<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="7.7.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="2" name="Route2" color="1" fill="3" visible="yes" active="yes"/>
<layer number="3" name="Route3" color="4" fill="3" visible="no" active="yes"/>
<layer number="4" name="Route4" color="1" fill="4" visible="no" active="yes"/>
<layer number="5" name="Route5" color="4" fill="4" visible="no" active="yes"/>
<layer number="6" name="Route6" color="1" fill="8" visible="no" active="yes"/>
<layer number="7" name="Route7" color="4" fill="8" visible="no" active="yes"/>
<layer number="8" name="Route8" color="1" fill="2" visible="no" active="yes"/>
<layer number="9" name="Route9" color="4" fill="2" visible="no" active="yes"/>
<layer number="10" name="Route10" color="1" fill="7" visible="no" active="yes"/>
<layer number="11" name="Route11" color="4" fill="7" visible="no" active="yes"/>
<layer number="12" name="Route12" color="1" fill="5" visible="no" active="yes"/>
<layer number="13" name="Route13" color="4" fill="5" visible="no" active="yes"/>
<layer number="14" name="Route14" color="1" fill="6" visible="no" active="yes"/>
<layer number="15" name="Route15" color="4" fill="6" visible="no" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="yes" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="90" name="Modules" color="5" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<packages>
<package name="MM5450">
<smd name="P$1" x="9.11" y="-1.26" dx="0.66" dy="2.39" layer="1"/>
<smd name="P$2" x="7.84" y="-1.26" dx="0.66" dy="2.39" layer="1"/>
<smd name="P$3" x="6.57" y="-1.26" dx="0.66" dy="2.39" layer="1"/>
<smd name="P$4" x="5.3" y="-1.26" dx="0.66" dy="2.39" layer="1"/>
<smd name="P$5" x="4.03" y="-1.26" dx="0.66" dy="2.39" layer="1"/>
<smd name="P$6" x="2.76" y="-0.92" dx="0.66" dy="1.8" layer="1"/>
<smd name="P$7" x="0.94" y="-2.78" dx="0.66" dy="1.8" layer="1" rot="R90"/>
<smd name="P$8" x="1.23" y="-4.04" dx="0.66" dy="2.39" layer="1" rot="R90"/>
<smd name="P$9" x="1.23" y="-5.31" dx="0.66" dy="2.39" layer="1" rot="R90"/>
<smd name="P$10" x="1.23" y="-6.58" dx="0.66" dy="2.39" layer="1" rot="R90"/>
<smd name="P$11" x="1.23" y="-7.85" dx="0.66" dy="2.39" layer="1" rot="R90"/>
<smd name="P$12" x="1.23" y="-9.12" dx="0.66" dy="2.39" layer="1" rot="R90"/>
<smd name="P$13" x="1.23" y="-10.39" dx="0.66" dy="2.39" layer="1" rot="R90"/>
<smd name="P$14" x="1.23" y="-11.66" dx="0.66" dy="2.39" layer="1" rot="R90"/>
<smd name="P$15" x="1.23" y="-12.93" dx="0.66" dy="2.39" layer="1" rot="R90"/>
<smd name="P$16" x="1.23" y="-14.2" dx="0.66" dy="2.39" layer="1" rot="R90"/>
<smd name="P$17" x="0.94" y="-15.48" dx="0.66" dy="1.8" layer="1" rot="R90"/>
<smd name="P$18" x="2.77" y="-17.3" dx="0.66" dy="1.8" layer="1" rot="R180"/>
<smd name="P$19" x="4.04" y="-17.01" dx="0.66" dy="2.39" layer="1" rot="R180"/>
