# Automatically-generated file. Do not edit!
SHELL = cmd.exe
CG_TOOL_ROOT := C:/ti/ccsv5/tools/compiler/msp430_4.1.1
ORDERED_OBJS += \
$(GEN_CMDS__FLAG) \
"./core/driver/eMPL/inv_mpu_dmp_motion_driver.obj" \
"./core/driver/eMPL/inv_mpu.obj" \
"./core/driver/msp430/F5xx_F6xx_Core_Lib/HAL_UCS.obj" \
"./core/driver/msp430/F5xx_F6xx_Core_Lib/HAL_TLV.obj" \
"./core/driver/msp430/F5xx_F6xx_Core_Lib/HAL_PMM.obj" \
"./core/driver/msp430/F5xx_F6xx_Core_Lib/HAL_PMAP.obj" \
"./core/driver/msp430/F5xx_F6xx_Core_Lib/HAL_FLASH.obj" \
"./core/driver/msp430/USB_API/USB_CDC_API/UsbCdc.obj" \
"./core/driver/msp430/USB_API/USB_Common/usb.obj" \
"./core/driver/msp430/USB_API/USB_Common/dma.obj" \
"./core/driver/msp430/USB_API/USB_HID_API/UsbHidReq.obj" \
"./core/driver/msp430/USB_API/USB_HID_API/UsbHid.obj" \
"./core/driver/msp430/USB_API/USB_MSC_API/UsbMscStateMachine.obj" \
"./core/driver/msp430/USB_API/USB_MSC_API/UsbMscScsi.obj" \
"./core/driver/msp430/USB_API/USB_MSC_API/UsbMscReq.obj" \
"./core/driver/msp430/USB_API/USB_PHDC_API/UsbPHDC.obj" \
"./core/driver/msp430/USB_eMPL/usbEventHandling.obj" \
"./core/driver/msp430/USB_eMPL/usbConstructs.obj" \
"./core/driver/msp430/USB_eMPL/descriptors.obj" \
"./core/driver/msp430/USB_eMPL/UsbIsr.obj" \
"./core/driver/msp430/msp430_interrupt.obj" \
"./core/driver/msp430/msp430_i2c.obj" \
"./core/driver/msp430/msp430_clock.obj" \
"./simple_apps/msp430/motion_driver_test.obj" \
-l"libc.a" \
"../lnk_msp430f5528.cmd" \
"../core/driver/msp430/msp430USB.cmd" \
-include ../makefile.init
RM := DEL /F
RMDIR := RMDIR /S/Q
# All of the sources participating in the build are defined here
-include sources.mk
-include subdir_vars.mk
-include simple_apps/msp430/subdir_vars.mk
-include core/driver/msp430/subdir_vars.mk
-include core/driver/msp430/USB_eMPL/subdir_vars.mk
-include core/driver/msp430/USB_API/USB_PHDC_API/subdir_vars.mk
-include core/driver/msp430/USB_API/USB_MSC_API/subdir_vars.mk
-include core/driver/msp430/USB_API/USB_HID_API/subdir_vars.mk
-include core/driver/msp430/USB_API/USB_Common/subdir_vars.mk
-include core/driver/msp430/USB_API/USB_CDC_API/subdir_vars.mk
-include core/driver/msp430/F5xx_F6xx_Core_Lib/subdir_vars.mk
-include core/driver/eMPL/subdir_vars.mk
-include subdir_rules.mk
-include simple_apps/msp430/subdir_rules.mk
-include core/driver/msp430/subdir_rules.mk
-include core/driver/msp430/USB_eMPL/subdir_rules.mk
-include core/driver/msp430/USB_API/USB_PHDC_API/subdir_rules.mk
-include core/driver/msp430/USB_API/USB_MSC_API/subdir_rules.mk
-include core/driver/msp430/USB_API/USB_HID_API/subdir_rules.mk
-include core/driver/msp430/USB_API/USB_Common/subdir_rules.mk
-include core/driver/msp430/USB_API/USB_CDC_API/subdir_rules.mk
