<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.4">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.025" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.025" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="yes"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="yes"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="yes"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="yes"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="yes"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="yes"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="yes"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="yes"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="yes"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="yes"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="yes"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="yes"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="yes"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="no" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="no" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="no" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="no" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="no" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="no" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="no" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="no" active="yes"/>
<layer number="53" name="tGND_GNDA" color="7" fill="9" visible="no" active="no"/>
<layer number="54" name="bGND_GNDA" color="1" fill="9" visible="no" active="no"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<text x="2.54" y="35.56" size="1.778" layer="16" rot="MR270">VILLANYPASZTOR</text>
<wire x1="-0.635" y1="49.53" x2="85.09" y2="49.53" width="0.6096" layer="20"/>
<wire x1="-0.635" y1="49.53" x2="-0.635" y2="-0.635" width="0.6096" layer="20"/>
<wire x1="-0.635" y1="-0.635" x2="85.09" y2="-0.635" width="0.6096" layer="20"/>
<wire x1="85.09" y1="49.53" x2="85.09" y2="-0.635" width="0.6096" layer="20"/>
</plain>
<libraries>
<library name="pinhead">
<packages>
<package name="1X01">
<description>&lt;b&gt;PIN HEADER&lt;/b&gt;</description>
<wire x1="-0.635" y1="1.27" x2="0.635" y2="1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="1.27" x2="1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="0.635" x2="1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.27" y1="-0.635" x2="0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="0.635" x2="-1.27" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="1.27" x2="-1.27" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.27" y1="-0.635" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="0.635" y1="-1.27" x2="-0.635" y2="-1.27" width="0.1524" layer="21"/>
<pad name="1" x="0" y="0" drill="1.016" shape="octagon"/>
<text x="-1.3462" y="1.8288" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.27" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.254" y1="-0.254" x2="0.254" y2="0.254" layer="51"/>
</package>
</packages>
</library>
<library name="rectifier">
<packages>
<package name="FB15">
<description>&lt;b&gt;FAGOR RECTIFIER&lt;/b&gt;&lt;p&gt;
grid 3 x 5 mm</description>
<wire x1="-10.04" y1="-2.54" x2="-10.04" y2="2.54" width="0.1524" layer="21"/>
<wire x1="10.28" y1="2.54" x2="10.28" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-10.04" y1="2.54" x2="6.724" y2="2.54" width="0.1524" layer="21"/>
<wire x1="6.724" y1="2.54" x2="10.28" y2="2.54" width="0.1524" layer="21"/>
<wire x1="7.232" y1="-1.778" x2="8.248" y2="-1.778" width="0.1524" layer="21"/>
<wire x1="-6.484" y1="-1.651" x2="-5.468" y2="-1.651" width="0.1524" layer="21"/>
<wire x1="-3.0296" y1="-1.778" x2="-2.3692" y2="-1.778" width="0.1524" layer="21" curve="180"/>
<wire x1="-3.69" y1="-1.778" x2="-3.0296" y2="-1.778" width="0.1524" layer="21" curve="-180"/>
<wire x1="1.7964" y1="-1.778" x2="2.4568" y2="-1.778" width="0.1524" layer="21" curve="180"/>
<wire x1="1.136" y1="-1.778" x2="1.7964" y2="-1.778" width="0.1524" layer="21" curve="-180"/>
<wire x1="10.28" y1="-2.54" x2="6.724" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="6.724" y1="-2.54" x2="-10.04" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.976" y1="-2.159" x2="-5.976" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="6.724" y1="2.54" x2="6.724" y2="1.397" width="0.1524" layer="21"/>
<wire x1="6.724" y1="-1.397" x2="6.724" y2="1.397" width="0.1524" layer="51"/>
<wire x1="6.724" y1="-1.397" x2="6.724" y2="-2.54" width="0.1524" layer="21"/>
<pad name="-" x="7.5114" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="+" x="-7.5" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="AC2" x="2.533" y="0" drill="1.016" shape="long" rot="R90"/>
<pad name="AC1" x="-2.4962" y="0" drill="1.016" shape="long" rot="R90"/>
<text x="-10.04" y="3.048" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.912" y="3.048" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-10" y1="-2.5" x2="10" y2="2.5" layer="43"/>
</package>
</packages>
</library>
<library name="fuse">
<packages>
<package name="SHK20L">
<description>&lt;b&gt;FUSE HOLDER&lt;/b&gt;&lt;p&gt; 5 x 20 mm, SH contact, SHH1 Schukat / E1073 Buerklin</description>
<wire x1="-5.334" y1="2.921" x2="5.334" y2="2.921" width="0.0508" layer="21"/>
