.889" y1="-14.224" x2="0.889" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-14.224" x2="1.651" y2="-14.224" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-12.065" x2="1.651" y2="-14.224" width="0.1524" layer="21"/>
<wire x1="14.224" y1="13.208" x2="12.065" y2="11.049" width="0.1524" layer="21"/>
<wire x1="14.224" y1="13.208" x2="13.208" y2="14.224" width="0.1524" layer="21"/>
<wire x1="13.208" y1="14.224" x2="11.049" y2="12.065" width="0.1524" layer="21"/>
<wire x1="12.065" y1="11.049" x2="12.065" y2="10.541" width="0.1524" layer="51"/>
<wire x1="14.224" y1="10.541" x2="12.065" y2="10.541" width="0.1524" layer="51"/>
<wire x1="14.224" y1="10.541" x2="14.224" y2="9.779" width="0.1524" layer="51"/>
<wire x1="12.065" y1="9.779" x2="14.224" y2="9.779" width="0.1524" layer="51"/>
<wire x1="14.224" y1="5.461" x2="12.065" y2="5.461" width="0.1524" layer="51"/>
<wire x1="14.224" y1="5.461" x2="14.224" y2="4.699" width="0.1524" layer="51"/>
<wire x1="12.065" y1="4.699" x2="14.224" y2="4.699" width="0.1524" layer="51"/>
<wire x1="12.065" y1="4.699" x2="12.065" y2="4.191" width="0.1524" layer="51"/>
<wire x1="14.224" y1="4.191" x2="12.065" y2="4.191" width="0.1524" layer="21"/>
<wire x1="14.224" y1="4.191" x2="14.224" y2="3.429" width="0.1524" layer="21"/>
<wire x1="12.065" y1="3.429" x2="14.224" y2="3.429" width="0.1524" layer="21"/>
<wire x1="12.065" y1="3.429" x2="12.065" y2="2.921" width="0.1524" layer="51"/>
<wire x1="14.224" y1="2.921" x2="12.065" y2="2.921" width="0.1524" layer="51"/>
<wire x1="14.224" y1="2.921" x2="14.224" y2="2.159" width="0.1524" layer="51"/>
<wire x1="12.065" y1="2.159" x2="14.224" y2="2.159" width="0.1524" layer="51"/>
<wire x1="12.065" y1="2.159" x2="12.065" y2="1.651" width="0.1524" layer="51"/>
<wire x1="14.224" y1="1.651" x2="12.065" y2="1.651" width="0.1524" layer="21"/>
<wire x1="14.224" y1="1.651" x2="14.224" y2="0.889" width="0.1524" layer="21"/>
<wire x1="12.065" y1="0.889" x2="14.224" y2="0.889" width="0.1524" layer="21"/>
<wire x1="12.065" y1="0.889" x2="12.065" y2="0.381" width="0.1524" layer="51"/>
<wire x1="14.224" y1="0.381" x2="12.065" y2="0.381" width="0.1524" layer="51"/>
<wire x1="14.224" y1="0.381" x2="14.224" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="12.065" y1="-0.381" x2="14.224" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="12.065" y1="-0.381" x2="12.065" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="14.224" y1="-0.889" x2="12.065" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="14.224" y1="-0.889" x2="14.224" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="12.065" y1="-1.651" x2="14.224" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-11.049" x2="-12.065" y2="-10.541" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="-10.541" x2="-12.065" y2="-10.541" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="-10.541" x2="-14.224" y2="-9.779" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="-5.461" x2="-12.065" y2="-5.461" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="-5.461" x2="-14.224" y2="-4.699" width="0.1524" layer="51"/>
<wire x1="-12.065" y1="-4.699" x2="-14.224" y2="-4.699" width="0.1524" layer="51"/>
<wire x1="-12.065" y1="-4.699" x2="-12.065" y2="-4.191" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="-4.191" x2="-12.065" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-14.224" y1="-4.191" x2="-14.224" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-3.429" x2="-14.224" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-3.429" x2="-12.065" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="-2.921" x2="-12.065" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="-2.921" x2="-14.224" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="-12.065" y1="-2.159" x2="-14.224" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="-12.065" y1="-2.159" x2="-12.065" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="-1.651" x2="-12.065" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-14.224" y1="-1.651" x2="-14.224" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-0.889" x2="-14.224" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-0.889" x2="-12.065" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="-0.381" x2="-12.065" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="-0.381" x2="-14.224" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-12.065" y1="0.381" x2="-14.224" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-12.065" y1="0.381" x2="-12.065" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="0.889" x2="-12.065" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-14.224" y1="0.889" x2="-14.224" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="1.651" x2="-14.224" y2="1.651" width="0.1524" layer="21"/>
<wire x1="11.049" y1="12.065" x2="10.541" y2="12.065" width="0.1524" layer="51"/>
<wire x1="10.541" y1="14.224" x2="10.541" y2="12.065" width="0.1524" layer="51"/>
<wire x1="10.541" y1="14.224" x2="9.779" y2="14.224" width="0.1524" layer="51"/>
<wire x1="9.779" y1="12.065" x2="9.779" y2="14.224" width="0.1524" layer="51"/>
<wire x1="5.461" y1="14.224" x2="5.461" y2="12.065" width="0.1524" layer="51"/>
<wire x1="5.461" y1="14.224" x2="4.699" y2="14.224" width="0.1524" layer="51"/>
<wire x1="4.699" y1="12.065" x2="4.699" y2="14.224" width="0.1524" layer="51"/>
<wire x1="4.699" y1="12.065" x2="4.191" y2="12.065" width="0.1524" layer="51"/>
<wire x1="4.191" y1="14.224" x2="4.191" y2="12.065" width="0.1524" layer="21"/>
<wire x1="4.191" y1="14.224" x2="3.429" y2="14.224" width="0.1524" layer="21"/>
<wire x1="3.429" y1="12.065" x2="3.429" y2="14.224" width="0.1524" layer="21"/>
<wire x1="3.429" y1="12.065" x2="2.921" y2="12.065" width="0.1524" layer="51"/>
<wire x1="2.921" y1="14.224" x2="2.921" y2="12.065" width="0.1524" layer="51"/>
<wire x1="2.921" y1="14.224" x2="2.159" y2="14.224" width="0.1524" layer="51"/>
<wire x1="2.159" y1="12.065" x2="2.159" y2="14.224" width="0.1524" layer="51"/>
<wire x1="2.159" y1="12.065" x2="1.651" y2="12.065" width="0.1524" layer="51"/>
<wire x1="1.651" y1="14.224" x2="1.651" y2="12.065" width="0.1524" layer="21"/>
<wire x1="1.651" y1="14.224" x2="0.889" y2="14.224" width="0.1524" layer="21"/>
<wire x1="0.889" y1="12.065" x2="0.889" y2="14.224" width="0.1524" layer="21"/>
<wire x1="0.889" y1="12.065" x2="0.381" y2="12.065" width="0.1524" layer="51"/>
<wire x1="0.381" y1="14.224" x2="0.381" y2="12.065" width="0.1524" layer="51"/>
<wire x1="0.381" y1="14.224" x2="-0.381" y2="14.224" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="12.065" x2="-0.381" y2="14.224" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="12.065" x2="-0.889" y2="12.065" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="14.224" x2="-0.889" y2="12.065" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="14.224" x2="-1.651" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="12.065" x2="-1.651" y2="14.224" width="0.1524" layer="21"/>
<wire x1="0" y1="6.35" x2="0" y2="4.445" width="0.508" layer="21"/>
<wire x1="0" y1="6.35" x2="0.635" y2="5.715" width="0.508" layer="21"/>
<wire x1="0.635" y1="5.715" x2="-0.635" y2="5.715" width="0.508" layer="21"/>
<wire x1="-0.635" y1="5.715" x2="0" y2="6.35" width="0.508" layer="21"/>
<wire x1="-1.651" y1="12.065" x2="-2.159" y2="12.065" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="14.224" x2="-2.159" y2="12.065" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="14.224" x2="-2.921" y2="14.224" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="12.065" x2="-2.921" y2="14.224" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="12.065" x2="-3.429" y2="12.065" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="14.224" x2="-3.429" y2="12.065" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="14.224" x2="-4.191" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="12.065" x2="-4.191" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="12.065" x2="-4.699" y2="12.065" width="0.1524" layer="51"/>
<wire x1="-4.699" y1="14.224" x2="-4.699" y2="12.065" width="0.1524" layer="51"/>
<wire x1="-4.699" y1="14.224" x2="-5.461" y2="14.224" width="0.1524" layer="51"/>
<wire x1="-5.461" y1="12.065" x2="-5.461" y2="14.224" width="0.1524" layer="51"/>
<wire x1="-9.779" y1="14.224" x2="-9.779" y2="12.065" width="0.1524" layer="51"/>
<wire x1="-9.779" y1="14.224" x2="-10.541" y2="14.224" width="0.1524" layer="51"/>
<wire x1="-10.541" y1="12.065" x2="-10.541" y2="14.224" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-12.065" x2="2.159" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-14.224" x2="2.159" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-14.224" x2="2.921" y2="-14.224" width="0.1524" layer="51"/>
<wire x1="2.921" y1="-12.065" x2="2.921" y2="-14.224" width="0.1524" layer="51"/>
<wire x1="2.921" y1="-12.065" x2="3.429" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-14.224" x2="3.429" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-14.224" x2="4.191" y2="-14.224" width="0.1524" layer="21"/>
<wire x1="4.191" y1="-12.065" x2="4.191" y2="-14.224" width="0.1524" layer="21"/>
<wire x1="4.191" y1="-12.065" x2="4.699" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="4.699" y1="-14.224" x2="4.699" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="4.699" y1="-14.224" x2="5.461" y2="-14.224" width="0.1524" layer="51"/>
<wire x1="5.461" y1="-12.065" x2="5.461" y2="-14.224" width="0.1524" layer="51"/>
<wire x1="9.779" y1="-14.224" x2="9.779" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="9.779" y1="-14.224" x2="10.541" y2="-14.224" width="0.1524" layer="51"/>
<wire x1="10.541" y1="-12.065" x2="10.541" y2="-14.224" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="10.541" x2="-12.065" y2="10.541" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="10.541" x2="-14.224" y2="9.779" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="5.461" x2="-12.065" y2="5.461" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="5.461" x2="-14.224" y2="4.699" width="0.1524" layer="51"/>
<wire x1="-12.065" y1="4.699" x2="-14.224" y2="4.699" width="0.1524" layer="51"/>
<wire x1="-12.065" y1="4.699" x2="-12.065" y2="4.191" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="4.191" x2="-12.065" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-14.224" y1="4.191" x2="-14.224" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="3.429" x2="-14.224" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="3.429" x2="-12.065" y2="2.921" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="2.921" x2="-12.065" y2="2.921" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="2.921" x2="-14.224" y2="2.159" width="0.1524" layer="51"/>
<wire x1="-12.065" y1="2.159" x2="-14.224" y2="2.159" width="0.1524" layer="51"/>
<wire x1="14.224" y1="-10.541" x2="12.065" y2="-10.541" width="0.1524" layer="51"/>
<wire x1="14.224" y1="-10.541" x2="14.224" y2="-9.779" width="0.1524" layer="51"/>
<wire x1="14.224" y1="-5.461" x2="12.065" y2="-5.461" width="0.1524" layer="51"/>
<wire x1="14.224" y1="-5.461" x2="14.224" y2="-4.699" width="0.1524" layer="51"/>
<wire x1="12.065" y1="-4.699" x2="14.224" y2="-4.699" width="0.1524" layer="51"/>
<wire x1="12.065" y1="-4.699" x2="12.065" y2="-4.191" width="0.1524" layer="51"/>
<wire x1="14.224" y1="-4.191" x2="12.065" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="14.224" y1="-4.191" x2="14.224" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="12.065" y1="-3.429" x2="14.224" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="12.065" y1="-3.429" x2="12.065" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="14.224" y1="-2.921" x2="12.065" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="14.224" y1="-2.921" x2="14.224" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="12.065" y1="-2.159" x2="14.224" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="10.541" y1="-12.065" x2="12.065" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="12.065" y1="-12.065" x2="12.065" y2="-10.541" width="0.1524" layer="21"/>
<wire x1="12.065" y1="-1.651" x2="12.065" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="-10.795" y1="12.065" x2="-10.541" y2="12.065" width="0.1524" layer="51"/>
<wire x1="-12.065" y1="10.541" x2="-12.065" y2="10.795" width="0.1524" layer="51"/>
<wire x1="-12.065" y1="2.159" x2="-12.065" y2="1.651" width="0.1524" layer="51"/>
<wire x1="14.224" y1="-6.731" x2="12.065" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="14.224" y1="-6.731" x2="14.224" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="12.065" y1="-5.969" x2="14.224" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="12.065" y1="-5.969" x2="12.065" y2="-5.461" width="0.1524" layer="51"/>
<wire x1="12.065" y1="5.461" x2="12.065" y2="5.969" width="0.1524" layer="51"/>
<wire x1="14.224" y1="5.969" x2="12.065" y2="5.969" width="0.1524" layer="21"/>
<wire x1="14.224" y1="5.969" x2="14.224" y2="6.731" width="0.1524" layer="21"/>
<wire x1="12.065" y1="6.731" x2="14.224" y2="6.731" width="0.1524" layer="21"/>
<wire x1="6.731" y1="14.224" x2="6.731" y2="12.065" width="0.1524" layer="21"/>
<wire x1="6.731" y1="14.224" x2="5.969" y2="14.224" width="0.1524" layer="21"/>
<wire x1="5.969" y1="12.065" x2="5.969" y2="14.224" width="0.1524" layer="21"/>
<wire x1="5.969" y1="12.065" x2="5.461" y2="12.065" width="0.1524" layer="51"/>
<wire x1="-5.461" y1="12.065" x2="-5.969" y2="12.065" width="0.1524" layer="51"/>
<wire x1="-5.969" y1="14.224" x2="-5.969" y2="12.065" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="14.224" x2="-6.731" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="12.065" x2="-6.731" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-14.224" y1="6.731" x2="-12.065" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-14.224" y1="6.731" x2="-14.224" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="5.969" x2="-14.224" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="5.969" x2="-12.065" y2="5.461" width="0.1524" layer="51"/>
<wire x1="5.461" y1="-12.065" x2="5.969" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="5.969" y1="-14.224" x2="5.969" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="5.969" y1="-14.224" x2="6.731" y2="-14.224" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-12.065" x2="6.731" y2="-14.224" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-14.224" x2="-6.731" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-14.224" x2="-5.969" y2="-14.224" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-12.065" x2="-5.969" y2="-14.224" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-12.065" x2="-5.461" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="-12.065" y1="-5.461" x2="-12.065" y2="-5.969" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="-5.969" x2="-12.065" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-14.224" y1="-5.969" x2="-14.224" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-6.731" x2="-14.224" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="14.224" y1="7.239" x2="12.065" y2="7.239" width="0.1524" layer="51"/>
<wire x1="14.224" y1="7.239" x2="14.224" y2="8.001" width="0.1524" layer="51"/>
<wire x1="12.065" y1="8.001" x2="14.224" y2="8.001" width="0.1524" layer="51"/>
<wire x1="12.065" y1="8.001" x2="12.065" y2="8.509" width="0.1524" layer="51"/>
<wire x1="14.224" y1="8.509" x2="12.065" y2="8.509" width="0.1524" layer="21"/>
<wire x1="14.224" y1="8.509" x2="14.224" y2="9.271" width="0.1524" layer="21"/>
<wire x1="12.065" y1="9.271" x2="14.224" y2="9.271" width="0.1524" layer="21"/>
<wire x1="12.065" y1="9.779" x2="12.065" y2="9.271" width="0.1524" layer="51"/>
<wire x1="12.065" y1="6.731" x2="12.065" y2="7.239" width="0.1524" layer="51"/>
<wire x1="6.731" y1="12.065" x2="7.239" y2="12.065" width="0.1524" layer="51"/>
<wire x1="7.239" y1="14.224" x2="7.239" y2="12.065" width="0.1524" layer="51"/>
<wire x1="7.239" y1="14.224" x2="8.001" y2="14.224" width="0.1524" layer="51"/>
<wire x1="8.001" y1="12.065" x2="8.001" y2="14.224" width="0.1524" layer="51"/>
<wire x1="9.271" y1="14.224" x2="9.271" y2="12.065" width="0.1524" layer="21"/>
<wire x1="9.271" y1="14.224" x2="8.509" y2="14.224" width="0.1524" layer="21"/>
<wire x1="8.509" y1="12.065" x2="8.509" y2="14.224" width="0.1524" layer="21"/>
<wire x1="8.001" y1="12.065" x2="8.509" y2="12.065" width="0.1524" layer="51"/>
<wire x1="9.779" y1="12.065" x2="9.271" y2="12.065" width="0.1524" layer="51"/>
<wire x1="-7.239" y1="14.224" x2="-7.239" y2="12.065" width="0.1524" layer="51"/>
<wire x1="-7.239" y1="14.224" x2="-8.001" y2="14.224" width="0.1524" layer="51"/>
<wire x1="-8.001" y1="12.065" x2="-8.001" y2="14.224" width="0.1524" layer="51"/>
<wire x1="-8.001" y1="12.065" x2="-8.509" y2="12.065" width="0.1524" layer="51"/>
<wire x1="-8.509" y1="14.224" x2="-8.509" y2="12.065" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="14.224" x2="-9.271" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-9.271" y1="12.065" x2="-9.271" y2="14.224" width="0.1524" layer="21"/>
<wire x1="-9.271" y1="12.065" x2="-9.779" y2="12.065" width="0.1524" layer="51"/>
<wire x1="-6.731" y1="12.065" x2="-7.239" y2="12.065" width="0.1524" layer="51"/>
<wire x1="12.065" y1="-6.731" x2="12.065" y2="-7.239" width="0.1524" layer="51"/>
<wire x1="14.224" y1="-7.239" x2="12.065" y2="-7.239" width="0.1524" layer="51"/>
<wire x1="14.224" y1="-7.239" x2="14.224" y2="-8.001" width="0.1524" layer="51"/>
<wire x1="12.065" y1="-8.001" x2="14.224" y2="-8.001" width="0.1524" layer="51"/>
<wire x1="12.065" y1="-9.779" x2="14.224" y2="-9.779" width="0.1524" layer="51"/>
<wire x1="12.065" y1="-9.779" x2="12.065" y2="-9.271" width="0.1524" layer="51"/>
<wire x1="14.224" y1="-9.271" x2="12.065" y2="-9.271" width="0.1524" layer="21"/>
<wire x1="14.224" y1="-9.271" x2="14.224" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="12.065" y1="-8.509" x2="14.224" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="12.065" y1="-8.001" x2="12.065" y2="-8.509" width="0.1524" layer="51"/>
<wire x1="9.779" y1="-12.065" x2="9.271" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="9.271" y1="-14.224" x2="9.271" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="7.239" y1="-14.224" x2="7.239" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="7.239" y1="-14.224" x2="8.001" y2="-14.224" width="0.1524" layer="51"/>
<wire x1="8.001" y1="-12.065" x2="8.001" y2="-14.224" width="0.1524" layer="51"/>
<wire x1="8.001" y1="-12.065" x2="8.509" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="8.509" y1="-14.224" x2="8.509" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-14.224" x2="9.271" y2="-14.224" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-12.065" x2="7.239" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="-6.731" y1="-12.065" x2="-7.239" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="-7.239" y1="-14.224" x2="-7.239" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="-7.239" y1="-14.224" x2="-8.001" y2="-14.224" width="0.1524" layer="51"/>
<wire x1="-8.001" y1="-12.065" x2="-8.001" y2="-14.224" width="0.1524" layer="51"/>
<wire x1="-9.779" y1="-12.065" x2="-9.271" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="-9.271" y1="-14.224" x2="-9.271" y2="-12.065" width="0.1524" layer="21"/>
<wire x1="-9.271" y1="-14.224" x2="-8.509" y2="-14.224" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-12.065" x2="-8.509" y2="-14.224" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-12.065" x2="-8.509" y2="-12.065" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="-7.239" x2="-12.065" y2="-7.239" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="-7.239" x2="-14.224" y2="-8.001" width="0.1524" layer="51"/>
<wire x1="-12.065" y1="-8.001" x2="-14.224" y2="-8.001" width="0.1524" layer="51"/>
<wire x1="-12.065" y1="-8.001" x2="-12.065" y2="-8.509" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="-8.509" x2="-12.065" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="-14.224" y1="-8.509" x2="-14.224" y2="-9.271" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-9.271" x2="-14.224" y2="-9.271" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="-9.271" x2="-12.065" y2="-9.779" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="-9.779" x2="-12.065" y2="-9.779" width="0.1524" layer="51"/>
<wire x1="-12.065" y1="-6.731" x2="-12.065" y2="-7.239" width="0.1524" layer="51"/>
<wire x1="-12.065" y1="6.731" x2="-12.065" y2="7.239" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="7.239" x2="-12.065" y2="7.239" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="7.239" x2="-14.224" y2="8.001" width="0.1524" layer="51"/>
<wire x1="-12.065" y1="8.001" x2="-14.224" y2="8.001" width="0.1524" layer="51"/>
<wire x1="-12.065" y1="9.779" x2="-14.224" y2="9.779" width="0.1524" layer="51"/>
<wire x1="-12.065" y1="9.779" x2="-12.065" y2="9.271" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="9.271" x2="-12.065" y2="9.271" width="0.1524" layer="21"/>
<wire x1="-14.224" y1="9.271" x2="-14.224" y2="8.509" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="8.509" x2="-14.224" y2="8.509" width="0.1524" layer="21"/>
<wire x1="-12.065" y1="8.001" x2="-12.065" y2="8.509" width="0.1524" layer="51"/>
<circle x="6.985" y="6.985" radius="0.635" width="0.1524" layer="21"/>
<circle x="-6.985" y="6.985" radius="0.635" width="0.1524" layer="21"/>
<circle x="-6.985" y="-6.985" radius="0.635" width="0.1524" layer="21"/>
<circle x="6.985" y="-6.985" radius="0.635" width="0.1524" layer="21"/>
<circle x="-3.81" y="3.81" radius="1.8034" width="0.1524" layer="21"/>
<circle x="3.81" y="3.81" radius="1.8034" width="0.1524" layer="21"/>
<circle x="-3.81" y="-3.81" radius="1.8034" width="0.1524" layer="21"/>
<circle x="3.81" y="-3.81" radius="1.8034" width="0.1524" layer="21"/>
<pad name="1" x="0" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="2" x="0" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="3" x="-2.54" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="4" x="-2.54" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="5" x="-5.08" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="6" x="-5.08" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="7" x="-7.62" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="8" x="-7.62" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="9" x="-10.16" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="10" x="-12.7" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="11" x="-10.16" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="12" x="-12.7" y="7.62" drill="0.8128" shape="octagon"/>
<pad name="13" x="-10.16" y="7.62" drill="0.8128" shape="octagon"/>
<pad name="14" x="-12.7" y="5.08" drill="0.8128" shape="octagon"/>
<pad name="15" x="-10.16" y="5.08" drill="0.8128" shape="octagon"/>
<pad name="16" x="-12.7" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="17" x="-10.16" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="18" x="-12.7" y="0" drill="0.8128" shape="octagon"/>
<pad name="19" x="-10.16" y="0" drill="0.8128" shape="octagon"/>
<pad name="20" x="-12.7" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="21" x="-10.16" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="22" x="-12.7" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="23" x="-10.16" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="24" x="-12.7" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="25" x="-10.16" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="26" x="-12.7" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="27" x="-10.16" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="28" x="-10.16" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="29" x="-7.62" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="30" x="-7.62" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="31" x="-5.08" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="32" x="-5.08" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="33" x="-2.54" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="34" x="-2.54" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="35" x="0" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="36" x="0" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="37" x="2.54" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="38" x="2.54" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="39" x="5.08" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="40" x="5.08" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="41" x="7.62" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="42" x="7.62" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="43" x="10.16" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="44" x="12.7" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="45" x="10.16" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="46" x="12.7" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="47" x="10.16" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="48" x="12.7" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="49" x="10.16" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="50" x="12.7" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="51" x="10.16" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="52" x="12.7" y="0" drill="0.8128" shape="octagon"/>
<pad name="53" x="10.16" y="0" drill="0.8128" shape="octagon"/>
<pad name="54" x="12.7" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="55" x="10.16" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="56" x="12.7" y="5.08" drill="0.8128" shape="octagon"/>
<pad name="57" x="10.16" y="5.08" drill="0.8128" shape="octagon"/>
<pad name="58" x="12.7" y="7.62" drill="0.8128" shape="octagon"/>
<pad name="59" x="10.16" y="7.62" drill="0.8128" shape="octagon"/>
<pad name="60" x="12.7" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="61" x="10.16" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="62" x="10.16" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="63" x="7.62" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="64" x="7.62" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="65" x="5.08" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="66" x="5.08" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="67" x="2.54" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="68" x="2.54" y="10.16" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="15.748" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-13.97" y="15.748" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="PLCC-S84-SOCKET">
<wire x1="17.78" y1="17.78" x2="-16.51" y2="17.78" width="0.1524" layer="21"/>
<wire x1="-16.51" y1="17.78" x2="-17.78" y2="16.51" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="16.51" x2="-17.78" y2="-17.78" width="0.1524" layer="21"/>
<wire x1="17.78" y1="-17.78" x2="-17.78" y2="-17.78" width="0.1524" layer="21"/>
<wire x1="17.78" y1="-17.78" x2="17.78" y2="17.78" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="13.335" x2="-13.335" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-16.764" x2="-13.589" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-16.764" x2="-16.764" y2="-15.748" width="0.1524" layer="21"/>
<wire x1="-16.764" y1="-15.748" x2="-14.605" y2="-13.589" width="0.1524" layer="21"/>
<wire x1="-13.589" y1="-14.605" x2="-13.081" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="-13.081" y1="-16.764" x2="-13.081" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="-13.081" y1="-16.764" x2="-12.319" y2="-16.764" width="0.1524" layer="51"/>
<wire x1="-12.319" y1="-14.605" x2="-12.319" y2="-16.764" width="0.1524" layer="51"/>
<wire x1="-5.461" y1="-16.764" x2="-5.461" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="-5.461" y1="-16.764" x2="-4.699" y2="-16.764" width="0.1524" layer="51"/>
<wire x1="-4.699" y1="-14.605" x2="-4.699" y2="-16.764" width="0.1524" layer="51"/>
<wire x1="-4.699" y1="-14.605" x2="-4.191" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="-16.764" x2="-4.191" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="-16.764" x2="-3.429" y2="-16.764" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-14.605" x2="-3.429" y2="-16.764" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-14.605" x2="-2.921" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="-16.764" x2="-2.921" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="-16.764" x2="-2.159" y2="-16.764" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="-14.605" x2="-2.159" y2="-16.764" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="-14.605" x2="-1.651" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-16.764" x2="-1.651" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="-16.764" x2="-0.889" y2="-16.764" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-14.605" x2="-0.889" y2="-16.764" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-14.605" x2="-0.381" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="-16.764" x2="-0.381" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="-16.764" x2="0.381" y2="-16.764" width="0.1524" layer="51"/>
<wire x1="0.381" y1="-14.605" x2="0.381" y2="-16.764" width="0.1524" layer="51"/>
<wire x1="0.381" y1="-14.605" x2="0.889" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="0.889" y1="-16.764" x2="0.889" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-16.764" x2="1.651" y2="-16.764" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-14.605" x2="1.651" y2="-16.764" width="0.1524" layer="21"/>
<wire x1="16.764" y1="15.748" x2="14.605" y2="13.589" width="0.1524" layer="21"/>
<wire x1="16.764" y1="15.748" x2="15.748" y2="16.764" width="0.1524" layer="21"/>
<wire x1="15.748" y1="16.764" x2="13.589" y2="14.605" width="0.1524" layer="21"/>
<wire x1="14.605" y1="13.589" x2="14.605" y2="13.081" width="0.1524" layer="51"/>
<wire x1="16.764" y1="13.081" x2="14.605" y2="13.081" width="0.1524" layer="51"/>
<wire x1="16.764" y1="13.081" x2="16.764" y2="12.319" width="0.1524" layer="51"/>
<wire x1="14.605" y1="12.319" x2="16.764" y2="12.319" width="0.1524" layer="51"/>
<wire x1="16.764" y1="5.461" x2="14.605" y2="5.461" width="0.1524" layer="51"/>
<wire x1="16.764" y1="5.461" x2="16.764" y2="4.699" width="0.1524" layer="51"/>
<wire x1="14.605" y1="4.699" x2="16.764" y2="4.699" width="0.1524" layer="51"/>
<wire x1="14.605" y1="4.699" x2="14.605" y2="4.191" width="0.1524" layer="51"/>
<wire x1="16.764" y1="4.191" x2="14.605" y2="4.191" width="0.1524" layer="21"/>
<wire x1="16.764" y1="4.191" x2="16.764" y2="3.429" width="0.1524" layer="21"/>
<wire x1="14.605" y1="3.429" x2="16.764" y2="3.429" width="0.1524" layer="21"/>
<wire x1="14.605" y1="3.429" x2="14.605" y2="2.921" width="0.1524" layer="51"/>
<wire x1="16.764" y1="2.921" x2="14.605" y2="2.921" width="0.1524" layer="51"/>
<wire x1="16.764" y1="2.921" x2="16.764" y2="2.159" width="0.1524" layer="51"/>
<wire x1="14.605" y1="2.159" x2="16.764" y2="2.159" width="0.1524" layer="51"/>
<wire x1="14.605" y1="2.159" x2="14.605" y2="1.651" width="0.1524" layer="51"/>
<wire x1="16.764" y1="1.651" x2="14.605" y2="1.651" width="0.1524" layer="21"/>
<wire x1="16.764" y1="1.651" x2="16.764" y2="0.889" width="0.1524" layer="21"/>
<wire x1="14.605" y1="0.889" x2="16.764" y2="0.889" width="0.1524" layer="21"/>
<wire x1="14.605" y1="0.889" x2="14.605" y2="0.381" width="0.1524" layer="51"/>
<wire x1="16.764" y1="0.381" x2="14.605" y2="0.381" width="0.1524" layer="51"/>
<wire x1="16.764" y1="0.381" x2="16.764" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="14.605" y1="-0.381" x2="16.764" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="14.605" y1="-0.381" x2="14.605" y2="-0.889" width="0.1524" layer="51"/>
<wire x1="16.764" y1="-0.889" x2="14.605" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="16.764" y1="-0.889" x2="16.764" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="14.605" y1="-1.651" x2="16.764" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-13.589" x2="-14.605" y2="-13.081" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="-13.081" x2="-14.605" y2="-13.081" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="-13.081" x2="-16.764" y2="-12.319" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="-12.319" x2="-16.764" y2="-12.319" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="-5.461" x2="-14.605" y2="-5.461" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="-5.461" x2="-16.764" y2="-4.699" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="-4.699" x2="-16.764" y2="-4.699" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="-4.699" x2="-14.605" y2="-4.191" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="-4.191" x2="-14.605" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-16.764" y1="-4.191" x2="-16.764" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-3.429" x2="-16.764" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-3.429" x2="-14.605" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="-2.921" x2="-14.605" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="-2.921" x2="-16.764" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="-2.159" x2="-16.764" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="-2.159" x2="-14.605" y2="-1.651" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="-1.651" x2="-14.605" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-16.764" y1="-1.651" x2="-16.764" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-0.889" x2="-16.764" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-0.889" x2="-14.605" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="-0.381" x2="-14.605" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="-0.381" x2="-16.764" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="0.381" x2="-16.764" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="0.381" x2="-14.605" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="0.889" x2="-14.605" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-16.764" y1="0.889" x2="-16.764" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="1.651" x2="-16.764" y2="1.651" width="0.1524" layer="21"/>
<wire x1="13.589" y1="14.605" x2="13.081" y2="14.605" width="0.1524" layer="51"/>
