#define WIRE_PORT P2_4
#define DS1820_SKIP_ROM             0xCC
#define DS1820_READ_SCRATCHPAD      0xBE
#define DS1820_CONVERT_T            0x44
void setup()
  Serial.begin(9600);
void loop()
  float temper = GetData();
  Serial.print(temper, DEC);
  Serial.println(" Celsius");
  delay(1000);
} // end loop
// ---- Reset ------------------------------------------------------------------
int ds1820_reset(int pin){
  pinMode(pin, OUTPUT);
  digitalWrite(pin, LOW);
  delayMicroseconds( 480 );
  pinMode( pin, INPUT );
  int bus = digitalRead(pin);
  return ( bus );
// ---- Read bit ---------------------------------------------------------------
int ds1820_read_bit(int pin){
  delayMicroseconds( 5 );
  delayMicroseconds( 10 );
  int value = ( digitalRead( pin ) == HIGH );
  delayMicroseconds( 45 );
  return value;
// ---- Read bits ---------------------------------------------------------------
int ds1820_read_bits( int pin ){
  int i;
  int value = 0;
  for(i=16; i>0; i--)
    value >>= 1;
    if ( ds1820_read_bit(pin) )
      value |= 0x8000;
  return value;
// ---- Write bit ---------------------------------------------------------------
void ds1820_write_bit(int b, int pin){
  if ( b ) {
   // digitalWrite(pin, HIGH);
    delayMicroseconds( 55 );
  } else {
    delayMicroseconds( 60 );
  delayMicroseconds( 1 );
// ---- Write bits ---------------------------------------------------------------
int ds1820_write_bits( int data, int pin ){
  int i;
  for(i=8; i>0; i--) {
    if(data & 0x01) {
      ds1820_write_bit(1, pin );
    else {
      ds1820_write_bit(0, pin );
    data >>=1;
  return 1;
float GetData(void)
  int temp;
  ds1820_reset(WIRE_PORT);
  ds1820_write_bits( DS1820_SKIP_ROM , WIRE_PORT );
  ds1820_write_bits( DS1820_CONVERT_T , WIRE_PORT );
  delay(750);
  ds1820_write_bits( DS1820_READ_SCRATCHPAD , WIRE_PORT );
  temp = ds1820_read_bits( WIRE_PORT );
  if(temp<0x8000){
    return(temp*0.0625);
  else
    temp=(~temp)+1;