<smd name="P$20" x="5.31" y="-17.01" dx="0.66" dy="2.39" layer="1" rot="R180"/>
<smd name="P$21" x="6.58" y="-17.01" dx="0.66" dy="2.39" layer="1" rot="R180"/>
<smd name="P$22" x="7.85" y="-17.01" dx="0.66" dy="2.39" layer="1" rot="R180"/>
<smd name="P$23" x="9.12" y="-17.01" dx="0.66" dy="2.39" layer="1" rot="R180"/>
<smd name="P$24" x="10.39" y="-17.01" dx="0.66" dy="2.39" layer="1" rot="R180"/>
<smd name="P$25" x="11.66" y="-17.01" dx="0.66" dy="2.39" layer="1" rot="R180"/>
<smd name="P$26" x="12.93" y="-17.01" dx="0.66" dy="2.39" layer="1" rot="R180"/>
<smd name="P$27" x="14.2" y="-17.01" dx="0.66" dy="2.39" layer="1" rot="R180"/>
<smd name="P$28" x="15.48" y="-17.28" dx="0.66" dy="1.8" layer="1" rot="R180"/>
<smd name="P$29" x="17.24" y="-15.47" dx="0.66" dy="1.8" layer="1" rot="R270"/>
<smd name="P$30" x="16.92" y="-14.19" dx="0.66" dy="2.39" layer="1" rot="R270"/>
<smd name="P$31" x="16.92" y="-12.92" dx="0.66" dy="2.39" layer="1" rot="R270"/>
<smd name="P$32" x="16.92" y="-11.65" dx="0.66" dy="2.39" layer="1" rot="R270"/>
<smd name="P$33" x="16.92" y="-10.38" dx="0.66" dy="2.39" layer="1" rot="R270"/>
<smd name="P$34" x="16.92" y="-9.11" dx="0.66" dy="2.39" layer="1" rot="R270"/>
<smd name="P$35" x="16.92" y="-7.84" dx="0.66" dy="2.39" layer="1" rot="R270"/>
<smd name="P$36" x="16.92" y="-6.57" dx="0.66" dy="2.39" layer="1" rot="R270"/>
<smd name="P$37" x="16.92" y="-5.3" dx="0.66" dy="2.39" layer="1" rot="R270"/>
<smd name="P$38" x="16.92" y="-4.03" dx="0.66" dy="2.39" layer="1" rot="R270"/>
<smd name="P$39" x="17.15" y="-2.76" dx="0.66" dy="1.8" layer="1" rot="R270"/>
<smd name="P$40" x="15.46" y="-0.96" dx="0.66" dy="1.8" layer="1"/>
<smd name="P$41" x="14.19" y="-1.26" dx="0.66" dy="2.39" layer="1"/>
<smd name="P$42" x="12.92" y="-1.26" dx="0.66" dy="2.39" layer="1"/>
<smd name="P$43" x="11.65" y="-1.26" dx="0.66" dy="2.39" layer="1"/>
<smd name="P$44" x="10.38" y="-1.26" dx="0.66" dy="2.39" layer="1"/>
<wire x1="2.54" y1="-1.27" x2="1.27" y2="-2.54" width="0.127" layer="21"/>
<wire x1="1.27" y1="-2.54" x2="1.27" y2="-16.51" width="0.127" layer="21"/>
<wire x1="1.27" y1="-16.51" x2="16.51" y2="-16.51" width="0.127" layer="21"/>
<wire x1="16.51" y1="-16.51" x2="16.51" y2="-1.27" width="0.127" layer="21"/>
<wire x1="16.51" y1="-1.27" x2="2.54" y2="-1.27" width="0.127" layer="21"/>
</package>
</packages>
<symbols>
<symbol name="MM5450">
<pin name="P$1" x="0" y="20.32" visible="off" length="middle" rot="R270"/>
<pin name="P$2" x="-2.54" y="20.32" visible="off" length="middle" rot="R270"/>
<pin name="P$3" x="-5.08" y="20.32" visible="off" length="middle" rot="R270"/>
<pin name="P$4" x="-7.62" y="20.32" visible="off" length="middle" rot="R270"/>
<pin name="P$5" x="-10.16" y="20.32" visible="off" length="middle" rot="R270"/>
<pin name="P$6" x="-12.7" y="20.32" visible="off" length="middle" rot="R270"/>