<wire x1="13.081" y1="16.764" x2="13.081" y2="14.605" width="0.1524" layer="51"/>
<wire x1="13.081" y1="16.764" x2="12.319" y2="16.764" width="0.1524" layer="51"/>
<wire x1="12.319" y1="14.605" x2="12.319" y2="16.764" width="0.1524" layer="51"/>
<wire x1="5.461" y1="16.764" x2="5.461" y2="14.605" width="0.1524" layer="51"/>
<wire x1="5.461" y1="16.764" x2="4.699" y2="16.764" width="0.1524" layer="51"/>
<wire x1="4.699" y1="14.605" x2="4.699" y2="16.764" width="0.1524" layer="51"/>
<wire x1="4.699" y1="14.605" x2="4.191" y2="14.605" width="0.1524" layer="51"/>
<wire x1="4.191" y1="16.764" x2="4.191" y2="14.605" width="0.1524" layer="21"/>
<wire x1="4.191" y1="16.764" x2="3.429" y2="16.764" width="0.1524" layer="21"/>
<wire x1="3.429" y1="14.605" x2="3.429" y2="16.764" width="0.1524" layer="21"/>
<wire x1="3.429" y1="14.605" x2="2.921" y2="14.605" width="0.1524" layer="51"/>
<wire x1="2.921" y1="16.764" x2="2.921" y2="14.605" width="0.1524" layer="51"/>
<wire x1="2.921" y1="16.764" x2="2.159" y2="16.764" width="0.1524" layer="51"/>
<wire x1="2.159" y1="14.605" x2="2.159" y2="16.764" width="0.1524" layer="51"/>
<wire x1="2.159" y1="14.605" x2="1.651" y2="14.605" width="0.1524" layer="51"/>
<wire x1="1.651" y1="16.764" x2="1.651" y2="14.605" width="0.1524" layer="21"/>
<wire x1="1.651" y1="16.764" x2="0.889" y2="16.764" width="0.1524" layer="21"/>
<wire x1="0.889" y1="14.605" x2="0.889" y2="16.764" width="0.1524" layer="21"/>
<wire x1="0.889" y1="14.605" x2="0.381" y2="14.605" width="0.1524" layer="51"/>
<wire x1="0.381" y1="16.764" x2="0.381" y2="14.605" width="0.1524" layer="51"/>
<wire x1="0.381" y1="16.764" x2="-0.381" y2="16.764" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="14.605" x2="-0.381" y2="16.764" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="14.605" x2="-0.889" y2="14.605" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="16.764" x2="-0.889" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="16.764" x2="-1.651" y2="16.764" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="14.605" x2="-1.651" y2="16.764" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="14.605" x2="-2.159" y2="14.605" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="16.764" x2="-2.159" y2="14.605" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="16.764" x2="-2.921" y2="16.764" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="14.605" x2="-2.921" y2="16.764" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="14.605" x2="-3.429" y2="14.605" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="16.764" x2="-3.429" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="16.764" x2="-4.191" y2="16.764" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="14.605" x2="-4.191" y2="16.764" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="14.605" x2="-4.699" y2="14.605" width="0.1524" layer="51"/>
<wire x1="-4.699" y1="16.764" x2="-4.699" y2="14.605" width="0.1524" layer="51"/>
<wire x1="-4.699" y1="16.764" x2="-5.461" y2="16.764" width="0.1524" layer="51"/>
<wire x1="-5.461" y1="14.605" x2="-5.461" y2="16.764" width="0.1524" layer="51"/>
<wire x1="-12.319" y1="16.764" x2="-12.319" y2="14.605" width="0.1524" layer="51"/>
<wire x1="-12.319" y1="16.764" x2="-13.081" y2="16.764" width="0.1524" layer="51"/>
<wire x1="-13.081" y1="14.605" x2="-13.081" y2="16.764" width="0.1524" layer="51"/>
<wire x1="1.651" y1="-14.605" x2="2.159" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-16.764" x2="2.159" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-16.764" x2="2.921" y2="-16.764" width="0.1524" layer="51"/>
<wire x1="2.921" y1="-14.605" x2="2.921" y2="-16.764" width="0.1524" layer="51"/>
<wire x1="2.921" y1="-14.605" x2="3.429" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="3.429" y1="-16.764" x2="3.429" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-16.764" x2="4.191" y2="-16.764" width="0.1524" layer="21"/>
<wire x1="4.191" y1="-14.605" x2="4.191" y2="-16.764" width="0.1524" layer="21"/>
<wire x1="4.191" y1="-14.605" x2="4.699" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="4.699" y1="-16.764" x2="4.699" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="4.699" y1="-16.764" x2="5.461" y2="-16.764" width="0.1524" layer="51"/>
<wire x1="5.461" y1="-14.605" x2="5.461" y2="-16.764" width="0.1524" layer="51"/>
<wire x1="12.319" y1="-16.764" x2="12.319" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="12.319" y1="-16.764" x2="13.081" y2="-16.764" width="0.1524" layer="51"/>
<wire x1="13.081" y1="-14.605" x2="13.081" y2="-16.764" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="13.081" x2="-14.605" y2="13.081" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="13.081" x2="-16.764" y2="12.319" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="12.319" x2="-16.764" y2="12.319" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="5.461" x2="-14.605" y2="5.461" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="5.461" x2="-16.764" y2="4.699" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="4.699" x2="-16.764" y2="4.699" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="4.699" x2="-14.605" y2="4.191" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="4.191" x2="-14.605" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-16.764" y1="4.191" x2="-16.764" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="3.429" x2="-16.764" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="3.429" x2="-14.605" y2="2.921" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="2.921" x2="-14.605" y2="2.921" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="2.921" x2="-16.764" y2="2.159" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="2.159" x2="-16.764" y2="2.159" width="0.1524" layer="51"/>
<wire x1="16.764" y1="-13.081" x2="14.605" y2="-13.081" width="0.1524" layer="51"/>
<wire x1="16.764" y1="-13.081" x2="16.764" y2="-12.319" width="0.1524" layer="51"/>
<wire x1="14.605" y1="-12.319" x2="16.764" y2="-12.319" width="0.1524" layer="51"/>
<wire x1="16.764" y1="-5.461" x2="14.605" y2="-5.461" width="0.1524" layer="51"/>
<wire x1="16.764" y1="-5.461" x2="16.764" y2="-4.699" width="0.1524" layer="51"/>
<wire x1="14.605" y1="-4.699" x2="16.764" y2="-4.699" width="0.1524" layer="51"/>
<wire x1="14.605" y1="-4.699" x2="14.605" y2="-4.191" width="0.1524" layer="51"/>
<wire x1="16.764" y1="-4.191" x2="14.605" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="16.764" y1="-4.191" x2="16.764" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="14.605" y1="-3.429" x2="16.764" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="14.605" y1="-3.429" x2="14.605" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="16.764" y1="-2.921" x2="14.605" y2="-2.921" width="0.1524" layer="51"/>
<wire x1="16.764" y1="-2.921" x2="16.764" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="14.605" y1="-2.159" x2="16.764" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="13.081" y1="-14.605" x2="14.605" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="14.605" y1="-14.605" x2="14.605" y2="-13.081" width="0.1524" layer="21"/>
<wire x1="14.605" y1="-1.651" x2="14.605" y2="-2.159" width="0.1524" layer="51"/>
<wire x1="-13.335" y1="14.605" x2="-13.081" y2="14.605" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="13.081" x2="-14.605" y2="13.335" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="2.159" x2="-14.605" y2="1.651" width="0.1524" layer="51"/>
<wire x1="16.764" y1="-6.731" x2="14.605" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="16.764" y1="-6.731" x2="16.764" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="14.605" y1="-5.969" x2="16.764" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="14.605" y1="-5.969" x2="14.605" y2="-5.461" width="0.1524" layer="51"/>
<wire x1="14.605" y1="5.461" x2="14.605" y2="5.969" width="0.1524" layer="51"/>
<wire x1="16.764" y1="5.969" x2="14.605" y2="5.969" width="0.1524" layer="21"/>
<wire x1="16.764" y1="5.969" x2="16.764" y2="6.731" width="0.1524" layer="21"/>
<wire x1="14.605" y1="6.731" x2="16.764" y2="6.731" width="0.1524" layer="21"/>
<wire x1="6.731" y1="16.764" x2="6.731" y2="14.605" width="0.1524" layer="21"/>
<wire x1="6.731" y1="16.764" x2="5.969" y2="16.764" width="0.1524" layer="21"/>
<wire x1="5.969" y1="14.605" x2="5.969" y2="16.764" width="0.1524" layer="21"/>
<wire x1="5.969" y1="14.605" x2="5.461" y2="14.605" width="0.1524" layer="51"/>
<wire x1="-5.461" y1="14.605" x2="-5.969" y2="14.605" width="0.1524" layer="51"/>
<wire x1="-5.969" y1="16.764" x2="-5.969" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="16.764" x2="-6.731" y2="16.764" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="14.605" x2="-6.731" y2="16.764" width="0.1524" layer="21"/>
<wire x1="-16.764" y1="6.731" x2="-14.605" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-16.764" y1="6.731" x2="-16.764" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="5.969" x2="-16.764" y2="5.969" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="5.969" x2="-14.605" y2="5.461" width="0.1524" layer="51"/>
<wire x1="5.461" y1="-14.605" x2="5.969" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="5.969" y1="-16.764" x2="5.969" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="5.969" y1="-16.764" x2="6.731" y2="-16.764" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-14.605" x2="6.731" y2="-16.764" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-16.764" x2="-6.731" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-16.764" x2="-5.969" y2="-16.764" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-14.605" x2="-5.969" y2="-16.764" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-14.605" x2="-5.461" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="-5.461" x2="-14.605" y2="-5.969" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="-5.969" x2="-14.605" y2="-5.969" width="0.1524" layer="21"/>
<wire x1="-16.764" y1="-5.969" x2="-16.764" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-6.731" x2="-16.764" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="14.605" y1="12.319" x2="14.605" y2="11.811" width="0.1524" layer="51"/>
<wire x1="16.764" y1="11.811" x2="14.605" y2="11.811" width="0.1524" layer="21"/>
<wire x1="16.764" y1="11.811" x2="16.764" y2="11.049" width="0.1524" layer="21"/>
<wire x1="14.605" y1="11.049" x2="16.764" y2="11.049" width="0.1524" layer="21"/>
<wire x1="16.764" y1="7.239" x2="14.605" y2="7.239" width="0.1524" layer="51"/>
<wire x1="16.764" y1="7.239" x2="16.764" y2="8.001" width="0.1524" layer="51"/>
<wire x1="14.605" y1="8.001" x2="16.764" y2="8.001" width="0.1524" layer="51"/>
<wire x1="14.605" y1="8.001" x2="14.605" y2="8.509" width="0.1524" layer="51"/>
<wire x1="16.764" y1="8.509" x2="14.605" y2="8.509" width="0.1524" layer="21"/>
<wire x1="16.764" y1="8.509" x2="16.764" y2="9.271" width="0.1524" layer="21"/>
<wire x1="14.605" y1="9.271" x2="16.764" y2="9.271" width="0.1524" layer="21"/>
<wire x1="14.605" y1="9.271" x2="14.605" y2="9.779" width="0.1524" layer="51"/>
<wire x1="16.764" y1="9.779" x2="14.605" y2="9.779" width="0.1524" layer="51"/>
<wire x1="16.764" y1="9.779" x2="16.764" y2="10.541" width="0.1524" layer="51"/>
<wire x1="14.605" y1="10.541" x2="16.764" y2="10.541" width="0.1524" layer="51"/>
<wire x1="14.605" y1="11.049" x2="14.605" y2="10.541" width="0.1524" layer="51"/>
<wire x1="14.605" y1="6.731" x2="14.605" y2="7.239" width="0.1524" layer="51"/>
<wire x1="6.731" y1="14.605" x2="7.239" y2="14.605" width="0.1524" layer="51"/>
<wire x1="7.239" y1="16.764" x2="7.239" y2="14.605" width="0.1524" layer="51"/>
<wire x1="7.239" y1="16.764" x2="8.001" y2="16.764" width="0.1524" layer="51"/>
<wire x1="8.001" y1="14.605" x2="8.001" y2="16.764" width="0.1524" layer="51"/>
<wire x1="11.811" y1="16.764" x2="11.811" y2="14.605" width="0.1524" layer="21"/>
<wire x1="11.811" y1="16.764" x2="11.049" y2="16.764" width="0.1524" layer="21"/>
<wire x1="11.049" y1="14.605" x2="11.049" y2="16.764" width="0.1524" layer="21"/>
<wire x1="11.049" y1="14.605" x2="10.541" y2="14.605" width="0.1524" layer="51"/>
<wire x1="10.541" y1="16.764" x2="10.541" y2="14.605" width="0.1524" layer="51"/>
<wire x1="10.541" y1="16.764" x2="9.779" y2="16.764" width="0.1524" layer="51"/>
<wire x1="9.779" y1="14.605" x2="9.779" y2="16.764" width="0.1524" layer="51"/>
<wire x1="9.779" y1="14.605" x2="9.271" y2="14.605" width="0.1524" layer="51"/>
<wire x1="9.271" y1="16.764" x2="9.271" y2="14.605" width="0.1524" layer="21"/>
<wire x1="9.271" y1="16.764" x2="8.509" y2="16.764" width="0.1524" layer="21"/>
<wire x1="8.509" y1="14.605" x2="8.509" y2="16.764" width="0.1524" layer="21"/>
<wire x1="8.001" y1="14.605" x2="8.509" y2="14.605" width="0.1524" layer="51"/>
<wire x1="12.319" y1="14.605" x2="11.811" y2="14.605" width="0.1524" layer="51"/>
<wire x1="-12.319" y1="14.605" x2="-11.811" y2="14.605" width="0.1524" layer="51"/>
<wire x1="-11.811" y1="16.764" x2="-11.811" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-11.811" y1="16.764" x2="-11.049" y2="16.764" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="14.605" x2="-11.049" y2="16.764" width="0.1524" layer="21"/>
<wire x1="-7.239" y1="16.764" x2="-7.239" y2="14.605" width="0.1524" layer="51"/>
<wire x1="-7.239" y1="16.764" x2="-8.001" y2="16.764" width="0.1524" layer="51"/>
<wire x1="-8.001" y1="14.605" x2="-8.001" y2="16.764" width="0.1524" layer="51"/>
<wire x1="-8.001" y1="14.605" x2="-8.509" y2="14.605" width="0.1524" layer="51"/>
<wire x1="-8.509" y1="16.764" x2="-8.509" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="16.764" x2="-9.271" y2="16.764" width="0.1524" layer="21"/>
<wire x1="-9.271" y1="14.605" x2="-9.271" y2="16.764" width="0.1524" layer="21"/>
<wire x1="-9.271" y1="14.605" x2="-9.779" y2="14.605" width="0.1524" layer="51"/>
<wire x1="-9.779" y1="16.764" x2="-9.779" y2="14.605" width="0.1524" layer="51"/>
<wire x1="-9.779" y1="16.764" x2="-10.541" y2="16.764" width="0.1524" layer="51"/>
<wire x1="-10.541" y1="14.605" x2="-10.541" y2="16.764" width="0.1524" layer="51"/>
<wire x1="-11.049" y1="14.605" x2="-10.541" y2="14.605" width="0.1524" layer="51"/>
<wire x1="-6.731" y1="14.605" x2="-7.239" y2="14.605" width="0.1524" layer="51"/>
<wire x1="14.605" y1="-6.731" x2="14.605" y2="-7.239" width="0.1524" layer="51"/>
<wire x1="16.764" y1="-7.239" x2="14.605" y2="-7.239" width="0.1524" layer="51"/>
<wire x1="16.764" y1="-7.239" x2="16.764" y2="-8.001" width="0.1524" layer="51"/>
<wire x1="14.605" y1="-8.001" x2="16.764" y2="-8.001" width="0.1524" layer="51"/>
<wire x1="16.764" y1="-11.811" x2="14.605" y2="-11.811" width="0.1524" layer="21"/>
<wire x1="16.764" y1="-11.811" x2="16.764" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="14.605" y1="-11.049" x2="16.764" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="14.605" y1="-11.049" x2="14.605" y2="-10.541" width="0.1524" layer="51"/>
<wire x1="16.764" y1="-10.541" x2="14.605" y2="-10.541" width="0.1524" layer="51"/>
<wire x1="16.764" y1="-10.541" x2="16.764" y2="-9.779" width="0.1524" layer="51"/>
<wire x1="14.605" y1="-9.779" x2="16.764" y2="-9.779" width="0.1524" layer="51"/>
<wire x1="14.605" y1="-9.779" x2="14.605" y2="-9.271" width="0.1524" layer="51"/>
<wire x1="16.764" y1="-9.271" x2="14.605" y2="-9.271" width="0.1524" layer="21"/>
<wire x1="16.764" y1="-9.271" x2="16.764" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="14.605" y1="-8.509" x2="16.764" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="14.605" y1="-8.001" x2="14.605" y2="-8.509" width="0.1524" layer="51"/>
<wire x1="14.605" y1="-12.319" x2="14.605" y2="-11.811" width="0.1524" layer="51"/>
<wire x1="12.319" y1="-14.605" x2="11.811" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="11.811" y1="-16.764" x2="11.811" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="11.811" y1="-16.764" x2="11.049" y2="-16.764" width="0.1524" layer="21"/>
<wire x1="11.049" y1="-14.605" x2="11.049" y2="-16.764" width="0.1524" layer="21"/>
<wire x1="7.239" y1="-16.764" x2="7.239" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="7.239" y1="-16.764" x2="8.001" y2="-16.764" width="0.1524" layer="51"/>
<wire x1="8.001" y1="-14.605" x2="8.001" y2="-16.764" width="0.1524" layer="51"/>
<wire x1="8.001" y1="-14.605" x2="8.509" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="8.509" y1="-16.764" x2="8.509" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-16.764" x2="9.271" y2="-16.764" width="0.1524" layer="21"/>
<wire x1="9.271" y1="-14.605" x2="9.271" y2="-16.764" width="0.1524" layer="21"/>
<wire x1="9.271" y1="-14.605" x2="9.779" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="9.779" y1="-16.764" x2="9.779" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="9.779" y1="-16.764" x2="10.541" y2="-16.764" width="0.1524" layer="51"/>
<wire x1="10.541" y1="-14.605" x2="10.541" y2="-16.764" width="0.1524" layer="51"/>
<wire x1="11.049" y1="-14.605" x2="10.541" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="6.731" y1="-14.605" x2="7.239" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="-6.731" y1="-14.605" x2="-7.239" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="-7.239" y1="-16.764" x2="-7.239" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="-7.239" y1="-16.764" x2="-8.001" y2="-16.764" width="0.1524" layer="51"/>
<wire x1="-8.001" y1="-14.605" x2="-8.001" y2="-16.764" width="0.1524" layer="51"/>
<wire x1="-11.811" y1="-16.764" x2="-11.811" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-11.811" y1="-16.764" x2="-11.049" y2="-16.764" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="-14.605" x2="-11.049" y2="-16.764" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="-14.605" x2="-10.541" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="-10.541" y1="-16.764" x2="-10.541" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="-10.541" y1="-16.764" x2="-9.779" y2="-16.764" width="0.1524" layer="51"/>
<wire x1="-9.779" y1="-14.605" x2="-9.779" y2="-16.764" width="0.1524" layer="51"/>
<wire x1="-9.779" y1="-14.605" x2="-9.271" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="-9.271" y1="-16.764" x2="-9.271" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-9.271" y1="-16.764" x2="-8.509" y2="-16.764" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="-14.605" x2="-8.509" y2="-16.764" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-14.605" x2="-8.509" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="-12.319" y1="-14.605" x2="-11.811" y2="-14.605" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="-12.319" x2="-14.605" y2="-11.811" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="-11.811" x2="-14.605" y2="-11.811" width="0.1524" layer="21"/>
<wire x1="-16.764" y1="-11.811" x2="-16.764" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-11.049" x2="-16.764" y2="-11.049" width="0.1524" layer="21"/>
<wire x1="-16.764" y1="-7.239" x2="-14.605" y2="-7.239" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="-7.239" x2="-16.764" y2="-8.001" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="-8.001" x2="-16.764" y2="-8.001" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="-8.001" x2="-14.605" y2="-8.509" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="-8.509" x2="-14.605" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="-16.764" y1="-8.509" x2="-16.764" y2="-9.271" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-9.271" x2="-16.764" y2="-9.271" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-9.271" x2="-14.605" y2="-9.779" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="-9.779" x2="-14.605" y2="-9.779" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="-9.779" x2="-16.764" y2="-10.541" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="-10.541" x2="-16.764" y2="-10.541" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="-11.049" x2="-14.605" y2="-10.541" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="-6.731" x2="-14.605" y2="-7.239" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="6.731" x2="-14.605" y2="7.239" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="7.239" x2="-14.605" y2="7.239" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="7.239" x2="-16.764" y2="8.001" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="8.001" x2="-16.764" y2="8.001" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="11.811" x2="-14.605" y2="11.811" width="0.1524" layer="21"/>
<wire x1="-16.764" y1="11.811" x2="-16.764" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="11.049" x2="-16.764" y2="11.049" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="11.049" x2="-14.605" y2="10.541" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="10.541" x2="-14.605" y2="10.541" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="10.541" x2="-16.764" y2="9.779" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="9.779" x2="-16.764" y2="9.779" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="9.779" x2="-14.605" y2="9.271" width="0.1524" layer="51"/>
<wire x1="-16.764" y1="9.271" x2="-14.605" y2="9.271" width="0.1524" layer="21"/>
<wire x1="-16.764" y1="9.271" x2="-16.764" y2="8.509" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="8.509" x2="-16.764" y2="8.509" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="8.001" x2="-14.605" y2="8.509" width="0.1524" layer="51"/>
<wire x1="-14.605" y1="12.319" x2="-14.605" y2="11.811" width="0.1524" layer="51"/>
<pad name="1" x="0" y="15.24" drill="0.8128" shape="octagon"/>
<pad name="2" x="0" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="3" x="-2.54" y="15.24" drill="0.8128" shape="octagon"/>
<pad name="4" x="-2.54" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="5" x="-5.08" y="15.24" drill="0.8128" shape="octagon"/>
<pad name="6" x="-5.08" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="7" x="-7.62" y="15.24" drill="0.8128" shape="octagon"/>
<pad name="8" x="-7.62" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="9" x="-10.16" y="15.24" drill="0.8128" shape="octagon"/>
<pad name="10" x="-10.16" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="11" x="-12.7" y="15.24" drill="0.8128" shape="octagon"/>
<pad name="12" x="-15.24" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="13" x="-12.7" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="14" x="-15.24" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="15" x="-12.7" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="16" x="-15.24" y="7.62" drill="0.8128" shape="octagon"/>
<pad name="17" x="-12.7" y="7.62" drill="0.8128" shape="octagon"/>
<pad name="18" x="-15.24" y="5.08" drill="0.8128" shape="octagon"/>
<pad name="19" x="-12.7" y="5.08" drill="0.8128" shape="octagon"/>
<pad name="20" x="-15.24" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="21" x="-12.7" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="22" x="-15.24" y="0" drill="0.8128" shape="octagon"/>
<pad name="23" x="-12.7" y="0" drill="0.8128" shape="octagon"/>
<pad name="24" x="-15.24" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="25" x="-12.7" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="26" x="-15.24" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="27" x="-12.7" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="28" x="-15.24" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="29" x="-12.7" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="30" x="-15.24" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="32" x="-15.24" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="31" x="-12.7" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="33" x="-12.7" y="-15.24" drill="0.8128" shape="octagon"/>
<pad name="34" x="-12.7" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="36" x="-10.16" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="35" x="-10.16" y="-15.24" drill="0.8128" shape="octagon"/>
<pad name="38" x="-7.62" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="37" x="-7.62" y="-15.24" drill="0.8128" shape="octagon"/>
<pad name="40" x="-5.08" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="39" x="-5.08" y="-15.24" drill="0.8128" shape="octagon"/>
<pad name="41" x="-2.54" y="-15.24" drill="0.8128" shape="octagon"/>
<pad name="42" x="-2.54" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="43" x="0" y="-15.24" drill="0.8128" shape="octagon"/>
<pad name="44" x="0" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="45" x="2.54" y="-15.24" drill="0.8128" shape="octagon"/>
<pad name="46" x="2.54" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="47" x="5.08" y="-15.24" drill="0.8128" shape="octagon"/>
<pad name="48" x="5.08" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="50" x="7.62" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="49" x="7.62" y="-15.24" drill="0.8128" shape="octagon"/>
<pad name="52" x="10.16" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="51" x="10.16" y="-15.24" drill="0.8128" shape="octagon"/>
<pad name="53" x="12.7" y="-15.24" drill="0.8128" shape="octagon"/>
<pad name="76" x="12.7" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="74" x="15.24" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="73" x="12.7" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="72" x="15.24" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="71" x="12.7" y="7.62" drill="0.8128" shape="octagon"/>
<pad name="70" x="15.24" y="7.62" drill="0.8128" shape="octagon"/>
<pad name="69" x="12.7" y="5.08" drill="0.8128" shape="octagon"/>
<pad name="68" x="15.24" y="5.08" drill="0.8128" shape="octagon"/>
<pad name="67" x="12.7" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="66" x="15.24" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="65" x="12.7" y="0" drill="0.8128" shape="octagon"/>
<pad name="64" x="15.24" y="0" drill="0.8128" shape="octagon"/>
<pad name="63" x="12.7" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="62" x="15.24" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="61" x="12.7" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="60" x="15.24" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="59" x="12.7" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="58" x="15.24" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="57" x="12.7" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="55" x="12.7" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="56" x="15.24" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="54" x="15.24" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="82" x="5.08" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="81" x="5.08" y="15.24" drill="0.8128" shape="octagon"/>
<pad name="80" x="7.62" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="79" x="7.62" y="15.24" drill="0.8128" shape="octagon"/>
<pad name="78" x="10.16" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="77" x="10.16" y="15.24" drill="0.8128" shape="octagon"/>
<pad name="75" x="12.7" y="15.24" drill="0.8128" shape="octagon"/>
<pad name="83" x="2.54" y="15.24" drill="0.8128" shape="octagon"/>
<pad name="84" x="2.54" y="12.7" drill="0.8128" shape="octagon"/>
<text x="-5.08" y="18.161" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-16.51" y="18.161" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="DIL10">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="6.35" y1="2.921" x2="-6.35" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-2.921" x2="6.35" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="6.35" y1="2.921" x2="6.35" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="2.921" x2="-6.35" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-2.921" x2="-6.35" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="1.016" x2="-6.35" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-6.604" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-4.953" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL14/4">
<wire x1="8.763" y1="2.921" x2="-8.763" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-2.921" x2="8.763" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="8.763" y1="2.921" x2="8.763" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="2.921" x2="-8.763" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="-2.921" x2="-8.763" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-8.763" y1="1.016" x2="-8.763" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-9.017" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-6.731" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL14/8">
<wire x1="8.89" y1="2.921" x2="-8.89" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.921" x2="8.89" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="8.89" y1="2.921" x2="8.89" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.921" x2="-8.89" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.921" x2="-8.89" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="1.016" x2="-8.89" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="2" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-9.144" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-7.366" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL48">
<wire x1="-29.845" y1="-6.604" x2="29.845" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="29.845" y1="-6.604" x2="29.845" y2="6.604" width="0.1524" layer="21"/>
<wire x1="29.845" y1="6.604" x2="-29.845" y2="6.604" width="0.1524" layer="21"/>
<wire x1="-29.845" y1="6.604" x2="-29.845" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-29.845" y1="-6.604" x2="-29.845" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-29.845" y1="0.889" x2="-29.845" y2="-1.143" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-29.21" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-26.67" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-24.13" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-21.59" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="-8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="-6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="-3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="-1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="21.59" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="24.13" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="26.67" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="29.21" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="29.21" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="26.67" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="24.13" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="21.59" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="29" x="19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="30" x="16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="31" x="13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="32" x="11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="33" x="8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="34" x="6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="35" x="3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="36" x="1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="37" x="-1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="38" x="-3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="39" x="-6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="40" x="-8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="41" x="-11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="42" x="-13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="43" x="-16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="44" x="-19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="45" x="-21.59" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="46" x="-24.13" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="47" x="-26.67" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="48" x="-29.21" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<text x="-30.226" y="-6.35" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-16.637" y="-1.016" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL28-3">
<description>&lt;b&gt;Dual In Line Package Small&lt;/b&gt;</description>
<wire x1="17.78" y1="2.921" x2="-17.78" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-2.921" x2="17.78" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="17.78" y1="2.921" x2="17.78" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="2.921" x2="-17.78" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-2.921" x2="-17.78" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="1.016" x2="-17.78" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-16.51" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="16.51" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="16.51" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="-11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="-13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="-16.51" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-18.034" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-8.509" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL22S">
<wire x1="13.97" y1="2.921" x2="-13.97" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-2.921" x2="13.97" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="13.97" y1="2.921" x2="13.97" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="2.921" x2="-13.97" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-2.921" x2="-13.97" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="1.016" x2="-13.97" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-12.7" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-10.16" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="10.16" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="12.7" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="12.7" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="10.16" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="-10.16" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-12.7" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-14.224" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-9.906" y="-0.508" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="PGA68L">
