  Description  :  Header file for Nokia 84x48 graphic LCD driver.
  Author       :  2003-03-08 - Louis Frigon.
  History      :  2003-03-08 - First release.
#ifndef _NOKIALCD_H_
#define _NOKIALCD_H_
                                  General purpose constants
#define NULL                       0
#define FALSE                      0
#define TRUE                       1
#define LCD_X_RES                  84
#define LCD_Y_RES                  48
//  Mega8 port B pinout for LCD.
#define LCD_DC_PIN                 0x01  //  PB0
#define LCD_CE_PIN                 0x04  //  PB2
#define SPI_MOSI_PIN               0x08  //  PB3
#define LCD_RST_PIN                0x10  //  PB4
#define SPI_CLK_PIN                0x20  //  PB5
#define LCD_CACHE_SIZE             ((LCD_X_RES * LCD_Y_RES) / 8)
                                       Type definitions
typedef char                       bool;
typedef unsigned char              byte;
typedef unsigned int               word;
typedef enum
    LCD_CMD  = 0,
    LCD_DATA = 1
} LcdCmdData;
typedef enum
    PIXEL_OFF =  0,
    PIXEL_ON  =  1,
    PIXEL_XOR =  2
} LcdPixelMode;
typedef enum
    FONT_1X = 1,
    FONT_2X = 2
} LcdFontSize;
                                 Public function prototypes
void LcdInit       ( void );
void LcdClear      ( void );
void LcdUpdate     ( void );
void LcdGotoXY     ( byte x, byte y );
void LcdChr        ( LcdFontSize size, byte ch );
void LcdStr        ( LcdFontSize size, byte *dataPtr );
void LcdPixel      ( byte x, byte y, LcdPixelMode mode );
void LcdLine       ( byte x1, byte y1, byte x2, byte y2, LcdPixelMode mode );
#endif  //  _NOKIALCD_H_
                                         End of file.
  Description  :  This is a driver for the Nokia 84x48 graphic LCD.
  Author       :  2003-03-08 - Sylvain Bissonnette
  History      :  2003-02-08 - First release (v0.1) derived from Sylvain Bissonnette code base.
                  2003-03-09 - v0.2, Louis Frigon: 2x fonts support.
                  2003-03-20 - v0.3: Serialization optimized,
#include <macros.h>
#include <iom8v.h>
//#include <stdio.h>
#include "NokiaLCD.h"
#define LCD_FIRMWARE_VERSION       0.3
                                Private function prototypes
//  Function prototypes are mandatory otherwise the compiler generates unreliable code.
static void LcdSend    ( byte data, LcdCmdData cd );
static void Delay      ( void );
                                     Character generator
             This table defines the standard ASCII characters in a 5x7 dot format.
static const byte FontLookup [][5] =
    { 0x00, 0x00, 0x00, 0x00, 0x00 },  // sp
    { 0x00, 0x00, 0x2f, 0x00, 0x00 },   // !
    { 0x00, 0x07, 0x00, 0x07, 0x00 },   // "
    { 0x14, 0x7f, 0x14, 0x7f, 0x14 },   // #
    { 0x24, 0x2a, 0x7f, 0x2a, 0x12 },   // $
    { 0xc4, 0xc8, 0x10, 0x26, 0x46 },   // %
    { 0x36, 0x49, 0x55, 0x22, 0x50 },   // &
    { 0x00, 0x05, 0x03, 0x00, 0x00 },   // '
    { 0x00, 0x1c, 0x22, 0x41, 0x00 },   // (
    { 0x00, 0x41, 0x22, 0x1c, 0x00 },   // )
    { 0x14, 0x08, 0x3E, 0x08, 0x14 },   // *
    { 0x08, 0x08, 0x3E, 0x08, 0x08 },   // +
    { 0x00, 0x00, 0x50, 0x30, 0x00 },   // ,
    { 0x10, 0x10, 0x10, 0x10, 0x10 },   // -
    { 0x00, 0x60, 0x60, 0x00, 0x00 },   // .