<pin name="P$7" x="-17.78" y="12.7" visible="off" length="middle"/>
<pin name="P$8" x="-17.78" y="10.16" visible="off" length="middle"/>
<pin name="P$9" x="-17.78" y="7.62" visible="off" length="middle"/>
<pin name="P$10" x="-17.78" y="5.08" visible="off" length="middle"/>
<pin name="P$11" x="-17.78" y="2.54" visible="off" length="middle"/>
<pin name="P$12" x="-17.78" y="0" visible="off" length="middle"/>
<pin name="P$13" x="-17.78" y="-2.54" visible="off" length="middle"/>
<pin name="P$14" x="-17.78" y="-5.08" visible="off" length="middle"/>
<pin name="P$15" x="-17.78" y="-7.62" visible="off" length="middle"/>
<pin name="P$16" x="-17.78" y="-10.16" visible="off" length="middle"/>
<pin name="P$17" x="-17.78" y="-12.7" visible="off" length="middle"/>
<pin name="P$18" x="-12.7" y="-20.32" visible="off" length="middle" rot="R90"/>
<pin name="P$19" x="-10.16" y="-20.32" visible="off" length="middle" rot="R90"/>
<pin name="P$20" x="-7.62" y="-20.32" visible="off" length="middle" rot="R90"/>
<pin name="P$21" x="-5.08" y="-20.32" visible="off" length="middle" rot="R90"/>
<pin name="P$22" x="-2.54" y="-20.32" visible="off" length="middle" rot="R90"/>
<pin name="P$23" x="0" y="-20.32" visible="off" length="middle" rot="R90"/>
<pin name="P$24" x="2.54" y="-20.32" visible="off" length="middle" rot="R90"/>
<pin name="P$25" x="5.08" y="-20.32" visible="off" length="middle" rot="R90"/>
<pin name="P$26" x="7.62" y="-20.32" visible="off" length="middle" rot="R90"/>
<pin name="P$27" x="10.16" y="-20.32" visible="off" length="middle" rot="R90"/>
<pin name="P$28" x="12.7" y="-20.32" visible="off" length="middle" rot="R90"/>
<pin name="P$29" x="17.78" y="-12.7" visible="off" length="middle" rot="R180"/>
<pin name="P$30" x="17.78" y="-10.16" visible="off" length="middle" rot="R180"/>
<pin name="P$31" x="17.78" y="-7.62" visible="off" length="middle" rot="R180"/>
<pin name="P$32" x="17.78" y="-5.08" visible="off" length="middle" rot="R180"/>
<pin name="P$33" x="17.78" y="-2.54" visible="off" length="middle" rot="R180"/>
<pin name="P$34" x="17.78" y="0" visible="off" length="middle" rot="R180"/>
<pin name="P$35" x="17.78" y="2.54" visible="off" length="middle" rot="R180"/>
<pin name="P$36" x="17.78" y="5.08" visible="off" length="middle" rot="R180"/>
<pin name="P$37" x="17.78" y="7.62" visible="off" length="middle" rot="R180"/>
<pin name="P$38" x="17.78" y="10.16" visible="off" length="middle" rot="R180"/>
<pin name="P$39" x="17.78" y="12.7" visible="off" length="middle" rot="R180"/>
<pin name="P$40" x="12.7" y="20.32" visible="off" length="middle" rot="R270"/>
<pin name="P$41" x="10.16" y="20.32" visible="off" length="middle" rot="R270"/>
<pin name="P$42" x="7.62" y="20.32" visible="off" length="middle" rot="R270"/>
<pin name="P$43" x="5.08" y="20.32" visible="off" length="middle" rot="R270"/>
<pin name="P$44" x="2.54" y="20.32" visible="off" length="middle" rot="R270"/>
