<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="7.6.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="mm" unit="mm" style="lines" multiple="1" display="yes" altdistance="0.1" altunitdist="mm" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="no" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="yes"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="yes"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="yes"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="yes"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="yes"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="yes"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="yes"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="yes"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="yes"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="yes"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="yes"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="yes"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="yes"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="no" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="no" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="no" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="no" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="no" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="no" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="yes"/>
<layer number="50" name="dxf" color="7" fill="1" visible="no" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="90" name="Modules" color="5" fill="1" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
<layer number="99" name="SpiceOrder" color="5" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<wire x1="20" y1="42" x2="100" y2="42" width="0" layer="20"/>
<wire x1="100" y1="42" x2="100" y2="82" width="0" layer="20"/>
<wire x1="100" y1="82" x2="20" y2="82" width="0" layer="20"/>
<wire x1="20" y1="82" x2="20" y2="42" width="0" layer="20"/>
<wire x1="20" y1="0" x2="100" y2="0" width="0" layer="20"/>
<wire x1="100" y1="0" x2="100" y2="40" width="0" layer="20"/>
<wire x1="100" y1="40" x2="20" y2="40" width="0" layer="20"/>
<wire x1="20" y1="40" x2="20" y2="0" width="0" layer="20"/>
</plain>
<libraries>
<library name="NANO">
<packages>
<package name="NANO">
<wire x1="-8.89" y1="21.59" x2="8.89" y2="21.59" width="0.4064" layer="21"/>
<wire x1="-8.89" y1="-21.59" x2="8.89" y2="-21.59" width="0.4064" layer="21"/>
<wire x1="-8.89" y1="21.59" x2="-8.89" y2="-21.59" width="0.4064" layer="21"/>
<wire x1="8.89" y1="21.59" x2="8.89" y2="-21.59" width="0.4064" layer="21"/>
<wire x1="-3" y1="-23" x2="4" y2="-23" width="0.4064" layer="21"/>
<wire x1="-3" y1="-23" x2="-3" y2="-14" width="0.4064" layer="21"/>
<wire x1="-3" y1="-14" x2="4" y2="-14" width="0.4064" layer="21"/>
<wire x1="4" y1="-14" x2="4" y2="-23" width="0.4064" layer="21"/>
<wire x1="-2" y1="-15.5" x2="-0.5" y2="-15.5" width="0.127" layer="21"/>
<wire x1="-0.5" y1="-15.5" x2="-0.5" y2="-16.5" width="0.127" layer="21"/>
<wire x1="-0.5" y1="-16.5" x2="1.5" y2="-16.5" width="0.127" layer="21"/>
<wire x1="1.5" y1="-16.5" x2="1.5" y2="-15.5" width="0.127" layer="21"/>
<wire x1="1.5" y1="-15.5" x2="3" y2="-15.5" width="0.127" layer="21"/>
<wire x1="-2" y1="-19.5" x2="-2" y2="-22" width="0.127" layer="21"/>
<wire x1="-2" y1="-22" x2="-1.5" y2="-22" width="0.127" layer="21"/>
<wire x1="-1.5" y1="-22" x2="-1.5" y2="-19.5" width="0.127" layer="21"/>
<wire x1="-1.5" y1="-19.5" x2="-2" y2="-19.5" width="0.127" layer="21"/>
<wire x1="3" y1="-22" x2="3" y2="-19.5" width="0.127" layer="21"/>
<wire x1="3" y1="-19.5" x2="2.5" y2="-19.5" width="0.127" layer="21"/>
<wire x1="2.5" y1="-19.5" x2="2.5" y2="-22" width="0.127" layer="21"/>
<wire x1="2.5" y1="-22" x2="3" y2="-22" width="0.127" layer="21"/>
<wire x1="-0.5" y1="-22" x2="-0.5" y2="-18.5" width="0.127" layer="21"/>
<wire x1="-0.5" y1="-18.5" x2="1.5" y2="-18.5" width="0.127" layer="21"/>
<wire x1="1.5" y1="-18.5" x2="1.5" y2="-22" width="0.127" layer="21"/>
<wire x1="1.5" y1="-22" x2="1" y2="-22" width="0.127" layer="21"/>
<wire x1="0" y1="-22" x2="-0.5" y2="-22" width="0.127" layer="21"/>
<wire x1="0.5" y1="-16" x2="0.5" y2="-15.25" width="0.127" layer="21"/>
<wire x1="0" y1="-22" x2="0.25" y2="-19.5" width="0.127" layer="21"/>
<wire x1="1" y1="-22" x2="0.75" y2="-19.5" width="0.127" layer="21"/>
<wire x1="0.75" y1="-19.5" x2="0.25" y2="-19.5" width="0.127" layer="21"/>
<wire x1="0" y1="-11" x2="4" y2="-7" width="0.127" layer="21"/>
<wire x1="4" y1="-7" x2="0" y2="-3" width="0.127" layer="21"/>
<wire x1="0" y1="-3" x2="-4" y2="-7" width="0.127" layer="21"/>
<wire x1="-4" y1="-7" x2="0" y2="-11" width="0.127" layer="21"/>
<wire x1="-4" y1="17" x2="3" y2="17" width="0.127" layer="21"/>
<wire x1="3" y1="17" x2="3" y2="21" width="0.127" layer="21"/>
<wire x1="3" y1="21" x2="-4" y2="21" width="0.127" layer="21"/>
<wire x1="-4" y1="21" x2="-4" y2="17" width="0.127" layer="21"/>
<wire x1="-2" y1="2" x2="-2" y2="0" width="0.127" layer="21"/>
<wire x1="-2" y1="0" x2="2" y2="0" width="0.127" layer="21"/>
<wire x1="2" y1="0" x2="2" y2="2" width="0.127" layer="21"/>
<wire x1="2" y1="2" x2="-2" y2="2" width="0.127" layer="21"/>
<wire x1="-4" y1="8" x2="-4" y2="5" width="0.127" layer="21"/>
<wire x1="-4" y1="5" x2="-3" y2="5" width="0.127" layer="21"/>
<wire x1="-3" y1="5" x2="-3" y2="8" width="0.127" layer="21"/>
<wire x1="-3" y1="8" x2="-4" y2="8" width="0.127" layer="21"/>
<wire x1="-2" y1="8" x2="-1" y2="8" width="0.127" layer="21"/>
<wire x1="-1" y1="8" x2="-1" y2="5" width="0.127" layer="21"/>
<wire x1="-1" y1="5" x2="-2" y2="5" width="0.127" layer="21"/>
<wire x1="-2" y1="5" x2="-2" y2="8" width="0.127" layer="21"/>
<wire x1="1" y1="8" x2="1" y2="5" width="0.127" layer="21"/>
<wire x1="1" y1="5" x2="2" y2="5" width="0.127" layer="21"/>
<wire x1="2" y1="5" x2="2" y2="8" width="0.127" layer="21"/>
<wire x1="2" y1="8" x2="1" y2="8" width="0.127" layer="21"/>
<wire x1="4" y1="8" x2="4" y2="5" width="0.127" layer="21"/>
<wire x1="4" y1="5" x2="5" y2="5" width="0.127" layer="21"/>
<wire x1="5" y1="5" x2="5" y2="8" width="0.127" layer="21"/>
<wire x1="5" y1="8" x2="4" y2="8" width="0.127" layer="21"/>
<circle x="0" y="1" radius="1" width="0.127" layer="21"/>
<pad name="A5" x="7.62" y="2.54" drill="1" diameter="1.778" shape="long"/>
<pad name="D4" x="-7.62" y="2.54" drill="1" diameter="1.778" shape="long"/>
<pad name="D5" x="-7.62" y="0" drill="1" diameter="1.778" shape="long"/>
<pad name="D6" x="-7.62" y="-2.54" drill="1" diameter="1.778" shape="long"/>
<pad name="D7" x="-7.62" y="-5.08" drill="1" diameter="1.778" shape="long"/>
<pad name="D8" x="-7.62" y="-7.62" drill="1" diameter="1.778" shape="long"/>
<pad name="D9" x="-7.62" y="-10.16" drill="1" diameter="1.778" shape="long"/>
<pad name="D3" x="-7.62" y="5.08" drill="1" diameter="1.778" shape="long"/>
<pad name="D2" x="-7.62" y="7.62" drill="1" diameter="1.778" shape="long"/>
<pad name="GND" x="-7.62" y="10.16" drill="1" diameter="1.778" shape="long"/>
<pad name="RESET" x="-7.62" y="12.7" drill="1" diameter="1.778" shape="long"/>
<pad name="D10" x="-7.62" y="-12.7" drill="1" diameter="1.778" shape="long"/>
<pad name="RX" x="-7.62" y="15.24" drill="1" diameter="1.778" shape="long"/>
<pad name="D11" x="-7.62" y="-15.24" drill="1" diameter="1.778" shape="long"/>
<pad name="TX" x="-7.62" y="17.78" drill="1" diameter="1.778" shape="long"/>
<pad name="D12" x="-7.62" y="-17.78" drill="1" diameter="1.778" shape="long"/>
<pad name="A4" x="7.62" y="0" drill="1" diameter="1.778" shape="long"/>
<pad name="A3" x="7.62" y="-2.54" drill="1" diameter="1.778" shape="long"/>
<pad name="A2" x="7.62" y="-5.08" drill="1" diameter="1.778" shape="long"/>
<pad name="A1" x="7.62" y="-7.62" drill="1" diameter="1.778" shape="long"/>
<pad name="A0" x="7.62" y="-10.16" drill="1" diameter="1.778" shape="long"/>
<pad name="AREF" x="7.62" y="-12.7" drill="1" diameter="1.778" shape="long"/>
<pad name="3V3" x="7.62" y="-15.24" drill="1" diameter="1.778" shape="long"/>
<pad name="D13" x="7.62" y="-17.78" drill="1" diameter="1.778" shape="long"/>
<pad name="A6" x="7.62" y="5.08" drill="1" diameter="1.778" shape="long"/>
<pad name="A7" x="7.62" y="7.62" drill="1" diameter="1.778" shape="long"/>
<pad name="5V" x="7.62" y="10.16" drill="1" diameter="1.778" shape="long"/>
<pad name="RESET2" x="7.62" y="12.7" drill="1" diameter="1.778" shape="long"/>
<pad name="GND2" x="7.62" y="15.24" drill="1" diameter="1.778" shape="long"/>
<pad name="VIN" x="7.62" y="17.78" drill="1" diameter="1.778" shape="long"/>
<text x="-4" y="15" size="1.27" layer="25">ARDUINO</text>
<text x="-2.75" y="13" size="1.27" layer="25">NANO</text>
<text x="-2.25" y="11" size="1.27" layer="25">V3.0</text>
<text x="-4.5" y="8.5" size="0.8128" layer="21">TX</text>
<text x="-2.25" y="8.5" size="0.8128" layer="21">RX</text>
<text x="0.25" y="8.5" size="0.8128" layer="21">PWR</text>
<text x="4.25" y="8.5" size="0.8128" layer="21">L</text>
<text x="-1.25" y="2.25" size="0.8128" layer="21">RST</text>
<hole x="-7.62" y="-20.32" drill="1.651"/>
<hole x="7.62" y="-20.32" drill="1.651"/>
<hole x="-7.62" y="20.32" drill="1.651"/>
<hole x="7.62" y="20.32" drill="1.651"/>
</package>
</packages>
</library>
<library name="max7219">
<packages>
<package name="SO24L">
<description>&lt;b&gt;Small Outline Package&lt;/b&gt;</description>
<wire x1="7.366" y1="3.7338" x2="-7.366" y2="3.7338" width="0.1524" layer="21"/>
<wire x1="7.366" y1="-3.7338" x2="7.747" y2="-3.3528" width="0.1524" layer="21" curve="90"/>
<wire x1="-7.747" y1="3.3528" x2="-7.366" y2="3.7338" width="0.1524" layer="21" curve="-90"/>
<wire x1="7.366" y1="3.7338" x2="7.747" y2="3.3528" width="0.1524" layer="21" curve="-90"/>
<wire x1="-7.747" y1="-3.3528" x2="-7.366" y2="-3.7338" width="0.1524" layer="21" curve="90"/>
<wire x1="-7.366" y1="-3.7338" x2="7.366" y2="-3.7338" width="0.1524" layer="21"/>
<wire x1="7.747" y1="-3.3528" x2="7.747" y2="3.3528" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="3.3528" x2="-7.747" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="1.27" x2="-7.747" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-1.27" x2="-7.747" y2="-3.3528" width="0.1524" layer="21"/>
