<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="7.1.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.025" unitdist="inch" unit="mm" style="dots" multiple="1" display="yes" altdistance="0.025" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="yes"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="yes"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="yes"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="yes"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="yes"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="yes"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="yes"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="yes"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="yes"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="yes"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="yes"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="yes"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="yes"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="no" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<wire x1="-0.63" y1="-0.47" x2="35.005" y2="-0.47" width="0" layer="20"/>
<wire x1="35.005" y1="-0.47" x2="35.005" y2="54.53" width="0" layer="20"/>
<wire x1="35.005" y1="54.53" x2="-0.63" y2="54.53" width="0" layer="20"/>
<wire x1="-0.63" y1="54.53" x2="-0.63" y2="-0.47" width="0" layer="20"/>
<rectangle x1="0" y1="-0.635" x2="34.29" y2="3.81" layer="1"/>
<rectangle x1="0" y1="3.81" x2="8.89" y2="54.61" layer="1"/>
<rectangle x1="8.255" y1="13.97" x2="10.795" y2="54.61" layer="1"/>
<hole x="3.81" y="50.8" drill="1.016"/>
<hole x="4.445" y="2.54" drill="1.016"/>
</plain>
<libraries>
<library name="wirepad">
<packages>
<package name="2,54/0,9">
<description>&lt;b&gt;THROUGH-HOLE PAD&lt;/b&gt;</description>
<wire x1="-1.27" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="0.762" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.27" x2="1.27" y2="0.762" width="0.1524" layer="21"/>
<wire x1="1.27" y1="1.27" x2="0.762" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.762" x2="1.27" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-1.27" x2="0.762" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.762" y1="-1.27" x2="-1.27" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-1.27" x2="-1.27" y2="-0.762" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="0.635" width="0.1524" layer="51"/>
<pad name="1" x="0" y="0" drill="0.9144" diameter="2.54" shape="octagon"/>
<text x="-1.27" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0" y="0.6" size="0.0254" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="linear">
<packages>
<package name="SO14">
<description>&lt;b&gt;Small Outline Package 14&lt;/b&gt;</description>
<wire x1="4.305" y1="-1.9" x2="-4.305" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="-4.305" y1="-1.9" x2="-4.305" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="-4.305" y1="-1.4" x2="-4.305" y2="1.9" width="0.2032" layer="51"/>
<wire x1="4.305" y1="-1.4" x2="-4.305" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="4.305" y1="1.9" x2="4.305" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="4.305" y1="-1.4" x2="4.305" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="-4.305" y1="1.9" x2="4.305" y2="1.9" width="0.2032" layer="51"/>
