<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.3">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="1" unitdist="mic" unit="mic" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="yes"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="yes"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="yes"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="yes"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="yes"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="yes"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="yes"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="yes"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="yes"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="yes"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="yes"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="yes"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="yes"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="yes" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
<layer number="250" name="Descript" color="7" fill="1" visible="yes" active="yes"/>
<layer number="251" name="SMDround" color="7" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<description>Generated from &lt;b&gt;ADC_module.sch&lt;/b&gt;&lt;p&gt;
by exp-project-lbr.ulp</description>
<packages>
<package name="DIODE_C1702-15">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 3.5 mm, horizontal, grid 15.24 mm</description>
<wire x1="-4.572" y1="-1.778" x2="-4.572" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.572" y1="1.778" x2="-4.572" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.572" y1="1.778" x2="4.572" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-4.572" y1="-1.778" x2="4.572" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="7.62" y1="0" x2="6.096" y2="0" width="1.1176" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.096" y2="0" width="1.1176" layer="51"/>
<rectangle x1="-3.81" y1="-1.778" x2="-3.302" y2="1.778" layer="21"/>
<rectangle x1="4.572" y1="-0.5334" x2="5.9436" y2="0.5334" layer="21"/>
<rectangle x1="-5.9436" y1="-0.5334" x2="-4.572" y2="0.5334" layer="21"/>
<pad name="A" x="7.62" y="0" drill="1.397" shape="long"/>
<pad name="C" x="-7.62" y="0" drill="1.397" shape="long"/>
<text x="-4.572" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.794" y="-1.397" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIODE_DO13M">
diameter 6.35 mm metall, horizontal, grid 20.32 mm</description>
<wire x1="-7.239" y1="3.175" x2="-7.239" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-7.239" y1="-3.175" x2="1.905" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="1.905" y1="3.175" x2="-7.239" y2="3.175" width="0.1524" layer="21"/>
<wire x1="7.239" y1="-1.27" x2="7.239" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-3.175" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.27" x2="1.905" y2="3.175" width="0.1524" layer="21"/>
<wire x1="10.16" y1="0" x2="8.636" y2="0" width="0.9144" layer="51"/>
<wire x1="-8.636" y1="0" x2="-10.16" y2="0" width="0.9144" layer="51"/>
<wire x1="-4.191" y1="0" x2="-2.921" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="0" x2="-1.778" y2="0.5842" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.5842" x2="-1.778" y2="-0.5842" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.5842" x2="-2.921" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="0" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.4572" x2="-3.302" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.635" x2="-2.921" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="0.635" x2="-2.921" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.4572" x2="-2.54" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.635" x2="-2.921" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-0.635" x2="-2.921" y2="0" width="0.1524" layer="21"/>
<wire x1="2.794" y1="-1.27" x2="6.35" y2="-1.27" width="0.1524" layer="21" curve="-86.050132"/>
<wire x1="2.794" y1="1.27" x2="6.35" y2="1.27" width="0.1524" layer="21" curve="86.050132"/>
<wire x1="7.239" y1="1.27" x2="6.35" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.794" y1="1.27" x2="1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="2.794" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-1.27" x2="7.239" y2="-1.27" width="0.1524" layer="21"/>
<rectangle x1="7.239" y1="-0.4318" x2="8.7122" y2="0.4318" layer="21"/>
<rectangle x1="-8.7122" y1="-0.4318" x2="-7.239" y2="0.4318" layer="21"/>
<rectangle x1="-6.731" y1="-3.175" x2="-6.096" y2="3.175" layer="21"/>
<pad name="A" x="10.16" y="0" drill="1.1938" shape="long"/>
<pad name="C" x="-10.16" y="0" drill="1.1938" shape="long"/>
<text x="-7.239" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.461" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIODE_DO34Z7">
diameter 1.8 mm, horizontal, grid 7.62 mm</description>
<wire x1="-1.524" y1="-0.889" x2="1.524" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.889" x2="-1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-0.889" x2="1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.889" x2="-1.524" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-0.508" y1="0" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="0.889" y1="0.508" x2="0.889" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-0.508" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="1.27" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="0.889" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="-0.127" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.127" y1="0.508" x2="-0.127" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0.508" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<rectangle x1="-1.143" y1="-0.889" x2="-0.762" y2="0.889" layer="21"/>
<rectangle x1="1.524" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-1.524" y2="0.254" layer="21"/>
<pad name="A" x="3.81" y="0" drill="0.8128" shape="long"/>
<pad name="C" x="-3.81" y="0" drill="0.8128" shape="long"/>
<text x="-1.524" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIODE_DO35Z10">
diameter 2 mm, horizontal, grid 10.16mm</description>
<wire x1="5.08" y1="0" x2="4.191" y2="0" width="0.508" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.191" y2="0" width="0.508" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0.635" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="2.032" y1="1.016" x2="2.286" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="0.762" x2="-2.032" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="-0.762" x2="-2.032" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.032" y1="-1.016" x2="2.286" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="0.762" x2="2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0.762" x2="-2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.016" x2="2.032" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.016" x2="2.032" y2="-1.016" width="0.1524" layer="21"/>
<rectangle x1="-1.905" y1="-1.016" x2="-1.397" y2="1.016" layer="21"/>
<rectangle x1="2.286" y1="-0.254" x2="4.191" y2="0.254" layer="21"/>
<rectangle x1="-4.191" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
<pad name="A" x="5.08" y="0" drill="0.8128" shape="long"/>
<pad name="C" x="-5.08" y="0" drill="0.8128" shape="long"/>
<text x="-2.286" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIODE_DO41Z10">
diameter 2.54 mm, horizontal, grid 10.16 mm</description>
<wire x1="2.032" y1="-1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="3.937" y2="0" width="0.762" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.762" layer="51"/>
<rectangle x1="-1.651" y1="-1.27" x2="-1.143" y2="1.27" layer="21"/>
<rectangle x1="2.032" y1="-0.381" x2="3.937" y2="0.381" layer="21"/>
<rectangle x1="-3.937" y1="-0.381" x2="-2.032" y2="0.381" layer="21"/>
<pad name="A" x="5.08" y="0" drill="1.1176"/>
<pad name="C" x="-5.08" y="0" drill="1.1176"/>
<text x="-1.905" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.905" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIODE_F126Z10">
diameter 3 mm, horizontal, grid 10.16 mm</description>
<wire x1="-3.175" y1="-1.524" x2="3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.524" x2="-3.175" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.524" x2="3.175" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.524" x2="-3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="3.81" y2="0" width="0.8128" layer="51"/>
<wire x1="-5.08" y1="0" x2="-3.81" y2="0" width="0.8128" layer="51"/>
<rectangle x1="-2.54" y1="-1.524" x2="-1.778" y2="1.524" layer="21"/>
<rectangle x1="3.175" y1="-0.4064" x2="3.7338" y2="0.4064" layer="21"/>
<rectangle x1="-3.7338" y1="-0.4064" x2="-3.175" y2="0.4064" layer="21"/>
<pad name="A" x="5.08" y="0" drill="1.016" shape="long"/>
<pad name="C" x="-5.08" y="0" drill="1.016" shape="long"/>
<text x="-3.175" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIODE_F126Z12">
diameter 3 mm, horizontal, grid 12.7 mm</description>
<wire x1="6.35" y1="0" x2="4.826" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.35" y1="0" x2="-4.826" y2="0" width="0.8128" layer="51"/>
<rectangle x1="-4.8514" y1="-0.4064" x2="-3.175" y2="0.4064" layer="21"/>
<rectangle x1="3.175" y1="-0.4064" x2="4.8514" y2="0.4064" layer="21"/>
<pad name="A" x="6.35" y="0" drill="1.016" shape="long"/>
<pad name="C" x="-6.35" y="0" drill="1.016" shape="long"/>
</package>
<package name="DIODE_P1Z12">
<wire x1="6.35" y1="0" x2="5.334" y2="0" width="0.762" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.334" y2="0" width="0.762" layer="51"/>
<rectangle x1="-2.794" y1="-1.524" x2="-2.032" y2="1.524" layer="21"/>
<rectangle x1="3.175" y1="-0.381" x2="5.207" y2="0.381" layer="21"/>
<rectangle x1="-5.207" y1="-0.381" x2="-3.175" y2="0.381" layer="21"/>
<pad name="A" x="6.35" y="0" drill="1.1176" shape="long"/>
<pad name="C" x="-6.35" y="0" drill="1.1176" shape="long"/>
<text x="-3.048" y="1.778" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.048" y="-3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIODE_SMB">
<description>&lt;B&gt;DIODE&lt;/B&gt;</description>
<wire x1="-2.2606" y1="1.905" x2="2.2606" y2="1.905" width="0.1016" layer="21"/>
<wire x1="-2.2606" y1="-1.905" x2="2.2606" y2="-1.905" width="0.1016" layer="21"/>
<wire x1="-2.2606" y1="-1.905" x2="-2.2606" y2="1.905" width="0.1016" layer="51"/>
<wire x1="2.2606" y1="-1.905" x2="2.2606" y2="1.905" width="0.1016" layer="51"/>
<wire x1="0.193" y1="1" x2="-0.83" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.83" y1="0" x2="0.193" y2="-1" width="0.2032" layer="21"/>
<wire x1="0.193" y1="-1" x2="0.193" y2="1" width="0.2032" layer="21"/>
<rectangle x1="-2.794" y1="-1.0922" x2="-2.2606" y2="1.0922" layer="51"/>
<rectangle x1="2.2606" y1="-1.0922" x2="2.794" y2="1.0922" layer="51"/>
<rectangle x1="-1.35" y1="-1.9" x2="-0.8" y2="1.9" layer="51"/>
<smd name="A" x="2.2" y="0" dx="2.4" dy="2.4" layer="1"/>
<smd name="C" x="-2.2" y="0" dx="2.4" dy="2.4" layer="1"/>
<text x="-2.159" y="2.159" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.159" y="-3.429" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="DIODE_SOD57Z10">
diameter 4 mm, vertical, grid 10.16 mm</description>
<wire x1="-1.143" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="0.508" y1="0.635" x2="0.508" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.508" y1="-0.635" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="1.016" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="0.508" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.016" x2="-2.286" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.016" x2="2.286" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.016" x2="1.397" y2="1.016" width="0.1524" layer="21" curve="-131.11209"/>
<wire x1="-1.397" y1="-1.016" x2="1.397" y2="-1.016" width="0.1524" layer="21" curve="131.11209"/>
<wire x1="-2.286" y1="1.016" x2="-1.397" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.016" x2="1.397" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.016" x2="-1.397" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.397" y1="-1.016" x2="2.286" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="0.635" x2="-0.508" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.635" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<rectangle x1="-3.8354" y1="-0.4064" x2="-2.286" y2="0.4064" layer="21"/>
<rectangle x1="2.286" y1="-0.4064" x2="3.8354" y2="0.4064" layer="21"/>
<pad name="A" x="5.08" y="0" drill="1.1938" shape="long"/>
<pad name="C" x="-5.08" y="0" drill="1.1938" shape="long"/>
<text x="-2.286" y="2.286" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.556" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIODE_SOD64Z10">
diameter 4.8 mm, vertical, grid 10.16 mm</description>
<wire x1="5.08" y1="0" x2="3.556" y2="0" width="1.3716" layer="51"/>
<wire x1="-5.08" y1="0" x2="-3.556" y2="0" width="1.3716" layer="51"/>
<wire x1="-2.54" y1="1.397" x2="-2.54" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.397" x2="2.54" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.397" x2="1.397" y2="1.397" width="0.1524" layer="21" curve="-131.11209"/>
<wire x1="-1.397" y1="-1.397" x2="1.397" y2="-1.397" width="0.1524" layer="21" curve="131.11209"/>
<wire x1="-2.54" y1="1.397" x2="-1.397" y2="1.397" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.397" x2="1.397" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.397" x2="-1.397" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="1.397" y1="-1.397" x2="2.54" y2="-1.397" width="0.1524" layer="21"/>
<rectangle x1="-1.905" y1="-1.397" x2="-1.397" y2="1.397" layer="21"/>
<rectangle x1="2.54" y1="-0.6604" x2="3.3274" y2="0.6604" layer="21"/>
<rectangle x1="-3.3274" y1="-0.6604" x2="-2.54" y2="0.6604" layer="21"/>
<pad name="A" x="5.08" y="0" drill="1.6002" shape="long"/>
<pad name="C" x="-5.08" y="0" drill="1.6002" shape="long"/>
<text x="-2.54" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.937" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIODE_SOD64Z12">
diameter 4.8 mm, vertical, grid 12.7 mm</description>
<wire x1="6.35" y1="0" x2="4.826" y2="0" width="1.3716" layer="51"/>
<wire x1="-6.35" y1="0" x2="-4.826" y2="0" width="1.3716" layer="51"/>
<rectangle x1="2.54" y1="-0.6604" x2="4.572" y2="0.6604" layer="21"/>
<rectangle x1="-4.572" y1="-0.6604" x2="-2.54" y2="0.6604" layer="21"/>
<pad name="A" x="6.35" y="0" drill="1.6002" shape="long"/>
<pad name="C" x="-6.35" y="0" drill="1.6002" shape="long"/>
</package>
<package name="DIODE_SOD80C">
<wire x1="1.3208" y1="0.7874" x2="-1.3208" y2="0.7874" width="0.1524" layer="51"/>
<wire x1="1.3208" y1="-0.7874" x2="-1.3208" y2="-0.7874" width="0.1524" layer="51"/>
<wire x1="0.627" y1="0.6" x2="-0.373" y2="0" width="0.2032" layer="21"/>
<wire x1="-0.373" y1="0" x2="0.627" y2="-0.6" width="0.2032" layer="21"/>
<wire x1="0.627" y1="-0.6" x2="0.627" y2="0.6" width="0.2032" layer="21"/>
<rectangle x1="-1.8542" y1="-0.8636" x2="-1.2954" y2="0.8636" layer="51"/>
<rectangle x1="1.2954" y1="-0.8636" x2="1.8542" y2="0.8636" layer="51"/>
<rectangle x1="-0.8636" y1="-0.7874" x2="-0.254" y2="0.7874" layer="21"/>
<smd name="A" x="1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<smd name="C" x="-1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<text x="-1.524" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="DIODE_SOT23">
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="-0.1524" x2="-1.4224" y2="0.6604" width="0.1524" layer="21"/>
<wire x1="-1.4224" y1="0.6604" x2="-0.8636" y2="0.6604" width="0.1524" layer="21"/>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.1524" width="0.1524" layer="21"/>
<wire x1="0.8636" y1="0.6604" x2="1.4224" y2="0.6604" width="0.1524" layer="21"/>
<rectangle x1="-0.2286" y1="0.7112" x2="0.2286" y2="1.2954" layer="51"/>
<rectangle x1="0.7112" y1="-1.2954" x2="1.1684" y2="-0.7112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.2954" x2="-0.7112" y2="-0.7112" layer="51"/>
<smd name="1" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="2" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="3" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="DIODE_SOT223">
<description>&lt;b&gt;Small Outline Transistor&lt;/b&gt;</description>
<wire x1="3.277" y1="1.778" x2="3.277" y2="-1.778" width="0.2032" layer="21"/>
<wire x1="3.277" y1="-1.778" x2="-3.277" y2="-1.778" width="0.2032" layer="21"/>
<wire x1="-3.277" y1="-1.778" x2="-3.277" y2="1.778" width="0.2032" layer="21"/>
<wire x1="-3.277" y1="1.778" x2="3.277" y2="1.778" width="0.2032" layer="21"/>
<rectangle x1="-1.6002" y1="1.8034" x2="1.6002" y2="3.6576" layer="51"/>
<rectangle x1="-0.4318" y1="-3.6576" x2="0.4318" y2="-1.8034" layer="51"/>
<rectangle x1="-2.7432" y1="-3.6576" x2="-1.8796" y2="-1.8034" layer="51"/>
<rectangle x1="1.8796" y1="-3.6576" x2="2.7432" y2="-1.8034" layer="51"/>
<smd name="1" x="-2.311" y="-3.099" dx="1.219" dy="2.235" layer="1"/>
<smd name="2" x="0" y="-3.099" dx="1.219" dy="2.235" layer="1"/>
<smd name="3" x="2.311" y="-3.099" dx="1.219" dy="2.235" layer="1"/>
<smd name="4" x="0" y="3.099" dx="3.6" dy="2.2" layer="1"/>
<text x="-2.54" y="0.0508" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-1.3208" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="DIODE_TO236">
3-lead smd</description>
<wire x1="-1.4" y1="1.15" x2="-0.7" y2="1.15" width="0.2032" layer="21"/>
<wire x1="-1.4" y1="1.15" x2="-1.4" y2="-0.2" width="0.2032" layer="21"/>
<wire x1="-0.3" y1="-1.15" x2="0.3" y2="-1.15" width="0.2032" layer="21"/>
<wire x1="1.4" y1="-0.2" x2="1.4" y2="1.15" width="0.2032" layer="21"/>
<wire x1="1.4" y1="1.15" x2="0.7" y2="1.15" width="0.2032" layer="21"/>
<wire x1="-0.7" y1="1.15" x2="0.7" y2="1.15" width="0.2032" layer="51"/>
<wire x1="-1.4" y1="-0.2" x2="-1.4" y2="-1.15" width="0.2032" layer="51"/>
<wire x1="-1.4" y1="-1.15" x2="-0.3" y2="-1.15" width="0.2032" layer="51"/>
<wire x1="0.3" y1="-1.15" x2="1.4" y2="-1.15" width="0.2032" layer="51"/>
<wire x1="1.4" y1="-1.15" x2="1.4" y2="-0.2" width="0.2032" layer="51"/>
<rectangle x1="-0.2" y1="0.6" x2="0.2" y2="1.25" layer="51"/>
<rectangle x1="-1.2" y1="-1.25" x2="-0.8" y2="-0.6" layer="51"/>
<rectangle x1="0.8" y1="-1.25" x2="1.2" y2="-0.6" layer="51"/>
<smd name="A" x="-1" y="-1" dx="1" dy="1.2" layer="16"/>
<smd name="C" x="0" y="1" dx="1" dy="1.2" layer="16"/>
<smd name="NC" x="1" y="-1" dx="1" dy="1.2" layer="16"/>
<text x="-1.397" y="1.794" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.524" y="-3.064" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="DIODE_ZDIO-2.5">
<description>&lt;b&gt;Z DIODE&lt;/b&gt;</description>
<wire x1="-0.254" y1="0.762" x2="-0.508" y2="0.762" width="0.254" layer="21"/>
<wire x1="-0.508" y1="0" x2="0.762" y2="0.762" width="0.254" layer="21"/>
<wire x1="0.762" y1="-0.762" x2="-0.508" y2="0" width="0.254" layer="21"/>
<wire x1="-0.508" y1="0.762" x2="-0.508" y2="0" width="0.254" layer="21"/>
<wire x1="0.762" y1="0.762" x2="0.762" y2="-0.762" width="0.254" layer="51"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.508" y1="-0.762" x2="-0.762" y2="-0.762" width="0.254" layer="21"/>
<wire x1="0.508" y1="0.254" x2="0.508" y2="0" width="0.6096" layer="51"/>
<wire x1="0.508" y1="0" x2="0.508" y2="-0.254" width="0.6096" layer="51"/>
<wire x1="0.508" y1="0" x2="-0.254" y2="0" width="0.6096" layer="51"/>
<pad name="A" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="C" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-1.3462" y="1.0668" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIODE_ZDIO-5">
<wire x1="0" y1="1.27" x2="-1.27" y2="1.27" width="0.254" layer="21"/>
<wire x1="-1.27" y1="0" x2="1.27" y2="1.27" width="0.254" layer="21"/>
<wire x1="1.27" y1="1.27" x2="1.27" y2="0" width="0.254" layer="21"/>
<wire x1="1.27" y1="-1.27" x2="-1.27" y2="0" width="0.254" layer="21"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="0" width="0.254" layer="21"/>
<wire x1="1.27" y1="0" x2="1.651" y2="0" width="0.254" layer="21"/>
<wire x1="1.27" y1="0" x2="1.27" y2="-1.27" width="0.254" layer="21"/>
<wire x1="-1.651" y1="0" x2="-1.27" y2="0" width="0.254" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-1.27" width="0.254" layer="21"/>
<wire x1="-1.27" y1="-1.27" x2="-2.54" y2="-1.27" width="0.254" layer="21"/>
<pad name="A" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="C" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.6162" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.54" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="DIODE_ZDIO-7.5">
<wire x1="1.27" y1="0" x2="2.794" y2="0" width="0.254" layer="21"/>
<wire x1="-2.794" y1="0" x2="-1.27" y2="0" width="0.254" layer="21"/>
