<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="6.3">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="1" unitdist="mic" unit="mm" style="lines" multiple="1" display="no" altdistance="1" altunitdist="mic" altunit="mm"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="no" active="no"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="no"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="no"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="no"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="no"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="no"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="no"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="no"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="no"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="no"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="no"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="no"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="no"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="no"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="yes" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="yes" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="yes" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="yes" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="yes" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="yes" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="yes" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="yes" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="yes" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="yes" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="yes" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="yes" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="yes" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="no" active="no"/>
<layer number="92" name="Busses" color="1" fill="1" visible="no" active="no"/>
<layer number="93" name="Pins" color="2" fill="1" visible="no" active="no"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="no" active="no"/>
<layer number="95" name="Names" color="7" fill="1" visible="no" active="no"/>
<layer number="96" name="Values" color="7" fill="1" visible="no" active="no"/>
<layer number="97" name="Info" color="7" fill="1" visible="no" active="no"/>
<layer number="98" name="Guide" color="6" fill="1" visible="no" active="no"/>
</layers>
<board>
<plain>
<text x="41.916" y="48.488" size="0.8128" layer="28" distance="25" rot="MR270">REF=MCP1541I</text>
<text x="92.861" y="25.894" size="0.8128" layer="28" distance="25" rot="MR0">TR1=BC847</text>
<circle x="135.371" y="18.886" radius="1.888653125" width="0.6096" layer="16"/>
<circle x="173.386" y="18.296" radius="1.888653125" width="0.6096" layer="16"/>
<circle x="173.288" y="85.218" radius="1.888653125" width="0.6096" layer="16"/>
<circle x="135.273" y="85.414" radius="1.888653125" width="0.6096" layer="16"/>
<circle x="27.632" y="124.492" radius="1.888653125" width="0.6096" layer="16"/>
<circle x="27.734" y="107.654" radius="1.888653125" width="0.6096" layer="16"/>
<circle x="106.134" y="108.5" radius="1.888653125" width="0.6096" layer="16"/>
<circle x="106.205" y="124.452" radius="1.888653125" width="0.6096" layer="16"/>
<circle x="24.349" y="83.821" radius="1.887484375" width="0.6096" layer="16"/>
<circle x="106.583" y="83.557" radius="1.85256875" width="0.6096" layer="16"/>
<circle x="106.428" y="22.413" radius="2.093853125" width="0.6096" layer="16"/>
<circle x="24.642" y="22.372" radius="1.905075" width="0.6096" layer="16"/>
<hole x="24.66" y="22.363" drill="3.2"/>
<hole x="106.582" y="22.363" drill="3.2"/>
<hole x="24.296" y="83.885" drill="3.2"/>
<hole x="106.711" y="83.637" drill="3.2"/>
<hole x="106.263" y="124.357" drill="3.2"/>
<hole x="106.13" y="108.506" drill="3.2"/>
<hole x="27.891" y="124.49" drill="3.2"/>
<hole x="27.891" y="107.574" drill="3.2"/>
<hole x="173.471" y="18.225" drill="3.2"/>
<hole x="135.214" y="18.558" drill="3.2"/>
<circle x="135.162" y="85.414" radius="1.888653125" width="0.6096" layer="16"/>
<hole x="135.325" y="85.32" drill="3.2"/>
<hole x="173.138" y="85.209" drill="3.2"/>
</plain>
<libraries>
<library name="microchip">
<description>&lt;b&gt;Microchip PIC Microcontrollers and other Devices&lt;/b&gt;&lt;p&gt;
Based on the following sources :
&lt;ul&gt;
&lt;li&gt;Microchip Data Book, 1993
&lt;li&gt;THE EMERGING WORLD STANDARD, 1995/1996
&lt;li&gt;Microchip, Technical Library CD-ROM, June 1998
&lt;li&gt;www.microchip.com
&lt;/ul&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;</description>
<packages>
<package name="TQFP44">
<description>&lt;b&gt;Thin Quad Flat Pack&lt;/b&gt;&lt;p&gt;
package type TQ</description>
<wire x1="-4.8" y1="4.4" x2="-4.4" y2="4.8" width="0.2032" layer="21"/>
<wire x1="-4.4" y1="4.8" x2="4.4" y2="4.8" width="0.2032" layer="21"/>
<wire x1="4.4" y1="4.8" x2="4.8" y2="4.4" width="0.2032" layer="21"/>
<wire x1="4.8" y1="4.4" x2="4.8" y2="-4.4" width="0.2032" layer="21"/>
<wire x1="4.8" y1="-4.4" x2="4.4" y2="-4.8" width="0.2032" layer="21"/>
<wire x1="4.4" y1="-4.8" x2="-4.4" y2="-4.8" width="0.2032" layer="21"/>
<wire x1="-4.4" y1="-4.8" x2="-4.8" y2="-4.4" width="0.2032" layer="21"/>
<wire x1="-4.8" y1="-4.4" x2="-4.8" y2="4.4" width="0.2032" layer="21"/>
<circle x="-4" y="4" radius="0.2827" width="0.254" layer="21"/>
<smd name="1" x="-5.8" y="4" dx="1.5" dy="0.5" layer="1"/>
<smd name="2" x="-5.8" y="3.2" dx="1.5" dy="0.5" layer="1"/>
<smd name="3" x="-5.8" y="2.4" dx="1.5" dy="0.5" layer="1"/>
<smd name="4" x="-5.8" y="1.6" dx="1.5" dy="0.5" layer="1"/>
<smd name="5" x="-5.8" y="0.8" dx="1.5" dy="0.5" layer="1"/>
<smd name="6" x="-5.8" y="0" dx="1.5" dy="0.5" layer="1"/>
<smd name="7" x="-5.8" y="-0.8" dx="1.5" dy="0.5" layer="1"/>
<smd name="8" x="-5.8" y="-1.6" dx="1.5" dy="0.5" layer="1"/>
<smd name="9" x="-5.8" y="-2.4" dx="1.5" dy="0.5" layer="1"/>
<smd name="10" x="-5.8" y="-3.2" dx="1.5" dy="0.5" layer="1"/>
<smd name="11" x="-5.8" y="-4" dx="1.5" dy="0.5" layer="1"/>
<smd name="12" x="-4" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="13" x="-3.2" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="14" x="-2.4" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="15" x="-1.6" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="16" x="-0.8" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="17" x="0" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="18" x="0.8" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="19" x="1.6" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="20" x="2.4" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="21" x="3.2" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="22" x="4" y="-5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="23" x="5.8" y="-4" dx="1.5" dy="0.5" layer="1"/>
<smd name="24" x="5.8" y="-3.2" dx="1.5" dy="0.5" layer="1"/>
<smd name="25" x="5.8" y="-2.4" dx="1.5" dy="0.5" layer="1"/>
<smd name="26" x="5.8" y="-1.6" dx="1.5" dy="0.5" layer="1"/>
<smd name="27" x="5.8" y="-0.8" dx="1.5" dy="0.5" layer="1"/>
<smd name="28" x="5.8" y="0" dx="1.5" dy="0.5" layer="1"/>
<smd name="29" x="5.8" y="0.8" dx="1.5" dy="0.5" layer="1"/>
<smd name="30" x="5.8" y="1.6" dx="1.5" dy="0.5" layer="1"/>
<smd name="31" x="5.8" y="2.4" dx="1.5" dy="0.5" layer="1"/>
<smd name="32" x="5.8" y="3.2" dx="1.5" dy="0.5" layer="1"/>
<smd name="33" x="5.8" y="4" dx="1.5" dy="0.5" layer="1"/>
<smd name="34" x="4" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="35" x="3.2" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="36" x="2.4" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="37" x="1.6" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="38" x="0.8" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="39" x="0" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="40" x="-0.8" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="41" x="-1.6" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="42" x="-2.4" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="43" x="-3.2" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<smd name="44" x="-4" y="5.8" dx="0.5" dy="1.5" layer="1"/>
<text x="-4.064" y="6.858" size="1.778" layer="25">&gt;NAME</text>
<text x="-4.064" y="-1.7701" size="1.778" layer="27">&gt;VALUE</text>
<rectangle x1="-6.1001" y1="3.8001" x2="-4.95" y2="4.1999" layer="51"/>
<rectangle x1="-6.1001" y1="3" x2="-4.95" y2="3.4" layer="51"/>
<rectangle x1="-6.1001" y1="2.1999" x2="-4.95" y2="2.5999" layer="51"/>
<rectangle x1="-6.1001" y1="1.4" x2="-4.95" y2="1.8001" layer="51"/>
<rectangle x1="-6.1001" y1="0.5999" x2="-4.95" y2="1" layer="51"/>
<rectangle x1="-6.1001" y1="-0.1999" x2="-4.95" y2="0.1999" layer="51"/>
<rectangle x1="-6.1001" y1="-1" x2="-4.95" y2="-0.5999" layer="51"/>
<rectangle x1="-6.1001" y1="-1.8001" x2="-4.95" y2="-1.4" layer="51"/>
<rectangle x1="-6.1001" y1="-2.5999" x2="-4.95" y2="-2.1999" layer="51"/>
<rectangle x1="-6.1001" y1="-3.4" x2="-4.95" y2="-3" layer="51"/>
<rectangle x1="-6.1001" y1="-4.1999" x2="-4.95" y2="-3.8001" layer="51"/>
<rectangle x1="-4.1999" y1="-6.1001" x2="-3.8001" y2="-4.95" layer="51"/>
<rectangle x1="-3.4" y1="-6.1001" x2="-3" y2="-4.95" layer="51"/>
<rectangle x1="-2.5999" y1="-6.1001" x2="-2.1999" y2="-4.95" layer="51"/>
<rectangle x1="-1.8001" y1="-6.1001" x2="-1.4" y2="-4.95" layer="51"/>
<rectangle x1="-1" y1="-6.1001" x2="-0.5999" y2="-4.95" layer="51"/>
<rectangle x1="-0.1999" y1="-6.1001" x2="0.1999" y2="-4.95" layer="51"/>
<rectangle x1="0.5999" y1="-6.1001" x2="1" y2="-4.95" layer="51"/>
<rectangle x1="1.4" y1="-6.1001" x2="1.8001" y2="-4.95" layer="51"/>
<rectangle x1="2.1999" y1="-6.1001" x2="2.5999" y2="-4.95" layer="51"/>
<rectangle x1="3" y1="-6.1001" x2="3.4" y2="-4.95" layer="51"/>
<rectangle x1="3.8001" y1="-6.1001" x2="4.1999" y2="-4.95" layer="51"/>
<rectangle x1="4.95" y1="-4.1999" x2="6.1001" y2="-3.8001" layer="51"/>
<rectangle x1="4.95" y1="-3.4" x2="6.1001" y2="-3" layer="51"/>
<rectangle x1="4.95" y1="-2.5999" x2="6.1001" y2="-2.1999" layer="51"/>
<rectangle x1="4.95" y1="-1.8001" x2="6.1001" y2="-1.4" layer="51"/>
<rectangle x1="4.95" y1="-1" x2="6.1001" y2="-0.5999" layer="51"/>
<rectangle x1="4.95" y1="-0.1999" x2="6.1001" y2="0.1999" layer="51"/>
<rectangle x1="4.95" y1="0.5999" x2="6.1001" y2="1" layer="51"/>
<rectangle x1="4.95" y1="1.4" x2="6.1001" y2="1.8001" layer="51"/>
<rectangle x1="4.95" y1="2.1999" x2="6.1001" y2="2.5999" layer="51"/>
<rectangle x1="4.95" y1="3" x2="6.1001" y2="3.4" layer="51"/>
<rectangle x1="4.95" y1="3.8001" x2="6.1001" y2="4.1999" layer="51"/>
<rectangle x1="3.8001" y1="4.95" x2="4.1999" y2="6.1001" layer="51"/>
<rectangle x1="3" y1="4.95" x2="3.4" y2="6.1001" layer="51"/>
<rectangle x1="2.1999" y1="4.95" x2="2.5999" y2="6.1001" layer="51"/>
<rectangle x1="1.4" y1="4.95" x2="1.8001" y2="6.1001" layer="51"/>
<rectangle x1="0.5999" y1="4.95" x2="1" y2="6.1001" layer="51"/>
<rectangle x1="-0.1999" y1="4.95" x2="0.1999" y2="6.1001" layer="51"/>
<rectangle x1="-1" y1="4.95" x2="-0.5999" y2="6.1001" layer="51"/>
<rectangle x1="-1.8001" y1="4.95" x2="-1.4" y2="6.1001" layer="51"/>
<rectangle x1="-2.5999" y1="4.95" x2="-2.1999" y2="6.1001" layer="51"/>
<rectangle x1="-3.4" y1="4.95" x2="-3" y2="6.1001" layer="51"/>
<rectangle x1="-4.1999" y1="4.95" x2="-3.8001" y2="6.1001" layer="51"/>
</package>
</packages>
</library>
<library name="resistor">
<description>&lt;b&gt;Resistors, Capacitors, Inductors&lt;/b&gt;&lt;p&gt;
Based on the previous libraries:
&lt;ul&gt;
&lt;li&gt;r.lbr
&lt;li&gt;cap.lbr
&lt;li&gt;cap-fe.lbr
&lt;li&gt;captant.lbr
&lt;li&gt;polcap.lbr
&lt;li&gt;ipc-smd.lbr
&lt;/ul&gt;
All SMD packages are defined according to the IPC specifications and  CECC&lt;p&gt;
&lt;author&gt;Created by librarian@cadsoft.de&lt;/author&gt;&lt;p&gt;
&lt;p&gt;
for Electrolyt Capacitors see also :&lt;p&gt;
www.bccomponents.com &lt;p&gt;
www.panasonic.com&lt;p&gt;
www.kemet.com&lt;p&gt;
&lt;p&gt;
for trimmer refence see : &lt;u&gt;www.electrospec-inc.com/cross_references/trimpotcrossref.asp&lt;/u&gt;&lt;p&gt;
&lt;map name="nav_main"&gt;
&lt;area shape="rect" coords="0,1,140,23" href="../military_specs.asp" title=""&gt;
&lt;area shape="rect" coords="0,24,140,51" href="../about.asp" title=""&gt;
&lt;area shape="rect" coords="1,52,140,77" href="../rfq.asp" title=""&gt;
&lt;area shape="rect" coords="0,78,139,103" href="../products.asp" title=""&gt;
&lt;area shape="rect" coords="1,102,138,128" href="../excess_inventory.asp" title=""&gt;
&lt;area shape="rect" coords="1,129,138,150" href="../edge.asp" title=""&gt;
&lt;area shape="rect" coords="1,151,139,178" href="../industry_links.asp" title=""&gt;
&lt;area shape="rect" coords="0,179,139,201" href="../comments.asp" title=""&gt;
&lt;area shape="rect" coords="1,203,138,231" href="../directory.asp" title=""&gt;
&lt;area shape="default" nohref&gt;
&lt;/map&gt;
&lt;html&gt;
&lt;title&gt;&lt;/title&gt;
 &lt;LINK REL="StyleSheet" TYPE="text/css" HREF="style-sheet.css"&gt;
&lt;body bgcolor="#ffffff" text="#000000" marginwidth="0" marginheight="0" topmargin="0" leftmargin="0"&gt;
&lt;table border=0 cellspacing=0 cellpadding=0 width="100%" cellpaddding=0 height="55%"&gt;
&lt;tr valign="top"&gt;
&lt;/td&gt;
&lt;! &lt;td width="10"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td width="90%"&gt;
&lt;b&gt;&lt;font color="#0000FF" size="4"&gt;TRIM-POT CROSS REFERENCE&lt;/font&gt;&lt;/b&gt;
&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=2&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;RECTANGULAR MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD ALIGN=CENTER&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BOURNS&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;BI&amp;nbsp;TECH&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;DALE-VISHAY&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PHILIPS/MEPCO&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MURATA&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;PANASONIC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;SPECTROL&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;
      &lt;B&gt;
      &lt;FONT SIZE=3 FACE=ARIAL color="#FF0000"&gt;MILSPEC&lt;/FONT&gt;
      &lt;/B&gt;
    &lt;/TD&gt;&lt;TD&gt;&amp;nbsp;&lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3 &gt;
      3005P&lt;BR&gt;
      3006P&lt;BR&gt;
      3006W&lt;BR&gt;
      3006Y&lt;BR&gt;
      3009P&lt;BR&gt;
      3009W&lt;BR&gt;
      3009Y&lt;BR&gt;
      3057J&lt;BR&gt;
      3057L&lt;BR&gt;
      3057P&lt;BR&gt;
      3057Y&lt;BR&gt;
      3059J&lt;BR&gt;
      3059L&lt;BR&gt;
      3059P&lt;BR&gt;
      3059Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD BGCOLOR="#cccccc" ALIGN=CENTER&gt;&lt;FONT FACE=ARIAL SIZE=3&gt;
      -&lt;BR&gt;
      89P&lt;BR&gt;
      89W&lt;BR&gt;
      89X&lt;BR&gt;
      89PH&lt;BR&gt;
      76P&lt;BR&gt;
      89XH&lt;BR&gt;
      78SLT&lt;BR&gt;
      78L&amp;nbsp;ALT&lt;BR&gt;
      56P&amp;nbsp;ALT&lt;BR&gt;
      78P&amp;nbsp;ALT&lt;BR&gt;
      T8S&lt;BR&gt;
      78L&lt;BR&gt;
      56P&lt;BR&gt;
      78P&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      T18/784&lt;BR&gt;
      783&lt;BR&gt;
      781&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2199&lt;BR&gt;
      1697/1897&lt;BR&gt;
      1680/1880&lt;BR&gt;
      2187&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      8035EKP/CT20/RJ-20P&lt;BR&gt;
      -&lt;BR&gt;
      RJ-20X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      1211L&lt;BR&gt;
      8012EKQ&amp;nbsp;ALT&lt;BR&gt;
      8012EKR&amp;nbsp;ALT&lt;BR&gt;
      1211P&lt;BR&gt;
      8012EKJ&lt;BR&gt;
      8012EKL&lt;BR&gt;
      8012EKQ&lt;BR&gt;
      8012EKR&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      2101P&lt;BR&gt;
      2101W&lt;BR&gt;
      2101Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      2102L&lt;BR&gt;
      2102S&lt;BR&gt;
      2102Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVMCOG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      43P&lt;BR&gt;
      43W&lt;BR&gt;
      43Y&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      40L&lt;BR&gt;
      40P&lt;BR&gt;
      40Y&lt;BR&gt;
      70Y-T602&lt;BR&gt;
      70L&lt;BR&gt;
      70P&lt;BR&gt;
      70Y&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      RT/RTR12&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;
      RJ/RJR12&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=8&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SQUARE MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BI&amp;nbsp;TECH&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;DALE-VISHAY&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PHILIPS/MEPCO&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MURATA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;PANASONIC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;SPECTROL&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;MILSPEC&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3250L&lt;BR&gt;
      3250P&lt;BR&gt;
      3250W&lt;BR&gt;
      3250X&lt;BR&gt;
      3252P&lt;BR&gt;
      3252W&lt;BR&gt;
      3252X&lt;BR&gt;
      3260P&lt;BR&gt;
      3260W&lt;BR&gt;
      3260X&lt;BR&gt;
      3262P&lt;BR&gt;
      3262W&lt;BR&gt;
      3262X&lt;BR&gt;
      3266P&lt;BR&gt;
      3266W&lt;BR&gt;
      3266X&lt;BR&gt;
      3290H&lt;BR&gt;
      3290P&lt;BR&gt;
      3290W&lt;BR&gt;
      3292P&lt;BR&gt;
      3292W&lt;BR&gt;
      3292X&lt;BR&gt;
      3296P&lt;BR&gt;
      3296W&lt;BR&gt;
      3296X&lt;BR&gt;
      3296Y&lt;BR&gt;
      3296Z&lt;BR&gt;
      3299P&lt;BR&gt;
      3299W&lt;BR&gt;
      3299X&lt;BR&gt;
      3299Y&lt;BR&gt;
      3299Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      66P&amp;nbsp;ALT&lt;BR&gt;
      66W&amp;nbsp;ALT&lt;BR&gt;
      66X&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64W&amp;nbsp;ALT&lt;BR&gt;
      -&lt;BR&gt;
      64P&amp;nbsp;ALT&lt;BR&gt;
      64X&amp;nbsp;ALT&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      66P&lt;BR&gt;
      66W&lt;BR&gt;
      66X&lt;BR&gt;
      67P&lt;BR&gt;
      67W&lt;BR&gt;
      67X&lt;BR&gt;
      67Y&lt;BR&gt;
      67Z&lt;BR&gt;
      68P&lt;BR&gt;
      68W&lt;BR&gt;
      68X&lt;BR&gt;
      67Y&amp;nbsp;ALT&lt;BR&gt;
      67Z&amp;nbsp;ALT&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      5050&lt;BR&gt;
      5091&lt;BR&gt;
      5080&lt;BR&gt;
      5087&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T63YB&lt;BR&gt;
      T63XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      5887&lt;BR&gt;
      5891&lt;BR&gt;
      5880&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T93Z&lt;BR&gt;
      T93YA&lt;BR&gt;
      T93XA&lt;BR&gt;
      T93YB&lt;BR&gt;
      T93XB&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKW&lt;BR&gt;
      8026EKM&lt;BR&gt;
      8026EKP&lt;BR&gt;
      8026EKB&lt;BR&gt;
      8026EKM&lt;BR&gt;
      1309X&lt;BR&gt;
      1309P&lt;BR&gt;
      1309W&lt;BR&gt;
      8024EKP&lt;BR&gt;
      8024EKW&lt;BR&gt;
      8024EKN&lt;BR&gt;
      RJ-9P/CT9P&lt;BR&gt;
      RJ-9W&lt;BR&gt;
      RJ-9X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      3103P&lt;BR&gt;
      3103Y&lt;BR&gt;
      3103Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3105P/3106P&lt;BR&gt;
      3105W/3106W&lt;BR&gt;
      3105X/3106X&lt;BR&gt;
      3105Y/3106Y&lt;BR&gt;
      3105Z/3105Z&lt;BR&gt;
      3102P&lt;BR&gt;
      3102W&lt;BR&gt;
      3102X&lt;BR&gt;
      3102Y&lt;BR&gt;
      3102Z&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMCBG&lt;BR&gt;
      EVMCCG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      55-1-X&lt;BR&gt;
      55-4-X&lt;BR&gt;
      55-3-X&lt;BR&gt;
      55-2-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      50-2-X&lt;BR&gt;
      50-4-X&lt;BR&gt;
      50-3-X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      64P&lt;BR&gt;
      64W&lt;BR&gt;
      64X&lt;BR&gt;
      64Y&lt;BR&gt;
      64Z&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RT/RTR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RJ/RJR22&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RT/RTR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RJ/RJR26&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RT/RTR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      RJ/RJR24&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SINGLE TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3323P&lt;BR&gt;
      3323S&lt;BR&gt;
      3323W&lt;BR&gt;
      3329H&lt;BR&gt;
      3329P&lt;BR&gt;
      3329W&lt;BR&gt;
      3339H&lt;BR&gt;
      3339P&lt;BR&gt;
      3339W&lt;BR&gt;
      3352E&lt;BR&gt;
      3352H&lt;BR&gt;
      3352K&lt;BR&gt;
      3352P&lt;BR&gt;
      3352T&lt;BR&gt;
      3352V&lt;BR&gt;
      3352W&lt;BR&gt;
      3362H&lt;BR&gt;
      3362M&lt;BR&gt;
      3362P&lt;BR&gt;
      3362R&lt;BR&gt;
      3362S&lt;BR&gt;
      3362U&lt;BR&gt;
      3362W&lt;BR&gt;
      3362X&lt;BR&gt;
      3386B&lt;BR&gt;
      3386C&lt;BR&gt;
      3386F&lt;BR&gt;
      3386H&lt;BR&gt;
      3386K&lt;BR&gt;
      3386M&lt;BR&gt;
      3386P&lt;BR&gt;
      3386S&lt;BR&gt;
      3386W&lt;BR&gt;
      3386X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      25P&lt;BR&gt;
      25S&lt;BR&gt;
      25RX&lt;BR&gt;
      82P&lt;BR&gt;
      82M&lt;BR&gt;
      82PA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      91E&lt;BR&gt;
      91X&lt;BR&gt;
      91T&lt;BR&gt;
      91B&lt;BR&gt;
      91A&lt;BR&gt;
      91V&lt;BR&gt;
      91W&lt;BR&gt;
      25W&lt;BR&gt;
      25V&lt;BR&gt;
      25P&lt;BR&gt;
      -&lt;BR&gt;
      25S&lt;BR&gt;
      25U&lt;BR&gt;
      25RX&lt;BR&gt;
      25X&lt;BR&gt;
      72XW&lt;BR&gt;
      72XL&lt;BR&gt;
      72PM&lt;BR&gt;
      72RX&lt;BR&gt;
      -&lt;BR&gt;
      72PX&lt;BR&gt;
      72P&lt;BR&gt;
      72RXW&lt;BR&gt;
      72RXL&lt;BR&gt;
      72X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      T7YB&lt;BR&gt;
      T7YA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      TXD&lt;BR&gt;
      TYA&lt;BR&gt;
      TYP&lt;BR&gt;
      -&lt;BR&gt;
      TYD&lt;BR&gt;
      TX&lt;BR&gt;
      -&lt;BR&gt;
      150SX&lt;BR&gt;
      100SX&lt;BR&gt;
      102T&lt;BR&gt;
      101S&lt;BR&gt;
      190T&lt;BR&gt;
      150TX&lt;BR&gt;
      101&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      101SX&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ET6P&lt;BR&gt;
      ET6S&lt;BR&gt;
      ET6X&lt;BR&gt;
      RJ-6W/8014EMW&lt;BR&gt;
      RJ-6P/8014EMP&lt;BR&gt;
      RJ-6X/8014EMX&lt;BR&gt;
      TM7W&lt;BR&gt;
      TM7P&lt;BR&gt;
      TM7X&lt;BR&gt;
      -&lt;BR&gt;
      8017SMS&lt;BR&gt;
      -&lt;BR&gt;
      8017SMB&lt;BR&gt;
      8017SMA&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      CT-6W&lt;BR&gt;
      CT-6H&lt;BR&gt;
      CT-6P&lt;BR&gt;
      CT-6R&lt;BR&gt;
      -&lt;BR&gt;
      CT-6V&lt;BR&gt;
      CT-6X&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKV&lt;BR&gt;
      -&lt;BR&gt;
      8038EKX&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      8038EKP&lt;BR&gt;
      8038EKZ&lt;BR&gt;
      8038EKW&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3321H&lt;BR&gt;
      3321P&lt;BR&gt;
      3321N&lt;BR&gt;
      1102H&lt;BR&gt;
      1102P&lt;BR&gt;
      1102T&lt;BR&gt;
      RVA0911V304A&lt;BR&gt;
      -&lt;BR&gt;
      RVA0911H413A&lt;BR&gt;
      RVG0707V100A&lt;BR&gt;
      RVA0607V(H)306A&lt;BR&gt;
      RVA1214H213A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      3104B&lt;BR&gt;
      3104C&lt;BR&gt;
      3104F&lt;BR&gt;
      3104H&lt;BR&gt;
      -&lt;BR&gt;
      3104M&lt;BR&gt;
      3104P&lt;BR&gt;
      3104S&lt;BR&gt;
      3104W&lt;BR&gt;
      3104X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      EVMQ0G&lt;BR&gt;
      EVMQIG&lt;BR&gt;
      EVMQ3G&lt;BR&gt;
      EVMS0G&lt;BR&gt;
      EVMQ0G&lt;BR&gt;
      EVMG0G&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMK4GA00B&lt;BR&gt;
      EVM30GA00B&lt;BR&gt;
      EVMK0GA00B&lt;BR&gt;
      EVM38GA00B&lt;BR&gt;
      EVMB6&lt;BR&gt;
      EVLQ0&lt;BR&gt;
      -&lt;BR&gt;
      EVMMSG&lt;BR&gt;
      EVMMBG&lt;BR&gt;
      EVMMAG&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMMCS&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM0&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      EVMM3&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      62-3-1&lt;BR&gt;
      62-1-2&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67R&lt;BR&gt;
      -&lt;BR&gt;
      67P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      67X&lt;BR&gt;
      63V&lt;BR&gt;
      63S&lt;BR&gt;
      63M&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63H&lt;BR&gt;
      63P&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      63X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      RJ/RJR50&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;&amp;nbsp;&lt;P&gt;
&lt;TABLE BORDER=0 CELLSPACING=1 CELLPADDING=3&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;
      &lt;FONT color="#0000FF" SIZE=4 FACE=ARIAL&gt;&lt;B&gt;SMD TRIM-POT CROSS REFERENCE&lt;/B&gt;&lt;/FONT&gt;
      &lt;P&gt;
      &lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;MULTI-TURN&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;BOURNS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;TOCOS&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
      &lt;FONT SIZE=3 FACE=ARIAL&gt;&lt;B&gt;AUX/KYOCERA&lt;/B&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3224G&lt;BR&gt;
      3224J&lt;BR&gt;
      3224W&lt;BR&gt;
      3269P&lt;BR&gt;
      3269W&lt;BR&gt;
      3269X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      44G&lt;BR&gt;
      44J&lt;BR&gt;
      44W&lt;BR&gt;
      84P&lt;BR&gt;
      84W&lt;BR&gt;
      84X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST63Z&lt;BR&gt;
      ST63Y&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST5P&lt;BR&gt;
      ST5W&lt;BR&gt;
      ST5X&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD COLSPAN=7&gt;&amp;nbsp;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
    &lt;TD&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
  &lt;TR&gt;
      3314G&lt;BR&gt;
      3314J&lt;BR&gt;
      3364A/B&lt;BR&gt;
      3364C/D&lt;BR&gt;
      3364W/X&lt;BR&gt;
      3313G&lt;BR&gt;
      3313J&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      23B&lt;BR&gt;
      23A&lt;BR&gt;
      21X&lt;BR&gt;
      21W&lt;BR&gt;
      -&lt;BR&gt;
      22B&lt;BR&gt;
      22A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      ST5YL/ST53YL&lt;BR&gt;
      ST5YJ/5T53YJ&lt;BR&gt;
      ST-23A&lt;BR&gt;
      ST-22B&lt;BR&gt;
      ST-22&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      ST-4B&lt;BR&gt;
      ST-4A&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      ST-3B&lt;BR&gt;
      ST-3A&lt;BR&gt;&lt;/FONT&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      EVM-6YS&lt;BR&gt;
      EVM-1E&lt;BR&gt;
      EVM-1G&lt;BR&gt;
      EVM-1D&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      G4B&lt;BR&gt;
      G4A&lt;BR&gt;
      TR04-3S1&lt;BR&gt;
      TRG04-2S1&lt;BR&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
      -&lt;BR&gt;
      -&lt;BR&gt;
      DVR-43A&lt;BR&gt;
      CVR-42C&lt;BR&gt;
      CVR-42A/C&lt;BR&gt;
      -&lt;BR&gt;
    &lt;/TD&gt;
  &lt;/TR&gt;
&lt;/TABLE&gt;
&lt;P&gt;
&lt;FONT SIZE=4 FACE=ARIAL&gt;&lt;B&gt;ALT =&amp;nbsp;ALTERNATE&lt;/B&gt;&lt;/FONT&gt;
&lt;P&gt;
&amp;nbsp;
&lt;P&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/table&gt;
&lt;/BODY&gt;&lt;/HTML&gt;</description>
<packages>
<package name="R1206">
<description>&lt;b&gt;RESISTOR&lt;/b&gt;&lt;p&gt;
chip</description>
<wire x1="0.9525" y1="-0.8128" x2="-0.9652" y2="-0.8128" width="0.1524" layer="51"/>
<wire x1="0.9525" y1="0.8128" x2="-0.9652" y2="0.8128" width="0.1524" layer="51"/>
<wire x1="-2.473" y1="0.983" x2="2.473" y2="0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="0.983" x2="2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="2.473" y1="-0.983" x2="-2.473" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-2.473" y1="-0.983" x2="-2.473" y2="0.983" width="0.0508" layer="39"/>
<smd name="2" x="1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<smd name="1" x="-1.422" y="0" dx="1.6" dy="1.803" layer="1"/>
<text x="-1.397" y="1.143" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.397" y="-2.413" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.6891" y1="-0.8763" x2="-0.9525" y2="0.8763" layer="51"/>
<rectangle x1="0.9525" y1="-0.8763" x2="1.6891" y2="0.8763" layer="51"/>
<rectangle x1="-0.3" y1="-0.7" x2="0.3" y2="0.7" layer="35"/>
</package>
</packages>
</library>
<library name="transistor-npn">
<description>&lt;b&gt;NPN Transistors&lt;/b&gt;&lt;p&gt;
<packages>
<package name="SOT23">
<description>&lt;b&gt;SOT-23&lt;/b&gt;</description>
<wire x1="1.4224" y1="0.6604" x2="1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="1.4224" y1="-0.6604" x2="-1.4224" y2="-0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="-0.6604" x2="-1.4224" y2="0.6604" width="0.1524" layer="51"/>
<wire x1="-1.4224" y1="0.6604" x2="1.4224" y2="0.6604" width="0.1524" layer="51"/>
<smd name="3" x="0" y="1.1" dx="1" dy="1.4" layer="1"/>
<smd name="2" x="0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<smd name="1" x="-0.95" y="-1.1" dx="1" dy="1.4" layer="1"/>
<text x="-1.905" y="1.905" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.905" y="-3.175" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-0.2286" y1="0.7112" x2="0.2286" y2="1.2954" layer="51"/>
<rectangle x1="0.7112" y1="-1.2954" x2="1.1684" y2="-0.7112" layer="51"/>
<rectangle x1="-1.1684" y1="-1.2954" x2="-0.7112" y2="-0.7112" layer="51"/>
</package>
</packages>
</library>
<library name="con-molex">
<packages>
<package name="22-23-2031">
<description>.100" (2.54mm) Center Header - 3 Pin</description>
<wire x1="-3.81" y1="3.175" x2="3.81" y2="3.175" width="0.254" layer="21"/>
<wire x1="3.81" y1="3.175" x2="3.81" y2="1.27" width="0.254" layer="21"/>
<wire x1="3.81" y1="1.27" x2="3.81" y2="-3.175" width="0.254" layer="21"/>
<wire x1="3.81" y1="-3.175" x2="-3.81" y2="-3.175" width="0.254" layer="21"/>
<wire x1="-3.81" y1="-3.175" x2="-3.81" y2="1.27" width="0.254" layer="21"/>
<wire x1="-3.81" y1="1.27" x2="-3.81" y2="3.175" width="0.254" layer="21"/>
<wire x1="-3.81" y1="1.27" x2="3.81" y2="1.27" width="0.254" layer="21"/>
<pad name="1" x="-2.54" y="0" drill="1" shape="long" rot="R90"/>
<pad name="2" x="0" y="0" drill="1" shape="long" rot="R90"/>
<pad name="3" x="2.54" y="0" drill="1" shape="long" rot="R90"/>
<text x="-3.81" y="3.81" size="1.016" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.81" y="-5.08" size="1.016" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="22-23-2041">
<description>.100" (2.54mm) Center Header - 4 Pin</description>
<wire x1="-5.08" y1="3.175" x2="5.08" y2="3.175" width="0.254" layer="21"/>
<wire x1="5.08" y1="3.175" x2="5.08" y2="1.27" width="0.254" layer="21"/>
<wire x1="5.08" y1="1.27" x2="5.08" y2="-3.175" width="0.254" layer="21"/>