<wire x1="-12.7" y1="15.24" x2="-12.7" y2="-15.24" width="0.254" layer="94"/>
<wire x1="-12.7" y1="-15.24" x2="12.7" y2="-15.24" width="0.254" layer="94"/>
<wire x1="12.7" y1="-15.24" x2="12.7" y2="15.24" width="0.254" layer="94"/>
<wire x1="12.7" y1="15.24" x2="-12.7" y2="15.24" width="0.254" layer="94"/>
<circle x="0" y="13.716" radius="0.567959375" width="0.254" layer="94"/>
<text x="-0.508" y="10.922" size="1.778" layer="94">1</text>
<text x="-12.192" y="11.684" size="1.778" layer="94">7</text>
<text x="-12.446" y="-13.462" size="1.778" layer="94">17</text>
<text x="9.652" y="-13.716" size="1.778" layer="94">29</text>
<text x="9.652" y="11.684" size="1.778" layer="94">39</text>
</symbol>
</symbols>
<devicesets>
<deviceset name="MM5450">
<gates>
<gate name="G$1" symbol="MM5450" x="0" y="0"/>
</gates>
<devices>
<device name="" package="MM5450">
<connects>
<connect gate="G$1" pin="P$1" pad="P$1"/>
<connect gate="G$1" pin="P$10" pad="P$10"/>
<connect gate="G$1" pin="P$11" pad="P$11"/>
<connect gate="G$1" pin="P$12" pad="P$12"/>
<connect gate="G$1" pin="P$13" pad="P$13"/>
<connect gate="G$1" pin="P$14" pad="P$14"/>
<connect gate="G$1" pin="P$15" pad="P$15"/>
<connect gate="G$1" pin="P$16" pad="P$16"/>
<connect gate="G$1" pin="P$17" pad="P$17"/>
<connect gate="G$1" pin="P$18" pad="P$18"/>
<connect gate="G$1" pin="P$19" pad="P$19"/>
<connect gate="G$1" pin="P$2" pad="P$2"/>
<connect gate="G$1" pin="P$20" pad="P$20"/>
<connect gate="G$1" pin="P$21" pad="P$21"/>
<connect gate="G$1" pin="P$22" pad="P$22"/>
<connect gate="G$1" pin="P$23" pad="P$23"/>
<connect gate="G$1" pin="P$24" pad="P$24"/>
<connect gate="G$1" pin="P$25" pad="P$25"/>
<connect gate="G$1" pin="P$26" pad="P$26"/>
<connect gate="G$1" pin="P$27" pad="P$27"/>
<connect gate="G$1" pin="P$28" pad="P$28"/>
<connect gate="G$1" pin="P$29" pad="P$29"/>
<connect gate="G$1" pin="P$3" pad="P$3"/>
<connect gate="G$1" pin="P$30" pad="P$30"/>
<connect gate="G$1" pin="P$31" pad="P$31"/>
<connect gate="G$1" pin="P$32" pad="P$32"/>
<connect gate="G$1" pin="P$33" pad="P$33"/>
<connect gate="G$1" pin="P$34" pad="P$34"/>
<connect gate="G$1" pin="P$35" pad="P$35"/>
<connect gate="G$1" pin="P$36" pad="P$36"/>
<connect gate="G$1" pin="P$37" pad="P$37"/>
<connect gate="G$1" pin="P$38" pad="P$38"/>
<connect gate="G$1" pin="P$39" pad="P$39"/>
<connect gate="G$1" pin="P$4" pad="P$4"/>
<connect gate="G$1" pin="P$40" pad="P$40"/>
<connect gate="G$1" pin="P$41" pad="P$41"/>
<connect gate="G$1" pin="P$42" pad="P$42"/>
<connect gate="G$1" pin="P$43" pad="P$43"/>
<connect gate="G$1" pin="P$44" pad="P$44"/>
<connect gate="G$1" pin="P$5" pad="P$5"/>
<connect gate="G$1" pin="P$6" pad="P$6"/>
<connect gate="G$1" pin="P$7" pad="P$7"/>
<connect gate="G$1" pin="P$8" pad="P$8"/>
<connect gate="G$1" pin="P$9" pad="P$9"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