<wire x1="-3.302" y1="0" x2="3.302" y2="0" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="3.683" x2="-5.969" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-3.683" x2="-10.414" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-2.54" x2="-5.969" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="3.683" x2="-10.414" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="2.54" x2="-5.969" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-3.683" x2="-10.414" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="-3.683" x2="-5.969" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-3.683" x2="-11.049" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="-3.683" x2="-11.049" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-2.032" x2="-10.795" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="-3.429" x2="-10.414" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="-3.429" x2="-10.414" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="-5.969" y1="2.54" x2="-5.969" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="-2.032" x2="-11.049" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-11.049" y1="-1.27" x2="-10.795" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-10.795" y1="-1.27" x2="-10.795" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="-3.302" y1="0" x2="-5.334" y2="0" width="0.1524" layer="51"/>
<wire x1="5.334" y1="-2.921" x2="-5.334" y2="-2.921" width="0.0508" layer="21"/>
<wire x1="10.414" y1="-3.683" x2="5.969" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="10.414" y1="3.683" x2="10.414" y2="3.429" width="0.1524" layer="21"/>
<wire x1="10.414" y1="2.54" x2="5.969" y2="2.54" width="0.1524" layer="21"/>
<wire x1="10.414" y1="-3.683" x2="10.414" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="10.414" y1="-2.54" x2="5.969" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="5.969" y1="3.683" x2="10.414" y2="3.683" width="0.1524" layer="21"/>
<wire x1="5.969" y1="3.683" x2="5.969" y2="2.54" width="0.1524" layer="21"/>
<wire x1="10.414" y1="3.683" x2="11.049" y2="3.683" width="0.1524" layer="21"/>
<wire x1="11.049" y1="3.683" x2="11.049" y2="2.032" width="0.1524" layer="21"/>
<wire x1="10.795" y1="2.032" x2="10.795" y2="3.429" width="0.1524" layer="21"/>
<wire x1="10.795" y1="3.429" x2="10.414" y2="3.429" width="0.1524" layer="21"/>
<wire x1="10.414" y1="3.429" x2="10.414" y2="2.54" width="0.1524" layer="21"/>
<wire x1="5.969" y1="-2.54" x2="5.969" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="11.049" y1="2.032" x2="11.049" y2="1.27" width="0.1524" layer="51"/>
<wire x1="11.049" y1="1.27" x2="10.795" y2="1.27" width="0.1524" layer="51"/>
<wire x1="10.795" y1="1.27" x2="10.795" y2="2.032" width="0.1524" layer="51"/>
<wire x1="3.302" y1="0" x2="5.334" y2="0" width="0.1524" layer="51"/>
<wire x1="10.414" y1="-3.683" x2="11.049" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="11.049" y1="-2.032" x2="11.049" y2="-3.683" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-3.429" x2="10.795" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="10.795" y1="-3.429" x2="10.414" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="10.414" y1="-3.429" x2="10.414" y2="-2.54" width="0.1524" layer="21"/>
<wire x1="11.049" y1="1.27" x2="11.049" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="10.795" y1="1.27" x2="10.795" y2="-2.032" width="0.1524" layer="51"/>
<wire x1="-10.795" y1="2.032" x2="-10.795" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-11.049" y1="2.032" x2="-11.049" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-10.414" y1="3.683" x2="-11.049" y2="3.683" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="3.429" x2="-10.414" y2="3.429" width="0.1524" layer="21"/>
<wire x1="-10.414" y1="3.429" x2="-10.414" y2="2.54" width="0.1524" layer="21"/>
<wire x1="-10.795" y1="3.429" x2="-10.795" y2="2.032" width="0.1524" layer="21"/>
<wire x1="-11.049" y1="2.032" x2="-11.049" y2="3.683" width="0.1524" layer="21"/>
<pad name="1A" x="-10.414" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<pad name="2A" x="10.414" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<pad name="2B" x="5.334" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<pad name="1B" x="-5.334" y="0" drill="1.3208" diameter="2.54" shape="long" rot="R90"/>
<text x="-3.81" y="3.175" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-5.08" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-10.033" y1="-2.032" x2="-9.652" y2="2.032" layer="51"/>
<rectangle x1="-5.969" y1="-3.175" x2="-5.334" y2="-2.032" layer="21"/>
<rectangle x1="-5.969" y1="2.032" x2="-5.334" y2="3.175" layer="21"/>
<rectangle x1="-5.969" y1="-2.032" x2="-5.334" y2="2.032" layer="51"/>
<rectangle x1="9.652" y1="-2.032" x2="10.033" y2="2.032" layer="51"/>
<rectangle x1="5.334" y1="2.032" x2="5.969" y2="3.175" layer="21"/>
<rectangle x1="5.334" y1="-3.175" x2="5.969" y2="-2.032" layer="21"/>
<rectangle x1="5.334" y1="-2.032" x2="5.969" y2="2.032" layer="51"/>
<rectangle x1="4.064" y1="1.651" x2="5.334" y2="2.159" layer="51"/>
<rectangle x1="4.064" y1="-2.159" x2="5.334" y2="-1.651" layer="51"/>
<rectangle x1="-5.334" y1="1.651" x2="-4.064" y2="2.159" layer="51"/>
<rectangle x1="-5.334" y1="-2.159" x2="-4.064" y2="-1.651" layer="51"/>
<rectangle x1="-10.414" y1="-2.54" x2="-5.969" y2="-2.032" layer="21"/>
<rectangle x1="-4.064" y1="-2.159" x2="4.064" y2="-1.651" layer="21"/>
<rectangle x1="-4.064" y1="1.651" x2="4.064" y2="2.159" layer="21"/>
<rectangle x1="-6.223" y1="1.905" x2="-5.969" y2="2.032" layer="51"/>
<rectangle x1="5.969" y1="1.905" x2="6.223" y2="2.032" layer="51"/>
<rectangle x1="5.969" y1="-2.032" x2="6.223" y2="-1.905" layer="51"/>
<rectangle x1="9.398" y1="1.905" x2="9.652" y2="2.032" layer="51"/>
<rectangle x1="9.398" y1="-2.032" x2="9.652" y2="-1.905" layer="51"/>
<rectangle x1="6.223" y1="-2.032" x2="9.398" y2="-1.905" layer="21"/>
<rectangle x1="6.223" y1="1.905" x2="9.398" y2="2.032" layer="21"/>
<rectangle x1="5.969" y1="2.032" x2="10.033" y2="2.54" layer="21"/>
<rectangle x1="5.969" y1="-2.54" x2="10.033" y2="-2.032" layer="21"/>
<rectangle x1="-10.033" y1="2.032" x2="-5.969" y2="2.54" layer="21"/>
<rectangle x1="-9.398" y1="1.905" x2="-6.223" y2="2.032" layer="21"/>
<rectangle x1="-9.652" y1="1.905" x2="-9.398" y2="2.032" layer="51"/>
<rectangle x1="-6.223" y1="-2.032" x2="-5.969" y2="-1.905" layer="51"/>
<rectangle x1="-9.398" y1="-2.032" x2="-6.223" y2="-1.905" layer="21"/>
<rectangle x1="-9.652" y1="-2.032" x2="-9.398" y2="-1.905" layer="51"/>
</package>
</packages>
</library>
<library name="diode">
<packages>
<package name="GT32">
<description>&lt;B&gt;DIODE&lt;/B&gt;&lt;p&gt;
