<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="7.1.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.05" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="no"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="no" active="no"/>
<layer number="17" name="Pads" color="2" fill="1" visible="no" active="no"/>
<layer number="18" name="Vias" color="2" fill="1" visible="no" active="no"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="no"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="no" active="no"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="no"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="no"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="no"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="no"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="no"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="no"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="no"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="no"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="no"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="no"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="no"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="no"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="no"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="no"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="no"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="no"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="no"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="no"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="no"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="no"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="no"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="no"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="no"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="no"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="no"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="no"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="no"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="no"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="no"/>
<layer number="90" name="Modules" color="5" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
<layer number="99" name="SpiceOrder" color="5" fill="1" visible="yes" active="yes"/>
<layer number="200" name="200bmp" color="1" fill="10" visible="no" active="no"/>
<layer number="201" name="201bmp" color="1" fill="10" visible="yes" active="yes"/>
<layer number="202" name="202bmp" color="2" fill="10" visible="yes" active="yes"/>
<layer number="203" name="203bmp" color="3" fill="10" visible="yes" active="yes"/>
<layer number="250" name="Descript" color="3" fill="1" visible="no" active="no"/>
<layer number="251" name="SMDround" color="12" fill="11" visible="no" active="no"/>
</layers>
<schematic xreflabel="%F%N/%S.%C%R" xrefpart="/%S.%C%R">
<libraries>
<library name="diode">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DO35-10">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2 mm, horizontal, grid 10.16 mm</description>
<wire x1="5.08" y1="0" x2="4.191" y2="0" width="0.508" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.191" y2="0" width="0.508" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="2.032" y1="1.016" x2="2.286" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="0.762" x2="-2.032" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.286" y1="-0.762" x2="-2.032" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.032" y1="-1.016" x2="2.286" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="-0.762" x2="2.286" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0.762" x2="-2.286" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.016" x2="2.032" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-1.016" x2="2.032" y2="-1.016" width="0.1524" layer="21"/>
<pad name="C" x="-5.08" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="5.08" y="0" drill="0.8128" shape="long"/>
<text x="-2.159" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.905" y1="-1.016" x2="-1.397" y2="1.016" layer="21"/>
<rectangle x1="2.286" y1="-0.254" x2="4.191" y2="0.254" layer="21"/>
<rectangle x1="-4.191" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
</package>
<package name="DO35-7">
diameter 2 mm, horizontal, grid 7.62 mm</description>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="2.286" y1="0.762" x2="2.286" y2="-0.762" width="0.1524" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="3.81" y="0" drill="0.8128" shape="long"/>
<text x="-2.286" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.286" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.286" y2="0.254" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="D">
<wire x1="-1.27" y1="-1.27" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="-1.27" y2="1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="1.27" x2="1.27" y2="0" width="0.254" layer="94"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="-1.27" width="0.254" layer="94"/>
<wire x1="1.27" y1="0" x2="1.27" y2="-1.27" width="0.254" layer="94"/>
<text x="2.54" y="0.4826" size="1.778" layer="95">&gt;NAME</text>
<text x="2.54" y="-2.3114" size="1.778" layer="96">&gt;VALUE</text>
<pin name="A" x="-2.54" y="0" visible="off" length="short" direction="pas"/>
<pin name="C" x="2.54" y="0" visible="off" length="short" direction="pas" rot="R180"/>
<text x="-2.54" y="0" size="0.4064" layer="99" align="center">SpiceOrder 1</text>
<text x="2.54" y="0" size="0.4064" layer="99" align="center">SpiceOrder 2</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="1N4148" prefix="D">
high speed (Philips)</description>
<gates>
<gate name="G$1" symbol="D" x="0" y="0"/>
</gates>
<devices>
<device name="DO35-10" package="DO35-10">
<connects>
<connect gate="G$1" pin="A" pad="A"/>
<connect gate="G$1" pin="C" pad="C"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="DO35-7" package="DO35-7">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="rcl">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="R0402">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;</description>
<wire x1="-0.245" y1="0.224" x2="0.245" y2="0.224" width="0.1524" layer="51"/>
<wire x1="0.245" y1="-0.224" x2="-0.245" y2="-0.224" width="0.1524" layer="51"/>
<wire x1="-1.473" y1="0.483" x2="1.473" y2="0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.483" x2="1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.483" x2="-1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.483" x2="-1.473" y2="0.483" width="0.0508" layer="39"/>
<smd name="1" x="-0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<smd name="2" x="0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<text x="-0.635" y="0.635" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-1.905" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.554" y1="-0.3048" x2="-0.254" y2="0.2951" layer="51"/>
<rectangle x1="0.2588" y1="-0.3048" x2="0.5588" y2="0.2951" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="R0603">
<wire x1="-0.432" y1="-0.356" x2="0.432" y2="-0.356" width="0.1524" layer="51"/>
<wire x1="0.432" y1="0.356" x2="-0.432" y2="0.356" width="0.1524" layer="51"/>
<wire x1="-1.473" y1="0.983" x2="1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.983" x2="1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.983" x2="-1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.983" x2="-1.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.85" y="0" dx="1" dy="1.1" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1" dy="1.1" layer="1"/>
<rectangle x1="0.4318" y1="-0.4318" x2="0.8382" y2="0.4318" layer="51"/>
<rectangle x1="-0.8382" y1="-0.4318" x2="-0.4318" y2="0.4318" layer="51"/>
</package>
<package name="R0805">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="-0.41" y1="0.635" x2="0.41" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.41" y1="-0.635" x2="0.41" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<text x="-0.635" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="0.4064" y1="-0.6985" x2="1.0564" y2="0.7015" layer="51"/>
<rectangle x1="-1.0668" y1="-0.6985" x2="-0.4168" y2="0.7015" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
<package name="R0805W">
<description>&lt;b&gt;RESISTOR&lt;/b&gt; wave soldering&lt;p&gt;</description>
<smd name="1" x="-1.0525" y="0" dx="1.5" dy="1" layer="1"/>
<smd name="2" x="1.0525" y="0" dx="1.5" dy="1" layer="1"/>
</package>
<package name="R1005">
<rectangle x1="-0.1999" y1="-0.3" x2="0.1999" y2="0.3" layer="35"/>
</package>
<package name="R1206">
<wire x1="0.9525" y1="-0.8128" x2="-0.9652" y2="-0.8128" width="0.1524" layer="51"/>
<wire x1="0.9525" y1="0.8128" x2="-0.9652" y2="0.8128" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="2" x="1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<smd name="1" x="-1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6891" y1="-0.8763" x2="-0.9525" y2="0.8763" layer="51"/>
<rectangle x1="0.9525" y1="-0.8763" x2="1.6891" y2="0.8763" layer="51"/>
<rectangle x1="-0.3" y1="-0.7" x2="0.3" y2="0.7" layer="35"/>
</package>
<package name="R1206W">
wave soldering</description>
<wire x1="-0.913" y1="0.8" x2="0.888" y2="0.8" width="0.1524" layer="51"/>
<wire x1="-0.913" y1="-0.8" x2="0.888" y2="-0.8" width="0.1524" layer="51"/>
<smd name="1" x="-1.499" y="0" dx="1.8" dy="1.2" layer="1"/>
<smd name="2" x="1.499" y="0" dx="1.8" dy="1.2" layer="1"/>
<text x="-1.905" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-0.8763" x2="-0.9009" y2="0.8738" layer="51"/>
<rectangle x1="0.889" y1="-0.8763" x2="1.6391" y2="0.8738" layer="51"/>
</package>
<package name="R1210">
<wire x1="-0.913" y1="1.219" x2="0.939" y2="1.219" width="0.1524" layer="51"/>
<wire x1="-0.913" y1="-1.219" x2="0.939" y2="-1.219" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<text x="-2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-1.3081" x2="-0.9009" y2="1.2918" layer="51"/>
<rectangle x1="0.9144" y1="-1.3081" x2="1.6645" y2="1.2918" layer="51"/>
<rectangle x1="-0.3" y1="-0.8999" x2="0.3" y2="0.8999" layer="35"/>
</package>
<package name="R1210W">
<smd name="1" x="-1.499" y="0" dx="1.8" dy="1.8" layer="1"/>
<smd name="2" x="1.499" y="0" dx="1.8" dy="1.8" layer="1"/>
<rectangle x1="-0.3" y1="-0.8001" x2="0.3" y2="0.8001" layer="35"/>
</package>
<package name="R2010">
<wire x1="-1.662" y1="1.245" x2="1.662" y2="1.245" width="0.1524" layer="51"/>
<wire x1="-1.637" y1="-1.245" x2="1.687" y2="-1.245" width="0.1524" layer="51"/>
<wire x1="-3.473" y1="1.483" x2="3.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="3.473" y1="1.483" x2="3.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="3.473" y1="-1.483" x2="-3.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-3.473" y1="-1.483" x2="-3.473" y2="1.483" width="0.0508" layer="39"/>
<smd name="1" x="-2.2" y="0" dx="1.8" dy="2.7" layer="1"/>
<smd name="2" x="2.2" y="0" dx="1.8" dy="2.7" layer="1"/>
<text x="-3.175" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.175" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.4892" y1="-1.3208" x2="-1.6393" y2="1.3292" layer="51"/>
<rectangle x1="1.651" y1="-1.3208" x2="2.5009" y2="1.3292" layer="51"/>
</package>
<package name="R2010W">
<smd name="1" x="-2.311" y="0" dx="2" dy="1.8" layer="1"/>
<smd name="2" x="2.311" y="0" dx="2" dy="1.8" layer="1"/>
</package>
<package name="R2012">
<smd name="1" x="-0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<rectangle x1="-0.1001" y1="-0.5999" x2="0.1001" y2="0.5999" layer="35"/>
</package>
<package name="R2012W">
<smd name="1" x="-0.94" y="0" dx="1.5" dy="1" layer="1"/>
<smd name="2" x="0.94" y="0" dx="1.5" dy="1" layer="1"/>
</package>
<package name="R2512">
<wire x1="-2.362" y1="1.473" x2="2.387" y2="1.473" width="0.1524" layer="51"/>
<wire x1="-2.362" y1="-1.473" x2="2.387" y2="-1.473" width="0.1524" layer="51"/>
<wire x1="-3.973" y1="1.983" x2="3.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="1.983" x2="3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="-1.983" x2="-3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-3.973" y1="-1.983" x2="-3.973" y2="1.983" width="0.0508" layer="39"/>
<smd name="1" x="-2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<smd name="2" x="2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<rectangle x1="-3.2004" y1="-1.5494" x2="-2.3505" y2="1.5507" layer="51"/>
<rectangle x1="2.3622" y1="-1.5494" x2="3.2121" y2="1.5507" layer="51"/>
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="R2512W">
<smd name="1" x="-2.896" y="0" dx="2" dy="2.1" layer="1"/>
<smd name="2" x="2.896" y="0" dx="2" dy="2.1" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R3216">
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
</package>
<package name="R3216W">
</package>
<package name="R3225">
<rectangle x1="-0.3" y1="-1" x2="0.3" y2="1" layer="35"/>
</package>
<package name="R3225W">
</package>
<package name="R5025">
</package>
<package name="R5025W">
</package>
<package name="R6332">
Source: http://download.siliconexpert.com/pdfs/2005/02/24/Semi_Ap/2/VSH/Resistor/dcrcwfre.pdf</description>
<smd name="1" x="-3.1" y="0" dx="1" dy="3.2" layer="1"/>
<smd name="2" x="3.1" y="0" dx="1" dy="3.2" layer="1"/>
</package>
<package name="R6332W">
<smd name="1" x="-3.196" y="0" dx="1.2" dy="3.2" layer="1"/>
<smd name="2" x="3.196" y="0" dx="1.2" dy="3.2" layer="1"/>
</package>
<package name="M0805">
MELF 0.10 W</description>
<wire x1="0.7112" y1="0.635" x2="-0.7112" y2="0.635" width="0.1524" layer="51"/>
<wire x1="0.7112" y1="-0.635" x2="-0.7112" y2="-0.635" width="0.1524" layer="51"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.6" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.6" layer="1"/>
<rectangle x1="-1.0414" y1="-0.7112" x2="-0.6858" y2="0.7112" layer="51"/>
<rectangle x1="0.6858" y1="-0.7112" x2="1.0414" y2="0.7112" layer="51"/>
<rectangle x1="-0.1999" y1="-0.5999" x2="0.1999" y2="0.5999" layer="35"/>
</package>
<package name="M1206">
MELF 0.25 W</description>
<wire x1="1.143" y1="0.8382" x2="-1.143" y2="0.8382" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.8382" x2="-1.143" y2="-0.8382" width="0.1524" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2" layer="1"/>
<rectangle x1="-1.7018" y1="-0.9144" x2="-1.1176" y2="0.9144" layer="51"/>
<rectangle x1="1.1176" y1="-0.9144" x2="1.7018" y2="0.9144" layer="51"/>
</package>
<package name="M1406">
MELF 0.12 W</description>
<wire x1="-2.973" y1="0.983" x2="2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-0.983" x2="-2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-0.983" x2="-2.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="0.983" x2="2.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.3208" y1="0.762" x2="-1.3208" y2="0.762" width="0.1524" layer="51"/>
<wire x1="1.3208" y1="-0.762" x2="-1.3208" y2="-0.762" width="0.1524" layer="51"/>
<smd name="1" x="-1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<smd name="2" x="1.7" y="0" dx="1.4" dy="1.8" layer="1"/>
<rectangle x1="-1.8542" y1="-0.8382" x2="-1.2954" y2="0.8382" layer="51"/>
<rectangle x1="1.2954" y1="-0.8382" x2="1.8542" y2="0.8382" layer="51"/>
</package>
<package name="M2012">
</package>
<package name="M2309">
<wire x1="-4.473" y1="1.483" x2="4.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="4.473" y1="-1.483" x2="-4.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-4.473" y1="-1.483" x2="-4.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="4.473" y1="1.483" x2="4.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="2.413" y1="1.1684" x2="-2.4384" y2="1.1684" width="0.1524" layer="51"/>
<wire x1="2.413" y1="-1.1684" x2="-2.413" y2="-1.1684" width="0.1524" layer="51"/>
<smd name="1" x="-2.85" y="0" dx="1.5" dy="2.6" layer="1"/>
<smd name="2" x="2.85" y="0" dx="1.5" dy="2.6" layer="1"/>
<text x="-2.54" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.048" y1="-1.2446" x2="-2.3876" y2="1.2446" layer="51"/>
<rectangle x1="2.3876" y1="-1.2446" x2="3.048" y2="1.2446" layer="51"/>
</package>
<package name="M3216">
</package>
<package name="M3516">
<rectangle x1="-0.4001" y1="-0.7" x2="0.4001" y2="0.7" layer="35"/>
</package>
<package name="M5923">
</package>
<package name="0204/5">
type 0204, grid 5 mm</description>
<wire x1="2.54" y1="0" x2="2.032" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0" x2="-2.032" y2="0" width="0.508" layer="51"/>
<wire x1="-1.778" y1="0.635" x2="-1.524" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.778" y1="-0.635" x2="-1.524" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="-0.889" x2="1.778" y2="-0.635" width="0.1524" layer="21" curve="90"/>
<wire x1="1.524" y1="0.889" x2="1.778" y2="0.635" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.778" y1="-0.635" x2="-1.778" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-1.524" y1="0.889" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="0.762" x2="-1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-0.889" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="-1.143" y1="-0.762" x2="-1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.762" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0.762" x2="-1.143" y2="0.762" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.762" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.143" y1="-0.762" x2="-1.143" y2="-0.762" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.889" x2="1.27" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-0.889" x2="1.27" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.635" x2="1.778" y2="0.635" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.0066" y="1.1684" size="0.9906" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="0.9906" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.032" y1="-0.254" x2="-1.778" y2="0.254" layer="51"/>
<rectangle x1="1.778" y1="-0.254" x2="2.032" y2="0.254" layer="51"/>
</package>
<package name="0204/7">
type 0204, grid 7.5 mm</description>
<wire x1="-2.54" y1="0.762" x2="-2.286" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.286" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="-1.016" x2="2.54" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.016" x2="2.54" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.54" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.016" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.889" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.016" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.889" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="-1.778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="-1.778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.016" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.016" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.762" x2="2.54" y2="0.762" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="1.2954" size="0.9906" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.6256" y="-0.4826" size="0.9906" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.54" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.54" y2="0.254" layer="21"/>
</package>
<package name="0204V">
type 0204, grid 2.5 mm</description>
<wire x1="-1.27" y1="0" x2="1.27" y2="0" width="0.508" layer="51"/>
<wire x1="-0.127" y1="0" x2="0.127" y2="0" width="0.508" layer="21"/>
<circle x="-1.27" y="0" radius="0.889" width="0.1524" layer="51"/>
<circle x="-1.27" y="0" radius="0.635" width="0.0508" layer="51"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.1336" y="1.1684" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.1336" y="-2.3114" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/10">
type 0207, grid 10 mm</description>
<wire x1="5.08" y1="0" x2="4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-5.08" y1="0" x2="-4.064" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="0.889" x2="-2.921" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-2.921" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="-1.143" x2="3.175" y2="-0.889" width="0.1524" layer="21" curve="90"/>
<wire x1="2.921" y1="1.143" x2="3.175" y2="0.889" width="0.1524" layer="21" curve="-90"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="1.143" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-2.921" y1="-1.143" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="-1.016" x2="-2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="-2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.921" y1="1.143" x2="2.54" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.921" y1="-1.143" x2="2.54" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.048" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.2606" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="3.175" y1="-0.3048" x2="4.0386" y2="0.3048" layer="21"/>
<rectangle x1="-4.0386" y1="-0.3048" x2="-3.175" y2="0.3048" layer="21"/>
</package>
<package name="0207/12">
type 0207, grid 12 mm</description>
<wire x1="6.35" y1="0" x2="5.334" y2="0" width="0.6096" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.334" y2="0" width="0.6096" layer="51"/>
<wire x1="4.445" y1="0" x2="4.064" y2="0" width="0.6096" layer="21"/>
<wire x1="-4.445" y1="0" x2="-4.064" y2="0" width="0.6096" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.175" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.6858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.445" y1="-0.3048" x2="5.3086" y2="0.3048" layer="21"/>
<rectangle x1="-5.3086" y1="-0.3048" x2="-4.445" y2="0.3048" layer="21"/>
</package>
<package name="0207/15">
type 0207, grid 15mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.6096" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.6096" layer="51"/>
<wire x1="5.715" y1="0" x2="4.064" y2="0" width="0.6096" layer="21"/>
<wire x1="-5.715" y1="0" x2="-4.064" y2="0" width="0.6096" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.8128" shape="octagon"/>
<rectangle x1="5.715" y1="-0.3048" x2="6.5786" y2="0.3048" layer="21"/>
<rectangle x1="-6.5786" y1="-0.3048" x2="-5.715" y2="0.3048" layer="21"/>
</package>
<package name="0207/2V">
type 0207, grid 2.5 mm</description>
<wire x1="-1.27" y1="0" x2="-0.381" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.254" y1="0" x2="0.254" y2="0" width="0.6096" layer="21"/>
<wire x1="0.381" y1="0" x2="1.27" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.27" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="1.016" width="0.1524" layer="51"/>
<text x="-0.0508" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.0508" y="-2.2352" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/5V">
type 0207, grid 5 mm</description>
<wire x1="-2.54" y1="0" x2="-0.889" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.762" y1="0" x2="0.762" y2="0" width="0.6096" layer="21"/>
<wire x1="0.889" y1="0" x2="2.54" y2="0" width="0.6096" layer="51"/>
<circle x="-2.54" y="0" radius="1.27" width="0.1016" layer="21"/>
<circle x="-2.54" y="0" radius="1.016" width="0.1524" layer="51"/>
<text x="-1.143" y="0.889" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.143" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="0207/7">
type 0207, grid 7.5 mm</description>
<wire x1="-3.81" y1="0" x2="-3.429" y2="0" width="0.6096" layer="51"/>
<wire x1="-3.175" y1="-0.889" x2="-3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="3.175" y1="-0.889" x2="3.175" y2="0.889" width="0.1524" layer="51"/>
<wire x1="3.429" y1="0" x2="3.81" y2="0" width="0.6096" layer="51"/>
<text x="-2.54" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-0.5588" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-3.429" y1="-0.3048" x2="-3.175" y2="0.3048" layer="51"/>
<rectangle x1="3.175" y1="-0.3048" x2="3.429" y2="0.3048" layer="51"/>
</package>
<package name="0309/10">
type 0309, grid 10mm</description>
<wire x1="-4.699" y1="0" x2="-5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-4.318" y1="1.27" x2="-4.064" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.318" y1="-1.27" x2="-4.064" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="4.064" y1="-1.524" x2="4.318" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="4.064" y1="1.524" x2="4.318" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.318" y1="-1.27" x2="-4.318" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-4.064" y1="1.524" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="1.397" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="-1.524" x2="-3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="-1.397" x2="-3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="1.397" x2="3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="1.397" x2="-3.302" y2="1.397" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-1.397" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.302" y1="-1.397" x2="-3.302" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="4.064" y1="1.524" x2="3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-1.524" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-1.27" x2="4.318" y2="1.27" width="0.1524" layer="51"/>
<wire x1="5.08" y1="0" x2="4.699" y2="0" width="0.6096" layer="51"/>
<text x="-4.191" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-0.6858" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-4.6228" y1="-0.3048" x2="-4.318" y2="0.3048" layer="51"/>
<rectangle x1="4.318" y1="-0.3048" x2="4.6228" y2="0.3048" layer="51"/>
</package>
<package name="0309/12">
type 0309, grid 12.5 mm</description>
<wire x1="6.35" y1="0" x2="5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.08" y2="0" width="0.6096" layer="51"/>
<wire x1="-4.318" y1="-1.27" x2="-4.318" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.318" y1="-1.27" x2="4.318" y2="1.27" width="0.1524" layer="21"/>
<rectangle x1="4.318" y1="-0.3048" x2="5.1816" y2="0.3048" layer="21"/>
<rectangle x1="-5.1816" y1="-0.3048" x2="-4.318" y2="0.3048" layer="21"/>
</package>
<package name="0309V">
type 0309, grid 2.5 mm</description>
<wire x1="1.27" y1="0" x2="0.635" y2="0" width="0.6096" layer="51"/>
<wire x1="-0.635" y1="0" x2="-1.27" y2="0" width="0.6096" layer="51"/>
<circle x="-1.27" y="0" radius="1.524" width="0.1524" layer="21"/>
<circle x="-1.27" y="0" radius="0.762" width="0.1524" layer="51"/>
<text x="0.254" y="1.016" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.254" y="-2.2098" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-0.3048" x2="0.5588" y2="0.3048" layer="51"/>
<rectangle x1="-0.635" y1="-0.3048" x2="-0.3302" y2="0.3048" layer="51"/>
<rectangle x1="-0.3302" y1="-0.3048" x2="0.254" y2="0.3048" layer="21"/>
</package>
<package name="0411/12">
type 0411, grid 12.5 mm</description>
<wire x1="6.35" y1="0" x2="5.461" y2="0" width="0.762" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.461" y2="0" width="0.762" layer="51"/>
<wire x1="5.08" y1="-1.651" x2="5.08" y2="1.651" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.032" x2="5.08" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.08" y1="-1.651" x2="-4.699" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="4.699" y1="-2.032" x2="5.08" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.651" x2="-4.699" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="2.032" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="1.905" x2="4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.032" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="3.937" y1="-1.905" x2="4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="1.905" x2="3.937" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.937" y1="-1.905" x2="3.937" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.651" x2="-5.08" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="2.032" x2="-4.064" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-2.032" x2="-4.064" y2="-2.032" width="0.1524" layer="21"/>
<pad name="1" x="-6.35" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="0.9144" shape="octagon"/>
<text x="-5.08" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.5814" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.3594" y1="-0.381" x2="-5.08" y2="0.381" layer="21"/>
<rectangle x1="5.08" y1="-0.381" x2="5.3594" y2="0.381" layer="21"/>
</package>
<package name="0411/15">
type 0411, grid 15 mm</description>
<wire x1="-7.62" y1="0" x2="-6.35" y2="0" width="0.762" layer="51"/>
<wire x1="6.35" y1="0" x2="7.62" y2="0" width="0.762" layer="51"/>
<pad name="1" x="-7.62" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="0.9144" shape="octagon"/>
<rectangle x1="5.08" y1="-0.381" x2="6.477" y2="0.381" layer="21"/>
<rectangle x1="-6.477" y1="-0.381" x2="-5.08" y2="0.381" layer="21"/>
</package>
<package name="0411V">
type 0411, grid 3.81 mm</description>
<wire x1="1.27" y1="0" x2="0.3048" y2="0" width="0.762" layer="51"/>
<wire x1="-1.5748" y1="0" x2="-2.54" y2="0" width="0.762" layer="51"/>
<circle x="-2.54" y="0" radius="2.032" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.9144" shape="octagon"/>
<text x="-0.508" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.5334" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.4732" y1="-0.381" x2="0.2032" y2="0.381" layer="21"/>
</package>
<package name="0414/15">
type 0414, grid 15 mm</description>
<wire x1="7.62" y1="0" x2="6.604" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.604" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.096" y1="1.905" x2="-5.842" y2="2.159" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.096" y1="-1.905" x2="-5.842" y2="-2.159" width="0.1524" layer="21" curve="90"/>
<wire x1="5.842" y1="-2.159" x2="6.096" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<wire x1="5.842" y1="2.159" x2="6.096" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.096" y1="-1.905" x2="-6.096" y2="1.905" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="2.159" x2="-4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.032" x2="-4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="-5.842" y1="-2.159" x2="-4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.032" x2="-4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.032" x2="4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="4.826" y1="-2.032" x2="-4.826" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="5.842" y1="2.159" x2="4.953" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.842" y1="-2.159" x2="4.953" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-1.905" x2="6.096" y2="1.905" width="0.1524" layer="21"/>
<pad name="1" x="-7.62" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="7.62" y="0" drill="1.016" shape="octagon"/>
<text x="-6.096" y="2.5654" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="6.096" y1="-0.4064" x2="6.5024" y2="0.4064" layer="21"/>
<rectangle x1="-6.5024" y1="-0.4064" x2="-6.096" y2="0.4064" layer="21"/>
</package>
<package name="0414V">
type 0414, grid 5 mm</description>
<wire x1="2.54" y1="0" x2="1.397" y2="0" width="0.8128" layer="51"/>
<wire x1="-2.54" y1="0" x2="-1.397" y2="0" width="0.8128" layer="51"/>
<circle x="-2.54" y="0" radius="2.159" width="0.1524" layer="21"/>
<circle x="-2.54" y="0" radius="1.143" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="1.016" shape="octagon"/>
<text x="-0.381" y="1.1684" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.381" y="-2.3622" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.2954" y1="-0.4064" x2="1.2954" y2="0.4064" layer="21"/>
</package>
<package name="0617/17">
type 0617, grid 17.5 mm</description>
<wire x1="-8.89" y1="0" x2="-8.636" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.874" y1="3.048" x2="-6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="2.794" x2="-6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-7.874" y1="-3.048" x2="-6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="-2.794" x2="-6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="2.794" x2="6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="2.794" x2="-6.731" y2="2.794" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.794" x2="6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.794" x2="-6.731" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="7.874" y1="3.048" x2="6.985" y2="3.048" width="0.1524" layer="21"/>
<wire x1="7.874" y1="-3.048" x2="6.985" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="-2.667" x2="-8.255" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-8.255" y1="1.016" x2="-8.255" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-8.255" y1="1.016" x2="-8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.667" x2="8.255" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="8.255" y1="1.016" x2="8.255" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="8.255" y1="1.016" x2="8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.636" y1="0" x2="8.89" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.255" y1="2.667" x2="-7.874" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="7.874" y1="3.048" x2="8.255" y2="2.667" width="0.1524" layer="21" curve="-90"/>
<wire x1="-8.255" y1="-2.667" x2="-7.874" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="7.874" y1="-3.048" x2="8.255" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<pad name="1" x="-8.89" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="8.89" y="0" drill="1.016" shape="octagon"/>
<text x="-8.128" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.096" y="-0.7112" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-8.5344" y1="-0.4064" x2="-8.2296" y2="0.4064" layer="51"/>
<rectangle x1="8.2296" y1="-0.4064" x2="8.5344" y2="0.4064" layer="51"/>
</package>
<package name="0617/22">
type 0617, grid 22.5 mm</description>
<wire x1="-10.287" y1="0" x2="-11.43" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.255" y1="-2.667" x2="-8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="8.255" y1="-2.667" x2="8.255" y2="2.667" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="10.287" y2="0" width="0.8128" layer="51"/>
<pad name="1" x="-11.43" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="11.43" y="0" drill="1.016" shape="octagon"/>
<text x="-8.255" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.477" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-10.1854" y1="-0.4064" x2="-8.255" y2="0.4064" layer="21"/>
<rectangle x1="8.255" y1="-0.4064" x2="10.1854" y2="0.4064" layer="21"/>
</package>
<package name="0617V">
type 0617, grid 5 mm</description>
<wire x1="-2.54" y1="0" x2="-1.27" y2="0" width="0.8128" layer="51"/>
<wire x1="1.27" y1="0" x2="2.54" y2="0" width="0.8128" layer="51"/>
<circle x="-2.54" y="0" radius="3.048" width="0.1524" layer="21"/>
<text x="0.635" y="1.4224" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0.635" y="-2.6162" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.3208" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="0922/22">
type 0922, grid 22.5 mm</description>
<wire x1="11.43" y1="0" x2="10.795" y2="0" width="0.8128" layer="51"/>
<wire x1="-11.43" y1="0" x2="-10.795" y2="0" width="0.8128" layer="51"/>
<wire x1="-10.16" y1="-4.191" x2="-10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="4.572" x2="-8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="4.318" x2="-8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="-9.779" y1="-4.572" x2="-8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-8.636" y1="-4.318" x2="-8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="4.318" x2="8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="4.318" x2="-8.636" y2="4.318" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-4.318" x2="8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="8.636" y1="-4.318" x2="-8.636" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="9.779" y1="4.572" x2="8.89" y2="4.572" width="0.1524" layer="21"/>
<wire x1="9.779" y1="-4.572" x2="8.89" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.191" x2="10.16" y2="4.191" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-4.191" x2="-9.779" y2="-4.572" width="0.1524" layer="21" curve="90"/>
<wire x1="-10.16" y1="4.191" x2="-9.779" y2="4.572" width="0.1524" layer="21" curve="-90"/>
<wire x1="9.779" y1="-4.572" x2="10.16" y2="-4.191" width="0.1524" layer="21" curve="90"/>
<wire x1="9.779" y1="4.572" x2="10.16" y2="4.191" width="0.1524" layer="21" curve="-90"/>
<text x="-10.16" y="5.1054" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-10.7188" y1="-0.4064" x2="-10.16" y2="0.4064" layer="51"/>
<rectangle x1="10.16" y1="-0.4064" x2="10.3124" y2="0.4064" layer="21"/>
<rectangle x1="-10.3124" y1="-0.4064" x2="-10.16" y2="0.4064" layer="21"/>
<rectangle x1="10.16" y1="-0.4064" x2="10.7188" y2="0.4064" layer="51"/>
</package>
<package name="P0613V">
type 0613, grid 5 mm</description>
<circle x="-2.54" y="0" radius="2.286" width="0.1524" layer="21"/>
<text x="-0.254" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.254" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.2954" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="P0613/15">
type 0613, grid 15 mm</description>
<wire x1="7.62" y1="0" x2="6.985" y2="0" width="0.8128" layer="51"/>
