This is a library for the Adafruit 2.2" SPI display.
This library works with the Adafruit 2.2" TFT Breakout w/SD card
  ----> http://www.adafruit.com/products/1480
Check out the links above for our tutorials and wiring diagrams.
These displays use SPI to communicate, 4 or 5 pins are required
to interface (RST is optional).
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
MIT license, all text above must be included in any redistribution
To download. click the DOWNLOADS button in the top right corner, rename the uncompressed folder Adafruit_ILI9340. Check that the Adafruit_ILI9340 folder contains Adafruit_ILI9340.cpp and Adafruit_ILI9340.
Place the Adafruit_ILI9340 library folder your <arduinosketchfolder>/libraries/ folder. You may need to create the libraries subfolder if its your first library. Restart the IDE
Also requires the Adafruit_GFX library for Arduino.