<pad name="A" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="C" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.4892" y="1.7018" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="DIODE_ZDIO-10">
<wire x1="-3.556" y1="0" x2="-1.27" y2="0" width="0.254" layer="21"/>
<wire x1="1.27" y1="0" x2="3.556" y2="0" width="0.254" layer="21"/>
<text x="-2.4892" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="DIODE_ZDIO12.5">
<wire x1="1.27" y1="0" x2="4.699" y2="0" width="0.254" layer="21"/>
<wire x1="-4.826" y1="0" x2="-1.27" y2="0" width="0.254" layer="21"/>
<pad name="A" x="6.223" y="0" drill="0.8128" shape="long"/>
<pad name="C" x="-6.35" y="0" drill="0.8128" shape="long"/>
<text x="-2.6162" y="1.7018" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.667" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="IC-PACKAGE_DIL24-3">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt; 0.3 inch</description>
<wire x1="-14.986" y1="-0.635" x2="-14.986" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-14.986" y1="0.635" x2="-14.986" y2="-0.635" width="0.1524" layer="21" curve="-180"/>
<wire x1="14.986" y1="-2.794" x2="14.986" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-14.986" y1="-2.794" x2="14.986" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-14.986" y1="2.794" x2="14.986" y2="2.794" width="0.1524" layer="21"/>
<wire x1="-14.986" y1="2.794" x2="-14.986" y2="0.635" width="0.1524" layer="21"/>
<pad name="1" x="-13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="6.35" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="8.89" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="13.97" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="-6.35" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-8.89" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-11.43" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-13.97" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-15.2908" y="-2.667" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-13.462" y="-0.889" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="IC-PACKAGE_DIL24-4">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt; 0.4 inch</description>
<wire x1="-15.367" y1="-0.635" x2="-15.367" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-15.367" y1="0.635" x2="-15.367" y2="-0.635" width="0.1524" layer="21" curve="-180"/>
<wire x1="15.367" y1="-4.064" x2="15.367" y2="4.064" width="0.1524" layer="21"/>
<wire x1="-15.367" y1="-4.064" x2="15.367" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-15.367" y1="4.064" x2="-15.367" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-15.367" y1="4.064" x2="15.367" y2="4.064" width="0.1524" layer="21"/>
<pad name="1" x="-13.97" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-11.43" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-8.89" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-6.35" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-3.81" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-1.27" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="1.27" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="3.81" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="6.35" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="8.89" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="13.97" y="-5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="11.43" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="8.89" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="6.35" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="3.81" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="1.27" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-1.27" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-3.81" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="-6.35" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-8.89" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-11.43" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-13.97" y="5.08" drill="0.8128" shape="long" rot="R90"/>
<text x="-15.6464" y="-3.81" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-12.7" y="-0.8382" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="IC-PACKAGE_DIL24-6">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt; 0.6 inch</description>
<wire x1="-15.113" y1="-1.27" x2="-15.113" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="1.27" x2="-15.113" y2="-1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="15.113" y1="-6.604" x2="15.113" y2="6.604" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="6.604" x2="-15.113" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="6.604" x2="15.113" y2="6.604" width="0.1524" layer="21"/>
<wire x1="-15.113" y1="-6.604" x2="15.113" y2="-6.604" width="0.1524" layer="21"/>
<pad name="1" x="-13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="1.27" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="3.81" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="6.35" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="8.89" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="13.97" y="-7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-1.27" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-3.81" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="-6.35" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-8.89" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-11.43" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-13.97" y="7.62" drill="0.8128" shape="long" rot="R90"/>
<text x="-15.621" y="-6.35" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-12.065" y="-0.889" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="IC-PACKAGE_DIL24-9">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt; 0.9 inch</description>
<wire x1="-16.129" y1="-1.27" x2="-16.129" y2="-10.414" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="1.27" x2="-16.129" y2="-1.27" width="0.1524" layer="21" curve="-180"/>
<wire x1="16.129" y1="-10.414" x2="16.129" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="10.414" x2="-16.129" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="10.414" x2="16.129" y2="10.414" width="0.1524" layer="21"/>
<wire x1="-16.129" y1="-10.414" x2="16.129" y2="-10.414" width="0.1524" layer="21"/>
<pad name="1" x="-13.97" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-11.43" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="-8.89" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="-6.35" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="-3.81" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="-1.27" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="1.27" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="3.81" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="9" x="6.35" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="10" x="8.89" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="11" x="11.43" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="12" x="13.97" y="-11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="13" x="13.97" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="14" x="11.43" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="15" x="8.89" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="16" x="6.35" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="17" x="3.81" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="18" x="1.27" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="19" x="-1.27" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="20" x="-3.81" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="21" x="-6.35" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="22" x="-8.89" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="23" x="-11.43" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<pad name="24" x="-13.97" y="11.43" drill="0.8128" shape="long" rot="R90"/>
<text x="-16.51" y="-9.906" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-11.43" y="-0.635" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_0204/5">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0204, grid 5 mm</description>
<wire x1="2.54" y1="0" x2="2.032" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0" x2="-2.032" y2="0" width="0.508" layer="51"/>
<wire x1="-1.778" y1="0.635" x2="-1.524" y2="0.889" width="0.1524" layer="21" curve="-90" cap="flat"/>
<wire x1="-1.778" y1="-0.635" x2="-1.524" y2="-0.889" width="0.1524" layer="21" curve="90" cap="flat"/>
<wire x1="1.524" y1="-0.889" x2="1.778" y2="-0.635" width="0.1524" layer="21" curve="90" cap="flat"/>
<wire x1="1.524" y1="0.889" x2="1.778" y2="0.635" width="0.1524" layer="21" curve="-90" cap="flat"/>
<wire x1="-1.778" y1="-0.635" x2="-1.778" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-1.524" y1="0.889" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.762" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-0.889" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-0.762" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.762" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.762" x2="-1.143" y2="0.762" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.762" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.762" x2="-1.143" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.889" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-0.889" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.635" x2="1.778" y2="0.635" width="0.1524" layer="51"/>
<rectangle x1="-2.032" y1="-0.254" x2="-1.778" y2="0.254" layer="51"/>
<rectangle x1="1.778" y1="-0.254" x2="2.032" y2="0.254" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.0066" y="1.1684" size="0.9906" layer="25" ratio="12">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="0.9906" layer="27" ratio="12">&gt;VALUE</text>
</package>
<package name="RCL_0204/7">
type 0204, grid 7.5 mm</description>
<wire x1="-2.54" y1="0.762" x2="-2.286" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.286" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="-1.016" x2="2.54" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.016" x2="2.54" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.54" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.016" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.889" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.016" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.889" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="-1.778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="-1.778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.016" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.016" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.762" x2="2.54" y2="0.762" width="0.1524" layer="21"/>
<rectangle x1="2.54" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.54" y2="0.254" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="1.2954" size="0.9906" layer="25" ratio="12">&gt;NAME</text>
<text x="-1.6256" y="-0.4826" size="0.9906" layer="27" ratio="12">&gt;VALUE</text>
</package>
<package name="RCL_0204V">
type 0204, grid 2.5 mm</description>
<circle x="-1.27" y="0" radius="0.889" width="0.1524" layer="51"/>
<circle x="-1.27" y="0" radius="0.635" width="0.0508" layer="51"/>
<wire x1="-1.27" y1="0" x2="1.27" y2="0" width="0.508" layer="51"/>
<wire x1="-0.127" y1="0" x2="0.127" y2="0" width="0.508" layer="21"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.1336" y="1.1684" size="1.27" layer="25" ratio="12">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="1.27" layer="27" ratio="12">&gt;VALUE</text>
</package>
<package name="RCL_0207/2V">
type 0207, grid 2.5 mm</description>
<circle x="-1.27" y="0" radius="1.27" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="1.016" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0" x2="-0.381" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.254" y1="0" x2="0.254" y2="0" width="0.6096" layer="21"/>
<wire x1="0.381" y1="0" x2="1.27" y2="0" width="0.6096" layer="51"/>
<text x="-0.0508" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.0508" y="-2.2352" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_0207/5V">
type 0207, grid 5 mm</description>
<circle x="-2.54" y="0" radius="1.27" width="0.1016" layer="21"/>
<circle x="-2.54" y="0" radius="1.016" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="0" x2="-0.889" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.762" y1="0" x2="0.762" y2="0" width="0.6096" layer="21"/>
<wire x1="0.889" y1="0" x2="2.54" y2="0" width="0.6096" layer="51"/>
<text x="-1.143" y="0.889" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.143" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_0207/7">
type 0207, grid 7.5 mm</description>
<wire x1="-3.81" y1="0" x2="-3.429" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90" cap="flat"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90" cap="flat"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90" cap="flat"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90" cap="flat"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="3.429" y1="0" x2="3.81" y2="0" width="0.6096" layer="51"/>
<rectangle x1="-3.429" y1="-0.3048" x2="-3.175" y2="0.3048" layer="51"/>
<rectangle x1="3.175" y1="-0.3048" x2="3.429" y2="0.3048" layer="51"/>
<text x="-2.54" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.5588" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_0207/10">
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_0207/12">
type 0207, grid 12 mm</description>
<wire x1="6.35" y1="0" x2="5.334" y2="0" width="0.6096" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.334" y2="0" width="0.6096" layer="51"/>
<wire x1="4.445" y1="0" x2="4.064" y2="0" width="0.6096" layer="21"/>
<wire x1="-4.445" y1="0" x2="-4.064" y2="0" width="0.6096" layer="21"/>
<rectangle x1="4.445" y1="-0.3048" x2="5.3086" y2="0.3048" layer="21"/>
<rectangle x1="-5.3086" y1="-0.3048" x2="-4.445" y2="0.3048" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.175" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.6858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_0207/15">
type 0207, grid 15mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.6096" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.6096" layer="51"/>
<wire x1="5.715" y1="0" x2="4.064" y2="0" width="0.6096" layer="21"/>
<wire x1="-5.715" y1="0" x2="-4.064" y2="0" width="0.6096" layer="21"/>
<rectangle x1="5.715" y1="-0.3048" x2="6.5786" y2="0.3048" layer="21"/>
<rectangle x1="-6.5786" y1="-0.3048" x2="-5.715" y2="0.3048" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.8128" shape="octagon"/>
</package>
<package name="RCL_0309/10">
type 0309, grid 10mm</description>
<wire x1="-4.699" y1="0" x2="-5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-4.318" y1="1.27" x2="-4.064" y2="1.524" width="0.1524" layer="21" curve="-90" cap="flat"/>
<wire x1="-4.318" y1="-1.27" x2="-4.064" y2="-1.524" width="0.1524" layer="21" curve="90" cap="flat"/>
<wire x1="4.064" y1="-1.524" x2="4.318" y2="-1.27" width="0.1524" layer="21" curve="90" cap="flat"/>
<wire x1="4.064" y1="1.524" x2="4.318" y2="1.27" width="0.1524" layer="21" curve="-90" cap="flat"/>
<wire x1="-4.318" y1="-1.27" x2="-4.318" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-4.064" y1="1.524" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.397" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="-1.524" x2="-3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-1.397" x2="-3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="1.397" x2="3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="1.397" x2="-3.302" y2="1.397" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-1.397" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-1.397" x2="-3.302" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="4.064" y1="1.524" x2="3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-1.524" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-1.27" x2="4.318" y2="1.27" width="0.1524" layer="51"/>
<wire x1="5.08" y1="0" x2="4.699" y2="0" width="0.6096" layer="51"/>
<rectangle x1="-4.6228" y1="-0.3048" x2="-4.318" y2="0.3048" layer="51"/>
<rectangle x1="4.318" y1="-0.3048" x2="4.6228" y2="0.3048" layer="51"/>
<text x="-4.191" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-0.6858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_0309/12">
type 0309, grid 12.5 mm</description>
<wire x1="6.35" y1="0" x2="5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-4.318" y1="1.27" x2="-4.064" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.318" y1="-1.27" x2="-4.064" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="4.064" y1="-1.524" x2="4.318" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="4.064" y1="1.524" x2="4.318" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.318" y1="-1.27" x2="-4.318" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-1.27" x2="4.318" y2="1.27" width="0.1524" layer="21"/>
<rectangle x1="4.318" y1="-0.3048" x2="5.1816" y2="0.3048" layer="21"/>
<rectangle x1="-5.1816" y1="-0.3048" x2="-4.318" y2="0.3048" layer="21"/>
</package>
<package name="RCL_0309V">
type 0309, grid 2.5 mm</description>
<circle x="-1.27" y="0" radius="1.524" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="0.762" width="0.1524" layer="51"/>
<wire x1="1.27" y1="0" x2="0.635" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.635" y1="0" x2="-1.27" y2="0" width="0.6096" layer="51"/>
<rectangle x1="0.254" y1="-0.3048" x2="0.5588" y2="0.3048" layer="51"/>
<rectangle x1="-0.635" y1="-0.3048" x2="-0.3302" y2="0.3048" layer="51"/>
<rectangle x1="-0.3302" y1="-0.3048" x2="0.254" y2="0.3048" layer="21"/>
<text x="0.254" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.254" y="-2.2098" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_0411/12">
type 0411, grid 12.5 mm</description>
<wire x1="6.35" y1="0" x2="5.461" y2="0" width="0.762" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.461" y2="0" width="0.762" layer="51"/>
<wire x1="5.08" y1="-1.651" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.032" x2="5.08" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.08" y1="-1.651" x2="-4.699" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="4.699" y1="-2.032" x2="5.08" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.651" x2="-4.699" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="2.032" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="1.905" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.032" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="-1.905" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="3.937" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="3.937" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.651" x2="-5.08" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.032" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-2.032" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<rectangle x1="-5.3594" y1="-0.381" x2="-5.08" y2="0.381" layer="21"/>
<rectangle x1="5.08" y1="-0.381" x2="5.3594" y2="0.381" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="0.9144" shape="octagon"/>
<text x="-5.08" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.5814" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_0411/15">
type 0411, grid 15 mm</description>
<wire x1="-7.62" y1="0" x2="-6.35" y2="0" width="0.762" layer="51"/>
<wire x1="6.35" y1="0" x2="7.62" y2="0" width="0.762" layer="51"/>
<rectangle x1="5.08" y1="-0.381" x2="6.477" y2="0.381" layer="21"/>
<rectangle x1="-6.477" y1="-0.381" x2="-5.08" y2="0.381" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.9144" shape="octagon"/>
</package>
<package name="RCL_0411V">
type 0411, grid 3.81 mm</description>
<circle x="-2.54" y="0" radius="2.032" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0" x2="0.3048" y2="0" width="0.762" layer="51"/>
<wire x1="-1.5748" y1="0" x2="-2.54" y2="0" width="0.762" layer="51"/>
<rectangle x1="-1.4732" y1="-0.381" x2="0.2032" y2="0.381" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.9144" shape="octagon"/>
<text x="-0.508" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.5334" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_0414/15">
type 0414, grid 15 mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.096" y1="1.905" x2="-5.842" y2="2.159" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.096" y1="-1.905" x2="-5.842" y2="-2.159" width="0.1524" layer="21" curve="90"/>