<smd name="2" x="-2.54" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="13" x="-2.54" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="1" x="-3.81" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="3" x="-1.27" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="4" x="0" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="14" x="-3.81" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="12" x="-1.27" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="11" x="0" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="6" x="2.54" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="9" x="2.54" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="5" x="1.27" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="7" x="3.81" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="10" x="1.27" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="8" x="3.81" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<text x="-4.572" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="5.842" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-4.055" y1="-3.1" x2="-3.565" y2="-2" layer="51"/>
<rectangle x1="-2.785" y1="-3.1" x2="-2.295" y2="-2" layer="51"/>
<rectangle x1="-1.515" y1="-3.1" x2="-1.025" y2="-2" layer="51"/>
<rectangle x1="-0.245" y1="-3.1" x2="0.245" y2="-2" layer="51"/>
<rectangle x1="-0.245" y1="2" x2="0.245" y2="3.1" layer="51"/>
<rectangle x1="-1.515" y1="2" x2="-1.025" y2="3.1" layer="51"/>
<rectangle x1="-2.785" y1="2" x2="-2.295" y2="3.1" layer="51"/>
<rectangle x1="-4.055" y1="2" x2="-3.565" y2="3.1" layer="51"/>
<rectangle x1="1.025" y1="-3.1" x2="1.515" y2="-2" layer="51"/>
<rectangle x1="2.295" y1="-3.1" x2="2.785" y2="-2" layer="51"/>
<rectangle x1="3.565" y1="-3.1" x2="4.055" y2="-2" layer="51"/>
<rectangle x1="3.565" y1="2" x2="4.055" y2="3.1" layer="51"/>
<rectangle x1="2.295" y1="2" x2="2.785" y2="3.1" layer="51"/>
<rectangle x1="1.025" y1="2" x2="1.515" y2="3.1" layer="51"/>
</package>
<package name="SO08">
<description>&lt;b&gt;Small Outline Package 8&lt;/b&gt;</description>
<wire x1="2.4" y1="1.9" x2="2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.9" x2="-2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.9" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.4" x2="-2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="1.9" x2="2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<smd name="2" x="-0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="7" x="-0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="1" x="-1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="3" x="0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="4" x="1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="8" x="-1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="6" x="0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="5" x="1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<text x="-2.667" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.937" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.15" y1="-3.1" x2="-1.66" y2="-2" layer="51"/>
<rectangle x1="-0.88" y1="-3.1" x2="-0.39" y2="-2" layer="51"/>
<rectangle x1="0.39" y1="-3.1" x2="0.88" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="-3.1" x2="2.15" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="2" x2="2.15" y2="3.1" layer="51"/>
<rectangle x1="0.39" y1="2" x2="0.88" y2="3.1" layer="51"/>
