|| @file AlphaLicense.txt
|| @version 1.0
|| @author Alexander Brevig
|| @contact alexanderbrevig@gmail.com
|| @description
|| | Describe the rights and expectations when using my code
|| @license
|| | Copyright (c) 2009 Alexander Brevig. All rights reserved.
|| | http://www.gnu.org/licenses/lgpl.html
updated for Arduino 1.0 by Tom Igoe, 27 April 2011
All content is released into the public domain, under the terms of the GNU LGPL (latest version).
All code is intellectual property, unless stated otherwise.
All usage of my code is permitted, as long as the headers stay intact ( from /* to */ ) or comply to these rules:
*) You are not permitted to change any of these fields, and they should stay as is:
    @file
    @version
    @author
    @contact
    @licence
*) You are permitted to modify the @description field, remember to update the changelog
*) You are permitted to add these fields
    @contribution
        This field has to be inserted immediatly after the @contact with a 'blank' line above and below (blank as in '||')
        The changelog should indicate what is contributed
    @dependencies
        This field has to be inserted immediatly after the @description with a 'blank' line above and below (blank as in '||')
    @configuration
        This field has to be inserted immediatly after the @description or, if existant, the @dependencies with a 'blank' line above and below (blank as in '||')
*) You are permitted and expected to add to the changelog, if changes or contributions are made.
Example Header (the header to this file modified according to rules)
|| @version 1.0
|| @contribution
|| | Name Surname - www.domain.com - contact@domain.com
|| @description
|| | Descripbe the rights and expectations when using my code
|| @dependencies
|| | This file depends on the user having accsess to the internet, in order to read the LGPL
|| @configuration
|| | No configuration needed
|| @license
