<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="7.2.0">
<drawing>
<settings>
<setting alwaysvectorfont="no"/>
<setting verticaltext="up"/>
</settings>
<grid distance="0.1" unitdist="inch" unit="inch" style="lines" multiple="1" display="no" altdistance="0.01" altunitdist="inch" altunit="inch"/>
<layers>
<layer number="1" name="Top" color="4" fill="1" visible="yes" active="yes"/>
<layer number="16" name="Bottom" color="1" fill="1" visible="yes" active="yes"/>
<layer number="17" name="Pads" color="2" fill="1" visible="yes" active="yes"/>
<layer number="18" name="Vias" color="2" fill="1" visible="yes" active="yes"/>
<layer number="19" name="Unrouted" color="6" fill="1" visible="yes" active="yes"/>
<layer number="20" name="Dimension" color="15" fill="1" visible="yes" active="yes"/>
<layer number="21" name="tPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="22" name="bPlace" color="7" fill="1" visible="yes" active="yes"/>
<layer number="23" name="tOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="24" name="bOrigins" color="15" fill="1" visible="yes" active="yes"/>
<layer number="25" name="tNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="26" name="bNames" color="7" fill="1" visible="yes" active="yes"/>
<layer number="27" name="tValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="28" name="bValues" color="7" fill="1" visible="yes" active="yes"/>
<layer number="29" name="tStop" color="7" fill="3" visible="no" active="yes"/>
<layer number="30" name="bStop" color="7" fill="6" visible="no" active="yes"/>
<layer number="31" name="tCream" color="7" fill="4" visible="no" active="yes"/>
<layer number="32" name="bCream" color="7" fill="5" visible="no" active="yes"/>
<layer number="33" name="tFinish" color="6" fill="3" visible="no" active="yes"/>
<layer number="34" name="bFinish" color="6" fill="6" visible="no" active="yes"/>
<layer number="35" name="tGlue" color="7" fill="4" visible="no" active="yes"/>
<layer number="36" name="bGlue" color="7" fill="5" visible="no" active="yes"/>
<layer number="37" name="tTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="38" name="bTest" color="7" fill="1" visible="no" active="yes"/>
<layer number="39" name="tKeepout" color="4" fill="11" visible="yes" active="yes"/>
<layer number="40" name="bKeepout" color="1" fill="11" visible="yes" active="yes"/>
<layer number="41" name="tRestrict" color="4" fill="10" visible="yes" active="yes"/>
<layer number="42" name="bRestrict" color="1" fill="10" visible="yes" active="yes"/>
<layer number="43" name="vRestrict" color="2" fill="10" visible="yes" active="yes"/>
<layer number="44" name="Drills" color="7" fill="1" visible="no" active="yes"/>
<layer number="45" name="Holes" color="7" fill="1" visible="no" active="yes"/>
<layer number="46" name="Milling" color="3" fill="1" visible="no" active="yes"/>
<layer number="47" name="Measures" color="7" fill="1" visible="no" active="yes"/>
<layer number="48" name="Document" color="7" fill="1" visible="yes" active="yes"/>
<layer number="49" name="Reference" color="7" fill="1" visible="yes" active="yes"/>
<layer number="51" name="tDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="52" name="bDocu" color="7" fill="1" visible="yes" active="yes"/>
<layer number="91" name="Nets" color="2" fill="1" visible="yes" active="yes"/>