<rectangle x1="-0.88" y1="2" x2="-0.39" y2="3.1" layer="51"/>
<rectangle x1="-2.15" y1="2" x2="-1.66" y2="3.1" layer="51"/>
</package>
</packages>
</library>
<library name="rcl">
<packages>
<package name="0204/7">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0204, grid 7.5 mm</description>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-2.54" y1="0.762" x2="-2.286" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.286" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="-1.016" x2="2.54" y2="-0.762" width="0.1524" layer="21" curve="90"/>
<wire x1="2.286" y1="1.016" x2="2.54" y2="0.762" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-0.762" x2="-2.54" y2="0.762" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="1.016" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="0.889" x2="-1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="-1.016" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-1.778" y1="-0.889" x2="-1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="0.889" x2="-1.778" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="1.778" y1="-0.889" x2="-1.778" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="2.286" y1="1.016" x2="1.905" y2="1.016" width="0.1524" layer="21"/>
<wire x1="2.286" y1="-1.016" x2="1.905" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-0.762" x2="2.54" y2="0.762" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.8128" shape="octagon"/>
<text x="-2.54" y="1.2954" size="0.9906" layer="25" ratio="12">&gt;NAME</text>
<text x="-1.6256" y="-0.4826" size="0.9906" layer="27" ratio="12">&gt;VALUE</text>
<rectangle x1="2.54" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-2.54" y2="0.254" layer="21"/>
</package>
</packages>
</library>
<library name="discrete">
<packages>
<package name="D-7,5">
<wire x1="-1.905" y1="-0.889" x2="1.905" y2="-0.889" width="0.127" layer="21"/>
<wire x1="1.905" y1="0.889" x2="-1.905" y2="0.889" width="0.127" layer="21"/>
<wire x1="1.905" y1="0" x2="2.794" y2="0" width="0.127" layer="21"/>
<wire x1="1.905" y1="-0.889" x2="1.905" y2="0" width="0.127" layer="21"/>
<wire x1="-2.794" y1="0" x2="-1.905" y2="0" width="0.127" layer="21"/>
<wire x1="-1.905" y1="0.889" x2="-1.905" y2="0" width="0.127" layer="21"/>
<wire x1="1.905" y1="0" x2="1.905" y2="0.889" width="0.127" layer="21"/>
<wire x1="-1.905" y1="0" x2="-1.905" y2="-0.889" width="0.127" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<text x="-1.905" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.905" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.762" y1="-0.889" x2="1.27" y2="0.889" layer="21"/>
</package>
</packages>
</library>
<library name="led">
<packages>
<package name="U57X32">
<description>&lt;B&gt;LED&lt;/B&gt;&lt;p&gt;
rectangle, 5.7 x 3.2 mm</description>
<wire x1="-3.175" y1="1.905" x2="3.175" y2="1.905" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.905" x2="3.175" y2="1.905" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.905" x2="-3.175" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.905" x2="-3.175" y2="-1.905" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="1.397" x2="2.667" y2="1.397" width="0.1524" layer="21"/>
<wire x1="2.667" y1="-1.397" x2="2.667" y2="1.397" width="0.1524" layer="21"/>
<wire x1="2.667" y1="-1.397" x2="-2.667" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-2.667" y1="1.397" x2="-2.667" y2="-1.397" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.016" x2="2.54" y2="1.016" width="0.1524" layer="51"/>