<wire x1="-7.747" y1="-3.3782" x2="7.747" y2="-3.3782" width="0.0508" layer="21"/>
<wire x1="-7.747" y1="1.27" x2="-7.747" y2="-1.27" width="0.1524" layer="21" curve="-180"/>
<smd name="1" x="-6.985" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="2" x="-5.715" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="3" x="-4.445" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="4" x="-3.175" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="5" x="-1.905" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="6" x="-0.635" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="7" x="0.635" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="8" x="1.905" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="17" x="1.905" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="18" x="0.635" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="19" x="-0.635" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="20" x="-1.905" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="21" x="-3.175" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="22" x="-4.445" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="23" x="-5.715" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="24" x="-6.985" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="16" x="3.175" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="15" x="4.445" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="14" x="5.715" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="13" x="6.985" y="5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="9" x="3.175" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="10" x="4.445" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="11" x="5.715" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<smd name="12" x="6.985" y="-5.0292" dx="0.6604" dy="2.032" layer="1"/>
<text x="-5.842" y="-0.762" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-8.128" y="-3.556" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<rectangle x1="-7.239" y1="-3.8608" x2="-6.731" y2="-3.7338" layer="21"/>
<rectangle x1="-7.239" y1="-5.334" x2="-6.731" y2="-3.8608" layer="51"/>
<rectangle x1="-5.969" y1="-3.8608" x2="-5.461" y2="-3.7338" layer="21"/>
<rectangle x1="-5.969" y1="-5.334" x2="-5.461" y2="-3.8608" layer="51"/>
<rectangle x1="-4.699" y1="-3.8608" x2="-4.191" y2="-3.7338" layer="21"/>
<rectangle x1="-4.699" y1="-5.334" x2="-4.191" y2="-3.8608" layer="51"/>
<rectangle x1="-3.429" y1="-3.8608" x2="-2.921" y2="-3.7338" layer="21"/>
<rectangle x1="-3.429" y1="-5.334" x2="-2.921" y2="-3.8608" layer="51"/>
<rectangle x1="-2.159" y1="-5.334" x2="-1.651" y2="-3.8608" layer="51"/>
<rectangle x1="-2.159" y1="-3.8608" x2="-1.651" y2="-3.7338" layer="21"/>
<rectangle x1="-0.889" y1="-3.8608" x2="-0.381" y2="-3.7338" layer="21"/>
<rectangle x1="-0.889" y1="-5.334" x2="-0.381" y2="-3.8608" layer="51"/>
<rectangle x1="0.381" y1="-3.8608" x2="0.889" y2="-3.7338" layer="21"/>
<rectangle x1="0.381" y1="-5.334" x2="0.889" y2="-3.8608" layer="51"/>
<rectangle x1="1.651" y1="-3.8608" x2="2.159" y2="-3.7338" layer="21"/>
<rectangle x1="1.651" y1="-5.334" x2="2.159" y2="-3.8608" layer="51"/>
<rectangle x1="-7.239" y1="3.8608" x2="-6.731" y2="5.334" layer="51"/>
<rectangle x1="-7.239" y1="3.7338" x2="-6.731" y2="3.8608" layer="21"/>
<rectangle x1="-5.969" y1="3.7338" x2="-5.461" y2="3.8608" layer="21"/>
<rectangle x1="-5.969" y1="3.8608" x2="-5.461" y2="5.334" layer="51"/>
<rectangle x1="-4.699" y1="3.7338" x2="-4.191" y2="3.8608" layer="21"/>
<rectangle x1="-4.699" y1="3.8608" x2="-4.191" y2="5.334" layer="51"/>
<rectangle x1="-3.429" y1="3.7338" x2="-2.921" y2="3.8608" layer="21"/>
<rectangle x1="-3.429" y1="3.8608" x2="-2.921" y2="5.334" layer="51"/>
<rectangle x1="-2.159" y1="3.7338" x2="-1.651" y2="3.8608" layer="21"/>
<rectangle x1="-2.159" y1="3.8608" x2="-1.651" y2="5.334" layer="51"/>
<rectangle x1="-0.889" y1="3.7338" x2="-0.381" y2="3.8608" layer="21"/>
<rectangle x1="-0.889" y1="3.8608" x2="-0.381" y2="5.334" layer="51"/>
<rectangle x1="0.381" y1="3.7338" x2="0.889" y2="3.8608" layer="21"/>
<rectangle x1="0.381" y1="3.8608" x2="0.889" y2="5.334" layer="51"/>
<rectangle x1="1.651" y1="3.7338" x2="2.159" y2="3.8608" layer="21"/>
<rectangle x1="1.651" y1="3.8608" x2="2.159" y2="5.334" layer="51"/>
<rectangle x1="2.921" y1="3.7338" x2="3.429" y2="3.8608" layer="21"/>
<rectangle x1="4.191" y1="3.7338" x2="4.699" y2="3.8608" layer="21"/>
<rectangle x1="5.461" y1="3.7338" x2="5.969" y2="3.8608" layer="21"/>
<rectangle x1="6.731" y1="3.7338" x2="7.239" y2="3.8608" layer="21"/>
<rectangle x1="2.921" y1="3.8608" x2="3.429" y2="5.334" layer="51"/>
<rectangle x1="4.191" y1="3.8608" x2="4.699" y2="5.334" layer="51"/>
<rectangle x1="5.461" y1="3.8608" x2="5.969" y2="5.334" layer="51"/>
<rectangle x1="6.731" y1="3.8608" x2="7.239" y2="5.334" layer="51"/>
<rectangle x1="2.921" y1="-3.8608" x2="3.429" y2="-3.7338" layer="21"/>
<rectangle x1="4.191" y1="-3.8608" x2="4.699" y2="-3.7338" layer="21"/>
<rectangle x1="5.461" y1="-3.8608" x2="5.969" y2="-3.7338" layer="21"/>
<rectangle x1="6.731" y1="-3.8608" x2="7.239" y2="-3.7338" layer="21"/>
<rectangle x1="2.921" y1="-5.334" x2="3.429" y2="-3.8608" layer="51"/>
<rectangle x1="4.191" y1="-5.334" x2="4.699" y2="-3.8608" layer="51"/>
<rectangle x1="5.461" y1="-5.334" x2="5.969" y2="-3.8608" layer="51"/>
<rectangle x1="6.731" y1="-5.334" x2="7.239" y2="-3.8608" layer="51"/>
</package>
</packages>
</library>
<library name="rcl">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
http://www.secc.co.jp/pdf/os_e/2004/e_os_all.pdf &lt;b&gt;(SANYO)&lt;/b&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0&gt;
&lt;tr valign="top"&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;</description>
<packages>
<package name="R2512">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;</description>
<wire x1="-2.362" y1="1.473" x2="2.387" y2="1.473" width="0.1524" layer="51"/>
<wire x1="-2.362" y1="-1.473" x2="2.387" y2="-1.473" width="0.1524" layer="51"/>
<wire x1="-3.973" y1="1.983" x2="3.973" y2="1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="1.983" x2="3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="3.973" y1="-1.983" x2="-3.973" y2="-1.983" width="0.0508" layer="39"/>
<wire x1="-3.973" y1="-1.983" x2="-3.973" y2="1.983" width="0.0508" layer="39"/>
<smd name="1" x="-2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<smd name="2" x="2.8" y="0" dx="1.8" dy="3.2" layer="1"/>
<text x="-2.54" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.54" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-3.2004" y1="-1.5494" x2="-2.3505" y2="1.5507" layer="51"/>
<rectangle x1="2.3622" y1="-1.5494" x2="3.2121" y2="1.5507" layer="51"/>
<rectangle x1="-0.5001" y1="-1" x2="0.5001" y2="1" layer="35"/>
</package>
<package name="R1206">
<wire x1="0.9525" y1="-0.8128" x2="-0.9652" y2="-0.8128" width="0.1524" layer="51"/>
<wire x1="0.9525" y1="0.8128" x2="-0.9652" y2="0.8128" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="2" x="1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<smd name="1" x="-1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6891" y1="-0.8763" x2="-0.9525" y2="0.8763" layer="51"/>
<rectangle x1="0.9525" y1="-0.8763" x2="1.6891" y2="0.8763" layer="51"/>
<rectangle x1="-0.3" y1="-0.7" x2="0.3" y2="0.7" layer="35"/>
</package>
<package name="E2,5-6">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 2.54 mm, diameter 6 mm</description>
<wire x1="-2.032" y1="1.27" x2="-1.651" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0.889" x2="-1.651" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.27" x2="-1.27" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="1.27" x2="-1.651" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="2.794" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<text x="2.667" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.667" y="-2.667" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="E3,5-10">
grid 3.5 mm, diameter 10 mm</description>
<wire x1="-3.429" y1="1.143" x2="-2.667" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="0.762" x2="-3.048" y2="1.524" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="5.08" width="0.1524" layer="21"/>
<pad name="-" x="1.778" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.778" y="0" drill="0.8128" diameter="1.6002"/>
<text x="4.064" y="3.429" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.302" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C1206">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;</description>
<wire x1="-0.965" y1="0.787" x2="0.965" y2="0.787" width="0.1016" layer="51"/>
<wire x1="-0.965" y1="-0.787" x2="0.965" y2="-0.787" width="0.1016" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="1.8" layer="1"/>
<rectangle x1="-1.7018" y1="-0.8509" x2="-0.9517" y2="0.8491" layer="51"/>
<rectangle x1="0.9517" y1="-0.8491" x2="1.7018" y2="0.8509" layer="51"/>
<rectangle x1="-0.1999" y1="-0.4001" x2="0.1999" y2="0.4001" layer="35"/>
</package>
<package name="0411V">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
type 0411, grid 3.81 mm</description>
<wire x1="1.27" y1="0" x2="0.3048" y2="0" width="0.762" layer="51"/>
<wire x1="-1.5748" y1="0" x2="-2.54" y2="0" width="0.762" layer="51"/>
<circle x="-2.54" y="0" radius="2.032" width="0.1524" layer="21"/>
<circle x="-2.54" y="0" radius="1.016" width="0.1524" layer="51"/>
<pad name="1" x="-2.54" y="0" drill="0.9144" shape="octagon"/>
<pad name="2" x="1.27" y="0" drill="0.9144" shape="octagon"/>
<text x="-0.508" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-0.5334" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.4732" y1="-0.381" x2="0.2032" y2="0.381" layer="21"/>
</package>
<package name="6000-XXXX-RC">
<description>&lt;b&gt;Radial Lead RF Chokes&lt;/b&gt;&lt;p&gt;
Source: www.bourns.com .. 6000_series.pdf</description>
<circle x="0" y="0" radius="4.4" width="0.2032" layer="21"/>
<pad name="1" x="-2.5" y="0" drill="0.9" diameter="1.4224"/>
<pad name="2" x="2.5" y="0" drill="0.9" diameter="1.4224"/>
<text x="-4.5056" y="4.6326" size="1.27" layer="25">&gt;NAME</text>