<layer number="92" name="Busses" color="1" fill="1" visible="yes" active="yes"/>
<layer number="93" name="Pins" color="2" fill="1" visible="yes" active="yes"/>
<layer number="94" name="Symbols" color="4" fill="1" visible="yes" active="yes"/>
<layer number="95" name="Names" color="7" fill="1" visible="yes" active="yes"/>
<layer number="96" name="Values" color="7" fill="1" visible="yes" active="yes"/>
<layer number="97" name="Info" color="7" fill="1" visible="yes" active="yes"/>
<layer number="98" name="Guide" color="6" fill="1" visible="yes" active="yes"/>
</layers>
<library>
<packages>
<package name="NUMERIC_DISPLAY">
<wire x1="0.13" y1="-0.075" x2="0.13" y2="69.925" width="0.127" layer="21"/>
<wire x1="0.13" y1="69.925" x2="48.13" y2="69.925" width="0.127" layer="21"/>
<wire x1="48.13" y1="69.925" x2="48.13" y2="-0.075" width="0.127" layer="21"/>
<wire x1="48.13" y1="-0.075" x2="0.13" y2="-0.075" width="0.127" layer="21"/>
<wire x1="14.13" y1="63.925" x2="44.03" y2="63.925" width="0.127" layer="21"/>
<wire x1="44.03" y1="63.925" x2="38.13" y2="58.925" width="0.127" layer="21"/>
<wire x1="38.13" y1="58.925" x2="19.13" y2="58.925" width="0.127" layer="21"/>
<wire x1="19.13" y1="58.925" x2="14.13" y2="63.925" width="0.127" layer="21"/>
<wire x1="9.13" y1="34.925" x2="15.23" y2="37.925" width="0.127" layer="21"/>
<wire x1="15.23" y1="37.925" x2="34.23" y2="37.925" width="0.127" layer="21"/>
<wire x1="34.23" y1="37.925" x2="39.13" y2="34.925" width="0.127" layer="21"/>
<wire x1="39.13" y1="34.925" x2="33.03" y2="31.925" width="0.127" layer="21"/>
<wire x1="33.03" y1="31.925" x2="14.13" y2="31.925" width="0.127" layer="21"/>
<wire x1="14.13" y1="31.925" x2="9.13" y2="34.925" width="0.127" layer="21"/>
<wire x1="34.13" y1="5.925" x2="29.13" y2="10.925" width="0.127" layer="21"/>
<wire x1="29.13" y1="10.925" x2="10.13" y2="10.925" width="0.127" layer="21"/>
<wire x1="10.13" y1="10.925" x2="4.13" y2="5.925" width="0.127" layer="21"/>
<wire x1="4.13" y1="5.925" x2="34.13" y2="5.925" width="0.127" layer="21"/>
<wire x1="19.13" y1="58.925" x2="15.23" y2="37.925" width="0.127" layer="21"/>
<wire x1="9.13" y1="34.925" x2="14.13" y2="63.925" width="0.127" layer="21"/>
<wire x1="44.03" y1="63.925" x2="39.13" y2="34.925" width="0.127" layer="21"/>
<wire x1="34.23" y1="37.925" x2="38.13" y2="58.925" width="0.127" layer="21"/>
<wire x1="9.13" y1="34.925" x2="4.13" y2="5.925" width="0.127" layer="21"/>
<wire x1="10.13" y1="10.925" x2="14.13" y2="31.925" width="0.127" layer="21"/>
<wire x1="33.03" y1="31.925" x2="29.13" y2="10.925" width="0.127" layer="21"/>
<wire x1="34.13" y1="5.925" x2="39.13" y2="34.925" width="0.127" layer="21"/>
<circle x="41.13" y="6.925" radius="4" width="0.127" layer="21"/>
<pad name="1" x="19.05" y="4.845" drill="1" shape="long" rot="R90"/>
<pad name="2" x="21.59" y="4.845" drill="1" shape="long" rot="R90"/>
<pad name="3" x="24.13" y="4.845" drill="1" shape="long" rot="R90"/>
<pad name="4" x="26.67" y="4.845" drill="1" shape="long" rot="R90"/>
<pad name="5" x="29.21" y="4.845" drill="1" shape="long" rot="R90"/>
<pad name="6" x="29.21" y="64.905" drill="1" shape="long" rot="R90"/>
<pad name="7" x="26.67" y="64.905" drill="1" shape="long" rot="R90"/>
<pad name="8" x="24.13" y="64.905" drill="1" shape="long" rot="R90"/>