<wire x1="2.286" y1="1.27" x2="2.286" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="0.508" x2="2.54" y2="0.508" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="0" x2="2.54" y2="0" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-0.508" x2="2.54" y2="-0.508" width="0.1524" layer="51"/>
<wire x1="-2.54" y1="-1.016" x2="2.54" y2="-1.016" width="0.1524" layer="51"/>
<wire x1="-2.286" y1="1.27" x2="-2.286" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-1.778" y1="1.27" x2="-1.778" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-1.27" y1="1.27" x2="-1.27" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="0.254" y1="1.27" x2="0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="0.762" y1="1.27" x2="0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="1.27" y1="1.27" x2="1.27" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="1.778" y1="1.27" x2="1.778" y2="-1.27" width="0.1524" layer="51"/>
<pad name="A" x="-1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<pad name="K" x="1.27" y="0" drill="0.8128" shape="long" rot="R90"/>
<text x="3.683" y="0.254" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="3.683" y="-1.524" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default">
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="AutoGrid" value="1"/>
<param name="Efforts" value="0"/>
<param name="TopRouterVariant" value="1"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="VCC" library="wirepad" package="2,54/0,9" value="" x="31.75" y="49.53"/>
<element name="GND" library="wirepad" package="2,54/0,9" value="" x="31.75" y="3.81"/>
<element name="IC1" library="linear" package="SO14" value="LM324D" x="24.765" y="25.4" rot="R180"/>
<element name="IC2" library="linear" package="SO08" value="LM311D" x="22.86" y="12.065" rot="R180"/>
<element name="R1" library="rcl" package="0204/7" value="" x="25.4" y="45.72" rot="R90"/>
<element name="R2" library="rcl" package="0204/7" value="" x="23.495" y="19.05" rot="R180"/>
<element name="RZ" library="rcl" package="0204/7" value="" x="27.94" y="45.72" rot="R270"/>
<element name="D1" library="discrete" package="D-7,5" value="" x="31.75" y="24.13" rot="R90"/>
<element name="R270" library="rcl" package="0204/7" value="" x="27.305" y="39.37" rot="R180"/>
<element name="R270-2" library="rcl" package="0204/7" value="" x="20.955" y="35.56" rot="R270"/>
<element name="R270-3" library="rcl" package="0204/7" value="" x="27.305" y="34.29"/>
<element name="RL1" library="rcl" package="0204/7" value="" x="27.305" y="36.83" rot="R180"/>
<element name="RL2" library="rcl" package="0204/7" value="" x="18.415" y="35.56" rot="R90"/>
<element name="RL3" library="rcl" package="0204/7" value="" x="17.78" y="23.495" rot="R90"/>
<element name="RL4" library="rcl" package="0204/7" value="" x="22.86" y="17.145" rot="R180"/>
<element name="RL5" library="rcl" package="0204/7" value="" x="13.97" y="12.065" rot="R180"/>
<element name="L-1" library="led" package="U57X32" value="" x="11.43" y="45.8" rot="R180"/>
<element name="L-2" library="led" package="U57X32" value="" x="11.43" y="36.195" rot="R180"/>
<element name="L-3" library="led" package="U57X32" value="" x="11.43" y="26.67" rot="R180"/>
