<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.2">
<drawing>
<settings>
<setting alwaysvectorfont="yes"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.05" unitdist="inch" unit="inch" style="lines" multiple="1" display="yes" altdistance="0.025" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="56" name="wert" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="105" name="Beschreib" color="9" fill="1" visible="no" active="no"/>
<layer number="106" name="BGA-Top" color="4" fill="1" visible="no" active="no"/>
<layer number="107" name="BD-Top" color="5" fill="1" visible="no" active="no"/>
<layer number="151" name="HeatSink" color="14" fill="1" visible="no" active="no"/>
<layer number="200" name="200bmp" color="1" fill="10" visible="no" active="no"/>
<layer number="201" name="201bmp" color="2" fill="1" visible="no" active="no"/>
<layer number="250" name="Descript" color="3" fill="1" visible="no" active="no"/>
<layer number="251" name="SMDround" color="12" fill="11" visible="no" active="no"/>
<layer number="254" name="cooling" color="7" fill="1" visible="no" active="yes"/>
</layers>
<board>
<plain>
<text x="2.54" y="43.18" size="3.81" layer="1" ratio="15">SD2IEC</text>
<rectangle x1="47" y1="8.9" x2="69.3" y2="12.8" layer="1"/>
<hole x="11.43" y="22.15" drill="1.6"/>
<hole x="14.43" y="23.9" drill="1.6"/>
<hole x="14.43" y="20.4" drill="1.6"/>
<hole x="11.43" y="18.65" drill="1.6"/>
<hole x="8.43" y="20.4" drill="1.6"/>
<hole x="8.43" y="23.9" drill="1.6"/>
<hole x="39" y="10.9" drill="3.3"/>
<hole x="77.5" y="10.9" drill="3.3"/>
<rectangle x1="46" y1="2" x2="49" y2="8" layer="1"/>
<rectangle x1="50" y1="2" x2="53" y2="8" layer="1"/>
<text x="53.34" y="10.16" size="1.778" layer="1">Cut out</text>
<text x="53.34" y="10.16" size="1.778" layer="49">Cut out</text>
</plain>
<libraries>
<library name="rcl">
<packages>
<package name="C0805">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-0.381" y1="0.66" x2="0.381" y2="0.66" width="0.1016" layer="51"/>
<wire x1="-0.356" y1="-0.66" x2="0.381" y2="-0.66" width="0.1016" layer="51"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.0922" y1="-0.7239" x2="-0.3421" y2="0.7262" layer="51"/>
<rectangle x1="0.3556" y1="-0.7239" x2="1.1057" y2="0.7262" layer="51"/>
<rectangle x1="-0.1001" y1="-0.4001" x2="0.1001" y2="0.4001" layer="35"/>
</package>
</packages>
</library>
<library name="MS2">
<packages>
<package name="SDCMF-10915W010">
<wire x1="-12.7" y1="12.7" x2="15.1765" y2="12.7" width="0.127" layer="21"/>
<wire x1="-12.7" y1="12.7" x2="-12.7" y2="-17.018" width="0.127" layer="21"/>
<wire x1="-12.7" y1="-17.018" x2="15.367" y2="-17.018" width="0.127" layer="21"/>
<wire x1="15.367" y1="-17.018" x2="15.367" y2="12.6365" width="0.127" layer="21"/>
<wire x1="-10.795" y1="-19.05" x2="13.335" y2="-19.05" width="0.127" layer="21"/>
<wire x1="13.335" y1="-19.05" x2="13.97" y2="-18.415" width="0.127" layer="21"/>
<wire x1="13.97" y1="-18.415" x2="13.97" y2="-17.145" width="0.127" layer="21"/>
<wire x1="-10.795" y1="-19.05" x2="-11.43" y2="-18.415" width="0.127" layer="21"/>
<wire x1="-11.43" y1="-18.415" x2="-11.43" y2="-17.145" width="0.127" layer="21"/>
<smd name="15" x="16.3195" y="-13.97" dx="2.54" dy="1.27" layer="1" rot="R90"/>
<smd name="14" x="-13.843" y="-13.97" dx="2.1844" dy="1.0668" layer="1" rot="R90"/>
<smd name="13" x="-13.97" y="-13.97" dx="3.81" dy="1.9304" layer="1" rot="R90"/>
<smd name="12" x="16.383" y="-13.97" dx="3.81" dy="1.9304" layer="1" rot="R270"/>
<smd name="10" x="-11.938" y="13.462" dx="1.6764" dy="0.8128" layer="1" rot="R90"/>
<smd name="11" x="-10.668" y="13.462" dx="1.6764" dy="0.8128" layer="1" rot="R90"/>
<smd name="8" x="-9.398" y="13.462" dx="1.6764" dy="0.8128" layer="1" rot="R90"/>
<smd name="7" x="-7.5565" y="13.462" dx="1.6764" dy="0.8128" layer="1" rot="R90"/>
<smd name="6" x="-5.334" y="13.462" dx="1.9304" dy="0.9652" layer="1" rot="R90"/>
<smd name="5" x="-2.794" y="13.462" dx="1.9304" dy="0.9652" layer="1" rot="R90"/>
<smd name="4" x="-0.254" y="13.462" dx="1.9304" dy="0.9652" layer="1" rot="R90"/>
<smd name="3" x="2.286" y="13.462" dx="1.9304" dy="0.9652" layer="1" rot="R90"/>
<smd name="2" x="4.826" y="13.462" dx="1.9304" dy="0.9652" layer="1" rot="R90"/>
<smd name="1" x="7.366" y="13.462" dx="1.9304" dy="0.9652" layer="1" rot="R90"/>
<smd name="9" x="9.906" y="13.462" dx="1.9304" dy="0.9652" layer="1" rot="R90"/>
<text x="3.302" y="-17.399" size="1.27" layer="21" rot="R180">SDCard</text>
<hole x="9.906" y="10.414" drill="1.6"/>
<hole x="-11.176" y="10.414" drill="1.1"/>
</package>
</packages>
</library>
<library name="0_rr">
<packages>
<package name="C_TANTAL_A">
chip
tantalum</description>
<wire x1="1.651" y1="-0.559" x2="1.651" y2="0.559" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="-0.559" x2="-1.651" y2="0.559" width="0.1524" layer="51"/>
<wire x1="1.535" y1="-0.798" x2="1.535" y2="0.798" width="0.2032" layer="51"/>
<wire x1="1.535" y1="0.798" x2="-1.535" y2="0.798" width="0.2032" layer="21"/>
<wire x1="-1.535" y1="0.798" x2="-1.535" y2="-0.798" width="0.2032" layer="51"/>
<wire x1="-1.535" y1="-0.798" x2="1.535" y2="-0.798" width="0.2032" layer="21"/>
<wire x1="0.3825" y1="0" x2="0.9425" y2="0" width="0.2032" layer="51"/>
<wire x1="0.6525" y1="-0.26" x2="0.6525" y2="0.3" width="0.2032" layer="51"/>
<smd name="1" x="1.5587" y="0" dx="1.3" dy="1.8" layer="1"/>
<smd name="2" x="-1.5588" y="0" dx="1.3" dy="1.8" layer="1"/>
<text x="-1.524" y="1.143" size="0.6096" layer="25">&gt;NAME</text>
<text x="-1.524" y="-1.778" size="0.6096" layer="27">&gt;VALUE</text>
</package>
<package name="TQFP44">
<description>&lt;B&gt;Thin Plasic Quad Flat Package&lt;/B&gt;</description>
<wire x1="-4.8" y1="4.4" x2="-4.4" y2="4.8" width="0.2032" layer="21"/>
<wire x1="-4.4" y1="4.8" x2="4.4" y2="4.8" width="0.2032" layer="21"/>
<wire x1="4.4" y1="4.8" x2="4.8" y2="4.4" width="0.2032" layer="21"/>
<wire x1="4.8" y1="4.4" x2="4.8" y2="-4.4" width="0.2032" layer="21"/>
<wire x1="4.8" y1="-4.4" x2="4.4" y2="-4.8" width="0.2032" layer="21"/>
<wire x1="4.4" y1="-4.8" x2="-4.4" y2="-4.8" width="0.2032" layer="21"/>
<wire x1="-4.4" y1="-4.8" x2="-4.8" y2="-4.4" width="0.2032" layer="21"/>
<wire x1="-4.8" y1="-4.4" x2="-4.8" y2="4.4" width="0.2032" layer="21"/>
<circle x="-4" y="4" radius="0.2827" width="0.254" layer="21"/>
<smd name="1" x="-5.8" y="4" dx="1.5" dy="0.5" layer="1"/>
<smd name="2" x="-5.8" y="3.2" dx="1.5" dy="0.5" layer="1"/>
<smd name="3" x="-5.8" y="2.4" dx="1.5" dy="0.5" layer="1"/>
<smd name="4" x="-5.8" y="1.6" dx="1.5" dy="0.5" layer="1"/>
<smd name="5" x="-5.8" y="0.8" dx="1.5" dy="0.5" layer="1"/>
<smd name="6" x="-5.8" y="0" dx="1.5" dy="0.5" layer="1"/>
<smd name="7" x="-5.8" y="-0.8" dx="1.5" dy="0.5" layer="1"/>
<smd name="8" x="-5.8" y="-1.6" dx="1.5" dy="0.5" layer="1"/>
<smd name="9" x="-5.8" y="-2.4" dx="1.5" dy="0.5" layer="1"/>
<smd name="10" x="-5.8" y="-3.2" dx="1.5" dy="0.5" layer="1"/>
<smd name="11" x="-5.8" y="-4" dx="1.5" dy="0.5" layer="1"/>