<pad name="9" x="21.59" y="64.905" drill="1" shape="long" rot="R90"/>
<pad name="10" x="19.05" y="64.905" drill="1" shape="long" rot="R90"/>
<text x="27.94" y="60.325" size="1.27" layer="49">a</text>
<text x="38.1" y="47.625" size="1.27" layer="49">b</text>
<text x="33.02" y="22.225" size="1.27" layer="49">c</text>
<text x="18.78" y="8.155" size="1.27" layer="49">d</text>
<text x="8.89" y="22.225" size="1.27" layer="49">e</text>
<text x="13.97" y="47.625" size="1.27" layer="49">f</text>
<text x="24.13" y="34.925" size="1.27" layer="49">g</text>
<text x="40.64" y="12.065" size="1.27" layer="49">DP</text>
<text x="6.35" y="66.675" size="1.27" layer="25">&gt;NAME</text>
<text x="3.81" y="1.905" size="1.27" layer="27">&gt;VALUE</text>
<text x="21.155" y="1.905" size="1.27" layer="49">2</text>
<text x="23.695" y="1.905" size="1.27" layer="49">3</text>
<text x="26.235" y="1.905" size="1.27" layer="49">4</text>
<text x="28.675" y="1.905" size="1.27" layer="49">5</text>
<text x="18.515" y="1.905" size="1.27" layer="49">1</text>
<text x="28.675" y="66.675" size="1.27" layer="49">6</text>
<text x="26.235" y="66.675" size="1.27" layer="49">7</text>
<text x="23.595" y="66.675" size="1.27" layer="49">8</text>
<text x="21.055" y="66.675" size="1.27" layer="49">9</text>
<text x="18.015" y="66.675" size="1.27" layer="49">10</text>
</package>
</packages>
<symbols>
<symbol name="NUMERIC_DISPLAY">
<description>2.3 Inch 7 Segment Display</description>
<wire x1="0" y1="0" x2="2.54" y2="0" width="0.127" layer="94"/>
<wire x1="2.54" y1="0" x2="5.08" y2="0" width="0.127" layer="94"/>
<wire x1="5.08" y1="0" x2="7.62" y2="0" width="0.127" layer="94"/>
<wire x1="7.62" y1="0" x2="10.16" y2="0" width="0.127" layer="94"/>
<wire x1="10.16" y1="0" x2="12.7" y2="0" width="0.127" layer="94"/>
<wire x1="12.7" y1="0" x2="15.24" y2="0" width="0.127" layer="94"/>
<wire x1="15.24" y1="0" x2="17.78" y2="0" width="0.127" layer="94"/>
<wire x1="7.62" y1="0" x2="7.62" y2="3.81" width="0.127" layer="94"/>
<wire x1="10.16" y1="0" x2="10.16" y2="3.81" width="0.127" layer="94"/>
<wire x1="0" y1="0" x2="0" y2="-1.27" width="0.127" layer="94"/>
<wire x1="0" y1="-1.27" x2="0" y2="-2.54" width="0.127" layer="94"/>
<wire x1="0" y1="-2.54" x2="0" y2="-4.445" width="0.127" layer="94"/>
<wire x1="0" y1="-4.445" x2="0" y2="-6.35" width="0.127" layer="94"/>
<wire x1="0" y1="-6.35" x2="0" y2="-8.255" width="0.127" layer="94"/>
<wire x1="0" y1="-8.255" x2="0" y2="-10.16" width="0.127" layer="94"/>
<wire x1="0" y1="-10.16" x2="0" y2="-11.43" width="0.127" layer="94"/>
<wire x1="0" y1="-1.27" x2="-0.635" y2="-1.27" width="0.127" layer="94"/>
<wire x1="0" y1="-1.27" x2="0.635" y2="-1.27" width="0.127" layer="94"/>
<wire x1="-0.635" y1="-1.27" x2="0" y2="-2.54" width="0.127" layer="94"/>
<wire x1="0.635" y1="-1.27" x2="0" y2="-2.54" width="0.127" layer="94"/>
<wire x1="0" y1="-2.54" x2="-0.635" y2="-2.54" width="0.127" layer="94"/>
<wire x1="0" y1="-2.54" x2="0.635" y2="-2.54" width="0.127" layer="94"/>
<wire x1="-0.635" y1="-3.175" x2="0.635" y2="-3.175" width="0.127" layer="94"/>
<wire x1="0.635" y1="-3.175" x2="0" y2="-4.445" width="0.127" layer="94"/>
<wire x1="0" y1="-4.445" x2="-0.635" y2="-3.175" width="0.127" layer="94"/>