<text x="-4.5056" y="-6.4106" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="diode">
<description>&lt;b&gt;Diodes&lt;/b&gt;&lt;p&gt;
Based on the following sources:
&lt;ul&gt;
&lt;li&gt;Motorola : www.onsemi.com
&lt;li&gt;Fairchild : www.fairchildsemi.com
&lt;li&gt;Philips : www.semiconductors.com
&lt;li&gt;Vishay : www.vishay.de
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="DO41-7.6">
<description>&lt;b&gt;DO41&lt;/b&gt; 7.6mm x 2mm&lt;p&gt;
Source: http://www.diodes.com/datasheets/ds23001.pdf</description>
<wire x1="2.082" y1="-0.92" x2="-2.082" y2="-0.92" width="0.1524" layer="21"/>
<wire x1="2.082" y1="-0.92" x2="2.082" y2="0.92" width="0.1524" layer="21"/>
<wire x1="-2.082" y1="0.92" x2="2.082" y2="0.92" width="0.1524" layer="21"/>
<wire x1="-2.082" y1="0.92" x2="-2.082" y2="-0.92" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0" x2="2.494" y2="0" width="0.85" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.519" y2="0" width="0.85" layer="51"/>
<wire x1="-0.635" y1="0" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="1.1" diameter="1.7"/>
<pad name="A" x="3.81" y="0" drill="1.1" diameter="1.7"/>
<text x="-2.032" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.651" y1="-0.95" x2="-1.143" y2="0.92" layer="21"/>
<rectangle x1="2.082" y1="-0.425" x2="2.717" y2="0.425" layer="21"/>
<rectangle x1="-2.717" y1="-0.425" x2="-2.082" y2="0.425" layer="21"/>
</package>
</packages>
</library>
<library name="con-amp">
<description>&lt;b&gt;AMP Connectors&lt;/b&gt;&lt;p&gt;
RJ45 Jack connectors&lt;br&gt;
 Based on the previous libraris:
 &lt;ul&gt;
 &lt;li&gt;amp.lbr
 &lt;li&gt;amp-j.lbr
 &lt;li&gt;amp-mta.lbr
 &lt;li&gt;amp-nlok.lbr
 &lt;li&gt;amp-sim.lbr
 &lt;li&gt;amp-micro-match.lbr
 &lt;/ul&gt;
 Sources :
 &lt;ul&gt;
 &lt;li&gt;Catalog 82066 Revised 11-95
 &lt;li&gt;Product Guide 296785 Rev. 8-99
 &lt;li&gt;Product Guide CD-ROM 1999
 &lt;li&gt;www.amp.com
 &lt;/ul&gt;
<packages>
<package name="10X02MTA">
<description>&lt;b&gt;AMP MTA connector&lt;/b&gt;&lt;p&gt;
Source: http://ecommas.tycoelectronics.com .. ENG_CD_640456_W.pdf</description>
<wire x1="-2.54" y1="-1.27" x2="-2.54" y2="1.27" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.27" x2="-2.54" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-1.27" x2="2.54" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.27" x2="-2.54" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.905" x2="-2.54" y2="1.905" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.27" x2="2.54" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.54" y1="1.905" x2="2.54" y2="1.27" width="0.1524" layer="21"/>
<pad name="2" x="-1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="1" x="1.27" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-2.6162" y="-3.2512" size="1.27" layer="25">&gt;NAME</text>
<text x="-2.5461" y="2.1509" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="1.016" y1="-0.254" x2="1.524" y2="0.254" layer="21"/>
<rectangle x1="-1.524" y1="-0.254" x2="-1.016" y2="0.254" layer="21"/>
</package>
</packages>
</library>
<library name="con-amp-quick">
<description>&lt;b&gt;AMP Connectors, Type QUICK&lt;/b&gt;&lt;p&gt;
<packages>
<package name="05P">
<description>&lt;b&gt;AMP QUICK CONNECTOR&lt;/b&gt;</description>
<wire x1="-4.191" y1="1.778" x2="-4.064" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="1.651" x2="-3.81" y2="1.397" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.397" x2="-3.556" y2="1.651" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.651" x2="-3.429" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="-2.159" x2="-4.064" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="-2.286" x2="-6.096" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-2.159" x2="-4.064" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-2.159" x2="-3.556" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="2.54" x2="-6.096" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="1.778" x2="-6.096" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-1.778" x2="-6.096" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-1.778" x2="-5.715" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.778" x2="-4.445" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.778" x2="-5.715" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.27" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.524" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.778" x2="-3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.524" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.524" x2="-4.064" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="-1.524" x2="-3.556" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-1.524" x2="-3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.524" x2="-6.096" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-1.524" x2="-5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="-1.524" x2="-6.096" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-6.096" y1="2.54" x2="-5.334" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.334" y1="2.54" x2="-5.334" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.54" x2="-4.826" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-4.826" y1="2.667" x2="-5.334" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-2.794" y1="2.54" x2="-2.794" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="2.54" x2="-2.286" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="2.413" x2="-3.556" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="2.413" x2="-4.064" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-2.159" x2="-1.524" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-2.159" x2="-1.016" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-2.286" x2="-1.016" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.016" y1="1.778" x2="1.016" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.778" x2="0.635" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.778" x2="-1.905" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.524" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.778" x2="-0.635" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.524" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.524" x2="-1.524" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-1.524" x2="-1.016" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-1.524" x2="-0.635" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.524" x2="1.016" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.524" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="2.54" x2="-0.254" y2="2.667" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.54" x2="1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.54" x2="0.254" y2="2.667" width="0.1524" layer="21"/>
<wire x1="0.254" y1="2.667" x2="-0.254" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="2.413" x2="-1.016" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="2.54" x2="-0.254" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="2.413" x2="-1.524" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="2.413" x2="-1.524" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="2.54" x2="-1.524" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-2.286" y1="2.667" x2="-2.794" y2="2.667" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="2.54" x2="-2.794" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="2.413" x2="-3.556" y2="2.413" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="2.54" x2="-4.826" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-4.191" y1="1.778" x2="-6.096" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.778" x2="-1.524" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="1.778" x2="-1.016" y2="1.778" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="1.651" x2="-3.556" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-4.064" y1="1.651" x2="-4.064" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="1.778" x2="-1.524" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="1.778" x2="-1.016" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.778" x2="-4.445" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-3.556" y1="-2.286" x2="-1.524" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.778" x2="-0.635" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="-2.159" x2="-1.524" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.524" y1="1.778" x2="1.524" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.778" x2="1.905" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.524" x2="1.524" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.524" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.286" y1="2.54" x2="2.286" y2="2.667" width="0.1524" layer="21"/>
<wire x1="2.794" y1="2.54" x2="2.794" y2="2.667" width="0.1524" layer="21"/>
<wire x1="3.81" y1="1.397" x2="4.064" y2="1.651" width="0.1524" layer="21"/>
<wire x1="4.064" y1="1.651" x2="4.191" y2="1.778" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-2.159" x2="3.556" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-2.159" x2="4.064" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-2.286" x2="4.064" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="4.191" y1="1.778" x2="6.096" y2="1.778" width="0.1524" layer="21"/>
<wire x1="6.096" y1="1.778" x2="6.096" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-1.778" x2="6.096" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-1.778" x2="5.715" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="6.096" y1="1.778" x2="6.096" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.778" x2="5.715" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.778" x2="3.175" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.524" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.778" x2="4.445" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.524" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.524" x2="3.556" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="3.556" y1="-1.524" x2="4.064" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.064" y1="-1.524" x2="4.445" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.524" x2="6.096" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.524" x2="5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="6.096" y1="-1.524" x2="6.096" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="4.826" y1="2.54" x2="4.826" y2="2.667" width="0.1524" layer="21"/>