<smd name="12" x="-4" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="13" x="-3.2" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="14" x="-2.4" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="15" x="-1.6" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="16" x="-0.8" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="17" x="0" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="18" x="0.8" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="19" x="1.6" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="20" x="2.4" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="21" x="3.2" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="22" x="4" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="23" x="5.8" y="-4" dx="1.5" dy="0.5" layer="1"/>
<smd name="24" x="5.8" y="-3.2" dx="1.5" dy="0.5" layer="1"/>
<smd name="25" x="5.8" y="-2.4" dx="1.5" dy="0.5" layer="1"/>
<smd name="26" x="5.8" y="-1.6" dx="1.5" dy="0.5" layer="1"/>
<smd name="27" x="5.8" y="-0.8" dx="1.5" dy="0.5" layer="1"/>
<smd name="28" x="5.8" y="0" dx="1.5" dy="0.5" layer="1"/>
<smd name="29" x="5.8" y="0.8" dx="1.5" dy="0.5" layer="1"/>
<smd name="30" x="5.8" y="1.6" dx="1.5" dy="0.5" layer="1"/>
<smd name="31" x="5.8" y="2.4" dx="1.5" dy="0.5" layer="1"/>
<smd name="32" x="5.8" y="3.2" dx="1.5" dy="0.5" layer="1"/>
<smd name="33" x="5.8" y="4" dx="1.5" dy="0.5" layer="1"/>
<smd name="34" x="4" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="35" x="3.2" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="36" x="2.4" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="37" x="1.6" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="38" x="0.8" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="39" x="0" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="40" x="-0.8" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="41" x="-1.6" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="42" x="-2.4" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="43" x="-3.2" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="44" x="-4" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<text x="-3.81" y="1.905" size="0.8128" layer="25">&gt;NAME</text>
<text x="-4.445" y="-3.6751" size="0.8128" layer="27">&gt;VALUE</text>
<rectangle x1="-6.1001" y1="3.8001" x2="-4.95" y2="4.1999" layer="51"/>
<rectangle x1="-6.1001" y1="3" x2="-4.95" y2="3.4" layer="51"/>
<rectangle x1="-6.1001" y1="2.1999" x2="-4.95" y2="2.5999" layer="51"/>
<rectangle x1="-6.1001" y1="1.4" x2="-4.95" y2="1.8001" layer="51"/>
<rectangle x1="-6.1001" y1="0.5999" x2="-4.95" y2="1" layer="51"/>
<rectangle x1="-6.1001" y1="-0.1999" x2="-4.95" y2="0.1999" layer="51"/>
<rectangle x1="-6.1001" y1="-1" x2="-4.95" y2="-0.5999" layer="51"/>
<rectangle x1="-6.1001" y1="-1.8001" x2="-4.95" y2="-1.4" layer="51"/>
<rectangle x1="-6.1001" y1="-2.5999" x2="-4.95" y2="-2.1999" layer="51"/>
<rectangle x1="-6.1001" y1="-3.4" x2="-4.95" y2="-3" layer="51"/>
<rectangle x1="-6.1001" y1="-4.1999" x2="-4.95" y2="-3.8001" layer="51"/>
<rectangle x1="-4.1999" y1="-6.1001" x2="-3.8001" y2="-4.95" layer="51"/>
<rectangle x1="-3.4" y1="-6.1001" x2="-3" y2="-4.95" layer="51"/>
<rectangle x1="-2.5999" y1="-6.1001" x2="-2.1999" y2="-4.95" layer="51"/>
<rectangle x1="-1.8001" y1="-6.1001" x2="-1.4" y2="-4.95" layer="51"/>
<rectangle x1="-1" y1="-6.1001" x2="-0.5999" y2="-4.95" layer="51"/>
<rectangle x1="-0.1999" y1="-6.1001" x2="0.1999" y2="-4.95" layer="51"/>
<rectangle x1="0.5999" y1="-6.1001" x2="1" y2="-4.95" layer="51"/>
<rectangle x1="1.4" y1="-6.1001" x2="1.8001" y2="-4.95" layer="51"/>
<rectangle x1="2.1999" y1="-6.1001" x2="2.5999" y2="-4.95" layer="51"/>
<rectangle x1="3" y1="-6.1001" x2="3.4" y2="-4.95" layer="51"/>
<rectangle x1="3.8001" y1="-6.1001" x2="4.1999" y2="-4.95" layer="51"/>
<rectangle x1="4.95" y1="-4.1999" x2="6.1001" y2="-3.8001" layer="51"/>
<rectangle x1="4.95" y1="-3.4" x2="6.1001" y2="-3" layer="51"/>
<rectangle x1="4.95" y1="-2.5999" x2="6.1001" y2="-2.1999" layer="51"/>
<rectangle x1="4.95" y1="-1.8001" x2="6.1001" y2="-1.4" layer="51"/>
<rectangle x1="4.95" y1="-1" x2="6.1001" y2="-0.5999" layer="51"/>
<rectangle x1="4.95" y1="-0.1999" x2="6.1001" y2="0.1999" layer="51"/>
<rectangle x1="4.95" y1="0.5999" x2="6.1001" y2="1" layer="51"/>
<rectangle x1="4.95" y1="1.4" x2="6.1001" y2="1.8001" layer="51"/>
<rectangle x1="4.95" y1="2.1999" x2="6.1001" y2="2.5999" layer="51"/>
<rectangle x1="4.95" y1="3" x2="6.1001" y2="3.4" layer="51"/>
<rectangle x1="4.95" y1="3.8001" x2="6.1001" y2="4.1999" layer="51"/>
<rectangle x1="3.8001" y1="4.95" x2="4.1999" y2="6.1001" layer="51"/>
<rectangle x1="3" y1="4.95" x2="3.4" y2="6.1001" layer="51"/>
<rectangle x1="2.1999" y1="4.95" x2="2.5999" y2="6.1001" layer="51"/>
<rectangle x1="1.4" y1="4.95" x2="1.8001" y2="6.1001" layer="51"/>
<rectangle x1="0.5999" y1="4.95" x2="1" y2="6.1001" layer="51"/>
<rectangle x1="-0.1999" y1="4.95" x2="0.1999" y2="6.1001" layer="51"/>
<rectangle x1="-1" y1="4.95" x2="-0.5999" y2="6.1001" layer="51"/>
<rectangle x1="-1.8001" y1="4.95" x2="-1.4" y2="6.1001" layer="51"/>
<rectangle x1="-2.5999" y1="4.95" x2="-2.1999" y2="6.1001" layer="51"/>
<rectangle x1="-3.4" y1="4.95" x2="-3" y2="6.1001" layer="51"/>
<rectangle x1="-4.1999" y1="4.95" x2="-3.8001" y2="6.1001" layer="51"/>
</package>
<package name="LED0805">
<wire x1="-0.1587" y1="0.3175" x2="-0.1587" y2="0" width="0.0762" layer="21"/>
<wire x1="-0.1587" y1="0" x2="-0.1587" y2="-0.3175" width="0.0762" layer="21"/>
<wire x1="-0.1587" y1="0" x2="0.1588" y2="0.3175" width="0.0762" layer="21"/>
<wire x1="0.1588" y1="0.3175" x2="0.1588" y2="-0.3175" width="0.0762" layer="21"/>
<wire x1="0.1588" y1="-0.3175" x2="-0.1587" y2="0" width="0.0762" layer="21"/>
<wire x1="-0.635" y1="0" x2="0.635" y2="0" width="0.0762" layer="21"/>
<wire x1="-0.41" y1="0.635" x2="0.41" y2="0.635" width="0.1524" layer="51"/>
<wire x1="-0.41" y1="-0.635" x2="0.41" y2="-0.635" width="0.1524" layer="51"/>
<smd name="1" x="-1.0087" y="0" dx="0.8" dy="1.4" layer="1"/>
<smd name="2" x="1.0087" y="0" dx="0.8" dy="1.4" layer="1"/>
<text x="-1.0795" y="0.8572" size="0.4064" layer="25">&gt;NAME</text>
<text x="-1.0795" y="-1.1747" size="0.4064" layer="27">&gt;VALUE</text>
<rectangle x1="0.4064" y1="-0.6985" x2="1.0564" y2="0.7015" layer="51"/>
<rectangle x1="-1.0668" y1="-0.6985" x2="-0.4168" y2="0.7015" layer="51"/>
</package>
<package name="SOD-123">
<wire x1="-1.905" y1="-0.9525" x2="1.905" y2="-0.9525" width="0.127" layer="21"/>
<wire x1="1.905" y1="-0.9525" x2="1.905" y2="0.9525" width="0.127" layer="21"/>
<wire x1="1.905" y1="0.9525" x2="-1.905" y2="0.9525" width="0.127" layer="21"/>
<wire x1="-1.905" y1="0.9525" x2="-1.905" y2="-0.9525" width="0.127" layer="21"/>
<wire x1="-0.9525" y1="0" x2="-0.3175" y2="0" width="0.127" layer="21"/>
<wire x1="-0.3175" y1="0" x2="0.9525" y2="0" width="0.127" layer="21"/>
<wire x1="-0.3175" y1="0.635" x2="-0.3175" y2="0" width="0.127" layer="21"/>
<wire x1="-0.3175" y1="0" x2="-0.3175" y2="-0.635" width="0.127" layer="21"/>