    { 0x20, 0x10, 0x08, 0x04, 0x02 },   // /
    { 0x3E, 0x51, 0x49, 0x45, 0x3E },   // 0
    { 0x00, 0x42, 0x7F, 0x40, 0x00 },   // 1
    { 0x42, 0x61, 0x51, 0x49, 0x46 },   // 2
    { 0x21, 0x41, 0x45, 0x4B, 0x31 },   // 3
    { 0x18, 0x14, 0x12, 0x7F, 0x10 },   // 4
    { 0x27, 0x45, 0x45, 0x45, 0x39 },   // 5
    { 0x3C, 0x4A, 0x49, 0x49, 0x30 },   // 6
    { 0x01, 0x71, 0x09, 0x05, 0x03 },   // 7
    { 0x36, 0x49, 0x49, 0x49, 0x36 },   // 8
    { 0x06, 0x49, 0x49, 0x29, 0x1E },   // 9
    { 0x00, 0x36, 0x36, 0x00, 0x00 },   // :
    { 0x00, 0x56, 0x36, 0x00, 0x00 },   // ;
    { 0x08, 0x14, 0x22, 0x41, 0x00 },   // <
    { 0x14, 0x14, 0x14, 0x14, 0x14 },   // =
    { 0x00, 0x41, 0x22, 0x14, 0x08 },   // >
    { 0x02, 0x01, 0x51, 0x09, 0x06 },   // ?
    { 0x32, 0x49, 0x59, 0x51, 0x3E },   // @
    { 0x7E, 0x11, 0x11, 0x11, 0x7E },   // A
    { 0x7F, 0x49, 0x49, 0x49, 0x36 },   // B
    { 0x3E, 0x41, 0x41, 0x41, 0x22 },   // C
    { 0x7F, 0x41, 0x41, 0x22, 0x1C },   // D
    { 0x7F, 0x49, 0x49, 0x49, 0x41 },   // E
    { 0x7F, 0x09, 0x09, 0x09, 0x01 },   // F
    { 0x3E, 0x41, 0x49, 0x49, 0x7A },   // G
    { 0x7F, 0x08, 0x08, 0x08, 0x7F },   // H
    { 0x00, 0x41, 0x7F, 0x41, 0x00 },   // I
    { 0x20, 0x40, 0x41, 0x3F, 0x01 },   // J
    { 0x7F, 0x08, 0x14, 0x22, 0x41 },   // K
    { 0x7F, 0x40, 0x40, 0x40, 0x40 },   // L
    { 0x7F, 0x02, 0x0C, 0x02, 0x7F },   // M
    { 0x7F, 0x04, 0x08, 0x10, 0x7F },   // N
    { 0x3E, 0x41, 0x41, 0x41, 0x3E },   // O
    { 0x7F, 0x09, 0x09, 0x09, 0x06 },   // P
    { 0x3E, 0x41, 0x51, 0x21, 0x5E },   // Q
    { 0x7F, 0x09, 0x19, 0x29, 0x46 },   // R
    { 0x46, 0x49, 0x49, 0x49, 0x31 },   // S
    { 0x01, 0x01, 0x7F, 0x01, 0x01 },   // T
    { 0x3F, 0x40, 0x40, 0x40, 0x3F },   // U
    { 0x1F, 0x20, 0x40, 0x20, 0x1F },   // V
    { 0x3F, 0x40, 0x38, 0x40, 0x3F },   // W
    { 0x63, 0x14, 0x08, 0x14, 0x63 },   // X
    { 0x07, 0x08, 0x70, 0x08, 0x07 },   // Y
    { 0x61, 0x51, 0x49, 0x45, 0x43 },   // Z
    { 0x00, 0x7F, 0x41, 0x41, 0x00 },   // [
    { 0x55, 0x2A, 0x55, 0x2A, 0x55 },   // 55
    { 0x00, 0x41, 0x41, 0x7F, 0x00 },   // ]
    { 0x04, 0x02, 0x01, 0x02, 0x04 },   // ^
    { 0x40, 0x40, 0x40, 0x40, 0x40 },   // _
    { 0x00, 0x01, 0x02, 0x04, 0x00 },   // '
    { 0x20, 0x54, 0x54, 0x54, 0x78 },   // a
    { 0x7F, 0x48, 0x44, 0x44, 0x38 },   // b
    { 0x38, 0x44, 0x44, 0x44, 0x20 },   // c
    { 0x38, 0x44, 0x44, 0x48, 0x7F },   // d
    { 0x38, 0x54, 0x54, 0x54, 0x18 },   // e
    { 0x08, 0x7E, 0x09, 0x01, 0x02 },   // f
    { 0x0C, 0x52, 0x52, 0x52, 0x3E },   // g
    { 0x7F, 0x08, 0x04, 0x04, 0x78 },   // h
    { 0x00, 0x44, 0x7D, 0x40, 0x00 },   // i
    { 0x20, 0x40, 0x44, 0x3D, 0x00 },   // j
    { 0x7F, 0x10, 0x28, 0x44, 0x00 },   // k
    { 0x00, 0x41, 0x7F, 0x40, 0x00 },   // l
    { 0x7C, 0x04, 0x18, 0x04, 0x78 },   // m
    { 0x7C, 0x08, 0x04, 0x04, 0x78 },   // n
    { 0x38, 0x44, 0x44, 0x44, 0x38 },   // o
    { 0x7C, 0x14, 0x14, 0x14, 0x08 },   // p
    { 0x08, 0x14, 0x14, 0x18, 0x7C },   // q
    { 0x7C, 0x08, 0x04, 0x04, 0x08 },   // r
    { 0x48, 0x54, 0x54, 0x54, 0x20 },   // s
    { 0x04, 0x3F, 0x44, 0x40, 0x20 },   // t
    { 0x3C, 0x40, 0x40, 0x20, 0x7C },   // u
    { 0x1C, 0x20, 0x40, 0x20, 0x1C },   // v
    { 0x3C, 0x40, 0x30, 0x40, 0x3C },   // w
    { 0x44, 0x28, 0x10, 0x28, 0x44 },   // x
    { 0x0C, 0x50, 0x50, 0x50, 0x3C },   // y
    { 0x44, 0x64, 0x54, 0x4C, 0x44 }    // z
                                      Global Variables
static byte  LcdCache [ LCD_CACHE_SIZE ];
static int   LcdCacheIdx;
static int   LoWaterMark;
static int   HiWaterMark;
static bool  UpdateLcd;
  Description  :  Performs MCU SPI & LCD controller initialization.