<description>&lt;b&gt;Pin Grid Array&lt;/b&gt;</description>
<wire x1="-12.065" y1="14.605" x2="14.605" y2="14.605" width="0.1524" layer="21"/>
<wire x1="14.605" y1="14.605" x2="14.605" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="14.605" y1="-14.605" x2="-14.605" y2="-14.605" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-14.605" x2="-14.605" y2="12.065" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="12.065" x2="-12.065" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="8.89" x2="8.89" y2="8.89" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-8.89" x2="8.89" y2="8.89" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-8.89" x2="-8.89" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="8.89" x2="-8.89" y2="-8.89" width="0.1524" layer="21"/>
<pad name="A02" x="-10.16" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A04" x="-5.08" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A05" x="-2.54" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A06" x="0" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A07" x="2.54" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A08" x="5.08" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A09" x="7.62" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A10" x="10.16" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B11" x="12.7" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C11" x="12.7" y="7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D11" x="12.7" y="5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E11" x="12.7" y="2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F11" x="12.7" y="0" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G11" x="12.7" y="-2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H11" x="12.7" y="-5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J11" x="12.7" y="-7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K11" x="12.7" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L10" x="10.16" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L09" x="7.62" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L08" x="5.08" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L07" x="2.54" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L06" x="0" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L05" x="-2.54" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L04" x="-5.08" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L03" x="-7.62" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L02" x="-10.16" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K01" x="-12.7" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J01" x="-12.7" y="-7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H01" x="-12.7" y="-5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G01" x="-12.7" y="-2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F01" x="-12.7" y="0" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E01" x="-12.7" y="2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D01" x="-12.7" y="5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C01" x="-12.7" y="7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B01" x="-12.7" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B03" x="-7.62" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B04" x="-5.08" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B05" x="-2.54" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B06" x="0" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B07" x="2.54" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B08" x="5.08" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B09" x="7.62" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B10" x="10.16" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C10" x="10.16" y="7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D10" x="10.16" y="5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E10" x="10.16" y="2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F10" x="10.16" y="0" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G10" x="10.16" y="-2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H10" x="10.16" y="-5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J10" x="10.16" y="-7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K10" x="10.16" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K09" x="7.62" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K08" x="5.08" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K07" x="2.54" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K06" x="0" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K05" x="-2.54" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K04" x="-5.08" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K03" x="-7.62" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K02" x="-10.16" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J02" x="-10.16" y="-7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H02" x="-10.16" y="-5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G02" x="-10.16" y="-2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F02" x="-10.16" y="0" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E02" x="-10.16" y="2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D02" x="-10.16" y="5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C02" x="-10.16" y="7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B02" x="-10.16" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A03" x="-7.62" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<text x="-3.81" y="2.54" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.35" y="-1.905" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="MPGA-132">
<description>&lt;b&gt;Micro Pin Grid Array&lt;/b&gt;</description>
<wire x1="-15.875" y1="17.145" x2="17.145" y2="17.145" width="0.1524" layer="21"/>
<wire x1="17.145" y1="17.145" x2="17.145" y2="-17.145" width="0.1524" layer="21"/>
<wire x1="17.145" y1="-17.145" x2="-17.145" y2="-17.145" width="0.1524" layer="21"/>
<wire x1="-17.145" y1="-17.145" x2="-17.145" y2="15.875" width="0.1524" layer="21"/>
<wire x1="-17.145" y1="15.875" x2="-15.875" y2="17.145" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="6.35" x2="-6.35" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="3.81" x2="-6.35" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-6.35" x2="6.35" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-6.35" x2="6.35" y2="6.35" width="0.1524" layer="21"/>
<wire x1="6.35" y1="6.35" x2="-3.81" y2="6.35" width="0.1524" layer="21"/>
<pad name="A01" x="-15.24" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A02" x="-12.7" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A03" x="-10.16" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A04" x="-7.62" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A05" x="-5.08" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A06" x="-2.54" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A07" x="0" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A08" x="2.54" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A09" x="5.08" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A10" x="7.62" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A11" x="10.16" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A12" x="12.7" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A13" x="15.24" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B13" x="15.24" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M01" x="-15.24" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L01" x="-15.24" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K01" x="-15.24" y="-7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J01" x="-15.24" y="-5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H01" x="-15.24" y="-2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G01" x="-15.24" y="0" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F01" x="-15.24" y="2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E01" x="-15.24" y="5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D01" x="-15.24" y="7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B01" x="-15.24" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B02" x="-12.7" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B03" x="-10.16" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B04" x="-7.62" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B05" x="-5.08" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B06" x="-2.54" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B07" x="0" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B08" x="2.54" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B09" x="5.08" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B10" x="7.62" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B11" x="10.16" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B12" x="12.7" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D13" x="15.24" y="7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E13" x="15.24" y="5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F13" x="15.24" y="2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G13" x="15.24" y="0" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H13" x="15.24" y="-2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J13" x="15.24" y="-5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K13" x="15.24" y="-7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L13" x="15.24" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M13" x="15.24" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M02" x="-12.7" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L02" x="-12.7" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K02" x="-12.7" y="-7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J02" x="-12.7" y="-5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H02" x="-12.7" y="-2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G02" x="-12.7" y="0" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F02" x="-12.7" y="2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E02" x="-12.7" y="5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D02" x="-12.7" y="7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N02" x="-12.7" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N13" x="15.24" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N12" x="12.7" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N11" x="10.16" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N10" x="7.62" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N09" x="5.08" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N08" x="2.54" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N07" x="0" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N06" x="-2.54" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N05" x="-5.08" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N04" x="-7.62" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N03" x="-10.16" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C13" x="15.24" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C01" x="-15.24" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C12" x="12.7" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C11" x="10.16" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C10" x="7.62" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C09" x="5.08" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C08" x="2.54" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C07" x="0" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C06" x="-2.54" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C05" x="-5.08" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C04" x="-7.62" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C03" x="-10.16" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C02" x="-12.7" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N01" x="-15.24" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M03" x="-10.16" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L03" x="-10.16" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K03" x="-10.16" y="-7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J03" x="-10.16" y="-5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H03" x="-10.16" y="-2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G03" x="-10.16" y="0" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F03" x="-10.16" y="2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E03" x="-10.16" y="5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D03" x="-10.16" y="7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M12" x="12.7" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L12" x="12.7" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K12" x="12.7" y="-7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J12" x="12.7" y="-5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H12" x="12.7" y="-2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G12" x="12.7" y="0" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F12" x="12.7" y="2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E12" x="12.7" y="5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D12" x="12.7" y="7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M04" x="-7.62" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M05" x="-5.08" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M06" x="-2.54" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M07" x="0" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M08" x="2.54" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M09" x="5.08" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M10" x="7.62" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M11" x="10.16" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L11" x="10.16" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L10" x="7.62" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L09" x="5.08" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L08" x="2.54" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L07" x="0" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L06" x="-2.54" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L05" x="-5.08" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L04" x="-7.62" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G11" x="10.16" y="0" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K11" x="10.16" y="-7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J11" x="10.16" y="-5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H11" x="10.16" y="-2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F11" x="10.16" y="2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E11" x="10.16" y="5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D11" x="10.16" y="7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D10" x="7.62" y="7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K10" x="7.62" y="-7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K04" x="-7.62" y="-7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D04" x="-7.62" y="7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J10" x="7.62" y="-5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E10" x="7.62" y="5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E04" x="-7.62" y="5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J04" x="-7.62" y="-5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K05" x="-5.08" y="-7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K09" x="5.08" y="-7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D09" x="5.08" y="7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D05" x="-5.08" y="7.62" drill="0.8128" shape="octagon" rot="R90"/>
<text x="-3.81" y="1.905" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-3.175" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="MPGA114">
<description>&lt;b&gt;Pin Grid Array&lt;/b&gt;&lt;p&gt;
Source: MC68020UM.pdf</description>
<wire x1="-8.89" y1="-8.89" x2="-8.89" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="8.89" x2="-8.89" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="8.89" x2="8.89" y2="8.89" width="0.1524" layer="21"/>
<wire x1="8.89" y1="8.89" x2="8.89" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-8.89" x2="8.89" y2="-8.89" width="0.1524" layer="21"/>
<circle x="-15.24" y="15.24" radius="1.27" width="0.1524" layer="21"/>
<pad name="A01" x="-15.24" y="15.24" drill="0.8128" shape="octagon"/>
<pad name="A02" x="-12.7" y="15.24" drill="0.8128" shape="octagon"/>
<pad name="A03" x="-10.16" y="15.24" drill="0.8128" shape="octagon"/>
<pad name="A04" x="-7.62" y="15.24" drill="0.8128" shape="octagon"/>
<pad name="A05" x="-5.08" y="15.24" drill="0.8128" shape="octagon"/>
<pad name="A06" x="-2.54" y="15.24" drill="0.8128" shape="octagon"/>
<pad name="A07" x="0" y="15.24" drill="0.8128" shape="octagon"/>
<pad name="A08" x="2.54" y="15.24" drill="0.8128" shape="octagon"/>
<pad name="A09" x="5.08" y="15.24" drill="0.8128" shape="octagon"/>
<pad name="A10" x="7.62" y="15.24" drill="0.8128" shape="octagon"/>
<pad name="A11" x="10.16" y="15.24" drill="0.8128" shape="octagon"/>
<pad name="A12" x="12.7" y="15.24" drill="0.8128" shape="octagon"/>
<pad name="A13" x="15.24" y="15.24" drill="0.8128" shape="octagon"/>
<pad name="B13" x="15.24" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="M01" x="-15.24" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="L01" x="-15.24" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="K01" x="-15.24" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="J01" x="-15.24" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="H01" x="-15.24" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="G01" x="-15.24" y="0" drill="0.8128" shape="octagon"/>
<pad name="F01" x="-15.24" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="E01" x="-15.24" y="5.08" drill="0.8128" shape="octagon"/>
<pad name="D01" x="-15.24" y="7.62" drill="0.8128" shape="octagon"/>
<pad name="B01" x="-15.24" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="B02" x="-12.7" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="B03" x="-10.16" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="B04" x="-7.62" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="B05" x="-5.08" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="B06" x="-2.54" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="B07" x="0" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="B08" x="2.54" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="B09" x="5.08" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="B10" x="7.62" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="B11" x="10.16" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="B12" x="12.7" y="12.7" drill="0.8128" shape="octagon"/>
<pad name="D13" x="15.24" y="7.62" drill="0.8128" shape="octagon"/>
<pad name="E13" x="15.24" y="5.08" drill="0.8128" shape="octagon"/>
<pad name="F13" x="15.24" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="G13" x="15.24" y="0" drill="0.8128" shape="octagon"/>
<pad name="H13" x="15.24" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="J13" x="15.24" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="K13" x="15.24" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="L13" x="15.24" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="M13" x="15.24" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="M02" x="-12.7" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="L02" x="-12.7" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="K02" x="-12.7" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="J02" x="-12.7" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="H02" x="-12.7" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="G02" x="-12.7" y="0" drill="0.8128" shape="octagon"/>
<pad name="F02" x="-12.7" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="E02" x="-12.7" y="5.08" drill="0.8128" shape="octagon"/>
<pad name="D02" x="-12.7" y="7.62" drill="0.8128" shape="octagon"/>
<pad name="N02" x="-12.7" y="-15.24" drill="0.8128" shape="octagon"/>
<pad name="N13" x="15.24" y="-15.24" drill="0.8128" shape="octagon"/>
<pad name="N12" x="12.7" y="-15.24" drill="0.8128" shape="octagon"/>
<pad name="N11" x="10.16" y="-15.24" drill="0.8128" shape="octagon"/>
<pad name="N10" x="7.62" y="-15.24" drill="0.8128" shape="octagon"/>
<pad name="N09" x="5.08" y="-15.24" drill="0.8128" shape="octagon"/>
<pad name="N08" x="2.54" y="-15.24" drill="0.8128" shape="octagon"/>
<pad name="N07" x="0" y="-15.24" drill="0.8128" shape="octagon"/>
<pad name="N06" x="-2.54" y="-15.24" drill="0.8128" shape="octagon"/>
<pad name="N05" x="-5.08" y="-15.24" drill="0.8128" shape="octagon"/>
<pad name="N04" x="-7.62" y="-15.24" drill="0.8128" shape="octagon"/>
<pad name="N03" x="-10.16" y="-15.24" drill="0.8128" shape="octagon"/>
<pad name="C13" x="15.24" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="C01" x="-15.24" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="C12" x="12.7" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="C11" x="10.16" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="C10" x="7.62" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="C09" x="5.08" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="C08" x="2.54" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="C07" x="0" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="C06" x="-2.54" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="C05" x="-5.08" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="C04" x="-7.62" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="C03" x="-10.16" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="C02" x="-12.7" y="10.16" drill="0.8128" shape="octagon"/>
<pad name="N01" x="-15.24" y="-15.24" drill="0.8128" shape="octagon"/>
<pad name="M03" x="-10.16" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="L03" x="-10.16" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="K03" x="-10.16" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="J03" x="-10.16" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="H03" x="-10.16" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="G03" x="-10.16" y="0" drill="0.8128" shape="octagon"/>
<pad name="F03" x="-10.16" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="E03" x="-10.16" y="5.08" drill="0.8128" shape="octagon"/>
<pad name="D03" x="-10.16" y="7.62" drill="0.8128" shape="octagon"/>
<pad name="M12" x="12.7" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="L12" x="12.7" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="K12" x="12.7" y="-7.62" drill="0.8128" shape="octagon"/>
<pad name="J12" x="12.7" y="-5.08" drill="0.8128" shape="octagon"/>
<pad name="H12" x="12.7" y="-2.54" drill="0.8128" shape="octagon"/>
<pad name="G12" x="12.7" y="0" drill="0.8128" shape="octagon"/>
<pad name="F12" x="12.7" y="2.54" drill="0.8128" shape="octagon"/>
<pad name="E12" x="12.7" y="5.08" drill="0.8128" shape="octagon"/>
<pad name="D12" x="12.7" y="7.62" drill="0.8128" shape="octagon"/>
<pad name="M04" x="-7.62" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="M05" x="-5.08" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="M06" x="-2.54" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="M07" x="0" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="M08" x="2.54" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="M09" x="5.08" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="M10" x="7.62" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="M11" x="10.16" y="-12.7" drill="0.8128" shape="octagon"/>
<pad name="L11" x="10.16" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="L07" x="0" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="G11" x="10.16" y="0" drill="0.8128" shape="octagon"/>
<pad name="L04" x="-7.62" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="L05" x="-5.08" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="L06" x="-2.54" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="L08" x="2.54" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="L09" x="5.08" y="-10.16" drill="0.8128" shape="octagon"/>
<pad name="L10" x="7.62" y="-10.16" drill="0.8128" shape="octagon"/>
<text x="-15.875" y="17.78" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.62" y="-1.27" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="PGA168">
<wire x1="-20.955" y1="22.225" x2="22.225" y2="22.225" width="0.1524" layer="21"/>
<wire x1="22.225" y1="22.225" x2="22.225" y2="-22.225" width="0.1524" layer="21"/>
<wire x1="22.225" y1="-22.225" x2="-22.225" y2="-22.225" width="0.1524" layer="21"/>
<wire x1="-22.225" y1="-22.225" x2="-22.225" y2="20.955" width="0.1524" layer="21"/>
<wire x1="-22.225" y1="20.955" x2="-20.955" y2="22.225" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-13.97" x2="13.97" y2="-13.97" width="0.1524" layer="21"/>
<wire x1="13.97" y1="-13.97" x2="13.97" y2="13.97" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="13.97" x2="13.97" y2="13.97" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="13.97" x2="-13.97" y2="-13.97" width="0.1524" layer="21"/>
<pad name="A01" x="-20.32" y="20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A02" x="-17.78" y="20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A03" x="-15.24" y="20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A04" x="-12.7" y="20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A05" x="-10.16" y="20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A06" x="-7.62" y="20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A07" x="-5.08" y="20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A08" x="-2.54" y="20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A09" x="0" y="20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A10" x="2.54" y="20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A11" x="5.08" y="20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A12" x="7.62" y="20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A13" x="10.16" y="20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B13" x="10.16" y="17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P02" x="-17.78" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M01" x="-20.32" y="-7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L01" x="-20.32" y="-5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K01" x="-20.32" y="-2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J01" x="-20.32" y="0" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H01" x="-20.32" y="2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G01" x="-20.32" y="5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F01" x="-20.32" y="7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E01" x="-20.32" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D01" x="-20.32" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B01" x="-20.32" y="17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B02" x="-17.78" y="17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B03" x="-15.24" y="17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B04" x="-12.7" y="17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B05" x="-10.16" y="17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B06" x="-7.62" y="17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B07" x="-5.08" y="17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B08" x="-2.54" y="17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B09" x="0" y="17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B10" x="2.54" y="17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B11" x="5.08" y="17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B12" x="7.62" y="17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P03" x="-15.24" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M02" x="-17.78" y="-7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L02" x="-17.78" y="-5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K02" x="-17.78" y="-2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J02" x="-17.78" y="0" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H02" x="-17.78" y="2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G02" x="-17.78" y="5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F02" x="-17.78" y="7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E02" x="-17.78" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D02" x="-17.78" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A14" x="12.7" y="20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B14" x="12.7" y="17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C14" x="12.7" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N02" x="-17.78" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N03" x="-15.24" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C13" x="10.16" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C01" x="-20.32" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C12" x="7.62" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C11" x="5.08" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C10" x="2.54" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C09" x="0" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C08" x="-2.54" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C07" x="-5.08" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C06" x="-7.62" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C05" x="-10.16" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C04" x="-12.7" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C03" x="-15.24" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C02" x="-17.78" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N01" x="-20.32" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P01" x="-20.32" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M03" x="-15.24" y="-7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L03" x="-15.24" y="-5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K03" x="-15.24" y="-2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J03" x="-15.24" y="0" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H03" x="-15.24" y="2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G03" x="-15.24" y="5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F03" x="-15.24" y="7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E03" x="-15.24" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D03" x="-15.24" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="Q01" x="-20.32" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R01" x="-20.32" y="-17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S01" x="-20.32" y="-20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A15" x="15.24" y="20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A16" x="17.78" y="20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A17" x="20.32" y="20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="Q14" x="12.7" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="Q02" x="-17.78" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="Q13" x="10.16" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="Q12" x="7.62" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="Q11" x="5.08" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="Q10" x="2.54" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="Q09" x="0" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="Q08" x="-2.54" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="Q06" x="-7.62" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="Q05" x="-10.16" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="Q04" x="-12.7" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="Q03" x="-15.24" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="Q07" x="-5.08" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R14" x="12.7" y="-17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R02" x="-17.78" y="-17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R13" x="10.16" y="-17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R12" x="7.62" y="-17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R11" x="5.08" y="-17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R10" x="2.54" y="-17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R09" x="0" y="-17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R08" x="-2.54" y="-17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R06" x="-7.62" y="-17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R05" x="-10.16" y="-17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R04" x="-12.7" y="-17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R03" x="-15.24" y="-17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R07" x="-5.08" y="-17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S14" x="12.7" y="-20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S02" x="-17.78" y="-20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S13" x="10.16" y="-20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S12" x="7.62" y="-20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S11" x="5.08" y="-20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S10" x="2.54" y="-20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S09" x="0" y="-20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S08" x="-2.54" y="-20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S06" x="-7.62" y="-20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S05" x="-10.16" y="-20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S04" x="-12.7" y="-20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S03" x="-15.24" y="-20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S07" x="-5.08" y="-20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B15" x="15.24" y="17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P15" x="15.24" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C15" x="15.24" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D15" x="15.24" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E15" x="15.24" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F15" x="15.24" y="7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G15" x="15.24" y="5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H15" x="15.24" y="2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K15" x="15.24" y="-2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L15" x="15.24" y="-5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M15" x="15.24" y="-7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N15" x="15.24" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J15" x="15.24" y="0" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B16" x="17.78" y="17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P16" x="17.78" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C16" x="17.78" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D16" x="17.78" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E16" x="17.78" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F16" x="17.78" y="7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G16" x="17.78" y="5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H16" x="17.78" y="2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K16" x="17.78" y="-2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L16" x="17.78" y="-5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M16" x="17.78" y="-7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N16" x="17.78" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J16" x="17.78" y="0" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P17" x="20.32" y="-12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B17" x="20.32" y="17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N17" x="20.32" y="-10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M17" x="20.32" y="-7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L17" x="20.32" y="-5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K17" x="20.32" y="-2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J17" x="20.32" y="0" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H17" x="20.32" y="2.54" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F17" x="20.32" y="7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E17" x="20.32" y="10.16" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D17" x="20.32" y="12.7" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C17" x="20.32" y="15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G17" x="20.32" y="5.08" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="Q15" x="15.24" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="Q16" x="17.78" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="Q17" x="20.32" y="-15.24" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R15" x="15.24" y="-17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R16" x="17.78" y="-17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R17" x="20.32" y="-17.78" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S15" x="15.24" y="-20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S16" x="17.78" y="-20.32" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S17" x="20.32" y="-20.32" drill="0.8128" shape="octagon" rot="R90"/>
