[Main] FileType=CIR Version=8.01 Program=Micro-Cap Screen=1440,900 MCAPVersion=8.1.1.0 Key ID=Demo NLCnt=223 TXCnt=32 [shapedef] Name=Battery Line=0,0,22,0 Line=22,-3,22,3 Line=26,-7,26,7 Line=26,0,48,0 Current=32,8,16,8 [shapedef] Name=Resistor PolyOpen=12 PolyLine=0,0 PolyLine=0,0 PolyLine=12,0 PolyLine=14,-4 PolyLine=18,4 PolyLine=22,-4 PolyLine=26,4 PolyLine=30,-4 PolyLine=34,4 PolyLine=36,0 PolyLine=48,0 PolyLine=48,0 Current=32,8,16,8 [shapedef] Name=Diode Root="Diode.root",0,-8,0 [shapedef] Name=Opamp5 Root="Opamp.root",0,-4,0 Root="Plus.root",23,-6,0 Root="Minus.root",23,52,0 Line=32,56,32,34 Line=32,-8,32,13 [shapedef] Name=Ground Line=0,0,12,0 Line=12,-8,12,8 Line=18,-4,18,4 Line=24,0,24,0 [shapedef] Name=Diode.root Line=0,0,20,0 Line=28,0,48,0 Rectangle=18,-8,20,8,SOLID PolyClosed=3 ,Solid PolyLine=20,0 PolyLine=28,-8 PolyLine=28,8 Current=32,16,16,16 [shapedef] Name=Opamp.root Line=0,48,6,48 Line=0,0,5,0 Line=6,-4,6,52 Line=6,-4,48,24 Line=6,52,48,24 Line=48,24,72,24 Line=10,12,14,12 Line=12,10,12,14 Line=10,36,14,36 Line=4,0,6,0 [shapedef] Name=Minus.root Line=-2,0,2,0 [shapedef] Name=Plus.root Line=-2,0,2,0 Line=0,-2,0,2 [shapedef] Name=Pot Line=0,0,12,0 Line=12,0,14,-4 Line=14,-4,18,4 Line=18,4,22,-4 Line=22,-4,26,4 Line=26,4,30,-4 Line=30,-4,34,4 Line=34,4,36,0 Line=36,0,48,0 PolyClosed=4 ,Solid PolyLine=24,4 PolyLine=24,4 PolyLine=22,8 PolyLine=26,8 Line=24,8,24,16 [shapedef] Name=Animated Analog Led Animated Analog Led=0,-24,8,0 Current=-8,-8,-8,-16 Line=-4,-6,-4,-2 Line=-6,-4,-2,-4 [shapedef] Name=Comp_Hys Line=0,48,6,48 Line=0,0,5,0 Line=6,-4,6,52 Line=6,-4,48,24 Line=6,52,48,24 Line=48,24,72,24 Line=10,12,14,12 Line=12,10,12,14 Line=10,36,14,36 Line=4,0,6,0 Line=21,16,32,16 Line=16,32,27,32 Line=27,32,27,16 Line=21,16,21,32 [compdef] Name=Comparator Definition=Macro Shape=Comp_Hys Mask=4224 memo=Comparator with Hysteresis Macro Label Offset=34,36,-10,31 PinCnt=3 Pin="Inp",a,0,0,-8,-3 Pin="Inm",a,0,6,-12,-2 Pin="Out",a,9,3,-8,-3 [compdef] Name=Resistor Definition=Resistor Shape=Resistor Mask=7937 memo=Resistor Label Offset=18,6,8,11 PinCnt=2 Pin="Plus",6,0,-10,-4 Pin="Minus",0,0,-14,-4 [compdef] Name=LM3401 Definition=NULL Shape=Opamp5 Mask=4224 memo=Quad Opamp Label Offset=51,32,-15,46 PinCnt=0 [compdef] Name=Diode Definition=Diode Shape=Diode Mask=5633 memo=Diode Label Offset=17,10,12,12 PinCnt=2 Pin="Anode",6,0,-9,-8 Pin="Cathode",0,0,-20,-8 [compdef] Name=Animated Analog LED Definition=ANIMATED ANALOG LED Shape=Animated Analog Led Mask=4096 memo=Animated Analog LED Label Offset=12,-27,5,10 PinCnt=2 Pin="Anode",0,0,-24,5 Pin="Cathode",1,0,5,5 [compdef] Name=Ground Definition=Ground Shape=Ground Mask=1793 memo=Ground Label Offset=0,0,0,0 PinCnt=1 Pin="PinA",0,0,-3,-7 [compdef] Name=Battery Definition=Battery Shape=Battery Mask=5889 memo=Battery Label Offset=19,7,10,13 PinCnt=2 Pin="Plus",6,0,-4,-5 Pin="Minus",0,0,-10,-5 [compdef] Name=Pot Definition=Macro Shape=Pot Mask=4096 memo=Potentiometer Macro Label Offset=32,4,9,11 PinCnt=3 Pin="PINA",a,0,0,-13,-5 Pin="PINB",a,3,2,6,5 Pin="PINC",a,6,0,-12,-5 [Circuit] Window Placement=2,3, -1,-1, -4,-30, 0,0,1068,502 Default Object=Color=4 Default Object Font=Height=-15,FStyle=0,Color=4,Name=Arial Default Object Apply Border To Text=No Default Object Apply Fill To Text=No WinBackGround Color=15 Select Color=9 Select Box Color=4 Grid Text Color=Height=-12,FStyle=0,Color=1,Name=Arial Component Color=12 Attribute Text=Height=-12,FStyle=0,Color=2,Name=Arial Wire Color=2 Pin Connection=Height=-10,FStyle=0,Color=9,Name=Arial Node Number=Height=-11,FStyle=0,Color=13,Name=Arial Node Voltage Color=0 Dynamic AC Voltage Color=56 Text Banner Text=Height=-15,FStyle=0,Color=1,Name=Arial Title Block Background=7 Current=Height=-11,FStyle=0,Color=12,Name=Arial Power/Condition=Height=-11,FStyle=0,Color=9,Name=Arial Digital Path Color=9 Title Block=Height=-15,FStyle=0,Color=0,Name=Arial Digital 0 Color=0 Digital R Color=11 Digital F Color=11 Digital 1 Color=9 Digital X Color=7 Digital Z Color=8 SpiceType=AMBIGUOUS Block Select Color=41 TitleBlock Field_1=$name TitleBlock Field_2=$user $company TitleBlock Field_3 TitleBlock Field_4=$date TitleBlock Field_5=Page $page of $maxpage TitleBlock One Title=False Title_Block_Border=False Title_Block=False [Comp] Name=Comparator Grid=85,27 Rot=3 [Attr] ONV=18,0,PART,X1 Style=8192 [Attr] ONV=34,51,FILE,Comparator [Comp] Name=Comparator Grid=91,35 Rot=3 [Attr] ONV=19,-3,PART,X2 Style=8192 [Attr] ONV=34,51,FILE,Comparator [Wire] Grids=94,12,94,26 [Wire] Grids=83,27,85,27 [Wire] Grids=83,21,83,27 [Wire] Grids=91,27,91,29 [Wire] Grids=82,29,91,29 [Wire] Grids=82,24,82,29 [Wire] Grids=36,24,77,24 [Wire] Grids=87,35,91,35 [Wire] Grids=87,31,87,35 [Wire] Grids=80,31,87,31 [Wire] Grids=80,26,80,31 [Wire] Grids=34,26,77,26 [Wire] Grids=97,35,97,38 [Wire] Grids=85,38,97,38 [Wire] Grids=85,33,85,38 [Wire] Grids=78,33,85,33 [Wire] Grids=78,28,78,33 [Wire] Grids=36,28,77,28 [Comp] Name=Comparator Grid=111,27 Rot=5 [Attr] ONV=-32,0,PART,X3 Style=8192 [Attr] ONV=-34,51,FILE,Comparator [Comp] Name=Comparator Grid=105,35 Rot=5 [Attr] ONV=-33,-3,PART,X4 Style=8192 [Attr] ONV=-34,51,FILE,Comparator [Wire] Grids=108,16,119,16 [Wire] Grids=102,12,102,26 [Wire] Grids=102,12,119,12 [Wire] Grids=111,27,113,27 [Wire] Grids=113,21,113,27 [Wire] Grids=113,21,119,21 [Wire] Grids=105,27,105,29 [Wire] Grids=105,29,114,29 [Wire] Grids=114,24,114,29 [Wire] Grids=114,24,119,24 [Wire] Grids=105,35,109,35 [Wire] Grids=109,31,109,35 [Wire] Grids=109,31,116,31 [Wire] Grids=116,26,116,31 [Wire] Grids=116,26,119,26 [Wire] Grids=99,35,99,38 [Wire] Grids=99,38,111,38 [Wire] Grids=111,33,111,38 [Wire] Grids=111,33,118,33 [Wire] Grids=118,28,118,33 [Wire] Grids=118,28,119,28 [Wire] Grids=77,12,94,12 [Wire] Grids=77,16,88,16 [Wire] Grids=77,21,83,21 [Wire] Grids=77,24,82,24 [Wire] Grids=77,26,80,26 [Wire] Grids=77,28,78,28 [Wire] Grids=125,12,186,12 [Wire] Grids=124,16,125,16 [Wire] Grids=119,21,144,21 [Wire] Grids=119,24,126,24 [Wire] Grids=119,26,147,26 [Wire] Grids=119,28,126,28 [Comp] Name=Comparator Grid=85,55 Rot=3 [Attr] ONV=18,0,PART,X5 Style=8192 [Attr] ONV=34,51,FILE,Comparator [Comp] Name=Comparator Grid=91,63 Rot=3 [Attr] ONV=19,-3,PART,X6 Style=8192 [Attr] ONV=34,51,FILE,Comparator [Wire] Grids=94,40,94,54 [Wire] Grids=83,55,85,55 [Wire] Grids=83,49,83,55 [Wire] Grids=34,49,77,49 [Wire] Grids=91,55,91,57 [Wire] Grids=82,57,91,57 [Wire] Grids=82,52,82,57 [Wire] Grids=87,63,91,63 [Wire] Grids=87,59,87,63 [Wire] Grids=80,59,87,59 [Wire] Grids=80,54,80,59 [Wire] Grids=34,54,77,54 [Wire] Grids=97,63,97,66 [Wire] Grids=85,66,97,66 [Wire] Grids=85,61,85,66 [Wire] Grids=78,61,85,61 [Wire] Grids=78,56,78,61 [Comp] Name=Comparator Grid=111,55 Rot=5 [Attr] ONV=-32,0,PART,X7 Style=8192 [Attr] ONV=-34,51,FILE,Comparator [Comp] Name=Comparator Grid=105,63 Rot=5 [Attr] ONV=-33,-3,PART,X8 Style=8192 [Attr] ONV=-34,51,FILE,Comparator [Wire] Grids=108,46,119,46 [Wire] Grids=102,43,102,54 [Wire] Grids=102,43,119,43 [Wire] Grids=111,55,113,55 [Wire] Grids=113,49,113,55 [Wire] Grids=113,49,119,49 [Wire] Grids=105,55,105,57 [Wire] Grids=105,57,114,57 [Wire] Grids=114,52,114,57 [Wire] Grids=114,52,119,52 [Wire] Grids=105,63,109,63 [Wire] Grids=109,59,109,63 [Wire] Grids=109,59,116,59 [Wire] Grids=116,54,116,59 [Wire] Grids=116,54,119,54 [Wire] Grids=99,63,99,66 [Wire] Grids=99,66,111,66 [Wire] Grids=111,61,111,66 [Wire] Grids=111,61,118,61 [Wire] Grids=118,56,118,61 [Wire] Grids=118,56,119,56 [Wire] Grids=77,40,94,40 [Wire] Grids=77,44,88,44 [Wire] Grids=77,49,83,49 [Wire] Grids=77,52,82,52 [Wire] Grids=77,54,80,54 [Wire] Grids=77,56,78,56 [Comp] Name=Resistor Grid=71,12 Rot=4 [Attr] ONV=15,-39,PART,R9 Style=8192 [Attr] ONV=10,-23,VALUE,604 Style=8192 [Attr] ONV=0,0,COST,1% [Comp] Name=Resistor Grid=71,16 Rot=4 [Attr] ONV=12,-17,PART,R8 Style=8192 [Attr] ONV=13,3,VALUE,604 Style=8192 [Attr] ONV=0,0,COST,1% [Comp] Name=Resistor Grid=119,12 Rot=4 [Attr] ONV=15,-39,PART,R10 Style=8192 [Attr] ONV=10,-23,VALUE,604 Style=8192 [Attr] ONV=0,0,COST,1% [Comp] Name=Resistor Grid=119,16 Rot=4 [Attr] ONV=15,-20,PART,R11 Style=8192 [Attr] ONV=16,4,VALUE,604 Style=8192 [Attr] ONV=0,0,COST,1% [Wire] Grids=125,16,185,16 [Wire] Grids=88,16,88,18 [Wire] Grids=108,16,108,18 [Comp] Name=Resistor Grid=71,40 Rot=4 [Attr] ONV=15,-39,PART,R12 Style=8192 [Attr] ONV=10,-23,VALUE,604 Style=8192 [Attr] ONV=0,0,COST,1% [Comp] Name=Resistor Grid=71,44 Rot=4 [Attr] ONV=12,-21,PART,R13 Style=8192 [Attr] ONV=12,6,VALUE,604 Style=8192 [Attr] ONV=0,0,COST,1% [Wire] Grids=88,44,88,46 [Comp] Name=LM3401 Grid=123,111 Rot=2 [Attr] ONV=7,-27,PART,Part1 Style=8192 [Attr] ONV=51,47,PACKAGE,DIP14 [Attr] ONV=51,62,GATE,A [Attr] ONV=51,77,COMPNAME,UPart1 [Wire] Grids=18,115,123,115 [Wire] Grids=18,121,21,121 [Wire] Grids=219,115,221,115 [Comp] Name=Resistor Grid=216,76 Rot=7 [Attr] ONV=-31,11,PART,R14 Style=8192 [Attr] ONV=-29,26,VALUE,464 Style=8192 [Attr] ONV=-26,41,COST,1% [Comp] Name=Diode Grid=216,82 Rot=7 [Attr] ONV=-33,10,PART,D1 Style=8192 [Attr] ONV=-61,25,MODEL,1N4007 [Comp] Name=Animated Analog LED Grid=210,55 Rot=6 [Attr] ONV=-40,-20,PART,Led1 Style=8192 [Attr] ONV=-12,-12,COLOR,Blue,3.4,0.012 [Attr] ONV=0,0,COLOR_INDEX,12 Style=256 [Comp] Name=Animated Analog LED Grid=210,60 Rot=6 [Attr] ONV=-40,-19,PART,Led2 Style=8192 [Attr] ONV=-12,-12,COLOR,Blue,3.4,0.012 [Attr] ONV=0,0,COLOR_INDEX,12 Style=256 [Comp] Name=Animated Analog LED Grid=210,64 Rot=6 [Attr] ONV=-40,-17,PART,Led3 Style=8192 [Attr] ONV=-12,-12,COLOR,Blue,3.4,0.012 [Attr] ONV=0,0,COLOR_INDEX,12 Style=256 [Comp] Name=Animated Analog LED Grid=210,68 Rot=6 [Attr] ONV=-40,-20,PART,Led4 Style=8192 [Attr] ONV=-12,-12,COLOR,Blue,3.4,0.012 [Attr] ONV=0,0,COLOR_INDEX,12 Style=256 [Comp] Name=Animated Analog LED Grid=210,72 Rot=6 [Attr] ONV=-40,-19,PART,Led5 Style=8192 [Attr] ONV=-12,-12,COLOR,Blue,3.4,0.012 [Attr] ONV=0,0,COLOR_INDEX,12 Style=256 [Comp] Name=Animated Analog LED Grid=210,76 Rot=6 [Attr] ONV=-40,-17,PART,Led6 Style=8192 [Attr] ONV=-12,-12,COLOR,Blue,3.4,0.012 [Attr] ONV=0,0,COLOR_INDEX,12 Style=256 [Wire] Grids=210,55,216,55 [Wire] Grids=216,55,216,60 [Wire] Grids=210,60,216,60 [Wire] Grids=216,60,216,64 [Wire] Grids=210,64,216,64 [Wire] Grids=216,64,216,68 [Wire] Grids=210,68,216,68 [Wire] Grids=216,68,216,72 [Wire] Grids=210,72,216,72 [Wire] Grids=216,72,216,76 [Wire] Grids=210,76,216,76 [Wire] Grids=193,55,209,55 [Wire] Grids=193,55,193,69 [Wire] Grids=20,69,26,69 [Wire] Grids=196,60,209,60 [Wire] Grids=196,60,196,72 [Wire] Grids=20,72,24,72 [Wire] Grids=198,64,209,64 [Wire] Grids=198,64,198,75 [Wire] Grids=20,75,186,75 [Wire] Grids=200,68,209,68 [Wire] Grids=200,68,200,77 [Wire] Grids=20,77,185,77 [Wire] Grids=202,72,209,72 [Wire] Grids=202,72,202,79 [Wire] Grids=20,79,28,79 [Wire] Grids=204,76,209,76 [Wire] Grids=204,76,204,81 [Wire] Grids=20,81,30,81 [Wire] Grids=26,16,26,69 [Wire] Grids=26,16,71,16 [Wire] Grids=26,69,193,69 [Wire] Grids=24,12,24,72 [Wire] Grids=24,12,71,12 [Wire] Grids=24,72,196,72 [Wire] Grids=28,40,28,79 [Wire] Grids=28,40,71,40 [Wire] Grids=28,79,202,79 [Wire] Grids=30,44,30,81 [Wire] Grids=30,44,71,44 [Wire] Grids=30,81,204,81 [Wire] Grids=185,16,185,77 [Wire] Grids=185,77,200,77 [Wire] Grids=186,12,186,75 [Wire] Grids=186,75,198,75 [Wire] Grids=216,88,216,115 [Wire] Grids=216,115,219,115 [Wire] Grids=34,21,34,26 [Wire] Grids=34,21,77,21 [Wire] Grids=34,26,34,39 [Wire] Grids=34,49,34,54 [Wire] Grids=34,54,34,100 [Wire] Grids=123,111,123,115 [Wire] Grids=109,108,117,108 [Comp] Name=Resistor Grid=133,99 Rot=7 [Attr] ONV=-31,11,PART,R1 Style=8192 [Attr] ONV=-29,26,VALUE,464 Style=8192 [Attr] ONV=-26,41,COST,1% [Comp] Name=Resistor Grid=142,99 Rot=7 [Attr] ONV=-31,11,PART,R2 Style=8192 [Attr] ONV=-29,26,VALUE,464 Style=8192 [Attr] ONV=-26,41,COST,1% [Comp] Name=Resistor Grid=151,99 Rot=7 [Attr] ONV=-31,11,PART,R3 Style=8192 [Attr] ONV=-29,26,VALUE,681 Style=8192 [Attr] ONV=-26,41,COST,1% [Comp] Name=Resistor Grid=159,99 Rot=7 [Attr] ONV=-31,11,PART,R4 Style=8192 [Attr] ONV=-29,26,VALUE,681 Style=8192 [Attr] ONV=-26,41,COST,1% [Comp] Name=Resistor