<wire x1="5.842" y1="-2.159" x2="6.096" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<wire x1="5.842" y1="2.159" x2="6.096" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.096" y1="-1.905" x2="-6.096" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="2.159" x2="-4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.032" x2="-4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-2.159" x2="-4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.032" x2="-4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.032" x2="4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.032" x2="-4.826" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="5.842" y1="2.159" x2="4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-2.159" x2="4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-1.905" x2="6.096" y2="1.905" width="0.1524" layer="21"/>
<rectangle x1="6.096" y1="-0.4064" x2="6.5024" y2="0.4064" layer="21"/>
<rectangle x1="-6.5024" y1="-0.4064" x2="-6.096" y2="0.4064" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="1.016" shape="octagon"/>
<text x="-6.096" y="2.5654" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_0414V">
type 0414, grid 5 mm</description>
<circle x="-2.54" y="0" radius="2.159" width="0.1524" layer="21"/>
<circle x="-2.54" y="0" radius="1.143" width="0.1524" layer="51"/>
<wire x1="2.54" y1="0" x2="1.397" y2="0" width="0.8128" layer="51"/>
<wire x1="-2.54" y1="0" x2="-1.397" y2="0" width="0.8128" layer="51"/>
<rectangle x1="-1.2954" y1="-0.4064" x2="1.2954" y2="0.4064" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="1.016" shape="octagon"/>
<text x="-0.381" y="1.1684" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.381" y="-2.3622" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_0617/17">
type 0617, grid 17.5 mm</description>
<wire x1="-8.89" y1="0" x2="-8.636" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.874" y1="3.048" x2="-6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.794" x2="-6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-3.048" x2="-6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-2.794" x2="-6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="2.794" x2="6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="2.794" x2="-6.731" y2="2.794" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.794" x2="6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.794" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="7.874" y1="3.048" x2="6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="7.874" y1="-3.048" x2="6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-2.667" x2="-8.255" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="1.016" x2="-8.255" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="1.016" x2="-8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.667" x2="8.255" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="8.255" y1="1.016" x2="8.255" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="8.255" y1="1.016" x2="8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.636" y1="0" x2="8.89" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.255" y1="2.667" x2="-7.874" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="7.874" y1="3.048" x2="8.255" y2="2.667" width="0.1524" layer="21" curve="-90"/>
<wire x1="-8.255" y1="-2.667" x2="-7.874" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="7.874" y1="-3.048" x2="8.255" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<rectangle x1="-8.5344" y1="-0.4064" x2="-8.2296" y2="0.4064" layer="51"/>
<rectangle x1="8.2296" y1="-0.4064" x2="8.5344" y2="0.4064" layer="51"/>
<pad name="1" x="-8.89" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="8.89" y="0" drill="1.016" shape="octagon"/>
<text x="-8.128" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.096" y="-0.7112" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_0617/22">
type 0617, grid 22.5 mm</description>
<wire x1="-10.287" y1="0" x2="-11.43" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.255" y1="-2.667" x2="-8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.667" x2="8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="10.287" y2="0" width="0.8128" layer="51"/>
<rectangle x1="-10.1854" y1="-0.4064" x2="-8.255" y2="0.4064" layer="21"/>
<rectangle x1="8.255" y1="-0.4064" x2="10.1854" y2="0.4064" layer="21"/>
<pad name="1" x="-11.43" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="11.43" y="0" drill="1.016" shape="octagon"/>
<text x="-8.255" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.477" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_0617V">
type 0617, grid 5 mm</description>
<circle x="-2.54" y="0" radius="3.048" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0" x2="-1.27" y2="0" width="0.8128" layer="51"/>
<wire x1="1.27" y1="0" x2="2.54" y2="0" width="0.8128" layer="51"/>
<rectangle x1="-1.3208" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
<text x="0.635" y="1.4224" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.635" y="-2.6162" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_0922/22">
type 0922, grid 22.5 mm</description>
<wire x1="11.43" y1="0" x2="10.795" y2="0" width="0.8128" layer="51"/>
<wire x1="-11.43" y1="0" x2="-10.795" y2="0" width="0.8128" layer="51"/>
<wire x1="-10.16" y1="-4.191" x2="-10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="4.572" x2="-8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="4.318" x2="-8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="-4.572" x2="-8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="-4.318" x2="-8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="4.318" x2="8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="4.318" x2="-8.636" y2="4.318" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-4.318" x2="8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-4.318" x2="-8.636" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="9.779" y1="4.572" x2="8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="9.779" y1="-4.572" x2="8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.191" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.191" x2="-9.779" y2="-4.572" width="0.1524" layer="21" curve="90"/>
<wire x1="-10.16" y1="4.191" x2="-9.779" y2="4.572" width="0.1524" layer="21" curve="-90"/>
<wire x1="9.779" y1="-4.572" x2="10.16" y2="-4.191" width="0.1524" layer="21" curve="90"/>
<wire x1="9.779" y1="4.572" x2="10.16" y2="4.191" width="0.1524" layer="21" curve="-90"/>
<rectangle x1="-10.7188" y1="-0.4064" x2="-10.16" y2="0.4064" layer="51"/>
<rectangle x1="10.16" y1="-0.4064" x2="10.3124" y2="0.4064" layer="21"/>
<rectangle x1="-10.3124" y1="-0.4064" x2="-10.16" y2="0.4064" layer="21"/>
<rectangle x1="10.16" y1="-0.4064" x2="10.7188" y2="0.4064" layer="51"/>
<text x="-10.16" y="5.1054" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="RCL_0922V">
type 0922, grid 7.5 mm</description>
<circle x="-5.08" y="0" radius="4.572" width="0.1524" layer="21"/>
<circle x="-5.08" y="0" radius="1.905" width="0.1524" layer="21"/>
<rectangle x1="-3.81" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="1.016" shape="octagon"/>
<text x="-0.508" y="1.6764" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.508" y="-2.9972" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.858" y="2.54" size="1.016" layer="21" ratio="12">0922</text>
</package>
<package name="RCL_C025-024X044">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 2.5 mm, outline 2.4 x 4.4 mm</description>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-1.651" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.159" y1="-0.635" x2="-1.651" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="1.651" y1="1.143" x2="-1.651" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-1.143" x2="-1.651" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="1.651" y1="1.143" x2="2.159" y2="0.635" width="0.1524" layer="21" curve="-90"/>
<wire x1="1.651" y1="-1.143" x2="2.159" y2="-0.635" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.3048" y1="0.762" x2="-0.3048" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0.762" x2="0.3302" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="1.27" y1="0" x2="0.3302" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0" x2="-0.3048" y2="0" width="0.1524" layer="51"/>
<text x="-1.778" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.778" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C025-025X050">
grid 2.5 mm, outline 2.5 x 5 mm</description>
<wire x1="-2.159" y1="1.27" x2="2.159" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.27" x2="-2.159" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.27" x2="2.413" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.016" x2="-2.159" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.27" x2="2.413" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.016" x2="-2.159" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="0" x2="0.381" y2="0" width="0.1524" layer="51"/>
<wire x1="0.381" y1="0" x2="0.254" y2="0" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="0.762" width="0.254" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="-0.254" y2="0" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<text x="-2.286" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C025-030X050">
grid 2.5 mm, outline 3 x 5 mm</description>
<wire x1="-2.159" y1="1.524" x2="2.159" y2="1.524" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.524" x2="-2.159" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.27" x2="2.413" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.27" x2="-2.413" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.524" x2="2.413" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.27" x2="-2.159" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.524" x2="2.413" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.27" x2="-2.159" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C025-040X050">
grid 2.5 mm, outline 4 x 5 mm</description>
<wire x1="-2.159" y1="1.905" x2="2.159" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.905" x2="-2.159" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.651" x2="2.413" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.651" x2="-2.413" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.905" x2="2.413" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.651" x2="-2.159" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.905" x2="2.413" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.651" x2="-2.159" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C025-050X050">
grid 2.5 mm, outline 5 x 5 mm</description>
<wire x1="-2.159" y1="2.286" x2="2.159" y2="2.286" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-2.286" x2="-2.159" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.032" x2="2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="2.032" x2="-2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.286" x2="2.413" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="2.032" x2="-2.159" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-2.286" x2="2.413" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-2.032" x2="-2.159" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C025-060X050">
grid 2.5 mm, outline 6 x 5 mm</description>
<wire x1="-2.159" y1="2.794" x2="2.159" y2="2.794" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-2.794" x2="-2.159" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.54" x2="2.413" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="2.54" x2="-2.413" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.794" x2="2.413" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="2.54" x2="-2.159" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-2.794" x2="2.413" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-2.54" x2="-2.159" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C025_050-024X070">
grid 2.5 mm + 5 mm, outline 2.4 x 7 mm</description>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-2.159" y1="0.635" x2="-1.651" y2="1.143" width="0.1524" layer="21" curve="-90" cap="flat"/>
<wire x1="-2.159" y1="-0.635" x2="-1.651" y2="-1.143" width="0.1524" layer="21" curve="90" cap="flat"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="0.635" width="0.1524" layer="51"/>
<wire x1="1.651" y1="1.143" x2="2.159" y2="0.635" width="0.1524" layer="21" curve="-90" cap="flat"/>
<wire x1="-4.191" y1="-1.143" x2="-3.9624" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="1.143" x2="-3.9624" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-0.635" x2="-4.191" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="1.651" y1="-1.143" x2="2.159" y2="-0.635" width="0.1524" layer="21" curve="90" cap="flat"/>
<wire x1="-4.699" y1="0.635" x2="-4.191" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.699" y1="-0.635" x2="-4.699" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.143" x2="-2.5654" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.143" x2="-2.5654" y2="-1.143" width="0.1524" layer="21"/>
<pad name="2" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="3" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.81" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C025_050-025X075">
grid 2.5 + 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="4.953" y1="1.016" x2="4.953" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="4.699" y1="1.27" x2="4.953" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-1.27" x2="4.953" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="1.27" x2="4.699" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.27" x2="2.794" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.413" y2="0.762" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-0.762" x2="2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.254" x2="2.413" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0" x2="2.286" y2="0" width="0.1524" layer="51"/>
<wire x1="2.286" y1="0" x2="2.794" y2="0" width="0.1524" layer="21"/>
<wire x1="2.794" y1="0" x2="3.302" y2="0" width="0.1524" layer="51"/>
<pad name="3" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.159" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C025_050-035X075">
grid 2.5 + 5 mm, outline 3.5 x 7.5 mm</description>
<wire x1="-2.159" y1="1.778" x2="2.159" y2="1.778" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.778" x2="-2.159" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.524" x2="-2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.778" x2="2.413" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.524" x2="-2.159" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.778" x2="2.413" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.524" x2="-2.159" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="4.953" y1="1.524" x2="4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.699" y1="1.778" x2="4.953" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-1.778" x2="4.953" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="1.778" x2="4.699" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.778" x2="2.794" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.524" x2="2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.508" x2="2.413" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.381" y1="0" x2="0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="2.286" y1="0" x2="1.778" y2="0" width="0.1524" layer="51"/>
<text x="-2.286" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C025_050-045X075">
grid 2.5 + 5 mm, outline 4.5 x 7.5 mm</description>
<wire x1="4.953" y1="2.032" x2="4.953" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.286" x2="4.953" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-2.286" x2="4.953" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="2.286" x2="4.699" y2="2.286" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.286" x2="2.794" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.032" x2="2.413" y2="1.397" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.397" x2="2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.762" x2="2.413" y2="-0.762" width="0.1524" layer="21"/>
<text x="-2.286" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="RCL_C025_050-055X075">
grid 2.5 + 5 mm, outline 5.5 x 7.5 mm</description>
<wire x1="4.953" y1="2.54" x2="4.953" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.794" x2="4.953" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-2.794" x2="4.953" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="2.794" x2="4.699" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.794" x2="2.794" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.54" x2="2.413" y2="2.032" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-2.032" x2="2.413" y2="-2.54" width="0.1524" layer="21"/>
<text x="-2.286" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C050-024X044">
grid 5 mm, outline 2.4 x 4.4 mm</description>
<wire x1="-0.3048" y1="0.762" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0.762" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="1.27" y1="0" x2="0.3302" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0" x2="-0.3048" y2="0" width="0.1524" layer="21"/>
<rectangle x1="2.159" y1="-0.381" x2="2.54" y2="0.381" layer="51"/>
<rectangle x1="-2.54" y1="-0.381" x2="-2.159" y2="0.381" layer="51"/>
<text x="-2.159" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C050-025X075">
grid 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.016" x2="-3.683" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.27" x2="3.429" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.016" x2="3.683" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="-3.429" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="3.683" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.27" x2="3.683" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.016" x2="-3.429" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.016" x2="-3.429" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C050-030X075">
grid 5 mm, outline 3 x 7.5 mm</description>
<wire x1="-3.683" y1="1.27" x2="-3.683" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.524" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.27" x2="3.683" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="3.683" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.524" x2="3.683" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.27" x2="-3.429" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.27" x2="-3.429" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<text x="-3.556" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C050-035X075">
grid 5 mm, outline 3.5 x 7.5 mm</description>
<wire x1="-3.683" y1="1.524" x2="-3.683" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.778" x2="3.429" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.524" x2="3.683" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.778" x2="-3.429" y2="1.778" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.778" x2="3.683" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.778" x2="3.683" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.524" x2="-3.429" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.524" x2="-3.429" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<text x="-3.556" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C050-045X075">
grid 5 mm, outline 4.5 x 7.5 mm</description>
<wire x1="-3.683" y1="2.032" x2="-3.683" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.286" x2="3.429" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.032" x2="3.683" y2="2.032" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.286" x2="-3.429" y2="2.286" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.286" x2="3.683" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.286" x2="3.683" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.032" x2="-3.429" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.032" x2="-3.429" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<text x="-3.556" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C050-050X075">
grid 5 mm, outline 5 x 7.5 mm</description>
<wire x1="-3.683" y1="2.286" x2="-3.683" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.54" x2="3.429" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.286" x2="3.683" y2="2.286" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.54" x2="-3.429" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.54" x2="3.683" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.54" x2="3.683" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.286" x2="-3.429" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.286" x2="-3.429" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C050-055X075">
grid 5 mm, outline 5.5 x 7.5 mm</description>
<wire x1="-3.683" y1="2.54" x2="-3.683" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.794" x2="3.429" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.54" x2="3.683" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.794" x2="-3.429" y2="2.794" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.794" x2="3.683" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.794" x2="3.683" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.54" x2="-3.429" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.54" x2="-3.429" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C050-075X075">