<wire x1="-0.3175" y1="0" x2="0.3175" y2="0.635" width="0.127" layer="21"/>
<wire x1="0.3175" y1="0.635" x2="0.3175" y2="-0.635" width="0.127" layer="21"/>
<wire x1="0.3175" y1="-0.635" x2="-0.3175" y2="0" width="0.127" layer="21"/>
<smd name="1" x="-1.884" y="0" dx="0.9144" dy="1.397" layer="1" roundness="15"/>
<smd name="2" x="1.884" y="0" dx="0.9144" dy="1.397" layer="1" roundness="15"/>
<text x="-1.27" y="1.27" size="0.6096" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.2225" size="0.6096" layer="27">&gt;VALUE</text>
<rectangle x1="-1.5875" y1="-0.9525" x2="-1.27" y2="0.9525" layer="21"/>
</package>
<package name="R0805">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
chip</description>
</package>
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 0805 Reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 2012</description>
<wire x1="-0.925" y1="0.6" x2="0.925" y2="0.6" width="0.1016" layer="51"/>
<wire x1="0.925" y1="-0.6" x2="-0.925" y2="-0.6" width="0.1016" layer="51"/>
<smd name="1" x="-1" y="0" dx="0.8" dy="1.4" layer="1"/>
<smd name="2" x="1" y="0" dx="0.8" dy="1.4" layer="1"/>
<text x="-1" y="0.875" size="0.6096" layer="25">&gt;NAME</text>
<text x="-1.3175" y="-1.5825" size="0.6096" layer="27">&gt;VALUE</text>
<rectangle x1="-1" y1="-0.65" x2="-0.5" y2="0.65" layer="51"/>
<rectangle x1="0.5" y1="-0.65" x2="1" y2="0.65" layer="51"/>
</package>
<package name="C1206">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1206 Reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 3216</description>
<wire x1="-1.525" y1="0.75" x2="1.525" y2="0.75" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-0.75" x2="-1.525" y2="-0.75" width="0.1016" layer="51"/>
<smd name="2" x="1.4619" y="0" dx="1.016" dy="1.651" layer="1"/>
<smd name="1" x="-1.4619" y="0" dx="1.016" dy="1.651" layer="1" rot="R180"/>
<text x="-1.6" y="0.973" size="0.4064" layer="25">&gt;NAME</text>
<text x="-1.6" y="-1.4015" size="0.4064" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-0.8" x2="-1.1" y2="0.8" layer="51"/>
<rectangle x1="1.1" y1="-0.8" x2="1.6" y2="0.8" layer="51"/>
</package>
<package name="SOT23_C">
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.1524" layer="51"/>
<smd name="3" x="0" y="1.1113" dx="0.7" dy="0.9" layer="1" roundness="25" rot="R180"/>
<smd name="1" x="-0.9525" y="-1.1113" dx="0.7" dy="0.9" layer="1" roundness="25" rot="R180"/>
<smd name="2" x="0.9525" y="-1.1112" dx="0.7" dy="0.9" layer="1" roundness="25" rot="R180"/>
<text x="-1.27" y="0.1588" size="0.4064" layer="25">&gt;NAME</text>
<text x="-1.27" y="-0.4763" size="0.4064" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2286" y1="0.7112" x2="0.2286" y2="1.2954" layer="51"/>
<rectangle x1="0.7112" y1="-1.2954" x2="1.1684" y2="-0.7112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.2954" x2="-0.7112" y2="-0.7112" layer="51"/>
</package>
</packages>
</library>
<library name="testpad">
<packages>
<package name="P1-17">
<description>&lt;b&gt;TEST PAD&lt;/b&gt;</description>
<circle x="0" y="0" radius="0.8128" width="0.1524" layer="51"/>
<pad name="TP" x="0" y="0" drill="1.7018" diameter="2.54" shape="octagon"/>
<text x="-1.143" y="1.397" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="0" y="0" size="0.0254" layer="27">&gt;VALUE</text>
<text x="-1.27" y="-3.175" size="1" layer="37">&gt;TP_SIGNAL_NAME</text>
<rectangle x1="-0.3302" y1="-0.3302" x2="0.3302" y2="0.3302" layer="51"/>
</package>
<package name="TP08SQ">
<smd name="TP" x="0" y="0" dx="0.8" dy="0.8" layer="1" cream="no"/>
<text x="-0.3" y="0.4001" size="1.27" layer="25">&gt;NAME</text>
<text x="-0.381" y="-0.508" size="0.0254" layer="27">&gt;VALUE</text>
<text x="0" y="-1.905" size="1" layer="37">&gt;TP_SIGNAL_NAME</text>
</package>
<package name="B2,54">
<wire x1="-0.635" y1="0" x2="0.635" y2="0" width="0.0024" layer="37"/>
<wire x1="0" y1="-0.635" x2="0" y2="0.635" width="0.0024" layer="37"/>
<circle x="0" y="0" radius="0.635" width="0.254" layer="37"/>
<smd name="TP" x="0" y="0" dx="2.54" dy="2.54" layer="1" roundness="100" cream="no"/>
<text x="-1.27" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-1.397" size="0.0254" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="crystal">
<packages>
<package name="HC49UP">
<description>&lt;b&gt;CRYSTAL&lt;/b&gt;</description>
<wire x1="-5.1091" y1="1.143" x2="-3.429" y2="2.0321" width="0.0508" layer="21" curve="-55.770993" cap="flat"/>
<wire x1="-5.715" y1="1.143" x2="-5.715" y2="2.159" width="0.1524" layer="21"/>
<wire x1="3.429" y1="2.032" x2="5.1091" y2="1.143" width="0.0508" layer="21" curve="-55.772485" cap="flat"/>
<wire x1="5.715" y1="1.143" x2="5.715" y2="2.159" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-1.27" x2="-3.429" y2="-1.27" width="0.0508" layer="21"/>
<wire x1="3.429" y1="-2.032" x2="-3.429" y2="-2.032" width="0.0508" layer="21"/>
<wire x1="-3.429" y1="1.27" x2="3.429" y2="1.27" width="0.0508" layer="21"/>
<wire x1="5.461" y1="-2.413" x2="-5.461" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-0.381" x2="6.477" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="5.715" y1="0.381" x2="6.477" y2="0.381" width="0.1524" layer="51"/>
<wire x1="6.477" y1="-0.381" x2="6.477" y2="0.381" width="0.1524" layer="51"/>
<wire x1="5.461" y1="-2.413" x2="5.715" y2="-2.159" width="0.1524" layer="21" curve="90"/>
<wire x1="5.715" y1="-1.143" x2="5.715" y2="1.143" width="0.1524" layer="51"/>
<wire x1="5.715" y1="-2.159" x2="5.715" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="3.429" y1="-1.27" x2="3.9826" y2="-1.143" width="0.0508" layer="21" curve="25.842828" cap="flat"/>
<wire x1="3.429" y1="1.27" x2="3.9826" y2="1.143" width="0.0508" layer="21" curve="-25.842828" cap="flat"/>
<wire x1="3.429" y1="-2.032" x2="5.109" y2="-1.1429" width="0.0508" layer="21" curve="55.771157" cap="flat"/>
<wire x1="3.9826" y1="-1.143" x2="3.9826" y2="1.143" width="0.0508" layer="51" curve="128.314524" cap="flat"/>
<wire x1="5.1091" y1="-1.143" x2="5.1091" y2="1.143" width="0.0508" layer="51" curve="68.456213" cap="flat"/>
<wire x1="-5.1091" y1="-1.143" x2="-3.429" y2="-2.032" width="0.0508" layer="21" curve="55.772485" cap="flat"/>
<wire x1="-3.9826" y1="-1.143" x2="-3.9826" y2="1.143" width="0.0508" layer="51" curve="-128.314524" cap="flat"/>
<wire x1="-3.9826" y1="-1.143" x2="-3.429" y2="-1.27" width="0.0508" layer="21" curve="25.842828" cap="flat"/>
<wire x1="-3.9826" y1="1.143" x2="-3.429" y2="1.27" width="0.0508" layer="21" curve="-25.842828" cap="flat"/>
<wire x1="-6.477" y1="-0.381" x2="-6.477" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-5.1091" y1="-1.143" x2="-5.1091" y2="1.143" width="0.0508" layer="51" curve="-68.456213" cap="flat"/>
<wire x1="-5.715" y1="-1.143" x2="-5.715" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="-0.381" x2="-5.715" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="0.381" x2="-5.715" y2="1.143" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="-2.159" x2="-5.715" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-2.159" x2="-5.461" y2="-2.413" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.715" y1="-0.381" x2="-6.477" y2="-0.381" width="0.1524" layer="51"/>