Grid=167,99 Rot=7 [Attr] ONV=-31,11,PART,R5 Style=8192 [Attr] ONV=-29,26,VALUE,604 Style=8192 [Attr] ONV=-26,41,COST,1% [Comp] Name=Resistor Grid=175,99 Rot=7 [Attr] ONV=-31,11,PART,R6 Style=8192 [Attr] ONV=-36,26,VALUE,1000 Style=8192 [Attr] ONV=-26,41,COST,1% [Comp] Name=Resistor Grid=184,99 Rot=7 [Attr] ONV=-31,11,PART,R7 Style=8192 [Attr] ONV=-36,26,VALUE,1000 Style=8192 [Attr] ONV=-26,41,COST,1% [Wire] Grids=123,115,216,115 [Wire] Grids=123,105,133,105 [Wire] Grids=133,99,137,99 [Wire] Grids=142,105,151,105 [Wire] Grids=151,99,155,99 [Wire] Grids=159,105,167,105 [Wire] Grids=167,99,171,99 [Wire] Grids=175,105,184,105 [Wire] Grids=184,99,188,99 [Wire] Grids=137,96,137,99 [Wire] Grids=137,99,142,99 [Wire] Grids=155,93,155,99 [Wire] Grids=155,99,159,99 [Wire] Grids=171,90,171,99 [Wire] Grids=171,99,175,99 [Wire] Grids=188,87,188,99 [Wire] Grids=188,99,191,99 [Wire] Grids=69,52,69,96 [Wire] Grids=72,56,72,93 [Wire] Grids=144,21,144,90 [Wire] Grids=144,90,171,90 [Wire] Grids=147,26,147,87 [Wire] Grids=147,87,188,87 [Wire] Grids=126,24,126,28 [Wire] Grids=126,28,126,39 [Wire] Grids=34,39,126,39 [Wire] Grids=34,39,34,49 [Wire] Grids=72,56,77,56 [Wire] Grids=72,93,155,93 [Wire] Grids=69,52,77,52 [Wire] Grids=69,96,137,96 [Comp] Name=Ground Grid=21,121 Rot=7 [Comp] Name=Ground Grid=109,108 Rot=7 [Comp] Name=Ground Grid=191,99 Rot=7 [Comp] Name=Ground Grid=34,106 Rot=7 [Comp] Name=Battery Style=ShowPinText ShowPinMarkers=True ShowPackagePins=True Grid=18,121 Rot=5 [Attr] ONV=-26,-25,PART,V2 Style=8192 [Attr] ONV=-45,28,POWER,12 volt [Comp] Name=Pot Grid=34,106 Rot=3 [Attr] ONV=32,4,PART,X9 Style=8192 [Attr] ONV=32,19,FILE,Pot [Attr] ONV=32,34,Param:POTSIZE,10K [Attr] ONV=32,49,Param:PERCENT,50 [Grid Text] Text="váltópozíció jel" Grid=34,97 CBorder=NONE [Grid Text] Text="1" Grid=77,12 CBorder=NONE [Grid Text] Text="2" Grid=77,16 CBorder=NONE [Grid Text] Text="4" Grid=77,21 CBorder=NONE [Grid Text] Text="5" Grid=77,24 CBorder=NONE [Grid Text] Text="6" Grid=77,26 CBorder=NONE [Grid Text] Text="7" Grid=77,28 CBorder=NONE [Grid Text] Text="14" Grid=119,12 CBorder=NONE [Grid Text] Text="13" Grid=119,16 CBorder=NONE [Grid Text] Text="11" Grid=119,21 CBorder=NONE [Grid Text] Text="10" Grid=119,24 CBorder=NONE [Grid Text] Text="9" Grid=119,26 CBorder=NONE [Grid Text] Text="8" Grid=119,28 CBorder=NONE [Grid Text] Text="1" Grid=77,40 CBorder=NONE [Grid Text] Text="2" Grid=77,44 