<text x="-5.715" y="1.27" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.62" y="-3.175" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL02">
<wire x1="-0.635" y1="-2.54" x2="0.635" y2="-2.54" width="0.254" layer="21"/>
<wire x1="0.635" y1="2.54" x2="-0.635" y2="2.54" width="0.254" layer="21"/>
<wire x1="-0.635" y1="2.54" x2="-0.635" y2="1.27" width="0.254" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0.635" y2="1.27" width="0.254" layer="21"/>
<wire x1="0.635" y1="1.27" x2="0.635" y2="2.54" width="0.254" layer="21"/>
<wire x1="0.635" y1="-2.54" x2="0.635" y2="-1.27" width="0.254" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="-0.635" y2="-1.27" width="0.254" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="0.635" y2="1.27" width="0.254" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-0.635" y2="-2.54" width="0.254" layer="21"/>
<pad name="1" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-1.143" y="-2.54" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="2.54" y="-2.54" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
</package>
<package name="PGA68-N">
<wire x1="8.89" y1="8.89" x2="-8.89" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-8.89" x2="-8.89" y2="8.89" width="0.1524" layer="21"/>
<pad name="68" x="-10.16" y="12.7" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="64" x="-5.08" y="12.7" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="62" x="-2.54" y="12.7" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="60" x="0" y="12.7" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="58" x="2.54" y="12.7" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="56" x="5.08" y="12.7" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="54" x="7.62" y="12.7" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="52" x="10.16" y="12.7" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="51" x="12.7" y="10.16" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="49" x="12.7" y="7.62" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="47" x="12.7" y="5.08" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="45" x="12.7" y="2.54" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="43" x="12.7" y="0" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="41" x="12.7" y="-2.54" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="39" x="12.7" y="-5.08" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="37" x="12.7" y="-7.62" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="35" x="12.7" y="-10.16" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="34" x="10.16" y="-12.7" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="32" x="7.62" y="-12.7" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="30" x="5.08" y="-12.7" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="28" x="2.54" y="-12.7" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="26" x="0" y="-12.7" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="24" x="-2.54" y="-12.7" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="22" x="-5.08" y="-12.7" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="20" x="-7.62" y="-12.7" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="18" x="-10.16" y="-12.7" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="17" x="-12.7" y="-10.16" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="15" x="-12.7" y="-7.62" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="13" x="-12.7" y="-5.08" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="11" x="-12.7" y="-2.54" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="9" x="-12.7" y="0" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="7" x="-12.7" y="2.54" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="5" x="-12.7" y="5.08" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="3" x="-12.7" y="7.62" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="1" x="-12.7" y="10.16" drill="0.8128" shape="square" rot="R270"/>
<pad name="67" x="-7.62" y="10.16" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="65" x="-5.08" y="10.16" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="63" x="-2.54" y="10.16" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="61" x="0" y="10.16" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="59" x="2.54" y="10.16" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="57" x="5.08" y="10.16" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="55" x="7.62" y="10.16" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="53" x="10.16" y="10.16" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="50" x="10.16" y="7.62" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="48" x="10.16" y="5.08" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="46" x="10.16" y="2.54" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="44" x="10.16" y="0" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="42" x="10.16" y="-2.54" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="40" x="10.16" y="-5.08" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="38" x="10.16" y="-7.62" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="36" x="10.16" y="-10.16" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="33" x="7.62" y="-10.16" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="31" x="5.08" y="-10.16" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="29" x="2.54" y="-10.16" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="27" x="0" y="-10.16" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="25" x="-2.54" y="-10.16" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="23" x="-5.08" y="-10.16" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="21" x="-7.62" y="-10.16" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="19" x="-10.16" y="-10.16" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="16" x="-10.16" y="-7.62" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="14" x="-10.16" y="-5.08" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="12" x="-10.16" y="-2.54" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="10" x="-10.16" y="0" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="8" x="-10.16" y="2.54" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="6" x="-10.16" y="5.08" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="4" x="-10.16" y="7.62" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="2" x="-10.16" y="10.16" drill="0.8128" shape="octagon" rot="R270"/>
<pad name="66" x="-7.62" y="12.7" drill="0.8128" shape="octagon" rot="R270"/>
<text x="-3.81" y="1.27" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.35" y="-3.175" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="MPGA-128">
<wire x1="-1.27" y1="7.62" x2="5.08" y2="7.62" width="0.1524" layer="21"/>
<wire x1="5.08" y1="7.62" x2="5.08" y2="3.81" width="0.1524" layer="21"/>
<wire x1="5.08" y1="3.81" x2="8.89" y2="3.81" width="0.1524" layer="21"/>
<wire x1="8.89" y1="3.81" x2="8.89" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-6.35" x2="-8.89" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-6.35" x2="-8.89" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="3.81" x2="-8.89" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="3.81" x2="-1.27" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="3.81" x2="-1.27" y2="7.62" width="0.1524" layer="21"/>
<pad name="K06" x="-2.54" y="-7.62" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D06" x="-2.54" y="7.62" drill="0.8128" shape="octagon" rot="R90"/>
<text x="-6.35" y="0" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.35" y="-3.81" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="PGA132">
<wire x1="-17.145" y1="18.415" x2="18.415" y2="18.415" width="0.1524" layer="21"/>
<wire x1="18.415" y1="18.415" x2="18.415" y2="-18.415" width="0.1524" layer="21"/>
<wire x1="18.415" y1="-18.415" x2="-18.415" y2="-18.415" width="0.1524" layer="21"/>
<wire x1="-18.415" y1="-18.415" x2="-18.415" y2="17.145" width="0.1524" layer="21"/>
<wire x1="-18.415" y1="17.145" x2="-17.145" y2="18.415" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-10.16" x2="10.16" y2="10.16" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-10.16" x2="-10.16" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="10.16" x2="-10.16" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="6.35" x2="-10.16" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="10.16" y1="10.16" x2="-6.35" y2="10.16" width="0.1524" layer="21"/>
<pad name="A01" x="-16.51" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A02" x="-13.97" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A03" x="-11.43" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A04" x="-8.89" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A05" x="-6.35" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A06" x="-3.81" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A07" x="-1.27" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A08" x="1.27" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A09" x="3.81" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A10" x="6.35" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A11" x="8.89" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A12" x="11.43" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A13" x="13.97" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B13" x="13.97" y="13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D14" x="16.51" y="8.89" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E14" x="16.51" y="6.35" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F14" x="16.51" y="3.81" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G14" x="16.51" y="1.27" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H14" x="16.51" y="-1.27" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J14" x="16.51" y="-3.81" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K14" x="16.51" y="-6.35" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L14" x="16.51" y="-8.89" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M14" x="16.51" y="-11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P14" x="16.51" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P02" x="-13.97" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M01" x="-16.51" y="-11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L01" x="-16.51" y="-8.89" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K01" x="-16.51" y="-6.35" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J01" x="-16.51" y="-3.81" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H01" x="-16.51" y="-1.27" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G01" x="-16.51" y="1.27" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F01" x="-16.51" y="3.81" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E01" x="-16.51" y="6.35" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D01" x="-16.51" y="8.89" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B01" x="-16.51" y="13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B02" x="-13.97" y="13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B03" x="-11.43" y="13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B04" x="-8.89" y="13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B05" x="-6.35" y="13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B06" x="-3.81" y="13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B07" x="-1.27" y="13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B08" x="1.27" y="13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B09" x="3.81" y="13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B10" x="6.35" y="13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B11" x="8.89" y="13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B12" x="11.43" y="13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D13" x="13.97" y="8.89" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E13" x="13.97" y="6.35" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F13" x="13.97" y="3.81" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G13" x="13.97" y="1.27" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H13" x="13.97" y="-1.27" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J13" x="13.97" y="-3.81" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K13" x="13.97" y="-6.35" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L13" x="13.97" y="-8.89" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M13" x="13.97" y="-11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P13" x="13.97" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P12" x="11.43" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P11" x="8.89" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P10" x="6.35" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P09" x="3.81" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P08" x="1.27" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P07" x="-1.27" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P06" x="-3.81" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P05" x="-6.35" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P04" x="-8.89" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P03" x="-11.43" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M02" x="-13.97" y="-11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L02" x="-13.97" y="-8.89" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K02" x="-13.97" y="-6.35" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J02" x="-13.97" y="-3.81" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H02" x="-13.97" y="-1.27" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G02" x="-13.97" y="1.27" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F02" x="-13.97" y="3.81" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E02" x="-13.97" y="6.35" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D02" x="-13.97" y="8.89" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A14" x="16.51" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B14" x="16.51" y="13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C14" x="16.51" y="11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N14" x="16.51" y="-13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N02" x="-13.97" y="-13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N13" x="13.97" y="-13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N12" x="11.43" y="-13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N11" x="8.89" y="-13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N10" x="6.35" y="-13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N09" x="3.81" y="-13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N08" x="1.27" y="-13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N07" x="-1.27" y="-13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N06" x="-3.81" y="-13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N05" x="-6.35" y="-13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N04" x="-8.89" y="-13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N03" x="-11.43" y="-13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C13" x="13.97" y="11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C01" x="-16.51" y="11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C12" x="11.43" y="11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C11" x="8.89" y="11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C10" x="6.35" y="11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C09" x="3.81" y="11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C08" x="1.27" y="11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C07" x="-1.27" y="11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C06" x="-3.81" y="11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C05" x="-6.35" y="11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C04" x="-8.89" y="11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C03" x="-11.43" y="11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C02" x="-13.97" y="11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N01" x="-16.51" y="-13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P01" x="-16.51" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M03" x="-11.43" y="-11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L03" x="-11.43" y="-8.89" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K03" x="-11.43" y="-6.35" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J03" x="-11.43" y="-3.81" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H03" x="-11.43" y="-1.27" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G03" x="-11.43" y="1.27" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F03" x="-11.43" y="3.81" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E03" x="-11.43" y="6.35" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D03" x="-11.43" y="8.89" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M12" x="11.43" y="-11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L12" x="11.43" y="-8.89" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K12" x="11.43" y="-6.35" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J12" x="11.43" y="-3.81" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H12" x="11.43" y="-1.27" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G12" x="11.43" y="1.27" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F12" x="11.43" y="3.81" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E12" x="11.43" y="6.35" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D12" x="11.43" y="8.89" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M04" x="-8.89" y="-11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M05" x="-6.35" y="-11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M06" x="-3.81" y="-11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M07" x="-1.27" y="-11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M08" x="1.27" y="-11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M09" x="3.81" y="-11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M10" x="6.35" y="-11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M11" x="8.89" y="-11.43" drill="0.8128" shape="octagon" rot="R90"/>
</package>
<package name="MPGA-179">
<wire x1="-22.225" y1="22.86" x2="22.86" y2="22.86" width="0.1524" layer="21"/>
<wire x1="22.86" y1="22.86" x2="22.86" y2="-22.86" width="0.1524" layer="21"/>
<wire x1="22.86" y1="-22.86" x2="-22.86" y2="-22.86" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-22.86" x2="-22.86" y2="22.225" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="22.225" x2="-22.225" y2="22.86" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-15.24" x2="-15.24" y2="-15.24" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-15.24" x2="15.24" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="15.24" x2="15.24" y2="15.24" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="15.24" x2="-15.24" y2="11.43" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="11.43" x2="-15.24" y2="-15.24" width="0.1524" layer="21"/>
<pad name="A01" x="-21.59" y="21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A02" x="-19.05" y="21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A03" x="-16.51" y="21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A04" x="-13.97" y="21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A05" x="-11.43" y="21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A06" x="-8.89" y="21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A07" x="-6.35" y="21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A08" x="-3.81" y="21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A09" x="-1.27" y="21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A10" x="1.27" y="21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A11" x="3.81" y="21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A12" x="6.35" y="21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A13" x="8.89" y="21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B13" x="8.89" y="19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M01" x="-21.59" y="-6.35" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L01" x="-21.59" y="-3.81" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K01" x="-21.59" y="-1.27" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J01" x="-21.59" y="1.27" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H01" x="-21.59" y="3.81" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G01" x="-21.59" y="6.35" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F01" x="-21.59" y="8.89" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E01" x="-21.59" y="11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D01" x="-21.59" y="13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B01" x="-21.59" y="19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B02" x="-19.05" y="19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B03" x="-16.51" y="19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B04" x="-13.97" y="19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B05" x="-11.43" y="19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B06" x="-8.89" y="19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B07" x="-6.35" y="19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B08" x="-3.81" y="19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B09" x="-1.27" y="19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B10" x="1.27" y="19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B11" x="3.81" y="19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B12" x="6.35" y="19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R13" x="8.89" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S13" x="8.89" y="-19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M02" x="-19.05" y="-6.35" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L02" x="-19.05" y="-3.81" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K02" x="-19.05" y="-1.27" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J02" x="-19.05" y="1.27" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H02" x="-19.05" y="3.81" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G02" x="-19.05" y="6.35" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F02" x="-19.05" y="8.89" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E02" x="-19.05" y="11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D02" x="-19.05" y="13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N02" x="-19.05" y="-8.89" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="T13" x="8.89" y="-21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="T12" x="6.35" y="-21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="T11" x="3.81" y="-21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="T10" x="1.27" y="-21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="T09" x="-1.27" y="-21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="T08" x="-3.81" y="-21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="T07" x="-6.35" y="-21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="T06" x="-8.89" y="-21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="T05" x="-11.43" y="-21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="T04" x="-13.97" y="-21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N03" x="-16.51" y="-8.89" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C13" x="8.89" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C01" x="-21.59" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C12" x="6.35" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C11" x="3.81" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C10" x="1.27" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C09" x="-1.27" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C08" x="-3.81" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C07" x="-6.35" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C06" x="-8.89" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C05" x="-11.43" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C04" x="-13.97" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C03" x="-16.51" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C02" x="-19.05" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N01" x="-21.59" y="-8.89" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M03" x="-16.51" y="-6.35" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L03" x="-16.51" y="-3.81" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K03" x="-16.51" y="-1.27" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J03" x="-16.51" y="1.27" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H03" x="-16.51" y="3.81" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G03" x="-16.51" y="6.35" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F03" x="-16.51" y="8.89" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E03" x="-16.51" y="11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D03" x="-16.51" y="13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S12" x="6.35" y="-19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R12" x="6.35" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S04" x="-13.97" y="-19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S05" x="-11.43" y="-19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S06" x="-8.89" y="-19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S07" x="-6.35" y="-19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S08" x="-3.81" y="-19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S09" x="-1.27" y="-19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S10" x="1.27" y="-19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S11" x="3.81" y="-19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R11" x="3.81" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R10" x="1.27" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R09" x="-1.27" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R08" x="-3.81" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R07" x="-6.35" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R06" x="-8.89" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R05" x="-11.43" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R04" x="-13.97" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P01" x="-21.59" y="-11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="Q01" x="-21.59" y="-13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R01" x="-21.59" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S01" x="-21.59" y="-19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A14" x="11.43" y="21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A15" x="13.97" y="21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A16" x="16.51" y="21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A17" x="19.05" y="21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P02" x="-19.05" y="-11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P03" x="-16.51" y="-11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="Q02" x="-19.05" y="-13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="Q03" x="-16.51" y="-13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R03" x="-16.51" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S03" x="-16.51" y="-19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="T03" x="-16.51" y="-21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="T02" x="-19.05" y="-21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S02" x="-19.05" y="-19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R02" x="-19.05" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B14" x="11.43" y="19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C14" x="11.43" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B15" x="13.97" y="19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C15" x="13.97" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B16" x="16.51" y="19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C16" x="16.51" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B17" x="19.05" y="19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C17" x="19.05" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="B18" x="21.59" y="19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="C18" x="21.59" y="16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D16" x="16.51" y="13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D17" x="19.05" y="13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="D18" x="21.59" y="13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E16" x="16.51" y="11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E17" x="19.05" y="11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="E18" x="21.59" y="11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F16" x="16.51" y="8.89" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F17" x="19.05" y="8.89" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="F18" x="21.59" y="8.89" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G16" x="16.51" y="6.35" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H16" x="16.51" y="3.81" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J16" x="16.51" y="1.27" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K16" x="16.51" y="-1.27" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L16" x="16.51" y="-3.81" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M16" x="16.51" y="-6.35" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N16" x="16.51" y="-8.89" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P16" x="16.51" y="-11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="Q16" x="16.51" y="-13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R16" x="16.51" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S16" x="16.51" y="-19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="T16" x="16.51" y="-21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="T17" x="19.05" y="-21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="T18" x="21.59" y="-21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S17" x="19.05" y="-19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R17" x="19.05" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="Q17" x="19.05" y="-13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P17" x="19.05" y="-11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N17" x="19.05" y="-8.89" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M17" x="19.05" y="-6.35" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L17" x="19.05" y="-3.81" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K17" x="19.05" y="-1.27" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J17" x="19.05" y="1.27" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H17" x="19.05" y="3.81" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G17" x="19.05" y="6.35" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="G18" x="21.59" y="6.35" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="H18" x="21.59" y="3.81" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="J18" x="21.59" y="1.27" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="K18" x="21.59" y="-1.27" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="L18" x="21.59" y="-3.81" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="M18" x="21.59" y="-6.35" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="N18" x="21.59" y="-8.89" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="P18" x="21.59" y="-11.43" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="Q18" x="21.59" y="-13.97" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R18" x="21.59" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S18" x="21.59" y="-19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R14" x="11.43" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="R15" x="13.97" y="-16.51" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S15" x="13.97" y="-19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="T15" x="13.97" y="-21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="T14" x="11.43" y="-21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="S14" x="11.43" y="-19.05" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="T01" x="-21.59" y="-21.59" drill="0.8128" shape="octagon" rot="R90"/>