<wire x1="-7.62" y1="0" x2="-6.985" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.477" y1="2.032" x2="-6.223" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.477" y1="-2.032" x2="-6.223" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="6.223" y1="-2.286" x2="6.477" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="6.223" y1="2.286" x2="6.477" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.223" y1="2.286" x2="-5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.159" x2="-5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="-6.223" y1="-2.286" x2="-5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-2.159" x2="-5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="2.159" x2="5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="2.159" x2="-5.207" y2="2.159" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.159" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.159" x2="-5.207" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="6.223" y1="2.286" x2="5.334" y2="2.286" width="0.1524" layer="21"/>
<wire x1="6.223" y1="-2.286" x2="5.334" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-0.635" x2="6.477" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-0.635" x2="6.477" y2="0.635" width="0.1524" layer="51"/>
<wire x1="6.477" y1="2.032" x2="6.477" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-2.032" x2="-6.477" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="0.635" x2="-6.477" y2="-0.635" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="0.635" x2="-6.477" y2="2.032" width="0.1524" layer="21"/>
<text x="-6.477" y="2.6924" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.318" y="-0.7112" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-7.0358" y1="-0.4064" x2="-6.477" y2="0.4064" layer="51"/>
<rectangle x1="6.477" y1="-0.4064" x2="7.0358" y2="0.4064" layer="51"/>
</package>
<package name="P0817/22">
type 0817, grid 22.5 mm</description>
<wire x1="-10.414" y1="0" x2="-11.43" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.509" y1="-3.429" x2="-8.509" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="3.81" x2="-7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="3.556" x2="-7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="-8.128" y1="-3.81" x2="-7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="-6.985" y1="-3.556" x2="-7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="3.556" x2="7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="3.556" x2="-6.985" y2="3.556" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-3.556" x2="7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-3.556" x2="-6.985" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="8.128" y1="3.81" x2="7.239" y2="3.81" width="0.1524" layer="21"/>
<wire x1="8.128" y1="-3.81" x2="7.239" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.429" x2="8.509" y2="3.429" width="0.1524" layer="21"/>
<wire x1="11.43" y1="0" x2="10.414" y2="0" width="0.8128" layer="51"/>
<wire x1="-8.509" y1="3.429" x2="-8.128" y2="3.81" width="0.1524" layer="21" curve="-90"/>
<wire x1="-8.509" y1="-3.429" x2="-8.128" y2="-3.81" width="0.1524" layer="21" curve="90"/>
<wire x1="8.128" y1="3.81" x2="8.509" y2="3.429" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.128" y1="-3.81" x2="8.509" y2="-3.429" width="0.1524" layer="21" curve="90"/>
<text x="-8.382" y="4.2164" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.223" y="-0.5842" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="6.604" y="-2.2606" size="1.27" layer="51" ratio="10" rot="R90">0817</text>
<rectangle x1="8.509" y1="-0.4064" x2="10.3124" y2="0.4064" layer="21"/>
<rectangle x1="-10.3124" y1="-0.4064" x2="-8.509" y2="0.4064" layer="21"/>
</package>
<package name="P0817V">
type 0817, grid 6.35 mm</description>
<wire x1="-3.81" y1="0" x2="-5.08" y2="0" width="0.8128" layer="51"/>
<wire x1="1.27" y1="0" x2="0" y2="0" width="0.8128" layer="51"/>
<circle x="-5.08" y="0" radius="3.81" width="0.1524" layer="21"/>
<circle x="-5.08" y="0" radius="1.27" width="0.1524" layer="51"/>
<pad name="1" x="-5.08" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="1.016" shape="octagon"/>
<text x="-1.016" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.016" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.858" y="2.032" size="1.016" layer="21" ratio="12">0817</text>
<rectangle x1="-3.81" y1="-0.4064" x2="0" y2="0.4064" layer="21"/>
</package>
<package name="V234/12">
type V234, grid 12.5 mm</description>
<wire x1="-4.953" y1="1.524" x2="-4.699" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="1.778" x2="4.953" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-1.778" x2="4.953" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.953" y1="-1.524" x2="-4.699" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.699" y1="1.778" x2="4.699" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="1.524" x2="-4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.778" x2="-4.699" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="4.953" y1="1.524" x2="4.953" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0" x2="5.461" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.35" y1="0" x2="-5.461" y2="0" width="0.8128" layer="51"/>
<pad name="1" x="-6.35" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="1.016" shape="octagon"/>
<text x="-4.953" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="4.953" y1="-0.4064" x2="5.4102" y2="0.4064" layer="21"/>
<rectangle x1="-5.4102" y1="-0.4064" x2="-4.953" y2="0.4064" layer="21"/>
</package>
<package name="V235/17">
type V235, grid 17.78 mm</description>
<wire x1="-6.731" y1="2.921" x2="6.731" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-7.112" y1="2.54" x2="-7.112" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.731" y1="-2.921" x2="-6.731" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="7.112" y1="2.54" x2="7.112" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.89" y1="0" x2="7.874" y2="0" width="1.016" layer="51"/>
<wire x1="-7.874" y1="0" x2="-8.89" y2="0" width="1.016" layer="51"/>
<wire x1="-7.112" y1="-2.54" x2="-6.731" y2="-2.921" width="0.1524" layer="21" curve="90"/>
<wire x1="6.731" y1="2.921" x2="7.112" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.731" y1="-2.921" x2="7.112" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-7.112" y1="2.54" x2="-6.731" y2="2.921" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-8.89" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="8.89" y="0" drill="1.1938" shape="octagon"/>
<text x="-6.858" y="3.302" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.842" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="7.112" y1="-0.508" x2="7.747" y2="0.508" layer="21"/>
<rectangle x1="-7.747" y1="-0.508" x2="-7.112" y2="0.508" layer="21"/>
</package>
<package name="V526-0">
type V526-0, grid 2.5 mm</description>
<wire x1="-2.54" y1="1.016" x2="-2.286" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="1.27" x2="2.54" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.286" y1="-1.27" x2="2.54" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.54" y1="-1.016" x2="-2.286" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.27" x2="-2.286" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.016" x2="2.54" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.27" x2="2.286" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.016" x2="-2.54" y2="-1.016" width="0.1524" layer="21"/>
<text x="-2.413" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.413" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0102R">
<description>&lt;b&gt;CECC Size RC2211&lt;/b&gt; Reflow Soldering&lt;p&gt;
source Beyschlag</description>
<wire x1="-1" y1="-0.5" x2="1" y2="-0.5" width="0.2032" layer="51"/>
<wire x1="1" y1="-0.5" x2="1" y2="0.5" width="0.2032" layer="51"/>
<wire x1="1" y1="0.5" x2="-1" y2="0.5" width="0.2032" layer="51"/>
<wire x1="-1" y1="0.5" x2="-1" y2="-0.5" width="0.2032" layer="51"/>
<smd name="1" x="-0.9" y="0" dx="0.5" dy="1.3" layer="1"/>
<smd name="2" x="0.9" y="0" dx="0.5" dy="1.3" layer="1"/>
<text x="-1.27" y="0.9525" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.2225" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0102W">
<description>&lt;b&gt;CECC Size RC2211&lt;/b&gt; Wave Soldering&lt;p&gt;
<smd name="1" x="-0.95" y="0" dx="0.6" dy="1.3" layer="1"/>
<smd name="2" x="0.95" y="0" dx="0.6" dy="1.3" layer="1"/>
</package>
<package name="MINI_MELF-0204R">
<description>&lt;b&gt;CECC Size RC3715&lt;/b&gt; Reflow Soldering&lt;p&gt;
<wire x1="-1.7" y1="-0.6" x2="1.7" y2="-0.6" width="0.2032" layer="51"/>
<wire x1="1.7" y1="-0.6" x2="1.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="1.7" y1="0.6" x2="-1.7" y2="0.6" width="0.2032" layer="51"/>
<wire x1="-1.7" y1="0.6" x2="-1.7" y2="-0.6" width="0.2032" layer="51"/>
<wire x1="0.938" y1="0.6" x2="-0.938" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-0.938" y1="-0.6" x2="0.938" y2="-0.6" width="0.2032" layer="21"/>
<smd name="1" x="-1.5" y="0" dx="0.8" dy="1.6" layer="1"/>
<smd name="2" x="1.5" y="0" dx="0.8" dy="1.6" layer="1"/>
</package>
<package name="MINI_MELF-0204W">
<description>&lt;b&gt;CECC Size RC3715&lt;/b&gt; Wave Soldering&lt;p&gt;
<wire x1="0.684" y1="0.6" x2="-0.684" y2="0.6" width="0.2032" layer="21"/>
<wire x1="-0.684" y1="-0.6" x2="0.684" y2="-0.6" width="0.2032" layer="21"/>
<smd name="1" x="-1.5" y="0" dx="1.2" dy="1.6" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.2" dy="1.6" layer="1"/>
</package>
<package name="MINI_MELF-0207R">
<description>&lt;b&gt;CECC Size RC6123&lt;/b&gt; Reflow Soldering&lt;p&gt;
<wire x1="-2.8" y1="-1" x2="2.8" y2="-1" width="0.2032" layer="51"/>
<wire x1="2.8" y1="-1" x2="2.8" y2="1" width="0.2032" layer="51"/>
<wire x1="2.8" y1="1" x2="-2.8" y2="1" width="0.2032" layer="51"/>
<wire x1="-2.8" y1="1" x2="-2.8" y2="-1" width="0.2032" layer="51"/>
<wire x1="1.2125" y1="1" x2="-1.2125" y2="1" width="0.2032" layer="21"/>
<wire x1="-1.2125" y1="-1" x2="1.2125" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-2.25" y="0" dx="1.6" dy="2.5" layer="1"/>
<smd name="2" x="2.25" y="0" dx="1.6" dy="2.5" layer="1"/>
<text x="-2.2225" y="1.5875" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.2225" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="MINI_MELF-0207W">
<description>&lt;b&gt;CECC Size RC6123&lt;/b&gt; Wave Soldering&lt;p&gt;
<wire x1="1.149" y1="1" x2="-1.149" y2="1" width="0.2032" layer="21"/>
<wire x1="-1.149" y1="-1" x2="1.149" y2="-1" width="0.2032" layer="21"/>
<smd name="1" x="-2.6" y="0" dx="2.4" dy="2.5" layer="1"/>
<smd name="2" x="2.6" y="0" dx="2.4" dy="2.5" layer="1"/>
<text x="-2.54" y="1.5875" size="1.27" layer="25">&gt;NAME</text>
</package>
<package name="0922V">
type 0922, grid 7.5 mm</description>
<wire x1="-5.08" y1="0" x2="-3.81" y2="0" width="0.8128" layer="51"/>
<circle x="-5.08" y="0" radius="4.572" width="0.1524" layer="21"/>
<circle x="-5.08" y="0" radius="1.905" width="0.1524" layer="21"/>
<text x="-0.508" y="1.6764" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.508" y="-2.9972" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-6.858" y="2.54" size="1.016" layer="21" ratio="12">0922</text>
<rectangle x1="-3.81" y1="-0.4064" x2="1.3208" y2="0.4064" layer="21"/>
</package>
<package name="RDH/15">
type RDH, grid 15 mm</description>
<wire x1="-7.62" y1="0" x2="-6.858" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.096" y1="3.048" x2="-5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="2.794" x2="-5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-3.048" x2="-5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.794" x2="-5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.794" x2="5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.794" x2="-4.953" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-2.794" x2="5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="4.953" y1="-2.794" x2="-4.953" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="6.096" y1="3.048" x2="5.207" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-3.048" x2="5.207" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="-2.667" x2="-6.477" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-6.477" y1="1.016" x2="-6.477" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-6.477" y1="1.016" x2="-6.477" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.477" y1="-2.667" x2="6.477" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="6.477" y1="1.016" x2="6.477" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="6.477" y1="1.016" x2="6.477" y2="2.667" width="0.1524" layer="21"/>
<wire x1="6.858" y1="0" x2="7.62" y2="0" width="0.8128" layer="51"/>
<wire x1="-6.477" y1="2.667" x2="-6.096" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="3.048" x2="6.477" y2="2.667" width="0.1524" layer="21" curve="-90"/>
<wire x1="-6.477" y1="-2.667" x2="-6.096" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="6.096" y1="-3.048" x2="6.477" y2="-2.667" width="0.1524" layer="21" curve="90"/>
<text x="-6.35" y="3.4544" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="4.572" y="-1.7272" size="1.27" layer="51" ratio="10" rot="R90">RDH</text>
<rectangle x1="-6.7564" y1="-0.4064" x2="-6.4516" y2="0.4064" layer="51"/>
<rectangle x1="6.4516" y1="-0.4064" x2="6.7564" y2="0.4064" layer="51"/>
</package>
<package name="MINI_MELF-0102AX">
<description>&lt;b&gt;Mini MELF 0102 Axial&lt;/b&gt;</description>
<circle x="0" y="0" radius="0.6" width="0" layer="51"/>
<circle x="0" y="0" radius="0.6" width="0" layer="52"/>
<smd name="1" x="0" y="0" dx="1.9" dy="1.9" layer="1" roundness="100"/>
<smd name="2" x="0" y="0" dx="1.9" dy="1.9" layer="16" roundness="100"/>
<hole x="0" y="0" drill="1.3"/>
</package>
<package name="R0201">
<description>&lt;b&gt;RESISTOR&lt;/b&gt; chip&lt;p&gt;
Source: http://www.vishay.com/docs/20008/dcrcw.pdf</description>
<smd name="1" x="-0.255" y="0" dx="0.28" dy="0.43" layer="1"/>
<smd name="2" x="0.255" y="0" dx="0.28" dy="0.43" layer="1"/>
<rectangle x1="-0.3" y1="-0.15" x2="-0.15" y2="0.15" layer="51"/>
<rectangle x1="0.15" y1="-0.15" x2="0.3" y2="0.15" layer="51"/>
<rectangle x1="-0.15" y1="-0.15" x2="0.15" y2="0.15" layer="21"/>
</package>
<package name="VTA52">
<description>&lt;b&gt;Bulk Metal® Foil Technology&lt;/b&gt;, Tubular Axial Lead Resistors, Meets or Exceeds MIL-R-39005 Requirements&lt;p&gt;
MIL SIZE RBR52&lt;br&gt;
Source: VISHAY .. vta56.pdf</description>
<wire x1="-15.24" y1="0" x2="-13.97" y2="0" width="0.6096" layer="51"/>
<wire x1="12.6225" y1="0.025" x2="12.6225" y2="4.725" width="0.1524" layer="21"/>
<wire x1="12.6225" y1="4.725" x2="-12.6225" y2="4.725" width="0.1524" layer="21"/>
<wire x1="-12.6225" y1="4.725" x2="-12.6225" y2="0.025" width="0.1524" layer="21"/>
<wire x1="-12.6225" y1="0.025" x2="-12.6225" y2="-4.65" width="0.1524" layer="21"/>
<wire x1="-12.6225" y1="-4.65" x2="12.6225" y2="-4.65" width="0.1524" layer="21"/>
<wire x1="12.6225" y1="-4.65" x2="12.6225" y2="0.025" width="0.1524" layer="21"/>
<wire x1="13.97" y1="0" x2="15.24" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-15.24" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="15.24" y="0" drill="1.1" shape="octagon"/>
<text x="-3.81" y="5.08" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-13.97" y1="-0.3048" x2="-12.5675" y2="0.3048" layer="21"/>
<rectangle x1="12.5675" y1="-0.3048" x2="13.97" y2="0.3048" layer="21"/>
</package>
<package name="VTA53">
MIL SIZE RBR53&lt;br&gt;
<wire x1="-12.065" y1="0" x2="-10.795" y2="0" width="0.6096" layer="51"/>
<wire x1="9.8975" y1="0" x2="9.8975" y2="4.7" width="0.1524" layer="21"/>
<wire x1="9.8975" y1="4.7" x2="-9.8975" y2="4.7" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="4.7" x2="-9.8975" y2="0" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="0" x2="-9.8975" y2="-4.675" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="-4.675" x2="9.8975" y2="-4.675" width="0.1524" layer="21"/>
<wire x1="9.8975" y1="-4.675" x2="9.8975" y2="0" width="0.1524" layer="21"/>
<wire x1="10.795" y1="0" x2="12.065" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-12.065" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="12.065" y="0" drill="1.1" shape="octagon"/>
<rectangle x1="-10.795" y1="-0.3048" x2="-9.8425" y2="0.3048" layer="21"/>
<rectangle x1="9.8425" y1="-0.3048" x2="10.795" y2="0.3048" layer="21"/>
</package>
<package name="VTA54">
MIL SIZE RBR54&lt;br&gt;
<wire x1="9.8975" y1="0" x2="9.8975" y2="3.3" width="0.1524" layer="21"/>
<wire x1="9.8975" y1="3.3" x2="-9.8975" y2="3.3" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="3.3" x2="-9.8975" y2="0" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="0" x2="-9.8975" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="-9.8975" y1="-3.3" x2="9.8975" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="9.8975" y1="-3.3" x2="9.8975" y2="0" width="0.1524" layer="21"/>
<text x="-3.81" y="3.81" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="VTA55">
MIL SIZE RBR55&lt;br&gt;
<wire x1="-8.255" y1="0" x2="-6.985" y2="0" width="0.6096" layer="51"/>
<wire x1="6.405" y1="0" x2="6.405" y2="3.3" width="0.1524" layer="21"/>
<wire x1="6.405" y1="3.3" x2="-6.405" y2="3.3" width="0.1524" layer="21"/>
<wire x1="-6.405" y1="3.3" x2="-6.405" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.405" y1="0" x2="-6.405" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="-6.405" y1="-3.3" x2="6.405" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="6.405" y1="-3.3" x2="6.405" y2="0" width="0.1524" layer="21"/>
<wire x1="6.985" y1="0" x2="8.255" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-8.255" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="8.255" y="0" drill="1.1" shape="octagon"/>
<rectangle x1="-6.985" y1="-0.3048" x2="-6.35" y2="0.3048" layer="21"/>
<rectangle x1="6.35" y1="-0.3048" x2="6.985" y2="0.3048" layer="21"/>
</package>
<package name="VTA56">
MIL SIZE RBR56&lt;br&gt;
<wire x1="4.5" y1="0" x2="4.5" y2="3.3" width="0.1524" layer="21"/>
<wire x1="4.5" y1="3.3" x2="-4.5" y2="3.3" width="0.1524" layer="21"/>
<wire x1="-4.5" y1="3.3" x2="-4.5" y2="0" width="0.1524" layer="21"/>
<wire x1="-4.5" y1="0" x2="-4.5" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="-4.5" y1="-3.3" x2="4.5" y2="-3.3" width="0.1524" layer="21"/>
<wire x1="4.5" y1="-3.3" x2="4.5" y2="0" width="0.1524" layer="21"/>
<wire x1="5.08" y1="0" x2="6.35" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-6.35" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="6.35" y="0" drill="1.1" shape="octagon"/>
<rectangle x1="-5.08" y1="-0.3048" x2="-4.445" y2="0.3048" layer="21"/>
<rectangle x1="4.445" y1="-0.3048" x2="5.08" y2="0.3048" layer="21"/>
</package>
<package name="VMTA55">
MIL SIZE RNC55&lt;br&gt;
<wire x1="-5.08" y1="0" x2="-4.26" y2="0" width="0.6096" layer="51"/>
<wire x1="3.3375" y1="-1.45" x2="3.3375" y2="1.45" width="0.1524" layer="21"/>
<wire x1="3.3375" y1="1.45" x2="-3.3625" y2="1.45" width="0.1524" layer="21"/>
<wire x1="-3.3625" y1="1.45" x2="-3.3625" y2="-1.45" width="0.1524" layer="21"/>
<wire x1="-3.3625" y1="-1.45" x2="3.3375" y2="-1.45" width="0.1524" layer="21"/>
<wire x1="4.235" y1="0" x2="5.08" y2="0" width="0.6096" layer="51"/>
<pad name="1" x="-5.08" y="0" drill="1.1" shape="octagon"/>
<pad name="2" x="5.08" y="0" drill="1.1" shape="octagon"/>
<text x="-3.175" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<rectangle x1="-4.26" y1="-0.3048" x2="-3.3075" y2="0.3048" layer="21"/>
<rectangle x1="3.2825" y1="-0.3048" x2="4.235" y2="0.3048" layer="21"/>
</package>
<package name="VMTB60">
MIL SIZE RNC60&lt;br&gt;
<wire x1="-6.35" y1="0" x2="-5.585" y2="0" width="0.6096" layer="51"/>
<wire x1="4.6875" y1="-1.95" x2="4.6875" y2="1.95" width="0.1524" layer="21"/>
<wire x1="4.6875" y1="1.95" x2="-4.6875" y2="1.95" width="0.1524" layer="21"/>
<wire x1="-4.6875" y1="1.95" x2="-4.6875" y2="-1.95" width="0.1524" layer="21"/>
<wire x1="-4.6875" y1="-1.95" x2="4.6875" y2="-1.95" width="0.1524" layer="21"/>
<wire x1="5.585" y1="0" x2="6.35" y2="0" width="0.6096" layer="51"/>
<text x="-4.445" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.445" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.585" y1="-0.3048" x2="-4.6325" y2="0.3048" layer="21"/>
<rectangle x1="4.6325" y1="-0.3048" x2="5.585" y2="0.3048" layer="21"/>
</package>
<package name="R4527">
<description>&lt;b&gt;Package 4527&lt;/b&gt;&lt;p&gt;
Source: http://www.vishay.com/docs/31059/wsrhigh.pdf</description>
<wire x1="-5.675" y1="-3.375" x2="5.65" y2="-3.375" width="0.2032" layer="21"/>
<wire x1="5.65" y1="-3.375" x2="5.65" y2="3.375" width="0.2032" layer="51"/>
<wire x1="5.65" y1="3.375" x2="-5.675" y2="3.375" width="0.2032" layer="21"/>
<wire x1="-5.675" y1="3.375" x2="-5.675" y2="-3.375" width="0.2032" layer="51"/>
<smd name="1" x="-4.575" y="0" dx="3.94" dy="5.84" layer="1"/>
<smd name="2" x="4.575" y="0" dx="3.94" dy="5.84" layer="1"/>
<text x="-5.715" y="3.81" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.715" y="-5.08" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC0001">
<description>&lt;b&gt;Wirewound Resistors, Precision Power&lt;/b&gt;&lt;p&gt;
Source: VISHAY wscwsn.pdf</description>
<wire x1="-3.075" y1="1.8" x2="-3.075" y2="-1.8" width="0.2032" layer="51"/>
<wire x1="-3.075" y1="-1.8" x2="3.075" y2="-1.8" width="0.2032" layer="21"/>
<wire x1="3.075" y1="-1.8" x2="3.075" y2="1.8" width="0.2032" layer="51"/>
<wire x1="3.075" y1="1.8" x2="-3.075" y2="1.8" width="0.2032" layer="21"/>
<wire x1="-3.075" y1="1.8" x2="-3.075" y2="1.606" width="0.2032" layer="21"/>
<wire x1="-3.075" y1="-1.606" x2="-3.075" y2="-1.8" width="0.2032" layer="21"/>
<wire x1="3.075" y1="1.606" x2="3.075" y2="1.8" width="0.2032" layer="21"/>
<wire x1="3.075" y1="-1.8" x2="3.075" y2="-1.606" width="0.2032" layer="21"/>
<smd name="1" x="-2.675" y="0" dx="2.29" dy="2.92" layer="1"/>
<smd name="2" x="2.675" y="0" dx="2.29" dy="2.92" layer="1"/>
<text x="-2.544" y="2.229" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.544" y="-3.501" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC0002">
<wire x1="-5.55" y1="3.375" x2="-5.55" y2="-3.375" width="0.2032" layer="51"/>
<wire x1="-5.55" y1="-3.375" x2="5.55" y2="-3.375" width="0.2032" layer="21"/>
<wire x1="5.55" y1="-3.375" x2="5.55" y2="3.375" width="0.2032" layer="51"/>
<wire x1="5.55" y1="3.375" x2="-5.55" y2="3.375" width="0.2032" layer="21"/>
<smd name="1" x="-4.575" y="0.025" dx="3.94" dy="5.84" layer="1"/>
<text x="-5.65" y="3.9" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.65" y="-5.15" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC01/2">
<wire x1="-2.45" y1="1.475" x2="-2.45" y2="-1.475" width="0.2032" layer="51"/>
<wire x1="-2.45" y1="-1.475" x2="2.45" y2="-1.475" width="0.2032" layer="21"/>
<wire x1="2.45" y1="-1.475" x2="2.45" y2="1.475" width="0.2032" layer="51"/>
<wire x1="2.45" y1="1.475" x2="-2.45" y2="1.475" width="0.2032" layer="21"/>
<wire x1="-2.45" y1="1.475" x2="-2.45" y2="1.106" width="0.2032" layer="21"/>
<wire x1="-2.45" y1="-1.106" x2="-2.45" y2="-1.475" width="0.2032" layer="21"/>
<wire x1="2.45" y1="1.106" x2="2.45" y2="1.475" width="0.2032" layer="21"/>
<wire x1="2.45" y1="-1.475" x2="2.45" y2="-1.106" width="0.2032" layer="21"/>
<smd name="1" x="-2.1" y="0" dx="2.16" dy="1.78" layer="1"/>
<smd name="2" x="2.1" y="0" dx="2.16" dy="1.78" layer="1"/>
<text x="-2.544" y="1.904" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.544" y="-3.176" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC2515">
<wire x1="-3.075" y1="-1.8" x2="3.05" y2="-1.8" width="0.2032" layer="21"/>
<wire x1="3.05" y1="-1.8" x2="3.05" y2="1.8" width="0.2032" layer="51"/>
<wire x1="3.05" y1="1.8" x2="-3.075" y2="1.8" width="0.2032" layer="21"/>
<wire x1="3.05" y1="1.606" x2="3.05" y2="1.8" width="0.2032" layer="21"/>
<wire x1="3.05" y1="-1.8" x2="3.05" y2="-1.606" width="0.2032" layer="21"/>
<text x="-3.2" y="2.15" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.2" y="-3.4" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC4527">
<wire x1="-5.675" y1="3.4" x2="-5.675" y2="-3.375" width="0.2032" layer="51"/>
<wire x1="-5.675" y1="-3.375" x2="5.675" y2="-3.375" width="0.2032" layer="21"/>
<wire x1="5.675" y1="-3.375" x2="5.675" y2="3.4" width="0.2032" layer="51"/>
<wire x1="5.675" y1="3.4" x2="-5.675" y2="3.4" width="0.2032" layer="21"/>
<text x="-5.775" y="3.925" size="1.27" layer="25">&gt;NAME</text>
<text x="-5.775" y="-5.15" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="WSC6927">
<wire x1="-8.65" y1="3.375" x2="-8.65" y2="-3.375" width="0.2032" layer="51"/>
<wire x1="-8.65" y1="-3.375" x2="8.65" y2="-3.375" width="0.2032" layer="21"/>
<wire x1="8.65" y1="-3.375" x2="8.65" y2="3.375" width="0.2032" layer="51"/>
<wire x1="8.65" y1="3.375" x2="-8.65" y2="3.375" width="0.2032" layer="21"/>
<smd name="1" x="-7.95" y="0.025" dx="3.94" dy="5.97" layer="1"/>
<smd name="2" x="7.95" y="0" dx="3.94" dy="5.97" layer="1"/>
<text x="-8.75" y="3.9" size="1.27" layer="25">&gt;NAME</text>
<text x="-8.75" y="-5.15" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="R1218">
<description>&lt;b&gt;CRCW1218 Thick Film, Rectangular Chip Resistors&lt;/b&gt;&lt;p&gt;
Source: http://www.vishay.com .. dcrcw.pdf</description>
<wire x1="-0.913" y1="-2.219" x2="0.939" y2="-2.219" width="0.1524" layer="51"/>
<wire x1="0.913" y1="2.219" x2="-0.939" y2="2.219" width="0.1524" layer="51"/>
<smd name="1" x="-1.475" y="0" dx="1.05" dy="4.9" layer="1"/>
<smd name="2" x="1.475" y="0" dx="1.05" dy="4.9" layer="1"/>
<text x="-2.54" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-2.3" x2="-0.9009" y2="2.3" layer="51"/>
<rectangle x1="0.9144" y1="-2.3" x2="1.6645" y2="2.3" layer="51"/>
</package>
<package name="1812X7R">
<description>&lt;b&gt;Chip Monolithic Ceramic Capacitors&lt;/b&gt; Medium Voltage High Capacitance for General Use&lt;p&gt;
Source: http://www.murata.com .. GRM43DR72E224KW01.pdf</description>
<wire x1="-1.1" y1="1.5" x2="1.1" y2="1.5" width="0.2032" layer="51"/>
<wire x1="1.1" y1="-1.5" x2="-1.1" y2="-1.5" width="0.2032" layer="51"/>
<wire x1="-0.6" y1="1.5" x2="0.6" y2="1.5" width="0.2032" layer="21"/>
<wire x1="0.6" y1="-1.5" x2="-0.6" y2="-1.5" width="0.2032" layer="21"/>
<smd name="1" x="-1.425" y="0" dx="0.8" dy="3.5" layer="1"/>
<smd name="2" x="1.425" y="0" dx="0.8" dy="3.5" layer="1" rot="R180"/>
<text x="-1.9456" y="1.9958" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.9456" y="-3.7738" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.4" y1="-1.6" x2="-1.1" y2="1.6" layer="51"/>
<rectangle x1="1.1" y1="-1.6" x2="1.4" y2="1.6" layer="51" rot="R180"/>
</package>
<package name="C0402">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;</description>
<wire x1="-0.245" y1="0.224" x2="0.245" y2="0.224" width="0.1524" layer="51"/>
<wire x1="0.245" y1="-0.224" x2="-0.245" y2="-0.224" width="0.1524" layer="51"/>
<wire x1="-1.473" y1="0.483" x2="1.473" y2="0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.483" x2="1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.483" x2="-1.473" y2="-0.483" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.483" x2="-1.473" y2="0.483" width="0.0508" layer="39"/>
<smd name="1" x="-0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<smd name="2" x="0.65" y="0" dx="0.7" dy="0.9" layer="1"/>
<text x="-0.635" y="0.635" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-1.905" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.554" y1="-0.3048" x2="-0.254" y2="0.2951" layer="51"/>
<rectangle x1="0.2588" y1="-0.3048" x2="0.5588" y2="0.2951" layer="51"/>
<rectangle x1="-0.1999" y1="-0.3" x2="0.1999" y2="0.3" layer="35"/>
</package>
<package name="C0504">
<wire x1="-1.473" y1="0.983" x2="1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="0.983" x2="1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="1.473" y1="-0.983" x2="-1.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.473" y1="-0.983" x2="-1.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-0.294" y1="0.559" x2="0.294" y2="0.559" width="0.1016" layer="51"/>
<wire x1="-0.294" y1="-0.559" x2="0.294" y2="-0.559" width="0.1016" layer="51"/>
<smd name="1" x="-0.7" y="0" dx="1" dy="1.3" layer="1"/>
<smd name="2" x="0.7" y="0" dx="1" dy="1.3" layer="1"/>
<text x="-0.635" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.6604" y1="-0.6223" x2="-0.2804" y2="0.6276" layer="51"/>
<rectangle x1="0.2794" y1="-0.6223" x2="0.6594" y2="0.6276" layer="51"/>
<rectangle x1="-0.1001" y1="-0.4001" x2="0.1001" y2="0.4001" layer="35"/>
</package>
<package name="C0603">
<wire x1="-0.356" y1="0.432" x2="0.356" y2="0.432" width="0.1016" layer="51"/>
<wire x1="-0.356" y1="-0.419" x2="0.356" y2="-0.419" width="0.1016" layer="51"/>
<smd name="1" x="-0.85" y="0" dx="1.1" dy="1" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.1" dy="1" layer="1"/>
<rectangle x1="-0.8382" y1="-0.4699" x2="-0.3381" y2="0.4801" layer="51"/>
<rectangle x1="0.3302" y1="-0.4699" x2="0.8303" y2="0.4801" layer="51"/>
</package>
<package name="C0805">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-0.381" y1="0.66" x2="0.381" y2="0.66" width="0.1016" layer="51"/>
<wire x1="-0.356" y1="-0.66" x2="0.381" y2="-0.66" width="0.1016" layer="51"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.0922" y1="-0.7239" x2="-0.3421" y2="0.7262" layer="51"/>
<rectangle x1="0.3556" y1="-0.7239" x2="1.1057" y2="0.7262" layer="51"/>
</package>
<package name="C1005">
</package>
<package name="C1206">
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-0.965" y1="0.787" x2="0.965" y2="0.787" width="0.1016" layer="51"/>
<wire x1="-0.965" y1="-0.787" x2="0.965" y2="-0.787" width="0.1016" layer="51"/>
<rectangle x1="-1.7018" y1="-0.8509" x2="-0.9517" y2="0.8491" layer="51"/>
<rectangle x1="0.9517" y1="-0.8491" x2="1.7018" y2="0.8509" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="C1210">
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="-0.9652" y1="1.2446" x2="0.9652" y2="1.2446" width="0.1016" layer="51"/>
<wire x1="-0.9652" y1="-1.2446" x2="0.9652" y2="-1.2446" width="0.1016" layer="51"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2.7" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-1.2954" x2="-0.9517" y2="1.3045" layer="51"/>
<rectangle x1="0.9517" y1="-1.3045" x2="1.7018" y2="1.2954" layer="51"/>
</package>
<package name="C1310">
<rectangle x1="-0.1001" y1="-0.3" x2="0.1001" y2="0.3" layer="35"/>
</package>
<package name="C1608">
</package>
<package name="C1812">
<wire x1="-2.973" y1="1.983" x2="2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-1.983" x2="-2.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-1.983" x2="-2.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="-1.4732" y1="1.6002" x2="1.4732" y2="1.6002" width="0.1016" layer="51"/>
<wire x1="-1.4478" y1="-1.6002" x2="1.4732" y2="-1.6002" width="0.1016" layer="51"/>
<wire x1="2.973" y1="1.983" x2="2.973" y2="-1.983" width="0.0508" layer="39"/>
<smd name="1" x="-1.95" y="0" dx="1.9" dy="3.4" layer="1"/>
<smd name="2" x="1.95" y="0" dx="1.9" dy="3.4" layer="1"/>
<text x="-1.905" y="2.54" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.81" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.3876" y1="-1.651" x2="-1.4376" y2="1.649" layer="51"/>
<rectangle x1="1.4478" y1="-1.651" x2="2.3978" y2="1.649" layer="51"/>
<rectangle x1="-0.3" y1="-0.4001" x2="0.3" y2="0.4001" layer="35"/>
</package>
<package name="C1825">
<wire x1="-2.973" y1="3.483" x2="2.973" y2="3.483" width="0.0508" layer="39"/>
<wire x1="2.973" y1="-3.483" x2="-2.973" y2="-3.483" width="0.0508" layer="39"/>
<wire x1="-2.973" y1="-3.483" x2="-2.973" y2="3.483" width="0.0508" layer="39"/>
<wire x1="-1.4986" y1="3.2766" x2="1.4732" y2="3.2766" width="0.1016" layer="51"/>
<wire x1="-1.4732" y1="-3.2766" x2="1.4986" y2="-3.2766" width="0.1016" layer="51"/>
<wire x1="2.973" y1="3.483" x2="2.973" y2="-3.483" width="0.0508" layer="39"/>
<smd name="1" x="-1.95" y="0" dx="1.9" dy="6.8" layer="1"/>
<smd name="2" x="1.95" y="0" dx="1.9" dy="6.8" layer="1"/>
<text x="-1.905" y="3.81" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-5.08" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.413" y1="-3.3528" x2="-1.463" y2="3.3472" layer="51"/>
<rectangle x1="1.4478" y1="-3.3528" x2="2.3978" y2="3.3472" layer="51"/>
<rectangle x1="-0.7" y1="-0.7" x2="0.7" y2="0.7" layer="35"/>
</package>
<package name="C2012">
<smd name="1" x="-0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.85" y="0" dx="1.3" dy="1.5" layer="1"/>
</package>
<package name="C3216">
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<rectangle x1="-0.3" y1="-0.5001" x2="0.3" y2="0.5001" layer="35"/>
</package>
<package name="C3225">
<rectangle x1="-0.1999" y1="-0.5001" x2="0.1999" y2="0.5001" layer="35"/>
</package>
<package name="C4532">
<rectangle x1="-0.4001" y1="-0.7" x2="0.4001" y2="0.7" layer="35"/>
</package>
<package name="C4564">
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="C025-024X044">
grid 2.5 mm, outline 2.4 x 4.4 mm</description>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="0.635" x2="-1.651" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.159" y1="-0.635" x2="-1.651" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="1.651" y1="1.143" x2="-1.651" y2="1.143" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.651" y1="-1.143" x2="-1.651" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="1.651" y1="1.143" x2="2.159" y2="0.635" width="0.1524" layer="21" curve="-90"/>
<wire x1="1.651" y1="-1.143" x2="2.159" y2="-0.635" width="0.1524" layer="21" curve="90"/>
<wire x1="-0.3048" y1="0.762" x2="-0.3048" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0.762" x2="0.3302" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="1.27" y1="0" x2="0.3302" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="0" x2="-0.3048" y2="0" width="0.1524" layer="51"/>
<text x="-1.778" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.778" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-025X050">
grid 2.5 mm, outline 2.5 x 5 mm</description>
<wire x1="-2.159" y1="1.27" x2="2.159" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.27" x2="-2.159" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.016" x2="-2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.27" x2="2.413" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.016" x2="-2.159" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.27" x2="2.413" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.016" x2="-2.159" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="0.762" y1="0" x2="0.381" y2="0" width="0.1524" layer="51"/>
<wire x1="0.381" y1="0" x2="0.254" y2="0" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="0.762" width="0.254" layer="21"/>
<wire x1="0.254" y1="0" x2="0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0.762" x2="-0.254" y2="0" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.254" y2="-0.762" width="0.254" layer="21"/>
<wire x1="-0.254" y1="0" x2="-0.381" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.381" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<text x="-2.286" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-030X050">
grid 2.5 mm, outline 3 x 5 mm</description>
<wire x1="-2.159" y1="1.524" x2="2.159" y2="1.524" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.524" x2="-2.159" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.27" x2="2.413" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.27" x2="-2.413" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.524" x2="2.413" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.27" x2="-2.159" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.524" x2="2.413" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.27" x2="-2.159" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-040X050">
grid 2.5 mm, outline 4 x 5 mm</description>
<wire x1="-2.159" y1="1.905" x2="2.159" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.905" x2="-2.159" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.651" x2="2.413" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.651" x2="-2.413" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.905" x2="2.413" y2="1.651" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.651" x2="-2.159" y2="1.905" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.905" x2="2.413" y2="-1.651" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.651" x2="-2.159" y2="-1.905" width="0.1524" layer="21" curve="90"/>
<pad name="1" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.286" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-050X050">
grid 2.5 mm, outline 5 x 5 mm</description>
<wire x1="-2.159" y1="2.286" x2="2.159" y2="2.286" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-2.286" x2="-2.159" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.032" x2="2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="2.032" x2="-2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.286" x2="2.413" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="2.032" x2="-2.159" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-2.286" x2="2.413" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-2.032" x2="-2.159" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="2.54" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025-060X050">
grid 2.5 mm, outline 6 x 5 mm</description>
<wire x1="-2.159" y1="2.794" x2="2.159" y2="2.794" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-2.794" x2="-2.159" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.54" x2="2.413" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="2.54" x2="-2.413" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="2.159" y1="2.794" x2="2.413" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="2.54" x2="-2.159" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-2.794" x2="2.413" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-2.54" x2="-2.159" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<text x="-2.286" y="3.048" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025_050-024X070">