<wire x1="5.08" y1="-3.175" x2="-5.08" y2="-3.175" width="0.254" layer="21"/>
<wire x1="-5.08" y1="-3.175" x2="-5.08" y2="1.27" width="0.254" layer="21"/>
<wire x1="-5.08" y1="1.27" x2="-5.08" y2="3.175" width="0.254" layer="21"/>
<wire x1="-5.08" y1="1.27" x2="5.08" y2="1.27" width="0.254" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="1" shape="long" rot="R90"/>
<pad name="2" x="-1.27" y="0" drill="1" shape="long" rot="R90"/>
<pad name="3" x="1.27" y="0" drill="1" shape="long" rot="R90"/>
<pad name="4" x="3.81" y="0" drill="1" shape="long" rot="R90"/>
<text x="-5.08" y="3.81" size="1.016" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="-5.08" size="1.016" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="22-23-2051">
<description>.100" (2.54mm) Center Header - 5 Pin</description>
<wire x1="-6.35" y1="3.175" x2="6.35" y2="3.175" width="0.254" layer="21"/>
<wire x1="6.35" y1="3.175" x2="6.35" y2="1.27" width="0.254" layer="21"/>
<wire x1="6.35" y1="1.27" x2="6.35" y2="-3.175" width="0.254" layer="21"/>
<wire x1="6.35" y1="-3.175" x2="-6.35" y2="-3.175" width="0.254" layer="21"/>
<wire x1="-6.35" y1="-3.175" x2="-6.35" y2="1.27" width="0.254" layer="21"/>
<wire x1="-6.35" y1="1.27" x2="-6.35" y2="3.175" width="0.254" layer="21"/>
<wire x1="-6.35" y1="1.27" x2="6.35" y2="1.27" width="0.254" layer="21"/>
<pad name="1" x="-5.08" y="0" drill="1" shape="long" rot="R90"/>
<pad name="2" x="-2.54" y="0" drill="1" shape="long" rot="R90"/>
<pad name="3" x="0" y="0" drill="1" shape="long" rot="R90"/>
<pad name="4" x="2.54" y="0" drill="1" shape="long" rot="R90"/>
<pad name="5" x="5.08" y="0" drill="1" shape="long" rot="R90"/>
<text x="-6.35" y="3.81" size="1.016" layer="25" ratio="10">&gt;NAME</text>
<text x="-6.35" y="-5.08" size="1.016" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="smd-ipc">
<description>&lt;b&gt;IPC Standard SMD Packages&lt;/b&gt;&lt;p&gt;
This is a package-only library, based on the Surface Mount Design and Land Pattern Standard developed by the
Institute for Interconnecting and Packaging electronic Circuits (IPC).&lt;p&gt;
Source:&lt;p&gt;
IPC-SM-782&lt;br&gt;
Revision A, August 1993&lt;br&gt;
Includes Amendment 1, October 1996&lt;p&gt;
<packages>
<package name="C0805">
<description>&lt;b&gt;CAPACITOR&lt;/b&gt;&lt;p&gt;</description>
<wire x1="-1.973" y1="0.983" x2="1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="1.973" y1="-0.983" x2="-1.973" y2="-0.983" width="0.0508" layer="39"/>
<wire x1="-1.973" y1="-0.983" x2="-1.973" y2="0.983" width="0.0508" layer="39"/>
<wire x1="-0.381" y1="0.66" x2="0.381" y2="0.66" width="0.1016" layer="51"/>
<wire x1="-0.356" y1="-0.66" x2="0.381" y2="-0.66" width="0.1016" layer="51"/>
<wire x1="1.973" y1="0.983" x2="1.973" y2="-0.983" width="0.0508" layer="39"/>
<smd name="1" x="-0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<smd name="2" x="0.95" y="0" dx="1.3" dy="1.5" layer="1"/>
<text x="-1.27" y="1.27" size="1.27" layer="25">&gt;NAME</text>
<text x="-1.27" y="-2.54" size="1.27" layer="27">&gt;VALUE</text>
<rectangle x1="-1.0922" y1="-0.7239" x2="-0.3421" y2="0.7262" layer="51"/>
<rectangle x1="0.3556" y1="-0.7239" x2="1.1057" y2="0.7262" layer="51"/>
<rectangle x1="-0.1001" y1="-0.4001" x2="0.1001" y2="0.4001" layer="35"/>
</package>
</packages>
</library>
<library name="transistor-small-signal">
<description>&lt;b&gt;Small Signal Transistors&lt;/b&gt;&lt;p&gt;
Packages from :&lt;br&gt;
www.infineon.com; &lt;br&gt;
www.semiconductors.com;&lt;br&gt;
www.irf.com&lt;p&gt;
<packages>
</package>
</packages>
</library>
<library name="74ac-logic">
<description>&lt;b&gt;TTL Logic Devices, 74AC11xx and 74AC16xx Series&lt;/b&gt;&lt;p&gt;
Based on the following source:
&lt;ul&gt;
&lt;li&gt;www.ti.com
&lt;/ul&gt;
<packages>
<package name="SO16">
<description>&lt;b&gt;Small Outline package&lt;/b&gt; 150 mil</description>
<wire x1="4.699" y1="1.9558" x2="-4.699" y2="1.9558" width="0.1524" layer="21"/>
<wire x1="4.699" y1="-1.9558" x2="5.08" y2="-1.5748" width="0.1524" layer="21" curve="90"/>
<wire x1="-5.08" y1="1.5748" x2="-4.699" y2="1.9558" width="0.1524" layer="21" curve="-90"/>
<wire x1="4.699" y1="1.9558" x2="5.08" y2="1.5748" width="0.1524" layer="21" curve="-90"/>
<wire x1="-5.08" y1="-1.5748" x2="-4.699" y2="-1.9558" width="0.1524" layer="21" curve="90"/>
<wire x1="-4.699" y1="-1.9558" x2="4.699" y2="-1.9558" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-1.5748" x2="5.08" y2="1.5748" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="1.5748" x2="-5.08" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.508" x2="-5.08" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="-0.508" x2="-5.08" y2="-1.5748" width="0.1524" layer="21"/>
<wire x1="-5.08" y1="0.508" x2="-5.08" y2="-0.508" width="0.1524" layer="21" curve="-180"/>
<wire x1="-5.08" y1="-1.6002" x2="5.08" y2="-1.6002" width="0.0508" layer="21"/>
<smd name="1" x="-4.445" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="16" x="-4.445" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="2" x="-3.175" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="3" x="-1.905" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="15" x="-3.175" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="14" x="-1.905" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="4" x="-0.635" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="13" x="-0.635" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="5" x="0.635" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="12" x="0.635" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="6" x="1.905" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="7" x="3.175" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="11" x="1.905" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="10" x="3.175" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="8" x="4.445" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="9" x="4.445" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<text x="-4.064" y="-0.635" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
<text x="-5.461" y="-1.778" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<rectangle x1="-0.889" y1="1.9558" x2="-0.381" y2="3.0988" layer="51"/>
<rectangle x1="-4.699" y1="-3.0988" x2="-4.191" y2="-1.9558" layer="51"/>
<rectangle x1="-3.429" y1="-3.0988" x2="-2.921" y2="-1.9558" layer="51"/>
<rectangle x1="-2.159" y1="-3.0734" x2="-1.651" y2="-1.9304" layer="51"/>
<rectangle x1="-0.889" y1="-3.0988" x2="-0.381" y2="-1.9558" layer="51"/>
<rectangle x1="-2.159" y1="1.9558" x2="-1.651" y2="3.0988" layer="51"/>
<rectangle x1="-3.429" y1="1.9558" x2="-2.921" y2="3.0988" layer="51"/>
<rectangle x1="-4.699" y1="1.9558" x2="-4.191" y2="3.0988" layer="51"/>
<rectangle x1="0.381" y1="-3.0988" x2="0.889" y2="-1.9558" layer="51"/>
<rectangle x1="1.651" y1="-3.0988" x2="2.159" y2="-1.9558" layer="51"/>
<rectangle x1="2.921" y1="-3.0988" x2="3.429" y2="-1.9558" layer="51"/>
<rectangle x1="4.191" y1="-3.0988" x2="4.699" y2="-1.9558" layer="51"/>
<rectangle x1="0.381" y1="1.9558" x2="0.889" y2="3.0988" layer="51"/>
<rectangle x1="1.651" y1="1.9558" x2="2.159" y2="3.0988" layer="51"/>
<rectangle x1="2.921" y1="1.9558" x2="3.429" y2="3.0988" layer="51"/>
<rectangle x1="4.191" y1="1.9558" x2="4.699" y2="3.0988" layer="51"/>
</package>
<package name="SO08">
<wire x1="2.159" y1="1.9558" x2="-2.159" y2="1.9558" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-1.9558" x2="2.54" y2="-1.5748" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.54" y1="1.5748" x2="-2.159" y2="1.9558" width="0.1524" layer="21" curve="-90"/>
<wire x1="2.159" y1="1.9558" x2="2.54" y2="1.5748" width="0.1524" layer="21" curve="-90"/>
<wire x1="-2.54" y1="-1.5748" x2="-2.159" y2="-1.9558" width="0.1524" layer="21" curve="90"/>
<wire x1="-2.159" y1="-1.9558" x2="2.159" y2="-1.9558" width="0.1524" layer="21"/>
<wire x1="2.54" y1="-1.5748" x2="2.54" y2="1.5748" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="1.5748" x2="-2.54" y2="0.508" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.508" x2="-2.54" y2="-0.508" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="-0.508" x2="-2.54" y2="-1.5748" width="0.1524" layer="21"/>
<wire x1="-2.54" y1="0.508" x2="-2.54" y2="-0.508" width="0.1524" layer="21" curve="-180"/>
<wire x1="-2.54" y1="-1.6002" x2="2.54" y2="-1.6002" width="0.0508" layer="21"/>
<smd name="1" x="-1.905" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="8" x="-1.905" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="2" x="-0.635" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="3" x="0.635" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="7" x="-0.635" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="6" x="0.635" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="4" x="1.905" y="-3.0734" dx="0.6604" dy="2.032" layer="1"/>
<smd name="5" x="1.905" y="3.0734" dx="0.6604" dy="2.032" layer="1"/>
<text x="3.937" y="-2.286" size="1.27" layer="27" ratio="10" rot="R90">&gt;VALUE</text>
<text x="-2.921" y="-2.159" size="1.27" layer="25" ratio="10" rot="R90">&gt;NAME</text>
<rectangle x1="-2.159" y1="-3.0988" x2="-1.651" y2="-1.9558" layer="51"/>
<rectangle x1="0.381" y1="-3.0734" x2="0.889" y2="-1.9304" layer="51"/>
</package>
</packages>
</library>
<library name="con-subd">
<description>&lt;b&gt;SUB-D Connectors&lt;/b&gt;&lt;p&gt;
Harting&lt;br&gt;
NorComp&lt;br&gt;
&lt;p&gt;
PREFIX :&lt;br&gt;
H = High density&lt;br&gt;
F = Female&lt;br&gt;
M = Male&lt;p&gt;
NUMBER: Number of pins&lt;p&gt;
SUFFIX :&lt;br&gt;
H = Horizontal&lt;br&gt;
V = Vertical &lt;br&gt;
P = Shield pin on housing&lt;br&gt;
B = No mounting holes&lt;br&gt;
S = Pins individually placeable (Single)&lt;br&gt;
D = Direct mounting &lt;p&gt;
<packages>
<package name="F09VB">
<description>&lt;b&gt;SUB-D&lt;/b&gt;</description>
<wire x1="7.5184" y1="2.9464" x2="8.3058" y2="-2.3368" width="0.1524" layer="21"/>
<wire x1="-7.5317" y1="2.905" x2="-6.223" y2="3.937" width="0.1524" layer="21" curve="-76.489196"/>
<wire x1="-8.3005" y1="-2.3038" x2="-6.985" y2="-3.937" width="0.1524" layer="21" curve="102.298925"/>
<wire x1="-8.3058" y1="-2.3114" x2="-7.5184" y2="2.921" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-3.937" x2="-6.985" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="6.985" y1="-3.937" x2="8.3051" y2="-2.3268" width="0.1524" layer="21" curve="101.30773"/>
<wire x1="6.223" y1="3.937" x2="7.5259" y2="2.9295" width="0.1524" layer="21" curve="-75.428151"/>
<wire x1="6.223" y1="3.937" x2="-6.223" y2="3.937" width="0.1524" layer="21"/>
<wire x1="12.7" y1="6.223" x2="12.7" y2="6.096" width="0.1524" layer="21"/>
<wire x1="12.7" y1="6.223" x2="10.16" y2="6.223" width="0.1524" layer="21"/>
<wire x1="12.7" y1="6.096" x2="10.16" y2="6.096" width="0.1524" layer="21"/>
<wire x1="10.16" y1="6.096" x2="10.16" y2="6.223" width="0.1524" layer="21"/>
<wire x1="10.16" y1="6.223" x2="-10.16" y2="6.223" width="0.1524" layer="21"/>
<wire x1="14.859" y1="6.223" x2="12.7" y2="6.223" width="0.1524" layer="21"/>
<wire x1="14.859" y1="6.223" x2="15.494" y2="5.588" width="0.1524" layer="21" curve="-90"/>
<wire x1="-15.494" y1="5.588" x2="-14.859" y2="6.223" width="0.1524" layer="21" curve="-90"/>
<wire x1="-14.859" y1="-6.223" x2="-12.7" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-15.494" y1="-5.588" x2="-15.494" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-15.494" y1="-5.588" x2="-14.859" y2="-6.223" width="0.1524" layer="21" curve="90"/>
<wire x1="15.494" y1="-5.588" x2="15.494" y2="5.588" width="0.1524" layer="21"/>
<wire x1="14.859" y1="-6.223" x2="15.494" y2="-5.588" width="0.1524" layer="21" curve="90"/>
<wire x1="-10.16" y1="6.223" x2="-10.16" y2="6.096" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="6.223" x2="-12.7" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="6.096" x2="-12.7" y2="6.096" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="6.096" x2="-12.7" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="6.223" x2="-14.859" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-6.223" x2="-10.16" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-6.223" x2="10.16" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="-6.096" x2="-12.7" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-6.096" x2="-12.7" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-12.7" y1="-6.223" x2="-10.16" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="12.7" y1="-6.223" x2="12.7" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="12.7" y1="-6.223" x2="14.859" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="12.7" y1="-6.096" x2="10.16" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-6.096" x2="10.16" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-6.223" x2="12.7" y2="-6.223" width="0.1524" layer="21"/>
<circle x="-1.3716" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-2.7432" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-4.1148" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-5.4864" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="0" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="1.3716" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="2.7432" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="4.1148" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="5.4864" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<pad name="1" x="-5.4864" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="2" x="-2.7432" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="3" x="0" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="4" x="2.7432" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="5" x="5.4864" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="6" x="-4.1148" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="7" x="-1.3716" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="8" x="1.3716" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="9" x="4.1148" y="1.4224" drill="1.016" shape="octagon"/>
<text x="-5.08" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">1</text>
<text x="-2.286" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">2</text>
<text x="0.508" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">3</text>
<text x="3.175" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">4</text>
<text x="5.969" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">5</text>
<text x="-3.81" y="3.556" size="0.9906" layer="21" ratio="12" rot="R180">6</text>
<text x="-1.016" y="3.556" size="0.9906" layer="21" ratio="12" rot="R180">7</text>
<text x="1.778" y="3.556" size="0.9906" layer="21" ratio="12" rot="R180">8</text>
<text x="4.572" y="3.556" size="0.9906" layer="21" ratio="12" rot="R180">9</text>
<text x="-15.367" y="8.255" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="0" y="8.255" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
</package>
<package name="F15VB">
<wire x1="11.7094" y1="2.9464" x2="12.4968" y2="-2.3368" width="0.1524" layer="21"/>
<wire x1="-11.7227" y1="2.905" x2="-10.414" y2="3.937" width="0.1524" layer="21" curve="-76.489196"/>
<wire x1="-12.4915" y1="-2.3038" x2="-11.176" y2="-3.937" width="0.1524" layer="21" curve="102.298925"/>
<wire x1="-12.4968" y1="-2.3114" x2="-11.7094" y2="2.921" width="0.1524" layer="21"/>
<wire x1="11.176" y1="-3.937" x2="-11.176" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="11.176" y1="-3.937" x2="12.4961" y2="-2.3268" width="0.1524" layer="21" curve="101.30773"/>
<wire x1="10.414" y1="3.937" x2="11.7169" y2="2.9295" width="0.1524" layer="21" curve="-75.428151"/>
<wire x1="10.414" y1="3.937" x2="-10.414" y2="3.937" width="0.1524" layer="21"/>
<wire x1="16.891" y1="6.223" x2="16.891" y2="6.096" width="0.1524" layer="21"/>
<wire x1="16.891" y1="6.223" x2="14.351" y2="6.223" width="0.1524" layer="21"/>
<wire x1="16.891" y1="6.096" x2="14.351" y2="6.096" width="0.1524" layer="21"/>
<wire x1="14.351" y1="6.096" x2="14.351" y2="6.223" width="0.1524" layer="21"/>
<wire x1="14.351" y1="6.223" x2="-14.351" y2="6.223" width="0.1524" layer="21"/>
<wire x1="19.05" y1="6.223" x2="16.891" y2="6.223" width="0.1524" layer="21"/>
<wire x1="19.05" y1="6.223" x2="19.685" y2="5.588" width="0.1524" layer="21" curve="-90"/>
<wire x1="-19.685" y1="5.588" x2="-19.05" y2="6.223" width="0.1524" layer="21" curve="-90"/>
<wire x1="-19.05" y1="-6.223" x2="-16.891" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="-5.588" x2="-19.685" y2="5.588" width="0.1524" layer="21"/>
<wire x1="-19.685" y1="-5.588" x2="-19.05" y2="-6.223" width="0.1524" layer="21" curve="90"/>
<wire x1="19.685" y1="-5.588" x2="19.685" y2="5.588" width="0.1524" layer="21"/>
<wire x1="19.05" y1="-6.223" x2="19.685" y2="-5.588" width="0.1524" layer="21" curve="90"/>
<wire x1="-14.351" y1="6.223" x2="-14.351" y2="6.096" width="0.1524" layer="21"/>
<wire x1="-14.351" y1="6.223" x2="-16.891" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-14.351" y1="6.096" x2="-16.891" y2="6.096" width="0.1524" layer="21"/>
<wire x1="-16.891" y1="6.096" x2="-16.891" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-16.891" y1="6.223" x2="-19.05" y2="6.223" width="0.1524" layer="21"/>
<wire x1="-14.351" y1="-6.223" x2="-14.351" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-14.351" y1="-6.223" x2="14.351" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-14.351" y1="-6.096" x2="-16.891" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="-16.891" y1="-6.096" x2="-16.891" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="-16.891" y1="-6.223" x2="-14.351" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="16.891" y1="-6.223" x2="16.891" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="16.891" y1="-6.223" x2="19.05" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="16.891" y1="-6.096" x2="14.351" y2="-6.096" width="0.1524" layer="21"/>
<wire x1="14.351" y1="-6.096" x2="14.351" y2="-6.223" width="0.1524" layer="21"/>
<wire x1="14.351" y1="-6.223" x2="16.891" y2="-6.223" width="0.1524" layer="21"/>
<circle x="-2.7432" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-4.1148" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-5.4864" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-6.858" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-1.3716" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="0" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="1.3716" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="2.7432" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="4.1148" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-9.6012" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="-8.2296" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="6.858" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="9.6012" y="-1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="5.4864" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<circle x="8.2296" y="1.4224" radius="0.762" width="0.254" layer="51"/>
<pad name="1" x="-9.6012" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="2" x="-6.858" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="3" x="-4.1148" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="4" x="-1.3716" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="5" x="1.3716" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="6" x="4.1148" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="7" x="6.858" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="8" x="9.6012" y="-1.4224" drill="1.016" shape="octagon"/>
<pad name="9" x="-8.2296" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="10" x="-5.4864" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="11" x="-2.7432" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="12" x="0" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="13" x="2.7432" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="14" x="5.4864" y="1.4224" drill="1.016" shape="octagon"/>
<pad name="15" x="8.2296" y="1.4224" drill="1.016" shape="octagon"/>
<text x="-9.2456" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">1</text>
<text x="-6.4516" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">2</text>
<text x="-3.6576" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">3</text>
<text x="-0.9906" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">4</text>
<text x="1.8034" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">5</text>
<text x="4.5974" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">6</text>
<text x="7.3914" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">7</text>
<text x="10.1854" y="-2.54" size="0.9906" layer="21" ratio="12" rot="R180">8</text>
<text x="-7.8486" y="3.556" size="0.9906" layer="21" ratio="12" rot="R180">9</text>
<text x="-18.288" y="8.255" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="-5.08" y="8.255" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-4.699" y="3.556" size="0.9906" layer="21" ratio="12" rot="R180">10</text>
<text x="-2.032" y="3.556" size="0.9906" layer="21" ratio="12" rot="R180">11</text>
<text x="0.762" y="3.556" size="0.9906" layer="21" ratio="12" rot="R180">12</text>
<text x="3.556" y="3.556" size="0.9906" layer="21" ratio="12" rot="R180">13</text>
<text x="6.35" y="3.556" size="0.9906" layer="21" ratio="12" rot="R180">14</text>
<text x="9.017" y="3.556" size="0.9906" layer="21" ratio="12" rot="R180">15</text>
</package>
</packages>
</library>
<library name="crystal">
<description>&lt;b&gt;Crystals and Crystal Resonators&lt;/b&gt;&lt;p&gt;
<packages>
<package name="CSM-7X-DU">
<description>&lt;b&gt;SMD CRYSTAL&lt;/b&gt;&lt;p&gt;
Source: www.ecsxtal.com .. Crystal 3.6864MHz CSM_7X_DU.PDF</description>
<wire x1="-5.575" y1="2.3" x2="-2.725" y2="2.3" width="0.2032" layer="51"/>
<wire x1="-2.725" y1="2.3" x2="2.75" y2="2.3" width="0.2032" layer="51"/>
<wire x1="2.75" y1="2.3" x2="5.55" y2="2.3" width="0.2032" layer="51"/>
<wire x1="5.55" y1="2.3" x2="5.55" y2="-2.3" width="0.2032" layer="51"/>
<wire x1="5.55" y1="-2.3" x2="-2.75" y2="-2.3" width="0.2032" layer="51"/>
<wire x1="-2.75" y1="-2.3" x2="-5.575" y2="-2.3" width="0.2032" layer="51"/>
<wire x1="-5.575" y1="-2.3" x2="-5.575" y2="2.3" width="0.2032" layer="51"/>
<wire x1="-2.75" y1="-2.3" x2="-2.725" y2="2.3" width="0.2032" layer="51" curve="-180"/>
<wire x1="2.75" y1="2.3" x2="2.725" y2="-2.3" width="0.2032" layer="51" curve="-180"/>
<smd name="1" x="-4.75" y="0" dx="5.5" dy="2" layer="1"/>
<smd name="2" x="4.75" y="0" dx="5.5" dy="2" layer="1"/>
<text x="-7.6288" y="2.5334" size="1.27" layer="25">&gt;NAME</text>
<text x="-7.6288" y="-4.3114" size="1.27" layer="27">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="con-harting-ml">
<description>&lt;b&gt;Harting  &amp; 3M Connectors&lt;/b&gt;&lt;p&gt;
Low profile connectors, straight&lt;p&gt;
<packages>
<package name="ML10">
<description>&lt;b&gt;HARTING&lt;/b&gt;</description>
<wire x1="-8.89" y1="3.175" x2="8.89" y2="3.175" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-3.175" x2="8.89" y2="3.175" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="3.175" x2="-8.89" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.445" x2="-8.89" y2="4.445" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.445" x2="5.461" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="10.16" y1="-4.445" x2="10.16" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-10.16" y1="4.445" x2="-10.16" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="8.89" y1="-3.175" x2="4.572" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-2.413" x2="-2.032" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-3.175" x2="-2.032" y2="-2.413" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-3.175" x2="-8.89" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-3.175" x2="-2.032" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-2.413" x2="2.032" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-3.175" x2="2.032" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="8.89" y1="4.445" x2="8.89" y2="4.699" width="0.1524" layer="21"/>
<wire x1="8.89" y1="4.699" x2="7.62" y2="4.699" width="0.1524" layer="21"/>
<wire x1="7.62" y1="4.445" x2="7.62" y2="4.699" width="0.1524" layer="21"/>
<wire x1="8.89" y1="4.445" x2="10.16" y2="4.445" width="0.1524" layer="21"/>
<wire x1="0.635" y1="4.699" x2="-0.635" y2="4.699" width="0.1524" layer="21"/>
<wire x1="0.635" y1="4.699" x2="0.635" y2="4.445" width="0.1524" layer="21"/>
<wire x1="0.635" y1="4.445" x2="7.62" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-0.635" y1="4.699" x2="-0.635" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.699" x2="-8.89" y2="4.699" width="0.1524" layer="21"/>
<wire x1="-8.89" y1="4.699" x2="-8.89" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.699" x2="-7.62" y2="4.445" width="0.1524" layer="21"/>
<wire x1="-7.62" y1="4.445" x2="-0.635" y2="4.445" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-4.445" x2="2.032" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="2.032" y1="-4.445" x2="-2.032" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-3.175" x2="3.048" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-3.175" x2="2.032" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="4.572" y1="-3.175" x2="4.572" y2="-3.429" width="0.1524" layer="21"/>
<wire x1="4.572" y1="-3.175" x2="3.048" y2="-3.175" width="0.1524" layer="21"/>
<wire x1="2.159" y1="-4.445" x2="2.54" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-3.937" x2="5.461" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="5.08" y1="-3.937" x2="4.572" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-3.429" x2="2.032" y2="-3.429" width="0.0508" layer="21"/>
<wire x1="2.032" y1="-3.429" x2="2.032" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="4.572" y1="-3.429" x2="9.144" y2="-3.429" width="0.0508" layer="21"/>
<wire x1="9.144" y1="-3.429" x2="9.144" y2="3.429" width="0.0508" layer="21"/>
<wire x1="9.144" y1="3.429" x2="-9.144" y2="3.429" width="0.0508" layer="21"/>
<wire x1="-9.144" y1="3.429" x2="-9.144" y2="-3.429" width="0.0508" layer="21"/>
<wire x1="-9.144" y1="-3.429" x2="-2.032" y2="-3.429" width="0.0508" layer="21"/>
<wire x1="-2.032" y1="-3.429" x2="-2.032" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-3.429" x2="3.048" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="3.048" y1="-3.937" x2="2.54" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="4.572" y1="-3.429" x2="4.572" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="4.572" y1="-3.937" x2="3.048" y2="-3.937" width="0.1524" layer="21"/>
<wire x1="-2.032" y1="-4.445" x2="-4.445" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-4.318" x2="-4.445" y2="-4.445" width="0.1524" layer="21"/>
<wire x1="-4.445" y1="-4.318" x2="-5.715" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-4.445" x2="-5.715" y2="-4.318" width="0.1524" layer="21"/>
<wire x1="-5.715" y1="-4.445" x2="-10.16" y2="-4.445" width="0.1524" layer="21"/>
<pad name="1" x="-5.08" y="-1.27" drill="0.9144" shape="octagon"/>
<pad name="2" x="-5.08" y="1.27" drill="0.9144" shape="octagon"/>
<pad name="3" x="-2.54" y="-1.27" drill="0.9144" shape="octagon"/>
<pad name="4" x="-2.54" y="1.27" drill="0.9144" shape="octagon"/>
<pad name="5" x="0" y="-1.27" drill="0.9144" shape="octagon"/>
<pad name="6" x="0" y="1.27" drill="0.9144" shape="octagon"/>
<pad name="7" x="2.54" y="-1.27" drill="0.9144" shape="octagon"/>
<pad name="8" x="2.54" y="1.27" drill="0.9144" shape="octagon"/>
<pad name="9" x="5.08" y="-1.27" drill="0.9144" shape="octagon"/>
<pad name="10" x="5.08" y="1.27" drill="0.9144" shape="octagon"/>
<text x="-1.016" y="-4.064" size="1.27" layer="21" ratio="10">10</text>
<text x="-10.16" y="5.08" size="1.778" layer="25" ratio="10">&gt;NAME</text>
<text x="0" y="5.08" size="1.778" layer="27" ratio="10">&gt;VALUE</text>
<text x="-7.62" y="-1.905" size="1.27" layer="21" ratio="10">1</text>
<text x="-7.62" y="0.635" size="1.27" layer="21" ratio="10">2</text>
<rectangle x1="-2.794" y1="1.016" x2="-2.286" y2="1.524" layer="51"/>
<rectangle x1="-5.334" y1="1.016" x2="-4.826" y2="1.524" layer="51"/>
<rectangle x1="-0.254" y1="1.016" x2="0.254" y2="1.524" layer="51"/>
<rectangle x1="4.826" y1="1.016" x2="5.334" y2="1.524" layer="51"/>
<rectangle x1="2.286" y1="1.016" x2="2.794" y2="1.524" layer="51"/>
<rectangle x1="-2.794" y1="-1.524" x2="-2.286" y2="-1.016" layer="51"/>
<rectangle x1="-5.334" y1="-1.524" x2="-4.826" y2="-1.016" layer="51"/>
<rectangle x1="-0.254" y1="-1.524" x2="0.254" y2="-1.016" layer="51"/>
<rectangle x1="4.826" y1="-1.524" x2="5.334" y2="-1.016" layer="51"/>
<rectangle x1="2.286" y1="-1.524" x2="2.794" y2="-1.016" layer="51"/>
</package>
</packages>
</library>
<library name="buzzer">
<description>&lt;b&gt;Speakers and Buzzers&lt;/b&gt;&lt;p&gt;
&lt;ul&gt;Distributors:
&lt;li&gt;Buerklin
&lt;li&gt;Spoerle
&lt;li&gt;Schukat
&lt;/ul&gt;
<packages>
<package name="F/HGP">
<description>&lt;b&gt;BUZZER&lt;/b&gt;</description>
<wire x1="-7.8361" y1="-1.6158" x2="-7.8361" y2="1.6158" width="0.1524" layer="21" curve="336.697868"/>
<wire x1="-5.882" y1="-2.032" x2="-5.882" y2="2.032" width="0.1524" layer="21" curve="321.883357"/>
<wire x1="-6.604" y1="2.032" x2="-6.604" y2="-2.032" width="0.1524" layer="21" curve="180"/>
<wire x1="-6.604" y1="-2.032" x2="-5.882" y2="-2.032" width="0.1524" layer="21"/>
<wire x1="-6.604" y1="2.032" x2="-5.882" y2="2.032" width="0.1524" layer="21"/>
<pad name="1" x="-3.81" y="0" drill="1.016" diameter="2.159" shape="octagon"/>
<pad name="2" x="3.81" y="0" drill="1.016" diameter="2.159" shape="octagon"/>
<text x="4.445" y="6.985" size="1.27" layer="25" ratio="10">&gt;NAME</text>
<text x="-3.683" y="-3.81" size="1.27" layer="27" ratio="10">&gt;VALUE</text>
</package>
</packages>
</library>
<library name="con-phoenix-smkdsp">
<description>Phoenix Connectors, Type SMKDSP</description>
<packages>
<package name="SMKDSP_1,5/12">
<description>&lt;b&gt;Printklemme, Nennstrom: 17,5 A, Bemessungsspannung: 250 V, Raster: 5,0 mm&lt;/b&gt;&lt;p&gt;
Source: http://eshop.phoenixcontact.de .. 1733415.pdf</description>
<wire x1="54.9" y1="-1.9017" x2="-4.9" y2="-1.9017" width="0.2032" layer="21"/>
<wire x1="54.9" y1="-2.354" x2="-4.9" y2="-2.354" width="0.2032" layer="21"/>
<wire x1="54.9" y1="2.192" x2="-4.9" y2="2.192" width="0.2032" layer="21"/>
<wire x1="54.9" y1="2.6785" x2="-4.9" y2="2.6785" width="0.2032" layer="21"/>
<wire x1="2.5" y1="6.0519" x2="2.0839" y2="6.0161" width="0.2032" layer="21" curve="9.818513"/>
<wire x1="2.0839" y1="6.016" x2="1.687" y2="5.9104" width="0.2032" layer="21" curve="10.070203"/>
<wire x1="1.687" y1="5.9104" x2="1.324" y2="5.7387" width="0.2032" layer="21" curve="10.633291"/>
<wire x1="1.324" y1="5.7387" x2="1.0139" y2="5.51" width="0.2032" layer="21" curve="11.361134"/>
<wire x1="1.0139" y1="5.51" x2="0.7679" y2="5.2327" width="0.2032" layer="21" curve="12.408633"/>
<wire x1="0.7679" y1="5.2327" x2="0.6204" y2="4.9736" width="0.2032" layer="21" curve="11.10896"/>
<wire x1="0.6205" y1="4.9736" x2="0.5305" y2="4.6984" width="0.2032" layer="21" curve="11.703364"/>
<wire x1="0.5305" y1="4.6984" x2="0.5" y2="4.4136" width="0.2032" layer="21" curve="12.150409"/>
<wire x1="4.5" y1="4.4136" x2="4.4695" y2="4.6984" width="0.2032" layer="21" curve="12.140502"/>