<pad name="A18" x="21.59" y="21.59" drill="0.8128" shape="octagon" rot="R90"/>
<text x="-7.62" y="-4.445" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-3.81" y="2.54" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="DIL28-4">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="17.78" y1="4.191" x2="-17.78" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-4.191" x2="17.78" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="17.78" y1="4.191" x2="17.78" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="4.191" x2="-17.78" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-4.191" x2="-17.78" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="1.016" x2="-17.78" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-16.51" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-13.97" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="1.27" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-11.43" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-8.89" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-3.81" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-6.35" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="3.81" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="8.89" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="11.43" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="16.51" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="16.51" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="11.43" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="8.89" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="6.35" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="3.81" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="1.27" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-1.27" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-3.81" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-6.35" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="-8.89" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="-11.43" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="-13.97" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="-16.51" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<text x="-18.161" y="-4.191" size="1.778" layer="25" rot="R90">&gt;NAME</text>
<text x="-13.335" y="-1.016" size="1.778" layer="27">&gt;VALUE</text>
</package>
<package name="DIL22">
<wire x1="13.97" y1="4.191" x2="-13.97" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-4.191" x2="13.97" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="13.97" y1="4.191" x2="13.97" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="4.191" x2="-13.97" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-4.191" x2="-13.97" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="1.016" x2="-13.97" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-12.7" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-10.16" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="2.54" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="5.08" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-7.62" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-5.08" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="0" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-2.54" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="7.62" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="10.16" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="10.16" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="7.62" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="5.08" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="2.54" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="0" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="-2.54" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-5.08" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-7.62" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="-10.16" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-12.7" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="12.7" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="12.7" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<text x="-14.224" y="-4.191" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="-9.144" y="-0.508" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="SOCKET-06">
<description>&lt;b&gt;Dual In Line Socket&lt;/b&gt;</description>
<wire x1="3.81" y1="5.08" x2="-3.81" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-5.08" x2="3.81" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="3.81" y1="5.08" x2="3.81" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="5.08" x2="-3.81" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-5.08" x2="-3.81" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.016" x2="-3.81" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<wire x1="-3.81" y1="2.54" x2="3.81" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="2.54" x2="-3.81" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.81" y1="2.54" x2="3.81" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-2.54" x2="3.81" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-2.54" x2="-3.81" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-2.54" x2="3.81" y2="-5.08" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-2.413" y="-0.508" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.191" y="-2.54" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
</package>
<package name="SOCKET-08">
<wire x1="5.08" y1="5.08" x2="-5.08" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-5.08" x2="5.08" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="5.08" y1="5.08" x2="5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="5.08" x2="-5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-5.08" x2="-5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.016" x2="-5.08" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<wire x1="-5.08" y1="2.54" x2="5.08" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.54" x2="-5.08" y2="1.016" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.54" x2="5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.54" x2="5.08" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.54" x2="-5.08" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-2.54" x2="5.08" y2="-5.08" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-3.048" y="-0.508" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-5.461" y="-2.667" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
</package>
<package name="SOCKET-14">
<wire x1="8.89" y1="5.08" x2="-8.89" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-5.08" x2="8.89" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="8.89" y1="5.08" x2="8.89" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="5.08" x2="-8.89" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-5.08" x2="-8.89" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="1.016" x2="-8.89" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<wire x1="-8.89" y1="2.54" x2="8.89" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.54" x2="-8.89" y2="1.016" width="0.1524" layer="21"/>
<wire x1="8.89" y1="2.54" x2="8.89" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.54" x2="8.89" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.54" x2="-8.89" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-2.54" x2="8.89" y2="-5.08" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-5.715" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-9.144" y="-3.937" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
</package>
<package name="SOCKET-16">
<wire x1="10.16" y1="5.08" x2="-10.16" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-5.08" x2="10.16" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="10.16" y1="5.08" x2="10.16" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="5.08" x2="-10.16" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-5.08" x2="-10.16" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="1.016" x2="-10.16" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<wire x1="-10.16" y1="2.54" x2="10.16" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="2.54" x2="-10.16" y2="1.016" width="0.1524" layer="21"/>
<wire x1="10.16" y1="2.54" x2="10.16" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-2.54" x2="10.16" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-2.54" x2="-10.16" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-2.54" x2="10.16" y2="-5.08" width="0.1524" layer="21"/>
<pad name="1" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-6.35" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-10.414" y="-4.953" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
</package>
<package name="SOCKET-18">
<wire x1="11.43" y1="5.08" x2="-11.43" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.08" x2="11.43" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="11.43" y1="5.08" x2="11.43" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="5.08" x2="-11.43" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-5.08" x2="-11.43" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="1.016" x2="-11.43" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<wire x1="-11.43" y1="2.54" x2="11.43" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="2.54" x2="-11.43" y2="1.016" width="0.1524" layer="21"/>
<wire x1="11.43" y1="2.54" x2="11.43" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-2.54" x2="11.43" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-11.43" y1="-2.54" x2="-11.43" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="11.43" y1="-2.54" x2="11.43" y2="-5.08" width="0.1524" layer="21"/>
<pad name="1" x="-10.16" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="10.16" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="10.16" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="-10.16" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-8.255" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-11.684" y="-4.953" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
</package>
<package name="SOCKET-20">
<wire x1="12.7" y1="5.08" x2="-12.7" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-5.08" x2="12.7" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="12.7" y1="5.08" x2="12.7" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="5.08" x2="-12.7" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-5.08" x2="-12.7" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="1.016" x2="-12.7" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<wire x1="-12.7" y1="2.54" x2="12.7" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="2.54" x2="-12.7" y2="1.016" width="0.1524" layer="21"/>
<wire x1="12.7" y1="2.54" x2="12.7" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-2.54" x2="12.7" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-2.54" x2="-12.7" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="12.7" y1="-2.54" x2="12.7" y2="-5.08" width="0.1524" layer="21"/>
<pad name="1" x="-11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-6.477" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-12.954" y="-4.953" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
</package>
<package name="SOCKET-22">
<wire x1="13.97" y1="6.35" x2="-13.97" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-6.35" x2="13.97" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="13.97" y1="6.35" x2="13.97" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="6.35" x2="-13.97" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-6.35" x2="-13.97" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="3.81" x2="13.97" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="3.81" x2="-13.97" y2="1.016" width="0.1524" layer="21"/>
<wire x1="13.97" y1="3.81" x2="13.97" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-3.81" x2="13.97" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-3.81" x2="-13.97" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="13.97" y1="-3.81" x2="13.97" y2="-6.35" width="0.1524" layer="21"/>
<text x="-9.144" y="-0.508" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-14.224" y="-5.842" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
</package>
<package name="SOCKET-24-4">
<wire x1="15.24" y1="6.35" x2="-15.24" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-6.35" x2="15.24" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="15.24" y1="6.35" x2="15.24" y2="3.81" width="0.1524" layer="21"/>
<wire x1="15.24" y1="3.81" x2="15.24" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-3.81" x2="15.24" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="6.35" x2="-15.24" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="3.81" x2="-15.24" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-6.35" x2="-15.24" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-3.81" x2="-15.24" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="1.016" x2="-15.24" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<wire x1="-15.24" y1="-3.81" x2="15.24" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="15.24" y1="3.81" x2="-15.24" y2="3.81" width="0.1524" layer="21"/>
<pad name="1" x="-13.97" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-11.43" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-3.81" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-1.27" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-8.89" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-6.35" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="1.27" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="3.81" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="6.35" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="8.89" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="13.97" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="11.43" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="8.89" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="6.35" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="3.81" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="1.27" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-1.27" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-3.81" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="-6.35" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-8.89" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-11.43" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-13.97" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<text x="-9.525" y="-0.508" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-15.494" y="-5.969" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
</package>
<package name="SOCKET-24-6">
<wire x1="15.24" y1="8.89" x2="-15.24" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-8.89" x2="15.24" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="15.24" y1="8.89" x2="15.24" y2="6.35" width="0.1524" layer="21"/>
<wire x1="15.24" y1="6.35" x2="15.24" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-6.35" x2="15.24" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="8.89" x2="-15.24" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="6.35" x2="-15.24" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-8.89" x2="-15.24" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-6.35" x2="-15.24" y2="-1.016" width="0.1524" layer="21"/>
<pad name="1" x="-13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="-6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<text x="-9.906" y="-0.508" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-15.621" y="-7.112" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
</package>
<package name="SOCKET-28-6">
<wire x1="17.78" y1="8.89" x2="-17.78" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.89" x2="17.78" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="17.78" y1="8.89" x2="17.78" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="8.89" x2="-17.78" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-8.89" x2="-17.78" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="6.35" x2="17.78" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="6.35" x2="-17.78" y2="1.016" width="0.1524" layer="21"/>
<wire x1="17.78" y1="6.35" x2="17.78" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-6.35" x2="17.78" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-6.35" x2="-17.78" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="17.78" y1="-6.35" x2="17.78" y2="-8.89" width="0.1524" layer="21"/>
<pad name="1" x="-16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="-8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="-11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="-13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="-16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<text x="-8.255" y="-0.508" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-18.034" y="-8.382" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
</package>
<package name="SOCKET-32">
<wire x1="20.32" y1="8.89" x2="-20.32" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-8.89" x2="20.32" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="20.32" y1="8.89" x2="20.32" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="8.89" x2="-20.32" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-8.89" x2="-20.32" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="1.016" x2="-20.32" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<wire x1="-20.32" y1="6.35" x2="20.32" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="6.35" x2="-20.32" y2="1.016" width="0.1524" layer="21"/>
<wire x1="20.32" y1="6.35" x2="20.32" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-6.35" x2="20.32" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-20.32" y1="-6.35" x2="-20.32" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-6.35" x2="20.32" y2="-8.89" width="0.1524" layer="21"/>
<pad name="1" x="-19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="-1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="-3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="-6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="-8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="29" x="-11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="30" x="-13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="31" x="-16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="32" x="-19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<text x="-9.144" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-20.574" y="-8.636" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
</package>
<package name="SOCKET-36">
<wire x1="22.86" y1="8.89" x2="-22.86" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-8.89" x2="22.86" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="22.86" y1="8.89" x2="22.86" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="8.89" x2="-22.86" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-8.89" x2="-22.86" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="1.016" x2="-22.86" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<wire x1="-22.86" y1="6.35" x2="22.86" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="6.35" x2="-22.86" y2="1.016" width="0.1524" layer="21"/>
<wire x1="22.86" y1="6.35" x2="22.86" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-6.35" x2="22.86" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-6.35" x2="-22.86" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="22.86" y1="-6.35" x2="22.86" y2="-8.89" width="0.1524" layer="21"/>
<pad name="1" x="-21.59" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="-1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="21.59" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="21.59" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="-1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="29" x="-3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="30" x="-6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="31" x="-8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="32" x="-11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="33" x="-13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="34" x="-16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="35" x="-19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="36" x="-21.59" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<text x="-7.493" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-23.241" y="-7.747" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
</package>
<package name="SOCKET-40">
<wire x1="25.4" y1="8.89" x2="-25.4" y2="8.89" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-8.89" x2="25.4" y2="-8.89" width="0.1524" layer="21"/>
<wire x1="25.4" y1="8.89" x2="25.4" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="8.89" x2="-25.4" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-8.89" x2="-25.4" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="1.016" x2="-25.4" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<wire x1="-25.4" y1="6.35" x2="25.4" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="6.35" x2="-25.4" y2="1.016" width="0.1524" layer="21"/>
<wire x1="25.4" y1="6.35" x2="25.4" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-6.35" x2="25.4" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="-25.4" y1="-6.35" x2="-25.4" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="25.4" y1="-6.35" x2="25.4" y2="-8.89" width="0.1524" layer="21"/>
<pad name="1" x="-24.13" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-21.59" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="-3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="-1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="21.59" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="24.13" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="24.13" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="21.59" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="29" x="3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="30" x="1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="31" x="-1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="32" x="-3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="33" x="-6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="34" x="-8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="35" x="-11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="36" x="-13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="37" x="-16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="38" x="-19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="39" x="-21.59" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="40" x="-24.13" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<text x="-9.525" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-25.908" y="-8.255" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
</package>
<package name="DIL36">
<wire x1="22.86" y1="6.731" x2="-22.86" y2="6.731" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-6.731" x2="22.86" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="22.86" y1="6.731" x2="22.86" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="6.731" x2="-22.86" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-6.731" x2="-22.86" y2="-1.016" width="0.1524" layer="21"/>
<text x="-23.368" y="-6.604" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-18.034" y="-0.889" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SOJ4-36">
<description>&lt;b&gt;Special Small Outline Package&lt;/b&gt;</description>
<wire x1="22.86" y1="4.191" x2="-22.86" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-4.191" x2="22.86" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="22.86" y1="4.191" x2="22.86" y2="-4.191" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="4.191" x2="-22.86" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-22.86" y1="-4.191" x2="-22.86" y2="-1.016" width="0.1524" layer="21"/>
<pad name="1" x="-21.59" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-19.05" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-6.35" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-16.51" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-13.97" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-8.89" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-11.43" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="-1.27" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="1.27" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="3.81" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="6.35" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="8.89" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="11.43" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="13.97" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="16.51" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="19.05" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="21.59" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="21.59" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="19.05" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="16.51" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="13.97" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="11.43" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="8.89" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="6.35" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="3.81" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="1.27" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="-1.27" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="29" x="-3.81" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="30" x="-6.35" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="31" x="-8.89" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="32" x="-11.43" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="33" x="-13.97" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="34" x="-16.51" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="35" x="-19.05" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="36" x="-21.59" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<text x="-8.89" y="0.635" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-8.89" y="-2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SOCKET-28-3">
<description>&lt;b&gt;Dual In Line Socket Small&lt;/b&gt;</description>
<wire x1="17.78" y1="2.921" x2="-17.78" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-2.921" x2="17.78" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="17.78" y1="2.921" x2="17.78" y2="2.54" width="0.1524" layer="21"/>
<wire x1="17.78" y1="2.54" x2="17.78" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="17.78" y1="-2.54" x2="17.78" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="2.921" x2="-17.78" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="2.54" x2="-17.78" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-2.921" x2="-17.78" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-2.54" x2="-17.78" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="17.78" y1="5.08" x2="-17.78" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="5.08" x2="-17.78" y2="2.54" width="0.1524" layer="21"/>
<wire x1="17.78" y1="5.08" x2="17.78" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-5.08" x2="17.78" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="17.78" y1="-5.08" x2="17.78" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-17.78" y1="-5.08" x2="-17.78" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="-16.51" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="16.51" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="16.51" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="-11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="-13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="-16.51" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-18.034" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-8.509" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SOCKET-22S">
<wire x1="13.97" y1="2.921" x2="-13.97" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-2.921" x2="13.97" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="13.97" y1="2.921" x2="13.97" y2="2.54" width="0.1524" layer="21"/>
<wire x1="13.97" y1="2.54" x2="13.97" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="13.97" y1="-2.54" x2="13.97" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="2.921" x2="-13.97" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="2.54" x2="-13.97" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-2.921" x2="-13.97" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-2.54" x2="-13.97" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="13.97" y1="5.08" x2="-13.97" y2="5.08" width="0.1524" layer="21"/>
<wire x1="13.97" y1="5.08" x2="13.97" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="5.08" x2="-13.97" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-5.08" x2="13.97" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-5.08" x2="-13.97" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="13.97" y1="-5.08" x2="13.97" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="-12.7" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-10.16" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="10.16" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="12.7" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="12.7" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="10.16" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="-10.16" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-12.7" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-14.224" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
</package>
<package name="SOCKET-24S">
<wire x1="15.24" y1="2.921" x2="-15.24" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-2.921" x2="15.24" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="15.24" y1="2.921" x2="15.24" y2="2.54" width="0.1524" layer="21"/>
<wire x1="15.24" y1="2.54" x2="15.24" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-2.54" x2="15.24" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="2.921" x2="-15.24" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="2.54" x2="-15.24" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-2.921" x2="-15.24" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-2.54" x2="-15.24" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="15.24" y1="5.08" x2="-15.24" y2="5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="5.08" x2="15.24" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="5.08" x2="-15.24" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-5.08" x2="15.24" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="-15.24" y1="-5.08" x2="-15.24" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-5.08" x2="15.24" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="-13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-15.494" y="-3.048" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-9.398" y="-0.762" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL24-6">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt; 0.6 inch</description>
<wire x1="-15.113" y1="-1.27" x2="-15.113" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="1.27" x2="-15.113" y2="-1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="15.113" y1="-6.604" x2="15.113" y2="6.604" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="6.604" x2="-15.113" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="6.604" x2="15.113" y2="6.604" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-6.604" x2="15.113" y2="-6.604" width="0.1524" layer="21"/>
<text x="-15.621" y="-6.35" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-12.065" y="-0.889" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL28-6">
<wire x1="-17.653" y1="-1.27" x2="-17.653" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="1.27" x2="-17.653" y2="-1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="17.653" y1="-6.604" x2="17.653" y2="6.604" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="6.604" x2="-17.653" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="6.604" x2="17.653" y2="6.604" width="0.1524" layer="21"/>
<wire x1="-17.653" y1="-6.604" x2="17.653" y2="-6.604" width="0.1524" layer="21"/>
<text x="-17.78" y="-6.35" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-14.605" y="-0.9398" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL24-3">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt; 0.3 inch</description>
<wire x1="-14.986" y1="-0.635" x2="-14.986" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-14.986" y1="0.635" x2="-14.986" y2="-0.635" width="0.1524" layer="21" curve="-180"/>
<wire x1="14.986" y1="-2.794" x2="14.986" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-14.986" y1="-2.794" x2="14.986" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-14.986" y1="2.794" x2="14.986" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-14.986" y1="2.794" x2="-14.986" y2="0.635" width="0.1524" layer="21"/>
<text x="-15.2908" y="-2.667" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-13.462" y="-0.889" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL22-3">