<wire x1="-0.635" y1="-4.445" x2="0.635" y2="-4.445" width="0.127" layer="94"/>
<wire x1="-0.635" y1="-5.08" x2="0.635" y2="-5.08" width="0.127" layer="94"/>
<wire x1="0.635" y1="-5.08" x2="0" y2="-6.35" width="0.127" layer="94"/>
<wire x1="0" y1="-6.35" x2="-0.635" y2="-5.08" width="0.127" layer="94"/>
<wire x1="-0.635" y1="-6.35" x2="0.635" y2="-6.35" width="0.127" layer="94"/>
<wire x1="-0.635" y1="-6.985" x2="0.635" y2="-6.985" width="0.127" layer="94"/>
<wire x1="0.635" y1="-6.985" x2="0" y2="-8.255" width="0.127" layer="94"/>
<wire x1="0" y1="-8.255" x2="-0.635" y2="-6.985" width="0.127" layer="94"/>
<wire x1="-0.635" y1="-8.255" x2="0.635" y2="-8.255" width="0.127" layer="94"/>
<wire x1="-0.635" y1="-8.89" x2="0.635" y2="-8.89" width="0.127" layer="94"/>
<wire x1="0.635" y1="-8.89" x2="0" y2="-10.16" width="0.127" layer="94"/>
<wire x1="-0.635" y1="-8.89" x2="0" y2="-10.16" width="0.127" layer="94"/>
<wire x1="0" y1="-10.16" x2="-0.635" y2="-10.16" width="0.127" layer="94"/>
<wire x1="0" y1="-10.16" x2="0.635" y2="-10.16" width="0.127" layer="94"/>
<wire x1="2.54" y1="0" x2="2.54" y2="-2.54" width="0.127" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="2.54" y2="-4.445" width="0.127" layer="94"/>
<wire x1="2.54" y1="-4.445" x2="2.54" y2="-6.35" width="0.127" layer="94"/>
<wire x1="2.54" y1="-6.35" x2="2.54" y2="-8.255" width="0.127" layer="94"/>
<wire x1="2.54" y1="-8.255" x2="2.54" y2="-10.16" width="0.127" layer="94"/>
<wire x1="2.54" y1="-10.16" x2="2.54" y2="-11.43" width="0.127" layer="94"/>
<wire x1="1.905" y1="-1.27" x2="3.175" y2="-1.27" width="0.127" layer="94"/>
<wire x1="3.175" y1="-1.27" x2="2.54" y2="-2.54" width="0.127" layer="94"/>
<wire x1="1.905" y1="-1.27" x2="2.54" y2="-2.54" width="0.127" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="1.905" y2="-2.54" width="0.127" layer="94"/>
<wire x1="2.54" y1="-2.54" x2="3.175" y2="-2.54" width="0.127" layer="94"/>
<wire x1="1.905" y1="-3.175" x2="3.175" y2="-3.175" width="0.127" layer="94"/>
<wire x1="3.175" y1="-3.175" x2="2.54" y2="-4.445" width="0.127" layer="94"/>
<wire x1="2.54" y1="-4.445" x2="1.905" y2="-3.175" width="0.127" layer="94"/>
<wire x1="1.905" y1="-4.445" x2="3.175" y2="-4.445" width="0.127" layer="94"/>
<wire x1="1.905" y1="-5.08" x2="3.175" y2="-5.08" width="0.127" layer="94"/>
<wire x1="3.175" y1="-5.08" x2="2.54" y2="-6.35" width="0.127" layer="94"/>
<wire x1="2.54" y1="-6.35" x2="1.905" y2="-5.08" width="0.127" layer="94"/>
<wire x1="1.905" y1="-6.35" x2="3.175" y2="-6.35" width="0.127" layer="94"/>
<wire x1="1.905" y1="-6.985" x2="3.175" y2="-6.985" width="0.127" layer="94"/>
<wire x1="3.175" y1="-6.985" x2="2.54" y2="-8.255" width="0.127" layer="94"/>
<wire x1="2.54" y1="-8.255" x2="1.905" y2="-6.985" width="0.127" layer="94"/>
<wire x1="1.905" y1="-8.255" x2="3.175" y2="-8.255" width="0.127" layer="94"/>
<wire x1="1.905" y1="-8.89" x2="3.175" y2="-8.89" width="0.127" layer="94"/>
<wire x1="3.175" y1="-8.89" x2="2.54" y2="-10.16" width="0.127" layer="94"/>
<wire x1="2.54" y1="-10.16" x2="1.905" y2="-8.89" width="0.127" layer="94"/>
<wire x1="1.905" y1="-10.16" x2="3.175" y2="-10.16" width="0.127" layer="94"/>
<wire x1="5.08" y1="0" x2="5.08" y2="-2.54" width="0.127" layer="94"/>
<wire x1="5.08" y1="-2.54" x2="5.08" y2="-4.445" width="0.127" layer="94"/>