grid 2.5 mm + 5 mm, outline 2.4 x 7 mm</description>
<wire x1="-2.159" y1="-0.635" x2="-2.159" y2="0.635" width="0.1524" layer="51"/>
<wire x1="2.159" y1="-0.635" x2="2.159" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-4.191" y1="-1.143" x2="-3.9624" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="1.143" x2="-3.9624" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-4.699" y1="-0.635" x2="-4.191" y2="-1.143" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.699" y1="0.635" x2="-4.191" y2="1.143" width="0.1524" layer="21" curve="-90"/>
<wire x1="-4.699" y1="-0.635" x2="-4.699" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.143" x2="-2.5654" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.143" x2="-2.5654" y2="-1.143" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="-1.27" y="0" drill="0.8128" shape="octagon"/>
<pad name="3" x="1.27" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.81" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025_050-025X075">
grid 2.5 + 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="4.953" y1="1.016" x2="4.953" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="4.699" y1="1.27" x2="4.953" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-1.27" x2="4.953" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="1.27" x2="4.699" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.27" x2="2.794" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.016" x2="2.413" y2="0.762" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-0.762" x2="2.413" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.254" x2="2.413" y2="-0.254" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0" x2="2.286" y2="0" width="0.1524" layer="51"/>
<wire x1="2.286" y1="0" x2="2.794" y2="0" width="0.1524" layer="21"/>
<wire x1="2.794" y1="0" x2="3.302" y2="0" width="0.1524" layer="51"/>
<pad name="3" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.159" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025_050-035X075">
grid 2.5 + 5 mm, outline 3.5 x 7.5 mm</description>
<wire x1="-2.159" y1="1.778" x2="2.159" y2="1.778" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.778" x2="-2.159" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-2.413" y1="1.524" x2="-2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.159" y1="1.778" x2="2.413" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.413" y1="1.524" x2="-2.159" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="-1.778" x2="2.413" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.413" y1="-1.524" x2="-2.159" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="1.778" x2="4.699" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.778" x2="2.794" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="2.413" y1="1.524" x2="2.413" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.016" x2="2.413" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.508" x2="2.413" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.381" y1="0" x2="0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="2.286" y1="0" x2="1.778" y2="0" width="0.1524" layer="51"/>
<text x="-2.286" y="-3.302" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C025_050-045X075">
grid 2.5 + 5 mm, outline 4.5 x 7.5 mm</description>
<wire x1="4.953" y1="2.032" x2="4.953" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.286" x2="4.953" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-2.286" x2="4.953" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="2.286" x2="4.699" y2="2.286" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.286" x2="2.794" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.032" x2="2.413" y2="1.397" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-1.397" x2="2.413" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="2.413" y1="0.762" x2="2.413" y2="-0.762" width="0.1524" layer="21"/>
<text x="-2.286" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C025_050-055X075">
grid 2.5 + 5 mm, outline 5.5 x 7.5 mm</description>
<wire x1="4.953" y1="2.54" x2="4.953" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="4.699" y1="2.794" x2="4.953" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="-2.794" x2="4.953" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="2.794" y1="2.794" x2="4.699" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-2.794" x2="2.794" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="2.413" y1="2.54" x2="2.413" y2="2.032" width="0.1524" layer="21"/>
<wire x1="2.413" y1="-2.032" x2="2.413" y2="-2.54" width="0.1524" layer="21"/>
<text x="-2.286" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-024X044">
grid 5 mm, outline 2.4 x 4.4 mm</description>
<wire x1="-0.3048" y1="0.762" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0.762" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.762" width="0.3048" layer="21"/>
<wire x1="1.27" y1="0" x2="0.3302" y2="0" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0" x2="-0.3048" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.159" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.159" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.159" y1="-0.381" x2="2.54" y2="0.381" layer="51"/>
<rectangle x1="-2.54" y1="-0.381" x2="-2.159" y2="0.381" layer="51"/>
</package>
<package name="C050-025X075">
grid 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.016" x2="-3.683" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.27" x2="3.429" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.016" x2="3.683" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="-3.429" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="3.683" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.27" x2="3.683" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.016" x2="-3.429" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.016" x2="-3.429" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-045X075">
grid 5 mm, outline 4.5 x 7.5 mm</description>
<wire x1="-3.683" y1="2.032" x2="-3.683" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.286" x2="3.429" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.032" x2="3.683" y2="2.032" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.286" x2="-3.429" y2="2.286" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.286" x2="3.683" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.286" x2="3.683" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.032" x2="-3.429" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.032" x2="-3.429" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<text x="-3.556" y="2.667" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-030X075">
grid 5 mm, outline 3 x 7.5 mm</description>
<wire x1="-3.683" y1="1.27" x2="-3.683" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.524" x2="3.429" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.27" x2="3.683" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="-3.429" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.524" x2="3.683" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.524" x2="3.683" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.27" x2="-3.429" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.27" x2="-3.429" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<text x="-3.556" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-050X075">
grid 5 mm, outline 5 x 7.5 mm</description>
<wire x1="-3.683" y1="2.286" x2="-3.683" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.54" x2="3.429" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.286" x2="3.683" y2="2.286" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.54" x2="-3.429" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.54" x2="3.683" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.54" x2="3.683" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.286" x2="-3.429" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.286" x2="-3.429" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-2.159" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-055X075">
grid 5 mm, outline 5.5 x 7.5 mm</description>
<wire x1="-3.683" y1="2.54" x2="-3.683" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-2.794" x2="3.429" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-2.54" x2="3.683" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.794" x2="-3.429" y2="2.794" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.794" x2="3.683" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-2.794" x2="3.683" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-2.54" x2="-3.429" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="2.54" x2="-3.429" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="3.175" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-075X075">
grid 5 mm, outline 7.5 x 7.5 mm</description>
<wire x1="-1.524" y1="0" x2="-0.4572" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.4572" y1="0" x2="-0.4572" y2="0.762" width="0.4064" layer="21"/>
<wire x1="-0.4572" y1="0" x2="-0.4572" y2="-0.762" width="0.4064" layer="21"/>
<wire x1="0.4318" y1="0.762" x2="0.4318" y2="0" width="0.4064" layer="21"/>
<wire x1="0.4318" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.4318" y1="0" x2="0.4318" y2="-0.762" width="0.4064" layer="21"/>
<wire x1="-3.683" y1="3.429" x2="-3.683" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-3.683" x2="3.429" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-3.429" x2="3.683" y2="3.429" width="0.1524" layer="21"/>
<wire x1="3.429" y1="3.683" x2="-3.429" y2="3.683" width="0.1524" layer="21"/>
<wire x1="3.429" y1="3.683" x2="3.683" y2="3.429" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-3.683" x2="3.683" y2="-3.429" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-3.429" x2="-3.429" y2="-3.683" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="3.429" x2="-3.429" y2="3.683" width="0.1524" layer="21" curve="-90"/>
<text x="-3.429" y="4.064" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050H075X075">
Horizontal, grid 5 mm, outline 7.5 x 7.5 mm</description>
<wire x1="-3.683" y1="7.112" x2="-3.683" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="0.508" x2="-3.302" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-3.302" y1="0.508" x2="-1.778" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-1.778" y1="0.508" x2="1.778" y2="0.508" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.508" x2="3.302" y2="0.508" width="0.1524" layer="51"/>
<wire x1="3.302" y1="0.508" x2="3.683" y2="0.508" width="0.1524" layer="21"/>
<wire x1="3.683" y1="0.508" x2="3.683" y2="7.112" width="0.1524" layer="21"/>
<wire x1="3.175" y1="7.62" x2="-3.175" y2="7.62" width="0.1524" layer="21"/>
<wire x1="-0.3048" y1="2.413" x2="-0.3048" y2="1.778" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="1.778" x2="-0.3048" y2="1.143" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="1.778" x2="-1.651" y2="1.778" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="2.413" x2="0.3302" y2="1.778" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="1.778" x2="0.3302" y2="1.143" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="1.778" x2="1.651" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="7.112" x2="-3.175" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.175" y1="7.62" x2="3.683" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="0" x2="-2.54" y2="0.254" width="0.508" layer="51"/>
<wire x1="2.54" y1="0" x2="2.54" y2="0.254" width="0.508" layer="51"/>
<text x="-3.302" y="8.001" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.175" y="3.175" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.794" y1="0.127" x2="-2.286" y2="0.508" layer="51"/>
<rectangle x1="2.286" y1="0.127" x2="2.794" y2="0.508" layer="51"/>
</package>
<package name="C075-032X103">
grid 7.5 mm, outline 3.2 x 10.3 mm</description>
<wire x1="4.826" y1="1.524" x2="-4.826" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-1.524" x2="4.826" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.27" x2="5.08" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.826" y1="1.524" x2="5.08" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.826" y1="-1.524" x2="5.08" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="-1.27" x2="-4.826" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.27" x2="-4.826" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="0.508" y1="0" x2="2.54" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0" x2="-0.508" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.508" y1="0.889" x2="-0.508" y2="0" width="0.4064" layer="21"/>
<wire x1="-0.508" y1="0" x2="-0.508" y2="-0.889" width="0.4064" layer="21"/>
<wire x1="0.508" y1="0.889" x2="0.508" y2="0" width="0.4064" layer="21"/>
<wire x1="0.508" y1="0" x2="0.508" y2="-0.889" width="0.4064" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.9144" shape="octagon"/>
<text x="-4.826" y="1.905" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-4.826" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C075-042X103">
grid 7.5 mm, outline 4.2 x 10.3 mm</description>
<wire x1="4.826" y1="2.032" x2="-4.826" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.778" x2="-5.08" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="-2.032" x2="4.826" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.778" x2="5.08" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.032" x2="5.08" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.826" y1="-2.032" x2="5.08" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="-1.778" x2="-4.826" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.778" x2="-4.826" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="-1.27" y1="0" x2="2.667" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="0" x2="-2.159" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.159" y1="1.27" x2="-2.159" y2="0" width="0.4064" layer="21"/>
<wire x1="-2.159" y1="0" x2="-2.159" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="0" width="0.4064" layer="21"/>
<wire x1="-1.27" y1="0" x2="-1.27" y2="-1.27" width="0.4064" layer="21"/>
<text x="-4.699" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C075-052X106">
grid 7.5 mm, outline 5.2 x 10.6 mm</description>
<wire x1="4.953" y1="2.54" x2="-4.953" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.286" x2="-5.207" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-2.54" x2="4.953" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.286" x2="5.207" y2="2.286" width="0.1524" layer="21"/>
<wire x1="4.953" y1="2.54" x2="5.207" y2="2.286" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.953" y1="-2.54" x2="5.207" y2="-2.286" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="-2.286" x2="-4.953" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="2.286" x2="-4.953" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-4.826" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C102-043X133">
grid 10.2 mm, outline 4.3 x 13.3 mm</description>
<wire x1="-3.175" y1="1.27" x2="-3.175" y2="0" width="0.4064" layer="21"/>
<wire x1="-2.286" y1="1.27" x2="-2.286" y2="0" width="0.4064" layer="21"/>
<wire x1="3.81" y1="0" x2="-2.286" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="-2.286" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-3.81" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="0" x2="-3.175" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-6.096" y1="2.032" x2="6.096" y2="2.032" width="0.1524" layer="21"/>
<wire x1="6.604" y1="1.524" x2="6.604" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-2.032" x2="-6.096" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-1.524" x2="-6.604" y2="1.524" width="0.1524" layer="21"/>
<wire x1="6.096" y1="2.032" x2="6.604" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-2.032" x2="6.604" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-1.524" x2="-6.096" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="1.524" x2="-6.096" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<pad name="2" x="5.08" y="0" drill="1.016" shape="octagon"/>
<text x="-6.096" y="2.413" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-1.651" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C102-054X133">
grid 10.2 mm, outline 5.4 x 13.3 mm</description>
<wire x1="-6.096" y1="2.54" x2="6.096" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.032" x2="6.604" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-2.54" x2="-6.096" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.032" x2="-6.604" y2="2.032" width="0.1524" layer="21"/>
<wire x1="6.096" y1="2.54" x2="6.604" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-2.54" x2="6.604" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-2.032" x2="-6.096" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="2.032" x2="-6.096" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<text x="-6.096" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-1.905" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C102-064X133">
grid 10.2 mm, outline 6.4 x 13.3 mm</description>
<wire x1="-6.096" y1="3.048" x2="6.096" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.604" y1="2.54" x2="6.604" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-3.048" x2="-6.096" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="-2.54" x2="-6.604" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.096" y1="3.048" x2="6.604" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.096" y1="-3.048" x2="6.604" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="-2.54" x2="-6.096" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-6.604" y1="2.54" x2="-6.096" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-6.096" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C102_152-062X184">
grid 10.2 mm + 15.2 mm, outline 6.2 x 18.4 mm</description>
<wire x1="-3.683" y1="0" x2="-3.175" y2="0" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="0" x2="3.683" y2="0" width="0.1524" layer="21"/>
<wire x1="6.477" y1="0" x2="8.636" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="3.048" x2="6.223" y2="3.048" width="0.1524" layer="21"/>
<wire x1="6.223" y1="-3.048" x2="-6.096" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="6.223" y1="3.048" x2="6.731" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="6.223" y1="-3.048" x2="6.731" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="6.731" y1="2.54" x2="6.731" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="11.176" y1="3.048" x2="11.684" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="11.176" y1="-3.048" x2="11.684" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="11.176" y1="-3.048" x2="7.112" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="7.112" y1="3.048" x2="11.176" y2="3.048" width="0.1524" layer="21"/>
<wire x1="11.684" y1="2.54" x2="11.684" y2="-2.54" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="1.016" shape="octagon"/>
<pad name="3" x="10.033" y="0" drill="1.016" shape="octagon"/>
<text x="-5.969" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-054X183">
grid 15 mm, outline 5.4 x 18.3 mm</description>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="0" width="0.4064" layer="21"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="1.27" x2="-4.191" y2="0" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="-4.191" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="9.017" y1="2.032" x2="9.017" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-2.54" x2="-8.509" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-2.032" x2="-9.017" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="2.54" x2="8.509" y2="2.54" width="0.1524" layer="21"/>
<wire x1="8.509" y1="2.54" x2="9.017" y2="2.032" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-2.54" x2="9.017" y2="-2.032" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-2.032" x2="-8.509" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="2.032" x2="-8.509" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-7.493" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="7.493" y="0" drill="1.016" shape="octagon"/>
<text x="-8.382" y="2.921" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.032" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-064X183">
grid 15 mm, outline 6.4 x 18.3 mm</description>
<wire x1="9.017" y1="2.54" x2="9.017" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.048" x2="-8.509" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-2.54" x2="-9.017" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.048" x2="8.509" y2="3.048" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.048" x2="9.017" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-3.048" x2="9.017" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-2.54" x2="-8.509" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="2.54" x2="-8.509" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C150-072X183">
grid 15 mm, outline 7.2 x 18.3 mm</description>
<wire x1="9.017" y1="3.048" x2="9.017" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-3.556" x2="-8.509" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.048" x2="-9.017" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="3.556" x2="8.509" y2="3.556" width="0.1524" layer="21"/>
<wire x1="8.509" y1="3.556" x2="9.017" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-3.556" x2="9.017" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.048" x2="-8.509" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.048" x2="-8.509" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="3.937" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.286" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-084X183">
grid 15 mm, outline 8.4 x 18.3 mm</description>
<wire x1="9.017" y1="3.556" x2="9.017" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.064" x2="-8.509" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.556" x2="-9.017" y2="3.556" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.064" x2="8.509" y2="4.064" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.064" x2="9.017" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-4.064" x2="9.017" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.556" x2="-8.509" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.556" x2="-8.509" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="4.445" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-091X182">
grid 15 mm, outline 9.1 x 18.2 mm</description>
<wire x1="9.017" y1="3.937" x2="9.017" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.445" x2="-8.509" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.937" x2="-9.017" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.445" x2="8.509" y2="4.445" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.445" x2="9.017" y2="3.937" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-4.445" x2="9.017" y2="-3.937" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.937" x2="-8.509" y2="-4.445" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.937" x2="-8.509" y2="4.445" width="0.1524" layer="21" curve="-90"/>
<text x="-8.509" y="4.826" size="1.27" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C225-062X268">
grid 22.5 mm, outline 6.2 x 26.8 mm</description>
<wire x1="-12.827" y1="3.048" x2="12.827" y2="3.048" width="0.1524" layer="21"/>
<wire x1="13.335" y1="2.54" x2="13.335" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-3.048" x2="-12.827" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-2.54" x2="-13.335" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="1.905" x2="-6.731" y2="0" width="0.4064" layer="21"/>
<wire x1="-6.731" y1="0" x2="-6.731" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="1.905" x2="-7.62" y2="0" width="0.4064" layer="21"/>
<wire x1="-7.62" y1="0" x2="-7.62" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="12.827" y1="3.048" x2="13.335" y2="2.54" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-3.048" x2="13.335" y2="-2.54" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-2.54" x2="-12.827" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="2.54" x2="-12.827" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="-9.652" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="9.652" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-11.303" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="11.303" y="0" drill="1.016" shape="octagon"/>
<text x="-12.7" y="3.429" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C225-074X268">
grid 22.5 mm, outline 7.4 x 26.8 mm</description>
<wire x1="-12.827" y1="3.556" x2="12.827" y2="3.556" width="0.1524" layer="21"/>
<wire x1="13.335" y1="3.048" x2="13.335" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-3.556" x2="-12.827" y2="-3.556" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-3.048" x2="-13.335" y2="3.048" width="0.1524" layer="21"/>
<wire x1="12.827" y1="3.556" x2="13.335" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-3.556" x2="13.335" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-3.048" x2="-12.827" y2="-3.556" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="3.048" x2="-12.827" y2="3.556" width="0.1524" layer="21" curve="-90"/>
<text x="-12.827" y="3.937" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C225-087X268">
grid 22.5 mm, outline 8.7 x 26.8 mm</description>
<wire x1="-12.827" y1="4.318" x2="12.827" y2="4.318" width="0.1524" layer="21"/>
<wire x1="13.335" y1="3.81" x2="13.335" y2="-3.81" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-4.318" x2="-12.827" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-3.81" x2="-13.335" y2="3.81" width="0.1524" layer="21"/>
<wire x1="12.827" y1="4.318" x2="13.335" y2="3.81" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-4.318" x2="13.335" y2="-3.81" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-3.81" x2="-12.827" y2="-4.318" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="3.81" x2="-12.827" y2="4.318" width="0.1524" layer="21" curve="-90"/>
<text x="-12.827" y="4.699" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C225-108X268">
grid 22.5 mm, outline 10.8 x 26.8 mm</description>
<wire x1="-12.827" y1="5.334" x2="12.827" y2="5.334" width="0.1524" layer="21"/>
<wire x1="13.335" y1="4.826" x2="13.335" y2="-4.826" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-5.334" x2="-12.827" y2="-5.334" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-4.826" x2="-13.335" y2="4.826" width="0.1524" layer="21"/>
<wire x1="12.827" y1="5.334" x2="13.335" y2="4.826" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-5.334" x2="13.335" y2="-4.826" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-4.826" x2="-12.827" y2="-5.334" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="4.826" x2="-12.827" y2="5.334" width="0.1524" layer="21" curve="-90"/>
<text x="-12.954" y="5.715" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C225-113X268">
grid 22.5 mm, outline 11.3 x 26.8 mm</description>
<wire x1="-12.827" y1="5.588" x2="12.827" y2="5.588" width="0.1524" layer="21"/>
<wire x1="13.335" y1="5.08" x2="13.335" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="12.827" y1="-5.588" x2="-12.827" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-13.335" y1="-5.08" x2="-13.335" y2="5.08" width="0.1524" layer="21"/>
<wire x1="12.827" y1="5.588" x2="13.335" y2="5.08" width="0.1524" layer="21" curve="-90"/>
<wire x1="12.827" y1="-5.588" x2="13.335" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="-5.08" x2="-12.827" y2="-5.588" width="0.1524" layer="21" curve="90"/>
<wire x1="-13.335" y1="5.08" x2="-12.827" y2="5.588" width="0.1524" layer="21" curve="-90"/>
<text x="-12.954" y="5.969" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-093X316">
grid 27.5 mm, outline 9.3 x 31.6 mm</description>
<wire x1="-15.24" y1="4.572" x2="15.24" y2="4.572" width="0.1524" layer="21"/>
<wire x1="15.748" y1="4.064" x2="15.748" y2="-4.064" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-4.572" x2="-15.24" y2="-4.572" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-4.064" x2="-15.748" y2="4.064" width="0.1524" layer="21"/>
<wire x1="15.24" y1="4.572" x2="15.748" y2="4.064" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-4.572" x2="15.748" y2="-4.064" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-4.064" x2="-15.24" y2="-4.572" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="4.064" x2="-15.24" y2="4.572" width="0.1524" layer="21" curve="-90"/>
<wire x1="-11.557" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="11.557" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-13.716" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="13.716" y="0" drill="1.1938" shape="octagon"/>
<text x="-15.24" y="4.953" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-113X316">
grid 27.5 mm, outline 11.3 x 31.6 mm</description>
<wire x1="-15.24" y1="5.588" x2="15.24" y2="5.588" width="0.1524" layer="21"/>
<wire x1="15.748" y1="5.08" x2="15.748" y2="-5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-5.588" x2="-15.24" y2="-5.588" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-5.08" x2="-15.748" y2="5.08" width="0.1524" layer="21"/>
<wire x1="15.24" y1="5.588" x2="15.748" y2="5.08" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-5.588" x2="15.748" y2="-5.08" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-5.08" x2="-15.24" y2="-5.588" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="5.08" x2="-15.24" y2="5.588" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="5.969" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-134X316">
grid 27.5 mm, outline 13.4 x 31.6 mm</description>
<wire x1="-15.24" y1="6.604" x2="15.24" y2="6.604" width="0.1524" layer="21"/>
<wire x1="15.748" y1="6.096" x2="15.748" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-6.604" x2="-15.24" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-6.096" x2="-15.748" y2="6.096" width="0.1524" layer="21"/>
<wire x1="15.24" y1="6.604" x2="15.748" y2="6.096" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-6.604" x2="15.748" y2="-6.096" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-6.096" x2="-15.24" y2="-6.604" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="6.096" x2="-15.24" y2="6.604" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="6.985" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-205X316">
grid 27.5 mm, outline 20.5 x 31.6 mm</description>
<wire x1="-15.24" y1="10.16" x2="15.24" y2="10.16" width="0.1524" layer="21"/>
<wire x1="15.748" y1="9.652" x2="15.748" y2="-9.652" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-10.16" x2="-15.24" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-9.652" x2="-15.748" y2="9.652" width="0.1524" layer="21"/>
<wire x1="15.24" y1="10.16" x2="15.748" y2="9.652" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-10.16" x2="15.748" y2="-9.652" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-9.652" x2="-15.24" y2="-10.16" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="9.652" x2="-15.24" y2="10.16" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="10.541" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-4.318" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C325-137X374">
grid 32.5 mm, outline 13.7 x 37.4 mm</description>
<wire x1="-14.2748" y1="0" x2="-12.7" y2="0" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="1.905" x2="-12.7" y2="0" width="0.4064" layer="21"/>
<wire x1="-11.811" y1="1.905" x2="-11.811" y2="0" width="0.4064" layer="21"/>
<wire x1="-11.811" y1="0" x2="14.2748" y2="0" width="0.1524" layer="21"/>
<wire x1="-11.811" y1="0" x2="-11.811" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="-12.7" y1="0" x2="-12.7" y2="-1.905" width="0.4064" layer="21"/>
<wire x1="18.542" y1="6.731" x2="18.542" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="6.731" x2="-18.542" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-6.731" x2="18.542" y2="-6.731" width="0.1524" layer="21"/>
<wire x1="18.542" y1="6.731" x2="-18.542" y2="6.731" width="0.1524" layer="21"/>
<pad name="1" x="-16.256" y="0" drill="1.1938" shape="octagon"/>
<pad name="2" x="16.256" y="0" drill="1.1938" shape="octagon"/>
<text x="-18.2372" y="7.0612" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-10.8458" y="-2.8702" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C325-162X374">
grid 32.5 mm, outline 16.2 x 37.4 mm</description>
<wire x1="18.542" y1="8.001" x2="18.542" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="8.001" x2="-18.542" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-8.001" x2="18.542" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="18.542" y1="8.001" x2="-18.542" y2="8.001" width="0.1524" layer="21"/>
<text x="-18.3642" y="8.3312" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C325-182X374">
grid 32.5 mm, outline 18.2 x 37.4 mm</description>
<wire x1="18.542" y1="9.017" x2="18.542" y2="-9.017" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="9.017" x2="-18.542" y2="-9.017" width="0.1524" layer="21"/>
<wire x1="-18.542" y1="-9.017" x2="18.542" y2="-9.017" width="0.1524" layer="21"/>
<wire x1="18.542" y1="9.017" x2="-18.542" y2="9.017" width="0.1524" layer="21"/>
<text x="-18.3642" y="9.3472" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C375-192X418">
grid 37.5 mm, outline 19.2 x 41.8 mm</description>
<wire x1="-20.32" y1="8.509" x2="20.32" y2="8.509" width="0.1524" layer="21"/>
<wire x1="20.828" y1="8.001" x2="20.828" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-8.509" x2="-20.32" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-8.001" x2="-20.828" y2="8.001" width="0.1524" layer="21"/>
<wire x1="20.32" y1="8.509" x2="20.828" y2="8.001" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-8.509" x2="20.828" y2="-8.001" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-8.001" x2="-20.32" y2="-8.509" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="8.001" x2="-20.32" y2="8.509" width="0.1524" layer="21" curve="-90"/>
<wire x1="-16.002" y1="0" x2="-7.62" y2="0" width="0.1524" layer="21"/>
<wire x1="-6.731" y1="0" x2="16.002" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-18.796" y="0" drill="1.3208" shape="octagon"/>
<pad name="2" x="18.796" y="0" drill="1.3208" shape="octagon"/>
<text x="-20.447" y="8.89" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C375-203X418">
grid 37.5 mm, outline 20.3 x 41.8 mm</description>
<wire x1="-20.32" y1="10.16" x2="20.32" y2="10.16" width="0.1524" layer="21"/>
<wire x1="20.828" y1="9.652" x2="20.828" y2="-9.652" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-10.16" x2="-20.32" y2="-10.16" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-9.652" x2="-20.828" y2="9.652" width="0.1524" layer="21"/>
<wire x1="20.32" y1="10.16" x2="20.828" y2="9.652" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-10.16" x2="20.828" y2="-9.652" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-9.652" x2="-20.32" y2="-10.16" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="9.652" x2="-20.32" y2="10.16" width="0.1524" layer="21" curve="-90"/>
<text x="-20.32" y="10.541" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C050-035X075">
grid 5 mm, outline 3.5 x 7.5 mm</description>
<wire x1="-3.683" y1="1.524" x2="-3.683" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.778" x2="3.429" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.524" x2="3.683" y2="1.524" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.778" x2="-3.429" y2="1.778" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.778" x2="3.683" y2="1.524" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.778" x2="3.683" y2="-1.524" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.524" x2="-3.429" y2="-1.778" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.524" x2="-3.429" y2="1.778" width="0.1524" layer="21" curve="-90"/>
<text x="-3.556" y="2.159" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.556" y="-3.429" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C375-155X418">
grid 37.5 mm, outline 15.5 x 41.8 mm</description>
<wire x1="-20.32" y1="7.62" x2="20.32" y2="7.62" width="0.1524" layer="21"/>
<wire x1="20.828" y1="7.112" x2="20.828" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="20.32" y1="-7.62" x2="-20.32" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-20.828" y1="-7.112" x2="-20.828" y2="7.112" width="0.1524" layer="21"/>
<wire x1="20.32" y1="7.62" x2="20.828" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="20.32" y1="-7.62" x2="20.828" y2="-7.112" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="-7.112" x2="-20.32" y2="-7.62" width="0.1524" layer="21" curve="90"/>
<wire x1="-20.828" y1="7.112" x2="-20.32" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<text x="-20.447" y="8.001" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C075-063X106">
grid 7.5 mm, outline 6.3 x 10.6 mm</description>
<wire x1="4.953" y1="3.048" x2="-4.953" y2="3.048" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="2.794" x2="-5.207" y2="-2.794" width="0.1524" layer="21"/>
<wire x1="-4.953" y1="-3.048" x2="4.953" y2="-3.048" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-2.794" x2="5.207" y2="2.794" width="0.1524" layer="21"/>