<wire x1="-14.605" y1="-0.635" x2="-14.605" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="0.635" x2="-14.605" y2="-0.635" width="0.1524" layer="21" curve="-180"/>
<wire x1="14.605" y1="-2.794" x2="14.605" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="-2.794" x2="14.605" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="2.794" x2="-14.605" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-14.605" y1="2.794" x2="14.605" y2="2.794" width="0.1524" layer="21"/>
<text x="-14.9098" y="-2.667" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-10.795" y="-0.889" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL22-4">
<description>&lt;b&gt;Dual In Line&lt;/b&gt; 0.4 inch</description>
<wire x1="-14.224" y1="-0.635" x2="-14.224" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-14.224" y1="0.635" x2="-14.224" y2="-0.635" width="0.1524" layer="21" curve="-180"/>
<wire x1="14.224" y1="-4.064" x2="14.224" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-14.224" y1="-4.064" x2="14.224" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-14.224" y1="4.064" x2="-14.224" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-14.224" y1="4.064" x2="14.224" y2="4.064" width="0.1524" layer="21"/>
<text x="-14.5288" y="-3.937" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-10.287" y="-0.9652" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL24-4">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt; 0.4 inch</description>
<wire x1="-15.367" y1="-0.635" x2="-15.367" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-15.367" y1="0.635" x2="-15.367" y2="-0.635" width="0.1524" layer="21" curve="-180"/>
<wire x1="15.367" y1="-4.064" x2="15.367" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-15.367" y1="-4.064" x2="15.367" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-15.367" y1="4.064" x2="-15.367" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-15.367" y1="4.064" x2="15.367" y2="4.064" width="0.1524" layer="21"/>
<text x="-15.6464" y="-3.81" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-12.7" y="-0.8382" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL24-9">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt; 0.9 inch</description>
<wire x1="-16.129" y1="-1.27" x2="-16.129" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="1.27" x2="-16.129" y2="-1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="16.129" y1="-10.414" x2="16.129" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="10.414" x2="-16.129" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="10.414" x2="16.129" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.414" x2="16.129" y2="-10.414" width="0.1524" layer="21"/>
<pad name="1" x="-13.97" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-11.43" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-8.89" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-6.35" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-3.81" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-1.27" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="1.27" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="3.81" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="6.35" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="8.89" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="13.97" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="11.43" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="8.89" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="6.35" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="3.81" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="1.27" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-1.27" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-3.81" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="-6.35" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-8.89" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-11.43" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-13.97" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<text x="-16.51" y="-9.906" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-11.43" y="-0.635" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ZIP24">
<description>&lt;b&gt;Single In Line Socket&lt;/b&gt;</description>
<wire x1="-14.859" y1="1.397" x2="-15.621" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-15.621" y1="0.635" x2="-15.621" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-15.621" y1="-0.635" x2="-14.859" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="15.621" y1="-0.635" x2="15.621" y2="0.635" width="0.1524" layer="21"/>
<wire x1="15.621" y1="0.635" x2="14.859" y2="1.397" width="0.1524" layer="51"/>
<wire x1="15.621" y1="0.635" x2="-13.97" y2="0.635" width="0.1524" layer="51"/>
<wire x1="15.621" y1="-0.635" x2="-13.97" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-13.97" y1="-1.397" x2="-13.97" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-13.97" y1="0.635" x2="-13.97" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-13.97" y1="-0.635" x2="-13.97" y2="0.635" width="0.1524" layer="51"/>
<wire x1="14.859" y1="1.397" x2="13.716" y2="1.397" width="0.1524" layer="51"/>
<wire x1="7.874" y1="1.397" x2="6.096" y2="1.397" width="0.1524" layer="51"/>
<wire x1="6.096" y1="1.397" x2="5.334" y2="1.397" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-1.397" x2="15.621" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-1.397" x2="14.224" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="7.366" y1="-1.397" x2="6.604" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="6.604" y1="-1.397" x2="4.826" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="5.334" y1="1.397" x2="3.556" y2="1.397" width="0.1524" layer="51"/>
<wire x1="3.556" y1="1.397" x2="2.794" y2="1.397" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-1.397" x2="4.064" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-1.397" x2="2.286" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="2.286" y1="-1.397" x2="1.524" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="2.794" y1="1.397" x2="1.016" y2="1.397" width="0.1524" layer="51"/>
<wire x1="1.016" y1="1.397" x2="0.254" y2="1.397" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-1.397" x2="-0.254" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.397" x2="-1.016" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="0.254" y1="1.397" x2="-1.524" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-1.524" y1="1.397" x2="-2.286" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="1.397" x2="-4.826" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-1.397" x2="-2.794" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-2.286" y1="1.397" x2="-4.064" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-2.794" y1="-1.397" x2="-3.556" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-1.397" x2="-5.334" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-4.826" y1="1.397" x2="-6.604" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-6.604" y1="1.397" x2="-7.366" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-9.144" y1="1.397" x2="-9.906" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-7.366" y1="1.397" x2="-9.144" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-6.096" y1="-1.397" x2="-7.874" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-8.636" y1="-1.397" x2="-10.414" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-5.334" y1="-1.397" x2="-6.096" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-1.397" x2="-8.636" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-1.397" x2="-11.176" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-12.954" y1="-1.397" x2="-13.716" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-11.684" y1="1.397" x2="-12.446" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="1.397" x2="-11.684" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-11.176" y1="-1.397" x2="-12.954" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-12.446" y1="1.397" x2="-13.97" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-14.224" y1="1.397" x2="-14.859" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-13.716" y1="-1.397" x2="-13.97" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-13.97" y1="-1.397" x2="-14.859" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-13.97" y1="1.397" x2="-14.224" y2="1.397" width="0.1524" layer="51"/>
<wire x1="10.414" y1="1.397" x2="8.636" y2="1.397" width="0.1524" layer="51"/>
<wire x1="12.954" y1="1.397" x2="11.176" y2="1.397" width="0.1524" layer="51"/>
<wire x1="9.906" y1="-1.397" x2="9.144" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="12.446" y1="-1.397" x2="11.684" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="9.144" y1="-1.397" x2="7.366" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="11.684" y1="-1.397" x2="9.906" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="14.224" y1="-1.397" x2="12.446" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="8.636" y1="1.397" x2="7.874" y2="1.397" width="0.1524" layer="21"/>
<wire x1="11.176" y1="1.397" x2="10.414" y2="1.397" width="0.1524" layer="21"/>
<wire x1="13.716" y1="1.397" x2="12.954" y2="1.397" width="0.1524" layer="21"/>
<circle x="-14.605" y="-0.762" radius="0.254" width="0.1524" layer="51"/>
<pad name="1" x="-14.605" y="-1.27" drill="0.8128"/>
<pad name="2" x="-13.335" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="3" x="-12.065" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="4" x="-10.795" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="5" x="-9.525" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="6" x="-8.255" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="7" x="-6.985" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="8" x="-5.715" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="9" x="-4.445" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="10" x="-3.175" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="11" x="-1.905" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="12" x="-0.635" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="13" x="0.635" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="14" x="1.905" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="15" x="3.175" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="16" x="4.445" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="17" x="5.715" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="18" x="6.985" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="19" x="8.255" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="20" x="9.525" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="21" x="10.795" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="22" x="12.065" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="23" x="13.335" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="24" x="14.605" y="1.27" drill="0.8128" shape="octagon"/>
<text x="-14.732" y="-3.556" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-13.081" y="2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ZIP14">
<wire x1="-9.144" y1="1.397" x2="-9.906" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="0.635" x2="-9.906" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="-0.635" x2="-9.144" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="8.636" y1="-0.635" x2="8.636" y2="0.635" width="0.1524" layer="21"/>
<wire x1="8.636" y1="0.635" x2="7.874" y2="1.397" width="0.1524" layer="51"/>
<wire x1="8.636" y1="0.635" x2="-8.255" y2="0.635" width="0.1524" layer="51"/>
<wire x1="8.636" y1="-0.635" x2="-8.255" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-1.397" x2="-8.255" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="0.635" x2="-8.255" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-0.635" x2="-8.255" y2="0.635" width="0.1524" layer="51"/>
<wire x1="7.874" y1="-1.397" x2="8.636" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="7.874" y1="-1.397" x2="7.239" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="7.874" y1="1.397" x2="6.731" y2="1.397" width="0.1524" layer="51"/>
<wire x1="6.731" y1="1.397" x2="5.969" y2="1.397" width="0.1524" layer="21"/>
<wire x1="7.239" y1="-1.397" x2="5.461" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="5.461" y1="-1.397" x2="4.699" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="5.969" y1="1.397" x2="4.191" y2="1.397" width="0.1524" layer="51"/>
<wire x1="4.191" y1="1.397" x2="3.429" y2="1.397" width="0.1524" layer="21"/>
<wire x1="1.651" y1="1.397" x2="0.889" y2="1.397" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.397" x2="2.921" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="3.429" y1="1.397" x2="1.651" y2="1.397" width="0.1524" layer="51"/>
<wire x1="2.921" y1="-1.397" x2="2.159" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.397" x2="0.381" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="0.889" y1="1.397" x2="-0.889" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-0.889" y1="1.397" x2="-1.651" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.397" x2="-4.191" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.397" x2="-3.429" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-0.381" y1="-1.397" x2="-2.159" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="-1.397" x2="-4.699" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="0.381" y1="-1.397" x2="-0.381" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="-1.397" x2="-2.921" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-1.397" x2="-5.461" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-7.239" y1="-1.397" x2="-8.001" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="1.397" x2="-6.731" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="1.397" x2="-5.969" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-5.461" y1="-1.397" x2="-7.239" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-6.731" y1="1.397" x2="-8.255" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-8.509" y1="1.397" x2="-9.144" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-8.001" y1="-1.397" x2="-8.255" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="-1.397" x2="-9.144" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="1.397" x2="-8.509" y2="1.397" width="0.1524" layer="51"/>
<circle x="-8.89" y="-0.762" radius="0.254" width="0.1524" layer="51"/>
<pad name="1" x="-8.89" y="-1.27" drill="0.8128"/>
<pad name="2" x="-7.62" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="3" x="-6.35" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="4" x="-5.08" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="5" x="-3.81" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="6" x="-2.54" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="7" x="-1.27" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="8" x="0" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="9" x="1.27" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="10" x="2.54" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="11" x="3.81" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="12" x="5.08" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="13" x="6.35" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="14" x="7.62" y="1.27" drill="0.8128" shape="octagon"/>
<text x="-9.017" y="-3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-7.62" y="2.1844" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL16/8">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt; 8 pins used</description>
<wire x1="-10.795" y1="-0.635" x2="-10.795" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-0.635" x2="-10.795" y2="0.635" width="0.1524" layer="21" curve="180"/>
<wire x1="10.795" y1="-2.794" x2="10.795" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="2.794" x2="-10.795" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="2.794" x2="10.795" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-2.794" x2="10.795" y2="-2.794" width="0.1524" layer="21"/>
<pad name="1" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-11.1252" y="-2.667" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-6.477" y="-0.9398" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL16/4">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt; 4 pins used</description>
<pad name="16" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-9.017" y="-0.9398" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL64">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="-41.275" y1="-1.27" x2="-41.275" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-41.275" y1="1.27" x2="-41.275" y2="-1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="41.275" y1="-10.414" x2="41.275" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-41.275" y1="-10.414" x2="41.275" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-41.275" y1="10.414" x2="-41.275" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-41.275" y1="10.414" x2="41.275" y2="10.414" width="0.1524" layer="21"/>
<pad name="1" x="-39.37" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-36.83" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-34.29" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-31.75" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-29.21" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-26.67" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-24.13" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-21.59" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="-19.05" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="-16.51" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="-13.97" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="-11.43" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-8.89" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-6.35" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="-3.81" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-1.27" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="1.27" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="3.81" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="6.35" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="32" x="39.37" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="33" x="39.37" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="46" x="6.35" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="47" x="3.81" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="48" x="1.27" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="49" x="-1.27" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="50" x="-3.81" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="51" x="-6.35" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="52" x="-8.89" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="53" x="-11.43" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="54" x="-13.97" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="55" x="-16.51" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="56" x="-19.05" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="57" x="-21.59" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="58" x="-24.13" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="59" x="-26.67" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="60" x="-29.21" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="61" x="-31.75" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="62" x="-34.29" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="63" x="-36.83" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="64" x="-39.37" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="8.89" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="11.43" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="13.97" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="16.51" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="19.05" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="21.59" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="24.13" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="26.67" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="29.21" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="29" x="31.75" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="30" x="34.29" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="31" x="36.83" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="45" x="8.89" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="44" x="11.43" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="43" x="13.97" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="42" x="16.51" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="41" x="19.05" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="40" x="21.59" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="39" x="24.13" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="38" x="26.67" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="37" x="29.21" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="36" x="31.75" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="35" x="34.29" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="34" x="36.83" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<text x="-41.783" y="-9.906" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-36.83" y="-0.9652" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL06-4">
<wire x1="-4.445" y1="0.635" x2="-4.445" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-0.635" x2="-4.445" y2="0.635" width="0.1524" layer="21" curve="180"/>
<wire x1="-4.445" y1="-2.794" x2="-4.445" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-2.794" x2="4.445" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="4.445" y1="2.794" x2="4.445" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="4.445" y1="2.794" x2="-4.445" y2="2.794" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="0" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="2.54" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="0" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-2.54" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<text x="-4.6736" y="-2.54" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.302" y="-0.6096" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="1.778" y1="-4.064" x2="3.3021" y2="-2.7939" layer="21"/>
<rectangle x1="-0.762" y1="-4.064" x2="0.7621" y2="-2.7939" layer="21"/>
<rectangle x1="-3.302" y1="-4.064" x2="-1.7779" y2="-2.7939" layer="21"/>
<rectangle x1="-3.302" y1="2.794" x2="-1.7779" y2="4.0641" layer="21"/>
<rectangle x1="-0.762" y1="2.794" x2="0.7621" y2="4.0641" layer="21"/>
<rectangle x1="1.778" y1="2.794" x2="3.3021" y2="4.0641" layer="21"/>
</package>
<package name="DIL16/8B">
<wire x1="-10.16" y1="-0.635" x2="-10.16" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-0.635" x2="-10.16" y2="0.635" width="0.1524" layer="21" curve="180"/>
<wire x1="-10.16" y1="-2.794" x2="10.16" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-2.794" x2="10.16" y2="2.794" width="0.1524" layer="21"/>
<wire x1="10.16" y1="2.794" x2="-10.16" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="2.794" x2="-10.16" y2="0.635" width="0.1524" layer="21"/>
<pad name="4" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-10.4394" y="-2.667" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-8.255" y="-0.9652" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL64Y">
<description>&lt;b&gt;Dual In Line, elongated pads&lt;/b&gt;</description>
<wire x1="-29.083" y1="-1.27" x2="-29.083" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-29.083" y1="1.27" x2="-29.083" y2="-1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="29.083" y1="-10.414" x2="29.083" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-29.083" y1="-10.414" x2="29.083" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-29.083" y1="10.414" x2="-29.083" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-29.083" y1="10.414" x2="29.083" y2="10.414" width="0.1524" layer="21"/>
<pad name="1" x="-27.559" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-25.781" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-24.003" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-22.225" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-20.447" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-18.669" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-16.891" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-15.113" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="-13.335" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="-11.557" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="-9.779" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="-8.001" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-6.223" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-4.445" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="-2.667" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-0.889" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="0.889" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="2.667" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="4.445" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="32" x="27.559" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="33" x="27.559" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="46" x="4.445" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="47" x="2.667" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="48" x="0.889" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="49" x="-0.889" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="50" x="-2.667" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="51" x="-4.445" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="52" x="-6.223" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="53" x="-8.001" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="54" x="-9.779" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="55" x="-11.557" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="56" x="-13.335" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="57" x="-15.113" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="58" x="-16.891" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="59" x="-18.669" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="60" x="-20.447" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="61" x="-22.225" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="62" x="-24.003" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="63" x="-25.781" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="64" x="-27.559" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="6.223" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="8.001" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="9.779" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="11.557" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="13.335" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="15.113" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="16.891" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="18.669" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="20.447" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="29" x="22.225" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="30" x="24.003" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="31" x="25.781" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="45" x="6.223" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="44" x="8.001" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="43" x="9.779" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="42" x="11.557" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="41" x="13.335" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="40" x="15.113" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="39" x="16.891" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="38" x="18.669" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="37" x="20.447" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="36" x="22.225" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="35" x="24.003" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="34" x="25.781" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<text x="-29.464" y="-9.906" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-24.638" y="-0.9652" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="ZIP20">
<wire x1="-12.319" y1="1.397" x2="-13.081" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-13.081" y1="0.635" x2="-13.081" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-13.081" y1="-0.635" x2="-12.319" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="13.081" y1="-0.635" x2="13.081" y2="0.635" width="0.1524" layer="21"/>
<wire x1="13.081" y1="0.635" x2="12.319" y2="1.397" width="0.1524" layer="51"/>
<wire x1="13.081" y1="0.635" x2="-11.43" y2="0.635" width="0.1524" layer="51"/>
<wire x1="13.081" y1="-0.635" x2="-11.43" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-11.43" y1="-1.397" x2="-11.43" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-11.43" y1="0.635" x2="-11.43" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-11.43" y1="-0.635" x2="-11.43" y2="0.635" width="0.1524" layer="51"/>
<wire x1="12.319" y1="1.397" x2="11.176" y2="1.397" width="0.1524" layer="51"/>
<wire x1="12.319" y1="-1.397" x2="13.081" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="12.319" y1="-1.397" x2="11.684" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-9.906" y1="1.397" x2="-11.43" y2="1.397" width="0.1524" layer="51"/>
<wire x1="-11.684" y1="1.397" x2="-12.319" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-11.176" y1="-1.397" x2="-11.43" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-11.43" y1="-1.397" x2="-12.319" y2="-1.397" width="0.1524" layer="51"/>
<wire x1="-11.43" y1="1.397" x2="-11.684" y2="1.397" width="0.1524" layer="51"/>
<circle x="-12.065" y="-0.762" radius="0.254" width="0.1524" layer="51"/>
<pad name="1" x="-12.065" y="-1.27" drill="0.8128"/>
<pad name="2" x="-10.795" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="3" x="-9.525" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="4" x="-8.255" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="5" x="-6.985" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="6" x="-5.715" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="7" x="-4.445" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="8" x="-3.175" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="9" x="-1.905" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="10" x="-0.635" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="11" x="0.635" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="12" x="1.905" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="13" x="3.175" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="14" x="4.445" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="15" x="5.715" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="16" x="6.985" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="17" x="8.255" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="18" x="9.525" y="1.27" drill="0.8128" shape="octagon"/>
<pad name="19" x="10.795" y="-1.27" drill="0.8128" shape="octagon"/>
<pad name="20" x="12.065" y="1.27" drill="0.8128" shape="octagon"/>
<text x="-12.192" y="-3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-11.176" y="2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL42">
<wire x1="-27.686" y1="-1.27" x2="-27.686" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="-27.686" y1="1.27" x2="-27.686" y2="-1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="27.686" y1="-6.604" x2="27.686" y2="6.604" width="0.1524" layer="21"/>
<wire x1="-27.686" y1="6.604" x2="-27.686" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-27.686" y1="6.604" x2="27.686" y2="6.604" width="0.1524" layer="21"/>
<wire x1="-27.686" y1="-6.604" x2="27.686" y2="-6.604" width="0.1524" layer="21"/>
<pad name="1" x="-25.4" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-22.86" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-20.32" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-17.78" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-15.24" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-12.7" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-10.16" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-7.62" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="-5.08" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="-2.54" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="0" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="2.54" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="5.08" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="7.62" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="10.16" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="12.7" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="15.24" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="17.78" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="20.32" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="22.86" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="25.4" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="25.4" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="22.86" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="20.32" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="17.78" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="15.24" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="12.7" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="10.16" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="29" x="7.62" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="30" x="5.08" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="31" x="2.54" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="32" x="0" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="33" x="-2.54" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="34" x="-5.08" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="35" x="-7.62" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="36" x="-10.16" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="37" x="-12.7" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="38" x="-15.24" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="39" x="-17.78" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="40" x="-20.32" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="41" x="-22.86" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="42" x="-25.4" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<text x="-28.194" y="-6.223" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-22.86" y="-0.9652" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL68">