<wire x1="5.334" y1="2.54" x2="6.096" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.334" y1="2.54" x2="5.334" y2="2.667" width="0.1524" layer="21"/>
<wire x1="5.334" y1="2.667" x2="4.826" y2="2.667" width="0.1524" layer="21"/>
<wire x1="4.064" y1="2.413" x2="4.064" y2="2.54" width="0.1524" layer="21"/>
<wire x1="4.064" y1="2.54" x2="4.826" y2="2.54" width="0.1524" layer="21"/>
<wire x1="4.064" y1="2.413" x2="3.556" y2="2.413" width="0.1524" layer="21"/>
<wire x1="3.556" y1="2.413" x2="3.556" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.778" x2="3.556" y2="1.651" width="0.1524" layer="21"/>
<wire x1="3.556" y1="1.651" x2="3.81" y2="1.397" width="0.1524" layer="21"/>
<wire x1="2.794" y1="2.54" x2="3.556" y2="2.54" width="0.1524" layer="21"/>
<wire x1="2.794" y1="2.667" x2="2.286" y2="2.667" width="0.1524" layer="21"/>
<wire x1="1.524" y1="2.54" x2="2.286" y2="2.54" width="0.1524" layer="21"/>
<wire x1="3.556" y1="1.651" x2="3.556" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="4.064" y1="1.651" x2="4.064" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-2.286" x2="3.556" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.778" x2="4.445" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="3.556" y1="-2.159" x2="3.556" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="1.778" x2="1.016" y2="1.778" width="0.1524" layer="21"/>
<wire x1="1.524" y1="1.778" x2="3.429" y2="1.778" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-2.159" x2="1.016" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-2.159" x2="1.524" y2="-2.286" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-2.159" x2="1.016" y2="-2.159" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.778" x2="0.635" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-1.524" x2="1.016" y2="-1.524" width="0.1524" layer="21"/>
<wire x1="1.524" y1="1.778" x2="1.016" y2="1.778" width="0.1524" layer="21"/>
<wire x1="1.524" y1="2.413" x2="1.016" y2="2.413" width="0.1524" layer="21"/>
<wire x1="1.016" y1="2.54" x2="1.016" y2="2.413" width="0.1524" layer="21"/>
<wire x1="1.524" y1="2.54" x2="1.524" y2="2.413" width="0.1524" layer="21"/>
<wire x1="1.905" y1="-1.27" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="2" x="-2.54" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="3" x="0" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="4" x="2.54" y="0" drill="0.9144" shape="long" rot="R90"/>
<pad name="5" x="5.08" y="0" drill="0.9144" shape="long" rot="R90"/>
<text x="-4.572" y="0.9398" size="0.9906" layer="21" ratio="12" rot="R90">1</text>
<text x="-6.096" y="2.9464" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.096" y="-3.8354" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-5.4102" y1="-0.3302" x2="-4.7498" y2="0.3302" layer="51"/>
<rectangle x1="-2.8702" y1="-0.3302" x2="-2.2098" y2="0.3302" layer="51"/>
<rectangle x1="-0.3302" y1="-0.3302" x2="0.3302" y2="0.3302" layer="51"/>
<rectangle x1="2.2098" y1="-0.3302" x2="2.8702" y2="0.3302" layer="51"/>
<rectangle x1="4.7498" y1="-0.3302" x2="5.4102" y2="0.3302" layer="51"/>
</package>
</packages>
</library>
<library name="mc34063">
<description>&lt;b&gt;MC34063: 1.5 A, Step-Up/Down/Inverting Switching Regulator&lt;/b&gt;
&lt;p&gt;&lt;b&gt;Doublecheck before using!&lt;/b&gt;&lt;/p&gt;</description>
<packages>
<package name="SOIC8">
<description>&lt;b&gt;Small Outline IC&lt;/b&gt;</description>
<wire x1="2.4" y1="1.9" x2="2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.9" x2="-2.4" y2="-1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.9" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="-1.4" x2="-2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="-2.4" y1="1.9" x2="2.4" y2="1.9" width="0.2032" layer="51"/>
<wire x1="2.4" y1="-1.4" x2="-2.4" y2="-1.4" width="0.2032" layer="51"/>
<smd name="2" x="-0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="7" x="-0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="1" x="-1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="3" x="0.635" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="4" x="1.905" y="-2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="8" x="-1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="6" x="0.635" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<smd name="5" x="1.905" y="2.6" dx="0.6" dy="2.2" layer="1"/>
<text x="-2.667" y="-1.905" size="1.27" layer="25" rot="R90">&gt;NAME</text>
<text x="3.937" y="-1.905" size="1.27" layer="27" rot="R90">&gt;VALUE</text>
<rectangle x1="-2.15" y1="-3.1" x2="-1.66" y2="-2" layer="51"/>
<rectangle x1="-0.88" y1="-3.1" x2="-0.39" y2="-2" layer="51"/>
<rectangle x1="0.39" y1="-3.1" x2="0.88" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="-3.1" x2="2.15" y2="-2" layer="51"/>
<rectangle x1="1.66" y1="2" x2="2.15" y2="3.1" layer="51"/>
<rectangle x1="0.39" y1="2" x2="0.88" y2="3.1" layer="51"/>
<rectangle x1="-0.88" y1="2" x2="-0.39" y2="3.1" layer="51"/>
<rectangle x1="-2.15" y1="2" x2="-1.66" y2="3.1" layer="51"/>
</package>
</packages>
</library>
<library name="display-kingbright">
<description>&lt;b&gt;KINGBRIGHT Numeric Displays&lt;/b&gt;&lt;p&gt;
&lt;author&gt;librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="BX56-12">
<description>&lt;b&gt;14.22mm (0.56INCH) THREE DIGIT NUMERIC DISPLAY&lt;/b&gt;&lt;p&gt;
Source: http://www.kingbright.com .. BA56-11EWA(Ver1189474895.pdf</description>
<wire x1="-18.675" y1="9.4" x2="18.7" y2="9.4" width="0.2032" layer="21"/>
<wire x1="18.7" y1="9.4" x2="18.7" y2="-9.4" width="0.2032" layer="21"/>
<wire x1="18.7" y1="-9.4" x2="-18.675" y2="-9.4" width="0.2032" layer="21"/>
<wire x1="-18.675" y1="-9.4" x2="-18.675" y2="9.4" width="0.2032" layer="21"/>
<circle x="-7.6017" y="-6.5231" radius="0.7305" width="0" layer="21"/>
<circle x="5.0233" y="-6.5731" radius="0.7305" width="0" layer="21"/>
<circle x="17.6983" y="-6.4481" radius="0.7305" width="0" layer="21"/>
<pad name="1" x="-6.35" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="2" x="-3.81" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="3" x="-1.27" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="4" x="1.27" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="5" x="3.81" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="6" x="6.35" y="-7.62" drill="0.8" diameter="1.4224"/>
<pad name="7" x="6.35" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<pad name="8" x="3.81" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<pad name="9" x="1.27" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<pad name="10" x="-1.27" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<pad name="11" x="-3.81" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<pad name="12" x="-6.35" y="7.62" drill="0.8" diameter="1.4224" rot="R180"/>
<text x="-18.415" y="10.16" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.715" y="10.16" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<polygon width="0.3976" layer="21" spacing="1.2428">
<vertex x="-13.5445" y="5.9694"/>
<vertex x="-13.3733" y="6.948"/>
<vertex x="-9.3537" y="6.948"/>
<vertex x="-9.476" y="5.9694"/>
</polygon>
<vertex x="-9.7632" y="1.0329"/>
<vertex x="-8.7296" y="6.9034"/>
<vertex x="-8.427" y="6.9114" curve="-104.731141"/>
<vertex x="-7.8092" y="6.071"/>
<vertex x="-8.8399" y="0.4893"/>
<vertex x="-9.3047" y="0.4893"/>
</polygon>
<vertex x="-15.0369" y="1.0764"/>
<vertex x="-14.0093" y="6.948"/>
<vertex x="-14.2785" y="6.948" curve="77.705866"/>
<vertex x="-15.1592" y="6.2385"/>
<vertex x="-16.1622" y="0.4893"/>
<vertex x="-15.5995" y="0.4893"/>
</polygon>
<vertex x="-15.1347" y="0.0245"/>
<vertex x="-14.5231" y="0.6361"/>
<vertex x="-10.3078" y="0.6361"/>
<vertex x="-9.9408" y="0.1223"/>
<vertex x="-10.3812" y="-0.3425"/>
<vertex x="-14.7677" y="-0.3425"/>
</polygon>
<vertex x="-11.4821" y="-5.7003"/>
<vertex x="-11.6533" y="-6.6789"/>
<vertex x="-15.6729" y="-6.6789"/>
<vertex x="-15.5506" y="-5.7003"/>
</polygon>
<vertex x="-15.3368" y="-0.7149"/>
<vertex x="-16.2971" y="-6.6343"/>
<vertex x="-16.5997" y="-6.6423" curve="-104.72259"/>
<vertex x="-17.2174" y="-5.8019"/>
<vertex x="-16.2601" y="-0.1713"/>
<vertex x="-15.7953" y="-0.1713"/>
</polygon>
<vertex x="-10.0387" y="-0.9541"/>
<vertex x="-11.0173" y="-6.6789"/>
<vertex x="-10.7482" y="-6.6789" curve="77.701982"/>
<vertex x="-9.8674" y="-5.9694"/>
<vertex x="-8.9378" y="-0.4159"/>
<vertex x="-9.5005" y="-0.4159"/>
</polygon>
<polygon width="0.3976" layer="51" spacing="1.2428">
<vertex x="-1.0445" y="5.9694"/>
<vertex x="-0.8733" y="6.948"/>
<vertex x="3.1463" y="6.948"/>
<vertex x="3.024" y="5.9694"/>
</polygon>
<vertex x="2.7368" y="1.0329"/>
<vertex x="3.7704" y="6.9034"/>
<vertex x="4.073" y="6.9114" curve="-104.731141"/>
<vertex x="4.6908" y="6.071"/>
<vertex x="3.6601" y="0.4893"/>
<vertex x="3.1953" y="0.4893"/>
</polygon>
<vertex x="-2.5369" y="1.0764"/>
<vertex x="-1.5093" y="6.948"/>
<vertex x="-1.7785" y="6.948" curve="77.705866"/>
<vertex x="-2.6592" y="6.2385"/>
<vertex x="-3.6622" y="0.4893"/>
<vertex x="-3.0995" y="0.4893"/>
</polygon>
<vertex x="-2.6347" y="0.0245"/>
<vertex x="-2.0231" y="0.6361"/>
<vertex x="2.1922" y="0.6361"/>
<vertex x="2.5592" y="0.1223"/>
<vertex x="2.1188" y="-0.3425"/>
<vertex x="-2.2677" y="-0.3425"/>
</polygon>
<vertex x="1.0179" y="-5.7003"/>
<vertex x="0.8467" y="-6.6789"/>
<vertex x="-3.1729" y="-6.6789"/>
<vertex x="-3.0506" y="-5.7003"/>
</polygon>
<vertex x="-2.8368" y="-0.7149"/>
<vertex x="-3.7971" y="-6.6343"/>
<vertex x="-4.0997" y="-6.6423" curve="-104.72259"/>
<vertex x="-4.7174" y="-5.8019"/>
<vertex x="-3.7601" y="-0.1713"/>
<vertex x="-3.2953" y="-0.1713"/>
</polygon>
<vertex x="2.4613" y="-0.9541"/>
<vertex x="1.4827" y="-6.6789"/>
<vertex x="1.7518" y="-6.6789" curve="77.701982"/>
<vertex x="2.6326" y="-5.9694"/>
<vertex x="3.5622" y="-0.4159"/>
<vertex x="2.9995" y="-0.4159"/>
</polygon>