<wire x1="5.08" y1="-4.445" x2="5.08" y2="-6.35" width="0.127" layer="94"/>
<wire x1="5.08" y1="-6.35" x2="5.08" y2="-8.255" width="0.127" layer="94"/>
<wire x1="5.08" y1="-8.255" x2="5.08" y2="-10.16" width="0.127" layer="94"/>
<wire x1="5.08" y1="-10.16" x2="5.08" y2="-11.43" width="0.127" layer="94"/>
<wire x1="4.445" y1="-1.27" x2="5.715" y2="-1.27" width="0.127" layer="94"/>
<wire x1="5.715" y1="-1.27" x2="5.08" y2="-2.54" width="0.127" layer="94"/>
<wire x1="5.08" y1="-2.54" x2="4.445" y2="-1.27" width="0.127" layer="94"/>
<wire x1="4.445" y1="-2.54" x2="5.715" y2="-2.54" width="0.127" layer="94"/>
<wire x1="4.445" y1="-3.175" x2="5.715" y2="-3.175" width="0.127" layer="94"/>
<wire x1="5.715" y1="-3.175" x2="5.08" y2="-4.445" width="0.127" layer="94"/>
<wire x1="5.08" y1="-4.445" x2="4.445" y2="-3.175" width="0.127" layer="94"/>
<wire x1="4.445" y1="-4.445" x2="5.715" y2="-4.445" width="0.127" layer="94"/>
<wire x1="4.445" y1="-5.08" x2="5.715" y2="-5.08" width="0.127" layer="94"/>
<wire x1="5.715" y1="-5.08" x2="5.08" y2="-6.35" width="0.127" layer="94"/>
<wire x1="5.08" y1="-6.35" x2="4.445" y2="-5.08" width="0.127" layer="94"/>
<wire x1="4.445" y1="-6.35" x2="5.715" y2="-6.35" width="0.127" layer="94"/>
<wire x1="4.445" y1="-6.985" x2="5.715" y2="-6.985" width="0.127" layer="94"/>
<wire x1="5.715" y1="-6.985" x2="5.08" y2="-8.255" width="0.127" layer="94"/>
<wire x1="5.08" y1="-8.255" x2="4.445" y2="-6.985" width="0.127" layer="94"/>
<wire x1="4.445" y1="-8.255" x2="5.715" y2="-8.255" width="0.127" layer="94"/>
<wire x1="4.445" y1="-8.89" x2="5.715" y2="-8.89" width="0.127" layer="94"/>
<wire x1="5.715" y1="-8.89" x2="5.08" y2="-10.16" width="0.127" layer="94"/>
<wire x1="5.08" y1="-10.16" x2="4.445" y2="-8.89" width="0.127" layer="94"/>
<wire x1="4.445" y1="-10.16" x2="5.715" y2="-10.16" width="0.127" layer="94"/>
<wire x1="7.62" y1="0" x2="7.62" y2="-2.54" width="0.127" layer="94"/>
<wire x1="7.62" y1="-2.54" x2="7.62" y2="-4.445" width="0.127" layer="94"/>
<wire x1="7.62" y1="-4.445" x2="7.62" y2="-6.35" width="0.127" layer="94"/>
<wire x1="7.62" y1="-6.35" x2="7.62" y2="-8.255" width="0.127" layer="94"/>
<wire x1="7.62" y1="-8.255" x2="7.62" y2="-10.16" width="0.127" layer="94"/>
<wire x1="7.62" y1="-10.16" x2="7.62" y2="-11.43" width="0.127" layer="94"/>
<wire x1="6.985" y1="-1.27" x2="8.255" y2="-1.27" width="0.127" layer="94"/>
<wire x1="8.255" y1="-1.27" x2="7.62" y2="-2.54" width="0.127" layer="94"/>
<wire x1="7.62" y1="-2.54" x2="6.985" y2="-1.27" width="0.127" layer="94"/>
<wire x1="6.985" y1="-2.54" x2="8.255" y2="-2.54" width="0.127" layer="94"/>
<wire x1="6.985" y1="-3.175" x2="8.255" y2="-3.175" width="0.127" layer="94"/>
<wire x1="8.255" y1="-3.175" x2="7.62" y2="-4.445" width="0.127" layer="94"/>
<wire x1="7.62" y1="-4.445" x2="6.985" y2="-3.175" width="0.127" layer="94"/>
<wire x1="6.985" y1="-4.445" x2="8.255" y2="-4.445" width="0.127" layer="94"/>
<wire x1="6.985" y1="-5.08" x2="8.255" y2="-5.08" width="0.127" layer="94"/>
<wire x1="8.255" y1="-5.08" x2="7.62" y2="-6.35" width="0.127" layer="94"/>
<wire x1="7.62" y1="-6.35" x2="6.985" y2="-5.08" width="0.127" layer="94"/>
<wire x1="6.985" y1="-6.35" x2="8.255" y2="-6.35" width="0.127" layer="94"/>
<wire x1="6.985" y1="-6.985" x2="8.255" y2="-6.985" width="0.127" layer="94"/>