  Argument(s)  :  None.
  Return value :  None.
    //  Pull-up on reset pin.
    PORTB |= LCD_RST_PIN;
    //  Set output bits on port B.
    DDRB |= LCD_RST_PIN | LCD_DC_PIN | LCD_CE_PIN | SPI_MOSI_PIN | SPI_CLK_PIN;
    Delay();
    //  Toggle display reset pin.
    PORTB &= ~LCD_RST_PIN;
    Delay();
    //  Enable SPI port: No interrupt, MSBit first, Master mode, CPOL->0, CPHA->0, Clk/4
    SPCR = 0x50;
    //  Disable LCD controller
    PORTB |= LCD_CE_PIN;
    LcdSend( 0x21, LCD_CMD );  // LCD Extended Commands.
    LcdSend( 0xC8, LCD_CMD );  // Set LCD Vop (Contrast).
    LcdSend( 0x06, LCD_CMD );  // Set Temp coefficent.
    LcdSend( 0x13, LCD_CMD );  // LCD bias mode 1:48.
    LcdSend( 0x20, LCD_CMD );  // LCD Standard Commands, Horizontal addressing mode.
    LcdSend( 0x0C, LCD_CMD );  // LCD in normal mode.
    //  Reset watermark pointers.
    LoWaterMark = LCD_CACHE_SIZE;
    HiWaterMark = 0;
    LcdClear();
    LcdUpdate();
  Description  :  Set display contrast.
  Argument(s)  :  contrast -> Contrast value from 0x00 to 0x7F.
  Notes        :  No change visible at ambient temperature.
void LcdContrast ( byte contrast )
    LcdSend( 0x80 | contrast, LCD_CMD );
    //  LCD Standard Commands, horizontal addressing mode.
  Description  :  Clears the display. LcdUpdate must be called next.
  Argument(s)  :  None.
    int i;
    for ( i = 0; i < LCD_CACHE_SIZE; i++ )
        LcdCache[i] = 0x00;
    LoWaterMark = 0;
    HiWaterMark = LCD_CACHE_SIZE - 1;
    UpdateLcd = TRUE;
  Description  :  Sets cursor location to xy location corresponding to basic font size.
  Argument(s)  :  x, y -> Coordinate for new cursor position. Range: 1,1 .. 14,6
    LcdCacheIdx = (x - 1) * 6 + (y - 1) * 84;
  Description  :  Displays a character at current cursor location and increment cursor location.
  Argument(s)  :  size -> Font size. See enum.
                  ch   -> Character to write.
    byte i, c;
    byte b1, b2;
    int  tmpIdx;
    if ( LcdCacheIdx < LoWaterMark )
        //  Update low marker.
        LoWaterMark = LcdCacheIdx;
    if ( (ch < 0x20) || (ch > 0x7b) )
        //  Convert to a printable character.
        ch = 92;
    if ( size == FONT_1X )
        for ( i = 0; i < 5; i++ )
            LcdCache[LcdCacheIdx++] = FontLookup[ch - 32][i] << 1;
    else if ( size == FONT_2X )
        tmpIdx = LcdCacheIdx - 84;
        if ( tmpIdx < LoWaterMark )
            LoWaterMark = tmpIdx;
        if ( tmpIdx < 0 ) return;
            c = FontLookup[ch - 32][i] << 1;
            b1 =  (c & 0x01) * 3;
            b1 |= (c & 0x02) * 6;
            b1 |= (c & 0x04) * 12;
            b1 |= (c & 0x08) * 24;
            c >>= 4;
            b2 =  (c & 0x01) * 3;
            b2 |= (c & 0x02) * 6;
            b2 |= (c & 0x04) * 12;
            b2 |= (c & 0x08) * 24;
            LcdCache[tmpIdx++] = b1;
            LcdCache[tmpIdx + 82] = b2;
            LcdCache[tmpIdx + 83] = b2;
        //  Update x cursor position.