<wire x1="-5.715" y1="0.381" x2="-6.477" y2="0.381" width="0.1524" layer="51"/>
<wire x1="-3.429" y1="2.032" x2="3.429" y2="2.032" width="0.0508" layer="21"/>
<wire x1="5.461" y1="2.413" x2="-5.461" y2="2.413" width="0.1524" layer="21"/>
<wire x1="5.461" y1="2.413" x2="5.715" y2="2.159" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.715" y1="2.159" x2="-5.461" y2="2.413" width="0.1524" layer="21" curve="-90"/>
<wire x1="-0.254" y1="0.635" x2="-0.254" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-0.635" x2="0.254" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.254" y1="-0.635" x2="0.254" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0.635" x2="-0.254" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0.635" x2="-0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-0.635" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="0" x2="-1.016" y2="0" width="0.0508" layer="21"/>
<wire x1="0.635" y1="0.635" x2="0.635" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="0.635" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.016" y2="0" width="0.0508" layer="21"/>
<smd name="1" x="-4.826" y="0" dx="5.334" dy="1.9304" layer="1"/>
<smd name="2" x="4.826" y="0" dx="5.334" dy="1.9304" layer="1"/>
<text x="-5.715" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.715" y="-4.191" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-6.604" y1="-3.048" x2="6.604" y2="3.048" layer="43"/>
</package>
</packages>
</library>
<library name="v-reg-2">
<description>&lt;b&gt;Voltage Regulators&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="TO263">
<description>&lt;b&gt;TO-263 Package&lt;/b&gt;</description>
<wire x1="-5.5" y1="-4.365" x2="-5.5" y2="4.635" width="0.254" layer="21"/>
<wire x1="5.5" y1="-4.365" x2="5.5" y2="4.635" width="0.254" layer="21"/>
<wire x1="5.5" y1="-4.365" x2="-5.5" y2="-4.365" width="0.254" layer="21"/>
<wire x1="-5.5" y1="4.635" x2="5.5" y2="4.635" width="0.254" layer="51"/>
<wire x1="-5.5" y1="4.635" x2="-4.4" y2="5.735" width="0.254" layer="51"/>
<wire x1="-4.4" y1="5.735" x2="4.4" y2="5.735" width="0.254" layer="51"/>
<wire x1="4.4" y1="5.735" x2="5.5" y2="4.635" width="0.254" layer="51"/>
<wire x1="-5.5" y1="3.935" x2="5.5" y2="3.935" width="0.127" layer="51"/>
<wire x1="-5.5" y1="-3.965" x2="5.5" y2="-3.965" width="0.127" layer="51"/>
<circle x="-3" y="-2.965" radius="0.4123" width="0" layer="51"/>
<smd name="4" x="0" y="2.635" dx="10.8" dy="9" layer="1" rot="R180"/>
<smd name="1" x="-2.54" y="-8.255" dx="3.81" dy="1.524" layer="1" rot="R90"/>
<smd name="2" x="0" y="-8.255" dx="3.81" dy="1.524" layer="1" rot="R90"/>
<smd name="3" x="2.54" y="-8.255" dx="3.81" dy="1.524" layer="1" rot="R90"/>
<text x="-6.0325" y="-4.445" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="7.3025" y="-4.445" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-3.2" y="-2.165" size="1.016" layer="51" ratio="10">1</text>
<text x="2.3" y="-2.165" size="1.016" layer="51" ratio="10">3</text>
<text x="-0.4" y="-2.165" size="1.016" layer="51" ratio="10">2</text>
<text x="-0.55" y="2.385" size="1.016" layer="51" ratio="10">4</text>
<rectangle x1="-3.04" y1="-5.865" x2="-2" y2="-4.37" layer="21"/>
<rectangle x1="-0.5" y1="-5.865" x2="0.5" y2="-4.37" layer="21"/>
<rectangle x1="2.04" y1="-5.865" x2="3" y2="-4.37" layer="21"/>
<rectangle x1="-3.04" y1="-8.64" x2="-2" y2="-5.865" layer="51"/>
<rectangle x1="-0.5" y1="-8.64" x2="0.5" y2="-5.865" layer="51"/>
<rectangle x1="2.04" y1="-8.64" x2="3" y2="-5.865" layer="51"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules>
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
</autorouter>
<elements>
<element name="U$4" library="MS2" package="SDCMF-10915W010" value="SDCARDVAR2" x="44.45" y="33.02" rot="R180"/>
<element name="C-REG3.3" library="rcl" package="C0805" value="10 uF" x="83.82" y="6.35" rot="R180"/>
<element name="C-REG5" library="rcl" package="C0805" value="100 nF" x="67.31" y="3.81" rot="R270"/>
<element name="R30" library="0_rr" package="R0805" value="330" x="82.55" y="44.45" rot="R90"/>
<element name="R31" library="0_rr" package="R0805" value="330" x="85.09" y="44.45" rot="R270"/>
<element name="IC3" library="0_rr" package="TQFP44" value="MEGA644P" x="69.85" y="38.1" rot="R90"/>
<element name="C1" library="0_rr" package="C0805" value="100n" x="69.85" y="46.99"/>
<element name="LED2" library="0_rr" package="LED0805" value="green" x="86.36" y="48.26" rot="R180"/>
<element name="LED3" library="0_rr" package="LED0805" value="red" x="81.28" y="48.26"/>
<element name="R4" library="0_rr" package="R0805" value="10k" x="15.24" y="27.94" rot="R90"/>
<element name="R5" library="0_rr" package="R0805" value="10k" x="10.16" y="27.94" rot="R90"/>
<element name="R6" library="0_rr" package="R0805" value="10k" x="12.7" y="27.94" rot="R90"/>
<element name="C4" library="0_rr" package="C1206" value="56p" x="81.28" y="29.21"/>
<element name="C5" library="0_rr" package="C1206" value="56p" x="81.28" y="31.75"/>
<element name="T4" library="0_rr" package="SOT23_C" value="IRLML2402" x="7.62" y="13.97" rot="R90"/>
<element name="T3" library="0_rr" package="SOT23_C" value="IRLML2402" x="7.62" y="3.81" rot="R90"/>
<element name="T2" library="0_rr" package="SOT23_C" value="IRLML2402" x="7.62" y="8.89" rot="R90"/>
<element name="R9" library="0_rr" package="R0805" value="18" x="21.59" y="8.89" rot="R270"/>
<element name="R10" library="0_rr" package="R0805" value="18" x="21.59" y="3.81" rot="R270"/>
<element name="R11" library="0_rr" package="R0805" value="18" x="21.59" y="13.97" rot="R270"/>
<element name="R12" library="0_rr" package="R0805" value="22k" x="15.24" y="31.75" rot="R90"/>
<element name="R13" library="0_rr" package="R0805" value="22k" x="10.16" y="31.75" rot="R90"/>
<element name="R14" library="0_rr" package="R0805" value="22k" x="12.7" y="31.75" rot="R90"/>
<element name="R16" library="0_rr" package="R0805" value="10k" x="17.78" y="27.94" rot="R270"/>
<element name="R18" library="0_rr" package="R0805" value="10k" x="11.43" y="8.89" rot="R90"/>
<element name="R19" library="0_rr" package="R0805" value="10k" x="11.43" y="3.81" rot="R90"/>
<element name="R21" library="0_rr" package="R0805" value="10k" x="11.43" y="13.97" rot="R90"/>
<element name="D2" library="0_rr" package="SOD-123" value="4148" x="60.96" y="5.08" rot="R180"/>
<element name="C2" library="0_rr" package="C_TANTAL_A" value="10µ" x="44.45" y="15.24"/>
<element name="TP4" library="testpad" package="P1-17" value="PTR1PAD1-17" x="8.43" y="20.4" locked="yes">
<attribute name="TP_SIGNAL_NAME" value="" x="8.43" y="20.4" size="1.778" layer="27" display="off"/>
</element>
<element name="TP5" library="testpad" package="P1-17" value="PTR1PAD1-17" x="8.43" y="23.9" locked="yes">
<attribute name="TP_SIGNAL_NAME" value="" x="8.43" y="23.9" size="1.778" layer="27" display="off"/>
</element>
<element name="TP3" library="testpad" package="P1-17" value="PTR1PAD1-17" x="11.43" y="18.65" locked="yes">