grid 5 mm, outline 7.5 x 7.5 mm</description>
<wire x1="-1.524" y1="0" x2="-0.4572" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.4572" y1="0" x2="-0.4572" y2="0.762" width="0.4064" layer="21"/>
<wire x1="-0.4572" y1="0" x2="-0.4572" y2="-0.762" width="0.4064" layer="21"/>
<wire x1="0.4318" y1="0.762" x2="0.4318" y2="0" width="0.4064" layer="21"/>
<wire x1="0.4318" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.4318" y1="0" x2="0.4318" y2="-0.762" width="0.4064" layer="21"/>
<wire x1="-3.683" y1="3.429" x2="-3.683" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-3.683" x2="3.429" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-3.429" x2="3.683" y2="3.429" width="0.1524" layer="21"/>
<wire x1="3.429" y1="3.683" x2="-3.429" y2="3.683" width="0.1524" layer="21"/>
<wire x1="3.429" y1="3.683" x2="3.683" y2="3.429" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-3.683" x2="3.683" y2="-3.429" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-3.429" x2="-3.429" y2="-3.683" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="3.429" x2="-3.429" y2="3.683" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C050H075X075">
Horizontal, grid 5 mm, outline 7.5 x 7.5 mm</description>
<wire x1="-3.683" y1="7.112" x2="-3.683" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0.508" x2="-3.302" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.508" x2="-1.778" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-1.778" y1="0.508" x2="1.778" y2="0.508" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.508" x2="3.302" y2="0.508" width="0.1524" layer="51"/>
<wire x1="3.302" y1="0.508" x2="3.683" y2="0.508" width="0.1524" layer="21"/>
<wire x1="3.683" y1="0.508" x2="3.683" y2="7.112" width="0.1524" layer="21"/>
<wire x1="3.175" y1="7.62" x2="-3.175" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="2.413" x2="-0.3048" y2="1.778" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="1.778" x2="-0.3048" y2="1.143" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="1.778" x2="-1.651" y2="1.778" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="2.413" x2="0.3302" y2="1.778" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="1.778" x2="0.3302" y2="1.143" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="1.778" x2="1.651" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="7.112" x2="-3.175" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.175" y1="7.62" x2="3.683" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="0" x2="-2.54" y2="0.254" width="0.508" layer="51"/>
<wire x1="2.54" y1="0" x2="2.54" y2="0.254" width="0.508" layer="51"/>
<rectangle x1="-2.794" y1="0.127" x2="-2.286" y2="0.508" layer="51"/>
<rectangle x1="2.286" y1="0.127" x2="2.794" y2="0.508" layer="51"/>
<text x="-3.302" y="8.001" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C075-032X103">
grid 7.5 mm, outline 3.2 x 10.3 mm</description>
<wire x1="4.826" y1="1.524" x2="-4.826" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-1.524" x2="4.826" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.27" x2="5.08" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.826" y1="1.524" x2="5.08" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.826" y1="-1.524" x2="5.08" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="-1.27" x2="-4.826" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.27" x2="-4.826" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="0.508" y1="0" x2="2.54" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.889" x2="-0.508" y2="0" width="0.4064" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.889" width="0.4064" layer="21"/>
<wire x1="0.508" y1="0.889" x2="0.508" y2="0" width="0.4064" layer="21"/>
<wire x1="0.508" y1="0" x2="0.508" y2="-0.889" width="0.4064" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.9144" shape="octagon"/>
<text x="-4.826" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.826" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C075-042X103">
grid 7.5 mm, outline 4.2 x 10.3 mm</description>
<wire x1="-5.08" y1="1.778" x2="-5.08" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.032" x2="4.826" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.778" x2="5.08" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="5.08" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.826" y1="-2.032" x2="5.08" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="-1.778" x2="-4.826" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.778" x2="-4.826" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.27" y1="0" x2="2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0" x2="-2.159" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.27" x2="-2.159" y2="0" width="0.4064" layer="21"/>
<wire x1="-2.159" y1="0" x2="-2.159" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="0" width="0.4064" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-1.27" width="0.4064" layer="21"/>
<text x="-4.699" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C075-052X106">
grid 7.5 mm, outline 5.2 x 10.6 mm</description>
<wire x1="4.953" y1="2.54" x2="-4.953" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.286" x2="-5.207" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.54" x2="4.953" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.286" x2="5.207" y2="2.286" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.54" x2="5.207" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.953" y1="-2.54" x2="5.207" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="-2.286" x2="-4.953" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="2.286" x2="-4.953" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-4.826" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C075-063X106">
grid 7.5 mm, outline 6.3 x 10.6 mm</description>
<wire x1="4.953" y1="3.048" x2="-4.953" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.794" x2="-5.207" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-3.048" x2="4.953" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.794" x2="5.207" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.953" y1="3.048" x2="5.207" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.953" y1="-3.048" x2="5.207" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="-2.794" x2="-4.953" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="2.794" x2="-4.953" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-4.826" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C102-043X133">
grid 10.2 mm, outline 4.3 x 13.3 mm</description>
<wire x1="-3.175" y1="1.27" x2="-3.175" y2="0" width="0.4064" layer="21"/>
<wire x1="-2.286" y1="1.27" x2="-2.286" y2="0" width="0.4064" layer="21"/>
<wire x1="3.81" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="-2.286" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-3.81" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0" x2="-3.175" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-6.096" y1="2.032" x2="6.096" y2="2.032" width="0.1524" layer="21"/>
<wire x1="6.604" y1="1.524" x2="6.604" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-2.032" x2="-6.096" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-1.524" x2="-6.604" y2="1.524" width="0.1524" layer="21"/>
<wire x1="6.096" y1="2.032" x2="6.604" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-2.032" x2="6.604" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-1.524" x2="-6.096" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="1.524" x2="-6.096" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<pad name="2" x="5.08" y="0" drill="1.016" shape="octagon"/>
<text x="-6.096" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C102-054X133">
grid 10.2 mm, outline 5.4 x 13.3 mm</description>
<wire x1="-6.096" y1="2.54" x2="6.096" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.032" x2="6.604" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-2.54" x2="-6.096" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.032" x2="-6.604" y2="2.032" width="0.1524" layer="21"/>
<wire x1="6.096" y1="2.54" x2="6.604" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-2.54" x2="6.604" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-2.032" x2="-6.096" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="2.032" x2="-6.096" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-6.096" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-1.905" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C102-064X133">
grid 10.2 mm, outline 6.4 x 13.3 mm</description>
<wire x1="-6.096" y1="3.048" x2="6.096" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.54" x2="6.604" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-3.048" x2="-6.096" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.54" x2="-6.604" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.096" y1="3.048" x2="6.604" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-3.048" x2="6.604" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-2.54" x2="-6.096" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="2.54" x2="-6.096" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-6.096" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C102_152-062X184">
grid 10.2 mm + 15.2 mm, outline 6.2 x 18.4 mm</description>
<wire x1="-3.683" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="3.683" y2="0" width="0.1524" layer="21"/>
<wire x1="6.477" y1="0" x2="8.636" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="3.048" x2="6.223" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.223" y1="-3.048" x2="-6.096" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.223" y1="3.048" x2="6.731" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.223" y1="-3.048" x2="6.731" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="6.731" y1="2.54" x2="6.731" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="11.176" y1="3.048" x2="11.684" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="11.176" y1="-3.048" x2="11.684" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="11.176" y1="-3.048" x2="7.112" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="7.112" y1="3.048" x2="11.176" y2="3.048" width="0.1524" layer="21"/>
<wire x1="11.684" y1="2.54" x2="11.684" y2="-2.54" width="0.1524" layer="21"/>
<pad name="3" x="10.033" y="0" drill="1.016" shape="octagon"/>
<text x="-5.969" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C150-054X183">
grid 15 mm, outline 5.4 x 18.3 mm</description>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="0" width="0.4064" layer="21"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="1.27" x2="-4.191" y2="0" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="-4.191" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="9.017" y1="2.032" x2="9.017" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-2.54" x2="-8.509" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-2.032" x2="-9.017" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="2.54" x2="8.509" y2="2.54" width="0.1524" layer="21"/>
<wire x1="8.509" y1="2.54" x2="9.017" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-2.54" x2="9.017" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-2.032" x2="-8.509" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="2.032" x2="-8.509" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-7.493" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="7.493" y="0" drill="1.016" shape="octagon"/>
<text x="-8.382" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C150-064X183">
grid 15 mm, outline 6.4 x 18.3 mm</description>
<wire x1="9.017" y1="2.54" x2="9.017" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.048" x2="-8.509" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-2.54" x2="-9.017" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.048" x2="8.509" y2="3.048" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.048" x2="9.017" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-3.048" x2="9.017" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-2.54" x2="-8.509" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="2.54" x2="-8.509" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="RCL_C150-072X183">
grid 15 mm, outline 7.2 x 18.3 mm</description>
<wire x1="9.017" y1="3.048" x2="9.017" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.556" x2="-8.509" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.048" x2="-9.017" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.556" x2="8.509" y2="3.556" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.556" x2="9.017" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-3.556" x2="9.017" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.048" x2="-8.509" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.048" x2="-8.509" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C150-084X183">
grid 15 mm, outline 8.4 x 18.3 mm</description>
<wire x1="9.017" y1="3.556" x2="9.017" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.064" x2="-8.509" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.556" x2="-9.017" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.064" x2="8.509" y2="4.064" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.064" x2="9.017" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-4.064" x2="9.017" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.556" x2="-8.509" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.556" x2="-8.509" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C150-091X182">
grid 15 mm, outline 9.1 x 18.2 mm</description>
<wire x1="9.017" y1="3.937" x2="9.017" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.445" x2="-8.509" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.937" x2="-9.017" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.445" x2="8.509" y2="4.445" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.445" x2="9.017" y2="3.937" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-4.445" x2="9.017" y2="-3.937" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.937" x2="-8.509" y2="-4.445" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.937" x2="-8.509" y2="4.445" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="4.826" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="RCL_C225-062X268">
grid 22.5 mm, outline 6.2 x 26.8 mm</description>
<wire x1="-12.827" y1="3.048" x2="12.827" y2="3.048" width="0.1524" layer="21"/>
<wire x1="13.335" y1="2.54" x2="13.335" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-3.048" x2="-12.827" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-2.54" x2="-13.335" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="1.905" x2="-6.731" y2="0" width="0.4064" layer="21"/>
<wire x1="-6.731" y1="0" x2="-6.731" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-7.62" y2="0" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="12.827" y1="3.048" x2="13.335" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-3.048" x2="13.335" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-2.54" x2="-12.827" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="2.54" x2="-12.827" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="-9.652" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="9.652" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-11.303" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="11.303" y="0" drill="1.016" shape="octagon"/>
<text x="-12.7" y="3.429" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C225-074X268">
grid 22.5 mm, outline 7.4 x 26.8 mm</description>
<wire x1="-12.827" y1="3.556" x2="12.827" y2="3.556" width="0.1524" layer="21"/>
<wire x1="13.335" y1="3.048" x2="13.335" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-3.556" x2="-12.827" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-3.048" x2="-13.335" y2="3.048" width="0.1524" layer="21"/>
<wire x1="12.827" y1="3.556" x2="13.335" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-3.556" x2="13.335" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-3.048" x2="-12.827" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="3.048" x2="-12.827" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<text x="-12.827" y="3.937" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="RCL_C225-087X268">
grid 22.5 mm, outline 8.7 x 26.8 mm</description>
<wire x1="-12.827" y1="4.318" x2="12.827" y2="4.318" width="0.1524" layer="21"/>
<wire x1="13.335" y1="3.81" x2="13.335" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-4.318" x2="-12.827" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-3.81" x2="-13.335" y2="3.81" width="0.1524" layer="21"/>
<wire x1="12.827" y1="4.318" x2="13.335" y2="3.81" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-4.318" x2="13.335" y2="-3.81" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-3.81" x2="-12.827" y2="-4.318" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="3.81" x2="-12.827" y2="4.318" width="0.1524" layer="21" curve="-90"/>
<text x="-12.827" y="4.699" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="RCL_C225-108X268">
grid 22.5 mm, outline 10.8 x 26.8 mm</description>
<wire x1="-12.827" y1="5.334" x2="12.827" y2="5.334" width="0.1524" layer="21"/>
<wire x1="13.335" y1="4.826" x2="13.335" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-5.334" x2="-12.827" y2="-5.334" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-4.826" x2="-13.335" y2="4.826" width="0.1524" layer="21"/>
<wire x1="12.827" y1="5.334" x2="13.335" y2="4.826" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-5.334" x2="13.335" y2="-4.826" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-4.826" x2="-12.827" y2="-5.334" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="4.826" x2="-12.827" y2="5.334" width="0.1524" layer="21" curve="-90"/>
<text x="-12.954" y="5.715" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="RCL_C225-113X268">
grid 22.5 mm, outline 11.3 x 26.8 mm</description>
<wire x1="-12.827" y1="5.588" x2="12.827" y2="5.588" width="0.1524" layer="21"/>
<wire x1="13.335" y1="5.08" x2="13.335" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-5.588" x2="-12.827" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.08" x2="-13.335" y2="5.08" width="0.1524" layer="21"/>
<wire x1="12.827" y1="5.588" x2="13.335" y2="5.08" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-5.588" x2="13.335" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-5.08" x2="-12.827" y2="-5.588" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="5.08" x2="-12.827" y2="5.588" width="0.1524" layer="21" curve="-90"/>
<text x="-12.954" y="5.969" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="RCL_C275-093X316">
grid 27.5 mm, outline 9.3 x 31.6 mm</description>
<wire x1="-15.24" y1="4.572" x2="15.24" y2="4.572" width="0.1524" layer="21"/>
<wire x1="15.748" y1="4.064" x2="15.748" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-4.572" x2="-15.24" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-4.064" x2="-15.748" y2="4.064" width="0.1524" layer="21"/>
<wire x1="15.24" y1="4.572" x2="15.748" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-4.572" x2="15.748" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-4.064" x2="-15.24" y2="-4.572" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="4.064" x2="-15.24" y2="4.572" width="0.1524" layer="21" curve="-90"/>
<wire x1="-11.557" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="11.557" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-13.716" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="13.716" y="0" drill="1.1938" shape="octagon"/>
<text x="-15.24" y="4.953" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="RCL_C275-113X316">
grid 27.5 mm, outline 11.3 x 31.6 mm</description>
<wire x1="-15.24" y1="5.588" x2="15.24" y2="5.588" width="0.1524" layer="21"/>
<wire x1="15.748" y1="5.08" x2="15.748" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-5.588" x2="-15.24" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-5.08" x2="-15.748" y2="5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="5.588" x2="15.748" y2="5.08" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-5.588" x2="15.748" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-5.08" x2="-15.24" y2="-5.588" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="5.08" x2="-15.24" y2="5.588" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="5.969" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="RCL_C275-134X316">
grid 27.5 mm, outline 13.4 x 31.6 mm</description>