<wire x1="4.4695" y1="4.6984" x2="4.3795" y2="4.9736" width="0.2032" layer="21" curve="11.823167"/>
<wire x1="4.3795" y1="4.9736" x2="4.2321" y2="5.2327" width="0.2032" layer="21" curve="11.320489"/>
<wire x1="4.2321" y1="5.2327" x2="3.9861" y2="5.51" width="0.2032" layer="21" curve="12.612712"/>
<wire x1="3.9861" y1="5.51" x2="3.676" y2="5.7387" width="0.2032" layer="21" curve="11.606712"/>
<wire x1="3.676" y1="5.7387" x2="3.313" y2="5.9104" width="0.2032" layer="21" curve="10.808503"/>
<wire x1="3.313" y1="5.9104" x2="2.9161" y2="6.016" width="0.2032" layer="21" curve="10.16131"/>
<wire x1="2.9161" y1="6.016" x2="2.5" y2="6.0519" width="0.2032" layer="21" curve="9.8976"/>
<wire x1="-0.5" y1="4.4136" x2="-0.5438" y2="4.7544" width="0.2032" layer="21" curve="14.529549"/>
<wire x1="-0.5438" y1="4.7544" x2="-0.6727" y2="5.0795" width="0.2032" layer="21" curve="14.030571"/>
<wire x1="-0.6727" y1="5.0795" x2="-0.9137" y2="5.4112" width="0.2032" layer="21" curve="16.398865"/>
<wire x1="-0.9136" y1="5.4113" x2="-1.282" y2="5.713" width="0.2032" layer="21" curve="14.813546"/>
<wire x1="-1.282" y1="5.713" x2="-1.7351" y2="5.9273" width="0.2032" layer="21" curve="13.519323"/>
<wire x1="-1.7351" y1="5.9273" x2="-2.2384" y2="6.0378" width="0.2032" layer="21" curve="12.581205"/>
<wire x1="-2.2384" y1="6.0378" x2="-2.7616" y2="6.0378" width="0.2032" layer="21" curve="12.28945"/>
<wire x1="-2.7616" y1="6.0378" x2="-3.2649" y2="5.9273" width="0.2032" layer="21" curve="12.443318"/>
<wire x1="-3.2649" y1="5.9273" x2="-3.718" y2="5.713" width="0.2032" layer="21" curve="13.248047"/>
<wire x1="-3.718" y1="5.713" x2="-4.0864" y2="5.4113" width="0.2032" layer="21" curve="14.439619"/>
<wire x1="-4.0864" y1="5.4113" x2="-4.3274" y2="5.0795" width="0.2032" layer="21" curve="12.857171"/>
<wire x1="-4.3273" y1="5.0795" x2="-4.4562" y2="4.7544" width="0.2032" layer="21" curve="13.812127"/>
<wire x1="-4.4562" y1="4.7544" x2="-4.5" y2="4.4136" width="0.2032" layer="21" curve="14.512364"/>
<wire x1="-4.5" y1="4.4136" x2="-4.4695" y2="4.1287" width="0.2032" layer="21" curve="12.149235"/>
<wire x1="-4.4695" y1="4.1287" x2="-4.3795" y2="3.8536" width="0.2032" layer="21" curve="11.818019"/>
<wire x1="-4.3795" y1="3.8536" x2="-4.232" y2="3.5945" width="0.2032" layer="21" curve="11.320919"/>
<wire x1="-4.2321" y1="3.5944" x2="-3.9861" y2="3.3171" width="0.2032" layer="21" curve="12.610717"/>
<wire x1="-3.9861" y1="3.3171" x2="-3.676" y2="3.0884" width="0.2032" layer="21" curve="11.607468"/>
<wire x1="-3.676" y1="3.0884" x2="-3.313" y2="2.9167" width="0.2032" layer="21" curve="10.807383"/>
<wire x1="-3.313" y1="2.9167" x2="-2.9161" y2="2.8111" width="0.2032" layer="21" curve="10.16131"/>
<wire x1="-2.9161" y1="2.8111" x2="-2.5" y2="2.7752" width="0.2032" layer="21" curve="9.89801"/>
<wire x1="0.5" y1="4.4136" x2="0.5438" y2="4.0727" width="0.2032" layer="21" curve="14.538071"/>
<wire x1="0.5438" y1="4.0727" x2="0.6727" y2="3.7476" width="0.2032" layer="21" curve="14.027417"/>
<wire x1="0.6727" y1="3.7476" x2="0.9136" y2="3.4159" width="0.2032" layer="21" curve="16.392544"/>
<wire x1="0.9136" y1="3.4159" x2="1.282" y2="3.1141" width="0.2032" layer="21" curve="14.814063"/>
<wire x1="1.282" y1="3.1141" x2="1.7351" y2="2.8998" width="0.2032" layer="21" curve="13.518622"/>
<wire x1="1.7351" y1="2.8998" x2="2.2384" y2="2.7893" width="0.2032" layer="21" curve="12.581752"/>
<wire x1="2.2384" y1="2.7893" x2="2.7616" y2="2.7893" width="0.2032" layer="21" curve="12.288948"/>
<wire x1="2.7616" y1="2.7893" x2="3.2649" y2="2.8998" width="0.2032" layer="21" curve="12.443853"/>
<wire x1="3.2649" y1="2.8998" x2="3.718" y2="3.1141" width="0.2032" layer="21" curve="13.24872"/>
<wire x1="3.718" y1="3.1141" x2="4.0864" y2="3.4159" width="0.2032" layer="21" curve="14.441093"/>
<wire x1="4.0864" y1="3.4159" x2="4.3273" y2="3.7476" width="0.2032" layer="21" curve="12.852895"/>
<wire x1="4.3273" y1="3.7476" x2="4.4562" y2="4.0727" width="0.2032" layer="21" curve="13.810089"/>
<wire x1="4.4562" y1="4.0727" x2="4.5" y2="4.4136" width="0.2032" layer="21" curve="14.520871"/>
<wire x1="-2.5" y1="2.7753" x2="-2.0839" y2="2.8111" width="0.2032" layer="21" curve="9.823356"/>
<wire x1="-2.0839" y1="2.8111" x2="-1.687" y2="2.9167" width="0.2032" layer="21" curve="10.070203"/>
<wire x1="-1.687" y1="2.9167" x2="-1.324" y2="3.0884" width="0.2032" layer="21" curve="10.632749"/>
<wire x1="-1.324" y1="3.0884" x2="-1.0139" y2="3.3171" width="0.2032" layer="21" curve="11.361858"/>
<wire x1="-1.0139" y1="3.3171" x2="-0.7679" y2="3.5944" width="0.2032" layer="21" curve="12.401879"/>
<wire x1="-0.7679" y1="3.5944" x2="-0.6204" y2="3.8536" width="0.2032" layer="21" curve="11.113221"/>
<wire x1="-0.6205" y1="3.8536" x2="-0.5305" y2="4.1287" width="0.2032" layer="21" curve="11.698276"/>
<wire x1="-0.5305" y1="4.1287" x2="-0.5001" y2="4.4136" width="0.2032" layer="21" curve="12.152389"/>
<wire x1="-4.9" y1="-6.9" x2="54.9" y2="-6.9" width="0.2032" layer="21"/>
<wire x1="54.9" y1="-6.9" x2="54.9" y2="-2.354" width="0.2032" layer="21"/>
<wire x1="54.9" y1="-2.354" x2="54.9" y2="-1.9017" width="0.2032" layer="21"/>
<wire x1="54.9" y1="-1.9017" x2="54.9" y2="2.192" width="0.2032" layer="21"/>
<wire x1="54.9" y1="2.192" x2="54.9" y2="2.6785" width="0.2032" layer="21"/>
<wire x1="54.9" y1="2.6785" x2="54.9" y2="6.3" width="0.2032" layer="21"/>
<wire x1="54.9" y1="6.3" x2="-4.9" y2="6.3" width="0.2032" layer="21"/>
<wire x1="-4.9" y1="6.3" x2="-4.9" y2="2.6785" width="0.2032" layer="21"/>
<wire x1="-4.9" y1="2.6785" x2="-4.9" y2="2.192" width="0.2032" layer="21"/>
<wire x1="-4.9" y1="2.192" x2="-4.9" y2="-1.9017" width="0.2032" layer="21"/>
<wire x1="-4.9" y1="-1.9017" x2="-4.9" y2="-2.354" width="0.2032" layer="21"/>
<wire x1="-4.9" y1="-2.354" x2="-4.9" y2="-6.9" width="0.2032" layer="21"/>
<wire x1="-4" y1="-5.4" x2="-1" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="-1" y1="-5.4" x2="-1" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-1" y1="-3.75" x2="-4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="-4" y1="-3.75" x2="-4" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="-6.2" x2="-0.8" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="-0.8" y1="-6.2" x2="-0.8" y2="-3" width="0.2032" layer="21"/>
<wire x1="-0.8" y1="-3" x2="-4.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="-4.2" y1="-3" x2="-4.2" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="55" y1="-6.3" x2="55.2" y2="-6.3" width="0.2032" layer="21"/>
<wire x1="55.2" y1="-6.3" x2="55.4" y2="-6.45" width="0.2032" layer="21"/>
<wire x1="55.4" y1="-6.45" x2="55.65" y2="-6.45" width="0.2032" layer="21"/>
<wire x1="55.65" y1="-6.45" x2="55.65" y2="-1.9" width="0.2032" layer="21"/>
<wire x1="55.65" y1="-1.9" x2="55.45" y2="-1.9" width="0.2032" layer="21"/>
<wire x1="55.45" y1="-1.9" x2="55.2" y2="-2.05" width="0.2032" layer="21"/>
<wire x1="55.2" y1="-2.05" x2="55" y2="-2.05" width="0.2032" layer="21"/>
<wire x1="55" y1="1.15" x2="55.2" y2="1.15" width="0.2032" layer="21"/>
<wire x1="55.2" y1="1.15" x2="55.4" y2="0.95" width="0.2032" layer="21"/>
<wire x1="55.4" y1="0.95" x2="55.65" y2="0.95" width="0.2032" layer="21"/>
<wire x1="55.65" y1="0.95" x2="55.65" y2="3.75" width="0.2032" layer="21"/>
<wire x1="55.65" y1="3.75" x2="55.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="55.4" y1="3.75" x2="55.2" y2="3.6" width="0.2032" layer="21"/>
<wire x1="55.2" y1="3.6" x2="55" y2="3.6" width="0.2032" layer="21"/>
<wire x1="1" y1="-5.15" x2="1" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="1" y1="-5.4" x2="4" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="4" y1="-5.4" x2="4" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="4" y1="-3.75" x2="1" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="1" y1="-3.75" x2="1" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="0.8" y1="-6.2" x2="4.2" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="4.2" y1="-6.2" x2="4.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="4.2" y1="-3" x2="0.8" y2="-3" width="0.2032" layer="21"/>
<wire x1="0.8" y1="-3" x2="0.8" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="7.5" y1="6.0519" x2="7.0839" y2="6.0161" width="0.2032" layer="21" curve="9.818513"/>
<wire x1="7.0839" y1="6.016" x2="6.687" y2="5.9104" width="0.2032" layer="21" curve="10.070203"/>
<wire x1="6.687" y1="5.9104" x2="6.324" y2="5.7387" width="0.2032" layer="21" curve="10.633291"/>
<wire x1="6.324" y1="5.7387" x2="6.0139" y2="5.51" width="0.2032" layer="21" curve="11.361134"/>
<wire x1="6.0139" y1="5.51" x2="5.7679" y2="5.2327" width="0.2032" layer="21" curve="12.408633"/>
<wire x1="5.7679" y1="5.2327" x2="5.6204" y2="4.9736" width="0.2032" layer="21" curve="11.10896"/>
<wire x1="5.6205" y1="4.9736" x2="5.5305" y2="4.6984" width="0.2032" layer="21" curve="11.703364"/>
<wire x1="5.5305" y1="4.6984" x2="5.5" y2="4.4136" width="0.2032" layer="21" curve="12.150409"/>
<wire x1="9.5" y1="4.4136" x2="9.4695" y2="4.6984" width="0.2032" layer="21" curve="12.140502"/>
<wire x1="9.4695" y1="4.6984" x2="9.3795" y2="4.9736" width="0.2032" layer="21" curve="11.823167"/>
<wire x1="9.3795" y1="4.9736" x2="9.2321" y2="5.2327" width="0.2032" layer="21" curve="11.320489"/>
<wire x1="9.2321" y1="5.2327" x2="8.9861" y2="5.51" width="0.2032" layer="21" curve="12.612712"/>
<wire x1="8.9861" y1="5.51" x2="8.676" y2="5.7387" width="0.2032" layer="21" curve="11.606712"/>
<wire x1="8.676" y1="5.7387" x2="8.313" y2="5.9104" width="0.2032" layer="21" curve="10.808503"/>
<wire x1="8.313" y1="5.9104" x2="7.9161" y2="6.016" width="0.2032" layer="21" curve="10.16131"/>
<wire x1="7.9161" y1="6.016" x2="7.5" y2="6.0519" width="0.2032" layer="21" curve="9.8976"/>
<wire x1="5.5" y1="4.4136" x2="5.5438" y2="4.0727" width="0.2032" layer="21" curve="14.538071"/>
<wire x1="5.5438" y1="4.0727" x2="5.6727" y2="3.7476" width="0.2032" layer="21" curve="14.027417"/>
<wire x1="5.6727" y1="3.7476" x2="5.9136" y2="3.4159" width="0.2032" layer="21" curve="16.392544"/>
<wire x1="5.9136" y1="3.4159" x2="6.282" y2="3.1141" width="0.2032" layer="21" curve="14.814063"/>
<wire x1="6.282" y1="3.1141" x2="6.7351" y2="2.8998" width="0.2032" layer="21" curve="13.518622"/>
<wire x1="6.7351" y1="2.8998" x2="7.2384" y2="2.7893" width="0.2032" layer="21" curve="12.581752"/>
<wire x1="7.2384" y1="2.7893" x2="7.7616" y2="2.7893" width="0.2032" layer="21" curve="12.288948"/>
<wire x1="7.7616" y1="2.7893" x2="8.2649" y2="2.8998" width="0.2032" layer="21" curve="12.443853"/>
<wire x1="8.2649" y1="2.8998" x2="8.718" y2="3.1141" width="0.2032" layer="21" curve="13.24872"/>
<wire x1="8.718" y1="3.1141" x2="9.0864" y2="3.4159" width="0.2032" layer="21" curve="14.441093"/>
<wire x1="9.0864" y1="3.4159" x2="9.3273" y2="3.7476" width="0.2032" layer="21" curve="12.852895"/>
<wire x1="9.3273" y1="3.7476" x2="9.4562" y2="4.0727" width="0.2032" layer="21" curve="13.810089"/>
<wire x1="9.4562" y1="4.0727" x2="9.5" y2="4.4136" width="0.2032" layer="21" curve="14.520871"/>
<wire x1="6" y1="-5.15" x2="6" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="6" y1="-5.4" x2="9" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="9" y1="-5.4" x2="9" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="9" y1="-3.75" x2="6" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="6" y1="-3.75" x2="6" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="5.8" y1="-6.2" x2="9.2" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="9.2" y1="-6.2" x2="9.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="9.2" y1="-3" x2="5.8" y2="-3" width="0.2032" layer="21"/>
<wire x1="5.8" y1="-3" x2="5.8" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="12.5" y1="6.0519" x2="12.0839" y2="6.0161" width="0.2032" layer="21" curve="9.818513"/>
<wire x1="12.0839" y1="6.016" x2="11.687" y2="5.9104" width="0.2032" layer="21" curve="10.070203"/>
<wire x1="11.687" y1="5.9104" x2="11.324" y2="5.7387" width="0.2032" layer="21" curve="10.633291"/>
<wire x1="11.324" y1="5.7387" x2="11.0139" y2="5.51" width="0.2032" layer="21" curve="11.361134"/>
<wire x1="11.0139" y1="5.51" x2="10.7679" y2="5.2327" width="0.2032" layer="21" curve="12.408633"/>
<wire x1="10.7679" y1="5.2327" x2="10.6204" y2="4.9736" width="0.2032" layer="21" curve="11.10896"/>
<wire x1="10.6205" y1="4.9736" x2="10.5305" y2="4.6984" width="0.2032" layer="21" curve="11.703364"/>
<wire x1="10.5305" y1="4.6984" x2="10.5" y2="4.4136" width="0.2032" layer="21" curve="12.150409"/>
<wire x1="14.5" y1="4.4136" x2="14.4695" y2="4.6984" width="0.2032" layer="21" curve="12.140502"/>
<wire x1="14.4695" y1="4.6984" x2="14.3795" y2="4.9736" width="0.2032" layer="21" curve="11.823167"/>
<wire x1="14.3795" y1="4.9736" x2="14.2321" y2="5.2327" width="0.2032" layer="21" curve="11.320489"/>
<wire x1="14.2321" y1="5.2327" x2="13.9861" y2="5.51" width="0.2032" layer="21" curve="12.612712"/>
<wire x1="13.9861" y1="5.51" x2="13.676" y2="5.7387" width="0.2032" layer="21" curve="11.606712"/>
<wire x1="13.676" y1="5.7387" x2="13.313" y2="5.9104" width="0.2032" layer="21" curve="10.808503"/>
<wire x1="13.313" y1="5.9104" x2="12.9161" y2="6.016" width="0.2032" layer="21" curve="10.16131"/>
<wire x1="12.9161" y1="6.016" x2="12.5" y2="6.0519" width="0.2032" layer="21" curve="9.8976"/>
<wire x1="10.5" y1="4.4136" x2="10.5438" y2="4.0727" width="0.2032" layer="21" curve="14.538071"/>
<wire x1="10.5438" y1="4.0727" x2="10.6727" y2="3.7476" width="0.2032" layer="21" curve="14.027417"/>
<wire x1="10.6727" y1="3.7476" x2="10.9136" y2="3.4159" width="0.2032" layer="21" curve="16.392544"/>
<wire x1="10.9136" y1="3.4159" x2="11.282" y2="3.1141" width="0.2032" layer="21" curve="14.814063"/>
<wire x1="11.282" y1="3.1141" x2="11.7351" y2="2.8998" width="0.2032" layer="21" curve="13.518622"/>
<wire x1="11.7351" y1="2.8998" x2="12.2384" y2="2.7893" width="0.2032" layer="21" curve="12.581752"/>
<wire x1="12.2384" y1="2.7893" x2="12.7616" y2="2.7893" width="0.2032" layer="21" curve="12.288948"/>
<wire x1="12.7616" y1="2.7893" x2="13.2649" y2="2.8998" width="0.2032" layer="21" curve="12.443853"/>
<wire x1="13.2649" y1="2.8998" x2="13.718" y2="3.1141" width="0.2032" layer="21" curve="13.24872"/>
<wire x1="13.718" y1="3.1141" x2="14.0864" y2="3.4159" width="0.2032" layer="21" curve="14.441093"/>
<wire x1="14.0864" y1="3.4159" x2="14.3273" y2="3.7476" width="0.2032" layer="21" curve="12.852895"/>
<wire x1="14.3273" y1="3.7476" x2="14.4562" y2="4.0727" width="0.2032" layer="21" curve="13.810089"/>
<wire x1="14.4562" y1="4.0727" x2="14.5" y2="4.4136" width="0.2032" layer="21" curve="14.520871"/>
<wire x1="11" y1="-5.15" x2="11" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="11" y1="-5.4" x2="14" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="14" y1="-5.4" x2="14" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="14" y1="-3.75" x2="11" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="11" y1="-3.75" x2="11" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="10.8" y1="-6.2" x2="14.2" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="14.2" y1="-6.2" x2="14.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="14.2" y1="-3" x2="10.8" y2="-3" width="0.2032" layer="21"/>
<wire x1="10.8" y1="-3" x2="10.8" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="17.5" y1="6.0519" x2="17.0839" y2="6.0161" width="0.2032" layer="21" curve="9.818513"/>
<wire x1="17.0839" y1="6.016" x2="16.687" y2="5.9104" width="0.2032" layer="21" curve="10.070203"/>
<wire x1="16.687" y1="5.9104" x2="16.324" y2="5.7387" width="0.2032" layer="21" curve="10.633291"/>
<wire x1="16.324" y1="5.7387" x2="16.0139" y2="5.51" width="0.2032" layer="21" curve="11.361134"/>
<wire x1="16.0139" y1="5.51" x2="15.7679" y2="5.2327" width="0.2032" layer="21" curve="12.408633"/>
<wire x1="15.7679" y1="5.2327" x2="15.6204" y2="4.9736" width="0.2032" layer="21" curve="11.10896"/>
<wire x1="15.6205" y1="4.9736" x2="15.5305" y2="4.6984" width="0.2032" layer="21" curve="11.703364"/>
<wire x1="15.5305" y1="4.6984" x2="15.5" y2="4.4136" width="0.2032" layer="21" curve="12.150409"/>
<wire x1="19.5" y1="4.4136" x2="19.4695" y2="4.6984" width="0.2032" layer="21" curve="12.140502"/>
<wire x1="19.4695" y1="4.6984" x2="19.3795" y2="4.9736" width="0.2032" layer="21" curve="11.823167"/>
<wire x1="19.3795" y1="4.9736" x2="19.2321" y2="5.2327" width="0.2032" layer="21" curve="11.320489"/>
<wire x1="19.2321" y1="5.2327" x2="18.9861" y2="5.51" width="0.2032" layer="21" curve="12.612712"/>
<wire x1="18.9861" y1="5.51" x2="18.676" y2="5.7387" width="0.2032" layer="21" curve="11.606712"/>
<wire x1="18.676" y1="5.7387" x2="18.313" y2="5.9104" width="0.2032" layer="21" curve="10.808503"/>
<wire x1="18.313" y1="5.9104" x2="17.9161" y2="6.016" width="0.2032" layer="21" curve="10.16131"/>
<wire x1="17.9161" y1="6.016" x2="17.5" y2="6.0519" width="0.2032" layer="21" curve="9.8976"/>
<wire x1="15.5" y1="4.4136" x2="15.5438" y2="4.0727" width="0.2032" layer="21" curve="14.538071"/>
<wire x1="15.5438" y1="4.0727" x2="15.6727" y2="3.7476" width="0.2032" layer="21" curve="14.027417"/>
<wire x1="15.6727" y1="3.7476" x2="15.9136" y2="3.4159" width="0.2032" layer="21" curve="16.392544"/>
<wire x1="15.9136" y1="3.4159" x2="16.282" y2="3.1141" width="0.2032" layer="21" curve="14.814063"/>
<wire x1="16.282" y1="3.1141" x2="16.7351" y2="2.8998" width="0.2032" layer="21" curve="13.518622"/>
<wire x1="16.7351" y1="2.8998" x2="17.2384" y2="2.7893" width="0.2032" layer="21" curve="12.581752"/>
<wire x1="17.2384" y1="2.7893" x2="17.7616" y2="2.7893" width="0.2032" layer="21" curve="12.288948"/>
<wire x1="17.7616" y1="2.7893" x2="18.2649" y2="2.8998" width="0.2032" layer="21" curve="12.443853"/>
<wire x1="18.2649" y1="2.8998" x2="18.718" y2="3.1141" width="0.2032" layer="21" curve="13.24872"/>
<wire x1="18.718" y1="3.1141" x2="19.0864" y2="3.4159" width="0.2032" layer="21" curve="14.441093"/>
<wire x1="19.0864" y1="3.4159" x2="19.3273" y2="3.7476" width="0.2032" layer="21" curve="12.852895"/>
<wire x1="19.3273" y1="3.7476" x2="19.4562" y2="4.0727" width="0.2032" layer="21" curve="13.810089"/>
<wire x1="19.4562" y1="4.0727" x2="19.5" y2="4.4136" width="0.2032" layer="21" curve="14.520871"/>
<wire x1="16" y1="-5.15" x2="16" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="16" y1="-5.4" x2="19" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="19" y1="-5.4" x2="19" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="19" y1="-3.75" x2="16" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="16" y1="-3.75" x2="16" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="15.8" y1="-6.2" x2="19.2" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="19.2" y1="-6.2" x2="19.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="19.2" y1="-3" x2="15.8" y2="-3" width="0.2032" layer="21"/>
<wire x1="15.8" y1="-3" x2="15.8" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="22.5" y1="6.0519" x2="22.0839" y2="6.0161" width="0.2032" layer="21" curve="9.818513"/>
<wire x1="22.0839" y1="6.016" x2="21.687" y2="5.9104" width="0.2032" layer="21" curve="10.070203"/>
<wire x1="21.687" y1="5.9104" x2="21.324" y2="5.7387" width="0.2032" layer="21" curve="10.633291"/>
<wire x1="21.324" y1="5.7387" x2="21.0139" y2="5.51" width="0.2032" layer="21" curve="11.361134"/>
<wire x1="21.0139" y1="5.51" x2="20.7679" y2="5.2327" width="0.2032" layer="21" curve="12.408633"/>
<wire x1="20.7679" y1="5.2327" x2="20.6204" y2="4.9736" width="0.2032" layer="21" curve="11.10896"/>
<wire x1="20.6205" y1="4.9736" x2="20.5305" y2="4.6984" width="0.2032" layer="21" curve="11.703364"/>
<wire x1="20.5305" y1="4.6984" x2="20.5" y2="4.4136" width="0.2032" layer="21" curve="12.150409"/>
<wire x1="24.5" y1="4.4136" x2="24.4695" y2="4.6984" width="0.2032" layer="21" curve="12.140502"/>
<wire x1="24.4695" y1="4.6984" x2="24.3795" y2="4.9736" width="0.2032" layer="21" curve="11.823167"/>
<wire x1="24.3795" y1="4.9736" x2="24.2321" y2="5.2327" width="0.2032" layer="21" curve="11.320489"/>
<wire x1="24.2321" y1="5.2327" x2="23.9861" y2="5.51" width="0.2032" layer="21" curve="12.612712"/>
<wire x1="23.9861" y1="5.51" x2="23.676" y2="5.7387" width="0.2032" layer="21" curve="11.606712"/>
<wire x1="23.676" y1="5.7387" x2="23.313" y2="5.9104" width="0.2032" layer="21" curve="10.808503"/>
<wire x1="23.313" y1="5.9104" x2="22.9161" y2="6.016" width="0.2032" layer="21" curve="10.16131"/>
<wire x1="22.9161" y1="6.016" x2="22.5" y2="6.0519" width="0.2032" layer="21" curve="9.8976"/>
<wire x1="20.5" y1="4.4136" x2="20.5438" y2="4.0727" width="0.2032" layer="21" curve="14.538071"/>
<wire x1="20.5438" y1="4.0727" x2="20.6727" y2="3.7476" width="0.2032" layer="21" curve="14.027417"/>
<wire x1="20.6727" y1="3.7476" x2="20.9136" y2="3.4159" width="0.2032" layer="21" curve="16.392544"/>
<wire x1="20.9136" y1="3.4159" x2="21.282" y2="3.1141" width="0.2032" layer="21" curve="14.814063"/>
<wire x1="21.282" y1="3.1141" x2="21.7351" y2="2.8998" width="0.2032" layer="21" curve="13.518622"/>
<wire x1="21.7351" y1="2.8998" x2="22.2384" y2="2.7893" width="0.2032" layer="21" curve="12.581752"/>
<wire x1="22.2384" y1="2.7893" x2="22.7616" y2="2.7893" width="0.2032" layer="21" curve="12.288948"/>
<wire x1="22.7616" y1="2.7893" x2="23.2649" y2="2.8998" width="0.2032" layer="21" curve="12.443853"/>
<wire x1="23.2649" y1="2.8998" x2="23.718" y2="3.1141" width="0.2032" layer="21" curve="13.24872"/>
<wire x1="23.718" y1="3.1141" x2="24.0864" y2="3.4159" width="0.2032" layer="21" curve="14.441093"/>
<wire x1="24.0864" y1="3.4159" x2="24.3273" y2="3.7476" width="0.2032" layer="21" curve="12.852895"/>
<wire x1="24.3273" y1="3.7476" x2="24.4562" y2="4.0727" width="0.2032" layer="21" curve="13.810089"/>
<wire x1="24.4562" y1="4.0727" x2="24.5" y2="4.4136" width="0.2032" layer="21" curve="14.520871"/>
<wire x1="21" y1="-5.15" x2="21" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="21" y1="-5.4" x2="24" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="24" y1="-5.4" x2="24" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="24" y1="-3.75" x2="21" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="21" y1="-3.75" x2="21" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="20.8" y1="-6.2" x2="24.2" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="24.2" y1="-6.2" x2="24.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="24.2" y1="-3" x2="20.8" y2="-3" width="0.2032" layer="21"/>
<wire x1="20.8" y1="-3" x2="20.8" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="27.5" y1="6.0519" x2="27.0839" y2="6.0161" width="0.2032" layer="21" curve="9.818513"/>
<wire x1="27.0839" y1="6.016" x2="26.687" y2="5.9104" width="0.2032" layer="21" curve="10.070203"/>
<wire x1="26.687" y1="5.9104" x2="26.324" y2="5.7387" width="0.2032" layer="21" curve="10.633291"/>
<wire x1="26.324" y1="5.7387" x2="26.0139" y2="5.51" width="0.2032" layer="21" curve="11.361134"/>
<wire x1="26.0139" y1="5.51" x2="25.7679" y2="5.2327" width="0.2032" layer="21" curve="12.408633"/>
<wire x1="25.7679" y1="5.2327" x2="25.6204" y2="4.9736" width="0.2032" layer="21" curve="11.10896"/>
<wire x1="25.6205" y1="4.9736" x2="25.5305" y2="4.6984" width="0.2032" layer="21" curve="11.703364"/>
<wire x1="25.5305" y1="4.6984" x2="25.5" y2="4.4136" width="0.2032" layer="21" curve="12.150409"/>
<wire x1="29.5" y1="4.4136" x2="29.4695" y2="4.6984" width="0.2032" layer="21" curve="12.140502"/>
<wire x1="29.4695" y1="4.6984" x2="29.3795" y2="4.9736" width="0.2032" layer="21" curve="11.823167"/>
<wire x1="29.3795" y1="4.9736" x2="29.2321" y2="5.2327" width="0.2032" layer="21" curve="11.320489"/>
<wire x1="29.2321" y1="5.2327" x2="28.9861" y2="5.51" width="0.2032" layer="21" curve="12.612712"/>
<wire x1="28.9861" y1="5.51" x2="28.676" y2="5.7387" width="0.2032" layer="21" curve="11.606712"/>
<wire x1="28.676" y1="5.7387" x2="28.313" y2="5.9104" width="0.2032" layer="21" curve="10.808503"/>
<wire x1="28.313" y1="5.9104" x2="27.9161" y2="6.016" width="0.2032" layer="21" curve="10.16131"/>
<wire x1="27.9161" y1="6.016" x2="27.5" y2="6.0519" width="0.2032" layer="21" curve="9.8976"/>
<wire x1="25.5" y1="4.4136" x2="25.5438" y2="4.0727" width="0.2032" layer="21" curve="14.538071"/>
<wire x1="25.5438" y1="4.0727" x2="25.6727" y2="3.7476" width="0.2032" layer="21" curve="14.027417"/>
<wire x1="25.6727" y1="3.7476" x2="25.9136" y2="3.4159" width="0.2032" layer="21" curve="16.392544"/>
<wire x1="25.9136" y1="3.4159" x2="26.282" y2="3.1141" width="0.2032" layer="21" curve="14.814063"/>
<wire x1="26.282" y1="3.1141" x2="26.7351" y2="2.8998" width="0.2032" layer="21" curve="13.518622"/>
<wire x1="26.7351" y1="2.8998" x2="27.2384" y2="2.7893" width="0.2032" layer="21" curve="12.581752"/>
<wire x1="27.2384" y1="2.7893" x2="27.7616" y2="2.7893" width="0.2032" layer="21" curve="12.288948"/>
<wire x1="27.7616" y1="2.7893" x2="28.2649" y2="2.8998" width="0.2032" layer="21" curve="12.443853"/>
<wire x1="28.2649" y1="2.8998" x2="28.718" y2="3.1141" width="0.2032" layer="21" curve="13.24872"/>
<wire x1="28.718" y1="3.1141" x2="29.0864" y2="3.4159" width="0.2032" layer="21" curve="14.441093"/>
<wire x1="29.0864" y1="3.4159" x2="29.3273" y2="3.7476" width="0.2032" layer="21" curve="12.852895"/>
<wire x1="29.3273" y1="3.7476" x2="29.4562" y2="4.0727" width="0.2032" layer="21" curve="13.810089"/>
<wire x1="29.4562" y1="4.0727" x2="29.5" y2="4.4136" width="0.2032" layer="21" curve="14.520871"/>
<wire x1="26" y1="-5.15" x2="26" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="26" y1="-5.4" x2="29" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="29" y1="-5.4" x2="29" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="29" y1="-3.75" x2="26" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="26" y1="-3.75" x2="26" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="25.8" y1="-6.2" x2="29.2" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="29.2" y1="-6.2" x2="29.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="29.2" y1="-3" x2="25.8" y2="-3" width="0.2032" layer="21"/>
<wire x1="25.8" y1="-3" x2="25.8" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="32.5" y1="6.0519" x2="32.0839" y2="6.0161" width="0.2032" layer="21" curve="9.818513"/>
<wire x1="32.0839" y1="6.016" x2="31.687" y2="5.9104" width="0.2032" layer="21" curve="10.070203"/>
<wire x1="31.687" y1="5.9104" x2="31.324" y2="5.7387" width="0.2032" layer="21" curve="10.633291"/>
<wire x1="31.324" y1="5.7387" x2="31.0139" y2="5.51" width="0.2032" layer="21" curve="11.361134"/>
<wire x1="31.0139" y1="5.51" x2="30.7679" y2="5.2327" width="0.2032" layer="21" curve="12.408633"/>
<wire x1="30.7679" y1="5.2327" x2="30.6204" y2="4.9736" width="0.2032" layer="21" curve="11.10896"/>
<wire x1="30.6205" y1="4.9736" x2="30.5305" y2="4.6984" width="0.2032" layer="21" curve="11.703364"/>
<wire x1="30.5305" y1="4.6984" x2="30.5" y2="4.4136" width="0.2032" layer="21" curve="12.150409"/>
<wire x1="34.5" y1="4.4136" x2="34.4695" y2="4.6984" width="0.2032" layer="21" curve="12.140502"/>
<wire x1="34.4695" y1="4.6984" x2="34.3795" y2="4.9736" width="0.2032" layer="21" curve="11.823167"/>
<wire x1="34.3795" y1="4.9736" x2="34.2321" y2="5.2327" width="0.2032" layer="21" curve="11.320489"/>
<wire x1="34.2321" y1="5.2327" x2="33.9861" y2="5.51" width="0.2032" layer="21" curve="12.612712"/>
<wire x1="33.9861" y1="5.51" x2="33.676" y2="5.7387" width="0.2032" layer="21" curve="11.606712"/>
<wire x1="33.676" y1="5.7387" x2="33.313" y2="5.9104" width="0.2032" layer="21" curve="10.808503"/>
<wire x1="33.313" y1="5.9104" x2="32.9161" y2="6.016" width="0.2032" layer="21" curve="10.16131"/>
<wire x1="32.9161" y1="6.016" x2="32.5" y2="6.0519" width="0.2032" layer="21" curve="9.8976"/>
<wire x1="30.5" y1="4.4136" x2="30.5438" y2="4.0727" width="0.2032" layer="21" curve="14.538071"/>
<wire x1="30.5438" y1="4.0727" x2="30.6727" y2="3.7476" width="0.2032" layer="21" curve="14.027417"/>
<wire x1="30.6727" y1="3.7476" x2="30.9136" y2="3.4159" width="0.2032" layer="21" curve="16.392544"/>
<wire x1="30.9136" y1="3.4159" x2="31.282" y2="3.1141" width="0.2032" layer="21" curve="14.814063"/>
<wire x1="31.282" y1="3.1141" x2="31.7351" y2="2.8998" width="0.2032" layer="21" curve="13.518622"/>
<wire x1="31.7351" y1="2.8998" x2="32.2384" y2="2.7893" width="0.2032" layer="21" curve="12.581752"/>
<wire x1="32.2384" y1="2.7893" x2="32.7616" y2="2.7893" width="0.2032" layer="21" curve="12.288948"/>
<wire x1="32.7616" y1="2.7893" x2="33.2649" y2="2.8998" width="0.2032" layer="21" curve="12.443853"/>
<wire x1="33.2649" y1="2.8998" x2="33.718" y2="3.1141" width="0.2032" layer="21" curve="13.24872"/>
<wire x1="33.718" y1="3.1141" x2="34.0864" y2="3.4159" width="0.2032" layer="21" curve="14.441093"/>
<wire x1="34.0864" y1="3.4159" x2="34.3273" y2="3.7476" width="0.2032" layer="21" curve="12.852895"/>
<wire x1="34.3273" y1="3.7476" x2="34.4562" y2="4.0727" width="0.2032" layer="21" curve="13.810089"/>
<wire x1="34.4562" y1="4.0727" x2="34.5" y2="4.4136" width="0.2032" layer="21" curve="14.520871"/>
<wire x1="31" y1="-5.15" x2="31" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="31" y1="-5.4" x2="34" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="34" y1="-5.4" x2="34" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="34" y1="-3.75" x2="31" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="31" y1="-3.75" x2="31" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="30.8" y1="-6.2" x2="34.2" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="34.2" y1="-6.2" x2="34.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="34.2" y1="-3" x2="30.8" y2="-3" width="0.2032" layer="21"/>
<wire x1="30.8" y1="-3" x2="30.8" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="37.5" y1="6.0519" x2="37.0839" y2="6.0161" width="0.2032" layer="21" curve="9.818513"/>
<wire x1="37.0839" y1="6.016" x2="36.687" y2="5.9104" width="0.2032" layer="21" curve="10.070203"/>
<wire x1="36.687" y1="5.9104" x2="36.324" y2="5.7387" width="0.2032" layer="21" curve="10.633291"/>
<wire x1="36.324" y1="5.7387" x2="36.0139" y2="5.51" width="0.2032" layer="21" curve="11.361134"/>
<wire x1="36.0139" y1="5.51" x2="35.7679" y2="5.2327" width="0.2032" layer="21" curve="12.408633"/>
<wire x1="35.7679" y1="5.2327" x2="35.6204" y2="4.9736" width="0.2032" layer="21" curve="11.10896"/>
<wire x1="35.6205" y1="4.9736" x2="35.5305" y2="4.6984" width="0.2032" layer="21" curve="11.703364"/>
<wire x1="35.5305" y1="4.6984" x2="35.5" y2="4.4136" width="0.2032" layer="21" curve="12.150409"/>
<wire x1="39.5" y1="4.4136" x2="39.4695" y2="4.6984" width="0.2032" layer="21" curve="12.140502"/>
<wire x1="39.4695" y1="4.6984" x2="39.3795" y2="4.9736" width="0.2032" layer="21" curve="11.823167"/>
<wire x1="39.3795" y1="4.9736" x2="39.2321" y2="5.2327" width="0.2032" layer="21" curve="11.320489"/>
<wire x1="39.2321" y1="5.2327" x2="38.9861" y2="5.51" width="0.2032" layer="21" curve="12.612712"/>
<wire x1="38.9861" y1="5.51" x2="38.676" y2="5.7387" width="0.2032" layer="21" curve="11.606712"/>
<wire x1="38.676" y1="5.7387" x2="38.313" y2="5.9104" width="0.2032" layer="21" curve="10.808503"/>
<wire x1="38.313" y1="5.9104" x2="37.9161" y2="6.016" width="0.2032" layer="21" curve="10.16131"/>
<wire x1="37.9161" y1="6.016" x2="37.5" y2="6.0519" width="0.2032" layer="21" curve="9.8976"/>