<attribute name="TP_SIGNAL_NAME" value="" x="11.43" y="18.65" size="1.778" layer="27" display="off"/>
</element>
<element name="TP7" library="testpad" package="TP08SQ" value="PTR1TP08SQ" x="51.2" y="6.69" locked="yes">
<attribute name="TP_SIGNAL_NAME" value="" x="51.2" y="6.69" size="1.778" layer="27" display="off"/>
</element>
<element name="TP8" library="testpad" package="TP08SQ" value="PTR1TP08SQ" x="46.96" y="6.69" locked="yes">
<attribute name="TP_SIGNAL_NAME" value="" x="46.96" y="6.69" size="1.778" layer="27" display="off"/>
</element>
<element name="Q1" library="crystal" package="HC49UP" value="8" x="73.74" y="22.17" rot="R270"/>
<element name="SCK" library="testpad" package="B2,54" value="PTR1B2,54" x="66.04" y="21.59">
<attribute name="TP_SIGNAL_NAME" value="" x="66.04" y="21.59" size="1.778" layer="27" display="off"/>
</element>
<element name="MISO" library="testpad" package="B2,54" value="PTR1B2,54" x="62.23" y="20.32">
<attribute name="TP_SIGNAL_NAME" value="" x="62.23" y="20.32" size="1.778" layer="27" display="off"/>
</element>
<element name="MOSI" library="testpad" package="B2,54" value="PTR1B2,54" x="62.23" y="29.21">
<attribute name="TP_SIGNAL_NAME" value="" x="62.23" y="29.21" size="1.778" layer="27" display="off"/>
</element>
<element name="RESET" library="testpad" package="B2,54" value="PTR1B2,54" x="67.31" y="17.78">
<attribute name="TP_SIGNAL_NAME" value="" x="67.31" y="17.78" size="1.778" layer="27" display="off"/>
</element>
<element name="R1" library="0_rr" package="R0805" value="10k" x="64.77" y="16.51" rot="R270"/>
<element name="U$6" library="v-reg-2" package="TO263" value="LM1086TO263" x="85.09" y="19.05"/>
</elements>
<signals>
<signal name="GND">
<contactref element="C-REG3.3" pad="2"/>
<contactref element="C-REG5" pad="2"/>
<contactref element="U$4" pad="12"/>
<contactref element="U$4" pad="6"/>
<contactref element="U$4" pad="3"/>
<contactref element="U$4" pad="15"/>
<contactref element="U$4" pad="14"/>
<contactref element="U$4" pad="13"/>
<contactref element="C2" pad="2"/>
<contactref element="U$4" pad="8"/>
<contactref element="U$4" pad="9"/>
<contactref element="IC3" pad="39"/>
<contactref element="IC3" pad="6"/>
<contactref element="IC3" pad="18"/>
<contactref element="IC3" pad="28"/>
<contactref element="C1" pad="1"/>
<contactref element="LED2" pad="1"/>
<contactref element="LED3" pad="1"/>
<contactref element="TP8" pad="TP"/>
<contactref element="C4" pad="2"/>
<contactref element="C5" pad="2"/>
<contactref element="R13" pad="2"/>
<contactref element="R10" pad="2"/>
<contactref element="R14" pad="2"/>
<contactref element="R9" pad="2"/>
<contactref element="R12" pad="2"/>
<contactref element="R11" pad="2"/>
<wire x1="46.99" y1="1.27" x2="67.31" y2="1.27" width="0.4064" layer="1"/>
<wire x1="46.96" y1="6.69" x2="46.99" y2="6.69" width="0.4064" layer="1"/>
<wire x1="46.99" y1="6.69" x2="46.99" y2="6.35" width="0.4064" layer="1"/>
<wire x1="46.99" y1="6.35" x2="46.99" y2="1.27" width="1.778" layer="1"/>
<wire x1="67.31" y1="2.86" x2="67.31" y2="1.27" width="0.4064" layer="1"/>
<wire x1="82.7419" y1="29.21" x2="82.7419" y2="31.75" width="0.4064" layer="1"/>
<wire x1="75.65" y1="38.9" x2="87.63" y2="38.9" width="0.4064" layer="1"/>
<wire x1="42.164" y1="19.558" x2="42.164" y2="23.114" width="0.4064" layer="1"/>
<wire x1="42.164" y1="23.114" x2="43.18" y2="24.13" width="0.4064" layer="1"/>
<wire x1="43.18" y1="24.13" x2="49.784" y2="24.13" width="0.4064" layer="1"/>
<wire x1="49.784" y1="24.13" x2="53.34" y2="24.13" width="0.4064" layer="1"/>
<wire x1="53.848" y1="19.558" x2="53.848" y2="23.622" width="0.4064" layer="1"/>
<wire x1="53.848" y1="23.622" x2="53.34" y2="24.13" width="0.4064" layer="1"/>
<wire x1="49.784" y1="19.558" x2="49.784" y2="24.13" width="0.4064" layer="1"/>
<wire x1="15.24" y1="32.7587" x2="12.7" y2="32.7587" width="0.4064" layer="1"/>
<wire x1="12.7" y1="32.7587" x2="10.16" y2="32.7587" width="0.4064" layer="1"/>
<wire x1="39.37" y1="35.56" x2="24.13" y2="20.32" width="0.4064" layer="1"/>
<wire x1="21.59" y1="12.9613" x2="23.8687" y2="12.9613" width="0.4064" layer="1"/>
<wire x1="23.8687" y1="12.9613" x2="24.13" y2="12.7" width="0.4064" layer="1"/>
<wire x1="24.13" y1="12.7" x2="24.13" y2="7.62" width="0.4064" layer="1"/>
<wire x1="24.13" y1="7.62" x2="24.13" y2="2.54" width="0.4064" layer="1"/>
<wire x1="24.13" y1="2.54" x2="24.13" y2="0" width="0.4064" layer="1"/>
<wire x1="21.59" y1="7.8813" x2="23.8687" y2="7.8813" width="0.4064" layer="1"/>
<wire x1="23.8687" y1="7.8813" x2="24.13" y2="7.62" width="0.4064" layer="1"/>
<wire x1="21.59" y1="2.8013" x2="23.8687" y2="2.8013" width="0.4064" layer="1"/>
<wire x1="23.8687" y1="2.8013" x2="24.13" y2="2.54" width="0.4064" layer="1" curve="-90"/>
<polygon width="0.254" layer="1" isolate="0.6096">
<vertex x="0" y="0"/>
<vertex x="0" y="49"/>
<vertex x="89.84" y="49"/>
<vertex x="89.84" y="0"/>
</polygon>
<contactref element="U$6" pad="1"/>
<wire x1="64.05" y1="38.1" x2="62.23" y2="38.1" width="0.4064" layer="1"/>
<wire x1="62.23" y1="38.1" x2="59.69" y2="35.56" width="0.4064" layer="1"/>
<wire x1="59.69" y1="35.56" x2="39.37" y2="35.56" width="0.4064" layer="1"/>
<wire x1="82.87" y1="6.35" x2="82.87" y2="10.475" width="0.4064" layer="1"/>
<wire x1="82.87" y1="10.475" x2="82.55" y2="10.795" width="0.4064" layer="1"/>
<wire x1="42.8912" y1="15.24" x2="43.18" y2="15.24" width="0.4064" layer="1"/>
<wire x1="46.96" y1="6.69" x2="46.96" y2="6.35" width="0.4064" layer="1"/>
<wire x1="46.96" y1="6.35" x2="46.99" y2="6.35" width="0.4064" layer="1"/>
<wire x1="43.18" y1="15.24" x2="43.18" y2="1.27" width="0.4064" layer="1"/>
<wire x1="43.18" y1="1.27" x2="46.99" y2="1.27" width="0.4064" layer="1"/>
<wire x1="69.85" y1="32.3" x2="69.85" y2="22.86" width="0.4064" layer="1"/>
<wire x1="69.85" y1="22.86" x2="71.12" y2="21.59" width="0.4064" layer="1"/>
<wire x1="71.12" y1="21.59" x2="71.12" y2="15.24" width="0.4064" layer="1"/>
<wire x1="71.12" y1="15.24" x2="72.39" y2="13.97" width="0.4064" layer="1"/>
<wire x1="72.39" y1="13.97" x2="74.93" y2="13.97" width="0.4064" layer="1"/>
<wire x1="74.93" y1="13.97" x2="76.2" y2="15.24" width="0.4064" layer="1"/>
<wire x1="69.85" y1="43.9" x2="69.85" y2="45.085" width="0.4064" layer="1"/>
<wire x1="69.85" y1="45.085" x2="68.85" y2="46.085" width="0.4064" layer="1"/>
<wire x1="68.85" y1="46.085" x2="68.85" y2="46.99" width="0.4064" layer="1"/>
<wire x1="42.164" y1="19.558" x2="42.164" y2="15.24" width="0.4064" layer="1"/>
<wire x1="42.164" y1="15.24" x2="42.8912" y2="15.24" width="0.4064" layer="1"/>
</signal>
<signal name="+5V">
<contactref element="TP7" pad="TP"/>
<contactref element="D2" pad="2"/>
<wire x1="51.2" y1="6.69" x2="51.2" y2="5.08" width="0.4064" layer="1"/>
<wire x1="51.2" y1="5.08" x2="59.076" y2="5.08" width="0.8128" layer="1"/>
</signal>
<signal name="+3.3V">
<contactref element="U$4" pad="4"/>
<contactref element="C2" pad="1"/>
<contactref element="C-REG3.3" pad="1"/>
<contactref element="IC3" pad="5"/>