<wire x1="-15.24" y1="6.604" x2="15.24" y2="6.604" width="0.1524" layer="21"/>
<wire x1="15.748" y1="6.096" x2="15.748" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-6.604" x2="-15.24" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-6.096" x2="-15.748" y2="6.096" width="0.1524" layer="21"/>
<wire x1="15.24" y1="6.604" x2="15.748" y2="6.096" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-6.604" x2="15.748" y2="-6.096" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-6.096" x2="-15.24" y2="-6.604" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="6.096" x2="-15.24" y2="6.604" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="6.985" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="RCL_C275-154X316">
grid 27.5 mm, outline 15.4 x 31.6 mm</description>
<wire x1="-15.24" y1="7.62" x2="15.24" y2="7.62" width="0.1524" layer="21"/>
<wire x1="15.748" y1="7.112" x2="15.748" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-7.62" x2="-15.24" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-7.112" x2="-15.748" y2="7.112" width="0.1524" layer="21"/>
<wire x1="15.24" y1="7.62" x2="15.748" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-7.62" x2="15.748" y2="-7.112" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-7.112" x2="-15.24" y2="-7.62" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="7.112" x2="-15.24" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="8.001" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="RCL_C275-173X316">
grid 27.5 mm, outline 17.3 x 31.6 mm</description>
<wire x1="-15.24" y1="8.509" x2="15.24" y2="8.509" width="0.1524" layer="21"/>
<wire x1="15.748" y1="8.001" x2="15.748" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-8.509" x2="-15.24" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-8.001" x2="-15.748" y2="8.001" width="0.1524" layer="21"/>
<wire x1="15.24" y1="8.509" x2="15.748" y2="8.001" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-8.509" x2="15.748" y2="-8.001" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-8.001" x2="-15.24" y2="-8.509" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="8.001" x2="-15.24" y2="8.509" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="8.89" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="RCL_C275-205X316">
grid 27.5 mm, outline 20.5 x 31.6 mm</description>
<wire x1="-15.24" y1="10.16" x2="15.24" y2="10.16" width="0.1524" layer="21"/>
<wire x1="15.748" y1="9.652" x2="15.748" y2="-9.652" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-10.16" x2="-15.24" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-9.652" x2="-15.748" y2="9.652" width="0.1524" layer="21"/>
<wire x1="15.24" y1="10.16" x2="15.748" y2="9.652" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-10.16" x2="15.748" y2="-9.652" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-9.652" x2="-15.24" y2="-10.16" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="9.652" x2="-15.24" y2="10.16" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="10.541" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.318" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C325-137X374">
grid 32.5 mm, outline 13.7 x 37.4 mm</description>
<wire x1="-14.2748" y1="0" x2="-12.7" y2="0" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="1.905" x2="-12.7" y2="0" width="0.4064" layer="21"/>
<wire x1="-11.811" y1="1.905" x2="-11.811" y2="0" width="0.4064" layer="21"/>
<wire x1="-11.811" y1="0" x2="14.2748" y2="0" width="0.1524" layer="21"/>
<wire x1="-11.811" y1="0" x2="-11.811" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="-12.7" y1="0" x2="-12.7" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="18.542" y1="6.731" x2="18.542" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="6.731" x2="-18.542" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-6.731" x2="18.542" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="18.542" y1="6.731" x2="-18.542" y2="6.731" width="0.1524" layer="21"/>
<pad name="1" x="-16.256" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="16.256" y="0" drill="1.1938" shape="octagon"/>
<text x="-18.2372" y="7.0612" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-10.8458" y="-2.8702" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_C325-162X374">
grid 32.5 mm, outline 16.2 x 37.4 mm</description>
<wire x1="18.542" y1="8.001" x2="18.542" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="8.001" x2="-18.542" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-8.001" x2="18.542" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="18.542" y1="8.001" x2="-18.542" y2="8.001" width="0.1524" layer="21"/>
<text x="-18.3642" y="8.3312" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="RCL_C325-182X374">
grid 32.5 mm, outline 18.2 x 37.4 mm</description>
<wire x1="18.542" y1="9.017" x2="18.542" y2="-9.017" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="9.017" x2="-18.542" y2="-9.017" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-9.017" x2="18.542" y2="-9.017" width="0.1524" layer="21"/>
<wire x1="18.542" y1="9.017" x2="-18.542" y2="9.017" width="0.1524" layer="21"/>
<text x="-18.3642" y="9.3472" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="RCL_C375-155X418">
grid 37.5 mm, outline 15.5 x 41.8 mm</description>
<wire x1="-20.32" y1="7.62" x2="20.32" y2="7.62" width="0.1524" layer="21"/>
<wire x1="20.828" y1="7.112" x2="20.828" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-7.62" x2="-20.32" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-7.112" x2="-20.828" y2="7.112" width="0.1524" layer="21"/>
<wire x1="20.32" y1="7.62" x2="20.828" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-7.62" x2="20.828" y2="-7.112" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-7.112" x2="-20.32" y2="-7.62" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="7.112" x2="-20.32" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<wire x1="-16.002" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="16.002" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-18.796" y="0" drill="1.3208" shape="octagon"/>
<pad name="2" x="18.796" y="0" drill="1.3208" shape="octagon"/>
<text x="-20.447" y="8.001" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="RCL_C375-192X418">
grid 37.5 mm, outline 19.2 x 41.8 mm</description>
<wire x1="-20.32" y1="8.509" x2="20.32" y2="8.509" width="0.1524" layer="21"/>
<wire x1="20.828" y1="8.001" x2="20.828" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-8.509" x2="-20.32" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-8.001" x2="-20.828" y2="8.001" width="0.1524" layer="21"/>
<wire x1="20.32" y1="8.509" x2="20.828" y2="8.001" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-8.509" x2="20.828" y2="-8.001" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-8.001" x2="-20.32" y2="-8.509" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="8.001" x2="-20.32" y2="8.509" width="0.1524" layer="21" curve="-90"/>
<text x="-20.447" y="8.89" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="RCL_C375-203X418">
grid 37.5 mm, outline 20.3 x 41.8 mm</description>
<wire x1="-20.32" y1="10.16" x2="20.32" y2="10.16" width="0.1524" layer="21"/>
<wire x1="20.828" y1="9.652" x2="20.828" y2="-9.652" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-10.16" x2="-20.32" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-9.652" x2="-20.828" y2="9.652" width="0.1524" layer="21"/>
<wire x1="20.32" y1="10.16" x2="20.828" y2="9.652" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-10.16" x2="20.828" y2="-9.652" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-9.652" x2="-20.32" y2="-10.16" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="9.652" x2="-20.32" y2="10.16" width="0.1524" layer="21" curve="-90"/>
<text x="-20.32" y="10.541" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="RCL_C0402">
chip</description>
<wire x1="-0.245" y1="0.224" x2="0.245" y2="0.224" width="0.1524" layer="51"/>
<wire x1="0.245" y1="-0.224" x2="-0.245" y2="-0.224" width="0.1524" layer="51"/>
<wire x1="-1.473" y1="0.483" x2="1.473" y2="0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.483" x2="1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.483" x2="-1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.483" x2="-1.473" y2="0.483" width="0.0508" layer="39"/>
<rectangle x1="-0.554" y1="-0.3048" x2="-0.254" y2="0.2951" layer="51"/>
<rectangle x1="0.2588" y1="-0.3048" x2="0.5588" y2="0.2951" layer="51"/>
<rectangle x1="-0.1999" y1="-0.3" x2="0.1999" y2="0.3" layer="35"/>
<smd name="1" x="-0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<smd name="2" x="0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<text x="-0.635" y="0.762" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-1.905" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_C0402K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 0204 Reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 1005</description>
<wire x1="-0.425" y1="0.2" x2="0.425" y2="0.2" width="0.1016" layer="51"/>
<wire x1="0.425" y1="-0.2" x2="-0.425" y2="-0.2" width="0.1016" layer="51"/>
<rectangle x1="-0.5" y1="-0.25" x2="-0.225" y2="0.25" layer="51"/>
<rectangle x1="0.225" y1="-0.25" x2="0.5" y2="0.25" layer="51"/>
<smd name="1" x="-0.6" y="0" dx="0.925" dy="0.74" layer="1"/>
<smd name="2" x="0.6" y="0" dx="0.925" dy="0.74" layer="1"/>
<text x="-0.5" y="0.425" size="1.016" layer="25">&gt;NAME</text>
<text x="-0.5" y="-1.45" size="1.016" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_C0504">
chip</description>
<wire x1="-1.473" y1="0.983" x2="1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.983" x2="1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.983" x2="-1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.983" x2="-1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-0.294" y1="0.559" x2="0.294" y2="0.559" width="0.1016" layer="51"/>
<wire x1="-0.294" y1="-0.559" x2="0.294" y2="-0.559" width="0.1016" layer="51"/>
<rectangle x1="-0.6604" y1="-0.6223" x2="-0.2804" y2="0.6276" layer="51"/>
<rectangle x1="0.2794" y1="-0.6223" x2="0.6594" y2="0.6276" layer="51"/>
<rectangle x1="-0.1001" y1="-0.4001" x2="0.1001" y2="0.4001" layer="35"/>
<smd name="1" x="-0.7" y="0" dx="1" dy="1.3" layer="1"/>
<smd name="2" x="0.7" y="0" dx="1" dy="1.3" layer="1"/>
<text x="-0.635" y="0.889" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-2.159" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_C0603">
chip</description>
<wire x1="-0.356" y1="0.432" x2="0.356" y2="0.432" width="0.1016" layer="51"/>
<wire x1="-0.356" y1="-0.419" x2="0.356" y2="-0.419" width="0.1016" layer="51"/>
<rectangle x1="-0.8382" y1="-0.4699" x2="-0.3381" y2="0.4801" layer="51"/>
<rectangle x1="0.3302" y1="-0.4699" x2="0.8303" y2="0.4801" layer="51"/>
<smd name="1" x="-0.85" y="0" dx="1.1" dy="1" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.1" dy="1" layer="1"/>
<text x="-0.889" y="0.762" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.889" y="-2.032" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_C0603K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 0603 Reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 1608</description>
<wire x1="-0.725" y1="0.35" x2="0.725" y2="0.35" width="0.1016" layer="51"/>
<wire x1="0.725" y1="-0.35" x2="-0.725" y2="-0.35" width="0.1016" layer="51"/>
<rectangle x1="-0.8" y1="-0.4" x2="-0.45" y2="0.4" layer="51"/>
<rectangle x1="0.45" y1="-0.4" x2="0.8" y2="0.4" layer="51"/>
<smd name="1" x="-0.875" y="0" dx="1.05" dy="1.08" layer="1"/>
<smd name="2" x="0.875" y="0" dx="1.05" dy="1.08" layer="1"/>
<text x="-0.8" y="0.65" size="1.016" layer="25">&gt;NAME</text>
<text x="-0.8" y="-1.65" size="1.016" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_C0805">
chip</description>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-0.381" y1="0.66" x2="0.381" y2="0.66" width="0.1016" layer="51"/>
<wire x1="-0.356" y1="-0.66" x2="0.381" y2="-0.66" width="0.1016" layer="51"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<rectangle x1="-1.0922" y1="-0.7239" x2="-0.3421" y2="0.7262" layer="51"/>
<rectangle x1="0.3556" y1="-0.7239" x2="1.1057" y2="0.7262" layer="51"/>
<smd name="1" x="-0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<text x="-0.889" y="1.016" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.889" y="-2.286" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_C0805K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 0805 Reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 2012</description>
<wire x1="-0.925" y1="0.6" x2="0.925" y2="0.6" width="0.1016" layer="51"/>
<wire x1="0.925" y1="-0.6" x2="-0.925" y2="-0.6" width="0.1016" layer="51"/>
<rectangle x1="-1" y1="-0.65" x2="-0.5" y2="0.65" layer="51"/>
<rectangle x1="0.5" y1="-0.65" x2="1" y2="0.65" layer="51"/>
<smd name="1" x="-1" y="0" dx="1.3" dy="1.6" layer="1"/>
<smd name="2" x="1" y="0" dx="1.3" dy="1.6" layer="1"/>
<text x="-1" y="0.875" size="1.016" layer="25">&gt;NAME</text>
<text x="-1" y="-1.9" size="1.016" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_C1005">
chip</description>
</package>
<package name="RCL_C1206">
chip</description>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-0.965" y1="0.787" x2="0.965" y2="0.787" width="0.1016" layer="51"/>
<wire x1="-0.965" y1="-0.787" x2="0.965" y2="-0.787" width="0.1016" layer="51"/>
<rectangle x1="-1.7018" y1="-0.8509" x2="-0.9517" y2="0.8491" layer="51"/>
<rectangle x1="0.9517" y1="-0.8491" x2="1.7018" y2="0.8509" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="16"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="16"/>
<text x="-1.27" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_C1206K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1206 Reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 3216</description>
<wire x1="-1.525" y1="0.75" x2="1.525" y2="0.75" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-0.75" x2="-1.525" y2="-0.75" width="0.1016" layer="51"/>
<rectangle x1="-1.6" y1="-0.8" x2="-1.1" y2="0.8" layer="51"/>
<rectangle x1="1.1" y1="-0.8" x2="1.6" y2="0.8" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="1.5" dy="2" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.5" dy="2" layer="1"/>
<text x="-1.6" y="1.1" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-2.1" size="1.016" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_C1210">
chip</description>
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="-0.9652" y1="1.2446" x2="0.9652" y2="1.2446" width="0.1016" layer="51"/>
<wire x1="-0.9652" y1="-1.2446" x2="0.9652" y2="-1.2446" width="0.1016" layer="51"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<rectangle x1="-1.7018" y1="-1.2954" x2="-0.9517" y2="1.3045" layer="51"/>
<rectangle x1="0.9517" y1="-1.3045" x2="1.7018" y2="1.2954" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<text x="-1.397" y="1.651" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.397" y="-2.921" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_C1210K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1210 Reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 3225</description>
<wire x1="-1.525" y1="1.175" x2="1.525" y2="1.175" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-1.175" x2="-1.525" y2="-1.175" width="0.1016" layer="51"/>
<rectangle x1="-1.6" y1="-1.25" x2="-1.1" y2="1.25" layer="51"/>
<rectangle x1="1.1" y1="-1.25" x2="1.6" y2="1.25" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="1.5" dy="2.9" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.5" dy="2.9" layer="1"/>
<text x="-1.6" y="1.55" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-2.575" size="1.016" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_C1310">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
chip</description>
<rectangle x1="-0.1001" y1="-0.3" x2="0.1001" y2="0.3" layer="35"/>
</package>
<package name="RCL_C1608">
chip</description>
<text x="-0.635" y="-2.032" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_C1812">
chip</description>
<wire x1="-2.973" y1="1.983" x2="2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-1.983" x2="-2.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-1.983" x2="-2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="-1.4732" y1="1.6002" x2="1.4732" y2="1.6002" width="0.1016" layer="51"/>
<wire x1="-1.4478" y1="-1.6002" x2="1.4732" y2="-1.6002" width="0.1016" layer="51"/>
<wire x1="2.973" y1="1.983" x2="2.973" y2="-1.983" width="0.0508" layer="39"/>
<rectangle x1="-2.3876" y1="-1.651" x2="-1.4376" y2="1.649" layer="51"/>
<rectangle x1="1.4478" y1="-1.651" x2="2.3978" y2="1.649" layer="51"/>
<rectangle x1="-0.3" y1="-0.4001" x2="0.3" y2="0.4001" layer="35"/>
<smd name="1" x="-1.95" y="0" dx="1.9" dy="3.4" layer="1"/>
<smd name="2" x="1.95" y="0" dx="1.9" dy="3.4" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_C1812K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1812 Reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 4532</description>
<wire x1="-2.175" y1="1.525" x2="2.175" y2="1.525" width="0.1016" layer="51"/>
<wire x1="2.175" y1="-1.525" x2="-2.175" y2="-1.525" width="0.1016" layer="51"/>
<rectangle x1="-2.25" y1="-1.6" x2="-1.65" y2="1.6" layer="51"/>
<rectangle x1="1.65" y1="-1.6" x2="2.25" y2="1.6" layer="51"/>
<smd name="1" x="-2.05" y="0" dx="1.8" dy="3.7" layer="1"/>
<smd name="2" x="2.05" y="0" dx="1.8" dy="3.7" layer="1"/>
<text x="-2.25" y="1.95" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.25" y="-2.975" size="1.016" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_C1825">
chip</description>
<wire x1="-2.973" y1="3.483" x2="2.973" y2="3.483" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-3.483" x2="-2.973" y2="-3.483" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-3.483" x2="-2.973" y2="3.483" width="0.0508" layer="39"/>
<wire x1="-1.4986" y1="3.2766" x2="1.4732" y2="3.2766" width="0.1016" layer="51"/>
<wire x1="-1.4732" y1="-3.2766" x2="1.4986" y2="-3.2766" width="0.1016" layer="51"/>
<wire x1="2.973" y1="3.483" x2="2.973" y2="-3.483" width="0.0508" layer="39"/>
<rectangle x1="-2.413" y1="-3.3528" x2="-1.463" y2="3.3472" layer="51"/>
<rectangle x1="1.4478" y1="-3.3528" x2="2.3978" y2="3.3472" layer="51"/>
<rectangle x1="-0.7" y1="-0.7" x2="0.7" y2="0.7" layer="35"/>
<smd name="1" x="-1.95" y="0" dx="1.9" dy="6.8" layer="1"/>
<smd name="2" x="1.95" y="0" dx="1.9" dy="6.8" layer="1"/>
<text x="-1.905" y="3.683" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-4.826" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_C1825K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1825 Reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 4564</description>
<wire x1="-1.525" y1="3.125" x2="1.525" y2="3.125" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-3.125" x2="-1.525" y2="-3.125" width="0.1016" layer="51"/>
<rectangle x1="-1.6" y1="-3.2" x2="-1.1" y2="3.2" layer="51"/>
<rectangle x1="1.1" y1="-3.2" x2="1.6" y2="3.2" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="1.8" dy="6.9" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.8" dy="6.9" layer="1"/>
<text x="-1.6" y="3.55" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-4.625" size="1.016" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_C2012">
chip</description>
</package>
<package name="RCL_C2220K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 2220 Reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 5650</description>
<wire x1="-2.725" y1="2.425" x2="2.725" y2="2.425" width="0.1016" layer="51"/>
<wire x1="2.725" y1="-2.425" x2="-2.725" y2="-2.425" width="0.1016" layer="51"/>
<rectangle x1="-2.8" y1="-2.5" x2="-2.2" y2="2.5" layer="51"/>
<rectangle x1="2.2" y1="-2.5" x2="2.8" y2="2.5" layer="51"/>
<smd name="1" x="-2.55" y="0" dx="1.85" dy="5.5" layer="1"/>
<smd name="2" x="2.55" y="0" dx="1.85" dy="5.5" layer="1"/>
<text x="-2.8" y="2.95" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.8" y="-3.975" size="1.016" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_C2225K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 2225 Reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 5664</description>
<wire x1="-2.725" y1="3.075" x2="2.725" y2="3.075" width="0.1016" layer="51"/>
<wire x1="2.725" y1="-3.075" x2="-2.725" y2="-3.075" width="0.1016" layer="51"/>
<rectangle x1="-2.8" y1="-3.15" x2="-2.2" y2="3.15" layer="51"/>
<rectangle x1="2.2" y1="-3.15" x2="2.8" y2="3.15" layer="51"/>
<smd name="1" x="-2.55" y="0" dx="1.85" dy="6.8" layer="1"/>
<smd name="2" x="2.55" y="0" dx="1.85" dy="6.8" layer="1"/>
<text x="-2.8" y="3.6" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.8" y="-4.575" size="1.016" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_C3216">