<wire x1="35.5" y1="4.4136" x2="35.5438" y2="4.0727" width="0.2032" layer="21" curve="14.538071"/>
<wire x1="35.5438" y1="4.0727" x2="35.6727" y2="3.7476" width="0.2032" layer="21" curve="14.027417"/>
<wire x1="35.6727" y1="3.7476" x2="35.9136" y2="3.4159" width="0.2032" layer="21" curve="16.392544"/>
<wire x1="35.9136" y1="3.4159" x2="36.282" y2="3.1141" width="0.2032" layer="21" curve="14.814063"/>
<wire x1="36.282" y1="3.1141" x2="36.7351" y2="2.8998" width="0.2032" layer="21" curve="13.518622"/>
<wire x1="36.7351" y1="2.8998" x2="37.2384" y2="2.7893" width="0.2032" layer="21" curve="12.581752"/>
<wire x1="37.2384" y1="2.7893" x2="37.7616" y2="2.7893" width="0.2032" layer="21" curve="12.288948"/>
<wire x1="37.7616" y1="2.7893" x2="38.2649" y2="2.8998" width="0.2032" layer="21" curve="12.443853"/>
<wire x1="38.2649" y1="2.8998" x2="38.718" y2="3.1141" width="0.2032" layer="21" curve="13.24872"/>
<wire x1="38.718" y1="3.1141" x2="39.0864" y2="3.4159" width="0.2032" layer="21" curve="14.441093"/>
<wire x1="39.0864" y1="3.4159" x2="39.3273" y2="3.7476" width="0.2032" layer="21" curve="12.852895"/>
<wire x1="39.3273" y1="3.7476" x2="39.4562" y2="4.0727" width="0.2032" layer="21" curve="13.810089"/>
<wire x1="39.4562" y1="4.0727" x2="39.5" y2="4.4136" width="0.2032" layer="21" curve="14.520871"/>
<wire x1="36" y1="-5.15" x2="36" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="36" y1="-5.4" x2="39" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="39" y1="-5.4" x2="39" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="39" y1="-3.75" x2="36" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="36" y1="-3.75" x2="36" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="35.8" y1="-6.2" x2="39.2" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="39.2" y1="-6.2" x2="39.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="39.2" y1="-3" x2="35.8" y2="-3" width="0.2032" layer="21"/>
<wire x1="35.8" y1="-3" x2="35.8" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="42.5" y1="6.0519" x2="42.0839" y2="6.0161" width="0.2032" layer="21" curve="9.818513"/>
<wire x1="42.0839" y1="6.016" x2="41.687" y2="5.9104" width="0.2032" layer="21" curve="10.070203"/>
<wire x1="41.687" y1="5.9104" x2="41.324" y2="5.7387" width="0.2032" layer="21" curve="10.633291"/>
<wire x1="41.324" y1="5.7387" x2="41.0139" y2="5.51" width="0.2032" layer="21" curve="11.361134"/>
<wire x1="41.0139" y1="5.51" x2="40.7679" y2="5.2327" width="0.2032" layer="21" curve="12.408633"/>
<wire x1="40.7679" y1="5.2327" x2="40.6204" y2="4.9736" width="0.2032" layer="21" curve="11.10896"/>
<wire x1="40.6205" y1="4.9736" x2="40.5305" y2="4.6984" width="0.2032" layer="21" curve="11.703364"/>
<wire x1="40.5305" y1="4.6984" x2="40.5" y2="4.4136" width="0.2032" layer="21" curve="12.150409"/>
<wire x1="44.5" y1="4.4136" x2="44.4695" y2="4.6984" width="0.2032" layer="21" curve="12.140502"/>
<wire x1="44.4695" y1="4.6984" x2="44.3795" y2="4.9736" width="0.2032" layer="21" curve="11.823167"/>
<wire x1="44.3795" y1="4.9736" x2="44.2321" y2="5.2327" width="0.2032" layer="21" curve="11.320489"/>
<wire x1="44.2321" y1="5.2327" x2="43.9861" y2="5.51" width="0.2032" layer="21" curve="12.612712"/>
<wire x1="43.9861" y1="5.51" x2="43.676" y2="5.7387" width="0.2032" layer="21" curve="11.606712"/>
<wire x1="43.676" y1="5.7387" x2="43.313" y2="5.9104" width="0.2032" layer="21" curve="10.808503"/>
<wire x1="43.313" y1="5.9104" x2="42.9161" y2="6.016" width="0.2032" layer="21" curve="10.16131"/>
<wire x1="42.9161" y1="6.016" x2="42.5" y2="6.0519" width="0.2032" layer="21" curve="9.8976"/>
<wire x1="40.5" y1="4.4136" x2="40.5438" y2="4.0727" width="0.2032" layer="21" curve="14.538071"/>
<wire x1="40.5438" y1="4.0727" x2="40.6727" y2="3.7476" width="0.2032" layer="21" curve="14.027417"/>
<wire x1="40.6727" y1="3.7476" x2="40.9136" y2="3.4159" width="0.2032" layer="21" curve="16.392544"/>
<wire x1="40.9136" y1="3.4159" x2="41.282" y2="3.1141" width="0.2032" layer="21" curve="14.814063"/>
<wire x1="41.282" y1="3.1141" x2="41.7351" y2="2.8998" width="0.2032" layer="21" curve="13.518622"/>
<wire x1="41.7351" y1="2.8998" x2="42.2384" y2="2.7893" width="0.2032" layer="21" curve="12.581752"/>
<wire x1="42.2384" y1="2.7893" x2="42.7616" y2="2.7893" width="0.2032" layer="21" curve="12.288948"/>
<wire x1="42.7616" y1="2.7893" x2="43.2649" y2="2.8998" width="0.2032" layer="21" curve="12.443853"/>
<wire x1="43.2649" y1="2.8998" x2="43.718" y2="3.1141" width="0.2032" layer="21" curve="13.24872"/>
<wire x1="43.718" y1="3.1141" x2="44.0864" y2="3.4159" width="0.2032" layer="21" curve="14.441093"/>
<wire x1="44.0864" y1="3.4159" x2="44.3273" y2="3.7476" width="0.2032" layer="21" curve="12.852895"/>
<wire x1="44.3273" y1="3.7476" x2="44.4562" y2="4.0727" width="0.2032" layer="21" curve="13.810089"/>
<wire x1="44.4562" y1="4.0727" x2="44.5" y2="4.4136" width="0.2032" layer="21" curve="14.520871"/>
<wire x1="41" y1="-5.15" x2="41" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="41" y1="-5.4" x2="44" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="44" y1="-5.4" x2="44" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="44" y1="-3.75" x2="41" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="41" y1="-3.75" x2="41" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="40.8" y1="-6.2" x2="44.2" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="44.2" y1="-6.2" x2="44.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="44.2" y1="-3" x2="40.8" y2="-3" width="0.2032" layer="21"/>
<wire x1="40.8" y1="-3" x2="40.8" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="47.5" y1="6.0519" x2="47.0839" y2="6.0161" width="0.2032" layer="21" curve="9.818513"/>
<wire x1="47.0839" y1="6.016" x2="46.687" y2="5.9104" width="0.2032" layer="21" curve="10.070203"/>
<wire x1="46.687" y1="5.9104" x2="46.324" y2="5.7387" width="0.2032" layer="21" curve="10.633291"/>
<wire x1="46.324" y1="5.7387" x2="46.0139" y2="5.51" width="0.2032" layer="21" curve="11.361134"/>
<wire x1="46.0139" y1="5.51" x2="45.7679" y2="5.2327" width="0.2032" layer="21" curve="12.408633"/>
<wire x1="45.7679" y1="5.2327" x2="45.6204" y2="4.9736" width="0.2032" layer="21" curve="11.10896"/>
<wire x1="45.6205" y1="4.9736" x2="45.5305" y2="4.6984" width="0.2032" layer="21" curve="11.703364"/>
<wire x1="45.5305" y1="4.6984" x2="45.5" y2="4.4136" width="0.2032" layer="21" curve="12.150409"/>
<wire x1="49.5" y1="4.4136" x2="49.4695" y2="4.6984" width="0.2032" layer="21" curve="12.140502"/>
<wire x1="49.4695" y1="4.6984" x2="49.3795" y2="4.9736" width="0.2032" layer="21" curve="11.823167"/>
<wire x1="49.3795" y1="4.9736" x2="49.2321" y2="5.2327" width="0.2032" layer="21" curve="11.320489"/>
<wire x1="49.2321" y1="5.2327" x2="48.9861" y2="5.51" width="0.2032" layer="21" curve="12.612712"/>
<wire x1="48.9861" y1="5.51" x2="48.676" y2="5.7387" width="0.2032" layer="21" curve="11.606712"/>
<wire x1="48.676" y1="5.7387" x2="48.313" y2="5.9104" width="0.2032" layer="21" curve="10.808503"/>
<wire x1="48.313" y1="5.9104" x2="47.9161" y2="6.016" width="0.2032" layer="21" curve="10.16131"/>
<wire x1="47.9161" y1="6.016" x2="47.5" y2="6.0519" width="0.2032" layer="21" curve="9.8976"/>
<wire x1="45.5" y1="4.4136" x2="45.5438" y2="4.0727" width="0.2032" layer="21" curve="14.538071"/>
<wire x1="45.5438" y1="4.0727" x2="45.6727" y2="3.7476" width="0.2032" layer="21" curve="14.027417"/>
<wire x1="45.6727" y1="3.7476" x2="45.9136" y2="3.4159" width="0.2032" layer="21" curve="16.392544"/>
<wire x1="45.9136" y1="3.4159" x2="46.282" y2="3.1141" width="0.2032" layer="21" curve="14.814063"/>
<wire x1="46.282" y1="3.1141" x2="46.7351" y2="2.8998" width="0.2032" layer="21" curve="13.518622"/>
<wire x1="46.7351" y1="2.8998" x2="47.2384" y2="2.7893" width="0.2032" layer="21" curve="12.581752"/>
<wire x1="47.2384" y1="2.7893" x2="47.7616" y2="2.7893" width="0.2032" layer="21" curve="12.288948"/>
<wire x1="47.7616" y1="2.7893" x2="48.2649" y2="2.8998" width="0.2032" layer="21" curve="12.443853"/>
<wire x1="48.2649" y1="2.8998" x2="48.718" y2="3.1141" width="0.2032" layer="21" curve="13.24872"/>
<wire x1="48.718" y1="3.1141" x2="49.0864" y2="3.4159" width="0.2032" layer="21" curve="14.441093"/>
<wire x1="49.0864" y1="3.4159" x2="49.3273" y2="3.7476" width="0.2032" layer="21" curve="12.852895"/>
<wire x1="49.3273" y1="3.7476" x2="49.4562" y2="4.0727" width="0.2032" layer="21" curve="13.810089"/>
<wire x1="49.4562" y1="4.0727" x2="49.5" y2="4.4136" width="0.2032" layer="21" curve="14.520871"/>
<wire x1="46" y1="-5.15" x2="46" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="46" y1="-5.4" x2="49" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="49" y1="-5.4" x2="49" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="49" y1="-3.75" x2="46" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="46" y1="-3.75" x2="46" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="45.8" y1="-6.2" x2="49.2" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="49.2" y1="-6.2" x2="49.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="49.2" y1="-3" x2="45.8" y2="-3" width="0.2032" layer="21"/>
<wire x1="45.8" y1="-3" x2="45.8" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="52.5" y1="6.0519" x2="52.0839" y2="6.0161" width="0.2032" layer="21" curve="9.818513"/>
<wire x1="52.0839" y1="6.016" x2="51.687" y2="5.9104" width="0.2032" layer="21" curve="10.070203"/>
<wire x1="51.687" y1="5.9104" x2="51.324" y2="5.7387" width="0.2032" layer="21" curve="10.633291"/>
<wire x1="51.324" y1="5.7387" x2="51.0139" y2="5.51" width="0.2032" layer="21" curve="11.361134"/>
<wire x1="51.0139" y1="5.51" x2="50.7679" y2="5.2327" width="0.2032" layer="21" curve="12.408633"/>
<wire x1="50.7679" y1="5.2327" x2="50.6204" y2="4.9736" width="0.2032" layer="21" curve="11.10896"/>
<wire x1="50.6205" y1="4.9736" x2="50.5305" y2="4.6984" width="0.2032" layer="21" curve="11.703364"/>
<wire x1="50.5305" y1="4.6984" x2="50.5" y2="4.4136" width="0.2032" layer="21" curve="12.150409"/>
<wire x1="54.5" y1="4.4136" x2="54.4695" y2="4.6984" width="0.2032" layer="21" curve="12.140502"/>
<wire x1="54.4695" y1="4.6984" x2="54.3795" y2="4.9736" width="0.2032" layer="21" curve="11.823167"/>
<wire x1="54.3795" y1="4.9736" x2="54.2321" y2="5.2327" width="0.2032" layer="21" curve="11.320489"/>
<wire x1="54.2321" y1="5.2327" x2="53.9861" y2="5.51" width="0.2032" layer="21" curve="12.612712"/>
<wire x1="53.9861" y1="5.51" x2="53.676" y2="5.7387" width="0.2032" layer="21" curve="11.606712"/>
<wire x1="53.676" y1="5.7387" x2="53.313" y2="5.9104" width="0.2032" layer="21" curve="10.808503"/>
<wire x1="53.313" y1="5.9104" x2="52.9161" y2="6.016" width="0.2032" layer="21" curve="10.16131"/>
<wire x1="52.9161" y1="6.016" x2="52.5" y2="6.0519" width="0.2032" layer="21" curve="9.8976"/>
<wire x1="50.5" y1="4.4136" x2="50.5438" y2="4.0727" width="0.2032" layer="21" curve="14.538071"/>
<wire x1="50.5438" y1="4.0727" x2="50.6727" y2="3.7476" width="0.2032" layer="21" curve="14.027417"/>
<wire x1="50.6727" y1="3.7476" x2="50.9136" y2="3.4159" width="0.2032" layer="21" curve="16.392544"/>
<wire x1="50.9136" y1="3.4159" x2="51.282" y2="3.1141" width="0.2032" layer="21" curve="14.814063"/>
<wire x1="51.282" y1="3.1141" x2="51.7351" y2="2.8998" width="0.2032" layer="21" curve="13.518622"/>
<wire x1="51.7351" y1="2.8998" x2="52.2384" y2="2.7893" width="0.2032" layer="21" curve="12.581752"/>
<wire x1="52.2384" y1="2.7893" x2="52.7616" y2="2.7893" width="0.2032" layer="21" curve="12.288948"/>
<wire x1="52.7616" y1="2.7893" x2="53.2649" y2="2.8998" width="0.2032" layer="21" curve="12.443853"/>
<wire x1="53.2649" y1="2.8998" x2="53.718" y2="3.1141" width="0.2032" layer="21" curve="13.24872"/>
<wire x1="53.718" y1="3.1141" x2="54.0864" y2="3.4159" width="0.2032" layer="21" curve="14.441093"/>
<wire x1="54.0864" y1="3.4159" x2="54.3273" y2="3.7476" width="0.2032" layer="21" curve="12.852895"/>
<wire x1="54.3273" y1="3.7476" x2="54.4562" y2="4.0727" width="0.2032" layer="21" curve="13.810089"/>
<wire x1="54.4562" y1="4.0727" x2="54.5" y2="4.4136" width="0.2032" layer="21" curve="14.520871"/>
<wire x1="51" y1="-5.15" x2="51" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="51" y1="-5.4" x2="54" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="54" y1="-5.4" x2="54" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="54" y1="-3.75" x2="51" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="51" y1="-3.75" x2="51" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="50.8" y1="-6.2" x2="54.2" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="54.2" y1="-6.2" x2="54.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="54.2" y1="-3" x2="50.8" y2="-3" width="0.2032" layer="21"/>
<wire x1="50.8" y1="-3" x2="50.8" y2="-6.2" width="0.2032" layer="21"/>
<pad name="1" x="-2.5" y="0" drill="1.6" diameter="1.8" shape="long" rot="R90"/>
<pad name="2" x="2.5" y="0" drill="1.6" diameter="1.8" shape="long" rot="R90"/>
<pad name="3" x="7.5" y="0" drill="1.6" diameter="1.8" shape="long" rot="R90"/>
<pad name="4" x="12.5" y="0" drill="1.6" diameter="1.8" shape="long" rot="R90"/>
<pad name="5" x="17.5" y="0" drill="1.6" diameter="1.8" shape="long" rot="R90"/>
<pad name="6" x="22.5" y="0" drill="1.6" diameter="1.8" shape="long" rot="R90"/>
<pad name="7" x="27.5" y="0" drill="1.6" diameter="1.8" shape="long" rot="R90"/>
<pad name="8" x="32.5" y="0" drill="1.6" diameter="1.8" shape="long" rot="R90"/>
<pad name="9" x="37.5" y="0" drill="1.6" diameter="1.8" shape="long" rot="R90"/>
<pad name="10" x="42.5" y="0" drill="1.6" diameter="1.8" shape="long" rot="R90"/>
<pad name="11" x="47.5" y="0" drill="1.6" diameter="1.8" shape="long" rot="R90"/>
<pad name="12" x="52.5" y="0" drill="1.6" diameter="1.8" shape="long" rot="R90"/>
<text x="-5.08" y="6.985" size="1.27" layer="25">&gt;NAME</text>
<text x="1.905" y="6.985" size="1.27" layer="27">&gt;VALUE</text>
</package>
<package name="SMKDSP_1,5/14">
<wire x1="64.9" y1="-1.9017" x2="-4.9" y2="-1.9017" width="0.2032" layer="21"/>
<wire x1="64.9" y1="-2.354" x2="-4.9" y2="-2.354" width="0.2032" layer="21"/>
<wire x1="64.9" y1="2.192" x2="-4.9" y2="2.192" width="0.2032" layer="21"/>
<wire x1="64.9" y1="2.6785" x2="-4.9" y2="2.6785" width="0.2032" layer="21"/>
<wire x1="-4.9" y1="-6.9" x2="64.9" y2="-6.9" width="0.2032" layer="21"/>
<wire x1="64.9" y1="-6.9" x2="64.9" y2="-2.354" width="0.2032" layer="21"/>
<wire x1="64.9" y1="-2.354" x2="64.9" y2="-1.9017" width="0.2032" layer="21"/>
<wire x1="64.9" y1="-1.9017" x2="64.9" y2="2.192" width="0.2032" layer="21"/>
<wire x1="64.9" y1="2.192" x2="64.9" y2="2.6785" width="0.2032" layer="21"/>
<wire x1="64.9" y1="2.6785" x2="64.9" y2="6.3" width="0.2032" layer="21"/>
<wire x1="64.9" y1="6.3" x2="-4.9" y2="6.3" width="0.2032" layer="21"/>
<wire x1="65" y1="-6.3" x2="65.2" y2="-6.3" width="0.2032" layer="21"/>
<wire x1="65.2" y1="-6.3" x2="65.4" y2="-6.45" width="0.2032" layer="21"/>
<wire x1="65.4" y1="-6.45" x2="65.65" y2="-6.45" width="0.2032" layer="21"/>
<wire x1="65.65" y1="-6.45" x2="65.65" y2="-1.9" width="0.2032" layer="21"/>
<wire x1="65.65" y1="-1.9" x2="65.45" y2="-1.9" width="0.2032" layer="21"/>
<wire x1="65.45" y1="-1.9" x2="65.2" y2="-2.05" width="0.2032" layer="21"/>
<wire x1="65.2" y1="-2.05" x2="65" y2="-2.05" width="0.2032" layer="21"/>
<wire x1="65" y1="1.15" x2="65.2" y2="1.15" width="0.2032" layer="21"/>
<wire x1="65.2" y1="1.15" x2="65.4" y2="0.95" width="0.2032" layer="21"/>
<wire x1="65.4" y1="0.95" x2="65.65" y2="0.95" width="0.2032" layer="21"/>
<wire x1="65.65" y1="0.95" x2="65.65" y2="3.75" width="0.2032" layer="21"/>
<wire x1="65.65" y1="3.75" x2="65.4" y2="3.75" width="0.2032" layer="21"/>
<wire x1="65.4" y1="3.75" x2="65.2" y2="3.6" width="0.2032" layer="21"/>
<wire x1="65.2" y1="3.6" x2="65" y2="3.6" width="0.2032" layer="21"/>
<wire x1="57.5" y1="6.0519" x2="57.0839" y2="6.0161" width="0.2032" layer="21" curve="9.818513"/>
<wire x1="57.0839" y1="6.016" x2="56.687" y2="5.9104" width="0.2032" layer="21" curve="10.070203"/>
<wire x1="56.687" y1="5.9104" x2="56.324" y2="5.7387" width="0.2032" layer="21" curve="10.633291"/>
<wire x1="56.324" y1="5.7387" x2="56.0139" y2="5.51" width="0.2032" layer="21" curve="11.361134"/>
<wire x1="56.0139" y1="5.51" x2="55.7679" y2="5.2327" width="0.2032" layer="21" curve="12.408633"/>
<wire x1="55.7679" y1="5.2327" x2="55.6204" y2="4.9736" width="0.2032" layer="21" curve="11.10896"/>
<wire x1="55.6205" y1="4.9736" x2="55.5305" y2="4.6984" width="0.2032" layer="21" curve="11.703364"/>
<wire x1="55.5305" y1="4.6984" x2="55.5" y2="4.4136" width="0.2032" layer="21" curve="12.150409"/>
<wire x1="59.5" y1="4.4136" x2="59.4695" y2="4.6984" width="0.2032" layer="21" curve="12.140502"/>
<wire x1="59.4695" y1="4.6984" x2="59.3795" y2="4.9736" width="0.2032" layer="21" curve="11.823167"/>
<wire x1="59.3795" y1="4.9736" x2="59.2321" y2="5.2327" width="0.2032" layer="21" curve="11.320489"/>
<wire x1="59.2321" y1="5.2327" x2="58.9861" y2="5.51" width="0.2032" layer="21" curve="12.612712"/>
<wire x1="58.9861" y1="5.51" x2="58.676" y2="5.7387" width="0.2032" layer="21" curve="11.606712"/>
<wire x1="58.676" y1="5.7387" x2="58.313" y2="5.9104" width="0.2032" layer="21" curve="10.808503"/>
<wire x1="58.313" y1="5.9104" x2="57.9161" y2="6.016" width="0.2032" layer="21" curve="10.16131"/>
<wire x1="57.9161" y1="6.016" x2="57.5" y2="6.0519" width="0.2032" layer="21" curve="9.8976"/>
<wire x1="55.5" y1="4.4136" x2="55.5438" y2="4.0727" width="0.2032" layer="21" curve="14.538071"/>
<wire x1="55.5438" y1="4.0727" x2="55.6727" y2="3.7476" width="0.2032" layer="21" curve="14.027417"/>
<wire x1="55.6727" y1="3.7476" x2="55.9136" y2="3.4159" width="0.2032" layer="21" curve="16.392544"/>
<wire x1="55.9136" y1="3.4159" x2="56.282" y2="3.1141" width="0.2032" layer="21" curve="14.814063"/>
<wire x1="56.282" y1="3.1141" x2="56.7351" y2="2.8998" width="0.2032" layer="21" curve="13.518622"/>
<wire x1="56.7351" y1="2.8998" x2="57.2384" y2="2.7893" width="0.2032" layer="21" curve="12.581752"/>
<wire x1="57.2384" y1="2.7893" x2="57.7616" y2="2.7893" width="0.2032" layer="21" curve="12.288948"/>
<wire x1="57.7616" y1="2.7893" x2="58.2649" y2="2.8998" width="0.2032" layer="21" curve="12.443853"/>
<wire x1="58.2649" y1="2.8998" x2="58.718" y2="3.1141" width="0.2032" layer="21" curve="13.24872"/>
<wire x1="58.718" y1="3.1141" x2="59.0864" y2="3.4159" width="0.2032" layer="21" curve="14.441093"/>
<wire x1="59.0864" y1="3.4159" x2="59.3273" y2="3.7476" width="0.2032" layer="21" curve="12.852895"/>
<wire x1="59.3273" y1="3.7476" x2="59.4562" y2="4.0727" width="0.2032" layer="21" curve="13.810089"/>
<wire x1="59.4562" y1="4.0727" x2="59.5" y2="4.4136" width="0.2032" layer="21" curve="14.520871"/>
<wire x1="56" y1="-5.15" x2="56" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="56" y1="-5.4" x2="59" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="59" y1="-5.4" x2="59" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="59" y1="-3.75" x2="56" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="56" y1="-3.75" x2="56" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="55.8" y1="-6.2" x2="59.2" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="59.2" y1="-6.2" x2="59.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="59.2" y1="-3" x2="55.8" y2="-3" width="0.2032" layer="21"/>
<wire x1="55.8" y1="-3" x2="55.8" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="62.5" y1="6.0519" x2="62.0839" y2="6.0161" width="0.2032" layer="21" curve="9.818513"/>
<wire x1="62.0839" y1="6.016" x2="61.687" y2="5.9104" width="0.2032" layer="21" curve="10.070203"/>
<wire x1="61.687" y1="5.9104" x2="61.324" y2="5.7387" width="0.2032" layer="21" curve="10.633291"/>
<wire x1="61.324" y1="5.7387" x2="61.0139" y2="5.51" width="0.2032" layer="21" curve="11.361134"/>
<wire x1="61.0139" y1="5.51" x2="60.7679" y2="5.2327" width="0.2032" layer="21" curve="12.408633"/>
<wire x1="60.7679" y1="5.2327" x2="60.6204" y2="4.9736" width="0.2032" layer="21" curve="11.10896"/>
<wire x1="60.6205" y1="4.9736" x2="60.5305" y2="4.6984" width="0.2032" layer="21" curve="11.703364"/>
<wire x1="60.5305" y1="4.6984" x2="60.5" y2="4.4136" width="0.2032" layer="21" curve="12.150409"/>
<wire x1="64.5" y1="4.4136" x2="64.4695" y2="4.6984" width="0.2032" layer="21" curve="12.140502"/>
<wire x1="64.4695" y1="4.6984" x2="64.3795" y2="4.9736" width="0.2032" layer="21" curve="11.823167"/>
<wire x1="64.3795" y1="4.9736" x2="64.2321" y2="5.2327" width="0.2032" layer="21" curve="11.320489"/>
<wire x1="64.2321" y1="5.2327" x2="63.9861" y2="5.51" width="0.2032" layer="21" curve="12.612712"/>
<wire x1="63.9861" y1="5.51" x2="63.676" y2="5.7387" width="0.2032" layer="21" curve="11.606712"/>
<wire x1="63.676" y1="5.7387" x2="63.313" y2="5.9104" width="0.2032" layer="21" curve="10.808503"/>
<wire x1="63.313" y1="5.9104" x2="62.9161" y2="6.016" width="0.2032" layer="21" curve="10.16131"/>
<wire x1="62.9161" y1="6.016" x2="62.5" y2="6.0519" width="0.2032" layer="21" curve="9.8976"/>
<wire x1="60.5" y1="4.4136" x2="60.5438" y2="4.0727" width="0.2032" layer="21" curve="14.538071"/>
<wire x1="60.5438" y1="4.0727" x2="60.6727" y2="3.7476" width="0.2032" layer="21" curve="14.027417"/>
<wire x1="60.6727" y1="3.7476" x2="60.9136" y2="3.4159" width="0.2032" layer="21" curve="16.392544"/>
<wire x1="60.9136" y1="3.4159" x2="61.282" y2="3.1141" width="0.2032" layer="21" curve="14.814063"/>
<wire x1="61.282" y1="3.1141" x2="61.7351" y2="2.8998" width="0.2032" layer="21" curve="13.518622"/>
<wire x1="61.7351" y1="2.8998" x2="62.2384" y2="2.7893" width="0.2032" layer="21" curve="12.581752"/>
<wire x1="62.2384" y1="2.7893" x2="62.7616" y2="2.7893" width="0.2032" layer="21" curve="12.288948"/>
<wire x1="62.7616" y1="2.7893" x2="63.2649" y2="2.8998" width="0.2032" layer="21" curve="12.443853"/>
<wire x1="63.2649" y1="2.8998" x2="63.718" y2="3.1141" width="0.2032" layer="21" curve="13.24872"/>
<wire x1="63.718" y1="3.1141" x2="64.0864" y2="3.4159" width="0.2032" layer="21" curve="14.441093"/>
<wire x1="64.0864" y1="3.4159" x2="64.3273" y2="3.7476" width="0.2032" layer="21" curve="12.852895"/>
<wire x1="64.3273" y1="3.7476" x2="64.4562" y2="4.0727" width="0.2032" layer="21" curve="13.810089"/>
<wire x1="64.4562" y1="4.0727" x2="64.5" y2="4.4136" width="0.2032" layer="21" curve="14.520871"/>
<wire x1="61" y1="-5.15" x2="61" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="61" y1="-5.4" x2="64" y2="-5.4" width="0.2032" layer="21"/>
<wire x1="64" y1="-5.4" x2="64" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="64" y1="-3.75" x2="61" y2="-3.75" width="0.2032" layer="21"/>
<wire x1="61" y1="-3.75" x2="61" y2="-5.15" width="0.2032" layer="21"/>
<wire x1="60.8" y1="-6.2" x2="64.2" y2="-6.2" width="0.2032" layer="21"/>
<wire x1="64.2" y1="-6.2" x2="64.2" y2="-3" width="0.2032" layer="21"/>
<wire x1="64.2" y1="-3" x2="60.8" y2="-3" width="0.2032" layer="21"/>
<wire x1="60.8" y1="-3" x2="60.8" y2="-6.2" width="0.2032" layer="21"/>
<pad name="13" x="57.5" y="0" drill="1.6" diameter="1.8" shape="long" rot="R90"/>
<pad name="14" x="62.5" y="0" drill="1.6" diameter="1.8" shape="long" rot="R90"/>
</package>
</packages>
</library>
</libraries>
<attributes>
</attributes>
<variantdefs>
</variantdefs>
<classes>
<class number="0" name="default" width="0" drill="0">
</class>
</classes>
<designrules name="default">
<description language="de">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
Die Standard-Design-Rules sind so gewählt, dass sie für
die meisten Anwendungen passen. Sollte ihre Platine
besondere Anforderungen haben, treffen Sie die erforderlichen
Einstellungen hier und speichern die Design Rules unter
einem neuen Namen ab.</description>
<description language="en">&lt;b&gt;EAGLE Design Rules&lt;/b&gt;
&lt;p&gt;
The default Design Rules have been set to cover
a wide range of applications. Your particular design
may have different requirements, so please make the
necessary adjustments and save your customized
design rules under a new name.</description>
<param name="layerSetup" value="(1*16)"/>
<param name="mtCopper" value="0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm 0.035mm"/>
<param name="mtIsolate" value="1.5mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm 0.15mm 0.2mm"/>
<param name="mdWireWire" value="8mil"/>
<param name="mdWirePad" value="8mil"/>
<param name="mdWireVia" value="8mil"/>
<param name="mdPadPad" value="8mil"/>
<param name="mdPadVia" value="8mil"/>
<param name="mdViaVia" value="8mil"/>
<param name="mdSmdPad" value="8mil"/>
<param name="mdSmdVia" value="8mil"/>
<param name="mdSmdSmd" value="8mil"/>
<param name="mdViaViaSameLayer" value="8mil"/>
<param name="mnLayersViaInSmd" value="2"/>
<param name="mdCopperDimension" value="40mil"/>
<param name="mdDrill" value="8mil"/>
<param name="mdSmdStop" value="0mil"/>
<param name="msWidth" value="10mil"/>
<param name="msDrill" value="24mil"/>
<param name="msMicroVia" value="9.99mm"/>
<param name="msBlindViaRatio" value="0.5"/>
<param name="rvPadTop" value="0.25"/>
<param name="rvPadInner" value="0.25"/>
<param name="rvPadBottom" value="0.25"/>
<param name="rvViaOuter" value="0.25"/>
<param name="rvViaInner" value="0.25"/>
<param name="rvMicroViaOuter" value="0.25"/>
<param name="rvMicroViaInner" value="0.25"/>
<param name="rlMinPadTop" value="10mil"/>
<param name="rlMaxPadTop" value="20mil"/>
<param name="rlMinPadInner" value="10mil"/>
<param name="rlMaxPadInner" value="20mil"/>
<param name="rlMinPadBottom" value="10mil"/>
<param name="rlMaxPadBottom" value="20mil"/>
<param name="rlMinViaOuter" value="8mil"/>
<param name="rlMaxViaOuter" value="20mil"/>
<param name="rlMinViaInner" value="8mil"/>
<param name="rlMaxViaInner" value="20mil"/>
<param name="rlMinMicroViaOuter" value="4mil"/>
<param name="rlMaxMicroViaOuter" value="20mil"/>
<param name="rlMinMicroViaInner" value="4mil"/>
<param name="rlMaxMicroViaInner" value="20mil"/>
<param name="psTop" value="-1"/>
<param name="psBottom" value="-1"/>
<param name="psFirst" value="-1"/>
<param name="psElongationLong" value="100"/>
<param name="psElongationOffset" value="100"/>
<param name="mvStopFrame" value="1"/>
<param name="mvCreamFrame" value="0"/>
<param name="mlMinStopFrame" value="4mil"/>
<param name="mlMaxStopFrame" value="4mil"/>
<param name="mlMinCreamFrame" value="0mil"/>
<param name="mlMaxCreamFrame" value="0mil"/>
<param name="mlViaStopLimit" value="0mil"/>
<param name="srRoundness" value="0"/>
<param name="srMinRoundness" value="0mil"/>
<param name="srMaxRoundness" value="0mil"/>
<param name="slThermalIsolate" value="10mil"/>
<param name="slThermalsForVias" value="0"/>
<param name="dpMaxLengthDifference" value="10mm"/>
<param name="dpGapFactor" value="2.5"/>
<param name="checkGrid" value="0"/>
<param name="checkAngle" value="0"/>
<param name="checkFont" value="1"/>
<param name="checkRestrict" value="1"/>
<param name="useDiameter" value="13"/>
<param name="maxErrors" value="50"/>
</designrules>
<autorouter>
<pass name="Default">
<param name="RoutingGrid" value="50mil"/>
<param name="tpViaShape" value="round"/>
<param name="PrefDir.1" value="|"/>
<param name="PrefDir.2" value="0"/>
<param name="PrefDir.3" value="0"/>
<param name="PrefDir.4" value="0"/>
<param name="PrefDir.5" value="0"/>
<param name="PrefDir.6" value="0"/>
<param name="PrefDir.7" value="0"/>
<param name="PrefDir.8" value="0"/>
<param name="PrefDir.9" value="0"/>
<param name="PrefDir.10" value="0"/>
<param name="PrefDir.11" value="0"/>
<param name="PrefDir.12" value="0"/>
<param name="PrefDir.13" value="0"/>
<param name="PrefDir.14" value="0"/>
<param name="PrefDir.15" value="0"/>
<param name="PrefDir.16" value="-"/>
<param name="cfVia" value="8"/>
<param name="cfNonPref" value="5"/>
<param name="cfChangeDir" value="2"/>
<param name="cfOrthStep" value="2"/>
<param name="cfDiagStep" value="3"/>
<param name="cfExtdStep" value="0"/>
<param name="cfBonusStep" value="1"/>
<param name="cfMalusStep" value="1"/>
<param name="cfPadImpact" value="4"/>
<param name="cfSmdImpact" value="4"/>
<param name="cfBusImpact" value="0"/>
<param name="cfHugging" value="3"/>
<param name="cfAvoid" value="4"/>
<param name="cfPolygon" value="10"/>
<param name="cfBase.1" value="0"/>
<param name="cfBase.2" value="1"/>
<param name="cfBase.3" value="1"/>
<param name="cfBase.4" value="1"/>
<param name="cfBase.5" value="1"/>
<param name="cfBase.6" value="1"/>
<param name="cfBase.7" value="1"/>
<param name="cfBase.8" value="1"/>
<param name="cfBase.9" value="1"/>
<param name="cfBase.10" value="1"/>
<param name="cfBase.11" value="1"/>
<param name="cfBase.12" value="1"/>
<param name="cfBase.13" value="1"/>
<param name="cfBase.14" value="1"/>
<param name="cfBase.15" value="1"/>
<param name="cfBase.16" value="0"/>
<param name="mnVias" value="20"/>
<param name="mnSegments" value="9999"/>
<param name="mnExtdSteps" value="9999"/>
<param name="mnRipupLevel" value="10"/>
<param name="mnRipupSteps" value="100"/>
<param name="mnRipupTotal" value="100"/>
</pass>
<pass name="Follow-me" refer="Default" active="yes">
</pass>
<pass name="Busses" refer="Default" active="yes">
<param name="cfNonPref" value="4"/>
<param name="cfBusImpact" value="4"/>
<param name="cfHugging" value="0"/>
<param name="mnVias" value="0"/>
</pass>
<pass name="Route" refer="Default" active="yes">
</pass>
<pass name="Optimize1" refer="Default" active="yes">
<param name="cfVia" value="99"/>
<param name="cfExtdStep" value="10"/>
<param name="cfHugging" value="1"/>
<param name="mnExtdSteps" value="1"/>
<param name="mnRipupLevel" value="0"/>
</pass>
<pass name="Optimize2" refer="Optimize1" active="yes">
<param name="cfNonPref" value="0"/>
<param name="cfChangeDir" value="6"/>
<param name="cfBonusStep" value="2"/>
<param name="cfMalusStep" value="2"/>
<param name="cfPadImpact" value="2"/>
<param name="cfSmdImpact" value="2"/>
</pass>
<pass name="Optimize3" refer="Optimize2" active="yes">
<param name="cfChangeDir" value="8"/>
<param name="cfPadImpact" value="0"/>
<param name="cfSmdImpact" value="0"/>
</pass>
<pass name="Optimize4" refer="Optimize3" active="yes">
<param name="cfChangeDir" value="25"/>
</pass>
</autorouter>
<elements>
<element name="16F1939" library="microchip" package="TQFP44" value="" x="58.98" y="56.961"/>
<element name="-_+_DC_INPUT" library="con-molex" package="22-23-2031" value="" x="61.431" y="33.211" rot="R180"/>
<element name="R6" library="resistor" package="R1206" value="500" x="91.758" y="35.621" rot="MR270"/>
<element name="ZD1" library="resistor" package="R1206" value="5,1" x="60.415" y="36.53" rot="MR180"/>
<element name="EC3" library="resistor" package="R1206" value="1uF" x="79.738" y="63.74" rot="MR0"/>
<element name="RS232TTL" library="con-molex" package="22-23-2041" value="" x="95.765" y="67.941" rot="R90"/>
<element name="PICKIT" library="con-molex" package="22-23-2051" value="" x="59.667" y="43.329"/>
<element name="R9" library="smd-ipc" package="C0805" value="0" x="84.025" y="62.384" rot="MR90"/>
<element name="REF" library="transistor-small-signal" package="SOT23" value="" x="48.551" y="43.402" rot="MR270"/>
<element name="R10" library="smd-ipc" package="C0805" value="1uF" x="48.331" y="40.638" rot="MR0"/>