<contactref element="IC3" pad="17"/>
<contactref element="IC3" pad="38"/>
<contactref element="IC3" pad="27"/>
<contactref element="C1" pad="2"/>
<wire x1="70.65" y1="43.9" x2="70.65" y2="38.9" width="0.4064" layer="1"/>
<wire x1="70.65" y1="38.9" x2="70.65" y2="38.1" width="0.4064" layer="1"/>
<wire x1="70.65" y1="38.1" x2="75.65" y2="38.1" width="0.4064" layer="1"/>
<wire x1="64.05" y1="38.9" x2="70.65" y2="38.9" width="0.4064" layer="1"/>
<wire x1="69.05" y1="32.3" x2="69.05" y2="38.1" width="0.4064" layer="1"/>
<wire x1="69.05" y1="38.1" x2="70.65" y2="38.1" width="0.4064" layer="1"/>
<contactref element="R1" pad="2"/>
<wire x1="44.704" y1="19.558" x2="44.704" y2="17.526" width="0.4064" layer="1"/>
<wire x1="44.704" y1="17.526" x2="45.72" y2="16.51" width="0.4064" layer="1"/>
<wire x1="45.72" y1="16.51" x2="45.72" y2="15.5287" width="0.4064" layer="1"/>
<wire x1="45.72" y1="15.5287" x2="46.0087" y2="15.24" width="0.4064" layer="1"/>
<wire x1="46.0087" y1="15.24" x2="48.26" y2="15.24" width="0.4064" layer="1"/>
<wire x1="48.26" y1="15.24" x2="49.53" y2="13.97" width="0.4064" layer="1"/>
<wire x1="49.53" y1="13.97" x2="62.23" y2="13.97" width="0.4064" layer="1"/>
<wire x1="69.05" y1="32.3" x2="69.05" y2="19.85" width="0.4064" layer="1"/>
<wire x1="69.05" y1="19.85" x2="69.85" y2="19.05" width="0.4064" layer="1"/>
<wire x1="69.85" y1="19.05" x2="69.85" y2="15.24" width="0.4064" layer="1"/>
<polygon width="0.254" layer="1">
<vertex x="66.04" y="41.91"/>
<vertex x="66.04" y="34.29"/>
<vertex x="73.66" y="34.29"/>
<vertex x="73.66" y="41.91"/>
</polygon>
<contactref element="U$6" pad="2"/>
<wire x1="84.77" y1="6.35" x2="84.77" y2="10.475" width="0.4064" layer="1"/>
<wire x1="84.77" y1="10.475" x2="85.09" y2="10.795" width="0.4064" layer="1"/>
<wire x1="83.82" y1="13.97" x2="85.09" y2="12.7" width="0.4064" layer="1"/>
<wire x1="85.09" y1="12.7" x2="85.09" y2="10.795" width="0.4064" layer="1"/>
<wire x1="83.82" y1="13.97" x2="76.2" y2="13.97" width="0.4064" layer="1"/>
<wire x1="76.2" y1="13.97" x2="74.93" y2="12.7" width="0.4064" layer="1"/>
<wire x1="74.93" y1="12.7" x2="72.39" y2="12.7" width="0.4064" layer="1"/>
<wire x1="72.39" y1="12.7" x2="69.85" y2="15.24" width="0.4064" layer="1"/>
<wire x1="69.85" y1="15.24" x2="69.5887" y2="15.5013" width="0.4064" layer="1"/>
<wire x1="69.5887" y1="15.5013" x2="64.77" y2="15.5013" width="0.4064" layer="1"/>
<wire x1="70.65" y1="43.9" x2="70.65" y2="46.99" width="0.4064" layer="1"/>
<wire x1="70.65" y1="46.99" x2="70.85" y2="46.99" width="0.4064" layer="1"/>
<wire x1="62.23" y1="13.97" x2="63.7613" y2="15.5013" width="0.4064" layer="1"/>
<wire x1="63.7613" y1="15.5013" x2="64.77" y2="15.5013" width="0.4064" layer="1"/>
</signal>
<signal name="PC1">
<contactref element="R30" pad="1"/>
<contactref element="IC3" pad="20"/>
<wire x1="75.65" y1="40.5" x2="81.14" y2="40.5" width="0.3048" layer="1"/>
<wire x1="81.14" y1="40.5" x2="82.55" y2="41.91" width="0.3048" layer="1"/>
<wire x1="82.55" y1="41.91" x2="82.55" y2="43.18" width="0.3048" layer="1"/>
<wire x1="82.55" y1="43.18" x2="82.55" y2="43.4413" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="PC0">
<contactref element="R31" pad="2"/>
<contactref element="IC3" pad="19"/>
<wire x1="75.65" y1="39.7" x2="84.15" y2="39.7" width="0.3048" layer="1"/>
<wire x1="84.15" y1="39.7" x2="85.09" y2="40.64" width="0.3048" layer="1"/>
<wire x1="85.09" y1="40.64" x2="85.09" y2="43.4413" width="0.3048" layer="1"/>
</signal>
<signal name="/RESET">
<contactref element="IC3" pad="4"/>
<contactref element="RESET" pad="TP"/>
<contactref element="R1" pad="1"/>
<wire x1="64.77" y1="17.5187" x2="67.0487" y2="17.5187" width="0.4064" layer="1"/>
<wire x1="67.0487" y1="17.5187" x2="67.31" y2="17.78" width="0.4064" layer="1"/>
<wire x1="68.25" y1="32.3" x2="68.25" y2="19.99" width="0.4064" layer="1"/>
<wire x1="68.25" y1="19.99" x2="67.31" y2="17.78" width="0.4064" layer="1"/>
</signal>
<signal name="WP">
<contactref element="IC3" pad="15"/>
<contactref element="U$4" pad="10"/>
<wire x1="75.65" y1="36.5" x2="82.88" y2="36.5" width="0.4064" layer="1"/>
<wire x1="82.88" y1="36.5" x2="83.82" y2="36.83" width="0.4064" layer="1"/>
<wire x1="83.82" y1="36.83" x2="86.36" y2="36.83" width="1.016" layer="1"/>
<wire x1="56.388" y1="19.558" x2="56.388" y2="20.828" width="0.4064" layer="1"/>
<wire x1="56.388" y1="20.828" x2="58.42" y2="22.86" width="0.4064" layer="1"/>
<wire x1="58.42" y1="22.86" x2="58.42" y2="24.13" width="0.4064" layer="1"/>
<wire x1="58.42" y1="24.13" x2="60.96" y2="26.67" width="0.4064" layer="1"/>
<wire x1="60.96" y1="26.67" x2="63.5" y2="26.67" width="1.016" layer="1"/>
<wire x1="63.5" y1="26.67" x2="75.65" y2="36.5" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="CD">
<contactref element="IC3" pad="11"/>
<contactref element="U$4" pad="11"/>
<wire x1="83.82" y1="34.29" x2="86.36" y2="34.29" width="1.016" layer="1"/>
<wire x1="55.118" y1="19.558" x2="55.118" y2="18.542" width="0.4064" layer="1"/>
<wire x1="55.118" y1="18.542" x2="55.88" y2="17.78" width="0.4064" layer="1"/>
<wire x1="55.88" y1="17.78" x2="58.42" y2="17.78" width="0.4064" layer="1"/>
<wire x1="58.42" y1="17.78" x2="60.96" y2="24.13" width="0.4064" layer="1"/>
<wire x1="60.96" y1="24.13" x2="63.5" y2="24.13" width="1.016" layer="1"/>
<wire x1="73.85" y1="32.3" x2="73.85" y2="30.48" width="0.4064" layer="1"/>
<wire x1="73.85" y1="30.48" x2="74.93" y2="30.48" width="0.4064" layer="1"/>
<wire x1="74.93" y1="30.48" x2="78.74" y2="34.29" width="0.4064" layer="1"/>
<wire x1="78.74" y1="34.29" x2="83.82" y2="34.29" width="0.4064" layer="1"/>
<wire x1="63.5" y1="24.13" x2="73.85" y2="30.48" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="DATA">
<contactref element="IC3" pad="36"/>
<contactref element="R5" pad="2"/>
<contactref element="R13" pad="1"/>
<wire x1="10.16" y1="28.9487" x2="10.16" y2="30.7413" width="0.4064" layer="1"/>
<wire x1="25.4" y1="30.48" x2="19.05" y2="30.48" width="0.4064" layer="1"/>
<wire x1="19.05" y1="30.48" x2="17.78" y2="31.75" width="0.4064" layer="1"/>
<wire x1="17.78" y1="31.75" x2="17.78" y2="34.29" width="1.016" layer="1"/>
<wire x1="64.05" y1="40.5" x2="62.09" y2="40.5" width="0.4064" layer="1"/>
<wire x1="62.09" y1="40.5" x2="59.69" y2="38.1" width="0.4064" layer="1"/>
<wire x1="59.69" y1="38.1" x2="33.02" y2="38.1" width="0.4064" layer="1"/>
<wire x1="25.4" y1="30.48" x2="33.02" y2="38.1" width="0.4064" layer="1"/>
<wire x1="10.16" y1="30.7413" x2="17.78" y2="31.75" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="LED1">
<contactref element="R30" pad="2"/>
<contactref element="LED3" pad="2"/>
<wire x1="82.55" y1="45.4587" x2="82.55" y2="47.9987" width="0.3048" layer="1"/>
<wire x1="82.55" y1="47.9987" x2="82.2887" y2="48.26" width="0.3048" layer="1"/>
</signal>
<signal name="LED2">
<contactref element="R31" pad="1"/>
<contactref element="LED2" pad="2"/>
<wire x1="85.09" y1="45.4587" x2="85.09" y2="47.9987" width="0.3048" layer="1"/>
<wire x1="85.09" y1="47.9987" x2="85.3513" y2="48.26" width="0.3048" layer="1"/>
</signal>