chip</description>
<rectangle x1="-0.3" y1="-0.5001" x2="0.3" y2="0.5001" layer="35"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
</package>
<package name="RCL_C3225">
chip</description>
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
<package name="RCL_C4532">
chip</description>
<rectangle x1="-0.4001" y1="-0.7" x2="0.4001" y2="0.7" layer="35"/>
<text x="-1.905" y="2.032" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="RCL_C4564">
chip</description>
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="RCL_M0805">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
MELF 0.10 W</description>
<wire x1="0.7112" y1="0.635" x2="-0.7112" y2="0.635" width="0.1524" layer="51"/>
<wire x1="0.7112" y1="-0.635" x2="-0.7112" y2="-0.635" width="0.1524" layer="51"/>
<rectangle x1="-1.0414" y1="-0.7112" x2="-0.6858" y2="0.7112" layer="51"/>
<rectangle x1="0.6858" y1="-0.7112" x2="1.0414" y2="0.7112" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5999" x2="0.1999" y2="0.5999" layer="35"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.6" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.6" layer="1"/>
<text x="-1.016" y="1.016" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.016" y="-2.286" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_M1206">
MELF 0.25 W</description>
<wire x1="1.143" y1="0.8382" x2="-1.143" y2="0.8382" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.8382" x2="-1.143" y2="-0.8382" width="0.1524" layer="51"/>
<rectangle x1="-1.7018" y1="-0.9144" x2="-1.1176" y2="0.9144" layer="51"/>
<rectangle x1="1.1176" y1="-0.9144" x2="1.7018" y2="0.9144" layer="51"/>
<rectangle x1="-0.3" y1="-0.8001" x2="0.3" y2="0.8001" layer="35"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2" layer="16"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2" layer="16"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_M1406">
MELF 0.12 W</description>
<wire x1="-2.973" y1="0.983" x2="2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-0.983" x2="-2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-0.983" x2="-2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="0.983" x2="2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.3208" y1="0.762" x2="-1.3208" y2="0.762" width="0.1524" layer="51"/>
<wire x1="1.3208" y1="-0.762" x2="-1.3208" y2="-0.762" width="0.1524" layer="51"/>
<wire x1="0.6858" y1="0.762" x2="-0.6858" y2="0.762" width="0.1524" layer="21"/>
<wire x1="0.6858" y1="-0.762" x2="-0.6858" y2="-0.762" width="0.1524" layer="21"/>
<rectangle x1="-1.8542" y1="-0.8382" x2="-1.2954" y2="0.8382" layer="51"/>
<rectangle x1="1.2954" y1="-0.8382" x2="1.8542" y2="0.8382" layer="51"/>
<rectangle x1="-0.3" y1="-0.7" x2="0.3" y2="0.7" layer="35"/>
<smd name="1" x="-1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<smd name="2" x="1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<text x="-1.651" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.651" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_M2012">
</package>
<package name="RCL_M2309">
<wire x1="-4.473" y1="1.483" x2="4.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="4.473" y1="-1.483" x2="-4.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-4.473" y1="-1.483" x2="-4.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="4.473" y1="1.483" x2="4.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="2.413" y1="1.1684" x2="-2.4384" y2="1.1684" width="0.1524" layer="51"/>
<wire x1="2.413" y1="-1.1684" x2="-2.413" y2="-1.1684" width="0.1524" layer="51"/>
<wire x1="1.651" y1="1.1684" x2="-1.6764" y2="1.1684" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-1.1684" x2="-1.651" y2="-1.1684" width="0.1524" layer="21"/>
<rectangle x1="-3.048" y1="-1.2446" x2="-2.3876" y2="1.2446" layer="51"/>
<rectangle x1="2.3876" y1="-1.2446" x2="3.048" y2="1.2446" layer="51"/>
<smd name="1" x="-2.85" y="0" dx="1.5" dy="2.6" layer="1"/>
<smd name="2" x="2.85" y="0" dx="1.5" dy="2.6" layer="1"/>
<text x="-2.794" y="1.651" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.794" y="-2.794" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_M3216">
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2" layer="1"/>
</package>
<package name="RCL_M3516">
</package>
<package name="RCL_M5923">
</package>
<package name="RCL_MINI_MELF-0102AX">
<description>&lt;b&gt;Mini MELF 0102 Axial&lt;/b&gt;</description>
<circle x="0" y="0" radius="0.6" width="0" layer="51"/>
<circle x="0" y="0" radius="0.6" width="0" layer="52"/>
<smd name="1" x="0" y="0" dx="1.9" dy="1.9" layer="1" roundness="100"/>
<smd name="2" x="0" y="0" dx="1.9" dy="1.9" layer="16" roundness="100"/>
<text x="-1.27" y="0.9525" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.2225" size="1.27" layer="27">&gt;VALUE</text>
<hole x="0" y="0" drill="1.3"/>
</package>
<package name="RCL_MINI_MELF-0102R">
<description>&lt;b&gt;CECC Size RC2211&lt;/b&gt; Reflow Soldering&lt;p&gt;
source Beyschlag</description>
<wire x1="-1" y1="-0.5" x2="1" y2="-0.5" width="0.2032" layer="51"/>
<wire x1="1" y1="-0.5" x2="1" y2="0.5" width="0.2032" layer="51"/>
<wire x1="1" y1="0.5" x2="-1" y2="0.5" width="0.2032" layer="51"/>
<wire x1="-1" y1="0.5" x2="-1" y2="-0.5" width="0.2032" layer="51"/>
<smd name="1" x="-0.9" y="0" dx="0.5" dy="1.3" layer="1"/>
<smd name="2" x="0.9" y="0" dx="0.5" dy="1.3" layer="1"/>
</package>
<package name="RCL_MINI_MELF-0102W">
<description>&lt;b&gt;CECC Size RC2211&lt;/b&gt; Wave Soldering&lt;p&gt;
<smd name="1" x="-0.95" y="0" dx="0.6" dy="1.3" layer="1"/>
<smd name="2" x="0.95" y="0" dx="0.6" dy="1.3" layer="1"/>
</package>
<package name="RCL_MINI_MELF-0204R">
<description>&lt;b&gt;CECC Size RC3715&lt;/b&gt; Reflow Soldering&lt;p&gt;
<wire x1="-1.7" y1="-0.6" x2="1.7" y2="-0.6" width="0.2032" layer="51"/>
<wire x1="1.7" y1="-0.6" x2="1.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="1.7" y1="0.6" x2="-1.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-1.7" y1="0.6" x2="-1.7" y2="-0.6" width="0.2032" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="0.8" dy="1.6" layer="1"/>
<smd name="2" x="1.5" y="0" dx="0.8" dy="1.6" layer="1"/>
</package>
<package name="RCL_MINI_MELF-0204W">
<description>&lt;b&gt;CECC Size RC3715&lt;/b&gt; Wave Soldering&lt;p&gt;
<smd name="1" x="-1.5" y="0" dx="1.2" dy="1.6" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.2" dy="1.6" layer="1"/>
</package>
<package name="RCL_MINI_MELF-0207R">
<description>&lt;b&gt;CECC Size RC6123&lt;/b&gt; Reflow Soldering&lt;p&gt;
<wire x1="-2.8" y1="-1" x2="2.8" y2="-1" width="0.2032" layer="51"/>
<wire x1="2.8" y1="-1" x2="2.8" y2="1" width="0.2032" layer="51"/>
<wire x1="2.8" y1="1" x2="-2.8" y2="1" width="0.2032" layer="51"/>
<wire x1="-2.8" y1="1" x2="-2.8" y2="-1" width="0.2032" layer="51"/>
<smd name="1" x="-2.25" y="0" dx="1.6" dy="2.5" layer="1"/>
<smd name="2" x="2.25" y="0" dx="1.6" dy="2.5" layer="1"/>
<text x="-2.2225" y="1.5875" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.2225" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_MINI_MELF-0207W">
<description>&lt;b&gt;CECC Size RC6123&lt;/b&gt; Wave Soldering&lt;p&gt;
<smd name="1" x="-2.6" y="0" dx="2.4" dy="2.5" layer="1"/>
<smd name="2" x="2.6" y="0" dx="2.4" dy="2.5" layer="1"/>
<text x="-2.54" y="1.5875" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_P0613/15">
type 0613, grid 15 mm</description>
<wire x1="7.62" y1="0" x2="6.985" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.985" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.477" y1="2.032" x2="-6.223" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.477" y1="-2.032" x2="-6.223" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="6.223" y1="-2.286" x2="6.477" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="6.223" y1="2.286" x2="6.477" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.223" y1="2.286" x2="-5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.159" x2="-5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="-2.286" x2="-5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-2.159" x2="-5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="2.159" x2="5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="2.159" x2="-5.207" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.159" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.159" x2="-5.207" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="6.223" y1="2.286" x2="5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="6.223" y1="-2.286" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-0.635" x2="6.477" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-0.635" x2="6.477" y2="0.635" width="0.1524" layer="51"/>
<wire x1="6.477" y1="2.032" x2="6.477" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-2.032" x2="-6.477" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="0.635" x2="-6.477" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="0.635" x2="-6.477" y2="2.032" width="0.1524" layer="21"/>
<rectangle x1="-7.0358" y1="-0.4064" x2="-6.477" y2="0.4064" layer="51"/>
<rectangle x1="6.477" y1="-0.4064" x2="7.0358" y2="0.4064" layer="51"/>
<pad name="1" x="-7.62" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="1.016" shape="octagon"/>
<text x="-6.477" y="2.6924" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-0.7112" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_P0613V">
type 0613, grid 5 mm</description>
<circle x="-2.54" y="0" radius="2.286" width="0.1524" layer="21"/>
<circle x="-2.54" y="0" radius="1.143" width="0.1524" layer="51"/>
<wire x1="2.54" y1="0" x2="1.397" y2="0" width="0.8128" layer="51"/>
<wire x1="-2.54" y1="0" x2="-1.397" y2="0" width="0.8128" layer="51"/>
<rectangle x1="-1.2954" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="1.016" shape="octagon"/>
<text x="-0.254" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.254" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_P0817/22">
type 0817, grid 22.5 mm</description>
<wire x1="-10.414" y1="0" x2="-11.43" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.509" y1="-3.429" x2="-8.509" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="3.81" x2="-7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="3.556" x2="-7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="-3.81" x2="-7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-3.556" x2="-7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="3.556" x2="7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="3.556" x2="-6.985" y2="3.556" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-3.556" x2="7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-3.556" x2="-6.985" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="8.128" y1="3.81" x2="7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="8.128" y1="-3.81" x2="7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.429" x2="8.509" y2="3.429" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="10.414" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.509" y1="3.429" x2="-8.128" y2="3.81" width="0.1524" layer="21" curve="-90"/>
<wire x1="-8.509" y1="-3.429" x2="-8.128" y2="-3.81" width="0.1524" layer="21" curve="90"/>
<wire x1="8.128" y1="3.81" x2="8.509" y2="3.429" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.128" y1="-3.81" x2="8.509" y2="-3.429" width="0.1524" layer="21" curve="90"/>
<rectangle x1="8.509" y1="-0.4064" x2="10.3124" y2="0.4064" layer="21"/>
<rectangle x1="-10.3124" y1="-0.4064" x2="-8.509" y2="0.4064" layer="21"/>
<pad name="1" x="-11.43" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="11.43" y="0" drill="1.016" shape="octagon"/>
<text x="-8.382" y="4.2164" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.223" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="6.604" y="-2.2606" size="1.27" layer="51" ratio="10" rot="R90">0817</text>
</package>
<package name="RCL_P0817V">
type 0817, grid 6.35 mm</description>
<circle x="-5.08" y="0" radius="3.81" width="0.1524" layer="21"/>
<circle x="-5.08" y="0" radius="1.27" width="0.1524" layer="51"/>
<wire x1="-3.81" y1="0" x2="-5.08" y2="0" width="0.8128" layer="51"/>
<wire x1="1.27" y1="0" x2="0" y2="0" width="0.8128" layer="51"/>
<rectangle x1="-3.81" y1="-0.4064" x2="0" y2="0.4064" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="1.016" shape="octagon"/>
<text x="-1.016" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.016" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.858" y="2.032" size="1.016" layer="21" ratio="12">0817</text>
</package>
<package name="RCL_R0402">
chip</description>
</package>
<package name="RCL_R0603">
chip</description>
<wire x1="-0.432" y1="-0.356" x2="0.432" y2="-0.356" width="0.1524" layer="51"/>
<wire x1="0.432" y1="0.356" x2="-0.432" y2="0.356" width="0.1524" layer="51"/>
<rectangle x1="0.4318" y1="-0.4318" x2="0.8382" y2="0.4318" layer="51"/>
<rectangle x1="-0.8382" y1="-0.4318" x2="-0.4318" y2="0.4318" layer="51"/>
<smd name="1" x="-0.85" y="0" dx="1" dy="1.1" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1" dy="1.1" layer="1"/>
<text x="-0.889" y="0.889" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="RCL_R0805">
chip</description>
<wire x1="-0.41" y1="0.635" x2="0.41" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.41" y1="-0.635" x2="0.41" y2="-0.635" width="0.1524" layer="51"/>
<rectangle x1="0.4064" y1="-0.6985" x2="1.0564" y2="0.7015" layer="51"/>
<rectangle x1="-1.0668" y1="-0.6985" x2="-0.4168" y2="0.7015" layer="51"/>
<text x="-0.762" y="1.016" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.762" y="-2.286" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_R0805W">
chip, wave soldering</description>
<smd name="1" x="-0.94" y="0" dx="1.5" dy="1" layer="1"/>
<smd name="2" x="0.94" y="0" dx="1.5" dy="1" layer="1"/>
<text x="-0.635" y="1.016" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="RCL_R1005">
chip</description>
</package>
<package name="RCL_R1206">
chip</description>
<wire x1="0.9525" y1="-0.8128" x2="-0.9652" y2="-0.8128" width="0.1524" layer="51"/>
<wire x1="0.9525" y1="0.8128" x2="-0.9652" y2="0.8128" width="0.1524" layer="51"/>
<rectangle x1="-1.6891" y1="-0.8763" x2="-0.9525" y2="0.8763" layer="51"/>
<rectangle x1="0.9525" y1="-0.8763" x2="1.6891" y2="0.8763" layer="51"/>
<smd name="1" x="-1.422" y="0" dx="1.6" dy="1.803" layer="16"/>
<smd name="2" x="1.422" y="0" dx="1.6" dy="1.803" layer="16"/>
<text x="-1.397" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.397" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_R1206W">
<wire x1="-0.913" y1="0.8" x2="0.888" y2="0.8" width="0.1524" layer="21"/>
<wire x1="-0.913" y1="-0.8" x2="0.888" y2="-0.8" width="0.1524" layer="21"/>
<rectangle x1="-1.651" y1="-0.8763" x2="-0.9009" y2="0.8738" layer="51"/>
<rectangle x1="0.889" y1="-0.8763" x2="1.6391" y2="0.8738" layer="51"/>
<smd name="1" x="-1.499" y="0" dx="1.8" dy="1.2" layer="1"/>
<smd name="2" x="1.499" y="0" dx="1.8" dy="1.2" layer="1"/>
</package>
<package name="RCL_R1210">
chip</description>
<wire x1="-0.913" y1="1.219" x2="0.939" y2="1.219" width="0.1524" layer="51"/>
<wire x1="-0.913" y1="-1.219" x2="0.939" y2="-1.219" width="0.1524" layer="51"/>
<rectangle x1="-1.651" y1="-1.3081" x2="-0.9009" y2="1.2918" layer="51"/>
<rectangle x1="0.9144" y1="-1.3081" x2="1.6645" y2="1.2918" layer="51"/>
<rectangle x1="-0.3" y1="-0.8999" x2="0.3" y2="0.8999" layer="35"/>
<text x="-1.27" y="1.651" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.921" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_R1210W">
<wire x1="-0.913" y1="1.219" x2="0.939" y2="1.219" width="0.1524" layer="21"/>
<wire x1="-0.913" y1="-1.219" x2="0.939" y2="-1.219" width="0.1524" layer="21"/>
<smd name="1" x="-1.499" y="0" dx="1.8" dy="1.8" layer="1"/>
<smd name="2" x="1.499" y="0" dx="1.8" dy="1.8" layer="1"/>
<text x="-1.651" y="1.524" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.651" y="-2.794" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_R2010">
chip</description>
<wire x1="-1.662" y1="1.245" x2="1.662" y2="1.245" width="0.1524" layer="51"/>
<wire x1="-1.637" y1="-1.245" x2="1.687" y2="-1.245" width="0.1524" layer="51"/>
<wire x1="-3.473" y1="1.483" x2="3.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="3.473" y1="1.483" x2="3.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="3.473" y1="-1.483" x2="-3.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-3.473" y1="-1.483" x2="-3.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="-1.027" y1="1.245" x2="1.027" y2="1.245" width="0.1524" layer="21"/>
<wire x1="-1.002" y1="-1.245" x2="1.016" y2="-1.245" width="0.1524" layer="21"/>
<rectangle x1="-2.4892" y1="-1.3208" x2="-1.6393" y2="1.3292" layer="51"/>
<rectangle x1="1.651" y1="-1.3208" x2="2.5009" y2="1.3292" layer="51"/>
<smd name="1" x="-2.2" y="0" dx="1.8" dy="2.7" layer="1"/>
<smd name="2" x="2.2" y="0" dx="1.8" dy="2.7" layer="1"/>
<text x="-2.159" y="1.651" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.159" y="-2.921" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_R2010W">
<wire x1="-1.662" y1="1.245" x2="1.662" y2="1.245" width="0.1524" layer="21"/>
<wire x1="-1.637" y1="-1.245" x2="1.687" y2="-1.245" width="0.1524" layer="21"/>
<smd name="1" x="-2.311" y="0" dx="2" dy="1.8" layer="1"/>
<smd name="2" x="2.311" y="0" dx="2" dy="1.8" layer="1"/>
<text x="-2.286" y="1.524" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.286" y="-2.921" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_R2012">
chip</description>
<rectangle x1="-0.1001" y1="-0.5999" x2="0.1001" y2="0.5999" layer="35"/>
</package>
<package name="RCL_R2012W">
<text x="-0.635" y="-2.286" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_R2512">
chip</description>
<wire x1="-2.362" y1="1.473" x2="2.387" y2="1.473" width="0.1524" layer="51"/>
<wire x1="-2.362" y1="-1.473" x2="2.387" y2="-1.473" width="0.1524" layer="51"/>
<wire x1="-3.973" y1="1.983" x2="3.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="1.983" x2="3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="-1.983" x2="-3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-3.973" y1="-1.983" x2="-3.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="1.473" x2="1.498" y2="1.473" width="0.1524" layer="21"/>
<wire x1="-1.473" y1="-1.473" x2="1.498" y2="-1.473" width="0.1524" layer="21"/>
<rectangle x1="-3.2004" y1="-1.5494" x2="-2.3505" y2="1.5507" layer="51"/>
<rectangle x1="2.3622" y1="-1.5494" x2="3.2121" y2="1.5507" layer="51"/>
<smd name="1" x="-2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<smd name="2" x="2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<text x="-2.667" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.667" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_R2512W">
<wire x1="-2.362" y1="1.473" x2="2.387" y2="1.473" width="0.1524" layer="21"/>
<wire x1="-2.362" y1="-1.473" x2="2.387" y2="-1.473" width="0.1524" layer="21"/>
<smd name="1" x="-2.896" y="0" dx="2" dy="2.1" layer="1"/>
<smd name="2" x="2.896" y="0" dx="2" dy="2.1" layer="1"/>
<text x="-2.794" y="1.778" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.794" y="-3.048" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_R3216">
chip</description>
<wire x1="-0.913" y1="0.8" x2="0.888" y2="0.8" width="0.1524" layer="51"/>
<wire x1="-0.913" y1="-0.8" x2="0.888" y2="-0.8" width="0.1524" layer="51"/>
</package>
<package name="RCL_R3216W">
<text x="-1.524" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_R3225">
chip</description>
<rectangle x1="-0.3" y1="-1" x2="0.3" y2="1" layer="35"/>
</package>
<package name="RCL_R3225W">
<text x="-1.397" y="1.524" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="RCL_R5025">
chip</description>
<wire x1="-0.9" y1="1.245" x2="0.9" y2="1.245" width="0.1524" layer="21"/>
<wire x1="-0.875" y1="-1.245" x2="0.925" y2="-1.245" width="0.1524" layer="21"/>
</package>
<package name="RCL_R5025W">
<text x="-2.286" y="1.651" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="RCL_R6332">
chip</description>
<text x="-2.794" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.794" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_R6332W">
<text x="-2.921" y="1.778" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.921" y="-3.048" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="RCL_RDH/15">
type RDH, grid 15 mm</description>