<element name="L-4" library="led" package="U57X32" value="" x="11.43" y="17.145" rot="R180"/>
<element name="L-5" library="led" package="U57X32" value="" x="11.43" y="6.905" rot="R180"/>
<element name="R3000" library="rcl" package="0204/7" value="" x="29.845" y="19.05" rot="R270"/>
</elements>
<signals>
<signal name="N$4">
<contactref element="R1" pad="1"/>
<contactref element="R2" pad="1"/>
<contactref element="IC1" pad="3"/>
<contactref element="IC1" pad="5"/>
<contactref element="IC1" pad="10"/>
<contactref element="IC1" pad="12"/>
<contactref element="IC2" pad="2"/>
<wire x1="26.035" y1="31.75" x2="26.035" y2="40.64" width="0.6096" layer="1"/>
<wire x1="26.035" y1="40.64" x2="25.4" y2="41.275" width="0.6096" layer="1"/>
<wire x1="25.4" y1="41.275" x2="25.4" y2="41.91" width="0.6096" layer="1"/>
<wire x1="23.495" y1="29.21" x2="26.035" y2="31.75" width="0.6096" layer="1"/>
<wire x1="23.495" y1="28" x2="23.495" y2="29.21" width="0.6096" layer="1"/>
<wire x1="23.495" y1="26.035" x2="26.035" y2="26.035" width="0.6096" layer="1"/>
<wire x1="26.035" y1="26.035" x2="26.035" y2="28" width="0.6096" layer="1"/>
<wire x1="23.495" y1="26.035" x2="23.495" y2="28" width="0.6096" layer="1"/>
<wire x1="26.035" y1="26.035" x2="26.035" y2="22.86" width="0.6096" layer="1"/>
<wire x1="23.495" y1="22.86" x2="23.495" y2="26.035" width="0.6096" layer="1"/>
<wire x1="26.035" y1="20.32" x2="27.305" y2="19.05" width="0.6096" layer="1"/>
<wire x1="26.035" y1="22.86" x2="26.035" y2="22.8" width="0.6096" layer="1"/>
<wire x1="26.035" y1="22.86" x2="26.035" y2="20.32" width="0.6096" layer="1"/>
<wire x1="23.495" y1="22.86" x2="23.495" y2="22.8" width="0.6096" layer="1"/>
<wire x1="23.495" y1="14.665" x2="23.495" y2="22.86" width="0.6096" layer="1"/>
</signal>
<signal name="N$3">
<contactref element="RZ" pad="2"/>
<contactref element="D1" pad="2"/>
<contactref element="IC1" pad="2"/>
<contactref element="R270" pad="1"/>
<wire x1="28.575" y1="36.83" x2="31.115" y2="39.37" width="0.6096" layer="1"/>
<wire x1="27.305" y1="28" x2="27.305" y2="27.94" width="0.6096" layer="1"/>
<wire x1="27.305" y1="28" x2="27.305" y2="30.48" width="0.6096" layer="1"/>
<wire x1="27.305" y1="30.48" x2="28.575" y2="31.75" width="0.6096" layer="1"/>
<wire x1="28.575" y1="31.75" x2="28.575" y2="36.83" width="0.6096" layer="1"/>
<wire x1="32.385" y1="28.575" x2="31.75" y2="27.94" width="0.6096" layer="1"/>
<wire x1="32.385" y1="38.1" x2="32.385" y2="28.575" width="0.6096" layer="1"/>
<wire x1="31.115" y1="39.37" x2="32.385" y2="38.1" width="0.6096" layer="1"/>
<wire x1="31.115" y1="39.37" x2="30.48" y2="39.37" width="0.6096" layer="1"/>
<wire x1="30.48" y1="39.37" x2="27.94" y2="41.91" width="0.6096" layer="1"/>
</signal>
<signal name="N$5">
<contactref element="R270-2" pad="1"/>
<contactref element="R270" pad="2"/>
<contactref element="IC1" pad="6"/>
<wire x1="22.225" y1="28" x2="22.225" y2="27.94" width="0.6096" layer="1"/>
<wire x1="20.955" y1="39.37" x2="23.495" y2="39.37" width="0.6096" layer="1"/>
<wire x1="22.225" y1="28" x2="22.225" y2="29.845" width="0.6096" layer="1"/>
<wire x1="22.225" y1="29.845" x2="24.765" y2="32.385" width="0.6096" layer="1"/>
<wire x1="24.765" y1="32.385" x2="24.765" y2="34.925" width="0.6096" layer="1"/>
<wire x1="24.765" y1="34.925" x2="24.13" y2="35.56" width="0.6096" layer="1"/>
<wire x1="24.13" y1="35.56" x2="22.225" y2="35.56" width="0.6096" layer="1"/>