<wire x1="4.953" y1="3.048" x2="5.207" y2="2.794" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.953" y1="-3.048" x2="5.207" y2="-2.794" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="-2.794" x2="-4.953" y2="-3.048" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.207" y1="2.794" x2="-4.953" y2="3.048" width="0.1524" layer="21" curve="-90"/>
<text x="-4.826" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.635" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C275-154X316">
grid 27.5 mm, outline 15.4 x 31.6 mm</description>
<wire x1="-15.24" y1="7.62" x2="15.24" y2="7.62" width="0.1524" layer="21"/>
<wire x1="15.748" y1="7.112" x2="15.748" y2="-7.112" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-7.62" x2="-15.24" y2="-7.62" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-7.112" x2="-15.748" y2="7.112" width="0.1524" layer="21"/>
<wire x1="15.24" y1="7.62" x2="15.748" y2="7.112" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-7.62" x2="15.748" y2="-7.112" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-7.112" x2="-15.24" y2="-7.62" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="7.112" x2="-15.24" y2="7.62" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="8.001" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C275-173X316">
grid 27.5 mm, outline 17.3 x 31.6 mm</description>
<wire x1="-15.24" y1="8.509" x2="15.24" y2="8.509" width="0.1524" layer="21"/>
<wire x1="15.748" y1="8.001" x2="15.748" y2="-8.001" width="0.1524" layer="21"/>
<wire x1="15.24" y1="-8.509" x2="-15.24" y2="-8.509" width="0.1524" layer="21"/>
<wire x1="-15.748" y1="-8.001" x2="-15.748" y2="8.001" width="0.1524" layer="21"/>
<wire x1="15.24" y1="8.509" x2="15.748" y2="8.001" width="0.1524" layer="21" curve="-90"/>
<wire x1="15.24" y1="-8.509" x2="15.748" y2="-8.001" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="-8.001" x2="-15.24" y2="-8.509" width="0.1524" layer="21" curve="90"/>
<wire x1="-15.748" y1="8.001" x2="-15.24" y2="8.509" width="0.1524" layer="21" curve="-90"/>
<text x="-15.24" y="8.89" size="1.778" layer="25" ratio="10">&gt;NAME</text>
</package>
<package name="C0402K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 0204 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 1005</description>
<wire x1="-0.425" y1="0.2" x2="0.425" y2="0.2" width="0.1016" layer="51"/>
<wire x1="0.425" y1="-0.2" x2="-0.425" y2="-0.2" width="0.1016" layer="51"/>
<smd name="1" x="-0.6" y="0" dx="0.925" dy="0.74" layer="1"/>
<smd name="2" x="0.6" y="0" dx="0.925" dy="0.74" layer="1"/>
<text x="-0.5" y="0.425" size="1.016" layer="25">&gt;NAME</text>
<text x="-0.5" y="-1.45" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-0.5" y1="-0.25" x2="-0.225" y2="0.25" layer="51"/>
<rectangle x1="0.225" y1="-0.25" x2="0.5" y2="0.25" layer="51"/>
</package>
<package name="C0603K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 0603 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 1608</description>
<wire x1="-0.725" y1="0.35" x2="0.725" y2="0.35" width="0.1016" layer="51"/>
<wire x1="0.725" y1="-0.35" x2="-0.725" y2="-0.35" width="0.1016" layer="51"/>
<smd name="1" x="-0.875" y="0" dx="1.05" dy="1.08" layer="1"/>
<smd name="2" x="0.875" y="0" dx="1.05" dy="1.08" layer="1"/>
<text x="-0.8" y="0.65" size="1.016" layer="25">&gt;NAME</text>
<text x="-0.8" y="-1.65" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-0.8" y1="-0.4" x2="-0.45" y2="0.4" layer="51"/>
<rectangle x1="0.45" y1="-0.4" x2="0.8" y2="0.4" layer="51"/>
</package>
<package name="C0805K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 0805 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 2012</description>
<wire x1="-0.925" y1="0.6" x2="0.925" y2="0.6" width="0.1016" layer="51"/>
<wire x1="0.925" y1="-0.6" x2="-0.925" y2="-0.6" width="0.1016" layer="51"/>
<smd name="1" x="-1" y="0" dx="1.3" dy="1.6" layer="1"/>
<smd name="2" x="1" y="0" dx="1.3" dy="1.6" layer="1"/>
<text x="-1" y="0.875" size="1.016" layer="25">&gt;NAME</text>
<text x="-1" y="-1.9" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1" y1="-0.65" x2="-0.5" y2="0.65" layer="51"/>
<rectangle x1="0.5" y1="-0.65" x2="1" y2="0.65" layer="51"/>
</package>
<package name="C1206K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1206 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 3216</description>
<wire x1="-1.525" y1="0.75" x2="1.525" y2="0.75" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-0.75" x2="-1.525" y2="-0.75" width="0.1016" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="1.5" dy="2" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.5" dy="2" layer="1"/>
<text x="-1.6" y="1.1" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-2.1" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-0.8" x2="-1.1" y2="0.8" layer="51"/>
<rectangle x1="1.1" y1="-0.8" x2="1.6" y2="0.8" layer="51"/>
</package>
<package name="C1210K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1210 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 3225</description>
<wire x1="-1.525" y1="1.175" x2="1.525" y2="1.175" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-1.175" x2="-1.525" y2="-1.175" width="0.1016" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="1.5" dy="2.9" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.5" dy="2.9" layer="1"/>
<text x="-1.6" y="1.55" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-2.575" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-1.25" x2="-1.1" y2="1.25" layer="51"/>
<rectangle x1="1.1" y1="-1.25" x2="1.6" y2="1.25" layer="51"/>
</package>
<package name="C1812K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1812 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 4532</description>
<wire x1="-2.175" y1="1.525" x2="2.175" y2="1.525" width="0.1016" layer="51"/>
<wire x1="2.175" y1="-1.525" x2="-2.175" y2="-1.525" width="0.1016" layer="51"/>
<smd name="1" x="-2.05" y="0" dx="1.8" dy="3.7" layer="1"/>
<smd name="2" x="2.05" y="0" dx="1.8" dy="3.7" layer="1"/>
<text x="-2.25" y="1.95" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.25" y="-2.975" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.25" y1="-1.6" x2="-1.65" y2="1.6" layer="51"/>
<rectangle x1="1.65" y1="-1.6" x2="2.25" y2="1.6" layer="51"/>
</package>
<package name="C1825K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1825 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 4564</description>
<wire x1="-1.525" y1="3.125" x2="1.525" y2="3.125" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-3.125" x2="-1.525" y2="-3.125" width="0.1016" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="1.8" dy="6.9" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.8" dy="6.9" layer="1"/>
<text x="-1.6" y="3.55" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-4.625" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-3.2" x2="-1.1" y2="3.2" layer="51"/>
<rectangle x1="1.1" y1="-3.2" x2="1.6" y2="3.2" layer="51"/>
</package>
<package name="C2220K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 2220 reflow solder&lt;/b&gt;&lt;p&gt;Metric Code Size 5650</description>
<wire x1="-2.725" y1="2.425" x2="2.725" y2="2.425" width="0.1016" layer="51"/>
<wire x1="2.725" y1="-2.425" x2="-2.725" y2="-2.425" width="0.1016" layer="51"/>
<smd name="1" x="-2.55" y="0" dx="1.85" dy="5.5" layer="1"/>
<smd name="2" x="2.55" y="0" dx="1.85" dy="5.5" layer="1"/>
<text x="-2.8" y="2.95" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.8" y="-3.975" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.8" y1="-2.5" x2="-2.2" y2="2.5" layer="51"/>
<rectangle x1="2.2" y1="-2.5" x2="2.8" y2="2.5" layer="51"/>
</package>
<package name="C2225K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 2225 reflow solder&lt;/b&gt;&lt;p&gt;Metric Code Size 5664</description>
<wire x1="-2.725" y1="3.075" x2="2.725" y2="3.075" width="0.1016" layer="51"/>
<wire x1="2.725" y1="-3.075" x2="-2.725" y2="-3.075" width="0.1016" layer="51"/>
<smd name="1" x="-2.55" y="0" dx="1.85" dy="6.8" layer="1"/>
<smd name="2" x="2.55" y="0" dx="1.85" dy="6.8" layer="1"/>
<text x="-2.8" y="3.6" size="1.016" layer="25">&gt;NAME</text>
<text x="-2.8" y="-4.575" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-2.8" y1="-3.15" x2="-2.2" y2="3.15" layer="51"/>
<rectangle x1="2.2" y1="-3.15" x2="2.8" y2="3.15" layer="51"/>
</package>
<package name="HPC0201">
<description>&lt;b&gt; &lt;/b&gt;&lt;p&gt;
Source: http://www.vishay.com/docs/10129/hpc0201a.pdf</description>
<smd name="1" x="-0.18" y="0" dx="0.2" dy="0.35" layer="1"/>
<smd name="2" x="0.18" y="0" dx="0.2" dy="0.35" layer="1"/>
<text x="-0.75" y="0.74" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.785" y="-1.865" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.305" y1="-0.15" x2="0.305" y2="0.15" layer="51"/>
</package>
<package name="C0201">
<description>Source: http://www.avxcorp.com/docs/catalogs/cx5r.pdf</description>
<smd name="1" x="-0.25" y="0" dx="0.25" dy="0.35" layer="1"/>
<smd name="2" x="0.25" y="0" dx="0.25" dy="0.35" layer="1"/>
<text x="-0.635" y="0.635" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.635" y="-1.905" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.3" y1="-0.15" x2="-0.15" y2="0.15" layer="51"/>
<rectangle x1="0.15" y1="-0.15" x2="0.3" y2="0.15" layer="51"/>
<rectangle x1="-0.15" y1="0.1" x2="0.15" y2="0.15" layer="51"/>
<rectangle x1="-0.15" y1="-0.15" x2="0.15" y2="-0.1" layer="51"/>
</package>
<package name="C1808">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
Source: AVX .. aphvc.pdf</description>
<wire x1="-1.4732" y1="0.9502" x2="1.4732" y2="0.9502" width="0.1016" layer="51"/>
<wire x1="-1.4478" y1="-0.9502" x2="1.4732" y2="-0.9502" width="0.1016" layer="51"/>
<smd name="1" x="-1.95" y="0" dx="1.6" dy="2.2" layer="1"/>
<smd name="2" x="1.95" y="0" dx="1.6" dy="2.2" layer="1"/>
<text x="-2.233" y="1.827" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.233" y="-2.842" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-2.275" y1="-1.015" x2="-1.225" y2="1.015" layer="51"/>
<rectangle x1="1.225" y1="-1.015" x2="2.275" y2="1.015" layer="51"/>
</package>
<package name="C3640">
<wire x1="-3.8322" y1="5.0496" x2="3.8322" y2="5.0496" width="0.1016" layer="51"/>
<wire x1="-3.8322" y1="-5.0496" x2="3.8322" y2="-5.0496" width="0.1016" layer="51"/>
<smd name="1" x="-4.267" y="0" dx="2.6" dy="10.7" layer="1"/>
<smd name="2" x="4.267" y="0" dx="2.6" dy="10.7" layer="1"/>
<text x="-4.647" y="6.465" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.647" y="-7.255" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-4.57" y1="-5.1" x2="-3.05" y2="5.1" layer="51"/>
<rectangle x1="3.05" y1="-5.1" x2="4.5688" y2="5.1" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="R-EU">
<wire x1="-2.54" y1="-0.889" x2="2.54" y2="-0.889" width="0.254" layer="94"/>
<wire x1="2.54" y1="0.889" x2="-2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="2.54" y1="-0.889" x2="2.54" y2="0.889" width="0.254" layer="94"/>
<wire x1="-2.54" y1="-0.889" x2="-2.54" y2="0.889" width="0.254" layer="94"/>
<text x="-3.81" y="1.4986" size="1.778" layer="95">&gt;NAME</text>
<text x="-3.81" y="-3.302" size="1.778" layer="96">&gt;VALUE</text>
<pin name="2" x="5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1" rot="R180"/>
<pin name="1" x="-5.08" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
</symbol>
<symbol name="C-EU">
<wire x1="0" y1="0" x2="0" y2="-0.508" width="0.1524" layer="94"/>
<wire x1="0" y1="-2.54" x2="0" y2="-2.032" width="0.1524" layer="94"/>
<text x="1.524" y="0.381" size="1.778" layer="95">&gt;NAME</text>
<text x="1.524" y="-4.699" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-2.032" y1="-2.032" x2="2.032" y2="-1.524" layer="94"/>
<rectangle x1="-2.032" y1="-1.016" x2="2.032" y2="-0.508" layer="94"/>
<pin name="1" x="0" y="2.54" visible="off" length="short" direction="pas" swaplevel="1" rot="R270"/>
<pin name="2" x="0" y="-5.08" visible="off" length="short" direction="pas" swaplevel="1" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="R-EU_" prefix="R" uservalue="yes">
<description>&lt;B&gt;RESISTOR&lt;/B&gt;, European symbol</description>
<gates>
<gate name="G$1" symbol="R-EU" x="0" y="0"/>
</gates>
<devices>
<device name="R0402" package="R0402">
<connects>
<connect gate="G$1" pin="1" pad="1"/>
<connect gate="G$1" pin="2" pad="2"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="R0603" package="R0603">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R0805" package="R0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R0805W" package="R0805W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1005" package="R1005">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1206" package="R1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1206W" package="R1206W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1210" package="R1210">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1210W" package="R1210W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2010" package="R2010">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2010W" package="R2010W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2012" package="R2012">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2012W" package="R2012W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2512" package="R2512">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R2512W" package="R2512W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3216" package="R3216">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3216W" package="R3216W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3225" package="R3225">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R3225W" package="R3225W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R5025" package="R5025">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R5025W" package="R5025W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R6332" package="R6332">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R6332W" package="R6332W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M0805" package="M0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M1206" package="M1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M1406" package="M1406">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M2012" package="M2012">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M2309" package="M2309">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M3216" package="M3216">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M3516" package="M3516">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="M5923" package="M5923">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/5" package="0204/5">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/7" package="0204/7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0204/2V" package="0204V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/10" package="0207/10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/12" package="0207/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/15" package="0207/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/2V" package="0207/2V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/5V" package="0207/5V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0207/7" package="0207/7">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0309/10" package="0309/10">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0309/12" package="0309/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0309/V" package="0309V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0411/12" package="0411/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0411/15" package="0411/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0411/3V" package="0411V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0414/15" package="0414/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0414/5V" package="0414V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0617/17" package="0617/17">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0617/22" package="0617/22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0617/5V" package="0617V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0922/22" package="0922/22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0613/5V" package="P0613V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0613/15" package="P0613/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0817/22" package="P0817/22">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0817/7V" package="P0817V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V234/12" package="V234/12">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V235/17" package="V235/17">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="V526-0" package="V526-0">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0102R" package="MINI_MELF-0102R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0102W" package="MINI_MELF-0102W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0204R" package="MINI_MELF-0204R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0204W" package="MINI_MELF-0204W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0207R" package="MINI_MELF-0207R">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0207W" package="MINI_MELF-0207W">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="0922V" package="0922V">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="RDH/15" package="RDH/15">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="MELF0102AX" package="MINI_MELF-0102AX">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R0201" package="R0201">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VTA52" package="VTA52">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VTA53" package="VTA53">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VTA54" package="VTA54">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VTA55" package="VTA55">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VTA56" package="VTA56">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VMTA55" package="VMTA55">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="VMTB60" package="VMTB60">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R4527" package="R4527">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WSC0001" package="WSC0001">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WSC0002" package="WSC0002">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WSC01/2" package="WSC01/2">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WSC2515" package="WSC2515">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WSC4527" package="WSC4527">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="WSC6927" package="WSC6927">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="R1218" package="R1218">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="1812X7R" package="1812X7R">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="C-EU" prefix="C" uservalue="yes">
<description>&lt;B&gt;CAPACITOR&lt;/B&gt;, European symbol</description>
<gates>
<gate name="G$1" symbol="C-EU" x="0" y="0"/>
</gates>
<devices>
<device name="C0402" package="C0402">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0504" package="C0504">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0603" package="C0603">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0805" package="C0805">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1005" package="C1005">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1206" package="C1206">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1210" package="C1210">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1310" package="C1310">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1608" package="C1608">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1812" package="C1812">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1825" package="C1825">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C2012" package="C2012">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C3216" package="C3216">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C3225" package="C3225">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C4532" package="C4532">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C4564" package="C4564">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-024X044" package="C025-024X044">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-025X050" package="C025-025X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-030X050" package="C025-030X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-040X050" package="C025-040X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-050X050" package="C025-050X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025-060X050" package="C025-060X050">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C025_050-024X070" package="C025_050-024X070">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025_050-025X075" package="C025_050-025X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025_050-035X075" package="C025_050-035X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025_050-045X075" package="C025_050-045X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="025_050-055X075" package="C025_050-055X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-024X044" package="C050-024X044">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-025X075" package="C050-025X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-045X075" package="C050-045X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-030X075" package="C050-030X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-050X075" package="C050-050X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-055X075" package="C050-055X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-075X075" package="C050-075X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050H075X075" package="C050H075X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="075-032X103" package="C075-032X103">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="075-042X103" package="C075-042X103">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="075-052X106" package="C075-052X106">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="102-043X133" package="C102-043X133">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="102-054X133" package="C102-054X133">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="102-064X133" package="C102-064X133">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="102_152-062X184" package="C102_152-062X184">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-054X183" package="C150-054X183">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-064X183" package="C150-064X183">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-072X183" package="C150-072X183">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-084X183" package="C150-084X183">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="150-091X182" package="C150-091X182">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-062X268" package="C225-062X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-074X268" package="C225-074X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-087X268" package="C225-087X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-108X268" package="C225-108X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="225-113X268" package="C225-113X268">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-093X316" package="C275-093X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-113X316" package="C275-113X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-134X316" package="C275-134X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-205X316" package="C275-205X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="325-137X374" package="C325-137X374">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="325-162X374" package="C325-162X374">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="325-182X374" package="C325-182X374">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="375-192X418" package="C375-192X418">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="375-203X418" package="C375-203X418">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="050-035X075" package="C050-035X075">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="375-155X418" package="C375-155X418">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="075-063X106" package="C075-063X106">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-154X316" package="C275-154X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="275-173X316" package="C275-173X316">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0402K" package="C0402K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0603K" package="C0603K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0805K" package="C0805K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1206K" package="C1206K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1210K" package="C1210K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1812K" package="C1812K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1825K" package="C1825K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C2220K" package="C2220K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C2225K" package="C2225K">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="HPC0201" package="HPC0201">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C0201" package="C0201">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C1808" package="C1808">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="C3640" package="C3640">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="relay">
<description>&lt;b&gt;Relays&lt;/b&gt;&lt;p&gt;
&lt;ul&gt;
&lt;li&gt;Eichhoff
&lt;li&gt;Finder
&lt;li&gt;Fujitsu
&lt;li&gt;HAMLIN
&lt;li&gt;OMRON
&lt;li&gt;Matsushita
&lt;li&gt;NAiS
&lt;li&gt;Siemens
&lt;li&gt;Schrack
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="JW1C">
<description>&lt;b&gt;Power relay&lt;/b&gt;&lt;p&gt;
Source: Panasonic Electric Works Co., Ltd. / jw.catalog.pdf</description>
<wire x1="-12.759" y1="-6.604" x2="15.9" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="15.9" y1="6.477" x2="15.9" y2="-6.604" width="0.1524" layer="21"/>
<wire x1="15.9" y1="6.477" x2="-12.759" y2="6.477" width="0.1524" layer="21"/>
<wire x1="-12.759" y1="-6.604" x2="-12.759" y2="6.477" width="0.1524" layer="21"/>
<wire x1="-10" y1="2.0574" x2="-10" y2="1.1938" width="0.1524" layer="21"/>
<wire x1="-8.1204" y1="1.1938" x2="-8.1204" y2="-1.3208" width="0.254" layer="21"/>
<wire x1="-11.8796" y1="-1.3208" x2="-11.8796" y2="1.1938" width="0.254" layer="21"/>
<wire x1="-11.8796" y1="1.1938" x2="-10" y2="1.1938" width="0.254" layer="21"/>
<wire x1="-10" y1="1.1938" x2="-8.7554" y2="1.1938" width="0.254" layer="21"/>
<wire x1="-11.2446" y1="-1.3208" x2="-11.8796" y2="-1.3208" width="0.254" layer="21"/>
<wire x1="-8.7554" y1="1.1938" x2="-11.2446" y2="-1.3208" width="0.1524" layer="21"/>
<wire x1="-8.7554" y1="1.1938" x2="-8.1204" y2="1.1938" width="0.254" layer="21"/>
<wire x1="-8.1204" y1="-1.3208" x2="-10" y2="-1.3208" width="0.254" layer="21"/>
<wire x1="-10" y1="-1.3208" x2="-10" y2="-1.9304" width="0.1524" layer="21"/>
<wire x1="-10" y1="-1.3208" x2="-11.2446" y2="-1.3208" width="0.254" layer="21"/>
<pad name="8" x="-10" y="3.81" drill="1.3208" diameter="1.9"/>
<pad name="1" x="-10" y="-3.683" drill="1.3208" diameter="1.9"/>
<pad name="6" x="10" y="3.81" drill="1.3208" diameter="1.9"/>
<pad name="4" x="13.5" y="-3.683" drill="1.3208" diameter="1.9"/>
<text x="-13.0175" y="-6.35" size="1.778" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-6.0325" y="0" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<pad name="2" x="6.5" y="-3.683" drill="1.3208" diameter="1.9"/>
<wire x1="10.795" y1="-0.3175" x2="13.335" y2="-0.3175" width="0.1524" layer="21"/>
<wire x1="13.335" y1="-0.3175" x2="13.335" y2="-2.2225" width="0.1524" layer="21"/>
<wire x1="6.6675" y1="-0.3175" x2="6.6675" y2="-2.2225" width="0.1524" layer="21"/>
<wire x1="6.6675" y1="-0.3175" x2="9.525" y2="-0.3175" width="0.1524" layer="21"/>
<wire x1="9.525" y1="-0.635" x2="10.16" y2="0.9525" width="0.1524" layer="21"/>
<wire x1="10.16" y1="2.2225" x2="10.16" y2="0.9525" width="0.1524" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="K">
<wire x1="-3.81" y1="-1.905" x2="-1.905" y2="-1.905" width="0.254" layer="94"/>
<wire x1="3.81" y1="-1.905" x2="3.81" y2="1.905" width="0.254" layer="94"/>
<wire x1="3.81" y1="1.905" x2="1.905" y2="1.905" width="0.254" layer="94"/>
<wire x1="-3.81" y1="1.905" x2="-3.81" y2="-1.905" width="0.254" layer="94"/>
<wire x1="0" y1="-2.54" x2="0" y2="-1.905" width="0.1524" layer="94"/>
<wire x1="0" y1="-1.905" x2="3.81" y2="-1.905" width="0.254" layer="94"/>
<wire x1="0" y1="2.54" x2="0" y2="1.905" width="0.1524" layer="94"/>
<wire x1="0" y1="1.905" x2="-3.81" y2="1.905" width="0.254" layer="94"/>
<wire x1="-1.905" y1="-1.905" x2="1.905" y2="1.905" width="0.1524" layer="94"/>
<wire x1="-1.905" y1="-1.905" x2="0" y2="-1.905" width="0.254" layer="94"/>
<wire x1="1.905" y1="1.905" x2="0" y2="1.905" width="0.254" layer="94"/>
<text x="1.27" y="2.921" size="1.778" layer="96">&gt;VALUE</text>
<text x="1.27" y="5.08" size="1.778" layer="95">&gt;PART</text>
<pin name="2" x="0" y="-5.08" visible="pad" length="short" direction="pas" rot="R90"/>
<pin name="1" x="0" y="5.08" visible="pad" length="short" direction="pas" rot="R270"/>
</symbol>
<symbol name="U">
<wire x1="3.175" y1="5.08" x2="1.905" y2="5.08" width="0.254" layer="94"/>
<wire x1="-3.175" y1="5.08" x2="-1.905" y2="5.08" width="0.254" layer="94"/>
<wire x1="0" y1="1.27" x2="2.54" y2="5.715" width="0.254" layer="94"/>
<wire x1="0" y1="1.27" x2="0" y2="0" width="0.254" layer="94"/>
<circle x="0" y="1.27" radius="0.127" width="0.4064" layer="94"/>
<text x="2.54" y="0" size="1.778" layer="95">&gt;PART</text>
<pin name="O" x="5.08" y="5.08" visible="pad" length="short" direction="pas" rot="R180"/>
<pin name="S" x="-5.08" y="5.08" visible="pad" length="short" direction="pas"/>
<pin name="P" x="0" y="-2.54" visible="pad" length="short" direction="pas" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="JW1C" prefix="K">
<gates>
<gate name="_" symbol="K" x="0" y="0" addlevel="must"/>
<gate name="1" symbol="U" x="22.86" y="0" addlevel="always"/>
</gates>
<devices>
<device name="" package="JW1C">
<connects>
<connect gate="1" pin="O" pad="2"/>
<connect gate="1" pin="P" pad="6"/>
<connect gate="1" pin="S" pad="4"/>
<connect gate="_" pin="1" pad="1"/>
<connect gate="_" pin="2" pad="8"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="con-phoenix-508">
<description>&lt;b&gt;Phoenix Connectors&lt;/b&gt;&lt;p&gt;
Grid 5.08 mm&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;pho508a.lbr
&lt;li&gt;pho508b.lbr
&lt;li&gt;pho508c.lbr
&lt;li&gt;pho508d.lbr
&lt;li&gt;pho508e.lbr
&lt;/ul&gt;
<packages>
<package name="MKDSN1,5/3-5,08">
<description>&lt;b&gt;MKDSN 1,5/ 3-5,08&lt;/b&gt; Printklemme&lt;p&gt;
Nennstrom: 13,5 A&lt;br&gt;
Nennspannung: 250 V&lt;br&gt;
Rastermaß: 5,08 mm&lt;br&gt;
Polzahl: 3&lt;br&gt;
Anschlussart: Schraubanschluss&lt;br&gt;
Montage: Löten&lt;br&gt;
Anschlussrichtung Leiter/Platine: 0 °&lt;br&gt;
Artikelnummer: 1729131&lt;br&gt;
Source: http://eshop.phoenixcontact.com .. 1729131.pdf</description>
<wire x1="-10.1811" y1="-4.05" x2="5.0589" y2="-4.05" width="0.2032" layer="21"/>
<wire x1="-10.1811" y1="2.5243" x2="5.0589" y2="2.5243" width="0.2032" layer="21"/>
<wire x1="-7.8011" y1="-0.63" x2="-8.7141" y2="-1.543" width="0.2032" layer="51"/>
<wire x1="-10.1811" y1="-1.9555" x2="-10.1811" y2="-2.4479" width="0.2032" layer="21"/>
<wire x1="-10.1811" y1="-3.327" x2="-10.3098" y2="-3.327" width="0.2032" layer="21"/>
<wire x1="-10.3098" y1="-2.913" x2="-10.1811" y2="-2.913" width="0.2032" layer="21"/>
<wire x1="-10.1811" y1="-3.1279" x2="-10.1811" y2="-2.913" width="0.2032" layer="21"/>
<wire x1="-10.1811" y1="-3.327" x2="-10.1811" y2="-3.1279" width="0.2032" layer="21"/>
<wire x1="-10.7511" y1="-2.763" x2="-10.4881" y2="-2.763" width="0.2032" layer="21"/>
<wire x1="-10.7511" y1="-3.477" x2="-10.4881" y2="-3.477" width="0.2032" layer="21"/>
<wire x1="-10.1811" y1="-2.913" x2="-10.1811" y2="-2.4479" width="0.2032" layer="21"/>
<wire x1="-10.3098" y1="-3.327" x2="-10.4881" y2="-3.477" width="0.2032" layer="21"/>
<wire x1="-10.7511" y1="-2.763" x2="-10.7511" y2="-3.477" width="0.2032" layer="21"/>
<wire x1="-10.1811" y1="2.5243" x2="-10.1811" y2="2.0413" width="0.2032" layer="21"/>
<wire x1="-10.1811" y1="-1.9555" x2="-10.1811" y2="2.0413" width="0.2032" layer="21"/>
<wire x1="-10.4881" y1="-2.763" x2="-10.3098" y2="-2.913" width="0.2032" layer="21"/>
<wire x1="5.0589" y1="-2.4479" x2="-10.1811" y2="-2.4479" width="0.2032" layer="21"/>
<wire x1="-7.6411" y1="-0.47" x2="-7.8011" y2="-0.63" width="0.2032" layer="51"/>
<wire x1="-8.2801" y1="-0.119" x2="-7.6411" y2="0.52" width="0.2032" layer="51"/>
<wire x1="-9.2091" y1="-1.048" x2="-8.2801" y2="-0.119" width="0.2032" layer="51"/>
<wire x1="-4.1291" y1="-1.048" x2="-3.2001" y2="-0.119" width="0.2032" layer="51"/>
<wire x1="5.0589" y1="-1.9555" x2="5.0589" y2="-2.4479" width="0.2032" layer="21"/>
<wire x1="-2.7211" y1="-0.63" x2="-3.6341" y2="-1.543" width="0.2032" layer="51"/>
<wire x1="0.9509" y1="-1.048" x2="1.8799" y2="-0.119" width="0.2032" layer="51"/>
<wire x1="2.3589" y1="-0.63" x2="1.4459" y2="-1.543" width="0.2032" layer="51"/>
<wire x1="-3.2001" y1="-0.119" x2="-2.5611" y2="0.52" width="0.2032" layer="51"/>
<wire x1="-2.5611" y1="-0.47" x2="-2.7211" y2="-0.63" width="0.2032" layer="51"/>
<wire x1="-0.9931" y1="1.098" x2="-1.9311" y2="0.16" width="0.2032" layer="51"/>
<wire x1="4.0869" y1="1.098" x2="3.1489" y2="0.16" width="0.2032" layer="51"/>
<wire x1="-2.4421" y1="0.639" x2="-1.4881" y2="1.593" width="0.2032" layer="51"/>
<wire x1="2.6379" y1="0.639" x2="3.5919" y2="1.593" width="0.2032" layer="51"/>
<wire x1="2.5189" y1="0.52" x2="2.6379" y2="0.639" width="0.2032" layer="51"/>
<wire x1="1.8799" y1="-0.119" x2="2.5189" y2="0.52" width="0.2032" layer="51"/>
<wire x1="-1.9311" y1="0.16" x2="-2.5611" y2="-0.47" width="0.2032" layer="51"/>
<wire x1="-2.5611" y1="0.52" x2="-2.4421" y2="0.639" width="0.2032" layer="51"/>
<wire x1="3.1489" y1="0.16" x2="2.5189" y2="-0.47" width="0.2032" layer="51"/>
<wire x1="2.5189" y1="-0.47" x2="2.3589" y2="-0.63" width="0.2032" layer="51"/>
<wire x1="-7.0111" y1="0.16" x2="-7.6411" y2="-0.47" width="0.2032" layer="51"/>
<wire x1="-7.6411" y1="0.52" x2="-7.5221" y2="0.639" width="0.2032" layer="51"/>
<wire x1="-7.5221" y1="0.639" x2="-6.5681" y2="1.593" width="0.2032" layer="51"/>
<wire x1="-6.0731" y1="1.098" x2="-7.0111" y2="0.16" width="0.2032" layer="51"/>
<wire x1="-10.1811" y1="-3.1279" x2="5.0589" y2="-3.1279" width="0.2032" layer="21"/>
<wire x1="5.0589" y1="-3.1279" x2="5.0589" y2="-2.4479" width="0.2032" layer="21"/>
<wire x1="5.0589" y1="-1.9555" x2="5.0589" y2="2.0413" width="0.2032" layer="21"/>
<wire x1="5.0589" y1="2.5243" x2="5.0589" y2="2.0413" width="0.2032" layer="21"/>
<wire x1="5.0589" y1="2.5243" x2="5.0589" y2="4.05" width="0.2032" layer="21"/>
<wire x1="-10.1811" y1="-3.75" x2="-10.1811" y2="-3.327" width="0.2032" layer="21"/>
<wire x1="5.0589" y1="-3.75" x2="5.0589" y2="-3.1279" width="0.2032" layer="21"/>
<wire x1="-10.1811" y1="4.05" x2="5.0589" y2="4.05" width="0.2032" layer="21"/>
<wire x1="-10.1811" y1="2.5243" x2="-10.1811" y2="4.05" width="0.2032" layer="21"/>
<wire x1="5.0589" y1="-3.75" x2="-10.1811" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-10.1811" y1="-3.75" x2="-10.1811" y2="-4.05" width="0.2032" layer="21"/>
<wire x1="5.0589" y1="-3.75" x2="5.0589" y2="-4.05" width="0.2032" layer="21"/>
<wire x1="-8.2801" y1="-0.119" x2="-7.8011" y2="-0.63" width="0.2032" layer="51" curve="65.201851"/>
<wire x1="-3.2001" y1="-0.119" x2="-2.7211" y2="-0.63" width="0.2032" layer="51" curve="65.201851"/>
<wire x1="3.1489" y1="0.16" x2="2.6379" y2="0.639" width="0.2032" layer="51" curve="65.201851"/>
<wire x1="-1.9311" y1="0.16" x2="-2.4421" y2="0.639" width="0.2032" layer="51" curve="65.201851"/>
<wire x1="1.8799" y1="-0.119" x2="2.3589" y2="-0.63" width="0.2032" layer="51" curve="65.201851"/>
<wire x1="-7.0111" y1="0.16" x2="-7.5221" y2="0.639" width="0.2032" layer="51" curve="65.201851"/>
<circle x="-7.6411" y="0.025" radius="1.915" width="0.2032" layer="21"/>
<circle x="-2.5611" y="0.025" radius="1.915" width="0.2032" layer="21"/>
<circle x="2.5189" y="0.025" radius="1.915" width="0.2032" layer="21"/>
<pad name="1" x="-7.6411" y="0.025" drill="1.3" diameter="2"/>
<pad name="2" x="-2.5611" y="0.025" drill="1.3" diameter="2"/>
<pad name="3" x="2.5189" y="0.025" drill="1.3" diameter="2"/>
<text x="-9.8311" y="4.445" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.81" y="4.445" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="MKDSN1,5/2-5,08">
<description>&lt;b&gt;MKDSN 1,5/ 2-5,08&lt;/b&gt; Printklemme&lt;p&gt;
Polzahl: 2&lt;br&gt;
Artikelnummer: 1729128&lt;br&gt;
Source: http://eshop.phoenixcontact.com .. 1729128.pdf</description>
<wire x1="-5.1011" y1="-4.05" x2="5.0589" y2="-4.05" width="0.2032" layer="21"/>
<wire x1="-5.1011" y1="2.5243" x2="5.0589" y2="2.5243" width="0.2032" layer="21"/>
<wire x1="-5.1011" y1="-1.9555" x2="-5.1011" y2="-2.4479" width="0.2032" layer="21"/>
<wire x1="-5.1011" y1="-3.327" x2="-5.2298" y2="-3.327" width="0.2032" layer="21"/>
<wire x1="-5.2298" y1="-2.913" x2="-5.1011" y2="-2.913" width="0.2032" layer="21"/>
<wire x1="-5.1011" y1="-3.1279" x2="-5.1011" y2="-2.913" width="0.2032" layer="21"/>
<wire x1="-5.1011" y1="-3.327" x2="-5.1011" y2="-3.1279" width="0.2032" layer="21"/>
<wire x1="-5.6711" y1="-2.763" x2="-5.4081" y2="-2.763" width="0.2032" layer="21"/>