diameter 2.54 mm, horizontal, grid 7.62 mm</description>
<wire x1="2.032" y1="-1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="2.032" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="1.27" x2="-2.032" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0" x2="2.794" y2="0" width="0.762" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.794" y2="0" width="0.762" layer="51"/>
<wire x1="1.016" y1="0.635" x2="1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="1.016" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="-0.635" x2="-1.016" y2="0.635" width="0.1524" layer="21"/>
<wire x1="-1.016" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="-1.397" y2="0" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="-1.016" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-0.635" x2="0" y2="-0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="-0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<wire x1="0.254" y1="0.635" x2="0" y2="0.635" width="0.1524" layer="21"/>
<wire x1="0" y1="0.635" x2="0" y2="0" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="1.1176" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="1.1176" shape="octagon"/>
<text x="-2.032" y="1.524" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.032" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="2.032" y1="-0.381" x2="2.667" y2="0.381" layer="21"/>
<rectangle x1="-2.667" y1="-0.381" x2="-2.032" y2="0.381" layer="21"/>
</package>
<package name="DO34-7">
diameter 1.8 mm, horizontal, grid 7.62 mm</description>
<wire x1="-1.524" y1="-0.889" x2="1.524" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="0.889" x2="-1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="1.524" y1="-0.889" x2="1.524" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-1.524" y1="0.889" x2="-1.524" y2="-0.889" width="0.1524" layer="21"/>
<wire x1="3.81" y1="0" x2="2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-3.81" y1="0" x2="-2.921" y2="0" width="0.508" layer="51"/>
<wire x1="-0.508" y1="0" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="0.889" y1="0.508" x2="0.889" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="0.889" y1="-0.508" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="1.27" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="0.889" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0.508" x2="-0.127" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.127" y1="0" x2="-0.127" y2="-0.508" width="0.1524" layer="21"/>
<pad name="C" x="-3.81" y="0" drill="0.8128" shape="long"/>
<pad name="A" x="3.81" y="0" drill="0.8128" shape="long"/>
<text x="-1.524" y="1.143" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-1.524" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="-1.143" y1="-0.889" x2="-0.762" y2="0.889" layer="21"/>
<rectangle x1="1.524" y1="-0.254" x2="2.921" y2="0.254" layer="21"/>
<rectangle x1="-2.921" y1="-0.254" x2="-1.524" y2="0.254" layer="21"/>
</package>
</packages>
</library>
<library name="rcl">
<packages>
<package name="E3,5-8">
<description>&lt;b&gt;ELECTROLYTIC CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 3.5 mm, diameter 8 mm</description>
<wire x1="-3.429" y1="1.143" x2="-2.667" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-3.048" y1="0.762" x2="-3.048" y2="1.524" width="0.1524" layer="21"/>
<wire x1="-1.651" y1="0" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="0" x2="-0.762" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="-1.27" x2="-0.254" y2="-1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="-1.27" x2="-0.254" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.254" y1="1.27" x2="-0.762" y2="1.27" width="0.1524" layer="51"/>
<wire x1="-0.762" y1="1.27" x2="-0.762" y2="0" width="0.1524" layer="51"/>
<wire x1="0.635" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="4.064" width="0.1524" layer="21"/>
<pad name="-" x="1.778" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.778" y="0" drill="0.8128" diameter="1.6002"/>
<text x="3.302" y="2.794" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-2.286" y="-3.048" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.27" x2="0.762" y2="1.27" layer="51"/>
</package>
<package name="M1206">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
MELF 0.25 W</description>
<wire x1="-2.473" y1="1.483" x2="2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-1.483" x2="-2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-1.483" x2="-2.473" y2="1.483" width="0.0508" layer="39"/>
<wire x1="2.473" y1="1.483" x2="2.473" y2="-1.483" width="0.0508" layer="39"/>
<wire x1="1.143" y1="0.8382" x2="-1.143" y2="0.8382" width="0.1524" layer="51"/>
<wire x1="1.143" y1="-0.8382" x2="-1.143" y2="-0.8382" width="0.1524" layer="51"/>
<smd name="1" x="-1.4" y="0" dx="1.6" dy="2" layer="1"/>
<smd name="2" x="1.4" y="0" dx="1.6" dy="2" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.7018" y1="-0.9144" x2="-1.1176" y2="0.9144" layer="51"/>
<rectangle x1="1.1176" y1="-0.9144" x2="1.7018" y2="0.9144" layer="51"/>
<rectangle x1="-0.3" y1="-0.8001" x2="0.3" y2="0.8001" layer="35"/>
</package>
<package name="E2,5-5">
grid 2.54 mm, diameter 5 mm</description>
<wire x1="-1.651" y1="1.27" x2="-1.397" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.016" x2="-1.397" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.27" x2="-1.143" y2="1.27" width="0.1524" layer="21"/>
<wire x1="-1.397" y1="1.27" x2="-1.397" y2="1.524" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="2.54" width="0.1524" layer="21"/>
<pad name="-" x="1.27" y="0" drill="0.8128" diameter="1.6002" shape="octagon"/>
<pad name="+" x="-1.27" y="0" drill="0.8128" diameter="1.6002"/>
<text x="2.413" y="1.27" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="2.413" y="-2.413" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C150-091X182">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;
