Az ic-prog oldalan van leiras rola hogy kell xp alatt eletre kelteni.
Nekem igy mukodott.
Udv: Balazs
http://www.ic-prog.com/index1.htm
UPDATE!!! : Settings for how to use IC-Prog with Windows XP. Thanks to
[Murph] for the explanation:
1.Open a browser and select the file ic-prog.exe
2.Press right button on your mouse
3.Go to Propertties
4.Go to Compatibility menu
5.Set compatibilty mode as Windows 2000 or Windows 98 / Win ME
6.Press Apply icon
7.Press Accept icon
You need to copy icprog.sys into the SAME directory as icprog.exe. Then you
can enter in the ic-prog software, go to Settings, Options and choose the
Misc. page. There you can enable the "NT/2000 Driver" it will then be
installed.