<element name="R11" library="smd-ipc" package="C0805" value="0,1uF" x="48.455" y="47.823" rot="MR0"/>
<element name="LED" library="resistor" package="R1206" value="" x="51.605" y="43.544" rot="R90"/>
<element name="R1" library="smd-ipc" package="C0805" value="500" x="50.319" y="37.434" rot="MR90"/>
<element name="MAX232" library="74ac-logic" package="SO16" value="" x="79.283" y="57.372" rot="R270"/>
<element name="RS232" library="con-subd" package="F09VB" value="" x="106.709" y="70.976" rot="R270"/>
<element name="EC4" library="resistor" package="R1206" value="1uF" x="76.707" y="59.511" rot="MR0"/>
<element name="EC5" library="resistor" package="R1206" value="1uF" x="79.371" y="54.381" rot="MR90"/>
<element name="EC9+" library="resistor" package="R1206" value="1UF" x="92.788" y="56.089" rot="R180"/>
<element name="EC2" library="resistor" package="R1206" value="10uf" x="88.436" y="69.111" rot="MR180"/>
<element name="C1" library="resistor" package="R1206" value="100NF" x="54.011" y="47.563" rot="MR180"/>
<element name="+EC8" library="resistor" package="R1206" value="10UF" x="68.113" y="50.659" rot="R270"/>
<element name="TR1" library="transistor-npn" package="SOT23" value="" x="90.997" y="30.526" rot="MR180"/>
<element name="75176B" library="74ac-logic" package="SO08" value="" x="73.996" y="73.43"/>
<element name="R13" library="resistor" package="R1206" value="500" x="88.463" y="82.69" rot="MR90"/>
<element name="R12" library="resistor" package="R1206" value="500" x="89.627" y="76.922" rot="MR90"/>
<element name="R14" library="resistor" package="R1206" value="120" x="84.138" y="79.312" rot="MR90"/>
<element name="RS485" library="con-molex" package="22-23-2031" value="" x="95.789" y="79.937" rot="R90"/>
<element name="+_-_SPI" library="con-molex" package="22-23-2051" value="" x="61.194" y="80.913" rot="R180"/>
<element name="QUARTZ" library="crystal" package="CSM-7X-DU" value="" x="79.546" y="39.692"/>
<element name="C2" library="resistor" package="R1206" value="22PF" x="75.026" y="36.935" rot="MR0"/>
<element name="C3" library="resistor" package="R1206" value="22PF" x="79.894" y="38.306" rot="MR270"/>
<element name="R7" library="resistor" package="R1206" value="0" x="63.590184375" y="47.732725" rot="MR45"/>
<element name="R8" library="resistor" package="R1206" value="0" x="59.00710625" y="50.857775" rot="MR90"/>
<element name="DIGITAL_INPUT" library="con-harting-ml" package="ML10" value="" x="26.025" y="70.531" rot="R270"/>
<element name="ANALOG_INPUT" library="con-harting-ml" package="ML10" value="" x="33.506" y="46.69" rot="R270"/>
<element name="LCD" library="con-subd" package="F15VB" value="" x="86.981" y="21.765" rot="R180"/>
<element name="R3" library="resistor" package="R1206" value="" x="65.465" y="24.61" rot="MR90"/>
<element name="R4" library="resistor" package="R1206" value="" x="71.769" y="24.658" rot="MR90"/>
<element name="R5" library="smd-ipc" package="C0805" value="0" x="68.766" y="29.5" rot="MR90"/>
<element name="PIEZZO" library="buzzer" package="F/HGP" value="" x="36.038" y="25.107"/>
<element name="FET1" library="transistor-small-signal" package="SOT23" value="2N7002" x="33.241" y="29.702" rot="MR0"/>
<element name="R2" library="smd-ipc" package="C0805" value="500" x="34.388" y="36.048" rot="MR0"/>
<element name="EC6" library="resistor" package="R1206" value="10uF" x="48.008" y="29.65" rot="R270"/>
<element name="OUTPUT_MATRIX" library="con-harting-ml" package="ML10" value="" x="153.247" y="54.33" rot="R270"/>
<element name="ZD3" library="resistor" package="R1206" value="" x="163.412" y="29.127" rot="MR180"/>
<element name="ZD4" library="resistor" package="R1206" value="" x="161.142" y="59.518" rot="MR180"/>
<element name="ZD2" library="resistor" package="R1206" value="" x="145.255" y="29.244" rot="MR180"/>
<element name="ZD5" library="resistor" package="R1206" value="" x="145.019" y="59.314" rot="MR180"/>
<element name="R36" library="resistor" package="R1206" value="" x="146.578" y="42.619" rot="MR180"/>
<element name="R32" library="resistor" package="R1206" value="" x="146.591" y="31.845" rot="MR180"/>
<element name="R38" library="resistor" package="R1206" value="" x="144.895" y="47.838" rot="MR270"/>
<element name="R40" library="resistor" package="R1206" value="" x="144.993" y="52.948" rot="MR270"/>
<element name="R39" library="resistor" package="R1206" value="" x="147.352" y="52.849" rot="MR90"/>
<element name="R37" library="resistor" package="R1206" value="" x="147.352" y="47.838" rot="MR90"/>
<element name="R49" library="resistor" package="R1206" value="" x="140.245" y="59.24" rot="MR90"/>
<element name="R30" library="resistor" package="R1206" value="" x="140.388" y="29.005" rot="MR90"/>
<element name="R48" library="resistor" package="R1206" value="" x="146.346" y="62.533" rot="MR0"/>
<element name="R41" library="resistor" package="R1206" value="" x="130.397390625" y="53.148503125" rot="MR45"/>
<element name="R47" library="resistor" package="R1206" value="" x="147.460546875" y="68.365803125" rot="MR225"/>
<element name="R46" library="resistor" package="R1206" value="" x="160.695196875" y="68.487546875" rot="MR135"/>
<element name="R43" library="resistor" package="R1206" value="" x="167.239" y="59.319" rot="MR90"/>
<element name="R31" library="resistor" package="R1206" value="" x="140.709" y="33.151" rot="MR0"/>
<element name="R33" library="resistor" package="R1206" value="" x="146.576" y="34.544" rot="MR0"/>
<element name="R34" library="resistor" package="R1206" value="" x="150.845" y="36.712" rot="MR180"/>
<element name="R35" library="resistor" package="R1206" value="" x="164.389" y="34.152" rot="MR180"/>
<element name="R44" library="resistor" package="R1206" value="" x="164.875" y="59.269" rot="MR90"/>
<element name="R42" library="resistor" package="R1206" value="" x="164.847" y="54.229" rot="MR90"/>
<element name="R45" library="resistor" package="R1206" value="" x="167.274" y="64.337" rot="MR0"/>
<element name="E$27" library="con-phoenix-smkdsp" package="SMKDSP_1,5/12" value="" x="135.461" y="26.942" rot="R90"/>
<element name="E$28" library="con-phoenix-smkdsp" package="SMKDSP_1,5/12" value="" x="173.344" y="76.766" rot="R270"/>
<element name="OUTPUT_ANALOG" library="con-harting-ml" package="ML10" value="" x="63.768" y="127.793" rot="R180"/>
<element name="C5" library="resistor" package="R1206" value="100uF" x="36.18" y="115.905" rot="MR180"/>
<element name="C4" library="resistor" package="R1206" value="100uF" x="41.054" y="115.911" rot="MR180"/>
<element name="C6" library="resistor" package="R1206" value="100uF" x="45.997" y="115.96" rot="MR180"/>
<element name="C7" library="resistor" package="R1206" value="100uF" x="50.892" y="115.924" rot="MR180"/>
<element name="C8" library="resistor" package="R1206" value="100uF" x="55.823" y="115.864" rot="MR180"/>
<element name="C9" library="resistor" package="R1206" value="100uF" x="60.847" y="115.956" rot="MR180"/>
<element name="C10" library="resistor" package="R1206" value="100uF" x="65.942" y="115.852" rot="MR180"/>
<element name="C11" library="resistor" package="R1206" value="100uF" x="71.246" y="115.852" rot="MR180"/>
<element name="C12" library="resistor" package="R1206" value="100uF" x="76.341" y="115.956" rot="MR180"/>
<element name="C13" library="resistor" package="R1206" value="100uF" x="81.333" y="115.956" rot="MR180"/>
<element name="C14" library="resistor" package="R1206" value="100uF" x="86.325" y="115.956" rot="MR180"/>
<element name="E$1" library="con-phoenix-smkdsp" package="SMKDSP_1,5/14" value="" x="35.955" y="108.205"/>
<element name="+_-_I2C" library="con-molex" package="22-23-2041" value="" x="42.8" y="80.917" rot="R180"/>
<element name="C15" library="resistor" package="R1206" value="100uF" x="91.449" y="115.956" rot="MR180"/>
<element name="R20" library="resistor" package="R1206" value="jumper" x="48.556" y="119.751" rot="MR180"/>
<element name="R15" library="resistor" package="R1206" value="jumper" x="58.183" y="119.528" rot="MR180"/>
<element name="R16" library="resistor" package="R1206" value="jumper" x="46.682" y="134.366" rot="MR90"/>
<element name="R17" library="resistor" package="R1206" value="jumper" x="86.8174125" y="123.163475" rot="MR135"/>
<element name="R18" library="resistor" package="R1206" value="jumper" x="91.7474125" y="123.264475" rot="MR135"/>
<element name="R19" library="resistor" package="R1206" value="500" x="81.113" y="128.844" rot="MR90"/>
<element name="LED3" library="resistor" package="R1206" value="" x="88.051" y="131.848" rot="MR0"/>
<element name="R50" library="resistor" package="R1206" value="500" x="153.400175" y="65.656940625" rot="MR270"/>
<element name="LED4" library="resistor" package="R1206" value="" x="155.854175" y="69.578940625" rot="MR90"/>
<element name="R21" library="smd-ipc" package="C0805" value="10k" x="57.027" y="39.571" rot="MR90"/>
<element name="R22" library="smd-ipc" package="C0805" value="10k" x="54.008" y="36.148" rot="MR90"/>
<element name="LED1" library="resistor" package="R1206" value="" x="68.122" y="29.424" rot="R90"/>
<element name="LED2" library="resistor" package="R1206" value="" x="109.702" y="49.444" rot="R90"/>
<element name="LED5" library="resistor" package="R1206" value="" x="104.188" y="49.341" rot="R90"/>
<element name="R23" library="resistor" package="R1206" value="500" x="104.558" y="57.826" rot="MR90"/>
<element name="R24" library="resistor" package="R1206" value="500" x="108.56" y="57.826" rot="MR90"/>
</elements>
<signals>
<signal name="S$6">
<wire x1="59.021" y1="35.604" x2="59.095" y2="35.678" width="0.4064" layer="16"/>
<wire x1="59.095" y1="35.678" x2="59.12" y2="35.678" width="0.4064" layer="16"/>
</signal>
<signal name="S$7">
<wire x1="92.26" y1="60.984" x2="94.986" y2="63.71" width="0.4064" layer="16"/>
<wire x1="94.986" y1="63.71" x2="94.81" y2="63.71" width="0.4064" layer="16"/>
</signal>
<signal name="S$8">
<wire x1="66.095" y1="66.494" x2="94.872" y2="66.494" width="0.4064" layer="16"/>
</signal>
<signal name="S$13">
<wire x1="49.417" y1="42.497" x2="49.233" y2="42.313" width="0.4064" layer="16"/>
<wire x1="49.233" y1="42.313" x2="49.262" y2="41.331" width="0.4064" layer="16"/>
</signal>
<signal name="S$14">
<wire x1="49.507" y1="47.411" x2="49.568" y2="47.35" width="0.4064" layer="16"/>
<wire x1="49.568" y1="47.35" x2="49.596" y2="44.475" width="0.4064" layer="16"/>
</signal>
<signal name="S$16">
<wire x1="47.171" y1="47.414" x2="47.068" y2="47.311" width="0.4064" layer="16"/>
<wire x1="47.068" y1="47.311" x2="47.068" y2="40.902" width="0.4064" layer="16"/>
</signal>
<signal name="S$27">
<wire x1="48.975" y1="40.082" x2="49.712" y2="40.537" width="0.4064" layer="16"/>
</signal>
<signal name="S$18">
<wire x1="47.64" y1="40.715" x2="47.589" y2="40.766" width="0.4064" layer="16"/>
</signal>
<signal name="S$58">
<wire x1="64.254" y1="56.953" x2="64.271" y2="56.97" width="0.4064" layer="1"/>
</signal>
<signal name="S$59">
<wire x1="64.271" y1="56.052" x2="64.305" y2="56.086" width="0.4064" layer="1"/>
</signal>
<signal name="S$10">
<via x="51.951" y="40.289" extent="1-16" drill="0.5"/>
</signal>
<signal name="S$11">
<wire x1="55.813" y1="50.588" x2="55.763" y2="50.638" width="0.4064" layer="1"/>
</signal>
<signal name="S$44">
<wire x1="83.057" y1="59.228" x2="98.862" y2="59.228" width="0.4064" layer="1"/>
</signal>
<signal name="S$53">
<wire x1="83.206" y1="57.96" x2="99.608" y2="57.96" width="0.4064" layer="1"/>
</signal>
<signal name="S$55">
<wire x1="83.206" y1="60.571" x2="86.259" y2="60.571" width="0.4064" layer="1"/>
</signal>
<signal name="S$185">
<wire x1="96.924" y1="69.149" x2="96.85" y2="69.075" width="0.4064" layer="16"/>
</signal>
<signal name="S$64">
<via x="85.965" y="56.766" extent="1-16" drill="0.5"/>
</signal>
<signal name="S$65">
<via x="87.904" y="55.573" extent="1-16" drill="0.5"/>
</signal>
<signal name="S$67">
<wire x1="85.998" y1="61.033" x2="85.998" y2="56.849" width="0.4064" layer="16"/>
<wire x1="85.998" y1="56.849" x2="86.041" y2="56.806" width="0.4064" layer="16"/>
</signal>
<signal name="S$68">
<wire x1="97.255" y1="66.727" x2="97.858" y2="66.727" width="0.4064" layer="16"/>
<wire x1="97.858" y1="66.727" x2="98.721" y2="65.864" width="0.4064" layer="16"/>
<wire x1="98.721" y1="65.864" x2="98.721" y2="63.793" width="0.4064" layer="16"/>
<wire x1="98.721" y1="63.793" x2="95.012" y2="60.084" width="0.4064" layer="16"/>
<wire x1="95.012" y1="60.084" x2="88.931" y2="60.084" width="0.4064" layer="16"/>
<wire x1="88.931" y1="60.084" x2="87.853" y2="59.006" width="0.4064" layer="16"/>
<wire x1="87.853" y1="59.006" x2="87.853" y2="55.9" width="0.4064" layer="16"/>
<wire x1="87.853" y1="55.9" x2="87.982" y2="55.771" width="0.4064" layer="16"/>
</signal>
<signal name="S$69">
<wire x1="83.152" y1="56.633" x2="85.912" y2="56.633" width="0.4064" layer="1"/>
<wire x1="85.912" y1="56.633" x2="85.998" y2="56.547" width="0.4064" layer="1"/>
</signal>
<signal name="S$70">
<wire x1="83.195" y1="55.426" x2="87.809" y2="55.426" width="0.4064" layer="1"/>
<wire x1="87.809" y1="55.426" x2="87.896" y2="55.339" width="0.4064" layer="1"/>
</signal>
<signal name="S$71">
<wire x1="81.362" y1="65.336" x2="81.155" y2="65.129" width="0.4064" layer="1"/>
<wire x1="81.155" y1="65.129" x2="81.155" y2="63.834" width="0.4064" layer="1"/>
<wire x1="81.155" y1="63.834" x2="83.122" y2="61.867" width="0.4064" layer="1"/>
</signal>
<signal name="S$72">
<wire x1="74.171" y1="63.789" x2="73.598" y2="63.217" width="0.4064" layer="1"/>
<wire x1="73.598" y1="63.217" x2="73.598" y2="61.194" width="0.4064" layer="1"/>
<wire x1="73.598" y1="61.194" x2="74.271" y2="60.521" width="0.4064" layer="1"/>
<wire x1="74.271" y1="60.521" x2="75.461" y2="60.521" width="0.4064" layer="1"/>
<wire x1="75.461" y1="60.521" x2="75.565" y2="60.625" width="0.4064" layer="1"/>
</signal>
<signal name="S$76">
<wire x1="75.249" y1="56.727" x2="74.177" y2="56.727" width="0.4064" layer="1"/>
<wire x1="74.177" y1="56.727" x2="72.48" y2="55.03" width="0.4064" layer="1"/>
</signal>
<signal name="S$78">
<wire x1="84.186" y1="50.937" x2="86.076" y2="50.937" width="0.6096" layer="1"/>
<wire x1="83.601" y1="50.971" x2="84.186" y2="50.937" width="0.6096" layer="1"/>
<wire x1="76.817" y1="50.971" x2="83.601" y2="50.971" width="0.6096" layer="1"/>
</signal>
<signal name="S$77">
<wire x1="86.31" y1="51.028" x2="88.504" y2="53.584" width="0.6096" layer="1"/>
<wire x1="88.504" y1="53.584" x2="90.73" y2="55.81" width="0.6096" layer="1"/>
</signal>
<signal name="S$79">
<wire x1="94.612" y1="56.276" x2="94.56" y2="56.328" width="0.6096" layer="1"/>
</signal>
<signal name="S$80">
<wire x1="94.992" y1="69.186" x2="91.76" y2="69.186" width="0.6096" layer="1"/>
<wire x1="91.76" y1="69.186" x2="91.446" y2="69.221" width="0.6096" layer="1"/>
</signal>
<signal name="S$81">
<wire x1="85.12" y1="69.042" x2="83.809" y2="69.062" width="0.6096" layer="1"/>
</signal>
<signal name="S$82">
<wire x1="76.975" y1="50.973" x2="74.428" y2="50.973" width="0.6096" layer="1"/>
<wire x1="74.428" y1="50.973" x2="73.558" y2="51.843" width="0.6096" layer="1"/>
<wire x1="73.558" y1="51.843" x2="73.558" y2="54.392" width="0.6096" layer="1"/>
<wire x1="73.558" y1="54.392" x2="74.427" y2="55.461" width="0.6096" layer="1"/>
<wire x1="74.427" y1="55.461" x2="75.421" y2="55.461" width="0.6096" layer="1"/>
<wire x1="75.421" y1="55.461" x2="75.858" y2="55.448" width="0.6096" layer="1"/>
</signal>
<signal name="S$83">
<wire x1="75.733" y1="56.754" x2="74.181" y2="56.754" width="0.6096" layer="1"/>
<wire x1="74.181" y1="56.754" x2="72.751" y2="55.324" width="0.6096" layer="1"/>
</signal>
<signal name="S$5">
<via x="51.291" y="31.836" extent="1-16" drill="0.5"/>
</signal>
<signal name="S$29">
<wire x1="61.835" y1="35.798" x2="61.871" y2="35.834" width="0.4064" layer="16"/>
</signal>
<signal name="S$32">
<via x="55.678" y="33.19" extent="1-16" drill="0.5"/>
</signal>
<signal name="S$60">
<wire x1="59.055" y1="36.861" x2="59.106" y2="36.81" width="0.4064" layer="16"/>
</signal>
<signal name="S$61">
<wire x1="61.798" y1="37.12" x2="62.005" y2="36.913" width="0.4064" layer="16"/>
</signal>
<signal name="S$1">
<wire x1="59.021" y1="32.013" x2="58.958" y2="32.076" width="0.4064" layer="1"/>
</signal>
<signal name="S$4">
<wire x1="58.225" y1="50.524" x2="58.225" y2="49.26" width="0.4064" layer="1"/>
<wire x1="58.225" y1="49.26" x2="56.787" y2="47.822" width="0.4064" layer="1"/>
<wire x1="56.787" y1="47.822" x2="55.488" y2="47.822" width="0.4064" layer="1"/>
<wire x1="55.488" y1="47.822" x2="54.517" y2="46.851" width="0.4064" layer="1"/>
<wire x1="54.517" y1="46.851" x2="54.517" y2="44.772" width="0.4064" layer="1"/>
</signal>
<signal name="S$42">
<wire x1="58.987" y1="50.524" x2="58.987" y2="48.93" width="0.4064" layer="1"/>
<wire x1="58.987" y1="48.93" x2="57.064" y2="47.007" width="0.4064" layer="1"/>
<wire x1="57.064" y1="47.007" x2="57.064" y2="44.581" width="0.4064" layer="1"/>
<wire x1="57.064" y1="44.581" x2="57.047" y2="44.564" width="0.4064" layer="1"/>
</signal>
<signal name="S$45">
<wire x1="59.749" y1="50.559" x2="59.749" y2="49.398" width="0.4064" layer="1"/>
<wire x1="59.749" y1="49.398" x2="61.828" y2="47.319" width="0.4064" layer="1"/>
<wire x1="61.828" y1="47.319" x2="63.941" y2="47.319" width="0.4064" layer="1"/>
<wire x1="63.941" y1="47.319" x2="64.686" y2="46.574" width="0.4064" layer="1"/>
<wire x1="64.686" y1="46.574" x2="64.686" y2="44.651" width="0.4064" layer="1"/>
</signal>
<signal name="S$47">
<wire x1="65.321" y1="52.906" x2="67.908" y2="52.906" width="0.4064" layer="1"/>
<wire x1="67.908" y1="52.906" x2="68.231" y2="52.583" width="0.4064" layer="1"/>
</signal>
<signal name="S$52">
<wire x1="67.728" y1="49.312" x2="67.872" y2="49.456" width="0.4064" layer="1"/>
</signal>
<signal name="S$2">
<wire x1="49.583" y1="48.148" x2="49.583" y2="49.494" width="0.4064" layer="16"/>
<wire x1="49.583" y1="49.494" x2="50.981" y2="50.892" width="0.4064" layer="16"/>
<wire x1="50.981" y1="50.892" x2="64.179" y2="50.892" width="0.4064" layer="16"/>
<wire x1="64.179" y1="50.892" x2="64.364" y2="50.907" width="0.4064" layer="16"/>
</signal>
<signal name="S$9">
<via x="64.437" y="50.84" extent="1-16" drill="0.5"/>
</signal>
<signal name="S$15">
<wire x1="63.022" y1="50.556" x2="63.022" y2="50.099" width="0.4064" layer="1"/>
<wire x1="63.022" y1="50.099" x2="63.095" y2="50.026" width="0.4064" layer="1"/>
<wire x1="63.095" y1="50.026" x2="64.297" y2="50.026" width="0.4064" layer="1"/>
<wire x1="64.297" y1="50.026" x2="64.43" y2="50.159" width="0.4064" layer="1"/>
<wire x1="64.43" y1="50.159" x2="64.43" y2="50.387" width="0.4064" layer="1"/>
<wire x1="64.43" y1="50.387" x2="64.406" y2="50.812" width="0.4064" layer="1"/>
</signal>
<signal name="S$20">
<wire x1="57.416" y1="50.534" x2="57.416" y2="49.563" width="0.4064" layer="1"/>
<wire x1="57.416" y1="49.563" x2="56.518" y2="48.665" width="0.4064" layer="1"/>
<wire x1="56.518" y1="48.665" x2="53.141" y2="48.665" width="0.4064" layer="1"/>
<wire x1="53.141" y1="48.665" x2="51.703" y2="47.227" width="0.4064" layer="1"/>
<wire x1="51.703" y1="47.227" x2="51.703" y2="45.215" width="0.4064" layer="1"/>
<wire x1="51.703" y1="45.215" x2="51.739" y2="45.179" width="0.4064" layer="1"/>
</signal>
<signal name="S$25">
<wire x1="51.991" y1="42.052" x2="51.991" y2="40.542" width="0.4064" layer="1"/>
</signal>
<signal name="S$31">
<wire x1="50.8" y1="38.824" x2="52.098" y2="39.968" width="0.4064" layer="16"/>
<wire x1="52.098" y1="39.968" x2="52.027" y2="40.039" width="0.4064" layer="16"/>
</signal>
<signal name="S$63">
<wire x1="83.091" y1="61.307" x2="51.292" y2="61.307" width="0.4064" layer="16"/>
<wire x1="51.292" y1="61.307" x2="51.262" y2="61.337" width="0.4064" layer="16"/>
</signal>
<signal name="S$66">
<wire x1="66.083" y1="66.488" x2="66.083" y2="63.403" width="0.4064" layer="16"/>
<wire x1="66.083" y1="63.403" x2="64.706" y2="62.026" width="0.4064" layer="16"/>
<wire x1="64.706" y1="62.026" x2="53.268" y2="62.026" width="0.4064" layer="16"/>
<wire x1="53.268" y1="62.026" x2="52.549" y2="62.745" width="0.4064" layer="16"/>
</signal>
<signal name="S$85">
<via x="50.783" y="61.157" extent="1-16" drill="0.5"/>
</signal>
<signal name="S$86">
<via x="52.609" y="63.134" extent="1-16" drill="0.5"/>
</signal>
<signal name="S$87">
<wire x1="54.945" y1="63.404" x2="54.945" y2="64.122" width="0.4064" layer="1"/>
<wire x1="54.945" y1="64.122" x2="54.675" y2="64.392" width="0.4064" layer="1"/>
<wire x1="54.675" y1="64.392" x2="52.969" y2="64.392" width="0.4064" layer="1"/>
<wire x1="52.969" y1="64.392" x2="52.639" y2="64.062" width="0.4064" layer="1"/>
<wire x1="52.639" y1="64.062" x2="52.639" y2="63.374" width="0.4064" layer="1"/>
</signal>
<signal name="S$88">
<wire x1="52.639" y1="61.008" x2="50.903" y2="61.008" width="0.4064" layer="1"/>
</signal>
<signal name="S$41">
<via x="83.728" y="65.27" extent="1-16" drill="0.5"/>
</signal>
<signal name="S$89">
<wire x1="83.54" y1="65.35" x2="81.474" y2="65.35" width="0.4064" layer="1"/>
<wire x1="81.474" y1="65.35" x2="81.414" y2="65.29" width="0.4064" layer="1"/>
</signal>
<signal name="S$90">
<wire x1="83.72" y1="68.914" x2="83.72" y2="65.47" width="0.4064" layer="1"/>
<wire x1="83.72" y1="65.47" x2="83.75" y2="65.44" width="0.4064" layer="1"/>
</signal>
<signal name="S$91">
<wire x1="83.75" y1="63.703" x2="83.75" y2="64.811" width="0.4064" layer="16"/>
</signal>
<signal name="S$26">
<wire x1="91.615" y1="68.887" x2="91.614" y2="65.367" width="0.4064" layer="1"/>
<wire x1="91.614" y1="65.367" x2="86.128" y2="60.559" width="0.4064" layer="1"/>
<wire x1="86.128" y1="60.559" x2="83.066" y2="60.559" width="0.4064" layer="1"/>
</signal>
<signal name="S$21">
<wire x1="52.789" y1="56.934" x2="60.693" y2="56.934" width="0.4064" layer="1"/>
<wire x1="60.693" y1="56.934" x2="61.472" y2="57.713" width="0.4064" layer="1"/>
<wire x1="61.472" y1="57.713" x2="64.137" y2="57.713" width="0.4064" layer="1"/>
<wire x1="64.137" y1="57.713" x2="64.167" y2="57.743" width="0.4064" layer="1"/>
</signal>
<signal name="S$34">
<wire x1="52.609" y1="56.126" x2="61.113" y2="56.126" width="0.4064" layer="1"/>
<wire x1="61.113" y1="56.126" x2="61.951" y2="56.964" width="0.4064" layer="1"/>
<wire x1="61.951" y1="56.964" x2="65.125" y2="56.964" width="0.4064" layer="1"/>
</signal>
<signal name="S$36">
<wire x1="68.423" y1="49.235" x2="69.52" y2="49.235" width="0.6096" layer="1"/>
<wire x1="69.52" y1="49.235" x2="71.933" y2="46.822" width="0.6096" layer="1"/>
<wire x1="71.933" y1="46.822" x2="85.442" y2="46.822" width="0.6096" layer="1"/>
<wire x1="85.442" y1="46.822" x2="87.859" y2="49.239" width="0.6096" layer="1"/>
<wire x1="87.859" y1="49.239" x2="92.242" y2="49.239" width="0.6096" layer="1"/>
<wire x1="92.242" y1="49.239" x2="94.301" y2="51.298" width="0.6096" layer="1"/>
<wire x1="94.301" y1="51.298" x2="94.301" y2="55.774" width="0.6096" layer="1"/>
<wire x1="94.301" y1="55.774" x2="94.211" y2="55.864" width="0.6096" layer="1"/>
</signal>
<signal name="S$37">
<wire x1="65.34" y1="57.755" x2="69.005" y2="57.755" width="0.6096" layer="1"/>
<wire x1="69.005" y1="57.755" x2="69.911" y2="56.849" width="0.6096" layer="1"/>
<wire x1="69.911" y1="56.849" x2="69.911" y2="49.042" width="0.6096" layer="1"/>
<wire x1="69.911" y1="49.042" x2="69.868" y2="48.999" width="0.6096" layer="1"/>
</signal>
<signal name="S$38">
<via x="61.799" y="56.357" extent="1-16" drill="0.5"/>
</signal>
<signal name="S$39">
<wire x1="62.123" y1="44.46" x2="62.123" y2="46.222" width="0.6096" layer="16"/>
<wire x1="62.123" y1="46.222" x2="65.68" y2="49.779" width="0.6096" layer="16"/>
<wire x1="65.68" y1="49.779" x2="65.68" y2="51.756" width="0.6096" layer="16"/>
<wire x1="65.68" y1="51.756" x2="65.033" y2="52.403" width="0.6096" layer="16"/>
<wire x1="65.033" y1="52.403" x2="62.23" y2="52.403" width="0.6096" layer="16"/>
<wire x1="62.23" y1="52.403" x2="61.835" y2="52.798" width="0.6096" layer="16"/>
<wire x1="61.835" y1="52.798" x2="61.835" y2="56.177" width="0.6096" layer="16"/>
</signal>
<signal name="S$40">
<wire x1="92.253" y1="61.067" x2="84.319" y2="61.067" width="0.6096" layer="16"/>
<wire x1="84.319" y1="61.067" x2="84.229" y2="61.157" width="0.6096" layer="16"/>
</signal>
<signal name="S$12">
<wire x1="83.76" y1="69.052" x2="83.76" y2="71.091" width="0.6096" layer="1"/>
<wire x1="83.76" y1="71.091" x2="84.674" y2="72.005" width="0.6096" layer="1"/>
<wire x1="84.674" y1="72.005" x2="94.57" y2="72.005" width="0.6096" layer="1"/>
<wire x1="94.57" y1="72.005" x2="94.653" y2="71.922" width="0.6096" layer="1"/>
</signal>
<signal name="S$22">
<wire x1="83.76" y1="65.497" x2="83.76" y2="69.198" width="0.6096" layer="1"/>
<wire x1="83.76" y1="69.198" x2="83.822" y2="69.26" width="0.6096" layer="1"/>
</signal>
<signal name="S$23">
<wire x1="83.489" y1="65.351" x2="81.639" y2="65.351" width="0.6096" layer="1"/>
</signal>
<signal name="S$3">
<wire x1="55.659" y1="32.94" x2="55.659" y2="32.056" width="0.4064" layer="16"/>
<wire x1="55.659" y1="32.056" x2="56.647" y2="31.068" width="0.4064" layer="16"/>
<wire x1="56.647" y1="31.068" x2="63.211" y2="31.068" width="0.4064" layer="16"/>
<wire x1="63.211" y1="31.068" x2="63.988" y2="31.845" width="0.4064" layer="16"/>
</signal>
<signal name="S$17">
<wire x1="64.059" y1="34.316" x2="64.059" y2="35.799" width="0.4064" layer="16"/>
<wire x1="64.059" y1="35.799" x2="63.247" y2="36.611" width="0.4064" layer="16"/>
<wire x1="63.247" y1="36.611" x2="62.506" y2="36.611" width="0.4064" layer="16"/>
<wire x1="62.506" y1="36.611" x2="62.4" y2="36.505" width="0.4064" layer="16"/>
<wire x1="62.4" y1="36.505" x2="62.365" y2="36.505" width="0.4064" layer="16"/>
</signal>
<signal name="S$24">
<wire x1="58.941" y1="34.175" x2="58.941" y2="36.258" width="0.4064" layer="16"/>
<wire x1="58.941" y1="36.258" x2="58.977" y2="36.294" width="0.4064" layer="16"/>
</signal>
<signal name="S$33">
<wire x1="47.224" y1="40.318" x2="47.224" y2="38.268" width="0.4064" layer="16"/>
</signal>
<signal name="S$28">
<wire x1="58.977" y1="31.951" x2="58.13" y2="31.104" width="0.4064" layer="1"/>
<wire x1="58.13" y1="31.104" x2="53.047" y2="31.104" width="0.4064" layer="1"/>
<wire x1="53.047" y1="31.104" x2="51.858" y2="31.106" width="0.4064" layer="1"/>
<wire x1="51.858" y1="31.106" x2="51.559" y2="31.605" width="0.4064" layer="1"/>
<wire x1="51.559" y1="31.605" x2="51.4" y2="31.922" width="0.4064" layer="1"/>
</signal>
<signal name="S$43">
<via x="66.923" y="56.784" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$46">
<via x="68.461" y="55.798" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$48">
<via x="66.966" y="54.805" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$49">
<via x="68.47" y="53.975" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$50">
<via x="62.9" y="53.961" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$51">
<wire x1="64.249" y1="53.69" x2="63.233" y2="53.69" width="0.4064" layer="1"/>
<wire x1="63.233" y1="53.69" x2="63.162" y2="53.761" width="0.4064" layer="1"/>
</signal>
<signal name="S$54">
<wire x1="65.337" y1="56.976" x2="66.778" y2="56.976" width="0.4064" layer="1"/>
</signal>
<signal name="S$92">
<wire x1="68.054" y1="55.806" x2="66.258" y2="55.806" width="0.4064" layer="1"/>
<wire x1="66.258" y1="55.806" x2="65.892" y2="56.172" width="0.4064" layer="1"/>
<wire x1="65.892" y1="56.172" x2="65.289" y2="56.172" width="0.4064" layer="1"/>
<wire x1="65.289" y1="56.172" x2="65.242" y2="56.125" width="0.4064" layer="1"/>
</signal>
<signal name="S$93">
<wire x1="65.348" y1="55.38" x2="65.845" y2="55.38" width="0.4064" layer="1"/>
<wire x1="65.845" y1="55.38" x2="66.105" y2="55.12" width="0.4064" layer="1"/>
<wire x1="66.105" y1="55.12" x2="66.66" y2="55.12" width="0.4064" layer="1"/>
</signal>
<signal name="S$94">
<wire x1="65.337" y1="54.577" x2="65.797" y2="54.577" width="0.4064" layer="1"/>
<wire x1="65.797" y1="54.577" x2="66.506" y2="53.868" width="0.4064" layer="1"/>
<wire x1="66.506" y1="53.868" x2="67.984" y2="53.868" width="0.4064" layer="1"/>
<wire x1="67.984" y1="53.868" x2="68.019" y2="53.903" width="0.4064" layer="1"/>
</signal>
<signal name="S$95">
<wire x1="67.277" y1="54.505" x2="67.277" y2="50.132" width="0.4064" layer="16"/>
<wire x1="67.277" y1="50.132" x2="67.785" y2="49.503" width="0.4064" layer="16"/>
<wire x1="67.785" y1="49.503" x2="84.217" y2="49.482" width="0.4064" layer="16"/>
</signal>
<signal name="S$96">
<wire x1="68.762" y1="53.663" x2="68.721" y2="51.322" width="0.4064" layer="16"/>
<wire x1="68.721" y1="51.322" x2="69.422" y2="50.418" width="0.4064" layer="16"/>
<wire x1="69.422" y1="50.418" x2="99.263" y2="50.437" width="0.4064" layer="16"/>
</signal>
<signal name="S$97">
<wire x1="68.831" y1="55.686" x2="68.831" y2="55.533" width="0.4064" layer="16"/>
<wire x1="68.831" y1="55.533" x2="70.458" y2="53.906" width="0.4064" layer="16"/>
<wire x1="70.458" y1="53.906" x2="70.458" y2="52.176" width="0.4064" layer="16"/>
<wire x1="70.458" y1="52.176" x2="71.322" y2="51.312" width="0.4064" layer="16"/>
<wire x1="71.322" y1="51.312" x2="100.406" y2="51.312" width="0.4064" layer="16"/>
</signal>
<signal name="S$98">
<wire x1="63.227" y1="53.961" x2="65.31" y2="53.961" width="0.4064" layer="16"/>
<wire x1="65.31" y1="53.961" x2="66.515" y2="52.756" width="0.4064" layer="16"/>
<wire x1="66.515" y1="52.756" x2="66.515" y2="49.427" width="0.4064" layer="16"/>
<wire x1="66.515" y1="49.427" x2="67.516" y2="48.426" width="0.4064" layer="16"/>
<wire x1="67.516" y1="48.426" x2="82.98" y2="48.426" width="0.4064" layer="16"/>
</signal>
<signal name="S$245">
<wire x1="62.25" y1="50.617" x2="62.267" y2="50.634" width="0.4064" layer="1"/>
</signal>
<signal name="S$110">
<wire x1="91.291" y1="28.837" x2="91.174" y2="28.954" width="0.4064" layer="16"/>
</signal>
<signal name="S$111">
<wire x1="94.674" y1="32.19" x2="94.674" y2="32.367" width="0.4064" layer="16"/>
</signal>
<signal name="R6">
<wire x1="94.674" y1="32.131" x2="94.674" y2="34.691" width="0.4064" layer="16"/>
<wire x1="94.674" y1="34.691" x2="93.821" y2="35.544" width="0.4064" layer="16"/>
<wire x1="93.821" y1="35.544" x2="90.615" y2="35.544" width="0.4064" layer="16"/>
<wire x1="90.615" y1="35.544" x2="89.968" y2="34.897" width="0.4064" layer="16"/>
<wire x1="89.968" y1="34.897" x2="89.968" y2="32.367" width="0.4064" layer="16"/>
<wire x1="89.968" y1="32.367" x2="90.145" y2="32.19" width="0.4064" layer="16"/>
</signal>
<signal name="S$113">
<wire x1="92.115" y1="32.102" x2="92.115" y2="33.691" width="0.4064" layer="16"/>
<wire x1="92.115" y1="33.691" x2="92.056" y2="33.75" width="0.4064" layer="16"/>
</signal>
<signal name="S$191">
<wire x1="98.16" y1="30.579" x2="98.16" y2="34.225" width="0.4064" layer="16"/>
</signal>
<signal name="S$118">
<wire x1="64.002" y1="48.067" x2="64.647" y2="48.73" width="0.4064" layer="16"/>
</signal>
<signal name="S$119">
<wire x1="88.536" y1="44.33" x2="70.534" y2="44.33" width="0.4064" layer="1"/>
<wire x1="70.534" y1="44.33" x2="67.517" y2="44.33" width="0.4064" layer="1"/>
<wire x1="67.517" y1="44.33" x2="66.784" y2="43.597" width="0.4064" layer="1"/>
<wire x1="66.784" y1="43.597" x2="66.784" y2="41.399" width="0.4064" layer="1"/>
<wire x1="66.784" y1="41.399" x2="66.125" y2="40.74" width="0.4064" layer="1"/>
<wire x1="66.125" y1="40.74" x2="60.513" y2="40.74" width="0.4064" layer="1"/>