<wire x1="8.255" y1="-6.985" x2="7.62" y2="-8.255" width="0.127" layer="94"/>
<wire x1="7.62" y1="-8.255" x2="6.985" y2="-6.985" width="0.127" layer="94"/>
<wire x1="6.985" y1="-8.255" x2="8.255" y2="-8.255" width="0.127" layer="94"/>
<wire x1="6.985" y1="-8.89" x2="8.255" y2="-8.89" width="0.127" layer="94"/>
<wire x1="8.255" y1="-8.89" x2="7.62" y2="-10.16" width="0.127" layer="94"/>
<wire x1="7.62" y1="-10.16" x2="6.985" y2="-8.89" width="0.127" layer="94"/>
<wire x1="6.985" y1="-10.16" x2="8.255" y2="-10.16" width="0.127" layer="94"/>
<wire x1="10.16" y1="0" x2="10.16" y2="-2.54" width="0.127" layer="94"/>
<wire x1="10.16" y1="-2.54" x2="10.16" y2="-4.445" width="0.127" layer="94"/>
<wire x1="10.16" y1="-4.445" x2="10.16" y2="-6.35" width="0.127" layer="94"/>
<wire x1="10.16" y1="-6.35" x2="10.16" y2="-8.255" width="0.127" layer="94"/>
<wire x1="10.16" y1="-8.255" x2="10.16" y2="-10.16" width="0.127" layer="94"/>
<wire x1="10.16" y1="-10.16" x2="10.16" y2="-11.43" width="0.127" layer="94"/>
<wire x1="9.525" y1="-1.27" x2="10.795" y2="-1.27" width="0.127" layer="94"/>
<wire x1="10.795" y1="-1.27" x2="10.16" y2="-2.54" width="0.127" layer="94"/>
<wire x1="10.16" y1="-2.54" x2="9.525" y2="-1.27" width="0.127" layer="94"/>
<wire x1="9.525" y1="-2.54" x2="10.795" y2="-2.54" width="0.127" layer="94"/>
<wire x1="9.525" y1="-3.175" x2="10.795" y2="-3.175" width="0.127" layer="94"/>
<wire x1="10.795" y1="-3.175" x2="10.16" y2="-4.445" width="0.127" layer="94"/>
<wire x1="10.16" y1="-4.445" x2="9.525" y2="-3.175" width="0.127" layer="94"/>
<wire x1="9.525" y1="-4.445" x2="10.795" y2="-4.445" width="0.127" layer="94"/>
<wire x1="9.525" y1="-5.08" x2="10.795" y2="-5.08" width="0.127" layer="94"/>
<wire x1="10.795" y1="-5.08" x2="10.16" y2="-6.35" width="0.127" layer="94"/>
<wire x1="10.16" y1="-6.35" x2="9.525" y2="-5.08" width="0.127" layer="94"/>
<wire x1="9.525" y1="-6.35" x2="10.795" y2="-6.35" width="0.127" layer="94"/>
<wire x1="9.525" y1="-6.985" x2="10.795" y2="-6.985" width="0.127" layer="94"/>
<wire x1="10.795" y1="-6.985" x2="10.16" y2="-8.255" width="0.127" layer="94"/>
<wire x1="10.16" y1="-8.255" x2="9.525" y2="-6.985" width="0.127" layer="94"/>
<wire x1="9.525" y1="-8.255" x2="10.795" y2="-8.255" width="0.127" layer="94"/>
<wire x1="9.525" y1="-8.89" x2="10.795" y2="-8.89" width="0.127" layer="94"/>
<wire x1="10.795" y1="-8.89" x2="10.16" y2="-10.16" width="0.127" layer="94"/>
<wire x1="10.16" y1="-10.16" x2="9.525" y2="-8.89" width="0.127" layer="94"/>
<wire x1="9.525" y1="-10.16" x2="10.795" y2="-10.16" width="0.127" layer="94"/>
<wire x1="12.7" y1="0" x2="12.7" y2="-2.54" width="0.127" layer="94"/>
<wire x1="12.7" y1="-2.54" x2="12.7" y2="-4.445" width="0.127" layer="94"/>
<wire x1="12.7" y1="-4.445" x2="12.7" y2="-6.35" width="0.127" layer="94"/>
<wire x1="12.7" y1="-6.35" x2="12.7" y2="-8.255" width="0.127" layer="94"/>
<wire x1="12.7" y1="-8.255" x2="12.7" y2="-10.16" width="0.127" layer="94"/>
<wire x1="12.7" y1="-10.16" x2="12.7" y2="-11.43" width="0.127" layer="94"/>
<wire x1="12.065" y1="-1.27" x2="13.335" y2="-1.27" width="0.127" layer="94"/>
<wire x1="13.335" y1="-1.27" x2="12.7" y2="-2.54" width="0.127" layer="94"/>
<wire x1="12.7" y1="-2.54" x2="12.065" y2="-1.27" width="0.127" layer="94"/>