grid 15 mm, outline 9.1 x 18.2 mm</description>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="0" width="0.4064" layer="21"/>
<wire x1="-5.08" y1="0" x2="-5.08" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="1.27" x2="-4.191" y2="0" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="-4.191" y2="-1.27" width="0.4064" layer="21"/>
<wire x1="-4.191" y1="0" x2="6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0" x2="-6.096" y2="0" width="0.1524" layer="21"/>
<wire x1="9.017" y1="3.937" x2="9.017" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="8.509" y1="-4.445" x2="-8.509" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-9.017" y1="-3.937" x2="-9.017" y2="3.937" width="0.1524" layer="21"/>
<wire x1="-8.509" y1="4.445" x2="8.509" y2="4.445" width="0.1524" layer="21"/>
<wire x1="8.509" y1="4.445" x2="9.017" y2="3.937" width="0.1524" layer="21" curve="-90"/>
<wire x1="8.509" y1="-4.445" x2="9.017" y2="-3.937" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="-3.937" x2="-8.509" y2="-4.445" width="0.1524" layer="21" curve="90"/>
<wire x1="-9.017" y1="3.937" x2="-8.509" y2="4.445" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-7.493" y="0" drill="1.016" shape="octagon"/>
<pad name="2" x="7.493" y="0" drill="1.016" shape="octagon"/>
<text x="-8.509" y="4.826" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.54" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="C050-025X075">
grid 5 mm, outline 2.5 x 7.5 mm</description>
<wire x1="-0.3048" y1="0.635" x2="-0.3048" y2="0" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-0.3048" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="-0.3048" y1="0" x2="-1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="0.3302" y1="0.635" x2="0.3302" y2="0" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="0.3302" y2="-0.635" width="0.3048" layer="21"/>
<wire x1="0.3302" y1="0" x2="1.524" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.683" y1="1.016" x2="-3.683" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="-1.27" x2="3.429" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="3.683" y1="-1.016" x2="3.683" y2="1.016" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="-3.429" y2="1.27" width="0.1524" layer="21"/>
<wire x1="3.429" y1="1.27" x2="3.683" y2="1.016" width="0.1524" layer="21" curve="-90"/>
<wire x1="3.429" y1="-1.27" x2="3.683" y2="-1.016" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="-1.016" x2="-3.429" y2="-1.27" width="0.1524" layer="21" curve="90"/>
<wire x1="-3.683" y1="1.016" x2="-3.429" y2="1.27" width="0.1524" layer="21" curve="-90"/>
<pad name="1" x="-2.54" y="0" drill="0.8128" shape="octagon"/>
<pad name="2" x="2.54" y="0" drill="0.8128" shape="octagon"/>
<text x="-3.429" y="1.651" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.429" y="-2.794" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="E5-10,5">
grid 5.08 mm, diameter 10.5 mm</description>
<wire x1="-1.143" y1="0" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="0" x2="-0.889" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="-1.143" x2="-0.254" y2="-1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="-1.143" x2="-0.254" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.254" y1="1.143" x2="-0.889" y2="1.143" width="0.1524" layer="21"/>
<wire x1="-0.889" y1="1.143" x2="-0.889" y2="0" width="0.1524" layer="21"/>
<wire x1="0.635" y1="0" x2="1.143" y2="0" width="0.1524" layer="21"/>
<wire x1="-3.81" y1="1.651" x2="-3.81" y2="0.889" width="0.1524" layer="21"/>
<wire x1="-3.429" y1="1.27" x2="-4.191" y2="1.27" width="0.1524" layer="21"/>
<wire x1="1.143" y1="0" x2="1.651" y2="0" width="0.1524" layer="51"/>
<wire x1="-1.651" y1="0" x2="-1.143" y2="0" width="0.1524" layer="51"/>
<circle x="0" y="0" radius="5.08" width="0.1524" layer="21"/>
<pad name="+" x="-2.54" y="0" drill="1.016" diameter="2.54"/>
<pad name="-" x="2.54" y="0" drill="1.016" diameter="2.54" shape="octagon"/>
<text x="4.699" y="2.7432" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.1242" y="-3.2258" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<rectangle x1="0.254" y1="-1.143" x2="0.889" y2="1.143" layer="21"/>
</package>
<package name="C1206K">
<description>&lt;b&gt;Ceramic Chip Capacitor KEMET 1206 reflow solder&lt;/b&gt;&lt;p&gt;
Metric Code Size 3216</description>
<wire x1="-1.525" y1="0.75" x2="1.525" y2="0.75" width="0.1016" layer="51"/>
<wire x1="1.525" y1="-0.75" x2="-1.525" y2="-0.75" width="0.1016" layer="51"/>
<smd name="1" x="-1.5" y="0" dx="1.5" dy="2" layer="1"/>
<smd name="2" x="1.5" y="0" dx="1.5" dy="2" layer="1"/>
<text x="-1.6" y="1.1" size="1.016" layer="25">&gt;NAME</text>
<text x="-1.6" y="-2.1" size="1.016" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6" y1="-0.8" x2="-1.1" y2="0.8" layer="51"/>
<rectangle x1="1.1" y1="-0.8" x2="1.6" y2="0.8" layer="51"/>
</package>
</packages>
</library>
<library name="linear">
<packages>
<package name="DIL08">
<description>&lt;b&gt;Dual In Line Package&lt;/b&gt;</description>
<wire x1="5.08" y1="2.921" x2="-5.08" y2="2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="5.08" y1="2.921" x2="5.08" y2="-2.921" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="2.921" x2="-5.08" y2="1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-2.921" x2="-5.08" y2="-1.016" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.016" x2="-5.08" y2="-1.016" width="0.1524" layer="21" curve="-180"/>
<pad name="1" x="-3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="7" x="-1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="8" x="-3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="-3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="6" x="1.27" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<pad name="5" x="3.81" y="3.81" drill="0.8128" shape="long" rot="R90"/>
<text x="-5.334" y="-2.921" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<text x="-3.556" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="transistor-npn">
<packages>
<package name="TO220">