<wire x1="60.513" y1="40.74" x2="59.563" y2="42.052" width="0.4064" layer="1"/>
<wire x1="72.022" y1="46.808" x2="72.022" y2="45.818" width="0.6096" layer="1"/>
<wire x1="72.022" y1="45.818" x2="70.534" y2="44.33" width="0.6096" layer="1"/>
<wire x1="70.534" y1="44.33" x2="67.518" y2="44.33" width="0.6096" layer="1"/>
<wire x1="67.518" y1="44.33" x2="66.774" y2="43.586" width="0.6096" layer="1"/>
<wire x1="66.774" y1="43.586" x2="66.774" y2="41.521" width="0.6096" layer="1"/>
<wire x1="66.774" y1="41.521" x2="66.071" y2="40.818" width="0.6096" layer="1"/>
<wire x1="66.071" y1="40.818" x2="60.741" y2="40.818" width="0.6096" layer="1"/>
<wire x1="60.741" y1="40.818" x2="59.584" y2="41.975" width="0.6096" layer="1"/>
</signal>
<signal name="S$120">
<wire x1="65.366" y1="60.093" x2="68.543" y2="60.093" width="0.4064" layer="1"/>
<wire x1="68.543" y1="60.093" x2="69.764" y2="60.114" width="0.4064" layer="1"/>
<wire x1="69.764" y1="60.114" x2="69.764" y2="64.782" width="0.4064" layer="1"/>
<wire x1="69.764" y1="64.782" x2="71.459" y2="66.477" width="0.4064" layer="1"/>
<wire x1="71.459" y1="66.477" x2="72.772" y2="66.477" width="0.4064" layer="1"/>
<wire x1="72.772" y1="66.477" x2="73.45" y2="67.155" width="0.4064" layer="1"/>
<wire x1="73.45" y1="67.155" x2="73.45" y2="69.57" width="0.4064" layer="1"/>
<wire x1="73.45" y1="69.57" x2="74.72" y2="69.57" width="0.4064" layer="1"/>
</signal>
<signal name="S$121">
<via x="68.424" y="61.433" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$122">
<via x="75.897" y="66.62" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$123">
<wire x1="76.054" y1="69.606" x2="76.054" y2="67.017" width="0.4064" layer="1"/>
<wire x1="76.054" y1="67.017" x2="75.936" y2="66.899" width="0.4064" layer="1"/>
</signal>
<signal name="S$124">
<wire x1="68.554" y1="61.663" x2="68.554" y2="64.929" width="0.4064" layer="1"/>
<wire x1="68.554" y1="64.929" x2="70.995" y2="67.37" width="0.4064" layer="1"/>
<wire x1="70.995" y1="67.37" x2="71.701" y2="67.37" width="0.4064" layer="1"/>
<wire x1="71.701" y1="67.37" x2="72.083" y2="67.752" width="0.4064" layer="1"/>
<wire x1="72.083" y1="67.752" x2="72.083" y2="69.546" width="0.4064" layer="1"/>
<wire x1="72.083" y1="69.546" x2="72.113" y2="69.576" width="0.4064" layer="1"/>
</signal>
<signal name="S$125">
<wire x1="88.607" y1="84.337" x2="77.552" y2="84.337" width="0.4064" layer="1"/>
<wire x1="77.552" y1="84.337" x2="72.057" y2="78.842" width="0.4064" layer="1"/>
<wire x1="72.057" y1="78.842" x2="72.057" y2="77.157" width="0.4064" layer="1"/>
</signal>
<signal name="S$126">
<wire x1="96.662" y1="71.734" x2="97.979" y2="71.734" width="0.4064" layer="1"/>
<wire x1="97.979" y1="71.734" x2="99.298" y2="73.053" width="0.4064" layer="1"/>
<wire x1="99.298" y1="73.053" x2="99.298" y2="83.313" width="0.4064" layer="1"/>
<wire x1="99.298" y1="83.313" x2="97.907" y2="84.704" width="0.4064" layer="1"/>
<wire x1="97.907" y1="84.704" x2="88.006" y2="84.704" width="0.4064" layer="1"/>
</signal>
<signal name="S$127">
<wire x1="87.467" y1="74.776" x2="97.165" y2="74.776" width="0.4064" layer="1"/>
<wire x1="97.165" y1="74.776" x2="98.259" y2="75.87" width="0.4064" layer="1"/>
<wire x1="98.259" y1="75.87" x2="98.259" y2="79.225" width="0.4064" layer="1"/>
<wire x1="98.259" y1="79.225" x2="97.624" y2="79.86" width="0.4064" layer="1"/>
<wire x1="97.624" y1="79.86" x2="96.953" y2="79.86" width="0.4064" layer="1"/>
</signal>
<signal name="S$128">
<wire x1="96.953" y1="79.93" x2="97.554" y2="79.93" width="0.4064" layer="16"/>
<wire x1="97.554" y1="79.93" x2="98.33" y2="79.154" width="0.4064" layer="16"/>
<wire x1="98.33" y1="79.154" x2="98.33" y2="69.727" width="0.4064" layer="16"/>
<wire x1="98.33" y1="69.727" x2="97.73" y2="69.127" width="0.4064" layer="16"/>
</signal>
<signal name="S$129">
<wire x1="73.341" y1="77.177" x2="73.341" y2="78.342" width="0.4064" layer="1"/>
<wire x1="73.341" y1="78.342" x2="75.741" y2="80.742" width="0.4064" layer="1"/>
<wire x1="75.741" y1="80.742" x2="84.169" y2="80.742" width="0.4064" layer="1"/>
<wire x1="84.169" y1="80.742" x2="84.24" y2="80.813" width="0.4064" layer="1"/>
</signal>
<signal name="S$130">
<wire x1="74.647" y1="77.459" x2="74.647" y2="77.988" width="0.4064" layer="1"/>
<wire x1="74.647" y1="77.988" x2="75.636" y2="78.977" width="0.4064" layer="1"/>
<wire x1="75.636" y1="78.977" x2="81.211" y2="78.977" width="0.4064" layer="1"/>
<wire x1="81.211" y1="78.977" x2="82.341" y2="77.847" width="0.4064" layer="1"/>
</signal>
<signal name="S$131">
<wire x1="76.13" y1="77.283" x2="76.13" y2="77.07" width="0.4064" layer="1"/>
<wire x1="76.13" y1="77.07" x2="77.894" y2="75.306" width="0.4064" layer="1"/>
<wire x1="77.894" y1="75.306" x2="87.267" y2="75.306" width="0.4064" layer="1"/>
</signal>
<signal name="S$133">
<wire x1="84.267" y1="80.76" x2="84.636" y2="81.096" width="0.4064" layer="1"/>
<wire x1="84.636" y1="81.096" x2="86.189" y2="82.649" width="0.4064" layer="1"/>
<wire x1="86.189" y1="82.649" x2="94.835" y2="82.649" width="0.4064" layer="1"/>
<wire x1="94.835" y1="82.649" x2="94.941" y2="82.543" width="0.4064" layer="1"/>
</signal>
<signal name="S$136">
<wire x1="76.05" y1="75.672" x2="76.05" y2="74.045" width="0.6096" layer="1"/>
<wire x1="76.05" y1="74.045" x2="75.236" y2="73.231" width="0.6096" layer="1"/>
<wire x1="75.236" y1="73.231" x2="70.865" y2="73.231" width="0.6096" layer="1"/>
<wire x1="70.865" y1="73.231" x2="69.441" y2="74.655" width="0.6096" layer="1"/>
<wire x1="69.441" y1="74.655" x2="69.441" y2="82.335" width="0.6096" layer="1"/>
<wire x1="69.441" y1="82.335" x2="68.323" y2="83.453" width="0.6096" layer="1"/>
<wire x1="68.323" y1="83.453" x2="59.224" y2="83.453" width="0.6096" layer="1"/>
<wire x1="59.224" y1="83.453" x2="58.715" y2="82.944" width="0.6096" layer="1"/>
<wire x1="58.715" y1="82.944" x2="58.715" y2="82.13" width="0.6096" layer="1"/>
</signal>
<signal name="S$137">
<wire x1="87.945" y1="84.622" x2="57.139" y2="84.622" width="0.6096" layer="1"/>
<wire x1="57.139" y1="84.622" x2="56.173" y2="83.656" width="0.6096" layer="1"/>
<wire x1="56.173" y1="83.656" x2="56.173" y2="82.029" width="0.6096" layer="1"/>
</signal>
<signal name="S$138">
<wire x1="62.224" y1="63.302" x2="62.224" y2="64.186" width="0.4064" layer="1"/>
<wire x1="62.224" y1="64.186" x2="66.424" y2="68.386" width="0.4064" layer="1"/>
<wire x1="66.424" y1="68.386" x2="66.424" y2="79.612" width="0.4064" layer="1"/>
<wire x1="66.424" y1="79.612" x2="66.388" y2="79.648" width="0.4064" layer="1"/>
</signal>
<signal name="S$139">
<wire x1="61.377" y1="63.196" x2="61.377" y2="64.751" width="0.4064" layer="1"/>
<wire x1="61.377" y1="64.751" x2="63.953" y2="67.327" width="0.4064" layer="1"/>
<wire x1="63.953" y1="67.327" x2="63.953" y2="79.542" width="0.4064" layer="1"/>
</signal>
<signal name="S$176">
<wire x1="61.306" y1="79.577" x2="61.235" y2="79.648" width="0.4064" layer="1"/>
</signal>
<signal name="S$141">
<via x="69.885" y="59.047" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$142">
<via x="62.696" y="58.842" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$143">
<wire x1="64.124" y1="58.57" x2="63.132" y2="58.57" width="0.4064" layer="1"/>
<wire x1="63.132" y1="58.57" x2="63.075" y2="58.627" width="0.4064" layer="1"/>
</signal>
<signal name="S$144">
<wire x1="65.344" y1="59.307" x2="69.513" y2="59.307" width="0.4064" layer="1"/>
<wire x1="69.513" y1="59.307" x2="69.598" y2="59.222" width="0.4064" layer="1"/>
</signal>
<signal name="S$145">
<via x="72.73" y="42.749" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$146">
<via x="86.496" y="42.92" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$147">
<wire x1="72.814" y1="42.454" x2="72.814" y2="40.377" width="0.4064" layer="1"/>
<wire x1="72.814" y1="40.377" x2="72.772" y2="40.335" width="0.4064" layer="1"/>
</signal>
<signal name="S$148">
<wire x1="86.411" y1="42.708" x2="86.411" y2="40.293" width="0.4064" layer="1"/>
<wire x1="86.411" y1="40.293" x2="86.454" y2="40.25" width="0.4064" layer="1"/>
</signal>
<signal name="S$153">
<wire x1="70" y1="59.093" x2="71.067" y2="59.093" width="0.4064" layer="16"/>
<wire x1="71.067" y1="59.093" x2="73.66" y2="56.5" width="0.4064" layer="16"/>
<wire x1="73.66" y1="56.5" x2="73.66" y2="55.229" width="0.4064" layer="16"/>
<wire x1="73.66" y1="55.229" x2="74.525" y2="54.364" width="0.4064" layer="16"/>
<wire x1="74.525" y1="54.364" x2="96.434" y2="54.364" width="0.4064" layer="16"/>
<wire x1="96.434" y1="54.364" x2="96.99" y2="54.303" width="0.4064" layer="16"/>
</signal>
<signal name="S$154">
<via x="97.197" y="54.425" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$155">
<via x="88.352" y="47.092" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$156">
<wire x1="97.369" y1="54.182" x2="97.4" y2="52.683" width="0.4064" layer="1"/>
<wire x1="97.4" y1="52.683" x2="91.656" y2="46.939" width="0.4064" layer="1"/>
<wire x1="91.656" y1="46.939" x2="88.606" y2="46.939" width="0.4064" layer="1"/>
<wire x1="88.606" y1="46.939" x2="88.555" y2="46.888" width="0.4064" layer="1"/>
</signal>
<signal name="S$159">
<wire x1="72.812" y1="43.001" x2="71.013" y2="43.001" width="0.4064" layer="16"/>
<wire x1="71.013" y1="43.001" x2="68.541" y2="45.473" width="0.4064" layer="16"/>
<wire x1="68.541" y1="45.473" x2="65.4" y2="45.473" width="0.4064" layer="16"/>
<wire x1="65.4" y1="45.473" x2="64.588" y2="46.285" width="0.4064" layer="16"/>
</signal>
<signal name="S$160">
<wire x1="59.347" y1="49.468" x2="61.572" y2="49.468" width="0.4064" layer="16"/>
<wire x1="61.572" y1="49.468" x2="62.165" y2="48.875" width="0.4064" layer="16"/>
</signal>
<signal name="S$161">
<wire x1="62.479" y1="58.638" x2="62.394" y2="58.638" width="0.4064" layer="16"/>
<wire x1="62.394" y1="58.638" x2="60.573" y2="56.817" width="0.4064" layer="16"/>
<wire x1="60.573" y1="56.817" x2="59.218" y2="56.817" width="0.4064" layer="16"/>
<wire x1="59.218" y1="56.817" x2="59.09" y2="56.689" width="0.4064" layer="16"/>
<wire x1="59.09" y1="56.689" x2="59.09" y2="52.834" width="0.4064" layer="16"/>
<wire x1="59.09" y1="52.834" x2="59.005" y2="52.749" width="0.4064" layer="16"/>
</signal>
<signal name="S$163">
<wire x1="56.612" y1="50.627" x2="56.612" y2="49.85" width="0.4064" layer="1"/>
<wire x1="56.612" y1="49.85" x2="56.118" y2="49.356" width="0.4064" layer="1"/>
<wire x1="56.118" y1="49.356" x2="52.553" y2="49.356" width="0.4064" layer="1"/>
</signal>
<signal name="S$162">
<wire x1="32.224" y1="41.095" x2="32.224" y2="40.212" width="0.6096" layer="1"/>
<wire x1="32.224" y1="40.212" x2="32.647" y2="39.789" width="0.6096" layer="1"/>
<wire x1="32.647" y1="39.789" x2="44.718" y2="39.789" width="0.6096" layer="1"/>
<wire x1="44.718" y1="39.789" x2="47.083" y2="42.154" width="0.6096" layer="1"/>
<wire x1="47.083" y1="42.154" x2="47.083" y2="46.851" width="0.6096" layer="1"/>
<wire x1="47.083" y1="46.851" x2="49.553" y2="49.321" width="0.6096" layer="1"/>
<wire x1="49.553" y1="49.321" x2="52.447" y2="49.321" width="0.6096" layer="1"/>
<wire x1="52.447" y1="49.321" x2="52.518" y2="49.392" width="0.6096" layer="1"/>
</signal>
<signal name="S$165">
<wire x1="51.141" y1="44.979" x2="49.413" y2="44.979" width="0.6096" layer="1"/>
<wire x1="49.413" y1="44.979" x2="48.318" y2="43.884" width="0.6096" layer="1"/>
<wire x1="48.318" y1="43.884" x2="48.318" y2="41.306" width="0.6096" layer="1"/>
<wire x1="48.318" y1="41.306" x2="45.53" y2="38.518" width="0.6096" layer="1"/>
<wire x1="45.53" y1="38.518" x2="31.165" y2="38.518" width="0.6096" layer="1"/>
<wire x1="31.165" y1="38.518" x2="29.753" y2="39.93" width="0.6096" layer="1"/>
<wire x1="29.753" y1="39.93" x2="29.753" y2="43.178" width="0.6096" layer="1"/>
<wire x1="29.753" y1="43.178" x2="30.53" y2="43.955" width="0.6096" layer="1"/>
<wire x1="30.53" y1="43.955" x2="31.624" y2="43.955" width="0.6096" layer="1"/>
<wire x1="31.624" y1="43.955" x2="31.659" y2="43.99" width="0.6096" layer="1"/>
<wire x1="31.694" y1="43.99" x2="31.659" y2="43.99" width="0.6096" layer="1"/>
</signal>
<signal name="S$166">
<wire x1="52.765" y1="52.922" x2="51.32" y2="52.922" width="0.4064" layer="1"/>
<wire x1="51.32" y1="52.922" x2="45.883" y2="47.485" width="0.4064" layer="1"/>
<wire x1="45.883" y1="47.485" x2="45.883" y2="42.896" width="0.4064" layer="1"/>
<wire x1="45.883" y1="42.896" x2="44.612" y2="41.625" width="0.4064" layer="1"/>
<wire x1="44.612" y1="41.625" x2="35.436" y2="41.625" width="0.4064" layer="1"/>
<wire x1="35.436" y1="41.625" x2="35.365" y2="41.554" width="0.4064" layer="1"/>
</signal>
<signal name="S$167">
<wire x1="52.624" y1="53.805" x2="50.931" y2="53.805" width="0.4064" layer="1"/>
<wire x1="50.931" y1="53.805" x2="44.682" y2="47.556" width="0.4064" layer="1"/>
<wire x1="44.682" y1="47.556" x2="44.682" y2="44.483" width="0.4064" layer="1"/>
<wire x1="44.682" y1="44.483" x2="44.118" y2="43.919" width="0.4064" layer="1"/>
<wire x1="35.471" y1="44.025" x2="35.435" y2="44.061" width="0.6096" layer="1"/>
<wire x1="44.118" y1="43.919" x2="35.577" y2="43.919" width="0.4064" layer="1"/>
<wire x1="35.577" y1="43.919" x2="35.435" y2="44.061" width="0.4064" layer="1"/>
<wire x1="35.435" y1="44.061" x2="35.435" y2="44.026" width="0.4064" layer="1"/>
<wire x1="35.435" y1="44.026" x2="35.506" y2="43.955" width="0.4064" layer="1"/>
</signal>
<signal name="S$168">
<wire x1="52.694" y1="54.511" x2="50.19" y2="54.511" width="0.4064" layer="1"/>
<wire x1="50.19" y1="54.511" x2="43.482" y2="47.803" width="0.4064" layer="1"/>
<wire x1="43.482" y1="47.803" x2="43.482" y2="46.884" width="0.4064" layer="1"/>
<wire x1="43.482" y1="46.884" x2="43.059" y2="46.461" width="0.4064" layer="1"/>
<wire x1="43.059" y1="46.461" x2="35.26" y2="46.461" width="0.4064" layer="1"/>
<wire x1="35.26" y1="46.461" x2="35.118" y2="46.603" width="0.4064" layer="1"/>
</signal>
<signal name="S$169">
<wire x1="52.659" y1="55.394" x2="49.626" y2="55.394" width="0.4064" layer="1"/>
<wire x1="49.626" y1="55.394" x2="42.388" y2="48.156" width="0.4064" layer="1"/>
<wire x1="42.388" y1="48.156" x2="36.283" y2="48.156" width="0.4064" layer="1"/>
<wire x1="36.283" y1="48.156" x2="35.365" y2="49.074" width="0.4064" layer="1"/>
</signal>
<signal name="S$170">
<wire x1="52.765" y1="56.17" x2="48.602" y2="56.17" width="0.4064" layer="1"/>
<wire x1="48.602" y1="56.17" x2="41.965" y2="49.533" width="0.4064" layer="1"/>
<wire x1="41.965" y1="49.533" x2="37.2" y2="49.533" width="0.4064" layer="1"/>
<wire x1="37.2" y1="49.533" x2="35.188" y2="51.545" width="0.4064" layer="1"/>
</signal>
<signal name="S$232">
<wire x1="35.859" y1="53.84" x2="32.788" y2="53.84" width="0.4064" layer="1"/>
<wire x1="32.788" y1="53.84" x2="32.259" y2="53.311" width="0.4064" layer="1"/>
<wire x1="32.259" y1="53.311" x2="32.259" y2="52.322" width="0.4064" layer="1"/>
<wire x1="32.259" y1="52.322" x2="32.188" y2="52.251" width="0.4064" layer="1"/>
</signal>
<signal name="S$171">
<wire x1="52.624" y1="56.982" x2="47.684" y2="56.982" width="0.4064" layer="1"/>
<wire x1="47.684" y1="56.982" x2="41.435" y2="50.733" width="0.4064" layer="1"/>
<wire x1="41.435" y1="50.733" x2="37.977" y2="50.733" width="0.4064" layer="1"/>
<wire x1="37.977" y1="50.733" x2="36.741" y2="51.969" width="0.4064" layer="1"/>
<wire x1="36.741" y1="51.969" x2="36.741" y2="52.958" width="0.4064" layer="1"/>
</signal>
<signal name="S$178">
<wire x1="52.524" y1="60.079" x2="30.286" y2="60.079" width="0.4064" layer="1"/>
</signal>
<signal name="S$179">
<wire x1="52.652" y1="59.316" x2="29.101" y2="59.316" width="0.4064" layer="1"/>
</signal>
<signal name="S$187">
<wire x1="31.601" y1="49.032" x2="31.601" y2="48.971" width="0.4064" layer="1"/>
<wire x1="31.54" y1="49.093" x2="31.601" y2="49.032" width="0.4064" layer="1"/>
</signal>
<signal name="S$164">
<wire x1="31.417" y1="46.712" x2="31.54" y2="46.589" width="0.4064" layer="1"/>
</signal>
<signal name="S$182">
<wire x1="104.503" y1="73.823" x2="102.005" y2="73.823" width="0.6096" layer="1"/>
<wire x1="102.005" y1="73.823" x2="99.318" y2="71.136" width="0.6096" layer="1"/>
<wire x1="99.318" y1="71.136" x2="99.318" y2="59.9" width="0.6096" layer="1"/>
<wire x1="99.318" y1="59.9" x2="98.708" y2="59.29" width="0.6096" layer="1"/>
</signal>
<signal name="S$183">
<wire x1="104.747" y1="70.953" x2="102.309" y2="70.953" width="0.6096" layer="1"/>
<wire x1="102.309" y1="70.953" x2="100.66" y2="69.304" width="0.6096" layer="1"/>
<wire x1="100.66" y1="69.304" x2="100.66" y2="58.801" width="0.6096" layer="1"/>
<wire x1="100.66" y1="58.801" x2="99.806" y2="57.947" width="0.6096" layer="1"/>
</signal>
<signal name="S$184">
<wire x1="104.808" y1="65.335" x2="103.223" y2="65.335" width="0.6096" layer="1"/>
<wire x1="103.223" y1="65.335" x2="101.819" y2="63.931" width="0.6096" layer="1"/>
<wire x1="101.819" y1="63.931" x2="101.819" y2="57.64" width="0.6096" layer="1"/>
<wire x1="101.819" y1="57.64" x2="100.416" y2="56.237" width="0.6096" layer="1"/>
<wire x1="100.416" y1="56.237" x2="94.864" y2="56.237" width="0.6096" layer="1"/>
<wire x1="94.864" y1="56.237" x2="94.742" y2="56.359" width="0.6096" layer="1"/>
</signal>
<signal name="S$57">
<wire x1="96.883" y1="69.127" x2="99.565" y2="69.127" width="0.6096" layer="16"/>
<wire x1="99.565" y1="69.127" x2="100.73" y2="67.962" width="0.6096" layer="16"/>
<wire x1="100.73" y1="67.962" x2="100.73" y2="66.585" width="0.6096" layer="16"/>
<wire x1="100.73" y1="66.585" x2="101.965" y2="65.35" width="0.6096" layer="16"/>
<wire x1="101.965" y1="65.35" x2="104.541" y2="65.35" width="0.6096" layer="16"/>
<wire x1="104.541" y1="65.35" x2="104.577" y2="65.314" width="0.6096" layer="16"/>
</signal>
<signal name="S$186">
<wire x1="58.81" y1="79.746" x2="58.81" y2="79.44" width="0.6096" layer="1"/>
</signal>
<signal name="S$107">
<wire x1="88.611" y1="44.373" x2="88.611" y2="26.889" width="0.6096" layer="1"/>
<wire x1="88.611" y1="26.889" x2="85.614" y2="23.892" width="0.6096" layer="1"/>
</signal>
<signal name="S$234">
<wire x1="96.616" y1="24.731" x2="96.616" y2="24.055" width="0.6096" layer="1"/>
<wire x1="96.181" y1="25.166" x2="96.616" y2="24.731" width="0.6096" layer="1"/>
<wire x1="91.981" y1="25.166" x2="96.181" y2="25.166" width="0.6096" layer="1"/>
</signal>
<signal name="S$188">
<wire x1="84.787" y1="20.915" x2="86.815" y2="20.915" width="0.6096" layer="1"/>
<wire x1="86.815" y1="20.915" x2="86.863" y2="20.963" width="0.6096" layer="1"/>
<wire x1="86.863" y1="20.963" x2="86.863" y2="21.157" width="0.6096" layer="1"/>
<wire x1="86.863" y1="21.157" x2="88.505" y2="22.799" width="0.6096" layer="1"/>
</signal>
<signal name="S$189">
<wire x1="88.649" y1="26.76" x2="88.649" y2="23.91" width="0.6096" layer="1"/>
</signal>
<signal name="S$116">
<wire x1="86.634" y1="42.761" x2="86.634" y2="45.579" width="0.6096" layer="16"/>
<wire x1="86.634" y1="45.579" x2="87.908" y2="46.853" width="0.6096" layer="16"/>
</signal>
<signal name="S$157">
<wire x1="82.9" y1="23.877" x2="82.9" y2="48.316" width="0.6096" layer="16"/>
<wire x1="82.9" y1="48.316" x2="82.916" y2="48.332" width="0.6096" layer="16"/>
</signal>
<signal name="S$158">
<wire x1="91.726" y1="25.281" x2="85.759" y2="25.281" width="0.4064" layer="16"/>
<wire x1="85.759" y1="25.281" x2="84.251" y2="26.789" width="0.4064" layer="16"/>
<wire x1="84.251" y1="26.789" x2="84.251" y2="49.416" width="0.4064" layer="16"/>
<wire x1="84.251" y1="49.416" x2="84.259" y2="49.424" width="0.4064" layer="16"/>
</signal>
<signal name="S$190">
<wire x1="97.6" y1="17.959" x2="99.104" y2="19.463" width="0.4064" layer="16"/>
<wire x1="99.104" y1="19.463" x2="99.104" y2="50.304" width="0.4064" layer="16"/>
<wire x1="99.104" y1="50.304" x2="99.132" y2="50.332" width="0.4064" layer="16"/>
</signal>
<signal name="S$104">
<wire x1="98.27" y1="17.124" x2="100.275" y2="19.129" width="0.4064" layer="16"/>
</signal>
<signal name="S$103">
<wire x1="100.417" y1="19.236" x2="100.417" y2="51.316" width="0.4064" layer="16"/>
</signal>
<signal name="R5">
<wire x1="66.793" y1="56.909" x2="64.038" y2="59.664" width="0.4064" layer="16"/>
<wire x1="64.038" y1="59.664" x2="64.038" y2="60.252" width="0.4064" layer="16"/>
<wire x1="64.038" y1="60.252" x2="63.871" y2="60.419" width="0.4064" layer="16"/>
<wire x1="63.871" y1="60.419" x2="61.283" y2="60.419" width="0.4064" layer="16"/>
<wire x1="61.283" y1="60.419" x2="57.857" y2="56.993" width="0.4064" layer="16"/>
<wire x1="57.857" y1="56.993" x2="57.776" y2="56.993" width="0.4064" layer="16"/>
<wire x1="57.776" y1="56.993" x2="56.941" y2="56.158" width="0.4064" layer="16"/>
<wire x1="56.941" y1="56.158" x2="56.941" y2="51.979" width="0.4064" layer="16"/>
<wire x1="56.941" y1="51.979" x2="48.01" y2="51.979" width="0.4064" layer="16"/>
<wire x1="48.01" y1="51.979" x2="45.753" y2="49.722" width="0.4064" layer="16"/>
<wire x1="45.753" y1="49.722" x2="45.753" y2="35.344" width="0.4064" layer="16"/>
<wire x1="45.753" y1="35.344" x2="51.598" y2="29.499" width="0.4064" layer="16"/>
<wire x1="51.598" y1="29.499" x2="77.561" y2="29.499" width="0.4064" layer="16"/>
<wire x1="77.561" y1="29.499" x2="80.402" y2="26.658" width="0.4064" layer="16"/>
<wire x1="80.402" y1="26.658" x2="80.402" y2="23.734" width="0.4064" layer="16"/>
<wire x1="80.402" y1="23.734" x2="80.486" y2="23.65" width="0.4064" layer="16"/>
</signal>
<signal name="S$237">
<wire x1="90.967" y1="28.982" x2="91.015" y2="29.03" width="0.4064" layer="16"/>
</signal>
<signal name="S$105">
<wire x1="96.423" y1="23.958" x2="94.683" y2="25.698" width="0.4064" layer="16"/>
<wire x1="94.683" y1="25.698" x2="94.683" y2="32.265" width="0.4064" layer="16"/>
</signal>
<signal name="S$109">
<wire x1="97.427" y1="19.902" x2="97.511" y2="20.232" width="0.4064" layer="16"/>
<wire x1="97.511" y1="20.232" x2="98.161" y2="21.833" width="0.4064" layer="16"/>
<wire x1="98.161" y1="21.833" x2="98.161" y2="30.881" width="0.4064" layer="16"/>
<wire x1="98.161" y1="30.881" x2="98.159" y2="30.883" width="0.4064" layer="16"/>
<wire x1="98.159" y1="30.883" x2="98.14" y2="30.864" width="0.4064" layer="16"/>
</signal>
<signal name="S$114">
<wire x1="98.173" y1="34.268" x2="98.173" y2="35.459" width="0.4064" layer="16"/>
<wire x1="98.173" y1="35.459" x2="96.535" y2="37.097" width="0.4064" layer="16"/>
<wire x1="96.535" y1="37.097" x2="92.147" y2="37.097" width="0.4064" layer="16"/>
<wire x1="92.147" y1="37.097" x2="92.124" y2="37.074" width="0.4064" layer="16"/>
</signal>
<signal name="S$101">
<wire x1="97.42" y1="19.922" x2="97.42" y2="17.949" width="0.6096" layer="1"/>
<wire x1="97.42" y1="17.949" x2="94.83" y2="17.92" width="0.6096" layer="1"/>
<wire x1="94.83" y1="17.92" x2="76.725" y2="17.92" width="0.6096" layer="1"/>
<wire x1="76.725" y1="17.92" x2="74.744" y2="19.901" width="0.6096" layer="1"/>
<wire x1="74.744" y1="19.901" x2="74.744" y2="28.354" width="0.6096" layer="1"/>
<wire x1="74.744" y1="28.354" x2="73.73" y2="29.368" width="0.6096" layer="1"/>
<wire x1="73.73" y1="29.368" x2="51.906" y2="29.368" width="0.6096" layer="1"/>
<wire x1="51.906" y1="29.368" x2="51.692" y2="29.582" width="0.6096" layer="1"/>
<wire x1="51.692" y1="29.582" x2="50.07" y2="31.204" width="0.6096" layer="1"/>
<wire x1="50.07" y1="31.204" x2="50.07" y2="33.957" width="0.6096" layer="1"/>
<wire x1="50.07" y1="33.957" x2="51.084" y2="34.971" width="0.6096" layer="1"/>
<wire x1="51.084" y1="34.971" x2="54.947" y2="34.971" width="0.6096" layer="1"/>
<wire x1="54.947" y1="34.971" x2="55.816" y2="34.102" width="0.6096" layer="1"/>
<wire x1="55.816" y1="34.102" x2="55.816" y2="33.281" width="0.6096" layer="1"/>
<wire x1="55.816" y1="33.281" x2="55.865" y2="33.232" width="0.6096" layer="1"/>
<wire x1="51.692" y1="29.582" x2="37.808" y2="29.582" width="0.6096" layer="1"/>
<wire x1="37.808" y1="29.582" x2="37.023" y2="28.797" width="0.6096" layer="1"/>
</signal>
<signal name="S$115">
<wire x1="78.365" y1="20.239" x2="71.462" y2="20.239" width="0.6096" layer="16"/>
<wire x1="71.462" y1="20.239" x2="68.95" y2="22.751" width="0.6096" layer="16"/>
<wire x1="68.95" y1="22.751" x2="65.955" y2="22.751" width="0.6096" layer="16"/>
<wire x1="65.955" y1="22.751" x2="65.714" y2="22.992" width="0.6096" layer="16"/>
</signal>
<signal name="S$192">
<via x="65.452" y="28.169" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$193">
<wire x1="65.475" y1="27.797" x2="65.475" y2="26.865" width="0.6096" layer="16"/>
<wire x1="65.475" y1="26.865" x2="65.429" y2="26.819" width="0.6096" layer="16"/>
</signal>
<signal name="S$194">
<wire x1="68.92" y1="28.146" x2="68.92" y2="26.493" width="0.6096" layer="16"/>
<wire x1="68.92" y1="26.493" x2="68.943" y2="26.47" width="0.6096" layer="16"/>
</signal>
<signal name="S$195">
<wire x1="65.43" y1="28.504" x2="65.43" y2="29.299" width="0.6096" layer="1"/>
</signal>
<signal name="S$196">
<via x="68.73" y="33.337" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$197">
<wire x1="58.84" y1="34.209" x2="58.84" y2="35.986" width="0.6096" layer="1"/>
<wire x1="58.84" y1="35.986" x2="59.276" y2="36.422" width="0.6096" layer="1"/>
<wire x1="59.276" y1="36.422" x2="67.725" y2="36.422" width="0.6096" layer="1"/>
<wire x1="67.725" y1="36.422" x2="68.764" y2="35.383" width="0.6096" layer="1"/>
<wire x1="68.764" y1="35.383" x2="68.764" y2="33.873" width="0.6096" layer="1"/>
</signal>
<signal name="S$198">
<wire x1="68.898" y1="30.788" x2="68.898" y2="32.935" width="0.6096" layer="16"/>
<wire x1="68.898" y1="32.935" x2="68.764" y2="33.069" width="0.6096" layer="16"/>
</signal>
<signal name="S$199">
<via x="85.126" y="69.041" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$200">
<via x="91.701" y="69.177" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$201">
<wire x1="85.494" y1="69.119" x2="86.659" y2="69.119" width="0.6096" layer="16"/>
<wire x1="86.659" y1="69.119" x2="86.697" y2="69.157" width="0.6096" layer="16"/>
<wire x1="86.697" y1="69.157" x2="86.678" y2="69.157" width="0.6096" layer="16"/>
<wire x1="86.678" y1="69.157" x2="86.658" y2="69.177" width="0.6096" layer="16"/>
</signal>
<signal name="S$202">
<wire x1="91.546" y1="69.235" x2="90.188" y2="69.235" width="0.6096" layer="16"/>
<wire x1="90.188" y1="69.235" x2="90.149" y2="69.274" width="0.6096" layer="16"/>
</signal>
<signal name="S$203">
<via x="86.639" y="84.56" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$204">
<via x="86.93" y="77.906" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$205">
<via x="87.162" y="74.996" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$206">
<via x="82.081" y="77.79" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$207">
<via x="81.964" y="80.758" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$132">
<wire x1="82.197" y1="80.545" x2="83.671" y2="80.545" width="0.6096" layer="16"/>
<wire x1="83.671" y1="80.545" x2="83.691" y2="80.525" width="0.6096" layer="16"/>
</signal>
<signal name="S$134">
<wire x1="82.275" y1="77.732" x2="83.496" y2="77.732" width="0.6096" layer="16"/>
<wire x1="83.496" y1="77.732" x2="83.516" y2="77.712" width="0.6096" layer="16"/>
</signal>
<signal name="S$135">
<wire x1="87.919" y1="80.952" x2="87.589" y2="80.952" width="0.6096" layer="16"/>
<wire x1="87.589" y1="80.952" x2="84.951" y2="78.314" width="0.6096" layer="16"/>
</signal>
<signal name="S$208">
<wire x1="94.843" y1="77.518" x2="94.378" y2="77.518" width="0.6096" layer="16"/>
<wire x1="94.378" y1="77.518" x2="92.632" y2="79.264" width="0.6096" layer="16"/>
<wire x1="92.632" y1="79.264" x2="92.632" y2="80.525" width="0.6096" layer="16"/>
<wire x1="92.632" y1="80.525" x2="91.953" y2="81.204" width="0.6096" layer="16"/>
<wire x1="91.953" y1="81.204" x2="89.16" y2="81.204" width="0.6096" layer="16"/>
<wire x1="89.16" y1="81.204" x2="89.121" y2="81.243" width="0.6096" layer="16"/>
</signal>
<signal name="S$209">
<wire x1="89.141" y1="75.19" x2="87.53" y2="75.19" width="0.6096" layer="16"/>
<wire x1="87.53" y1="75.19" x2="87.414" y2="75.074" width="0.6096" layer="16"/>
</signal>
<signal name="S$210">
<wire x1="87.143" y1="77.848" x2="89.082" y2="77.848" width="0.6096" layer="16"/>
</signal>
<signal name="S$211">
<wire x1="86.774" y1="84.618" x2="87.842" y2="84.618" width="0.6096" layer="16"/>
<wire x1="87.842" y1="84.618" x2="87.88" y2="84.58" width="0.6096" layer="16"/>
</signal>
<signal name="S$212">
<wire x1="86.794" y1="77.829" x2="86.794" y2="77.984" width="0.6096" layer="1"/>
<wire x1="86.794" y1="77.984" x2="84.117" y2="80.661" width="0.6096" layer="1"/>
<wire x1="84.117" y1="80.661" x2="82.274" y2="80.661" width="0.6096" layer="1"/>
<wire x1="82.274" y1="80.661" x2="82.255" y2="80.68" width="0.6096" layer="1"/>
</signal>
<signal name="S$152">
<via x="79.943" y="42.922" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$149">
<wire x1="72.793" y1="42.587" x2="73.21" y2="42.587" width="0.6096" layer="16"/>
<wire x1="73.21" y1="42.587" x2="76.48" y2="39.317" width="0.6096" layer="16"/>
<wire x1="76.48" y1="39.317" x2="76.48" y2="37.417" width="0.6096" layer="16"/>
<wire x1="76.48" y1="37.417" x2="76.536" y2="37.361" width="0.6096" layer="16"/>
</signal>
<signal name="S$150">
<wire x1="79.971" y1="39.82" x2="79.971" y2="42.503" width="0.6096" layer="16"/>
<wire x1="79.971" y1="42.503" x2="80.027" y2="42.559" width="0.6096" layer="16"/>
</signal>
<signal name="S$151">
<wire x1="79.804" y1="36.467" x2="79.804" y2="35.126" width="0.6096" layer="16"/>
<wire x1="79.804" y1="35.126" x2="79.608" y2="34.93" width="0.6096" layer="16"/>
<wire x1="79.608" y1="34.93" x2="73.77" y2="34.93" width="0.6096" layer="16"/>
<wire x1="73.77" y1="34.93" x2="73.519" y2="35.181" width="0.6096" layer="16"/>
<wire x1="73.519" y1="35.181" x2="73.519" y2="36.355" width="0.6096" layer="16"/>
<wire x1="73.519" y1="36.355" x2="73.435" y2="36.439" width="0.6096" layer="16"/>
</signal>
<signal name="S$213">
<wire x1="68.91" y1="33.337" x2="71.87" y2="33.337" width="0.6096" layer="16"/>
<wire x1="71.87" y1="33.337" x2="73.519" y2="34.986" width="0.6096" layer="16"/>
</signal>
<signal name="S$214">
<wire x1="86.368" y1="42.894" x2="80.083" y2="42.894" width="0.6096" layer="1"/>
<wire x1="80.083" y1="42.894" x2="80.055" y2="42.922" width="0.6096" layer="1"/>
</signal>
<signal name="S$215">
<via x="73.941" y="63.586" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$216">
<via x="81.585" y="65.326" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$217">
<wire x1="74.076" y1="63.586" x2="77.466" y2="63.586" width="0.6096" layer="16"/>
<wire x1="77.466" y1="63.586" x2="77.477" y2="63.597" width="0.6096" layer="16"/>
<wire x1="77.477" y1="63.597" x2="77.443" y2="63.597" width="0.6096" layer="16"/>
<wire x1="77.443" y1="63.597" x2="77.443" y2="63.575" width="0.6096" layer="16"/>
<wire x1="77.443" y1="63.575" x2="77.477" y2="63.541" width="0.6096" layer="16"/>
</signal>
<signal name="S$218">
<wire x1="81.506" y1="65.068" x2="81.506" y2="64.035" width="0.6096" layer="16"/>
<wire x1="81.506" y1="64.035" x2="81.472" y2="64.001" width="0.6096" layer="16"/>
</signal>
<signal name="S$219">
<via x="73.346" y="59.702" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$220">
<via x="80.036" y="59.523" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$74">
<wire x1="75.445" y1="59.276" x2="74.435" y2="59.276" width="0.6096" layer="1"/>
<wire x1="74.435" y1="59.276" x2="73.795" y2="59.488" width="0.6096" layer="1"/>
</signal>
<signal name="S$73">