<description>&lt;b&gt;Dual In Line&lt;/b&gt;</description>
<wire x1="-43.815" y1="-1.27" x2="-43.815" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-43.815" y1="1.27" x2="-43.815" y2="-1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="43.815" y1="-10.414" x2="43.815" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-43.815" y1="-10.414" x2="43.815" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-43.815" y1="10.414" x2="-43.815" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-43.815" y1="10.414" x2="43.815" y2="10.414" width="0.1524" layer="21"/>
<pad name="1" x="-41.91" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-39.37" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-36.83" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-34.29" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-31.75" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-29.21" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-26.67" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-24.13" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="-21.59" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="-19.05" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="-16.51" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="-13.97" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-11.43" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-8.89" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="-6.35" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="-3.81" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="-1.27" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="1.27" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="3.81" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="32" x="36.83" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="33" x="39.37" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="46" x="13.97" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="47" x="11.43" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="48" x="8.89" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="49" x="6.35" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="50" x="3.81" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="51" x="1.27" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="52" x="-1.27" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="53" x="-3.81" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="54" x="-6.35" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="55" x="-8.89" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="56" x="-11.43" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="57" x="-13.97" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="58" x="-16.51" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="59" x="-19.05" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="60" x="-21.59" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="61" x="-24.13" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="62" x="-26.67" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="63" x="-29.21" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="64" x="-31.75" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="6.35" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="8.89" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="11.43" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="13.97" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="16.51" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="19.05" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="21.59" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="24.13" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="26.67" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="29" x="29.21" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="30" x="31.75" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="31" x="34.29" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="45" x="16.51" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="44" x="19.05" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="43" x="21.59" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="42" x="24.13" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="41" x="26.67" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="40" x="29.21" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="39" x="31.75" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="38" x="34.29" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="37" x="36.83" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="36" x="39.37" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="35" x="41.91" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="34" x="41.91" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="65" x="-34.29" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="66" x="-36.83" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="67" x="-39.37" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="68" x="-41.91" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<text x="-44.323" y="-10.033" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-39.37" y="-0.9652" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="SOCKET-04">
<description>&lt;b&gt;Dual In Line Socket&lt;/b&gt;</description>
<wire x1="2.54" y1="5.08" x2="-2.54" y2="5.08" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-5.08" x2="2.54" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="2.54" y1="5.08" x2="2.54" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="5.08" x2="-2.54" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-5.08" x2="-2.54" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.016" x2="-2.54" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<wire x1="-2.54" y1="2.54" x2="2.54" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="2.54" x2="-2.54" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.54" y1="2.54" x2="2.54" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-2.54" x2="2.54" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-2.54" x2="-2.54" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-2.54" x2="2.54" y2="-5.08" width="0.1524" layer="21"/>
<pad name="1" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R270"/>
<pad name="4" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R270"/>
<text x="4.318" y="-3.048" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-2.921" y="-2.667" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
</package>
<package name="SOCKET-22-4">
<description>&lt;b&gt;Dual In Line, 0.4 inch Socket&lt;/b&gt;</description>
<wire x1="13.97" y1="6.35" x2="-13.97" y2="6.35" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-6.35" x2="13.97" y2="-6.35" width="0.1524" layer="21"/>
<wire x1="13.97" y1="3.556" x2="-13.97" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-3.556" x2="13.97" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="13.97" y1="3.556" x2="13.97" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="3.556" x2="-13.97" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="1.016" x2="-13.97" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<wire x1="13.97" y1="6.35" x2="13.97" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="6.35" x2="-13.97" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-6.35" x2="-13.97" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-13.97" y1="-3.556" x2="-13.97" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="13.97" y1="-6.35" x2="13.97" y2="-3.556" width="0.1524" layer="21"/>
<pad name="1" x="-12.7" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-10.16" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-7.62" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-5.08" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-2.54" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="0" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="2.54" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="5.08" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="7.62" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="10.16" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="12.7" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="12.7" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="10.16" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="7.62" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="5.08" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="2.54" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="0" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="-2.54" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-5.08" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-7.62" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="-10.16" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-12.7" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<text x="-9.906" y="-0.508" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL52">
<wire x1="-32.766" y1="1.27" x2="-32.766" y2="-1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="32.766" y1="-6.604" x2="32.766" y2="6.604" width="0.1524" layer="21"/>
<wire x1="-32.766" y1="1.27" x2="-32.766" y2="6.604" width="0.1524" layer="21"/>
<wire x1="-32.766" y1="6.604" x2="32.766" y2="6.604" width="0.1524" layer="21"/>
<wire x1="-32.766" y1="-1.27" x2="-32.766" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="-32.766" y1="-6.604" x2="32.766" y2="-6.604" width="0.1524" layer="21"/>
<pad name="1" x="-31.75" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-29.21" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-26.67" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-24.13" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-21.59" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="-11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="-8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="-6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="-3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="16.51" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="19.05" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="21.59" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="24.13" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="26.67" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="25" x="29.21" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="26" x="31.75" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="27" x="31.75" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="28" x="29.21" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="29" x="26.67" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="30" x="24.13" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="31" x="21.59" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="32" x="19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="33" x="16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="34" x="13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="35" x="11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="36" x="8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="37" x="6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="38" x="3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="39" x="1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="40" x="-1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="41" x="-3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="42" x="-6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="43" x="-8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="44" x="-11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="45" x="-13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="46" x="-16.51" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="47" x="-19.05" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="48" x="-21.59" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="49" x="-24.13" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="50" x="-26.67" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="51" x="-29.21" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="52" x="-31.75" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<text x="-33.02" y="-6.35" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-29.21" y="-1.905" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIL14">
<wire x1="8.89" y1="2.921" x2="-8.89" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.921" x2="8.89" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="8.89" y1="2.921" x2="8.89" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="2.921" x2="-8.89" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="-2.921" x2="-8.89" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="1.016" x2="-8.89" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="7.62" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="0" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="5.08" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="2.54" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="0" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="-2.54" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="-5.08" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="-7.62" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-9.271" y="-3.048" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-6.731" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="LT1158">
<description>LT1158</description>
<pad name="P$1" x="-8.89" y="-3.81" drill="0.5" diameter="1.6764" shape="square"/>
<pad name="P$2" x="-6.35" y="-3.81" drill="0.5" diameter="1.6764"/>
<pad name="P$3" x="-3.81" y="-3.81" drill="0.5" diameter="1.6764"/>
<pad name="P$4" x="-1.27" y="-3.81" drill="0.5" diameter="1.6764"/>
<pad name="P$5" x="1.27" y="-3.81" drill="0.5" diameter="1.6764"/>
<pad name="P$6" x="3.81" y="-3.81" drill="0.5" diameter="1.6764"/>
<pad name="P$7" x="6.35" y="-3.81" drill="0.5" diameter="1.6764"/>
<pad name="P$8" x="8.89" y="-3.81" drill="0.5" diameter="1.6764"/>
<pad name="P$9" x="8.89" y="3.81" drill="0.5" diameter="1.6764"/>
<pad name="P$10" x="6.35" y="3.81" drill="0.5" diameter="1.6764"/>
<pad name="P$11" x="3.81" y="3.81" drill="0.5" diameter="1.6764"/>
<pad name="P$12" x="1.27" y="3.81" drill="0.5" diameter="1.6764"/>
<pad name="P$13" x="-1.27" y="3.81" drill="0.5" diameter="1.6764"/>
<pad name="P$14" x="-3.81" y="3.81" drill="0.5" diameter="1.6764"/>
<pad name="P$15" x="-6.35" y="3.81" drill="0.5" diameter="1.6764"/>
<pad name="P$16" x="-8.89" y="3.81" drill="0.5" diameter="1.6764"/>
<wire x1="-10.16" y1="3.175" x2="10.16" y2="3.175" width="0.127" layer="21"/>
<wire x1="10.16" y1="3.175" x2="10.16" y2="-3.175" width="0.127" layer="21"/>
<wire x1="10.16" y1="-3.175" x2="-10.16" y2="-3.175" width="0.127" layer="21"/>
<wire x1="-10.16" y1="-3.175" x2="-10.16" y2="-1.27" width="0.127" layer="21"/>
<wire x1="-10.16" y1="1.27" x2="-10.16" y2="3.175" width="0.127" layer="21"/>
<wire x1="-10.16" y1="1.27" x2="-10.16" y2="-1.27" width="0.127" layer="21" curve="-180"/>
</package>
</packages>
<symbols>
<symbol name="DIL4">
<wire x1="-5.08" y1="3.81" x2="-5.08" y2="-3.81" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-3.81" x2="5.08" y2="-3.81" width="0.254" layer="94"/>
<wire x1="5.08" y1="-3.81" x2="5.08" y2="3.81" width="0.254" layer="94"/>
<wire x1="5.08" y1="3.81" x2="2.54" y2="3.81" width="0.254" layer="94"/>
<wire x1="-5.08" y1="3.81" x2="-2.54" y2="3.81" width="0.254" layer="94"/>
<wire x1="-2.54" y1="3.81" x2="2.54" y2="3.81" width="0.254" layer="94" curve="180"/>
<text x="-4.445" y="4.445" size="1.778" layer="95">&gt;NAME</text>
<text x="-4.445" y="-6.35" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-7.62" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="2" x="-7.62" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="3" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="4" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="DIL8">
<wire x1="-5.08" y1="3.81" x2="-5.08" y2="-6.35" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-6.35" x2="5.08" y2="-6.35" width="0.254" layer="94"/>
<wire x1="5.08" y1="-6.35" x2="5.08" y2="3.81" width="0.254" layer="94"/>
<text x="-4.445" y="-8.89" size="1.778" layer="96">&gt;VALUE</text>
<pin name="2" x="-7.62" y="0" visible="pad" length="short" direction="pas"/>
<pin name="3" x="-7.62" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="4" x="-7.62" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="5" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="6" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="7" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="8" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="DIL6">
<pin name="4" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="5" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="6" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="DIL10">
<wire x1="-5.08" y1="3.81" x2="-5.08" y2="-8.89" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-8.89" x2="5.08" y2="-8.89" width="0.254" layer="94"/>
<wire x1="5.08" y1="-8.89" x2="5.08" y2="3.81" width="0.254" layer="94"/>
<text x="-4.445" y="-11.43" size="1.778" layer="96">&gt;VALUE</text>
<pin name="5" x="-7.62" y="-7.62" visible="pad" length="short" direction="pas"/>
<pin name="6" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="7" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="8" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="9" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="10" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="DIL14">
<wire x1="-5.08" y1="8.89" x2="-5.08" y2="-8.89" width="0.254" layer="94"/>
<wire x1="5.08" y1="-8.89" x2="5.08" y2="8.89" width="0.254" layer="94"/>
<wire x1="5.08" y1="8.89" x2="2.54" y2="8.89" width="0.254" layer="94"/>
<wire x1="-5.08" y1="8.89" x2="-2.54" y2="8.89" width="0.254" layer="94"/>
<wire x1="-2.54" y1="8.89" x2="2.54" y2="8.89" width="0.254" layer="94" curve="180"/>
<text x="-4.445" y="9.525" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="-7.62" y="7.62" visible="pad" length="short" direction="pas"/>
<pin name="2" x="-7.62" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="3" x="-7.62" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="4" x="-7.62" y="0" visible="pad" length="short" direction="pas"/>
<pin name="5" x="-7.62" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="6" x="-7.62" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="7" x="-7.62" y="-7.62" visible="pad" length="short" direction="pas"/>
<pin name="8" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="9" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="10" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="11" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="12" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="13" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="14" x="7.62" y="7.62" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="DIL16">
<wire x1="-5.08" y1="8.89" x2="-5.08" y2="-11.43" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-11.43" x2="5.08" y2="-11.43" width="0.254" layer="94"/>
<wire x1="5.08" y1="-11.43" x2="5.08" y2="8.89" width="0.254" layer="94"/>
<text x="-4.445" y="-13.97" size="1.778" layer="96">&gt;VALUE</text>
<pin name="8" x="-7.62" y="-10.16" visible="pad" length="short" direction="pas"/>
<pin name="9" x="7.62" y="-10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="10" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="11" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="12" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="13" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="14" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="15" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="16" x="7.62" y="7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<text x="-17.526" y="7.62" size="1.27" layer="96">BOOST DR</text>
<text x="-10.414" y="5.08" size="1.27" layer="96">V+</text>
<text x="-12.192" y="2.54" size="1.27" layer="96">BIAS</text>
<text x="-15.24" y="0" size="1.27" layer="96">ENABLE</text>
<text x="-13.716" y="-2.54" size="1.27" layer="96">FAULT</text>
<text x="-13.716" y="-5.08" size="1.27" layer="96">INPUT</text>
<text x="-12.7" y="-7.62" size="1.27" layer="96">GND</text>
<text x="-17.78" y="-10.16" size="1.27" layer="96">B GATE FB</text>
<text x="7.62" y="7.62" size="1.27" layer="96">BOOST</text>
<text x="7.62" y="5.08" size="1.27" layer="96">T GATE DR</text>
<text x="7.62" y="2.54" size="1.27" layer="96">T GATE FB</text>
<text x="7.62" y="0" size="1.27" layer="96">T SOURCE</text>
<text x="7.62" y="-2.54" size="1.27" layer="96">SENSE+</text>
<text x="7.62" y="-5.08" size="1.27" layer="96">SENSE–</text>
<text x="7.62" y="-7.62" size="1.27" layer="96">V+</text>
<text x="7.62" y="-10.16" size="1.27" layer="96">B GATE DR</text>
<text x="-2.54" y="2.54" size="1.27" layer="94">LT1158</text>
</symbol>
<symbol name="DIL18">
<wire x1="-5.08" y1="11.43" x2="-5.08" y2="-11.43" width="0.254" layer="94"/>
<wire x1="5.08" y1="-11.43" x2="5.08" y2="11.43" width="0.254" layer="94"/>
<wire x1="5.08" y1="11.43" x2="2.54" y2="11.43" width="0.254" layer="94"/>
<wire x1="-5.08" y1="11.43" x2="-2.54" y2="11.43" width="0.254" layer="94"/>
<wire x1="-2.54" y1="11.43" x2="2.54" y2="11.43" width="0.254" layer="94" curve="180"/>
<text x="-4.445" y="12.065" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="-7.62" y="10.16" visible="pad" length="short" direction="pas"/>
<pin name="2" x="-7.62" y="7.62" visible="pad" length="short" direction="pas"/>
<pin name="3" x="-7.62" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="4" x="-7.62" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="5" x="-7.62" y="0" visible="pad" length="short" direction="pas"/>
<pin name="6" x="-7.62" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="7" x="-7.62" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="8" x="-7.62" y="-7.62" visible="pad" length="short" direction="pas"/>
<pin name="9" x="-7.62" y="-10.16" visible="pad" length="short" direction="pas"/>
<pin name="10" x="7.62" y="-10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="11" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="12" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="13" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="14" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="15" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="16" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="17" x="7.62" y="7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="18" x="7.62" y="10.16" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="DIL20">
<wire x1="-5.08" y1="11.43" x2="-5.08" y2="-13.97" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-13.97" x2="5.08" y2="-13.97" width="0.254" layer="94"/>
<wire x1="5.08" y1="-13.97" x2="5.08" y2="11.43" width="0.254" layer="94"/>
<text x="-4.445" y="-16.51" size="1.778" layer="96">&gt;VALUE</text>
<pin name="10" x="-7.62" y="-12.7" visible="pad" length="short" direction="pas"/>
<pin name="11" x="7.62" y="-12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="12" x="7.62" y="-10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="13" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="14" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="15" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="16" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="17" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="18" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="19" x="7.62" y="7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="20" x="7.62" y="10.16" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="DIL22">
<wire x1="-5.08" y1="13.97" x2="-5.08" y2="-13.97" width="0.254" layer="94"/>
<wire x1="5.08" y1="-13.97" x2="5.08" y2="13.97" width="0.254" layer="94"/>
<wire x1="5.08" y1="13.97" x2="2.54" y2="13.97" width="0.254" layer="94"/>
<wire x1="-5.08" y1="13.97" x2="-2.54" y2="13.97" width="0.254" layer="94"/>
<wire x1="-2.54" y1="13.97" x2="2.54" y2="13.97" width="0.254" layer="94" curve="180"/>
<text x="-4.445" y="14.605" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="-7.62" y="12.7" visible="pad" length="short" direction="pas"/>
<pin name="2" x="-7.62" y="10.16" visible="pad" length="short" direction="pas"/>
<pin name="3" x="-7.62" y="7.62" visible="pad" length="short" direction="pas"/>
<pin name="4" x="-7.62" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="5" x="-7.62" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="6" x="-7.62" y="0" visible="pad" length="short" direction="pas"/>
<pin name="7" x="-7.62" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="8" x="-7.62" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="9" x="-7.62" y="-7.62" visible="pad" length="short" direction="pas"/>
<pin name="10" x="-7.62" y="-10.16" visible="pad" length="short" direction="pas"/>
<pin name="11" x="-7.62" y="-12.7" visible="pad" length="short" direction="pas"/>
<pin name="12" x="7.62" y="-12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="13" x="7.62" y="-10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="14" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="15" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="16" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="17" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="18" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="19" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="20" x="7.62" y="7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="21" x="7.62" y="10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="22" x="7.62" y="12.7" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="DIL24">
<wire x1="-5.08" y1="16.51" x2="-5.08" y2="-13.97" width="0.254" layer="94"/>
<wire x1="5.08" y1="-13.97" x2="5.08" y2="16.51" width="0.254" layer="94"/>
<wire x1="5.08" y1="16.51" x2="2.54" y2="16.51" width="0.254" layer="94"/>
<wire x1="-5.08" y1="16.51" x2="-2.54" y2="16.51" width="0.254" layer="94"/>
<wire x1="-2.54" y1="16.51" x2="2.54" y2="16.51" width="0.254" layer="94" curve="180"/>
<text x="-4.445" y="17.145" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="-7.62" y="15.24" visible="pad" length="short" direction="pas"/>
<pin name="2" x="-7.62" y="12.7" visible="pad" length="short" direction="pas"/>
<pin name="3" x="-7.62" y="10.16" visible="pad" length="short" direction="pas"/>
<pin name="4" x="-7.62" y="7.62" visible="pad" length="short" direction="pas"/>
<pin name="5" x="-7.62" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="6" x="-7.62" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="7" x="-7.62" y="0" visible="pad" length="short" direction="pas"/>
<pin name="8" x="-7.62" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="9" x="-7.62" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="10" x="-7.62" y="-7.62" visible="pad" length="short" direction="pas"/>
<pin name="11" x="-7.62" y="-10.16" visible="pad" length="short" direction="pas"/>
<pin name="12" x="-7.62" y="-12.7" visible="pad" length="short" direction="pas"/>
<pin name="13" x="7.62" y="-12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="14" x="7.62" y="-10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="15" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="16" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="17" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="18" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="19" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="20" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="21" x="7.62" y="7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="22" x="7.62" y="10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="23" x="7.62" y="12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="24" x="7.62" y="15.24" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="DIL28">
<wire x1="-5.08" y1="16.51" x2="-5.08" y2="-19.05" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-19.05" x2="5.08" y2="-19.05" width="0.254" layer="94"/>
<wire x1="5.08" y1="-19.05" x2="5.08" y2="16.51" width="0.254" layer="94"/>
<text x="-4.445" y="-21.59" size="1.778" layer="96">&gt;VALUE</text>
<pin name="13" x="-7.62" y="-15.24" visible="pad" length="short" direction="pas"/>
<pin name="14" x="-7.62" y="-17.78" visible="pad" length="short" direction="pas"/>
<pin name="15" x="7.62" y="-17.78" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="16" x="7.62" y="-15.24" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="17" x="7.62" y="-12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="18" x="7.62" y="-10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="19" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="20" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="21" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="22" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="23" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="24" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="25" x="7.62" y="7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="26" x="7.62" y="10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="27" x="7.62" y="12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="28" x="7.62" y="15.24" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="DIL32">
<wire x1="-5.08" y1="19.05" x2="-5.08" y2="-21.59" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-21.59" x2="5.08" y2="-21.59" width="0.254" layer="94"/>
<wire x1="5.08" y1="-21.59" x2="5.08" y2="19.05" width="0.254" layer="94"/>
<wire x1="5.08" y1="19.05" x2="2.54" y2="19.05" width="0.254" layer="94"/>
<wire x1="-5.08" y1="19.05" x2="-2.54" y2="19.05" width="0.254" layer="94"/>
<wire x1="-2.54" y1="19.05" x2="2.54" y2="19.05" width="0.254" layer="94" curve="180"/>
<text x="-4.445" y="19.685" size="1.778" layer="95">&gt;NAME</text>
<text x="-4.445" y="-24.13" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-7.62" y="17.78" visible="pad" length="short" direction="pas"/>
<pin name="2" x="-7.62" y="15.24" visible="pad" length="short" direction="pas"/>
<pin name="3" x="-7.62" y="12.7" visible="pad" length="short" direction="pas"/>
<pin name="4" x="-7.62" y="10.16" visible="pad" length="short" direction="pas"/>
<pin name="5" x="-7.62" y="7.62" visible="pad" length="short" direction="pas"/>
<pin name="6" x="-7.62" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="7" x="-7.62" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="8" x="-7.62" y="0" visible="pad" length="short" direction="pas"/>
<pin name="9" x="-7.62" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="10" x="-7.62" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="11" x="-7.62" y="-7.62" visible="pad" length="short" direction="pas"/>
<pin name="12" x="-7.62" y="-10.16" visible="pad" length="short" direction="pas"/>
<pin name="13" x="-7.62" y="-12.7" visible="pad" length="short" direction="pas"/>
<pin name="14" x="-7.62" y="-15.24" visible="pad" length="short" direction="pas"/>
<pin name="15" x="-7.62" y="-17.78" visible="pad" length="short" direction="pas"/>
<pin name="16" x="-7.62" y="-20.32" visible="pad" length="short" direction="pas"/>
<pin name="17" x="7.62" y="-20.32" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="18" x="7.62" y="-17.78" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="19" x="7.62" y="-15.24" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="20" x="7.62" y="-12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="21" x="7.62" y="-10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="22" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="23" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="24" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="25" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="26" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="27" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="28" x="7.62" y="7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="29" x="7.62" y="10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="30" x="7.62" y="12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="31" x="7.62" y="15.24" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="32" x="7.62" y="17.78" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="DIL40">
<wire x1="-5.08" y1="24.13" x2="-5.08" y2="-26.67" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-26.67" x2="5.08" y2="-26.67" width="0.254" layer="94"/>
<wire x1="5.08" y1="-26.67" x2="5.08" y2="24.13" width="0.254" layer="94"/>
<wire x1="5.08" y1="24.13" x2="2.54" y2="24.13" width="0.254" layer="94"/>
<wire x1="-5.08" y1="24.13" x2="-2.54" y2="24.13" width="0.254" layer="94"/>
<wire x1="-2.54" y1="24.13" x2="2.54" y2="24.13" width="0.254" layer="94" curve="180"/>
<text x="-4.445" y="24.765" size="1.778" layer="95">&gt;NAME</text>
<text x="-4.445" y="-29.21" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-7.62" y="22.86" visible="pad" length="short" direction="pas"/>
<pin name="2" x="-7.62" y="20.32" visible="pad" length="short" direction="pas"/>
<pin name="3" x="-7.62" y="17.78" visible="pad" length="short" direction="pas"/>
<pin name="4" x="-7.62" y="15.24" visible="pad" length="short" direction="pas"/>
<pin name="5" x="-7.62" y="12.7" visible="pad" length="short" direction="pas"/>
<pin name="6" x="-7.62" y="10.16" visible="pad" length="short" direction="pas"/>
<pin name="7" x="-7.62" y="7.62" visible="pad" length="short" direction="pas"/>
<pin name="8" x="-7.62" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="9" x="-7.62" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="10" x="-7.62" y="0" visible="pad" length="short" direction="pas"/>