<wire x1="-5.6711" y1="-3.477" x2="-5.4081" y2="-3.477" width="0.2032" layer="21"/>
<wire x1="-5.1011" y1="-2.913" x2="-5.1011" y2="-2.4479" width="0.2032" layer="21"/>
<wire x1="-5.2298" y1="-3.327" x2="-5.4081" y2="-3.477" width="0.2032" layer="21"/>
<wire x1="-5.6711" y1="-2.763" x2="-5.6711" y2="-3.477" width="0.2032" layer="21"/>
<wire x1="-5.1011" y1="2.5243" x2="-5.1011" y2="2.0413" width="0.2032" layer="21"/>
<wire x1="-5.1011" y1="-1.9555" x2="-5.1011" y2="2.0413" width="0.2032" layer="21"/>
<wire x1="-5.4081" y1="-2.763" x2="-5.2298" y2="-2.913" width="0.2032" layer="21"/>
<wire x1="5.0589" y1="-2.4479" x2="-5.1011" y2="-2.4479" width="0.2032" layer="21"/>
<wire x1="-5.1011" y1="-3.1279" x2="5.0589" y2="-3.1279" width="0.2032" layer="21"/>
<wire x1="-5.1011" y1="-3.75" x2="-5.1011" y2="-3.327" width="0.2032" layer="21"/>
<wire x1="-5.1011" y1="4.05" x2="5.0589" y2="4.05" width="0.2032" layer="21"/>
<wire x1="-5.1011" y1="2.5243" x2="-5.1011" y2="4.05" width="0.2032" layer="21"/>
<wire x1="5.0589" y1="-3.75" x2="-5.1011" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-5.1011" y1="-3.75" x2="-5.1011" y2="-4.05" width="0.2032" layer="21"/>
<pad name="1" x="-2.5611" y="0.025" drill="1.3" diameter="2"/>
<pad name="2" x="2.5189" y="0.025" drill="1.3" diameter="2"/>
<text x="-4.7511" y="4.445" size="1.27" layer="25">&gt;NAME</text>
<text x="6.985" y="-3.81" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
</package>
</packages>
<symbols>
<symbol name="KLV">
<circle x="1.27" y="0" radius="1.27" width="0.254" layer="94"/>
<text x="3.048" y="-0.889" size="1.778" layer="95">&gt;NAME</text>
<text x="-2.54" y="-3.683" size="1.778" layer="96">&gt;VALUE</text>
<pin name="KL" x="-2.54" y="0" visible="off" length="short" direction="pas"/>
</symbol>
<symbol name="KL">
</symbol>
</symbols>
<devicesets>
<deviceset name="MKDSN1,5/3-5,08" prefix="X">
<gates>
<gate name="-1" symbol="KLV" x="0" y="0" addlevel="always" swaplevel="1"/>
<gate name="-2" symbol="KL" x="0" y="-5.08" addlevel="always" swaplevel="1"/>
<gate name="-3" symbol="KL" x="0" y="-10.16" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="" package="MKDSN1,5/3-5,08">
<connects>
<connect gate="-1" pin="KL" pad="1"/>
<connect gate="-2" pin="KL" pad="2"/>
<connect gate="-3" pin="KL" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MKDSN1,5/2-5,08" prefix="X">
<gates>
<gate name="-2" symbol="KLV" x="0" y="-5.08" addlevel="always" swaplevel="1"/>
</gates>
<devices>
<device name="" package="MKDSN1,5/2-5,08">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="transistor-npn">
<description>&lt;b&gt;NPN Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="SOT223">
<description>&lt;b&gt;Small Outline Transistor&lt;/b&gt;</description>
<wire x1="3.2766" y1="1.778" x2="3.2766" y2="-1.778" width="0.2032" layer="21"/>
<wire x1="3.2766" y1="-1.778" x2="-3.2766" y2="-1.778" width="0.2032" layer="21"/>
<wire x1="-3.2766" y1="-1.778" x2="-3.2766" y2="1.778" width="0.2032" layer="21"/>
<wire x1="-3.2766" y1="1.778" x2="3.2766" y2="1.778" width="0.2032" layer="21"/>
<smd name="1" x="-2.3114" y="-3.0988" dx="1.2192" dy="2.2352" layer="1"/>
<smd name="2" x="0" y="-3.0988" dx="1.2192" dy="2.2352" layer="1"/>
<smd name="3" x="2.3114" y="-3.0988" dx="1.2192" dy="2.2352" layer="1"/>
<smd name="4" x="0" y="3.099" dx="3.6" dy="2.2" layer="1"/>
<text x="1.0208" y="-4.318" size="0.8128" layer="21" ratio="12">3</text>
<text x="1.905" y="2.54" size="0.8128" layer="21" ratio="12">4</text>
<text x="-3.4526" y="-4.318" size="0.8128" layer="21" ratio="12">1</text>
<text x="-1.2906" y="-4.3274" size="0.8128" layer="21" ratio="12">2</text>
<text x="-2.54" y="0.0508" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-1.3208" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6002" y1="1.8034" x2="1.6002" y2="3.6576" layer="51"/>
<rectangle x1="-0.4318" y1="-3.6576" x2="0.4318" y2="-1.8034" layer="51"/>
<rectangle x1="-2.7432" y1="-3.6576" x2="-1.8796" y2="-1.8034" layer="51"/>
<rectangle x1="1.8796" y1="-3.6576" x2="2.7432" y2="-1.8034" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="NPN">
<wire x1="2.54" y1="2.54" x2="0.508" y2="1.524" width="0.1524" layer="94"/>
<wire x1="1.778" y1="-1.524" x2="2.54" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="1.27" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="1.778" y2="-1.524" width="0.1524" layer="94"/>
<wire x1="1.54" y1="-2.04" x2="0.308" y2="-1.424" width="0.1524" layer="94"/>
<wire x1="1.524" y1="-2.413" x2="2.286" y2="-2.413" width="0.254" layer="94"/>
<wire x1="2.286" y1="-2.413" x2="1.778" y2="-1.778" width="0.254" layer="94"/>
<wire x1="1.778" y1="-1.778" x2="1.524" y2="-2.286" width="0.254" layer="94"/>
<wire x1="1.524" y1="-2.286" x2="1.905" y2="-2.286" width="0.254" layer="94"/>
<wire x1="1.905" y1="-2.286" x2="1.778" y2="-2.032" width="0.254" layer="94"/>
<text x="-10.16" y="7.62" size="1.778" layer="95">&gt;NAME</text>
<text x="-10.16" y="5.08" size="1.778" layer="96">&gt;VALUE</text>
<rectangle x1="-0.254" y1="-2.54" x2="0.508" y2="2.54" layer="94"/>
<pin name="B" x="-2.54" y="0" visible="off" length="short" direction="pas" swaplevel="1"/>
<pin name="E" x="2.54" y="-5.08" visible="off" length="short" direction="pas" swaplevel="3" rot="R90"/>
<pin name="C" x="2.54" y="5.08" visible="off" length="short" direction="pas" swaplevel="2" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="BCP56">
<gates>
<gate name="BCP56" symbol="NPN" x="0" y="0"/>
</gates>
<devices>
<device name="" package="SOT223">
<connects>
<connect gate="BCP56" pin="B" pad="1"/>
<connect gate="BCP56" pin="C" pad="2 4"/>
<connect gate="BCP56" pin="E" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="transistor-power">
<description>&lt;b&gt;Power Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="D2PACK">
<description>&lt;b&gt;D2PACK&lt;/b&gt;&lt;p&gt;
INTERNATIONAL RECTIFIER, irg4bc15ud-s.pdf</description>
<wire x1="-5.1308" y1="-4.0894" x2="5.1308" y2="-4.0894" width="0.254" layer="21"/>
<wire x1="5.1308" y1="-4.0894" x2="5.1308" y2="4.445" width="0.254" layer="51"/>
<wire x1="5.1308" y1="4.445" x2="3.1242" y2="5.8166" width="0.254" layer="51"/>
<wire x1="3.1242" y1="5.8166" x2="-3.3782" y2="5.8166" width="0.254" layer="51"/>
<wire x1="-3.3782" y1="5.8166" x2="-5.1308" y2="4.699" width="0.254" layer="51"/>
<wire x1="-5.1308" y1="4.699" x2="-5.1308" y2="4.445" width="0.254" layer="51"/>
<wire x1="-5.1308" y1="4.445" x2="-5.1308" y2="-4.0894" width="0.254" layer="51"/>
<wire x1="-5.1308" y1="4.445" x2="5.1308" y2="4.445" width="0.254" layer="51"/>
<wire x1="-5.1308" y1="-4.0894" x2="-5.1308" y2="-2.3114" width="0.254" layer="21"/>
<wire x1="5.1308" y1="-4.0894" x2="5.1308" y2="-2.3114" width="0.254" layer="21"/>
<smd name="1" x="-2.54" y="-8.89" dx="2.0828" dy="3.81" layer="1"/>
<smd name="3" x="2.54" y="-8.89" dx="2.0828" dy="3.81" layer="1"/>
<smd name="2" x="0" y="2.54" dx="11.43" dy="8.89" layer="1"/>
<text x="-5.588" y="7.239" size="1.27" layer="25">&gt;NAME</text>
<text x="-3.81" y="-3.429" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.0988" y1="-9.525" x2="-1.9812" y2="-8.1026" layer="51"/>
<rectangle x1="-3.2512" y1="-8.1534" x2="-1.8288" y2="-6.731" layer="51"/>
<rectangle x1="-3.2512" y1="-6.731" x2="-1.8288" y2="-4.2418" layer="21"/>
<rectangle x1="1.9812" y1="-9.525" x2="3.0988" y2="-8.1026" layer="51"/>
<rectangle x1="1.8288" y1="-8.1534" x2="3.2512" y2="-6.731" layer="51"/>
<rectangle x1="1.8288" y1="-6.731" x2="3.2512" y2="-4.2418" layer="21"/>
<rectangle x1="-0.7112" y1="-6.731" x2="0.7112" y2="-4.2418" layer="21"/>
</package>
<package name="TO-251AA">
<description>TO-251AA
&lt;p&gt;www.irf.com
&lt;p&gt;IRLR2905.pdf</description>
<pad name="1" x="0" y="0" drill="1.27"/>
<pad name="2" x="2.286" y="0" drill="1.27"/>
<pad name="3" x="4.572" y="0" drill="1.27"/>
<wire x1="-1.016" y1="1.778" x2="5.588" y2="1.778" width="0.6096" layer="21"/>
<wire x1="5.588" y1="1.778" x2="5.588" y2="-1.016" width="0.127" layer="21"/>
<wire x1="5.588" y1="-1.016" x2="-1.016" y2="-1.016" width="0.127" layer="21"/>
<wire x1="-1.016" y1="-1.016" x2="-1.016" y2="1.778" width="0.127" layer="21"/>
</package>
<package name="D-PAK_TO252AA">
<description>&lt;b&gt;D-Pak (TO-252AA) Package&lt;/b&gt;&lt;p&gt;
Source: http://www.irf.com/product-info/datasheets/data/irfr5305pbf.pdf</description>
<wire x1="3.275" y1="-2.15" x2="-3.275" y2="-2.15" width="0.2032" layer="21"/>
<wire x1="-3.275" y1="-2.15" x2="-3.275" y2="3.325" width="0.2032" layer="21"/>
<wire x1="-3.275" y1="3.325" x2="-2.775" y2="3.825" width="0.2032" layer="21"/>
<wire x1="-2.775" y1="3.825" x2="2.775" y2="3.825" width="0.2032" layer="21"/>
<wire x1="2.775" y1="3.825" x2="3.275" y2="3.325" width="0.2032" layer="21"/>
<wire x1="3.275" y1="3.325" x2="3.275" y2="-2.15" width="0.2032" layer="21"/>
<wire x1="-2.5654" y1="3.937" x2="-2.5654" y2="4.6482" width="0.2032" layer="51"/>
<wire x1="-2.5654" y1="4.6482" x2="-2.1082" y2="5.1054" width="0.2032" layer="51"/>
<wire x1="-2.1082" y1="5.1054" x2="2.1082" y2="5.1054" width="0.2032" layer="51"/>
<wire x1="2.1082" y1="5.1054" x2="2.5654" y2="4.6482" width="0.2032" layer="51"/>
<wire x1="2.5654" y1="4.6482" x2="2.5654" y2="3.937" width="0.2032" layer="51"/>
<wire x1="2.5654" y1="3.937" x2="-2.5654" y2="3.937" width="0.2032" layer="51"/>
<smd name="4" x="0" y="2.5" dx="5.4" dy="6.2" layer="1"/>
<smd name="1" x="-2.28" y="-4.8" dx="1" dy="1.6" layer="1"/>
<smd name="3" x="2.28" y="-4.8" dx="1" dy="1.6" layer="1"/>
<text x="-3.81" y="-2.54" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="5.08" y="-2.54" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.7178" y1="-5.1562" x2="-1.8542" y2="-2.2606" layer="51"/>
<rectangle x1="1.8542" y1="-5.1562" x2="2.7178" y2="-2.2606" layer="51"/>
<rectangle x1="-0.4318" y1="-3.0226" x2="0.4318" y2="-2.2606" layer="21"/>
<polygon width="0.1998" layer="51">
<vertex x="-2.5654" y="3.937"/>
<vertex x="-2.5654" y="4.6482"/>
<vertex x="-2.1082" y="5.1054"/>
<vertex x="2.1082" y="5.1054"/>
<vertex x="2.5654" y="4.6482"/>
<vertex x="2.5654" y="3.937"/>
</polygon>
</package>
</packages>
<symbols>
<symbol name="MFNS">
<wire x1="-1.1176" y1="2.413" x2="-1.1176" y2="-2.54" width="0.254" layer="94"/>
<wire x1="-1.1176" y1="-2.54" x2="-2.54" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="2.54" y1="1.905" x2="0.5334" y2="1.905" width="0.1524" layer="94"/>
<wire x1="2.54" y1="0" x2="2.54" y2="-1.905" width="0.1524" layer="94"/>
<wire x1="0.508" y1="-1.905" x2="2.54" y2="-1.905" width="0.1524" layer="94"/>
<wire x1="2.54" y1="2.54" x2="2.54" y2="1.905" width="0.1524" layer="94"/>
<wire x1="2.54" y1="1.905" x2="5.08" y2="1.905" width="0.1524" layer="94"/>
<wire x1="5.08" y1="1.905" x2="5.08" y2="0.762" width="0.1524" layer="94"/>
<wire x1="5.08" y1="0.762" x2="5.08" y2="-1.905" width="0.1524" layer="94"/>
<wire x1="5.08" y1="-1.905" x2="2.54" y2="-1.905" width="0.1524" layer="94"/>
<wire x1="2.54" y1="-1.905" x2="2.54" y2="-2.54" width="0.1524" layer="94"/>
<wire x1="5.08" y1="0.762" x2="4.445" y2="-0.635" width="0.1524" layer="94"/>
<wire x1="4.445" y1="-0.635" x2="5.715" y2="-0.635" width="0.1524" layer="94"/>
<wire x1="5.715" y1="-0.635" x2="5.08" y2="0.762" width="0.1524" layer="94"/>
<wire x1="4.445" y1="0.762" x2="5.08" y2="0.762" width="0.1524" layer="94"/>
<wire x1="5.08" y1="0.762" x2="5.715" y2="0.762" width="0.1524" layer="94"/>
<wire x1="5.715" y1="0.762" x2="5.969" y2="1.016" width="0.1524" layer="94"/>
<wire x1="4.445" y1="0.762" x2="4.191" y2="0.508" width="0.1524" layer="94"/>
<wire x1="0.508" y1="0" x2="1.778" y2="-0.508" width="0.1524" layer="94"/>
<wire x1="1.778" y1="-0.508" x2="1.778" y2="0.508" width="0.1524" layer="94"/>
<wire x1="1.778" y1="0.508" x2="0.508" y2="0" width="0.1524" layer="94"/>
<wire x1="1.651" y1="0" x2="2.54" y2="0" width="0.1524" layer="94"/>
<wire x1="1.651" y1="0.254" x2="0.762" y2="0" width="0.3048" layer="94"/>
<wire x1="0.762" y1="0" x2="1.651" y2="-0.254" width="0.3048" layer="94"/>
<wire x1="1.651" y1="-0.254" x2="1.651" y2="0" width="0.3048" layer="94"/>
<wire x1="1.651" y1="0" x2="1.397" y2="0" width="0.3048" layer="94"/>
<circle x="2.54" y="-1.905" radius="0.127" width="0.4064" layer="94"/>
<circle x="2.54" y="1.905" radius="0.127" width="0.4064" layer="94"/>
<text x="7.62" y="2.54" size="1.778" layer="95">&gt;NAME</text>
<text x="7.62" y="0" size="1.778" layer="96">&gt;VALUE</text>
<text x="1.27" y="2.54" size="0.8128" layer="93">D</text>
<text x="1.27" y="-3.175" size="0.8128" layer="93">S</text>
<text x="-2.54" y="-1.27" size="0.8128" layer="93">G</text>
<rectangle x1="-0.254" y1="-2.54" x2="0.508" y2="-1.27" layer="94"/>
<rectangle x1="-0.254" y1="1.27" x2="0.508" y2="2.54" layer="94"/>
<rectangle x1="-0.254" y1="-0.889" x2="0.508" y2="0.889" layer="94"/>
<pin name="G" x="-2.54" y="-2.54" visible="off" length="point" direction="pas"/>
<pin name="D" x="2.54" y="5.08" visible="off" length="short" direction="pas" rot="R270"/>
<pin name="S" x="2.54" y="-5.08" visible="off" length="short" direction="pas" rot="R90"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="IRL?2905" prefix="T">
<description>&lt;b&gt;HEXFET® Power MOSFET&lt;/b&gt;&lt;p&gt;
VDSS = 55V,
RDS(on) = 0.0135 ohm,
ID = 42A
&lt;ul&gt;
&lt;li&gt; Logic-Level Gate Drive
&lt;li&gt; Ultra Low On-Resistance
&lt;li&gt; Surface Mount (IRLR2905)
&lt;li&gt; Straight Lead (IRLU2905)
&lt;li&gt; Advanced Process Technology
&lt;li&gt; Fast Switching
&lt;li&gt; Fully Avalanche Rated
&lt;/ul&gt;www.irf.com</description>
<gates>
<gate name="T" symbol="MFNS" x="-2.54" y="0"/>
</gates>
<devices>
<device name="R" package="D2PACK">
<connects>
<connect gate="T" pin="D" pad="2"/>
<connect gate="T" pin="G" pad="1"/>
<connect gate="T" pin="S" pad="3"/>
</connects>
<technologies>
</technologies>
</device>
<device name="U" package="TO-251AA">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="" package="D-PAK_TO252AA">
<connects>
<connect gate="T" pin="D" pad="4"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="supply1">
<description>&lt;b&gt;Supply Symbols&lt;/b&gt;&lt;p&gt;
 GND, VCC, 0V, +5V, -5V, etc.&lt;p&gt;
 Please keep in mind, that these devices are necessary for the
 automatic wiring of the supply signals.&lt;p&gt;
 The pin name defined in the symbol is identical to the net which is to be wired automatically.&lt;p&gt;
 In this library the device names are the same as the pin names of the symbols, therefore the correct signal names appear next to the supply symbols in the schematic.&lt;p&gt;
<packages>
</packages>
<symbols>
<symbol name="+12V">
<wire x1="1.27" y1="-1.905" x2="0" y2="0" width="0.254" layer="94"/>
<wire x1="0" y1="0" x2="-1.27" y2="-1.905" width="0.254" layer="94"/>
<wire x1="1.27" y1="-0.635" x2="0" y2="1.27" width="0.254" layer="94"/>
<wire x1="0" y1="1.27" x2="-1.27" y2="-0.635" width="0.254" layer="94"/>
<text x="-2.54" y="-5.08" size="1.778" layer="96" rot="R90">&gt;VALUE</text>
<pin name="+12V" x="0" y="-2.54" visible="off" length="short" direction="sup" rot="R90"/>
</symbol>
<symbol name="GND">
<wire x1="-1.905" y1="0" x2="1.905" y2="0" width="0.254" layer="94"/>
<text x="-2.54" y="-2.54" size="1.778" layer="96">&gt;VALUE</text>
<pin name="GND" x="0" y="2.54" visible="off" length="short" direction="sup" rot="R270"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="+12V" prefix="P+">
<description>&lt;b&gt;SUPPLY SYMBOL&lt;/b&gt;</description>
<gates>
<gate name="1" symbol="+12V" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="GND" prefix="GND">
<gates>
<gate name="1" symbol="GND" x="0" y="0"/>
</gates>
<devices>
<device name="">
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="con-amp-quick">
<description>&lt;b&gt;AMP Connectors, Type QUICK&lt;/b&gt;&lt;p&gt;
<packages>
<package name="05P">
<description>&lt;b&gt;AMP QUICK CONNECTOR&lt;/b&gt;</description>
<wire x1="-4.191" y1="1.778" x2="-4.064" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="1.651" x2="-3.81" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.397" x2="-3.556" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.651" x2="-3.429" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="-2.159" x2="-4.064" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="-2.286" x2="-6.096" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-2.159" x2="-4.064" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-2.159" x2="-3.556" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="2.54" x2="-6.096" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="1.778" x2="-6.096" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-1.778" x2="-6.096" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-1.778" x2="-5.715" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.778" x2="-4.445" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.778" x2="-5.715" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.27" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.524" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.778" x2="-3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.524" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.524" x2="-4.064" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="-1.524" x2="-3.556" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-1.524" x2="-3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.524" x2="-6.096" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.524" x2="-5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-1.524" x2="-6.096" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="2.54" x2="-5.334" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="2.54" x2="-5.334" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.54" x2="-4.826" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.667" x2="-5.334" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="2.54" x2="-2.794" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="2.54" x2="-2.286" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="2.413" x2="-3.556" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="2.413" x2="-4.064" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-2.159" x2="-1.524" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-2.159" x2="-1.016" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-2.286" x2="-1.016" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.016" y1="1.778" x2="1.016" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.778" x2="0.635" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.778" x2="-1.905" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.524" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.778" x2="-0.635" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.524" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.524" x2="-1.524" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-1.524" x2="-1.016" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-1.524" x2="-0.635" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.524" x2="1.016" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.524" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="2.54" x2="-0.254" y2="2.667" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.54" x2="1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.54" x2="0.254" y2="2.667" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.667" x2="-0.254" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="2.413" x2="-1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="2.54" x2="-0.254" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="2.413" x2="-1.524" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="2.413" x2="-1.524" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="2.54" x2="-1.524" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="2.667" x2="-2.794" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="2.54" x2="-2.794" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="2.413" x2="-3.556" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="2.54" x2="-4.826" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="1.778" x2="-6.096" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.778" x2="-1.524" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="1.778" x2="-1.016" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.651" x2="-3.556" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="1.651" x2="-4.064" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="1.778" x2="-1.524" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="1.778" x2="-1.016" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.778" x2="-4.445" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-2.286" x2="-1.524" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.778" x2="-0.635" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-2.159" x2="-1.524" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.524" y1="1.778" x2="1.524" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.778" x2="1.905" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.524" x2="1.524" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.524" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.286" y1="2.54" x2="2.286" y2="2.667" width="0.1524" layer="21"/>
<wire x1="2.794" y1="2.54" x2="2.794" y2="2.667" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.397" x2="4.064" y2="1.651" width="0.1524" layer="21"/>
<wire x1="4.064" y1="1.651" x2="4.191" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-2.159" x2="3.556" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-2.159" x2="4.064" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-2.286" x2="4.064" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="4.191" y1="1.778" x2="6.096" y2="1.778" width="0.1524" layer="21"/>
<wire x1="6.096" y1="1.778" x2="6.096" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-1.778" x2="6.096" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-1.778" x2="5.715" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="6.096" y1="1.778" x2="6.096" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.778" x2="5.715" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.778" x2="3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.524" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.778" x2="4.445" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.524" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.524" x2="3.556" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.556" y1="-1.524" x2="4.064" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-1.524" x2="4.445" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.524" x2="6.096" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.524" x2="5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-1.524" x2="6.096" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.54" x2="4.826" y2="2.667" width="0.1524" layer="21"/>
<wire x1="5.334" y1="2.54" x2="6.096" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.334" y1="2.54" x2="5.334" y2="2.667" width="0.1524" layer="21"/>
<wire x1="5.334" y1="2.667" x2="4.826" y2="2.667" width="0.1524" layer="21"/>
<wire x1="4.064" y1="2.413" x2="4.064" y2="2.54" width="0.1524" layer="21"/>
<wire x1="4.064" y1="2.54" x2="4.826" y2="2.54" width="0.1524" layer="21"/>
<wire x1="4.064" y1="2.413" x2="3.556" y2="2.413" width="0.1524" layer="21"/>
<wire x1="3.556" y1="2.413" x2="3.556" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.778" x2="3.556" y2="1.651" width="0.1524" layer="21"/>
<wire x1="3.556" y1="1.651" x2="3.81" y2="1.397" width="0.1524" layer="21"/>
<wire x1="2.794" y1="2.54" x2="3.556" y2="2.54" width="0.1524" layer="21"/>
<wire x1="2.794" y1="2.667" x2="2.286" y2="2.667" width="0.1524" layer="21"/>
<wire x1="1.524" y1="2.54" x2="2.286" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.556" y1="1.651" x2="3.556" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.064" y1="1.651" x2="4.064" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-2.286" x2="3.556" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.778" x2="4.445" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="3.556" y1="-2.159" x2="3.556" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="1.778" x2="1.016" y2="1.778" width="0.1524" layer="21"/>
<wire x1="1.524" y1="1.778" x2="3.429" y2="1.778" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-2.159" x2="1.016" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-2.159" x2="1.524" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-2.159" x2="1.016" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.778" x2="0.635" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-1.524" x2="1.016" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.524" y1="1.778" x2="1.016" y2="1.778" width="0.1524" layer="21"/>
<wire x1="1.524" y1="2.413" x2="1.016" y2="2.413" width="0.1524" layer="21"/>
<wire x1="1.016" y1="2.54" x2="1.016" y2="2.413" width="0.1524" layer="21"/>
<wire x1="1.524" y1="2.54" x2="1.524" y2="2.413" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="2" x="-2.54" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="3" x="0" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="4" x="2.54" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="5" x="5.08" y="0" drill="0.9144" shape="long" rot="R90"/>
<text x="-4.572" y="0.9398" size="0.9906" layer="21" ratio="12" rot="R90">1</text>
<text x="-6.096" y="2.9464" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.096" y="-3.8354" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.4102" y1="-0.3302" x2="-4.7498" y2="0.3302" layer="51"/>
<rectangle x1="-2.8702" y1="-0.3302" x2="-2.2098" y2="0.3302" layer="51"/>
<rectangle x1="-0.3302" y1="-0.3302" x2="0.3302" y2="0.3302" layer="51"/>
<rectangle x1="2.2098" y1="-0.3302" x2="2.8702" y2="0.3302" layer="51"/>
<rectangle x1="4.7498" y1="-0.3302" x2="5.4102" y2="0.3302" layer="51"/>
</package>
</packages>
<symbols>
<symbol name="M05">
<wire x1="3.81" y1="-7.62" x2="-2.54" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="1.27" y1="0" x2="2.54" y2="0" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-2.54" x2="2.54" y2="-2.54" width="0.6096" layer="94"/>
<wire x1="1.27" y1="-5.08" x2="2.54" y2="-5.08" width="0.6096" layer="94"/>
<wire x1="-2.54" y1="7.62" x2="-2.54" y2="-7.62" width="0.4064" layer="94"/>
<wire x1="3.81" y1="-7.62" x2="3.81" y2="7.62" width="0.4064" layer="94"/>
<wire x1="-2.54" y1="7.62" x2="3.81" y2="7.62" width="0.4064" layer="94"/>
<wire x1="1.27" y1="5.08" x2="2.54" y2="5.08" width="0.6096" layer="94"/>
<wire x1="1.27" y1="2.54" x2="2.54" y2="2.54" width="0.6096" layer="94"/>
<text x="-2.54" y="-10.16" size="1.778" layer="96">&gt;VALUE</text>
<text x="-2.54" y="8.382" size="1.778" layer="95">&gt;NAME</text>
<pin name="1" x="7.62" y="-5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="2" x="7.62" y="-2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="3" x="7.62" y="0" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="4" x="7.62" y="2.54" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
<pin name="5" x="7.62" y="5.08" visible="pad" length="middle" direction="pas" swaplevel="1" rot="R180"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="M05" prefix="SL" uservalue="yes">
<gates>
<gate name="G$1" symbol="M05" x="-2.54" y="0"/>
</gates>
<devices>
<device name="" package="05P">
<connects>
<connect gate="G$1" pin="3" pad="3"/>
<connect gate="G$1" pin="4" pad="4"/>
<connect gate="G$1" pin="5" pad="5"/>
</connects>
<technologies>
<technology name="">
<attribute name="MF" value="" constant="no"/>
<attribute name="MPN" value="" constant="no"/>
<attribute name="OC_FARNELL" value="unknown" constant="no"/>
<attribute name="OC_NEWARK" value="unknown" constant="no"/>
</technology>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
<library name="arduino">
<description>&lt;b&gt;Arduino Boards&lt;/b&gt;
&lt;ul&gt;
&lt;li&gt;MegaArduino
&lt;li&gt;Arduino Duemilanove (2009)
&lt;/ul&gt;
Based on the following sources:
&lt;br&gt;&lt;br&gt;
Schematic &amp; Reference Design from:
&lt;ul&gt;
&lt;li&gt; http://arduino.cc/en/Main/ArduinoBoardMega
&lt;li&gt;http://arduino.cc/en/Main/ArduinoBoardDuemilanove
&lt;/ul&gt;
Version: 1.0 / 30.08.2009&lt;br&gt;
&lt;author&gt;Created by atami@gmx.net&lt;/author&gt;</description>
<packages>
<package name="ARDUINO2009">
<wire x1="0" y1="0" x2="0" y2="58.42" width="0.127" layer="51"/>
<wire x1="77.47" y1="0" x2="0" y2="0" width="0.127" layer="51"/>
<wire x1="48.641" y1="54.61" x2="49.911" y2="54.61" width="0.1524" layer="21"/>
<wire x1="49.911" y1="54.61" x2="50.546" y2="53.975" width="0.1524" layer="21"/>
<wire x1="50.546" y1="53.975" x2="50.546" y2="52.705" width="0.1524" layer="21"/>
<wire x1="50.546" y1="52.705" x2="49.911" y2="52.07" width="0.1524" layer="21"/>
<wire x1="45.466" y1="53.975" x2="46.101" y2="54.61" width="0.1524" layer="21"/>
<wire x1="46.101" y1="54.61" x2="47.371" y2="54.61" width="0.1524" layer="21"/>
<wire x1="47.371" y1="54.61" x2="48.006" y2="53.975" width="0.1524" layer="21"/>
<wire x1="48.006" y1="53.975" x2="48.006" y2="52.705" width="0.1524" layer="21"/>
<wire x1="48.006" y1="52.705" x2="47.371" y2="52.07" width="0.1524" layer="21"/>
<wire x1="47.371" y1="52.07" x2="46.101" y2="52.07" width="0.1524" layer="21"/>
<wire x1="46.101" y1="52.07" x2="45.466" y2="52.705" width="0.1524" layer="21"/>
<wire x1="48.641" y1="54.61" x2="48.006" y2="53.975" width="0.1524" layer="21"/>
<wire x1="48.006" y1="52.705" x2="48.641" y2="52.07" width="0.1524" layer="21"/>
<wire x1="49.911" y1="52.07" x2="48.641" y2="52.07" width="0.1524" layer="21"/>
<wire x1="41.021" y1="54.61" x2="42.291" y2="54.61" width="0.1524" layer="21"/>
<wire x1="42.291" y1="54.61" x2="42.926" y2="53.975" width="0.1524" layer="21"/>
<wire x1="42.926" y1="53.975" x2="42.926" y2="52.705" width="0.1524" layer="21"/>
<wire x1="42.926" y1="52.705" x2="42.291" y2="52.07" width="0.1524" layer="21"/>
<wire x1="42.926" y1="53.975" x2="43.561" y2="54.61" width="0.1524" layer="21"/>
<wire x1="43.561" y1="54.61" x2="44.831" y2="54.61" width="0.1524" layer="21"/>
<wire x1="44.831" y1="54.61" x2="45.466" y2="53.975" width="0.1524" layer="21"/>
<wire x1="45.466" y1="53.975" x2="45.466" y2="52.705" width="0.1524" layer="21"/>
<wire x1="45.466" y1="52.705" x2="44.831" y2="52.07" width="0.1524" layer="21"/>
<wire x1="44.831" y1="52.07" x2="43.561" y2="52.07" width="0.1524" layer="21"/>
<wire x1="43.561" y1="52.07" x2="42.926" y2="52.705" width="0.1524" layer="21"/>
<wire x1="37.846" y1="53.975" x2="38.481" y2="54.61" width="0.1524" layer="21"/>
<wire x1="38.481" y1="54.61" x2="39.751" y2="54.61" width="0.1524" layer="21"/>
<wire x1="39.751" y1="54.61" x2="40.386" y2="53.975" width="0.1524" layer="21"/>
<wire x1="40.386" y1="53.975" x2="40.386" y2="52.705" width="0.1524" layer="21"/>
<wire x1="40.386" y1="52.705" x2="39.751" y2="52.07" width="0.1524" layer="21"/>
<wire x1="39.751" y1="52.07" x2="38.481" y2="52.07" width="0.1524" layer="21"/>
<wire x1="38.481" y1="52.07" x2="37.846" y2="52.705" width="0.1524" layer="21"/>
<wire x1="41.021" y1="54.61" x2="40.386" y2="53.975" width="0.1524" layer="21"/>
<wire x1="40.386" y1="52.705" x2="41.021" y2="52.07" width="0.1524" layer="21"/>
<wire x1="42.291" y1="52.07" x2="41.021" y2="52.07" width="0.1524" layer="21"/>
<wire x1="33.401" y1="54.61" x2="34.671" y2="54.61" width="0.1524" layer="21"/>
<wire x1="34.671" y1="54.61" x2="35.306" y2="53.975" width="0.1524" layer="21"/>
<wire x1="35.306" y1="53.975" x2="35.306" y2="52.705" width="0.1524" layer="21"/>
<wire x1="35.306" y1="52.705" x2="34.671" y2="52.07" width="0.1524" layer="21"/>
<wire x1="35.306" y1="53.975" x2="35.941" y2="54.61" width="0.1524" layer="21"/>
<wire x1="35.941" y1="54.61" x2="37.211" y2="54.61" width="0.1524" layer="21"/>
<wire x1="37.211" y1="54.61" x2="37.846" y2="53.975" width="0.1524" layer="21"/>
<wire x1="37.846" y1="53.975" x2="37.846" y2="52.705" width="0.1524" layer="21"/>
<wire x1="37.846" y1="52.705" x2="37.211" y2="52.07" width="0.1524" layer="21"/>
<wire x1="37.211" y1="52.07" x2="35.941" y2="52.07" width="0.1524" layer="21"/>
<wire x1="35.941" y1="52.07" x2="35.306" y2="52.705" width="0.1524" layer="21"/>
<wire x1="32.766" y1="53.975" x2="32.766" y2="52.705" width="0.1524" layer="21"/>
<wire x1="33.401" y1="54.61" x2="32.766" y2="53.975" width="0.1524" layer="21"/>
<wire x1="32.766" y1="52.705" x2="33.401" y2="52.07" width="0.1524" layer="21"/>
<wire x1="34.671" y1="52.07" x2="33.401" y2="52.07" width="0.1524" layer="21"/>
<wire x1="51.181" y1="54.61" x2="52.451" y2="54.61" width="0.1524" layer="21"/>
<wire x1="52.451" y1="54.61" x2="53.086" y2="53.975" width="0.1524" layer="21"/>
<wire x1="53.086" y1="53.975" x2="53.086" y2="52.705" width="0.1524" layer="21"/>
<wire x1="53.086" y1="52.705" x2="52.451" y2="52.07" width="0.1524" layer="21"/>
<wire x1="51.181" y1="54.61" x2="50.546" y2="53.975" width="0.1524" layer="21"/>
<wire x1="50.546" y1="52.705" x2="51.181" y2="52.07" width="0.1524" layer="21"/>
<wire x1="52.451" y1="52.07" x2="51.181" y2="52.07" width="0.1524" layer="21"/>
<wire x1="70.485" y1="54.61" x2="71.755" y2="54.61" width="0.1524" layer="21"/>
<wire x1="71.755" y1="54.61" x2="72.39" y2="53.975" width="0.1524" layer="21"/>
<wire x1="72.39" y1="53.975" x2="72.39" y2="52.705" width="0.1524" layer="21"/>
<wire x1="72.39" y1="52.705" x2="71.755" y2="52.07" width="0.1524" layer="21"/>
<wire x1="67.31" y1="53.975" x2="67.945" y2="54.61" width="0.1524" layer="21"/>
<wire x1="67.945" y1="54.61" x2="69.215" y2="54.61" width="0.1524" layer="21"/>
<wire x1="69.215" y1="54.61" x2="69.85" y2="53.975" width="0.1524" layer="21"/>
<wire x1="69.85" y1="53.975" x2="69.85" y2="52.705" width="0.1524" layer="21"/>
<wire x1="69.85" y1="52.705" x2="69.215" y2="52.07" width="0.1524" layer="21"/>
<wire x1="69.215" y1="52.07" x2="67.945" y2="52.07" width="0.1524" layer="21"/>
<wire x1="67.945" y1="52.07" x2="67.31" y2="52.705" width="0.1524" layer="21"/>
<wire x1="70.485" y1="54.61" x2="69.85" y2="53.975" width="0.1524" layer="21"/>
<wire x1="69.85" y1="52.705" x2="70.485" y2="52.07" width="0.1524" layer="21"/>
<wire x1="71.755" y1="52.07" x2="70.485" y2="52.07" width="0.1524" layer="21"/>
<wire x1="62.865" y1="54.61" x2="64.135" y2="54.61" width="0.1524" layer="21"/>
<wire x1="64.135" y1="54.61" x2="64.77" y2="53.975" width="0.1524" layer="21"/>
<wire x1="64.77" y1="53.975" x2="64.77" y2="52.705" width="0.1524" layer="21"/>
<wire x1="64.77" y1="52.705" x2="64.135" y2="52.07" width="0.1524" layer="21"/>
<wire x1="64.77" y1="53.975" x2="65.405" y2="54.61" width="0.1524" layer="21"/>
<wire x1="65.405" y1="54.61" x2="66.675" y2="54.61" width="0.1524" layer="21"/>
<wire x1="66.675" y1="54.61" x2="67.31" y2="53.975" width="0.1524" layer="21"/>
<wire x1="67.31" y1="53.975" x2="67.31" y2="52.705" width="0.1524" layer="21"/>
<wire x1="67.31" y1="52.705" x2="66.675" y2="52.07" width="0.1524" layer="21"/>
<wire x1="66.675" y1="52.07" x2="65.405" y2="52.07" width="0.1524" layer="21"/>
<wire x1="65.405" y1="52.07" x2="64.77" y2="52.705" width="0.1524" layer="21"/>
<wire x1="59.69" y1="53.975" x2="60.325" y2="54.61" width="0.1524" layer="21"/>
<wire x1="60.325" y1="54.61" x2="61.595" y2="54.61" width="0.1524" layer="21"/>
<wire x1="61.595" y1="54.61" x2="62.23" y2="53.975" width="0.1524" layer="21"/>
<wire x1="62.23" y1="53.975" x2="62.23" y2="52.705" width="0.1524" layer="21"/>
<wire x1="62.23" y1="52.705" x2="61.595" y2="52.07" width="0.1524" layer="21"/>
<wire x1="61.595" y1="52.07" x2="60.325" y2="52.07" width="0.1524" layer="21"/>
<wire x1="60.325" y1="52.07" x2="59.69" y2="52.705" width="0.1524" layer="21"/>
<wire x1="62.865" y1="54.61" x2="62.23" y2="53.975" width="0.1524" layer="21"/>
<wire x1="62.23" y1="52.705" x2="62.865" y2="52.07" width="0.1524" layer="21"/>
<wire x1="64.135" y1="52.07" x2="62.865" y2="52.07" width="0.1524" layer="21"/>
<wire x1="55.245" y1="54.61" x2="56.515" y2="54.61" width="0.1524" layer="21"/>
<wire x1="56.515" y1="54.61" x2="57.15" y2="53.975" width="0.1524" layer="21"/>
<wire x1="57.15" y1="53.975" x2="57.15" y2="52.705" width="0.1524" layer="21"/>
<wire x1="57.15" y1="52.705" x2="56.515" y2="52.07" width="0.1524" layer="21"/>
<wire x1="57.15" y1="53.975" x2="57.785" y2="54.61" width="0.1524" layer="21"/>
<wire x1="57.785" y1="54.61" x2="59.055" y2="54.61" width="0.1524" layer="21"/>
<wire x1="59.055" y1="54.61" x2="59.69" y2="53.975" width="0.1524" layer="21"/>
<wire x1="59.69" y1="53.975" x2="59.69" y2="52.705" width="0.1524" layer="21"/>
<wire x1="59.69" y1="52.705" x2="59.055" y2="52.07" width="0.1524" layer="21"/>
<wire x1="59.055" y1="52.07" x2="57.785" y2="52.07" width="0.1524" layer="21"/>
<wire x1="57.785" y1="52.07" x2="57.15" y2="52.705" width="0.1524" layer="21"/>
<wire x1="54.61" y1="53.975" x2="54.61" y2="52.705" width="0.1524" layer="21"/>
<wire x1="55.245" y1="54.61" x2="54.61" y2="53.975" width="0.1524" layer="21"/>
<wire x1="54.61" y1="52.705" x2="55.245" y2="52.07" width="0.1524" layer="21"/>
<wire x1="56.515" y1="52.07" x2="55.245" y2="52.07" width="0.1524" layer="21"/>
<wire x1="73.025" y1="54.61" x2="74.295" y2="54.61" width="0.1524" layer="21"/>
<wire x1="74.295" y1="54.61" x2="74.93" y2="53.975" width="0.1524" layer="21"/>
<wire x1="74.93" y1="53.975" x2="74.93" y2="52.705" width="0.1524" layer="21"/>
<wire x1="74.93" y1="52.705" x2="74.295" y2="52.07" width="0.1524" layer="21"/>
<wire x1="73.025" y1="54.61" x2="72.39" y2="53.975" width="0.1524" layer="21"/>
<wire x1="72.39" y1="52.705" x2="73.025" y2="52.07" width="0.1524" layer="21"/>
<wire x1="74.295" y1="52.07" x2="73.025" y2="52.07" width="0.1524" layer="21"/>