<description>&lt;b&gt;TO 220 horizontal&lt;/b&gt;</description>
<wire x1="-5.207" y1="-1.27" x2="5.207" y2="-1.27" width="0.127" layer="21"/>
<wire x1="5.207" y1="14.605" x2="-5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="5.207" y1="-1.27" x2="5.207" y2="11.176" width="0.127" layer="21"/>
<wire x1="5.207" y1="11.176" x2="4.318" y2="11.176" width="0.127" layer="21"/>
<wire x1="4.318" y1="11.176" x2="4.318" y2="12.7" width="0.127" layer="21"/>
<wire x1="4.318" y1="12.7" x2="5.207" y2="12.7" width="0.127" layer="21"/>
<wire x1="5.207" y1="12.7" x2="5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="11.176" width="0.127" layer="21"/>
<wire x1="-5.207" y1="11.176" x2="-4.318" y2="11.176" width="0.127" layer="21"/>
<wire x1="-4.318" y1="11.176" x2="-4.318" y2="12.7" width="0.127" layer="21"/>
<wire x1="-4.318" y1="12.7" x2="-5.207" y2="12.7" width="0.127" layer="21"/>
<wire x1="-5.207" y1="12.7" x2="-5.207" y2="14.605" width="0.127" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="4.572" y2="-0.635" width="0.0508" layer="21"/>
<wire x1="4.572" y1="7.62" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<wire x1="-4.572" y1="-0.635" x2="-4.572" y2="7.62" width="0.0508" layer="21"/>
<circle x="0" y="11.176" radius="1.8034" width="0.127" layer="21"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="42"/>
<circle x="0" y="11.176" radius="4.191" width="0" layer="43"/>
<pad name="1" x="-2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="2" x="0" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<text x="-3.81" y="5.207" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.937" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="7.874" size="0.9906" layer="21" ratio="12">A17,5mm</text>
<text x="-3.175" y="0" size="1.27" layer="51" ratio="10">1</text>
<text x="-0.635" y="0" size="1.27" layer="51" ratio="10">2</text>
<text x="1.905" y="0" size="1.27" layer="51" ratio="10">3</text>
<rectangle x1="2.159" y1="-4.699" x2="2.921" y2="-4.064" layer="21"/>
<rectangle x1="-0.381" y1="-4.699" x2="0.381" y2="-4.064" layer="21"/>
<rectangle x1="-2.921" y1="-4.699" x2="-2.159" y2="-4.064" layer="21"/>
<rectangle x1="-3.175" y1="-4.064" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="-0.635" y1="-4.064" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-4.064" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="-2.921" y1="-6.604" x2="-2.159" y2="-4.699" layer="51"/>
<rectangle x1="-0.381" y1="-6.604" x2="0.381" y2="-4.699" layer="51"/>
<rectangle x1="2.159" y1="-6.604" x2="2.921" y2="-4.699" layer="51"/>
<hole x="0" y="11.176" drill="3.302"/>
</package>
</packages>
</library>
<library name="triac">
<packages>
<package name="TO220CL">
<description>&lt;b&gt;TO 220 CL&lt;/b&gt; horizontal (Cathode; Anode; Gate)</description>
<wire x1="-5.207" y1="-1.27" x2="5.207" y2="-1.27" width="0.1524" layer="21"/>
<wire x1="5.207" y1="14.605" x2="-5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="5.207" y1="-1.27" x2="5.207" y2="11.176" width="0.1524" layer="21"/>
<wire x1="5.207" y1="11.176" x2="4.318" y2="11.176" width="0.1524" layer="21"/>
<wire x1="4.318" y1="11.176" x2="4.318" y2="12.7" width="0.1524" layer="21"/>
<wire x1="4.318" y1="12.7" x2="5.207" y2="12.7" width="0.1524" layer="21"/>
<wire x1="5.207" y1="12.7" x2="5.207" y2="14.605" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="-1.27" x2="-5.207" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="11.176" x2="-4.318" y2="11.176" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="11.176" x2="-4.318" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-4.318" y1="12.7" x2="-5.207" y2="12.7" width="0.1524" layer="21"/>
<wire x1="-5.207" y1="12.7" x2="-5.207" y2="14.605" width="0.1524" layer="21"/>
<circle x="0" y="11.176" radius="1.8034" width="0.1524" layer="21"/>
<pad name="C" x="-2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="A" x="0" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<pad name="G" x="2.54" y="-6.35" drill="1.1176" shape="long" rot="R90"/>
<text x="-3.81" y="5.08" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="2.54" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.445" y="7.874" size="0.9906" layer="21" ratio="10">A17,5mm</text>
<rectangle x1="-0.635" y1="-4.445" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="-3.175" y1="-4.445" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-4.445" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="-2.921" y1="-4.699" x2="-2.159" y2="-4.445" layer="21"/>
<rectangle x1="-2.921" y1="-6.477" x2="-2.159" y2="-4.699" layer="51"/>
<rectangle x1="-0.381" y1="-4.699" x2="0.381" y2="-4.445" layer="21"/>
<rectangle x1="-0.381" y1="-6.477" x2="0.381" y2="-4.699" layer="51"/>
<rectangle x1="2.159" y1="-4.699" x2="2.921" y2="-4.445" layer="21"/>
<rectangle x1="2.159" y1="-6.477" x2="2.921" y2="-4.699" layer="51"/>
</package>
</packages>
</library>
<library name="holes">
<packages>
<package name="3,2-PAD">
<description>&lt;b&gt;MOUNTING PAD&lt;/b&gt; 3.2 mm, round</description>
<wire x1="-2.159" y1="0" x2="0" y2="-2.159" width="2.4892" layer="51" curve="90" cap="flat"/>
<wire x1="0" y1="2.159" x2="2.159" y2="0" width="2.4892" layer="51" curve="-90" cap="flat"/>
<circle x="0" y="0" radius="3.429" width="0.1524" layer="21"/>
<circle x="0" y="0" radius="0.762" width="0.4572" layer="51"/>
<circle x="0" y="0" radius="3.683" width="1.27" layer="39"/>
<circle x="0" y="0" radius="3.683" width="1.27" layer="40"/>
<circle x="0" y="0" radius="3.556" width="1.016" layer="43"/>
<circle x="0" y="0" radius="1.7" width="0.1524" layer="21"/>
<pad name="B3,2" x="0" y="0" drill="3.2" diameter="5.842"/>
<text x="-1.27" y="-3.81" size="1.27" layer="48">3,2</text>
</package>
</packages>
</library>
<library name="v-reg">
<description>&lt;b&gt;Voltage Regulators&lt;/b&gt;&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="78XXL">
<description>&lt;b&gt;VOLTAGE REGULATOR&lt;/b&gt;</description>