<wire x1="80.058" y1="59.815" x2="80.058" y2="59.995" width="0.6096" layer="1"/>
<wire x1="80.058" y1="59.995" x2="78.24" y2="61.813" width="0.6096" layer="1"/>
<wire x1="78.24" y1="61.813" x2="76.512" y2="61.813" width="0.6096" layer="1"/>
<wire x1="76.512" y1="61.813" x2="76.489" y2="61.79" width="0.6096" layer="1"/>
</signal>
<signal name="S$221">
<wire x1="73.616" y1="59.702" x2="74.739" y2="59.702" width="0.6096" layer="16"/>
<wire x1="74.739" y1="59.702" x2="74.761" y2="59.68" width="0.6096" layer="16"/>
</signal>
<signal name="S$222">
<wire x1="79.778" y1="59.545" x2="78.52" y2="59.545" width="0.6096" layer="16"/>
<wire x1="78.52" y1="59.545" x2="78.487" y2="59.512" width="0.6096" layer="16"/>
</signal>
<signal name="S$223">
<via x="72.272" y="54.933" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$224">
<via x="80.07" y="57.83" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$225">
<wire x1="72.138" y1="54.799" x2="72.138" y2="53.936" width="0.6096" layer="16"/>
<wire x1="72.138" y1="53.936" x2="73.013" y2="53.061" width="0.6096" layer="16"/>
<wire x1="73.013" y1="53.061" x2="78.805" y2="53.061" width="0.6096" layer="16"/>
<wire x1="78.805" y1="53.061" x2="78.818" y2="53.048" width="0.6096" layer="16"/>
</signal>
<signal name="S$75">
<wire x1="80.111" y1="57.574" x2="80.111" y2="56.536" width="0.6096" layer="16"/>
<wire x1="80.111" y1="56.536" x2="80.017" y2="56.442" width="0.6096" layer="16"/>
</signal>
<signal name="S$84">
<wire x1="76.205" y1="58.005" x2="79.774" y2="58.005" width="0.6096" layer="1"/>
<wire x1="79.774" y1="58.005" x2="79.936" y2="57.843" width="0.6096" layer="1"/>
</signal>
<signal name="S$235">
<wire x1="91.965" y1="25.119" x2="88.741" y2="25.119" width="0.6096" layer="1"/>
<wire x1="88.741" y1="25.119" x2="88.741" y2="24.788" width="0.6096" layer="1"/>
</signal>
<signal name="S$236">
<via x="97.516" y="20.326" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$99">
<wire x1="95.262" y1="21.085" x2="95.262" y2="24.039" width="0.4064" layer="16"/>
<wire x1="95.262" y1="24.039" x2="93.942" y2="25.359" width="0.4064" layer="16"/>
<wire x1="93.942" y1="25.359" x2="93.942" y2="28.458" width="0.4064" layer="16"/>
<wire x1="93.942" y1="28.458" x2="93.082" y2="29.318" width="0.4064" layer="16"/>
<wire x1="93.082" y1="29.318" x2="91.246" y2="29.318" width="0.4064" layer="16"/>
</signal>
<signal name="S$238">
<wire x1="91.707" y1="25.258" x2="93.035" y2="25.258" width="0.4064" layer="16"/>
<wire x1="93.035" y1="25.258" x2="93.782" y2="24.511" width="0.4064" layer="16"/>
<wire x1="93.782" y1="24.511" x2="93.782" y2="23.549" width="0.4064" layer="16"/>
<wire x1="93.782" y1="23.549" x2="93.832" y2="23.499" width="0.4064" layer="16"/>
</signal>
<signal name="S$239">
<wire x1="97.599" y1="17.906" x2="93.134" y2="17.906" width="0.4064" layer="16"/>
<wire x1="93.134" y1="17.906" x2="92.387" y2="18.653" width="0.4064" layer="16"/>
<wire x1="92.387" y1="18.653" x2="92.387" y2="19.698" width="0.4064" layer="16"/>
<wire x1="92.387" y1="19.698" x2="92.437" y2="19.748" width="0.4064" layer="16"/>
</signal>
<signal name="S$240">
<wire x1="98.197" y1="17.089" x2="92.373" y2="17.089" width="0.4064" layer="16"/>
<wire x1="92.373" y1="17.089" x2="91.131" y2="18.331" width="0.4064" layer="16"/>
<wire x1="91.131" y1="18.331" x2="91.131" y2="22.434" width="0.4064" layer="16"/>
<wire x1="91.131" y1="22.434" x2="91.103" y2="22.462" width="0.4064" layer="16"/>
</signal>
<signal name="S$241">
<via x="55.535" y="53.501" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$242">
<wire x1="60.609" y1="51.623" x2="60.609" y2="52.798" width="0.4064" layer="1"/>
<wire x1="60.609" y1="52.798" x2="59.912" y2="53.495" width="0.4064" layer="1"/>
<wire x1="59.912" y1="53.495" x2="55.909" y2="53.495" width="0.4064" layer="1"/>
</signal>
<signal name="S$243">
<wire x1="55.311" y1="53.456" x2="47.842" y2="53.456" width="0.6096" layer="16"/>
<wire x1="47.842" y1="53.456" x2="44.436" y2="50.05" width="0.6096" layer="16"/>
<wire x1="44.436" y1="50.05" x2="44.436" y2="34.178" width="0.6096" layer="16"/>
<wire x1="44.436" y1="34.178" x2="51.097" y2="27.517" width="0.6096" layer="16"/>
<wire x1="51.097" y1="27.517" x2="61.813" y2="27.517" width="0.6096" layer="16"/>
<wire x1="61.813" y1="27.517" x2="63.648" y2="25.682" width="0.6096" layer="16"/>
<wire x1="63.648" y1="25.682" x2="63.648" y2="20.031" width="0.6096" layer="16"/>
<wire x1="63.648" y1="20.031" x2="64.64" y2="19.039" width="0.6096" layer="16"/>
<wire x1="64.64" y1="19.039" x2="75.654" y2="19.039" width="0.6096" layer="16"/>
<wire x1="75.654" y1="19.039" x2="76.844" y2="17.849" width="0.6096" layer="16"/>
<wire x1="76.844" y1="17.849" x2="88.949" y2="17.849" width="0.6096" layer="16"/>
<wire x1="88.949" y1="17.849" x2="89.792" y2="18.692" width="0.6096" layer="16"/>
<wire x1="89.792" y1="18.692" x2="89.792" y2="19.634" width="0.6096" layer="16"/>
</signal>
<signal name="S$244">
<wire x1="82.049" y1="20.65" x2="84.432" y2="20.65" width="0.6096" layer="1"/>
<wire x1="84.432" y1="20.65" x2="84.61" y2="20.828" width="0.6096" layer="1"/>
</signal>
<signal name="S$100">
<wire x1="76.803" y1="23.136" x2="75.321" y2="23.136" width="0.6096" layer="1"/>
<wire x1="75.321" y1="23.136" x2="74.843" y2="23.614" width="0.6096" layer="1"/>
</signal>
<signal name="S$102">
<wire x1="64.129" y1="32.142" x2="64.129" y2="31.894" width="0.6096" layer="16"/>
<wire x1="64.129" y1="31.894" x2="63.386" y2="31.151" width="0.6096" layer="16"/>
<wire x1="63.386" y1="31.151" x2="56.567" y2="31.151" width="0.6096" layer="16"/>
<wire x1="56.567" y1="31.151" x2="55.7" y2="32.018" width="0.6096" layer="16"/>
<wire x1="55.7" y1="32.018" x2="55.7" y2="32.927" width="0.6096" layer="16"/>
<wire x1="55.7" y1="32.927" x2="55.576" y2="33.051" width="0.6096" layer="16"/>
</signal>
<signal name="S$108">
<via x="55.538" y="55.047" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$226">
<wire x1="61.406" y1="51.006" x2="61.406" y2="53.415" width="0.4064" layer="1"/>
<wire x1="61.406" y1="53.415" x2="59.892" y2="54.929" width="0.4064" layer="1"/>
<wire x1="59.892" y1="54.929" x2="55.909" y2="54.929" width="0.4064" layer="1"/>
<wire x1="55.909" y1="54.929" x2="55.889" y2="54.909" width="0.4064" layer="1"/>
</signal>
<signal name="S$227">
<wire x1="55.231" y1="55.029" x2="54.096" y2="55.029" width="0.4064" layer="16"/>
<wire x1="54.096" y1="55.029" x2="53.558" y2="54.491" width="0.4064" layer="16"/>
<wire x1="53.558" y1="54.491" x2="47.085" y2="54.491" width="0.4064" layer="16"/>
<wire x1="47.085" y1="54.491" x2="43.142" y2="50.548" width="0.4064" layer="16"/>
<wire x1="43.142" y1="50.548" x2="43.142" y2="34.789" width="0.6096" layer="16"/>
<wire x1="43.142" y1="34.789" x2="38.566" y2="34.794" width="0.6096" layer="16"/>
<wire x1="38.566" y1="34.794" x2="35.514" y2="34.794" width="0.6096" layer="16"/>
<wire x1="35.514" y1="34.794" x2="35.553" y2="35.871" width="0.6096" layer="16"/>
</signal>
<signal name="S$246">
<wire x1="33.181" y1="31.027" x2="33.181" y2="32.926" width="0.6096" layer="16"/>
<wire x1="33.181" y1="32.926" x2="33.258" y2="35.477" width="0.6096" layer="16"/>
</signal>
<signal name="S$247">
<wire x1="32.065" y1="25.821" x2="32.065" y2="28.3" width="0.6096" layer="16"/>
<wire x1="32.065" y1="28.3" x2="32.106" y2="28.341" width="0.6096" layer="16"/>
</signal>
<signal name="S$248">
<via x="36.899" y="28.59" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$249">
<wire x1="34.337" y1="28.549" x2="36.651" y2="28.549" width="0.6096" layer="16"/>
</signal>
<signal name="S$250">
<wire x1="58.799" y1="34.168" x2="58.303" y2="34.168" width="0.6096" layer="1"/>
<wire x1="58.303" y1="34.168" x2="56.32" y2="36.151" width="0.6096" layer="1"/>
<wire x1="56.32" y1="36.151" x2="50.122" y2="36.151" width="0.6096" layer="1"/>
<wire x1="50.122" y1="36.151" x2="48.552" y2="34.581" width="0.6096" layer="1"/>
<wire x1="48.552" y1="34.581" x2="48.552" y2="32.102" width="0.6096" layer="1"/>
<wire x1="48.552" y1="32.102" x2="47.643" y2="31.193" width="0.6096" layer="1"/>
<wire x1="47.643" y1="31.193" x2="36.774" y2="31.193" width="0.6096" layer="1"/>
<wire x1="36.774" y1="31.193" x2="34.213" y2="28.632" width="0.6096" layer="1"/>
<wire x1="34.213" y1="28.632" x2="34.213" y2="27.228" width="0.6096" layer="1"/>
<wire x1="34.213" y1="27.228" x2="36.321" y2="25.12" width="0.6096" layer="1"/>
<wire x1="36.321" y1="25.12" x2="39.337" y2="25.12" width="0.6096" layer="1"/>
<wire x1="39.337" y1="25.12" x2="39.378" y2="25.161" width="0.6096" layer="1"/>
</signal>
<signal name="S$251">
<wire x1="48.003" y1="29.656" x2="48.003" y2="28.528" width="0.6096" layer="1"/>
<wire x1="48.003" y1="28.528" x2="47.986" y2="28.511" width="0.6096" layer="1"/>
</signal>
<signal name="S$252">
<wire x1="71.31" y1="26.45" x2="69.101" y2="26.45" width="0.6096" layer="16"/>
<wire x1="69.101" y1="26.45" x2="69.015" y2="26.536" width="0.6096" layer="16"/>
</signal>
<signal name="S$253">
<wire x1="71.425" y1="22.921" x2="69.159" y2="22.921" width="0.6096" layer="16"/>
<wire x1="69.159" y1="22.921" x2="68.987" y2="22.749" width="0.6096" layer="16"/>
</signal>
<signal name="S$56">
<wire x1="56.308" y1="47.592" x2="60.869" y2="47.592" width="0.6096" layer="16"/>
<wire x1="60.869" y1="47.592" x2="62.074" y2="46.387" width="0.6096" layer="16"/>
<wire x1="62.074" y1="46.387" x2="62.074" y2="46.444" width="0.6096" layer="16"/>
<wire x1="62.074" y1="46.444" x2="62.045" y2="46.473" width="0.6096" layer="16"/>
<wire x1="62.045" y1="46.473" x2="62.045" y2="37.063" width="0.6096" layer="16"/>
<wire x1="62.045" y1="37.063" x2="62.102" y2="37.006" width="0.6096" layer="16"/>
</signal>
<signal name="S$62">
<wire x1="53.296" y1="47.506" x2="53.296" y2="46.645" width="0.6096" layer="16"/>
<wire x1="53.296" y1="46.645" x2="54.099" y2="45.842" width="0.6096" layer="16"/>
<wire x1="54.099" y1="45.842" x2="58.661" y2="45.842" width="0.6096" layer="16"/>
<wire x1="58.661" y1="45.842" x2="59.722" y2="44.781" width="0.6096" layer="16"/>
<wire x1="59.722" y1="44.781" x2="59.722" y2="39.589" width="0.6096" layer="16"/>
<wire x1="59.722" y1="39.589" x2="59.004" y2="38.871" width="0.6096" layer="16"/>
<wire x1="59.004" y1="38.871" x2="59.004" y2="33.965" width="0.6096" layer="16"/>
<wire x1="59.004" y1="33.965" x2="58.976" y2="33.937" width="0.6096" layer="16"/>
</signal>
<signal name="S$117">
<wire x1="64.11" y1="34.109" x2="64.11" y2="35.687" width="0.6096" layer="16"/>
<wire x1="64.11" y1="35.687" x2="63.221" y2="36.576" width="0.6096" layer="16"/>
<wire x1="63.221" y1="36.576" x2="62.446" y2="36.576" width="0.6096" layer="16"/>
<wire x1="62.446" y1="36.576" x2="62.389" y2="36.633" width="0.6096" layer="16"/>
</signal>
<signal name="S$365">
<wire x1="49.558" y1="42.483" x2="49.491" y2="42.473" width="0.6096" layer="16"/>
<wire x1="49.539" y1="40.592" x2="49.558" y2="42.483" width="0.6096" layer="16"/>
<wire x1="49.653" y1="40.478" x2="49.539" y2="40.592" width="0.6096" layer="16"/>
</signal>
<signal name="S$254">
<wire x1="55.734" y1="33.306" x2="50.78" y2="33.314" width="0.6096" layer="16"/>
<wire x1="50.78" y1="33.314" x2="50.754" y2="34.98" width="0.6096" layer="16"/>
</signal>
<signal name="S$255">
<wire x1="47.043" y1="47.362" x2="47.043" y2="41.109" width="0.6096" layer="16"/>
<wire x1="47.043" y1="41.109" x2="47.014" y2="41.08" width="0.6096" layer="16"/>
</signal>
<signal name="S$256">
<wire x1="49.729" y1="44.825" x2="49.739" y2="47.649" width="0.6096" layer="16"/>
<wire x1="49.739" y1="47.649" x2="49.653" y2="47.735" width="0.6096" layer="16"/>
</signal>
<signal name="S$257">
<wire x1="50.9" y1="31.73" x2="47.306" y2="35.083" width="0.6096" layer="16"/>
<wire x1="47.306" y1="35.083" x2="47.158" y2="41.194" width="0.6096" layer="16"/>
<wire x1="47.158" y1="41.194" x2="47.129" y2="41.223" width="0.6096" layer="16"/>
</signal>
<signal name="S$112">
<wire x1="171.795" y1="29.041" x2="164.913" y2="29.041" width="0.6096" layer="16"/>
<wire x1="164.913" y1="29.041" x2="164.913" y2="28.96" width="0.6096" layer="16"/>
</signal>
<signal name="S$259">
<wire x1="175.318" y1="29.123" x2="177.694" y2="29.123" width="0.6096" layer="16"/>
<wire x1="177.694" y1="29.123" x2="177.694" y2="44.264" width="0.6096" layer="16"/>
<wire x1="177.694" y1="44.264" x2="175.073" y2="44.264" width="0.6096" layer="16"/>
<wire x1="175.073" y1="44.264" x2="175.073" y2="44.346" width="0.6096" layer="16"/>
<wire x1="175.073" y1="44.346" x2="174.827" y2="44.346" width="0.6096" layer="16"/>
<wire x1="174.827" y1="44.346" x2="174.827" y2="44.183" width="0.6096" layer="16"/>
</signal>
<signal name="S$260">
<wire x1="174.827" y1="59.406" x2="177.819" y2="59.406" width="0.6096" layer="16"/>
<wire x1="177.819" y1="59.406" x2="177.819" y2="74.219" width="0.6096" layer="16"/>
<wire x1="177.819" y1="74.219" x2="175.317" y2="74.219" width="0.6096" layer="16"/>
<wire x1="175.317" y1="74.219" x2="175.317" y2="74.276" width="0.6096" layer="16"/>
</signal>
<signal name="S$261">
<wire x1="171.905" y1="59.276" x2="165.024" y2="59.276" width="0.6096" layer="16"/>
<wire x1="165.024" y1="59.276" x2="163.117" y2="59.289" width="0.6096" layer="16"/>
</signal>
<signal name="S$264">
<wire x1="155.182" y1="51.63" x2="155.101" y2="51.549" width="0.6096" layer="16"/>
</signal>
<signal name="S$265">
<wire x1="143.933" y1="29.007" x2="137.154" y2="29.007" width="0.6096" layer="16"/>
<wire x1="137.154" y1="29.007" x2="136.859" y2="29.302" width="0.6096" layer="16"/>
</signal>
<signal name="S$266">
<wire x1="134.108" y1="29.204" x2="131.259" y2="29.204" width="0.6096" layer="16"/>
<wire x1="131.259" y1="29.204" x2="130.178" y2="30.285" width="0.6096" layer="16"/>
<wire x1="130.178" y1="30.285" x2="130.178" y2="42.863" width="0.6096" layer="16"/>
<wire x1="130.178" y1="42.863" x2="131.652" y2="44.337" width="0.6096" layer="16"/>
<wire x1="131.652" y1="44.337" x2="133.715" y2="44.337" width="0.6096" layer="16"/>
<wire x1="133.715" y1="44.337" x2="133.912" y2="44.534" width="0.6096" layer="16"/>
</signal>
<signal name="S$267">
<wire x1="143.54" y1="59.176" x2="131.947" y2="59.176" width="0.6096" layer="16"/>
<wire x1="131.947" y1="59.176" x2="130.178" y2="60.945" width="0.6096" layer="16"/>
<wire x1="130.178" y1="60.945" x2="130.178" y2="72.639" width="0.6096" layer="16"/>
<wire x1="130.178" y1="72.639" x2="131.652" y2="74.113" width="0.6096" layer="16"/>
<wire x1="131.652" y1="74.113" x2="133.715" y2="74.113" width="0.6096" layer="16"/>
<wire x1="133.715" y1="74.113" x2="134.01" y2="74.408" width="0.6096" layer="16"/>
</signal>
<signal name="S$287">
<wire x1="162.011" y1="28.909" x2="146.782" y2="28.909" width="0.6096" layer="16"/>
<wire x1="146.782" y1="28.909" x2="146.684" y2="29.007" width="0.6096" layer="16"/>
</signal>
<signal name="S$262">
<wire x1="146.684" y1="59.274" x2="146.389" y2="59.569" width="0.6096" layer="16"/>
<wire x1="146.389" y1="59.569" x2="146.389" y2="67.333" width="0.6096" layer="16"/>
<wire x1="146.389" y1="67.333" x2="148.649" y2="69.593" width="0.6096" layer="16"/>
<wire x1="148.649" y1="69.593" x2="159.653" y2="69.593" width="0.6096" layer="16"/>
<wire x1="159.653" y1="69.593" x2="161.815" y2="67.431" width="0.6096" layer="16"/>
</signal>
<signal name="S$270">
<wire x1="160.071" y1="59.438" x2="155.035" y2="59.471" width="0.6096" layer="16"/>
<wire x1="155.035" y1="59.471" x2="154.937" y2="59.569" width="0.6096" layer="16"/>
</signal>
<signal name="S$271">
<wire x1="155.101" y1="56.95" x2="163.044" y2="56.95" width="0.6096" layer="16"/>
<wire x1="163.044" y1="56.95" x2="163.134" y2="59.177" width="0.6096" layer="16"/>
</signal>
<signal name="S$272">
<wire x1="164.435" y1="29.86" x2="164.681" y2="29.614" width="0.6096" layer="16"/>
</signal>
<signal name="S$286">
<wire x1="145.296" y1="43.269" x2="145.454" y2="43.111" width="0.6096" layer="16"/>
</signal>
<signal name="S$279">
<wire x1="143.441" y1="59.129" x2="143.441" y2="58.774" width="0.6096" layer="16"/>
<wire x1="143.441" y1="58.774" x2="145.296" y2="56.919" width="0.6096" layer="16"/>
</signal>
<signal name="S$280">
<wire x1="148.137" y1="42.953" x2="152.517" y2="42.953" width="0.6096" layer="16"/>
<wire x1="152.517" y1="42.953" x2="154.608" y2="45.044" width="0.6096" layer="16"/>
<wire x1="154.608" y1="45.044" x2="154.608" y2="48.477" width="0.6096" layer="16"/>
<wire x1="154.608" y1="48.477" x2="154.569" y2="48.516" width="0.6096" layer="16"/>
</signal>
<signal name="S$281">
<wire x1="143.991" y1="29.763" x2="143.991" y2="30.859" width="0.6096" layer="16"/>
<wire x1="143.991" y1="30.859" x2="144.648" y2="31.516" width="0.6096" layer="16"/>
</signal>
<signal name="S$282">
<wire x1="153.795" y1="41.984" x2="156.293" y2="44.482" width="0.6096" layer="16"/>
<wire x1="156.293" y1="44.482" x2="156.293" y2="50.548" width="0.6096" layer="16"/>
<wire x1="156.293" y1="50.548" x2="155.278" y2="51.563" width="0.6096" layer="16"/>
</signal>
<signal name="S$283">
<wire x1="133.903" y1="54.331" x2="131.527" y2="54.331" width="0.6096" layer="16"/>
<wire x1="131.527" y1="54.331" x2="128.745" y2="51.549" width="0.6096" layer="16"/>
<wire x1="128.745" y1="51.549" x2="128.745" y2="26.259" width="0.6096" layer="16"/>
<wire x1="128.745" y1="26.259" x2="131.037" y2="23.967" width="0.6096" layer="16"/>
<wire x1="131.037" y1="23.967" x2="133.657" y2="23.967" width="0.6096" layer="16"/>
<wire x1="133.657" y1="23.967" x2="133.903" y2="24.213" width="0.6096" layer="16"/>
</signal>
<signal name="S$284">
<wire x1="175.482" y1="54.263" x2="177.054" y2="54.263" width="0.6096" layer="16"/>
<wire x1="177.054" y1="54.263" x2="179.413" y2="51.904" width="0.6096" layer="16"/>
<wire x1="179.413" y1="51.904" x2="179.413" y2="26.354" width="0.6096" layer="16"/>
<wire x1="179.413" y1="26.354" x2="177.448" y2="24.389" width="0.6096" layer="16"/>
<wire x1="177.448" y1="24.389" x2="175.188" y2="24.389" width="0.6096" layer="16"/>
<wire x1="175.188" y1="24.389" x2="174.893" y2="24.094" width="0.6096" layer="16"/>
</signal>
<signal name="S$285">
<wire x1="172.142" y1="24.094" x2="137.357" y2="24.094" width="0.6096" layer="16"/>
<wire x1="137.357" y1="24.094" x2="137.259" y2="24.192" width="0.6096" layer="16"/>
</signal>
<signal name="S$288">
<wire x1="147.575" y1="54.164" x2="147.575" y2="57.714" width="0.6096" layer="16"/>
<wire x1="147.575" y1="57.714" x2="146.722" y2="58.567" width="0.6096" layer="16"/>
<wire x1="146.722" y1="58.567" x2="146.485" y2="58.567" width="0.6096" layer="16"/>
<wire x1="146.722" y1="58.567" x2="146.723" y2="58.567" width="0.6096" layer="16"/>
<wire x1="146.723" y1="58.567" x2="146.77" y2="58.614" width="0.6096" layer="16"/>
</signal>
<signal name="S$289">
<wire x1="144.591" y1="54.448" x2="144.591" y2="56.247" width="0.6096" layer="16"/>
<wire x1="144.591" y1="56.247" x2="145.207" y2="56.863" width="0.6096" layer="16"/>
</signal>
<signal name="S$290">
<wire x1="145.017" y1="49.287" x2="145.017" y2="51.087" width="0.6096" layer="16"/>
<wire x1="145.017" y1="51.087" x2="144.97" y2="51.134" width="0.6096" layer="16"/>
</signal>
<signal name="S$291">
<wire x1="147.527" y1="51.181" x2="147.527" y2="49.571" width="0.6096" layer="16"/>
<wire x1="147.527" y1="49.571" x2="147.433" y2="49.477" width="0.6096" layer="16"/>
</signal>
<signal name="S$292">
<wire x1="144.97" y1="43.227" x2="144.97" y2="45.973" width="0.6096" layer="16"/>
<wire x1="144.97" y1="45.973" x2="145.017" y2="46.02" width="0.6096" layer="16"/>
</signal>
<signal name="S$293">
<wire x1="147.19" y1="45.926" x2="147.19" y2="44.931" width="0.6096" layer="16"/>
<wire x1="147.19" y1="44.931" x2="146.575" y2="44.316" width="0.6096" layer="16"/>
<wire x1="146.575" y1="44.316" x2="146.575" y2="29.355" width="0.6096" layer="16"/>
<wire x1="146.575" y1="29.355" x2="146.527" y2="29.307" width="0.6096" layer="16"/>
</signal>
<signal name="S$294">
<wire x1="137.379" y1="34.511" x2="138.461" y2="34.511" width="0.6096" layer="16"/>
<wire x1="138.461" y1="34.511" x2="140.426" y2="36.476" width="0.6096" layer="16"/>
<wire x1="140.426" y1="36.476" x2="140.426" y2="57.505" width="0.6096" layer="16"/>
<wire x1="140.426" y1="57.505" x2="140.229" y2="57.702" width="0.6096" layer="16"/>
</signal>
<signal name="S$295">
<wire x1="140.426" y1="61.142" x2="140.426" y2="63.008" width="0.6096" layer="16"/>
<wire x1="140.426" y1="63.008" x2="139.148" y2="64.286" width="0.6096" layer="16"/>
<wire x1="139.148" y1="64.286" x2="137.281" y2="64.286" width="0.6096" layer="16"/>
</signal>
<signal name="S$296">
<wire x1="151.614" y1="51.83" x2="150.727" y2="51.83" width="0.6096" layer="16"/>
<wire x1="150.727" y1="51.83" x2="149.704" y2="52.853" width="0.6096" layer="16"/>
<wire x1="149.704" y1="52.853" x2="140.495" y2="52.853" width="0.6096" layer="16"/>
<wire x1="140.495" y1="52.853" x2="140.427" y2="52.921" width="0.6096" layer="16"/>
</signal>
<signal name="S$297">
<wire x1="137.535" y1="24.389" x2="137.594" y2="24.389" width="0.6096" layer="16"/>
<wire x1="137.594" y1="24.389" x2="140.378" y2="27.173" width="0.6096" layer="16"/>
</signal>
<signal name="S$298">
<wire x1="140.719" y1="30.469" x2="140.719" y2="34.729" width="0.6096" layer="16"/>
<wire x1="140.719" y1="34.729" x2="142.14" y2="36.15" width="0.6096" layer="16"/>
<wire x1="142.14" y1="36.15" x2="142.14" y2="46.997" width="0.6096" layer="16"/>
<wire x1="142.14" y1="46.997" x2="142.885" y2="47.742" width="0.6096" layer="16"/>
<wire x1="142.885" y1="47.742" x2="150.265" y2="47.742" width="0.6096" layer="16"/>
<wire x1="150.265" y1="47.742" x2="151.406" y2="48.883" width="0.6096" layer="16"/>
<wire x1="151.406" y1="48.883" x2="151.426" y2="48.883" width="0.6096" layer="16"/>
<wire x1="151.426" y1="48.883" x2="151.426" y2="48.923" width="0.6096" layer="16"/>
<wire x1="151.426" y1="48.923" x2="151.408" y2="48.941" width="0.6096" layer="16"/>
</signal>
<signal name="S$299">
<wire x1="137.402" y1="39.354" x2="137.976" y2="39.354" width="0.6096" layer="16"/>
<wire x1="137.976" y1="39.354" x2="139.203" y2="40.581" width="0.6096" layer="16"/>
<wire x1="139.203" y1="40.581" x2="139.203" y2="55.559" width="0.6096" layer="16"/>
<wire x1="139.203" y1="55.559" x2="138.221" y2="56.541" width="0.6096" layer="16"/>
<wire x1="138.221" y1="56.541" x2="131.426" y2="56.541" width="0.6096" layer="16"/>
<wire x1="131.426" y1="56.541" x2="128.561" y2="59.406" width="0.6096" layer="16"/>
</signal>
<signal name="S$300">
<wire x1="128.642" y1="59.306" x2="128.642" y2="74.467" width="0.6096" layer="16"/>
<wire x1="128.642" y1="74.467" x2="131.112" y2="76.937" width="0.6096" layer="16"/>
<wire x1="131.112" y1="76.937" x2="138.6" y2="76.937" width="0.6096" layer="16"/>
<wire x1="138.6" y1="76.937" x2="140.635" y2="74.902" width="0.6096" layer="16"/>
<wire x1="140.635" y1="74.902" x2="140.635" y2="70.594" width="0.6096" layer="16"/>
<wire x1="140.635" y1="70.594" x2="139.545" y2="69.504" width="0.6096" layer="16"/>
<wire x1="139.545" y1="69.504" x2="137.744" y2="69.504" width="0.6096" layer="16"/>
<wire x1="137.744" y1="69.504" x2="137.697" y2="69.457" width="0.6096" layer="16"/>
</signal>
<signal name="S$301">
<wire x1="151.389" y1="54.353" x2="150.441" y2="54.353" width="0.6096" layer="16"/>
<wire x1="150.441" y1="54.353" x2="149.352" y2="55.442" width="0.6096" layer="16"/>
<wire x1="149.352" y1="55.442" x2="149.352" y2="60.791" width="0.6096" layer="16"/>
<wire x1="149.352" y1="60.791" x2="147.836" y2="62.307" width="0.6096" layer="16"/>
<wire x1="149.234" y1="60.91" x2="147.718" y2="62.426" width="0.6096" layer="16"/>
<wire x1="149.352" y1="60.791" x2="149.234" y2="60.91" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="S$302">
<wire x1="144.567" y1="62.97" x2="144.567" y2="64.767" width="0.6096" layer="16"/>
<wire x1="144.567" y1="64.767" x2="139.735" y2="69.599" width="0.6096" layer="16"/>
</signal>
<signal name="S$303">
<wire x1="133.935" y1="49.786" x2="133.825" y2="49.786" width="0.6096" layer="16"/>
<wire x1="133.825" y1="49.786" x2="131.798" y2="51.813" width="0.6096" layer="16"/>
</signal>
<signal name="S$304">
<wire x1="133.956" y1="79.597" x2="131.634" y2="79.597" width="0.6096" layer="16"/>
<wire x1="131.634" y1="79.597" x2="127.263" y2="75.226" width="0.6096" layer="16"/>
<wire x1="127.263" y1="75.226" x2="127.263" y2="56.249" width="0.6096" layer="16"/>
<wire x1="127.263" y1="56.249" x2="128.96" y2="54.552" width="0.6096" layer="16"/>
</signal>
<signal name="S$305">
<wire x1="151.501" y1="56.919" x2="150.988" y2="56.919" width="0.6096" layer="16"/>
<wire x1="150.988" y1="56.919" x2="150.317" y2="57.59" width="0.6096" layer="16"/>
<wire x1="150.317" y1="57.59" x2="150.317" y2="65.283" width="0.6096" layer="16"/>
<wire x1="150.317" y1="65.283" x2="148.778" y2="66.822" width="0.6096" layer="16"/>
</signal>
<signal name="S$306">
<wire x1="137.298" y1="79.305" x2="138.436" y2="79.305" width="0.6096" layer="16"/>
<wire x1="138.436" y1="79.305" x2="142.319" y2="75.422" width="0.6096" layer="16"/>
<wire x1="142.319" y1="75.422" x2="142.319" y2="73.292" width="0.6096" layer="16"/>
<wire x1="142.319" y1="73.292" x2="146.06" y2="69.551" width="0.6096" layer="16"/>
</signal>
<signal name="S$308">
<wire x1="171.913" y1="69.298" x2="171.423" y2="69.298" width="0.6096" layer="16"/>
<wire x1="171.423" y1="69.298" x2="169.163" y2="71.558" width="0.6096" layer="16"/>
<wire x1="169.163" y1="71.558" x2="169.163" y2="75.194" width="0.6096" layer="16"/>
<wire x1="169.163" y1="75.194" x2="170.735" y2="76.766" width="0.6096" layer="16"/>
<wire x1="170.735" y1="76.766" x2="177.709" y2="76.766" width="0.6096" layer="16"/>
<wire x1="177.709" y1="76.766" x2="179.477" y2="74.998" width="0.6096" layer="16"/>
<wire x1="179.477" y1="74.998" x2="179.477" y2="58.782" width="0.6096" layer="16"/>
<wire x1="179.477" y1="58.782" x2="178.004" y2="57.309" width="0.6096" layer="16"/>
<wire x1="178.004" y1="57.309" x2="177.827" y2="57.309" width="0.6096" layer="16"/>
<wire x1="177.827" y1="57.309" x2="177.57" y2="57.052" width="0.6096" layer="16"/>
<wire x1="177.57" y1="57.052" x2="170.514" y2="57.052" width="0.6096" layer="16"/>
<wire x1="170.514" y1="57.052" x2="168.147" y2="54.685" width="0.6096" layer="16"/>
<wire x1="168.147" y1="54.685" x2="168.147" y2="52.412" width="0.6096" layer="16"/>
</signal>
<signal name="S$309">
<wire x1="171.569" y1="39.503" x2="168.199" y2="42.873" width="0.6096" layer="16"/>
<wire x1="168.199" y1="42.873" x2="168.199" y2="52.512" width="0.6096" layer="16"/>
<wire x1="168.199" y1="52.512" x2="168.199" y2="52.648" width="0.6096" layer="16"/>
<wire x1="168.199" y1="52.648" x2="168.267" y2="52.58" width="0.6096" layer="16"/>
<wire x1="168.267" y1="52.58" x2="168.267" y2="52.512" width="0.6096" layer="16"/>
<wire x1="168.267" y1="52.512" x2="168.199" y2="52.512" width="0.6096" layer="16"/>
</signal>
<signal name="S$310">
<wire x1="171.589" y1="49.332" x2="169.544" y2="51.377" width="0.6096" layer="16"/>
<wire x1="169.544" y1="51.377" x2="169.544" y2="54.446" width="0.6096" layer="16"/>
<wire x1="169.544" y1="54.446" x2="171.249" y2="56.151" width="0.6096" layer="16"/>
<wire x1="171.249" y1="56.151" x2="171.249" y2="56.207" width="0.6096" layer="16"/>
<wire x1="171.249" y1="56.207" x2="171.362" y2="56.094" width="0.6096" layer="16"/>
<wire x1="171.362" y1="56.094" x2="178.351" y2="56.094" width="0.6096" layer="16"/>
<wire x1="178.351" y1="56.094" x2="181.105" y2="58.848" width="0.6096" layer="16"/>
<wire x1="181.105" y1="58.848" x2="181.105" y2="77.084" width="0.6096" layer="16"/>
<wire x1="181.105" y1="77.084" x2="179.141" y2="79.048" width="0.6096" layer="16"/>
<wire x1="179.141" y1="79.048" x2="175.212" y2="79.048" width="0.6096" layer="16"/>
</signal>
<signal name="S$355">
<wire x1="148.765" y1="67.571" x2="148.935" y2="67.401" width="0.6096" layer="16"/>
</signal>
<signal name="S$311">
<wire x1="159.62" y1="67.401" x2="159.563" y2="67.344" width="0.6096" layer="16"/>
<wire x1="159.563" y1="67.344" x2="159.45" y2="67.344" width="0.6096" layer="16"/>
<wire x1="159.45" y1="67.344" x2="159.564" y2="67.458" width="0.6096" layer="16"/>
<wire x1="159.564" y1="67.458" x2="159.564" y2="67.685" width="0.6096" layer="16"/>
</signal>
<signal name="S$312">
<wire x1="171.897" y1="79.162" x2="170.588" y2="79.162" width="0.6096" layer="16"/>
<wire x1="170.588" y1="79.162" x2="167.52" y2="76.094" width="0.6096" layer="16"/>
<wire x1="167.52" y1="76.094" x2="167.52" y2="71.094" width="0.6096" layer="16"/>
<wire x1="167.52" y1="71.094" x2="166.384" y2="69.958" width="0.6096" layer="16"/>
<wire x1="166.384" y1="69.958" x2="161.95" y2="69.958" width="0.6096" layer="16"/>
<wire x1="161.95" y1="69.958" x2="161.894" y2="70.014" width="0.6096" layer="16"/>
</signal>
<signal name="S$322">
<wire x1="152.347" y1="54.908" x2="152.456" y2="54.908" width="0.4064" layer="16"/>
</signal>
<signal name="S$314">
<wire x1="171.354" y1="69.544" x2="168.63" y2="69.544" width="0.6096" layer="16"/>
<wire x1="168.63" y1="69.544" x2="167.249" y2="68.163" width="0.6096" layer="16"/>
<wire x1="167.249" y1="68.163" x2="167.249" y2="60.984" width="0.6096" layer="16"/>
<wire x1="167.249" y1="60.984" x2="167.368" y2="60.865" width="0.6096" layer="16"/>
<wire x1="167.17" y1="68.084" x2="167.17" y2="60.905" width="0.6096" layer="16"/>
<wire x1="167.17" y1="68.084" x2="167.249" y2="68.163" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="S$315">
<wire x1="148.496" y1="31.919" x2="149.725" y2="31.919" width="0.6096" layer="16"/>
<wire x1="149.725" y1="31.919" x2="150.885" y2="33.079" width="0.6096" layer="16"/>
</signal>
<signal name="S$316">
<wire x1="148.155" y1="34.94" x2="148.155" y2="35.542" width="0.6096" layer="16"/>
<wire x1="148.155" y1="35.542" x2="149.114" y2="36.501" width="0.6096" layer="16"/>
</signal>
<signal name="S$317">
<wire x1="142.648" y1="33.379" x2="143.854" y2="33.379" width="0.6096" layer="16"/>
<wire x1="143.854" y1="33.379" x2="144.895" y2="34.42" width="0.6096" layer="16"/>
</signal>
<signal name="S$318">
<wire x1="139.278" y1="33.215" x2="138.73" y2="33.215" width="0.6096" layer="16"/>
<wire x1="138.73" y1="33.215" x2="137.744" y2="34.201" width="0.6096" layer="16"/>
</signal>
<signal name="S$319">
<wire x1="162.704" y1="34.036" x2="153.58" y2="34.036" width="0.6096" layer="16"/>
<wire x1="153.58" y1="34.036" x2="152.539" y2="35.077" width="0.6096" layer="16"/>
<wire x1="152.539" y1="35.077" x2="152.539" y2="36.064" width="0.6096" layer="16"/>
<wire x1="152.539" y1="36.064" x2="152.43" y2="36.173" width="0.6096" layer="16"/>
</signal>
<signal name="S$320">
<wire x1="166.047" y1="34.201" x2="171.691" y2="34.201" width="0.6096" layer="16"/>
<wire x1="171.691" y1="34.201" x2="171.773" y2="34.283" width="0.6096" layer="16"/>
</signal>
<signal name="S$324">
<wire x1="155.358" y1="54.105" x2="155.245" y2="53.992" width="0.6096" layer="16"/>
</signal>
<signal name="S$313">
<wire x1="152.265" y1="54.826" x2="152.265" y2="54.881" width="0.4064" layer="16"/>
<wire x1="152.265" y1="54.881" x2="152.895" y2="55.511" width="0.4064" layer="16"/>
<wire x1="152.895" y1="55.511" x2="161.362" y2="55.511" width="0.4064" layer="16"/>
<wire x1="161.362" y1="55.511" x2="162.677" y2="54.196" width="0.4064" layer="16"/>
<wire x1="162.677" y1="54.196" x2="166.238" y2="54.196" width="0.4064" layer="16"/>
<wire x1="166.238" y1="54.196" x2="167.115" y2="55.073" width="0.4064" layer="16"/>
<wire x1="167.115" y1="55.073" x2="167.115" y2="57.565" width="0.4064" layer="16"/>