<wire x1="-7.62" y1="0" x2="-6.858" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.096" y1="3.048" x2="-5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="2.794" x2="-5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-3.048" x2="-5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.794" x2="-5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.794" x2="5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.794" x2="-4.953" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-2.794" x2="5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-2.794" x2="-4.953" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="6.096" y1="3.048" x2="5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-3.048" x2="5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-2.667" x2="-6.477" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="1.016" x2="-6.477" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="1.016" x2="-6.477" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-2.667" x2="6.477" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="6.477" y1="1.016" x2="6.477" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="6.477" y1="1.016" x2="6.477" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.858" y1="0" x2="7.62" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.477" y1="2.667" x2="-6.096" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="3.048" x2="6.477" y2="2.667" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.477" y1="-2.667" x2="-6.096" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="6.096" y1="-3.048" x2="6.477" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<rectangle x1="-6.7564" y1="-0.4064" x2="-6.4516" y2="0.4064" layer="51"/>
<rectangle x1="6.4516" y1="-0.4064" x2="6.7564" y2="0.4064" layer="51"/>
<text x="-6.35" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="4.572" y="-1.7272" size="1.27" layer="51" ratio="10" rot="R90">RDH</text>
</package>
<package name="RCL_V234/12">
type V234, grid 12.5 mm</description>
<wire x1="-4.953" y1="1.524" x2="-4.699" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="1.778" x2="4.953" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-1.778" x2="4.953" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.953" y1="-1.524" x2="-4.699" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.699" y1="1.778" x2="4.699" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="1.524" x2="-4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.778" x2="-4.699" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="4.953" y1="1.524" x2="4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0" x2="5.461" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.461" y2="0" width="0.8128" layer="51"/>
<rectangle x1="4.953" y1="-0.4064" x2="5.4102" y2="0.4064" layer="21"/>
<rectangle x1="-5.4102" y1="-0.4064" x2="-4.953" y2="0.4064" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="1.016" shape="octagon"/>
<text x="-4.953" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_V235/17">
type V235, grid 17.78 mm</description>
<wire x1="-6.731" y1="2.921" x2="6.731" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="2.54" x2="-7.112" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.921" x2="-6.731" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="7.112" y1="2.54" x2="7.112" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.89" y1="0" x2="7.874" y2="0" width="1.016" layer="51"/>
<wire x1="-7.874" y1="0" x2="-8.89" y2="0" width="1.016" layer="51"/>
<wire x1="-7.112" y1="-2.54" x2="-6.731" y2="-2.921" width="0.1524" layer="21" curve="90"/>
<wire x1="6.731" y1="2.921" x2="7.112" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.731" y1="-2.921" x2="7.112" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-7.112" y1="2.54" x2="-6.731" y2="2.921" width="0.1524" layer="21" curve="-90"/>
<rectangle x1="7.112" y1="-0.508" x2="7.747" y2="0.508" layer="21"/>
<rectangle x1="-7.747" y1="-0.508" x2="-7.112" y2="0.508" layer="21"/>
<pad name="1" x="-8.89" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="8.89" y="0" drill="1.1938" shape="octagon"/>
<text x="-6.858" y="3.302" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.842" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="RCL_V526-0">
type V526-0, grid 2.5 mm</description>
<wire x1="-2.54" y1="1.016" x2="-2.286" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="1.27" x2="2.54" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="-1.27" x2="2.54" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.54" y1="-1.016" x2="-2.286" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.27" x2="-2.286" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.016" x2="2.54" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.27" x2="2.286" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.016" x2="-2.54" y2="-1.016" width="0.1524" layer="21"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.413" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.413" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="TEXAS_SO-24">
<wire x1="-5.715" y1="10.795" x2="-5.715" y2="4.445" width="0.3048" layer="20"/>
<wire x1="-5.715" y1="4.445" x2="-5.715" y2="3.81" width="0.3048" layer="20"/>
<wire x1="-5.715" y1="3.81" x2="9.525" y2="3.81" width="0.3048" layer="20"/>
<wire x1="9.525" y1="3.81" x2="9.525" y2="4.445" width="0.3048" layer="20"/>
<wire x1="9.525" y1="4.445" x2="9.525" y2="10.795" width="0.3048" layer="20"/>
<wire x1="9.525" y1="10.795" x2="-5.715" y2="10.795" width="0.3048" layer="20"/>
<wire x1="-5.715" y1="4.445" x2="9.525" y2="4.445" width="0.3048" layer="20"/>
<rectangle x1="-5.2388" y1="10.9538" x2="-4.9213" y2="11.9063" layer="20"/>
<rectangle x1="-3.9688" y1="10.9538" x2="-3.6513" y2="11.9063" layer="20"/>
<rectangle x1="-2.6988" y1="10.9538" x2="-2.3813" y2="11.9063" layer="20"/>
<rectangle x1="-1.4288" y1="10.9538" x2="-1.1113" y2="11.9063" layer="20"/>
<rectangle x1="-0.1588" y1="10.9538" x2="0.1588" y2="11.9063" layer="20"/>
<rectangle x1="1.1113" y1="10.9538" x2="1.4288" y2="11.7475" layer="20"/>
<rectangle x1="1.27" y1="11.5888" x2="1.4288" y2="11.9063" layer="20"/>
<rectangle x1="1.1113" y1="11.5888" x2="1.27" y2="11.9063" layer="20"/>
<rectangle x1="2.3813" y1="10.9538" x2="2.6988" y2="11.9063" layer="20"/>
<rectangle x1="3.6513" y1="10.9538" x2="3.9688" y2="11.9063" layer="20"/>
<rectangle x1="4.9213" y1="10.9538" x2="5.2388" y2="11.9063" layer="20"/>
<rectangle x1="6.1913" y1="10.9538" x2="6.5088" y2="11.9063" layer="20"/>
<rectangle x1="7.4613" y1="10.9538" x2="7.7788" y2="11.9063" layer="20"/>
<rectangle x1="8.7313" y1="10.9538" x2="9.0488" y2="11.9063" layer="20"/>
<rectangle x1="-5.2388" y1="2.6988" x2="-4.9213" y2="3.6513" layer="20"/>
<rectangle x1="-3.9688" y1="2.6988" x2="-3.6513" y2="3.6513" layer="20"/>
<rectangle x1="-2.6988" y1="2.6988" x2="-2.3813" y2="3.6513" layer="20"/>
<rectangle x1="-1.4288" y1="2.6988" x2="-1.1113" y2="3.6513" layer="20"/>
<rectangle x1="-0.1588" y1="2.6988" x2="0.1588" y2="3.6513" layer="20"/>
<rectangle x1="1.1113" y1="2.6988" x2="1.4288" y2="3.6513" layer="20"/>
<rectangle x1="2.3813" y1="2.6988" x2="2.6988" y2="3.6513" layer="20"/>
<rectangle x1="3.6513" y1="2.6988" x2="3.9688" y2="3.6513" layer="20"/>
<rectangle x1="4.9213" y1="2.6988" x2="5.2388" y2="3.6513" layer="20"/>
<rectangle x1="6.1913" y1="2.6988" x2="6.5088" y2="3.6513" layer="20"/>
<rectangle x1="7.4613" y1="2.6988" x2="7.7788" y2="3.6513" layer="20"/>
<rectangle x1="8.7313" y1="2.6988" x2="8.89" y2="3.6513" layer="20"/>
<rectangle x1="8.89" y1="2.6988" x2="9.0488" y2="3.6513" layer="20"/>
<smd name="1" x="8.89" y="3.175" dx="1.4224" dy="0.7112" layer="16" rot="R90"/>
<smd name="2" x="7.62" y="3.175" dx="1.4224" dy="0.7112" layer="16" rot="R90"/>
<smd name="3" x="6.35" y="3.175" dx="1.4224" dy="0.7112" layer="16" rot="R90"/>
<smd name="4" x="5.08" y="3.175" dx="1.4224" dy="0.7112" layer="16" rot="R90"/>
<smd name="5" x="3.81" y="3.175" dx="1.4224" dy="0.7112" layer="16" rot="R90"/>
<smd name="6" x="2.54" y="3.175" dx="1.4224" dy="0.7112" layer="16" rot="R90"/>
<smd name="7" x="1.27" y="3.175" dx="1.4224" dy="0.7112" layer="16" rot="R90"/>
<smd name="8" x="0" y="3.175" dx="1.4224" dy="0.7112" layer="16" rot="R90"/>
<smd name="9" x="-1.27" y="3.175" dx="1.4224" dy="0.7112" layer="16" rot="R90"/>
<smd name="10" x="-2.54" y="3.175" dx="1.4224" dy="0.7112" layer="16" rot="R90"/>
<smd name="11" x="-3.81" y="3.175" dx="1.4224" dy="0.7112" layer="16" rot="R90"/>
<smd name="12" x="-5.08" y="3.175" dx="1.4224" dy="0.7112" layer="16" rot="R90"/>
<smd name="13" x="-5.08" y="11.43" dx="1.4224" dy="0.7112" layer="16" rot="R90"/>
<smd name="14" x="-3.81" y="11.43" dx="1.4224" dy="0.7112" layer="16" rot="R90"/>
<smd name="15" x="-2.54" y="11.43" dx="1.4224" dy="0.7112" layer="16" rot="R90"/>
<smd name="16" x="-1.27" y="11.43" dx="1.4224" dy="0.7112" layer="16" rot="R90"/>
<smd name="17" x="0" y="11.43" dx="1.4224" dy="0.7112" layer="16" rot="R90"/>
<smd name="18" x="1.27" y="11.43" dx="1.4224" dy="0.7112" layer="16" rot="R90"/>
<smd name="19" x="2.54" y="11.43" dx="1.4224" dy="0.7112" layer="16" rot="R90"/>
<smd name="20" x="3.81" y="11.43" dx="1.4224" dy="0.7112" layer="16" rot="R90"/>
<smd name="21" x="5.08" y="11.43" dx="1.4224" dy="0.7112" layer="16" rot="R90"/>
<smd name="22" x="6.35" y="11.43" dx="1.4224" dy="0.7112" layer="16" rot="R90"/>
<smd name="23" x="7.62" y="11.43" dx="1.4224" dy="0.7112" layer="16" rot="R90"/>
<smd name="24" x="8.89" y="11.43" dx="1.4224" dy="0.7112" layer="16" rot="R90"/>
<text x="-4.445" y="8.255" size="1.27" layer="20">&gt;NAME</text>
<text x="-4.445" y="5.715" size="1.27" layer="20">&gt;VALUE</text>
</package>
</packages>
<symbols>
<symbol name="DIODE_ZD">
<wire x1="-1.27" y1="-1.27" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="-1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="1.27" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="-1.27" x2="0.635" y2="-1.27" width="0.254" layer="94"/>
<pin name="A" x="-2.54" y="0" visible="off" length="short" direction="pas"/>
<pin name="C" x="2.54" y="0" visible="off" length="short" direction="pas" rot="R180"/>
<text x="-1.778" y="1.905" size="1.778" layer="95">&gt;NAME</text>
<text x="-1.778" y="-3.429" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="FRAMES_A4L-LOC">
<wire x1="0" y1="0" x2="3.175" y2="0" width="0.1524" layer="94"/>
<wire x1="3.175" y1="0" x2="50.8" y2="0" width="0.1016" layer="94"/>
<wire x1="50.8" y1="0" x2="98.425" y2="0" width="0.1016" layer="94"/>
<wire x1="98.425" y1="0" x2="146.05" y2="0" width="0.1016" layer="94"/>
<wire x1="146.05" y1="0" x2="193.675" y2="0" width="0.1016" layer="94"/>
<wire x1="193.675" y1="0" x2="241.3" y2="0" width="0.1016" layer="94"/>
<wire x1="260.35" y1="0" x2="260.35" y2="53.975" width="0.1016" layer="94"/>
<wire x1="260.35" y1="53.975" x2="260.35" y2="104.775" width="0.1016" layer="94"/>
<wire x1="260.35" y1="104.775" x2="260.35" y2="155.575" width="0.1016" layer="94"/>
<wire x1="260.35" y1="155.575" x2="260.35" y2="179.07" width="0.1016" layer="94"/>
<wire x1="146.05" y1="179.07" x2="98.425" y2="179.07" width="0.1524" layer="94"/>
<wire x1="98.425" y1="179.07" x2="50.8" y2="179.07" width="0.1016" layer="94"/>
<wire x1="50.8" y1="179.07" x2="0" y2="179.07" width="0.1016" layer="94"/>
<wire x1="0" y1="179.07" x2="0" y2="155.575" width="0.1016" layer="94"/>
<wire x1="0" y1="155.575" x2="0" y2="104.775" width="0.1016" layer="94"/>
<wire x1="0" y1="104.775" x2="0" y2="53.975" width="0.1016" layer="94"/>
<wire x1="0" y1="53.975" x2="0" y2="3.175" width="0.1016" layer="94"/>
<wire x1="0" y1="3.175" x2="0" y2="0" width="0.1524" layer="94"/>
<wire x1="3.175" y1="3.175" x2="50.8" y2="3.175" width="0.1016" layer="94"/>
<wire x1="50.8" y1="3.175" x2="98.425" y2="3.175" width="0.1016" layer="94"/>
<wire x1="257.175" y1="3.175" x2="257.175" y2="8.255" width="0.1016" layer="94"/>
<wire x1="257.175" y1="8.255" x2="257.175" y2="13.335" width="0.1016" layer="94"/>
<wire x1="257.175" y1="13.335" x2="257.175" y2="18.415" width="0.1016" layer="94"/>
<wire x1="257.175" y1="18.415" x2="257.175" y2="23.495" width="0.1016" layer="94"/>
<wire x1="257.175" y1="23.495" x2="257.175" y2="53.975" width="0.1016" layer="94"/>
<wire x1="257.175" y1="53.975" x2="257.175" y2="104.775" width="0.1016" layer="94"/>
<wire x1="257.175" y1="104.775" x2="257.175" y2="155.575" width="0.1016" layer="94"/>
<wire x1="257.175" y1="155.575" x2="257.175" y2="175.895" width="0.1016" layer="94"/>
<wire x1="193.675" y1="175.895" x2="146.05" y2="175.895" width="0.1016" layer="94"/>
<wire x1="146.05" y1="175.895" x2="98.425" y2="175.895" width="0.1524" layer="94"/>
<wire x1="98.425" y1="175.895" x2="50.8" y2="175.895" width="0.1016" layer="94"/>
<wire x1="50.8" y1="175.895" x2="3.175" y2="175.895" width="0.1016" layer="94"/>
<wire x1="3.175" y1="175.895" x2="3.175" y2="155.575" width="0.1016" layer="94"/>
<wire x1="3.175" y1="155.575" x2="3.175" y2="104.775" width="0.1016" layer="94"/>
<wire x1="3.175" y1="104.775" x2="3.175" y2="53.975" width="0.1016" layer="94"/>
<wire x1="3.175" y1="53.975" x2="3.175" y2="3.175" width="0.1016" layer="94"/>
<wire x1="193.675" y1="179.07" x2="146.05" y2="179.07" width="0.1016" layer="94"/>
<wire x1="193.675" y1="179.07" x2="193.675" y2="175.895" width="0.1016" layer="94"/>
<wire x1="193.675" y1="3.175" x2="193.675" y2="0" width="0.1016" layer="94"/>
<wire x1="0" y1="104.775" x2="3.175" y2="104.775" width="0.1016" layer="94"/>
<wire x1="257.175" y1="155.575" x2="260.35" y2="155.575" width="0.1016" layer="94"/>
<wire x1="98.425" y1="175.895" x2="98.425" y2="179.07" width="0.1016" layer="94"/>
<wire x1="98.425" y1="3.175" x2="98.425" y2="0" width="0.1016" layer="94"/>
<wire x1="0" y1="53.975" x2="3.175" y2="53.975" width="0.1016" layer="94"/>
<wire x1="257.175" y1="104.775" x2="260.35" y2="104.775" width="0.1016" layer="94"/>
<wire x1="0" y1="155.575" x2="3.175" y2="155.575" width="0.1016" layer="94"/>
<wire x1="50.8" y1="175.895" x2="50.8" y2="179.07" width="0.1016" layer="94"/>
<wire x1="257.175" y1="53.975" x2="260.35" y2="53.975" width="0.1016" layer="94"/>
<wire x1="146.05" y1="175.895" x2="146.05" y2="179.07" width="0.1016" layer="94"/>
<wire x1="241.3" y1="179.07" x2="241.3" y2="175.895" width="0.1016" layer="94"/>
<wire x1="241.3" y1="3.175" x2="241.3" y2="0" width="0.1016" layer="94"/>
<wire x1="146.05" y1="3.175" x2="146.05" y2="0" width="0.1016" layer="94"/>
<wire x1="50.8" y1="0" x2="50.8" y2="3.175" width="0.1016" layer="94"/>
<wire x1="161.925" y1="3.175" x2="161.925" y2="23.495" width="0.6096" layer="94"/>
<wire x1="161.925" y1="23.495" x2="215.9" y2="23.495" width="0.6096" layer="94"/>
<wire x1="215.9" y1="23.495" x2="257.175" y2="23.495" width="0.6096" layer="94"/>
<wire x1="247.015" y1="3.175" x2="247.015" y2="8.255" width="0.1016" layer="94"/>
<wire x1="247.015" y1="8.255" x2="257.175" y2="8.255" width="0.1016" layer="94"/>
<wire x1="247.015" y1="8.255" x2="215.9" y2="8.255" width="0.1016" layer="94"/>
<wire x1="215.9" y1="8.255" x2="215.9" y2="3.175" width="0.6096" layer="94"/>
<wire x1="215.9" y1="8.255" x2="215.9" y2="13.335" width="0.6096" layer="94"/>
<wire x1="215.9" y1="13.335" x2="257.175" y2="13.335" width="0.1016" layer="94"/>
<wire x1="215.9" y1="13.335" x2="215.9" y2="18.415" width="0.6096" layer="94"/>
<wire x1="215.9" y1="18.415" x2="257.175" y2="18.415" width="0.1016" layer="94"/>
<wire x1="215.9" y1="18.415" x2="215.9" y2="23.495" width="0.6096" layer="94"/>
<wire x1="257.175" y1="175.895" x2="193.675" y2="175.895" width="0.1016" layer="94"/>
<wire x1="260.35" y1="179.07" x2="193.675" y2="179.07" width="0.1016" layer="94"/>
<wire x1="98.425" y1="3.175" x2="193.548" y2="3.175" width="0.1016" layer="94"/>
<wire x1="193.929" y1="3.175" x2="241.3" y2="3.175" width="0.1016" layer="94"/>
<wire x1="241.427" y1="3.175" x2="257.175" y2="3.175" width="0.1016" layer="94"/>
<wire x1="241.427" y1="0" x2="260.35" y2="0" width="0.1016" layer="94"/>
<text x="24.384" y="0.254" size="2.54" layer="94" font="vector">A</text>
<text x="74.422" y="0.254" size="2.54" layer="94" font="vector">B</text>
<text x="121.158" y="0.254" size="2.54" layer="94" font="vector">C</text>
<text x="169.418" y="0.254" size="2.54" layer="94" font="vector">D</text>
<text x="216.916" y="0.254" size="2.54" layer="94" font="vector">E</text>
<text x="254.762" y="0.254" size="2.54" layer="94" font="vector">F</text>
<text x="258.064" y="28.702" size="2.54" layer="94" font="vector">1</text>
<text x="257.81" y="79.502" size="2.54" layer="94" font="vector">2</text>
<text x="257.81" y="130.302" size="2.54" layer="94" font="vector">3</text>
<text x="215.9" y="176.276" size="2.54" layer="94" font="vector">E</text>
<text x="168.148" y="176.276" size="2.54" layer="94" font="vector">D</text>
<text x="120.904" y="176.276" size="2.54" layer="94" font="vector">C</text>
<text x="72.898" y="176.276" size="2.54" layer="94" font="vector">B</text>
<text x="24.384" y="176.276" size="2.54" layer="94" font="vector">A</text>
<text x="0.762" y="130.302" size="2.54" layer="94" font="vector">3</text>
<text x="0.762" y="79.248" size="2.54" layer="94" font="vector">2</text>
<text x="1.016" y="26.67" size="2.54" layer="94" font="vector">1</text>
<text x="217.805" y="14.605" size="2.54" layer="94" font="vector">&gt;DRAWING_NAME</text>
<text x="217.805" y="9.525" size="2.286" layer="94" font="vector">&gt;LAST_DATE_TIME</text>
<text x="231.14" y="4.445" size="2.54" layer="94" font="vector">&gt;SHEET</text>
<text x="217.551" y="4.318" size="2.54" layer="94" font="vector">Sheet:</text>
<text x="249.682" y="176.276" size="2.54" layer="94" font="vector">F</text>
<text x="257.556" y="168.148" size="2.54" layer="94" font="vector">4</text>
<text x="0.508" y="168.148" size="2.54" layer="94" font="vector">4</text>
</symbol>
<symbol name="IC-PACKAGE_DIL24">
<wire x1="-5.08" y1="16.51" x2="-5.08" y2="-13.97" width="0.254" layer="94"/>
<wire x1="-5.08" y1="-13.97" x2="5.08" y2="-13.97" width="0.254" layer="94"/>
<wire x1="5.08" y1="-13.97" x2="5.08" y2="16.51" width="0.254" layer="94"/>
<wire x1="5.08" y1="16.51" x2="2.54" y2="16.51" width="0.254" layer="94"/>
<wire x1="-5.08" y1="16.51" x2="-2.54" y2="16.51" width="0.254" layer="94"/>
<wire x1="-2.54" y1="16.51" x2="2.54" y2="16.51" width="0.254" layer="94" curve="180"/>
<pin name="1" x="-7.62" y="15.24" visible="pad" length="short" direction="pas"/>
<pin name="2" x="-7.62" y="12.7" visible="pad" length="short" direction="pas"/>
<pin name="3" x="-7.62" y="10.16" visible="pad" length="short" direction="pas"/>
<pin name="4" x="-7.62" y="7.62" visible="pad" length="short" direction="pas"/>
<pin name="5" x="-7.62" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="6" x="-7.62" y="2.54" visible="pad" length="short" direction="pas"/>
<pin name="7" x="-7.62" y="0" visible="pad" length="short" direction="pas"/>
<pin name="8" x="-7.62" y="-2.54" visible="pad" length="short" direction="pas"/>
<pin name="9" x="-7.62" y="-5.08" visible="pad" length="short" direction="pas"/>
<pin name="10" x="-7.62" y="-7.62" visible="pad" length="short" direction="pas"/>
<pin name="11" x="-7.62" y="-10.16" visible="pad" length="short" direction="pas"/>
<pin name="12" x="-7.62" y="-12.7" visible="pad" length="short" direction="pas"/>
<pin name="13" x="7.62" y="-12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="14" x="7.62" y="-10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="15" x="7.62" y="-7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="16" x="7.62" y="-5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="17" x="7.62" y="-2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="18" x="7.62" y="0" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="19" x="7.62" y="2.54" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="20" x="7.62" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="21" x="7.62" y="7.62" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="22" x="7.62" y="10.16" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="23" x="7.62" y="12.7" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="24" x="7.62" y="15.24" visible="pad" length="short" direction="pas" rot="R180"/>
<text x="-4.445" y="17.145" size="1.778" layer="95">&gt;NAME</text>
<text x="-4.445" y="-16.51" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="RCL_C-EU">
<rectangle x1="-2.032" y1="-2.032" x2="2.032" y2="-1.524" layer="94"/>
<rectangle x1="-2.032" y1="-1.016" x2="2.032" y2="-0.508" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="-0.508" width="0.1524" layer="94"/>
<wire x1="0" y1="-2.54" x2="0" y2="-2.032" width="0.1524" layer="94"/>
<pin name="1" x="0" y="2.54" visible="off" length="short" direction="pas" swaplevel="1" rot="R270"/>
<pin name="2" x="0" y="-5.08" visible="off" length="short" direction="pas" swaplevel="1" rot="R90"/>
<text x="1.524" y="0.381" size="1.778" layer="95">&gt;NAME</text>
<text x="1.524" y="-4.699" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="RCL_R-EU">
<wire x1="-2.54" y1="-0.889" x2="2.54" y2="-0.889" width="0.254" layer="94"/>