<vertex x="11.4555" y="5.9694"/>
<vertex x="11.6267" y="6.948"/>
<vertex x="15.6463" y="6.948"/>
<vertex x="15.524" y="5.9694"/>
</polygon>
<vertex x="15.2368" y="1.0329"/>
<vertex x="16.2704" y="6.9034"/>
<vertex x="16.573" y="6.9114" curve="-104.731141"/>
<vertex x="17.1908" y="6.071"/>
<vertex x="16.1601" y="0.4893"/>
<vertex x="15.6953" y="0.4893"/>
</polygon>
<vertex x="9.9631" y="1.0764"/>
<vertex x="10.9907" y="6.948"/>
<vertex x="10.7215" y="6.948" curve="77.705866"/>
<vertex x="9.8408" y="6.2385"/>
<vertex x="8.8378" y="0.4893"/>
<vertex x="9.4005" y="0.4893"/>
</polygon>
<vertex x="9.8653" y="0.0245"/>
<vertex x="10.4769" y="0.6361"/>
<vertex x="14.6922" y="0.6361"/>
<vertex x="15.0592" y="0.1223"/>
<vertex x="14.6188" y="-0.3425"/>
<vertex x="10.2323" y="-0.3425"/>
</polygon>
<vertex x="13.5179" y="-5.7003"/>
<vertex x="13.3467" y="-6.6789"/>
<vertex x="9.3271" y="-6.6789"/>
<vertex x="9.4494" y="-5.7003"/>
</polygon>
<vertex x="9.6632" y="-0.7149"/>
<vertex x="8.7029" y="-6.6343"/>
<vertex x="8.4003" y="-6.6423" curve="-104.72259"/>
<vertex x="7.7826" y="-5.8019"/>
<vertex x="8.7399" y="-0.1713"/>
<vertex x="9.2047" y="-0.1713"/>
</polygon>
<vertex x="14.9613" y="-0.9541"/>
<vertex x="13.9827" y="-6.6789"/>
<vertex x="14.2518" y="-6.6789" curve="77.701982"/>
<vertex x="15.1326" y="-5.9694"/>
<vertex x="16.0622" y="-0.4159"/>
<vertex x="15.4995" y="-0.4159"/>
</polygon>
</package>
</packages>
</library>
<library name="con-lstb">
<description>&lt;b&gt;Pin Headers&lt;/b&gt;&lt;p&gt;
Naming:&lt;p&gt;
MA = male&lt;p&gt;
# contacts - # rows&lt;p&gt;
W = angled&lt;p&gt;
<packages>
<package name="MA05-1">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<wire x1="-5.715" y1="1.27" x2="-4.445" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="1.27" x2="-3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="-0.635" x2="-4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="0.635" x2="-3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="1.27" x2="-1.905" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="1.27" x2="-1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.905" y1="-1.27" x2="-3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-3.175" y1="-1.27" x2="-3.81" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="0.635" x2="-6.35" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="1.27" x2="-6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-6.35" y1="-0.635" x2="-5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-1.27" x2="-5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="-1.27" x2="-1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.27" x2="3.175" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="1.27" x2="3.81" y2="0.635" width="0.1524" layer="21"/>
<wire x1="3.81" y1="-0.635" x2="3.175" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0.635" x2="4.445" y2="1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="1.27" x2="5.715" y2="1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="1.27" x2="6.35" y2="0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="0.635" x2="6.35" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="6.35" y1="-0.635" x2="5.715" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.715" y1="-1.27" x2="4.445" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="4.445" y1="-1.27" x2="3.81" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.905" y1="1.27" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.175" y1="-1.27" x2="1.905" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="2" x="-2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="3" x="0" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="4" x="2.54" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="5" x="5.08" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-6.35" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.715" y="-2.921" size="1.27" layer="21" ratio="10">1</text>
<text x="4.445" y="1.651" size="1.27" layer="21" ratio="10">5</text>
<text x="-2.54" y="-2.921" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-2.794" y1="-0.254" x2="-2.286" y2="0.254" layer="51"/>
<rectangle x1="-5.334" y1="-0.254" x2="-4.826" y2="0.254" layer="51"/>
<rectangle x1="-0.254" y1="-0.254" x2="0.254" y2="0.254" layer="51"/>
<rectangle x1="4.826" y1="-0.254" x2="5.334" y2="0.254" layer="51"/>
<rectangle x1="2.286" y1="-0.254" x2="2.794" y2="0.254" layer="51"/>
</package>
</packages>
</library>
<library name="holes">
<description>&lt;b&gt;Mounting Holes and Pads&lt;/b&gt;&lt;p&gt;
<packages>
<package name="3,2">
<description>&lt;b&gt;MOUNTING HOLE&lt;/b&gt; 3.2 mm with drill center</description>
<wire x1="-2.159" y1="0" x2="0" y2="-2.159" width="2.4892" layer="51" curve="90" cap="flat"/>
<wire x1="0" y1="2.159" x2="2.159" y2="0" width="2.4892" layer="51" curve="-90" cap="flat"/>
<circle x="0" y="0" radius="3.429" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="0.762" width="0.4572" layer="51"/>
<circle x="0" y="0" radius="3.048" width="2.032" layer="39"/>
<circle x="0" y="0" radius="3.048" width="2.032" layer="43"/>
<circle x="0" y="0" radius="3.048" width="2.032" layer="40"/>
<circle x="0" y="0" radius="3.048" width="2.032" layer="41"/>
<circle x="0" y="0" radius="3.048" width="2.032" layer="42"/>
<circle x="0" y="0" radius="1.7" width="0.2032" layer="21"/>
<hole x="0" y="0" drill="3.2"/>
</package>
</packages>
</library>
<library name="transistor-fet">
<description>&lt;b&gt;Field Effect Transistors&lt;/b&gt;&lt;p&gt;
&lt;p&gt;
Symbols changed according to IEC617&lt;p&gt;
All types, packages and assignment to symbols and pins checked&lt;p&gt;
Package outlines partly checked&lt;p&gt;
&lt;p&gt;
JFET = junction FET&lt;p&gt;
IGBT-x = insulated gate bipolar transistor&lt;p&gt;
x=N: NPN; x=P: PNP&lt;p&gt;
IGFET-mc-nnn; (IGFET=insulated gate field effect transistor)&lt;P&gt;
m=D: depletion mode (Verdr&amp;auml;ngungstyp)&lt;p&gt;
m=E: enhancement mode (Anreicherungstyp)&lt;p&gt;
c: N=N-channel; P=P-Channel&lt;p&gt;
GDSB: gate, drain, source, bulk&lt;p&gt;
&lt;p&gt;
by R. Vogg  15.March.2002</description>
<packages>
<package name="TO220">
<description>&lt;b&gt;TO 220 horizontal&lt;/b&gt;</description>
<wire x1="-5.207" y1="-1.27" x2="5.207" y2="-1.27" width="0.127" layer="21"/>
<wire x1="5.207" y1="14.605" x2="-5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="5.207" y1="-1.27" x2="5.207" y2="11.176" width="0.127" layer="21"/>
<wire x1="5.207" y1="11.176" x2="4.318" y2="11.176" width="0.127" layer="21"/>
<wire x1="4.318" y1="11.176" x2="4.318" y2="12.7" width="0.127" layer="21"/>
<wire x1="4.318" y1="12.7" x2="5.207" y2="12.7" width="0.127" layer="21"/>
<wire x1="5.207" y1="12.7" x2="5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="11.176" width="0.127" layer="21"/>
<wire x1="-5.207" y1="11.176" x2="-4.318" y2="11.176" width="0.127" layer="21"/>
<wire x1="-4.318" y1="11.176" x2="-4.318" y2="12.7" width="0.127" layer="21"/>
<wire x1="-4.318" y1="12.7" x2="-5.207" y2="12.7" width="0.127" layer="21"/>
<wire x1="-5.207" y1="12.7" x2="-5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<circle x="0" y="11.176" radius="1.8034" width="0.127" layer="21"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="42"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="43"/>
<pad name="1" x="-2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<text x="-3.81" y="5.207" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.937" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="7.874" size="0.9906" layer="21" ratio="12">A17,5mm</text>
<text x="-3.175" y="0" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="0" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="0" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="2.159" y1="-4.699" x2="2.921" y2="-4.064" layer="21"/>
<rectangle x1="-0.381" y1="-4.699" x2="0.381" y2="-4.064" layer="21"/>
<rectangle x1="-2.921" y1="-4.699" x2="-2.159" y2="-4.064" layer="21"/>
<rectangle x1="-3.175" y1="-4.064" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="-0.635" y1="-4.064" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-4.064" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="-2.921" y1="-6.604" x2="-2.159" y2="-4.699" layer="51"/>
<rectangle x1="-0.381" y1="-6.604" x2="0.381" y2="-4.699" layer="51"/>
<rectangle x1="2.159" y1="-6.604" x2="2.921" y2="-4.699" layer="51"/>
<hole x="0" y="11.176" drill="3.302"/>
</package>
</packages>
</library>
<library name="potsaj">
<description>&lt;b&gt;Potentiometers&lt;/b&gt;&lt;p&gt;
Beckman, Copal, Piher, Spectrol, Schukat&lt;p&gt;
<packages>
<package name="3RP/1610N">
<description>&lt;b&gt;16mm Potentiometer&lt;/b&gt; one level&lt;p&gt;
Source: http://www.alphapotentiometers.net/html/16mm_pot_2.html</description>
<wire x1="-7.93" y1="-1.26" x2="8" y2="-1.26" width="0.2032" layer="21"/>
<wire x1="-8" y1="3.4" x2="8" y2="3.4" width="0.2032" layer="21"/>
<wire x1="-7.93" y1="-1.26" x2="-8" y2="3.4" width="0.2032" layer="21"/>
<wire x1="8" y1="-1.26" x2="8" y2="3.4" width="0.2032" layer="21"/>
<pad name="1" x="-5" y="0" drill="1.2" diameter="2.1844"/>
<pad name="2" x="0" y="0" drill="1.2" diameter="2.1844"/>
<pad name="3" x="5" y="0" drill="1.2" diameter="2.1844"/>
<text x="8.745" y="0.715" size="1.27" layer="25">&gt;NAME</text>
<text x="8.825" y="-1.46" size="1.27" layer="27">&gt;VALUE</text>
<circle x="0" y="12" radius="8" width="0.127" layer="21"/>
<circle x="0" y="12" radius="3.150871875" width="0.127" layer="21"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="AutoGrid" value="1"/>
<param name="Efforts" value="0"/>
<param name="TopRouterVariant" value="1"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="U$1" library="NANO" package="NANO" value="NANO" x="77" y="61" locked="yes" rot="MR270"/>
<element name="U$2" library="max7219" package="SO24L" value="MAX7219CWG" x="70" y="20" rot="MR180"/>
<element name="R3" library="rcl" package="R1206" value="100" x="56" y="76.3" rot="MR0"/>
<element name="J1" library="con-amp" package="10X02MTA" value="Páka csatlakozó" x="48.43" y="78.5" rot="R180"/>
<element name="J2" library="con-amp" package="10X02MTA" value="20VDC" x="43" y="78.5" smashed="yes" rot="R180">