</signal>
<signal name="S$323">
<wire x1="165.17" y1="55.675" x2="165.17" y2="57.374" width="0.4064" layer="16"/>
<wire x1="165.17" y1="57.374" x2="164.951" y2="57.593" width="0.4064" layer="16"/>
</signal>
<signal name="S$321">
<wire x1="164.642" y1="29.503" x2="164.642" y2="32.117" width="0.6096" layer="16"/>
<wire x1="164.642" y1="32.117" x2="164.472" y2="32.287" width="0.6096" layer="16"/>
<wire x1="164.472" y1="32.287" x2="164.472" y2="35.923" width="0.6096" layer="16"/>
<wire x1="164.472" y1="35.923" x2="163.108" y2="37.287" width="0.6096" layer="16"/>
<wire x1="163.108" y1="37.287" x2="159.752" y2="37.287" width="0.6096" layer="16"/>
<wire x1="159.752" y1="37.287" x2="158.048" y2="38.991" width="0.6096" layer="16"/>
<wire x1="158.048" y1="38.991" x2="158.048" y2="52.628" width="0.6096" layer="16"/>
<wire x1="158.048" y1="52.628" x2="156.457" y2="54.219" width="0.6096" layer="16"/>
<wire x1="156.457" y1="54.219" x2="155.263" y2="54.219" width="0.6096" layer="16"/>
<wire x1="155.263" y1="54.219" x2="155.206" y2="54.276" width="0.6096" layer="16"/>
</signal>
<signal name="S$325">
<wire x1="165.836" y1="34.73" x2="165.836" y2="50.185" width="0.6096" layer="16"/>
<wire x1="165.836" y1="50.185" x2="164.927" y2="51.094" width="0.6096" layer="16"/>
<wire x1="164.927" y1="51.094" x2="164.927" y2="52.23" width="0.6096" layer="16"/>
</signal>
<signal name="S$326">
<wire x1="165.4" y1="63.769" x2="164.798" y2="63.167" width="0.6096" layer="16"/>
<wire x1="164.798" y1="63.167" x2="164.798" y2="61.091" width="0.6096" layer="16"/>
</signal>
<signal name="S$327">
<wire x1="171.36" y1="64.387" x2="171.233" y2="64.26" width="0.6096" layer="16"/>
<wire x1="171.233" y1="64.26" x2="169.331" y2="64.26" width="0.6096" layer="16"/>
</signal>
<signal name="S$228">
<wire x1="125.641" y1="15.111" x2="184.045" y2="15.111" width="0.6096" layer="16"/>
<wire x1="184.045" y1="15.111" x2="184.045" y2="88.691" width="0.6096" layer="16"/>
<wire x1="184.045" y1="88.691" x2="125.641" y2="88.691" width="0.6096" layer="16"/>
<wire x1="125.641" y1="88.691" x2="125.641" y2="14.941" width="0.6096" layer="16"/>
</signal>
<signal name="S$233">
<wire x1="77.522" y1="113.87" x2="77.601" y2="113.791" width="0" layer="19" extent="16-16"/>
</signal>
<signal name="S$372">
<wire x1="24.493" y1="139.223" x2="24.549" y2="96.995" width="0.6096" layer="16"/>
<wire x1="24.549" y1="96.995" x2="110.357" y2="96.995" width="0.6096" layer="16"/>
<wire x1="110.357" y1="96.995" x2="110.191" y2="138.952" width="0.6096" layer="16"/>
<wire x1="110.191" y1="138.952" x2="24.213" y2="139.007" width="0.6096" layer="16"/>
</signal>
<signal name="S$140">
<wire x1="59.819" y1="63.244" x2="59.819" y2="66.461" width="0.4064" layer="1"/>
<wire x1="59.819" y1="66.461" x2="61.334" y2="67.976" width="0.4064" layer="1"/>
<wire x1="61.334" y1="67.976" x2="61.334" y2="80.066" width="0.4064" layer="1"/>
</signal>
<signal name="S$230">
<wire x1="24.088" y1="67.874" x2="24.142" y2="67.928" width="0.4064" layer="1"/>
</signal>
<signal name="S$177">
<wire x1="55.794" y1="63.187" x2="55.794" y2="64.795" width="0.4064" layer="1"/>
<wire x1="55.794" y1="64.795" x2="54.894" y2="65.695" width="0.4064" layer="1"/>
<wire x1="54.894" y1="65.695" x2="52.417" y2="65.695" width="0.4064" layer="1"/>
<wire x1="52.417" y1="65.695" x2="48.43" y2="61.708" width="0.4064" layer="1"/>
<wire x1="48.43" y1="61.708" x2="48.334" y2="61.708" width="0.4064" layer="1"/>
<wire x1="48.334" y1="61.708" x2="47.819" y2="61.193" width="0.4064" layer="1"/>
</signal>
<signal name="S$175">
<wire x1="57.438" y1="63.283" x2="57.438" y2="66.659" width="0.4064" layer="1"/>
<wire x1="57.438" y1="66.659" x2="56.537" y2="67.56" width="0.4064" layer="1"/>
<wire x1="56.537" y1="67.56" x2="52.966" y2="67.56" width="0.4064" layer="1"/>
<wire x1="52.966" y1="67.56" x2="47.468" y2="62.062" width="0.4064" layer="1"/>
</signal>
<signal name="S$229">
<wire x1="27.182" y1="65.146" x2="27.127" y2="65.201" width="0.4064" layer="1"/>
</signal>
<signal name="S$173">
<wire x1="58.206" y1="63.251" x2="58.206" y2="67.11" width="0.4064" layer="1"/>
<wire x1="58.206" y1="67.11" x2="56.855" y2="68.461" width="0.4064" layer="1"/>
<wire x1="56.855" y1="68.461" x2="52.514" y2="68.461" width="0.4064" layer="1"/>
<wire x1="52.514" y1="68.461" x2="46.886" y2="62.833" width="0.4064" layer="1"/>
</signal>
<signal name="S$174">
<wire x1="59.034" y1="63.2" x2="59.034" y2="67.757" width="0.4064" layer="1"/>
<wire x1="59.034" y1="67.757" x2="57.255" y2="69.536" width="0.4064" layer="1"/>
<wire x1="57.255" y1="69.536" x2="51.973" y2="69.536" width="0.4064" layer="1"/>
<wire x1="51.973" y1="69.536" x2="46.582" y2="64.145" width="0.4064" layer="1"/>
</signal>
<signal name="S$181">
<wire x1="36.796" y1="52.916" x2="36.796" y2="52.983" width="0.4064" layer="1"/>
<wire x1="36.796" y1="52.983" x2="35.992" y2="53.787" width="0.4064" layer="1"/>
</signal>
<signal name="S$172">
<wire x1="52.795" y1="57.752" x2="22.619" y2="57.752" width="0.4064" layer="1"/>
<wire x1="22.619" y1="57.752" x2="21.118" y2="59.253" width="0.4064" layer="1"/>
<wire x1="21.118" y1="59.253" x2="21.118" y2="72.649" width="0.4064" layer="1"/>
<wire x1="21.118" y1="72.649" x2="21.896" y2="73.427" width="0.4064" layer="1"/>
<wire x1="21.896" y1="73.427" x2="24.23" y2="73.427" width="0.4064" layer="1"/>
<wire x1="24.23" y1="73.427" x2="24.286" y2="73.483" width="0.4064" layer="1"/>
</signal>
<signal name="S$180">
<wire x1="52.684" y1="58.53" x2="23.064" y2="58.53" width="0.4064" layer="1"/>
<wire x1="23.064" y1="58.53" x2="21.952" y2="59.642" width="0.4064" layer="1"/>
<wire x1="21.952" y1="59.642" x2="21.952" y2="69.87" width="0.4064" layer="1"/>
<wire x1="21.952" y1="69.87" x2="22.619" y2="70.537" width="0.4064" layer="1"/>
<wire x1="22.619" y1="70.537" x2="24.064" y2="70.537" width="0.4064" layer="1"/>
<wire x1="24.064" y1="70.537" x2="24.119" y2="70.592" width="0.4064" layer="1"/>
</signal>
<signal name="S$231">
<wire x1="29.232" y1="59.309" x2="23.674" y2="59.309" width="0.4064" layer="1"/>
<wire x1="23.674" y1="59.309" x2="22.674" y2="60.309" width="0.4064" layer="1"/>
<wire x1="22.674" y1="60.309" x2="22.674" y2="67.368" width="0.4064" layer="1"/>
<wire x1="22.674" y1="67.368" x2="23.286" y2="67.98" width="0.4064" layer="1"/>
<wire x1="23.286" y1="67.98" x2="24.008" y2="67.98" width="0.4064" layer="1"/>
<wire x1="24.008" y1="67.98" x2="24.119" y2="67.869" width="0.4064" layer="1"/>
</signal>
<signal name="S$258">
<wire x1="30.288" y1="60.142" x2="25.342" y2="60.142" width="0.4064" layer="1"/>
<wire x1="25.342" y1="60.142" x2="24.397" y2="61.087" width="0.4064" layer="1"/>
<wire x1="24.397" y1="61.087" x2="24.397" y2="65.145" width="0.4064" layer="1"/>
</signal>
<signal name="S$263">
<wire x1="47.794" y1="61.199" x2="28.009" y2="61.199" width="0.4064" layer="1"/>
<wire x1="28.009" y1="61.199" x2="27.176" y2="62.032" width="0.4064" layer="1"/>
<wire x1="27.176" y1="62.032" x2="27.176" y2="64.812" width="0.4064" layer="1"/>
<wire x1="27.176" y1="64.812" x2="27.342" y2="64.978" width="0.4064" layer="1"/>
</signal>
<signal name="S$268">
<wire x1="47.49" y1="62.004" x2="30.745" y2="62.004" width="0.4064" layer="1"/>
<wire x1="30.745" y1="62.004" x2="29.361" y2="63.388" width="0.4064" layer="1"/>
<wire x1="29.361" y1="63.388" x2="29.361" y2="67.317" width="0.4064" layer="1"/>
<wire x1="29.361" y1="67.317" x2="28.735" y2="67.943" width="0.4064" layer="1"/>
<wire x1="28.735" y1="67.943" x2="27.954" y2="67.943" width="0.4064" layer="1"/>
</signal>
<signal name="S$269">
<wire x1="46.865" y1="62.785" x2="31.526" y2="62.785" width="0.4064" layer="1"/>
<wire x1="31.526" y1="62.785" x2="30.365" y2="63.946" width="0.4064" layer="1"/>
<wire x1="30.365" y1="63.946" x2="30.365" y2="69.707" width="0.4064" layer="1"/>
<wire x1="30.365" y1="69.707" x2="29.517" y2="70.555" width="0.4064" layer="1"/>
<wire x1="29.517" y1="70.555" x2="27.909" y2="70.555" width="0.4064" layer="1"/>
<wire x1="27.909" y1="70.555" x2="27.775" y2="70.421" width="0.4064" layer="1"/>
</signal>
<signal name="S$273">
<wire x1="46.664" y1="64.17" x2="32.039" y2="64.17" width="0.4064" layer="1"/>
<wire x1="32.039" y1="64.17" x2="31.37" y2="64.839" width="0.4064" layer="1"/>
<wire x1="31.37" y1="64.839" x2="31.37" y2="72.118" width="0.4064" layer="1"/>
<wire x1="31.37" y1="72.118" x2="30.499" y2="72.989" width="0.4064" layer="1"/>
<wire x1="30.499" y1="72.989" x2="27.887" y2="72.989" width="0.4064" layer="1"/>
</signal>
<signal name="S$274">
<wire x1="57.112" y1="84.571" x2="30.201" y2="84.571" width="0.6096" layer="1"/>
<wire x1="30.201" y1="84.571" x2="24.839" y2="79.209" width="0.6096" layer="1"/>
<wire x1="24.839" y1="79.209" x2="24.839" y2="76.502" width="0.6096" layer="1"/>
<wire x1="24.839" y1="76.502" x2="24.732" y2="76.395" width="0.6096" layer="1"/>
</signal>
<signal name="S$275">
<wire x1="58.359" y1="79.691" x2="58.359" y2="79.101" width="0.6096" layer="1"/>
<wire x1="58.359" y1="79.101" x2="57.529" y2="78.271" width="0.6096" layer="1"/>
<wire x1="57.529" y1="78.271" x2="54.26" y2="78.271" width="0.6096" layer="1"/>
<wire x1="54.26" y1="78.271" x2="52.947" y2="79.584" width="0.6096" layer="1"/>
<wire x1="52.947" y1="79.584" x2="52.947" y2="82.505" width="0.6096" layer="1"/>
<wire x1="52.947" y1="82.505" x2="52.143" y2="83.309" width="0.6096" layer="1"/>
<wire x1="52.143" y1="83.309" x2="31.565" y2="83.309" width="0.6096" layer="1"/>
<wire x1="31.565" y1="83.309" x2="27.331" y2="79.075" width="0.6096" layer="1"/>
<wire x1="27.331" y1="79.075" x2="27.331" y2="76.342" width="0.6096" layer="1"/>
<wire x1="27.331" y1="76.342" x2="27.304" y2="76.315" width="0.6096" layer="1"/>
</signal>
<signal name="S$276">
<via x="56.156" y="66.154" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$277">
<via x="62.601" y="68.431" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$331">
<wire x1="56.63" y1="63.155" x2="56.63" y2="65.663" width="0.4064" layer="1"/>
<wire x1="56.63" y1="65.663" x2="56.373" y2="65.92" width="0.4064" layer="1"/>
</signal>
<signal name="S$332">
<wire x1="60.618" y1="63.219" x2="60.618" y2="65.471" width="0.4064" layer="1"/>
<wire x1="60.618" y1="65.471" x2="62.418" y2="67.271" width="0.4064" layer="1"/>
<wire x1="62.418" y1="67.271" x2="62.418" y2="67.914" width="0.4064" layer="1"/>
</signal>
<signal name="S$278">
<wire x1="38.863" y1="82.029" x2="38.77" y2="81.936" width="0.4064" layer="16"/>
</signal>
<signal name="S$307">
<wire x1="58.781" y1="79.806" x2="58.781" y2="79.575" width="0.4064" layer="16"/>
<wire x1="58.781" y1="79.575" x2="57.437" y2="78.231" width="0.4064" layer="16"/>
<wire x1="57.437" y1="78.231" x2="54.24" y2="78.231" width="0.4064" layer="16"/>
<wire x1="54.24" y1="78.231" x2="52.99" y2="79.481" width="0.4064" layer="16"/>
<wire x1="52.99" y1="79.481" x2="52.99" y2="82.354" width="0.4064" layer="16"/>
<wire x1="52.99" y1="82.354" x2="51.879" y2="83.465" width="0.4064" layer="16"/>
<wire x1="51.879" y1="83.465" x2="42.105" y2="83.465" width="0.4064" layer="16"/>
<wire x1="42.105" y1="83.465" x2="41.503" y2="82.863" width="0.4064" layer="16"/>
<wire x1="41.503" y1="82.863" x2="41.503" y2="82.029" width="0.4064" layer="16"/>
</signal>
<signal name="S$329">
<wire x1="62.671" y1="68.643" x2="62.671" y2="75.73" width="0.4064" layer="16"/>
<wire x1="62.671" y1="75.73" x2="61.467" y2="76.934" width="0.4064" layer="16"/>
<wire x1="61.467" y1="76.934" x2="53.639" y2="76.934" width="0.4064" layer="16"/>
<wire x1="53.639" y1="76.934" x2="51.508" y2="79.065" width="0.4064" layer="16"/>
<wire x1="51.508" y1="79.065" x2="51.508" y2="80.5" width="0.4064" layer="16"/>
<wire x1="51.508" y1="80.5" x2="50.813" y2="81.195" width="0.4064" layer="16"/>
<wire x1="50.813" y1="81.195" x2="47.201" y2="81.195" width="0.4064" layer="16"/>
<wire x1="47.201" y1="81.195" x2="47.108" y2="81.288" width="0.4064" layer="16"/>
</signal>
<signal name="S$333">
<wire x1="56.001" y1="66.512" x2="56.001" y2="75.128" width="0.4064" layer="16"/>
<wire x1="56.001" y1="75.128" x2="55.168" y2="75.961" width="0.4064" layer="16"/>
<wire x1="55.168" y1="75.961" x2="52.991" y2="75.961" width="0.4064" layer="16"/>
<wire x1="52.991" y1="75.961" x2="50.258" y2="78.694" width="0.4064" layer="16"/>
<wire x1="50.258" y1="78.694" x2="44.56" y2="78.694" width="0.4064" layer="16"/>
<wire x1="44.56" y1="78.694" x2="43.819" y2="79.435" width="0.4064" layer="16"/>
<wire x1="43.819" y1="79.435" x2="43.866" y2="79.435" width="0.4064" layer="16"/>
<wire x1="43.866" y1="79.435" x2="44.051" y2="79.62" width="0.4064" layer="16"/>
</signal>
<signal name="S$328">
<wire x1="56.109" y1="82.054" x2="56.109" y2="83.304" width="0.4064" layer="16"/>
<wire x1="56.109" y1="83.304" x2="54.836" y2="84.577" width="0.4064" layer="16"/>
<wire x1="54.836" y1="84.577" x2="39.699" y2="84.577" width="0.4064" layer="16"/>
<wire x1="39.699" y1="84.577" x2="39.051" y2="83.929" width="0.4064" layer="16"/>
<wire x1="39.051" y1="83.929" x2="39.051" y2="82.189" width="0.4064" layer="16"/>
<wire x1="39.051" y1="82.189" x2="39.028" y2="82.166" width="0.4064" layer="16"/>
</signal>
<signal name="S$330">
<wire x1="48.552" y1="109.875" x2="48.552" y2="129.256" width="0.8128" layer="16"/>
<wire x1="48.552" y1="129.256" x2="51.436" y2="132.14" width="0.8128" layer="16"/>
<wire x1="51.436" y1="132.14" x2="56.973" y2="132.14" width="0.8128" layer="16"/>
<wire x1="56.973" y1="132.14" x2="58.473" y2="130.64" width="0.8128" layer="16"/>
<wire x1="58.473" y1="130.64" x2="58.473" y2="129.14" width="0.8128" layer="16"/>
<wire x1="58.473" y1="129.14" x2="58.358" y2="129.025" width="0.8128" layer="16"/>
</signal>
<signal name="S$334">
<wire x1="38.054" y1="109.991" x2="38.054" y2="115.297" width="0.8128" layer="16"/>
<wire x1="38.054" y1="115.297" x2="38.977" y2="116.22" width="0.8128" layer="16"/>
<wire x1="38.977" y1="116.22" x2="38.977" y2="130.871" width="0.8128" layer="16"/>
<wire x1="38.977" y1="130.871" x2="42.438" y2="134.332" width="0.8128" layer="16"/>
<wire x1="42.438" y1="134.332" x2="58.935" y2="134.332" width="0.8128" layer="16"/>
<wire x1="58.935" y1="134.332" x2="63.665" y2="129.602" width="0.8128" layer="16"/>
</signal>
<signal name="S$335">
<wire x1="58.212" y1="110.081" x2="58.212" y2="125.694" width="0.8128" layer="16"/>
<wire x1="58.212" y1="125.694" x2="58.452" y2="125.934" width="0.8128" layer="16"/>
</signal>
<signal name="S$336">
<wire x1="68.3" y1="109.761" x2="68.3" y2="115.285" width="0.8128" layer="16"/>
<wire x1="68.3" y1="115.285" x2="69.101" y2="116.086" width="0.8128" layer="16"/>
<wire x1="69.101" y1="116.086" x2="69.101" y2="117.686" width="0.8128" layer="16"/>
<wire x1="69.101" y1="117.686" x2="66.218" y2="120.569" width="0.8128" layer="16"/>
<wire x1="66.218" y1="120.569" x2="62.776" y2="120.569" width="0.8128" layer="16"/>
<wire x1="62.776" y1="120.569" x2="61.014" y2="122.331" width="0.8128" layer="16"/>
<wire x1="61.014" y1="122.331" x2="61.014" y2="125.774" width="0.8128" layer="16"/>
<wire x1="61.014" y1="125.774" x2="60.934" y2="125.854" width="0.8128" layer="16"/>
</signal>
<signal name="S$337">
<wire x1="78.228" y1="110.081" x2="78.228" y2="115.125" width="0.8128" layer="16"/>
<wire x1="78.228" y1="115.125" x2="79.269" y2="116.166" width="0.8128" layer="16"/>
<wire x1="79.269" y1="116.166" x2="79.269" y2="118.407" width="0.8128" layer="16"/>
<wire x1="79.269" y1="118.407" x2="75.826" y2="121.85" width="0.8128" layer="16"/>
<wire x1="75.826" y1="121.85" x2="65.498" y2="121.85" width="0.8128" layer="16"/>
<wire x1="65.498" y1="121.85" x2="63.736" y2="123.612" width="0.8128" layer="16"/>
<wire x1="63.736" y1="123.612" x2="63.736" y2="125.854" width="0.8128" layer="16"/>
<wire x1="63.736" y1="125.854" x2="63.576" y2="126.014" width="0.8128" layer="16"/>
</signal>
<signal name="S$338">
<wire x1="88.156" y1="109.52" x2="88.156" y2="114.884" width="0.8128" layer="16"/>
<wire x1="88.156" y1="114.884" x2="89.598" y2="116.326" width="0.8128" layer="16"/>
<wire x1="89.598" y1="116.326" x2="89.598" y2="120.409" width="0.8128" layer="16"/>
<wire x1="89.598" y1="120.409" x2="85.915" y2="124.092" width="0.8128" layer="16"/>
<wire x1="85.915" y1="124.092" x2="67.259" y2="124.092" width="0.8128" layer="16"/>
<wire x1="67.259" y1="124.092" x2="66.218" y2="125.133" width="0.8128" layer="16"/>
<wire x1="66.218" y1="125.133" x2="66.218" y2="125.934" width="0.8128" layer="16"/>
</signal>
<signal name="S$339">
<wire x1="69.317" y1="126.313" x2="88.7" y2="126.313" width="0.8128" layer="16"/>
<wire x1="88.7" y1="126.313" x2="93.197" y2="121.816" width="0.8128" layer="16"/>
<wire x1="93.197" y1="121.816" x2="93.197" y2="110.054" width="0.8128" layer="16"/>
<wire x1="93.197" y1="110.054" x2="93.428" y2="109.823" width="0.8128" layer="16"/>
</signal>
<signal name="S$340">
<wire x1="69.202" y1="128.85" x2="95.275" y2="128.85" width="0.8128" layer="16"/>
<wire x1="95.275" y1="128.85" x2="98.965" y2="125.16" width="0.8128" layer="16"/>
<wire x1="98.965" y1="125.16" x2="98.965" y2="109.592" width="0.8128" layer="16"/>
<wire x1="98.965" y1="109.592" x2="98.504" y2="109.131" width="0.8128" layer="16"/>
</signal>
<signal name="S$341">
<wire x1="33.67" y1="106.357" x2="33.67" y2="104.744" width="0.8128" layer="16"/>
<wire x1="33.67" y1="104.744" x2="35.632" y2="102.782" width="0.8128" layer="16"/>
<wire x1="35.632" y1="102.782" x2="51.437" y2="102.782" width="0.8128" layer="16"/>
<wire x1="51.437" y1="102.782" x2="53.167" y2="104.512" width="0.8128" layer="16"/>
<wire x1="53.167" y1="104.512" x2="53.167" y2="104.742" width="0.8128" layer="16"/>
<wire x1="53.167" y1="106.357" x2="53.167" y2="104.742" width="0.8128" layer="16"/>
<wire x1="53.167" y1="104.742" x2="55.012" y2="102.897" width="0.8128" layer="16"/>
<wire x1="55.012" y1="102.897" x2="72.201" y2="102.897" width="0.8128" layer="16"/>
<wire x1="72.201" y1="102.897" x2="73.47" y2="104.166" width="0.8128" layer="16"/>
<wire x1="73.47" y1="104.166" x2="73.47" y2="105.665" width="0.8128" layer="16"/>
<wire x1="73.47" y1="105.665" x2="73.586" y2="105.781" width="0.8128" layer="16"/>
<wire x1="73.586" y1="105.781" x2="73.586" y2="105.088" width="0.8128" layer="16"/>
<wire x1="73.586" y1="105.088" x2="75.431" y2="103.243" width="0.8128" layer="16"/>
<wire x1="75.431" y1="103.243" x2="91.929" y2="103.243" width="0.8128" layer="16"/>
<wire x1="91.929" y1="103.243" x2="93.313" y2="104.627" width="0.8128" layer="16"/>
<wire x1="93.313" y1="104.627" x2="93.313" y2="106.011" width="0.8128" layer="16"/>
</signal>
<signal name="S$342">
<wire x1="34.478" y1="115.604" x2="34.478" y2="110.513" width="0.8128" layer="16"/>
<wire x1="34.478" y1="110.513" x2="33.421" y2="109.456" width="0.8128" layer="16"/>
</signal>
<signal name="S$343">
<wire x1="54.282" y1="115.797" x2="53.033" y2="115.797" width="0.8128" layer="16"/>
<wire x1="53.033" y1="115.797" x2="52.744" y2="115.508" width="0.8128" layer="16"/>
<wire x1="52.744" y1="115.508" x2="52.744" y2="109.744" width="0.8128" layer="16"/>
<wire x1="52.744" y1="109.744" x2="53.128" y2="109.36" width="0.8128" layer="16"/>
</signal>
<signal name="S$344">
<wire x1="74.566" y1="115.604" x2="73.412" y2="115.604" width="0.8128" layer="16"/>
<wire x1="73.412" y1="115.604" x2="73.124" y2="115.316" width="0.8128" layer="16"/>
<wire x1="73.124" y1="115.316" x2="73.124" y2="109.936" width="0.8128" layer="16"/>
<wire x1="73.124" y1="109.936" x2="73.316" y2="109.744" width="0.8128" layer="16"/>
</signal>
<signal name="S$345">
<wire x1="63.415" y1="109.531" x2="63.415" y2="115.801" width="0.8128" layer="16"/>
<wire x1="63.415" y1="115.801" x2="64.005" y2="116.391" width="0.8128" layer="16"/>
<wire x1="64.005" y1="116.391" x2="64.005" y2="117.328" width="0.8128" layer="16"/>
<wire x1="64.005" y1="117.328" x2="61.968" y2="119.365" width="0.8128" layer="16"/>
<wire x1="61.968" y1="119.365" x2="60.146" y2="119.365" width="0.8128" layer="16"/>
<wire x1="60.146" y1="119.365" x2="60.119" y2="119.392" width="0.8128" layer="16"/>
</signal>
<signal name="S$346">
<wire x1="56.443" y1="119.605" x2="50.496" y2="119.605" width="0.8128" layer="16"/>
<wire x1="50.496" y1="119.605" x2="50.44" y2="119.661" width="0.8128" layer="16"/>
</signal>
<signal name="S$347">
<wire x1="43.047" y1="110.156" x2="43.047" y2="115.325" width="0.8128" layer="16"/>
<wire x1="43.047" y1="115.325" x2="44.159" y2="116.437" width="0.8128" layer="16"/>
<wire x1="44.159" y1="116.437" x2="44.159" y2="119.05" width="0.8128" layer="16"/>
<wire x1="44.159" y1="119.05" x2="45.048" y2="119.939" width="0.8128" layer="16"/>
<wire x1="45.048" y1="119.939" x2="46.993" y2="119.939" width="0.8128" layer="16"/>
<wire x1="46.993" y1="119.939" x2="47.049" y2="119.883" width="0.8128" layer="16"/>
</signal>
<signal name="S$348">
<wire x1="92.64" y1="124.355" x2="92.64" y2="127.637" width="0.8128" layer="16"/>
<wire x1="92.64" y1="127.637" x2="91.599" y2="128.678" width="0.8128" layer="16"/>
</signal>
<signal name="S$349">
<wire x1="87.916" y1="124.275" x2="88.397" y2="124.275" width="0.8128" layer="16"/>
<wire x1="88.397" y1="124.275" x2="90.398" y2="122.274" width="0.8128" layer="16"/>
<wire x1="88.397" y1="124.387" x2="90.398" y2="122.386" width="0.8128" layer="16"/>
</signal>
<signal name="S$350">
<wire x1="83.352" y1="109.385" x2="83.352" y2="115.389" width="0.8128" layer="16"/>
<wire x1="83.352" y1="115.389" x2="84.233" y2="116.27" width="0.8128" layer="16"/>
<wire x1="84.233" y1="116.27" x2="84.233" y2="120.432" width="0.8128" layer="16"/>
<wire x1="84.233" y1="120.432" x2="85.354" y2="121.553" width="0.8128" layer="16"/>
</signal>
<signal name="S$351">
<wire x1="45.673" y1="119.835" x2="45.673" y2="131.579" width="0.8128" layer="16"/>
<wire x1="45.673" y1="131.579" x2="46.473" y2="132.379" width="0.8128" layer="16"/>
</signal>
<signal name="S$352">
<wire x1="46.74" y1="135.981" x2="67.219" y2="135.981" width="0.8128" layer="16"/>
<wire x1="67.219" y1="135.981" x2="68.62" y2="134.58" width="0.8128" layer="16"/>
<wire x1="68.62" y1="134.58" x2="68.62" y2="129.309" width="0.8128" layer="16"/>
<wire x1="68.62" y1="129.309" x2="68.753" y2="129.176" width="0.8128" layer="16"/>
</signal>
<signal name="S$353">
<wire x1="86.272" y1="131.946" x2="81.717" y2="131.946" width="0.8128" layer="16"/>
<wire x1="81.717" y1="131.946" x2="81.181" y2="131.41" width="0.8128" layer="16"/>
<wire x1="81.181" y1="131.41" x2="81.181" y2="130.874" width="0.8128" layer="16"/>
</signal>
<signal name="S$354">
<wire x1="89.836" y1="128.972" x2="89.836" y2="131.49" width="0.8128" layer="16"/>
</signal>
<signal name="S$356">
<wire x1="161.928" y1="67.172" x2="161.928" y2="66.529" width="0.8128" layer="16"/>
<wire x1="161.928" y1="66.529" x2="159.677" y2="64.278" width="0.8128" layer="16"/>
<wire x1="159.677" y1="64.278" x2="159.677" y2="59.643" width="0.8128" layer="16"/>
<wire x1="159.677" y1="59.643" x2="159.623" y2="59.589" width="0.8128" layer="16"/>
</signal>
<signal name="S$357">
<wire x1="159.543" y1="67.279" x2="159.543" y2="66.69" width="0.6096" layer="16"/>
<wire x1="159.543" y1="66.69" x2="158.471" y2="65.618" width="0.6096" layer="16"/>
<wire x1="158.471" y1="65.618" x2="150.54" y2="65.618" width="0.6096" layer="16"/>
<wire x1="150.54" y1="65.618" x2="150.218" y2="65.296" width="0.6096" layer="16"/>
</signal>
<signal name="S$358">
<wire x1="151.916" y1="59.912" x2="151.916" y2="62.349" width="0.6096" layer="16"/>
<wire x1="151.916" y1="62.349" x2="153.312" y2="63.745" width="0.6096" layer="16"/>
</signal>
<signal name="S$359">
<wire x1="155.917" y1="67.652" x2="154.205" y2="67.652" width="0.6096" layer="16"/>
<wire x1="154.205" y1="67.652" x2="153.74" y2="67.187" width="0.6096" layer="16"/>
</signal>
<signal name="S$360">
<wire x1="155.601" y1="71.206" x2="154.001" y2="71.206" width="0.6096" layer="16"/>
<wire x1="154.001" y1="71.206" x2="153.424" y2="70.629" width="0.6096" layer="16"/>
<wire x1="153.424" y1="70.629" x2="153.424" y2="69.662" width="0.6096" layer="16"/>
</signal>
<signal name="S$361">
<wire x1="153.775" y1="41.96" x2="153.55" y2="41.735" width="0.6096" layer="16"/>
<wire x1="153.55" y1="41.735" x2="150.9" y2="41.709" width="0.6096" layer="16"/>
<wire x1="150.9" y1="41.709" x2="150.883" y2="41.597" width="0.6096" layer="16"/>
<wire x1="150.883" y1="41.597" x2="150.883" y2="33.172" width="0.6096" layer="16"/>
</signal>
<signal name="S$362">
<wire x1="20.172" y1="15.533" x2="113.009" y2="15.533" width="0.6096" layer="16"/>
<wire x1="113.009" y1="15.533" x2="113.009" y2="87.268" width="0.6096" layer="16"/>
<wire x1="113.009" y1="87.268" x2="20.151" y2="87.268" width="0.6096" layer="16"/>
<wire x1="20.151" y1="87.268" x2="20.151" y2="15.676" width="0.6096" layer="16"/>
</signal>
<signal name="S$106">
<wire x1="54.408" y1="40.955" x2="54.412" y2="37.291" width="0.4064" layer="16"/>
<wire x1="54.412" y1="37.291" x2="54.411" y2="42.207" width="0.4064" layer="16"/>
</signal>
<signal name="S$363">
<wire x1="56.962" y1="40.776" x2="57.088" y2="40.776" width="0.4064" layer="16"/>
<wire x1="57.088" y1="40.776" x2="57.088" y2="42.135" width="0.4064" layer="16"/>
</signal>
<signal name="S$364">
<wire x1="58.912" y1="37.199" x2="56.998" y2="37.199" width="0.4064" layer="16"/>
<wire x1="56.998" y1="37.199" x2="56.998" y2="38.081" width="0.4064" layer="16"/>
<wire x1="56.998" y1="38.081" x2="55.194" y2="35.285" width="0.4064" layer="16"/>
<wire x1="55.194" y1="35.285" x2="54.23" y2="35.245" width="0.4064" layer="16"/>
</signal>
<signal name="S$19">
<wire x1="49.04" y1="40.402" x2="48.817" y2="40.402" width="0.4064" layer="16"/>
<wire x1="48.817" y1="40.402" x2="48.817" y2="36.655" width="0.4064" layer="16"/>
<wire x1="48.817" y1="36.655" x2="50.672" y2="36.655" width="0.4064" layer="16"/>
<wire x1="50.672" y1="36.655" x2="50.672" y2="36.358" width="0.4064" layer="16"/>
</signal>
<signal name="S$35">
<wire x1="50.724" y1="35.028" x2="50.709" y2="36.358" width="0.6096" layer="16"/>
<wire x1="50.709" y1="36.358" x2="50.709" y2="36.321" width="0.6096" layer="16"/>
</signal>
<signal name="S$30">
<wire x1="27.527" y1="75.771" x2="30.206" y2="73.092" width="0.8128" layer="16"/>
<wire x1="30.206" y1="73.092" x2="30.206" y2="63.759" width="0.8128" layer="16"/>
<wire x1="30.206" y1="63.759" x2="29.005" y2="62.558" width="0.8128" layer="16"/>
<wire x1="29.005" y1="62.558" x2="29.005" y2="22.362" width="0.8128" layer="16"/>
<wire x1="29.005" y1="22.362" x2="30.668" y2="20.699" width="0.8128" layer="16"/>
<wire x1="30.668" y1="20.699" x2="36.303" y2="20.699" width="0.8128" layer="16"/>
<wire x1="36.303" y1="20.699" x2="39.628" y2="24.024" width="0.8128" layer="16"/>
<wire x1="39.628" y1="24.024" x2="39.628" y2="24.672" width="0.8128" layer="16"/>
<wire x1="39.628" y1="24.672" x2="39.72" y2="24.58" width="0.8128" layer="16"/>
<wire x1="39.72" y1="24.58" x2="39.721" y2="24.58" width="0.8128" layer="16"/>
</signal>
<signal name="S$366">
<wire x1="64.103" y1="32.131" x2="65.262" y2="30.972" width="0.8128" layer="1"/>
<wire x1="65.262" y1="30.972" x2="67.536" y2="30.972" width="0.8128" layer="1"/>
</signal>
<signal name="S$367">
<wire x1="68.38" y1="27.871" x2="66.421" y2="25.912" width="0.8128" layer="1"/>
<wire x1="66.421" y1="25.912" x2="43.094" y2="25.912" width="0.8128" layer="1"/>
<wire x1="43.094" y1="25.912" x2="43.049" y2="25.867" width="0.8128" layer="1"/>
<wire x1="43.049" y1="25.867" x2="43.049" y2="23.33" width="0.8128" layer="1"/>
<wire x1="43.049" y1="23.33" x2="40.289" y2="20.57" width="0.8128" layer="1"/>
<wire x1="40.289" y1="20.57" x2="30.985" y2="20.57" width="0.8128" layer="1"/>
<wire x1="30.985" y1="20.57" x2="28.981" y2="22.574" width="0.8128" layer="1"/>
<wire x1="28.981" y1="22.574" x2="28.981" y2="22.662" width="0.8128" layer="1"/>
<wire x1="28.981" y1="22.662" x2="27.344" y2="24.299" width="0.8128" layer="1"/>
<wire x1="27.344" y1="24.299" x2="27.344" y2="55.897" width="0.8128" layer="1"/>
</signal>
<signal name="S$368">
<via x="27.005" y="55.836" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$369">
<wire x1="24.56" y1="75.676" x2="22.38" y2="73.496" width="0.8128" layer="16"/>
<wire x1="22.38" y1="73.496" x2="22.38" y2="61.888" width="0.8128" layer="16"/>
<wire x1="22.38" y1="61.888" x2="26.997" y2="57.271" width="0.8128" layer="16"/>
<wire x1="26.997" y1="57.271" x2="26.997" y2="55.859" width="0.8128" layer="16"/>
</signal>
<signal name="S$370">
<via x="41.026" y="84.586" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$371">
<via x="42.108" y="83.246" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$373">
<wire x1="105.282" y1="65.068" x2="104.667" y2="65.068" width="0.8128" layer="16"/>
<wire x1="104.667" y1="65.068" x2="104.667" y2="59.601" width="0.8128" layer="16"/>
<wire x1="104.667" y1="59.601" x2="108.207" y2="59.601" width="0.8128" layer="16"/>
<wire x1="108.207" y1="59.601" x2="108.207" y2="59.37" width="0.8128" layer="16"/>
</signal>
<signal name="S$374">
<via x="86.237" y="53.267" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$375">
<via x="84.568" y="52.525" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$376">
<wire x1="86.639" y1="53.236" x2="107.719" y2="53.236" width="0.6096" layer="16"/>
<wire x1="107.719" y1="53.236" x2="107.719" y2="47.764" width="0.6096" layer="16"/>
</signal>
<signal name="S$377">
<wire x1="84.822" y1="52.243" x2="101.915" y2="52.243" width="0.6096" layer="16"/>
<wire x1="101.915" y1="52.243" x2="102.001" y2="47.795" width="0.6096" layer="16"/>
</signal>
<signal name="S$378">
<via x="102.032" y="47.795" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$379">
<via x="107.658" y="47.857" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$380">
<via x="104.474" y="54.411" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$381">
<via x="108.678" y="54.535" extent="1-16" drill="0.6"/>
</signal>
<signal name="S$382">
<wire x1="83.115" y1="54.133" x2="86.237" y2="54.133" width="0.6096" layer="1"/>
<wire x1="86.237" y1="54.133" x2="86.237" y2="53.824" width="0.6096" layer="1"/>
</signal>
<signal name="S$383">
<wire x1="83.239" y1="52.711" x2="84.29" y2="52.711" width="0.6096" layer="1"/>
</signal>
<signal name="S$384">
<wire x1="102.465" y1="47.734" x2="103.547" y2="47.734" width="0.6096" layer="1"/>
<wire x1="103.547" y1="47.734" x2="103.547" y2="47.795" width="0.6096" layer="1"/>
</signal>
<signal name="S$385">
<wire x1="107.936" y1="47.703" x2="109.172" y2="47.703" width="0.6096" layer="1"/>
<wire x1="109.172" y1="47.703" x2="109.172" y2="47.734" width="0.6096" layer="1"/>
</signal>
<signal name="S$386">
<wire x1="109.543" y1="51.196" x2="108.832" y2="51.196" width="0.6096" layer="1"/>
<wire x1="108.832" y1="51.196" x2="108.832" y2="54.102" width="0.6096" layer="1"/>
</signal>
<signal name="S$387">
<wire x1="104.35" y1="51.382" x2="104.536" y2="51.382" width="0.6096" layer="1"/>
<wire x1="104.536" y1="51.382" x2="104.536" y2="53.855" width="0.6096" layer="1"/>
</signal>
<signal name="S$388">
<wire x1="104.505" y1="54.751" x2="104.567" y2="54.751" width="0.6096" layer="16"/>
<wire x1="104.567" y1="54.751" x2="104.567" y2="55.957" width="0.6096" layer="16"/>
</signal>
<signal name="S$389">
<wire x1="108.77" y1="54.875" x2="108.708" y2="54.875" width="0.6096" layer="16"/>
<wire x1="108.708" y1="54.875" x2="108.708" y2="55.833" width="0.6096" layer="16"/>
</signal>
</signals>
</board>
</drawing>
</eagle>
