#ifndef _TFT_ILI9163C_USETT_H_
#define _TFT_ILI9163C_USETT_H_
//DID YOU HAVE A RED PCB, BLACk PCB or WHAT DISPLAY TYPE????????????
//  ---> SELECT HERE <----
#define __144_RED_PCB__//128x128
//#define __144_BLACK_PCB__//128x128
//#define __22_RED_PCB__//240x320
#if defined(__144_RED_PCB__)
This display:
http://www.ebay.com/itm/Replace-Nokia-5110-LCD-1-44-Red-Serial-128X128-SPI-Color-TFT-LCD-Display-Module-/271422122271
This particular display has a design error! The controller has 3 pins to configure to constrain
the memory and resolution to a fixed dimension (in that case 128x128) but they leaved those pins
configured for 128x160 so there was several pixel memory addressing problems.
I solved by setup several parameters that dinamically fix the resolution as needed so below
the parameters for this diplay. If you have a strain or a correct display (can happen with chinese)
you can copy those parameters and create setup for different displays.
	#define _TFTWIDTH  		128//the REAL W resolution of the TFT
	#define _TFTHEIGHT 		128//the REAL H resolution of the TFT
	#define _GRAMWIDTH      128
	#define _GRAMHEIGH      160//160
	#define _GRAMSIZE		_GRAMWIDTH * _GRAMHEIGH//*see note 1
	#define __COLORSPC		1// 1:GBR - 0:RGB
	#define __GAMMASET3		//uncomment for another gamma
	#define __OFFSET		1//*see note 2
	//Tested!
#elif defined (__144_BLACK_PCB__)
	#define _GRAMHEIGH      128
	#define __GAMMASET1		//uncomment for another gamma
	#define __OFFSET		32
	//not tested
#elif defined (__22_RED_PCB__)
Like this one:
http://www.ebay.it/itm/2-2-Serial-SPI-TFT-LCD-Display-Module-240x320-Chip-ILI9340C-PCB-Adapter-SD-Card-/281304733556
Not tested!
	#define _TFTWIDTH  		240//the REAL W resolution of the TFT
	#define _TFTHEIGHT 		320//the REAL H resolution of the TFT
	#define _GRAMWIDTH      240
	#define _GRAMHEIGH      320
	#define __OFFSET		0
#else
	#define _TFTWIDTH  		128//128
	#define _TFTHEIGHT 		160//160
	#define __GAMMASET1
	#define __OFFSET		0
#endif
	#if defined(__GAMMASET1)
		const uint8_t pGammaSet[15]= {0x36,0x29,0x12,0x22,0x1C,0x15,0x42,0xB7,0x2F,0x13,0x12,0x0A,0x11,0x0B,0x06};
		const uint8_t nGammaSet[15]= {0x09,0x16,0x2D,0x0D,0x13,0x15,0x40,0x48,0x53,0x0C,0x1D,0x25,0x2E,0x34,0x39};
	#elif defined(__GAMMASET2)
		const uint8_t pGammaSet[15]= {0x3F,0x21,0x12,0x22,0x1C,0x15,0x42,0xB7,0x2F,0x13,0x02,0x0A,0x01,0x00,0x00};
		const uint8_t nGammaSet[15]= {0x09,0x18,0x2D,0x0D,0x13,0x15,0x40,0x48,0x53,0x0C,0x1D,0x25,0x2E,0x24,0x29};
	#elif defined(__GAMMASET3)
		const uint8_t pGammaSet[15]= {0x3F,0x26,0x23,0x30,0x28,0x10,0x55,0xB7,0x40,0x19,0x10,0x1E,0x02,0x01,0x00};
	#else
		const uint8_t pGammaSet[15]= {0x3F,0x25,0x1C,0x1E,0x20,0x12,0x2A,0x90,0x24,0x11,0x00,0x00,0x00,0x00,0x00};
		const uint8_t nGammaSet[15]= {0x20,0x20,0x20,0x20,0x05,0x15,0x00,0xA7,0x3D,0x18,0x25,0x2A,0x2B,0x2B,0x3A};
	#endif
	Note 1: The __144_RED_PCB__ display has hardware addressing of 128 x 160
	but the tft resolution it's 128 x 128 so the dram should be set correctly
	Note 2: This is the offset between image in RAM and TFT. In that case 160 - 128 = 32;
#endif
Benchmark                Time (microseconds)
Screen fill              74698
Text                     4253
Text2                    15366
Lines                    16034
Horiz/Vert Lines         5028
Rectangles (outline)     4183
Rectangles (filled)      91226
Circles (filled)         14436
Circles (outline)        14910
Triangles (outline)      5069
Triangles (filled)       30717
Rounded rects (outline)  9910
Rounded rects (filled)   99550
Done!