<pad name="IN" x="-2.54" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="GND" x="0" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<pad name="OUT" x="2.54" y="-3.81" drill="1.016" shape="long" rot="R90"/>
<text x="-4.445" y="7.874" size="0.9906" layer="21" ratio="10">A15,2mm</text>
<text x="-0.508" y="0" size="1.27" layer="51" ratio="10">-</text>
<text x="-3.048" y="0" size="1.27" layer="51" ratio="10">I</text>
<text x="2.032" y="0" size="1.27" layer="51" ratio="10">O</text>
<rectangle x1="1.905" y1="-2.159" x2="3.175" y2="-1.27" layer="21"/>
<rectangle x1="1.905" y1="-3.81" x2="3.175" y2="-2.159" layer="51"/>
<rectangle x1="-0.635" y1="-2.159" x2="0.635" y2="-1.27" layer="21"/>
<rectangle x1="-3.175" y1="-2.159" x2="-1.905" y2="-1.27" layer="21"/>
<rectangle x1="-0.635" y1="-3.81" x2="0.635" y2="-2.159" layer="51"/>
<rectangle x1="-3.175" y1="-3.81" x2="-1.905" y2="-2.159" layer="51"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
</autorouter>
<elements>
<element name="JP1" library="pinhead" package="1X01" value="+12V" x="5.715" y="38.1"/>
<element name="JP2" library="pinhead" package="1X01" value="-12V" x="5.715" y="33.02"/>
<element name="F1" library="fuse" package="SHK20L" value="" x="-5.715" y="28.575" rot="R270"/>
<element name="D1" library="diode" package="DO34-7" value="1N4007" x="16.51" y="40.005" rot="R180"/>
<element name="C1" library="rcl" package="E3,5-8" value="100uF" x="14.605" y="34.29" rot="R180"/>
<element name="IC1" library="linear" package="DIL08" value="NE555N" x="17.78" y="19.685"/>
<element name="R1" library="rcl" package="M1206" value="470(E530-560)" x="14.605" y="28.575" rot="MR0"/>
<element name="R2" library="rcl" package="M1206" value="6k8(E2k2)" x="19.05" y="27.305" rot="MR270"/>
<element name="R3" library="rcl" package="M1206" value="100" x="20.32" y="10.795" rot="MR90"/>
<element name="R4" library="rcl" package="M1206" value="100" x="25.4" y="9.525" rot="MR0"/>
<element name="C2" library="rcl" package="C050-025X075" value="100n" x="16.51" y="7.62" rot="R270"/>
<element name="Q1" library="transistor-npn" package="TO220" value="BUT12A" x="38.1" y="6.985" rot="R270"/>
<element name="T1" library="triac" package="TO220CL" value="BT151" x="76.835" y="32.385"/>
<element name="R5" library="rcl" package="M1206" value="1-2M" x="69.85" y="29.21" rot="MR90"/>
<element name="D3" library="diode" package="GT32" value="" x="75.565" y="22.225"/>
<element name="C3" library="rcl" package="E2,5-5" value="4u7-22u" x="62.865" y="24.13" rot="R180"/>
<element name="R6" library="rcl" package="M1206" value="1M" x="75.565" y="20.32" rot="MR180"/>
<element name="R7" library="rcl" package="M1206" value="33" x="75.565" y="16.51" rot="MR180"/>
<element name="C4" library="rcl" package="C150-091X182" value="22n/630v" x="64.135" y="16.51" rot="R180"/>
<element name="JP3" library="pinhead" package="1X01" value="" x="79.375" y="13.97"/>
<element name="JP4" library="pinhead" package="1X01" value="" x="79.375" y="8.89"/>
<element name="H1" library="holes" package="3,2-PAD" value="MOUNT-PAD-ROUND3.2" x="4.445" y="4.445"/>
<element name="H2" library="holes" package="3,2-PAD" value="MOUNT-PAD-ROUND3.2" x="70.485" y="4.445"/>
<element name="JP5" library="pinhead" package="1X01" value="TRAF9V~" x="29.21" y="44.45" rot="R90"/>
<element name="JP6" library="pinhead" package="1X01" value="TRAF9V~" x="34.29" y="44.45" rot="R90"/>
<element name="JP7" library="pinhead" package="1X01" value="TRAF220V~" x="49.53" y="44.45" rot="R90"/>
<element name="JP8" library="pinhead" package="1X01" value="TRAF220V~" x="54.61" y="44.45" rot="R90"/>
<element name="B2" library="rectifier" package="FB15" value="" x="39.37" y="37.465"/>
<element name="C5" library="rcl" package="E5-10,5" value="1000uF" x="31.75" y="29.845"/>
<element name="C6" library="rcl" package="C1206K" value="100n" x="29.21" y="22.86" rot="MR270"/>
<element name="IC2" library="v-reg" package="78XXL" value="7812" x="38.1" y="21.59" rot="R270"/>
<element name="JP9" library="pinhead" package="1X01" value="11-15~" x="39.37" y="44.45" rot="R90"/>
<element name="JP10" library="pinhead" package="1X01" value="11-15~" x="44.45" y="44.45" rot="R90"/>
<element name="C7" library="rcl" package="E2,5-5" value="10uF" x="30.48" y="14.605" rot="R270"/>
<element name="JP11" library="pinhead" package="1X01" value="GND" x="24.13" y="44.45" rot="R90"/>
<element name="B3" library="rectifier" package="FB15" value="" x="60.325" y="37.465" rot="R180"/>
<element name="C8" library="rcl" package="E2,5-5" value="4u7-22u" x="62.865" y="29.845" rot="R180"/>
</elements>
<signals>
<signal name="GND">
<contactref element="C2" pad="2"/>
<contactref element="JP2" pad="1"/>
<contactref element="C1" pad="-"/>
<contactref element="IC1" pad="1"/>
<contactref element="Q1" pad="3"/>
<contactref element="C7" pad="-"/>
<contactref element="C6" pad="2"/>
<contactref element="C5" pad="-"/>
<contactref element="IC2" pad="GND"/>
<contactref element="B2" pad="-"/>
<wire x1="38.1" y1="29.845" x2="44.45" y2="29.845" width="1.27" layer="16"/>
<wire x1="5.715" y1="33.02" x2="5.715" y2="18.415" width="1.27" layer="16"/>
<wire x1="5.715" y1="18.415" x2="13.97" y2="18.415" width="1.27" layer="16"/>
<wire x1="13.97" y1="18.415" x2="13.97" y2="15.875" width="1.27" layer="16"/>
<wire x1="13.97" y1="15.875" x2="13.97" y2="4.445" width="1.27" layer="16"/>
<wire x1="13.97" y1="4.445" x2="16.51" y2="4.445" width="1.27" layer="16"/>
<wire x1="16.51" y1="4.445" x2="31.75" y2="4.445" width="1.27" layer="16"/>
<wire x1="34.29" y1="21.59" x2="38.1" y2="21.59" width="1.27" layer="16"/>
<wire x1="31.75" y1="4.445" x2="38.1" y2="4.445" width="1.27" layer="16"/>
<wire x1="38.1" y1="4.445" x2="38.1" y2="13.335" width="1.27" layer="16"/>
<wire x1="38.1" y1="13.335" x2="38.1" y2="21.59" width="1.27" layer="16"/>
<wire x1="46.8814" y1="37.465" x2="46.8814" y2="32.2764" width="1.27" layer="16"/>
<wire x1="46.8814" y1="32.2764" x2="44.45" y2="29.845" width="1.27" layer="16"/>
<wire x1="29.21" y1="21.36" x2="34.29" y2="21.59" width="1.27" layer="16"/>