<wire x1="22.225" y1="35.56" x2="20.955" y2="36.83" width="0.6096" layer="1"/>
<wire x1="20.955" y1="36.83" x2="20.955" y2="39.37" width="0.6096" layer="1"/>
</signal>
<signal name="N$6">
<contactref element="R270-3" pad="1"/>
<contactref element="R270-2" pad="2"/>
<contactref element="IC1" pad="9"/>
<wire x1="22.225" y1="34.29" x2="23.495" y2="34.29" width="0.6096" layer="1"/>
<wire x1="20.955" y1="33.02" x2="22.225" y2="34.29" width="0.6096" layer="1"/>
<wire x1="20.955" y1="31.75" x2="20.955" y2="33.02" width="0.6096" layer="1"/>
<wire x1="20.955" y1="31.115" x2="20.955" y2="31.75" width="0.6096" layer="1"/>
<wire x1="21.59" y1="30.48" x2="20.955" y2="31.115" width="0.6096" layer="1"/>
<wire x1="21.59" y1="26.035" x2="21.59" y2="30.48" width="0.3048" layer="1"/>
<wire x1="22.225" y1="25.4" x2="21.59" y2="26.035" width="0.6096" layer="1"/>
<wire x1="22.225" y1="22.8" x2="22.225" y2="25.4" width="0.6096" layer="1"/>
</signal>
<signal name="N$7">
<contactref element="IC1" pad="13"/>
<contactref element="R270-3" pad="2"/>
<contactref element="R3000" pad="1"/>
<contactref element="IC2" pad="3"/>
<wire x1="31.115" y1="30.48" x2="31.115" y2="34.29" width="0.6096" layer="1"/>
<wire x1="29.845" y1="29.21" x2="31.115" y2="30.48" width="0.6096" layer="1"/>
<wire x1="27.94" y1="25.4" x2="29.845" y2="25.4" width="0.6096" layer="1"/>
<wire x1="29.845" y1="25.4" x2="29.845" y2="22.86" width="0.6096" layer="1"/>
<wire x1="29.845" y1="25.4" x2="29.845" y2="29.21" width="0.6096" layer="1"/>
<wire x1="27.305" y1="24.765" x2="27.305" y2="22.8" width="0.6096" layer="1"/>
<wire x1="27.94" y1="25.4" x2="27.305" y2="24.765" width="0.6096" layer="1"/>
<wire x1="32.385" y1="25.4" x2="27.94" y2="25.4" width="0.6096" layer="1"/>
<wire x1="33.02" y1="24.765" x2="32.385" y2="25.4" width="0.6096" layer="1"/>
<wire x1="33.02" y1="13.335" x2="33.02" y2="24.765" width="0.6096" layer="1"/>
<wire x1="22.225" y1="12.7" x2="23.1775" y2="11.7475" width="0.6096" layer="1"/>
<wire x1="23.1775" y1="11.7475" x2="31.4325" y2="11.7475" width="0.6096" layer="1"/>
<wire x1="31.4325" y1="11.7475" x2="33.02" y2="13.335" width="0.6096" layer="1"/>
<wire x1="22.225" y1="14.665" x2="22.225" y2="12.7" width="0.6096" layer="1"/>
</signal>
<signal name="N$8">
<contactref element="IC1" pad="1"/>
<contactref element="RL1" pad="1"/>
<wire x1="29.845" y1="35.56" x2="31.115" y2="36.83" width="0.6096" layer="1"/>
<wire x1="29.845" y1="31.115" x2="29.845" y2="35.56" width="0.6096" layer="1"/>
<wire x1="28.575" y1="29.845" x2="29.845" y2="31.115" width="0.6096" layer="1"/>
<wire x1="28.575" y1="28" x2="28.575" y2="27.94" width="0.4064" layer="1"/>
<wire x1="28.575" y1="28" x2="28.575" y2="29.845" width="0.6096" layer="1"/>
</signal>
<signal name="N$9">
<contactref element="RL1" pad="2"/>
<contactref element="L-1" pad="A"/>
<wire x1="24.13" y1="36.83" x2="23.495" y2="36.83" width="0.6096" layer="1"/>
<wire x1="24.765" y1="37.465" x2="24.13" y2="36.83" width="0.6096" layer="1"/>
<wire x1="15.24" y1="41.275" x2="23.3451" y2="41.275" width="0.6096" layer="1"/>
<wire x1="23.3451" y1="41.275" x2="24.765" y2="39.8551" width="0.6096" layer="1"/>
<wire x1="24.765" y1="39.8551" x2="24.765" y2="37.465" width="0.6096" layer="1"/>
<wire x1="12.7" y1="43.815" x2="15.24" y2="41.275" width="0.6096" layer="1"/>
<wire x1="12.7" y1="43.815" x2="12.7" y2="45.8" width="0.6096" layer="1"/>