<wire x1="55.245" y1="6.35" x2="56.515" y2="6.35" width="0.1524" layer="21"/>
<wire x1="56.515" y1="6.35" x2="57.15" y2="5.715" width="0.1524" layer="21"/>
<wire x1="57.15" y1="4.445" x2="56.515" y2="3.81" width="0.1524" layer="21"/>
<wire x1="52.07" y1="5.715" x2="52.705" y2="6.35" width="0.1524" layer="21"/>
<wire x1="52.705" y1="6.35" x2="53.975" y2="6.35" width="0.1524" layer="21"/>
<wire x1="53.975" y1="6.35" x2="54.61" y2="5.715" width="0.1524" layer="21"/>
<wire x1="54.61" y1="5.715" x2="54.61" y2="4.445" width="0.1524" layer="21"/>
<wire x1="54.61" y1="4.445" x2="53.975" y2="3.81" width="0.1524" layer="21"/>
<wire x1="53.975" y1="3.81" x2="52.705" y2="3.81" width="0.1524" layer="21"/>
<wire x1="52.705" y1="3.81" x2="52.07" y2="4.445" width="0.1524" layer="21"/>
<wire x1="55.245" y1="6.35" x2="54.61" y2="5.715" width="0.1524" layer="21"/>
<wire x1="54.61" y1="4.445" x2="55.245" y2="3.81" width="0.1524" layer="21"/>
<wire x1="56.515" y1="3.81" x2="55.245" y2="3.81" width="0.1524" layer="21"/>
<wire x1="47.625" y1="6.35" x2="48.895" y2="6.35" width="0.1524" layer="21"/>
<wire x1="48.895" y1="6.35" x2="49.53" y2="5.715" width="0.1524" layer="21"/>
<wire x1="49.53" y1="5.715" x2="49.53" y2="4.445" width="0.1524" layer="21"/>
<wire x1="49.53" y1="4.445" x2="48.895" y2="3.81" width="0.1524" layer="21"/>
<wire x1="49.53" y1="5.715" x2="50.165" y2="6.35" width="0.1524" layer="21"/>
<wire x1="50.165" y1="6.35" x2="51.435" y2="6.35" width="0.1524" layer="21"/>
<wire x1="51.435" y1="6.35" x2="52.07" y2="5.715" width="0.1524" layer="21"/>
<wire x1="52.07" y1="5.715" x2="52.07" y2="4.445" width="0.1524" layer="21"/>
<wire x1="52.07" y1="4.445" x2="51.435" y2="3.81" width="0.1524" layer="21"/>
<wire x1="51.435" y1="3.81" x2="50.165" y2="3.81" width="0.1524" layer="21"/>
<wire x1="50.165" y1="3.81" x2="49.53" y2="4.445" width="0.1524" layer="21"/>
<wire x1="44.45" y1="5.715" x2="45.085" y2="6.35" width="0.1524" layer="21"/>
<wire x1="45.085" y1="6.35" x2="46.355" y2="6.35" width="0.1524" layer="21"/>
<wire x1="46.355" y1="6.35" x2="46.99" y2="5.715" width="0.1524" layer="21"/>
<wire x1="46.99" y1="5.715" x2="46.99" y2="4.445" width="0.1524" layer="21"/>
<wire x1="46.99" y1="4.445" x2="46.355" y2="3.81" width="0.1524" layer="21"/>
<wire x1="46.355" y1="3.81" x2="45.085" y2="3.81" width="0.1524" layer="21"/>
<wire x1="45.085" y1="3.81" x2="44.45" y2="4.445" width="0.1524" layer="21"/>
<wire x1="47.625" y1="6.35" x2="46.99" y2="5.715" width="0.1524" layer="21"/>
<wire x1="46.99" y1="4.445" x2="47.625" y2="3.81" width="0.1524" layer="21"/>
<wire x1="48.895" y1="3.81" x2="47.625" y2="3.81" width="0.1524" layer="21"/>
<wire x1="41.91" y1="5.715" x2="41.91" y2="4.445" width="0.1524" layer="21"/>
<wire x1="41.91" y1="5.715" x2="42.545" y2="6.35" width="0.1524" layer="21"/>
<wire x1="42.545" y1="6.35" x2="43.815" y2="6.35" width="0.1524" layer="21"/>
<wire x1="43.815" y1="6.35" x2="44.45" y2="5.715" width="0.1524" layer="21"/>
<wire x1="44.45" y1="5.715" x2="44.45" y2="4.445" width="0.1524" layer="21"/>
<wire x1="44.45" y1="4.445" x2="43.815" y2="3.81" width="0.1524" layer="21"/>
<wire x1="43.815" y1="3.81" x2="42.545" y2="3.81" width="0.1524" layer="21"/>
<wire x1="42.545" y1="3.81" x2="41.91" y2="4.445" width="0.1524" layer="21"/>
<wire x1="73.025" y1="6.35" x2="74.295" y2="6.35" width="0.1524" layer="21"/>
<wire x1="74.295" y1="6.35" x2="74.93" y2="5.715" width="0.1524" layer="21"/>
<wire x1="74.93" y1="5.715" x2="74.93" y2="4.445" width="0.1524" layer="21"/>
<wire x1="74.93" y1="4.445" x2="74.295" y2="3.81" width="0.1524" layer="21"/>
<wire x1="69.85" y1="5.715" x2="70.485" y2="6.35" width="0.1524" layer="21"/>
<wire x1="70.485" y1="6.35" x2="71.755" y2="6.35" width="0.1524" layer="21"/>
<wire x1="71.755" y1="6.35" x2="72.39" y2="5.715" width="0.1524" layer="21"/>
<wire x1="72.39" y1="5.715" x2="72.39" y2="4.445" width="0.1524" layer="21"/>
<wire x1="72.39" y1="4.445" x2="71.755" y2="3.81" width="0.1524" layer="21"/>
<wire x1="71.755" y1="3.81" x2="70.485" y2="3.81" width="0.1524" layer="21"/>
<wire x1="70.485" y1="3.81" x2="69.85" y2="4.445" width="0.1524" layer="21"/>
<wire x1="73.025" y1="6.35" x2="72.39" y2="5.715" width="0.1524" layer="21"/>
<wire x1="72.39" y1="4.445" x2="73.025" y2="3.81" width="0.1524" layer="21"/>
<wire x1="74.295" y1="3.81" x2="73.025" y2="3.81" width="0.1524" layer="21"/>
<wire x1="65.405" y1="6.35" x2="66.675" y2="6.35" width="0.1524" layer="21"/>
<wire x1="66.675" y1="6.35" x2="67.31" y2="5.715" width="0.1524" layer="21"/>
<wire x1="67.31" y1="5.715" x2="67.31" y2="4.445" width="0.1524" layer="21"/>
<wire x1="67.31" y1="4.445" x2="66.675" y2="3.81" width="0.1524" layer="21"/>
<wire x1="67.31" y1="5.715" x2="67.945" y2="6.35" width="0.1524" layer="21"/>
<wire x1="67.945" y1="6.35" x2="69.215" y2="6.35" width="0.1524" layer="21"/>
<wire x1="69.215" y1="6.35" x2="69.85" y2="5.715" width="0.1524" layer="21"/>
<wire x1="69.85" y1="5.715" x2="69.85" y2="4.445" width="0.1524" layer="21"/>
<wire x1="69.85" y1="4.445" x2="69.215" y2="3.81" width="0.1524" layer="21"/>
<wire x1="69.215" y1="3.81" x2="67.945" y2="3.81" width="0.1524" layer="21"/>
<wire x1="67.945" y1="3.81" x2="67.31" y2="4.445" width="0.1524" layer="21"/>
<wire x1="62.23" y1="5.715" x2="62.865" y2="6.35" width="0.1524" layer="21"/>
<wire x1="62.865" y1="6.35" x2="64.135" y2="6.35" width="0.1524" layer="21"/>
<wire x1="64.135" y1="6.35" x2="64.77" y2="5.715" width="0.1524" layer="21"/>
<wire x1="64.77" y1="5.715" x2="64.77" y2="4.445" width="0.1524" layer="21"/>
<wire x1="64.77" y1="4.445" x2="64.135" y2="3.81" width="0.1524" layer="21"/>
<wire x1="64.135" y1="3.81" x2="62.865" y2="3.81" width="0.1524" layer="21"/>
<wire x1="62.865" y1="3.81" x2="62.23" y2="4.445" width="0.1524" layer="21"/>
<wire x1="65.405" y1="6.35" x2="64.77" y2="5.715" width="0.1524" layer="21"/>
<wire x1="64.77" y1="4.445" x2="65.405" y2="3.81" width="0.1524" layer="21"/>
<wire x1="66.675" y1="3.81" x2="65.405" y2="3.81" width="0.1524" layer="21"/>
<wire x1="59.69" y1="5.715" x2="59.69" y2="4.445" width="0.1524" layer="21"/>
<wire x1="59.69" y1="5.715" x2="60.325" y2="6.35" width="0.1524" layer="21"/>
<wire x1="60.325" y1="6.35" x2="61.595" y2="6.35" width="0.1524" layer="21"/>
<wire x1="61.595" y1="6.35" x2="62.23" y2="5.715" width="0.1524" layer="21"/>
<wire x1="62.23" y1="5.715" x2="62.23" y2="4.445" width="0.1524" layer="21"/>
<wire x1="62.23" y1="4.445" x2="61.595" y2="3.81" width="0.1524" layer="21"/>
<wire x1="61.595" y1="3.81" x2="60.325" y2="3.81" width="0.1524" layer="21"/>
<wire x1="60.325" y1="3.81" x2="59.69" y2="4.445" width="0.1524" layer="21"/>
<wire x1="57.15" y1="5.715" x2="57.15" y2="4.445" width="0.1524" layer="21"/>
<pad name="28" x="34.036" y="53.34" drill="1.016" shape="long" rot="R90"/>
<pad name="27" x="36.576" y="53.34" drill="1.016" shape="long" rot="R90"/>
<pad name="26" x="39.116" y="53.34" drill="1.016" shape="long" rot="R90"/>
<pad name="25" x="41.656" y="53.34" drill="1.016" shape="long" rot="R90"/>
<pad name="24" x="44.196" y="53.34" drill="1.016" shape="long" rot="R90"/>
<pad name="23" x="46.736" y="53.34" drill="1.016" shape="long" rot="R90"/>
<pad name="22" x="49.276" y="53.34" drill="1.016" shape="long" rot="R90"/>
<pad name="21" x="51.816" y="53.34" drill="1.016" shape="long" rot="R90"/>
<pad name="20" x="55.88" y="53.34" drill="1.016" shape="long" rot="R90"/>
<pad name="19" x="58.42" y="53.34" drill="1.016" shape="long" rot="R90"/>
<pad name="18" x="60.96" y="53.34" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="63.5" y="53.34" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="66.04" y="53.34" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="68.58" y="53.34" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="71.12" y="53.34" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="73.66" y="53.34" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="43.18" y="5.08" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="45.72" y="5.08" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="48.26" y="5.08" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="50.8" y="5.08" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="53.34" y="5.08" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="55.88" y="5.08" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="60.96" y="5.08" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="63.5" y="5.08" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="66.04" y="5.08" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="68.58" y="5.08" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="71.12" y="5.08" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="73.66" y="5.08" drill="1.016" shape="long" rot="R90"/>
<text x="33.2784" y="51.3212" size="1.016" layer="48" font="vector" ratio="10" rot="R270">AREF</text>
<text x="35.814" y="51.308" size="1.016" layer="48" font="vector" ratio="10" rot="R270">GND</text>
<text x="38.354" y="51.308" size="1.016" layer="48" font="vector" ratio="10" rot="R270">13</text>
<text x="40.894" y="51.308" size="1.016" layer="48" font="vector" ratio="10" rot="R270">12</text>
<text x="43.434" y="51.308" size="1.016" layer="48" font="vector" ratio="10" rot="R270">11</text>
<text x="45.974" y="51.308" size="1.016" layer="48" font="vector" ratio="10" rot="R270">10</text>
<text x="48.514" y="51.308" size="1.016" layer="48" font="vector" ratio="10" rot="R270">9</text>
<text x="51.054" y="51.308" size="1.016" layer="48" font="vector" ratio="10" rot="R270">8</text>
<text x="55.118" y="51.308" size="1.016" layer="48" font="vector" ratio="10" rot="R270">7</text>
<text x="57.658" y="51.308" size="1.016" layer="48" font="vector" ratio="10" rot="R270">6</text>
<text x="60.198" y="51.308" size="1.016" layer="48" font="vector" ratio="10" rot="R270">5</text>
<text x="62.738" y="51.308" size="1.016" layer="48" font="vector" ratio="10" rot="R270">4</text>
<text x="65.278" y="51.308" size="1.016" layer="48" font="vector" ratio="10" rot="R270">3</text>
<text x="67.818" y="51.308" size="1.016" layer="48" font="vector" ratio="10" rot="R270">2</text>
<text x="70.358" y="51.308" size="1.016" layer="48" font="vector" ratio="10" rot="R270">RxD 1</text>
<text x="72.898" y="51.308" size="1.016" layer="48" font="vector" ratio="10" rot="R270">TxD 0</text>
<text x="43.9376" y="7.3528" size="1.016" layer="48" font="vector" ratio="10" rot="R90">!Reset</text>
<text x="46.4776" y="7.3528" size="1.016" layer="48" font="vector" ratio="10" rot="R90">+3V3</text>
<text x="49.0176" y="7.3528" size="1.016" layer="48" font="vector" ratio="10" rot="R90">+5V</text>
<text x="51.5576" y="7.3528" size="1.016" layer="48" font="vector" ratio="10" rot="R90">GND</text>
<text x="54.0976" y="7.3528" size="1.016" layer="48" font="vector" ratio="10" rot="R90">GND</text>
<text x="56.6376" y="7.3528" size="1.016" layer="48" font="vector" ratio="10" rot="R90">+Vin</text>
<text x="61.7176" y="7.3528" size="1.016" layer="48" font="vector" ratio="10" rot="R90">A0</text>
<text x="64.2576" y="7.3528" size="1.016" layer="48" font="vector" ratio="10" rot="R90">A1</text>
<text x="66.7976" y="7.3528" size="1.016" layer="48" font="vector" ratio="10" rot="R90">A2</text>
<text x="69.3376" y="7.3528" size="1.016" layer="48" font="vector" ratio="10" rot="R90">A3</text>
<text x="71.8776" y="7.3528" size="1.016" layer="48" font="vector" ratio="10" rot="R90">A4</text>
<text x="74.4176" y="7.3528" size="1.016" layer="48" font="vector" ratio="10" rot="R90">A5</text>
<rectangle x1="49.022" y1="53.086" x2="49.53" y2="53.594" layer="51"/>
<rectangle x1="46.482" y1="53.086" x2="46.99" y2="53.594" layer="51"/>
<rectangle x1="43.942" y1="53.086" x2="44.45" y2="53.594" layer="51"/>
<rectangle x1="41.402" y1="53.086" x2="41.91" y2="53.594" layer="51"/>
<rectangle x1="38.862" y1="53.086" x2="39.37" y2="53.594" layer="51"/>
<rectangle x1="36.322" y1="53.086" x2="36.83" y2="53.594" layer="51"/>
<rectangle x1="33.782" y1="53.086" x2="34.29" y2="53.594" layer="51"/>
<rectangle x1="51.562" y1="53.086" x2="52.07" y2="53.594" layer="51"/>
<rectangle x1="70.866" y1="53.086" x2="71.374" y2="53.594" layer="51"/>
<rectangle x1="68.326" y1="53.086" x2="68.834" y2="53.594" layer="51"/>
<rectangle x1="65.786" y1="53.086" x2="66.294" y2="53.594" layer="51"/>
<rectangle x1="63.246" y1="53.086" x2="63.754" y2="53.594" layer="51"/>
<rectangle x1="60.706" y1="53.086" x2="61.214" y2="53.594" layer="51"/>
<rectangle x1="58.166" y1="53.086" x2="58.674" y2="53.594" layer="51"/>
<rectangle x1="55.626" y1="53.086" x2="56.134" y2="53.594" layer="51"/>
<rectangle x1="73.406" y1="53.086" x2="73.914" y2="53.594" layer="51"/>
<rectangle x1="55.626" y1="4.826" x2="56.134" y2="5.334" layer="51"/>
<rectangle x1="53.086" y1="4.826" x2="53.594" y2="5.334" layer="51"/>
<rectangle x1="50.546" y1="4.826" x2="51.054" y2="5.334" layer="51"/>
<rectangle x1="48.006" y1="4.826" x2="48.514" y2="5.334" layer="51"/>
<rectangle x1="45.466" y1="4.826" x2="45.974" y2="5.334" layer="51"/>
<rectangle x1="42.926" y1="4.826" x2="43.434" y2="5.334" layer="51"/>
<rectangle x1="73.406" y1="4.826" x2="73.914" y2="5.334" layer="51"/>
<rectangle x1="70.866" y1="4.826" x2="71.374" y2="5.334" layer="51"/>
<rectangle x1="68.326" y1="4.826" x2="68.834" y2="5.334" layer="51"/>
<rectangle x1="65.786" y1="4.826" x2="66.294" y2="5.334" layer="51"/>
<rectangle x1="63.246" y1="4.826" x2="63.754" y2="5.334" layer="51"/>
<rectangle x1="60.706" y1="4.826" x2="61.214" y2="5.334" layer="51"/>
<wire x1="0" y1="58.42" x2="80.01" y2="58.42" width="0.127" layer="21"/>
<wire x1="80.01" y1="0" x2="80.01" y2="58.42" width="0.127" layer="21"/>
<wire x1="77.47" y1="0" x2="80.01" y2="0" width="0.127" layer="21"/>
</package>
<package name="ARDUINO2009_1">
<wire x1="0" y1="0" x2="0" y2="53.34" width="0.127" layer="51"/>
<wire x1="0" y1="53.34" x2="64.516" y2="53.34" width="0.127" layer="51"/>
<wire x1="64.516" y1="53.34" x2="66.04" y2="51.816" width="0.127" layer="51"/>
<wire x1="66.04" y1="51.816" x2="66.04" y2="40.386" width="0.127" layer="51"/>
<wire x1="66.04" y1="40.386" x2="68.58" y2="37.846" width="0.127" layer="51"/>
<wire x1="68.58" y1="37.846" x2="68.58" y2="5.08" width="0.127" layer="51"/>
<wire x1="68.58" y1="5.08" x2="66.04" y2="2.54" width="0.127" layer="51"/>
<wire x1="66.04" y1="2.54" x2="66.04" y2="0" width="0.127" layer="51"/>
<wire x1="66.04" y1="0" x2="0" y2="0" width="0.127" layer="51"/>
<wire x1="38.481" y1="52.07" x2="39.751" y2="52.07" width="0.1524" layer="21"/>
<wire x1="39.751" y1="52.07" x2="40.386" y2="51.435" width="0.1524" layer="21"/>
<wire x1="40.386" y1="51.435" x2="40.386" y2="50.165" width="0.1524" layer="21"/>
<wire x1="40.386" y1="50.165" x2="39.751" y2="49.53" width="0.1524" layer="21"/>
<wire x1="35.306" y1="51.435" x2="35.941" y2="52.07" width="0.1524" layer="21"/>
<wire x1="35.941" y1="52.07" x2="37.211" y2="52.07" width="0.1524" layer="21"/>
<wire x1="37.211" y1="52.07" x2="37.846" y2="51.435" width="0.1524" layer="21"/>
<wire x1="37.846" y1="51.435" x2="37.846" y2="50.165" width="0.1524" layer="21"/>
<wire x1="37.846" y1="50.165" x2="37.211" y2="49.53" width="0.1524" layer="21"/>
<wire x1="37.211" y1="49.53" x2="35.941" y2="49.53" width="0.1524" layer="21"/>
<wire x1="35.941" y1="49.53" x2="35.306" y2="50.165" width="0.1524" layer="21"/>
<wire x1="38.481" y1="52.07" x2="37.846" y2="51.435" width="0.1524" layer="21"/>
<wire x1="37.846" y1="50.165" x2="38.481" y2="49.53" width="0.1524" layer="21"/>
<wire x1="39.751" y1="49.53" x2="38.481" y2="49.53" width="0.1524" layer="21"/>
<wire x1="30.861" y1="52.07" x2="32.131" y2="52.07" width="0.1524" layer="21"/>
<wire x1="32.131" y1="52.07" x2="32.766" y2="51.435" width="0.1524" layer="21"/>
<wire x1="32.766" y1="51.435" x2="32.766" y2="50.165" width="0.1524" layer="21"/>
<wire x1="32.766" y1="50.165" x2="32.131" y2="49.53" width="0.1524" layer="21"/>
<wire x1="32.766" y1="51.435" x2="33.401" y2="52.07" width="0.1524" layer="21"/>
<wire x1="33.401" y1="52.07" x2="34.671" y2="52.07" width="0.1524" layer="21"/>
<wire x1="34.671" y1="52.07" x2="35.306" y2="51.435" width="0.1524" layer="21"/>
<wire x1="35.306" y1="51.435" x2="35.306" y2="50.165" width="0.1524" layer="21"/>
<wire x1="35.306" y1="50.165" x2="34.671" y2="49.53" width="0.1524" layer="21"/>
<wire x1="34.671" y1="49.53" x2="33.401" y2="49.53" width="0.1524" layer="21"/>
<wire x1="33.401" y1="49.53" x2="32.766" y2="50.165" width="0.1524" layer="21"/>
<wire x1="27.686" y1="51.435" x2="28.321" y2="52.07" width="0.1524" layer="21"/>
<wire x1="28.321" y1="52.07" x2="29.591" y2="52.07" width="0.1524" layer="21"/>
<wire x1="29.591" y1="52.07" x2="30.226" y2="51.435" width="0.1524" layer="21"/>
<wire x1="30.226" y1="51.435" x2="30.226" y2="50.165" width="0.1524" layer="21"/>
<wire x1="30.226" y1="50.165" x2="29.591" y2="49.53" width="0.1524" layer="21"/>
<wire x1="29.591" y1="49.53" x2="28.321" y2="49.53" width="0.1524" layer="21"/>
<wire x1="28.321" y1="49.53" x2="27.686" y2="50.165" width="0.1524" layer="21"/>
<wire x1="30.861" y1="52.07" x2="30.226" y2="51.435" width="0.1524" layer="21"/>
<wire x1="30.226" y1="50.165" x2="30.861" y2="49.53" width="0.1524" layer="21"/>
<wire x1="32.131" y1="49.53" x2="30.861" y2="49.53" width="0.1524" layer="21"/>
<wire x1="23.241" y1="52.07" x2="24.511" y2="52.07" width="0.1524" layer="21"/>
<wire x1="24.511" y1="52.07" x2="25.146" y2="51.435" width="0.1524" layer="21"/>
<wire x1="25.146" y1="51.435" x2="25.146" y2="50.165" width="0.1524" layer="21"/>
<wire x1="25.146" y1="50.165" x2="24.511" y2="49.53" width="0.1524" layer="21"/>
<wire x1="25.146" y1="51.435" x2="25.781" y2="52.07" width="0.1524" layer="21"/>
<wire x1="25.781" y1="52.07" x2="27.051" y2="52.07" width="0.1524" layer="21"/>
<wire x1="27.051" y1="52.07" x2="27.686" y2="51.435" width="0.1524" layer="21"/>
<wire x1="27.686" y1="51.435" x2="27.686" y2="50.165" width="0.1524" layer="21"/>
<wire x1="27.686" y1="50.165" x2="27.051" y2="49.53" width="0.1524" layer="21"/>
<wire x1="27.051" y1="49.53" x2="25.781" y2="49.53" width="0.1524" layer="21"/>
<wire x1="25.781" y1="49.53" x2="25.146" y2="50.165" width="0.1524" layer="21"/>
<wire x1="22.606" y1="51.435" x2="22.606" y2="50.165" width="0.1524" layer="21"/>
<wire x1="23.241" y1="52.07" x2="22.606" y2="51.435" width="0.1524" layer="21"/>
<wire x1="22.606" y1="50.165" x2="23.241" y2="49.53" width="0.1524" layer="21"/>
<wire x1="24.511" y1="49.53" x2="23.241" y2="49.53" width="0.1524" layer="21"/>
<wire x1="41.021" y1="52.07" x2="42.291" y2="52.07" width="0.1524" layer="21"/>
<wire x1="42.291" y1="52.07" x2="42.926" y2="51.435" width="0.1524" layer="21"/>
<wire x1="42.926" y1="51.435" x2="42.926" y2="50.165" width="0.1524" layer="21"/>
<wire x1="42.926" y1="50.165" x2="42.291" y2="49.53" width="0.1524" layer="21"/>
<wire x1="41.021" y1="52.07" x2="40.386" y2="51.435" width="0.1524" layer="21"/>
<wire x1="40.386" y1="50.165" x2="41.021" y2="49.53" width="0.1524" layer="21"/>
<wire x1="42.291" y1="49.53" x2="41.021" y2="49.53" width="0.1524" layer="21"/>
<wire x1="60.325" y1="52.07" x2="61.595" y2="52.07" width="0.1524" layer="21"/>
<wire x1="61.595" y1="52.07" x2="62.23" y2="51.435" width="0.1524" layer="21"/>
<wire x1="62.23" y1="51.435" x2="62.23" y2="50.165" width="0.1524" layer="21"/>
<wire x1="62.23" y1="50.165" x2="61.595" y2="49.53" width="0.1524" layer="21"/>
<wire x1="57.15" y1="51.435" x2="57.785" y2="52.07" width="0.1524" layer="21"/>
<wire x1="57.785" y1="52.07" x2="59.055" y2="52.07" width="0.1524" layer="21"/>
<wire x1="59.055" y1="52.07" x2="59.69" y2="51.435" width="0.1524" layer="21"/>
<wire x1="59.69" y1="51.435" x2="59.69" y2="50.165" width="0.1524" layer="21"/>
<wire x1="59.69" y1="50.165" x2="59.055" y2="49.53" width="0.1524" layer="21"/>
<wire x1="59.055" y1="49.53" x2="57.785" y2="49.53" width="0.1524" layer="21"/>
<wire x1="57.785" y1="49.53" x2="57.15" y2="50.165" width="0.1524" layer="21"/>
<wire x1="60.325" y1="52.07" x2="59.69" y2="51.435" width="0.1524" layer="21"/>
<wire x1="59.69" y1="50.165" x2="60.325" y2="49.53" width="0.1524" layer="21"/>
<wire x1="61.595" y1="49.53" x2="60.325" y2="49.53" width="0.1524" layer="21"/>
<wire x1="52.705" y1="52.07" x2="53.975" y2="52.07" width="0.1524" layer="21"/>
<wire x1="53.975" y1="52.07" x2="54.61" y2="51.435" width="0.1524" layer="21"/>
<wire x1="54.61" y1="51.435" x2="54.61" y2="50.165" width="0.1524" layer="21"/>
<wire x1="54.61" y1="50.165" x2="53.975" y2="49.53" width="0.1524" layer="21"/>
<wire x1="54.61" y1="51.435" x2="55.245" y2="52.07" width="0.1524" layer="21"/>
<wire x1="55.245" y1="52.07" x2="56.515" y2="52.07" width="0.1524" layer="21"/>
<wire x1="56.515" y1="52.07" x2="57.15" y2="51.435" width="0.1524" layer="21"/>
<wire x1="57.15" y1="51.435" x2="57.15" y2="50.165" width="0.1524" layer="21"/>
<wire x1="57.15" y1="50.165" x2="56.515" y2="49.53" width="0.1524" layer="21"/>
<wire x1="56.515" y1="49.53" x2="55.245" y2="49.53" width="0.1524" layer="21"/>
<wire x1="55.245" y1="49.53" x2="54.61" y2="50.165" width="0.1524" layer="21"/>
<wire x1="49.53" y1="51.435" x2="50.165" y2="52.07" width="0.1524" layer="21"/>
<wire x1="50.165" y1="52.07" x2="51.435" y2="52.07" width="0.1524" layer="21"/>
<wire x1="51.435" y1="52.07" x2="52.07" y2="51.435" width="0.1524" layer="21"/>
<wire x1="52.07" y1="51.435" x2="52.07" y2="50.165" width="0.1524" layer="21"/>
<wire x1="52.07" y1="50.165" x2="51.435" y2="49.53" width="0.1524" layer="21"/>
<wire x1="51.435" y1="49.53" x2="50.165" y2="49.53" width="0.1524" layer="21"/>
<wire x1="50.165" y1="49.53" x2="49.53" y2="50.165" width="0.1524" layer="21"/>
<wire x1="52.705" y1="52.07" x2="52.07" y2="51.435" width="0.1524" layer="21"/>
<wire x1="52.07" y1="50.165" x2="52.705" y2="49.53" width="0.1524" layer="21"/>
<wire x1="53.975" y1="49.53" x2="52.705" y2="49.53" width="0.1524" layer="21"/>
<wire x1="45.085" y1="52.07" x2="46.355" y2="52.07" width="0.1524" layer="21"/>
<wire x1="46.355" y1="52.07" x2="46.99" y2="51.435" width="0.1524" layer="21"/>
<wire x1="46.99" y1="51.435" x2="46.99" y2="50.165" width="0.1524" layer="21"/>
<wire x1="46.99" y1="50.165" x2="46.355" y2="49.53" width="0.1524" layer="21"/>
<wire x1="46.99" y1="51.435" x2="47.625" y2="52.07" width="0.1524" layer="21"/>
<wire x1="47.625" y1="52.07" x2="48.895" y2="52.07" width="0.1524" layer="21"/>
<wire x1="48.895" y1="52.07" x2="49.53" y2="51.435" width="0.1524" layer="21"/>
<wire x1="49.53" y1="51.435" x2="49.53" y2="50.165" width="0.1524" layer="21"/>
<wire x1="49.53" y1="50.165" x2="48.895" y2="49.53" width="0.1524" layer="21"/>
<wire x1="48.895" y1="49.53" x2="47.625" y2="49.53" width="0.1524" layer="21"/>
<wire x1="47.625" y1="49.53" x2="46.99" y2="50.165" width="0.1524" layer="21"/>
<wire x1="44.45" y1="51.435" x2="44.45" y2="50.165" width="0.1524" layer="21"/>
<wire x1="45.085" y1="52.07" x2="44.45" y2="51.435" width="0.1524" layer="21"/>
<wire x1="44.45" y1="50.165" x2="45.085" y2="49.53" width="0.1524" layer="21"/>
<wire x1="46.355" y1="49.53" x2="45.085" y2="49.53" width="0.1524" layer="21"/>
<wire x1="62.865" y1="52.07" x2="64.135" y2="52.07" width="0.1524" layer="21"/>
<wire x1="64.135" y1="52.07" x2="64.77" y2="51.435" width="0.1524" layer="21"/>
<wire x1="64.77" y1="51.435" x2="64.77" y2="50.165" width="0.1524" layer="21"/>
<wire x1="64.77" y1="50.165" x2="64.135" y2="49.53" width="0.1524" layer="21"/>
<wire x1="62.865" y1="52.07" x2="62.23" y2="51.435" width="0.1524" layer="21"/>
<wire x1="62.23" y1="50.165" x2="62.865" y2="49.53" width="0.1524" layer="21"/>
<wire x1="64.135" y1="49.53" x2="62.865" y2="49.53" width="0.1524" layer="21"/>
<wire x1="45.085" y1="3.81" x2="46.355" y2="3.81" width="0.1524" layer="21"/>
<wire x1="46.355" y1="3.81" x2="46.99" y2="3.175" width="0.1524" layer="21"/>
<wire x1="46.99" y1="1.905" x2="46.355" y2="1.27" width="0.1524" layer="21"/>
<wire x1="41.91" y1="3.175" x2="42.545" y2="3.81" width="0.1524" layer="21"/>
<wire x1="42.545" y1="3.81" x2="43.815" y2="3.81" width="0.1524" layer="21"/>
<wire x1="43.815" y1="3.81" x2="44.45" y2="3.175" width="0.1524" layer="21"/>
<wire x1="44.45" y1="3.175" x2="44.45" y2="1.905" width="0.1524" layer="21"/>
<wire x1="44.45" y1="1.905" x2="43.815" y2="1.27" width="0.1524" layer="21"/>
<wire x1="43.815" y1="1.27" x2="42.545" y2="1.27" width="0.1524" layer="21"/>
<wire x1="42.545" y1="1.27" x2="41.91" y2="1.905" width="0.1524" layer="21"/>
<wire x1="45.085" y1="3.81" x2="44.45" y2="3.175" width="0.1524" layer="21"/>
<wire x1="44.45" y1="1.905" x2="45.085" y2="1.27" width="0.1524" layer="21"/>
<wire x1="46.355" y1="1.27" x2="45.085" y2="1.27" width="0.1524" layer="21"/>
<wire x1="37.465" y1="3.81" x2="38.735" y2="3.81" width="0.1524" layer="21"/>
<wire x1="38.735" y1="3.81" x2="39.37" y2="3.175" width="0.1524" layer="21"/>
<wire x1="39.37" y1="3.175" x2="39.37" y2="1.905" width="0.1524" layer="21"/>
<wire x1="39.37" y1="1.905" x2="38.735" y2="1.27" width="0.1524" layer="21"/>
<wire x1="39.37" y1="3.175" x2="40.005" y2="3.81" width="0.1524" layer="21"/>
<wire x1="40.005" y1="3.81" x2="41.275" y2="3.81" width="0.1524" layer="21"/>
<wire x1="41.275" y1="3.81" x2="41.91" y2="3.175" width="0.1524" layer="21"/>
<wire x1="41.91" y1="3.175" x2="41.91" y2="1.905" width="0.1524" layer="21"/>
<wire x1="41.91" y1="1.905" x2="41.275" y2="1.27" width="0.1524" layer="21"/>
<wire x1="41.275" y1="1.27" x2="40.005" y2="1.27" width="0.1524" layer="21"/>
<wire x1="40.005" y1="1.27" x2="39.37" y2="1.905" width="0.1524" layer="21"/>
<wire x1="34.29" y1="3.175" x2="34.925" y2="3.81" width="0.1524" layer="21"/>
<wire x1="34.925" y1="3.81" x2="36.195" y2="3.81" width="0.1524" layer="21"/>
<wire x1="36.195" y1="3.81" x2="36.83" y2="3.175" width="0.1524" layer="21"/>
<wire x1="36.83" y1="3.175" x2="36.83" y2="1.905" width="0.1524" layer="21"/>
<wire x1="36.83" y1="1.905" x2="36.195" y2="1.27" width="0.1524" layer="21"/>
<wire x1="36.195" y1="1.27" x2="34.925" y2="1.27" width="0.1524" layer="21"/>
<wire x1="34.925" y1="1.27" x2="34.29" y2="1.905" width="0.1524" layer="21"/>
<wire x1="37.465" y1="3.81" x2="36.83" y2="3.175" width="0.1524" layer="21"/>
<wire x1="36.83" y1="1.905" x2="37.465" y2="1.27" width="0.1524" layer="21"/>
<wire x1="38.735" y1="1.27" x2="37.465" y2="1.27" width="0.1524" layer="21"/>
<wire x1="31.75" y1="3.175" x2="31.75" y2="1.905" width="0.1524" layer="21"/>
<wire x1="31.75" y1="3.175" x2="32.385" y2="3.81" width="0.1524" layer="21"/>
<wire x1="32.385" y1="3.81" x2="33.655" y2="3.81" width="0.1524" layer="21"/>
<wire x1="33.655" y1="3.81" x2="34.29" y2="3.175" width="0.1524" layer="21"/>
<wire x1="34.29" y1="3.175" x2="34.29" y2="1.905" width="0.1524" layer="21"/>
<wire x1="34.29" y1="1.905" x2="33.655" y2="1.27" width="0.1524" layer="21"/>
<wire x1="33.655" y1="1.27" x2="32.385" y2="1.27" width="0.1524" layer="21"/>
<wire x1="32.385" y1="1.27" x2="31.75" y2="1.905" width="0.1524" layer="21"/>
<wire x1="62.865" y1="3.81" x2="64.135" y2="3.81" width="0.1524" layer="21"/>
<wire x1="64.135" y1="3.81" x2="64.77" y2="3.175" width="0.1524" layer="21"/>
<wire x1="64.77" y1="3.175" x2="64.77" y2="1.905" width="0.1524" layer="21"/>
<wire x1="64.77" y1="1.905" x2="64.135" y2="1.27" width="0.1524" layer="21"/>
<wire x1="59.69" y1="3.175" x2="60.325" y2="3.81" width="0.1524" layer="21"/>
<wire x1="60.325" y1="3.81" x2="61.595" y2="3.81" width="0.1524" layer="21"/>
<wire x1="61.595" y1="3.81" x2="62.23" y2="3.175" width="0.1524" layer="21"/>
<wire x1="62.23" y1="3.175" x2="62.23" y2="1.905" width="0.1524" layer="21"/>
<wire x1="62.23" y1="1.905" x2="61.595" y2="1.27" width="0.1524" layer="21"/>
<wire x1="61.595" y1="1.27" x2="60.325" y2="1.27" width="0.1524" layer="21"/>
<wire x1="60.325" y1="1.27" x2="59.69" y2="1.905" width="0.1524" layer="21"/>
<wire x1="62.865" y1="3.81" x2="62.23" y2="3.175" width="0.1524" layer="21"/>
<wire x1="62.23" y1="1.905" x2="62.865" y2="1.27" width="0.1524" layer="21"/>
<wire x1="64.135" y1="1.27" x2="62.865" y2="1.27" width="0.1524" layer="21"/>
<wire x1="55.245" y1="3.81" x2="56.515" y2="3.81" width="0.1524" layer="21"/>
<wire x1="56.515" y1="3.81" x2="57.15" y2="3.175" width="0.1524" layer="21"/>
<wire x1="57.15" y1="3.175" x2="57.15" y2="1.905" width="0.1524" layer="21"/>
<wire x1="57.15" y1="1.905" x2="56.515" y2="1.27" width="0.1524" layer="21"/>
<wire x1="57.15" y1="3.175" x2="57.785" y2="3.81" width="0.1524" layer="21"/>
<wire x1="57.785" y1="3.81" x2="59.055" y2="3.81" width="0.1524" layer="21"/>
<wire x1="59.055" y1="3.81" x2="59.69" y2="3.175" width="0.1524" layer="21"/>
<wire x1="59.69" y1="3.175" x2="59.69" y2="1.905" width="0.1524" layer="21"/>
<wire x1="59.69" y1="1.905" x2="59.055" y2="1.27" width="0.1524" layer="21"/>
<wire x1="59.055" y1="1.27" x2="57.785" y2="1.27" width="0.1524" layer="21"/>
<wire x1="57.785" y1="1.27" x2="57.15" y2="1.905" width="0.1524" layer="21"/>
<wire x1="52.07" y1="3.175" x2="52.705" y2="3.81" width="0.1524" layer="21"/>
<wire x1="52.705" y1="3.81" x2="53.975" y2="3.81" width="0.1524" layer="21"/>
<wire x1="53.975" y1="3.81" x2="54.61" y2="3.175" width="0.1524" layer="21"/>
<wire x1="54.61" y1="3.175" x2="54.61" y2="1.905" width="0.1524" layer="21"/>
<wire x1="54.61" y1="1.905" x2="53.975" y2="1.27" width="0.1524" layer="21"/>
<wire x1="53.975" y1="1.27" x2="52.705" y2="1.27" width="0.1524" layer="21"/>
<wire x1="52.705" y1="1.27" x2="52.07" y2="1.905" width="0.1524" layer="21"/>
<wire x1="55.245" y1="3.81" x2="54.61" y2="3.175" width="0.1524" layer="21"/>
<wire x1="54.61" y1="1.905" x2="55.245" y2="1.27" width="0.1524" layer="21"/>
<wire x1="56.515" y1="1.27" x2="55.245" y2="1.27" width="0.1524" layer="21"/>
<wire x1="49.53" y1="3.175" x2="49.53" y2="1.905" width="0.1524" layer="21"/>
<wire x1="49.53" y1="3.175" x2="50.165" y2="3.81" width="0.1524" layer="21"/>
<wire x1="50.165" y1="3.81" x2="51.435" y2="3.81" width="0.1524" layer="21"/>
<wire x1="51.435" y1="3.81" x2="52.07" y2="3.175" width="0.1524" layer="21"/>
<wire x1="52.07" y1="3.175" x2="52.07" y2="1.905" width="0.1524" layer="21"/>
<wire x1="52.07" y1="1.905" x2="51.435" y2="1.27" width="0.1524" layer="21"/>
<wire x1="51.435" y1="1.27" x2="50.165" y2="1.27" width="0.1524" layer="21"/>
<wire x1="50.165" y1="1.27" x2="49.53" y2="1.905" width="0.1524" layer="21"/>
<wire x1="46.99" y1="3.175" x2="46.99" y2="1.905" width="0.1524" layer="21"/>
<pad name="28" x="23.876" y="50.8" drill="1.016" shape="long" rot="R90"/>
<pad name="27" x="26.416" y="50.8" drill="1.016" shape="long" rot="R90"/>
<pad name="26" x="28.956" y="50.8" drill="1.016" shape="long" rot="R90"/>
<pad name="25" x="31.496" y="50.8" drill="1.016" shape="long" rot="R90"/>
<pad name="24" x="34.036" y="50.8" drill="1.016" shape="long" rot="R90"/>
<pad name="23" x="36.576" y="50.8" drill="1.016" shape="long" rot="R90"/>
<pad name="22" x="39.116" y="50.8" drill="1.016" shape="long" rot="R90"/>
<pad name="21" x="41.656" y="50.8" drill="1.016" shape="long" rot="R90"/>
<pad name="20" x="45.72" y="50.8" drill="1.016" shape="long" rot="R90"/>
<pad name="19" x="48.26" y="50.8" drill="1.016" shape="long" rot="R90"/>
<pad name="18" x="50.8" y="50.8" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="53.34" y="50.8" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="55.88" y="50.8" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="58.42" y="50.8" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="60.96" y="50.8" drill="1.016" shape="long" rot="R90"/>
<pad name="13" x="63.5" y="50.8" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="33.02" y="2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="35.56" y="2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="38.1" y="2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="40.64" y="2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="43.18" y="2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="6" x="45.72" y="2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="7" x="50.8" y="2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="8" x="53.34" y="2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="9" x="55.88" y="2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="10" x="58.42" y="2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="11" x="60.96" y="2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="12" x="63.5" y="2.54" drill="1.016" shape="long" rot="R90"/>
<text x="23.1184" y="48.7812" size="1.016" layer="48" font="vector" ratio="10" rot="R270">AREF</text>
<text x="25.654" y="48.768" size="1.016" layer="48" font="vector" ratio="10" rot="R270">GND</text>
<text x="28.194" y="48.768" size="1.016" layer="48" font="vector" ratio="10" rot="R270">PB5</text>
<text x="30.734" y="48.768" size="1.016" layer="48" font="vector" ratio="10" rot="R270">PB4</text>
<text x="33.274" y="48.768" size="1.016" layer="48" font="vector" ratio="10" rot="R270">PB3</text>
<text x="35.814" y="48.768" size="1.016" layer="48" font="vector" ratio="10" rot="R270">PB2</text>
<text x="38.354" y="48.768" size="1.016" layer="48" font="vector" ratio="10" rot="R270">PB1</text>
<text x="40.894" y="48.768" size="1.016" layer="48" font="vector" ratio="10" rot="R270">PB0</text>
<text x="44.958" y="48.768" size="1.016" layer="48" font="vector" ratio="10" rot="R270">PD7</text>
<text x="47.498" y="48.768" size="1.016" layer="48" font="vector" ratio="10" rot="R270">PD6</text>
<text x="50.038" y="48.768" size="1.016" layer="48" font="vector" ratio="10" rot="R270">PD5</text>
<text x="52.578" y="48.768" size="1.016" layer="48" font="vector" ratio="10" rot="R270">PD4</text>
<text x="55.118" y="48.768" size="1.016" layer="48" font="vector" ratio="10" rot="R270">PD3</text>
<text x="57.658" y="48.768" size="1.016" layer="48" font="vector" ratio="10" rot="R270">PD2</text>
<text x="60.198" y="48.768" size="1.016" layer="48" font="vector" ratio="10" rot="R270">PD1</text>
<text x="62.738" y="48.768" size="1.016" layer="48" font="vector" ratio="10" rot="R270">PD0</text>
<text x="33.7776" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">!Reset</text>
<text x="36.3176" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">+3V3</text>
<text x="38.8576" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">+5V</text>
<text x="41.3976" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">GND</text>
<text x="43.9376" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">GND</text>
<text x="46.4776" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">+Vin</text>
<text x="51.5576" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">PC0</text>
<text x="54.0976" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">PC1</text>
<text x="56.6376" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">PC2</text>
<text x="59.1776" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">PC3</text>
<text x="61.7176" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">PC4</text>
<text x="64.2576" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">PC5</text>
<rectangle x1="38.862" y1="50.546" x2="39.37" y2="51.054" layer="51"/>
<rectangle x1="36.322" y1="50.546" x2="36.83" y2="51.054" layer="51"/>
<rectangle x1="33.782" y1="50.546" x2="34.29" y2="51.054" layer="51"/>
<rectangle x1="31.242" y1="50.546" x2="31.75" y2="51.054" layer="51"/>
<rectangle x1="28.702" y1="50.546" x2="29.21" y2="51.054" layer="51"/>
<rectangle x1="26.162" y1="50.546" x2="26.67" y2="51.054" layer="51"/>
<rectangle x1="23.622" y1="50.546" x2="24.13" y2="51.054" layer="51"/>
<rectangle x1="41.402" y1="50.546" x2="41.91" y2="51.054" layer="51"/>
<rectangle x1="60.706" y1="50.546" x2="61.214" y2="51.054" layer="51"/>
<rectangle x1="58.166" y1="50.546" x2="58.674" y2="51.054" layer="51"/>
<rectangle x1="55.626" y1="50.546" x2="56.134" y2="51.054" layer="51"/>
<rectangle x1="53.086" y1="50.546" x2="53.594" y2="51.054" layer="51"/>
<rectangle x1="50.546" y1="50.546" x2="51.054" y2="51.054" layer="51"/>
<rectangle x1="48.006" y1="50.546" x2="48.514" y2="51.054" layer="51"/>
<rectangle x1="45.466" y1="50.546" x2="45.974" y2="51.054" layer="51"/>
<rectangle x1="63.246" y1="50.546" x2="63.754" y2="51.054" layer="51"/>
<rectangle x1="45.466" y1="2.286" x2="45.974" y2="2.794" layer="51"/>
<rectangle x1="42.926" y1="2.286" x2="43.434" y2="2.794" layer="51"/>
<rectangle x1="40.386" y1="2.286" x2="40.894" y2="2.794" layer="51"/>
<rectangle x1="37.846" y1="2.286" x2="38.354" y2="2.794" layer="51"/>
<rectangle x1="35.306" y1="2.286" x2="35.814" y2="2.794" layer="51"/>
<rectangle x1="32.766" y1="2.286" x2="33.274" y2="2.794" layer="51"/>
<rectangle x1="63.246" y1="2.286" x2="63.754" y2="2.794" layer="51"/>
<rectangle x1="60.706" y1="2.286" x2="61.214" y2="2.794" layer="51"/>
<rectangle x1="58.166" y1="2.286" x2="58.674" y2="2.794" layer="51"/>
<rectangle x1="55.626" y1="2.286" x2="56.134" y2="2.794" layer="51"/>
<rectangle x1="53.086" y1="2.286" x2="53.594" y2="2.794" layer="51"/>
<rectangle x1="50.546" y1="2.286" x2="51.054" y2="2.794" layer="51"/>
<hole x="15.24" y="50.8" drill="3.2"/>
<hole x="66.04" y="35.56" drill="3.2"/>
<hole x="66.04" y="7.62" drill="3.2"/>
<hole x="55.1696" y="27.1138" drill="2"/>
</package>
<package name="ARDUINO2009_2">
</package>
<package name="MEGA_ARDUINO">
<wire x1="96.52" y1="53.34" x2="99.06" y2="50.8" width="0.127" layer="51"/>
<wire x1="99.06" y1="50.8" x2="99.06" y2="40.64" width="0.127" layer="51"/>
<wire x1="99.06" y1="40.64" x2="101.6" y2="38.1" width="0.127" layer="51"/>
<wire x1="101.6" y1="38.1" x2="101.6" y2="3.81" width="0.127" layer="51"/>
<wire x1="101.6" y1="3.81" x2="99.06" y2="1.27" width="0.127" layer="51"/>
<wire x1="99.06" y1="1.27" x2="99.06" y2="0" width="0.127" layer="51"/>