<attribute name="NAME" x="45.6162" y="81.7512" size="1.27" layer="25" rot="R180"/>
<attribute name="VALUE" x="45.5461" y="76.3491" size="1.27" layer="27" rot="R180"/>
</element>
<element name="SL1" library="con-amp-quick" package="05P" value="MAX31855" x="71" y="62">
<attribute name="OC_NEWARK" value="unknown" x="71" y="62" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="71" y="62" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="" x="71" y="62" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="71" y="62" size="1.778" layer="27" display="off"/>
</element>
<element name="IC1" library="mc34063" package="SOIC8" value="MC34063AD" x="47.276840625" y="64.17094375" rot="MR0"/>
<element name="R6" library="rcl" package="R2512" value="0,33" x="49.4392875" y="70.219071875" rot="MR180"/>
<element name="C3" library="rcl" package="E2,5-6" value="100u/25V" x="43" y="73.500484375" rot="R180"/>
<element name="R7" library="rcl" package="R1206" value="1k" x="41.484528125" y="68.04555" rot="MR180"/>
<element name="R8" library="rcl" package="R1206" value="6.2k" x="41.503640625" y="65.53478125" rot="MR180"/>
<element name="D3" library="diode" package="DO41-7.6" value="1N5819" x="42.05121875" y="58.36399375" rot="R90"/>
<element name="C4" library="rcl" package="C1206" value="470p" x="44.693246875" y="58.04075625" rot="MR0"/>
<element name="L1" library="rcl" package="6000-XXXX-RC" value="220u" x="42.10618125" y="48.959865625" rot="R270"/>
<element name="C5" library="rcl" package="E3,5-10" value="470u/25V" x="51.954415625" y="48.217103125" rot="R90"/>
<element name="L2" library="rcl" package="0411V" value="1u" x="59.234571875" y="49.013290625" rot="R90"/>
<element name="C6" library="rcl" package="E2,5-6" value="100u/25V" x="59.23910625" y="58.315175" rot="R90"/>
<element name="LED2" library="display-kingbright" package="BX56-12" value="BC56-12EWA" x="67" y="20" locked="yes">
<attribute name="OC_NEWARK" value="unknown" x="67" y="20" size="1.778" layer="27" display="off"/>
<attribute name="MF" value="" x="67" y="20" size="1.778" layer="27" display="off"/>
<attribute name="MPN" value="" x="67" y="20" size="1.778" layer="27" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="67" y="20" size="1.778" layer="27" display="off"/>
</element>
<element name="R9" library="rcl" package="R1206" value="20k" x="59.4" y="18.9" rot="MR90"/>
<element name="C7" library="rcl" package="C1206" value="0.1u" x="56.5" y="16.1" rot="MR270"/>
<element name="R1" library="rcl" package="R1206" value="4,7k" x="56" y="74" rot="MR0"/>
<element name="R2" library="potsaj" package="3RP/1610N" value="5k" x="29.8" y="51.6"/>
<element name="Q2" library="transistor-fet" package="TO220" value="IRL540" x="49.7" y="68.7" rot="R180"/>
<element name="SV1" library="con-lstb" package="MA05-1" value="" x="85" y="33" locked="yes" rot="R180">
<attribute name="OC_FARNELL" value="unknown" x="85" y="33" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="85" y="33" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_NEWARK" value="unknown" x="85" y="33" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="85" y="33" size="1.778" layer="27" rot="R180" display="off"/>
</element>
<element name="H1" library="holes" package="3,2" value="MOUNT-HOLE3.2" x="24" y="36" locked="yes"/>
<element name="H2" library="holes" package="3,2" value="MOUNT-HOLE3.2" x="24" y="4" locked="yes" rot="R180"/>
<element name="H3" library="holes" package="3,2" value="MOUNT-HOLE3.2" x="96" y="36" locked="yes" rot="R180"/>
<element name="H4" library="holes" package="3,2" value="MOUNT-HOLE3.2" x="96" y="4" locked="yes"/>
<element name="H5" library="holes" package="3,2" value="MOUNT-HOLE3.2" x="24" y="78" rot="R90"/>
<element name="H6" library="holes" package="3,2" value="MOUNT-HOLE3.2" x="24" y="46" rot="R90"/>
<element name="H7" library="holes" package="3,2" value="MOUNT-HOLE3.2" x="96" y="78"/>
<element name="H8" library="holes" package="3,2" value="MOUNT-HOLE3.2" x="96" y="46"/>
<element name="SV2" library="con-lstb" package="MA05-1" value="" x="85" y="75" locked="yes" rot="R180">
<attribute name="OC_NEWARK" value="unknown" x="85" y="75" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MPN" value="" x="85" y="75" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="MF" value="" x="85" y="75" size="1.778" layer="27" rot="R180" display="off"/>
<attribute name="OC_FARNELL" value="unknown" x="85" y="75" size="1.778" layer="27" rot="R180" display="off"/>
</element>
</elements>
<signals>
<signal name="GND">
<contactref element="U$1" pad="GND"/>
<contactref element="U$1" pad="GND2"/>
<contactref element="SL1" pad="2"/>
<contactref element="C3" pad="-"/>
<contactref element="R7" pad="1"/>
<contactref element="IC1" pad="4"/>
<contactref element="D3" pad="A"/>
<contactref element="C4" pad="2"/>
<contactref element="C5" pad="-"/>
<contactref element="C6" pad="-"/>
<contactref element="R1" pad="1"/>
<contactref element="R2" pad="1"/>
<contactref element="J2" pad="1"/>
<contactref element="Q2" pad="3"/>
<polygon width="0.254" layer="16" isolate="0.6096">
<vertex x="20" y="82"/>
<vertex x="100" y="82"/>
<vertex x="100" y="42"/>
<vertex x="20" y="42"/>
</polygon>
<polygon width="0.4064" layer="1" isolate="0.4064">
</polygon>
<contactref element="SV2" pad="4"/>
</signal>
<signal name="N$2">
<contactref element="U$1" pad="D2"/>
<contactref element="R3" pad="1"/>
<wire x1="69.38" y1="68.62" x2="69.39513125" y2="68.582715625" width="0.4064" layer="16"/>
<wire x1="69.4304" y1="77" x2="69.3833875" y2="77" width="0.4064" layer="16"/>
<via x="69.3833875" y="77" extent="1-16" drill="0.6" shape="square"/>
<wire x1="69.3833875" y1="77" x2="69.383384375" y2="75.736434375" width="0.4064" layer="1"/>
<wire x1="69.383384375" y1="75.736434375" x2="69.383384375" y2="72.14974375" width="0.4064" layer="1"/>
<via x="69.383384375" y="72.14974375" extent="1-16" drill="0.6" shape="square"/>
<wire x1="69.383384375" y1="72.14974375" x2="69.38" y2="72.146359375" width="0.4064" layer="16"/>
<wire x1="69.38" y1="72.146359375" x2="69.38" y2="68.62" width="0.4064" layer="16"/>
<wire x1="57.422" y1="76.3" x2="58.1" y2="76.3" width="0.4064" layer="16"/>
<wire x1="58.1" y1="76.3" x2="58.1" y2="77" width="0.4064" layer="16"/>
<wire x1="58.1" y1="77" x2="69.3833875" y2="77" width="0.4064" layer="16"/>
</signal>
<signal name="N$4">
<contactref element="R3" pad="2"/>
<contactref element="Q2" pad="1"/>
<contactref element="R1" pad="2"/>
<wire x1="54.578" y1="76.3" x2="53.8" y2="76.2" width="0.4064" layer="16"/>
<wire x1="53.8" y1="76.2" x2="53.8" y2="75.05" width="0.4064" layer="16"/>
<wire x1="53.8" y1="75.05" x2="53.8" y2="74.1" width="0.4064" layer="16"/>
<wire x1="53.8" y1="74.1" x2="54.578" y2="74.1" width="0.4064" layer="16"/>
<wire x1="54.578" y1="74.1" x2="54.578" y2="74" width="0.4064" layer="16"/>
<wire x1="52.24" y1="75.05" x2="53.8" y2="75.05" width="0.4064" layer="16"/>
</signal>
<signal name="N$9">
<contactref element="J1" pad="2"/>
<contactref element="Q2" pad="2"/>
<wire x1="49.7" y1="78.5" x2="49.7" y2="75.05" width="1.27" layer="16"/>
</signal>
<signal name="N$6">
<contactref element="U$1" pad="A1"/>
<contactref element="R2" pad="2"/>
<wire x1="29.8" y1="51.6" x2="29.7970875" y2="51.61598125" width="0.4064" layer="1"/>
<via x="29.7970875" y="51.61598125" extent="1-16" drill="0.6" shape="square"/>
<wire x1="29.7970875" y1="51.61598125" x2="29.7" y2="51.51889375" width="0.4064" layer="16"/>
<wire x1="29.7" y1="51.51889375" x2="29.7" y2="47.3" width="0.4064" layer="16"/>
<wire x1="29.7" y1="47.3" x2="33.9" y2="43.1" width="0.4064" layer="16"/>
<wire x1="33.9" y1="43.1" x2="80" y2="43.1" width="0.4064" layer="16"/>
<wire x1="80" y1="43.1" x2="84.62" y2="47.72" width="0.4064" layer="16"/>
<wire x1="84.62" y1="47.72" x2="84.62" y2="53.38" width="0.4064" layer="16"/>
</signal>
<signal name="N$7">
<contactref element="U$1" pad="D3"/>
<contactref element="SL1" pad="3"/>
<wire x1="71.92" y1="68.62" x2="71.92" y2="67" width="0.4064" layer="16"/>
<wire x1="71" y1="63.5" x2="71" y2="62" width="0.4064" layer="16"/>
<wire x1="71.92" y1="67" x2="71" y2="63.5" width="0.4064" layer="16"/>
</signal>
<signal name="N$10">
<contactref element="SL1" pad="4"/>
<contactref element="U$1" pad="D4"/>
<wire x1="74.46" y1="68.62" x2="74.46" y2="67" width="0.4064" layer="16"/>
<wire x1="73.54" y1="63.5" x2="73.54" y2="62" width="0.4064" layer="16"/>
<wire x1="74.46" y1="67" x2="73.54" y2="63.5" width="0.4064" layer="16"/>
</signal>
<signal name="N$11">
<contactref element="U$1" pad="D5"/>
<contactref element="SL1" pad="5"/>
<wire x1="77" y1="68.62" x2="77" y2="67" width="0.4064" layer="16"/>
<wire x1="76" y1="63.5" x2="76" y2="62.08" width="0.4064" layer="16"/>
<wire x1="76" y1="62.08" x2="76.08" y2="62" width="0.4064" layer="16"/>
<wire x1="77" y1="67" x2="76" y2="63.5" width="0.4064" layer="16"/>
</signal>
<signal name="N$12">
<contactref element="IC1" pad="7"/>
<contactref element="R6" pad="2"/>
<contactref element="IC1" pad="8"/>
<contactref element="IC1" pad="1"/>
<wire x1="49.181840625" y1="66.77094375" x2="47.911840625" y2="66.77094375" width="0.5" layer="16"/>
<wire x1="49.181840625" y1="61.57094375" x2="49.181840625" y2="66.77094375" width="0.4064" layer="16"/>
<wire x1="52.2392875" y1="70.219071875" x2="52.3" y2="70.219071875" width="0.4064" layer="16"/>
<wire x1="52.3" y1="70.219071875" x2="52.3" y2="68.7" width="0.4064" layer="16"/>
<wire x1="52.3" y1="68.7" x2="50.37094375" y2="66.77094375" width="0.4064" layer="16"/>
<wire x1="50.37094375" y1="66.77094375" x2="49.181840625" y2="66.77094375" width="0.4064" layer="16"/>
</signal>
<signal name="N$13">
<contactref element="IC1" pad="5"/>
<contactref element="R7" pad="2"/>
<contactref element="R8" pad="2"/>
<wire x1="42.906528125" y1="68.04555" x2="42.952078125" y2="68" width="0.4064" layer="16"/>
<wire x1="42.952078125" y1="68" x2="43.6" y2="68" width="0.4064" layer="16"/>
<wire x1="43.6" y1="68" x2="43.6" y2="66.8" width="0.4064" layer="16"/>
<wire x1="43.6" y1="66.8" x2="43.6" y2="65.6" width="0.4064" layer="16"/>
<wire x1="43.6" y1="65.6" x2="43.53478125" y2="65.53478125" width="0.4064" layer="16"/>