CBorder=NONE [Grid Text] Text="4" Grid=77,49 CBorder=NONE [Grid Text] Text="5" Grid=77,52 CBorder=NONE [Grid Text] Text="6" Grid=77,54 CBorder=NONE [Grid Text] Text="7" Grid=77,56 CBorder=NONE [Grid Text] Text="14" Grid=119,43 CBorder=NONE [Grid Text] Text="13" Grid=119,46 CBorder=NONE [Grid Text] Text="11" Grid=119,49 CBorder=NONE [Grid Text] Text="10" Grid=119,52 CBorder=NONE [Grid Text] Text="9" Grid=119,54 CBorder=NONE [Grid Text] Text="8" Grid=119,56 CBorder=NONE [Grid Text] Text="+" Grid=219,115 CBorder=NONE [Grid Text] Text="led 1" Grid=21,69 CBorder=NONE [Grid Text] Text="led 2" Grid=21,72 CBorder=NONE [Grid Text] Text="led 3" Grid=21,75 CBorder=NONE [Grid Text] Text="led 4" Grid=21,77 CBorder=NONE [Grid Text] Text="led 5" Grid=21,79 CBorder=NONE [Grid Text] Text="led 6" Grid=21,81 CBorder=NONE [Schematic] Page 0=0 TabSize 0=340 Page 1=0 TabSize 1=340 Page 2=0 TabSize 2=340 Page 3=0 TabSize 3=340 Splitter.xs=0 Splitter.ys=0 TextQuad=4099 Scale=1.333333333333333 PrinterScale=1 View=304 GridUser=10 [Tools] Pos=Top SELECT=Yes COMP=Yes TEXT=Yes WIRE=Yes WIRED=Yes GRAPHIC=Yes LINE=No ELLIPSE=No RECT=No DIAM=No ARC=No PIE=No LEFTBRK=No RIGHTBRK=No BOTHBRK=No FLAG=Yes META=No INFO=Yes HELP=Yes DIGTRC=No DIGTRC2=No DIGALL=No GRIDTEXT=Yes COMPTEXT=Yes NODE=Yes NODEV=Yes CURRENT=Yes POWER=Yes CONDITIN=Yes PIN=Yes CROSS=Yes GRID=Yes BORDER=Yes TITLE=Yes RUBBER=Yes PROPERTY=Yes STEP=Yes MIRROR=Yes ROTATE=Yes FLIPY=Yes FILPX=Yes FINDCOMP=Yes FIND=Yes REPEAT=No MODEL=Yes CIR2CKT=No ATTDISP=No TOFRONT=Yes TOBACK=Yes PAGEADD=Yes PAGEDEL=Yes ZOOMIN=Yes ZOOMOUT=Yes GOTOFLAG=Yes COLOR=Yes FONT=Yes [Page] Index=0 Print=True Name=Main Scale 0=1 Scale 1=1 Scale 2=1 SB 3=38,230 Scale 3=1.333333333333333 Grid=82,109 [Page] Index=1 Type=Text Print=False Name=Text Scale 0=1 Scale 1=1 Scale 2=1 Scale 3=1 Grid=0,0 [Page] Index=2 Type=Text Print=False Name=Models Scale 0=1 Scale 1=1 Scale 2=1 Scale 3=1 Grid=0,0 [Page] Index=3 Type=Info Print=False Name=Info Scale 0=1 Scale 1=1 Scale 2=1 Scale 3=1 Grid=0,0 [Text Area] Page=1 Font=Height=-15,FStyle=0,Color=4,Name=Courier New Comment Color=8 Background Color=15 Len=0 [Text Area] Page=2 Font=Height=-15,FStyle=0,Color=4,Name=Courier New Comment Color=8 Background Color=15 Len=20 .MODEL 1N4007 D () [Limits] Analysis=DynamicAC FirstValueDisplay=Mag SecondValueDisplay=PhaseDeg PlaceText=True [Limits] Analysis=DynamicDC PlaceText=True [Optimize] Format=3