<wire x1="99.06" y1="0" x2="0" y2="0" width="0.127" layer="51"/>
<wire x1="63.627" y1="27.94" x2="66.167" y2="27.94" width="0" layer="37"/>
<wire x1="64.897" y1="26.67" x2="64.897" y2="29.21" width="0" layer="37"/>
<wire x1="67.945" y1="3.81" x2="69.215" y2="3.81" width="0.1524" layer="21"/>
<wire x1="69.215" y1="3.81" x2="69.85" y2="3.175" width="0.1524" layer="21"/>
<wire x1="69.85" y1="3.175" x2="69.85" y2="1.905" width="0.1524" layer="21"/>
<wire x1="69.85" y1="1.905" x2="69.215" y2="1.27" width="0.1524" layer="21"/>
<wire x1="64.77" y1="3.175" x2="65.405" y2="3.81" width="0.1524" layer="21"/>
<wire x1="65.405" y1="3.81" x2="66.675" y2="3.81" width="0.1524" layer="21"/>
<wire x1="66.675" y1="3.81" x2="67.31" y2="3.175" width="0.1524" layer="21"/>
<wire x1="67.31" y1="3.175" x2="67.31" y2="1.905" width="0.1524" layer="21"/>
<wire x1="67.31" y1="1.905" x2="66.675" y2="1.27" width="0.1524" layer="21"/>
<wire x1="66.675" y1="1.27" x2="65.405" y2="1.27" width="0.1524" layer="21"/>
<wire x1="65.405" y1="1.27" x2="64.77" y2="1.905" width="0.1524" layer="21"/>
<wire x1="67.945" y1="3.81" x2="67.31" y2="3.175" width="0.1524" layer="21"/>
<wire x1="67.31" y1="1.905" x2="67.945" y2="1.27" width="0.1524" layer="21"/>
<wire x1="69.215" y1="1.27" x2="67.945" y2="1.27" width="0.1524" layer="21"/>
<wire x1="85.725" y1="3.81" x2="86.995" y2="3.81" width="0.1524" layer="21"/>
<wire x1="86.995" y1="3.81" x2="87.63" y2="3.175" width="0.1524" layer="21"/>
<wire x1="87.63" y1="3.175" x2="87.63" y2="1.905" width="0.1524" layer="21"/>
<wire x1="87.63" y1="1.905" x2="86.995" y2="1.27" width="0.1524" layer="21"/>
<wire x1="82.55" y1="3.175" x2="83.185" y2="3.81" width="0.1524" layer="21"/>
<wire x1="83.185" y1="3.81" x2="84.455" y2="3.81" width="0.1524" layer="21"/>
<wire x1="84.455" y1="3.81" x2="85.09" y2="3.175" width="0.1524" layer="21"/>
<wire x1="85.09" y1="3.175" x2="85.09" y2="1.905" width="0.1524" layer="21"/>
<wire x1="85.09" y1="1.905" x2="84.455" y2="1.27" width="0.1524" layer="21"/>
<wire x1="84.455" y1="1.27" x2="83.185" y2="1.27" width="0.1524" layer="21"/>
<wire x1="83.185" y1="1.27" x2="82.55" y2="1.905" width="0.1524" layer="21"/>
<wire x1="85.725" y1="3.81" x2="85.09" y2="3.175" width="0.1524" layer="21"/>
<wire x1="85.09" y1="1.905" x2="85.725" y2="1.27" width="0.1524" layer="21"/>
<wire x1="86.995" y1="1.27" x2="85.725" y2="1.27" width="0.1524" layer="21"/>
<wire x1="78.105" y1="3.81" x2="79.375" y2="3.81" width="0.1524" layer="21"/>
<wire x1="79.375" y1="3.81" x2="80.01" y2="3.175" width="0.1524" layer="21"/>
<wire x1="80.01" y1="3.175" x2="80.01" y2="1.905" width="0.1524" layer="21"/>
<wire x1="80.01" y1="1.905" x2="79.375" y2="1.27" width="0.1524" layer="21"/>
<wire x1="80.01" y1="3.175" x2="80.645" y2="3.81" width="0.1524" layer="21"/>
<wire x1="80.645" y1="3.81" x2="81.915" y2="3.81" width="0.1524" layer="21"/>
<wire x1="81.915" y1="3.81" x2="82.55" y2="3.175" width="0.1524" layer="21"/>
<wire x1="82.55" y1="3.175" x2="82.55" y2="1.905" width="0.1524" layer="21"/>
<wire x1="82.55" y1="1.905" x2="81.915" y2="1.27" width="0.1524" layer="21"/>
<wire x1="81.915" y1="1.27" x2="80.645" y2="1.27" width="0.1524" layer="21"/>
<wire x1="80.645" y1="1.27" x2="80.01" y2="1.905" width="0.1524" layer="21"/>
<wire x1="74.93" y1="3.175" x2="75.565" y2="3.81" width="0.1524" layer="21"/>
<wire x1="75.565" y1="3.81" x2="76.835" y2="3.81" width="0.1524" layer="21"/>
<wire x1="76.835" y1="3.81" x2="77.47" y2="3.175" width="0.1524" layer="21"/>
<wire x1="77.47" y1="3.175" x2="77.47" y2="1.905" width="0.1524" layer="21"/>
<wire x1="77.47" y1="1.905" x2="76.835" y2="1.27" width="0.1524" layer="21"/>
<wire x1="76.835" y1="1.27" x2="75.565" y2="1.27" width="0.1524" layer="21"/>
<wire x1="75.565" y1="1.27" x2="74.93" y2="1.905" width="0.1524" layer="21"/>
<wire x1="78.105" y1="3.81" x2="77.47" y2="3.175" width="0.1524" layer="21"/>
<wire x1="77.47" y1="1.905" x2="78.105" y2="1.27" width="0.1524" layer="21"/>
<wire x1="79.375" y1="1.27" x2="78.105" y2="1.27" width="0.1524" layer="21"/>
<wire x1="72.39" y1="3.175" x2="72.39" y2="1.905" width="0.1524" layer="21"/>
<wire x1="72.39" y1="3.175" x2="73.025" y2="3.81" width="0.1524" layer="21"/>
<wire x1="73.025" y1="3.81" x2="74.295" y2="3.81" width="0.1524" layer="21"/>
<wire x1="74.295" y1="3.81" x2="74.93" y2="3.175" width="0.1524" layer="21"/>
<wire x1="74.93" y1="3.175" x2="74.93" y2="1.905" width="0.1524" layer="21"/>
<wire x1="74.93" y1="1.905" x2="74.295" y2="1.27" width="0.1524" layer="21"/>
<wire x1="74.295" y1="1.27" x2="73.025" y2="1.27" width="0.1524" layer="21"/>
<wire x1="73.025" y1="1.27" x2="72.39" y2="1.905" width="0.1524" layer="21"/>
<wire x1="90.805" y1="3.81" x2="92.075" y2="3.81" width="0.1524" layer="21"/>
<wire x1="92.075" y1="3.81" x2="92.71" y2="3.175" width="0.1524" layer="21"/>
<wire x1="92.71" y1="1.905" x2="92.075" y2="1.27" width="0.1524" layer="21"/>
<wire x1="87.63" y1="3.175" x2="88.265" y2="3.81" width="0.1524" layer="21"/>
<wire x1="88.265" y1="3.81" x2="89.535" y2="3.81" width="0.1524" layer="21"/>
<wire x1="89.535" y1="3.81" x2="90.17" y2="3.175" width="0.1524" layer="21"/>
<wire x1="90.17" y1="3.175" x2="90.17" y2="1.905" width="0.1524" layer="21"/>
<wire x1="90.17" y1="1.905" x2="89.535" y2="1.27" width="0.1524" layer="21"/>
<wire x1="89.535" y1="1.27" x2="88.265" y2="1.27" width="0.1524" layer="21"/>
<wire x1="88.265" y1="1.27" x2="87.63" y2="1.905" width="0.1524" layer="21"/>
<wire x1="90.805" y1="3.81" x2="90.17" y2="3.175" width="0.1524" layer="21"/>
<wire x1="90.17" y1="1.905" x2="90.805" y2="1.27" width="0.1524" layer="21"/>
<wire x1="92.075" y1="1.27" x2="90.805" y2="1.27" width="0.1524" layer="21"/>
<wire x1="49.53" y1="50.165" x2="49.53" y2="51.435" width="0.1524" layer="21"/>
<wire x1="52.705" y1="49.53" x2="52.07" y2="50.165" width="0.1524" layer="21"/>
<wire x1="52.07" y1="50.165" x2="52.07" y2="51.435" width="0.1524" layer="21"/>
<wire x1="52.07" y1="51.435" x2="52.705" y2="52.07" width="0.1524" layer="21"/>
<wire x1="51.435" y1="49.53" x2="52.07" y2="50.165" width="0.1524" layer="21"/>
<wire x1="52.07" y1="51.435" x2="51.435" y2="52.07" width="0.1524" layer="21"/>
<wire x1="57.15" y1="50.165" x2="57.15" y2="51.435" width="0.1524" layer="21"/>
<wire x1="54.61" y1="50.165" x2="54.61" y2="51.435" width="0.1524" layer="21"/>
<wire x1="60.325" y1="49.53" x2="59.69" y2="50.165" width="0.1524" layer="21"/>
<wire x1="59.69" y1="50.165" x2="59.69" y2="51.435" width="0.1524" layer="21"/>
<wire x1="59.69" y1="51.435" x2="60.325" y2="52.07" width="0.1524" layer="21"/>
<wire x1="59.055" y1="49.53" x2="59.69" y2="50.165" width="0.1524" layer="21"/>
<wire x1="59.69" y1="51.435" x2="59.055" y2="52.07" width="0.1524" layer="21"/>
<wire x1="64.77" y1="50.165" x2="64.77" y2="51.435" width="0.1524" layer="21"/>
<wire x1="62.865" y1="49.53" x2="62.23" y2="50.165" width="0.1524" layer="21"/>
<wire x1="62.23" y1="50.165" x2="62.23" y2="51.435" width="0.1524" layer="21"/>
<wire x1="62.23" y1="51.435" x2="62.865" y2="52.07" width="0.1524" layer="21"/>
<wire x1="45.085" y1="49.53" x2="44.45" y2="50.165" width="0.1524" layer="21"/>
<wire x1="44.45" y1="50.165" x2="44.45" y2="51.435" width="0.1524" layer="21"/>
<wire x1="44.45" y1="51.435" x2="45.085" y2="52.07" width="0.1524" layer="21"/>
<wire x1="46.99" y1="50.165" x2="46.99" y2="51.435" width="0.1524" layer="21"/>
<wire x1="46.355" y1="49.53" x2="46.99" y2="50.165" width="0.1524" layer="21"/>
<wire x1="46.99" y1="51.435" x2="46.355" y2="52.07" width="0.1524" layer="21"/>
<wire x1="29.845" y1="49.53" x2="28.575" y2="49.53" width="0.1524" layer="21"/>
<wire x1="28.575" y1="49.53" x2="27.94" y2="50.165" width="0.1524" layer="21"/>
<wire x1="27.94" y1="50.165" x2="27.94" y2="51.435" width="0.1524" layer="21"/>
<wire x1="27.94" y1="51.435" x2="28.575" y2="52.07" width="0.1524" layer="21"/>
<wire x1="33.02" y1="50.165" x2="32.385" y2="49.53" width="0.1524" layer="21"/>
<wire x1="32.385" y1="49.53" x2="31.115" y2="49.53" width="0.1524" layer="21"/>
<wire x1="31.115" y1="49.53" x2="30.48" y2="50.165" width="0.1524" layer="21"/>
<wire x1="30.48" y1="50.165" x2="30.48" y2="51.435" width="0.1524" layer="21"/>
<wire x1="30.48" y1="51.435" x2="31.115" y2="52.07" width="0.1524" layer="21"/>
<wire x1="31.115" y1="52.07" x2="32.385" y2="52.07" width="0.1524" layer="21"/>
<wire x1="32.385" y1="52.07" x2="33.02" y2="51.435" width="0.1524" layer="21"/>
<wire x1="29.845" y1="49.53" x2="30.48" y2="50.165" width="0.1524" layer="21"/>
<wire x1="30.48" y1="51.435" x2="29.845" y2="52.07" width="0.1524" layer="21"/>
<wire x1="28.575" y1="52.07" x2="29.845" y2="52.07" width="0.1524" layer="21"/>
<wire x1="37.465" y1="49.53" x2="36.195" y2="49.53" width="0.1524" layer="21"/>
<wire x1="36.195" y1="49.53" x2="35.56" y2="50.165" width="0.1524" layer="21"/>
<wire x1="35.56" y1="50.165" x2="35.56" y2="51.435" width="0.1524" layer="21"/>
<wire x1="35.56" y1="51.435" x2="36.195" y2="52.07" width="0.1524" layer="21"/>
<wire x1="35.56" y1="50.165" x2="34.925" y2="49.53" width="0.1524" layer="21"/>
<wire x1="34.925" y1="49.53" x2="33.655" y2="49.53" width="0.1524" layer="21"/>
<wire x1="33.655" y1="49.53" x2="33.02" y2="50.165" width="0.1524" layer="21"/>
<wire x1="33.02" y1="50.165" x2="33.02" y2="51.435" width="0.1524" layer="21"/>
<wire x1="33.02" y1="51.435" x2="33.655" y2="52.07" width="0.1524" layer="21"/>
<wire x1="33.655" y1="52.07" x2="34.925" y2="52.07" width="0.1524" layer="21"/>
<wire x1="34.925" y1="52.07" x2="35.56" y2="51.435" width="0.1524" layer="21"/>
<wire x1="40.64" y1="50.165" x2="40.005" y2="49.53" width="0.1524" layer="21"/>
<wire x1="40.005" y1="49.53" x2="38.735" y2="49.53" width="0.1524" layer="21"/>
<wire x1="38.735" y1="49.53" x2="38.1" y2="50.165" width="0.1524" layer="21"/>
<wire x1="38.1" y1="50.165" x2="38.1" y2="51.435" width="0.1524" layer="21"/>
<wire x1="38.1" y1="51.435" x2="38.735" y2="52.07" width="0.1524" layer="21"/>
<wire x1="38.735" y1="52.07" x2="40.005" y2="52.07" width="0.1524" layer="21"/>
<wire x1="40.005" y1="52.07" x2="40.64" y2="51.435" width="0.1524" layer="21"/>
<wire x1="37.465" y1="49.53" x2="38.1" y2="50.165" width="0.1524" layer="21"/>
<wire x1="38.1" y1="51.435" x2="37.465" y2="52.07" width="0.1524" layer="21"/>
<wire x1="36.195" y1="52.07" x2="37.465" y2="52.07" width="0.1524" layer="21"/>
<wire x1="43.18" y1="50.165" x2="43.18" y2="51.435" width="0.1524" layer="21"/>
<wire x1="43.18" y1="50.165" x2="42.545" y2="49.53" width="0.1524" layer="21"/>
<wire x1="42.545" y1="49.53" x2="41.275" y2="49.53" width="0.1524" layer="21"/>
<wire x1="41.275" y1="49.53" x2="40.64" y2="50.165" width="0.1524" layer="21"/>
<wire x1="40.64" y1="50.165" x2="40.64" y2="51.435" width="0.1524" layer="21"/>
<wire x1="40.64" y1="51.435" x2="41.275" y2="52.07" width="0.1524" layer="21"/>
<wire x1="41.275" y1="52.07" x2="42.545" y2="52.07" width="0.1524" layer="21"/>
<wire x1="42.545" y1="52.07" x2="43.18" y2="51.435" width="0.1524" layer="21"/>
<wire x1="24.765" y1="49.53" x2="23.495" y2="49.53" width="0.1524" layer="21"/>
<wire x1="23.495" y1="49.53" x2="22.86" y2="50.165" width="0.1524" layer="21"/>
<wire x1="22.86" y1="50.165" x2="22.86" y2="51.435" width="0.1524" layer="21"/>
<wire x1="22.86" y1="51.435" x2="23.495" y2="52.07" width="0.1524" layer="21"/>
<wire x1="27.94" y1="50.165" x2="27.305" y2="49.53" width="0.1524" layer="21"/>
<wire x1="27.305" y1="49.53" x2="26.035" y2="49.53" width="0.1524" layer="21"/>
<wire x1="26.035" y1="49.53" x2="25.4" y2="50.165" width="0.1524" layer="21"/>
<wire x1="25.4" y1="50.165" x2="25.4" y2="51.435" width="0.1524" layer="21"/>
<wire x1="25.4" y1="51.435" x2="26.035" y2="52.07" width="0.1524" layer="21"/>
<wire x1="26.035" y1="52.07" x2="27.305" y2="52.07" width="0.1524" layer="21"/>
<wire x1="27.305" y1="52.07" x2="27.94" y2="51.435" width="0.1524" layer="21"/>
<wire x1="24.765" y1="49.53" x2="25.4" y2="50.165" width="0.1524" layer="21"/>
<wire x1="25.4" y1="51.435" x2="24.765" y2="52.07" width="0.1524" layer="21"/>
<wire x1="23.495" y1="52.07" x2="24.765" y2="52.07" width="0.1524" layer="21"/>
<wire x1="93.345" y1="49.53" x2="92.71" y2="48.895" width="0.1524" layer="21"/>
<wire x1="92.71" y1="48.895" x2="92.71" y2="47.625" width="0.1524" layer="21"/>
<wire x1="92.71" y1="47.625" x2="93.345" y2="46.99" width="0.1524" layer="21"/>
<wire x1="93.345" y1="46.99" x2="92.71" y2="46.355" width="0.1524" layer="21"/>
<wire x1="92.71" y1="46.355" x2="92.71" y2="45.085" width="0.1524" layer="21"/>
<wire x1="92.71" y1="45.085" x2="93.345" y2="44.45" width="0.1524" layer="21"/>
<wire x1="93.345" y1="44.45" x2="92.71" y2="43.815" width="0.1524" layer="21"/>
<wire x1="92.71" y1="43.815" x2="92.71" y2="42.545" width="0.1524" layer="21"/>
<wire x1="92.71" y1="42.545" x2="93.345" y2="41.91" width="0.1524" layer="21"/>
<wire x1="93.345" y1="41.91" x2="92.71" y2="41.275" width="0.1524" layer="21"/>
<wire x1="92.71" y1="41.275" x2="92.71" y2="40.005" width="0.1524" layer="21"/>
<wire x1="92.71" y1="40.005" x2="93.345" y2="39.37" width="0.1524" layer="21"/>
<wire x1="97.155" y1="49.53" x2="97.79" y2="48.895" width="0.1524" layer="21"/>
<wire x1="97.79" y1="48.895" x2="97.79" y2="47.625" width="0.1524" layer="21"/>
<wire x1="97.79" y1="47.625" x2="97.155" y2="46.99" width="0.1524" layer="21"/>
<wire x1="97.155" y1="46.99" x2="97.79" y2="46.355" width="0.1524" layer="21"/>
<wire x1="97.79" y1="46.355" x2="97.79" y2="45.085" width="0.1524" layer="21"/>
<wire x1="97.79" y1="45.085" x2="97.155" y2="44.45" width="0.1524" layer="21"/>
<wire x1="97.155" y1="44.45" x2="97.79" y2="43.815" width="0.1524" layer="21"/>
<wire x1="97.79" y1="43.815" x2="97.79" y2="42.545" width="0.1524" layer="21"/>
<wire x1="97.79" y1="42.545" x2="97.155" y2="41.91" width="0.1524" layer="21"/>
<wire x1="97.155" y1="41.91" x2="97.79" y2="41.275" width="0.1524" layer="21"/>
<wire x1="97.79" y1="41.275" x2="97.79" y2="40.005" width="0.1524" layer="21"/>
<wire x1="97.79" y1="40.005" x2="97.155" y2="39.37" width="0.1524" layer="21"/>
<wire x1="97.155" y1="49.53" x2="93.345" y2="49.53" width="0.1524" layer="21"/>
<wire x1="97.155" y1="46.99" x2="93.345" y2="46.99" width="0.1524" layer="21"/>
<wire x1="97.155" y1="44.45" x2="93.345" y2="44.45" width="0.1524" layer="21"/>
<wire x1="97.155" y1="41.91" x2="93.345" y2="41.91" width="0.1524" layer="21"/>
<wire x1="97.155" y1="39.37" x2="93.345" y2="39.37" width="0.1524" layer="21"/>
<pad name="13" x="66.04" y="2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="14" x="68.58" y="2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="15" x="73.66" y="2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="16" x="76.2" y="2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="17" x="78.74" y="2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="18" x="81.28" y="2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="19" x="83.82" y="2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="20" x="86.36" y="2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="21" x="88.9" y="2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="22" x="91.44" y="2.54" drill="1.016" shape="long" rot="R90"/>
<pad name="31" x="63.5" y="50.8" drill="1.016" shape="long" rot="R270"/>
<pad name="32" x="60.96" y="50.8" drill="1.016" shape="long" rot="R270"/>
<pad name="33" x="58.42" y="50.8" drill="1.016" shape="long" rot="R270"/>
<pad name="34" x="55.88" y="50.8" drill="1.016" shape="long" rot="R270"/>
<pad name="35" x="53.34" y="50.8" drill="1.016" shape="long" rot="R270"/>
<pad name="36" x="50.8" y="50.8" drill="1.016" shape="long" rot="R270"/>
<pad name="37" x="48.26" y="50.8" drill="1.016" shape="long" rot="R270"/>
<pad name="38" x="45.72" y="50.8" drill="1.016" shape="long" rot="R270"/>
<pad name="39" x="41.91" y="50.8" drill="1.016" shape="long" rot="R270"/>
<pad name="40" x="39.37" y="50.8" drill="1.016" shape="long" rot="R270"/>
<pad name="41" x="36.83" y="50.8" drill="1.016" shape="long" rot="R270"/>
<pad name="42" x="34.29" y="50.8" drill="1.016" shape="long" rot="R270"/>
<pad name="43" x="31.75" y="50.8" drill="1.016" shape="long" rot="R270"/>
<pad name="44" x="29.21" y="50.8" drill="1.016" shape="long" rot="R270"/>
<pad name="45" x="26.67" y="50.8" drill="1.016" shape="long" rot="R270"/>
<pad name="46" x="24.13" y="50.8" drill="1.016" shape="long" rot="R270"/>
<pad name="49" x="93.98" y="48.26" drill="1.016" shape="octagon" rot="R270"/>
<pad name="50" x="96.52" y="48.26" drill="1.016" shape="octagon" rot="R270"/>
<pad name="51" x="93.98" y="45.72" drill="1.016" shape="octagon" rot="R270"/>
<pad name="52" x="96.52" y="45.72" drill="1.016" shape="octagon" rot="R270"/>
<pad name="53" x="93.98" y="43.18" drill="1.016" shape="octagon" rot="R270"/>
<pad name="54" x="96.52" y="43.18" drill="1.016" shape="octagon" rot="R270"/>
<pad name="55" x="93.98" y="40.64" drill="1.016" shape="octagon" rot="R270"/>
<pad name="56" x="96.52" y="40.64" drill="1.016" shape="octagon" rot="R270"/>
<text x="51.5576" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">A0</text>
<text x="54.0976" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">A1</text>
<text x="56.6376" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">A2</text>
<text x="59.1776" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">A3</text>
<text x="61.7176" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">A4</text>
<text x="64.2576" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">A5</text>
<text x="66.7976" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">A6</text>
<text x="69.3376" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">A7</text>
<text x="74.4176" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">A8</text>
<text x="76.9576" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">A9</text>
<text x="79.4976" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">A10</text>
<text x="82.0376" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">A11</text>
<text x="84.5776" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">A12</text>
<text x="87.1176" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">A13</text>
<text x="89.6576" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">A14</text>
<text x="92.1976" y="4.8128" size="1.016" layer="48" font="vector" ratio="10" rot="R90">A15</text>
<text x="62.7424" y="48.5272" size="1.016" layer="48" font="vector" ratio="10" rot="R270">Rx0 0</text>
<text x="60.2024" y="48.5272" size="1.016" layer="48" font="vector" ratio="10" rot="R270">Tx0 1</text>
<text x="57.6624" y="48.5272" size="1.016" layer="48" font="vector" ratio="10" rot="R270">PWM 2</text>
<text x="55.1224" y="48.5272" size="1.016" layer="48" font="vector" ratio="10" rot="R270">3</text>
<text x="52.5824" y="48.5272" size="1.016" layer="48" font="vector" ratio="10" rot="R270">4</text>
<text x="50.0424" y="48.5272" size="1.016" layer="48" font="vector" ratio="10" rot="R270">5</text>
<text x="47.5024" y="48.5272" size="1.016" layer="48" font="vector" ratio="10" rot="R270">6</text>
<text x="44.9624" y="48.5272" size="1.016" layer="48" font="vector" ratio="10" rot="R270">7</text>
<text x="41.1524" y="48.5272" size="1.016" layer="48" font="vector" ratio="10" rot="R270">8</text>
<text x="38.6124" y="48.5272" size="1.016" layer="48" font="vector" ratio="10" rot="R270">9</text>
<text x="36.0724" y="48.5272" size="1.016" layer="48" font="vector" ratio="10" rot="R270">10</text>
<text x="33.5324" y="48.5272" size="1.016" layer="48" font="vector" ratio="10" rot="R270">11</text>
<text x="30.9924" y="48.5272" size="1.016" layer="48" font="vector" ratio="10" rot="R270">12</text>
<text x="28.4524" y="48.5272" size="1.016" layer="48" font="vector" ratio="10" rot="R270">PWM 13</text>
<text x="25.9124" y="48.5272" size="1.016" layer="48" font="vector" ratio="10" rot="R270">GND</text>
<text x="23.3724" y="48.5272" size="1.016" layer="48" font="vector" ratio="10" rot="R270">AREF</text>
<text x="91.5802" y="41.1436" size="1.016" layer="48" font="vector" ratio="10" rot="R180">28</text>
<text x="91.5802" y="43.6836" size="1.016" layer="48" font="vector" ratio="10" rot="R180">26</text>
<text x="91.5802" y="46.2236" size="1.016" layer="48" font="vector" ratio="10" rot="R180">24</text>
<text x="91.5802" y="48.7636" size="1.016" layer="48" font="vector" ratio="10" rot="R180">22</text>
<rectangle x1="68.326" y1="2.286" x2="68.834" y2="2.794" layer="51"/>
<rectangle x1="65.786" y1="2.286" x2="66.294" y2="2.794" layer="51"/>
<rectangle x1="86.106" y1="2.286" x2="86.614" y2="2.794" layer="51"/>
<rectangle x1="83.566" y1="2.286" x2="84.074" y2="2.794" layer="51"/>
<rectangle x1="81.026" y1="2.286" x2="81.534" y2="2.794" layer="51"/>
<rectangle x1="78.486" y1="2.286" x2="78.994" y2="2.794" layer="51"/>
<rectangle x1="75.946" y1="2.286" x2="76.454" y2="2.794" layer="51"/>
<rectangle x1="73.406" y1="2.286" x2="73.914" y2="2.794" layer="51"/>
<rectangle x1="91.186" y1="2.286" x2="91.694" y2="2.794" layer="51"/>
<rectangle x1="88.646" y1="2.286" x2="89.154" y2="2.794" layer="51"/>
<rectangle x1="50.546" y1="50.546" x2="51.054" y2="51.054" layer="51" rot="R180"/>
<rectangle x1="53.086" y1="50.546" x2="53.594" y2="51.054" layer="51" rot="R180"/>
<rectangle x1="55.626" y1="50.546" x2="56.134" y2="51.054" layer="51" rot="R180"/>
<rectangle x1="58.166" y1="50.546" x2="58.674" y2="51.054" layer="51" rot="R180"/>
<rectangle x1="60.706" y1="50.546" x2="61.214" y2="51.054" layer="51" rot="R180"/>
<rectangle x1="63.246" y1="50.546" x2="63.754" y2="51.054" layer="51" rot="R180"/>
<rectangle x1="45.466" y1="50.546" x2="45.974" y2="51.054" layer="51" rot="R180"/>
<rectangle x1="48.006" y1="50.546" x2="48.514" y2="51.054" layer="51" rot="R180"/>
<rectangle x1="28.956" y1="50.546" x2="29.464" y2="51.054" layer="51" rot="R180"/>
<rectangle x1="31.496" y1="50.546" x2="32.004" y2="51.054" layer="51" rot="R180"/>
<rectangle x1="34.036" y1="50.546" x2="34.544" y2="51.054" layer="51" rot="R180"/>
<rectangle x1="36.576" y1="50.546" x2="37.084" y2="51.054" layer="51" rot="R180"/>
<rectangle x1="39.116" y1="50.546" x2="39.624" y2="51.054" layer="51" rot="R180"/>
<rectangle x1="41.656" y1="50.546" x2="42.164" y2="51.054" layer="51" rot="R180"/>
<rectangle x1="23.876" y1="50.546" x2="24.384" y2="51.054" layer="51" rot="R180"/>
<rectangle x1="26.416" y1="50.546" x2="26.924" y2="51.054" layer="51" rot="R180"/>
<rectangle x1="96.266" y1="48.006" x2="96.774" y2="48.514" layer="51" rot="R270"/>
<rectangle x1="93.726" y1="48.006" x2="94.234" y2="48.514" layer="51" rot="R270"/>
<rectangle x1="96.266" y1="45.466" x2="96.774" y2="45.974" layer="51" rot="R270"/>
<rectangle x1="93.726" y1="45.466" x2="94.234" y2="45.974" layer="51" rot="R270"/>
<rectangle x1="96.266" y1="42.926" x2="96.774" y2="43.434" layer="51" rot="R270"/>
<rectangle x1="96.266" y1="40.386" x2="96.774" y2="40.894" layer="51" rot="R270"/>
<rectangle x1="93.726" y1="42.926" x2="94.234" y2="43.434" layer="51" rot="R270"/>
<rectangle x1="93.726" y1="40.386" x2="94.234" y2="40.894" layer="51" rot="R270"/>
<wire x1="0" y1="53.34" x2="96.52" y2="53.34" width="0.127" layer="21"/>
<wire x1="92.71" y1="3.175" x2="92.71" y2="1.905" width="0.1524" layer="21"/>
<smd name="P$1" x="48.26" y="52.07" dx="0.3048" dy="0.1524" layer="1"/>
<smd name="P$2" x="50.8" y="52.07" dx="0.3048" dy="0.1524" layer="1"/>
<wire x1="85.09" y1="50.165" x2="84.455" y2="49.53" width="0.1524" layer="21"/>
<wire x1="84.455" y1="49.53" x2="83.185" y2="49.53" width="0.1524" layer="21"/>
<wire x1="83.185" y1="49.53" x2="82.55" y2="50.165" width="0.1524" layer="21"/>
<wire x1="82.55" y1="50.165" x2="82.55" y2="51.435" width="0.1524" layer="21"/>
<wire x1="82.55" y1="51.435" x2="83.185" y2="52.07" width="0.1524" layer="21"/>
<wire x1="83.185" y1="52.07" x2="84.455" y2="52.07" width="0.1524" layer="21"/>
<wire x1="84.455" y1="52.07" x2="85.09" y2="51.435" width="0.1524" layer="21"/>
<wire x1="87.63" y1="50.165" x2="87.63" y2="51.435" width="0.1524" layer="21"/>
<wire x1="87.63" y1="50.165" x2="86.995" y2="49.53" width="0.1524" layer="21"/>
<wire x1="86.995" y1="49.53" x2="85.725" y2="49.53" width="0.1524" layer="21"/>
<wire x1="85.725" y1="49.53" x2="85.09" y2="50.165" width="0.1524" layer="21"/>
<wire x1="85.09" y1="50.165" x2="85.09" y2="51.435" width="0.1524" layer="21"/>
<wire x1="85.09" y1="51.435" x2="85.725" y2="52.07" width="0.1524" layer="21"/>
<wire x1="85.725" y1="52.07" x2="86.995" y2="52.07" width="0.1524" layer="21"/>
<wire x1="86.995" y1="52.07" x2="87.63" y2="51.435" width="0.1524" layer="21"/>
<pad name="SCL" x="86.36" y="50.8" drill="1.016" shape="long" rot="R270"/>
<pad name="SDA" x="83.82" y="50.8" drill="1.016" shape="long" rot="R270"/>
<rectangle x1="83.566" y1="50.546" x2="84.074" y2="51.054" layer="51" rot="R180"/>
<rectangle x1="86.106" y1="50.546" x2="86.614" y2="51.054" layer="51" rot="R180"/>
<text x="84.455" y="43.18" size="1.016" layer="21" font="vector" rot="R90">SDA 20</text>
<text x="86.995" y="43.18" size="1.016" layer="21" font="vector" rot="R90">SCL 21</text>
</package>
</packages>
<symbols>
<symbol name="ARDUNIO2009_1">
<wire x1="-12.7" y1="22.86" x2="12.7" y2="22.86" width="0.254" layer="94"/>
<wire x1="12.7" y1="22.86" x2="12.7" y2="-25.4" width="0.254" layer="94"/>
<wire x1="12.7" y1="-25.4" x2="-12.7" y2="-25.4" width="0.254" layer="94"/>
<wire x1="-12.7" y1="-25.4" x2="-12.7" y2="22.86" width="0.254" layer="94"/>
<text x="-12.7" y="24.13" size="1.6764" layer="95">&gt;Name</text>
<text x="-4.572" y="0.508" size="1.778" layer="94">Arduino</text>
<text x="-2.794" y="-2.794" size="1.778" layer="94">2009</text>
<pin name="13" x="17.78" y="-20.32" length="middle" rot="R180"/>
<pin name="12" x="17.78" y="-17.78" length="middle" rot="R180"/>
<pin name="11" x="17.78" y="-15.24" length="middle" rot="R180"/>
<pin name="10" x="17.78" y="-12.7" length="middle" rot="R180"/>
<pin name="9" x="17.78" y="-10.16" length="middle" rot="R180"/>
<pin name="8" x="17.78" y="-7.62" length="middle" rot="R180"/>
<pin name="7" x="17.78" y="-2.54" length="middle" rot="R180"/>
<pin name="6" x="17.78" y="0" length="middle" rot="R180"/>
<pin name="5" x="17.78" y="2.54" length="middle" rot="R180"/>
<pin name="4" x="17.78" y="5.08" length="middle" rot="R180"/>
<pin name="3" x="17.78" y="7.62" length="middle" rot="R180"/>
<pin name="2" x="17.78" y="10.16" length="middle" rot="R180"/>
<pin name="1" x="17.78" y="12.7" length="middle" rot="R180"/>
<pin name="0" x="17.78" y="15.24" length="middle" rot="R180"/>
<pin name="AREF" x="-17.78" y="7.62" length="middle"/>
<pin name="A0" x="-17.78" y="2.54" length="middle"/>
<pin name="A4" x="-17.78" y="-7.62" length="middle"/>
<pin name="A3" x="-17.78" y="-5.08" length="middle"/>
<pin name="A2" x="-17.78" y="-2.54" length="middle"/>
<pin name="A1" x="-17.78" y="0" length="middle"/>
<pin name="A5" x="-17.78" y="-10.16" length="middle"/>
<pin name="!RESET" x="-17.78" y="15.24" length="middle" function="dot"/>
</symbol>
<symbol name="PWR5V">
<text x="-2.032" y="-1.016" size="1.6764" layer="97">+5V</text>
<pin name="+5V" x="0" y="10.16" visible="pad" length="middle" direction="pwr" function="dot" rot="R270"/>
<pin name="GND" x="0" y="-10.16" visible="pad" length="middle" direction="pwr" function="dot" rot="R90"/>
</symbol>
<symbol name="PWR3V3">
<text x="-3.048" y="-1.016" size="1.6764" layer="97">+3V3</text>
<pin name="+3V3" x="0" y="10.16" visible="pad" length="middle" direction="pwr" function="dot" rot="R270"/>
</symbol>
<symbol name="PWRVIN">
<text x="-2.54" y="-1.016" size="1.6764" layer="97">+Vin</text>
<pin name="+VIN" x="0" y="10.16" visible="pad" length="middle" direction="pwr" function="dot" rot="R270"/>
</symbol>
<symbol name="MEGAARDUINO_2">
<wire x1="-27.94" y1="68.58" x2="27.94" y2="68.58" width="0.254" layer="94"/>
<wire x1="27.94" y1="68.58" x2="27.94" y2="-53.34" width="0.254" layer="94"/>
<wire x1="27.94" y1="-53.34" x2="-27.94" y2="-53.34" width="0.254" layer="94"/>
<wire x1="-27.94" y1="-53.34" x2="-27.94" y2="68.58" width="0.254" layer="94"/>
<text x="-27.94" y="69.85" size="1.6764" layer="95">&gt;Name</text>
<text x="-3.048" y="0.508" size="1.778" layer="94">Mega</text>
<text x="-4.318" y="-2.794" size="1.778" layer="94">Arduino</text>
<pin name="(OC2A/PCINT4)PB4" x="33.02" y="30.48" length="middle" rot="R180"/>
<pin name="(OC1A/PCINT5)PB5" x="33.02" y="27.94" length="middle" rot="R180"/>
<pin name="(OC1B/PCINT6)PB6" x="33.02" y="25.4" length="middle" rot="R180"/>
<pin name="(OC0A/OC1C/PCINT7)PB7" x="33.02" y="22.86" length="middle" rot="R180"/>
<pin name="(AD7)PA7" x="33.02" y="45.72" length="middle" rot="R180"/>
<pin name="(AD6)PA6" x="33.02" y="48.26" length="middle" rot="R180"/>
<pin name="(AD5)PA5" x="33.02" y="50.8" length="middle" rot="R180"/>
<pin name="(AD4)PA4" x="33.02" y="53.34" length="middle" rot="R180"/>
<pin name="(AD3)PA3" x="33.02" y="55.88" length="middle" rot="R180"/>
<pin name="(AD2)PA2" x="33.02" y="58.42" length="middle" rot="R180"/>
<pin name="(AD1)PA1" x="33.02" y="60.96" length="middle" rot="R180"/>
<pin name="(AD0)PA0" x="33.02" y="63.5" length="middle" rot="R180"/>
<pin name="AREF" x="-33.02" y="58.42" length="middle"/>
<pin name="PF0(ADC0)" x="-33.02" y="-30.48" length="middle"/>
<pin name="PF4(ADC4/TCK)" x="-33.02" y="-40.64" length="middle"/>
<pin name="PF3(ADC3)" x="-33.02" y="-38.1" length="middle"/>
<pin name="PF2(ADC2)" x="-33.02" y="-35.56" length="middle"/>
<pin name="PF1(ADC1)" x="-33.02" y="-33.02" length="middle"/>
<pin name="PF5(ADC5/TMS)" x="-33.02" y="-43.18" length="middle"/>
<pin name="!RESET" x="-33.02" y="63.5" length="middle" function="dot"/>
<pin name="PF6(ADC6/TDO)" x="-33.02" y="-45.72" length="middle"/>
<pin name="PF7(ADC7/TDI)" x="-33.02" y="-48.26" length="middle"/>
<pin name="PH4(OC4B)" x="-33.02" y="-7.62" length="middle"/>
<pin name="PH5(OC4C)" x="-33.02" y="-10.16" length="middle"/>
<pin name="PH6(OC2B)" x="-33.02" y="-12.7" length="middle"/>
<pin name="PK0(ADC8/PCINT16)" x="-33.02" y="30.48" length="middle"/>
<pin name="PK1(ADC9/PCINT17)" x="-33.02" y="27.94" length="middle"/>
<pin name="PK2(ADC10/PCINT18)" x="-33.02" y="25.4" length="middle"/>
<pin name="PK3(ADC11/PCINT19)" x="-33.02" y="22.86" length="middle"/>
<pin name="PK4(ADC12/PCINT20)" x="-33.02" y="20.32" length="middle"/>
<pin name="PK5(ADC13/PCINT21)" x="-33.02" y="17.78" length="middle"/>
<pin name="PK6(ADC14/PCINT22)" x="-33.02" y="15.24" length="middle"/>
<pin name="PK7(ADC15/PCINT23)" x="-33.02" y="12.7" length="middle"/>
<pin name="(RXD0/PCIN8)PE0" x="33.02" y="-20.32" length="middle" rot="R180"/>
<pin name="(TXD0)PE1" x="33.02" y="-22.86" length="middle" rot="R180"/>
<pin name="(OC3A/AIN1)PE3" x="33.02" y="-25.4" length="middle" rot="R180"/>
<pin name="(OC3B/AIN4)PE4" x="33.02" y="-27.94" length="middle" rot="R180"/>
<pin name="(OC3C/INT5)PE5" x="33.02" y="-30.48" length="middle" rot="R180"/>
<pin name="PG5(OC0B)" x="-33.02" y="-25.4" length="middle"/>
<pin name="PH3(OC4A)" x="-33.02" y="-5.08" length="middle"/>
<pin name="G$3" x="33.02" y="-43.18" length="middle" rot="R180"/>
<pin name="G$4" x="33.02" y="-48.26" length="middle" rot="R180"/>
<pin name="SDA" x="-33.02" y="48.26" length="middle"/>
<pin name="SCL" x="-33.02" y="43.18" length="middle"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="ARDUINO2009_2" prefix="IC" uservalue="yes">
<description>The Arduino Duemilanove ("2009") is a microcontroller board based on the ATmega168  or ATmega328.&lt;br&gt;
- 14 digital input/output pins (of which 6 can be used as PWM outputs) &lt;br&gt;
- 6 analog inputs, a 16 MHz crystal oscillator&lt;br&gt;
- USB connection&lt;br&gt;
- power jack&lt;br&gt;
- ISP header&lt;br&gt;
- reset button &lt;br&gt;
&lt;br&gt;
It contains everything needed to support the microcontroller; simply connect it to a computer with a USB cable or power it with a AC-to-DC adapter or battery to get started
&lt;br&gt;&lt;br&gt;
http://arduino.cc/en/Main/ArduinoBoardDuemilanove</description>
<gates>
<gate name="G$1" symbol="ARDUNIO2009_1" x="0" y="0"/>
<gate name="G$2" symbol="PWR5V" x="-35.56" y="0"/>
<gate name="G$3" symbol="PWR3V3" x="-30.48" y="0"/>
<gate name="G$4" symbol="PWRVIN" x="-25.4" y="0"/>
</gates>
<devices>
<device name="0" package="ARDUINO2009">
<connects>
<connect gate="G$1" pin="!RESET" pad="1"/>
<connect gate="G$1" pin="0" pad="13"/>
<connect gate="G$1" pin="1" pad="14"/>
<connect gate="G$1" pin="10" pad="23"/>
<connect gate="G$1" pin="11" pad="24"/>
<connect gate="G$1" pin="12" pad="25"/>
<connect gate="G$1" pin="13" pad="26"/>
<connect gate="G$1" pin="2" pad="15"/>
<connect gate="G$1" pin="3" pad="16"/>
<connect gate="G$1" pin="4" pad="17"/>
<connect gate="G$1" pin="5" pad="18"/>
<connect gate="G$1" pin="6" pad="19"/>
<connect gate="G$1" pin="7" pad="20"/>
<connect gate="G$1" pin="8" pad="21"/>
<connect gate="G$1" pin="9" pad="22"/>
<connect gate="G$1" pin="A0" pad="7"/>
<connect gate="G$1" pin="A1" pad="8"/>
<connect gate="G$1" pin="A2" pad="9"/>
<connect gate="G$1" pin="A3" pad="10"/>
<connect gate="G$1" pin="A4" pad="11"/>
<connect gate="G$1" pin="A5" pad="12"/>
<connect gate="G$1" pin="AREF" pad="28"/>
<connect gate="G$2" pin="+5V" pad="3"/>
<connect gate="G$2" pin="GND" pad="4"/>
<connect gate="G$3" pin="+3V3" pad="2"/>
<connect gate="G$3" pin="GND" pad="5"/>
<connect gate="G$4" pin="+VIN" pad="6"/>
<connect gate="G$4" pin="GND" pad="27"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
<device name="1" package="ARDUINO2009_1">
<connects>
</connects>
<technologies>
</technologies>
</device>
<device name="2" package="ARDUINO2009_2">
<connects>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
<deviceset name="MEGAARDUINO_2" prefix="IC" uservalue="yes">
<description>The Arduino Mega is a microcontroller board based on the ATmega1280.&lt;br&gt;&lt;br&gt;
- 54 digital input/output pins (of which 14 can be used as PWM outputs)&lt;br&gt;
- 16 analog inputs&lt;br&gt;
- 4 UARTs (hardware serial ports)&lt;br&gt;
- 16 MHz crystal oscillator&lt;br&gt;
- ICSP header&lt;br&gt;
- reset button&lt;br&gt;&lt;br&gt;
 It contains everything needed to support the microcontroller; simply connect it to a computer with a USB cable or power it with a AC-to-DC adapter or battery to get started.&lt;br&gt;
The Mega is compatible with most shields designed for the Arduino Duemilanove or Diecimila.
http://arduino.cc/en/Main/ArduinoBoardMega</description>
<gates>
<gate name="G$1" symbol="MEGAARDUINO_2" x="0" y="0"/>
<gate name="G$2" symbol="PWR5V" x="-83.82" y="5.08"/>
<gate name="G$5" symbol="PWR3V3" x="-68.58" y="5.08"/>
<gate name="G$6" symbol="PWRVIN" x="-63.5" y="5.08"/>
</gates>
<devices>
<device name="0" package="MEGA_ARDUINO">
<connects>
<connect gate="G$1" pin="(AD0)PA0" pad="49"/>
<connect gate="G$1" pin="(AD1)PA1" pad="50"/>
<connect gate="G$1" pin="(AD2)PA2" pad="51"/>
<connect gate="G$1" pin="(AD3)PA3" pad="52"/>
<connect gate="G$1" pin="(AD4)PA4" pad="53"/>
<connect gate="G$1" pin="(AD5)PA5" pad="54"/>
<connect gate="G$1" pin="(AD6)PA6" pad="55"/>
<connect gate="G$1" pin="(AD7)PA7" pad="56"/>
<connect gate="G$1" pin="(OC0A/OC1C/PCINT7)PB7" pad="44"/>
<connect gate="G$1" pin="(OC1A/PCINT5)PB5" pad="42"/>
<connect gate="G$1" pin="(OC1B/PCINT6)PB6" pad="43"/>
<connect gate="G$1" pin="(OC2A/PCINT4)PB4" pad="41"/>
<connect gate="G$1" pin="(OC3A/AIN1)PE3" pad="36"/>
<connect gate="G$1" pin="(OC3B/AIN4)PE4" pad="33"/>
<connect gate="G$1" pin="(OC3C/INT5)PE5" pad="34"/>
<connect gate="G$1" pin="(RXD0/PCIN8)PE0" pad="31"/>
<connect gate="G$1" pin="(TXD0)PE1" pad="32"/>
<connect gate="G$1" pin="AREF" pad="46"/>
<connect gate="G$1" pin="G$3" pad="P$1"/>
<connect gate="G$1" pin="G$4" pad="P$2"/>
<connect gate="G$1" pin="PF0(ADC0)" pad="7"/>
<connect gate="G$1" pin="PF1(ADC1)" pad="8"/>
<connect gate="G$1" pin="PF2(ADC2)" pad="9"/>
<connect gate="G$1" pin="PF3(ADC3)" pad="10"/>
<connect gate="G$1" pin="PF4(ADC4/TCK)" pad="11"/>
<connect gate="G$1" pin="PF5(ADC5/TMS)" pad="12"/>
<connect gate="G$1" pin="PF6(ADC6/TDO)" pad="13"/>
<connect gate="G$1" pin="PF7(ADC7/TDI)" pad="14"/>
<connect gate="G$1" pin="PG5(OC0B)" pad="35"/>
<connect gate="G$1" pin="PH3(OC4A)" pad="37"/>
<connect gate="G$1" pin="PH4(OC4B)" pad="38"/>
<connect gate="G$1" pin="PH5(OC4C)" pad="39"/>
<connect gate="G$1" pin="PH6(OC2B)" pad="40"/>
<connect gate="G$1" pin="PK0(ADC8/PCINT16)" pad="15"/>
<connect gate="G$1" pin="PK1(ADC9/PCINT17)" pad="16"/>
<connect gate="G$1" pin="PK2(ADC10/PCINT18)" pad="17"/>
<connect gate="G$1" pin="PK3(ADC11/PCINT19)" pad="18"/>
<connect gate="G$1" pin="PK4(ADC12/PCINT20)" pad="19"/>
<connect gate="G$1" pin="PK5(ADC13/PCINT21)" pad="20"/>
<connect gate="G$1" pin="PK6(ADC14/PCINT22)" pad="21"/>
<connect gate="G$1" pin="PK7(ADC15/PCINT23)" pad="22"/>
<connect gate="G$1" pin="SCL" pad="SCL"/>
<connect gate="G$1" pin="SDA" pad="SDA"/>
<connect gate="G$2" pin="GND" pad="5"/>
<connect gate="G$5" pin="+3V3" pad="2"/>
<connect gate="G$5" pin="GND" pad="4"/>
<connect gate="G$6" pin="+VIN" pad="6"/>
<connect gate="G$6" pin="GND" pad="45"/>
</connects>
<technologies>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<parts>
<part name="D1" library="diode" deviceset="1N4148" device="DO35-10"/>
<part name="R1" library="rcl" deviceset="R-EU_" device="0207/10" value="1k"/>
<part name="K4" library="relay" deviceset="JW1C" device=""/>
<part name="X1" library="con-phoenix-508" deviceset="MKDSN1,5/3-5,08" device=""/>
<part name="X2" library="con-phoenix-508" deviceset="MKDSN1,5/2-5,08" device=""/>
<part name="U$1" library="transistor-npn" deviceset="BCP56" device=""/>
<part name="T1" library="transistor-power" deviceset="IRL?2905" device=""/>
<part name="R2" library="rcl" deviceset="R-EU_" device="0207/10" value="10k"/>