<wire x1="12.065" y1="-2.54" x2="13.335" y2="-2.54" width="0.127" layer="94"/>
<wire x1="12.065" y1="-3.175" x2="13.335" y2="-3.175" width="0.127" layer="94"/>
<wire x1="13.335" y1="-3.175" x2="12.7" y2="-4.445" width="0.127" layer="94"/>
<wire x1="12.7" y1="-4.445" x2="12.065" y2="-3.175" width="0.127" layer="94"/>
<wire x1="12.065" y1="-4.445" x2="13.335" y2="-4.445" width="0.127" layer="94"/>
<wire x1="12.065" y1="-5.08" x2="13.335" y2="-5.08" width="0.127" layer="94"/>
<wire x1="13.335" y1="-5.08" x2="12.7" y2="-6.35" width="0.127" layer="94"/>
<wire x1="12.7" y1="-6.35" x2="12.065" y2="-5.08" width="0.127" layer="94"/>
<wire x1="12.065" y1="-6.35" x2="13.335" y2="-6.35" width="0.127" layer="94"/>
<wire x1="12.065" y1="-6.985" x2="13.335" y2="-6.985" width="0.127" layer="94"/>
<wire x1="13.335" y1="-6.985" x2="12.7" y2="-8.255" width="0.127" layer="94"/>
<wire x1="12.7" y1="-8.255" x2="12.065" y2="-6.985" width="0.127" layer="94"/>
<wire x1="12.065" y1="-8.255" x2="13.335" y2="-8.255" width="0.127" layer="94"/>
<wire x1="12.065" y1="-8.89" x2="13.335" y2="-8.89" width="0.127" layer="94"/>
<wire x1="13.335" y1="-8.89" x2="12.7" y2="-10.16" width="0.127" layer="94"/>
<wire x1="12.7" y1="-10.16" x2="12.065" y2="-8.89" width="0.127" layer="94"/>
<wire x1="12.065" y1="-10.16" x2="13.335" y2="-10.16" width="0.127" layer="94"/>
<wire x1="15.24" y1="0" x2="15.24" y2="-2.54" width="0.127" layer="94"/>
<wire x1="15.24" y1="-2.54" x2="15.24" y2="-4.445" width="0.127" layer="94"/>
<wire x1="15.24" y1="-4.445" x2="15.24" y2="-6.35" width="0.127" layer="94"/>
<wire x1="15.24" y1="-6.35" x2="15.24" y2="-8.255" width="0.127" layer="94"/>
<wire x1="15.24" y1="-8.255" x2="15.24" y2="-10.16" width="0.127" layer="94"/>
<wire x1="15.24" y1="-10.16" x2="15.24" y2="-11.43" width="0.127" layer="94"/>
<wire x1="14.605" y1="-1.27" x2="15.875" y2="-1.27" width="0.127" layer="94"/>
<wire x1="15.875" y1="-1.27" x2="15.24" y2="-2.54" width="0.127" layer="94"/>
<wire x1="14.605" y1="-1.27" x2="15.24" y2="-2.54" width="0.127" layer="94"/>
<wire x1="14.605" y1="-2.54" x2="15.875" y2="-2.54" width="0.127" layer="94"/>
<wire x1="14.605" y1="-3.175" x2="15.875" y2="-3.175" width="0.127" layer="94"/>
<wire x1="15.875" y1="-3.175" x2="15.24" y2="-4.445" width="0.127" layer="94"/>
<wire x1="15.24" y1="-4.445" x2="14.605" y2="-3.175" width="0.127" layer="94"/>
<wire x1="14.605" y1="-4.445" x2="15.875" y2="-4.445" width="0.127" layer="94"/>
<wire x1="14.605" y1="-5.08" x2="15.875" y2="-5.08" width="0.127" layer="94"/>
<wire x1="15.875" y1="-5.08" x2="15.24" y2="-6.35" width="0.127" layer="94"/>
<wire x1="15.24" y1="-6.35" x2="14.605" y2="-5.08" width="0.127" layer="94"/>
<wire x1="14.605" y1="-6.35" x2="15.875" y2="-6.35" width="0.127" layer="94"/>
<wire x1="14.605" y1="-6.985" x2="15.875" y2="-6.985" width="0.127" layer="94"/>
<wire x1="15.875" y1="-6.985" x2="15.24" y2="-8.255" width="0.127" layer="94"/>
<wire x1="15.24" y1="-8.255" x2="14.605" y2="-6.985" width="0.127" layer="94"/>
<wire x1="14.605" y1="-8.255" x2="15.875" y2="-8.255" width="0.127" layer="94"/>
<wire x1="14.605" y1="-8.89" x2="15.875" y2="-8.89" width="0.127" layer="94"/>
<wire x1="15.875" y1="-8.89" x2="15.24" y2="-10.16" width="0.127" layer="94"/>
