# Makefile for the project LedBoard_8x48
## General Flags
PROJECT = LedBoard_8x48
MCU = atmega328p
TARGET = LedBoard_8x48.elf
CC = avr-gcc.exe
## Options common to compile, link and assembly rules
COMMON = -mmcu=$(MCU)
## Compile options common for all C compilation units.
CFLAGS = $(COMMON)
CFLAGS += -Wall -gdwarf-2 -std=gnu99 -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums
CFLAGS += -MD -MP -MT $(*F).o -MF dep/$(@F).d
## Assembly specific flags
ASMFLAGS = $(COMMON)
ASMFLAGS += -x assembler-with-cpp -Wa,-gdwarf2
## Linker flags
LDFLAGS = $(COMMON)
LDFLAGS +=  -Wl,-Map=LedBoard_8x48.map
## Intel Hex file production flags
HEX_FLASH_FLAGS = -R .eeprom
HEX_EEPROM_FLAGS = -j .eeprom
HEX_EEPROM_FLAGS += --set-section-flags=.eeprom="alloc,load"
HEX_EEPROM_FLAGS += --change-section-lma .eeprom=0
## Objects that must be built in order to link
OBJECTS = LedBoard_8x48.o xprintf.o
## Objects explicitly added by the user
LINKONLYOBJECTS =
## Build
all: $(TARGET) LedBoard_8x48.hex LedBoard_8x48.eep LedBoard_8x48.lss size
## Compile
LedBoard_8x48.o: ../LedBoard_8x48.c
	$(CC) $(INCLUDES) $(CFLAGS) -c  $<
xprintf.o: ../xprintf.c
##Link
$(TARGET): $(OBJECTS)
	 $(CC) $(LDFLAGS) $(OBJECTS) $(LINKONLYOBJECTS) $(LIBDIRS) $(LIBS) -o $(TARGET)
%.hex: $(TARGET)
	avr-objcopy -O ihex $(HEX_FLASH_FLAGS)  $< $@
%.eep: $(TARGET)
	avr-objcopy $(HEX_EEPROM_FLAGS) -O ihex $< $@
%.lss: $(TARGET)
	avr-objdump -h -S $< > $@
	@echo
	@avr-size -C --mcu=${MCU} ${TARGET}
## Clean target
.PHONY: clean
clean:
	-rm -rf $(OBJECTS) LedBoard_8x48.elf dep/* LedBoard_8x48.hex LedBoard_8x48.eep LedBoard_8x48.lss LedBoard_8x48.map
## Other dependencies
-include $(shell mkdir dep 2>/dev/null) $(wildcard dep/*)
