;=={INFORMATION}================================================================
;	File:		1wire.asm
;	Project:
;	Author:		Tamás Nagy
;	Version:	4.5.0
;	Used PIC:	PIC18F26K80
;=={DESCRIPTION}================================================================
;=={SPECIFICATIONS}=============================================================
;=={PROCESSOR + CONFIG}=========================================================
; PIC18F26K80 Configuration Bit Settings
; ASM source line config statements
#include "p18F26K80.inc"
; CONFIG1L
  CONFIG  RETEN = ON            ; VREG Sleep Enable bit (Ultra low-power regulator is Enabled (Controlled by SRETEN bit))
  CONFIG  INTOSCSEL = HIGH      ; LF-INTOSC Low-power Enable bit (LF-INTOSC in High-power mode during Sleep)
  CONFIG  SOSCSEL = HIGH        ; SOSC Power Selection and mode Configuration bits (High Power SOSC circuit selected)
  CONFIG  XINST = OFF           ; Extended Instruction Set (Disabled)
; CONFIG1H
  CONFIG  FOSC = INTIO2         ; Oscillator (Internal RC oscillator)
  CONFIG  PLLCFG = OFF          ; PLL x4 Enable bit (Disabled)
  CONFIG  FCMEN = OFF           ; Fail-Safe Clock Monitor (Disabled)
  CONFIG  IESO = OFF            ; Internal External Oscillator Switch Over Mode (Disabled)
; CONFIG2L
  CONFIG  PWRTEN = ON           ; Power Up Timer (Enabled)
  CONFIG  BOREN = SBORDIS       ; Brown Out Detect (Enabled in hardware, SBOREN disabled)
  CONFIG  BORV = 3              ; Brown-out Reset Voltage bits (1.8V)
  CONFIG  BORPWR = ZPBORMV      ; BORMV Power level (ZPBORMV instead of BORMV is selected)
; CONFIG2H
  CONFIG  WDTEN = OFF           ; Watchdog Timer (WDT disabled in hardware; SWDTEN bit disabled)
  CONFIG  WDTPS = 1048576       ; Watchdog Postscaler (1:1048576)
; CONFIG3H
  CONFIG  CANMX = PORTB         ; ECAN Mux bit (ECAN TX and RX pins are located on RB2 and RB3, respectively)
  CONFIG  MSSPMSK = MSK7        ; MSSP address masking (7 Bit address masking mode)
  CONFIG  MCLRE = ON            ; Master Clear Enable (MCLR Enabled, RE3 Disabled)
; CONFIG4L
  CONFIG  STVREN = ON           ; Stack Overflow Reset (Enabled)
  CONFIG  BBSIZ = BB2K          ; Boot Block Size (2K word Boot Block size)
; CONFIG5L
  CONFIG  CP0 = OFF             ; Code Protect 00800-03FFF (Disabled)
  CONFIG  CP1 = OFF             ; Code Protect 04000-07FFF (Disabled)
  CONFIG  CP2 = OFF             ; Code Protect 08000-0BFFF (Disabled)
  CONFIG  CP3 = OFF             ; Code Protect 0C000-0FFFF (Disabled)
; CONFIG5H
  CONFIG  CPB = OFF             ; Code Protect Boot (Disabled)
  CONFIG  CPD = OFF             ; Data EE Read Protect (Disabled)
; CONFIG6L
  CONFIG  WRT0 = OFF            ; Table Write Protect 00800-03FFF (Disabled)
  CONFIG  WRT1 = OFF            ; Table Write Protect 04000-07FFF (Disabled)
  CONFIG  WRT2 = OFF            ; Table Write Protect 08000-0BFFF (Disabled)
  CONFIG  WRT3 = OFF            ; Table Write Protect 0C000-0FFFF (Disabled)
; CONFIG6H
  CONFIG  WRTC = OFF            ; Config. Write Protect (Disabled)
  CONFIG  WRTB = OFF            ; Table Write Protect Boot (Disabled)
  CONFIG  WRTD = OFF            ; Data EE Write Protect (Disabled)
; CONFIG7L
  CONFIG  EBTR0 = OFF           ; Table Read Protect 00800-03FFF (Disabled)
  CONFIG  EBTR1 = OFF           ; Table Read Protect 04000-07FFF (Disabled)
  CONFIG  EBTR2 = OFF           ; Table Read Protect 08000-0BFFF (Disabled)
  CONFIG  EBTR3 = OFF           ; Table Read Protect 0C000-0FFFF (Disabled)
; CONFIG7H
  CONFIG  EBTRB = OFF           ; Table Read Protect Boot (Disabled)
;=={DEFINITIONS}================================================================
;--{I/O PORTS}------------------------------------------------------------------
;--{CONSTANTS}------------------------------------------------------------------
;--{VARIABLES}------------------------------------------------------------------
     cblock    0x000
               W_TEMP, STATUS_TEMP,BSR_TEMP
               t,t1,t2,t3
     endc
;--{MACROES}--------------------------------------------------------------------
;==(PROGRAM START)==============================================================
	 org	   0x000	 ; start vector
     goto      main
;=={HIGH PRIORITY INTERRUPT VECTOR}=============================================
	 org	   0x008
     goto      ISR_CODE
;=={LOW PRIORITY INTERRUPT VECTOR}==============================================
;	 org	   0x018
;//{MAIN}\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
main:
     movlw     0x70
     movwf     OSCCON
     bcf       INTCON2,RBPU
     clrf      LATB
     movlw     0x03
     movwf     TRISB
     movlw     0x01
     movwf     PORTB
     clrf      PORTC
     clrf      LATC
     clrf      TRISC
     bsf       INTCON,INT0IE
     bcf       INTCON2,INTEDG0
     bsf       INTCON,GIE
main_loop:
     movlw     d'5'
     call      delay_100ms
     bcf       LATC,RC6
	 goto      main_loop
ISR_CODE:
     bcf       INTCON,INT0IF
     movff     WREG,W_TEMP         ; W_TEMP is in virtual bank
     MOVFF     STATUS, STATUS_TEMP ; STATUS_TEMP located anywhere
     MOVFF     BSR, BSR_TEMP       ; BSR_TMEP located anywhere
     bsf       LATC,RC6
     MOVFF     BSR_TEMP, BSR       ; Restore BSR
     MOVF      W_TEMP,W           ; Restore WREG
     MOVFF     STATUS_TEMP, STATUS ; Restore STATUS
     retfie
;=={SUBROUTINES}================================================================
     #include  "delay16MHz.inc"
;=={END Program}================================================================
	 end