-include core/driver/msp430/F5xx_F6xx_Core_Lib/subdir_rules.mk
-include core/driver/eMPL/subdir_rules.mk
-include objects.mk
ifneq ($(MAKECMDGOALS),clean)
ifneq ($(strip $(S_DEPS)),)
-include $(S_DEPS)
endif
ifneq ($(strip $(S_UPPER_DEPS)),)
-include $(S_UPPER_DEPS)
endif
ifneq ($(strip $(S62_DEPS)),)
-include $(S62_DEPS)
endif
ifneq ($(strip $(C64_DEPS)),)
-include $(C64_DEPS)
endif
ifneq ($(strip $(ASM_DEPS)),)
-include $(ASM_DEPS)
endif
ifneq ($(strip $(CC_DEPS)),)
-include $(CC_DEPS)
endif
ifneq ($(strip $(S55_DEPS)),)
-include $(S55_DEPS)
endif
ifneq ($(strip $(C67_DEPS)),)
-include $(C67_DEPS)
endif
ifneq ($(strip $(C??_DEPS)),)
-include $(C??_DEPS)
endif
ifneq ($(strip $(CLA_DEPS)),)
-include $(CLA_DEPS)
endif
ifneq ($(strip $(CPP_DEPS)),)
-include $(CPP_DEPS)
endif
ifneq ($(strip $(S??_DEPS)),)
-include $(S??_DEPS)
endif
ifneq ($(strip $(C_DEPS)),)
-include $(C_DEPS)
endif
ifneq ($(strip $(C62_DEPS)),)
-include $(C62_DEPS)
endif
ifneq ($(strip $(CXX_DEPS)),)
-include $(CXX_DEPS)
endif
ifneq ($(strip $(C++_DEPS)),)
-include $(C++_DEPS)
endif
ifneq ($(strip $(ASM_UPPER_DEPS)),)
-include $(ASM_UPPER_DEPS)
endif
ifneq ($(strip $(K_DEPS)),)
-include $(K_DEPS)
endif
ifneq ($(strip $(C43_DEPS)),)
-include $(C43_DEPS)
endif
ifneq ($(strip $(S67_DEPS)),)
-include $(S67_DEPS)
endif
ifneq ($(strip $(SA_DEPS)),)
-include $(SA_DEPS)
endif
ifneq ($(strip $(S43_DEPS)),)
-include $(S43_DEPS)
endif
ifneq ($(strip $(OPT_DEPS)),)
-include $(OPT_DEPS)
endif
ifneq ($(strip $(S64_DEPS)),)
-include $(S64_DEPS)
endif
ifneq ($(strip $(C_UPPER_DEPS)),)
-include $(C_UPPER_DEPS)
endif
ifneq ($(strip $(C55_DEPS)),)
-include $(C55_DEPS)
endif
endif
-include ../makefile.defs
# Add inputs and outputs from these tool invocations to the build variables
# All Target
all: motion_driver-5.1.2.out
# Tool invocations
motion_driver-5.1.2.out: $(OBJS) $(CMD_SRCS) $(GEN_CMDS)
	@echo 'Building target: $@'
	@echo 'Invoking: MSP430 Linker'
	"C:/ti/ccsv5/tools/compiler/msp430_4.1.1/bin/cl430" -vmspx --abi=coffabi --code_model=large --data_model=restricted --near_data=globals -O2 --opt_for_speed=0 --symdebug:none --gcc --define=__MSP430F5528__ --define=USE_DMP --define=CONFIG_INTERFACE_USB --define=MPU6050 --define=I2C_B0 --define=EMPL --define=MOTION_DRIVER_TARGET_MSP430 --diag_warning=225 --display_error_number --silicon_errata=CPU21 --silicon_errata=CPU22 --silicon_errata=CPU23 --silicon_errata=CPU40 --printf_support=minimal -z -m"motion_driver-5.1.2.map" --stack_size=512 --heap_size=0 --use_hw_mpy=F5 -i"C:/ti/ccsv5/ccs_base/msp430/include" -i"C:/ti/ccsv5/tools/compiler/msp430_4.1.1/lib" -i"C:/ti/ccsv5/tools/compiler/msp430_4.1.1/include" --reread_libs --warn_sections --mapfile_contents=all --rom_model -o "motion_driver-5.1.2.out" $(ORDERED_OBJS)