<wire x1="34.29" y1="29.845" x2="38.1" y2="29.845" width="1.27" layer="16"/>
<wire x1="38.1" y1="29.845" x2="38.1" y2="21.59" width="1.27" layer="16"/>
<wire x1="16.51" y1="5.08" x2="16.51" y2="4.445" width="1.27" layer="16"/>
<wire x1="30.48" y1="13.335" x2="38.1" y2="13.335" width="1.27" layer="16"/>
<wire x1="12.827" y1="34.29" x2="11.557" y2="34.417" width="1.27" layer="16"/>
<wire x1="11.557" y1="34.417" x2="10.16" y2="33.02" width="1.27" layer="16"/>
<wire x1="10.16" y1="33.02" x2="5.715" y2="33.02" width="1.27" layer="16"/>
<contactref element="JP11" pad="1"/>
<wire x1="12.827" y1="34.29" x2="12.827" y2="35.687" width="1.27" layer="16"/>
<wire x1="12.827" y1="35.687" x2="17.145" y2="40.005" width="1.27" layer="16"/>
<wire x1="17.145" y1="40.005" x2="17.145" y2="41.91" width="1.27" layer="16"/>
<wire x1="17.145" y1="41.91" x2="19.685" y2="44.45" width="1.27" layer="16"/>
<wire x1="19.685" y1="44.45" x2="24.13" y2="44.45" width="1.27" layer="16"/>
</signal>
<signal name="N$12">
<contactref element="R1" pad="1"/>
<contactref element="IC1" pad="7"/>
<contactref element="R2" pad="1"/>
<wire x1="19.05" y1="28.705" x2="16.51" y2="28.705" width="1.27" layer="16"/>
<wire x1="16.51" y1="28.705" x2="16.135" y2="28.705" width="1.27" layer="16"/>
<wire x1="16.135" y1="28.705" x2="16.005" y2="28.575" width="1.27" layer="16"/>
<wire x1="16.51" y1="23.495" x2="16.51" y2="28.705" width="1.27" layer="16"/>
</signal>
<signal name="N$13">
<contactref element="IC1" pad="6"/>
<contactref element="IC1" pad="2"/>
<contactref element="R2" pad="2"/>
<contactref element="C2" pad="1"/>
<wire x1="16.51" y1="15.875" x2="16.51" y2="19.685" width="1.27" layer="16"/>
<wire x1="16.51" y1="19.685" x2="19.05" y2="19.685" width="1.27" layer="16"/>
<wire x1="19.05" y1="19.685" x2="19.05" y2="23.495" width="1.27" layer="16"/>
<wire x1="16.51" y1="10.16" x2="16.51" y2="15.875" width="1.27" layer="16"/>
<wire x1="19.05" y1="23.495" x2="19.05" y2="25.905" width="1.27" layer="16"/>
</signal>
<signal name="N$16">
<contactref element="R3" pad="1"/>
<contactref element="R4" pad="2"/>
<wire x1="24" y1="9.525" x2="20.32" y2="9.525" width="1.27" layer="16"/>
<wire x1="20.32" y1="9.525" x2="20.32" y2="9.395" width="1.27" layer="16"/>
</signal>
<signal name="N$17">
<contactref element="R3" pad="2"/>
<contactref element="IC1" pad="3"/>
<wire x1="20.32" y1="12.195" x2="19.05" y2="12.195" width="1.27" layer="16"/>
<wire x1="19.05" y1="12.195" x2="19.05" y2="15.875" width="1.27" layer="16"/>
</signal>
<signal name="N$18">
<contactref element="R4" pad="1"/>
<contactref element="Q1" pad="1"/>
<wire x1="31.75" y1="9.525" x2="26.8" y2="9.525" width="1.27" layer="16"/>
</signal>
<signal name="N$4">
<contactref element="R5" pad="2"/>
<contactref element="T1" pad="A"/>
<contactref element="R6" pad="2"/>
<contactref element="R7" pad="2"/>
<contactref element="JP3" pad="1"/>
<wire x1="76.835" y1="16.51" x2="79.375" y2="13.97" width="1.27" layer="16"/>
<wire x1="76.965" y1="17.145" x2="76.965" y2="20.32" width="1.27" layer="16"/>
<wire x1="76.965" y1="20.32" x2="76.835" y2="20.32" width="1.27" layer="16"/>
<wire x1="76.835" y1="20.32" x2="76.835" y2="26.035" width="1.27" layer="16"/>
<wire x1="76.835" y1="26.035" x2="76.835" y2="30.48" width="1.27" layer="16"/>
<wire x1="76.835" y1="30.48" x2="69.98" y2="30.48" width="1.27" layer="16"/>
<wire x1="69.98" y1="30.48" x2="69.85" y2="30.61" width="1.27" layer="16"/>
<wire x1="76.835" y1="16.51" x2="76.835" y2="17.145" width="1.27" layer="16"/>
<wire x1="76.835" y1="17.145" x2="76.965" y2="17.145" width="1.27" layer="16"/>
<wire x1="76.965" y1="16.51" x2="76.835" y2="16.51" width="1.27" layer="16"/>
<wire x1="67.945" y1="30.48" x2="69.85" y2="30.61" width="1.27" layer="16"/>
<contactref element="B3" pad="+"/>
<wire x1="67.825" y1="37.465" x2="67.945" y2="37.465" width="1.27" layer="16"/>
<wire x1="67.945" y1="37.465" x2="67.945" y2="30.48" width="1.27" layer="16"/>
</signal>
<signal name="N$5">
<contactref element="D3" pad="2"/>
<contactref element="T1" pad="G"/>
<wire x1="79.375" y1="22.225" x2="79.375" y2="26.035" width="1.27" layer="16"/>
</signal>
<signal name="N$6">
<contactref element="D3" pad="1"/>
<contactref element="R5" pad="1"/>
<contactref element="C3" pad="+"/>
<wire x1="71.755" y1="22.225" x2="69.85" y2="22.225" width="1.27" layer="16"/>
<wire x1="69.85" y1="22.225" x2="69.85" y2="24.13" width="1.27" layer="16"/>
<wire x1="69.85" y1="24.13" x2="69.85" y2="27.81" width="1.27" layer="16"/>
<wire x1="64.135" y1="24.13" x2="69.85" y2="24.13" width="1.27" layer="16"/>
<contactref element="C8" pad="+"/>
<wire x1="64.135" y1="29.845" x2="64.135" y2="24.13" width="1.27" layer="16"/>
</signal>
<signal name="N$19">
<contactref element="R7" pad="1"/>
<contactref element="C4" pad="1"/>
<wire x1="71.628" y1="16.51" x2="74.165" y2="16.51" width="1.27" layer="16"/>
</signal>
<signal name="AGND">
<contactref element="C3" pad="-"/>
<contactref element="T1" pad="C"/>
<contactref element="R6" pad="1"/>
<contactref element="C4" pad="2"/>
<contactref element="JP4" pad="1"/>
<wire x1="74.165" y1="20.32" x2="74.295" y2="20.32" width="1.27" layer="16"/>
<wire x1="74.295" y1="20.32" x2="74.295" y2="26.035" width="1.27" layer="16"/>
<wire x1="56.642" y1="16.51" x2="58.42" y2="16.51" width="1.27" layer="16"/>
<wire x1="58.42" y1="16.51" x2="58.42" y2="24.13" width="1.27" layer="16"/>
<wire x1="79.375" y1="8.89" x2="76.2" y2="8.89" width="1.27" layer="16"/>
<wire x1="76.2" y1="8.89" x2="73.025" y2="12.065" width="1.27" layer="16"/>
<wire x1="73.025" y1="12.065" x2="65.405" y2="12.065" width="1.27" layer="16"/>
<wire x1="65.405" y1="12.065" x2="58.42" y2="12.065" width="1.27" layer="16"/>
<wire x1="58.42" y1="12.065" x2="58.42" y2="16.51" width="1.27" layer="16"/>
<wire x1="61.595" y1="24.13" x2="58.42" y2="24.13" width="1.27" layer="16"/>
<wire x1="74.165" y1="20.32" x2="74.165" y2="19.685" width="1.27" layer="16"/>