<wire x1="43.53478125" y1="65.53478125" x2="42.925640625" y2="65.53478125" width="0.4064" layer="16"/>
<wire x1="45.371840625" y1="66.77094375" x2="45.342784375" y2="66.8" width="0.4064" layer="16"/>
<wire x1="45.342784375" y1="66.8" x2="43.6" y2="66.8" width="0.4064" layer="16"/>
</signal>
<signal name="N$14">
<contactref element="IC1" pad="2"/>
<contactref element="D3" pad="C"/>
<contactref element="L1" pad="1"/>
<wire x1="42.05121875" y1="54.55399375" x2="42.10618125" y2="54.55399375" width="0.4064" layer="16"/>
<wire x1="42.10618125" y1="54.55399375" x2="42.10618125" y2="51.459865625" width="0.4064" layer="16"/>
<wire x1="47.911840625" y1="61.57094375" x2="47.911840625" y2="57.011840625" width="0.4064" layer="16"/>
<wire x1="47.911840625" y1="57.011840625" x2="45.5" y2="54.6" width="0.4064" layer="16"/>
<wire x1="45.5" y1="54.6" x2="42.097225" y2="54.6" width="0.4064" layer="16"/>
<wire x1="42.097225" y1="54.6" x2="42.05121875" y2="54.55399375" width="0.4064" layer="16"/>
</signal>
<signal name="N$15">
<contactref element="IC1" pad="3"/>
<contactref element="C4" pad="1"/>
<wire x1="46.641840625" y1="61.57094375" x2="46.641840625" y2="58.158159375" width="0.4064" layer="16"/>
<wire x1="46.641840625" y1="58.158159375" x2="46.7" y2="58.1" width="0.4064" layer="16"/>
<wire x1="46.7" y1="58.1" x2="46.152490625" y2="58.1" width="0.4064" layer="16"/>
<wire x1="46.152490625" y1="58.1" x2="46.093246875" y2="58.04075625" width="0.4064" layer="16"/>
</signal>
<signal name="N$16">
<contactref element="R8" pad="1"/>
<contactref element="L1" pad="2"/>
<contactref element="C5" pad="+"/>
<contactref element="L2" pad="1"/>
<wire x1="59.234571875" y1="46.473290625" x2="51.954415625" y2="46.473290625" width="0.4064" layer="16"/>
<wire x1="51.954415625" y1="46.473290625" x2="51.954415625" y2="46.439103125" width="0.4064" layer="16"/>
<wire x1="51.954415625" y1="46.439103125" x2="42.10618125" y2="46.439103125" width="0.4064" layer="16"/>
<wire x1="42.10618125" y1="46.439103125" x2="42.10618125" y2="46.459865625" width="0.4064" layer="16"/>
<wire x1="40.081640625" y1="65.53478125" x2="39.1" y2="65.53478125" width="0.4064" layer="16"/>
<wire x1="39.1" y1="65.53478125" x2="39.1" y2="48.4" width="0.4064" layer="16"/>
<wire x1="39.1" y1="48.4" x2="40.9" y2="46.6" width="0.4064" layer="16"/>
<wire x1="40.9" y1="46.6" x2="41.966046875" y2="46.6" width="0.4064" layer="16"/>
<wire x1="41.966046875" y1="46.6" x2="42.10618125" y2="46.459865625" width="0.4064" layer="16"/>
</signal>
<signal name="+24V">
<contactref element="IC1" pad="6"/>
<contactref element="C3" pad="+"/>
<contactref element="R6" pad="1"/>
<contactref element="J1" pad="1"/>
<contactref element="J2" pad="2"/>
<wire x1="47.16" y1="78.5" x2="44.3" y2="78.5" width="1.4224" layer="16"/>
<wire x1="44.27" y1="78.5" x2="44.3" y2="78.5" width="0.4064" layer="16"/>
<wire x1="44.3" y1="78.5" x2="44.27" y2="73.500484375" width="1.016" layer="16"/>
<wire x1="46.641840625" y1="66.77094375" x2="46.6392875" y2="66.773496875" width="0.4064" layer="16"/>
<wire x1="46.6392875" y1="66.773496875" x2="46.6392875" y2="70.219071875" width="0.4064" layer="16"/>
<wire x1="46.6392875" y1="70.219071875" x2="46.558359375" y2="70.3" width="0.4064" layer="16"/>
<wire x1="46.558359375" y1="70.3" x2="45.9" y2="70.3" width="0.4064" layer="16"/>
<wire x1="45.9" y1="70.3" x2="44.27" y2="71.93" width="0.4064" layer="16"/>
<wire x1="44.27" y1="71.93" x2="44.27" y2="73.500484375" width="0.4064" layer="16"/>
</signal>
<signal name="+10V">
<contactref element="L2" pad="2"/>
<contactref element="C6" pad="+"/>
<contactref element="U$1" pad="VIN"/>
<wire x1="59.234571875" y1="50.283290625" x2="59.234571875" y2="53.365428125" width="0.4064" layer="16"/>
<wire x1="59.234571875" y1="53.365428125" x2="59.22" y2="53.38" width="0.4064" layer="16"/>
<wire x1="59.23910625" y1="57.045175" x2="59.23910625" y2="53.39910625" width="0.4064" layer="16"/>
<wire x1="59.23910625" y1="53.39910625" x2="59.22" y2="53.38" width="0.4064" layer="16"/>
</signal>
<signal name="+5V">
<contactref element="U$1" pad="5V"/>
<contactref element="R2" pad="3"/>
<wire x1="66.9" y1="53.33665625" x2="66.84" y2="53.38" width="0.4064" layer="16"/>
<wire x1="34.8" y1="51.6" x2="34.786559375" y2="51.563921875" width="0.4064" layer="1"/>
<contactref element="SV2" pad="5"/>
<via x="34.786559375" y="51.563921875" extent="1-16" drill="0.6" shape="square"/>
<wire x1="34.7" y1="51.4773625" x2="34.786559375" y2="51.563921875" width="0.4064" layer="16"/>
<wire x1="66.84" y1="53.38" x2="66.8" y2="53.34" width="0.4064" layer="16"/>
<wire x1="66.8" y1="53.34" x2="66.8" y2="46.3" width="0.4064" layer="16"/>
<wire x1="66.8" y1="46.3" x2="64.7" y2="44.2" width="0.4064" layer="16"/>
<wire x1="64.7" y1="44.2" x2="36.2" y2="44.2" width="0.4064" layer="16"/>
<wire x1="36.2" y1="44.2" x2="34.786559375" y2="45.613440625" width="0.4064" layer="16"/>
<wire x1="34.786559375" y1="45.613440625" x2="34.786559375" y2="51.563921875" width="0.4064" layer="16"/>
<wire x1="66.84" y1="53.38" x2="66.8" y2="53.42" width="0.4064" layer="16"/>
<wire x1="66.8" y1="53.42" x2="66.8" y2="55.6" width="0.4064" layer="16"/>
<wire x1="66.8" y1="55.6" x2="55.4" y2="67" width="0.4064" layer="16"/>
<wire x1="55.4" y1="67" x2="55.4" y2="70" width="0.4064" layer="16"/>
<wire x1="55.4" y1="70" x2="56.2" y2="70.8" width="0.4064" layer="16"/>
<wire x1="62.4" y1="74.6" x2="79.9" y2="74.6" width="0.4064" layer="16"/>
<wire x1="79.9" y1="74.6" x2="80.1" y2="75" width="0.4064" layer="16"/>
<wire x1="80.1" y1="75" x2="79.92" y2="75" width="0.4064" layer="16"/>
<wire x1="79.9" y1="75" x2="79.92" y2="75" width="0.4064" layer="16"/>
<wire x1="56.2" y1="70.8" x2="58.5" y2="70.8" width="0.4064" layer="16"/>
<wire x1="58.5" y1="70.8" x2="62.3" y2="74.6" width="0.4064" layer="16"/>
<wire x1="62.3" y1="74.6" x2="62.4" y2="74.6" width="0.4064" layer="16"/>
</signal>
<signal name="N$17">
<contactref element="LED2" pad="11"/>
<contactref element="U$2" pad="14"/>
<wire x1="63.19" y1="27.62" x2="63.1" y2="27.71" width="0.4064" layer="16"/>
<via x="83.92348125" y="27.781696875" extent="1-16" drill="0.6" shape="square"/>
<wire x1="83.92348125" y1="27.781696875" x2="84.0114" y2="27.29814375" width="0.4064" layer="1"/>
<wire x1="84.0114" y1="27.29814375" x2="84.0114" y2="17.03363125" width="0.4064" layer="1"/>
<via x="84.0114" y="17.03363125" extent="1-16" drill="0.6" shape="square"/>
<wire x1="84.0114" y1="17.03363125" x2="84.0114" y2="17.063196875" width="0.4064" layer="16"/>
<wire x1="84.0114" y1="17.063196875" x2="83.747634375" y2="17" width="0.4064" layer="16"/>
<wire x1="83.752865625" y1="17.0153625" x2="84.0114" y2="17.03363125" width="0.4064" layer="16"/>
<wire x1="75.715" y1="14.9708" x2="75.7147625" y2="14.9710375" width="0.4064" layer="16"/>
<wire x1="75.7147625" y1="14.9710375" x2="75.7299625" y2="16.408784375" width="0.4064" layer="16"/>
<wire x1="75.7299625" y1="16.408784375" x2="76.364928125" y2="17" width="0.4064" layer="16"/>
<wire x1="76.364928125" y1="17" x2="83.883921875" y2="17" width="0.4064" layer="16"/>
<wire x1="83.883921875" y1="17" x2="84.0114" y2="17.03363125" width="0.4064" layer="16"/>
<wire x1="63.1" y1="27.71" x2="63.1" y2="30" width="0.4064" layer="16"/>
<wire x1="63.1" y1="30" x2="64.1" y2="31" width="0.4064" layer="16"/>
<wire x1="64.1" y1="31" x2="83" y2="31" width="0.4064" layer="16"/>
<wire x1="83" y1="31" x2="83.92348125" y2="30.07651875" width="0.4064" layer="16"/>
<wire x1="83.92348125" y1="30.07651875" x2="83.92348125" y2="27.781696875" width="0.4064" layer="16"/>
</signal>
<signal name="N$18">
<contactref element="LED2" pad="7"/>
<contactref element="U$2" pad="16"/>
<wire x1="73.35" y1="27.62" x2="73.3641375" y2="27.6058625" width="0.4064" layer="16"/>
<wire x1="73.3641375" y1="27.6058625" x2="78.692" y2="27.6058625" width="0.4064" layer="16"/>
<via x="78.692" y="27.6058625" extent="1-16" drill="0.6" shape="square"/>
<wire x1="78.692" y1="27.6058625" x2="78.7359625" y2="27.5619" width="0.4064" layer="1"/>
<wire x1="78.7359625" y1="27.5619" x2="78.7359625" y2="19" width="0.4064" layer="1"/>
<via x="78.7359625" y="19" extent="1-16" drill="0.6" shape="square"/>
<wire x1="78.7359625" y1="19" x2="73.81" y2="19" width="0.4064" layer="16"/>
<wire x1="73.81" y1="19" x2="73.175" y2="18.365" width="0.4064" layer="16"/>
<wire x1="73.175" y1="18.365" x2="73.175" y2="14.9708" width="0.4064" layer="16"/>
</signal>
<signal name="N$19">
<contactref element="LED2" pad="4"/>
<contactref element="U$2" pad="20"/>
<wire x1="68.095" y1="14.9708" x2="68.095" y2="12.555" width="0.4064" layer="16"/>
<wire x1="68.095" y1="12.555" x2="68.27" y2="12.38" width="0.4064" layer="16"/>
</signal>
<signal name="N$20">
<contactref element="U$2" pad="23"/>
<contactref element="LED2" pad="2"/>
<wire x1="64.285" y1="14.9708" x2="64.285" y2="13.475" width="0.4064" layer="16"/>
<wire x1="64.285" y1="13.475" x2="63.19" y2="12.38" width="0.4064" layer="16"/>
</signal>
<signal name="N$21">
<contactref element="LED2" pad="1"/>
<contactref element="U$2" pad="21"/>
<wire x1="66.825" y1="14.9708" x2="66.826515625" y2="14.972315625" width="0.4064" layer="16"/>
<wire x1="66.826515625" y1="14.972315625" x2="66.833225" y2="16.093978125" width="0.4064" layer="16"/>
<wire x1="66.833225" y1="16.093978125" x2="66.1982375" y2="16.7329125" width="0.4064" layer="16"/>
<wire x1="66.1982375" y1="16.7329125" x2="61.600915625" y2="16.732909375" width="0.4064" layer="16"/>
<wire x1="61.600915625" y1="16.732909375" x2="60.65" y2="15.708284375" width="0.4064" layer="16"/>
<wire x1="60.65" y1="15.708284375" x2="60.65" y2="12.38" width="0.4064" layer="16"/>
</signal>
<signal name="N$22">
<contactref element="U$2" pad="15"/>
<contactref element="LED2" pad="10"/>
<wire x1="65.73" y1="27.62" x2="65.67924375" y2="27.67075625" width="0.4064" layer="16"/>
<wire x1="65.67924375" y1="27.67075625" x2="65.67924375" y2="29.365" width="0.4064" layer="16"/>
<wire x1="65.67924375" y1="29.365" x2="66.31424375" y2="30" width="0.4064" layer="16"/>
<via x="82.34085" y="27.649821875" extent="1-16" drill="0.6" shape="square"/>
<wire x1="82.34085" y1="27.649821875" x2="82.34084375" y2="27.56189375" width="0.4064" layer="1"/>