</signal>
<signal name="N$10">
<contactref element="IC1" pad="7"/>
<contactref element="RL2" pad="1"/>
<wire x1="18.355" y1="30.54" x2="20.955" y2="28" width="0.6096" layer="1"/>
<wire x1="18.415" y1="31.75" x2="18.355" y2="30.54" width="0.6096" layer="1"/>
</signal>
<signal name="N$11">
<contactref element="RL2" pad="2"/>
<contactref element="L-2" pad="A"/>
<wire x1="15.875" y1="39.37" x2="18.415" y2="39.37" width="0.6096" layer="1"/>
<wire x1="12.7" y1="36.195" x2="15.875" y2="39.37" width="0.6096" layer="1"/>
</signal>
<signal name="N$12">
<contactref element="IC1" pad="8"/>
<contactref element="RL3" pad="1"/>
<wire x1="17.78" y1="19.685" x2="20.895" y2="22.8" width="0.6096" layer="1"/>
<wire x1="20.895" y1="22.8" x2="20.955" y2="22.8" width="0.4064" layer="1"/>
</signal>
<signal name="N$13">
<contactref element="RL3" pad="2"/>
<contactref element="L-3" pad="A"/>
<wire x1="13.335" y1="27.305" x2="17.78" y2="27.305" width="0.6096" layer="1"/>
<wire x1="12.7" y1="26.67" x2="13.335" y2="27.305" width="0.6096" layer="1"/>
</signal>
<signal name="N$14">
<contactref element="IC1" pad="14"/>
<contactref element="RL4" pad="1"/>
<wire x1="28.575" y1="22.8" x2="28.575" y2="22.86" width="0.4064" layer="1"/>
<wire x1="26.67" y1="17.145" x2="27.677" y2="17.145" width="0.6096" layer="1"/>
<wire x1="27.677" y1="17.145" x2="28.575" y2="18.043" width="0.6096" layer="1"/>
<wire x1="28.575" y1="18.043" x2="28.575" y2="22.8" width="0.6096" layer="1"/>
</signal>
<signal name="N$15">
<contactref element="RL4" pad="2"/>
<contactref element="L-4" pad="A"/>
<wire x1="12.7" y1="17.145" x2="19.05" y2="17.145" width="0.6096" layer="1"/>
</signal>
<signal name="N$16">
<contactref element="IC2" pad="7"/>
<contactref element="RL5" pad="1"/>
<wire x1="23.495" y1="7.62" x2="23.495" y2="9.465" width="0.6096" layer="1"/>
<wire x1="22.86" y1="6.985" x2="23.495" y2="7.62" width="0.6096" layer="1"/>
<wire x1="19.685" y1="6.985" x2="22.86" y2="6.985" width="0.6096" layer="1"/>
<wire x1="19.685" y1="6.985" x2="17.78" y2="8.89" width="0.6096" layer="1"/>
<wire x1="17.78" y1="8.89" x2="17.78" y2="12.065" width="0.6096" layer="1"/>
</signal>
<signal name="N$1">
<contactref element="L-1" pad="K"/>
<contactref element="L-2" pad="K"/>
<contactref element="L-3" pad="K"/>
<contactref element="L-4" pad="K"/>
<contactref element="GND" pad="1"/>
<contactref element="IC1" pad="11"/>
<contactref element="IC2" pad="4"/>
<contactref element="R2" pad="2"/>
<contactref element="D1" pad="1"/>
<contactref element="R3000" pad="2"/>
<contactref element="IC2" pad="1"/>
<wire x1="10.16" y1="36.195" x2="10.16" y2="45.8" width="0.4064" layer="1"/>
<wire x1="10.16" y1="26.67" x2="10.16" y2="36.195" width="0.4064" layer="1"/>
<wire x1="10.16" y1="17.145" x2="10.16" y2="19.685" width="0.4064" layer="1"/>
<wire x1="10.16" y1="19.685" x2="10.16" y2="26.67" width="0.4064" layer="1"/>
<wire x1="10.16" y1="14.605" x2="10.16" y2="17.145" width="0.4064" layer="1"/>
<wire x1="24.765" y1="22.8" x2="24.765" y2="22.86" width="0.4064" layer="1"/>
<wire x1="24.765" y1="15.24" x2="24.765" y2="22.8" width="0.6096" layer="1"/>
<wire x1="19.05" y1="19.05" x2="19.685" y2="19.05" width="0.6096" layer="1"/>
<wire x1="17.145" y1="18.415" x2="18.415" y2="18.415" width="0.6096" layer="1"/>
<wire x1="15.875" y1="19.685" x2="17.145" y2="18.415" width="0.6096" layer="1"/>