<wire x1="2.54" y1="0.889" x2="-2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="2.54" y1="-0.889" x2="2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-0.889" x2="-2.54" y2="0.889" width="0.254" layer="94"/>
<pin name="1" x="-5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
<pin name="2" x="5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1" rot="R180"/>
<text x="-3.81" y="1.4986" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.81" y="-3.302" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="SUPPLY1_GND">
<wire x1="-1.905" y1="0" x2="1.905" y2="0" width="0.254" layer="94"/>
<pin name="GND" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
<text x="-2.54" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
</symbol>
<symbol name="SUPPLY1_VCC">
<wire x1="1.27" y1="-1.905" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="-1.27" y2="-1.905" width="0.254" layer="94"/>
<pin name="VCC" x="0" y="-2.54" visible="off" length="short" direction="sup" rot="R90"/>
<text x="-2.54" y="-2.54" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
</symbol>
<symbol name="TEXAS_TLC5540">
<wire x1="-17.78" y1="25.4" x2="-17.78" y2="-25.4" width="0.254" layer="94"/>
<wire x1="-17.78" y1="-25.4" x2="15.24" y2="-25.4" width="0.254" layer="94"/>
<wire x1="15.24" y1="-25.4" x2="15.24" y2="25.4" width="0.254" layer="94"/>
<wire x1="15.24" y1="25.4" x2="-17.78" y2="25.4" width="0.254" layer="94"/>
<pin name="A-IN" x="-22.86" y="22.86" length="middle"/>
<pin name="AGND" x="-22.86" y="-17.78" length="middle"/>
<pin name="AGND2" x="-22.86" y="-22.86" length="middle"/>
<pin name="CLK" x="20.32" y="-17.78" length="middle" function="clk" rot="R180"/>
<pin name="D1" x="20.32" y="-12.7" length="middle" rot="R180"/>
<pin name="D2" x="20.32" y="-7.62" length="middle" rot="R180"/>
<pin name="D3" x="20.32" y="-2.54" length="middle" rot="R180"/>
<pin name="D4" x="20.32" y="2.54" length="middle" rot="R180"/>
<pin name="D5" x="20.32" y="7.62" length="middle" rot="R180"/>
<pin name="D6" x="20.32" y="12.7" length="middle" rot="R180"/>
<pin name="D7" x="20.32" y="17.78" length="middle" rot="R180"/>
<pin name="D8" x="20.32" y="22.86" length="middle" rot="R180"/>
<pin name="DGND1" x="-5.08" y="-30.48" length="middle" rot="R90"/>
<pin name="DGND2" x="5.08" y="-30.48" length="middle" rot="R90"/>
<pin name="OE" x="20.32" y="-22.86" length="middle" function="dot" rot="R180"/>
<pin name="REFB" x="-22.86" y="-7.62" length="middle"/>
<pin name="REFBS" x="-22.86" y="-12.7" length="middle"/>
<pin name="REFT" x="-22.86" y="-2.54" length="middle"/>
<pin name="REFTS" x="-22.86" y="2.54" length="middle"/>
<pin name="VDDA" x="-22.86" y="17.78" length="middle"/>
<pin name="VDDA2" x="-22.86" y="12.7" length="middle"/>
<pin name="VDDA3" x="-22.86" y="7.62" length="middle"/>
<pin name="VDDD1" x="-5.08" y="30.48" length="middle" rot="R270"/>
<pin name="VDDD2" x="5.08" y="30.48" length="middle" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="DIODE_ZENER-DIODE" prefix="D" uservalue="yes">
<description>Z-Diode</description>
<gates>
<gate name="G$1" symbol="DIODE_ZD" x="0" y="0"/>
</gates>
<devices>
<device name="C1702-15" package="DIODE_C1702-15">
<connects>
<connect gate="G$1" pin="A" pad="A"/>
<connect gate="G$1" pin="C" pad="C"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="DO13M" package="DIODE_DO13M">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DO34-7" package="DIODE_DO34Z7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DO35Z10" package="DIODE_DO35Z10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="DO41Z10" package="DIODE_DO41Z10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="F126-10" package="DIODE_F126Z10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="F126-12" package="DIODE_F126Z12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P1-12" package="DIODE_P1Z12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="P1-Z12" package="DIODE_P1Z12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SMB" package="DIODE_SMB">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD57-10" package="DIODE_SOD57Z10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD64-10" package="DIODE_SOD64Z10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD64-12" package="DIODE_SOD64Z12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOD80C" package="DIODE_SOD80C">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="SOT23" package="DIODE_SOT23">
<connects>
<connect gate="G$1" pin="A" pad="1"/>
<connect gate="G$1" pin="C" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
<device name="SOT223" package="DIODE_SOT223">
<connects>
<connect gate="G$1" pin="C" pad="4"/>
</connects>
<technologies>
</technologies>
</device>
<device name="TO236" package="DIODE_TO236">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ZD-2.5" package="DIODE_ZDIO-2.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ZD-5" package="DIODE_ZDIO-5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ZD-7.5" package="DIODE_ZDIO-7.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ZD-10" package="DIODE_ZDIO-10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="ZD-12.5" package="DIODE_ZDIO12.5">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="FRAMES_A4L-LOC" prefix="FRAME">
<description>&lt;b&gt;FRAME&lt;/b&gt;&lt;p&gt;
DIN A4, landscape with location and doc. field</description>
<gates>
<gate name="G$1" symbol="FRAMES_A4L-LOC" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="IC-PACKAGE_DIL24" prefix="IC" uservalue="yes">
<description>&lt;b&gt;Dual In Line&lt;/b&gt;</description>
<gates>
<gate name="G$1" symbol="IC-PACKAGE_DIL24" x="0" y="0"/>
</gates>
<devices>
<device name="-3" package="IC-PACKAGE_DIL24-3">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="10" pad="10"/>
<connect gate="G$1" pin="11" pad="11"/>
<connect gate="G$1" pin="12" pad="12"/>
<connect gate="G$1" pin="13" pad="13"/>
<connect gate="G$1" pin="14" pad="14"/>
<connect gate="G$1" pin="15" pad="15"/>
<connect gate="G$1" pin="16" pad="16"/>
<connect gate="G$1" pin="17" pad="17"/>
<connect gate="G$1" pin="18" pad="18"/>
<connect gate="G$1" pin="19" pad="19"/>
<connect gate="G$1" pin="2" pad="2"/>
<connect gate="G$1" pin="20" pad="20"/>
<connect gate="G$1" pin="21" pad="21"/>
<connect gate="G$1" pin="22" pad="22"/>
<connect gate="G$1" pin="23" pad="23"/>
<connect gate="G$1" pin="24" pad="24"/>
<connect gate="G$1" pin="3" pad="3"/>
<connect gate="G$1" pin="4" pad="4"/>
<connect gate="G$1" pin="5" pad="5"/>
<connect gate="G$1" pin="6" pad="6"/>
<connect gate="G$1" pin="7" pad="7"/>
<connect gate="G$1" pin="8" pad="8"/>
<connect gate="G$1" pin="9" pad="9"/>
</connects>
<technologies>
</technologies>
</device>
<device name="-4" package="IC-PACKAGE_DIL24-4">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-6" package="IC-PACKAGE_DIL24-6">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="-9" package="IC-PACKAGE_DIL24-9">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="RCL_C-EU" prefix="C" uservalue="yes">
<description>&lt;B&gt;CAPACITOR&lt;/B&gt;, European symbol</description>
<gates>
<gate name="G$1" symbol="RCL_C-EU" x="0" y="0"/>
</gates>
<devices>
<device name="025-024X044" package="RCL_C025-024X044">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-025X050" package="RCL_C025-025X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-030X050" package="RCL_C025-030X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-040X050" package="RCL_C025-040X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-050X050" package="RCL_C025-050X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-060X050" package="RCL_C025-060X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025_050-025X075" package="RCL_C025_050-025X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025_050-035X075" package="RCL_C025_050-035X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025_050-045X075" package="RCL_C025_050-045X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025_050-055X075" package="RCL_C025_050-055X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-024X044" package="RCL_C050-024X044">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-025X075" package="RCL_C050-025X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-030X075" package="RCL_C050-030X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-035X075" package="RCL_C050-035X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-045X075" package="RCL_C050-045X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-050X075" package="RCL_C050-050X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-055X075" package="RCL_C050-055X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-075X075" package="RCL_C050-075X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050H075X075" package="RCL_C050H075X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="075-032X103" package="RCL_C075-032X103">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="075-042X103" package="RCL_C075-042X103">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="075-052X106" package="RCL_C075-052X106">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="075-063X106" package="RCL_C075-063X106">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="102-043X133" package="RCL_C102-043X133">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="102-054X133" package="RCL_C102-054X133">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="102-064X133" package="RCL_C102-064X133">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="102_152-062X184" package="RCL_C102_152-062X184">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-054X183" package="RCL_C150-054X183">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-064X183" package="RCL_C150-064X183">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-072X183" package="RCL_C150-072X183">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-084X183" package="RCL_C150-084X183">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-091X182" package="RCL_C150-091X182">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-062X268" package="RCL_C225-062X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-074X268" package="RCL_C225-074X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-087X268" package="RCL_C225-087X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-108X268" package="RCL_C225-108X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-113X268" package="RCL_C225-113X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-093X316" package="RCL_C275-093X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-113X316" package="RCL_C275-113X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-134X316" package="RCL_C275-134X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-154X316" package="RCL_C275-154X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-173X316" package="RCL_C275-173X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-205X316" package="RCL_C275-205X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="325-137X374" package="RCL_C325-137X374">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="325-162X374" package="RCL_C325-162X374">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="325-182X374" package="RCL_C325-182X374">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="375-155X418" package="RCL_C375-155X418">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="375-192X418" package="RCL_C375-192X418">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="375-203X418" package="RCL_C375-203X418">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C025_050-024X070" package="RCL_C025_050-024X070">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0402" package="RCL_C0402">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0402K" package="RCL_C0402K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0504" package="RCL_C0504">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0603" package="RCL_C0603">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0603K" package="RCL_C0603K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0805" package="RCL_C0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0805K" package="RCL_C0805K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1005" package="RCL_C1005">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1206" package="RCL_C1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1206K" package="RCL_C1206K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1210" package="RCL_C1210">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1210K" package="RCL_C1210K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1310" package="RCL_C1310">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1608" package="RCL_C1608">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1812" package="RCL_C1812">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1812K" package="RCL_C1812K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1825" package="RCL_C1825">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1825K" package="RCL_C1825K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C2012" package="RCL_C2012">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C2220K" package="RCL_C2220K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C2225K" package="RCL_C2225K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C3216" package="RCL_C3216">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C3225" package="RCL_C3225">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C4532" package="RCL_C4532">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C4564" package="RCL_C4564">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="RCL_R-EU_" prefix="R" uservalue="yes">
<description>&lt;B&gt;RESISTOR&lt;/B&gt;, European symbol</description>
<gates>
<gate name="G$1" symbol="RCL_R-EU" x="0" y="0"/>
</gates>
<devices>
<device name="0204/2V" package="RCL_0204V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/5" package="RCL_0204/5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/7" package="RCL_0204/7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/2V" package="RCL_0207/2V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/5V" package="RCL_0207/5V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/7" package="RCL_0207/7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/10" package="RCL_0207/10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/12" package="RCL_0207/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/15" package="RCL_0207/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0309/10" package="RCL_0309/10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0309/12" package="RCL_0309/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0309/V" package="RCL_0309V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0411/3V" package="RCL_0411V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0411/12" package="RCL_0411/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0411/15" package="RCL_0411/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0414/5V" package="RCL_0414V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0414/15" package="RCL_0414/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0613/5V" package="RCL_P0613V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0613/15" package="RCL_P0613/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0617/5V" package="RCL_0617V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0617/17" package="RCL_0617/17">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0617/22" package="RCL_0617/22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0817/7V" package="RCL_P0817V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0817/22" package="RCL_P0817/22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0922/22" package="RCL_0922/22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0922V" package="RCL_0922V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M0805" package="RCL_M0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M1206" package="RCL_M1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M1406" package="RCL_M1406">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M2012" package="RCL_M2012">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M2309" package="RCL_M2309">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M3216" package="RCL_M3216">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M3516" package="RCL_M3516">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M5923" package="RCL_M5923">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0102AX" package="RCL_MINI_MELF-0102AX">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0102R" package="RCL_MINI_MELF-0102R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0102W" package="RCL_MINI_MELF-0102W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0204R" package="RCL_MINI_MELF-0204R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0204W" package="RCL_MINI_MELF-0204W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0207R" package="RCL_MINI_MELF-0207R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0207W" package="RCL_MINI_MELF-0207W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R0402" package="RCL_R0402">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R0603" package="RCL_R0603">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R0805" package="RCL_R0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R0805W" package="RCL_R0805W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1005" package="RCL_R1005">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1206" package="RCL_R1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1206W" package="RCL_R1206W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1210" package="RCL_R1210">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1210W" package="RCL_R1210W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2010" package="RCL_R2010">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2010W" package="RCL_R2010W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2012" package="RCL_R2012">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2012W" package="RCL_R2012W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2512" package="RCL_R2512">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2512W" package="RCL_R2512W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3216" package="RCL_R3216">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3216W" package="RCL_R3216W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3225" package="RCL_R3225">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3225W" package="RCL_R3225W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R5025" package="RCL_R5025">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R5025W" package="RCL_R5025W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R6332" package="RCL_R6332">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R6332W" package="RCL_R6332W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="RDH/15" package="RCL_RDH/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V234/12" package="RCL_V234/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V235/17" package="RCL_V235/17">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V526-0" package="RCL_V526-0">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="SUPPLY1_GND" prefix="GND">
<description>&lt;b&gt;SUPPLY SYMBOL&lt;/b&gt;</description>
<gates>
<gate name="1" symbol="SUPPLY1_GND" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="SUPPLY1_VCC" prefix="P+">
<gates>
<gate name="VCC" symbol="SUPPLY1_VCC" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="TEXAS_TLC5540" prefix="IC">
<gates>
<gate name="G$1" symbol="TEXAS_TLC5540" x="2.54" y="-2.54"/>
</gates>
<devices>
<device name="" package="TEXAS_SO-24">
<connects>
<connect gate="G$1" pin="A-IN" pad="19"/>
<connect gate="G$1" pin="AGND" pad="20"/>
<connect gate="G$1" pin="AGND2" pad="21"/>
<connect gate="G$1" pin="CLK" pad="12"/>
<connect gate="G$1" pin="D1" pad="3"/>
<connect gate="G$1" pin="D2" pad="4"/>
<connect gate="G$1" pin="D3" pad="5"/>
<connect gate="G$1" pin="D4" pad="6"/>
<connect gate="G$1" pin="D5" pad="7"/>
<connect gate="G$1" pin="D6" pad="8"/>
<connect gate="G$1" pin="D7" pad="9"/>
<connect gate="G$1" pin="D8" pad="10"/>
<connect gate="G$1" pin="DGND1" pad="2"/>
<connect gate="G$1" pin="DGND2" pad="24"/>
<connect gate="G$1" pin="OE" pad="1"/>
<connect gate="G$1" pin="REFB" pad="23"/>
<connect gate="G$1" pin="REFBS" pad="22"/>
<connect gate="G$1" pin="REFT" pad="17"/>
<connect gate="G$1" pin="REFTS" pad="16"/>
<connect gate="G$1" pin="VDDA" pad="14"/>
<connect gate="G$1" pin="VDDA2" pad="15"/>
<connect gate="G$1" pin="VDDA3" pad="18"/>
<connect gate="G$1" pin="VDDD1" pad="11"/>
<connect gate="G$1" pin="VDDD2" pad="13"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