        LcdCacheIdx += 11;
    if ( LcdCacheIdx > HiWaterMark )
        //  Update high marker.
        HiWaterMark = LcdCacheIdx;
    //  Horizontal gap between characters.
    LcdCache[LcdCacheIdx++] = 0x00;
                  according to font size.
                  dataPtr -> Pointer to null terminated ASCII string to display.
    while ( *dataPtr )
        LcdChr( size, *dataPtr++ );
  Description  :  Displays a pixel at given absolute (x, y) location.
  Argument(s)  :  x, y -> Absolute pixel coordinates
                  mode -> Off, On or Xor. See enum.
    word  index;
    byte  offset;
    byte  data;
    if ( x > LCD_X_RES ) return;
    if ( y > LCD_Y_RES ) return;
    index = ((y / 8) * 84) + x;
    offset  = y - ((y / 8) * 8);
    data = LcdCache[index];
    if ( mode == PIXEL_OFF )
        data &= (~(0x01 << offset));
    else if ( mode == PIXEL_ON )
        data |= (0x01 << offset);
    else if ( mode  == PIXEL_XOR )
        data ^= (0x01 << offset);
    LcdCache[index] = data;
    if ( index < LoWaterMark )
        LoWaterMark = index;
    if ( index > HiWaterMark )
        HiWaterMark = index;
  Description  :  Draws a line between two points on the display.
  Argument(s)  :  x1, y1 -> Absolute pixel coordinates for line origin.
                  x2, y2 -> Absolute pixel coordinates for line end.
    int dx, dy, stepx, stepy, fraction;
    dy = y2 - y1;
    dx = x2 - x1;
    if ( dy < 0 )
        dy    = -dy;
        stepy = -1;
    else
        stepy = 1;
    if ( dx < 0 )
        dx    = -dx;
        stepx = -1;
    else
        stepx = 1;
    dx <<= 1;
    dy <<= 1;
    LcdPixel( x1, y1, mode );
    if ( dx > dy )
        fraction = dy - (dx >> 1);
        while ( x1 != x2 )
            if ( fraction >= 0 )
                y1 += stepy;
                fraction -= dx;
            x1 += stepx;
            fraction += dy;
    else
        fraction = dx - (dy >> 1);
        while ( y1 != y2 )
                x1 += stepx;
                fraction -= dy;
            y1 += stepy;
            fraction += dx;
    UpdateLcd = TRUE;
  Description  :  Copies the LCD cache into the device RAM.
  Argument(s)  :  None.
    int i;
    if ( LoWaterMark < 0 )
        LoWaterMark = 0;
    else if ( LoWaterMark >= LCD_CACHE_SIZE )
        LoWaterMark = LCD_CACHE_SIZE - 1;
    if ( HiWaterMark < 0 )
        HiWaterMark = 0;
    else if ( HiWaterMark >= LCD_CACHE_SIZE )
    //  Set base address according to LoWaterMark.
    LcdSend( 0x80 | (LoWaterMark % LCD_X_RES), LCD_CMD );
    LcdSend( 0x40 | (LoWaterMark / LCD_X_RES), LCD_CMD );
    //  Serialize the video buffer.
    for ( i = LoWaterMark; i <= HiWaterMark; i++ )
        LcdSend( LcdCache[i], LCD_DATA );
    HiWaterMark = 0;
    UpdateLcd = FALSE;
  Description  :  Sends data to display controller.
  Argument(s)  :  data -> Data to be sent
                  cd   -> Command or data (see/use enum)
    //  Enable display controller (active low).
    PORTB &= ~LCD_CE_PIN;
    if ( cd == LCD_DATA )
        PORTB |= LCD_DC_PIN;
    else
        PORTB &= ~LCD_DC_PIN;
    //  Send data to display controller.
    SPDR = data;
    //  Wait until Tx register empty.
    while ( (SPSR & 0x80) != 0x80 );
    //  Disable display controller.
  Description  :  Uncalibrated delay for LCD init routine.
  Argument(s)  :  None.
    int i;
    for ( i = -32000; i < 32000; i++ );
                                         End of file.