<wire x1="10.16" y1="19.685" x2="15.875" y2="19.685" width="0.6096" layer="1"/>
<wire x1="10.16" y1="14.605" x2="10.16" y2="19.685" width="0.6096" layer="1"/>
<wire x1="8.89" y1="13.335" x2="10.16" y2="14.605" width="0.6096" layer="1"/>
<wire x1="8.89" y1="13.335" x2="8.89" y2="3.81" width="0.6096" layer="1"/>
<wire x1="8.89" y1="3.81" x2="31.75" y2="3.81" width="0.6096" layer="1"/>
<wire x1="24.825" y1="15.3" x2="24.765" y2="14.665" width="0.6096" layer="1"/>
<wire x1="24.765" y1="15.24" x2="24.825" y2="15.3" width="0.6096" layer="1"/>
<wire x1="31.115" y1="20.32" x2="31.75" y2="20.32" width="0.6096" layer="1"/>
<wire x1="29.845" y1="19.05" x2="31.115" y2="20.32" width="0.6096" layer="1"/>
<wire x1="29.845" y1="15.24" x2="29.845" y2="19.05" width="0.6096" layer="1"/>
<wire x1="18.415" y1="18.415" x2="19.05" y2="19.05" width="0.6096" layer="1"/>
<wire x1="19.05" y1="19.05" x2="20.32" y2="19.05" width="0.6096" layer="1"/>
<wire x1="20.32" y1="19.05" x2="20.955" y2="18.415" width="0.6096" layer="1"/>
<wire x1="20.955" y1="14.665" x2="20.955" y2="14.605" width="0.6096" layer="1"/>
<wire x1="20.955" y1="18.415" x2="20.955" y2="14.665" width="0.6096" layer="1"/>
<wire x1="24.765" y1="15.24" x2="24.765" y2="14.665" width="0.6096" layer="1"/>
<wire x1="29.845" y1="15.24" x2="24.765" y2="15.24" width="0.6096" layer="1"/>
<wire x1="29.845" y1="5.715" x2="29.845" y2="15.24" width="0.6096" layer="16"/>
<wire x1="31.75" y1="3.81" x2="29.845" y2="5.715" width="0.6096" layer="16"/>
</signal>
<signal name="N$2">
<contactref element="IC2" pad="8"/>
<contactref element="IC1" pad="4"/>
<contactref element="VCC" pad="1"/>
<contactref element="R1" pad="2"/>
<contactref element="RZ" pad="1"/>
<contactref element="L-5" pad="A"/>
<wire x1="31.75" y1="49.53" x2="27.94" y2="49.53" width="0.8128" layer="1"/>
<wire x1="27.94" y1="49.53" x2="26.67" y2="49.53" width="0.8128" layer="1"/>
<wire x1="26.67" y1="49.53" x2="25.4" y2="49.53" width="0.8128" layer="1"/>
<wire x1="27.305" y1="40.64" x2="27.305" y2="31.75" width="0.6096" layer="1"/>
<wire x1="26.67" y1="41.275" x2="27.305" y2="40.64" width="0.6096" layer="1"/>
<wire x1="26.67" y1="49.53" x2="26.67" y2="41.275" width="0.6096" layer="1"/>
<wire x1="27.305" y1="31.75" x2="24.765" y2="29.21" width="0.6096" layer="1"/>
<wire x1="24.765" y1="28" x2="24.765" y2="27.94" width="0.6096" layer="1"/>
<wire x1="24.765" y1="29.21" x2="24.765" y2="28" width="0.6096" layer="1"/>
<wire x1="33.655" y1="49.53" x2="31.75" y2="49.53" width="0.8128" layer="1"/>
<wire x1="34.29" y1="48.895" x2="33.655" y2="49.53" width="0.6096" layer="1"/>
<wire x1="12.7" y1="6.905" x2="14.05" y2="6.905" width="0.6096" layer="1"/>
<wire x1="14.05" y1="6.905" x2="15.24" y2="5.715" width="0.6096" layer="1"/>
<wire x1="15.24" y1="5.715" x2="24.765" y2="5.715" width="0.6096" layer="1"/>
<wire x1="24.765" y1="5.715" x2="27.7523" y2="5.715" width="0.6096" layer="1"/>
<wire x1="27.7523" y1="5.715" x2="34.29" y2="12.2527" width="0.6096" layer="1"/>
<wire x1="34.29" y1="12.2527" x2="34.29" y2="48.895" width="0.6096" layer="1"/>
<wire x1="24.765" y1="5.715" x2="24.765" y2="9.465" width="0.6096" layer="1"/>
</signal>
<signal name="N$17">
<contactref element="L-5" pad="K"/>
<contactref element="RL5" pad="2"/>
<wire x1="10.16" y1="6.905" x2="10.16" y2="12.065" width="0.6096" layer="1"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