<wire x1="15.24" y1="-10.16" x2="14.605" y2="-8.89" width="0.127" layer="94"/>
<wire x1="14.605" y1="-10.16" x2="15.875" y2="-10.16" width="0.127" layer="94"/>
<wire x1="17.78" y1="0" x2="17.78" y2="-2.54" width="0.127" layer="94"/>
<wire x1="17.78" y1="-2.54" x2="17.78" y2="-4.445" width="0.127" layer="94"/>
<wire x1="17.78" y1="-4.445" x2="17.78" y2="-11.43" width="0.127" layer="94"/>
<wire x1="17.145" y1="-1.27" x2="18.415" y2="-1.27" width="0.127" layer="94"/>
<wire x1="18.415" y1="-1.27" x2="17.78" y2="-2.54" width="0.127" layer="94"/>
<wire x1="17.78" y1="-2.54" x2="17.145" y2="-1.27" width="0.127" layer="94"/>
<wire x1="17.145" y1="-2.54" x2="18.415" y2="-2.54" width="0.127" layer="94"/>
<wire x1="17.145" y1="-3.175" x2="18.415" y2="-3.175" width="0.127" layer="94"/>
<wire x1="18.415" y1="-3.175" x2="17.78" y2="-4.445" width="0.127" layer="94"/>
<wire x1="17.78" y1="-4.445" x2="17.145" y2="-3.175" width="0.127" layer="94"/>
<wire x1="17.145" y1="-4.445" x2="18.415" y2="-4.445" width="0.127" layer="94"/>
<text x="0" y="0.635" size="1.27" layer="97">a</text>
<text x="2.54" y="0.635" size="1.27" layer="97">b</text>
<text x="5.08" y="0.635" size="1.27" layer="97">c</text>
<text x="7.62" y="0.635" size="1.27" layer="97">d</text>
<text x="10.16" y="0.635" size="1.27" layer="97">e</text>
<text x="12.7" y="0.635" size="1.27" layer="97">f</text>
<text x="15.24" y="0.635" size="1.27" layer="97">g</text>
<text x="17.145" y="0.635" size="1.27" layer="97">DP</text>
<text x="0.635" y="2.54" size="1.27" layer="95">&gt;NAME</text>
<text x="12.7" y="2.54" size="1.27" layer="96">&gt;VALUE</text>
<pin name="P$E2" x="10.16" y="-11.43" visible="off" length="point" swaplevel="1"/>
<pin name="P$D3" x="7.62" y="-11.43" visible="off" length="point" swaplevel="1"/>
<pin name="P$1" x="7.62" y="3.81" visible="off" length="point" swaplevel="1"/>
<pin name="P$C4" x="5.08" y="-11.43" visible="off" length="point" swaplevel="1"/>
<pin name="P$DP8" x="17.78" y="-11.43" visible="off" length="point" swaplevel="1"/>
<pin name="P$B6" x="2.54" y="-11.43" visible="off" length="point" swaplevel="1"/>
<pin name="P$A7" x="0" y="-11.43" visible="off" length="point" swaplevel="1"/>
<pin name="P$5" x="10.16" y="3.81" visible="off" length="point" swaplevel="1"/>
<pin name="P$F9" x="12.7" y="-11.43" visible="off" length="point" swaplevel="1"/>
<pin name="P$1G0" x="15.24" y="-11.43" visible="off" length="point" swaplevel="1"/>
</symbol>
</symbols>
<devicesets>
<deviceset name="NUMERIC_DISPLAY" prefix="ND" uservalue="yes">
<description>SA23-11SRWA single digit numeric display</description>
<gates>
<gate name="G$1" symbol="NUMERIC_DISPLAY" x="-17.78" y="-5.08" swaplevel="1"/>
</gates>
<devices>
<device name="" package="NUMERIC_DISPLAY">
<connects>
<connect gate="G$1" pin="P$1" pad="1"/>
<connect gate="G$1" pin="P$1G0" pad="10"/>
<connect gate="G$1" pin="P$5" pad="5"/>
<connect gate="G$1" pin="P$A7" pad="7"/>
<connect gate="G$1" pin="P$B6" pad="6"/>
<connect gate="G$1" pin="P$C4" pad="4"/>
<connect gate="G$1" pin="P$D3" pad="3"/>
<connect gate="G$1" pin="P$DP8" pad="8"/>
<connect gate="G$1" pin="P$E2" pad="2"/>
<connect gate="G$1" pin="P$F9" pad="9"/>
</connects>
<technologies>
<technology name=""/>
</technologies>
</device>
</devices>
</deviceset>
</devicesets>
</library>
</drawing>
</eagle>