<signal name="IEC_CLK">
<contactref element="T2" pad="3"/>
<contactref element="R6" pad="1"/>
<contactref element="TP4" pad="TP"/>
<wire x1="6.5087" y1="8.89" x2="6.35" y2="8.89" width="0.4064" layer="1"/>
<wire x1="6.35" y1="8.89" x2="5.08" y2="10.16" width="0.4064" layer="1"/>
<wire x1="5.08" y1="10.16" x2="5.08" y2="17.78" width="0.4064" layer="1"/>
<wire x1="5.08" y1="17.78" x2="6.35" y2="20.32" width="0.4064" layer="1"/>
<wire x1="6.35" y1="20.32" x2="8.35" y2="20.32" width="0.4064" layer="1"/>
<wire x1="8.35" y1="20.32" x2="8.43" y2="20.4" width="0.4064" layer="1"/>
<wire x1="8.43" y1="20.4" x2="11.51" y2="20.4" width="0.4064" layer="1"/>
<wire x1="11.51" y1="20.4" x2="12.7" y2="21.59" width="0.4064" layer="1"/>
<wire x1="12.7" y1="21.59" x2="12.7" y2="26.9313" width="0.4064" layer="1"/>
</signal>
<signal name="N$3">
<contactref element="IC3" pad="8"/>
<contactref element="C5" pad="1"/>
<contactref element="Q1" pad="1"/>
<wire x1="71.45" y1="32.3" x2="71.45" y2="27.61" width="0.4064" layer="1"/>
<wire x1="72.39" y1="26.67" x2="73.414" y2="26.67" width="0.4064" layer="1"/>
<wire x1="73.414" y1="26.67" x2="73.74" y2="26.996" width="0.4064" layer="1"/>
<wire x1="73.74" y1="26.996" x2="73.74" y2="29.21" width="0.4064" layer="1"/>
<wire x1="71.45" y1="27.61" x2="72.39" y2="26.67" width="0.4064" layer="1" curve="90"/>
<wire x1="73.74" y1="29.21" x2="76.2" y2="29.21" width="0.4064" layer="1"/>
<wire x1="76.2" y1="29.21" x2="78.74" y2="31.75" width="0.4064" layer="1"/>
<wire x1="78.74" y1="31.75" x2="79.8181" y2="31.75" width="0.4064" layer="1"/>
</signal>
<signal name="N$7">
<contactref element="IC3" pad="7"/>
<contactref element="C4" pad="1"/>
<contactref element="Q1" pad="2"/>
<wire x1="70.65" y1="32.3" x2="70.65" y2="24.6" width="0.4064" layer="1"/>
<wire x1="70.65" y1="24.6" x2="73.74" y2="21.51" width="0.4064" layer="1"/>
<wire x1="73.74" y1="21.51" x2="73.74" y2="17.344" width="0.4064" layer="1"/>
<wire x1="76.2" y1="26.67" x2="76.2" y2="22.86" width="0.4064" layer="1"/>
<wire x1="76.2" y1="22.86" x2="73.58" y2="21.51" width="0.4064" layer="1"/>
<wire x1="73.58" y1="21.51" x2="73.74" y2="21.51" width="0.4064" layer="1"/>
<wire x1="76.2" y1="26.67" x2="78.74" y2="29.21" width="0.4064" layer="1"/>
<wire x1="78.74" y1="29.21" x2="79.8181" y2="29.21" width="0.4064" layer="1"/>
</signal>
<signal name="ATN">
<contactref element="IC3" pad="37"/>
<contactref element="R12" pad="1"/>
<contactref element="R4" pad="2"/>
<contactref element="R16" pad="1"/>
<wire x1="15.24" y1="28.9487" x2="15.24" y2="30.7413" width="0.4064" layer="1"/>
<wire x1="15.24" y1="28.9487" x2="17.78" y2="28.9487" width="0.4064" layer="1"/>
<wire x1="17.78" y1="28.9487" x2="30.2187" y2="28.9487" width="0.4064" layer="1"/>
<wire x1="30.2187" y1="28.9487" x2="38.1" y2="36.83" width="0.4064" layer="1"/>
<wire x1="38.1" y1="36.83" x2="59.69" y2="36.83" width="0.4064" layer="1"/>
<wire x1="64.05" y1="39.7" x2="62.56" y2="39.7" width="0.4064" layer="1"/>
<wire x1="62.56" y1="39.7" x2="59.69" y2="36.83" width="0.4064" layer="1"/>
</signal>
<signal name="N$23">
<contactref element="T2" pad="2"/>
<contactref element="R9" pad="1"/>
<contactref element="R18" pad="2"/>
<wire x1="8.7312" y1="9.8425" x2="8.7312" y2="9.8987" width="0.4064" layer="1"/>
<wire x1="8.7312" y1="9.8987" x2="11.43" y2="9.8987" width="0.4064" layer="1"/>
<wire x1="11.43" y1="9.8987" x2="21.59" y2="9.8987" width="0.4064" layer="1"/>
</signal>
<signal name="N$24">
<contactref element="T3" pad="2"/>
<contactref element="R10" pad="1"/>
<contactref element="R19" pad="2"/>
<wire x1="8.7312" y1="4.7625" x2="8.7312" y2="4.8187" width="0.4064" layer="1"/>
<wire x1="8.7312" y1="4.8187" x2="11.43" y2="4.8187" width="0.4064" layer="1"/>
<wire x1="11.43" y1="4.8187" x2="21.59" y2="4.8187" width="0.4064" layer="1"/>
</signal>
<signal name="N$25">
<contactref element="T4" pad="2"/>
<contactref element="R11" pad="1"/>
<contactref element="R21" pad="2"/>
<wire x1="8.7312" y1="14.9225" x2="8.7312" y2="14.9787" width="0.4064" layer="1"/>
<wire x1="8.7312" y1="14.9787" x2="11.43" y2="14.9787" width="0.4064" layer="1"/>
<wire x1="11.43" y1="14.9787" x2="21.59" y2="14.9787" width="0.4064" layer="1"/>
</signal>
<signal name="IEC_ATN">
<contactref element="T4" pad="3"/>
<contactref element="R4" pad="1"/>
<contactref element="TP3" pad="TP"/>
<wire x1="6.5087" y1="13.97" x2="6.5087" y2="16.6687" width="0.4064" layer="1"/>
<wire x1="6.5087" y1="16.6687" x2="7.62" y2="17.78" width="0.4064" layer="1"/>
<wire x1="7.62" y1="17.78" x2="10.56" y2="17.78" width="0.4064" layer="1"/>
<wire x1="10.56" y1="17.78" x2="11.43" y2="18.65" width="0.4064" layer="1"/>
<wire x1="11.43" y1="18.65" x2="16.11" y2="18.65" width="0.4064" layer="1"/>
<wire x1="16.11" y1="18.65" x2="16.51" y2="19.05" width="0.4064" layer="1"/>
<wire x1="16.51" y1="19.05" x2="16.51" y2="25.4" width="0.4064" layer="1"/>
<wire x1="16.51" y1="25.4" x2="15.24" y2="26.67" width="0.4064" layer="1"/>
<wire x1="15.24" y1="26.67" x2="15.24" y2="26.9313" width="0.4064" layer="1"/>
</signal>
<signal name="IEC_DATA">
<contactref element="T3" pad="3"/>
<contactref element="R5" pad="1"/>
<contactref element="TP5" pad="TP"/>
<wire x1="6.5087" y1="3.81" x2="5.08" y2="3.81" width="0.4064" layer="1"/>
<wire x1="5.08" y1="3.81" x2="3.81" y2="5.08" width="0.4064" layer="1"/>
<wire x1="3.81" y1="5.08" x2="3.81" y2="19.05" width="0.4064" layer="1"/>
<wire x1="3.81" y1="19.05" x2="6.12" y2="23.9" width="0.4064" layer="1"/>
<wire x1="6.12" y1="23.9" x2="8.43" y2="23.9" width="0.4064" layer="1"/>
<wire x1="8.43" y1="23.9" x2="8.43" y2="25.6613" width="0.4064" layer="1"/>
<wire x1="8.43" y1="25.6613" x2="10.16" y2="26.9313" width="0.4064" layer="1"/>
</signal>
<signal name="CLK">
<contactref element="IC3" pad="35"/>
<contactref element="R6" pad="2"/>
<contactref element="R14" pad="1"/>
<wire x1="12.7" y1="28.9487" x2="12.7" y2="30.7413" width="0.4064" layer="1"/>
<wire x1="25.4" y1="31.75" x2="33.02" y2="39.37" width="0.4064" layer="1"/>
<wire x1="25.4" y1="31.75" x2="21.59" y2="31.75" width="0.4064" layer="1"/>
<wire x1="21.59" y1="31.75" x2="20.32" y2="33.02" width="0.4064" layer="1"/>
<wire x1="20.32" y1="33.02" x2="20.32" y2="35.56" width="1.016" layer="1"/>
<wire x1="64.05" y1="41.3" x2="61.62" y2="41.3" width="0.4064" layer="1"/>
<wire x1="61.62" y1="41.3" x2="59.69" y2="39.37" width="0.4064" layer="1"/>
<wire x1="59.69" y1="39.37" x2="33.02" y2="39.37" width="0.4064" layer="1"/>
<wire x1="12.7" y1="30.7413" x2="20.32" y2="33.02" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$26">
<contactref element="IC3" pad="42"/>
<contactref element="R16" pad="2"/>
<wire x1="20.32" y1="17.78" x2="22.86" y2="17.78" width="1.016" layer="1"/>
<wire x1="30.48" y1="17.78" x2="27.94" y2="17.78" width="1.016" layer="1"/>
<wire x1="17.78" y1="26.9313" x2="17.78" y2="19.05" width="0.4064" layer="1"/>
<wire x1="17.78" y1="19.05" x2="19.05" y2="17.78" width="0.4064" layer="1"/>
<wire x1="19.05" y1="17.78" x2="20.32" y2="17.78" width="0.4064" layer="1"/>