<pin name="11" x="-7.62" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="12" x="-7.62" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="13" x="-7.62" y="-7.62" visible="pad" length="short" direction="pas"/>
<pin name="14" x="-7.62" y="-10.16" visible="pad" length="short" direction="pas"/>
<pin name="15" x="-7.62" y="-12.7" visible="pad" length="short" direction="pas"/>
<pin name="16" x="-7.62" y="-15.24" visible="pad" length="short" direction="pas"/>
<pin name="17" x="-7.62" y="-17.78" visible="pad" length="short" direction="pas"/>
<pin name="18" x="-7.62" y="-20.32" visible="pad" length="short" direction="pas"/>
<pin name="19" x="-7.62" y="-22.86" visible="pad" length="short" direction="pas"/>
<pin name="20" x="-7.62" y="-25.4" visible="pad" length="short" direction="pas"/>
<pin name="21" x="7.62" y="-25.4" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="22" x="7.62" y="-22.86" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="23" x="7.62" y="-20.32" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="24" x="7.62" y="-17.78" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="25" x="7.62" y="-15.24" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="26" x="7.62" y="-12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="27" x="7.62" y="-10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="28" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="29" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="30" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="31" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="32" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="33" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="34" x="7.62" y="7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="35" x="7.62" y="10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="36" x="7.62" y="12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="37" x="7.62" y="15.24" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="38" x="7.62" y="17.78" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="39" x="7.62" y="20.32" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="40" x="7.62" y="22.86" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="DIL48">
<wire x1="-5.08" y1="29.21" x2="-5.08" y2="-31.75" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-31.75" x2="5.08" y2="-31.75" width="0.254" layer="94"/>
<wire x1="5.08" y1="-31.75" x2="5.08" y2="29.21" width="0.254" layer="94"/>
<wire x1="5.08" y1="29.21" x2="2.54" y2="29.21" width="0.254" layer="94"/>
<wire x1="-5.08" y1="29.21" x2="-2.54" y2="29.21" width="0.254" layer="94"/>
<wire x1="-2.54" y1="29.21" x2="2.54" y2="29.21" width="0.254" layer="94" curve="180"/>
<text x="-4.445" y="29.845" size="1.778" layer="95">&gt;NAME</text>
<text x="-4.445" y="-34.29" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-7.62" y="27.94" visible="pad" length="short" direction="pas"/>
<pin name="2" x="-7.62" y="25.4" visible="pad" length="short" direction="pas"/>
<pin name="3" x="-7.62" y="22.86" visible="pad" length="short" direction="pas"/>
<pin name="4" x="-7.62" y="20.32" visible="pad" length="short" direction="pas"/>
<pin name="5" x="-7.62" y="17.78" visible="pad" length="short" direction="pas"/>
<pin name="6" x="-7.62" y="15.24" visible="pad" length="short" direction="pas"/>
<pin name="7" x="-7.62" y="12.7" visible="pad" length="short" direction="pas"/>
<pin name="8" x="-7.62" y="10.16" visible="pad" length="short" direction="pas"/>
<pin name="9" x="-7.62" y="7.62" visible="pad" length="short" direction="pas"/>
<pin name="10" x="-7.62" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="11" x="-7.62" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="12" x="-7.62" y="0" visible="pad" length="short" direction="pas"/>
<pin name="13" x="-7.62" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="14" x="-7.62" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="15" x="-7.62" y="-7.62" visible="pad" length="short" direction="pas"/>
<pin name="16" x="-7.62" y="-10.16" visible="pad" length="short" direction="pas"/>
<pin name="17" x="-7.62" y="-12.7" visible="pad" length="short" direction="pas"/>
<pin name="18" x="-7.62" y="-15.24" visible="pad" length="short" direction="pas"/>
<pin name="19" x="-7.62" y="-17.78" visible="pad" length="short" direction="pas"/>
<pin name="20" x="-7.62" y="-20.32" visible="pad" length="short" direction="pas"/>
<pin name="21" x="-7.62" y="-22.86" visible="pad" length="short" direction="pas"/>
<pin name="22" x="-7.62" y="-25.4" visible="pad" length="short" direction="pas"/>
<pin name="23" x="-7.62" y="-27.94" visible="pad" length="short" direction="pas"/>
<pin name="24" x="-7.62" y="-30.48" visible="pad" length="short" direction="pas"/>
<pin name="25" x="7.62" y="-30.48" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="26" x="7.62" y="-27.94" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="27" x="7.62" y="-25.4" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="28" x="7.62" y="-22.86" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="29" x="7.62" y="-20.32" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="30" x="7.62" y="-17.78" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="31" x="7.62" y="-15.24" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="32" x="7.62" y="-12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="33" x="7.62" y="-10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="34" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="35" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="36" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="37" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="38" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="39" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="40" x="7.62" y="7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="41" x="7.62" y="10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="42" x="7.62" y="12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="43" x="7.62" y="15.24" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="44" x="7.62" y="17.78" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="45" x="7.62" y="20.32" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="46" x="7.62" y="22.86" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="47" x="7.62" y="25.4" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="48" x="7.62" y="27.94" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="DIL68">
<wire x1="-5.08" y1="41.91" x2="-5.08" y2="-44.45" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-44.45" x2="5.08" y2="-44.45" width="0.254" layer="94"/>
<wire x1="5.08" y1="-44.45" x2="5.08" y2="41.91" width="0.254" layer="94"/>
<wire x1="5.08" y1="41.91" x2="2.54" y2="41.91" width="0.254" layer="94"/>
<wire x1="-5.08" y1="41.91" x2="-2.54" y2="41.91" width="0.254" layer="94"/>
<wire x1="-2.54" y1="41.91" x2="2.54" y2="41.91" width="0.254" layer="94" curve="180"/>
<text x="-4.445" y="42.545" size="1.778" layer="95">&gt;NAME</text>
<text x="-4.445" y="-46.99" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-7.62" y="40.64" visible="pad" length="short" direction="pas"/>
<pin name="2" x="-7.62" y="38.1" visible="pad" length="short" direction="pas"/>
<pin name="3" x="-7.62" y="35.56" visible="pad" length="short" direction="pas"/>
<pin name="4" x="-7.62" y="33.02" visible="pad" length="short" direction="pas"/>
<pin name="5" x="-7.62" y="30.48" visible="pad" length="short" direction="pas"/>
<pin name="6" x="-7.62" y="27.94" visible="pad" length="short" direction="pas"/>
<pin name="7" x="-7.62" y="25.4" visible="pad" length="short" direction="pas"/>
<pin name="8" x="-7.62" y="22.86" visible="pad" length="short" direction="pas"/>
<pin name="9" x="-7.62" y="20.32" visible="pad" length="short" direction="pas"/>
<pin name="10" x="-7.62" y="17.78" visible="pad" length="short" direction="pas"/>
<pin name="11" x="-7.62" y="15.24" visible="pad" length="short" direction="pas"/>
<pin name="12" x="-7.62" y="12.7" visible="pad" length="short" direction="pas"/>
<pin name="13" x="-7.62" y="10.16" visible="pad" length="short" direction="pas"/>
<pin name="14" x="-7.62" y="7.62" visible="pad" length="short" direction="pas"/>
<pin name="15" x="-7.62" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="16" x="-7.62" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="17" x="-7.62" y="0" visible="pad" length="short" direction="pas"/>
<pin name="18" x="-7.62" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="19" x="-7.62" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="20" x="-7.62" y="-7.62" visible="pad" length="short" direction="pas"/>
<pin name="21" x="-7.62" y="-10.16" visible="pad" length="short" direction="pas"/>
<pin name="22" x="-7.62" y="-12.7" visible="pad" length="short" direction="pas"/>
<pin name="23" x="-7.62" y="-15.24" visible="pad" length="short" direction="pas"/>
<pin name="24" x="-7.62" y="-17.78" visible="pad" length="short" direction="pas"/>
<pin name="25" x="-7.62" y="-20.32" visible="pad" length="short" direction="pas"/>
<pin name="26" x="-7.62" y="-22.86" visible="pad" length="short" direction="pas"/>
<pin name="27" x="-7.62" y="-25.4" visible="pad" length="short" direction="pas"/>
<pin name="28" x="-7.62" y="-27.94" visible="pad" length="short" direction="pas"/>
<pin name="29" x="-7.62" y="-30.48" visible="pad" length="short" direction="pas"/>
<pin name="30" x="-7.62" y="-33.02" visible="pad" length="short" direction="pas"/>
<pin name="31" x="-7.62" y="-35.56" visible="pad" length="short" direction="pas"/>
<pin name="32" x="-7.62" y="-38.1" visible="pad" length="short" direction="pas"/>
<pin name="33" x="-7.62" y="-40.64" visible="pad" length="short" direction="pas"/>
<pin name="34" x="-7.62" y="-43.18" visible="pad" length="short" direction="pas"/>
<pin name="35" x="7.62" y="-43.18" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="36" x="7.62" y="-40.64" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="37" x="7.62" y="-38.1" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="38" x="7.62" y="-35.56" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="39" x="7.62" y="-33.02" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="40" x="7.62" y="-30.48" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="41" x="7.62" y="-27.94" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="42" x="7.62" y="-25.4" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="43" x="7.62" y="-22.86" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="44" x="7.62" y="-20.32" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="45" x="7.62" y="-17.78" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="46" x="7.62" y="-15.24" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="47" x="7.62" y="-12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="48" x="7.62" y="-10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="49" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="50" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="51" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="52" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="53" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="54" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="55" x="7.62" y="7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="56" x="7.62" y="10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="57" x="7.62" y="12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="58" x="7.62" y="15.24" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="59" x="7.62" y="17.78" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="60" x="7.62" y="20.32" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="61" x="7.62" y="22.86" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="62" x="7.62" y="25.4" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="63" x="7.62" y="27.94" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="64" x="7.62" y="30.48" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="65" x="7.62" y="33.02" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="66" x="7.62" y="35.56" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="67" x="7.62" y="38.1" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="68" x="7.62" y="40.64" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="DIL64">
<wire x1="-5.08" y1="39.37" x2="-5.08" y2="-41.91" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-41.91" x2="5.08" y2="-41.91" width="0.254" layer="94"/>
<wire x1="5.08" y1="-41.91" x2="5.08" y2="39.37" width="0.254" layer="94"/>
<wire x1="5.08" y1="39.37" x2="2.54" y2="39.37" width="0.254" layer="94"/>
<wire x1="-5.08" y1="39.37" x2="-2.54" y2="39.37" width="0.254" layer="94"/>
<wire x1="-2.54" y1="39.37" x2="2.54" y2="39.37" width="0.254" layer="94" curve="180"/>
<text x="-4.445" y="40.005" size="1.778" layer="95">&gt;NAME</text>
<text x="-4.445" y="-44.45" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-7.62" y="38.1" visible="pad" length="short" direction="pas"/>
<pin name="2" x="-7.62" y="35.56" visible="pad" length="short" direction="pas"/>
<pin name="3" x="-7.62" y="33.02" visible="pad" length="short" direction="pas"/>
<pin name="4" x="-7.62" y="30.48" visible="pad" length="short" direction="pas"/>
<pin name="5" x="-7.62" y="27.94" visible="pad" length="short" direction="pas"/>
<pin name="6" x="-7.62" y="25.4" visible="pad" length="short" direction="pas"/>
<pin name="7" x="-7.62" y="22.86" visible="pad" length="short" direction="pas"/>
<pin name="8" x="-7.62" y="20.32" visible="pad" length="short" direction="pas"/>
<pin name="9" x="-7.62" y="17.78" visible="pad" length="short" direction="pas"/>
<pin name="10" x="-7.62" y="15.24" visible="pad" length="short" direction="pas"/>
<pin name="11" x="-7.62" y="12.7" visible="pad" length="short" direction="pas"/>
<pin name="12" x="-7.62" y="10.16" visible="pad" length="short" direction="pas"/>
<pin name="13" x="-7.62" y="7.62" visible="pad" length="short" direction="pas"/>
<pin name="14" x="-7.62" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="15" x="-7.62" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="16" x="-7.62" y="0" visible="pad" length="short" direction="pas"/>
<pin name="17" x="-7.62" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="18" x="-7.62" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="19" x="-7.62" y="-7.62" visible="pad" length="short" direction="pas"/>
<pin name="20" x="-7.62" y="-10.16" visible="pad" length="short" direction="pas"/>
<pin name="21" x="-7.62" y="-12.7" visible="pad" length="short" direction="pas"/>
<pin name="22" x="-7.62" y="-15.24" visible="pad" length="short" direction="pas"/>
<pin name="23" x="-7.62" y="-17.78" visible="pad" length="short" direction="pas"/>
<pin name="24" x="-7.62" y="-20.32" visible="pad" length="short" direction="pas"/>
<pin name="25" x="-7.62" y="-22.86" visible="pad" length="short" direction="pas"/>
<pin name="26" x="-7.62" y="-25.4" visible="pad" length="short" direction="pas"/>
<pin name="27" x="-7.62" y="-27.94" visible="pad" length="short" direction="pas"/>
<pin name="28" x="-7.62" y="-30.48" visible="pad" length="short" direction="pas"/>
<pin name="29" x="-7.62" y="-33.02" visible="pad" length="short" direction="pas"/>
<pin name="30" x="-7.62" y="-35.56" visible="pad" length="short" direction="pas"/>
<pin name="31" x="-7.62" y="-38.1" visible="pad" length="short" direction="pas"/>
<pin name="32" x="-7.62" y="-40.64" visible="pad" length="short" direction="pas"/>
<pin name="33" x="7.62" y="-40.64" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="34" x="7.62" y="-38.1" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="35" x="7.62" y="-35.56" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="36" x="7.62" y="-33.02" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="37" x="7.62" y="-30.48" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="38" x="7.62" y="-27.94" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="39" x="7.62" y="-25.4" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="40" x="7.62" y="-22.86" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="41" x="7.62" y="-20.32" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="42" x="7.62" y="-17.78" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="43" x="7.62" y="-15.24" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="44" x="7.62" y="-12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="45" x="7.62" y="-10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="46" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="47" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="48" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="49" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="50" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="51" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="52" x="7.62" y="7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="53" x="7.62" y="10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="54" x="7.62" y="12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="55" x="7.62" y="15.24" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="56" x="7.62" y="17.78" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="57" x="7.62" y="20.32" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="58" x="7.62" y="22.86" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="59" x="7.62" y="25.4" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="60" x="7.62" y="27.94" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="61" x="7.62" y="30.48" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="62" x="7.62" y="33.02" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="63" x="7.62" y="35.56" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="64" x="7.62" y="38.1" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="DIL14/4">
</symbol>
<symbol name="DIL14/8">
</symbol>
<symbol name="DIL16/4">
</symbol>
<symbol name="DIL16/8">
</symbol>
<symbol name="DIL16/8B">
</symbol>
<symbol name="DIL42">
<wire x1="-5.08" y1="29.21" x2="-5.08" y2="-24.13" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-24.13" x2="5.08" y2="-24.13" width="0.254" layer="94"/>
<wire x1="5.08" y1="-24.13" x2="5.08" y2="29.21" width="0.254" layer="94"/>
<text x="-4.445" y="-26.67" size="1.778" layer="96">&gt;VALUE</text>
<pin name="41" x="7.62" y="25.4" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="42" x="7.62" y="27.94" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="ZIP14">
<wire x1="-5.08" y1="-19.05" x2="-4.318" y2="-19.812" width="0.254" layer="94"/>
<wire x1="-4.318" y1="-19.812" x2="4.318" y2="-19.812" width="0.254" layer="94"/>
<wire x1="4.318" y1="-19.812" x2="5.08" y2="-19.05" width="0.254" layer="94"/>
<wire x1="-5.08" y1="16.51" x2="-4.064" y2="17.526" width="0.254" layer="94"/>
<wire x1="-4.064" y1="17.526" x2="4.064" y2="17.526" width="0.254" layer="94"/>
<wire x1="4.064" y1="17.526" x2="5.08" y2="16.51" width="0.254" layer="94"/>
<wire x1="-1.778" y1="17.272" x2="-1.778" y2="16.51" width="0.254" layer="94"/>
<wire x1="-1.778" y1="16.51" x2="1.778" y2="16.51" width="0.254" layer="94"/>
<wire x1="1.778" y1="16.51" x2="1.778" y2="17.272" width="0.254" layer="94"/>
<text x="-5.207" y="17.907" size="1.778" layer="95">&gt;NAME</text>
<text x="-4.953" y="-22.352" size="1.778" layer="96">&gt;VALUE</text>
<pin name="5" x="-7.62" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="6" x="-7.62" y="-10.16" visible="pad" length="short" direction="pas"/>
<pin name="7" x="-7.62" y="-15.24" visible="pad" length="short" direction="pas"/>
<pin name="8" x="7.62" y="-17.78" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="9" x="7.62" y="-12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="11" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="13" x="7.62" y="7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="14" x="7.62" y="12.7" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="ZIP20">
<wire x1="-5.08" y1="-26.67" x2="-4.318" y2="-27.432" width="0.254" layer="94"/>
<wire x1="-4.318" y1="-27.432" x2="4.318" y2="-27.432" width="0.254" layer="94"/>
<wire x1="4.318" y1="-27.432" x2="5.08" y2="-26.67" width="0.254" layer="94"/>
<wire x1="-5.08" y1="24.13" x2="-4.064" y2="25.146" width="0.254" layer="94"/>
<wire x1="-4.064" y1="25.146" x2="4.064" y2="25.146" width="0.254" layer="94"/>
<wire x1="4.064" y1="25.146" x2="5.08" y2="24.13" width="0.254" layer="94"/>
<wire x1="-1.778" y1="24.892" x2="-1.778" y2="24.13" width="0.254" layer="94"/>
<wire x1="-1.778" y1="24.13" x2="1.778" y2="24.13" width="0.254" layer="94"/>
<wire x1="1.778" y1="24.13" x2="1.778" y2="24.892" width="0.254" layer="94"/>
<text x="-5.207" y="25.527" size="1.778" layer="95">&gt;NAME</text>
<text x="-4.953" y="-29.972" size="1.778" layer="96">&gt;VALUE</text>
<pin name="2" x="-7.62" y="17.78" visible="pad" length="short" direction="pas"/>
<pin name="8" x="-7.62" y="-12.7" visible="pad" length="short" direction="pas"/>
<pin name="9" x="-7.62" y="-17.78" visible="pad" length="short" direction="pas"/>
<pin name="10" x="-7.62" y="-22.86" visible="pad" length="short" direction="pas"/>
<pin name="11" x="7.62" y="-25.4" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="12" x="7.62" y="-20.32" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="13" x="7.62" y="-15.24" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="17" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="19" x="7.62" y="15.24" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="20" x="7.62" y="20.32" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="ZIP24">
<wire x1="-5.08" y1="24.13" x2="-5.08" y2="-36.83" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-36.83" x2="-4.318" y2="-37.592" width="0.254" layer="94"/>
<wire x1="-4.318" y1="-37.592" x2="4.318" y2="-37.592" width="0.254" layer="94"/>
<wire x1="4.318" y1="-37.592" x2="5.08" y2="-36.83" width="0.254" layer="94"/>
<wire x1="5.08" y1="-36.83" x2="5.08" y2="24.13" width="0.254" layer="94"/>
<text x="-4.953" y="-40.132" size="1.778" layer="96">&gt;VALUE</text>
<pin name="11" x="-7.62" y="-27.94" visible="pad" length="short" direction="pas"/>
<pin name="12" x="-7.62" y="-33.02" visible="pad" length="short" direction="pas"/>
<pin name="13" x="7.62" y="-35.56" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="14" x="7.62" y="-30.48" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="15" x="7.62" y="-25.4" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="16" x="7.62" y="-20.32" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="17" x="7.62" y="-15.24" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="19" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="20" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="21" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="23" x="7.62" y="15.24" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="24" x="7.62" y="20.32" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="DIL2">
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="-1.524" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-1.524" x2="5.08" y2="-1.524" width="0.254" layer="94"/>
<wire x1="5.08" y1="-1.524" x2="5.08" y2="1.27" width="0.254" layer="94"/>
<wire x1="5.08" y1="1.27" x2="1.778" y2="1.27" width="0.254" layer="94"/>
<wire x1="-5.08" y1="1.27" x2="-1.778" y2="1.27" width="0.254" layer="94"/>
<wire x1="-1.778" y1="1.27" x2="1.778" y2="1.27" width="0.254" layer="94" curve="171.200618"/>
<text x="-4.445" y="1.905" size="1.778" layer="95">&gt;NAME</text>
<text x="-4.445" y="-4.064" size="1.778" layer="96">&gt;VALUE</text>
<pin name="1" x="-7.62" y="0" visible="pad" length="short" direction="pas"/>
<pin name="2" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
</symbol>
<symbol name="LT1158">
<description>1158</description>
</symbol>
</symbols>
<devicesets>
<deviceset name="DIL4" prefix="IC" uservalue="yes">
<description>&lt;b&gt;Dual In Line / Socket&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="DIL4" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL04">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
<connect gate="G$1" pin="3" pad="3"/>
<connect gate="G$1" pin="4" pad="4"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="S" package="SOCKET-04">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIL6" prefix="IC" uservalue="yes">
<gates>
<gate name="G$1" symbol="DIL6" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL06">
<connects>
<connect gate="G$1" pin="5" pad="5"/>
<connect gate="G$1" pin="6" pad="6"/>
</connects>
<technologies>
</technologies>
</device>
<device name="/4" package="DIL06-4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="S" package="SOCKET-06">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIL8" prefix="IC" uservalue="yes">
<gates>
<gate name="G$1" symbol="DIL8" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL08">
<connects>
<connect gate="G$1" pin="7" pad="7"/>
<connect gate="G$1" pin="8" pad="8"/>
</connects>
<technologies>
</technologies>
</device>
<device name="S" package="SOCKET-08">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIL10" prefix="IC" uservalue="yes">
<gates>
<gate name="G$1" symbol="DIL10" x="0" y="2.54"/>
</gates>
<devices>
<device name="" package="DIL10">
<connects>
<connect gate="G$1" pin="10" pad="10"/>
<connect gate="G$1" pin="9" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIL14" prefix="IC" uservalue="yes">
<gates>
<gate name="G$1" symbol="DIL14" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL14">
<connects>
<connect gate="G$1" pin="11" pad="11"/>
<connect gate="G$1" pin="12" pad="12"/>
<connect gate="G$1" pin="13" pad="13"/>
<connect gate="G$1" pin="14" pad="14"/>
</connects>
<technologies>
</technologies>
</device>
<device name="S" package="SOCKET-14">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIL16" prefix="IC" uservalue="yes">
<gates>
<gate name="G$1" symbol="DIL16" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL16">
<connects>
<connect gate="G$1" pin="15" pad="15"/>
<connect gate="G$1" pin="16" pad="16"/>
</connects>
<technologies>
</technologies>
</device>
<device name="S" package="SOCKET-16">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIL18" prefix="IC" uservalue="yes">
<gates>
<gate name="G$1" symbol="DIL18" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL18">
<connects>
<connect gate="G$1" pin="17" pad="17"/>
<connect gate="G$1" pin="18" pad="18"/>
</connects>
<technologies>
</technologies>
</device>
<device name="S" package="SOCKET-18">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIL20" prefix="IC" uservalue="yes">
<gates>
<gate name="G$1" symbol="DIL20" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL20">
<connects>
<connect gate="G$1" pin="19" pad="19"/>
<connect gate="G$1" pin="20" pad="20"/>
</connects>
<technologies>
</technologies>
</device>
<device name="S" package="SOCKET-20">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIL22" prefix="IC" uservalue="yes">
<gates>
<gate name="G$1" symbol="DIL22" x="0" y="0"/>
</gates>
<devices>
<device name="-4" package="DIL22-4">
<connects>
<connect gate="G$1" pin="21" pad="21"/>
<connect gate="G$1" pin="22" pad="22"/>
</connects>
<technologies>
</technologies>
</device>
<device name="-3" package="DIL22-3">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="S-3" package="SOCKET-22S">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIL24" prefix="IC" uservalue="yes">
<description>&lt;b&gt;Dual In Line&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="DIL24" x="0" y="0"/>
</gates>
<devices>
<device name="-3" package="DIL24-3">
<connects>
<connect gate="G$1" pin="23" pad="23"/>
<connect gate="G$1" pin="24" pad="24"/>
</connects>
<technologies>
</technologies>
</device>
<device name="-4" package="DIL24-4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-6" package="DIL24-6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-9" package="DIL24-9">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIL28" prefix="IC" uservalue="yes">
<gates>
<gate name="G$1" symbol="DIL28" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL28-6">
<connects>
<connect gate="G$1" pin="25" pad="25"/>
<connect gate="G$1" pin="26" pad="26"/>
<connect gate="G$1" pin="27" pad="27"/>
<connect gate="G$1" pin="28" pad="28"/>
</connects>
<technologies>
</technologies>
</device>
<device name="-3" package="DIL28-3">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-4" package="DIL28-4">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIL32" prefix="IC" uservalue="yes">
<gates>
<gate name="G$1" symbol="DIL32" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL32">
<connects>
<connect gate="G$1" pin="29" pad="29"/>
<connect gate="G$1" pin="30" pad="30"/>
<connect gate="G$1" pin="31" pad="31"/>
<connect gate="G$1" pin="32" pad="32"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIL40" prefix="IC" uservalue="yes">
<gates>
<gate name="G$1" symbol="DIL40" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL40">
<connects>
<connect gate="G$1" pin="33" pad="33"/>
<connect gate="G$1" pin="34" pad="34"/>
<connect gate="G$1" pin="35" pad="35"/>
<connect gate="G$1" pin="36" pad="36"/>
<connect gate="G$1" pin="37" pad="37"/>
<connect gate="G$1" pin="38" pad="38"/>
<connect gate="G$1" pin="39" pad="39"/>
<connect gate="G$1" pin="40" pad="40"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIL68" prefix="IC" uservalue="yes">
<gates>
<gate name="G$1" symbol="DIL68" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL68">
<connects>
<connect gate="G$1" pin="41" pad="41"/>
<connect gate="G$1" pin="42" pad="42"/>
<connect gate="G$1" pin="43" pad="43"/>
<connect gate="G$1" pin="44" pad="44"/>
<connect gate="G$1" pin="45" pad="45"/>
<connect gate="G$1" pin="46" pad="46"/>
<connect gate="G$1" pin="47" pad="47"/>
<connect gate="G$1" pin="48" pad="48"/>
<connect gate="G$1" pin="49" pad="49"/>
<connect gate="G$1" pin="50" pad="50"/>
<connect gate="G$1" pin="51" pad="51"/>
<connect gate="G$1" pin="52" pad="52"/>
<connect gate="G$1" pin="53" pad="53"/>
<connect gate="G$1" pin="54" pad="54"/>
<connect gate="G$1" pin="55" pad="55"/>
<connect gate="G$1" pin="56" pad="56"/>
<connect gate="G$1" pin="57" pad="57"/>
<connect gate="G$1" pin="58" pad="58"/>
<connect gate="G$1" pin="59" pad="59"/>
<connect gate="G$1" pin="60" pad="60"/>
<connect gate="G$1" pin="61" pad="61"/>
<connect gate="G$1" pin="62" pad="62"/>
<connect gate="G$1" pin="63" pad="63"/>
<connect gate="G$1" pin="64" pad="64"/>
<connect gate="G$1" pin="65" pad="65"/>
<connect gate="G$1" pin="66" pad="66"/>
<connect gate="G$1" pin="67" pad="67"/>
<connect gate="G$1" pin="68" pad="68"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIL64" prefix="IC" uservalue="yes">
<gates>
<gate name="G$1" symbol="DIL64" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL64">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="YL" package="DIL64Y">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIL14/4" prefix="IC" uservalue="yes">
<gates>
<gate name="G$1" symbol="DIL16/4" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL14/4">
<connects>
<connect gate="G$1" pin="16" pad="14"/>
<connect gate="G$1" pin="8" pad="7"/>
<connect gate="G$1" pin="9" pad="8"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIL14/8" prefix="IC" uservalue="yes">
<gates>
<gate name="G$1" symbol="DIL14/8" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL14/8">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIL16/4" prefix="IC" uservalue="yes">
<description>&lt;b&gt;Dual In Line&lt;/b&gt; 4 pins used</description>
<gates>
</gates>
<devices>
<device name="" package="DIL16/4">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIL16/8" prefix="IC" uservalue="yes">
<description>&lt;b&gt;Dual In Line&lt;/b&gt; 8 pins used</description>
<gates>
<gate name="G$1" symbol="DIL16/8" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL16/8">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIL16/8B" prefix="IC" uservalue="yes">
<gates>
<gate name="G$1" symbol="DIL16/8B" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL16/8B">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIL42" prefix="IC" uservalue="yes">
<gates>
<gate name="G$1" symbol="DIL42" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL42">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIL48" prefix="IC" uservalue="yes">
<gates>
<gate name="G$1" symbol="DIL48" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL48">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="SIP14" prefix="IC" uservalue="yes">
<description>&lt;b&gt;Single In Line&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="ZIP14" x="0" y="0"/>
</gates>
<devices>
<device name="" package="ZIP14">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="SIP20" prefix="IC" uservalue="yes">
<gates>
<gate name="G$1" symbol="ZIP20" x="0" y="0"/>
</gates>
<devices>
<device name="" package="ZIP20">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="SIP24" prefix="IC" uservalue="yes">
<gates>
<gate name="G$1" symbol="ZIP24" x="0" y="0"/>
</gates>
<devices>
<device name="" package="ZIP24">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="DIL2" prefix="IC" uservalue="yes">
<gates>
<gate name="G$1" symbol="DIL2" x="0" y="0"/>
</gates>
<devices>
<device name="" package="DIL02">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="LT1158" uservalue="yes">
<description>LT1158</description>
<gates>
<gate name="G$1" symbol="DIL16" x="-5.08" y="20.32"/>
</gates>
<devices>
<device name="" package="LT1158">
<connects>
<connect gate="G$1" pin="1" pad="P$1"/>
<connect gate="G$1" pin="10" pad="P$10"/>
<connect gate="G$1" pin="11" pad="P$11"/>
<connect gate="G$1" pin="12" pad="P$12"/>
<connect gate="G$1" pin="13" pad="P$13"/>
<connect gate="G$1" pin="14" pad="P$14"/>
<connect gate="G$1" pin="15" pad="P$15"/>
<connect gate="G$1" pin="16" pad="P$16"/>
<connect gate="G$1" pin="2" pad="P$2"/>
<connect gate="G$1" pin="3" pad="P$3"/>
<connect gate="G$1" pin="4" pad="P$4"/>
<connect gate="G$1" pin="5" pad="P$5"/>
<connect gate="G$1" pin="6" pad="P$6"/>
<connect gate="G$1" pin="7" pad="P$7"/>
<connect gate="G$1" pin="8" pad="P$8"/>
<connect gate="G$1" pin="9" pad="P$9"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