<wire x1="82.34084375" y1="27.56189375" x2="82.34084375" y2="18.0008" width="0.4064" layer="1"/>
<via x="82.34084375" y="18.0008" extent="1-16" drill="0.6" shape="square"/>
<wire x1="82.34084375" y1="18.0008" x2="82.340840625" y2="18" width="0.4064" layer="16"/>
<wire x1="82.30421875" y1="18.0229" x2="82.340840625" y2="18" width="0.4064" layer="16"/>
<wire x1="82.098053125" y1="17.9764375" x2="82.34084375" y2="18.0008" width="0.4064" layer="16"/>
<wire x1="74.445" y1="14.9708" x2="74.447753125" y2="14.973553125" width="0.4064" layer="16"/>
<wire x1="74.447753125" y1="14.973553125" x2="74.447753125" y2="17.297753125" width="0.4064" layer="16"/>
<wire x1="74.447753125" y1="17.297753125" x2="75.082753125" y2="17.932753125" width="0.4064" layer="16"/>
<wire x1="75.082753125" y1="17.932753125" x2="82.2728" y2="17.932753125" width="0.4064" layer="16"/>
<wire x1="82.2728" y1="17.932753125" x2="82.34084375" y2="18.0008" width="0.4064" layer="16"/>
<wire x1="66.31424375" y1="30" x2="81.70585" y2="30" width="0.4064" layer="16"/>
<wire x1="81.70585" y1="30" x2="82.34085" y2="29.365" width="0.4064" layer="16"/>
<wire x1="82.34085" y1="29.365" x2="82.34085" y2="27.649821875" width="0.4064" layer="16"/>
</signal>
<signal name="N$23">
<contactref element="U$2" pad="17"/>
<contactref element="LED2" pad="5"/>
<wire x1="71.905" y1="14.9708" x2="71.91" y2="14.915815625" width="0.4064" layer="16"/>
<wire x1="71.91" y1="14.915815625" x2="71.91" y2="13.529984375" width="0.4064" layer="16"/>
<wire x1="71.91" y1="13.529984375" x2="70.81" y2="12.38" width="0.4064" layer="16"/>
</signal>
<signal name="N$24">
<contactref element="LED2" pad="3"/>
<contactref element="U$2" pad="22"/>
<wire x1="65.555" y1="14.9708" x2="65.555" y2="12.555" width="0.4064" layer="16"/>
<wire x1="65.555" y1="12.555" x2="65.73" y2="12.38" width="0.4064" layer="16"/>
</signal>
<signal name="N$25">
<contactref element="LED2" pad="12"/>
<contactref element="U$2" pad="2"/>
<wire x1="60.65" y1="27.62" x2="57.5" y2="27.62" width="0.4064" layer="16"/>
<wire x1="57.5" y1="27.62" x2="57.5" y2="23" width="0.4064" layer="16"/>
<wire x1="57.5" y1="23" x2="64.285" y2="23" width="0.4064" layer="16"/>
<wire x1="64.285" y1="23" x2="64.285" y2="25.0292" width="0.4064" layer="16"/>
</signal>
<signal name="N$26">
<contactref element="LED2" pad="9"/>
<contactref element="U$2" pad="11"/>
<wire x1="68.27" y1="27.62" x2="68.273003125" y2="27.623003125" width="0.4064" layer="16"/>
<wire x1="68.273003125" y1="27.623003125" x2="68.273003125" y2="28.365" width="0.4064" layer="16"/>
<wire x1="80.538403125" y1="28.365" x2="80.538403125" y2="27.8696125" width="0.4064" layer="16"/>
<wire x1="80.538403125" y1="27.8696125" x2="80.49444375" y2="27.649821875" width="0.4064" layer="16"/>
<via x="80.49444375" y="27.649821875" extent="1-16" drill="0.6" shape="square"/>
<wire x1="80.49444375" y1="27.649821875" x2="80.49444375" y2="22.946346875" width="0.4064" layer="1"/>
<via x="80.49444375" y="22.946346875" extent="1-16" drill="0.6" shape="square"/>
<wire x1="80.49444375" y1="22.946346875" x2="80.4504875" y2="23" width="0.4064" layer="16"/>
<wire x1="75.715" y1="25.0292" x2="75.722734375" y2="25.021465625" width="0.4064" layer="16"/>
<wire x1="75.722734375" y1="25.021465625" x2="75.722734375" y2="23.58490625" width="0.4064" layer="16"/>
<wire x1="75.722734375" y1="23.58490625" x2="76.357734375" y2="22.94990625" width="0.4064" layer="16"/>
<wire x1="76.357734375" y1="22.94990625" x2="80.490884375" y2="22.94990625" width="0.4064" layer="16"/>
<wire x1="80.490884375" y1="22.94990625" x2="80.49444375" y2="22.946346875" width="0.4064" layer="16"/>
<wire x1="68.273003125" y1="28.365" x2="68.269809375" y2="28.36819375" width="0.4064" layer="16"/>
<wire x1="68.269809375" y1="28.36819375" x2="68.813996875" y2="29" width="0.4064" layer="16"/>
<wire x1="68.813996875" y1="29" x2="79.991021875" y2="29" width="0.4064" layer="16"/>
<wire x1="79.991021875" y1="29" x2="80.538403125" y2="28.365" width="0.4064" layer="16"/>
</signal>
<signal name="N$27">
<contactref element="LED2" pad="8"/>
<contactref element="U$2" pad="6"/>
<wire x1="70.81" y1="27.62" x2="70.568509375" y2="27.62" width="0.4064" layer="16"/>
<wire x1="70.568509375" y1="27.62" x2="69.36706875" y2="26.418559375" width="0.4064" layer="16"/>
<wire x1="69.36706875" y1="26.418559375" x2="69.36706875" y2="25.03126875" width="0.4064" layer="16"/>
<wire x1="69.36706875" y1="25.03126875" x2="69.365" y2="25.0292" width="0.4064" layer="16"/>
</signal>
<signal name="N$28">
<contactref element="U$2" pad="18"/>
<contactref element="R9" pad="2"/>
<wire x1="59.4" y1="20.322" x2="70" y2="20.322" width="0.4064" layer="16"/>
<wire x1="70" y1="20.322" x2="70.635" y2="19.687" width="0.4064" layer="16"/>
<wire x1="70.635" y1="19.687" x2="70.635" y2="14.9708" width="0.4064" layer="16"/>
</signal>
<signal name="N$30">
<contactref element="U$1" pad="D10"/>
<contactref element="SV2" pad="3"/>
<wire x1="85" y1="75" x2="85" y2="73.4" width="0.4064" layer="16"/>
<wire x1="85" y1="73.4" x2="89.7" y2="70.4" width="0.4064" layer="16"/>
<wire x1="89.7" y1="70.4" x2="89.7" y2="68.62" width="0.4064" layer="16"/>
</signal>
<signal name="N$31">
<contactref element="U$1" pad="D11"/>
<contactref element="SV2" pad="2"/>
<wire x1="92.24" y1="68.62" x2="92.2" y2="68.82" width="0.4064" layer="16"/>
<wire x1="92.2" y1="68.82" x2="92.2" y2="70.5" width="0.4064" layer="16"/>
<wire x1="92.2" y1="70.5" x2="87.54" y2="73.5" width="0.4064" layer="16"/>
<wire x1="87.54" y1="73.5" x2="87.54" y2="75" width="0.4064" layer="16"/>
</signal>
<signal name="N$32">
<contactref element="U$1" pad="D12"/>
<contactref element="SV2" pad="1"/>
<wire x1="94.78" y1="68.62" x2="94.8" y2="70.5" width="0.4064" layer="16"/>
<wire x1="94.8" y1="70.5" x2="90.08" y2="73.4" width="0.4064" layer="16"/>
<wire x1="90.08" y1="73.4" x2="90.08" y2="75" width="0.4064" layer="16"/>
</signal>
<signal name="N$1">
</signal>
<signal name="N$3">
<contactref element="SL1" pad="1"/>
<contactref element="U$1" pad="3V3"/>
<wire x1="65.92" y1="62" x2="65.9" y2="61.98" width="0.4064" layer="16"/>
<wire x1="65.9" y1="61.98" x2="65.9" y2="59.2" width="0.4064" layer="16"/>
<wire x1="65.9" y1="59.2" x2="67.7" y2="57.4" width="0.4064" layer="16"/>
<wire x1="67.7" y1="57.4" x2="90.4" y2="57.4" width="0.4064" layer="16"/>
<wire x1="90.4" y1="57.4" x2="92.24" y2="55.56" width="0.4064" layer="16"/>
<wire x1="92.24" y1="55.56" x2="92.24" y2="53.38" width="0.4064" layer="16"/>
</signal>
<signal name="GNDA">
<contactref element="U$2" pad="4"/>
<contactref element="U$2" pad="9"/>
<contactref element="C7" pad="2"/>
<contactref element="SV1" pad="4"/>
<polygon width="0.254" layer="16" spacing="0.254" isolate="0.6096">
<vertex x="20" y="40"/>
<vertex x="20" y="0"/>
<vertex x="100" y="0"/>
<vertex x="100" y="40"/>
</polygon>
</polygon>
</signal>
<signal name="N$5">
<contactref element="R9" pad="1"/>
<contactref element="U$2" pad="19"/>
<contactref element="C7" pad="1"/>
<wire x1="56.5" y1="17.5" x2="59.425671875" y2="17.5" width="1.27" layer="16"/>
<wire x1="59.425671875" y1="17.5" x2="59.4" y2="17.478" width="0.4064" layer="16"/>
<wire x1="69.365" y1="14.9708" x2="69.396525" y2="15.002325" width="0.4064" layer="16"/>
<wire x1="59.4" y1="17.478" x2="68.73" y2="17.478" width="0.4064" layer="16"/>
<wire x1="68.73" y1="17.478" x2="69.365" y2="16.843" width="0.4064" layer="16"/>
<wire x1="69.365" y1="16.843" x2="69.365" y2="14.9708" width="0.4064" layer="16"/>
<contactref element="SV1" pad="5"/>
<wire x1="56.5" y1="17.5" x2="56.3" y2="17.5" width="0.4064" layer="16"/>
<wire x1="56.3" y1="17.5" x2="56.3" y2="30.7" width="0.4064" layer="16"/>
<wire x1="56.3" y1="30.7" x2="58.6" y2="33" width="0.4064" layer="16"/>
<wire x1="58.6" y1="33" x2="79.92" y2="33" width="0.4064" layer="16"/>
</signal>
<signal name="N$8">
<contactref element="U$2" pad="1"/>
<contactref element="SV1" pad="1"/>
<wire x1="63.015" y1="25.0292" x2="62.900834375" y2="25" width="0.4064" layer="16"/>
<wire x1="62.900834375" y1="25" x2="59.217125" y2="25" width="0.4064" layer="16"/>
<wire x1="59.217125" y1="25" x2="59.320084375" y2="24.965221875" width="0.4064" layer="16"/>
<via x="58.9" y="36.7" extent="1-16" drill="0.6" shape="square"/>
<wire x1="58.9" y1="36.7" x2="59" y2="25.032815625" width="0.4064" layer="1"/>
<via x="59" y="25.032815625" extent="1-16" drill="0.6" shape="square"/>
<wire x1="59.320084375" y1="24.965221875" x2="59.1980625" y2="25.27943125" width="0.4064" layer="16"/>
<wire x1="59.1980625" y1="25.27943125" x2="59" y2="25.032815625" width="0.4064" layer="16"/>
<wire x1="90.08" y1="33" x2="90.1" y2="33.02" width="0.4064" layer="16"/>
<wire x1="90.1" y1="33.02" x2="90.1" y2="34.9" width="0.4064" layer="16"/>
<wire x1="90.1" y1="34.9" x2="88.3" y2="36.7" width="0.4064" layer="16"/>
<wire x1="88.3" y1="36.7" x2="58.9" y2="36.7" width="0.4064" layer="16"/>
</signal>
<signal name="N$29">
<contactref element="U$2" pad="13"/>
<contactref element="SV1" pad="2"/>
<wire x1="87.5162875" y1="32.9762875" x2="87.5" y2="27.56079375" width="0.4064" layer="16"/>
<via x="87.5" y="27.56079375" extent="1-16" drill="0.6" shape="square"/>
<wire x1="87.5" y1="27.56079375" x2="87.5" y2="14.979359375" width="0.4064" layer="1"/>
<via x="87.5" y="14.979359375" extent="1-16" drill="0.6" shape="square"/>
<wire x1="87.5" y1="14.979359375" x2="87.456471875" y2="14.99701875" width="0.4064" layer="16"/>
<wire x1="76.985" y1="14.9708" x2="87.3915625" y2="14.9708" width="0.4064" layer="16"/>
<wire x1="87.3915625" y1="14.9708" x2="87.5" y2="14.979359375" width="0.4064" layer="16"/>
<wire x1="87.5162875" y1="32.9762875" x2="87.54" y2="33" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="N$33">
<contactref element="U$2" pad="12"/>
<contactref element="SV1" pad="3"/>
<wire x1="85.02253125" y1="32.97746875" x2="85.02253125" y2="25.6642" width="0.4064" layer="16"/>
<wire x1="85.02253125" y1="25.6642" x2="84.38753125" y2="25.0292" width="0.4064" layer="16"/>
<wire x1="84.38753125" y1="25.0292" x2="76.985" y2="25.0292" width="0.4064" layer="16"/>
<wire x1="85.02253125" y1="32.97746875" x2="85" y2="33" width="0" layer="19" extent="16-16"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