<wire x1="74.165" y1="19.685" x2="65.405" y2="19.685" width="1.27" layer="16"/>
<wire x1="65.405" y1="19.685" x2="65.405" y2="12.065" width="1.27" layer="16"/>
<wire x1="58.42" y1="31.8586" x2="58.42" y2="29.845" width="1.27" layer="16"/>
<contactref element="B3" pad="-"/>
<wire x1="58.42" y1="29.845" x2="58.42" y2="24.13" width="1.27" layer="16"/>
<wire x1="58.42" y1="31.8586" x2="52.8136" y2="37.465" width="1.27" layer="16"/>
<contactref element="C8" pad="-"/>
<wire x1="61.595" y1="29.845" x2="58.42" y2="29.845" width="1.27" layer="16"/>
</signal>
<signal name="N$7">
<via x="5.715" y="38.1" extent="1-16" drill="0.6" diameter="3.81"/>
</signal>
<signal name="N$8">
<via x="5.715" y="33.02" extent="1-16" drill="0.6" diameter="3.81"/>
</signal>
<signal name="N$11">
<via x="79.375" y="13.97" extent="1-16" drill="0.6" diameter="3.81"/>
</signal>
<signal name="N$14">
<via x="79.375" y="8.89" extent="1-16" drill="0.6" diameter="3.81"/>
</signal>
<signal name="N$2">
<contactref element="JP6" pad="1"/>
<contactref element="Q1" pad="2"/>
<wire x1="34.29" y1="44.45" x2="26.035" y2="36.195" width="1.27" layer="16"/>
<wire x1="26.035" y1="36.195" x2="26.035" y2="20.32" width="1.27" layer="16"/>
<via x="26.035" y="20.32" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="26.035" y1="20.32" x2="26.035" y2="6.985" width="0.254" layer="1"/>
<via x="26.035" y="6.985" extent="1-16" drill="0.6" diameter="1.6764"/>
<wire x1="26.035" y1="6.985" x2="31.75" y2="6.985" width="1.27" layer="16"/>
</signal>
<signal name="N$3">
<contactref element="JP7" pad="1"/>
<contactref element="B3" pad="AC2"/>
<wire x1="49.53" y1="44.45" x2="52.705" y2="41.275" width="1.27" layer="16"/>
<wire x1="52.705" y1="41.275" x2="53.982" y2="41.275" width="1.27" layer="16"/>
<wire x1="53.982" y1="41.275" x2="57.792" y2="37.465" width="1.27" layer="16"/>
</signal>
<signal name="N$10">
<contactref element="JP8" pad="1"/>
<contactref element="B3" pad="AC1"/>
<wire x1="54.61" y1="44.45" x2="59.055" y2="44.45" width="1.27" layer="16"/>
<wire x1="59.055" y1="44.45" x2="62.865" y2="40.64" width="1.27" layer="16"/>
<wire x1="62.865" y1="40.64" x2="62.865" y2="37.5088" width="1.27" layer="16"/>
<wire x1="62.865" y1="37.5088" x2="62.8212" y2="37.465" width="1.27" layer="16"/>
</signal>
<signal name="N$15">
<contactref element="JP9" pad="1"/>
<contactref element="B2" pad="AC1"/>
<wire x1="36.8738" y1="37.465" x2="39.37" y2="40.005" width="1.27" layer="16"/>
<wire x1="39.37" y1="40.005" x2="39.37" y2="44.45" width="1.27" layer="16"/>
</signal>
<signal name="N$21">
<contactref element="C7" pad="+"/>
<contactref element="IC2" pad="OUT"/>
<contactref element="C1" pad="+"/>
<contactref element="IC1" pad="8"/>
<contactref element="IC1" pad="4"/>
<contactref element="R1" pad="2"/>
<contactref element="JP5" pad="1"/>
<wire x1="23.495" y1="15.875" x2="21.59" y2="15.875" width="1.27" layer="16"/>
<contactref element="D1" pad="C"/>
<wire x1="23.495" y1="38.735" x2="23.495" y2="34.29" width="1.27" layer="16"/>
<wire x1="23.495" y1="34.29" x2="23.495" y2="15.875" width="1.27" layer="16"/>
<wire x1="23.495" y1="15.875" x2="30.48" y2="15.875" width="1.27" layer="16"/>
<wire x1="30.48" y1="15.875" x2="30.48" y2="19.05" width="1.27" layer="16"/>
<wire x1="30.48" y1="19.05" x2="34.29" y2="19.05" width="1.27" layer="16"/>
<wire x1="13.97" y1="23.495" x2="13.205" y2="24.26" width="1.27" layer="16"/>
<wire x1="13.205" y1="24.26" x2="13.205" y2="28.575" width="1.27" layer="16"/>
<wire x1="16.383" y1="34.29" x2="16.51" y2="34.29" width="1.27" layer="16"/>
<wire x1="16.51" y1="34.29" x2="23.495" y2="34.29" width="1.27" layer="16"/>
<wire x1="13.205" y1="28.575" x2="13.205" y2="30.985" width="1.27" layer="16"/>
<wire x1="13.205" y1="30.985" x2="16.51" y2="34.29" width="1.27" layer="16"/>
<wire x1="16.51" y1="34.29" x2="16.51" y2="34.163" width="1.27" layer="16"/>
<wire x1="16.51" y1="34.163" x2="16.383" y2="34.29" width="1.27" layer="16"/>
<wire x1="29.21" y1="44.45" x2="23.8125" y2="39.0525" width="1.27" layer="16"/>
<wire x1="23.8125" y1="39.0525" x2="23.495" y2="38.735" width="1.27" layer="16"/>
<wire x1="20.32" y1="40.005" x2="22.225" y2="40.005" width="1.27" layer="16"/>
<wire x1="22.225" y1="40.005" x2="23.8125" y2="39.0525" width="1.27" layer="16"/>
</signal>
<signal name="N$26">
<contactref element="C5" pad="+"/>
<contactref element="C6" pad="1"/>
<contactref element="IC2" pad="IN"/>
<contactref element="B2" pad="+"/>
<wire x1="29.21" y1="29.845" x2="29.21" y2="34.805" width="1.27" layer="16"/>
<wire x1="29.21" y1="34.805" x2="31.87" y2="37.465" width="1.27" layer="16"/>
<wire x1="29.21" y1="29.845" x2="29.21" y2="24.36" width="1.27" layer="16"/>
<wire x1="29.21" y1="24.36" x2="34.29" y2="24.13" width="1.27" layer="16"/>
</signal>
<signal name="N$9">
<contactref element="JP10" pad="1"/>
<contactref element="B2" pad="AC2"/>
<wire x1="41.903" y1="37.465" x2="44.45" y2="40.005" width="1.27" layer="16"/>
<wire x1="44.45" y1="40.005" x2="44.45" y2="44.45" width="1.27" layer="16"/>
</signal>
<signal name="N$20">
<via x="29.21" y="44.45" extent="1-16" drill="0.6" diameter="3.81"/>
</signal>
<signal name="N$22">
<via x="34.29" y="44.45" extent="1-16" drill="0.6" diameter="3.81"/>
</signal>
<signal name="N$23">
<via x="39.37" y="44.45" extent="1-16" drill="0.6" diameter="3.81"/>
</signal>
<signal name="N$24">
<via x="44.45" y="44.45" extent="1-16" drill="0.6" diameter="3.81"/>
</signal>
<signal name="N$25">
<via x="49.53" y="44.45" extent="1-16" drill="0.6" diameter="3.81"/>
</signal>
<signal name="N$27">
<via x="54.61" y="44.45" extent="1-16" drill="0.6" diameter="3.81"/>
</signal>
<signal name="N$1">
<contactref element="JP1" pad="1"/>
<contactref element="D1" pad="A"/>
<wire x1="5.715" y1="38.1" x2="5.715" y2="40.005" width="1.27" layer="16"/>
<wire x1="5.715" y1="40.005" x2="12.7" y2="40.005" width="1.27" layer="16"/>
</signal>
<signal name="N$28">
<via x="24.13" y="44.45" extent="1-16" drill="0.6" diameter="3.81"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