<wire x1="31.75" y1="25.4" x2="31.75" y2="19.05" width="0.4064" layer="1"/>
<wire x1="31.75" y1="19.05" x2="30.48" y2="17.78" width="0.4064" layer="1"/>
<wire x1="64.05" y1="35.7" x2="62.37" y2="35.7" width="0.4064" layer="1"/>
<wire x1="62.37" y1="35.7" x2="59.69" y2="33.02" width="0.4064" layer="1"/>
<wire x1="59.69" y1="33.02" x2="39.37" y2="33.02" width="0.4064" layer="1"/>
<wire x1="31.75" y1="25.4" x2="39.37" y2="33.02" width="0.4064" layer="1"/>
<wire x1="22.86" y1="17.78" x2="27.94" y2="17.78" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$27">
<contactref element="R21" pad="1"/>
<contactref element="IC3" pad="33"/>
<contactref element="T4" pad="1"/>
<wire x1="8.7313" y1="13.0175" x2="8.7313" y2="12.9613" width="0.4064" layer="1"/>
<wire x1="8.7313" y1="12.9613" x2="11.43" y2="12.9613" width="0.4064" layer="1"/>
<wire x1="25.4" y1="33.02" x2="22.86" y2="33.02" width="0.4064" layer="1"/>
<wire x1="22.86" y1="33.02" x2="22.86" y2="35.56" width="1.016" layer="1"/>
<wire x1="11.43" y1="12.9613" x2="15.24" y2="12.9613" width="0.4064" layer="1"/>
<wire x1="15.24" y1="12.9613" x2="17.78" y2="12.9613" width="1.016" layer="1"/>
<wire x1="65.85" y1="43.9" x2="65.85" y2="45.275" width="0.4064" layer="1"/>
<wire x1="64.77" y1="45.72" x2="59.69" y2="40.64" width="0.4064" layer="1"/>
<wire x1="59.69" y1="40.64" x2="33.02" y2="40.64" width="0.4064" layer="1"/>
<wire x1="33.02" y1="40.64" x2="25.4" y2="33.02" width="0.4064" layer="1"/>
<wire x1="65.85" y1="45.275" x2="65.405" y2="45.72" width="0.4064" layer="1"/>
<wire x1="65.405" y1="45.72" x2="64.77" y2="45.72" width="0.4064" layer="1"/>
<wire x1="17.78" y1="12.9613" x2="22.86" y2="33.02" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$28">
<contactref element="R19" pad="1"/>
<contactref element="T3" pad="1"/>
<contactref element="IC3" pad="32"/>
<wire x1="8.7313" y1="2.8575" x2="8.7313" y2="2.8013" width="0.4064" layer="1"/>
<wire x1="8.7313" y1="2.8013" x2="11.43" y2="2.8013" width="0.4064" layer="1"/>
<wire x1="59.69" y1="41.91" x2="27.94" y2="41.91" width="0.4064" layer="1"/>
<wire x1="27.94" y1="41.91" x2="26.67" y2="40.64" width="0.4064" layer="1"/>
<wire x1="26.67" y1="40.64" x2="26.67" y2="38.1" width="1.016" layer="1"/>
<wire x1="11.43" y1="2.8013" x2="15.24" y2="2.8013" width="0.4064" layer="1"/>
<wire x1="15.24" y1="2.8013" x2="17.78" y2="2.8013" width="1.016" layer="1"/>
<wire x1="64.4525" y1="46.6725" x2="59.69" y2="41.91" width="0.4064" layer="1"/>
<wire x1="66.65" y1="43.9" x2="66.65" y2="45.745" width="0.4064" layer="1"/>
<wire x1="66.65" y1="45.745" x2="65.7225" y2="46.6725" width="0.4064" layer="1"/>
<wire x1="65.7225" y1="46.6725" x2="64.4525" y2="46.6725" width="0.4064" layer="1"/>
<wire x1="17.78" y1="2.8013" x2="26.67" y2="38.1" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="N$29">
<contactref element="R18" pad="1"/>
<contactref element="IC3" pad="31"/>
<contactref element="T2" pad="1"/>
<wire x1="8.7313" y1="7.9375" x2="8.7313" y2="7.8813" width="0.4064" layer="1"/>
<wire x1="8.7313" y1="7.8813" x2="11.43" y2="7.8813" width="0.4064" layer="1"/>
<wire x1="59.69" y1="43.18" x2="25.4" y2="43.18" width="0.4064" layer="1"/>
<wire x1="25.4" y1="43.18" x2="24.13" y2="41.91" width="0.4064" layer="1"/>
<wire x1="24.13" y1="41.91" x2="24.13" y2="39.37" width="1.016" layer="1"/>
<wire x1="11.43" y1="7.8813" x2="15.24" y2="7.8813" width="0.4064" layer="1"/>
<wire x1="15.24" y1="7.8813" x2="17.78" y2="7.8813" width="1.016" layer="1"/>
<wire x1="59.69" y1="43.18" x2="64.135" y2="47.625" width="0.4064" layer="1"/>
<wire x1="67.45" y1="43.9" x2="67.45" y2="46.215" width="0.4064" layer="1"/>
<wire x1="67.45" y1="46.215" x2="66.04" y2="47.625" width="0.4064" layer="1"/>
<wire x1="66.04" y1="47.625" x2="64.135" y2="47.625" width="0.4064" layer="1"/>
<wire x1="17.78" y1="7.8813" x2="24.13" y2="39.37" width="0" layer="19" extent="1-1"/>
</signal>
<signal name="MISO">
<contactref element="IC3" pad="2"/>
<contactref element="U$4" pad="7"/>
<contactref element="MISO" pad="TP"/>
<wire x1="66.65" y1="32.3" x2="66.65" y2="26.01" width="0.4064" layer="1"/>
<wire x1="66.65" y1="26.01" x2="62.23" y2="20.32" width="0.4064" layer="1"/>
<wire x1="59.69" y1="16.51" x2="53.34" y2="16.51" width="0.4064" layer="1"/>
<wire x1="53.34" y1="16.51" x2="52.0065" y2="17.8435" width="0.4064" layer="1"/>
<wire x1="52.0065" y1="17.8435" x2="52.0065" y2="19.558" width="0.4064" layer="1"/>
<wire x1="62.23" y1="20.32" x2="59.69" y2="16.51" width="0.4064" layer="1"/>
</signal>
<signal name="MOSI">
<contactref element="IC3" pad="1"/>
<contactref element="U$4" pad="2"/>
<wire x1="62.23" y1="29.21" x2="64.77" y2="29.21" width="0.4064" layer="1"/>
<wire x1="64.77" y1="29.21" x2="65.85" y2="30.29" width="0.4064" layer="1"/>
<wire x1="65.85" y1="32.3" x2="65.85" y2="30.29" width="0.4064" layer="1"/>
<contactref element="MOSI" pad="TP"/>
<wire x1="39.624" y1="19.558" x2="39.624" y2="25.4" width="0.4064" layer="1"/>
<wire x1="39.624" y1="25.4" x2="40.894" y2="26.67" width="0.4064" layer="1"/>
<wire x1="40.894" y1="26.67" x2="57.15" y2="26.67" width="0.4064" layer="1"/>
<wire x1="57.15" y1="26.67" x2="59.69" y2="29.21" width="0.4064" layer="1"/>
<wire x1="59.69" y1="29.21" x2="62.23" y2="29.21" width="0.4064" layer="1"/>
</signal>
<signal name="SCK">
<contactref element="IC3" pad="3"/>
<contactref element="U$4" pad="5"/>
<contactref element="SCK" pad="TP"/>
<wire x1="47.244" y1="19.558" x2="47.244" y2="17.526" width="0.4064" layer="1"/>
<wire x1="47.244" y1="17.526" x2="49.53" y2="15.24" width="0.4064" layer="1"/>
<wire x1="49.53" y1="15.24" x2="60.96" y2="15.24" width="0.4064" layer="1"/>
<wire x1="67.45" y1="32.3" x2="67.45" y2="23" width="0.4064" layer="1"/>
<wire x1="67.45" y1="23" x2="66.04" y2="21.59" width="0.4064" layer="1"/>
<wire x1="66.04" y1="21.59" x2="60.96" y2="15.24" width="0.4064" layer="1"/>
</signal>
<signal name="CS">
<contactref element="IC3" pad="44"/>
<contactref element="U$4" pad="1"/>
<wire x1="37.084" y1="19.558" x2="37.084" y2="28.194" width="0.4064" layer="1"/>
<wire x1="37.084" y1="28.194" x2="39.37" y2="30.48" width="0.4064" layer="1"/>
<wire x1="64.05" y1="34.1" x2="62.04" y2="34.1" width="0.4064" layer="1"/>
<wire x1="62.04" y1="34.1" x2="58.42" y2="30.48" width="0.4064" layer="1"/>
<wire x1="58.42" y1="30.48" x2="39.37" y2="30.48" width="0.4064" layer="1"/>
</signal>
<signal name="N$1">
<contactref element="U$6" pad="3"/>
<contactref element="C-REG5" pad="1"/>
<contactref element="D2" pad="1"/>
<wire x1="87.63" y1="5.08" x2="87.63" y2="10.795" width="0.8128" layer="1"/>
<wire x1="77.47" y1="3.81" x2="86.36" y2="3.81" width="0.8128" layer="1"/>
<wire x1="86.36" y1="3.81" x2="87.63" y2="5.08" width="0.8128" layer="1"/>
<wire x1="77.47" y1="3.81" x2="76.2" y2="5.08" width="0.8128" layer="1"/>
<wire x1="76.2" y1="5.08" x2="67.31" y2="5.08" width="0.8128" layer="1"/>
<wire x1="67.31" y1="5.08" x2="62.844" y2="5.08" width="0.8128" layer="1"/>
<wire x1="67.31" y1="4.76" x2="67.31" y2="5.08" width="0.8128" layer="1"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