	@echo 'Finished building target: $@'
	@echo ' '
# Other Targets
clean:
	-$(RM) $(MSP430_EXECUTABLE_OUTPUTS__QUOTED) "motion_driver-5.1.2.out"
	-$(RM) "simple_apps\msp430\motion_driver_test.pp" "core\driver\msp430\msp430_clock.pp" "core\driver\msp430\msp430_i2c.pp" "core\driver\msp430\msp430_interrupt.pp" "core\driver\msp430\USB_eMPL\UsbIsr.pp" "core\driver\msp430\USB_eMPL\descriptors.pp" "core\driver\msp430\USB_eMPL\usbConstructs.pp" "core\driver\msp430\USB_eMPL\usbEventHandling.pp" "core\driver\msp430\USB_API\USB_PHDC_API\UsbPHDC.pp" "core\driver\msp430\USB_API\USB_MSC_API\UsbMscReq.pp" "core\driver\msp430\USB_API\USB_MSC_API\UsbMscScsi.pp" "core\driver\msp430\USB_API\USB_MSC_API\UsbMscStateMachine.pp" "core\driver\msp430\USB_API\USB_HID_API\UsbHid.pp" "core\driver\msp430\USB_API\USB_HID_API\UsbHidReq.pp" "core\driver\msp430\USB_API\USB_Common\dma.pp" "core\driver\msp430\USB_API\USB_Common\usb.pp" "core\driver\msp430\USB_API\USB_CDC_API\UsbCdc.pp" "core\driver\msp430\F5xx_F6xx_Core_Lib\HAL_FLASH.pp" "core\driver\msp430\F5xx_F6xx_Core_Lib\HAL_PMAP.pp" "core\driver\msp430\F5xx_F6xx_Core_Lib\HAL_PMM.pp" "core\driver\msp430\F5xx_F6xx_Core_Lib\HAL_TLV.pp"
	-$(RM) "core\driver\msp430\F5xx_F6xx_Core_Lib\HAL_UCS.pp" "core\driver\eMPL\inv_mpu.pp" "core\driver\eMPL\inv_mpu_dmp_motion_driver.pp"
	-$(RM) "simple_apps\msp430\motion_driver_test.obj" "core\driver\msp430\msp430_clock.obj" "core\driver\msp430\msp430_i2c.obj" "core\driver\msp430\msp430_interrupt.obj" "core\driver\msp430\USB_eMPL\UsbIsr.obj" "core\driver\msp430\USB_eMPL\descriptors.obj" "core\driver\msp430\USB_eMPL\usbConstructs.obj" "core\driver\msp430\USB_eMPL\usbEventHandling.obj" "core\driver\msp430\USB_API\USB_PHDC_API\UsbPHDC.obj" "core\driver\msp430\USB_API\USB_MSC_API\UsbMscReq.obj" "core\driver\msp430\USB_API\USB_MSC_API\UsbMscScsi.obj" "core\driver\msp430\USB_API\USB_MSC_API\UsbMscStateMachine.obj" "core\driver\msp430\USB_API\USB_HID_API\UsbHid.obj" "core\driver\msp430\USB_API\USB_HID_API\UsbHidReq.obj" "core\driver\msp430\USB_API\USB_Common\dma.obj" "core\driver\msp430\USB_API\USB_Common\usb.obj" "core\driver\msp430\USB_API\USB_CDC_API\UsbCdc.obj" "core\driver\msp430\F5xx_F6xx_Core_Lib\HAL_FLASH.obj" "core\driver\msp430\F5xx_F6xx_Core_Lib\HAL_PMAP.obj" "core\driver\msp430\F5xx_F6xx_Core_Lib\HAL_PMM.obj" "core\driver\msp430\F5xx_F6xx_Core_Lib\HAL_TLV.obj"
	-$(RM) "core\driver\msp430\F5xx_F6xx_Core_Lib\HAL_UCS.obj" "core\driver\eMPL\inv_mpu.obj" "core\driver\eMPL\inv_mpu_dmp_motion_driver.obj"
	-@echo 'Finished clean'
	-@echo ' '
.PHONY: all clean dependents
.SECONDARY:
-include ../makefile.targets