<part name="P+1" library="supply1" deviceset="+12V" device=""/>
<part name="GND1" library="supply1" deviceset="GND" device=""/>
<part name="R3" library="rcl" deviceset="R-EU_" device="0207/10" value="1k"/>
<part name="U$2" library="transistor-npn" deviceset="BCP56" device=""/>
<part name="T2" library="transistor-power" deviceset="IRL?2905" device=""/>
<part name="R4" library="rcl" deviceset="R-EU_" device="0207/10" value="10k"/>
<part name="R5" library="rcl" deviceset="R-EU_" device="0207/10" value="1k"/>
<part name="U$3" library="transistor-npn" deviceset="BCP56" device=""/>
<part name="T3" library="transistor-power" deviceset="IRL?2905" device=""/>
<part name="R6" library="rcl" deviceset="R-EU_" device="0207/10" value="10k"/>
<part name="R7" library="rcl" deviceset="R-EU_" device="0207/10" value="1k"/>
<part name="U$4" library="transistor-npn" deviceset="BCP56" device=""/>
<part name="T4" library="transistor-power" deviceset="IRL?2905" device=""/>
<part name="R8" library="rcl" deviceset="R-EU_" device="0207/10" value="10k"/>
<part name="R9" library="rcl" deviceset="R-EU_" device="0207/10" value="1k"/>
<part name="U$5" library="transistor-npn" deviceset="BCP56" device=""/>
<part name="T5" library="transistor-power" deviceset="IRL?2905" device=""/>
<part name="R10" library="rcl" deviceset="R-EU_" device="0207/10" value="10k"/>
<part name="R11" library="rcl" deviceset="R-EU_" device="0207/10" value="1k"/>
<part name="U$6" library="transistor-npn" deviceset="BCP56" device=""/>
<part name="T6" library="transistor-power" deviceset="IRL?2905" device=""/>
<part name="R12" library="rcl" deviceset="R-EU_" device="0207/10" value="10k"/>
<part name="X3" library="con-phoenix-508" deviceset="MKDSN1,5/3-5,08" device=""/>
<part name="U$7" library="transistor-npn" deviceset="BCP56" device=""/>
<part name="R13" library="rcl" deviceset="R-EU_" device="0207/10" value="220"/>
<part name="SL1" library="con-amp-quick" deviceset="M05" device=""/>
<part name="P+2" library="supply1" deviceset="+12V" device=""/>
<part name="GND2" library="supply1" deviceset="GND" device=""/>
<part name="X4" library="con-phoenix-508" deviceset="MKDSN1,5/3-5,08" device=""/>
<part name="D2" library="diode" deviceset="1N4148" device="DO35-10"/>
<part name="K1" library="relay" deviceset="JW1C" device=""/>
<part name="U$8" library="transistor-npn" deviceset="BCP56" device=""/>
<part name="R14" library="rcl" deviceset="R-EU_" device="0207/10" value="220"/>
<part name="P+3" library="supply1" deviceset="+12V" device=""/>
<part name="GND3" library="supply1" deviceset="GND" device=""/>
<part name="X5" library="con-phoenix-508" deviceset="MKDSN1,5/3-5,08" device=""/>
<part name="C1" library="rcl" deviceset="C-EU" device="025_050-035X075" value="100nF"/>
<part name="R15" library="rcl" deviceset="R-EU_" device="0207/10" value="10k"/>
<part name="X6" library="con-phoenix-508" deviceset="MKDSN1,5/2-5,08" device=""/>
<part name="GND4" library="supply1" deviceset="GND" device=""/>
<part name="IC1" library="arduino" deviceset="ARDUINO2009_2" device="0"/>
<part name="SL2" library="con-amp-quick" deviceset="M05" device=""/>
<part name="IC2" library="arduino" deviceset="MEGAARDUINO_2" device="0"/>
</parts>
<sheets>
<sheet>
<plain>
</plain>
<instances>
<instance part="D1" gate="G$1" x="-87.63" y="-22.86" rot="R90"/>
<instance part="R1" gate="G$1" x="-137.16" y="-77.47" rot="R180"/>
<instance part="K4" gate="_" x="-77.47" y="-22.86"/>
<instance part="K4" gate="1" x="-58.42" y="-16.51" rot="R180"/>
<instance part="X1" gate="-1" x="-107.95" y="-76.2" rot="R90"/>
<instance part="X1" gate="-2" x="-54.61" y="-74.93" rot="R90"/>
<instance part="X1" gate="-3" x="-1.27" y="-74.93" rot="R90"/>
<instance part="X2" gate="-1" x="-134.62" y="-67.31" rot="R180"/>
<instance part="X2" gate="-2" x="-133.35" y="-102.87" rot="R180"/>
<instance part="U$1" gate="BCP56" x="-128.27" y="-77.47" smashed="yes">
<attribute name="NAME" x="-123.19" y="-74.93" size="1.778" layer="95"/>
<attribute name="VALUE" x="-125.73" y="-77.47" size="1.778" layer="96"/>
</instance>
<instance part="T1" gate="T" x="-110.49" y="-85.09"/>
<instance part="R2" gate="G$1" x="-125.73" y="-95.25" rot="R270"/>
<instance part="P+1" gate="1" x="-125.73" y="-62.23"/>
<instance part="GND1" gate="1" x="-125.73" y="-106.68"/>
<instance part="R3" gate="G$1" x="-83.82" y="-77.47" rot="R180"/>
<instance part="U$2" gate="BCP56" x="-74.93" y="-77.47" smashed="yes">
<attribute name="NAME" x="-69.85" y="-74.93" size="1.778" layer="95"/>
<attribute name="VALUE" x="-72.39" y="-77.47" size="1.778" layer="96"/>
</instance>
<instance part="T2" gate="T" x="-57.15" y="-83.82"/>
<instance part="R4" gate="G$1" x="-72.39" y="-95.25" rot="R270"/>
<instance part="R5" gate="G$1" x="-30.48" y="-77.47" rot="R180"/>
<instance part="U$3" gate="BCP56" x="-21.59" y="-77.47" smashed="yes">
<attribute name="NAME" x="-16.51" y="-74.93" size="1.778" layer="95"/>
<attribute name="VALUE" x="-19.05" y="-77.47" size="1.778" layer="96"/>
</instance>
<instance part="T3" gate="T" x="-3.81" y="-85.09"/>
<instance part="R6" gate="G$1" x="-19.05" y="-95.25" rot="R270"/>
<instance part="R7" gate="G$1" x="19.05" y="-77.47" rot="R180"/>
<instance part="U$4" gate="BCP56" x="31.75" y="-77.47" smashed="yes">
<attribute name="NAME" x="36.83" y="-74.93" size="1.778" layer="95"/>
<attribute name="VALUE" x="34.29" y="-77.47" size="1.778" layer="96"/>
</instance>
<instance part="T4" gate="T" x="49.53" y="-85.09"/>
<instance part="R8" gate="G$1" x="34.29" y="-95.25" rot="R270"/>
<instance part="R9" gate="G$1" x="76.2" y="-77.47" rot="R180"/>
<instance part="U$5" gate="BCP56" x="85.09" y="-77.47" smashed="yes">
<attribute name="NAME" x="90.17" y="-74.93" size="1.778" layer="95"/>
<attribute name="VALUE" x="87.63" y="-77.47" size="1.778" layer="96"/>
</instance>
<instance part="T5" gate="T" x="102.87" y="-85.09"/>
<instance part="R10" gate="G$1" x="87.63" y="-95.25" rot="R270"/>
<instance part="R11" gate="G$1" x="129.54" y="-77.47" rot="R180"/>
<instance part="U$6" gate="BCP56" x="138.43" y="-77.47" smashed="yes">
<attribute name="NAME" x="143.51" y="-74.93" size="1.778" layer="95"/>
<attribute name="VALUE" x="140.97" y="-77.47" size="1.778" layer="96"/>
</instance>
<instance part="T6" gate="T" x="156.21" y="-85.09"/>
<instance part="R12" gate="G$1" x="140.97" y="-95.25" rot="R270"/>
<instance part="X3" gate="-1" x="52.07" y="-74.93" rot="R90"/>
<instance part="X3" gate="-2" x="105.41" y="-74.93" rot="R90"/>
<instance part="X3" gate="-3" x="158.75" y="-74.93" rot="R90"/>
<instance part="U$7" gate="BCP56" x="-80.01" y="-38.1" smashed="yes">
<attribute name="NAME" x="-74.93" y="-35.56" size="1.778" layer="95"/>
<attribute name="VALUE" x="-76.2" y="-38.1" size="1.778" layer="96"/>
</instance>
<instance part="R13" gate="G$1" x="-96.52" y="-38.1" rot="R180"/>
<instance part="SL1" gate="G$1" x="-45.72" y="55.88"/>
<instance part="P+2" gate="1" x="-77.47" y="-6.35"/>
<instance part="GND2" gate="1" x="-77.47" y="-46.99"/>
<instance part="X4" gate="-1" x="-53.34" y="-7.62" rot="R90"/>
<instance part="X4" gate="-2" x="-58.42" y="-7.62" rot="R90"/>
<instance part="X4" gate="-3" x="-63.5" y="-7.62" rot="R90"/>
<instance part="D2" gate="G$1" x="-19.05" y="-21.59" rot="R90"/>
<instance part="K1" gate="_" x="-8.89" y="-21.59"/>
<instance part="K1" gate="1" x="10.16" y="-15.24" rot="R180"/>
<instance part="U$8" gate="BCP56" x="-11.43" y="-36.83" smashed="yes">
<attribute name="NAME" x="-6.35" y="-34.29" size="1.778" layer="95"/>
<attribute name="VALUE" x="-7.62" y="-36.83" size="1.778" layer="96"/>
</instance>
<instance part="R14" gate="G$1" x="-27.94" y="-36.83" rot="R180"/>
<instance part="P+3" gate="1" x="-8.89" y="-5.08"/>
<instance part="GND3" gate="1" x="-8.89" y="-45.72"/>
<instance part="X5" gate="-1" x="15.24" y="-6.35" rot="R90"/>
<instance part="X5" gate="-2" x="10.16" y="-6.35" rot="R90"/>
<instance part="X5" gate="-3" x="5.08" y="-6.35" rot="R90"/>
<instance part="C1" gate="G$1" x="50.8" y="-34.29"/>
<instance part="R15" gate="G$1" x="58.42" y="-20.32" rot="R270"/>
<instance part="X6" gate="-1" x="63.5" y="-29.21"/>
<instance part="X6" gate="-2" x="63.5" y="-39.37"/>
<instance part="GND4" gate="1" x="58.42" y="-46.99"/>
<instance part="IC1" gate="G$1" x="-96.52" y="40.64"/>
<instance part="SL2" gate="G$1" x="-12.7" y="55.88"/>
<instance part="IC2" gate="G$1" x="77.47" y="57.15" rot="R90"/>
</instances>
<busses>
</busses>
<nets>
<net name="N$2" class="0">
<segment>
<pinref part="T1" gate="T" pin="D"/>
<wire x1="-107.95" y1="-80.01" x2="-107.95" y2="-78.74" width="0.1524" layer="91"/>
<pinref part="X1" gate="-1" pin="KL"/>
</segment>
</net>
<net name="N$3" class="0">
<segment>
<pinref part="T1" gate="T" pin="G"/>
<pinref part="U$1" gate="BCP56" pin="E"/>
<wire x1="-113.03" y1="-87.63" x2="-125.73" y2="-87.63" width="0.1524" layer="91"/>
<wire x1="-125.73" y1="-87.63" x2="-125.73" y2="-82.55" width="0.1524" layer="91"/>
<pinref part="R2" gate="G$1" pin="1"/>
<wire x1="-125.73" y1="-90.17" x2="-125.73" y2="-87.63" width="0.1524" layer="91"/>
<junction x="-125.73" y="-87.63"/>
</segment>
</net>
<net name="N$5" class="0">
<segment>
<pinref part="R1" gate="G$1" pin="1"/>
<pinref part="U$1" gate="BCP56" pin="B"/>
<wire x1="-132.08" y1="-77.47" x2="-130.81" y2="-77.47" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$7" class="0">
<segment>
<pinref part="T2" gate="T" pin="D"/>
<pinref part="X1" gate="-2" pin="KL"/>
<wire x1="-54.61" y1="-77.47" x2="-54.61" y2="-78.74" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$8" class="0">
<segment>
<pinref part="U$2" gate="BCP56" pin="E"/>
<wire x1="-72.39" y1="-90.17" x2="-72.39" y2="-86.36" width="0.1524" layer="91"/>
<pinref part="R4" gate="G$1" pin="1"/>
<pinref part="T2" gate="T" pin="G"/>
<wire x1="-72.39" y1="-86.36" x2="-72.39" y2="-82.55" width="0.1524" layer="91"/>
<wire x1="-59.69" y1="-86.36" x2="-72.39" y2="-86.36" width="0.1524" layer="91"/>
<junction x="-72.39" y="-86.36"/>
</segment>
</net>
<net name="N$10" class="0">
<segment>
<pinref part="R3" gate="G$1" pin="1"/>
<pinref part="U$2" gate="BCP56" pin="B"/>
<wire x1="-78.74" y1="-77.47" x2="-77.47" y2="-77.47" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$12" class="0">
<segment>
<pinref part="T3" gate="T" pin="D"/>
<wire x1="-1.27" y1="-80.01" x2="-1.27" y2="-77.47" width="0.1524" layer="91"/>
<pinref part="X1" gate="-3" pin="KL"/>
</segment>
</net>
<net name="N$13" class="0">
<segment>
<pinref part="U$3" gate="BCP56" pin="E"/>
<wire x1="-19.05" y1="-90.17" x2="-19.05" y2="-87.63" width="0.1524" layer="91"/>
<pinref part="R6" gate="G$1" pin="1"/>
<pinref part="T3" gate="T" pin="G"/>
<wire x1="-19.05" y1="-87.63" x2="-19.05" y2="-82.55" width="0.1524" layer="91"/>
<wire x1="-6.35" y1="-87.63" x2="-19.05" y2="-87.63" width="0.1524" layer="91"/>
<junction x="-19.05" y="-87.63"/>
</segment>
</net>
<net name="N$15" class="0">
<segment>
<pinref part="R5" gate="G$1" pin="1"/>
<pinref part="U$3" gate="BCP56" pin="B"/>
<wire x1="-25.4" y1="-77.47" x2="-24.13" y2="-77.47" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$17" class="0">
<segment>
<pinref part="T4" gate="T" pin="D"/>
<wire x1="52.07" y1="-80.01" x2="52.07" y2="-77.47" width="0.1524" layer="91"/>
<pinref part="X3" gate="-1" pin="KL"/>
</segment>
</net>
<net name="N$18" class="0">
<segment>
<pinref part="U$4" gate="BCP56" pin="E"/>
<wire x1="34.29" y1="-90.17" x2="34.29" y2="-87.63" width="0.1524" layer="91"/>
<pinref part="R8" gate="G$1" pin="1"/>
<pinref part="T4" gate="T" pin="G"/>
<wire x1="34.29" y1="-87.63" x2="34.29" y2="-82.55" width="0.1524" layer="91"/>
<wire x1="46.99" y1="-87.63" x2="34.29" y2="-87.63" width="0.1524" layer="91"/>
<junction x="34.29" y="-87.63"/>
</segment>
</net>
<net name="N$20" class="0">
<segment>
<pinref part="R7" gate="G$1" pin="1"/>
<pinref part="U$4" gate="BCP56" pin="B"/>
<wire x1="24.13" y1="-77.47" x2="29.21" y2="-77.47" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$22" class="0">
<segment>
<pinref part="T5" gate="T" pin="D"/>
<wire x1="105.41" y1="-80.01" x2="105.41" y2="-77.47" width="0.1524" layer="91"/>
<pinref part="X3" gate="-2" pin="KL"/>
</segment>
</net>
<net name="N$23" class="0">
<segment>
<pinref part="U$5" gate="BCP56" pin="E"/>
<wire x1="87.63" y1="-90.17" x2="87.63" y2="-87.63" width="0.1524" layer="91"/>
<pinref part="R10" gate="G$1" pin="1"/>
<pinref part="T5" gate="T" pin="G"/>
<wire x1="87.63" y1="-87.63" x2="87.63" y2="-82.55" width="0.1524" layer="91"/>
<wire x1="100.33" y1="-87.63" x2="87.63" y2="-87.63" width="0.1524" layer="91"/>
<junction x="87.63" y="-87.63"/>
</segment>
</net>
<net name="N$25" class="0">
<segment>
<pinref part="R9" gate="G$1" pin="1"/>
<pinref part="U$5" gate="BCP56" pin="B"/>
<wire x1="81.28" y1="-77.47" x2="82.55" y2="-77.47" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$27" class="0">
<segment>
<pinref part="T6" gate="T" pin="D"/>
<wire x1="158.75" y1="-80.01" x2="158.75" y2="-77.47" width="0.1524" layer="91"/>
<pinref part="X3" gate="-3" pin="KL"/>
</segment>
</net>
<net name="N$28" class="0">
<segment>
<pinref part="U$6" gate="BCP56" pin="E"/>
<wire x1="140.97" y1="-90.17" x2="140.97" y2="-87.63" width="0.1524" layer="91"/>
<pinref part="R12" gate="G$1" pin="1"/>
<pinref part="T6" gate="T" pin="G"/>
<wire x1="140.97" y1="-87.63" x2="140.97" y2="-82.55" width="0.1524" layer="91"/>
<wire x1="153.67" y1="-87.63" x2="140.97" y2="-87.63" width="0.1524" layer="91"/>
<junction x="140.97" y="-87.63"/>
</segment>
</net>
<net name="N$30" class="0">
<segment>
<pinref part="R11" gate="G$1" pin="1"/>
<pinref part="U$6" gate="BCP56" pin="B"/>
<wire x1="134.62" y1="-77.47" x2="135.89" y2="-77.47" width="0.1524" layer="91"/>
</segment>
</net>
<net name="GND" class="0">
<segment>
<pinref part="T1" gate="T" pin="S"/>
<wire x1="-107.95" y1="-90.17" x2="-107.95" y2="-102.87" width="0.1524" layer="91"/>
<pinref part="R2" gate="G$1" pin="2"/>
<wire x1="-107.95" y1="-102.87" x2="-125.73" y2="-102.87" width="0.1524" layer="91"/>
<wire x1="-125.73" y1="-102.87" x2="-125.73" y2="-100.33" width="0.1524" layer="91"/>
<pinref part="T2" gate="T" pin="S"/>
<wire x1="-54.61" y1="-88.9" x2="-54.61" y2="-102.87" width="0.1524" layer="91"/>
<pinref part="R4" gate="G$1" pin="2"/>
<wire x1="-54.61" y1="-102.87" x2="-72.39" y2="-102.87" width="0.1524" layer="91"/>
<wire x1="-72.39" y1="-102.87" x2="-72.39" y2="-100.33" width="0.1524" layer="91"/>
<wire x1="-107.95" y1="-102.87" x2="-72.39" y2="-102.87" width="0.1524" layer="91"/>
<junction x="-107.95" y="-102.87"/>
<junction x="-72.39" y="-102.87"/>
<pinref part="T3" gate="T" pin="S"/>
<wire x1="-1.27" y1="-90.17" x2="-1.27" y2="-102.87" width="0.1524" layer="91"/>
<pinref part="R6" gate="G$1" pin="2"/>
<wire x1="-1.27" y1="-102.87" x2="-19.05" y2="-102.87" width="0.1524" layer="91"/>
<wire x1="-19.05" y1="-102.87" x2="-19.05" y2="-100.33" width="0.1524" layer="91"/>
<wire x1="-54.61" y1="-102.87" x2="-19.05" y2="-102.87" width="0.1524" layer="91"/>
<junction x="-54.61" y="-102.87"/>
<junction x="-19.05" y="-102.87"/>
<pinref part="T4" gate="T" pin="S"/>
<wire x1="52.07" y1="-90.17" x2="52.07" y2="-102.87" width="0.1524" layer="91"/>
<pinref part="R8" gate="G$1" pin="2"/>
<wire x1="52.07" y1="-102.87" x2="34.29" y2="-102.87" width="0.1524" layer="91"/>
<wire x1="34.29" y1="-102.87" x2="34.29" y2="-100.33" width="0.1524" layer="91"/>
<wire x1="-1.27" y1="-102.87" x2="34.29" y2="-102.87" width="0.1524" layer="91"/>
<junction x="-1.27" y="-102.87"/>
<junction x="34.29" y="-102.87"/>
<pinref part="T5" gate="T" pin="S"/>
<wire x1="105.41" y1="-90.17" x2="105.41" y2="-102.87" width="0.1524" layer="91"/>
<pinref part="R10" gate="G$1" pin="2"/>
<wire x1="105.41" y1="-102.87" x2="87.63" y2="-102.87" width="0.1524" layer="91"/>
<wire x1="87.63" y1="-102.87" x2="87.63" y2="-100.33" width="0.1524" layer="91"/>
<wire x1="52.07" y1="-102.87" x2="87.63" y2="-102.87" width="0.1524" layer="91"/>
<junction x="52.07" y="-102.87"/>
<junction x="87.63" y="-102.87"/>
<pinref part="T6" gate="T" pin="S"/>
<wire x1="158.75" y1="-90.17" x2="158.75" y2="-102.87" width="0.1524" layer="91"/>
<pinref part="R12" gate="G$1" pin="2"/>
<wire x1="158.75" y1="-102.87" x2="140.97" y2="-102.87" width="0.1524" layer="91"/>
<wire x1="140.97" y1="-102.87" x2="140.97" y2="-100.33" width="0.1524" layer="91"/>
<wire x1="105.41" y1="-102.87" x2="140.97" y2="-102.87" width="0.1524" layer="91"/>
<junction x="105.41" y="-102.87"/>
<junction x="140.97" y="-102.87"/>
<pinref part="GND1" gate="1" pin="GND"/>
<wire x1="-125.73" y1="-104.14" x2="-125.73" y2="-102.87" width="0.1524" layer="91"/>
<junction x="-125.73" y="-102.87"/>
<pinref part="X2" gate="-2" pin="KL"/>
<wire x1="-130.81" y1="-102.87" x2="-125.73" y2="-102.87" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="SL1" gate="G$1" pin="1"/>
<label x="-30.48" y="48.26" size="1.778" layer="95" xref="yes"/>
<wire x1="-30.48" y1="48.26" x2="-34.29" y2="48.26" width="0.1524" layer="91"/>
<wire x1="-34.29" y1="48.26" x2="-34.29" y2="50.8" width="0.1524" layer="91"/>
<wire x1="-34.29" y1="50.8" x2="-38.1" y2="50.8" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND2" gate="1" pin="GND"/>
<pinref part="U$7" gate="BCP56" pin="E"/>
<wire x1="-77.47" y1="-44.45" x2="-77.47" y2="-43.18" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="GND3" gate="1" pin="GND"/>
<pinref part="U$8" gate="BCP56" pin="E"/>
<wire x1="-8.89" y1="-43.18" x2="-8.89" y2="-41.91" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="X6" gate="-2" pin="KL"/>
<wire x1="60.96" y1="-39.37" x2="58.42" y2="-39.37" width="0.1524" layer="91"/>
<wire x1="58.42" y1="-39.37" x2="58.42" y2="-41.91" width="0.1524" layer="91"/>
<wire x1="58.42" y1="-41.91" x2="50.8" y2="-41.91" width="0.1524" layer="91"/>
<pinref part="C1" gate="G$1" pin="2"/>
<wire x1="50.8" y1="-41.91" x2="50.8" y2="-39.37" width="0.1524" layer="91"/>
<wire x1="58.42" y1="-41.91" x2="58.42" y2="-44.45" width="0.1524" layer="91"/>
<junction x="58.42" y="-41.91"/>
<pinref part="GND4" gate="1" pin="GND"/>
</segment>
</net>
<net name="+12V" class="0">
<segment>
<pinref part="U$1" gate="BCP56" pin="C"/>
<wire x1="-125.73" y1="-72.39" x2="-125.73" y2="-67.31" width="0.1524" layer="91"/>
<pinref part="U$2" gate="BCP56" pin="C"/>
<wire x1="-72.39" y1="-72.39" x2="-72.39" y2="-67.31" width="0.1524" layer="91"/>
<wire x1="-125.73" y1="-67.31" x2="-72.39" y2="-67.31" width="0.1524" layer="91"/>
<junction x="-72.39" y="-67.31"/>
<pinref part="U$3" gate="BCP56" pin="C"/>
<wire x1="-19.05" y1="-72.39" x2="-19.05" y2="-67.31" width="0.1524" layer="91"/>
<wire x1="-72.39" y1="-67.31" x2="-19.05" y2="-67.31" width="0.1524" layer="91"/>
<junction x="-19.05" y="-67.31"/>
<pinref part="U$4" gate="BCP56" pin="C"/>
<wire x1="34.29" y1="-72.39" x2="34.29" y2="-67.31" width="0.1524" layer="91"/>
<wire x1="-19.05" y1="-67.31" x2="34.29" y2="-67.31" width="0.1524" layer="91"/>
<junction x="34.29" y="-67.31"/>
<pinref part="U$5" gate="BCP56" pin="C"/>
<wire x1="87.63" y1="-72.39" x2="87.63" y2="-67.31" width="0.1524" layer="91"/>
<wire x1="34.29" y1="-67.31" x2="87.63" y2="-67.31" width="0.1524" layer="91"/>
<junction x="87.63" y="-67.31"/>
<pinref part="U$6" gate="BCP56" pin="C"/>
<wire x1="140.97" y1="-72.39" x2="140.97" y2="-67.31" width="0.1524" layer="91"/>
<wire x1="87.63" y1="-67.31" x2="140.97" y2="-67.31" width="0.1524" layer="91"/>
<pinref part="P+1" gate="1" pin="+12V"/>
<wire x1="-125.73" y1="-64.77" x2="-125.73" y2="-67.31" width="0.1524" layer="91"/>
<junction x="-125.73" y="-67.31"/>
<pinref part="X2" gate="-1" pin="KL"/>
<wire x1="-132.08" y1="-67.31" x2="-125.73" y2="-67.31" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="P+2" gate="1" pin="+12V"/>
<wire x1="-77.47" y1="-8.89" x2="-77.47" y2="-13.97" width="0.1524" layer="91"/>
<pinref part="K4" gate="_" pin="1"/>
<wire x1="-77.47" y1="-17.78" x2="-77.47" y2="-13.97" width="0.1524" layer="91"/>
<wire x1="-77.47" y1="-13.97" x2="-87.63" y2="-13.97" width="0.1524" layer="91"/>
<pinref part="D1" gate="G$1" pin="C"/>
<wire x1="-87.63" y1="-13.97" x2="-87.63" y2="-20.32" width="0.1524" layer="91"/>
<junction x="-77.47" y="-13.97"/>
</segment>
<segment>
<pinref part="P+3" gate="1" pin="+12V"/>
<wire x1="-8.89" y1="-7.62" x2="-8.89" y2="-12.7" width="0.1524" layer="91"/>
<pinref part="K1" gate="_" pin="1"/>
<wire x1="-8.89" y1="-16.51" x2="-8.89" y2="-12.7" width="0.1524" layer="91"/>
<wire x1="-8.89" y1="-12.7" x2="-19.05" y2="-12.7" width="0.1524" layer="91"/>
<pinref part="D2" gate="G$1" pin="C"/>
<wire x1="-19.05" y1="-12.7" x2="-19.05" y2="-19.05" width="0.1524" layer="91"/>
<junction x="-8.89" y="-12.7"/>
</segment>
</net>
<net name="CH1" class="0">
<segment>
<label x="-143.51" y="-77.47" size="1.778" layer="95" rot="R180" xref="yes"/>
<pinref part="R1" gate="G$1" pin="2"/>
<wire x1="-143.51" y1="-77.47" x2="-142.24" y2="-77.47" width="0.1524" layer="91"/>
</segment>
<segment>
<label x="83.82" y="17.78" size="1.778" layer="95" rot="MR270" xref="yes"/>
<wire x1="83.82" y1="20.32" x2="83.82" y2="17.78" width="0.1524" layer="91"/>
<wire x1="83.82" y1="20.32" x2="86.36" y2="20.32" width="0.1524" layer="91"/>
<wire x1="86.36" y1="20.32" x2="90.17" y2="24.13" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="PH6(OC2B)"/>
</segment>
</net>
<net name="CH3" class="0">
<segment>
<label x="-36.83" y="-77.47" size="1.778" layer="95" rot="R180" xref="yes"/>
<pinref part="R5" gate="G$1" pin="2"/>
<wire x1="-36.83" y1="-77.47" x2="-35.56" y2="-77.47" width="0.1524" layer="91"/>
</segment>
<segment>
<label x="91.44" y="17.78" size="1.778" layer="95" rot="MR270" xref="yes"/>
<wire x1="90.17" y1="20.32" x2="91.44" y2="20.32" width="0.1524" layer="91"/>
<wire x1="91.44" y1="20.32" x2="91.44" y2="17.78" width="0.1524" layer="91"/>
<wire x1="85.09" y1="24.13" x2="85.09" y2="22.86" width="0.1524" layer="91"/>
<wire x1="85.09" y1="22.86" x2="90.17" y2="22.86" width="0.1524" layer="91"/>
<wire x1="90.17" y1="22.86" x2="90.17" y2="20.32" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="PH4(OC4B)"/>
</segment>
</net>
<net name="CH4" class="0">
<segment>
<label x="11.43" y="-77.47" size="1.778" layer="95" rot="R180" xref="yes"/>
<pinref part="R7" gate="G$1" pin="2"/>
<wire x1="11.43" y1="-77.47" x2="13.97" y2="-77.47" width="0.1524" layer="91"/>
</segment>
<segment>
<wire x1="52.07" y1="90.17" x2="52.07" y2="92.71" width="0.1524" layer="91"/>
<wire x1="52.07" y1="92.71" x2="53.34" y2="92.71" width="0.1524" layer="91"/>
<wire x1="53.34" y1="92.71" x2="53.34" y2="96.52" width="0.1524" layer="91"/>
<label x="53.34" y="96.52" size="1.778" layer="95" rot="R90" xref="yes"/>
<pinref part="IC2" gate="G$1" pin="(OC1B/PCINT6)PB6"/>
</segment>
</net>
<net name="CH5" class="0">
<segment>
<label x="69.85" y="-77.47" size="1.778" layer="95" rot="R180" xref="yes"/>
<pinref part="R9" gate="G$1" pin="2"/>
<wire x1="69.85" y1="-77.47" x2="71.12" y2="-77.47" width="0.1524" layer="91"/>
</segment>
<segment>
<label x="49.53" y="96.52" size="1.778" layer="95" rot="MR90" xref="yes"/>
<wire x1="49.53" y1="90.17" x2="49.53" y2="96.52" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="(OC1A/PCINT5)PB5"/>
</segment>
</net>
<net name="CH6" class="0">
<segment>
<label x="123.19" y="-77.47" size="1.778" layer="95" rot="R180" xref="yes"/>
<pinref part="R11" gate="G$1" pin="2"/>
<wire x1="123.19" y1="-77.47" x2="124.46" y2="-77.47" width="0.1524" layer="91"/>
</segment>
<segment>
<wire x1="46.99" y1="90.17" x2="46.99" y2="92.71" width="0.1524" layer="91"/>
<wire x1="46.99" y1="92.71" x2="45.72" y2="92.71" width="0.1524" layer="91"/>
<wire x1="45.72" y1="92.71" x2="45.72" y2="96.52" width="0.1524" layer="91"/>
<label x="45.72" y="96.52" size="1.778" layer="95" rot="R90" xref="yes"/>
<pinref part="IC2" gate="G$1" pin="(OC2A/PCINT4)PB4"/>
</segment>
</net>
<net name="CH2" class="0">
<segment>
<label x="-90.17" y="-77.47" size="1.778" layer="95" rot="R180" xref="yes"/>
<pinref part="R3" gate="G$1" pin="2"/>
<wire x1="-90.17" y1="-77.47" x2="-88.9" y2="-77.47" width="0.1524" layer="91"/>
</segment>
<segment>
<label x="87.63" y="17.78" size="1.778" layer="95" rot="MR270" xref="yes"/>
<wire x1="87.63" y1="24.13" x2="87.63" y2="17.78" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="PH5(OC4C)"/>
</segment>
</net>
<net name="N$1" class="0">
<segment>
<wire x1="-87.63" y1="-25.4" x2="-87.63" y2="-30.48" width="0.1524" layer="91"/>
<wire x1="-87.63" y1="-30.48" x2="-77.47" y2="-30.48" width="0.1524" layer="91"/>
<pinref part="U$7" gate="BCP56" pin="C"/>
<wire x1="-77.47" y1="-30.48" x2="-77.47" y2="-33.02" width="0.1524" layer="91"/>
<pinref part="K4" gate="_" pin="2"/>
<wire x1="-77.47" y1="-27.94" x2="-77.47" y2="-30.48" width="0.1524" layer="91"/>
<junction x="-77.47" y="-30.48"/>
<pinref part="D1" gate="G$1" pin="A"/>
</segment>
</net>
<net name="N$9" class="0">
<segment>
<pinref part="R13" gate="G$1" pin="1"/>
<pinref part="U$7" gate="BCP56" pin="B"/>
<wire x1="-91.44" y1="-38.1" x2="-82.55" y2="-38.1" width="0.1524" layer="91"/>
</segment>
</net>
<net name="BLC" class="0">
<segment>
<wire x1="82.55" y1="24.13" x2="82.55" y2="20.32" width="0.1524" layer="91"/>
<wire x1="82.55" y1="20.32" x2="77.47" y2="20.32" width="0.1524" layer="91"/>
<wire x1="77.47" y1="20.32" x2="77.47" y2="17.78" width="0.1524" layer="91"/>
<label x="77.47" y="17.78" size="1.778" layer="95" rot="R270" xref="yes"/>
<pinref part="IC2" gate="G$1" pin="PH3(OC4A)"/>
</segment>
<segment>
<label x="-71.12" y="24.13" size="1.778" layer="95" xref="yes"/>
<wire x1="-71.12" y1="24.13" x2="-73.66" y2="24.13" width="0.1524" layer="91"/>
<wire x1="-73.66" y1="25.4" x2="-73.66" y2="24.13" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="11"/>
<wire x1="-73.66" y1="25.4" x2="-78.74" y2="25.4" width="0.1524" layer="91"/>
</segment>
</net>
<net name="D5" class="0">
<segment>
<label x="109.22" y="96.52" size="1.778" layer="95" rot="R90" xref="yes"/>
<wire x1="109.22" y1="96.52" x2="109.22" y2="93.98" width="0.1524" layer="91"/>
<wire x1="109.22" y1="93.98" x2="107.95" y2="93.98" width="0.1524" layer="91"/>
<wire x1="107.95" y1="93.98" x2="107.95" y2="90.17" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="(OC3C/INT5)PE5"/>
</segment>
<segment>
<wire x1="-78.74" y1="43.18" x2="-71.12" y2="43.18" width="0.1524" layer="91"/>
<label x="-71.12" y="43.18" size="1.778" layer="95" xref="yes"/>
<pinref part="IC1" gate="G$1" pin="5"/>
</segment>
</net>
<net name="D6" class="0">
<segment>
<label x="102.87" y="17.78" size="1.778" layer="95" rot="R270" xref="yes"/>
<wire x1="102.87" y1="24.13" x2="102.87" y2="17.78" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="PG5(OC0B)"/>
</segment>
<segment>
<label x="-71.12" y="39.37" size="1.778" layer="95" xref="yes"/>
<wire x1="-71.12" y1="39.37" x2="-73.66" y2="39.37" width="0.1524" layer="91"/>
<wire x1="-73.66" y1="39.37" x2="-73.66" y2="40.64" width="0.1524" layer="91"/>
<wire x1="-73.66" y1="40.64" x2="-78.74" y2="40.64" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="6"/>
</segment>
</net>
<net name="D7" class="0">
<segment>
<label x="-71.12" y="35.56" size="1.778" layer="95" xref="yes"/>
<wire x1="-71.12" y1="35.56" x2="-73.66" y2="35.56" width="0.1524" layer="91"/>
<wire x1="-73.66" y1="35.56" x2="-73.66" y2="38.1" width="0.1524" layer="91"/>
<wire x1="-73.66" y1="38.1" x2="-78.74" y2="38.1" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="7"/>
</segment>
<segment>
<label x="101.6" y="96.52" size="1.778" layer="95" rot="R90" xref="yes"/>
<wire x1="101.6" y1="96.52" x2="101.6" y2="93.98" width="0.1524" layer="91"/>
<wire x1="101.6" y1="93.98" x2="102.87" y2="93.98" width="0.1524" layer="91"/>
<wire x1="102.87" y1="93.98" x2="102.87" y2="90.17" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="(OC3A/AIN1)PE3"/>
</segment>
</net>
<net name="D4" class="0">
<segment>
<wire x1="105.41" y1="90.17" x2="105.41" y2="96.52" width="0.1524" layer="91"/>
<label x="105.41" y="96.52" size="1.778" layer="95" rot="R90" xref="yes"/>
<pinref part="IC2" gate="G$1" pin="(OC3B/AIN4)PE4"/>
</segment>
<segment>
<label x="-71.12" y="46.99" size="1.778" layer="95" xref="yes"/>
<wire x1="-71.12" y1="46.99" x2="-73.66" y2="46.99" width="0.1524" layer="91"/>
<wire x1="-73.66" y1="46.99" x2="-73.66" y2="45.72" width="0.1524" layer="91"/>
<wire x1="-73.66" y1="45.72" x2="-78.74" y2="45.72" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="4"/>
</segment>
</net>
<net name="N$4" class="0">
<segment>
<wire x1="73.66" y1="97.79" x2="73.66" y2="99.06" width="0.1524" layer="91"/>
</segment>
</net>
<net name="RS" class="0">
<segment>
<label x="-71.12" y="31.75" size="1.778" layer="95" xref="yes"/>
<wire x1="-71.12" y1="31.75" x2="-73.66" y2="31.75" width="0.1524" layer="91"/>
<pinref part="IC1" gate="G$1" pin="8"/>
<wire x1="-78.74" y1="33.02" x2="-73.66" y2="33.02" width="0.1524" layer="91"/>
<wire x1="-73.66" y1="33.02" x2="-73.66" y2="31.75" width="0.1524" layer="91"/>
</segment>
<segment>
<label x="21.59" y="95.25" size="1.778" layer="95" rot="R90" xref="yes"/>
<wire x1="21.59" y1="91.44" x2="21.59" y2="95.25" width="0.1524" layer="91"/>
<wire x1="13.97" y1="90.17" x2="13.97" y2="91.44" width="0.1524" layer="91"/>
<wire x1="13.97" y1="91.44" x2="21.59" y2="91.44" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="(AD0)PA0"/>
</segment>
</net>
<net name="E" class="0">
<segment>
<label x="-71.12" y="27.94" size="1.778" layer="95" xref="yes"/>
<pinref part="IC1" gate="G$1" pin="9"/>
<wire x1="-74.93" y1="27.94" x2="-71.12" y2="27.94" width="0.1524" layer="91"/>
<wire x1="-78.74" y1="30.48" x2="-74.93" y2="30.48" width="0.1524" layer="91"/>
<wire x1="-74.93" y1="30.48" x2="-74.93" y2="27.94" width="0.1524" layer="91"/>
</segment>
<segment>
<wire x1="16.51" y1="90.17" x2="16.51" y2="93.98" width="0.1524" layer="91"/>
<label x="16.51" y="93.98" size="1.778" layer="95" rot="R90" xref="yes"/>
<pinref part="IC2" gate="G$1" pin="(AD1)PA1"/>
</segment>
</net>
<net name="BUTTONS" class="0">
<segment>
<wire x1="107.95" y1="24.13" x2="107.95" y2="17.78" width="0.1524" layer="91"/>
<label x="107.95" y="17.78" size="1.778" layer="95" rot="R270" xref="yes"/>
<pinref part="IC2" gate="G$1" pin="PF0(ADC0)"/>
</segment>
<segment>
<wire x1="-114.3" y1="43.18" x2="-115.57" y2="43.18" width="0.1524" layer="91"/>
<label x="-115.57" y="43.18" size="1.778" layer="95" rot="R180" xref="yes"/>
<pinref part="IC1" gate="G$1" pin="A0"/>
</segment>
</net>
<net name="SCL" class="0">
<segment>
<pinref part="SL1" gate="G$1" pin="4"/>
<label x="-30.48" y="59.69" size="1.778" layer="95" xref="yes"/>
<wire x1="-30.48" y1="59.69" x2="-34.29" y2="59.69" width="0.1524" layer="91"/>
<wire x1="-34.29" y1="59.69" x2="-34.29" y2="58.42" width="0.1524" layer="91"/>
<wire x1="-34.29" y1="58.42" x2="-38.1" y2="58.42" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="IC2" gate="G$1" pin="SCL"/>
<wire x1="34.29" y1="24.13" x2="34.29" y2="19.05" width="0.1524" layer="91"/>
<label x="34.29" y="19.05" size="1.778" layer="95" rot="R270" xref="yes"/>
</segment>
</net>
<net name="SDA" class="0">
<segment>
<pinref part="SL1" gate="G$1" pin="3"/>
<wire x1="-38.1" y1="55.88" x2="-30.48" y2="55.88" width="0.1524" layer="91"/>
<label x="-30.48" y="55.88" size="1.778" layer="95" xref="yes"/>
</segment>
<segment>
<pinref part="IC2" gate="G$1" pin="SDA"/>
<wire x1="29.21" y1="24.13" x2="29.21" y2="19.05" width="0.1524" layer="91"/>
<label x="29.21" y="19.05" size="1.778" layer="95" rot="R270" xref="yes"/>
</segment>
</net>
<net name="+5V" class="0">
<segment>
<pinref part="SL1" gate="G$1" pin="2"/>
<label x="-30.48" y="52.07" size="1.778" layer="95" xref="yes"/>
<wire x1="-30.48" y1="52.07" x2="-34.29" y2="52.07" width="0.1524" layer="91"/>
<wire x1="-34.29" y1="52.07" x2="-34.29" y2="53.34" width="0.1524" layer="91"/>
<wire x1="-34.29" y1="53.34" x2="-38.1" y2="53.34" width="0.1524" layer="91"/>
</segment>
<segment>
<pinref part="R15" gate="G$1" pin="1"/>
<wire x1="58.42" y1="-15.24" x2="58.42" y2="-12.7" width="0.1524" layer="91"/>
<label x="58.42" y="-12.7" size="1.778" layer="95" rot="R90" xref="yes"/>
</segment>
</net>
<net name="N$11" class="0">
<segment>
<pinref part="X4" gate="-2" pin="KL"/>
<pinref part="K4" gate="1" pin="P"/>
<wire x1="-58.42" y1="-10.16" x2="-58.42" y2="-13.97" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$14" class="0">
<segment>
<pinref part="X4" gate="-1" pin="KL"/>
<wire x1="-53.34" y1="-10.16" x2="-53.34" y2="-13.97" width="0.1524" layer="91"/>
<wire x1="-53.34" y1="-13.97" x2="-50.8" y2="-13.97" width="0.1524" layer="91"/>
<pinref part="K4" gate="1" pin="S"/>
<wire x1="-50.8" y1="-13.97" x2="-50.8" y2="-21.59" width="0.1524" layer="91"/>
<wire x1="-50.8" y1="-21.59" x2="-53.34" y2="-21.59" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$16" class="0">
<segment>
<pinref part="K4" gate="1" pin="O"/>
<wire x1="-63.5" y1="-21.59" x2="-66.04" y2="-21.59" width="0.1524" layer="91"/>
<wire x1="-66.04" y1="-21.59" x2="-66.04" y2="-13.97" width="0.1524" layer="91"/>
<wire x1="-66.04" y1="-13.97" x2="-63.5" y2="-13.97" width="0.1524" layer="91"/>
<pinref part="X4" gate="-3" pin="KL"/>
<wire x1="-63.5" y1="-13.97" x2="-63.5" y2="-10.16" width="0.1524" layer="91"/>
</segment>
</net>
<net name="FILTER" class="0">
<segment>
<label x="25.4" y="95.25" size="1.778" layer="95" rot="R90" xref="yes"/>
<wire x1="25.4" y1="95.25" x2="25.4" y2="91.44" width="0.1524" layer="91"/>
<wire x1="25.4" y1="91.44" x2="24.13" y2="91.44" width="0.1524" layer="91"/>
<wire x1="24.13" y1="91.44" x2="24.13" y2="90.17" width="0.1524" layer="91"/>
<pinref part="IC2" gate="G$1" pin="(AD4)PA4"/>
</segment>
<segment>
<pinref part="R14" gate="G$1" pin="2"/>
<wire x1="-33.02" y1="-36.83" x2="-36.83" y2="-36.83" width="0.1524" layer="91"/>
<label x="-36.83" y="-36.83" size="1.778" layer="95" rot="R180" xref="yes"/>
</segment>
</net>
<net name="N$6" class="0">
<segment>
<wire x1="-19.05" y1="-24.13" x2="-19.05" y2="-29.21" width="0.1524" layer="91"/>
<wire x1="-19.05" y1="-29.21" x2="-8.89" y2="-29.21" width="0.1524" layer="91"/>
<pinref part="U$8" gate="BCP56" pin="C"/>
<wire x1="-8.89" y1="-29.21" x2="-8.89" y2="-31.75" width="0.1524" layer="91"/>
<pinref part="K1" gate="_" pin="2"/>
<wire x1="-8.89" y1="-26.67" x2="-8.89" y2="-29.21" width="0.1524" layer="91"/>
<junction x="-8.89" y="-29.21"/>
<pinref part="D2" gate="G$1" pin="A"/>
</segment>
</net>
<net name="N$19" class="0">
<segment>
<pinref part="R14" gate="G$1" pin="1"/>
<pinref part="U$8" gate="BCP56" pin="B"/>
<wire x1="-22.86" y1="-36.83" x2="-13.97" y2="-36.83" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$21" class="0">
<segment>
<pinref part="X5" gate="-2" pin="KL"/>
<pinref part="K1" gate="1" pin="P"/>
<wire x1="10.16" y1="-8.89" x2="10.16" y2="-12.7" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$24" class="0">
<segment>
<pinref part="X5" gate="-1" pin="KL"/>
<wire x1="15.24" y1="-8.89" x2="15.24" y2="-12.7" width="0.1524" layer="91"/>
<wire x1="15.24" y1="-12.7" x2="17.78" y2="-12.7" width="0.1524" layer="91"/>
<pinref part="K1" gate="1" pin="S"/>
<wire x1="17.78" y1="-12.7" x2="17.78" y2="-20.32" width="0.1524" layer="91"/>
<wire x1="17.78" y1="-20.32" x2="15.24" y2="-20.32" width="0.1524" layer="91"/>
</segment>
</net>
<net name="N$26" class="0">
<segment>
<pinref part="K1" gate="1" pin="O"/>
<wire x1="5.08" y1="-20.32" x2="2.54" y2="-20.32" width="0.1524" layer="91"/>
<wire x1="2.54" y1="-20.32" x2="2.54" y2="-12.7" width="0.1524" layer="91"/>
<wire x1="2.54" y1="-12.7" x2="5.08" y2="-12.7" width="0.1524" layer="91"/>
<pinref part="X5" gate="-3" pin="KL"/>
<wire x1="5.08" y1="-12.7" x2="5.08" y2="-8.89" width="0.1524" layer="91"/>
</segment>
</net>
<net name="GOMB" class="0">
<segment>
<pinref part="R15" gate="G$1" pin="2"/>
<pinref part="X6" gate="-1" pin="KL"/>
<wire x1="58.42" y1="-25.4" x2="58.42" y2="-29.21" width="0.1524" layer="91"/>
<wire x1="58.42" y1="-29.21" x2="60.96" y2="-29.21" width="0.1524" layer="91"/>
<wire x1="58.42" y1="-29.21" x2="50.8" y2="-29.21" width="0.1524" layer="91"/>
<junction x="58.42" y="-29.21"/>
<pinref part="C1" gate="G$1" pin="1"/>
<wire x1="50.8" y1="-29.21" x2="50.8" y2="-31.75" width="0.1524" layer="91"/>
<wire x1="50.8" y1="-29.21" x2="46.99" y2="-29.21" width="0.1524" layer="91"/>
<junction x="50.8" y="-29.21"/>
<label x="46.99" y="-29.21" size="1.778" layer="95" rot="R180" xref="yes"/>
</segment>
<segment>
<pinref part="IC2" gate="G$1" pin="PK7(ADC15/PCINT23)"/>
<wire x1="64.77" y1="24.13" x2="64.77" y2="17.78" width="0.1524" layer="91"/>
<label x="64.77" y="17.78" size="1.778" layer="95" rot="R270" xref="yes"/>
</segment>
</net>
<net name="FAN" class="0">
<segment>
<pinref part="R13" gate="G$1" pin="2"/>
<wire x1="-101.6" y1="-38.1" x2="-105.41" y2="-38.1" width="0.1524" layer="91"/>
<label x="-105.41" y="-38.1" size="1.778" layer="95" rot="R180" xref="yes"/>
</segment>
<segment>
<wire x1="29.21" y1="90.17" x2="29.21" y2="95.25" width="0.1524" layer="91"/>
<label x="29.21" y="95.25" size="1.778" layer="95" rot="R90" xref="yes"/>
<pinref part="IC2" gate="G$1" pin="(AD6)PA6"/>
</segment>
</net>
<net name="RESET" class="0">
<segment>
<wire x1="13.97" y1="24.13" x2="13.97" y2="20.32" width="0.1524" layer="91"/>
<label x="13.97" y="20.32" size="1.778" layer="95" rot="R270" xref="yes"/>
<pinref part="IC2" gate="G$1" pin="!RESET"/>
</segment>
<segment>
<label x="-118.11" y="55.88" size="1.778" layer="95" rot="R180" xref="yes"/>
<pinref part="IC1" gate="G$1" pin="!RESET"/>
<wire x1="-118.11" y1="55.88" x2="-114.3" y2="55.88" width="0.1524" layer="91"/>
</segment>
</net>
</nets>
</sheet>
</sheets>
</schematic>
</drawing>
</eagle>
