--Small demo of internet/network controlled relay using ESP8266 (ESP-01) module and 2 channel optoisolated relay board --Made by Sandeep Vaidya @ Robokits India - http://www.robokits.co.in for demo. --Configure relay ouutput pins, pins are floating and relay opto needs ground to be activated. So pins are kept high on startup. Relay1 = 4 Relay2 = 3 gpio.mode(Relay1, gpio.OUTPUT) gpio.write(Relay1, gpio.LOW); gpio.mode(Relay2, gpio.OUTPUT) gpio.write(Relay2, gpio.HIGH); wifi.setmode(wifi.STATION) --Set network mode to station to connect it to wifi router. You can also set it to AP to make it a access point allowing connection from other wifi devices. --Set a static ip so its easy to access cfg = { ip="192.168.0.24", netmask="255.255.252.0", gateway="192.168.0.1" } wifi.sta.setip(cfg) --Your router wifi network's SSID and password wifi.sta.config("XXXXXXX","XXXXXXX") --Automatically connect to network after disconnection wifi.sta.autoconnect(1) print ("\r\n") --Print network ip address on UART to confirm that network is connected print(wifi.sta.getip()) --Create server and send html data, process request from html for relay on/off. srv=net.createServer(net.TCP) srv:listen(80,function(conn) --change port number if required. Provides flexibility when controlling through internet. conn:on("receive", function(client,request) local html_buffer = ""; local html_buffer1 = ""; local _, _, method, path, vars = string.find(request, "([A-Z]+) (.+)?(.+) HTTP"); if(method == nil)then _, _, method, path = string.find(request, "([A-Z]+) (.+) HTTP"); end local _GET = {} if (vars ~= nil)then for k, v in string.gmatch(vars, "(%w+)=(%w+)&*") do _GET[k] = v end end html_buffer = html_buffer.."
"; html_buffer = html_buffer..""; html_buffer = html_buffer.."
